[Lizmap-de] QGIS Server, Lizmap and Postgis
Etienne Trimaille
etienne.trimaille at gmail.com
Do Mär 24 04:42:42 PDT 2022
As you are running 3.4.6, for your information, we have just released
3.4.10 a few minutes ago :
https://github.com/3liz/lizmap-web-client/releases/tag/3.4.10
Le jeu. 24 mars 2022 à 11:58, Wolfgang Meinolf <wmeinolf at bbv-deutschland.de>
a écrit :
> Yes, I did but w/o success. This is, why I currently investigate the
> rights management.
> *Von:* Etienne Trimaille <etienne.trimaille at gmail.com>
> *Gesendet:* Donnerstag, 24. März 2022 11:30
> *An:* Wolfgang Meinolf <wmeinolf at bbv-deutschland.de>
> *Cc:* guenter at lizmap.de; lizmap-de at lists.osgeo.org
> *Betreff:* Re: [Lizmap-de] QGIS Server, Lizmap and Postgis
> Ok.
> Did you check your credentials in the QGS project ?
> https://github.com/3liz/lizmap-web-client/issues/1638#issuecomment-627872662
> Le jeu. 24 mars 2022 à 10:48, Wolfgang Meinolf <
> wmeinolf at bbv-deutschland.de> a écrit :
> Yes. Everything without PG works perfect. I have currently 38 Portals
> online (intranet and extranet) including some of them serving WMS and WFS.
> We also included some in frames in our Homepage:
> https://bbv-deutschland.de/wir-sind-toni/vermarktungsgebiete/
> *Gesendet:* Donnerstag, 24. März 2022 10:28
> Sorry, yes, it's only 3.5.
> It's a new panel to check your QGIS Server settings and installed QGIS
> Server plugins.
> As Günter asked, does a simple shapefile works in Lizmap without the use
> of PG ?
> Le jeu. 24 mars 2022 à 09:54, Wolfgang Meinolf <
> Hi Etienne,
> thanks for your comment. I’m currently on 3.4.6 and QGIS server 3.16.xx on
> my live system. On my VM I have installed QGIS Server 3.24.x and 3.5.1
> Lizmap. I plan to upgrade live system, once I identified the issue with
> Postgis Layers on my VM as all Portals I have internally and as Extranet
> work perfect as long as no DB Layer are included. Is “Server Information”
> translated “Lizmap-Konfiguration?
> Or is it not available pre 3.5?
> Ans thks for the info about the bugfix releases.
> *Gesendet:* Donnerstag, 24. März 2022 09:03
> Hi,
> Do you have the table "server information" working correctly ? (In the
> administration interface). It's the first thing to check before trying a
> project if you are 3.5.
> FYI, we will release bugfix versions for 3.4 and 3.5 today.
> On Wed, 23 Mar 2022, 21:34 Wolfgang Meinolf, <wmeinolf at bbv-deutschland.de>
> wrote:
> Hallo Günter,
> danke für den Hinweis mit den anderen .conf Dateien. Das werde ich morgen
> mal probieren, obwohl ich da wenig Hoffnung habe. Heute habe ich eine neue
> VM aufgesetzt, die unserem Server entspricht.
> Zu Deiner Frage: Ja, der Server läuft im Wirkeinsatz fantastisch. Gerade
> gestern habe ich ein neues Extranet Portal für eine Behörde, mit der wie
> zusammenarbeiten, aktiviert. In aller Regel habe ich pro Portal neben der
> .QGS eine GPKG, in der sich alle Layer befinden. Auch eine Mischung aus
> GPKG und SHP aus verschiedenen Verzeichnisästen funktioniert problemlos.
> Insofern glaube ich aktuell nicht, dass das Problem bei LIZMAP liegt.
> Vielmehr scheint der QGIS Server nicht in der Lage zu sein, Layer aus der
> ebenfalls auf dem Server laufenden Postgres/Postgis DB zu öffnen. Meine
> Suche konzentriert sich daher aktuell auf dieses Scenario.
> Das kann ich mit der neuen VM deutlich besser testen als am Live System.
> Das Lizmap Log reflektiert vermutlich nur die Fehlermeldung des Servers.
> Ich werde berichten.
> Gruß und schönen Abend
> Wolfgang
> *Von:* guenter at lizmap.de <guenter at lizmap.de>
> *Gesendet:* Mittwoch, 23. März 2022 19:11
> *An:* Wolfgang Meinolf <wmeinolf at bbv-deutschland.de>;
> *Betreff:* AW: [Lizmap-de] QGIS Server, Lizmap and Postgis
> Hallo Wolfgang,
> zu den Log-Files kann ich ohne Recherche und testen (wozu leider die Zeit
> fehlt) auch nichts sagen.
> Wenn eine QGIS-Server Variable wie
> „FcgidInitialEnv QGIS_SERVER_IGNORE_BAD_LAYERS 1“
> nicht berücksichtigt wird, so würde ich vermuten, dass sie an der falschen
> Stelle, in der falschen .conf-Datei gesetzt wird.
> Ich muss mich mit den conf-Dateien der VirtualHosts in Apache auch noch
> mal genauer beschäftigen.
> Aber ich habe die Variablen in der allgemeinen, ersten .conf-Datei
> „000-default.conf“ und in meinen jeweiligen Projekt-.conf-Dateien gesetzt.
> Das ist zwar doppelt aber funktioniert.
> Ich hatte schon mal zu einer Deinen ersten Mails gefragt:
> Läuft denn der QGIS-Server mit einfachen, lokalen Datenquellen, also
> z.Bsp. einer Geopackage-DB oder notfalls auch mit SHAPE-Daten?
> Gruß, Günter
> *Von:* Lizmap-de <lizmap-de-bounces at lists.osgeo.org> *Im Auftrag von *Wolfgang
> Meinolf
> *Gesendet:* Dienstag, 22. März 2022 21:34
> *An:* lizmap-de at lists.osgeo.org
> *Betreff:* [Lizmap-de] QGIS Server, Lizmap and Postgis
> Hallo zusammen,
> ich forsche immer noch an meinem Server, warum ich mit den Postgis Layern
> nicht weiterkomme. Und warum einige Server Einstellungen wie z.B.
> „FcgidInitialEnv QGIS_SERVER_IGNORE_BAD_LAYERS 1“ ohne Wirkung sind.
> Aktuell habe ich das folgende Problem, dass mein QGIS Server Log unter
> /var/log/qgis/qgisserver.log seine Funktion Ende Februar eingestellt hat
> und ich es nicht mehr zum Laufen bekomme. Lediglich die access und error
> Logs meiner Virtuellen Apache Site kann ich auswerten. Laut QGIS
> Dokumentation wird QGIS_SERVER_LOG_FILE ja seit 3.4 durch
> QGIS_SERVER_LOG_STDERR ersetzt und alle Daten nach stdout bzw. stderr
> geschrieben. Wie kann ich das sichtbar machen, oder in eine Datei umleiten,
> um es auszuwerten?
> In Lizmap sehe ich folgende 4 Zeilen, jedesmal, wenn ich eine der Sites
> mit Postgis Layer aufrufe:
> 2022-03-22 20:24:36 84.136.144.157 error GetCapabilities result
> code: 500
> code: 500
> code: 500
> 2022-03-22 20:24:36 84.136.144.157 error An error has been raised
> when loading WMS GetCapabilities: HTTP Code 400
> Angezeigt wird dabei statt des Portals Service non Disponible. Es ist zum
> verzweifeln. Ich bin kurz davor, den kompletten Server neu aufzusetzten,
> aber ohne Wissen der Ursache scheint mir das wenig sinnvoll.
> Vielleicht gibt’s hier ja noch Ideen, wie und woran ich drehen kann.
> Gruß und einen schönen Abend
> Wolfgang Meinolf
> Lizmap-de mailing list
> Lizmap-de at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/lizmap-de
-------------- nächster Teil --------------
Ein Dateianhang mit HTML-Daten wurde abgetrennt...
URL: <http://lists.osgeo.org/pipermail/lizmap-de/attachments/20220324/abd6f1c8/attachment-0001.html>
Ein Dateianhang mit Binärdaten wurde abgetrennt...
Dateiname : image001.png
Dateityp : image/png
Dateigröße : 37585 bytes
Beschreibung: nicht verfügbar
URL : <http://lists.osgeo.org/pipermail/lizmap-de/attachments/20220324/abd6f1c8/attachment-0001.png>
Mehr Informationen über die Mailingliste Lizmap-de
