[webmap-discuss] Re: Map Width/Height defined as a percentage in OWS Context
Kralidis,Tom [Burlington]
Tom.Kralidis at ec.gc.ca
Wed Dec 6 18:43:15 EST 2006
What if the OWSContext doc is intended to be viewed given a target
width/height?
Having said this, maybe Window/@units (i.e. "pixels" or "percent") would
be useful.
I still think, as per our decisions in WMC 1.0.0, that a client can
decipher what to do with BoundingBox and Window. Nevertheless, I'll
tack this on as a discussion item for next week's ContextRWG.
..Tom
> -----Original Message-----
> From: Cameron Shorter [mailto:cameron.shorter at gmail.com]
> Sent: 06 December, 2006 5:10 PM
> To: webmap-discuss at mail.osgeo.org
> Cc: ows-4-geodss at opengeospatial.org
> Subject: Re: [webmap-discuss] Re: Map Width/Height defined as
> I assume that anything that is rendering a map has a window
> or a Pane concept which has width/height attributes.
> 100% = as big as you can make the map using your current
> display device.
> 50% = half of the Window width.
> etc.
> Kralidis,Tom [Burlington] wrote:
> > What if the context is not being used by an HTML client?
> >>Sent: 06 December, 2006 5:05 PM
> >>To: Kralidis,Tom [Burlington]
> >>Cc: ows-4-geodss at opengeospatial.org; webmap-discuss at mail.osgeo.org
> >>Subject: [webmap-discuss] Re: Map Width/Height defined as a
> percentage
> >>in OWS Context
> >>Width would be set to 100% of the size of the <DIV> (in
> line with HTML
> >>convensions). The will often be 100% of the browser window width.
> >>>>Sent: 06 December, 2006 4:32 PM
> >>>>To: 'ows-4-geodss at opengeospatial.org';
> >>>>webmap-discuss at mail.osgeo.org; Kralidis,Tom [Burlington]
> >>>>Subject: Map Width/Height defined as a percentage in OWS Context
> >>>>Tom,
> >>>>Am I right in understanding that WMC and OWS Context
> always specify
> >>>>Map Size in fixed coordinates. Eg:
> >>>> <Window width="600" height="300"/>
> >>>Correct. This was originally from the WMC days.
> >>>>With modern webmapping clients these days, maps are set to
> >>fit within
> >>>>the HTML <DIV> element that encloses them.
> >>>>So what would work better for the context is to set
> window size as:
> >>>> <Window width="100%" height="100%"/>
> >>>>The Area of Interest would then need to be calculated to fit the
> >>>>specified BoundingBox. (We need to make the assumption that users
> >>>>don't want to stretch images).
> >>>100% of what? This is assuming that a client has a
> width/height in
> >>>place when loading a context. What if my client purely
> >>derived from
> >>>what a WMC/OWSContext provided in Window/@width and
> Window/@height ?
> >>>Similarly, we encountered this when working on WMC 1.0.0 (i.e.
> >>>honouring bbox vs. window size). It was decided that it
> >>would be up
> >>>to the client on whether to recalculate the bbox or adjust
> >>the window
> >>>width/height (i.e. when aspect ratio is off).
> >>>I would see this same behavious (i.e. letting the client
> decide) as
> >>>can be applied to modern webmapping clients also.
> >>>Does this make sense?
> >>>>Could you please add this to your OWS Context issues to
> >>>>address/discuss.
> >>>For sure. Thanks.
> >>>>Cameron Shorter
> >>>>http://cameron.shorter.net
> >>Cameron Shorter
> >>To unsubscribe, e-mail: webmap-discuss-unsubscribe at mail.osgeo.org
> >>For additional commands, e-mail: webmap-discuss-help at mail.osgeo.org
> Cameron Shorter
More information about the Mail_webmap-discuss
