[Lizmap-de] QGIS and Postgis
Etienne Trimaille
etienne.trimaille at gmail.com
Di Feb 15 13:05:45 PST 2022
With Apache, QGIS Server might run with www-data user. So it won't find
service files located in your current /home.
You can check with the command "ps -aux | grep qgis" so see the which user
is running QGIS Server.
pg_config –sysconfdir will work. But be careful, the file is
"pg_service.conf" without any dot
https://www.postgresql.org/docs/current/libpq-pgservice.html
Le mar. 15 févr. 2022 à 22:00, G. Wagner, Wagner-IT <info at wagner-it.de> a
écrit :
> Hallo Wolfgang,
> ich bin die Woche nicht im Büro und mir deshalb nicht sicher, ob es das
> ausführliche Protokoll vom QGIS-Server oder vom Apache war, in dem die
> gesetzten Variablen angezeigt werden. Das könnte doch helfen – oder?
> Viele Grüße
> Günter
> *Von:* Lizmap-de <lizmap-de-bounces at lists.osgeo.org> *Im Auftrag von *Wolfgang
> Meinolf
> *Gesendet:* Dienstag, 15. Februar 2022 17:25
> *An:* Etienne Trimaille <etienne.trimaille at gmail.com>
> *Cc:* lizmap-de at lists.osgeo.org
> *Betreff:* Re: [Lizmap-de] QGIS and Postgis
> Hm, on my machine I have /home/gisuserhome and /home/qgis. My Portals are
> located in separate folders under /home/gisuserhome, e.g.
> /home/gisuserhome/portal1, /home/gisuserhome/portal2 and so on. Owner of
> these folders is gisuserhome.
> In /home/qgis I just see 2 folders called qgisserverdb and projects. Owner
> of these folders is www-data. I installed the entire server about 18 months
> ago, so it’s difficult to remember.
> So I tried to place the „.pg_service.conf“ in both home dirs, gisuserhome
> and qgis, but without success. I also ran pg_config –sysconfdir, which lead
> me to /etc/postgresql-common and placed the „.pg_service.conf“ there
> without success.
> How can I check the user, used for QGIS Server?
> *Von:* Etienne Trimaille <etienne.trimaille at gmail.com>
> *Gesendet:* Dienstag, 15. Februar 2022 16:33
> *An:* Wolfgang Meinolf <wmeinolf at bbv-deutschland.de>
> Hi,
> You need to check the user used for QGIS Server.
> Does it use /home/gisuserhome ?
> Try to set explicitly the path to the service file with PGSERVICEFILE when
> launching QGIS Server.
> QGIS_SERVER_IGNORE_BAD_LAYERS is very convenient.
> https://docs.qgis.org/3.22/en/docs/server_manual/config.html#environment-variables
> Le mar. 15 févr. 2022 à 16:25, Wolfgang Meinolf <
> wmeinolf at bbv-deutschland.de> a écrit :
> Hallo zusammen,
> auf meinem Web Server (UBUNTU) läuft Lizmap mit QGIS Server unter Apache
> und Postgres mit Postgis Erweiterung. Die Postgis credentials habe ich auf
> meinem Windows PC in pg_service.conf. Darin auf dem PC die URL des
> Webservers. Die gleiche pg_service.conf ist auf dem Webserver unter
> /home/gisuserhome, also meinem Home Verzeichnis dort, nur natürlich mit
> punkt davor, also „.pg_service.conf“. Ausserdem ist die host adresse dort
> „localhost“.
> Ein QGS Projekt auf meinem PC enthält ausschließlich einen Postgis Layer.
> In Qgis funktioniert das Ganze einwandfrei, die credentials kommen
> offensichtlich aus der pg_service.conf. Lade ich das QGS und Lizmap cfg
> file auf meinen Server zeigt Lizmap Service non disponible. Offensichtlich
> kann der POSTGIS Layer nicht geöffnet werden. Ist ja sonst kein Layer im
> Projekt.
> Was mache ich falsch?
> Gruß
> Wolfgang
> Lizmap-de mailing list
> Lizmap-de at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/lizmap-de
-------------- nächster Teil --------------
Ein Dateianhang mit HTML-Daten wurde abgetrennt...
URL: <http://lists.osgeo.org/pipermail/lizmap-de/attachments/20220215/a1aaacc6/attachment.html>
Mehr Informationen über die Mailingliste Lizmap-de
