[Live-demo] [OSGeo] #1645: Rasdaman not installed on 32 bit system
    OSGeo
    trac_osgeo at osgeo.org
    Mon Mar 14 12:40:32 PDT 2016
 Reporter:  kalxas   |      Owner:  live-demo@…
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  OSGeoLive9.5
Component:  LiveDVD  |   Keywords:
 Unfortunately we failed to test the new rasdaman installer on 32 bit
 environment. It seems that the installer did not have the i386 binaries
 until now.
 Alex Dumitru is working to provide the 32 bit binaries ASAP.
 Hopefully we can fix this in RC2 (at least for the 32 bit iso).
 Starting "install_rasdaman.sh" ...
 --2016-03-14 12:42:17--  http://download.rasdaman.org/installer/install.sh
 Resolving download.rasdaman.org (download.rasdaman.org)... 212.201.49.173
 Connecting to download.rasdaman.org
 (download.rasdaman.org)|212.201.49.173|:80... connected.
 HTTP request sent, awaiting response... 200 OK
 Length: 8871 (8.7K) [text/x-sh]
 Saving to: 'install.sh'
      0K ........                                              100%
 8.25M=0.001s
 2016-03-14 12:42:17 (8.25 MB/s) - 'install.sh' saved [8871/8871]
 [0mChecking if installer needs to update...[0m
 [0mInstaller is at latest version.[0m
 [0mStrategy building is handled by the General Strategy Builder.[0m
 [1mReview the installation settings:[0m
 [0m
 Installation path: /opt/rasdaman/
 Version: master
 Update: False
 User: user
 Debug: False
 Communication protocol: rasnet
 Database type: sqlite
   Database data directory: /opt/rasdaman/data/
 Rasdaman binary:
 http://download.rasdaman.org/packages/binary/rasdaman.tar.gz
 Petascope enabled: True
   Petascope database url: jdbc:postgresql://localhost:5432/petascopedb
   Petascope database user: user
   Petascope server type: tomcat
   Tomcat home: /var/lib/tomcat7/
 Secore enabled: True
 Run systemtest: False
 Rasdaman demo data: False
 Petascope demo data: False
 [0m
 [1mValidating system...[0m
 [0mCleaning up any old rasdaman files...[0m
 [0mOld rasdaman files cleaned up successfully.[0m
 [1mSystem was validated.[0m
 [1mInstalling third party dependencies...[0m
 [0mChecking user user....[0m
 [0mUser user checked successfully.[0m
 [0mCreating directory structure...[0m
 [0mDirectory structure created successfully.[0m
 [0mInstalling deb packages ['make', 'zlib1g', 'zlib1g-dev', 'automake',
 'autotools-dev', 'libtool', 'm4', 'gawk', 'bison', 'flex', 'git-core',
 'g++', 'libncurses5-dev', 'libtiff-dev', 'libgdal-dev', 'gdal-bin',
 'libnetpbm10-dev', 'libjpeg-dev', 'libpng-dev', 'libffi-dev',
 'postgresql', 'postgresql-contrib', 'libedit-dev', 'libecpg-dev',
 'libsqlite-dev', 'sqlite3', 'python-dateutil', 'python-lxml', 'python-
 pip', 'python-gdal', 'libboost-all-dev', 'openjdk-7-jdk', 'python-pip',
 'unzip', 'tomcat7']... [0m
 [0mDeb packages installed successfully[0m
 [0mInstalling pip packages ['glob2']... [0m
 [0mPip packages installed successfully[0m
 [0mSetting up the PATH environment variable...[0m
 [0mThe PATH environment variable was set up successfully.[0m
 [0mAdding the current user to tomcat user group...[0m
 [0mUser user added to tomcat user group successfully.[0m
 [0mIncreasing tomcat memory limit...[0m
 [0mTomcat memory increased succesfully.[0m
 [1mThird party dependencies installed successfully.[0m
 [1mRetrieving rasdaman...[0m
 [1mRasdaman retrieved successfully[0m
 [1mBuilding rasdaman...[0m
 [0mDownloading and installing rasdaman binaries...[0m
 [0mDownloaded and installed rasdaman binaries successfully[0m
 [0mDownloading and deploying petascope war...[0m
 [0mDownloaded and installed petascope war...[0m
 [0mDownloading and deploying secore war...[0m
 [0mDownloaded and installed secore war...[0m
 [1mRasdaman was built successfully.[0m
 [1mPreparing rasdaman...[0m
 [0mPreparing Rasdaman SQLite database...[0m
 [31mAn error has occured while executing this command:
 /opt/rasdaman//bin/create_db.sh. We collected the following information:
 Return code: 1
 Stderr: create_db.sh: Error: cannot find rasdl - PATH variable does not
 contain rasdaman path?
 Stdout:create_db.sh: Creating database, rasdaman v9.2 on base DBMS sqlite
 /opt/rasdaman//bin/create_db.sh: line 79: /opt/rasdaman/bin/rasdl: cannot
 execute binary file: Exec format error
 [0m
 ERROR: The installer returned an error code. The installation might not be
 valid.
 rasdaman: unrecognized service
  * Stopping Tomcat servlet engine tomcat7
    ...done.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1645>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo
