[Live-demo] PyWPS application
Cameron Shorter
cameron.shorter at gmail.com
Fri May 13 04:25:34 PDT 2016
Tom,
Based on your description below, it seems like pyWPS would be a good
addition to OSGeo-Live.
A few questions/comments:
* I'm not sure that you completed question about using OSGeo-Live
existing datasets? What are your thoughts there?
* It appears there is no GUI interface to the WPS? The lack of a GUI
makes pyWPS appear less polished and I suspect will limit potential
uses. You could start with a HTML web page which provides template WPS
queries and displays the response. You might want to look at the
GeoServer web interface for inspiration.
I think PyWPS could still be included on OSGeo-Live without the GUI, but
I suggest aiming to put a GUI in place before completing OSGeo Incubation.
I'm +1 for inviting PyWPS to join OSGeo-Live.
Warm regards, Cameron
On 13/05/2016 8:18 pm, Tom Kralidis wrote:
> Hi all: below is the application for PyWPS for inclusion into OSGeo Live. If
> it helps, the below can also be found at [1].
> If you have any questions or comments, feel free to contact me.
> Thanks
> ..Tom
> [1] https://github.com/geopython/pywps/wiki/OSGeoLiveApplication
> Please describe your application.
> What is its name? PyWPS
> What is the home page URL? http://pywps.org
> Which OSI approved Open Source Licence is used? GPL for PyWPS 3.x.
> Note that PyWPS 4 (in development) is a rewrite and will be available
> under MIT
> What does the application do and how does it add value to the
> GeoSpatial stack of software? PyWPS provides an OGC WPS server
> implementation written in Python. PyWPS allows for processes to be
> exposed, discovered and executed in support of geospatial workflows
> Does the application make use of OGC standards? Which versions of the
> standards? Client or server? You may wish to add comments about how
> standards are used. PyWPS implements OGC WPS 1.0.0 (2.0.0 in
> development)
> What language is it written in? Python
> Which version of the application should be included in the next
> OSGeo-Live release? 3.2.5
> Stability is very important to us on OSGeo-Live. If a new user finds a
> bug in one application, it will tarnish the reputation of all other
> OSGeo-Live applications as well. (We pay most attention to the
> following answers):
> If risk adverse organisations have deployed your application into
> production, it would imply that these organisations have verified the
> stability of your software. Has the application been rolled out to
> production into risk (ideally risk adverse) organisations? Please
> mention some of these organisations? The Meteorological Service of
> Canada, the WMO WOUDC project, Department of Earth Observation at the
> Friedrich-Schiller University Jena (Germany), International Union of
> Soil Sciences, NASA (JPL), UNEP/GRID, Luxembourg Institute of Science
> and Technology (LIST)
> Open HUB provides metrics to help assess the health of a project. Eg:
> http://adhoc.osgeo.osuosl.org/livedvd/docs/en/metrics.html Could you
> please ensure that your project is registered with Open HUB, and Open
> HUB has been updated to reference the correct code repository(s) for
> your project. What is the Open HUB URL for your project?
> https://www.openhub.net/p/PyWPS
> What is the size of the user community? You can often answer this by
> mentioning downloads, or describing a healthy, busy email list? In
> 2016 the PyWPS mailing list received 250 messages, averaging almost 2
> messages per day. So far, 17 different individuals have subscribed the
> contribution agreement. The pywps-3 repository has been forked 43
> times and the pywps-4 repository has 17 forks.
> What is the size of your developer community (5-6 core developers)
> Do you have a bug free, stable release? yes
> Please discuss the level of testing that your project has gone
> through. PyWPS has regression testing. Bugs/issues are managed via
> GitHub and triaged accordingly
> How long has the project has had mature code. Started in 2006, PyWPS
> has had stable releases since 2008 with PyWPS 3.0.0
> OSGeo-Live is targeted at applications that people can use rather than
> libraries. Does the application have a user interface (possibly a
> command line interface) that a user can interact with? (We do make an
> exception for Incubated OSGeo Libraries, and will include Project
> Overviews for these libraries, even if they don't have a user
> interface.). PyWPS is configurable via the command line and
> configuration files. PyWPS does not have a graphical user interface
> We give preference to OSGeo Incubated Projects, or Projects which are
> presented at FOSS4G conferences. If your project is involved in OSGeo
> Incubation, or has been selected to be presented at FOSS4G, then
> please mention it. PyWPS is currently working through the OSGeo
> incubation process
> With around 50 applications installed on OSGeo-Live, us core packagers
> do not have the time to liaise with every single project email list
> for each OSGeo-Live release. So we require a volunteer (or two) to
> take responsibility for liaising between OSGeo-Live and the project's
> communities. This volunteer will be responsible for ensuring the
> install scripts and English documentation are updated by someone for
> each OSGeo-Live release. Also test that the installed application and
> Quickstart documentation works as expected on release candidate
> releases of OSGeo-Live. Who will act as the project's liaison person.
> Tom Kralidis
> OSGeo-Live is Ubuntu Linux based. Our installation preference is:
> Install from UbuntuGIS or DebianGIS Install .deb files from a PPA or
> Write a custom install script. Can you please discuss how your
> application will be installed. via UbuntuGIS and install script with
> configuration
> OSGeo-Live is memory and disk constrained. Can the application run in
> 512 Meg of RAM? Yes
> How much disk space will be required to install the application and a
> suitable example application? ~ 250KB
> We aim to reduce disk space by having all applications make use of a
> common dataset. We encourage applications to make use of the example
> datasets already installed:
> http://wiki.osgeo.org/wiki/Live_GIS_Add_Project#Example_Datasets If
> another dataset would be more appropriate, please discuss here. Is it
> appropriate, to remove existing demo datasets which may already be
> included in the standard release.
> Each OSGeo-Live application requires a Project Overview available
> under a CC By and a Quickstart available under a CC By-SA license.
> (You may release under a second license as well). Will you produce
> this? Yes
> In past releases, we have included Windows and Mac installers for some
> applications. It is likely we won't have space for these in future
> releases. However, if there is room, would you be wishing to include
> Windows and/or Mac installers? Yes, this is feasible given the very
> nature of Python
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://live.osgeo.org
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
Cameron Shorter,
Software and Data Solutions Manager
LISAsoft
Suite 112, Jones Bay Wharf,
26 - 32 Pirrama Rd, Pyrmont NSW 2009
P +61 2 9009 5000, W www.lisasoft.com, F +61 2 9009 5099
More information about the Live-demo
