[OSGeoLive] Presentation.
Basques, Bob (CI-StPaul)
bob.basques at ci.stpaul.mn.us
Tue Feb 27 11:16:06 PST 2018
Hi Cameron,
The “s” options works fine when I run it from the Website (online), but when I try to save the presentation locally and run if from a local file location, the NOTE aspects are not found. I can get both to work independently (so far). I downloaded the NOTEs pages locally as a separate download, just trying to link them together correctly, in the main presentation.
I want to be able to run without a internet connection, etc. all resources contained on a Thumb drive.
Just looking for hints on where the link might be in the main presentation.
bobb
On Feb 27, 2018, at 1:08 PM, Cameron Shorter <cameron.shorter at gmail.com<mailto:cameron.shorter at gmail.com>> wrote:
Hi Bob,
As it seems you have noticed, the front page of the slide deck [1] says:
Press "s" for slide notes, ESC to zoom out, SPACE / arrow keys to navigate.
It is possible you have been pressing upper case "S" (which doesn't work) instead of lower case "s" (which should work).
What should happen is another browser window will open up. If your browser has been configured to prevent the opening of popups, then that might be the problem you are experiencing. Maybe see if you have an error message saying that a window is being blocked from being opened, or check your settings, or try a different browser.
Hope that helps, Cameron
[1] https://live.osgeo.org/en/presentation/index.html#/
On 28/2/18 5:07 am, Basques, Bob (CI-StPaul) wrote:
All (or Cameron),
I’m givong the OSGeoLive presentation next week and I have a localized copy of the Reveal.js presentation, but I can’t seem to figure out how to easily get the presenter notes.
This is actually the first time I’ve even worried about, since the presentation itself just works as a localized set of file, but I figured I would try to get the Notes working too.
I want to run from a USB (HTML) folder. Again I have the presentation just fine, jus tlooking for hints on an easy way to get the NOTE working. I tried a couple of Link changes in the main file, but I didn’t see anything obvious that the “S” option activates in the HTML. Still looking.
Thanks
all
bobb
"Whenever you find yourself on the side of the majority, it is time to pause and reflect.”
- Mark Twain
Live-demo mailing list
Live-demo at lists.osgeo.org<mailto:Live-demo at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/live-demo
http://live.osgeo.org<http://live.osgeo.org/>
http://wiki.osgeo.org/wiki/Live_GIS_Disc
Cameron Shorter
Technology Demystifier, Learnosity
Open Technologies Consultant
M +61 (0) 419 142 254
"Life isn't about waiting for the storm to pass; it's about learning to dance in the rain."
- Vivian Greene
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20180227/b417e6d6/attachment.html>
More information about the Live-demo
