[Live-demo] [OSGeo] #1442: GeoNode fails to load demo vector layers
OSGeo
trac_osgeo at osgeo.org
Mon Feb 27 14:04:13 PST 2017
Reporter: kalxas | Owner: live-demo@…
Type: defect | Status: reopened
Priority: major | Milestone: OSGeoLive10.5
Component: LiveDVD | Resolution:
Keywords: |
Comment (by kalxas):
Updating GeoNode layers...
2017-02-23 11:52:03.374:INFO:geoserver:qtp1685538367-17: Initializing
Spring FrameworkServlet 'dispatcher'
23 Feb 11:52:04 INFO [org.geoserver] - Loaded feature type 'streams',
enabled
23 Feb 11:52:04 INFO [catalog.rest] - PUT FeatureTypesf,streams updated
metadata only
23 Feb 11:52:04 INFO [org.geoserver] - Loaded feature type 'roads',
enabled
23 Feb 11:52:04 INFO [catalog.rest] - PUT FeatureTypesf,roads updated
metadata only
23 Feb 11:52:04 INFO [org.geoserver] - Loaded feature type 'restricted',
enabled
23 Feb 11:52:04 INFO [catalog.rest] - PUT FeatureTypesf,restricted updated
metadata only
23 Feb 11:52:04 INFO [org.geoserver] - Loaded feature type 'bugsites',
enabled
23 Feb 11:52:04 INFO [catalog.rest] - PUT FeatureTypesf,bugsites updated
metadata only
23 Feb 11:52:04 INFO [org.geoserver] - Loaded feature type 'archsites',
enabled
23 Feb 11:52:04 INFO [catalog.rest] - PUT FeatureTypesf,archsites updated
metadata only
23 Feb 11:52:05 INFO [org.geoserver] - Loaded coverage 'sfdem', enabled
23 Feb 11:52:05 INFO [catalog.rest] - PUT coverage sfdem,sfdem
23 Feb 11:52:05 INFO [org.geoserver] - Loaded coverage 'Img_Sample',
enabled
worldImageSample,Img_Sample
23 Feb 11:52:05 INFO [org.geoserver] - Loaded coverage 'mosaic', enabled
23 Feb 11:52:05 INFO [catalog.rest] - PUT coverage mosaic,mosaic
23 Feb 11:52:05 INFO [org.geoserver] - Loaded coverage 'Pk50095', enabled
23 Feb 11:52:05 INFO [catalog.rest] - PUT coverage img_sample2,Pk50095
23 Feb 11:52:05 INFO [org.geoserver] - Loaded coverage 'Arc_Sample',
enabled
arcGridSample,Arc_Sample
23 Feb 11:52:05 INFO [org.geoserver] - Loaded feature type
'poly_landmarks', enabled
23 Feb 11:52:05 INFO [catalog.rest] - PUT FeatureTypenyc,poly_landmarks
updated metadata only
23 Feb 11:52:05 INFO [org.geoserver] - Loaded feature type 'poi', enabled
23 Feb 11:52:05 INFO [catalog.rest] - PUT FeatureTypenyc,poi updated
metadata only
23 Feb 11:52:05 INFO [org.geoserver] - Loaded feature type 'tiger_roads',
enabled
23 Feb 11:52:05 INFO [catalog.rest] - PUT FeatureTypenyc,tiger_roads
23 Feb 11:52:06 INFO [org.geoserver] - Loaded feature type
'giant_polygon', enabled
23 Feb 11:52:06 INFO [catalog.rest] - PUT FeatureTypenyc,giant_polygon
23 Feb 11:52:06 INFO [org.geoserver] - Loaded feature type 'states',
enabled
FeatureTypestates_shapefile,states updated metadata only
'tasmania_state_boundaries', enabled
FeatureTypetaz_shapes,tasmania_state_boundaries updated metadata only
'tasmania_roads', enabled
FeatureTypetaz_shapes,tasmania_roads updated metadata only
'tasmania_cities', enabled
FeatureTypetaz_shapes,tasmania_cities updated metadata only
'tasmania_water_bodies', enabled
FeatureTypetaz_shapes,tasmania_water_bodies updated metadata only
Not enabling BingMaps base layer as a BING_API_KEY is not defined in
local_settings.py file.
[failed] Layer streams (1/19)
[failed] Layer roads (2/19)
[failed] Layer restricted (3/19)
[failed] Layer bugsites (4/19)
[failed] Layer archsites (5/19)
[failed] Layer sfdem (6/19)
[failed] Layer Img_Sample (7/19)
[failed] Layer mosaic (8/19)
[failed] Layer Pk50095 (9/19)
[failed] Layer Arc_Sample (10/19)
[failed] Layer poly_landmarks (11/19)
[failed] Layer poi (12/19)
[failed] Layer tiger_roads (13/19)
[failed] Layer giant_polygon (14/19)
[failed] Layer states (15/19)
[failed] Layer tasmania_state_boundaries (16/19)
[failed] Layer tasmania_roads (17/19)
[failed] Layer tasmania_cities (18/19)
[failed] Layer tasmania_water_bodies (19/19)
Finished processing 19 layers in 2.0 seconds.
0 Created layers
0 Updated layers
19 Failed layers
0.110000 seconds per layer
Done
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1442#comment:12>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo
