[Geoapi-devel] Modeling associations in ISO TC/211 standards
Bryce L Nordgren bnordgren at fs.fed.us
Tue Dec 19 15:13:18 EST 2006
GeoAPIers,
I think the following problem with the PDF document has been resolved.
What I'm looking for (Martin, Simone and others) is a warm fuzzy feeling
that my statement of the java generics issue is correct, as I'm redo-ing
the existing 19123 interfaces based on it.  I think that the geometry
interfaces may have to be looked at too.
On the up side, if I'm right we can always just use the java 1.4 version of
the library until the silly 1.5 semantics get sorted out. :)
Bryce
geoapi-devel-bounces at lists.sourceforge.net wrote on 12/16/2006 01:05:43 AM:
> Thanks for the work.
> It seems the Semantics.pdf file is damaged. I have tried off/online to
> read it with the Adobe PDF 7 and always get the message
> "There was an error opening this document. This file is damaged and
> could not be repaired".
> Best regards,
> Paul.
> On 12/16/06, Bryce L Nordgren <bnordgren at fs.fed.us> wrote:
> > All Implementors:
> > A problem has crept up related to "how do we implement type narrowing
UML
> > associations" from the coverage schema (ISO 19123).  I discovered the
> > problem with Java generics, but I seek input from those with expertise
in
> > C++/STL, C#, and {insert platform name here} to determine how extensive
the
> > semantic differences are.
> > All Participants In TC/211 Standards Processes:
> > You are also invited to read the problem description.  Questions for
you
> > are: 1] Do you think it is worth formalizing how to model type
narrowing in
> > 19103? 2] Should we further clarify the semantics of the collection
data
> > types (in 19103) so the "modeled" behavior can be compared with the
library
> > supplied with a given environment?
> > Problem description is attached to this page (comment at will):
> > http://docs.codehaus.
> org/display/GEO/Interface+implementation+of+UML+associations
> > PDF of Problem Description:
> > http://docs.codehaus.org/download/attachments/68990/Semantics.pdf
> > Background on ISO 19123:
> > http://docs.codehaus.org/download/attachments/31212/ISO19123+Primer.pdf
> > Thanx,
> > Bryce Nordgren
> > Take Surveys. Earn Cash. Influence the Future of IT
> > Join SourceForge.net's Techsay panel and you'll get the chance to share
your
> > opinions on IT & business topics through brief surveys - and earn cash
http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEVDEV
> > Geoapi-devel mailing list
> > Geoapi-devel at lists.sourceforge.net
> > https://lists.sourceforge.net/lists/listinfo/geoapi-devel
your
More information about the Mail_discuss mailing list
