[OSGeo-Discuss] project tracker question
Paul Spencer
pspencer at dmsolutions.ca
Wed Jul 5 11:17:29 EDT 2006
Andrew,
you are correct. I was already on the advanced query tab but I
didn't refine the choice to just defects or just enhancements.
I see now that enhancements don't identify a component ... I hadn't
realized that (do you think that enhancements should be targeted at
specific components/sub-components?)
I'm not sure that a change is necessary now that I understand how the
system works. Thanks for the rapid response.
Cheers
Paul
On 5-Jul-06, at 10:42 AM, Andrew Kelly wrote:
> Paul,
> I'm fairly sure I know what you are running into. When you query on
> multiple artifact types (in your case, defects and enhancements) the
> query window only displays as choices the fields that are common to
> both. I just checked out the enhancement artifact, and it doesn't
> include sub-component, hence you don't see that field when you
> query for
> enhancements.
> In this case, you should only choose "defect" as the artifact type in
> the query, and you'll get all those fields to choose from. It also
> sounds to me like you may want to extend the "enhancement" artifact to
> include more field. If that's the case, work with me and I'll make
> the
> changes. I'll need to know what fields you see in "defect" that are
> relevant in "enhancement", and I'll add them.
> One other note, just for your own knowledge. PT has 2 query tabs:
> "query" and "advanced query". The "query" tab includes only those
> fields that are commonly queried on, while the "advanced query" tab
> contains all fields of an artifact. Most fields in the mapguide
> "defect" artifact have been tagged as common, so I don't think we
> have a
> problem there.
> Let me know if you need any more help, and if you want changes made to
> the "enhancement" artifact.
> Cheers,
> Andrew K.
> CollabNet
> -----Original Message-----
> From: Paul Spencer [mailto:pspencer at dmsolutions.ca]
> Sent: Wednesday, July 05, 2006 10:07 AM
> To: discuss at mail.osgeo.org
> Cc: Auke Jilderda
> Subject: [OSGeo-Discuss] project tracker question
> Not sure where to post this question as it is a general question
> about the CN infrastructure rather than project-specific. I guess
> this is targeted at Auke :)
> I would like to have a pre-defined query that returns all open
> defects and enhancements for a specific sub-component of the mapguide
> project. When creating an issue in the project tracker, there are
> all kinds of useful(?) fields that are entered, including the fields
> I am particularly interested in (in this case). However, when
> querying the project tracker, none of these fields seem to be
> accessible for creating a query. Am I missing something?
> Cheers
> Paul
> |Paul Spencer pspencer at dmsolutions.ca |
> |Applications & Software Development |
> |DM Solutions Group Inc http://www.dmsolutions.ca/|
> To unsubscribe, e-mail: discuss-unsubscribe at mail.osgeo.org
> For additional commands, e-mail: discuss-help at mail.osgeo.org
More information about the Mail_discuss
