[OSGeo-Discuss] Mobile GPS data collection, summary of sorts.
Bob Basques
bob.b at gritechnologies.com
Wed Aug 2 20:16:54 EDT 2006
Just van den Broecke wrote:
> (Back from holiday...just went through the MGPSDC threads...wew..)
> What I can offer is the GeoTracing (www.geotracing.com) platform, not
> as much not as the solution but as a way to try out, share ideas,
> design issues and experience. If the FOSS4G submission is accepted I
> hope to present and/or demo in Lausanne (and/or have interesting
> discussions with you).
I actually looked at this when you posted (just before you went on
Vacation??).
> I plan to move the code to geotracing.codehaus.org somewhere this
> month (time!). Documentation (time!) is lacking, but several working
> applications have been delivered that do personalized GPS tracking
> from a mobile phone through a server finally into a (MySQL
> non-spatial) DB.
Geez, somebody else that think like me. Non-Spatial database, oh no!! :c)
So it this set up as a standalone operation entirely on the phone (as an
optional mode of operation) or is the data sent directly to a Mainserver
for Storage?
MYSQL work great for simple datasets, even simple to moderately complex
Spatial databases, as long as the data are indexed approriately.
> Application-requirements were the main driver for the project. The
> underlying Media/CMS platform KeyWorx (www.keyworx.org) that e.g.
> describes protocol concepts is reasonably documented:
> http://kwx.dev.waag.org/docs
> If you have a smartphone with bluetooth (JSR-82) plus bt gps you may
> try out the MobiTracer client by signing up and downloading OTA:
> http://www.geotracing.com/gt/my
> The related TraceLand webapp runs at http://www.geotracing.com/gt
> For MacOSX a _very_ experimental browser-AJAX-based client is available:
> http://www.geotracing.com/gt/webtracer and
> http://www.geotracing.com/gt/gpsdoor (small CLI Python program similar
> to gpsd but HTTP-service-based)
Is there a TREO 650/Socket (BT) GPS package?
> Other:
> - client/server comms uses lightweight XML over HTTP or TCP/IP
> - hence client technology is independent of server
As it should be :c)
> - authorization: users logon before any other action like submitting data
How is this mnanaged on the server side, just an on/off proposiition, or
can things be controlled at a particular layer of information?
> - personalization: all submitted data (GPS, media, POIs) is linked to
> user (in DB).
> - basically client does remote track recording through the XML
> protocol (create-track, write-track, suspend/resume (creates
> segments), etc)
Very similar to how we set up out Listener some years back.
> - media files (photo/video) can be uploaded (HTTP) or emailed
> - geotagging media is attempted by matching EXIF timestamp data with
> GPS points or else submission time
> - raw GPS (NMEA) samples are sent to server, who parses, checks for
> quality and spikes (GPS data can be "filthy") before appending to track
A little different from our version, we did the cleaning at the server
the same way, but all points were time indexed and IDed seperately and
simply recorded in the database, The AVL hardware seems to have been a
bit more stable than GPS receivers I think.
> - client does some GPS-prefiltering: taking best sample in an
> configurable interval
We grabbed everything, got a point every 1.5 seconds or so by polling
the remote capture device (IP polling), this was plenty of data to build
a track for following vehicles.
> - time is a nasty issue: though a GPS has exact time, some phones do
> not provide correct UTC, photos do not provide timezone info in EXIF etc
> - no local storage/later syncing yet (a much wanted option since
> connectivity may not be present in e.g. rural areas)
Almost a must if you need to do any sort of trail analysis. Make the
dispatching system more effective for example.
> - for desktop and possibly/hopefully some PDA-type clients
> (http://weblogs.mozillazine.org/dougt/archives/016719.html) I see
> browser-AJAX-based solutions as a way to go over dedicated apps. You
> will then only need small components to handle GPS and possibly local
> storage.
> - Opera Mobile on Symbian is not yet there, Minimo for CE is hopeful
> with AJAX support.
> - data organisation: server stores tracks per user divided into
> segments (like GPX)
Can you explain this a bit further, segment of time, Distance, other ???
> - REST service to acquire data as XML (e.g. GPX export)
> - realtime tracking in browser with AJAX-based Pushlets
> (www.pushlets.com)
> - yesyes, GeoTracing does not comply with OpenGIS stacks yet
> I realize the above is somewhat long/unordered and not a direct reply
> but I am enthousiastic about this topic and many issues discussed are
> familiar to those that I have been working on the past year.
Same here, don't worry about it, all good stuff from what I can tell.
How would you guess this would fit into what has been described so far?
bobb
> best,
> --Just
> Just van den Broecke just at justobjects.nl
> Just Objects B.V. tel +31 65 4268627 Skype: justb4
> The Netherlands http://www.justobjects.nl
> Bob Basques wrote:
>> First off, I'm about ready to put some of this into a WIKI, just
>> figured it needs to be hashed out here first. :c)
>> Mateusz Loskot wrote:
>>> Bob Basques wrote:
>> Development of a BETA package for Mobile Data capture:
>>>> The CLI approach seems to most sane to me. This will most like
>>>> change over time with some of the seperate utilities being combined
>>>> into bigger and better things later on. One reason I like this
>>>> approach is that it's very easy to segment the utilities into smaller
>>>> work area/groups. As long as a good Comm directive is followed, ann
>>>> utilities should work in harmony together. This "Utility"
>>>> approach also affords us the opportunity to work precisely on the
>>>> things that need to be worked on, while at the same time using the
>>>> tools already developed for other things.
>>> What about the idea of modularized package + UI, for example command
>>> line interface at the first stage?
>> I like thinking about this as a CGI sort of request handler. If this
>> method were followed, then it's just that much easier to use
>> components via a Webserver when the time comes, or even to combine
>> utilities into a piped structure as handlers.
>>>> Related to the above is the question of what build.
>>>> I keep pointing
>>>> to LINUX as the first version of things because it will require the
>>>> least amount of NEW work to get a prototype operational.
>>>> Basic requirements (as I see them):
>>>> Every Device that is considered for porting, should have:
>>>> * Have a Web Server of some sort (in the near term, nothing
>>>> exotic should be attempted on the LINUX side, just keep it
>>>> short and sweet so that the capabilities are easier to port
>>>> to other OS's.
>>> What is the idea of communication, could you elaborate?
>> Since my notion is that the Main server (mothership) and the portable
>> device (figher ship) will each have about the same capabilites
>> (ideally THE same), the only real problem is with syncing the data
>> between them. The next biggest piece will be in updating tracking
>> layers at each remote device, but the DB sysning should take care of
>> this easily.
>>>> * Have a Web Browser that has at least some Javascript
>>>> capabilities, (most do, BTW, although most are also
>>>> incomplete when talking about what features they support,
>>>> don't support)
>>> Yes, though it may be a problem with portability.
>>> What Web browsers do you consider?
>> Since I wouldn't advocate anything to wierd in the Client GUI, it
>> could be just about anything with Javascript support, Blazer (PALM),
>> Opera(lot's of portable OS's), WinCE, etc. Even some of the Phone
>> browser should support basic Javascript operations. I say we shoot
>> for most, but not all up front.
>>>> * These might be optional items
>>>> * Have a way of generating a Map, even in a simplified
>>>> form as a standalone operation.
>>> What does "generate a map" means?
>>> Do you mean it should be able to display map on a device screen?
>> Yup, the portable device acts just like a desktop version of thing,
>> even when disconnected (it has some basic mapping data resident on
>> the machine. Some smaller form factors will have limited space and
>> the Syncing process could be made a bit more robust in these
>> situations, where only a localized version of the data is resident on
>> the portable device based on dispatching etc.
>>>> * Have a way of connecting to a AVL hardware stack ??(etc.)
>>> I'm not experienced with technical specification of AVL but OK :-)
>> I explain some of this in the earlier Email, but the important piece,
>> is that they too also capture GPS data as a built in Capability.
>>>> If we can agree to the above, then what we'll need to build (short
>>>> list):
>>>> * Collection format for the data (Points only to start with?)
>>> What does "collection format" means?
>>> Is this about log GPS locations or also from manual map editing?
>> Yes, and yes, with my description in the previous Email, I think you
>> can see how this would work usig a database storage technique.
>>>> * Database, Flat File, etc.
>>> IMHO one of the most important requirement is insert/update/query
>>> performance with good indexing.
>>> So, I'd stick to SQLite.
>> Any SQL database, I'm most familiar with MYSQL. But since I'm
>> suggesting that no special data formatting is needed, that the data
>> could reside in anything with a SQL retrieval mechanism.
>>>> * Server comm LIB, Main (MotherShip) to Secondary (Attack
>>>> Fighter) web servers.
>>>> * Syncing of captured data points
>>>> * Syncing of Mapping data between servers fore
>>>> re-distribution.
>>>> * Daemon (listener) to monitor GPS (could be a wrapper around
>>>> any of the options already available for reading
>>>> GPS devices.) coordinate locations, and other digital
>>>> devices, Compass, etc.
>>> As Paulo has suggested, gpsd should work well.
>> See my notes on this in other Emails.
>>>> * Some sort of GUI (web Based, even when running standalone)
>>>> Do you mean it will be a JavaScript/AJAX application>
>> Yes.
>>>> * MapService, for providing Automated location services.
>>> I imagine it can be one of the biggest problem to find/create services
>>> infrastructure.
>> I'm not sure I understand this statement. If by it you mean a
>> Mapping system with this type data already present, I have access to
>> this type of thing. It's a big reason why I'm pushing hard to make
>> this component based, as the CLIENT end of anything will end up in
>> our Main Spatial service, not as a seperate application, but as an
>> enhancement to the existing one.
>>>> could be a start for pulling a project proposal out of.
>>> There are a bunch of details I'm glossing over here, but I think this
>>> Although it's hard for me to comment a Web-based interface for
>>> GPS-driven application for data collecting, I think the plan is good.
>>> Here are my additional questions:
>>> 1. What's the suggested development platform for the prototype?
>>> 2. Are we still going to create and use underlying core components for
>>> data accessing, processing, analysing, computing, etc?
>>> 3. What about services infrastructure?
>> I think these questions should start to become clearer for all those
>> reading so far, let me know if anyone is still needing some aspects
>> (that I have described) explained further. I'm very interested in
>> hearing about why my ideas are hair brained, etc. Don't worry about
>> offending me either, I have this same problem with every application
>> team I get on it seems. :c)
>> bobb
>>> Best regards
>> To unsubscribe, e-mail: discuss-unsubscribe at mail.osgeo.org
>> For additional commands, e-mail: discuss-help at mail.osgeo.org
More information about the Mail_discuss
