[OSGeo-Discuss] CollabNet Project Roles
Auke Jilderda
auke at collab.net
Fri Jul 21 10:25:20 EDT 2006
Markus, Mateusz,
the site's on-line help only describes the some roles such as Observer,
Developer, and Project Owner that are provided out-of-the-box. Each
role can be adapted and new roles can be defined; the on-line help does
not cover those. Normal usage would have system admins provide
reasonable summary of the role as its description upon creating or
adapting the role. With the "User" role, this is set to "User or
application developer that makes use of the software in the project"
which, agreed, is not particularly informative.
In general, I feel we need to clean up the roles on the site a bit as
described in that one post of mine [1] which also includes a summary of
what permissions each role would grant.
As to granting roles: you cannot "downgrade" a requested role but you
can reject that role and grant whatever other role to the user (and
optionally send a message to clarify).
Auke
PS: The normal location to ask these questions is
https://support.osgeo.org/
1.
https://incubator.osgeo.org/servlets/ReadMsg?listName=incubator&msgNo=30
7
On Friday, July 21, 2006 15:14, Markus Neteler wrote:
> Hi,
> I had a similar question last month:
> https://webcommittee.osgeo.org/servlets/ReadMsg?listName=dev&msgNo=335
> Since then someone still is waiting to get a role approved (or not) in
> the GRASS project. Auke sent some suggestions on roles here:
7
> https://webcommittee.osgeo.org/servlets/ReadMsg?list=dev&msgNo=336
> So far didn't figure out if I should grant the requested role or not.
> If not, I don't know how to "downgrade" the request to a less
> intrusive role... simple reject it? Maybe other project managers have
> a suggestion?
> Markus
More information about the Mail_discuss
