[webmap-discuss] OGC and google style tiling
Rob Atkinson rob at socialchange.net.au
Thu Apr 27 18:07:28 EDT 2006
The issues below are the relatively simple ones compared to the issue I
saw previously raised - are you going to constrain the map scales the
client is allowed to ask for, and if so:
1) how to advertise the scales available
2) how to get the client to ask for the appropriate scale
3) how to handle intermediate scales
Possibly, modern desktop power would allow scaling of images to occur in
the desktop, giving advantages of caching at the browser side. There is
still going to be a contract between the client code to choose the
scales and the server's capabilities, realised through some form of
"getCapabilities" response.
The same contract would be required for the client to restrict - jump
between available scales.
The alternative is to have scale-independent server side - i.e. have the
cache itself generate tiles for intermediate scales seamlessly. This may
be a large server load, quality issues would affect any "intermediate
scale" solution, client or server
The other issue is whether the tiling strategy is one of partitioning or
caching potentially overlapping requests.  Gazetteer driven solutions
can afford to cache requests (tiled or not) since the users will go to
specific areas repeatedly, but eventually a tile based solution would win.
The final issue affecting client design is knowing whether a service can
be tiled. If a tiling proxy is used in front of all services, this may
not be an issue, but you will be bound to a server. If not, you need to
handle tiling strategy per layer. Maybe its possible to have this
seamlessly - i.e. the client API justs accepts a layer handle and works
it out, or maybe this needs to be specified. Some way of choosing the
"aggregate behaviour" would be required if certain layers are restricted
to scales and you want to restrict the client to these scales
Feels like a tractable problem, but it would be nice to see the APIs of
the components defined at both server and client side.
rob
dblasby at openplans.org wrote:
>I've been thinking of tiling rendering for WMS in general, and geoserver
>in particular (especially with OpenLayers apparently coming out soon
>and mapbuilder also adding similar functionality).
>Paul gave a good account of the problems that I've been thinking about:
>a) Edge Rendering Effects
>b) cache HTTP headers
>c) Get capabilities (ie. tell clients about how to make requests --
>hopefully OGC will define this)
>d) Labeling
>I think a-c are actually fairly easy to handle with a "dumb" proxy WMS.
>Take a quick look at the two images I attached.
>     This can be handled simply by intercepting an incoming WMS
>request, expanding the request bounding box and image size and sending
>the request down to the actual WMS server.  The image returned is then
>"cookie cut" so its the proper size/extent of the original request.
>     You'd have to tune the expansion size, but generally you'll want it
>to be a few pixels wider than your "widest style."  For example, if
>your roads are 12 pixels wide you'd want to expand the image by about
>14 pixels in all directions (extra pixels are to account for
>anti-aliasing).
>      Geoserver allows you to set the cache expire headers, but you can
>also have the WMS proxy mangle header for servers that dont allow this.
>c) Get capabilities
>      At some time in the future, the WMS 'get capabilities' document
>will contain the grid information the server wants the client to use
>for tiling.  Once this is defined, the proxy WMS can augment the real
>server's get capabilities so that clients make "proper" requests.
>Unfortunately, I dont see a good solution to labeling issues (except
>making requests for very large images) - anyone have any ideas?
>dave
>This mail sent through IMP: https://webmail.limegroup.com/
>To unsubscribe, e-mail: webmap-discuss-unsubscribe at mail.osgeo.org
>For additional commands, e-mail: webmap-discuss-help at mail.osgeo.org
More information about the Mail_webmap-discuss mailing list
