[Live-demo] Docker and Docker-compose issue
Pieter du Plooy
pjduplooy at zpanelcp.com
Wed Sep 20 00:23:50 PDT 2017
Hi guys
I have a an "unofficial" workaround for installing docker from Ubuntu PPA.
As Alex M said the preferred way is to use the official Docker PPA:
https://docs.docker.com/engine/installation/linux/docker-ce/ubuntu/ and
docker-compose from: https://github.com/docker/compose/releases
Works like a charm!!!.
Cheers guys
Pieter
On Sun, Sep 17, 2017 at 6:09 PM, Pieter du Plooy <pjduplooy at zpanelcp.com>
wrote:
> Hi guys. As I mentioned on irc, there is an issue with regards to the
> installation of docker and docker compose.
> I did a clean install on pc, apt-get upgrade, and then apt-get
> dist-upgrade.
> Then wanted to install docker and docker-compose, and got the following
> output about ipython that is going to be removed:
> user at osgeolive:~$ sudo apt-get install docker docker-compose
> [sudo] password for user:
> Reading package lists... Done
> Building dependency tree
> Reading state information... Done
> The following packages were automatically installed and are no longer
> required:
> acl libllvm3.8 libmircommon5 python-ipython-genutils
> python-jupyter-client python-jupyter-core python-path python-pathlib2
> python-pexpect python-pickleshare
> python-prompt-toolkit python-ptyprocess python-pyqt5 python-pyqt5.qtsvg
> python-simplegeneric python-traitlets python-wcwidth python-zmq
> Use 'sudo apt autoremove' to remove them.
> The following additional packages will be installed:
> python-backports.ssl-match-hostname python-cached-property
> python-docker python-dockerpty python-docopt python-functools32
> python-jsonschema python-texttable
> python-websocket
> Recommended packages:
> docker.io
> The following packages will be REMOVED:
> ipython python-backports-shutil-get-terminal-size python-ipykernel
> python-ipyleaflet python-ipython python-ipywidgets python-qtconsole
> The following NEW packages will be installed:
> docker docker-compose python-backports.ssl-match-hostname
> python-cached-property python-docker python-dockerpty python-docopt
> python-functools32 python-jsonschema
> python-texttable python-websocket
> 0 upgraded, 11 newly installed, 7 to remove and 0 not upgraded.
> Need to get 412 kB of archives.
> After this operation, 3,258 kB disk space will be freed.
> Must I file a big report? I really need docker....
> Pieter
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20170920/f08fd574/attachment.html>
More information about the Live-demo
