[OSGeoLive] Presentation.
Basques, Bob (CI-StPaul) bob.basques at ci.stpaul.mn.us
Tue Feb 27 11:34:38 PST 2018
All,
I figured it out.  I needed the whole reveal.js javascript lib to make it work.  Just have to repoint some of the javascript locating links at the bottom of the main presentation page.
I’ve got it all running locally now from a USB drive.
Thanks
bobb
On Feb 27, 2018, at 1:08 PM, Cameron Shorter <cameron.shorter at gmail.com<mailto:cameron.shorter at gmail.com>> wrote:
Hi Bob,
As it seems you have noticed, the front page of the slide deck [1] says:
Press "s" for slide notes, ESC to zoom out, SPACE / arrow keys to navigate.
It is possible you have been pressing upper case "S" (which doesn't work) instead of lower case "s" (which should work).
What should happen is another browser window will open up. If your browser has been configured to prevent the opening of popups, then that might be the problem you are experiencing. Maybe see if you have an error message saying that a window is being blocked from being opened, or check your settings, or try a different browser.
Hope that helps, Cameron
[1] https://live.osgeo.org/en/presentation/index.html#/
On 28/2/18 5:07 am, Basques, Bob (CI-StPaul) wrote:
All (or Cameron),
I’m givong the OSGeoLive presentation next week and I have a localized copy of the Reveal.js presentation, but I can’t seem to figure out how to easily get the presenter notes.
This is actually the first time I’ve even worried about, since the presentation itself just works as a localized set of file, but I figured I would try to get the Notes working too.
I want to run from a USB  (HTML) folder.  Again I have the presentation just fine, jus tlooking for hints on an easy way to get the NOTE working.  I tried a couple of Link changes in the main file, but I didn’t see anything obvious that the “S” option activates in the HTML.  Still looking.
Thanks
all
bobb
"Whenever you find yourself on the side of the majority, it is time to pause and reflect.”
-  Mark Twain
Live-demo mailing list
Live-demo at lists.osgeo.org<mailto:Live-demo at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/live-demo
http://live.osgeo.org<http://live.osgeo.org/>
http://wiki.osgeo.org/wiki/Live_GIS_Disc
Cameron Shorter
Technology Demystifier, Learnosity
Open Technologies Consultant
M +61 (0) 419 142 254
"Black holes are where God divided by zero."
- Steven Wright
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20180227/e43402b1/attachment-0001.html>
More information about the Live-demo mailing list
