[Live-demo] ipython upgrade via conda
Brian M Hamlin maplabs at light42.com
Sun May 28 11:13:15 PDT 2017
Python 2.7 upgrade via Anaconda distribution
28May17 -dbb
The Anaconda Python install solution is widely used and respected for
Scientific Python.
In the pre11 Live VM, I am looking around and taking notes..
* there is a minimal bootstrap shell script, which does not require the
entire set of packages to be stored locally.
The README does encourage the user to get the entire setup locally,
like some other install solutions on Mac
and Linux, however it is not required.      miniconda [0]
* there is an advertisement for "conda cloud" as well as the license
agreements.. and also at least two opaque
binary blobs in the install script. However, there is also an MD5
checksum and script linecount clearly documented,
so the security is adequate in my opinion. It is a third party product
and the relationship would have to be with
that third party, as far as content and license..
* there is a minimal set of bootstrap packages, with versions .. this
is useful!  we should get in synch with this ! [1]
* the install is per-user by default.. NOT in the system python areas..
  PREFIX=$HOME/miniconda2
* installed miniconda2 for Python 2.7 64bit, transcript excerpts below  [2]
* cartopy is not available with this setup.. therefor IRIS is not
possible either
[0] miniconda Python 2.7 64bit current
#!/bin/bash
# Copyright (c) 2012-2017 Continuum Analytics, Inc.
# All rights reserved.
# Name: Miniconda2
# Version: 4.3.14
# Packages: 25
# PLAT:  linux-64
# DESCR: 4.3.1
# BYTES:  28826662
# LINES: 370
# MD5:   0d76ee42d687f1a14fe73b5ed7f2e604
[1] package versions from the Python 2.7 installer bootstrap
python-2.7.13-0
extract_dist python-2.7.13-0
extract_dist cffi-1.9.1-py27_0
extract_dist conda-env-2.6.0-0
extract_dist cryptography-1.7.1-py27_0
extract_dist enum34-1.1.6-py27_0
extract_dist idna-2.2-py27_0
extract_dist ipaddress-1.0.18-py27_0
extract_dist libffi-3.2.1-1
extract_dist openssl-1.0.2k-1
extract_dist pyasn1-0.1.9-py27_0
extract_dist pycosat-0.6.1-py27_1
extract_dist pycparser-2.17-py27_0
extract_dist pyopenssl-16.2.0-py27_0
extract_dist readline-6.2-2
extract_dist requests-2.12.4-py27_0
extract_dist ruamel_yaml-0.11.14-py27_1
extract_dist setuptools-27.2.0-py27_0
extract_dist six-1.10.0-py27_0
extract_dist sqlite-3.13.0-0
extract_dist tk-8.5.18-0
extract_dist yaml-0.1.6-0
extract_dist zlib-1.2.8-3
extract_dist conda-4.3.14-py27_0
extract_dist pip-9.0.1-py27_1
extract_dist wheel-0.29.0-py27_0
[2]
user at live-pre11:~/conda_misc$ echo $PATH
/home/user/conda_misc/mini2/bin:/home/user/bin:/home/user/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
user at live-pre11:~/conda_misc$ ls mini2/bin
2to3*      conda-env*   easy_install*      openssl*
python@     python-config*  tclsh8.5*
activate*  c_rehash*    easy_install-2.7@  pip*
python2@    smtpd.py*       wheel*
conda*     deactivate*  idle*
pydoc*    python2.7*  sqlite3*        wish8.5*
user at live-pre11:~/conda_misc$ conda install numpy matplotlib pandas scipy
Fetching package metadata .........
Solving package specifications: .
Package plan for installation in environment /home/user/conda_misc/mini2:
The following NEW packages will be INSTALLED:
    cairo:            1.14.8-0
    cycler:           0.10.0-py27_0
    dbus:             1.10.10-0
    expat:            2.1.0-0
    fontconfig:       2.12.1-3
    freetype:         2.5.5-2
    functools32:      3.2.3.2-py27_0
    glib:             2.50.2-1
    gst-plugins-base: 1.8.0-0
    gstreamer:        1.8.0-0
    icu:              54.1-0
    jpeg:             9b-0
    libgcc:           5.2.0-0
    libgfortran:      3.0.0-1
    libiconv:         1.14-0
    libpng:           1.6.27-0
    libxcb:           1.12-1
    libxml2:          2.9.4-0
    matplotlib:       2.0.2-np112py27_0
    mkl:              2017.0.1-0
    numpy:            1.12.1-py27_0
    pandas:           0.20.1-np112py27_0
    pcre:             8.39-1
    pixman:           0.34.0-0
    pycairo:          1.10.0-py27_0
    pyparsing:        2.1.4-py27_0
    pyqt:             5.6.0-py27_2
    python-dateutil:  2.6.0-py27_0
    pytz:             2017.2-py27_0
    qt:               5.6.2-4
    scipy:            0.19.0-np112py27_0
    sip:              4.18-py27_0
    subprocess32:     3.2.7-py27_0
user at live-pre11:~/conda_misc$ conda install ipython
    backports:         1.0-py27_0
    decorator:         4.0.11-py27_0
    get_terminal_size: 1.0.0-py27_0
    ipython:           5.3.0-py27_0
    ipython_genutils:  0.2.0-py27_0
    path.py:           10.3.1-py27_0
    pathlib2:          2.2.1-py27_0
    pexpect:           4.2.1-py27_0
    pickleshare:       0.7.4-py27_0
    prompt_toolkit:    1.0.14-py27_0
    ptyprocess:        0.5.1-py27_0
    pygments:          2.2.0-py27_0
    scandir:           1.5-py27_0
    simplegeneric:     0.8.1-py27_1
    traitlets:         4.3.2-py27_0
    wcwidth:           0.1.7-py27_0
user at live-pre11:~/conda_misc$ conda install jupyter
    backports_abc:      0.5-py27_0
    bleach:             1.5.0-py27_0
    configparser:       3.5.0-py27_0
    entrypoints:        0.2.2-py27_1
    html5lib:           0.999-py27_0
    ipykernel:          4.6.1-py27_0
    ipywidgets:         6.0.0-py27_0
    jinja2:             2.9.6-py27_0
    jsonschema:         2.6.0-py27_0
    jupyter:            1.0.0-py27_3
    jupyter_client:     5.0.1-py27_0
    jupyter_console:    5.1.0-py27_0
    jupyter_core:       4.3.0-py27_0
    libsodium:          1.0.10-0
    markupsafe:         0.23-py27_2
    mistune:            0.7.4-py27_0
    nbconvert:          5.1.1-py27_0
    nbformat:           4.3.0-py27_0
    notebook:           5.0.0-py27_0
    pandocfilters:      1.4.1-py27_0
    pyzmq:              16.0.2-py27_0
    qtconsole:          4.3.0-py27_0
    singledispatch:     3.4.0.3-py27_0
    ssl_match_hostname: 3.4.0.2-py27_1
    terminado:          0.6-py27_0
    testpath:           0.3-py27_0
    tornado:            4.5.1-py27_0
    widgetsnbextension: 2.0.0-py27_0
    zeromq:             4.1.5-0
More information about the Live-demo mailing list
