[webmap-discuss] Re: vector editing summary
Cameron Shorter cameron.shorter at gmail.com
Wed Nov 1 14:39:31 EST 2006
Pierre Giraud and Bertil Chapuis's vector rendering demo has moved to
http://dev.camptocamp.com/openlayers
They also have UML of their design there. Their design is very similar
to ours at
http://wiki.osgeo.org/index.php/AJAX_WebMapping_Vector_Rendering_Design
At this early stage, it should be quite easy to merge the two code
bases, then work on a common code base together.
Could someone please forward this email to Bertil. I'm not sure what his
  contact details are.
Pierre, Bertil,
I'm very keen to get in touch with you when you are free. I've been
hanging out at http://freenode.net#openlayers
Or you can try one of the chat programs I use (listed at
http://cameron.shorter.net )
Paul Spencer wrote:
> http://svn.openlayers.org/sandbox/pagameba/vector is the current (not
> working) version that I am using to move code around in.
> I created a copy of the more-or-less working version in http://
> svn.openlayers.org/sandbox/pagameba/vector-original
> The newer version is starting to look like the list below but a bunch
> of stuff is still not moved around and its not in a runnable state
> right now.
> Also, I did add the primative methods to the point and line segment
> code for basic picking functions, which are the building blocks for
> editing controls.  Once the code is running again, I'll chat with  Chris
> Schmidt about creating controls for digitizing and editing.
> Anselm ... not sure where you want to dig in, perhaps just dig around
> and look at the code ... I'll be working on it again tomorrow night  for
> an hour or two I think, perhaps we could discuss how to split up  the
> work if you see an area you want to work on.
> Cheers
> Paul
> On 31-Oct-06, at 5:28 PM, Cameron Shorter wrote:
>> Yes Anselm, I suggest working in Paul's directory. (I assume that  is
>> OK with Paul?)
>> And use the design from the UML diagrams as the master.
>> At the moment, focus on the Graphics code.
>> I'm struggling with how to handle Geometry at different scales.
>> How do you describe a feature using a different FeatureCollection  for
>> each zoom level.
>> I've raise the issue on the OWS Context email list and it seems  that
>> this problem has not been resolved properly in Context, WFS,  and
>> possibly even GML specs.
>> Anselm Hook wrote:
>>> I'd like to be able to play with some code a bit - should i use  the
>>> stuff here:
>>> http://svn.openlayers.org/sandbox/pagameba/vector/lib/OpenLayers/
>>> Vector.js
>>> Or should I use pauls stuff which may be elsewhere?
>>> I wouldn't mind roughing out some of camerons framework and then
>>> playing with some canvas based implementations of the abstractions  for
>>> fun...
>>> - a
>>> On 10/31/06, Cameron Shorter <cameron.shorter at gmail.com> wrote:
>>>> Paul, Anselm,
>>>> I haven't updated as much of the design as I hoped. Other
>>>> priorities got
>>>>   in the way.
>>>> I've primarilly only updated the Graphics code.
>>>> I've changed the names slightly to align with GO-1 naming  convensions.
>>>> (A Java standard API)
>>>> I've re-introduced a Factory.
>>>> The key API will be the Canvas object.
>>>> I'll be back onto this tomorrow. (your afternoon)
>>>> Paul Spencer wrote:
>>>> > Cameron, here is my non-uml version of where I think we could  go
>>>> with
>>>> > the design/architecture.  I think this allows for a lot of
>>>> flexibility
>>>> > but is reasonably easy to understand.
>>>> > Lemme know what you think ...
>>>> > Cheers
>>>> > Paul
>>>> > Graphics
>>>> > Graphics.Point
>>>> > Graphics.Line
>>>> > Graphics.LineSegment
>>>> > Graphics.Polygon
>>>> > Graphics.Circle
>>>> > Graphics represents graphic primitives.  Graphic primitives deal
>>>> > directly in pixel coordinates and know nothing about the spatial
>>>> > objects they represent.
>>>> > Vector
>>>> > Vector.Point
>>>> > Vector.Line
>>>> > Vector.Polygon
>>>> > Vector encapsulates a geo-spatial feature.  Vector objects can
>>>> create
>>>> > Graphics primitives to use for rendering.  A Vector object can
>>>> also  be
>>>> > initialized from a Graphics object to aid in digitizing new
>>>> features
>>>> > and editing existing features.
>>>> > Style
>>>> > Style.PointSymbolizer
>>>> > Style.LineSymbolizer
>>>> > Style.AreaSymbolizer
>>>> > Style is a general description of how to render a specific type of
>>>> > Vector feature.  Styles can be associated with a Layer or with
>>>> > individual Vector objects.  Style is used by the Renderer to
>>>> create a
>>>> > visual representation of a Vector
>>>> > Renderer
>>>> > Renderer.Graphic
>>>> > Renderer.Graphic.Canvas
>>>> > Renderer.Graphic.SVG
>>>> > Renderer.Graphic.VML
>>>> > Renderer.WKT
>>>> > Renderer.GML
>>>> > Renderer is a generic virtual vector rendering interface.  Only
>>>> > specific subclasses of Renderer can be instantiated.  A vector  layer
>>>> > uses the renderer to render its Vector objects into some  output.
>>>> The
>>>> > main use is to render a graphic representation of a Vector  feature.
>>>> > However, Renderers can also produce string representations such
>>>> as  WKT
>>>> > and GML.
>>>> > Layer
>>>> > Layer.Vector
>>>> > Layer.Vector.GeoRSS
>>>> > Layer.Vector.WFS
>>>> > A Layer.Vector is a generic vector rendering layer.  It manages an
>>>> > array of Vector objects.  Sub-classes of Layer.Vector provide  direct
>>>> > access to vector data via a specific protocol like GeoRSS or WFS.
>>>> > |Paul Spencer                           pspencer at dmsolutions.ca    |
>>>> > |Chief Technology  Officer                                         |
>>>> > |DM Solutions Group Inc                http:// www.dmsolutions.ca/ |
>>>> Cameron Shorter
>> Cameron Shorter
>> To unsubscribe, e-mail: webmap-discuss-unsubscribe at mail.osgeo.org
>> For additional commands, e-mail: webmap-discuss-help at mail.osgeo.org
> |DM Solutions Group Inc                http://www.dmsolutions.ca/ |
Cameron Shorter
More information about the Mail_webmap-discuss mailing list
