[webmap-discuss] WMS Requests: Rounding BBOX
Paul Spencer
pspencer at dmsolutions.ca
Thu Sep 21 10:28:45 EDT 2006
Chris, could the amount of rounding be configurable per layer with a
reasonable default of 6 ... so that if you know you are working in a
different projection where that doesn't make sense, you can override it?
Paul
On 21-Sep-06, at 6:32 AM, Christopher Schmidt wrote:
>>> Today, an OpenLayers user asked me why we weren't rounding BBOX
>>> values
>>> in our tiled image requests, since it was causing problems with his
>>> reverse proxy caching to have OpenLayers not do so. The primary
>>> reason
>>> this isn't done at the moment is that I couldn't pick a good
>>> value to
>>> use :)
>>> 6 decimal places seems to be a generally good value to cut-off at
>>> when
>>> working in degrees: that gets you down to half-meter accuracy (I
>>> think?). Does anyone have any other thoughts on this? How have you
>>> addressed rounding BBOX requests in your own applications?
>> 6 decimal places for lat/long is fine. I don't think we need to be
>> able
>> to give bounding boxes in mm on lat/long systems anyway. But 6
>> decimal
>> places for projected ones is a bit overkill. Can you make sure that
>> those bounding boxes are rounded in a more sensible way?
> What is sensible? I know that I can implement it in OpenLayers, but
> there needs to be some kind of agreement on what makes sense... the
> problem being that what makes sense for you or I doesn't make sense
> for
> everyone.
> For systems using meters, usually two decimal places is overkill...
> but
> there might be someone working with extremely large scale cad drawings
> (1:10, or 1:100) where webmap clients make sense... and that 1 cm
> difference could be major.
> Should rounding be based on the current scale? I think that's the only
> way to make sure that requests are never going to lose precision which
> is neccesary for correctly displaying the map -- otherwise, when
> you get
> into 1px = 1unit, you'll run into problems with most any rounding...
> Does anyone have use cases where rounding has played an effect?
> I know that when I was first working with ka-map, I actually did see
> rounding have an effect. THe ka-Map tiling engine rounded scale
> requests
> to the nearest integer. Since ka-Map requires you to enter fixed
> scales,
> this had never been a problem: but when you try to combined OpenLayers
> and ka-map, it did become a problem -- rounding scale to the nearest
> integer caused errors that could be as high as half a tile as the tile
> got further and further from the geographic meridians. So, I'm aware
> that these things do matter... but not sure at what point they matter.
> Rounding the scale to four decimal places brought any such differences
> to being invisible -- but is that enough for bounding boxes?
> Christopher Schmidt
> MetaCarta
> To unsubscribe, e-mail: webmap-discuss-unsubscribe at mail.osgeo.org
> For additional commands, e-mail: webmap-discuss-help at mail.osgeo.org
|Paul Spencer pspencer at dmsolutions.ca |
|Chief Technology Officer |
|DM Solutions Group Inc http://www.dmsolutions.ca/|
More information about the Mail_webmap-discuss
