Web project feedback wanted
    Kathy Cashel
    kathy at cashel.net
    Mon Jul 24 17:49:27 EDT 2006
I'm in the planning stages of an online mapping project, and
wondering if I have chosen the best tools for the job.
The goal is to present political campaign contributions amounts at a
zip-code level for the state of Virginia. I will need to create
hundreds of dynamic maps: one for every county, congressional
district, and senate district in the state. I then need clickable zip
code polygons colored according to how much money came from that
area. Each of these hundreds of maps could then be drawn hundreds of
different ways, depending on which politician you're looking at.
The organization is a nonprofit and can't afford a full-on ArcGIS web
solution, but has a copy of ArcView 8. In fact the web site is on a
shared server, so there is no way to install new software at the
current web host. My plan is to use ArcView's DSMapBook extension to
create static vector maps with landmarks (highways etc.) for each
district, and then use WorldKit (http://worldkit.org/) or something
similar to draw the zip code polygons on top and present the whole
thing in Flash. Geocoded polygon data would be stored in XML files
for each district, and presented in the Flash WorldKit wrapper.
(Flash having the advantages of being a common plug-in, making adding
other interactivity / animation easy, and being easily embedded into
the current web pages.) The contributions data for the zip code
polygons is in a SQL database, and would be displayed on the fly. The
last hurdle is to get latitude / longitude boundaries for each
district map out of DSMapBook, which may not be possible.
If there are other issues I haven't thought of, or better ways to do
this, or if you think this is a good plan, it would be very helpful
to hear about it. This is a non-commercial, non-charging project
which will make this information freely accessible to the public; any
help or advice you have to offer is very much appreciated.
More information about the Mail_discuss
