[Live-demo] [OSGeo] #1636: QGIS Server fails to work after QGIS upgrade to 2.14 LTR
OSGeo
trac_osgeo at osgeo.org
Sat Mar 5 02:48:54 PST 2016
Reporter: kalxas | Owner: live-demo@…
Type: defect | Status: new
Priority: major | Milestone: Unplanned
Component: LiveDVD | Keywords: qgis server
QGIS 2.14.0 LTR was released few days ago.
Since we are very close to the OSGeoLive 9.5 release I did not upgrade to
it right away, rather I pulled the deb package to our staging ppa and re-
built it to test.
https://launchpad.net/~gcpp-kalxas/+archive/ubuntu/osgeolive/+packages
Then I did a nightly build based on that staging ppa to see how things
are.
http://aiolos.survey.ntua.gr/gisvm/dev/osgeo-live-nightly-
build168-amd64-e572448.iso
QGIS Desktop works flawlessly.
QGIS Server though fails to work due to this apache error:
[Sat Mar 05 09:33:10.320224 2016] [core:notice] [pid 5062] AH00094:
Command line: '/usr/sbin/apache2'
QFSFileEngine::open: No file name specified
Warning 1: Unable to find driver ECW to unload from GDAL_SKIP environment
variable.
variable.
Warning 1: Unable to find driver JP2ECW to unload from GDAL_SKIP
environment variable.
variable.
ERROR: Auth db directory path could not be created
variable.
variable.
variable.
[Sat Mar 05 10:42:45.144576 2016] [fcgid:warn] [pid 5076] [client
127.0.0.1:57996] mod_fcgid: error reading data, FastCGI server closed
connection
[Sat Mar 05 10:42:45.144604 2016] [core:error] [pid 5076] [client
127.0.0.1:57996] End of script output before headers: qgis_mapserv.fcgi
[Sat Mar 05 10:42:47.741248 2016] [fcgid:warn] [pid 5074] [client
127.0.0.1:57995] mod_fcgid: error reading data, FastCGI server closed
connection
[Sat Mar 05 10:42:47.741266 2016] [core:error] [pid 5074] [client
127.0.0.1:57995] End of script output before headers: qgis_mapserv.fcgi
[Sat Mar 05 10:42:50.905775 2016] [fcgid:error] [pid 5065] mod_fcgid:
process /usr/lib/cgi-bin/qgis_mapserv.fcgi(6447) exit(communication
error), get signal 6, possible coredump generated
[Sat Mar 05 10:42:50.905847 2016] [fcgid:error] [pid 5065] mod_fcgid:
process /usr/lib/cgi-bin/qgis_mapserv.fcgi(6455) exit(communication
I have been bugging the QGIS maintainers about this error for a few days:
and this post seems relevant:
http://lists.osgeo.org/pipermail/qgis-user/2015-October/034050.html
I tried to create the QGIS_AUTH_DB_DIR_PATH in the FastCGI Apache
configuration but no luck, the error persists...
It would be nice for once to have the latest release of QGIS included in
OSGeo-Live 9.5 since our release schedules synced :)
Any suggestions/thoughts/pull requests are welcome...
Best,
Angelos
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1636>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo
