[Lizmap-de] Vektorlayer Styles in Postgis speichern: Zusatzfrage
peter.berger at bluewin.ch
Mo Apr 7 00:59:17 PDT 2025
Hallo Wolfgang
Die Erweiterung ist aus 2018 und hilft eh nicht weiter.
Liebe Grüsse
Peter
Habe eine E-Mail an die QGIS Verteilliste geschrieben. Hoffe es kommt dann mal was zurück.
Liebe Grüsse
Peter
Von: peter.berger at bluewin.ch
Gesendet: Montag, 7. April 2025 08:45
An: qgis-user at lists.osgeo.org
Betreff: Storing and Retrieving Vector Layers with Styles to Postgres DB
There are serveral steps necessary to store from QGIS a vector layer with his style in a postgres DB. For a
big amout of layers this is impracticaI.
Therfore I would do this in one step from QGIS. Is this in any way possible?
Peter Berger
Brunnwiesenstrasse 62
8049 Zürich
Schweiz
mobile +41 79 301 71 54
The several step procedure:
* Load the layer: Import the layer from a vector file into QGIS.
* Rename (if necessary): Give the layer an appropriate name.
* Transfer the layer to Postgres: Drag the layer into the PostgreSQL database. You will find it there with
the specific name.
* Load the layer from Postgres: Import it back from the PostgreSQL database into QGIS.
* Assign the style: Copy the style from the original layer and assign it to the Postgres layer loaded in
QGIS.
* Export the style: Export the style of the Postgres layer. You will now find an option to save the style
with the exact name of the layer in the PostgreSQL database.
* Delete old layers and reload: Delete all associated layers and reload the layer from the PostgreSQL
database.
Von: Wolfgang Meinolf <wmeinolf at telecomconsult.de>
Gesendet: Montag, 7. April 2025 09:09
An: peter.berger at bluewin.ch
Cc: lizmap-de at lists.osgeo.org
Betreff: Re: [Lizmap-de] Vektorlayer Styles in Postgis speichern: Zusatzfrage
Moin Peter,
Hab grad mal folgendes gegoogelt:
<https://github.com/PnGuadeloupe/db-style-manager> PnGuadeloupe/db-style-manager: Improve the workflow for managing styles in PostgreSQL
<https://github.com/PnGuadeloupe/db-style-manager> github.com
Vielleicht hilft dir das.
Beste Grüße
Wolfgang
Wolfgang Meinolf
Send from my Phone
+49 151 1142 7451
Am 07.04.2025 um 08:19 schrieb peter.berger--- via Lizmap-de <lizmap-de at lists.osgeo.org <mailto:lizmap-de at lists.osgeo.org> >:
Morgen zusammen
Ich verwende eine Vektorkarte mit über 60 Layern. Auch diese würde ich gerne mit den Stylen in der Postgres DB speichern.
Hat jemand einen schnelleren Weg als bereits beschrieben?
Liebe Grüsse
Peter
Lizmap-de mailing list
Lizmap-de at lists.osgeo.org <mailto:Lizmap-de at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/lizmap-de
-------------- nächster Teil --------------
Ein Dateianhang mit HTML-Daten wurde abgetrennt...
URL: <http://lists.osgeo.org/pipermail/lizmap-de/attachments/20250407/06b09ab9/attachment-0001.htm>
Ein Dateianhang mit Binärdaten wurde abgetrennt...
Dateiname : image001.png
Dateityp : image/png
Dateigröße : 133493 bytes
Beschreibung: nicht verfügbar
URL : <http://lists.osgeo.org/pipermail/lizmap-de/attachments/20250407/06b09ab9/attachment-0001.png>
Mehr Informationen über die Mailingliste Lizmap-de
