[OSGeo-Discuss] Enterprise OSDB for OSGIS
Eduardo Patto Kanegae
epk.lists at gmail.com
Mon Dec 11 09:55:33 EST 2006
I know that MS-SQL2005Express is NOT opensource( despite it's a freeware),
but last week I have installed this database with the spatial database
extension MsSQLSpatial and I liked a lot too. Because this extension is
OGC/SFS compliant, if you know how to user PostGIS, so you will feel
comfortable to manage MsSqlSpatial too.
The bad side is that it's still a very new project, so there's not much
render-clients available. The only I know is SharpMap and MapServer - which
can render MsSQLSpatial object using an OGR/ODBC connection.
best regards,
http://www.webmapit.com.br
On 12/11/06, chenrg at lreis.ac.cn <chenrg at lreis.ac.cn> wrote:
> Dear all,
> There are many comparisons about OSDBs, such as:
> http://www.geocities.com/mailsoftware42/db/
> http://www.fabalabs.org/research/papers/FabalabsResearchPaper-OSDBMS-Eval.pdf
> http://www.virtuas.com/files/osl-osrdb-01.pdf
> http://www.osdbmigration.org:8080/osdb/osdb-features
> I'm not sure which will be the most promising enterprise OSDB for OSGIS.
> (1) PostGIS is an excellent one, but its performance depends on
> PostgreSQL;
> (2) MySQL Spatial Extension (MyGIS) faces the same problem.
> Another solution is to build a Spatial Data Engine (like ArcSDE) for
> FireBird or MaxDB or Ingres.
> Checked the source codes of several OSDB:
> MaxDB V7.6
> PostgreSQL V8.2
> FireBird V2.0
> MySQL V5.0
> Ingres2006
> Files
> 1,203
> 1,081
> 913
> 2,353
> 5,696
> Functions
> 4,692
> 9,506
> 7,075
> 30,994
> 22,470
> Lines Code
> 287,792
> 374,124
> 584,431
> 890,415
> 1,440,326
> Lines Comment
> 103,035
> 155,720
> 254,937
> 286,385
> 1,373,997
> Ratio Comment/Code
> 0.36
> 0.42
> 0.44
> 0.32
> 0.95
> It seems that Ingres is more powerful and has more enterprise functions.
> Further more, it has internal support for spatial extension.
> Is it a reasonable solution to choose it to build enterprise OSGIS? Any
> advice and suggestions?
> Regards.
> Chen
> Rongguo Chen, Prof., Ph.D
> Representative of China OSGeo Chapter (
> http://wiki.osgeo.org/index.php/China, https://china.osgeo.org)
> State Key Laboratory of Resources & Environmental Information System
> (LREIS, http://www.lreis.ac.cn)
> Email: chenrg at lreis.ac.cn, chenrg at igsnrr.ac.cn
> Tel: (86-10)64888963, 13911825587
> Fax: (86-10)64889630
URL: http://lists.osgeo.org/pipermail/mail_discuss/attachments/20061211/8c792c6c/attachment.html
More information about the Mail_discuss
