Map Width/Height defined as a percentage in OWS Context
Cameron Shorter
cameron.shorter at gmail.com
Wed Dec 6 17:05:08 EST 2006
Width would be set to 100% of the size of the <DIV> (in line with HTML
convensions). The will often be 100% of the browser window width.
Kralidis,Tom [Burlington] wrote:
>>-----Original Message-----
>>From: Cameron Shorter [mailto:cameron.shorter at gmail.com]
>>Sent: 06 December, 2006 4:32 PM
>>To: 'ows-4-geodss at opengeospatial.org';
>>webmap-discuss at mail.osgeo.org; Kralidis,Tom [Burlington]
>>Subject: Map Width/Height defined as a percentage in OWS Context
>>Tom,
>>Am I right in understanding that WMC and OWS Context always
>>specify Map Size in fixed coordinates. Eg:
>> <Window width="600" height="300"/>
> Correct. This was originally from the WMC days.
>>With modern webmapping clients these days, maps are set to
>>fit within the HTML <DIV> element that encloses them.
>>So what would work better for the context is to set window size as:
>> <Window width="100%" height="100%"/>
>>The Area of Interest would then need to be calculated to fit
>>the specified BoundingBox. (We need to make the assumption
>>that users don't want to stretch images).
> 100% of what? This is assuming that a client has a width/height in
> place when loading a context. What if my client purely derived from
> what a WMC/OWSContext provided in Window/@width and Window/@height ?
> Similarly, we encountered this when working on WMC 1.0.0 (i.e. honouring
> bbox vs. window size). It was decided that it would be up to the client
> on whether to recalculate the bbox or adjust the window width/height
> (i.e. when aspect ratio is off).
> I would see this same behavious (i.e. letting the client decide) as can
> be applied to modern webmapping clients also.
> Does this make sense?
>>Could you please add this to your OWS Context issues to
>>address/discuss.
> For sure. Thanks.
>>Cameron Shorter
>>http://cameron.shorter.net
Cameron Shorter
More information about the Mail_webmap-discuss
