svn commit: r13 - trunk/mapbender/http/classes: . fonts phpmailer-1.72 phpmailer-1.72/docs phpmailer-1.72/language phpmailer-1.72/phpdoc phpmailer-1.72/test
uli at osgeo.org
uli at osgeo.org
Thu Apr 13 15:38:28 EDT 2006
Author: uli
Date: 2006-04-13 19:38:28+0000
New Revision: 13
Added:
trunk/mapbender/http/classes/
trunk/mapbender/http/classes/class.ezpdf.php
trunk/mapbender/http/classes/class.pdf.php
trunk/mapbender/http/classes/class_SaveLegend.php
trunk/mapbender/http/classes/class_administration.php
trunk/mapbender/http/classes/class_connector.php
trunk/mapbender/http/classes/class_database.php
trunk/mapbender/http/classes/class_database_table.php
trunk/mapbender/http/classes/class_database_table_column.php
trunk/mapbender/http/classes/class_database_table_constraint.php
trunk/mapbender/http/classes/class_database_table_key.php
trunk/mapbender/http/classes/class_exception.php
trunk/mapbender/http/classes/class_geomObj.php
trunk/mapbender/http/classes/class_log.php
trunk/mapbender/http/classes/class_weldLegend2PNG.php
trunk/mapbender/http/classes/class_weldMaps2PNG.php
trunk/mapbender/http/classes/class_weldOverview2PNG.php
trunk/mapbender/http/classes/class_wmc.php
trunk/mapbender/http/classes/class_wms.php
trunk/mapbender/http/classes/fonts/
trunk/mapbender/http/classes/fonts/Courier-Bold.afm
trunk/mapbender/http/classes/fonts/Courier-BoldOblique.afm
trunk/mapbender/http/classes/fonts/Courier.afm
trunk/mapbender/http/classes/fonts/Helvetica-Bold.afm
trunk/mapbender/http/classes/fonts/Helvetica-BoldOblique.afm
trunk/mapbender/http/classes/fonts/Helvetica-Oblique.afm
trunk/mapbender/http/classes/fonts/Symbol.afm
trunk/mapbender/http/classes/fonts/Times-BoldItalic.afm
trunk/mapbender/http/classes/fonts/Times-Italic.afm
trunk/mapbender/http/classes/fonts/Times-Roman.afm
trunk/mapbender/http/classes/fonts/php_Courier-Bold.afm
trunk/mapbender/http/classes/fonts/php_Courier-BoldOblique.afm
trunk/mapbender/http/classes/fonts/php_Courier-Oblique.afm
trunk/mapbender/http/classes/fonts/php_Courier.afm
trunk/mapbender/http/classes/fonts/php_Helvetica-Bold.afm
trunk/mapbender/http/classes/fonts/php_Helvetica-BoldOblique.afm
trunk/mapbender/http/classes/fonts/php_Helvetica-Oblique.afm
trunk/mapbender/http/classes/fonts/php_Helvetica.afm
trunk/mapbender/http/classes/fonts/php_Symbol.afm
trunk/mapbender/http/classes/fonts/php_Times-Bold.afm
trunk/mapbender/http/classes/fonts/php_Times-Roman.afm
trunk/mapbender/http/classes/fonts/php_a0100131.afm
trunk/mapbender/http/classes/fonts/php_a010013l.afm
trunk/mapbender/http/classes/fonts/php_verdana.afm
trunk/mapbender/http/classes/fonts/verdana.afm
trunk/mapbender/http/classes/phpmailer-1.72/
trunk/mapbender/http/classes/phpmailer-1.72/ChangeLog.txt
trunk/mapbender/http/classes/phpmailer-1.72/class.phpmailer.php
trunk/mapbender/http/classes/phpmailer-1.72/class.smtp.php
trunk/mapbender/http/classes/phpmailer-1.72/docs/
trunk/mapbender/http/classes/phpmailer-1.72/docs/extending.html
trunk/mapbender/http/classes/phpmailer-1.72/docs/faq.html
trunk/mapbender/http/classes/phpmailer-1.72/docs/timeoutfix.diff
trunk/mapbender/http/classes/phpmailer-1.72/language/
trunk/mapbender/http/classes/phpmailer-1.72/language/phpmailer.lang-br.php
trunk/mapbender/http/classes/phpmailer-1.72/language/phpmailer.lang-cz.php
trunk/mapbender/http/classes/phpmailer-1.72/language/phpmailer.lang-de.php
trunk/mapbender/http/classes/phpmailer-1.72/language/phpmailer.lang-en.php
trunk/mapbender/http/classes/phpmailer-1.72/language/phpmailer.lang-es.php
trunk/mapbender/http/classes/phpmailer-1.72/language/phpmailer.lang-fr.php
trunk/mapbender/http/classes/phpmailer-1.72/language/phpmailer.lang-it.php
trunk/mapbender/http/classes/phpmailer-1.72/language/phpmailer.lang-nl.php
trunk/mapbender/http/classes/phpmailer-1.72/language/phpmailer.lang-no.php
trunk/mapbender/http/classes/phpmailer-1.72/language/phpmailer.lang-se.php
trunk/mapbender/http/classes/phpmailer-1.72/language/phpmailer.lang-tr.php
trunk/mapbender/http/classes/phpmailer-1.72/mail.php
trunk/mapbender/http/classes/phpmailer-1.72/phpdoc/
trunk/mapbender/http/classes/phpmailer-1.72/phpdoc/allclasses-frame.html
trunk/mapbender/http/classes/phpmailer-1.72/phpdoc/help-doc.html
trunk/mapbender/http/classes/phpmailer-1.72/phpdoc/index.html
trunk/mapbender/http/classes/phpmailer-1.72/phpdoc/overview-tree.html
trunk/mapbender/http/classes/phpmailer-1.72/phpdoc/packages.html
trunk/mapbender/http/classes/phpmailer-1.72/phpdoc/phpmailer.html
trunk/mapbender/http/classes/phpmailer-1.72/phpdoc/serialized-form.html
trunk/mapbender/http/classes/phpmailer-1.72/phpdoc/stylesheet.css
trunk/mapbender/http/classes/phpmailer-1.72/test/
trunk/mapbender/http/classes/phpmailer-1.72/test/phpmailer_test.php
trunk/mapbender/http/classes/phpmailer-1.72/test/phpunit.php
trunk/mapbender/http/classes/phpmailer-1.72/test/rocks.png
import Mapbender source without history
Added: trunk/mapbender/http/classes/class.ezpdf.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/class.ezpdf.php?view=auto&rev=13
--- (empty file)
+++ trunk/mapbender/http/classes/class.ezpdf.php 2006-04-13 19:38:28+0000
@@ -0,0 +1,1555 @@
+<?php
+include_once('class.pdf.php');
+class Cezpdf extends Cpdf {
+// this class will take the basic interaction facilities of the Cpdf class
+// and make more useful functions so that the user does not have to
+// know all the ins and outs of pdf presentation to produce something pretty.
+// IMPORTANT NOTE
+// there is no warranty, implied or otherwise with this software.
+// version 009 (versioning is linked to class.pdf.php)
+// released under a public domain licence.
+// Wayne Munro, R&OS Ltd, http://www.ros.co.nz/pdf
+var $ez=array('fontSize'=>10); // used for storing most of the page configuration parameters
+var $y; // this is the current vertical positon on the page of the writing point, very important
+var $ezPages=array(); // keep an array of the ids of the pages, making it easy to go back and add page numbers etc.
+var $ezPageCount=0;
+function Cezpdf($paper='a4',$orientation='portrait'){
+ // Assuming that people don't want to specify the paper size using the absolute coordinates
+ // allow a couple of options:
+ // orientation can be 'portrait' or 'landscape'
+ // or, to actually set the coordinates, then pass an array in as the first parameter.
+ // the defaults are as shown.
+ // 2002-07-24 - Nicola Asuni (info at tecnick.com):
+ // Added new page formats (45 standard ISO paper formats and 4 american common formats)
+ // paper cordinates are calculated in this way: (inches * 72) where 1 inch = 2.54 cm
+ // Now you may also pass a 2 values array containing the page width and height in centimeters
+ if (!is_array($paper)){
+ switch (strtoupper($paper)){
+ case '4A0': {$size = array(0,0,4767.87,6740.79); break;}
+ case '2A0': {$size = array(0,0,3370.39,4767.87); break;}
+ case 'A0': {$size = array(0,0,2383.94,3370.39); break;}
+ case 'A1': {$size = array(0,0,1683.78,2383.94); break;}
+ case 'A2': {$size = array(0,0,1190.55,1683.78); break;}
+ case 'A3': {$size = array(0,0,841.89,1190.55); break;}
+ case 'A4': default: {$size = array(0,0,595.28,841.89); break;}
+ case 'A5': {$size = array(0,0,419.53,595.28); break;}
+ case 'A6': {$size = array(0,0,297.64,419.53); break;}
+ case 'A7': {$size = array(0,0,209.76,297.64); break;}
+ case 'A8': {$size = array(0,0,147.40,209.76); break;}
+ case 'A9': {$size = array(0,0,104.88,147.40); break;}
+ case 'A10': {$size = array(0,0,73.70,104.88); break;}
+ case 'B0': {$size = array(0,0,2834.65,4008.19); break;}
+ case 'B1': {$size = array(0,0,2004.09,2834.65); break;}
+ case 'B2': {$size = array(0,0,1417.32,2004.09); break;}
+ case 'B3': {$size = array(0,0,1000.63,1417.32); break;}
+ case 'B4': {$size = array(0,0,708.66,1000.63); break;}
+ case 'B5': {$size = array(0,0,498.90,708.66); break;}
+ case 'B6': {$size = array(0,0,354.33,498.90); break;}
+ case 'B7': {$size = array(0,0,249.45,354.33); break;}
+ case 'B8': {$size = array(0,0,175.75,249.45); break;}
+ case 'B9': {$size = array(0,0,124.72,175.75); break;}
+ case 'B10': {$size = array(0,0,87.87,124.72); break;}
+ case 'C0': {$size = array(0,0,2599.37,3676.54); break;}
+ case 'C1': {$size = array(0,0,1836.85,2599.37); break;}
+ case 'C2': {$size = array(0,0,1298.27,1836.85); break;}
+ case 'C3': {$size = array(0,0,918.43,1298.27); break;}
+ case 'C4': {$size = array(0,0,649.13,918.43); break;}
+ case 'C5': {$size = array(0,0,459.21,649.13); break;}
+ case 'C6': {$size = array(0,0,323.15,459.21); break;}
+ case 'C7': {$size = array(0,0,229.61,323.15); break;}
+ case 'C8': {$size = array(0,0,161.57,229.61); break;}
+ case 'C9': {$size = array(0,0,113.39,161.57); break;}
+ case 'C10': {$size = array(0,0,79.37,113.39); break;}
+ case 'RA0': {$size = array(0,0,2437.80,3458.27); break;}
+ case 'RA1': {$size = array(0,0,1729.13,2437.80); break;}
+ case 'RA2': {$size = array(0,0,1218.90,1729.13); break;}
+ case 'RA3': {$size = array(0,0,864.57,1218.90); break;}
+ case 'RA4': {$size = array(0,0,609.45,864.57); break;}
+ case 'SRA0': {$size = array(0,0,2551.18,3628.35); break;}
+ case 'SRA1': {$size = array(0,0,1814.17,2551.18); break;}
+ case 'SRA2': {$size = array(0,0,1275.59,1814.17); break;}
+ case 'SRA3': {$size = array(0,0,907.09,1275.59); break;}
+ case 'SRA4': {$size = array(0,0,637.80,907.09); break;}
+ case 'LETTER': {$size = array(0,0,612.00,792.00); break;}
+ case 'LEGAL': {$size = array(0,0,612.00,1008.00); break;}
+ case 'EXECUTIVE': {$size = array(0,0,521.86,756.00); break;}
+ case 'FOLIO': {$size = array(0,0,612.00,936.00); break;}
+ switch (strtolower($orientation)){
+ case 'landscape':
+ $a=$size[3];
+ $size[3]=$size[2];
+ $size[2]=$a;
+ break;
+ } else {
+ if (count($paper)>2) {
+ // then an array was sent it to set the size
+ $size = $paper;
+ else { //size in centimeters has been passed
+ $size[0] = 0;
+ $size[1] = 0;
+ $size[2] = ( $paper[0] / 2.54 ) * 72;
+ $size[3] = ( $paper[1] / 2.54 ) * 72;
+ $this->Cpdf($size);
+ $this->ez['pageWidth']=$size[2];
+ $this->ez['pageHeight']=$size[3];
+ // also set the margins to some reasonable defaults
+ $this->ez['topMargin']=30;
+ $this->ez['bottomMargin']=30;
+ $this->ez['leftMargin']=30;
+ $this->ez['rightMargin']=30;
+ // set the current writing position to the top of the first page
+ $this->y = $this->ez['pageHeight']-$this->ez['topMargin'];
+ // and get the ID of the page that was created during the instancing process.
+ $this->ezPages[1]=$this->getFirstPageId();
+ $this->ezPageCount=1;
+// 2002-07-24: Nicola Asuni (info at tecnick.com)
+// Set Margins in centimeters
+function ezSetCmMargins($top,$bottom,$left,$right){
+ $top = ( $top / 2.54 ) * 72;
+ $bottom = ( $bottom / 2.54 ) * 72;
+ $left = ( $left / 2.54 ) * 72;
+ $right = ( $right / 2.54 ) * 72;
+ $this->ezSetMargins($top,$bottom,$left,$right);
+function ezColumnsStart($options=array()){
+ // start from the current y-position, make the set number of columne
+ if (isset($this->ez['columns']) && $this->ez['columns']==1){
+ // if we are already in a column mode then just return.
+ return;
+ $def=array('gap'=>10,'num'=>2);
+ foreach($def as $k=>$v){
+ if (!isset($options[$k])){
+ $options[$k]=$v;
+ // setup the columns
+ $this->ez['columns']=array('on'=>1,'colNum'=>1);
+ // store the current margins
+ $this->ez['columns']['margins']=array(
+ ,$this->ez['rightMargin']
+ ,$this->ez['topMargin']
+ ,$this->ez['bottomMargin']
+ // and store the settings for the columns
+ $this->ez['columns']['options']=$options;
+ // then reset the margins to suit the new columns
+ // safe enough to assume the first column here, but start from the current y-position
+ $this->ez['topMargin']=$this->ez['pageHeight']-$this->y;
+ $width=($this->ez['pageWidth']-$this->ez['leftMargin']-$this->ez['rightMargin']-($options['num']-1)*$options['gap'])/$options['num'];
+ $this->ez['columns']['width']=$width;
+ $this->ez['rightMargin']=$this->ez['pageWidth']-$this->ez['leftMargin']-$width;
+function ezColumnsStop(){
+ if (isset($this->ez['columns']) && $this->ez['columns']['on']==1){
+ $this->ez['columns']['on']=0;
+ $this->ez['leftMargin']=$this->ez['columns']['margins'][0];
+ $this->ez['rightMargin']=$this->ez['columns']['margins'][1];
+ $this->ez['topMargin']=$this->ez['columns']['margins'][2];
+ $this->ez['bottomMargin']=$this->ez['columns']['margins'][3];
+function ezInsertMode($status=1,$pageNum=1,$pos='before'){
+ // puts the document into insert mode. new pages are inserted until this is re-called with status=0
+ // by default pages wil be inserted at the start of the document
+ switch($status){
+ case '1':
+ if (isset($this->ezPages[$pageNum])){
+ $this->ez['insertMode']=1;
+ $this->ez['insertOptions']=array('id'=>$this->ezPages[$pageNum],'pos'=>$pos);
+ break;
+ case '0':
+ $this->ez['insertMode']=0;
+ break;
+function ezNewPage(){
+ $pageRequired=1;
+ // check if this is just going to a new column
+ // increment the column number
+//echo 'HERE<br>';
+ $this->ez['columns']['colNum']++;
+//echo $this->ez['columns']['colNum'].'<br>';
+ if ($this->ez['columns']['colNum'] <= $this->ez['columns']['options']['num']){
+ // then just reset to the top of the next column
+ $pageRequired=0;
+ } else {
+ $this->ez['columns']['colNum']=1;
+ $width = $this->ez['columns']['width'];
+ $this->ez['leftMargin']=$this->ez['columns']['margins'][0]+($this->ez['columns']['colNum']-1)*($this->ez['columns']['options']['gap']+$width);
+//echo 'left='.$this->ez['leftMargin'].' right='.$this->ez['rightMargin'].'<br>';
+ if ($pageRequired){
+ // make a new page, setting the writing point back to the top
+ // make the new page with a call to the basic class.
+ $this->ezPageCount++;
+ if (isset($this->ez['insertMode']) && $this->ez['insertMode']==1){
+ $id = $this->ezPages[$this->ezPageCount] = $this->newPage(1,$this->ez['insertOptions']['id'],$this->ez['insertOptions']['pos']);
+ // then manipulate the insert options so that inserted pages follow each other
+ $this->ez['insertOptions']['id']=$id;
+ $this->ez['insertOptions']['pos']='after';
+ } else {
+ $this->ezPages[$this->ezPageCount] = $this->newPage();
+ } else {
+function ezSetMargins($top,$bottom,$left,$right){
+ // sets the margins to new values
+ $this->ez['topMargin']=$top;
+ $this->ez['bottomMargin']=$bottom;
+ $this->ez['leftMargin']=$left;
+ $this->ez['rightMargin']=$right;
+ // check to see if this means that the current writing position is outside the
+ // writable area
+ if ($this->y > $this->ez['pageHeight']-$top){
+ // then move y down
+ $this->y = $this->ez['pageHeight']-$top;
+ if ( $this->y < $bottom){
+ // then make a new page
+ $this->ezNewPage();
+function ezGetCurrentPageNumber(){
+ // return the strict numbering (1,2,3,4..) number of the current page
+ return $this->ezPageCount;
+function ezStartPageNumbers($x,$y,$size,$pos='left',$pattern='{PAGENUM} of {TOTALPAGENUM}',$num=''){
+ // put page numbers on the pages from here.
+ // place then on the 'pos' side of the coordinates (x,y).
+ // pos can be 'left' or 'right'
+ // use the given 'pattern' for display, where (PAGENUM} and {TOTALPAGENUM} are replaced
+ // as required.
+ // if $num is set, then make the first page this number, the number of total pages will
+ // be adjusted to account for this.
+ // Adjust this function so that each time you 'start' page numbers then you effectively start a different batch
+ // return the number of the batch, so that they can be stopped in a different order if required.
+ if (!$pos || !strlen($pos)){
+ $pos='left';
+ if (!$pattern || !strlen($pattern)){
+ $pattern='{PAGENUM} of {TOTALPAGENUM}';
+ if (!isset($this->ez['pageNumbering'])){
+ $this->ez['pageNumbering']=array();
+ $i = count($this->ez['pageNumbering']);
+ $this->ez['pageNumbering'][$i][$this->ezPageCount]=array('x'=>$x,'y'=>$y,'pos'=>$pos,'pattern'=>$pattern,'num'=>$num,'size'=>$size);
+ return $i;
+function ezWhatPageNumber($pageNum,$i=0){
+ // given a particular generic page number (ie, document numbered sequentially from beginning),
+ // return the page number under a particular page numbering scheme ($i)
+ $num=0;
+ $start=1;
+ $startNum=1;
+ $this->addMessage('WARNING: page numbering called for and wasn\'t started with ezStartPageNumbers');
+ return 0;
+ foreach($this->ez['pageNumbering'][$i] as $k=>$v){
+ if ($k<=$pageNum){
+ if (is_array($v)){
+ // start block
+ if (strlen($v['num'])){
+ // a start was specified
+ $start=$v['num'];
+ $startNum=$k;
+ $num=$pageNum-$startNum+$start;
+ } else {
+ // stop block
+ $num=0;
+ return $num;
+function ezStopPageNumbers($stopTotal=0,$next=0,$i=0){
+ // if stopTotal=1 then the totalling of pages for this number will stop too
+ // if $next=1, then do this page, but not the next, else do not do this page either
+ // if $i is set, then stop that particular pagenumbering sequence.
+ if ($next && isset($this->ez['pageNumbering'][$i][$this->ezPageCount]) && is_array($this->ez['pageNumbering'][$i][$this->ezPageCount])){
+ // then this has only just been started, this will over-write the start, and nothing will appear
+ // add a special command to the start block, telling it to stop as well
+ if ($stopTotal){
+ $this->ez['pageNumbering'][$i][$this->ezPageCount]['stoptn']=1;
+ } else {
+ $this->ez['pageNumbering'][$i][$this->ezPageCount]['stopn']=1;
+ } else {
+ if ($stopTotal){
+ $this->ez['pageNumbering'][$i][$this->ezPageCount]='stopt';
+ } else {
+ $this->ez['pageNumbering'][$i][$this->ezPageCount]='stop';
+ if ($next){
+ $this->ez['pageNumbering'][$i][$this->ezPageCount].='n';
+function ezPRVTpageNumberSearch($lbl,&$tmp){
+ foreach($tmp as $i=>$v){
+ if (isset($v[$lbl])){
+ return $i;
+ } else {
+ if ($v==$lbl){
+ return $i;
+ return 0;
+function ezPRVTaddPageNumbers(){
+ // this will go through the pageNumbering array and add the page numbers are required
+ if (isset($this->ez['pageNumbering'])){
+ $totalPages1 = $this->ezPageCount;
+ $tmp1=$this->ez['pageNumbering'];
+ $status=0;
+ foreach($tmp1 as $i=>$tmp){
+ // do each of the page numbering systems
+ // firstly, find the total pages for this one
+ $k = $this->ezPRVTpageNumberSearch('stopt',$tmp);
+ if ($k && $k>0){
+ $totalPages = $k-1;
+ } else {
+ $l = $this->ezPRVTpageNumberSearch('stoptn',$tmp);
+ if ($l && $l>0){
+ $totalPages = $l;
+ } else {
+ $totalPages = $totalPages1;
+ foreach ($this->ezPages as $pageNum=>$id){
+ if (isset($tmp[$pageNum])){
+ if (is_array($tmp[$pageNum])){
+ // then this must be starting page numbers
+ $status=1;
+ $info = $tmp[$pageNum];
+ $info['dnum']=$info['num']-$pageNum;
+ // also check for the special case of the numbering stopping and starting on the same page
+ if (isset($info['stopn']) || isset($info['stoptn']) ){
+ $status=2;
+ } else if ($tmp[$pageNum]=='stop' || $tmp[$pageNum]=='stopt'){
+ // then we are stopping page numbers
+ $status=0;
+ } else if ($status==1 && ($tmp[$pageNum]=='stoptn' || $tmp[$pageNum]=='stopn')){
+ $status=2;
+ if ($status){
+ // then add the page numbering to this page
+ if (strlen($info['num'])){
+ $num=$pageNum+$info['dnum'];
+ } else {
+ $num=$pageNum;
+ $total = $totalPages+$num-$pageNum;
+ $pat = str_replace('{PAGENUM}',$num,$info['pattern']);
+ $pat = str_replace('{TOTALPAGENUM}',$total,$pat);
+ $this->reopenObject($id);
+ switch($info['pos']){
+ case 'right':
+ $this->addText($info['x'],$info['y'],$info['size'],$pat);
+ break;
+ default:
+ $w=$this->getTextWidth($info['size'],$pat);
+ $this->addText($info['x']-$w,$info['y'],$info['size'],$pat);
+ break;
+ $this->closeObject();
+ if ($status==2){
+ $status=0;
+function ezPRVTcleanUp(){
+ $this->ezPRVTaddPageNumbers();
+function ezStream($options=''){
+ $this->ezPRVTcleanUp();
+ $this->stream($options);
+function ezOutput($options=0){
+ return $this->output($options);
+function ezSetY($y){
+ // used to change the vertical position of the writing point.
+ $this->y = $y;
+ if ( $this->y < $this->ez['bottomMargin']){
+function ezSetDy($dy,$mod=''){
+ // changes up by a positive increment, so enter a negative number to go
+ // down the page
+ // if $mod is set to 'makeSpace' and a new page is forced, then the pointed will be moved
+ // down on the new page, this will allow space to be reserved for graphics etc.
+ $this->y += $dy;
+ if ($mod=='makeSpace'){
+ $this->y += $dy;
+function ezPrvtTableDrawLines($pos,$gap,$x0,$x1,$y0,$y1,$y2,$col,$inner,$outer,$opt=1){
+ $x0=1000;
+ $x1=0;
+ $this->setStrokeColor($col[0],$col[1],$col[2]);
+ $cnt=0;
+ $n = count($pos);
+ foreach($pos as $x){
+ $cnt++;
+ if ($cnt==1 || $cnt==$n){
+ $this->setLineStyle($outer);
+ } else {
+ $this->setLineStyle($inner);
+ $this->line($x-$gap/2,$y0,$x-$gap/2,$y2);
+ if ($x>$x1){ $x1=$x; };
+ if ($x<$x0){ $x0=$x; };
+ $this->line($x0-$gap/2-$outer/2,$y0,$x1-$gap/2+$outer/2,$y0);
+ // only do the second line if it is different to the first, AND each row does not have
+ // a line on it.
+ if ($y0!=$y1 && $opt<2){
+ $this->line($x0-$gap/2,$y1,$x1-$gap/2,$y1);
+ $this->line($x0-$gap/2-$outer/2,$y2,$x1-$gap/2+$outer/2,$y2);
+function ezPrvtTableColumnHeadings($cols,$pos,$maxWidth,$height,$decender,$gap,$size,&$y,$optionsAll=array()){
+ // uses ezText to add the text, and returns the height taken by the largest heading
+ // this page will move the headings to a new page if they will not fit completely on this one
+ // transaction support will be used to implement this
+ if (isset($optionsAll['cols'])){
+ $options = $optionsAll['cols'];
+ } else {
+ $options = array();
+ $mx=0;
+ $startPage = $this->ezPageCount;
+ $secondGo=0;
+ // $y is the position at which the top of the table should start, so the base
+ // of the first text, is $y-$height-$gap-$decender, but ezText starts by dropping $height
+ // the return from this function is the total cell height, including gaps, and $y is adjusted
+ // to be the postion of the bottom line
+ // begin the transaction
+ $this->transaction('start');
+ $ok=0;
+// $y-=$gap-$decender;
+ $y-=$gap;
+ while ($ok==0){
+ foreach($cols as $colName=>$colHeading){
+ $this->ezSetY($y);
+ if (isset($options[$colName]) && isset($options[$colName]['justification'])){
+ $justification = $options[$colName]['justification'];
+ } else {
+ $justification = 'left';
+ $this->ezText($colHeading,$size,array('aleft'=> $pos[$colName],'aright'=>($maxWidth[$colName]+$pos[$colName]),'justification'=>$justification));
+ $dy = $y-$this->y;
+ if ($dy>$mx){
+ $mx=$dy;
+ $y = $y - $mx - $gap + $decender;
+// $y -= $mx-$gap+$decender;
+ // now, if this has moved to a new page, then abort the transaction, move to a new page, and put it there
+ // do not check on the second time around, to avoid an infinite loop
+ if ($this->ezPageCount != $startPage && $secondGo==0){
+ $this->transaction('rewind');
+ $y = $this->y - $gap-$decender;
+ $ok=0;
+ $secondGo=1;
+// $y = $store_y;
+ $mx=0;
+ } else {
+ $this->transaction('commit');
+ $ok=1;
+ return $mx+$gap*2-$decender;
+function ezPrvtGetTextWidth($size,$text){
+ // will calculate the maximum width, taking into account that the text may be broken
+ // by line breaks.
+ $mx=0;
+ $lines = explode("\n",$text);
+ foreach ($lines as $line){
+ $w = $this->getTextWidth($size,$line);
+ if ($w>$mx){
+ $mx=$w;
+ return $mx;
+function ezTable(&$data,$cols='',$title='',$options=''){
+ // add a table of information to the pdf document
+ // $data is a two dimensional array
+ // $cols (optional) is an associative array, the keys are the names of the columns from $data
+ // to be presented (and in that order), the values are the titles to be given to the columns
+ // $title (optional) is the title to be put on the top of the table
+ // $options is an associative array which can contain:
+ // 'showLines'=> 0,1,2, default is 1 (show outside and top lines only), 2=> lines on each row
+ // 'showHeadings' => 0 or 1
+ // 'shaded'=> 0,1,2,3 default is 1 (1->alternate lines are shaded, 0->no shading, 2-> both shaded, second uses shadeCol2)
+ // 'shadeCol' => (r,g,b) array, defining the colour of the shading, default is (0.8,0.8,0.8)
+ // 'shadeCol2' => (r,g,b) array, defining the colour of the shading of the other blocks, default is (0.7,0.7,0.7)
+ // 'fontSize' => 10
+ // 'textCol' => (r,g,b) array, text colour
+ // 'titleFontSize' => 12
+ // 'rowGap' => 2 , the space added at the top and bottom of each row, between the text and the lines
+ // 'colGap' => 5 , the space on the left and right sides of each cell
+ // 'lineCol' => (r,g,b) array, defining the colour of the lines, default, black.
+ // 'xPos' => 'left','right','center','centre',or coordinate, reference coordinate in the x-direction
+ // 'xOrientation' => 'left','right','center','centre', position of the table w.r.t 'xPos'
+ // 'width'=> <number> which will specify the width of the table, if it turns out to not be this
+ // wide, then it will stretch the table to fit, if it is wider then each cell will be made
+ // proportionalty smaller, and the content may have to wrap.
+ // 'maxWidth'=> <number> similar to 'width', but will only make table smaller than it wants to be
+ // 'options' => array(<colname>=>array('justification'=>'left','width'=>100,'link'=>linkDataName),<colname>=>....)
+ // allow the setting of other paramaters for the individual columns
+ // 'minRowSpace'=> the minimum space between the bottom of each row and the bottom margin, in which a new row will be started
+ // if it is less, then a new page would be started, default=-100
+ // 'innerLineThickness'=>1
+ // 'outerLineThickness'=>1
+ // 'splitRows'=>0, 0 or 1, whether or not to allow the rows to be split across page boundaries
+ // 'protectRows'=>number, the number of rows to hold with the heading on page, ie, if there less than this number of
+ // rows on the page, then move the whole lot onto the next page, default=1
+ // note that the user will have had to make a font selection already or this will not
+ // produce a valid pdf file.
+ if (!is_array($data)){
+ return;
+ if (!is_array($cols)){
+ // take the columns from the first row of the data set
+ reset($data);
+ list($k,$v)=each($data);
+ if (!is_array($v)){
+ return;
+ $cols=array();
+ foreach($v as $k1=>$v1){
+ $cols[$k1]=$k1;
+ if (!is_array($options)){
+ $options=array();
+ $defaults = array(
+ 'shaded'=>1,'showLines'=>1,'shadeCol'=>array(0.8,0.8,0.8),'shadeCol2'=>array(0.7,0.7,0.7),'fontSize'=>10,'titleFontSize'=>12
+ ,'titleGap'=>5,'lineCol'=>array(0,0,0),'gap'=>5,'xPos'=>'centre','xOrientation'=>'centre'
+ ,'showHeadings'=>1,'textCol'=>array(0,0,0),'width'=>0,'maxWidth'=>0,'cols'=>array(),'minRowSpace'=>-100,'rowGap'=>2,'colGap'=>5
+ ,'innerLineThickness'=>1,'outerLineThickness'=>1,'splitRows'=>0,'protectRows'=>1
+ foreach($defaults as $key=>$value){
+ if (is_array($value)){
+ if (!isset($options[$key]) || !is_array($options[$key])){
+ $options[$key]=$value;
+ } else {
+ if (!isset($options[$key])){
+ $options['gap']=2*$options['colGap'];
+ $middle = ($this->ez['pageWidth']-$this->ez['rightMargin'])/2+($this->ez['leftMargin'])/2;
+ // figure out the maximum widths of the text within each column
+ $maxWidth=array();
+ $maxWidth[$colName]=0;
+ // find the maximum cell widths based on the data
+ foreach($data as $row){
+ $w = $this->ezPrvtGetTextWidth($options['fontSize'],(string)$row[$colName])*1.01;
+ if ($w > $maxWidth[$colName]){
+ $maxWidth[$colName]=$w;
+ // and the maximum widths to fit in the headings
+ foreach($cols as $colName=>$colTitle){
+ $w = $this->ezPrvtGetTextWidth($options['fontSize'],(string)$colTitle)*1.01;
+ // calculate the start positions of each of the columns
+ $pos=array();
+ $x=0;
+ $t=$x;
+ $adjustmentWidth=0;
+ $setWidth=0;
+ foreach($maxWidth as $colName => $w){
+ $pos[$colName]=$t;
+ // if the column width has been specified then set that here, also total the
+ // width avaliable for adjustment
+ if (isset($options['cols'][$colName]) && isset($options['cols'][$colName]['width']) && $options['cols'][$colName]['width']>0){
+ $t=$t+$options['cols'][$colName]['width'];
+ $maxWidth[$colName] = $options['cols'][$colName]['width']-$options['gap'];
+ $setWidth += $options['cols'][$colName]['width'];
+ } else {
+ $t=$t+$w+$options['gap'];
+ $adjustmentWidth += $w;
+ $setWidth += $options['gap'];
+ $pos['_end_']=$t;
+ // if maxWidth is specified, and the table is too wide, and the width has not been set,
+ // then set the width.
+ if ($options['width']==0 && $options['maxWidth'] && ($t-$x)>$options['maxWidth']){
+ // then need to make this one smaller
+ $options['width']=$options['maxWidth'];
+ if ($options['width'] && $adjustmentWidth>0 && $setWidth<$options['width']){
+ // first find the current widths of the columns involved in this mystery
+ $cols0 = array();
+ $cols1 = array();
+ $xq=0;
+ $presentWidth=0;
+ $last='';
+ foreach($pos as $colName=>$p){
+ if (!isset($options['cols'][$last]) || !isset($options['cols'][$last]['width']) || $options['cols'][$last]['width']<=0){
+ if (strlen($last)){
+ $cols0[$last]=$p-$xq -$options['gap'];
+ $presentWidth += ($p-$xq - $options['gap']);
+ } else {
+ $cols1[$last]=$p-$xq;
+ $last=$colName;
+ $xq=$p;
+ // $cols0 contains the widths of all the columns which are not set
+ $neededWidth = $options['width']-$setWidth;
+ // if needed width is negative then add it equally to each column, else get more tricky
+ if ($presentWidth<$neededWidth){
+ foreach($cols0 as $colName=>$w){
+ $cols0[$colName]+= ($neededWidth-$presentWidth)/count($cols0);
+ } else {
+ $cnt=0;
+ while ($presentWidth>$neededWidth && $cnt<100){
+ $cnt++; // insurance policy
+ // find the widest columns, and the next to widest width
+ $aWidest = array();
+ $nWidest=0;
+ $widest=0;
+ if ($w>$widest){
+ $aWidest=array($colName);
+ $nWidest = $widest;
+ $widest=$w;
+ } else if ($w==$widest){
+ $aWidest[]=$colName;
+ // then figure out what the width of the widest columns would have to be to take up all the slack
+ $newWidestWidth = $widest - ($presentWidth-$neededWidth)/count($aWidest);
+ if ($newWidestWidth > $nWidest){
+ // then there is space to set them to this
+ foreach($aWidest as $colName){
+ $cols0[$colName] = $newWidestWidth;
+ $presentWidth=$neededWidth;
+ } else {
+ // there is not space, reduce the size of the widest ones down to the next size down, and we
+ // will go round again
+ $cols0[$colName] = $nWidest;
+ $presentWidth=$presentWidth-($widest-$nWidest)*count($aWidest);
+ // $cols0 now contains the new widths of the constrained columns.
+ // now need to update the $pos and $maxWidth arrays
+ $xq=0;
+ $pos[$colName]=$xq;
+ if (!isset($options['cols'][$colName]) || !isset($options['cols'][$colName]['width']) || $options['cols'][$colName]['width']<=0){
+ if (isset($cols0[$colName])){
+ $xq += $cols0[$colName] + $options['gap'];
+ $maxWidth[$colName]=$cols0[$colName];
+ } else {
+ if (isset($cols1[$colName])){
+ $xq += $cols1[$colName];
+ $t=$x+$options['width'];
+ $pos['_end_']=$t;
+ // now adjust the table to the correct location across the page
+ switch ($options['xPos']){
+ case 'left':
+ $xref = $this->ez['leftMargin'];
+ break;
+ case 'right':
+ $xref = $this->ez['pageWidth'] - $this->ez['rightMargin'];
+ break;
+ case 'centre':
+ case 'center':
+ $xref = $middle;
+ break;
+ default:
+ $xref = $options['xPos'];
+ break;
+ switch ($options['xOrientation']){
+ case 'left':
+ $dx = $xref-$t;
+ break;
+ case 'right':
+ $dx = $xref;
+ break;
+ case 'centre':
+ case 'center':
+ $dx = $xref-$t/2;
+ break;
+ foreach($pos as $k=>$v){
+ $pos[$k]=$v+$dx;
+ $x0=$x+$dx;
+ $x1=$t+$dx;
+ $baseLeftMargin = $this->ez['leftMargin'];
+ $basePos = $pos;
+ $baseX0 = $x0;
+ $baseX1 = $x1;
+ // ok, just about ready to make me a table
+ $this->setColor($options['textCol'][0],$options['textCol'][1],$options['textCol'][2]);
+ $this->setStrokeColor($options['shadeCol'][0],$options['shadeCol'][1],$options['shadeCol'][2]);
+ $middle = ($x1+$x0)/2;
+ // start a transaction which will be used to regress the table, if there are not enough rows protected
+ if ($options['protectRows']>0){
+ $movedOnce=0;
+ $abortTable = 1;
+ while ($abortTable){
+ $abortTable=0;
+ $dm = $this->ez['leftMargin']-$baseLeftMargin;
+ foreach($basePos as $k=>$v){
+ $pos[$k]=$v+$dm;
+ $x0=$baseX0+$dm;
+ $x1=$baseX1+$dm;
+ // if the title is set, then do that
+ if (strlen($title)){
+ $w = $this->getTextWidth($options['titleFontSize'],$title);
+ $this->y -= $this->getFontHeight($options['titleFontSize']);
+ if ($this->y < $this->ez['bottomMargin']){
+ // margins may have changed on the newpage
+ $pos[$k]=$v+$dm;
+ $x0=$baseX0+$dm;
+ $x1=$baseX1+$dm;
+ $this->addText($middle-$w/2,$this->y,$options['titleFontSize'],$title);
+ $this->y -= $options['titleGap'];
+ $pos[$k]=$v+$dm;
+ $x0=$baseX0+$dm;
+ $x1=$baseX1+$dm;
+ $y=$this->y; // to simplify the code a bit
+ // make the table
+ $height = $this->getFontHeight($options['fontSize']);
+ $decender = $this->getFontDecender($options['fontSize']);
+ $y0=$y+$decender;
+ $dy=0;
+ if ($options['showHeadings']){
+ // this function will move the start of the table to a new page if it does not fit on this one
+ $headingHeight = $this->ezPrvtTableColumnHeadings($cols,$pos,$maxWidth,$height,$decender,$options['rowGap'],$options['fontSize'],$y,$options);
+ $y0 = $y+$headingHeight;
+ $y1 = $y;
+ $pos[$k]=$v+$dm;
+ $x0=$baseX0+$dm;
+ $x1=$baseX1+$dm;
+ } else {
+ $y1 = $y0;
+ $firstLine=1;
+ // open an object here so that the text can be put in over the shading
+ if ($options['shaded']){
+ $this->saveState();
+ $textObjectId = $this->openObject();
+ $this->addObject($textObjectId);
+ $this->reopenObject($textObjectId);
+ $cnt=0;
+ $newPage=0;
+ $cnt++;
+ // the transaction support will be used to prevent rows being split
+ if ($options['splitRows']==0){
+ $pageStart = $this->ezPageCount;
+ $columnStart = $this->ez['columns']['colNum'];
+ $row_orig = $row;
+ $y_orig = $y;
+ $y0_orig = $y0;
+ $y1_orig = $y1;
+ $ok=0;
+ $secondTurn=0;
+ while(!$abortTable && $ok == 0){
+ $mx=0;
+ $newRow=1;
+ while(!$abortTable && ($newPage || $newRow)){
+ $y-=$height;
+ if ($newPage || $y<$this->ez['bottomMargin'] || (isset($options['minRowSpace']) && $y<($this->ez['bottomMargin']+$options['minRowSpace'])) ){
+ // check that enough rows are with the heading
+ if ($options['protectRows']>0 && $movedOnce==0 && $cnt<=$options['protectRows']){
+ // then we need to move the whole table onto the next page
+ $movedOnce = 1;
+ $abortTable = 1;
+ $y2=$y-$mx+2*$height+$decender-$newRow*$height;
+ if ($options['showLines']){
+ if (!$options['showHeadings']){
+ $y0=$y1;
+ $this->ezPrvtTableDrawLines($pos,$options['gap'],$x0,$x1,$y0,$y1,$y2,$options['lineCol'],$options['innerLineThickness'],$options['outerLineThickness'],$options['showLines']);
+ $this->restoreState();
+ // and the margins may have changed, this is due to the possibility of the columns being turned on
+ // as the columns are managed by manipulating the margins
+ $pos[$k]=$v+$dm;
+// $x0=$x0+$dm;
+// $x1=$x1+$dm;
+ $x0=$baseX0+$dm;
+ $x1=$baseX1+$dm;
+ $this->setColor($options['textCol'][0],$options['textCol'][1],$options['textCol'][2],1);
+ $y = $this->ez['pageHeight']-$this->ez['topMargin'];
+ $y0=$y+$decender;
+ $mx=0;
+ $this->ezPrvtTableColumnHeadings($cols,$pos,$maxWidth,$height,$decender,$options['rowGap'],$options['fontSize'],$y,$options);
+ $y1=$y;
+ } else {
+ $y1=$y0;
+ $firstLine=1;
+ $y -= $height;
+ $newRow=0;
+ // write the actual data
+ // if these cells need to be split over a page, then $newPage will be set, and the remaining
+ // text will be placed in $leftOvers
+ $newPage=0;
+ $leftOvers=array();
+ $this->ezSetY($y+$height);
+ $colNewPage=0;
+ if (isset($row[$colName])){
+ if (isset($options['cols'][$colName]) && isset($options['cols'][$colName]['link']) && strlen($options['cols'][$colName]['link'])){
+ $lines = explode("\n",$row[$colName]);
+ if (isset($row[$options['cols'][$colName]['link']]) && strlen($row[$options['cols'][$colName]['link']])){
+ foreach($lines as $k=>$v){
+ $lines[$k]='<c:alink:'.$row[$options['cols'][$colName]['link']].'>'.$v.'</c:alink>';
+ } else {
+ } else {
+ $lines = array();
+ $this->y -= $options['rowGap'];
+ $line = $this->ezProcessText($line);
+ $start=1;
+ while (strlen($line) || $start){
+ $start=0;
+ if (!$colNewPage){
+ $this->y=$this->y-$height;
+ // $this->ezNewPage();
+ $newPage=1; // whether a new page is required for any of the columns
+ $colNewPage=1; // whether a new page is required for this column
+ if ($colNewPage){
+ if (isset($leftOvers[$colName])){
+ $leftOvers[$colName].="\n".$line;
+ } else {
+ $leftOvers[$colName] = $line;
+ $line='';
+ } else {
+ if (isset($options['cols'][$colName]) && isset($options['cols'][$colName]['justification']) ){
+ $just = $options['cols'][$colName]['justification'];
+ } else {
+ $just='left';
+ $line=$this->addTextWrap($pos[$colName],$this->y,$maxWidth[$colName],$options['fontSize'],$line,$just);
+ $dy=$y+$height-$this->y+$options['rowGap'];
+ if ($dy-$height*$newPage>$mx){
+ $mx=$dy-$height*$newPage;
+ // set $row to $leftOvers so that they will be processed onto the new page
+ $row = $leftOvers;
+ // now add the shading underneath
+ if ($options['shaded'] && $cnt%2==0){
+ $this->setColor($options['shadeCol'][0],$options['shadeCol'][1],$options['shadeCol'][2],1);
+ $this->filledRectangle($x0-$options['gap']/2,$y+$decender+$height-$mx,$x1-$x0,$mx);
+ if ($options['shaded']==2 && $cnt%2==1){
+ $this->setColor($options['shadeCol2'][0],$options['shadeCol2'][1],$options['shadeCol2'][2],1);
+ if ($options['showLines']>1){
+ // then draw a line on the top of each block
+// $this->closeObject();
+ $this->setStrokeColor($options['lineCol'][0],$options['lineCol'][1],$options['lineCol'][2],1);
+// $this->line($x0-$options['gap']/2,$y+$decender+$height-$mx,$x1-$x0,$mx);
+ if ($firstLine){
+ $this->setLineStyle($options['outerLineThickness']);
+ $firstLine=0;
+ } else {
+ $this->setLineStyle($options['innerLineThickness']);
+ $this->line($x0-$options['gap']/2,$y+$decender+$height,$x1-$options['gap']/2,$y+$decender+$height);
+// $this->reopenObject($textObjectId);
+ } // end of while
+ $y=$y-$mx+$height;
+ // checking row split over pages
+ if ( ( ($this->ezPageCount != $pageStart) || (isset($this->ez['columns']) && $this->ez['columns']['on']==1 && $columnStart != $this->ez['columns']['colNum'] )) && $secondTurn==0){
+ // then we need to go back and try that again !
+ $newPage=1;
+ $secondTurn=1;
+ $row = $row_orig;
+ $y = $y_orig;
+ $y0 = $y0_orig;
+ $y1 = $y1_orig;
+ $ok=0;
+ $pos[$k]=$v+$dm;
+ $x0=$baseX0+$dm;
+ $x1=$baseX1+$dm;
+ } else {
+ $ok=1;
+ } else {
+ $ok=1; // don't go round the loop if splitting rows is allowed
+ } // end of while to check for row splitting
+ if ($abortTable){
+ if ($ok==0){
+ $this->transaction('abort');
+ // only the outer transaction should be operational
+ break;
+ } // end of foreach ($data as $row)
+ } // end of while ($abortTable)
+ // table has been put on the page, the rows guarded as required, commit.
+ $y2=$y+$decender;
+ $y0=$y1;
+ // close the object for drawing the text on top
+ $this->y=$y;
+ return $y;
+function ezProcessText($text){
+ // this function will intially be used to implement underlining support, but could be used for a range of other
+ // purposes
+ $search = array('<u>','<U>','</u>','</U>');
+ $replace = array('<c:uline>','<c:uline>','</c:uline>','</c:uline>');
+ return str_replace($search,$replace,$text);
+function ezText($text,$size=0,$options=array(),$test=0){
+ // this will add a string of text to the document, starting at the current drawing
+ // position.
+ // it will wrap to keep within the margins, including optional offsets from the left
+ // and the right, if $size is not specified, then it will be the last one used, or
+ // the default value (12 I think).
+ // the text will go to the start of the next line when a return code "\n" is found.
+ // possible options are:
+ // 'left'=> number, gap to leave from the left margin
+ // 'right'=> number, gap to leave from the right margin
+ // 'aleft'=> number, absolute left position (overrides 'left')
+ // 'aright'=> number, absolute right position (overrides 'right')
+ // 'justification' => 'left','right','center','centre','full'
+ // only set one of the next two items (leading overrides spacing)
+ // 'leading' => number, defines the total height taken by the line, independent of the font height.
+ // 'spacing' => a real number, though usually set to one of 1, 1.5, 2 (line spacing as used in word processing)
+ // if $test is set then this should just check if the text is going to flow onto a new page or not, returning true or false
+ // apply the filtering which will make the underlining function.
+ $text = $this->ezProcessText($text);
+ $newPage=false;
+ $store_y = $this->y;
+ if (is_array($options) && isset($options['aleft'])){
+ $left=$options['aleft'];
+ } else {
+ $left = $this->ez['leftMargin'] + ((is_array($options) && isset($options['left']))?$options['left']:0);
+ if (is_array($options) && isset($options['aright'])){
+ $right=$options['aright'];
+ } else {
+ $right = $this->ez['pageWidth'] - $this->ez['rightMargin'] - ((is_array($options) && isset($options['right']))?$options['right']:0);
+ if ($size<=0){
+ $size = $this->ez['fontSize'];
+ } else {
+ $this->ez['fontSize']=$size;
+ if (is_array($options) && isset($options['justification'])){
+ $just = $options['justification'];
+ } else {
+ $just = 'left';
+ // modifications to give leading and spacing based on those given by Craig Heydenburg 1/1/02
+ if (is_array($options) && isset($options['leading'])) { ## use leading instead of spacing
+ $height = $options['leading'];
+ } else if (is_array($options) && isset($options['spacing'])) {
+ $height = $this->getFontHeight($size) * $options['spacing'];
+ } else {
+ $height = $this->getFontHeight($size);
+ $start=1;
+ $start=0;
+ if ($test){
+ $newPage=true;
+ } else {
+ // and then re-calc the left and right, in case they have changed due to columns
+ } else {
+ } else {
+ $line=$this->addTextWrap($left,$this->y,$right-$left,$size,$line,$just,0,$test);
+ if ($test){
+ $this->y=$store_y;
+ return $newPage;
+ } else {
+ return $this->y;
+function ezImage($image,$pad = 5,$width = 0,$resize = 'full',$just = 'center',$border = ''){
+ //beta ezimage function
+ if (stristr($image,'://'))//copy to temp file
+ $fp = @fopen($image,"rb");
+ while(!feof($fp))
+ $cont.= fread($fp,1024);
+ fclose($fp);
+ $image = tempnam ("/tmp", "php-pdf");
+ $fp2 = @fopen($image,"w");
+ fwrite($fp2,$cont);
+ fclose($fp2);
+ $temp = true;
+ if (!(file_exists($image))) return false; //return immediately if image file does not exist
+ $imageInfo = getimagesize($image);
+ switch ($imageInfo[2]){
+ case 2:
+ $type = "jpeg";
+ break;
+ case 3:
+ $type = "png";
+ break;
+ default:
+ return false; //return if file is not jpg or png
+ if ($width == 0) $width = $imageInfo[0]; //set width
+ $ratio = $imageInfo[0]/$imageInfo[1];
+ //get maximum width of image
+ if (isset($this->ez['columns']) && $this->ez['columns']['on'] == 1)
+ $bigwidth = $this->ez['columns']['width'] - ($pad * 2);
+ else
+ $bigwidth = $this->ez['pageWidth'] - ($pad * 2);
+ //fix width if larger than maximum or if $resize=full
+ if ($resize == 'full' || $resize == 'width' || $width > $bigwidth)
+ $width = $bigwidth;
+ $height = ($width/$ratio); //set height
+ //fix size if runs off page
+ if ($height > ($this->y - $this->ez['bottomMargin'] - ($pad * 2)))
+ if ($resize != 'full')
+ else
+ $height = ($this->y - $this->ez['bottomMargin'] - ($pad * 2)); //shrink height
+ $width = ($height*$ratio); //fix width
+ //fix x-offset if image smaller than bigwidth
+ if ($width < $bigwidth)
+ //center if justification=center
+ if ($just == 'center')
+ $offset = ($bigwidth - $width) / 2;
+ //move to right if justification=right
+ if ($just == 'right')
+ $offset = ($bigwidth - $width);
+ //leave at left if justification=left
+ if ($just == 'left')
+ $offset = 0;
+ //call appropriate function
+ if ($type == "jpeg"){
+ $this->addJpegFromFile($image,$this->ez['leftMargin'] + $pad + $offset, $this->y + $this->getFontHeight($this->ez['fontSize']) - $pad - $height,$width);
+ if ($type == "png"){
+ $this->addPngFromFile($image,$this->ez['leftMargin'] + $pad + $offset, $this->y + $this->getFontHeight($this->ez['fontSize']) - $pad - $height,$width);
+ //draw border
+ if ($border != '')
+ if (!(isset($border['color'])))
+ $border['color']['red'] = .5;
+ $border['color']['blue'] = .5;
+ $border['color']['green'] = .5;
+ if (!(isset($border['width']))) $border['width'] = 1;
+ if (!(isset($border['cap']))) $border['cap'] = 'round';
+ if (!(isset($border['join']))) $border['join'] = 'round';
+ $this->setStrokeColor($border['color']['red'],$border['color']['green'],$border['color']['blue']);
+ $this->setLineStyle($border['width'],$border['cap'],$border['join']);
+ $this->rectangle($this->ez['leftMargin'] + $pad + $offset, $this->y + $this->getFontHeight($this->ez['fontSize']) - $pad - $height,$width,$height);
+ // move y below image
+ $this->y = $this->y - $pad - $height;
+ //remove tempfile for remote images
+ if ($temp == true) unlink($image);
+// note that templating code is still considered developmental - have not really figured
+// out a good way of doing this yet.
+function loadTemplate($templateFile){
+ // this function will load the requested template ($file includes full or relative pathname)
+ // the code for the template will be modified to make it name safe, and then stored in
+ // an array for later use
+ // The id of the template will be returned for the user to operate on it later
+ if (!file_exists($templateFile)){
+ return -1;
+ $code = implode('',file($templateFile));
+ if (!strlen($code)){
+ return;
+ $code = trim($code);
+ if (substr($code,0,5)=='<?php'){
+ $code = substr($code,5);
+ if (substr($code,-2)=='?>'){
+ $code = substr($code,0,strlen($code)-2);
+ if (isset($this->ez['numTemplates'])){
+ $newNum = $this->ez['numTemplates'];
+ $this->ez['numTemplates']++;
+ } else {
+ $newNum=0;
+ $this->ez['numTemplates']=1;
+ $this->ez['templates']=array();
+ $this->ez['templates'][$newNum]['code']=$code;
+ return $newNum;
+function execTemplate($id,$data=array(),$options=array()){
+ // execute the given template on the current document.
+ if (!isset($this->ez['templates'][$id])){
+ return;
+ eval($this->ez['templates'][$id]['code']);
+function ilink($info){
+ $this->alink($info,1);
+function alink($info,$internal=0){
+ // a callback function to support the formation of clickable links within the document
+ $lineFactor=0.05; // the thickness of the line as a proportion of the height. also the drop of the line.
+ switch($info['status']){
+ case 'start':
+ case 'sol':
+ // the beginning of the link
+ // this should contain the URl for the link as the 'p' entry, and will also contain the value of 'nCallback'
+ if (!isset($this->ez['links'])){
+ $this->ez['links']=array();
+ $i = $info['nCallback'];
+ $this->ez['links'][$i] = array('x'=>$info['x'],'y'=>$info['y'],'angle'=>$info['angle'],'decender'=>$info['decender'],'height'=>$info['height'],'url'=>$info['p']);
+ if ($internal==0){
+ $this->setColor(0,0,1);
+ $this->setStrokeColor(0,0,1);
+ $thick = $info['height']*$lineFactor;
+ $this->setLineStyle($thick);
+ break;
+ case 'end':
+ case 'eol':
+ // the end of the link
+ // assume that it is the most recent opening which has closed
+ $start = $this->ez['links'][$i];
+ // add underlining
+ if ($internal){
+ $this->addInternalLink($start['url'],$start['x'],$start['y']+$start['decender'],$info['x'],$start['y']+$start['decender']+$start['height']);
+ } else {
+ $a = deg2rad((float)$start['angle']-90.0);
+ $drop = $start['height']*$lineFactor*1.5;
+ $dropx = cos($a)*$drop;
+ $dropy = -sin($a)*$drop;
+ $this->line($start['x']-$dropx,$start['y']-$dropy,$info['x']-$dropx,$info['y']-$dropy);
+ $this->addLink($start['url'],$start['x'],$start['y']+$start['decender'],$info['x'],$start['y']+$start['decender']+$start['height']);
+ break;
+function uline($info){
+ // a callback function to support underlining
+ case 'start':
+ case 'sol':
+ // the beginning of the underline zone
+ $this->ez['links'][$i] = array('x'=>$info['x'],'y'=>$info['y'],'angle'=>$info['angle'],'decender'=>$info['decender'],'height'=>$info['height']);
+ break;
+ case 'end':
+ case 'eol':
+ break;
\ No newline at end of file
Added: trunk/mapbender/http/classes/class.pdf.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/class.pdf.php?view=auto&rev=13
--- (empty file)
+++ trunk/mapbender/http/classes/class.pdf.php 2006-04-13 19:38:28+0000
@@ -0,0 +1,3075 @@
+<?php
+* Cpdf
+* http://www.ros.co.nz/pdf
+* A PHP class to provide the basic functionality to create a pdf document without
+* any requirement for additional modules.
+* Note that they companion class CezPdf can be used to extend this class and dramatically
+* simplify the creation of documents.
+* IMPORTANT NOTE
+* there is no warranty, implied or otherwise with this software.
+* LICENCE
+* This code has been placed in the Public Domain for all to enjoy.
+* @author Wayne Munro <pdf at ros.co.nz>
+* @version 009
+* @package Cpdf
+class Cpdf {
+* the current number of pdf objects in the document
+var $numObj=0;
+* this array contains all of the pdf objects, ready for final assembly
+var $objects = array();
+* the objectId (number within the objects array) of the document catalog
+var $catalogId;
+* array carrying information about the fonts that the system currently knows about
+* used to ensure that a font is not loaded twice, among other things
+var $fonts=array();
+* a record of the current font
+var $currentFont='';
+* the current base font
+var $currentBaseFont='';
+* the number of the current font within the font array
+var $currentFontNum=0;
+var $currentNode;
+* object number of the current page
+var $currentPage;
+* object number of the currently active contents block
+var $currentContents;
+* number of fonts within the system
+var $numFonts=0;
+* current colour for fill operations, defaults to inactive value, all three components should be between 0 and 1 inclusive when active
+var $currentColour=array('r'=>-1,'g'=>-1,'b'=>-1);
+* current colour for stroke operations (lines etc.)
+var $currentStrokeColour=array('r'=>-1,'g'=>-1,'b'=>-1);
+* current style that lines are drawn in
+var $currentLineStyle='';
+* an array which is used to save the state of the document, mainly the colours and styles
+* it is used to temporarily change to another state, the change back to what it was before
+var $stateStack = array();
+* number of elements within the state stack
+var $nStateStack = 0;
+* number of page objects within the document
+var $numPages=0;
+* object Id storage stack
+var $stack=array();
+* number of elements within the object Id storage stack
+var $nStack=0;
+* an array which contains information about the objects which are not firmly attached to pages
+* these have been added with the addObject function
+var $looseObjects=array();
+* array contains infomation about how the loose objects are to be added to the document
+var $addLooseObjects=array();
+* the objectId of the information object for the document
+* this contains authorship, title etc.
+var $infoObject=0;
+* number of images being tracked within the document
+var $numImages=0;
+* an array containing options about the document
+* it defaults to turning on the compression of the objects
+var $options=array('compression'=>1);
+* the objectId of the first page of the document
+var $firstPageId;
+* used to track the last used value of the inter-word spacing, this is so that it is known
+* when the spacing is changed.
+var $wordSpaceAdjust=0;
+* the object Id of the procset object
+var $procsetObjectId;
+* store the information about the relationship between font families
+* this used so that the code knows which font is the bold version of another font, etc.
+* the value of this array is initialised in the constuctor function.
+var $fontFamilies = array();
+* track if the current font is bolded or italicised
+var $currentTextState = '';
+* messages are stored here during processing, these can be selected afterwards to give some useful debug information
+var $messages='';
+* the ancryption array for the document encryption is stored here
+var $arc4='';
+* the object Id of the encryption information
+var $arc4_objnum=0;
+* the file identifier, used to uniquely identify a pdf document
+var $fileIdentifier='';
+* a flag to say if a document is to be encrypted or not
+var $encrypted=0;
+* the ancryption key for the encryption of all the document content (structure is not encrypted)
+var $encryptionKey='';
+* array which forms a stack to keep track of nested callback functions
+var $callback = array();
+* the number of callback functions in the callback array
+var $nCallback = 0;
+* store label->id pairs for named destinations, these will be used to replace internal links
+* done this way so that destinations can be defined after the location that links to them
+var $destinations = array();
+* store the stack for the transaction commands, each item in here is a record of the values of all the
+* variables within the class, so that the user can rollback at will (from each 'start' command)
+* note that this includes the objects array, so these can be large.
+var $checkpoint = '';
+* class constructor
+* this will start a new document
+* @var array array of 4 numbers, defining the bottom left and upper right corner of the page. first two are normally zero.
+function Cpdf ($pageSize=array(0,0,612,792)){
+ $this->newDocument($pageSize);
+ // also initialize the font families that are known about already
+ $this->setFontFamily('init');
+// $this->fileIdentifier = md5('xxxxxxxx'.time());
+* Document object methods (internal use only)
+* There is about one object method for each type of object in the pdf document
+* Each function has the same call list ($id,$action,$options).
+* $id = the object ID of the object, or what it is to be if it is being created
+* $action = a string specifying the action to be performed, though ALL must support:
+* 'new' - create the object with the id $id
+* 'out' - produce the output for the pdf object
+* $options = optional, a string or array containing the various parameters for the object
+* These, in conjunction with the output function are the ONLY way for output to be produced
+* within the pdf 'file'.
+*destination object, used to specify the location for the user to jump to, presently on opening
+function o_destination($id,$action,$options=''){
+ if ($action!='new'){
+ $o =& $this->objects[$id];
+ switch($action){
+ case 'new':
+ $this->objects[$id]=array('t'=>'destination','info'=>array());
+ $tmp = '';
+ switch ($options['type']){
+ case 'XYZ':
+ case 'FitR':
+ $tmp = ' '.$options['p3'].$tmp;
+ case 'FitH':
+ case 'FitV':
+ case 'FitBH':
+ case 'FitBV':
+ $tmp = ' '.$options['p1'].' '.$options['p2'].$tmp;
+ case 'Fit':
+ case 'FitB':
+ $tmp = $options['type'].$tmp;
+ $this->objects[$id]['info']['string']=$tmp;
+ $this->objects[$id]['info']['page']=$options['page'];
+ break;
+ case 'out':
+ $tmp = $o['info'];
+ $res="\n".$id." 0 obj\n".'['.$tmp['page'].' 0 R /'.$tmp['string']."]\nendobj\n";
+ return $res;
+ break;
+* set the viewer preferences
+function o_viewerPreferences($id,$action,$options=''){
+ switch ($action){
+ case 'new':
+ $this->objects[$id]=array('t'=>'viewerPreferences','info'=>array());
+ break;
+ case 'add':
+ foreach($options as $k=>$v){
+ switch ($k){
+ case 'HideToolbar':
+ case 'HideMenubar':
+ case 'HideWindowUI':
+ case 'FitWindow':
+ case 'CenterWindow':
+ case 'NonFullScreenPageMode':
+ case 'Direction':
+ $o['info'][$k]=$v;
+ break;
+ break;
+ case 'out':
+ $res="\n".$id." 0 obj\n".'<< ';
+ foreach($o['info'] as $k=>$v){
+ $res.="\n/".$k.' '.$v;
+ $res.="\n>>\n";
+ return $res;
+ break;
+* define the document catalog, the overall controller for the document
+function o_catalog($id,$action,$options=''){
+ switch ($action){
+ case 'new':
+ $this->objects[$id]=array('t'=>'catalog','info'=>array());
+ $this->catalogId=$id;
+ break;
+ case 'outlines':
+ case 'pages':
+ case 'openHere':
+ $o['info'][$action]=$options;
+ break;
+ case 'viewerPreferences':
+ if (!isset($o['info']['viewerPreferences'])){
+ $this->numObj++;
+ $this->o_viewerPreferences($this->numObj,'new');
+ $o['info']['viewerPreferences']=$this->numObj;
+ $vp = $o['info']['viewerPreferences'];
+ $this->o_viewerPreferences($vp,'add',$options);
+ break;
+ case 'out':
+ $res="\n".$id." 0 obj\n".'<< /Type /Catalog';
+ switch($k){
+ case 'outlines':
+ $res.="\n".'/Outlines '.$v.' 0 R';
+ break;
+ case 'pages':
+ $res.="\n".'/Pages '.$v.' 0 R';
+ break;
+ $res.="\n".'/ViewerPreferences '.$o['info']['viewerPreferences'].' 0 R';
+ break;
+ case 'openHere':
+ $res.="\n".'/OpenAction '.$o['info']['openHere'].' 0 R';
+ break;
+ $res.=" >>\nendobj";
+ return $res;
+ break;
+* object which is a parent to the pages in the document
+function o_pages($id,$action,$options=''){
+ switch ($action){
+ case 'new':
+ $this->objects[$id]=array('t'=>'pages','info'=>array());
+ $this->o_catalog($this->catalogId,'pages',$id);
+ break;
+ case 'page':
+ // then it will just be the id of the new page
+ $o['info']['pages'][]=$options;
+ } else {
+ // then it should be an array having 'id','rid','pos', where rid=the page to which this one will be placed relative
+ // and pos is either 'before' or 'after', saying where this page will fit.
+ if (isset($options['id']) && isset($options['rid']) && isset($options['pos'])){
+ $i = array_search($options['rid'],$o['info']['pages']);
+ if (isset($o['info']['pages'][$i]) && $o['info']['pages'][$i]==$options['rid']){
+ // then there is a match
+ // make a space
+ switch ($options['pos']){
+ case 'before':
+ $k = $i;
+ break;
+ case 'after':
+ $k=$i+1;
+ break;
+ default:
+ $k=-1;
+ break;
+ if ($k>=0){
+ for ($j=count($o['info']['pages'])-1;$j>=$k;$j--){
+ $o['info']['pages'][$j+1]=$o['info']['pages'][$j];
+ $o['info']['pages'][$k]=$options['id'];
+ break;
+ case 'procset':
+ $o['info']['procset']=$options;
+ break;
+ case 'mediaBox':
+ $o['info']['mediaBox']=$options; // which should be an array of 4 numbers
+ break;
+ case 'font':
+ $o['info']['fonts'][]=array('objNum'=>$options['objNum'],'fontNum'=>$options['fontNum']);
+ break;
+ case 'xObject':
+ $o['info']['xObjects'][]=array('objNum'=>$options['objNum'],'label'=>$options['label']);
+ break;
+ case 'out':
+ if (count($o['info']['pages'])){
+ $res="\n".$id." 0 obj\n<< /Type /Pages\n/Kids [";
+ foreach($o['info']['pages'] as $k=>$v){
+ $res.=$v." 0 R\n";
+ $res.="]\n/Count ".count($this->objects[$id]['info']['pages']);
+ if ((isset($o['info']['fonts']) && count($o['info']['fonts'])) || isset($o['info']['procset'])){
+ $res.="\n/Resources <<";
+ if (isset($o['info']['procset'])){
+ $res.="\n/ProcSet ".$o['info']['procset']." 0 R";
+ if (isset($o['info']['fonts']) && count($o['info']['fonts'])){
+ $res.="\n/Font << ";
+ foreach($o['info']['fonts'] as $finfo){
+ $res.="\n/F".$finfo['fontNum']." ".$finfo['objNum']." 0 R";
+ $res.=" >>";
+ if (isset($o['info']['xObjects']) && count($o['info']['xObjects'])){
+ $res.="\n/XObject << ";
+ foreach($o['info']['xObjects'] as $finfo){
+ $res.="\n/".$finfo['label']." ".$finfo['objNum']." 0 R";
+ $res.=" >>";
+ $res.="\n>>";
+ if (isset($o['info']['mediaBox'])){
+ $tmp=$o['info']['mediaBox'];
+ $res.="\n/MediaBox [".sprintf('%.3f',$tmp[0]).' '.sprintf('%.3f',$tmp[1]).' '.sprintf('%.3f',$tmp[2]).' '.sprintf('%.3f',$tmp[3]).']';
+ $res.="\n >>\nendobj";
+ } else {
+ $res="\n".$id." 0 obj\n<< /Type /Pages\n/Count 0\n>>\nendobj";
+ return $res;
+ break;
+* define the outlines in the doc, empty for now
+function o_outlines($id,$action,$options=''){
+ switch ($action){
+ case 'new':
+ $this->objects[$id]=array('t'=>'outlines','info'=>array('outlines'=>array()));
+ $this->o_catalog($this->catalogId,'outlines',$id);
+ break;
+ case 'outline':
+ $o['info']['outlines'][]=$options;
+ break;
+ case 'out':
+ if (count($o['info']['outlines'])){
+ $res="\n".$id." 0 obj\n<< /Type /Outlines /Kids [";
+ foreach($o['info']['outlines'] as $k=>$v){
+ $res.=$v." 0 R ";
+ $res.="] /Count ".count($o['info']['outlines'])." >>\nendobj";
+ } else {
+ $res="\n".$id." 0 obj\n<< /Type /Outlines /Count 0 >>\nendobj";
+ return $res;
+ break;
+* an object to hold the font description
+function o_font($id,$action,$options=''){
+ switch ($action){
+ case 'new':
+ $this->objects[$id]=array('t'=>'font','info'=>array('name'=>$options['name'],'SubType'=>'Type1'));
+ $fontNum=$this->numFonts;
+ $this->objects[$id]['info']['fontNum']=$fontNum;
+ // deal with the encoding and the differences
+ if (isset($options['differences'])){
+ // then we'll need an encoding dictionary
+ $this->numObj++;
+ $this->o_fontEncoding($this->numObj,'new',$options);
+ $this->objects[$id]['info']['encodingDictionary']=$this->numObj;
+ } else if (isset($options['encoding'])){
+ // we can specify encoding here
+ switch($options['encoding']){
+ case 'WinAnsiEncoding':
+ case 'MacRomanEncoding':
+ case 'MacExpertEncoding':
+ $this->objects[$id]['info']['encoding']=$options['encoding'];
+ break;
+ case 'none':
+ break;
+ default:
+ $this->objects[$id]['info']['encoding']='WinAnsiEncoding';
+ break;
+ } else {
+ // also tell the pages node about the new font
+ $this->o_pages($this->currentNode,'font',array('fontNum'=>$fontNum,'objNum'=>$id));
+ break;
+ case 'add':
+ foreach ($options as $k=>$v){
+ switch ($k){
+ case 'BaseFont':
+ $o['info']['name'] = $v;
+ break;
+ case 'FirstChar':
+ case 'LastChar':
+ case 'Widths':
+ case 'FontDescriptor':
+ case 'SubType':
+ $this->addMessage('o_font '.$k." : ".$v);
+ $o['info'][$k] = $v;
+ break;
+ break;
+ case 'out':
+ $res="\n".$id." 0 obj\n<< /Type /Font\n/Subtype /".$o['info']['SubType']."\n";
+ $res.="/Name /F".$o['info']['fontNum']."\n";
+ $res.="/BaseFont /".$o['info']['name']."\n";
+ if (isset($o['info']['encodingDictionary'])){
+ // then place a reference to the dictionary
+ $res.="/Encoding ".$o['info']['encodingDictionary']." 0 R\n";
+ } else if (isset($o['info']['encoding'])){
+ // use the specified encoding
+ $res.="/Encoding /".$o['info']['encoding']."\n";
+ if (isset($o['info']['FirstChar'])){
+ $res.="/FirstChar ".$o['info']['FirstChar']."\n";
+ if (isset($o['info']['LastChar'])){
+ $res.="/LastChar ".$o['info']['LastChar']."\n";
+ if (isset($o['info']['Widths'])){
+ $res.="/Widths ".$o['info']['Widths']." 0 R\n";
+ if (isset($o['info']['FontDescriptor'])){
+ $res.="/FontDescriptor ".$o['info']['FontDescriptor']." 0 R\n";
+ $res.=">>\nendobj";
+ return $res;
+ break;
+* a font descriptor, needed for including additional fonts
+function o_fontDescriptor($id,$action,$options=''){
+ switch ($action){
+ case 'new':
+ $this->objects[$id]=array('t'=>'fontDescriptor','info'=>$options);
+ break;
+ case 'out':
+ $res="\n".$id." 0 obj\n<< /Type /FontDescriptor\n";
+ foreach ($o['info'] as $label => $value){
+ switch ($label){
+ case 'Ascent':
+ case 'CapHeight':
+ case 'Descent':
+ case 'Flags':
+ case 'ItalicAngle':
+ case 'StemV':
+ case 'AvgWidth':
+ case 'Leading':
+ case 'MaxWidth':
+ case 'MissingWidth':
+ case 'StemH':
+ case 'XHeight':
+ case 'CharSet':
+ if (strlen($value)){
+ $res.='/'.$label.' '.$value."\n";
+ break;
+ case 'FontFile':
+ case 'FontFile2':
+ case 'FontFile3':
+ $res.='/'.$label.' '.$value." 0 R\n";
+ break;
+ case 'FontBBox':
+ $res.='/'.$label.' ['.$value[0].' '.$value[1].' '.$value[2].' '.$value[3]."]\n";
+ break;
+ case 'FontName':
+ $res.='/'.$label.' /'.$value."\n";
+ break;
+ return $res;
+ break;
+* the font encoding
+function o_fontEncoding($id,$action,$options=''){
+ switch ($action){
+ case 'new':
+ // the options array should contain 'differences' and maybe 'encoding'
+ $this->objects[$id]=array('t'=>'fontEncoding','info'=>$options);
+ break;
+ case 'out':
+ $res="\n".$id." 0 obj\n<< /Type /Encoding\n";
+ if (!isset($o['info']['encoding'])){
+ $o['info']['encoding']='WinAnsiEncoding';
+ if ($o['info']['encoding']!='none'){
+ $res.="/BaseEncoding /".$o['info']['encoding']."\n";
+ $res.="/Differences \n[";
+ $onum=-100;
+ foreach($o['info']['differences'] as $num=>$label){
+ if ($num!=$onum+1){
+ // we cannot make use of consecutive numbering
+ $res.= "\n".$num." /".$label;
+ } else {
+ $res.= " /".$label;
+ $onum=$num;
+ $res.="\n]\n>>\nendobj";
+ return $res;
+ break;
+* the document procset, solves some problems with printing to old PS printers
+function o_procset($id,$action,$options=''){
+ switch ($action){
+ case 'new':
+ $this->objects[$id]=array('t'=>'procset','info'=>array('PDF'=>1,'Text'=>1));
+ $this->o_pages($this->currentNode,'procset',$id);
+ $this->procsetObjectId=$id;
+ break;
+ case 'add':
+ // this is to add new items to the procset list, despite the fact that this is considered
+ // obselete, the items are required for printing to some postscript printers
+ switch ($options) {
+ case 'ImageB':
+ case 'ImageC':
+ case 'ImageI':
+ $o['info'][$options]=1;
+ break;
+ break;
+ case 'out':
+ $res="\n".$id." 0 obj\n[";
+ foreach ($o['info'] as $label=>$val){
+ $res.='/'.$label.' ';
+ $res.="]\nendobj";
+ return $res;
+ break;
+* define the document information
+function o_info($id,$action,$options=''){
+ switch ($action){
+ case 'new':
+ $this->infoObject=$id;
+ $date='D:'.date('Ymd');
+ $this->objects[$id]=array('t'=>'info','info'=>array('Creator'=>'R and OS php pdf writer, http://www.ros.co.nz','CreationDate'=>$date));
+ break;
+ case 'Title':
+ case 'Author':
+ case 'Subject':
+ case 'Keywords':
+ case 'Creator':
+ case 'Producer':
+ case 'CreationDate':
+ case 'ModDate':
+ case 'Trapped':
+ break;
+ case 'out':
+ if ($this->encrypted){
+ $this->encryptInit($id);
+ $res="\n".$id." 0 obj\n<<\n";
+ foreach ($o['info'] as $k=>$v){
+ $res.='/'.$k.' (';
+ $res.=$this->filterText($this->ARC4($v));
+ } else {
+ $res.=$this->filterText($v);
+ $res.=")\n";
+ return $res;
+ break;
+* an action object, used to link to URLS initially
+function o_action($id,$action,$options=''){
+ switch ($action){
+ case 'new':
+ if (is_array($options)){
+ $this->objects[$id]=array('t'=>'action','info'=>$options,'type'=>$options['type']);
+ } else {
+ // then assume a URI action
+ $this->objects[$id]=array('t'=>'action','info'=>$options,'type'=>'URI');
+ break;
+ case 'out':
+ $res="\n".$id." 0 obj\n<< /Type /Action";
+ switch($o['type']){
+ case 'ilink':
+ // there will be an 'label' setting, this is the name of the destination
+ $res.="\n/S /GoTo\n/D ".$this->destinations[(string)$o['info']['label']]." 0 R";
+ break;
+ case 'URI':
+ $res.="\n/S /URI\n/URI (";
+ $res.=$this->filterText($this->ARC4($o['info']));
+ } else {
+ $res.=$this->filterText($o['info']);
+ $res.=")";
+ break;
+ $res.="\n>>\nendobj";
+ return $res;
+ break;
+* an annotation object, this will add an annotation to the current page.
+* initially will support just link annotations
+function o_annotation($id,$action,$options=''){
+ switch ($action){
+ case 'new':
+ // add the annotation to the current page
+ $pageId = $this->currentPage;
+ $this->o_page($pageId,'annot',$id);
+ // and add the action object which is going to be required
+ switch($options['type']){
+ case 'link':
+ $this->objects[$id]=array('t'=>'annotation','info'=>$options);
+ $this->numObj++;
+ $this->o_action($this->numObj,'new',$options['url']);
+ $this->objects[$id]['info']['actionId']=$this->numObj;
+ break;
+ case 'ilink':
+ // this is to a named internal link
+ $label = $options['label'];
+ $this->numObj++;
+ $this->o_action($this->numObj,'new',array('type'=>'ilink','label'=>$label));
+ break;
+ break;
+ case 'out':
+ $res="\n".$id." 0 obj\n<< /Type /Annot";
+ switch($o['info']['type']){
+ case 'link':
+ case 'ilink':
+ $res.= "\n/Subtype /Link";
+ break;
+ $res.="\n/A ".$o['info']['actionId']." 0 R";
+ $res.="\n/Border [0 0 0]";
+ $res.="\n/H /I";
+ $res.="\n/Rect [ ";
+ foreach($o['info']['rect'] as $v){
+ $res.= sprintf("%.4f ",$v);
+ $res.="]";
+ return $res;
+ break;
+* a page object, it also creates a contents object to hold its contents
+function o_page($id,$action,$options=''){
+ switch ($action){
+ case 'new':
+ $this->numPages++;
+ $this->objects[$id]=array('t'=>'page','info'=>array('parent'=>$this->currentNode,'pageNum'=>$this->numPages));
+ // then this must be a page insertion, array shoudl contain 'rid','pos'=[before|after]
+ $options['id']=$id;
+ $this->o_pages($this->currentNode,'page',$options);
+ } else {
+ $this->o_pages($this->currentNode,'page',$id);
+ $this->currentPage=$id;
+ //make a contents object to go with this page
+ $this->numObj++;
+ $this->o_contents($this->numObj,'new',$id);
+ $this->currentContents=$this->numObj;
+ $this->objects[$id]['info']['contents']=array();
+ $this->objects[$id]['info']['contents'][]=$this->numObj;
+ $match = ($this->numPages%2 ? 'odd' : 'even');
+ foreach($this->addLooseObjects as $oId=>$target){
+ if ($target=='all' || $match==$target){
+ $this->objects[$id]['info']['contents'][]=$oId;
+ break;
+ case 'content':
+ $o['info']['contents'][]=$options;
+ break;
+ case 'annot':
+ // add an annotation to this page
+ if (!isset($o['info']['annot'])){
+ $o['info']['annot']=array();
+ // $options should contain the id of the annotation dictionary
+ $o['info']['annot'][]=$options;
+ break;
+ case 'out':
+ $res="\n".$id." 0 obj\n<< /Type /Page";
+ $res.="\n/Parent ".$o['info']['parent']." 0 R";
+ if (isset($o['info']['annot'])){
+ $res.="\n/Annots [";
+ foreach($o['info']['annot'] as $aId){
+ $res.=" ".$aId." 0 R";
+ $res.=" ]";
+ $count = count($o['info']['contents']);
+ if ($count==1){
+ $res.="\n/Contents ".$o['info']['contents'][0]." 0 R";
+ } else if ($count>1){
+ $res.="\n/Contents [\n";
+ foreach ($o['info']['contents'] as $cId){
+ $res.=$cId." 0 R\n";
+ $res.="]";
+ return $res;
+ break;
+* the contents objects hold all of the content which appears on pages
+function o_contents($id,$action,$options=''){
+ switch ($action){
+ case 'new':
+ $this->objects[$id]=array('t'=>'contents','c'=>'','info'=>array());
+ if (strlen($options) && intval($options)){
+ // then this contents is the primary for a page
+ $this->objects[$id]['onPage']=$options;
+ } else if ($options=='raw'){
+ // then this page contains some other type of system object
+ $this->objects[$id]['raw']=1;
+ break;
+ case 'add':
+ // add more options to the decleration
+ case 'out':
+ $tmp=$o['c'];
+ $res= "\n".$id." 0 obj\n";
+ if (isset($this->objects[$id]['raw'])){
+ $res.=$tmp;
+ } else {
+ $res.= "<<";
+ if (function_exists('gzcompress') && $this->options['compression']){
+ // then implement ZLIB based compression on this content stream
+ $res.=" /Filter /FlateDecode";
+ $tmp = gzcompress($tmp);
+ $tmp = $this->ARC4($tmp);
+ $res .= "\n/".$k.' '.$v;
+ $res.="\n/Length ".strlen($tmp)." >>\nstream\n".$tmp."\nendstream";
+ $res.="\nendobj\n";
+ return $res;
+ break;
+* an image object, will be an XObject in the document, includes description and data
+function o_image($id,$action,$options=''){
+ switch($action){
+ case 'new':
+ // make the new object
+ $this->objects[$id]=array('t'=>'image','data'=>$options['data'],'info'=>array());
+ $this->objects[$id]['info']['Type']='/XObject';
+ $this->objects[$id]['info']['Subtype']='/Image';
+ $this->objects[$id]['info']['Width']=$options['iw'];
+ $this->objects[$id]['info']['Height']=$options['ih'];
+ if (!isset($options['type']) || $options['type']=='jpg'){
+ if (!isset($options['channels'])){
+ $options['channels']=3;
+ switch($options['channels']){
+ case 1:
+ $this->objects[$id]['info']['ColorSpace']='/DeviceGray';
+ break;
+ default:
+ $this->objects[$id]['info']['ColorSpace']='/DeviceRGB';
+ break;
+ $this->objects[$id]['info']['Filter']='/DCTDecode';
+ $this->objects[$id]['info']['BitsPerComponent']=8;
+ } else if ($options['type']=='png'){
+ $this->objects[$id]['info']['Filter']='/FlateDecode';
+ $this->objects[$id]['info']['DecodeParms']='<< /Predictor 15 /Colors '.$options['ncolor'].' /Columns '.$options['iw'].' /BitsPerComponent '.$options['bitsPerComponent'].'>>';
+ if (strlen($options['pdata'])){
+ $tmp = ' [ /Indexed /DeviceRGB '.(strlen($options['pdata'])/3-1).' ';
+ $this->numObj++;
+ $this->o_contents($this->numObj,'new');
+ $this->objects[$this->numObj]['c']=$options['pdata'];
+ $tmp.=$this->numObj.' 0 R';
+ $tmp .=' ]';
+ $this->objects[$id]['info']['ColorSpace'] = $tmp;
+ if (isset($options['transparency'])){
+ switch($options['transparency']['type']){
+ case 'indexed':
+ $tmp=' [ '.$options['transparency']['data'].' '.$options['transparency']['data'].'] ';
+ $this->objects[$id]['info']['Mask'] = $tmp;
+ break;
+ } else {
+ $this->objects[$id]['info']['ColorSpace']='/'.$options['color'];
+ $this->objects[$id]['info']['BitsPerComponent']=$options['bitsPerComponent'];
+ // assign it a place in the named resource dictionary as an external object, according to
+ // the label passed in with it.
+ $this->o_pages($this->currentNode,'xObject',array('label'=>$options['label'],'objNum'=>$id));
+ // also make sure that we have the right procset object for it.
+ $this->o_procset($this->procsetObjectId,'add','ImageC');
+ break;
+ case 'out':
+ $tmp=$o['data'];
+ $res= "\n".$id." 0 obj\n<<";
+ $res.="\n/Length ".strlen($tmp)." >>\nstream\n".$tmp."\nendstream\nendobj\n";
+ return $res;
+ break;
+* encryption object.
+function o_encryption($id,$action,$options=''){
+ switch($action){
+ case 'new':
+ $this->objects[$id]=array('t'=>'encryption','info'=>$options);
+ $this->arc4_objnum=$id;
+ // figure out the additional paramaters required
+ $pad = chr(0x28).chr(0xBF).chr(0x4E).chr(0x5E).chr(0x4E).chr(0x75).chr(0x8A).chr(0x41).chr(0x64).chr(0x00).chr(0x4E).chr(0x56).chr(0xFF).chr(0xFA).chr(0x01).chr(0x08).chr(0x2E).chr(0x2E).chr(0x00).chr(0xB6).chr(0xD0).chr(0x68).chr(0x3E).chr(0x80).chr(0x2F).chr(0x0C).chr(0xA9).chr(0xFE).chr(0x64).chr(0x53).chr(0x69).chr(0x7A);
+ $len = strlen($options['owner']);
+ if ($len>32){
+ $owner = substr($options['owner'],0,32);
+ } else if ($len<32){
+ $owner = $options['owner'].substr($pad,0,32-$len);
+ } else {
+ $owner = $options['owner'];
+ $len = strlen($options['user']);
+ if ($len>32){
+ $user = substr($options['user'],0,32);
+ $user = $options['user'].substr($pad,0,32-$len);
+ } else {
+ $user = $options['user'];
+ $tmp = $this->md5_16($owner);
+ $okey = substr($tmp,0,5);
+ $this->ARC4_init($okey);
+ $ovalue=$this->ARC4($user);
+ $this->objects[$id]['info']['O']=$ovalue;
+ // now make the u value, phew.
+ $tmp = $this->md5_16($user.$ovalue.chr($options['p']).chr(255).chr(255).chr(255).$this->fileIdentifier);
+ $ukey = substr($tmp,0,5);
+ $this->ARC4_init($ukey);
+ $this->encryptionKey = $ukey;
+ $this->encrypted=1;
+ $uvalue=$this->ARC4($pad);
+ $this->objects[$id]['info']['U']=$uvalue;
+ $this->encryptionKey=$ukey;
+ // initialize the arc4 array
+ break;
+ case 'out':
+ $res.="\n/Filter /Standard";
+ $res.="\n/V 1";
+ $res.="\n/R 2";
+ $res.="\n/O (".$this->filterText($o['info']['O']).')';
+ $res.="\n/U (".$this->filterText($o['info']['U']).')';
+ // and the p-value needs to be converted to account for the twos-complement approach
+ $o['info']['p'] = (($o['info']['p']^255)+1)*-1;
+ $res.="\n/P ".($o['info']['p']);
+ $res.="\n>>\nendobj\n";
+ return $res;
+ break;
+* ARC4 functions
+* A series of function to implement ARC4 encoding in PHP
+* calculate the 16 byte version of the 128 bit md5 digest of the string
+function md5_16($string){
+ $tmp = md5($string);
+ $out='';
+ for ($i=0;$i<=30;$i=$i+2){
+ $out.=chr(hexdec(substr($tmp,$i,2)));
+ return $out;
+* initialize the encryption for processing a particular object
+function encryptInit($id){
+ $tmp = $this->encryptionKey;
+ $hex = dechex($id);
+ if (strlen($hex)<6){
+ $hex = substr('000000',0,6-strlen($hex)).$hex;
+ $tmp.= chr(hexdec(substr($hex,4,2))).chr(hexdec(substr($hex,2,2))).chr(hexdec(substr($hex,0,2))).chr(0).chr(0);
+ $key = $this->md5_16($tmp);
+ $this->ARC4_init(substr($key,0,10));
+* initialize the ARC4 encryption
+function ARC4_init($key=''){
+ $this->arc4 = '';
+ // setup the control array
+ if (strlen($key)==0){
+ return;
+ $k = '';
+ while(strlen($k)<256){
+ $k.=$key;
+ $k=substr($k,0,256);
+ for ($i=0;$i<256;$i++){
+ $this->arc4 .= chr($i);
+ $j=0;
+ $t = $this->arc4[$i];
+ $j = ($j + ord($t) + ord($k[$i]))%256;
+ $this->arc4[$i]=$this->arc4[$j];
+ $this->arc4[$j]=$t;
+* ARC4 encrypt a text string
+function ARC4($text){
+ $len=strlen($text);
+ $a=0;
+ $b=0;
+ $c = $this->arc4;
+ $out='';
+ for ($i=0;$i<$len;$i++){
+ $a = ($a+1)%256;
+ $t= $c[$a];
+ $b = ($b+ord($t))%256;
+ $c[$a]=$c[$b];
+ $c[$b]=$t;
+ $k = ord($c[(ord($c[$a])+ord($c[$b]))%256]);
+ $out.=chr(ord($text[$i]) ^ $k);
+ return $out;
+* functions which can be called to adjust or add to the document
+* add a link in the document to an external URL
+function addLink($url,$x0,$y0,$x1,$y1){
+ $this->numObj++;
+ $info = array('type'=>'link','url'=>$url,'rect'=>array($x0,$y0,$x1,$y1));
+ $this->o_annotation($this->numObj,'new',$info);
+* add a link in the document to an internal destination (ie. within the document)
+function addInternalLink($label,$x0,$y0,$x1,$y1){
+ $this->numObj++;
+ $info = array('type'=>'ilink','label'=>$label,'rect'=>array($x0,$y0,$x1,$y1));
+* set the encryption of the document
+* can be used to turn it on and/or set the passwords which it will have.
+* also the functions that the user will have are set here, such as print, modify, add
+function setEncryption($userPass='',$ownerPass='',$pc=array()){
+ $p=bindec(11000000);
+ $options = array(
+ 'print'=>4
+ ,'modify'=>8
+ ,'copy'=>16
+ ,'add'=>32
+ foreach($pc as $k=>$v){
+ if ($v && isset($options[$k])){
+ $p+=$options[$k];
+ } else if (isset($options[$v])){
+ $p+=$options[$v];
+ // implement encryption on the document
+ if ($this->arc4_objnum == 0){
+ // then the block does not exist already, add it.
+ $this->numObj++;
+ if (strlen($ownerPass)==0){
+ $ownerPass=$userPass;
+ $this->o_encryption($this->numObj,'new',array('user'=>$userPass,'owner'=>$ownerPass,'p'=>$p));
+* should be used for internal checks, not implemented as yet
+function checkAllHere(){
+* return the pdf stream as a string returned from the function
+function output($debug=0){
+ if ($debug){
+ // turn compression off
+ $this->options['compression']=0;
+ if ($this->arc4_objnum){
+ $this->ARC4_init($this->encryptionKey);
+ $this->checkAllHere();
+ $xref=array();
+ $content="%PDF-1.3\n%âãÏÓ\n";
+// $content="%PDF-1.3\n";
+ $pos=strlen($content);
+ foreach($this->objects as $k=>$v){
+ $tmp='o_'.$v['t'];
+ $cont=$this->$tmp($k,'out');
+ $content.=$cont;
+ $xref[]=$pos;
+ $pos+=strlen($cont);
+ $content.="\nxref\n0 ".(count($xref)+1)."\n0000000000 65535 f \n";
+ foreach($xref as $p){
+ $content.=substr('0000000000',0,10-strlen($p)).$p." 00000 n \n";
+ $content.="\ntrailer\n << /Size ".(count($xref)+1)."\n /Root 1 0 R\n /Info ".$this->infoObject." 0 R\n";
+ // if encryption has been applied to this document then add the marker for this dictionary
+ if ($this->arc4_objnum > 0){
+ $content .= "/Encrypt ".$this->arc4_objnum." 0 R\n";
+ if (strlen($this->fileIdentifier)){
+ $content .= "/ID[<".$this->fileIdentifier."><".$this->fileIdentifier.">]\n";
+ $content .= " >>\nstartxref\n".$pos."\n%%EOF\n";
+ return $content;
+* intialize a new document
+* if this is called on an existing document results may be unpredictable, but the existing document would be lost at minimum
+* this function is called automatically by the constructor function
+* @access private
+function newDocument($pageSize=array(0,0,612,792)){
+ $this->numObj=0;
+ $this->objects = array();
+ $this->numObj++;
+ $this->o_catalog($this->numObj,'new');
+ $this->numObj++;
+ $this->o_outlines($this->numObj,'new');
+ $this->numObj++;
+ $this->o_pages($this->numObj,'new');
+ $this->o_pages($this->numObj,'mediaBox',$pageSize);
+ $this->currentNode = 3;
+ $this->numObj++;
+ $this->o_procset($this->numObj,'new');
+ $this->numObj++;
+ $this->o_info($this->numObj,'new');
+ $this->numObj++;
+ $this->o_page($this->numObj,'new');
+ // need to store the first page id as there is no way to get it to the user during
+ // startup
+ $this->firstPageId = $this->currentContents;
+* open the font file and return a php structure containing it.
+* first check if this one has been done before and saved in a form more suited to php
+* note that if a php serialized version does not exist it will try and make one, but will
+* require write access to the directory to do it... it is MUCH faster to have these serialized
+* files.
+* @access private
+function openFont($font){
+ // assume that $font contains both the path and perhaps the extension to the file, split them
+ $pos=strrpos($font,'/');
+ if ($pos===false){
+ $dir = './';
+ $name = $font;
+ } else {
+ $dir=substr($font,0,$pos+1);
+ $name=substr($font,$pos+1);
+ if (substr($name,-4)=='.afm'){
+ $name=substr($name,0,strlen($name)-4);
+ $this->addMessage('openFont: '.$font.' - '.$name);
+ if (file_exists($dir.'php_'.$name.'.afm')){
+ $this->addMessage('openFont: php file exists '.$dir.'php_'.$name.'.afm');
+ $tmp = file($dir.'php_'.$name.'.afm');
+ $this->fonts[$font]=unserialize($tmp[0]);
+ if (!isset($this->fonts[$font]['_version_']) || $this->fonts[$font]['_version_']<1){
+ // if the font file is old, then clear it out and prepare for re-creation
+ $this->addMessage('openFont: clear out, make way for new version.');
+ unset($this->fonts[$font]);
+ if (!isset($this->fonts[$font]) && file_exists($dir.$name.'.afm')){
+ // then rebuild the php_<font>.afm file from the <font>.afm file
+ $this->addMessage('openFont: build php file from '.$dir.$name.'.afm');
+ $data = array();
+ $file = file($dir.$name.'.afm');
+ foreach ($file as $rowA){
+ $row=trim($rowA);
+ $pos=strpos($row,' ');
+ if ($pos){
+ // then there must be some keyword
+ $key = substr($row,0,$pos);
+ switch ($key){
+ case 'FontName':
+ case 'FullName':
+ case 'FamilyName':
+ case 'Weight':
+ case 'IsFixedPitch':
+ case 'CharacterSet':
+ case 'UnderlinePosition':
+ case 'UnderlineThickness':
+ case 'Version':
+ case 'EncodingScheme':
+ case 'CapHeight':
+ case 'XHeight':
+ case 'Ascender':
+ case 'Descender':
+ case 'StdHW':
+ case 'StdVW':
+ case 'StartCharMetrics':
+ $data[$key]=trim(substr($row,$pos));
+ break;
+ case 'FontBBox':
+ $data[$key]=explode(' ',trim(substr($row,$pos)));
+ break;
+ case 'C':
+ //C 39 ; WX 222 ; N quoteright ; B 53 463 157 718 ;
+ $bits=explode(';',trim($row));
+ $dtmp=array();
+ foreach($bits as $bit){
+ $bits2 = explode(' ',trim($bit));
+ if (strlen($bits2[0])){
+ if (count($bits2)>2){
+ $dtmp[$bits2[0]]=array();
+ for ($i=1;$i<count($bits2);$i++){
+ $dtmp[$bits2[0]][]=$bits2[$i];
+ } else if (count($bits2)==2){
+ $dtmp[$bits2[0]]=$bits2[1];
+ if ($dtmp['C']>=0){
+ $data['C'][$dtmp['C']]=$dtmp;
+ $data['C'][$dtmp['N']]=$dtmp;
+ } else {
+ break;
+ case 'KPX':
+ //KPX Adieresis yacute -40
+ $bits=explode(' ',trim($row));
+ $data['KPX'][$bits[1]][$bits[2]]=$bits[3];
+ break;
+ $data['_version_']=1;
+ $this->fonts[$font]=$data;
+ $fp = fopen($dir.'php_'.$name.'.afm','w');
+ fwrite($fp,serialize($data));
+ fclose($fp);
+ } else if (!isset($this->fonts[$font])){
+ $this->addMessage('openFont: no font file found');
+// echo 'Font not Found '.$font;
+* if the font is not loaded then load it and make the required object
+* else just make it the current font
+* the encoding array can contain 'encoding'=> 'none','WinAnsiEncoding','MacRomanEncoding' or 'MacExpertEncoding'
+* note that encoding='none' will need to be used for symbolic fonts
+* and 'differences' => an array of mappings between numbers 0->255 and character names.
+function selectFont($fontName,$encoding='',$set=1){
+ if (!isset($this->fonts[$fontName])){
+ // load the file
+ $this->openFont($fontName);
+ if (isset($this->fonts[$fontName])){
+ $this->numObj++;
+ $this->numFonts++;
+ $pos=strrpos($fontName,'/');
+// $dir=substr($fontName,0,$pos+1);
+ $name=substr($fontName,$pos+1);
+ $options=array('name'=>$name);
+ if (is_array($encoding)){
+ // then encoding and differences might be set
+ if (isset($encoding['encoding'])){
+ $options['encoding']=$encoding['encoding'];
+ if (isset($encoding['differences'])){
+ $options['differences']=$encoding['differences'];
+ } else if (strlen($encoding)){
+ // then perhaps only the encoding has been set
+ $options['encoding']=$encoding;
+ $fontObj = $this->numObj;
+ $this->o_font($this->numObj,'new',$options);
+ $this->fonts[$fontName]['fontNum']=$this->numFonts;
+ // if this is a '.afm' font, and there is a '.pfa' file to go with it ( as there
+ // should be for all non-basic fonts), then load it into an object and put the
+ // references into the font object
+ $basefile = substr($fontName,0,strlen($fontName)-4);
+ if (file_exists($basefile.'.pfb')){
+ $fbtype = 'pfb';
+ } else if (file_exists($basefile.'.ttf')){
+ $fbtype = 'ttf';
+ } else {
+ $fbtype='';
+ $fbfile = $basefile.'.'.$fbtype;
+// $pfbfile = substr($fontName,0,strlen($fontName)-4).'.pfb';
+// $ttffile = substr($fontName,0,strlen($fontName)-4).'.ttf';
+ $this->addMessage('selectFont: checking for - '.$fbfile);
+ if (substr($fontName,-4)=='.afm' && strlen($fbtype) ){
+ $adobeFontName = $this->fonts[$fontName]['FontName'];
+// $fontObj = $this->numObj;
+ $this->addMessage('selectFont: adding font file - '.$fbfile.' - '.$adobeFontName);
+ // find the array of fond widths, and put that into an object.
+ $firstChar = -1;
+ $lastChar = 0;
+ $widths = array();
+ foreach ($this->fonts[$fontName]['C'] as $num=>$d){
+ if (intval($num)>0 || $num=='0'){
+ if ($lastChar>0 && $num>$lastChar+1){
+ for($i=$lastChar+1;$i<$num;$i++){
+ $widths[] = 0;
+ $widths[] = $d['WX'];
+ if ($firstChar==-1){
+ $firstChar = $num;
+ $lastChar = $num;
+ // also need to adjust the widths for the differences array
+ foreach($options['differences'] as $charNum=>$charName){
+ if ($charNum>$lastChar){
+ for($i=$lastChar+1;$i<=$charNum;$i++){
+ $widths[]=0;
+ $lastChar=$charNum;
+ if (isset($this->fonts[$fontName]['C'][$charName])){
+ $widths[$charNum-$firstChar]=$this->fonts[$fontName]['C'][$charName]['WX'];
+ $this->addMessage('selectFont: FirstChar='.$firstChar);
+ $this->addMessage('selectFont: LastChar='.$lastChar);
+ $this->numObj++;
+ $this->o_contents($this->numObj,'new','raw');
+ $this->objects[$this->numObj]['c'].='[';
+ foreach($widths as $width){
+ $this->objects[$this->numObj]['c'].=' '.$width;
+ $this->objects[$this->numObj]['c'].=' ]';
+ $widthid = $this->numObj;
+ // load the pfb file, and put that into an object too.
+ // note that pdf supports only binary format type 1 font files, though there is a
+ // simple utility to convert them from pfa to pfb.
+ $fp = fopen($fbfile,'rb');
+ $tmp = get_magic_quotes_runtime();
+ set_magic_quotes_runtime(0);
+ $data = fread($fp,filesize($fbfile));
+ set_magic_quotes_runtime($tmp);
+ fclose($fp);
+ // create the font descriptor
+ $this->numObj++;
+ $fontDescriptorId = $this->numObj;
+ $this->numObj++;
+ $pfbid = $this->numObj;
+ // determine flags (more than a little flakey, hopefully will not matter much)
+ $flags=0;
+ if ($this->fonts[$fontName]['ItalicAngle']!=0){ $flags+=pow(2,6); }
+ if ($this->fonts[$fontName]['IsFixedPitch']=='true'){ $flags+=1; }
+ $flags+=pow(2,5); // assume non-sybolic
+ $list = array('Ascent'=>'Ascender','CapHeight'=>'CapHeight','Descent'=>'Descender','FontBBox'=>'FontBBox','ItalicAngle'=>'ItalicAngle');
+ $fdopt = array(
+ 'Flags'=>$flags
+ ,'FontName'=>$adobeFontName
+ ,'StemV'=>100 // don't know what the value for this should be!
+ foreach($list as $k=>$v){
+ if (isset($this->fonts[$fontName][$v])){
+ $fdopt[$k]=$this->fonts[$fontName][$v];
+ if ($fbtype=='pfb'){
+ $fdopt['FontFile']=$pfbid;
+ } else if ($fbtype=='ttf'){
+ $fdopt['FontFile2']=$pfbid;
+ $this->o_fontDescriptor($fontDescriptorId,'new',$fdopt);
+ // embed the font program
+ $this->objects[$pfbid]['c'].=$data;
+ // determine the cruicial lengths within this file
+ $l1 = strpos($data,'eexec')+6;
+ $l2 = strpos($data,'00000000')-$l1;
+ $l3 = strlen($data)-$l2-$l1;
+ $this->o_contents($this->numObj,'add',array('Length1'=>$l1,'Length2'=>$l2,'Length3'=>$l3));
+ $l1 = strlen($data);
+ $this->o_contents($this->numObj,'add',array('Length1'=>$l1));
+ // tell the font object about all this new stuff
+ $tmp = array('BaseFont'=>$adobeFontName,'Widths'=>$widthid
+ ,'FirstChar'=>$firstChar,'LastChar'=>$lastChar
+ ,'FontDescriptor'=>$fontDescriptorId);
+ if ($fbtype=='ttf'){
+ $tmp['SubType']='TrueType';
+ $this->addMessage('adding extra info to font.('.$fontObj.')');
+ foreach($tmp as $fk=>$fv){
+ $this->addMessage($fk." : ".$fv);
+ $this->o_font($fontObj,'add',$tmp);
+ } else {
+ $this->addMessage('selectFont: pfb or ttf file not found, ok if this is one of the 14 standard fonts');
+ // also set the differences here, note that this means that these will take effect only the
+ //first time that a font is selected, else they are ignored
+ $this->fonts[$fontName]['differences']=$options['differences'];
+ if ($set && isset($this->fonts[$fontName])){
+ // so if for some reason the font was not set in the last one then it will not be selected
+ $this->currentBaseFont=$fontName;
+ // the next line means that if a new font is selected, then the current text state will be
+ // applied to it as well.
+ $this->setCurrentFont();
+ return $this->currentFontNum;
+* sets up the current font, based on the font families, and the current text state
+* note that this system is quite flexible, a <b><i> font can be completely different to a
+* <i><b> font, and even <b><b> will have to be defined within the family to have meaning
+* This function is to be called whenever the currentTextState is changed, it will update
+* the currentFont setting to whatever the appropriatte family one is.
+* If the user calls selectFont themselves then that will reset the currentBaseFont, and the currentFont
+* This function will change the currentFont to whatever it should be, but will not change the
+* currentBaseFont.
+* @access private
+function setCurrentFont(){
+ if (strlen($this->currentBaseFont)==0){
+ // then assume an initial font
+ $this->selectFont('./fonts/Helvetica.afm');
+ $cf = substr($this->currentBaseFont,strrpos($this->currentBaseFont,'/')+1);
+ if (strlen($this->currentTextState)
+ && isset($this->fontFamilies[$cf])
+ && isset($this->fontFamilies[$cf][$this->currentTextState])){
+ // then we are in some state or another
+ // and this font has a family, and the current setting exists within it
+ // select the font, then return it
+ $nf = substr($this->currentBaseFont,0,strrpos($this->currentBaseFont,'/')+1).$this->fontFamilies[$cf][$this->currentTextState];
+ $this->selectFont($nf,'',0);
+ $this->currentFont = $nf;
+ $this->currentFontNum = $this->fonts[$nf]['fontNum'];
+ } else {
+ // the this font must not have the right family member for the current state
+ // simply assume the base font
+ $this->currentFont = $this->currentBaseFont;
+ $this->currentFontNum = $this->fonts[$this->currentFont]['fontNum'];
+* function for the user to find out what the ID is of the first page that was created during
+* startup - useful if they wish to add something to it later.
+function getFirstPageId(){
+ return $this->firstPageId;
+* add content to the currently active object
+* @access private
+function addContent($content){
+ $this->objects[$this->currentContents]['c'].=$content;
+* sets the colour for fill operations
+function setColor($r,$g,$b,$force=0){
+ if ($r>=0 && ($force || $r!=$this->currentColour['r'] || $g!=$this->currentColour['g'] || $b!=$this->currentColour['b'])){
+ $this->objects[$this->currentContents]['c'].="\n".sprintf('%.3f',$r).' '.sprintf('%.3f',$g).' '.sprintf('%.3f',$b).' rg';
+ $this->currentColour=array('r'=>$r,'g'=>$g,'b'=>$b);
+* sets the colour for stroke operations
+function setStrokeColor($r,$g,$b,$force=0){
+ if ($r>=0 && ($force || $r!=$this->currentStrokeColour['r'] || $g!=$this->currentStrokeColour['g'] || $b!=$this->currentStrokeColour['b'])){
+ $this->objects[$this->currentContents]['c'].="\n".sprintf('%.3f',$r).' '.sprintf('%.3f',$g).' '.sprintf('%.3f',$b).' RG';
+ $this->currentStrokeColour=array('r'=>$r,'g'=>$g,'b'=>$b);
+* draw a line from one set of coordinates to another
+function line($x1,$y1,$x2,$y2){
+ $this->objects[$this->currentContents]['c'].="\n".sprintf('%.3f',$x1).' '.sprintf('%.3f',$y1).' m '.sprintf('%.3f',$x2).' '.sprintf('%.3f',$y2).' l S';
+* draw a bezier curve based on 4 control points
+function curve($x0,$y0,$x1,$y1,$x2,$y2,$x3,$y3){
+ // in the current line style, draw a bezier curve from (x0,y0) to (x3,y3) using the other two points
+ // as the control points for the curve.
+ $this->objects[$this->currentContents]['c'].="\n".sprintf('%.3f',$x0).' '.sprintf('%.3f',$y0).' m '.sprintf('%.3f',$x1).' '.sprintf('%.3f',$y1);
+ $this->objects[$this->currentContents]['c'].= ' '.sprintf('%.3f',$x2).' '.sprintf('%.3f',$y2).' '.sprintf('%.3f',$x3).' '.sprintf('%.3f',$y3).' c S';
+* draw a part of an ellipse
+function partEllipse($x0,$y0,$astart,$afinish,$r1,$r2=0,$angle=0,$nSeg=8){
+ $this->ellipse($x0,$y0,$r1,$r2,$angle,$nSeg,$astart,$afinish,0);
+* draw a filled ellipse
+function filledEllipse($x0,$y0,$r1,$r2=0,$angle=0,$nSeg=8,$astart=0,$afinish=360){
+ return $this->ellipse($x0,$y0,$r1,$r2=0,$angle,$nSeg,$astart,$afinish,1,1);
+* draw an ellipse
+* note that the part and filled ellipse are just special cases of this function
+* draws an ellipse in the current line style
+* centered at $x0,$y0, radii $r1,$r2
+* if $r2 is not set, then a circle is drawn
+* nSeg is not allowed to be less than 2, as this will simply draw a line (and will even draw a
+* pretty crappy shape at 2, as we are approximating with bezier curves.
+function ellipse($x0,$y0,$r1,$r2=0,$angle=0,$nSeg=8,$astart=0,$afinish=360,$close=1,$fill=0){
+ if ($r1==0){
+ return;
+ if ($r2==0){
+ $r2=$r1;
+ if ($nSeg<2){
+ $nSeg=2;
+ $astart = deg2rad((float)$astart);
+ $afinish = deg2rad((float)$afinish);
+ $totalAngle =$afinish-$astart;
+ $dt = $totalAngle/$nSeg;
+ $dtm = $dt/3;
+ if ($angle != 0){
+ $a = -1*deg2rad((float)$angle);
+ $tmp = "\n q ";
+ $tmp .= sprintf('%.3f',cos($a)).' '.sprintf('%.3f',(-1.0*sin($a))).' '.sprintf('%.3f',sin($a)).' '.sprintf('%.3f',cos($a)).' ';
+ $tmp .= sprintf('%.3f',$x0).' '.sprintf('%.3f',$y0).' cm';
+ $this->objects[$this->currentContents]['c'].= $tmp;
+ $x0=0;
+ $y0=0;
+ $t1 = $astart;
+ $a0 = $x0+$r1*cos($t1);
+ $b0 = $y0+$r2*sin($t1);
+ $c0 = -$r1*sin($t1);
+ $d0 = $r2*cos($t1);
+ $this->objects[$this->currentContents]['c'].="\n".sprintf('%.3f',$a0).' '.sprintf('%.3f',$b0).' m ';
+ for ($i=1;$i<=$nSeg;$i++){
+ // draw this bit of the total curve
+ $t1 = $i*$dt+$astart;
+ $a1 = $x0+$r1*cos($t1);
+ $b1 = $y0+$r2*sin($t1);
+ $c1 = -$r1*sin($t1);
+ $d1 = $r2*cos($t1);
+ $this->objects[$this->currentContents]['c'].="\n".sprintf('%.3f',($a0+$c0*$dtm)).' '.sprintf('%.3f',($b0+$d0*$dtm));
+ $this->objects[$this->currentContents]['c'].= ' '.sprintf('%.3f',($a1-$c1*$dtm)).' '.sprintf('%.3f',($b1-$d1*$dtm)).' '.sprintf('%.3f',$a1).' '.sprintf('%.3f',$b1).' c';
+ $a0=$a1;
+ $b0=$b1;
+ $c0=$c1;
+ $d0=$d1;
+ if ($fill){
+ $this->objects[$this->currentContents]['c'].=' f';
+ } else {
+ if ($close){
+ $this->objects[$this->currentContents]['c'].=' s'; // small 's' signifies closing the path as well
+ } else {
+ $this->objects[$this->currentContents]['c'].=' S';
+ if ($angle !=0){
+ $this->objects[$this->currentContents]['c'].=' Q';
+* this sets the line drawing style.
+* width, is the thickness of the line in user units
+* cap is the type of cap to put on the line, values can be 'butt','round','square'
+* where the diffference between 'square' and 'butt' is that 'square' projects a flat end past the
+* end of the line.
+* join can be 'miter', 'round', 'bevel'
+* dash is an array which sets the dash pattern, is a series of length values, which are the lengths of the
+* on and off dashes.
+* (2) represents 2 on, 2 off, 2 on , 2 off ...
+* (2,1) is 2 on, 1 off, 2 on, 1 off.. etc
+* phase is a modifier on the dash pattern which is used to shift the point at which the pattern starts.
+function setLineStyle($width=1,$cap='',$join='',$dash='',$phase=0){
+ // this is quite inefficient in that it sets all the parameters whenever 1 is changed, but will fix another day
+ $string = '';
+ if ($width>0){
+ $string.= $width.' w';
+ $ca = array('butt'=>0,'round'=>1,'square'=>2);
+ if (isset($ca[$cap])){
+ $string.= ' '.$ca[$cap].' J';
+ $ja = array('miter'=>0,'round'=>1,'bevel'=>2);
+ if (isset($ja[$join])){
+ $string.= ' '.$ja[$join].' j';
+ if (is_array($dash)){
+ $string.= ' [';
+ foreach ($dash as $len){
+ $string.=' '.$len;
+ $string.= ' ] '.$phase.' d';
+ $this->currentLineStyle = $string;
+ $this->objects[$this->currentContents]['c'].="\n".$string;
+* draw a polygon, the syntax for this is similar to the GD polygon command
+function polygon($p,$np,$f=0){
+ $this->objects[$this->currentContents]['c'].="\n";
+ $this->objects[$this->currentContents]['c'].=sprintf('%.3f',$p[0]).' '.sprintf('%.3f',$p[1]).' m ';
+ for ($i=2;$i<$np*2;$i=$i+2){
+ $this->objects[$this->currentContents]['c'].= sprintf('%.3f',$p[$i]).' '.sprintf('%.3f',$p[$i+1]).' l ';
+ if ($f==1){
+ } else {
+* a filled rectangle, note that it is the width and height of the rectangle which are the secondary paramaters, not
+* the coordinates of the upper-right corner
+function filledRectangle($x1,$y1,$width,$height){
+ $this->objects[$this->currentContents]['c'].="\n".sprintf('%.3f',$x1).' '.sprintf('%.3f',$y1).' '.sprintf('%.3f',$width).' '.sprintf('%.3f',$height).' re f';
+* draw a rectangle, note that it is the width and height of the rectangle which are the secondary paramaters, not
+function rectangle($x1,$y1,$width,$height){
+ $this->objects[$this->currentContents]['c'].="\n".sprintf('%.3f',$x1).' '.sprintf('%.3f',$y1).' '.sprintf('%.3f',$width).' '.sprintf('%.3f',$height).' re S';
+* add a new page to the document
+* this also makes the new page the current active object
+function newPage($insert=0,$id=0,$pos='after'){
+ // if there is a state saved, then go up the stack closing them
+ // then on the new page, re-open them with the right setings
+ if ($this->nStateStack){
+ for ($i=$this->nStateStack;$i>=1;$i--){
+ $this->restoreState($i);
+ $this->numObj++;
+ if ($insert){
+ // the id from the ezPdf class is the od of the contents of the page, not the page object itself
+ // query that object to find the parent
+ $rid = $this->objects[$id]['onPage'];
+ $opt= array('rid'=>$rid,'pos'=>$pos);
+ $this->o_page($this->numObj,'new',$opt);
+ } else {
+ // if there is a stack saved, then put that onto the page
+ for ($i=1;$i<=$this->nStateStack;$i++){
+ $this->saveState($i);
+ // and if there has been a stroke or fill colour set, then transfer them
+ if ($this->currentColour['r']>=0){
+ $this->setColor($this->currentColour['r'],$this->currentColour['g'],$this->currentColour['b'],1);
+ if ($this->currentStrokeColour['r']>=0){
+ $this->setStrokeColor($this->currentStrokeColour['r'],$this->currentStrokeColour['g'],$this->currentStrokeColour['b'],1);
+ // if there is a line style set, then put this in too
+ if (strlen($this->currentLineStyle)){
+ $this->objects[$this->currentContents]['c'].="\n".$this->currentLineStyle;
+ // the call to the o_page object set currentContents to the present page, so this can be returned as the page id
+ return $this->currentContents;
+* output the pdf code, streaming it to the browser
+* the relevant headers are set so that hopefully the browser will recognise it
+function stream($options=''){
+ // setting the options allows the adjustment of the headers
+ // values at the moment are:
+ // 'Content-Disposition'=>'filename' - sets the filename, though not too sure how well this will
+ // work as in my trial the browser seems to use the filename of the php file with .pdf on the end
+ // 'Accept-Ranges'=>1 or 0 - if this is not set to 1, then this header is not included, off by default
+ // this header seems to have caused some problems despite tha fact that it is supposed to solve
+ // them, so I am leaving it off by default.
+ // 'compress'=> 1 or 0 - apply content stream compression, this is on (1) by default
+ if (!is_array($options)){
+ $options=array();
+ if ( isset($options['compress']) && $options['compress']==0){
+ $tmp = $this->output(1);
+ } else {
+ $tmp = $this->output();
+ header("Content-type: application/pdf");
+ header("Content-Length: ".strlen(ltrim($tmp)));
+ $fileName = (isset($options['Content-Disposition'])?$options['Content-Disposition']:'file.pdf');
+ header("Content-Disposition: inline; filename=".$fileName);
+ if (isset($options['Accept-Ranges']) && $options['Accept-Ranges']==1){
+ header("Accept-Ranges: ".strlen(ltrim($tmp)));
+ echo ltrim($tmp);
+* return the height in units of the current font in the given size
+function getFontHeight($size){
+ if (!$this->numFonts){
+ $this->selectFont('./fonts/Helvetica');
+ // for the current font, and the given size, what is the height of the font in user units
+ $h = $this->fonts[$this->currentFont]['FontBBox'][3]-$this->fonts[$this->currentFont]['FontBBox'][1];
+ return $size*$h/1000;
+* return the font decender, this will normally return a negative number
+* if you add this number to the baseline, you get the level of the bottom of the font
+* it is in the pdf user units
+function getFontDecender($size){
+ // note that this will most likely return a negative value
+ $h = $this->fonts[$this->currentFont]['FontBBox'][1];
+* filter the text, this is applied to all text just before being inserted into the pdf document
+* it escapes the various things that need to be escaped, and so on
+* @access private
+function filterText($text){
+ $text = str_replace('\\','\\\\',$text);
+ $text = str_replace('(','\(',$text);
+ $text = str_replace(')','\)',$text);
+ $text = str_replace('<','<',$text);
+ $text = str_replace('>','>',$text);
+ $text = str_replace(''','\'',$text);
+ $text = str_replace('"','"',$text);
+ $text = str_replace('&','&',$text);
+ return $text;
+* given a start position and information about how text is to be laid out, calculate where
+* on the page the text will end
+* @access private
+function PRVTgetTextPosition($x,$y,$angle,$size,$wa,$text){
+ // given this information return an array containing x and y for the end position as elements 0 and 1
+ $w = $this->getTextWidth($size,$text);
+ // need to adjust for the number of spaces in this text
+ $words = explode(' ',$text);
+ $nspaces=count($words)-1;
+ $w += $wa*$nspaces;
+ $a = deg2rad((float)$angle);
+ return array(cos($a)*$w+$x,-sin($a)*$w+$y);
+* wrapper function for PRVTcheckTextDirective1
+* @access private
+function PRVTcheckTextDirective(&$text,$i,&$f){
+ $x=0;
+ $y=0;
+ return $this->PRVTcheckTextDirective1($text,$i,$f,0,$x,$y);
+* checks if the text stream contains a control directive
+* if so then makes some changes and returns the number of characters involved in the directive
+* this has been re-worked to include everything neccesary to fins the current writing point, so that
+* the location can be sent to the callback function if required
+* if the directive does not require a font change, then $f should be set to 0
+* @access private
+function PRVTcheckTextDirective1(&$text,$i,&$f,$final,&$x,&$y,$size=0,$angle=0,$wordSpaceAdjust=0){
+ $directive = 0;
+ $j=$i;
+ if ($text[$j]=='<'){
+ $j++;
+ switch($text[$j]){
+ case '/':
+ $j++;
+ if (strlen($text) <= $j){
+ return $directive;
+ case 'b':
+ case 'i':
+ $j++;
+ if ($text[$j]=='>'){
+ $p = strrpos($this->currentTextState,$text[$j-1]);
+ if ($p !== false){
+ // then there is one to remove
+ $this->currentTextState = substr($this->currentTextState,0,$p).substr($this->currentTextState,$p+1);
+ $directive=$j-$i+1;
+ break;
+ case 'c':
+ // this this might be a callback function
+ $j++;
+ $k = strpos($text,'>',$j);
+ if ($k!==false && $text[$j]==':'){
+ // then this will be treated as a callback directive
+ $directive = $k-$i+1;
+ $f=0;
+ // split the remainder on colons to get the function name and the paramater
+ $tmp = substr($text,$j+1,$k-$j-1);
+ $b1 = strpos($tmp,':');
+ if ($b1!==false){
+ $func = substr($tmp,0,$b1);
+ $parm = substr($tmp,$b1+1);
+ } else {
+ $func=$tmp;
+ $parm='';
+ if (!isset($func) || !strlen(trim($func))){
+ $directive=0;
+ } else {
+ // only call the function if this is the final call
+ if ($final){
+ // need to assess the text position, calculate the text width to this point
+ // can use getTextWidth to find the text width I think
+ $tmp = $this->PRVTgetTextPosition($x,$y,$angle,$size,$wordSpaceAdjust,substr($text,0,$i));
+ $info = array('x'=>$tmp[0],'y'=>$tmp[1],'angle'=>$angle,'status'=>'end','p'=>$parm,'nCallback'=>$this->nCallback);
+ $x=$tmp[0];
+ $y=$tmp[1];
+ $ret = $this->$func($info);
+ if (is_array($ret)){
+ // then the return from the callback function could set the position, to start with, later will do font colour, and font
+ foreach($ret as $rk=>$rv){
+ switch($rk){
+ case 'x':
+ case 'y':
+ $$rk=$rv;
+ break;
+ // also remove from to the stack
+ // for simplicity, just take from the end, fix this another day
+ $this->nCallback--;
+ if ($this->nCallback<0){
+ $this->nCallBack=0;
+ break;
+ break;
+ case 'b':
+ case 'i':
+ $j++;
+ $this->currentTextState.=$text[$j-1];
+ break;
+ case 'C':
+ $noClose=1;
+ case 'c':
+ $j++;
+ $f=0;
+// $bits = explode(':',substr($text,$j+1,$k-$j-1));
+ if ($b1!==false){
+ } else {
+ $func=$tmp;
+ $parm='';
+ $directive=0;
+ } else {
+ // only call the function if this is the final call, ie, the one actually doing printing, not measurement
+ if ($final){
+ // also add the text height and decender
+ $info = array('x'=>$tmp[0],'y'=>$tmp[1],'angle'=>$angle,'status'=>'start','p'=>$parm,'f'=>$func,'height'=>$this->getFontHeight($size),'decender'=>$this->getFontDecender($size));
+ $x=$tmp[0];
+ $y=$tmp[1];
+ if (!isset($noClose) || !$noClose){
+ // only add to the stack if this is a small 'c', therefore is a start-stop pair
+ $this->nCallback++;
+ $info['nCallback']=$this->nCallback;
+ $this->callback[$this->nCallback]=$info;
+ switch($rk){
+ case 'x':
+ case 'y':
+ $$rk=$rv;
+ break;
+ break;
+* add text to the document, at a specified location, size and angle on the page
+function addText($x,$y,$size,$text,$angle=0,$wordSpaceAdjust=0){
+ if (!$this->numFonts){$this->selectFont('./fonts/Helvetica');}
+ // if there are any open callbacks, then they should be called, to show the start of the line
+ if ($this->nCallback>0){
+ for ($i=$this->nCallback;$i>0;$i--){
+ // call each function
+ $info = array('x'=>$x,'y'=>$y,'angle'=>$angle,'status'=>'sol','p'=>$this->callback[$i]['p'],'nCallback'=>$this->callback[$i]['nCallback'],'height'=>$this->callback[$i]['height'],'decender'=>$this->callback[$i]['decender']);
+ $func = $this->callback[$i]['f'];
+ $this->$func($info);
+ if ($angle==0){
+ $this->objects[$this->currentContents]['c'].="\n".'BT '.sprintf('%.3f',$x).' '.sprintf('%.3f',$y).' Td';
+ } else {
+ $tmp = "\n".'BT ';
+ $tmp .= sprintf('%.3f',$x).' '.sprintf('%.3f',$y).' Tm';
+ $this->objects[$this->currentContents]['c'] .= $tmp;
+ if ($wordSpaceAdjust!=0 || $wordSpaceAdjust != $this->wordSpaceAdjust){
+ $this->wordSpaceAdjust=$wordSpaceAdjust;
+ $this->objects[$this->currentContents]['c'].=' '.sprintf('%.3f',$wordSpaceAdjust).' Tw';
+ $start=0;
+ $f=1;
+ $directive = $this->PRVTcheckTextDirective($text,$i,$f);
+ if ($directive){
+ // then we should write what we need to
+ if ($i>$start){
+ $part = substr($text,$start,$i-$start);
+ $this->objects[$this->currentContents]['c'].=' /F'.$this->currentFontNum.' '.sprintf('%.1f',$size).' Tf ';
+ $this->objects[$this->currentContents]['c'].=' ('.$this->filterText($part).') Tj';
+ if ($f){
+ // then there was nothing drastic done here, restore the contents
+ } else {
+ $this->objects[$this->currentContents]['c'] .= ' ET';
+ $f=1;
+ $xp=$x;
+ $yp=$y;
+ $directive = $this->PRVTcheckTextDirective1($text,$i,$f,1,$xp,$yp,$size,$angle,$wordSpaceAdjust);
+ // restart the text object
+ if ($angle==0){
+ $this->objects[$this->currentContents]['c'].="\n".'BT '.sprintf('%.3f',$xp).' '.sprintf('%.3f',$yp).' Td';
+ } else {
+ $tmp .= sprintf('%.3f',$xp).' '.sprintf('%.3f',$yp).' Tm';
+ // and move the writing point to the next piece of text
+ $i=$i+$directive-1;
+ $start=$i+1;
+ if ($start<$len){
+ $part = substr($text,$start);
+ $this->objects[$this->currentContents]['c'].=' ET';
+ // if there are any open callbacks, then they should be called, to show the end of the line
+ $tmp = $this->PRVTgetTextPosition($x,$y,$angle,$size,$wordSpaceAdjust,$text);
+ $info = array('x'=>$tmp[0],'y'=>$tmp[1],'angle'=>$angle,'status'=>'eol','p'=>$this->callback[$i]['p'],'nCallback'=>$this->callback[$i]['nCallback'],'height'=>$this->callback[$i]['height'],'decender'=>$this->callback[$i]['decender']);
+* calculate how wide a given text string will be on a page, at a given size.
+* this can be called externally, but is alse used by the other class functions
+function getTextWidth($size,$text){
+ // this function should not change any of the settings, though it will need to
+ // track any directives which change during calculation, so copy them at the start
+ // and put them back at the end.
+ $store_currentTextState = $this->currentTextState;
+ // converts a number or a float to a string so it can get the width
+ $text = "$text";
+ // hmm, this is where it all starts to get tricky - use the font information to
+ // calculate the width of each character, add them up and convert to user units
+ $w=0;
+ $cf = $this->currentFont;
+ $f=1;
+ if ($directive){
+ if ($f){
+ } else {
+ $char=ord($text[$i]);
+ if (isset($this->fonts[$cf]['differences'][$char])){
+ // then this character is being replaced by another
+ $name = $this->fonts[$cf]['differences'][$char];
+ if (isset($this->fonts[$cf]['C'][$name]['WX'])){
+ $w+=$this->fonts[$cf]['C'][$name]['WX'];
+ } else if (isset($this->fonts[$cf]['C'][$char]['WX'])){
+ $w+=$this->fonts[$cf]['C'][$char]['WX'];
+ $this->currentTextState = $store_currentTextState;
+ return $w*$size/1000;
+* do a part of the calculation for sorting out the justification of the text
+* @access private
+function PRVTadjustWrapText($text,$actual,$width,&$x,&$adjust,$justification){
+ switch ($justification){
+ case 'left':
+ return;
+ break;
+ case 'right':
+ $x+=$width-$actual;
+ break;
+ case 'center':
+ case 'centre':
+ $x+=($width-$actual)/2;
+ break;
+ case 'full':
+ // count the number of words
+ if ($nspaces>0){
+ $adjust = ($width-$actual)/$nspaces;
+ } else {
+ $adjust=0;
+ break;
+* add text to the page, but ensure that it fits within a certain width
+* if it does not fit then put in as much as possible, splitting at word boundaries
+* and return the remainder.
+* justification and angle can also be specified for the text
+function addTextWrap($x,$y,$width,$size,$text,$justification='left',$angle=0,$test=0){
+ // this will display the text, and if it goes beyond the width $width, will backtrack to the
+ // previous space or hyphen, and return the remainder of the text.
+ // $justification can be set to 'left','right','center','centre','full'
+ // need to store the initial text state, as this will change during the width calculation
+ // but will need to be re-set before printing, so that the chars work out right
+ if ($width<=0){
+ // error, pretend it printed ok, otherwise risking a loop
+ return '';
+ $w=0;
+ $break=0;
+ $breakWidth=0;
+ $tw = $width/$size*1000;
+ $f=1;
+ if ($directive){
+ if ($f){
+ } else {
+ $cOrd = ord($text[$i]);
+ if (isset($this->fonts[$cf]['differences'][$cOrd])){
+ $cOrd2 = $this->fonts[$cf]['differences'][$cOrd];
+ } else {
+ $cOrd2 = $cOrd;
+ if (isset($this->fonts[$cf]['C'][$cOrd2]['WX'])){
+ $w+=$this->fonts[$cf]['C'][$cOrd2]['WX'];
+ if ($w>$tw){
+ // then we need to truncate this line
+ if ($break>0){
+ // then we have somewhere that we can split :)
+ if ($text[$break]==' '){
+ $tmp = substr($text,0,$break);
+ } else {
+ $tmp = substr($text,0,$break+1);
+ $adjust=0;
+ $this->PRVTadjustWrapText($tmp,$breakWidth,$width,$x,$adjust,$justification);
+ // reset the text state
+ if (!$test){
+ $this->addText($x,$y,$size,$tmp,$angle,$adjust);
+ return substr($text,$break+1);
+ } else {
+ // just split before the current character
+ $tmp = substr($text,0,$i);
+ $adjust=0;
+ $ctmp=ord($text[$i]);
+ if (isset($this->fonts[$cf]['differences'][$ctmp])){
+ $ctmp=$this->fonts[$cf]['differences'][$ctmp];
+ $tmpw=($w-$this->fonts[$cf]['C'][$ctmp]['WX'])*$size/1000;
+ $this->PRVTadjustWrapText($tmp,$tmpw,$width,$x,$adjust,$justification);
+ if (!$test){
+ return substr($text,$i);
+ if ($text[$i]=='-'){
+ $break=$i;
+ $breakWidth = $w*$size/1000;
+ if ($text[$i]==' '){
+ $break=$i;
+ $breakWidth = ($w-$this->fonts[$cf]['C'][$ctmp]['WX'])*$size/1000;
+ // then there was no need to break this line
+ if ($justification=='full'){
+ $justification='left';
+ $adjust=0;
+ $tmpw=$w*$size/1000;
+ $this->PRVTadjustWrapText($text,$tmpw,$width,$x,$adjust,$justification);
+ if (!$test){
+ $this->addText($x,$y,$size,$text,$angle,$adjust,$angle);
+ return '';
+* this will be called at a new page to return the state to what it was on the
+* end of the previous page, before the stack was closed down
+* This is to get around not being able to have open 'q' across pages
+function saveState($pageEnd=0){
+ if ($pageEnd){
+ // this will be called at a new page to return the state to what it was on the
+ // end of the previous page, before the stack was closed down
+ // This is to get around not being able to have open 'q' across pages
+ $opt = $this->stateStack[$pageEnd]; // ok to use this as stack starts numbering at 1
+ $this->setColor($opt['col']['r'],$opt['col']['g'],$opt['col']['b'],1);
+ $this->setStrokeColor($opt['str']['r'],$opt['str']['g'],$opt['str']['b'],1);
+ $this->objects[$this->currentContents]['c'].="\n".$opt['lin'];
+// $this->currentLineStyle = $opt['lin'];
+ } else {
+ $this->nStateStack++;
+ $this->stateStack[$this->nStateStack]=array(
+ 'col'=>$this->currentColour
+ ,'str'=>$this->currentStrokeColour
+ ,'lin'=>$this->currentLineStyle
+ $this->objects[$this->currentContents]['c'].="\nq";
+* restore a previously saved state
+function restoreState($pageEnd=0){
+ if (!$pageEnd){
+ $n = $this->nStateStack;
+ $this->currentColour = $this->stateStack[$n]['col'];
+ $this->currentStrokeColour = $this->stateStack[$n]['str'];
+ $this->objects[$this->currentContents]['c'].="\n".$this->stateStack[$n]['lin'];
+ $this->currentLineStyle = $this->stateStack[$n]['lin'];
+ unset($this->stateStack[$n]);
+ $this->nStateStack--;
+ $this->objects[$this->currentContents]['c'].="\nQ";
+* make a loose object, the output will go into this object, until it is closed, then will revert to
+* the current one.
+* this object will not appear until it is included within a page.
+* the function will return the object number
+function openObject(){
+ $this->nStack++;
+ $this->stack[$this->nStack]=array('c'=>$this->currentContents,'p'=>$this->currentPage);
+ // add a new object of the content type, to hold the data flow
+ $this->numObj++;
+ $this->looseObjects[$this->numObj]=1;
+ return $this->numObj;
+* open an existing object for editing
+function reopenObject($id){
+ $this->nStack++;
+ $this->currentContents=$id;
+ // also if this object is the primary contents for a page, then set the current page to its parent
+ if (isset($this->objects[$id]['onPage'])){
+ $this->currentPage = $this->objects[$id]['onPage'];
+* close an object
+function closeObject(){
+ // close the object, as long as there was one open in the first place, which will be indicated by
+ // an objectId on the stack.
+ if ($this->nStack>0){
+ $this->currentContents=$this->stack[$this->nStack]['c'];
+ $this->currentPage=$this->stack[$this->nStack]['p'];
+ $this->nStack--;
+ // easier to probably not worry about removing the old entries, they will be overwritten
+ // if there are new ones.
+* stop an object from appearing on pages from this point on
+function stopObject($id){
+ // if an object has been appearing on pages up to now, then stop it, this page will
+ // be the last one that could contian it.
+ if (isset($this->addLooseObjects[$id])){
+ $this->addLooseObjects[$id]='';
+* after an object has been created, it wil only show if it has been added, using this function.
+function addObject($id,$options='add'){
+ // add the specified object to the page
+ if (isset($this->looseObjects[$id]) && $this->currentContents!=$id){
+ // then it is a valid object, and it is not being added to itself
+ switch($options){
+ case 'all':
+ // then this object is to be added to this page (done in the next block) and
+ // all future new pages.
+ $this->addLooseObjects[$id]='all';
+ case 'add':
+ if (isset($this->objects[$this->currentContents]['onPage'])){
+ // then the destination contents is the primary for the page
+ // (though this object is actually added to that page)
+ $this->o_page($this->objects[$this->currentContents]['onPage'],'content',$id);
+ break;
+ case 'even':
+ $this->addLooseObjects[$id]='even';
+ $pageObjectId=$this->objects[$this->currentContents]['onPage'];
+ if ($this->objects[$pageObjectId]['info']['pageNum']%2==0){
+ $this->addObject($id); // hacky huh :)
+ break;
+ case 'odd':
+ $this->addLooseObjects[$id]='odd';
+ if ($this->objects[$pageObjectId]['info']['pageNum']%2==1){
+ break;
+ case 'next':
+ break;
+ case 'nexteven':
+ break;
+ case 'nextodd':
+ break;
+* add content to the documents info object
+function addInfo($label,$value=0){
+ // this will only work if the label is one of the valid ones.
+ // modify this so that arrays can be passed as well.
+ // if $label is an array then assume that it is key=>value pairs
+ // else assume that they are both scalar, anything else will probably error
+ if (is_array($label)){
+ foreach ($label as $l=>$v){
+ $this->o_info($this->infoObject,$l,$v);
+ } else {
+ $this->o_info($this->infoObject,$label,$value);
+* set the viewer preferences of the document, it is up to the browser to obey these.
+function setPreferences($label,$value=0){
+ $this->o_catalog($this->catalogId,'viewerPreferences',array($l=>$v));
+ } else {
+ $this->o_catalog($this->catalogId,'viewerPreferences',array($label=>$value));
+* extract an integer from a position in a byte stream
+* @access private
+function PRVT_getBytes(&$data,$pos,$num){
+ // return the integer represented by $num bytes from $pos within $data
+ $ret=0;
+ for ($i=0;$i<$num;$i++){
+ $ret=$ret*256;
+ $ret+=ord($data[$pos+$i]);
+ return $ret;
+* add a PNG image into the document, from a file
+* this should work with remote files
+function addPngFromFile($file,$x,$y,$w=0,$h=0){
+ // read in a png file, interpret it, then add to the system
+ $error=0;
+ $fp = @fopen($file,'rb');
+ if ($fp){
+ $data='';
+ while(!feof($fp)){
+ $data .= fread($fp,1024);
+ fclose($fp);
+ } else {
+ $error = 1;
+ $errormsg = 'trouble opening file: '.$file;
+ if (!$error){
+ $header = chr(137).chr(80).chr(78).chr(71).chr(13).chr(10).chr(26).chr(10);
+ if (substr($data,0,8)!=$header){
+ $error=1;
+ $errormsg = 'this file does not have a valid header';
+ if (!$error){
+ // set pointer
+ $p = 8;
+ $len = strlen($data);
+ // cycle through the file, identifying chunks
+ $haveHeader=0;
+ $info=array();
+ $idata='';
+ $pdata='';
+ while ($p<$len){
+ $chunkLen = $this->PRVT_getBytes($data,$p,4);
+ $chunkType = substr($data,$p+4,4);
+// echo $chunkType.' - '.$chunkLen.'<br>';
+ switch($chunkType){
+ case 'IHDR':
+ // this is where all the file information comes from
+ $info['width']=$this->PRVT_getBytes($data,$p+8,4);
+ $info['height']=$this->PRVT_getBytes($data,$p+12,4);
+ $info['bitDepth']=ord($data[$p+16]);
+ $info['colorType']=ord($data[$p+17]);
+ $info['compressionMethod']=ord($data[$p+18]);
+ $info['filterMethod']=ord($data[$p+19]);
+ $info['interlaceMethod']=ord($data[$p+20]);
+//print_r($info);
+ $haveHeader=1;
+ if ($info['compressionMethod']!=0){
+ $error=1;
+ $errormsg = 'unsupported compression method';
+ if ($info['filterMethod']!=0){
+ $error=1;
+ $errormsg = 'unsupported filter method';
+ break;
+ case 'PLTE':
+ $pdata.=substr($data,$p+8,$chunkLen);
+ break;
+ case 'IDAT':
+ $idata.=substr($data,$p+8,$chunkLen);
+ break;
+ case 'tRNS':
+ //this chunk can only occur once and it must occur after the PLTE chunk and before IDAT chunk
+ //print "tRNS found, color type = ".$info['colorType']."<BR>";
+ $transparency = array();
+ if ($info['colorType'] == 3) { // indexed color, rbg
+ /* corresponding to entries in the plte chunk
+ Alpha for palette index 0: 1 byte
+ Alpha for palette index 1: 1 byte
+ ...etc...
+ // there will be one entry for each palette entry. up until the last non-opaque entry.
+ // set up an array, stretching over all palette entries which will be o (opaque) or 1 (transparent)
+ $transparency['type']='indexed';
+ $numPalette = strlen($pdata)/3;
+ $trans=0;
+ for ($i=$chunkLen;$i>=0;$i--){
+ if (ord($data[$p+8+$i])==0){
+ $trans=$i;
+ $transparency['data'] = $trans;
+ } elseif($info['colorType'] == 0) { // grayscale
+ Gray: 2 bytes, range 0 .. (2^bitdepth)-1
+// $transparency['grayscale']=$this->PRVT_getBytes($data,$p+8,2); // g = grayscale
+ $transparency['data'] = ord($data[$p+8+1]);
+ } elseif($info['colorType'] == 2) { // truecolor
+ Red: 2 bytes, range 0 .. (2^bitdepth)-1
+ Green: 2 bytes, range 0 .. (2^bitdepth)-1
+ Blue: 2 bytes, range 0 .. (2^bitdepth)-1
+ $transparency['r']=$this->PRVT_getBytes($data,$p+8,2); // r from truecolor
+ $transparency['g']=$this->PRVT_getBytes($data,$p+10,2); // g from truecolor
+ $transparency['b']=$this->PRVT_getBytes($data,$p+12,2); // b from truecolor
+ } else {
+ //unsupported transparency type
+ // KS End new code
+ break;
+ default:
+ break;
+ $p += $chunkLen+12;
+ if(!$haveHeader){
+ $error = 1;
+ $errormsg = 'information header is missing';
+ if (isset($info['interlaceMethod']) && $info['interlaceMethod']){
+ $error = 1;
+ $errormsg = 'There appears to be no support for interlaced images in pdf.';
+ if (!$error && $info['bitDepth'] > 8){
+ $error = 1;
+ $errormsg = 'only bit depth of 8 or less is supported';
+ if (!$error){
+ if ($info['colorType']!=2 && $info['colorType']!=0 && $info['colorType']!=3){
+ $error = 1;
+ $errormsg = 'transparancey alpha channel not supported, transparency only supported for palette images.';
+ } else {
+ switch ($info['colorType']){
+ case 3:
+ $color = 'DeviceRGB';
+ $ncolor=1;
+ break;
+ case 2:
+ $ncolor=3;
+ break;
+ case 0:
+ $color = 'DeviceGray';
+ $ncolor=1;
+ break;
+ if ($error){
+ $this->addMessage('PNG error - ('.$file.') '.$errormsg);
+ return;
+ if ($w==0){
+ $w=$h/$info['height']*$info['width'];
+ if ($h==0){
+ $h=$w*$info['height']/$info['width'];
+//print_r($info);
+ // so this image is ok... add it in.
+ $this->numImages++;
+ $im=$this->numImages;
+ $label='I'.$im;
+ $this->numObj++;
+// $this->o_image($this->numObj,'new',array('label'=>$label,'data'=>$idata,'iw'=>$w,'ih'=>$h,'type'=>'png','ic'=>$info['width']));
+ $options = array('label'=>$label,'data'=>$idata,'bitsPerComponent'=>$info['bitDepth'],'pdata'=>$pdata
+ ,'iw'=>$info['width'],'ih'=>$info['height'],'type'=>'png','color'=>$color,'ncolor'=>$ncolor);
+ if (isset($transparency)){
+ $options['transparency']=$transparency;
+ $this->o_image($this->numObj,'new',$options);
+ $this->objects[$this->currentContents]['c'].="\n".sprintf('%.3f',$w)." 0 0 ".sprintf('%.3f',$h)." ".sprintf('%.3f',$x)." ".sprintf('%.3f',$y)." cm";
+ $this->objects[$this->currentContents]['c'].="\n/".$label.' Do';
+* add a JPEG image into the document, from a file
+function addJpegFromFile($img,$x,$y,$w=0,$h=0){
+ // attempt to add a jpeg image straight from a file, using no GD commands
+ // note that this function is unable to operate on a remote file.
+ if (!file_exists($img)){
+ return;
+ $tmp=getimagesize($img);
+ $imageWidth=$tmp[0];
+ $imageHeight=$tmp[1];
+ if (isset($tmp['channels'])){
+ $channels = $tmp['channels'];
+ } else {
+ $channels = 3;
+ if ($w<=0 && $h<=0){
+ $w=$imageWidth;
+ if ($w==0){
+ $w=$h/$imageHeight*$imageWidth;
+ if ($h==0){
+ $h=$w*$imageHeight/$imageWidth;
+ $fp=fopen($img,'rb');
+ $data = fread($fp,filesize($img));
+ fclose($fp);
+ $this->addJpegImage_common($data,$x,$y,$w,$h,$imageWidth,$imageHeight,$channels);
+* add an image into the document, from a GD object
+* this function is not all that reliable, and I would probably encourage people to use
+* the file based functions
+function addImage(&$img,$x,$y,$w=0,$h=0,$quality=75){
+ // add a new image into the current location, as an external object
+ // add the image at $x,$y, and with width and height as defined by $w & $h
+ // note that this will only work with full colour images and makes them jpg images for display
+ // later versions could present lossless image formats if there is interest.
+ // there seems to be some problem here in that images that have quality set above 75 do not appear
+ // not too sure why this is, but in the meantime I have restricted this to 75.
+ if ($quality>75){
+ $quality=75;
+ // if the width or height are set to zero, then set the other one based on keeping the image
+ // height/width ratio the same, if they are both zero, then give up :)
+ $imageWidth=imagesx($img);
+ $imageHeight=imagesy($img);
+ return;
+ if ($w==0){
+ if ($h==0){
+ // gotta get the data out of the img..
+ // so I write to a temp file, and then read it back.. soo ugly, my apologies.
+ $tmpDir='/tmp';
+ $tmpName=tempnam($tmpDir,'img');
+ imagejpeg($img,$tmpName,$quality);
+ $fp=fopen($tmpName,'rb');
+ $fp = @fopen($tmpName,'rb');
+ if ($fp){
+ $data='';
+ fclose($fp);
+ } else {
+ $error = 1;
+ $errormsg = 'trouble opening file';
+// $data = fread($fp,filesize($tmpName));
+// fclose($fp);
+ unlink($tmpName);
+ $this->addJpegImage_common($data,$x,$y,$w,$h,$imageWidth,$imageHeight);
+* common code used by the two JPEG adding functions
+* @access private
+function addJpegImage_common(&$data,$x,$y,$w=0,$h=0,$imageWidth,$imageHeight,$channels=3){
+ // note that this function is not to be called externally
+ // it is just the common code between the GD and the file options
+ $label='I'.$im;
+ $this->numObj++;
+ $this->o_image($this->numObj,'new',array('label'=>$label,'data'=>$data,'iw'=>$imageWidth,'ih'=>$imageHeight,'channels'=>$channels));
+* specify where the document should open when it first starts
+function openHere($style,$a=0,$b=0,$c=0){
+ // this function will open the document at a specified page, in a specified style
+ // the values for style, and the required paramters are:
+ // 'XYZ' left, top, zoom
+ // 'Fit'
+ // 'FitH' top
+ // 'FitV' left
+ // 'FitR' left,bottom,right
+ // 'FitB'
+ // 'FitBH' top
+ // 'FitBV' left
+ $this->numObj++;
+ $this->o_destination($this->numObj,'new',array('page'=>$this->currentPage,'type'=>$style,'p1'=>$a,'p2'=>$b,'p3'=>$c));
+ $id = $this->catalogId;
+ $this->o_catalog($id,'openHere',$this->numObj);
+* create a labelled destination within the document
+function addDestination($label,$style,$a=0,$b=0,$c=0){
+ // associates the given label with the destination, it is done this way so that a destination can be specified after
+ // it has been linked to
+ // styles are the same as the 'openHere' function
+ $this->numObj++;
+ $id = $this->numObj;
+ // store the label->idf relationship, note that this means that labels can be used only once
+ $this->destinations["$label"]=$id;
+* define font families, this is used to initialize the font families for the default fonts
+* and for the user to add new ones for their fonts. The default bahavious can be overridden should
+* that be desired.
+function setFontFamily($family,$options=''){
+ if ($family=='init'){
+ // set the known family groups
+ // these font families will be used to enable bold and italic markers to be included
+ // within text streams. html forms will be used... <b></b> <i></i>
+ $this->fontFamilies['Helvetica.afm']=array(
+ 'b'=>'Helvetica-Bold.afm'
+ ,'i'=>'Helvetica-Oblique.afm'
+ ,'bi'=>'Helvetica-BoldOblique.afm'
+ ,'ib'=>'Helvetica-BoldOblique.afm'
+ $this->fontFamilies['Courier.afm']=array(
+ 'b'=>'Courier-Bold.afm'
+ ,'i'=>'Courier-Oblique.afm'
+ ,'bi'=>'Courier-BoldOblique.afm'
+ ,'ib'=>'Courier-BoldOblique.afm'
+ $this->fontFamilies['Times-Roman.afm']=array(
+ 'b'=>'Times-Bold.afm'
+ ,'i'=>'Times-Italic.afm'
+ ,'bi'=>'Times-BoldItalic.afm'
+ ,'ib'=>'Times-BoldItalic.afm'
+ } else {
+ // the user is trying to set a font family
+ // note that this can also be used to set the base ones to something else
+ if (strlen($family)){
+ $this->fontFamilies[$family] = $options;
+* used to add messages for use in debugging
+function addMessage($message){
+ $this->messages.=$message."\n";
+* a few functions which should allow the document to be treated transactionally.
+function transaction($action){
+ switch ($action){
+ case 'start':
+ // store all the data away into the checkpoint variable
+ $data = get_object_vars($this);
+ $this->checkpoint = $data;
+ unset($data);
+ break;
+ case 'commit':
+ if (is_array($this->checkpoint) && isset($this->checkpoint['checkpoint'])){
+ $tmp = $this->checkpoint['checkpoint'];
+ $this->checkpoint = $tmp;
+ unset($tmp);
+ } else {
+ $this->checkpoint='';
+ break;
+ case 'rewind':
+ // do not destroy the current checkpoint, but move us back to the state then, so that we can try again
+ if (is_array($this->checkpoint)){
+ // can only abort if were inside a checkpoint
+ $tmp = $this->checkpoint;
+ foreach ($tmp as $k=>$v){
+ if ($k != 'checkpoint'){
+ $this->$k=$v;
+ unset($tmp);
+ break;
+ case 'abort':
+ $this->$k=$v;
+ unset($tmp);
+ break;
+} // end of class
\ No newline at end of file
Added: trunk/mapbender/http/classes/class_SaveLegend.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/class_SaveLegend.php?view=auto&rev=13
--- (empty file)
+++ trunk/mapbender/http/classes/class_SaveLegend.php 2006-04-13 19:38:28+0000
@@ -0,0 +1,68 @@
+<?php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+* class_SaveLegend
+* @version 1.0.0
+* getlegendurl
+require_once("class_stripRequest.php");
+require_once("class_mb_exception.php");
+require_once("class_connector.php");
+class SaveLegend{
+ function SaveLegend($url,$legend_filename){
+ if(!$url || $url == ""){
+ $e = new mb_exception("SaveLegend: no legendurl delivered");
+ $obj1 = new stripRequest($url);
+ $size = getimagesize($url);
+ $width = $size[0];
+ $height = $size[1];
+ $image = imagecreatetruecolor($width, $height);
+ $white = ImageColorAllocate($image,255,255,255);
+ ImageFilledRectangle($image,0,0,$width,$height,$white);
+ $obj = new stripRequest($url);
+ $url = $obj->setPNG();
+ //$url = $obj->encodeGET(); entfernt AE
+ $img = $this->loadpng($url);
+ if($img != false){
+ imagecopy($image, $img, 0, 0, 0, 0, $width, $height);
+ }else{
+ $e = new mb_exception("SaveLegend: unable to load image: " . $url);
+ imagepng($img,$legend_filename);
+ imagedestroy($img);
+ function loadpng ($imgurl) {
+ $x = new connector($imgurl);
+ $im = @imagecreatefromstring($x->file);
+ if(!$im){
+ $im = false;
+ $e = new mb_exception("SaveLegend: unable to load image: ".$imgurl);
+ imageinterlace($im, 0);
+ return $im;
+ imagedestroy($im);
Added: trunk/mapbender/http/classes/class_administration.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/class_administration.php?view=auto&rev=13
--- (empty file)
+++ trunk/mapbender/http/classes/class_administration.php 2006-04-13 19:38:28+0000
@@ -0,0 +1,722 @@
+<?php
+#$Id: class_administration.php,v 1.22 2006/02/15 10:51:14 astrid_emde Exp $
+#$Header: /cvsroot/mapbender/mapbender/http/classes/class_administration.php,v 1.22 2006/02/15 10:51:14 astrid_emde Exp $
+require_once("../../conf/mapbender.conf");
+ * class administration
+ * Methods:
+ * getGuisByOwner(id): returns an array of all guis where the user is owner
+ * getGuisByPermission(id): returns an array of all guis where the user has
+ * permission to read
+ * getWmsByOwnGuis($array_gui_ids): returns an array of wms which are included
+ * in own guis
+ require("phpmailer-1.72/class.phpmailer.php");
+class administration{
+ function adminstration(){
+ // CB - returns true if $email is a valid email
+ function isValidEmail ($email) {
+ if(eregi("^[_a-z0-9-]+(\.[_a-z0-9-]+)*@[a-z0-9-]+(\.[a-z0-9-]+)*(\.[a-z]{2,3})$", $email)) {
+ return true;
+ return false;
+ // CB - sends email with less parameters
+ function sendEmail($fromAddr, $fromName, $toAddr, $toName, $subject, $body, &$error_msg ) {
+ global $mailHost, $mailUsername, $mailPassword;
+ if($fromAddr == ''){
+ $fromAddr = MAILADMIN;
+ if($fromName == ''){
+ $fromName = MAILADMINNAME;
+ if ($this->isValidEmail($fromAddr) && $this->isValidEmail($toAddr)) {
+ $mail = new PHPMailer();
+ if ($fromName != "" ) {
+ $mail->FromName = $fromName;
+ $mail->IsSMTP(); // set mailer to use SMTP
+ $mail->Host = $mailHost; // specify main and backup server
+ $mail->SMTPAuth = true; // turn on SMTP authentication
+ $mail->Username = $mailUsername; // SMTP username
+ $mail->Password = $mailPassword; // SMTP password
+ $mail->From = $fromAddr;
+ $mail->AddAddress($toAddr, $toName);
+ #$mail->AddReplyTo("info at ccgis.de", "Information");
+ $mail->WordWrap = 50; // set word wrap to 50 characters
+ #$mail->AddAttachment("/var/tmp/file.tar.gz"); // add attachments
+ #$mail->AddAttachment("/tmp/image.jpg", "new.jpg"); // optional name
+ $mail->IsHTML(false); // set email format to HTML
+ $mail->Subject = "[".$fromName."] ".$subject;
+ $mail->Body = $body;
+ #$mail->AltBody = "This is the body in plain text for non-HTML mail clients";
+ $error_msg='';
+ if(!$mail->Send())
+ $error_msg .= "Mailer Error: " . $mail->ErrorInfo;
+ return false;
+ return true;
+ else {
+ return false;
+ // CB - generates random password with $max digits
+ function getRandomPassword() {
+ // password length
+ $max = 16;
+ //new password
+ $newpass = "";
+ for ($i=0;$i <= $max;$i++) {
+ //die ASCII-Zeichen 48 - 57 sind die zahlen 0-9
+ //die ASCII-Zeichen 65 - 90 sind die buchstaben A-Z (Groß)
+ //die ASCII-Zeichen 97 - 122 sind die buchstaben a-z (Klein)
+ $ascii = 0;
+ do {
+ $ascii=rand(48,122);
+ } while ( ($ascii > 57 && $ascii < 65) || ($ascii > 90 && $ascii < 97));
+ $newpass .= chr($ascii);
+ return $newpass;
+ // CB - returns all owners (both from mb_user *and* mb_user from mb_group) of a gui
+ function getOwnerByGui($gui_id) {
+ global $DBSERVER,$DB,$OWNER,$PW;
+$sql = "(SELECT mb_user.mb_user_name";
+$sql .= "FROM mb_user ";
+$sql .= "JOIN gui_mb_user ON mb_user.mb_user_id = gui_mb_user.fkey_mb_user_id ";
+$sql .= "WHERE gui_mb_user.mb_user_type = 'owner' ";
+$sql .= "AND gui_mb_user.fkey_gui_id = '".$gui_id."' ";
+$sql .= "GROUP BY mb_user.mb_user_name ";
+$sql .= ") ";
+$sql .= "UNION ( ";
+$sql .= "SELECT mb_user.mb_user_name ";
+$sql .= "FROM gui_mb_group ";
+$sql .= "JOIN mb_user_mb_group ON mb_user_mb_group.fkey_mb_group_id = gui_mb_group.fkey_mb_group_id ";
+$sql .= "JOIN mb_user ON mb_user.mb_user_id = mb_user_mb_group.fkey_mb_user_id ";
+$sql .= "WHERE gui_mb_group.mb_group_type = 'owner' ";
+$sql .= "AND gui_mb_group.fkey_gui_id = '".$gui_id."' ";
+$sql .= "GROUP BY mb_user.mb_user_name) ;";
+ $owner = array();
+ $res = db_query($sql);
+ $cnt = 0;
+ while($row = db_fetch_array($res)){
+ $owner[$cnt] = $row["mb_user_name"];
+ $cnt++;
+ return $owner;
+ //CB - returns the email address of a user identified by id
+ function getEmailByUserId($id){
+ $con = db_connect($DBSERVER,$OWNER,$PW);
+ db_select_db(DB,$con);
+ $sql = "SELECT mb_user_email FROM mb_user ";
+ $sql .= "WHERE mb_user_id = '".$id."' GROUP by mb_user_email";
+ $count_g = 0;
+ $array = array();
+ $row = db_fetch_array($res);
+ if ($row) {
+ return $row["mb_user_email"];
+ else {
+ return false;
+ //CB - returns the user id of a user identified by username
+ function getUserNameByUserId($id){
+ $sql = "SELECT mb_user_name FROM mb_user ";
+ $sql .= "WHERE mb_user_id = '".$id."' GROUP BY mb_user_name";
+ $count_g = 0;
+ $array = array();
+ if ($row) {
+ return $row["mb_user_name"];
+ else {
+ return false;
+ // CB - returns userId of user(s) with email address $email
+ function getUserIdByEmail($email){
+ $sql = "SELECT mb_user_id FROM mb_user ";
+ $sql .= "WHERE mb_user_email = '".$email."' GROUP BY mb_user_id";
+ $count_g = 0;
+ $array = array();
+ $array[$count_g] = $row["mb_user_id"];
+ $count_g++;
+ if ($count_g >0) {
+ return $array;
+ else {
+ return false;
+ // CB - returns all owners of wms $wms_id
+ function getOwnerByWms($wms_id){
+ $sql = "SELECT fkey_gui_id FROM gui_wms WHERE fkey_wms_id = ".$wms_id." GROUP BY fkey_gui_id";
+ $count=0;
+ $gui[$count] = $row["fkey_gui_id"];
+ $count++;
+ if ($count > 0) {
+ if(count($gui)>0){
+ $sql = "(SELECT mb_user.mb_user_name FROM mb_user JOIN gui_mb_user ";
+ $sql .= "ON mb_user.mb_user_id = gui_mb_user.fkey_mb_user_id ";
+ $sql .= " WHERE gui_mb_user.mb_user_type = 'owner'";
+ $sql .= " AND gui_mb_user.fkey_gui_id IN (";
+ for($i=0; $i<count($gui); $i++){
+ if($i>0){ $sql .= ",";}
+ $sql .= "'".$gui[$i]."'";
+ $sql .= ") GROUP BY mb_user.mb_user_name";
+ $sql .= ") UNION (";
+ $sql .= "SELECT mb_user.mb_user_name FROM gui_mb_group JOIN mb_user_mb_group ON mb_user_mb_group.fkey_mb_group_id = gui_mb_group.fkey_mb_group_id JOIN mb_user ";
+ $sql .= "ON mb_user.mb_user_id = mb_user_mb_group.fkey_mb_user_id ";
+ $sql .= " WHERE gui_mb_group.mb_group_type = 'owner'";
+ $sql .= " AND gui_mb_group.fkey_gui_id IN (";
+ $sql .= ") GROUP BY mb_user.mb_user_name)";
+ $user = array();
+ $cnt = 0;
+ $user[$cnt] = $row["mb_user_name"];
+ $cnt++;
+ if ($cnt>0) return $user;
+ else return false;
+ * CB
+ * these functions may be easier to use as existing functions
+ * however i have now decided not included them to avoid confusion
+ // CB (works)
+ function getWmsByGuis($array_gui_ids){
+ $sql = "SELECT distinct fkey_wms_id from gui_wms WHERE gui_wms.fkey_gui_id IN(";
+ for($i=0; $i<count($array_gui_ids); $i++){
+ $sql .= "'".$array_gui_ids[$i]."'";
+ $sql .= ")";
+ $count=0;
+ $wms_id = array();
+ $wms_id[$count] = $row["fkey_wms_id"];
+ $count++;
+ return $wms_id;
+ // CB (not tested)
+ function getWmsByPermGuis($user_id){
+ $gui_list = $this->getGuisByPermission($user_id);
+ return $this->getWmsByGuis($gui_list);
+ //CB - returns the GML of a WMC identifies by wmc_id
+ function guiExists($id){
+ $sql = "SELECT * FROM gui WHERE gui_id = '". $id."'";
+ if ($row) {
+ return true;
+ else {
+ return false;
+ //CB - deletes a wmc by id. $user_id has to fit db entry
+ function deleteWmc($wmc_id, $user_id){
+ $sql = "DELETE FROM mb_user_wmc ";
+ $sql .= "WHERE fkey_user_id = '".$user_id."' AND wmc_id = '" . $wmc_id . "'";
+ if ($res) {
+ return true;
+ else {
+ return false;
+ // CB - insert gui $gui_id
+ function insertGui($guiId) {
+ if (!$this->guiExists($guiId)) {
+ $sql = "INSERT INTO gui VALUES ('" . $guiId . "', '" . $guiId . "', '', '1')";
+ if ($res) {
+ return true;
+ return false;
+ // CB - deletes from gui_mb_user where gui_id
+ function delAllUsersOfGui($guiId) {
+ $sql = "DELETE FROM gui_mb_user WHERE fkey_gui_id = '" . $guiId . "'";
+ if (!$res) {
+ return false;
+ else {
+ return true;
+ // CB (works)
+ function getWmsByOwner($user_id) {
+ $gui_list = $this->getGuisByOwner($user_id);
+ return $this->getWmsByOwnGuis($gui_list);
+ // CB -returns all users using a certain wms $wms_id
+ function getUserByWms($wms_id){
+ $count=0;
+ $count++;
+ $sql .= " WHERE gui_mb_user.fkey_gui_id IN (";
+ $sql .= ") GROUP BY mb_user.mb_user_name) UNION";
+ $sql .= "(SELECT mb_user.mb_user_name FROM gui_mb_group JOIN mb_user_mb_group ON mb_user_mb_group.fkey_mb_group_id = gui_mb_group.fkey_mb_group_id JOIN mb_user ";
+ $sql .= " WHERE gui_mb_group.fkey_gui_id IN (";
+ $sql .= ") GROUP BY mb_user.mb_user_name )";
+ $user = array();
+ $cnt = 0;
+ $cnt++;
+ return $user;
+ //CB - returns the title of a WMS identifies by wms_id
+ function getWmsTitleByWmsId($id){
+ $sql = "SELECT wms_title from wms WHERE wms_id = '". $id."' GROUP BY wms_title";
+ if ($row) {
+ return $row["wms_title"];
+ else {
+ return false;
+ //CB - returns the title of a GUI identifies by gui_id
+ function getGuiTitleByGuiId($id){
+ $sql = "SELECT gui_title from gui WHERE gui_id = '".$id."' GROUP BY gui_title";
+ if ($row) {
+ return $row["gui_title"];
+ else {
+ return false;
+ function getWmcById($id){
+ $sql = "SELECT wmc FROM mb_user_wmc WHERE wmc_id = '".$id."'";
+ if ($row) {
+ return $row["wmc"];
+ else {
+ return false;
+ // CB
+ function resetLoginCount($userId) {
+ $sql = "UPDATE mb_user SET mb_user_login_count = '0' ";
+ $sql .= "WHERE mb_user_id = '" . $userId . "'";
+ if (!$res) {
+ return false;
+ else {
+ return true;
+ function getUserIdByUserName($username){
+ $sql .= "WHERE mb_user_name = '".$username."' GROUP BY mb_user_id";
+ $count_g = 0;
+ $array = array();
+ $count_g++;
+ return $array;
+ else {
+ return false;
+ // CB - set user identified by name as owner of gui $gui_id
+ function setUserAsGuiOwner($guiId, $userId) {
+ $sql = "UPDATE gui_mb_user SET mb_user_type = 'owner' ";
+ $sql .= "WHERE fkey_gui_id = '" . $guiId . "' AND fkey_mb_user_id = '".$userId."'";
+ if (!$res) {
+ return false;
+ else {
+ return true;
+ // CB - returns the guiId for a given guiTitle
+ function getGuiIdByGuiName($guiTitle){
+ $sql = "SELECT gui_id FROM gui ";
+ $sql .= "WHERE gui_name = '".$guiTitle."' GROUP BY gui_id";
+ $count_g = 0;
+ $array = array();
+ $array[$count_g] = $row["gui_id"];
+ $count_g++;
+ return $array;
+ else {
+ return false;
+ function getGuisByOwner($user_id){
+ $connect = db_connect($DBSERVER,$OWNER,$PW);
+ db_select_db(DB);
+ $sql_guis = "SELECT gui.gui_id FROM gui,gui_mb_user ";
+ $sql_guis .= "WHERE (gui.gui_id = gui_mb_user.fkey_gui_id AND gui_mb_user.fkey_mb_user_id = ".$user_id.") ";
+ $sql_guis .= " AND gui.gui_public = 1 AND gui_mb_user.mb_user_type = 'owner' GROUP BY gui.gui_id";
+ $res_guis = db_query($sql_guis);
+ $count_g = 0;
+ $arrayGuis = array();
+ while($row = db_fetch_array($res_guis)){
+ $arrayGuis[$count_g] = $row["gui_id"];
+ $count_g++;
+ return $arrayGuis;
+ //CB - returns an array of WMC IDs
+ function getWmcByOwner($user_id){
+ db_select_db(DB);
+ $sql_wmc = "SELECT wmc_id FROM mb_user_wmc ";
+ $sql_wmc .= "WHERE fkey_user_id = '".$user_id."' GROUP BY wmc_id";
+ $res_wmc = db_query($sql_wmc);
+ $count_g = 0;
+ $arrayWmc = array();
+ while($row = db_fetch_array($res_wmc)){
+ $arrayWmc[$count_g] = $row["wmc_id"];
+ $count_g++;
+ return $arrayWmc;
+ function getGuisByPermission($mb_user_id){
+ $sql_groups = "SELECT fkey_mb_group_id FROM mb_user_mb_group WHERE fkey_mb_user_id = ". $mb_user_id." ;";
+ $res_groups = db_query($sql_groups);
+ $cnt_groups = 0;
+ while($row = db_fetch_array($res_groups)){
+ $mb_user_groups[$cnt_groups] = $row["fkey_mb_group_id"];
+ $cnt_groups++;
+ $count_g = 0;
+ if($cnt_groups > 0){
+ $sql_g = "SELECT gui.gui_id FROM gui JOIN gui_mb_group ";
+ $sql_g .= " ON gui.gui_id = gui_mb_group.fkey_gui_id WHERE gui_mb_group.fkey_mb_group_id IN (";
+ for($i=0; $i<count($mb_user_groups);$i++){
+ if($i > 0){$sql_g .= ",";}
+ $sql_g .= $mb_user_groups[$i];
+ $sql_g .= ") GROUP BY gui.gui_id";
+ $res_g = db_query($sql_g);
+ while($row = db_fetch_array($res_g)){
+ $count_g++;
+ $sql_guis = "SELECT gui.gui_id FROM gui JOIN gui_mb_user ON gui.gui_id = gui_mb_user.fkey_gui_id";
+ $sql_guis .= " WHERE (gui_mb_user.fkey_mb_user_id = ".$mb_user_id.") ";
+ $sql_guis .= " AND gui.gui_public = 1 GROUP BY gui.gui_id";
+ $count_guis = 0;
+ $guis = array();
+ $guis[$count_guis] = $row['gui_id'];
+ $count_guis++;
+ return $guis;
+ function getWmsByOwnGuis($array_gui_ids){
+ if(count($array_gui_ids)>0){
+ $sql = "SELECT fkey_wms_id from gui_wms WHERE gui_wms.fkey_gui_id IN(";
+ $sql .= ") GROUP BY fkey_wms_id";
+ $ownguis = array();
+ $i=0;
+ $ownguis[$i] = $row['fkey_wms_id'];
+ $i++;
+ return $ownguis;
+ #ToDo: check if empty function is merge error
+ #function getWmsByPermGuis($array_gui_ids){
+ function getWmsOwner($wms_id){
+ $count=0;
+ $count++;
+ $sql = "SELECT mb_user.mb_user_name FROM mb_user JOIN gui_mb_user ";
+ $sql .= "ON mb_user.mb_user_id = gui_mb_user.fkey_mb_user_id WHERE";
+ $sql .= " gui_mb_user.fkey_gui_id IN (";
+ $sql .= ")";
+ $sql .= " AND gui_mb_user.mb_user_type = 'owner' GROUP BY mb_user.mb_user_name";
+ $i=0;
+ $wmsowner = array();
+ $wmsowner[$i]=$row['mb_user_name'];
+ $i++;
+ return $wmsowner;
+ // CB - insert user $user_id as owner of gui $gui_id
+ function insertUserAsGuiOwner($guiId, $userId) {
+ db_select_db($DB,$con);
+ $sql = "INSERT INTO gui_mb_user VALUES ('" . $guiId . "', '" . $userId . "', 'owner')";
+ if (!$res) {
+ return false;
+ else {
+ return true;
+ function checkModulePermission($arrayGuis, $modulePath, $column){
+ $check = true;
+ if($check == true){
+ $perm = false;
+ if(count($arrayGuis)>0){
+ $sql = "SELECT ".$column." FROM gui_element WHERE fkey_gui_id IN(";
+ for($i=0; $i<count($arrayGuis); $i++){
+ if($i > 0){ $sql .= ","; }
+ $sql .= "'".$arrayGuis[$i]."'";
+ $sql .= ")";
+ $cnt = 0;
+ if(strpos(stripslashes($row[$column]),$modulePath) !== false){
+ $perm = true;
+ $cnt++;
+ return $perm;
+ else{
+ return true;
Added: trunk/mapbender/http/classes/class_connector.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/class_connector.php?view=auto&rev=13
--- (empty file)
+++ trunk/mapbender/http/classes/class_connector.php 2006-04-13 19:38:28+0000
@@ -0,0 +1,69 @@
+<?php
+# $Id: class_connector.php,v 1.1 2005/11/07 17:00:28 uli_rothstein Exp $
+# $Header: /cvsroot/mapbender/mapbender/http/classes/class_connector.php,v 1.1 2005/11/07 17:00:28 uli_rothstein Exp $
+class connector{
+ var $file;
+ function connector($url){
+ if(CONNECTION == 'curl'){
+ $this->file = $this->getCURL($url);
+ if(CONNECTION == 'http'){
+ $this->file = $this->getHTTP($url);
+ if(CONNECTION == 'socket'){
+ $this->file = $this->getSOCKET($url);
+ function getCURL($url){
+ $ch = curl_init ($url);
+// curl_setopt($ch, CURLOPT_BINARYTRANSFER, 1);
+ if(CONNECTION_PROXY != ""){
+ curl_setopt($ch, CURLOPT_PROXY,CONNECTION_PROXY.":".CONNECTION_PORT);
+ if(CONNECTION_PASSWORD != ""){
+ curl_setopt ($ch, CURLOPT_PROXYUSERPWD, CONNECTION_USER.':'.CONNECTION_PASSWORD);
+ curl_setopt ($ch, CURLOPT_RETURNTRANSFER, 1);
+ $file = curl_exec ($ch);
+ curl_close ($ch);
+ return $file;
+ function getHTTP($url){
+ return file_get_contents($url);
+ function getSOCKET($url){
+ $r = "";
+ $fp = fsockopen (CONNECTION_PROXY, CONNECTION_PORT, $errno, $errstr, 30);
+ if (!$fp) {
+ echo "$errstr ($errno)<br />\n";
+ } else {
+ fputs ($fp, "GET ".$url." HTTP/1.0\r\n\r\n");
+ while (!feof($fp)) {
+ $r .= fgets($fp,4096);
+ fclose($fp);
+ return $r;
+#$x = new connector("http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/mapbender_user/mapbender_user.map&&VERSION=1.1.1&REQUEST=GetCapabilities&SERVICE=WMS");
+#$x = new connector("http://www.ccgis.de/img/header_02.gif");
+#echo $x->file;
Added: trunk/mapbender/http/classes/class_database.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/class_database.php?view=auto&rev=13
--- (empty file)
+++ trunk/mapbender/http/classes/class_database.php 2006-04-13 19:38:28+0000
@@ -0,0 +1,939 @@
+<?php
+# $Id: class_database.php,v 1.7 2005/09/26 15:02:25 c_baudson Exp $
+# $Header: /cvsroot/mapbender/mapbender/http/classes/class_database.php,v 1.7 2005/09/26 15:02:25 c_baudson Exp $
+ manages a database structure
+ contact christoph.baudson at ccgis.de for help
+require_once("class_database_table.php");
+class database{
+ * Class variables:
+ var $table = array();
+ var $table_cnt = -1;
+ var $server;
+ var $db;
+ var $owner;
+ var $pw;
+ var $con;
+ // constructs a database object
+ // if it represents a database of the mapbender user, it should be initialized with arguments,
+ // otherwise (if it represents a remote db) arguments are "", "", "", ""
+ // the constructor already connects to the database!
+ function database($aServer, $aDbName, $anOwner, $aPassword) {
+ $this->table_cnt = 0;
+ $this->server = $aServer;
+ $this->db = $aDbName;
+ $this->owner = $anOwner;
+ $this->pw = $aPassword;
+ // connect only if all parameters are set
+ if (!($this->server == "" || $this->db == "" || $this->owner == "")) {
+ $this->connect();
+ function connect () {
+ if ($this->server == "" || $this->db == "" || $this->owner == "" ) {
+ echo "Could not connect to database. Some arguments are missing.<br>";
+ echo "server = '" . $this->server . "'; db = '" . $this->db . "'; owner = '" . $this->owner . "';<br>";
+ die();
+ else {
+ $this->con = db_connect($this->server,$this->owner,$this->pw);
+ if ($this->con) {
+ $this->selectDb();
+# echo $this->server . "<br>";
+# echo $this->db . "<br>";
+# echo $this->owner . "<br>";
+# echo $this->pw . "<br>";
+ function selectDb () {
+ if (!db_select_db($this->db)) {
+ echo "Error while selecting database '" . $this->db . "'<br>";
+ die();
+ // adds a table object to the database object
+ // the table name must be unique
+ function addTable($aTableName){
+ if ($this->getNumberOfTables() == 0 || !in_array($aTableName, $this->getTableNames())) {
+ $this->table[$this->table_cnt] = new database_table($aTableName);
+ $this->table_cnt++;
+ return (strval($this->table_cnt)-1);
+ else {
+ echo "Table '" . $aTableName . "' already in database!<br>";
+ // adds a column object to the table object (table index is known)
+ // the column name must be unique within its table object
+ function addColumnToTableAtIndex($aColumnName, $aTableIndex) {
+ $columnIndex = $this->table[$aTableIndex]->addColumn($aColumnName);
+ return $columnIndex;
+ // adds a column object to the table object (table index is unknown)
+ function addKeyToTableAtIndex($aKeyName, $aColumnName, $isPrimary, $aTableIndex) {
+ $keyIndex = $this->table[$aTableIndex]->addKey($aKeyName, $aColumnName, $isPrimary);
+ return $keyIndex;
+ // adds a constraint object to the table object (table index is unknown)
+ function addConstraintToTableAtIndex ($conSymbol, $tableIndex, $conColumn, $conTableName, $conTableColumnName, $conOnDelete, $conOnUpdate) {
+ $this->table[$tableIndex]->addConstraint($conSymbol, $conColumn, $conTableName, $conTableColumnName, $conOnDelete, $conOnUpdate);
+ // returns an array of all table names in this database
+ function getTableNames() {
+ $tables = array();
+ for ($i=0; $i<$this->table_cnt; $i++) {
+ $tables[$i] = $this->table[$i]->getName();
+ if ($this->table_cnt>0) {
+ return $tables;
+ else {
+ return false;
+ // return a table object (index is known)
+ function getTableAtIndex($anIndex) {
+ return $this->table[$anIndex];
+ // return a table object (index is unknown)
+ function getTableWithName($aName) {
+ return $this->table[$this->getTableIndex($aName)];
+ // return the index of a table object
+ function getTableIndex($aTableName) {
+ if ($aTableName == $this->table[$i]->getName()) {
+ return $i;
+ return false;
+ // returns the number of tables in this database object
+ function getNumberOfTables () {
+ return $this->table_cnt;
+ // sets the engine type (f.e. 'InnoDb')
+ function setTableType($anIndex, $aType) {
+ $this->table[$anIndex]->setType($aType);
+ // sets the column data type for a column objext in a table object (both indexes unknown)
+ function setColumnTypeInColumnAtIndexInTableAtIndex($aColumnType, $aColumnIndex, $aTableIndex) {
+ $this->table[$aTableIndex]->setColumnTypeAtIndex($aColumnType, $aColumnIndex);
+ // sets the column attributes (f.e. "NOT NULL")
+ function setColumnAttributesInColumnAtIndexInTableAtIndex($someColumnAttributes, $aColumnIndex, $aTableIndex) {
+ $this->table[$aTableIndex]->setColumnAttributesAtIndex($someColumnAttributes, $aColumnIndex);
+ // sets the column default (f.e. "DEFAULT ''")
+ function setColumnDefaultInColumnAtIndexInTableAtIndex($someColumnDefault, $aColumnIndex, $aTableIndex) {
+ $this->table[$aTableIndex]->setColumnDefaultAtIndex($someColumnDefault, $aColumnIndex);
+ // displays the whole database structure
+ function displayDatabase() {
+ print_r($this->table);
+ // imports the structure of an actual database specified by server, db, owner, pw
+ function mysqlDbToDatabase() {
+ if (!$this->con) {
+ $this->connect();
+ // collects all table names
+ $sql = "SHOW TABLES FROM " . $this->db;
+ $cnt = 0;
+ while($table = db_fetch_row($res)){
+ $inst_tables[$cnt] = $table[0];
+ $cnt++;
+ $message = array();
+ $createTable = array();
+ // generates SHOW CREATE TABLE sqls for each table name
+ for ($i=0; $i<count($inst_tables); $i++) {
+ $sql = "SHOW CREATE TABLE " . $inst_tables[$i];
+ $cnt = 0;
+ $message[$cnt] = $table[1];
+ $cnt++;
+ $createTable[$i] = $message[0] . ";";
+ $createTableString = implode("\n", $createTable);
+ $createTableArray = array();
+ $createTableArray = explode("\n", $createTableString);
+ // treat the sqls just like a dump
+ $cleanDump = $this->mysqlCleanDumpArray($createTableArray);
+ $this->mysqlDumpToDatabaseFromArray($cleanDump);
+ // compares this database object with another (remote) one
+ // returns sql statements that adds or changes tables/columns/constraints/keys
+ // so that this database has all fields of the remote database as well
+ function compareDbWithRemoteDb($remoteDb, &$messageArray) {
+ $sql = "";
+ $message = "";
+ $sqlCreateTable = "";
+ $messageCreateTable = "";
+ $sqlColumn = "";
+ $messageColumn = "";
+ $sqlKey = "";
+ $messageKey = "";
+ $sqlConstraint = "";
+ $messageConstraint = "";
+ $splitString = "::::";
+ for ($i=0; $i < $remoteDb->getNumberOfTables(); $i++) {
+ $t = $remoteDb->getTableAtIndex($i);
+ $table = $t->getName();
+ // check tables
+ // check if all tables from the remote DB are in the local DB
+ // if a table is missing, generate a SQL containg a CREATE TABLE statement
+ if (!in_array($table, $this->getTableNames())) {
+ $messageCreateTable .= "Table '" . $table . "' is missing.";
+ $messageCreateTable .= $splitString;
+ $sqlCreateTable .= $t->getMysql();
+ //table exists, now checking columns
+ else {
+ // check columns
+ // check if all columns of a table from the remote DB are in the local DB
+ // if a column is missing, generate a SQL containg a ALTER TABLE statement
+ //php4
+ $table_i = $t;
+ $table_i_nr_cols = $table_i->getNumberOfColumns();
+ $tableWithName_table = $this->getTableWithName($table);
+ for ($j=0; $j < $table_i_nr_cols; $j++) {
+ $c = $table_i->getColumnAtIndex($j);
+ $column = $c->getName();
+ if (!in_array($column, $tableWithName_table->getColumnNames())) {
+#PHP5 if (!in_array($column, $this->getTableWithName($table)->getColumnNames())) {
+ $messageColumn .= "Column '".$column."' is missing.";
+ $messageColumn .= $splitString;
+ $sqlColumn .= "ALTER TABLE " . $table . " ADD COLUMN";
+ $sqlColumn .= $c->getMysql();
+ //column exists, now checking type and attributes
+ else {
+ // check if type (varchar etc) AND attributes are equal
+ $colWithName_column = $tableWithName_table->getColumnWithName($column);
+ if (trim(strtoupper($colWithName_column->getType())) != trim(strtoupper($c->getType()))
+ || trim(strtoupper($colWithName_column->getAttributes())) != trim(strtoupper($c->getAttributes()))) {
+#php5 if (trim(strtoupper($this->getTableWithName($table)->getColumnWithName($column)->getType())) != trim(strtoupper($remoteDb->getTableAtIndex($i)->getColumnAtIndex($j)->getType()))
+#php5 || trim(strtoupper($this->getTableWithName($table)->getColumnWithName($column)->getAttributes())) != trim(strtoupper($remoteDb->getTableAtIndex($i)->getColumnAtIndex($j)->getAttributes()))) {
+ $messageColumn .= "Column '".$column."' has incorrect type or attributes.";
+ $sqlColumn .= "ALTER TABLE " . $table . " CHANGE COLUMN " . $column;
+ * checking DEFAULTs doesn't work properly
+ if (trim(strtoupper($this->getTableWithName($table)->getColumnWithName($column)->getDefaultValue())) != trim(strtoupper($remoteDb->getTableAtIndex($i)->getColumnAtIndex($j)->getDefaultValue()))) {
+ $messageColumn .= "Column '".$remoteDb->getTableAtIndex($i)->getColumnAtIndex($j)->getName()."' has incorrect default value.";
+ #echo trim(strtoupper($this->getTableWithName($table)->getColumnWithName($column)->getDefaultValue())) . "<br>";
+ #echo trim(strtoupper($remoteDb->getTableAtIndex($i)->getColumnAtIndex($j)->getDefaultValue())) . "<br><br>";
+ $sqlColumn .= "ALTER TABLE " . $table . " ALTER COLUMN " . $column;
+ $newDef = trim(strtoupper($remoteDb->getTableAtIndex($i)->getColumnAtIndex($j)->getDefaultValue()));
+ if ($newDef) {
+ $sqlColumn .= " SET DEFAULT " . trim(strtoupper($remoteDb->getTableAtIndex($i)->getColumnAtIndex($j)->getDefaultValue())) . "\n\n";
+ else {
+ $sqlColumn .= " DROP DEFAULT\n\n";
+ // check keys
+ for ($j=0; $j < $table_i->getNumberOfKeys(); $j++) {
+ $k = $table_i->getKeyAtIndex($j);
+ $key = $k->getKey();
+ if (!in_array($key, $tableWithName_table->getAllKeys())) {
+#php5 if (!in_array($key, $this->getTableWithName($table)->getAllKeys())) {
+ $messageKey .= "Key '".$k->getName()."' is missing.";
+ $messageKey .= $splitString;
+ $sqlKey .= "ALTER TABLE " . $table . " ADD";
+ $sqlKey .= $k->getMysql();
+ // check constraints
+ // FIXME
+ // InnoDB: Let InnoDB's FOREIGN KEY parser to remove the latin1 character 0xA0
+ // from the end of an unquoted identifier. The EMS MySQL Manager in ALTER TABLE
+ // adds that character after a table name, which caused error 121 when we tried
+ // to add a new constraint.
+ // May work with Mysql >= 4.1
+ // http://bugs.mysql.com/bug.php?id=6340
+ for ($j=0; $j < $table_i->getNumberOfConstraints(); $j++) {
+ $k = $table_i->getConstraintAtIndex($j);
+ $key = $k->getConstraint();
+ $someArray = $tableWithName_table->getAllConstraints();
+ if (!in_array($key, $someArray)) {
+ $messageConstraint .= "Constraint is missing.";
+ $messageConstraint .= $splitString;
+ $sqlConstraint .= "ALTER TABLE " . $table . " ADD";
+ $sqlConstraint .= $k->getMysql();
+ //order in which the sql statements will be processed
+ // create table
+ // add / change column
+ // add / change key
+ // add / change constraints
+ $sql = $sqlCreateTable . $sqlColumn . $sqlKey . $sqlConstraint;
+ $message = $messageCreateTable . $messageColumn . $messageKey . $messageConstraint;
+ // remove last "\n\n"
+ $sql = substr($sql, 0, strlen($sql)-2);
+ // remove last $splitString
+ $message = substr($message, 0, strlen($message)-strlen($splitString));
+ // break sql string into single sql statements
+ $sqlArray = explode("\n\n", $sql);
+ // break message string into single message statements
+ $messageArray = explode($splitString, $message);
+ return $sqlArray;
+ // executes a single sql statement
+ // connection details have to be specified in this database object
+ // returns a string with error message
+ function executeMysql($sql) {
+ $error = "";
+ $this->connect();
+ if (db_errno()) {
+ $error .= $sql . "<br>" . db_error() . "<br><br>";
+ return $error;
+ // executes sql statements
+ // returns a string with all error messages
+ function executeMysqlArray($sqlArray) {
+ $error = "";
+ for ($i=0; $i<count($sqlArray); $i++) {
+ if ($sqlArray[$i] != "") {
+ $error .= $this->executeMysql($sqlArray[$i]);
+ return $error;
+ // executes sql transaction
+ function executeMysqlTransaction($sqlArray) {
+ $error = "";
+ $error .= $this->executeMysql("START TRANSACTION");
+ //echo $error;
+ $error .= $this->executeMysql("COMMIT");
+ return $error;
+ // ONLY NEEDED IN function mysqlDumpToDatabaseFromArrayNew($dumpArray)
+ // this function extracts attributes of a constraint from an excerpt of an sql statement
+ // this is needed in two segments of the algorithm and is therefore put in a function
+ function addConstraintFromString($row, $tableIndex) {
+ //retrieve constraint data
+ $row = str_replace("(", "", $row);
+ $row = str_replace(")", "", $row);
+ $row = str_replace(", ", " ", $row);
+ while (ereg("([:space:]){2}")) {
+ ereg_replace("([:space:]){2}", "([:space:])", $row);
+ $row = str_replace("on delete", "ondelete", strtolower($row));
+ $row = str_replace("on update", "onupdate", strtolower($row));
+ $row = str_replace("foreign key", "foreignkey", strtolower($row));
+ $values = explode(" ", $row);
+ $cnt = 0;
+ $conSymbol = "";
+ $conOnDelete = "";
+ $conOnUpdate = "";
+ $conColumn = "";
+ $conTableName = "";
+ $conTableColumnName = "";
+ if ($cnt < count($values) && strtolower($values[$cnt]) == "constraint") {
+ $cnt++;
+ if ($cnt < count($values) && strtolower($values[$cnt]) != "foreignkey") {
+ $conSymbol = $values[$cnt];
+ $cnt++;
+ if ($cnt < count($values) && strtolower($values[$cnt]) == "foreignkey") {
+ $cnt++;
+ while ($cnt < count($values) && strtolower($values[$cnt]) != "references") {
+ if (!$conColumn) {
+ $conColumn = $values[$cnt];
+ else {
+ $conColumn .= "," . $values[$cnt];
+ $cnt++;
+ if ($cnt < count($values) && strtolower($values[$cnt]) == "references") {
+ $cnt++;
+ $conTableName = $values[$cnt];
+ $cnt++;
+ while ($cnt < count($values) && strtolower($values[$cnt]) != "ondelete" && strtolower($values[$cnt]) != "onupdate" ) {
+ if (!$conTableColumnName) {
+ $conTableColumnName = $values[$cnt];
+ else {
+ $conTableColumnName .= "," . $values[$cnt];
+ $cnt++;
+ if ($cnt < count($values) && strtolower($values[$cnt]) == "ondelete") {
+ $cnt++;
+ $conOnDelete = $values[$cnt];
+ $cnt++;
+ if ($cnt < count($values) && strtolower($values[$cnt]) == "onupdate") {
+ $cnt++;
+ $conOnUpdate = $values[$cnt];
+ $cnt++;
+ $this->addConstraintToTableAtIndex($conSymbol, $tableIndex, $conColumn, $conTableName, $conTableColumnName, $conOnDelete, $conOnUpdate);
+ // creates a database object from a mysql dump
+ // the dump is parsed and the objects are generated accordingly
+ // needs some testing!
+ // restrictions:
+ // only 'foreign key' constraints are implemented, no other constraints.
+ function mysqlDumpToDatabaseFromArray($commandArray) {
+ // now the parsing begins
+ $tableIndex = -1;
+ $keyIndex = -1;
+ $tablename = "";
+ $verbose = "";
+ for ($i=0; $i<count($commandArray); $i++) {
+ $line = $commandArray[$i];
+ // check for "CREATE TABLE"
+ if (strtolower(substr($line, 0, 12)) == "create table") {
+ // remove "create table" from the string
+ $line = trim(substr($line, 12));
+ // look for "(", because it marks the end of the table name
+ $pos = strpos($line, "(");
+ $tablename = trim(substr($line, 0, $pos));
+ $tableIndex = $this->addTable($tablename);
+ //remove tablename and "(" from string
+ $line = trim(substr($line, $pos+1));
+ //get the last ")" in the string and get the type
+ $type = trim(substr(strrchr($line, ")"), 1));
+ $type = trim(substr(strstr($line, '='), 1));
+ $this->setTableType($tableIndex, $type);
+ //remove the type bit from the line
+ $line = substr($line, 0, strlen($line)-strlen(strrchr($line, ")")));
+ //replace , that are not seperating column definitions (or key definitions)
+ // these may be , that seperate two columns forming a key
+ $regexp = "(\([A-Za-z0-9[:space:]_\-\,;]+)\,([A-Za-z0-9[:space:]_\-\,;]+\))";
+ $regexp_replace = "\\1;;;\\2";
+ $replace = false;
+ while (ereg($regexp, $line)) {
+ #if (!$replace) echo "<br><br>" . $line . "<br><br>";
+ $line = ereg_replace($regexp, $regexp_replace, $line);
+ $replace = true;
+ $rows = explode(",", $line);
+ $rows = str_replace(";;;", ",", $rows);
+ for ($j=0; $j<count($rows); $j++) {
+ // trim each row.
+ $row = trim($rows[$j]);
+ //find primary keys
+ if (strtolower(substr($row,0,11)) == "primary key" ) {
+ //retrieve key data
+ $row = trim(substr($row, 12));
+ $row = trim(str_replace("(", "", $row));
+ $row = trim(str_replace(")", "", $row));
+ $keyIndex = $this->addKeyToTableAtIndex("", $row, true, $tableIndex);
+ // key
+ elseif (strtolower(substr($row,0,3)) == "key" ) {
+ $row = trim(substr($row, 4));
+ $keys = explode(" ", $row);
+ //add key to object
+ $keyIndex = $this->addKeyToTableAtIndex($keys[0], $keys[1], false, $tableIndex);
+ elseif (strtolower(substr($row,0,10)) == "constraint" ) {
+ $this->addConstraintFromString(substr($row, 11), $tableIndex);
+ else {
+ //retrieve column information
+ $column = explode(" ", $row);
+ $col_name = $column[0];
+ $col_type = $column[1];
+ $col_attributes = substr($row,strlen($column[0])+strlen($column[1])+2);
+ $col_attr_array = explode(" ", $col_attributes);
+ $col_attributes = "";
+ for ($r=0; $r<strlen($col_attr_array); $r++) {
+ if (strtoupper($col_attr_array[$r]) == "DEFAULT") {
+ $defaultValue = $col_attr_array[$r+1];
+ $r++;
+ else {
+ $col_attributes .= $col_attr_array[$r] . " ";
+ //add columns to object
+ $columnIndex = $this->addColumnToTableAtIndex($col_name, $tableIndex);
+ $this->setColumnTypeInColumnAtIndexInTableAtIndex($col_type, $columnIndex, $tableIndex);
+ $this->setColumnAttributesInColumnAtIndexInTableAtIndex($col_attributes, $columnIndex, $tableIndex);
+ $this->setColumnDefaultInColumnAtIndexInTableAtIndex($defaultValue, $columnIndex, $tableIndex);
+ // CHECK FOR ALTER TABLE (for constraints, like in PHPMyAdmin dumps)
+ elseif (strtolower(substr($line, 0, 11)) == "alter table") {
+ // remove "alter table" from the string
+ // identify the tableIndex of the constraint
+ $pos = strpos($line, " ");
+ $tableIndex = $this->getTableIndex($tablename);
+ // delete table name from line
+ // identify the command, f.e. ADD
+ $cmd = trim(substr($line, 0, $pos));
+ $line = trim(str_replace(",", "", $line));
+ $constraintStrings = explode($cmd, $line);
+ for ($k=0; $k<count($constraintStrings); $k++) {
+ $con = trim($constraintStrings[$k]);
+ $this->addConstraintFromString($con, $tableIndex);
+ function mysqlCleanDumpArray ($dumpArray) {
+ // remove commentary and name wrappers
+ $cnt=0;
+ $newDumpArray = array();
+ for ($i=0; $i<count($dumpArray); $i++) {
+ // remove ` (name wrappers, like in dumpArrays from PHPMyAdmin)
+ $dumpArray[$i] = trim(str_replace("`", "", $dumpArray[$i]));
+ // discard empty lines and comments (lines beginning with "#" (like in MySQL Front), or "-" (like in PHPMyAdmin))
+ if (substr($dumpArray[$i], 0, 1) == "#" || substr($dumpArray[$i], 0, 1) == "-" || $dumpArray[$i]=="") {
+ $dumpArray[$i] = "";
+ else {
+ $newDumpArray[$cnt] = $dumpArray[$i];
+ $cnt++;
+ // put everything in one string
+ $dump = implode(":::: ", $newDumpArray);
+ //remove tabs and new lines
+ $dump = str_replace("\n", "", $dump);
+ $dump = str_replace("\t", "", $dump);
+ // replace multiple spaces by single spaces
+ while(ereg(" ", $dump)){
+ $dump = ereg_replace(" ", " ", $dump);
+ // split string to array of single sql commands
+ $commandArray = explode(";::::", $dump);
+ // trim each command
+ $commandArray[$i] = str_replace("::::", "", trim($commandArray[$i]));
+ //remove last ";"
+ if (substr($commandArray[$i], -1) == ";") {
+ $commandArray[$i] = substr($commandArray[$i], 0, strlen($commandArray[$i])-1);
+ return $commandArray;
+ // loads a mysql dump hands it over to the parser
+ function mysqlDumpToDatabaseFromUrl($url) {
+ $dumpArray=array();
+ if ($dumpArray = file($url)) {
+ $cleanDump = $this->mysqlCleanDumpArray($dumpArray);
+ else {
+ echo "MySQL dump not found!";
+ die();
+ function mysqlDumpFromArray($dumpArray) {
+ return $cleanDump;
+ function mysqlDumpFromUrl($url) {
+ return false;
+ // removes a table object at a given index
+ function removeTableAtIndex ($aTableIndex) {
+ if ($aTableIndex && $aTableIndex < $this->table_cnt && $aTableIndex >= 0) {
+ $this->table[$aTableIndex]->destroyTable();
+ //fill gap in table array with last entry
+ if ($this->table_cnt > 1 && $aTableIndex != $this->table_cnt-1) {
+ $this->table[$aTableIndex] = $this->table[$this->table_cnt-1];
+ $this->table[$this->table_cnt-1] = null;
+ $this->table_cnt--;
+ else {
+ echo "Table '" . $aTableIndex . "' not in database!<br>";
+ // removes a table object (table index unknown)
+ function removeTableWithName($aTableName){
+ $index = $this->getTableIndex($aTableName);
+ $this->removeTableAtIndex($index);
+ // removes a column object in a table object (table index unknown)
+ function removeColumnWithNameInTableWithName($aColumnName, $aTableName){
+ $this->removeColumnWithNameInTableAtIndex($aColumnName, $index);
+ // removes a key object in a table object (table index unknown)
+ function removeKeyWithNameInTableWithName($aKeyName, $aTableName){
+ $this->removeKeyWithNameInTableAtIndex($aKeyName, $index);
+ // removes a constraint object in a table object (table index unknown)
+ function removeConstraintWithNameInTableWithName($aConstraintName, $aTableName){
+ $this->removeConstraintWithNameInTableAtIndex($aConstraintName, $index);
+ // removes a column object in a table object at a given table index
+ function removeKeyWithNameInTableAtIndex($aKeyName, $aTableIndex){
+ if ($aTableIndex < $this->table_cnt && $aTableIndex >= 0 && $aKeyName != "") {
+ $this->table[$aTableIndex]->removeKeyWithName($aKeyName);
+ else {
+ echo "Table index out of range!<br>";
+ // removes a constraint object in a table object at a given table index
+ function removeConstraintWithNameInTableAtIndex($aConstraintName, $aTableIndex){
+ if ($aTableIndex < $this->table_cnt && $aTableIndex >= 0 && $aConstraintName != "") {
+ $this->table[$aTableIndex]->removeConstraintWithName($aConstraintName);
+ else {
+ function removeColumnWithNameInTableAtIndex($aColumnName, $aTableIndex){
+ if ($aTableIndex < $this->table_cnt && $aTableIndex >= 0 && $aColumnName != "") {
+ $this->table[$aTableIndex]->removeColumnWithName($aColumnName);
+ else {
+// EXAMPLES
+// this is how the database object may be accessed
+//creates a database from an actual database
+//$myDb = new database($server, $db, $owner, $pw);
+//$myDb->mysqlDbToDatabase();
+//creates a database from a mysql dump
+//$myDb = new database("", "", "", "");
+//$myDb->mysqlDumpToDatabaseFromUrl("http://localhost/mapbender/mapbender_PHPMyAdmin.sql");
+//removes the table "wms" from the database
+//$myDb->removeTableWithName("mb_user_mb_group");
+//(intended to be a private method)
+//removes the column "gui_id" from table "gui"
+//$myDb->removeColumnWithNameInTableWithName("gui_id", "gui");
+//removes the key "mb_Group_index" from table "mb_user_mb_group"
+//$myDb->removeKeyWithNameInTableWithName("mb_group_index", "mb_user_mb_group");
+//removes the constraint "mb_user_mb_group_ibfk_1" from table "mb_user_mb_group"
+//$myDb->removeConstraintWithNameInTableWithName("mb_user_mb_group_ibfk_1", "mb_user_mb_group");
+//validates ownDb against remoteDb and returns an SQL string
+//$sql = $myDb->compareDbWithRemoteDb($theirDb);
+// executes all statements and displays occuring mysql errors
+//echo $myDb->executeMysqlArray($sqlArray);
+//displays the complete database structure
+//$myDb->displayDatabase();
+ * MySQL - Definition CREATE TABLE
+ CREATE [TEMPORARY] TABLE [IF NOT EXISTS] tbl_name
+ [(create_definition,...)]
+ [table_options] [select_statement]
+ [(] LIKE old_tbl_name [)];
+ create_definition:
+ column_definition
+ | [CONSTRAINT [symbol]] PRIMARY KEY [index_type] (index_col_name,...)
+ | KEY [index_name] [index_type] (index_col_name,...)
+ | INDEX [index_name] [index_type] (index_col_name,...)
+ | [CONSTRAINT [symbol]] UNIQUE [INDEX]
+ [index_name] [index_type] (index_col_name,...)
+ | [FULLTEXT|SPATIAL] [INDEX] [index_name] (index_col_name,...)
+ | [CONSTRAINT [symbol]] FOREIGN KEY
+ [index_name] (index_col_name,...) [reference_definition]
+ | CHECK (expr)
+ column_definition:
+ col_name type [NOT NULL | NULL] [DEFAULT default_value]
+ [AUTO_INCREMENT] [UNIQUE [KEY] | [PRIMARY] KEY]
+ [COMMENT 'string'] [reference_definition]
+ type:
+ TINYINT[(length)] [UNSIGNED] [ZEROFILL]
+ | SMALLINT[(length)] [UNSIGNED] [ZEROFILL]
+ | MEDIUMINT[(length)] [UNSIGNED] [ZEROFILL]
+ | INT[(length)] [UNSIGNED] [ZEROFILL]
+ | INTEGER[(length)] [UNSIGNED] [ZEROFILL]
+ | BIGINT[(length)] [UNSIGNED] [ZEROFILL]
+ | REAL[(length,decimals)] [UNSIGNED] [ZEROFILL]
+ | DOUBLE[(length,decimals)] [UNSIGNED] [ZEROFILL]
+ | FLOAT[(length,decimals)] [UNSIGNED] [ZEROFILL]
+ | DECIMAL(length,decimals) [UNSIGNED] [ZEROFILL]
+ | NUMERIC(length,decimals) [UNSIGNED] [ZEROFILL]
+ | DATE
+ | TIME
+ | TIMESTAMP
+ | DATETIME
+ | CHAR(length) [BINARY | ASCII | UNICODE]
+ | VARCHAR(length) [BINARY]
+ | TINYBLOB
+ | BLOB
+ | MEDIUMBLOB
+ | LONGBLOB
+ | TINYTEXT [BINARY]
+ | TEXT [BINARY]
+ | MEDIUMTEXT [BINARY]
+ | LONGTEXT [BINARY]
+ | ENUM(value1,value2,value3,...)
+ | SET(value1,value2,value3,...)
+ | spatial_type
+ index_col_name:
+ col_name [(length)] [ASC | DESC]
+ reference_definition:
+ REFERENCES tbl_name [(index_col_name,...)]
+ [MATCH FULL | MATCH PARTIAL | MATCH SIMPLE]
+ [ON DELETE reference_option]
+ [ON UPDATE reference_option]
+ reference_option:
+ RESTRICT | CASCADE | SET NULL | NO ACTION
+ table_options: table_option [table_option] ...
+ table_option:
+ {ENGINE|TYPE} = engine_name
+ | AUTO_INCREMENT = value
+ | AVG_ROW_LENGTH = value
+ | [DEFAULT] CHARACTER SET charset_name [COLLATE collation_name]
+ | CHECKSUM = {0 | 1}
+ | COMMENT = 'string'
+ | MAX_ROWS = value
+ | MIN_ROWS = value
+ | PACK_KEYS = {0 | 1 | DEFAULT}
+ | PASSWORD = 'string'
+ | DELAY_KEY_WRITE = {0 | 1}
+ | ROW_FORMAT = {DEFAULT|DYNAMIC|FIXED|COMPRESSED|REDUNDANT|COMPACT}
+ | RAID_TYPE = { 1 | STRIPED | RAID0 }
+ RAID_CHUNKS = value
+ RAID_CHUNKSIZE = value
+ | UNION = (tbl_name[,tbl_name]...)
+ | INSERT_METHOD = { NO | FIRST | LAST }
+ | DATA DIRECTORY = 'absolute path to directory'
+ | INDEX DIRECTORY = 'absolute path to directory'
+ select_statement:
+ [IGNORE | REPLACE] [AS] SELECT ... (Some legal select statement)
Added: trunk/mapbender/http/classes/class_database_table.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/class_database_table.php?view=auto&rev=13
--- (empty file)
+++ trunk/mapbender/http/classes/class_database_table.php 2006-04-13 19:38:28+0000
@@ -0,0 +1,416 @@
+<?php
+# $Id: class_database_table.php,v 1.5 2005/09/26 15:02:25 c_baudson Exp $
+# $Header: /cvsroot/mapbender/mapbender/http/classes/class_database_table.php,v 1.5 2005/09/26 15:02:25 c_baudson Exp $
+require_once("class_database_table_column.php");
+require_once("class_database_table_key.php");
+require_once("class_database_table_constraint.php");
+class database_table{
+ var $name;
+ var $column = array();
+ var $key = array();
+ var $constraint = array();
+ var $key_cnt = -1;
+ var $column_cnt = -1;
+ var $constraint_cnt = -1;
+ var $type;
+ function database_table($aName) {
+ $this->constraint_cnt = 0;
+ $this->column_cnt = 0;
+ $this->key_cnt = 0;
+ $this->name = $aName;
+ function addKey ($aKeyName, $aColumnName, $isPrimary) {
+ if (!strpos($aColumnName, ",")) {
+ // referenced column must be part of the table
+ if (in_array($aColumnName, $this->getColumnNames())) {
+ if ($this->getNumberOfKeys() == 0 || !$this->keyExists($aKeyName, $aColumnName)) {
+ $this->key[$this->key_cnt] = new database_table_key($aKeyName, $aColumnName, $isPrimary);
+ $index = $this->key_cnt;
+ $this->key_cnt ++;
+ return $index;
+ else {
+ echo "Key '" . $aKeyName . "' already in table!<br>";
+ else {
+ echo "Error when adding a new key: Column '" . $aColumnName . "' must be from table '" . $this->getName() . "'!<br>";
+ else {
+ $keyArray = explode(",", $aColumnName);
+ $inArray = true;
+ for ($i=0; $i < count($keyArray); $i++) {
+ if (!in_array($keyArray[$i], $this->getColumnNames())) {
+ $inArray = false;
+ if ($inArray) {
+ return $index;
+ else {
+ function addConstraint($conSymbol, $conColumn, $conTableName, $conTableColumnName, $conOnDelete, $conOnUpdate) {
+ if (!strpos($conColumn, ",")&& !strpos($conTableColumnName, ",")) {
+ if (in_array($conColumn, $this->getColumnNames())) {
+ $newConstr = new database_table_constraint($conSymbol, $conColumn, $conTableName, $conTableColumnName, $conOnDelete, $conOnUpdate);
+ $conSymbol = "";
+ #print_r($newConstr);
+ #print_r($this->getAllConstraints());
+ if (!in_array($newConstr, $this->getAllConstraints())) {
+ $this->constraint[$this->constraint_cnt] = $newConstr;
+ $index = $this->constraint_cnt;
+ $this->constraint_cnt ++;
+ return $index;
+ else {
+ echo "Error when adding a new constraint: Column '" . $conColumn . "' must be from table '" . $this->getName() . "'!<br>";
+ else {
+ $inArray = true;
+ $keyArray = explode(",", $conColumn);
+ $inArray = false;
+ $keyArray = explode(",", $conTableColumnName);
+ $inArray = false;
+ if ($inArray) {
+ return $index;
+ return false;
+ function addColumn ($aColumnName) {
+ if ($this->getNumberOfColumns() == 0 || !in_array($aColumnName, $this->getColumnNames())) {
+ $this->column[$this->column_cnt] = new database_table_column($aColumnName);
+ $index = $this->column_cnt;
+ $this->column_cnt ++;
+ return $index;
+ else {
+ echo "Column '" . $aColumnName . "' already in table!<br>";
+ function getName(){
+ return $this->name;
+ function getKeyAtIndex($anIndex){
+ return $this->key[$anIndex];
+ function getAllKeys(){
+ $keyArray = array();
+ for ($i=0; $i<$this->getNumberOfKeys(); $i++) {
+ $key_i = $this->getKeyAtIndex($i);
+ $keyArray[$i] = $key_i->getKey();
+ return $keyArray;
+ function getAllConstraints(){
+ $conArray = array();
+ for ($i=0; $i<$this->getNumberOfConstraints(); $i++) {
+ $con_i = $this->getConstraintAtIndex($i);
+ $conArray[$i] = $con_i->getConstraint();
+ return $conArray;
+ function getConstraintAtIndex($anIndex){
+ return $this->constraint[$anIndex];
+ function getColumnAtIndex($anIndex){
+ return $this->column[$anIndex];
+ function getColumnWithName($aName){
+ return $this->getColumnAtIndex($this->getColumnIndex($aName));
+ function getType() {
+ return $this->type;
+ function getMysql() {
+ $sql = "";
+ $sql .= "CREATE TABLE " . $this->getName() . " (\n";
+ // add the columns
+ for ($i=0; $i<$this->getNumberOfColumns(); $i++) {
+ $sql .= "\t" . $this->column[$i]->getName() . " ";
+ $sql .= $this->column[$i]->getType() . " ";
+ $sql .= $this->column[$i]->getAttributes();
+ $sql .= ",";
+ $sql .= "\n";
+ // add keys
+ if ($this->key[$i]->isPrimary()) {
+ $sql .= "\tPRIMARY KEY ";
+ else {
+ $sql .= "\tKEY ";
+ $sql .= $this->key[$i]->getKeyName() . " ";
+ $sql .= "(" . $this->key[$i]->getColumnName() . "),\n";
+ // add constraints
+ $constr = array();
+ $constr = $this->constraint[$i]->getConstraint();
+ $sql .= "\tCONSTRAINT";
+ // constraint name
+ if ($constr[0]) {
+ $sql .= " " . $constr[0];
+ if ($constr[1]) {
+ $sql .= " FOREIGN KEY (" . $constr[1] . ")";
+ if ($constr[2] && $constr[3]) {
+ $sql .= " REFERENCES " . $constr[2] . " (" . $constr[3] . ")";
+ if ($constr[4]) {
+ $sql .= " ON DELETE " . $constr[4];
+ if ($constr[5]) {
+ $sql .= " ON UPDATE " . $constr[5];
+ $sql .= ",\n";
+ // remove last ","
+ $sql = substr($sql, 0, strlen($sql)-2) . "\n";
+ // add the table type
+ $sql .= ") TYPE = " . $this->getType() . "\n\n";
+ return $sql;
+ function getColumnNames() {
+ $columns = array();
+ for ($i=0; $i<$this->column_cnt; $i++) {
+ $columns[$i] = $this->column[$i]->getName();
+ if ($this->column_cnt>0) {
+ return $columns;
+ else {
+ return false;
+ function getColumnIndex($aColumnName) {
+ if ($aColumnName == $this->column[$i]->getName()) {
+ return $i;
+ return false;
+ function getKeyIndex($aKeyName) {
+ for ($i=0; $i<$this->key_cnt; $i++) {
+ if ($aKeyName == $this->key[$i]->getKeyName()) {
+ return $i;
+ return false;
+ function getConstraintIndex($aConstraintName) {
+ for ($i=0; $i<$this->constraint_cnt; $i++) {
+ if ($aConstraintName == $this->constraint[$i]->getName()) {
+ return $i;
+ return false;
+ function getNumberOfColumns () {
+ return $this->column_cnt;
+ function getNumberOfConstraints () {
+ return $this->constraint_cnt;
+ function getNumberOfKeys () {
+ return $this->key_cnt;
+ function destroyTable() {
+ settype(&$this, 'null');
+ //FIXME
+ function keyExists ($aKeyName, $aColumnName) {
+ return false;
+ //FIXME
+ function constraintExists ($aConstraintName, $aColumnName) {
+ return false;
+ function setType($aType) {
+ $this->type = $aType;
+ function setColumnTypeAtIndex($aColumnType, $aColumnIndex) {
+ if ($aColumnIndex < $this->column_cnt) {
+ $this->column[$aColumnIndex]->setType($aColumnType);
+ else {
+ echo "column index out of range!";
+ function setColumnAttributesAtIndex($someColumnAttributes, $aColumnIndex) {
+ $this->column[$aColumnIndex]->setAttributes($someColumnAttributes);
+ else {
+ function setColumnDefaultAtIndex($someColumnDefault, $aColumnIndex) {
+ $this->column[$aColumnIndex]->setDefaultValue($someColumnDefault);
+ else {
+ function removeColumnWithName($aColumnName){
+ $index = $this->getColumnIndex($aColumnName);
+ $this->removeColumnAtIndex($index);
+ function removeKeyWithName($aKeyName){
+ $index = $this->getKeyIndex($aKeyName);
+ $this->removeKeyAtIndex($index);
+ function removeKeyAtIndex ($aKeyIndex) {
+ if ($aKeyIndex < $this->key_cnt && $aKeyIndex >= 0) {
+ $this->key[$aKeyIndex]->destroyKey();
+ //if key is not only key and not last key
+ if ($this->key_cnt > 1 && $aKeyIndex != $this->key_cnt-1) {
+ //fill gap in key array with last entry
+ $this->key[$aKeyIndex] = $this->key[$this->key_cnt-1];
+ $this->key[$this->key_cnt-1] = null;
+ $this->key_cnt--;
+ else {
+ echo "Key '" . $aKeyIndex . "' not in database!<br>";
+ function removeConstraintWithName($aConstraintName){
+ $index = $this->getConstraintIndex($aConstraintName);
+ $this->removeConstraintAtIndex($index);
+ function removeConstraintAtIndex ($aConstraintIndex) {
+ if ($aConstraintIndex < $this->constraint_cnt && $aConstraintIndex >= 0) {
+ $this->constraint[$aConstraintIndex]->destroyConstraint();
+ //if constraint is not only constraint and not last constraint
+ if ($this->constraint_cnt > 1 && $aConstraintIndex != $this->constraint_cnt-1) {
+ //fill gap in constraint array with last entry
+ $this->constraint[$aConstraintIndex] = $this->constraint[$this->constraint_cnt-1];
+ $this->constraint[$this->constraint_cnt-1] = null;
+ $this->constraint_cnt--;
+ else {
+ echo "Constraint '" . $aConstraintIndex . "' not in database!<br>";
+ function removeColumnAtIndex ($aColumnIndex) {
+ if ($aColumnIndex < $this->column_cnt && $aColumnIndex >= 0) {
+ $this->column[$aColumnIndex]->destroyColumn();
+ //if column is not only column and not last column
+ if ($this->column_cnt > 1 && $aColumnIndex != $this->column_cnt-1) {
+ //fill gap in column array with last entry
+ $this->column[$aColumnIndex] = $this->column[$this->column_cnt-1];
+ $this->column[$this->column_cnt-1] = null;
+ $this->column_cnt--;
+ else {
+ echo "Column '" . $aColumnIndex . "' not in database!<br>";
Added: trunk/mapbender/http/classes/class_database_table_column.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/class_database_table_column.php?view=auto&rev=13
--- (empty file)
+++ trunk/mapbender/http/classes/class_database_table_column.php 2006-04-13 19:38:28+0000
@@ -0,0 +1,72 @@
+<?php
+# $Id: class_database_table_column.php,v 1.4 2005/09/13 16:23:31 c_baudson Exp $
+# $Header: /cvsroot/mapbender/mapbender/http/classes/class_database_table_column.php,v 1.4 2005/09/13 16:23:31 c_baudson Exp $
+class database_table_column{
+ var $name;
+ var $type;
+ var $defaultValue;
+ var $attributes;
+ function database_table_column($aName) {
+ function getName() {
+ function getDefaultValue() {
+ return $this->defaultValue;
+ function getAttributes() {
+ return $this->attributes;
+ $sql = "";
+ $sql .= " " . $this->getName() . " " . $this->getType() . " " . $this->getAttributes();
+ $sql .= "\n\n";
+ return $sql;
+ function setType ($aType) {
+ function setAttributes ($someAttributes) {
+ $this->attributes = $someAttributes;
+ function setDefaultValue ($someAttributes) {
+ $this->defaultValue = $someAttributes;
+ function destroyColumn () {
Added: trunk/mapbender/http/classes/class_database_table_constraint.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/class_database_table_constraint.php?view=auto&rev=13
--- (empty file)
+++ trunk/mapbender/http/classes/class_database_table_constraint.php 2006-04-13 19:38:28+0000
@@ -0,0 +1,103 @@
+<?php
+# $Id: class_database_table_constraint.php,v 1.4 2005/09/13 16:23:31 c_baudson Exp $
+# $Header: /cvsroot/mapbender/mapbender/http/classes/class_database_table_constraint.php,v 1.4 2005/09/13 16:23:31 c_baudson Exp $
+// TODO
+// this version implements foreign key constraints only!
+class database_table_constraint{
+ var $conSymbol;
+ var $conColumn;
+ var $conTableName;
+ var $conTableColumnName;
+ var $conOnDelete;
+ var $conOnUpdate;
+ function database_table_constraint($conSymbol, $conColumn, $conTableName, $conTableColumnName, $conOnDelete, $conOnUpdate) {
+ #$this->conSymbol = $conSymbol;
+ $this->conSymbol = "";
+ $this->conColumn = trim($conColumn);
+ $this->conTableName = trim($conTableName);
+ $this->conTableColumnName = trim($conTableColumnName);
+ $this->conOnDelete = trim($conOnDelete);
+ $this->conOnUpdate = trim($conOnUpdate);
+ function getConstraint() {
+ return array(conSymbol => $this->conSymbol, conColumn => $this->conColumn, conTableName => $this->conTableName, conTableColumnName => $this->conTableColumnName, conOnDelete => $this->conOnDelete, conOnUpdate => $this->conOnUpdate);
+ return $this->conSymbol;
+ function getColumn() {
+ return $this->conColumn;
+ function getTableName() {
+ return $this->conTableName;
+ function getTableColumnName() {
+ return $this->conTableColumnName;
+ function getOnDelete() {
+ return $this->conOnDelete;
+ function getOnUpdate() {
+ return $this->conOnUpdate;
+ $sql = "";
+ $sql .= " CONSTRAINT";
+ if ($this->getName()) {
+ $sql .= " " . $this->getName();
+ $sql .= " FOREIGN KEY";
+ $sql .= " (" . $this->getColumn() . ")";
+ $sql .= " REFERENCES";
+ $sql .= " " . $this->getTableName() . " (" . $this->getTableColumnName() . ")";
+ if ($this->getOnDelete()) {
+ $sql .= " ON DELETE " . $this->getOnDelete();
+ if ($this->getOnUpdate()) {
+ $sql .= " ON UPDATE " . $this->getOnUpdate();
+ $sql .= "\n\n";
+ return $sql;
+ function destroyConstraint () {
Added: trunk/mapbender/http/classes/class_database_table_key.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/class_database_table_key.php?view=auto&rev=13
--- (empty file)
+++ trunk/mapbender/http/classes/class_database_table_key.php 2006-04-13 19:38:28+0000
@@ -0,0 +1,69 @@
+<?php
+# $Id: class_database_table_key.php,v 1.4 2005/09/13 16:23:31 c_baudson Exp $
+# $Header: /cvsroot/mapbender/mapbender/http/classes/class_database_table_key.php,v 1.4 2005/09/13 16:23:31 c_baudson Exp $
+class database_table_key{
+ var $keyName;
+ var $columnName;
+ var $isPrimary = false;
+ function database_table_key($aKeyName, $aColumnName, $isPrimary) {
+ $this->keyName = $aKeyName;
+ $this->columnName = $aColumnName;
+ $this->isPrimary = $isPrimary;
+ function getKey() {
+ return $this->keyName . "," . $this->columnName . "," . $this->isPrimary;
+ function isPrimary() {
+ return $this->isPrimary;
+ function getColumnName() {
+ return $this->columnName;
+ function getKeyName() {
+ return $this->keyName;
+ $sql = "";
+ if ($this->isPrimary()) {
+ $sql .= " PRIMARY";
+ $sql .= " KEY";
+ if ($this->getKeyName()) {
+ $sql .= " " . $this->getKeyName();
+ $sql .= " (" . $this->getColumnName() . ")";
+ $sql .= "\n\n";
+ return $sql;
+ function destroyKey () {
Added: trunk/mapbender/http/classes/class_exception.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/class_exception.php?view=auto&rev=13
--- (empty file)
+++ trunk/mapbender/http/classes/class_exception.php 2006-04-13 19:38:28+0000
@@ -0,0 +1,45 @@
+<?php
+# $Id: class_exception.php,v 1.8 2005/09/13 16:23:31 c_baudson Exp $
+# $Header: /cvsroot/mapbender/mapbender/http/classes/class_exception.php,v 1.8 2005/09/13 16:23:31 c_baudson Exp $
+* class exception
+class exception{
+ var $dir = "../../log/";
+ function exception($n){
+ if(is_dir($this->dir)){
+ $logfile = $this->dir . "mb_" . date("Y_m_d") . ".log";
+ $logfile = $this->dir . "mb_error_" . date("Y_m_d") . ".log";
+ if(!$h = @fopen($logfile,"a")){
+ else{
+ $content = date("Y.m.d") . "," . date("H:i:s") . "," . $n .chr(13).chr(10);
+ if(!fwrite($h,$content)){
+ #exit;
+ fclose($h);
Added: trunk/mapbender/http/classes/class_geomObj.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/class_geomObj.php?view=auto&rev=13
--- (empty file)
+++ trunk/mapbender/http/classes/class_geomObj.php 2006-04-13 19:38:28+0000
@@ -0,0 +1,86 @@
+<?php
+# $Id: map.php,v 1.13 2005/09/13 14:08:41 uli_rothstein Exp $
+# $Header: /cvsroot/mapbender/mapbender/http/javascripts/map.php,v 1.13 2005/09/13 14:08:41 uli_rothstein Exp $
+class _geomObj {
+ var $realx = array();
+ var $realy = array();
+# var $pixx = array();
+# var $pixy = array();
+ var $label;
+ function _geomObj() {
+ function getLabel() {
+ return $this->label;
+ function setLabel($label) {
+ $this->label = $label;
+ function addCoordinates ($coord) {
+ $this->realx[count($this->realx)] = $coord[0];
+ $this->realy[count($this->realy)] = $coord[1];
+# function addCoordinates ($coord, $pos) {
+# $this->pixx[count($this->pixx)] = $pos[0];
+# $this->pixy[count($this->pixy)] = $pos[1];
+# $this->realx[count($this->realx)] = $coord[0];
+# $this->realy[count($this->realy)] = $coord[1];
+# function getCoordinates() {
+# $data = array("x" => $this->pixx, "y" => $this->pixy);
+# return $data;
+ function getCoordinates() {
+ $data = array("x" => $this->realx, "y" => $this->realy);
+ return $data;
+class _polygon extends _geomObj{
+ return "polygon";
+class _point extends _geomObj{
+ return "point";
+class _line extends _geomObj{
+ return "line";
\ No newline at end of file
Added: trunk/mapbender/http/classes/class_log.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/class_log.php?view=auto&rev=13
--- (empty file)
+++ trunk/mapbender/http/classes/class_log.php 2006-04-13 19:38:28+0000
@@ -0,0 +1,104 @@
+<?php
+# $Id: class_log.php,v 1.7 2006/01/13 13:59:30 astrid_emde Exp $
+# $Header: /cvsroot/mapbender/mapbender/http/classes/class_log.php,v 1.7 2006/01/13 13:59:30 astrid_emde Exp $
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify # it under the terms of the GNU General Public License as published by # the Free Software Foundation; either version 2, or (at your option) # any later version.
+# This program is distributed in the hope that it will be useful, # but WITHOUT ANY WARRANTY; without even the implied warranty of # MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the # GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License # along with this program; if not, write to the Free Software # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+* class exception
+* [15/Jul/2004: 10:00:08 +0200] 192.168.2.102 urldecode(username) userid
+*modul "GET /map/http/ HTTP/1.1"
+class log{
+ var $log_username = true;
+ var $url = array();
+ * {'file' || 'db'}
+ var $logtype = 'db';
+ function log($module,$req,$time_client){
+ $this->url = $req;
+ if($this->logtype == "file"){
+ $logfile = $this->dir . "mb_access_" . date("Y_m_d") . ".log";
+ #exit;
+ else{
+ for($i = 0; $i < count($this->url); $i++){
+ $content = strtotime("now")." ";
+ $content .= "[".date("d/M/Y:H:i:s O")."]";
+ $content .= " " . $_SESSION["mb_user_ip"];
+ $content .= ' "';
+ if($this->log_username == true){
+ $content .= $_SESSION["mb_user_name"];
+ $content .= '"';
+ $content .= " " . $_SESSION["mb_user_id"];
+ $content .= " " . $module;
+ $content .= ' "' . $this->url[$i] . '"';
+ $content .= chr(13).chr(10);
+ #exit;
+ fclose($h);
+ else if($this->logtype == 'db'){
+ include_once("../../conf/mapbender.conf");
+ $con = db_connect(DBSERVER,OWNER,PW);
+ $sql = "INSERT INTO mb_log(";
+ $sql .= "time_client,";
+ $sql .= "time_server,";
+ $sql .= "time_readable,";
+ $sql .= "mb_session,";
+ $sql .= "gui,";
+ $sql .= "module,";
+ $sql .= "ip,";
+ $sql .= "username,";
+ $sql .= "userid,";
+ $sql .= "request";
+ $sql .= ") VALUES (";
+ $sql .= "'".$time_client."',";
+ $sql .= "'".strtotime("now")."',";
+ $sql .= "'[".date("d/M/Y:H:i:s O")."]',";
+ $sql .= "'".SID."',";
+ $sql .= "'".$_SESSION["mb_user_gui"]."',";
+ $sql .= "'".$module."',";
+ $sql .= "'".$_SESSION["mb_user_ip"]."',";
+ $sql .= "'".$_SESSION["mb_user_name"]."',";
+ $sql .= "'".$_SESSION["mb_user_id"]."',";
+ $sql .= "'".$this->url[$i]."'";
+ $sql .= ")";
+ $res = db_query($sql)or die(db_error());
+ if(!$res){
+ include_once("class_mb_exception.php");
+ $e = new mb_exception("class_log: Writing table mb_log failed.");
Added: trunk/mapbender/http/classes/class_weldLegend2PNG.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/class_weldLegend2PNG.php?view=auto&rev=13
--- (empty file)
+++ trunk/mapbender/http/classes/class_weldLegend2PNG.php 2006-04-13 19:38:28+0000
@@ -0,0 +1,78 @@
+<?php
+# $Id: class_weldLegend2PNG.php,v 1.4 2005/09/13 16:23:31 c_baudson Exp $
+# $Header: /cvsroot/mapbender/mapbender/http/classes/class_weldLegend2PNG.php,v 1.4 2005/09/13 16:23:31 c_baudson Exp $
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+* class_weldMaps2PNG
+* @version 1.0.0
+* get/post '___' separated maprequests
+require_once("class_stripRequest.php");
+require_once("class_mb_exception.php");
+class weldMaps2PNG{
+ function weldMaps2PNG($urls,$filename){
+ if(!$urls || $urls == ""){
+ $e = new mb_exception("weldMaps2PNG: no maprequests delivered");
+ $url = explode("___", $urls);
+ $obj1 = new stripRequest($url[0]);
+ $width = $obj1->get("width");
+ $height = $obj1->get("height");
+ $image = imagecreatetruecolor($width, $height);
+ $white = ImageColorAllocate($image,255,255,255);
+ ImageFilledRectangle($image,0,0,$width,$height,$white);
+ for($i=0; $i<count($url); $i++){
+ $obj = new stripRequest($url[$i]);
+ #$url[$i] = $obj->setPNG();
+ $url[$i] = $obj->encodeGET();
+ $img = $this->loadpng($url[$i]);
+ if($img != false){
+ imagecopy($image, $img, 0, 0, 0, 0, $width, $height);
+ else{
+ $e = new mb_exception("weldMaps2PNG: unable to copy image: " . $url[$i]);
+ imagepng($image,$filename);
+ function loadpng ($imgurl) {
+ $obj = new stripRequest($imgurl);
+ $f = $obj->get("format");
+ if(strtolower($f) == 'image/png' || strtolower($f) == 'png'){
+ $im = @ImageCreateFromPNG($imgurl);
+ if(strtolower($f) == 'image/jpeg' || strtolower($f) == 'jpeg'){
+ $im = @ImageCreateFromJPEG($imgurl);
+ if(strtolower($f) == 'image/gif' || strtolower($f) == 'gif'){
+ $im = @ImageCreateFromGIF($imgurl);
+ if(!$im){
+ $im = false;
+ $e = new mb_exception("weldMaps2PNG: unable to load image: ".$imgurl);
+ return $im;
Added: trunk/mapbender/http/classes/class_weldMaps2PNG.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/class_weldMaps2PNG.php?view=auto&rev=13
--- (empty file)
+++ trunk/mapbender/http/classes/class_weldMaps2PNG.php 2006-04-13 19:38:28+0000
@@ -0,0 +1,80 @@
+<?php
+# $Id: class_weldMaps2PNG.php,v 1.9 2005/11/07 16:52:05 uli_rothstein Exp $
+# $Header: /cvsroot/mapbender/mapbender/http/classes/class_weldMaps2PNG.php,v 1.9 2005/11/07 16:52:05 uli_rothstein Exp $
+* @version 1.0.0
+require_once("class_connector.php");
+include_once("../../conf/mapbender.conf");
+ $image = imagecreatetruecolor($width, $height );
+ $url[$i] = $obj->setPNG();
+ else{
+ $e = new mb_exception("weldMaps2PNG: unable to load image: " . $url[$i]);
+ $x = new connector($imgurl);
+ $im = @imagecreatefromstring($x->file);
+ if(!$im){
+ $im = false;
+ return $im;
Added: trunk/mapbender/http/classes/class_weldOverview2PNG.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/class_weldOverview2PNG.php?view=auto&rev=13
--- (empty file)
+++ trunk/mapbender/http/classes/class_weldOverview2PNG.php 2006-04-13 19:38:28+0000
@@ -0,0 +1,153 @@
+<?php
+# $Id: class_weldOverview2PNG.php,v 1.3 2006/02/22 11:56:22 astrid_emde Exp $
+# $Header: /cvsroot/mapbender/mapbender/http/classes/class_weldOverview2PNG.php,v 1.3 2006/02/22 11:56:22 astrid_emde Exp $
+* class_weldOverview2PNG
+* @version 1.0.0
+class weldOverview2PNG{
+ function weldOverview2PNG($url_overview,$url_extent,$filename){
+ if(!$url_overview || $url_overview == ""){
+ $e = new mb_exception("weldOverview2PNG: no maprequests delivered");
+ $url = $url_overview;
+ $obj1 = new stripRequest($url);
+ $e = new mb_exception("--------overview-----------------");
+ $e = new mb_exception("-----width ".$width." / height: ".$height."--------------------");
+ $e = new mb_exception("url_overview: ".$url_overview);
+ $e = new mb_exception("url_extent: ".$url_extent);
+ $white = ImageColorAllocate($image,255,255, 255);
+ //overview
+ $obj = new stripRequest($url_overview);
+ $xurl_overview = $obj->setPNG();
+ $xurl_overview = $obj->encodeGET();
+ $img = $this->loadpng($xurl_overview);
+ else{
+ $e = new mb_exception("weldMaps2PNG: unable to load image: " . $url_overview);
+ // rectangle - position of the map in the overview
+ $objx = new stripRequest($url_extent);
+ $ex_width = $objx->get("width");
+ $ex_height = $objx->get("height");
+ $extent = explode(",",$objx->get("BBOX"));
+ $lowerleft = $this->makeRealWorld2mapPos($url_overview, round($extent[0]), round($extent[1]));
+ $upperright = $this->makeRealWorld2mapPos($url_overview, $extent[2], $extent[3]);
+ $e = new mb_exception("ex_width: " .$ex_width);
+ $e = new mb_exception("ex_height: " . $ex_height);
+ $e = new mb_exception("bbox:".$extent[0]."--".$extent[1]."--".$extent[2]."--------".$extent[3]);
+ $e = new mb_exception("ll: " . $lowerleft[0]." / ".$lowerleft[1]);
+ $e = new mb_exception("ur: " . $upperright[0]." / ".$upperright[1]);
+ $lowerleft[0] = round($lowerleft[0]);
+ $lowerleft[1] = round($lowerleft[1]);
+ $upperright[0] = round($upperright[0]);
+ $upperright[1] = round($upperright[1]);
+ $red = ImageColorAllocate($image,255,0,0);
+ imageline ( $image, $lowerleft[0], $upperright[1], $upperright[0], $upperright[1], $red);
+ imageline ( $image, $upperright[0], $upperright[1], $upperright[0], $lowerleft[1], $red);
+ imageline ( $image, $upperright[0], $lowerleft[1], $lowerleft[0], $lowerleft[1], $red);
+ imageline ( $image, $lowerleft[0], $lowerleft[1], $lowerleft[0], $upperright[1], $red);
+ // black frame - size of the overview
+ $black = ImageColorAllocate($image,0,0,0);
+ imageline ( $image, 0, 0, $width-1, 0, $black);
+ imageline ( $image, $width-1, 0, $width-1, $height-1, $black);
+ imageline ( $image, $width-1, $height-1, 0, $height-1, $black);
+ imageline ( $image, 0, $height-1, 0, 0, $black);
+ #ereg_replace(' ', "\%90", $imgurl);
+ if(!$im){
+ $im = false;
+ $e = new mb_exception("weldOverview2PNG: unable to load image: ".$imgurl);
+ return $im;
+ function makeRealWorld2mapPos($url, $rw_posx, $rw_posy){
+ $obj = new stripRequest($url);
+ $width = $obj->get("width");
+ $height = $obj->get("height");
+ #$e = new mb_exception("weld_url: ".$url);
+ #$e = new mb_exception("w: ".$width."height".$height);
+ $arrayBBox = explode(",",$obj->get("BBOX"));
+ $minX = $arrayBBox[0];
+ $minY = $arrayBBox[1];
+ $maxX = $arrayBBox[2];
+ $maxY = $arrayBBox[3];
+ #$e = new mb_exception("------- minx: ".$minX." miny:".$minY." maxx:".$maxX." maxy:".$maxY."----------");
+ $xtentx = $maxX - $minX ;
+ $xtenty = $maxY - $minY ;
+ $pixPos_x = (($rw_posx - $minX)/$xtentx)*$width;
+ $pixPos_y = (($maxY - $rw_posy)/$xtenty)*$height;
+ $pixPos = array($pixPos_x, $pixPos_y);
+ return $pixPos;
Added: trunk/mapbender/http/classes/class_wmc.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/class_wmc.php?view=auto&rev=13
--- (empty file)
+++ trunk/mapbender/http/classes/class_wmc.php 2006-04-13 19:38:28+0000
@@ -0,0 +1,1000 @@
+<?php
+# $Id: class_wmc.php,v 1.31 2006/03/16 14:49:30 c_baudson Exp $
+# $Header: /cvsroot/mapbender/mapbender/http/classes/class_wmc.php,v 1.31 2006/03/16 14:49:30 c_baudson Exp $
+require_once("../../conf/mapbender.conf");
+require_once("../classes/class_wms.php");
+class wmc {
+ var $wmc_id;
+ var $wmc_version;
+ var $wmc_windowWidth;
+ var $wmc_windowHeight;
+ var $wmc_bBox_SRS;
+ var $wmc_bBox_minx;
+ var $wmc_bBox_maxx;
+ var $wmc_bBox_miny;
+ var $wmc_bBox_maxy;
+ var $wmc_name;
+ var $wmc_title;
+ var $wmc_abstract;
+ var $wmc_logourl;
+ var $wmc_logourl_format;
+ var $wmc_logourl_type;
+ var $wmc_logourl_width;
+ var $wmc_logourl_height;
+ var $wmc_descriptionurl;
+ var $wmc_descriptionurl_format;
+ var $wmc_descriptionurl_type;
+ var $wmc_keyword = array();
+ var $wmc_contactposition;
+ var $wmc_contactvoicetelephone;
+ var $wmc_contactemail;
+ var $wmc_contactfacsimiletelephone;
+ var $wmc_contactperson;
+ var $wmc_contactorganization;
+ var $wmc_contactaddresstype;
+ var $wmc_contactaddress;
+ var $wmc_contactcity;
+ var $wmc_contactstateorprovince;
+ var $wmc_contactpostcode;
+ var $wmc_contactcountry;
+ var $wmc_wms_title = array();
+ var $wmc_layer_queryable = array();
+ var $wmc_layer_hidden = array();
+ var $wmc_wms_service = array();
+ var $wmc_wms_version = array();
+ var $wmc_layer_title = array();
+ var $wmc_layer_name = array();
+ var $wmc_layer_abstract = array();
+ var $wmc_layer_srs = array();
+ var $wmc_wms_serviceURL = array();
+ var $wmc_layer_format_current = array();
+ var $wmc_layer_dataurl = array();
+ var $wmc_layer_metadataurl = array();
+ var $wmc_layer_format = array();
+ var $wmc_layer_style_current = array();
+ var $wmc_layer_style_name = array();
+ var $wmc_layer_style_title = array();
+ var $wmc_layer_style_legendurl = array();
+ var $wmc_layer_style_legendurl_width = array();
+ var $wmc_layer_style_legendurl_height = array();
+ var $wmc_layer_style_legendurl_format = array();
+ var $wmc_layer_style_legendurl_type = array();
+ var $wmc_layer_style_sld_url = array();
+ var $wmc_layer_style_sld_type = array();
+ var $wmc_layer_style_sld_title = array();
+ var $wmc_wms_count = 0;
+ var $data_type = array();
+ var $data_format = array();
+ var $objLayer = array();
+ var $gui_wms_mapformat;
+ var $gui_wms_featureinfoformat;
+ var $gui_wms_exceptionformat;
+ var $gui_wms_epsg;
+ var $default_epsg = 0;
+ function wmc() {
+function getTitle() {
+ return $this->wmc_title;
+function getNumberOfWms () {
+ return $this->wmc_wms_count;
+function createObjFromWMC($wmc_id){
+ global $DBSERVER,$DB,$OWNER,$PW;
+ $con = db_connect($DBSERVER,$OWNER,$PW);
+ db_select_db(DB, $con);
+ $sql = "SELECT wmc FROM mb_user_wmc WHERE wmc_id = '" . $wmc_id . "'";
+ $res = db_query($sql);
+ $wmc = db_fetch_row($res);
+ $verbose = "<pre>" . htmlentities($wmc[0]) . "</pre>";
+// $data = str_replace("&", "&", $wmc[0]);
+ $data = str_replace("&", "&", $wmc[0]);
+ $parser = xml_parser_create(CHARSET);
+ xml_parser_set_option($parser,XML_OPTION_CASE_FOLDING,0);
+ xml_parser_set_option($parser,XML_OPTION_SKIP_WHITE,1);
+ xml_parser_set_option($parser,XML_OPTION_TARGET_ENCODING,CHARSET);
+ xml_parse_into_struct($parser,$data,$values,$tags);
+ $code = xml_get_error_code ($parser);
+ if ($code) {
+ echo "<br><br>Error " . $code . " (" . xml_error_string($code) . ")<br><br>";
+ xml_parser_free($parser);
+ /* echo "Index array\n";
+ * print_r($tags);
+ * echo "\nVals array\n";
+ * print_r($values);
+ $section;
+ $format;
+ $cnt_format = 0;
+ $parent = array();
+ $myParent = array();
+ $cnt_layer = -1;
+ $request;
+ $layer_style = array();
+ $cnt_styles = -1;
+ $general = false;
+ $layerlist = false;
+ $layer = false;
+ foreach ($values as $element) {
+ $verbose .= ".";
+ if(strtoupper($element[tag]) == "VIEWCONTEXT" && $element[type] == "open"){
+ $this->wmc_id = $element[attributes]["id"];
+ $this->wmc_version = $element[attributes]["version"];
+ $verbose .= "Viewcontext begin<br>\n";
+ $verbose .= $this->wmc_id . "<br>\n";
+ $verbose .= $this->wmc_version . "<br>\n";
+ if(strtoupper($element[tag]) == "VIEWCONTEXT" && $element[type] == "close"){
+ $verbose .= "Viewcontext end<br>\n";
+ if(strtoupper($element[tag]) == "GENERAL" && $element[type] == "open"){
+ $general = true;
+ $verbose .= "General begin<br>\n";
+ if(strtoupper($element[tag]) == "LAYERLIST" && $element[type] == "open"){
+ $layerlist = true;
+ $verbose .= "LayerList begin<br>\n";
+ if ($general) {
+ if(strtoupper($element[tag]) == "WINDOW"){
+ $this->wmc_windowWidth = $element[attributes]["width"];
+ $this->wmc_windowHeight = $element[attributes]["height"];
+ $verbose .= $this->wmc_windowHeight . "<br>\n";
+ $verbose .= $this->wmc_windowWidth . "<br>\n";
+ if(strtoupper($element[tag]) == "BOUNDINGBOX"){
+ $this->wmc_bBox_SRS = $element[attributes]["SRS"];
+ $verbose .= $this->wmc_bBox_SRS . "<br>\n";
+ $this->wmc_bBox_minx = $element[attributes]["minx"];
+ $verbose .= $this->wmc_bBox_minx . "<br>\n";
+ $this->wmc_bBox_miny = $element[attributes]["miny"];
+ $verbose .= $this->wmc_bBox_miny . "<br>\n";
+ $this->wmc_bBox_maxx = $element[attributes]["maxx"];
+ $verbose .= $this->wmc_bBox_maxx . "<br>\n";
+ $this->wmc_bBox_maxy = $element[attributes]["maxy"];
+ $verbose .= $this->wmc_bBox_maxy . "<br>\n";
+ if(strtoupper($element[tag]) == "NAME"){
+ $this->wmc_name = $this->char_encode($element[value]);
+ $verbose .= $this->wmc_name . "<br>\n";
+ if(strtoupper($element[tag]) == "TITLE"){
+ $this->wmc_title = $this->char_encode($element[value]);
+ $verbose .= $this->wmc_title . "<br>\n";
+ if(strtoupper($element[tag]) == "ABSTRACT"){
+ $this->wmc_abstract = $this->char_encode($element[value]);
+ $verbose .= $this->wmc_abstract . "<br>\n";
+ if(strtoupper($element[tag]) == "CONTACTINFORMATION" && $element['type'] == "open"){
+ $contactinformation = true;
+ $verbose .= "Contactinformation begin<br>\n";
+ if ($contactinformation) {
+ if(strtoupper($element[tag]) == "CONTACTPOSITION"){
+ $this->wmc_contactposition = $this->char_encode($element[value]);
+ $verbose .= $this->wmc_contactposition . "<br>\n";
+ if(strtoupper($element[tag]) == "CONTACTVOICETELEPHONE"){
+ $this->wmc_contactvoicetelephone = $this->char_encode($element[value]);
+ $verbose .= $this->wmc_contactvoicetelephone . "<br>\n";
+ if(strtoupper($element[tag]) == "CONTACTFACSIMILETELEPHONE"){
+ $this->wmc_contactfacsimiletelephone = $this->char_encode($element[value]);
+ $verbose .= $this->wmc_contactfacsimiletelephone . "<br>\n";
+ if(strtoupper($element[tag]) == "CONTACTELECTRONICMAILADDRESS"){
+ $this->wmc_contactemail = $this->char_encode($element[value]);
+ $verbose .= $this->wmc_contactemail . "<br>\n";
+ if(strtoupper($element[tag]) == "CONTACTPERSONPRIMARY" && $element['type'] == "open"){
+ $contactpersonprimary = true;
+ $verbose .= "Contactpersonprimary begin<br>\n";
+ if ($contactpersonprimary) {
+ if(strtoupper($element[tag]) == "CONTACTPERSON"){
+ $this->wmc_contactperson = $this->char_encode($element[value]);
+ $verbose .= $this->wmc_contactperson . "<br>\n";
+ if(strtoupper($element[tag]) == "CONTACTORGANIZATION"){
+ $this->wmc_contactorganization = $this->char_encode($element[value]);
+ $verbose .= $this->wmc_contactorganization . "<br>\n";
+ if(strtoupper($element[tag]) == "CONTACTPERSONPRIMARY" && $element['type'] == "close"){
+ $contactpersonprimary = false;
+ $verbose .= "Contactpersonprimary end<br>\n";
+ if(strtoupper($element[tag]) == "CONTACTADDRESS" && $element['type'] == "open"){
+ $contactaddress = true;
+ $verbose .= "Contactaddress begin<br>\n";
+ if ($contactaddress) {
+ if(strtoupper($element[tag]) == "ADDRESSTYPE"){
+ $this->wmc_contactaddresstype = $this->char_encode($element[value]);
+ $verbose .= $this->wmc_contactaddresstype . "<br>\n";
+ if(strtoupper($element[tag]) == "ADDRESS"){
+ $this->wmc_contactaddress = $this->char_encode($element[value]);
+ $verbose .= $this->wmc_contactaddress . "<br>\n";
+ if(strtoupper($element[tag]) == "CITY"){
+ $this->wmc_contactcity = $this->char_encode($element[value]);
+ $verbose .= $this->wmc_contactcity . "<br>\n";
+ if(strtoupper($element[tag]) == "STATEORPROVINCE"){
+ $this->wmc_contactstateorprovince = $this->char_encode($element[value]);
+ $verbose .= $this->wmc_contactstateorprovince . "<br>\n";
+ if(strtoupper($element[tag]) == "POSTCODE"){
+ $this->wmc_contactpostcode = $element[value];
+ $verbose .= $this->wmc_contactpostcode . "<br>\n";
+ if(strtoupper($element[tag]) == "COUNTRY"){
+ $this->wmc_contactcountry = $this->char_encode($element[value]);
+ $verbose .= $this->wmc_contactcountry . "<br>\n";
+ if(strtoupper($element[tag]) == "CONTACTADDRESS" && $element['type'] == "close"){
+ $contactaddress = false;
+ $verbose .= "Contactaddress end<br>\n";
+ if(strtoupper($element[tag]) == "LOGOURL" && $element['type'] == "open"){
+ $logourl = true;
+ $verbose .= "Logourl begin<br>\n";
+ $this->wmc_logourl_width = $element[attributes]["width"];
+ $verbose .= $this->wmc_logourl_width . "<br>\n";
+ $this->wmc_logourl_height = $element[attributes]["height"];
+ $verbose .= $this->wmc_logourl_height ."<br>\n";
+ $this->wmc_logourl_format = $element[attributes]["format"];
+ $verbose .= $this->wmc_logourl_format . "<br>\n";
+ if ($logourl) {
+ if(strtoupper($element[tag]) == "LOGOURL" && $element['type'] == "close"){
+ $logourl = false;
+ $verbose .= "Logourl end<br>\n";
+ if(strtoupper($element[tag]) == "ONLINERESOURCE"){
+ $this->wmc_logourl_type = $element[attributes]["xlink:type"];
+ $verbose .= $this->wmc_logourl_type . "<br>\n";
+ $this->wmc_logourl = $element[attributes]["xlink:href"];
+ $verbose .= $this->wmc_logourl . "<br>\n";
+ if(strtoupper($element[tag]) == "DESCRIPTIONURL" && $element['type'] == "open"){
+ $descriptionurl = true;
+ $verbose .= "Descriptionurl begin<br>\n";
+ $this->wmc_descriptionurl_format = $element[attributes]["format"];
+ $verbose .= $this->wmc_descriptionurl_format . "<br>\n";
+ if ($descriptionurl) {
+ if(strtoupper($element[tag]) == "DESCRIPTIONURL" && $element['type'] == "close"){
+ $descriptionurl = false;
+ $verbose .= "Descriptionurl end<br>\n";
+ $this->wmc_descriptionurl_type = $element[attributes]["xlink:type"];
+ $verbose .= $this->wmc_descriptionurl_type . "<br>\n";
+ $this->wmc_descriptionurl = $element[attributes]["xlink:href"];
+ $verbose .= $this->wmc_descriptionurl . "<br>\n";
+ if(strtoupper($element[tag]) == "KEYWORDLIST" && $element['type'] == "open"){
+ $keywordlist = true;
+ $verbose .= "Keywordlist begin<br>\n";
+ if ($keywordlist) {
+ if(strtoupper($element[tag]) == "KEYWORDLIST" && $element['type'] == "close"){
+ $keywordlist = false;
+ $cnt_keyword = -1;
+ $verbose .= "Keywordlist end<br>\n";
+ if(strtoupper($element[tag]) == "KEYWORD"){
+ $cnt_keyword++;
+ $this->wmc_keyword[$cnt_keyword] = $this->char_encode($element[value]);
+ $verbose .= $this->wmc_keyword[$cnt_keyword] . "<br>\n";
+ if(strtoupper($element[tag]) == "GENERAL" && $element['type'] == "close"){
+ $general = false;
+ $verbose .= "General end<br>\n";
+ if ($layerlist) {
+ if(strtoupper($element[tag]) == "LAYERLIST" && $element['type'] == "close"){
+ $verbose .= "LayerList end<br>\n";
+ if(strtoupper($element[tag]) == "LAYER" && $element[type] == "open"){
+ $cnt_layer++;
+ $this->wmc_layer_queryable[$cnt_layer] = $element[attributes]["queryable"];
+ $this->wmc_layer_hidden[$cnt_layer] = $element[attributes]["hidden"];
+ $layer = true;
+ $verbose .= "Layer begin<br>\n";
+ $verbose .= $this->wmc_layer_queryable[$cnt_layer] . "<br>\n";
+ $verbose .= $this->wmc_layer_hidden[$cnt_layer] . "<br>\n";
+ $cnt_epsg = 0;
+ if ($layer) {
+ if(strtoupper($element[tag]) == "LAYER" && $element[type] == "close"){
+ $layer = false;
+ $verbose .= "Layer end<br>\n";
+ if ($formatlist) {
+ if(strtoupper($element[tag]) == "FORMAT"){
+ $cnt_format++;
+ $this->wmc_layer_format_current[$cnt_layer][$cnt_format] = $element[attributes]["current"];
+ $verbose .= $this->wmc_layer_format_current[$cnt_layer][$cnt_format] . "<br>\n";
+ $this->wmc_layer_format[$cnt_layer][$cnt_format] = $element[value];
+ $verbose .= $this->wmc_layer_format[$cnt_layer][$cnt_format] . "<br>\n";
+ if(strtoupper($element[tag]) == "FORMATLIST" && $element[type] == "close"){
+ $verbose .= "Formatlist end<br>\n";
+ $formatlist = false;
+ elseif ($metadataurl) {
+ $this->wmc_layer_metadataurl[$cnt_layer] = $element[attributes]["xlink:href"];
+ $verbose .= $this->wmc_layer_metadataurl[$cnt_layer] . "<br>\n";
+ if(strtoupper($element[tag]) == "METADATAURL" && $element[type] == "close"){
+ $verbose .= "Metadataurl end<br>\n";
+ $metadataurl = false;
+ elseif ($dataurl) {
+ $this->wmc_layer_dataurl[$cnt_layer] = $element[attributes]["xlink:href"];
+ $verbose .= $this->wmc_layer_dataurl[$cnt_layer] . "<br>\n";
+ if(strtoupper($element[tag]) == "DATAURL" && $element[type] == "close"){
+ $verbose .= "Dataurl end<br>\n";
+ $dataurl = false;
+ elseif ($stylelist) {
+ if(strtoupper($element[tag]) == "STYLE" && $element[type] == "open"){
+ $cnt_style++;
+ $style = true;
+ $this->wmc_layer_style_current[$cnt_layer][$cnt_style] = $element[attributes]["current"];
+ $verbose .= "Style begin<br>\n";
+ $verbose .= $this->wmc_layer_style_current[$cnt_layer][$cnt_style] . "<br>\n";
+ if ($style) {
+ if(strtoupper($element[tag]) == "STYLE" && $element[type] == "close"){
+ $style = false;
+ $verbose .= "Style end<br>\n";
+ if(strtoupper($element[tag]) == "SLD" && $element[type] == "open"){
+ $sld = true;
+ $verbose .= "sld begin<br>\n";
+ if ($sld) {
+ if(strtoupper($element[tag]) == "SLD" && $element[type] == "close"){
+ $verbose .= "sld end<br>\n";
+ $sld = false;
+ $this->wmc_layer_style_sld_type[$cnt_layer][$cnt_style] = $element[attributes]["xlink:type"];
+ $verbose .= $this->wmc_layer_style_sld_type[$cnt_layer][$cnt_style] . "<br>\n";
+ $this->wmc_layer_style_sld_url[$cnt_layer][$cnt_style] = $element[attributes]["xlink:href"];
+ $verbose .= $this->wmc_layer_style_sld_url[$cnt_layer][$cnt_style] . "<br>\n";
+ $this->wmc_layer_style_sld_title[$cnt_layer][$cnt_style] = $this->char_encode($element[value]);
+ $verbose .= $this->wmc_layer_style_sld_title[$cnt_layer][$cnt_style] . "<br>\n";
+ else {
+ $this->wmc_layer_style_name[$cnt_layer][$cnt_style] = $this->char_encode($element[value]);
+ $verbose .= $this->wmc_layer_style_name[$cnt_layer][$cnt_style] . "<br>\n";
+ $this->wmc_layer_style_title[$cnt_layer][$cnt_style] = $this->char_encode($element[value]);
+ $verbose .= $this->wmc_layer_style_title[$cnt_layer][$cnt_style] . "<br>\n";
+ if(strtoupper($element[tag]) == "LEGENDURL" && $element[type] == "open"){
+ $verbose .= "legendurl begin<br>\n";
+ $legendurl = true;
+ $this->wmc_layer_style_legendurl_width[$cnt_layer][$cnt_style] = $element[attributes]["width"];
+ $verbose .= $this->wmc_layer_style_legendurl_width[$cnt_layer][$cnt_style] . "<br>\n";
+ $this->wmc_layer_style_legendurl_height[$cnt_layer][$cnt_style] = $element[attributes]["height"];
+ $verbose .= $this->wmc_layer_style_legendurl_height[$cnt_layer][$cnt_style] . "<br>\n";
+ $this->wmc_layer_style_legendurl_format[$cnt_layer][$cnt_style] = $element[attributes]["format"];
+ $verbose .= $this->wmc_layer_style_legendurl_format[$cnt_layer][$cnt_style] . "<br>\n";
+ if ($legendurl) {
+ if(strtoupper($element[tag]) == "LEGENDURL" && $element[type] == "close"){
+ $verbose .= "legendurl end<br>\n";
+ $legendurl = false;
+ $this->wmc_layer_style_legendurl_type[$cnt_layer][$cnt_style] = $element[attributes]["xlink:type"];
+ $verbose .= $this->wmc_layer_style_legendurl_type[$cnt_layer][$cnt_style] . "<br>\n";
+ $this->wmc_layer_style_legendurl[$cnt_layer][$cnt_style] = $element[attributes]["xlink:href"];
+ $verbose .= $this->wmc_layer_style_legendurl[$cnt_layer][$cnt_style] . "<br>\n";
+ if(strtoupper($element[tag]) == "STYLELIST" && $element[type] == "close"){
+ $stylelist = false;
+ $verbose .= "Stylelist end<br>\n";
+ else {
+ if(strtoupper($element[tag]) == "SERVER" && $element[type] == "open"){
+ $server = true;
+ $this->wmc_wms_service[$cnt_layer] = $element[attributes]["service"];
+ $this->wmc_wms_version[$cnt_layer] = $element[attributes]["version"];
+ $this->wmc_wms_title[$cnt_layer] = $this->char_encode($element[attributes]["title"]);
+ $verbose .= "Server begin<br>\n";
+ $verbose .= $this->wmc_wms_service[$cnt_layer] . "<br>\n";
+ $verbose .= $this->wmc_wms_version[$cnt_layer] . "<br>\n";
+ $verbose .= $this->wmc_layer_title[$cnt_layer] . "<br>\n";
+ if ($server) {
+ if(strtoupper($element[tag]) == "SERVER" && $element[type] == "close"){
+ $verbose .= "Server end<br>\n";
+ $server = false;
+ $this->wmc_wms_serviceURL[$cnt_layer] = $element[attributes]["xlink:href"];
+ $verbose .= $this->wmc_wms_serviceURL[$cnt_layer] . "<br>\n";
+ $this->wmc_layer_name[$cnt_layer] = $this->char_encode($element[value]);
+ $verbose .= $this->wmc_layer_name[$cnt_layer] . "<br>\n";
+ $this->wmc_layer_title[$cnt_layer] = $this->char_encode($element[value]);
+ $this->wmc_layer_abstract[$cnt_layer] = $this->char_encode($element[value]);
+ $verbose .= $this->wmc_layer_abstract[$cnt_layer] . "<br>\n";
+ if(strtoupper($element[tag]) == "SRS"){
+ $epsgArray = explode(" ", $element[value]);
+ for ($c = 0 ; $c < count($epsgArray) ; $c ++) {
+ $this->wmc_layer_srs[$cnt_layer][$cnt_epsg] = $epsgArray[$c];
+ $verbose .= $this->wmc_layer_srs[$cnt_layer][$cnt_epsg] . "<br>\n";
+ $cnt_epsg++;
+ if(strtoupper($element[tag]) == "METADATAURL" && $element[type] == "open"){
+ $verbose .= "Metadataurl begin<br>\n";
+ $metadataurl = true;
+ if(strtoupper($element[tag]) == "DATAURL" && $element[type] == "open"){
+ $verbose .= "Dataurl begin<br>\n";
+ $dataurl = true;
+ if(strtoupper($element[tag]) == "FORMATLIST" && $element[type] == "open"){
+ $verbose .= "Formatlist begin<br>\n";
+ $formatlist = true;
+ $cnt_format = -1;
+ if(strtoupper($element[tag]) == "STYLELIST" && $element[type] == "open"){
+ $verbose .= "Stylelist begin<br>\n";
+ $stylelist = true;
+ $cnt_style = -1;
+ //return $verbose;
+ function createJsObjFromWMC($target, $mapObj){
+ $wmc_string = "";
+ $new_wms = "";
+ $cnt_wms = -1;
+ //added_wms contains all the wms that have been added already.
+ $added_wms = array();
+ // for all layers do
+ for ($i = 0; $i < count($this->wmc_layer_title); $i++) {
+ //get wms of this layer
+ $current_wms = $this->wmc_wms_serviceURL[$i];
+ //BEGIN : check if wms has not been added before
+ if (!in_array($current_wms , $added_wms)) {
+ //gathers all the layers of the current wms (seperated by ,)
+ $layerlist = "";
+ //gathers all the querylayers of the current wms (seperated by ,)
+ $querylayerlist = "";
+ // BEGIN: add this wms as it has not been added before
+ $mywms = new wms();
+ if(!$this->wmc_layer_title[$i] || $this->wmc_layer_title[$i] == ""){
+ echo "alert('Error: no valid capabilities-document !!');";
+ die; exit;
+ // create temporary WMS id
+ $time = explode(" ", microtime(1));
+ $id = substr(md5(substr($time[0], 2)), 0, 5);
+ $this->wmc_wms_count ++;
+ $wmc_string .= $target . "add_wms('" .
+ $id ."','".
+ $this->wmc_wms_version[$i] ."','".
+ $this->wmc_wms_title[$i] ."','".
+ $this->wmc_layer_abstract[$i] ."','".
+ $this->wmc_wms_serviceURL[$i] ."','" .
+ $this->wmc_layer_style_legendurl[$i][0] ."','','".
+ $this->wmc_layer_format[$i][0] ."','text/html','application/vnd.ogc.se_xml','".
+ $this->wmc_layer_srs[$i][0] ."','1');\n";
+ // END: add this wms as it has not been added before
+ // add wms to added wms
+ $added_wms[count($added_wms)] = $current_wms;
+ $cnt_wms++;
+ $cnt_layers = 0;
+ $cnt_query_layers = 0;
+ // list of all added formats in this wms
+ //BEGIN : gather all layers of this wms
+ for ($ii = 0; $ii < count($this->wmc_layer_title); $ii++) {
+ //the wms of the current layer
+ $layer_wms = $this->wmc_wms_serviceURL[$ii];
+ // BEGIN: check if the layer belongs to the current wms
+ if ($current_wms == $layer_wms) {
+ // BEGIN: Add format to WMS
+ $z = count($this->wmc_layer_format[$ii]);
+ for($j=0;$j<$z;$j++){
+ $wmc_string .= $target . "wms_add_data_type_format('map','". $this->wmc_layer_format[$ii][$j] ."');\n";
+ // END: Add format to WMS
+ // BEGIN: BUILD AND ADD PARENT LAYER
+ if ($cnt_layers == 0) {
+ $wmc_string .= $target . "wms_add_layer('','','". $this->wmc_wms_title[$i] ."','','0','0','0','0','','".$id."','1','1','1','0','0','0','0');\n";
+ // END: BUILD AND ADD PARENT LAYER
+ // BEGIN: counting layers and queryable layers belonging to a certain wms
+ $cnt_layers++;
+ if ($this->wmc_layer_queryable[$ii]) {
+ $cnt_query_layers++;
+ //add layer to querylayerlist
+ if (!in_array($this->wmc_layer_name[$ii], explode(",", $querylayerlist))) {
+ if ($querylayerlist == "") {$querylayerlist = $this->wmc_layer_name[$ii];} else {$querylayerlist .= "," . $this->wmc_layer_name[$ii];}
+ // END: counting layers and queryable layers belonging to a certain wms
+ // BEGIN: Add layer to WMS (using $new_wms_id as index)
+ $wmc_string .= $target . "wms_add_layer('0','".
+ $this->wmc_layer_name[$ii] . "','".
+ $this->wmc_layer_title[$ii] ."','".
+ $this->wmc_layer_dataurl[$ii]
+ intval($cnt_layers) ."','".
+ $this->wmc_layer_queryable[$ii] ."','0','0','".
+ $this->wmc_layer_metadataurl[$ii]
+ $id ."','1','1','".
+ intval(!$this->wmc_layer_hidden[$ii]) ."','".
+ $this->wmc_layer_queryable[$ii] ."','".
+ $this->wmc_layer_queryable[$ii] ."','0','0');\n";
+ // END: Add layer to WMS (using $new_wms_id as index)
+ //add layer to layerlist if layer is visible
+ if (intval(!$this->wmc_layer_hidden[$ii]) && !in_array($this->wmc_layer_name[$ii], explode(",", $layerlist))) {
+ if ($layerlist == "") {$layerlist = $this->wmc_layer_name[$ii];} else {$layerlist .= "," . $this->wmc_layer_name[$ii];}
+ // BEGIN: Add epsg to layer
+ for($j=0; $j<count($this->wmc_layer_srs[$ii]);$j++){
+ $wmc_string .= $target . "wms_addSRS('".
+ $this->wmc_layer_srs[$ii][$j] ."','".
+ $this->wmc_bBox_minx ."','".
+ $this->wmc_bBox_miny ."','".
+ $this->wmc_bBox_maxx ."','".
+ $this->wmc_bBox_maxy ."','".
+ "');\n";
+ // END: Add epsg to layer
+ // BEGIN: Add style to layer
+ for($j=0; $j<count($this->wmc_layer_style_name[$ii]);$j++){
+ $wmc_string .= $target . "wms_addLayerStyle('".$this->wmc_layer_style_name[$ii][$j] ."','".$this->wmc_layer_style_title[$ii][$j] ."','".$j."','".$cnt_layers."', '" . $this->wmc_layer_style_legendurl[$ii][$j] . "', '" . $this->wmc_layer_style_legendurl_format[$ii][$j] . "');\n";
+ // END: Add style to layer
+ // END: check if the layer belongs to the current wms
+ //END : gather all layers of this wms
+ // add wms to mapObj with all layers and querylayers
+ $wmc_string .= $target;
+ $wmc_string .= "mb_mapObjaddWMSwithLayers('" . $mapObj . "', '" . $layerlist . "', '" . $querylayerlist . "');\n";
+ //END : check if wms has not been added before
+ $wmc_string .= "var ind = " . $target . "getMapObjIndexByName('" . $mapObj . "');\n";
+ $wmc_string .= $target . "mb_mapObj[ind].width = " . $this->wmc_windowWidth . ";\n";
+ $wmc_string .= $target . "mb_mapObj[ind].height = " . $this->wmc_windowHeight . ";\n";
+ $wmc_string .= $target . "mb_mapObj[ind].epsg = '" . $this->wmc_bBox_SRS . "';\n";
+ $wmc_string .= $target . "mb_calculateExtent('" . $mapObj . "', " . $this->wmc_bBox_minx . ", " . $this->wmc_bBox_miny . ", " . $this->wmc_bBox_maxx . ", " . $this->wmc_bBox_maxy . ");\n";
+ return $wmc_string;
+ * checks if layers of the wmc are existing in the client. If yes, they are only updated, and not loaded twice.
+ function mergeExistingJsObjWithWMC($target, $mapObj){
+ $wmc_string = "";
+ $wmc_string .= "var wms_exists = false;\n";
+ $wmc_string .= "var layer_exists = false;\n";
+ $wmc_string .= "var current_wms_index = null;\n";
+ $wmc_string .= "var current_layer_index = null;\n";
+ $wmc_string .= "var changedWmsIds = new Array();\n";
+ $wmc_string .= "var wmsAlreadyInArray = false;\n";
+ $new_wms = "";
+ $cnt_wms = -1;
+ $layerlist = "";
+ // BEGIN: check if this wms is already included in the client
+ // if not, add wms and and add layers
+ // if yes, check layers
+ $wmc_string .= "wms_exists = false;\n";
+ $wmc_string .= "current_wms_index = null;\n";
+ $wmc_string .= "for (var m=0; m < " . $target . "mb_mapObj[ind].wms.length; m++) {\n";
+ $wmc_string .= "\tif ('" . $this->wmc_wms_serviceURL[$i] . "' == " . $target . "mb_mapObj[ind].wms[m].wms_getmap) {\n";
+ $wmc_string .= "\t\twms_exists = true;\n";
+ $wmc_string .= "\t\tcurrent_wms_index = m;\n";
+// $wmc_string .= "\t\talert('match: ' + " . $target . "mb_mapObj[ind].wms[m].wms_getmap);\n";
+ $wmc_string .= "\t}\n";
+ $wmc_string .= "}\n";
+ $wmc_string .= "if (!wms_exists) {\n";
+ // END: check if this wms is already included in the client
+ echo "alert('Error: no valid capabilities-document !!');\n";
+ die; exit;
+ $wmc_string .= "\tchangedWmsIds[changedWmsIds.length] = '" . $id . "';\n";
+ $wmc_string .= "\t" . $target . "add_wms('" .
+ $id ."','".
+ $cnt_wms++;
+ $cnt_layers = 0;
+ $wmc_string .= "\t" . $target . "wms_add_layer('','','". $this->wmc_wms_title[$i] ."','','0','0','0','0','','".$id."','1','1','1','0','0','0','0');\n";
+ $cnt_layers++;
+ if (!in_array($this->wmc_layer_name[$ii], explode(",",$querylayerlist))) {
+ $wmc_string .= "\t" . $target . "wms_add_layer('0','".
+ // in this case, check if the current (PHP) wmc layer exists within the (JS) wms at current_wms_index
+ $wmc_string .= "else {\n";
+ // check if this layer already exists in this wms
+ $wmc_string .= "\tlayer_exists = false;\n";
+ $wmc_string .= "\tcurrent_layer_index = null;\n";
+ $wmc_string .= "\tfor (var m=0; m < " . $target . "mb_mapObj[ind].wms[current_wms_index].objLayer.length; m++) {\n";
+ $wmc_string .= "\t\tif ('" . $this->wmc_layer_name[$ii] . "' == " . $target . "mb_mapObj[ind].wms[current_wms_index].objLayer[m].layer_name) {\n";
+ $wmc_string .= "\t\t\tlayer_exists = true;\n";
+ $wmc_string .= "\t\t\tcurrent_layer_index = m;\n";
+// $wmc_string .= "\t\t\talert('match: ' + " . $target . "mb_mapObj[ind].wms[current_wms_index].objLayer[m].layer_name);\n";
+ $wmc_string .= "\t\t}\n";
+ $wmc_string .= "\tif (!layer_exists) {\n";
+ // do nothing (later: add this layer to current wms)
+ $wmc_string .= "\telse {\n";
+ // check if the visibility or the queryability are different to the existing layer
+ // FIXME: this 'if' may not work
+ $wmc_string .= "\t\tif (" . $target . "mb_mapObj[ind].wms[current_wms_index].objLayer[current_layer_index].gui_layer_visible != '" . intval(!$this->wmc_layer_hidden[$ii]) . "'";
+ $wmc_string .= " || " . $target . "mb_mapObj[ind].wms[current_wms_index].objLayer[current_layer_index].gui_layer_querylayer != '" . $this->wmc_layer_queryable[$ii] . "') {\n";
+ // if yes, update the visibility and queryability..
+ $wmc_string .= "\t\t\t" . $target . "mb_mapObj[ind].wms[current_wms_index].objLayer[current_layer_index].gui_layer_visible = " . intval(!$this->wmc_layer_hidden[$ii]) . ";\n";
+ $wmc_string .= "\t\t\t" . $target . "mb_mapObj[ind].wms[current_wms_index].objLayer[current_layer_index].gui_layer_querylayer = " . $this->wmc_layer_queryable[$ii] . ";\n";
+ // ... and check if current wms is in array of wmses that need restating...
+ $wmc_string .= "\t\t\twmsAlreadyInArray = false;\n";
+ $wmc_string .= "\t\t\tfor (var z=0; z<changedWmsIds.length; z++) {\n";
+ $wmc_string .= "\t\t\t\tif (changedWmsIds[z] == " . $target . "mb_mapObj[ind].wms[current_wms_index].wms_id) {\n";
+ $wmc_string .= "\t\t\t\t\twmsAlreadyInArray = true;\n";
+ $wmc_string .= "\t\t\t\t}\n";
+ $wmc_string .= "\t\t\t}\n";
+ //...if the layers of the current wms need restating, add them to the array
+ $wmc_string .= "\t\t\tif (wmsAlreadyInArray == false) {\n";
+ $wmc_string .= "\t\t\t\tchangedWmsIds[changedWmsIds.length] = " . $target . "mb_mapObj[ind].wms[current_wms_index].wms_id;\n";
+ if (intval(!$this->wmc_layer_hidden[$ii]) && !in_array($this->wmc_layer_name[$ii], explode(",",$layerlist))) {
+ "');\n";
+ $wmc_string .= $target. "mb_mapObjaddWMSwithLayers('" . $mapObj . "', '" . $layerlist . "', '" . $querylayerlist . "');\n";
+ // if the wms already exists, the layerlist and the querylayerlist of the mapObj have to be updated
+ $wmc_string .= $target. "mb_mapObj[ind].layers[current_wms_index] = \"" . $layerlist . "\";\n";
+ $wmc_string .= $target. "mb_mapObj[ind].querylayers[current_wms_index] = \"" . $querylayerlist . "\";\n";
+ function char_encode($s){
+ if(CHARSET == 'UTF-8'){
+ $s = utf8_encode($s);
+ return $s;
+// end class
+#$my_wmc = new wmc();
+//missing: createWmcStringFromJsObj
+//gets wmc from db and creates a PHP object
+//$my_wmc->createObjFromWMC("16_1112782628445");
+//creates a JS object from a PHP object
+//$my_wmc->createJsObjFromWMC("");
+//print("mb_restateLayers('" . $frameName . "');\n");
+//print("mb_repaint('" . $frameName . "'," . $my_wmc->wmc_bBox_minx . ",". $my_wmc->wmc_bBox_maxx . ",". $my_wmc->wmc_bBox_miny . ",". $my_wmc->wmc_bBox_maxy . ");\n");
+$mywms = new wms();
+mywms->createObjFromXML("http://wms1.ccgis.de/cgi-bin/mapserv44?map=/data/umn/germany_demo/germany_demo_wfs.map&&VERSION=1.1.1&REQUEST=GetCapabilities&SERVICE=WMS");
+$mywms->optimizeWMS();
+$mywms->writeObjInDB("legend");
+#$mywms->displayWMS();
+#$mywms->createObjFromXML("http://zoidberg/web/xml/brd_administrativ.xml");
+#$mywms->createObjFromXML("http://zoidberg/web/xml/dienste_1_1_1.xml");
+#$mywms->createObjFromXML("http://localhost/cgi-bin/mapserv?map=/data/umn/germany_demo/germany_demo.map&&VERSION=1.1.0&REQUEST=GetCapabilities&SERVICE=WMS");
+$mywms->createObjFromXML("http://localhost/mapbender2/classes/germany.xml");
+$mywms->displayWMS();
+#$mywms->createObjFromDB("gui1",2);
+$mywms->createObjFromXML("http://localhost/mapbender2/caps/rastertest.xml");
+$mywms->createJsObjFromWMS();
Added: trunk/mapbender/http/classes/class_wms.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/class_wms.php?view=auto&rev=13
--- (empty file)
+++ trunk/mapbender/http/classes/class_wms.php 2006-04-13 19:38:28+0000
@@ -0,0 +1,1310 @@
+<?php
+# $Id: class_wms.php,v 1.31 2006/04/06 07:34:07 astrid_emde Exp $
+# $Header: /cvsroot/mapbender/mapbender/http/classes/class_wms.php,v 1.31 2006/04/06 07:34:07 astrid_emde Exp $
+class wms {
+ var $wms_id;
+ var $wms_status;
+ var $wms_version;
+ var $wms_title;
+ var $wms_abstract;
+ var $wms_getcapabilities;
+ var $wms_getcapabilities_doc;
+ var $wms_getmap;
+ var $wms_getfeatureinfo;
+ var $wms_getlegendurl;
+ function wms() {
+function createObjFromXML($url){
+ db_select_db($DB,$con);
+ $x = new connector($url);
+ $data = $this->char_encode($x->file);
+ if(!$data){
+ echo "Unable to open document: ".$url;
+ die;
+ $this->wms_getcapabilities_doc = $data;
+ if(!$data){
+ $this->wms_status = false;
+ else{
+ $this->wms_status = true;
+ # for temporary wms a id has to be created...
+ $sql="SELECT MAX(wms_id) AS id FROM wms";
+ if(db_fetch_row($res)){
+ $this->wms_id = db_result($res, 0, "id") +1;
+ $this->wms_id = substr(md5(substr($time[0], 2)), 0, 5);
+ //$this->wms_id = "id_" . substr(md5(srand((double)time())),0,6);
+ $section;
+ $format;
+ $cnt_format = 0;
+ $cnt_layer = -1;
+ $request;
+ $cnt_styles = -1;
+ if(strtoupper($element[tag]) == "WMT_MS_CAPABILITIES" && $element[type] == "open"){
+ $this->wms_version = $element[attributes][version];
+ if(strtoupper($element[tag]) == "TITLE" && $element[level] == '3'){
+ $this->wms_title = $element[value];
+ if(strtoupper($element[tag]) == "ABSTRACT" && $element[level] == '3'){
+ $this->wms_abstract = $element[value];
+ /*map section*/
+ if($this->wms_version == "1.0.0"){
+ if(strtoupper($element[tag]) == "MAP" && $element[type] == "open"){
+ $section = "map";
+ if($section == "map" && strtoupper($element[tag]) == "GET"){
+ $this->wms_getmap = $element[attributes][onlineResource];
+ if($section == "map" && strtoupper($element[tag]) == "FORMAT" && $element[type] == "open"){
+ $format = "map";
+ if(strtoupper($element[tag]) != "FORMAT" && $section == "map" && $format == "map"){
+ $this->data_type[$cnt_format] = "map";
+ $this->data_format[$cnt_format] = trim($element[tag]);
+ $cnt_format++;
+ if(strtoupper($element[tag]) == "FORMAT" && $element[type] == "close"){
+ $format = "";
+ if(strtoupper($element[tag]) == "MAP" && $element[type] == "close"){
+ $section = "";
+ else{
+ if(strtoupper($element[tag]) == "GETMAP" && $element[type] == "open"){
+ $section = "map";
+ if($section == "map" && strtoupper($element[tag]) == "GET" && $element[type] == "open"){
+ $request = "get";
+ if($section == "map" && $request == "get" && strtoupper($element[tag]) == "ONLINERESOURCE"){
+ $this->wms_getmap = $element[attributes]["xlink:href"];
+ if($section == "map" && strtoupper($element[tag]) == "FORMAT"){
+ $this->data_format[$cnt_format] = trim($element[value]);
+ $cnt_format++;
+ if($section == "map" && strtoupper($element[tag]) == "GET" && $element[type] == "close"){
+ $request = "";
+ if(strtoupper($element[tag]) == "GETMAP" && $element[type] == "close"){
+ $section = "";
+ /*capabilities section*/
+ if(strtoupper($element[tag]) == "CAPABILITIES" && $element[type] == "open"){
+ $section = "capabilities";
+ if($section == "capabilities" && strtoupper($element[tag]) == "GET"){
+ $this->wms_getcapabilities = $element[attributes][onlineResource];
+ if(strtoupper($element[tag]) == "CAPABILITIES" && $element[type] == "close"){
+ $section = "";
+ else{
+ if(strtoupper($element[tag]) == "GETCAPABILITIES" && $element[type] == "open"){
+ if($section == "capabilities" && strtoupper($element[tag]) == "GET" && $element[type] == "open"){
+ $request = "get";
+ if($section == "capabilities" && $request == "get" && strtoupper($element[tag]) == "ONLINERESOURCE"){
+ $this->wms_getcapabilities = $element[attributes]["xlink:href"];
+ if($section == "capabilities" && strtoupper($element[tag]) == "GET" && $element[type] == "close"){
+ $request = "";
+ if(strtoupper($element[tag]) == "GETCAPABILITIES" && $element[type] == "close"){
+ $section = "";
+ /*featureInfo section*/
+ if(strtoupper($element[tag]) == "FEATUREINFO" && $element[type] == "open"){
+ $section = "featureinfo";
+ if($section == "featureinfo" && strtoupper($element[tag]) == "GET"){
+ $this->wms_getfeatureinfo = $element[attributes][onlineResource];
+ if($section == "featureinfo" && strtoupper($element[tag]) == "FORMAT" && $element[type] == "open"){
+ $format = "featureinfo";
+ if(strtoupper($element[tag]) != "FORMAT" && $section == "featureinfo" && $format == "featureinfo"){
+ $this->data_type[$cnt_format] = "featureinfo";
+ $cnt_format++;
+ $format = "";
+ if(strtoupper($element[tag]) == "FEATUREINFO" && $element[type] == "close"){
+ $section = "";
+ else{
+ if(strtoupper($element[tag]) == "GETFEATUREINFO" && $element[type] == "open"){
+ if($section == "featureinfo" && strtoupper($element[tag]) == "GET" && $element[type] == "open"){
+ $request = "get";
+ if($section == "featureinfo" && $request == "get" && strtoupper($element[tag]) == "ONLINERESOURCE"){
+ $this->wms_getfeatureinfo = $element[attributes]["xlink:href"];
+ if($section == "featureinfo" && strtoupper($element[tag]) == "FORMAT"){
+ $cnt_format++;
+ if($section == "featureinfo" && strtoupper($element[tag]) == "GET" && $element[type] == "close"){
+ $request = "";
+ if(strtoupper($element[tag]) == "GETFEATUREINFO" && $element[type] == "close"){
+ $section = "";
+ /*exception section*/
+ if(strtoupper($element[tag]) == "EXCEPTION" && $element[type] == "open"){
+ $section = "exception";
+ if($section == "exception" && strtoupper($element[tag]) == "FORMAT" && $element[type] == "open"){
+ $format = "exception";
+ if(strtoupper($element[tag]) != "FORMAT" && $section == "exception" && $format == "exception"){
+ $this->data_type[$cnt_format] = "exception";
+ $cnt_format++;
+ if($section == "exception" && strtoupper($element[tag]) == "FORMAT" && $element[type] == "close"){
+ $format = "";
+ if(strtoupper($element[tag]) == "EXCEPTION" && $element[type] == "close"){
+ $section = "";
+ else{
+ if($section == "exception" && strtoupper($element[tag]) == "FORMAT"){
+ $cnt_format++;
+ $section = "";
+ /*legend section*/
+ else{
+ if(strtoupper($element[tag]) == "GETLEGENDGRAPHIC" && $element[type] == "open"){
+ $section = "legend";
+ if($section == "legend" && strtoupper($element[tag]) == "GET" && $element[type] == "open"){
+ $request = "get";
+ if($section == "legend" && $request == "get" && strtoupper($element[tag]) == "ONLINERESOURCE"){
+ $this->wms_getlegendurl = $element[attributes]["xlink:href"];
+ if($section == "legend" && strtoupper($element[tag]) == "GET" && $element[type] == "close"){
+ $request = "";
+ if(strtoupper($element[tag]) == "GETLEGENDGRAPHIC" && $element[type] == "close"){
+ $section = "";
+ /*layer section*/
+ if(strtoupper($element[tag]) == "LAYER"){
+ $section = "layer";
+ if ($element[type] == "open") {
+ $cnt_epsg = -1;
+ $cnt_layer++;
+ $parent[$element[level]+1] = $cnt_layer;
+ $myParent[$cnt_layer]= $parent[$element[level]];
+ $this->addLayer($cnt_layer,$myParent[$cnt_layer]);
+ $this->objLayer[$cnt_layer]->layer_queryable = $element[attributes][queryable];
+ if ($element[type] == "close") {
+ /* styles */
+ if(strtoupper($element[tag]) == "STYLE"){
+ $section = "style";
+ if($cnt_layer != $layer_style){
+ $layer_style = $cnt_layer;
+ $cnt_styles = -1;
+ $cnt_styles++;
+ if($section == "style"){
+ $this->objLayer[$cnt_layer]->layer_style[$cnt_styles]["name"] = $element[value];
+ $this->objLayer[$cnt_layer]->layer_style[$cnt_styles]["title"] = $element[value];
+ if($legendurl && strtoupper($element[tag]) == "FORMAT"){
+ $this->objLayer[$cnt_layer]->layer_style[$cnt_styles]["legendurlformat"] = $element[value];
+ if($legendurl && strtoupper($element[tag]) == "ONLINERESOURCE"){
+ $this->objLayer[$cnt_layer]->layer_style[$cnt_styles]["legendurl"] = $element[attributes]["xlink:href"];
+ /* end of styles */
+ if($section == "layer"){
+ $this->objLayer[$cnt_layer]->layer_name = $element[value];
+ $this->objLayer[$cnt_layer]->layer_title = $element[value];
+ $dataurl = true;
+ if($dataurl && strtoupper($element[tag]) == "ONLINERESOURCE"){
+ $this->objLayer[$cnt_layer]->layer_dataurl_href = $element[attributes]["xlink:href"];
+ $dataurl = false;
+ if($metadataurl && strtoupper($element[tag]) == "ONLINERESOURCE"){
+ $this->objLayer[$cnt_layer]->layer_metadataurl = $element[attributes]["xlink:href"];
+ # $this->objLayer[$cnt_layer]->wms_srs = $element[value];
+ $this->objLayer[$cnt_layer]->wms_srs1 = $element[value];
+ # $wms_srs2 = explode (" ", $wms_srs1);
+ $this->wms_srs = explode (" ", $this->objLayer[0]->wms_srs1);
+ if(strtoupper($element[tag]) == "LATLONBOUNDINGBOX"){
+ $cnt_epsg++;
+ $this->objLayer[$cnt_layer]->layer_epsg[$cnt_epsg]["epsg"] = "EPSG:4326";
+ $this->objLayer[$cnt_layer]->layer_epsg[$cnt_epsg]["minx"] = $element[attributes][minx];
+ $this->objLayer[$cnt_layer]->layer_epsg[$cnt_epsg]["miny"] = $element[attributes][miny];
+ $this->objLayer[$cnt_layer]->layer_epsg[$cnt_epsg]["maxx"] = $element[attributes][maxx];
+ $this->objLayer[$cnt_layer]->layer_epsg[$cnt_epsg]["maxy"] = $element[attributes][maxy];
+ $cnt_epsg++;
+ $this->objLayer[$cnt_layer]->layer_epsg[$cnt_epsg]["epsg"] = $element[attributes][SRS];
+ // a default epsg for mapbender
+ if($cnt_layer == 0 && $this->default_epsg == 0 && strlen(trim($element[attributes][SRS]))>= 10){
+ $this->default_epsg = $cnt_epsg;
+ if(strtoupper($element[tag]) == "SCALEHINT"){
+ if($element[attributes][max]>1000){
+ $max = 0;
+ else{
+ $max = $element[attributes][max];
+ $this->objLayer[$cnt_layer]->layer_minscale = round(($element[attributes][min] * 2004.3976484406788493955738891127));
+ $this->objLayer[$cnt_layer]->layer_maxscale = round(($max * 2004.3976484406788493955738891127));
+ else {
+ continue;
+ if(!$this->wms_title || $this->wms_title == ""){
+ else{
+ $this->optimizeWMS();
+function optimizeWMS(){
+ /*define defaults for wms-version 1.0.0*/
+ $map_default_ok = false;
+ $featureinfo_default_ok = false;
+ $exception_default_ok = false;
+ $map_default = "PNG";
+ $featureinfo_default = "MIME";
+ $exception_default = "INIMAGE";
+ /*define defaults for wms-version 1.1.0 and 1.1.1*/
+ else{
+ $map_default = "image/png";
+ $featureinfo_default = "text/html";
+ $exception_default = "application/vnd.ogc.se_inimage";
+ #some default
+ $this->gui_wms_visible = 1;
+ /*if the rootlayer has no epsg...*/
+ if($this->objLayer[0]->layer_epsg[0]["epsg"] == ""){
+ $this->objLayer[0]->layer_epsg = $this->objLayer[1]->layer_epsg;
+ for($i=0;$i<count($this->objLayer[0]->layer_epsg);$i++){
+ for($j=1; $j<count($this->objLayer); $j++){
+ if($this->objLayer[0]->layer_epsg[$i]["epsg"] == $this->objLayer[$j]->layer_epsg[$i]["epsg"]){
+ if($this->objLayer[$j]->layer_epsg[$i]["minx"]<$this->objLayer[0]->layer_epsg[$i]["minx"]){
+ $this->objLayer[0]->layer_epsg[$i]["minx"] = $this->objLayer[$j]->layer_epsg[$i]["minx"];
+ if($this->objLayer[$j]->layer_epsg[$i]["miny"]<$this->objLayer[0]->layer_epsg[$i]["miny"]){
+ $this->objLayer[0]->layer_epsg[$i]["miny"] = $this->objLayer[$j]->layer_epsg[$i]["miny"];
+ if($this->objLayer[$j]->layer_epsg[$i]["maxx"]>$this->objLayer[0]->layer_epsg[$i]["maxx"]){
+ $this->objLayer[0]->layer_epsg[$i]["maxx"] = $this->objLayer[$j]->layer_epsg[$i]["maxx"];
+ if($this->objLayer[$j]->layer_epsg[$i]["maxy"]>$this->objLayer[0]->layer_epsg[$i]["maxy"]){
+ $this->objLayer[0]->layer_epsg[$i]["maxy"] = $this->objLayer[$j]->layer_epsg[$i]["maxy"];
+ for($i=0;$i<count($this->objLayer);$i++){
+ if($this->objLayer[$i]->layer_minscale == ""){
+ $this->objLayer[$i]->layer_minscale = 0;
+ if($this->objLayer[$i]->layer_maxscale == ""){
+ $this->objLayer[$i]->layer_maxscale = 0;
+ if($this->objLayer[$i]->layer_queryable == ""){
+ $this->objLayer[$i]->layer_queryable = 0;
+ $this->objLayer[$i]->gui_layer_minscale = $this->objLayer[$i]->layer_minscale;
+ $this->objLayer[$i]->gui_layer_maxscale = $this->objLayer[$i]->layer_maxscale;
+ for($i=0;$i<count($this->data_format);$i++){
+ if(strtolower($this->data_type[$i]) == 'map' && strtoupper($this->data_format[$i]) == strtoupper($map_default)){
+ $this->gui_wms_mapformat = strtolower($map_default);
+ $map_default_ok = true;
+ if(strtolower($this->data_type[$i]) == 'featureinfo' && strtoupper($this->data_format[$i]) == strtoupper($featureinfo_default)){
+ $this->gui_wms_featureinfoformat = strtolower($featureinfo_default);
+ $featureinfo_default_ok = true;
+ if(strtolower($this->data_type[$i]) == 'exception' && strtolower($this->data_format[$i]) == strtolower($exception_default)){
+ $this->gui_wms_exceptionformat = strtolower($exception_default);
+ $exception_default_ok = true;
+ if($map_default_ok == false){
+ if(strtolower($this->data_type[$i]) == "map" ){$this->gui_wms_mapformat = $this->data_format[$i]; break;}
+ if($featureinfo_default_ok == false){
+ if(strtolower($this->data_type[$i]) == "featureinfo" ){$this->gui_wms_featureinfoformat = $this->data_format[$i]; break;}
+ if($exception_default_ok == false){
+ if(strtolower($this->data_type[$i]) == "exception" ){$this->gui_wms_exceptionformat = $this->data_format[$i]; break;}
+ if(count($this->objLayer[0]->layer_epsg)>1){
+ $this->gui_wms_epsg = $this->objLayer[0]->layer_epsg[$this->default_epsg][epsg];
+ else{
+ $this->gui_wms_epsg = $this->objLayer[0]->layer_epsg[0][epsg];
+ /*the queryable layers*/
+ for($i=0; $i<count($this->objLayer); $i++){
+ if($this->objLayer[$i]->layer_queryable == 1){
+ $this->objLayer[$i]->gui_layer_queryable = 1;
+ else{
+ $this->objLayer[$i]->gui_layer_queryable = 0;
+function displayWMS(){
+ echo "id: " . $this->wms_id . " <br>";
+ echo "version: " . $this->wms_version . " <br>";
+ echo "title: " . $this->wms_title . " <br>";
+ echo "abstract: " . $this->wms_abstract . " <br>";
+ echo "maprequest: " . $this->wms_getmap . " <br>";
+ echo "capabilitiesrequest: " . $this->wms_getcapabilities . " <br>";
+ echo "featureinforequest: " . $this->wms_getfeatureinfo . " <br>";
+ echo "gui_wms_mapformat: " . $this->gui_wms_mapformat . " <br>";
+ echo "gui_wms_featureinfoformat: " . $this->gui_wms_featureinfoformat . " <br>";
+ echo "gui_wms_exceptionformat: " . $this->gui_wms_exceptionformat . " <br>";
+ echo "gui_wms_epsg: " . $this->gui_wms_epsg . " <br>";
+ echo "wms_srs: " . $this->objLayer[0]->wms_srs1 . " <br>";
+ echo "gui_wms_visible: " . $this->gui_wms_visible . " <br>";
+ for($i=0; $i<count($this->data_type);$i++){
+ echo $this->data_type[$i]. " -> ".$this->data_format[$i]. "<br>";
+ echo "<hr>";
+ echo "id: <b>".$this->objLayer[$i]->layer_id ."</b> parent: <b>".$this->objLayer[$i]->layer_parent."</b> name: <b>".$this->objLayer[$i]->layer_name;
+ echo "</b> title: <b>".$this->objLayer[$i]->layer_title. "</b> queryable: <b>".$this->objLayer[$i]->layer_queryable."</b> minScale: <b>". $this->objLayer[$i]->layer_minscale."</b> maxScale: <b>".$this->objLayer[$i]->layer_maxscale."</b>";
+ echo "<br>dataurl: <b>".$this->objLayer[$i]->layer_dataurl_href. "</b>";
+ echo "<br>metadataurl: <b>".$this->objLayer[$i]->layer_metadataurl. "</b>";
+ echo "<table border='1'>";
+ for($j=0; $j<count($this->objLayer[$i]->layer_epsg);$j++){
+ echo "<tr><td>".$this->objLayer[$i]->layer_epsg[$j][epsg]."</td><td>".$this->objLayer[$i]->layer_epsg[$j][minx]."</td>";
+ echo "<td>".$this->objLayer[$i]->layer_epsg[$j][miny]."</td><td>".$this->objLayer[$i]->layer_epsg[$j][maxx]."</td>";
+ echo "<td>".$this->objLayer[$i]->layer_epsg[$j][maxy]."</td></tr>";
+ echo "</table>";
+ echo "layerstyle:";
+ echo "<tr><td>name</td><td>title</td><td>legendurl</td><td>legendurlformat</td></tr>";
+ for($j=0; $j<count($this->objLayer[$i]->layer_style);$j++){
+ echo "<tr><td>".$this->objLayer[$i]->layer_style[$j][name]."</td><td>".$this->objLayer[$i]->layer_style[$j][title]."</td><td>".$this->objLayer[$i]->layer_style[$j][legendurl]."</td><td>".$this->objLayer[$i]->layer_style[$j][legendurlformat]."</td></tr>";
+ echo "</table>";
+ function addLayer($id,$parent){
+ $this->objLayer[count($this->objLayer)] = new layer($id,$parent);
+ function createJsObjFromWMS($parent=0){
+ die; exit;
+ if($parent){
+ echo "parent.";
+ // wms_title and abstract have previously been urlencoded
+ // this solution may not yet be the ultimate one
+ print("add_wms('".
+ $this->wms_id ."','".
+ $this->wms_version ."','".
+ str_replace("'", "", $this->wms_title) ."','".
+ str_replace("'", "", $this->wms_abstract) ."','".
+ $this->wms_getmap ."','" .
+ $this->wms_getfeatureinfo ."','".
+ $this->wms_getlegendurl ."','".
+ $this->wms_filter ."','".
+ $this->gui_wms_mapformat ."','".
+ $this->gui_wms_featureinfoformat ."','".
+ $this->gui_wms_exceptionformat . "','".
+ $this->gui_wms_epsg ."','".
+ $this->gui_wms_visible ."');");
+ if($parent){
+ echo "parent.";
+ echo "wms_add_data_type_format('". $this->data_type[$i] ."','". $this->data_format[$i] ."');";
+ #echo "alert('". $this->data_type[$i] ."','". $this->data_format[$i] ."');";
+ if($parent){
+ echo "parent.";
+ print ("wms_add_layer('".
+ #$this->objLayer[$i]->layer_id ."','".
+ $this->objLayer[$i]->layer_parent ."','".
+ $this->objLayer[$i]->layer_name . "','".
+ $this->objLayer[$i]->layer_title ."','".
+ $this->objLayer[$i]->layer_dataurl_href ."','".
+ $this->objLayer[$i]->layer_pos ."','".
+ $this->objLayer[$i]->layer_queryable ."','".
+ $this->objLayer[$i]->layer_minscale . "','".
+ $this->objLayer[$i]->layer_maxscale ."','".
+ $this->objLayer[$i]->layer_metadataurl ."','".
+ $this->objLayer[$i]->gui_layer_wms_id ."','".
+ $this->objLayer[$i]->gui_layer_status ."','".
+ $this->objLayer[$i]->gui_layer_selectable ."','".
+ $this->objLayer[$i]->gui_layer_visible ."','".
+ $this->objLayer[$i]->gui_layer_queryable ."','".
+ $this->objLayer[$i]->gui_layer_querylayer ."','".
+ $this->objLayer[$i]->gui_layer_minscale ."','".
+ $this->objLayer[$i]->gui_layer_maxscale ."','".
+ $this->objLayer[$i]->gui_layer_wfs_featuretype ."');");
+ if($i==0){
+ if($parent){
+ echo "parent.";
+ print("wms_addSRS('".
+ $this->objLayer[$i]->layer_epsg[$j]["epsg"] ."','".
+ $this->objLayer[$i]->layer_epsg[$j]["minx"] ."','".
+ $this->objLayer[$i]->layer_epsg[$j]["miny"] ."','".
+ $this->objLayer[$i]->layer_epsg[$j]["maxx"] ."','".
+ $this->objLayer[$i]->layer_epsg[$j]["maxy"] ."');");
+ if($parent){
+ echo "parent.";
+ print("wms_addLayerStyle('".$this->objLayer[$i]->layer_style[$j]["name"]."', '".$this->objLayer[$i]->layer_style[$j]["title"]."', ".$j.",".$i.",'".$this->objLayer[$i]->layer_style[$j]["legendurl"]."', '".$this->objLayer[$i]->layer_style[$j]["legendformat"]."');");
+* writeObjInDB
+* this function exports the information from the xml to the mapbender database
+function writeObjInDB($gui_id){
+ if(SYS_DBTYPE=="pgsql") {
+ $sql = "SET AUTOCOMMIT=1;";
+ else {
+ $sql = "SET AUTOCOMMIT=1";
+ $sql = "BEGIN";
+ # TABLE wms
+ //echo "<pre>" . $this->wms_getcapabilities_doc . "</pre>";
+ $sql = "INSERT INTO wms (wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_getcapabilities_doc) ";
+ $sql .= "VALUES(";
+ $sql .= "'" . $this->wms_version ."', ";
+ $sql .= "'" . db_escape_string(str_replace("'","",$this->wms_title)) ."', ";
+ $sql .= "'" . db_escape_string(str_replace("'","",$this->wms_abstract)) . "', ";
+ $sql .= "'" . $this->wms_getcapabilities ."', ";
+ $sql .= "'" . $this->wms_getmap . "', ";
+ $sql .= "'". $this->wms_getfeatureinfo . "', ";
+ $sql .= "'". $this->wms_getlegendurl . "', ";
+ #$newgetcapdoc=str_replace("'", "\"", $this->wms_getcapabilities_doc);
+ #$newgetcapdoc=str_replace("\"", "\\\"", $newgetcapdoc);
+ #echo "<br><br>".$newgetcapdoc."<br><br>";
+ $sql .= "'". addslashes($this->wms_getcapabilities_doc) . "'";
+ #$sql .= "''";
+ $sql .= ");";
+ #echo "<br>". $sql."<br>";
+ $this->transaction($sql);
+ $myWMS = db_insert_id($con,'wms', 'wms_id');
+ # TABLE layer
+ $sql = "INSERT INTO layer(fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_dataurl, layer_queryable, layer_minscale, layer_maxscale,layer_metadataurl) ";
+ $sql .= $myWMS . ",";
+ if($this->objLayer[$i]->layer_id != null){
+ $sql .= $this->objLayer[$i]->layer_id . ",";
+ else {
+ $sql .= "'0',";
+ $sql .= "'".$this->objLayer[$i]->layer_parent."',";
+ $sql .= "'".$this->objLayer[$i]->layer_name."',";
+ $sql .= "'".$this->objLayer[$i]->layer_title."',";
+ $sql .= "'".$this->objLayer[$i]->layer_dataurl_href."',";
+ $sql .= $this->objLayer[$i]->layer_queryable . ",";
+ $sql .= $this->objLayer[$i]->layer_minscale . ",";
+ $sql .= $this->objLayer[$i]->layer_maxscale. ",";
+ $sql .= "'".$this->objLayer[$i]->layer_metadataurl."'";
+ $sql .= ")";
+ # save the id of each layer: set param2 true
+ $this->objLayer[$i]->db_id = db_insert_id($con, 'layer','layer_id');
+ $sql = "INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) ";
+ $sql .= $this->objLayer[$i]->db_id . ", ";
+ $sql .= "'" .$this->objLayer[$i]->layer_epsg[$j][epsg]. "', ";
+ $sql .= $this->objLayer[$i]->layer_epsg[$j][minx] . ", ";
+ $sql .= $this->objLayer[$i]->layer_epsg[$j][miny] . ", ";
+ $sql .= $this->objLayer[$i]->layer_epsg[$j][maxx]. ", ";
+ $sql .= $this->objLayer[$i]->layer_epsg[$j][maxy];
+ $sql .= ")";
+ # TABLE layer_style for each layer
+ $sql = "INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) ";
+ $sql .= $this->objLayer[$i]->db_id .", ";
+ $sql .= "'".$this->objLayer[$i]->layer_style[$j]["name"]."', ";
+ $sql .= "'".$this->objLayer[$i]->layer_style[$j]["title"]."', ";
+ $sql .= "'".$this->objLayer[$i]->layer_style[$j]["legendurl"]."', ";
+ $sql .= "'".$this->objLayer[$i]->layer_style[$j]["legendurlformat"]."'";
+ $sql .= ");";
+ for($i=0; $i<count($this->wms_srs);$i++){
+ $sql ="INSERT INTO wms_srs (fkey_wms_id, wms_srs) ";
+ $sql .= " VALUES(".$myWMS.",'".strtoupper($this->wms_srs[$i])."');";
+ # TABLE wms_format
+ $sql ="INSERT INTO wms_format (fkey_wms_id, data_type, data_format) ";
+ $sql .= " VALUES(".$myWMS.",'".$this->data_type[$i]."','".$this->data_format[$i]."');";
+ # TABLE gui_wms
+ $sql ="SELECT MAX(gui_wms_position) AS pos FROM gui_wms WHERE fkey_gui_id='".$gui_id."';";
+ if(db_result($res, 0,"pos") > -1){
+ $position = db_result($res, 0,"pos") + 1;
+ } else{ $position = 0; }
+ $sql ="INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, ";
+ $sql .= "gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg)";
+ $sql .= "'" . $gui_id . "', ";
+ $sql .= $myWMS . ", ";
+ $sql .= $position .", ";
+ $sql .= "'" . $this->gui_wms_mapformat ."', ";
+ $sql .= "'" . $this->gui_wms_featureinfoformat ."', ";
+ $sql .= "'". $this->gui_wms_exceptionformat ."', ";
+ $sql .= "'" . $this->gui_wms_epsg ."'";
+ $sql .= ");";
+ # table gui_layer
+ $sql="Select * from layer where fkey_wms_id=".$myWMS.";";
+ $res_layer= db_query($sql);
+ $count=0;
+ while($row = db_fetch_array($res_layer)){
+ $sql = "INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, ";
+ $sql .= "gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, ";
+ $sql .= "gui_layer_querylayer,gui_layer_minscale,gui_layer_maxscale, gui_layer_priority) ";
+ $sql .= "'".$gui_id."', ";
+ $sql .= $row['layer_id'].", ";
+ $sql .= "1, ";
+ $sql .= "1, ";
+ $sql .= "1, ";
+ $sql .= $row['layer_queryable'] . ", ";
+ $sql .= $row['layer_minscale'] . ", ";
+ $sql .= $row['layer_maxscale'].", ";
+ $sql .= $count;
+ $sql .= ");";
+ $count++;
+ $res = db_query("COMMIT");
+ if($SYS_DBTYPE=="pgsql")
+ {$sql2 = "SET AUTOCOMMIT=0";}
+ else{
+ $sql2 = "SET AUTOCOMMIT=1";
+ $res = db_query($sql2);
+function updateObjInDB($myWMS){
+ db_select_db($DB, $con);
+ {$sql = "SET AUTOCOMMIT=1";}
+ else{
+ $sql = "BEGIN";
+ # TABLE wms
+ $sql = "UPDATE wms SET ";
+ $sql .= "wms_version = '".$this->wms_version."' ,";
+ $sql .= "wms_title = '".db_escape_string(str_replace("'","",$this->wms_title))."' ,";
+ $sql .= "wms_abstract = '".db_escape_string(str_replace("'","",$this->wms_abstract))."' ,";
+ $sql .= "wms_getcapabilities = '".$this->wms_getcapabilities."' ,";
+ $sql .= "wms_getmap = '".$this->wms_getmap."' ,";
+ $sql .= "wms_getfeatureinfo = '".$this->wms_getfeatureinfo."' ,";
+ $sql .= "wms_getlegendurl = '".$this->wms_getlegendurl."' ,";
+ $sql .= "wms_getcapabilities_doc = '".addslashes($this->wms_getcapabilities_doc) . "'";
+ $sql .= " WHERE wms_id = ". $myWMS;
+ # TABLE layer
+ # backup layer_params
+ $sql = "SELECT * FROM gui_layer INNER JOIN layer ON layer.layer_id = gui_layer.fkey_layer_id WHERE gui_layer_wms_id = ".$myWMS;
+ $res_backup = db_query($sql);
+ $cnt = 0;
+ while($row = db_fetch_array($res_backup)){
+# $my_layer_name[$cnt] = $row["layer.layer_name"];
+# $fkey_gui_id[$cnt] = $row["gui_layer.fkey_gui_id"];
+# $fkey_layer_id[$cnt] = $row["gui_layer.fkey_layer_id"];
+ $my_layer_name[$cnt] = $row["layer_name"];
+ $fkey_gui_id[$cnt] = $row["fkey_gui_id"];
+ $fkey_layer_id[$cnt] = $row["fkey_layer_id"];
+ $gui_layer_wms_id[$cnt] = $row["gui_layer_wms_id"];
+ $gui_layer_status[$cnt] = $row["gui_layer_status"];
+ $gui_layer_selectable[$cnt] = $row["gui_layer_selectable"];
+ $gui_layer_visible[$cnt] = $row["gui_layer_visible"];
+ $gui_layer_queryable[$cnt] = $row["gui_layer_queryable"];
+ $gui_layer_querylayer[$cnt] = $row["gui_layer_querylayer"];
+ $gui_layer_minscale[$cnt] = $row["gui_layer_minscale"];
+ $gui_layer_maxscale[$cnt] = $row["gui_layer_maxscale"];
+ $gui_layer_priority[$cnt] = $row["gui_layer_priority"];
+ $gui_layer_style[$cnt] = $row["gui_layer_style"];
+ $cnt++;
+ $sql = "DELETE FROM layer WHERE fkey_wms_id = ".$myWMS;
+ $sql .= ")";
+ $this->objLayer[$i]->db_id = db_insert_id($con,"layer","layer_id");
+ $sql .= ")";
+ # delete and refill TABLE layer_style for each layer
+ $sql .= ");";
+ # TABLE wms_srs
+ $sql .= " VALUES(".$myWMS.",'".$this->wms_srs[$i]."');";
+ $sql = "DELETE FROM wms_format WHERE fkey_wms_id = " . $myWMS;
+ # TABLE gui_wms
+ $sql = "SELECT * FROM gui_wms where fkey_wms_id = " . $myWMS;
+ $cnt = 0;
+ while($row = db_fetch_array($res)){
+ unset($mySubmit);
+ $myGUI[$cnt] = $row["fkey_gui_id"];
+ $sql = "UPDATE gui_wms SET ";
+ for($i=0; $i<count($this->data_type); $i++){
+ # gui_wms_mapformat
+ if(strtolower($this->data_type[$i]) == "map" && strtolower($this->data_format[$i]) == strtolower($row["gui_wms_mapformat"])){
+ $myMapFormat = true;
+ # gui_wms_featureinfoformat
+ if(strtolower($this->data_type[$i]) == "featureinfo" && strtolower($this->data_format[$i]) == strtolower($row["gui_wms_featureinfoformat"])){
+ $myFeatureInfoFormat = true;
+ # gui_wms_exceptionformat
+ if(strtolower($this->data_type[$i]) == "exception" && strtolower($this->data_format[$i]) == strtolower($row["gui_wms_exceptionformat"])){
+ $myExceptionFormat = true;
+ if(!$myMapFormat){
+ $sql .= "gui_wms_mapformat = '".$this->gui_wms_mapformat."' ";
+ $mySubmit = true;
+ if(!$myFeatureInfoFormat){
+ if($mySubmit){ $sql .= ",";}
+ $sql .= "gui_wms_featureinfoformat = '".$this->gui_wms_featureinfoformat."' ";
+ $mySubmit = true;
+ if(!$myExceptionFormat){
+ $sql .= "gui_wms_exceptionformat = '".$this->gui_wms_exceptionformat."' ";
+ $mySubmit = true;
+ # gui_wms_epsg
+ for($j=0; $j<count($this->objLayer[0]->layer_epsg);$j++){
+ if($this->objLayer[0]->layer_epsg[$j][epsg] == strtoupper($row["gui_wms_epsg"])){
+ $myGUI_EPSG = true;
+ if(!$myGUI_EPSG){
+ $sql .= "gui_wms_epsg = '".$this->gui_wms_epsg."' ";
+ $mySubmit = true;
+ $sql .= " WHERE fkey_gui_id = '".$row["fkey_gui_id"]."' AND fkey_wms_id = " . $myWMS;
+ if($mySubmit){
+ $cnt++;
+ # TABLE gui_layer
+ for($k=0; $k<count($myGUI); $k++){
+ unset($lastLayer_index);
+ for($j=0; $j<count($my_layer_name); $j++){
+# echo "<br>" . $this->objLayer[$i]->layer_name . " vs. " . $my_layer_name[$j] . "<br>";
+# echo "<br>" . $myGUI[$k] . " vs. " . $fkey_gui_id[$j] . "<br>";
+ if($this->objLayer[$i]->layer_name == $my_layer_name[$j] && $myGUI[$k] == $fkey_gui_id[$j]){
+ $lastLayer_index = $j;
+ if($lastLayer_index >= 0 && $lastLayer_index != ""){
+ $sql = "INSERT INTO gui_layer(fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, ";
+ $sql .= "gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, ";
+ $sql .= "gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style) VALUES(";
+ $sql .= "'".$myGUI[$k]."', ";
+ $sql .= $this->objLayer[$i]->db_id. ", ";
+ $sql .= $myWMS. ", ";
+ $sql .= $gui_layer_status[$lastLayer_index]. ", ";
+ $sql .= $gui_layer_selectable[$lastLayer_index]. ", ";
+ $sql .= $gui_layer_visible[$lastLayer_index]. ", ";
+ # gui_layer_queryable
+ if($this->objLayer[$i]->layer_queryable == 1 && $gui_layer_queryable[$lastLayer_index] == 1){
+ $sql .= $this->objLayer[$i]->layer_queryable. ", ";
+ } else{$sql .= "0, ";}
+ # gui_layer_querylayer
+ if($this->objLayer[$i]->layer_queryable == 1 && $gui_layer_querylayer[$lastLayer_index] == 1){
+ $sql .= "1, ";
+ # gui_layer_minscale
+ if($gui_layer_minscale[$lastLayer_index] >= $this->objLayer[$i]->layer_minscale){
+ $sql .= $gui_layer_minscale[$lastLayer_index] . ", ";
+ } else{ $sql .= $this->objLayer[$i]->layer_minscale . ", ";}
+ # gui_layer_maxscale
+ if($this->objLayer[$i]->layer_maxscale == 0 || $gui_layer_maxscale[$lastLayer_index] <= $this->objLayer[$i]->layer_maxscale){
+ $sql .= $gui_layer_maxscale[$lastLayer_index] . ", ";
+ } else{ $sql .= $this->objLayer[$i]->layer_maxscale . ", ";}
+ # gui_layer_priority
+ $sql .= $gui_layer_priority[$lastLayer_index] . ", ";
+ # gui_layer_style
+ for($n=0; $n<count($this->objLayer[$i]->layer_style); $n++){
+ if($gui_layer_style[$lastLayer_index] == $this->objLayer[$i]->layer_style[$n]["name"]){
+ $myStyle = true;
+ if($myStyle){
+ $sql .= "'".$gui_layer_style[$lastLayer_index]."'";
+ else{$sql .= "''";}
+ $sql .= ")";
+ else{
+ # gui_layer_status
+ $sql .= "0, ";
+ # gui_layer_selectable
+ $sql .= "0, ";
+ # gui_layer_visible
+ $sql .= "0, ";
+ $sql .= "0, ";
+ $sql .= $this->objLayer[$i]->layer_minscale . ", ";
+ $sql .= $this->objLayer[$i]->layer_maxscale . ", ";
+ $sql .= $this->objLayer[$i]->layer_id . ", ";
+ $sql .= "''";
+ $sql .= ")";
+ $sql = "COMMIT";
+ {$sql = "SET AUTOCOMMIT=0";}
+ else{
+function getVersion() {
+ return $this->wms_version;
+function getCapabilities() {
+ return $this->wms_getcapabilities;
+function getCapabilitiesDoc() {
+ return $this->wms_getcapabilities_doc;
+function transaction($sql){
+ #echo "<hr>". $sql;
+ $ok = db_query($sql);
+ if(!$ok){
+ echo "<pre>".$sql."</pre><br> <br><p>";
+ $error = db_error();
+ $sql = "ROLLBACK";
+ $sql = "SET AUTOCOMMIT=0";
+ else
+ echo $error;
+ echo "<br /> UPDATE ERROR -> KILL PROCESS AND ROLLBACK....................no update<br><br>";
+* creatObjfromDB
+ function createObjFromDB($gui_id,$wms_id){
+ $connect = db_connect($DBSERVER,$OWNER,$PW);
+ $sql="Select * from gui_wms where fkey_wms_id=".$wms_id." AND fkey_gui_id='".$gui_id."';";
+ $count=0;
+ #$res_count=db_num_rows($res);
+ $this->gui_wms_mapformat=$row["gui_wms_mapformat"];
+ $this->gui_wms_featureinfoformat=$row["gui_wms_featureinfoformat"];
+ $this->gui_wms_exceptionformat=$row["gui_wms_exceptionformat"];
+ $this->gui_wms_epsg=$row["gui_wms_epsg"];
+ $this->gui_wms_visible = $row["gui_wms_visible"];
+ $sql="Select * from wms where wms_id=".$wms_id.";";
+ $res_wms = db_query($sql);
+ $count_wms=0;
+ while($row2 = db_fetch_array($res_wms)){
+ $this->wms_id = $row2["wms_id"];
+ $this->wms_version = $row2["wms_version"];
+ $this->wms_title = $row2["wms_title"];
+ $this->wms_abstract = $row2["wms_abstract"];
+ $this->wms_getmap = $row2["wms_getmap"];
+ $this->wms_getcapabilities = $row2["wms_getcapabilities"];
+ $this->wms_getcapabilities_doc = $row2["wms_getcapabilities_doc"];
+ $this->wms_getfeatureinfo = $row2["wms_getfeatureinfo"];
+ $this->wms_getlegendurl = $row2["wms_getlegendurl"];
+ $this->wms_filter = $row2["wms_filter"];
+ $count_wms++;
+ ### formats
+ $sql = "SELECT * FROM wms_format WHERE fkey_wms_id = ".$wms_id.";";
+ $count_format=0;
+ while($row3 = db_fetch_array($res_wms)){
+ $this->data_type[$count_format] = $row3["data_type"];
+ $this->data_format[$count_format] = $row3["data_format"];
+ $count_format++;
+ $count++;
+ #layer
+ $sql="Select * from gui_layer where gui_layer_wms_id=".$wms_id." AND fkey_gui_id='";
+ $sql .= $gui_id."' AND gui_layer_status = 1 ORDER BY gui_layer_priority;";
+ $count=0;
+ $layer_id=$row["fkey_layer_id"];
+ $sql="Select * from layer where layer_id=".$layer_id.";";
+ $res_layer = db_query($sql);
+ $count_layer=0;
+ while($row2 = db_fetch_array($res_layer)){
+ $this->addLayer($row2["layer_pos"],$row2["layer_parent"]);
+ $layer_cnt=count($this->objLayer)-1;
+ $this->objLayer[$layer_cnt]->layer_name =$row2["layer_name"];
+ $this->objLayer[$layer_cnt]->layer_title =$row2["layer_title"];
+ $this->objLayer[$layer_cnt]->layer_dataurl_href =$row2["layer_dataurl"];
+ $this->objLayer[$layer_cnt]->layer_metadataurl =$row2["layer_metadataurl"];
+ $this->objLayer[$layer_cnt]->layer_pos =$row2["layer_pos"];
+ $this->objLayer[$layer_cnt]->layer_queryable =$row2["layer_pos"];
+ $this->objLayer[$layer_cnt]->layer_queryable =$row2["layer_queryable"];
+ $this->objLayer[$layer_cnt]->layer_minscale =$row2["layer_minscale"];
+ $this->objLayer[$layer_cnt]->layer_maxscale = $row2["layer_maxscale"];
+ $count_layer++;
+ $this->objLayer[$layer_cnt]->gui_layer_wms_id = $row["gui_layer_wms_id"];
+ $this->objLayer[$layer_cnt]->gui_layer_selectable = $row["gui_layer_selectable"];
+ $this->objLayer[$layer_cnt]->gui_layer_visible = $row["gui_layer_visible"];
+ $this->objLayer[$layer_cnt]->gui_layer_queryable = $row["gui_layer_queryable"];
+ $this->objLayer[$layer_cnt]->gui_layer_querylayer = $row["gui_layer_querylayer"];
+ $this->objLayer[$layer_cnt]->gui_layer_minscale = $row["gui_layer_minscale"];
+ $this->objLayer[$layer_cnt]->gui_layer_maxscale = $row["gui_layer_maxscale"];
+ $this->objLayer[$layer_cnt]->gui_layer_wfs_featuretype = $row["gui_layer_wfs_featuretype"];
+ $sql="Select * from layer_epsg where fkey_layer_id=".$layer_id." ORDER BY fkey_layer_id;";
+ $res_layer_epsg = db_query($sql);
+ $count_layer_epsg=0;
+ while($row2 = db_fetch_array($res_layer_epsg)){
+ $this->objLayer[$layer_cnt]->layer_epsg[$count_layer_epsg]["epsg"]=$row2["epsg"];
+ $this->objLayer[$layer_cnt]->layer_epsg[$count_layer_epsg]["minx"]=$row2["minx"];
+ $this->objLayer[$layer_cnt]->layer_epsg[$count_layer_epsg]["miny"]=$row2["miny"];
+ $this->objLayer[$layer_cnt]->layer_epsg[$count_layer_epsg]["maxx"]=$row2["maxx"];
+ $this->objLayer[$layer_cnt]->layer_epsg[$count_layer_epsg]["maxy"]=$row2["maxy"];
+ $j++;
+ $count_layer_epsg++;
+ ### handle styles
+ $sql = "SELECT * FROM layer_style WHERE fkey_layer_id = " . $layer_id;
+ $res_style = db_query($sql);
+ $count_layer_style = 0;
+ while($row2 = db_fetch_array($res_style)){
+ $this->objLayer[$layer_cnt]->layer_style[$count_layer_style]["name"]=$row2["name"];
+ $this->objLayer[$layer_cnt]->layer_style[$count_layer_style]["title"]=$row2["title"];
+ $this->objLayer[$layer_cnt]->layer_style[$count_layer_style]["legendurl"]=$row2["legendurl"];
+ $this->objLayer[$layer_cnt]->layer_style[$count_layer_style]["legendurlformat"]=$row2["legendurlformat"];
+ $count_layer_style++;
+ $count++;
+/** end createObjfromDB **/
+* function checkObjExistsInDB()
+* this function checks wether the onlineresource already exists in the database.
+function checkObjExistsInDB(){
+ global $DBSERVER,$DB,$OWNER,$PW;
+ $sql="Select * from wms where wms_getcapabilities='".$this->wms_getcapabilities."';";
+ $res = db_query($sql);
+ $res_count= db_num_rows($res);
+ $wms_id=0;
+ If ($res_count>0){
+ $count=0;
+ $wms_id=$row["wms_id"];
+ $count++;
+ return $wms_id;
+function displayDBInformation(){
+# include("../../conf/mapbender.conf");
+ echo $this->wms_getcapabilities;
+ $sql="Select * from wms where wms_getcapabilities='". $this->wms_getcapabilities ."';";
+ $count=0;
+ echo "count: ".$count."<br>";
+ echo "version: " .$wms_id." <br>";
+ echo "title: " .$row["wms_version"]. " <br>";
+ echo "abstract: " . $row["wms_title"] . " <br>";
+ echo "maprequest: " .$row["wms_abstract"] . " <br>";
+ echo "capabilitiesrequest: " . $row["wms_getcapabilities"] . " <br>";
+ echo "featureinforequest: " . $row["wms_getmap"]. " <br>";
+ echo "gui_wms_mapformat: " . $row["wms_getfeatureinfo"] . " <br>---------<br>";
+ $count++;
+ echo "----<br> wms_id: ".$wms_id."<br>";
+ $sql="Select * from gui_wms where fkey_wms_id =".$wms_id.";";
+ echo "sql: ".$sql." <br>---------<br>";
+ echo "result count: ".$res_count." <br>---------<br>";
+ $count=0;
+ echo "gui_wms_featureinfoformat: " . $row["gui_wms_featureinfoformat"]." <br>";
+ echo "gui_wms_exceptionformat: " . $row["gui_wms_exceptionformat"]. " <br>";
+ echo "gui_wms_epsg: " . $row["gui_wms_epsg"]. " <br>";
+ $count++;
+ #db_close($connect);
+ return $s;
+class layer extends wms{
+ var $layer_id;
+ var $layer_parent;
+ var $layer_name;
+ var $layer_title;
+ var $layer_pos;
+ var $layer_queryable;
+ var $layer_minscale;
+ var $layer_maxscale;
+ var $layer_dataurl_href;
+ var $layer_metadataurl;
+ var $layer_epsg = array();
+ var $layer_style = array();
+ var $gui_layer_wms_id;
+ var $gui_layer_status = 1;
+ var $gui_layer_selectable = 1;
+ var $gui_layer_visible = 0;
+ var $gui_layer_queryable;
+ var $gui_layer_querylayer = 0;
+ function layer($id,$parent){
+ $this->layer_id = $id;
+ $this->layer_parent = $parent;
+ return $s;
Added: trunk/mapbender/http/classes/fonts/Courier-Bold.afm
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/fonts/Courier-Bold.afm?view=auto&rev=13
--- (empty file)
+++ trunk/mapbender/http/classes/fonts/Courier-Bold.afm 2006-04-13 19:38:28+0000
@@ -0,0 +1,342 @@
+StartFontMetrics 4.1
+Comment Copyright (c) 1989, 1990, 1991, 1993, 1997 Adobe Systems Incorporated. All Rights Reserved.
+Comment Creation Date: Mon Jun 23 16:28:00 1997
+Comment UniqueID 43048
+Comment VMusage 41139 52164
+FontName Courier-Bold
+FullName Courier Bold
+FamilyName Courier
+Weight Bold
+ItalicAngle 0
+IsFixedPitch true
+CharacterSet ExtendedRoman
+FontBBox -113 -250 749 801
+UnderlinePosition -100
+UnderlineThickness 50
+Version 003.000
+Notice Copyright (c) 1989, 1990, 1991, 1993, 1997 Adobe Systems Incorporated. All Rights Reserved.
+EncodingScheme AdobeStandardEncoding
+CapHeight 562
+XHeight 439
+Ascender 629
+Descender -157
+StdHW 84
+StdVW 106
+StartCharMetrics 315
+C 32 ; WX 600 ; N space ; B 0 0 0 0 ;
+C 33 ; WX 600 ; N exclam ; B 202 -15 398 572 ;
+C 34 ; WX 600 ; N quotedbl ; B 135 277 465 562 ;
+C 35 ; WX 600 ; N numbersign ; B 56 -45 544 651 ;
+C 36 ; WX 600 ; N dollar ; B 82 -126 519 666 ;
+C 37 ; WX 600 ; N percent ; B 5 -15 595 616 ;
+C 38 ; WX 600 ; N ampersand ; B 36 -15 546 543 ;
+C 39 ; WX 600 ; N quoteright ; B 171 277 423 562 ;
+C 40 ; WX 600 ; N parenleft ; B 219 -102 461 616 ;
+C 41 ; WX 600 ; N parenright ; B 139 -102 381 616 ;
+C 42 ; WX 600 ; N asterisk ; B 91 219 509 601 ;
+C 43 ; WX 600 ; N plus ; B 71 39 529 478 ;
+C 44 ; WX 600 ; N comma ; B 123 -111 393 174 ;
+C 45 ; WX 600 ; N hyphen ; B 100 203 500 313 ;
+C 46 ; WX 600 ; N period ; B 192 -15 408 171 ;
+C 47 ; WX 600 ; N slash ; B 98 -77 502 626 ;
+C 48 ; WX 600 ; N zero ; B 87 -15 513 616 ;
+C 49 ; WX 600 ; N one ; B 81 0 539 616 ;
+C 50 ; WX 600 ; N two ; B 61 0 499 616 ;
+C 51 ; WX 600 ; N three ; B 63 -15 501 616 ;
+C 52 ; WX 600 ; N four ; B 53 0 507 616 ;
+C 53 ; WX 600 ; N five ; B 70 -15 521 601 ;
+C 54 ; WX 600 ; N six ; B 90 -15 521 616 ;
+C 55 ; WX 600 ; N seven ; B 55 0 494 601 ;
+C 56 ; WX 600 ; N eight ; B 83 -15 517 616 ;
+C 57 ; WX 600 ; N nine ; B 79 -15 510 616 ;
+C 58 ; WX 600 ; N colon ; B 191 -15 407 425 ;
+C 59 ; WX 600 ; N semicolon ; B 123 -111 408 425 ;
+C 60 ; WX 600 ; N less ; B 66 15 523 501 ;
+C 61 ; WX 600 ; N equal ; B 71 118 529 398 ;
+C 62 ; WX 600 ; N greater ; B 77 15 534 501 ;
+C 63 ; WX 600 ; N question ; B 98 -14 501 580 ;
+C 64 ; WX 600 ; N at ; B 16 -15 584 616 ;
+C 65 ; WX 600 ; N A ; B -9 0 609 562 ;
+C 66 ; WX 600 ; N B ; B 30 0 573 562 ;
+C 67 ; WX 600 ; N C ; B 22 -18 560 580 ;
+C 68 ; WX 600 ; N D ; B 30 0 594 562 ;
+C 69 ; WX 600 ; N E ; B 25 0 560 562 ;
+C 70 ; WX 600 ; N F ; B 39 0 570 562 ;
+C 71 ; WX 600 ; N G ; B 22 -18 594 580 ;
+C 72 ; WX 600 ; N H ; B 20 0 580 562 ;
+C 73 ; WX 600 ; N I ; B 77 0 523 562 ;
+C 74 ; WX 600 ; N J ; B 37 -18 601 562 ;
+C 75 ; WX 600 ; N K ; B 21 0 599 562 ;
+C 76 ; WX 600 ; N L ; B 39 0 578 562 ;
+C 77 ; WX 600 ; N M ; B -2 0 602 562 ;
+C 78 ; WX 600 ; N N ; B 8 -12 610 562 ;
+C 79 ; WX 600 ; N O ; B 22 -18 578 580 ;
+C 80 ; WX 600 ; N P ; B 48 0 559 562 ;
+C 81 ; WX 600 ; N Q ; B 32 -138 578 580 ;
+C 82 ; WX 600 ; N R ; B 24 0 599 562 ;
+C 83 ; WX 600 ; N S ; B 47 -22 553 582 ;
+C 84 ; WX 600 ; N T ; B 21 0 579 562 ;
+C 85 ; WX 600 ; N U ; B 4 -18 596 562 ;
+C 86 ; WX 600 ; N V ; B -13 0 613 562 ;
+C 87 ; WX 600 ; N W ; B -18 0 618 562 ;
+C 88 ; WX 600 ; N X ; B 12 0 588 562 ;
+C 89 ; WX 600 ; N Y ; B 12 0 589 562 ;
+C 90 ; WX 600 ; N Z ; B 62 0 539 562 ;
+C 91 ; WX 600 ; N bracketleft ; B 245 -102 475 616 ;
+C 92 ; WX 600 ; N backslash ; B 99 -77 503 626 ;
+C 93 ; WX 600 ; N bracketright ; B 125 -102 355 616 ;
+C 94 ; WX 600 ; N asciicircum ; B 108 250 492 616 ;
+C 95 ; WX 600 ; N underscore ; B 0 -125 600 -75 ;
+C 96 ; WX 600 ; N quoteleft ; B 178 277 428 562 ;
+C 97 ; WX 600 ; N a ; B 35 -15 570 454 ;
+C 98 ; WX 600 ; N b ; B 0 -15 584 626 ;
+C 99 ; WX 600 ; N c ; B 40 -15 545 459 ;
+C 100 ; WX 600 ; N d ; B 20 -15 591 626 ;
+C 101 ; WX 600 ; N e ; B 40 -15 563 454 ;
+C 102 ; WX 600 ; N f ; B 83 0 547 626 ; L i fi ; L l fl ;
+C 103 ; WX 600 ; N g ; B 30 -146 580 454 ;
+C 104 ; WX 600 ; N h ; B 5 0 592 626 ;
+C 105 ; WX 600 ; N i ; B 77 0 523 658 ;
+C 106 ; WX 600 ; N j ; B 63 -146 440 658 ;
+C 107 ; WX 600 ; N k ; B 20 0 585 626 ;
+C 108 ; WX 600 ; N l ; B 77 0 523 626 ;
+C 109 ; WX 600 ; N m ; B -22 0 626 454 ;
+C 110 ; WX 600 ; N n ; B 18 0 592 454 ;
+C 111 ; WX 600 ; N o ; B 30 -15 570 454 ;
+C 112 ; WX 600 ; N p ; B -1 -142 570 454 ;
+C 113 ; WX 600 ; N q ; B 20 -142 591 454 ;
+C 114 ; WX 600 ; N r ; B 47 0 580 454 ;
+C 115 ; WX 600 ; N s ; B 68 -17 535 459 ;
+C 116 ; WX 600 ; N t ; B 47 -15 532 562 ;
+C 117 ; WX 600 ; N u ; B -1 -15 569 439 ;
+C 118 ; WX 600 ; N v ; B -1 0 601 439 ;
+C 119 ; WX 600 ; N w ; B -18 0 618 439 ;
+C 120 ; WX 600 ; N x ; B 6 0 594 439 ;
+C 121 ; WX 600 ; N y ; B -4 -142 601 439 ;
+C 122 ; WX 600 ; N z ; B 81 0 520 439 ;
+C 123 ; WX 600 ; N braceleft ; B 160 -102 464 616 ;
+C 124 ; WX 600 ; N bar ; B 255 -250 345 750 ;
+C 125 ; WX 600 ; N braceright ; B 136 -102 440 616 ;
+C 126 ; WX 600 ; N asciitilde ; B 71 153 530 356 ;
+C 161 ; WX 600 ; N exclamdown ; B 202 -146 398 449 ;
+C 162 ; WX 600 ; N cent ; B 66 -49 518 614 ;
+C 163 ; WX 600 ; N sterling ; B 72 -28 558 611 ;
+C 164 ; WX 600 ; N fraction ; B 25 -60 576 661 ;
+C 165 ; WX 600 ; N yen ; B 10 0 590 562 ;
+C 166 ; WX 600 ; N florin ; B -30 -131 572 616 ;
+C 167 ; WX 600 ; N section ; B 83 -70 517 580 ;
+C 168 ; WX 600 ; N currency ; B 54 49 546 517 ;
+C 169 ; WX 600 ; N quotesingle ; B 227 277 373 562 ;
+C 170 ; WX 600 ; N quotedblleft ; B 71 277 535 562 ;
+C 171 ; WX 600 ; N guillemotleft ; B 8 70 553 446 ;
+C 172 ; WX 600 ; N guilsinglleft ; B 141 70 459 446 ;
+C 173 ; WX 600 ; N guilsinglright ; B 141 70 459 446 ;
+C 174 ; WX 600 ; N fi ; B 12 0 593 626 ;
+C 175 ; WX 600 ; N fl ; B 12 0 593 626 ;
+C 177 ; WX 600 ; N endash ; B 65 203 535 313 ;
+C 178 ; WX 600 ; N dagger ; B 106 -70 494 580 ;
+C 179 ; WX 600 ; N daggerdbl ; B 106 -70 494 580 ;
+C 180 ; WX 600 ; N periodcentered ; B 196 165 404 351 ;
+C 182 ; WX 600 ; N paragraph ; B 6 -70 576 580 ;
+C 183 ; WX 600 ; N bullet ; B 140 132 460 430 ;
+C 184 ; WX 600 ; N quotesinglbase ; B 175 -142 427 143 ;
+C 185 ; WX 600 ; N quotedblbase ; B 65 -142 529 143 ;
+C 186 ; WX 600 ; N quotedblright ; B 61 277 525 562 ;
+C 187 ; WX 600 ; N guillemotright ; B 47 70 592 446 ;
+C 188 ; WX 600 ; N ellipsis ; B 26 -15 574 116 ;
+C 189 ; WX 600 ; N perthousand ; B -113 -15 713 616 ;
+C 191 ; WX 600 ; N questiondown ; B 99 -146 502 449 ;
+C 193 ; WX 600 ; N grave ; B 132 508 395 661 ;
+C 194 ; WX 600 ; N acute ; B 205 508 468 661 ;
+C 195 ; WX 600 ; N circumflex ; B 103 483 497 657 ;
+C 196 ; WX 600 ; N tilde ; B 89 493 512 636 ;
+C 197 ; WX 600 ; N macron ; B 88 505 512 585 ;
+C 198 ; WX 600 ; N breve ; B 83 468 517 631 ;
+C 199 ; WX 600 ; N dotaccent ; B 230 498 370 638 ;
+C 200 ; WX 600 ; N dieresis ; B 128 498 472 638 ;
+C 202 ; WX 600 ; N ring ; B 198 481 402 678 ;
+C 203 ; WX 600 ; N cedilla ; B 205 -206 387 0 ;
+C 205 ; WX 600 ; N hungarumlaut ; B 68 488 588 661 ;
+C 206 ; WX 600 ; N ogonek ; B 169 -199 400 0 ;
+C 207 ; WX 600 ; N caron ; B 103 493 497 667 ;
+C 208 ; WX 600 ; N emdash ; B -10 203 610 313 ;
+C 225 ; WX 600 ; N AE ; B -29 0 602 562 ;
+C 227 ; WX 600 ; N ordfeminine ; B 147 196 453 580 ;
+C 232 ; WX 600 ; N Lslash ; B 39 0 578 562 ;
+C 233 ; WX 600 ; N Oslash ; B 22 -22 578 584 ;
+C 234 ; WX 600 ; N OE ; B -25 0 595 562 ;
+C 235 ; WX 600 ; N ordmasculine ; B 147 196 453 580 ;
+C 241 ; WX 600 ; N ae ; B -4 -15 601 454 ;
+C 245 ; WX 600 ; N dotlessi ; B 77 0 523 439 ;
+C 248 ; WX 600 ; N lslash ; B 77 0 523 626 ;
+C 249 ; WX 600 ; N oslash ; B 30 -24 570 463 ;
+C 250 ; WX 600 ; N oe ; B -18 -15 611 454 ;
+C 251 ; WX 600 ; N germandbls ; B 22 -15 596 626 ;
+C -1 ; WX 600 ; N Idieresis ; B 77 0 523 761 ;
+C -1 ; WX 600 ; N eacute ; B 40 -15 563 661 ;
+C -1 ; WX 600 ; N abreve ; B 35 -15 570 661 ;
+C -1 ; WX 600 ; N uhungarumlaut ; B -1 -15 628 661 ;
+C -1 ; WX 600 ; N ecaron ; B 40 -15 563 667 ;
+C -1 ; WX 600 ; N Ydieresis ; B 12 0 589 761 ;
+C -1 ; WX 600 ; N divide ; B 71 16 529 500 ;
+C -1 ; WX 600 ; N Yacute ; B 12 0 589 784 ;
+C -1 ; WX 600 ; N Acircumflex ; B -9 0 609 780 ;
+C -1 ; WX 600 ; N aacute ; B 35 -15 570 661 ;
+C -1 ; WX 600 ; N Ucircumflex ; B 4 -18 596 780 ;
+C -1 ; WX 600 ; N yacute ; B -4 -142 601 661 ;
+C -1 ; WX 600 ; N scommaaccent ; B 68 -250 535 459 ;
+C -1 ; WX 600 ; N ecircumflex ; B 40 -15 563 657 ;
+C -1 ; WX 600 ; N Uring ; B 4 -18 596 801 ;
+C -1 ; WX 600 ; N Udieresis ; B 4 -18 596 761 ;
+C -1 ; WX 600 ; N aogonek ; B 35 -199 586 454 ;
+C -1 ; WX 600 ; N Uacute ; B 4 -18 596 784 ;
+C -1 ; WX 600 ; N uogonek ; B -1 -199 585 439 ;
+C -1 ; WX 600 ; N Edieresis ; B 25 0 560 761 ;
+C -1 ; WX 600 ; N Dcroat ; B 30 0 594 562 ;
+C -1 ; WX 600 ; N commaaccent ; B 205 -250 397 -57 ;
+C -1 ; WX 600 ; N copyright ; B 0 -18 600 580 ;
+C -1 ; WX 600 ; N Emacron ; B 25 0 560 708 ;
+C -1 ; WX 600 ; N ccaron ; B 40 -15 545 667 ;
+C -1 ; WX 600 ; N aring ; B 35 -15 570 678 ;
+C -1 ; WX 600 ; N Ncommaaccent ; B 8 -250 610 562 ;
+C -1 ; WX 600 ; N lacute ; B 77 0 523 801 ;
+C -1 ; WX 600 ; N agrave ; B 35 -15 570 661 ;
+C -1 ; WX 600 ; N Tcommaaccent ; B 21 -250 579 562 ;
+C -1 ; WX 600 ; N Cacute ; B 22 -18 560 784 ;
+C -1 ; WX 600 ; N atilde ; B 35 -15 570 636 ;
+C -1 ; WX 600 ; N Edotaccent ; B 25 0 560 761 ;
+C -1 ; WX 600 ; N scaron ; B 68 -17 535 667 ;
+C -1 ; WX 600 ; N scedilla ; B 68 -206 535 459 ;
+C -1 ; WX 600 ; N iacute ; B 77 0 523 661 ;
+C -1 ; WX 600 ; N lozenge ; B 66 0 534 740 ;
+C -1 ; WX 600 ; N Rcaron ; B 24 0 599 790 ;
+C -1 ; WX 600 ; N Gcommaaccent ; B 22 -250 594 580 ;
+C -1 ; WX 600 ; N ucircumflex ; B -1 -15 569 657 ;
+C -1 ; WX 600 ; N acircumflex ; B 35 -15 570 657 ;
+C -1 ; WX 600 ; N Amacron ; B -9 0 609 708 ;
+C -1 ; WX 600 ; N rcaron ; B 47 0 580 667 ;
+C -1 ; WX 600 ; N ccedilla ; B 40 -206 545 459 ;
+C -1 ; WX 600 ; N Zdotaccent ; B 62 0 539 761 ;
+C -1 ; WX 600 ; N Thorn ; B 48 0 557 562 ;
+C -1 ; WX 600 ; N Omacron ; B 22 -18 578 708 ;
+C -1 ; WX 600 ; N Racute ; B 24 0 599 784 ;
+C -1 ; WX 600 ; N Sacute ; B 47 -22 553 784 ;
+C -1 ; WX 600 ; N dcaron ; B 20 -15 727 626 ;
+C -1 ; WX 600 ; N Umacron ; B 4 -18 596 708 ;
+C -1 ; WX 600 ; N uring ; B -1 -15 569 678 ;
+C -1 ; WX 600 ; N threesuperior ; B 138 222 433 616 ;
+C -1 ; WX 600 ; N Ograve ; B 22 -18 578 784 ;
+C -1 ; WX 600 ; N Agrave ; B -9 0 609 784 ;
+C -1 ; WX 600 ; N Abreve ; B -9 0 609 784 ;
+C -1 ; WX 600 ; N multiply ; B 81 39 520 478 ;
+C -1 ; WX 600 ; N uacute ; B -1 -15 569 661 ;
+C -1 ; WX 600 ; N Tcaron ; B 21 0 579 790 ;
+C -1 ; WX 600 ; N partialdiff ; B 63 -38 537 728 ;
+C -1 ; WX 600 ; N ydieresis ; B -4 -142 601 638 ;
+C -1 ; WX 600 ; N Nacute ; B 8 -12 610 784 ;
+C -1 ; WX 600 ; N icircumflex ; B 73 0 523 657 ;
+C -1 ; WX 600 ; N Ecircumflex ; B 25 0 560 780 ;
+C -1 ; WX 600 ; N adieresis ; B 35 -15 570 638 ;
+C -1 ; WX 600 ; N edieresis ; B 40 -15 563 638 ;
+C -1 ; WX 600 ; N cacute ; B 40 -15 545 661 ;
+C -1 ; WX 600 ; N nacute ; B 18 0 592 661 ;
+C -1 ; WX 600 ; N umacron ; B -1 -15 569 585 ;
+C -1 ; WX 600 ; N Ncaron ; B 8 -12 610 790 ;
+C -1 ; WX 600 ; N Iacute ; B 77 0 523 784 ;
+C -1 ; WX 600 ; N plusminus ; B 71 24 529 515 ;
+C -1 ; WX 600 ; N brokenbar ; B 255 -175 345 675 ;
+C -1 ; WX 600 ; N registered ; B 0 -18 600 580 ;
+C -1 ; WX 600 ; N Gbreve ; B 22 -18 594 784 ;
+C -1 ; WX 600 ; N Idotaccent ; B 77 0 523 761 ;
+C -1 ; WX 600 ; N summation ; B 15 -10 586 706 ;
+C -1 ; WX 600 ; N Egrave ; B 25 0 560 784 ;
+C -1 ; WX 600 ; N racute ; B 47 0 580 661 ;
+C -1 ; WX 600 ; N omacron ; B 30 -15 570 585 ;
+C -1 ; WX 600 ; N Zacute ; B 62 0 539 784 ;
+C -1 ; WX 600 ; N Zcaron ; B 62 0 539 790 ;
+C -1 ; WX 600 ; N greaterequal ; B 26 0 523 696 ;
+C -1 ; WX 600 ; N Eth ; B 30 0 594 562 ;
+C -1 ; WX 600 ; N Ccedilla ; B 22 -206 560 580 ;
+C -1 ; WX 600 ; N lcommaaccent ; B 77 -250 523 626 ;
+C -1 ; WX 600 ; N tcaron ; B 47 -15 532 703 ;
+C -1 ; WX 600 ; N eogonek ; B 40 -199 563 454 ;
+C -1 ; WX 600 ; N Uogonek ; B 4 -199 596 562 ;
+C -1 ; WX 600 ; N Aacute ; B -9 0 609 784 ;
+C -1 ; WX 600 ; N Adieresis ; B -9 0 609 761 ;
+C -1 ; WX 600 ; N egrave ; B 40 -15 563 661 ;
+C -1 ; WX 600 ; N zacute ; B 81 0 520 661 ;
+C -1 ; WX 600 ; N iogonek ; B 77 -199 523 658 ;
+C -1 ; WX 600 ; N Oacute ; B 22 -18 578 784 ;
+C -1 ; WX 600 ; N oacute ; B 30 -15 570 661 ;
+C -1 ; WX 600 ; N amacron ; B 35 -15 570 585 ;
+C -1 ; WX 600 ; N sacute ; B 68 -17 535 661 ;
+C -1 ; WX 600 ; N idieresis ; B 77 0 523 618 ;
+C -1 ; WX 600 ; N Ocircumflex ; B 22 -18 578 780 ;
+C -1 ; WX 600 ; N Ugrave ; B 4 -18 596 784 ;
+C -1 ; WX 600 ; N Delta ; B 6 0 594 688 ;
+C -1 ; WX 600 ; N thorn ; B -14 -142 570 626 ;
+C -1 ; WX 600 ; N twosuperior ; B 143 230 436 616 ;
+C -1 ; WX 600 ; N Odieresis ; B 22 -18 578 761 ;
+C -1 ; WX 600 ; N mu ; B -1 -142 569 439 ;
+C -1 ; WX 600 ; N igrave ; B 77 0 523 661 ;
+C -1 ; WX 600 ; N ohungarumlaut ; B 30 -15 668 661 ;
+C -1 ; WX 600 ; N Eogonek ; B 25 -199 576 562 ;
+C -1 ; WX 600 ; N dcroat ; B 20 -15 591 626 ;
+C -1 ; WX 600 ; N threequarters ; B -47 -60 648 661 ;
+C -1 ; WX 600 ; N Scedilla ; B 47 -206 553 582 ;
+C -1 ; WX 600 ; N lcaron ; B 77 0 597 626 ;
+C -1 ; WX 600 ; N Kcommaaccent ; B 21 -250 599 562 ;
+C -1 ; WX 600 ; N Lacute ; B 39 0 578 784 ;
+C -1 ; WX 600 ; N trademark ; B -9 230 749 562 ;
+C -1 ; WX 600 ; N edotaccent ; B 40 -15 563 638 ;
+C -1 ; WX 600 ; N Igrave ; B 77 0 523 784 ;
+C -1 ; WX 600 ; N Imacron ; B 77 0 523 708 ;
+C -1 ; WX 600 ; N Lcaron ; B 39 0 637 562 ;
+C -1 ; WX 600 ; N onehalf ; B -47 -60 648 661 ;
+C -1 ; WX 600 ; N lessequal ; B 26 0 523 696 ;
+C -1 ; WX 600 ; N ocircumflex ; B 30 -15 570 657 ;
+C -1 ; WX 600 ; N ntilde ; B 18 0 592 636 ;
+C -1 ; WX 600 ; N Uhungarumlaut ; B 4 -18 638 784 ;
+C -1 ; WX 600 ; N Eacute ; B 25 0 560 784 ;
+C -1 ; WX 600 ; N emacron ; B 40 -15 563 585 ;
+C -1 ; WX 600 ; N gbreve ; B 30 -146 580 661 ;
+C -1 ; WX 600 ; N onequarter ; B -56 -60 656 661 ;
+C -1 ; WX 600 ; N Scaron ; B 47 -22 553 790 ;
+C -1 ; WX 600 ; N Scommaaccent ; B 47 -250 553 582 ;
+C -1 ; WX 600 ; N Ohungarumlaut ; B 22 -18 628 784 ;
+C -1 ; WX 600 ; N degree ; B 86 243 474 616 ;
+C -1 ; WX 600 ; N ograve ; B 30 -15 570 661 ;
+C -1 ; WX 600 ; N Ccaron ; B 22 -18 560 790 ;
+C -1 ; WX 600 ; N ugrave ; B -1 -15 569 661 ;
+C -1 ; WX 600 ; N radical ; B -19 -104 473 778 ;
+C -1 ; WX 600 ; N Dcaron ; B 30 0 594 790 ;
+C -1 ; WX 600 ; N rcommaaccent ; B 47 -250 580 454 ;
+C -1 ; WX 600 ; N Ntilde ; B 8 -12 610 759 ;
+C -1 ; WX 600 ; N otilde ; B 30 -15 570 636 ;
+C -1 ; WX 600 ; N Rcommaaccent ; B 24 -250 599 562 ;
+C -1 ; WX 600 ; N Lcommaaccent ; B 39 -250 578 562 ;
+C -1 ; WX 600 ; N Atilde ; B -9 0 609 759 ;
+C -1 ; WX 600 ; N Aogonek ; B -9 -199 625 562 ;
+C -1 ; WX 600 ; N Aring ; B -9 0 609 801 ;
+C -1 ; WX 600 ; N Otilde ; B 22 -18 578 759 ;
+C -1 ; WX 600 ; N zdotaccent ; B 81 0 520 638 ;
+C -1 ; WX 600 ; N Ecaron ; B 25 0 560 790 ;
+C -1 ; WX 600 ; N Iogonek ; B 77 -199 523 562 ;
+C -1 ; WX 600 ; N kcommaaccent ; B 20 -250 585 626 ;
+C -1 ; WX 600 ; N minus ; B 71 203 529 313 ;
+C -1 ; WX 600 ; N Icircumflex ; B 77 0 523 780 ;
+C -1 ; WX 600 ; N ncaron ; B 18 0 592 667 ;
+C -1 ; WX 600 ; N tcommaaccent ; B 47 -250 532 562 ;
+C -1 ; WX 600 ; N logicalnot ; B 71 103 529 413 ;
+C -1 ; WX 600 ; N odieresis ; B 30 -15 570 638 ;
+C -1 ; WX 600 ; N udieresis ; B -1 -15 569 638 ;
+C -1 ; WX 600 ; N notequal ; B 12 -47 537 563 ;
+C -1 ; WX 600 ; N gcommaaccent ; B 30 -146 580 714 ;
+C -1 ; WX 600 ; N eth ; B 58 -27 543 626 ;
+C -1 ; WX 600 ; N zcaron ; B 81 0 520 667 ;
+C -1 ; WX 600 ; N ncommaaccent ; B 18 -250 592 454 ;
+C -1 ; WX 600 ; N onesuperior ; B 153 230 447 616 ;
+C -1 ; WX 600 ; N imacron ; B 77 0 523 585 ;
+C -1 ; WX 600 ; N Euro ; B 0 0 0 0 ;
+EndCharMetrics
+EndFontMetrics
Added: trunk/mapbender/http/classes/fonts/Courier-BoldOblique.afm
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/fonts/Courier-BoldOblique.afm?view=auto&rev=13
--- (empty file)
+++ trunk/mapbender/http/classes/fonts/Courier-BoldOblique.afm 2006-04-13 19:38:28+0000
@@ -0,0 +1,342 @@
+Comment Creation Date: Mon Jun 23 16:28:46 1997
+Comment UniqueID 43049
+Comment VMusage 17529 79244
+FontName Courier-BoldOblique
+FullName Courier Bold Oblique
+FamilyName Courier
+Weight Bold
+ItalicAngle -12
+IsFixedPitch true
+FontBBox -57 -250 869 801
+Version 003.000
+CapHeight 562
+XHeight 439
+Ascender 629
+Descender -157
+StdHW 84
+StdVW 106
+C 33 ; WX 600 ; N exclam ; B 215 -15 495 572 ;
+C 34 ; WX 600 ; N quotedbl ; B 211 277 585 562 ;
+C 35 ; WX 600 ; N numbersign ; B 88 -45 641 651 ;
+C 36 ; WX 600 ; N dollar ; B 87 -126 630 666 ;
+C 37 ; WX 600 ; N percent ; B 101 -15 625 616 ;
+C 38 ; WX 600 ; N ampersand ; B 61 -15 595 543 ;
+C 39 ; WX 600 ; N quoteright ; B 229 277 543 562 ;
+C 40 ; WX 600 ; N parenleft ; B 265 -102 592 616 ;
+C 41 ; WX 600 ; N parenright ; B 117 -102 444 616 ;
+C 42 ; WX 600 ; N asterisk ; B 179 219 598 601 ;
+C 43 ; WX 600 ; N plus ; B 114 39 596 478 ;
+C 44 ; WX 600 ; N comma ; B 99 -111 430 174 ;
+C 45 ; WX 600 ; N hyphen ; B 143 203 567 313 ;
+C 46 ; WX 600 ; N period ; B 206 -15 427 171 ;
+C 47 ; WX 600 ; N slash ; B 90 -77 626 626 ;
+C 48 ; WX 600 ; N zero ; B 135 -15 593 616 ;
+C 49 ; WX 600 ; N one ; B 93 0 562 616 ;
+C 50 ; WX 600 ; N two ; B 61 0 594 616 ;
+C 51 ; WX 600 ; N three ; B 71 -15 571 616 ;
+C 52 ; WX 600 ; N four ; B 81 0 559 616 ;
+C 53 ; WX 600 ; N five ; B 77 -15 621 601 ;
+C 54 ; WX 600 ; N six ; B 135 -15 652 616 ;
+C 55 ; WX 600 ; N seven ; B 147 0 622 601 ;
+C 56 ; WX 600 ; N eight ; B 115 -15 604 616 ;
+C 57 ; WX 600 ; N nine ; B 75 -15 592 616 ;
+C 58 ; WX 600 ; N colon ; B 205 -15 480 425 ;
+C 59 ; WX 600 ; N semicolon ; B 99 -111 481 425 ;
+C 60 ; WX 600 ; N less ; B 120 15 613 501 ;
+C 61 ; WX 600 ; N equal ; B 96 118 614 398 ;
+C 62 ; WX 600 ; N greater ; B 97 15 589 501 ;
+C 63 ; WX 600 ; N question ; B 183 -14 592 580 ;
+C 64 ; WX 600 ; N at ; B 65 -15 642 616 ;
+C 65 ; WX 600 ; N A ; B -9 0 632 562 ;
+C 66 ; WX 600 ; N B ; B 30 0 630 562 ;
+C 67 ; WX 600 ; N C ; B 74 -18 675 580 ;
+C 68 ; WX 600 ; N D ; B 30 0 664 562 ;
+C 69 ; WX 600 ; N E ; B 25 0 670 562 ;
+C 70 ; WX 600 ; N F ; B 39 0 684 562 ;
+C 71 ; WX 600 ; N G ; B 74 -18 675 580 ;
+C 72 ; WX 600 ; N H ; B 20 0 700 562 ;
+C 73 ; WX 600 ; N I ; B 77 0 643 562 ;
+C 74 ; WX 600 ; N J ; B 58 -18 721 562 ;
+C 75 ; WX 600 ; N K ; B 21 0 692 562 ;
+C 76 ; WX 600 ; N L ; B 39 0 636 562 ;
+C 77 ; WX 600 ; N M ; B -2 0 722 562 ;
+C 78 ; WX 600 ; N N ; B 8 -12 730 562 ;
+C 79 ; WX 600 ; N O ; B 74 -18 645 580 ;
+C 80 ; WX 600 ; N P ; B 48 0 643 562 ;
+C 81 ; WX 600 ; N Q ; B 83 -138 636 580 ;
+C 82 ; WX 600 ; N R ; B 24 0 617 562 ;
+C 83 ; WX 600 ; N S ; B 54 -22 673 582 ;
+C 84 ; WX 600 ; N T ; B 86 0 679 562 ;
+C 85 ; WX 600 ; N U ; B 101 -18 716 562 ;
+C 86 ; WX 600 ; N V ; B 84 0 733 562 ;
+C 87 ; WX 600 ; N W ; B 79 0 738 562 ;
+C 88 ; WX 600 ; N X ; B 12 0 690 562 ;
+C 89 ; WX 600 ; N Y ; B 109 0 709 562 ;
+C 90 ; WX 600 ; N Z ; B 62 0 637 562 ;
+C 91 ; WX 600 ; N bracketleft ; B 223 -102 606 616 ;
+C 92 ; WX 600 ; N backslash ; B 222 -77 496 626 ;
+C 93 ; WX 600 ; N bracketright ; B 103 -102 486 616 ;
+C 94 ; WX 600 ; N asciicircum ; B 171 250 556 616 ;
+C 95 ; WX 600 ; N underscore ; B -27 -125 585 -75 ;
+C 96 ; WX 600 ; N quoteleft ; B 297 277 487 562 ;
+C 97 ; WX 600 ; N a ; B 61 -15 593 454 ;
+C 98 ; WX 600 ; N b ; B 13 -15 636 626 ;
+C 99 ; WX 600 ; N c ; B 81 -15 631 459 ;
+C 100 ; WX 600 ; N d ; B 60 -15 645 626 ;
+C 101 ; WX 600 ; N e ; B 81 -15 605 454 ;
+C 102 ; WX 600 ; N f ; B 83 0 677 626 ; L i fi ; L l fl ;
+C 103 ; WX 600 ; N g ; B 40 -146 674 454 ;
+C 104 ; WX 600 ; N h ; B 18 0 615 626 ;
+C 105 ; WX 600 ; N i ; B 77 0 546 658 ;
+C 106 ; WX 600 ; N j ; B 36 -146 580 658 ;
+C 107 ; WX 600 ; N k ; B 33 0 643 626 ;
+C 108 ; WX 600 ; N l ; B 77 0 546 626 ;
+C 109 ; WX 600 ; N m ; B -22 0 649 454 ;
+C 110 ; WX 600 ; N n ; B 18 0 615 454 ;
+C 111 ; WX 600 ; N o ; B 71 -15 622 454 ;
+C 112 ; WX 600 ; N p ; B -32 -142 622 454 ;
+C 113 ; WX 600 ; N q ; B 60 -142 685 454 ;
+C 114 ; WX 600 ; N r ; B 47 0 655 454 ;
+C 115 ; WX 600 ; N s ; B 66 -17 608 459 ;
+C 116 ; WX 600 ; N t ; B 118 -15 567 562 ;
+C 117 ; WX 600 ; N u ; B 70 -15 592 439 ;
+C 118 ; WX 600 ; N v ; B 70 0 695 439 ;
+C 119 ; WX 600 ; N w ; B 53 0 712 439 ;
+C 120 ; WX 600 ; N x ; B 6 0 671 439 ;
+C 121 ; WX 600 ; N y ; B -21 -142 695 439 ;
+C 122 ; WX 600 ; N z ; B 81 0 614 439 ;
+C 123 ; WX 600 ; N braceleft ; B 203 -102 595 616 ;
+C 124 ; WX 600 ; N bar ; B 201 -250 505 750 ;
+C 125 ; WX 600 ; N braceright ; B 114 -102 506 616 ;
+C 126 ; WX 600 ; N asciitilde ; B 120 153 590 356 ;
+C 161 ; WX 600 ; N exclamdown ; B 196 -146 477 449 ;
+C 162 ; WX 600 ; N cent ; B 121 -49 605 614 ;
+C 163 ; WX 600 ; N sterling ; B 106 -28 650 611 ;
+C 164 ; WX 600 ; N fraction ; B 22 -60 708 661 ;
+C 165 ; WX 600 ; N yen ; B 98 0 710 562 ;
+C 166 ; WX 600 ; N florin ; B -57 -131 702 616 ;
+C 167 ; WX 600 ; N section ; B 74 -70 620 580 ;
+C 168 ; WX 600 ; N currency ; B 77 49 644 517 ;
+C 169 ; WX 600 ; N quotesingle ; B 303 277 493 562 ;
+C 170 ; WX 600 ; N quotedblleft ; B 190 277 594 562 ;
+C 171 ; WX 600 ; N guillemotleft ; B 62 70 639 446 ;
+C 172 ; WX 600 ; N guilsinglleft ; B 195 70 545 446 ;
+C 173 ; WX 600 ; N guilsinglright ; B 165 70 514 446 ;
+C 174 ; WX 600 ; N fi ; B 12 0 644 626 ;
+C 175 ; WX 600 ; N fl ; B 12 0 644 626 ;
+C 177 ; WX 600 ; N endash ; B 108 203 602 313 ;
+C 178 ; WX 600 ; N dagger ; B 175 -70 586 580 ;
+C 179 ; WX 600 ; N daggerdbl ; B 121 -70 587 580 ;
+C 180 ; WX 600 ; N periodcentered ; B 248 165 461 351 ;
+C 182 ; WX 600 ; N paragraph ; B 61 -70 700 580 ;
+C 183 ; WX 600 ; N bullet ; B 196 132 523 430 ;
+C 184 ; WX 600 ; N quotesinglbase ; B 144 -142 458 143 ;
+C 185 ; WX 600 ; N quotedblbase ; B 34 -142 560 143 ;
+C 186 ; WX 600 ; N quotedblright ; B 119 277 645 562 ;
+C 187 ; WX 600 ; N guillemotright ; B 71 70 647 446 ;
+C 188 ; WX 600 ; N ellipsis ; B 35 -15 587 116 ;
+C 189 ; WX 600 ; N perthousand ; B -45 -15 743 616 ;
+C 191 ; WX 600 ; N questiondown ; B 100 -146 509 449 ;
+C 193 ; WX 600 ; N grave ; B 272 508 503 661 ;
+C 194 ; WX 600 ; N acute ; B 312 508 609 661 ;
+C 195 ; WX 600 ; N circumflex ; B 212 483 607 657 ;
+C 196 ; WX 600 ; N tilde ; B 199 493 643 636 ;
+C 197 ; WX 600 ; N macron ; B 195 505 637 585 ;
+C 198 ; WX 600 ; N breve ; B 217 468 652 631 ;
+C 199 ; WX 600 ; N dotaccent ; B 348 498 493 638 ;
+C 200 ; WX 600 ; N dieresis ; B 246 498 595 638 ;
+C 202 ; WX 600 ; N ring ; B 319 481 528 678 ;
+C 203 ; WX 600 ; N cedilla ; B 168 -206 368 0 ;
+C 205 ; WX 600 ; N hungarumlaut ; B 171 488 729 661 ;
+C 206 ; WX 600 ; N ogonek ; B 143 -199 367 0 ;
+C 207 ; WX 600 ; N caron ; B 238 493 633 667 ;
+C 208 ; WX 600 ; N emdash ; B 33 203 677 313 ;
+C 225 ; WX 600 ; N AE ; B -29 0 708 562 ;
+C 227 ; WX 600 ; N ordfeminine ; B 188 196 526 580 ;
+C 232 ; WX 600 ; N Lslash ; B 39 0 636 562 ;
+C 233 ; WX 600 ; N Oslash ; B 48 -22 673 584 ;
+C 234 ; WX 600 ; N OE ; B 26 0 701 562 ;
+C 235 ; WX 600 ; N ordmasculine ; B 188 196 543 580 ;
+C 241 ; WX 600 ; N ae ; B 21 -15 652 454 ;
+C 245 ; WX 600 ; N dotlessi ; B 77 0 546 439 ;
+C 248 ; WX 600 ; N lslash ; B 77 0 587 626 ;
+C 249 ; WX 600 ; N oslash ; B 54 -24 638 463 ;
+C 250 ; WX 600 ; N oe ; B 18 -15 662 454 ;
+C 251 ; WX 600 ; N germandbls ; B 22 -15 629 626 ;
+C -1 ; WX 600 ; N Idieresis ; B 77 0 643 761 ;
+C -1 ; WX 600 ; N eacute ; B 81 -15 609 661 ;
+C -1 ; WX 600 ; N abreve ; B 61 -15 658 661 ;
+C -1 ; WX 600 ; N uhungarumlaut ; B 70 -15 769 661 ;
+C -1 ; WX 600 ; N ecaron ; B 81 -15 633 667 ;
+C -1 ; WX 600 ; N Ydieresis ; B 109 0 709 761 ;
+C -1 ; WX 600 ; N divide ; B 114 16 596 500 ;
+C -1 ; WX 600 ; N Yacute ; B 109 0 709 784 ;
+C -1 ; WX 600 ; N Acircumflex ; B -9 0 632 780 ;
+C -1 ; WX 600 ; N aacute ; B 61 -15 609 661 ;
+C -1 ; WX 600 ; N Ucircumflex ; B 101 -18 716 780 ;
+C -1 ; WX 600 ; N yacute ; B -21 -142 695 661 ;
+C -1 ; WX 600 ; N scommaaccent ; B 66 -250 608 459 ;
+C -1 ; WX 600 ; N ecircumflex ; B 81 -15 607 657 ;
+C -1 ; WX 600 ; N Uring ; B 101 -18 716 801 ;
+C -1 ; WX 600 ; N Udieresis ; B 101 -18 716 761 ;
+C -1 ; WX 600 ; N aogonek ; B 61 -199 593 454 ;
+C -1 ; WX 600 ; N Uacute ; B 101 -18 716 784 ;
+C -1 ; WX 600 ; N uogonek ; B 70 -199 592 439 ;
+C -1 ; WX 600 ; N Edieresis ; B 25 0 670 761 ;
+C -1 ; WX 600 ; N Dcroat ; B 30 0 664 562 ;
+C -1 ; WX 600 ; N commaaccent ; B 151 -250 385 -57 ;
+C -1 ; WX 600 ; N copyright ; B 53 -18 667 580 ;
+C -1 ; WX 600 ; N Emacron ; B 25 0 670 708 ;
+C -1 ; WX 600 ; N ccaron ; B 81 -15 633 667 ;
+C -1 ; WX 600 ; N aring ; B 61 -15 593 678 ;
+C -1 ; WX 600 ; N Ncommaaccent ; B 8 -250 730 562 ;
+C -1 ; WX 600 ; N lacute ; B 77 0 639 801 ;
+C -1 ; WX 600 ; N agrave ; B 61 -15 593 661 ;
+C -1 ; WX 600 ; N Tcommaaccent ; B 86 -250 679 562 ;
+C -1 ; WX 600 ; N Cacute ; B 74 -18 675 784 ;
+C -1 ; WX 600 ; N atilde ; B 61 -15 643 636 ;
+C -1 ; WX 600 ; N Edotaccent ; B 25 0 670 761 ;
+C -1 ; WX 600 ; N scaron ; B 66 -17 633 667 ;
+C -1 ; WX 600 ; N scedilla ; B 66 -206 608 459 ;
+C -1 ; WX 600 ; N iacute ; B 77 0 609 661 ;
+C -1 ; WX 600 ; N lozenge ; B 145 0 614 740 ;
+C -1 ; WX 600 ; N Rcaron ; B 24 0 659 790 ;
+C -1 ; WX 600 ; N Gcommaaccent ; B 74 -250 675 580 ;
+C -1 ; WX 600 ; N ucircumflex ; B 70 -15 597 657 ;
+C -1 ; WX 600 ; N acircumflex ; B 61 -15 607 657 ;
+C -1 ; WX 600 ; N Amacron ; B -9 0 633 708 ;
+C -1 ; WX 600 ; N rcaron ; B 47 0 655 667 ;
+C -1 ; WX 600 ; N ccedilla ; B 81 -206 631 459 ;
+C -1 ; WX 600 ; N Zdotaccent ; B 62 0 637 761 ;
+C -1 ; WX 600 ; N Thorn ; B 48 0 620 562 ;
+C -1 ; WX 600 ; N Omacron ; B 74 -18 663 708 ;
+C -1 ; WX 600 ; N Racute ; B 24 0 665 784 ;
+C -1 ; WX 600 ; N Sacute ; B 54 -22 673 784 ;
+C -1 ; WX 600 ; N dcaron ; B 60 -15 861 626 ;
+C -1 ; WX 600 ; N Umacron ; B 101 -18 716 708 ;
+C -1 ; WX 600 ; N uring ; B 70 -15 592 678 ;
+C -1 ; WX 600 ; N threesuperior ; B 193 222 526 616 ;
+C -1 ; WX 600 ; N Ograve ; B 74 -18 645 784 ;
+C -1 ; WX 600 ; N Agrave ; B -9 0 632 784 ;
+C -1 ; WX 600 ; N Abreve ; B -9 0 684 784 ;
+C -1 ; WX 600 ; N multiply ; B 104 39 606 478 ;
+C -1 ; WX 600 ; N uacute ; B 70 -15 599 661 ;
+C -1 ; WX 600 ; N Tcaron ; B 86 0 679 790 ;
+C -1 ; WX 600 ; N partialdiff ; B 91 -38 627 728 ;
+C -1 ; WX 600 ; N ydieresis ; B -21 -142 695 638 ;
+C -1 ; WX 600 ; N Nacute ; B 8 -12 730 784 ;
+C -1 ; WX 600 ; N icircumflex ; B 77 0 577 657 ;
+C -1 ; WX 600 ; N Ecircumflex ; B 25 0 670 780 ;
+C -1 ; WX 600 ; N adieresis ; B 61 -15 595 638 ;
+C -1 ; WX 600 ; N edieresis ; B 81 -15 605 638 ;
+C -1 ; WX 600 ; N cacute ; B 81 -15 649 661 ;
+C -1 ; WX 600 ; N nacute ; B 18 0 639 661 ;
+C -1 ; WX 600 ; N umacron ; B 70 -15 637 585 ;
+C -1 ; WX 600 ; N Ncaron ; B 8 -12 730 790 ;
+C -1 ; WX 600 ; N Iacute ; B 77 0 643 784 ;
+C -1 ; WX 600 ; N plusminus ; B 76 24 614 515 ;
+C -1 ; WX 600 ; N brokenbar ; B 217 -175 489 675 ;
+C -1 ; WX 600 ; N registered ; B 53 -18 667 580 ;
+C -1 ; WX 600 ; N Gbreve ; B 74 -18 684 784 ;
+C -1 ; WX 600 ; N Idotaccent ; B 77 0 643 761 ;
+C -1 ; WX 600 ; N summation ; B 15 -10 672 706 ;
+C -1 ; WX 600 ; N Egrave ; B 25 0 670 784 ;
+C -1 ; WX 600 ; N racute ; B 47 0 655 661 ;
+C -1 ; WX 600 ; N omacron ; B 71 -15 637 585 ;
+C -1 ; WX 600 ; N Zacute ; B 62 0 665 784 ;
+C -1 ; WX 600 ; N Zcaron ; B 62 0 659 790 ;
+C -1 ; WX 600 ; N greaterequal ; B 26 0 627 696 ;
+C -1 ; WX 600 ; N Eth ; B 30 0 664 562 ;
+C -1 ; WX 600 ; N Ccedilla ; B 74 -206 675 580 ;
+C -1 ; WX 600 ; N lcommaaccent ; B 77 -250 546 626 ;
+C -1 ; WX 600 ; N tcaron ; B 118 -15 627 703 ;
+C -1 ; WX 600 ; N eogonek ; B 81 -199 605 454 ;
+C -1 ; WX 600 ; N Uogonek ; B 101 -199 716 562 ;
+C -1 ; WX 600 ; N Aacute ; B -9 0 655 784 ;
+C -1 ; WX 600 ; N Adieresis ; B -9 0 632 761 ;
+C -1 ; WX 600 ; N egrave ; B 81 -15 605 661 ;
+C -1 ; WX 600 ; N zacute ; B 81 0 614 661 ;
+C -1 ; WX 600 ; N iogonek ; B 77 -199 546 658 ;
+C -1 ; WX 600 ; N Oacute ; B 74 -18 645 784 ;
+C -1 ; WX 600 ; N oacute ; B 71 -15 649 661 ;
+C -1 ; WX 600 ; N amacron ; B 61 -15 637 585 ;
+C -1 ; WX 600 ; N sacute ; B 66 -17 609 661 ;
+C -1 ; WX 600 ; N idieresis ; B 77 0 561 618 ;
+C -1 ; WX 600 ; N Ocircumflex ; B 74 -18 645 780 ;
+C -1 ; WX 600 ; N Ugrave ; B 101 -18 716 784 ;
+C -1 ; WX 600 ; N thorn ; B -32 -142 622 626 ;
+C -1 ; WX 600 ; N twosuperior ; B 191 230 542 616 ;
+C -1 ; WX 600 ; N Odieresis ; B 74 -18 645 761 ;
+C -1 ; WX 600 ; N mu ; B 49 -142 592 439 ;
+C -1 ; WX 600 ; N igrave ; B 77 0 546 661 ;
+C -1 ; WX 600 ; N ohungarumlaut ; B 71 -15 809 661 ;
+C -1 ; WX 600 ; N Eogonek ; B 25 -199 670 562 ;
+C -1 ; WX 600 ; N dcroat ; B 60 -15 712 626 ;
+C -1 ; WX 600 ; N threequarters ; B 8 -60 699 661 ;
+C -1 ; WX 600 ; N Scedilla ; B 54 -206 673 582 ;
+C -1 ; WX 600 ; N lcaron ; B 77 0 731 626 ;
+C -1 ; WX 600 ; N Kcommaaccent ; B 21 -250 692 562 ;
+C -1 ; WX 600 ; N Lacute ; B 39 0 636 784 ;
+C -1 ; WX 600 ; N trademark ; B 86 230 869 562 ;
+C -1 ; WX 600 ; N edotaccent ; B 81 -15 605 638 ;
+C -1 ; WX 600 ; N Igrave ; B 77 0 643 784 ;
+C -1 ; WX 600 ; N Imacron ; B 77 0 663 708 ;
+C -1 ; WX 600 ; N Lcaron ; B 39 0 757 562 ;
+C -1 ; WX 600 ; N onehalf ; B 22 -60 716 661 ;
+C -1 ; WX 600 ; N lessequal ; B 26 0 671 696 ;
+C -1 ; WX 600 ; N ocircumflex ; B 71 -15 622 657 ;
+C -1 ; WX 600 ; N ntilde ; B 18 0 643 636 ;
+C -1 ; WX 600 ; N Uhungarumlaut ; B 101 -18 805 784 ;
+C -1 ; WX 600 ; N Eacute ; B 25 0 670 784 ;
+C -1 ; WX 600 ; N emacron ; B 81 -15 637 585 ;
+C -1 ; WX 600 ; N gbreve ; B 40 -146 674 661 ;
+C -1 ; WX 600 ; N onequarter ; B 13 -60 707 661 ;
+C -1 ; WX 600 ; N Scaron ; B 54 -22 689 790 ;
+C -1 ; WX 600 ; N Scommaaccent ; B 54 -250 673 582 ;
+C -1 ; WX 600 ; N Ohungarumlaut ; B 74 -18 795 784 ;
+C -1 ; WX 600 ; N degree ; B 173 243 570 616 ;
+C -1 ; WX 600 ; N ograve ; B 71 -15 622 661 ;
+C -1 ; WX 600 ; N Ccaron ; B 74 -18 689 790 ;
+C -1 ; WX 600 ; N ugrave ; B 70 -15 592 661 ;
+C -1 ; WX 600 ; N radical ; B 67 -104 635 778 ;
+C -1 ; WX 600 ; N Dcaron ; B 30 0 664 790 ;
+C -1 ; WX 600 ; N rcommaaccent ; B 47 -250 655 454 ;
+C -1 ; WX 600 ; N Ntilde ; B 8 -12 730 759 ;
+C -1 ; WX 600 ; N otilde ; B 71 -15 643 636 ;
+C -1 ; WX 600 ; N Rcommaaccent ; B 24 -250 617 562 ;
+C -1 ; WX 600 ; N Lcommaaccent ; B 39 -250 636 562 ;
+C -1 ; WX 600 ; N Atilde ; B -9 0 669 759 ;
+C -1 ; WX 600 ; N Aogonek ; B -9 -199 632 562 ;
+C -1 ; WX 600 ; N Aring ; B -9 0 632 801 ;
+C -1 ; WX 600 ; N Otilde ; B 74 -18 669 759 ;
+C -1 ; WX 600 ; N zdotaccent ; B 81 0 614 638 ;
+C -1 ; WX 600 ; N Ecaron ; B 25 0 670 790 ;
+C -1 ; WX 600 ; N Iogonek ; B 77 -199 643 562 ;
+C -1 ; WX 600 ; N kcommaaccent ; B 33 -250 643 626 ;
+C -1 ; WX 600 ; N minus ; B 114 203 596 313 ;
+C -1 ; WX 600 ; N Icircumflex ; B 77 0 643 780 ;
+C -1 ; WX 600 ; N ncaron ; B 18 0 633 667 ;
+C -1 ; WX 600 ; N tcommaaccent ; B 118 -250 567 562 ;
+C -1 ; WX 600 ; N logicalnot ; B 135 103 617 413 ;
+C -1 ; WX 600 ; N odieresis ; B 71 -15 622 638 ;
+C -1 ; WX 600 ; N udieresis ; B 70 -15 595 638 ;
+C -1 ; WX 600 ; N notequal ; B 30 -47 626 563 ;
+C -1 ; WX 600 ; N gcommaaccent ; B 40 -146 674 714 ;
+C -1 ; WX 600 ; N eth ; B 93 -27 661 626 ;
+C -1 ; WX 600 ; N zcaron ; B 81 0 643 667 ;
+C -1 ; WX 600 ; N ncommaaccent ; B 18 -250 615 454 ;
+C -1 ; WX 600 ; N onesuperior ; B 212 230 514 616 ;
+C -1 ; WX 600 ; N imacron ; B 77 0 575 585 ;
+EndCharMetrics
+EndFontMetrics
Added: trunk/mapbender/http/classes/fonts/Courier.afm
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/fonts/Courier.afm?view=auto&rev=13
--- (empty file)
+++ trunk/mapbender/http/classes/fonts/Courier.afm 2006-04-13 19:38:28+0000
@@ -0,0 +1,342 @@
+Comment Copyright (c) 1989, 1990, 1991, 1992, 1993, 1997 Adobe Systems Incorporated. All Rights Reserved.
+Comment Creation Date: Thu May 1 17:27:09 1997
+Comment UniqueID 43050
+Comment VMusage 39754 50779
+FontName Courier
+FullName Courier
+FamilyName Courier
+Weight Medium
+ItalicAngle 0
+IsFixedPitch true
+FontBBox -23 -250 715 805
+Version 003.000
+Notice Copyright (c) 1989, 1990, 1991, 1992, 1993, 1997 Adobe Systems Incorporated. All Rights Reserved.
+CapHeight 562
+XHeight 426
+Ascender 629
+Descender -157
+StdHW 51
+StdVW 51
+C 33 ; WX 600 ; N exclam ; B 236 -15 364 572 ;
+C 34 ; WX 600 ; N quotedbl ; B 187 328 413 562 ;
+C 35 ; WX 600 ; N numbersign ; B 93 -32 507 639 ;
+C 36 ; WX 600 ; N dollar ; B 105 -126 496 662 ;
+C 37 ; WX 600 ; N percent ; B 81 -15 518 622 ;
+C 38 ; WX 600 ; N ampersand ; B 63 -15 538 543 ;
+C 39 ; WX 600 ; N quoteright ; B 213 328 376 562 ;
+C 40 ; WX 600 ; N parenleft ; B 269 -108 440 622 ;
+C 41 ; WX 600 ; N parenright ; B 160 -108 331 622 ;
+C 42 ; WX 600 ; N asterisk ; B 116 257 484 607 ;
+C 43 ; WX 600 ; N plus ; B 80 44 520 470 ;
+C 44 ; WX 600 ; N comma ; B 181 -112 344 122 ;
+C 45 ; WX 600 ; N hyphen ; B 103 231 497 285 ;
+C 46 ; WX 600 ; N period ; B 229 -15 371 109 ;
+C 47 ; WX 600 ; N slash ; B 125 -80 475 629 ;
+C 48 ; WX 600 ; N zero ; B 106 -15 494 622 ;
+C 49 ; WX 600 ; N one ; B 96 0 505 622 ;
+C 50 ; WX 600 ; N two ; B 70 0 471 622 ;
+C 51 ; WX 600 ; N three ; B 75 -15 466 622 ;
+C 52 ; WX 600 ; N four ; B 78 0 500 622 ;
+C 53 ; WX 600 ; N five ; B 92 -15 497 607 ;
+C 54 ; WX 600 ; N six ; B 111 -15 497 622 ;
+C 55 ; WX 600 ; N seven ; B 82 0 483 607 ;
+C 56 ; WX 600 ; N eight ; B 102 -15 498 622 ;
+C 57 ; WX 600 ; N nine ; B 96 -15 489 622 ;
+C 58 ; WX 600 ; N colon ; B 229 -15 371 385 ;
+C 59 ; WX 600 ; N semicolon ; B 181 -112 371 385 ;
+C 60 ; WX 600 ; N less ; B 41 42 519 472 ;
+C 61 ; WX 600 ; N equal ; B 80 138 520 376 ;
+C 62 ; WX 600 ; N greater ; B 66 42 544 472 ;
+C 63 ; WX 600 ; N question ; B 129 -15 492 572 ;
+C 64 ; WX 600 ; N at ; B 77 -15 533 622 ;
+C 65 ; WX 600 ; N A ; B 3 0 597 562 ;
+C 66 ; WX 600 ; N B ; B 43 0 559 562 ;
+C 67 ; WX 600 ; N C ; B 41 -18 540 580 ;
+C 68 ; WX 600 ; N D ; B 43 0 574 562 ;
+C 69 ; WX 600 ; N E ; B 53 0 550 562 ;
+C 70 ; WX 600 ; N F ; B 53 0 545 562 ;
+C 71 ; WX 600 ; N G ; B 31 -18 575 580 ;
+C 72 ; WX 600 ; N H ; B 32 0 568 562 ;
+C 73 ; WX 600 ; N I ; B 96 0 504 562 ;
+C 74 ; WX 600 ; N J ; B 34 -18 566 562 ;
+C 75 ; WX 600 ; N K ; B 38 0 582 562 ;
+C 76 ; WX 600 ; N L ; B 47 0 554 562 ;
+C 77 ; WX 600 ; N M ; B 4 0 596 562 ;
+C 78 ; WX 600 ; N N ; B 7 -13 593 562 ;
+C 79 ; WX 600 ; N O ; B 43 -18 557 580 ;
+C 80 ; WX 600 ; N P ; B 79 0 558 562 ;
+C 81 ; WX 600 ; N Q ; B 43 -138 557 580 ;
+C 82 ; WX 600 ; N R ; B 38 0 588 562 ;
+C 83 ; WX 600 ; N S ; B 72 -20 529 580 ;
+C 84 ; WX 600 ; N T ; B 38 0 563 562 ;
+C 85 ; WX 600 ; N U ; B 17 -18 583 562 ;
+C 86 ; WX 600 ; N V ; B -4 -13 604 562 ;
+C 87 ; WX 600 ; N W ; B -3 -13 603 562 ;
+C 88 ; WX 600 ; N X ; B 23 0 577 562 ;
+C 89 ; WX 600 ; N Y ; B 24 0 576 562 ;
+C 90 ; WX 600 ; N Z ; B 86 0 514 562 ;
+C 91 ; WX 600 ; N bracketleft ; B 269 -108 442 622 ;
+C 92 ; WX 600 ; N backslash ; B 118 -80 482 629 ;
+C 93 ; WX 600 ; N bracketright ; B 158 -108 331 622 ;
+C 94 ; WX 600 ; N asciicircum ; B 94 354 506 622 ;
+C 96 ; WX 600 ; N quoteleft ; B 224 328 387 562 ;
+C 97 ; WX 600 ; N a ; B 53 -15 559 441 ;
+C 98 ; WX 600 ; N b ; B 14 -15 575 629 ;
+C 99 ; WX 600 ; N c ; B 66 -15 529 441 ;
+C 100 ; WX 600 ; N d ; B 45 -15 591 629 ;
+C 101 ; WX 600 ; N e ; B 66 -15 548 441 ;
+C 102 ; WX 600 ; N f ; B 114 0 531 629 ; L i fi ; L l fl ;
+C 103 ; WX 600 ; N g ; B 45 -157 566 441 ;
+C 104 ; WX 600 ; N h ; B 18 0 582 629 ;
+C 105 ; WX 600 ; N i ; B 95 0 505 657 ;
+C 106 ; WX 600 ; N j ; B 82 -157 410 657 ;
+C 107 ; WX 600 ; N k ; B 43 0 580 629 ;
+C 108 ; WX 600 ; N l ; B 95 0 505 629 ;
+C 109 ; WX 600 ; N m ; B -5 0 605 441 ;
+C 110 ; WX 600 ; N n ; B 26 0 575 441 ;
+C 111 ; WX 600 ; N o ; B 62 -15 538 441 ;
+C 112 ; WX 600 ; N p ; B 9 -157 555 441 ;
+C 113 ; WX 600 ; N q ; B 45 -157 591 441 ;
+C 114 ; WX 600 ; N r ; B 60 0 559 441 ;
+C 115 ; WX 600 ; N s ; B 80 -15 513 441 ;
+C 116 ; WX 600 ; N t ; B 87 -15 530 561 ;
+C 117 ; WX 600 ; N u ; B 21 -15 562 426 ;
+C 118 ; WX 600 ; N v ; B 10 -10 590 426 ;
+C 119 ; WX 600 ; N w ; B -4 -10 604 426 ;
+C 120 ; WX 600 ; N x ; B 20 0 580 426 ;
+C 121 ; WX 600 ; N y ; B 7 -157 592 426 ;
+C 122 ; WX 600 ; N z ; B 99 0 502 426 ;
+C 123 ; WX 600 ; N braceleft ; B 182 -108 437 622 ;
+C 124 ; WX 600 ; N bar ; B 275 -250 326 750 ;
+C 125 ; WX 600 ; N braceright ; B 163 -108 418 622 ;
+C 126 ; WX 600 ; N asciitilde ; B 63 197 540 320 ;
+C 161 ; WX 600 ; N exclamdown ; B 236 -157 364 430 ;
+C 162 ; WX 600 ; N cent ; B 96 -49 500 614 ;
+C 163 ; WX 600 ; N sterling ; B 84 -21 521 611 ;
+C 164 ; WX 600 ; N fraction ; B 92 -57 509 665 ;
+C 165 ; WX 600 ; N yen ; B 26 0 574 562 ;
+C 166 ; WX 600 ; N florin ; B 4 -143 539 622 ;
+C 167 ; WX 600 ; N section ; B 113 -78 488 580 ;
+C 168 ; WX 600 ; N currency ; B 73 58 527 506 ;
+C 169 ; WX 600 ; N quotesingle ; B 259 328 341 562 ;
+C 170 ; WX 600 ; N quotedblleft ; B 143 328 471 562 ;
+C 171 ; WX 600 ; N guillemotleft ; B 37 70 563 446 ;
+C 172 ; WX 600 ; N guilsinglleft ; B 149 70 451 446 ;
+C 173 ; WX 600 ; N guilsinglright ; B 149 70 451 446 ;
+C 174 ; WX 600 ; N fi ; B 3 0 597 629 ;
+C 175 ; WX 600 ; N fl ; B 3 0 597 629 ;
+C 177 ; WX 600 ; N endash ; B 75 231 525 285 ;
+C 178 ; WX 600 ; N dagger ; B 141 -78 459 580 ;
+C 179 ; WX 600 ; N daggerdbl ; B 141 -78 459 580 ;
+C 180 ; WX 600 ; N periodcentered ; B 222 189 378 327 ;
+C 182 ; WX 600 ; N paragraph ; B 50 -78 511 562 ;
+C 183 ; WX 600 ; N bullet ; B 172 130 428 383 ;
+C 184 ; WX 600 ; N quotesinglbase ; B 213 -134 376 100 ;
+C 185 ; WX 600 ; N quotedblbase ; B 143 -134 457 100 ;
+C 186 ; WX 600 ; N quotedblright ; B 143 328 457 562 ;
+C 187 ; WX 600 ; N guillemotright ; B 37 70 563 446 ;
+C 188 ; WX 600 ; N ellipsis ; B 37 -15 563 111 ;
+C 189 ; WX 600 ; N perthousand ; B 3 -15 600 622 ;
+C 191 ; WX 600 ; N questiondown ; B 108 -157 471 430 ;
+C 193 ; WX 600 ; N grave ; B 151 497 378 672 ;
+C 194 ; WX 600 ; N acute ; B 242 497 469 672 ;
+C 195 ; WX 600 ; N circumflex ; B 124 477 476 654 ;
+C 196 ; WX 600 ; N tilde ; B 105 489 503 606 ;
+C 197 ; WX 600 ; N macron ; B 120 525 480 565 ;
+C 198 ; WX 600 ; N breve ; B 153 501 447 609 ;
+C 199 ; WX 600 ; N dotaccent ; B 249 537 352 640 ;
+C 200 ; WX 600 ; N dieresis ; B 148 537 453 640 ;
+C 202 ; WX 600 ; N ring ; B 218 463 382 627 ;
+C 203 ; WX 600 ; N cedilla ; B 224 -151 362 10 ;
+C 205 ; WX 600 ; N hungarumlaut ; B 133 497 540 672 ;
+C 206 ; WX 600 ; N ogonek ; B 211 -172 407 4 ;
+C 207 ; WX 600 ; N caron ; B 124 492 476 669 ;
+C 208 ; WX 600 ; N emdash ; B 0 231 600 285 ;
+C 225 ; WX 600 ; N AE ; B 3 0 550 562 ;
+C 227 ; WX 600 ; N ordfeminine ; B 156 249 442 580 ;
+C 232 ; WX 600 ; N Lslash ; B 47 0 554 562 ;
+C 233 ; WX 600 ; N Oslash ; B 43 -80 557 629 ;
+C 234 ; WX 600 ; N OE ; B 7 0 567 562 ;
+C 235 ; WX 600 ; N ordmasculine ; B 157 249 443 580 ;
+C 241 ; WX 600 ; N ae ; B 19 -15 570 441 ;
+C 245 ; WX 600 ; N dotlessi ; B 95 0 505 426 ;
+C 248 ; WX 600 ; N lslash ; B 95 0 505 629 ;
+C 249 ; WX 600 ; N oslash ; B 62 -80 538 506 ;
+C 250 ; WX 600 ; N oe ; B 19 -15 559 441 ;
+C 251 ; WX 600 ; N germandbls ; B 48 -15 588 629 ;
+C -1 ; WX 600 ; N Idieresis ; B 96 0 504 753 ;
+C -1 ; WX 600 ; N eacute ; B 66 -15 548 672 ;
+C -1 ; WX 600 ; N abreve ; B 53 -15 559 609 ;
+C -1 ; WX 600 ; N uhungarumlaut ; B 21 -15 580 672 ;
+C -1 ; WX 600 ; N ecaron ; B 66 -15 548 669 ;
+C -1 ; WX 600 ; N Ydieresis ; B 24 0 576 753 ;
+C -1 ; WX 600 ; N divide ; B 87 48 513 467 ;
+C -1 ; WX 600 ; N Yacute ; B 24 0 576 805 ;
+C -1 ; WX 600 ; N Acircumflex ; B 3 0 597 787 ;
+C -1 ; WX 600 ; N aacute ; B 53 -15 559 672 ;
+C -1 ; WX 600 ; N Ucircumflex ; B 17 -18 583 787 ;
+C -1 ; WX 600 ; N yacute ; B 7 -157 592 672 ;
+C -1 ; WX 600 ; N scommaaccent ; B 80 -250 513 441 ;
+C -1 ; WX 600 ; N ecircumflex ; B 66 -15 548 654 ;
+C -1 ; WX 600 ; N Uring ; B 17 -18 583 760 ;
+C -1 ; WX 600 ; N Udieresis ; B 17 -18 583 753 ;
+C -1 ; WX 600 ; N aogonek ; B 53 -172 587 441 ;
+C -1 ; WX 600 ; N Uacute ; B 17 -18 583 805 ;
+C -1 ; WX 600 ; N uogonek ; B 21 -172 590 426 ;
+C -1 ; WX 600 ; N Edieresis ; B 53 0 550 753 ;
+C -1 ; WX 600 ; N Dcroat ; B 30 0 574 562 ;
+C -1 ; WX 600 ; N commaaccent ; B 198 -250 335 -58 ;
+C -1 ; WX 600 ; N Emacron ; B 53 0 550 698 ;
+C -1 ; WX 600 ; N ccaron ; B 66 -15 529 669 ;
+C -1 ; WX 600 ; N aring ; B 53 -15 559 627 ;
+C -1 ; WX 600 ; N Ncommaaccent ; B 7 -250 593 562 ;
+C -1 ; WX 600 ; N lacute ; B 95 0 505 805 ;
+C -1 ; WX 600 ; N agrave ; B 53 -15 559 672 ;
+C -1 ; WX 600 ; N Tcommaaccent ; B 38 -250 563 562 ;
+C -1 ; WX 600 ; N Cacute ; B 41 -18 540 805 ;
+C -1 ; WX 600 ; N atilde ; B 53 -15 559 606 ;
+C -1 ; WX 600 ; N Edotaccent ; B 53 0 550 753 ;
+C -1 ; WX 600 ; N scaron ; B 80 -15 513 669 ;
+C -1 ; WX 600 ; N scedilla ; B 80 -151 513 441 ;
+C -1 ; WX 600 ; N iacute ; B 95 0 505 672 ;
+C -1 ; WX 600 ; N lozenge ; B 18 0 443 706 ;
+C -1 ; WX 600 ; N Rcaron ; B 38 0 588 802 ;
+C -1 ; WX 600 ; N Gcommaaccent ; B 31 -250 575 580 ;
+C -1 ; WX 600 ; N ucircumflex ; B 21 -15 562 654 ;
+C -1 ; WX 600 ; N acircumflex ; B 53 -15 559 654 ;
+C -1 ; WX 600 ; N Amacron ; B 3 0 597 698 ;
+C -1 ; WX 600 ; N rcaron ; B 60 0 559 669 ;
+C -1 ; WX 600 ; N ccedilla ; B 66 -151 529 441 ;
+C -1 ; WX 600 ; N Zdotaccent ; B 86 0 514 753 ;
+C -1 ; WX 600 ; N Thorn ; B 79 0 538 562 ;
+C -1 ; WX 600 ; N Omacron ; B 43 -18 557 698 ;
+C -1 ; WX 600 ; N Racute ; B 38 0 588 805 ;
+C -1 ; WX 600 ; N Sacute ; B 72 -20 529 805 ;
+C -1 ; WX 600 ; N dcaron ; B 45 -15 715 629 ;
+C -1 ; WX 600 ; N Umacron ; B 17 -18 583 698 ;
+C -1 ; WX 600 ; N uring ; B 21 -15 562 627 ;
+C -1 ; WX 600 ; N threesuperior ; B 155 240 406 622 ;
+C -1 ; WX 600 ; N Ograve ; B 43 -18 557 805 ;
+C -1 ; WX 600 ; N Agrave ; B 3 0 597 805 ;
+C -1 ; WX 600 ; N Abreve ; B 3 0 597 732 ;
+C -1 ; WX 600 ; N multiply ; B 87 43 515 470 ;
+C -1 ; WX 600 ; N uacute ; B 21 -15 562 672 ;
+C -1 ; WX 600 ; N Tcaron ; B 38 0 563 802 ;
+C -1 ; WX 600 ; N partialdiff ; B 17 -38 459 710 ;
+C -1 ; WX 600 ; N ydieresis ; B 7 -157 592 620 ;
+C -1 ; WX 600 ; N Nacute ; B 7 -13 593 805 ;
+C -1 ; WX 600 ; N icircumflex ; B 94 0 505 654 ;
+C -1 ; WX 600 ; N Ecircumflex ; B 53 0 550 787 ;
+C -1 ; WX 600 ; N adieresis ; B 53 -15 559 620 ;
+C -1 ; WX 600 ; N edieresis ; B 66 -15 548 620 ;
+C -1 ; WX 600 ; N cacute ; B 66 -15 529 672 ;
+C -1 ; WX 600 ; N nacute ; B 26 0 575 672 ;
+C -1 ; WX 600 ; N umacron ; B 21 -15 562 565 ;
+C -1 ; WX 600 ; N Ncaron ; B 7 -13 593 802 ;
+C -1 ; WX 600 ; N Iacute ; B 96 0 504 805 ;
+C -1 ; WX 600 ; N plusminus ; B 87 44 513 558 ;
+C -1 ; WX 600 ; N brokenbar ; B 275 -175 326 675 ;
+C -1 ; WX 600 ; N Gbreve ; B 31 -18 575 732 ;
+C -1 ; WX 600 ; N Idotaccent ; B 96 0 504 753 ;
+C -1 ; WX 600 ; N summation ; B 15 -10 585 706 ;
+C -1 ; WX 600 ; N Egrave ; B 53 0 550 805 ;
+C -1 ; WX 600 ; N racute ; B 60 0 559 672 ;
+C -1 ; WX 600 ; N omacron ; B 62 -15 538 565 ;
+C -1 ; WX 600 ; N Zacute ; B 86 0 514 805 ;
+C -1 ; WX 600 ; N Zcaron ; B 86 0 514 802 ;
+C -1 ; WX 600 ; N greaterequal ; B 98 0 502 710 ;
+C -1 ; WX 600 ; N Eth ; B 30 0 574 562 ;
+C -1 ; WX 600 ; N Ccedilla ; B 41 -151 540 580 ;
+C -1 ; WX 600 ; N lcommaaccent ; B 95 -250 505 629 ;
+C -1 ; WX 600 ; N tcaron ; B 87 -15 530 717 ;
+C -1 ; WX 600 ; N eogonek ; B 66 -172 548 441 ;
+C -1 ; WX 600 ; N Uogonek ; B 17 -172 583 562 ;
+C -1 ; WX 600 ; N Aacute ; B 3 0 597 805 ;
+C -1 ; WX 600 ; N Adieresis ; B 3 0 597 753 ;
+C -1 ; WX 600 ; N egrave ; B 66 -15 548 672 ;
+C -1 ; WX 600 ; N zacute ; B 99 0 502 672 ;
+C -1 ; WX 600 ; N iogonek ; B 95 -172 505 657 ;
+C -1 ; WX 600 ; N Oacute ; B 43 -18 557 805 ;
+C -1 ; WX 600 ; N oacute ; B 62 -15 538 672 ;
+C -1 ; WX 600 ; N amacron ; B 53 -15 559 565 ;
+C -1 ; WX 600 ; N sacute ; B 80 -15 513 672 ;
+C -1 ; WX 600 ; N idieresis ; B 95 0 505 620 ;
+C -1 ; WX 600 ; N Ocircumflex ; B 43 -18 557 787 ;
+C -1 ; WX 600 ; N Ugrave ; B 17 -18 583 805 ;
+C -1 ; WX 600 ; N Delta ; B 6 0 598 688 ;
+C -1 ; WX 600 ; N thorn ; B -6 -157 555 629 ;
+C -1 ; WX 600 ; N twosuperior ; B 177 249 424 622 ;
+C -1 ; WX 600 ; N Odieresis ; B 43 -18 557 753 ;
+C -1 ; WX 600 ; N mu ; B 21 -157 562 426 ;
+C -1 ; WX 600 ; N igrave ; B 95 0 505 672 ;
+C -1 ; WX 600 ; N ohungarumlaut ; B 62 -15 580 672 ;
+C -1 ; WX 600 ; N Eogonek ; B 53 -172 561 562 ;
+C -1 ; WX 600 ; N dcroat ; B 45 -15 591 629 ;
+C -1 ; WX 600 ; N threequarters ; B 8 -56 593 666 ;
+C -1 ; WX 600 ; N Scedilla ; B 72 -151 529 580 ;
+C -1 ; WX 600 ; N lcaron ; B 95 0 533 629 ;
+C -1 ; WX 600 ; N Kcommaaccent ; B 38 -250 582 562 ;
+C -1 ; WX 600 ; N Lacute ; B 47 0 554 805 ;
+C -1 ; WX 600 ; N trademark ; B -23 263 623 562 ;
+C -1 ; WX 600 ; N edotaccent ; B 66 -15 548 620 ;
+C -1 ; WX 600 ; N Igrave ; B 96 0 504 805 ;
+C -1 ; WX 600 ; N Imacron ; B 96 0 504 698 ;
+C -1 ; WX 600 ; N Lcaron ; B 47 0 554 562 ;
+C -1 ; WX 600 ; N onehalf ; B 0 -57 611 665 ;
+C -1 ; WX 600 ; N lessequal ; B 98 0 502 710 ;
+C -1 ; WX 600 ; N ocircumflex ; B 62 -15 538 654 ;
+C -1 ; WX 600 ; N ntilde ; B 26 0 575 606 ;
+C -1 ; WX 600 ; N Uhungarumlaut ; B 17 -18 590 805 ;
+C -1 ; WX 600 ; N Eacute ; B 53 0 550 805 ;
+C -1 ; WX 600 ; N emacron ; B 66 -15 548 565 ;
+C -1 ; WX 600 ; N gbreve ; B 45 -157 566 609 ;
+C -1 ; WX 600 ; N onequarter ; B 0 -57 600 665 ;
+C -1 ; WX 600 ; N Scaron ; B 72 -20 529 802 ;
+C -1 ; WX 600 ; N Scommaaccent ; B 72 -250 529 580 ;
+C -1 ; WX 600 ; N Ohungarumlaut ; B 43 -18 580 805 ;
+C -1 ; WX 600 ; N degree ; B 123 269 477 622 ;
+C -1 ; WX 600 ; N ograve ; B 62 -15 538 672 ;
+C -1 ; WX 600 ; N Ccaron ; B 41 -18 540 802 ;
+C -1 ; WX 600 ; N ugrave ; B 21 -15 562 672 ;
+C -1 ; WX 600 ; N radical ; B 3 -15 597 792 ;
+C -1 ; WX 600 ; N Dcaron ; B 43 0 574 802 ;
+C -1 ; WX 600 ; N rcommaaccent ; B 60 -250 559 441 ;
+C -1 ; WX 600 ; N Ntilde ; B 7 -13 593 729 ;
+C -1 ; WX 600 ; N otilde ; B 62 -15 538 606 ;
+C -1 ; WX 600 ; N Rcommaaccent ; B 38 -250 588 562 ;
+C -1 ; WX 600 ; N Lcommaaccent ; B 47 -250 554 562 ;
+C -1 ; WX 600 ; N Atilde ; B 3 0 597 729 ;
+C -1 ; WX 600 ; N Aogonek ; B 3 -172 608 562 ;
+C -1 ; WX 600 ; N Aring ; B 3 0 597 750 ;
+C -1 ; WX 600 ; N Otilde ; B 43 -18 557 729 ;
+C -1 ; WX 600 ; N zdotaccent ; B 99 0 502 620 ;
+C -1 ; WX 600 ; N Ecaron ; B 53 0 550 802 ;
+C -1 ; WX 600 ; N Iogonek ; B 96 -172 504 562 ;
+C -1 ; WX 600 ; N kcommaaccent ; B 43 -250 580 629 ;
+C -1 ; WX 600 ; N minus ; B 80 232 520 283 ;
+C -1 ; WX 600 ; N Icircumflex ; B 96 0 504 787 ;
+C -1 ; WX 600 ; N ncaron ; B 26 0 575 669 ;
+C -1 ; WX 600 ; N tcommaaccent ; B 87 -250 530 561 ;
+C -1 ; WX 600 ; N logicalnot ; B 87 108 513 369 ;
+C -1 ; WX 600 ; N odieresis ; B 62 -15 538 620 ;
+C -1 ; WX 600 ; N udieresis ; B 21 -15 562 620 ;
+C -1 ; WX 600 ; N notequal ; B 15 -16 540 529 ;
+C -1 ; WX 600 ; N gcommaaccent ; B 45 -157 566 708 ;
+C -1 ; WX 600 ; N eth ; B 62 -15 538 629 ;
+C -1 ; WX 600 ; N zcaron ; B 99 0 502 669 ;
+C -1 ; WX 600 ; N ncommaaccent ; B 26 -250 575 441 ;
+C -1 ; WX 600 ; N onesuperior ; B 172 249 428 622 ;
+C -1 ; WX 600 ; N imacron ; B 95 0 505 565 ;
+EndCharMetrics
+EndFontMetrics
Added: trunk/mapbender/http/classes/fonts/Helvetica-Bold.afm
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/fonts/Helvetica-Bold.afm?view=auto&rev=13
--- (empty file)
+++ trunk/mapbender/http/classes/fonts/Helvetica-Bold.afm 2006-04-13 19:38:28+0000
@@ -0,0 +1,2827 @@
+Comment Copyright (c) 1985, 1987, 1989, 1990, 1997 Adobe Systems Incorporated. All Rights Reserved.
+Comment Creation Date: Thu May 1 12:43:52 1997
+Comment UniqueID 43052
+Comment VMusage 37169 48194
+FontName Helvetica-Bold
+FullName Helvetica Bold
+FamilyName Helvetica
+Weight Bold
+ItalicAngle 0
+IsFixedPitch false
+FontBBox -170 -228 1003 962
+Version 002.000
+Notice Copyright (c) 1985, 1987, 1989, 1990, 1997 Adobe Systems Incorporated. All Rights Reserved.Helvetica is a trademark of Linotype-Hell AG and/or its subsidiaries.
+CapHeight 718
+XHeight 532
+Ascender 718
+Descender -207
+StdHW 118
+StdVW 140
+C 32 ; WX 278 ; N space ; B 0 0 0 0 ;
+C 33 ; WX 333 ; N exclam ; B 90 0 244 718 ;
+C 34 ; WX 474 ; N quotedbl ; B 98 447 376 718 ;
+C 35 ; WX 556 ; N numbersign ; B 18 0 538 698 ;
+C 36 ; WX 556 ; N dollar ; B 30 -115 523 775 ;
+C 37 ; WX 889 ; N percent ; B 28 -19 861 710 ;
+C 38 ; WX 722 ; N ampersand ; B 54 -19 701 718 ;
+C 39 ; WX 278 ; N quoteright ; B 69 445 209 718 ;
+C 40 ; WX 333 ; N parenleft ; B 35 -208 314 734 ;
+C 41 ; WX 333 ; N parenright ; B 19 -208 298 734 ;
+C 42 ; WX 389 ; N asterisk ; B 27 387 362 718 ;
+C 43 ; WX 584 ; N plus ; B 40 0 544 506 ;
+C 44 ; WX 278 ; N comma ; B 64 -168 214 146 ;
+C 45 ; WX 333 ; N hyphen ; B 27 215 306 345 ;
+C 46 ; WX 278 ; N period ; B 64 0 214 146 ;
+C 47 ; WX 278 ; N slash ; B -33 -19 311 737 ;
+C 48 ; WX 556 ; N zero ; B 32 -19 524 710 ;
+C 49 ; WX 556 ; N one ; B 69 0 378 710 ;
+C 50 ; WX 556 ; N two ; B 26 0 511 710 ;
+C 51 ; WX 556 ; N three ; B 27 -19 516 710 ;
+C 52 ; WX 556 ; N four ; B 27 0 526 710 ;
+C 53 ; WX 556 ; N five ; B 27 -19 516 698 ;
+C 54 ; WX 556 ; N six ; B 31 -19 520 710 ;
+C 55 ; WX 556 ; N seven ; B 25 0 528 698 ;
+C 56 ; WX 556 ; N eight ; B 32 -19 524 710 ;
+C 57 ; WX 556 ; N nine ; B 30 -19 522 710 ;
+C 58 ; WX 333 ; N colon ; B 92 0 242 512 ;
+C 59 ; WX 333 ; N semicolon ; B 92 -168 242 512 ;
+C 60 ; WX 584 ; N less ; B 38 -8 546 514 ;
+C 61 ; WX 584 ; N equal ; B 40 87 544 419 ;
+C 62 ; WX 584 ; N greater ; B 38 -8 546 514 ;
+C 63 ; WX 611 ; N question ; B 60 0 556 727 ;
+C 64 ; WX 975 ; N at ; B 118 -19 856 737 ;
+C 65 ; WX 722 ; N A ; B 20 0 702 718 ;
+C 66 ; WX 722 ; N B ; B 76 0 669 718 ;
+C 67 ; WX 722 ; N C ; B 44 -19 684 737 ;
+C 68 ; WX 722 ; N D ; B 76 0 685 718 ;
+C 69 ; WX 667 ; N E ; B 76 0 621 718 ;
+C 70 ; WX 611 ; N F ; B 76 0 587 718 ;
+C 71 ; WX 778 ; N G ; B 44 -19 713 737 ;
+C 72 ; WX 722 ; N H ; B 71 0 651 718 ;
+C 73 ; WX 278 ; N I ; B 64 0 214 718 ;
+C 74 ; WX 556 ; N J ; B 22 -18 484 718 ;
+C 75 ; WX 722 ; N K ; B 87 0 722 718 ;
+C 76 ; WX 611 ; N L ; B 76 0 583 718 ;
+C 77 ; WX 833 ; N M ; B 69 0 765 718 ;
+C 78 ; WX 722 ; N N ; B 69 0 654 718 ;
+C 79 ; WX 778 ; N O ; B 44 -19 734 737 ;
+C 80 ; WX 667 ; N P ; B 76 0 627 718 ;
+C 81 ; WX 778 ; N Q ; B 44 -52 737 737 ;
+C 82 ; WX 722 ; N R ; B 76 0 677 718 ;
+C 83 ; WX 667 ; N S ; B 39 -19 629 737 ;
+C 84 ; WX 611 ; N T ; B 14 0 598 718 ;
+C 85 ; WX 722 ; N U ; B 72 -19 651 718 ;
+C 86 ; WX 667 ; N V ; B 19 0 648 718 ;
+C 87 ; WX 944 ; N W ; B 16 0 929 718 ;
+C 88 ; WX 667 ; N X ; B 14 0 653 718 ;
+C 89 ; WX 667 ; N Y ; B 15 0 653 718 ;
+C 90 ; WX 611 ; N Z ; B 25 0 586 718 ;
+C 91 ; WX 333 ; N bracketleft ; B 63 -196 309 722 ;
+C 92 ; WX 278 ; N backslash ; B -33 -19 311 737 ;
+C 93 ; WX 333 ; N bracketright ; B 24 -196 270 722 ;
+C 94 ; WX 584 ; N asciicircum ; B 62 323 522 698 ;
+C 95 ; WX 556 ; N underscore ; B 0 -125 556 -75 ;
+C 96 ; WX 278 ; N quoteleft ; B 69 454 209 727 ;
+C 97 ; WX 556 ; N a ; B 29 -14 527 546 ;
+C 98 ; WX 611 ; N b ; B 61 -14 578 718 ;
+C 99 ; WX 556 ; N c ; B 34 -14 524 546 ;
+C 100 ; WX 611 ; N d ; B 34 -14 551 718 ;
+C 101 ; WX 556 ; N e ; B 23 -14 528 546 ;
+C 102 ; WX 333 ; N f ; B 10 0 318 727 ; L i fi ; L l fl ;
+C 103 ; WX 611 ; N g ; B 40 -217 553 546 ;
+C 104 ; WX 611 ; N h ; B 65 0 546 718 ;
+C 105 ; WX 278 ; N i ; B 69 0 209 725 ;
+C 106 ; WX 278 ; N j ; B 3 -214 209 725 ;
+C 107 ; WX 556 ; N k ; B 69 0 562 718 ;
+C 108 ; WX 278 ; N l ; B 69 0 209 718 ;
+C 109 ; WX 889 ; N m ; B 64 0 826 546 ;
+C 110 ; WX 611 ; N n ; B 65 0 546 546 ;
+C 111 ; WX 611 ; N o ; B 34 -14 578 546 ;
+C 112 ; WX 611 ; N p ; B 62 -207 578 546 ;
+C 113 ; WX 611 ; N q ; B 34 -207 552 546 ;
+C 114 ; WX 389 ; N r ; B 64 0 373 546 ;
+C 115 ; WX 556 ; N s ; B 30 -14 519 546 ;
+C 116 ; WX 333 ; N t ; B 10 -6 309 676 ;
+C 117 ; WX 611 ; N u ; B 66 -14 545 532 ;
+C 118 ; WX 556 ; N v ; B 13 0 543 532 ;
+C 119 ; WX 778 ; N w ; B 10 0 769 532 ;
+C 120 ; WX 556 ; N x ; B 15 0 541 532 ;
+C 121 ; WX 556 ; N y ; B 10 -214 539 532 ;
+C 122 ; WX 500 ; N z ; B 20 0 480 532 ;
+C 123 ; WX 389 ; N braceleft ; B 48 -196 365 722 ;
+C 124 ; WX 280 ; N bar ; B 84 -225 196 775 ;
+C 125 ; WX 389 ; N braceright ; B 24 -196 341 722 ;
+C 126 ; WX 584 ; N asciitilde ; B 61 163 523 343 ;
+C 161 ; WX 333 ; N exclamdown ; B 90 -186 244 532 ;
+C 162 ; WX 556 ; N cent ; B 34 -118 524 628 ;
+C 163 ; WX 556 ; N sterling ; B 28 -16 541 718 ;
+C 164 ; WX 167 ; N fraction ; B -170 -19 336 710 ;
+C 165 ; WX 556 ; N yen ; B -9 0 565 698 ;
+C 166 ; WX 556 ; N florin ; B -10 -210 516 737 ;
+C 167 ; WX 556 ; N section ; B 34 -184 522 727 ;
+C 168 ; WX 556 ; N currency ; B -3 76 559 636 ;
+C 169 ; WX 238 ; N quotesingle ; B 70 447 168 718 ;
+C 170 ; WX 500 ; N quotedblleft ; B 64 454 436 727 ;
+C 171 ; WX 556 ; N guillemotleft ; B 88 76 468 484 ;
+C 172 ; WX 333 ; N guilsinglleft ; B 83 76 250 484 ;
+C 173 ; WX 333 ; N guilsinglright ; B 83 76 250 484 ;
+C 174 ; WX 611 ; N fi ; B 10 0 542 727 ;
+C 175 ; WX 611 ; N fl ; B 10 0 542 727 ;
+C 177 ; WX 556 ; N endash ; B 0 227 556 333 ;
+C 178 ; WX 556 ; N dagger ; B 36 -171 520 718 ;
+C 179 ; WX 556 ; N daggerdbl ; B 36 -171 520 718 ;
+C 180 ; WX 278 ; N periodcentered ; B 58 172 220 334 ;
+C 182 ; WX 556 ; N paragraph ; B -8 -191 539 700 ;
+C 183 ; WX 350 ; N bullet ; B 10 194 340 524 ;
+C 184 ; WX 278 ; N quotesinglbase ; B 69 -146 209 127 ;
+C 185 ; WX 500 ; N quotedblbase ; B 64 -146 436 127 ;
+C 186 ; WX 500 ; N quotedblright ; B 64 445 436 718 ;
+C 187 ; WX 556 ; N guillemotright ; B 88 76 468 484 ;
+C 188 ; WX 1000 ; N ellipsis ; B 92 0 908 146 ;
+C 189 ; WX 1000 ; N perthousand ; B -3 -19 1003 710 ;
+C 191 ; WX 611 ; N questiondown ; B 55 -195 551 532 ;
+C 193 ; WX 333 ; N grave ; B -23 604 225 750 ;
+C 194 ; WX 333 ; N acute ; B 108 604 356 750 ;
+C 195 ; WX 333 ; N circumflex ; B -10 604 343 750 ;
+C 196 ; WX 333 ; N tilde ; B -17 610 350 737 ;
+C 197 ; WX 333 ; N macron ; B -6 604 339 678 ;
+C 198 ; WX 333 ; N breve ; B -2 604 335 750 ;
+C 199 ; WX 333 ; N dotaccent ; B 104 614 230 729 ;
+C 200 ; WX 333 ; N dieresis ; B 6 614 327 729 ;
+C 202 ; WX 333 ; N ring ; B 59 568 275 776 ;
+C 203 ; WX 333 ; N cedilla ; B 6 -228 245 0 ;
+C 205 ; WX 333 ; N hungarumlaut ; B 9 604 486 750 ;
+C 206 ; WX 333 ; N ogonek ; B 71 -228 304 0 ;
+C 207 ; WX 333 ; N caron ; B -10 604 343 750 ;
+C 208 ; WX 1000 ; N emdash ; B 0 227 1000 333 ;
+C 225 ; WX 1000 ; N AE ; B 5 0 954 718 ;
+C 227 ; WX 370 ; N ordfeminine ; B 22 401 347 737 ;
+C 232 ; WX 611 ; N Lslash ; B -20 0 583 718 ;
+C 233 ; WX 778 ; N Oslash ; B 33 -27 744 745 ;
+C 234 ; WX 1000 ; N OE ; B 37 -19 961 737 ;
+C 235 ; WX 365 ; N ordmasculine ; B 6 401 360 737 ;
+C 241 ; WX 889 ; N ae ; B 29 -14 858 546 ;
+C 245 ; WX 278 ; N dotlessi ; B 69 0 209 532 ;
+C 248 ; WX 278 ; N lslash ; B -18 0 296 718 ;
+C 249 ; WX 611 ; N oslash ; B 22 -29 589 560 ;
+C 250 ; WX 944 ; N oe ; B 34 -14 912 546 ;
+C 251 ; WX 611 ; N germandbls ; B 69 -14 579 731 ;
+C -1 ; WX 278 ; N Idieresis ; B -21 0 300 915 ;
+C -1 ; WX 556 ; N eacute ; B 23 -14 528 750 ;
+C -1 ; WX 556 ; N abreve ; B 29 -14 527 750 ;
+C -1 ; WX 611 ; N uhungarumlaut ; B 66 -14 625 750 ;
+C -1 ; WX 556 ; N ecaron ; B 23 -14 528 750 ;
+C -1 ; WX 667 ; N Ydieresis ; B 15 0 653 915 ;
+C -1 ; WX 584 ; N divide ; B 40 -42 544 548 ;
+C -1 ; WX 667 ; N Yacute ; B 15 0 653 936 ;
+C -1 ; WX 722 ; N Acircumflex ; B 20 0 702 936 ;
+C -1 ; WX 556 ; N aacute ; B 29 -14 527 750 ;
+C -1 ; WX 722 ; N Ucircumflex ; B 72 -19 651 936 ;
+C -1 ; WX 556 ; N yacute ; B 10 -214 539 750 ;
+C -1 ; WX 556 ; N scommaaccent ; B 30 -228 519 546 ;
+C -1 ; WX 556 ; N ecircumflex ; B 23 -14 528 750 ;
+C -1 ; WX 722 ; N Uring ; B 72 -19 651 962 ;
+C -1 ; WX 722 ; N Udieresis ; B 72 -19 651 915 ;
+C -1 ; WX 556 ; N aogonek ; B 29 -224 545 546 ;
+C -1 ; WX 722 ; N Uacute ; B 72 -19 651 936 ;
+C -1 ; WX 611 ; N uogonek ; B 66 -228 545 532 ;
+C -1 ; WX 667 ; N Edieresis ; B 76 0 621 915 ;
+C -1 ; WX 722 ; N Dcroat ; B -5 0 685 718 ;
+C -1 ; WX 250 ; N commaaccent ; B 64 -228 199 -50 ;
+C -1 ; WX 737 ; N copyright ; B -11 -19 749 737 ;
+C -1 ; WX 667 ; N Emacron ; B 76 0 621 864 ;
+C -1 ; WX 556 ; N ccaron ; B 34 -14 524 750 ;
+C -1 ; WX 556 ; N aring ; B 29 -14 527 776 ;
+C -1 ; WX 722 ; N Ncommaaccent ; B 69 -228 654 718 ;
+C -1 ; WX 278 ; N lacute ; B 69 0 329 936 ;
+C -1 ; WX 556 ; N agrave ; B 29 -14 527 750 ;
+C -1 ; WX 611 ; N Tcommaaccent ; B 14 -228 598 718 ;
+C -1 ; WX 722 ; N Cacute ; B 44 -19 684 936 ;
+C -1 ; WX 556 ; N atilde ; B 29 -14 527 737 ;
+C -1 ; WX 667 ; N Edotaccent ; B 76 0 621 915 ;
+C -1 ; WX 556 ; N scaron ; B 30 -14 519 750 ;
+C -1 ; WX 556 ; N scedilla ; B 30 -228 519 546 ;
+C -1 ; WX 278 ; N iacute ; B 69 0 329 750 ;
+C -1 ; WX 494 ; N lozenge ; B 10 0 484 745 ;
+C -1 ; WX 722 ; N Rcaron ; B 76 0 677 936 ;
+C -1 ; WX 778 ; N Gcommaaccent ; B 44 -228 713 737 ;
+C -1 ; WX 611 ; N ucircumflex ; B 66 -14 545 750 ;
+C -1 ; WX 556 ; N acircumflex ; B 29 -14 527 750 ;
+C -1 ; WX 722 ; N Amacron ; B 20 0 702 864 ;
+C -1 ; WX 389 ; N rcaron ; B 18 0 373 750 ;
+C -1 ; WX 556 ; N ccedilla ; B 34 -228 524 546 ;
+C -1 ; WX 611 ; N Zdotaccent ; B 25 0 586 915 ;
+C -1 ; WX 667 ; N Thorn ; B 76 0 627 718 ;
+C -1 ; WX 778 ; N Omacron ; B 44 -19 734 864 ;
+C -1 ; WX 722 ; N Racute ; B 76 0 677 936 ;
+C -1 ; WX 667 ; N Sacute ; B 39 -19 629 936 ;
+C -1 ; WX 743 ; N dcaron ; B 34 -14 750 718 ;
+C -1 ; WX 722 ; N Umacron ; B 72 -19 651 864 ;
+C -1 ; WX 611 ; N uring ; B 66 -14 545 776 ;
+C -1 ; WX 333 ; N threesuperior ; B 8 271 326 710 ;
+C -1 ; WX 778 ; N Ograve ; B 44 -19 734 936 ;
+C -1 ; WX 722 ; N Agrave ; B 20 0 702 936 ;
+C -1 ; WX 722 ; N Abreve ; B 20 0 702 936 ;
+C -1 ; WX 584 ; N multiply ; B 40 1 545 505 ;
+C -1 ; WX 611 ; N uacute ; B 66 -14 545 750 ;
+C -1 ; WX 611 ; N Tcaron ; B 14 0 598 936 ;
+C -1 ; WX 494 ; N partialdiff ; B 11 -21 494 750 ;
+C -1 ; WX 556 ; N ydieresis ; B 10 -214 539 729 ;
+C -1 ; WX 722 ; N Nacute ; B 69 0 654 936 ;
+C -1 ; WX 278 ; N icircumflex ; B -37 0 316 750 ;
+C -1 ; WX 667 ; N Ecircumflex ; B 76 0 621 936 ;
+C -1 ; WX 556 ; N adieresis ; B 29 -14 527 729 ;
+C -1 ; WX 556 ; N edieresis ; B 23 -14 528 729 ;
+C -1 ; WX 556 ; N cacute ; B 34 -14 524 750 ;
+C -1 ; WX 611 ; N nacute ; B 65 0 546 750 ;
+C -1 ; WX 611 ; N umacron ; B 66 -14 545 678 ;
+C -1 ; WX 722 ; N Ncaron ; B 69 0 654 936 ;
+C -1 ; WX 278 ; N Iacute ; B 64 0 329 936 ;
+C -1 ; WX 584 ; N plusminus ; B 40 0 544 506 ;
+C -1 ; WX 280 ; N brokenbar ; B 84 -150 196 700 ;
+C -1 ; WX 737 ; N registered ; B -11 -19 748 737 ;
+C -1 ; WX 778 ; N Gbreve ; B 44 -19 713 936 ;
+C -1 ; WX 278 ; N Idotaccent ; B 64 0 214 915 ;
+C -1 ; WX 600 ; N summation ; B 14 -10 585 706 ;
+C -1 ; WX 667 ; N Egrave ; B 76 0 621 936 ;
+C -1 ; WX 389 ; N racute ; B 64 0 384 750 ;
+C -1 ; WX 611 ; N omacron ; B 34 -14 578 678 ;
+C -1 ; WX 611 ; N Zacute ; B 25 0 586 936 ;
+C -1 ; WX 611 ; N Zcaron ; B 25 0 586 936 ;
+C -1 ; WX 549 ; N greaterequal ; B 26 0 523 704 ;
+C -1 ; WX 722 ; N Eth ; B -5 0 685 718 ;
+C -1 ; WX 722 ; N Ccedilla ; B 44 -228 684 737 ;
+C -1 ; WX 278 ; N lcommaaccent ; B 69 -228 213 718 ;
+C -1 ; WX 389 ; N tcaron ; B 10 -6 421 878 ;
+C -1 ; WX 556 ; N eogonek ; B 23 -228 528 546 ;
+C -1 ; WX 722 ; N Uogonek ; B 72 -228 651 718 ;
+C -1 ; WX 722 ; N Aacute ; B 20 0 702 936 ;
+C -1 ; WX 722 ; N Adieresis ; B 20 0 702 915 ;
+C -1 ; WX 556 ; N egrave ; B 23 -14 528 750 ;
+C -1 ; WX 500 ; N zacute ; B 20 0 480 750 ;
+C -1 ; WX 278 ; N iogonek ; B 16 -224 249 725 ;
+C -1 ; WX 778 ; N Oacute ; B 44 -19 734 936 ;
+C -1 ; WX 611 ; N oacute ; B 34 -14 578 750 ;
+C -1 ; WX 556 ; N amacron ; B 29 -14 527 678 ;
+C -1 ; WX 556 ; N sacute ; B 30 -14 519 750 ;
+C -1 ; WX 278 ; N idieresis ; B -21 0 300 729 ;
+C -1 ; WX 778 ; N Ocircumflex ; B 44 -19 734 936 ;
+C -1 ; WX 722 ; N Ugrave ; B 72 -19 651 936 ;
+C -1 ; WX 612 ; N Delta ; B 6 0 608 688 ;
+C -1 ; WX 611 ; N thorn ; B 62 -208 578 718 ;
+C -1 ; WX 333 ; N twosuperior ; B 9 283 324 710 ;
+C -1 ; WX 778 ; N Odieresis ; B 44 -19 734 915 ;
+C -1 ; WX 611 ; N mu ; B 66 -207 545 532 ;
+C -1 ; WX 278 ; N igrave ; B -50 0 209 750 ;
+C -1 ; WX 611 ; N ohungarumlaut ; B 34 -14 625 750 ;
+C -1 ; WX 667 ; N Eogonek ; B 76 -224 639 718 ;
+C -1 ; WX 611 ; N dcroat ; B 34 -14 650 718 ;
+C -1 ; WX 834 ; N threequarters ; B 16 -19 799 710 ;
+C -1 ; WX 667 ; N Scedilla ; B 39 -228 629 737 ;
+C -1 ; WX 400 ; N lcaron ; B 69 0 408 718 ;
+C -1 ; WX 722 ; N Kcommaaccent ; B 87 -228 722 718 ;
+C -1 ; WX 611 ; N Lacute ; B 76 0 583 936 ;
+C -1 ; WX 1000 ; N trademark ; B 44 306 956 718 ;
+C -1 ; WX 556 ; N edotaccent ; B 23 -14 528 729 ;
+C -1 ; WX 278 ; N Igrave ; B -50 0 214 936 ;
+C -1 ; WX 278 ; N Imacron ; B -33 0 312 864 ;
+C -1 ; WX 611 ; N Lcaron ; B 76 0 583 718 ;
+C -1 ; WX 834 ; N onehalf ; B 26 -19 794 710 ;
+C -1 ; WX 549 ; N lessequal ; B 29 0 526 704 ;
+C -1 ; WX 611 ; N ocircumflex ; B 34 -14 578 750 ;
+C -1 ; WX 611 ; N ntilde ; B 65 0 546 737 ;
+C -1 ; WX 722 ; N Uhungarumlaut ; B 72 -19 681 936 ;
+C -1 ; WX 667 ; N Eacute ; B 76 0 621 936 ;
+C -1 ; WX 556 ; N emacron ; B 23 -14 528 678 ;
+C -1 ; WX 611 ; N gbreve ; B 40 -217 553 750 ;
+C -1 ; WX 834 ; N onequarter ; B 26 -19 766 710 ;
+C -1 ; WX 667 ; N Scaron ; B 39 -19 629 936 ;
+C -1 ; WX 667 ; N Scommaaccent ; B 39 -228 629 737 ;
+C -1 ; WX 778 ; N Ohungarumlaut ; B 44 -19 734 936 ;
+C -1 ; WX 400 ; N degree ; B 57 426 343 712 ;
+C -1 ; WX 611 ; N ograve ; B 34 -14 578 750 ;
+C -1 ; WX 722 ; N Ccaron ; B 44 -19 684 936 ;
+C -1 ; WX 611 ; N ugrave ; B 66 -14 545 750 ;
+C -1 ; WX 549 ; N radical ; B 10 -46 512 850 ;
+C -1 ; WX 722 ; N Dcaron ; B 76 0 685 936 ;
+C -1 ; WX 389 ; N rcommaaccent ; B 64 -228 373 546 ;
+C -1 ; WX 722 ; N Ntilde ; B 69 0 654 923 ;
+C -1 ; WX 611 ; N otilde ; B 34 -14 578 737 ;
+C -1 ; WX 722 ; N Rcommaaccent ; B 76 -228 677 718 ;
+C -1 ; WX 611 ; N Lcommaaccent ; B 76 -228 583 718 ;
+C -1 ; WX 722 ; N Atilde ; B 20 0 702 923 ;
+C -1 ; WX 722 ; N Aogonek ; B 20 -224 742 718 ;
+C -1 ; WX 722 ; N Aring ; B 20 0 702 962 ;
+C -1 ; WX 778 ; N Otilde ; B 44 -19 734 923 ;
+C -1 ; WX 500 ; N zdotaccent ; B 20 0 480 729 ;
+C -1 ; WX 667 ; N Ecaron ; B 76 0 621 936 ;
+C -1 ; WX 278 ; N Iogonek ; B -11 -228 222 718 ;
+C -1 ; WX 556 ; N kcommaaccent ; B 69 -228 562 718 ;
+C -1 ; WX 584 ; N minus ; B 40 197 544 309 ;
+C -1 ; WX 278 ; N Icircumflex ; B -37 0 316 936 ;
+C -1 ; WX 611 ; N ncaron ; B 65 0 546 750 ;
+C -1 ; WX 333 ; N tcommaaccent ; B 10 -228 309 676 ;
+C -1 ; WX 584 ; N logicalnot ; B 40 108 544 419 ;
+C -1 ; WX 611 ; N odieresis ; B 34 -14 578 729 ;
+C -1 ; WX 611 ; N udieresis ; B 66 -14 545 729 ;
+C -1 ; WX 549 ; N notequal ; B 15 -49 540 570 ;
+C -1 ; WX 611 ; N gcommaaccent ; B 40 -217 553 850 ;
+C -1 ; WX 611 ; N eth ; B 34 -14 578 737 ;
+C -1 ; WX 500 ; N zcaron ; B 20 0 480 750 ;
+C -1 ; WX 611 ; N ncommaaccent ; B 65 -228 546 546 ;
+C -1 ; WX 333 ; N onesuperior ; B 26 283 237 710 ;
+C -1 ; WX 278 ; N imacron ; B -8 0 285 678 ;
+C -1 ; WX 556 ; N Euro ; B 0 0 0 0 ;
+EndCharMetrics
+StartKernData
+StartKernPairs 2481
+KPX A C -40
+KPX A Cacute -40
+KPX A Ccaron -40
+KPX A Ccedilla -40
+KPX A G -50
+KPX A Gbreve -50
+KPX A Gcommaaccent -50
+KPX A O -40
+KPX A Oacute -40
+KPX A Ocircumflex -40
+KPX A Odieresis -40
+KPX A Ograve -40
+KPX A Ohungarumlaut -40
+KPX A Omacron -40
+KPX A Oslash -40
+KPX A Otilde -40
+KPX A Q -40
+KPX A T -90
+KPX A Tcaron -90
+KPX A Tcommaaccent -90
+KPX A U -50
+KPX A Uacute -50
+KPX A Ucircumflex -50
+KPX A Udieresis -50
+KPX A Ugrave -50
+KPX A Uhungarumlaut -50
+KPX A Umacron -50
+KPX A Uogonek -50
+KPX A Uring -50
+KPX A V -80
+KPX A W -60
+KPX A Y -110
+KPX A Yacute -110
+KPX A Ydieresis -110
+KPX A u -30
+KPX A uacute -30
+KPX A ucircumflex -30
+KPX A udieresis -30
+KPX A ugrave -30
+KPX A uhungarumlaut -30
+KPX A umacron -30
+KPX A uogonek -30
+KPX A uring -30
+KPX A v -40
+KPX A w -30
+KPX A y -30
+KPX A yacute -30
+KPX A ydieresis -30
+KPX Aacute C -40
+KPX Aacute Cacute -40
+KPX Aacute Ccaron -40
+KPX Aacute Ccedilla -40
+KPX Aacute G -50
+KPX Aacute Gbreve -50
+KPX Aacute Gcommaaccent -50
+KPX Aacute O -40
+KPX Aacute Oacute -40
+KPX Aacute Ocircumflex -40
+KPX Aacute Odieresis -40
+KPX Aacute Ograve -40
+KPX Aacute Ohungarumlaut -40
+KPX Aacute Omacron -40
+KPX Aacute Oslash -40
+KPX Aacute Otilde -40
+KPX Aacute Q -40
+KPX Aacute T -90
+KPX Aacute Tcaron -90
+KPX Aacute Tcommaaccent -90
+KPX Aacute U -50
+KPX Aacute Uacute -50
+KPX Aacute Ucircumflex -50
+KPX Aacute Udieresis -50
+KPX Aacute Ugrave -50
+KPX Aacute Uhungarumlaut -50
+KPX Aacute Umacron -50
+KPX Aacute Uogonek -50
+KPX Aacute Uring -50
+KPX Aacute V -80
+KPX Aacute W -60
+KPX Aacute Y -110
+KPX Aacute Yacute -110
+KPX Aacute Ydieresis -110
+KPX Aacute u -30
+KPX Aacute uacute -30
+KPX Aacute ucircumflex -30
+KPX Aacute udieresis -30
+KPX Aacute ugrave -30
+KPX Aacute uhungarumlaut -30
+KPX Aacute umacron -30
+KPX Aacute uogonek -30
+KPX Aacute uring -30
+KPX Aacute v -40
+KPX Aacute w -30
+KPX Aacute y -30
+KPX Aacute yacute -30
+KPX Aacute ydieresis -30
+KPX Abreve C -40
+KPX Abreve Cacute -40
+KPX Abreve Ccaron -40
+KPX Abreve Ccedilla -40
+KPX Abreve G -50
+KPX Abreve Gbreve -50
+KPX Abreve Gcommaaccent -50
+KPX Abreve O -40
+KPX Abreve Oacute -40
+KPX Abreve Ocircumflex -40
+KPX Abreve Odieresis -40
+KPX Abreve Ograve -40
+KPX Abreve Ohungarumlaut -40
+KPX Abreve Omacron -40
+KPX Abreve Oslash -40
+KPX Abreve Otilde -40
+KPX Abreve Q -40
+KPX Abreve T -90
+KPX Abreve Tcaron -90
+KPX Abreve Tcommaaccent -90
+KPX Abreve U -50
+KPX Abreve Uacute -50
+KPX Abreve Ucircumflex -50
+KPX Abreve Udieresis -50
+KPX Abreve Ugrave -50
+KPX Abreve Uhungarumlaut -50
+KPX Abreve Umacron -50
+KPX Abreve Uogonek -50
+KPX Abreve Uring -50
+KPX Abreve V -80
+KPX Abreve W -60
+KPX Abreve Y -110
+KPX Abreve Yacute -110
+KPX Abreve Ydieresis -110
+KPX Abreve u -30
+KPX Abreve uacute -30
+KPX Abreve ucircumflex -30
+KPX Abreve udieresis -30
+KPX Abreve ugrave -30
+KPX Abreve uhungarumlaut -30
+KPX Abreve umacron -30
+KPX Abreve uogonek -30
+KPX Abreve uring -30
+KPX Abreve v -40
+KPX Abreve w -30
+KPX Abreve y -30
+KPX Abreve yacute -30
+KPX Abreve ydieresis -30
+KPX Acircumflex C -40
+KPX Acircumflex Cacute -40
+KPX Acircumflex Ccaron -40
+KPX Acircumflex Ccedilla -40
+KPX Acircumflex G -50
+KPX Acircumflex Gbreve -50
+KPX Acircumflex Gcommaaccent -50
+KPX Acircumflex O -40
+KPX Acircumflex Oacute -40
+KPX Acircumflex Ocircumflex -40
+KPX Acircumflex Odieresis -40
+KPX Acircumflex Ograve -40
+KPX Acircumflex Ohungarumlaut -40
+KPX Acircumflex Omacron -40
+KPX Acircumflex Oslash -40
+KPX Acircumflex Otilde -40
+KPX Acircumflex Q -40
+KPX Acircumflex T -90
+KPX Acircumflex Tcaron -90
+KPX Acircumflex Tcommaaccent -90
+KPX Acircumflex U -50
+KPX Acircumflex Uacute -50
+KPX Acircumflex Ucircumflex -50
+KPX Acircumflex Udieresis -50
+KPX Acircumflex Ugrave -50
+KPX Acircumflex Uhungarumlaut -50
+KPX Acircumflex Umacron -50
+KPX Acircumflex Uogonek -50
+KPX Acircumflex Uring -50
+KPX Acircumflex V -80
+KPX Acircumflex W -60
+KPX Acircumflex Y -110
+KPX Acircumflex Yacute -110
+KPX Acircumflex Ydieresis -110
+KPX Acircumflex u -30
+KPX Acircumflex uacute -30
+KPX Acircumflex ucircumflex -30
+KPX Acircumflex udieresis -30
+KPX Acircumflex ugrave -30
+KPX Acircumflex uhungarumlaut -30
+KPX Acircumflex umacron -30
+KPX Acircumflex uogonek -30
+KPX Acircumflex uring -30
+KPX Acircumflex v -40
+KPX Acircumflex w -30
+KPX Acircumflex y -30
+KPX Acircumflex yacute -30
+KPX Acircumflex ydieresis -30
+KPX Adieresis C -40
+KPX Adieresis Cacute -40
+KPX Adieresis Ccaron -40
+KPX Adieresis Ccedilla -40
+KPX Adieresis G -50
+KPX Adieresis Gbreve -50
+KPX Adieresis Gcommaaccent -50
+KPX Adieresis O -40
+KPX Adieresis Oacute -40
+KPX Adieresis Ocircumflex -40
+KPX Adieresis Odieresis -40
+KPX Adieresis Ograve -40
+KPX Adieresis Ohungarumlaut -40
+KPX Adieresis Omacron -40
+KPX Adieresis Oslash -40
+KPX Adieresis Otilde -40
+KPX Adieresis Q -40
+KPX Adieresis T -90
+KPX Adieresis Tcaron -90
+KPX Adieresis Tcommaaccent -90
+KPX Adieresis U -50
+KPX Adieresis Uacute -50
+KPX Adieresis Ucircumflex -50
+KPX Adieresis Udieresis -50
+KPX Adieresis Ugrave -50
+KPX Adieresis Uhungarumlaut -50
+KPX Adieresis Umacron -50
+KPX Adieresis Uogonek -50
+KPX Adieresis Uring -50
+KPX Adieresis V -80
+KPX Adieresis W -60
+KPX Adieresis Y -110
+KPX Adieresis Yacute -110
+KPX Adieresis Ydieresis -110
+KPX Adieresis u -30
+KPX Adieresis uacute -30
+KPX Adieresis ucircumflex -30
+KPX Adieresis udieresis -30
+KPX Adieresis ugrave -30
+KPX Adieresis uhungarumlaut -30
+KPX Adieresis umacron -30
+KPX Adieresis uogonek -30
+KPX Adieresis uring -30
+KPX Adieresis v -40
+KPX Adieresis w -30
+KPX Adieresis y -30
+KPX Adieresis yacute -30
+KPX Adieresis ydieresis -30
+KPX Agrave C -40
+KPX Agrave Cacute -40
+KPX Agrave Ccaron -40
+KPX Agrave Ccedilla -40
+KPX Agrave G -50
+KPX Agrave Gbreve -50
+KPX Agrave Gcommaaccent -50
+KPX Agrave O -40
+KPX Agrave Oacute -40
+KPX Agrave Ocircumflex -40
+KPX Agrave Odieresis -40
+KPX Agrave Ograve -40
+KPX Agrave Ohungarumlaut -40
+KPX Agrave Omacron -40
+KPX Agrave Oslash -40
+KPX Agrave Otilde -40
+KPX Agrave Q -40
+KPX Agrave T -90
+KPX Agrave Tcaron -90
+KPX Agrave Tcommaaccent -90
+KPX Agrave U -50
+KPX Agrave Uacute -50
+KPX Agrave Ucircumflex -50
+KPX Agrave Udieresis -50
+KPX Agrave Ugrave -50
+KPX Agrave Uhungarumlaut -50
+KPX Agrave Umacron -50
+KPX Agrave Uogonek -50
+KPX Agrave Uring -50
+KPX Agrave V -80
+KPX Agrave W -60
+KPX Agrave Y -110
+KPX Agrave Yacute -110
+KPX Agrave Ydieresis -110
+KPX Agrave u -30
+KPX Agrave uacute -30
+KPX Agrave ucircumflex -30
+KPX Agrave udieresis -30
+KPX Agrave ugrave -30
+KPX Agrave uhungarumlaut -30
+KPX Agrave umacron -30
+KPX Agrave uogonek -30
+KPX Agrave uring -30
+KPX Agrave v -40
+KPX Agrave w -30
+KPX Agrave y -30
+KPX Agrave yacute -30
+KPX Agrave ydieresis -30
+KPX Amacron C -40
+KPX Amacron Cacute -40
+KPX Amacron Ccaron -40
+KPX Amacron Ccedilla -40
+KPX Amacron G -50
+KPX Amacron Gbreve -50
+KPX Amacron Gcommaaccent -50
+KPX Amacron O -40
+KPX Amacron Oacute -40
+KPX Amacron Ocircumflex -40
+KPX Amacron Odieresis -40
+KPX Amacron Ograve -40
+KPX Amacron Ohungarumlaut -40
+KPX Amacron Omacron -40
+KPX Amacron Oslash -40
+KPX Amacron Otilde -40
+KPX Amacron Q -40
+KPX Amacron T -90
+KPX Amacron Tcaron -90
+KPX Amacron Tcommaaccent -90
+KPX Amacron U -50
+KPX Amacron Uacute -50
+KPX Amacron Ucircumflex -50
+KPX Amacron Udieresis -50
+KPX Amacron Ugrave -50
+KPX Amacron Uhungarumlaut -50
+KPX Amacron Umacron -50
+KPX Amacron Uogonek -50
+KPX Amacron Uring -50
+KPX Amacron V -80
+KPX Amacron W -60
+KPX Amacron Y -110
+KPX Amacron Yacute -110
+KPX Amacron Ydieresis -110
+KPX Amacron u -30
+KPX Amacron uacute -30
+KPX Amacron ucircumflex -30
+KPX Amacron udieresis -30
+KPX Amacron ugrave -30
+KPX Amacron uhungarumlaut -30
+KPX Amacron umacron -30
+KPX Amacron uogonek -30
+KPX Amacron uring -30
+KPX Amacron v -40
+KPX Amacron w -30
+KPX Amacron y -30
+KPX Amacron yacute -30
+KPX Amacron ydieresis -30
+KPX Aogonek C -40
+KPX Aogonek Cacute -40
+KPX Aogonek Ccaron -40
+KPX Aogonek Ccedilla -40
+KPX Aogonek G -50
+KPX Aogonek Gbreve -50
+KPX Aogonek Gcommaaccent -50
+KPX Aogonek O -40
+KPX Aogonek Oacute -40
+KPX Aogonek Ocircumflex -40
+KPX Aogonek Odieresis -40
+KPX Aogonek Ograve -40
+KPX Aogonek Ohungarumlaut -40
+KPX Aogonek Omacron -40
+KPX Aogonek Oslash -40
+KPX Aogonek Otilde -40
+KPX Aogonek Q -40
+KPX Aogonek T -90
+KPX Aogonek Tcaron -90
+KPX Aogonek Tcommaaccent -90
+KPX Aogonek U -50
+KPX Aogonek Uacute -50
+KPX Aogonek Ucircumflex -50
+KPX Aogonek Udieresis -50
+KPX Aogonek Ugrave -50
+KPX Aogonek Uhungarumlaut -50
+KPX Aogonek Umacron -50
+KPX Aogonek Uogonek -50
+KPX Aogonek Uring -50
+KPX Aogonek V -80
+KPX Aogonek W -60
+KPX Aogonek Y -110
+KPX Aogonek Yacute -110
+KPX Aogonek Ydieresis -110
+KPX Aogonek u -30
+KPX Aogonek uacute -30
+KPX Aogonek ucircumflex -30
+KPX Aogonek udieresis -30
+KPX Aogonek ugrave -30
+KPX Aogonek uhungarumlaut -30
+KPX Aogonek umacron -30
+KPX Aogonek uogonek -30
+KPX Aogonek uring -30
+KPX Aogonek v -40
+KPX Aogonek w -30
+KPX Aogonek y -30
+KPX Aogonek yacute -30
+KPX Aogonek ydieresis -30
+KPX Aring C -40
+KPX Aring Cacute -40
+KPX Aring Ccaron -40
+KPX Aring Ccedilla -40
+KPX Aring G -50
+KPX Aring Gbreve -50
+KPX Aring Gcommaaccent -50
+KPX Aring O -40
+KPX Aring Oacute -40
+KPX Aring Ocircumflex -40
+KPX Aring Odieresis -40
+KPX Aring Ograve -40
+KPX Aring Ohungarumlaut -40
+KPX Aring Omacron -40
+KPX Aring Oslash -40
+KPX Aring Otilde -40
+KPX Aring Q -40
+KPX Aring T -90
+KPX Aring Tcaron -90
+KPX Aring Tcommaaccent -90
+KPX Aring U -50
+KPX Aring Uacute -50
+KPX Aring Ucircumflex -50
+KPX Aring Udieresis -50
+KPX Aring Ugrave -50
+KPX Aring Uhungarumlaut -50
+KPX Aring Umacron -50
+KPX Aring Uogonek -50
+KPX Aring Uring -50
+KPX Aring V -80
+KPX Aring W -60
+KPX Aring Y -110
+KPX Aring Yacute -110
+KPX Aring Ydieresis -110
+KPX Aring u -30
+KPX Aring uacute -30
+KPX Aring ucircumflex -30
+KPX Aring udieresis -30
+KPX Aring ugrave -30
+KPX Aring uhungarumlaut -30
+KPX Aring umacron -30
+KPX Aring uogonek -30
+KPX Aring uring -30
+KPX Aring v -40
+KPX Aring w -30
+KPX Aring y -30
+KPX Aring yacute -30
+KPX Aring ydieresis -30
+KPX Atilde C -40
+KPX Atilde Cacute -40
+KPX Atilde Ccaron -40
+KPX Atilde Ccedilla -40
+KPX Atilde G -50
+KPX Atilde Gbreve -50
+KPX Atilde Gcommaaccent -50
+KPX Atilde O -40
+KPX Atilde Oacute -40
+KPX Atilde Ocircumflex -40
+KPX Atilde Odieresis -40
+KPX Atilde Ograve -40
+KPX Atilde Ohungarumlaut -40
+KPX Atilde Omacron -40
+KPX Atilde Oslash -40
+KPX Atilde Otilde -40
+KPX Atilde Q -40
+KPX Atilde T -90
+KPX Atilde Tcaron -90
+KPX Atilde Tcommaaccent -90
+KPX Atilde U -50
+KPX Atilde Uacute -50
+KPX Atilde Ucircumflex -50
+KPX Atilde Udieresis -50
+KPX Atilde Ugrave -50
+KPX Atilde Uhungarumlaut -50
+KPX Atilde Umacron -50
+KPX Atilde Uogonek -50
+KPX Atilde Uring -50
+KPX Atilde V -80
+KPX Atilde W -60
+KPX Atilde Y -110
+KPX Atilde Yacute -110
+KPX Atilde Ydieresis -110
+KPX Atilde u -30
+KPX Atilde uacute -30
+KPX Atilde ucircumflex -30
+KPX Atilde udieresis -30
+KPX Atilde ugrave -30
+KPX Atilde uhungarumlaut -30
+KPX Atilde umacron -30
+KPX Atilde uogonek -30
+KPX Atilde uring -30
+KPX Atilde v -40
+KPX Atilde w -30
+KPX Atilde y -30
+KPX Atilde yacute -30
+KPX Atilde ydieresis -30
+KPX B A -30
+KPX B Aacute -30
+KPX B Abreve -30
+KPX B Acircumflex -30
+KPX B Adieresis -30
+KPX B Agrave -30
+KPX B Amacron -30
+KPX B Aogonek -30
+KPX B Aring -30
+KPX B Atilde -30
+KPX B U -10
+KPX B Uacute -10
+KPX B Ucircumflex -10
+KPX B Udieresis -10
+KPX B Ugrave -10
+KPX B Uhungarumlaut -10
+KPX B Umacron -10
+KPX B Uogonek -10
+KPX B Uring -10
+KPX D A -40
+KPX D Aacute -40
+KPX D Abreve -40
+KPX D Acircumflex -40
+KPX D Adieresis -40
+KPX D Agrave -40
+KPX D Amacron -40
+KPX D Aogonek -40
+KPX D Aring -40
+KPX D Atilde -40
+KPX D V -40
+KPX D W -40
+KPX D Y -70
+KPX D Yacute -70
+KPX D Ydieresis -70
+KPX D comma -30
+KPX D period -30
+KPX Dcaron A -40
+KPX Dcaron Aacute -40
+KPX Dcaron Abreve -40
+KPX Dcaron Acircumflex -40
+KPX Dcaron Adieresis -40
+KPX Dcaron Agrave -40
+KPX Dcaron Amacron -40
+KPX Dcaron Aogonek -40
+KPX Dcaron Aring -40
+KPX Dcaron Atilde -40
+KPX Dcaron V -40
+KPX Dcaron W -40
+KPX Dcaron Y -70
+KPX Dcaron Yacute -70
+KPX Dcaron Ydieresis -70
+KPX Dcaron comma -30
+KPX Dcaron period -30
+KPX Dcroat A -40
+KPX Dcroat Aacute -40
+KPX Dcroat Abreve -40
+KPX Dcroat Acircumflex -40
+KPX Dcroat Adieresis -40
+KPX Dcroat Agrave -40
+KPX Dcroat Amacron -40
+KPX Dcroat Aogonek -40
+KPX Dcroat Aring -40
+KPX Dcroat Atilde -40
+KPX Dcroat V -40
+KPX Dcroat W -40
+KPX Dcroat Y -70
+KPX Dcroat Yacute -70
+KPX Dcroat Ydieresis -70
+KPX Dcroat comma -30
+KPX Dcroat period -30
+KPX F A -80
+KPX F Aacute -80
+KPX F Abreve -80
+KPX F Acircumflex -80
+KPX F Adieresis -80
+KPX F Agrave -80
+KPX F Amacron -80
+KPX F Aogonek -80
+KPX F Aring -80
+KPX F Atilde -80
+KPX F a -20
+KPX F aacute -20
+KPX F abreve -20
+KPX F acircumflex -20
+KPX F adieresis -20
+KPX F agrave -20
+KPX F amacron -20
+KPX F aogonek -20
+KPX F aring -20
+KPX F atilde -20
+KPX F comma -100
+KPX F period -100
+KPX J A -20
+KPX J Aacute -20
+KPX J Abreve -20
+KPX J Acircumflex -20
+KPX J Adieresis -20
+KPX J Agrave -20
+KPX J Amacron -20
+KPX J Aogonek -20
+KPX J Aring -20
+KPX J Atilde -20
+KPX J comma -20
+KPX J period -20
+KPX J u -20
+KPX J uacute -20
+KPX J ucircumflex -20
+KPX J udieresis -20
+KPX J ugrave -20
+KPX J uhungarumlaut -20
+KPX J umacron -20
+KPX J uogonek -20
+KPX J uring -20
+KPX K O -30
+KPX K Oacute -30
+KPX K Ocircumflex -30
+KPX K Odieresis -30
+KPX K Ograve -30
+KPX K Ohungarumlaut -30
+KPX K Omacron -30
+KPX K Oslash -30
+KPX K Otilde -30
+KPX K e -15
+KPX K eacute -15
+KPX K ecaron -15
+KPX K ecircumflex -15
+KPX K edieresis -15
+KPX K edotaccent -15
+KPX K egrave -15
+KPX K emacron -15
+KPX K eogonek -15
+KPX K o -35
+KPX K oacute -35
+KPX K ocircumflex -35
+KPX K odieresis -35
+KPX K ograve -35
+KPX K ohungarumlaut -35
+KPX K omacron -35
+KPX K oslash -35
+KPX K otilde -35
+KPX K u -30
+KPX K uacute -30
+KPX K ucircumflex -30
+KPX K udieresis -30
+KPX K ugrave -30
+KPX K uhungarumlaut -30
+KPX K umacron -30
+KPX K uogonek -30
+KPX K uring -30
+KPX K y -40
+KPX K yacute -40
+KPX K ydieresis -40
+KPX Kcommaaccent O -30
+KPX Kcommaaccent Oacute -30
+KPX Kcommaaccent Ocircumflex -30
+KPX Kcommaaccent Odieresis -30
+KPX Kcommaaccent Ograve -30
+KPX Kcommaaccent Ohungarumlaut -30
+KPX Kcommaaccent Omacron -30
+KPX Kcommaaccent Oslash -30
+KPX Kcommaaccent Otilde -30
+KPX Kcommaaccent e -15
+KPX Kcommaaccent eacute -15
+KPX Kcommaaccent ecaron -15
+KPX Kcommaaccent ecircumflex -15
+KPX Kcommaaccent edieresis -15
+KPX Kcommaaccent edotaccent -15
+KPX Kcommaaccent egrave -15
+KPX Kcommaaccent emacron -15
+KPX Kcommaaccent eogonek -15
+KPX Kcommaaccent o -35
+KPX Kcommaaccent oacute -35
+KPX Kcommaaccent ocircumflex -35
+KPX Kcommaaccent odieresis -35
+KPX Kcommaaccent ograve -35
+KPX Kcommaaccent ohungarumlaut -35
+KPX Kcommaaccent omacron -35
+KPX Kcommaaccent oslash -35
+KPX Kcommaaccent otilde -35
+KPX Kcommaaccent u -30
+KPX Kcommaaccent uacute -30
+KPX Kcommaaccent ucircumflex -30
+KPX Kcommaaccent udieresis -30
+KPX Kcommaaccent ugrave -30
+KPX Kcommaaccent uhungarumlaut -30
+KPX Kcommaaccent umacron -30
+KPX Kcommaaccent uogonek -30
+KPX Kcommaaccent uring -30
+KPX Kcommaaccent y -40
+KPX Kcommaaccent yacute -40
+KPX Kcommaaccent ydieresis -40
+KPX L T -90
+KPX L Tcaron -90
+KPX L Tcommaaccent -90
+KPX L V -110
+KPX L W -80
+KPX L Y -120
+KPX L Yacute -120
+KPX L Ydieresis -120
+KPX L quotedblright -140
+KPX L quoteright -140
+KPX L y -30
+KPX L yacute -30
+KPX L ydieresis -30
+KPX Lacute T -90
+KPX Lacute Tcaron -90
+KPX Lacute Tcommaaccent -90
+KPX Lacute V -110
+KPX Lacute W -80
+KPX Lacute Y -120
+KPX Lacute Yacute -120
+KPX Lacute Ydieresis -120
+KPX Lacute quotedblright -140
+KPX Lacute quoteright -140
+KPX Lacute y -30
+KPX Lacute yacute -30
+KPX Lacute ydieresis -30
+KPX Lcommaaccent T -90
+KPX Lcommaaccent Tcaron -90
+KPX Lcommaaccent Tcommaaccent -90
+KPX Lcommaaccent V -110
+KPX Lcommaaccent W -80
+KPX Lcommaaccent Y -120
+KPX Lcommaaccent Yacute -120
+KPX Lcommaaccent Ydieresis -120
+KPX Lcommaaccent quotedblright -140
+KPX Lcommaaccent quoteright -140
+KPX Lcommaaccent y -30
+KPX Lcommaaccent yacute -30
+KPX Lcommaaccent ydieresis -30
+KPX Lslash T -90
+KPX Lslash Tcaron -90
+KPX Lslash Tcommaaccent -90
+KPX Lslash V -110
+KPX Lslash W -80
+KPX Lslash Y -120
+KPX Lslash Yacute -120
+KPX Lslash Ydieresis -120
+KPX Lslash quotedblright -140
+KPX Lslash quoteright -140
+KPX Lslash y -30
+KPX Lslash yacute -30
+KPX Lslash ydieresis -30
+KPX O A -50
+KPX O Aacute -50
+KPX O Abreve -50
+KPX O Acircumflex -50
+KPX O Adieresis -50
+KPX O Agrave -50
+KPX O Amacron -50
+KPX O Aogonek -50
+KPX O Aring -50
+KPX O Atilde -50
+KPX O T -40
+KPX O Tcaron -40
+KPX O Tcommaaccent -40
+KPX O V -50
+KPX O W -50
+KPX O X -50
+KPX O Y -70
+KPX O Yacute -70
+KPX O Ydieresis -70
+KPX O comma -40
+KPX O period -40
+KPX Oacute A -50
+KPX Oacute Aacute -50
+KPX Oacute Abreve -50
+KPX Oacute Acircumflex -50
+KPX Oacute Adieresis -50
+KPX Oacute Agrave -50
+KPX Oacute Amacron -50
+KPX Oacute Aogonek -50
+KPX Oacute Aring -50
+KPX Oacute Atilde -50
+KPX Oacute T -40
+KPX Oacute Tcaron -40
+KPX Oacute Tcommaaccent -40
+KPX Oacute V -50
+KPX Oacute W -50
+KPX Oacute X -50
+KPX Oacute Y -70
+KPX Oacute Yacute -70
+KPX Oacute Ydieresis -70
+KPX Oacute comma -40
+KPX Oacute period -40
+KPX Ocircumflex A -50
+KPX Ocircumflex Aacute -50
+KPX Ocircumflex Abreve -50
+KPX Ocircumflex Acircumflex -50
+KPX Ocircumflex Adieresis -50
+KPX Ocircumflex Agrave -50
+KPX Ocircumflex Amacron -50
+KPX Ocircumflex Aogonek -50
+KPX Ocircumflex Aring -50
+KPX Ocircumflex Atilde -50
+KPX Ocircumflex T -40
+KPX Ocircumflex Tcaron -40
+KPX Ocircumflex Tcommaaccent -40
+KPX Ocircumflex V -50
+KPX Ocircumflex W -50
+KPX Ocircumflex X -50
+KPX Ocircumflex Y -70
+KPX Ocircumflex Yacute -70
+KPX Ocircumflex Ydieresis -70
+KPX Ocircumflex comma -40
+KPX Ocircumflex period -40
+KPX Odieresis A -50
+KPX Odieresis Aacute -50
+KPX Odieresis Abreve -50
+KPX Odieresis Acircumflex -50
+KPX Odieresis Adieresis -50
+KPX Odieresis Agrave -50
+KPX Odieresis Amacron -50
+KPX Odieresis Aogonek -50
+KPX Odieresis Aring -50
+KPX Odieresis Atilde -50
+KPX Odieresis T -40
+KPX Odieresis Tcaron -40
+KPX Odieresis Tcommaaccent -40
+KPX Odieresis V -50
+KPX Odieresis W -50
+KPX Odieresis X -50
+KPX Odieresis Y -70
+KPX Odieresis Yacute -70
+KPX Odieresis Ydieresis -70
+KPX Odieresis comma -40
+KPX Odieresis period -40
+KPX Ograve A -50
+KPX Ograve Aacute -50
+KPX Ograve Abreve -50
+KPX Ograve Acircumflex -50
+KPX Ograve Adieresis -50
+KPX Ograve Agrave -50
+KPX Ograve Amacron -50
+KPX Ograve Aogonek -50
+KPX Ograve Aring -50
+KPX Ograve Atilde -50
+KPX Ograve T -40
+KPX Ograve Tcaron -40
+KPX Ograve Tcommaaccent -40
+KPX Ograve V -50
+KPX Ograve W -50
+KPX Ograve X -50
+KPX Ograve Y -70
+KPX Ograve Yacute -70
+KPX Ograve Ydieresis -70
+KPX Ograve comma -40
+KPX Ograve period -40
+KPX Ohungarumlaut A -50
+KPX Ohungarumlaut Aacute -50
+KPX Ohungarumlaut Abreve -50
+KPX Ohungarumlaut Acircumflex -50
+KPX Ohungarumlaut Adieresis -50
+KPX Ohungarumlaut Agrave -50
+KPX Ohungarumlaut Amacron -50
+KPX Ohungarumlaut Aogonek -50
+KPX Ohungarumlaut Aring -50
+KPX Ohungarumlaut Atilde -50
+KPX Ohungarumlaut T -40
+KPX Ohungarumlaut Tcaron -40
+KPX Ohungarumlaut Tcommaaccent -40
+KPX Ohungarumlaut V -50
+KPX Ohungarumlaut W -50
+KPX Ohungarumlaut X -50
+KPX Ohungarumlaut Y -70
+KPX Ohungarumlaut Yacute -70
+KPX Ohungarumlaut Ydieresis -70
+KPX Ohungarumlaut comma -40
+KPX Ohungarumlaut period -40
+KPX Omacron A -50
+KPX Omacron Aacute -50
+KPX Omacron Abreve -50
+KPX Omacron Acircumflex -50
+KPX Omacron Adieresis -50
+KPX Omacron Agrave -50
+KPX Omacron Amacron -50
+KPX Omacron Aogonek -50
+KPX Omacron Aring -50
+KPX Omacron Atilde -50
+KPX Omacron T -40
+KPX Omacron Tcaron -40
+KPX Omacron Tcommaaccent -40
+KPX Omacron V -50
+KPX Omacron W -50
+KPX Omacron X -50
+KPX Omacron Y -70
+KPX Omacron Yacute -70
+KPX Omacron Ydieresis -70
+KPX Omacron comma -40
+KPX Omacron period -40
+KPX Oslash A -50
+KPX Oslash Aacute -50
+KPX Oslash Abreve -50
+KPX Oslash Acircumflex -50
+KPX Oslash Adieresis -50
+KPX Oslash Agrave -50
+KPX Oslash Amacron -50
+KPX Oslash Aogonek -50
+KPX Oslash Aring -50
+KPX Oslash Atilde -50
+KPX Oslash T -40
+KPX Oslash Tcaron -40
+KPX Oslash Tcommaaccent -40
+KPX Oslash V -50
+KPX Oslash W -50
+KPX Oslash X -50
+KPX Oslash Y -70
+KPX Oslash Yacute -70
+KPX Oslash Ydieresis -70
+KPX Oslash comma -40
+KPX Oslash period -40
+KPX Otilde A -50
+KPX Otilde Aacute -50
+KPX Otilde Abreve -50
+KPX Otilde Acircumflex -50
+KPX Otilde Adieresis -50
+KPX Otilde Agrave -50
+KPX Otilde Amacron -50
+KPX Otilde Aogonek -50
+KPX Otilde Aring -50
+KPX Otilde Atilde -50
+KPX Otilde T -40
+KPX Otilde Tcaron -40
+KPX Otilde Tcommaaccent -40
+KPX Otilde V -50
+KPX Otilde W -50
+KPX Otilde X -50
+KPX Otilde Y -70
+KPX Otilde Yacute -70
+KPX Otilde Ydieresis -70
+KPX Otilde comma -40
+KPX Otilde period -40
+KPX P A -100
+KPX P Aacute -100
+KPX P Abreve -100
+KPX P Acircumflex -100
+KPX P Adieresis -100
+KPX P Agrave -100
+KPX P Amacron -100
+KPX P Aogonek -100
+KPX P Aring -100
+KPX P Atilde -100
+KPX P a -30
+KPX P aacute -30
+KPX P abreve -30
+KPX P acircumflex -30
+KPX P adieresis -30
+KPX P agrave -30
+KPX P amacron -30
+KPX P aogonek -30
+KPX P aring -30
+KPX P atilde -30
+KPX P comma -120
+KPX P e -30
+KPX P eacute -30
+KPX P ecaron -30
+KPX P ecircumflex -30
+KPX P edieresis -30
+KPX P edotaccent -30
+KPX P egrave -30
+KPX P emacron -30
+KPX P eogonek -30
+KPX P o -40
+KPX P oacute -40
+KPX P ocircumflex -40
+KPX P odieresis -40
+KPX P ograve -40
+KPX P ohungarumlaut -40
+KPX P omacron -40
+KPX P oslash -40
+KPX P otilde -40
+KPX P period -120
+KPX Q U -10
+KPX Q Uacute -10
+KPX Q Ucircumflex -10
+KPX Q Udieresis -10
+KPX Q Ugrave -10
+KPX Q Uhungarumlaut -10
+KPX Q Umacron -10
+KPX Q Uogonek -10
+KPX Q Uring -10
+KPX Q comma 20
+KPX Q period 20
+KPX R O -20
+KPX R Oacute -20
+KPX R Ocircumflex -20
+KPX R Odieresis -20
+KPX R Ograve -20
+KPX R Ohungarumlaut -20
+KPX R Omacron -20
+KPX R Oslash -20
+KPX R Otilde -20
+KPX R T -20
+KPX R Tcaron -20
+KPX R Tcommaaccent -20
+KPX R U -20
+KPX R Uacute -20
+KPX R Ucircumflex -20
+KPX R Udieresis -20
+KPX R Ugrave -20
+KPX R Uhungarumlaut -20
+KPX R Umacron -20
+KPX R Uogonek -20
+KPX R Uring -20
+KPX R V -50
+KPX R W -40
+KPX R Y -50
+KPX R Yacute -50
+KPX R Ydieresis -50
+KPX Racute O -20
+KPX Racute Oacute -20
+KPX Racute Ocircumflex -20
+KPX Racute Odieresis -20
+KPX Racute Ograve -20
+KPX Racute Ohungarumlaut -20
+KPX Racute Omacron -20
+KPX Racute Oslash -20
+KPX Racute Otilde -20
+KPX Racute T -20
+KPX Racute Tcaron -20
+KPX Racute Tcommaaccent -20
+KPX Racute U -20
+KPX Racute Uacute -20
+KPX Racute Ucircumflex -20
+KPX Racute Udieresis -20
+KPX Racute Ugrave -20
+KPX Racute Uhungarumlaut -20
+KPX Racute Umacron -20
+KPX Racute Uogonek -20
+KPX Racute Uring -20
+KPX Racute V -50
+KPX Racute W -40
+KPX Racute Y -50
+KPX Racute Yacute -50
+KPX Racute Ydieresis -50
+KPX Rcaron O -20
+KPX Rcaron Oacute -20
+KPX Rcaron Ocircumflex -20
+KPX Rcaron Odieresis -20
+KPX Rcaron Ograve -20
+KPX Rcaron Ohungarumlaut -20
+KPX Rcaron Omacron -20
+KPX Rcaron Oslash -20
+KPX Rcaron Otilde -20
+KPX Rcaron T -20
+KPX Rcaron Tcaron -20
+KPX Rcaron Tcommaaccent -20
+KPX Rcaron U -20
+KPX Rcaron Uacute -20
+KPX Rcaron Ucircumflex -20
+KPX Rcaron Udieresis -20
+KPX Rcaron Ugrave -20
+KPX Rcaron Uhungarumlaut -20
+KPX Rcaron Umacron -20
+KPX Rcaron Uogonek -20
+KPX Rcaron Uring -20
+KPX Rcaron V -50
+KPX Rcaron W -40
+KPX Rcaron Y -50
+KPX Rcaron Yacute -50
+KPX Rcaron Ydieresis -50
+KPX Rcommaaccent O -20
+KPX Rcommaaccent Oacute -20
+KPX Rcommaaccent Ocircumflex -20
+KPX Rcommaaccent Odieresis -20
+KPX Rcommaaccent Ograve -20
+KPX Rcommaaccent Ohungarumlaut -20
+KPX Rcommaaccent Omacron -20
+KPX Rcommaaccent Oslash -20
+KPX Rcommaaccent Otilde -20
+KPX Rcommaaccent T -20
+KPX Rcommaaccent Tcaron -20
+KPX Rcommaaccent Tcommaaccent -20
+KPX Rcommaaccent U -20
+KPX Rcommaaccent Uacute -20
+KPX Rcommaaccent Ucircumflex -20
+KPX Rcommaaccent Udieresis -20
+KPX Rcommaaccent Ugrave -20
+KPX Rcommaaccent Uhungarumlaut -20
+KPX Rcommaaccent Umacron -20
+KPX Rcommaaccent Uogonek -20
+KPX Rcommaaccent Uring -20
+KPX Rcommaaccent V -50
+KPX Rcommaaccent W -40
+KPX Rcommaaccent Y -50
+KPX Rcommaaccent Yacute -50
+KPX Rcommaaccent Ydieresis -50
+KPX T A -90
+KPX T Aacute -90
+KPX T Abreve -90
+KPX T Acircumflex -90
+KPX T Adieresis -90
+KPX T Agrave -90
+KPX T Amacron -90
+KPX T Aogonek -90
+KPX T Aring -90
+KPX T Atilde -90
+KPX T O -40
+KPX T Oacute -40
+KPX T Ocircumflex -40
+KPX T Odieresis -40
+KPX T Ograve -40
+KPX T Ohungarumlaut -40
+KPX T Omacron -40
+KPX T Oslash -40
+KPX T Otilde -40
+KPX T a -80
+KPX T aacute -80
+KPX T abreve -80
+KPX T acircumflex -80
+KPX T adieresis -80
+KPX T agrave -80
+KPX T amacron -80
+KPX T aogonek -80
+KPX T aring -80
+KPX T atilde -80
+KPX T colon -40
+KPX T comma -80
+KPX T e -60
+KPX T eacute -60
+KPX T ecaron -60
+KPX T ecircumflex -60
+KPX T edieresis -60
+KPX T edotaccent -60
+KPX T egrave -60
+KPX T emacron -60
+KPX T eogonek -60
+KPX T hyphen -120
+KPX T o -80
+KPX T oacute -80
+KPX T ocircumflex -80
+KPX T odieresis -80
+KPX T ograve -80
+KPX T ohungarumlaut -80
+KPX T omacron -80
+KPX T oslash -80
+KPX T otilde -80
+KPX T period -80
+KPX T r -80
+KPX T racute -80
+KPX T rcommaaccent -80
+KPX T semicolon -40
+KPX T u -90
+KPX T uacute -90
+KPX T ucircumflex -90
+KPX T udieresis -90
+KPX T ugrave -90
+KPX T uhungarumlaut -90
+KPX T umacron -90
+KPX T uogonek -90
+KPX T uring -90
+KPX T w -60
+KPX T y -60
+KPX T yacute -60
+KPX T ydieresis -60
+KPX Tcaron A -90
+KPX Tcaron Aacute -90
+KPX Tcaron Abreve -90
+KPX Tcaron Acircumflex -90
+KPX Tcaron Adieresis -90
+KPX Tcaron Agrave -90
+KPX Tcaron Amacron -90
+KPX Tcaron Aogonek -90
+KPX Tcaron Aring -90
+KPX Tcaron Atilde -90
+KPX Tcaron O -40
+KPX Tcaron Oacute -40
+KPX Tcaron Ocircumflex -40
+KPX Tcaron Odieresis -40
+KPX Tcaron Ograve -40
+KPX Tcaron Ohungarumlaut -40
+KPX Tcaron Omacron -40
+KPX Tcaron Oslash -40
+KPX Tcaron Otilde -40
+KPX Tcaron a -80
+KPX Tcaron aacute -80
+KPX Tcaron abreve -80
+KPX Tcaron acircumflex -80
+KPX Tcaron adieresis -80
+KPX Tcaron agrave -80
+KPX Tcaron amacron -80
+KPX Tcaron aogonek -80
+KPX Tcaron aring -80
+KPX Tcaron atilde -80
+KPX Tcaron colon -40
+KPX Tcaron comma -80
+KPX Tcaron e -60
+KPX Tcaron eacute -60
+KPX Tcaron ecaron -60
+KPX Tcaron ecircumflex -60
+KPX Tcaron edieresis -60
+KPX Tcaron edotaccent -60
+KPX Tcaron egrave -60
+KPX Tcaron emacron -60
+KPX Tcaron eogonek -60
+KPX Tcaron hyphen -120
+KPX Tcaron o -80
+KPX Tcaron oacute -80
+KPX Tcaron ocircumflex -80
+KPX Tcaron odieresis -80
+KPX Tcaron ograve -80
+KPX Tcaron ohungarumlaut -80
+KPX Tcaron omacron -80
+KPX Tcaron oslash -80
+KPX Tcaron otilde -80
+KPX Tcaron period -80
+KPX Tcaron r -80
+KPX Tcaron racute -80
+KPX Tcaron rcommaaccent -80
+KPX Tcaron semicolon -40
+KPX Tcaron u -90
+KPX Tcaron uacute -90
+KPX Tcaron ucircumflex -90
+KPX Tcaron udieresis -90
+KPX Tcaron ugrave -90
+KPX Tcaron uhungarumlaut -90
+KPX Tcaron umacron -90
+KPX Tcaron uogonek -90
+KPX Tcaron uring -90
+KPX Tcaron w -60
+KPX Tcaron y -60
+KPX Tcaron yacute -60
+KPX Tcaron ydieresis -60
+KPX Tcommaaccent A -90
+KPX Tcommaaccent Aacute -90
+KPX Tcommaaccent Abreve -90
+KPX Tcommaaccent Acircumflex -90
+KPX Tcommaaccent Adieresis -90
+KPX Tcommaaccent Agrave -90
+KPX Tcommaaccent Amacron -90
+KPX Tcommaaccent Aogonek -90
+KPX Tcommaaccent Aring -90
+KPX Tcommaaccent Atilde -90
+KPX Tcommaaccent O -40
+KPX Tcommaaccent Oacute -40
+KPX Tcommaaccent Ocircumflex -40
+KPX Tcommaaccent Odieresis -40
+KPX Tcommaaccent Ograve -40
+KPX Tcommaaccent Ohungarumlaut -40
+KPX Tcommaaccent Omacron -40
+KPX Tcommaaccent Oslash -40
+KPX Tcommaaccent Otilde -40
+KPX Tcommaaccent a -80
+KPX Tcommaaccent aacute -80
+KPX Tcommaaccent abreve -80
+KPX Tcommaaccent acircumflex -80
+KPX Tcommaaccent adieresis -80
+KPX Tcommaaccent agrave -80
+KPX Tcommaaccent amacron -80
+KPX Tcommaaccent aogonek -80
+KPX Tcommaaccent aring -80
+KPX Tcommaaccent atilde -80
+KPX Tcommaaccent colon -40
+KPX Tcommaaccent comma -80
+KPX Tcommaaccent e -60
+KPX Tcommaaccent eacute -60
+KPX Tcommaaccent ecaron -60
+KPX Tcommaaccent ecircumflex -60
+KPX Tcommaaccent edieresis -60
+KPX Tcommaaccent edotaccent -60
+KPX Tcommaaccent egrave -60
+KPX Tcommaaccent emacron -60
+KPX Tcommaaccent eogonek -60
+KPX Tcommaaccent hyphen -120
+KPX Tcommaaccent o -80
+KPX Tcommaaccent oacute -80
+KPX Tcommaaccent ocircumflex -80
+KPX Tcommaaccent odieresis -80
+KPX Tcommaaccent ograve -80
+KPX Tcommaaccent ohungarumlaut -80
+KPX Tcommaaccent omacron -80
+KPX Tcommaaccent oslash -80
+KPX Tcommaaccent otilde -80
+KPX Tcommaaccent period -80
+KPX Tcommaaccent r -80
+KPX Tcommaaccent racute -80
+KPX Tcommaaccent rcommaaccent -80
+KPX Tcommaaccent semicolon -40
+KPX Tcommaaccent u -90
+KPX Tcommaaccent uacute -90
+KPX Tcommaaccent ucircumflex -90
+KPX Tcommaaccent udieresis -90
+KPX Tcommaaccent ugrave -90
+KPX Tcommaaccent uhungarumlaut -90
+KPX Tcommaaccent umacron -90
+KPX Tcommaaccent uogonek -90
+KPX Tcommaaccent uring -90
+KPX Tcommaaccent w -60
+KPX Tcommaaccent y -60
+KPX Tcommaaccent yacute -60
+KPX Tcommaaccent ydieresis -60
+KPX U A -50
+KPX U Aacute -50
+KPX U Abreve -50
+KPX U Acircumflex -50
+KPX U Adieresis -50
+KPX U Agrave -50
+KPX U Amacron -50
+KPX U Aogonek -50
+KPX U Aring -50
+KPX U Atilde -50
+KPX U comma -30
+KPX U period -30
+KPX Uacute A -50
+KPX Uacute Aacute -50
+KPX Uacute Abreve -50
+KPX Uacute Acircumflex -50
+KPX Uacute Adieresis -50
+KPX Uacute Agrave -50
+KPX Uacute Amacron -50
+KPX Uacute Aogonek -50
+KPX Uacute Aring -50
+KPX Uacute Atilde -50
+KPX Uacute comma -30
+KPX Uacute period -30
+KPX Ucircumflex A -50
+KPX Ucircumflex Aacute -50
+KPX Ucircumflex Abreve -50
+KPX Ucircumflex Acircumflex -50
+KPX Ucircumflex Adieresis -50
+KPX Ucircumflex Agrave -50
+KPX Ucircumflex Amacron -50
+KPX Ucircumflex Aogonek -50
+KPX Ucircumflex Aring -50
+KPX Ucircumflex Atilde -50
+KPX Ucircumflex comma -30
+KPX Ucircumflex period -30
+KPX Udieresis A -50
+KPX Udieresis Aacute -50
+KPX Udieresis Abreve -50
+KPX Udieresis Acircumflex -50
+KPX Udieresis Adieresis -50
+KPX Udieresis Agrave -50
+KPX Udieresis Amacron -50
+KPX Udieresis Aogonek -50
+KPX Udieresis Aring -50
+KPX Udieresis Atilde -50
+KPX Udieresis comma -30
+KPX Udieresis period -30
+KPX Ugrave A -50
+KPX Ugrave Aacute -50
+KPX Ugrave Abreve -50
+KPX Ugrave Acircumflex -50
+KPX Ugrave Adieresis -50
+KPX Ugrave Agrave -50
+KPX Ugrave Amacron -50
+KPX Ugrave Aogonek -50
+KPX Ugrave Aring -50
+KPX Ugrave Atilde -50
+KPX Ugrave comma -30
+KPX Ugrave period -30
+KPX Uhungarumlaut A -50
+KPX Uhungarumlaut Aacute -50
+KPX Uhungarumlaut Abreve -50
+KPX Uhungarumlaut Acircumflex -50
+KPX Uhungarumlaut Adieresis -50
+KPX Uhungarumlaut Agrave -50
+KPX Uhungarumlaut Amacron -50
+KPX Uhungarumlaut Aogonek -50
+KPX Uhungarumlaut Aring -50
+KPX Uhungarumlaut Atilde -50
+KPX Uhungarumlaut comma -30
+KPX Uhungarumlaut period -30
+KPX Umacron A -50
+KPX Umacron Aacute -50
+KPX Umacron Abreve -50
+KPX Umacron Acircumflex -50
+KPX Umacron Adieresis -50
+KPX Umacron Agrave -50
+KPX Umacron Amacron -50
+KPX Umacron Aogonek -50
+KPX Umacron Aring -50
+KPX Umacron Atilde -50
+KPX Umacron comma -30
+KPX Umacron period -30
+KPX Uogonek A -50
+KPX Uogonek Aacute -50
+KPX Uogonek Abreve -50
+KPX Uogonek Acircumflex -50
+KPX Uogonek Adieresis -50
+KPX Uogonek Agrave -50
+KPX Uogonek Amacron -50
+KPX Uogonek Aogonek -50
+KPX Uogonek Aring -50
+KPX Uogonek Atilde -50
+KPX Uogonek comma -30
+KPX Uogonek period -30
+KPX Uring A -50
+KPX Uring Aacute -50
+KPX Uring Abreve -50
+KPX Uring Acircumflex -50
+KPX Uring Adieresis -50
+KPX Uring Agrave -50
+KPX Uring Amacron -50
+KPX Uring Aogonek -50
+KPX Uring Aring -50
+KPX Uring Atilde -50
+KPX Uring comma -30
+KPX Uring period -30
+KPX V A -80
+KPX V Aacute -80
+KPX V Abreve -80
+KPX V Acircumflex -80
+KPX V Adieresis -80
+KPX V Agrave -80
+KPX V Amacron -80
+KPX V Aogonek -80
+KPX V Aring -80
+KPX V Atilde -80
+KPX V G -50
+KPX V Gbreve -50
+KPX V Gcommaaccent -50
+KPX V O -50
+KPX V Oacute -50
+KPX V Ocircumflex -50
+KPX V Odieresis -50
+KPX V Ograve -50
+KPX V Ohungarumlaut -50
+KPX V Omacron -50
+KPX V Oslash -50
+KPX V Otilde -50
+KPX V a -60
+KPX V aacute -60
+KPX V abreve -60
+KPX V acircumflex -60
+KPX V adieresis -60
+KPX V agrave -60
+KPX V amacron -60
+KPX V aogonek -60
+KPX V aring -60
+KPX V atilde -60
+KPX V colon -40
+KPX V comma -120
+KPX V e -50
+KPX V eacute -50
+KPX V ecaron -50
+KPX V ecircumflex -50
+KPX V edieresis -50
+KPX V edotaccent -50
+KPX V egrave -50
+KPX V emacron -50
+KPX V eogonek -50
+KPX V hyphen -80
+KPX V o -90
+KPX V oacute -90
+KPX V ocircumflex -90
+KPX V odieresis -90
+KPX V ograve -90
+KPX V ohungarumlaut -90
+KPX V omacron -90
+KPX V oslash -90
+KPX V otilde -90
+KPX V period -120
+KPX V semicolon -40
+KPX V u -60
+KPX V uacute -60
+KPX V ucircumflex -60
+KPX V udieresis -60
+KPX V ugrave -60
+KPX V uhungarumlaut -60
+KPX V umacron -60
+KPX V uogonek -60
+KPX V uring -60
+KPX W A -60
+KPX W Aacute -60
+KPX W Abreve -60
+KPX W Acircumflex -60
+KPX W Adieresis -60
+KPX W Agrave -60
+KPX W Amacron -60
+KPX W Aogonek -60
+KPX W Aring -60
+KPX W Atilde -60
+KPX W O -20
+KPX W Oacute -20
+KPX W Ocircumflex -20
+KPX W Odieresis -20
+KPX W Ograve -20
+KPX W Ohungarumlaut -20
+KPX W Omacron -20
+KPX W Oslash -20
+KPX W Otilde -20
+KPX W a -40
+KPX W aacute -40
+KPX W abreve -40
+KPX W acircumflex -40
+KPX W adieresis -40
+KPX W agrave -40
+KPX W amacron -40
+KPX W aogonek -40
+KPX W aring -40
+KPX W atilde -40
+KPX W colon -10
+KPX W comma -80
+KPX W e -35
+KPX W eacute -35
+KPX W ecaron -35
+KPX W ecircumflex -35
+KPX W edieresis -35
+KPX W edotaccent -35
+KPX W egrave -35
+KPX W emacron -35
+KPX W eogonek -35
+KPX W hyphen -40
+KPX W o -60
+KPX W oacute -60
+KPX W ocircumflex -60
+KPX W odieresis -60
+KPX W ograve -60
+KPX W ohungarumlaut -60
+KPX W omacron -60
+KPX W oslash -60
+KPX W otilde -60
+KPX W period -80
+KPX W semicolon -10
+KPX W u -45
+KPX W uacute -45
+KPX W ucircumflex -45
+KPX W udieresis -45
+KPX W ugrave -45
+KPX W uhungarumlaut -45
+KPX W umacron -45
+KPX W uogonek -45
+KPX W uring -45
+KPX W y -20
+KPX W yacute -20
+KPX W ydieresis -20
+KPX Y A -110
+KPX Y Aacute -110
+KPX Y Abreve -110
+KPX Y Acircumflex -110
+KPX Y Adieresis -110
+KPX Y Agrave -110
+KPX Y Amacron -110
+KPX Y Aogonek -110
+KPX Y Aring -110
+KPX Y Atilde -110
+KPX Y O -70
+KPX Y Oacute -70
+KPX Y Ocircumflex -70
+KPX Y Odieresis -70
+KPX Y Ograve -70
+KPX Y Ohungarumlaut -70
+KPX Y Omacron -70
+KPX Y Oslash -70
+KPX Y Otilde -70
+KPX Y a -90
+KPX Y aacute -90
+KPX Y abreve -90
+KPX Y acircumflex -90
+KPX Y adieresis -90
+KPX Y agrave -90
+KPX Y amacron -90
+KPX Y aogonek -90
+KPX Y aring -90
+KPX Y atilde -90
+KPX Y colon -50
+KPX Y comma -100
+KPX Y e -80
+KPX Y eacute -80
+KPX Y ecaron -80
+KPX Y ecircumflex -80
+KPX Y edieresis -80
+KPX Y edotaccent -80
+KPX Y egrave -80
+KPX Y emacron -80
+KPX Y eogonek -80
+KPX Y o -100
+KPX Y oacute -100
+KPX Y ocircumflex -100
+KPX Y odieresis -100
+KPX Y ograve -100
+KPX Y ohungarumlaut -100
+KPX Y omacron -100
+KPX Y oslash -100
+KPX Y otilde -100
+KPX Y period -100
+KPX Y semicolon -50
+KPX Y u -100
+KPX Y uacute -100
+KPX Y ucircumflex -100
+KPX Y udieresis -100
+KPX Y ugrave -100
+KPX Y uhungarumlaut -100
+KPX Y umacron -100
+KPX Y uogonek -100
+KPX Y uring -100
+KPX Yacute A -110
+KPX Yacute Aacute -110
+KPX Yacute Abreve -110
+KPX Yacute Acircumflex -110
+KPX Yacute Adieresis -110
+KPX Yacute Agrave -110
+KPX Yacute Amacron -110
+KPX Yacute Aogonek -110
+KPX Yacute Aring -110
+KPX Yacute Atilde -110
+KPX Yacute O -70
+KPX Yacute Oacute -70
+KPX Yacute Ocircumflex -70
+KPX Yacute Odieresis -70
+KPX Yacute Ograve -70
+KPX Yacute Ohungarumlaut -70
+KPX Yacute Omacron -70
+KPX Yacute Oslash -70
+KPX Yacute Otilde -70
+KPX Yacute a -90
+KPX Yacute aacute -90
+KPX Yacute abreve -90
+KPX Yacute acircumflex -90
+KPX Yacute adieresis -90
+KPX Yacute agrave -90
+KPX Yacute amacron -90
+KPX Yacute aogonek -90
+KPX Yacute aring -90
+KPX Yacute atilde -90
+KPX Yacute colon -50
+KPX Yacute comma -100
+KPX Yacute e -80
+KPX Yacute eacute -80
+KPX Yacute ecaron -80
+KPX Yacute ecircumflex -80
+KPX Yacute edieresis -80
+KPX Yacute edotaccent -80
+KPX Yacute egrave -80
+KPX Yacute emacron -80
+KPX Yacute eogonek -80
+KPX Yacute o -100
+KPX Yacute oacute -100
+KPX Yacute ocircumflex -100
+KPX Yacute odieresis -100
+KPX Yacute ograve -100
+KPX Yacute ohungarumlaut -100
+KPX Yacute omacron -100
+KPX Yacute oslash -100
+KPX Yacute otilde -100
+KPX Yacute period -100
+KPX Yacute semicolon -50
+KPX Yacute u -100
+KPX Yacute uacute -100
+KPX Yacute ucircumflex -100
+KPX Yacute udieresis -100
+KPX Yacute ugrave -100
+KPX Yacute uhungarumlaut -100
+KPX Yacute umacron -100
+KPX Yacute uogonek -100
+KPX Yacute uring -100
+KPX Ydieresis A -110
+KPX Ydieresis Aacute -110
+KPX Ydieresis Abreve -110
+KPX Ydieresis Acircumflex -110
+KPX Ydieresis Adieresis -110
+KPX Ydieresis Agrave -110
+KPX Ydieresis Amacron -110
+KPX Ydieresis Aogonek -110
+KPX Ydieresis Aring -110
+KPX Ydieresis Atilde -110
+KPX Ydieresis O -70
+KPX Ydieresis Oacute -70
+KPX Ydieresis Ocircumflex -70
+KPX Ydieresis Odieresis -70
+KPX Ydieresis Ograve -70
+KPX Ydieresis Ohungarumlaut -70
+KPX Ydieresis Omacron -70
+KPX Ydieresis Oslash -70
+KPX Ydieresis Otilde -70
+KPX Ydieresis a -90
+KPX Ydieresis aacute -90
+KPX Ydieresis abreve -90
+KPX Ydieresis acircumflex -90
+KPX Ydieresis adieresis -90
+KPX Ydieresis agrave -90
+KPX Ydieresis amacron -90
+KPX Ydieresis aogonek -90
+KPX Ydieresis aring -90
+KPX Ydieresis atilde -90
+KPX Ydieresis colon -50
+KPX Ydieresis comma -100
+KPX Ydieresis e -80
+KPX Ydieresis eacute -80
+KPX Ydieresis ecaron -80
+KPX Ydieresis ecircumflex -80
+KPX Ydieresis edieresis -80
+KPX Ydieresis edotaccent -80
+KPX Ydieresis egrave -80
+KPX Ydieresis emacron -80
+KPX Ydieresis eogonek -80
+KPX Ydieresis o -100
+KPX Ydieresis oacute -100
+KPX Ydieresis ocircumflex -100
+KPX Ydieresis odieresis -100
+KPX Ydieresis ograve -100
+KPX Ydieresis ohungarumlaut -100
+KPX Ydieresis omacron -100
+KPX Ydieresis oslash -100
+KPX Ydieresis otilde -100
+KPX Ydieresis period -100
+KPX Ydieresis semicolon -50
+KPX Ydieresis u -100
+KPX Ydieresis uacute -100
+KPX Ydieresis ucircumflex -100
+KPX Ydieresis udieresis -100
+KPX Ydieresis ugrave -100
+KPX Ydieresis uhungarumlaut -100
+KPX Ydieresis umacron -100
+KPX Ydieresis uogonek -100
+KPX Ydieresis uring -100
+KPX a g -10
+KPX a gbreve -10
+KPX a gcommaaccent -10
+KPX a v -15
+KPX a w -15
+KPX a y -20
+KPX a yacute -20
+KPX a ydieresis -20
+KPX aacute g -10
+KPX aacute gbreve -10
+KPX aacute gcommaaccent -10
+KPX aacute v -15
+KPX aacute w -15
+KPX aacute y -20
+KPX aacute yacute -20
+KPX aacute ydieresis -20
+KPX abreve g -10
+KPX abreve gbreve -10
+KPX abreve gcommaaccent -10
+KPX abreve v -15
+KPX abreve w -15
+KPX abreve y -20
+KPX abreve yacute -20
+KPX abreve ydieresis -20
+KPX acircumflex g -10
+KPX acircumflex gbreve -10
+KPX acircumflex gcommaaccent -10
+KPX acircumflex v -15
+KPX acircumflex w -15
+KPX acircumflex y -20
+KPX acircumflex yacute -20
+KPX acircumflex ydieresis -20
+KPX adieresis g -10
+KPX adieresis gbreve -10
+KPX adieresis gcommaaccent -10
+KPX adieresis v -15
+KPX adieresis w -15
+KPX adieresis y -20
+KPX adieresis yacute -20
+KPX adieresis ydieresis -20
+KPX agrave g -10
+KPX agrave gbreve -10
+KPX agrave gcommaaccent -10
+KPX agrave v -15
+KPX agrave w -15
+KPX agrave y -20
+KPX agrave yacute -20
+KPX agrave ydieresis -20
+KPX amacron g -10
+KPX amacron gbreve -10
+KPX amacron gcommaaccent -10
+KPX amacron v -15
+KPX amacron w -15
+KPX amacron y -20
+KPX amacron yacute -20
+KPX amacron ydieresis -20
+KPX aogonek g -10
+KPX aogonek gbreve -10
+KPX aogonek gcommaaccent -10
+KPX aogonek v -15
+KPX aogonek w -15
+KPX aogonek y -20
+KPX aogonek yacute -20
+KPX aogonek ydieresis -20
+KPX aring g -10
+KPX aring gbreve -10
+KPX aring gcommaaccent -10
+KPX aring v -15
+KPX aring w -15
+KPX aring y -20
+KPX aring yacute -20
+KPX aring ydieresis -20
+KPX atilde g -10
+KPX atilde gbreve -10
+KPX atilde gcommaaccent -10
+KPX atilde v -15
+KPX atilde w -15
+KPX atilde y -20
+KPX atilde yacute -20
+KPX atilde ydieresis -20
+KPX b l -10
+KPX b lacute -10
+KPX b lcommaaccent -10
+KPX b lslash -10
+KPX b u -20
+KPX b uacute -20
+KPX b ucircumflex -20
+KPX b udieresis -20
+KPX b ugrave -20
+KPX b uhungarumlaut -20
+KPX b umacron -20
+KPX b uogonek -20
+KPX b uring -20
+KPX b v -20
+KPX b y -20
+KPX b yacute -20
+KPX b ydieresis -20
+KPX c h -10
+KPX c k -20
+KPX c kcommaaccent -20
+KPX c l -20
+KPX c lacute -20
+KPX c lcommaaccent -20
+KPX c lslash -20
+KPX c y -10
+KPX c yacute -10
+KPX c ydieresis -10
+KPX cacute h -10
+KPX cacute k -20
+KPX cacute kcommaaccent -20
+KPX cacute l -20
+KPX cacute lacute -20
+KPX cacute lcommaaccent -20
+KPX cacute lslash -20
+KPX cacute y -10
+KPX cacute yacute -10
+KPX cacute ydieresis -10
+KPX ccaron h -10
+KPX ccaron k -20
+KPX ccaron kcommaaccent -20
+KPX ccaron l -20
+KPX ccaron lacute -20
+KPX ccaron lcommaaccent -20
+KPX ccaron lslash -20
+KPX ccaron y -10
+KPX ccaron yacute -10
+KPX ccaron ydieresis -10
+KPX ccedilla h -10
+KPX ccedilla k -20
+KPX ccedilla kcommaaccent -20
+KPX ccedilla l -20
+KPX ccedilla lacute -20
+KPX ccedilla lcommaaccent -20
+KPX ccedilla lslash -20
+KPX ccedilla y -10
+KPX ccedilla yacute -10
+KPX ccedilla ydieresis -10
+KPX colon space -40
+KPX comma quotedblright -120
+KPX comma quoteright -120
+KPX comma space -40
+KPX d d -10
+KPX d dcroat -10
+KPX d v -15
+KPX d w -15
+KPX d y -15
+KPX d yacute -15
+KPX d ydieresis -15
+KPX dcroat d -10
+KPX dcroat dcroat -10
+KPX dcroat v -15
+KPX dcroat w -15
+KPX dcroat y -15
+KPX dcroat yacute -15
+KPX dcroat ydieresis -15
+KPX e comma 10
+KPX e period 20
+KPX e v -15
+KPX e w -15
+KPX e x -15
+KPX e y -15
+KPX e yacute -15
+KPX e ydieresis -15
+KPX eacute comma 10
+KPX eacute period 20
+KPX eacute v -15
+KPX eacute w -15
+KPX eacute x -15
+KPX eacute y -15
+KPX eacute yacute -15
+KPX eacute ydieresis -15
+KPX ecaron comma 10
+KPX ecaron period 20
+KPX ecaron v -15
+KPX ecaron w -15
+KPX ecaron x -15
+KPX ecaron y -15
+KPX ecaron yacute -15
+KPX ecaron ydieresis -15
+KPX ecircumflex comma 10
+KPX ecircumflex period 20
+KPX ecircumflex v -15
+KPX ecircumflex w -15
+KPX ecircumflex x -15
+KPX ecircumflex y -15
+KPX ecircumflex yacute -15
+KPX ecircumflex ydieresis -15
+KPX edieresis comma 10
+KPX edieresis period 20
+KPX edieresis v -15
+KPX edieresis w -15
+KPX edieresis x -15
+KPX edieresis y -15
+KPX edieresis yacute -15
+KPX edieresis ydieresis -15
+KPX edotaccent comma 10
+KPX edotaccent period 20
+KPX edotaccent v -15
+KPX edotaccent w -15
+KPX edotaccent x -15
+KPX edotaccent y -15
+KPX edotaccent yacute -15
+KPX edotaccent ydieresis -15
+KPX egrave comma 10
+KPX egrave period 20
+KPX egrave v -15
+KPX egrave w -15
+KPX egrave x -15
+KPX egrave y -15
+KPX egrave yacute -15
+KPX egrave ydieresis -15
+KPX emacron comma 10
+KPX emacron period 20
+KPX emacron v -15
+KPX emacron w -15
+KPX emacron x -15
+KPX emacron y -15
+KPX emacron yacute -15
+KPX emacron ydieresis -15
+KPX eogonek comma 10
+KPX eogonek period 20
+KPX eogonek v -15
+KPX eogonek w -15
+KPX eogonek x -15
+KPX eogonek y -15
+KPX eogonek yacute -15
+KPX eogonek ydieresis -15
+KPX f comma -10
+KPX f e -10
+KPX f eacute -10
+KPX f ecaron -10
+KPX f ecircumflex -10
+KPX f edieresis -10
+KPX f edotaccent -10
+KPX f egrave -10
+KPX f emacron -10
+KPX f eogonek -10
+KPX f o -20
+KPX f oacute -20
+KPX f ocircumflex -20
+KPX f odieresis -20
+KPX f ograve -20
+KPX f ohungarumlaut -20
+KPX f omacron -20
+KPX f oslash -20
+KPX f otilde -20
+KPX f period -10
+KPX f quotedblright 30
+KPX f quoteright 30
+KPX g e 10
+KPX g eacute 10
+KPX g ecaron 10
+KPX g ecircumflex 10
+KPX g edieresis 10
+KPX g edotaccent 10
+KPX g egrave 10
+KPX g emacron 10
+KPX g eogonek 10
+KPX g g -10
+KPX g gbreve -10
+KPX g gcommaaccent -10
+KPX gbreve e 10
+KPX gbreve eacute 10
+KPX gbreve ecaron 10
+KPX gbreve ecircumflex 10
+KPX gbreve edieresis 10
+KPX gbreve edotaccent 10
+KPX gbreve egrave 10
+KPX gbreve emacron 10
+KPX gbreve eogonek 10
+KPX gbreve g -10
+KPX gbreve gbreve -10
+KPX gbreve gcommaaccent -10
+KPX gcommaaccent e 10
+KPX gcommaaccent eacute 10
+KPX gcommaaccent ecaron 10
+KPX gcommaaccent ecircumflex 10
+KPX gcommaaccent edieresis 10
+KPX gcommaaccent edotaccent 10
+KPX gcommaaccent egrave 10
+KPX gcommaaccent emacron 10
+KPX gcommaaccent eogonek 10
+KPX gcommaaccent g -10
+KPX gcommaaccent gbreve -10
+KPX gcommaaccent gcommaaccent -10
+KPX h y -20
+KPX h yacute -20
+KPX h ydieresis -20
+KPX k o -15
+KPX k oacute -15
+KPX k ocircumflex -15
+KPX k odieresis -15
+KPX k ograve -15
+KPX k ohungarumlaut -15
+KPX k omacron -15
+KPX k oslash -15
+KPX k otilde -15
+KPX kcommaaccent o -15
+KPX kcommaaccent oacute -15
+KPX kcommaaccent ocircumflex -15
+KPX kcommaaccent odieresis -15
+KPX kcommaaccent ograve -15
+KPX kcommaaccent ohungarumlaut -15
+KPX kcommaaccent omacron -15
+KPX kcommaaccent oslash -15
+KPX kcommaaccent otilde -15
+KPX l w -15
+KPX l y -15
+KPX l yacute -15
+KPX l ydieresis -15
+KPX lacute w -15
+KPX lacute y -15
+KPX lacute yacute -15
+KPX lacute ydieresis -15
+KPX lcommaaccent w -15
+KPX lcommaaccent y -15
+KPX lcommaaccent yacute -15
+KPX lcommaaccent ydieresis -15
+KPX lslash w -15
+KPX lslash y -15
+KPX lslash yacute -15
+KPX lslash ydieresis -15
+KPX m u -20
+KPX m uacute -20
+KPX m ucircumflex -20
+KPX m udieresis -20
+KPX m ugrave -20
+KPX m uhungarumlaut -20
+KPX m umacron -20
+KPX m uogonek -20
+KPX m uring -20
+KPX m y -30
+KPX m yacute -30
+KPX m ydieresis -30
+KPX n u -10
+KPX n uacute -10
+KPX n ucircumflex -10
+KPX n udieresis -10
+KPX n ugrave -10
+KPX n uhungarumlaut -10
+KPX n umacron -10
+KPX n uogonek -10
+KPX n uring -10
+KPX n v -40
+KPX n y -20
+KPX n yacute -20
+KPX n ydieresis -20
+KPX nacute u -10
+KPX nacute uacute -10
+KPX nacute ucircumflex -10
+KPX nacute udieresis -10
+KPX nacute ugrave -10
+KPX nacute uhungarumlaut -10
+KPX nacute umacron -10
+KPX nacute uogonek -10
+KPX nacute uring -10
+KPX nacute v -40
+KPX nacute y -20
+KPX nacute yacute -20
+KPX nacute ydieresis -20
+KPX ncaron u -10
+KPX ncaron uacute -10
+KPX ncaron ucircumflex -10
+KPX ncaron udieresis -10
+KPX ncaron ugrave -10
+KPX ncaron uhungarumlaut -10
+KPX ncaron umacron -10
+KPX ncaron uogonek -10
+KPX ncaron uring -10
+KPX ncaron v -40
+KPX ncaron y -20
+KPX ncaron yacute -20
+KPX ncaron ydieresis -20
+KPX ncommaaccent u -10
+KPX ncommaaccent uacute -10
+KPX ncommaaccent ucircumflex -10
+KPX ncommaaccent udieresis -10
+KPX ncommaaccent ugrave -10
+KPX ncommaaccent uhungarumlaut -10
+KPX ncommaaccent umacron -10
+KPX ncommaaccent uogonek -10
+KPX ncommaaccent uring -10
+KPX ncommaaccent v -40
+KPX ncommaaccent y -20
+KPX ncommaaccent yacute -20
+KPX ncommaaccent ydieresis -20
+KPX ntilde u -10
+KPX ntilde uacute -10
+KPX ntilde ucircumflex -10
+KPX ntilde udieresis -10
+KPX ntilde ugrave -10
+KPX ntilde uhungarumlaut -10
+KPX ntilde umacron -10
+KPX ntilde uogonek -10
+KPX ntilde uring -10
+KPX ntilde v -40
+KPX ntilde y -20
+KPX ntilde yacute -20
+KPX ntilde ydieresis -20
+KPX o v -20
+KPX o w -15
+KPX o x -30
+KPX o y -20
+KPX o yacute -20
+KPX o ydieresis -20
+KPX oacute v -20
+KPX oacute w -15
+KPX oacute x -30
+KPX oacute y -20
+KPX oacute yacute -20
+KPX oacute ydieresis -20
+KPX ocircumflex v -20
+KPX ocircumflex w -15
+KPX ocircumflex x -30
+KPX ocircumflex y -20
+KPX ocircumflex yacute -20
+KPX ocircumflex ydieresis -20
+KPX odieresis v -20
+KPX odieresis w -15
+KPX odieresis x -30
+KPX odieresis y -20
+KPX odieresis yacute -20
+KPX odieresis ydieresis -20
+KPX ograve v -20
+KPX ograve w -15
+KPX ograve x -30
+KPX ograve y -20
+KPX ograve yacute -20
+KPX ograve ydieresis -20
+KPX ohungarumlaut v -20
+KPX ohungarumlaut w -15
+KPX ohungarumlaut x -30
+KPX ohungarumlaut y -20
+KPX ohungarumlaut yacute -20
+KPX ohungarumlaut ydieresis -20
+KPX omacron v -20
+KPX omacron w -15
+KPX omacron x -30
+KPX omacron y -20
+KPX omacron yacute -20
+KPX omacron ydieresis -20
+KPX oslash v -20
+KPX oslash w -15
+KPX oslash x -30
+KPX oslash y -20
+KPX oslash yacute -20
+KPX oslash ydieresis -20
+KPX otilde v -20
+KPX otilde w -15
+KPX otilde x -30
+KPX otilde y -20
+KPX otilde yacute -20
+KPX otilde ydieresis -20
+KPX p y -15
+KPX p yacute -15
+KPX p ydieresis -15
+KPX period quotedblright -120
+KPX period quoteright -120
+KPX period space -40
+KPX quotedblright space -80
+KPX quoteleft quoteleft -46
+KPX quoteright d -80
+KPX quoteright dcroat -80
+KPX quoteright l -20
+KPX quoteright lacute -20
+KPX quoteright lcommaaccent -20
+KPX quoteright lslash -20
+KPX quoteright quoteright -46
+KPX quoteright r -40
+KPX quoteright racute -40
+KPX quoteright rcaron -40
+KPX quoteright rcommaaccent -40
+KPX quoteright s -60
+KPX quoteright sacute -60
+KPX quoteright scaron -60
+KPX quoteright scedilla -60
+KPX quoteright scommaaccent -60
+KPX quoteright space -80
+KPX quoteright v -20
+KPX r c -20
+KPX r cacute -20
+KPX r ccaron -20
+KPX r ccedilla -20
+KPX r comma -60
+KPX r d -20
+KPX r dcroat -20
+KPX r g -15
+KPX r gbreve -15
+KPX r gcommaaccent -15
+KPX r hyphen -20
+KPX r o -20
+KPX r oacute -20
+KPX r ocircumflex -20
+KPX r odieresis -20
+KPX r ograve -20
+KPX r ohungarumlaut -20
+KPX r omacron -20
+KPX r oslash -20
+KPX r otilde -20
+KPX r period -60
+KPX r q -20
+KPX r s -15
+KPX r sacute -15
+KPX r scaron -15
+KPX r scedilla -15
+KPX r scommaaccent -15
+KPX r t 20
+KPX r tcommaaccent 20
+KPX r v 10
+KPX r y 10
+KPX r yacute 10
+KPX r ydieresis 10
+KPX racute c -20
+KPX racute cacute -20
+KPX racute ccaron -20
+KPX racute ccedilla -20
+KPX racute comma -60
+KPX racute d -20
+KPX racute dcroat -20
+KPX racute g -15
+KPX racute gbreve -15
+KPX racute gcommaaccent -15
+KPX racute hyphen -20
+KPX racute o -20
+KPX racute oacute -20
+KPX racute ocircumflex -20
+KPX racute odieresis -20
+KPX racute ograve -20
+KPX racute ohungarumlaut -20
+KPX racute omacron -20
+KPX racute oslash -20
+KPX racute otilde -20
+KPX racute period -60
+KPX racute q -20
+KPX racute s -15
+KPX racute sacute -15
+KPX racute scaron -15
+KPX racute scedilla -15
+KPX racute scommaaccent -15
+KPX racute t 20
+KPX racute tcommaaccent 20
+KPX racute v 10
+KPX racute y 10
+KPX racute yacute 10
+KPX racute ydieresis 10
+KPX rcaron c -20
+KPX rcaron cacute -20
+KPX rcaron ccaron -20
+KPX rcaron ccedilla -20
+KPX rcaron comma -60
+KPX rcaron d -20
+KPX rcaron dcroat -20
+KPX rcaron g -15
+KPX rcaron gbreve -15
+KPX rcaron gcommaaccent -15
+KPX rcaron hyphen -20
+KPX rcaron o -20
+KPX rcaron oacute -20
+KPX rcaron ocircumflex -20
+KPX rcaron odieresis -20
+KPX rcaron ograve -20
+KPX rcaron ohungarumlaut -20
+KPX rcaron omacron -20
+KPX rcaron oslash -20
+KPX rcaron otilde -20
+KPX rcaron period -60
+KPX rcaron q -20
+KPX rcaron s -15
+KPX rcaron sacute -15
+KPX rcaron scaron -15
+KPX rcaron scedilla -15
+KPX rcaron scommaaccent -15
+KPX rcaron t 20
+KPX rcaron tcommaaccent 20
+KPX rcaron v 10
+KPX rcaron y 10
+KPX rcaron yacute 10
+KPX rcaron ydieresis 10
+KPX rcommaaccent c -20
+KPX rcommaaccent cacute -20
+KPX rcommaaccent ccaron -20
+KPX rcommaaccent ccedilla -20
+KPX rcommaaccent comma -60
+KPX rcommaaccent d -20
+KPX rcommaaccent dcroat -20
+KPX rcommaaccent g -15
+KPX rcommaaccent gbreve -15
+KPX rcommaaccent gcommaaccent -15
+KPX rcommaaccent hyphen -20
+KPX rcommaaccent o -20
+KPX rcommaaccent oacute -20
+KPX rcommaaccent ocircumflex -20
+KPX rcommaaccent odieresis -20
+KPX rcommaaccent ograve -20
+KPX rcommaaccent ohungarumlaut -20
+KPX rcommaaccent omacron -20
+KPX rcommaaccent oslash -20
+KPX rcommaaccent otilde -20
+KPX rcommaaccent period -60
+KPX rcommaaccent q -20
+KPX rcommaaccent s -15
+KPX rcommaaccent sacute -15
+KPX rcommaaccent scaron -15
+KPX rcommaaccent scedilla -15
+KPX rcommaaccent scommaaccent -15
+KPX rcommaaccent t 20
+KPX rcommaaccent tcommaaccent 20
+KPX rcommaaccent v 10
+KPX rcommaaccent y 10
+KPX rcommaaccent yacute 10
+KPX rcommaaccent ydieresis 10
+KPX s w -15
+KPX sacute w -15
+KPX scaron w -15
+KPX scedilla w -15
+KPX scommaaccent w -15
+KPX semicolon space -40
+KPX space T -100
+KPX space Tcaron -100
+KPX space Tcommaaccent -100
+KPX space V -80
+KPX space W -80
+KPX space Y -120
+KPX space Yacute -120
+KPX space Ydieresis -120
+KPX space quotedblleft -80
+KPX space quoteleft -60
+KPX v a -20
+KPX v aacute -20
+KPX v abreve -20
+KPX v acircumflex -20
+KPX v adieresis -20
+KPX v agrave -20
+KPX v amacron -20
+KPX v aogonek -20
+KPX v aring -20
+KPX v atilde -20
+KPX v comma -80
+KPX v o -30
+KPX v oacute -30
+KPX v ocircumflex -30
+KPX v odieresis -30
+KPX v ograve -30
+KPX v ohungarumlaut -30
+KPX v omacron -30
+KPX v oslash -30
+KPX v otilde -30
+KPX v period -80
+KPX w comma -40
+KPX w o -20
+KPX w oacute -20
+KPX w ocircumflex -20
+KPX w odieresis -20
+KPX w ograve -20
+KPX w ohungarumlaut -20
+KPX w omacron -20
+KPX w oslash -20
+KPX w otilde -20
+KPX w period -40
+KPX x e -10
+KPX x eacute -10
+KPX x ecaron -10
+KPX x ecircumflex -10
+KPX x edieresis -10
+KPX x edotaccent -10
+KPX x egrave -10
+KPX x emacron -10
+KPX x eogonek -10
+KPX y a -30
+KPX y aacute -30
+KPX y abreve -30
+KPX y acircumflex -30
+KPX y adieresis -30
+KPX y agrave -30
+KPX y amacron -30
+KPX y aogonek -30
+KPX y aring -30
+KPX y atilde -30
+KPX y comma -80
+KPX y e -10
+KPX y eacute -10
+KPX y ecaron -10
+KPX y ecircumflex -10
+KPX y edieresis -10
+KPX y edotaccent -10
+KPX y egrave -10
+KPX y emacron -10
+KPX y eogonek -10
+KPX y o -25
+KPX y oacute -25
+KPX y ocircumflex -25
+KPX y odieresis -25
+KPX y ograve -25
+KPX y ohungarumlaut -25
+KPX y omacron -25
+KPX y oslash -25
+KPX y otilde -25
+KPX y period -80
+KPX yacute a -30
+KPX yacute aacute -30
+KPX yacute abreve -30
+KPX yacute acircumflex -30
+KPX yacute adieresis -30
+KPX yacute agrave -30
+KPX yacute amacron -30
+KPX yacute aogonek -30
+KPX yacute aring -30
+KPX yacute atilde -30
+KPX yacute comma -80
+KPX yacute e -10
+KPX yacute eacute -10
+KPX yacute ecaron -10
+KPX yacute ecircumflex -10
+KPX yacute edieresis -10
+KPX yacute edotaccent -10
+KPX yacute egrave -10
+KPX yacute emacron -10
+KPX yacute eogonek -10
+KPX yacute o -25
+KPX yacute oacute -25
+KPX yacute ocircumflex -25
+KPX yacute odieresis -25
+KPX yacute ograve -25
+KPX yacute ohungarumlaut -25
+KPX yacute omacron -25
+KPX yacute oslash -25
+KPX yacute otilde -25
+KPX yacute period -80
+KPX ydieresis a -30
+KPX ydieresis aacute -30
+KPX ydieresis abreve -30
+KPX ydieresis acircumflex -30
+KPX ydieresis adieresis -30
+KPX ydieresis agrave -30
+KPX ydieresis amacron -30
+KPX ydieresis aogonek -30
+KPX ydieresis aring -30
+KPX ydieresis atilde -30
+KPX ydieresis comma -80
+KPX ydieresis e -10
+KPX ydieresis eacute -10
+KPX ydieresis ecaron -10
+KPX ydieresis ecircumflex -10
+KPX ydieresis edieresis -10
+KPX ydieresis edotaccent -10
+KPX ydieresis egrave -10
+KPX ydieresis emacron -10
+KPX ydieresis eogonek -10
+KPX ydieresis o -25
+KPX ydieresis oacute -25
+KPX ydieresis ocircumflex -25
+KPX ydieresis odieresis -25
+KPX ydieresis ograve -25
+KPX ydieresis ohungarumlaut -25
+KPX ydieresis omacron -25
+KPX ydieresis oslash -25
+KPX ydieresis otilde -25
+KPX ydieresis period -80
+KPX z e 10
+KPX z eacute 10
+KPX z ecaron 10
+KPX z ecircumflex 10
+KPX z edieresis 10
+KPX z edotaccent 10
+KPX z egrave 10
+KPX z emacron 10
+KPX z eogonek 10
+KPX zacute e 10
+KPX zacute eacute 10
+KPX zacute ecaron 10
+KPX zacute ecircumflex 10
+KPX zacute edieresis 10
+KPX zacute edotaccent 10
+KPX zacute egrave 10
+KPX zacute emacron 10
+KPX zacute eogonek 10
+KPX zcaron e 10
+KPX zcaron eacute 10
+KPX zcaron ecaron 10
+KPX zcaron ecircumflex 10
+KPX zcaron edieresis 10
+KPX zcaron edotaccent 10
+KPX zcaron egrave 10
+KPX zcaron emacron 10
+KPX zcaron eogonek 10
+KPX zdotaccent e 10
+KPX zdotaccent eacute 10
+KPX zdotaccent ecaron 10
+KPX zdotaccent ecircumflex 10
+KPX zdotaccent edieresis 10
+KPX zdotaccent edotaccent 10
+KPX zdotaccent egrave 10
+KPX zdotaccent emacron 10
+KPX zdotaccent eogonek 10
+EndKernPairs
+EndKernData
+EndFontMetrics
Added: trunk/mapbender/http/classes/fonts/Helvetica-BoldOblique.afm
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/fonts/Helvetica-BoldOblique.afm?view=auto&rev=13
--- (empty file)
+++ trunk/mapbender/http/classes/fonts/Helvetica-BoldOblique.afm 2006-04-13 19:38:28+0000
@@ -0,0 +1,2827 @@
+StartFontMetrics 4.1
+Comment Copyright (c) 1985, 1987, 1989, 1990, 1997 Adobe Systems Incorporated. All Rights Reserved.
+Comment Creation Date: Thu May 1 12:45:12 1997
+Comment UniqueID 43053
+Comment VMusage 14482 68586
+FontName Helvetica-BoldOblique
+FullName Helvetica Bold Oblique
+FamilyName Helvetica
+Weight Bold
+ItalicAngle -12
+IsFixedPitch false
+CharacterSet ExtendedRoman
+FontBBox -174 -228 1114 962
+UnderlinePosition -100
+UnderlineThickness 50
+Version 002.000
+Notice Copyright (c) 1985, 1987, 1989, 1990, 1997 Adobe Systems Incorporated. All Rights Reserved.Helvetica is a trademark of Linotype-Hell AG and/or its subsidiaries.
+EncodingScheme AdobeStandardEncoding
+CapHeight 718
+XHeight 532
+Ascender 718
+Descender -207
+StdHW 118
+StdVW 140
+StartCharMetrics 315
+C 32 ; WX 278 ; N space ; B 0 0 0 0 ;
+C 33 ; WX 333 ; N exclam ; B 94 0 397 718 ;
+C 34 ; WX 474 ; N quotedbl ; B 193 447 529 718 ;
+C 35 ; WX 556 ; N numbersign ; B 60 0 644 698 ;
+C 36 ; WX 556 ; N dollar ; B 67 -115 622 775 ;
+C 37 ; WX 889 ; N percent ; B 136 -19 901 710 ;
+C 38 ; WX 722 ; N ampersand ; B 89 -19 732 718 ;
+C 39 ; WX 278 ; N quoteright ; B 167 445 362 718 ;
+C 40 ; WX 333 ; N parenleft ; B 76 -208 470 734 ;
+C 41 ; WX 333 ; N parenright ; B -25 -208 369 734 ;
+C 42 ; WX 389 ; N asterisk ; B 146 387 481 718 ;
+C 43 ; WX 584 ; N plus ; B 82 0 610 506 ;
+C 44 ; WX 278 ; N comma ; B 28 -168 245 146 ;
+C 45 ; WX 333 ; N hyphen ; B 73 215 379 345 ;
+C 46 ; WX 278 ; N period ; B 64 0 245 146 ;
+C 47 ; WX 278 ; N slash ; B -37 -19 468 737 ;
+C 48 ; WX 556 ; N zero ; B 86 -19 617 710 ;
+C 49 ; WX 556 ; N one ; B 173 0 529 710 ;
+C 50 ; WX 556 ; N two ; B 26 0 619 710 ;
+C 51 ; WX 556 ; N three ; B 65 -19 608 710 ;
+C 52 ; WX 556 ; N four ; B 60 0 598 710 ;
+C 53 ; WX 556 ; N five ; B 64 -19 636 698 ;
+C 54 ; WX 556 ; N six ; B 85 -19 619 710 ;
+C 55 ; WX 556 ; N seven ; B 125 0 676 698 ;
+C 56 ; WX 556 ; N eight ; B 69 -19 616 710 ;
+C 57 ; WX 556 ; N nine ; B 78 -19 615 710 ;
+C 58 ; WX 333 ; N colon ; B 92 0 351 512 ;
+C 59 ; WX 333 ; N semicolon ; B 56 -168 351 512 ;
+C 60 ; WX 584 ; N less ; B 82 -8 655 514 ;
+C 61 ; WX 584 ; N equal ; B 58 87 633 419 ;
+C 62 ; WX 584 ; N greater ; B 36 -8 609 514 ;
+C 63 ; WX 611 ; N question ; B 165 0 671 727 ;
+C 64 ; WX 975 ; N at ; B 186 -19 954 737 ;
+C 65 ; WX 722 ; N A ; B 20 0 702 718 ;
+C 66 ; WX 722 ; N B ; B 76 0 764 718 ;
+C 67 ; WX 722 ; N C ; B 107 -19 789 737 ;
+C 68 ; WX 722 ; N D ; B 76 0 777 718 ;
+C 69 ; WX 667 ; N E ; B 76 0 757 718 ;
+C 70 ; WX 611 ; N F ; B 76 0 740 718 ;
+C 71 ; WX 778 ; N G ; B 108 -19 817 737 ;
+C 72 ; WX 722 ; N H ; B 71 0 804 718 ;
+C 73 ; WX 278 ; N I ; B 64 0 367 718 ;
+C 74 ; WX 556 ; N J ; B 60 -18 637 718 ;
+C 75 ; WX 722 ; N K ; B 87 0 858 718 ;
+C 76 ; WX 611 ; N L ; B 76 0 611 718 ;
+C 77 ; WX 833 ; N M ; B 69 0 918 718 ;
+C 78 ; WX 722 ; N N ; B 69 0 807 718 ;
+C 79 ; WX 778 ; N O ; B 107 -19 823 737 ;
+C 80 ; WX 667 ; N P ; B 76 0 738 718 ;
+C 81 ; WX 778 ; N Q ; B 107 -52 823 737 ;
+C 82 ; WX 722 ; N R ; B 76 0 778 718 ;
+C 83 ; WX 667 ; N S ; B 81 -19 718 737 ;
+C 84 ; WX 611 ; N T ; B 140 0 751 718 ;
+C 85 ; WX 722 ; N U ; B 116 -19 804 718 ;
+C 86 ; WX 667 ; N V ; B 172 0 801 718 ;
+C 87 ; WX 944 ; N W ; B 169 0 1082 718 ;
+C 88 ; WX 667 ; N X ; B 14 0 791 718 ;
+C 89 ; WX 667 ; N Y ; B 168 0 806 718 ;
+C 90 ; WX 611 ; N Z ; B 25 0 737 718 ;
+C 91 ; WX 333 ; N bracketleft ; B 21 -196 462 722 ;
+C 92 ; WX 278 ; N backslash ; B 124 -19 307 737 ;
+C 93 ; WX 333 ; N bracketright ; B -18 -196 423 722 ;
+C 94 ; WX 584 ; N asciicircum ; B 131 323 591 698 ;
+C 95 ; WX 556 ; N underscore ; B -27 -125 540 -75 ;
+C 96 ; WX 278 ; N quoteleft ; B 165 454 361 727 ;
+C 97 ; WX 556 ; N a ; B 55 -14 583 546 ;
+C 98 ; WX 611 ; N b ; B 61 -14 645 718 ;
+C 99 ; WX 556 ; N c ; B 79 -14 599 546 ;
+C 100 ; WX 611 ; N d ; B 82 -14 704 718 ;
+C 101 ; WX 556 ; N e ; B 70 -14 593 546 ;
+C 102 ; WX 333 ; N f ; B 87 0 469 727 ; L i fi ; L l fl ;
+C 103 ; WX 611 ; N g ; B 38 -217 666 546 ;
+C 104 ; WX 611 ; N h ; B 65 0 629 718 ;
+C 105 ; WX 278 ; N i ; B 69 0 363 725 ;
+C 106 ; WX 278 ; N j ; B -42 -214 363 725 ;
+C 107 ; WX 556 ; N k ; B 69 0 670 718 ;
+C 108 ; WX 278 ; N l ; B 69 0 362 718 ;
+C 109 ; WX 889 ; N m ; B 64 0 909 546 ;
+C 110 ; WX 611 ; N n ; B 65 0 629 546 ;
+C 111 ; WX 611 ; N o ; B 82 -14 643 546 ;
+C 112 ; WX 611 ; N p ; B 18 -207 645 546 ;
+C 113 ; WX 611 ; N q ; B 80 -207 665 546 ;
+C 114 ; WX 389 ; N r ; B 64 0 489 546 ;
+C 115 ; WX 556 ; N s ; B 63 -14 584 546 ;
+C 116 ; WX 333 ; N t ; B 100 -6 422 676 ;
+C 117 ; WX 611 ; N u ; B 98 -14 658 532 ;
+C 118 ; WX 556 ; N v ; B 126 0 656 532 ;
+C 119 ; WX 778 ; N w ; B 123 0 882 532 ;
+C 120 ; WX 556 ; N x ; B 15 0 648 532 ;
+C 121 ; WX 556 ; N y ; B 42 -214 652 532 ;
+C 122 ; WX 500 ; N z ; B 20 0 583 532 ;
+C 123 ; WX 389 ; N braceleft ; B 94 -196 518 722 ;
+C 124 ; WX 280 ; N bar ; B 36 -225 361 775 ;
+C 125 ; WX 389 ; N braceright ; B -18 -196 407 722 ;
+C 126 ; WX 584 ; N asciitilde ; B 115 163 577 343 ;
+C 161 ; WX 333 ; N exclamdown ; B 50 -186 353 532 ;
+C 162 ; WX 556 ; N cent ; B 79 -118 599 628 ;
+C 163 ; WX 556 ; N sterling ; B 50 -16 635 718 ;
+C 164 ; WX 167 ; N fraction ; B -174 -19 487 710 ;
+C 165 ; WX 556 ; N yen ; B 60 0 713 698 ;
+C 166 ; WX 556 ; N florin ; B -50 -210 669 737 ;
+C 167 ; WX 556 ; N section ; B 61 -184 598 727 ;
+C 168 ; WX 556 ; N currency ; B 27 76 680 636 ;
+C 169 ; WX 238 ; N quotesingle ; B 165 447 321 718 ;
+C 170 ; WX 500 ; N quotedblleft ; B 160 454 588 727 ;
+C 171 ; WX 556 ; N guillemotleft ; B 135 76 571 484 ;
+C 172 ; WX 333 ; N guilsinglleft ; B 130 76 353 484 ;
+C 173 ; WX 333 ; N guilsinglright ; B 99 76 322 484 ;
+C 174 ; WX 611 ; N fi ; B 87 0 696 727 ;
+C 175 ; WX 611 ; N fl ; B 87 0 695 727 ;
+C 177 ; WX 556 ; N endash ; B 48 227 627 333 ;
+C 178 ; WX 556 ; N dagger ; B 118 -171 626 718 ;
+C 179 ; WX 556 ; N daggerdbl ; B 46 -171 628 718 ;
+C 180 ; WX 278 ; N periodcentered ; B 110 172 276 334 ;
+C 182 ; WX 556 ; N paragraph ; B 98 -191 688 700 ;
+C 183 ; WX 350 ; N bullet ; B 83 194 420 524 ;
+C 184 ; WX 278 ; N quotesinglbase ; B 41 -146 236 127 ;
+C 185 ; WX 500 ; N quotedblbase ; B 36 -146 463 127 ;
+C 186 ; WX 500 ; N quotedblright ; B 162 445 589 718 ;
+C 187 ; WX 556 ; N guillemotright ; B 104 76 540 484 ;
+C 188 ; WX 1000 ; N ellipsis ; B 92 0 939 146 ;
+C 189 ; WX 1000 ; N perthousand ; B 76 -19 1038 710 ;
+C 191 ; WX 611 ; N questiondown ; B 53 -195 559 532 ;
+C 193 ; WX 333 ; N grave ; B 136 604 353 750 ;
+C 194 ; WX 333 ; N acute ; B 236 604 515 750 ;
+C 195 ; WX 333 ; N circumflex ; B 118 604 471 750 ;
+C 196 ; WX 333 ; N tilde ; B 113 610 507 737 ;
+C 197 ; WX 333 ; N macron ; B 122 604 483 678 ;
+C 198 ; WX 333 ; N breve ; B 156 604 494 750 ;
+C 199 ; WX 333 ; N dotaccent ; B 235 614 385 729 ;
+C 200 ; WX 333 ; N dieresis ; B 137 614 482 729 ;
+C 202 ; WX 333 ; N ring ; B 200 568 420 776 ;
+C 203 ; WX 333 ; N cedilla ; B -37 -228 220 0 ;
+C 205 ; WX 333 ; N hungarumlaut ; B 137 604 645 750 ;
+C 206 ; WX 333 ; N ogonek ; B 41 -228 264 0 ;
+C 207 ; WX 333 ; N caron ; B 149 604 502 750 ;
+C 208 ; WX 1000 ; N emdash ; B 48 227 1071 333 ;
+C 225 ; WX 1000 ; N AE ; B 5 0 1100 718 ;
+C 227 ; WX 370 ; N ordfeminine ; B 125 401 465 737 ;
+C 232 ; WX 611 ; N Lslash ; B 34 0 611 718 ;
+C 233 ; WX 778 ; N Oslash ; B 35 -27 894 745 ;
+C 234 ; WX 1000 ; N OE ; B 99 -19 1114 737 ;
+C 235 ; WX 365 ; N ordmasculine ; B 123 401 485 737 ;
+C 241 ; WX 889 ; N ae ; B 56 -14 923 546 ;
+C 245 ; WX 278 ; N dotlessi ; B 69 0 322 532 ;
+C 248 ; WX 278 ; N lslash ; B 40 0 407 718 ;
+C 249 ; WX 611 ; N oslash ; B 22 -29 701 560 ;
+C 250 ; WX 944 ; N oe ; B 82 -14 977 546 ;
+C 251 ; WX 611 ; N germandbls ; B 69 -14 657 731 ;
+C -1 ; WX 278 ; N Idieresis ; B 64 0 494 915 ;
+C -1 ; WX 556 ; N eacute ; B 70 -14 627 750 ;
+C -1 ; WX 556 ; N abreve ; B 55 -14 606 750 ;
+C -1 ; WX 611 ; N uhungarumlaut ; B 98 -14 784 750 ;
+C -1 ; WX 556 ; N ecaron ; B 70 -14 614 750 ;
+C -1 ; WX 667 ; N Ydieresis ; B 168 0 806 915 ;
+C -1 ; WX 584 ; N divide ; B 82 -42 610 548 ;
+C -1 ; WX 667 ; N Yacute ; B 168 0 806 936 ;
+C -1 ; WX 722 ; N Acircumflex ; B 20 0 706 936 ;
+C -1 ; WX 556 ; N aacute ; B 55 -14 627 750 ;
+C -1 ; WX 722 ; N Ucircumflex ; B 116 -19 804 936 ;
+C -1 ; WX 556 ; N yacute ; B 42 -214 652 750 ;
+C -1 ; WX 556 ; N scommaaccent ; B 63 -228 584 546 ;
+C -1 ; WX 556 ; N ecircumflex ; B 70 -14 593 750 ;
+C -1 ; WX 722 ; N Uring ; B 116 -19 804 962 ;
+C -1 ; WX 722 ; N Udieresis ; B 116 -19 804 915 ;
+C -1 ; WX 556 ; N aogonek ; B 55 -224 583 546 ;
+C -1 ; WX 722 ; N Uacute ; B 116 -19 804 936 ;
+C -1 ; WX 611 ; N uogonek ; B 98 -228 658 532 ;
+C -1 ; WX 667 ; N Edieresis ; B 76 0 757 915 ;
+C -1 ; WX 722 ; N Dcroat ; B 62 0 777 718 ;
+C -1 ; WX 250 ; N commaaccent ; B 16 -228 188 -50 ;
+C -1 ; WX 737 ; N copyright ; B 56 -19 835 737 ;
+C -1 ; WX 667 ; N Emacron ; B 76 0 757 864 ;
+C -1 ; WX 556 ; N ccaron ; B 79 -14 614 750 ;
+C -1 ; WX 556 ; N aring ; B 55 -14 583 776 ;
+C -1 ; WX 722 ; N Ncommaaccent ; B 69 -228 807 718 ;
+C -1 ; WX 278 ; N lacute ; B 69 0 528 936 ;
+C -1 ; WX 556 ; N agrave ; B 55 -14 583 750 ;
+C -1 ; WX 611 ; N Tcommaaccent ; B 140 -228 751 718 ;
+C -1 ; WX 722 ; N Cacute ; B 107 -19 789 936 ;
+C -1 ; WX 556 ; N atilde ; B 55 -14 619 737 ;
+C -1 ; WX 667 ; N Edotaccent ; B 76 0 757 915 ;
+C -1 ; WX 556 ; N scaron ; B 63 -14 614 750 ;
+C -1 ; WX 556 ; N scedilla ; B 63 -228 584 546 ;
+C -1 ; WX 278 ; N iacute ; B 69 0 488 750 ;
+C -1 ; WX 494 ; N lozenge ; B 90 0 564 745 ;
+C -1 ; WX 722 ; N Rcaron ; B 76 0 778 936 ;
+C -1 ; WX 778 ; N Gcommaaccent ; B 108 -228 817 737 ;
+C -1 ; WX 611 ; N ucircumflex ; B 98 -14 658 750 ;
+C -1 ; WX 556 ; N acircumflex ; B 55 -14 583 750 ;
+C -1 ; WX 722 ; N Amacron ; B 20 0 718 864 ;
+C -1 ; WX 389 ; N rcaron ; B 64 0 530 750 ;
+C -1 ; WX 556 ; N ccedilla ; B 79 -228 599 546 ;
+C -1 ; WX 611 ; N Zdotaccent ; B 25 0 737 915 ;
+C -1 ; WX 667 ; N Thorn ; B 76 0 716 718 ;
+C -1 ; WX 778 ; N Omacron ; B 107 -19 823 864 ;
+C -1 ; WX 722 ; N Racute ; B 76 0 778 936 ;
+C -1 ; WX 667 ; N Sacute ; B 81 -19 722 936 ;
+C -1 ; WX 743 ; N dcaron ; B 82 -14 903 718 ;
+C -1 ; WX 722 ; N Umacron ; B 116 -19 804 864 ;
+C -1 ; WX 611 ; N uring ; B 98 -14 658 776 ;
+C -1 ; WX 333 ; N threesuperior ; B 91 271 441 710 ;
+C -1 ; WX 778 ; N Ograve ; B 107 -19 823 936 ;
+C -1 ; WX 722 ; N Agrave ; B 20 0 702 936 ;
+C -1 ; WX 722 ; N Abreve ; B 20 0 729 936 ;
+C -1 ; WX 584 ; N multiply ; B 57 1 635 505 ;
+C -1 ; WX 611 ; N uacute ; B 98 -14 658 750 ;
+C -1 ; WX 611 ; N Tcaron ; B 140 0 751 936 ;
+C -1 ; WX 494 ; N partialdiff ; B 43 -21 585 750 ;
+C -1 ; WX 556 ; N ydieresis ; B 42 -214 652 729 ;
+C -1 ; WX 722 ; N Nacute ; B 69 0 807 936 ;
+C -1 ; WX 278 ; N icircumflex ; B 69 0 444 750 ;
+C -1 ; WX 667 ; N Ecircumflex ; B 76 0 757 936 ;
+C -1 ; WX 556 ; N adieresis ; B 55 -14 594 729 ;
+C -1 ; WX 556 ; N edieresis ; B 70 -14 594 729 ;
+C -1 ; WX 556 ; N cacute ; B 79 -14 627 750 ;
+C -1 ; WX 611 ; N nacute ; B 65 0 654 750 ;
+C -1 ; WX 611 ; N umacron ; B 98 -14 658 678 ;
+C -1 ; WX 722 ; N Ncaron ; B 69 0 807 936 ;
+C -1 ; WX 278 ; N Iacute ; B 64 0 528 936 ;
+C -1 ; WX 584 ; N plusminus ; B 40 0 625 506 ;
+C -1 ; WX 280 ; N brokenbar ; B 52 -150 345 700 ;
+C -1 ; WX 737 ; N registered ; B 55 -19 834 737 ;
+C -1 ; WX 778 ; N Gbreve ; B 108 -19 817 936 ;
+C -1 ; WX 278 ; N Idotaccent ; B 64 0 397 915 ;
+C -1 ; WX 600 ; N summation ; B 14 -10 670 706 ;
+C -1 ; WX 667 ; N Egrave ; B 76 0 757 936 ;
+C -1 ; WX 389 ; N racute ; B 64 0 543 750 ;
+C -1 ; WX 611 ; N omacron ; B 82 -14 643 678 ;
+C -1 ; WX 611 ; N Zacute ; B 25 0 737 936 ;
+C -1 ; WX 611 ; N Zcaron ; B 25 0 737 936 ;
+C -1 ; WX 549 ; N greaterequal ; B 26 0 629 704 ;
+C -1 ; WX 722 ; N Eth ; B 62 0 777 718 ;
+C -1 ; WX 722 ; N Ccedilla ; B 107 -228 789 737 ;
+C -1 ; WX 278 ; N lcommaaccent ; B 30 -228 362 718 ;
+C -1 ; WX 389 ; N tcaron ; B 100 -6 608 878 ;
+C -1 ; WX 556 ; N eogonek ; B 70 -228 593 546 ;
+C -1 ; WX 722 ; N Uogonek ; B 116 -228 804 718 ;
+C -1 ; WX 722 ; N Aacute ; B 20 0 750 936 ;
+C -1 ; WX 722 ; N Adieresis ; B 20 0 716 915 ;
+C -1 ; WX 556 ; N egrave ; B 70 -14 593 750 ;
+C -1 ; WX 500 ; N zacute ; B 20 0 599 750 ;
+C -1 ; WX 278 ; N iogonek ; B -14 -224 363 725 ;
+C -1 ; WX 778 ; N Oacute ; B 107 -19 823 936 ;
+C -1 ; WX 611 ; N oacute ; B 82 -14 654 750 ;
+C -1 ; WX 556 ; N amacron ; B 55 -14 595 678 ;
+C -1 ; WX 556 ; N sacute ; B 63 -14 627 750 ;
+C -1 ; WX 278 ; N idieresis ; B 69 0 455 729 ;
+C -1 ; WX 778 ; N Ocircumflex ; B 107 -19 823 936 ;
+C -1 ; WX 722 ; N Ugrave ; B 116 -19 804 936 ;
+C -1 ; WX 612 ; N Delta ; B 6 0 608 688 ;
+C -1 ; WX 611 ; N thorn ; B 18 -208 645 718 ;
+C -1 ; WX 333 ; N twosuperior ; B 69 283 449 710 ;
+C -1 ; WX 778 ; N Odieresis ; B 107 -19 823 915 ;
+C -1 ; WX 611 ; N mu ; B 22 -207 658 532 ;
+C -1 ; WX 278 ; N igrave ; B 69 0 326 750 ;
+C -1 ; WX 611 ; N ohungarumlaut ; B 82 -14 784 750 ;
+C -1 ; WX 667 ; N Eogonek ; B 76 -224 757 718 ;
+C -1 ; WX 611 ; N dcroat ; B 82 -14 789 718 ;
+C -1 ; WX 834 ; N threequarters ; B 99 -19 839 710 ;
+C -1 ; WX 667 ; N Scedilla ; B 81 -228 718 737 ;
+C -1 ; WX 400 ; N lcaron ; B 69 0 561 718 ;
+C -1 ; WX 722 ; N Kcommaaccent ; B 87 -228 858 718 ;
+C -1 ; WX 611 ; N Lacute ; B 76 0 611 936 ;
+C -1 ; WX 1000 ; N trademark ; B 179 306 1109 718 ;
+C -1 ; WX 556 ; N edotaccent ; B 70 -14 593 729 ;
+C -1 ; WX 278 ; N Igrave ; B 64 0 367 936 ;
+C -1 ; WX 278 ; N Imacron ; B 64 0 496 864 ;
+C -1 ; WX 611 ; N Lcaron ; B 76 0 643 718 ;
+C -1 ; WX 834 ; N onehalf ; B 132 -19 858 710 ;
+C -1 ; WX 549 ; N lessequal ; B 29 0 676 704 ;
+C -1 ; WX 611 ; N ocircumflex ; B 82 -14 643 750 ;
+C -1 ; WX 611 ; N ntilde ; B 65 0 646 737 ;
+C -1 ; WX 722 ; N Uhungarumlaut ; B 116 -19 880 936 ;
+C -1 ; WX 667 ; N Eacute ; B 76 0 757 936 ;
+C -1 ; WX 556 ; N emacron ; B 70 -14 595 678 ;
+C -1 ; WX 611 ; N gbreve ; B 38 -217 666 750 ;
+C -1 ; WX 834 ; N onequarter ; B 132 -19 806 710 ;
+C -1 ; WX 667 ; N Scaron ; B 81 -19 718 936 ;
+C -1 ; WX 667 ; N Scommaaccent ; B 81 -228 718 737 ;
+C -1 ; WX 778 ; N Ohungarumlaut ; B 107 -19 908 936 ;
+C -1 ; WX 400 ; N degree ; B 175 426 467 712 ;
+C -1 ; WX 611 ; N ograve ; B 82 -14 643 750 ;
+C -1 ; WX 722 ; N Ccaron ; B 107 -19 789 936 ;
+C -1 ; WX 611 ; N ugrave ; B 98 -14 658 750 ;
+C -1 ; WX 549 ; N radical ; B 112 -46 689 850 ;
+C -1 ; WX 722 ; N Dcaron ; B 76 0 777 936 ;
+C -1 ; WX 389 ; N rcommaaccent ; B 26 -228 489 546 ;
+C -1 ; WX 722 ; N Ntilde ; B 69 0 807 923 ;
+C -1 ; WX 611 ; N otilde ; B 82 -14 646 737 ;
+C -1 ; WX 722 ; N Rcommaaccent ; B 76 -228 778 718 ;
+C -1 ; WX 611 ; N Lcommaaccent ; B 76 -228 611 718 ;
+C -1 ; WX 722 ; N Atilde ; B 20 0 741 923 ;
+C -1 ; WX 722 ; N Aogonek ; B 20 -224 702 718 ;
+C -1 ; WX 722 ; N Aring ; B 20 0 702 962 ;
+C -1 ; WX 778 ; N Otilde ; B 107 -19 823 923 ;
+C -1 ; WX 500 ; N zdotaccent ; B 20 0 583 729 ;
+C -1 ; WX 667 ; N Ecaron ; B 76 0 757 936 ;
+C -1 ; WX 278 ; N Iogonek ; B -41 -228 367 718 ;
+C -1 ; WX 556 ; N kcommaaccent ; B 69 -228 670 718 ;
+C -1 ; WX 584 ; N minus ; B 82 197 610 309 ;
+C -1 ; WX 278 ; N Icircumflex ; B 64 0 484 936 ;
+C -1 ; WX 611 ; N ncaron ; B 65 0 641 750 ;
+C -1 ; WX 333 ; N tcommaaccent ; B 58 -228 422 676 ;
+C -1 ; WX 584 ; N logicalnot ; B 105 108 633 419 ;
+C -1 ; WX 611 ; N odieresis ; B 82 -14 643 729 ;
+C -1 ; WX 611 ; N udieresis ; B 98 -14 658 729 ;
+C -1 ; WX 549 ; N notequal ; B 32 -49 630 570 ;
+C -1 ; WX 611 ; N gcommaaccent ; B 38 -217 666 850 ;
+C -1 ; WX 611 ; N eth ; B 82 -14 670 737 ;
+C -1 ; WX 500 ; N zcaron ; B 20 0 586 750 ;
+C -1 ; WX 611 ; N ncommaaccent ; B 65 -228 629 546 ;
+C -1 ; WX 333 ; N onesuperior ; B 148 283 388 710 ;
+C -1 ; WX 278 ; N imacron ; B 69 0 429 678 ;
+C -1 ; WX 556 ; N Euro ; B 0 0 0 0 ;
+EndCharMetrics
+StartKernData
+StartKernPairs 2481
+KPX A C -40
+KPX A Cacute -40
+KPX A Ccaron -40
+KPX A Ccedilla -40
+KPX A G -50
+KPX A Gbreve -50
+KPX A Gcommaaccent -50
+KPX A O -40
+KPX A Oacute -40
+KPX A Ocircumflex -40
+KPX A Odieresis -40
+KPX A Ograve -40
+KPX A Ohungarumlaut -40
+KPX A Omacron -40
+KPX A Oslash -40
+KPX A Otilde -40
+KPX A Q -40
+KPX A T -90
+KPX A Tcaron -90
+KPX A Tcommaaccent -90
+KPX A U -50
+KPX A Uacute -50
+KPX A Ucircumflex -50
+KPX A Udieresis -50
+KPX A Ugrave -50
+KPX A Uhungarumlaut -50
+KPX A Umacron -50
+KPX A Uogonek -50
+KPX A Uring -50
+KPX A V -80
+KPX A W -60
+KPX A Y -110
+KPX A Yacute -110
+KPX A Ydieresis -110
+KPX A u -30
+KPX A uacute -30
+KPX A ucircumflex -30
+KPX A udieresis -30
+KPX A ugrave -30
+KPX A uhungarumlaut -30
+KPX A umacron -30
+KPX A uogonek -30
+KPX A uring -30
+KPX A v -40
+KPX A w -30
+KPX A y -30
+KPX A yacute -30
+KPX A ydieresis -30
+KPX Aacute C -40
+KPX Aacute Cacute -40
+KPX Aacute Ccaron -40
+KPX Aacute Ccedilla -40
+KPX Aacute G -50
+KPX Aacute Gbreve -50
+KPX Aacute Gcommaaccent -50
+KPX Aacute O -40
+KPX Aacute Oacute -40
+KPX Aacute Ocircumflex -40
+KPX Aacute Odieresis -40
+KPX Aacute Ograve -40
+KPX Aacute Ohungarumlaut -40
+KPX Aacute Omacron -40
+KPX Aacute Oslash -40
+KPX Aacute Otilde -40
+KPX Aacute Q -40
+KPX Aacute T -90
+KPX Aacute Tcaron -90
+KPX Aacute Tcommaaccent -90
+KPX Aacute U -50
+KPX Aacute Uacute -50
+KPX Aacute Ucircumflex -50
+KPX Aacute Udieresis -50
+KPX Aacute Ugrave -50
+KPX Aacute Uhungarumlaut -50
+KPX Aacute Umacron -50
+KPX Aacute Uogonek -50
+KPX Aacute Uring -50
+KPX Aacute V -80
+KPX Aacute W -60
+KPX Aacute Y -110
+KPX Aacute Yacute -110
+KPX Aacute Ydieresis -110
+KPX Aacute u -30
+KPX Aacute uacute -30
+KPX Aacute ucircumflex -30
+KPX Aacute udieresis -30
+KPX Aacute ugrave -30
+KPX Aacute uhungarumlaut -30
+KPX Aacute umacron -30
+KPX Aacute uogonek -30
+KPX Aacute uring -30
+KPX Aacute v -40
+KPX Aacute w -30
+KPX Aacute y -30
+KPX Aacute yacute -30
+KPX Aacute ydieresis -30
+KPX Abreve C -40
+KPX Abreve Cacute -40
+KPX Abreve Ccaron -40
+KPX Abreve Ccedilla -40
+KPX Abreve G -50
+KPX Abreve Gbreve -50
+KPX Abreve Gcommaaccent -50
+KPX Abreve O -40
+KPX Abreve Oacute -40
+KPX Abreve Ocircumflex -40
+KPX Abreve Odieresis -40
+KPX Abreve Ograve -40
+KPX Abreve Ohungarumlaut -40
+KPX Abreve Omacron -40
+KPX Abreve Oslash -40
+KPX Abreve Otilde -40
+KPX Abreve Q -40
+KPX Abreve T -90
+KPX Abreve Tcaron -90
+KPX Abreve Tcommaaccent -90
+KPX Abreve U -50
+KPX Abreve Uacute -50
+KPX Abreve Ucircumflex -50
+KPX Abreve Udieresis -50
+KPX Abreve Ugrave -50
+KPX Abreve Uhungarumlaut -50
+KPX Abreve Umacron -50
+KPX Abreve Uogonek -50
+KPX Abreve Uring -50
+KPX Abreve V -80
+KPX Abreve W -60
+KPX Abreve Y -110
+KPX Abreve Yacute -110
+KPX Abreve Ydieresis -110
+KPX Abreve u -30
+KPX Abreve uacute -30
+KPX Abreve ucircumflex -30
+KPX Abreve udieresis -30
+KPX Abreve ugrave -30
+KPX Abreve uhungarumlaut -30
+KPX Abreve umacron -30
+KPX Abreve uogonek -30
+KPX Abreve uring -30
+KPX Abreve v -40
+KPX Abreve w -30
+KPX Abreve y -30
+KPX Abreve yacute -30
+KPX Abreve ydieresis -30
+KPX Acircumflex C -40
+KPX Acircumflex Cacute -40
+KPX Acircumflex Ccaron -40
+KPX Acircumflex Ccedilla -40
+KPX Acircumflex G -50
+KPX Acircumflex Gbreve -50
+KPX Acircumflex Gcommaaccent -50
+KPX Acircumflex O -40
+KPX Acircumflex Oacute -40
+KPX Acircumflex Ocircumflex -40
+KPX Acircumflex Odieresis -40
+KPX Acircumflex Ograve -40
+KPX Acircumflex Ohungarumlaut -40
+KPX Acircumflex Omacron -40
+KPX Acircumflex Oslash -40
+KPX Acircumflex Otilde -40
+KPX Acircumflex Q -40
+KPX Acircumflex T -90
+KPX Acircumflex Tcaron -90
+KPX Acircumflex Tcommaaccent -90
+KPX Acircumflex U -50
+KPX Acircumflex Uacute -50
+KPX Acircumflex Ucircumflex -50
+KPX Acircumflex Udieresis -50
+KPX Acircumflex Ugrave -50
+KPX Acircumflex Uhungarumlaut -50
+KPX Acircumflex Umacron -50
+KPX Acircumflex Uogonek -50
+KPX Acircumflex Uring -50
+KPX Acircumflex V -80
+KPX Acircumflex W -60
+KPX Acircumflex Y -110
+KPX Acircumflex Yacute -110
+KPX Acircumflex Ydieresis -110
+KPX Acircumflex u -30
+KPX Acircumflex uacute -30
+KPX Acircumflex ucircumflex -30
+KPX Acircumflex udieresis -30
+KPX Acircumflex ugrave -30
+KPX Acircumflex uhungarumlaut -30
+KPX Acircumflex umacron -30
+KPX Acircumflex uogonek -30
+KPX Acircumflex uring -30
+KPX Acircumflex v -40
+KPX Acircumflex w -30
+KPX Acircumflex y -30
+KPX Acircumflex yacute -30
+KPX Acircumflex ydieresis -30
+KPX Adieresis C -40
+KPX Adieresis Cacute -40
+KPX Adieresis Ccaron -40
+KPX Adieresis Ccedilla -40
+KPX Adieresis G -50
+KPX Adieresis Gbreve -50
+KPX Adieresis Gcommaaccent -50
+KPX Adieresis O -40
+KPX Adieresis Oacute -40
+KPX Adieresis Ocircumflex -40
+KPX Adieresis Odieresis -40
+KPX Adieresis Ograve -40
+KPX Adieresis Ohungarumlaut -40
+KPX Adieresis Omacron -40
+KPX Adieresis Oslash -40
+KPX Adieresis Otilde -40
+KPX Adieresis Q -40
+KPX Adieresis T -90
+KPX Adieresis Tcaron -90
+KPX Adieresis Tcommaaccent -90
+KPX Adieresis U -50
+KPX Adieresis Uacute -50
+KPX Adieresis Ucircumflex -50
+KPX Adieresis Udieresis -50
+KPX Adieresis Ugrave -50
+KPX Adieresis Uhungarumlaut -50
+KPX Adieresis Umacron -50
+KPX Adieresis Uogonek -50
+KPX Adieresis Uring -50
+KPX Adieresis V -80
+KPX Adieresis W -60
+KPX Adieresis Y -110
+KPX Adieresis Yacute -110
+KPX Adieresis Ydieresis -110
+KPX Adieresis u -30
+KPX Adieresis uacute -30
+KPX Adieresis ucircumflex -30
+KPX Adieresis udieresis -30
+KPX Adieresis ugrave -30
+KPX Adieresis uhungarumlaut -30
+KPX Adieresis umacron -30
+KPX Adieresis uogonek -30
+KPX Adieresis uring -30
+KPX Adieresis v -40
+KPX Adieresis w -30
+KPX Adieresis y -30
+KPX Adieresis yacute -30
+KPX Adieresis ydieresis -30
+KPX Agrave C -40
+KPX Agrave Cacute -40
+KPX Agrave Ccaron -40
+KPX Agrave Ccedilla -40
+KPX Agrave G -50
+KPX Agrave Gbreve -50
+KPX Agrave Gcommaaccent -50
+KPX Agrave O -40
+KPX Agrave Oacute -40
+KPX Agrave Ocircumflex -40
+KPX Agrave Odieresis -40
+KPX Agrave Ograve -40
+KPX Agrave Ohungarumlaut -40
+KPX Agrave Omacron -40
+KPX Agrave Oslash -40
+KPX Agrave Otilde -40
+KPX Agrave Q -40
+KPX Agrave T -90
+KPX Agrave Tcaron -90
+KPX Agrave Tcommaaccent -90
+KPX Agrave U -50
+KPX Agrave Uacute -50
+KPX Agrave Ucircumflex -50
+KPX Agrave Udieresis -50
+KPX Agrave Ugrave -50
+KPX Agrave Uhungarumlaut -50
+KPX Agrave Umacron -50
+KPX Agrave Uogonek -50
+KPX Agrave Uring -50
+KPX Agrave V -80
+KPX Agrave W -60
+KPX Agrave Y -110
+KPX Agrave Yacute -110
+KPX Agrave Ydieresis -110
+KPX Agrave u -30
+KPX Agrave uacute -30
+KPX Agrave ucircumflex -30
+KPX Agrave udieresis -30
+KPX Agrave ugrave -30
+KPX Agrave uhungarumlaut -30
+KPX Agrave umacron -30
+KPX Agrave uogonek -30
+KPX Agrave uring -30
+KPX Agrave v -40
+KPX Agrave w -30
+KPX Agrave y -30
+KPX Agrave yacute -30
+KPX Agrave ydieresis -30
+KPX Amacron C -40
+KPX Amacron Cacute -40
+KPX Amacron Ccaron -40
+KPX Amacron Ccedilla -40
+KPX Amacron G -50
+KPX Amacron Gbreve -50
+KPX Amacron Gcommaaccent -50
+KPX Amacron O -40
+KPX Amacron Oacute -40
+KPX Amacron Ocircumflex -40
+KPX Amacron Odieresis -40
+KPX Amacron Ograve -40
+KPX Amacron Ohungarumlaut -40
+KPX Amacron Omacron -40
+KPX Amacron Oslash -40
+KPX Amacron Otilde -40
+KPX Amacron Q -40
+KPX Amacron T -90
+KPX Amacron Tcaron -90
+KPX Amacron Tcommaaccent -90
+KPX Amacron U -50
+KPX Amacron Uacute -50
+KPX Amacron Ucircumflex -50
+KPX Amacron Udieresis -50
+KPX Amacron Ugrave -50
+KPX Amacron Uhungarumlaut -50
+KPX Amacron Umacron -50
+KPX Amacron Uogonek -50
+KPX Amacron Uring -50
+KPX Amacron V -80
+KPX Amacron W -60
+KPX Amacron Y -110
+KPX Amacron Yacute -110
+KPX Amacron Ydieresis -110
+KPX Amacron u -30
+KPX Amacron uacute -30
+KPX Amacron ucircumflex -30
+KPX Amacron udieresis -30
+KPX Amacron ugrave -30
+KPX Amacron uhungarumlaut -30
+KPX Amacron umacron -30
+KPX Amacron uogonek -30
+KPX Amacron uring -30
+KPX Amacron v -40
+KPX Amacron w -30
+KPX Amacron y -30
+KPX Amacron yacute -30
+KPX Amacron ydieresis -30
+KPX Aogonek C -40
+KPX Aogonek Cacute -40
+KPX Aogonek Ccaron -40
+KPX Aogonek Ccedilla -40
+KPX Aogonek G -50
+KPX Aogonek Gbreve -50
+KPX Aogonek Gcommaaccent -50
+KPX Aogonek O -40
+KPX Aogonek Oacute -40
+KPX Aogonek Ocircumflex -40
+KPX Aogonek Odieresis -40
+KPX Aogonek Ograve -40
+KPX Aogonek Ohungarumlaut -40
+KPX Aogonek Omacron -40
+KPX Aogonek Oslash -40
+KPX Aogonek Otilde -40
+KPX Aogonek Q -40
+KPX Aogonek T -90
+KPX Aogonek Tcaron -90
+KPX Aogonek Tcommaaccent -90
+KPX Aogonek U -50
+KPX Aogonek Uacute -50
+KPX Aogonek Ucircumflex -50
+KPX Aogonek Udieresis -50
+KPX Aogonek Ugrave -50
+KPX Aogonek Uhungarumlaut -50
+KPX Aogonek Umacron -50
+KPX Aogonek Uogonek -50
+KPX Aogonek Uring -50
+KPX Aogonek V -80
+KPX Aogonek W -60
+KPX Aogonek Y -110
+KPX Aogonek Yacute -110
+KPX Aogonek Ydieresis -110
+KPX Aogonek u -30
+KPX Aogonek uacute -30
+KPX Aogonek ucircumflex -30
+KPX Aogonek udieresis -30
+KPX Aogonek ugrave -30
+KPX Aogonek uhungarumlaut -30
+KPX Aogonek umacron -30
+KPX Aogonek uogonek -30
+KPX Aogonek uring -30
+KPX Aogonek v -40
+KPX Aogonek w -30
+KPX Aogonek y -30
+KPX Aogonek yacute -30
+KPX Aogonek ydieresis -30
+KPX Aring C -40
+KPX Aring Cacute -40
+KPX Aring Ccaron -40
+KPX Aring Ccedilla -40
+KPX Aring G -50
+KPX Aring Gbreve -50
+KPX Aring Gcommaaccent -50
+KPX Aring O -40
+KPX Aring Oacute -40
+KPX Aring Ocircumflex -40
+KPX Aring Odieresis -40
+KPX Aring Ograve -40
+KPX Aring Ohungarumlaut -40
+KPX Aring Omacron -40
+KPX Aring Oslash -40
+KPX Aring Otilde -40
+KPX Aring Q -40
+KPX Aring T -90
+KPX Aring Tcaron -90
+KPX Aring Tcommaaccent -90
+KPX Aring U -50
+KPX Aring Uacute -50
+KPX Aring Ucircumflex -50
+KPX Aring Udieresis -50
+KPX Aring Ugrave -50
+KPX Aring Uhungarumlaut -50
+KPX Aring Umacron -50
+KPX Aring Uogonek -50
+KPX Aring Uring -50
+KPX Aring V -80
+KPX Aring W -60
+KPX Aring Y -110
+KPX Aring Yacute -110
+KPX Aring Ydieresis -110
+KPX Aring u -30
+KPX Aring uacute -30
+KPX Aring ucircumflex -30
+KPX Aring udieresis -30
+KPX Aring ugrave -30
+KPX Aring uhungarumlaut -30
+KPX Aring umacron -30
+KPX Aring uogonek -30
+KPX Aring uring -30
+KPX Aring v -40
+KPX Aring w -30
+KPX Aring y -30
+KPX Aring yacute -30
+KPX Aring ydieresis -30
+KPX Atilde C -40
+KPX Atilde Cacute -40
+KPX Atilde Ccaron -40
+KPX Atilde Ccedilla -40
+KPX Atilde G -50
+KPX Atilde Gbreve -50
+KPX Atilde Gcommaaccent -50
+KPX Atilde O -40
+KPX Atilde Oacute -40
+KPX Atilde Ocircumflex -40
+KPX Atilde Odieresis -40
+KPX Atilde Ograve -40
+KPX Atilde Ohungarumlaut -40
+KPX Atilde Omacron -40
+KPX Atilde Oslash -40
+KPX Atilde Otilde -40
+KPX Atilde Q -40
+KPX Atilde T -90
+KPX Atilde Tcaron -90
+KPX Atilde Tcommaaccent -90
+KPX Atilde U -50
+KPX Atilde Uacute -50
+KPX Atilde Ucircumflex -50
+KPX Atilde Udieresis -50
+KPX Atilde Ugrave -50
+KPX Atilde Uhungarumlaut -50
+KPX Atilde Umacron -50
+KPX Atilde Uogonek -50
+KPX Atilde Uring -50
+KPX Atilde V -80
+KPX Atilde W -60
+KPX Atilde Y -110
+KPX Atilde Yacute -110
+KPX Atilde Ydieresis -110
+KPX Atilde u -30
+KPX Atilde uacute -30
+KPX Atilde ucircumflex -30
+KPX Atilde udieresis -30
+KPX Atilde ugrave -30
+KPX Atilde uhungarumlaut -30
+KPX Atilde umacron -30
+KPX Atilde uogonek -30
+KPX Atilde uring -30
+KPX Atilde v -40
+KPX Atilde w -30
+KPX Atilde y -30
+KPX Atilde yacute -30
+KPX Atilde ydieresis -30
+KPX B A -30
+KPX B Aacute -30
+KPX B Abreve -30
+KPX B Acircumflex -30
+KPX B Adieresis -30
+KPX B Agrave -30
+KPX B Amacron -30
+KPX B Aogonek -30
+KPX B Aring -30
+KPX B Atilde -30
+KPX B U -10
+KPX B Uacute -10
+KPX B Ucircumflex -10
+KPX B Udieresis -10
+KPX B Ugrave -10
+KPX B Uhungarumlaut -10
+KPX B Umacron -10
+KPX B Uogonek -10
+KPX B Uring -10
+KPX D A -40
+KPX D Aacute -40
+KPX D Abreve -40
+KPX D Acircumflex -40
+KPX D Adieresis -40
+KPX D Agrave -40
+KPX D Amacron -40
+KPX D Aogonek -40
+KPX D Aring -40
+KPX D Atilde -40
+KPX D V -40
+KPX D W -40
+KPX D Y -70
+KPX D Yacute -70
+KPX D Ydieresis -70
+KPX D comma -30
+KPX D period -30
+KPX Dcaron A -40
+KPX Dcaron Aacute -40
+KPX Dcaron Abreve -40
+KPX Dcaron Acircumflex -40
+KPX Dcaron Adieresis -40
+KPX Dcaron Agrave -40
+KPX Dcaron Amacron -40
+KPX Dcaron Aogonek -40
+KPX Dcaron Aring -40
+KPX Dcaron Atilde -40
+KPX Dcaron V -40
+KPX Dcaron W -40
+KPX Dcaron Y -70
+KPX Dcaron Yacute -70
+KPX Dcaron Ydieresis -70
+KPX Dcaron comma -30
+KPX Dcaron period -30
+KPX Dcroat A -40
+KPX Dcroat Aacute -40
+KPX Dcroat Abreve -40
+KPX Dcroat Acircumflex -40
+KPX Dcroat Adieresis -40
+KPX Dcroat Agrave -40
+KPX Dcroat Amacron -40
+KPX Dcroat Aogonek -40
+KPX Dcroat Aring -40
+KPX Dcroat Atilde -40
+KPX Dcroat V -40
+KPX Dcroat W -40
+KPX Dcroat Y -70
+KPX Dcroat Yacute -70
+KPX Dcroat Ydieresis -70
+KPX Dcroat comma -30
+KPX Dcroat period -30
+KPX F A -80
+KPX F Aacute -80
+KPX F Abreve -80
+KPX F Acircumflex -80
+KPX F Adieresis -80
+KPX F Agrave -80
+KPX F Amacron -80
+KPX F Aogonek -80
+KPX F Aring -80
+KPX F Atilde -80
+KPX F a -20
+KPX F aacute -20
+KPX F abreve -20
+KPX F acircumflex -20
+KPX F adieresis -20
+KPX F agrave -20
+KPX F amacron -20
+KPX F aogonek -20
+KPX F aring -20
+KPX F atilde -20
+KPX F comma -100
+KPX F period -100
+KPX J A -20
+KPX J Aacute -20
+KPX J Abreve -20
+KPX J Acircumflex -20
+KPX J Adieresis -20
+KPX J Agrave -20
+KPX J Amacron -20
+KPX J Aogonek -20
+KPX J Aring -20
+KPX J Atilde -20
+KPX J comma -20
+KPX J period -20
+KPX J u -20
+KPX J uacute -20
+KPX J ucircumflex -20
+KPX J udieresis -20
+KPX J ugrave -20
+KPX J uhungarumlaut -20
+KPX J umacron -20
+KPX J uogonek -20
+KPX J uring -20
+KPX K O -30
+KPX K Oacute -30
+KPX K Ocircumflex -30
+KPX K Odieresis -30
+KPX K Ograve -30
+KPX K Ohungarumlaut -30
+KPX K Omacron -30
+KPX K Oslash -30
+KPX K Otilde -30
+KPX K e -15
+KPX K eacute -15
+KPX K ecaron -15
+KPX K ecircumflex -15
+KPX K edieresis -15
+KPX K edotaccent -15
+KPX K egrave -15
+KPX K emacron -15
+KPX K eogonek -15
+KPX K o -35
+KPX K oacute -35
+KPX K ocircumflex -35
+KPX K odieresis -35
+KPX K ograve -35
+KPX K ohungarumlaut -35
+KPX K omacron -35
+KPX K oslash -35
+KPX K otilde -35
+KPX K u -30
+KPX K uacute -30
+KPX K ucircumflex -30
+KPX K udieresis -30
+KPX K ugrave -30
+KPX K uhungarumlaut -30
+KPX K umacron -30
+KPX K uogonek -30
+KPX K uring -30
+KPX K y -40
+KPX K yacute -40
+KPX K ydieresis -40
+KPX Kcommaaccent O -30
+KPX Kcommaaccent Oacute -30
+KPX Kcommaaccent Ocircumflex -30
+KPX Kcommaaccent Odieresis -30
+KPX Kcommaaccent Ograve -30
+KPX Kcommaaccent Ohungarumlaut -30
+KPX Kcommaaccent Omacron -30
+KPX Kcommaaccent Oslash -30
+KPX Kcommaaccent Otilde -30
+KPX Kcommaaccent e -15
+KPX Kcommaaccent eacute -15
+KPX Kcommaaccent ecaron -15
+KPX Kcommaaccent ecircumflex -15
+KPX Kcommaaccent edieresis -15
+KPX Kcommaaccent edotaccent -15
+KPX Kcommaaccent egrave -15
+KPX Kcommaaccent emacron -15
+KPX Kcommaaccent eogonek -15
+KPX Kcommaaccent o -35
+KPX Kcommaaccent oacute -35
+KPX Kcommaaccent ocircumflex -35
+KPX Kcommaaccent odieresis -35
+KPX Kcommaaccent ograve -35
+KPX Kcommaaccent ohungarumlaut -35
+KPX Kcommaaccent omacron -35
+KPX Kcommaaccent oslash -35
+KPX Kcommaaccent otilde -35
+KPX Kcommaaccent u -30
+KPX Kcommaaccent uacute -30
+KPX Kcommaaccent ucircumflex -30
+KPX Kcommaaccent udieresis -30
+KPX Kcommaaccent ugrave -30
+KPX Kcommaaccent uhungarumlaut -30
+KPX Kcommaaccent umacron -30
+KPX Kcommaaccent uogonek -30
+KPX Kcommaaccent uring -30
+KPX Kcommaaccent y -40
+KPX Kcommaaccent yacute -40
+KPX Kcommaaccent ydieresis -40
+KPX L T -90
+KPX L Tcaron -90
+KPX L Tcommaaccent -90
+KPX L V -110
+KPX L W -80
+KPX L Y -120
+KPX L Yacute -120
+KPX L Ydieresis -120
+KPX L quotedblright -140
+KPX L quoteright -140
+KPX L y -30
+KPX L yacute -30
+KPX L ydieresis -30
+KPX Lacute T -90
+KPX Lacute Tcaron -90
+KPX Lacute Tcommaaccent -90
+KPX Lacute V -110
+KPX Lacute W -80
+KPX Lacute Y -120
+KPX Lacute Yacute -120
+KPX Lacute Ydieresis -120
+KPX Lacute quotedblright -140
+KPX Lacute quoteright -140
+KPX Lacute y -30
+KPX Lacute yacute -30
+KPX Lacute ydieresis -30
+KPX Lcommaaccent T -90
+KPX Lcommaaccent Tcaron -90
+KPX Lcommaaccent Tcommaaccent -90
+KPX Lcommaaccent V -110
+KPX Lcommaaccent W -80
+KPX Lcommaaccent Y -120
+KPX Lcommaaccent Yacute -120
+KPX Lcommaaccent Ydieresis -120
+KPX Lcommaaccent quotedblright -140
+KPX Lcommaaccent quoteright -140
+KPX Lcommaaccent y -30
+KPX Lcommaaccent yacute -30
+KPX Lcommaaccent ydieresis -30
+KPX Lslash T -90
+KPX Lslash Tcaron -90
+KPX Lslash Tcommaaccent -90
+KPX Lslash V -110
+KPX Lslash W -80
+KPX Lslash Y -120
+KPX Lslash Yacute -120
+KPX Lslash Ydieresis -120
+KPX Lslash quotedblright -140
+KPX Lslash quoteright -140
+KPX Lslash y -30
+KPX Lslash yacute -30
+KPX Lslash ydieresis -30
+KPX O A -50
+KPX O Aacute -50
+KPX O Abreve -50
+KPX O Acircumflex -50
+KPX O Adieresis -50
+KPX O Agrave -50
+KPX O Amacron -50
+KPX O Aogonek -50
+KPX O Aring -50
+KPX O Atilde -50
+KPX O T -40
+KPX O Tcaron -40
+KPX O Tcommaaccent -40
+KPX O V -50
+KPX O W -50
+KPX O X -50
+KPX O Y -70
+KPX O Yacute -70
+KPX O Ydieresis -70
+KPX O comma -40
+KPX O period -40
+KPX Oacute A -50
+KPX Oacute Aacute -50
+KPX Oacute Abreve -50
+KPX Oacute Acircumflex -50
+KPX Oacute Adieresis -50
+KPX Oacute Agrave -50
+KPX Oacute Amacron -50
+KPX Oacute Aogonek -50
+KPX Oacute Aring -50
+KPX Oacute Atilde -50
+KPX Oacute T -40
+KPX Oacute Tcaron -40
+KPX Oacute Tcommaaccent -40
+KPX Oacute V -50
+KPX Oacute W -50
+KPX Oacute X -50
+KPX Oacute Y -70
+KPX Oacute Yacute -70
+KPX Oacute Ydieresis -70
+KPX Oacute comma -40
+KPX Oacute period -40
+KPX Ocircumflex A -50
+KPX Ocircumflex Aacute -50
+KPX Ocircumflex Abreve -50
+KPX Ocircumflex Acircumflex -50
+KPX Ocircumflex Adieresis -50
+KPX Ocircumflex Agrave -50
+KPX Ocircumflex Amacron -50
+KPX Ocircumflex Aogonek -50
+KPX Ocircumflex Aring -50
+KPX Ocircumflex Atilde -50
+KPX Ocircumflex T -40
+KPX Ocircumflex Tcaron -40
+KPX Ocircumflex Tcommaaccent -40
+KPX Ocircumflex V -50
+KPX Ocircumflex W -50
+KPX Ocircumflex X -50
+KPX Ocircumflex Y -70
+KPX Ocircumflex Yacute -70
+KPX Ocircumflex Ydieresis -70
+KPX Ocircumflex comma -40
+KPX Ocircumflex period -40
+KPX Odieresis A -50
+KPX Odieresis Aacute -50
+KPX Odieresis Abreve -50
+KPX Odieresis Acircumflex -50
+KPX Odieresis Adieresis -50
+KPX Odieresis Agrave -50
+KPX Odieresis Amacron -50
+KPX Odieresis Aogonek -50
+KPX Odieresis Aring -50
+KPX Odieresis Atilde -50
+KPX Odieresis T -40
+KPX Odieresis Tcaron -40
+KPX Odieresis Tcommaaccent -40
+KPX Odieresis V -50
+KPX Odieresis W -50
+KPX Odieresis X -50
+KPX Odieresis Y -70
+KPX Odieresis Yacute -70
+KPX Odieresis Ydieresis -70
+KPX Odieresis comma -40
+KPX Odieresis period -40
+KPX Ograve A -50
+KPX Ograve Aacute -50
+KPX Ograve Abreve -50
+KPX Ograve Acircumflex -50
+KPX Ograve Adieresis -50
+KPX Ograve Agrave -50
+KPX Ograve Amacron -50
+KPX Ograve Aogonek -50
+KPX Ograve Aring -50
+KPX Ograve Atilde -50
+KPX Ograve T -40
+KPX Ograve Tcaron -40
+KPX Ograve Tcommaaccent -40
+KPX Ograve V -50
+KPX Ograve W -50
+KPX Ograve X -50
+KPX Ograve Y -70
+KPX Ograve Yacute -70
+KPX Ograve Ydieresis -70
+KPX Ograve comma -40
+KPX Ograve period -40
+KPX Ohungarumlaut A -50
+KPX Ohungarumlaut Aacute -50
+KPX Ohungarumlaut Abreve -50
+KPX Ohungarumlaut Acircumflex -50
+KPX Ohungarumlaut Adieresis -50
+KPX Ohungarumlaut Agrave -50
+KPX Ohungarumlaut Amacron -50
+KPX Ohungarumlaut Aogonek -50
+KPX Ohungarumlaut Aring -50
+KPX Ohungarumlaut Atilde -50
+KPX Ohungarumlaut T -40
+KPX Ohungarumlaut Tcaron -40
+KPX Ohungarumlaut Tcommaaccent -40
+KPX Ohungarumlaut V -50
+KPX Ohungarumlaut W -50
+KPX Ohungarumlaut X -50
+KPX Ohungarumlaut Y -70
+KPX Ohungarumlaut Yacute -70
+KPX Ohungarumlaut Ydieresis -70
+KPX Ohungarumlaut comma -40
+KPX Ohungarumlaut period -40
+KPX Omacron A -50
+KPX Omacron Aacute -50
+KPX Omacron Abreve -50
+KPX Omacron Acircumflex -50
+KPX Omacron Adieresis -50
+KPX Omacron Agrave -50
+KPX Omacron Amacron -50
+KPX Omacron Aogonek -50
+KPX Omacron Aring -50
+KPX Omacron Atilde -50
+KPX Omacron T -40
+KPX Omacron Tcaron -40
+KPX Omacron Tcommaaccent -40
+KPX Omacron V -50
+KPX Omacron W -50
+KPX Omacron X -50
+KPX Omacron Y -70
+KPX Omacron Yacute -70
+KPX Omacron Ydieresis -70
+KPX Omacron comma -40
+KPX Omacron period -40
+KPX Oslash A -50
+KPX Oslash Aacute -50
+KPX Oslash Abreve -50
+KPX Oslash Acircumflex -50
+KPX Oslash Adieresis -50
+KPX Oslash Agrave -50
+KPX Oslash Amacron -50
+KPX Oslash Aogonek -50
+KPX Oslash Aring -50
+KPX Oslash Atilde -50
+KPX Oslash T -40
+KPX Oslash Tcaron -40
+KPX Oslash Tcommaaccent -40
+KPX Oslash V -50
+KPX Oslash W -50
+KPX Oslash X -50
+KPX Oslash Y -70
+KPX Oslash Yacute -70
+KPX Oslash Ydieresis -70
+KPX Oslash comma -40
+KPX Oslash period -40
+KPX Otilde A -50
+KPX Otilde Aacute -50
+KPX Otilde Abreve -50
+KPX Otilde Acircumflex -50
+KPX Otilde Adieresis -50
+KPX Otilde Agrave -50
+KPX Otilde Amacron -50
+KPX Otilde Aogonek -50
+KPX Otilde Aring -50
+KPX Otilde Atilde -50
+KPX Otilde T -40
+KPX Otilde Tcaron -40
+KPX Otilde Tcommaaccent -40
+KPX Otilde V -50
+KPX Otilde W -50
+KPX Otilde X -50
+KPX Otilde Y -70
+KPX Otilde Yacute -70
+KPX Otilde Ydieresis -70
+KPX Otilde comma -40
+KPX Otilde period -40
+KPX P A -100
+KPX P Aacute -100
+KPX P Abreve -100
+KPX P Acircumflex -100
+KPX P Adieresis -100
+KPX P Agrave -100
+KPX P Amacron -100
+KPX P Aogonek -100
+KPX P Aring -100
+KPX P Atilde -100
+KPX P a -30
+KPX P aacute -30
+KPX P abreve -30
+KPX P acircumflex -30
+KPX P adieresis -30
+KPX P agrave -30
+KPX P amacron -30
+KPX P aogonek -30
+KPX P aring -30
+KPX P atilde -30
+KPX P comma -120
+KPX P e -30
+KPX P eacute -30
+KPX P ecaron -30
+KPX P ecircumflex -30
+KPX P edieresis -30
+KPX P edotaccent -30
+KPX P egrave -30
+KPX P emacron -30
+KPX P eogonek -30
+KPX P o -40
+KPX P oacute -40
+KPX P ocircumflex -40
+KPX P odieresis -40
+KPX P ograve -40
+KPX P ohungarumlaut -40
+KPX P omacron -40
+KPX P oslash -40
+KPX P otilde -40
+KPX P period -120
+KPX Q U -10
+KPX Q Uacute -10
+KPX Q Ucircumflex -10
+KPX Q Udieresis -10
+KPX Q Ugrave -10
+KPX Q Uhungarumlaut -10
+KPX Q Umacron -10
+KPX Q Uogonek -10
+KPX Q Uring -10
+KPX Q comma 20
+KPX Q period 20
+KPX R O -20
+KPX R Oacute -20
+KPX R Ocircumflex -20
+KPX R Odieresis -20
+KPX R Ograve -20
+KPX R Ohungarumlaut -20
+KPX R Omacron -20
+KPX R Oslash -20
+KPX R Otilde -20
+KPX R T -20
+KPX R Tcaron -20
+KPX R Tcommaaccent -20
+KPX R U -20
+KPX R Uacute -20
+KPX R Ucircumflex -20
+KPX R Udieresis -20
+KPX R Ugrave -20
+KPX R Uhungarumlaut -20
+KPX R Umacron -20
+KPX R Uogonek -20
+KPX R Uring -20
+KPX R V -50
+KPX R W -40
+KPX R Y -50
+KPX R Yacute -50
+KPX R Ydieresis -50
+KPX Racute O -20
+KPX Racute Oacute -20
+KPX Racute Ocircumflex -20
+KPX Racute Odieresis -20
+KPX Racute Ograve -20
+KPX Racute Ohungarumlaut -20
+KPX Racute Omacron -20
+KPX Racute Oslash -20
+KPX Racute Otilde -20
+KPX Racute T -20
+KPX Racute Tcaron -20
+KPX Racute Tcommaaccent -20
+KPX Racute U -20
+KPX Racute Uacute -20
+KPX Racute Ucircumflex -20
+KPX Racute Udieresis -20
+KPX Racute Ugrave -20
+KPX Racute Uhungarumlaut -20
+KPX Racute Umacron -20
+KPX Racute Uogonek -20
+KPX Racute Uring -20
+KPX Racute V -50
+KPX Racute W -40
+KPX Racute Y -50
+KPX Racute Yacute -50
+KPX Racute Ydieresis -50
+KPX Rcaron O -20
+KPX Rcaron Oacute -20
+KPX Rcaron Ocircumflex -20
+KPX Rcaron Odieresis -20
+KPX Rcaron Ograve -20
+KPX Rcaron Ohungarumlaut -20
+KPX Rcaron Omacron -20
+KPX Rcaron Oslash -20
+KPX Rcaron Otilde -20
+KPX Rcaron T -20
+KPX Rcaron Tcaron -20
+KPX Rcaron Tcommaaccent -20
+KPX Rcaron U -20
+KPX Rcaron Uacute -20
+KPX Rcaron Ucircumflex -20
+KPX Rcaron Udieresis -20
+KPX Rcaron Ugrave -20
+KPX Rcaron Uhungarumlaut -20
+KPX Rcaron Umacron -20
+KPX Rcaron Uogonek -20
+KPX Rcaron Uring -20
+KPX Rcaron V -50
+KPX Rcaron W -40
+KPX Rcaron Y -50
+KPX Rcaron Yacute -50
+KPX Rcaron Ydieresis -50
+KPX Rcommaaccent O -20
+KPX Rcommaaccent Oacute -20
+KPX Rcommaaccent Ocircumflex -20
+KPX Rcommaaccent Odieresis -20
+KPX Rcommaaccent Ograve -20
+KPX Rcommaaccent Ohungarumlaut -20
+KPX Rcommaaccent Omacron -20
+KPX Rcommaaccent Oslash -20
+KPX Rcommaaccent Otilde -20
+KPX Rcommaaccent T -20
+KPX Rcommaaccent Tcaron -20
+KPX Rcommaaccent Tcommaaccent -20
+KPX Rcommaaccent U -20
+KPX Rcommaaccent Uacute -20
+KPX Rcommaaccent Ucircumflex -20
+KPX Rcommaaccent Udieresis -20
+KPX Rcommaaccent Ugrave -20
+KPX Rcommaaccent Uhungarumlaut -20
+KPX Rcommaaccent Umacron -20
+KPX Rcommaaccent Uogonek -20
+KPX Rcommaaccent Uring -20
+KPX Rcommaaccent V -50
+KPX Rcommaaccent W -40
+KPX Rcommaaccent Y -50
+KPX Rcommaaccent Yacute -50
+KPX Rcommaaccent Ydieresis -50
+KPX T A -90
+KPX T Aacute -90
+KPX T Abreve -90
+KPX T Acircumflex -90
+KPX T Adieresis -90
+KPX T Agrave -90
+KPX T Amacron -90
+KPX T Aogonek -90
+KPX T Aring -90
+KPX T Atilde -90
+KPX T O -40
+KPX T Oacute -40
+KPX T Ocircumflex -40
+KPX T Odieresis -40
+KPX T Ograve -40
+KPX T Ohungarumlaut -40
+KPX T Omacron -40
+KPX T Oslash -40
+KPX T Otilde -40
+KPX T a -80
+KPX T aacute -80
+KPX T abreve -80
+KPX T acircumflex -80
+KPX T adieresis -80
+KPX T agrave -80
+KPX T amacron -80
+KPX T aogonek -80
+KPX T aring -80
+KPX T atilde -80
+KPX T colon -40
+KPX T comma -80
+KPX T e -60
+KPX T eacute -60
+KPX T ecaron -60
+KPX T ecircumflex -60
+KPX T edieresis -60
+KPX T edotaccent -60
+KPX T egrave -60
+KPX T emacron -60
+KPX T eogonek -60
+KPX T hyphen -120
+KPX T o -80
+KPX T oacute -80
+KPX T ocircumflex -80
+KPX T odieresis -80
+KPX T ograve -80
+KPX T ohungarumlaut -80
+KPX T omacron -80
+KPX T oslash -80
+KPX T otilde -80
+KPX T period -80
+KPX T r -80
+KPX T racute -80
+KPX T rcommaaccent -80
+KPX T semicolon -40
+KPX T u -90
+KPX T uacute -90
+KPX T ucircumflex -90
+KPX T udieresis -90
+KPX T ugrave -90
+KPX T uhungarumlaut -90
+KPX T umacron -90
+KPX T uogonek -90
+KPX T uring -90
+KPX T w -60
+KPX T y -60
+KPX T yacute -60
+KPX T ydieresis -60
+KPX Tcaron A -90
+KPX Tcaron Aacute -90
+KPX Tcaron Abreve -90
+KPX Tcaron Acircumflex -90
+KPX Tcaron Adieresis -90
+KPX Tcaron Agrave -90
+KPX Tcaron Amacron -90
+KPX Tcaron Aogonek -90
+KPX Tcaron Aring -90
+KPX Tcaron Atilde -90
+KPX Tcaron O -40
+KPX Tcaron Oacute -40
+KPX Tcaron Ocircumflex -40
+KPX Tcaron Odieresis -40
+KPX Tcaron Ograve -40
+KPX Tcaron Ohungarumlaut -40
+KPX Tcaron Omacron -40
+KPX Tcaron Oslash -40
+KPX Tcaron Otilde -40
+KPX Tcaron a -80
+KPX Tcaron aacute -80
+KPX Tcaron abreve -80
+KPX Tcaron acircumflex -80
+KPX Tcaron adieresis -80
+KPX Tcaron agrave -80
+KPX Tcaron amacron -80
+KPX Tcaron aogonek -80
+KPX Tcaron aring -80
+KPX Tcaron atilde -80
+KPX Tcaron colon -40
+KPX Tcaron comma -80
+KPX Tcaron e -60
+KPX Tcaron eacute -60
+KPX Tcaron ecaron -60
+KPX Tcaron ecircumflex -60
+KPX Tcaron edieresis -60
+KPX Tcaron edotaccent -60
+KPX Tcaron egrave -60
+KPX Tcaron emacron -60
+KPX Tcaron eogonek -60
+KPX Tcaron hyphen -120
+KPX Tcaron o -80
+KPX Tcaron oacute -80
+KPX Tcaron ocircumflex -80
+KPX Tcaron odieresis -80
+KPX Tcaron ograve -80
+KPX Tcaron ohungarumlaut -80
+KPX Tcaron omacron -80
+KPX Tcaron oslash -80
+KPX Tcaron otilde -80
+KPX Tcaron period -80
+KPX Tcaron r -80
+KPX Tcaron racute -80
+KPX Tcaron rcommaaccent -80
+KPX Tcaron semicolon -40
+KPX Tcaron u -90
+KPX Tcaron uacute -90
+KPX Tcaron ucircumflex -90
+KPX Tcaron udieresis -90
+KPX Tcaron ugrave -90
+KPX Tcaron uhungarumlaut -90
+KPX Tcaron umacron -90
+KPX Tcaron uogonek -90
+KPX Tcaron uring -90
+KPX Tcaron w -60
+KPX Tcaron y -60
+KPX Tcaron yacute -60
+KPX Tcaron ydieresis -60
+KPX Tcommaaccent A -90
+KPX Tcommaaccent Aacute -90
+KPX Tcommaaccent Abreve -90
+KPX Tcommaaccent Acircumflex -90
+KPX Tcommaaccent Adieresis -90
+KPX Tcommaaccent Agrave -90
+KPX Tcommaaccent Amacron -90
+KPX Tcommaaccent Aogonek -90
+KPX Tcommaaccent Aring -90
+KPX Tcommaaccent Atilde -90
+KPX Tcommaaccent O -40
+KPX Tcommaaccent Oacute -40
+KPX Tcommaaccent Ocircumflex -40
+KPX Tcommaaccent Odieresis -40
+KPX Tcommaaccent Ograve -40
+KPX Tcommaaccent Ohungarumlaut -40
+KPX Tcommaaccent Omacron -40
+KPX Tcommaaccent Oslash -40
+KPX Tcommaaccent Otilde -40
+KPX Tcommaaccent a -80
+KPX Tcommaaccent aacute -80
+KPX Tcommaaccent abreve -80
+KPX Tcommaaccent acircumflex -80
+KPX Tcommaaccent adieresis -80
+KPX Tcommaaccent agrave -80
+KPX Tcommaaccent amacron -80
+KPX Tcommaaccent aogonek -80
+KPX Tcommaaccent aring -80
+KPX Tcommaaccent atilde -80
+KPX Tcommaaccent colon -40
+KPX Tcommaaccent comma -80
+KPX Tcommaaccent e -60
+KPX Tcommaaccent eacute -60
+KPX Tcommaaccent ecaron -60
+KPX Tcommaaccent ecircumflex -60
+KPX Tcommaaccent edieresis -60
+KPX Tcommaaccent edotaccent -60
+KPX Tcommaaccent egrave -60
+KPX Tcommaaccent emacron -60
+KPX Tcommaaccent eogonek -60
+KPX Tcommaaccent hyphen -120
+KPX Tcommaaccent o -80
+KPX Tcommaaccent oacute -80
+KPX Tcommaaccent ocircumflex -80
+KPX Tcommaaccent odieresis -80
+KPX Tcommaaccent ograve -80
+KPX Tcommaaccent ohungarumlaut -80
+KPX Tcommaaccent omacron -80
+KPX Tcommaaccent oslash -80
+KPX Tcommaaccent otilde -80
+KPX Tcommaaccent period -80
+KPX Tcommaaccent r -80
+KPX Tcommaaccent racute -80
+KPX Tcommaaccent rcommaaccent -80
+KPX Tcommaaccent semicolon -40
+KPX Tcommaaccent u -90
+KPX Tcommaaccent uacute -90
+KPX Tcommaaccent ucircumflex -90
+KPX Tcommaaccent udieresis -90
+KPX Tcommaaccent ugrave -90
+KPX Tcommaaccent uhungarumlaut -90
+KPX Tcommaaccent umacron -90
+KPX Tcommaaccent uogonek -90
+KPX Tcommaaccent uring -90
+KPX Tcommaaccent w -60
+KPX Tcommaaccent y -60
+KPX Tcommaaccent yacute -60
+KPX Tcommaaccent ydieresis -60
+KPX U A -50
+KPX U Aacute -50
+KPX U Abreve -50
+KPX U Acircumflex -50
+KPX U Adieresis -50
+KPX U Agrave -50
+KPX U Amacron -50
+KPX U Aogonek -50
+KPX U Aring -50
+KPX U Atilde -50
+KPX U comma -30
+KPX U period -30
+KPX Uacute A -50
+KPX Uacute Aacute -50
+KPX Uacute Abreve -50
+KPX Uacute Acircumflex -50
+KPX Uacute Adieresis -50
+KPX Uacute Agrave -50
+KPX Uacute Amacron -50
+KPX Uacute Aogonek -50
+KPX Uacute Aring -50
+KPX Uacute Atilde -50
+KPX Uacute comma -30
+KPX Uacute period -30
+KPX Ucircumflex A -50
+KPX Ucircumflex Aacute -50
+KPX Ucircumflex Abreve -50
+KPX Ucircumflex Acircumflex -50
+KPX Ucircumflex Adieresis -50
+KPX Ucircumflex Agrave -50
+KPX Ucircumflex Amacron -50
+KPX Ucircumflex Aogonek -50
+KPX Ucircumflex Aring -50
+KPX Ucircumflex Atilde -50
+KPX Ucircumflex comma -30
+KPX Ucircumflex period -30
+KPX Udieresis A -50
+KPX Udieresis Aacute -50
+KPX Udieresis Abreve -50
+KPX Udieresis Acircumflex -50
+KPX Udieresis Adieresis -50
+KPX Udieresis Agrave -50
+KPX Udieresis Amacron -50
+KPX Udieresis Aogonek -50
+KPX Udieresis Aring -50
+KPX Udieresis Atilde -50
+KPX Udieresis comma -30
+KPX Udieresis period -30
+KPX Ugrave A -50
+KPX Ugrave Aacute -50
+KPX Ugrave Abreve -50
+KPX Ugrave Acircumflex -50
+KPX Ugrave Adieresis -50
+KPX Ugrave Agrave -50
+KPX Ugrave Amacron -50
+KPX Ugrave Aogonek -50
+KPX Ugrave Aring -50
+KPX Ugrave Atilde -50
+KPX Ugrave comma -30
+KPX Ugrave period -30
+KPX Uhungarumlaut A -50
+KPX Uhungarumlaut Aacute -50
+KPX Uhungarumlaut Abreve -50
+KPX Uhungarumlaut Acircumflex -50
+KPX Uhungarumlaut Adieresis -50
+KPX Uhungarumlaut Agrave -50
+KPX Uhungarumlaut Amacron -50
+KPX Uhungarumlaut Aogonek -50
+KPX Uhungarumlaut Aring -50
+KPX Uhungarumlaut Atilde -50
+KPX Uhungarumlaut comma -30
+KPX Uhungarumlaut period -30
+KPX Umacron A -50
+KPX Umacron Aacute -50
+KPX Umacron Abreve -50
+KPX Umacron Acircumflex -50
+KPX Umacron Adieresis -50
+KPX Umacron Agrave -50
+KPX Umacron Amacron -50
+KPX Umacron Aogonek -50
+KPX Umacron Aring -50
+KPX Umacron Atilde -50
+KPX Umacron comma -30
+KPX Umacron period -30
+KPX Uogonek A -50
+KPX Uogonek Aacute -50
+KPX Uogonek Abreve -50
+KPX Uogonek Acircumflex -50
+KPX Uogonek Adieresis -50
+KPX Uogonek Agrave -50
+KPX Uogonek Amacron -50
+KPX Uogonek Aogonek -50
+KPX Uogonek Aring -50
+KPX Uogonek Atilde -50
+KPX Uogonek comma -30
+KPX Uogonek period -30
+KPX Uring A -50
+KPX Uring Aacute -50
+KPX Uring Abreve -50
+KPX Uring Acircumflex -50
+KPX Uring Adieresis -50
+KPX Uring Agrave -50
+KPX Uring Amacron -50
+KPX Uring Aogonek -50
+KPX Uring Aring -50
+KPX Uring Atilde -50
+KPX Uring comma -30
+KPX Uring period -30
+KPX V A -80
+KPX V Aacute -80
+KPX V Abreve -80
+KPX V Acircumflex -80
+KPX V Adieresis -80
+KPX V Agrave -80
+KPX V Amacron -80
+KPX V Aogonek -80
+KPX V Aring -80
+KPX V Atilde -80
+KPX V G -50
+KPX V Gbreve -50
+KPX V Gcommaaccent -50
+KPX V O -50
+KPX V Oacute -50
+KPX V Ocircumflex -50
+KPX V Odieresis -50
+KPX V Ograve -50
+KPX V Ohungarumlaut -50
+KPX V Omacron -50
+KPX V Oslash -50
+KPX V Otilde -50
+KPX V a -60
+KPX V aacute -60
+KPX V abreve -60
+KPX V acircumflex -60
+KPX V adieresis -60
+KPX V agrave -60
+KPX V amacron -60
+KPX V aogonek -60
+KPX V aring -60
+KPX V atilde -60
+KPX V colon -40
+KPX V comma -120
+KPX V e -50
+KPX V eacute -50
+KPX V ecaron -50
+KPX V ecircumflex -50
+KPX V edieresis -50
+KPX V edotaccent -50
+KPX V egrave -50
+KPX V emacron -50
+KPX V eogonek -50
+KPX V hyphen -80
+KPX V o -90
+KPX V oacute -90
+KPX V ocircumflex -90
+KPX V odieresis -90
+KPX V ograve -90
+KPX V ohungarumlaut -90
+KPX V omacron -90
+KPX V oslash -90
+KPX V otilde -90
+KPX V period -120
+KPX V semicolon -40
+KPX V u -60
+KPX V uacute -60
+KPX V ucircumflex -60
+KPX V udieresis -60
+KPX V ugrave -60
+KPX V uhungarumlaut -60
+KPX V umacron -60
+KPX V uogonek -60
+KPX V uring -60
+KPX W A -60
+KPX W Aacute -60
+KPX W Abreve -60
+KPX W Acircumflex -60
+KPX W Adieresis -60
+KPX W Agrave -60
+KPX W Amacron -60
+KPX W Aogonek -60
+KPX W Aring -60
+KPX W Atilde -60
+KPX W O -20
+KPX W Oacute -20
+KPX W Ocircumflex -20
+KPX W Odieresis -20
+KPX W Ograve -20
+KPX W Ohungarumlaut -20
+KPX W Omacron -20
+KPX W Oslash -20
+KPX W Otilde -20
+KPX W a -40
+KPX W aacute -40
+KPX W abreve -40
+KPX W acircumflex -40
+KPX W adieresis -40
+KPX W agrave -40
+KPX W amacron -40
+KPX W aogonek -40
+KPX W aring -40
+KPX W atilde -40
+KPX W colon -10
+KPX W comma -80
+KPX W e -35
+KPX W eacute -35
+KPX W ecaron -35
+KPX W ecircumflex -35
+KPX W edieresis -35
+KPX W edotaccent -35
+KPX W egrave -35
+KPX W emacron -35
+KPX W eogonek -35
+KPX W hyphen -40
+KPX W o -60
+KPX W oacute -60
+KPX W ocircumflex -60
+KPX W odieresis -60
+KPX W ograve -60
+KPX W ohungarumlaut -60
+KPX W omacron -60
+KPX W oslash -60
+KPX W otilde -60
+KPX W period -80
+KPX W semicolon -10
+KPX W u -45
+KPX W uacute -45
+KPX W ucircumflex -45
+KPX W udieresis -45
+KPX W ugrave -45
+KPX W uhungarumlaut -45
+KPX W umacron -45
+KPX W uogonek -45
+KPX W uring -45
+KPX W y -20
+KPX W yacute -20
+KPX W ydieresis -20
+KPX Y A -110
+KPX Y Aacute -110
+KPX Y Abreve -110
+KPX Y Acircumflex -110
+KPX Y Adieresis -110
+KPX Y Agrave -110
+KPX Y Amacron -110
+KPX Y Aogonek -110
+KPX Y Aring -110
+KPX Y Atilde -110
+KPX Y O -70
+KPX Y Oacute -70
+KPX Y Ocircumflex -70
+KPX Y Odieresis -70
+KPX Y Ograve -70
+KPX Y Ohungarumlaut -70
+KPX Y Omacron -70
+KPX Y Oslash -70
+KPX Y Otilde -70
+KPX Y a -90
+KPX Y aacute -90
+KPX Y abreve -90
+KPX Y acircumflex -90
+KPX Y adieresis -90
+KPX Y agrave -90
+KPX Y amacron -90
+KPX Y aogonek -90
+KPX Y aring -90
+KPX Y atilde -90
+KPX Y colon -50
+KPX Y comma -100
+KPX Y e -80
+KPX Y eacute -80
+KPX Y ecaron -80
+KPX Y ecircumflex -80
+KPX Y edieresis -80
+KPX Y edotaccent -80
+KPX Y egrave -80
+KPX Y emacron -80
+KPX Y eogonek -80
+KPX Y o -100
+KPX Y oacute -100
+KPX Y ocircumflex -100
+KPX Y odieresis -100
+KPX Y ograve -100
+KPX Y ohungarumlaut -100
+KPX Y omacron -100
+KPX Y oslash -100
+KPX Y otilde -100
+KPX Y period -100
+KPX Y semicolon -50
+KPX Y u -100
+KPX Y uacute -100
+KPX Y ucircumflex -100
+KPX Y udieresis -100
+KPX Y ugrave -100
+KPX Y uhungarumlaut -100
+KPX Y umacron -100
+KPX Y uogonek -100
+KPX Y uring -100
+KPX Yacute A -110
+KPX Yacute Aacute -110
+KPX Yacute Abreve -110
+KPX Yacute Acircumflex -110
+KPX Yacute Adieresis -110
+KPX Yacute Agrave -110
+KPX Yacute Amacron -110
+KPX Yacute Aogonek -110
+KPX Yacute Aring -110
+KPX Yacute Atilde -110
+KPX Yacute O -70
+KPX Yacute Oacute -70
+KPX Yacute Ocircumflex -70
+KPX Yacute Odieresis -70
+KPX Yacute Ograve -70
+KPX Yacute Ohungarumlaut -70
+KPX Yacute Omacron -70
+KPX Yacute Oslash -70
+KPX Yacute Otilde -70
+KPX Yacute a -90
+KPX Yacute aacute -90
+KPX Yacute abreve -90
+KPX Yacute acircumflex -90
+KPX Yacute adieresis -90
+KPX Yacute agrave -90
+KPX Yacute amacron -90
+KPX Yacute aogonek -90
+KPX Yacute aring -90
+KPX Yacute atilde -90
+KPX Yacute colon -50
+KPX Yacute comma -100
+KPX Yacute e -80
+KPX Yacute eacute -80
+KPX Yacute ecaron -80
+KPX Yacute ecircumflex -80
+KPX Yacute edieresis -80
+KPX Yacute edotaccent -80
+KPX Yacute egrave -80
+KPX Yacute emacron -80
+KPX Yacute eogonek -80
+KPX Yacute o -100
+KPX Yacute oacute -100
+KPX Yacute ocircumflex -100
+KPX Yacute odieresis -100
+KPX Yacute ograve -100
+KPX Yacute ohungarumlaut -100
+KPX Yacute omacron -100
+KPX Yacute oslash -100
+KPX Yacute otilde -100
+KPX Yacute period -100
+KPX Yacute semicolon -50
+KPX Yacute u -100
+KPX Yacute uacute -100
+KPX Yacute ucircumflex -100
+KPX Yacute udieresis -100
+KPX Yacute ugrave -100
+KPX Yacute uhungarumlaut -100
+KPX Yacute umacron -100
+KPX Yacute uogonek -100
+KPX Yacute uring -100
+KPX Ydieresis A -110
+KPX Ydieresis Aacute -110
+KPX Ydieresis Abreve -110
+KPX Ydieresis Acircumflex -110
+KPX Ydieresis Adieresis -110
+KPX Ydieresis Agrave -110
+KPX Ydieresis Amacron -110
+KPX Ydieresis Aogonek -110
+KPX Ydieresis Aring -110
+KPX Ydieresis Atilde -110
+KPX Ydieresis O -70
+KPX Ydieresis Oacute -70
+KPX Ydieresis Ocircumflex -70
+KPX Ydieresis Odieresis -70
+KPX Ydieresis Ograve -70
+KPX Ydieresis Ohungarumlaut -70
+KPX Ydieresis Omacron -70
+KPX Ydieresis Oslash -70
+KPX Ydieresis Otilde -70
+KPX Ydieresis a -90
+KPX Ydieresis aacute -90
+KPX Ydieresis abreve -90
+KPX Ydieresis acircumflex -90
+KPX Ydieresis adieresis -90
+KPX Ydieresis agrave -90
+KPX Ydieresis amacron -90
+KPX Ydieresis aogonek -90
+KPX Ydieresis aring -90
+KPX Ydieresis atilde -90
+KPX Ydieresis colon -50
+KPX Ydieresis comma -100
+KPX Ydieresis e -80
+KPX Ydieresis eacute -80
+KPX Ydieresis ecaron -80
+KPX Ydieresis ecircumflex -80
+KPX Ydieresis edieresis -80
+KPX Ydieresis edotaccent -80
+KPX Ydieresis egrave -80
+KPX Ydieresis emacron -80
+KPX Ydieresis eogonek -80
+KPX Ydieresis o -100
+KPX Ydieresis oacute -100
+KPX Ydieresis ocircumflex -100
+KPX Ydieresis odieresis -100
+KPX Ydieresis ograve -100
+KPX Ydieresis ohungarumlaut -100
+KPX Ydieresis omacron -100
+KPX Ydieresis oslash -100
+KPX Ydieresis otilde -100
+KPX Ydieresis period -100
+KPX Ydieresis semicolon -50
+KPX Ydieresis u -100
+KPX Ydieresis uacute -100
+KPX Ydieresis ucircumflex -100
+KPX Ydieresis udieresis -100
+KPX Ydieresis ugrave -100
+KPX Ydieresis uhungarumlaut -100
+KPX Ydieresis umacron -100
+KPX Ydieresis uogonek -100
+KPX Ydieresis uring -100
+KPX a g -10
+KPX a gbreve -10
+KPX a gcommaaccent -10
+KPX a v -15
+KPX a w -15
+KPX a y -20
+KPX a yacute -20
+KPX a ydieresis -20
+KPX aacute g -10
+KPX aacute gbreve -10
+KPX aacute gcommaaccent -10
+KPX aacute v -15
+KPX aacute w -15
+KPX aacute y -20
+KPX aacute yacute -20
+KPX aacute ydieresis -20
+KPX abreve g -10
+KPX abreve gbreve -10
+KPX abreve gcommaaccent -10
+KPX abreve v -15
+KPX abreve w -15
+KPX abreve y -20
+KPX abreve yacute -20
+KPX abreve ydieresis -20
+KPX acircumflex g -10
+KPX acircumflex gbreve -10
+KPX acircumflex gcommaaccent -10
+KPX acircumflex v -15
+KPX acircumflex w -15
+KPX acircumflex y -20
+KPX acircumflex yacute -20
+KPX acircumflex ydieresis -20
+KPX adieresis g -10
+KPX adieresis gbreve -10
+KPX adieresis gcommaaccent -10
+KPX adieresis v -15
+KPX adieresis w -15
+KPX adieresis y -20
+KPX adieresis yacute -20
+KPX adieresis ydieresis -20
+KPX agrave g -10
+KPX agrave gbreve -10
+KPX agrave gcommaaccent -10
+KPX agrave v -15
+KPX agrave w -15
+KPX agrave y -20
+KPX agrave yacute -20
+KPX agrave ydieresis -20
+KPX amacron g -10
+KPX amacron gbreve -10
+KPX amacron gcommaaccent -10
+KPX amacron v -15
+KPX amacron w -15
+KPX amacron y -20
+KPX amacron yacute -20
+KPX amacron ydieresis -20
+KPX aogonek g -10
+KPX aogonek gbreve -10
+KPX aogonek gcommaaccent -10
+KPX aogonek v -15
+KPX aogonek w -15
+KPX aogonek y -20
+KPX aogonek yacute -20
+KPX aogonek ydieresis -20
+KPX aring g -10
+KPX aring gbreve -10
+KPX aring gcommaaccent -10
+KPX aring v -15
+KPX aring w -15
+KPX aring y -20
+KPX aring yacute -20
+KPX aring ydieresis -20
+KPX atilde g -10
+KPX atilde gbreve -10
+KPX atilde gcommaaccent -10
+KPX atilde v -15
+KPX atilde w -15
+KPX atilde y -20
+KPX atilde yacute -20
+KPX atilde ydieresis -20
+KPX b l -10
+KPX b lacute -10
+KPX b lcommaaccent -10
+KPX b lslash -10
+KPX b u -20
+KPX b uacute -20
+KPX b ucircumflex -20
+KPX b udieresis -20
+KPX b ugrave -20
+KPX b uhungarumlaut -20
+KPX b umacron -20
+KPX b uogonek -20
+KPX b uring -20
+KPX b v -20
+KPX b y -20
+KPX b yacute -20
+KPX b ydieresis -20
+KPX c h -10
+KPX c k -20
+KPX c kcommaaccent -20
+KPX c l -20
+KPX c lacute -20
+KPX c lcommaaccent -20
+KPX c lslash -20
+KPX c y -10
+KPX c yacute -10
+KPX c ydieresis -10
+KPX cacute h -10
+KPX cacute k -20
+KPX cacute kcommaaccent -20
+KPX cacute l -20
+KPX cacute lacute -20
+KPX cacute lcommaaccent -20
+KPX cacute lslash -20
+KPX cacute y -10
+KPX cacute yacute -10
+KPX cacute ydieresis -10
+KPX ccaron h -10
+KPX ccaron k -20
+KPX ccaron kcommaaccent -20
+KPX ccaron l -20
+KPX ccaron lacute -20
+KPX ccaron lcommaaccent -20
+KPX ccaron lslash -20
+KPX ccaron y -10
+KPX ccaron yacute -10
+KPX ccaron ydieresis -10
+KPX ccedilla h -10
+KPX ccedilla k -20
+KPX ccedilla kcommaaccent -20
+KPX ccedilla l -20
+KPX ccedilla lacute -20
+KPX ccedilla lcommaaccent -20
+KPX ccedilla lslash -20
+KPX ccedilla y -10
+KPX ccedilla yacute -10
+KPX ccedilla ydieresis -10
+KPX colon space -40
+KPX comma quotedblright -120
+KPX comma quoteright -120
+KPX comma space -40
+KPX d d -10
+KPX d dcroat -10
+KPX d v -15
+KPX d w -15
+KPX d y -15
+KPX d yacute -15
+KPX d ydieresis -15
+KPX dcroat d -10
+KPX dcroat dcroat -10
+KPX dcroat v -15
+KPX dcroat w -15
+KPX dcroat y -15
+KPX dcroat yacute -15
+KPX dcroat ydieresis -15
+KPX e comma 10
+KPX e period 20
+KPX e v -15
+KPX e w -15
+KPX e x -15
+KPX e y -15
+KPX e yacute -15
+KPX e ydieresis -15
+KPX eacute comma 10
+KPX eacute period 20
+KPX eacute v -15
+KPX eacute w -15
+KPX eacute x -15
+KPX eacute y -15
+KPX eacute yacute -15
+KPX eacute ydieresis -15
+KPX ecaron comma 10
+KPX ecaron period 20
+KPX ecaron v -15
+KPX ecaron w -15
+KPX ecaron x -15
+KPX ecaron y -15
+KPX ecaron yacute -15
+KPX ecaron ydieresis -15
+KPX ecircumflex comma 10
+KPX ecircumflex period 20
+KPX ecircumflex v -15
+KPX ecircumflex w -15
+KPX ecircumflex x -15
+KPX ecircumflex y -15
+KPX ecircumflex yacute -15
+KPX ecircumflex ydieresis -15
+KPX edieresis comma 10
+KPX edieresis period 20
+KPX edieresis v -15
+KPX edieresis w -15
+KPX edieresis x -15
+KPX edieresis y -15
+KPX edieresis yacute -15
+KPX edieresis ydieresis -15
+KPX edotaccent comma 10
+KPX edotaccent period 20
+KPX edotaccent v -15
+KPX edotaccent w -15
+KPX edotaccent x -15
+KPX edotaccent y -15
+KPX edotaccent yacute -15
+KPX edotaccent ydieresis -15
+KPX egrave comma 10
+KPX egrave period 20
+KPX egrave v -15
+KPX egrave w -15
+KPX egrave x -15
+KPX egrave y -15
+KPX egrave yacute -15
+KPX egrave ydieresis -15
+KPX emacron comma 10
+KPX emacron period 20
+KPX emacron v -15
+KPX emacron w -15
+KPX emacron x -15
+KPX emacron y -15
+KPX emacron yacute -15
+KPX emacron ydieresis -15
+KPX eogonek comma 10
+KPX eogonek period 20
+KPX eogonek v -15
+KPX eogonek w -15
+KPX eogonek x -15
+KPX eogonek y -15
+KPX eogonek yacute -15
+KPX eogonek ydieresis -15
+KPX f comma -10
+KPX f e -10
+KPX f eacute -10
+KPX f ecaron -10
+KPX f ecircumflex -10
+KPX f edieresis -10
+KPX f edotaccent -10
+KPX f egrave -10
+KPX f emacron -10
+KPX f eogonek -10
+KPX f o -20
+KPX f oacute -20
+KPX f ocircumflex -20
+KPX f odieresis -20
+KPX f ograve -20
+KPX f ohungarumlaut -20
+KPX f omacron -20
+KPX f oslash -20
+KPX f otilde -20
+KPX f period -10
+KPX f quotedblright 30
+KPX f quoteright 30
+KPX g e 10
+KPX g eacute 10
+KPX g ecaron 10
+KPX g ecircumflex 10
+KPX g edieresis 10
+KPX g edotaccent 10
+KPX g egrave 10
+KPX g emacron 10
+KPX g eogonek 10
+KPX g g -10
+KPX g gbreve -10
+KPX g gcommaaccent -10
+KPX gbreve e 10
+KPX gbreve eacute 10
+KPX gbreve ecaron 10
+KPX gbreve ecircumflex 10
+KPX gbreve edieresis 10
+KPX gbreve edotaccent 10
+KPX gbreve egrave 10
+KPX gbreve emacron 10
+KPX gbreve eogonek 10
+KPX gbreve g -10
+KPX gbreve gbreve -10
+KPX gbreve gcommaaccent -10
+KPX gcommaaccent e 10
+KPX gcommaaccent eacute 10
+KPX gcommaaccent ecaron 10
+KPX gcommaaccent ecircumflex 10
+KPX gcommaaccent edieresis 10
+KPX gcommaaccent edotaccent 10
+KPX gcommaaccent egrave 10
+KPX gcommaaccent emacron 10
+KPX gcommaaccent eogonek 10
+KPX gcommaaccent g -10
+KPX gcommaaccent gbreve -10
+KPX gcommaaccent gcommaaccent -10
+KPX h y -20
+KPX h yacute -20
+KPX h ydieresis -20
+KPX k o -15
+KPX k oacute -15
+KPX k ocircumflex -15
+KPX k odieresis -15
+KPX k ograve -15
+KPX k ohungarumlaut -15
+KPX k omacron -15
+KPX k oslash -15
+KPX k otilde -15
+KPX kcommaaccent o -15
+KPX kcommaaccent oacute -15
+KPX kcommaaccent ocircumflex -15
+KPX kcommaaccent odieresis -15
+KPX kcommaaccent ograve -15
+KPX kcommaaccent ohungarumlaut -15
+KPX kcommaaccent omacron -15
+KPX kcommaaccent oslash -15
+KPX kcommaaccent otilde -15
+KPX l w -15
+KPX l y -15
+KPX l yacute -15
+KPX l ydieresis -15
+KPX lacute w -15
+KPX lacute y -15
+KPX lacute yacute -15
+KPX lacute ydieresis -15
+KPX lcommaaccent w -15
+KPX lcommaaccent y -15
+KPX lcommaaccent yacute -15
+KPX lcommaaccent ydieresis -15
+KPX lslash w -15
+KPX lslash y -15
+KPX lslash yacute -15
+KPX lslash ydieresis -15
+KPX m u -20
+KPX m uacute -20
+KPX m ucircumflex -20
+KPX m udieresis -20
+KPX m ugrave -20
+KPX m uhungarumlaut -20
+KPX m umacron -20
+KPX m uogonek -20
+KPX m uring -20
+KPX m y -30
+KPX m yacute -30
+KPX m ydieresis -30
+KPX n u -10
+KPX n uacute -10
+KPX n ucircumflex -10
+KPX n udieresis -10
+KPX n ugrave -10
+KPX n uhungarumlaut -10
+KPX n umacron -10
+KPX n uogonek -10
+KPX n uring -10
+KPX n v -40
+KPX n y -20
+KPX n yacute -20
+KPX n ydieresis -20
+KPX nacute u -10
+KPX nacute uacute -10
+KPX nacute ucircumflex -10
+KPX nacute udieresis -10
+KPX nacute ugrave -10
+KPX nacute uhungarumlaut -10
+KPX nacute umacron -10
+KPX nacute uogonek -10
+KPX nacute uring -10
+KPX nacute v -40
+KPX nacute y -20
+KPX nacute yacute -20
+KPX nacute ydieresis -20
+KPX ncaron u -10
+KPX ncaron uacute -10
+KPX ncaron ucircumflex -10
+KPX ncaron udieresis -10
+KPX ncaron ugrave -10
+KPX ncaron uhungarumlaut -10
+KPX ncaron umacron -10
+KPX ncaron uogonek -10
+KPX ncaron uring -10
+KPX ncaron v -40
+KPX ncaron y -20
+KPX ncaron yacute -20
+KPX ncaron ydieresis -20
+KPX ncommaaccent u -10
+KPX ncommaaccent uacute -10
+KPX ncommaaccent ucircumflex -10
+KPX ncommaaccent udieresis -10
+KPX ncommaaccent ugrave -10
+KPX ncommaaccent uhungarumlaut -10
+KPX ncommaaccent umacron -10
+KPX ncommaaccent uogonek -10
+KPX ncommaaccent uring -10
+KPX ncommaaccent v -40
+KPX ncommaaccent y -20
+KPX ncommaaccent yacute -20
+KPX ncommaaccent ydieresis -20
+KPX ntilde u -10
+KPX ntilde uacute -10
+KPX ntilde ucircumflex -10
+KPX ntilde udieresis -10
+KPX ntilde ugrave -10
+KPX ntilde uhungarumlaut -10
+KPX ntilde umacron -10
+KPX ntilde uogonek -10
+KPX ntilde uring -10
+KPX ntilde v -40
+KPX ntilde y -20
+KPX ntilde yacute -20
+KPX ntilde ydieresis -20
+KPX o v -20
+KPX o w -15
+KPX o x -30
+KPX o y -20
+KPX o yacute -20
+KPX o ydieresis -20
+KPX oacute v -20
+KPX oacute w -15
+KPX oacute x -30
+KPX oacute y -20
+KPX oacute yacute -20
+KPX oacute ydieresis -20
+KPX ocircumflex v -20
+KPX ocircumflex w -15
+KPX ocircumflex x -30
+KPX ocircumflex y -20
+KPX ocircumflex yacute -20
+KPX ocircumflex ydieresis -20
+KPX odieresis v -20
+KPX odieresis w -15
+KPX odieresis x -30
+KPX odieresis y -20
+KPX odieresis yacute -20
+KPX odieresis ydieresis -20
+KPX ograve v -20
+KPX ograve w -15
+KPX ograve x -30
+KPX ograve y -20
+KPX ograve yacute -20
+KPX ograve ydieresis -20
+KPX ohungarumlaut v -20
+KPX ohungarumlaut w -15
+KPX ohungarumlaut x -30
+KPX ohungarumlaut y -20
+KPX ohungarumlaut yacute -20
+KPX ohungarumlaut ydieresis -20
+KPX omacron v -20
+KPX omacron w -15
+KPX omacron x -30
+KPX omacron y -20
+KPX omacron yacute -20
+KPX omacron ydieresis -20
+KPX oslash v -20
+KPX oslash w -15
+KPX oslash x -30
+KPX oslash y -20
+KPX oslash yacute -20
+KPX oslash ydieresis -20
+KPX otilde v -20
+KPX otilde w -15
+KPX otilde x -30
+KPX otilde y -20
+KPX otilde yacute -20
+KPX otilde ydieresis -20
+KPX p y -15
+KPX p yacute -15
+KPX p ydieresis -15
+KPX period quotedblright -120
+KPX period quoteright -120
+KPX period space -40
+KPX quotedblright space -80
+KPX quoteleft quoteleft -46
+KPX quoteright d -80
+KPX quoteright dcroat -80
+KPX quoteright l -20
+KPX quoteright lacute -20
+KPX quoteright lcommaaccent -20
+KPX quoteright lslash -20
+KPX quoteright quoteright -46
+KPX quoteright r -40
+KPX quoteright racute -40
+KPX quoteright rcaron -40
+KPX quoteright rcommaaccent -40
+KPX quoteright s -60
+KPX quoteright sacute -60
+KPX quoteright scaron -60
+KPX quoteright scedilla -60
+KPX quoteright scommaaccent -60
+KPX quoteright space -80
+KPX quoteright v -20
+KPX r c -20
+KPX r cacute -20
+KPX r ccaron -20
+KPX r ccedilla -20
+KPX r comma -60
+KPX r d -20
+KPX r dcroat -20
+KPX r g -15
+KPX r gbreve -15
+KPX r gcommaaccent -15
+KPX r hyphen -20
+KPX r o -20
+KPX r oacute -20
+KPX r ocircumflex -20
+KPX r odieresis -20
+KPX r ograve -20
+KPX r ohungarumlaut -20
+KPX r omacron -20
+KPX r oslash -20
+KPX r otilde -20
+KPX r period -60
+KPX r q -20
+KPX r s -15
+KPX r sacute -15
+KPX r scaron -15
+KPX r scedilla -15
+KPX r scommaaccent -15
+KPX r t 20
+KPX r tcommaaccent 20
+KPX r v 10
+KPX r y 10
+KPX r yacute 10
+KPX r ydieresis 10
+KPX racute c -20
+KPX racute cacute -20
+KPX racute ccaron -20
+KPX racute ccedilla -20
+KPX racute comma -60
+KPX racute d -20
+KPX racute dcroat -20
+KPX racute g -15
+KPX racute gbreve -15
+KPX racute gcommaaccent -15
+KPX racute hyphen -20
+KPX racute o -20
+KPX racute oacute -20
+KPX racute ocircumflex -20
+KPX racute odieresis -20
+KPX racute ograve -20
+KPX racute ohungarumlaut -20
+KPX racute omacron -20
+KPX racute oslash -20
+KPX racute otilde -20
+KPX racute period -60
+KPX racute q -20
+KPX racute s -15
+KPX racute sacute -15
+KPX racute scaron -15
+KPX racute scedilla -15
+KPX racute scommaaccent -15
+KPX racute t 20
+KPX racute tcommaaccent 20
+KPX racute v 10
+KPX racute y 10
+KPX racute yacute 10
+KPX racute ydieresis 10
+KPX rcaron c -20
+KPX rcaron cacute -20
+KPX rcaron ccaron -20
+KPX rcaron ccedilla -20
+KPX rcaron comma -60
+KPX rcaron d -20
+KPX rcaron dcroat -20
+KPX rcaron g -15
+KPX rcaron gbreve -15
+KPX rcaron gcommaaccent -15
+KPX rcaron hyphen -20
+KPX rcaron o -20
+KPX rcaron oacute -20
+KPX rcaron ocircumflex -20
+KPX rcaron odieresis -20
+KPX rcaron ograve -20
+KPX rcaron ohungarumlaut -20
+KPX rcaron omacron -20
+KPX rcaron oslash -20
+KPX rcaron otilde -20
+KPX rcaron period -60
+KPX rcaron q -20
+KPX rcaron s -15
+KPX rcaron sacute -15
+KPX rcaron scaron -15
+KPX rcaron scedilla -15
+KPX rcaron scommaaccent -15
+KPX rcaron t 20
+KPX rcaron tcommaaccent 20
+KPX rcaron v 10
+KPX rcaron y 10
+KPX rcaron yacute 10
+KPX rcaron ydieresis 10
+KPX rcommaaccent c -20
+KPX rcommaaccent cacute -20
+KPX rcommaaccent ccaron -20
+KPX rcommaaccent ccedilla -20
+KPX rcommaaccent comma -60
+KPX rcommaaccent d -20
+KPX rcommaaccent dcroat -20
+KPX rcommaaccent g -15
+KPX rcommaaccent gbreve -15
+KPX rcommaaccent gcommaaccent -15
+KPX rcommaaccent hyphen -20
+KPX rcommaaccent o -20
+KPX rcommaaccent oacute -20
+KPX rcommaaccent ocircumflex -20
+KPX rcommaaccent odieresis -20
+KPX rcommaaccent ograve -20
+KPX rcommaaccent ohungarumlaut -20
+KPX rcommaaccent omacron -20
+KPX rcommaaccent oslash -20
+KPX rcommaaccent otilde -20
+KPX rcommaaccent period -60
+KPX rcommaaccent q -20
+KPX rcommaaccent s -15
+KPX rcommaaccent sacute -15
+KPX rcommaaccent scaron -15
+KPX rcommaaccent scedilla -15
+KPX rcommaaccent scommaaccent -15
+KPX rcommaaccent t 20
+KPX rcommaaccent tcommaaccent 20
+KPX rcommaaccent v 10
+KPX rcommaaccent y 10
+KPX rcommaaccent yacute 10
+KPX rcommaaccent ydieresis 10
+KPX s w -15
+KPX sacute w -15
+KPX scaron w -15
+KPX scedilla w -15
+KPX scommaaccent w -15
+KPX semicolon space -40
+KPX space T -100
+KPX space Tcaron -100
+KPX space Tcommaaccent -100
+KPX space V -80
+KPX space W -80
+KPX space Y -120
+KPX space Yacute -120
+KPX space Ydieresis -120
+KPX space quotedblleft -80
+KPX space quoteleft -60
+KPX v a -20
+KPX v aacute -20
+KPX v abreve -20
+KPX v acircumflex -20
+KPX v adieresis -20
+KPX v agrave -20
+KPX v amacron -20
+KPX v aogonek -20
+KPX v aring -20
+KPX v atilde -20
+KPX v comma -80
+KPX v o -30
+KPX v oacute -30
+KPX v ocircumflex -30
+KPX v odieresis -30
+KPX v ograve -30
+KPX v ohungarumlaut -30
+KPX v omacron -30
+KPX v oslash -30
+KPX v otilde -30
+KPX v period -80
+KPX w comma -40
+KPX w o -20
+KPX w oacute -20
+KPX w ocircumflex -20
+KPX w odieresis -20
+KPX w ograve -20
+KPX w ohungarumlaut -20
+KPX w omacron -20
+KPX w oslash -20
+KPX w otilde -20
+KPX w period -40
+KPX x e -10
+KPX x eacute -10
+KPX x ecaron -10
+KPX x ecircumflex -10
+KPX x edieresis -10
+KPX x edotaccent -10
+KPX x egrave -10
+KPX x emacron -10
+KPX x eogonek -10
+KPX y a -30
+KPX y aacute -30
+KPX y abreve -30
+KPX y acircumflex -30
+KPX y adieresis -30
+KPX y agrave -30
+KPX y amacron -30
+KPX y aogonek -30
+KPX y aring -30
+KPX y atilde -30
+KPX y comma -80
+KPX y e -10
+KPX y eacute -10
+KPX y ecaron -10
+KPX y ecircumflex -10
+KPX y edieresis -10
+KPX y edotaccent -10
+KPX y egrave -10
+KPX y emacron -10
+KPX y eogonek -10
+KPX y o -25
+KPX y oacute -25
+KPX y ocircumflex -25
+KPX y odieresis -25
+KPX y ograve -25
+KPX y ohungarumlaut -25
+KPX y omacron -25
+KPX y oslash -25
+KPX y otilde -25
+KPX y period -80
+KPX yacute a -30
+KPX yacute aacute -30
+KPX yacute abreve -30
+KPX yacute acircumflex -30
+KPX yacute adieresis -30
+KPX yacute agrave -30
+KPX yacute amacron -30
+KPX yacute aogonek -30
+KPX yacute aring -30
+KPX yacute atilde -30
+KPX yacute comma -80
+KPX yacute e -10
+KPX yacute eacute -10
+KPX yacute ecaron -10
+KPX yacute ecircumflex -10
+KPX yacute edieresis -10
+KPX yacute edotaccent -10
+KPX yacute egrave -10
+KPX yacute emacron -10
+KPX yacute eogonek -10
+KPX yacute o -25
+KPX yacute oacute -25
+KPX yacute ocircumflex -25
+KPX yacute odieresis -25
+KPX yacute ograve -25
+KPX yacute ohungarumlaut -25
+KPX yacute omacron -25
+KPX yacute oslash -25
+KPX yacute otilde -25
+KPX yacute period -80
+KPX ydieresis a -30
+KPX ydieresis aacute -30
+KPX ydieresis abreve -30
+KPX ydieresis acircumflex -30
+KPX ydieresis adieresis -30
+KPX ydieresis agrave -30
+KPX ydieresis amacron -30
+KPX ydieresis aogonek -30
+KPX ydieresis aring -30
+KPX ydieresis atilde -30
+KPX ydieresis comma -80
+KPX ydieresis e -10
+KPX ydieresis eacute -10
+KPX ydieresis ecaron -10
+KPX ydieresis ecircumflex -10
+KPX ydieresis edieresis -10
+KPX ydieresis edotaccent -10
+KPX ydieresis egrave -10
+KPX ydieresis emacron -10
+KPX ydieresis eogonek -10
+KPX ydieresis o -25
+KPX ydieresis oacute -25
+KPX ydieresis ocircumflex -25
+KPX ydieresis odieresis -25
+KPX ydieresis ograve -25
+KPX ydieresis ohungarumlaut -25
+KPX ydieresis omacron -25
+KPX ydieresis oslash -25
+KPX ydieresis otilde -25
+KPX ydieresis period -80
+KPX z e 10
+KPX z eacute 10
+KPX z ecaron 10
+KPX z ecircumflex 10
+KPX z edieresis 10
+KPX z edotaccent 10
+KPX z egrave 10
+KPX z emacron 10
+KPX z eogonek 10
+KPX zacute e 10
+KPX zacute eacute 10
+KPX zacute ecaron 10
+KPX zacute ecircumflex 10
+KPX zacute edieresis 10
+KPX zacute edotaccent 10
+KPX zacute egrave 10
+KPX zacute emacron 10
+KPX zacute eogonek 10
+KPX zcaron e 10
+KPX zcaron eacute 10
+KPX zcaron ecaron 10
+KPX zcaron ecircumflex 10
+KPX zcaron edieresis 10
+KPX zcaron edotaccent 10
+KPX zcaron egrave 10
+KPX zcaron emacron 10
+KPX zcaron eogonek 10
+KPX zdotaccent e 10
+KPX zdotaccent eacute 10
+KPX zdotaccent ecaron 10
+KPX zdotaccent ecircumflex 10
+KPX zdotaccent edieresis 10
+KPX zdotaccent edotaccent 10
+KPX zdotaccent egrave 10
+KPX zdotaccent emacron 10
+KPX zdotaccent eogonek 10
+EndKernPairs
+EndKernData
+EndFontMetrics
Added: trunk/mapbender/http/classes/fonts/Helvetica-Oblique.afm
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/fonts/Helvetica-Oblique.afm?view=auto&rev=13
--- (empty file)
+++ trunk/mapbender/http/classes/fonts/Helvetica-Oblique.afm 2006-04-13 19:38:28+0000
@@ -0,0 +1,3051 @@
+StartFontMetrics 4.1
+Comment Copyright (c) 1985, 1987, 1989, 1990, 1997 Adobe Systems Incorporated. All Rights Reserved.
+Comment Creation Date: Thu May 1 12:44:31 1997
+Comment UniqueID 43055
+Comment VMusage 14960 69346
+FontName Helvetica-Oblique
+FullName Helvetica Oblique
+FamilyName Helvetica
+Weight Medium
+ItalicAngle -12
+IsFixedPitch false
+CharacterSet ExtendedRoman
+FontBBox -170 -225 1116 931
+UnderlinePosition -100
+UnderlineThickness 50
+Version 002.000
+Notice Copyright (c) 1985, 1987, 1989, 1990, 1997 Adobe Systems Incorporated. All Rights Reserved.Helvetica is a trademark of Linotype-Hell AG and/or its subsidiaries.
+EncodingScheme AdobeStandardEncoding
+CapHeight 718
+XHeight 523
+Ascender 718
+Descender -207
+StdHW 76
+StdVW 88
+StartCharMetrics 315
+C 32 ; WX 278 ; N space ; B 0 0 0 0 ;
+C 33 ; WX 278 ; N exclam ; B 90 0 340 718 ;
+C 34 ; WX 355 ; N quotedbl ; B 168 463 438 718 ;
+C 35 ; WX 556 ; N numbersign ; B 73 0 631 688 ;
+C 36 ; WX 556 ; N dollar ; B 69 -115 617 775 ;
+C 37 ; WX 889 ; N percent ; B 147 -19 889 703 ;
+C 38 ; WX 667 ; N ampersand ; B 77 -15 647 718 ;
+C 39 ; WX 222 ; N quoteright ; B 151 463 310 718 ;
+C 40 ; WX 333 ; N parenleft ; B 108 -207 454 733 ;
+C 41 ; WX 333 ; N parenright ; B -9 -207 337 733 ;
+C 42 ; WX 389 ; N asterisk ; B 165 431 475 718 ;
+C 43 ; WX 584 ; N plus ; B 85 0 606 505 ;
+C 44 ; WX 278 ; N comma ; B 56 -147 214 106 ;
+C 45 ; WX 333 ; N hyphen ; B 93 232 357 322 ;
+C 46 ; WX 278 ; N period ; B 87 0 214 106 ;
+C 47 ; WX 278 ; N slash ; B -21 -19 452 737 ;
+C 48 ; WX 556 ; N zero ; B 93 -19 608 703 ;
+C 49 ; WX 556 ; N one ; B 207 0 508 703 ;
+C 50 ; WX 556 ; N two ; B 26 0 617 703 ;
+C 51 ; WX 556 ; N three ; B 75 -19 610 703 ;
+C 52 ; WX 556 ; N four ; B 61 0 576 703 ;
+C 53 ; WX 556 ; N five ; B 68 -19 621 688 ;
+C 54 ; WX 556 ; N six ; B 91 -19 615 703 ;
+C 55 ; WX 556 ; N seven ; B 137 0 669 688 ;
+C 56 ; WX 556 ; N eight ; B 74 -19 607 703 ;
+C 57 ; WX 556 ; N nine ; B 82 -19 609 703 ;
+C 58 ; WX 278 ; N colon ; B 87 0 301 516 ;
+C 59 ; WX 278 ; N semicolon ; B 56 -147 301 516 ;
+C 60 ; WX 584 ; N less ; B 94 11 641 495 ;
+C 61 ; WX 584 ; N equal ; B 63 115 628 390 ;
+C 62 ; WX 584 ; N greater ; B 50 11 597 495 ;
+C 63 ; WX 556 ; N question ; B 161 0 610 727 ;
+C 64 ; WX 1015 ; N at ; B 215 -19 965 737 ;
+C 65 ; WX 667 ; N A ; B 14 0 654 718 ;
+C 66 ; WX 667 ; N B ; B 74 0 712 718 ;
+C 67 ; WX 722 ; N C ; B 108 -19 782 737 ;
+C 68 ; WX 722 ; N D ; B 81 0 764 718 ;
+C 69 ; WX 667 ; N E ; B 86 0 762 718 ;
+C 70 ; WX 611 ; N F ; B 86 0 736 718 ;
+C 71 ; WX 778 ; N G ; B 111 -19 799 737 ;
+C 72 ; WX 722 ; N H ; B 77 0 799 718 ;
+C 73 ; WX 278 ; N I ; B 91 0 341 718 ;
+C 74 ; WX 500 ; N J ; B 47 -19 581 718 ;
+C 75 ; WX 667 ; N K ; B 76 0 808 718 ;
+C 76 ; WX 556 ; N L ; B 76 0 555 718 ;
+C 77 ; WX 833 ; N M ; B 73 0 914 718 ;
+C 78 ; WX 722 ; N N ; B 76 0 799 718 ;
+C 79 ; WX 778 ; N O ; B 105 -19 826 737 ;
+C 80 ; WX 667 ; N P ; B 86 0 737 718 ;
+C 81 ; WX 778 ; N Q ; B 105 -56 826 737 ;
+C 82 ; WX 722 ; N R ; B 88 0 773 718 ;
+C 83 ; WX 667 ; N S ; B 90 -19 713 737 ;
+C 84 ; WX 611 ; N T ; B 148 0 750 718 ;
+C 85 ; WX 722 ; N U ; B 123 -19 797 718 ;
+C 86 ; WX 667 ; N V ; B 173 0 800 718 ;
+C 87 ; WX 944 ; N W ; B 169 0 1081 718 ;
+C 88 ; WX 667 ; N X ; B 19 0 790 718 ;
+C 89 ; WX 667 ; N Y ; B 167 0 806 718 ;
+C 90 ; WX 611 ; N Z ; B 23 0 741 718 ;
+C 91 ; WX 278 ; N bracketleft ; B 21 -196 403 722 ;
+C 92 ; WX 278 ; N backslash ; B 140 -19 291 737 ;
+C 93 ; WX 278 ; N bracketright ; B -14 -196 368 722 ;
+C 94 ; WX 469 ; N asciicircum ; B 42 264 539 688 ;
+C 95 ; WX 556 ; N underscore ; B -27 -125 540 -75 ;
+C 96 ; WX 222 ; N quoteleft ; B 165 470 323 725 ;
+C 97 ; WX 556 ; N a ; B 61 -15 559 538 ;
+C 98 ; WX 556 ; N b ; B 58 -15 584 718 ;
+C 99 ; WX 500 ; N c ; B 74 -15 553 538 ;
+C 100 ; WX 556 ; N d ; B 84 -15 652 718 ;
+C 101 ; WX 556 ; N e ; B 84 -15 578 538 ;
+C 102 ; WX 278 ; N f ; B 86 0 416 728 ; L i fi ; L l fl ;
+C 103 ; WX 556 ; N g ; B 42 -220 610 538 ;
+C 104 ; WX 556 ; N h ; B 65 0 573 718 ;
+C 105 ; WX 222 ; N i ; B 67 0 308 718 ;
+C 106 ; WX 222 ; N j ; B -60 -210 308 718 ;
+C 107 ; WX 500 ; N k ; B 67 0 600 718 ;
+C 108 ; WX 222 ; N l ; B 67 0 308 718 ;
+C 109 ; WX 833 ; N m ; B 65 0 852 538 ;
+C 110 ; WX 556 ; N n ; B 65 0 573 538 ;
+C 111 ; WX 556 ; N o ; B 83 -14 585 538 ;
+C 112 ; WX 556 ; N p ; B 14 -207 584 538 ;
+C 113 ; WX 556 ; N q ; B 84 -207 605 538 ;
+C 114 ; WX 333 ; N r ; B 77 0 446 538 ;
+C 115 ; WX 500 ; N s ; B 63 -15 529 538 ;
+C 116 ; WX 278 ; N t ; B 102 -7 368 669 ;
+C 117 ; WX 556 ; N u ; B 94 -15 600 523 ;
+C 118 ; WX 500 ; N v ; B 119 0 603 523 ;
+C 119 ; WX 722 ; N w ; B 125 0 820 523 ;
+C 120 ; WX 500 ; N x ; B 11 0 594 523 ;
+C 121 ; WX 500 ; N y ; B 15 -214 600 523 ;
+C 122 ; WX 500 ; N z ; B 31 0 571 523 ;
+C 123 ; WX 334 ; N braceleft ; B 92 -196 445 722 ;
+C 124 ; WX 260 ; N bar ; B 46 -225 332 775 ;
+C 125 ; WX 334 ; N braceright ; B 0 -196 354 722 ;
+C 126 ; WX 584 ; N asciitilde ; B 111 180 580 326 ;
+C 161 ; WX 333 ; N exclamdown ; B 77 -195 326 523 ;
+C 162 ; WX 556 ; N cent ; B 95 -115 584 623 ;
+C 163 ; WX 556 ; N sterling ; B 49 -16 634 718 ;
+C 164 ; WX 167 ; N fraction ; B -170 -19 482 703 ;
+C 165 ; WX 556 ; N yen ; B 81 0 699 688 ;
+C 166 ; WX 556 ; N florin ; B -52 -207 654 737 ;
+C 167 ; WX 556 ; N section ; B 76 -191 584 737 ;
+C 168 ; WX 556 ; N currency ; B 60 99 646 603 ;
+C 169 ; WX 191 ; N quotesingle ; B 157 463 285 718 ;
+C 170 ; WX 333 ; N quotedblleft ; B 138 470 461 725 ;
+C 171 ; WX 556 ; N guillemotleft ; B 146 108 554 446 ;
+C 172 ; WX 333 ; N guilsinglleft ; B 137 108 340 446 ;
+C 173 ; WX 333 ; N guilsinglright ; B 111 108 314 446 ;
+C 174 ; WX 500 ; N fi ; B 86 0 587 728 ;
+C 175 ; WX 500 ; N fl ; B 86 0 585 728 ;
+C 177 ; WX 556 ; N endash ; B 51 240 623 313 ;
+C 178 ; WX 556 ; N dagger ; B 135 -159 622 718 ;
+C 179 ; WX 556 ; N daggerdbl ; B 52 -159 623 718 ;
+C 180 ; WX 278 ; N periodcentered ; B 129 190 257 315 ;
+C 182 ; WX 537 ; N paragraph ; B 126 -173 650 718 ;
+C 183 ; WX 350 ; N bullet ; B 91 202 413 517 ;
+C 184 ; WX 222 ; N quotesinglbase ; B 21 -149 180 106 ;
+C 185 ; WX 333 ; N quotedblbase ; B -6 -149 318 106 ;
+C 186 ; WX 333 ; N quotedblright ; B 124 463 448 718 ;
+C 187 ; WX 556 ; N guillemotright ; B 120 108 528 446 ;
+C 188 ; WX 1000 ; N ellipsis ; B 115 0 908 106 ;
+C 189 ; WX 1000 ; N perthousand ; B 88 -19 1029 703 ;
+C 191 ; WX 611 ; N questiondown ; B 85 -201 534 525 ;
+C 193 ; WX 333 ; N grave ; B 170 593 337 734 ;
+C 194 ; WX 333 ; N acute ; B 248 593 475 734 ;
+C 195 ; WX 333 ; N circumflex ; B 147 593 438 734 ;
+C 196 ; WX 333 ; N tilde ; B 125 606 490 722 ;
+C 197 ; WX 333 ; N macron ; B 143 627 468 684 ;
+C 198 ; WX 333 ; N breve ; B 167 595 476 731 ;
+C 199 ; WX 333 ; N dotaccent ; B 249 604 362 706 ;
+C 200 ; WX 333 ; N dieresis ; B 168 604 443 706 ;
+C 202 ; WX 333 ; N ring ; B 214 572 402 756 ;
+C 203 ; WX 333 ; N cedilla ; B 2 -225 232 0 ;
+C 205 ; WX 333 ; N hungarumlaut ; B 157 593 565 734 ;
+C 206 ; WX 333 ; N ogonek ; B 43 -225 249 0 ;
+C 207 ; WX 333 ; N caron ; B 177 593 468 734 ;
+C 208 ; WX 1000 ; N emdash ; B 51 240 1067 313 ;
+C 225 ; WX 1000 ; N AE ; B 8 0 1097 718 ;
+C 227 ; WX 370 ; N ordfeminine ; B 127 405 449 737 ;
+C 232 ; WX 556 ; N Lslash ; B 41 0 555 718 ;
+C 233 ; WX 778 ; N Oslash ; B 43 -19 890 737 ;
+C 234 ; WX 1000 ; N OE ; B 98 -19 1116 737 ;
+C 235 ; WX 365 ; N ordmasculine ; B 141 405 468 737 ;
+C 241 ; WX 889 ; N ae ; B 61 -15 909 538 ;
+C 245 ; WX 278 ; N dotlessi ; B 95 0 294 523 ;
+C 248 ; WX 222 ; N lslash ; B 41 0 347 718 ;
+C 249 ; WX 611 ; N oslash ; B 29 -22 647 545 ;
+C 250 ; WX 944 ; N oe ; B 83 -15 964 538 ;
+C 251 ; WX 611 ; N germandbls ; B 67 -15 658 728 ;
+C -1 ; WX 278 ; N Idieresis ; B 91 0 458 901 ;
+C -1 ; WX 556 ; N eacute ; B 84 -15 587 734 ;
+C -1 ; WX 556 ; N abreve ; B 61 -15 578 731 ;
+C -1 ; WX 556 ; N uhungarumlaut ; B 94 -15 677 734 ;
+C -1 ; WX 556 ; N ecaron ; B 84 -15 580 734 ;
+C -1 ; WX 667 ; N Ydieresis ; B 167 0 806 901 ;
+C -1 ; WX 584 ; N divide ; B 85 -19 606 524 ;
+C -1 ; WX 667 ; N Yacute ; B 167 0 806 929 ;
+C -1 ; WX 667 ; N Acircumflex ; B 14 0 654 929 ;
+C -1 ; WX 556 ; N aacute ; B 61 -15 587 734 ;
+C -1 ; WX 722 ; N Ucircumflex ; B 123 -19 797 929 ;
+C -1 ; WX 500 ; N yacute ; B 15 -214 600 734 ;
+C -1 ; WX 500 ; N scommaaccent ; B 63 -225 529 538 ;
+C -1 ; WX 556 ; N ecircumflex ; B 84 -15 578 734 ;
+C -1 ; WX 722 ; N Uring ; B 123 -19 797 931 ;
+C -1 ; WX 722 ; N Udieresis ; B 123 -19 797 901 ;
+C -1 ; WX 556 ; N aogonek ; B 61 -220 559 538 ;
+C -1 ; WX 722 ; N Uacute ; B 123 -19 797 929 ;
+C -1 ; WX 556 ; N uogonek ; B 94 -225 600 523 ;
+C -1 ; WX 667 ; N Edieresis ; B 86 0 762 901 ;
+C -1 ; WX 722 ; N Dcroat ; B 69 0 764 718 ;
+C -1 ; WX 250 ; N commaaccent ; B 39 -225 172 -40 ;
+C -1 ; WX 737 ; N copyright ; B 54 -19 837 737 ;
+C -1 ; WX 667 ; N Emacron ; B 86 0 762 879 ;
+C -1 ; WX 500 ; N ccaron ; B 74 -15 553 734 ;
+C -1 ; WX 556 ; N aring ; B 61 -15 559 756 ;
+C -1 ; WX 722 ; N Ncommaaccent ; B 76 -225 799 718 ;
+C -1 ; WX 222 ; N lacute ; B 67 0 461 929 ;
+C -1 ; WX 556 ; N agrave ; B 61 -15 559 734 ;
+C -1 ; WX 611 ; N Tcommaaccent ; B 148 -225 750 718 ;
+C -1 ; WX 722 ; N Cacute ; B 108 -19 782 929 ;
+C -1 ; WX 556 ; N atilde ; B 61 -15 592 722 ;
+C -1 ; WX 667 ; N Edotaccent ; B 86 0 762 901 ;
+C -1 ; WX 500 ; N scaron ; B 63 -15 552 734 ;
+C -1 ; WX 500 ; N scedilla ; B 63 -225 529 538 ;
+C -1 ; WX 278 ; N iacute ; B 95 0 448 734 ;
+C -1 ; WX 471 ; N lozenge ; B 88 0 540 728 ;
+C -1 ; WX 722 ; N Rcaron ; B 88 0 773 929 ;
+C -1 ; WX 778 ; N Gcommaaccent ; B 111 -225 799 737 ;
+C -1 ; WX 556 ; N ucircumflex ; B 94 -15 600 734 ;
+C -1 ; WX 556 ; N acircumflex ; B 61 -15 559 734 ;
+C -1 ; WX 667 ; N Amacron ; B 14 0 677 879 ;
+C -1 ; WX 333 ; N rcaron ; B 77 0 508 734 ;
+C -1 ; WX 500 ; N ccedilla ; B 74 -225 553 538 ;
+C -1 ; WX 611 ; N Zdotaccent ; B 23 0 741 901 ;
+C -1 ; WX 667 ; N Thorn ; B 86 0 712 718 ;
+C -1 ; WX 778 ; N Omacron ; B 105 -19 826 879 ;
+C -1 ; WX 722 ; N Racute ; B 88 0 773 929 ;
+C -1 ; WX 667 ; N Sacute ; B 90 -19 713 929 ;
+C -1 ; WX 643 ; N dcaron ; B 84 -15 808 718 ;
+C -1 ; WX 722 ; N Umacron ; B 123 -19 797 879 ;
+C -1 ; WX 556 ; N uring ; B 94 -15 600 756 ;
+C -1 ; WX 333 ; N threesuperior ; B 90 270 436 703 ;
+C -1 ; WX 778 ; N Ograve ; B 105 -19 826 929 ;
+C -1 ; WX 667 ; N Agrave ; B 14 0 654 929 ;
+C -1 ; WX 667 ; N Abreve ; B 14 0 685 926 ;
+C -1 ; WX 584 ; N multiply ; B 50 0 642 506 ;
+C -1 ; WX 556 ; N uacute ; B 94 -15 600 734 ;
+C -1 ; WX 611 ; N Tcaron ; B 148 0 750 929 ;
+C -1 ; WX 476 ; N partialdiff ; B 41 -38 550 714 ;
+C -1 ; WX 500 ; N ydieresis ; B 15 -214 600 706 ;
+C -1 ; WX 722 ; N Nacute ; B 76 0 799 929 ;
+C -1 ; WX 278 ; N icircumflex ; B 95 0 411 734 ;
+C -1 ; WX 667 ; N Ecircumflex ; B 86 0 762 929 ;
+C -1 ; WX 556 ; N adieresis ; B 61 -15 559 706 ;
+C -1 ; WX 556 ; N edieresis ; B 84 -15 578 706 ;
+C -1 ; WX 500 ; N cacute ; B 74 -15 559 734 ;
+C -1 ; WX 556 ; N nacute ; B 65 0 587 734 ;
+C -1 ; WX 556 ; N umacron ; B 94 -15 600 684 ;
+C -1 ; WX 722 ; N Ncaron ; B 76 0 799 929 ;
+C -1 ; WX 278 ; N Iacute ; B 91 0 489 929 ;
+C -1 ; WX 584 ; N plusminus ; B 39 0 618 506 ;
+C -1 ; WX 260 ; N brokenbar ; B 62 -150 316 700 ;
+C -1 ; WX 737 ; N registered ; B 54 -19 837 737 ;
+C -1 ; WX 778 ; N Gbreve ; B 111 -19 799 926 ;
+C -1 ; WX 278 ; N Idotaccent ; B 91 0 377 901 ;
+C -1 ; WX 600 ; N summation ; B 15 -10 671 706 ;
+C -1 ; WX 667 ; N Egrave ; B 86 0 762 929 ;
+C -1 ; WX 333 ; N racute ; B 77 0 475 734 ;
+C -1 ; WX 556 ; N omacron ; B 83 -14 585 684 ;
+C -1 ; WX 611 ; N Zacute ; B 23 0 741 929 ;
+C -1 ; WX 611 ; N Zcaron ; B 23 0 741 929 ;
+C -1 ; WX 549 ; N greaterequal ; B 26 0 620 674 ;
+C -1 ; WX 722 ; N Eth ; B 69 0 764 718 ;
+C -1 ; WX 722 ; N Ccedilla ; B 108 -225 782 737 ;
+C -1 ; WX 222 ; N lcommaaccent ; B 25 -225 308 718 ;
+C -1 ; WX 317 ; N tcaron ; B 102 -7 501 808 ;
+C -1 ; WX 556 ; N eogonek ; B 84 -225 578 538 ;
+C -1 ; WX 722 ; N Uogonek ; B 123 -225 797 718 ;
+C -1 ; WX 667 ; N Aacute ; B 14 0 683 929 ;
+C -1 ; WX 667 ; N Adieresis ; B 14 0 654 901 ;
+C -1 ; WX 556 ; N egrave ; B 84 -15 578 734 ;
+C -1 ; WX 500 ; N zacute ; B 31 0 571 734 ;
+C -1 ; WX 222 ; N iogonek ; B -61 -225 308 718 ;
+C -1 ; WX 778 ; N Oacute ; B 105 -19 826 929 ;
+C -1 ; WX 556 ; N oacute ; B 83 -14 587 734 ;
+C -1 ; WX 556 ; N amacron ; B 61 -15 580 684 ;
+C -1 ; WX 500 ; N sacute ; B 63 -15 559 734 ;
+C -1 ; WX 278 ; N idieresis ; B 95 0 416 706 ;
+C -1 ; WX 778 ; N Ocircumflex ; B 105 -19 826 929 ;
+C -1 ; WX 722 ; N Ugrave ; B 123 -19 797 929 ;
+C -1 ; WX 612 ; N Delta ; B 6 0 608 688 ;
+C -1 ; WX 556 ; N thorn ; B 14 -207 584 718 ;
+C -1 ; WX 333 ; N twosuperior ; B 64 281 449 703 ;
+C -1 ; WX 778 ; N Odieresis ; B 105 -19 826 901 ;
+C -1 ; WX 556 ; N mu ; B 24 -207 600 523 ;
+C -1 ; WX 278 ; N igrave ; B 95 0 310 734 ;
+C -1 ; WX 556 ; N ohungarumlaut ; B 83 -14 677 734 ;
+C -1 ; WX 667 ; N Eogonek ; B 86 -220 762 718 ;
+C -1 ; WX 556 ; N dcroat ; B 84 -15 689 718 ;
+C -1 ; WX 834 ; N threequarters ; B 130 -19 861 703 ;
+C -1 ; WX 667 ; N Scedilla ; B 90 -225 713 737 ;
+C -1 ; WX 299 ; N lcaron ; B 67 0 464 718 ;
+C -1 ; WX 667 ; N Kcommaaccent ; B 76 -225 808 718 ;
+C -1 ; WX 556 ; N Lacute ; B 76 0 555 929 ;
+C -1 ; WX 1000 ; N trademark ; B 186 306 1056 718 ;
+C -1 ; WX 556 ; N edotaccent ; B 84 -15 578 706 ;
+C -1 ; WX 278 ; N Igrave ; B 91 0 351 929 ;
+C -1 ; WX 278 ; N Imacron ; B 91 0 483 879 ;
+C -1 ; WX 556 ; N Lcaron ; B 76 0 570 718 ;
+C -1 ; WX 834 ; N onehalf ; B 114 -19 839 703 ;
+C -1 ; WX 549 ; N lessequal ; B 26 0 666 674 ;
+C -1 ; WX 556 ; N ocircumflex ; B 83 -14 585 734 ;
+C -1 ; WX 556 ; N ntilde ; B 65 0 592 722 ;
+C -1 ; WX 722 ; N Uhungarumlaut ; B 123 -19 801 929 ;
+C -1 ; WX 667 ; N Eacute ; B 86 0 762 929 ;
+C -1 ; WX 556 ; N emacron ; B 84 -15 580 684 ;
+C -1 ; WX 556 ; N gbreve ; B 42 -220 610 731 ;
+C -1 ; WX 834 ; N onequarter ; B 150 -19 802 703 ;
+C -1 ; WX 667 ; N Scaron ; B 90 -19 713 929 ;
+C -1 ; WX 667 ; N Scommaaccent ; B 90 -225 713 737 ;
+C -1 ; WX 778 ; N Ohungarumlaut ; B 105 -19 829 929 ;
+C -1 ; WX 400 ; N degree ; B 169 411 468 703 ;
+C -1 ; WX 556 ; N ograve ; B 83 -14 585 734 ;
+C -1 ; WX 722 ; N Ccaron ; B 108 -19 782 929 ;
+C -1 ; WX 556 ; N ugrave ; B 94 -15 600 734 ;
+C -1 ; WX 453 ; N radical ; B 79 -80 617 762 ;
+C -1 ; WX 722 ; N Dcaron ; B 81 0 764 929 ;
+C -1 ; WX 333 ; N rcommaaccent ; B 30 -225 446 538 ;
+C -1 ; WX 722 ; N Ntilde ; B 76 0 799 917 ;
+C -1 ; WX 556 ; N otilde ; B 83 -14 602 722 ;
+C -1 ; WX 722 ; N Rcommaaccent ; B 88 -225 773 718 ;
+C -1 ; WX 556 ; N Lcommaaccent ; B 76 -225 555 718 ;
+C -1 ; WX 667 ; N Atilde ; B 14 0 699 917 ;
+C -1 ; WX 667 ; N Aogonek ; B 14 -225 654 718 ;
+C -1 ; WX 667 ; N Aring ; B 14 0 654 931 ;
+C -1 ; WX 778 ; N Otilde ; B 105 -19 826 917 ;
+C -1 ; WX 500 ; N zdotaccent ; B 31 0 571 706 ;
+C -1 ; WX 667 ; N Ecaron ; B 86 0 762 929 ;
+C -1 ; WX 278 ; N Iogonek ; B -33 -225 341 718 ;
+C -1 ; WX 500 ; N kcommaaccent ; B 67 -225 600 718 ;
+C -1 ; WX 584 ; N minus ; B 85 216 606 289 ;
+C -1 ; WX 278 ; N Icircumflex ; B 91 0 452 929 ;
+C -1 ; WX 556 ; N ncaron ; B 65 0 580 734 ;
+C -1 ; WX 278 ; N tcommaaccent ; B 63 -225 368 669 ;
+C -1 ; WX 584 ; N logicalnot ; B 106 108 628 390 ;
+C -1 ; WX 556 ; N odieresis ; B 83 -14 585 706 ;
+C -1 ; WX 556 ; N udieresis ; B 94 -15 600 706 ;
+C -1 ; WX 549 ; N notequal ; B 34 -35 623 551 ;
+C -1 ; WX 556 ; N gcommaaccent ; B 42 -220 610 822 ;
+C -1 ; WX 556 ; N eth ; B 81 -15 617 737 ;
+C -1 ; WX 500 ; N zcaron ; B 31 0 571 734 ;
+C -1 ; WX 556 ; N ncommaaccent ; B 65 -225 573 538 ;
+C -1 ; WX 333 ; N onesuperior ; B 166 281 371 703 ;
+C -1 ; WX 278 ; N imacron ; B 95 0 417 684 ;
+C -1 ; WX 556 ; N Euro ; B 0 0 0 0 ;
+EndCharMetrics
+StartKernData
+StartKernPairs 2705
+KPX A C -30
+KPX A Cacute -30
+KPX A Ccaron -30
+KPX A Ccedilla -30
+KPX A G -30
+KPX A Gbreve -30
+KPX A Gcommaaccent -30
+KPX A O -30
+KPX A Oacute -30
+KPX A Ocircumflex -30
+KPX A Odieresis -30
+KPX A Ograve -30
+KPX A Ohungarumlaut -30
+KPX A Omacron -30
+KPX A Oslash -30
+KPX A Otilde -30
+KPX A Q -30
+KPX A T -120
+KPX A Tcaron -120
+KPX A Tcommaaccent -120
+KPX A U -50
+KPX A Uacute -50
+KPX A Ucircumflex -50
+KPX A Udieresis -50
+KPX A Ugrave -50
+KPX A Uhungarumlaut -50
+KPX A Umacron -50
+KPX A Uogonek -50
+KPX A Uring -50
+KPX A V -70
+KPX A W -50
+KPX A Y -100
+KPX A Yacute -100
+KPX A Ydieresis -100
+KPX A u -30
+KPX A uacute -30
+KPX A ucircumflex -30
+KPX A udieresis -30
+KPX A ugrave -30
+KPX A uhungarumlaut -30
+KPX A umacron -30
+KPX A uogonek -30
+KPX A uring -30
+KPX A v -40
+KPX A w -40
+KPX A y -40
+KPX A yacute -40
+KPX A ydieresis -40
+KPX Aacute C -30
+KPX Aacute Cacute -30
+KPX Aacute Ccaron -30
+KPX Aacute Ccedilla -30
+KPX Aacute G -30
+KPX Aacute Gbreve -30
+KPX Aacute Gcommaaccent -30
+KPX Aacute O -30
+KPX Aacute Oacute -30
+KPX Aacute Ocircumflex -30
+KPX Aacute Odieresis -30
+KPX Aacute Ograve -30
+KPX Aacute Ohungarumlaut -30
+KPX Aacute Omacron -30
+KPX Aacute Oslash -30
+KPX Aacute Otilde -30
+KPX Aacute Q -30
+KPX Aacute T -120
+KPX Aacute Tcaron -120
+KPX Aacute Tcommaaccent -120
+KPX Aacute U -50
+KPX Aacute Uacute -50
+KPX Aacute Ucircumflex -50
+KPX Aacute Udieresis -50
+KPX Aacute Ugrave -50
+KPX Aacute Uhungarumlaut -50
+KPX Aacute Umacron -50
+KPX Aacute Uogonek -50
+KPX Aacute Uring -50
+KPX Aacute V -70
+KPX Aacute W -50
+KPX Aacute Y -100
+KPX Aacute Yacute -100
+KPX Aacute Ydieresis -100
+KPX Aacute u -30
+KPX Aacute uacute -30
+KPX Aacute ucircumflex -30
+KPX Aacute udieresis -30
+KPX Aacute ugrave -30
+KPX Aacute uhungarumlaut -30
+KPX Aacute umacron -30
+KPX Aacute uogonek -30
+KPX Aacute uring -30
+KPX Aacute v -40
+KPX Aacute w -40
+KPX Aacute y -40
+KPX Aacute yacute -40
+KPX Aacute ydieresis -40
+KPX Abreve C -30
+KPX Abreve Cacute -30
+KPX Abreve Ccaron -30
+KPX Abreve Ccedilla -30
+KPX Abreve G -30
+KPX Abreve Gbreve -30
+KPX Abreve Gcommaaccent -30
+KPX Abreve O -30
+KPX Abreve Oacute -30
+KPX Abreve Ocircumflex -30
+KPX Abreve Odieresis -30
+KPX Abreve Ograve -30
+KPX Abreve Ohungarumlaut -30
+KPX Abreve Omacron -30
+KPX Abreve Oslash -30
+KPX Abreve Otilde -30
+KPX Abreve Q -30
+KPX Abreve T -120
+KPX Abreve Tcaron -120
+KPX Abreve Tcommaaccent -120
+KPX Abreve U -50
+KPX Abreve Uacute -50
+KPX Abreve Ucircumflex -50
+KPX Abreve Udieresis -50
+KPX Abreve Ugrave -50
+KPX Abreve Uhungarumlaut -50
+KPX Abreve Umacron -50
+KPX Abreve Uogonek -50
+KPX Abreve Uring -50
+KPX Abreve V -70
+KPX Abreve W -50
+KPX Abreve Y -100
+KPX Abreve Yacute -100
+KPX Abreve Ydieresis -100
+KPX Abreve u -30
+KPX Abreve uacute -30
+KPX Abreve ucircumflex -30
+KPX Abreve udieresis -30
+KPX Abreve ugrave -30
+KPX Abreve uhungarumlaut -30
+KPX Abreve umacron -30
+KPX Abreve uogonek -30
+KPX Abreve uring -30
+KPX Abreve v -40
+KPX Abreve w -40
+KPX Abreve y -40
+KPX Abreve yacute -40
+KPX Abreve ydieresis -40
+KPX Acircumflex C -30
+KPX Acircumflex Cacute -30
+KPX Acircumflex Ccaron -30
+KPX Acircumflex Ccedilla -30
+KPX Acircumflex G -30
+KPX Acircumflex Gbreve -30
+KPX Acircumflex Gcommaaccent -30
+KPX Acircumflex O -30
+KPX Acircumflex Oacute -30
+KPX Acircumflex Ocircumflex -30
+KPX Acircumflex Odieresis -30
+KPX Acircumflex Ograve -30
+KPX Acircumflex Ohungarumlaut -30
+KPX Acircumflex Omacron -30
+KPX Acircumflex Oslash -30
+KPX Acircumflex Otilde -30
+KPX Acircumflex Q -30
+KPX Acircumflex T -120
+KPX Acircumflex Tcaron -120
+KPX Acircumflex Tcommaaccent -120
+KPX Acircumflex U -50
+KPX Acircumflex Uacute -50
+KPX Acircumflex Ucircumflex -50
+KPX Acircumflex Udieresis -50
+KPX Acircumflex Ugrave -50
+KPX Acircumflex Uhungarumlaut -50
+KPX Acircumflex Umacron -50
+KPX Acircumflex Uogonek -50
+KPX Acircumflex Uring -50
+KPX Acircumflex V -70
+KPX Acircumflex W -50
+KPX Acircumflex Y -100
+KPX Acircumflex Yacute -100
+KPX Acircumflex Ydieresis -100
+KPX Acircumflex u -30
+KPX Acircumflex uacute -30
+KPX Acircumflex ucircumflex -30
+KPX Acircumflex udieresis -30
+KPX Acircumflex ugrave -30
+KPX Acircumflex uhungarumlaut -30
+KPX Acircumflex umacron -30
+KPX Acircumflex uogonek -30
+KPX Acircumflex uring -30
+KPX Acircumflex v -40
+KPX Acircumflex w -40
+KPX Acircumflex y -40
+KPX Acircumflex yacute -40
+KPX Acircumflex ydieresis -40
+KPX Adieresis C -30
+KPX Adieresis Cacute -30
+KPX Adieresis Ccaron -30
+KPX Adieresis Ccedilla -30
+KPX Adieresis G -30
+KPX Adieresis Gbreve -30
+KPX Adieresis Gcommaaccent -30
+KPX Adieresis O -30
+KPX Adieresis Oacute -30
+KPX Adieresis Ocircumflex -30
+KPX Adieresis Odieresis -30
+KPX Adieresis Ograve -30
+KPX Adieresis Ohungarumlaut -30
+KPX Adieresis Omacron -30
+KPX Adieresis Oslash -30
+KPX Adieresis Otilde -30
+KPX Adieresis Q -30
+KPX Adieresis T -120
+KPX Adieresis Tcaron -120
+KPX Adieresis Tcommaaccent -120
+KPX Adieresis U -50
+KPX Adieresis Uacute -50
+KPX Adieresis Ucircumflex -50
+KPX Adieresis Udieresis -50
+KPX Adieresis Ugrave -50
+KPX Adieresis Uhungarumlaut -50
+KPX Adieresis Umacron -50
+KPX Adieresis Uogonek -50
+KPX Adieresis Uring -50
+KPX Adieresis V -70
+KPX Adieresis W -50
+KPX Adieresis Y -100
+KPX Adieresis Yacute -100
+KPX Adieresis Ydieresis -100
+KPX Adieresis u -30
+KPX Adieresis uacute -30
+KPX Adieresis ucircumflex -30
+KPX Adieresis udieresis -30
+KPX Adieresis ugrave -30
+KPX Adieresis uhungarumlaut -30
+KPX Adieresis umacron -30
+KPX Adieresis uogonek -30
+KPX Adieresis uring -30
+KPX Adieresis v -40
+KPX Adieresis w -40
+KPX Adieresis y -40
+KPX Adieresis yacute -40
+KPX Adieresis ydieresis -40
+KPX Agrave C -30
+KPX Agrave Cacute -30
+KPX Agrave Ccaron -30
+KPX Agrave Ccedilla -30
+KPX Agrave G -30
+KPX Agrave Gbreve -30
+KPX Agrave Gcommaaccent -30
+KPX Agrave O -30
+KPX Agrave Oacute -30
+KPX Agrave Ocircumflex -30
+KPX Agrave Odieresis -30
+KPX Agrave Ograve -30
+KPX Agrave Ohungarumlaut -30
+KPX Agrave Omacron -30
+KPX Agrave Oslash -30
+KPX Agrave Otilde -30
+KPX Agrave Q -30
+KPX Agrave T -120
+KPX Agrave Tcaron -120
+KPX Agrave Tcommaaccent -120
+KPX Agrave U -50
+KPX Agrave Uacute -50
+KPX Agrave Ucircumflex -50
+KPX Agrave Udieresis -50
+KPX Agrave Ugrave -50
+KPX Agrave Uhungarumlaut -50
+KPX Agrave Umacron -50
+KPX Agrave Uogonek -50
+KPX Agrave Uring -50
+KPX Agrave V -70
+KPX Agrave W -50
+KPX Agrave Y -100
+KPX Agrave Yacute -100
+KPX Agrave Ydieresis -100
+KPX Agrave u -30
+KPX Agrave uacute -30
+KPX Agrave ucircumflex -30
+KPX Agrave udieresis -30
+KPX Agrave ugrave -30
+KPX Agrave uhungarumlaut -30
+KPX Agrave umacron -30
+KPX Agrave uogonek -30
+KPX Agrave uring -30
+KPX Agrave v -40
+KPX Agrave w -40
+KPX Agrave y -40
+KPX Agrave yacute -40
+KPX Agrave ydieresis -40
+KPX Amacron C -30
+KPX Amacron Cacute -30
+KPX Amacron Ccaron -30
+KPX Amacron Ccedilla -30
+KPX Amacron G -30
+KPX Amacron Gbreve -30
+KPX Amacron Gcommaaccent -30
+KPX Amacron O -30
+KPX Amacron Oacute -30
+KPX Amacron Ocircumflex -30
+KPX Amacron Odieresis -30
+KPX Amacron Ograve -30
+KPX Amacron Ohungarumlaut -30
+KPX Amacron Omacron -30
+KPX Amacron Oslash -30
+KPX Amacron Otilde -30
+KPX Amacron Q -30
+KPX Amacron T -120
+KPX Amacron Tcaron -120
+KPX Amacron Tcommaaccent -120
+KPX Amacron U -50
+KPX Amacron Uacute -50
+KPX Amacron Ucircumflex -50
+KPX Amacron Udieresis -50
+KPX Amacron Ugrave -50
+KPX Amacron Uhungarumlaut -50
+KPX Amacron Umacron -50
+KPX Amacron Uogonek -50
+KPX Amacron Uring -50
+KPX Amacron V -70
+KPX Amacron W -50
+KPX Amacron Y -100
+KPX Amacron Yacute -100
+KPX Amacron Ydieresis -100
+KPX Amacron u -30
+KPX Amacron uacute -30
+KPX Amacron ucircumflex -30
+KPX Amacron udieresis -30
+KPX Amacron ugrave -30
+KPX Amacron uhungarumlaut -30
+KPX Amacron umacron -30
+KPX Amacron uogonek -30
+KPX Amacron uring -30
+KPX Amacron v -40
+KPX Amacron w -40
+KPX Amacron y -40
+KPX Amacron yacute -40
+KPX Amacron ydieresis -40
+KPX Aogonek C -30
+KPX Aogonek Cacute -30
+KPX Aogonek Ccaron -30
+KPX Aogonek Ccedilla -30
+KPX Aogonek G -30
+KPX Aogonek Gbreve -30
+KPX Aogonek Gcommaaccent -30
+KPX Aogonek O -30
+KPX Aogonek Oacute -30
+KPX Aogonek Ocircumflex -30
+KPX Aogonek Odieresis -30
+KPX Aogonek Ograve -30
+KPX Aogonek Ohungarumlaut -30
+KPX Aogonek Omacron -30
+KPX Aogonek Oslash -30
+KPX Aogonek Otilde -30
+KPX Aogonek Q -30
+KPX Aogonek T -120
+KPX Aogonek Tcaron -120
+KPX Aogonek Tcommaaccent -120
+KPX Aogonek U -50
+KPX Aogonek Uacute -50
+KPX Aogonek Ucircumflex -50
+KPX Aogonek Udieresis -50
+KPX Aogonek Ugrave -50
+KPX Aogonek Uhungarumlaut -50
+KPX Aogonek Umacron -50
+KPX Aogonek Uogonek -50
+KPX Aogonek Uring -50
+KPX Aogonek V -70
+KPX Aogonek W -50
+KPX Aogonek Y -100
+KPX Aogonek Yacute -100
+KPX Aogonek Ydieresis -100
+KPX Aogonek u -30
+KPX Aogonek uacute -30
+KPX Aogonek ucircumflex -30
+KPX Aogonek udieresis -30
+KPX Aogonek ugrave -30
+KPX Aogonek uhungarumlaut -30
+KPX Aogonek umacron -30
+KPX Aogonek uogonek -30
+KPX Aogonek uring -30
+KPX Aogonek v -40
+KPX Aogonek w -40
+KPX Aogonek y -40
+KPX Aogonek yacute -40
+KPX Aogonek ydieresis -40
+KPX Aring C -30
+KPX Aring Cacute -30
+KPX Aring Ccaron -30
+KPX Aring Ccedilla -30
+KPX Aring G -30
+KPX Aring Gbreve -30
+KPX Aring Gcommaaccent -30
+KPX Aring O -30
+KPX Aring Oacute -30
+KPX Aring Ocircumflex -30
+KPX Aring Odieresis -30
+KPX Aring Ograve -30
+KPX Aring Ohungarumlaut -30
+KPX Aring Omacron -30
+KPX Aring Oslash -30
+KPX Aring Otilde -30
+KPX Aring Q -30
+KPX Aring T -120
+KPX Aring Tcaron -120
+KPX Aring Tcommaaccent -120
+KPX Aring U -50
+KPX Aring Uacute -50
+KPX Aring Ucircumflex -50
+KPX Aring Udieresis -50
+KPX Aring Ugrave -50
+KPX Aring Uhungarumlaut -50
+KPX Aring Umacron -50
+KPX Aring Uogonek -50
+KPX Aring Uring -50
+KPX Aring V -70
+KPX Aring W -50
+KPX Aring Y -100
+KPX Aring Yacute -100
+KPX Aring Ydieresis -100
+KPX Aring u -30
+KPX Aring uacute -30
+KPX Aring ucircumflex -30
+KPX Aring udieresis -30
+KPX Aring ugrave -30
+KPX Aring uhungarumlaut -30
+KPX Aring umacron -30
+KPX Aring uogonek -30
+KPX Aring uring -30
+KPX Aring v -40
+KPX Aring w -40
+KPX Aring y -40
+KPX Aring yacute -40
+KPX Aring ydieresis -40
+KPX Atilde C -30
+KPX Atilde Cacute -30
+KPX Atilde Ccaron -30
+KPX Atilde Ccedilla -30
+KPX Atilde G -30
+KPX Atilde Gbreve -30
+KPX Atilde Gcommaaccent -30
+KPX Atilde O -30
+KPX Atilde Oacute -30
+KPX Atilde Ocircumflex -30
+KPX Atilde Odieresis -30
+KPX Atilde Ograve -30
+KPX Atilde Ohungarumlaut -30
+KPX Atilde Omacron -30
+KPX Atilde Oslash -30
+KPX Atilde Otilde -30
+KPX Atilde Q -30
+KPX Atilde T -120
+KPX Atilde Tcaron -120
+KPX Atilde Tcommaaccent -120
+KPX Atilde U -50
+KPX Atilde Uacute -50
+KPX Atilde Ucircumflex -50
+KPX Atilde Udieresis -50
+KPX Atilde Ugrave -50
+KPX Atilde Uhungarumlaut -50
+KPX Atilde Umacron -50
+KPX Atilde Uogonek -50
+KPX Atilde Uring -50
+KPX Atilde V -70
+KPX Atilde W -50
+KPX Atilde Y -100
+KPX Atilde Yacute -100
+KPX Atilde Ydieresis -100
+KPX Atilde u -30
+KPX Atilde uacute -30
+KPX Atilde ucircumflex -30
+KPX Atilde udieresis -30
+KPX Atilde ugrave -30
+KPX Atilde uhungarumlaut -30
+KPX Atilde umacron -30
+KPX Atilde uogonek -30
+KPX Atilde uring -30
+KPX Atilde v -40
+KPX Atilde w -40
+KPX Atilde y -40
+KPX Atilde yacute -40
+KPX Atilde ydieresis -40
+KPX B U -10
+KPX B Uacute -10
+KPX B Ucircumflex -10
+KPX B Udieresis -10
+KPX B Ugrave -10
+KPX B Uhungarumlaut -10
+KPX B Umacron -10
+KPX B Uogonek -10
+KPX B Uring -10
+KPX B comma -20
+KPX B period -20
+KPX C comma -30
+KPX C period -30
+KPX Cacute comma -30
+KPX Cacute period -30
+KPX Ccaron comma -30
+KPX Ccaron period -30
+KPX Ccedilla comma -30
+KPX Ccedilla period -30
+KPX D A -40
+KPX D Aacute -40
+KPX D Abreve -40
+KPX D Acircumflex -40
+KPX D Adieresis -40
+KPX D Agrave -40
+KPX D Amacron -40
+KPX D Aogonek -40
+KPX D Aring -40
+KPX D Atilde -40
+KPX D V -70
+KPX D W -40
+KPX D Y -90
+KPX D Yacute -90
+KPX D Ydieresis -90
+KPX D comma -70
+KPX D period -70
+KPX Dcaron A -40
+KPX Dcaron Aacute -40
+KPX Dcaron Abreve -40
+KPX Dcaron Acircumflex -40
+KPX Dcaron Adieresis -40
+KPX Dcaron Agrave -40
+KPX Dcaron Amacron -40
+KPX Dcaron Aogonek -40
+KPX Dcaron Aring -40
+KPX Dcaron Atilde -40
+KPX Dcaron V -70
+KPX Dcaron W -40
+KPX Dcaron Y -90
+KPX Dcaron Yacute -90
+KPX Dcaron Ydieresis -90
+KPX Dcaron comma -70
+KPX Dcaron period -70
+KPX Dcroat A -40
+KPX Dcroat Aacute -40
+KPX Dcroat Abreve -40
+KPX Dcroat Acircumflex -40
+KPX Dcroat Adieresis -40
+KPX Dcroat Agrave -40
+KPX Dcroat Amacron -40
+KPX Dcroat Aogonek -40
+KPX Dcroat Aring -40
+KPX Dcroat Atilde -40
+KPX Dcroat V -70
+KPX Dcroat W -40
+KPX Dcroat Y -90
+KPX Dcroat Yacute -90
+KPX Dcroat Ydieresis -90
+KPX Dcroat comma -70
+KPX Dcroat period -70
+KPX F A -80
+KPX F Aacute -80
+KPX F Abreve -80
+KPX F Acircumflex -80
+KPX F Adieresis -80
+KPX F Agrave -80
+KPX F Amacron -80
+KPX F Aogonek -80
+KPX F Aring -80
+KPX F Atilde -80
+KPX F a -50
+KPX F aacute -50
+KPX F abreve -50
+KPX F acircumflex -50
+KPX F adieresis -50
+KPX F agrave -50
+KPX F amacron -50
+KPX F aogonek -50
+KPX F aring -50
+KPX F atilde -50
+KPX F comma -150
+KPX F e -30
+KPX F eacute -30
+KPX F ecaron -30
+KPX F ecircumflex -30
+KPX F edieresis -30
+KPX F edotaccent -30
+KPX F egrave -30
+KPX F emacron -30
+KPX F eogonek -30
+KPX F o -30
+KPX F oacute -30
+KPX F ocircumflex -30
+KPX F odieresis -30
+KPX F ograve -30
+KPX F ohungarumlaut -30
+KPX F omacron -30
+KPX F oslash -30
+KPX F otilde -30
+KPX F period -150
+KPX F r -45
+KPX F racute -45
+KPX F rcaron -45
+KPX F rcommaaccent -45
+KPX J A -20
+KPX J Aacute -20
+KPX J Abreve -20
+KPX J Acircumflex -20
+KPX J Adieresis -20
+KPX J Agrave -20
+KPX J Amacron -20
+KPX J Aogonek -20
+KPX J Aring -20
+KPX J Atilde -20
+KPX J a -20
+KPX J aacute -20
+KPX J abreve -20
+KPX J acircumflex -20
+KPX J adieresis -20
+KPX J agrave -20
+KPX J amacron -20
+KPX J aogonek -20
+KPX J aring -20
+KPX J atilde -20
+KPX J comma -30
+KPX J period -30
+KPX J u -20
+KPX J uacute -20
+KPX J ucircumflex -20
+KPX J udieresis -20
+KPX J ugrave -20
+KPX J uhungarumlaut -20
+KPX J umacron -20
+KPX J uogonek -20
+KPX J uring -20
+KPX K O -50
+KPX K Oacute -50
+KPX K Ocircumflex -50
+KPX K Odieresis -50
+KPX K Ograve -50
+KPX K Ohungarumlaut -50
+KPX K Omacron -50
+KPX K Oslash -50
+KPX K Otilde -50
+KPX K e -40
+KPX K eacute -40
+KPX K ecaron -40
+KPX K ecircumflex -40
+KPX K edieresis -40
+KPX K edotaccent -40
+KPX K egrave -40
+KPX K emacron -40
+KPX K eogonek -40
+KPX K o -40
+KPX K oacute -40
+KPX K ocircumflex -40
+KPX K odieresis -40
+KPX K ograve -40
+KPX K ohungarumlaut -40
+KPX K omacron -40
+KPX K oslash -40
+KPX K otilde -40
+KPX K u -30
+KPX K uacute -30
+KPX K ucircumflex -30
+KPX K udieresis -30
+KPX K ugrave -30
+KPX K uhungarumlaut -30
+KPX K umacron -30
+KPX K uogonek -30
+KPX K uring -30
+KPX K y -50
+KPX K yacute -50
+KPX K ydieresis -50
+KPX Kcommaaccent O -50
+KPX Kcommaaccent Oacute -50
+KPX Kcommaaccent Ocircumflex -50
+KPX Kcommaaccent Odieresis -50
+KPX Kcommaaccent Ograve -50
+KPX Kcommaaccent Ohungarumlaut -50
+KPX Kcommaaccent Omacron -50
+KPX Kcommaaccent Oslash -50
+KPX Kcommaaccent Otilde -50
+KPX Kcommaaccent e -40
+KPX Kcommaaccent eacute -40
+KPX Kcommaaccent ecaron -40
+KPX Kcommaaccent ecircumflex -40
+KPX Kcommaaccent edieresis -40
+KPX Kcommaaccent edotaccent -40
+KPX Kcommaaccent egrave -40
+KPX Kcommaaccent emacron -40
+KPX Kcommaaccent eogonek -40
+KPX Kcommaaccent o -40
+KPX Kcommaaccent oacute -40
+KPX Kcommaaccent ocircumflex -40
+KPX Kcommaaccent odieresis -40
+KPX Kcommaaccent ograve -40
+KPX Kcommaaccent ohungarumlaut -40
+KPX Kcommaaccent omacron -40
+KPX Kcommaaccent oslash -40
+KPX Kcommaaccent otilde -40
+KPX Kcommaaccent u -30
+KPX Kcommaaccent uacute -30
+KPX Kcommaaccent ucircumflex -30
+KPX Kcommaaccent udieresis -30
+KPX Kcommaaccent ugrave -30
+KPX Kcommaaccent uhungarumlaut -30
+KPX Kcommaaccent umacron -30
+KPX Kcommaaccent uogonek -30
+KPX Kcommaaccent uring -30
+KPX Kcommaaccent y -50
+KPX Kcommaaccent yacute -50
+KPX Kcommaaccent ydieresis -50
+KPX L T -110
+KPX L Tcaron -110
+KPX L Tcommaaccent -110
+KPX L V -110
+KPX L W -70
+KPX L Y -140
+KPX L Yacute -140
+KPX L Ydieresis -140
+KPX L quotedblright -140
+KPX L quoteright -160
+KPX L y -30
+KPX L yacute -30
+KPX L ydieresis -30
+KPX Lacute T -110
+KPX Lacute Tcaron -110
+KPX Lacute Tcommaaccent -110
+KPX Lacute V -110
+KPX Lacute W -70
+KPX Lacute Y -140
+KPX Lacute Yacute -140
+KPX Lacute Ydieresis -140
+KPX Lacute quotedblright -140
+KPX Lacute quoteright -160
+KPX Lacute y -30
+KPX Lacute yacute -30
+KPX Lacute ydieresis -30
+KPX Lcaron T -110
+KPX Lcaron Tcaron -110
+KPX Lcaron Tcommaaccent -110
+KPX Lcaron V -110
+KPX Lcaron W -70
+KPX Lcaron Y -140
+KPX Lcaron Yacute -140
+KPX Lcaron Ydieresis -140
+KPX Lcaron quotedblright -140
+KPX Lcaron quoteright -160
+KPX Lcaron y -30
+KPX Lcaron yacute -30
+KPX Lcaron ydieresis -30
+KPX Lcommaaccent T -110
+KPX Lcommaaccent Tcaron -110
+KPX Lcommaaccent Tcommaaccent -110
+KPX Lcommaaccent V -110
+KPX Lcommaaccent W -70
+KPX Lcommaaccent Y -140
+KPX Lcommaaccent Yacute -140
+KPX Lcommaaccent Ydieresis -140
+KPX Lcommaaccent quotedblright -140
+KPX Lcommaaccent quoteright -160
+KPX Lcommaaccent y -30
+KPX Lcommaaccent yacute -30
+KPX Lcommaaccent ydieresis -30
+KPX Lslash T -110
+KPX Lslash Tcaron -110
+KPX Lslash Tcommaaccent -110
+KPX Lslash V -110
+KPX Lslash W -70
+KPX Lslash Y -140
+KPX Lslash Yacute -140
+KPX Lslash Ydieresis -140
+KPX Lslash quotedblright -140
+KPX Lslash quoteright -160
+KPX Lslash y -30
+KPX Lslash yacute -30
+KPX Lslash ydieresis -30
+KPX O A -20
+KPX O Aacute -20
+KPX O Abreve -20
+KPX O Acircumflex -20
+KPX O Adieresis -20
+KPX O Agrave -20
+KPX O Amacron -20
+KPX O Aogonek -20
+KPX O Aring -20
+KPX O Atilde -20
+KPX O T -40
+KPX O Tcaron -40
+KPX O Tcommaaccent -40
+KPX O V -50
+KPX O W -30
+KPX O X -60
+KPX O Y -70
+KPX O Yacute -70
+KPX O Ydieresis -70
+KPX O comma -40
+KPX O period -40
+KPX Oacute A -20
+KPX Oacute Aacute -20
+KPX Oacute Abreve -20
+KPX Oacute Acircumflex -20
+KPX Oacute Adieresis -20
+KPX Oacute Agrave -20
+KPX Oacute Amacron -20
+KPX Oacute Aogonek -20
+KPX Oacute Aring -20
+KPX Oacute Atilde -20
+KPX Oacute T -40
+KPX Oacute Tcaron -40
+KPX Oacute Tcommaaccent -40
+KPX Oacute V -50
+KPX Oacute W -30
+KPX Oacute X -60
+KPX Oacute Y -70
+KPX Oacute Yacute -70
+KPX Oacute Ydieresis -70
+KPX Oacute comma -40
+KPX Oacute period -40
+KPX Ocircumflex A -20
+KPX Ocircumflex Aacute -20
+KPX Ocircumflex Abreve -20
+KPX Ocircumflex Acircumflex -20
+KPX Ocircumflex Adieresis -20
+KPX Ocircumflex Agrave -20
+KPX Ocircumflex Amacron -20
+KPX Ocircumflex Aogonek -20
+KPX Ocircumflex Aring -20
+KPX Ocircumflex Atilde -20
+KPX Ocircumflex T -40
+KPX Ocircumflex Tcaron -40
+KPX Ocircumflex Tcommaaccent -40
+KPX Ocircumflex V -50
+KPX Ocircumflex W -30
+KPX Ocircumflex X -60
+KPX Ocircumflex Y -70
+KPX Ocircumflex Yacute -70
+KPX Ocircumflex Ydieresis -70
+KPX Ocircumflex comma -40
+KPX Ocircumflex period -40
+KPX Odieresis A -20
+KPX Odieresis Aacute -20
+KPX Odieresis Abreve -20
+KPX Odieresis Acircumflex -20
+KPX Odieresis Adieresis -20
+KPX Odieresis Agrave -20
+KPX Odieresis Amacron -20
+KPX Odieresis Aogonek -20
+KPX Odieresis Aring -20
+KPX Odieresis Atilde -20
+KPX Odieresis T -40
+KPX Odieresis Tcaron -40
+KPX Odieresis Tcommaaccent -40
+KPX Odieresis V -50
+KPX Odieresis W -30
+KPX Odieresis X -60
+KPX Odieresis Y -70
+KPX Odieresis Yacute -70
+KPX Odieresis Ydieresis -70
+KPX Odieresis comma -40
+KPX Odieresis period -40
+KPX Ograve A -20
+KPX Ograve Aacute -20
+KPX Ograve Abreve -20
+KPX Ograve Acircumflex -20
+KPX Ograve Adieresis -20
+KPX Ograve Agrave -20
+KPX Ograve Amacron -20
+KPX Ograve Aogonek -20
+KPX Ograve Aring -20
+KPX Ograve Atilde -20
+KPX Ograve T -40
+KPX Ograve Tcaron -40
+KPX Ograve Tcommaaccent -40
+KPX Ograve V -50
+KPX Ograve W -30
+KPX Ograve X -60
+KPX Ograve Y -70
+KPX Ograve Yacute -70
+KPX Ograve Ydieresis -70
+KPX Ograve comma -40
+KPX Ograve period -40
+KPX Ohungarumlaut A -20
+KPX Ohungarumlaut Aacute -20
+KPX Ohungarumlaut Abreve -20
+KPX Ohungarumlaut Acircumflex -20
+KPX Ohungarumlaut Adieresis -20
+KPX Ohungarumlaut Agrave -20
+KPX Ohungarumlaut Amacron -20
+KPX Ohungarumlaut Aogonek -20
+KPX Ohungarumlaut Aring -20
+KPX Ohungarumlaut Atilde -20
+KPX Ohungarumlaut T -40
+KPX Ohungarumlaut Tcaron -40
+KPX Ohungarumlaut Tcommaaccent -40
+KPX Ohungarumlaut V -50
+KPX Ohungarumlaut W -30
+KPX Ohungarumlaut X -60
+KPX Ohungarumlaut Y -70
+KPX Ohungarumlaut Yacute -70
+KPX Ohungarumlaut Ydieresis -70
+KPX Ohungarumlaut comma -40
+KPX Ohungarumlaut period -40
+KPX Omacron A -20
+KPX Omacron Aacute -20
+KPX Omacron Abreve -20
+KPX Omacron Acircumflex -20
+KPX Omacron Adieresis -20
+KPX Omacron Agrave -20
+KPX Omacron Amacron -20
+KPX Omacron Aogonek -20
+KPX Omacron Aring -20
+KPX Omacron Atilde -20
+KPX Omacron T -40
+KPX Omacron Tcaron -40
+KPX Omacron Tcommaaccent -40
+KPX Omacron V -50
+KPX Omacron W -30
+KPX Omacron X -60
+KPX Omacron Y -70
+KPX Omacron Yacute -70
+KPX Omacron Ydieresis -70
+KPX Omacron comma -40
+KPX Omacron period -40
+KPX Oslash A -20
+KPX Oslash Aacute -20
+KPX Oslash Abreve -20
+KPX Oslash Acircumflex -20
+KPX Oslash Adieresis -20
+KPX Oslash Agrave -20
+KPX Oslash Amacron -20
+KPX Oslash Aogonek -20
+KPX Oslash Aring -20
+KPX Oslash Atilde -20
+KPX Oslash T -40
+KPX Oslash Tcaron -40
+KPX Oslash Tcommaaccent -40
+KPX Oslash V -50
+KPX Oslash W -30
+KPX Oslash X -60
+KPX Oslash Y -70
+KPX Oslash Yacute -70
+KPX Oslash Ydieresis -70
+KPX Oslash comma -40
+KPX Oslash period -40
+KPX Otilde A -20
+KPX Otilde Aacute -20
+KPX Otilde Abreve -20
+KPX Otilde Acircumflex -20
+KPX Otilde Adieresis -20
+KPX Otilde Agrave -20
+KPX Otilde Amacron -20
+KPX Otilde Aogonek -20
+KPX Otilde Aring -20
+KPX Otilde Atilde -20
+KPX Otilde T -40
+KPX Otilde Tcaron -40
+KPX Otilde Tcommaaccent -40
+KPX Otilde V -50
+KPX Otilde W -30
+KPX Otilde X -60
+KPX Otilde Y -70
+KPX Otilde Yacute -70
+KPX Otilde Ydieresis -70
+KPX Otilde comma -40
+KPX Otilde period -40
+KPX P A -120
+KPX P Aacute -120
+KPX P Abreve -120
+KPX P Acircumflex -120
+KPX P Adieresis -120
+KPX P Agrave -120
+KPX P Amacron -120
+KPX P Aogonek -120
+KPX P Aring -120
+KPX P Atilde -120
+KPX P a -40
+KPX P aacute -40
+KPX P abreve -40
+KPX P acircumflex -40
+KPX P adieresis -40
+KPX P agrave -40
+KPX P amacron -40
+KPX P aogonek -40
+KPX P aring -40
+KPX P atilde -40
+KPX P comma -180
+KPX P e -50
+KPX P eacute -50
+KPX P ecaron -50
+KPX P ecircumflex -50
+KPX P edieresis -50
+KPX P edotaccent -50
+KPX P egrave -50
+KPX P emacron -50
+KPX P eogonek -50
+KPX P o -50
+KPX P oacute -50
+KPX P ocircumflex -50
+KPX P odieresis -50
+KPX P ograve -50
+KPX P ohungarumlaut -50
+KPX P omacron -50
+KPX P oslash -50
+KPX P otilde -50
+KPX P period -180
+KPX Q U -10
+KPX Q Uacute -10
+KPX Q Ucircumflex -10
+KPX Q Udieresis -10
+KPX Q Ugrave -10
+KPX Q Uhungarumlaut -10
+KPX Q Umacron -10
+KPX Q Uogonek -10
+KPX Q Uring -10
+KPX R O -20
+KPX R Oacute -20
+KPX R Ocircumflex -20
+KPX R Odieresis -20
+KPX R Ograve -20
+KPX R Ohungarumlaut -20
+KPX R Omacron -20
+KPX R Oslash -20
+KPX R Otilde -20
+KPX R T -30
+KPX R Tcaron -30
+KPX R Tcommaaccent -30
+KPX R U -40
+KPX R Uacute -40
+KPX R Ucircumflex -40
+KPX R Udieresis -40
+KPX R Ugrave -40
+KPX R Uhungarumlaut -40
+KPX R Umacron -40
+KPX R Uogonek -40
+KPX R Uring -40
+KPX R V -50
+KPX R W -30
+KPX R Y -50
+KPX R Yacute -50
+KPX R Ydieresis -50
+KPX Racute O -20
+KPX Racute Oacute -20
+KPX Racute Ocircumflex -20
+KPX Racute Odieresis -20
+KPX Racute Ograve -20
+KPX Racute Ohungarumlaut -20
+KPX Racute Omacron -20
+KPX Racute Oslash -20
+KPX Racute Otilde -20
+KPX Racute T -30
+KPX Racute Tcaron -30
+KPX Racute Tcommaaccent -30
+KPX Racute U -40
+KPX Racute Uacute -40
+KPX Racute Ucircumflex -40
+KPX Racute Udieresis -40
+KPX Racute Ugrave -40
+KPX Racute Uhungarumlaut -40
+KPX Racute Umacron -40
+KPX Racute Uogonek -40
+KPX Racute Uring -40
+KPX Racute V -50
+KPX Racute W -30
+KPX Racute Y -50
+KPX Racute Yacute -50
+KPX Racute Ydieresis -50
+KPX Rcaron O -20
+KPX Rcaron Oacute -20
+KPX Rcaron Ocircumflex -20
+KPX Rcaron Odieresis -20
+KPX Rcaron Ograve -20
+KPX Rcaron Ohungarumlaut -20
+KPX Rcaron Omacron -20
+KPX Rcaron Oslash -20
+KPX Rcaron Otilde -20
+KPX Rcaron T -30
+KPX Rcaron Tcaron -30
+KPX Rcaron Tcommaaccent -30
+KPX Rcaron U -40
+KPX Rcaron Uacute -40
+KPX Rcaron Ucircumflex -40
+KPX Rcaron Udieresis -40
+KPX Rcaron Ugrave -40
+KPX Rcaron Uhungarumlaut -40
+KPX Rcaron Umacron -40
+KPX Rcaron Uogonek -40
+KPX Rcaron Uring -40
+KPX Rcaron V -50
+KPX Rcaron W -30
+KPX Rcaron Y -50
+KPX Rcaron Yacute -50
+KPX Rcaron Ydieresis -50
+KPX Rcommaaccent O -20
+KPX Rcommaaccent Oacute -20
+KPX Rcommaaccent Ocircumflex -20
+KPX Rcommaaccent Odieresis -20
+KPX Rcommaaccent Ograve -20
+KPX Rcommaaccent Ohungarumlaut -20
+KPX Rcommaaccent Omacron -20
+KPX Rcommaaccent Oslash -20
+KPX Rcommaaccent Otilde -20
+KPX Rcommaaccent T -30
+KPX Rcommaaccent Tcaron -30
+KPX Rcommaaccent Tcommaaccent -30
+KPX Rcommaaccent U -40
+KPX Rcommaaccent Uacute -40
+KPX Rcommaaccent Ucircumflex -40
+KPX Rcommaaccent Udieresis -40
+KPX Rcommaaccent Ugrave -40
+KPX Rcommaaccent Uhungarumlaut -40
+KPX Rcommaaccent Umacron -40
+KPX Rcommaaccent Uogonek -40
+KPX Rcommaaccent Uring -40
+KPX Rcommaaccent V -50
+KPX Rcommaaccent W -30
+KPX Rcommaaccent Y -50
+KPX Rcommaaccent Yacute -50
+KPX Rcommaaccent Ydieresis -50
+KPX S comma -20
+KPX S period -20
+KPX Sacute comma -20
+KPX Sacute period -20
+KPX Scaron comma -20
+KPX Scaron period -20
+KPX Scedilla comma -20
+KPX Scedilla period -20
+KPX Scommaaccent comma -20
+KPX Scommaaccent period -20
+KPX T A -120
+KPX T Aacute -120
+KPX T Abreve -120
+KPX T Acircumflex -120
+KPX T Adieresis -120
+KPX T Agrave -120
+KPX T Amacron -120
+KPX T Aogonek -120
+KPX T Aring -120
+KPX T Atilde -120
+KPX T O -40
+KPX T Oacute -40
+KPX T Ocircumflex -40
+KPX T Odieresis -40
+KPX T Ograve -40
+KPX T Ohungarumlaut -40
+KPX T Omacron -40
+KPX T Oslash -40
+KPX T Otilde -40
+KPX T a -120
+KPX T aacute -120
+KPX T abreve -60
+KPX T acircumflex -120
+KPX T adieresis -120
+KPX T agrave -120
+KPX T amacron -60
+KPX T aogonek -120
+KPX T aring -120
+KPX T atilde -60
+KPX T colon -20
+KPX T comma -120
+KPX T e -120
+KPX T eacute -120
+KPX T ecaron -120
+KPX T ecircumflex -120
+KPX T edieresis -120
+KPX T edotaccent -120
+KPX T egrave -60
+KPX T emacron -60
+KPX T eogonek -120
+KPX T hyphen -140
+KPX T o -120
+KPX T oacute -120
+KPX T ocircumflex -120
+KPX T odieresis -120
+KPX T ograve -120
+KPX T ohungarumlaut -120
+KPX T omacron -60
+KPX T oslash -120
+KPX T otilde -60
+KPX T period -120
+KPX T r -120
+KPX T racute -120
+KPX T rcaron -120
+KPX T rcommaaccent -120
+KPX T semicolon -20
+KPX T u -120
+KPX T uacute -120
+KPX T ucircumflex -120
+KPX T udieresis -120
+KPX T ugrave -120
+KPX T uhungarumlaut -120
+KPX T umacron -60
+KPX T uogonek -120
+KPX T uring -120
+KPX T w -120
+KPX T y -120
+KPX T yacute -120
+KPX T ydieresis -60
+KPX Tcaron A -120
+KPX Tcaron Aacute -120
+KPX Tcaron Abreve -120
+KPX Tcaron Acircumflex -120
+KPX Tcaron Adieresis -120
+KPX Tcaron Agrave -120
+KPX Tcaron Amacron -120
+KPX Tcaron Aogonek -120
+KPX Tcaron Aring -120
+KPX Tcaron Atilde -120
+KPX Tcaron O -40
+KPX Tcaron Oacute -40
+KPX Tcaron Ocircumflex -40
+KPX Tcaron Odieresis -40
+KPX Tcaron Ograve -40
+KPX Tcaron Ohungarumlaut -40
+KPX Tcaron Omacron -40
+KPX Tcaron Oslash -40
+KPX Tcaron Otilde -40
+KPX Tcaron a -120
+KPX Tcaron aacute -120
+KPX Tcaron abreve -60
+KPX Tcaron acircumflex -120
+KPX Tcaron adieresis -120
+KPX Tcaron agrave -120
+KPX Tcaron amacron -60
+KPX Tcaron aogonek -120
+KPX Tcaron aring -120
+KPX Tcaron atilde -60
+KPX Tcaron colon -20
+KPX Tcaron comma -120
+KPX Tcaron e -120
+KPX Tcaron eacute -120
+KPX Tcaron ecaron -120
+KPX Tcaron ecircumflex -120
+KPX Tcaron edieresis -120
+KPX Tcaron edotaccent -120
+KPX Tcaron egrave -60
+KPX Tcaron emacron -60
+KPX Tcaron eogonek -120
+KPX Tcaron hyphen -140
+KPX Tcaron o -120
+KPX Tcaron oacute -120
+KPX Tcaron ocircumflex -120
+KPX Tcaron odieresis -120
+KPX Tcaron ograve -120
+KPX Tcaron ohungarumlaut -120
+KPX Tcaron omacron -60
+KPX Tcaron oslash -120
+KPX Tcaron otilde -60
+KPX Tcaron period -120
+KPX Tcaron r -120
+KPX Tcaron racute -120
+KPX Tcaron rcaron -120
+KPX Tcaron rcommaaccent -120
+KPX Tcaron semicolon -20
+KPX Tcaron u -120
+KPX Tcaron uacute -120
+KPX Tcaron ucircumflex -120
+KPX Tcaron udieresis -120
+KPX Tcaron ugrave -120
+KPX Tcaron uhungarumlaut -120
+KPX Tcaron umacron -60
+KPX Tcaron uogonek -120
+KPX Tcaron uring -120
+KPX Tcaron w -120
+KPX Tcaron y -120
+KPX Tcaron yacute -120
+KPX Tcaron ydieresis -60
+KPX Tcommaaccent A -120
+KPX Tcommaaccent Aacute -120
+KPX Tcommaaccent Abreve -120
+KPX Tcommaaccent Acircumflex -120
+KPX Tcommaaccent Adieresis -120
+KPX Tcommaaccent Agrave -120
+KPX Tcommaaccent Amacron -120
+KPX Tcommaaccent Aogonek -120
+KPX Tcommaaccent Aring -120
+KPX Tcommaaccent Atilde -120
+KPX Tcommaaccent O -40
+KPX Tcommaaccent Oacute -40
+KPX Tcommaaccent Ocircumflex -40
+KPX Tcommaaccent Odieresis -40
+KPX Tcommaaccent Ograve -40
+KPX Tcommaaccent Ohungarumlaut -40
+KPX Tcommaaccent Omacron -40
+KPX Tcommaaccent Oslash -40
+KPX Tcommaaccent Otilde -40
+KPX Tcommaaccent a -120
+KPX Tcommaaccent aacute -120
+KPX Tcommaaccent abreve -60
+KPX Tcommaaccent acircumflex -120
+KPX Tcommaaccent adieresis -120
+KPX Tcommaaccent agrave -120
+KPX Tcommaaccent amacron -60
+KPX Tcommaaccent aogonek -120
+KPX Tcommaaccent aring -120
+KPX Tcommaaccent atilde -60
+KPX Tcommaaccent colon -20
+KPX Tcommaaccent comma -120
+KPX Tcommaaccent e -120
+KPX Tcommaaccent eacute -120
+KPX Tcommaaccent ecaron -120
+KPX Tcommaaccent ecircumflex -120
+KPX Tcommaaccent edieresis -120
+KPX Tcommaaccent edotaccent -120
+KPX Tcommaaccent egrave -60
+KPX Tcommaaccent emacron -60
+KPX Tcommaaccent eogonek -120
+KPX Tcommaaccent hyphen -140
+KPX Tcommaaccent o -120
+KPX Tcommaaccent oacute -120
+KPX Tcommaaccent ocircumflex -120
+KPX Tcommaaccent odieresis -120
+KPX Tcommaaccent ograve -120
+KPX Tcommaaccent ohungarumlaut -120
+KPX Tcommaaccent omacron -60
+KPX Tcommaaccent oslash -120
+KPX Tcommaaccent otilde -60
+KPX Tcommaaccent period -120
+KPX Tcommaaccent r -120
+KPX Tcommaaccent racute -120
+KPX Tcommaaccent rcaron -120
+KPX Tcommaaccent rcommaaccent -120
+KPX Tcommaaccent semicolon -20
+KPX Tcommaaccent u -120
+KPX Tcommaaccent uacute -120
+KPX Tcommaaccent ucircumflex -120
+KPX Tcommaaccent udieresis -120
+KPX Tcommaaccent ugrave -120
+KPX Tcommaaccent uhungarumlaut -120
+KPX Tcommaaccent umacron -60
+KPX Tcommaaccent uogonek -120
+KPX Tcommaaccent uring -120
+KPX Tcommaaccent w -120
+KPX Tcommaaccent y -120
+KPX Tcommaaccent yacute -120
+KPX Tcommaaccent ydieresis -60
+KPX U A -40
+KPX U Aacute -40
+KPX U Abreve -40
+KPX U Acircumflex -40
+KPX U Adieresis -40
+KPX U Agrave -40
+KPX U Amacron -40
+KPX U Aogonek -40
+KPX U Aring -40
+KPX U Atilde -40
+KPX U comma -40
+KPX U period -40
+KPX Uacute A -40
+KPX Uacute Aacute -40
+KPX Uacute Abreve -40
+KPX Uacute Acircumflex -40
+KPX Uacute Adieresis -40
+KPX Uacute Agrave -40
+KPX Uacute Amacron -40
+KPX Uacute Aogonek -40
+KPX Uacute Aring -40
+KPX Uacute Atilde -40
+KPX Uacute comma -40
+KPX Uacute period -40
+KPX Ucircumflex A -40
+KPX Ucircumflex Aacute -40
+KPX Ucircumflex Abreve -40
+KPX Ucircumflex Acircumflex -40
+KPX Ucircumflex Adieresis -40
+KPX Ucircumflex Agrave -40
+KPX Ucircumflex Amacron -40
+KPX Ucircumflex Aogonek -40
+KPX Ucircumflex Aring -40
+KPX Ucircumflex Atilde -40
+KPX Ucircumflex comma -40
+KPX Ucircumflex period -40
+KPX Udieresis A -40
+KPX Udieresis Aacute -40
+KPX Udieresis Abreve -40
+KPX Udieresis Acircumflex -40
+KPX Udieresis Adieresis -40
+KPX Udieresis Agrave -40
+KPX Udieresis Amacron -40
+KPX Udieresis Aogonek -40
+KPX Udieresis Aring -40
+KPX Udieresis Atilde -40
+KPX Udieresis comma -40
+KPX Udieresis period -40
+KPX Ugrave A -40
+KPX Ugrave Aacute -40
+KPX Ugrave Abreve -40
+KPX Ugrave Acircumflex -40
+KPX Ugrave Adieresis -40
+KPX Ugrave Agrave -40
+KPX Ugrave Amacron -40
+KPX Ugrave Aogonek -40
+KPX Ugrave Aring -40
+KPX Ugrave Atilde -40
+KPX Ugrave comma -40
+KPX Ugrave period -40
+KPX Uhungarumlaut A -40
+KPX Uhungarumlaut Aacute -40
+KPX Uhungarumlaut Abreve -40
+KPX Uhungarumlaut Acircumflex -40
+KPX Uhungarumlaut Adieresis -40
+KPX Uhungarumlaut Agrave -40
+KPX Uhungarumlaut Amacron -40
+KPX Uhungarumlaut Aogonek -40
+KPX Uhungarumlaut Aring -40
+KPX Uhungarumlaut Atilde -40
+KPX Uhungarumlaut comma -40
+KPX Uhungarumlaut period -40
+KPX Umacron A -40
+KPX Umacron Aacute -40
+KPX Umacron Abreve -40
+KPX Umacron Acircumflex -40
+KPX Umacron Adieresis -40
+KPX Umacron Agrave -40
+KPX Umacron Amacron -40
+KPX Umacron Aogonek -40
+KPX Umacron Aring -40
+KPX Umacron Atilde -40
+KPX Umacron comma -40
+KPX Umacron period -40
+KPX Uogonek A -40
+KPX Uogonek Aacute -40
+KPX Uogonek Abreve -40
+KPX Uogonek Acircumflex -40
+KPX Uogonek Adieresis -40
+KPX Uogonek Agrave -40
+KPX Uogonek Amacron -40
+KPX Uogonek Aogonek -40
+KPX Uogonek Aring -40
+KPX Uogonek Atilde -40
+KPX Uogonek comma -40
+KPX Uogonek period -40
+KPX Uring A -40
+KPX Uring Aacute -40
+KPX Uring Abreve -40
+KPX Uring Acircumflex -40
+KPX Uring Adieresis -40
+KPX Uring Agrave -40
+KPX Uring Amacron -40
+KPX Uring Aogonek -40
+KPX Uring Aring -40
+KPX Uring Atilde -40
+KPX Uring comma -40
+KPX Uring period -40
+KPX V A -80
+KPX V Aacute -80
+KPX V Abreve -80
+KPX V Acircumflex -80
+KPX V Adieresis -80
+KPX V Agrave -80
+KPX V Amacron -80
+KPX V Aogonek -80
+KPX V Aring -80
+KPX V Atilde -80
+KPX V G -40
+KPX V Gbreve -40
+KPX V Gcommaaccent -40
+KPX V O -40
+KPX V Oacute -40
+KPX V Ocircumflex -40
+KPX V Odieresis -40
+KPX V Ograve -40
+KPX V Ohungarumlaut -40
+KPX V Omacron -40
+KPX V Oslash -40
+KPX V Otilde -40
+KPX V a -70
+KPX V aacute -70
+KPX V abreve -70
+KPX V acircumflex -70
+KPX V adieresis -70
+KPX V agrave -70
+KPX V amacron -70
+KPX V aogonek -70
+KPX V aring -70
+KPX V atilde -70
+KPX V colon -40
+KPX V comma -125
+KPX V e -80
+KPX V eacute -80
+KPX V ecaron -80
+KPX V ecircumflex -80
+KPX V edieresis -80
+KPX V edotaccent -80
+KPX V egrave -80
+KPX V emacron -80
+KPX V eogonek -80
+KPX V hyphen -80
+KPX V o -80
+KPX V oacute -80
+KPX V ocircumflex -80
+KPX V odieresis -80
+KPX V ograve -80
+KPX V ohungarumlaut -80
+KPX V omacron -80
+KPX V oslash -80
+KPX V otilde -80
+KPX V period -125
+KPX V semicolon -40
+KPX V u -70
+KPX V uacute -70
+KPX V ucircumflex -70
+KPX V udieresis -70
+KPX V ugrave -70
+KPX V uhungarumlaut -70
+KPX V umacron -70
+KPX V uogonek -70
+KPX V uring -70
+KPX W A -50
+KPX W Aacute -50
+KPX W Abreve -50
+KPX W Acircumflex -50
+KPX W Adieresis -50
+KPX W Agrave -50
+KPX W Amacron -50
+KPX W Aogonek -50
+KPX W Aring -50
+KPX W Atilde -50
+KPX W O -20
+KPX W Oacute -20
+KPX W Ocircumflex -20
+KPX W Odieresis -20
+KPX W Ograve -20
+KPX W Ohungarumlaut -20
+KPX W Omacron -20
+KPX W Oslash -20
+KPX W Otilde -20
+KPX W a -40
+KPX W aacute -40
+KPX W abreve -40
+KPX W acircumflex -40
+KPX W adieresis -40
+KPX W agrave -40
+KPX W amacron -40
+KPX W aogonek -40
+KPX W aring -40
+KPX W atilde -40
+KPX W comma -80
+KPX W e -30
+KPX W eacute -30
+KPX W ecaron -30
+KPX W ecircumflex -30
+KPX W edieresis -30
+KPX W edotaccent -30
+KPX W egrave -30
+KPX W emacron -30
+KPX W eogonek -30
+KPX W hyphen -40
+KPX W o -30
+KPX W oacute -30
+KPX W ocircumflex -30
+KPX W odieresis -30
+KPX W ograve -30
+KPX W ohungarumlaut -30
+KPX W omacron -30
+KPX W oslash -30
+KPX W otilde -30
+KPX W period -80
+KPX W u -30
+KPX W uacute -30
+KPX W ucircumflex -30
+KPX W udieresis -30
+KPX W ugrave -30
+KPX W uhungarumlaut -30
+KPX W umacron -30
+KPX W uogonek -30
+KPX W uring -30
+KPX W y -20
+KPX W yacute -20
+KPX W ydieresis -20
+KPX Y A -110
+KPX Y Aacute -110
+KPX Y Abreve -110
+KPX Y Acircumflex -110
+KPX Y Adieresis -110
+KPX Y Agrave -110
+KPX Y Amacron -110
+KPX Y Aogonek -110
+KPX Y Aring -110
+KPX Y Atilde -110
+KPX Y O -85
+KPX Y Oacute -85
+KPX Y Ocircumflex -85
+KPX Y Odieresis -85
+KPX Y Ograve -85
+KPX Y Ohungarumlaut -85
+KPX Y Omacron -85
+KPX Y Oslash -85
+KPX Y Otilde -85
+KPX Y a -140
+KPX Y aacute -140
+KPX Y abreve -70
+KPX Y acircumflex -140
+KPX Y adieresis -140
+KPX Y agrave -140
+KPX Y amacron -70
+KPX Y aogonek -140
+KPX Y aring -140
+KPX Y atilde -140
+KPX Y colon -60
+KPX Y comma -140
+KPX Y e -140
+KPX Y eacute -140
+KPX Y ecaron -140
+KPX Y ecircumflex -140
+KPX Y edieresis -140
+KPX Y edotaccent -140
+KPX Y egrave -140
+KPX Y emacron -70
+KPX Y eogonek -140
+KPX Y hyphen -140
+KPX Y i -20
+KPX Y iacute -20
+KPX Y iogonek -20
+KPX Y o -140
+KPX Y oacute -140
+KPX Y ocircumflex -140
+KPX Y odieresis -140
+KPX Y ograve -140
+KPX Y ohungarumlaut -140
+KPX Y omacron -140
+KPX Y oslash -140
+KPX Y otilde -140
+KPX Y period -140
+KPX Y semicolon -60
+KPX Y u -110
+KPX Y uacute -110
+KPX Y ucircumflex -110
+KPX Y udieresis -110
+KPX Y ugrave -110
+KPX Y uhungarumlaut -110
+KPX Y umacron -110
+KPX Y uogonek -110
+KPX Y uring -110
+KPX Yacute A -110
+KPX Yacute Aacute -110
+KPX Yacute Abreve -110
+KPX Yacute Acircumflex -110
+KPX Yacute Adieresis -110
+KPX Yacute Agrave -110
+KPX Yacute Amacron -110
+KPX Yacute Aogonek -110
+KPX Yacute Aring -110
+KPX Yacute Atilde -110
+KPX Yacute O -85
+KPX Yacute Oacute -85
+KPX Yacute Ocircumflex -85
+KPX Yacute Odieresis -85
+KPX Yacute Ograve -85
+KPX Yacute Ohungarumlaut -85
+KPX Yacute Omacron -85
+KPX Yacute Oslash -85
+KPX Yacute Otilde -85
+KPX Yacute a -140
+KPX Yacute aacute -140
+KPX Yacute abreve -70
+KPX Yacute acircumflex -140
+KPX Yacute adieresis -140
+KPX Yacute agrave -140
+KPX Yacute amacron -70
+KPX Yacute aogonek -140
+KPX Yacute aring -140
+KPX Yacute atilde -70
+KPX Yacute colon -60
+KPX Yacute comma -140
+KPX Yacute e -140
+KPX Yacute eacute -140
+KPX Yacute ecaron -140
+KPX Yacute ecircumflex -140
+KPX Yacute edieresis -140
+KPX Yacute edotaccent -140
+KPX Yacute egrave -140
+KPX Yacute emacron -70
+KPX Yacute eogonek -140
+KPX Yacute hyphen -140
+KPX Yacute i -20
+KPX Yacute iacute -20
+KPX Yacute iogonek -20
+KPX Yacute o -140
+KPX Yacute oacute -140
+KPX Yacute ocircumflex -140
+KPX Yacute odieresis -140
+KPX Yacute ograve -140
+KPX Yacute ohungarumlaut -140
+KPX Yacute omacron -70
+KPX Yacute oslash -140
+KPX Yacute otilde -140
+KPX Yacute period -140
+KPX Yacute semicolon -60
+KPX Yacute u -110
+KPX Yacute uacute -110
+KPX Yacute ucircumflex -110
+KPX Yacute udieresis -110
+KPX Yacute ugrave -110
+KPX Yacute uhungarumlaut -110
+KPX Yacute umacron -110
+KPX Yacute uogonek -110
+KPX Yacute uring -110
+KPX Ydieresis A -110
+KPX Ydieresis Aacute -110
+KPX Ydieresis Abreve -110
+KPX Ydieresis Acircumflex -110
+KPX Ydieresis Adieresis -110
+KPX Ydieresis Agrave -110
+KPX Ydieresis Amacron -110
+KPX Ydieresis Aogonek -110
+KPX Ydieresis Aring -110
+KPX Ydieresis Atilde -110
+KPX Ydieresis O -85
+KPX Ydieresis Oacute -85
+KPX Ydieresis Ocircumflex -85
+KPX Ydieresis Odieresis -85
+KPX Ydieresis Ograve -85
+KPX Ydieresis Ohungarumlaut -85
+KPX Ydieresis Omacron -85
+KPX Ydieresis Oslash -85
+KPX Ydieresis Otilde -85
+KPX Ydieresis a -140
+KPX Ydieresis aacute -140
+KPX Ydieresis abreve -70
+KPX Ydieresis acircumflex -140
+KPX Ydieresis adieresis -140
+KPX Ydieresis agrave -140
+KPX Ydieresis amacron -70
+KPX Ydieresis aogonek -140
+KPX Ydieresis aring -140
+KPX Ydieresis atilde -70
+KPX Ydieresis colon -60
+KPX Ydieresis comma -140
+KPX Ydieresis e -140
+KPX Ydieresis eacute -140
+KPX Ydieresis ecaron -140
+KPX Ydieresis ecircumflex -140
+KPX Ydieresis edieresis -140
+KPX Ydieresis edotaccent -140
+KPX Ydieresis egrave -140
+KPX Ydieresis emacron -70
+KPX Ydieresis eogonek -140
+KPX Ydieresis hyphen -140
+KPX Ydieresis i -20
+KPX Ydieresis iacute -20
+KPX Ydieresis iogonek -20
+KPX Ydieresis o -140
+KPX Ydieresis oacute -140
+KPX Ydieresis ocircumflex -140
+KPX Ydieresis odieresis -140
+KPX Ydieresis ograve -140
+KPX Ydieresis ohungarumlaut -140
+KPX Ydieresis omacron -140
+KPX Ydieresis oslash -140
+KPX Ydieresis otilde -140
+KPX Ydieresis period -140
+KPX Ydieresis semicolon -60
+KPX Ydieresis u -110
+KPX Ydieresis uacute -110
+KPX Ydieresis ucircumflex -110
+KPX Ydieresis udieresis -110
+KPX Ydieresis ugrave -110
+KPX Ydieresis uhungarumlaut -110
+KPX Ydieresis umacron -110
+KPX Ydieresis uogonek -110
+KPX Ydieresis uring -110
+KPX a v -20
+KPX a w -20
+KPX a y -30
+KPX a yacute -30
+KPX a ydieresis -30
+KPX aacute v -20
+KPX aacute w -20
+KPX aacute y -30
+KPX aacute yacute -30
+KPX aacute ydieresis -30
+KPX abreve v -20
+KPX abreve w -20
+KPX abreve y -30
+KPX abreve yacute -30
+KPX abreve ydieresis -30
+KPX acircumflex v -20
+KPX acircumflex w -20
+KPX acircumflex y -30
+KPX acircumflex yacute -30
+KPX acircumflex ydieresis -30
+KPX adieresis v -20
+KPX adieresis w -20
+KPX adieresis y -30
+KPX adieresis yacute -30
+KPX adieresis ydieresis -30
+KPX agrave v -20
+KPX agrave w -20
+KPX agrave y -30
+KPX agrave yacute -30
+KPX agrave ydieresis -30
+KPX amacron v -20
+KPX amacron w -20
+KPX amacron y -30
+KPX amacron yacute -30
+KPX amacron ydieresis -30
+KPX aogonek v -20
+KPX aogonek w -20
+KPX aogonek y -30
+KPX aogonek yacute -30
+KPX aogonek ydieresis -30
+KPX aring v -20
+KPX aring w -20
+KPX aring y -30
+KPX aring yacute -30
+KPX aring ydieresis -30
+KPX atilde v -20
+KPX atilde w -20
+KPX atilde y -30
+KPX atilde yacute -30
+KPX atilde ydieresis -30
+KPX b b -10
+KPX b comma -40
+KPX b l -20
+KPX b lacute -20
+KPX b lcommaaccent -20
+KPX b lslash -20
+KPX b period -40
+KPX b u -20
+KPX b uacute -20
+KPX b ucircumflex -20
+KPX b udieresis -20
+KPX b ugrave -20
+KPX b uhungarumlaut -20
+KPX b umacron -20
+KPX b uogonek -20
+KPX b uring -20
+KPX b v -20
+KPX b y -20
+KPX b yacute -20
+KPX b ydieresis -20
+KPX c comma -15
+KPX c k -20
+KPX c kcommaaccent -20
+KPX cacute comma -15
+KPX cacute k -20
+KPX cacute kcommaaccent -20
+KPX ccaron comma -15
+KPX ccaron k -20
+KPX ccaron kcommaaccent -20
+KPX ccedilla comma -15
+KPX ccedilla k -20
+KPX ccedilla kcommaaccent -20
+KPX colon space -50
+KPX comma quotedblright -100
+KPX comma quoteright -100
+KPX e comma -15
+KPX e period -15
+KPX e v -30
+KPX e w -20
+KPX e x -30
+KPX e y -20
+KPX e yacute -20
+KPX e ydieresis -20
+KPX eacute comma -15
+KPX eacute period -15
+KPX eacute v -30
+KPX eacute w -20
+KPX eacute x -30
+KPX eacute y -20
+KPX eacute yacute -20
+KPX eacute ydieresis -20
+KPX ecaron comma -15
+KPX ecaron period -15
+KPX ecaron v -30
+KPX ecaron w -20
+KPX ecaron x -30
+KPX ecaron y -20
+KPX ecaron yacute -20
+KPX ecaron ydieresis -20
+KPX ecircumflex comma -15
+KPX ecircumflex period -15
+KPX ecircumflex v -30
+KPX ecircumflex w -20
+KPX ecircumflex x -30
+KPX ecircumflex y -20
+KPX ecircumflex yacute -20
+KPX ecircumflex ydieresis -20
+KPX edieresis comma -15
+KPX edieresis period -15
+KPX edieresis v -30
+KPX edieresis w -20
+KPX edieresis x -30
+KPX edieresis y -20
+KPX edieresis yacute -20
+KPX edieresis ydieresis -20
+KPX edotaccent comma -15
+KPX edotaccent period -15
+KPX edotaccent v -30
+KPX edotaccent w -20
+KPX edotaccent x -30
+KPX edotaccent y -20
+KPX edotaccent yacute -20
+KPX edotaccent ydieresis -20
+KPX egrave comma -15
+KPX egrave period -15
+KPX egrave v -30
+KPX egrave w -20
+KPX egrave x -30
+KPX egrave y -20
+KPX egrave yacute -20
+KPX egrave ydieresis -20
+KPX emacron comma -15
+KPX emacron period -15
+KPX emacron v -30
+KPX emacron w -20
+KPX emacron x -30
+KPX emacron y -20
+KPX emacron yacute -20
+KPX emacron ydieresis -20
+KPX eogonek comma -15
+KPX eogonek period -15
+KPX eogonek v -30
+KPX eogonek w -20
+KPX eogonek x -30
+KPX eogonek y -20
+KPX eogonek yacute -20
+KPX eogonek ydieresis -20
+KPX f a -30
+KPX f aacute -30
+KPX f abreve -30
+KPX f acircumflex -30
+KPX f adieresis -30
+KPX f agrave -30
+KPX f amacron -30
+KPX f aogonek -30
+KPX f aring -30
+KPX f atilde -30
+KPX f comma -30
+KPX f dotlessi -28
+KPX f e -30
+KPX f eacute -30
+KPX f ecaron -30
+KPX f ecircumflex -30
+KPX f edieresis -30
+KPX f edotaccent -30
+KPX f egrave -30
+KPX f emacron -30
+KPX f eogonek -30
+KPX f o -30
+KPX f oacute -30
+KPX f ocircumflex -30
+KPX f odieresis -30
+KPX f ograve -30
+KPX f ohungarumlaut -30
+KPX f omacron -30
+KPX f oslash -30
+KPX f otilde -30
+KPX f period -30
+KPX f quotedblright 60
+KPX f quoteright 50
+KPX g r -10
+KPX g racute -10
+KPX g rcaron -10
+KPX g rcommaaccent -10
+KPX gbreve r -10
+KPX gbreve racute -10
+KPX gbreve rcaron -10
+KPX gbreve rcommaaccent -10
+KPX gcommaaccent r -10
+KPX gcommaaccent racute -10
+KPX gcommaaccent rcaron -10
+KPX gcommaaccent rcommaaccent -10
+KPX h y -30
+KPX h yacute -30
+KPX h ydieresis -30
+KPX k e -20
+KPX k eacute -20
+KPX k ecaron -20
+KPX k ecircumflex -20
+KPX k edieresis -20
+KPX k edotaccent -20
+KPX k egrave -20
+KPX k emacron -20
+KPX k eogonek -20
+KPX k o -20
+KPX k oacute -20
+KPX k ocircumflex -20
+KPX k odieresis -20
+KPX k ograve -20
+KPX k ohungarumlaut -20
+KPX k omacron -20
+KPX k oslash -20
+KPX k otilde -20
+KPX kcommaaccent e -20
+KPX kcommaaccent eacute -20
+KPX kcommaaccent ecaron -20
+KPX kcommaaccent ecircumflex -20
+KPX kcommaaccent edieresis -20
+KPX kcommaaccent edotaccent -20
+KPX kcommaaccent egrave -20
+KPX kcommaaccent emacron -20
+KPX kcommaaccent eogonek -20
+KPX kcommaaccent o -20
+KPX kcommaaccent oacute -20
+KPX kcommaaccent ocircumflex -20
+KPX kcommaaccent odieresis -20
+KPX kcommaaccent ograve -20
+KPX kcommaaccent ohungarumlaut -20
+KPX kcommaaccent omacron -20
+KPX kcommaaccent oslash -20
+KPX kcommaaccent otilde -20
+KPX m u -10
+KPX m uacute -10
+KPX m ucircumflex -10
+KPX m udieresis -10
+KPX m ugrave -10
+KPX m uhungarumlaut -10
+KPX m umacron -10
+KPX m uogonek -10
+KPX m uring -10
+KPX m y -15
+KPX m yacute -15
+KPX m ydieresis -15
+KPX n u -10
+KPX n uacute -10
+KPX n ucircumflex -10
+KPX n udieresis -10
+KPX n ugrave -10
+KPX n uhungarumlaut -10
+KPX n umacron -10
+KPX n uogonek -10
+KPX n uring -10
+KPX n v -20
+KPX n y -15
+KPX n yacute -15
+KPX n ydieresis -15
+KPX nacute u -10
+KPX nacute uacute -10
+KPX nacute ucircumflex -10
+KPX nacute udieresis -10
+KPX nacute ugrave -10
+KPX nacute uhungarumlaut -10
+KPX nacute umacron -10
+KPX nacute uogonek -10
+KPX nacute uring -10
+KPX nacute v -20
+KPX nacute y -15
+KPX nacute yacute -15
+KPX nacute ydieresis -15
+KPX ncaron u -10
+KPX ncaron uacute -10
+KPX ncaron ucircumflex -10
+KPX ncaron udieresis -10
+KPX ncaron ugrave -10
+KPX ncaron uhungarumlaut -10
+KPX ncaron umacron -10
+KPX ncaron uogonek -10
+KPX ncaron uring -10
+KPX ncaron v -20
+KPX ncaron y -15
+KPX ncaron yacute -15
+KPX ncaron ydieresis -15
+KPX ncommaaccent u -10
+KPX ncommaaccent uacute -10
+KPX ncommaaccent ucircumflex -10
+KPX ncommaaccent udieresis -10
+KPX ncommaaccent ugrave -10
+KPX ncommaaccent uhungarumlaut -10
+KPX ncommaaccent umacron -10
+KPX ncommaaccent uogonek -10
+KPX ncommaaccent uring -10
+KPX ncommaaccent v -20
+KPX ncommaaccent y -15
+KPX ncommaaccent yacute -15
+KPX ncommaaccent ydieresis -15
+KPX ntilde u -10
+KPX ntilde uacute -10
+KPX ntilde ucircumflex -10
+KPX ntilde udieresis -10
+KPX ntilde ugrave -10
+KPX ntilde uhungarumlaut -10
+KPX ntilde umacron -10
+KPX ntilde uogonek -10
+KPX ntilde uring -10
+KPX ntilde v -20
+KPX ntilde y -15
+KPX ntilde yacute -15
+KPX ntilde ydieresis -15
+KPX o comma -40
+KPX o period -40
+KPX o v -15
+KPX o w -15
+KPX o x -30
+KPX o y -30
+KPX o yacute -30
+KPX o ydieresis -30
+KPX oacute comma -40
+KPX oacute period -40
+KPX oacute v -15
+KPX oacute w -15
+KPX oacute x -30
+KPX oacute y -30
+KPX oacute yacute -30
+KPX oacute ydieresis -30
+KPX ocircumflex comma -40
+KPX ocircumflex period -40
+KPX ocircumflex v -15
+KPX ocircumflex w -15
+KPX ocircumflex x -30
+KPX ocircumflex y -30
+KPX ocircumflex yacute -30
+KPX ocircumflex ydieresis -30
+KPX odieresis comma -40
+KPX odieresis period -40
+KPX odieresis v -15
+KPX odieresis w -15
+KPX odieresis x -30
+KPX odieresis y -30
+KPX odieresis yacute -30
+KPX odieresis ydieresis -30
+KPX ograve comma -40
+KPX ograve period -40
+KPX ograve v -15
+KPX ograve w -15
+KPX ograve x -30
+KPX ograve y -30
+KPX ograve yacute -30
+KPX ograve ydieresis -30
+KPX ohungarumlaut comma -40
+KPX ohungarumlaut period -40
+KPX ohungarumlaut v -15
+KPX ohungarumlaut w -15
+KPX ohungarumlaut x -30
+KPX ohungarumlaut y -30
+KPX ohungarumlaut yacute -30
+KPX ohungarumlaut ydieresis -30
+KPX omacron comma -40
+KPX omacron period -40
+KPX omacron v -15
+KPX omacron w -15
+KPX omacron x -30
+KPX omacron y -30
+KPX omacron yacute -30
+KPX omacron ydieresis -30
+KPX oslash a -55
+KPX oslash aacute -55
+KPX oslash abreve -55
+KPX oslash acircumflex -55
+KPX oslash adieresis -55
+KPX oslash agrave -55
+KPX oslash amacron -55
+KPX oslash aogonek -55
+KPX oslash aring -55
+KPX oslash atilde -55
+KPX oslash b -55
+KPX oslash c -55
+KPX oslash cacute -55
+KPX oslash ccaron -55
+KPX oslash ccedilla -55
+KPX oslash comma -95
+KPX oslash d -55
+KPX oslash dcroat -55
+KPX oslash e -55
+KPX oslash eacute -55
+KPX oslash ecaron -55
+KPX oslash ecircumflex -55
+KPX oslash edieresis -55
+KPX oslash edotaccent -55
+KPX oslash egrave -55
+KPX oslash emacron -55
+KPX oslash eogonek -55
+KPX oslash f -55
+KPX oslash g -55
+KPX oslash gbreve -55
+KPX oslash gcommaaccent -55
+KPX oslash h -55
+KPX oslash i -55
+KPX oslash iacute -55
+KPX oslash icircumflex -55
+KPX oslash idieresis -55
+KPX oslash igrave -55
+KPX oslash imacron -55
+KPX oslash iogonek -55
+KPX oslash j -55
+KPX oslash k -55
+KPX oslash kcommaaccent -55
+KPX oslash l -55
+KPX oslash lacute -55
+KPX oslash lcommaaccent -55
+KPX oslash lslash -55
+KPX oslash m -55
+KPX oslash n -55
+KPX oslash nacute -55
+KPX oslash ncaron -55
+KPX oslash ncommaaccent -55
+KPX oslash ntilde -55
+KPX oslash o -55
+KPX oslash oacute -55
+KPX oslash ocircumflex -55
+KPX oslash odieresis -55
+KPX oslash ograve -55
+KPX oslash ohungarumlaut -55
+KPX oslash omacron -55
+KPX oslash oslash -55
+KPX oslash otilde -55
+KPX oslash p -55
+KPX oslash period -95
+KPX oslash q -55
+KPX oslash r -55
+KPX oslash racute -55
+KPX oslash rcaron -55
+KPX oslash rcommaaccent -55
+KPX oslash s -55
+KPX oslash sacute -55
+KPX oslash scaron -55
+KPX oslash scedilla -55
+KPX oslash scommaaccent -55
+KPX oslash t -55
+KPX oslash tcommaaccent -55
+KPX oslash u -55
+KPX oslash uacute -55
+KPX oslash ucircumflex -55
+KPX oslash udieresis -55
+KPX oslash ugrave -55
+KPX oslash uhungarumlaut -55
+KPX oslash umacron -55
+KPX oslash uogonek -55
+KPX oslash uring -55
+KPX oslash v -70
+KPX oslash w -70
+KPX oslash x -85
+KPX oslash y -70
+KPX oslash yacute -70
+KPX oslash ydieresis -70
+KPX oslash z -55
+KPX oslash zacute -55
+KPX oslash zcaron -55
+KPX oslash zdotaccent -55
+KPX otilde comma -40
+KPX otilde period -40
+KPX otilde v -15
+KPX otilde w -15
+KPX otilde x -30
+KPX otilde y -30
+KPX otilde yacute -30
+KPX otilde ydieresis -30
+KPX p comma -35
+KPX p period -35
+KPX p y -30
+KPX p yacute -30
+KPX p ydieresis -30
+KPX period quotedblright -100
+KPX period quoteright -100
+KPX period space -60
+KPX quotedblright space -40
+KPX quoteleft quoteleft -57
+KPX quoteright d -50
+KPX quoteright dcroat -50
+KPX quoteright quoteright -57
+KPX quoteright r -50
+KPX quoteright racute -50
+KPX quoteright rcaron -50
+KPX quoteright rcommaaccent -50
+KPX quoteright s -50
+KPX quoteright sacute -50
+KPX quoteright scaron -50
+KPX quoteright scedilla -50
+KPX quoteright scommaaccent -50
+KPX quoteright space -70
+KPX r a -10
+KPX r aacute -10
+KPX r abreve -10
+KPX r acircumflex -10
+KPX r adieresis -10
+KPX r agrave -10
+KPX r amacron -10
+KPX r aogonek -10
+KPX r aring -10
+KPX r atilde -10
+KPX r colon 30
+KPX r comma -50
+KPX r i 15
+KPX r iacute 15
+KPX r icircumflex 15
+KPX r idieresis 15
+KPX r igrave 15
+KPX r imacron 15
+KPX r iogonek 15
+KPX r k 15
+KPX r kcommaaccent 15
+KPX r l 15
+KPX r lacute 15
+KPX r lcommaaccent 15
+KPX r lslash 15
+KPX r m 25
+KPX r n 25
+KPX r nacute 25
+KPX r ncaron 25
+KPX r ncommaaccent 25
+KPX r ntilde 25
+KPX r p 30
+KPX r period -50
+KPX r semicolon 30
+KPX r t 40
+KPX r tcommaaccent 40
+KPX r u 15
+KPX r uacute 15
+KPX r ucircumflex 15
+KPX r udieresis 15
+KPX r ugrave 15
+KPX r uhungarumlaut 15
+KPX r umacron 15
+KPX r uogonek 15
+KPX r uring 15
+KPX r v 30
+KPX r y 30
+KPX r yacute 30
+KPX r ydieresis 30
+KPX racute a -10
+KPX racute aacute -10
+KPX racute abreve -10
+KPX racute acircumflex -10
+KPX racute adieresis -10
+KPX racute agrave -10
+KPX racute amacron -10
+KPX racute aogonek -10
+KPX racute aring -10
+KPX racute atilde -10
+KPX racute colon 30
+KPX racute comma -50
+KPX racute i 15
+KPX racute iacute 15
+KPX racute icircumflex 15
+KPX racute idieresis 15
+KPX racute igrave 15
+KPX racute imacron 15
+KPX racute iogonek 15
+KPX racute k 15
+KPX racute kcommaaccent 15
+KPX racute l 15
+KPX racute lacute 15
+KPX racute lcommaaccent 15
+KPX racute lslash 15
+KPX racute m 25
+KPX racute n 25
+KPX racute nacute 25
+KPX racute ncaron 25
+KPX racute ncommaaccent 25
+KPX racute ntilde 25
+KPX racute p 30
+KPX racute period -50
+KPX racute semicolon 30
+KPX racute t 40
+KPX racute tcommaaccent 40
+KPX racute u 15
+KPX racute uacute 15
+KPX racute ucircumflex 15
+KPX racute udieresis 15
+KPX racute ugrave 15
+KPX racute uhungarumlaut 15
+KPX racute umacron 15
+KPX racute uogonek 15
+KPX racute uring 15
+KPX racute v 30
+KPX racute y 30
+KPX racute yacute 30
+KPX racute ydieresis 30
+KPX rcaron a -10
+KPX rcaron aacute -10
+KPX rcaron abreve -10
+KPX rcaron acircumflex -10
+KPX rcaron adieresis -10
+KPX rcaron agrave -10
+KPX rcaron amacron -10
+KPX rcaron aogonek -10
+KPX rcaron aring -10
+KPX rcaron atilde -10
+KPX rcaron colon 30
+KPX rcaron comma -50
+KPX rcaron i 15
+KPX rcaron iacute 15
+KPX rcaron icircumflex 15
+KPX rcaron idieresis 15
+KPX rcaron igrave 15
+KPX rcaron imacron 15
+KPX rcaron iogonek 15
+KPX rcaron k 15
+KPX rcaron kcommaaccent 15
+KPX rcaron l 15
+KPX rcaron lacute 15
+KPX rcaron lcommaaccent 15
+KPX rcaron lslash 15
+KPX rcaron m 25
+KPX rcaron n 25
+KPX rcaron nacute 25
+KPX rcaron ncaron 25
+KPX rcaron ncommaaccent 25
+KPX rcaron ntilde 25
+KPX rcaron p 30
+KPX rcaron period -50
+KPX rcaron semicolon 30
+KPX rcaron t 40
+KPX rcaron tcommaaccent 40
+KPX rcaron u 15
+KPX rcaron uacute 15
+KPX rcaron ucircumflex 15
+KPX rcaron udieresis 15
+KPX rcaron ugrave 15
+KPX rcaron uhungarumlaut 15
+KPX rcaron umacron 15
+KPX rcaron uogonek 15
+KPX rcaron uring 15
+KPX rcaron v 30
+KPX rcaron y 30
+KPX rcaron yacute 30
+KPX rcaron ydieresis 30
+KPX rcommaaccent a -10
+KPX rcommaaccent aacute -10
+KPX rcommaaccent abreve -10
+KPX rcommaaccent acircumflex -10
+KPX rcommaaccent adieresis -10
+KPX rcommaaccent agrave -10
+KPX rcommaaccent amacron -10
+KPX rcommaaccent aogonek -10
+KPX rcommaaccent aring -10
+KPX rcommaaccent atilde -10
+KPX rcommaaccent colon 30
+KPX rcommaaccent comma -50
+KPX rcommaaccent i 15
+KPX rcommaaccent iacute 15
+KPX rcommaaccent icircumflex 15
+KPX rcommaaccent idieresis 15
+KPX rcommaaccent igrave 15
+KPX rcommaaccent imacron 15
+KPX rcommaaccent iogonek 15
+KPX rcommaaccent k 15
+KPX rcommaaccent kcommaaccent 15
+KPX rcommaaccent l 15
+KPX rcommaaccent lacute 15
+KPX rcommaaccent lcommaaccent 15
+KPX rcommaaccent lslash 15
+KPX rcommaaccent m 25
+KPX rcommaaccent n 25
+KPX rcommaaccent nacute 25
+KPX rcommaaccent ncaron 25
+KPX rcommaaccent ncommaaccent 25
+KPX rcommaaccent ntilde 25
+KPX rcommaaccent p 30
+KPX rcommaaccent period -50
+KPX rcommaaccent semicolon 30
+KPX rcommaaccent t 40
+KPX rcommaaccent tcommaaccent 40
+KPX rcommaaccent u 15
+KPX rcommaaccent uacute 15
+KPX rcommaaccent ucircumflex 15
+KPX rcommaaccent udieresis 15
+KPX rcommaaccent ugrave 15
+KPX rcommaaccent uhungarumlaut 15
+KPX rcommaaccent umacron 15
+KPX rcommaaccent uogonek 15
+KPX rcommaaccent uring 15
+KPX rcommaaccent v 30
+KPX rcommaaccent y 30
+KPX rcommaaccent yacute 30
+KPX rcommaaccent ydieresis 30
+KPX s comma -15
+KPX s period -15
+KPX s w -30
+KPX sacute comma -15
+KPX sacute period -15
+KPX sacute w -30
+KPX scaron comma -15
+KPX scaron period -15
+KPX scaron w -30
+KPX scedilla comma -15
+KPX scedilla period -15
+KPX scedilla w -30
+KPX scommaaccent comma -15
+KPX scommaaccent period -15
+KPX scommaaccent w -30
+KPX semicolon space -50
+KPX space T -50
+KPX space Tcaron -50
+KPX space Tcommaaccent -50
+KPX space V -50
+KPX space W -40
+KPX space Y -90
+KPX space Yacute -90
+KPX space Ydieresis -90
+KPX space quotedblleft -30
+KPX space quoteleft -60
+KPX v a -25
+KPX v aacute -25
+KPX v abreve -25
+KPX v acircumflex -25
+KPX v adieresis -25
+KPX v agrave -25
+KPX v amacron -25
+KPX v aogonek -25
+KPX v aring -25
+KPX v atilde -25
+KPX v comma -80
+KPX v e -25
+KPX v eacute -25
+KPX v ecaron -25
+KPX v ecircumflex -25
+KPX v edieresis -25
+KPX v edotaccent -25
+KPX v egrave -25
+KPX v emacron -25
+KPX v eogonek -25
+KPX v o -25
+KPX v oacute -25
+KPX v ocircumflex -25
+KPX v odieresis -25
+KPX v ograve -25
+KPX v ohungarumlaut -25
+KPX v omacron -25
+KPX v oslash -25
+KPX v otilde -25
+KPX v period -80
+KPX w a -15
+KPX w aacute -15
+KPX w abreve -15
+KPX w acircumflex -15
+KPX w adieresis -15
+KPX w agrave -15
+KPX w amacron -15
+KPX w aogonek -15
+KPX w aring -15
+KPX w atilde -15
+KPX w comma -60
+KPX w e -10
+KPX w eacute -10
+KPX w ecaron -10
+KPX w ecircumflex -10
+KPX w edieresis -10
+KPX w edotaccent -10
+KPX w egrave -10
+KPX w emacron -10
+KPX w eogonek -10
+KPX w o -10
+KPX w oacute -10
+KPX w ocircumflex -10
+KPX w odieresis -10
+KPX w ograve -10
+KPX w ohungarumlaut -10
+KPX w omacron -10
+KPX w oslash -10
+KPX w otilde -10
+KPX w period -60
+KPX x e -30
+KPX x eacute -30
+KPX x ecaron -30
+KPX x ecircumflex -30
+KPX x edieresis -30
+KPX x edotaccent -30
+KPX x egrave -30
+KPX x emacron -30
+KPX x eogonek -30
+KPX y a -20
+KPX y aacute -20
+KPX y abreve -20
+KPX y acircumflex -20
+KPX y adieresis -20
+KPX y agrave -20
+KPX y amacron -20
+KPX y aogonek -20
+KPX y aring -20
+KPX y atilde -20
+KPX y comma -100
+KPX y e -20
+KPX y eacute -20
+KPX y ecaron -20
+KPX y ecircumflex -20
+KPX y edieresis -20
+KPX y edotaccent -20
+KPX y egrave -20
+KPX y emacron -20
+KPX y eogonek -20
+KPX y o -20
+KPX y oacute -20
+KPX y ocircumflex -20
+KPX y odieresis -20
+KPX y ograve -20
+KPX y ohungarumlaut -20
+KPX y omacron -20
+KPX y oslash -20
+KPX y otilde -20
+KPX y period -100
+KPX yacute a -20
+KPX yacute aacute -20
+KPX yacute abreve -20
+KPX yacute acircumflex -20
+KPX yacute adieresis -20
+KPX yacute agrave -20
+KPX yacute amacron -20
+KPX yacute aogonek -20
+KPX yacute aring -20
+KPX yacute atilde -20
+KPX yacute comma -100
+KPX yacute e -20
+KPX yacute eacute -20
+KPX yacute ecaron -20
+KPX yacute ecircumflex -20
+KPX yacute edieresis -20
+KPX yacute edotaccent -20
+KPX yacute egrave -20
+KPX yacute emacron -20
+KPX yacute eogonek -20
+KPX yacute o -20
+KPX yacute oacute -20
+KPX yacute ocircumflex -20
+KPX yacute odieresis -20
+KPX yacute ograve -20
+KPX yacute ohungarumlaut -20
+KPX yacute omacron -20
+KPX yacute oslash -20
+KPX yacute otilde -20
+KPX yacute period -100
+KPX ydieresis a -20
+KPX ydieresis aacute -20
+KPX ydieresis abreve -20
+KPX ydieresis acircumflex -20
+KPX ydieresis adieresis -20
+KPX ydieresis agrave -20
+KPX ydieresis amacron -20
+KPX ydieresis aogonek -20
+KPX ydieresis aring -20
+KPX ydieresis atilde -20
+KPX ydieresis comma -100
+KPX ydieresis e -20
+KPX ydieresis eacute -20
+KPX ydieresis ecaron -20
+KPX ydieresis ecircumflex -20
+KPX ydieresis edieresis -20
+KPX ydieresis edotaccent -20
+KPX ydieresis egrave -20
+KPX ydieresis emacron -20
+KPX ydieresis eogonek -20
+KPX ydieresis o -20
+KPX ydieresis oacute -20
+KPX ydieresis ocircumflex -20
+KPX ydieresis odieresis -20
+KPX ydieresis ograve -20
+KPX ydieresis ohungarumlaut -20
+KPX ydieresis omacron -20
+KPX ydieresis oslash -20
+KPX ydieresis otilde -20
+KPX ydieresis period -100
+KPX z e -15
+KPX z eacute -15
+KPX z ecaron -15
+KPX z ecircumflex -15
+KPX z edieresis -15
+KPX z edotaccent -15
+KPX z egrave -15
+KPX z emacron -15
+KPX z eogonek -15
+KPX z o -15
+KPX z oacute -15
+KPX z ocircumflex -15
+KPX z odieresis -15
+KPX z ograve -15
+KPX z ohungarumlaut -15
+KPX z omacron -15
+KPX z oslash -15
+KPX z otilde -15
+KPX zacute e -15
+KPX zacute eacute -15
+KPX zacute ecaron -15
+KPX zacute ecircumflex -15
+KPX zacute edieresis -15
+KPX zacute edotaccent -15
+KPX zacute egrave -15
+KPX zacute emacron -15
+KPX zacute eogonek -15
+KPX zacute o -15
+KPX zacute oacute -15
+KPX zacute ocircumflex -15
+KPX zacute odieresis -15
+KPX zacute ograve -15
+KPX zacute ohungarumlaut -15
+KPX zacute omacron -15
+KPX zacute oslash -15
+KPX zacute otilde -15
+KPX zcaron e -15
+KPX zcaron eacute -15
+KPX zcaron ecaron -15
+KPX zcaron ecircumflex -15
+KPX zcaron edieresis -15
+KPX zcaron edotaccent -15
+KPX zcaron egrave -15
+KPX zcaron emacron -15
+KPX zcaron eogonek -15
+KPX zcaron o -15
+KPX zcaron oacute -15
+KPX zcaron ocircumflex -15
+KPX zcaron odieresis -15
+KPX zcaron ograve -15
+KPX zcaron ohungarumlaut -15
+KPX zcaron omacron -15
+KPX zcaron oslash -15
+KPX zcaron otilde -15
+KPX zdotaccent e -15
+KPX zdotaccent eacute -15
+KPX zdotaccent ecaron -15
+KPX zdotaccent ecircumflex -15
+KPX zdotaccent edieresis -15
+KPX zdotaccent edotaccent -15
+KPX zdotaccent egrave -15
+KPX zdotaccent emacron -15
+KPX zdotaccent eogonek -15
+KPX zdotaccent o -15
+KPX zdotaccent oacute -15
+KPX zdotaccent ocircumflex -15
+KPX zdotaccent odieresis -15
+KPX zdotaccent ograve -15
+KPX zdotaccent ohungarumlaut -15
+KPX zdotaccent omacron -15
+KPX zdotaccent oslash -15
+KPX zdotaccent otilde -15
+EndKernPairs
+EndKernData
+EndFontMetrics
Added: trunk/mapbender/http/classes/fonts/Symbol.afm
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/fonts/Symbol.afm?view=auto&rev=13
--- (empty file)
+++ trunk/mapbender/http/classes/fonts/Symbol.afm 2006-04-13 19:38:28+0000
@@ -0,0 +1,213 @@
+StartFontMetrics 4.1
+Comment Copyright (c) 1985, 1987, 1989, 1990, 1997 Adobe Systems Incorporated. All rights reserved.
+Comment Creation Date: Thu May 1 15:12:25 1997
+Comment UniqueID 43064
+Comment VMusage 30820 39997
+FontName Symbol
+FullName Symbol
+FamilyName Symbol
+Weight Medium
+ItalicAngle 0
+IsFixedPitch false
+CharacterSet Special
+FontBBox -180 -293 1090 1010
+UnderlinePosition -100
+UnderlineThickness 50
+Version 001.008
+Notice Copyright (c) 1985, 1987, 1989, 1990, 1997 Adobe Systems Incorporated. All rights reserved.
+EncodingScheme FontSpecific
+StdHW 92
+StdVW 85
+StartCharMetrics 190
+C 32 ; WX 250 ; N space ; B 0 0 0 0 ;
+C 33 ; WX 333 ; N exclam ; B 128 -17 240 672 ;
+C 34 ; WX 713 ; N universal ; B 31 0 681 705 ;
+C 35 ; WX 500 ; N numbersign ; B 20 -16 481 673 ;
+C 36 ; WX 549 ; N existential ; B 25 0 478 707 ;
+C 37 ; WX 833 ; N percent ; B 63 -36 771 655 ;
+C 38 ; WX 778 ; N ampersand ; B 41 -18 750 661 ;
+C 39 ; WX 439 ; N suchthat ; B 48 -17 414 500 ;
+C 40 ; WX 333 ; N parenleft ; B 53 -191 300 673 ;
+C 41 ; WX 333 ; N parenright ; B 30 -191 277 673 ;
+C 42 ; WX 500 ; N asteriskmath ; B 65 134 427 551 ;
+C 43 ; WX 549 ; N plus ; B 10 0 539 533 ;
+C 44 ; WX 250 ; N comma ; B 56 -152 194 104 ;
+C 45 ; WX 549 ; N minus ; B 11 233 535 288 ;
+C 46 ; WX 250 ; N period ; B 69 -17 181 95 ;
+C 47 ; WX 278 ; N slash ; B 0 -18 254 646 ;
+C 48 ; WX 500 ; N zero ; B 24 -14 476 685 ;
+C 49 ; WX 500 ; N one ; B 117 0 390 673 ;
+C 50 ; WX 500 ; N two ; B 25 0 475 685 ;
+C 51 ; WX 500 ; N three ; B 43 -14 435 685 ;
+C 52 ; WX 500 ; N four ; B 15 0 469 685 ;
+C 53 ; WX 500 ; N five ; B 32 -14 445 690 ;
+C 54 ; WX 500 ; N six ; B 34 -14 468 685 ;
+C 55 ; WX 500 ; N seven ; B 24 -16 448 673 ;
+C 56 ; WX 500 ; N eight ; B 56 -14 445 685 ;
+C 57 ; WX 500 ; N nine ; B 30 -18 459 685 ;
+C 58 ; WX 278 ; N colon ; B 81 -17 193 460 ;
+C 59 ; WX 278 ; N semicolon ; B 83 -152 221 460 ;
+C 60 ; WX 549 ; N less ; B 26 0 523 522 ;
+C 61 ; WX 549 ; N equal ; B 11 141 537 390 ;
+C 62 ; WX 549 ; N greater ; B 26 0 523 522 ;
+C 63 ; WX 444 ; N question ; B 70 -17 412 686 ;
+C 64 ; WX 549 ; N congruent ; B 11 0 537 475 ;
+C 65 ; WX 722 ; N Alpha ; B 4 0 684 673 ;
+C 66 ; WX 667 ; N Beta ; B 29 0 592 673 ;
+C 67 ; WX 722 ; N Chi ; B -9 0 704 673 ;
+C 68 ; WX 612 ; N Delta ; B 6 0 608 688 ;
+C 69 ; WX 611 ; N Epsilon ; B 32 0 617 673 ;
+C 70 ; WX 763 ; N Phi ; B 26 0 741 673 ;
+C 71 ; WX 603 ; N Gamma ; B 24 0 609 673 ;
+C 72 ; WX 722 ; N Eta ; B 39 0 729 673 ;
+C 73 ; WX 333 ; N Iota ; B 32 0 316 673 ;
+C 74 ; WX 631 ; N theta1 ; B 18 -18 623 689 ;
+C 75 ; WX 722 ; N Kappa ; B 35 0 722 673 ;
+C 76 ; WX 686 ; N Lambda ; B 6 0 680 688 ;
+C 77 ; WX 889 ; N Mu ; B 28 0 887 673 ;
+C 78 ; WX 722 ; N Nu ; B 29 -8 720 673 ;
+C 79 ; WX 722 ; N Omicron ; B 41 -17 715 685 ;
+C 80 ; WX 768 ; N Pi ; B 25 0 745 673 ;
+C 81 ; WX 741 ; N Theta ; B 41 -17 715 685 ;
+C 82 ; WX 556 ; N Rho ; B 28 0 563 673 ;
+C 83 ; WX 592 ; N Sigma ; B 5 0 589 673 ;
+C 84 ; WX 611 ; N Tau ; B 33 0 607 673 ;
+C 85 ; WX 690 ; N Upsilon ; B -8 0 694 673 ;
+C 86 ; WX 439 ; N sigma1 ; B 40 -233 436 500 ;
+C 87 ; WX 768 ; N Omega ; B 34 0 736 688 ;
+C 88 ; WX 645 ; N Xi ; B 40 0 599 673 ;
+C 89 ; WX 795 ; N Psi ; B 15 0 781 684 ;
+C 90 ; WX 611 ; N Zeta ; B 44 0 636 673 ;
+C 91 ; WX 333 ; N bracketleft ; B 86 -155 299 674 ;
+C 92 ; WX 863 ; N therefore ; B 163 0 701 487 ;
+C 93 ; WX 333 ; N bracketright ; B 33 -155 246 674 ;
+C 94 ; WX 658 ; N perpendicular ; B 15 0 652 674 ;
+C 95 ; WX 500 ; N underscore ; B -2 -125 502 -75 ;
+C 96 ; WX 500 ; N radicalex ; B 480 881 1090 917 ;
+C 97 ; WX 631 ; N alpha ; B 41 -18 622 500 ;
+C 98 ; WX 549 ; N beta ; B 61 -223 515 741 ;
+C 99 ; WX 549 ; N chi ; B 12 -231 522 499 ;
+C 100 ; WX 494 ; N delta ; B 40 -19 481 740 ;
+C 101 ; WX 439 ; N epsilon ; B 22 -19 427 502 ;
+C 102 ; WX 521 ; N phi ; B 28 -224 492 673 ;
+C 103 ; WX 411 ; N gamma ; B 5 -225 484 499 ;
+C 104 ; WX 603 ; N eta ; B 0 -202 527 514 ;
+C 105 ; WX 329 ; N iota ; B 0 -17 301 503 ;
+C 106 ; WX 603 ; N phi1 ; B 36 -224 587 499 ;
+C 107 ; WX 549 ; N kappa ; B 33 0 558 501 ;
+C 108 ; WX 549 ; N lambda ; B 24 -17 548 739 ;
+C 109 ; WX 576 ; N mu ; B 33 -223 567 500 ;
+C 110 ; WX 521 ; N nu ; B -9 -16 475 507 ;
+C 111 ; WX 549 ; N omicron ; B 35 -19 501 499 ;
+C 112 ; WX 549 ; N pi ; B 10 -19 530 487 ;
+C 113 ; WX 521 ; N theta ; B 43 -17 485 690 ;
+C 114 ; WX 549 ; N rho ; B 50 -230 490 499 ;
+C 115 ; WX 603 ; N sigma ; B 30 -21 588 500 ;
+C 116 ; WX 439 ; N tau ; B 10 -19 418 500 ;
+C 117 ; WX 576 ; N upsilon ; B 7 -18 535 507 ;
+C 118 ; WX 713 ; N omega1 ; B 12 -18 671 583 ;
+C 119 ; WX 686 ; N omega ; B 42 -17 684 500 ;
+C 120 ; WX 493 ; N xi ; B 27 -224 469 766 ;
+C 121 ; WX 686 ; N psi ; B 12 -228 701 500 ;
+C 122 ; WX 494 ; N zeta ; B 60 -225 467 756 ;
+C 123 ; WX 480 ; N braceleft ; B 58 -183 397 673 ;
+C 124 ; WX 200 ; N bar ; B 65 -293 135 707 ;
+C 125 ; WX 480 ; N braceright ; B 79 -183 418 673 ;
+C 126 ; WX 549 ; N similar ; B 17 203 529 307 ;
+C 160 ; WX 750 ; N Euro ; B 20 -12 714 685 ;
+C 161 ; WX 620 ; N Upsilon1 ; B -2 0 610 685 ;
+C 162 ; WX 247 ; N minute ; B 27 459 228 735 ;
+C 163 ; WX 549 ; N lessequal ; B 29 0 526 639 ;
+C 164 ; WX 167 ; N fraction ; B -180 -12 340 677 ;
+C 165 ; WX 713 ; N infinity ; B 26 124 688 404 ;
+C 166 ; WX 500 ; N florin ; B 2 -193 494 686 ;
+C 167 ; WX 753 ; N club ; B 86 -26 660 533 ;
+C 168 ; WX 753 ; N diamond ; B 142 -36 600 550 ;
+C 169 ; WX 753 ; N heart ; B 117 -33 631 532 ;
+C 170 ; WX 753 ; N spade ; B 113 -36 629 548 ;
+C 171 ; WX 1042 ; N arrowboth ; B 24 -15 1024 511 ;
+C 172 ; WX 987 ; N arrowleft ; B 32 -15 942 511 ;
+C 173 ; WX 603 ; N arrowup ; B 45 0 571 910 ;
+C 174 ; WX 987 ; N arrowright ; B 49 -15 959 511 ;
+C 175 ; WX 603 ; N arrowdown ; B 45 -22 571 888 ;
+C 176 ; WX 400 ; N degree ; B 50 385 350 685 ;
+C 177 ; WX 549 ; N plusminus ; B 10 0 539 645 ;
+C 178 ; WX 411 ; N second ; B 20 459 413 737 ;
+C 179 ; WX 549 ; N greaterequal ; B 29 0 526 639 ;
+C 180 ; WX 549 ; N multiply ; B 17 8 533 524 ;
+C 181 ; WX 713 ; N proportional ; B 27 123 639 404 ;
+C 182 ; WX 494 ; N partialdiff ; B 26 -20 462 746 ;
+C 183 ; WX 460 ; N bullet ; B 50 113 410 473 ;
+C 184 ; WX 549 ; N divide ; B 10 71 536 456 ;
+C 185 ; WX 549 ; N notequal ; B 15 -25 540 549 ;
+C 186 ; WX 549 ; N equivalence ; B 14 82 538 443 ;
+C 187 ; WX 549 ; N approxequal ; B 14 135 527 394 ;
+C 188 ; WX 1000 ; N ellipsis ; B 111 -17 889 95 ;
+C 189 ; WX 603 ; N arrowvertex ; B 280 -120 336 1010 ;
+C 190 ; WX 1000 ; N arrowhorizex ; B -60 220 1050 276 ;
+C 191 ; WX 658 ; N carriagereturn ; B 15 -16 602 629 ;
+C 192 ; WX 823 ; N aleph ; B 175 -18 661 658 ;
+C 193 ; WX 686 ; N Ifraktur ; B 10 -53 578 740 ;
+C 194 ; WX 795 ; N Rfraktur ; B 26 -15 759 734 ;
+C 195 ; WX 987 ; N weierstrass ; B 159 -211 870 573 ;
+C 196 ; WX 768 ; N circlemultiply ; B 43 -17 733 673 ;
+C 197 ; WX 768 ; N circleplus ; B 43 -15 733 675 ;
+C 198 ; WX 823 ; N emptyset ; B 39 -24 781 719 ;
+C 199 ; WX 768 ; N intersection ; B 40 0 732 509 ;
+C 200 ; WX 768 ; N union ; B 40 -17 732 492 ;
+C 201 ; WX 713 ; N propersuperset ; B 20 0 673 470 ;
+C 202 ; WX 713 ; N reflexsuperset ; B 20 -125 673 470 ;
+C 203 ; WX 713 ; N notsubset ; B 36 -70 690 540 ;
+C 204 ; WX 713 ; N propersubset ; B 37 0 690 470 ;
+C 205 ; WX 713 ; N reflexsubset ; B 37 -125 690 470 ;
+C 206 ; WX 713 ; N element ; B 45 0 505 468 ;
+C 207 ; WX 713 ; N notelement ; B 45 -58 505 555 ;
+C 208 ; WX 768 ; N angle ; B 26 0 738 673 ;
+C 209 ; WX 713 ; N gradient ; B 36 -19 681 718 ;
+C 210 ; WX 790 ; N registerserif ; B 50 -17 740 673 ;
+C 211 ; WX 790 ; N copyrightserif ; B 51 -15 741 675 ;
+C 212 ; WX 890 ; N trademarkserif ; B 18 293 855 673 ;
+C 213 ; WX 823 ; N product ; B 25 -101 803 751 ;
+C 214 ; WX 549 ; N radical ; B 10 -38 515 917 ;
+C 215 ; WX 250 ; N dotmath ; B 69 210 169 310 ;
+C 216 ; WX 713 ; N logicalnot ; B 15 0 680 288 ;
+C 217 ; WX 603 ; N logicaland ; B 23 0 583 454 ;
+C 218 ; WX 603 ; N logicalor ; B 30 0 578 477 ;
+C 219 ; WX 1042 ; N arrowdblboth ; B 27 -20 1023 510 ;
+C 220 ; WX 987 ; N arrowdblleft ; B 30 -15 939 513 ;
+C 221 ; WX 603 ; N arrowdblup ; B 39 2 567 911 ;
+C 222 ; WX 987 ; N arrowdblright ; B 45 -20 954 508 ;
+C 223 ; WX 603 ; N arrowdbldown ; B 44 -19 572 890 ;
+C 224 ; WX 494 ; N lozenge ; B 18 0 466 745 ;
+C 225 ; WX 329 ; N angleleft ; B 25 -198 306 746 ;
+C 226 ; WX 790 ; N registersans ; B 50 -20 740 670 ;
+C 227 ; WX 790 ; N copyrightsans ; B 49 -15 739 675 ;
+C 228 ; WX 786 ; N trademarksans ; B 5 293 725 673 ;
+C 229 ; WX 713 ; N summation ; B 14 -108 695 752 ;
+C 230 ; WX 384 ; N parenlefttp ; B 24 -293 436 926 ;
+C 231 ; WX 384 ; N parenleftex ; B 24 -85 108 925 ;
+C 232 ; WX 384 ; N parenleftbt ; B 24 -293 436 926 ;
+C 233 ; WX 384 ; N bracketlefttp ; B 0 -80 349 926 ;
+C 234 ; WX 384 ; N bracketleftex ; B 0 -79 77 925 ;
+C 235 ; WX 384 ; N bracketleftbt ; B 0 -80 349 926 ;
+C 236 ; WX 494 ; N bracelefttp ; B 209 -85 445 925 ;
+C 237 ; WX 494 ; N braceleftmid ; B 20 -85 284 935 ;
+C 238 ; WX 494 ; N braceleftbt ; B 209 -75 445 935 ;
+C 239 ; WX 494 ; N braceex ; B 209 -85 284 935 ;
+C 241 ; WX 329 ; N angleright ; B 21 -198 302 746 ;
+C 242 ; WX 274 ; N integral ; B 2 -107 291 916 ;
+C 243 ; WX 686 ; N integraltp ; B 308 -88 675 920 ;
+C 244 ; WX 686 ; N integralex ; B 308 -88 378 975 ;
+C 245 ; WX 686 ; N integralbt ; B 11 -87 378 921 ;
+C 246 ; WX 384 ; N parenrighttp ; B 54 -293 466 926 ;
+C 247 ; WX 384 ; N parenrightex ; B 382 -85 466 925 ;
+C 248 ; WX 384 ; N parenrightbt ; B 54 -293 466 926 ;
+C 249 ; WX 384 ; N bracketrighttp ; B 22 -80 371 926 ;
+C 250 ; WX 384 ; N bracketrightex ; B 294 -79 371 925 ;
+C 251 ; WX 384 ; N bracketrightbt ; B 22 -80 371 926 ;
+C 252 ; WX 494 ; N bracerighttp ; B 48 -85 284 925 ;
+C 253 ; WX 494 ; N bracerightmid ; B 209 -85 473 935 ;
+C 254 ; WX 494 ; N bracerightbt ; B 48 -75 284 935 ;
+C -1 ; WX 790 ; N apple ; B 56 -3 733 808 ;
+EndCharMetrics
+EndFontMetrics
Added: trunk/mapbender/http/classes/fonts/Times-BoldItalic.afm
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/fonts/Times-BoldItalic.afm?view=auto&rev=13
--- (empty file)
+++ trunk/mapbender/http/classes/fonts/Times-BoldItalic.afm 2006-04-13 19:38:28+0000
@@ -0,0 +1,2384 @@
+Comment Copyright (c) 1985, 1987, 1989, 1990, 1993, 1997 Adobe Systems Incorporated. All Rights Reserved.
+Comment Creation Date: Thu May 1 13:04:06 1997
+Comment UniqueID 43066
+Comment VMusage 45874 56899
+FontName Times-BoldItalic
+FullName Times Bold Italic
+FamilyName Times
+Weight Bold
+ItalicAngle -15
+IsFixedPitch false
+CharacterSet ExtendedRoman
+FontBBox -200 -218 996 921
+Version 002.000
+Notice Copyright (c) 1985, 1987, 1989, 1990, 1993, 1997 Adobe Systems Incorporated. All Rights Reserved.Times is a trademark of Linotype-Hell AG and/or its subsidiaries.
+EncodingScheme AdobeStandardEncoding
+CapHeight 669
+XHeight 462
+Ascender 683
+Descender -217
+StdHW 42
+StdVW 121
+StartCharMetrics 315
+C 33 ; WX 389 ; N exclam ; B 67 -13 370 684 ;
+C 34 ; WX 555 ; N quotedbl ; B 136 398 536 685 ;
+C 35 ; WX 500 ; N numbersign ; B -33 0 533 700 ;
+C 36 ; WX 500 ; N dollar ; B -20 -100 497 733 ;
+C 37 ; WX 833 ; N percent ; B 39 -10 793 692 ;
+C 38 ; WX 778 ; N ampersand ; B 5 -19 699 682 ;
+C 39 ; WX 333 ; N quoteright ; B 98 369 302 685 ;
+C 40 ; WX 333 ; N parenleft ; B 28 -179 344 685 ;
+C 41 ; WX 333 ; N parenright ; B -44 -179 271 685 ;
+C 42 ; WX 500 ; N asterisk ; B 65 249 456 685 ;
+C 43 ; WX 570 ; N plus ; B 33 0 537 506 ;
+C 44 ; WX 250 ; N comma ; B -60 -182 144 134 ;
+C 45 ; WX 333 ; N hyphen ; B 2 166 271 282 ;
+C 46 ; WX 250 ; N period ; B -9 -13 139 135 ;
+C 47 ; WX 278 ; N slash ; B -64 -18 342 685 ;
+C 48 ; WX 500 ; N zero ; B 17 -14 477 683 ;
+C 49 ; WX 500 ; N one ; B 5 0 419 683 ;
+C 50 ; WX 500 ; N two ; B -27 0 446 683 ;
+C 51 ; WX 500 ; N three ; B -15 -13 450 683 ;
+C 52 ; WX 500 ; N four ; B -15 0 503 683 ;
+C 53 ; WX 500 ; N five ; B -11 -13 487 669 ;
+C 54 ; WX 500 ; N six ; B 23 -15 509 679 ;
+C 55 ; WX 500 ; N seven ; B 52 0 525 669 ;
+C 56 ; WX 500 ; N eight ; B 3 -13 476 683 ;
+C 57 ; WX 500 ; N nine ; B -12 -10 475 683 ;
+C 58 ; WX 333 ; N colon ; B 23 -13 264 459 ;
+C 59 ; WX 333 ; N semicolon ; B -25 -183 264 459 ;
+C 60 ; WX 570 ; N less ; B 31 -8 539 514 ;
+C 61 ; WX 570 ; N equal ; B 33 107 537 399 ;
+C 62 ; WX 570 ; N greater ; B 31 -8 539 514 ;
+C 63 ; WX 500 ; N question ; B 79 -13 470 684 ;
+C 64 ; WX 832 ; N at ; B 63 -18 770 685 ;
+C 65 ; WX 667 ; N A ; B -67 0 593 683 ;
+C 66 ; WX 667 ; N B ; B -24 0 624 669 ;
+C 67 ; WX 667 ; N C ; B 32 -18 677 685 ;
+C 68 ; WX 722 ; N D ; B -46 0 685 669 ;
+C 69 ; WX 667 ; N E ; B -27 0 653 669 ;
+C 70 ; WX 667 ; N F ; B -13 0 660 669 ;
+C 71 ; WX 722 ; N G ; B 21 -18 706 685 ;
+C 72 ; WX 778 ; N H ; B -24 0 799 669 ;
+C 73 ; WX 389 ; N I ; B -32 0 406 669 ;
+C 74 ; WX 500 ; N J ; B -46 -99 524 669 ;
+C 75 ; WX 667 ; N K ; B -21 0 702 669 ;
+C 76 ; WX 611 ; N L ; B -22 0 590 669 ;
+C 77 ; WX 889 ; N M ; B -29 -12 917 669 ;
+C 78 ; WX 722 ; N N ; B -27 -15 748 669 ;
+C 79 ; WX 722 ; N O ; B 27 -18 691 685 ;
+C 80 ; WX 611 ; N P ; B -27 0 613 669 ;
+C 81 ; WX 722 ; N Q ; B 27 -208 691 685 ;
+C 82 ; WX 667 ; N R ; B -29 0 623 669 ;
+C 83 ; WX 556 ; N S ; B 2 -18 526 685 ;
+C 84 ; WX 611 ; N T ; B 50 0 650 669 ;
+C 85 ; WX 722 ; N U ; B 67 -18 744 669 ;
+C 86 ; WX 667 ; N V ; B 65 -18 715 669 ;
+C 87 ; WX 889 ; N W ; B 65 -18 940 669 ;
+C 88 ; WX 667 ; N X ; B -24 0 694 669 ;
+C 89 ; WX 611 ; N Y ; B 73 0 659 669 ;
+C 90 ; WX 611 ; N Z ; B -11 0 590 669 ;
+C 91 ; WX 333 ; N bracketleft ; B -37 -159 362 674 ;
+C 92 ; WX 278 ; N backslash ; B -1 -18 279 685 ;
+C 93 ; WX 333 ; N bracketright ; B -56 -157 343 674 ;
+C 94 ; WX 570 ; N asciicircum ; B 67 304 503 669 ;
+C 95 ; WX 500 ; N underscore ; B 0 -125 500 -75 ;
+C 96 ; WX 333 ; N quoteleft ; B 128 369 332 685 ;
+C 97 ; WX 500 ; N a ; B -21 -14 455 462 ;
+C 98 ; WX 500 ; N b ; B -14 -13 444 699 ;
+C 99 ; WX 444 ; N c ; B -5 -13 392 462 ;
+C 100 ; WX 500 ; N d ; B -21 -13 517 699 ;
+C 101 ; WX 444 ; N e ; B 5 -13 398 462 ;
+C 102 ; WX 333 ; N f ; B -169 -205 446 698 ; L i fi ; L l fl ;
+C 103 ; WX 500 ; N g ; B -52 -203 478 462 ;
+C 104 ; WX 556 ; N h ; B -13 -9 498 699 ;
+C 105 ; WX 278 ; N i ; B 2 -9 263 684 ;
+C 106 ; WX 278 ; N j ; B -189 -207 279 684 ;
+C 107 ; WX 500 ; N k ; B -23 -8 483 699 ;
+C 108 ; WX 278 ; N l ; B 2 -9 290 699 ;
+C 109 ; WX 778 ; N m ; B -14 -9 722 462 ;
+C 110 ; WX 556 ; N n ; B -6 -9 493 462 ;
+C 111 ; WX 500 ; N o ; B -3 -13 441 462 ;
+C 112 ; WX 500 ; N p ; B -120 -205 446 462 ;
+C 113 ; WX 500 ; N q ; B 1 -205 471 462 ;
+C 114 ; WX 389 ; N r ; B -21 0 389 462 ;
+C 115 ; WX 389 ; N s ; B -19 -13 333 462 ;
+C 116 ; WX 278 ; N t ; B -11 -9 281 594 ;
+C 117 ; WX 556 ; N u ; B 15 -9 492 462 ;
+C 118 ; WX 444 ; N v ; B 16 -13 401 462 ;
+C 119 ; WX 667 ; N w ; B 16 -13 614 462 ;
+C 120 ; WX 500 ; N x ; B -46 -13 469 462 ;
+C 121 ; WX 444 ; N y ; B -94 -205 392 462 ;
+C 122 ; WX 389 ; N z ; B -43 -78 368 449 ;
+C 123 ; WX 348 ; N braceleft ; B 5 -187 436 686 ;
+C 124 ; WX 220 ; N bar ; B 66 -218 154 782 ;
+C 125 ; WX 348 ; N braceright ; B -129 -187 302 686 ;
+C 126 ; WX 570 ; N asciitilde ; B 54 173 516 333 ;
+C 161 ; WX 389 ; N exclamdown ; B 19 -205 322 492 ;
+C 162 ; WX 500 ; N cent ; B 42 -143 439 576 ;
+C 163 ; WX 500 ; N sterling ; B -32 -12 510 683 ;
+C 164 ; WX 167 ; N fraction ; B -169 -14 324 683 ;
+C 165 ; WX 500 ; N yen ; B 33 0 628 669 ;
+C 166 ; WX 500 ; N florin ; B -87 -156 537 707 ;
+C 167 ; WX 500 ; N section ; B 36 -143 459 685 ;
+C 168 ; WX 500 ; N currency ; B -26 34 526 586 ;
+C 169 ; WX 278 ; N quotesingle ; B 128 398 268 685 ;
+C 170 ; WX 500 ; N quotedblleft ; B 53 369 513 685 ;
+C 171 ; WX 500 ; N guillemotleft ; B 12 32 468 415 ;
+C 172 ; WX 333 ; N guilsinglleft ; B 32 32 303 415 ;
+C 173 ; WX 333 ; N guilsinglright ; B 10 32 281 415 ;
+C 174 ; WX 556 ; N fi ; B -188 -205 514 703 ;
+C 175 ; WX 556 ; N fl ; B -186 -205 553 704 ;
+C 177 ; WX 500 ; N endash ; B -40 178 477 269 ;
+C 178 ; WX 500 ; N dagger ; B 91 -145 494 685 ;
+C 179 ; WX 500 ; N daggerdbl ; B 10 -139 493 685 ;
+C 180 ; WX 250 ; N periodcentered ; B 51 257 199 405 ;
+C 182 ; WX 500 ; N paragraph ; B -57 -193 562 669 ;
+C 183 ; WX 350 ; N bullet ; B 0 175 350 525 ;
+C 184 ; WX 333 ; N quotesinglbase ; B -5 -182 199 134 ;
+C 185 ; WX 500 ; N quotedblbase ; B -57 -182 403 134 ;
+C 186 ; WX 500 ; N quotedblright ; B 53 369 513 685 ;
+C 187 ; WX 500 ; N guillemotright ; B 12 32 468 415 ;
+C 188 ; WX 1000 ; N ellipsis ; B 40 -13 852 135 ;
+C 189 ; WX 1000 ; N perthousand ; B 7 -29 996 706 ;
+C 191 ; WX 500 ; N questiondown ; B 30 -205 421 492 ;
+C 193 ; WX 333 ; N grave ; B 85 516 297 697 ;
+C 194 ; WX 333 ; N acute ; B 139 516 379 697 ;
+C 195 ; WX 333 ; N circumflex ; B 40 516 367 690 ;
+C 196 ; WX 333 ; N tilde ; B 48 536 407 655 ;
+C 197 ; WX 333 ; N macron ; B 51 553 393 623 ;
+C 198 ; WX 333 ; N breve ; B 71 516 387 678 ;
+C 199 ; WX 333 ; N dotaccent ; B 163 550 298 684 ;
+C 200 ; WX 333 ; N dieresis ; B 55 550 402 684 ;
+C 202 ; WX 333 ; N ring ; B 127 516 340 729 ;
+C 203 ; WX 333 ; N cedilla ; B -80 -218 156 5 ;
+C 205 ; WX 333 ; N hungarumlaut ; B 69 516 498 697 ;
+C 206 ; WX 333 ; N ogonek ; B 15 -183 244 34 ;
+C 207 ; WX 333 ; N caron ; B 79 516 411 690 ;
+C 208 ; WX 1000 ; N emdash ; B -40 178 977 269 ;
+C 225 ; WX 944 ; N AE ; B -64 0 918 669 ;
+C 227 ; WX 266 ; N ordfeminine ; B 16 399 330 685 ;
+C 232 ; WX 611 ; N Lslash ; B -22 0 590 669 ;
+C 233 ; WX 722 ; N Oslash ; B 27 -125 691 764 ;
+C 234 ; WX 944 ; N OE ; B 23 -8 946 677 ;
+C 235 ; WX 300 ; N ordmasculine ; B 56 400 347 685 ;
+C 241 ; WX 722 ; N ae ; B -5 -13 673 462 ;
+C 245 ; WX 278 ; N dotlessi ; B 2 -9 238 462 ;
+C 248 ; WX 278 ; N lslash ; B -7 -9 307 699 ;
+C 249 ; WX 500 ; N oslash ; B -3 -119 441 560 ;
+C 250 ; WX 722 ; N oe ; B 6 -13 674 462 ;
+C 251 ; WX 500 ; N germandbls ; B -200 -200 473 705 ;
+C -1 ; WX 389 ; N Idieresis ; B -32 0 450 862 ;
+C -1 ; WX 444 ; N eacute ; B 5 -13 435 697 ;
+C -1 ; WX 500 ; N abreve ; B -21 -14 471 678 ;
+C -1 ; WX 556 ; N uhungarumlaut ; B 15 -9 610 697 ;
+C -1 ; WX 444 ; N ecaron ; B 5 -13 467 690 ;
+C -1 ; WX 611 ; N Ydieresis ; B 73 0 659 862 ;
+C -1 ; WX 570 ; N divide ; B 33 -29 537 535 ;
+C -1 ; WX 611 ; N Yacute ; B 73 0 659 904 ;
+C -1 ; WX 667 ; N Acircumflex ; B -67 0 593 897 ;
+C -1 ; WX 500 ; N aacute ; B -21 -14 463 697 ;
+C -1 ; WX 722 ; N Ucircumflex ; B 67 -18 744 897 ;
+C -1 ; WX 444 ; N yacute ; B -94 -205 435 697 ;
+C -1 ; WX 389 ; N scommaaccent ; B -19 -218 333 462 ;
+C -1 ; WX 444 ; N ecircumflex ; B 5 -13 423 690 ;
+C -1 ; WX 722 ; N Uring ; B 67 -18 744 921 ;
+C -1 ; WX 722 ; N Udieresis ; B 67 -18 744 862 ;
+C -1 ; WX 500 ; N aogonek ; B -21 -183 455 462 ;
+C -1 ; WX 722 ; N Uacute ; B 67 -18 744 904 ;
+C -1 ; WX 556 ; N uogonek ; B 15 -183 492 462 ;
+C -1 ; WX 667 ; N Edieresis ; B -27 0 653 862 ;
+C -1 ; WX 722 ; N Dcroat ; B -31 0 700 669 ;
+C -1 ; WX 250 ; N commaaccent ; B -36 -218 131 -50 ;
+C -1 ; WX 747 ; N copyright ; B 30 -18 718 685 ;
+C -1 ; WX 667 ; N Emacron ; B -27 0 653 830 ;
+C -1 ; WX 444 ; N ccaron ; B -5 -13 467 690 ;
+C -1 ; WX 500 ; N aring ; B -21 -14 455 729 ;
+C -1 ; WX 722 ; N Ncommaaccent ; B -27 -218 748 669 ;
+C -1 ; WX 278 ; N lacute ; B 2 -9 392 904 ;
+C -1 ; WX 500 ; N agrave ; B -21 -14 455 697 ;
+C -1 ; WX 611 ; N Tcommaaccent ; B 50 -218 650 669 ;
+C -1 ; WX 667 ; N Cacute ; B 32 -18 677 904 ;
+C -1 ; WX 500 ; N atilde ; B -21 -14 491 655 ;
+C -1 ; WX 667 ; N Edotaccent ; B -27 0 653 862 ;
+C -1 ; WX 389 ; N scaron ; B -19 -13 424 690 ;
+C -1 ; WX 389 ; N scedilla ; B -19 -218 333 462 ;
+C -1 ; WX 278 ; N iacute ; B 2 -9 352 697 ;
+C -1 ; WX 494 ; N lozenge ; B 10 0 484 745 ;
+C -1 ; WX 667 ; N Rcaron ; B -29 0 623 897 ;
+C -1 ; WX 722 ; N Gcommaaccent ; B 21 -218 706 685 ;
+C -1 ; WX 556 ; N ucircumflex ; B 15 -9 492 690 ;
+C -1 ; WX 500 ; N acircumflex ; B -21 -14 455 690 ;
+C -1 ; WX 667 ; N Amacron ; B -67 0 593 830 ;
+C -1 ; WX 389 ; N rcaron ; B -21 0 424 690 ;
+C -1 ; WX 444 ; N ccedilla ; B -5 -218 392 462 ;
+C -1 ; WX 611 ; N Zdotaccent ; B -11 0 590 862 ;
+C -1 ; WX 611 ; N Thorn ; B -27 0 573 669 ;
+C -1 ; WX 722 ; N Omacron ; B 27 -18 691 830 ;
+C -1 ; WX 667 ; N Racute ; B -29 0 623 904 ;
+C -1 ; WX 556 ; N Sacute ; B 2 -18 531 904 ;
+C -1 ; WX 608 ; N dcaron ; B -21 -13 675 708 ;
+C -1 ; WX 722 ; N Umacron ; B 67 -18 744 830 ;
+C -1 ; WX 556 ; N uring ; B 15 -9 492 729 ;
+C -1 ; WX 300 ; N threesuperior ; B 17 265 321 683 ;
+C -1 ; WX 722 ; N Ograve ; B 27 -18 691 904 ;
+C -1 ; WX 667 ; N Agrave ; B -67 0 593 904 ;
+C -1 ; WX 667 ; N Abreve ; B -67 0 593 885 ;
+C -1 ; WX 570 ; N multiply ; B 48 16 522 490 ;
+C -1 ; WX 556 ; N uacute ; B 15 -9 492 697 ;
+C -1 ; WX 611 ; N Tcaron ; B 50 0 650 897 ;
+C -1 ; WX 494 ; N partialdiff ; B 11 -21 494 750 ;
+C -1 ; WX 444 ; N ydieresis ; B -94 -205 443 655 ;
+C -1 ; WX 722 ; N Nacute ; B -27 -15 748 904 ;
+C -1 ; WX 278 ; N icircumflex ; B -3 -9 324 690 ;
+C -1 ; WX 667 ; N Ecircumflex ; B -27 0 653 897 ;
+C -1 ; WX 500 ; N adieresis ; B -21 -14 476 655 ;
+C -1 ; WX 444 ; N edieresis ; B 5 -13 448 655 ;
+C -1 ; WX 444 ; N cacute ; B -5 -13 435 697 ;
+C -1 ; WX 556 ; N nacute ; B -6 -9 493 697 ;
+C -1 ; WX 556 ; N umacron ; B 15 -9 492 623 ;
+C -1 ; WX 722 ; N Ncaron ; B -27 -15 748 897 ;
+C -1 ; WX 389 ; N Iacute ; B -32 0 432 904 ;
+C -1 ; WX 570 ; N plusminus ; B 33 0 537 506 ;
+C -1 ; WX 220 ; N brokenbar ; B 66 -143 154 707 ;
+C -1 ; WX 747 ; N registered ; B 30 -18 718 685 ;
+C -1 ; WX 722 ; N Gbreve ; B 21 -18 706 885 ;
+C -1 ; WX 389 ; N Idotaccent ; B -32 0 406 862 ;
+C -1 ; WX 600 ; N summation ; B 14 -10 585 706 ;
+C -1 ; WX 667 ; N Egrave ; B -27 0 653 904 ;
+C -1 ; WX 389 ; N racute ; B -21 0 407 697 ;
+C -1 ; WX 500 ; N omacron ; B -3 -13 462 623 ;
+C -1 ; WX 611 ; N Zacute ; B -11 0 590 904 ;
+C -1 ; WX 611 ; N Zcaron ; B -11 0 590 897 ;
+C -1 ; WX 549 ; N greaterequal ; B 26 0 523 704 ;
+C -1 ; WX 722 ; N Eth ; B -31 0 700 669 ;
+C -1 ; WX 667 ; N Ccedilla ; B 32 -218 677 685 ;
+C -1 ; WX 278 ; N lcommaaccent ; B -42 -218 290 699 ;
+C -1 ; WX 366 ; N tcaron ; B -11 -9 434 754 ;
+C -1 ; WX 444 ; N eogonek ; B 5 -183 398 462 ;
+C -1 ; WX 722 ; N Uogonek ; B 67 -183 744 669 ;
+C -1 ; WX 667 ; N Aacute ; B -67 0 593 904 ;
+C -1 ; WX 667 ; N Adieresis ; B -67 0 593 862 ;
+C -1 ; WX 444 ; N egrave ; B 5 -13 398 697 ;
+C -1 ; WX 389 ; N zacute ; B -43 -78 407 697 ;
+C -1 ; WX 278 ; N iogonek ; B -20 -183 263 684 ;
+C -1 ; WX 722 ; N Oacute ; B 27 -18 691 904 ;
+C -1 ; WX 500 ; N oacute ; B -3 -13 463 697 ;
+C -1 ; WX 500 ; N amacron ; B -21 -14 467 623 ;
+C -1 ; WX 389 ; N sacute ; B -19 -13 407 697 ;
+C -1 ; WX 278 ; N idieresis ; B 2 -9 364 655 ;
+C -1 ; WX 722 ; N Ocircumflex ; B 27 -18 691 897 ;
+C -1 ; WX 722 ; N Ugrave ; B 67 -18 744 904 ;
+C -1 ; WX 612 ; N Delta ; B 6 0 608 688 ;
+C -1 ; WX 500 ; N thorn ; B -120 -205 446 699 ;
+C -1 ; WX 300 ; N twosuperior ; B 2 274 313 683 ;
+C -1 ; WX 722 ; N Odieresis ; B 27 -18 691 862 ;
+C -1 ; WX 576 ; N mu ; B -60 -207 516 449 ;
+C -1 ; WX 278 ; N igrave ; B 2 -9 259 697 ;
+C -1 ; WX 500 ; N ohungarumlaut ; B -3 -13 582 697 ;
+C -1 ; WX 667 ; N Eogonek ; B -27 -183 653 669 ;
+C -1 ; WX 500 ; N dcroat ; B -21 -13 552 699 ;
+C -1 ; WX 750 ; N threequarters ; B 7 -14 726 683 ;
+C -1 ; WX 556 ; N Scedilla ; B 2 -218 526 685 ;
+C -1 ; WX 382 ; N lcaron ; B 2 -9 448 708 ;
+C -1 ; WX 667 ; N Kcommaaccent ; B -21 -218 702 669 ;
+C -1 ; WX 611 ; N Lacute ; B -22 0 590 904 ;
+C -1 ; WX 1000 ; N trademark ; B 32 263 968 669 ;
+C -1 ; WX 444 ; N edotaccent ; B 5 -13 398 655 ;
+C -1 ; WX 389 ; N Igrave ; B -32 0 406 904 ;
+C -1 ; WX 389 ; N Imacron ; B -32 0 461 830 ;
+C -1 ; WX 611 ; N Lcaron ; B -22 0 671 718 ;
+C -1 ; WX 750 ; N onehalf ; B -9 -14 723 683 ;
+C -1 ; WX 549 ; N lessequal ; B 29 0 526 704 ;
+C -1 ; WX 500 ; N ocircumflex ; B -3 -13 451 690 ;
+C -1 ; WX 556 ; N ntilde ; B -6 -9 504 655 ;
+C -1 ; WX 722 ; N Uhungarumlaut ; B 67 -18 744 904 ;
+C -1 ; WX 667 ; N Eacute ; B -27 0 653 904 ;
+C -1 ; WX 444 ; N emacron ; B 5 -13 439 623 ;
+C -1 ; WX 500 ; N gbreve ; B -52 -203 478 678 ;
+C -1 ; WX 750 ; N onequarter ; B 7 -14 721 683 ;
+C -1 ; WX 556 ; N Scaron ; B 2 -18 553 897 ;
+C -1 ; WX 556 ; N Scommaaccent ; B 2 -218 526 685 ;
+C -1 ; WX 722 ; N Ohungarumlaut ; B 27 -18 723 904 ;
+C -1 ; WX 400 ; N degree ; B 83 397 369 683 ;
+C -1 ; WX 500 ; N ograve ; B -3 -13 441 697 ;
+C -1 ; WX 667 ; N Ccaron ; B 32 -18 677 897 ;
+C -1 ; WX 556 ; N ugrave ; B 15 -9 492 697 ;
+C -1 ; WX 549 ; N radical ; B 10 -46 512 850 ;
+C -1 ; WX 722 ; N Dcaron ; B -46 0 685 897 ;
+C -1 ; WX 389 ; N rcommaaccent ; B -67 -218 389 462 ;
+C -1 ; WX 722 ; N Ntilde ; B -27 -15 748 862 ;
+C -1 ; WX 500 ; N otilde ; B -3 -13 491 655 ;
+C -1 ; WX 667 ; N Rcommaaccent ; B -29 -218 623 669 ;
+C -1 ; WX 611 ; N Lcommaaccent ; B -22 -218 590 669 ;
+C -1 ; WX 667 ; N Atilde ; B -67 0 593 862 ;
+C -1 ; WX 667 ; N Aogonek ; B -67 -183 604 683 ;
+C -1 ; WX 667 ; N Aring ; B -67 0 593 921 ;
+C -1 ; WX 722 ; N Otilde ; B 27 -18 691 862 ;
+C -1 ; WX 389 ; N zdotaccent ; B -43 -78 368 655 ;
+C -1 ; WX 667 ; N Ecaron ; B -27 0 653 897 ;
+C -1 ; WX 389 ; N Iogonek ; B -32 -183 406 669 ;
+C -1 ; WX 500 ; N kcommaaccent ; B -23 -218 483 699 ;
+C -1 ; WX 606 ; N minus ; B 51 209 555 297 ;
+C -1 ; WX 389 ; N Icircumflex ; B -32 0 450 897 ;
+C -1 ; WX 556 ; N ncaron ; B -6 -9 523 690 ;
+C -1 ; WX 278 ; N tcommaaccent ; B -62 -218 281 594 ;
+C -1 ; WX 606 ; N logicalnot ; B 51 108 555 399 ;
+C -1 ; WX 500 ; N odieresis ; B -3 -13 471 655 ;
+C -1 ; WX 556 ; N udieresis ; B 15 -9 499 655 ;
+C -1 ; WX 549 ; N notequal ; B 15 -49 540 570 ;
+C -1 ; WX 500 ; N gcommaaccent ; B -52 -203 478 767 ;
+C -1 ; WX 500 ; N eth ; B -3 -13 454 699 ;
+C -1 ; WX 389 ; N zcaron ; B -43 -78 424 690 ;
+C -1 ; WX 556 ; N ncommaaccent ; B -6 -218 493 462 ;
+C -1 ; WX 300 ; N onesuperior ; B 30 274 301 683 ;
+C -1 ; WX 278 ; N imacron ; B 2 -9 294 623 ;
+C -1 ; WX 500 ; N Euro ; B 0 0 0 0 ;
+EndCharMetrics
+StartKernData
+StartKernPairs 2038
+KPX A C -65
+KPX A Cacute -65
+KPX A Ccaron -65
+KPX A Ccedilla -65
+KPX A G -60
+KPX A Gbreve -60
+KPX A Gcommaaccent -60
+KPX A O -50
+KPX A Oacute -50
+KPX A Ocircumflex -50
+KPX A Odieresis -50
+KPX A Ograve -50
+KPX A Ohungarumlaut -50
+KPX A Omacron -50
+KPX A Oslash -50
+KPX A Otilde -50
+KPX A Q -55
+KPX A T -55
+KPX A Tcaron -55
+KPX A Tcommaaccent -55
+KPX A U -50
+KPX A Uacute -50
+KPX A Ucircumflex -50
+KPX A Udieresis -50
+KPX A Ugrave -50
+KPX A Uhungarumlaut -50
+KPX A Umacron -50
+KPX A Uogonek -50
+KPX A Uring -50
+KPX A V -95
+KPX A W -100
+KPX A Y -70
+KPX A Yacute -70
+KPX A Ydieresis -70
+KPX A quoteright -74
+KPX A u -30
+KPX A uacute -30
+KPX A ucircumflex -30
+KPX A udieresis -30
+KPX A ugrave -30
+KPX A uhungarumlaut -30
+KPX A umacron -30
+KPX A uogonek -30
+KPX A uring -30
+KPX A v -74
+KPX A w -74
+KPX A y -74
+KPX A yacute -74
+KPX A ydieresis -74
+KPX Aacute C -65
+KPX Aacute Cacute -65
+KPX Aacute Ccaron -65
+KPX Aacute Ccedilla -65
+KPX Aacute G -60
+KPX Aacute Gbreve -60
+KPX Aacute Gcommaaccent -60
+KPX Aacute O -50
+KPX Aacute Oacute -50
+KPX Aacute Ocircumflex -50
+KPX Aacute Odieresis -50
+KPX Aacute Ograve -50
+KPX Aacute Ohungarumlaut -50
+KPX Aacute Omacron -50
+KPX Aacute Oslash -50
+KPX Aacute Otilde -50
+KPX Aacute Q -55
+KPX Aacute T -55
+KPX Aacute Tcaron -55
+KPX Aacute Tcommaaccent -55
+KPX Aacute U -50
+KPX Aacute Uacute -50
+KPX Aacute Ucircumflex -50
+KPX Aacute Udieresis -50
+KPX Aacute Ugrave -50
+KPX Aacute Uhungarumlaut -50
+KPX Aacute Umacron -50
+KPX Aacute Uogonek -50
+KPX Aacute Uring -50
+KPX Aacute V -95
+KPX Aacute W -100
+KPX Aacute Y -70
+KPX Aacute Yacute -70
+KPX Aacute Ydieresis -70
+KPX Aacute quoteright -74
+KPX Aacute u -30
+KPX Aacute uacute -30
+KPX Aacute ucircumflex -30
+KPX Aacute udieresis -30
+KPX Aacute ugrave -30
+KPX Aacute uhungarumlaut -30
+KPX Aacute umacron -30
+KPX Aacute uogonek -30
+KPX Aacute uring -30
+KPX Aacute v -74
+KPX Aacute w -74
+KPX Aacute y -74
+KPX Aacute yacute -74
+KPX Aacute ydieresis -74
+KPX Abreve C -65
+KPX Abreve Cacute -65
+KPX Abreve Ccaron -65
+KPX Abreve Ccedilla -65
+KPX Abreve G -60
+KPX Abreve Gbreve -60
+KPX Abreve Gcommaaccent -60
+KPX Abreve O -50
+KPX Abreve Oacute -50
+KPX Abreve Ocircumflex -50
+KPX Abreve Odieresis -50
+KPX Abreve Ograve -50
+KPX Abreve Ohungarumlaut -50
+KPX Abreve Omacron -50
+KPX Abreve Oslash -50
+KPX Abreve Otilde -50
+KPX Abreve Q -55
+KPX Abreve T -55
+KPX Abreve Tcaron -55
+KPX Abreve Tcommaaccent -55
+KPX Abreve U -50
+KPX Abreve Uacute -50
+KPX Abreve Ucircumflex -50
+KPX Abreve Udieresis -50
+KPX Abreve Ugrave -50
+KPX Abreve Uhungarumlaut -50
+KPX Abreve Umacron -50
+KPX Abreve Uogonek -50
+KPX Abreve Uring -50
+KPX Abreve V -95
+KPX Abreve W -100
+KPX Abreve Y -70
+KPX Abreve Yacute -70
+KPX Abreve Ydieresis -70
+KPX Abreve quoteright -74
+KPX Abreve u -30
+KPX Abreve uacute -30
+KPX Abreve ucircumflex -30
+KPX Abreve udieresis -30
+KPX Abreve ugrave -30
+KPX Abreve uhungarumlaut -30
+KPX Abreve umacron -30
+KPX Abreve uogonek -30
+KPX Abreve uring -30
+KPX Abreve v -74
+KPX Abreve w -74
+KPX Abreve y -74
+KPX Abreve yacute -74
+KPX Abreve ydieresis -74
+KPX Acircumflex C -65
+KPX Acircumflex Cacute -65
+KPX Acircumflex Ccaron -65
+KPX Acircumflex Ccedilla -65
+KPX Acircumflex G -60
+KPX Acircumflex Gbreve -60
+KPX Acircumflex Gcommaaccent -60
+KPX Acircumflex O -50
+KPX Acircumflex Oacute -50
+KPX Acircumflex Ocircumflex -50
+KPX Acircumflex Odieresis -50
+KPX Acircumflex Ograve -50
+KPX Acircumflex Ohungarumlaut -50
+KPX Acircumflex Omacron -50
+KPX Acircumflex Oslash -50
+KPX Acircumflex Otilde -50
+KPX Acircumflex Q -55
+KPX Acircumflex T -55
+KPX Acircumflex Tcaron -55
+KPX Acircumflex Tcommaaccent -55
+KPX Acircumflex U -50
+KPX Acircumflex Uacute -50
+KPX Acircumflex Ucircumflex -50
+KPX Acircumflex Udieresis -50
+KPX Acircumflex Ugrave -50
+KPX Acircumflex Uhungarumlaut -50
+KPX Acircumflex Umacron -50
+KPX Acircumflex Uogonek -50
+KPX Acircumflex Uring -50
+KPX Acircumflex V -95
+KPX Acircumflex W -100
+KPX Acircumflex Y -70
+KPX Acircumflex Yacute -70
+KPX Acircumflex Ydieresis -70
+KPX Acircumflex quoteright -74
+KPX Acircumflex u -30
+KPX Acircumflex uacute -30
+KPX Acircumflex ucircumflex -30
+KPX Acircumflex udieresis -30
+KPX Acircumflex ugrave -30
+KPX Acircumflex uhungarumlaut -30
+KPX Acircumflex umacron -30
+KPX Acircumflex uogonek -30
+KPX Acircumflex uring -30
+KPX Acircumflex v -74
+KPX Acircumflex w -74
+KPX Acircumflex y -74
+KPX Acircumflex yacute -74
+KPX Acircumflex ydieresis -74
+KPX Adieresis C -65
+KPX Adieresis Cacute -65
+KPX Adieresis Ccaron -65
+KPX Adieresis Ccedilla -65
+KPX Adieresis G -60
+KPX Adieresis Gbreve -60
+KPX Adieresis Gcommaaccent -60
+KPX Adieresis O -50
+KPX Adieresis Oacute -50
+KPX Adieresis Ocircumflex -50
+KPX Adieresis Odieresis -50
+KPX Adieresis Ograve -50
+KPX Adieresis Ohungarumlaut -50
+KPX Adieresis Omacron -50
+KPX Adieresis Oslash -50
+KPX Adieresis Otilde -50
+KPX Adieresis Q -55
+KPX Adieresis T -55
+KPX Adieresis Tcaron -55
+KPX Adieresis Tcommaaccent -55
+KPX Adieresis U -50
+KPX Adieresis Uacute -50
+KPX Adieresis Ucircumflex -50
+KPX Adieresis Udieresis -50
+KPX Adieresis Ugrave -50
+KPX Adieresis Uhungarumlaut -50
+KPX Adieresis Umacron -50
+KPX Adieresis Uogonek -50
+KPX Adieresis Uring -50
+KPX Adieresis V -95
+KPX Adieresis W -100
+KPX Adieresis Y -70
+KPX Adieresis Yacute -70
+KPX Adieresis Ydieresis -70
+KPX Adieresis quoteright -74
+KPX Adieresis u -30
+KPX Adieresis uacute -30
+KPX Adieresis ucircumflex -30
+KPX Adieresis udieresis -30
+KPX Adieresis ugrave -30
+KPX Adieresis uhungarumlaut -30
+KPX Adieresis umacron -30
+KPX Adieresis uogonek -30
+KPX Adieresis uring -30
+KPX Adieresis v -74
+KPX Adieresis w -74
+KPX Adieresis y -74
+KPX Adieresis yacute -74
+KPX Adieresis ydieresis -74
+KPX Agrave C -65
+KPX Agrave Cacute -65
+KPX Agrave Ccaron -65
+KPX Agrave Ccedilla -65
+KPX Agrave G -60
+KPX Agrave Gbreve -60
+KPX Agrave Gcommaaccent -60
+KPX Agrave O -50
+KPX Agrave Oacute -50
+KPX Agrave Ocircumflex -50
+KPX Agrave Odieresis -50
+KPX Agrave Ograve -50
+KPX Agrave Ohungarumlaut -50
+KPX Agrave Omacron -50
+KPX Agrave Oslash -50
+KPX Agrave Otilde -50
+KPX Agrave Q -55
+KPX Agrave T -55
+KPX Agrave Tcaron -55
+KPX Agrave Tcommaaccent -55
+KPX Agrave U -50
+KPX Agrave Uacute -50
+KPX Agrave Ucircumflex -50
+KPX Agrave Udieresis -50
+KPX Agrave Ugrave -50
+KPX Agrave Uhungarumlaut -50
+KPX Agrave Umacron -50
+KPX Agrave Uogonek -50
+KPX Agrave Uring -50
+KPX Agrave V -95
+KPX Agrave W -100
+KPX Agrave Y -70
+KPX Agrave Yacute -70
+KPX Agrave Ydieresis -70
+KPX Agrave quoteright -74
+KPX Agrave u -30
+KPX Agrave uacute -30
+KPX Agrave ucircumflex -30
+KPX Agrave udieresis -30
+KPX Agrave ugrave -30
+KPX Agrave uhungarumlaut -30
+KPX Agrave umacron -30
+KPX Agrave uogonek -30
+KPX Agrave uring -30
+KPX Agrave v -74
+KPX Agrave w -74
+KPX Agrave y -74
+KPX Agrave yacute -74
+KPX Agrave ydieresis -74
+KPX Amacron C -65
+KPX Amacron Cacute -65
+KPX Amacron Ccaron -65
+KPX Amacron Ccedilla -65
+KPX Amacron G -60
+KPX Amacron Gbreve -60
+KPX Amacron Gcommaaccent -60
+KPX Amacron O -50
+KPX Amacron Oacute -50
+KPX Amacron Ocircumflex -50
+KPX Amacron Odieresis -50
+KPX Amacron Ograve -50
+KPX Amacron Ohungarumlaut -50
+KPX Amacron Omacron -50
+KPX Amacron Oslash -50
+KPX Amacron Otilde -50
+KPX Amacron Q -55
+KPX Amacron T -55
+KPX Amacron Tcaron -55
+KPX Amacron Tcommaaccent -55
+KPX Amacron U -50
+KPX Amacron Uacute -50
+KPX Amacron Ucircumflex -50
+KPX Amacron Udieresis -50
+KPX Amacron Ugrave -50
+KPX Amacron Uhungarumlaut -50
+KPX Amacron Umacron -50
+KPX Amacron Uogonek -50
+KPX Amacron Uring -50
+KPX Amacron V -95
+KPX Amacron W -100
+KPX Amacron Y -70
+KPX Amacron Yacute -70
+KPX Amacron Ydieresis -70
+KPX Amacron quoteright -74
+KPX Amacron u -30
+KPX Amacron uacute -30
+KPX Amacron ucircumflex -30
+KPX Amacron udieresis -30
+KPX Amacron ugrave -30
+KPX Amacron uhungarumlaut -30
+KPX Amacron umacron -30
+KPX Amacron uogonek -30
+KPX Amacron uring -30
+KPX Amacron v -74
+KPX Amacron w -74
+KPX Amacron y -74
+KPX Amacron yacute -74
+KPX Amacron ydieresis -74
+KPX Aogonek C -65
+KPX Aogonek Cacute -65
+KPX Aogonek Ccaron -65
+KPX Aogonek Ccedilla -65
+KPX Aogonek G -60
+KPX Aogonek Gbreve -60
+KPX Aogonek Gcommaaccent -60
+KPX Aogonek O -50
+KPX Aogonek Oacute -50
+KPX Aogonek Ocircumflex -50
+KPX Aogonek Odieresis -50
+KPX Aogonek Ograve -50
+KPX Aogonek Ohungarumlaut -50
+KPX Aogonek Omacron -50
+KPX Aogonek Oslash -50
+KPX Aogonek Otilde -50
+KPX Aogonek Q -55
+KPX Aogonek T -55
+KPX Aogonek Tcaron -55
+KPX Aogonek Tcommaaccent -55
+KPX Aogonek U -50
+KPX Aogonek Uacute -50
+KPX Aogonek Ucircumflex -50
+KPX Aogonek Udieresis -50
+KPX Aogonek Ugrave -50
+KPX Aogonek Uhungarumlaut -50
+KPX Aogonek Umacron -50
+KPX Aogonek Uogonek -50
+KPX Aogonek Uring -50
+KPX Aogonek V -95
+KPX Aogonek W -100
+KPX Aogonek Y -70
+KPX Aogonek Yacute -70
+KPX Aogonek Ydieresis -70
+KPX Aogonek quoteright -74
+KPX Aogonek u -30
+KPX Aogonek uacute -30
+KPX Aogonek ucircumflex -30
+KPX Aogonek udieresis -30
+KPX Aogonek ugrave -30
+KPX Aogonek uhungarumlaut -30
+KPX Aogonek umacron -30
+KPX Aogonek uogonek -30
+KPX Aogonek uring -30
+KPX Aogonek v -74
+KPX Aogonek w -74
+KPX Aogonek y -34
+KPX Aogonek yacute -34
+KPX Aogonek ydieresis -34
+KPX Aring C -65
+KPX Aring Cacute -65
+KPX Aring Ccaron -65
+KPX Aring Ccedilla -65
+KPX Aring G -60
+KPX Aring Gbreve -60
+KPX Aring Gcommaaccent -60
+KPX Aring O -50
+KPX Aring Oacute -50
+KPX Aring Ocircumflex -50
+KPX Aring Odieresis -50
+KPX Aring Ograve -50
+KPX Aring Ohungarumlaut -50
+KPX Aring Omacron -50
+KPX Aring Oslash -50
+KPX Aring Otilde -50
+KPX Aring Q -55
+KPX Aring T -55
+KPX Aring Tcaron -55
+KPX Aring Tcommaaccent -55
+KPX Aring U -50
+KPX Aring Uacute -50
+KPX Aring Ucircumflex -50
+KPX Aring Udieresis -50
+KPX Aring Ugrave -50
+KPX Aring Uhungarumlaut -50
+KPX Aring Umacron -50
+KPX Aring Uogonek -50
+KPX Aring Uring -50
+KPX Aring V -95
+KPX Aring W -100
+KPX Aring Y -70
+KPX Aring Yacute -70
+KPX Aring Ydieresis -70
+KPX Aring quoteright -74
+KPX Aring u -30
+KPX Aring uacute -30
+KPX Aring ucircumflex -30
+KPX Aring udieresis -30
+KPX Aring ugrave -30
+KPX Aring uhungarumlaut -30
+KPX Aring umacron -30
+KPX Aring uogonek -30
+KPX Aring uring -30
+KPX Aring v -74
+KPX Aring w -74
+KPX Aring y -74
+KPX Aring yacute -74
+KPX Aring ydieresis -74
+KPX Atilde C -65
+KPX Atilde Cacute -65
+KPX Atilde Ccaron -65
+KPX Atilde Ccedilla -65
+KPX Atilde G -60
+KPX Atilde Gbreve -60
+KPX Atilde Gcommaaccent -60
+KPX Atilde O -50
+KPX Atilde Oacute -50
+KPX Atilde Ocircumflex -50
+KPX Atilde Odieresis -50
+KPX Atilde Ograve -50
+KPX Atilde Ohungarumlaut -50
+KPX Atilde Omacron -50
+KPX Atilde Oslash -50
+KPX Atilde Otilde -50
+KPX Atilde Q -55
+KPX Atilde T -55
+KPX Atilde Tcaron -55
+KPX Atilde Tcommaaccent -55
+KPX Atilde U -50
+KPX Atilde Uacute -50
+KPX Atilde Ucircumflex -50
+KPX Atilde Udieresis -50
+KPX Atilde Ugrave -50
+KPX Atilde Uhungarumlaut -50
+KPX Atilde Umacron -50
+KPX Atilde Uogonek -50
+KPX Atilde Uring -50
+KPX Atilde V -95
+KPX Atilde W -100
+KPX Atilde Y -70
+KPX Atilde Yacute -70
+KPX Atilde Ydieresis -70
+KPX Atilde quoteright -74
+KPX Atilde u -30
+KPX Atilde uacute -30
+KPX Atilde ucircumflex -30
+KPX Atilde udieresis -30
+KPX Atilde ugrave -30
+KPX Atilde uhungarumlaut -30
+KPX Atilde umacron -30
+KPX Atilde uogonek -30
+KPX Atilde uring -30
+KPX Atilde v -74
+KPX Atilde w -74
+KPX Atilde y -74
+KPX Atilde yacute -74
+KPX Atilde ydieresis -74
+KPX B A -25
+KPX B Aacute -25
+KPX B Abreve -25
+KPX B Acircumflex -25
+KPX B Adieresis -25
+KPX B Agrave -25
+KPX B Amacron -25
+KPX B Aogonek -25
+KPX B Aring -25
+KPX B Atilde -25
+KPX B U -10
+KPX B Uacute -10
+KPX B Ucircumflex -10
+KPX B Udieresis -10
+KPX B Ugrave -10
+KPX B Uhungarumlaut -10
+KPX B Umacron -10
+KPX B Uogonek -10
+KPX B Uring -10
+KPX D A -25
+KPX D Aacute -25
+KPX D Abreve -25
+KPX D Acircumflex -25
+KPX D Adieresis -25
+KPX D Agrave -25
+KPX D Amacron -25
+KPX D Aogonek -25
+KPX D Aring -25
+KPX D Atilde -25
+KPX D V -50
+KPX D W -40
+KPX D Y -50
+KPX D Yacute -50
+KPX D Ydieresis -50
+KPX Dcaron A -25
+KPX Dcaron Aacute -25
+KPX Dcaron Abreve -25
+KPX Dcaron Acircumflex -25
+KPX Dcaron Adieresis -25
+KPX Dcaron Agrave -25
+KPX Dcaron Amacron -25
+KPX Dcaron Aogonek -25
+KPX Dcaron Aring -25
+KPX Dcaron Atilde -25
+KPX Dcaron V -50
+KPX Dcaron W -40
+KPX Dcaron Y -50
+KPX Dcaron Yacute -50
+KPX Dcaron Ydieresis -50
+KPX Dcroat A -25
+KPX Dcroat Aacute -25
+KPX Dcroat Abreve -25
+KPX Dcroat Acircumflex -25
+KPX Dcroat Adieresis -25
+KPX Dcroat Agrave -25
+KPX Dcroat Amacron -25
+KPX Dcroat Aogonek -25
+KPX Dcroat Aring -25
+KPX Dcroat Atilde -25
+KPX Dcroat V -50
+KPX Dcroat W -40
+KPX Dcroat Y -50
+KPX Dcroat Yacute -50
+KPX Dcroat Ydieresis -50
+KPX F A -100
+KPX F Aacute -100
+KPX F Abreve -100
+KPX F Acircumflex -100
+KPX F Adieresis -100
+KPX F Agrave -100
+KPX F Amacron -100
+KPX F Aogonek -100
+KPX F Aring -100
+KPX F Atilde -100
+KPX F a -95
+KPX F aacute -95
+KPX F abreve -95
+KPX F acircumflex -95
+KPX F adieresis -95
+KPX F agrave -95
+KPX F amacron -95
+KPX F aogonek -95
+KPX F aring -95
+KPX F atilde -95
+KPX F comma -129
+KPX F e -100
+KPX F eacute -100
+KPX F ecaron -100
+KPX F ecircumflex -100
+KPX F edieresis -100
+KPX F edotaccent -100
+KPX F egrave -100
+KPX F emacron -100
+KPX F eogonek -100
+KPX F i -40
+KPX F iacute -40
+KPX F icircumflex -40
+KPX F idieresis -40
+KPX F igrave -40
+KPX F imacron -40
+KPX F iogonek -40
+KPX F o -70
+KPX F oacute -70
+KPX F ocircumflex -70
+KPX F odieresis -70
+KPX F ograve -70
+KPX F ohungarumlaut -70
+KPX F omacron -70
+KPX F oslash -70
+KPX F otilde -70
+KPX F period -129
+KPX F r -50
+KPX F racute -50
+KPX F rcaron -50
+KPX F rcommaaccent -50
+KPX J A -25
+KPX J Aacute -25
+KPX J Abreve -25
+KPX J Acircumflex -25
+KPX J Adieresis -25
+KPX J Agrave -25
+KPX J Amacron -25
+KPX J Aogonek -25
+KPX J Aring -25
+KPX J Atilde -25
+KPX J a -40
+KPX J aacute -40
+KPX J abreve -40
+KPX J acircumflex -40
+KPX J adieresis -40
+KPX J agrave -40
+KPX J amacron -40
+KPX J aogonek -40
+KPX J aring -40
+KPX J atilde -40
+KPX J comma -10
+KPX J e -40
+KPX J eacute -40
+KPX J ecaron -40
+KPX J ecircumflex -40
+KPX J edieresis -40
+KPX J edotaccent -40
+KPX J egrave -40
+KPX J emacron -40
+KPX J eogonek -40
+KPX J o -40
+KPX J oacute -40
+KPX J ocircumflex -40
+KPX J odieresis -40
+KPX J ograve -40
+KPX J ohungarumlaut -40
+KPX J omacron -40
+KPX J oslash -40
+KPX J otilde -40
+KPX J period -10
+KPX J u -40
+KPX J uacute -40
+KPX J ucircumflex -40
+KPX J udieresis -40
+KPX J ugrave -40
+KPX J uhungarumlaut -40
+KPX J umacron -40
+KPX J uogonek -40
+KPX J uring -40
+KPX K O -30
+KPX K Oacute -30
+KPX K Ocircumflex -30
+KPX K Odieresis -30
+KPX K Ograve -30
+KPX K Ohungarumlaut -30
+KPX K Omacron -30
+KPX K Oslash -30
+KPX K Otilde -30
+KPX K e -25
+KPX K eacute -25
+KPX K ecaron -25
+KPX K ecircumflex -25
+KPX K edieresis -25
+KPX K edotaccent -25
+KPX K egrave -25
+KPX K emacron -25
+KPX K eogonek -25
+KPX K o -25
+KPX K oacute -25
+KPX K ocircumflex -25
+KPX K odieresis -25
+KPX K ograve -25
+KPX K ohungarumlaut -25
+KPX K omacron -25
+KPX K oslash -25
+KPX K otilde -25
+KPX K u -20
+KPX K uacute -20
+KPX K ucircumflex -20
+KPX K udieresis -20
+KPX K ugrave -20
+KPX K uhungarumlaut -20
+KPX K umacron -20
+KPX K uogonek -20
+KPX K uring -20
+KPX K y -20
+KPX K yacute -20
+KPX K ydieresis -20
+KPX Kcommaaccent O -30
+KPX Kcommaaccent Oacute -30
+KPX Kcommaaccent Ocircumflex -30
+KPX Kcommaaccent Odieresis -30
+KPX Kcommaaccent Ograve -30
+KPX Kcommaaccent Ohungarumlaut -30
+KPX Kcommaaccent Omacron -30
+KPX Kcommaaccent Oslash -30
+KPX Kcommaaccent Otilde -30
+KPX Kcommaaccent e -25
+KPX Kcommaaccent eacute -25
+KPX Kcommaaccent ecaron -25
+KPX Kcommaaccent ecircumflex -25
+KPX Kcommaaccent edieresis -25
+KPX Kcommaaccent edotaccent -25
+KPX Kcommaaccent egrave -25
+KPX Kcommaaccent emacron -25
+KPX Kcommaaccent eogonek -25
+KPX Kcommaaccent o -25
+KPX Kcommaaccent oacute -25
+KPX Kcommaaccent ocircumflex -25
+KPX Kcommaaccent odieresis -25
+KPX Kcommaaccent ograve -25
+KPX Kcommaaccent ohungarumlaut -25
+KPX Kcommaaccent omacron -25
+KPX Kcommaaccent oslash -25
+KPX Kcommaaccent otilde -25
+KPX Kcommaaccent u -20
+KPX Kcommaaccent uacute -20
+KPX Kcommaaccent ucircumflex -20
+KPX Kcommaaccent udieresis -20
+KPX Kcommaaccent ugrave -20
+KPX Kcommaaccent uhungarumlaut -20
+KPX Kcommaaccent umacron -20
+KPX Kcommaaccent uogonek -20
+KPX Kcommaaccent uring -20
+KPX Kcommaaccent y -20
+KPX Kcommaaccent yacute -20
+KPX Kcommaaccent ydieresis -20
+KPX L T -18
+KPX L Tcaron -18
+KPX L Tcommaaccent -18
+KPX L V -37
+KPX L W -37
+KPX L Y -37
+KPX L Yacute -37
+KPX L Ydieresis -37
+KPX L quoteright -55
+KPX L y -37
+KPX L yacute -37
+KPX L ydieresis -37
+KPX Lacute T -18
+KPX Lacute Tcaron -18
+KPX Lacute Tcommaaccent -18
+KPX Lacute V -37
+KPX Lacute W -37
+KPX Lacute Y -37
+KPX Lacute Yacute -37
+KPX Lacute Ydieresis -37
+KPX Lacute quoteright -55
+KPX Lacute y -37
+KPX Lacute yacute -37
+KPX Lacute ydieresis -37
+KPX Lcommaaccent T -18
+KPX Lcommaaccent Tcaron -18
+KPX Lcommaaccent Tcommaaccent -18
+KPX Lcommaaccent V -37
+KPX Lcommaaccent W -37
+KPX Lcommaaccent Y -37
+KPX Lcommaaccent Yacute -37
+KPX Lcommaaccent Ydieresis -37
+KPX Lcommaaccent quoteright -55
+KPX Lcommaaccent y -37
+KPX Lcommaaccent yacute -37
+KPX Lcommaaccent ydieresis -37
+KPX Lslash T -18
+KPX Lslash Tcaron -18
+KPX Lslash Tcommaaccent -18
+KPX Lslash V -37
+KPX Lslash W -37
+KPX Lslash Y -37
+KPX Lslash Yacute -37
+KPX Lslash Ydieresis -37
+KPX Lslash quoteright -55
+KPX Lslash y -37
+KPX Lslash yacute -37
+KPX Lslash ydieresis -37
+KPX N A -30
+KPX N Aacute -30
+KPX N Abreve -30
+KPX N Acircumflex -30
+KPX N Adieresis -30
+KPX N Agrave -30
+KPX N Amacron -30
+KPX N Aogonek -30
+KPX N Aring -30
+KPX N Atilde -30
+KPX Nacute A -30
+KPX Nacute Aacute -30
+KPX Nacute Abreve -30
+KPX Nacute Acircumflex -30
+KPX Nacute Adieresis -30
+KPX Nacute Agrave -30
+KPX Nacute Amacron -30
+KPX Nacute Aogonek -30
+KPX Nacute Aring -30
+KPX Nacute Atilde -30
+KPX Ncaron A -30
+KPX Ncaron Aacute -30
+KPX Ncaron Abreve -30
+KPX Ncaron Acircumflex -30
+KPX Ncaron Adieresis -30
+KPX Ncaron Agrave -30
+KPX Ncaron Amacron -30
+KPX Ncaron Aogonek -30
+KPX Ncaron Aring -30
+KPX Ncaron Atilde -30
+KPX Ncommaaccent A -30
+KPX Ncommaaccent Aacute -30
+KPX Ncommaaccent Abreve -30
+KPX Ncommaaccent Acircumflex -30
+KPX Ncommaaccent Adieresis -30
+KPX Ncommaaccent Agrave -30
+KPX Ncommaaccent Amacron -30
+KPX Ncommaaccent Aogonek -30
+KPX Ncommaaccent Aring -30
+KPX Ncommaaccent Atilde -30
+KPX Ntilde A -30
+KPX Ntilde Aacute -30
+KPX Ntilde Abreve -30
+KPX Ntilde Acircumflex -30
+KPX Ntilde Adieresis -30
+KPX Ntilde Agrave -30
+KPX Ntilde Amacron -30
+KPX Ntilde Aogonek -30
+KPX Ntilde Aring -30
+KPX Ntilde Atilde -30
+KPX O A -40
+KPX O Aacute -40
+KPX O Abreve -40
+KPX O Acircumflex -40
+KPX O Adieresis -40
+KPX O Agrave -40
+KPX O Amacron -40
+KPX O Aogonek -40
+KPX O Aring -40
+KPX O Atilde -40
+KPX O T -40
+KPX O Tcaron -40
+KPX O Tcommaaccent -40
+KPX O V -50
+KPX O W -50
+KPX O X -40
+KPX O Y -50
+KPX O Yacute -50
+KPX O Ydieresis -50
+KPX Oacute A -40
+KPX Oacute Aacute -40
+KPX Oacute Abreve -40
+KPX Oacute Acircumflex -40
+KPX Oacute Adieresis -40
+KPX Oacute Agrave -40
+KPX Oacute Amacron -40
+KPX Oacute Aogonek -40
+KPX Oacute Aring -40
+KPX Oacute Atilde -40
+KPX Oacute T -40
+KPX Oacute Tcaron -40
+KPX Oacute Tcommaaccent -40
+KPX Oacute V -50
+KPX Oacute W -50
+KPX Oacute X -40
+KPX Oacute Y -50
+KPX Oacute Yacute -50
+KPX Oacute Ydieresis -50
+KPX Ocircumflex A -40
+KPX Ocircumflex Aacute -40
+KPX Ocircumflex Abreve -40
+KPX Ocircumflex Acircumflex -40
+KPX Ocircumflex Adieresis -40
+KPX Ocircumflex Agrave -40
+KPX Ocircumflex Amacron -40
+KPX Ocircumflex Aogonek -40
+KPX Ocircumflex Aring -40
+KPX Ocircumflex Atilde -40
+KPX Ocircumflex T -40
+KPX Ocircumflex Tcaron -40
+KPX Ocircumflex Tcommaaccent -40
+KPX Ocircumflex V -50
+KPX Ocircumflex W -50
+KPX Ocircumflex X -40
+KPX Ocircumflex Y -50
+KPX Ocircumflex Yacute -50
+KPX Ocircumflex Ydieresis -50
+KPX Odieresis A -40
+KPX Odieresis Aacute -40
+KPX Odieresis Abreve -40
+KPX Odieresis Acircumflex -40
+KPX Odieresis Adieresis -40
+KPX Odieresis Agrave -40
+KPX Odieresis Amacron -40
+KPX Odieresis Aogonek -40
+KPX Odieresis Aring -40
+KPX Odieresis Atilde -40
+KPX Odieresis T -40
+KPX Odieresis Tcaron -40
+KPX Odieresis Tcommaaccent -40
+KPX Odieresis V -50
+KPX Odieresis W -50
+KPX Odieresis X -40
+KPX Odieresis Y -50
+KPX Odieresis Yacute -50
+KPX Odieresis Ydieresis -50
+KPX Ograve A -40
+KPX Ograve Aacute -40
+KPX Ograve Abreve -40
+KPX Ograve Acircumflex -40
+KPX Ograve Adieresis -40
+KPX Ograve Agrave -40
+KPX Ograve Amacron -40
+KPX Ograve Aogonek -40
+KPX Ograve Aring -40
+KPX Ograve Atilde -40
+KPX Ograve T -40
+KPX Ograve Tcaron -40
+KPX Ograve Tcommaaccent -40
+KPX Ograve V -50
+KPX Ograve W -50
+KPX Ograve X -40
+KPX Ograve Y -50
+KPX Ograve Yacute -50
+KPX Ograve Ydieresis -50
+KPX Ohungarumlaut A -40
+KPX Ohungarumlaut Aacute -40
+KPX Ohungarumlaut Abreve -40
+KPX Ohungarumlaut Acircumflex -40
+KPX Ohungarumlaut Adieresis -40
+KPX Ohungarumlaut Agrave -40
+KPX Ohungarumlaut Amacron -40
+KPX Ohungarumlaut Aogonek -40
+KPX Ohungarumlaut Aring -40
+KPX Ohungarumlaut Atilde -40
+KPX Ohungarumlaut T -40
+KPX Ohungarumlaut Tcaron -40
+KPX Ohungarumlaut Tcommaaccent -40
+KPX Ohungarumlaut V -50
+KPX Ohungarumlaut W -50
+KPX Ohungarumlaut X -40
+KPX Ohungarumlaut Y -50
+KPX Ohungarumlaut Yacute -50
+KPX Ohungarumlaut Ydieresis -50
+KPX Omacron A -40
+KPX Omacron Aacute -40
+KPX Omacron Abreve -40
+KPX Omacron Acircumflex -40
+KPX Omacron Adieresis -40
+KPX Omacron Agrave -40
+KPX Omacron Amacron -40
+KPX Omacron Aogonek -40
+KPX Omacron Aring -40
+KPX Omacron Atilde -40
+KPX Omacron T -40
+KPX Omacron Tcaron -40
+KPX Omacron Tcommaaccent -40
+KPX Omacron V -50
+KPX Omacron W -50
+KPX Omacron X -40
+KPX Omacron Y -50
+KPX Omacron Yacute -50
+KPX Omacron Ydieresis -50
+KPX Oslash A -40
+KPX Oslash Aacute -40
+KPX Oslash Abreve -40
+KPX Oslash Acircumflex -40
+KPX Oslash Adieresis -40
+KPX Oslash Agrave -40
+KPX Oslash Amacron -40
+KPX Oslash Aogonek -40
+KPX Oslash Aring -40
+KPX Oslash Atilde -40
+KPX Oslash T -40
+KPX Oslash Tcaron -40
+KPX Oslash Tcommaaccent -40
+KPX Oslash V -50
+KPX Oslash W -50
+KPX Oslash X -40
+KPX Oslash Y -50
+KPX Oslash Yacute -50
+KPX Oslash Ydieresis -50
+KPX Otilde A -40
+KPX Otilde Aacute -40
+KPX Otilde Abreve -40
+KPX Otilde Acircumflex -40
+KPX Otilde Adieresis -40
+KPX Otilde Agrave -40
+KPX Otilde Amacron -40
+KPX Otilde Aogonek -40
+KPX Otilde Aring -40
+KPX Otilde Atilde -40
+KPX Otilde T -40
+KPX Otilde Tcaron -40
+KPX Otilde Tcommaaccent -40
+KPX Otilde V -50
+KPX Otilde W -50
+KPX Otilde X -40
+KPX Otilde Y -50
+KPX Otilde Yacute -50
+KPX Otilde Ydieresis -50
+KPX P A -85
+KPX P Aacute -85
+KPX P Abreve -85
+KPX P Acircumflex -85
+KPX P Adieresis -85
+KPX P Agrave -85
+KPX P Amacron -85
+KPX P Aogonek -85
+KPX P Aring -85
+KPX P Atilde -85
+KPX P a -40
+KPX P aacute -40
+KPX P abreve -40
+KPX P acircumflex -40
+KPX P adieresis -40
+KPX P agrave -40
+KPX P amacron -40
+KPX P aogonek -40
+KPX P aring -40
+KPX P atilde -40
+KPX P comma -129
+KPX P e -50
+KPX P eacute -50
+KPX P ecaron -50
+KPX P ecircumflex -50
+KPX P edieresis -50
+KPX P edotaccent -50
+KPX P egrave -50
+KPX P emacron -50
+KPX P eogonek -50
+KPX P o -55
+KPX P oacute -55
+KPX P ocircumflex -55
+KPX P odieresis -55
+KPX P ograve -55
+KPX P ohungarumlaut -55
+KPX P omacron -55
+KPX P oslash -55
+KPX P otilde -55
+KPX P period -129
+KPX Q U -10
+KPX Q Uacute -10
+KPX Q Ucircumflex -10
+KPX Q Udieresis -10
+KPX Q Ugrave -10
+KPX Q Uhungarumlaut -10
+KPX Q Umacron -10
+KPX Q Uogonek -10
+KPX Q Uring -10
+KPX R O -40
+KPX R Oacute -40
+KPX R Ocircumflex -40
+KPX R Odieresis -40
+KPX R Ograve -40
+KPX R Ohungarumlaut -40
+KPX R Omacron -40
+KPX R Oslash -40
+KPX R Otilde -40
+KPX R T -30
+KPX R Tcaron -30
+KPX R Tcommaaccent -30
+KPX R U -40
+KPX R Uacute -40
+KPX R Ucircumflex -40
+KPX R Udieresis -40
+KPX R Ugrave -40
+KPX R Uhungarumlaut -40
+KPX R Umacron -40
+KPX R Uogonek -40
+KPX R Uring -40
+KPX R V -18
+KPX R W -18
+KPX R Y -18
+KPX R Yacute -18
+KPX R Ydieresis -18
+KPX Racute O -40
+KPX Racute Oacute -40
+KPX Racute Ocircumflex -40
+KPX Racute Odieresis -40
+KPX Racute Ograve -40
+KPX Racute Ohungarumlaut -40
+KPX Racute Omacron -40
+KPX Racute Oslash -40
+KPX Racute Otilde -40
+KPX Racute T -30
+KPX Racute Tcaron -30
+KPX Racute Tcommaaccent -30
+KPX Racute U -40
+KPX Racute Uacute -40
+KPX Racute Ucircumflex -40
+KPX Racute Udieresis -40
+KPX Racute Ugrave -40
+KPX Racute Uhungarumlaut -40
+KPX Racute Umacron -40
+KPX Racute Uogonek -40
+KPX Racute Uring -40
+KPX Racute V -18
+KPX Racute W -18
+KPX Racute Y -18
+KPX Racute Yacute -18
+KPX Racute Ydieresis -18
+KPX Rcaron O -40
+KPX Rcaron Oacute -40
+KPX Rcaron Ocircumflex -40
+KPX Rcaron Odieresis -40
+KPX Rcaron Ograve -40
+KPX Rcaron Ohungarumlaut -40
+KPX Rcaron Omacron -40
+KPX Rcaron Oslash -40
+KPX Rcaron Otilde -40
+KPX Rcaron T -30
+KPX Rcaron Tcaron -30
+KPX Rcaron Tcommaaccent -30
+KPX Rcaron U -40
+KPX Rcaron Uacute -40
+KPX Rcaron Ucircumflex -40
+KPX Rcaron Udieresis -40
+KPX Rcaron Ugrave -40
+KPX Rcaron Uhungarumlaut -40
+KPX Rcaron Umacron -40
+KPX Rcaron Uogonek -40
+KPX Rcaron Uring -40
+KPX Rcaron V -18
+KPX Rcaron W -18
+KPX Rcaron Y -18
+KPX Rcaron Yacute -18
+KPX Rcaron Ydieresis -18
+KPX Rcommaaccent O -40
+KPX Rcommaaccent Oacute -40
+KPX Rcommaaccent Ocircumflex -40
+KPX Rcommaaccent Odieresis -40
+KPX Rcommaaccent Ograve -40
+KPX Rcommaaccent Ohungarumlaut -40
+KPX Rcommaaccent Omacron -40
+KPX Rcommaaccent Oslash -40
+KPX Rcommaaccent Otilde -40
+KPX Rcommaaccent T -30
+KPX Rcommaaccent Tcaron -30
+KPX Rcommaaccent Tcommaaccent -30
+KPX Rcommaaccent U -40
+KPX Rcommaaccent Uacute -40
+KPX Rcommaaccent Ucircumflex -40
+KPX Rcommaaccent Udieresis -40
+KPX Rcommaaccent Ugrave -40
+KPX Rcommaaccent Uhungarumlaut -40
+KPX Rcommaaccent Umacron -40
+KPX Rcommaaccent Uogonek -40
+KPX Rcommaaccent Uring -40
+KPX Rcommaaccent V -18
+KPX Rcommaaccent W -18
+KPX Rcommaaccent Y -18
+KPX Rcommaaccent Yacute -18
+KPX Rcommaaccent Ydieresis -18
+KPX T A -55
+KPX T Aacute -55
+KPX T Abreve -55
+KPX T Acircumflex -55
+KPX T Adieresis -55
+KPX T Agrave -55
+KPX T Amacron -55
+KPX T Aogonek -55
+KPX T Aring -55
+KPX T Atilde -55
+KPX T O -18
+KPX T Oacute -18
+KPX T Ocircumflex -18
+KPX T Odieresis -18
+KPX T Ograve -18
+KPX T Ohungarumlaut -18
+KPX T Omacron -18
+KPX T Oslash -18
+KPX T Otilde -18
+KPX T a -92
+KPX T aacute -92
+KPX T abreve -92
+KPX T acircumflex -92
+KPX T adieresis -92
+KPX T agrave -92
+KPX T amacron -92
+KPX T aogonek -92
+KPX T aring -92
+KPX T atilde -92
+KPX T colon -74
+KPX T comma -92
+KPX T e -92
+KPX T eacute -92
+KPX T ecaron -92
+KPX T ecircumflex -92
+KPX T edieresis -52
+KPX T edotaccent -92
+KPX T egrave -52
+KPX T emacron -52
+KPX T eogonek -92
+KPX T hyphen -92
+KPX T i -37
+KPX T iacute -37
+KPX T iogonek -37
+KPX T o -95
+KPX T oacute -95
+KPX T ocircumflex -95
+KPX T odieresis -95
+KPX T ograve -95
+KPX T ohungarumlaut -95
+KPX T omacron -95
+KPX T oslash -95
+KPX T otilde -95
+KPX T period -92
+KPX T r -37
+KPX T racute -37
+KPX T rcaron -37
+KPX T rcommaaccent -37
+KPX T semicolon -74
+KPX T u -37
+KPX T uacute -37
+KPX T ucircumflex -37
+KPX T udieresis -37
+KPX T ugrave -37
+KPX T uhungarumlaut -37
+KPX T umacron -37
+KPX T uogonek -37
+KPX T uring -37
+KPX T w -37
+KPX T y -37
+KPX T yacute -37
+KPX T ydieresis -37
+KPX Tcaron A -55
+KPX Tcaron Aacute -55
+KPX Tcaron Abreve -55
+KPX Tcaron Acircumflex -55
+KPX Tcaron Adieresis -55
+KPX Tcaron Agrave -55
+KPX Tcaron Amacron -55
+KPX Tcaron Aogonek -55
+KPX Tcaron Aring -55
+KPX Tcaron Atilde -55
+KPX Tcaron O -18
+KPX Tcaron Oacute -18
+KPX Tcaron Ocircumflex -18
+KPX Tcaron Odieresis -18
+KPX Tcaron Ograve -18
+KPX Tcaron Ohungarumlaut -18
+KPX Tcaron Omacron -18
+KPX Tcaron Oslash -18
+KPX Tcaron Otilde -18
+KPX Tcaron a -92
+KPX Tcaron aacute -92
+KPX Tcaron abreve -92
+KPX Tcaron acircumflex -92
+KPX Tcaron adieresis -92
+KPX Tcaron agrave -92
+KPX Tcaron amacron -92
+KPX Tcaron aogonek -92
+KPX Tcaron aring -92
+KPX Tcaron atilde -92
+KPX Tcaron colon -74
+KPX Tcaron comma -92
+KPX Tcaron e -92
+KPX Tcaron eacute -92
+KPX Tcaron ecaron -92
+KPX Tcaron ecircumflex -92
+KPX Tcaron edieresis -52
+KPX Tcaron edotaccent -92
+KPX Tcaron egrave -52
+KPX Tcaron emacron -52
+KPX Tcaron eogonek -92
+KPX Tcaron hyphen -92
+KPX Tcaron i -37
+KPX Tcaron iacute -37
+KPX Tcaron iogonek -37
+KPX Tcaron o -95
+KPX Tcaron oacute -95
+KPX Tcaron ocircumflex -95
+KPX Tcaron odieresis -95
+KPX Tcaron ograve -95
+KPX Tcaron ohungarumlaut -95
+KPX Tcaron omacron -95
+KPX Tcaron oslash -95
+KPX Tcaron otilde -95
+KPX Tcaron period -92
+KPX Tcaron r -37
+KPX Tcaron racute -37
+KPX Tcaron rcaron -37
+KPX Tcaron rcommaaccent -37
+KPX Tcaron semicolon -74
+KPX Tcaron u -37
+KPX Tcaron uacute -37
+KPX Tcaron ucircumflex -37
+KPX Tcaron udieresis -37
+KPX Tcaron ugrave -37
+KPX Tcaron uhungarumlaut -37
+KPX Tcaron umacron -37
+KPX Tcaron uogonek -37
+KPX Tcaron uring -37
+KPX Tcaron w -37
+KPX Tcaron y -37
+KPX Tcaron yacute -37
+KPX Tcaron ydieresis -37
+KPX Tcommaaccent A -55
+KPX Tcommaaccent Aacute -55
+KPX Tcommaaccent Abreve -55
+KPX Tcommaaccent Acircumflex -55
+KPX Tcommaaccent Adieresis -55
+KPX Tcommaaccent Agrave -55
+KPX Tcommaaccent Amacron -55
+KPX Tcommaaccent Aogonek -55
+KPX Tcommaaccent Aring -55
+KPX Tcommaaccent Atilde -55
+KPX Tcommaaccent O -18
+KPX Tcommaaccent Oacute -18
+KPX Tcommaaccent Ocircumflex -18
+KPX Tcommaaccent Odieresis -18
+KPX Tcommaaccent Ograve -18
+KPX Tcommaaccent Ohungarumlaut -18
+KPX Tcommaaccent Omacron -18
+KPX Tcommaaccent Oslash -18
+KPX Tcommaaccent Otilde -18
+KPX Tcommaaccent a -92
+KPX Tcommaaccent aacute -92
+KPX Tcommaaccent abreve -92
+KPX Tcommaaccent acircumflex -92
+KPX Tcommaaccent adieresis -92
+KPX Tcommaaccent agrave -92
+KPX Tcommaaccent amacron -92
+KPX Tcommaaccent aogonek -92
+KPX Tcommaaccent aring -92
+KPX Tcommaaccent atilde -92
+KPX Tcommaaccent colon -74
+KPX Tcommaaccent comma -92
+KPX Tcommaaccent e -92
+KPX Tcommaaccent eacute -92
+KPX Tcommaaccent ecaron -92
+KPX Tcommaaccent ecircumflex -92
+KPX Tcommaaccent edieresis -52
+KPX Tcommaaccent edotaccent -92
+KPX Tcommaaccent egrave -52
+KPX Tcommaaccent emacron -52
+KPX Tcommaaccent eogonek -92
+KPX Tcommaaccent hyphen -92
+KPX Tcommaaccent i -37
+KPX Tcommaaccent iacute -37
+KPX Tcommaaccent iogonek -37
+KPX Tcommaaccent o -95
+KPX Tcommaaccent oacute -95
+KPX Tcommaaccent ocircumflex -95
+KPX Tcommaaccent odieresis -95
+KPX Tcommaaccent ograve -95
+KPX Tcommaaccent ohungarumlaut -95
+KPX Tcommaaccent omacron -95
+KPX Tcommaaccent oslash -95
+KPX Tcommaaccent otilde -95
+KPX Tcommaaccent period -92
+KPX Tcommaaccent r -37
+KPX Tcommaaccent racute -37
+KPX Tcommaaccent rcaron -37
+KPX Tcommaaccent rcommaaccent -37
+KPX Tcommaaccent semicolon -74
+KPX Tcommaaccent u -37
+KPX Tcommaaccent uacute -37
+KPX Tcommaaccent ucircumflex -37
+KPX Tcommaaccent udieresis -37
+KPX Tcommaaccent ugrave -37
+KPX Tcommaaccent uhungarumlaut -37
+KPX Tcommaaccent umacron -37
+KPX Tcommaaccent uogonek -37
+KPX Tcommaaccent uring -37
+KPX Tcommaaccent w -37
+KPX Tcommaaccent y -37
+KPX Tcommaaccent yacute -37
+KPX Tcommaaccent ydieresis -37
+KPX U A -45
+KPX U Aacute -45
+KPX U Abreve -45
+KPX U Acircumflex -45
+KPX U Adieresis -45
+KPX U Agrave -45
+KPX U Amacron -45
+KPX U Aogonek -45
+KPX U Aring -45
+KPX U Atilde -45
+KPX Uacute A -45
+KPX Uacute Aacute -45
+KPX Uacute Abreve -45
+KPX Uacute Acircumflex -45
+KPX Uacute Adieresis -45
+KPX Uacute Agrave -45
+KPX Uacute Amacron -45
+KPX Uacute Aogonek -45
+KPX Uacute Aring -45
+KPX Uacute Atilde -45
+KPX Ucircumflex A -45
+KPX Ucircumflex Aacute -45
+KPX Ucircumflex Abreve -45
+KPX Ucircumflex Acircumflex -45
+KPX Ucircumflex Adieresis -45
+KPX Ucircumflex Agrave -45
+KPX Ucircumflex Amacron -45
+KPX Ucircumflex Aogonek -45
+KPX Ucircumflex Aring -45
+KPX Ucircumflex Atilde -45
+KPX Udieresis A -45
+KPX Udieresis Aacute -45
+KPX Udieresis Abreve -45
+KPX Udieresis Acircumflex -45
+KPX Udieresis Adieresis -45
+KPX Udieresis Agrave -45
+KPX Udieresis Amacron -45
+KPX Udieresis Aogonek -45
+KPX Udieresis Aring -45
+KPX Udieresis Atilde -45
+KPX Ugrave A -45
+KPX Ugrave Aacute -45
+KPX Ugrave Abreve -45
+KPX Ugrave Acircumflex -45
+KPX Ugrave Adieresis -45
+KPX Ugrave Agrave -45
+KPX Ugrave Amacron -45
+KPX Ugrave Aogonek -45
+KPX Ugrave Aring -45
+KPX Ugrave Atilde -45
+KPX Uhungarumlaut A -45
+KPX Uhungarumlaut Aacute -45
+KPX Uhungarumlaut Abreve -45
+KPX Uhungarumlaut Acircumflex -45
+KPX Uhungarumlaut Adieresis -45
+KPX Uhungarumlaut Agrave -45
+KPX Uhungarumlaut Amacron -45
+KPX Uhungarumlaut Aogonek -45
+KPX Uhungarumlaut Aring -45
+KPX Uhungarumlaut Atilde -45
+KPX Umacron A -45
+KPX Umacron Aacute -45
+KPX Umacron Abreve -45
+KPX Umacron Acircumflex -45
+KPX Umacron Adieresis -45
+KPX Umacron Agrave -45
+KPX Umacron Amacron -45
+KPX Umacron Aogonek -45
+KPX Umacron Aring -45
+KPX Umacron Atilde -45
+KPX Uogonek A -45
+KPX Uogonek Aacute -45
+KPX Uogonek Abreve -45
+KPX Uogonek Acircumflex -45
+KPX Uogonek Adieresis -45
+KPX Uogonek Agrave -45
+KPX Uogonek Amacron -45
+KPX Uogonek Aogonek -45
+KPX Uogonek Aring -45
+KPX Uogonek Atilde -45
+KPX Uring A -45
+KPX Uring Aacute -45
+KPX Uring Abreve -45
+KPX Uring Acircumflex -45
+KPX Uring Adieresis -45
+KPX Uring Agrave -45
+KPX Uring Amacron -45
+KPX Uring Aogonek -45
+KPX Uring Aring -45
+KPX Uring Atilde -45
+KPX V A -85
+KPX V Aacute -85
+KPX V Abreve -85
+KPX V Acircumflex -85
+KPX V Adieresis -85
+KPX V Agrave -85
+KPX V Amacron -85
+KPX V Aogonek -85
+KPX V Aring -85
+KPX V Atilde -85
+KPX V G -10
+KPX V Gbreve -10
+KPX V Gcommaaccent -10
+KPX V O -30
+KPX V Oacute -30
+KPX V Ocircumflex -30
+KPX V Odieresis -30
+KPX V Ograve -30
+KPX V Ohungarumlaut -30
+KPX V Omacron -30
+KPX V Oslash -30
+KPX V Otilde -30
+KPX V a -111
+KPX V aacute -111
+KPX V abreve -111
+KPX V acircumflex -111
+KPX V adieresis -111
+KPX V agrave -111
+KPX V amacron -111
+KPX V aogonek -111
+KPX V aring -111
+KPX V atilde -111
+KPX V colon -74
+KPX V comma -129
+KPX V e -111
+KPX V eacute -111
+KPX V ecaron -111
+KPX V ecircumflex -111
+KPX V edieresis -71
+KPX V edotaccent -111
+KPX V egrave -71
+KPX V emacron -71
+KPX V eogonek -111
+KPX V hyphen -70
+KPX V i -55
+KPX V iacute -55
+KPX V iogonek -55
+KPX V o -111
+KPX V oacute -111
+KPX V ocircumflex -111
+KPX V odieresis -111
+KPX V ograve -111
+KPX V ohungarumlaut -111
+KPX V omacron -111
+KPX V oslash -111
+KPX V otilde -111
+KPX V period -129
+KPX V semicolon -74
+KPX V u -55
+KPX V uacute -55
+KPX V ucircumflex -55
+KPX V udieresis -55
+KPX V ugrave -55
+KPX V uhungarumlaut -55
+KPX V umacron -55
+KPX V uogonek -55
+KPX V uring -55
+KPX W A -74
+KPX W Aacute -74
+KPX W Abreve -74
+KPX W Acircumflex -74
+KPX W Adieresis -74
+KPX W Agrave -74
+KPX W Amacron -74
+KPX W Aogonek -74
+KPX W Aring -74
+KPX W Atilde -74
+KPX W O -15
+KPX W Oacute -15
+KPX W Ocircumflex -15
+KPX W Odieresis -15
+KPX W Ograve -15
+KPX W Ohungarumlaut -15
+KPX W Omacron -15
+KPX W Oslash -15
+KPX W Otilde -15
+KPX W a -85
+KPX W aacute -85
+KPX W abreve -85
+KPX W acircumflex -85
+KPX W adieresis -85
+KPX W agrave -85
+KPX W amacron -85
+KPX W aogonek -85
+KPX W aring -85
+KPX W atilde -85
+KPX W colon -55
+KPX W comma -74
+KPX W e -90
+KPX W eacute -90
+KPX W ecaron -90
+KPX W ecircumflex -90
+KPX W edieresis -50
+KPX W edotaccent -90
+KPX W egrave -50
+KPX W emacron -50
+KPX W eogonek -90
+KPX W hyphen -50
+KPX W i -37
+KPX W iacute -37
+KPX W iogonek -37
+KPX W o -80
+KPX W oacute -80
+KPX W ocircumflex -80
+KPX W odieresis -80
+KPX W ograve -80
+KPX W ohungarumlaut -80
+KPX W omacron -80
+KPX W oslash -80
+KPX W otilde -80
+KPX W period -74
+KPX W semicolon -55
+KPX W u -55
+KPX W uacute -55
+KPX W ucircumflex -55
+KPX W udieresis -55
+KPX W ugrave -55
+KPX W uhungarumlaut -55
+KPX W umacron -55
+KPX W uogonek -55
+KPX W uring -55
+KPX W y -55
+KPX W yacute -55
+KPX W ydieresis -55
+KPX Y A -74
+KPX Y Aacute -74
+KPX Y Abreve -74
+KPX Y Acircumflex -74
+KPX Y Adieresis -74
+KPX Y Agrave -74
+KPX Y Amacron -74
+KPX Y Aogonek -74
+KPX Y Aring -74
+KPX Y Atilde -74
+KPX Y O -25
+KPX Y Oacute -25
+KPX Y Ocircumflex -25
+KPX Y Odieresis -25
+KPX Y Ograve -25
+KPX Y Ohungarumlaut -25
+KPX Y Omacron -25
+KPX Y Oslash -25
+KPX Y Otilde -25
+KPX Y a -92
+KPX Y aacute -92
+KPX Y abreve -92
+KPX Y acircumflex -92
+KPX Y adieresis -92
+KPX Y agrave -92
+KPX Y amacron -92
+KPX Y aogonek -92
+KPX Y aring -92
+KPX Y atilde -92
+KPX Y colon -92
+KPX Y comma -92
+KPX Y e -111
+KPX Y eacute -111
+KPX Y ecaron -111
+KPX Y ecircumflex -71
+KPX Y edieresis -71
+KPX Y edotaccent -111
+KPX Y egrave -71
+KPX Y emacron -71
+KPX Y eogonek -111
+KPX Y hyphen -92
+KPX Y i -55
+KPX Y iacute -55
+KPX Y iogonek -55
+KPX Y o -111
+KPX Y oacute -111
+KPX Y ocircumflex -111
+KPX Y odieresis -111
+KPX Y ograve -111
+KPX Y ohungarumlaut -111
+KPX Y omacron -111
+KPX Y oslash -111
+KPX Y otilde -111
+KPX Y period -74
+KPX Y semicolon -92
+KPX Y u -92
+KPX Y uacute -92
+KPX Y ucircumflex -92
+KPX Y udieresis -92
+KPX Y ugrave -92
+KPX Y uhungarumlaut -92
+KPX Y umacron -92
+KPX Y uogonek -92
+KPX Y uring -92
+KPX Yacute A -74
+KPX Yacute Aacute -74
+KPX Yacute Abreve -74
+KPX Yacute Acircumflex -74
+KPX Yacute Adieresis -74
+KPX Yacute Agrave -74
+KPX Yacute Amacron -74
+KPX Yacute Aogonek -74
+KPX Yacute Aring -74
+KPX Yacute Atilde -74
+KPX Yacute O -25
+KPX Yacute Oacute -25
+KPX Yacute Ocircumflex -25
+KPX Yacute Odieresis -25
+KPX Yacute Ograve -25
+KPX Yacute Ohungarumlaut -25
+KPX Yacute Omacron -25
+KPX Yacute Oslash -25
+KPX Yacute Otilde -25
+KPX Yacute a -92
+KPX Yacute aacute -92
+KPX Yacute abreve -92
+KPX Yacute acircumflex -92
+KPX Yacute adieresis -92
+KPX Yacute agrave -92
+KPX Yacute amacron -92
+KPX Yacute aogonek -92
+KPX Yacute aring -92
+KPX Yacute atilde -92
+KPX Yacute colon -92
+KPX Yacute comma -92
+KPX Yacute e -111
+KPX Yacute eacute -111
+KPX Yacute ecaron -111
+KPX Yacute ecircumflex -71
+KPX Yacute edieresis -71
+KPX Yacute edotaccent -111
+KPX Yacute egrave -71
+KPX Yacute emacron -71
+KPX Yacute eogonek -111
+KPX Yacute hyphen -92
+KPX Yacute i -55
+KPX Yacute iacute -55
+KPX Yacute iogonek -55
+KPX Yacute o -111
+KPX Yacute oacute -111
+KPX Yacute ocircumflex -111
+KPX Yacute odieresis -111
+KPX Yacute ograve -111
+KPX Yacute ohungarumlaut -111
+KPX Yacute omacron -111
+KPX Yacute oslash -111
+KPX Yacute otilde -111
+KPX Yacute period -74
+KPX Yacute semicolon -92
+KPX Yacute u -92
+KPX Yacute uacute -92
+KPX Yacute ucircumflex -92
+KPX Yacute udieresis -92
+KPX Yacute ugrave -92
+KPX Yacute uhungarumlaut -92
+KPX Yacute umacron -92
+KPX Yacute uogonek -92
+KPX Yacute uring -92
+KPX Ydieresis A -74
+KPX Ydieresis Aacute -74
+KPX Ydieresis Abreve -74
+KPX Ydieresis Acircumflex -74
+KPX Ydieresis Adieresis -74
+KPX Ydieresis Agrave -74
+KPX Ydieresis Amacron -74
+KPX Ydieresis Aogonek -74
+KPX Ydieresis Aring -74
+KPX Ydieresis Atilde -74
+KPX Ydieresis O -25
+KPX Ydieresis Oacute -25
+KPX Ydieresis Ocircumflex -25
+KPX Ydieresis Odieresis -25
+KPX Ydieresis Ograve -25
+KPX Ydieresis Ohungarumlaut -25
+KPX Ydieresis Omacron -25
+KPX Ydieresis Oslash -25
+KPX Ydieresis Otilde -25
+KPX Ydieresis a -92
+KPX Ydieresis aacute -92
+KPX Ydieresis abreve -92
+KPX Ydieresis acircumflex -92
+KPX Ydieresis adieresis -92
+KPX Ydieresis agrave -92
+KPX Ydieresis amacron -92
+KPX Ydieresis aogonek -92
+KPX Ydieresis aring -92
+KPX Ydieresis atilde -92
+KPX Ydieresis colon -92
+KPX Ydieresis comma -92
+KPX Ydieresis e -111
+KPX Ydieresis eacute -111
+KPX Ydieresis ecaron -111
+KPX Ydieresis ecircumflex -71
+KPX Ydieresis edieresis -71
+KPX Ydieresis edotaccent -111
+KPX Ydieresis egrave -71
+KPX Ydieresis emacron -71
+KPX Ydieresis eogonek -111
+KPX Ydieresis hyphen -92
+KPX Ydieresis i -55
+KPX Ydieresis iacute -55
+KPX Ydieresis iogonek -55
+KPX Ydieresis o -111
+KPX Ydieresis oacute -111
+KPX Ydieresis ocircumflex -111
+KPX Ydieresis odieresis -111
+KPX Ydieresis ograve -111
+KPX Ydieresis ohungarumlaut -111
+KPX Ydieresis omacron -111
+KPX Ydieresis oslash -111
+KPX Ydieresis otilde -111
+KPX Ydieresis period -74
+KPX Ydieresis semicolon -92
+KPX Ydieresis u -92
+KPX Ydieresis uacute -92
+KPX Ydieresis ucircumflex -92
+KPX Ydieresis udieresis -92
+KPX Ydieresis ugrave -92
+KPX Ydieresis uhungarumlaut -92
+KPX Ydieresis umacron -92
+KPX Ydieresis uogonek -92
+KPX Ydieresis uring -92
+KPX b b -10
+KPX b period -40
+KPX b u -20
+KPX b uacute -20
+KPX b ucircumflex -20
+KPX b udieresis -20
+KPX b ugrave -20
+KPX b uhungarumlaut -20
+KPX b umacron -20
+KPX b uogonek -20
+KPX b uring -20
+KPX c h -10
+KPX c k -10
+KPX c kcommaaccent -10
+KPX cacute h -10
+KPX cacute k -10
+KPX cacute kcommaaccent -10
+KPX ccaron h -10
+KPX ccaron k -10
+KPX ccaron kcommaaccent -10
+KPX ccedilla h -10
+KPX ccedilla k -10
+KPX ccedilla kcommaaccent -10
+KPX comma quotedblright -95
+KPX comma quoteright -95
+KPX e b -10
+KPX eacute b -10
+KPX ecaron b -10
+KPX ecircumflex b -10
+KPX edieresis b -10
+KPX edotaccent b -10
+KPX egrave b -10
+KPX emacron b -10
+KPX eogonek b -10
+KPX f comma -10
+KPX f dotlessi -30
+KPX f e -10
+KPX f eacute -10
+KPX f edotaccent -10
+KPX f eogonek -10
+KPX f f -18
+KPX f o -10
+KPX f oacute -10
+KPX f ocircumflex -10
+KPX f ograve -10
+KPX f ohungarumlaut -10
+KPX f oslash -10
+KPX f otilde -10
+KPX f period -10
+KPX f quoteright 55
+KPX k e -30
+KPX k eacute -30
+KPX k ecaron -30
+KPX k ecircumflex -30
+KPX k edieresis -30
+KPX k edotaccent -30
+KPX k egrave -30
+KPX k emacron -30
+KPX k eogonek -30
+KPX k o -10
+KPX k oacute -10
+KPX k ocircumflex -10
+KPX k odieresis -10
+KPX k ograve -10
+KPX k ohungarumlaut -10
+KPX k omacron -10
+KPX k oslash -10
+KPX k otilde -10
+KPX kcommaaccent e -30
+KPX kcommaaccent eacute -30
+KPX kcommaaccent ecaron -30
+KPX kcommaaccent ecircumflex -30
+KPX kcommaaccent edieresis -30
+KPX kcommaaccent edotaccent -30
+KPX kcommaaccent egrave -30
+KPX kcommaaccent emacron -30
+KPX kcommaaccent eogonek -30
+KPX kcommaaccent o -10
+KPX kcommaaccent oacute -10
+KPX kcommaaccent ocircumflex -10
+KPX kcommaaccent odieresis -10
+KPX kcommaaccent ograve -10
+KPX kcommaaccent ohungarumlaut -10
+KPX kcommaaccent omacron -10
+KPX kcommaaccent oslash -10
+KPX kcommaaccent otilde -10
+KPX n v -40
+KPX nacute v -40
+KPX ncaron v -40
+KPX ncommaaccent v -40
+KPX ntilde v -40
+KPX o v -15
+KPX o w -25
+KPX o x -10
+KPX o y -10
+KPX o yacute -10
+KPX o ydieresis -10
+KPX oacute v -15
+KPX oacute w -25
+KPX oacute x -10
+KPX oacute y -10
+KPX oacute yacute -10
+KPX oacute ydieresis -10
+KPX ocircumflex v -15
+KPX ocircumflex w -25
+KPX ocircumflex x -10
+KPX ocircumflex y -10
+KPX ocircumflex yacute -10
+KPX ocircumflex ydieresis -10
+KPX odieresis v -15
+KPX odieresis w -25
+KPX odieresis x -10
+KPX odieresis y -10
+KPX odieresis yacute -10
+KPX odieresis ydieresis -10
+KPX ograve v -15
+KPX ograve w -25
+KPX ograve x -10
+KPX ograve y -10
+KPX ograve yacute -10
+KPX ograve ydieresis -10
+KPX ohungarumlaut v -15
+KPX ohungarumlaut w -25
+KPX ohungarumlaut x -10
+KPX ohungarumlaut y -10
+KPX ohungarumlaut yacute -10
+KPX ohungarumlaut ydieresis -10
+KPX omacron v -15
+KPX omacron w -25
+KPX omacron x -10
+KPX omacron y -10
+KPX omacron yacute -10
+KPX omacron ydieresis -10
+KPX oslash v -15
+KPX oslash w -25
+KPX oslash x -10
+KPX oslash y -10
+KPX oslash yacute -10
+KPX oslash ydieresis -10
+KPX otilde v -15
+KPX otilde w -25
+KPX otilde x -10
+KPX otilde y -10
+KPX otilde yacute -10
+KPX otilde ydieresis -10
+KPX period quotedblright -95
+KPX period quoteright -95
+KPX quoteleft quoteleft -74
+KPX quoteright d -15
+KPX quoteright dcroat -15
+KPX quoteright quoteright -74
+KPX quoteright r -15
+KPX quoteright racute -15
+KPX quoteright rcaron -15
+KPX quoteright rcommaaccent -15
+KPX quoteright s -74
+KPX quoteright sacute -74
+KPX quoteright scaron -74
+KPX quoteright scedilla -74
+KPX quoteright scommaaccent -74
+KPX quoteright space -74
+KPX quoteright t -37
+KPX quoteright tcommaaccent -37
+KPX quoteright v -15
+KPX r comma -65
+KPX r period -65
+KPX racute comma -65
+KPX racute period -65
+KPX rcaron comma -65
+KPX rcaron period -65
+KPX rcommaaccent comma -65
+KPX rcommaaccent period -65
+KPX space A -37
+KPX space Aacute -37
+KPX space Abreve -37
+KPX space Acircumflex -37
+KPX space Adieresis -37
+KPX space Agrave -37
+KPX space Amacron -37
+KPX space Aogonek -37
+KPX space Aring -37
+KPX space Atilde -37
+KPX space V -70
+KPX space W -70
+KPX space Y -70
+KPX space Yacute -70
+KPX space Ydieresis -70
+KPX v comma -37
+KPX v e -15
+KPX v eacute -15
+KPX v ecaron -15
+KPX v ecircumflex -15
+KPX v edieresis -15
+KPX v edotaccent -15
+KPX v egrave -15
+KPX v emacron -15
+KPX v eogonek -15
+KPX v o -15
+KPX v oacute -15
+KPX v ocircumflex -15
+KPX v odieresis -15
+KPX v ograve -15
+KPX v ohungarumlaut -15
+KPX v omacron -15
+KPX v oslash -15
+KPX v otilde -15
+KPX v period -37
+KPX w a -10
+KPX w aacute -10
+KPX w abreve -10
+KPX w acircumflex -10
+KPX w adieresis -10
+KPX w agrave -10
+KPX w amacron -10
+KPX w aogonek -10
+KPX w aring -10
+KPX w atilde -10
+KPX w comma -37
+KPX w e -10
+KPX w eacute -10
+KPX w ecaron -10
+KPX w ecircumflex -10
+KPX w edieresis -10
+KPX w edotaccent -10
+KPX w egrave -10
+KPX w emacron -10
+KPX w eogonek -10
+KPX w o -15
+KPX w oacute -15
+KPX w ocircumflex -15
+KPX w odieresis -15
+KPX w ograve -15
+KPX w ohungarumlaut -15
+KPX w omacron -15
+KPX w oslash -15
+KPX w otilde -15
+KPX w period -37
+KPX x e -10
+KPX x eacute -10
+KPX x ecaron -10
+KPX x ecircumflex -10
+KPX x edieresis -10
+KPX x edotaccent -10
+KPX x egrave -10
+KPX x emacron -10
+KPX x eogonek -10
+KPX y comma -37
+KPX y period -37
+KPX yacute comma -37
+KPX yacute period -37
+KPX ydieresis comma -37
+KPX ydieresis period -37
+EndKernPairs
+EndKernData
+EndFontMetrics
Added: trunk/mapbender/http/classes/fonts/Times-Italic.afm
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/fonts/Times-Italic.afm?view=auto&rev=13
--- (empty file)
+++ trunk/mapbender/http/classes/fonts/Times-Italic.afm 2006-04-13 19:38:28+0000
@@ -0,0 +1,2667 @@
+StartFontMetrics 4.1
+Comment Copyright (c) 1985, 1987, 1989, 1990, 1993, 1997 Adobe Systems Incorporated. All Rights Reserved.
+Comment Creation Date: Thu May 1 12:56:55 1997
+Comment UniqueID 43067
+Comment VMusage 47727 58752
+FontName Times-Italic
+FullName Times Italic
+FamilyName Times
+Weight Medium
+ItalicAngle -15.5
+IsFixedPitch false
+CharacterSet ExtendedRoman
+FontBBox -169 -217 1010 883
+UnderlinePosition -100
+UnderlineThickness 50
+Version 002.000
+Notice Copyright (c) 1985, 1987, 1989, 1990, 1993, 1997 Adobe Systems Incorporated. All Rights Reserved.Times is a trademark of Linotype-Hell AG and/or its subsidiaries.
+EncodingScheme AdobeStandardEncoding
+CapHeight 653
+XHeight 441
+Ascender 683
+Descender -217
+StdHW 32
+StdVW 76
+StartCharMetrics 315
+C 32 ; WX 250 ; N space ; B 0 0 0 0 ;
+C 33 ; WX 333 ; N exclam ; B 39 -11 302 667 ;
+C 34 ; WX 420 ; N quotedbl ; B 144 421 432 666 ;
+C 35 ; WX 500 ; N numbersign ; B 2 0 540 676 ;
+C 36 ; WX 500 ; N dollar ; B 31 -89 497 731 ;
+C 37 ; WX 833 ; N percent ; B 79 -13 790 676 ;
+C 38 ; WX 778 ; N ampersand ; B 76 -18 723 666 ;
+C 39 ; WX 333 ; N quoteright ; B 151 436 290 666 ;
+C 40 ; WX 333 ; N parenleft ; B 42 -181 315 669 ;
+C 41 ; WX 333 ; N parenright ; B 16 -180 289 669 ;
+C 42 ; WX 500 ; N asterisk ; B 128 255 492 666 ;
+C 43 ; WX 675 ; N plus ; B 86 0 590 506 ;
+C 44 ; WX 250 ; N comma ; B -4 -129 135 101 ;
+C 45 ; WX 333 ; N hyphen ; B 49 192 282 255 ;
+C 46 ; WX 250 ; N period ; B 27 -11 138 100 ;
+C 47 ; WX 278 ; N slash ; B -65 -18 386 666 ;
+C 48 ; WX 500 ; N zero ; B 32 -7 497 676 ;
+C 49 ; WX 500 ; N one ; B 49 0 409 676 ;
+C 50 ; WX 500 ; N two ; B 12 0 452 676 ;
+C 51 ; WX 500 ; N three ; B 15 -7 465 676 ;
+C 52 ; WX 500 ; N four ; B 1 0 479 676 ;
+C 53 ; WX 500 ; N five ; B 15 -7 491 666 ;
+C 54 ; WX 500 ; N six ; B 30 -7 521 686 ;
+C 55 ; WX 500 ; N seven ; B 75 -8 537 666 ;
+C 56 ; WX 500 ; N eight ; B 30 -7 493 676 ;
+C 57 ; WX 500 ; N nine ; B 23 -17 492 676 ;
+C 58 ; WX 333 ; N colon ; B 50 -11 261 441 ;
+C 59 ; WX 333 ; N semicolon ; B 27 -129 261 441 ;
+C 60 ; WX 675 ; N less ; B 84 -8 592 514 ;
+C 61 ; WX 675 ; N equal ; B 86 120 590 386 ;
+C 62 ; WX 675 ; N greater ; B 84 -8 592 514 ;
+C 63 ; WX 500 ; N question ; B 132 -12 472 664 ;
+C 64 ; WX 920 ; N at ; B 118 -18 806 666 ;
+C 65 ; WX 611 ; N A ; B -51 0 564 668 ;
+C 66 ; WX 611 ; N B ; B -8 0 588 653 ;
+C 67 ; WX 667 ; N C ; B 66 -18 689 666 ;
+C 68 ; WX 722 ; N D ; B -8 0 700 653 ;
+C 69 ; WX 611 ; N E ; B -1 0 634 653 ;
+C 70 ; WX 611 ; N F ; B 8 0 645 653 ;
+C 71 ; WX 722 ; N G ; B 52 -18 722 666 ;
+C 72 ; WX 722 ; N H ; B -8 0 767 653 ;
+C 73 ; WX 333 ; N I ; B -8 0 384 653 ;
+C 74 ; WX 444 ; N J ; B -6 -18 491 653 ;
+C 75 ; WX 667 ; N K ; B 7 0 722 653 ;
+C 76 ; WX 556 ; N L ; B -8 0 559 653 ;
+C 77 ; WX 833 ; N M ; B -18 0 873 653 ;
+C 78 ; WX 667 ; N N ; B -20 -15 727 653 ;
+C 79 ; WX 722 ; N O ; B 60 -18 699 666 ;
+C 80 ; WX 611 ; N P ; B 0 0 605 653 ;
+C 81 ; WX 722 ; N Q ; B 59 -182 699 666 ;
+C 82 ; WX 611 ; N R ; B -13 0 588 653 ;
+C 83 ; WX 500 ; N S ; B 17 -18 508 667 ;
+C 84 ; WX 556 ; N T ; B 59 0 633 653 ;
+C 85 ; WX 722 ; N U ; B 102 -18 765 653 ;
+C 86 ; WX 611 ; N V ; B 76 -18 688 653 ;
+C 87 ; WX 833 ; N W ; B 71 -18 906 653 ;
+C 88 ; WX 611 ; N X ; B -29 0 655 653 ;
+C 89 ; WX 556 ; N Y ; B 78 0 633 653 ;
+C 90 ; WX 556 ; N Z ; B -6 0 606 653 ;
+C 91 ; WX 389 ; N bracketleft ; B 21 -153 391 663 ;
+C 92 ; WX 278 ; N backslash ; B -41 -18 319 666 ;
+C 93 ; WX 389 ; N bracketright ; B 12 -153 382 663 ;
+C 94 ; WX 422 ; N asciicircum ; B 0 301 422 666 ;
+C 95 ; WX 500 ; N underscore ; B 0 -125 500 -75 ;
+C 96 ; WX 333 ; N quoteleft ; B 171 436 310 666 ;
+C 97 ; WX 500 ; N a ; B 17 -11 476 441 ;
+C 98 ; WX 500 ; N b ; B 23 -11 473 683 ;
+C 99 ; WX 444 ; N c ; B 30 -11 425 441 ;
+C 100 ; WX 500 ; N d ; B 15 -13 527 683 ;
+C 101 ; WX 444 ; N e ; B 31 -11 412 441 ;
+C 102 ; WX 278 ; N f ; B -147 -207 424 678 ; L i fi ; L l fl ;
+C 103 ; WX 500 ; N g ; B 8 -206 472 441 ;
+C 104 ; WX 500 ; N h ; B 19 -9 478 683 ;
+C 105 ; WX 278 ; N i ; B 49 -11 264 654 ;
+C 106 ; WX 278 ; N j ; B -124 -207 276 654 ;
+C 107 ; WX 444 ; N k ; B 14 -11 461 683 ;
+C 108 ; WX 278 ; N l ; B 41 -11 279 683 ;
+C 109 ; WX 722 ; N m ; B 12 -9 704 441 ;
+C 110 ; WX 500 ; N n ; B 14 -9 474 441 ;
+C 111 ; WX 500 ; N o ; B 27 -11 468 441 ;
+C 112 ; WX 500 ; N p ; B -75 -205 469 441 ;
+C 113 ; WX 500 ; N q ; B 25 -209 483 441 ;
+C 114 ; WX 389 ; N r ; B 45 0 412 441 ;
+C 115 ; WX 389 ; N s ; B 16 -13 366 442 ;
+C 116 ; WX 278 ; N t ; B 37 -11 296 546 ;
+C 117 ; WX 500 ; N u ; B 42 -11 475 441 ;
+C 118 ; WX 444 ; N v ; B 21 -18 426 441 ;
+C 119 ; WX 667 ; N w ; B 16 -18 648 441 ;
+C 120 ; WX 444 ; N x ; B -27 -11 447 441 ;
+C 121 ; WX 444 ; N y ; B -24 -206 426 441 ;
+C 122 ; WX 389 ; N z ; B -2 -81 380 428 ;
+C 123 ; WX 400 ; N braceleft ; B 51 -177 407 687 ;
+C 124 ; WX 275 ; N bar ; B 105 -217 171 783 ;
+C 125 ; WX 400 ; N braceright ; B -7 -177 349 687 ;
+C 126 ; WX 541 ; N asciitilde ; B 40 183 502 323 ;
+C 161 ; WX 389 ; N exclamdown ; B 59 -205 322 473 ;
+C 162 ; WX 500 ; N cent ; B 77 -143 472 560 ;
+C 163 ; WX 500 ; N sterling ; B 10 -6 517 670 ;
+C 164 ; WX 167 ; N fraction ; B -169 -10 337 676 ;
+C 165 ; WX 500 ; N yen ; B 27 0 603 653 ;
+C 166 ; WX 500 ; N florin ; B 25 -182 507 682 ;
+C 167 ; WX 500 ; N section ; B 53 -162 461 666 ;
+C 168 ; WX 500 ; N currency ; B -22 53 522 597 ;
+C 169 ; WX 214 ; N quotesingle ; B 132 421 241 666 ;
+C 170 ; WX 556 ; N quotedblleft ; B 166 436 514 666 ;
+C 171 ; WX 500 ; N guillemotleft ; B 53 37 445 403 ;
+C 172 ; WX 333 ; N guilsinglleft ; B 51 37 281 403 ;
+C 173 ; WX 333 ; N guilsinglright ; B 52 37 282 403 ;
+C 174 ; WX 500 ; N fi ; B -141 -207 481 681 ;
+C 175 ; WX 500 ; N fl ; B -141 -204 518 682 ;
+C 177 ; WX 500 ; N endash ; B -6 197 505 243 ;
+C 178 ; WX 500 ; N dagger ; B 101 -159 488 666 ;
+C 179 ; WX 500 ; N daggerdbl ; B 22 -143 491 666 ;
+C 180 ; WX 250 ; N periodcentered ; B 70 199 181 310 ;
+C 182 ; WX 523 ; N paragraph ; B 55 -123 616 653 ;
+C 183 ; WX 350 ; N bullet ; B 40 191 310 461 ;
+C 184 ; WX 333 ; N quotesinglbase ; B 44 -129 183 101 ;
+C 185 ; WX 556 ; N quotedblbase ; B 57 -129 405 101 ;
+C 186 ; WX 556 ; N quotedblright ; B 151 436 499 666 ;
+C 187 ; WX 500 ; N guillemotright ; B 55 37 447 403 ;
+C 188 ; WX 889 ; N ellipsis ; B 57 -11 762 100 ;
+C 189 ; WX 1000 ; N perthousand ; B 25 -19 1010 706 ;
+C 191 ; WX 500 ; N questiondown ; B 28 -205 368 471 ;
+C 193 ; WX 333 ; N grave ; B 121 492 311 664 ;
+C 194 ; WX 333 ; N acute ; B 180 494 403 664 ;
+C 195 ; WX 333 ; N circumflex ; B 91 492 385 661 ;
+C 196 ; WX 333 ; N tilde ; B 100 517 427 624 ;
+C 197 ; WX 333 ; N macron ; B 99 532 411 583 ;
+C 198 ; WX 333 ; N breve ; B 117 492 418 650 ;
+C 199 ; WX 333 ; N dotaccent ; B 207 548 305 646 ;
+C 200 ; WX 333 ; N dieresis ; B 107 548 405 646 ;
+C 202 ; WX 333 ; N ring ; B 155 492 355 691 ;
+C 203 ; WX 333 ; N cedilla ; B -30 -217 182 0 ;
+C 205 ; WX 333 ; N hungarumlaut ; B 93 494 486 664 ;
+C 206 ; WX 333 ; N ogonek ; B 20 -169 203 40 ;
+C 207 ; WX 333 ; N caron ; B 121 492 426 661 ;
+C 208 ; WX 889 ; N emdash ; B -6 197 894 243 ;
+C 225 ; WX 889 ; N AE ; B -27 0 911 653 ;
+C 227 ; WX 276 ; N ordfeminine ; B 42 406 352 676 ;
+C 232 ; WX 556 ; N Lslash ; B -8 0 559 653 ;
+C 233 ; WX 722 ; N Oslash ; B 60 -105 699 722 ;
+C 234 ; WX 944 ; N OE ; B 49 -8 964 666 ;
+C 235 ; WX 310 ; N ordmasculine ; B 67 406 362 676 ;
+C 241 ; WX 667 ; N ae ; B 23 -11 640 441 ;
+C 245 ; WX 278 ; N dotlessi ; B 49 -11 235 441 ;
+C 248 ; WX 278 ; N lslash ; B 41 -11 312 683 ;
+C 249 ; WX 500 ; N oslash ; B 28 -135 469 554 ;
+C 250 ; WX 667 ; N oe ; B 20 -12 646 441 ;
+C 251 ; WX 500 ; N germandbls ; B -168 -207 493 679 ;
+C -1 ; WX 333 ; N Idieresis ; B -8 0 435 818 ;
+C -1 ; WX 444 ; N eacute ; B 31 -11 459 664 ;
+C -1 ; WX 500 ; N abreve ; B 17 -11 502 650 ;
+C -1 ; WX 500 ; N uhungarumlaut ; B 42 -11 580 664 ;
+C -1 ; WX 444 ; N ecaron ; B 31 -11 482 661 ;
+C -1 ; WX 556 ; N Ydieresis ; B 78 0 633 818 ;
+C -1 ; WX 675 ; N divide ; B 86 -11 590 517 ;
+C -1 ; WX 556 ; N Yacute ; B 78 0 633 876 ;
+C -1 ; WX 611 ; N Acircumflex ; B -51 0 564 873 ;
+C -1 ; WX 500 ; N aacute ; B 17 -11 487 664 ;
+C -1 ; WX 722 ; N Ucircumflex ; B 102 -18 765 873 ;
+C -1 ; WX 444 ; N yacute ; B -24 -206 459 664 ;
+C -1 ; WX 389 ; N scommaaccent ; B 16 -217 366 442 ;
+C -1 ; WX 444 ; N ecircumflex ; B 31 -11 441 661 ;
+C -1 ; WX 722 ; N Uring ; B 102 -18 765 883 ;
+C -1 ; WX 722 ; N Udieresis ; B 102 -18 765 818 ;
+C -1 ; WX 500 ; N aogonek ; B 17 -169 476 441 ;
+C -1 ; WX 722 ; N Uacute ; B 102 -18 765 876 ;
+C -1 ; WX 500 ; N uogonek ; B 42 -169 477 441 ;
+C -1 ; WX 611 ; N Edieresis ; B -1 0 634 818 ;
+C -1 ; WX 722 ; N Dcroat ; B -8 0 700 653 ;
+C -1 ; WX 250 ; N commaaccent ; B 8 -217 133 -50 ;
+C -1 ; WX 760 ; N copyright ; B 41 -18 719 666 ;
+C -1 ; WX 611 ; N Emacron ; B -1 0 634 795 ;
+C -1 ; WX 444 ; N ccaron ; B 30 -11 482 661 ;
+C -1 ; WX 500 ; N aring ; B 17 -11 476 691 ;
+C -1 ; WX 667 ; N Ncommaaccent ; B -20 -187 727 653 ;
+C -1 ; WX 278 ; N lacute ; B 41 -11 395 876 ;
+C -1 ; WX 500 ; N agrave ; B 17 -11 476 664 ;
+C -1 ; WX 556 ; N Tcommaaccent ; B 59 -217 633 653 ;
+C -1 ; WX 667 ; N Cacute ; B 66 -18 690 876 ;
+C -1 ; WX 500 ; N atilde ; B 17 -11 511 624 ;
+C -1 ; WX 611 ; N Edotaccent ; B -1 0 634 818 ;
+C -1 ; WX 389 ; N scaron ; B 16 -13 454 661 ;
+C -1 ; WX 389 ; N scedilla ; B 16 -217 366 442 ;
+C -1 ; WX 278 ; N iacute ; B 49 -11 355 664 ;
+C -1 ; WX 471 ; N lozenge ; B 13 0 459 724 ;
+C -1 ; WX 611 ; N Rcaron ; B -13 0 588 873 ;
+C -1 ; WX 722 ; N Gcommaaccent ; B 52 -217 722 666 ;
+C -1 ; WX 500 ; N ucircumflex ; B 42 -11 475 661 ;
+C -1 ; WX 500 ; N acircumflex ; B 17 -11 476 661 ;
+C -1 ; WX 611 ; N Amacron ; B -51 0 564 795 ;
+C -1 ; WX 389 ; N rcaron ; B 45 0 434 661 ;
+C -1 ; WX 444 ; N ccedilla ; B 30 -217 425 441 ;
+C -1 ; WX 556 ; N Zdotaccent ; B -6 0 606 818 ;
+C -1 ; WX 611 ; N Thorn ; B 0 0 569 653 ;
+C -1 ; WX 722 ; N Omacron ; B 60 -18 699 795 ;
+C -1 ; WX 611 ; N Racute ; B -13 0 588 876 ;
+C -1 ; WX 500 ; N Sacute ; B 17 -18 508 876 ;
+C -1 ; WX 544 ; N dcaron ; B 15 -13 658 683 ;
+C -1 ; WX 722 ; N Umacron ; B 102 -18 765 795 ;
+C -1 ; WX 500 ; N uring ; B 42 -11 475 691 ;
+C -1 ; WX 300 ; N threesuperior ; B 43 268 339 676 ;
+C -1 ; WX 722 ; N Ograve ; B 60 -18 699 876 ;
+C -1 ; WX 611 ; N Agrave ; B -51 0 564 876 ;
+C -1 ; WX 611 ; N Abreve ; B -51 0 564 862 ;
+C -1 ; WX 675 ; N multiply ; B 93 8 582 497 ;
+C -1 ; WX 500 ; N uacute ; B 42 -11 477 664 ;
+C -1 ; WX 556 ; N Tcaron ; B 59 0 633 873 ;
+C -1 ; WX 476 ; N partialdiff ; B 17 -38 459 710 ;
+C -1 ; WX 444 ; N ydieresis ; B -24 -206 441 606 ;
+C -1 ; WX 667 ; N Nacute ; B -20 -15 727 876 ;
+C -1 ; WX 278 ; N icircumflex ; B 33 -11 327 661 ;
+C -1 ; WX 611 ; N Ecircumflex ; B -1 0 634 873 ;
+C -1 ; WX 500 ; N adieresis ; B 17 -11 489 606 ;
+C -1 ; WX 444 ; N edieresis ; B 31 -11 451 606 ;
+C -1 ; WX 444 ; N cacute ; B 30 -11 459 664 ;
+C -1 ; WX 500 ; N nacute ; B 14 -9 477 664 ;
+C -1 ; WX 500 ; N umacron ; B 42 -11 485 583 ;
+C -1 ; WX 667 ; N Ncaron ; B -20 -15 727 873 ;
+C -1 ; WX 333 ; N Iacute ; B -8 0 433 876 ;
+C -1 ; WX 675 ; N plusminus ; B 86 0 590 506 ;
+C -1 ; WX 275 ; N brokenbar ; B 105 -142 171 708 ;
+C -1 ; WX 760 ; N registered ; B 41 -18 719 666 ;
+C -1 ; WX 722 ; N Gbreve ; B 52 -18 722 862 ;
+C -1 ; WX 333 ; N Idotaccent ; B -8 0 384 818 ;
+C -1 ; WX 600 ; N summation ; B 15 -10 585 706 ;
+C -1 ; WX 611 ; N Egrave ; B -1 0 634 876 ;
+C -1 ; WX 389 ; N racute ; B 45 0 431 664 ;
+C -1 ; WX 500 ; N omacron ; B 27 -11 495 583 ;
+C -1 ; WX 556 ; N Zacute ; B -6 0 606 876 ;
+C -1 ; WX 556 ; N Zcaron ; B -6 0 606 873 ;
+C -1 ; WX 549 ; N greaterequal ; B 26 0 523 658 ;
+C -1 ; WX 722 ; N Eth ; B -8 0 700 653 ;
+C -1 ; WX 667 ; N Ccedilla ; B 66 -217 689 666 ;
+C -1 ; WX 278 ; N lcommaaccent ; B 22 -217 279 683 ;
+C -1 ; WX 300 ; N tcaron ; B 37 -11 407 681 ;
+C -1 ; WX 444 ; N eogonek ; B 31 -169 412 441 ;
+C -1 ; WX 722 ; N Uogonek ; B 102 -184 765 653 ;
+C -1 ; WX 611 ; N Aacute ; B -51 0 564 876 ;
+C -1 ; WX 611 ; N Adieresis ; B -51 0 564 818 ;
+C -1 ; WX 444 ; N egrave ; B 31 -11 412 664 ;
+C -1 ; WX 389 ; N zacute ; B -2 -81 431 664 ;
+C -1 ; WX 278 ; N iogonek ; B 49 -169 264 654 ;
+C -1 ; WX 722 ; N Oacute ; B 60 -18 699 876 ;
+C -1 ; WX 500 ; N oacute ; B 27 -11 487 664 ;
+C -1 ; WX 500 ; N amacron ; B 17 -11 495 583 ;
+C -1 ; WX 389 ; N sacute ; B 16 -13 431 664 ;
+C -1 ; WX 278 ; N idieresis ; B 49 -11 352 606 ;
+C -1 ; WX 722 ; N Ocircumflex ; B 60 -18 699 873 ;
+C -1 ; WX 722 ; N Ugrave ; B 102 -18 765 876 ;
+C -1 ; WX 612 ; N Delta ; B 6 0 608 688 ;
+C -1 ; WX 500 ; N thorn ; B -75 -205 469 683 ;
+C -1 ; WX 300 ; N twosuperior ; B 33 271 324 676 ;
+C -1 ; WX 722 ; N Odieresis ; B 60 -18 699 818 ;
+C -1 ; WX 500 ; N mu ; B -30 -209 497 428 ;
+C -1 ; WX 278 ; N igrave ; B 49 -11 284 664 ;
+C -1 ; WX 500 ; N ohungarumlaut ; B 27 -11 590 664 ;
+C -1 ; WX 611 ; N Eogonek ; B -1 -169 634 653 ;
+C -1 ; WX 500 ; N dcroat ; B 15 -13 572 683 ;
+C -1 ; WX 750 ; N threequarters ; B 23 -10 736 676 ;
+C -1 ; WX 500 ; N Scedilla ; B 17 -217 508 667 ;
+C -1 ; WX 300 ; N lcaron ; B 41 -11 407 683 ;
+C -1 ; WX 667 ; N Kcommaaccent ; B 7 -217 722 653 ;
+C -1 ; WX 556 ; N Lacute ; B -8 0 559 876 ;
+C -1 ; WX 980 ; N trademark ; B 30 247 957 653 ;
+C -1 ; WX 444 ; N edotaccent ; B 31 -11 412 606 ;
+C -1 ; WX 333 ; N Igrave ; B -8 0 384 876 ;
+C -1 ; WX 333 ; N Imacron ; B -8 0 441 795 ;
+C -1 ; WX 611 ; N Lcaron ; B -8 0 586 653 ;
+C -1 ; WX 750 ; N onehalf ; B 34 -10 749 676 ;
+C -1 ; WX 549 ; N lessequal ; B 26 0 523 658 ;
+C -1 ; WX 500 ; N ocircumflex ; B 27 -11 468 661 ;
+C -1 ; WX 500 ; N ntilde ; B 14 -9 476 624 ;
+C -1 ; WX 722 ; N Uhungarumlaut ; B 102 -18 765 876 ;
+C -1 ; WX 611 ; N Eacute ; B -1 0 634 876 ;
+C -1 ; WX 444 ; N emacron ; B 31 -11 457 583 ;
+C -1 ; WX 500 ; N gbreve ; B 8 -206 487 650 ;
+C -1 ; WX 750 ; N onequarter ; B 33 -10 736 676 ;
+C -1 ; WX 500 ; N Scaron ; B 17 -18 520 873 ;
+C -1 ; WX 500 ; N Scommaaccent ; B 17 -217 508 667 ;
+C -1 ; WX 722 ; N Ohungarumlaut ; B 60 -18 699 876 ;
+C -1 ; WX 400 ; N degree ; B 101 390 387 676 ;
+C -1 ; WX 500 ; N ograve ; B 27 -11 468 664 ;
+C -1 ; WX 667 ; N Ccaron ; B 66 -18 689 873 ;
+C -1 ; WX 500 ; N ugrave ; B 42 -11 475 664 ;
+C -1 ; WX 453 ; N radical ; B 2 -60 452 768 ;
+C -1 ; WX 722 ; N Dcaron ; B -8 0 700 873 ;
+C -1 ; WX 389 ; N rcommaaccent ; B -3 -217 412 441 ;
+C -1 ; WX 667 ; N Ntilde ; B -20 -15 727 836 ;
+C -1 ; WX 500 ; N otilde ; B 27 -11 496 624 ;
+C -1 ; WX 611 ; N Rcommaaccent ; B -13 -187 588 653 ;
+C -1 ; WX 556 ; N Lcommaaccent ; B -8 -217 559 653 ;
+C -1 ; WX 611 ; N Atilde ; B -51 0 566 836 ;
+C -1 ; WX 611 ; N Aogonek ; B -51 -169 566 668 ;
+C -1 ; WX 611 ; N Aring ; B -51 0 564 883 ;
+C -1 ; WX 722 ; N Otilde ; B 60 -18 699 836 ;
+C -1 ; WX 389 ; N zdotaccent ; B -2 -81 380 606 ;
+C -1 ; WX 611 ; N Ecaron ; B -1 0 634 873 ;
+C -1 ; WX 333 ; N Iogonek ; B -8 -169 384 653 ;
+C -1 ; WX 444 ; N kcommaaccent ; B 14 -187 461 683 ;
+C -1 ; WX 675 ; N minus ; B 86 220 590 286 ;
+C -1 ; WX 333 ; N Icircumflex ; B -8 0 425 873 ;
+C -1 ; WX 500 ; N ncaron ; B 14 -9 510 661 ;
+C -1 ; WX 278 ; N tcommaaccent ; B 2 -217 296 546 ;
+C -1 ; WX 675 ; N logicalnot ; B 86 108 590 386 ;
+C -1 ; WX 500 ; N odieresis ; B 27 -11 489 606 ;
+C -1 ; WX 500 ; N udieresis ; B 42 -11 479 606 ;
+C -1 ; WX 549 ; N notequal ; B 12 -29 537 541 ;
+C -1 ; WX 500 ; N gcommaaccent ; B 8 -206 472 706 ;
+C -1 ; WX 500 ; N eth ; B 27 -11 482 683 ;
+C -1 ; WX 389 ; N zcaron ; B -2 -81 434 661 ;
+C -1 ; WX 500 ; N ncommaaccent ; B 14 -187 474 441 ;
+C -1 ; WX 300 ; N onesuperior ; B 43 271 284 676 ;
+C -1 ; WX 278 ; N imacron ; B 46 -11 311 583 ;
+C -1 ; WX 500 ; N Euro ; B 0 0 0 0 ;
+EndCharMetrics
+StartKernData
+StartKernPairs 2321
+KPX A C -30
+KPX A Cacute -30
+KPX A Ccaron -30
+KPX A Ccedilla -30
+KPX A G -35
+KPX A Gbreve -35
+KPX A Gcommaaccent -35
+KPX A O -40
+KPX A Oacute -40
+KPX A Ocircumflex -40
+KPX A Odieresis -40
+KPX A Ograve -40
+KPX A Ohungarumlaut -40
+KPX A Omacron -40
+KPX A Oslash -40
+KPX A Otilde -40
+KPX A Q -40
+KPX A T -37
+KPX A Tcaron -37
+KPX A Tcommaaccent -37
+KPX A U -50
+KPX A Uacute -50
+KPX A Ucircumflex -50
+KPX A Udieresis -50
+KPX A Ugrave -50
+KPX A Uhungarumlaut -50
+KPX A Umacron -50
+KPX A Uogonek -50
+KPX A Uring -50
+KPX A V -105
+KPX A W -95
+KPX A Y -55
+KPX A Yacute -55
+KPX A Ydieresis -55
+KPX A quoteright -37
+KPX A u -20
+KPX A uacute -20
+KPX A ucircumflex -20
+KPX A udieresis -20
+KPX A ugrave -20
+KPX A uhungarumlaut -20
+KPX A umacron -20
+KPX A uogonek -20
+KPX A uring -20
+KPX A v -55
+KPX A w -55
+KPX A y -55
+KPX A yacute -55
+KPX A ydieresis -55
+KPX Aacute C -30
+KPX Aacute Cacute -30
+KPX Aacute Ccaron -30
+KPX Aacute Ccedilla -30
+KPX Aacute G -35
+KPX Aacute Gbreve -35
+KPX Aacute Gcommaaccent -35
+KPX Aacute O -40
+KPX Aacute Oacute -40
+KPX Aacute Ocircumflex -40
+KPX Aacute Odieresis -40
+KPX Aacute Ograve -40
+KPX Aacute Ohungarumlaut -40
+KPX Aacute Omacron -40
+KPX Aacute Oslash -40
+KPX Aacute Otilde -40
+KPX Aacute Q -40
+KPX Aacute T -37
+KPX Aacute Tcaron -37
+KPX Aacute Tcommaaccent -37
+KPX Aacute U -50
+KPX Aacute Uacute -50
+KPX Aacute Ucircumflex -50
+KPX Aacute Udieresis -50
+KPX Aacute Ugrave -50
+KPX Aacute Uhungarumlaut -50
+KPX Aacute Umacron -50
+KPX Aacute Uogonek -50
+KPX Aacute Uring -50
+KPX Aacute V -105
+KPX Aacute W -95
+KPX Aacute Y -55
+KPX Aacute Yacute -55
+KPX Aacute Ydieresis -55
+KPX Aacute quoteright -37
+KPX Aacute u -20
+KPX Aacute uacute -20
+KPX Aacute ucircumflex -20
+KPX Aacute udieresis -20
+KPX Aacute ugrave -20
+KPX Aacute uhungarumlaut -20
+KPX Aacute umacron -20
+KPX Aacute uogonek -20
+KPX Aacute uring -20
+KPX Aacute v -55
+KPX Aacute w -55
+KPX Aacute y -55
+KPX Aacute yacute -55
+KPX Aacute ydieresis -55
+KPX Abreve C -30
+KPX Abreve Cacute -30
+KPX Abreve Ccaron -30
+KPX Abreve Ccedilla -30
+KPX Abreve G -35
+KPX Abreve Gbreve -35
+KPX Abreve Gcommaaccent -35
+KPX Abreve O -40
+KPX Abreve Oacute -40
+KPX Abreve Ocircumflex -40
+KPX Abreve Odieresis -40
+KPX Abreve Ograve -40
+KPX Abreve Ohungarumlaut -40
+KPX Abreve Omacron -40
+KPX Abreve Oslash -40
+KPX Abreve Otilde -40
+KPX Abreve Q -40
+KPX Abreve T -37
+KPX Abreve Tcaron -37
+KPX Abreve Tcommaaccent -37
+KPX Abreve U -50
+KPX Abreve Uacute -50
+KPX Abreve Ucircumflex -50
+KPX Abreve Udieresis -50
+KPX Abreve Ugrave -50
+KPX Abreve Uhungarumlaut -50
+KPX Abreve Umacron -50
+KPX Abreve Uogonek -50
+KPX Abreve Uring -50
+KPX Abreve V -105
+KPX Abreve W -95
+KPX Abreve Y -55
+KPX Abreve Yacute -55
+KPX Abreve Ydieresis -55
+KPX Abreve quoteright -37
+KPX Abreve u -20
+KPX Abreve uacute -20
+KPX Abreve ucircumflex -20
+KPX Abreve udieresis -20
+KPX Abreve ugrave -20
+KPX Abreve uhungarumlaut -20
+KPX Abreve umacron -20
+KPX Abreve uogonek -20
+KPX Abreve uring -20
+KPX Abreve v -55
+KPX Abreve w -55
+KPX Abreve y -55
+KPX Abreve yacute -55
+KPX Abreve ydieresis -55
+KPX Acircumflex C -30
+KPX Acircumflex Cacute -30
+KPX Acircumflex Ccaron -30
+KPX Acircumflex Ccedilla -30
+KPX Acircumflex G -35
+KPX Acircumflex Gbreve -35
+KPX Acircumflex Gcommaaccent -35
+KPX Acircumflex O -40
+KPX Acircumflex Oacute -40
+KPX Acircumflex Ocircumflex -40
+KPX Acircumflex Odieresis -40
+KPX Acircumflex Ograve -40
+KPX Acircumflex Ohungarumlaut -40
+KPX Acircumflex Omacron -40
+KPX Acircumflex Oslash -40
+KPX Acircumflex Otilde -40
+KPX Acircumflex Q -40
+KPX Acircumflex T -37
+KPX Acircumflex Tcaron -37
+KPX Acircumflex Tcommaaccent -37
+KPX Acircumflex U -50
+KPX Acircumflex Uacute -50
+KPX Acircumflex Ucircumflex -50
+KPX Acircumflex Udieresis -50
+KPX Acircumflex Ugrave -50
+KPX Acircumflex Uhungarumlaut -50
+KPX Acircumflex Umacron -50
+KPX Acircumflex Uogonek -50
+KPX Acircumflex Uring -50
+KPX Acircumflex V -105
+KPX Acircumflex W -95
+KPX Acircumflex Y -55
+KPX Acircumflex Yacute -55
+KPX Acircumflex Ydieresis -55
+KPX Acircumflex quoteright -37
+KPX Acircumflex u -20
+KPX Acircumflex uacute -20
+KPX Acircumflex ucircumflex -20
+KPX Acircumflex udieresis -20
+KPX Acircumflex ugrave -20
+KPX Acircumflex uhungarumlaut -20
+KPX Acircumflex umacron -20
+KPX Acircumflex uogonek -20
+KPX Acircumflex uring -20
+KPX Acircumflex v -55
+KPX Acircumflex w -55
+KPX Acircumflex y -55
+KPX Acircumflex yacute -55
+KPX Acircumflex ydieresis -55
+KPX Adieresis C -30
+KPX Adieresis Cacute -30
+KPX Adieresis Ccaron -30
+KPX Adieresis Ccedilla -30
+KPX Adieresis G -35
+KPX Adieresis Gbreve -35
+KPX Adieresis Gcommaaccent -35
+KPX Adieresis O -40
+KPX Adieresis Oacute -40
+KPX Adieresis Ocircumflex -40
+KPX Adieresis Odieresis -40
+KPX Adieresis Ograve -40
+KPX Adieresis Ohungarumlaut -40
+KPX Adieresis Omacron -40
+KPX Adieresis Oslash -40
+KPX Adieresis Otilde -40
+KPX Adieresis Q -40
+KPX Adieresis T -37
+KPX Adieresis Tcaron -37
+KPX Adieresis Tcommaaccent -37
+KPX Adieresis U -50
+KPX Adieresis Uacute -50
+KPX Adieresis Ucircumflex -50
+KPX Adieresis Udieresis -50
+KPX Adieresis Ugrave -50
+KPX Adieresis Uhungarumlaut -50
+KPX Adieresis Umacron -50
+KPX Adieresis Uogonek -50
+KPX Adieresis Uring -50
+KPX Adieresis V -105
+KPX Adieresis W -95
+KPX Adieresis Y -55
+KPX Adieresis Yacute -55
+KPX Adieresis Ydieresis -55
+KPX Adieresis quoteright -37
+KPX Adieresis u -20
+KPX Adieresis uacute -20
+KPX Adieresis ucircumflex -20
+KPX Adieresis udieresis -20
+KPX Adieresis ugrave -20
+KPX Adieresis uhungarumlaut -20
+KPX Adieresis umacron -20
+KPX Adieresis uogonek -20
+KPX Adieresis uring -20
+KPX Adieresis v -55
+KPX Adieresis w -55
+KPX Adieresis y -55
+KPX Adieresis yacute -55
+KPX Adieresis ydieresis -55
+KPX Agrave C -30
+KPX Agrave Cacute -30
+KPX Agrave Ccaron -30
+KPX Agrave Ccedilla -30
+KPX Agrave G -35
+KPX Agrave Gbreve -35
+KPX Agrave Gcommaaccent -35
+KPX Agrave O -40
+KPX Agrave Oacute -40
+KPX Agrave Ocircumflex -40
+KPX Agrave Odieresis -40
+KPX Agrave Ograve -40
+KPX Agrave Ohungarumlaut -40
+KPX Agrave Omacron -40
+KPX Agrave Oslash -40
+KPX Agrave Otilde -40
+KPX Agrave Q -40
+KPX Agrave T -37
+KPX Agrave Tcaron -37
+KPX Agrave Tcommaaccent -37
+KPX Agrave U -50
+KPX Agrave Uacute -50
+KPX Agrave Ucircumflex -50
+KPX Agrave Udieresis -50
+KPX Agrave Ugrave -50
+KPX Agrave Uhungarumlaut -50
+KPX Agrave Umacron -50
+KPX Agrave Uogonek -50
+KPX Agrave Uring -50
+KPX Agrave V -105
+KPX Agrave W -95
+KPX Agrave Y -55
+KPX Agrave Yacute -55
+KPX Agrave Ydieresis -55
+KPX Agrave quoteright -37
+KPX Agrave u -20
+KPX Agrave uacute -20
+KPX Agrave ucircumflex -20
+KPX Agrave udieresis -20
+KPX Agrave ugrave -20
+KPX Agrave uhungarumlaut -20
+KPX Agrave umacron -20
+KPX Agrave uogonek -20
+KPX Agrave uring -20
+KPX Agrave v -55
+KPX Agrave w -55
+KPX Agrave y -55
+KPX Agrave yacute -55
+KPX Agrave ydieresis -55
+KPX Amacron C -30
+KPX Amacron Cacute -30
+KPX Amacron Ccaron -30
+KPX Amacron Ccedilla -30
+KPX Amacron G -35
+KPX Amacron Gbreve -35
+KPX Amacron Gcommaaccent -35
+KPX Amacron O -40
+KPX Amacron Oacute -40
+KPX Amacron Ocircumflex -40
+KPX Amacron Odieresis -40
+KPX Amacron Ograve -40
+KPX Amacron Ohungarumlaut -40
+KPX Amacron Omacron -40
+KPX Amacron Oslash -40
+KPX Amacron Otilde -40
+KPX Amacron Q -40
+KPX Amacron T -37
+KPX Amacron Tcaron -37
+KPX Amacron Tcommaaccent -37
+KPX Amacron U -50
+KPX Amacron Uacute -50
+KPX Amacron Ucircumflex -50
+KPX Amacron Udieresis -50
+KPX Amacron Ugrave -50
+KPX Amacron Uhungarumlaut -50
+KPX Amacron Umacron -50
+KPX Amacron Uogonek -50
+KPX Amacron Uring -50
+KPX Amacron V -105
+KPX Amacron W -95
+KPX Amacron Y -55
+KPX Amacron Yacute -55
+KPX Amacron Ydieresis -55
+KPX Amacron quoteright -37
+KPX Amacron u -20
+KPX Amacron uacute -20
+KPX Amacron ucircumflex -20
+KPX Amacron udieresis -20
+KPX Amacron ugrave -20
+KPX Amacron uhungarumlaut -20
+KPX Amacron umacron -20
+KPX Amacron uogonek -20
+KPX Amacron uring -20
+KPX Amacron v -55
+KPX Amacron w -55
+KPX Amacron y -55
+KPX Amacron yacute -55
+KPX Amacron ydieresis -55
+KPX Aogonek C -30
+KPX Aogonek Cacute -30
+KPX Aogonek Ccaron -30
+KPX Aogonek Ccedilla -30
+KPX Aogonek G -35
+KPX Aogonek Gbreve -35
+KPX Aogonek Gcommaaccent -35
+KPX Aogonek O -40
+KPX Aogonek Oacute -40
+KPX Aogonek Ocircumflex -40
+KPX Aogonek Odieresis -40
+KPX Aogonek Ograve -40
+KPX Aogonek Ohungarumlaut -40
+KPX Aogonek Omacron -40
+KPX Aogonek Oslash -40
+KPX Aogonek Otilde -40
+KPX Aogonek Q -40
+KPX Aogonek T -37
+KPX Aogonek Tcaron -37
+KPX Aogonek Tcommaaccent -37
+KPX Aogonek U -50
+KPX Aogonek Uacute -50
+KPX Aogonek Ucircumflex -50
+KPX Aogonek Udieresis -50
+KPX Aogonek Ugrave -50
+KPX Aogonek Uhungarumlaut -50
+KPX Aogonek Umacron -50
+KPX Aogonek Uogonek -50
+KPX Aogonek Uring -50
+KPX Aogonek V -105
+KPX Aogonek W -95
+KPX Aogonek Y -55
+KPX Aogonek Yacute -55
+KPX Aogonek Ydieresis -55
+KPX Aogonek quoteright -37
+KPX Aogonek u -20
+KPX Aogonek uacute -20
+KPX Aogonek ucircumflex -20
+KPX Aogonek udieresis -20
+KPX Aogonek ugrave -20
+KPX Aogonek uhungarumlaut -20
+KPX Aogonek umacron -20
+KPX Aogonek uogonek -20
+KPX Aogonek uring -20
+KPX Aogonek v -55
+KPX Aogonek w -55
+KPX Aogonek y -55
+KPX Aogonek yacute -55
+KPX Aogonek ydieresis -55
+KPX Aring C -30
+KPX Aring Cacute -30
+KPX Aring Ccaron -30
+KPX Aring Ccedilla -30
+KPX Aring G -35
+KPX Aring Gbreve -35
+KPX Aring Gcommaaccent -35
+KPX Aring O -40
+KPX Aring Oacute -40
+KPX Aring Ocircumflex -40
+KPX Aring Odieresis -40
+KPX Aring Ograve -40
+KPX Aring Ohungarumlaut -40
+KPX Aring Omacron -40
+KPX Aring Oslash -40
+KPX Aring Otilde -40
+KPX Aring Q -40
+KPX Aring T -37
+KPX Aring Tcaron -37
+KPX Aring Tcommaaccent -37
+KPX Aring U -50
+KPX Aring Uacute -50
+KPX Aring Ucircumflex -50
+KPX Aring Udieresis -50
+KPX Aring Ugrave -50
+KPX Aring Uhungarumlaut -50
+KPX Aring Umacron -50
+KPX Aring Uogonek -50
+KPX Aring Uring -50
+KPX Aring V -105
+KPX Aring W -95
+KPX Aring Y -55
+KPX Aring Yacute -55
+KPX Aring Ydieresis -55
+KPX Aring quoteright -37
+KPX Aring u -20
+KPX Aring uacute -20
+KPX Aring ucircumflex -20
+KPX Aring udieresis -20
+KPX Aring ugrave -20
+KPX Aring uhungarumlaut -20
+KPX Aring umacron -20
+KPX Aring uogonek -20
+KPX Aring uring -20
+KPX Aring v -55
+KPX Aring w -55
+KPX Aring y -55
+KPX Aring yacute -55
+KPX Aring ydieresis -55
+KPX Atilde C -30
+KPX Atilde Cacute -30
+KPX Atilde Ccaron -30
+KPX Atilde Ccedilla -30
+KPX Atilde G -35
+KPX Atilde Gbreve -35
+KPX Atilde Gcommaaccent -35
+KPX Atilde O -40
+KPX Atilde Oacute -40
+KPX Atilde Ocircumflex -40
+KPX Atilde Odieresis -40
+KPX Atilde Ograve -40
+KPX Atilde Ohungarumlaut -40
+KPX Atilde Omacron -40
+KPX Atilde Oslash -40
+KPX Atilde Otilde -40
+KPX Atilde Q -40
+KPX Atilde T -37
+KPX Atilde Tcaron -37
+KPX Atilde Tcommaaccent -37
+KPX Atilde U -50
+KPX Atilde Uacute -50
+KPX Atilde Ucircumflex -50
+KPX Atilde Udieresis -50
+KPX Atilde Ugrave -50
+KPX Atilde Uhungarumlaut -50
+KPX Atilde Umacron -50
+KPX Atilde Uogonek -50
+KPX Atilde Uring -50
+KPX Atilde V -105
+KPX Atilde W -95
+KPX Atilde Y -55
+KPX Atilde Yacute -55
+KPX Atilde Ydieresis -55
+KPX Atilde quoteright -37
+KPX Atilde u -20
+KPX Atilde uacute -20
+KPX Atilde ucircumflex -20
+KPX Atilde udieresis -20
+KPX Atilde ugrave -20
+KPX Atilde uhungarumlaut -20
+KPX Atilde umacron -20
+KPX Atilde uogonek -20
+KPX Atilde uring -20
+KPX Atilde v -55
+KPX Atilde w -55
+KPX Atilde y -55
+KPX Atilde yacute -55
+KPX Atilde ydieresis -55
+KPX B A -25
+KPX B Aacute -25
+KPX B Abreve -25
+KPX B Acircumflex -25
+KPX B Adieresis -25
+KPX B Agrave -25
+KPX B Amacron -25
+KPX B Aogonek -25
+KPX B Aring -25
+KPX B Atilde -25
+KPX B U -10
+KPX B Uacute -10
+KPX B Ucircumflex -10
+KPX B Udieresis -10
+KPX B Ugrave -10
+KPX B Uhungarumlaut -10
+KPX B Umacron -10
+KPX B Uogonek -10
+KPX B Uring -10
+KPX D A -35
+KPX D Aacute -35
+KPX D Abreve -35
+KPX D Acircumflex -35
+KPX D Adieresis -35
+KPX D Agrave -35
+KPX D Amacron -35
+KPX D Aogonek -35
+KPX D Aring -35
+KPX D Atilde -35
+KPX D V -40
+KPX D W -40
+KPX D Y -40
+KPX D Yacute -40
+KPX D Ydieresis -40
+KPX Dcaron A -35
+KPX Dcaron Aacute -35
+KPX Dcaron Abreve -35
+KPX Dcaron Acircumflex -35
+KPX Dcaron Adieresis -35
+KPX Dcaron Agrave -35
+KPX Dcaron Amacron -35
+KPX Dcaron Aogonek -35
+KPX Dcaron Aring -35
+KPX Dcaron Atilde -35
+KPX Dcaron V -40
+KPX Dcaron W -40
+KPX Dcaron Y -40
+KPX Dcaron Yacute -40
+KPX Dcaron Ydieresis -40
+KPX Dcroat A -35
+KPX Dcroat Aacute -35
+KPX Dcroat Abreve -35
+KPX Dcroat Acircumflex -35
+KPX Dcroat Adieresis -35
+KPX Dcroat Agrave -35
+KPX Dcroat Amacron -35
+KPX Dcroat Aogonek -35
+KPX Dcroat Aring -35
+KPX Dcroat Atilde -35
+KPX Dcroat V -40
+KPX Dcroat W -40
+KPX Dcroat Y -40
+KPX Dcroat Yacute -40
+KPX Dcroat Ydieresis -40
+KPX F A -115
+KPX F Aacute -115
+KPX F Abreve -115
+KPX F Acircumflex -115
+KPX F Adieresis -115
+KPX F Agrave -115
+KPX F Amacron -115
+KPX F Aogonek -115
+KPX F Aring -115
+KPX F Atilde -115
+KPX F a -75
+KPX F aacute -75
+KPX F abreve -75
+KPX F acircumflex -75
+KPX F adieresis -75
+KPX F agrave -75
+KPX F amacron -75
+KPX F aogonek -75
+KPX F aring -75
+KPX F atilde -75
+KPX F comma -135
+KPX F e -75
+KPX F eacute -75
+KPX F ecaron -75
+KPX F ecircumflex -75
+KPX F edieresis -75
+KPX F edotaccent -75
+KPX F egrave -75
+KPX F emacron -75
+KPX F eogonek -75
+KPX F i -45
+KPX F iacute -45
+KPX F icircumflex -45
+KPX F idieresis -45
+KPX F igrave -45
+KPX F imacron -45
+KPX F iogonek -45
+KPX F o -105
+KPX F oacute -105
+KPX F ocircumflex -105
+KPX F odieresis -105
+KPX F ograve -105
+KPX F ohungarumlaut -105
+KPX F omacron -105
+KPX F oslash -105
+KPX F otilde -105
+KPX F period -135
+KPX F r -55
+KPX F racute -55
+KPX F rcaron -55
+KPX F rcommaaccent -55
+KPX J A -40
+KPX J Aacute -40
+KPX J Abreve -40
+KPX J Acircumflex -40
+KPX J Adieresis -40
+KPX J Agrave -40
+KPX J Amacron -40
+KPX J Aogonek -40
+KPX J Aring -40
+KPX J Atilde -40
+KPX J a -35
+KPX J aacute -35
+KPX J abreve -35
+KPX J acircumflex -35
+KPX J adieresis -35
+KPX J agrave -35
+KPX J amacron -35
+KPX J aogonek -35
+KPX J aring -35
+KPX J atilde -35
+KPX J comma -25
+KPX J e -25
+KPX J eacute -25
+KPX J ecaron -25
+KPX J ecircumflex -25
+KPX J edieresis -25
+KPX J edotaccent -25
+KPX J egrave -25
+KPX J emacron -25
+KPX J eogonek -25
+KPX J o -25
+KPX J oacute -25
+KPX J ocircumflex -25
+KPX J odieresis -25
+KPX J ograve -25
+KPX J ohungarumlaut -25
+KPX J omacron -25
+KPX J oslash -25
+KPX J otilde -25
+KPX J period -25
+KPX J u -35
+KPX J uacute -35
+KPX J ucircumflex -35
+KPX J udieresis -35
+KPX J ugrave -35
+KPX J uhungarumlaut -35
+KPX J umacron -35
+KPX J uogonek -35
+KPX J uring -35
+KPX K O -50
+KPX K Oacute -50
+KPX K Ocircumflex -50
+KPX K Odieresis -50
+KPX K Ograve -50
+KPX K Ohungarumlaut -50
+KPX K Omacron -50
+KPX K Oslash -50
+KPX K Otilde -50
+KPX K e -35
+KPX K eacute -35
+KPX K ecaron -35
+KPX K ecircumflex -35
+KPX K edieresis -35
+KPX K edotaccent -35
+KPX K egrave -35
+KPX K emacron -35
+KPX K eogonek -35
+KPX K o -40
+KPX K oacute -40
+KPX K ocircumflex -40
+KPX K odieresis -40
+KPX K ograve -40
+KPX K ohungarumlaut -40
+KPX K omacron -40
+KPX K oslash -40
+KPX K otilde -40
+KPX K u -40
+KPX K uacute -40
+KPX K ucircumflex -40
+KPX K udieresis -40
+KPX K ugrave -40
+KPX K uhungarumlaut -40
+KPX K umacron -40
+KPX K uogonek -40
+KPX K uring -40
+KPX K y -40
+KPX K yacute -40
+KPX K ydieresis -40
+KPX Kcommaaccent O -50
+KPX Kcommaaccent Oacute -50
+KPX Kcommaaccent Ocircumflex -50
+KPX Kcommaaccent Odieresis -50
+KPX Kcommaaccent Ograve -50
+KPX Kcommaaccent Ohungarumlaut -50
+KPX Kcommaaccent Omacron -50
+KPX Kcommaaccent Oslash -50
+KPX Kcommaaccent Otilde -50
+KPX Kcommaaccent e -35
+KPX Kcommaaccent eacute -35
+KPX Kcommaaccent ecaron -35
+KPX Kcommaaccent ecircumflex -35
+KPX Kcommaaccent edieresis -35
+KPX Kcommaaccent edotaccent -35
+KPX Kcommaaccent egrave -35
+KPX Kcommaaccent emacron -35
+KPX Kcommaaccent eogonek -35
+KPX Kcommaaccent o -40
+KPX Kcommaaccent oacute -40
+KPX Kcommaaccent ocircumflex -40
+KPX Kcommaaccent odieresis -40
+KPX Kcommaaccent ograve -40
+KPX Kcommaaccent ohungarumlaut -40
+KPX Kcommaaccent omacron -40
+KPX Kcommaaccent oslash -40
+KPX Kcommaaccent otilde -40
+KPX Kcommaaccent u -40
+KPX Kcommaaccent uacute -40
+KPX Kcommaaccent ucircumflex -40
+KPX Kcommaaccent udieresis -40
+KPX Kcommaaccent ugrave -40
+KPX Kcommaaccent uhungarumlaut -40
+KPX Kcommaaccent umacron -40
+KPX Kcommaaccent uogonek -40
+KPX Kcommaaccent uring -40
+KPX Kcommaaccent y -40
+KPX Kcommaaccent yacute -40
+KPX Kcommaaccent ydieresis -40
+KPX L T -20
+KPX L Tcaron -20
+KPX L Tcommaaccent -20
+KPX L V -55
+KPX L W -55
+KPX L Y -20
+KPX L Yacute -20
+KPX L Ydieresis -20
+KPX L quoteright -37
+KPX L y -30
+KPX L yacute -30
+KPX L ydieresis -30
+KPX Lacute T -20
+KPX Lacute Tcaron -20
+KPX Lacute Tcommaaccent -20
+KPX Lacute V -55
+KPX Lacute W -55
+KPX Lacute Y -20
+KPX Lacute Yacute -20
+KPX Lacute Ydieresis -20
+KPX Lacute quoteright -37
+KPX Lacute y -30
+KPX Lacute yacute -30
+KPX Lacute ydieresis -30
+KPX Lcommaaccent T -20
+KPX Lcommaaccent Tcaron -20
+KPX Lcommaaccent Tcommaaccent -20
+KPX Lcommaaccent V -55
+KPX Lcommaaccent W -55
+KPX Lcommaaccent Y -20
+KPX Lcommaaccent Yacute -20
+KPX Lcommaaccent Ydieresis -20
+KPX Lcommaaccent quoteright -37
+KPX Lcommaaccent y -30
+KPX Lcommaaccent yacute -30
+KPX Lcommaaccent ydieresis -30
+KPX Lslash T -20
+KPX Lslash Tcaron -20
+KPX Lslash Tcommaaccent -20
+KPX Lslash V -55
+KPX Lslash W -55
+KPX Lslash Y -20
+KPX Lslash Yacute -20
+KPX Lslash Ydieresis -20
+KPX Lslash quoteright -37
+KPX Lslash y -30
+KPX Lslash yacute -30
+KPX Lslash ydieresis -30
+KPX N A -27
+KPX N Aacute -27
+KPX N Abreve -27
+KPX N Acircumflex -27
+KPX N Adieresis -27
+KPX N Agrave -27
+KPX N Amacron -27
+KPX N Aogonek -27
+KPX N Aring -27
+KPX N Atilde -27
+KPX Nacute A -27
+KPX Nacute Aacute -27
+KPX Nacute Abreve -27
+KPX Nacute Acircumflex -27
+KPX Nacute Adieresis -27
+KPX Nacute Agrave -27
+KPX Nacute Amacron -27
+KPX Nacute Aogonek -27
+KPX Nacute Aring -27
+KPX Nacute Atilde -27
+KPX Ncaron A -27
+KPX Ncaron Aacute -27
+KPX Ncaron Abreve -27
+KPX Ncaron Acircumflex -27
+KPX Ncaron Adieresis -27
+KPX Ncaron Agrave -27
+KPX Ncaron Amacron -27
+KPX Ncaron Aogonek -27
+KPX Ncaron Aring -27
+KPX Ncaron Atilde -27
+KPX Ncommaaccent A -27
+KPX Ncommaaccent Aacute -27
+KPX Ncommaaccent Abreve -27
+KPX Ncommaaccent Acircumflex -27
+KPX Ncommaaccent Adieresis -27
+KPX Ncommaaccent Agrave -27
+KPX Ncommaaccent Amacron -27
+KPX Ncommaaccent Aogonek -27
+KPX Ncommaaccent Aring -27
+KPX Ncommaaccent Atilde -27
+KPX Ntilde A -27
+KPX Ntilde Aacute -27
+KPX Ntilde Abreve -27
+KPX Ntilde Acircumflex -27
+KPX Ntilde Adieresis -27
+KPX Ntilde Agrave -27
+KPX Ntilde Amacron -27
+KPX Ntilde Aogonek -27
+KPX Ntilde Aring -27
+KPX Ntilde Atilde -27
+KPX O A -55
+KPX O Aacute -55
+KPX O Abreve -55
+KPX O Acircumflex -55
+KPX O Adieresis -55
+KPX O Agrave -55
+KPX O Amacron -55
+KPX O Aogonek -55
+KPX O Aring -55
+KPX O Atilde -55
+KPX O T -40
+KPX O Tcaron -40
+KPX O Tcommaaccent -40
+KPX O V -50
+KPX O W -50
+KPX O X -40
+KPX O Y -50
+KPX O Yacute -50
+KPX O Ydieresis -50
+KPX Oacute A -55
+KPX Oacute Aacute -55
+KPX Oacute Abreve -55
+KPX Oacute Acircumflex -55
+KPX Oacute Adieresis -55
+KPX Oacute Agrave -55
+KPX Oacute Amacron -55
+KPX Oacute Aogonek -55
+KPX Oacute Aring -55
+KPX Oacute Atilde -55
+KPX Oacute T -40
+KPX Oacute Tcaron -40
+KPX Oacute Tcommaaccent -40
+KPX Oacute V -50
+KPX Oacute W -50
+KPX Oacute X -40
+KPX Oacute Y -50
+KPX Oacute Yacute -50
+KPX Oacute Ydieresis -50
+KPX Ocircumflex A -55
+KPX Ocircumflex Aacute -55
+KPX Ocircumflex Abreve -55
+KPX Ocircumflex Acircumflex -55
+KPX Ocircumflex Adieresis -55
+KPX Ocircumflex Agrave -55
+KPX Ocircumflex Amacron -55
+KPX Ocircumflex Aogonek -55
+KPX Ocircumflex Aring -55
+KPX Ocircumflex Atilde -55
+KPX Ocircumflex T -40
+KPX Ocircumflex Tcaron -40
+KPX Ocircumflex Tcommaaccent -40
+KPX Ocircumflex V -50
+KPX Ocircumflex W -50
+KPX Ocircumflex X -40
+KPX Ocircumflex Y -50
+KPX Ocircumflex Yacute -50
+KPX Ocircumflex Ydieresis -50
+KPX Odieresis A -55
+KPX Odieresis Aacute -55
+KPX Odieresis Abreve -55
+KPX Odieresis Acircumflex -55
+KPX Odieresis Adieresis -55
+KPX Odieresis Agrave -55
+KPX Odieresis Amacron -55
+KPX Odieresis Aogonek -55
+KPX Odieresis Aring -55
+KPX Odieresis Atilde -55
+KPX Odieresis T -40
+KPX Odieresis Tcaron -40
+KPX Odieresis Tcommaaccent -40
+KPX Odieresis V -50
+KPX Odieresis W -50
+KPX Odieresis X -40
+KPX Odieresis Y -50
+KPX Odieresis Yacute -50
+KPX Odieresis Ydieresis -50
+KPX Ograve A -55
+KPX Ograve Aacute -55
+KPX Ograve Abreve -55
+KPX Ograve Acircumflex -55
+KPX Ograve Adieresis -55
+KPX Ograve Agrave -55
+KPX Ograve Amacron -55
+KPX Ograve Aogonek -55
+KPX Ograve Aring -55
+KPX Ograve Atilde -55
+KPX Ograve T -40
+KPX Ograve Tcaron -40
+KPX Ograve Tcommaaccent -40
+KPX Ograve V -50
+KPX Ograve W -50
+KPX Ograve X -40
+KPX Ograve Y -50
+KPX Ograve Yacute -50
+KPX Ograve Ydieresis -50
+KPX Ohungarumlaut A -55
+KPX Ohungarumlaut Aacute -55
+KPX Ohungarumlaut Abreve -55
+KPX Ohungarumlaut Acircumflex -55
+KPX Ohungarumlaut Adieresis -55
+KPX Ohungarumlaut Agrave -55
+KPX Ohungarumlaut Amacron -55
+KPX Ohungarumlaut Aogonek -55
+KPX Ohungarumlaut Aring -55
+KPX Ohungarumlaut Atilde -55
+KPX Ohungarumlaut T -40
+KPX Ohungarumlaut Tcaron -40
+KPX Ohungarumlaut Tcommaaccent -40
+KPX Ohungarumlaut V -50
+KPX Ohungarumlaut W -50
+KPX Ohungarumlaut X -40
+KPX Ohungarumlaut Y -50
+KPX Ohungarumlaut Yacute -50
+KPX Ohungarumlaut Ydieresis -50
+KPX Omacron A -55
+KPX Omacron Aacute -55
+KPX Omacron Abreve -55
+KPX Omacron Acircumflex -55
+KPX Omacron Adieresis -55
+KPX Omacron Agrave -55
+KPX Omacron Amacron -55
+KPX Omacron Aogonek -55
+KPX Omacron Aring -55
+KPX Omacron Atilde -55
+KPX Omacron T -40
+KPX Omacron Tcaron -40
+KPX Omacron Tcommaaccent -40
+KPX Omacron V -50
+KPX Omacron W -50
+KPX Omacron X -40
+KPX Omacron Y -50
+KPX Omacron Yacute -50
+KPX Omacron Ydieresis -50
+KPX Oslash A -55
+KPX Oslash Aacute -55
+KPX Oslash Abreve -55
+KPX Oslash Acircumflex -55
+KPX Oslash Adieresis -55
+KPX Oslash Agrave -55
+KPX Oslash Amacron -55
+KPX Oslash Aogonek -55
+KPX Oslash Aring -55
+KPX Oslash Atilde -55
+KPX Oslash T -40
+KPX Oslash Tcaron -40
+KPX Oslash Tcommaaccent -40
+KPX Oslash V -50
+KPX Oslash W -50
+KPX Oslash X -40
+KPX Oslash Y -50
+KPX Oslash Yacute -50
+KPX Oslash Ydieresis -50
+KPX Otilde A -55
+KPX Otilde Aacute -55
+KPX Otilde Abreve -55
+KPX Otilde Acircumflex -55
+KPX Otilde Adieresis -55
+KPX Otilde Agrave -55
+KPX Otilde Amacron -55
+KPX Otilde Aogonek -55
+KPX Otilde Aring -55
+KPX Otilde Atilde -55
+KPX Otilde T -40
+KPX Otilde Tcaron -40
+KPX Otilde Tcommaaccent -40
+KPX Otilde V -50
+KPX Otilde W -50
+KPX Otilde X -40
+KPX Otilde Y -50
+KPX Otilde Yacute -50
+KPX Otilde Ydieresis -50
+KPX P A -90
+KPX P Aacute -90
+KPX P Abreve -90
+KPX P Acircumflex -90
+KPX P Adieresis -90
+KPX P Agrave -90
+KPX P Amacron -90
+KPX P Aogonek -90
+KPX P Aring -90
+KPX P Atilde -90
+KPX P a -80
+KPX P aacute -80
+KPX P abreve -80
+KPX P acircumflex -80
+KPX P adieresis -80
+KPX P agrave -80
+KPX P amacron -80
+KPX P aogonek -80
+KPX P aring -80
+KPX P atilde -80
+KPX P comma -135
+KPX P e -80
+KPX P eacute -80
+KPX P ecaron -80
+KPX P ecircumflex -80
+KPX P edieresis -80
+KPX P edotaccent -80
+KPX P egrave -80
+KPX P emacron -80
+KPX P eogonek -80
+KPX P o -80
+KPX P oacute -80
+KPX P ocircumflex -80
+KPX P odieresis -80
+KPX P ograve -80
+KPX P ohungarumlaut -80
+KPX P omacron -80
+KPX P oslash -80
+KPX P otilde -80
+KPX P period -135
+KPX Q U -10
+KPX Q Uacute -10
+KPX Q Ucircumflex -10
+KPX Q Udieresis -10
+KPX Q Ugrave -10
+KPX Q Uhungarumlaut -10
+KPX Q Umacron -10
+KPX Q Uogonek -10
+KPX Q Uring -10
+KPX R O -40
+KPX R Oacute -40
+KPX R Ocircumflex -40
+KPX R Odieresis -40
+KPX R Ograve -40
+KPX R Ohungarumlaut -40
+KPX R Omacron -40
+KPX R Oslash -40
+KPX R Otilde -40
+KPX R U -40
+KPX R Uacute -40
+KPX R Ucircumflex -40
+KPX R Udieresis -40
+KPX R Ugrave -40
+KPX R Uhungarumlaut -40
+KPX R Umacron -40
+KPX R Uogonek -40
+KPX R Uring -40
+KPX R V -18
+KPX R W -18
+KPX R Y -18
+KPX R Yacute -18
+KPX R Ydieresis -18
+KPX Racute O -40
+KPX Racute Oacute -40
+KPX Racute Ocircumflex -40
+KPX Racute Odieresis -40
+KPX Racute Ograve -40
+KPX Racute Ohungarumlaut -40
+KPX Racute Omacron -40
+KPX Racute Oslash -40
+KPX Racute Otilde -40
+KPX Racute U -40
+KPX Racute Uacute -40
+KPX Racute Ucircumflex -40
+KPX Racute Udieresis -40
+KPX Racute Ugrave -40
+KPX Racute Uhungarumlaut -40
+KPX Racute Umacron -40
+KPX Racute Uogonek -40
+KPX Racute Uring -40
+KPX Racute V -18
+KPX Racute W -18
+KPX Racute Y -18
+KPX Racute Yacute -18
+KPX Racute Ydieresis -18
+KPX Rcaron O -40
+KPX Rcaron Oacute -40
+KPX Rcaron Ocircumflex -40
+KPX Rcaron Odieresis -40
+KPX Rcaron Ograve -40
+KPX Rcaron Ohungarumlaut -40
+KPX Rcaron Omacron -40
+KPX Rcaron Oslash -40
+KPX Rcaron Otilde -40
+KPX Rcaron U -40
+KPX Rcaron Uacute -40
+KPX Rcaron Ucircumflex -40
+KPX Rcaron Udieresis -40
+KPX Rcaron Ugrave -40
+KPX Rcaron Uhungarumlaut -40
+KPX Rcaron Umacron -40
+KPX Rcaron Uogonek -40
+KPX Rcaron Uring -40
+KPX Rcaron V -18
+KPX Rcaron W -18
+KPX Rcaron Y -18
+KPX Rcaron Yacute -18
+KPX Rcaron Ydieresis -18
+KPX Rcommaaccent O -40
+KPX Rcommaaccent Oacute -40
+KPX Rcommaaccent Ocircumflex -40
+KPX Rcommaaccent Odieresis -40
+KPX Rcommaaccent Ograve -40
+KPX Rcommaaccent Ohungarumlaut -40
+KPX Rcommaaccent Omacron -40
+KPX Rcommaaccent Oslash -40
+KPX Rcommaaccent Otilde -40
+KPX Rcommaaccent U -40
+KPX Rcommaaccent Uacute -40
+KPX Rcommaaccent Ucircumflex -40
+KPX Rcommaaccent Udieresis -40
+KPX Rcommaaccent Ugrave -40
+KPX Rcommaaccent Uhungarumlaut -40
+KPX Rcommaaccent Umacron -40
+KPX Rcommaaccent Uogonek -40
+KPX Rcommaaccent Uring -40
+KPX Rcommaaccent V -18
+KPX Rcommaaccent W -18
+KPX Rcommaaccent Y -18
+KPX Rcommaaccent Yacute -18
+KPX Rcommaaccent Ydieresis -18
+KPX T A -50
+KPX T Aacute -50
+KPX T Abreve -50
+KPX T Acircumflex -50
+KPX T Adieresis -50
+KPX T Agrave -50
+KPX T Amacron -50
+KPX T Aogonek -50
+KPX T Aring -50
+KPX T Atilde -50
+KPX T O -18
+KPX T Oacute -18
+KPX T Ocircumflex -18
+KPX T Odieresis -18
+KPX T Ograve -18
+KPX T Ohungarumlaut -18
+KPX T Omacron -18
+KPX T Oslash -18
+KPX T Otilde -18
+KPX T a -92
+KPX T aacute -92
+KPX T abreve -92
+KPX T acircumflex -92
+KPX T adieresis -92
+KPX T agrave -92
+KPX T amacron -92
+KPX T aogonek -92
+KPX T aring -92
+KPX T atilde -92
+KPX T colon -55
+KPX T comma -74
+KPX T e -92
+KPX T eacute -92
+KPX T ecaron -92
+KPX T ecircumflex -52
+KPX T edieresis -52
+KPX T edotaccent -92
+KPX T egrave -52
+KPX T emacron -52
+KPX T eogonek -92
+KPX T hyphen -74
+KPX T i -55
+KPX T iacute -55
+KPX T iogonek -55
+KPX T o -92
+KPX T oacute -92
+KPX T ocircumflex -92
+KPX T odieresis -92
+KPX T ograve -92
+KPX T ohungarumlaut -92
+KPX T omacron -92
+KPX T oslash -92
+KPX T otilde -92
+KPX T period -74
+KPX T r -55
+KPX T racute -55
+KPX T rcaron -55
+KPX T rcommaaccent -55
+KPX T semicolon -65
+KPX T u -55
+KPX T uacute -55
+KPX T ucircumflex -55
+KPX T udieresis -55
+KPX T ugrave -55
+KPX T uhungarumlaut -55
+KPX T umacron -55
+KPX T uogonek -55
+KPX T uring -55
+KPX T w -74
+KPX T y -74
+KPX T yacute -74
+KPX T ydieresis -34
+KPX Tcaron A -50
+KPX Tcaron Aacute -50
+KPX Tcaron Abreve -50
+KPX Tcaron Acircumflex -50
+KPX Tcaron Adieresis -50
+KPX Tcaron Agrave -50
+KPX Tcaron Amacron -50
+KPX Tcaron Aogonek -50
+KPX Tcaron Aring -50
+KPX Tcaron Atilde -50
+KPX Tcaron O -18
+KPX Tcaron Oacute -18
+KPX Tcaron Ocircumflex -18
+KPX Tcaron Odieresis -18
+KPX Tcaron Ograve -18
+KPX Tcaron Ohungarumlaut -18
+KPX Tcaron Omacron -18
+KPX Tcaron Oslash -18
+KPX Tcaron Otilde -18
+KPX Tcaron a -92
+KPX Tcaron aacute -92
+KPX Tcaron abreve -92
+KPX Tcaron acircumflex -92
+KPX Tcaron adieresis -92
+KPX Tcaron agrave -92
+KPX Tcaron amacron -92
+KPX Tcaron aogonek -92
+KPX Tcaron aring -92
+KPX Tcaron atilde -92
+KPX Tcaron colon -55
+KPX Tcaron comma -74
+KPX Tcaron e -92
+KPX Tcaron eacute -92
+KPX Tcaron ecaron -92
+KPX Tcaron ecircumflex -52
+KPX Tcaron edieresis -52
+KPX Tcaron edotaccent -92
+KPX Tcaron egrave -52
+KPX Tcaron emacron -52
+KPX Tcaron eogonek -92
+KPX Tcaron hyphen -74
+KPX Tcaron i -55
+KPX Tcaron iacute -55
+KPX Tcaron iogonek -55
+KPX Tcaron o -92
+KPX Tcaron oacute -92
+KPX Tcaron ocircumflex -92
+KPX Tcaron odieresis -92
+KPX Tcaron ograve -92
+KPX Tcaron ohungarumlaut -92
+KPX Tcaron omacron -92
+KPX Tcaron oslash -92
+KPX Tcaron otilde -92
+KPX Tcaron period -74
+KPX Tcaron r -55
+KPX Tcaron racute -55
+KPX Tcaron rcaron -55
+KPX Tcaron rcommaaccent -55
+KPX Tcaron semicolon -65
+KPX Tcaron u -55
+KPX Tcaron uacute -55
+KPX Tcaron ucircumflex -55
+KPX Tcaron udieresis -55
+KPX Tcaron ugrave -55
+KPX Tcaron uhungarumlaut -55
+KPX Tcaron umacron -55
+KPX Tcaron uogonek -55
+KPX Tcaron uring -55
+KPX Tcaron w -74
+KPX Tcaron y -74
+KPX Tcaron yacute -74
+KPX Tcaron ydieresis -34
+KPX Tcommaaccent A -50
+KPX Tcommaaccent Aacute -50
+KPX Tcommaaccent Abreve -50
+KPX Tcommaaccent Acircumflex -50
+KPX Tcommaaccent Adieresis -50
+KPX Tcommaaccent Agrave -50
+KPX Tcommaaccent Amacron -50
+KPX Tcommaaccent Aogonek -50
+KPX Tcommaaccent Aring -50
+KPX Tcommaaccent Atilde -50
+KPX Tcommaaccent O -18
+KPX Tcommaaccent Oacute -18
+KPX Tcommaaccent Ocircumflex -18
+KPX Tcommaaccent Odieresis -18
+KPX Tcommaaccent Ograve -18
+KPX Tcommaaccent Ohungarumlaut -18
+KPX Tcommaaccent Omacron -18
+KPX Tcommaaccent Oslash -18
+KPX Tcommaaccent Otilde -18
+KPX Tcommaaccent a -92
+KPX Tcommaaccent aacute -92
+KPX Tcommaaccent abreve -92
+KPX Tcommaaccent acircumflex -92
+KPX Tcommaaccent adieresis -92
+KPX Tcommaaccent agrave -92
+KPX Tcommaaccent amacron -92
+KPX Tcommaaccent aogonek -92
+KPX Tcommaaccent aring -92
+KPX Tcommaaccent atilde -92
+KPX Tcommaaccent colon -55
+KPX Tcommaaccent comma -74
+KPX Tcommaaccent e -92
+KPX Tcommaaccent eacute -92
+KPX Tcommaaccent ecaron -92
+KPX Tcommaaccent ecircumflex -52
+KPX Tcommaaccent edieresis -52
+KPX Tcommaaccent edotaccent -92
+KPX Tcommaaccent egrave -52
+KPX Tcommaaccent emacron -52
+KPX Tcommaaccent eogonek -92
+KPX Tcommaaccent hyphen -74
+KPX Tcommaaccent i -55
+KPX Tcommaaccent iacute -55
+KPX Tcommaaccent iogonek -55
+KPX Tcommaaccent o -92
+KPX Tcommaaccent oacute -92
+KPX Tcommaaccent ocircumflex -92
+KPX Tcommaaccent odieresis -92
+KPX Tcommaaccent ograve -92
+KPX Tcommaaccent ohungarumlaut -92
+KPX Tcommaaccent omacron -92
+KPX Tcommaaccent oslash -92
+KPX Tcommaaccent otilde -92
+KPX Tcommaaccent period -74
+KPX Tcommaaccent r -55
+KPX Tcommaaccent racute -55
+KPX Tcommaaccent rcaron -55
+KPX Tcommaaccent rcommaaccent -55
+KPX Tcommaaccent semicolon -65
+KPX Tcommaaccent u -55
+KPX Tcommaaccent uacute -55
+KPX Tcommaaccent ucircumflex -55
+KPX Tcommaaccent udieresis -55
+KPX Tcommaaccent ugrave -55
+KPX Tcommaaccent uhungarumlaut -55
+KPX Tcommaaccent umacron -55
+KPX Tcommaaccent uogonek -55
+KPX Tcommaaccent uring -55
+KPX Tcommaaccent w -74
+KPX Tcommaaccent y -74
+KPX Tcommaaccent yacute -74
+KPX Tcommaaccent ydieresis -34
+KPX U A -40
+KPX U Aacute -40
+KPX U Abreve -40
+KPX U Acircumflex -40
+KPX U Adieresis -40
+KPX U Agrave -40
+KPX U Amacron -40
+KPX U Aogonek -40
+KPX U Aring -40
+KPX U Atilde -40
+KPX U comma -25
+KPX U period -25
+KPX Uacute A -40
+KPX Uacute Aacute -40
+KPX Uacute Abreve -40
+KPX Uacute Acircumflex -40
+KPX Uacute Adieresis -40
+KPX Uacute Agrave -40
+KPX Uacute Amacron -40
+KPX Uacute Aogonek -40
+KPX Uacute Aring -40
+KPX Uacute Atilde -40
+KPX Uacute comma -25
+KPX Uacute period -25
+KPX Ucircumflex A -40
+KPX Ucircumflex Aacute -40
+KPX Ucircumflex Abreve -40
+KPX Ucircumflex Acircumflex -40
+KPX Ucircumflex Adieresis -40
+KPX Ucircumflex Agrave -40
+KPX Ucircumflex Amacron -40
+KPX Ucircumflex Aogonek -40
+KPX Ucircumflex Aring -40
+KPX Ucircumflex Atilde -40
+KPX Ucircumflex comma -25
+KPX Ucircumflex period -25
+KPX Udieresis A -40
+KPX Udieresis Aacute -40
+KPX Udieresis Abreve -40
+KPX Udieresis Acircumflex -40
+KPX Udieresis Adieresis -40
+KPX Udieresis Agrave -40
+KPX Udieresis Amacron -40
+KPX Udieresis Aogonek -40
+KPX Udieresis Aring -40
+KPX Udieresis Atilde -40
+KPX Udieresis comma -25
+KPX Udieresis period -25
+KPX Ugrave A -40
+KPX Ugrave Aacute -40
+KPX Ugrave Abreve -40
+KPX Ugrave Acircumflex -40
+KPX Ugrave Adieresis -40
+KPX Ugrave Agrave -40
+KPX Ugrave Amacron -40
+KPX Ugrave Aogonek -40
+KPX Ugrave Aring -40
+KPX Ugrave Atilde -40
+KPX Ugrave comma -25
+KPX Ugrave period -25
+KPX Uhungarumlaut A -40
+KPX Uhungarumlaut Aacute -40
+KPX Uhungarumlaut Abreve -40
+KPX Uhungarumlaut Acircumflex -40
+KPX Uhungarumlaut Adieresis -40
+KPX Uhungarumlaut Agrave -40
+KPX Uhungarumlaut Amacron -40
+KPX Uhungarumlaut Aogonek -40
+KPX Uhungarumlaut Aring -40
+KPX Uhungarumlaut Atilde -40
+KPX Uhungarumlaut comma -25
+KPX Uhungarumlaut period -25
+KPX Umacron A -40
+KPX Umacron Aacute -40
+KPX Umacron Abreve -40
+KPX Umacron Acircumflex -40
+KPX Umacron Adieresis -40
+KPX Umacron Agrave -40
+KPX Umacron Amacron -40
+KPX Umacron Aogonek -40
+KPX Umacron Aring -40
+KPX Umacron Atilde -40
+KPX Umacron comma -25
+KPX Umacron period -25
+KPX Uogonek A -40
+KPX Uogonek Aacute -40
+KPX Uogonek Abreve -40
+KPX Uogonek Acircumflex -40
+KPX Uogonek Adieresis -40
+KPX Uogonek Agrave -40
+KPX Uogonek Amacron -40
+KPX Uogonek Aogonek -40
+KPX Uogonek Aring -40
+KPX Uogonek Atilde -40
+KPX Uogonek comma -25
+KPX Uogonek period -25
+KPX Uring A -40
+KPX Uring Aacute -40
+KPX Uring Abreve -40
+KPX Uring Acircumflex -40
+KPX Uring Adieresis -40
+KPX Uring Agrave -40
+KPX Uring Amacron -40
+KPX Uring Aogonek -40
+KPX Uring Aring -40
+KPX Uring Atilde -40
+KPX Uring comma -25
+KPX Uring period -25
+KPX V A -60
+KPX V Aacute -60
+KPX V Abreve -60
+KPX V Acircumflex -60
+KPX V Adieresis -60
+KPX V Agrave -60
+KPX V Amacron -60
+KPX V Aogonek -60
+KPX V Aring -60
+KPX V Atilde -60
+KPX V O -30
+KPX V Oacute -30
+KPX V Ocircumflex -30
+KPX V Odieresis -30
+KPX V Ograve -30
+KPX V Ohungarumlaut -30
+KPX V Omacron -30
+KPX V Oslash -30
+KPX V Otilde -30
+KPX V a -111
+KPX V aacute -111
+KPX V abreve -111
+KPX V acircumflex -111
+KPX V adieresis -111
+KPX V agrave -111
+KPX V amacron -111
+KPX V aogonek -111
+KPX V aring -111
+KPX V atilde -111
+KPX V colon -65
+KPX V comma -129
+KPX V e -111
+KPX V eacute -111
+KPX V ecaron -111
+KPX V ecircumflex -111
+KPX V edieresis -71
+KPX V edotaccent -111
+KPX V egrave -71
+KPX V emacron -71
+KPX V eogonek -111
+KPX V hyphen -55
+KPX V i -74
+KPX V iacute -74
+KPX V icircumflex -34
+KPX V idieresis -34
+KPX V igrave -34
+KPX V imacron -34
+KPX V iogonek -74
+KPX V o -111
+KPX V oacute -111
+KPX V ocircumflex -111
+KPX V odieresis -111
+KPX V ograve -111
+KPX V ohungarumlaut -111
+KPX V omacron -111
+KPX V oslash -111
+KPX V otilde -111
+KPX V period -129
+KPX V semicolon -74
+KPX V u -74
+KPX V uacute -74
+KPX V ucircumflex -74
+KPX V udieresis -74
+KPX V ugrave -74
+KPX V uhungarumlaut -74
+KPX V umacron -74
+KPX V uogonek -74
+KPX V uring -74
+KPX W A -60
+KPX W Aacute -60
+KPX W Abreve -60
+KPX W Acircumflex -60
+KPX W Adieresis -60
+KPX W Agrave -60
+KPX W Amacron -60
+KPX W Aogonek -60
+KPX W Aring -60
+KPX W Atilde -60
+KPX W O -25
+KPX W Oacute -25
+KPX W Ocircumflex -25
+KPX W Odieresis -25
+KPX W Ograve -25
+KPX W Ohungarumlaut -25
+KPX W Omacron -25
+KPX W Oslash -25
+KPX W Otilde -25
+KPX W a -92
+KPX W aacute -92
+KPX W abreve -92
+KPX W acircumflex -92
+KPX W adieresis -92
+KPX W agrave -92
+KPX W amacron -92
+KPX W aogonek -92
+KPX W aring -92
+KPX W atilde -92
+KPX W colon -65
+KPX W comma -92
+KPX W e -92
+KPX W eacute -92
+KPX W ecaron -92
+KPX W ecircumflex -92
+KPX W edieresis -52
+KPX W edotaccent -92
+KPX W egrave -52
+KPX W emacron -52
+KPX W eogonek -92
+KPX W hyphen -37
+KPX W i -55
+KPX W iacute -55
+KPX W iogonek -55
+KPX W o -92
+KPX W oacute -92
+KPX W ocircumflex -92
+KPX W odieresis -92
+KPX W ograve -92
+KPX W ohungarumlaut -92
+KPX W omacron -92
+KPX W oslash -92
+KPX W otilde -92
+KPX W period -92
+KPX W semicolon -65
+KPX W u -55
+KPX W uacute -55
+KPX W ucircumflex -55
+KPX W udieresis -55
+KPX W ugrave -55
+KPX W uhungarumlaut -55
+KPX W umacron -55
+KPX W uogonek -55
+KPX W uring -55
+KPX W y -70
+KPX W yacute -70
+KPX W ydieresis -70
+KPX Y A -50
+KPX Y Aacute -50
+KPX Y Abreve -50
+KPX Y Acircumflex -50
+KPX Y Adieresis -50
+KPX Y Agrave -50
+KPX Y Amacron -50
+KPX Y Aogonek -50
+KPX Y Aring -50
+KPX Y Atilde -50
+KPX Y O -15
+KPX Y Oacute -15
+KPX Y Ocircumflex -15
+KPX Y Odieresis -15
+KPX Y Ograve -15
+KPX Y Ohungarumlaut -15
+KPX Y Omacron -15
+KPX Y Oslash -15
+KPX Y Otilde -15
+KPX Y a -92
+KPX Y aacute -92
+KPX Y abreve -92
+KPX Y acircumflex -92
+KPX Y adieresis -92
+KPX Y agrave -92
+KPX Y amacron -92
+KPX Y aogonek -92
+KPX Y aring -92
+KPX Y atilde -92
+KPX Y colon -65
+KPX Y comma -92
+KPX Y e -92
+KPX Y eacute -92
+KPX Y ecaron -92
+KPX Y ecircumflex -92
+KPX Y edieresis -52
+KPX Y edotaccent -92
+KPX Y egrave -52
+KPX Y emacron -52
+KPX Y eogonek -92
+KPX Y hyphen -74
+KPX Y i -74
+KPX Y iacute -74
+KPX Y icircumflex -34
+KPX Y idieresis -34
+KPX Y igrave -34
+KPX Y imacron -34
+KPX Y iogonek -74
+KPX Y o -92
+KPX Y oacute -92
+KPX Y ocircumflex -92
+KPX Y odieresis -92
+KPX Y ograve -92
+KPX Y ohungarumlaut -92
+KPX Y omacron -92
+KPX Y oslash -92
+KPX Y otilde -92
+KPX Y period -92
+KPX Y semicolon -65
+KPX Y u -92
+KPX Y uacute -92
+KPX Y ucircumflex -92
+KPX Y udieresis -92
+KPX Y ugrave -92
+KPX Y uhungarumlaut -92
+KPX Y umacron -92
+KPX Y uogonek -92
+KPX Y uring -92
+KPX Yacute A -50
+KPX Yacute Aacute -50
+KPX Yacute Abreve -50
+KPX Yacute Acircumflex -50
+KPX Yacute Adieresis -50
+KPX Yacute Agrave -50
+KPX Yacute Amacron -50
+KPX Yacute Aogonek -50
+KPX Yacute Aring -50
+KPX Yacute Atilde -50
+KPX Yacute O -15
+KPX Yacute Oacute -15
+KPX Yacute Ocircumflex -15
+KPX Yacute Odieresis -15
+KPX Yacute Ograve -15
+KPX Yacute Ohungarumlaut -15
+KPX Yacute Omacron -15
+KPX Yacute Oslash -15
+KPX Yacute Otilde -15
+KPX Yacute a -92
+KPX Yacute aacute -92
+KPX Yacute abreve -92
+KPX Yacute acircumflex -92
+KPX Yacute adieresis -92
+KPX Yacute agrave -92
+KPX Yacute amacron -92
+KPX Yacute aogonek -92
+KPX Yacute aring -92
+KPX Yacute atilde -92
+KPX Yacute colon -65
+KPX Yacute comma -92
+KPX Yacute e -92
+KPX Yacute eacute -92
+KPX Yacute ecaron -92
+KPX Yacute ecircumflex -92
+KPX Yacute edieresis -52
+KPX Yacute edotaccent -92
+KPX Yacute egrave -52
+KPX Yacute emacron -52
+KPX Yacute eogonek -92
+KPX Yacute hyphen -74
+KPX Yacute i -74
+KPX Yacute iacute -74
+KPX Yacute icircumflex -34
+KPX Yacute idieresis -34
+KPX Yacute igrave -34
+KPX Yacute imacron -34
+KPX Yacute iogonek -74
+KPX Yacute o -92
+KPX Yacute oacute -92
+KPX Yacute ocircumflex -92
+KPX Yacute odieresis -92
+KPX Yacute ograve -92
+KPX Yacute ohungarumlaut -92
+KPX Yacute omacron -92
+KPX Yacute oslash -92
+KPX Yacute otilde -92
+KPX Yacute period -92
+KPX Yacute semicolon -65
+KPX Yacute u -92
+KPX Yacute uacute -92
+KPX Yacute ucircumflex -92
+KPX Yacute udieresis -92
+KPX Yacute ugrave -92
+KPX Yacute uhungarumlaut -92
+KPX Yacute umacron -92
+KPX Yacute uogonek -92
+KPX Yacute uring -92
+KPX Ydieresis A -50
+KPX Ydieresis Aacute -50
+KPX Ydieresis Abreve -50
+KPX Ydieresis Acircumflex -50
+KPX Ydieresis Adieresis -50
+KPX Ydieresis Agrave -50
+KPX Ydieresis Amacron -50
+KPX Ydieresis Aogonek -50
+KPX Ydieresis Aring -50
+KPX Ydieresis Atilde -50
+KPX Ydieresis O -15
+KPX Ydieresis Oacute -15
+KPX Ydieresis Ocircumflex -15
+KPX Ydieresis Odieresis -15
+KPX Ydieresis Ograve -15
+KPX Ydieresis Ohungarumlaut -15
+KPX Ydieresis Omacron -15
+KPX Ydieresis Oslash -15
+KPX Ydieresis Otilde -15
+KPX Ydieresis a -92
+KPX Ydieresis aacute -92
+KPX Ydieresis abreve -92
+KPX Ydieresis acircumflex -92
+KPX Ydieresis adieresis -92
+KPX Ydieresis agrave -92
+KPX Ydieresis amacron -92
+KPX Ydieresis aogonek -92
+KPX Ydieresis aring -92
+KPX Ydieresis atilde -92
+KPX Ydieresis colon -65
+KPX Ydieresis comma -92
+KPX Ydieresis e -92
+KPX Ydieresis eacute -92
+KPX Ydieresis ecaron -92
+KPX Ydieresis ecircumflex -92
+KPX Ydieresis edieresis -52
+KPX Ydieresis edotaccent -92
+KPX Ydieresis egrave -52
+KPX Ydieresis emacron -52
+KPX Ydieresis eogonek -92
+KPX Ydieresis hyphen -74
+KPX Ydieresis i -74
+KPX Ydieresis iacute -74
+KPX Ydieresis icircumflex -34
+KPX Ydieresis idieresis -34
+KPX Ydieresis igrave -34
+KPX Ydieresis imacron -34
+KPX Ydieresis iogonek -74
+KPX Ydieresis o -92
+KPX Ydieresis oacute -92
+KPX Ydieresis ocircumflex -92
+KPX Ydieresis odieresis -92
+KPX Ydieresis ograve -92
+KPX Ydieresis ohungarumlaut -92
+KPX Ydieresis omacron -92
+KPX Ydieresis oslash -92
+KPX Ydieresis otilde -92
+KPX Ydieresis period -92
+KPX Ydieresis semicolon -65
+KPX Ydieresis u -92
+KPX Ydieresis uacute -92
+KPX Ydieresis ucircumflex -92
+KPX Ydieresis udieresis -92
+KPX Ydieresis ugrave -92
+KPX Ydieresis uhungarumlaut -92
+KPX Ydieresis umacron -92
+KPX Ydieresis uogonek -92
+KPX Ydieresis uring -92
+KPX a g -10
+KPX a gbreve -10
+KPX a gcommaaccent -10
+KPX aacute g -10
+KPX aacute gbreve -10
+KPX aacute gcommaaccent -10
+KPX abreve g -10
+KPX abreve gbreve -10
+KPX abreve gcommaaccent -10
+KPX acircumflex g -10
+KPX acircumflex gbreve -10
+KPX acircumflex gcommaaccent -10
+KPX adieresis g -10
+KPX adieresis gbreve -10
+KPX adieresis gcommaaccent -10
+KPX agrave g -10
+KPX agrave gbreve -10
+KPX agrave gcommaaccent -10
+KPX amacron g -10
+KPX amacron gbreve -10
+KPX amacron gcommaaccent -10
+KPX aogonek g -10
+KPX aogonek gbreve -10
+KPX aogonek gcommaaccent -10
+KPX aring g -10
+KPX aring gbreve -10
+KPX aring gcommaaccent -10
+KPX atilde g -10
+KPX atilde gbreve -10
+KPX atilde gcommaaccent -10
+KPX b period -40
+KPX b u -20
+KPX b uacute -20
+KPX b ucircumflex -20
+KPX b udieresis -20
+KPX b ugrave -20
+KPX b uhungarumlaut -20
+KPX b umacron -20
+KPX b uogonek -20
+KPX b uring -20
+KPX c h -15
+KPX c k -20
+KPX c kcommaaccent -20
+KPX cacute h -15
+KPX cacute k -20
+KPX cacute kcommaaccent -20
+KPX ccaron h -15
+KPX ccaron k -20
+KPX ccaron kcommaaccent -20
+KPX ccedilla h -15
+KPX ccedilla k -20
+KPX ccedilla kcommaaccent -20
+KPX comma quotedblright -140
+KPX comma quoteright -140
+KPX e comma -10
+KPX e g -40
+KPX e gbreve -40
+KPX e gcommaaccent -40
+KPX e period -15
+KPX e v -15
+KPX e w -15
+KPX e x -20
+KPX e y -30
+KPX e yacute -30
+KPX e ydieresis -30
+KPX eacute comma -10
+KPX eacute g -40
+KPX eacute gbreve -40
+KPX eacute gcommaaccent -40
+KPX eacute period -15
+KPX eacute v -15
+KPX eacute w -15
+KPX eacute x -20
+KPX eacute y -30
+KPX eacute yacute -30
+KPX eacute ydieresis -30
+KPX ecaron comma -10
+KPX ecaron g -40
+KPX ecaron gbreve -40
+KPX ecaron gcommaaccent -40
+KPX ecaron period -15
+KPX ecaron v -15
+KPX ecaron w -15
+KPX ecaron x -20
+KPX ecaron y -30
+KPX ecaron yacute -30
+KPX ecaron ydieresis -30
+KPX ecircumflex comma -10
+KPX ecircumflex g -40
+KPX ecircumflex gbreve -40
+KPX ecircumflex gcommaaccent -40
+KPX ecircumflex period -15
+KPX ecircumflex v -15
+KPX ecircumflex w -15
+KPX ecircumflex x -20
+KPX ecircumflex y -30
+KPX ecircumflex yacute -30
+KPX ecircumflex ydieresis -30
+KPX edieresis comma -10
+KPX edieresis g -40
+KPX edieresis gbreve -40
+KPX edieresis gcommaaccent -40
+KPX edieresis period -15
+KPX edieresis v -15
+KPX edieresis w -15
+KPX edieresis x -20
+KPX edieresis y -30
+KPX edieresis yacute -30
+KPX edieresis ydieresis -30
+KPX edotaccent comma -10
+KPX edotaccent g -40
+KPX edotaccent gbreve -40
+KPX edotaccent gcommaaccent -40
+KPX edotaccent period -15
+KPX edotaccent v -15
+KPX edotaccent w -15
+KPX edotaccent x -20
+KPX edotaccent y -30
+KPX edotaccent yacute -30
+KPX edotaccent ydieresis -30
+KPX egrave comma -10
+KPX egrave g -40
+KPX egrave gbreve -40
+KPX egrave gcommaaccent -40
+KPX egrave period -15
+KPX egrave v -15
+KPX egrave w -15
+KPX egrave x -20
+KPX egrave y -30
+KPX egrave yacute -30
+KPX egrave ydieresis -30
+KPX emacron comma -10
+KPX emacron g -40
+KPX emacron gbreve -40
+KPX emacron gcommaaccent -40
+KPX emacron period -15
+KPX emacron v -15
+KPX emacron w -15
+KPX emacron x -20
+KPX emacron y -30
+KPX emacron yacute -30
+KPX emacron ydieresis -30
+KPX eogonek comma -10
+KPX eogonek g -40
+KPX eogonek gbreve -40
+KPX eogonek gcommaaccent -40
+KPX eogonek period -15
+KPX eogonek v -15
+KPX eogonek w -15
+KPX eogonek x -20
+KPX eogonek y -30
+KPX eogonek yacute -30
+KPX eogonek ydieresis -30
+KPX f comma -10
+KPX f dotlessi -60
+KPX f f -18
+KPX f i -20
+KPX f iogonek -20
+KPX f period -15
+KPX f quoteright 92
+KPX g comma -10
+KPX g e -10
+KPX g eacute -10
+KPX g ecaron -10
+KPX g ecircumflex -10
+KPX g edieresis -10
+KPX g edotaccent -10
+KPX g egrave -10
+KPX g emacron -10
+KPX g eogonek -10
+KPX g g -10
+KPX g gbreve -10
+KPX g gcommaaccent -10
+KPX g period -15
+KPX gbreve comma -10
+KPX gbreve e -10
+KPX gbreve eacute -10
+KPX gbreve ecaron -10
+KPX gbreve ecircumflex -10
+KPX gbreve edieresis -10
+KPX gbreve edotaccent -10
+KPX gbreve egrave -10
+KPX gbreve emacron -10
+KPX gbreve eogonek -10
+KPX gbreve g -10
+KPX gbreve gbreve -10
+KPX gbreve gcommaaccent -10
+KPX gbreve period -15
+KPX gcommaaccent comma -10
+KPX gcommaaccent e -10
+KPX gcommaaccent eacute -10
+KPX gcommaaccent ecaron -10
+KPX gcommaaccent ecircumflex -10
+KPX gcommaaccent edieresis -10
+KPX gcommaaccent edotaccent -10
+KPX gcommaaccent egrave -10
+KPX gcommaaccent emacron -10
+KPX gcommaaccent eogonek -10
+KPX gcommaaccent g -10
+KPX gcommaaccent gbreve -10
+KPX gcommaaccent gcommaaccent -10
+KPX gcommaaccent period -15
+KPX k e -10
+KPX k eacute -10
+KPX k ecaron -10
+KPX k ecircumflex -10
+KPX k edieresis -10
+KPX k edotaccent -10
+KPX k egrave -10
+KPX k emacron -10
+KPX k eogonek -10
+KPX k o -10
+KPX k oacute -10
+KPX k ocircumflex -10
+KPX k odieresis -10
+KPX k ograve -10
+KPX k ohungarumlaut -10
+KPX k omacron -10
+KPX k oslash -10
+KPX k otilde -10
+KPX k y -10
+KPX k yacute -10
+KPX k ydieresis -10
+KPX kcommaaccent e -10
+KPX kcommaaccent eacute -10
+KPX kcommaaccent ecaron -10
+KPX kcommaaccent ecircumflex -10
+KPX kcommaaccent edieresis -10
+KPX kcommaaccent edotaccent -10
+KPX kcommaaccent egrave -10
+KPX kcommaaccent emacron -10
+KPX kcommaaccent eogonek -10
+KPX kcommaaccent o -10
+KPX kcommaaccent oacute -10
+KPX kcommaaccent ocircumflex -10
+KPX kcommaaccent odieresis -10
+KPX kcommaaccent ograve -10
+KPX kcommaaccent ohungarumlaut -10
+KPX kcommaaccent omacron -10
+KPX kcommaaccent oslash -10
+KPX kcommaaccent otilde -10
+KPX kcommaaccent y -10
+KPX kcommaaccent yacute -10
+KPX kcommaaccent ydieresis -10
+KPX n v -40
+KPX nacute v -40
+KPX ncaron v -40
+KPX ncommaaccent v -40
+KPX ntilde v -40
+KPX o g -10
+KPX o gbreve -10
+KPX o gcommaaccent -10
+KPX o v -10
+KPX oacute g -10
+KPX oacute gbreve -10
+KPX oacute gcommaaccent -10
+KPX oacute v -10
+KPX ocircumflex g -10
+KPX ocircumflex gbreve -10
+KPX ocircumflex gcommaaccent -10
+KPX ocircumflex v -10
+KPX odieresis g -10
+KPX odieresis gbreve -10
+KPX odieresis gcommaaccent -10
+KPX odieresis v -10
+KPX ograve g -10
+KPX ograve gbreve -10
+KPX ograve gcommaaccent -10
+KPX ograve v -10
+KPX ohungarumlaut g -10
+KPX ohungarumlaut gbreve -10
+KPX ohungarumlaut gcommaaccent -10
+KPX ohungarumlaut v -10
+KPX omacron g -10
+KPX omacron gbreve -10
+KPX omacron gcommaaccent -10
+KPX omacron v -10
+KPX oslash g -10
+KPX oslash gbreve -10
+KPX oslash gcommaaccent -10
+KPX oslash v -10
+KPX otilde g -10
+KPX otilde gbreve -10
+KPX otilde gcommaaccent -10
+KPX otilde v -10
+KPX period quotedblright -140
+KPX period quoteright -140
+KPX quoteleft quoteleft -111
+KPX quoteright d -25
+KPX quoteright dcroat -25
+KPX quoteright quoteright -111
+KPX quoteright r -25
+KPX quoteright racute -25
+KPX quoteright rcaron -25
+KPX quoteright rcommaaccent -25
+KPX quoteright s -40
+KPX quoteright sacute -40
+KPX quoteright scaron -40
+KPX quoteright scedilla -40
+KPX quoteright scommaaccent -40
+KPX quoteright space -111
+KPX quoteright t -30
+KPX quoteright tcommaaccent -30
+KPX quoteright v -10
+KPX r a -15
+KPX r aacute -15
+KPX r abreve -15
+KPX r acircumflex -15
+KPX r adieresis -15
+KPX r agrave -15
+KPX r amacron -15
+KPX r aogonek -15
+KPX r aring -15
+KPX r atilde -15
+KPX r c -37
+KPX r cacute -37
+KPX r ccaron -37
+KPX r ccedilla -37
+KPX r comma -111
+KPX r d -37
+KPX r dcroat -37
+KPX r e -37
+KPX r eacute -37
+KPX r ecaron -37
+KPX r ecircumflex -37
+KPX r edieresis -37
+KPX r edotaccent -37
+KPX r egrave -37
+KPX r emacron -37
+KPX r eogonek -37
+KPX r g -37
+KPX r gbreve -37
+KPX r gcommaaccent -37
+KPX r hyphen -20
+KPX r o -45
+KPX r oacute -45
+KPX r ocircumflex -45
+KPX r odieresis -45
+KPX r ograve -45
+KPX r ohungarumlaut -45
+KPX r omacron -45
+KPX r oslash -45
+KPX r otilde -45
+KPX r period -111
+KPX r q -37
+KPX r s -10
+KPX r sacute -10
+KPX r scaron -10
+KPX r scedilla -10
+KPX r scommaaccent -10
+KPX racute a -15
+KPX racute aacute -15
+KPX racute abreve -15
+KPX racute acircumflex -15
+KPX racute adieresis -15
+KPX racute agrave -15
+KPX racute amacron -15
+KPX racute aogonek -15
+KPX racute aring -15
+KPX racute atilde -15
+KPX racute c -37
+KPX racute cacute -37
+KPX racute ccaron -37
+KPX racute ccedilla -37
+KPX racute comma -111
+KPX racute d -37
+KPX racute dcroat -37
+KPX racute e -37
+KPX racute eacute -37
+KPX racute ecaron -37
+KPX racute ecircumflex -37
+KPX racute edieresis -37
+KPX racute edotaccent -37
+KPX racute egrave -37
+KPX racute emacron -37
+KPX racute eogonek -37
+KPX racute g -37
+KPX racute gbreve -37
+KPX racute gcommaaccent -37
+KPX racute hyphen -20
+KPX racute o -45
+KPX racute oacute -45
+KPX racute ocircumflex -45
+KPX racute odieresis -45
+KPX racute ograve -45
+KPX racute ohungarumlaut -45
+KPX racute omacron -45
+KPX racute oslash -45
+KPX racute otilde -45
+KPX racute period -111
+KPX racute q -37
+KPX racute s -10
+KPX racute sacute -10
+KPX racute scaron -10
+KPX racute scedilla -10
+KPX racute scommaaccent -10
+KPX rcaron a -15
+KPX rcaron aacute -15
+KPX rcaron abreve -15
+KPX rcaron acircumflex -15
+KPX rcaron adieresis -15
+KPX rcaron agrave -15
+KPX rcaron amacron -15
+KPX rcaron aogonek -15
+KPX rcaron aring -15
+KPX rcaron atilde -15
+KPX rcaron c -37
+KPX rcaron cacute -37
+KPX rcaron ccaron -37
+KPX rcaron ccedilla -37
+KPX rcaron comma -111
+KPX rcaron d -37
+KPX rcaron dcroat -37
+KPX rcaron e -37
+KPX rcaron eacute -37
+KPX rcaron ecaron -37
+KPX rcaron ecircumflex -37
+KPX rcaron edieresis -37
+KPX rcaron edotaccent -37
+KPX rcaron egrave -37
+KPX rcaron emacron -37
+KPX rcaron eogonek -37
+KPX rcaron g -37
+KPX rcaron gbreve -37
+KPX rcaron gcommaaccent -37
+KPX rcaron hyphen -20
+KPX rcaron o -45
+KPX rcaron oacute -45
+KPX rcaron ocircumflex -45
+KPX rcaron odieresis -45
+KPX rcaron ograve -45
+KPX rcaron ohungarumlaut -45
+KPX rcaron omacron -45
+KPX rcaron oslash -45
+KPX rcaron otilde -45
+KPX rcaron period -111
+KPX rcaron q -37
+KPX rcaron s -10
+KPX rcaron sacute -10
+KPX rcaron scaron -10
+KPX rcaron scedilla -10
+KPX rcaron scommaaccent -10
+KPX rcommaaccent a -15
+KPX rcommaaccent aacute -15
+KPX rcommaaccent abreve -15
+KPX rcommaaccent acircumflex -15
+KPX rcommaaccent adieresis -15
+KPX rcommaaccent agrave -15
+KPX rcommaaccent amacron -15
+KPX rcommaaccent aogonek -15
+KPX rcommaaccent aring -15
+KPX rcommaaccent atilde -15
+KPX rcommaaccent c -37
+KPX rcommaaccent cacute -37
+KPX rcommaaccent ccaron -37
+KPX rcommaaccent ccedilla -37
+KPX rcommaaccent comma -111
+KPX rcommaaccent d -37
+KPX rcommaaccent dcroat -37
+KPX rcommaaccent e -37
+KPX rcommaaccent eacute -37
+KPX rcommaaccent ecaron -37
+KPX rcommaaccent ecircumflex -37
+KPX rcommaaccent edieresis -37
+KPX rcommaaccent edotaccent -37
+KPX rcommaaccent egrave -37
+KPX rcommaaccent emacron -37
+KPX rcommaaccent eogonek -37
+KPX rcommaaccent g -37
+KPX rcommaaccent gbreve -37
+KPX rcommaaccent gcommaaccent -37
+KPX rcommaaccent hyphen -20
+KPX rcommaaccent o -45
+KPX rcommaaccent oacute -45
+KPX rcommaaccent ocircumflex -45
+KPX rcommaaccent odieresis -45
+KPX rcommaaccent ograve -45
+KPX rcommaaccent ohungarumlaut -45
+KPX rcommaaccent omacron -45
+KPX rcommaaccent oslash -45
+KPX rcommaaccent otilde -45
+KPX rcommaaccent period -111
+KPX rcommaaccent q -37
+KPX rcommaaccent s -10
+KPX rcommaaccent sacute -10
+KPX rcommaaccent scaron -10
+KPX rcommaaccent scedilla -10
+KPX rcommaaccent scommaaccent -10
+KPX space A -18
+KPX space Aacute -18
+KPX space Abreve -18
+KPX space Acircumflex -18
+KPX space Adieresis -18
+KPX space Agrave -18
+KPX space Amacron -18
+KPX space Aogonek -18
+KPX space Aring -18
+KPX space Atilde -18
+KPX space T -18
+KPX space Tcaron -18
+KPX space Tcommaaccent -18
+KPX space V -35
+KPX space W -40
+KPX space Y -75
+KPX space Yacute -75
+KPX space Ydieresis -75
+KPX v comma -74
+KPX v period -74
+KPX w comma -74
+KPX w period -74
+KPX y comma -55
+KPX y period -55
+KPX yacute comma -55
+KPX yacute period -55
+KPX ydieresis comma -55
+KPX ydieresis period -55
+EndKernPairs
+EndKernData
+EndFontMetrics
Added: trunk/mapbender/http/classes/fonts/Times-Roman.afm
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/fonts/Times-Roman.afm?view=auto&rev=13
--- (empty file)
+++ trunk/mapbender/http/classes/fonts/Times-Roman.afm 2006-04-13 19:38:28+0000
@@ -0,0 +1,2419 @@
+StartFontMetrics 4.1
+Comment Copyright (c) 1985, 1987, 1989, 1990, 1993, 1997 Adobe Systems Incorporated. All Rights Reserved.
+Comment Creation Date: Thu May 1 12:49:17 1997
+Comment UniqueID 43068
+Comment VMusage 43909 54934
+FontName Times-Roman
+FullName Times Roman
+FamilyName Times
+Weight Roman
+ItalicAngle 0
+IsFixedPitch false
+CharacterSet ExtendedRoman
+FontBBox -168 -218 1000 898
+UnderlinePosition -100
+UnderlineThickness 50
+Version 002.000
+Notice Copyright (c) 1985, 1987, 1989, 1990, 1993, 1997 Adobe Systems Incorporated. All Rights Reserved.Times is a trademark of Linotype-Hell AG and/or its subsidiaries.
+EncodingScheme AdobeStandardEncoding
+CapHeight 662
+XHeight 450
+Ascender 683
+Descender -217
+StdHW 28
+StdVW 84
+StartCharMetrics 315
+C 32 ; WX 250 ; N space ; B 0 0 0 0 ;
+C 33 ; WX 333 ; N exclam ; B 130 -9 238 676 ;
+C 34 ; WX 408 ; N quotedbl ; B 77 431 331 676 ;
+C 35 ; WX 500 ; N numbersign ; B 5 0 496 662 ;
+C 36 ; WX 500 ; N dollar ; B 44 -87 457 727 ;
+C 37 ; WX 833 ; N percent ; B 61 -13 772 676 ;
+C 38 ; WX 778 ; N ampersand ; B 42 -13 750 676 ;
+C 39 ; WX 333 ; N quoteright ; B 79 433 218 676 ;
+C 40 ; WX 333 ; N parenleft ; B 48 -177 304 676 ;
+C 41 ; WX 333 ; N parenright ; B 29 -177 285 676 ;
+C 42 ; WX 500 ; N asterisk ; B 69 265 432 676 ;
+C 43 ; WX 564 ; N plus ; B 30 0 534 506 ;
+C 44 ; WX 250 ; N comma ; B 56 -141 195 102 ;
+C 45 ; WX 333 ; N hyphen ; B 39 194 285 257 ;
+C 46 ; WX 250 ; N period ; B 70 -11 181 100 ;
+C 47 ; WX 278 ; N slash ; B -9 -14 287 676 ;
+C 48 ; WX 500 ; N zero ; B 24 -14 476 676 ;
+C 49 ; WX 500 ; N one ; B 111 0 394 676 ;
+C 50 ; WX 500 ; N two ; B 30 0 475 676 ;
+C 51 ; WX 500 ; N three ; B 43 -14 431 676 ;
+C 52 ; WX 500 ; N four ; B 12 0 472 676 ;
+C 53 ; WX 500 ; N five ; B 32 -14 438 688 ;
+C 54 ; WX 500 ; N six ; B 34 -14 468 684 ;
+C 55 ; WX 500 ; N seven ; B 20 -8 449 662 ;
+C 56 ; WX 500 ; N eight ; B 56 -14 445 676 ;
+C 57 ; WX 500 ; N nine ; B 30 -22 459 676 ;
+C 58 ; WX 278 ; N colon ; B 81 -11 192 459 ;
+C 59 ; WX 278 ; N semicolon ; B 80 -141 219 459 ;
+C 60 ; WX 564 ; N less ; B 28 -8 536 514 ;
+C 61 ; WX 564 ; N equal ; B 30 120 534 386 ;
+C 62 ; WX 564 ; N greater ; B 28 -8 536 514 ;
+C 63 ; WX 444 ; N question ; B 68 -8 414 676 ;
+C 64 ; WX 921 ; N at ; B 116 -14 809 676 ;
+C 65 ; WX 722 ; N A ; B 15 0 706 674 ;
+C 66 ; WX 667 ; N B ; B 17 0 593 662 ;
+C 67 ; WX 667 ; N C ; B 28 -14 633 676 ;
+C 68 ; WX 722 ; N D ; B 16 0 685 662 ;
+C 69 ; WX 611 ; N E ; B 12 0 597 662 ;
+C 70 ; WX 556 ; N F ; B 12 0 546 662 ;
+C 71 ; WX 722 ; N G ; B 32 -14 709 676 ;
+C 72 ; WX 722 ; N H ; B 19 0 702 662 ;
+C 73 ; WX 333 ; N I ; B 18 0 315 662 ;
+C 74 ; WX 389 ; N J ; B 10 -14 370 662 ;
+C 75 ; WX 722 ; N K ; B 34 0 723 662 ;
+C 76 ; WX 611 ; N L ; B 12 0 598 662 ;
+C 77 ; WX 889 ; N M ; B 12 0 863 662 ;
+C 78 ; WX 722 ; N N ; B 12 -11 707 662 ;
+C 79 ; WX 722 ; N O ; B 34 -14 688 676 ;
+C 80 ; WX 556 ; N P ; B 16 0 542 662 ;
+C 81 ; WX 722 ; N Q ; B 34 -178 701 676 ;
+C 82 ; WX 667 ; N R ; B 17 0 659 662 ;
+C 83 ; WX 556 ; N S ; B 42 -14 491 676 ;
+C 84 ; WX 611 ; N T ; B 17 0 593 662 ;
+C 85 ; WX 722 ; N U ; B 14 -14 705 662 ;
+C 86 ; WX 722 ; N V ; B 16 -11 697 662 ;
+C 87 ; WX 944 ; N W ; B 5 -11 932 662 ;
+C 88 ; WX 722 ; N X ; B 10 0 704 662 ;
+C 89 ; WX 722 ; N Y ; B 22 0 703 662 ;
+C 90 ; WX 611 ; N Z ; B 9 0 597 662 ;
+C 91 ; WX 333 ; N bracketleft ; B 88 -156 299 662 ;
+C 92 ; WX 278 ; N backslash ; B -9 -14 287 676 ;
+C 93 ; WX 333 ; N bracketright ; B 34 -156 245 662 ;
+C 94 ; WX 469 ; N asciicircum ; B 24 297 446 662 ;
+C 95 ; WX 500 ; N underscore ; B 0 -125 500 -75 ;
+C 96 ; WX 333 ; N quoteleft ; B 115 433 254 676 ;
+C 97 ; WX 444 ; N a ; B 37 -10 442 460 ;
+C 98 ; WX 500 ; N b ; B 3 -10 468 683 ;
+C 99 ; WX 444 ; N c ; B 25 -10 412 460 ;
+C 100 ; WX 500 ; N d ; B 27 -10 491 683 ;
+C 101 ; WX 444 ; N e ; B 25 -10 424 460 ;
+C 102 ; WX 333 ; N f ; B 20 0 383 683 ; L i fi ; L l fl ;
+C 103 ; WX 500 ; N g ; B 28 -218 470 460 ;
+C 104 ; WX 500 ; N h ; B 9 0 487 683 ;
+C 105 ; WX 278 ; N i ; B 16 0 253 683 ;
+C 106 ; WX 278 ; N j ; B -70 -218 194 683 ;
+C 107 ; WX 500 ; N k ; B 7 0 505 683 ;
+C 108 ; WX 278 ; N l ; B 19 0 257 683 ;
+C 109 ; WX 778 ; N m ; B 16 0 775 460 ;
+C 110 ; WX 500 ; N n ; B 16 0 485 460 ;
+C 111 ; WX 500 ; N o ; B 29 -10 470 460 ;
+C 112 ; WX 500 ; N p ; B 5 -217 470 460 ;
+C 113 ; WX 500 ; N q ; B 24 -217 488 460 ;
+C 114 ; WX 333 ; N r ; B 5 0 335 460 ;
+C 115 ; WX 389 ; N s ; B 51 -10 348 460 ;
+C 116 ; WX 278 ; N t ; B 13 -10 279 579 ;
+C 117 ; WX 500 ; N u ; B 9 -10 479 450 ;
+C 118 ; WX 500 ; N v ; B 19 -14 477 450 ;
+C 119 ; WX 722 ; N w ; B 21 -14 694 450 ;
+C 120 ; WX 500 ; N x ; B 17 0 479 450 ;
+C 121 ; WX 500 ; N y ; B 14 -218 475 450 ;
+C 122 ; WX 444 ; N z ; B 27 0 418 450 ;
+C 123 ; WX 480 ; N braceleft ; B 100 -181 350 680 ;
+C 124 ; WX 200 ; N bar ; B 67 -218 133 782 ;
+C 125 ; WX 480 ; N braceright ; B 130 -181 380 680 ;
+C 126 ; WX 541 ; N asciitilde ; B 40 183 502 323 ;
+C 161 ; WX 333 ; N exclamdown ; B 97 -218 205 467 ;
+C 162 ; WX 500 ; N cent ; B 53 -138 448 579 ;
+C 163 ; WX 500 ; N sterling ; B 12 -8 490 676 ;
+C 164 ; WX 167 ; N fraction ; B -168 -14 331 676 ;
+C 165 ; WX 500 ; N yen ; B -53 0 512 662 ;
+C 166 ; WX 500 ; N florin ; B 7 -189 490 676 ;
+C 167 ; WX 500 ; N section ; B 70 -148 426 676 ;
+C 168 ; WX 500 ; N currency ; B -22 58 522 602 ;
+C 169 ; WX 180 ; N quotesingle ; B 48 431 133 676 ;
+C 170 ; WX 444 ; N quotedblleft ; B 43 433 414 676 ;
+C 171 ; WX 500 ; N guillemotleft ; B 42 33 456 416 ;
+C 172 ; WX 333 ; N guilsinglleft ; B 63 33 285 416 ;
+C 173 ; WX 333 ; N guilsinglright ; B 48 33 270 416 ;
+C 174 ; WX 556 ; N fi ; B 31 0 521 683 ;
+C 175 ; WX 556 ; N fl ; B 32 0 521 683 ;
+C 177 ; WX 500 ; N endash ; B 0 201 500 250 ;
+C 178 ; WX 500 ; N dagger ; B 59 -149 442 676 ;
+C 179 ; WX 500 ; N daggerdbl ; B 58 -153 442 676 ;
+C 180 ; WX 250 ; N periodcentered ; B 70 199 181 310 ;
+C 182 ; WX 453 ; N paragraph ; B -22 -154 450 662 ;
+C 183 ; WX 350 ; N bullet ; B 40 196 310 466 ;
+C 184 ; WX 333 ; N quotesinglbase ; B 79 -141 218 102 ;
+C 185 ; WX 444 ; N quotedblbase ; B 45 -141 416 102 ;
+C 186 ; WX 444 ; N quotedblright ; B 30 433 401 676 ;
+C 187 ; WX 500 ; N guillemotright ; B 44 33 458 416 ;
+C 188 ; WX 1000 ; N ellipsis ; B 111 -11 888 100 ;
+C 189 ; WX 1000 ; N perthousand ; B 7 -19 994 706 ;
+C 191 ; WX 444 ; N questiondown ; B 30 -218 376 466 ;
+C 193 ; WX 333 ; N grave ; B 19 507 242 678 ;
+C 194 ; WX 333 ; N acute ; B 93 507 317 678 ;
+C 195 ; WX 333 ; N circumflex ; B 11 507 322 674 ;
+C 196 ; WX 333 ; N tilde ; B 1 532 331 638 ;
+C 197 ; WX 333 ; N macron ; B 11 547 322 601 ;
+C 198 ; WX 333 ; N breve ; B 26 507 307 664 ;
+C 199 ; WX 333 ; N dotaccent ; B 118 581 216 681 ;
+C 200 ; WX 333 ; N dieresis ; B 18 581 315 681 ;
+C 202 ; WX 333 ; N ring ; B 67 512 266 711 ;
+C 203 ; WX 333 ; N cedilla ; B 52 -215 261 0 ;
+C 205 ; WX 333 ; N hungarumlaut ; B -3 507 377 678 ;
+C 206 ; WX 333 ; N ogonek ; B 62 -165 243 0 ;
+C 207 ; WX 333 ; N caron ; B 11 507 322 674 ;
+C 208 ; WX 1000 ; N emdash ; B 0 201 1000 250 ;
+C 225 ; WX 889 ; N AE ; B 0 0 863 662 ;
+C 227 ; WX 276 ; N ordfeminine ; B 4 394 270 676 ;
+C 232 ; WX 611 ; N Lslash ; B 12 0 598 662 ;
+C 233 ; WX 722 ; N Oslash ; B 34 -80 688 734 ;
+C 234 ; WX 889 ; N OE ; B 30 -6 885 668 ;
+C 235 ; WX 310 ; N ordmasculine ; B 6 394 304 676 ;
+C 241 ; WX 667 ; N ae ; B 38 -10 632 460 ;
+C 245 ; WX 278 ; N dotlessi ; B 16 0 253 460 ;
+C 248 ; WX 278 ; N lslash ; B 19 0 259 683 ;
+C 249 ; WX 500 ; N oslash ; B 29 -112 470 551 ;
+C 250 ; WX 722 ; N oe ; B 30 -10 690 460 ;
+C 251 ; WX 500 ; N germandbls ; B 12 -9 468 683 ;
+C -1 ; WX 333 ; N Idieresis ; B 18 0 315 835 ;
+C -1 ; WX 444 ; N eacute ; B 25 -10 424 678 ;
+C -1 ; WX 444 ; N abreve ; B 37 -10 442 664 ;
+C -1 ; WX 500 ; N uhungarumlaut ; B 9 -10 501 678 ;
+C -1 ; WX 444 ; N ecaron ; B 25 -10 424 674 ;
+C -1 ; WX 722 ; N Ydieresis ; B 22 0 703 835 ;
+C -1 ; WX 564 ; N divide ; B 30 -10 534 516 ;
+C -1 ; WX 722 ; N Yacute ; B 22 0 703 890 ;
+C -1 ; WX 722 ; N Acircumflex ; B 15 0 706 886 ;
+C -1 ; WX 444 ; N aacute ; B 37 -10 442 678 ;
+C -1 ; WX 722 ; N Ucircumflex ; B 14 -14 705 886 ;
+C -1 ; WX 500 ; N yacute ; B 14 -218 475 678 ;
+C -1 ; WX 389 ; N scommaaccent ; B 51 -218 348 460 ;
+C -1 ; WX 444 ; N ecircumflex ; B 25 -10 424 674 ;
+C -1 ; WX 722 ; N Uring ; B 14 -14 705 898 ;
+C -1 ; WX 722 ; N Udieresis ; B 14 -14 705 835 ;
+C -1 ; WX 444 ; N aogonek ; B 37 -165 469 460 ;
+C -1 ; WX 722 ; N Uacute ; B 14 -14 705 890 ;
+C -1 ; WX 500 ; N uogonek ; B 9 -155 487 450 ;
+C -1 ; WX 611 ; N Edieresis ; B 12 0 597 835 ;
+C -1 ; WX 722 ; N Dcroat ; B 16 0 685 662 ;
+C -1 ; WX 250 ; N commaaccent ; B 59 -218 184 -50 ;
+C -1 ; WX 760 ; N copyright ; B 38 -14 722 676 ;
+C -1 ; WX 611 ; N Emacron ; B 12 0 597 813 ;
+C -1 ; WX 444 ; N ccaron ; B 25 -10 412 674 ;
+C -1 ; WX 444 ; N aring ; B 37 -10 442 711 ;
+C -1 ; WX 722 ; N Ncommaaccent ; B 12 -198 707 662 ;
+C -1 ; WX 278 ; N lacute ; B 19 0 290 890 ;
+C -1 ; WX 444 ; N agrave ; B 37 -10 442 678 ;
+C -1 ; WX 611 ; N Tcommaaccent ; B 17 -218 593 662 ;
+C -1 ; WX 667 ; N Cacute ; B 28 -14 633 890 ;
+C -1 ; WX 444 ; N atilde ; B 37 -10 442 638 ;
+C -1 ; WX 611 ; N Edotaccent ; B 12 0 597 835 ;
+C -1 ; WX 389 ; N scaron ; B 39 -10 350 674 ;
+C -1 ; WX 389 ; N scedilla ; B 51 -215 348 460 ;
+C -1 ; WX 278 ; N iacute ; B 16 0 290 678 ;
+C -1 ; WX 471 ; N lozenge ; B 13 0 459 724 ;
+C -1 ; WX 667 ; N Rcaron ; B 17 0 659 886 ;
+C -1 ; WX 722 ; N Gcommaaccent ; B 32 -218 709 676 ;
+C -1 ; WX 500 ; N ucircumflex ; B 9 -10 479 674 ;
+C -1 ; WX 444 ; N acircumflex ; B 37 -10 442 674 ;
+C -1 ; WX 722 ; N Amacron ; B 15 0 706 813 ;
+C -1 ; WX 333 ; N rcaron ; B 5 0 335 674 ;
+C -1 ; WX 444 ; N ccedilla ; B 25 -215 412 460 ;
+C -1 ; WX 611 ; N Zdotaccent ; B 9 0 597 835 ;
+C -1 ; WX 556 ; N Thorn ; B 16 0 542 662 ;
+C -1 ; WX 722 ; N Omacron ; B 34 -14 688 813 ;
+C -1 ; WX 667 ; N Racute ; B 17 0 659 890 ;
+C -1 ; WX 556 ; N Sacute ; B 42 -14 491 890 ;
+C -1 ; WX 588 ; N dcaron ; B 27 -10 589 695 ;
+C -1 ; WX 722 ; N Umacron ; B 14 -14 705 813 ;
+C -1 ; WX 500 ; N uring ; B 9 -10 479 711 ;
+C -1 ; WX 300 ; N threesuperior ; B 15 262 291 676 ;
+C -1 ; WX 722 ; N Ograve ; B 34 -14 688 890 ;
+C -1 ; WX 722 ; N Agrave ; B 15 0 706 890 ;
+C -1 ; WX 722 ; N Abreve ; B 15 0 706 876 ;
+C -1 ; WX 564 ; N multiply ; B 38 8 527 497 ;
+C -1 ; WX 500 ; N uacute ; B 9 -10 479 678 ;
+C -1 ; WX 611 ; N Tcaron ; B 17 0 593 886 ;
+C -1 ; WX 476 ; N partialdiff ; B 17 -38 459 710 ;
+C -1 ; WX 500 ; N ydieresis ; B 14 -218 475 623 ;
+C -1 ; WX 722 ; N Nacute ; B 12 -11 707 890 ;
+C -1 ; WX 278 ; N icircumflex ; B -16 0 295 674 ;
+C -1 ; WX 611 ; N Ecircumflex ; B 12 0 597 886 ;
+C -1 ; WX 444 ; N adieresis ; B 37 -10 442 623 ;
+C -1 ; WX 444 ; N edieresis ; B 25 -10 424 623 ;
+C -1 ; WX 444 ; N cacute ; B 25 -10 413 678 ;
+C -1 ; WX 500 ; N nacute ; B 16 0 485 678 ;
+C -1 ; WX 500 ; N umacron ; B 9 -10 479 601 ;
+C -1 ; WX 722 ; N Ncaron ; B 12 -11 707 886 ;
+C -1 ; WX 333 ; N Iacute ; B 18 0 317 890 ;
+C -1 ; WX 564 ; N plusminus ; B 30 0 534 506 ;
+C -1 ; WX 200 ; N brokenbar ; B 67 -143 133 707 ;
+C -1 ; WX 760 ; N registered ; B 38 -14 722 676 ;
+C -1 ; WX 722 ; N Gbreve ; B 32 -14 709 876 ;
+C -1 ; WX 333 ; N Idotaccent ; B 18 0 315 835 ;
+C -1 ; WX 600 ; N summation ; B 15 -10 585 706 ;
+C -1 ; WX 611 ; N Egrave ; B 12 0 597 890 ;
+C -1 ; WX 333 ; N racute ; B 5 0 335 678 ;
+C -1 ; WX 500 ; N omacron ; B 29 -10 470 601 ;
+C -1 ; WX 611 ; N Zacute ; B 9 0 597 890 ;
+C -1 ; WX 611 ; N Zcaron ; B 9 0 597 886 ;
+C -1 ; WX 549 ; N greaterequal ; B 26 0 523 666 ;
+C -1 ; WX 722 ; N Eth ; B 16 0 685 662 ;
+C -1 ; WX 667 ; N Ccedilla ; B 28 -215 633 676 ;
+C -1 ; WX 278 ; N lcommaaccent ; B 19 -218 257 683 ;
+C -1 ; WX 326 ; N tcaron ; B 13 -10 318 722 ;
+C -1 ; WX 444 ; N eogonek ; B 25 -165 424 460 ;
+C -1 ; WX 722 ; N Uogonek ; B 14 -165 705 662 ;
+C -1 ; WX 722 ; N Aacute ; B 15 0 706 890 ;
+C -1 ; WX 722 ; N Adieresis ; B 15 0 706 835 ;
+C -1 ; WX 444 ; N egrave ; B 25 -10 424 678 ;
+C -1 ; WX 444 ; N zacute ; B 27 0 418 678 ;
+C -1 ; WX 278 ; N iogonek ; B 16 -165 265 683 ;
+C -1 ; WX 722 ; N Oacute ; B 34 -14 688 890 ;
+C -1 ; WX 500 ; N oacute ; B 29 -10 470 678 ;
+C -1 ; WX 444 ; N amacron ; B 37 -10 442 601 ;
+C -1 ; WX 389 ; N sacute ; B 51 -10 348 678 ;
+C -1 ; WX 278 ; N idieresis ; B -9 0 288 623 ;
+C -1 ; WX 722 ; N Ocircumflex ; B 34 -14 688 886 ;
+C -1 ; WX 722 ; N Ugrave ; B 14 -14 705 890 ;
+C -1 ; WX 612 ; N Delta ; B 6 0 608 688 ;
+C -1 ; WX 500 ; N thorn ; B 5 -217 470 683 ;
+C -1 ; WX 300 ; N twosuperior ; B 1 270 296 676 ;
+C -1 ; WX 722 ; N Odieresis ; B 34 -14 688 835 ;
+C -1 ; WX 500 ; N mu ; B 36 -218 512 450 ;
+C -1 ; WX 278 ; N igrave ; B -8 0 253 678 ;
+C -1 ; WX 500 ; N ohungarumlaut ; B 29 -10 491 678 ;
+C -1 ; WX 611 ; N Eogonek ; B 12 -165 597 662 ;
+C -1 ; WX 500 ; N dcroat ; B 27 -10 500 683 ;
+C -1 ; WX 750 ; N threequarters ; B 15 -14 718 676 ;
+C -1 ; WX 556 ; N Scedilla ; B 42 -215 491 676 ;
+C -1 ; WX 344 ; N lcaron ; B 19 0 347 695 ;
+C -1 ; WX 722 ; N Kcommaaccent ; B 34 -198 723 662 ;
+C -1 ; WX 611 ; N Lacute ; B 12 0 598 890 ;
+C -1 ; WX 980 ; N trademark ; B 30 256 957 662 ;
+C -1 ; WX 444 ; N edotaccent ; B 25 -10 424 623 ;
+C -1 ; WX 333 ; N Igrave ; B 18 0 315 890 ;
+C -1 ; WX 333 ; N Imacron ; B 11 0 322 813 ;
+C -1 ; WX 611 ; N Lcaron ; B 12 0 598 676 ;
+C -1 ; WX 750 ; N onehalf ; B 31 -14 746 676 ;
+C -1 ; WX 549 ; N lessequal ; B 26 0 523 666 ;
+C -1 ; WX 500 ; N ocircumflex ; B 29 -10 470 674 ;
+C -1 ; WX 500 ; N ntilde ; B 16 0 485 638 ;
+C -1 ; WX 722 ; N Uhungarumlaut ; B 14 -14 705 890 ;
+C -1 ; WX 611 ; N Eacute ; B 12 0 597 890 ;
+C -1 ; WX 444 ; N emacron ; B 25 -10 424 601 ;
+C -1 ; WX 500 ; N gbreve ; B 28 -218 470 664 ;
+C -1 ; WX 750 ; N onequarter ; B 37 -14 718 676 ;
+C -1 ; WX 556 ; N Scaron ; B 42 -14 491 886 ;
+C -1 ; WX 556 ; N Scommaaccent ; B 42 -218 491 676 ;
+C -1 ; WX 722 ; N Ohungarumlaut ; B 34 -14 688 890 ;
+C -1 ; WX 400 ; N degree ; B 57 390 343 676 ;
+C -1 ; WX 500 ; N ograve ; B 29 -10 470 678 ;
+C -1 ; WX 667 ; N Ccaron ; B 28 -14 633 886 ;
+C -1 ; WX 500 ; N ugrave ; B 9 -10 479 678 ;
+C -1 ; WX 453 ; N radical ; B 2 -60 452 768 ;
+C -1 ; WX 722 ; N Dcaron ; B 16 0 685 886 ;
+C -1 ; WX 333 ; N rcommaaccent ; B 5 -218 335 460 ;
+C -1 ; WX 722 ; N Ntilde ; B 12 -11 707 850 ;
+C -1 ; WX 500 ; N otilde ; B 29 -10 470 638 ;
+C -1 ; WX 667 ; N Rcommaaccent ; B 17 -198 659 662 ;
+C -1 ; WX 611 ; N Lcommaaccent ; B 12 -218 598 662 ;
+C -1 ; WX 722 ; N Atilde ; B 15 0 706 850 ;
+C -1 ; WX 722 ; N Aogonek ; B 15 -165 738 674 ;
+C -1 ; WX 722 ; N Aring ; B 15 0 706 898 ;
+C -1 ; WX 722 ; N Otilde ; B 34 -14 688 850 ;
+C -1 ; WX 444 ; N zdotaccent ; B 27 0 418 623 ;
+C -1 ; WX 611 ; N Ecaron ; B 12 0 597 886 ;
+C -1 ; WX 333 ; N Iogonek ; B 18 -165 315 662 ;
+C -1 ; WX 500 ; N kcommaaccent ; B 7 -218 505 683 ;
+C -1 ; WX 564 ; N minus ; B 30 220 534 286 ;
+C -1 ; WX 333 ; N Icircumflex ; B 11 0 322 886 ;
+C -1 ; WX 500 ; N ncaron ; B 16 0 485 674 ;
+C -1 ; WX 278 ; N tcommaaccent ; B 13 -218 279 579 ;
+C -1 ; WX 564 ; N logicalnot ; B 30 108 534 386 ;
+C -1 ; WX 500 ; N odieresis ; B 29 -10 470 623 ;
+C -1 ; WX 500 ; N udieresis ; B 9 -10 479 623 ;
+C -1 ; WX 549 ; N notequal ; B 12 -31 537 547 ;
+C -1 ; WX 500 ; N gcommaaccent ; B 28 -218 470 749 ;
+C -1 ; WX 500 ; N eth ; B 29 -10 471 686 ;
+C -1 ; WX 444 ; N zcaron ; B 27 0 418 674 ;
+C -1 ; WX 500 ; N ncommaaccent ; B 16 -218 485 460 ;
+C -1 ; WX 300 ; N onesuperior ; B 57 270 248 676 ;
+C -1 ; WX 278 ; N imacron ; B 6 0 271 601 ;
+C -1 ; WX 500 ; N Euro ; B 0 0 0 0 ;
+EndCharMetrics
+StartKernData
+StartKernPairs 2073
+KPX A C -40
+KPX A Cacute -40
+KPX A Ccaron -40
+KPX A Ccedilla -40
+KPX A G -40
+KPX A Gbreve -40
+KPX A Gcommaaccent -40
+KPX A O -55
+KPX A Oacute -55
+KPX A Ocircumflex -55
+KPX A Odieresis -55
+KPX A Ograve -55
+KPX A Ohungarumlaut -55
+KPX A Omacron -55
+KPX A Oslash -55
+KPX A Otilde -55
+KPX A Q -55
+KPX A T -111
+KPX A Tcaron -111
+KPX A Tcommaaccent -111
+KPX A U -55
+KPX A Uacute -55
+KPX A Ucircumflex -55
+KPX A Udieresis -55
+KPX A Ugrave -55
+KPX A Uhungarumlaut -55
+KPX A Umacron -55
+KPX A Uogonek -55
+KPX A Uring -55
+KPX A V -135
+KPX A W -90
+KPX A Y -105
+KPX A Yacute -105
+KPX A Ydieresis -105
+KPX A quoteright -111
+KPX A v -74
+KPX A w -92
+KPX A y -92
+KPX A yacute -92
+KPX A ydieresis -92
+KPX Aacute C -40
+KPX Aacute Cacute -40
+KPX Aacute Ccaron -40
+KPX Aacute Ccedilla -40
+KPX Aacute G -40
+KPX Aacute Gbreve -40
+KPX Aacute Gcommaaccent -40
+KPX Aacute O -55
+KPX Aacute Oacute -55
+KPX Aacute Ocircumflex -55
+KPX Aacute Odieresis -55
+KPX Aacute Ograve -55
+KPX Aacute Ohungarumlaut -55
+KPX Aacute Omacron -55
+KPX Aacute Oslash -55
+KPX Aacute Otilde -55
+KPX Aacute Q -55
+KPX Aacute T -111
+KPX Aacute Tcaron -111
+KPX Aacute Tcommaaccent -111
+KPX Aacute U -55
+KPX Aacute Uacute -55
+KPX Aacute Ucircumflex -55
+KPX Aacute Udieresis -55
+KPX Aacute Ugrave -55
+KPX Aacute Uhungarumlaut -55
+KPX Aacute Umacron -55
+KPX Aacute Uogonek -55
+KPX Aacute Uring -55
+KPX Aacute V -135
+KPX Aacute W -90
+KPX Aacute Y -105
+KPX Aacute Yacute -105
+KPX Aacute Ydieresis -105
+KPX Aacute quoteright -111
+KPX Aacute v -74
+KPX Aacute w -92
+KPX Aacute y -92
+KPX Aacute yacute -92
+KPX Aacute ydieresis -92
+KPX Abreve C -40
+KPX Abreve Cacute -40
+KPX Abreve Ccaron -40
+KPX Abreve Ccedilla -40
+KPX Abreve G -40
+KPX Abreve Gbreve -40
+KPX Abreve Gcommaaccent -40
+KPX Abreve O -55
+KPX Abreve Oacute -55
+KPX Abreve Ocircumflex -55
+KPX Abreve Odieresis -55
+KPX Abreve Ograve -55
+KPX Abreve Ohungarumlaut -55
+KPX Abreve Omacron -55
+KPX Abreve Oslash -55
+KPX Abreve Otilde -55
+KPX Abreve Q -55
+KPX Abreve T -111
+KPX Abreve Tcaron -111
+KPX Abreve Tcommaaccent -111
+KPX Abreve U -55
+KPX Abreve Uacute -55
+KPX Abreve Ucircumflex -55
+KPX Abreve Udieresis -55
+KPX Abreve Ugrave -55
+KPX Abreve Uhungarumlaut -55
+KPX Abreve Umacron -55
+KPX Abreve Uogonek -55
+KPX Abreve Uring -55
+KPX Abreve V -135
+KPX Abreve W -90
+KPX Abreve Y -105
+KPX Abreve Yacute -105
+KPX Abreve Ydieresis -105
+KPX Abreve quoteright -111
+KPX Abreve v -74
+KPX Abreve w -92
+KPX Abreve y -92
+KPX Abreve yacute -92
+KPX Abreve ydieresis -92
+KPX Acircumflex C -40
+KPX Acircumflex Cacute -40
+KPX Acircumflex Ccaron -40
+KPX Acircumflex Ccedilla -40
+KPX Acircumflex G -40
+KPX Acircumflex Gbreve -40
+KPX Acircumflex Gcommaaccent -40
+KPX Acircumflex O -55
+KPX Acircumflex Oacute -55
+KPX Acircumflex Ocircumflex -55
+KPX Acircumflex Odieresis -55
+KPX Acircumflex Ograve -55
+KPX Acircumflex Ohungarumlaut -55
+KPX Acircumflex Omacron -55
+KPX Acircumflex Oslash -55
+KPX Acircumflex Otilde -55
+KPX Acircumflex Q -55
+KPX Acircumflex T -111
+KPX Acircumflex Tcaron -111
+KPX Acircumflex Tcommaaccent -111
+KPX Acircumflex U -55
+KPX Acircumflex Uacute -55
+KPX Acircumflex Ucircumflex -55
+KPX Acircumflex Udieresis -55
+KPX Acircumflex Ugrave -55
+KPX Acircumflex Uhungarumlaut -55
+KPX Acircumflex Umacron -55
+KPX Acircumflex Uogonek -55
+KPX Acircumflex Uring -55
+KPX Acircumflex V -135
+KPX Acircumflex W -90
+KPX Acircumflex Y -105
+KPX Acircumflex Yacute -105
+KPX Acircumflex Ydieresis -105
+KPX Acircumflex quoteright -111
+KPX Acircumflex v -74
+KPX Acircumflex w -92
+KPX Acircumflex y -92
+KPX Acircumflex yacute -92
+KPX Acircumflex ydieresis -92
+KPX Adieresis C -40
+KPX Adieresis Cacute -40
+KPX Adieresis Ccaron -40
+KPX Adieresis Ccedilla -40
+KPX Adieresis G -40
+KPX Adieresis Gbreve -40
+KPX Adieresis Gcommaaccent -40
+KPX Adieresis O -55
+KPX Adieresis Oacute -55
+KPX Adieresis Ocircumflex -55
+KPX Adieresis Odieresis -55
+KPX Adieresis Ograve -55
+KPX Adieresis Ohungarumlaut -55
+KPX Adieresis Omacron -55
+KPX Adieresis Oslash -55
+KPX Adieresis Otilde -55
+KPX Adieresis Q -55
+KPX Adieresis T -111
+KPX Adieresis Tcaron -111
+KPX Adieresis Tcommaaccent -111
+KPX Adieresis U -55
+KPX Adieresis Uacute -55
+KPX Adieresis Ucircumflex -55
+KPX Adieresis Udieresis -55
+KPX Adieresis Ugrave -55
+KPX Adieresis Uhungarumlaut -55
+KPX Adieresis Umacron -55
+KPX Adieresis Uogonek -55
+KPX Adieresis Uring -55
+KPX Adieresis V -135
+KPX Adieresis W -90
+KPX Adieresis Y -105
+KPX Adieresis Yacute -105
+KPX Adieresis Ydieresis -105
+KPX Adieresis quoteright -111
+KPX Adieresis v -74
+KPX Adieresis w -92
+KPX Adieresis y -92
+KPX Adieresis yacute -92
+KPX Adieresis ydieresis -92
+KPX Agrave C -40
+KPX Agrave Cacute -40
+KPX Agrave Ccaron -40
+KPX Agrave Ccedilla -40
+KPX Agrave G -40
+KPX Agrave Gbreve -40
+KPX Agrave Gcommaaccent -40
+KPX Agrave O -55
+KPX Agrave Oacute -55
+KPX Agrave Ocircumflex -55
+KPX Agrave Odieresis -55
+KPX Agrave Ograve -55
+KPX Agrave Ohungarumlaut -55
+KPX Agrave Omacron -55
+KPX Agrave Oslash -55
+KPX Agrave Otilde -55
+KPX Agrave Q -55
+KPX Agrave T -111
+KPX Agrave Tcaron -111
+KPX Agrave Tcommaaccent -111
+KPX Agrave U -55
+KPX Agrave Uacute -55
+KPX Agrave Ucircumflex -55
+KPX Agrave Udieresis -55
+KPX Agrave Ugrave -55
+KPX Agrave Uhungarumlaut -55
+KPX Agrave Umacron -55
+KPX Agrave Uogonek -55
+KPX Agrave Uring -55
+KPX Agrave V -135
+KPX Agrave W -90
+KPX Agrave Y -105
+KPX Agrave Yacute -105
+KPX Agrave Ydieresis -105
+KPX Agrave quoteright -111
+KPX Agrave v -74
+KPX Agrave w -92
+KPX Agrave y -92
+KPX Agrave yacute -92
+KPX Agrave ydieresis -92
+KPX Amacron C -40
+KPX Amacron Cacute -40
+KPX Amacron Ccaron -40
+KPX Amacron Ccedilla -40
+KPX Amacron G -40
+KPX Amacron Gbreve -40
+KPX Amacron Gcommaaccent -40
+KPX Amacron O -55
+KPX Amacron Oacute -55
+KPX Amacron Ocircumflex -55
+KPX Amacron Odieresis -55
+KPX Amacron Ograve -55
+KPX Amacron Ohungarumlaut -55
+KPX Amacron Omacron -55
+KPX Amacron Oslash -55
+KPX Amacron Otilde -55
+KPX Amacron Q -55
+KPX Amacron T -111
+KPX Amacron Tcaron -111
+KPX Amacron Tcommaaccent -111
+KPX Amacron U -55
+KPX Amacron Uacute -55
+KPX Amacron Ucircumflex -55
+KPX Amacron Udieresis -55
+KPX Amacron Ugrave -55
+KPX Amacron Uhungarumlaut -55
+KPX Amacron Umacron -55
+KPX Amacron Uogonek -55
+KPX Amacron Uring -55
+KPX Amacron V -135
+KPX Amacron W -90
+KPX Amacron Y -105
+KPX Amacron Yacute -105
+KPX Amacron Ydieresis -105
+KPX Amacron quoteright -111
+KPX Amacron v -74
+KPX Amacron w -92
+KPX Amacron y -92
+KPX Amacron yacute -92
+KPX Amacron ydieresis -92
+KPX Aogonek C -40
+KPX Aogonek Cacute -40
+KPX Aogonek Ccaron -40
+KPX Aogonek Ccedilla -40
+KPX Aogonek G -40
+KPX Aogonek Gbreve -40
+KPX Aogonek Gcommaaccent -40
+KPX Aogonek O -55
+KPX Aogonek Oacute -55
+KPX Aogonek Ocircumflex -55
+KPX Aogonek Odieresis -55
+KPX Aogonek Ograve -55
+KPX Aogonek Ohungarumlaut -55
+KPX Aogonek Omacron -55
+KPX Aogonek Oslash -55
+KPX Aogonek Otilde -55
+KPX Aogonek Q -55
+KPX Aogonek T -111
+KPX Aogonek Tcaron -111
+KPX Aogonek Tcommaaccent -111
+KPX Aogonek U -55
+KPX Aogonek Uacute -55
+KPX Aogonek Ucircumflex -55
+KPX Aogonek Udieresis -55
+KPX Aogonek Ugrave -55
+KPX Aogonek Uhungarumlaut -55
+KPX Aogonek Umacron -55
+KPX Aogonek Uogonek -55
+KPX Aogonek Uring -55
+KPX Aogonek V -135
+KPX Aogonek W -90
+KPX Aogonek Y -105
+KPX Aogonek Yacute -105
+KPX Aogonek Ydieresis -105
+KPX Aogonek quoteright -111
+KPX Aogonek v -74
+KPX Aogonek w -52
+KPX Aogonek y -52
+KPX Aogonek yacute -52
+KPX Aogonek ydieresis -52
+KPX Aring C -40
+KPX Aring Cacute -40
+KPX Aring Ccaron -40
+KPX Aring Ccedilla -40
+KPX Aring G -40
+KPX Aring Gbreve -40
+KPX Aring Gcommaaccent -40
+KPX Aring O -55
+KPX Aring Oacute -55
+KPX Aring Ocircumflex -55
+KPX Aring Odieresis -55
+KPX Aring Ograve -55
+KPX Aring Ohungarumlaut -55
+KPX Aring Omacron -55
+KPX Aring Oslash -55
+KPX Aring Otilde -55
+KPX Aring Q -55
+KPX Aring T -111
+KPX Aring Tcaron -111
+KPX Aring Tcommaaccent -111
+KPX Aring U -55
+KPX Aring Uacute -55
+KPX Aring Ucircumflex -55
+KPX Aring Udieresis -55
+KPX Aring Ugrave -55
+KPX Aring Uhungarumlaut -55
+KPX Aring Umacron -55
+KPX Aring Uogonek -55
+KPX Aring Uring -55
+KPX Aring V -135
+KPX Aring W -90
+KPX Aring Y -105
+KPX Aring Yacute -105
+KPX Aring Ydieresis -105
+KPX Aring quoteright -111
+KPX Aring v -74
+KPX Aring w -92
+KPX Aring y -92
+KPX Aring yacute -92
+KPX Aring ydieresis -92
+KPX Atilde C -40
+KPX Atilde Cacute -40
+KPX Atilde Ccaron -40
+KPX Atilde Ccedilla -40
+KPX Atilde G -40
+KPX Atilde Gbreve -40
+KPX Atilde Gcommaaccent -40
+KPX Atilde O -55
+KPX Atilde Oacute -55
+KPX Atilde Ocircumflex -55
+KPX Atilde Odieresis -55
+KPX Atilde Ograve -55
+KPX Atilde Ohungarumlaut -55
+KPX Atilde Omacron -55
+KPX Atilde Oslash -55
+KPX Atilde Otilde -55
+KPX Atilde Q -55
+KPX Atilde T -111
+KPX Atilde Tcaron -111
+KPX Atilde Tcommaaccent -111
+KPX Atilde U -55
+KPX Atilde Uacute -55
+KPX Atilde Ucircumflex -55
+KPX Atilde Udieresis -55
+KPX Atilde Ugrave -55
+KPX Atilde Uhungarumlaut -55
+KPX Atilde Umacron -55
+KPX Atilde Uogonek -55
+KPX Atilde Uring -55
+KPX Atilde V -135
+KPX Atilde W -90
+KPX Atilde Y -105
+KPX Atilde Yacute -105
+KPX Atilde Ydieresis -105
+KPX Atilde quoteright -111
+KPX Atilde v -74
+KPX Atilde w -92
+KPX Atilde y -92
+KPX Atilde yacute -92
+KPX Atilde ydieresis -92
+KPX B A -35
+KPX B Aacute -35
+KPX B Abreve -35
+KPX B Acircumflex -35
+KPX B Adieresis -35
+KPX B Agrave -35
+KPX B Amacron -35
+KPX B Aogonek -35
+KPX B Aring -35
+KPX B Atilde -35
+KPX B U -10
+KPX B Uacute -10
+KPX B Ucircumflex -10
+KPX B Udieresis -10
+KPX B Ugrave -10
+KPX B Uhungarumlaut -10
+KPX B Umacron -10
+KPX B Uogonek -10
+KPX B Uring -10
+KPX D A -40
+KPX D Aacute -40
+KPX D Abreve -40
+KPX D Acircumflex -40
+KPX D Adieresis -40
+KPX D Agrave -40
+KPX D Amacron -40
+KPX D Aogonek -40
+KPX D Aring -40
+KPX D Atilde -40
+KPX D V -40
+KPX D W -30
+KPX D Y -55
+KPX D Yacute -55
+KPX D Ydieresis -55
+KPX Dcaron A -40
+KPX Dcaron Aacute -40
+KPX Dcaron Abreve -40
+KPX Dcaron Acircumflex -40
+KPX Dcaron Adieresis -40
+KPX Dcaron Agrave -40
+KPX Dcaron Amacron -40
+KPX Dcaron Aogonek -40
+KPX Dcaron Aring -40
+KPX Dcaron Atilde -40
+KPX Dcaron V -40
+KPX Dcaron W -30
+KPX Dcaron Y -55
+KPX Dcaron Yacute -55
+KPX Dcaron Ydieresis -55
+KPX Dcroat A -40
+KPX Dcroat Aacute -40
+KPX Dcroat Abreve -40
+KPX Dcroat Acircumflex -40
+KPX Dcroat Adieresis -40
+KPX Dcroat Agrave -40
+KPX Dcroat Amacron -40
+KPX Dcroat Aogonek -40
+KPX Dcroat Aring -40
+KPX Dcroat Atilde -40
+KPX Dcroat V -40
+KPX Dcroat W -30
+KPX Dcroat Y -55
+KPX Dcroat Yacute -55
+KPX Dcroat Ydieresis -55
+KPX F A -74
+KPX F Aacute -74
+KPX F Abreve -74
+KPX F Acircumflex -74
+KPX F Adieresis -74
+KPX F Agrave -74
+KPX F Amacron -74
+KPX F Aogonek -74
+KPX F Aring -74
+KPX F Atilde -74
+KPX F a -15
+KPX F aacute -15
+KPX F abreve -15
+KPX F acircumflex -15
+KPX F adieresis -15
+KPX F agrave -15
+KPX F amacron -15
+KPX F aogonek -15
+KPX F aring -15
+KPX F atilde -15
+KPX F comma -80
+KPX F o -15
+KPX F oacute -15
+KPX F ocircumflex -15
+KPX F odieresis -15
+KPX F ograve -15
+KPX F ohungarumlaut -15
+KPX F omacron -15
+KPX F oslash -15
+KPX F otilde -15
+KPX F period -80
+KPX J A -60
+KPX J Aacute -60
+KPX J Abreve -60
+KPX J Acircumflex -60
+KPX J Adieresis -60
+KPX J Agrave -60
+KPX J Amacron -60
+KPX J Aogonek -60
+KPX J Aring -60
+KPX J Atilde -60
+KPX K O -30
+KPX K Oacute -30
+KPX K Ocircumflex -30
+KPX K Odieresis -30
+KPX K Ograve -30
+KPX K Ohungarumlaut -30
+KPX K Omacron -30
+KPX K Oslash -30
+KPX K Otilde -30
+KPX K e -25
+KPX K eacute -25
+KPX K ecaron -25
+KPX K ecircumflex -25
+KPX K edieresis -25
+KPX K edotaccent -25
+KPX K egrave -25
+KPX K emacron -25
+KPX K eogonek -25
+KPX K o -35
+KPX K oacute -35
+KPX K ocircumflex -35
+KPX K odieresis -35
+KPX K ograve -35
+KPX K ohungarumlaut -35
+KPX K omacron -35
+KPX K oslash -35
+KPX K otilde -35
+KPX K u -15
+KPX K uacute -15
+KPX K ucircumflex -15
+KPX K udieresis -15
+KPX K ugrave -15
+KPX K uhungarumlaut -15
+KPX K umacron -15
+KPX K uogonek -15
+KPX K uring -15
+KPX K y -25
+KPX K yacute -25
+KPX K ydieresis -25
+KPX Kcommaaccent O -30
+KPX Kcommaaccent Oacute -30
+KPX Kcommaaccent Ocircumflex -30
+KPX Kcommaaccent Odieresis -30
+KPX Kcommaaccent Ograve -30
+KPX Kcommaaccent Ohungarumlaut -30
+KPX Kcommaaccent Omacron -30
+KPX Kcommaaccent Oslash -30
+KPX Kcommaaccent Otilde -30
+KPX Kcommaaccent e -25
+KPX Kcommaaccent eacute -25
+KPX Kcommaaccent ecaron -25
+KPX Kcommaaccent ecircumflex -25
+KPX Kcommaaccent edieresis -25
+KPX Kcommaaccent edotaccent -25
+KPX Kcommaaccent egrave -25
+KPX Kcommaaccent emacron -25
+KPX Kcommaaccent eogonek -25
+KPX Kcommaaccent o -35
+KPX Kcommaaccent oacute -35
+KPX Kcommaaccent ocircumflex -35
+KPX Kcommaaccent odieresis -35
+KPX Kcommaaccent ograve -35
+KPX Kcommaaccent ohungarumlaut -35
+KPX Kcommaaccent omacron -35
+KPX Kcommaaccent oslash -35
+KPX Kcommaaccent otilde -35
+KPX Kcommaaccent u -15
+KPX Kcommaaccent uacute -15
+KPX Kcommaaccent ucircumflex -15
+KPX Kcommaaccent udieresis -15
+KPX Kcommaaccent ugrave -15
+KPX Kcommaaccent uhungarumlaut -15
+KPX Kcommaaccent umacron -15
+KPX Kcommaaccent uogonek -15
+KPX Kcommaaccent uring -15
+KPX Kcommaaccent y -25
+KPX Kcommaaccent yacute -25
+KPX Kcommaaccent ydieresis -25
+KPX L T -92
+KPX L Tcaron -92
+KPX L Tcommaaccent -92
+KPX L V -100
+KPX L W -74
+KPX L Y -100
+KPX L Yacute -100
+KPX L Ydieresis -100
+KPX L quoteright -92
+KPX L y -55
+KPX L yacute -55
+KPX L ydieresis -55
+KPX Lacute T -92
+KPX Lacute Tcaron -92
+KPX Lacute Tcommaaccent -92
+KPX Lacute V -100
+KPX Lacute W -74
+KPX Lacute Y -100
+KPX Lacute Yacute -100
+KPX Lacute Ydieresis -100
+KPX Lacute quoteright -92
+KPX Lacute y -55
+KPX Lacute yacute -55
+KPX Lacute ydieresis -55
+KPX Lcaron quoteright -92
+KPX Lcaron y -55
+KPX Lcaron yacute -55
+KPX Lcaron ydieresis -55
+KPX Lcommaaccent T -92
+KPX Lcommaaccent Tcaron -92
+KPX Lcommaaccent Tcommaaccent -92
+KPX Lcommaaccent V -100
+KPX Lcommaaccent W -74
+KPX Lcommaaccent Y -100
+KPX Lcommaaccent Yacute -100
+KPX Lcommaaccent Ydieresis -100
+KPX Lcommaaccent quoteright -92
+KPX Lcommaaccent y -55
+KPX Lcommaaccent yacute -55
+KPX Lcommaaccent ydieresis -55
+KPX Lslash T -92
+KPX Lslash Tcaron -92
+KPX Lslash Tcommaaccent -92
+KPX Lslash V -100
+KPX Lslash W -74
+KPX Lslash Y -100
+KPX Lslash Yacute -100
+KPX Lslash Ydieresis -100
+KPX Lslash quoteright -92
+KPX Lslash y -55
+KPX Lslash yacute -55
+KPX Lslash ydieresis -55
+KPX N A -35
+KPX N Aacute -35
+KPX N Abreve -35
+KPX N Acircumflex -35
+KPX N Adieresis -35
+KPX N Agrave -35
+KPX N Amacron -35
+KPX N Aogonek -35
+KPX N Aring -35
+KPX N Atilde -35
+KPX Nacute A -35
+KPX Nacute Aacute -35
+KPX Nacute Abreve -35
+KPX Nacute Acircumflex -35
+KPX Nacute Adieresis -35
+KPX Nacute Agrave -35
+KPX Nacute Amacron -35
+KPX Nacute Aogonek -35
+KPX Nacute Aring -35
+KPX Nacute Atilde -35
+KPX Ncaron A -35
+KPX Ncaron Aacute -35
+KPX Ncaron Abreve -35
+KPX Ncaron Acircumflex -35
+KPX Ncaron Adieresis -35
+KPX Ncaron Agrave -35
+KPX Ncaron Amacron -35
+KPX Ncaron Aogonek -35
+KPX Ncaron Aring -35
+KPX Ncaron Atilde -35
+KPX Ncommaaccent A -35
+KPX Ncommaaccent Aacute -35
+KPX Ncommaaccent Abreve -35
+KPX Ncommaaccent Acircumflex -35
+KPX Ncommaaccent Adieresis -35
+KPX Ncommaaccent Agrave -35
+KPX Ncommaaccent Amacron -35
+KPX Ncommaaccent Aogonek -35
+KPX Ncommaaccent Aring -35
+KPX Ncommaaccent Atilde -35
+KPX Ntilde A -35
+KPX Ntilde Aacute -35
+KPX Ntilde Abreve -35
+KPX Ntilde Acircumflex -35
+KPX Ntilde Adieresis -35
+KPX Ntilde Agrave -35
+KPX Ntilde Amacron -35
+KPX Ntilde Aogonek -35
+KPX Ntilde Aring -35
+KPX Ntilde Atilde -35
+KPX O A -35
+KPX O Aacute -35
+KPX O Abreve -35
+KPX O Acircumflex -35
+KPX O Adieresis -35
+KPX O Agrave -35
+KPX O Amacron -35
+KPX O Aogonek -35
+KPX O Aring -35
+KPX O Atilde -35
+KPX O T -40
+KPX O Tcaron -40
+KPX O Tcommaaccent -40
+KPX O V -50
+KPX O W -35
+KPX O X -40
+KPX O Y -50
+KPX O Yacute -50
+KPX O Ydieresis -50
+KPX Oacute A -35
+KPX Oacute Aacute -35
+KPX Oacute Abreve -35
+KPX Oacute Acircumflex -35
+KPX Oacute Adieresis -35
+KPX Oacute Agrave -35
+KPX Oacute Amacron -35
+KPX Oacute Aogonek -35
+KPX Oacute Aring -35
+KPX Oacute Atilde -35
+KPX Oacute T -40
+KPX Oacute Tcaron -40
+KPX Oacute Tcommaaccent -40
+KPX Oacute V -50
+KPX Oacute W -35
+KPX Oacute X -40
+KPX Oacute Y -50
+KPX Oacute Yacute -50
+KPX Oacute Ydieresis -50
+KPX Ocircumflex A -35
+KPX Ocircumflex Aacute -35
+KPX Ocircumflex Abreve -35
+KPX Ocircumflex Acircumflex -35
+KPX Ocircumflex Adieresis -35
+KPX Ocircumflex Agrave -35
+KPX Ocircumflex Amacron -35
+KPX Ocircumflex Aogonek -35
+KPX Ocircumflex Aring -35
+KPX Ocircumflex Atilde -35
+KPX Ocircumflex T -40
+KPX Ocircumflex Tcaron -40
+KPX Ocircumflex Tcommaaccent -40
+KPX Ocircumflex V -50
+KPX Ocircumflex W -35
+KPX Ocircumflex X -40
+KPX Ocircumflex Y -50
+KPX Ocircumflex Yacute -50
+KPX Ocircumflex Ydieresis -50
+KPX Odieresis A -35
+KPX Odieresis Aacute -35
+KPX Odieresis Abreve -35
+KPX Odieresis Acircumflex -35
+KPX Odieresis Adieresis -35
+KPX Odieresis Agrave -35
+KPX Odieresis Amacron -35
+KPX Odieresis Aogonek -35
+KPX Odieresis Aring -35
+KPX Odieresis Atilde -35
+KPX Odieresis T -40
+KPX Odieresis Tcaron -40
+KPX Odieresis Tcommaaccent -40
+KPX Odieresis V -50
+KPX Odieresis W -35
+KPX Odieresis X -40
+KPX Odieresis Y -50
+KPX Odieresis Yacute -50
+KPX Odieresis Ydieresis -50
+KPX Ograve A -35
+KPX Ograve Aacute -35
+KPX Ograve Abreve -35
+KPX Ograve Acircumflex -35
+KPX Ograve Adieresis -35
+KPX Ograve Agrave -35
+KPX Ograve Amacron -35
+KPX Ograve Aogonek -35
+KPX Ograve Aring -35
+KPX Ograve Atilde -35
+KPX Ograve T -40
+KPX Ograve Tcaron -40
+KPX Ograve Tcommaaccent -40
+KPX Ograve V -50
+KPX Ograve W -35
+KPX Ograve X -40
+KPX Ograve Y -50
+KPX Ograve Yacute -50
+KPX Ograve Ydieresis -50
+KPX Ohungarumlaut A -35
+KPX Ohungarumlaut Aacute -35
+KPX Ohungarumlaut Abreve -35
+KPX Ohungarumlaut Acircumflex -35
+KPX Ohungarumlaut Adieresis -35
+KPX Ohungarumlaut Agrave -35
+KPX Ohungarumlaut Amacron -35
+KPX Ohungarumlaut Aogonek -35
+KPX Ohungarumlaut Aring -35
+KPX Ohungarumlaut Atilde -35
+KPX Ohungarumlaut T -40
+KPX Ohungarumlaut Tcaron -40
+KPX Ohungarumlaut Tcommaaccent -40
+KPX Ohungarumlaut V -50
+KPX Ohungarumlaut W -35
+KPX Ohungarumlaut X -40
+KPX Ohungarumlaut Y -50
+KPX Ohungarumlaut Yacute -50
+KPX Ohungarumlaut Ydieresis -50
+KPX Omacron A -35
+KPX Omacron Aacute -35
+KPX Omacron Abreve -35
+KPX Omacron Acircumflex -35
+KPX Omacron Adieresis -35
+KPX Omacron Agrave -35
+KPX Omacron Amacron -35
+KPX Omacron Aogonek -35
+KPX Omacron Aring -35
+KPX Omacron Atilde -35
+KPX Omacron T -40
+KPX Omacron Tcaron -40
+KPX Omacron Tcommaaccent -40
+KPX Omacron V -50
+KPX Omacron W -35
+KPX Omacron X -40
+KPX Omacron Y -50
+KPX Omacron Yacute -50
+KPX Omacron Ydieresis -50
+KPX Oslash A -35
+KPX Oslash Aacute -35
+KPX Oslash Abreve -35
+KPX Oslash Acircumflex -35
+KPX Oslash Adieresis -35
+KPX Oslash Agrave -35
+KPX Oslash Amacron -35
+KPX Oslash Aogonek -35
+KPX Oslash Aring -35
+KPX Oslash Atilde -35
+KPX Oslash T -40
+KPX Oslash Tcaron -40
+KPX Oslash Tcommaaccent -40
+KPX Oslash V -50
+KPX Oslash W -35
+KPX Oslash X -40
+KPX Oslash Y -50
+KPX Oslash Yacute -50
+KPX Oslash Ydieresis -50
+KPX Otilde A -35
+KPX Otilde Aacute -35
+KPX Otilde Abreve -35
+KPX Otilde Acircumflex -35
+KPX Otilde Adieresis -35
+KPX Otilde Agrave -35
+KPX Otilde Amacron -35
+KPX Otilde Aogonek -35
+KPX Otilde Aring -35
+KPX Otilde Atilde -35
+KPX Otilde T -40
+KPX Otilde Tcaron -40
+KPX Otilde Tcommaaccent -40
+KPX Otilde V -50
+KPX Otilde W -35
+KPX Otilde X -40
+KPX Otilde Y -50
+KPX Otilde Yacute -50
+KPX Otilde Ydieresis -50
+KPX P A -92
+KPX P Aacute -92
+KPX P Abreve -92
+KPX P Acircumflex -92
+KPX P Adieresis -92
+KPX P Agrave -92
+KPX P Amacron -92
+KPX P Aogonek -92
+KPX P Aring -92
+KPX P Atilde -92
+KPX P a -15
+KPX P aacute -15
+KPX P abreve -15
+KPX P acircumflex -15
+KPX P adieresis -15
+KPX P agrave -15
+KPX P amacron -15
+KPX P aogonek -15
+KPX P aring -15
+KPX P atilde -15
+KPX P comma -111
+KPX P period -111
+KPX Q U -10
+KPX Q Uacute -10
+KPX Q Ucircumflex -10
+KPX Q Udieresis -10
+KPX Q Ugrave -10
+KPX Q Uhungarumlaut -10
+KPX Q Umacron -10
+KPX Q Uogonek -10
+KPX Q Uring -10
+KPX R O -40
+KPX R Oacute -40
+KPX R Ocircumflex -40
+KPX R Odieresis -40
+KPX R Ograve -40
+KPX R Ohungarumlaut -40
+KPX R Omacron -40
+KPX R Oslash -40
+KPX R Otilde -40
+KPX R T -60
+KPX R Tcaron -60
+KPX R Tcommaaccent -60
+KPX R U -40
+KPX R Uacute -40
+KPX R Ucircumflex -40
+KPX R Udieresis -40
+KPX R Ugrave -40
+KPX R Uhungarumlaut -40
+KPX R Umacron -40
+KPX R Uogonek -40
+KPX R Uring -40
+KPX R V -80
+KPX R W -55
+KPX R Y -65
+KPX R Yacute -65
+KPX R Ydieresis -65
+KPX Racute O -40
+KPX Racute Oacute -40
+KPX Racute Ocircumflex -40
+KPX Racute Odieresis -40
+KPX Racute Ograve -40
+KPX Racute Ohungarumlaut -40
+KPX Racute Omacron -40
+KPX Racute Oslash -40
+KPX Racute Otilde -40
+KPX Racute T -60
+KPX Racute Tcaron -60
+KPX Racute Tcommaaccent -60
+KPX Racute U -40
+KPX Racute Uacute -40
+KPX Racute Ucircumflex -40
+KPX Racute Udieresis -40
+KPX Racute Ugrave -40
+KPX Racute Uhungarumlaut -40
+KPX Racute Umacron -40
+KPX Racute Uogonek -40
+KPX Racute Uring -40
+KPX Racute V -80
+KPX Racute W -55
+KPX Racute Y -65
+KPX Racute Yacute -65
+KPX Racute Ydieresis -65
+KPX Rcaron O -40
+KPX Rcaron Oacute -40
+KPX Rcaron Ocircumflex -40
+KPX Rcaron Odieresis -40
+KPX Rcaron Ograve -40
+KPX Rcaron Ohungarumlaut -40
+KPX Rcaron Omacron -40
+KPX Rcaron Oslash -40
+KPX Rcaron Otilde -40
+KPX Rcaron T -60
+KPX Rcaron Tcaron -60
+KPX Rcaron Tcommaaccent -60
+KPX Rcaron U -40
+KPX Rcaron Uacute -40
+KPX Rcaron Ucircumflex -40
+KPX Rcaron Udieresis -40
+KPX Rcaron Ugrave -40
+KPX Rcaron Uhungarumlaut -40
+KPX Rcaron Umacron -40
+KPX Rcaron Uogonek -40
+KPX Rcaron Uring -40
+KPX Rcaron V -80
+KPX Rcaron W -55
+KPX Rcaron Y -65
+KPX Rcaron Yacute -65
+KPX Rcaron Ydieresis -65
+KPX Rcommaaccent O -40
+KPX Rcommaaccent Oacute -40
+KPX Rcommaaccent Ocircumflex -40
+KPX Rcommaaccent Odieresis -40
+KPX Rcommaaccent Ograve -40
+KPX Rcommaaccent Ohungarumlaut -40
+KPX Rcommaaccent Omacron -40
+KPX Rcommaaccent Oslash -40
+KPX Rcommaaccent Otilde -40
+KPX Rcommaaccent T -60
+KPX Rcommaaccent Tcaron -60
+KPX Rcommaaccent Tcommaaccent -60
+KPX Rcommaaccent U -40
+KPX Rcommaaccent Uacute -40
+KPX Rcommaaccent Ucircumflex -40
+KPX Rcommaaccent Udieresis -40
+KPX Rcommaaccent Ugrave -40
+KPX Rcommaaccent Uhungarumlaut -40
+KPX Rcommaaccent Umacron -40
+KPX Rcommaaccent Uogonek -40
+KPX Rcommaaccent Uring -40
+KPX Rcommaaccent V -80
+KPX Rcommaaccent W -55
+KPX Rcommaaccent Y -65
+KPX Rcommaaccent Yacute -65
+KPX Rcommaaccent Ydieresis -65
+KPX T A -93
+KPX T Aacute -93
+KPX T Abreve -93
+KPX T Acircumflex -93
+KPX T Adieresis -93
+KPX T Agrave -93
+KPX T Amacron -93
+KPX T Aogonek -93
+KPX T Aring -93
+KPX T Atilde -93
+KPX T O -18
+KPX T Oacute -18
+KPX T Ocircumflex -18
+KPX T Odieresis -18
+KPX T Ograve -18
+KPX T Ohungarumlaut -18
+KPX T Omacron -18
+KPX T Oslash -18
+KPX T Otilde -18
+KPX T a -80
+KPX T aacute -80
+KPX T abreve -80
+KPX T acircumflex -80
+KPX T adieresis -40
+KPX T agrave -40
+KPX T amacron -40
+KPX T aogonek -80
+KPX T aring -80
+KPX T atilde -40
+KPX T colon -50
+KPX T comma -74
+KPX T e -70
+KPX T eacute -70
+KPX T ecaron -70
+KPX T ecircumflex -70
+KPX T edieresis -30
+KPX T edotaccent -70
+KPX T egrave -70
+KPX T emacron -30
+KPX T eogonek -70
+KPX T hyphen -92
+KPX T i -35
+KPX T iacute -35
+KPX T iogonek -35
+KPX T o -80
+KPX T oacute -80
+KPX T ocircumflex -80
+KPX T odieresis -80
+KPX T ograve -80
+KPX T ohungarumlaut -80
+KPX T omacron -80
+KPX T oslash -80
+KPX T otilde -80
+KPX T period -74
+KPX T r -35
+KPX T racute -35
+KPX T rcaron -35
+KPX T rcommaaccent -35
+KPX T semicolon -55
+KPX T u -45
+KPX T uacute -45
+KPX T ucircumflex -45
+KPX T udieresis -45
+KPX T ugrave -45
+KPX T uhungarumlaut -45
+KPX T umacron -45
+KPX T uogonek -45
+KPX T uring -45
+KPX T w -80
+KPX T y -80
+KPX T yacute -80
+KPX T ydieresis -80
+KPX Tcaron A -93
+KPX Tcaron Aacute -93
+KPX Tcaron Abreve -93
+KPX Tcaron Acircumflex -93
+KPX Tcaron Adieresis -93
+KPX Tcaron Agrave -93
+KPX Tcaron Amacron -93
+KPX Tcaron Aogonek -93
+KPX Tcaron Aring -93
+KPX Tcaron Atilde -93
+KPX Tcaron O -18
+KPX Tcaron Oacute -18
+KPX Tcaron Ocircumflex -18
+KPX Tcaron Odieresis -18
+KPX Tcaron Ograve -18
+KPX Tcaron Ohungarumlaut -18
+KPX Tcaron Omacron -18
+KPX Tcaron Oslash -18
+KPX Tcaron Otilde -18
+KPX Tcaron a -80
+KPX Tcaron aacute -80
+KPX Tcaron abreve -80
+KPX Tcaron acircumflex -80
+KPX Tcaron adieresis -40
+KPX Tcaron agrave -40
+KPX Tcaron amacron -40
+KPX Tcaron aogonek -80
+KPX Tcaron aring -80
+KPX Tcaron atilde -40
+KPX Tcaron colon -50
+KPX Tcaron comma -74
+KPX Tcaron e -70
+KPX Tcaron eacute -70
+KPX Tcaron ecaron -70
+KPX Tcaron ecircumflex -30
+KPX Tcaron edieresis -30
+KPX Tcaron edotaccent -70
+KPX Tcaron egrave -70
+KPX Tcaron emacron -30
+KPX Tcaron eogonek -70
+KPX Tcaron hyphen -92
+KPX Tcaron i -35
+KPX Tcaron iacute -35
+KPX Tcaron iogonek -35
+KPX Tcaron o -80
+KPX Tcaron oacute -80
+KPX Tcaron ocircumflex -80
+KPX Tcaron odieresis -80
+KPX Tcaron ograve -80
+KPX Tcaron ohungarumlaut -80
+KPX Tcaron omacron -80
+KPX Tcaron oslash -80
+KPX Tcaron otilde -80
+KPX Tcaron period -74
+KPX Tcaron r -35
+KPX Tcaron racute -35
+KPX Tcaron rcaron -35
+KPX Tcaron rcommaaccent -35
+KPX Tcaron semicolon -55
+KPX Tcaron u -45
+KPX Tcaron uacute -45
+KPX Tcaron ucircumflex -45
+KPX Tcaron udieresis -45
+KPX Tcaron ugrave -45
+KPX Tcaron uhungarumlaut -45
+KPX Tcaron umacron -45
+KPX Tcaron uogonek -45
+KPX Tcaron uring -45
+KPX Tcaron w -80
+KPX Tcaron y -80
+KPX Tcaron yacute -80
+KPX Tcaron ydieresis -80
+KPX Tcommaaccent A -93
+KPX Tcommaaccent Aacute -93
+KPX Tcommaaccent Abreve -93
+KPX Tcommaaccent Acircumflex -93
+KPX Tcommaaccent Adieresis -93
+KPX Tcommaaccent Agrave -93
+KPX Tcommaaccent Amacron -93
+KPX Tcommaaccent Aogonek -93
+KPX Tcommaaccent Aring -93
+KPX Tcommaaccent Atilde -93
+KPX Tcommaaccent O -18
+KPX Tcommaaccent Oacute -18
+KPX Tcommaaccent Ocircumflex -18
+KPX Tcommaaccent Odieresis -18
+KPX Tcommaaccent Ograve -18
+KPX Tcommaaccent Ohungarumlaut -18
+KPX Tcommaaccent Omacron -18
+KPX Tcommaaccent Oslash -18
+KPX Tcommaaccent Otilde -18
+KPX Tcommaaccent a -80
+KPX Tcommaaccent aacute -80
+KPX Tcommaaccent abreve -80
+KPX Tcommaaccent acircumflex -80
+KPX Tcommaaccent adieresis -40
+KPX Tcommaaccent agrave -40
+KPX Tcommaaccent amacron -40
+KPX Tcommaaccent aogonek -80
+KPX Tcommaaccent aring -80
+KPX Tcommaaccent atilde -40
+KPX Tcommaaccent colon -50
+KPX Tcommaaccent comma -74
+KPX Tcommaaccent e -70
+KPX Tcommaaccent eacute -70
+KPX Tcommaaccent ecaron -70
+KPX Tcommaaccent ecircumflex -30
+KPX Tcommaaccent edieresis -30
+KPX Tcommaaccent edotaccent -70
+KPX Tcommaaccent egrave -30
+KPX Tcommaaccent emacron -70
+KPX Tcommaaccent eogonek -70
+KPX Tcommaaccent hyphen -92
+KPX Tcommaaccent i -35
+KPX Tcommaaccent iacute -35
+KPX Tcommaaccent iogonek -35
+KPX Tcommaaccent o -80
+KPX Tcommaaccent oacute -80
+KPX Tcommaaccent ocircumflex -80
+KPX Tcommaaccent odieresis -80
+KPX Tcommaaccent ograve -80
+KPX Tcommaaccent ohungarumlaut -80
+KPX Tcommaaccent omacron -80
+KPX Tcommaaccent oslash -80
+KPX Tcommaaccent otilde -80
+KPX Tcommaaccent period -74
+KPX Tcommaaccent r -35
+KPX Tcommaaccent racute -35
+KPX Tcommaaccent rcaron -35
+KPX Tcommaaccent rcommaaccent -35
+KPX Tcommaaccent semicolon -55
+KPX Tcommaaccent u -45
+KPX Tcommaaccent uacute -45
+KPX Tcommaaccent ucircumflex -45
+KPX Tcommaaccent udieresis -45
+KPX Tcommaaccent ugrave -45
+KPX Tcommaaccent uhungarumlaut -45
+KPX Tcommaaccent umacron -45
+KPX Tcommaaccent uogonek -45
+KPX Tcommaaccent uring -45
+KPX Tcommaaccent w -80
+KPX Tcommaaccent y -80
+KPX Tcommaaccent yacute -80
+KPX Tcommaaccent ydieresis -80
+KPX U A -40
+KPX U Aacute -40
+KPX U Abreve -40
+KPX U Acircumflex -40
+KPX U Adieresis -40
+KPX U Agrave -40
+KPX U Amacron -40
+KPX U Aogonek -40
+KPX U Aring -40
+KPX U Atilde -40
+KPX Uacute A -40
+KPX Uacute Aacute -40
+KPX Uacute Abreve -40
+KPX Uacute Acircumflex -40
+KPX Uacute Adieresis -40
+KPX Uacute Agrave -40
+KPX Uacute Amacron -40
+KPX Uacute Aogonek -40
+KPX Uacute Aring -40
+KPX Uacute Atilde -40
+KPX Ucircumflex A -40
+KPX Ucircumflex Aacute -40
+KPX Ucircumflex Abreve -40
+KPX Ucircumflex Acircumflex -40
+KPX Ucircumflex Adieresis -40
+KPX Ucircumflex Agrave -40
+KPX Ucircumflex Amacron -40
+KPX Ucircumflex Aogonek -40
+KPX Ucircumflex Aring -40
+KPX Ucircumflex Atilde -40
+KPX Udieresis A -40
+KPX Udieresis Aacute -40
+KPX Udieresis Abreve -40
+KPX Udieresis Acircumflex -40
+KPX Udieresis Adieresis -40
+KPX Udieresis Agrave -40
+KPX Udieresis Amacron -40
+KPX Udieresis Aogonek -40
+KPX Udieresis Aring -40
+KPX Udieresis Atilde -40
+KPX Ugrave A -40
+KPX Ugrave Aacute -40
+KPX Ugrave Abreve -40
+KPX Ugrave Acircumflex -40
+KPX Ugrave Adieresis -40
+KPX Ugrave Agrave -40
+KPX Ugrave Amacron -40
+KPX Ugrave Aogonek -40
+KPX Ugrave Aring -40
+KPX Ugrave Atilde -40
+KPX Uhungarumlaut A -40
+KPX Uhungarumlaut Aacute -40
+KPX Uhungarumlaut Abreve -40
+KPX Uhungarumlaut Acircumflex -40
+KPX Uhungarumlaut Adieresis -40
+KPX Uhungarumlaut Agrave -40
+KPX Uhungarumlaut Amacron -40
+KPX Uhungarumlaut Aogonek -40
+KPX Uhungarumlaut Aring -40
+KPX Uhungarumlaut Atilde -40
+KPX Umacron A -40
+KPX Umacron Aacute -40
+KPX Umacron Abreve -40
+KPX Umacron Acircumflex -40
+KPX Umacron Adieresis -40
+KPX Umacron Agrave -40
+KPX Umacron Amacron -40
+KPX Umacron Aogonek -40
+KPX Umacron Aring -40
+KPX Umacron Atilde -40
+KPX Uogonek A -40
+KPX Uogonek Aacute -40
+KPX Uogonek Abreve -40
+KPX Uogonek Acircumflex -40
+KPX Uogonek Adieresis -40
+KPX Uogonek Agrave -40
+KPX Uogonek Amacron -40
+KPX Uogonek Aogonek -40
+KPX Uogonek Aring -40
+KPX Uogonek Atilde -40
+KPX Uring A -40
+KPX Uring Aacute -40
+KPX Uring Abreve -40
+KPX Uring Acircumflex -40
+KPX Uring Adieresis -40
+KPX Uring Agrave -40
+KPX Uring Amacron -40
+KPX Uring Aogonek -40
+KPX Uring Aring -40
+KPX Uring Atilde -40
+KPX V A -135
+KPX V Aacute -135
+KPX V Abreve -135
+KPX V Acircumflex -135
+KPX V Adieresis -135
+KPX V Agrave -135
+KPX V Amacron -135
+KPX V Aogonek -135
+KPX V Aring -135
+KPX V Atilde -135
+KPX V G -15
+KPX V Gbreve -15
+KPX V Gcommaaccent -15
+KPX V O -40
+KPX V Oacute -40
+KPX V Ocircumflex -40
+KPX V Odieresis -40
+KPX V Ograve -40
+KPX V Ohungarumlaut -40
+KPX V Omacron -40
+KPX V Oslash -40
+KPX V Otilde -40
+KPX V a -111
+KPX V aacute -111
+KPX V abreve -111
+KPX V acircumflex -71
+KPX V adieresis -71
+KPX V agrave -71
+KPX V amacron -71
+KPX V aogonek -111
+KPX V aring -111
+KPX V atilde -71
+KPX V colon -74
+KPX V comma -129
+KPX V e -111
+KPX V eacute -111
+KPX V ecaron -71
+KPX V ecircumflex -71
+KPX V edieresis -71
+KPX V edotaccent -111
+KPX V egrave -71
+KPX V emacron -71
+KPX V eogonek -111
+KPX V hyphen -100
+KPX V i -60
+KPX V iacute -60
+KPX V icircumflex -20
+KPX V idieresis -20
+KPX V igrave -20
+KPX V imacron -20
+KPX V iogonek -60
+KPX V o -129
+KPX V oacute -129
+KPX V ocircumflex -129
+KPX V odieresis -89
+KPX V ograve -89
+KPX V ohungarumlaut -129
+KPX V omacron -89
+KPX V oslash -129
+KPX V otilde -89
+KPX V period -129
+KPX V semicolon -74
+KPX V u -75
+KPX V uacute -75
+KPX V ucircumflex -75
+KPX V udieresis -75
+KPX V ugrave -75
+KPX V uhungarumlaut -75
+KPX V umacron -75
+KPX V uogonek -75
+KPX V uring -75
+KPX W A -120
+KPX W Aacute -120
+KPX W Abreve -120
+KPX W Acircumflex -120
+KPX W Adieresis -120
+KPX W Agrave -120
+KPX W Amacron -120
+KPX W Aogonek -120
+KPX W Aring -120
+KPX W Atilde -120
+KPX W O -10
+KPX W Oacute -10
+KPX W Ocircumflex -10
+KPX W Odieresis -10
+KPX W Ograve -10
+KPX W Ohungarumlaut -10
+KPX W Omacron -10
+KPX W Oslash -10
+KPX W Otilde -10
+KPX W a -80
+KPX W aacute -80
+KPX W abreve -80
+KPX W acircumflex -80
+KPX W adieresis -80
+KPX W agrave -80
+KPX W amacron -80
+KPX W aogonek -80
+KPX W aring -80
+KPX W atilde -80
+KPX W colon -37
+KPX W comma -92
+KPX W e -80
+KPX W eacute -80
+KPX W ecaron -80
+KPX W ecircumflex -80
+KPX W edieresis -40
+KPX W edotaccent -80
+KPX W egrave -40
+KPX W emacron -40
+KPX W eogonek -80
+KPX W hyphen -65
+KPX W i -40
+KPX W iacute -40
+KPX W iogonek -40
+KPX W o -80
+KPX W oacute -80
+KPX W ocircumflex -80
+KPX W odieresis -80
+KPX W ograve -80
+KPX W ohungarumlaut -80
+KPX W omacron -80
+KPX W oslash -80
+KPX W otilde -80
+KPX W period -92
+KPX W semicolon -37
+KPX W u -50
+KPX W uacute -50
+KPX W ucircumflex -50
+KPX W udieresis -50
+KPX W ugrave -50
+KPX W uhungarumlaut -50
+KPX W umacron -50
+KPX W uogonek -50
+KPX W uring -50
+KPX W y -73
+KPX W yacute -73
+KPX W ydieresis -73
+KPX Y A -120
+KPX Y Aacute -120
+KPX Y Abreve -120
+KPX Y Acircumflex -120
+KPX Y Adieresis -120
+KPX Y Agrave -120
+KPX Y Amacron -120
+KPX Y Aogonek -120
+KPX Y Aring -120
+KPX Y Atilde -120
+KPX Y O -30
+KPX Y Oacute -30
+KPX Y Ocircumflex -30
+KPX Y Odieresis -30
+KPX Y Ograve -30
+KPX Y Ohungarumlaut -30
+KPX Y Omacron -30
+KPX Y Oslash -30
+KPX Y Otilde -30
+KPX Y a -100
+KPX Y aacute -100
+KPX Y abreve -100
+KPX Y acircumflex -100
+KPX Y adieresis -60
+KPX Y agrave -60
+KPX Y amacron -60
+KPX Y aogonek -100
+KPX Y aring -100
+KPX Y atilde -60
+KPX Y colon -92
+KPX Y comma -129
+KPX Y e -100
+KPX Y eacute -100
+KPX Y ecaron -100
+KPX Y ecircumflex -100
+KPX Y edieresis -60
+KPX Y edotaccent -100
+KPX Y egrave -60
+KPX Y emacron -60
+KPX Y eogonek -100
+KPX Y hyphen -111
+KPX Y i -55
+KPX Y iacute -55
+KPX Y iogonek -55
+KPX Y o -110
+KPX Y oacute -110
+KPX Y ocircumflex -110
+KPX Y odieresis -70
+KPX Y ograve -70
+KPX Y ohungarumlaut -110
+KPX Y omacron -70
+KPX Y oslash -110
+KPX Y otilde -70
+KPX Y period -129
+KPX Y semicolon -92
+KPX Y u -111
+KPX Y uacute -111
+KPX Y ucircumflex -111
+KPX Y udieresis -71
+KPX Y ugrave -71
+KPX Y uhungarumlaut -111
+KPX Y umacron -71
+KPX Y uogonek -111
+KPX Y uring -111
+KPX Yacute A -120
+KPX Yacute Aacute -120
+KPX Yacute Abreve -120
+KPX Yacute Acircumflex -120
+KPX Yacute Adieresis -120
+KPX Yacute Agrave -120
+KPX Yacute Amacron -120
+KPX Yacute Aogonek -120
+KPX Yacute Aring -120
+KPX Yacute Atilde -120
+KPX Yacute O -30
+KPX Yacute Oacute -30
+KPX Yacute Ocircumflex -30
+KPX Yacute Odieresis -30
+KPX Yacute Ograve -30
+KPX Yacute Ohungarumlaut -30
+KPX Yacute Omacron -30
+KPX Yacute Oslash -30
+KPX Yacute Otilde -30
+KPX Yacute a -100
+KPX Yacute aacute -100
+KPX Yacute abreve -100
+KPX Yacute acircumflex -100
+KPX Yacute adieresis -60
+KPX Yacute agrave -60
+KPX Yacute amacron -60
+KPX Yacute aogonek -100
+KPX Yacute aring -100
+KPX Yacute atilde -60
+KPX Yacute colon -92
+KPX Yacute comma -129
+KPX Yacute e -100
+KPX Yacute eacute -100
+KPX Yacute ecaron -100
+KPX Yacute ecircumflex -100
+KPX Yacute edieresis -60
+KPX Yacute edotaccent -100
+KPX Yacute egrave -60
+KPX Yacute emacron -60
+KPX Yacute eogonek -100
+KPX Yacute hyphen -111
+KPX Yacute i -55
+KPX Yacute iacute -55
+KPX Yacute iogonek -55
+KPX Yacute o -110
+KPX Yacute oacute -110
+KPX Yacute ocircumflex -110
+KPX Yacute odieresis -70
+KPX Yacute ograve -70
+KPX Yacute ohungarumlaut -110
+KPX Yacute omacron -70
+KPX Yacute oslash -110
+KPX Yacute otilde -70
+KPX Yacute period -129
+KPX Yacute semicolon -92
+KPX Yacute u -111
+KPX Yacute uacute -111
+KPX Yacute ucircumflex -111
+KPX Yacute udieresis -71
+KPX Yacute ugrave -71
+KPX Yacute uhungarumlaut -111
+KPX Yacute umacron -71
+KPX Yacute uogonek -111
+KPX Yacute uring -111
+KPX Ydieresis A -120
+KPX Ydieresis Aacute -120
+KPX Ydieresis Abreve -120
+KPX Ydieresis Acircumflex -120
+KPX Ydieresis Adieresis -120
+KPX Ydieresis Agrave -120
+KPX Ydieresis Amacron -120
+KPX Ydieresis Aogonek -120
+KPX Ydieresis Aring -120
+KPX Ydieresis Atilde -120
+KPX Ydieresis O -30
+KPX Ydieresis Oacute -30
+KPX Ydieresis Ocircumflex -30
+KPX Ydieresis Odieresis -30
+KPX Ydieresis Ograve -30
+KPX Ydieresis Ohungarumlaut -30
+KPX Ydieresis Omacron -30
+KPX Ydieresis Oslash -30
+KPX Ydieresis Otilde -30
+KPX Ydieresis a -100
+KPX Ydieresis aacute -100
+KPX Ydieresis abreve -100
+KPX Ydieresis acircumflex -100
+KPX Ydieresis adieresis -60
+KPX Ydieresis agrave -60
+KPX Ydieresis amacron -60
+KPX Ydieresis aogonek -100
+KPX Ydieresis aring -100
+KPX Ydieresis atilde -100
+KPX Ydieresis colon -92
+KPX Ydieresis comma -129
+KPX Ydieresis e -100
+KPX Ydieresis eacute -100
+KPX Ydieresis ecaron -100
+KPX Ydieresis ecircumflex -100
+KPX Ydieresis edieresis -60
+KPX Ydieresis edotaccent -100
+KPX Ydieresis egrave -60
+KPX Ydieresis emacron -60
+KPX Ydieresis eogonek -100
+KPX Ydieresis hyphen -111
+KPX Ydieresis i -55
+KPX Ydieresis iacute -55
+KPX Ydieresis iogonek -55
+KPX Ydieresis o -110
+KPX Ydieresis oacute -110
+KPX Ydieresis ocircumflex -110
+KPX Ydieresis odieresis -70
+KPX Ydieresis ograve -70
+KPX Ydieresis ohungarumlaut -110
+KPX Ydieresis omacron -70
+KPX Ydieresis oslash -110
+KPX Ydieresis otilde -70
+KPX Ydieresis period -129
+KPX Ydieresis semicolon -92
+KPX Ydieresis u -111
+KPX Ydieresis uacute -111
+KPX Ydieresis ucircumflex -111
+KPX Ydieresis udieresis -71
+KPX Ydieresis ugrave -71
+KPX Ydieresis uhungarumlaut -111
+KPX Ydieresis umacron -71
+KPX Ydieresis uogonek -111
+KPX Ydieresis uring -111
+KPX a v -20
+KPX a w -15
+KPX aacute v -20
+KPX aacute w -15
+KPX abreve v -20
+KPX abreve w -15
+KPX acircumflex v -20
+KPX acircumflex w -15
+KPX adieresis v -20
+KPX adieresis w -15
+KPX agrave v -20
+KPX agrave w -15
+KPX amacron v -20
+KPX amacron w -15
+KPX aogonek v -20
+KPX aogonek w -15
+KPX aring v -20
+KPX aring w -15
+KPX atilde v -20
+KPX atilde w -15
+KPX b period -40
+KPX b u -20
+KPX b uacute -20
+KPX b ucircumflex -20
+KPX b udieresis -20
+KPX b ugrave -20
+KPX b uhungarumlaut -20
+KPX b umacron -20
+KPX b uogonek -20
+KPX b uring -20
+KPX b v -15
+KPX c y -15
+KPX c yacute -15
+KPX c ydieresis -15
+KPX cacute y -15
+KPX cacute yacute -15
+KPX cacute ydieresis -15
+KPX ccaron y -15
+KPX ccaron yacute -15
+KPX ccaron ydieresis -15
+KPX ccedilla y -15
+KPX ccedilla yacute -15
+KPX ccedilla ydieresis -15
+KPX comma quotedblright -70
+KPX comma quoteright -70
+KPX e g -15
+KPX e gbreve -15
+KPX e gcommaaccent -15
+KPX e v -25
+KPX e w -25
+KPX e x -15
+KPX e y -15
+KPX e yacute -15
+KPX e ydieresis -15
+KPX eacute g -15
+KPX eacute gbreve -15
+KPX eacute gcommaaccent -15
+KPX eacute v -25
+KPX eacute w -25
+KPX eacute x -15
+KPX eacute y -15
+KPX eacute yacute -15
+KPX eacute ydieresis -15
+KPX ecaron g -15
+KPX ecaron gbreve -15
+KPX ecaron gcommaaccent -15
+KPX ecaron v -25
+KPX ecaron w -25
+KPX ecaron x -15
+KPX ecaron y -15
+KPX ecaron yacute -15
+KPX ecaron ydieresis -15
+KPX ecircumflex g -15
+KPX ecircumflex gbreve -15
+KPX ecircumflex gcommaaccent -15
+KPX ecircumflex v -25
+KPX ecircumflex w -25
+KPX ecircumflex x -15
+KPX ecircumflex y -15
+KPX ecircumflex yacute -15
+KPX ecircumflex ydieresis -15
+KPX edieresis g -15
+KPX edieresis gbreve -15
+KPX edieresis gcommaaccent -15
+KPX edieresis v -25
+KPX edieresis w -25
+KPX edieresis x -15
+KPX edieresis y -15
+KPX edieresis yacute -15
+KPX edieresis ydieresis -15
+KPX edotaccent g -15
+KPX edotaccent gbreve -15
+KPX edotaccent gcommaaccent -15
+KPX edotaccent v -25
+KPX edotaccent w -25
+KPX edotaccent x -15
+KPX edotaccent y -15
+KPX edotaccent yacute -15
+KPX edotaccent ydieresis -15
+KPX egrave g -15
+KPX egrave gbreve -15
+KPX egrave gcommaaccent -15
+KPX egrave v -25
+KPX egrave w -25
+KPX egrave x -15
+KPX egrave y -15
+KPX egrave yacute -15
+KPX egrave ydieresis -15
+KPX emacron g -15
+KPX emacron gbreve -15
+KPX emacron gcommaaccent -15
+KPX emacron v -25
+KPX emacron w -25
+KPX emacron x -15
+KPX emacron y -15
+KPX emacron yacute -15
+KPX emacron ydieresis -15
+KPX eogonek g -15
+KPX eogonek gbreve -15
+KPX eogonek gcommaaccent -15
+KPX eogonek v -25
+KPX eogonek w -25
+KPX eogonek x -15
+KPX eogonek y -15
+KPX eogonek yacute -15
+KPX eogonek ydieresis -15
+KPX f a -10
+KPX f aacute -10
+KPX f abreve -10
+KPX f acircumflex -10
+KPX f adieresis -10
+KPX f agrave -10
+KPX f amacron -10
+KPX f aogonek -10
+KPX f aring -10
+KPX f atilde -10
+KPX f dotlessi -50
+KPX f f -25
+KPX f i -20
+KPX f iacute -20
+KPX f quoteright 55
+KPX g a -5
+KPX g aacute -5
+KPX g abreve -5
+KPX g acircumflex -5
+KPX g adieresis -5
+KPX g agrave -5
+KPX g amacron -5
+KPX g aogonek -5
+KPX g aring -5
+KPX g atilde -5
+KPX gbreve a -5
+KPX gbreve aacute -5
+KPX gbreve abreve -5
+KPX gbreve acircumflex -5
+KPX gbreve adieresis -5
+KPX gbreve agrave -5
+KPX gbreve amacron -5
+KPX gbreve aogonek -5
+KPX gbreve aring -5
+KPX gbreve atilde -5
+KPX gcommaaccent a -5
+KPX gcommaaccent aacute -5
+KPX gcommaaccent abreve -5
+KPX gcommaaccent acircumflex -5
+KPX gcommaaccent adieresis -5
+KPX gcommaaccent agrave -5
+KPX gcommaaccent amacron -5
+KPX gcommaaccent aogonek -5
+KPX gcommaaccent aring -5
+KPX gcommaaccent atilde -5
+KPX h y -5
+KPX h yacute -5
+KPX h ydieresis -5
+KPX i v -25
+KPX iacute v -25
+KPX icircumflex v -25
+KPX idieresis v -25
+KPX igrave v -25
+KPX imacron v -25
+KPX iogonek v -25
+KPX k e -10
+KPX k eacute -10
+KPX k ecaron -10
+KPX k ecircumflex -10
+KPX k edieresis -10
+KPX k edotaccent -10
+KPX k egrave -10
+KPX k emacron -10
+KPX k eogonek -10
+KPX k o -10
+KPX k oacute -10
+KPX k ocircumflex -10
+KPX k odieresis -10
+KPX k ograve -10
+KPX k ohungarumlaut -10
+KPX k omacron -10
+KPX k oslash -10
+KPX k otilde -10
+KPX k y -15
+KPX k yacute -15
+KPX k ydieresis -15
+KPX kcommaaccent e -10
+KPX kcommaaccent eacute -10
+KPX kcommaaccent ecaron -10
+KPX kcommaaccent ecircumflex -10
+KPX kcommaaccent edieresis -10
+KPX kcommaaccent edotaccent -10
+KPX kcommaaccent egrave -10
+KPX kcommaaccent emacron -10
+KPX kcommaaccent eogonek -10
+KPX kcommaaccent o -10
+KPX kcommaaccent oacute -10
+KPX kcommaaccent ocircumflex -10
+KPX kcommaaccent odieresis -10
+KPX kcommaaccent ograve -10
+KPX kcommaaccent ohungarumlaut -10
+KPX kcommaaccent omacron -10
+KPX kcommaaccent oslash -10
+KPX kcommaaccent otilde -10
+KPX kcommaaccent y -15
+KPX kcommaaccent yacute -15
+KPX kcommaaccent ydieresis -15
+KPX l w -10
+KPX lacute w -10
+KPX lcommaaccent w -10
+KPX lslash w -10
+KPX n v -40
+KPX n y -15
+KPX n yacute -15
+KPX n ydieresis -15
+KPX nacute v -40
+KPX nacute y -15
+KPX nacute yacute -15
+KPX nacute ydieresis -15
+KPX ncaron v -40
+KPX ncaron y -15
+KPX ncaron yacute -15
+KPX ncaron ydieresis -15
+KPX ncommaaccent v -40
+KPX ncommaaccent y -15
+KPX ncommaaccent yacute -15
+KPX ncommaaccent ydieresis -15
+KPX ntilde v -40
+KPX ntilde y -15
+KPX ntilde yacute -15
+KPX ntilde ydieresis -15
+KPX o v -15
+KPX o w -25
+KPX o y -10
+KPX o yacute -10
+KPX o ydieresis -10
+KPX oacute v -15
+KPX oacute w -25
+KPX oacute y -10
+KPX oacute yacute -10
+KPX oacute ydieresis -10
+KPX ocircumflex v -15
+KPX ocircumflex w -25
+KPX ocircumflex y -10
+KPX ocircumflex yacute -10
+KPX ocircumflex ydieresis -10
+KPX odieresis v -15
+KPX odieresis w -25
+KPX odieresis y -10
+KPX odieresis yacute -10
+KPX odieresis ydieresis -10
+KPX ograve v -15
+KPX ograve w -25
+KPX ograve y -10
+KPX ograve yacute -10
+KPX ograve ydieresis -10
+KPX ohungarumlaut v -15
+KPX ohungarumlaut w -25
+KPX ohungarumlaut y -10
+KPX ohungarumlaut yacute -10
+KPX ohungarumlaut ydieresis -10
+KPX omacron v -15
+KPX omacron w -25
+KPX omacron y -10
+KPX omacron yacute -10
+KPX omacron ydieresis -10
+KPX oslash v -15
+KPX oslash w -25
+KPX oslash y -10
+KPX oslash yacute -10
+KPX oslash ydieresis -10
+KPX otilde v -15
+KPX otilde w -25
+KPX otilde y -10
+KPX otilde yacute -10
+KPX otilde ydieresis -10
+KPX p y -10
+KPX p yacute -10
+KPX p ydieresis -10
+KPX period quotedblright -70
+KPX period quoteright -70
+KPX quotedblleft A -80
+KPX quotedblleft Aacute -80
+KPX quotedblleft Abreve -80
+KPX quotedblleft Acircumflex -80
+KPX quotedblleft Adieresis -80
+KPX quotedblleft Agrave -80
+KPX quotedblleft Amacron -80
+KPX quotedblleft Aogonek -80
+KPX quotedblleft Aring -80
+KPX quotedblleft Atilde -80
+KPX quoteleft A -80
+KPX quoteleft Aacute -80
+KPX quoteleft Abreve -80
+KPX quoteleft Acircumflex -80
+KPX quoteleft Adieresis -80
+KPX quoteleft Agrave -80
+KPX quoteleft Amacron -80
+KPX quoteleft Aogonek -80
+KPX quoteleft Aring -80
+KPX quoteleft Atilde -80
+KPX quoteleft quoteleft -74
+KPX quoteright d -50
+KPX quoteright dcroat -50
+KPX quoteright l -10
+KPX quoteright lacute -10
+KPX quoteright lcommaaccent -10
+KPX quoteright lslash -10
+KPX quoteright quoteright -74
+KPX quoteright r -50
+KPX quoteright racute -50
+KPX quoteright rcaron -50
+KPX quoteright rcommaaccent -50
+KPX quoteright s -55
+KPX quoteright sacute -55
+KPX quoteright scaron -55
+KPX quoteright scedilla -55
+KPX quoteright scommaaccent -55
+KPX quoteright space -74
+KPX quoteright t -18
+KPX quoteright tcommaaccent -18
+KPX quoteright v -50
+KPX r comma -40
+KPX r g -18
+KPX r gbreve -18
+KPX r gcommaaccent -18
+KPX r hyphen -20
+KPX r period -55
+KPX racute comma -40
+KPX racute g -18
+KPX racute gbreve -18
+KPX racute gcommaaccent -18
+KPX racute hyphen -20
+KPX racute period -55
+KPX rcaron comma -40
+KPX rcaron g -18
+KPX rcaron gbreve -18
+KPX rcaron gcommaaccent -18
+KPX rcaron hyphen -20
+KPX rcaron period -55
+KPX rcommaaccent comma -40
+KPX rcommaaccent g -18
+KPX rcommaaccent gbreve -18
+KPX rcommaaccent gcommaaccent -18
+KPX rcommaaccent hyphen -20
+KPX rcommaaccent period -55
+KPX space A -55
+KPX space Aacute -55
+KPX space Abreve -55
+KPX space Acircumflex -55
+KPX space Adieresis -55
+KPX space Agrave -55
+KPX space Amacron -55
+KPX space Aogonek -55
+KPX space Aring -55
+KPX space Atilde -55
+KPX space T -18
+KPX space Tcaron -18
+KPX space Tcommaaccent -18
+KPX space V -50
+KPX space W -30
+KPX space Y -90
+KPX space Yacute -90
+KPX space Ydieresis -90
+KPX v a -25
+KPX v aacute -25
+KPX v abreve -25
+KPX v acircumflex -25
+KPX v adieresis -25
+KPX v agrave -25
+KPX v amacron -25
+KPX v aogonek -25
+KPX v aring -25
+KPX v atilde -25
+KPX v comma -65
+KPX v e -15
+KPX v eacute -15
+KPX v ecaron -15
+KPX v ecircumflex -15
+KPX v edieresis -15
+KPX v edotaccent -15
+KPX v egrave -15
+KPX v emacron -15
+KPX v eogonek -15
+KPX v o -20
+KPX v oacute -20
+KPX v ocircumflex -20
+KPX v odieresis -20
+KPX v ograve -20
+KPX v ohungarumlaut -20
+KPX v omacron -20
+KPX v oslash -20
+KPX v otilde -20
+KPX v period -65
+KPX w a -10
+KPX w aacute -10
+KPX w abreve -10
+KPX w acircumflex -10
+KPX w adieresis -10
+KPX w agrave -10
+KPX w amacron -10
+KPX w aogonek -10
+KPX w aring -10
+KPX w atilde -10
+KPX w comma -65
+KPX w o -10
+KPX w oacute -10
+KPX w ocircumflex -10
+KPX w odieresis -10
+KPX w ograve -10
+KPX w ohungarumlaut -10
+KPX w omacron -10
+KPX w oslash -10
+KPX w otilde -10
+KPX w period -65
+KPX x e -15
+KPX x eacute -15
+KPX x ecaron -15
+KPX x ecircumflex -15
+KPX x edieresis -15
+KPX x edotaccent -15
+KPX x egrave -15
+KPX x emacron -15
+KPX x eogonek -15
+KPX y comma -65
+KPX y period -65
+KPX yacute comma -65
+KPX yacute period -65
+KPX ydieresis comma -65
+KPX ydieresis period -65
+EndKernPairs
+EndKernData
+EndFontMetrics
Added: trunk/mapbender/http/classes/fonts/php_Courier-Bold.afm
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/fonts/php_Courier-Bold.afm?view=auto&rev=13
--- (empty file)
+++ trunk/mapbender/http/classes/fonts/php_Courier-Bold.afm 2006-04-13 19:38:28+0000
@@ -0,0 +1 @@
+a:21:{s:8:"FontName";s:12:"Courier-Bold";s:8:"FullName";s:12:"Courier Bold";s:10:"FamilyName";s:7:"Courier";s:6:"Weight";s:4:"Bold";s:11:"ItalicAngle";s:1:"0";s:12:"IsFixedPitch";s:4:"true";s:12:"CharacterSet";s:13:"ExtendedRoman";s:8:"FontBBox";a:4:{i:0;s:4:"-113";i:1;s:4:"-250";i:2;s:3:"749";i:3;s:3:"801";}s:17:"UnderlinePosition";s:4:"-100";s:18:"UnderlineThickness";s:2:"50";s:7:"Version";s:7:"003.000";s:14:"EncodingScheme";s:21:"AdobeStandardEncoding";s:9:"CapHeight";s:3:"562";s:7:"XHeight";s:3:"439";s:8:"Ascender";s:3:"629";s:9:"Descender";s:4:"-157";s:5:"StdHW";s:2:"84";s:5:"StdVW";s:3:"106";s:16:"StartCharMetrics";s:3:"315";s:1:"C";a:464:{i:32;a:4:{s:1:"C";s:2:"32";s:2:"WX";s:3:"600";s:1:"N";s:5:"space";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}s:5:"space";a:4:{s:1:"C";s:2:"32";s:2:"WX";s:3:"600";s:1:"N";s:5:"space";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}i:33;a:4:{s:1:"C";s:2:"33";s:2:"WX";s:3:"600";s:1:"N";s:6:"exclam";s:1:"B";a:4:{i:0;s:3:"202";i:1;s:3:"-15";i:2;s:3:"398";i:3;s:3:"572";}}s:6:"exclam";a:4:{s:1:"C";s:2:"33";s:2:"WX";s:3:"600";s:1:"N";s:6:"exclam";s:1:"B";a:4:{i:0;s:3:"202";i:1;s:3:"-15";i:2;s:3:"398";i:3;s:3:"572";}}i:34;a:4:{s:1:"C";s:2:"34";s:2:"WX";s:3:"600";s:1:"N";s:8:"quotedbl";s:1:"B";a:4:{i:0;s:3:"135";i:1;s:3:"277";i:2;s:3:"465";i:3;s:3:"562";}}s:8:"quotedbl";a:4:{s:1:"C";s:2:"34";s:2:"WX";s:3:"600";s:1:"N";s:8:"quotedbl";s:1:"B";a:4:{i:0;s:3:"135";i:1;s:3:"277";i:2;s:3:"465";i:3;s:3:"562";}}i:35;a:4:{s:1:"C";s:2:"35";s:2:"WX";s:3:"600";s:1:"N";s:10:"numbersign";s:1:"B";a:4:{i:0;s:2:"56";i:1;s:3:"-45";i:2;s:3:"544";i:3;s:3:"651";}}s:10:"numbersign";a:4:{s:1:"C";s:2:"35";s:2:"WX";s:3:"600";s:1:"N";s:10:"numbersign";s:1:"B";a:4:{i:0;s:2:"56";i:1;s:3:"-45";i:2;s:3:"544";i:3;s:3:"651";}}i:36;a:4:{s:1:"C";s:2:"36";s:2:"WX";s:3:"600";s:1:"N";s:6:"dollar";s:1:"B";a:4:{i:0;s:2:"82";i:1;s:4:"-126";i:2;s:3:"519";i:3;s:3:"666";}}s:6:"dollar";a:4:{s:1:"C";s:2:"36";s:2:"WX";s:3:"600";s:1:"N";s:6:"dollar";s:1:"B";a:4:{i:0;s:2:"82";i:1;s:4:"-126";i:2;s:3:"519";i:3;s:3:"666";}}i:37;a:4:{s:1:"C";s:2:"37";s:2:"WX";s:3:"600";s:1:"N";s:7:"percent";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:3:"-15";i:2;s:3:"595";i:3;s:3:"616";}}s:7:"percent";a:4:{s:1:"C";s:2:"37";s:2:"WX";s:3:"600";s:1:"N";s:7:"percent";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:3:"-15";i:2;s:3:"595";i:3;s:3:"616";}}i:38;a:4:{s:1:"C";s:2:"38";s:2:"WX";s:3:"600";s:1:"N";s:9:"ampersand";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:3:"-15";i:2;s:3:"546";i:3;s:3:"543";}}s:9:"ampersand";a:4:{s:1:"C";s:2:"38";s:2:"WX";s:3:"600";s:1:"N";s:9:"ampersand";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:3:"-15";i:2;s:3:"546";i:3;s:3:"543";}}i:39;a:4:{s:1:"C";s:2:"39";s:2:"WX";s:3:"600";s:1:"N";s:10:"quoteright";s:1:"B";a:4:{i:0;s:3:"171";i:1;s:3:"277";i:2;s:3:"423";i:3;s:3:"562";}}s:10:"quoteright";a:4:{s:1:"C";s:2:"39";s:2:"WX";s:3:"600";s:1:"N";s:10:"quoteright";s:1:"B";a:4:{i:0;s:3:"171";i:1;s:3:"277";i:2;s:3:"423";i:3;s:3:"562";}}i:40;a:4:{s:1:"C";s:2:"40";s:2:"WX";s:3:"600";s:1:"N";s:9:"parenleft";s:1:"B";a:4:{i:0;s:3:"219";i:1;s:4:"-102";i:2;s:3:"461";i:3;s:3:"616";}}s:9:"parenleft";a:4:{s:1:"C";s:2:"40";s:2:"WX";s:3:"600";s:1:"N";s:9:"parenleft";s:1:"B";a:4:{i:0;s:3:"219";i:1;s:4:"-102";i:2;s:3:"461";i:3;s:3:"616";}}i:41;a:4:{s:1:"C";s:2:"41";s:2:"WX";s:3:"600";s:1:"N";s:10:"parenright";s:1:"B";a:4:{i:0;s:3:"139";i:1;s:4:"-102";i:2;s:3:"381";i:3;s:3:"616";}}s:10:"parenright";a:4:{s:1:"C";s:2:"41";s:2:"WX";s:3:"600";s:1:"N";s:10:"parenright";s:1:"B";a:4:{i:0;s:3:"139";i:1;s:4:"-102";i:2;s:3:"381";i:3;s:3:"616";}}i:42;a:4:{s:1:"C";s:2:"42";s:2:"WX";s:3:"600";s:1:"N";s:8:"asterisk";s:1:"B";a:4:{i:0;s:2:"91";i:1;s:3:"219";i:2;s:3:"509";i:3;s:3:"601";}}s:8:"asterisk";a:4:{s:1:"C";s:2:"42";s:2:"WX";s:3:"600";s:1:"N";s:8:"asterisk";s:1:"B";a:4:{i:0;s:2:"91";i:1;s:3:"219";i:2;s:3:"509";i:3;s:3:"601";}}i:43;a:4:{s:1:"C";s:2:"43";s:2:"WX";s:3:"600";s:1:"N";s:4:"plus";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:2:"39";i:2;s:3:"529";i:3;s:3:"478";}}s:4:"plus";a:4:{s:1:"C";s:2:"43";s:2:"WX";s:3:"600";s:1:"N";s:4:"plus";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:2:"39";i:2;s:3:"529";i:3;s:3:"478";}}i:44;a:4:{s:1:"C";s:2:"44";s:2:"WX";s:3:"600";s:1:"N";s:5:"comma";s:1:"B";a:4:{i:0;s:3:"123";i:1;s:4:"-111";i:2;s:3:"393";i:3;s:3:"174";}}s:5:"comma";a:4:{s:1:"C";s:2:"44";s:2:"WX";s:3:"600";s:1:"N";s:5:"comma";s:1:"B";a:4:{i:0;s:3:"123";i:1;s:4:"-111";i:2;s:3:"393";i:3;s:3:"174";}}i:45;a:4:{s:1:"C";s:2:"45";s:2:"WX";s:3:"600";s:1:"N";s:6:"hyphen";s:1:"B";a:4:{i:0;s:3:"100";i:1;s:3:"203";i:2;s:3:"500";i:3;s:3:"313";}}s:6:"hyphen";a:4:{s:1:"C";s:2:"45";s:2:"WX";s:3:"600";s:1:"N";s:6:"hyphen";s:1:"B";a:4:{i:0;s:3:"100";i:1;s:3:"203";i:2;s:3:"500";i:3;s:3:"313";}}i:46;a:4:{s:1:"C";s:2:"46";s:2:"WX";s:3:"600";s:1:"N";s:6:"period";s:1:"B";a:4:{i:0;s:3:"192";i:1;s:3:"-15";i:2;s:3:"408";i:3;s:3:"171";}}s:6:"period";a:4:{s:1:"C";s:2:"46";s:2:"WX";s:3:"600";s:1:"N";s:6:"period";s:1:"B";a:4:{i:0;s:3:"192";i:1;s:3:"-15";i:2;s:3:"408";i:3;s:3:"171";}}i:47;a:4:{s:1:"C";s:2:"47";s:2:"WX";s:3:"600";s:1:"N";s:5:"slash";s:1:"B";a:4:{i:0;s:2:"98";i:1;s:3:"-77";i:2;s:3:"502";i:3;s:3:"626";}}s:5:"slash";a:4:{s:1:"C";s:2:"47";s:2:"WX";s:3:"600";s:1:"N";s:5:"slash";s:1:"B";a:4:{i:0;s:2:"98";i:1;s:3:"-77";i:2;s:3:"502";i:3;s:3:"626";}}i:48;a:4:{s:1:"C";s:2:"48";s:2:"WX";s:3:"600";s:1:"N";s:4:"zero";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:3:"-15";i:2;s:3:"513";i:3;s:3:"616";}}s:4:"zero";a:4:{s:1:"C";s:2:"48";s:2:"WX";s:3:"600";s:1:"N";s:4:"zero";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:3:"-15";i:2;s:3:"513";i:3;s:3:"616";}}i:49;a:4:{s:1:"C";s:2:"49";s:2:"WX";s:3:"600";s:1:"N";s:3:"one";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:1:"0";i:2;s:3:"539";i:3;s:3:"616";}}s:3:"one";a:4:{s:1:"C";s:2:"49";s:2:"WX";s:3:"600";s:1:"N";s:3:"one";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:1:"0";i:2;s:3:"539";i:3;s:3:"616";}}i:50;a:4:{s:1:"C";s:2:"50";s:2:"WX";s:3:"600";s:1:"N";s:3:"two";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:1:"0";i:2;s:3:"499";i:3;s:3:"616";}}s:3:"two";a:4:{s:1:"C";s:2:"50";s:2:"WX";s:3:"600";s:1:"N";s:3:"two";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:1:"0";i:2;s:3:"499";i:3;s:3:"616";}}i:51;a:4:{s:1:"C";s:2:"51";s:2:"WX";s:3:"600";s:1:"N";s:5:"three";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:3:"-15";i:2;s:3:"501";i:3;s:3:"616";}}s:5:"three";a:4:{s:1:"C";s:2:"51";s:2:"WX";s:3:"600";s:1:"N";s:5:"three";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:3:"-15";i:2;s:3:"501";i:3;s:3:"616";}}i:52;a:4:{s:1:"C";s:2:"52";s:2:"WX";s:3:"600";s:1:"N";s:4:"four";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:1:"0";i:2;s:3:"507";i:3;s:3:"616";}}s:4:"four";a:4:{s:1:"C";s:2:"52";s:2:"WX";s:3:"600";s:1:"N";s:4:"four";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:1:"0";i:2;s:3:"507";i:3;s:3:"616";}}i:53;a:4:{s:1:"C";s:2:"53";s:2:"WX";s:3:"600";s:1:"N";s:4:"five";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:3:"-15";i:2;s:3:"521";i:3;s:3:"601";}}s:4:"five";a:4:{s:1:"C";s:2:"53";s:2:"WX";s:3:"600";s:1:"N";s:4:"five";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:3:"-15";i:2;s:3:"521";i:3;s:3:"601";}}i:54;a:4:{s:1:"C";s:2:"54";s:2:"WX";s:3:"600";s:1:"N";s:3:"six";s:1:"B";a:4:{i:0;s:2:"90";i:1;s:3:"-15";i:2;s:3:"521";i:3;s:3:"616";}}s:3:"six";a:4:{s:1:"C";s:2:"54";s:2:"WX";s:3:"600";s:1:"N";s:3:"six";s:1:"B";a:4:{i:0;s:2:"90";i:1;s:3:"-15";i:2;s:3:"521";i:3;s:3:"616";}}i:55;a:4:{s:1:"C";s:2:"55";s:2:"WX";s:3:"600";s:1:"N";s:5:"seven";s:1:"B";a:4:{i:0;s:2:"55";i:1;s:1:"0";i:2;s:3:"494";i:3;s:3:"601";}}s:5:"seven";a:4:{s:1:"C";s:2:"55";s:2:"WX";s:3:"600";s:1:"N";s:5:"seven";s:1:"B";a:4:{i:0;s:2:"55";i:1;s:1:"0";i:2;s:3:"494";i:3;s:3:"601";}}i:56;a:4:{s:1:"C";s:2:"56";s:2:"WX";s:3:"600";s:1:"N";s:5:"eight";s:1:"B";a:4:{i:0;s:2:"83";i:1;s:3:"-15";i:2;s:3:"517";i:3;s:3:"616";}}s:5:"eight";a:4:{s:1:"C";s:2:"56";s:2:"WX";s:3:"600";s:1:"N";s:5:"eight";s:1:"B";a:4:{i:0;s:2:"83";i:1;s:3:"-15";i:2;s:3:"517";i:3;s:3:"616";}}i:57;a:4:{s:1:"C";s:2:"57";s:2:"WX";s:3:"600";s:1:"N";s:4:"nine";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:3:"-15";i:2;s:3:"510";i:3;s:3:"616";}}s:4:"nine";a:4:{s:1:"C";s:2:"57";s:2:"WX";s:3:"600";s:1:"N";s:4:"nine";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:3:"-15";i:2;s:3:"510";i:3;s:3:"616";}}i:58;a:4:{s:1:"C";s:2:"58";s:2:"WX";s:3:"600";s:1:"N";s:5:"colon";s:1:"B";a:4:{i:0;s:3:"191";i:1;s:3:"-15";i:2;s:3:"407";i:3;s:3:"425";}}s:5:"colon";a:4:{s:1:"C";s:2:"58";s:2:"WX";s:3:"600";s:1:"N";s:5:"colon";s:1:"B";a:4:{i:0;s:3:"191";i:1;s:3:"-15";i:2;s:3:"407";i:3;s:3:"425";}}i:59;a:4:{s:1:"C";s:2:"59";s:2:"WX";s:3:"600";s:1:"N";s:9:"semicolon";s:1:"B";a:4:{i:0;s:3:"123";i:1;s:4:"-111";i:2;s:3:"408";i:3;s:3:"425";}}s:9:"semicolon";a:4:{s:1:"C";s:2:"59";s:2:"WX";s:3:"600";s:1:"N";s:9:"semicolon";s:1:"B";a:4:{i:0;s:3:"123";i:1;s:4:"-111";i:2;s:3:"408";i:3;s:3:"425";}}i:60;a:4:{s:1:"C";s:2:"60";s:2:"WX";s:3:"600";s:1:"N";s:4:"less";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:2:"15";i:2;s:3:"523";i:3;s:3:"501";}}s:4:"less";a:4:{s:1:"C";s:2:"60";s:2:"WX";s:3:"600";s:1:"N";s:4:"less";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:2:"15";i:2;s:3:"523";i:3;s:3:"501";}}i:61;a:4:{s:1:"C";s:2:"61";s:2:"WX";s:3:"600";s:1:"N";s:5:"equal";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:3:"118";i:2;s:3:"529";i:3;s:3:"398";}}s:5:"equal";a:4:{s:1:"C";s:2:"61";s:2:"WX";s:3:"600";s:1:"N";s:5:"equal";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:3:"118";i:2;s:3:"529";i:3;s:3:"398";}}i:62;a:4:{s:1:"C";s:2:"62";s:2:"WX";s:3:"600";s:1:"N";s:7:"greater";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:2:"15";i:2;s:3:"534";i:3;s:3:"501";}}s:7:"greater";a:4:{s:1:"C";s:2:"62";s:2:"WX";s:3:"600";s:1:"N";s:7:"greater";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:2:"15";i:2;s:3:"534";i:3;s:3:"501";}}i:63;a:4:{s:1:"C";s:2:"63";s:2:"WX";s:3:"600";s:1:"N";s:8:"question";s:1:"B";a:4:{i:0;s:2:"98";i:1;s:3:"-14";i:2;s:3:"501";i:3;s:3:"580";}}s:8:"question";a:4:{s:1:"C";s:2:"63";s:2:"WX";s:3:"600";s:1:"N";s:8:"question";s:1:"B";a:4:{i:0;s:2:"98";i:1;s:3:"-14";i:2;s:3:"501";i:3;s:3:"580";}}i:64;a:4:{s:1:"C";s:2:"64";s:2:"WX";s:3:"600";s:1:"N";s:2:"at";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-15";i:2;s:3:"584";i:3;s:3:"616";}}s:2:"at";a:4:{s:1:"C";s:2:"64";s:2:"WX";s:3:"600";s:1:"N";s:2:"at";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-15";i:2;s:3:"584";i:3;s:3:"616";}}i:65;a:4:{s:1:"C";s:2:"65";s:2:"WX";s:3:"600";s:1:"N";s:1:"A";s:1:"B";a:4:{i:0;s:2:"-9";i:1;s:1:"0";i:2;s:3:"609";i:3;s:3:"562";}}s:1:"A";a:4:{s:1:"C";s:2:"65";s:2:"WX";s:3:"600";s:1:"N";s:1:"A";s:1:"B";a:4:{i:0;s:2:"-9";i:1;s:1:"0";i:2;s:3:"609";i:3;s:3:"562";}}i:66;a:4:{s:1:"C";s:2:"66";s:2:"WX";s:3:"600";s:1:"N";s:1:"B";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:1:"0";i:2;s:3:"573";i:3;s:3:"562";}}s:1:"B";a:4:{s:1:"C";s:2:"66";s:2:"WX";s:3:"600";s:1:"N";s:1:"B";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:1:"0";i:2;s:3:"573";i:3;s:3:"562";}}i:67;a:4:{s:1:"C";s:2:"67";s:2:"WX";s:3:"600";s:1:"N";s:1:"C";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-18";i:2;s:3:"560";i:3;s:3:"580";}}s:1:"C";a:4:{s:1:"C";s:2:"67";s:2:"WX";s:3:"600";s:1:"N";s:1:"C";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-18";i:2;s:3:"560";i:3;s:3:"580";}}i:68;a:4:{s:1:"C";s:2:"68";s:2:"WX";s:3:"600";s:1:"N";s:1:"D";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:1:"0";i:2;s:3:"594";i:3;s:3:"562";}}s:1:"D";a:4:{s:1:"C";s:2:"68";s:2:"WX";s:3:"600";s:1:"N";s:1:"D";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:1:"0";i:2;s:3:"594";i:3;s:3:"562";}}i:69;a:4:{s:1:"C";s:2:"69";s:2:"WX";s:3:"600";s:1:"N";s:1:"E";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"560";i:3;s:3:"562";}}s:1:"E";a:4:{s:1:"C";s:2:"69";s:2:"WX";s:3:"600";s:1:"N";s:1:"E";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"560";i:3;s:3:"562";}}i:70;a:4:{s:1:"C";s:2:"70";s:2:"WX";s:3:"600";s:1:"N";s:1:"F";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:1:"0";i:2;s:3:"570";i:3;s:3:"562";}}s:1:"F";a:4:{s:1:"C";s:2:"70";s:2:"WX";s:3:"600";s:1:"N";s:1:"F";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:1:"0";i:2;s:3:"570";i:3;s:3:"562";}}i:71;a:4:{s:1:"C";s:2:"71";s:2:"WX";s:3:"600";s:1:"N";s:1:"G";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-18";i:2;s:3:"594";i:3;s:3:"580";}}s:1:"G";a:4:{s:1:"C";s:2:"71";s:2:"WX";s:3:"600";s:1:"N";s:1:"G";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-18";i:2;s:3:"594";i:3;s:3:"580";}}i:72;a:4:{s:1:"C";s:2:"72";s:2:"WX";s:3:"600";s:1:"N";s:1:"H";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"580";i:3;s:3:"562";}}s:1:"H";a:4:{s:1:"C";s:2:"72";s:2:"WX";s:3:"600";s:1:"N";s:1:"H";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"580";i:3;s:3:"562";}}i:73;a:4:{s:1:"C";s:2:"73";s:2:"WX";s:3:"600";s:1:"N";s:1:"I";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"523";i:3;s:3:"562";}}s:1:"I";a:4:{s:1:"C";s:2:"73";s:2:"WX";s:3:"600";s:1:"N";s:1:"I";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"523";i:3;s:3:"562";}}i:74;a:4:{s:1:"C";s:2:"74";s:2:"WX";s:3:"600";s:1:"N";s:1:"J";s:1:"B";a:4:{i:0;s:2:"37";i:1;s:3:"-18";i:2;s:3:"601";i:3;s:3:"562";}}s:1:"J";a:4:{s:1:"C";s:2:"74";s:2:"WX";s:3:"600";s:1:"N";s:1:"J";s:1:"B";a:4:{i:0;s:2:"37";i:1;s:3:"-18";i:2;s:3:"601";i:3;s:3:"562";}}i:75;a:4:{s:1:"C";s:2:"75";s:2:"WX";s:3:"600";s:1:"N";s:1:"K";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:1:"0";i:2;s:3:"599";i:3;s:3:"562";}}s:1:"K";a:4:{s:1:"C";s:2:"75";s:2:"WX";s:3:"600";s:1:"N";s:1:"K";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:1:"0";i:2;s:3:"599";i:3;s:3:"562";}}i:76;a:4:{s:1:"C";s:2:"76";s:2:"WX";s:3:"600";s:1:"N";s:1:"L";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:1:"0";i:2;s:3:"578";i:3;s:3:"562";}}s:1:"L";a:4:{s:1:"C";s:2:"76";s:2:"WX";s:3:"600";s:1:"N";s:1:"L";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:1:"0";i:2;s:3:"578";i:3;s:3:"562";}}i:77;a:4:{s:1:"C";s:2:"77";s:2:"WX";s:3:"600";s:1:"N";s:1:"M";s:1:"B";a:4:{i:0;s:2:"-2";i:1;s:1:"0";i:2;s:3:"602";i:3;s:3:"562";}}s:1:"M";a:4:{s:1:"C";s:2:"77";s:2:"WX";s:3:"600";s:1:"N";s:1:"M";s:1:"B";a:4:{i:0;s:2:"-2";i:1;s:1:"0";i:2;s:3:"602";i:3;s:3:"562";}}i:78;a:4:{s:1:"C";s:2:"78";s:2:"WX";s:3:"600";s:1:"N";s:1:"N";s:1:"B";a:4:{i:0;s:1:"8";i:1;s:3:"-12";i:2;s:3:"610";i:3;s:3:"562";}}s:1:"N";a:4:{s:1:"C";s:2:"78";s:2:"WX";s:3:"600";s:1:"N";s:1:"N";s:1:"B";a:4:{i:0;s:1:"8";i:1;s:3:"-12";i:2;s:3:"610";i:3;s:3:"562";}}i:79;a:4:{s:1:"C";s:2:"79";s:2:"WX";s:3:"600";s:1:"N";s:1:"O";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-18";i:2;s:3:"578";i:3;s:3:"580";}}s:1:"O";a:4:{s:1:"C";s:2:"79";s:2:"WX";s:3:"600";s:1:"N";s:1:"O";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-18";i:2;s:3:"578";i:3;s:3:"580";}}i:80;a:4:{s:1:"C";s:2:"80";s:2:"WX";s:3:"600";s:1:"N";s:1:"P";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:1:"0";i:2;s:3:"559";i:3;s:3:"562";}}s:1:"P";a:4:{s:1:"C";s:2:"80";s:2:"WX";s:3:"600";s:1:"N";s:1:"P";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:1:"0";i:2;s:3:"559";i:3;s:3:"562";}}i:81;a:4:{s:1:"C";s:2:"81";s:2:"WX";s:3:"600";s:1:"N";s:1:"Q";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:4:"-138";i:2;s:3:"578";i:3;s:3:"580";}}s:1:"Q";a:4:{s:1:"C";s:2:"81";s:2:"WX";s:3:"600";s:1:"N";s:1:"Q";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:4:"-138";i:2;s:3:"578";i:3;s:3:"580";}}i:82;a:4:{s:1:"C";s:2:"82";s:2:"WX";s:3:"600";s:1:"N";s:1:"R";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:1:"0";i:2;s:3:"599";i:3;s:3:"562";}}s:1:"R";a:4:{s:1:"C";s:2:"82";s:2:"WX";s:3:"600";s:1:"N";s:1:"R";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:1:"0";i:2;s:3:"599";i:3;s:3:"562";}}i:83;a:4:{s:1:"C";s:2:"83";s:2:"WX";s:3:"600";s:1:"N";s:1:"S";s:1:"B";a:4:{i:0;s:2:"47";i:1;s:3:"-22";i:2;s:3:"553";i:3;s:3:"582";}}s:1:"S";a:4:{s:1:"C";s:2:"83";s:2:"WX";s:3:"600";s:1:"N";s:1:"S";s:1:"B";a:4:{i:0;s:2:"47";i:1;s:3:"-22";i:2;s:3:"553";i:3;s:3:"582";}}i:84;a:4:{s:1:"C";s:2:"84";s:2:"WX";s:3:"600";s:1:"N";s:1:"T";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:1:"0";i:2;s:3:"579";i:3;s:3:"562";}}s:1:"T";a:4:{s:1:"C";s:2:"84";s:2:"WX";s:3:"600";s:1:"N";s:1:"T";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:1:"0";i:2;s:3:"579";i:3;s:3:"562";}}i:85;a:4:{s:1:"C";s:2:"85";s:2:"WX";s:3:"600";s:1:"N";s:1:"U";s:1:"B";a:4:{i:0;s:1:"4";i:1;s:3:"-18";i:2;s:3:"596";i:3;s:3:"562";}}s:1:"U";a:4:{s:1:"C";s:2:"85";s:2:"WX";s:3:"600";s:1:"N";s:1:"U";s:1:"B";a:4:{i:0;s:1:"4";i:1;s:3:"-18";i:2;s:3:"596";i:3;s:3:"562";}}i:86;a:4:{s:1:"C";s:2:"86";s:2:"WX";s:3:"600";s:1:"N";s:1:"V";s:1:"B";a:4:{i:0;s:3:"-13";i:1;s:1:"0";i:2;s:3:"613";i:3;s:3:"562";}}s:1:"V";a:4:{s:1:"C";s:2:"86";s:2:"WX";s:3:"600";s:1:"N";s:1:"V";s:1:"B";a:4:{i:0;s:3:"-13";i:1;s:1:"0";i:2;s:3:"613";i:3;s:3:"562";}}i:87;a:4:{s:1:"C";s:2:"87";s:2:"WX";s:3:"600";s:1:"N";s:1:"W";s:1:"B";a:4:{i:0;s:3:"-18";i:1;s:1:"0";i:2;s:3:"618";i:3;s:3:"562";}}s:1:"W";a:4:{s:1:"C";s:2:"87";s:2:"WX";s:3:"600";s:1:"N";s:1:"W";s:1:"B";a:4:{i:0;s:3:"-18";i:1;s:1:"0";i:2;s:3:"618";i:3;s:3:"562";}}i:88;a:4:{s:1:"C";s:2:"88";s:2:"WX";s:3:"600";s:1:"N";s:1:"X";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"588";i:3;s:3:"562";}}s:1:"X";a:4:{s:1:"C";s:2:"88";s:2:"WX";s:3:"600";s:1:"N";s:1:"X";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"588";i:3;s:3:"562";}}i:89;a:4:{s:1:"C";s:2:"89";s:2:"WX";s:3:"600";s:1:"N";s:1:"Y";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"589";i:3;s:3:"562";}}s:1:"Y";a:4:{s:1:"C";s:2:"89";s:2:"WX";s:3:"600";s:1:"N";s:1:"Y";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"589";i:3;s:3:"562";}}i:90;a:4:{s:1:"C";s:2:"90";s:2:"WX";s:3:"600";s:1:"N";s:1:"Z";s:1:"B";a:4:{i:0;s:2:"62";i:1;s:1:"0";i:2;s:3:"539";i:3;s:3:"562";}}s:1:"Z";a:4:{s:1:"C";s:2:"90";s:2:"WX";s:3:"600";s:1:"N";s:1:"Z";s:1:"B";a:4:{i:0;s:2:"62";i:1;s:1:"0";i:2;s:3:"539";i:3;s:3:"562";}}i:91;a:4:{s:1:"C";s:2:"91";s:2:"WX";s:3:"600";s:1:"N";s:11:"bracketleft";s:1:"B";a:4:{i:0;s:3:"245";i:1;s:4:"-102";i:2;s:3:"475";i:3;s:3:"616";}}s:11:"bracketleft";a:4:{s:1:"C";s:2:"91";s:2:"WX";s:3:"600";s:1:"N";s:11:"bracketleft";s:1:"B";a:4:{i:0;s:3:"245";i:1;s:4:"-102";i:2;s:3:"475";i:3;s:3:"616";}}i:92;a:4:{s:1:"C";s:2:"92";s:2:"WX";s:3:"600";s:1:"N";s:9:"backslash";s:1:"B";a:4:{i:0;s:2:"99";i:1;s:3:"-77";i:2;s:3:"503";i:3;s:3:"626";}}s:9:"backslash";a:4:{s:1:"C";s:2:"92";s:2:"WX";s:3:"600";s:1:"N";s:9:"backslash";s:1:"B";a:4:{i:0;s:2:"99";i:1;s:3:"-77";i:2;s:3:"503";i:3;s:3:"626";}}i:93;a:4:{s:1:"C";s:2:"93";s:2:"WX";s:3:"600";s:1:"N";s:12:"bracketright";s:1:"B";a:4:{i:0;s:3:"125";i:1;s:4:"-102";i:2;s:3:"355";i:3;s:3:"616";}}s:12:"bracketright";a:4:{s:1:"C";s:2:"93";s:2:"WX";s:3:"600";s:1:"N";s:12:"bracketright";s:1:"B";a:4:{i:0;s:3:"125";i:1;s:4:"-102";i:2;s:3:"355";i:3;s:3:"616";}}i:94;a:4:{s:1:"C";s:2:"94";s:2:"WX";s:3:"600";s:1:"N";s:11:"asciicircum";s:1:"B";a:4:{i:0;s:3:"108";i:1;s:3:"250";i:2;s:3:"492";i:3;s:3:"616";}}s:11:"asciicircum";a:4:{s:1:"C";s:2:"94";s:2:"WX";s:3:"600";s:1:"N";s:11:"asciicircum";s:1:"B";a:4:{i:0;s:3:"108";i:1;s:3:"250";i:2;s:3:"492";i:3;s:3:"616";}}i:95;a:4:{s:1:"C";s:2:"95";s:2:"WX";s:3:"600";s:1:"N";s:10:"underscore";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:4:"-125";i:2;s:3:"600";i:3;s:3:"-75";}}s:10:"underscore";a:4:{s:1:"C";s:2:"95";s:2:"WX";s:3:"600";s:1:"N";s:10:"underscore";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:4:"-125";i:2;s:3:"600";i:3;s:3:"-75";}}i:96;a:4:{s:1:"C";s:2:"96";s:2:"WX";s:3:"600";s:1:"N";s:9:"quoteleft";s:1:"B";a:4:{i:0;s:3:"178";i:1;s:3:"277";i:2;s:3:"428";i:3;s:3:"562";}}s:9:"quoteleft";a:4:{s:1:"C";s:2:"96";s:2:"WX";s:3:"600";s:1:"N";s:9:"quoteleft";s:1:"B";a:4:{i:0;s:3:"178";i:1;s:3:"277";i:2;s:3:"428";i:3;s:3:"562";}}i:97;a:4:{s:1:"C";s:2:"97";s:2:"WX";s:3:"600";s:1:"N";s:1:"a";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-15";i:2;s:3:"570";i:3;s:3:"454";}}s:1:"a";a:4:{s:1:"C";s:2:"97";s:2:"WX";s:3:"600";s:1:"N";s:1:"a";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-15";i:2;s:3:"570";i:3;s:3:"454";}}i:98;a:4:{s:1:"C";s:2:"98";s:2:"WX";s:3:"600";s:1:"N";s:1:"b";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"-15";i:2;s:3:"584";i:3;s:3:"626";}}s:1:"b";a:4:{s:1:"C";s:2:"98";s:2:"WX";s:3:"600";s:1:"N";s:1:"b";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"-15";i:2;s:3:"584";i:3;s:3:"626";}}i:99;a:4:{s:1:"C";s:2:"99";s:2:"WX";s:3:"600";s:1:"N";s:1:"c";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"-15";i:2;s:3:"545";i:3;s:3:"459";}}s:1:"c";a:4:{s:1:"C";s:2:"99";s:2:"WX";s:3:"600";s:1:"N";s:1:"c";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"-15";i:2;s:3:"545";i:3;s:3:"459";}}i:100;a:4:{s:1:"C";s:3:"100";s:2:"WX";s:3:"600";s:1:"N";s:1:"d";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:3:"-15";i:2;s:3:"591";i:3;s:3:"626";}}s:1:"d";a:4:{s:1:"C";s:3:"100";s:2:"WX";s:3:"600";s:1:"N";s:1:"d";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:3:"-15";i:2;s:3:"591";i:3;s:3:"626";}}i:101;a:4:{s:1:"C";s:3:"101";s:2:"WX";s:3:"600";s:1:"N";s:1:"e";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"-15";i:2;s:3:"563";i:3;s:3:"454";}}s:1:"e";a:4:{s:1:"C";s:3:"101";s:2:"WX";s:3:"600";s:1:"N";s:1:"e";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"-15";i:2;s:3:"563";i:3;s:3:"454";}}i:102;a:5:{s:1:"C";s:3:"102";s:2:"WX";s:3:"600";s:1:"N";s:1:"f";s:1:"B";a:4:{i:0;s:2:"83";i:1;s:1:"0";i:2;s:3:"547";i:3;s:3:"626";}s:1:"L";a:2:{i:0;s:1:"l";i:1;s:2:"fl";}}s:1:"f";a:5:{s:1:"C";s:3:"102";s:2:"WX";s:3:"600";s:1:"N";s:1:"f";s:1:"B";a:4:{i:0;s:2:"83";i:1;s:1:"0";i:2;s:3:"547";i:3;s:3:"626";}s:1:"L";a:2:{i:0;s:1:"l";i:1;s:2:"fl";}}i:103;a:4:{s:1:"C";s:3:"103";s:2:"WX";s:3:"600";s:1:"N";s:1:"g";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:4:"-146";i:2;s:3:"580";i:3;s:3:"454";}}s:1:"g";a:4:{s:1:"C";s:3:"103";s:2:"WX";s:3:"600";s:1:"N";s:1:"g";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:4:"-146";i:2;s:3:"580";i:3;s:3:"454";}}i:104;a:4:{s:1:"C";s:3:"104";s:2:"WX";s:3:"600";s:1:"N";s:1:"h";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:1:"0";i:2;s:3:"592";i:3;s:3:"626";}}s:1:"h";a:4:{s:1:"C";s:3:"104";s:2:"WX";s:3:"600";s:1:"N";s:1:"h";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:1:"0";i:2;s:3:"592";i:3;s:3:"626";}}i:105;a:4:{s:1:"C";s:3:"105";s:2:"WX";s:3:"600";s:1:"N";s:1:"i";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"523";i:3;s:3:"658";}}s:1:"i";a:4:{s:1:"C";s:3:"105";s:2:"WX";s:3:"600";s:1:"N";s:1:"i";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"523";i:3;s:3:"658";}}i:106;a:4:{s:1:"C";s:3:"106";s:2:"WX";s:3:"600";s:1:"N";s:1:"j";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:4:"-146";i:2;s:3:"440";i:3;s:3:"658";}}s:1:"j";a:4:{s:1:"C";s:3:"106";s:2:"WX";s:3:"600";s:1:"N";s:1:"j";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:4:"-146";i:2;s:3:"440";i:3;s:3:"658";}}i:107;a:4:{s:1:"C";s:3:"107";s:2:"WX";s:3:"600";s:1:"N";s:1:"k";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"585";i:3;s:3:"626";}}s:1:"k";a:4:{s:1:"C";s:3:"107";s:2:"WX";s:3:"600";s:1:"N";s:1:"k";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"585";i:3;s:3:"626";}}i:108;a:4:{s:1:"C";s:3:"108";s:2:"WX";s:3:"600";s:1:"N";s:1:"l";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"523";i:3;s:3:"626";}}s:1:"l";a:4:{s:1:"C";s:3:"108";s:2:"WX";s:3:"600";s:1:"N";s:1:"l";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"523";i:3;s:3:"626";}}i:109;a:4:{s:1:"C";s:3:"109";s:2:"WX";s:3:"600";s:1:"N";s:1:"m";s:1:"B";a:4:{i:0;s:3:"-22";i:1;s:1:"0";i:2;s:3:"626";i:3;s:3:"454";}}s:1:"m";a:4:{s:1:"C";s:3:"109";s:2:"WX";s:3:"600";s:1:"N";s:1:"m";s:1:"B";a:4:{i:0;s:3:"-22";i:1;s:1:"0";i:2;s:3:"626";i:3;s:3:"454";}}i:110;a:4:{s:1:"C";s:3:"110";s:2:"WX";s:3:"600";s:1:"N";s:1:"n";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:1:"0";i:2;s:3:"592";i:3;s:3:"454";}}s:1:"n";a:4:{s:1:"C";s:3:"110";s:2:"WX";s:3:"600";s:1:"N";s:1:"n";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:1:"0";i:2;s:3:"592";i:3;s:3:"454";}}i:111;a:4:{s:1:"C";s:3:"111";s:2:"WX";s:3:"600";s:1:"N";s:1:"o";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-15";i:2;s:3:"570";i:3;s:3:"454";}}s:1:"o";a:4:{s:1:"C";s:3:"111";s:2:"WX";s:3:"600";s:1:"N";s:1:"o";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-15";i:2;s:3:"570";i:3;s:3:"454";}}i:112;a:4:{s:1:"C";s:3:"112";s:2:"WX";s:3:"600";s:1:"N";s:1:"p";s:1:"B";a:4:{i:0;s:2:"-1";i:1;s:4:"-142";i:2;s:3:"570";i:3;s:3:"454";}}s:1:"p";a:4:{s:1:"C";s:3:"112";s:2:"WX";s:3:"600";s:1:"N";s:1:"p";s:1:"B";a:4:{i:0;s:2:"-1";i:1;s:4:"-142";i:2;s:3:"570";i:3;s:3:"454";}}i:113;a:4:{s:1:"C";s:3:"113";s:2:"WX";s:3:"600";s:1:"N";s:1:"q";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:4:"-142";i:2;s:3:"591";i:3;s:3:"454";}}s:1:"q";a:4:{s:1:"C";s:3:"113";s:2:"WX";s:3:"600";s:1:"N";s:1:"q";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:4:"-142";i:2;s:3:"591";i:3;s:3:"454";}}i:114;a:4:{s:1:"C";s:3:"114";s:2:"WX";s:3:"600";s:1:"N";s:1:"r";s:1:"B";a:4:{i:0;s:2:"47";i:1;s:1:"0";i:2;s:3:"580";i:3;s:3:"454";}}s:1:"r";a:4:{s:1:"C";s:3:"114";s:2:"WX";s:3:"600";s:1:"N";s:1:"r";s:1:"B";a:4:{i:0;s:2:"47";i:1;s:1:"0";i:2;s:3:"580";i:3;s:3:"454";}}i:115;a:4:{s:1:"C";s:3:"115";s:2:"WX";s:3:"600";s:1:"N";s:1:"s";s:1:"B";a:4:{i:0;s:2:"68";i:1;s:3:"-17";i:2;s:3:"535";i:3;s:3:"459";}}s:1:"s";a:4:{s:1:"C";s:3:"115";s:2:"WX";s:3:"600";s:1:"N";s:1:"s";s:1:"B";a:4:{i:0;s:2:"68";i:1;s:3:"-17";i:2;s:3:"535";i:3;s:3:"459";}}i:116;a:4:{s:1:"C";s:3:"116";s:2:"WX";s:3:"600";s:1:"N";s:1:"t";s:1:"B";a:4:{i:0;s:2:"47";i:1;s:3:"-15";i:2;s:3:"532";i:3;s:3:"562";}}s:1:"t";a:4:{s:1:"C";s:3:"116";s:2:"WX";s:3:"600";s:1:"N";s:1:"t";s:1:"B";a:4:{i:0;s:2:"47";i:1;s:3:"-15";i:2;s:3:"532";i:3;s:3:"562";}}i:117;a:4:{s:1:"C";s:3:"117";s:2:"WX";s:3:"600";s:1:"N";s:1:"u";s:1:"B";a:4:{i:0;s:2:"-1";i:1;s:3:"-15";i:2;s:3:"569";i:3;s:3:"439";}}s:1:"u";a:4:{s:1:"C";s:3:"117";s:2:"WX";s:3:"600";s:1:"N";s:1:"u";s:1:"B";a:4:{i:0;s:2:"-1";i:1;s:3:"-15";i:2;s:3:"569";i:3;s:3:"439";}}i:118;a:4:{s:1:"C";s:3:"118";s:2:"WX";s:3:"600";s:1:"N";s:1:"v";s:1:"B";a:4:{i:0;s:2:"-1";i:1;s:1:"0";i:2;s:3:"601";i:3;s:3:"439";}}s:1:"v";a:4:{s:1:"C";s:3:"118";s:2:"WX";s:3:"600";s:1:"N";s:1:"v";s:1:"B";a:4:{i:0;s:2:"-1";i:1;s:1:"0";i:2;s:3:"601";i:3;s:3:"439";}}i:119;a:4:{s:1:"C";s:3:"119";s:2:"WX";s:3:"600";s:1:"N";s:1:"w";s:1:"B";a:4:{i:0;s:3:"-18";i:1;s:1:"0";i:2;s:3:"618";i:3;s:3:"439";}}s:1:"w";a:4:{s:1:"C";s:3:"119";s:2:"WX";s:3:"600";s:1:"N";s:1:"w";s:1:"B";a:4:{i:0;s:3:"-18";i:1;s:1:"0";i:2;s:3:"618";i:3;s:3:"439";}}i:120;a:4:{s:1:"C";s:3:"120";s:2:"WX";s:3:"600";s:1:"N";s:1:"x";s:1:"B";a:4:{i:0;s:1:"6";i:1;s:1:"0";i:2;s:3:"594";i:3;s:3:"439";}}s:1:"x";a:4:{s:1:"C";s:3:"120";s:2:"WX";s:3:"600";s:1:"N";s:1:"x";s:1:"B";a:4:{i:0;s:1:"6";i:1;s:1:"0";i:2;s:3:"594";i:3;s:3:"439";}}i:121;a:4:{s:1:"C";s:3:"121";s:2:"WX";s:3:"600";s:1:"N";s:1:"y";s:1:"B";a:4:{i:0;s:2:"-4";i:1;s:4:"-142";i:2;s:3:"601";i:3;s:3:"439";}}s:1:"y";a:4:{s:1:"C";s:3:"121";s:2:"WX";s:3:"600";s:1:"N";s:1:"y";s:1:"B";a:4:{i:0;s:2:"-4";i:1;s:4:"-142";i:2;s:3:"601";i:3;s:3:"439";}}i:122;a:4:{s:1:"C";s:3:"122";s:2:"WX";s:3:"600";s:1:"N";s:1:"z";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:1:"0";i:2;s:3:"520";i:3;s:3:"439";}}s:1:"z";a:4:{s:1:"C";s:3:"122";s:2:"WX";s:3:"600";s:1:"N";s:1:"z";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:1:"0";i:2;s:3:"520";i:3;s:3:"439";}}i:123;a:4:{s:1:"C";s:3:"123";s:2:"WX";s:3:"600";s:1:"N";s:9:"braceleft";s:1:"B";a:4:{i:0;s:3:"160";i:1;s:4:"-102";i:2;s:3:"464";i:3;s:3:"616";}}s:9:"braceleft";a:4:{s:1:"C";s:3:"123";s:2:"WX";s:3:"600";s:1:"N";s:9:"braceleft";s:1:"B";a:4:{i:0;s:3:"160";i:1;s:4:"-102";i:2;s:3:"464";i:3;s:3:"616";}}i:124;a:4:{s:1:"C";s:3:"124";s:2:"WX";s:3:"600";s:1:"N";s:3:"bar";s:1:"B";a:4:{i:0;s:3:"255";i:1;s:4:"-250";i:2;s:3:"345";i:3;s:3:"750";}}s:3:"bar";a:4:{s:1:"C";s:3:"124";s:2:"WX";s:3:"600";s:1:"N";s:3:"bar";s:1:"B";a:4:{i:0;s:3:"255";i:1;s:4:"-250";i:2;s:3:"345";i:3;s:3:"750";}}i:125;a:4:{s:1:"C";s:3:"125";s:2:"WX";s:3:"600";s:1:"N";s:10:"braceright";s:1:"B";a:4:{i:0;s:3:"136";i:1;s:4:"-102";i:2;s:3:"440";i:3;s:3:"616";}}s:10:"braceright";a:4:{s:1:"C";s:3:"125";s:2:"WX";s:3:"600";s:1:"N";s:10:"braceright";s:1:"B";a:4:{i:0;s:3:"136";i:1;s:4:"-102";i:2;s:3:"440";i:3;s:3:"616";}}i:126;a:4:{s:1:"C";s:3:"126";s:2:"WX";s:3:"600";s:1:"N";s:10:"asciitilde";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:3:"153";i:2;s:3:"530";i:3;s:3:"356";}}s:10:"asciitilde";a:4:{s:1:"C";s:3:"126";s:2:"WX";s:3:"600";s:1:"N";s:10:"asciitilde";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:3:"153";i:2;s:3:"530";i:3;s:3:"356";}}i:161;a:4:{s:1:"C";s:3:"161";s:2:"WX";s:3:"600";s:1:"N";s:10:"exclamdown";s:1:"B";a:4:{i:0;s:3:"202";i:1;s:4:"-146";i:2;s:3:"398";i:3;s:3:"449";}}s:10:"exclamdown";a:4:{s:1:"C";s:3:"161";s:2:"WX";s:3:"600";s:1:"N";s:10:"exclamdown";s:1:"B";a:4:{i:0;s:3:"202";i:1;s:4:"-146";i:2;s:3:"398";i:3;s:3:"449";}}i:162;a:4:{s:1:"C";s:3:"162";s:2:"WX";s:3:"600";s:1:"N";s:4:"cent";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:3:"-49";i:2;s:3:"518";i:3;s:3:"614";}}s:4:"cent";a:4:{s:1:"C";s:3:"162";s:2:"WX";s:3:"600";s:1:"N";s:4:"cent";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:3:"-49";i:2;s:3:"518";i:3;s:3:"614";}}i:163;a:4:{s:1:"C";s:3:"163";s:2:"WX";s:3:"600";s:1:"N";s:8:"sterling";s:1:"B";a:4:{i:0;s:2:"72";i:1;s:3:"-28";i:2;s:3:"558";i:3;s:3:"611";}}s:8:"sterling";a:4:{s:1:"C";s:3:"163";s:2:"WX";s:3:"600";s:1:"N";s:8:"sterling";s:1:"B";a:4:{i:0;s:2:"72";i:1;s:3:"-28";i:2;s:3:"558";i:3;s:3:"611";}}i:164;a:4:{s:1:"C";s:3:"164";s:2:"WX";s:3:"600";s:1:"N";s:8:"fraction";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-60";i:2;s:3:"576";i:3;s:3:"661";}}s:8:"fraction";a:4:{s:1:"C";s:3:"164";s:2:"WX";s:3:"600";s:1:"N";s:8:"fraction";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-60";i:2;s:3:"576";i:3;s:3:"661";}}i:165;a:4:{s:1:"C";s:3:"165";s:2:"WX";s:3:"600";s:1:"N";s:3:"yen";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:1:"0";i:2;s:3:"590";i:3;s:3:"562";}}s:3:"yen";a:4:{s:1:"C";s:3:"165";s:2:"WX";s:3:"600";s:1:"N";s:3:"yen";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:1:"0";i:2;s:3:"590";i:3;s:3:"562";}}i:166;a:4:{s:1:"C";s:3:"166";s:2:"WX";s:3:"600";s:1:"N";s:6:"florin";s:1:"B";a:4:{i:0;s:3:"-30";i:1;s:4:"-131";i:2;s:3:"572";i:3;s:3:"616";}}s:6:"florin";a:4:{s:1:"C";s:3:"166";s:2:"WX";s:3:"600";s:1:"N";s:6:"florin";s:1:"B";a:4:{i:0;s:3:"-30";i:1;s:4:"-131";i:2;s:3:"572";i:3;s:3:"616";}}i:167;a:4:{s:1:"C";s:3:"167";s:2:"WX";s:3:"600";s:1:"N";s:7:"section";s:1:"B";a:4:{i:0;s:2:"83";i:1;s:3:"-70";i:2;s:3:"517";i:3;s:3:"580";}}s:7:"section";a:4:{s:1:"C";s:3:"167";s:2:"WX";s:3:"600";s:1:"N";s:7:"section";s:1:"B";a:4:{i:0;s:2:"83";i:1;s:3:"-70";i:2;s:3:"517";i:3;s:3:"580";}}i:168;a:4:{s:1:"C";s:3:"168";s:2:"WX";s:3:"600";s:1:"N";s:8:"currency";s:1:"B";a:4:{i:0;s:2:"54";i:1;s:2:"49";i:2;s:3:"546";i:3;s:3:"517";}}s:8:"currency";a:4:{s:1:"C";s:3:"168";s:2:"WX";s:3:"600";s:1:"N";s:8:"currency";s:1:"B";a:4:{i:0;s:2:"54";i:1;s:2:"49";i:2;s:3:"546";i:3;s:3:"517";}}i:169;a:4:{s:1:"C";s:3:"169";s:2:"WX";s:3:"600";s:1:"N";s:11:"quotesingle";s:1:"B";a:4:{i:0;s:3:"227";i:1;s:3:"277";i:2;s:3:"373";i:3;s:3:"562";}}s:11:"quotesingle";a:4:{s:1:"C";s:3:"169";s:2:"WX";s:3:"600";s:1:"N";s:11:"quotesingle";s:1:"B";a:4:{i:0;s:3:"227";i:1;s:3:"277";i:2;s:3:"373";i:3;s:3:"562";}}i:170;a:4:{s:1:"C";s:3:"170";s:2:"WX";s:3:"600";s:1:"N";s:12:"quotedblleft";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:3:"277";i:2;s:3:"535";i:3;s:3:"562";}}s:12:"quotedblleft";a:4:{s:1:"C";s:3:"170";s:2:"WX";s:3:"600";s:1:"N";s:12:"quotedblleft";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:3:"277";i:2;s:3:"535";i:3;s:3:"562";}}i:171;a:4:{s:1:"C";s:3:"171";s:2:"WX";s:3:"600";s:1:"N";s:13:"guillemotleft";s:1:"B";a:4:{i:0;s:1:"8";i:1;s:2:"70";i:2;s:3:"553";i:3;s:3:"446";}}s:13:"guillemotleft";a:4:{s:1:"C";s:3:"171";s:2:"WX";s:3:"600";s:1:"N";s:13:"guillemotleft";s:1:"B";a:4:{i:0;s:1:"8";i:1;s:2:"70";i:2;s:3:"553";i:3;s:3:"446";}}i:172;a:4:{s:1:"C";s:3:"172";s:2:"WX";s:3:"600";s:1:"N";s:13:"guilsinglleft";s:1:"B";a:4:{i:0;s:3:"141";i:1;s:2:"70";i:2;s:3:"459";i:3;s:3:"446";}}s:13:"guilsinglleft";a:4:{s:1:"C";s:3:"172";s:2:"WX";s:3:"600";s:1:"N";s:13:"guilsinglleft";s:1:"B";a:4:{i:0;s:3:"141";i:1;s:2:"70";i:2;s:3:"459";i:3;s:3:"446";}}i:173;a:4:{s:1:"C";s:3:"173";s:2:"WX";s:3:"600";s:1:"N";s:14:"guilsinglright";s:1:"B";a:4:{i:0;s:3:"141";i:1;s:2:"70";i:2;s:3:"459";i:3;s:3:"446";}}s:14:"guilsinglright";a:4:{s:1:"C";s:3:"173";s:2:"WX";s:3:"600";s:1:"N";s:14:"guilsinglright";s:1:"B";a:4:{i:0;s:3:"141";i:1;s:2:"70";i:2;s:3:"459";i:3;s:3:"446";}}i:174;a:4:{s:1:"C";s:3:"174";s:2:"WX";s:3:"600";s:1:"N";s:2:"fi";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"593";i:3;s:3:"626";}}s:2:"fi";a:4:{s:1:"C";s:3:"174";s:2:"WX";s:3:"600";s:1:"N";s:2:"fi";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"593";i:3;s:3:"626";}}i:175;a:4:{s:1:"C";s:3:"175";s:2:"WX";s:3:"600";s:1:"N";s:2:"fl";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"593";i:3;s:3:"626";}}s:2:"fl";a:4:{s:1:"C";s:3:"175";s:2:"WX";s:3:"600";s:1:"N";s:2:"fl";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"593";i:3;s:3:"626";}}i:177;a:4:{s:1:"C";s:3:"177";s:2:"WX";s:3:"600";s:1:"N";s:6:"endash";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:3:"203";i:2;s:3:"535";i:3;s:3:"313";}}s:6:"endash";a:4:{s:1:"C";s:3:"177";s:2:"WX";s:3:"600";s:1:"N";s:6:"endash";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:3:"203";i:2;s:3:"535";i:3;s:3:"313";}}i:178;a:4:{s:1:"C";s:3:"178";s:2:"WX";s:3:"600";s:1:"N";s:6:"dagger";s:1:"B";a:4:{i:0;s:3:"106";i:1;s:3:"-70";i:2;s:3:"494";i:3;s:3:"580";}}s:6:"dagger";a:4:{s:1:"C";s:3:"178";s:2:"WX";s:3:"600";s:1:"N";s:6:"dagger";s:1:"B";a:4:{i:0;s:3:"106";i:1;s:3:"-70";i:2;s:3:"494";i:3;s:3:"580";}}i:179;a:4:{s:1:"C";s:3:"179";s:2:"WX";s:3:"600";s:1:"N";s:9:"daggerdbl";s:1:"B";a:4:{i:0;s:3:"106";i:1;s:3:"-70";i:2;s:3:"494";i:3;s:3:"580";}}s:9:"daggerdbl";a:4:{s:1:"C";s:3:"179";s:2:"WX";s:3:"600";s:1:"N";s:9:"daggerdbl";s:1:"B";a:4:{i:0;s:3:"106";i:1;s:3:"-70";i:2;s:3:"494";i:3;s:3:"580";}}i:180;a:4:{s:1:"C";s:3:"180";s:2:"WX";s:3:"600";s:1:"N";s:14:"periodcentered";s:1:"B";a:4:{i:0;s:3:"196";i:1;s:3:"165";i:2;s:3:"404";i:3;s:3:"351";}}s:14:"periodcentered";a:4:{s:1:"C";s:3:"180";s:2:"WX";s:3:"600";s:1:"N";s:14:"periodcentered";s:1:"B";a:4:{i:0;s:3:"196";i:1;s:3:"165";i:2;s:3:"404";i:3;s:3:"351";}}i:182;a:4:{s:1:"C";s:3:"182";s:2:"WX";s:3:"600";s:1:"N";s:9:"paragraph";s:1:"B";a:4:{i:0;s:1:"6";i:1;s:3:"-70";i:2;s:3:"576";i:3;s:3:"580";}}s:9:"paragraph";a:4:{s:1:"C";s:3:"182";s:2:"WX";s:3:"600";s:1:"N";s:9:"paragraph";s:1:"B";a:4:{i:0;s:1:"6";i:1;s:3:"-70";i:2;s:3:"576";i:3;s:3:"580";}}i:183;a:4:{s:1:"C";s:3:"183";s:2:"WX";s:3:"600";s:1:"N";s:6:"bullet";s:1:"B";a:4:{i:0;s:3:"140";i:1;s:3:"132";i:2;s:3:"460";i:3;s:3:"430";}}s:6:"bullet";a:4:{s:1:"C";s:3:"183";s:2:"WX";s:3:"600";s:1:"N";s:6:"bullet";s:1:"B";a:4:{i:0;s:3:"140";i:1;s:3:"132";i:2;s:3:"460";i:3;s:3:"430";}}i:184;a:4:{s:1:"C";s:3:"184";s:2:"WX";s:3:"600";s:1:"N";s:14:"quotesinglbase";s:1:"B";a:4:{i:0;s:3:"175";i:1;s:4:"-142";i:2;s:3:"427";i:3;s:3:"143";}}s:14:"quotesinglbase";a:4:{s:1:"C";s:3:"184";s:2:"WX";s:3:"600";s:1:"N";s:14:"quotesinglbase";s:1:"B";a:4:{i:0;s:3:"175";i:1;s:4:"-142";i:2;s:3:"427";i:3;s:3:"143";}}i:185;a:4:{s:1:"C";s:3:"185";s:2:"WX";s:3:"600";s:1:"N";s:12:"quotedblbase";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:4:"-142";i:2;s:3:"529";i:3;s:3:"143";}}s:12:"quotedblbase";a:4:{s:1:"C";s:3:"185";s:2:"WX";s:3:"600";s:1:"N";s:12:"quotedblbase";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:4:"-142";i:2;s:3:"529";i:3;s:3:"143";}}i:186;a:4:{s:1:"C";s:3:"186";s:2:"WX";s:3:"600";s:1:"N";s:13:"quotedblright";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:3:"277";i:2;s:3:"525";i:3;s:3:"562";}}s:13:"quotedblright";a:4:{s:1:"C";s:3:"186";s:2:"WX";s:3:"600";s:1:"N";s:13:"quotedblright";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:3:"277";i:2;s:3:"525";i:3;s:3:"562";}}i:187;a:4:{s:1:"C";s:3:"187";s:2:"WX";s:3:"600";s:1:"N";s:14:"guillemotright";s:1:"B";a:4:{i:0;s:2:"47";i:1;s:2:"70";i:2;s:3:"592";i:3;s:3:"446";}}s:14:"guillemotright";a:4:{s:1:"C";s:3:"187";s:2:"WX";s:3:"600";s:1:"N";s:14:"guillemotright";s:1:"B";a:4:{i:0;s:2:"47";i:1;s:2:"70";i:2;s:3:"592";i:3;s:3:"446";}}i:188;a:4:{s:1:"C";s:3:"188";s:2:"WX";s:3:"600";s:1:"N";s:8:"ellipsis";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:3:"-15";i:2;s:3:"574";i:3;s:3:"116";}}s:8:"ellipsis";a:4:{s:1:"C";s:3:"188";s:2:"WX";s:3:"600";s:1:"N";s:8:"ellipsis";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:3:"-15";i:2;s:3:"574";i:3;s:3:"116";}}i:189;a:4:{s:1:"C";s:3:"189";s:2:"WX";s:3:"600";s:1:"N";s:11:"perthousand";s:1:"B";a:4:{i:0;s:4:"-113";i:1;s:3:"-15";i:2;s:3:"713";i:3;s:3:"616";}}s:11:"perthousand";a:4:{s:1:"C";s:3:"189";s:2:"WX";s:3:"600";s:1:"N";s:11:"perthousand";s:1:"B";a:4:{i:0;s:4:"-113";i:1;s:3:"-15";i:2;s:3:"713";i:3;s:3:"616";}}i:191;a:4:{s:1:"C";s:3:"191";s:2:"WX";s:3:"600";s:1:"N";s:12:"questiondown";s:1:"B";a:4:{i:0;s:2:"99";i:1;s:4:"-146";i:2;s:3:"502";i:3;s:3:"449";}}s:12:"questiondown";a:4:{s:1:"C";s:3:"191";s:2:"WX";s:3:"600";s:1:"N";s:12:"questiondown";s:1:"B";a:4:{i:0;s:2:"99";i:1;s:4:"-146";i:2;s:3:"502";i:3;s:3:"449";}}i:193;a:4:{s:1:"C";s:3:"193";s:2:"WX";s:3:"600";s:1:"N";s:5:"grave";s:1:"B";a:4:{i:0;s:3:"132";i:1;s:3:"508";i:2;s:3:"395";i:3;s:3:"661";}}s:5:"grave";a:4:{s:1:"C";s:3:"193";s:2:"WX";s:3:"600";s:1:"N";s:5:"grave";s:1:"B";a:4:{i:0;s:3:"132";i:1;s:3:"508";i:2;s:3:"395";i:3;s:3:"661";}}i:194;a:4:{s:1:"C";s:3:"194";s:2:"WX";s:3:"600";s:1:"N";s:5:"acute";s:1:"B";a:4:{i:0;s:3:"205";i:1;s:3:"508";i:2;s:3:"468";i:3;s:3:"661";}}s:5:"acute";a:4:{s:1:"C";s:3:"194";s:2:"WX";s:3:"600";s:1:"N";s:5:"acute";s:1:"B";a:4:{i:0;s:3:"205";i:1;s:3:"508";i:2;s:3:"468";i:3;s:3:"661";}}i:195;a:4:{s:1:"C";s:3:"195";s:2:"WX";s:3:"600";s:1:"N";s:10:"circumflex";s:1:"B";a:4:{i:0;s:3:"103";i:1;s:3:"483";i:2;s:3:"497";i:3;s:3:"657";}}s:10:"circumflex";a:4:{s:1:"C";s:3:"195";s:2:"WX";s:3:"600";s:1:"N";s:10:"circumflex";s:1:"B";a:4:{i:0;s:3:"103";i:1;s:3:"483";i:2;s:3:"497";i:3;s:3:"657";}}i:196;a:4:{s:1:"C";s:3:"196";s:2:"WX";s:3:"600";s:1:"N";s:5:"tilde";s:1:"B";a:4:{i:0;s:2:"89";i:1;s:3:"493";i:2;s:3:"512";i:3;s:3:"636";}}s:5:"tilde";a:4:{s:1:"C";s:3:"196";s:2:"WX";s:3:"600";s:1:"N";s:5:"tilde";s:1:"B";a:4:{i:0;s:2:"89";i:1;s:3:"493";i:2;s:3:"512";i:3;s:3:"636";}}i:197;a:4:{s:1:"C";s:3:"197";s:2:"WX";s:3:"600";s:1:"N";s:6:"macron";s:1:"B";a:4:{i:0;s:2:"88";i:1;s:3:"505";i:2;s:3:"512";i:3;s:3:"585";}}s:6:"macron";a:4:{s:1:"C";s:3:"197";s:2:"WX";s:3:"600";s:1:"N";s:6:"macron";s:1:"B";a:4:{i:0;s:2:"88";i:1;s:3:"505";i:2;s:3:"512";i:3;s:3:"585";}}i:198;a:4:{s:1:"C";s:3:"198";s:2:"WX";s:3:"600";s:1:"N";s:5:"breve";s:1:"B";a:4:{i:0;s:2:"83";i:1;s:3:"468";i:2;s:3:"517";i:3;s:3:"631";}}s:5:"breve";a:4:{s:1:"C";s:3:"198";s:2:"WX";s:3:"600";s:1:"N";s:5:"breve";s:1:"B";a:4:{i:0;s:2:"83";i:1;s:3:"468";i:2;s:3:"517";i:3;s:3:"631";}}i:199;a:4:{s:1:"C";s:3:"199";s:2:"WX";s:3:"600";s:1:"N";s:9:"dotaccent";s:1:"B";a:4:{i:0;s:3:"230";i:1;s:3:"498";i:2;s:3:"370";i:3;s:3:"638";}}s:9:"dotaccent";a:4:{s:1:"C";s:3:"199";s:2:"WX";s:3:"600";s:1:"N";s:9:"dotaccent";s:1:"B";a:4:{i:0;s:3:"230";i:1;s:3:"498";i:2;s:3:"370";i:3;s:3:"638";}}i:200;a:4:{s:1:"C";s:3:"200";s:2:"WX";s:3:"600";s:1:"N";s:8:"dieresis";s:1:"B";a:4:{i:0;s:3:"128";i:1;s:3:"498";i:2;s:3:"472";i:3;s:3:"638";}}s:8:"dieresis";a:4:{s:1:"C";s:3:"200";s:2:"WX";s:3:"600";s:1:"N";s:8:"dieresis";s:1:"B";a:4:{i:0;s:3:"128";i:1;s:3:"498";i:2;s:3:"472";i:3;s:3:"638";}}i:202;a:4:{s:1:"C";s:3:"202";s:2:"WX";s:3:"600";s:1:"N";s:4:"ring";s:1:"B";a:4:{i:0;s:3:"198";i:1;s:3:"481";i:2;s:3:"402";i:3;s:3:"678";}}s:4:"ring";a:4:{s:1:"C";s:3:"202";s:2:"WX";s:3:"600";s:1:"N";s:4:"ring";s:1:"B";a:4:{i:0;s:3:"198";i:1;s:3:"481";i:2;s:3:"402";i:3;s:3:"678";}}i:203;a:4:{s:1:"C";s:3:"203";s:2:"WX";s:3:"600";s:1:"N";s:7:"cedilla";s:1:"B";a:4:{i:0;s:3:"205";i:1;s:4:"-206";i:2;s:3:"387";i:3;s:1:"0";}}s:7:"cedilla";a:4:{s:1:"C";s:3:"203";s:2:"WX";s:3:"600";s:1:"N";s:7:"cedilla";s:1:"B";a:4:{i:0;s:3:"205";i:1;s:4:"-206";i:2;s:3:"387";i:3;s:1:"0";}}i:205;a:4:{s:1:"C";s:3:"205";s:2:"WX";s:3:"600";s:1:"N";s:12:"hungarumlaut";s:1:"B";a:4:{i:0;s:2:"68";i:1;s:3:"488";i:2;s:3:"588";i:3;s:3:"661";}}s:12:"hungarumlaut";a:4:{s:1:"C";s:3:"205";s:2:"WX";s:3:"600";s:1:"N";s:12:"hungarumlaut";s:1:"B";a:4:{i:0;s:2:"68";i:1;s:3:"488";i:2;s:3:"588";i:3;s:3:"661";}}i:206;a:4:{s:1:"C";s:3:"206";s:2:"WX";s:3:"600";s:1:"N";s:6:"ogonek";s:1:"B";a:4:{i:0;s:3:"169";i:1;s:4:"-199";i:2;s:3:"400";i:3;s:1:"0";}}s:6:"ogonek";a:4:{s:1:"C";s:3:"206";s:2:"WX";s:3:"600";s:1:"N";s:6:"ogonek";s:1:"B";a:4:{i:0;s:3:"169";i:1;s:4:"-199";i:2;s:3:"400";i:3;s:1:"0";}}i:207;a:4:{s:1:"C";s:3:"207";s:2:"WX";s:3:"600";s:1:"N";s:5:"caron";s:1:"B";a:4:{i:0;s:3:"103";i:1;s:3:"493";i:2;s:3:"497";i:3;s:3:"667";}}s:5:"caron";a:4:{s:1:"C";s:3:"207";s:2:"WX";s:3:"600";s:1:"N";s:5:"caron";s:1:"B";a:4:{i:0;s:3:"103";i:1;s:3:"493";i:2;s:3:"497";i:3;s:3:"667";}}i:208;a:4:{s:1:"C";s:3:"208";s:2:"WX";s:3:"600";s:1:"N";s:6:"emdash";s:1:"B";a:4:{i:0;s:3:"-10";i:1;s:3:"203";i:2;s:3:"610";i:3;s:3:"313";}}s:6:"emdash";a:4:{s:1:"C";s:3:"208";s:2:"WX";s:3:"600";s:1:"N";s:6:"emdash";s:1:"B";a:4:{i:0;s:3:"-10";i:1;s:3:"203";i:2;s:3:"610";i:3;s:3:"313";}}i:225;a:4:{s:1:"C";s:3:"225";s:2:"WX";s:3:"600";s:1:"N";s:2:"AE";s:1:"B";a:4:{i:0;s:3:"-29";i:1;s:1:"0";i:2;s:3:"602";i:3;s:3:"562";}}s:2:"AE";a:4:{s:1:"C";s:3:"225";s:2:"WX";s:3:"600";s:1:"N";s:2:"AE";s:1:"B";a:4:{i:0;s:3:"-29";i:1;s:1:"0";i:2;s:3:"602";i:3;s:3:"562";}}i:227;a:4:{s:1:"C";s:3:"227";s:2:"WX";s:3:"600";s:1:"N";s:11:"ordfeminine";s:1:"B";a:4:{i:0;s:3:"147";i:1;s:3:"196";i:2;s:3:"453";i:3;s:3:"580";}}s:11:"ordfeminine";a:4:{s:1:"C";s:3:"227";s:2:"WX";s:3:"600";s:1:"N";s:11:"ordfeminine";s:1:"B";a:4:{i:0;s:3:"147";i:1;s:3:"196";i:2;s:3:"453";i:3;s:3:"580";}}i:232;a:4:{s:1:"C";s:3:"232";s:2:"WX";s:3:"600";s:1:"N";s:6:"Lslash";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:1:"0";i:2;s:3:"578";i:3;s:3:"562";}}s:6:"Lslash";a:4:{s:1:"C";s:3:"232";s:2:"WX";s:3:"600";s:1:"N";s:6:"Lslash";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:1:"0";i:2;s:3:"578";i:3;s:3:"562";}}i:233;a:4:{s:1:"C";s:3:"233";s:2:"WX";s:3:"600";s:1:"N";s:6:"Oslash";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-22";i:2;s:3:"578";i:3;s:3:"584";}}s:6:"Oslash";a:4:{s:1:"C";s:3:"233";s:2:"WX";s:3:"600";s:1:"N";s:6:"Oslash";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-22";i:2;s:3:"578";i:3;s:3:"584";}}i:234;a:4:{s:1:"C";s:3:"234";s:2:"WX";s:3:"600";s:1:"N";s:2:"OE";s:1:"B";a:4:{i:0;s:3:"-25";i:1;s:1:"0";i:2;s:3:"595";i:3;s:3:"562";}}s:2:"OE";a:4:{s:1:"C";s:3:"234";s:2:"WX";s:3:"600";s:1:"N";s:2:"OE";s:1:"B";a:4:{i:0;s:3:"-25";i:1;s:1:"0";i:2;s:3:"595";i:3;s:3:"562";}}i:235;a:4:{s:1:"C";s:3:"235";s:2:"WX";s:3:"600";s:1:"N";s:12:"ordmasculine";s:1:"B";a:4:{i:0;s:3:"147";i:1;s:3:"196";i:2;s:3:"453";i:3;s:3:"580";}}s:12:"ordmasculine";a:4:{s:1:"C";s:3:"235";s:2:"WX";s:3:"600";s:1:"N";s:12:"ordmasculine";s:1:"B";a:4:{i:0;s:3:"147";i:1;s:3:"196";i:2;s:3:"453";i:3;s:3:"580";}}i:241;a:4:{s:1:"C";s:3:"241";s:2:"WX";s:3:"600";s:1:"N";s:2:"ae";s:1:"B";a:4:{i:0;s:2:"-4";i:1;s:3:"-15";i:2;s:3:"601";i:3;s:3:"454";}}s:2:"ae";a:4:{s:1:"C";s:3:"241";s:2:"WX";s:3:"600";s:1:"N";s:2:"ae";s:1:"B";a:4:{i:0;s:2:"-4";i:1;s:3:"-15";i:2;s:3:"601";i:3;s:3:"454";}}i:245;a:4:{s:1:"C";s:3:"245";s:2:"WX";s:3:"600";s:1:"N";s:8:"dotlessi";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"523";i:3;s:3:"439";}}s:8:"dotlessi";a:4:{s:1:"C";s:3:"245";s:2:"WX";s:3:"600";s:1:"N";s:8:"dotlessi";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"523";i:3;s:3:"439";}}i:248;a:4:{s:1:"C";s:3:"248";s:2:"WX";s:3:"600";s:1:"N";s:6:"lslash";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"523";i:3;s:3:"626";}}s:6:"lslash";a:4:{s:1:"C";s:3:"248";s:2:"WX";s:3:"600";s:1:"N";s:6:"lslash";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"523";i:3;s:3:"626";}}i:249;a:4:{s:1:"C";s:3:"249";s:2:"WX";s:3:"600";s:1:"N";s:6:"oslash";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-24";i:2;s:3:"570";i:3;s:3:"463";}}s:6:"oslash";a:4:{s:1:"C";s:3:"249";s:2:"WX";s:3:"600";s:1:"N";s:6:"oslash";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-24";i:2;s:3:"570";i:3;s:3:"463";}}i:250;a:4:{s:1:"C";s:3:"250";s:2:"WX";s:3:"600";s:1:"N";s:2:"oe";s:1:"B";a:4:{i:0;s:3:"-18";i:1;s:3:"-15";i:2;s:3:"611";i:3;s:3:"454";}}s:2:"oe";a:4:{s:1:"C";s:3:"250";s:2:"WX";s:3:"600";s:1:"N";s:2:"oe";s:1:"B";a:4:{i:0;s:3:"-18";i:1;s:3:"-15";i:2;s:3:"611";i:3;s:3:"454";}}i:251;a:4:{s:1:"C";s:3:"251";s:2:"WX";s:3:"600";s:1:"N";s:10:"germandbls";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-15";i:2;s:3:"596";i:3;s:3:"626";}}s:10:"germandbls";a:4:{s:1:"C";s:3:"251";s:2:"WX";s:3:"600";s:1:"N";s:10:"germandbls";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-15";i:2;s:3:"596";i:3;s:3:"626";}}s:9:"Idieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"Idieresis";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"523";i:3;s:3:"761";}}s:6:"eacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"eacute";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"-15";i:2;s:3:"563";i:3;s:3:"661";}}s:6:"abreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"abreve";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-15";i:2;s:3:"570";i:3;s:3:"661";}}s:13:"uhungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:13:"uhungarumlaut";s:1:"B";a:4:{i:0;s:2:"-1";i:1;s:3:"-15";i:2;s:3:"628";i:3;s:3:"661";}}s:6:"ecaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"ecaron";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"-15";i:2;s:3:"563";i:3;s:3:"667";}}s:9:"Ydieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"Ydieresis";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"589";i:3;s:3:"761";}}s:6:"divide";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"divide";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:2:"16";i:2;s:3:"529";i:3;s:3:"500";}}s:6:"Yacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Yacute";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"589";i:3;s:3:"784";}}s:11:"Acircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"Acircumflex";s:1:"B";a:4:{i:0;s:2:"-9";i:1;s:1:"0";i:2;s:3:"609";i:3;s:3:"780";}}s:6:"aacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"aacute";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-15";i:2;s:3:"570";i:3;s:3:"661";}}s:11:"Ucircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"Ucircumflex";s:1:"B";a:4:{i:0;s:1:"4";i:1;s:3:"-18";i:2;s:3:"596";i:3;s:3:"780";}}s:6:"yacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"yacute";s:1:"B";a:4:{i:0;s:2:"-4";i:1;s:4:"-142";i:2;s:3:"601";i:3;s:3:"661";}}s:12:"scommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"scommaaccent";s:1:"B";a:4:{i:0;s:2:"68";i:1;s:4:"-250";i:2;s:3:"535";i:3;s:3:"459";}}s:11:"ecircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"ecircumflex";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"-15";i:2;s:3:"563";i:3;s:3:"657";}}s:5:"Uring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:5:"Uring";s:1:"B";a:4:{i:0;s:1:"4";i:1;s:3:"-18";i:2;s:3:"596";i:3;s:3:"801";}}s:9:"Udieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"Udieresis";s:1:"B";a:4:{i:0;s:1:"4";i:1;s:3:"-18";i:2;s:3:"596";i:3;s:3:"761";}}s:7:"aogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"aogonek";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:4:"-199";i:2;s:3:"586";i:3;s:3:"454";}}s:6:"Uacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Uacute";s:1:"B";a:4:{i:0;s:1:"4";i:1;s:3:"-18";i:2;s:3:"596";i:3;s:3:"784";}}s:7:"uogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"uogonek";s:1:"B";a:4:{i:0;s:2:"-1";i:1;s:4:"-199";i:2;s:3:"585";i:3;s:3:"439";}}s:9:"Edieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"Edieresis";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"560";i:3;s:3:"761";}}s:6:"Dcroat";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Dcroat";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:1:"0";i:2;s:3:"594";i:3;s:3:"562";}}s:11:"commaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"commaaccent";s:1:"B";a:4:{i:0;s:3:"205";i:1;s:4:"-250";i:2;s:3:"397";i:3;s:3:"-57";}}s:9:"copyright";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"copyright";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"-18";i:2;s:3:"600";i:3;s:3:"580";}}s:7:"Emacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"Emacron";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"560";i:3;s:3:"708";}}s:6:"ccaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"ccaron";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"-15";i:2;s:3:"545";i:3;s:3:"667";}}s:5:"aring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:5:"aring";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-15";i:2;s:3:"570";i:3;s:3:"678";}}s:12:"Ncommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"Ncommaaccent";s:1:"B";a:4:{i:0;s:1:"8";i:1;s:4:"-250";i:2;s:3:"610";i:3;s:3:"562";}}s:6:"lacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"lacute";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"523";i:3;s:3:"801";}}s:6:"agrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"agrave";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-15";i:2;s:3:"570";i:3;s:3:"661";}}s:12:"Tcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"Tcommaaccent";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:4:"-250";i:2;s:3:"579";i:3;s:3:"562";}}s:6:"Cacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Cacute";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-18";i:2;s:3:"560";i:3;s:3:"784";}}s:6:"atilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"atilde";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-15";i:2;s:3:"570";i:3;s:3:"636";}}s:10:"Edotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:10:"Edotaccent";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"560";i:3;s:3:"761";}}s:6:"scaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"scaron";s:1:"B";a:4:{i:0;s:2:"68";i:1;s:3:"-17";i:2;s:3:"535";i:3;s:3:"667";}}s:8:"scedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:8:"scedilla";s:1:"B";a:4:{i:0;s:2:"68";i:1;s:4:"-206";i:2;s:3:"535";i:3;s:3:"459";}}s:6:"iacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"iacute";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"523";i:3;s:3:"661";}}s:7:"lozenge";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"lozenge";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:1:"0";i:2;s:3:"534";i:3;s:3:"740";}}s:6:"Rcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Rcaron";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:1:"0";i:2;s:3:"599";i:3;s:3:"790";}}s:12:"Gcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"Gcommaaccent";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:4:"-250";i:2;s:3:"594";i:3;s:3:"580";}}s:11:"ucircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"ucircumflex";s:1:"B";a:4:{i:0;s:2:"-1";i:1;s:3:"-15";i:2;s:3:"569";i:3;s:3:"657";}}s:11:"acircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"acircumflex";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-15";i:2;s:3:"570";i:3;s:3:"657";}}s:7:"Amacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"Amacron";s:1:"B";a:4:{i:0;s:2:"-9";i:1;s:1:"0";i:2;s:3:"609";i:3;s:3:"708";}}s:6:"rcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"rcaron";s:1:"B";a:4:{i:0;s:2:"47";i:1;s:1:"0";i:2;s:3:"580";i:3;s:3:"667";}}s:8:"ccedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:8:"ccedilla";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:4:"-206";i:2;s:3:"545";i:3;s:3:"459";}}s:10:"Zdotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:10:"Zdotaccent";s:1:"B";a:4:{i:0;s:2:"62";i:1;s:1:"0";i:2;s:3:"539";i:3;s:3:"761";}}s:5:"Thorn";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:5:"Thorn";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:1:"0";i:2;s:3:"557";i:3;s:3:"562";}}s:7:"Omacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"Omacron";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-18";i:2;s:3:"578";i:3;s:3:"708";}}s:6:"Racute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Racute";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:1:"0";i:2;s:3:"599";i:3;s:3:"784";}}s:6:"Sacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Sacute";s:1:"B";a:4:{i:0;s:2:"47";i:1;s:3:"-22";i:2;s:3:"553";i:3;s:3:"784";}}s:6:"dcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"dcaron";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:3:"-15";i:2;s:3:"727";i:3;s:3:"626";}}s:7:"Umacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"Umacron";s:1:"B";a:4:{i:0;s:1:"4";i:1;s:3:"-18";i:2;s:3:"596";i:3;s:3:"708";}}s:5:"uring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:5:"uring";s:1:"B";a:4:{i:0;s:2:"-1";i:1;s:3:"-15";i:2;s:3:"569";i:3;s:3:"678";}}s:13:"threesuperior";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:13:"threesuperior";s:1:"B";a:4:{i:0;s:3:"138";i:1;s:3:"222";i:2;s:3:"433";i:3;s:3:"616";}}s:6:"Ograve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Ograve";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-18";i:2;s:3:"578";i:3;s:3:"784";}}s:6:"Agrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Agrave";s:1:"B";a:4:{i:0;s:2:"-9";i:1;s:1:"0";i:2;s:3:"609";i:3;s:3:"784";}}s:6:"Abreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Abreve";s:1:"B";a:4:{i:0;s:2:"-9";i:1;s:1:"0";i:2;s:3:"609";i:3;s:3:"784";}}s:8:"multiply";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:8:"multiply";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:2:"39";i:2;s:3:"520";i:3;s:3:"478";}}s:6:"uacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"uacute";s:1:"B";a:4:{i:0;s:2:"-1";i:1;s:3:"-15";i:2;s:3:"569";i:3;s:3:"661";}}s:6:"Tcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Tcaron";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:1:"0";i:2;s:3:"579";i:3;s:3:"790";}}s:11:"partialdiff";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"partialdiff";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:3:"-38";i:2;s:3:"537";i:3;s:3:"728";}}s:9:"ydieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"ydieresis";s:1:"B";a:4:{i:0;s:2:"-4";i:1;s:4:"-142";i:2;s:3:"601";i:3;s:3:"638";}}s:6:"Nacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Nacute";s:1:"B";a:4:{i:0;s:1:"8";i:1;s:3:"-12";i:2;s:3:"610";i:3;s:3:"784";}}s:11:"icircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"icircumflex";s:1:"B";a:4:{i:0;s:2:"73";i:1;s:1:"0";i:2;s:3:"523";i:3;s:3:"657";}}s:11:"Ecircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"Ecircumflex";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"560";i:3;s:3:"780";}}s:9:"adieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"adieresis";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-15";i:2;s:3:"570";i:3;s:3:"638";}}s:9:"edieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"edieresis";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"-15";i:2;s:3:"563";i:3;s:3:"638";}}s:6:"cacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"cacute";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"-15";i:2;s:3:"545";i:3;s:3:"661";}}s:6:"nacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"nacute";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:1:"0";i:2;s:3:"592";i:3;s:3:"661";}}s:7:"umacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"umacron";s:1:"B";a:4:{i:0;s:2:"-1";i:1;s:3:"-15";i:2;s:3:"569";i:3;s:3:"585";}}s:6:"Ncaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Ncaron";s:1:"B";a:4:{i:0;s:1:"8";i:1;s:3:"-12";i:2;s:3:"610";i:3;s:3:"790";}}s:6:"Iacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Iacute";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"523";i:3;s:3:"784";}}s:9:"plusminus";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"plusminus";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:2:"24";i:2;s:3:"529";i:3;s:3:"515";}}s:9:"brokenbar";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"brokenbar";s:1:"B";a:4:{i:0;s:3:"255";i:1;s:4:"-175";i:2;s:3:"345";i:3;s:3:"675";}}s:10:"registered";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:10:"registered";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"-18";i:2;s:3:"600";i:3;s:3:"580";}}s:6:"Gbreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Gbreve";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-18";i:2;s:3:"594";i:3;s:3:"784";}}s:10:"Idotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:10:"Idotaccent";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"523";i:3;s:3:"761";}}s:9:"summation";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"summation";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:3:"-10";i:2;s:3:"586";i:3;s:3:"706";}}s:6:"Egrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Egrave";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"560";i:3;s:3:"784";}}s:6:"racute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"racute";s:1:"B";a:4:{i:0;s:2:"47";i:1;s:1:"0";i:2;s:3:"580";i:3;s:3:"661";}}s:7:"omacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"omacron";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-15";i:2;s:3:"570";i:3;s:3:"585";}}s:6:"Zacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Zacute";s:1:"B";a:4:{i:0;s:2:"62";i:1;s:1:"0";i:2;s:3:"539";i:3;s:3:"784";}}s:6:"Zcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Zcaron";s:1:"B";a:4:{i:0;s:2:"62";i:1;s:1:"0";i:2;s:3:"539";i:3;s:3:"790";}}s:12:"greaterequal";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"greaterequal";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"523";i:3;s:3:"696";}}s:3:"Eth";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:3:"Eth";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:1:"0";i:2;s:3:"594";i:3;s:3:"562";}}s:8:"Ccedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:8:"Ccedilla";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:4:"-206";i:2;s:3:"560";i:3;s:3:"580";}}s:12:"lcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"lcommaaccent";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:4:"-250";i:2;s:3:"523";i:3;s:3:"626";}}s:6:"tcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"tcaron";s:1:"B";a:4:{i:0;s:2:"47";i:1;s:3:"-15";i:2;s:3:"532";i:3;s:3:"703";}}s:7:"eogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"eogonek";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:4:"-199";i:2;s:3:"563";i:3;s:3:"454";}}s:7:"Uogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"Uogonek";s:1:"B";a:4:{i:0;s:1:"4";i:1;s:4:"-199";i:2;s:3:"596";i:3;s:3:"562";}}s:6:"Aacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Aacute";s:1:"B";a:4:{i:0;s:2:"-9";i:1;s:1:"0";i:2;s:3:"609";i:3;s:3:"784";}}s:9:"Adieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"Adieresis";s:1:"B";a:4:{i:0;s:2:"-9";i:1;s:1:"0";i:2;s:3:"609";i:3;s:3:"761";}}s:6:"egrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"egrave";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"-15";i:2;s:3:"563";i:3;s:3:"661";}}s:6:"zacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"zacute";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:1:"0";i:2;s:3:"520";i:3;s:3:"661";}}s:7:"iogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"iogonek";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:4:"-199";i:2;s:3:"523";i:3;s:3:"658";}}s:6:"Oacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Oacute";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-18";i:2;s:3:"578";i:3;s:3:"784";}}s:6:"oacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"oacute";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-15";i:2;s:3:"570";i:3;s:3:"661";}}s:7:"amacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"amacron";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-15";i:2;s:3:"570";i:3;s:3:"585";}}s:6:"sacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"sacute";s:1:"B";a:4:{i:0;s:2:"68";i:1;s:3:"-17";i:2;s:3:"535";i:3;s:3:"661";}}s:9:"idieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"idieresis";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"523";i:3;s:3:"618";}}s:11:"Ocircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"Ocircumflex";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-18";i:2;s:3:"578";i:3;s:3:"780";}}s:6:"Ugrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Ugrave";s:1:"B";a:4:{i:0;s:1:"4";i:1;s:3:"-18";i:2;s:3:"596";i:3;s:3:"784";}}s:5:"Delta";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:5:"Delta";s:1:"B";a:4:{i:0;s:1:"6";i:1;s:1:"0";i:2;s:3:"594";i:3;s:3:"688";}}s:5:"thorn";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:5:"thorn";s:1:"B";a:4:{i:0;s:3:"-14";i:1;s:4:"-142";i:2;s:3:"570";i:3;s:3:"626";}}s:11:"twosuperior";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"twosuperior";s:1:"B";a:4:{i:0;s:3:"143";i:1;s:3:"230";i:2;s:3:"436";i:3;s:3:"616";}}s:9:"Odieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"Odieresis";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-18";i:2;s:3:"578";i:3;s:3:"761";}}s:2:"mu";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:2:"mu";s:1:"B";a:4:{i:0;s:2:"-1";i:1;s:4:"-142";i:2;s:3:"569";i:3;s:3:"439";}}s:6:"igrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"igrave";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"523";i:3;s:3:"661";}}s:13:"ohungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:13:"ohungarumlaut";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-15";i:2;s:3:"668";i:3;s:3:"661";}}s:7:"Eogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"Eogonek";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:4:"-199";i:2;s:3:"576";i:3;s:3:"562";}}s:6:"dcroat";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"dcroat";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:3:"-15";i:2;s:3:"591";i:3;s:3:"626";}}s:13:"threequarters";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:13:"threequarters";s:1:"B";a:4:{i:0;s:3:"-47";i:1;s:3:"-60";i:2;s:3:"648";i:3;s:3:"661";}}s:8:"Scedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:8:"Scedilla";s:1:"B";a:4:{i:0;s:2:"47";i:1;s:4:"-206";i:2;s:3:"553";i:3;s:3:"582";}}s:6:"lcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"lcaron";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"597";i:3;s:3:"626";}}s:12:"Kcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"Kcommaaccent";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:4:"-250";i:2;s:3:"599";i:3;s:3:"562";}}s:6:"Lacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Lacute";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:1:"0";i:2;s:3:"578";i:3;s:3:"784";}}s:9:"trademark";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"trademark";s:1:"B";a:4:{i:0;s:2:"-9";i:1;s:3:"230";i:2;s:3:"749";i:3;s:3:"562";}}s:10:"edotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:10:"edotaccent";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"-15";i:2;s:3:"563";i:3;s:3:"638";}}s:6:"Igrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Igrave";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"523";i:3;s:3:"784";}}s:7:"Imacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"Imacron";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"523";i:3;s:3:"708";}}s:6:"Lcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Lcaron";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:1:"0";i:2;s:3:"637";i:3;s:3:"562";}}s:7:"onehalf";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"onehalf";s:1:"B";a:4:{i:0;s:3:"-47";i:1;s:3:"-60";i:2;s:3:"648";i:3;s:3:"661";}}s:9:"lessequal";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"lessequal";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"523";i:3;s:3:"696";}}s:11:"ocircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"ocircumflex";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-15";i:2;s:3:"570";i:3;s:3:"657";}}s:6:"ntilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"ntilde";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:1:"0";i:2;s:3:"592";i:3;s:3:"636";}}s:13:"Uhungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:13:"Uhungarumlaut";s:1:"B";a:4:{i:0;s:1:"4";i:1;s:3:"-18";i:2;s:3:"638";i:3;s:3:"784";}}s:6:"Eacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Eacute";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"560";i:3;s:3:"784";}}s:7:"emacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"emacron";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"-15";i:2;s:3:"563";i:3;s:3:"585";}}s:6:"gbreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"gbreve";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:4:"-146";i:2;s:3:"580";i:3;s:3:"661";}}s:10:"onequarter";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:10:"onequarter";s:1:"B";a:4:{i:0;s:3:"-56";i:1;s:3:"-60";i:2;s:3:"656";i:3;s:3:"661";}}s:6:"Scaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Scaron";s:1:"B";a:4:{i:0;s:2:"47";i:1;s:3:"-22";i:2;s:3:"553";i:3;s:3:"790";}}s:12:"Scommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"Scommaaccent";s:1:"B";a:4:{i:0;s:2:"47";i:1;s:4:"-250";i:2;s:3:"553";i:3;s:3:"582";}}s:13:"Ohungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:13:"Ohungarumlaut";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-18";i:2;s:3:"628";i:3;s:3:"784";}}s:6:"degree";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"degree";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:3:"243";i:2;s:3:"474";i:3;s:3:"616";}}s:6:"ograve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"ograve";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-15";i:2;s:3:"570";i:3;s:3:"661";}}s:6:"Ccaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Ccaron";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-18";i:2;s:3:"560";i:3;s:3:"790";}}s:6:"ugrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"ugrave";s:1:"B";a:4:{i:0;s:2:"-1";i:1;s:3:"-15";i:2;s:3:"569";i:3;s:3:"661";}}s:7:"radical";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"radical";s:1:"B";a:4:{i:0;s:3:"-19";i:1;s:4:"-104";i:2;s:3:"473";i:3;s:3:"778";}}s:6:"Dcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Dcaron";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:1:"0";i:2;s:3:"594";i:3;s:3:"790";}}s:12:"rcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"rcommaaccent";s:1:"B";a:4:{i:0;s:2:"47";i:1;s:4:"-250";i:2;s:3:"580";i:3;s:3:"454";}}s:6:"Ntilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Ntilde";s:1:"B";a:4:{i:0;s:1:"8";i:1;s:3:"-12";i:2;s:3:"610";i:3;s:3:"759";}}s:6:"otilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"otilde";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-15";i:2;s:3:"570";i:3;s:3:"636";}}s:12:"Rcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"Rcommaaccent";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:4:"-250";i:2;s:3:"599";i:3;s:3:"562";}}s:12:"Lcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"Lcommaaccent";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:4:"-250";i:2;s:3:"578";i:3;s:3:"562";}}s:6:"Atilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Atilde";s:1:"B";a:4:{i:0;s:2:"-9";i:1;s:1:"0";i:2;s:3:"609";i:3;s:3:"759";}}s:7:"Aogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"Aogonek";s:1:"B";a:4:{i:0;s:2:"-9";i:1;s:4:"-199";i:2;s:3:"625";i:3;s:3:"562";}}s:5:"Aring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:5:"Aring";s:1:"B";a:4:{i:0;s:2:"-9";i:1;s:1:"0";i:2;s:3:"609";i:3;s:3:"801";}}s:6:"Otilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Otilde";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-18";i:2;s:3:"578";i:3;s:3:"759";}}s:10:"zdotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:10:"zdotaccent";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:1:"0";i:2;s:3:"520";i:3;s:3:"638";}}s:6:"Ecaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Ecaron";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"560";i:3;s:3:"790";}}s:7:"Iogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"Iogonek";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:4:"-199";i:2;s:3:"523";i:3;s:3:"562";}}s:12:"kcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"kcommaaccent";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:4:"-250";i:2;s:3:"585";i:3;s:3:"626";}}s:5:"minus";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:5:"minus";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:3:"203";i:2;s:3:"529";i:3;s:3:"313";}}s:11:"Icircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"Icircumflex";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"523";i:3;s:3:"780";}}s:6:"ncaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"ncaron";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:1:"0";i:2;s:3:"592";i:3;s:3:"667";}}s:12:"tcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"tcommaaccent";s:1:"B";a:4:{i:0;s:2:"47";i:1;s:4:"-250";i:2;s:3:"532";i:3;s:3:"562";}}s:10:"logicalnot";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:10:"logicalnot";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:3:"103";i:2;s:3:"529";i:3;s:3:"413";}}s:9:"odieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"odieresis";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-15";i:2;s:3:"570";i:3;s:3:"638";}}s:9:"udieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"udieresis";s:1:"B";a:4:{i:0;s:2:"-1";i:1;s:3:"-15";i:2;s:3:"569";i:3;s:3:"638";}}s:8:"notequal";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:8:"notequal";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:3:"-47";i:2;s:3:"537";i:3;s:3:"563";}}s:12:"gcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"gcommaaccent";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:4:"-146";i:2;s:3:"580";i:3;s:3:"714";}}s:3:"eth";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:3:"eth";s:1:"B";a:4:{i:0;s:2:"58";i:1;s:3:"-27";i:2;s:3:"543";i:3;s:3:"626";}}s:6:"zcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"zcaron";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:1:"0";i:2;s:3:"520";i:3;s:3:"667";}}s:12:"ncommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"ncommaaccent";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:4:"-250";i:2;s:3:"592";i:3;s:3:"454";}}s:11:"onesuperior";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"onesuperior";s:1:"B";a:4:{i:0;s:3:"153";i:1;s:3:"230";i:2;s:3:"447";i:3;s:3:"616";}}s:7:"imacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"imacron";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"523";i:3;s:3:"585";}}s:4:"Euro";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:4:"Euro";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}}s:9:"_version_";i:1;}
\ No newline at end of file
Added: trunk/mapbender/http/classes/fonts/php_Courier-BoldOblique.afm
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/fonts/php_Courier-BoldOblique.afm?view=auto&rev=13
--- (empty file)
+++ trunk/mapbender/http/classes/fonts/php_Courier-BoldOblique.afm 2006-04-13 19:38:28+0000
@@ -0,0 +1 @@
+a:21:{s:8:"FontName";s:19:"Courier-BoldOblique";s:8:"FullName";s:20:"Courier Bold Oblique";s:10:"FamilyName";s:7:"Courier";s:6:"Weight";s:4:"Bold";s:11:"ItalicAngle";s:3:"-12";s:12:"IsFixedPitch";s:4:"true";s:12:"CharacterSet";s:13:"ExtendedRoman";s:8:"FontBBox";a:4:{i:0;s:3:"-57";i:1;s:4:"-250";i:2;s:3:"869";i:3;s:3:"801";}s:17:"UnderlinePosition";s:4:"-100";s:18:"UnderlineThickness";s:2:"50";s:7:"Version";s:7:"003.000";s:14:"EncodingScheme";s:21:"AdobeStandardEncoding";s:9:"CapHeight";s:3:"562";s:7:"XHeight";s:3:"439";s:8:"Ascender";s:3:"629";s:9:"Descender";s:4:"-157";s:5:"StdHW";s:2:"84";s:5:"StdVW";s:3:"106";s:16:"StartCharMetrics";s:3:"315";s:1:"C";a:464:{i:32;a:4:{s:1:"C";s:2:"32";s:2:"WX";s:3:"600";s:1:"N";s:5:"space";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}s:5:"space";a:4:{s:1:"C";s:2:"32";s:2:"WX";s:3:"600";s:1:"N";s:5:"space";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}i:33;a:4:{s:1:"C";s:2:"33";s:2:"WX";s:3:"600";s:1:"N";s:6:"exclam";s:1:"B";a:4:{i:0;s:3:"215";i:1;s:3:"-15";i:2;s:3:"495";i:3;s:3:"572";}}s:6:"exclam";a:4:{s:1:"C";s:2:"33";s:2:"WX";s:3:"600";s:1:"N";s:6:"exclam";s:1:"B";a:4:{i:0;s:3:"215";i:1;s:3:"-15";i:2;s:3:"495";i:3;s:3:"572";}}i:34;a:4:{s:1:"C";s:2:"34";s:2:"WX";s:3:"600";s:1:"N";s:8:"quotedbl";s:1:"B";a:4:{i:0;s:3:"211";i:1;s:3:"277";i:2;s:3:"585";i:3;s:3:"562";}}s:8:"quotedbl";a:4:{s:1:"C";s:2:"34";s:2:"WX";s:3:"600";s:1:"N";s:8:"quotedbl";s:1:"B";a:4:{i:0;s:3:"211";i:1;s:3:"277";i:2;s:3:"585";i:3;s:3:"562";}}i:35;a:4:{s:1:"C";s:2:"35";s:2:"WX";s:3:"600";s:1:"N";s:10:"numbersign";s:1:"B";a:4:{i:0;s:2:"88";i:1;s:3:"-45";i:2;s:3:"641";i:3;s:3:"651";}}s:10:"numbersign";a:4:{s:1:"C";s:2:"35";s:2:"WX";s:3:"600";s:1:"N";s:10:"numbersign";s:1:"B";a:4:{i:0;s:2:"88";i:1;s:3:"-45";i:2;s:3:"641";i:3;s:3:"651";}}i:36;a:4:{s:1:"C";s:2:"36";s:2:"WX";s:3:"600";s:1:"N";s:6:"dollar";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:4:"-126";i:2;s:3:"630";i:3;s:3:"666";}}s:6:"dollar";a:4:{s:1:"C";s:2:"36";s:2:"WX";s:3:"600";s:1:"N";s:6:"dollar";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:4:"-126";i:2;s:3:"630";i:3;s:3:"666";}}i:37;a:4:{s:1:"C";s:2:"37";s:2:"WX";s:3:"600";s:1:"N";s:7:"percent";s:1:"B";a:4:{i:0;s:3:"101";i:1;s:3:"-15";i:2;s:3:"625";i:3;s:3:"616";}}s:7:"percent";a:4:{s:1:"C";s:2:"37";s:2:"WX";s:3:"600";s:1:"N";s:7:"percent";s:1:"B";a:4:{i:0;s:3:"101";i:1;s:3:"-15";i:2;s:3:"625";i:3;s:3:"616";}}i:38;a:4:{s:1:"C";s:2:"38";s:2:"WX";s:3:"600";s:1:"N";s:9:"ampersand";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:3:"-15";i:2;s:3:"595";i:3;s:3:"543";}}s:9:"ampersand";a:4:{s:1:"C";s:2:"38";s:2:"WX";s:3:"600";s:1:"N";s:9:"ampersand";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:3:"-15";i:2;s:3:"595";i:3;s:3:"543";}}i:39;a:4:{s:1:"C";s:2:"39";s:2:"WX";s:3:"600";s:1:"N";s:10:"quoteright";s:1:"B";a:4:{i:0;s:3:"229";i:1;s:3:"277";i:2;s:3:"543";i:3;s:3:"562";}}s:10:"quoteright";a:4:{s:1:"C";s:2:"39";s:2:"WX";s:3:"600";s:1:"N";s:10:"quoteright";s:1:"B";a:4:{i:0;s:3:"229";i:1;s:3:"277";i:2;s:3:"543";i:3;s:3:"562";}}i:40;a:4:{s:1:"C";s:2:"40";s:2:"WX";s:3:"600";s:1:"N";s:9:"parenleft";s:1:"B";a:4:{i:0;s:3:"265";i:1;s:4:"-102";i:2;s:3:"592";i:3;s:3:"616";}}s:9:"parenleft";a:4:{s:1:"C";s:2:"40";s:2:"WX";s:3:"600";s:1:"N";s:9:"parenleft";s:1:"B";a:4:{i:0;s:3:"265";i:1;s:4:"-102";i:2;s:3:"592";i:3;s:3:"616";}}i:41;a:4:{s:1:"C";s:2:"41";s:2:"WX";s:3:"600";s:1:"N";s:10:"parenright";s:1:"B";a:4:{i:0;s:3:"117";i:1;s:4:"-102";i:2;s:3:"444";i:3;s:3:"616";}}s:10:"parenright";a:4:{s:1:"C";s:2:"41";s:2:"WX";s:3:"600";s:1:"N";s:10:"parenright";s:1:"B";a:4:{i:0;s:3:"117";i:1;s:4:"-102";i:2;s:3:"444";i:3;s:3:"616";}}i:42;a:4:{s:1:"C";s:2:"42";s:2:"WX";s:3:"600";s:1:"N";s:8:"asterisk";s:1:"B";a:4:{i:0;s:3:"179";i:1;s:3:"219";i:2;s:3:"598";i:3;s:3:"601";}}s:8:"asterisk";a:4:{s:1:"C";s:2:"42";s:2:"WX";s:3:"600";s:1:"N";s:8:"asterisk";s:1:"B";a:4:{i:0;s:3:"179";i:1;s:3:"219";i:2;s:3:"598";i:3;s:3:"601";}}i:43;a:4:{s:1:"C";s:2:"43";s:2:"WX";s:3:"600";s:1:"N";s:4:"plus";s:1:"B";a:4:{i:0;s:3:"114";i:1;s:2:"39";i:2;s:3:"596";i:3;s:3:"478";}}s:4:"plus";a:4:{s:1:"C";s:2:"43";s:2:"WX";s:3:"600";s:1:"N";s:4:"plus";s:1:"B";a:4:{i:0;s:3:"114";i:1;s:2:"39";i:2;s:3:"596";i:3;s:3:"478";}}i:44;a:4:{s:1:"C";s:2:"44";s:2:"WX";s:3:"600";s:1:"N";s:5:"comma";s:1:"B";a:4:{i:0;s:2:"99";i:1;s:4:"-111";i:2;s:3:"430";i:3;s:3:"174";}}s:5:"comma";a:4:{s:1:"C";s:2:"44";s:2:"WX";s:3:"600";s:1:"N";s:5:"comma";s:1:"B";a:4:{i:0;s:2:"99";i:1;s:4:"-111";i:2;s:3:"430";i:3;s:3:"174";}}i:45;a:4:{s:1:"C";s:2:"45";s:2:"WX";s:3:"600";s:1:"N";s:6:"hyphen";s:1:"B";a:4:{i:0;s:3:"143";i:1;s:3:"203";i:2;s:3:"567";i:3;s:3:"313";}}s:6:"hyphen";a:4:{s:1:"C";s:2:"45";s:2:"WX";s:3:"600";s:1:"N";s:6:"hyphen";s:1:"B";a:4:{i:0;s:3:"143";i:1;s:3:"203";i:2;s:3:"567";i:3;s:3:"313";}}i:46;a:4:{s:1:"C";s:2:"46";s:2:"WX";s:3:"600";s:1:"N";s:6:"period";s:1:"B";a:4:{i:0;s:3:"206";i:1;s:3:"-15";i:2;s:3:"427";i:3;s:3:"171";}}s:6:"period";a:4:{s:1:"C";s:2:"46";s:2:"WX";s:3:"600";s:1:"N";s:6:"period";s:1:"B";a:4:{i:0;s:3:"206";i:1;s:3:"-15";i:2;s:3:"427";i:3;s:3:"171";}}i:47;a:4:{s:1:"C";s:2:"47";s:2:"WX";s:3:"600";s:1:"N";s:5:"slash";s:1:"B";a:4:{i:0;s:2:"90";i:1;s:3:"-77";i:2;s:3:"626";i:3;s:3:"626";}}s:5:"slash";a:4:{s:1:"C";s:2:"47";s:2:"WX";s:3:"600";s:1:"N";s:5:"slash";s:1:"B";a:4:{i:0;s:2:"90";i:1;s:3:"-77";i:2;s:3:"626";i:3;s:3:"626";}}i:48;a:4:{s:1:"C";s:2:"48";s:2:"WX";s:3:"600";s:1:"N";s:4:"zero";s:1:"B";a:4:{i:0;s:3:"135";i:1;s:3:"-15";i:2;s:3:"593";i:3;s:3:"616";}}s:4:"zero";a:4:{s:1:"C";s:2:"48";s:2:"WX";s:3:"600";s:1:"N";s:4:"zero";s:1:"B";a:4:{i:0;s:3:"135";i:1;s:3:"-15";i:2;s:3:"593";i:3;s:3:"616";}}i:49;a:4:{s:1:"C";s:2:"49";s:2:"WX";s:3:"600";s:1:"N";s:3:"one";s:1:"B";a:4:{i:0;s:2:"93";i:1;s:1:"0";i:2;s:3:"562";i:3;s:3:"616";}}s:3:"one";a:4:{s:1:"C";s:2:"49";s:2:"WX";s:3:"600";s:1:"N";s:3:"one";s:1:"B";a:4:{i:0;s:2:"93";i:1;s:1:"0";i:2;s:3:"562";i:3;s:3:"616";}}i:50;a:4:{s:1:"C";s:2:"50";s:2:"WX";s:3:"600";s:1:"N";s:3:"two";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:1:"0";i:2;s:3:"594";i:3;s:3:"616";}}s:3:"two";a:4:{s:1:"C";s:2:"50";s:2:"WX";s:3:"600";s:1:"N";s:3:"two";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:1:"0";i:2;s:3:"594";i:3;s:3:"616";}}i:51;a:4:{s:1:"C";s:2:"51";s:2:"WX";s:3:"600";s:1:"N";s:5:"three";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:3:"-15";i:2;s:3:"571";i:3;s:3:"616";}}s:5:"three";a:4:{s:1:"C";s:2:"51";s:2:"WX";s:3:"600";s:1:"N";s:5:"three";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:3:"-15";i:2;s:3:"571";i:3;s:3:"616";}}i:52;a:4:{s:1:"C";s:2:"52";s:2:"WX";s:3:"600";s:1:"N";s:4:"four";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:1:"0";i:2;s:3:"559";i:3;s:3:"616";}}s:4:"four";a:4:{s:1:"C";s:2:"52";s:2:"WX";s:3:"600";s:1:"N";s:4:"four";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:1:"0";i:2;s:3:"559";i:3;s:3:"616";}}i:53;a:4:{s:1:"C";s:2:"53";s:2:"WX";s:3:"600";s:1:"N";s:4:"five";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:3:"-15";i:2;s:3:"621";i:3;s:3:"601";}}s:4:"five";a:4:{s:1:"C";s:2:"53";s:2:"WX";s:3:"600";s:1:"N";s:4:"five";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:3:"-15";i:2;s:3:"621";i:3;s:3:"601";}}i:54;a:4:{s:1:"C";s:2:"54";s:2:"WX";s:3:"600";s:1:"N";s:3:"six";s:1:"B";a:4:{i:0;s:3:"135";i:1;s:3:"-15";i:2;s:3:"652";i:3;s:3:"616";}}s:3:"six";a:4:{s:1:"C";s:2:"54";s:2:"WX";s:3:"600";s:1:"N";s:3:"six";s:1:"B";a:4:{i:0;s:3:"135";i:1;s:3:"-15";i:2;s:3:"652";i:3;s:3:"616";}}i:55;a:4:{s:1:"C";s:2:"55";s:2:"WX";s:3:"600";s:1:"N";s:5:"seven";s:1:"B";a:4:{i:0;s:3:"147";i:1;s:1:"0";i:2;s:3:"622";i:3;s:3:"601";}}s:5:"seven";a:4:{s:1:"C";s:2:"55";s:2:"WX";s:3:"600";s:1:"N";s:5:"seven";s:1:"B";a:4:{i:0;s:3:"147";i:1;s:1:"0";i:2;s:3:"622";i:3;s:3:"601";}}i:56;a:4:{s:1:"C";s:2:"56";s:2:"WX";s:3:"600";s:1:"N";s:5:"eight";s:1:"B";a:4:{i:0;s:3:"115";i:1;s:3:"-15";i:2;s:3:"604";i:3;s:3:"616";}}s:5:"eight";a:4:{s:1:"C";s:2:"56";s:2:"WX";s:3:"600";s:1:"N";s:5:"eight";s:1:"B";a:4:{i:0;s:3:"115";i:1;s:3:"-15";i:2;s:3:"604";i:3;s:3:"616";}}i:57;a:4:{s:1:"C";s:2:"57";s:2:"WX";s:3:"600";s:1:"N";s:4:"nine";s:1:"B";a:4:{i:0;s:2:"75";i:1;s:3:"-15";i:2;s:3:"592";i:3;s:3:"616";}}s:4:"nine";a:4:{s:1:"C";s:2:"57";s:2:"WX";s:3:"600";s:1:"N";s:4:"nine";s:1:"B";a:4:{i:0;s:2:"75";i:1;s:3:"-15";i:2;s:3:"592";i:3;s:3:"616";}}i:58;a:4:{s:1:"C";s:2:"58";s:2:"WX";s:3:"600";s:1:"N";s:5:"colon";s:1:"B";a:4:{i:0;s:3:"205";i:1;s:3:"-15";i:2;s:3:"480";i:3;s:3:"425";}}s:5:"colon";a:4:{s:1:"C";s:2:"58";s:2:"WX";s:3:"600";s:1:"N";s:5:"colon";s:1:"B";a:4:{i:0;s:3:"205";i:1;s:3:"-15";i:2;s:3:"480";i:3;s:3:"425";}}i:59;a:4:{s:1:"C";s:2:"59";s:2:"WX";s:3:"600";s:1:"N";s:9:"semicolon";s:1:"B";a:4:{i:0;s:2:"99";i:1;s:4:"-111";i:2;s:3:"481";i:3;s:3:"425";}}s:9:"semicolon";a:4:{s:1:"C";s:2:"59";s:2:"WX";s:3:"600";s:1:"N";s:9:"semicolon";s:1:"B";a:4:{i:0;s:2:"99";i:1;s:4:"-111";i:2;s:3:"481";i:3;s:3:"425";}}i:60;a:4:{s:1:"C";s:2:"60";s:2:"WX";s:3:"600";s:1:"N";s:4:"less";s:1:"B";a:4:{i:0;s:3:"120";i:1;s:2:"15";i:2;s:3:"613";i:3;s:3:"501";}}s:4:"less";a:4:{s:1:"C";s:2:"60";s:2:"WX";s:3:"600";s:1:"N";s:4:"less";s:1:"B";a:4:{i:0;s:3:"120";i:1;s:2:"15";i:2;s:3:"613";i:3;s:3:"501";}}i:61;a:4:{s:1:"C";s:2:"61";s:2:"WX";s:3:"600";s:1:"N";s:5:"equal";s:1:"B";a:4:{i:0;s:2:"96";i:1;s:3:"118";i:2;s:3:"614";i:3;s:3:"398";}}s:5:"equal";a:4:{s:1:"C";s:2:"61";s:2:"WX";s:3:"600";s:1:"N";s:5:"equal";s:1:"B";a:4:{i:0;s:2:"96";i:1;s:3:"118";i:2;s:3:"614";i:3;s:3:"398";}}i:62;a:4:{s:1:"C";s:2:"62";s:2:"WX";s:3:"600";s:1:"N";s:7:"greater";s:1:"B";a:4:{i:0;s:2:"97";i:1;s:2:"15";i:2;s:3:"589";i:3;s:3:"501";}}s:7:"greater";a:4:{s:1:"C";s:2:"62";s:2:"WX";s:3:"600";s:1:"N";s:7:"greater";s:1:"B";a:4:{i:0;s:2:"97";i:1;s:2:"15";i:2;s:3:"589";i:3;s:3:"501";}}i:63;a:4:{s:1:"C";s:2:"63";s:2:"WX";s:3:"600";s:1:"N";s:8:"question";s:1:"B";a:4:{i:0;s:3:"183";i:1;s:3:"-14";i:2;s:3:"592";i:3;s:3:"580";}}s:8:"question";a:4:{s:1:"C";s:2:"63";s:2:"WX";s:3:"600";s:1:"N";s:8:"question";s:1:"B";a:4:{i:0;s:3:"183";i:1;s:3:"-14";i:2;s:3:"592";i:3;s:3:"580";}}i:64;a:4:{s:1:"C";s:2:"64";s:2:"WX";s:3:"600";s:1:"N";s:2:"at";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:3:"-15";i:2;s:3:"642";i:3;s:3:"616";}}s:2:"at";a:4:{s:1:"C";s:2:"64";s:2:"WX";s:3:"600";s:1:"N";s:2:"at";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:3:"-15";i:2;s:3:"642";i:3;s:3:"616";}}i:65;a:4:{s:1:"C";s:2:"65";s:2:"WX";s:3:"600";s:1:"N";s:1:"A";s:1:"B";a:4:{i:0;s:2:"-9";i:1;s:1:"0";i:2;s:3:"632";i:3;s:3:"562";}}s:1:"A";a:4:{s:1:"C";s:2:"65";s:2:"WX";s:3:"600";s:1:"N";s:1:"A";s:1:"B";a:4:{i:0;s:2:"-9";i:1;s:1:"0";i:2;s:3:"632";i:3;s:3:"562";}}i:66;a:4:{s:1:"C";s:2:"66";s:2:"WX";s:3:"600";s:1:"N";s:1:"B";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:1:"0";i:2;s:3:"630";i:3;s:3:"562";}}s:1:"B";a:4:{s:1:"C";s:2:"66";s:2:"WX";s:3:"600";s:1:"N";s:1:"B";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:1:"0";i:2;s:3:"630";i:3;s:3:"562";}}i:67;a:4:{s:1:"C";s:2:"67";s:2:"WX";s:3:"600";s:1:"N";s:1:"C";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"-18";i:2;s:3:"675";i:3;s:3:"580";}}s:1:"C";a:4:{s:1:"C";s:2:"67";s:2:"WX";s:3:"600";s:1:"N";s:1:"C";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"-18";i:2;s:3:"675";i:3;s:3:"580";}}i:68;a:4:{s:1:"C";s:2:"68";s:2:"WX";s:3:"600";s:1:"N";s:1:"D";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:1:"0";i:2;s:3:"664";i:3;s:3:"562";}}s:1:"D";a:4:{s:1:"C";s:2:"68";s:2:"WX";s:3:"600";s:1:"N";s:1:"D";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:1:"0";i:2;s:3:"664";i:3;s:3:"562";}}i:69;a:4:{s:1:"C";s:2:"69";s:2:"WX";s:3:"600";s:1:"N";s:1:"E";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"670";i:3;s:3:"562";}}s:1:"E";a:4:{s:1:"C";s:2:"69";s:2:"WX";s:3:"600";s:1:"N";s:1:"E";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"670";i:3;s:3:"562";}}i:70;a:4:{s:1:"C";s:2:"70";s:2:"WX";s:3:"600";s:1:"N";s:1:"F";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:1:"0";i:2;s:3:"684";i:3;s:3:"562";}}s:1:"F";a:4:{s:1:"C";s:2:"70";s:2:"WX";s:3:"600";s:1:"N";s:1:"F";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:1:"0";i:2;s:3:"684";i:3;s:3:"562";}}i:71;a:4:{s:1:"C";s:2:"71";s:2:"WX";s:3:"600";s:1:"N";s:1:"G";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"-18";i:2;s:3:"675";i:3;s:3:"580";}}s:1:"G";a:4:{s:1:"C";s:2:"71";s:2:"WX";s:3:"600";s:1:"N";s:1:"G";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"-18";i:2;s:3:"675";i:3;s:3:"580";}}i:72;a:4:{s:1:"C";s:2:"72";s:2:"WX";s:3:"600";s:1:"N";s:1:"H";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"700";i:3;s:3:"562";}}s:1:"H";a:4:{s:1:"C";s:2:"72";s:2:"WX";s:3:"600";s:1:"N";s:1:"H";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"700";i:3;s:3:"562";}}i:73;a:4:{s:1:"C";s:2:"73";s:2:"WX";s:3:"600";s:1:"N";s:1:"I";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"643";i:3;s:3:"562";}}s:1:"I";a:4:{s:1:"C";s:2:"73";s:2:"WX";s:3:"600";s:1:"N";s:1:"I";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"643";i:3;s:3:"562";}}i:74;a:4:{s:1:"C";s:2:"74";s:2:"WX";s:3:"600";s:1:"N";s:1:"J";s:1:"B";a:4:{i:0;s:2:"58";i:1;s:3:"-18";i:2;s:3:"721";i:3;s:3:"562";}}s:1:"J";a:4:{s:1:"C";s:2:"74";s:2:"WX";s:3:"600";s:1:"N";s:1:"J";s:1:"B";a:4:{i:0;s:2:"58";i:1;s:3:"-18";i:2;s:3:"721";i:3;s:3:"562";}}i:75;a:4:{s:1:"C";s:2:"75";s:2:"WX";s:3:"600";s:1:"N";s:1:"K";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:1:"0";i:2;s:3:"692";i:3;s:3:"562";}}s:1:"K";a:4:{s:1:"C";s:2:"75";s:2:"WX";s:3:"600";s:1:"N";s:1:"K";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:1:"0";i:2;s:3:"692";i:3;s:3:"562";}}i:76;a:4:{s:1:"C";s:2:"76";s:2:"WX";s:3:"600";s:1:"N";s:1:"L";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:1:"0";i:2;s:3:"636";i:3;s:3:"562";}}s:1:"L";a:4:{s:1:"C";s:2:"76";s:2:"WX";s:3:"600";s:1:"N";s:1:"L";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:1:"0";i:2;s:3:"636";i:3;s:3:"562";}}i:77;a:4:{s:1:"C";s:2:"77";s:2:"WX";s:3:"600";s:1:"N";s:1:"M";s:1:"B";a:4:{i:0;s:2:"-2";i:1;s:1:"0";i:2;s:3:"722";i:3;s:3:"562";}}s:1:"M";a:4:{s:1:"C";s:2:"77";s:2:"WX";s:3:"600";s:1:"N";s:1:"M";s:1:"B";a:4:{i:0;s:2:"-2";i:1;s:1:"0";i:2;s:3:"722";i:3;s:3:"562";}}i:78;a:4:{s:1:"C";s:2:"78";s:2:"WX";s:3:"600";s:1:"N";s:1:"N";s:1:"B";a:4:{i:0;s:1:"8";i:1;s:3:"-12";i:2;s:3:"730";i:3;s:3:"562";}}s:1:"N";a:4:{s:1:"C";s:2:"78";s:2:"WX";s:3:"600";s:1:"N";s:1:"N";s:1:"B";a:4:{i:0;s:1:"8";i:1;s:3:"-12";i:2;s:3:"730";i:3;s:3:"562";}}i:79;a:4:{s:1:"C";s:2:"79";s:2:"WX";s:3:"600";s:1:"N";s:1:"O";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"-18";i:2;s:3:"645";i:3;s:3:"580";}}s:1:"O";a:4:{s:1:"C";s:2:"79";s:2:"WX";s:3:"600";s:1:"N";s:1:"O";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"-18";i:2;s:3:"645";i:3;s:3:"580";}}i:80;a:4:{s:1:"C";s:2:"80";s:2:"WX";s:3:"600";s:1:"N";s:1:"P";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:1:"0";i:2;s:3:"643";i:3;s:3:"562";}}s:1:"P";a:4:{s:1:"C";s:2:"80";s:2:"WX";s:3:"600";s:1:"N";s:1:"P";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:1:"0";i:2;s:3:"643";i:3;s:3:"562";}}i:81;a:4:{s:1:"C";s:2:"81";s:2:"WX";s:3:"600";s:1:"N";s:1:"Q";s:1:"B";a:4:{i:0;s:2:"83";i:1;s:4:"-138";i:2;s:3:"636";i:3;s:3:"580";}}s:1:"Q";a:4:{s:1:"C";s:2:"81";s:2:"WX";s:3:"600";s:1:"N";s:1:"Q";s:1:"B";a:4:{i:0;s:2:"83";i:1;s:4:"-138";i:2;s:3:"636";i:3;s:3:"580";}}i:82;a:4:{s:1:"C";s:2:"82";s:2:"WX";s:3:"600";s:1:"N";s:1:"R";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:1:"0";i:2;s:3:"617";i:3;s:3:"562";}}s:1:"R";a:4:{s:1:"C";s:2:"82";s:2:"WX";s:3:"600";s:1:"N";s:1:"R";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:1:"0";i:2;s:3:"617";i:3;s:3:"562";}}i:83;a:4:{s:1:"C";s:2:"83";s:2:"WX";s:3:"600";s:1:"N";s:1:"S";s:1:"B";a:4:{i:0;s:2:"54";i:1;s:3:"-22";i:2;s:3:"673";i:3;s:3:"582";}}s:1:"S";a:4:{s:1:"C";s:2:"83";s:2:"WX";s:3:"600";s:1:"N";s:1:"S";s:1:"B";a:4:{i:0;s:2:"54";i:1;s:3:"-22";i:2;s:3:"673";i:3;s:3:"582";}}i:84;a:4:{s:1:"C";s:2:"84";s:2:"WX";s:3:"600";s:1:"N";s:1:"T";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"679";i:3;s:3:"562";}}s:1:"T";a:4:{s:1:"C";s:2:"84";s:2:"WX";s:3:"600";s:1:"N";s:1:"T";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"679";i:3;s:3:"562";}}i:85;a:4:{s:1:"C";s:2:"85";s:2:"WX";s:3:"600";s:1:"N";s:1:"U";s:1:"B";a:4:{i:0;s:3:"101";i:1;s:3:"-18";i:2;s:3:"716";i:3;s:3:"562";}}s:1:"U";a:4:{s:1:"C";s:2:"85";s:2:"WX";s:3:"600";s:1:"N";s:1:"U";s:1:"B";a:4:{i:0;s:3:"101";i:1;s:3:"-18";i:2;s:3:"716";i:3;s:3:"562";}}i:86;a:4:{s:1:"C";s:2:"86";s:2:"WX";s:3:"600";s:1:"N";s:1:"V";s:1:"B";a:4:{i:0;s:2:"84";i:1;s:1:"0";i:2;s:3:"733";i:3;s:3:"562";}}s:1:"V";a:4:{s:1:"C";s:2:"86";s:2:"WX";s:3:"600";s:1:"N";s:1:"V";s:1:"B";a:4:{i:0;s:2:"84";i:1;s:1:"0";i:2;s:3:"733";i:3;s:3:"562";}}i:87;a:4:{s:1:"C";s:2:"87";s:2:"WX";s:3:"600";s:1:"N";s:1:"W";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:1:"0";i:2;s:3:"738";i:3;s:3:"562";}}s:1:"W";a:4:{s:1:"C";s:2:"87";s:2:"WX";s:3:"600";s:1:"N";s:1:"W";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:1:"0";i:2;s:3:"738";i:3;s:3:"562";}}i:88;a:4:{s:1:"C";s:2:"88";s:2:"WX";s:3:"600";s:1:"N";s:1:"X";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"690";i:3;s:3:"562";}}s:1:"X";a:4:{s:1:"C";s:2:"88";s:2:"WX";s:3:"600";s:1:"N";s:1:"X";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"690";i:3;s:3:"562";}}i:89;a:4:{s:1:"C";s:2:"89";s:2:"WX";s:3:"600";s:1:"N";s:1:"Y";s:1:"B";a:4:{i:0;s:3:"109";i:1;s:1:"0";i:2;s:3:"709";i:3;s:3:"562";}}s:1:"Y";a:4:{s:1:"C";s:2:"89";s:2:"WX";s:3:"600";s:1:"N";s:1:"Y";s:1:"B";a:4:{i:0;s:3:"109";i:1;s:1:"0";i:2;s:3:"709";i:3;s:3:"562";}}i:90;a:4:{s:1:"C";s:2:"90";s:2:"WX";s:3:"600";s:1:"N";s:1:"Z";s:1:"B";a:4:{i:0;s:2:"62";i:1;s:1:"0";i:2;s:3:"637";i:3;s:3:"562";}}s:1:"Z";a:4:{s:1:"C";s:2:"90";s:2:"WX";s:3:"600";s:1:"N";s:1:"Z";s:1:"B";a:4:{i:0;s:2:"62";i:1;s:1:"0";i:2;s:3:"637";i:3;s:3:"562";}}i:91;a:4:{s:1:"C";s:2:"91";s:2:"WX";s:3:"600";s:1:"N";s:11:"bracketleft";s:1:"B";a:4:{i:0;s:3:"223";i:1;s:4:"-102";i:2;s:3:"606";i:3;s:3:"616";}}s:11:"bracketleft";a:4:{s:1:"C";s:2:"91";s:2:"WX";s:3:"600";s:1:"N";s:11:"bracketleft";s:1:"B";a:4:{i:0;s:3:"223";i:1;s:4:"-102";i:2;s:3:"606";i:3;s:3:"616";}}i:92;a:4:{s:1:"C";s:2:"92";s:2:"WX";s:3:"600";s:1:"N";s:9:"backslash";s:1:"B";a:4:{i:0;s:3:"222";i:1;s:3:"-77";i:2;s:3:"496";i:3;s:3:"626";}}s:9:"backslash";a:4:{s:1:"C";s:2:"92";s:2:"WX";s:3:"600";s:1:"N";s:9:"backslash";s:1:"B";a:4:{i:0;s:3:"222";i:1;s:3:"-77";i:2;s:3:"496";i:3;s:3:"626";}}i:93;a:4:{s:1:"C";s:2:"93";s:2:"WX";s:3:"600";s:1:"N";s:12:"bracketright";s:1:"B";a:4:{i:0;s:3:"103";i:1;s:4:"-102";i:2;s:3:"486";i:3;s:3:"616";}}s:12:"bracketright";a:4:{s:1:"C";s:2:"93";s:2:"WX";s:3:"600";s:1:"N";s:12:"bracketright";s:1:"B";a:4:{i:0;s:3:"103";i:1;s:4:"-102";i:2;s:3:"486";i:3;s:3:"616";}}i:94;a:4:{s:1:"C";s:2:"94";s:2:"WX";s:3:"600";s:1:"N";s:11:"asciicircum";s:1:"B";a:4:{i:0;s:3:"171";i:1;s:3:"250";i:2;s:3:"556";i:3;s:3:"616";}}s:11:"asciicircum";a:4:{s:1:"C";s:2:"94";s:2:"WX";s:3:"600";s:1:"N";s:11:"asciicircum";s:1:"B";a:4:{i:0;s:3:"171";i:1;s:3:"250";i:2;s:3:"556";i:3;s:3:"616";}}i:95;a:4:{s:1:"C";s:2:"95";s:2:"WX";s:3:"600";s:1:"N";s:10:"underscore";s:1:"B";a:4:{i:0;s:3:"-27";i:1;s:4:"-125";i:2;s:3:"585";i:3;s:3:"-75";}}s:10:"underscore";a:4:{s:1:"C";s:2:"95";s:2:"WX";s:3:"600";s:1:"N";s:10:"underscore";s:1:"B";a:4:{i:0;s:3:"-27";i:1;s:4:"-125";i:2;s:3:"585";i:3;s:3:"-75";}}i:96;a:4:{s:1:"C";s:2:"96";s:2:"WX";s:3:"600";s:1:"N";s:9:"quoteleft";s:1:"B";a:4:{i:0;s:3:"297";i:1;s:3:"277";i:2;s:3:"487";i:3;s:3:"562";}}s:9:"quoteleft";a:4:{s:1:"C";s:2:"96";s:2:"WX";s:3:"600";s:1:"N";s:9:"quoteleft";s:1:"B";a:4:{i:0;s:3:"297";i:1;s:3:"277";i:2;s:3:"487";i:3;s:3:"562";}}i:97;a:4:{s:1:"C";s:2:"97";s:2:"WX";s:3:"600";s:1:"N";s:1:"a";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:3:"-15";i:2;s:3:"593";i:3;s:3:"454";}}s:1:"a";a:4:{s:1:"C";s:2:"97";s:2:"WX";s:3:"600";s:1:"N";s:1:"a";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:3:"-15";i:2;s:3:"593";i:3;s:3:"454";}}i:98;a:4:{s:1:"C";s:2:"98";s:2:"WX";s:3:"600";s:1:"N";s:1:"b";s:1:"B";a:4:{i:0;s:2:"13";i:1;s:3:"-15";i:2;s:3:"636";i:3;s:3:"626";}}s:1:"b";a:4:{s:1:"C";s:2:"98";s:2:"WX";s:3:"600";s:1:"N";s:1:"b";s:1:"B";a:4:{i:0;s:2:"13";i:1;s:3:"-15";i:2;s:3:"636";i:3;s:3:"626";}}i:99;a:4:{s:1:"C";s:2:"99";s:2:"WX";s:3:"600";s:1:"N";s:1:"c";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:3:"-15";i:2;s:3:"631";i:3;s:3:"459";}}s:1:"c";a:4:{s:1:"C";s:2:"99";s:2:"WX";s:3:"600";s:1:"N";s:1:"c";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:3:"-15";i:2;s:3:"631";i:3;s:3:"459";}}i:100;a:4:{s:1:"C";s:3:"100";s:2:"WX";s:3:"600";s:1:"N";s:1:"d";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:3:"-15";i:2;s:3:"645";i:3;s:3:"626";}}s:1:"d";a:4:{s:1:"C";s:3:"100";s:2:"WX";s:3:"600";s:1:"N";s:1:"d";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:3:"-15";i:2;s:3:"645";i:3;s:3:"626";}}i:101;a:4:{s:1:"C";s:3:"101";s:2:"WX";s:3:"600";s:1:"N";s:1:"e";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:3:"-15";i:2;s:3:"605";i:3;s:3:"454";}}s:1:"e";a:4:{s:1:"C";s:3:"101";s:2:"WX";s:3:"600";s:1:"N";s:1:"e";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:3:"-15";i:2;s:3:"605";i:3;s:3:"454";}}i:102;a:5:{s:1:"C";s:3:"102";s:2:"WX";s:3:"600";s:1:"N";s:1:"f";s:1:"B";a:4:{i:0;s:2:"83";i:1;s:1:"0";i:2;s:3:"677";i:3;s:3:"626";}s:1:"L";a:2:{i:0;s:1:"l";i:1;s:2:"fl";}}s:1:"f";a:5:{s:1:"C";s:3:"102";s:2:"WX";s:3:"600";s:1:"N";s:1:"f";s:1:"B";a:4:{i:0;s:2:"83";i:1;s:1:"0";i:2;s:3:"677";i:3;s:3:"626";}s:1:"L";a:2:{i:0;s:1:"l";i:1;s:2:"fl";}}i:103;a:4:{s:1:"C";s:3:"103";s:2:"WX";s:3:"600";s:1:"N";s:1:"g";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:4:"-146";i:2;s:3:"674";i:3;s:3:"454";}}s:1:"g";a:4:{s:1:"C";s:3:"103";s:2:"WX";s:3:"600";s:1:"N";s:1:"g";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:4:"-146";i:2;s:3:"674";i:3;s:3:"454";}}i:104;a:4:{s:1:"C";s:3:"104";s:2:"WX";s:3:"600";s:1:"N";s:1:"h";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:1:"0";i:2;s:3:"615";i:3;s:3:"626";}}s:1:"h";a:4:{s:1:"C";s:3:"104";s:2:"WX";s:3:"600";s:1:"N";s:1:"h";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:1:"0";i:2;s:3:"615";i:3;s:3:"626";}}i:105;a:4:{s:1:"C";s:3:"105";s:2:"WX";s:3:"600";s:1:"N";s:1:"i";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"546";i:3;s:3:"658";}}s:1:"i";a:4:{s:1:"C";s:3:"105";s:2:"WX";s:3:"600";s:1:"N";s:1:"i";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"546";i:3;s:3:"658";}}i:106;a:4:{s:1:"C";s:3:"106";s:2:"WX";s:3:"600";s:1:"N";s:1:"j";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:4:"-146";i:2;s:3:"580";i:3;s:3:"658";}}s:1:"j";a:4:{s:1:"C";s:3:"106";s:2:"WX";s:3:"600";s:1:"N";s:1:"j";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:4:"-146";i:2;s:3:"580";i:3;s:3:"658";}}i:107;a:4:{s:1:"C";s:3:"107";s:2:"WX";s:3:"600";s:1:"N";s:1:"k";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:1:"0";i:2;s:3:"643";i:3;s:3:"626";}}s:1:"k";a:4:{s:1:"C";s:3:"107";s:2:"WX";s:3:"600";s:1:"N";s:1:"k";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:1:"0";i:2;s:3:"643";i:3;s:3:"626";}}i:108;a:4:{s:1:"C";s:3:"108";s:2:"WX";s:3:"600";s:1:"N";s:1:"l";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"546";i:3;s:3:"626";}}s:1:"l";a:4:{s:1:"C";s:3:"108";s:2:"WX";s:3:"600";s:1:"N";s:1:"l";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"546";i:3;s:3:"626";}}i:109;a:4:{s:1:"C";s:3:"109";s:2:"WX";s:3:"600";s:1:"N";s:1:"m";s:1:"B";a:4:{i:0;s:3:"-22";i:1;s:1:"0";i:2;s:3:"649";i:3;s:3:"454";}}s:1:"m";a:4:{s:1:"C";s:3:"109";s:2:"WX";s:3:"600";s:1:"N";s:1:"m";s:1:"B";a:4:{i:0;s:3:"-22";i:1;s:1:"0";i:2;s:3:"649";i:3;s:3:"454";}}i:110;a:4:{s:1:"C";s:3:"110";s:2:"WX";s:3:"600";s:1:"N";s:1:"n";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:1:"0";i:2;s:3:"615";i:3;s:3:"454";}}s:1:"n";a:4:{s:1:"C";s:3:"110";s:2:"WX";s:3:"600";s:1:"N";s:1:"n";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:1:"0";i:2;s:3:"615";i:3;s:3:"454";}}i:111;a:4:{s:1:"C";s:3:"111";s:2:"WX";s:3:"600";s:1:"N";s:1:"o";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:3:"-15";i:2;s:3:"622";i:3;s:3:"454";}}s:1:"o";a:4:{s:1:"C";s:3:"111";s:2:"WX";s:3:"600";s:1:"N";s:1:"o";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:3:"-15";i:2;s:3:"622";i:3;s:3:"454";}}i:112;a:4:{s:1:"C";s:3:"112";s:2:"WX";s:3:"600";s:1:"N";s:1:"p";s:1:"B";a:4:{i:0;s:3:"-32";i:1;s:4:"-142";i:2;s:3:"622";i:3;s:3:"454";}}s:1:"p";a:4:{s:1:"C";s:3:"112";s:2:"WX";s:3:"600";s:1:"N";s:1:"p";s:1:"B";a:4:{i:0;s:3:"-32";i:1;s:4:"-142";i:2;s:3:"622";i:3;s:3:"454";}}i:113;a:4:{s:1:"C";s:3:"113";s:2:"WX";s:3:"600";s:1:"N";s:1:"q";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:4:"-142";i:2;s:3:"685";i:3;s:3:"454";}}s:1:"q";a:4:{s:1:"C";s:3:"113";s:2:"WX";s:3:"600";s:1:"N";s:1:"q";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:4:"-142";i:2;s:3:"685";i:3;s:3:"454";}}i:114;a:4:{s:1:"C";s:3:"114";s:2:"WX";s:3:"600";s:1:"N";s:1:"r";s:1:"B";a:4:{i:0;s:2:"47";i:1;s:1:"0";i:2;s:3:"655";i:3;s:3:"454";}}s:1:"r";a:4:{s:1:"C";s:3:"114";s:2:"WX";s:3:"600";s:1:"N";s:1:"r";s:1:"B";a:4:{i:0;s:2:"47";i:1;s:1:"0";i:2;s:3:"655";i:3;s:3:"454";}}i:115;a:4:{s:1:"C";s:3:"115";s:2:"WX";s:3:"600";s:1:"N";s:1:"s";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:3:"-17";i:2;s:3:"608";i:3;s:3:"459";}}s:1:"s";a:4:{s:1:"C";s:3:"115";s:2:"WX";s:3:"600";s:1:"N";s:1:"s";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:3:"-17";i:2;s:3:"608";i:3;s:3:"459";}}i:116;a:4:{s:1:"C";s:3:"116";s:2:"WX";s:3:"600";s:1:"N";s:1:"t";s:1:"B";a:4:{i:0;s:3:"118";i:1;s:3:"-15";i:2;s:3:"567";i:3;s:3:"562";}}s:1:"t";a:4:{s:1:"C";s:3:"116";s:2:"WX";s:3:"600";s:1:"N";s:1:"t";s:1:"B";a:4:{i:0;s:3:"118";i:1;s:3:"-15";i:2;s:3:"567";i:3;s:3:"562";}}i:117;a:4:{s:1:"C";s:3:"117";s:2:"WX";s:3:"600";s:1:"N";s:1:"u";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:3:"-15";i:2;s:3:"592";i:3;s:3:"439";}}s:1:"u";a:4:{s:1:"C";s:3:"117";s:2:"WX";s:3:"600";s:1:"N";s:1:"u";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:3:"-15";i:2;s:3:"592";i:3;s:3:"439";}}i:118;a:4:{s:1:"C";s:3:"118";s:2:"WX";s:3:"600";s:1:"N";s:1:"v";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:1:"0";i:2;s:3:"695";i:3;s:3:"439";}}s:1:"v";a:4:{s:1:"C";s:3:"118";s:2:"WX";s:3:"600";s:1:"N";s:1:"v";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:1:"0";i:2;s:3:"695";i:3;s:3:"439";}}i:119;a:4:{s:1:"C";s:3:"119";s:2:"WX";s:3:"600";s:1:"N";s:1:"w";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:1:"0";i:2;s:3:"712";i:3;s:3:"439";}}s:1:"w";a:4:{s:1:"C";s:3:"119";s:2:"WX";s:3:"600";s:1:"N";s:1:"w";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:1:"0";i:2;s:3:"712";i:3;s:3:"439";}}i:120;a:4:{s:1:"C";s:3:"120";s:2:"WX";s:3:"600";s:1:"N";s:1:"x";s:1:"B";a:4:{i:0;s:1:"6";i:1;s:1:"0";i:2;s:3:"671";i:3;s:3:"439";}}s:1:"x";a:4:{s:1:"C";s:3:"120";s:2:"WX";s:3:"600";s:1:"N";s:1:"x";s:1:"B";a:4:{i:0;s:1:"6";i:1;s:1:"0";i:2;s:3:"671";i:3;s:3:"439";}}i:121;a:4:{s:1:"C";s:3:"121";s:2:"WX";s:3:"600";s:1:"N";s:1:"y";s:1:"B";a:4:{i:0;s:3:"-21";i:1;s:4:"-142";i:2;s:3:"695";i:3;s:3:"439";}}s:1:"y";a:4:{s:1:"C";s:3:"121";s:2:"WX";s:3:"600";s:1:"N";s:1:"y";s:1:"B";a:4:{i:0;s:3:"-21";i:1;s:4:"-142";i:2;s:3:"695";i:3;s:3:"439";}}i:122;a:4:{s:1:"C";s:3:"122";s:2:"WX";s:3:"600";s:1:"N";s:1:"z";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:1:"0";i:2;s:3:"614";i:3;s:3:"439";}}s:1:"z";a:4:{s:1:"C";s:3:"122";s:2:"WX";s:3:"600";s:1:"N";s:1:"z";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:1:"0";i:2;s:3:"614";i:3;s:3:"439";}}i:123;a:4:{s:1:"C";s:3:"123";s:2:"WX";s:3:"600";s:1:"N";s:9:"braceleft";s:1:"B";a:4:{i:0;s:3:"203";i:1;s:4:"-102";i:2;s:3:"595";i:3;s:3:"616";}}s:9:"braceleft";a:4:{s:1:"C";s:3:"123";s:2:"WX";s:3:"600";s:1:"N";s:9:"braceleft";s:1:"B";a:4:{i:0;s:3:"203";i:1;s:4:"-102";i:2;s:3:"595";i:3;s:3:"616";}}i:124;a:4:{s:1:"C";s:3:"124";s:2:"WX";s:3:"600";s:1:"N";s:3:"bar";s:1:"B";a:4:{i:0;s:3:"201";i:1;s:4:"-250";i:2;s:3:"505";i:3;s:3:"750";}}s:3:"bar";a:4:{s:1:"C";s:3:"124";s:2:"WX";s:3:"600";s:1:"N";s:3:"bar";s:1:"B";a:4:{i:0;s:3:"201";i:1;s:4:"-250";i:2;s:3:"505";i:3;s:3:"750";}}i:125;a:4:{s:1:"C";s:3:"125";s:2:"WX";s:3:"600";s:1:"N";s:10:"braceright";s:1:"B";a:4:{i:0;s:3:"114";i:1;s:4:"-102";i:2;s:3:"506";i:3;s:3:"616";}}s:10:"braceright";a:4:{s:1:"C";s:3:"125";s:2:"WX";s:3:"600";s:1:"N";s:10:"braceright";s:1:"B";a:4:{i:0;s:3:"114";i:1;s:4:"-102";i:2;s:3:"506";i:3;s:3:"616";}}i:126;a:4:{s:1:"C";s:3:"126";s:2:"WX";s:3:"600";s:1:"N";s:10:"asciitilde";s:1:"B";a:4:{i:0;s:3:"120";i:1;s:3:"153";i:2;s:3:"590";i:3;s:3:"356";}}s:10:"asciitilde";a:4:{s:1:"C";s:3:"126";s:2:"WX";s:3:"600";s:1:"N";s:10:"asciitilde";s:1:"B";a:4:{i:0;s:3:"120";i:1;s:3:"153";i:2;s:3:"590";i:3;s:3:"356";}}i:161;a:4:{s:1:"C";s:3:"161";s:2:"WX";s:3:"600";s:1:"N";s:10:"exclamdown";s:1:"B";a:4:{i:0;s:3:"196";i:1;s:4:"-146";i:2;s:3:"477";i:3;s:3:"449";}}s:10:"exclamdown";a:4:{s:1:"C";s:3:"161";s:2:"WX";s:3:"600";s:1:"N";s:10:"exclamdown";s:1:"B";a:4:{i:0;s:3:"196";i:1;s:4:"-146";i:2;s:3:"477";i:3;s:3:"449";}}i:162;a:4:{s:1:"C";s:3:"162";s:2:"WX";s:3:"600";s:1:"N";s:4:"cent";s:1:"B";a:4:{i:0;s:3:"121";i:1;s:3:"-49";i:2;s:3:"605";i:3;s:3:"614";}}s:4:"cent";a:4:{s:1:"C";s:3:"162";s:2:"WX";s:3:"600";s:1:"N";s:4:"cent";s:1:"B";a:4:{i:0;s:3:"121";i:1;s:3:"-49";i:2;s:3:"605";i:3;s:3:"614";}}i:163;a:4:{s:1:"C";s:3:"163";s:2:"WX";s:3:"600";s:1:"N";s:8:"sterling";s:1:"B";a:4:{i:0;s:3:"106";i:1;s:3:"-28";i:2;s:3:"650";i:3;s:3:"611";}}s:8:"sterling";a:4:{s:1:"C";s:3:"163";s:2:"WX";s:3:"600";s:1:"N";s:8:"sterling";s:1:"B";a:4:{i:0;s:3:"106";i:1;s:3:"-28";i:2;s:3:"650";i:3;s:3:"611";}}i:164;a:4:{s:1:"C";s:3:"164";s:2:"WX";s:3:"600";s:1:"N";s:8:"fraction";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-60";i:2;s:3:"708";i:3;s:3:"661";}}s:8:"fraction";a:4:{s:1:"C";s:3:"164";s:2:"WX";s:3:"600";s:1:"N";s:8:"fraction";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-60";i:2;s:3:"708";i:3;s:3:"661";}}i:165;a:4:{s:1:"C";s:3:"165";s:2:"WX";s:3:"600";s:1:"N";s:3:"yen";s:1:"B";a:4:{i:0;s:2:"98";i:1;s:1:"0";i:2;s:3:"710";i:3;s:3:"562";}}s:3:"yen";a:4:{s:1:"C";s:3:"165";s:2:"WX";s:3:"600";s:1:"N";s:3:"yen";s:1:"B";a:4:{i:0;s:2:"98";i:1;s:1:"0";i:2;s:3:"710";i:3;s:3:"562";}}i:166;a:4:{s:1:"C";s:3:"166";s:2:"WX";s:3:"600";s:1:"N";s:6:"florin";s:1:"B";a:4:{i:0;s:3:"-57";i:1;s:4:"-131";i:2;s:3:"702";i:3;s:3:"616";}}s:6:"florin";a:4:{s:1:"C";s:3:"166";s:2:"WX";s:3:"600";s:1:"N";s:6:"florin";s:1:"B";a:4:{i:0;s:3:"-57";i:1;s:4:"-131";i:2;s:3:"702";i:3;s:3:"616";}}i:167;a:4:{s:1:"C";s:3:"167";s:2:"WX";s:3:"600";s:1:"N";s:7:"section";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"-70";i:2;s:3:"620";i:3;s:3:"580";}}s:7:"section";a:4:{s:1:"C";s:3:"167";s:2:"WX";s:3:"600";s:1:"N";s:7:"section";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"-70";i:2;s:3:"620";i:3;s:3:"580";}}i:168;a:4:{s:1:"C";s:3:"168";s:2:"WX";s:3:"600";s:1:"N";s:8:"currency";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:2:"49";i:2;s:3:"644";i:3;s:3:"517";}}s:8:"currency";a:4:{s:1:"C";s:3:"168";s:2:"WX";s:3:"600";s:1:"N";s:8:"currency";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:2:"49";i:2;s:3:"644";i:3;s:3:"517";}}i:169;a:4:{s:1:"C";s:3:"169";s:2:"WX";s:3:"600";s:1:"N";s:11:"quotesingle";s:1:"B";a:4:{i:0;s:3:"303";i:1;s:3:"277";i:2;s:3:"493";i:3;s:3:"562";}}s:11:"quotesingle";a:4:{s:1:"C";s:3:"169";s:2:"WX";s:3:"600";s:1:"N";s:11:"quotesingle";s:1:"B";a:4:{i:0;s:3:"303";i:1;s:3:"277";i:2;s:3:"493";i:3;s:3:"562";}}i:170;a:4:{s:1:"C";s:3:"170";s:2:"WX";s:3:"600";s:1:"N";s:12:"quotedblleft";s:1:"B";a:4:{i:0;s:3:"190";i:1;s:3:"277";i:2;s:3:"594";i:3;s:3:"562";}}s:12:"quotedblleft";a:4:{s:1:"C";s:3:"170";s:2:"WX";s:3:"600";s:1:"N";s:12:"quotedblleft";s:1:"B";a:4:{i:0;s:3:"190";i:1;s:3:"277";i:2;s:3:"594";i:3;s:3:"562";}}i:171;a:4:{s:1:"C";s:3:"171";s:2:"WX";s:3:"600";s:1:"N";s:13:"guillemotleft";s:1:"B";a:4:{i:0;s:2:"62";i:1;s:2:"70";i:2;s:3:"639";i:3;s:3:"446";}}s:13:"guillemotleft";a:4:{s:1:"C";s:3:"171";s:2:"WX";s:3:"600";s:1:"N";s:13:"guillemotleft";s:1:"B";a:4:{i:0;s:2:"62";i:1;s:2:"70";i:2;s:3:"639";i:3;s:3:"446";}}i:172;a:4:{s:1:"C";s:3:"172";s:2:"WX";s:3:"600";s:1:"N";s:13:"guilsinglleft";s:1:"B";a:4:{i:0;s:3:"195";i:1;s:2:"70";i:2;s:3:"545";i:3;s:3:"446";}}s:13:"guilsinglleft";a:4:{s:1:"C";s:3:"172";s:2:"WX";s:3:"600";s:1:"N";s:13:"guilsinglleft";s:1:"B";a:4:{i:0;s:3:"195";i:1;s:2:"70";i:2;s:3:"545";i:3;s:3:"446";}}i:173;a:4:{s:1:"C";s:3:"173";s:2:"WX";s:3:"600";s:1:"N";s:14:"guilsinglright";s:1:"B";a:4:{i:0;s:3:"165";i:1;s:2:"70";i:2;s:3:"514";i:3;s:3:"446";}}s:14:"guilsinglright";a:4:{s:1:"C";s:3:"173";s:2:"WX";s:3:"600";s:1:"N";s:14:"guilsinglright";s:1:"B";a:4:{i:0;s:3:"165";i:1;s:2:"70";i:2;s:3:"514";i:3;s:3:"446";}}i:174;a:4:{s:1:"C";s:3:"174";s:2:"WX";s:3:"600";s:1:"N";s:2:"fi";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"644";i:3;s:3:"626";}}s:2:"fi";a:4:{s:1:"C";s:3:"174";s:2:"WX";s:3:"600";s:1:"N";s:2:"fi";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"644";i:3;s:3:"626";}}i:175;a:4:{s:1:"C";s:3:"175";s:2:"WX";s:3:"600";s:1:"N";s:2:"fl";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"644";i:3;s:3:"626";}}s:2:"fl";a:4:{s:1:"C";s:3:"175";s:2:"WX";s:3:"600";s:1:"N";s:2:"fl";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"644";i:3;s:3:"626";}}i:177;a:4:{s:1:"C";s:3:"177";s:2:"WX";s:3:"600";s:1:"N";s:6:"endash";s:1:"B";a:4:{i:0;s:3:"108";i:1;s:3:"203";i:2;s:3:"602";i:3;s:3:"313";}}s:6:"endash";a:4:{s:1:"C";s:3:"177";s:2:"WX";s:3:"600";s:1:"N";s:6:"endash";s:1:"B";a:4:{i:0;s:3:"108";i:1;s:3:"203";i:2;s:3:"602";i:3;s:3:"313";}}i:178;a:4:{s:1:"C";s:3:"178";s:2:"WX";s:3:"600";s:1:"N";s:6:"dagger";s:1:"B";a:4:{i:0;s:3:"175";i:1;s:3:"-70";i:2;s:3:"586";i:3;s:3:"580";}}s:6:"dagger";a:4:{s:1:"C";s:3:"178";s:2:"WX";s:3:"600";s:1:"N";s:6:"dagger";s:1:"B";a:4:{i:0;s:3:"175";i:1;s:3:"-70";i:2;s:3:"586";i:3;s:3:"580";}}i:179;a:4:{s:1:"C";s:3:"179";s:2:"WX";s:3:"600";s:1:"N";s:9:"daggerdbl";s:1:"B";a:4:{i:0;s:3:"121";i:1;s:3:"-70";i:2;s:3:"587";i:3;s:3:"580";}}s:9:"daggerdbl";a:4:{s:1:"C";s:3:"179";s:2:"WX";s:3:"600";s:1:"N";s:9:"daggerdbl";s:1:"B";a:4:{i:0;s:3:"121";i:1;s:3:"-70";i:2;s:3:"587";i:3;s:3:"580";}}i:180;a:4:{s:1:"C";s:3:"180";s:2:"WX";s:3:"600";s:1:"N";s:14:"periodcentered";s:1:"B";a:4:{i:0;s:3:"248";i:1;s:3:"165";i:2;s:3:"461";i:3;s:3:"351";}}s:14:"periodcentered";a:4:{s:1:"C";s:3:"180";s:2:"WX";s:3:"600";s:1:"N";s:14:"periodcentered";s:1:"B";a:4:{i:0;s:3:"248";i:1;s:3:"165";i:2;s:3:"461";i:3;s:3:"351";}}i:182;a:4:{s:1:"C";s:3:"182";s:2:"WX";s:3:"600";s:1:"N";s:9:"paragraph";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:3:"-70";i:2;s:3:"700";i:3;s:3:"580";}}s:9:"paragraph";a:4:{s:1:"C";s:3:"182";s:2:"WX";s:3:"600";s:1:"N";s:9:"paragraph";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:3:"-70";i:2;s:3:"700";i:3;s:3:"580";}}i:183;a:4:{s:1:"C";s:3:"183";s:2:"WX";s:3:"600";s:1:"N";s:6:"bullet";s:1:"B";a:4:{i:0;s:3:"196";i:1;s:3:"132";i:2;s:3:"523";i:3;s:3:"430";}}s:6:"bullet";a:4:{s:1:"C";s:3:"183";s:2:"WX";s:3:"600";s:1:"N";s:6:"bullet";s:1:"B";a:4:{i:0;s:3:"196";i:1;s:3:"132";i:2;s:3:"523";i:3;s:3:"430";}}i:184;a:4:{s:1:"C";s:3:"184";s:2:"WX";s:3:"600";s:1:"N";s:14:"quotesinglbase";s:1:"B";a:4:{i:0;s:3:"144";i:1;s:4:"-142";i:2;s:3:"458";i:3;s:3:"143";}}s:14:"quotesinglbase";a:4:{s:1:"C";s:3:"184";s:2:"WX";s:3:"600";s:1:"N";s:14:"quotesinglbase";s:1:"B";a:4:{i:0;s:3:"144";i:1;s:4:"-142";i:2;s:3:"458";i:3;s:3:"143";}}i:185;a:4:{s:1:"C";s:3:"185";s:2:"WX";s:3:"600";s:1:"N";s:12:"quotedblbase";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:4:"-142";i:2;s:3:"560";i:3;s:3:"143";}}s:12:"quotedblbase";a:4:{s:1:"C";s:3:"185";s:2:"WX";s:3:"600";s:1:"N";s:12:"quotedblbase";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:4:"-142";i:2;s:3:"560";i:3;s:3:"143";}}i:186;a:4:{s:1:"C";s:3:"186";s:2:"WX";s:3:"600";s:1:"N";s:13:"quotedblright";s:1:"B";a:4:{i:0;s:3:"119";i:1;s:3:"277";i:2;s:3:"645";i:3;s:3:"562";}}s:13:"quotedblright";a:4:{s:1:"C";s:3:"186";s:2:"WX";s:3:"600";s:1:"N";s:13:"quotedblright";s:1:"B";a:4:{i:0;s:3:"119";i:1;s:3:"277";i:2;s:3:"645";i:3;s:3:"562";}}i:187;a:4:{s:1:"C";s:3:"187";s:2:"WX";s:3:"600";s:1:"N";s:14:"guillemotright";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:2:"70";i:2;s:3:"647";i:3;s:3:"446";}}s:14:"guillemotright";a:4:{s:1:"C";s:3:"187";s:2:"WX";s:3:"600";s:1:"N";s:14:"guillemotright";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:2:"70";i:2;s:3:"647";i:3;s:3:"446";}}i:188;a:4:{s:1:"C";s:3:"188";s:2:"WX";s:3:"600";s:1:"N";s:8:"ellipsis";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-15";i:2;s:3:"587";i:3;s:3:"116";}}s:8:"ellipsis";a:4:{s:1:"C";s:3:"188";s:2:"WX";s:3:"600";s:1:"N";s:8:"ellipsis";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-15";i:2;s:3:"587";i:3;s:3:"116";}}i:189;a:4:{s:1:"C";s:3:"189";s:2:"WX";s:3:"600";s:1:"N";s:11:"perthousand";s:1:"B";a:4:{i:0;s:3:"-45";i:1;s:3:"-15";i:2;s:3:"743";i:3;s:3:"616";}}s:11:"perthousand";a:4:{s:1:"C";s:3:"189";s:2:"WX";s:3:"600";s:1:"N";s:11:"perthousand";s:1:"B";a:4:{i:0;s:3:"-45";i:1;s:3:"-15";i:2;s:3:"743";i:3;s:3:"616";}}i:191;a:4:{s:1:"C";s:3:"191";s:2:"WX";s:3:"600";s:1:"N";s:12:"questiondown";s:1:"B";a:4:{i:0;s:3:"100";i:1;s:4:"-146";i:2;s:3:"509";i:3;s:3:"449";}}s:12:"questiondown";a:4:{s:1:"C";s:3:"191";s:2:"WX";s:3:"600";s:1:"N";s:12:"questiondown";s:1:"B";a:4:{i:0;s:3:"100";i:1;s:4:"-146";i:2;s:3:"509";i:3;s:3:"449";}}i:193;a:4:{s:1:"C";s:3:"193";s:2:"WX";s:3:"600";s:1:"N";s:5:"grave";s:1:"B";a:4:{i:0;s:3:"272";i:1;s:3:"508";i:2;s:3:"503";i:3;s:3:"661";}}s:5:"grave";a:4:{s:1:"C";s:3:"193";s:2:"WX";s:3:"600";s:1:"N";s:5:"grave";s:1:"B";a:4:{i:0;s:3:"272";i:1;s:3:"508";i:2;s:3:"503";i:3;s:3:"661";}}i:194;a:4:{s:1:"C";s:3:"194";s:2:"WX";s:3:"600";s:1:"N";s:5:"acute";s:1:"B";a:4:{i:0;s:3:"312";i:1;s:3:"508";i:2;s:3:"609";i:3;s:3:"661";}}s:5:"acute";a:4:{s:1:"C";s:3:"194";s:2:"WX";s:3:"600";s:1:"N";s:5:"acute";s:1:"B";a:4:{i:0;s:3:"312";i:1;s:3:"508";i:2;s:3:"609";i:3;s:3:"661";}}i:195;a:4:{s:1:"C";s:3:"195";s:2:"WX";s:3:"600";s:1:"N";s:10:"circumflex";s:1:"B";a:4:{i:0;s:3:"212";i:1;s:3:"483";i:2;s:3:"607";i:3;s:3:"657";}}s:10:"circumflex";a:4:{s:1:"C";s:3:"195";s:2:"WX";s:3:"600";s:1:"N";s:10:"circumflex";s:1:"B";a:4:{i:0;s:3:"212";i:1;s:3:"483";i:2;s:3:"607";i:3;s:3:"657";}}i:196;a:4:{s:1:"C";s:3:"196";s:2:"WX";s:3:"600";s:1:"N";s:5:"tilde";s:1:"B";a:4:{i:0;s:3:"199";i:1;s:3:"493";i:2;s:3:"643";i:3;s:3:"636";}}s:5:"tilde";a:4:{s:1:"C";s:3:"196";s:2:"WX";s:3:"600";s:1:"N";s:5:"tilde";s:1:"B";a:4:{i:0;s:3:"199";i:1;s:3:"493";i:2;s:3:"643";i:3;s:3:"636";}}i:197;a:4:{s:1:"C";s:3:"197";s:2:"WX";s:3:"600";s:1:"N";s:6:"macron";s:1:"B";a:4:{i:0;s:3:"195";i:1;s:3:"505";i:2;s:3:"637";i:3;s:3:"585";}}s:6:"macron";a:4:{s:1:"C";s:3:"197";s:2:"WX";s:3:"600";s:1:"N";s:6:"macron";s:1:"B";a:4:{i:0;s:3:"195";i:1;s:3:"505";i:2;s:3:"637";i:3;s:3:"585";}}i:198;a:4:{s:1:"C";s:3:"198";s:2:"WX";s:3:"600";s:1:"N";s:5:"breve";s:1:"B";a:4:{i:0;s:3:"217";i:1;s:3:"468";i:2;s:3:"652";i:3;s:3:"631";}}s:5:"breve";a:4:{s:1:"C";s:3:"198";s:2:"WX";s:3:"600";s:1:"N";s:5:"breve";s:1:"B";a:4:{i:0;s:3:"217";i:1;s:3:"468";i:2;s:3:"652";i:3;s:3:"631";}}i:199;a:4:{s:1:"C";s:3:"199";s:2:"WX";s:3:"600";s:1:"N";s:9:"dotaccent";s:1:"B";a:4:{i:0;s:3:"348";i:1;s:3:"498";i:2;s:3:"493";i:3;s:3:"638";}}s:9:"dotaccent";a:4:{s:1:"C";s:3:"199";s:2:"WX";s:3:"600";s:1:"N";s:9:"dotaccent";s:1:"B";a:4:{i:0;s:3:"348";i:1;s:3:"498";i:2;s:3:"493";i:3;s:3:"638";}}i:200;a:4:{s:1:"C";s:3:"200";s:2:"WX";s:3:"600";s:1:"N";s:8:"dieresis";s:1:"B";a:4:{i:0;s:3:"246";i:1;s:3:"498";i:2;s:3:"595";i:3;s:3:"638";}}s:8:"dieresis";a:4:{s:1:"C";s:3:"200";s:2:"WX";s:3:"600";s:1:"N";s:8:"dieresis";s:1:"B";a:4:{i:0;s:3:"246";i:1;s:3:"498";i:2;s:3:"595";i:3;s:3:"638";}}i:202;a:4:{s:1:"C";s:3:"202";s:2:"WX";s:3:"600";s:1:"N";s:4:"ring";s:1:"B";a:4:{i:0;s:3:"319";i:1;s:3:"481";i:2;s:3:"528";i:3;s:3:"678";}}s:4:"ring";a:4:{s:1:"C";s:3:"202";s:2:"WX";s:3:"600";s:1:"N";s:4:"ring";s:1:"B";a:4:{i:0;s:3:"319";i:1;s:3:"481";i:2;s:3:"528";i:3;s:3:"678";}}i:203;a:4:{s:1:"C";s:3:"203";s:2:"WX";s:3:"600";s:1:"N";s:7:"cedilla";s:1:"B";a:4:{i:0;s:3:"168";i:1;s:4:"-206";i:2;s:3:"368";i:3;s:1:"0";}}s:7:"cedilla";a:4:{s:1:"C";s:3:"203";s:2:"WX";s:3:"600";s:1:"N";s:7:"cedilla";s:1:"B";a:4:{i:0;s:3:"168";i:1;s:4:"-206";i:2;s:3:"368";i:3;s:1:"0";}}i:205;a:4:{s:1:"C";s:3:"205";s:2:"WX";s:3:"600";s:1:"N";s:12:"hungarumlaut";s:1:"B";a:4:{i:0;s:3:"171";i:1;s:3:"488";i:2;s:3:"729";i:3;s:3:"661";}}s:12:"hungarumlaut";a:4:{s:1:"C";s:3:"205";s:2:"WX";s:3:"600";s:1:"N";s:12:"hungarumlaut";s:1:"B";a:4:{i:0;s:3:"171";i:1;s:3:"488";i:2;s:3:"729";i:3;s:3:"661";}}i:206;a:4:{s:1:"C";s:3:"206";s:2:"WX";s:3:"600";s:1:"N";s:6:"ogonek";s:1:"B";a:4:{i:0;s:3:"143";i:1;s:4:"-199";i:2;s:3:"367";i:3;s:1:"0";}}s:6:"ogonek";a:4:{s:1:"C";s:3:"206";s:2:"WX";s:3:"600";s:1:"N";s:6:"ogonek";s:1:"B";a:4:{i:0;s:3:"143";i:1;s:4:"-199";i:2;s:3:"367";i:3;s:1:"0";}}i:207;a:4:{s:1:"C";s:3:"207";s:2:"WX";s:3:"600";s:1:"N";s:5:"caron";s:1:"B";a:4:{i:0;s:3:"238";i:1;s:3:"493";i:2;s:3:"633";i:3;s:3:"667";}}s:5:"caron";a:4:{s:1:"C";s:3:"207";s:2:"WX";s:3:"600";s:1:"N";s:5:"caron";s:1:"B";a:4:{i:0;s:3:"238";i:1;s:3:"493";i:2;s:3:"633";i:3;s:3:"667";}}i:208;a:4:{s:1:"C";s:3:"208";s:2:"WX";s:3:"600";s:1:"N";s:6:"emdash";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:3:"203";i:2;s:3:"677";i:3;s:3:"313";}}s:6:"emdash";a:4:{s:1:"C";s:3:"208";s:2:"WX";s:3:"600";s:1:"N";s:6:"emdash";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:3:"203";i:2;s:3:"677";i:3;s:3:"313";}}i:225;a:4:{s:1:"C";s:3:"225";s:2:"WX";s:3:"600";s:1:"N";s:2:"AE";s:1:"B";a:4:{i:0;s:3:"-29";i:1;s:1:"0";i:2;s:3:"708";i:3;s:3:"562";}}s:2:"AE";a:4:{s:1:"C";s:3:"225";s:2:"WX";s:3:"600";s:1:"N";s:2:"AE";s:1:"B";a:4:{i:0;s:3:"-29";i:1;s:1:"0";i:2;s:3:"708";i:3;s:3:"562";}}i:227;a:4:{s:1:"C";s:3:"227";s:2:"WX";s:3:"600";s:1:"N";s:11:"ordfeminine";s:1:"B";a:4:{i:0;s:3:"188";i:1;s:3:"196";i:2;s:3:"526";i:3;s:3:"580";}}s:11:"ordfeminine";a:4:{s:1:"C";s:3:"227";s:2:"WX";s:3:"600";s:1:"N";s:11:"ordfeminine";s:1:"B";a:4:{i:0;s:3:"188";i:1;s:3:"196";i:2;s:3:"526";i:3;s:3:"580";}}i:232;a:4:{s:1:"C";s:3:"232";s:2:"WX";s:3:"600";s:1:"N";s:6:"Lslash";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:1:"0";i:2;s:3:"636";i:3;s:3:"562";}}s:6:"Lslash";a:4:{s:1:"C";s:3:"232";s:2:"WX";s:3:"600";s:1:"N";s:6:"Lslash";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:1:"0";i:2;s:3:"636";i:3;s:3:"562";}}i:233;a:4:{s:1:"C";s:3:"233";s:2:"WX";s:3:"600";s:1:"N";s:6:"Oslash";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:3:"-22";i:2;s:3:"673";i:3;s:3:"584";}}s:6:"Oslash";a:4:{s:1:"C";s:3:"233";s:2:"WX";s:3:"600";s:1:"N";s:6:"Oslash";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:3:"-22";i:2;s:3:"673";i:3;s:3:"584";}}i:234;a:4:{s:1:"C";s:3:"234";s:2:"WX";s:3:"600";s:1:"N";s:2:"OE";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"701";i:3;s:3:"562";}}s:2:"OE";a:4:{s:1:"C";s:3:"234";s:2:"WX";s:3:"600";s:1:"N";s:2:"OE";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"701";i:3;s:3:"562";}}i:235;a:4:{s:1:"C";s:3:"235";s:2:"WX";s:3:"600";s:1:"N";s:12:"ordmasculine";s:1:"B";a:4:{i:0;s:3:"188";i:1;s:3:"196";i:2;s:3:"543";i:3;s:3:"580";}}s:12:"ordmasculine";a:4:{s:1:"C";s:3:"235";s:2:"WX";s:3:"600";s:1:"N";s:12:"ordmasculine";s:1:"B";a:4:{i:0;s:3:"188";i:1;s:3:"196";i:2;s:3:"543";i:3;s:3:"580";}}i:241;a:4:{s:1:"C";s:3:"241";s:2:"WX";s:3:"600";s:1:"N";s:2:"ae";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:3:"-15";i:2;s:3:"652";i:3;s:3:"454";}}s:2:"ae";a:4:{s:1:"C";s:3:"241";s:2:"WX";s:3:"600";s:1:"N";s:2:"ae";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:3:"-15";i:2;s:3:"652";i:3;s:3:"454";}}i:245;a:4:{s:1:"C";s:3:"245";s:2:"WX";s:3:"600";s:1:"N";s:8:"dotlessi";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"546";i:3;s:3:"439";}}s:8:"dotlessi";a:4:{s:1:"C";s:3:"245";s:2:"WX";s:3:"600";s:1:"N";s:8:"dotlessi";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"546";i:3;s:3:"439";}}i:248;a:4:{s:1:"C";s:3:"248";s:2:"WX";s:3:"600";s:1:"N";s:6:"lslash";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"587";i:3;s:3:"626";}}s:6:"lslash";a:4:{s:1:"C";s:3:"248";s:2:"WX";s:3:"600";s:1:"N";s:6:"lslash";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"587";i:3;s:3:"626";}}i:249;a:4:{s:1:"C";s:3:"249";s:2:"WX";s:3:"600";s:1:"N";s:6:"oslash";s:1:"B";a:4:{i:0;s:2:"54";i:1;s:3:"-24";i:2;s:3:"638";i:3;s:3:"463";}}s:6:"oslash";a:4:{s:1:"C";s:3:"249";s:2:"WX";s:3:"600";s:1:"N";s:6:"oslash";s:1:"B";a:4:{i:0;s:2:"54";i:1;s:3:"-24";i:2;s:3:"638";i:3;s:3:"463";}}i:250;a:4:{s:1:"C";s:3:"250";s:2:"WX";s:3:"600";s:1:"N";s:2:"oe";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:3:"-15";i:2;s:3:"662";i:3;s:3:"454";}}s:2:"oe";a:4:{s:1:"C";s:3:"250";s:2:"WX";s:3:"600";s:1:"N";s:2:"oe";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:3:"-15";i:2;s:3:"662";i:3;s:3:"454";}}i:251;a:4:{s:1:"C";s:3:"251";s:2:"WX";s:3:"600";s:1:"N";s:10:"germandbls";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-15";i:2;s:3:"629";i:3;s:3:"626";}}s:10:"germandbls";a:4:{s:1:"C";s:3:"251";s:2:"WX";s:3:"600";s:1:"N";s:10:"germandbls";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-15";i:2;s:3:"629";i:3;s:3:"626";}}s:9:"Idieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"Idieresis";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"643";i:3;s:3:"761";}}s:6:"eacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"eacute";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:3:"-15";i:2;s:3:"609";i:3;s:3:"661";}}s:6:"abreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"abreve";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:3:"-15";i:2;s:3:"658";i:3;s:3:"661";}}s:13:"uhungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:13:"uhungarumlaut";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:3:"-15";i:2;s:3:"769";i:3;s:3:"661";}}s:6:"ecaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"ecaron";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:3:"-15";i:2;s:3:"633";i:3;s:3:"667";}}s:9:"Ydieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"Ydieresis";s:1:"B";a:4:{i:0;s:3:"109";i:1;s:1:"0";i:2;s:3:"709";i:3;s:3:"761";}}s:6:"divide";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"divide";s:1:"B";a:4:{i:0;s:3:"114";i:1;s:2:"16";i:2;s:3:"596";i:3;s:3:"500";}}s:6:"Yacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Yacute";s:1:"B";a:4:{i:0;s:3:"109";i:1;s:1:"0";i:2;s:3:"709";i:3;s:3:"784";}}s:11:"Acircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"Acircumflex";s:1:"B";a:4:{i:0;s:2:"-9";i:1;s:1:"0";i:2;s:3:"632";i:3;s:3:"780";}}s:6:"aacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"aacute";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:3:"-15";i:2;s:3:"609";i:3;s:3:"661";}}s:11:"Ucircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"Ucircumflex";s:1:"B";a:4:{i:0;s:3:"101";i:1;s:3:"-18";i:2;s:3:"716";i:3;s:3:"780";}}s:6:"yacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"yacute";s:1:"B";a:4:{i:0;s:3:"-21";i:1;s:4:"-142";i:2;s:3:"695";i:3;s:3:"661";}}s:12:"scommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"scommaaccent";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:4:"-250";i:2;s:3:"608";i:3;s:3:"459";}}s:11:"ecircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"ecircumflex";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:3:"-15";i:2;s:3:"607";i:3;s:3:"657";}}s:5:"Uring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:5:"Uring";s:1:"B";a:4:{i:0;s:3:"101";i:1;s:3:"-18";i:2;s:3:"716";i:3;s:3:"801";}}s:9:"Udieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"Udieresis";s:1:"B";a:4:{i:0;s:3:"101";i:1;s:3:"-18";i:2;s:3:"716";i:3;s:3:"761";}}s:7:"aogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"aogonek";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:4:"-199";i:2;s:3:"593";i:3;s:3:"454";}}s:6:"Uacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Uacute";s:1:"B";a:4:{i:0;s:3:"101";i:1;s:3:"-18";i:2;s:3:"716";i:3;s:3:"784";}}s:7:"uogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"uogonek";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:4:"-199";i:2;s:3:"592";i:3;s:3:"439";}}s:9:"Edieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"Edieresis";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"670";i:3;s:3:"761";}}s:6:"Dcroat";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Dcroat";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:1:"0";i:2;s:3:"664";i:3;s:3:"562";}}s:11:"commaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"commaaccent";s:1:"B";a:4:{i:0;s:3:"151";i:1;s:4:"-250";i:2;s:3:"385";i:3;s:3:"-57";}}s:9:"copyright";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"copyright";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:3:"-18";i:2;s:3:"667";i:3;s:3:"580";}}s:7:"Emacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"Emacron";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"670";i:3;s:3:"708";}}s:6:"ccaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"ccaron";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:3:"-15";i:2;s:3:"633";i:3;s:3:"667";}}s:5:"aring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:5:"aring";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:3:"-15";i:2;s:3:"593";i:3;s:3:"678";}}s:12:"Ncommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"Ncommaaccent";s:1:"B";a:4:{i:0;s:1:"8";i:1;s:4:"-250";i:2;s:3:"730";i:3;s:3:"562";}}s:6:"lacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"lacute";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"639";i:3;s:3:"801";}}s:6:"agrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"agrave";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:3:"-15";i:2;s:3:"593";i:3;s:3:"661";}}s:12:"Tcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"Tcommaaccent";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:4:"-250";i:2;s:3:"679";i:3;s:3:"562";}}s:6:"Cacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Cacute";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"-18";i:2;s:3:"675";i:3;s:3:"784";}}s:6:"atilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"atilde";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:3:"-15";i:2;s:3:"643";i:3;s:3:"636";}}s:10:"Edotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:10:"Edotaccent";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"670";i:3;s:3:"761";}}s:6:"scaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"scaron";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:3:"-17";i:2;s:3:"633";i:3;s:3:"667";}}s:8:"scedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:8:"scedilla";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:4:"-206";i:2;s:3:"608";i:3;s:3:"459";}}s:6:"iacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"iacute";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"609";i:3;s:3:"661";}}s:7:"lozenge";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"lozenge";s:1:"B";a:4:{i:0;s:3:"145";i:1;s:1:"0";i:2;s:3:"614";i:3;s:3:"740";}}s:6:"Rcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Rcaron";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:1:"0";i:2;s:3:"659";i:3;s:3:"790";}}s:12:"Gcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"Gcommaaccent";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:4:"-250";i:2;s:3:"675";i:3;s:3:"580";}}s:11:"ucircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"ucircumflex";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:3:"-15";i:2;s:3:"597";i:3;s:3:"657";}}s:11:"acircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"acircumflex";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:3:"-15";i:2;s:3:"607";i:3;s:3:"657";}}s:7:"Amacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"Amacron";s:1:"B";a:4:{i:0;s:2:"-9";i:1;s:1:"0";i:2;s:3:"633";i:3;s:3:"708";}}s:6:"rcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"rcaron";s:1:"B";a:4:{i:0;s:2:"47";i:1;s:1:"0";i:2;s:3:"655";i:3;s:3:"667";}}s:8:"ccedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:8:"ccedilla";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:4:"-206";i:2;s:3:"631";i:3;s:3:"459";}}s:10:"Zdotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:10:"Zdotaccent";s:1:"B";a:4:{i:0;s:2:"62";i:1;s:1:"0";i:2;s:3:"637";i:3;s:3:"761";}}s:5:"Thorn";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:5:"Thorn";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:1:"0";i:2;s:3:"620";i:3;s:3:"562";}}s:7:"Omacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"Omacron";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"-18";i:2;s:3:"663";i:3;s:3:"708";}}s:6:"Racute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Racute";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:1:"0";i:2;s:3:"665";i:3;s:3:"784";}}s:6:"Sacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Sacute";s:1:"B";a:4:{i:0;s:2:"54";i:1;s:3:"-22";i:2;s:3:"673";i:3;s:3:"784";}}s:6:"dcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"dcaron";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:3:"-15";i:2;s:3:"861";i:3;s:3:"626";}}s:7:"Umacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"Umacron";s:1:"B";a:4:{i:0;s:3:"101";i:1;s:3:"-18";i:2;s:3:"716";i:3;s:3:"708";}}s:5:"uring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:5:"uring";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:3:"-15";i:2;s:3:"592";i:3;s:3:"678";}}s:13:"threesuperior";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:13:"threesuperior";s:1:"B";a:4:{i:0;s:3:"193";i:1;s:3:"222";i:2;s:3:"526";i:3;s:3:"616";}}s:6:"Ograve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Ograve";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"-18";i:2;s:3:"645";i:3;s:3:"784";}}s:6:"Agrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Agrave";s:1:"B";a:4:{i:0;s:2:"-9";i:1;s:1:"0";i:2;s:3:"632";i:3;s:3:"784";}}s:6:"Abreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Abreve";s:1:"B";a:4:{i:0;s:2:"-9";i:1;s:1:"0";i:2;s:3:"684";i:3;s:3:"784";}}s:8:"multiply";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:8:"multiply";s:1:"B";a:4:{i:0;s:3:"104";i:1;s:2:"39";i:2;s:3:"606";i:3;s:3:"478";}}s:6:"uacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"uacute";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:3:"-15";i:2;s:3:"599";i:3;s:3:"661";}}s:6:"Tcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Tcaron";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"679";i:3;s:3:"790";}}s:11:"partialdiff";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"partialdiff";s:1:"B";a:4:{i:0;s:2:"91";i:1;s:3:"-38";i:2;s:3:"627";i:3;s:3:"728";}}s:9:"ydieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"ydieresis";s:1:"B";a:4:{i:0;s:3:"-21";i:1;s:4:"-142";i:2;s:3:"695";i:3;s:3:"638";}}s:6:"Nacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Nacute";s:1:"B";a:4:{i:0;s:1:"8";i:1;s:3:"-12";i:2;s:3:"730";i:3;s:3:"784";}}s:11:"icircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"icircumflex";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"577";i:3;s:3:"657";}}s:11:"Ecircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"Ecircumflex";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"670";i:3;s:3:"780";}}s:9:"adieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"adieresis";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:3:"-15";i:2;s:3:"595";i:3;s:3:"638";}}s:9:"edieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"edieresis";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:3:"-15";i:2;s:3:"605";i:3;s:3:"638";}}s:6:"cacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"cacute";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:3:"-15";i:2;s:3:"649";i:3;s:3:"661";}}s:6:"nacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"nacute";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:1:"0";i:2;s:3:"639";i:3;s:3:"661";}}s:7:"umacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"umacron";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:3:"-15";i:2;s:3:"637";i:3;s:3:"585";}}s:6:"Ncaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Ncaron";s:1:"B";a:4:{i:0;s:1:"8";i:1;s:3:"-12";i:2;s:3:"730";i:3;s:3:"790";}}s:6:"Iacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Iacute";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"643";i:3;s:3:"784";}}s:9:"plusminus";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"plusminus";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:2:"24";i:2;s:3:"614";i:3;s:3:"515";}}s:9:"brokenbar";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"brokenbar";s:1:"B";a:4:{i:0;s:3:"217";i:1;s:4:"-175";i:2;s:3:"489";i:3;s:3:"675";}}s:10:"registered";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:10:"registered";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:3:"-18";i:2;s:3:"667";i:3;s:3:"580";}}s:6:"Gbreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Gbreve";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"-18";i:2;s:3:"684";i:3;s:3:"784";}}s:10:"Idotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:10:"Idotaccent";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"643";i:3;s:3:"761";}}s:9:"summation";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"summation";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:3:"-10";i:2;s:3:"672";i:3;s:3:"706";}}s:6:"Egrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Egrave";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"670";i:3;s:3:"784";}}s:6:"racute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"racute";s:1:"B";a:4:{i:0;s:2:"47";i:1;s:1:"0";i:2;s:3:"655";i:3;s:3:"661";}}s:7:"omacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"omacron";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:3:"-15";i:2;s:3:"637";i:3;s:3:"585";}}s:6:"Zacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Zacute";s:1:"B";a:4:{i:0;s:2:"62";i:1;s:1:"0";i:2;s:3:"665";i:3;s:3:"784";}}s:6:"Zcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Zcaron";s:1:"B";a:4:{i:0;s:2:"62";i:1;s:1:"0";i:2;s:3:"659";i:3;s:3:"790";}}s:12:"greaterequal";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"greaterequal";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"627";i:3;s:3:"696";}}s:3:"Eth";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:3:"Eth";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:1:"0";i:2;s:3:"664";i:3;s:3:"562";}}s:8:"Ccedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:8:"Ccedilla";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:4:"-206";i:2;s:3:"675";i:3;s:3:"580";}}s:12:"lcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"lcommaaccent";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:4:"-250";i:2;s:3:"546";i:3;s:3:"626";}}s:6:"tcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"tcaron";s:1:"B";a:4:{i:0;s:3:"118";i:1;s:3:"-15";i:2;s:3:"627";i:3;s:3:"703";}}s:7:"eogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"eogonek";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:4:"-199";i:2;s:3:"605";i:3;s:3:"454";}}s:7:"Uogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"Uogonek";s:1:"B";a:4:{i:0;s:3:"101";i:1;s:4:"-199";i:2;s:3:"716";i:3;s:3:"562";}}s:6:"Aacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Aacute";s:1:"B";a:4:{i:0;s:2:"-9";i:1;s:1:"0";i:2;s:3:"655";i:3;s:3:"784";}}s:9:"Adieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"Adieresis";s:1:"B";a:4:{i:0;s:2:"-9";i:1;s:1:"0";i:2;s:3:"632";i:3;s:3:"761";}}s:6:"egrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"egrave";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:3:"-15";i:2;s:3:"605";i:3;s:3:"661";}}s:6:"zacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"zacute";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:1:"0";i:2;s:3:"614";i:3;s:3:"661";}}s:7:"iogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"iogonek";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:4:"-199";i:2;s:3:"546";i:3;s:3:"658";}}s:6:"Oacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Oacute";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"-18";i:2;s:3:"645";i:3;s:3:"784";}}s:6:"oacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"oacute";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:3:"-15";i:2;s:3:"649";i:3;s:3:"661";}}s:7:"amacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"amacron";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:3:"-15";i:2;s:3:"637";i:3;s:3:"585";}}s:6:"sacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"sacute";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:3:"-17";i:2;s:3:"609";i:3;s:3:"661";}}s:9:"idieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"idieresis";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"561";i:3;s:3:"618";}}s:11:"Ocircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"Ocircumflex";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"-18";i:2;s:3:"645";i:3;s:3:"780";}}s:6:"Ugrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Ugrave";s:1:"B";a:4:{i:0;s:3:"101";i:1;s:3:"-18";i:2;s:3:"716";i:3;s:3:"784";}}s:5:"Delta";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:5:"Delta";s:1:"B";a:4:{i:0;s:1:"6";i:1;s:1:"0";i:2;s:3:"594";i:3;s:3:"688";}}s:5:"thorn";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:5:"thorn";s:1:"B";a:4:{i:0;s:3:"-32";i:1;s:4:"-142";i:2;s:3:"622";i:3;s:3:"626";}}s:11:"twosuperior";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"twosuperior";s:1:"B";a:4:{i:0;s:3:"191";i:1;s:3:"230";i:2;s:3:"542";i:3;s:3:"616";}}s:9:"Odieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"Odieresis";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"-18";i:2;s:3:"645";i:3;s:3:"761";}}s:2:"mu";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:2:"mu";s:1:"B";a:4:{i:0;s:2:"49";i:1;s:4:"-142";i:2;s:3:"592";i:3;s:3:"439";}}s:6:"igrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"igrave";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"546";i:3;s:3:"661";}}s:13:"ohungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:13:"ohungarumlaut";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:3:"-15";i:2;s:3:"809";i:3;s:3:"661";}}s:7:"Eogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"Eogonek";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:4:"-199";i:2;s:3:"670";i:3;s:3:"562";}}s:6:"dcroat";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"dcroat";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:3:"-15";i:2;s:3:"712";i:3;s:3:"626";}}s:13:"threequarters";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:13:"threequarters";s:1:"B";a:4:{i:0;s:1:"8";i:1;s:3:"-60";i:2;s:3:"699";i:3;s:3:"661";}}s:8:"Scedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:8:"Scedilla";s:1:"B";a:4:{i:0;s:2:"54";i:1;s:4:"-206";i:2;s:3:"673";i:3;s:3:"582";}}s:6:"lcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"lcaron";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"731";i:3;s:3:"626";}}s:12:"Kcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"Kcommaaccent";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:4:"-250";i:2;s:3:"692";i:3;s:3:"562";}}s:6:"Lacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Lacute";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:1:"0";i:2;s:3:"636";i:3;s:3:"784";}}s:9:"trademark";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"trademark";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:3:"230";i:2;s:3:"869";i:3;s:3:"562";}}s:10:"edotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:10:"edotaccent";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:3:"-15";i:2;s:3:"605";i:3;s:3:"638";}}s:6:"Igrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Igrave";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"643";i:3;s:3:"784";}}s:7:"Imacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"Imacron";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"663";i:3;s:3:"708";}}s:6:"Lcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Lcaron";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:1:"0";i:2;s:3:"757";i:3;s:3:"562";}}s:7:"onehalf";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"onehalf";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-60";i:2;s:3:"716";i:3;s:3:"661";}}s:9:"lessequal";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"lessequal";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"671";i:3;s:3:"696";}}s:11:"ocircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"ocircumflex";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:3:"-15";i:2;s:3:"622";i:3;s:3:"657";}}s:6:"ntilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"ntilde";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:1:"0";i:2;s:3:"643";i:3;s:3:"636";}}s:13:"Uhungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:13:"Uhungarumlaut";s:1:"B";a:4:{i:0;s:3:"101";i:1;s:3:"-18";i:2;s:3:"805";i:3;s:3:"784";}}s:6:"Eacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Eacute";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"670";i:3;s:3:"784";}}s:7:"emacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"emacron";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:3:"-15";i:2;s:3:"637";i:3;s:3:"585";}}s:6:"gbreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"gbreve";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:4:"-146";i:2;s:3:"674";i:3;s:3:"661";}}s:10:"onequarter";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:10:"onequarter";s:1:"B";a:4:{i:0;s:2:"13";i:1;s:3:"-60";i:2;s:3:"707";i:3;s:3:"661";}}s:6:"Scaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Scaron";s:1:"B";a:4:{i:0;s:2:"54";i:1;s:3:"-22";i:2;s:3:"689";i:3;s:3:"790";}}s:12:"Scommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"Scommaaccent";s:1:"B";a:4:{i:0;s:2:"54";i:1;s:4:"-250";i:2;s:3:"673";i:3;s:3:"582";}}s:13:"Ohungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:13:"Ohungarumlaut";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"-18";i:2;s:3:"795";i:3;s:3:"784";}}s:6:"degree";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"degree";s:1:"B";a:4:{i:0;s:3:"173";i:1;s:3:"243";i:2;s:3:"570";i:3;s:3:"616";}}s:6:"ograve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"ograve";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:3:"-15";i:2;s:3:"622";i:3;s:3:"661";}}s:6:"Ccaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Ccaron";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"-18";i:2;s:3:"689";i:3;s:3:"790";}}s:6:"ugrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"ugrave";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:3:"-15";i:2;s:3:"592";i:3;s:3:"661";}}s:7:"radical";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"radical";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:4:"-104";i:2;s:3:"635";i:3;s:3:"778";}}s:6:"Dcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Dcaron";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:1:"0";i:2;s:3:"664";i:3;s:3:"790";}}s:12:"rcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"rcommaaccent";s:1:"B";a:4:{i:0;s:2:"47";i:1;s:4:"-250";i:2;s:3:"655";i:3;s:3:"454";}}s:6:"Ntilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Ntilde";s:1:"B";a:4:{i:0;s:1:"8";i:1;s:3:"-12";i:2;s:3:"730";i:3;s:3:"759";}}s:6:"otilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"otilde";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:3:"-15";i:2;s:3:"643";i:3;s:3:"636";}}s:12:"Rcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"Rcommaaccent";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:4:"-250";i:2;s:3:"617";i:3;s:3:"562";}}s:12:"Lcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"Lcommaaccent";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:4:"-250";i:2;s:3:"636";i:3;s:3:"562";}}s:6:"Atilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Atilde";s:1:"B";a:4:{i:0;s:2:"-9";i:1;s:1:"0";i:2;s:3:"669";i:3;s:3:"759";}}s:7:"Aogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"Aogonek";s:1:"B";a:4:{i:0;s:2:"-9";i:1;s:4:"-199";i:2;s:3:"632";i:3;s:3:"562";}}s:5:"Aring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:5:"Aring";s:1:"B";a:4:{i:0;s:2:"-9";i:1;s:1:"0";i:2;s:3:"632";i:3;s:3:"801";}}s:6:"Otilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Otilde";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"-18";i:2;s:3:"669";i:3;s:3:"759";}}s:10:"zdotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:10:"zdotaccent";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:1:"0";i:2;s:3:"614";i:3;s:3:"638";}}s:6:"Ecaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Ecaron";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"670";i:3;s:3:"790";}}s:7:"Iogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"Iogonek";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:4:"-199";i:2;s:3:"643";i:3;s:3:"562";}}s:12:"kcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"kcommaaccent";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:4:"-250";i:2;s:3:"643";i:3;s:3:"626";}}s:5:"minus";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:5:"minus";s:1:"B";a:4:{i:0;s:3:"114";i:1;s:3:"203";i:2;s:3:"596";i:3;s:3:"313";}}s:11:"Icircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"Icircumflex";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"643";i:3;s:3:"780";}}s:6:"ncaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"ncaron";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:1:"0";i:2;s:3:"633";i:3;s:3:"667";}}s:12:"tcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"tcommaaccent";s:1:"B";a:4:{i:0;s:3:"118";i:1;s:4:"-250";i:2;s:3:"567";i:3;s:3:"562";}}s:10:"logicalnot";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:10:"logicalnot";s:1:"B";a:4:{i:0;s:3:"135";i:1;s:3:"103";i:2;s:3:"617";i:3;s:3:"413";}}s:9:"odieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"odieresis";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:3:"-15";i:2;s:3:"622";i:3;s:3:"638";}}s:9:"udieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"udieresis";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:3:"-15";i:2;s:3:"595";i:3;s:3:"638";}}s:8:"notequal";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:8:"notequal";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-47";i:2;s:3:"626";i:3;s:3:"563";}}s:12:"gcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"gcommaaccent";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:4:"-146";i:2;s:3:"674";i:3;s:3:"714";}}s:3:"eth";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:3:"eth";s:1:"B";a:4:{i:0;s:2:"93";i:1;s:3:"-27";i:2;s:3:"661";i:3;s:3:"626";}}s:6:"zcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"zcaron";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:1:"0";i:2;s:3:"643";i:3;s:3:"667";}}s:12:"ncommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"ncommaaccent";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:4:"-250";i:2;s:3:"615";i:3;s:3:"454";}}s:11:"onesuperior";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"onesuperior";s:1:"B";a:4:{i:0;s:3:"212";i:1;s:3:"230";i:2;s:3:"514";i:3;s:3:"616";}}s:7:"imacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"imacron";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"575";i:3;s:3:"585";}}s:4:"Euro";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:4:"Euro";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}}s:9:"_version_";i:1;}
\ No newline at end of file
Added: trunk/mapbender/http/classes/fonts/php_Courier-Oblique.afm
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/fonts/php_Courier-Oblique.afm?view=auto&rev=13
--- (empty file)
+++ trunk/mapbender/http/classes/fonts/php_Courier-Oblique.afm 2006-04-13 19:38:28+0000
@@ -0,0 +1 @@
+a:21:{s:8:"FontName";s:15:"Courier-Oblique";s:8:"FullName";s:15:"Courier Oblique";s:10:"FamilyName";s:7:"Courier";s:6:"Weight";s:6:"Medium";s:11:"ItalicAngle";s:3:"-12";s:12:"IsFixedPitch";s:4:"true";s:12:"CharacterSet";s:13:"ExtendedRoman";s:8:"FontBBox";a:4:{i:0;s:3:"-27";i:1;s:4:"-250";i:2;s:3:"849";i:3;s:3:"805";}s:17:"UnderlinePosition";s:4:"-100";s:18:"UnderlineThickness";s:2:"50";s:7:"Version";s:7:"003.000";s:14:"EncodingScheme";s:21:"AdobeStandardEncoding";s:9:"CapHeight";s:3:"562";s:7:"XHeight";s:3:"426";s:8:"Ascender";s:3:"629";s:9:"Descender";s:4:"-157";s:5:"StdHW";s:2:"51";s:5:"StdVW";s:2:"51";s:16:"StartCharMetrics";s:3:"315";s:1:"C";a:464:{i:32;a:4:{s:1:"C";s:2:"32";s:2:"WX";s:3:"600";s:1:"N";s:5:"space";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}s:5:"space";a:4:{s:1:"C";s:2:"32";s:2:"WX";s:3:"600";s:1:"N";s:5:"space";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}i:33;a:4:{s:1:"C";s:2:"33";s:2:"WX";s:3:"600";s:1:"N";s:6:"exclam";s:1:"B";a:4:{i:0;s:3:"243";i:1;s:3:"-15";i:2;s:3:"464";i:3;s:3:"572";}}s:6:"exclam";a:4:{s:1:"C";s:2:"33";s:2:"WX";s:3:"600";s:1:"N";s:6:"exclam";s:1:"B";a:4:{i:0;s:3:"243";i:1;s:3:"-15";i:2;s:3:"464";i:3;s:3:"572";}}i:34;a:4:{s:1:"C";s:2:"34";s:2:"WX";s:3:"600";s:1:"N";s:8:"quotedbl";s:1:"B";a:4:{i:0;s:3:"273";i:1;s:3:"328";i:2;s:3:"532";i:3;s:3:"562";}}s:8:"quotedbl";a:4:{s:1:"C";s:2:"34";s:2:"WX";s:3:"600";s:1:"N";s:8:"quotedbl";s:1:"B";a:4:{i:0;s:3:"273";i:1;s:3:"328";i:2;s:3:"532";i:3;s:3:"562";}}i:35;a:4:{s:1:"C";s:2:"35";s:2:"WX";s:3:"600";s:1:"N";s:10:"numbersign";s:1:"B";a:4:{i:0;s:3:"133";i:1;s:3:"-32";i:2;s:3:"596";i:3;s:3:"639";}}s:10:"numbersign";a:4:{s:1:"C";s:2:"35";s:2:"WX";s:3:"600";s:1:"N";s:10:"numbersign";s:1:"B";a:4:{i:0;s:3:"133";i:1;s:3:"-32";i:2;s:3:"596";i:3;s:3:"639";}}i:36;a:4:{s:1:"C";s:2:"36";s:2:"WX";s:3:"600";s:1:"N";s:6:"dollar";s:1:"B";a:4:{i:0;s:3:"108";i:1;s:4:"-126";i:2;s:3:"596";i:3;s:3:"662";}}s:6:"dollar";a:4:{s:1:"C";s:2:"36";s:2:"WX";s:3:"600";s:1:"N";s:6:"dollar";s:1:"B";a:4:{i:0;s:3:"108";i:1;s:4:"-126";i:2;s:3:"596";i:3;s:3:"662";}}i:37;a:4:{s:1:"C";s:2:"37";s:2:"WX";s:3:"600";s:1:"N";s:7:"percent";s:1:"B";a:4:{i:0;s:3:"134";i:1;s:3:"-15";i:2;s:3:"599";i:3;s:3:"622";}}s:7:"percent";a:4:{s:1:"C";s:2:"37";s:2:"WX";s:3:"600";s:1:"N";s:7:"percent";s:1:"B";a:4:{i:0;s:3:"134";i:1;s:3:"-15";i:2;s:3:"599";i:3;s:3:"622";}}i:38;a:4:{s:1:"C";s:2:"38";s:2:"WX";s:3:"600";s:1:"N";s:9:"ampersand";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:3:"-15";i:2;s:3:"580";i:3;s:3:"543";}}s:9:"ampersand";a:4:{s:1:"C";s:2:"38";s:2:"WX";s:3:"600";s:1:"N";s:9:"ampersand";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:3:"-15";i:2;s:3:"580";i:3;s:3:"543";}}i:39;a:4:{s:1:"C";s:2:"39";s:2:"WX";s:3:"600";s:1:"N";s:10:"quoteright";s:1:"B";a:4:{i:0;s:3:"283";i:1;s:3:"328";i:2;s:3:"495";i:3;s:3:"562";}}s:10:"quoteright";a:4:{s:1:"C";s:2:"39";s:2:"WX";s:3:"600";s:1:"N";s:10:"quoteright";s:1:"B";a:4:{i:0;s:3:"283";i:1;s:3:"328";i:2;s:3:"495";i:3;s:3:"562";}}i:40;a:4:{s:1:"C";s:2:"40";s:2:"WX";s:3:"600";s:1:"N";s:9:"parenleft";s:1:"B";a:4:{i:0;s:3:"313";i:1;s:4:"-108";i:2;s:3:"572";i:3;s:3:"622";}}s:9:"parenleft";a:4:{s:1:"C";s:2:"40";s:2:"WX";s:3:"600";s:1:"N";s:9:"parenleft";s:1:"B";a:4:{i:0;s:3:"313";i:1;s:4:"-108";i:2;s:3:"572";i:3;s:3:"622";}}i:41;a:4:{s:1:"C";s:2:"41";s:2:"WX";s:3:"600";s:1:"N";s:10:"parenright";s:1:"B";a:4:{i:0;s:3:"137";i:1;s:4:"-108";i:2;s:3:"396";i:3;s:3:"622";}}s:10:"parenright";a:4:{s:1:"C";s:2:"41";s:2:"WX";s:3:"600";s:1:"N";s:10:"parenright";s:1:"B";a:4:{i:0;s:3:"137";i:1;s:4:"-108";i:2;s:3:"396";i:3;s:3:"622";}}i:42;a:4:{s:1:"C";s:2:"42";s:2:"WX";s:3:"600";s:1:"N";s:8:"asterisk";s:1:"B";a:4:{i:0;s:3:"212";i:1;s:3:"257";i:2;s:3:"580";i:3;s:3:"607";}}s:8:"asterisk";a:4:{s:1:"C";s:2:"42";s:2:"WX";s:3:"600";s:1:"N";s:8:"asterisk";s:1:"B";a:4:{i:0;s:3:"212";i:1;s:3:"257";i:2;s:3:"580";i:3;s:3:"607";}}i:43;a:4:{s:1:"C";s:2:"43";s:2:"WX";s:3:"600";s:1:"N";s:4:"plus";s:1:"B";a:4:{i:0;s:3:"129";i:1;s:2:"44";i:2;s:3:"580";i:3;s:3:"470";}}s:4:"plus";a:4:{s:1:"C";s:2:"43";s:2:"WX";s:3:"600";s:1:"N";s:4:"plus";s:1:"B";a:4:{i:0;s:3:"129";i:1;s:2:"44";i:2;s:3:"580";i:3;s:3:"470";}}i:44;a:4:{s:1:"C";s:2:"44";s:2:"WX";s:3:"600";s:1:"N";s:5:"comma";s:1:"B";a:4:{i:0;s:3:"157";i:1;s:4:"-112";i:2;s:3:"370";i:3;s:3:"122";}}s:5:"comma";a:4:{s:1:"C";s:2:"44";s:2:"WX";s:3:"600";s:1:"N";s:5:"comma";s:1:"B";a:4:{i:0;s:3:"157";i:1;s:4:"-112";i:2;s:3:"370";i:3;s:3:"122";}}i:45;a:4:{s:1:"C";s:2:"45";s:2:"WX";s:3:"600";s:1:"N";s:6:"hyphen";s:1:"B";a:4:{i:0;s:3:"152";i:1;s:3:"231";i:2;s:3:"558";i:3;s:3:"285";}}s:6:"hyphen";a:4:{s:1:"C";s:2:"45";s:2:"WX";s:3:"600";s:1:"N";s:6:"hyphen";s:1:"B";a:4:{i:0;s:3:"152";i:1;s:3:"231";i:2;s:3:"558";i:3;s:3:"285";}}i:46;a:4:{s:1:"C";s:2:"46";s:2:"WX";s:3:"600";s:1:"N";s:6:"period";s:1:"B";a:4:{i:0;s:3:"238";i:1;s:3:"-15";i:2;s:3:"382";i:3;s:3:"109";}}s:6:"period";a:4:{s:1:"C";s:2:"46";s:2:"WX";s:3:"600";s:1:"N";s:6:"period";s:1:"B";a:4:{i:0;s:3:"238";i:1;s:3:"-15";i:2;s:3:"382";i:3;s:3:"109";}}i:47;a:4:{s:1:"C";s:2:"47";s:2:"WX";s:3:"600";s:1:"N";s:5:"slash";s:1:"B";a:4:{i:0;s:3:"112";i:1;s:3:"-80";i:2;s:3:"604";i:3;s:3:"629";}}s:5:"slash";a:4:{s:1:"C";s:2:"47";s:2:"WX";s:3:"600";s:1:"N";s:5:"slash";s:1:"B";a:4:{i:0;s:3:"112";i:1;s:3:"-80";i:2;s:3:"604";i:3;s:3:"629";}}i:48;a:4:{s:1:"C";s:2:"48";s:2:"WX";s:3:"600";s:1:"N";s:4:"zero";s:1:"B";a:4:{i:0;s:3:"154";i:1;s:3:"-15";i:2;s:3:"575";i:3;s:3:"622";}}s:4:"zero";a:4:{s:1:"C";s:2:"48";s:2:"WX";s:3:"600";s:1:"N";s:4:"zero";s:1:"B";a:4:{i:0;s:3:"154";i:1;s:3:"-15";i:2;s:3:"575";i:3;s:3:"622";}}i:49;a:4:{s:1:"C";s:2:"49";s:2:"WX";s:3:"600";s:1:"N";s:3:"one";s:1:"B";a:4:{i:0;s:2:"98";i:1;s:1:"0";i:2;s:3:"515";i:3;s:3:"622";}}s:3:"one";a:4:{s:1:"C";s:2:"49";s:2:"WX";s:3:"600";s:1:"N";s:3:"one";s:1:"B";a:4:{i:0;s:2:"98";i:1;s:1:"0";i:2;s:3:"515";i:3;s:3:"622";}}i:50;a:4:{s:1:"C";s:2:"50";s:2:"WX";s:3:"600";s:1:"N";s:3:"two";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:1:"0";i:2;s:3:"568";i:3;s:3:"622";}}s:3:"two";a:4:{s:1:"C";s:2:"50";s:2:"WX";s:3:"600";s:1:"N";s:3:"two";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:1:"0";i:2;s:3:"568";i:3;s:3:"622";}}i:51;a:4:{s:1:"C";s:2:"51";s:2:"WX";s:3:"600";s:1:"N";s:5:"three";s:1:"B";a:4:{i:0;s:2:"82";i:1;s:3:"-15";i:2;s:3:"538";i:3;s:3:"622";}}s:5:"three";a:4:{s:1:"C";s:2:"51";s:2:"WX";s:3:"600";s:1:"N";s:5:"three";s:1:"B";a:4:{i:0;s:2:"82";i:1;s:3:"-15";i:2;s:3:"538";i:3;s:3:"622";}}i:52;a:4:{s:1:"C";s:2:"52";s:2:"WX";s:3:"600";s:1:"N";s:4:"four";s:1:"B";a:4:{i:0;s:3:"108";i:1;s:1:"0";i:2;s:3:"541";i:3;s:3:"622";}}s:4:"four";a:4:{s:1:"C";s:2:"52";s:2:"WX";s:3:"600";s:1:"N";s:4:"four";s:1:"B";a:4:{i:0;s:3:"108";i:1;s:1:"0";i:2;s:3:"541";i:3;s:3:"622";}}i:53;a:4:{s:1:"C";s:2:"53";s:2:"WX";s:3:"600";s:1:"N";s:4:"five";s:1:"B";a:4:{i:0;s:2:"99";i:1;s:3:"-15";i:2;s:3:"589";i:3;s:3:"607";}}s:4:"five";a:4:{s:1:"C";s:2:"53";s:2:"WX";s:3:"600";s:1:"N";s:4:"five";s:1:"B";a:4:{i:0;s:2:"99";i:1;s:3:"-15";i:2;s:3:"589";i:3;s:3:"607";}}i:54;a:4:{s:1:"C";s:2:"54";s:2:"WX";s:3:"600";s:1:"N";s:3:"six";s:1:"B";a:4:{i:0;s:3:"155";i:1;s:3:"-15";i:2;s:3:"629";i:3;s:3:"622";}}s:3:"six";a:4:{s:1:"C";s:2:"54";s:2:"WX";s:3:"600";s:1:"N";s:3:"six";s:1:"B";a:4:{i:0;s:3:"155";i:1;s:3:"-15";i:2;s:3:"629";i:3;s:3:"622";}}i:55;a:4:{s:1:"C";s:2:"55";s:2:"WX";s:3:"600";s:1:"N";s:5:"seven";s:1:"B";a:4:{i:0;s:3:"182";i:1;s:1:"0";i:2;s:3:"612";i:3;s:3:"607";}}s:5:"seven";a:4:{s:1:"C";s:2:"55";s:2:"WX";s:3:"600";s:1:"N";s:5:"seven";s:1:"B";a:4:{i:0;s:3:"182";i:1;s:1:"0";i:2;s:3:"612";i:3;s:3:"607";}}i:56;a:4:{s:1:"C";s:2:"56";s:2:"WX";s:3:"600";s:1:"N";s:5:"eight";s:1:"B";a:4:{i:0;s:3:"132";i:1;s:3:"-15";i:2;s:3:"588";i:3;s:3:"622";}}s:5:"eight";a:4:{s:1:"C";s:2:"56";s:2:"WX";s:3:"600";s:1:"N";s:5:"eight";s:1:"B";a:4:{i:0;s:3:"132";i:1;s:3:"-15";i:2;s:3:"588";i:3;s:3:"622";}}i:57;a:4:{s:1:"C";s:2:"57";s:2:"WX";s:3:"600";s:1:"N";s:4:"nine";s:1:"B";a:4:{i:0;s:2:"93";i:1;s:3:"-15";i:2;s:3:"574";i:3;s:3:"622";}}s:4:"nine";a:4:{s:1:"C";s:2:"57";s:2:"WX";s:3:"600";s:1:"N";s:4:"nine";s:1:"B";a:4:{i:0;s:2:"93";i:1;s:3:"-15";i:2;s:3:"574";i:3;s:3:"622";}}i:58;a:4:{s:1:"C";s:2:"58";s:2:"WX";s:3:"600";s:1:"N";s:5:"colon";s:1:"B";a:4:{i:0;s:3:"238";i:1;s:3:"-15";i:2;s:3:"441";i:3;s:3:"385";}}s:5:"colon";a:4:{s:1:"C";s:2:"58";s:2:"WX";s:3:"600";s:1:"N";s:5:"colon";s:1:"B";a:4:{i:0;s:3:"238";i:1;s:3:"-15";i:2;s:3:"441";i:3;s:3:"385";}}i:59;a:4:{s:1:"C";s:2:"59";s:2:"WX";s:3:"600";s:1:"N";s:9:"semicolon";s:1:"B";a:4:{i:0;s:3:"157";i:1;s:4:"-112";i:2;s:3:"441";i:3;s:3:"385";}}s:9:"semicolon";a:4:{s:1:"C";s:2:"59";s:2:"WX";s:3:"600";s:1:"N";s:9:"semicolon";s:1:"B";a:4:{i:0;s:3:"157";i:1;s:4:"-112";i:2;s:3:"441";i:3;s:3:"385";}}i:60;a:4:{s:1:"C";s:2:"60";s:2:"WX";s:3:"600";s:1:"N";s:4:"less";s:1:"B";a:4:{i:0;s:2:"96";i:1;s:2:"42";i:2;s:3:"610";i:3;s:3:"472";}}s:4:"less";a:4:{s:1:"C";s:2:"60";s:2:"WX";s:3:"600";s:1:"N";s:4:"less";s:1:"B";a:4:{i:0;s:2:"96";i:1;s:2:"42";i:2;s:3:"610";i:3;s:3:"472";}}i:61;a:4:{s:1:"C";s:2:"61";s:2:"WX";s:3:"600";s:1:"N";s:5:"equal";s:1:"B";a:4:{i:0;s:3:"109";i:1;s:3:"138";i:2;s:3:"600";i:3;s:3:"376";}}s:5:"equal";a:4:{s:1:"C";s:2:"61";s:2:"WX";s:3:"600";s:1:"N";s:5:"equal";s:1:"B";a:4:{i:0;s:3:"109";i:1;s:3:"138";i:2;s:3:"600";i:3;s:3:"376";}}i:62;a:4:{s:1:"C";s:2:"62";s:2:"WX";s:3:"600";s:1:"N";s:7:"greater";s:1:"B";a:4:{i:0;s:2:"85";i:1;s:2:"42";i:2;s:3:"599";i:3;s:3:"472";}}s:7:"greater";a:4:{s:1:"C";s:2:"62";s:2:"WX";s:3:"600";s:1:"N";s:7:"greater";s:1:"B";a:4:{i:0;s:2:"85";i:1;s:2:"42";i:2;s:3:"599";i:3;s:3:"472";}}i:63;a:4:{s:1:"C";s:2:"63";s:2:"WX";s:3:"600";s:1:"N";s:8:"question";s:1:"B";a:4:{i:0;s:3:"222";i:1;s:3:"-15";i:2;s:3:"583";i:3;s:3:"572";}}s:8:"question";a:4:{s:1:"C";s:2:"63";s:2:"WX";s:3:"600";s:1:"N";s:8:"question";s:1:"B";a:4:{i:0;s:3:"222";i:1;s:3:"-15";i:2;s:3:"583";i:3;s:3:"572";}}i:64;a:4:{s:1:"C";s:2:"64";s:2:"WX";s:3:"600";s:1:"N";s:2:"at";s:1:"B";a:4:{i:0;s:3:"127";i:1;s:3:"-15";i:2;s:3:"582";i:3;s:3:"622";}}s:2:"at";a:4:{s:1:"C";s:2:"64";s:2:"WX";s:3:"600";s:1:"N";s:2:"at";s:1:"B";a:4:{i:0;s:3:"127";i:1;s:3:"-15";i:2;s:3:"582";i:3;s:3:"622";}}i:65;a:4:{s:1:"C";s:2:"65";s:2:"WX";s:3:"600";s:1:"N";s:1:"A";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:1:"0";i:2;s:3:"607";i:3;s:3:"562";}}s:1:"A";a:4:{s:1:"C";s:2:"65";s:2:"WX";s:3:"600";s:1:"N";s:1:"A";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:1:"0";i:2;s:3:"607";i:3;s:3:"562";}}i:66;a:4:{s:1:"C";s:2:"66";s:2:"WX";s:3:"600";s:1:"N";s:1:"B";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:1:"0";i:2;s:3:"616";i:3;s:3:"562";}}s:1:"B";a:4:{s:1:"C";s:2:"66";s:2:"WX";s:3:"600";s:1:"N";s:1:"B";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:1:"0";i:2;s:3:"616";i:3;s:3:"562";}}i:67;a:4:{s:1:"C";s:2:"67";s:2:"WX";s:3:"600";s:1:"N";s:1:"C";s:1:"B";a:4:{i:0;s:2:"93";i:1;s:3:"-18";i:2;s:3:"655";i:3;s:3:"580";}}s:1:"C";a:4:{s:1:"C";s:2:"67";s:2:"WX";s:3:"600";s:1:"N";s:1:"C";s:1:"B";a:4:{i:0;s:2:"93";i:1;s:3:"-18";i:2;s:3:"655";i:3;s:3:"580";}}i:68;a:4:{s:1:"C";s:2:"68";s:2:"WX";s:3:"600";s:1:"N";s:1:"D";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:1:"0";i:2;s:3:"645";i:3;s:3:"562";}}s:1:"D";a:4:{s:1:"C";s:2:"68";s:2:"WX";s:3:"600";s:1:"N";s:1:"D";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:1:"0";i:2;s:3:"645";i:3;s:3:"562";}}i:69;a:4:{s:1:"C";s:2:"69";s:2:"WX";s:3:"600";s:1:"N";s:1:"E";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:1:"0";i:2;s:3:"660";i:3;s:3:"562";}}s:1:"E";a:4:{s:1:"C";s:2:"69";s:2:"WX";s:3:"600";s:1:"N";s:1:"E";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:1:"0";i:2;s:3:"660";i:3;s:3:"562";}}i:70;a:4:{s:1:"C";s:2:"70";s:2:"WX";s:3:"600";s:1:"N";s:1:"F";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:1:"0";i:2;s:3:"660";i:3;s:3:"562";}}s:1:"F";a:4:{s:1:"C";s:2:"70";s:2:"WX";s:3:"600";s:1:"N";s:1:"F";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:1:"0";i:2;s:3:"660";i:3;s:3:"562";}}i:71;a:4:{s:1:"C";s:2:"71";s:2:"WX";s:3:"600";s:1:"N";s:1:"G";s:1:"B";a:4:{i:0;s:2:"83";i:1;s:3:"-18";i:2;s:3:"645";i:3;s:3:"580";}}s:1:"G";a:4:{s:1:"C";s:2:"71";s:2:"WX";s:3:"600";s:1:"N";s:1:"G";s:1:"B";a:4:{i:0;s:2:"83";i:1;s:3:"-18";i:2;s:3:"645";i:3;s:3:"580";}}i:72;a:4:{s:1:"C";s:2:"72";s:2:"WX";s:3:"600";s:1:"N";s:1:"H";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:1:"0";i:2;s:3:"687";i:3;s:3:"562";}}s:1:"H";a:4:{s:1:"C";s:2:"72";s:2:"WX";s:3:"600";s:1:"N";s:1:"H";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:1:"0";i:2;s:3:"687";i:3;s:3:"562";}}i:73;a:4:{s:1:"C";s:2:"73";s:2:"WX";s:3:"600";s:1:"N";s:1:"I";s:1:"B";a:4:{i:0;s:2:"96";i:1;s:1:"0";i:2;s:3:"623";i:3;s:3:"562";}}s:1:"I";a:4:{s:1:"C";s:2:"73";s:2:"WX";s:3:"600";s:1:"N";s:1:"I";s:1:"B";a:4:{i:0;s:2:"96";i:1;s:1:"0";i:2;s:3:"623";i:3;s:3:"562";}}i:74;a:4:{s:1:"C";s:2:"74";s:2:"WX";s:3:"600";s:1:"N";s:1:"J";s:1:"B";a:4:{i:0;s:2:"52";i:1;s:3:"-18";i:2;s:3:"685";i:3;s:3:"562";}}s:1:"J";a:4:{s:1:"C";s:2:"74";s:2:"WX";s:3:"600";s:1:"N";s:1:"J";s:1:"B";a:4:{i:0;s:2:"52";i:1;s:3:"-18";i:2;s:3:"685";i:3;s:3:"562";}}i:75;a:4:{s:1:"C";s:2:"75";s:2:"WX";s:3:"600";s:1:"N";s:1:"K";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:1:"0";i:2;s:3:"671";i:3;s:3:"562";}}s:1:"K";a:4:{s:1:"C";s:2:"75";s:2:"WX";s:3:"600";s:1:"N";s:1:"K";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:1:"0";i:2;s:3:"671";i:3;s:3:"562";}}i:76;a:4:{s:1:"C";s:2:"76";s:2:"WX";s:3:"600";s:1:"N";s:1:"L";s:1:"B";a:4:{i:0;s:2:"47";i:1;s:1:"0";i:2;s:3:"607";i:3;s:3:"562";}}s:1:"L";a:4:{s:1:"C";s:2:"76";s:2:"WX";s:3:"600";s:1:"N";s:1:"L";s:1:"B";a:4:{i:0;s:2:"47";i:1;s:1:"0";i:2;s:3:"607";i:3;s:3:"562";}}i:77;a:4:{s:1:"C";s:2:"77";s:2:"WX";s:3:"600";s:1:"N";s:1:"M";s:1:"B";a:4:{i:0;s:1:"4";i:1;s:1:"0";i:2;s:3:"715";i:3;s:3:"562";}}s:1:"M";a:4:{s:1:"C";s:2:"77";s:2:"WX";s:3:"600";s:1:"N";s:1:"M";s:1:"B";a:4:{i:0;s:1:"4";i:1;s:1:"0";i:2;s:3:"715";i:3;s:3:"562";}}i:78;a:4:{s:1:"C";s:2:"78";s:2:"WX";s:3:"600";s:1:"N";s:1:"N";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:3:"-13";i:2;s:3:"712";i:3;s:3:"562";}}s:1:"N";a:4:{s:1:"C";s:2:"78";s:2:"WX";s:3:"600";s:1:"N";s:1:"N";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:3:"-13";i:2;s:3:"712";i:3;s:3:"562";}}i:79;a:4:{s:1:"C";s:2:"79";s:2:"WX";s:3:"600";s:1:"N";s:1:"O";s:1:"B";a:4:{i:0;s:2:"94";i:1;s:3:"-18";i:2;s:3:"625";i:3;s:3:"580";}}s:1:"O";a:4:{s:1:"C";s:2:"79";s:2:"WX";s:3:"600";s:1:"N";s:1:"O";s:1:"B";a:4:{i:0;s:2:"94";i:1;s:3:"-18";i:2;s:3:"625";i:3;s:3:"580";}}i:80;a:4:{s:1:"C";s:2:"80";s:2:"WX";s:3:"600";s:1:"N";s:1:"P";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:1:"0";i:2;s:3:"644";i:3;s:3:"562";}}s:1:"P";a:4:{s:1:"C";s:2:"80";s:2:"WX";s:3:"600";s:1:"N";s:1:"P";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:1:"0";i:2;s:3:"644";i:3;s:3:"562";}}i:81;a:4:{s:1:"C";s:2:"81";s:2:"WX";s:3:"600";s:1:"N";s:1:"Q";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:4:"-138";i:2;s:3:"625";i:3;s:3:"580";}}s:1:"Q";a:4:{s:1:"C";s:2:"81";s:2:"WX";s:3:"600";s:1:"N";s:1:"Q";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:4:"-138";i:2;s:3:"625";i:3;s:3:"580";}}i:82;a:4:{s:1:"C";s:2:"82";s:2:"WX";s:3:"600";s:1:"N";s:1:"R";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:1:"0";i:2;s:3:"598";i:3;s:3:"562";}}s:1:"R";a:4:{s:1:"C";s:2:"82";s:2:"WX";s:3:"600";s:1:"N";s:1:"R";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:1:"0";i:2;s:3:"598";i:3;s:3:"562";}}i:83;a:4:{s:1:"C";s:2:"83";s:2:"WX";s:3:"600";s:1:"N";s:1:"S";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:3:"-20";i:2;s:3:"650";i:3;s:3:"580";}}s:1:"S";a:4:{s:1:"C";s:2:"83";s:2:"WX";s:3:"600";s:1:"N";s:1:"S";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:3:"-20";i:2;s:3:"650";i:3;s:3:"580";}}i:84;a:4:{s:1:"C";s:2:"84";s:2:"WX";s:3:"600";s:1:"N";s:1:"T";s:1:"B";a:4:{i:0;s:3:"108";i:1;s:1:"0";i:2;s:3:"665";i:3;s:3:"562";}}s:1:"T";a:4:{s:1:"C";s:2:"84";s:2:"WX";s:3:"600";s:1:"N";s:1:"T";s:1:"B";a:4:{i:0;s:3:"108";i:1;s:1:"0";i:2;s:3:"665";i:3;s:3:"562";}}i:85;a:4:{s:1:"C";s:2:"85";s:2:"WX";s:3:"600";s:1:"N";s:1:"U";s:1:"B";a:4:{i:0;s:3:"125";i:1;s:3:"-18";i:2;s:3:"702";i:3;s:3:"562";}}s:1:"U";a:4:{s:1:"C";s:2:"85";s:2:"WX";s:3:"600";s:1:"N";s:1:"U";s:1:"B";a:4:{i:0;s:3:"125";i:1;s:3:"-18";i:2;s:3:"702";i:3;s:3:"562";}}i:86;a:4:{s:1:"C";s:2:"86";s:2:"WX";s:3:"600";s:1:"N";s:1:"V";s:1:"B";a:4:{i:0;s:3:"105";i:1;s:3:"-13";i:2;s:3:"723";i:3;s:3:"562";}}s:1:"V";a:4:{s:1:"C";s:2:"86";s:2:"WX";s:3:"600";s:1:"N";s:1:"V";s:1:"B";a:4:{i:0;s:3:"105";i:1;s:3:"-13";i:2;s:3:"723";i:3;s:3:"562";}}i:87;a:4:{s:1:"C";s:2:"87";s:2:"WX";s:3:"600";s:1:"N";s:1:"W";s:1:"B";a:4:{i:0;s:3:"106";i:1;s:3:"-13";i:2;s:3:"722";i:3;s:3:"562";}}s:1:"W";a:4:{s:1:"C";s:2:"87";s:2:"WX";s:3:"600";s:1:"N";s:1:"W";s:1:"B";a:4:{i:0;s:3:"106";i:1;s:3:"-13";i:2;s:3:"722";i:3;s:3:"562";}}i:88;a:4:{s:1:"C";s:2:"88";s:2:"WX";s:3:"600";s:1:"N";s:1:"X";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:1:"0";i:2;s:3:"675";i:3;s:3:"562";}}s:1:"X";a:4:{s:1:"C";s:2:"88";s:2:"WX";s:3:"600";s:1:"N";s:1:"X";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:1:"0";i:2;s:3:"675";i:3;s:3:"562";}}i:89;a:4:{s:1:"C";s:2:"89";s:2:"WX";s:3:"600";s:1:"N";s:1:"Y";s:1:"B";a:4:{i:0;s:3:"133";i:1;s:1:"0";i:2;s:3:"695";i:3;s:3:"562";}}s:1:"Y";a:4:{s:1:"C";s:2:"89";s:2:"WX";s:3:"600";s:1:"N";s:1:"Y";s:1:"B";a:4:{i:0;s:3:"133";i:1;s:1:"0";i:2;s:3:"695";i:3;s:3:"562";}}i:90;a:4:{s:1:"C";s:2:"90";s:2:"WX";s:3:"600";s:1:"N";s:1:"Z";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"610";i:3;s:3:"562";}}s:1:"Z";a:4:{s:1:"C";s:2:"90";s:2:"WX";s:3:"600";s:1:"N";s:1:"Z";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"610";i:3;s:3:"562";}}i:91;a:4:{s:1:"C";s:2:"91";s:2:"WX";s:3:"600";s:1:"N";s:11:"bracketleft";s:1:"B";a:4:{i:0;s:3:"246";i:1;s:4:"-108";i:2;s:3:"574";i:3;s:3:"622";}}s:11:"bracketleft";a:4:{s:1:"C";s:2:"91";s:2:"WX";s:3:"600";s:1:"N";s:11:"bracketleft";s:1:"B";a:4:{i:0;s:3:"246";i:1;s:4:"-108";i:2;s:3:"574";i:3;s:3:"622";}}i:92;a:4:{s:1:"C";s:2:"92";s:2:"WX";s:3:"600";s:1:"N";s:9:"backslash";s:1:"B";a:4:{i:0;s:3:"249";i:1;s:3:"-80";i:2;s:3:"468";i:3;s:3:"629";}}s:9:"backslash";a:4:{s:1:"C";s:2:"92";s:2:"WX";s:3:"600";s:1:"N";s:9:"backslash";s:1:"B";a:4:{i:0;s:3:"249";i:1;s:3:"-80";i:2;s:3:"468";i:3;s:3:"629";}}i:93;a:4:{s:1:"C";s:2:"93";s:2:"WX";s:3:"600";s:1:"N";s:12:"bracketright";s:1:"B";a:4:{i:0;s:3:"135";i:1;s:4:"-108";i:2;s:3:"463";i:3;s:3:"622";}}s:12:"bracketright";a:4:{s:1:"C";s:2:"93";s:2:"WX";s:3:"600";s:1:"N";s:12:"bracketright";s:1:"B";a:4:{i:0;s:3:"135";i:1;s:4:"-108";i:2;s:3:"463";i:3;s:3:"622";}}i:94;a:4:{s:1:"C";s:2:"94";s:2:"WX";s:3:"600";s:1:"N";s:11:"asciicircum";s:1:"B";a:4:{i:0;s:3:"175";i:1;s:3:"354";i:2;s:3:"587";i:3;s:3:"622";}}s:11:"asciicircum";a:4:{s:1:"C";s:2:"94";s:2:"WX";s:3:"600";s:1:"N";s:11:"asciicircum";s:1:"B";a:4:{i:0;s:3:"175";i:1;s:3:"354";i:2;s:3:"587";i:3;s:3:"622";}}i:95;a:4:{s:1:"C";s:2:"95";s:2:"WX";s:3:"600";s:1:"N";s:10:"underscore";s:1:"B";a:4:{i:0;s:3:"-27";i:1;s:4:"-125";i:2;s:3:"584";i:3;s:3:"-75";}}s:10:"underscore";a:4:{s:1:"C";s:2:"95";s:2:"WX";s:3:"600";s:1:"N";s:10:"underscore";s:1:"B";a:4:{i:0;s:3:"-27";i:1;s:4:"-125";i:2;s:3:"584";i:3;s:3:"-75";}}i:96;a:4:{s:1:"C";s:2:"96";s:2:"WX";s:3:"600";s:1:"N";s:9:"quoteleft";s:1:"B";a:4:{i:0;s:3:"343";i:1;s:3:"328";i:2;s:3:"457";i:3;s:3:"562";}}s:9:"quoteleft";a:4:{s:1:"C";s:2:"96";s:2:"WX";s:3:"600";s:1:"N";s:9:"quoteleft";s:1:"B";a:4:{i:0;s:3:"343";i:1;s:3:"328";i:2;s:3:"457";i:3;s:3:"562";}}i:97;a:4:{s:1:"C";s:2:"97";s:2:"WX";s:3:"600";s:1:"N";s:1:"a";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:3:"-15";i:2;s:3:"569";i:3;s:3:"441";}}s:1:"a";a:4:{s:1:"C";s:2:"97";s:2:"WX";s:3:"600";s:1:"N";s:1:"a";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:3:"-15";i:2;s:3:"569";i:3;s:3:"441";}}i:98;a:4:{s:1:"C";s:2:"98";s:2:"WX";s:3:"600";s:1:"N";s:1:"b";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:3:"-15";i:2;s:3:"625";i:3;s:3:"629";}}s:1:"b";a:4:{s:1:"C";s:2:"98";s:2:"WX";s:3:"600";s:1:"N";s:1:"b";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:3:"-15";i:2;s:3:"625";i:3;s:3:"629";}}i:99;a:4:{s:1:"C";s:2:"99";s:2:"WX";s:3:"600";s:1:"N";s:1:"c";s:1:"B";a:4:{i:0;s:3:"106";i:1;s:3:"-15";i:2;s:3:"608";i:3;s:3:"441";}}s:1:"c";a:4:{s:1:"C";s:2:"99";s:2:"WX";s:3:"600";s:1:"N";s:1:"c";s:1:"B";a:4:{i:0;s:3:"106";i:1;s:3:"-15";i:2;s:3:"608";i:3;s:3:"441";}}i:100;a:4:{s:1:"C";s:3:"100";s:2:"WX";s:3:"600";s:1:"N";s:1:"d";s:1:"B";a:4:{i:0;s:2:"85";i:1;s:3:"-15";i:2;s:3:"640";i:3;s:3:"629";}}s:1:"d";a:4:{s:1:"C";s:3:"100";s:2:"WX";s:3:"600";s:1:"N";s:1:"d";s:1:"B";a:4:{i:0;s:2:"85";i:1;s:3:"-15";i:2;s:3:"640";i:3;s:3:"629";}}i:101;a:4:{s:1:"C";s:3:"101";s:2:"WX";s:3:"600";s:1:"N";s:1:"e";s:1:"B";a:4:{i:0;s:3:"106";i:1;s:3:"-15";i:2;s:3:"598";i:3;s:3:"441";}}s:1:"e";a:4:{s:1:"C";s:3:"101";s:2:"WX";s:3:"600";s:1:"N";s:1:"e";s:1:"B";a:4:{i:0;s:3:"106";i:1;s:3:"-15";i:2;s:3:"598";i:3;s:3:"441";}}i:102;a:5:{s:1:"C";s:3:"102";s:2:"WX";s:3:"600";s:1:"N";s:1:"f";s:1:"B";a:4:{i:0;s:3:"114";i:1;s:1:"0";i:2;s:3:"662";i:3;s:3:"629";}s:1:"L";a:2:{i:0;s:1:"l";i:1;s:2:"fl";}}s:1:"f";a:5:{s:1:"C";s:3:"102";s:2:"WX";s:3:"600";s:1:"N";s:1:"f";s:1:"B";a:4:{i:0;s:3:"114";i:1;s:1:"0";i:2;s:3:"662";i:3;s:3:"629";}s:1:"L";a:2:{i:0;s:1:"l";i:1;s:2:"fl";}}i:103;a:4:{s:1:"C";s:3:"103";s:2:"WX";s:3:"600";s:1:"N";s:1:"g";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:4:"-157";i:2;s:3:"657";i:3;s:3:"441";}}s:1:"g";a:4:{s:1:"C";s:3:"103";s:2:"WX";s:3:"600";s:1:"N";s:1:"g";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:4:"-157";i:2;s:3:"657";i:3;s:3:"441";}}i:104;a:4:{s:1:"C";s:3:"104";s:2:"WX";s:3:"600";s:1:"N";s:1:"h";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:1:"0";i:2;s:3:"592";i:3;s:3:"629";}}s:1:"h";a:4:{s:1:"C";s:3:"104";s:2:"WX";s:3:"600";s:1:"N";s:1:"h";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:1:"0";i:2;s:3:"592";i:3;s:3:"629";}}i:105;a:4:{s:1:"C";s:3:"105";s:2:"WX";s:3:"600";s:1:"N";s:1:"i";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:1:"0";i:2;s:3:"515";i:3;s:3:"657";}}s:1:"i";a:4:{s:1:"C";s:3:"105";s:2:"WX";s:3:"600";s:1:"N";s:1:"i";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:1:"0";i:2;s:3:"515";i:3;s:3:"657";}}i:106;a:4:{s:1:"C";s:3:"106";s:2:"WX";s:3:"600";s:1:"N";s:1:"j";s:1:"B";a:4:{i:0;s:2:"52";i:1;s:4:"-157";i:2;s:3:"550";i:3;s:3:"657";}}s:1:"j";a:4:{s:1:"C";s:3:"106";s:2:"WX";s:3:"600";s:1:"N";s:1:"j";s:1:"B";a:4:{i:0;s:2:"52";i:1;s:4:"-157";i:2;s:3:"550";i:3;s:3:"657";}}i:107;a:4:{s:1:"C";s:3:"107";s:2:"WX";s:3:"600";s:1:"N";s:1:"k";s:1:"B";a:4:{i:0;s:2:"58";i:1;s:1:"0";i:2;s:3:"633";i:3;s:3:"629";}}s:1:"k";a:4:{s:1:"C";s:3:"107";s:2:"WX";s:3:"600";s:1:"N";s:1:"k";s:1:"B";a:4:{i:0;s:2:"58";i:1;s:1:"0";i:2;s:3:"633";i:3;s:3:"629";}}i:108;a:4:{s:1:"C";s:3:"108";s:2:"WX";s:3:"600";s:1:"N";s:1:"l";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:1:"0";i:2;s:3:"515";i:3;s:3:"629";}}s:1:"l";a:4:{s:1:"C";s:3:"108";s:2:"WX";s:3:"600";s:1:"N";s:1:"l";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:1:"0";i:2;s:3:"515";i:3;s:3:"629";}}i:109;a:4:{s:1:"C";s:3:"109";s:2:"WX";s:3:"600";s:1:"N";s:1:"m";s:1:"B";a:4:{i:0;s:2:"-5";i:1;s:1:"0";i:2;s:3:"615";i:3;s:3:"441";}}s:1:"m";a:4:{s:1:"C";s:3:"109";s:2:"WX";s:3:"600";s:1:"N";s:1:"m";s:1:"B";a:4:{i:0;s:2:"-5";i:1;s:1:"0";i:2;s:3:"615";i:3;s:3:"441";}}i:110;a:4:{s:1:"C";s:3:"110";s:2:"WX";s:3:"600";s:1:"N";s:1:"n";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"585";i:3;s:3:"441";}}s:1:"n";a:4:{s:1:"C";s:3:"110";s:2:"WX";s:3:"600";s:1:"N";s:1:"n";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"585";i:3;s:3:"441";}}i:111;a:4:{s:1:"C";s:3:"111";s:2:"WX";s:3:"600";s:1:"N";s:1:"o";s:1:"B";a:4:{i:0;s:3:"102";i:1;s:3:"-15";i:2;s:3:"588";i:3;s:3:"441";}}s:1:"o";a:4:{s:1:"C";s:3:"111";s:2:"WX";s:3:"600";s:1:"N";s:1:"o";s:1:"B";a:4:{i:0;s:3:"102";i:1;s:3:"-15";i:2;s:3:"588";i:3;s:3:"441";}}i:112;a:4:{s:1:"C";s:3:"112";s:2:"WX";s:3:"600";s:1:"N";s:1:"p";s:1:"B";a:4:{i:0;s:3:"-24";i:1;s:4:"-157";i:2;s:3:"605";i:3;s:3:"441";}}s:1:"p";a:4:{s:1:"C";s:3:"112";s:2:"WX";s:3:"600";s:1:"N";s:1:"p";s:1:"B";a:4:{i:0;s:3:"-24";i:1;s:4:"-157";i:2;s:3:"605";i:3;s:3:"441";}}i:113;a:4:{s:1:"C";s:3:"113";s:2:"WX";s:3:"600";s:1:"N";s:1:"q";s:1:"B";a:4:{i:0;s:2:"85";i:1;s:4:"-157";i:2;s:3:"682";i:3;s:3:"441";}}s:1:"q";a:4:{s:1:"C";s:3:"113";s:2:"WX";s:3:"600";s:1:"N";s:1:"q";s:1:"B";a:4:{i:0;s:2:"85";i:1;s:4:"-157";i:2;s:3:"682";i:3;s:3:"441";}}i:114;a:4:{s:1:"C";s:3:"114";s:2:"WX";s:3:"600";s:1:"N";s:1:"r";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:1:"0";i:2;s:3:"636";i:3;s:3:"441";}}s:1:"r";a:4:{s:1:"C";s:3:"114";s:2:"WX";s:3:"600";s:1:"N";s:1:"r";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:1:"0";i:2;s:3:"636";i:3;s:3:"441";}}i:115;a:4:{s:1:"C";s:3:"115";s:2:"WX";s:3:"600";s:1:"N";s:1:"s";s:1:"B";a:4:{i:0;s:2:"78";i:1;s:3:"-15";i:2;s:3:"584";i:3;s:3:"441";}}s:1:"s";a:4:{s:1:"C";s:3:"115";s:2:"WX";s:3:"600";s:1:"N";s:1:"s";s:1:"B";a:4:{i:0;s:2:"78";i:1;s:3:"-15";i:2;s:3:"584";i:3;s:3:"441";}}i:116;a:4:{s:1:"C";s:3:"116";s:2:"WX";s:3:"600";s:1:"N";s:1:"t";s:1:"B";a:4:{i:0;s:3:"167";i:1;s:3:"-15";i:2;s:3:"561";i:3;s:3:"561";}}s:1:"t";a:4:{s:1:"C";s:3:"116";s:2:"WX";s:3:"600";s:1:"N";s:1:"t";s:1:"B";a:4:{i:0;s:3:"167";i:1;s:3:"-15";i:2;s:3:"561";i:3;s:3:"561";}}i:117;a:4:{s:1:"C";s:3:"117";s:2:"WX";s:3:"600";s:1:"N";s:1:"u";s:1:"B";a:4:{i:0;s:3:"101";i:1;s:3:"-15";i:2;s:3:"572";i:3;s:3:"426";}}s:1:"u";a:4:{s:1:"C";s:3:"117";s:2:"WX";s:3:"600";s:1:"N";s:1:"u";s:1:"B";a:4:{i:0;s:3:"101";i:1;s:3:"-15";i:2;s:3:"572";i:3;s:3:"426";}}i:118;a:4:{s:1:"C";s:3:"118";s:2:"WX";s:3:"600";s:1:"N";s:1:"v";s:1:"B";a:4:{i:0;s:2:"90";i:1;s:3:"-10";i:2;s:3:"681";i:3;s:3:"426";}}s:1:"v";a:4:{s:1:"C";s:3:"118";s:2:"WX";s:3:"600";s:1:"N";s:1:"v";s:1:"B";a:4:{i:0;s:2:"90";i:1;s:3:"-10";i:2;s:3:"681";i:3;s:3:"426";}}i:119;a:4:{s:1:"C";s:3:"119";s:2:"WX";s:3:"600";s:1:"N";s:1:"w";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:3:"-10";i:2;s:3:"695";i:3;s:3:"426";}}s:1:"w";a:4:{s:1:"C";s:3:"119";s:2:"WX";s:3:"600";s:1:"N";s:1:"w";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:3:"-10";i:2;s:3:"695";i:3;s:3:"426";}}i:120;a:4:{s:1:"C";s:3:"120";s:2:"WX";s:3:"600";s:1:"N";s:1:"x";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"655";i:3;s:3:"426";}}s:1:"x";a:4:{s:1:"C";s:3:"120";s:2:"WX";s:3:"600";s:1:"N";s:1:"x";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"655";i:3;s:3:"426";}}i:121;a:4:{s:1:"C";s:3:"121";s:2:"WX";s:3:"600";s:1:"N";s:1:"y";s:1:"B";a:4:{i:0;s:2:"-4";i:1;s:4:"-157";i:2;s:3:"683";i:3;s:3:"426";}}s:1:"y";a:4:{s:1:"C";s:3:"121";s:2:"WX";s:3:"600";s:1:"N";s:1:"y";s:1:"B";a:4:{i:0;s:2:"-4";i:1;s:4:"-157";i:2;s:3:"683";i:3;s:3:"426";}}i:122;a:4:{s:1:"C";s:3:"122";s:2:"WX";s:3:"600";s:1:"N";s:1:"z";s:1:"B";a:4:{i:0;s:2:"99";i:1;s:1:"0";i:2;s:3:"593";i:3;s:3:"426";}}s:1:"z";a:4:{s:1:"C";s:3:"122";s:2:"WX";s:3:"600";s:1:"N";s:1:"z";s:1:"B";a:4:{i:0;s:2:"99";i:1;s:1:"0";i:2;s:3:"593";i:3;s:3:"426";}}i:123;a:4:{s:1:"C";s:3:"123";s:2:"WX";s:3:"600";s:1:"N";s:9:"braceleft";s:1:"B";a:4:{i:0;s:3:"233";i:1;s:4:"-108";i:2;s:3:"569";i:3;s:3:"622";}}s:9:"braceleft";a:4:{s:1:"C";s:3:"123";s:2:"WX";s:3:"600";s:1:"N";s:9:"braceleft";s:1:"B";a:4:{i:0;s:3:"233";i:1;s:4:"-108";i:2;s:3:"569";i:3;s:3:"622";}}i:124;a:4:{s:1:"C";s:3:"124";s:2:"WX";s:3:"600";s:1:"N";s:3:"bar";s:1:"B";a:4:{i:0;s:3:"222";i:1;s:4:"-250";i:2;s:3:"485";i:3;s:3:"750";}}s:3:"bar";a:4:{s:1:"C";s:3:"124";s:2:"WX";s:3:"600";s:1:"N";s:3:"bar";s:1:"B";a:4:{i:0;s:3:"222";i:1;s:4:"-250";i:2;s:3:"485";i:3;s:3:"750";}}i:125;a:4:{s:1:"C";s:3:"125";s:2:"WX";s:3:"600";s:1:"N";s:10:"braceright";s:1:"B";a:4:{i:0;s:3:"140";i:1;s:4:"-108";i:2;s:3:"477";i:3;s:3:"622";}}s:10:"braceright";a:4:{s:1:"C";s:3:"125";s:2:"WX";s:3:"600";s:1:"N";s:10:"braceright";s:1:"B";a:4:{i:0;s:3:"140";i:1;s:4:"-108";i:2;s:3:"477";i:3;s:3:"622";}}i:126;a:4:{s:1:"C";s:3:"126";s:2:"WX";s:3:"600";s:1:"N";s:10:"asciitilde";s:1:"B";a:4:{i:0;s:3:"116";i:1;s:3:"197";i:2;s:3:"600";i:3;s:3:"320";}}s:10:"asciitilde";a:4:{s:1:"C";s:3:"126";s:2:"WX";s:3:"600";s:1:"N";s:10:"asciitilde";s:1:"B";a:4:{i:0;s:3:"116";i:1;s:3:"197";i:2;s:3:"600";i:3;s:3:"320";}}i:161;a:4:{s:1:"C";s:3:"161";s:2:"WX";s:3:"600";s:1:"N";s:10:"exclamdown";s:1:"B";a:4:{i:0;s:3:"225";i:1;s:4:"-157";i:2;s:3:"445";i:3;s:3:"430";}}s:10:"exclamdown";a:4:{s:1:"C";s:3:"161";s:2:"WX";s:3:"600";s:1:"N";s:10:"exclamdown";s:1:"B";a:4:{i:0;s:3:"225";i:1;s:4:"-157";i:2;s:3:"445";i:3;s:3:"430";}}i:162;a:4:{s:1:"C";s:3:"162";s:2:"WX";s:3:"600";s:1:"N";s:4:"cent";s:1:"B";a:4:{i:0;s:3:"151";i:1;s:3:"-49";i:2;s:3:"588";i:3;s:3:"614";}}s:4:"cent";a:4:{s:1:"C";s:3:"162";s:2:"WX";s:3:"600";s:1:"N";s:4:"cent";s:1:"B";a:4:{i:0;s:3:"151";i:1;s:3:"-49";i:2;s:3:"588";i:3;s:3:"614";}}i:163;a:4:{s:1:"C";s:3:"163";s:2:"WX";s:3:"600";s:1:"N";s:8:"sterling";s:1:"B";a:4:{i:0;s:3:"124";i:1;s:3:"-21";i:2;s:3:"621";i:3;s:3:"611";}}s:8:"sterling";a:4:{s:1:"C";s:3:"163";s:2:"WX";s:3:"600";s:1:"N";s:8:"sterling";s:1:"B";a:4:{i:0;s:3:"124";i:1;s:3:"-21";i:2;s:3:"621";i:3;s:3:"611";}}i:164;a:4:{s:1:"C";s:3:"164";s:2:"WX";s:3:"600";s:1:"N";s:8:"fraction";s:1:"B";a:4:{i:0;s:2:"84";i:1;s:3:"-57";i:2;s:3:"646";i:3;s:3:"665";}}s:8:"fraction";a:4:{s:1:"C";s:3:"164";s:2:"WX";s:3:"600";s:1:"N";s:8:"fraction";s:1:"B";a:4:{i:0;s:2:"84";i:1;s:3:"-57";i:2;s:3:"646";i:3;s:3:"665";}}i:165;a:4:{s:1:"C";s:3:"165";s:2:"WX";s:3:"600";s:1:"N";s:3:"yen";s:1:"B";a:4:{i:0;s:3:"120";i:1;s:1:"0";i:2;s:3:"693";i:3;s:3:"562";}}s:3:"yen";a:4:{s:1:"C";s:3:"165";s:2:"WX";s:3:"600";s:1:"N";s:3:"yen";s:1:"B";a:4:{i:0;s:3:"120";i:1;s:1:"0";i:2;s:3:"693";i:3;s:3:"562";}}i:166;a:4:{s:1:"C";s:3:"166";s:2:"WX";s:3:"600";s:1:"N";s:6:"florin";s:1:"B";a:4:{i:0;s:3:"-26";i:1;s:4:"-143";i:2;s:3:"671";i:3;s:3:"622";}}s:6:"florin";a:4:{s:1:"C";s:3:"166";s:2:"WX";s:3:"600";s:1:"N";s:6:"florin";s:1:"B";a:4:{i:0;s:3:"-26";i:1;s:4:"-143";i:2;s:3:"671";i:3;s:3:"622";}}i:167;a:4:{s:1:"C";s:3:"167";s:2:"WX";s:3:"600";s:1:"N";s:7:"section";s:1:"B";a:4:{i:0;s:3:"104";i:1;s:3:"-78";i:2;s:3:"590";i:3;s:3:"580";}}s:7:"section";a:4:{s:1:"C";s:3:"167";s:2:"WX";s:3:"600";s:1:"N";s:7:"section";s:1:"B";a:4:{i:0;s:3:"104";i:1;s:3:"-78";i:2;s:3:"590";i:3;s:3:"580";}}i:168;a:4:{s:1:"C";s:3:"168";s:2:"WX";s:3:"600";s:1:"N";s:8:"currency";s:1:"B";a:4:{i:0;s:2:"94";i:1;s:2:"58";i:2;s:3:"628";i:3;s:3:"506";}}s:8:"currency";a:4:{s:1:"C";s:3:"168";s:2:"WX";s:3:"600";s:1:"N";s:8:"currency";s:1:"B";a:4:{i:0;s:2:"94";i:1;s:2:"58";i:2;s:3:"628";i:3;s:3:"506";}}i:169;a:4:{s:1:"C";s:3:"169";s:2:"WX";s:3:"600";s:1:"N";s:11:"quotesingle";s:1:"B";a:4:{i:0;s:3:"345";i:1;s:3:"328";i:2;s:3:"460";i:3;s:3:"562";}}s:11:"quotesingle";a:4:{s:1:"C";s:3:"169";s:2:"WX";s:3:"600";s:1:"N";s:11:"quotesingle";s:1:"B";a:4:{i:0;s:3:"345";i:1;s:3:"328";i:2;s:3:"460";i:3;s:3:"562";}}i:170;a:4:{s:1:"C";s:3:"170";s:2:"WX";s:3:"600";s:1:"N";s:12:"quotedblleft";s:1:"B";a:4:{i:0;s:3:"262";i:1;s:3:"328";i:2;s:3:"541";i:3;s:3:"562";}}s:12:"quotedblleft";a:4:{s:1:"C";s:3:"170";s:2:"WX";s:3:"600";s:1:"N";s:12:"quotedblleft";s:1:"B";a:4:{i:0;s:3:"262";i:1;s:3:"328";i:2;s:3:"541";i:3;s:3:"562";}}i:171;a:4:{s:1:"C";s:3:"171";s:2:"WX";s:3:"600";s:1:"N";s:13:"guillemotleft";s:1:"B";a:4:{i:0;s:2:"92";i:1;s:2:"70";i:2;s:3:"652";i:3;s:3:"446";}}s:13:"guillemotleft";a:4:{s:1:"C";s:3:"171";s:2:"WX";s:3:"600";s:1:"N";s:13:"guillemotleft";s:1:"B";a:4:{i:0;s:2:"92";i:1;s:2:"70";i:2;s:3:"652";i:3;s:3:"446";}}i:172;a:4:{s:1:"C";s:3:"172";s:2:"WX";s:3:"600";s:1:"N";s:13:"guilsinglleft";s:1:"B";a:4:{i:0;s:3:"204";i:1;s:2:"70";i:2;s:3:"540";i:3;s:3:"446";}}s:13:"guilsinglleft";a:4:{s:1:"C";s:3:"172";s:2:"WX";s:3:"600";s:1:"N";s:13:"guilsinglleft";s:1:"B";a:4:{i:0;s:3:"204";i:1;s:2:"70";i:2;s:3:"540";i:3;s:3:"446";}}i:173;a:4:{s:1:"C";s:3:"173";s:2:"WX";s:3:"600";s:1:"N";s:14:"guilsinglright";s:1:"B";a:4:{i:0;s:3:"170";i:1;s:2:"70";i:2;s:3:"506";i:3;s:3:"446";}}s:14:"guilsinglright";a:4:{s:1:"C";s:3:"173";s:2:"WX";s:3:"600";s:1:"N";s:14:"guilsinglright";s:1:"B";a:4:{i:0;s:3:"170";i:1;s:2:"70";i:2;s:3:"506";i:3;s:3:"446";}}i:174;a:4:{s:1:"C";s:3:"174";s:2:"WX";s:3:"600";s:1:"N";s:2:"fi";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:1:"0";i:2;s:3:"619";i:3;s:3:"629";}}s:2:"fi";a:4:{s:1:"C";s:3:"174";s:2:"WX";s:3:"600";s:1:"N";s:2:"fi";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:1:"0";i:2;s:3:"619";i:3;s:3:"629";}}i:175;a:4:{s:1:"C";s:3:"175";s:2:"WX";s:3:"600";s:1:"N";s:2:"fl";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:1:"0";i:2;s:3:"619";i:3;s:3:"629";}}s:2:"fl";a:4:{s:1:"C";s:3:"175";s:2:"WX";s:3:"600";s:1:"N";s:2:"fl";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:1:"0";i:2;s:3:"619";i:3;s:3:"629";}}i:177;a:4:{s:1:"C";s:3:"177";s:2:"WX";s:3:"600";s:1:"N";s:6:"endash";s:1:"B";a:4:{i:0;s:3:"124";i:1;s:3:"231";i:2;s:3:"586";i:3;s:3:"285";}}s:6:"endash";a:4:{s:1:"C";s:3:"177";s:2:"WX";s:3:"600";s:1:"N";s:6:"endash";s:1:"B";a:4:{i:0;s:3:"124";i:1;s:3:"231";i:2;s:3:"586";i:3;s:3:"285";}}i:178;a:4:{s:1:"C";s:3:"178";s:2:"WX";s:3:"600";s:1:"N";s:6:"dagger";s:1:"B";a:4:{i:0;s:3:"217";i:1;s:3:"-78";i:2;s:3:"546";i:3;s:3:"580";}}s:6:"dagger";a:4:{s:1:"C";s:3:"178";s:2:"WX";s:3:"600";s:1:"N";s:6:"dagger";s:1:"B";a:4:{i:0;s:3:"217";i:1;s:3:"-78";i:2;s:3:"546";i:3;s:3:"580";}}i:179;a:4:{s:1:"C";s:3:"179";s:2:"WX";s:3:"600";s:1:"N";s:9:"daggerdbl";s:1:"B";a:4:{i:0;s:3:"163";i:1;s:3:"-78";i:2;s:3:"546";i:3;s:3:"580";}}s:9:"daggerdbl";a:4:{s:1:"C";s:3:"179";s:2:"WX";s:3:"600";s:1:"N";s:9:"daggerdbl";s:1:"B";a:4:{i:0;s:3:"163";i:1;s:3:"-78";i:2;s:3:"546";i:3;s:3:"580";}}i:180;a:4:{s:1:"C";s:3:"180";s:2:"WX";s:3:"600";s:1:"N";s:14:"periodcentered";s:1:"B";a:4:{i:0;s:3:"275";i:1;s:3:"189";i:2;s:3:"434";i:3;s:3:"327";}}s:14:"periodcentered";a:4:{s:1:"C";s:3:"180";s:2:"WX";s:3:"600";s:1:"N";s:14:"periodcentered";s:1:"B";a:4:{i:0;s:3:"275";i:1;s:3:"189";i:2;s:3:"434";i:3;s:3:"327";}}i:182;a:4:{s:1:"C";s:3:"182";s:2:"WX";s:3:"600";s:1:"N";s:9:"paragraph";s:1:"B";a:4:{i:0;s:3:"100";i:1;s:3:"-78";i:2;s:3:"630";i:3;s:3:"562";}}s:9:"paragraph";a:4:{s:1:"C";s:3:"182";s:2:"WX";s:3:"600";s:1:"N";s:9:"paragraph";s:1:"B";a:4:{i:0;s:3:"100";i:1;s:3:"-78";i:2;s:3:"630";i:3;s:3:"562";}}i:183;a:4:{s:1:"C";s:3:"183";s:2:"WX";s:3:"600";s:1:"N";s:6:"bullet";s:1:"B";a:4:{i:0;s:3:"224";i:1;s:3:"130";i:2;s:3:"485";i:3;s:3:"383";}}s:6:"bullet";a:4:{s:1:"C";s:3:"183";s:2:"WX";s:3:"600";s:1:"N";s:6:"bullet";s:1:"B";a:4:{i:0;s:3:"224";i:1;s:3:"130";i:2;s:3:"485";i:3;s:3:"383";}}i:184;a:4:{s:1:"C";s:3:"184";s:2:"WX";s:3:"600";s:1:"N";s:14:"quotesinglbase";s:1:"B";a:4:{i:0;s:3:"185";i:1;s:4:"-134";i:2;s:3:"397";i:3;s:3:"100";}}s:14:"quotesinglbase";a:4:{s:1:"C";s:3:"184";s:2:"WX";s:3:"600";s:1:"N";s:14:"quotesinglbase";s:1:"B";a:4:{i:0;s:3:"185";i:1;s:4:"-134";i:2;s:3:"397";i:3;s:3:"100";}}i:185;a:4:{s:1:"C";s:3:"185";s:2:"WX";s:3:"600";s:1:"N";s:12:"quotedblbase";s:1:"B";a:4:{i:0;s:3:"115";i:1;s:4:"-134";i:2;s:3:"478";i:3;s:3:"100";}}s:12:"quotedblbase";a:4:{s:1:"C";s:3:"185";s:2:"WX";s:3:"600";s:1:"N";s:12:"quotedblbase";s:1:"B";a:4:{i:0;s:3:"115";i:1;s:4:"-134";i:2;s:3:"478";i:3;s:3:"100";}}i:186;a:4:{s:1:"C";s:3:"186";s:2:"WX";s:3:"600";s:1:"N";s:13:"quotedblright";s:1:"B";a:4:{i:0;s:3:"213";i:1;s:3:"328";i:2;s:3:"576";i:3;s:3:"562";}}s:13:"quotedblright";a:4:{s:1:"C";s:3:"186";s:2:"WX";s:3:"600";s:1:"N";s:13:"quotedblright";s:1:"B";a:4:{i:0;s:3:"213";i:1;s:3:"328";i:2;s:3:"576";i:3;s:3:"562";}}i:187;a:4:{s:1:"C";s:3:"187";s:2:"WX";s:3:"600";s:1:"N";s:14:"guillemotright";s:1:"B";a:4:{i:0;s:2:"58";i:1;s:2:"70";i:2;s:3:"618";i:3;s:3:"446";}}s:14:"guillemotright";a:4:{s:1:"C";s:3:"187";s:2:"WX";s:3:"600";s:1:"N";s:14:"guillemotright";s:1:"B";a:4:{i:0;s:2:"58";i:1;s:2:"70";i:2;s:3:"618";i:3;s:3:"446";}}i:188;a:4:{s:1:"C";s:3:"188";s:2:"WX";s:3:"600";s:1:"N";s:8:"ellipsis";s:1:"B";a:4:{i:0;s:2:"46";i:1;s:3:"-15";i:2;s:3:"575";i:3;s:3:"111";}}s:8:"ellipsis";a:4:{s:1:"C";s:3:"188";s:2:"WX";s:3:"600";s:1:"N";s:8:"ellipsis";s:1:"B";a:4:{i:0;s:2:"46";i:1;s:3:"-15";i:2;s:3:"575";i:3;s:3:"111";}}i:189;a:4:{s:1:"C";s:3:"189";s:2:"WX";s:3:"600";s:1:"N";s:11:"perthousand";s:1:"B";a:4:{i:0;s:2:"59";i:1;s:3:"-15";i:2;s:3:"627";i:3;s:3:"622";}}s:11:"perthousand";a:4:{s:1:"C";s:3:"189";s:2:"WX";s:3:"600";s:1:"N";s:11:"perthousand";s:1:"B";a:4:{i:0;s:2:"59";i:1;s:3:"-15";i:2;s:3:"627";i:3;s:3:"622";}}i:191;a:4:{s:1:"C";s:3:"191";s:2:"WX";s:3:"600";s:1:"N";s:12:"questiondown";s:1:"B";a:4:{i:0;s:3:"105";i:1;s:4:"-157";i:2;s:3:"466";i:3;s:3:"430";}}s:12:"questiondown";a:4:{s:1:"C";s:3:"191";s:2:"WX";s:3:"600";s:1:"N";s:12:"questiondown";s:1:"B";a:4:{i:0;s:3:"105";i:1;s:4:"-157";i:2;s:3:"466";i:3;s:3:"430";}}i:193;a:4:{s:1:"C";s:3:"193";s:2:"WX";s:3:"600";s:1:"N";s:5:"grave";s:1:"B";a:4:{i:0;s:3:"294";i:1;s:3:"497";i:2;s:3:"484";i:3;s:3:"672";}}s:5:"grave";a:4:{s:1:"C";s:3:"193";s:2:"WX";s:3:"600";s:1:"N";s:5:"grave";s:1:"B";a:4:{i:0;s:3:"294";i:1;s:3:"497";i:2;s:3:"484";i:3;s:3:"672";}}i:194;a:4:{s:1:"C";s:3:"194";s:2:"WX";s:3:"600";s:1:"N";s:5:"acute";s:1:"B";a:4:{i:0;s:3:"348";i:1;s:3:"497";i:2;s:3:"612";i:3;s:3:"672";}}s:5:"acute";a:4:{s:1:"C";s:3:"194";s:2:"WX";s:3:"600";s:1:"N";s:5:"acute";s:1:"B";a:4:{i:0;s:3:"348";i:1;s:3:"497";i:2;s:3:"612";i:3;s:3:"672";}}i:195;a:4:{s:1:"C";s:3:"195";s:2:"WX";s:3:"600";s:1:"N";s:10:"circumflex";s:1:"B";a:4:{i:0;s:3:"229";i:1;s:3:"477";i:2;s:3:"581";i:3;s:3:"654";}}s:10:"circumflex";a:4:{s:1:"C";s:3:"195";s:2:"WX";s:3:"600";s:1:"N";s:10:"circumflex";s:1:"B";a:4:{i:0;s:3:"229";i:1;s:3:"477";i:2;s:3:"581";i:3;s:3:"654";}}i:196;a:4:{s:1:"C";s:3:"196";s:2:"WX";s:3:"600";s:1:"N";s:5:"tilde";s:1:"B";a:4:{i:0;s:3:"212";i:1;s:3:"489";i:2;s:3:"629";i:3;s:3:"606";}}s:5:"tilde";a:4:{s:1:"C";s:3:"196";s:2:"WX";s:3:"600";s:1:"N";s:5:"tilde";s:1:"B";a:4:{i:0;s:3:"212";i:1;s:3:"489";i:2;s:3:"629";i:3;s:3:"606";}}i:197;a:4:{s:1:"C";s:3:"197";s:2:"WX";s:3:"600";s:1:"N";s:6:"macron";s:1:"B";a:4:{i:0;s:3:"232";i:1;s:3:"525";i:2;s:3:"600";i:3;s:3:"565";}}s:6:"macron";a:4:{s:1:"C";s:3:"197";s:2:"WX";s:3:"600";s:1:"N";s:6:"macron";s:1:"B";a:4:{i:0;s:3:"232";i:1;s:3:"525";i:2;s:3:"600";i:3;s:3:"565";}}i:198;a:4:{s:1:"C";s:3:"198";s:2:"WX";s:3:"600";s:1:"N";s:5:"breve";s:1:"B";a:4:{i:0;s:3:"279";i:1;s:3:"501";i:2;s:3:"576";i:3;s:3:"609";}}s:5:"breve";a:4:{s:1:"C";s:3:"198";s:2:"WX";s:3:"600";s:1:"N";s:5:"breve";s:1:"B";a:4:{i:0;s:3:"279";i:1;s:3:"501";i:2;s:3:"576";i:3;s:3:"609";}}i:199;a:4:{s:1:"C";s:3:"199";s:2:"WX";s:3:"600";s:1:"N";s:9:"dotaccent";s:1:"B";a:4:{i:0;s:3:"373";i:1;s:3:"537";i:2;s:3:"478";i:3;s:3:"640";}}s:9:"dotaccent";a:4:{s:1:"C";s:3:"199";s:2:"WX";s:3:"600";s:1:"N";s:9:"dotaccent";s:1:"B";a:4:{i:0;s:3:"373";i:1;s:3:"537";i:2;s:3:"478";i:3;s:3:"640";}}i:200;a:4:{s:1:"C";s:3:"200";s:2:"WX";s:3:"600";s:1:"N";s:8:"dieresis";s:1:"B";a:4:{i:0;s:3:"272";i:1;s:3:"537";i:2;s:3:"579";i:3;s:3:"640";}}s:8:"dieresis";a:4:{s:1:"C";s:3:"200";s:2:"WX";s:3:"600";s:1:"N";s:8:"dieresis";s:1:"B";a:4:{i:0;s:3:"272";i:1;s:3:"537";i:2;s:3:"579";i:3;s:3:"640";}}i:202;a:4:{s:1:"C";s:3:"202";s:2:"WX";s:3:"600";s:1:"N";s:4:"ring";s:1:"B";a:4:{i:0;s:3:"332";i:1;s:3:"463";i:2;s:3:"500";i:3;s:3:"627";}}s:4:"ring";a:4:{s:1:"C";s:3:"202";s:2:"WX";s:3:"600";s:1:"N";s:4:"ring";s:1:"B";a:4:{i:0;s:3:"332";i:1;s:3:"463";i:2;s:3:"500";i:3;s:3:"627";}}i:203;a:4:{s:1:"C";s:3:"203";s:2:"WX";s:3:"600";s:1:"N";s:7:"cedilla";s:1:"B";a:4:{i:0;s:3:"197";i:1;s:4:"-151";i:2;s:3:"344";i:3;s:2:"10";}}s:7:"cedilla";a:4:{s:1:"C";s:3:"203";s:2:"WX";s:3:"600";s:1:"N";s:7:"cedilla";s:1:"B";a:4:{i:0;s:3:"197";i:1;s:4:"-151";i:2;s:3:"344";i:3;s:2:"10";}}i:205;a:4:{s:1:"C";s:3:"205";s:2:"WX";s:3:"600";s:1:"N";s:12:"hungarumlaut";s:1:"B";a:4:{i:0;s:3:"239";i:1;s:3:"497";i:2;s:3:"683";i:3;s:3:"672";}}s:12:"hungarumlaut";a:4:{s:1:"C";s:3:"205";s:2:"WX";s:3:"600";s:1:"N";s:12:"hungarumlaut";s:1:"B";a:4:{i:0;s:3:"239";i:1;s:3:"497";i:2;s:3:"683";i:3;s:3:"672";}}i:206;a:4:{s:1:"C";s:3:"206";s:2:"WX";s:3:"600";s:1:"N";s:6:"ogonek";s:1:"B";a:4:{i:0;s:3:"189";i:1;s:4:"-172";i:2;s:3:"377";i:3;s:1:"4";}}s:6:"ogonek";a:4:{s:1:"C";s:3:"206";s:2:"WX";s:3:"600";s:1:"N";s:6:"ogonek";s:1:"B";a:4:{i:0;s:3:"189";i:1;s:4:"-172";i:2;s:3:"377";i:3;s:1:"4";}}i:207;a:4:{s:1:"C";s:3:"207";s:2:"WX";s:3:"600";s:1:"N";s:5:"caron";s:1:"B";a:4:{i:0;s:3:"262";i:1;s:3:"492";i:2;s:3:"614";i:3;s:3:"669";}}s:5:"caron";a:4:{s:1:"C";s:3:"207";s:2:"WX";s:3:"600";s:1:"N";s:5:"caron";s:1:"B";a:4:{i:0;s:3:"262";i:1;s:3:"492";i:2;s:3:"614";i:3;s:3:"669";}}i:208;a:4:{s:1:"C";s:3:"208";s:2:"WX";s:3:"600";s:1:"N";s:6:"emdash";s:1:"B";a:4:{i:0;s:2:"49";i:1;s:3:"231";i:2;s:3:"661";i:3;s:3:"285";}}s:6:"emdash";a:4:{s:1:"C";s:3:"208";s:2:"WX";s:3:"600";s:1:"N";s:6:"emdash";s:1:"B";a:4:{i:0;s:2:"49";i:1;s:3:"231";i:2;s:3:"661";i:3;s:3:"285";}}i:225;a:4:{s:1:"C";s:3:"225";s:2:"WX";s:3:"600";s:1:"N";s:2:"AE";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:1:"0";i:2;s:3:"655";i:3;s:3:"562";}}s:2:"AE";a:4:{s:1:"C";s:3:"225";s:2:"WX";s:3:"600";s:1:"N";s:2:"AE";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:1:"0";i:2;s:3:"655";i:3;s:3:"562";}}i:227;a:4:{s:1:"C";s:3:"227";s:2:"WX";s:3:"600";s:1:"N";s:11:"ordfeminine";s:1:"B";a:4:{i:0;s:3:"209";i:1;s:3:"249";i:2;s:3:"512";i:3;s:3:"580";}}s:11:"ordfeminine";a:4:{s:1:"C";s:3:"227";s:2:"WX";s:3:"600";s:1:"N";s:11:"ordfeminine";s:1:"B";a:4:{i:0;s:3:"209";i:1;s:3:"249";i:2;s:3:"512";i:3;s:3:"580";}}i:232;a:4:{s:1:"C";s:3:"232";s:2:"WX";s:3:"600";s:1:"N";s:6:"Lslash";s:1:"B";a:4:{i:0;s:2:"47";i:1;s:1:"0";i:2;s:3:"607";i:3;s:3:"562";}}s:6:"Lslash";a:4:{s:1:"C";s:3:"232";s:2:"WX";s:3:"600";s:1:"N";s:6:"Lslash";s:1:"B";a:4:{i:0;s:2:"47";i:1;s:1:"0";i:2;s:3:"607";i:3;s:3:"562";}}i:233;a:4:{s:1:"C";s:3:"233";s:2:"WX";s:3:"600";s:1:"N";s:6:"Oslash";s:1:"B";a:4:{i:0;s:2:"94";i:1;s:3:"-80";i:2;s:3:"625";i:3;s:3:"629";}}s:6:"Oslash";a:4:{s:1:"C";s:3:"233";s:2:"WX";s:3:"600";s:1:"N";s:6:"Oslash";s:1:"B";a:4:{i:0;s:2:"94";i:1;s:3:"-80";i:2;s:3:"625";i:3;s:3:"629";}}i:234;a:4:{s:1:"C";s:3:"234";s:2:"WX";s:3:"600";s:1:"N";s:2:"OE";s:1:"B";a:4:{i:0;s:2:"59";i:1;s:1:"0";i:2;s:3:"672";i:3;s:3:"562";}}s:2:"OE";a:4:{s:1:"C";s:3:"234";s:2:"WX";s:3:"600";s:1:"N";s:2:"OE";s:1:"B";a:4:{i:0;s:2:"59";i:1;s:1:"0";i:2;s:3:"672";i:3;s:3:"562";}}i:235;a:4:{s:1:"C";s:3:"235";s:2:"WX";s:3:"600";s:1:"N";s:12:"ordmasculine";s:1:"B";a:4:{i:0;s:3:"210";i:1;s:3:"249";i:2;s:3:"535";i:3;s:3:"580";}}s:12:"ordmasculine";a:4:{s:1:"C";s:3:"235";s:2:"WX";s:3:"600";s:1:"N";s:12:"ordmasculine";s:1:"B";a:4:{i:0;s:3:"210";i:1;s:3:"249";i:2;s:3:"535";i:3;s:3:"580";}}i:241;a:4:{s:1:"C";s:3:"241";s:2:"WX";s:3:"600";s:1:"N";s:2:"ae";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:3:"-15";i:2;s:3:"626";i:3;s:3:"441";}}s:2:"ae";a:4:{s:1:"C";s:3:"241";s:2:"WX";s:3:"600";s:1:"N";s:2:"ae";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:3:"-15";i:2;s:3:"626";i:3;s:3:"441";}}i:245;a:4:{s:1:"C";s:3:"245";s:2:"WX";s:3:"600";s:1:"N";s:8:"dotlessi";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:1:"0";i:2;s:3:"515";i:3;s:3:"426";}}s:8:"dotlessi";a:4:{s:1:"C";s:3:"245";s:2:"WX";s:3:"600";s:1:"N";s:8:"dotlessi";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:1:"0";i:2;s:3:"515";i:3;s:3:"426";}}i:248;a:4:{s:1:"C";s:3:"248";s:2:"WX";s:3:"600";s:1:"N";s:6:"lslash";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:1:"0";i:2;s:3:"587";i:3;s:3:"629";}}s:6:"lslash";a:4:{s:1:"C";s:3:"248";s:2:"WX";s:3:"600";s:1:"N";s:6:"lslash";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:1:"0";i:2;s:3:"587";i:3;s:3:"629";}}i:249;a:4:{s:1:"C";s:3:"249";s:2:"WX";s:3:"600";s:1:"N";s:6:"oslash";s:1:"B";a:4:{i:0;s:3:"102";i:1;s:3:"-80";i:2;s:3:"588";i:3;s:3:"506";}}s:6:"oslash";a:4:{s:1:"C";s:3:"249";s:2:"WX";s:3:"600";s:1:"N";s:6:"oslash";s:1:"B";a:4:{i:0;s:3:"102";i:1;s:3:"-80";i:2;s:3:"588";i:3;s:3:"506";}}i:250;a:4:{s:1:"C";s:3:"250";s:2:"WX";s:3:"600";s:1:"N";s:2:"oe";s:1:"B";a:4:{i:0;s:2:"54";i:1;s:3:"-15";i:2;s:3:"615";i:3;s:3:"441";}}s:2:"oe";a:4:{s:1:"C";s:3:"250";s:2:"WX";s:3:"600";s:1:"N";s:2:"oe";s:1:"B";a:4:{i:0;s:2:"54";i:1;s:3:"-15";i:2;s:3:"615";i:3;s:3:"441";}}i:251;a:4:{s:1:"C";s:3:"251";s:2:"WX";s:3:"600";s:1:"N";s:10:"germandbls";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:3:"-15";i:2;s:3:"617";i:3;s:3:"629";}}s:10:"germandbls";a:4:{s:1:"C";s:3:"251";s:2:"WX";s:3:"600";s:1:"N";s:10:"germandbls";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:3:"-15";i:2;s:3:"617";i:3;s:3:"629";}}s:9:"Idieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"Idieresis";s:1:"B";a:4:{i:0;s:2:"96";i:1;s:1:"0";i:2;s:3:"623";i:3;s:3:"753";}}s:6:"eacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"eacute";s:1:"B";a:4:{i:0;s:3:"106";i:1;s:3:"-15";i:2;s:3:"612";i:3;s:3:"672";}}s:6:"abreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"abreve";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:3:"-15";i:2;s:3:"576";i:3;s:3:"609";}}s:13:"uhungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:13:"uhungarumlaut";s:1:"B";a:4:{i:0;s:3:"101";i:1;s:3:"-15";i:2;s:3:"723";i:3;s:3:"672";}}s:6:"ecaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"ecaron";s:1:"B";a:4:{i:0;s:3:"106";i:1;s:3:"-15";i:2;s:3:"614";i:3;s:3:"669";}}s:9:"Ydieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"Ydieresis";s:1:"B";a:4:{i:0;s:3:"133";i:1;s:1:"0";i:2;s:3:"695";i:3;s:3:"753";}}s:6:"divide";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"divide";s:1:"B";a:4:{i:0;s:3:"136";i:1;s:2:"48";i:2;s:3:"573";i:3;s:3:"467";}}s:6:"Yacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Yacute";s:1:"B";a:4:{i:0;s:3:"133";i:1;s:1:"0";i:2;s:3:"695";i:3;s:3:"805";}}s:11:"Acircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"Acircumflex";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:1:"0";i:2;s:3:"607";i:3;s:3:"787";}}s:6:"aacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"aacute";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:3:"-15";i:2;s:3:"612";i:3;s:3:"672";}}s:11:"Ucircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"Ucircumflex";s:1:"B";a:4:{i:0;s:3:"125";i:1;s:3:"-18";i:2;s:3:"702";i:3;s:3:"787";}}s:6:"yacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"yacute";s:1:"B";a:4:{i:0;s:2:"-4";i:1;s:4:"-157";i:2;s:3:"683";i:3;s:3:"672";}}s:12:"scommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"scommaaccent";s:1:"B";a:4:{i:0;s:2:"78";i:1;s:4:"-250";i:2;s:3:"584";i:3;s:3:"441";}}s:11:"ecircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"ecircumflex";s:1:"B";a:4:{i:0;s:3:"106";i:1;s:3:"-15";i:2;s:3:"598";i:3;s:3:"654";}}s:5:"Uring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:5:"Uring";s:1:"B";a:4:{i:0;s:3:"125";i:1;s:3:"-18";i:2;s:3:"702";i:3;s:3:"760";}}s:9:"Udieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"Udieresis";s:1:"B";a:4:{i:0;s:3:"125";i:1;s:3:"-18";i:2;s:3:"702";i:3;s:3:"753";}}s:7:"aogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"aogonek";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:4:"-172";i:2;s:3:"569";i:3;s:3:"441";}}s:6:"Uacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Uacute";s:1:"B";a:4:{i:0;s:3:"125";i:1;s:3:"-18";i:2;s:3:"702";i:3;s:3:"805";}}s:7:"uogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"uogonek";s:1:"B";a:4:{i:0;s:3:"101";i:1;s:4:"-172";i:2;s:3:"572";i:3;s:3:"426";}}s:9:"Edieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"Edieresis";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:1:"0";i:2;s:3:"660";i:3;s:3:"753";}}s:6:"Dcroat";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Dcroat";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:1:"0";i:2;s:3:"645";i:3;s:3:"562";}}s:11:"commaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"commaaccent";s:1:"B";a:4:{i:0;s:3:"145";i:1;s:4:"-250";i:2;s:3:"323";i:3;s:3:"-58";}}s:9:"copyright";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"copyright";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:3:"-18";i:2;s:3:"667";i:3;s:3:"580";}}s:7:"Emacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"Emacron";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:1:"0";i:2;s:3:"660";i:3;s:3:"698";}}s:6:"ccaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"ccaron";s:1:"B";a:4:{i:0;s:3:"106";i:1;s:3:"-15";i:2;s:3:"614";i:3;s:3:"669";}}s:5:"aring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:5:"aring";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:3:"-15";i:2;s:3:"569";i:3;s:3:"627";}}s:12:"Ncommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"Ncommaaccent";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:4:"-250";i:2;s:3:"712";i:3;s:3:"562";}}s:6:"lacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"lacute";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:1:"0";i:2;s:3:"640";i:3;s:3:"805";}}s:6:"agrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"agrave";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:3:"-15";i:2;s:3:"569";i:3;s:3:"672";}}s:12:"Tcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"Tcommaaccent";s:1:"B";a:4:{i:0;s:3:"108";i:1;s:4:"-250";i:2;s:3:"665";i:3;s:3:"562";}}s:6:"Cacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Cacute";s:1:"B";a:4:{i:0;s:2:"93";i:1;s:3:"-18";i:2;s:3:"655";i:3;s:3:"805";}}s:6:"atilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"atilde";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:3:"-15";i:2;s:3:"629";i:3;s:3:"606";}}s:10:"Edotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:10:"Edotaccent";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:1:"0";i:2;s:3:"660";i:3;s:3:"753";}}s:6:"scaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"scaron";s:1:"B";a:4:{i:0;s:2:"78";i:1;s:3:"-15";i:2;s:3:"614";i:3;s:3:"669";}}s:8:"scedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:8:"scedilla";s:1:"B";a:4:{i:0;s:2:"78";i:1;s:4:"-151";i:2;s:3:"584";i:3;s:3:"441";}}s:6:"iacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"iacute";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:1:"0";i:2;s:3:"612";i:3;s:3:"672";}}s:7:"lozenge";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"lozenge";s:1:"B";a:4:{i:0;s:2:"94";i:1;s:1:"0";i:2;s:3:"519";i:3;s:3:"706";}}s:6:"Rcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Rcaron";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:1:"0";i:2;s:3:"642";i:3;s:3:"802";}}s:12:"Gcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"Gcommaaccent";s:1:"B";a:4:{i:0;s:2:"83";i:1;s:4:"-250";i:2;s:3:"645";i:3;s:3:"580";}}s:11:"ucircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"ucircumflex";s:1:"B";a:4:{i:0;s:3:"101";i:1;s:3:"-15";i:2;s:3:"572";i:3;s:3:"654";}}s:11:"acircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"acircumflex";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:3:"-15";i:2;s:3:"581";i:3;s:3:"654";}}s:7:"Amacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"Amacron";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:1:"0";i:2;s:3:"607";i:3;s:3:"698";}}s:6:"rcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"rcaron";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:1:"0";i:2;s:3:"636";i:3;s:3:"669";}}s:8:"ccedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:8:"ccedilla";s:1:"B";a:4:{i:0;s:3:"106";i:1;s:4:"-151";i:2;s:3:"614";i:3;s:3:"441";}}s:10:"Zdotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:10:"Zdotaccent";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"610";i:3;s:3:"753";}}s:5:"Thorn";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:5:"Thorn";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:1:"0";i:2;s:3:"606";i:3;s:3:"562";}}s:7:"Omacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"Omacron";s:1:"B";a:4:{i:0;s:2:"94";i:1;s:3:"-18";i:2;s:3:"628";i:3;s:3:"698";}}s:6:"Racute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Racute";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:1:"0";i:2;s:3:"670";i:3;s:3:"805";}}s:6:"Sacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Sacute";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:3:"-20";i:2;s:3:"650";i:3;s:3:"805";}}s:6:"dcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"dcaron";s:1:"B";a:4:{i:0;s:2:"85";i:1;s:3:"-15";i:2;s:3:"849";i:3;s:3:"629";}}s:7:"Umacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"Umacron";s:1:"B";a:4:{i:0;s:3:"125";i:1;s:3:"-18";i:2;s:3:"702";i:3;s:3:"698";}}s:5:"uring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:5:"uring";s:1:"B";a:4:{i:0;s:3:"101";i:1;s:3:"-15";i:2;s:3:"572";i:3;s:3:"627";}}s:13:"threesuperior";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:13:"threesuperior";s:1:"B";a:4:{i:0;s:3:"213";i:1;s:3:"240";i:2;s:3:"501";i:3;s:3:"622";}}s:6:"Ograve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Ograve";s:1:"B";a:4:{i:0;s:2:"94";i:1;s:3:"-18";i:2;s:3:"625";i:3;s:3:"805";}}s:6:"Agrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Agrave";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:1:"0";i:2;s:3:"607";i:3;s:3:"805";}}s:6:"Abreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Abreve";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:1:"0";i:2;s:3:"607";i:3;s:3:"732";}}s:8:"multiply";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:8:"multiply";s:1:"B";a:4:{i:0;s:3:"103";i:1;s:2:"43";i:2;s:3:"607";i:3;s:3:"470";}}s:6:"uacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"uacute";s:1:"B";a:4:{i:0;s:3:"101";i:1;s:3:"-15";i:2;s:3:"602";i:3;s:3:"672";}}s:6:"Tcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Tcaron";s:1:"B";a:4:{i:0;s:3:"108";i:1;s:1:"0";i:2;s:3:"665";i:3;s:3:"802";}}s:11:"partialdiff";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"partialdiff";s:1:"B";a:4:{i:0;s:2:"45";i:1;s:3:"-38";i:2;s:3:"546";i:3;s:3:"710";}}s:9:"ydieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"ydieresis";s:1:"B";a:4:{i:0;s:2:"-4";i:1;s:4:"-157";i:2;s:3:"683";i:3;s:3:"620";}}s:6:"Nacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Nacute";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:3:"-13";i:2;s:3:"712";i:3;s:3:"805";}}s:11:"icircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"icircumflex";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:1:"0";i:2;s:3:"551";i:3;s:3:"654";}}s:11:"Ecircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"Ecircumflex";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:1:"0";i:2;s:3:"660";i:3;s:3:"787";}}s:9:"adieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"adieresis";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:3:"-15";i:2;s:3:"575";i:3;s:3:"620";}}s:9:"edieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"edieresis";s:1:"B";a:4:{i:0;s:3:"106";i:1;s:3:"-15";i:2;s:3:"598";i:3;s:3:"620";}}s:6:"cacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"cacute";s:1:"B";a:4:{i:0;s:3:"106";i:1;s:3:"-15";i:2;s:3:"612";i:3;s:3:"672";}}s:6:"nacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"nacute";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"602";i:3;s:3:"672";}}s:7:"umacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"umacron";s:1:"B";a:4:{i:0;s:3:"101";i:1;s:3:"-15";i:2;s:3:"600";i:3;s:3:"565";}}s:6:"Ncaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Ncaron";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:3:"-13";i:2;s:3:"712";i:3;s:3:"802";}}s:6:"Iacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Iacute";s:1:"B";a:4:{i:0;s:2:"96";i:1;s:1:"0";i:2;s:3:"640";i:3;s:3:"805";}}s:9:"plusminus";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"plusminus";s:1:"B";a:4:{i:0;s:2:"96";i:1;s:2:"44";i:2;s:3:"594";i:3;s:3:"558";}}s:9:"brokenbar";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"brokenbar";s:1:"B";a:4:{i:0;s:3:"238";i:1;s:4:"-175";i:2;s:3:"469";i:3;s:3:"675";}}s:10:"registered";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:10:"registered";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:3:"-18";i:2;s:3:"667";i:3;s:3:"580";}}s:6:"Gbreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Gbreve";s:1:"B";a:4:{i:0;s:2:"83";i:1;s:3:"-18";i:2;s:3:"645";i:3;s:3:"732";}}s:10:"Idotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:10:"Idotaccent";s:1:"B";a:4:{i:0;s:2:"96";i:1;s:1:"0";i:2;s:3:"623";i:3;s:3:"753";}}s:9:"summation";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"summation";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:3:"-10";i:2;s:3:"670";i:3;s:3:"706";}}s:6:"Egrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Egrave";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:1:"0";i:2;s:3:"660";i:3;s:3:"805";}}s:6:"racute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"racute";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:1:"0";i:2;s:3:"636";i:3;s:3:"672";}}s:7:"omacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"omacron";s:1:"B";a:4:{i:0;s:3:"102";i:1;s:3:"-15";i:2;s:3:"600";i:3;s:3:"565";}}s:6:"Zacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Zacute";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"670";i:3;s:3:"805";}}s:6:"Zcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Zcaron";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"642";i:3;s:3:"802";}}s:12:"greaterequal";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"greaterequal";s:1:"B";a:4:{i:0;s:2:"98";i:1;s:1:"0";i:2;s:3:"594";i:3;s:3:"710";}}s:3:"Eth";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:3:"Eth";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:1:"0";i:2;s:3:"645";i:3;s:3:"562";}}s:8:"Ccedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:8:"Ccedilla";s:1:"B";a:4:{i:0;s:2:"93";i:1;s:4:"-151";i:2;s:3:"658";i:3;s:3:"580";}}s:12:"lcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"lcommaaccent";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:4:"-250";i:2;s:3:"515";i:3;s:3:"629";}}s:6:"tcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"tcaron";s:1:"B";a:4:{i:0;s:3:"167";i:1;s:3:"-15";i:2;s:3:"587";i:3;s:3:"717";}}s:7:"eogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"eogonek";s:1:"B";a:4:{i:0;s:3:"106";i:1;s:4:"-172";i:2;s:3:"598";i:3;s:3:"441";}}s:7:"Uogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"Uogonek";s:1:"B";a:4:{i:0;s:3:"124";i:1;s:4:"-172";i:2;s:3:"702";i:3;s:3:"562";}}s:6:"Aacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Aacute";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:1:"0";i:2;s:3:"660";i:3;s:3:"805";}}s:9:"Adieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"Adieresis";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:1:"0";i:2;s:3:"607";i:3;s:3:"753";}}s:6:"egrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"egrave";s:1:"B";a:4:{i:0;s:3:"106";i:1;s:3:"-15";i:2;s:3:"598";i:3;s:3:"672";}}s:6:"zacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"zacute";s:1:"B";a:4:{i:0;s:2:"99";i:1;s:1:"0";i:2;s:3:"612";i:3;s:3:"672";}}s:7:"iogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"iogonek";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:4:"-172";i:2;s:3:"515";i:3;s:3:"657";}}s:6:"Oacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Oacute";s:1:"B";a:4:{i:0;s:2:"94";i:1;s:3:"-18";i:2;s:3:"640";i:3;s:3:"805";}}s:6:"oacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"oacute";s:1:"B";a:4:{i:0;s:3:"102";i:1;s:3:"-15";i:2;s:3:"612";i:3;s:3:"672";}}s:7:"amacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"amacron";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:3:"-15";i:2;s:3:"600";i:3;s:3:"565";}}s:6:"sacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"sacute";s:1:"B";a:4:{i:0;s:2:"78";i:1;s:3:"-15";i:2;s:3:"612";i:3;s:3:"672";}}s:9:"idieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"idieresis";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:1:"0";i:2;s:3:"545";i:3;s:3:"620";}}s:11:"Ocircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"Ocircumflex";s:1:"B";a:4:{i:0;s:2:"94";i:1;s:3:"-18";i:2;s:3:"625";i:3;s:3:"787";}}s:6:"Ugrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Ugrave";s:1:"B";a:4:{i:0;s:3:"125";i:1;s:3:"-18";i:2;s:3:"702";i:3;s:3:"805";}}s:5:"Delta";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:5:"Delta";s:1:"B";a:4:{i:0;s:1:"6";i:1;s:1:"0";i:2;s:3:"598";i:3;s:3:"688";}}s:5:"thorn";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:5:"thorn";s:1:"B";a:4:{i:0;s:3:"-24";i:1;s:4:"-157";i:2;s:3:"605";i:3;s:3:"629";}}s:11:"twosuperior";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"twosuperior";s:1:"B";a:4:{i:0;s:3:"230";i:1;s:3:"249";i:2;s:3:"535";i:3;s:3:"622";}}s:9:"Odieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"Odieresis";s:1:"B";a:4:{i:0;s:2:"94";i:1;s:3:"-18";i:2;s:3:"625";i:3;s:3:"753";}}s:2:"mu";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:2:"mu";s:1:"B";a:4:{i:0;s:2:"72";i:1;s:4:"-157";i:2;s:3:"572";i:3;s:3:"426";}}s:6:"igrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"igrave";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:1:"0";i:2;s:3:"515";i:3;s:3:"672";}}s:13:"ohungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:13:"ohungarumlaut";s:1:"B";a:4:{i:0;s:3:"102";i:1;s:3:"-15";i:2;s:3:"723";i:3;s:3:"672";}}s:7:"Eogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"Eogonek";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:4:"-172";i:2;s:3:"660";i:3;s:3:"562";}}s:6:"dcroat";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"dcroat";s:1:"B";a:4:{i:0;s:2:"85";i:1;s:3:"-15";i:2;s:3:"704";i:3;s:3:"629";}}s:13:"threequarters";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:13:"threequarters";s:1:"B";a:4:{i:0;s:2:"73";i:1;s:3:"-56";i:2;s:3:"659";i:3;s:3:"666";}}s:8:"Scedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:8:"Scedilla";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:4:"-151";i:2;s:3:"650";i:3;s:3:"580";}}s:6:"lcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"lcaron";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:1:"0";i:2;s:3:"667";i:3;s:3:"629";}}s:12:"Kcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"Kcommaaccent";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:4:"-250";i:2;s:3:"671";i:3;s:3:"562";}}s:6:"Lacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Lacute";s:1:"B";a:4:{i:0;s:2:"47";i:1;s:1:"0";i:2;s:3:"607";i:3;s:3:"805";}}s:9:"trademark";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"trademark";s:1:"B";a:4:{i:0;s:2:"75";i:1;s:3:"263";i:2;s:3:"742";i:3;s:3:"562";}}s:10:"edotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:10:"edotaccent";s:1:"B";a:4:{i:0;s:3:"106";i:1;s:3:"-15";i:2;s:3:"598";i:3;s:3:"620";}}s:6:"Igrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Igrave";s:1:"B";a:4:{i:0;s:2:"96";i:1;s:1:"0";i:2;s:3:"623";i:3;s:3:"805";}}s:7:"Imacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"Imacron";s:1:"B";a:4:{i:0;s:2:"96";i:1;s:1:"0";i:2;s:3:"628";i:3;s:3:"698";}}s:6:"Lcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Lcaron";s:1:"B";a:4:{i:0;s:2:"47";i:1;s:1:"0";i:2;s:3:"632";i:3;s:3:"562";}}s:7:"onehalf";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"onehalf";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:3:"-57";i:2;s:3:"669";i:3;s:3:"665";}}s:9:"lessequal";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"lessequal";s:1:"B";a:4:{i:0;s:2:"98";i:1;s:1:"0";i:2;s:3:"645";i:3;s:3:"710";}}s:11:"ocircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"ocircumflex";s:1:"B";a:4:{i:0;s:3:"102";i:1;s:3:"-15";i:2;s:3:"588";i:3;s:3:"654";}}s:6:"ntilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"ntilde";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"629";i:3;s:3:"606";}}s:13:"Uhungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:13:"Uhungarumlaut";s:1:"B";a:4:{i:0;s:3:"125";i:1;s:3:"-18";i:2;s:3:"761";i:3;s:3:"805";}}s:6:"Eacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Eacute";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:1:"0";i:2;s:3:"670";i:3;s:3:"805";}}s:7:"emacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"emacron";s:1:"B";a:4:{i:0;s:3:"106";i:1;s:3:"-15";i:2;s:3:"600";i:3;s:3:"565";}}s:6:"gbreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"gbreve";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:4:"-157";i:2;s:3:"657";i:3;s:3:"609";}}s:10:"onequarter";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:10:"onequarter";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:3:"-57";i:2;s:3:"674";i:3;s:3:"665";}}s:6:"Scaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Scaron";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:3:"-20";i:2;s:3:"672";i:3;s:3:"802";}}s:12:"Scommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"Scommaaccent";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:4:"-250";i:2;s:3:"650";i:3;s:3:"580";}}s:13:"Ohungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:13:"Ohungarumlaut";s:1:"B";a:4:{i:0;s:2:"94";i:1;s:3:"-18";i:2;s:3:"751";i:3;s:3:"805";}}s:6:"degree";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"degree";s:1:"B";a:4:{i:0;s:3:"214";i:1;s:3:"269";i:2;s:3:"576";i:3;s:3:"622";}}s:6:"ograve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"ograve";s:1:"B";a:4:{i:0;s:3:"102";i:1;s:3:"-15";i:2;s:3:"588";i:3;s:3:"672";}}s:6:"Ccaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Ccaron";s:1:"B";a:4:{i:0;s:2:"93";i:1;s:3:"-18";i:2;s:3:"672";i:3;s:3:"802";}}s:6:"ugrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"ugrave";s:1:"B";a:4:{i:0;s:3:"101";i:1;s:3:"-15";i:2;s:3:"572";i:3;s:3:"672";}}s:7:"radical";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"radical";s:1:"B";a:4:{i:0;s:2:"85";i:1;s:3:"-15";i:2;s:3:"765";i:3;s:3:"792";}}s:6:"Dcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Dcaron";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:1:"0";i:2;s:3:"645";i:3;s:3:"802";}}s:12:"rcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"rcommaaccent";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:4:"-250";i:2;s:3:"636";i:3;s:3:"441";}}s:6:"Ntilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Ntilde";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:3:"-13";i:2;s:3:"712";i:3;s:3:"729";}}s:6:"otilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"otilde";s:1:"B";a:4:{i:0;s:3:"102";i:1;s:3:"-15";i:2;s:3:"629";i:3;s:3:"606";}}s:12:"Rcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"Rcommaaccent";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:4:"-250";i:2;s:3:"598";i:3;s:3:"562";}}s:12:"Lcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"Lcommaaccent";s:1:"B";a:4:{i:0;s:2:"47";i:1;s:4:"-250";i:2;s:3:"607";i:3;s:3:"562";}}s:6:"Atilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Atilde";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:1:"0";i:2;s:3:"655";i:3;s:3:"729";}}s:7:"Aogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"Aogonek";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:4:"-172";i:2;s:3:"607";i:3;s:3:"562";}}s:5:"Aring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:5:"Aring";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:1:"0";i:2;s:3:"607";i:3;s:3:"750";}}s:6:"Otilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Otilde";s:1:"B";a:4:{i:0;s:2:"94";i:1;s:3:"-18";i:2;s:3:"655";i:3;s:3:"729";}}s:10:"zdotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:10:"zdotaccent";s:1:"B";a:4:{i:0;s:2:"99";i:1;s:1:"0";i:2;s:3:"593";i:3;s:3:"620";}}s:6:"Ecaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Ecaron";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:1:"0";i:2;s:3:"660";i:3;s:3:"802";}}s:7:"Iogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"Iogonek";s:1:"B";a:4:{i:0;s:2:"96";i:1;s:4:"-172";i:2;s:3:"623";i:3;s:3:"562";}}s:12:"kcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"kcommaaccent";s:1:"B";a:4:{i:0;s:2:"58";i:1;s:4:"-250";i:2;s:3:"633";i:3;s:3:"629";}}s:5:"minus";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:5:"minus";s:1:"B";a:4:{i:0;s:3:"129";i:1;s:3:"232";i:2;s:3:"580";i:3;s:3:"283";}}s:11:"Icircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"Icircumflex";s:1:"B";a:4:{i:0;s:2:"96";i:1;s:1:"0";i:2;s:3:"623";i:3;s:3:"787";}}s:6:"ncaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"ncaron";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"614";i:3;s:3:"669";}}s:12:"tcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"tcommaaccent";s:1:"B";a:4:{i:0;s:3:"165";i:1;s:4:"-250";i:2;s:3:"561";i:3;s:3:"561";}}s:10:"logicalnot";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:10:"logicalnot";s:1:"B";a:4:{i:0;s:3:"155";i:1;s:3:"108";i:2;s:3:"591";i:3;s:3:"369";}}s:9:"odieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"odieresis";s:1:"B";a:4:{i:0;s:3:"102";i:1;s:3:"-15";i:2;s:3:"588";i:3;s:3:"620";}}s:9:"udieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"udieresis";s:1:"B";a:4:{i:0;s:3:"101";i:1;s:3:"-15";i:2;s:3:"575";i:3;s:3:"620";}}s:8:"notequal";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:8:"notequal";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:3:"-16";i:2;s:3:"621";i:3;s:3:"529";}}s:12:"gcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"gcommaaccent";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:4:"-157";i:2;s:3:"657";i:3;s:3:"708";}}s:3:"eth";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:3:"eth";s:1:"B";a:4:{i:0;s:3:"102";i:1;s:3:"-15";i:2;s:3:"639";i:3;s:3:"629";}}s:6:"zcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"zcaron";s:1:"B";a:4:{i:0;s:2:"99";i:1;s:1:"0";i:2;s:3:"624";i:3;s:3:"669";}}s:12:"ncommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"ncommaaccent";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:4:"-250";i:2;s:3:"585";i:3;s:3:"441";}}s:11:"onesuperior";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"onesuperior";s:1:"B";a:4:{i:0;s:3:"231";i:1;s:3:"249";i:2;s:3:"491";i:3;s:3:"622";}}s:7:"imacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"imacron";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:1:"0";i:2;s:3:"543";i:3;s:3:"565";}}s:4:"Euro";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:4:"Euro";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}}s:9:"_version_";i:1;}
\ No newline at end of file
Added: trunk/mapbender/http/classes/fonts/php_Courier.afm
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/fonts/php_Courier.afm?view=auto&rev=13
--- (empty file)
+++ trunk/mapbender/http/classes/fonts/php_Courier.afm 2006-04-13 19:38:28+0000
@@ -0,0 +1 @@
+a:21:{s:8:"FontName";s:7:"Courier";s:8:"FullName";s:7:"Courier";s:10:"FamilyName";s:7:"Courier";s:6:"Weight";s:6:"Medium";s:11:"ItalicAngle";s:1:"0";s:12:"IsFixedPitch";s:4:"true";s:12:"CharacterSet";s:13:"ExtendedRoman";s:8:"FontBBox";a:4:{i:0;s:3:"-23";i:1;s:4:"-250";i:2;s:3:"715";i:3;s:3:"805";}s:17:"UnderlinePosition";s:4:"-100";s:18:"UnderlineThickness";s:2:"50";s:7:"Version";s:7:"003.000";s:14:"EncodingScheme";s:21:"AdobeStandardEncoding";s:9:"CapHeight";s:3:"562";s:7:"XHeight";s:3:"426";s:8:"Ascender";s:3:"629";s:9:"Descender";s:4:"-157";s:5:"StdHW";s:2:"51";s:5:"StdVW";s:2:"51";s:16:"StartCharMetrics";s:3:"315";s:1:"C";a:464:{i:32;a:4:{s:1:"C";s:2:"32";s:2:"WX";s:3:"600";s:1:"N";s:5:"space";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}s:5:"space";a:4:{s:1:"C";s:2:"32";s:2:"WX";s:3:"600";s:1:"N";s:5:"space";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}i:33;a:4:{s:1:"C";s:2:"33";s:2:"WX";s:3:"600";s:1:"N";s:6:"exclam";s:1:"B";a:4:{i:0;s:3:"236";i:1;s:3:"-15";i:2;s:3:"364";i:3;s:3:"572";}}s:6:"exclam";a:4:{s:1:"C";s:2:"33";s:2:"WX";s:3:"600";s:1:"N";s:6:"exclam";s:1:"B";a:4:{i:0;s:3:"236";i:1;s:3:"-15";i:2;s:3:"364";i:3;s:3:"572";}}i:34;a:4:{s:1:"C";s:2:"34";s:2:"WX";s:3:"600";s:1:"N";s:8:"quotedbl";s:1:"B";a:4:{i:0;s:3:"187";i:1;s:3:"328";i:2;s:3:"413";i:3;s:3:"562";}}s:8:"quotedbl";a:4:{s:1:"C";s:2:"34";s:2:"WX";s:3:"600";s:1:"N";s:8:"quotedbl";s:1:"B";a:4:{i:0;s:3:"187";i:1;s:3:"328";i:2;s:3:"413";i:3;s:3:"562";}}i:35;a:4:{s:1:"C";s:2:"35";s:2:"WX";s:3:"600";s:1:"N";s:10:"numbersign";s:1:"B";a:4:{i:0;s:2:"93";i:1;s:3:"-32";i:2;s:3:"507";i:3;s:3:"639";}}s:10:"numbersign";a:4:{s:1:"C";s:2:"35";s:2:"WX";s:3:"600";s:1:"N";s:10:"numbersign";s:1:"B";a:4:{i:0;s:2:"93";i:1;s:3:"-32";i:2;s:3:"507";i:3;s:3:"639";}}i:36;a:4:{s:1:"C";s:2:"36";s:2:"WX";s:3:"600";s:1:"N";s:6:"dollar";s:1:"B";a:4:{i:0;s:3:"105";i:1;s:4:"-126";i:2;s:3:"496";i:3;s:3:"662";}}s:6:"dollar";a:4:{s:1:"C";s:2:"36";s:2:"WX";s:3:"600";s:1:"N";s:6:"dollar";s:1:"B";a:4:{i:0;s:3:"105";i:1;s:4:"-126";i:2;s:3:"496";i:3;s:3:"662";}}i:37;a:4:{s:1:"C";s:2:"37";s:2:"WX";s:3:"600";s:1:"N";s:7:"percent";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:3:"-15";i:2;s:3:"518";i:3;s:3:"622";}}s:7:"percent";a:4:{s:1:"C";s:2:"37";s:2:"WX";s:3:"600";s:1:"N";s:7:"percent";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:3:"-15";i:2;s:3:"518";i:3;s:3:"622";}}i:38;a:4:{s:1:"C";s:2:"38";s:2:"WX";s:3:"600";s:1:"N";s:9:"ampersand";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:3:"-15";i:2;s:3:"538";i:3;s:3:"543";}}s:9:"ampersand";a:4:{s:1:"C";s:2:"38";s:2:"WX";s:3:"600";s:1:"N";s:9:"ampersand";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:3:"-15";i:2;s:3:"538";i:3;s:3:"543";}}i:39;a:4:{s:1:"C";s:2:"39";s:2:"WX";s:3:"600";s:1:"N";s:10:"quoteright";s:1:"B";a:4:{i:0;s:3:"213";i:1;s:3:"328";i:2;s:3:"376";i:3;s:3:"562";}}s:10:"quoteright";a:4:{s:1:"C";s:2:"39";s:2:"WX";s:3:"600";s:1:"N";s:10:"quoteright";s:1:"B";a:4:{i:0;s:3:"213";i:1;s:3:"328";i:2;s:3:"376";i:3;s:3:"562";}}i:40;a:4:{s:1:"C";s:2:"40";s:2:"WX";s:3:"600";s:1:"N";s:9:"parenleft";s:1:"B";a:4:{i:0;s:3:"269";i:1;s:4:"-108";i:2;s:3:"440";i:3;s:3:"622";}}s:9:"parenleft";a:4:{s:1:"C";s:2:"40";s:2:"WX";s:3:"600";s:1:"N";s:9:"parenleft";s:1:"B";a:4:{i:0;s:3:"269";i:1;s:4:"-108";i:2;s:3:"440";i:3;s:3:"622";}}i:41;a:4:{s:1:"C";s:2:"41";s:2:"WX";s:3:"600";s:1:"N";s:10:"parenright";s:1:"B";a:4:{i:0;s:3:"160";i:1;s:4:"-108";i:2;s:3:"331";i:3;s:3:"622";}}s:10:"parenright";a:4:{s:1:"C";s:2:"41";s:2:"WX";s:3:"600";s:1:"N";s:10:"parenright";s:1:"B";a:4:{i:0;s:3:"160";i:1;s:4:"-108";i:2;s:3:"331";i:3;s:3:"622";}}i:42;a:4:{s:1:"C";s:2:"42";s:2:"WX";s:3:"600";s:1:"N";s:8:"asterisk";s:1:"B";a:4:{i:0;s:3:"116";i:1;s:3:"257";i:2;s:3:"484";i:3;s:3:"607";}}s:8:"asterisk";a:4:{s:1:"C";s:2:"42";s:2:"WX";s:3:"600";s:1:"N";s:8:"asterisk";s:1:"B";a:4:{i:0;s:3:"116";i:1;s:3:"257";i:2;s:3:"484";i:3;s:3:"607";}}i:43;a:4:{s:1:"C";s:2:"43";s:2:"WX";s:3:"600";s:1:"N";s:4:"plus";s:1:"B";a:4:{i:0;s:2:"80";i:1;s:2:"44";i:2;s:3:"520";i:3;s:3:"470";}}s:4:"plus";a:4:{s:1:"C";s:2:"43";s:2:"WX";s:3:"600";s:1:"N";s:4:"plus";s:1:"B";a:4:{i:0;s:2:"80";i:1;s:2:"44";i:2;s:3:"520";i:3;s:3:"470";}}i:44;a:4:{s:1:"C";s:2:"44";s:2:"WX";s:3:"600";s:1:"N";s:5:"comma";s:1:"B";a:4:{i:0;s:3:"181";i:1;s:4:"-112";i:2;s:3:"344";i:3;s:3:"122";}}s:5:"comma";a:4:{s:1:"C";s:2:"44";s:2:"WX";s:3:"600";s:1:"N";s:5:"comma";s:1:"B";a:4:{i:0;s:3:"181";i:1;s:4:"-112";i:2;s:3:"344";i:3;s:3:"122";}}i:45;a:4:{s:1:"C";s:2:"45";s:2:"WX";s:3:"600";s:1:"N";s:6:"hyphen";s:1:"B";a:4:{i:0;s:3:"103";i:1;s:3:"231";i:2;s:3:"497";i:3;s:3:"285";}}s:6:"hyphen";a:4:{s:1:"C";s:2:"45";s:2:"WX";s:3:"600";s:1:"N";s:6:"hyphen";s:1:"B";a:4:{i:0;s:3:"103";i:1;s:3:"231";i:2;s:3:"497";i:3;s:3:"285";}}i:46;a:4:{s:1:"C";s:2:"46";s:2:"WX";s:3:"600";s:1:"N";s:6:"period";s:1:"B";a:4:{i:0;s:3:"229";i:1;s:3:"-15";i:2;s:3:"371";i:3;s:3:"109";}}s:6:"period";a:4:{s:1:"C";s:2:"46";s:2:"WX";s:3:"600";s:1:"N";s:6:"period";s:1:"B";a:4:{i:0;s:3:"229";i:1;s:3:"-15";i:2;s:3:"371";i:3;s:3:"109";}}i:47;a:4:{s:1:"C";s:2:"47";s:2:"WX";s:3:"600";s:1:"N";s:5:"slash";s:1:"B";a:4:{i:0;s:3:"125";i:1;s:3:"-80";i:2;s:3:"475";i:3;s:3:"629";}}s:5:"slash";a:4:{s:1:"C";s:2:"47";s:2:"WX";s:3:"600";s:1:"N";s:5:"slash";s:1:"B";a:4:{i:0;s:3:"125";i:1;s:3:"-80";i:2;s:3:"475";i:3;s:3:"629";}}i:48;a:4:{s:1:"C";s:2:"48";s:2:"WX";s:3:"600";s:1:"N";s:4:"zero";s:1:"B";a:4:{i:0;s:3:"106";i:1;s:3:"-15";i:2;s:3:"494";i:3;s:3:"622";}}s:4:"zero";a:4:{s:1:"C";s:2:"48";s:2:"WX";s:3:"600";s:1:"N";s:4:"zero";s:1:"B";a:4:{i:0;s:3:"106";i:1;s:3:"-15";i:2;s:3:"494";i:3;s:3:"622";}}i:49;a:4:{s:1:"C";s:2:"49";s:2:"WX";s:3:"600";s:1:"N";s:3:"one";s:1:"B";a:4:{i:0;s:2:"96";i:1;s:1:"0";i:2;s:3:"505";i:3;s:3:"622";}}s:3:"one";a:4:{s:1:"C";s:2:"49";s:2:"WX";s:3:"600";s:1:"N";s:3:"one";s:1:"B";a:4:{i:0;s:2:"96";i:1;s:1:"0";i:2;s:3:"505";i:3;s:3:"622";}}i:50;a:4:{s:1:"C";s:2:"50";s:2:"WX";s:3:"600";s:1:"N";s:3:"two";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:1:"0";i:2;s:3:"471";i:3;s:3:"622";}}s:3:"two";a:4:{s:1:"C";s:2:"50";s:2:"WX";s:3:"600";s:1:"N";s:3:"two";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:1:"0";i:2;s:3:"471";i:3;s:3:"622";}}i:51;a:4:{s:1:"C";s:2:"51";s:2:"WX";s:3:"600";s:1:"N";s:5:"three";s:1:"B";a:4:{i:0;s:2:"75";i:1;s:3:"-15";i:2;s:3:"466";i:3;s:3:"622";}}s:5:"three";a:4:{s:1:"C";s:2:"51";s:2:"WX";s:3:"600";s:1:"N";s:5:"three";s:1:"B";a:4:{i:0;s:2:"75";i:1;s:3:"-15";i:2;s:3:"466";i:3;s:3:"622";}}i:52;a:4:{s:1:"C";s:2:"52";s:2:"WX";s:3:"600";s:1:"N";s:4:"four";s:1:"B";a:4:{i:0;s:2:"78";i:1;s:1:"0";i:2;s:3:"500";i:3;s:3:"622";}}s:4:"four";a:4:{s:1:"C";s:2:"52";s:2:"WX";s:3:"600";s:1:"N";s:4:"four";s:1:"B";a:4:{i:0;s:2:"78";i:1;s:1:"0";i:2;s:3:"500";i:3;s:3:"622";}}i:53;a:4:{s:1:"C";s:2:"53";s:2:"WX";s:3:"600";s:1:"N";s:4:"five";s:1:"B";a:4:{i:0;s:2:"92";i:1;s:3:"-15";i:2;s:3:"497";i:3;s:3:"607";}}s:4:"five";a:4:{s:1:"C";s:2:"53";s:2:"WX";s:3:"600";s:1:"N";s:4:"five";s:1:"B";a:4:{i:0;s:2:"92";i:1;s:3:"-15";i:2;s:3:"497";i:3;s:3:"607";}}i:54;a:4:{s:1:"C";s:2:"54";s:2:"WX";s:3:"600";s:1:"N";s:3:"six";s:1:"B";a:4:{i:0;s:3:"111";i:1;s:3:"-15";i:2;s:3:"497";i:3;s:3:"622";}}s:3:"six";a:4:{s:1:"C";s:2:"54";s:2:"WX";s:3:"600";s:1:"N";s:3:"six";s:1:"B";a:4:{i:0;s:3:"111";i:1;s:3:"-15";i:2;s:3:"497";i:3;s:3:"622";}}i:55;a:4:{s:1:"C";s:2:"55";s:2:"WX";s:3:"600";s:1:"N";s:5:"seven";s:1:"B";a:4:{i:0;s:2:"82";i:1;s:1:"0";i:2;s:3:"483";i:3;s:3:"607";}}s:5:"seven";a:4:{s:1:"C";s:2:"55";s:2:"WX";s:3:"600";s:1:"N";s:5:"seven";s:1:"B";a:4:{i:0;s:2:"82";i:1;s:1:"0";i:2;s:3:"483";i:3;s:3:"607";}}i:56;a:4:{s:1:"C";s:2:"56";s:2:"WX";s:3:"600";s:1:"N";s:5:"eight";s:1:"B";a:4:{i:0;s:3:"102";i:1;s:3:"-15";i:2;s:3:"498";i:3;s:3:"622";}}s:5:"eight";a:4:{s:1:"C";s:2:"56";s:2:"WX";s:3:"600";s:1:"N";s:5:"eight";s:1:"B";a:4:{i:0;s:3:"102";i:1;s:3:"-15";i:2;s:3:"498";i:3;s:3:"622";}}i:57;a:4:{s:1:"C";s:2:"57";s:2:"WX";s:3:"600";s:1:"N";s:4:"nine";s:1:"B";a:4:{i:0;s:2:"96";i:1;s:3:"-15";i:2;s:3:"489";i:3;s:3:"622";}}s:4:"nine";a:4:{s:1:"C";s:2:"57";s:2:"WX";s:3:"600";s:1:"N";s:4:"nine";s:1:"B";a:4:{i:0;s:2:"96";i:1;s:3:"-15";i:2;s:3:"489";i:3;s:3:"622";}}i:58;a:4:{s:1:"C";s:2:"58";s:2:"WX";s:3:"600";s:1:"N";s:5:"colon";s:1:"B";a:4:{i:0;s:3:"229";i:1;s:3:"-15";i:2;s:3:"371";i:3;s:3:"385";}}s:5:"colon";a:4:{s:1:"C";s:2:"58";s:2:"WX";s:3:"600";s:1:"N";s:5:"colon";s:1:"B";a:4:{i:0;s:3:"229";i:1;s:3:"-15";i:2;s:3:"371";i:3;s:3:"385";}}i:59;a:4:{s:1:"C";s:2:"59";s:2:"WX";s:3:"600";s:1:"N";s:9:"semicolon";s:1:"B";a:4:{i:0;s:3:"181";i:1;s:4:"-112";i:2;s:3:"371";i:3;s:3:"385";}}s:9:"semicolon";a:4:{s:1:"C";s:2:"59";s:2:"WX";s:3:"600";s:1:"N";s:9:"semicolon";s:1:"B";a:4:{i:0;s:3:"181";i:1;s:4:"-112";i:2;s:3:"371";i:3;s:3:"385";}}i:60;a:4:{s:1:"C";s:2:"60";s:2:"WX";s:3:"600";s:1:"N";s:4:"less";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:2:"42";i:2;s:3:"519";i:3;s:3:"472";}}s:4:"less";a:4:{s:1:"C";s:2:"60";s:2:"WX";s:3:"600";s:1:"N";s:4:"less";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:2:"42";i:2;s:3:"519";i:3;s:3:"472";}}i:61;a:4:{s:1:"C";s:2:"61";s:2:"WX";s:3:"600";s:1:"N";s:5:"equal";s:1:"B";a:4:{i:0;s:2:"80";i:1;s:3:"138";i:2;s:3:"520";i:3;s:3:"376";}}s:5:"equal";a:4:{s:1:"C";s:2:"61";s:2:"WX";s:3:"600";s:1:"N";s:5:"equal";s:1:"B";a:4:{i:0;s:2:"80";i:1;s:3:"138";i:2;s:3:"520";i:3;s:3:"376";}}i:62;a:4:{s:1:"C";s:2:"62";s:2:"WX";s:3:"600";s:1:"N";s:7:"greater";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:2:"42";i:2;s:3:"544";i:3;s:3:"472";}}s:7:"greater";a:4:{s:1:"C";s:2:"62";s:2:"WX";s:3:"600";s:1:"N";s:7:"greater";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:2:"42";i:2;s:3:"544";i:3;s:3:"472";}}i:63;a:4:{s:1:"C";s:2:"63";s:2:"WX";s:3:"600";s:1:"N";s:8:"question";s:1:"B";a:4:{i:0;s:3:"129";i:1;s:3:"-15";i:2;s:3:"492";i:3;s:3:"572";}}s:8:"question";a:4:{s:1:"C";s:2:"63";s:2:"WX";s:3:"600";s:1:"N";s:8:"question";s:1:"B";a:4:{i:0;s:3:"129";i:1;s:3:"-15";i:2;s:3:"492";i:3;s:3:"572";}}i:64;a:4:{s:1:"C";s:2:"64";s:2:"WX";s:3:"600";s:1:"N";s:2:"at";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:3:"-15";i:2;s:3:"533";i:3;s:3:"622";}}s:2:"at";a:4:{s:1:"C";s:2:"64";s:2:"WX";s:3:"600";s:1:"N";s:2:"at";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:3:"-15";i:2;s:3:"533";i:3;s:3:"622";}}i:65;a:4:{s:1:"C";s:2:"65";s:2:"WX";s:3:"600";s:1:"N";s:1:"A";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:1:"0";i:2;s:3:"597";i:3;s:3:"562";}}s:1:"A";a:4:{s:1:"C";s:2:"65";s:2:"WX";s:3:"600";s:1:"N";s:1:"A";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:1:"0";i:2;s:3:"597";i:3;s:3:"562";}}i:66;a:4:{s:1:"C";s:2:"66";s:2:"WX";s:3:"600";s:1:"N";s:1:"B";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:1:"0";i:2;s:3:"559";i:3;s:3:"562";}}s:1:"B";a:4:{s:1:"C";s:2:"66";s:2:"WX";s:3:"600";s:1:"N";s:1:"B";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:1:"0";i:2;s:3:"559";i:3;s:3:"562";}}i:67;a:4:{s:1:"C";s:2:"67";s:2:"WX";s:3:"600";s:1:"N";s:1:"C";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:3:"-18";i:2;s:3:"540";i:3;s:3:"580";}}s:1:"C";a:4:{s:1:"C";s:2:"67";s:2:"WX";s:3:"600";s:1:"N";s:1:"C";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:3:"-18";i:2;s:3:"540";i:3;s:3:"580";}}i:68;a:4:{s:1:"C";s:2:"68";s:2:"WX";s:3:"600";s:1:"N";s:1:"D";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:1:"0";i:2;s:3:"574";i:3;s:3:"562";}}s:1:"D";a:4:{s:1:"C";s:2:"68";s:2:"WX";s:3:"600";s:1:"N";s:1:"D";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:1:"0";i:2;s:3:"574";i:3;s:3:"562";}}i:69;a:4:{s:1:"C";s:2:"69";s:2:"WX";s:3:"600";s:1:"N";s:1:"E";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:1:"0";i:2;s:3:"550";i:3;s:3:"562";}}s:1:"E";a:4:{s:1:"C";s:2:"69";s:2:"WX";s:3:"600";s:1:"N";s:1:"E";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:1:"0";i:2;s:3:"550";i:3;s:3:"562";}}i:70;a:4:{s:1:"C";s:2:"70";s:2:"WX";s:3:"600";s:1:"N";s:1:"F";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:1:"0";i:2;s:3:"545";i:3;s:3:"562";}}s:1:"F";a:4:{s:1:"C";s:2:"70";s:2:"WX";s:3:"600";s:1:"N";s:1:"F";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:1:"0";i:2;s:3:"545";i:3;s:3:"562";}}i:71;a:4:{s:1:"C";s:2:"71";s:2:"WX";s:3:"600";s:1:"N";s:1:"G";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:3:"-18";i:2;s:3:"575";i:3;s:3:"580";}}s:1:"G";a:4:{s:1:"C";s:2:"71";s:2:"WX";s:3:"600";s:1:"N";s:1:"G";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:3:"-18";i:2;s:3:"575";i:3;s:3:"580";}}i:72;a:4:{s:1:"C";s:2:"72";s:2:"WX";s:3:"600";s:1:"N";s:1:"H";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:1:"0";i:2;s:3:"568";i:3;s:3:"562";}}s:1:"H";a:4:{s:1:"C";s:2:"72";s:2:"WX";s:3:"600";s:1:"N";s:1:"H";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:1:"0";i:2;s:3:"568";i:3;s:3:"562";}}i:73;a:4:{s:1:"C";s:2:"73";s:2:"WX";s:3:"600";s:1:"N";s:1:"I";s:1:"B";a:4:{i:0;s:2:"96";i:1;s:1:"0";i:2;s:3:"504";i:3;s:3:"562";}}s:1:"I";a:4:{s:1:"C";s:2:"73";s:2:"WX";s:3:"600";s:1:"N";s:1:"I";s:1:"B";a:4:{i:0;s:2:"96";i:1;s:1:"0";i:2;s:3:"504";i:3;s:3:"562";}}i:74;a:4:{s:1:"C";s:2:"74";s:2:"WX";s:3:"600";s:1:"N";s:1:"J";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-18";i:2;s:3:"566";i:3;s:3:"562";}}s:1:"J";a:4:{s:1:"C";s:2:"74";s:2:"WX";s:3:"600";s:1:"N";s:1:"J";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-18";i:2;s:3:"566";i:3;s:3:"562";}}i:75;a:4:{s:1:"C";s:2:"75";s:2:"WX";s:3:"600";s:1:"N";s:1:"K";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:1:"0";i:2;s:3:"582";i:3;s:3:"562";}}s:1:"K";a:4:{s:1:"C";s:2:"75";s:2:"WX";s:3:"600";s:1:"N";s:1:"K";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:1:"0";i:2;s:3:"582";i:3;s:3:"562";}}i:76;a:4:{s:1:"C";s:2:"76";s:2:"WX";s:3:"600";s:1:"N";s:1:"L";s:1:"B";a:4:{i:0;s:2:"47";i:1;s:1:"0";i:2;s:3:"554";i:3;s:3:"562";}}s:1:"L";a:4:{s:1:"C";s:2:"76";s:2:"WX";s:3:"600";s:1:"N";s:1:"L";s:1:"B";a:4:{i:0;s:2:"47";i:1;s:1:"0";i:2;s:3:"554";i:3;s:3:"562";}}i:77;a:4:{s:1:"C";s:2:"77";s:2:"WX";s:3:"600";s:1:"N";s:1:"M";s:1:"B";a:4:{i:0;s:1:"4";i:1;s:1:"0";i:2;s:3:"596";i:3;s:3:"562";}}s:1:"M";a:4:{s:1:"C";s:2:"77";s:2:"WX";s:3:"600";s:1:"N";s:1:"M";s:1:"B";a:4:{i:0;s:1:"4";i:1;s:1:"0";i:2;s:3:"596";i:3;s:3:"562";}}i:78;a:4:{s:1:"C";s:2:"78";s:2:"WX";s:3:"600";s:1:"N";s:1:"N";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:3:"-13";i:2;s:3:"593";i:3;s:3:"562";}}s:1:"N";a:4:{s:1:"C";s:2:"78";s:2:"WX";s:3:"600";s:1:"N";s:1:"N";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:3:"-13";i:2;s:3:"593";i:3;s:3:"562";}}i:79;a:4:{s:1:"C";s:2:"79";s:2:"WX";s:3:"600";s:1:"N";s:1:"O";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:3:"-18";i:2;s:3:"557";i:3;s:3:"580";}}s:1:"O";a:4:{s:1:"C";s:2:"79";s:2:"WX";s:3:"600";s:1:"N";s:1:"O";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:3:"-18";i:2;s:3:"557";i:3;s:3:"580";}}i:80;a:4:{s:1:"C";s:2:"80";s:2:"WX";s:3:"600";s:1:"N";s:1:"P";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:1:"0";i:2;s:3:"558";i:3;s:3:"562";}}s:1:"P";a:4:{s:1:"C";s:2:"80";s:2:"WX";s:3:"600";s:1:"N";s:1:"P";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:1:"0";i:2;s:3:"558";i:3;s:3:"562";}}i:81;a:4:{s:1:"C";s:2:"81";s:2:"WX";s:3:"600";s:1:"N";s:1:"Q";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:4:"-138";i:2;s:3:"557";i:3;s:3:"580";}}s:1:"Q";a:4:{s:1:"C";s:2:"81";s:2:"WX";s:3:"600";s:1:"N";s:1:"Q";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:4:"-138";i:2;s:3:"557";i:3;s:3:"580";}}i:82;a:4:{s:1:"C";s:2:"82";s:2:"WX";s:3:"600";s:1:"N";s:1:"R";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:1:"0";i:2;s:3:"588";i:3;s:3:"562";}}s:1:"R";a:4:{s:1:"C";s:2:"82";s:2:"WX";s:3:"600";s:1:"N";s:1:"R";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:1:"0";i:2;s:3:"588";i:3;s:3:"562";}}i:83;a:4:{s:1:"C";s:2:"83";s:2:"WX";s:3:"600";s:1:"N";s:1:"S";s:1:"B";a:4:{i:0;s:2:"72";i:1;s:3:"-20";i:2;s:3:"529";i:3;s:3:"580";}}s:1:"S";a:4:{s:1:"C";s:2:"83";s:2:"WX";s:3:"600";s:1:"N";s:1:"S";s:1:"B";a:4:{i:0;s:2:"72";i:1;s:3:"-20";i:2;s:3:"529";i:3;s:3:"580";}}i:84;a:4:{s:1:"C";s:2:"84";s:2:"WX";s:3:"600";s:1:"N";s:1:"T";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:1:"0";i:2;s:3:"563";i:3;s:3:"562";}}s:1:"T";a:4:{s:1:"C";s:2:"84";s:2:"WX";s:3:"600";s:1:"N";s:1:"T";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:1:"0";i:2;s:3:"563";i:3;s:3:"562";}}i:85;a:4:{s:1:"C";s:2:"85";s:2:"WX";s:3:"600";s:1:"N";s:1:"U";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:3:"-18";i:2;s:3:"583";i:3;s:3:"562";}}s:1:"U";a:4:{s:1:"C";s:2:"85";s:2:"WX";s:3:"600";s:1:"N";s:1:"U";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:3:"-18";i:2;s:3:"583";i:3;s:3:"562";}}i:86;a:4:{s:1:"C";s:2:"86";s:2:"WX";s:3:"600";s:1:"N";s:1:"V";s:1:"B";a:4:{i:0;s:2:"-4";i:1;s:3:"-13";i:2;s:3:"604";i:3;s:3:"562";}}s:1:"V";a:4:{s:1:"C";s:2:"86";s:2:"WX";s:3:"600";s:1:"N";s:1:"V";s:1:"B";a:4:{i:0;s:2:"-4";i:1;s:3:"-13";i:2;s:3:"604";i:3;s:3:"562";}}i:87;a:4:{s:1:"C";s:2:"87";s:2:"WX";s:3:"600";s:1:"N";s:1:"W";s:1:"B";a:4:{i:0;s:2:"-3";i:1;s:3:"-13";i:2;s:3:"603";i:3;s:3:"562";}}s:1:"W";a:4:{s:1:"C";s:2:"87";s:2:"WX";s:3:"600";s:1:"N";s:1:"W";s:1:"B";a:4:{i:0;s:2:"-3";i:1;s:3:"-13";i:2;s:3:"603";i:3;s:3:"562";}}i:88;a:4:{s:1:"C";s:2:"88";s:2:"WX";s:3:"600";s:1:"N";s:1:"X";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:1:"0";i:2;s:3:"577";i:3;s:3:"562";}}s:1:"X";a:4:{s:1:"C";s:2:"88";s:2:"WX";s:3:"600";s:1:"N";s:1:"X";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:1:"0";i:2;s:3:"577";i:3;s:3:"562";}}i:89;a:4:{s:1:"C";s:2:"89";s:2:"WX";s:3:"600";s:1:"N";s:1:"Y";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:1:"0";i:2;s:3:"576";i:3;s:3:"562";}}s:1:"Y";a:4:{s:1:"C";s:2:"89";s:2:"WX";s:3:"600";s:1:"N";s:1:"Y";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:1:"0";i:2;s:3:"576";i:3;s:3:"562";}}i:90;a:4:{s:1:"C";s:2:"90";s:2:"WX";s:3:"600";s:1:"N";s:1:"Z";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"514";i:3;s:3:"562";}}s:1:"Z";a:4:{s:1:"C";s:2:"90";s:2:"WX";s:3:"600";s:1:"N";s:1:"Z";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"514";i:3;s:3:"562";}}i:91;a:4:{s:1:"C";s:2:"91";s:2:"WX";s:3:"600";s:1:"N";s:11:"bracketleft";s:1:"B";a:4:{i:0;s:3:"269";i:1;s:4:"-108";i:2;s:3:"442";i:3;s:3:"622";}}s:11:"bracketleft";a:4:{s:1:"C";s:2:"91";s:2:"WX";s:3:"600";s:1:"N";s:11:"bracketleft";s:1:"B";a:4:{i:0;s:3:"269";i:1;s:4:"-108";i:2;s:3:"442";i:3;s:3:"622";}}i:92;a:4:{s:1:"C";s:2:"92";s:2:"WX";s:3:"600";s:1:"N";s:9:"backslash";s:1:"B";a:4:{i:0;s:3:"118";i:1;s:3:"-80";i:2;s:3:"482";i:3;s:3:"629";}}s:9:"backslash";a:4:{s:1:"C";s:2:"92";s:2:"WX";s:3:"600";s:1:"N";s:9:"backslash";s:1:"B";a:4:{i:0;s:3:"118";i:1;s:3:"-80";i:2;s:3:"482";i:3;s:3:"629";}}i:93;a:4:{s:1:"C";s:2:"93";s:2:"WX";s:3:"600";s:1:"N";s:12:"bracketright";s:1:"B";a:4:{i:0;s:3:"158";i:1;s:4:"-108";i:2;s:3:"331";i:3;s:3:"622";}}s:12:"bracketright";a:4:{s:1:"C";s:2:"93";s:2:"WX";s:3:"600";s:1:"N";s:12:"bracketright";s:1:"B";a:4:{i:0;s:3:"158";i:1;s:4:"-108";i:2;s:3:"331";i:3;s:3:"622";}}i:94;a:4:{s:1:"C";s:2:"94";s:2:"WX";s:3:"600";s:1:"N";s:11:"asciicircum";s:1:"B";a:4:{i:0;s:2:"94";i:1;s:3:"354";i:2;s:3:"506";i:3;s:3:"622";}}s:11:"asciicircum";a:4:{s:1:"C";s:2:"94";s:2:"WX";s:3:"600";s:1:"N";s:11:"asciicircum";s:1:"B";a:4:{i:0;s:2:"94";i:1;s:3:"354";i:2;s:3:"506";i:3;s:3:"622";}}i:95;a:4:{s:1:"C";s:2:"95";s:2:"WX";s:3:"600";s:1:"N";s:10:"underscore";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:4:"-125";i:2;s:3:"600";i:3;s:3:"-75";}}s:10:"underscore";a:4:{s:1:"C";s:2:"95";s:2:"WX";s:3:"600";s:1:"N";s:10:"underscore";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:4:"-125";i:2;s:3:"600";i:3;s:3:"-75";}}i:96;a:4:{s:1:"C";s:2:"96";s:2:"WX";s:3:"600";s:1:"N";s:9:"quoteleft";s:1:"B";a:4:{i:0;s:3:"224";i:1;s:3:"328";i:2;s:3:"387";i:3;s:3:"562";}}s:9:"quoteleft";a:4:{s:1:"C";s:2:"96";s:2:"WX";s:3:"600";s:1:"N";s:9:"quoteleft";s:1:"B";a:4:{i:0;s:3:"224";i:1;s:3:"328";i:2;s:3:"387";i:3;s:3:"562";}}i:97;a:4:{s:1:"C";s:2:"97";s:2:"WX";s:3:"600";s:1:"N";s:1:"a";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:3:"-15";i:2;s:3:"559";i:3;s:3:"441";}}s:1:"a";a:4:{s:1:"C";s:2:"97";s:2:"WX";s:3:"600";s:1:"N";s:1:"a";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:3:"-15";i:2;s:3:"559";i:3;s:3:"441";}}i:98;a:4:{s:1:"C";s:2:"98";s:2:"WX";s:3:"600";s:1:"N";s:1:"b";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:3:"-15";i:2;s:3:"575";i:3;s:3:"629";}}s:1:"b";a:4:{s:1:"C";s:2:"98";s:2:"WX";s:3:"600";s:1:"N";s:1:"b";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:3:"-15";i:2;s:3:"575";i:3;s:3:"629";}}i:99;a:4:{s:1:"C";s:2:"99";s:2:"WX";s:3:"600";s:1:"N";s:1:"c";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:3:"-15";i:2;s:3:"529";i:3;s:3:"441";}}s:1:"c";a:4:{s:1:"C";s:2:"99";s:2:"WX";s:3:"600";s:1:"N";s:1:"c";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:3:"-15";i:2;s:3:"529";i:3;s:3:"441";}}i:100;a:4:{s:1:"C";s:3:"100";s:2:"WX";s:3:"600";s:1:"N";s:1:"d";s:1:"B";a:4:{i:0;s:2:"45";i:1;s:3:"-15";i:2;s:3:"591";i:3;s:3:"629";}}s:1:"d";a:4:{s:1:"C";s:3:"100";s:2:"WX";s:3:"600";s:1:"N";s:1:"d";s:1:"B";a:4:{i:0;s:2:"45";i:1;s:3:"-15";i:2;s:3:"591";i:3;s:3:"629";}}i:101;a:4:{s:1:"C";s:3:"101";s:2:"WX";s:3:"600";s:1:"N";s:1:"e";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:3:"-15";i:2;s:3:"548";i:3;s:3:"441";}}s:1:"e";a:4:{s:1:"C";s:3:"101";s:2:"WX";s:3:"600";s:1:"N";s:1:"e";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:3:"-15";i:2;s:3:"548";i:3;s:3:"441";}}i:102;a:5:{s:1:"C";s:3:"102";s:2:"WX";s:3:"600";s:1:"N";s:1:"f";s:1:"B";a:4:{i:0;s:3:"114";i:1;s:1:"0";i:2;s:3:"531";i:3;s:3:"629";}s:1:"L";a:2:{i:0;s:1:"l";i:1;s:2:"fl";}}s:1:"f";a:5:{s:1:"C";s:3:"102";s:2:"WX";s:3:"600";s:1:"N";s:1:"f";s:1:"B";a:4:{i:0;s:3:"114";i:1;s:1:"0";i:2;s:3:"531";i:3;s:3:"629";}s:1:"L";a:2:{i:0;s:1:"l";i:1;s:2:"fl";}}i:103;a:4:{s:1:"C";s:3:"103";s:2:"WX";s:3:"600";s:1:"N";s:1:"g";s:1:"B";a:4:{i:0;s:2:"45";i:1;s:4:"-157";i:2;s:3:"566";i:3;s:3:"441";}}s:1:"g";a:4:{s:1:"C";s:3:"103";s:2:"WX";s:3:"600";s:1:"N";s:1:"g";s:1:"B";a:4:{i:0;s:2:"45";i:1;s:4:"-157";i:2;s:3:"566";i:3;s:3:"441";}}i:104;a:4:{s:1:"C";s:3:"104";s:2:"WX";s:3:"600";s:1:"N";s:1:"h";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:1:"0";i:2;s:3:"582";i:3;s:3:"629";}}s:1:"h";a:4:{s:1:"C";s:3:"104";s:2:"WX";s:3:"600";s:1:"N";s:1:"h";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:1:"0";i:2;s:3:"582";i:3;s:3:"629";}}i:105;a:4:{s:1:"C";s:3:"105";s:2:"WX";s:3:"600";s:1:"N";s:1:"i";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:1:"0";i:2;s:3:"505";i:3;s:3:"657";}}s:1:"i";a:4:{s:1:"C";s:3:"105";s:2:"WX";s:3:"600";s:1:"N";s:1:"i";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:1:"0";i:2;s:3:"505";i:3;s:3:"657";}}i:106;a:4:{s:1:"C";s:3:"106";s:2:"WX";s:3:"600";s:1:"N";s:1:"j";s:1:"B";a:4:{i:0;s:2:"82";i:1;s:4:"-157";i:2;s:3:"410";i:3;s:3:"657";}}s:1:"j";a:4:{s:1:"C";s:3:"106";s:2:"WX";s:3:"600";s:1:"N";s:1:"j";s:1:"B";a:4:{i:0;s:2:"82";i:1;s:4:"-157";i:2;s:3:"410";i:3;s:3:"657";}}i:107;a:4:{s:1:"C";s:3:"107";s:2:"WX";s:3:"600";s:1:"N";s:1:"k";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:1:"0";i:2;s:3:"580";i:3;s:3:"629";}}s:1:"k";a:4:{s:1:"C";s:3:"107";s:2:"WX";s:3:"600";s:1:"N";s:1:"k";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:1:"0";i:2;s:3:"580";i:3;s:3:"629";}}i:108;a:4:{s:1:"C";s:3:"108";s:2:"WX";s:3:"600";s:1:"N";s:1:"l";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:1:"0";i:2;s:3:"505";i:3;s:3:"629";}}s:1:"l";a:4:{s:1:"C";s:3:"108";s:2:"WX";s:3:"600";s:1:"N";s:1:"l";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:1:"0";i:2;s:3:"505";i:3;s:3:"629";}}i:109;a:4:{s:1:"C";s:3:"109";s:2:"WX";s:3:"600";s:1:"N";s:1:"m";s:1:"B";a:4:{i:0;s:2:"-5";i:1;s:1:"0";i:2;s:3:"605";i:3;s:3:"441";}}s:1:"m";a:4:{s:1:"C";s:3:"109";s:2:"WX";s:3:"600";s:1:"N";s:1:"m";s:1:"B";a:4:{i:0;s:2:"-5";i:1;s:1:"0";i:2;s:3:"605";i:3;s:3:"441";}}i:110;a:4:{s:1:"C";s:3:"110";s:2:"WX";s:3:"600";s:1:"N";s:1:"n";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"575";i:3;s:3:"441";}}s:1:"n";a:4:{s:1:"C";s:3:"110";s:2:"WX";s:3:"600";s:1:"N";s:1:"n";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"575";i:3;s:3:"441";}}i:111;a:4:{s:1:"C";s:3:"111";s:2:"WX";s:3:"600";s:1:"N";s:1:"o";s:1:"B";a:4:{i:0;s:2:"62";i:1;s:3:"-15";i:2;s:3:"538";i:3;s:3:"441";}}s:1:"o";a:4:{s:1:"C";s:3:"111";s:2:"WX";s:3:"600";s:1:"N";s:1:"o";s:1:"B";a:4:{i:0;s:2:"62";i:1;s:3:"-15";i:2;s:3:"538";i:3;s:3:"441";}}i:112;a:4:{s:1:"C";s:3:"112";s:2:"WX";s:3:"600";s:1:"N";s:1:"p";s:1:"B";a:4:{i:0;s:1:"9";i:1;s:4:"-157";i:2;s:3:"555";i:3;s:3:"441";}}s:1:"p";a:4:{s:1:"C";s:3:"112";s:2:"WX";s:3:"600";s:1:"N";s:1:"p";s:1:"B";a:4:{i:0;s:1:"9";i:1;s:4:"-157";i:2;s:3:"555";i:3;s:3:"441";}}i:113;a:4:{s:1:"C";s:3:"113";s:2:"WX";s:3:"600";s:1:"N";s:1:"q";s:1:"B";a:4:{i:0;s:2:"45";i:1;s:4:"-157";i:2;s:3:"591";i:3;s:3:"441";}}s:1:"q";a:4:{s:1:"C";s:3:"113";s:2:"WX";s:3:"600";s:1:"N";s:1:"q";s:1:"B";a:4:{i:0;s:2:"45";i:1;s:4:"-157";i:2;s:3:"591";i:3;s:3:"441";}}i:114;a:4:{s:1:"C";s:3:"114";s:2:"WX";s:3:"600";s:1:"N";s:1:"r";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:1:"0";i:2;s:3:"559";i:3;s:3:"441";}}s:1:"r";a:4:{s:1:"C";s:3:"114";s:2:"WX";s:3:"600";s:1:"N";s:1:"r";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:1:"0";i:2;s:3:"559";i:3;s:3:"441";}}i:115;a:4:{s:1:"C";s:3:"115";s:2:"WX";s:3:"600";s:1:"N";s:1:"s";s:1:"B";a:4:{i:0;s:2:"80";i:1;s:3:"-15";i:2;s:3:"513";i:3;s:3:"441";}}s:1:"s";a:4:{s:1:"C";s:3:"115";s:2:"WX";s:3:"600";s:1:"N";s:1:"s";s:1:"B";a:4:{i:0;s:2:"80";i:1;s:3:"-15";i:2;s:3:"513";i:3;s:3:"441";}}i:116;a:4:{s:1:"C";s:3:"116";s:2:"WX";s:3:"600";s:1:"N";s:1:"t";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:3:"-15";i:2;s:3:"530";i:3;s:3:"561";}}s:1:"t";a:4:{s:1:"C";s:3:"116";s:2:"WX";s:3:"600";s:1:"N";s:1:"t";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:3:"-15";i:2;s:3:"530";i:3;s:3:"561";}}i:117;a:4:{s:1:"C";s:3:"117";s:2:"WX";s:3:"600";s:1:"N";s:1:"u";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:3:"-15";i:2;s:3:"562";i:3;s:3:"426";}}s:1:"u";a:4:{s:1:"C";s:3:"117";s:2:"WX";s:3:"600";s:1:"N";s:1:"u";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:3:"-15";i:2;s:3:"562";i:3;s:3:"426";}}i:118;a:4:{s:1:"C";s:3:"118";s:2:"WX";s:3:"600";s:1:"N";s:1:"v";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:3:"-10";i:2;s:3:"590";i:3;s:3:"426";}}s:1:"v";a:4:{s:1:"C";s:3:"118";s:2:"WX";s:3:"600";s:1:"N";s:1:"v";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:3:"-10";i:2;s:3:"590";i:3;s:3:"426";}}i:119;a:4:{s:1:"C";s:3:"119";s:2:"WX";s:3:"600";s:1:"N";s:1:"w";s:1:"B";a:4:{i:0;s:2:"-4";i:1;s:3:"-10";i:2;s:3:"604";i:3;s:3:"426";}}s:1:"w";a:4:{s:1:"C";s:3:"119";s:2:"WX";s:3:"600";s:1:"N";s:1:"w";s:1:"B";a:4:{i:0;s:2:"-4";i:1;s:3:"-10";i:2;s:3:"604";i:3;s:3:"426";}}i:120;a:4:{s:1:"C";s:3:"120";s:2:"WX";s:3:"600";s:1:"N";s:1:"x";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"580";i:3;s:3:"426";}}s:1:"x";a:4:{s:1:"C";s:3:"120";s:2:"WX";s:3:"600";s:1:"N";s:1:"x";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"580";i:3;s:3:"426";}}i:121;a:4:{s:1:"C";s:3:"121";s:2:"WX";s:3:"600";s:1:"N";s:1:"y";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:4:"-157";i:2;s:3:"592";i:3;s:3:"426";}}s:1:"y";a:4:{s:1:"C";s:3:"121";s:2:"WX";s:3:"600";s:1:"N";s:1:"y";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:4:"-157";i:2;s:3:"592";i:3;s:3:"426";}}i:122;a:4:{s:1:"C";s:3:"122";s:2:"WX";s:3:"600";s:1:"N";s:1:"z";s:1:"B";a:4:{i:0;s:2:"99";i:1;s:1:"0";i:2;s:3:"502";i:3;s:3:"426";}}s:1:"z";a:4:{s:1:"C";s:3:"122";s:2:"WX";s:3:"600";s:1:"N";s:1:"z";s:1:"B";a:4:{i:0;s:2:"99";i:1;s:1:"0";i:2;s:3:"502";i:3;s:3:"426";}}i:123;a:4:{s:1:"C";s:3:"123";s:2:"WX";s:3:"600";s:1:"N";s:9:"braceleft";s:1:"B";a:4:{i:0;s:3:"182";i:1;s:4:"-108";i:2;s:3:"437";i:3;s:3:"622";}}s:9:"braceleft";a:4:{s:1:"C";s:3:"123";s:2:"WX";s:3:"600";s:1:"N";s:9:"braceleft";s:1:"B";a:4:{i:0;s:3:"182";i:1;s:4:"-108";i:2;s:3:"437";i:3;s:3:"622";}}i:124;a:4:{s:1:"C";s:3:"124";s:2:"WX";s:3:"600";s:1:"N";s:3:"bar";s:1:"B";a:4:{i:0;s:3:"275";i:1;s:4:"-250";i:2;s:3:"326";i:3;s:3:"750";}}s:3:"bar";a:4:{s:1:"C";s:3:"124";s:2:"WX";s:3:"600";s:1:"N";s:3:"bar";s:1:"B";a:4:{i:0;s:3:"275";i:1;s:4:"-250";i:2;s:3:"326";i:3;s:3:"750";}}i:125;a:4:{s:1:"C";s:3:"125";s:2:"WX";s:3:"600";s:1:"N";s:10:"braceright";s:1:"B";a:4:{i:0;s:3:"163";i:1;s:4:"-108";i:2;s:3:"418";i:3;s:3:"622";}}s:10:"braceright";a:4:{s:1:"C";s:3:"125";s:2:"WX";s:3:"600";s:1:"N";s:10:"braceright";s:1:"B";a:4:{i:0;s:3:"163";i:1;s:4:"-108";i:2;s:3:"418";i:3;s:3:"622";}}i:126;a:4:{s:1:"C";s:3:"126";s:2:"WX";s:3:"600";s:1:"N";s:10:"asciitilde";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:3:"197";i:2;s:3:"540";i:3;s:3:"320";}}s:10:"asciitilde";a:4:{s:1:"C";s:3:"126";s:2:"WX";s:3:"600";s:1:"N";s:10:"asciitilde";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:3:"197";i:2;s:3:"540";i:3;s:3:"320";}}i:161;a:4:{s:1:"C";s:3:"161";s:2:"WX";s:3:"600";s:1:"N";s:10:"exclamdown";s:1:"B";a:4:{i:0;s:3:"236";i:1;s:4:"-157";i:2;s:3:"364";i:3;s:3:"430";}}s:10:"exclamdown";a:4:{s:1:"C";s:3:"161";s:2:"WX";s:3:"600";s:1:"N";s:10:"exclamdown";s:1:"B";a:4:{i:0;s:3:"236";i:1;s:4:"-157";i:2;s:3:"364";i:3;s:3:"430";}}i:162;a:4:{s:1:"C";s:3:"162";s:2:"WX";s:3:"600";s:1:"N";s:4:"cent";s:1:"B";a:4:{i:0;s:2:"96";i:1;s:3:"-49";i:2;s:3:"500";i:3;s:3:"614";}}s:4:"cent";a:4:{s:1:"C";s:3:"162";s:2:"WX";s:3:"600";s:1:"N";s:4:"cent";s:1:"B";a:4:{i:0;s:2:"96";i:1;s:3:"-49";i:2;s:3:"500";i:3;s:3:"614";}}i:163;a:4:{s:1:"C";s:3:"163";s:2:"WX";s:3:"600";s:1:"N";s:8:"sterling";s:1:"B";a:4:{i:0;s:2:"84";i:1;s:3:"-21";i:2;s:3:"521";i:3;s:3:"611";}}s:8:"sterling";a:4:{s:1:"C";s:3:"163";s:2:"WX";s:3:"600";s:1:"N";s:8:"sterling";s:1:"B";a:4:{i:0;s:2:"84";i:1;s:3:"-21";i:2;s:3:"521";i:3;s:3:"611";}}i:164;a:4:{s:1:"C";s:3:"164";s:2:"WX";s:3:"600";s:1:"N";s:8:"fraction";s:1:"B";a:4:{i:0;s:2:"92";i:1;s:3:"-57";i:2;s:3:"509";i:3;s:3:"665";}}s:8:"fraction";a:4:{s:1:"C";s:3:"164";s:2:"WX";s:3:"600";s:1:"N";s:8:"fraction";s:1:"B";a:4:{i:0;s:2:"92";i:1;s:3:"-57";i:2;s:3:"509";i:3;s:3:"665";}}i:165;a:4:{s:1:"C";s:3:"165";s:2:"WX";s:3:"600";s:1:"N";s:3:"yen";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"574";i:3;s:3:"562";}}s:3:"yen";a:4:{s:1:"C";s:3:"165";s:2:"WX";s:3:"600";s:1:"N";s:3:"yen";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"574";i:3;s:3:"562";}}i:166;a:4:{s:1:"C";s:3:"166";s:2:"WX";s:3:"600";s:1:"N";s:6:"florin";s:1:"B";a:4:{i:0;s:1:"4";i:1;s:4:"-143";i:2;s:3:"539";i:3;s:3:"622";}}s:6:"florin";a:4:{s:1:"C";s:3:"166";s:2:"WX";s:3:"600";s:1:"N";s:6:"florin";s:1:"B";a:4:{i:0;s:1:"4";i:1;s:4:"-143";i:2;s:3:"539";i:3;s:3:"622";}}i:167;a:4:{s:1:"C";s:3:"167";s:2:"WX";s:3:"600";s:1:"N";s:7:"section";s:1:"B";a:4:{i:0;s:3:"113";i:1;s:3:"-78";i:2;s:3:"488";i:3;s:3:"580";}}s:7:"section";a:4:{s:1:"C";s:3:"167";s:2:"WX";s:3:"600";s:1:"N";s:7:"section";s:1:"B";a:4:{i:0;s:3:"113";i:1;s:3:"-78";i:2;s:3:"488";i:3;s:3:"580";}}i:168;a:4:{s:1:"C";s:3:"168";s:2:"WX";s:3:"600";s:1:"N";s:8:"currency";s:1:"B";a:4:{i:0;s:2:"73";i:1;s:2:"58";i:2;s:3:"527";i:3;s:3:"506";}}s:8:"currency";a:4:{s:1:"C";s:3:"168";s:2:"WX";s:3:"600";s:1:"N";s:8:"currency";s:1:"B";a:4:{i:0;s:2:"73";i:1;s:2:"58";i:2;s:3:"527";i:3;s:3:"506";}}i:169;a:4:{s:1:"C";s:3:"169";s:2:"WX";s:3:"600";s:1:"N";s:11:"quotesingle";s:1:"B";a:4:{i:0;s:3:"259";i:1;s:3:"328";i:2;s:3:"341";i:3;s:3:"562";}}s:11:"quotesingle";a:4:{s:1:"C";s:3:"169";s:2:"WX";s:3:"600";s:1:"N";s:11:"quotesingle";s:1:"B";a:4:{i:0;s:3:"259";i:1;s:3:"328";i:2;s:3:"341";i:3;s:3:"562";}}i:170;a:4:{s:1:"C";s:3:"170";s:2:"WX";s:3:"600";s:1:"N";s:12:"quotedblleft";s:1:"B";a:4:{i:0;s:3:"143";i:1;s:3:"328";i:2;s:3:"471";i:3;s:3:"562";}}s:12:"quotedblleft";a:4:{s:1:"C";s:3:"170";s:2:"WX";s:3:"600";s:1:"N";s:12:"quotedblleft";s:1:"B";a:4:{i:0;s:3:"143";i:1;s:3:"328";i:2;s:3:"471";i:3;s:3:"562";}}i:171;a:4:{s:1:"C";s:3:"171";s:2:"WX";s:3:"600";s:1:"N";s:13:"guillemotleft";s:1:"B";a:4:{i:0;s:2:"37";i:1;s:2:"70";i:2;s:3:"563";i:3;s:3:"446";}}s:13:"guillemotleft";a:4:{s:1:"C";s:3:"171";s:2:"WX";s:3:"600";s:1:"N";s:13:"guillemotleft";s:1:"B";a:4:{i:0;s:2:"37";i:1;s:2:"70";i:2;s:3:"563";i:3;s:3:"446";}}i:172;a:4:{s:1:"C";s:3:"172";s:2:"WX";s:3:"600";s:1:"N";s:13:"guilsinglleft";s:1:"B";a:4:{i:0;s:3:"149";i:1;s:2:"70";i:2;s:3:"451";i:3;s:3:"446";}}s:13:"guilsinglleft";a:4:{s:1:"C";s:3:"172";s:2:"WX";s:3:"600";s:1:"N";s:13:"guilsinglleft";s:1:"B";a:4:{i:0;s:3:"149";i:1;s:2:"70";i:2;s:3:"451";i:3;s:3:"446";}}i:173;a:4:{s:1:"C";s:3:"173";s:2:"WX";s:3:"600";s:1:"N";s:14:"guilsinglright";s:1:"B";a:4:{i:0;s:3:"149";i:1;s:2:"70";i:2;s:3:"451";i:3;s:3:"446";}}s:14:"guilsinglright";a:4:{s:1:"C";s:3:"173";s:2:"WX";s:3:"600";s:1:"N";s:14:"guilsinglright";s:1:"B";a:4:{i:0;s:3:"149";i:1;s:2:"70";i:2;s:3:"451";i:3;s:3:"446";}}i:174;a:4:{s:1:"C";s:3:"174";s:2:"WX";s:3:"600";s:1:"N";s:2:"fi";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:1:"0";i:2;s:3:"597";i:3;s:3:"629";}}s:2:"fi";a:4:{s:1:"C";s:3:"174";s:2:"WX";s:3:"600";s:1:"N";s:2:"fi";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:1:"0";i:2;s:3:"597";i:3;s:3:"629";}}i:175;a:4:{s:1:"C";s:3:"175";s:2:"WX";s:3:"600";s:1:"N";s:2:"fl";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:1:"0";i:2;s:3:"597";i:3;s:3:"629";}}s:2:"fl";a:4:{s:1:"C";s:3:"175";s:2:"WX";s:3:"600";s:1:"N";s:2:"fl";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:1:"0";i:2;s:3:"597";i:3;s:3:"629";}}i:177;a:4:{s:1:"C";s:3:"177";s:2:"WX";s:3:"600";s:1:"N";s:6:"endash";s:1:"B";a:4:{i:0;s:2:"75";i:1;s:3:"231";i:2;s:3:"525";i:3;s:3:"285";}}s:6:"endash";a:4:{s:1:"C";s:3:"177";s:2:"WX";s:3:"600";s:1:"N";s:6:"endash";s:1:"B";a:4:{i:0;s:2:"75";i:1;s:3:"231";i:2;s:3:"525";i:3;s:3:"285";}}i:178;a:4:{s:1:"C";s:3:"178";s:2:"WX";s:3:"600";s:1:"N";s:6:"dagger";s:1:"B";a:4:{i:0;s:3:"141";i:1;s:3:"-78";i:2;s:3:"459";i:3;s:3:"580";}}s:6:"dagger";a:4:{s:1:"C";s:3:"178";s:2:"WX";s:3:"600";s:1:"N";s:6:"dagger";s:1:"B";a:4:{i:0;s:3:"141";i:1;s:3:"-78";i:2;s:3:"459";i:3;s:3:"580";}}i:179;a:4:{s:1:"C";s:3:"179";s:2:"WX";s:3:"600";s:1:"N";s:9:"daggerdbl";s:1:"B";a:4:{i:0;s:3:"141";i:1;s:3:"-78";i:2;s:3:"459";i:3;s:3:"580";}}s:9:"daggerdbl";a:4:{s:1:"C";s:3:"179";s:2:"WX";s:3:"600";s:1:"N";s:9:"daggerdbl";s:1:"B";a:4:{i:0;s:3:"141";i:1;s:3:"-78";i:2;s:3:"459";i:3;s:3:"580";}}i:180;a:4:{s:1:"C";s:3:"180";s:2:"WX";s:3:"600";s:1:"N";s:14:"periodcentered";s:1:"B";a:4:{i:0;s:3:"222";i:1;s:3:"189";i:2;s:3:"378";i:3;s:3:"327";}}s:14:"periodcentered";a:4:{s:1:"C";s:3:"180";s:2:"WX";s:3:"600";s:1:"N";s:14:"periodcentered";s:1:"B";a:4:{i:0;s:3:"222";i:1;s:3:"189";i:2;s:3:"378";i:3;s:3:"327";}}i:182;a:4:{s:1:"C";s:3:"182";s:2:"WX";s:3:"600";s:1:"N";s:9:"paragraph";s:1:"B";a:4:{i:0;s:2:"50";i:1;s:3:"-78";i:2;s:3:"511";i:3;s:3:"562";}}s:9:"paragraph";a:4:{s:1:"C";s:3:"182";s:2:"WX";s:3:"600";s:1:"N";s:9:"paragraph";s:1:"B";a:4:{i:0;s:2:"50";i:1;s:3:"-78";i:2;s:3:"511";i:3;s:3:"562";}}i:183;a:4:{s:1:"C";s:3:"183";s:2:"WX";s:3:"600";s:1:"N";s:6:"bullet";s:1:"B";a:4:{i:0;s:3:"172";i:1;s:3:"130";i:2;s:3:"428";i:3;s:3:"383";}}s:6:"bullet";a:4:{s:1:"C";s:3:"183";s:2:"WX";s:3:"600";s:1:"N";s:6:"bullet";s:1:"B";a:4:{i:0;s:3:"172";i:1;s:3:"130";i:2;s:3:"428";i:3;s:3:"383";}}i:184;a:4:{s:1:"C";s:3:"184";s:2:"WX";s:3:"600";s:1:"N";s:14:"quotesinglbase";s:1:"B";a:4:{i:0;s:3:"213";i:1;s:4:"-134";i:2;s:3:"376";i:3;s:3:"100";}}s:14:"quotesinglbase";a:4:{s:1:"C";s:3:"184";s:2:"WX";s:3:"600";s:1:"N";s:14:"quotesinglbase";s:1:"B";a:4:{i:0;s:3:"213";i:1;s:4:"-134";i:2;s:3:"376";i:3;s:3:"100";}}i:185;a:4:{s:1:"C";s:3:"185";s:2:"WX";s:3:"600";s:1:"N";s:12:"quotedblbase";s:1:"B";a:4:{i:0;s:3:"143";i:1;s:4:"-134";i:2;s:3:"457";i:3;s:3:"100";}}s:12:"quotedblbase";a:4:{s:1:"C";s:3:"185";s:2:"WX";s:3:"600";s:1:"N";s:12:"quotedblbase";s:1:"B";a:4:{i:0;s:3:"143";i:1;s:4:"-134";i:2;s:3:"457";i:3;s:3:"100";}}i:186;a:4:{s:1:"C";s:3:"186";s:2:"WX";s:3:"600";s:1:"N";s:13:"quotedblright";s:1:"B";a:4:{i:0;s:3:"143";i:1;s:3:"328";i:2;s:3:"457";i:3;s:3:"562";}}s:13:"quotedblright";a:4:{s:1:"C";s:3:"186";s:2:"WX";s:3:"600";s:1:"N";s:13:"quotedblright";s:1:"B";a:4:{i:0;s:3:"143";i:1;s:3:"328";i:2;s:3:"457";i:3;s:3:"562";}}i:187;a:4:{s:1:"C";s:3:"187";s:2:"WX";s:3:"600";s:1:"N";s:14:"guillemotright";s:1:"B";a:4:{i:0;s:2:"37";i:1;s:2:"70";i:2;s:3:"563";i:3;s:3:"446";}}s:14:"guillemotright";a:4:{s:1:"C";s:3:"187";s:2:"WX";s:3:"600";s:1:"N";s:14:"guillemotright";s:1:"B";a:4:{i:0;s:2:"37";i:1;s:2:"70";i:2;s:3:"563";i:3;s:3:"446";}}i:188;a:4:{s:1:"C";s:3:"188";s:2:"WX";s:3:"600";s:1:"N";s:8:"ellipsis";s:1:"B";a:4:{i:0;s:2:"37";i:1;s:3:"-15";i:2;s:3:"563";i:3;s:3:"111";}}s:8:"ellipsis";a:4:{s:1:"C";s:3:"188";s:2:"WX";s:3:"600";s:1:"N";s:8:"ellipsis";s:1:"B";a:4:{i:0;s:2:"37";i:1;s:3:"-15";i:2;s:3:"563";i:3;s:3:"111";}}i:189;a:4:{s:1:"C";s:3:"189";s:2:"WX";s:3:"600";s:1:"N";s:11:"perthousand";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:3:"-15";i:2;s:3:"600";i:3;s:3:"622";}}s:11:"perthousand";a:4:{s:1:"C";s:3:"189";s:2:"WX";s:3:"600";s:1:"N";s:11:"perthousand";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:3:"-15";i:2;s:3:"600";i:3;s:3:"622";}}i:191;a:4:{s:1:"C";s:3:"191";s:2:"WX";s:3:"600";s:1:"N";s:12:"questiondown";s:1:"B";a:4:{i:0;s:3:"108";i:1;s:4:"-157";i:2;s:3:"471";i:3;s:3:"430";}}s:12:"questiondown";a:4:{s:1:"C";s:3:"191";s:2:"WX";s:3:"600";s:1:"N";s:12:"questiondown";s:1:"B";a:4:{i:0;s:3:"108";i:1;s:4:"-157";i:2;s:3:"471";i:3;s:3:"430";}}i:193;a:4:{s:1:"C";s:3:"193";s:2:"WX";s:3:"600";s:1:"N";s:5:"grave";s:1:"B";a:4:{i:0;s:3:"151";i:1;s:3:"497";i:2;s:3:"378";i:3;s:3:"672";}}s:5:"grave";a:4:{s:1:"C";s:3:"193";s:2:"WX";s:3:"600";s:1:"N";s:5:"grave";s:1:"B";a:4:{i:0;s:3:"151";i:1;s:3:"497";i:2;s:3:"378";i:3;s:3:"672";}}i:194;a:4:{s:1:"C";s:3:"194";s:2:"WX";s:3:"600";s:1:"N";s:5:"acute";s:1:"B";a:4:{i:0;s:3:"242";i:1;s:3:"497";i:2;s:3:"469";i:3;s:3:"672";}}s:5:"acute";a:4:{s:1:"C";s:3:"194";s:2:"WX";s:3:"600";s:1:"N";s:5:"acute";s:1:"B";a:4:{i:0;s:3:"242";i:1;s:3:"497";i:2;s:3:"469";i:3;s:3:"672";}}i:195;a:4:{s:1:"C";s:3:"195";s:2:"WX";s:3:"600";s:1:"N";s:10:"circumflex";s:1:"B";a:4:{i:0;s:3:"124";i:1;s:3:"477";i:2;s:3:"476";i:3;s:3:"654";}}s:10:"circumflex";a:4:{s:1:"C";s:3:"195";s:2:"WX";s:3:"600";s:1:"N";s:10:"circumflex";s:1:"B";a:4:{i:0;s:3:"124";i:1;s:3:"477";i:2;s:3:"476";i:3;s:3:"654";}}i:196;a:4:{s:1:"C";s:3:"196";s:2:"WX";s:3:"600";s:1:"N";s:5:"tilde";s:1:"B";a:4:{i:0;s:3:"105";i:1;s:3:"489";i:2;s:3:"503";i:3;s:3:"606";}}s:5:"tilde";a:4:{s:1:"C";s:3:"196";s:2:"WX";s:3:"600";s:1:"N";s:5:"tilde";s:1:"B";a:4:{i:0;s:3:"105";i:1;s:3:"489";i:2;s:3:"503";i:3;s:3:"606";}}i:197;a:4:{s:1:"C";s:3:"197";s:2:"WX";s:3:"600";s:1:"N";s:6:"macron";s:1:"B";a:4:{i:0;s:3:"120";i:1;s:3:"525";i:2;s:3:"480";i:3;s:3:"565";}}s:6:"macron";a:4:{s:1:"C";s:3:"197";s:2:"WX";s:3:"600";s:1:"N";s:6:"macron";s:1:"B";a:4:{i:0;s:3:"120";i:1;s:3:"525";i:2;s:3:"480";i:3;s:3:"565";}}i:198;a:4:{s:1:"C";s:3:"198";s:2:"WX";s:3:"600";s:1:"N";s:5:"breve";s:1:"B";a:4:{i:0;s:3:"153";i:1;s:3:"501";i:2;s:3:"447";i:3;s:3:"609";}}s:5:"breve";a:4:{s:1:"C";s:3:"198";s:2:"WX";s:3:"600";s:1:"N";s:5:"breve";s:1:"B";a:4:{i:0;s:3:"153";i:1;s:3:"501";i:2;s:3:"447";i:3;s:3:"609";}}i:199;a:4:{s:1:"C";s:3:"199";s:2:"WX";s:3:"600";s:1:"N";s:9:"dotaccent";s:1:"B";a:4:{i:0;s:3:"249";i:1;s:3:"537";i:2;s:3:"352";i:3;s:3:"640";}}s:9:"dotaccent";a:4:{s:1:"C";s:3:"199";s:2:"WX";s:3:"600";s:1:"N";s:9:"dotaccent";s:1:"B";a:4:{i:0;s:3:"249";i:1;s:3:"537";i:2;s:3:"352";i:3;s:3:"640";}}i:200;a:4:{s:1:"C";s:3:"200";s:2:"WX";s:3:"600";s:1:"N";s:8:"dieresis";s:1:"B";a:4:{i:0;s:3:"148";i:1;s:3:"537";i:2;s:3:"453";i:3;s:3:"640";}}s:8:"dieresis";a:4:{s:1:"C";s:3:"200";s:2:"WX";s:3:"600";s:1:"N";s:8:"dieresis";s:1:"B";a:4:{i:0;s:3:"148";i:1;s:3:"537";i:2;s:3:"453";i:3;s:3:"640";}}i:202;a:4:{s:1:"C";s:3:"202";s:2:"WX";s:3:"600";s:1:"N";s:4:"ring";s:1:"B";a:4:{i:0;s:3:"218";i:1;s:3:"463";i:2;s:3:"382";i:3;s:3:"627";}}s:4:"ring";a:4:{s:1:"C";s:3:"202";s:2:"WX";s:3:"600";s:1:"N";s:4:"ring";s:1:"B";a:4:{i:0;s:3:"218";i:1;s:3:"463";i:2;s:3:"382";i:3;s:3:"627";}}i:203;a:4:{s:1:"C";s:3:"203";s:2:"WX";s:3:"600";s:1:"N";s:7:"cedilla";s:1:"B";a:4:{i:0;s:3:"224";i:1;s:4:"-151";i:2;s:3:"362";i:3;s:2:"10";}}s:7:"cedilla";a:4:{s:1:"C";s:3:"203";s:2:"WX";s:3:"600";s:1:"N";s:7:"cedilla";s:1:"B";a:4:{i:0;s:3:"224";i:1;s:4:"-151";i:2;s:3:"362";i:3;s:2:"10";}}i:205;a:4:{s:1:"C";s:3:"205";s:2:"WX";s:3:"600";s:1:"N";s:12:"hungarumlaut";s:1:"B";a:4:{i:0;s:3:"133";i:1;s:3:"497";i:2;s:3:"540";i:3;s:3:"672";}}s:12:"hungarumlaut";a:4:{s:1:"C";s:3:"205";s:2:"WX";s:3:"600";s:1:"N";s:12:"hungarumlaut";s:1:"B";a:4:{i:0;s:3:"133";i:1;s:3:"497";i:2;s:3:"540";i:3;s:3:"672";}}i:206;a:4:{s:1:"C";s:3:"206";s:2:"WX";s:3:"600";s:1:"N";s:6:"ogonek";s:1:"B";a:4:{i:0;s:3:"211";i:1;s:4:"-172";i:2;s:3:"407";i:3;s:1:"4";}}s:6:"ogonek";a:4:{s:1:"C";s:3:"206";s:2:"WX";s:3:"600";s:1:"N";s:6:"ogonek";s:1:"B";a:4:{i:0;s:3:"211";i:1;s:4:"-172";i:2;s:3:"407";i:3;s:1:"4";}}i:207;a:4:{s:1:"C";s:3:"207";s:2:"WX";s:3:"600";s:1:"N";s:5:"caron";s:1:"B";a:4:{i:0;s:3:"124";i:1;s:3:"492";i:2;s:3:"476";i:3;s:3:"669";}}s:5:"caron";a:4:{s:1:"C";s:3:"207";s:2:"WX";s:3:"600";s:1:"N";s:5:"caron";s:1:"B";a:4:{i:0;s:3:"124";i:1;s:3:"492";i:2;s:3:"476";i:3;s:3:"669";}}i:208;a:4:{s:1:"C";s:3:"208";s:2:"WX";s:3:"600";s:1:"N";s:6:"emdash";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"231";i:2;s:3:"600";i:3;s:3:"285";}}s:6:"emdash";a:4:{s:1:"C";s:3:"208";s:2:"WX";s:3:"600";s:1:"N";s:6:"emdash";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"231";i:2;s:3:"600";i:3;s:3:"285";}}i:225;a:4:{s:1:"C";s:3:"225";s:2:"WX";s:3:"600";s:1:"N";s:2:"AE";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:1:"0";i:2;s:3:"550";i:3;s:3:"562";}}s:2:"AE";a:4:{s:1:"C";s:3:"225";s:2:"WX";s:3:"600";s:1:"N";s:2:"AE";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:1:"0";i:2;s:3:"550";i:3;s:3:"562";}}i:227;a:4:{s:1:"C";s:3:"227";s:2:"WX";s:3:"600";s:1:"N";s:11:"ordfeminine";s:1:"B";a:4:{i:0;s:3:"156";i:1;s:3:"249";i:2;s:3:"442";i:3;s:3:"580";}}s:11:"ordfeminine";a:4:{s:1:"C";s:3:"227";s:2:"WX";s:3:"600";s:1:"N";s:11:"ordfeminine";s:1:"B";a:4:{i:0;s:3:"156";i:1;s:3:"249";i:2;s:3:"442";i:3;s:3:"580";}}i:232;a:4:{s:1:"C";s:3:"232";s:2:"WX";s:3:"600";s:1:"N";s:6:"Lslash";s:1:"B";a:4:{i:0;s:2:"47";i:1;s:1:"0";i:2;s:3:"554";i:3;s:3:"562";}}s:6:"Lslash";a:4:{s:1:"C";s:3:"232";s:2:"WX";s:3:"600";s:1:"N";s:6:"Lslash";s:1:"B";a:4:{i:0;s:2:"47";i:1;s:1:"0";i:2;s:3:"554";i:3;s:3:"562";}}i:233;a:4:{s:1:"C";s:3:"233";s:2:"WX";s:3:"600";s:1:"N";s:6:"Oslash";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:3:"-80";i:2;s:3:"557";i:3;s:3:"629";}}s:6:"Oslash";a:4:{s:1:"C";s:3:"233";s:2:"WX";s:3:"600";s:1:"N";s:6:"Oslash";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:3:"-80";i:2;s:3:"557";i:3;s:3:"629";}}i:234;a:4:{s:1:"C";s:3:"234";s:2:"WX";s:3:"600";s:1:"N";s:2:"OE";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:1:"0";i:2;s:3:"567";i:3;s:3:"562";}}s:2:"OE";a:4:{s:1:"C";s:3:"234";s:2:"WX";s:3:"600";s:1:"N";s:2:"OE";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:1:"0";i:2;s:3:"567";i:3;s:3:"562";}}i:235;a:4:{s:1:"C";s:3:"235";s:2:"WX";s:3:"600";s:1:"N";s:12:"ordmasculine";s:1:"B";a:4:{i:0;s:3:"157";i:1;s:3:"249";i:2;s:3:"443";i:3;s:3:"580";}}s:12:"ordmasculine";a:4:{s:1:"C";s:3:"235";s:2:"WX";s:3:"600";s:1:"N";s:12:"ordmasculine";s:1:"B";a:4:{i:0;s:3:"157";i:1;s:3:"249";i:2;s:3:"443";i:3;s:3:"580";}}i:241;a:4:{s:1:"C";s:3:"241";s:2:"WX";s:3:"600";s:1:"N";s:2:"ae";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:3:"-15";i:2;s:3:"570";i:3;s:3:"441";}}s:2:"ae";a:4:{s:1:"C";s:3:"241";s:2:"WX";s:3:"600";s:1:"N";s:2:"ae";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:3:"-15";i:2;s:3:"570";i:3;s:3:"441";}}i:245;a:4:{s:1:"C";s:3:"245";s:2:"WX";s:3:"600";s:1:"N";s:8:"dotlessi";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:1:"0";i:2;s:3:"505";i:3;s:3:"426";}}s:8:"dotlessi";a:4:{s:1:"C";s:3:"245";s:2:"WX";s:3:"600";s:1:"N";s:8:"dotlessi";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:1:"0";i:2;s:3:"505";i:3;s:3:"426";}}i:248;a:4:{s:1:"C";s:3:"248";s:2:"WX";s:3:"600";s:1:"N";s:6:"lslash";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:1:"0";i:2;s:3:"505";i:3;s:3:"629";}}s:6:"lslash";a:4:{s:1:"C";s:3:"248";s:2:"WX";s:3:"600";s:1:"N";s:6:"lslash";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:1:"0";i:2;s:3:"505";i:3;s:3:"629";}}i:249;a:4:{s:1:"C";s:3:"249";s:2:"WX";s:3:"600";s:1:"N";s:6:"oslash";s:1:"B";a:4:{i:0;s:2:"62";i:1;s:3:"-80";i:2;s:3:"538";i:3;s:3:"506";}}s:6:"oslash";a:4:{s:1:"C";s:3:"249";s:2:"WX";s:3:"600";s:1:"N";s:6:"oslash";s:1:"B";a:4:{i:0;s:2:"62";i:1;s:3:"-80";i:2;s:3:"538";i:3;s:3:"506";}}i:250;a:4:{s:1:"C";s:3:"250";s:2:"WX";s:3:"600";s:1:"N";s:2:"oe";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:3:"-15";i:2;s:3:"559";i:3;s:3:"441";}}s:2:"oe";a:4:{s:1:"C";s:3:"250";s:2:"WX";s:3:"600";s:1:"N";s:2:"oe";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:3:"-15";i:2;s:3:"559";i:3;s:3:"441";}}i:251;a:4:{s:1:"C";s:3:"251";s:2:"WX";s:3:"600";s:1:"N";s:10:"germandbls";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:3:"-15";i:2;s:3:"588";i:3;s:3:"629";}}s:10:"germandbls";a:4:{s:1:"C";s:3:"251";s:2:"WX";s:3:"600";s:1:"N";s:10:"germandbls";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:3:"-15";i:2;s:3:"588";i:3;s:3:"629";}}s:9:"Idieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"Idieresis";s:1:"B";a:4:{i:0;s:2:"96";i:1;s:1:"0";i:2;s:3:"504";i:3;s:3:"753";}}s:6:"eacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"eacute";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:3:"-15";i:2;s:3:"548";i:3;s:3:"672";}}s:6:"abreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"abreve";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:3:"-15";i:2;s:3:"559";i:3;s:3:"609";}}s:13:"uhungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:13:"uhungarumlaut";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:3:"-15";i:2;s:3:"580";i:3;s:3:"672";}}s:6:"ecaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"ecaron";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:3:"-15";i:2;s:3:"548";i:3;s:3:"669";}}s:9:"Ydieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"Ydieresis";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:1:"0";i:2;s:3:"576";i:3;s:3:"753";}}s:6:"divide";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"divide";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:2:"48";i:2;s:3:"513";i:3;s:3:"467";}}s:6:"Yacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Yacute";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:1:"0";i:2;s:3:"576";i:3;s:3:"805";}}s:11:"Acircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"Acircumflex";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:1:"0";i:2;s:3:"597";i:3;s:3:"787";}}s:6:"aacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"aacute";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:3:"-15";i:2;s:3:"559";i:3;s:3:"672";}}s:11:"Ucircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"Ucircumflex";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:3:"-18";i:2;s:3:"583";i:3;s:3:"787";}}s:6:"yacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"yacute";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:4:"-157";i:2;s:3:"592";i:3;s:3:"672";}}s:12:"scommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"scommaaccent";s:1:"B";a:4:{i:0;s:2:"80";i:1;s:4:"-250";i:2;s:3:"513";i:3;s:3:"441";}}s:11:"ecircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"ecircumflex";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:3:"-15";i:2;s:3:"548";i:3;s:3:"654";}}s:5:"Uring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:5:"Uring";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:3:"-18";i:2;s:3:"583";i:3;s:3:"760";}}s:9:"Udieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"Udieresis";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:3:"-18";i:2;s:3:"583";i:3;s:3:"753";}}s:7:"aogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"aogonek";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:4:"-172";i:2;s:3:"587";i:3;s:3:"441";}}s:6:"Uacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Uacute";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:3:"-18";i:2;s:3:"583";i:3;s:3:"805";}}s:7:"uogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"uogonek";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:4:"-172";i:2;s:3:"590";i:3;s:3:"426";}}s:9:"Edieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"Edieresis";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:1:"0";i:2;s:3:"550";i:3;s:3:"753";}}s:6:"Dcroat";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Dcroat";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:1:"0";i:2;s:3:"574";i:3;s:3:"562";}}s:11:"commaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"commaaccent";s:1:"B";a:4:{i:0;s:3:"198";i:1;s:4:"-250";i:2;s:3:"335";i:3;s:3:"-58";}}s:9:"copyright";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"copyright";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"-18";i:2;s:3:"600";i:3;s:3:"580";}}s:7:"Emacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"Emacron";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:1:"0";i:2;s:3:"550";i:3;s:3:"698";}}s:6:"ccaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"ccaron";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:3:"-15";i:2;s:3:"529";i:3;s:3:"669";}}s:5:"aring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:5:"aring";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:3:"-15";i:2;s:3:"559";i:3;s:3:"627";}}s:12:"Ncommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"Ncommaaccent";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:4:"-250";i:2;s:3:"593";i:3;s:3:"562";}}s:6:"lacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"lacute";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:1:"0";i:2;s:3:"505";i:3;s:3:"805";}}s:6:"agrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"agrave";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:3:"-15";i:2;s:3:"559";i:3;s:3:"672";}}s:12:"Tcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"Tcommaaccent";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:4:"-250";i:2;s:3:"563";i:3;s:3:"562";}}s:6:"Cacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Cacute";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:3:"-18";i:2;s:3:"540";i:3;s:3:"805";}}s:6:"atilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"atilde";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:3:"-15";i:2;s:3:"559";i:3;s:3:"606";}}s:10:"Edotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:10:"Edotaccent";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:1:"0";i:2;s:3:"550";i:3;s:3:"753";}}s:6:"scaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"scaron";s:1:"B";a:4:{i:0;s:2:"80";i:1;s:3:"-15";i:2;s:3:"513";i:3;s:3:"669";}}s:8:"scedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:8:"scedilla";s:1:"B";a:4:{i:0;s:2:"80";i:1;s:4:"-151";i:2;s:3:"513";i:3;s:3:"441";}}s:6:"iacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"iacute";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:1:"0";i:2;s:3:"505";i:3;s:3:"672";}}s:7:"lozenge";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"lozenge";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:1:"0";i:2;s:3:"443";i:3;s:3:"706";}}s:6:"Rcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Rcaron";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:1:"0";i:2;s:3:"588";i:3;s:3:"802";}}s:12:"Gcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"Gcommaaccent";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:4:"-250";i:2;s:3:"575";i:3;s:3:"580";}}s:11:"ucircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"ucircumflex";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:3:"-15";i:2;s:3:"562";i:3;s:3:"654";}}s:11:"acircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"acircumflex";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:3:"-15";i:2;s:3:"559";i:3;s:3:"654";}}s:7:"Amacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"Amacron";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:1:"0";i:2;s:3:"597";i:3;s:3:"698";}}s:6:"rcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"rcaron";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:1:"0";i:2;s:3:"559";i:3;s:3:"669";}}s:8:"ccedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:8:"ccedilla";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:4:"-151";i:2;s:3:"529";i:3;s:3:"441";}}s:10:"Zdotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:10:"Zdotaccent";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"514";i:3;s:3:"753";}}s:5:"Thorn";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:5:"Thorn";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:1:"0";i:2;s:3:"538";i:3;s:3:"562";}}s:7:"Omacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"Omacron";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:3:"-18";i:2;s:3:"557";i:3;s:3:"698";}}s:6:"Racute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Racute";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:1:"0";i:2;s:3:"588";i:3;s:3:"805";}}s:6:"Sacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Sacute";s:1:"B";a:4:{i:0;s:2:"72";i:1;s:3:"-20";i:2;s:3:"529";i:3;s:3:"805";}}s:6:"dcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"dcaron";s:1:"B";a:4:{i:0;s:2:"45";i:1;s:3:"-15";i:2;s:3:"715";i:3;s:3:"629";}}s:7:"Umacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"Umacron";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:3:"-18";i:2;s:3:"583";i:3;s:3:"698";}}s:5:"uring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:5:"uring";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:3:"-15";i:2;s:3:"562";i:3;s:3:"627";}}s:13:"threesuperior";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:13:"threesuperior";s:1:"B";a:4:{i:0;s:3:"155";i:1;s:3:"240";i:2;s:3:"406";i:3;s:3:"622";}}s:6:"Ograve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Ograve";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:3:"-18";i:2;s:3:"557";i:3;s:3:"805";}}s:6:"Agrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Agrave";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:1:"0";i:2;s:3:"597";i:3;s:3:"805";}}s:6:"Abreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Abreve";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:1:"0";i:2;s:3:"597";i:3;s:3:"732";}}s:8:"multiply";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:8:"multiply";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:2:"43";i:2;s:3:"515";i:3;s:3:"470";}}s:6:"uacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"uacute";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:3:"-15";i:2;s:3:"562";i:3;s:3:"672";}}s:6:"Tcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Tcaron";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:1:"0";i:2;s:3:"563";i:3;s:3:"802";}}s:11:"partialdiff";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"partialdiff";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:3:"-38";i:2;s:3:"459";i:3;s:3:"710";}}s:9:"ydieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"ydieresis";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:4:"-157";i:2;s:3:"592";i:3;s:3:"620";}}s:6:"Nacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Nacute";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:3:"-13";i:2;s:3:"593";i:3;s:3:"805";}}s:11:"icircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"icircumflex";s:1:"B";a:4:{i:0;s:2:"94";i:1;s:1:"0";i:2;s:3:"505";i:3;s:3:"654";}}s:11:"Ecircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"Ecircumflex";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:1:"0";i:2;s:3:"550";i:3;s:3:"787";}}s:9:"adieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"adieresis";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:3:"-15";i:2;s:3:"559";i:3;s:3:"620";}}s:9:"edieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"edieresis";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:3:"-15";i:2;s:3:"548";i:3;s:3:"620";}}s:6:"cacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"cacute";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:3:"-15";i:2;s:3:"529";i:3;s:3:"672";}}s:6:"nacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"nacute";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"575";i:3;s:3:"672";}}s:7:"umacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"umacron";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:3:"-15";i:2;s:3:"562";i:3;s:3:"565";}}s:6:"Ncaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Ncaron";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:3:"-13";i:2;s:3:"593";i:3;s:3:"802";}}s:6:"Iacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Iacute";s:1:"B";a:4:{i:0;s:2:"96";i:1;s:1:"0";i:2;s:3:"504";i:3;s:3:"805";}}s:9:"plusminus";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"plusminus";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:2:"44";i:2;s:3:"513";i:3;s:3:"558";}}s:9:"brokenbar";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"brokenbar";s:1:"B";a:4:{i:0;s:3:"275";i:1;s:4:"-175";i:2;s:3:"326";i:3;s:3:"675";}}s:10:"registered";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:10:"registered";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"-18";i:2;s:3:"600";i:3;s:3:"580";}}s:6:"Gbreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Gbreve";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:3:"-18";i:2;s:3:"575";i:3;s:3:"732";}}s:10:"Idotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:10:"Idotaccent";s:1:"B";a:4:{i:0;s:2:"96";i:1;s:1:"0";i:2;s:3:"504";i:3;s:3:"753";}}s:9:"summation";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"summation";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:3:"-10";i:2;s:3:"585";i:3;s:3:"706";}}s:6:"Egrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Egrave";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:1:"0";i:2;s:3:"550";i:3;s:3:"805";}}s:6:"racute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"racute";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:1:"0";i:2;s:3:"559";i:3;s:3:"672";}}s:7:"omacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"omacron";s:1:"B";a:4:{i:0;s:2:"62";i:1;s:3:"-15";i:2;s:3:"538";i:3;s:3:"565";}}s:6:"Zacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Zacute";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"514";i:3;s:3:"805";}}s:6:"Zcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Zcaron";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"514";i:3;s:3:"802";}}s:12:"greaterequal";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"greaterequal";s:1:"B";a:4:{i:0;s:2:"98";i:1;s:1:"0";i:2;s:3:"502";i:3;s:3:"710";}}s:3:"Eth";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:3:"Eth";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:1:"0";i:2;s:3:"574";i:3;s:3:"562";}}s:8:"Ccedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:8:"Ccedilla";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:4:"-151";i:2;s:3:"540";i:3;s:3:"580";}}s:12:"lcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"lcommaaccent";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:4:"-250";i:2;s:3:"505";i:3;s:3:"629";}}s:6:"tcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"tcaron";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:3:"-15";i:2;s:3:"530";i:3;s:3:"717";}}s:7:"eogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"eogonek";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:4:"-172";i:2;s:3:"548";i:3;s:3:"441";}}s:7:"Uogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"Uogonek";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:4:"-172";i:2;s:3:"583";i:3;s:3:"562";}}s:6:"Aacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Aacute";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:1:"0";i:2;s:3:"597";i:3;s:3:"805";}}s:9:"Adieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"Adieresis";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:1:"0";i:2;s:3:"597";i:3;s:3:"753";}}s:6:"egrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"egrave";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:3:"-15";i:2;s:3:"548";i:3;s:3:"672";}}s:6:"zacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"zacute";s:1:"B";a:4:{i:0;s:2:"99";i:1;s:1:"0";i:2;s:3:"502";i:3;s:3:"672";}}s:7:"iogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"iogonek";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:4:"-172";i:2;s:3:"505";i:3;s:3:"657";}}s:6:"Oacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Oacute";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:3:"-18";i:2;s:3:"557";i:3;s:3:"805";}}s:6:"oacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"oacute";s:1:"B";a:4:{i:0;s:2:"62";i:1;s:3:"-15";i:2;s:3:"538";i:3;s:3:"672";}}s:7:"amacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"amacron";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:3:"-15";i:2;s:3:"559";i:3;s:3:"565";}}s:6:"sacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"sacute";s:1:"B";a:4:{i:0;s:2:"80";i:1;s:3:"-15";i:2;s:3:"513";i:3;s:3:"672";}}s:9:"idieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"idieresis";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:1:"0";i:2;s:3:"505";i:3;s:3:"620";}}s:11:"Ocircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"Ocircumflex";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:3:"-18";i:2;s:3:"557";i:3;s:3:"787";}}s:6:"Ugrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Ugrave";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:3:"-18";i:2;s:3:"583";i:3;s:3:"805";}}s:5:"Delta";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:5:"Delta";s:1:"B";a:4:{i:0;s:1:"6";i:1;s:1:"0";i:2;s:3:"598";i:3;s:3:"688";}}s:5:"thorn";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:5:"thorn";s:1:"B";a:4:{i:0;s:2:"-6";i:1;s:4:"-157";i:2;s:3:"555";i:3;s:3:"629";}}s:11:"twosuperior";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"twosuperior";s:1:"B";a:4:{i:0;s:3:"177";i:1;s:3:"249";i:2;s:3:"424";i:3;s:3:"622";}}s:9:"Odieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"Odieresis";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:3:"-18";i:2;s:3:"557";i:3;s:3:"753";}}s:2:"mu";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:2:"mu";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:4:"-157";i:2;s:3:"562";i:3;s:3:"426";}}s:6:"igrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"igrave";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:1:"0";i:2;s:3:"505";i:3;s:3:"672";}}s:13:"ohungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:13:"ohungarumlaut";s:1:"B";a:4:{i:0;s:2:"62";i:1;s:3:"-15";i:2;s:3:"580";i:3;s:3:"672";}}s:7:"Eogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"Eogonek";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:4:"-172";i:2;s:3:"561";i:3;s:3:"562";}}s:6:"dcroat";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"dcroat";s:1:"B";a:4:{i:0;s:2:"45";i:1;s:3:"-15";i:2;s:3:"591";i:3;s:3:"629";}}s:13:"threequarters";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:13:"threequarters";s:1:"B";a:4:{i:0;s:1:"8";i:1;s:3:"-56";i:2;s:3:"593";i:3;s:3:"666";}}s:8:"Scedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:8:"Scedilla";s:1:"B";a:4:{i:0;s:2:"72";i:1;s:4:"-151";i:2;s:3:"529";i:3;s:3:"580";}}s:6:"lcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"lcaron";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:1:"0";i:2;s:3:"533";i:3;s:3:"629";}}s:12:"Kcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"Kcommaaccent";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:4:"-250";i:2;s:3:"582";i:3;s:3:"562";}}s:6:"Lacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Lacute";s:1:"B";a:4:{i:0;s:2:"47";i:1;s:1:"0";i:2;s:3:"554";i:3;s:3:"805";}}s:9:"trademark";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"trademark";s:1:"B";a:4:{i:0;s:3:"-23";i:1;s:3:"263";i:2;s:3:"623";i:3;s:3:"562";}}s:10:"edotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:10:"edotaccent";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:3:"-15";i:2;s:3:"548";i:3;s:3:"620";}}s:6:"Igrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Igrave";s:1:"B";a:4:{i:0;s:2:"96";i:1;s:1:"0";i:2;s:3:"504";i:3;s:3:"805";}}s:7:"Imacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"Imacron";s:1:"B";a:4:{i:0;s:2:"96";i:1;s:1:"0";i:2;s:3:"504";i:3;s:3:"698";}}s:6:"Lcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Lcaron";s:1:"B";a:4:{i:0;s:2:"47";i:1;s:1:"0";i:2;s:3:"554";i:3;s:3:"562";}}s:7:"onehalf";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"onehalf";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"-57";i:2;s:3:"611";i:3;s:3:"665";}}s:9:"lessequal";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"lessequal";s:1:"B";a:4:{i:0;s:2:"98";i:1;s:1:"0";i:2;s:3:"502";i:3;s:3:"710";}}s:11:"ocircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"ocircumflex";s:1:"B";a:4:{i:0;s:2:"62";i:1;s:3:"-15";i:2;s:3:"538";i:3;s:3:"654";}}s:6:"ntilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"ntilde";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"575";i:3;s:3:"606";}}s:13:"Uhungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:13:"Uhungarumlaut";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:3:"-18";i:2;s:3:"590";i:3;s:3:"805";}}s:6:"Eacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Eacute";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:1:"0";i:2;s:3:"550";i:3;s:3:"805";}}s:7:"emacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"emacron";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:3:"-15";i:2;s:3:"548";i:3;s:3:"565";}}s:6:"gbreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"gbreve";s:1:"B";a:4:{i:0;s:2:"45";i:1;s:4:"-157";i:2;s:3:"566";i:3;s:3:"609";}}s:10:"onequarter";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:10:"onequarter";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"-57";i:2;s:3:"600";i:3;s:3:"665";}}s:6:"Scaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Scaron";s:1:"B";a:4:{i:0;s:2:"72";i:1;s:3:"-20";i:2;s:3:"529";i:3;s:3:"802";}}s:12:"Scommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"Scommaaccent";s:1:"B";a:4:{i:0;s:2:"72";i:1;s:4:"-250";i:2;s:3:"529";i:3;s:3:"580";}}s:13:"Ohungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:13:"Ohungarumlaut";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:3:"-18";i:2;s:3:"580";i:3;s:3:"805";}}s:6:"degree";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"degree";s:1:"B";a:4:{i:0;s:3:"123";i:1;s:3:"269";i:2;s:3:"477";i:3;s:3:"622";}}s:6:"ograve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"ograve";s:1:"B";a:4:{i:0;s:2:"62";i:1;s:3:"-15";i:2;s:3:"538";i:3;s:3:"672";}}s:6:"Ccaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Ccaron";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:3:"-18";i:2;s:3:"540";i:3;s:3:"802";}}s:6:"ugrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"ugrave";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:3:"-15";i:2;s:3:"562";i:3;s:3:"672";}}s:7:"radical";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"radical";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:3:"-15";i:2;s:3:"597";i:3;s:3:"792";}}s:6:"Dcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Dcaron";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:1:"0";i:2;s:3:"574";i:3;s:3:"802";}}s:12:"rcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"rcommaaccent";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:4:"-250";i:2;s:3:"559";i:3;s:3:"441";}}s:6:"Ntilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Ntilde";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:3:"-13";i:2;s:3:"593";i:3;s:3:"729";}}s:6:"otilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"otilde";s:1:"B";a:4:{i:0;s:2:"62";i:1;s:3:"-15";i:2;s:3:"538";i:3;s:3:"606";}}s:12:"Rcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"Rcommaaccent";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:4:"-250";i:2;s:3:"588";i:3;s:3:"562";}}s:12:"Lcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"Lcommaaccent";s:1:"B";a:4:{i:0;s:2:"47";i:1;s:4:"-250";i:2;s:3:"554";i:3;s:3:"562";}}s:6:"Atilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Atilde";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:1:"0";i:2;s:3:"597";i:3;s:3:"729";}}s:7:"Aogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"Aogonek";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:4:"-172";i:2;s:3:"608";i:3;s:3:"562";}}s:5:"Aring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:5:"Aring";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:1:"0";i:2;s:3:"597";i:3;s:3:"750";}}s:6:"Otilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Otilde";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:3:"-18";i:2;s:3:"557";i:3;s:3:"729";}}s:10:"zdotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:10:"zdotaccent";s:1:"B";a:4:{i:0;s:2:"99";i:1;s:1:"0";i:2;s:3:"502";i:3;s:3:"620";}}s:6:"Ecaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"Ecaron";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:1:"0";i:2;s:3:"550";i:3;s:3:"802";}}s:7:"Iogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"Iogonek";s:1:"B";a:4:{i:0;s:2:"96";i:1;s:4:"-172";i:2;s:3:"504";i:3;s:3:"562";}}s:12:"kcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"kcommaaccent";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:4:"-250";i:2;s:3:"580";i:3;s:3:"629";}}s:5:"minus";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:5:"minus";s:1:"B";a:4:{i:0;s:2:"80";i:1;s:3:"232";i:2;s:3:"520";i:3;s:3:"283";}}s:11:"Icircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"Icircumflex";s:1:"B";a:4:{i:0;s:2:"96";i:1;s:1:"0";i:2;s:3:"504";i:3;s:3:"787";}}s:6:"ncaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"ncaron";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"575";i:3;s:3:"669";}}s:12:"tcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"tcommaaccent";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:4:"-250";i:2;s:3:"530";i:3;s:3:"561";}}s:10:"logicalnot";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:10:"logicalnot";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:3:"108";i:2;s:3:"513";i:3;s:3:"369";}}s:9:"odieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"odieresis";s:1:"B";a:4:{i:0;s:2:"62";i:1;s:3:"-15";i:2;s:3:"538";i:3;s:3:"620";}}s:9:"udieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"udieresis";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:3:"-15";i:2;s:3:"562";i:3;s:3:"620";}}s:8:"notequal";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:8:"notequal";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:3:"-16";i:2;s:3:"540";i:3;s:3:"529";}}s:12:"gcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"gcommaaccent";s:1:"B";a:4:{i:0;s:2:"45";i:1;s:4:"-157";i:2;s:3:"566";i:3;s:3:"708";}}s:3:"eth";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:3:"eth";s:1:"B";a:4:{i:0;s:2:"62";i:1;s:3:"-15";i:2;s:3:"538";i:3;s:3:"629";}}s:6:"zcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:6:"zcaron";s:1:"B";a:4:{i:0;s:2:"99";i:1;s:1:"0";i:2;s:3:"502";i:3;s:3:"669";}}s:12:"ncommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:12:"ncommaaccent";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:4:"-250";i:2;s:3:"575";i:3;s:3:"441";}}s:11:"onesuperior";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:11:"onesuperior";s:1:"B";a:4:{i:0;s:3:"172";i:1;s:3:"249";i:2;s:3:"428";i:3;s:3:"622";}}s:7:"imacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:7:"imacron";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:1:"0";i:2;s:3:"505";i:3;s:3:"565";}}s:4:"Euro";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:4:"Euro";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}}s:9:"_version_";i:1;}
\ No newline at end of file
Added: trunk/mapbender/http/classes/fonts/php_Helvetica-Bold.afm
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/fonts/php_Helvetica-Bold.afm?view=auto&rev=13
--- (empty file)
+++ trunk/mapbender/http/classes/fonts/php_Helvetica-Bold.afm 2006-04-13 19:38:28+0000
@@ -0,0 +1 @@
+a:22:{s:8:"FontName";s:14:"Helvetica-Bold";s:8:"FullName";s:14:"Helvetica Bold";s:10:"FamilyName";s:9:"Helvetica";s:6:"Weight";s:4:"Bold";s:11:"ItalicAngle";s:1:"0";s:12:"IsFixedPitch";s:5:"false";s:12:"CharacterSet";s:13:"ExtendedRoman";s:8:"FontBBox";a:4:{i:0;s:4:"-170";i:1;s:4:"-228";i:2;s:4:"1003";i:3;s:3:"962";}s:17:"UnderlinePosition";s:4:"-100";s:18:"UnderlineThickness";s:2:"50";s:7:"Version";s:7:"002.000";s:14:"EncodingScheme";s:21:"AdobeStandardEncoding";s:9:"CapHeight";s:3:"718";s:7:"XHeight";s:3:"532";s:8:"Ascender";s:3:"718";s:9:"Descender";s:4:"-207";s:5:"StdHW";s:3:"118";s:5:"StdVW";s:3:"140";s:16:"StartCharMetrics";s:3:"315";s:1:"C";a:464:{i:32;a:4:{s:1:"C";s:2:"32";s:2:"WX";s:3:"278";s:1:"N";s:5:"space";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}s:5:"space";a:4:{s:1:"C";s:2:"32";s:2:"WX";s:3:"278";s:1:"N";s:5:"space";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}i:33;a:4:{s:1:"C";s:2:"33";s:2:"WX";s:3:"333";s:1:"N";s:6:"exclam";s:1:"B";a:4:{i:0;s:2:"90";i:1;s:1:"0";i:2;s:3:"244";i:3;s:3:"718";}}s:6:"exclam";a:4:{s:1:"C";s:2:"33";s:2:"WX";s:3:"333";s:1:"N";s:6:"exclam";s:1:"B";a:4:{i:0;s:2:"90";i:1;s:1:"0";i:2;s:3:"244";i:3;s:3:"718";}}i:34;a:4:{s:1:"C";s:2:"34";s:2:"WX";s:3:"474";s:1:"N";s:8:"quotedbl";s:1:"B";a:4:{i:0;s:2:"98";i:1;s:3:"447";i:2;s:3:"376";i:3;s:3:"718";}}s:8:"quotedbl";a:4:{s:1:"C";s:2:"34";s:2:"WX";s:3:"474";s:1:"N";s:8:"quotedbl";s:1:"B";a:4:{i:0;s:2:"98";i:1;s:3:"447";i:2;s:3:"376";i:3;s:3:"718";}}i:35;a:4:{s:1:"C";s:2:"35";s:2:"WX";s:3:"556";s:1:"N";s:10:"numbersign";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:1:"0";i:2;s:3:"538";i:3;s:3:"698";}}s:10:"numbersign";a:4:{s:1:"C";s:2:"35";s:2:"WX";s:3:"556";s:1:"N";s:10:"numbersign";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:1:"0";i:2;s:3:"538";i:3;s:3:"698";}}i:36;a:4:{s:1:"C";s:2:"36";s:2:"WX";s:3:"556";s:1:"N";s:6:"dollar";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:4:"-115";i:2;s:3:"523";i:3;s:3:"775";}}s:6:"dollar";a:4:{s:1:"C";s:2:"36";s:2:"WX";s:3:"556";s:1:"N";s:6:"dollar";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:4:"-115";i:2;s:3:"523";i:3;s:3:"775";}}i:37;a:4:{s:1:"C";s:2:"37";s:2:"WX";s:3:"889";s:1:"N";s:7:"percent";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:3:"-19";i:2;s:3:"861";i:3;s:3:"710";}}s:7:"percent";a:4:{s:1:"C";s:2:"37";s:2:"WX";s:3:"889";s:1:"N";s:7:"percent";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:3:"-19";i:2;s:3:"861";i:3;s:3:"710";}}i:38;a:4:{s:1:"C";s:2:"38";s:2:"WX";s:3:"722";s:1:"N";s:9:"ampersand";s:1:"B";a:4:{i:0;s:2:"54";i:1;s:3:"-19";i:2;s:3:"701";i:3;s:3:"718";}}s:9:"ampersand";a:4:{s:1:"C";s:2:"38";s:2:"WX";s:3:"722";s:1:"N";s:9:"ampersand";s:1:"B";a:4:{i:0;s:2:"54";i:1;s:3:"-19";i:2;s:3:"701";i:3;s:3:"718";}}i:39;a:4:{s:1:"C";s:2:"39";s:2:"WX";s:3:"278";s:1:"N";s:10:"quoteright";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:3:"445";i:2;s:3:"209";i:3;s:3:"718";}}s:10:"quoteright";a:4:{s:1:"C";s:2:"39";s:2:"WX";s:3:"278";s:1:"N";s:10:"quoteright";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:3:"445";i:2;s:3:"209";i:3;s:3:"718";}}i:40;a:4:{s:1:"C";s:2:"40";s:2:"WX";s:3:"333";s:1:"N";s:9:"parenleft";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:4:"-208";i:2;s:3:"314";i:3;s:3:"734";}}s:9:"parenleft";a:4:{s:1:"C";s:2:"40";s:2:"WX";s:3:"333";s:1:"N";s:9:"parenleft";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:4:"-208";i:2;s:3:"314";i:3;s:3:"734";}}i:41;a:4:{s:1:"C";s:2:"41";s:2:"WX";s:3:"333";s:1:"N";s:10:"parenright";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:4:"-208";i:2;s:3:"298";i:3;s:3:"734";}}s:10:"parenright";a:4:{s:1:"C";s:2:"41";s:2:"WX";s:3:"333";s:1:"N";s:10:"parenright";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:4:"-208";i:2;s:3:"298";i:3;s:3:"734";}}i:42;a:4:{s:1:"C";s:2:"42";s:2:"WX";s:3:"389";s:1:"N";s:8:"asterisk";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:3:"387";i:2;s:3:"362";i:3;s:3:"718";}}s:8:"asterisk";a:4:{s:1:"C";s:2:"42";s:2:"WX";s:3:"389";s:1:"N";s:8:"asterisk";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:3:"387";i:2;s:3:"362";i:3;s:3:"718";}}i:43;a:4:{s:1:"C";s:2:"43";s:2:"WX";s:3:"584";s:1:"N";s:4:"plus";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:1:"0";i:2;s:3:"544";i:3;s:3:"506";}}s:4:"plus";a:4:{s:1:"C";s:2:"43";s:2:"WX";s:3:"584";s:1:"N";s:4:"plus";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:1:"0";i:2;s:3:"544";i:3;s:3:"506";}}i:44;a:4:{s:1:"C";s:2:"44";s:2:"WX";s:3:"278";s:1:"N";s:5:"comma";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:4:"-168";i:2;s:3:"214";i:3;s:3:"146";}}s:5:"comma";a:4:{s:1:"C";s:2:"44";s:2:"WX";s:3:"278";s:1:"N";s:5:"comma";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:4:"-168";i:2;s:3:"214";i:3;s:3:"146";}}i:45;a:4:{s:1:"C";s:2:"45";s:2:"WX";s:3:"333";s:1:"N";s:6:"hyphen";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:3:"215";i:2;s:3:"306";i:3;s:3:"345";}}s:6:"hyphen";a:4:{s:1:"C";s:2:"45";s:2:"WX";s:3:"333";s:1:"N";s:6:"hyphen";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:3:"215";i:2;s:3:"306";i:3;s:3:"345";}}i:46;a:4:{s:1:"C";s:2:"46";s:2:"WX";s:3:"278";s:1:"N";s:6:"period";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:1:"0";i:2;s:3:"214";i:3;s:3:"146";}}s:6:"period";a:4:{s:1:"C";s:2:"46";s:2:"WX";s:3:"278";s:1:"N";s:6:"period";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:1:"0";i:2;s:3:"214";i:3;s:3:"146";}}i:47;a:4:{s:1:"C";s:2:"47";s:2:"WX";s:3:"278";s:1:"N";s:5:"slash";s:1:"B";a:4:{i:0;s:3:"-33";i:1;s:3:"-19";i:2;s:3:"311";i:3;s:3:"737";}}s:5:"slash";a:4:{s:1:"C";s:2:"47";s:2:"WX";s:3:"278";s:1:"N";s:5:"slash";s:1:"B";a:4:{i:0;s:3:"-33";i:1;s:3:"-19";i:2;s:3:"311";i:3;s:3:"737";}}i:48;a:4:{s:1:"C";s:2:"48";s:2:"WX";s:3:"556";s:1:"N";s:4:"zero";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:3:"-19";i:2;s:3:"524";i:3;s:3:"710";}}s:4:"zero";a:4:{s:1:"C";s:2:"48";s:2:"WX";s:3:"556";s:1:"N";s:4:"zero";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:3:"-19";i:2;s:3:"524";i:3;s:3:"710";}}i:49;a:4:{s:1:"C";s:2:"49";s:2:"WX";s:3:"556";s:1:"N";s:3:"one";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"378";i:3;s:3:"710";}}s:3:"one";a:4:{s:1:"C";s:2:"49";s:2:"WX";s:3:"556";s:1:"N";s:3:"one";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"378";i:3;s:3:"710";}}i:50;a:4:{s:1:"C";s:2:"50";s:2:"WX";s:3:"556";s:1:"N";s:3:"two";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"511";i:3;s:3:"710";}}s:3:"two";a:4:{s:1:"C";s:2:"50";s:2:"WX";s:3:"556";s:1:"N";s:3:"two";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"511";i:3;s:3:"710";}}i:51;a:4:{s:1:"C";s:2:"51";s:2:"WX";s:3:"556";s:1:"N";s:5:"three";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:3:"-19";i:2;s:3:"516";i:3;s:3:"710";}}s:5:"three";a:4:{s:1:"C";s:2:"51";s:2:"WX";s:3:"556";s:1:"N";s:5:"three";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:3:"-19";i:2;s:3:"516";i:3;s:3:"710";}}i:52;a:4:{s:1:"C";s:2:"52";s:2:"WX";s:3:"556";s:1:"N";s:4:"four";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:1:"0";i:2;s:3:"526";i:3;s:3:"710";}}s:4:"four";a:4:{s:1:"C";s:2:"52";s:2:"WX";s:3:"556";s:1:"N";s:4:"four";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:1:"0";i:2;s:3:"526";i:3;s:3:"710";}}i:53;a:4:{s:1:"C";s:2:"53";s:2:"WX";s:3:"556";s:1:"N";s:4:"five";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:3:"-19";i:2;s:3:"516";i:3;s:3:"698";}}s:4:"five";a:4:{s:1:"C";s:2:"53";s:2:"WX";s:3:"556";s:1:"N";s:4:"five";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:3:"-19";i:2;s:3:"516";i:3;s:3:"698";}}i:54;a:4:{s:1:"C";s:2:"54";s:2:"WX";s:3:"556";s:1:"N";s:3:"six";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:3:"-19";i:2;s:3:"520";i:3;s:3:"710";}}s:3:"six";a:4:{s:1:"C";s:2:"54";s:2:"WX";s:3:"556";s:1:"N";s:3:"six";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:3:"-19";i:2;s:3:"520";i:3;s:3:"710";}}i:55;a:4:{s:1:"C";s:2:"55";s:2:"WX";s:3:"556";s:1:"N";s:5:"seven";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"528";i:3;s:3:"698";}}s:5:"seven";a:4:{s:1:"C";s:2:"55";s:2:"WX";s:3:"556";s:1:"N";s:5:"seven";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"528";i:3;s:3:"698";}}i:56;a:4:{s:1:"C";s:2:"56";s:2:"WX";s:3:"556";s:1:"N";s:5:"eight";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:3:"-19";i:2;s:3:"524";i:3;s:3:"710";}}s:5:"eight";a:4:{s:1:"C";s:2:"56";s:2:"WX";s:3:"556";s:1:"N";s:5:"eight";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:3:"-19";i:2;s:3:"524";i:3;s:3:"710";}}i:57;a:4:{s:1:"C";s:2:"57";s:2:"WX";s:3:"556";s:1:"N";s:4:"nine";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-19";i:2;s:3:"522";i:3;s:3:"710";}}s:4:"nine";a:4:{s:1:"C";s:2:"57";s:2:"WX";s:3:"556";s:1:"N";s:4:"nine";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-19";i:2;s:3:"522";i:3;s:3:"710";}}i:58;a:4:{s:1:"C";s:2:"58";s:2:"WX";s:3:"333";s:1:"N";s:5:"colon";s:1:"B";a:4:{i:0;s:2:"92";i:1;s:1:"0";i:2;s:3:"242";i:3;s:3:"512";}}s:5:"colon";a:4:{s:1:"C";s:2:"58";s:2:"WX";s:3:"333";s:1:"N";s:5:"colon";s:1:"B";a:4:{i:0;s:2:"92";i:1;s:1:"0";i:2;s:3:"242";i:3;s:3:"512";}}i:59;a:4:{s:1:"C";s:2:"59";s:2:"WX";s:3:"333";s:1:"N";s:9:"semicolon";s:1:"B";a:4:{i:0;s:2:"92";i:1;s:4:"-168";i:2;s:3:"242";i:3;s:3:"512";}}s:9:"semicolon";a:4:{s:1:"C";s:2:"59";s:2:"WX";s:3:"333";s:1:"N";s:9:"semicolon";s:1:"B";a:4:{i:0;s:2:"92";i:1;s:4:"-168";i:2;s:3:"242";i:3;s:3:"512";}}i:60;a:4:{s:1:"C";s:2:"60";s:2:"WX";s:3:"584";s:1:"N";s:4:"less";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:2:"-8";i:2;s:3:"546";i:3;s:3:"514";}}s:4:"less";a:4:{s:1:"C";s:2:"60";s:2:"WX";s:3:"584";s:1:"N";s:4:"less";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:2:"-8";i:2;s:3:"546";i:3;s:3:"514";}}i:61;a:4:{s:1:"C";s:2:"61";s:2:"WX";s:3:"584";s:1:"N";s:5:"equal";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:2:"87";i:2;s:3:"544";i:3;s:3:"419";}}s:5:"equal";a:4:{s:1:"C";s:2:"61";s:2:"WX";s:3:"584";s:1:"N";s:5:"equal";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:2:"87";i:2;s:3:"544";i:3;s:3:"419";}}i:62;a:4:{s:1:"C";s:2:"62";s:2:"WX";s:3:"584";s:1:"N";s:7:"greater";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:2:"-8";i:2;s:3:"546";i:3;s:3:"514";}}s:7:"greater";a:4:{s:1:"C";s:2:"62";s:2:"WX";s:3:"584";s:1:"N";s:7:"greater";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:2:"-8";i:2;s:3:"546";i:3;s:3:"514";}}i:63;a:4:{s:1:"C";s:2:"63";s:2:"WX";s:3:"611";s:1:"N";s:8:"question";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:1:"0";i:2;s:3:"556";i:3;s:3:"727";}}s:8:"question";a:4:{s:1:"C";s:2:"63";s:2:"WX";s:3:"611";s:1:"N";s:8:"question";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:1:"0";i:2;s:3:"556";i:3;s:3:"727";}}i:64;a:4:{s:1:"C";s:2:"64";s:2:"WX";s:3:"975";s:1:"N";s:2:"at";s:1:"B";a:4:{i:0;s:3:"118";i:1;s:3:"-19";i:2;s:3:"856";i:3;s:3:"737";}}s:2:"at";a:4:{s:1:"C";s:2:"64";s:2:"WX";s:3:"975";s:1:"N";s:2:"at";s:1:"B";a:4:{i:0;s:3:"118";i:1;s:3:"-19";i:2;s:3:"856";i:3;s:3:"737";}}i:65;a:4:{s:1:"C";s:2:"65";s:2:"WX";s:3:"722";s:1:"N";s:1:"A";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"702";i:3;s:3:"718";}}s:1:"A";a:4:{s:1:"C";s:2:"65";s:2:"WX";s:3:"722";s:1:"N";s:1:"A";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"702";i:3;s:3:"718";}}i:66;a:4:{s:1:"C";s:2:"66";s:2:"WX";s:3:"722";s:1:"N";s:1:"B";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"669";i:3;s:3:"718";}}s:1:"B";a:4:{s:1:"C";s:2:"66";s:2:"WX";s:3:"722";s:1:"N";s:1:"B";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"669";i:3;s:3:"718";}}i:67;a:4:{s:1:"C";s:2:"67";s:2:"WX";s:3:"722";s:1:"N";s:1:"C";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-19";i:2;s:3:"684";i:3;s:3:"737";}}s:1:"C";a:4:{s:1:"C";s:2:"67";s:2:"WX";s:3:"722";s:1:"N";s:1:"C";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-19";i:2;s:3:"684";i:3;s:3:"737";}}i:68;a:4:{s:1:"C";s:2:"68";s:2:"WX";s:3:"722";s:1:"N";s:1:"D";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"685";i:3;s:3:"718";}}s:1:"D";a:4:{s:1:"C";s:2:"68";s:2:"WX";s:3:"722";s:1:"N";s:1:"D";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"685";i:3;s:3:"718";}}i:69;a:4:{s:1:"C";s:2:"69";s:2:"WX";s:3:"667";s:1:"N";s:1:"E";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"621";i:3;s:3:"718";}}s:1:"E";a:4:{s:1:"C";s:2:"69";s:2:"WX";s:3:"667";s:1:"N";s:1:"E";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"621";i:3;s:3:"718";}}i:70;a:4:{s:1:"C";s:2:"70";s:2:"WX";s:3:"611";s:1:"N";s:1:"F";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"587";i:3;s:3:"718";}}s:1:"F";a:4:{s:1:"C";s:2:"70";s:2:"WX";s:3:"611";s:1:"N";s:1:"F";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"587";i:3;s:3:"718";}}i:71;a:4:{s:1:"C";s:2:"71";s:2:"WX";s:3:"778";s:1:"N";s:1:"G";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-19";i:2;s:3:"713";i:3;s:3:"737";}}s:1:"G";a:4:{s:1:"C";s:2:"71";s:2:"WX";s:3:"778";s:1:"N";s:1:"G";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-19";i:2;s:3:"713";i:3;s:3:"737";}}i:72;a:4:{s:1:"C";s:2:"72";s:2:"WX";s:3:"722";s:1:"N";s:1:"H";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:1:"0";i:2;s:3:"651";i:3;s:3:"718";}}s:1:"H";a:4:{s:1:"C";s:2:"72";s:2:"WX";s:3:"722";s:1:"N";s:1:"H";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:1:"0";i:2;s:3:"651";i:3;s:3:"718";}}i:73;a:4:{s:1:"C";s:2:"73";s:2:"WX";s:3:"278";s:1:"N";s:1:"I";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:1:"0";i:2;s:3:"214";i:3;s:3:"718";}}s:1:"I";a:4:{s:1:"C";s:2:"73";s:2:"WX";s:3:"278";s:1:"N";s:1:"I";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:1:"0";i:2;s:3:"214";i:3;s:3:"718";}}i:74;a:4:{s:1:"C";s:2:"74";s:2:"WX";s:3:"556";s:1:"N";s:1:"J";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-18";i:2;s:3:"484";i:3;s:3:"718";}}s:1:"J";a:4:{s:1:"C";s:2:"74";s:2:"WX";s:3:"556";s:1:"N";s:1:"J";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-18";i:2;s:3:"484";i:3;s:3:"718";}}i:75;a:4:{s:1:"C";s:2:"75";s:2:"WX";s:3:"722";s:1:"N";s:1:"K";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:1:"0";i:2;s:3:"722";i:3;s:3:"718";}}s:1:"K";a:4:{s:1:"C";s:2:"75";s:2:"WX";s:3:"722";s:1:"N";s:1:"K";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:1:"0";i:2;s:3:"722";i:3;s:3:"718";}}i:76;a:4:{s:1:"C";s:2:"76";s:2:"WX";s:3:"611";s:1:"N";s:1:"L";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"583";i:3;s:3:"718";}}s:1:"L";a:4:{s:1:"C";s:2:"76";s:2:"WX";s:3:"611";s:1:"N";s:1:"L";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"583";i:3;s:3:"718";}}i:77;a:4:{s:1:"C";s:2:"77";s:2:"WX";s:3:"833";s:1:"N";s:1:"M";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"765";i:3;s:3:"718";}}s:1:"M";a:4:{s:1:"C";s:2:"77";s:2:"WX";s:3:"833";s:1:"N";s:1:"M";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"765";i:3;s:3:"718";}}i:78;a:4:{s:1:"C";s:2:"78";s:2:"WX";s:3:"722";s:1:"N";s:1:"N";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"654";i:3;s:3:"718";}}s:1:"N";a:4:{s:1:"C";s:2:"78";s:2:"WX";s:3:"722";s:1:"N";s:1:"N";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"654";i:3;s:3:"718";}}i:79;a:4:{s:1:"C";s:2:"79";s:2:"WX";s:3:"778";s:1:"N";s:1:"O";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-19";i:2;s:3:"734";i:3;s:3:"737";}}s:1:"O";a:4:{s:1:"C";s:2:"79";s:2:"WX";s:3:"778";s:1:"N";s:1:"O";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-19";i:2;s:3:"734";i:3;s:3:"737";}}i:80;a:4:{s:1:"C";s:2:"80";s:2:"WX";s:3:"667";s:1:"N";s:1:"P";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"627";i:3;s:3:"718";}}s:1:"P";a:4:{s:1:"C";s:2:"80";s:2:"WX";s:3:"667";s:1:"N";s:1:"P";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"627";i:3;s:3:"718";}}i:81;a:4:{s:1:"C";s:2:"81";s:2:"WX";s:3:"778";s:1:"N";s:1:"Q";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-52";i:2;s:3:"737";i:3;s:3:"737";}}s:1:"Q";a:4:{s:1:"C";s:2:"81";s:2:"WX";s:3:"778";s:1:"N";s:1:"Q";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-52";i:2;s:3:"737";i:3;s:3:"737";}}i:82;a:4:{s:1:"C";s:2:"82";s:2:"WX";s:3:"722";s:1:"N";s:1:"R";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"677";i:3;s:3:"718";}}s:1:"R";a:4:{s:1:"C";s:2:"82";s:2:"WX";s:3:"722";s:1:"N";s:1:"R";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"677";i:3;s:3:"718";}}i:83;a:4:{s:1:"C";s:2:"83";s:2:"WX";s:3:"667";s:1:"N";s:1:"S";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:3:"-19";i:2;s:3:"629";i:3;s:3:"737";}}s:1:"S";a:4:{s:1:"C";s:2:"83";s:2:"WX";s:3:"667";s:1:"N";s:1:"S";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:3:"-19";i:2;s:3:"629";i:3;s:3:"737";}}i:84;a:4:{s:1:"C";s:2:"84";s:2:"WX";s:3:"611";s:1:"N";s:1:"T";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"598";i:3;s:3:"718";}}s:1:"T";a:4:{s:1:"C";s:2:"84";s:2:"WX";s:3:"611";s:1:"N";s:1:"T";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"598";i:3;s:3:"718";}}i:85;a:4:{s:1:"C";s:2:"85";s:2:"WX";s:3:"722";s:1:"N";s:1:"U";s:1:"B";a:4:{i:0;s:2:"72";i:1;s:3:"-19";i:2;s:3:"651";i:3;s:3:"718";}}s:1:"U";a:4:{s:1:"C";s:2:"85";s:2:"WX";s:3:"722";s:1:"N";s:1:"U";s:1:"B";a:4:{i:0;s:2:"72";i:1;s:3:"-19";i:2;s:3:"651";i:3;s:3:"718";}}i:86;a:4:{s:1:"C";s:2:"86";s:2:"WX";s:3:"667";s:1:"N";s:1:"V";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:1:"0";i:2;s:3:"648";i:3;s:3:"718";}}s:1:"V";a:4:{s:1:"C";s:2:"86";s:2:"WX";s:3:"667";s:1:"N";s:1:"V";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:1:"0";i:2;s:3:"648";i:3;s:3:"718";}}i:87;a:4:{s:1:"C";s:2:"87";s:2:"WX";s:3:"944";s:1:"N";s:1:"W";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"929";i:3;s:3:"718";}}s:1:"W";a:4:{s:1:"C";s:2:"87";s:2:"WX";s:3:"944";s:1:"N";s:1:"W";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"929";i:3;s:3:"718";}}i:88;a:4:{s:1:"C";s:2:"88";s:2:"WX";s:3:"667";s:1:"N";s:1:"X";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"653";i:3;s:3:"718";}}s:1:"X";a:4:{s:1:"C";s:2:"88";s:2:"WX";s:3:"667";s:1:"N";s:1:"X";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"653";i:3;s:3:"718";}}i:89;a:4:{s:1:"C";s:2:"89";s:2:"WX";s:3:"667";s:1:"N";s:1:"Y";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:1:"0";i:2;s:3:"653";i:3;s:3:"718";}}s:1:"Y";a:4:{s:1:"C";s:2:"89";s:2:"WX";s:3:"667";s:1:"N";s:1:"Y";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:1:"0";i:2;s:3:"653";i:3;s:3:"718";}}i:90;a:4:{s:1:"C";s:2:"90";s:2:"WX";s:3:"611";s:1:"N";s:1:"Z";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"586";i:3;s:3:"718";}}s:1:"Z";a:4:{s:1:"C";s:2:"90";s:2:"WX";s:3:"611";s:1:"N";s:1:"Z";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"586";i:3;s:3:"718";}}i:91;a:4:{s:1:"C";s:2:"91";s:2:"WX";s:3:"333";s:1:"N";s:11:"bracketleft";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:4:"-196";i:2;s:3:"309";i:3;s:3:"722";}}s:11:"bracketleft";a:4:{s:1:"C";s:2:"91";s:2:"WX";s:3:"333";s:1:"N";s:11:"bracketleft";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:4:"-196";i:2;s:3:"309";i:3;s:3:"722";}}i:92;a:4:{s:1:"C";s:2:"92";s:2:"WX";s:3:"278";s:1:"N";s:9:"backslash";s:1:"B";a:4:{i:0;s:3:"-33";i:1;s:3:"-19";i:2;s:3:"311";i:3;s:3:"737";}}s:9:"backslash";a:4:{s:1:"C";s:2:"92";s:2:"WX";s:3:"278";s:1:"N";s:9:"backslash";s:1:"B";a:4:{i:0;s:3:"-33";i:1;s:3:"-19";i:2;s:3:"311";i:3;s:3:"737";}}i:93;a:4:{s:1:"C";s:2:"93";s:2:"WX";s:3:"333";s:1:"N";s:12:"bracketright";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:4:"-196";i:2;s:3:"270";i:3;s:3:"722";}}s:12:"bracketright";a:4:{s:1:"C";s:2:"93";s:2:"WX";s:3:"333";s:1:"N";s:12:"bracketright";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:4:"-196";i:2;s:3:"270";i:3;s:3:"722";}}i:94;a:4:{s:1:"C";s:2:"94";s:2:"WX";s:3:"584";s:1:"N";s:11:"asciicircum";s:1:"B";a:4:{i:0;s:2:"62";i:1;s:3:"323";i:2;s:3:"522";i:3;s:3:"698";}}s:11:"asciicircum";a:4:{s:1:"C";s:2:"94";s:2:"WX";s:3:"584";s:1:"N";s:11:"asciicircum";s:1:"B";a:4:{i:0;s:2:"62";i:1;s:3:"323";i:2;s:3:"522";i:3;s:3:"698";}}i:95;a:4:{s:1:"C";s:2:"95";s:2:"WX";s:3:"556";s:1:"N";s:10:"underscore";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:4:"-125";i:2;s:3:"556";i:3;s:3:"-75";}}s:10:"underscore";a:4:{s:1:"C";s:2:"95";s:2:"WX";s:3:"556";s:1:"N";s:10:"underscore";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:4:"-125";i:2;s:3:"556";i:3;s:3:"-75";}}i:96;a:4:{s:1:"C";s:2:"96";s:2:"WX";s:3:"278";s:1:"N";s:9:"quoteleft";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:3:"454";i:2;s:3:"209";i:3;s:3:"727";}}s:9:"quoteleft";a:4:{s:1:"C";s:2:"96";s:2:"WX";s:3:"278";s:1:"N";s:9:"quoteleft";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:3:"454";i:2;s:3:"209";i:3;s:3:"727";}}i:97;a:4:{s:1:"C";s:2:"97";s:2:"WX";s:3:"556";s:1:"N";s:1:"a";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:3:"-14";i:2;s:3:"527";i:3;s:3:"546";}}s:1:"a";a:4:{s:1:"C";s:2:"97";s:2:"WX";s:3:"556";s:1:"N";s:1:"a";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:3:"-14";i:2;s:3:"527";i:3;s:3:"546";}}i:98;a:4:{s:1:"C";s:2:"98";s:2:"WX";s:3:"611";s:1:"N";s:1:"b";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:3:"-14";i:2;s:3:"578";i:3;s:3:"718";}}s:1:"b";a:4:{s:1:"C";s:2:"98";s:2:"WX";s:3:"611";s:1:"N";s:1:"b";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:3:"-14";i:2;s:3:"578";i:3;s:3:"718";}}i:99;a:4:{s:1:"C";s:2:"99";s:2:"WX";s:3:"556";s:1:"N";s:1:"c";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"524";i:3;s:3:"546";}}s:1:"c";a:4:{s:1:"C";s:2:"99";s:2:"WX";s:3:"556";s:1:"N";s:1:"c";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"524";i:3;s:3:"546";}}i:100;a:4:{s:1:"C";s:3:"100";s:2:"WX";s:3:"611";s:1:"N";s:1:"d";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"551";i:3;s:3:"718";}}s:1:"d";a:4:{s:1:"C";s:3:"100";s:2:"WX";s:3:"611";s:1:"N";s:1:"d";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"551";i:3;s:3:"718";}}i:101;a:4:{s:1:"C";s:3:"101";s:2:"WX";s:3:"556";s:1:"N";s:1:"e";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:3:"-14";i:2;s:3:"528";i:3;s:3:"546";}}s:1:"e";a:4:{s:1:"C";s:3:"101";s:2:"WX";s:3:"556";s:1:"N";s:1:"e";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:3:"-14";i:2;s:3:"528";i:3;s:3:"546";}}i:102;a:5:{s:1:"C";s:3:"102";s:2:"WX";s:3:"333";s:1:"N";s:1:"f";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:1:"0";i:2;s:3:"318";i:3;s:3:"727";}s:1:"L";a:2:{i:0;s:1:"l";i:1;s:2:"fl";}}s:1:"f";a:5:{s:1:"C";s:3:"102";s:2:"WX";s:3:"333";s:1:"N";s:1:"f";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:1:"0";i:2;s:3:"318";i:3;s:3:"727";}s:1:"L";a:2:{i:0;s:1:"l";i:1;s:2:"fl";}}i:103;a:4:{s:1:"C";s:3:"103";s:2:"WX";s:3:"611";s:1:"N";s:1:"g";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:4:"-217";i:2;s:3:"553";i:3;s:3:"546";}}s:1:"g";a:4:{s:1:"C";s:3:"103";s:2:"WX";s:3:"611";s:1:"N";s:1:"g";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:4:"-217";i:2;s:3:"553";i:3;s:3:"546";}}i:104;a:4:{s:1:"C";s:3:"104";s:2:"WX";s:3:"611";s:1:"N";s:1:"h";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:1:"0";i:2;s:3:"546";i:3;s:3:"718";}}s:1:"h";a:4:{s:1:"C";s:3:"104";s:2:"WX";s:3:"611";s:1:"N";s:1:"h";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:1:"0";i:2;s:3:"546";i:3;s:3:"718";}}i:105;a:4:{s:1:"C";s:3:"105";s:2:"WX";s:3:"278";s:1:"N";s:1:"i";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"209";i:3;s:3:"725";}}s:1:"i";a:4:{s:1:"C";s:3:"105";s:2:"WX";s:3:"278";s:1:"N";s:1:"i";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"209";i:3;s:3:"725";}}i:106;a:4:{s:1:"C";s:3:"106";s:2:"WX";s:3:"278";s:1:"N";s:1:"j";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:4:"-214";i:2;s:3:"209";i:3;s:3:"725";}}s:1:"j";a:4:{s:1:"C";s:3:"106";s:2:"WX";s:3:"278";s:1:"N";s:1:"j";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:4:"-214";i:2;s:3:"209";i:3;s:3:"725";}}i:107;a:4:{s:1:"C";s:3:"107";s:2:"WX";s:3:"556";s:1:"N";s:1:"k";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"562";i:3;s:3:"718";}}s:1:"k";a:4:{s:1:"C";s:3:"107";s:2:"WX";s:3:"556";s:1:"N";s:1:"k";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"562";i:3;s:3:"718";}}i:108;a:4:{s:1:"C";s:3:"108";s:2:"WX";s:3:"278";s:1:"N";s:1:"l";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"209";i:3;s:3:"718";}}s:1:"l";a:4:{s:1:"C";s:3:"108";s:2:"WX";s:3:"278";s:1:"N";s:1:"l";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"209";i:3;s:3:"718";}}i:109;a:4:{s:1:"C";s:3:"109";s:2:"WX";s:3:"889";s:1:"N";s:1:"m";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:1:"0";i:2;s:3:"826";i:3;s:3:"546";}}s:1:"m";a:4:{s:1:"C";s:3:"109";s:2:"WX";s:3:"889";s:1:"N";s:1:"m";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:1:"0";i:2;s:3:"826";i:3;s:3:"546";}}i:110;a:4:{s:1:"C";s:3:"110";s:2:"WX";s:3:"611";s:1:"N";s:1:"n";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:1:"0";i:2;s:3:"546";i:3;s:3:"546";}}s:1:"n";a:4:{s:1:"C";s:3:"110";s:2:"WX";s:3:"611";s:1:"N";s:1:"n";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:1:"0";i:2;s:3:"546";i:3;s:3:"546";}}i:111;a:4:{s:1:"C";s:3:"111";s:2:"WX";s:3:"611";s:1:"N";s:1:"o";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"578";i:3;s:3:"546";}}s:1:"o";a:4:{s:1:"C";s:3:"111";s:2:"WX";s:3:"611";s:1:"N";s:1:"o";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"578";i:3;s:3:"546";}}i:112;a:4:{s:1:"C";s:3:"112";s:2:"WX";s:3:"611";s:1:"N";s:1:"p";s:1:"B";a:4:{i:0;s:2:"62";i:1;s:4:"-207";i:2;s:3:"578";i:3;s:3:"546";}}s:1:"p";a:4:{s:1:"C";s:3:"112";s:2:"WX";s:3:"611";s:1:"N";s:1:"p";s:1:"B";a:4:{i:0;s:2:"62";i:1;s:4:"-207";i:2;s:3:"578";i:3;s:3:"546";}}i:113;a:4:{s:1:"C";s:3:"113";s:2:"WX";s:3:"611";s:1:"N";s:1:"q";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:4:"-207";i:2;s:3:"552";i:3;s:3:"546";}}s:1:"q";a:4:{s:1:"C";s:3:"113";s:2:"WX";s:3:"611";s:1:"N";s:1:"q";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:4:"-207";i:2;s:3:"552";i:3;s:3:"546";}}i:114;a:4:{s:1:"C";s:3:"114";s:2:"WX";s:3:"389";s:1:"N";s:1:"r";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:1:"0";i:2;s:3:"373";i:3;s:3:"546";}}s:1:"r";a:4:{s:1:"C";s:3:"114";s:2:"WX";s:3:"389";s:1:"N";s:1:"r";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:1:"0";i:2;s:3:"373";i:3;s:3:"546";}}i:115;a:4:{s:1:"C";s:3:"115";s:2:"WX";s:3:"556";s:1:"N";s:1:"s";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-14";i:2;s:3:"519";i:3;s:3:"546";}}s:1:"s";a:4:{s:1:"C";s:3:"115";s:2:"WX";s:3:"556";s:1:"N";s:1:"s";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-14";i:2;s:3:"519";i:3;s:3:"546";}}i:116;a:4:{s:1:"C";s:3:"116";s:2:"WX";s:3:"333";s:1:"N";s:1:"t";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:2:"-6";i:2;s:3:"309";i:3;s:3:"676";}}s:1:"t";a:4:{s:1:"C";s:3:"116";s:2:"WX";s:3:"333";s:1:"N";s:1:"t";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:2:"-6";i:2;s:3:"309";i:3;s:3:"676";}}i:117;a:4:{s:1:"C";s:3:"117";s:2:"WX";s:3:"611";s:1:"N";s:1:"u";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:3:"-14";i:2;s:3:"545";i:3;s:3:"532";}}s:1:"u";a:4:{s:1:"C";s:3:"117";s:2:"WX";s:3:"611";s:1:"N";s:1:"u";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:3:"-14";i:2;s:3:"545";i:3;s:3:"532";}}i:118;a:4:{s:1:"C";s:3:"118";s:2:"WX";s:3:"556";s:1:"N";s:1:"v";s:1:"B";a:4:{i:0;s:2:"13";i:1;s:1:"0";i:2;s:3:"543";i:3;s:3:"532";}}s:1:"v";a:4:{s:1:"C";s:3:"118";s:2:"WX";s:3:"556";s:1:"N";s:1:"v";s:1:"B";a:4:{i:0;s:2:"13";i:1;s:1:"0";i:2;s:3:"543";i:3;s:3:"532";}}i:119;a:4:{s:1:"C";s:3:"119";s:2:"WX";s:3:"778";s:1:"N";s:1:"w";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:1:"0";i:2;s:3:"769";i:3;s:3:"532";}}s:1:"w";a:4:{s:1:"C";s:3:"119";s:2:"WX";s:3:"778";s:1:"N";s:1:"w";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:1:"0";i:2;s:3:"769";i:3;s:3:"532";}}i:120;a:4:{s:1:"C";s:3:"120";s:2:"WX";s:3:"556";s:1:"N";s:1:"x";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:1:"0";i:2;s:3:"541";i:3;s:3:"532";}}s:1:"x";a:4:{s:1:"C";s:3:"120";s:2:"WX";s:3:"556";s:1:"N";s:1:"x";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:1:"0";i:2;s:3:"541";i:3;s:3:"532";}}i:121;a:4:{s:1:"C";s:3:"121";s:2:"WX";s:3:"556";s:1:"N";s:1:"y";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:4:"-214";i:2;s:3:"539";i:3;s:3:"532";}}s:1:"y";a:4:{s:1:"C";s:3:"121";s:2:"WX";s:3:"556";s:1:"N";s:1:"y";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:4:"-214";i:2;s:3:"539";i:3;s:3:"532";}}i:122;a:4:{s:1:"C";s:3:"122";s:2:"WX";s:3:"500";s:1:"N";s:1:"z";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"480";i:3;s:3:"532";}}s:1:"z";a:4:{s:1:"C";s:3:"122";s:2:"WX";s:3:"500";s:1:"N";s:1:"z";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"480";i:3;s:3:"532";}}i:123;a:4:{s:1:"C";s:3:"123";s:2:"WX";s:3:"389";s:1:"N";s:9:"braceleft";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:4:"-196";i:2;s:3:"365";i:3;s:3:"722";}}s:9:"braceleft";a:4:{s:1:"C";s:3:"123";s:2:"WX";s:3:"389";s:1:"N";s:9:"braceleft";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:4:"-196";i:2;s:3:"365";i:3;s:3:"722";}}i:124;a:4:{s:1:"C";s:3:"124";s:2:"WX";s:3:"280";s:1:"N";s:3:"bar";s:1:"B";a:4:{i:0;s:2:"84";i:1;s:4:"-225";i:2;s:3:"196";i:3;s:3:"775";}}s:3:"bar";a:4:{s:1:"C";s:3:"124";s:2:"WX";s:3:"280";s:1:"N";s:3:"bar";s:1:"B";a:4:{i:0;s:2:"84";i:1;s:4:"-225";i:2;s:3:"196";i:3;s:3:"775";}}i:125;a:4:{s:1:"C";s:3:"125";s:2:"WX";s:3:"389";s:1:"N";s:10:"braceright";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:4:"-196";i:2;s:3:"341";i:3;s:3:"722";}}s:10:"braceright";a:4:{s:1:"C";s:3:"125";s:2:"WX";s:3:"389";s:1:"N";s:10:"braceright";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:4:"-196";i:2;s:3:"341";i:3;s:3:"722";}}i:126;a:4:{s:1:"C";s:3:"126";s:2:"WX";s:3:"584";s:1:"N";s:10:"asciitilde";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:3:"163";i:2;s:3:"523";i:3;s:3:"343";}}s:10:"asciitilde";a:4:{s:1:"C";s:3:"126";s:2:"WX";s:3:"584";s:1:"N";s:10:"asciitilde";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:3:"163";i:2;s:3:"523";i:3;s:3:"343";}}i:161;a:4:{s:1:"C";s:3:"161";s:2:"WX";s:3:"333";s:1:"N";s:10:"exclamdown";s:1:"B";a:4:{i:0;s:2:"90";i:1;s:4:"-186";i:2;s:3:"244";i:3;s:3:"532";}}s:10:"exclamdown";a:4:{s:1:"C";s:3:"161";s:2:"WX";s:3:"333";s:1:"N";s:10:"exclamdown";s:1:"B";a:4:{i:0;s:2:"90";i:1;s:4:"-186";i:2;s:3:"244";i:3;s:3:"532";}}i:162;a:4:{s:1:"C";s:3:"162";s:2:"WX";s:3:"556";s:1:"N";s:4:"cent";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:4:"-118";i:2;s:3:"524";i:3;s:3:"628";}}s:4:"cent";a:4:{s:1:"C";s:3:"162";s:2:"WX";s:3:"556";s:1:"N";s:4:"cent";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:4:"-118";i:2;s:3:"524";i:3;s:3:"628";}}i:163;a:4:{s:1:"C";s:3:"163";s:2:"WX";s:3:"556";s:1:"N";s:8:"sterling";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:3:"-16";i:2;s:3:"541";i:3;s:3:"718";}}s:8:"sterling";a:4:{s:1:"C";s:3:"163";s:2:"WX";s:3:"556";s:1:"N";s:8:"sterling";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:3:"-16";i:2;s:3:"541";i:3;s:3:"718";}}i:164;a:4:{s:1:"C";s:3:"164";s:2:"WX";s:3:"167";s:1:"N";s:8:"fraction";s:1:"B";a:4:{i:0;s:4:"-170";i:1;s:3:"-19";i:2;s:3:"336";i:3;s:3:"710";}}s:8:"fraction";a:4:{s:1:"C";s:3:"164";s:2:"WX";s:3:"167";s:1:"N";s:8:"fraction";s:1:"B";a:4:{i:0;s:4:"-170";i:1;s:3:"-19";i:2;s:3:"336";i:3;s:3:"710";}}i:165;a:4:{s:1:"C";s:3:"165";s:2:"WX";s:3:"556";s:1:"N";s:3:"yen";s:1:"B";a:4:{i:0;s:2:"-9";i:1;s:1:"0";i:2;s:3:"565";i:3;s:3:"698";}}s:3:"yen";a:4:{s:1:"C";s:3:"165";s:2:"WX";s:3:"556";s:1:"N";s:3:"yen";s:1:"B";a:4:{i:0;s:2:"-9";i:1;s:1:"0";i:2;s:3:"565";i:3;s:3:"698";}}i:166;a:4:{s:1:"C";s:3:"166";s:2:"WX";s:3:"556";s:1:"N";s:6:"florin";s:1:"B";a:4:{i:0;s:3:"-10";i:1;s:4:"-210";i:2;s:3:"516";i:3;s:3:"737";}}s:6:"florin";a:4:{s:1:"C";s:3:"166";s:2:"WX";s:3:"556";s:1:"N";s:6:"florin";s:1:"B";a:4:{i:0;s:3:"-10";i:1;s:4:"-210";i:2;s:3:"516";i:3;s:3:"737";}}i:167;a:4:{s:1:"C";s:3:"167";s:2:"WX";s:3:"556";s:1:"N";s:7:"section";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:4:"-184";i:2;s:3:"522";i:3;s:3:"727";}}s:7:"section";a:4:{s:1:"C";s:3:"167";s:2:"WX";s:3:"556";s:1:"N";s:7:"section";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:4:"-184";i:2;s:3:"522";i:3;s:3:"727";}}i:168;a:4:{s:1:"C";s:3:"168";s:2:"WX";s:3:"556";s:1:"N";s:8:"currency";s:1:"B";a:4:{i:0;s:2:"-3";i:1;s:2:"76";i:2;s:3:"559";i:3;s:3:"636";}}s:8:"currency";a:4:{s:1:"C";s:3:"168";s:2:"WX";s:3:"556";s:1:"N";s:8:"currency";s:1:"B";a:4:{i:0;s:2:"-3";i:1;s:2:"76";i:2;s:3:"559";i:3;s:3:"636";}}i:169;a:4:{s:1:"C";s:3:"169";s:2:"WX";s:3:"238";s:1:"N";s:11:"quotesingle";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:3:"447";i:2;s:3:"168";i:3;s:3:"718";}}s:11:"quotesingle";a:4:{s:1:"C";s:3:"169";s:2:"WX";s:3:"238";s:1:"N";s:11:"quotesingle";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:3:"447";i:2;s:3:"168";i:3;s:3:"718";}}i:170;a:4:{s:1:"C";s:3:"170";s:2:"WX";s:3:"500";s:1:"N";s:12:"quotedblleft";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:3:"454";i:2;s:3:"436";i:3;s:3:"727";}}s:12:"quotedblleft";a:4:{s:1:"C";s:3:"170";s:2:"WX";s:3:"500";s:1:"N";s:12:"quotedblleft";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:3:"454";i:2;s:3:"436";i:3;s:3:"727";}}i:171;a:4:{s:1:"C";s:3:"171";s:2:"WX";s:3:"556";s:1:"N";s:13:"guillemotleft";s:1:"B";a:4:{i:0;s:2:"88";i:1;s:2:"76";i:2;s:3:"468";i:3;s:3:"484";}}s:13:"guillemotleft";a:4:{s:1:"C";s:3:"171";s:2:"WX";s:3:"556";s:1:"N";s:13:"guillemotleft";s:1:"B";a:4:{i:0;s:2:"88";i:1;s:2:"76";i:2;s:3:"468";i:3;s:3:"484";}}i:172;a:4:{s:1:"C";s:3:"172";s:2:"WX";s:3:"333";s:1:"N";s:13:"guilsinglleft";s:1:"B";a:4:{i:0;s:2:"83";i:1;s:2:"76";i:2;s:3:"250";i:3;s:3:"484";}}s:13:"guilsinglleft";a:4:{s:1:"C";s:3:"172";s:2:"WX";s:3:"333";s:1:"N";s:13:"guilsinglleft";s:1:"B";a:4:{i:0;s:2:"83";i:1;s:2:"76";i:2;s:3:"250";i:3;s:3:"484";}}i:173;a:4:{s:1:"C";s:3:"173";s:2:"WX";s:3:"333";s:1:"N";s:14:"guilsinglright";s:1:"B";a:4:{i:0;s:2:"83";i:1;s:2:"76";i:2;s:3:"250";i:3;s:3:"484";}}s:14:"guilsinglright";a:4:{s:1:"C";s:3:"173";s:2:"WX";s:3:"333";s:1:"N";s:14:"guilsinglright";s:1:"B";a:4:{i:0;s:2:"83";i:1;s:2:"76";i:2;s:3:"250";i:3;s:3:"484";}}i:174;a:4:{s:1:"C";s:3:"174";s:2:"WX";s:3:"611";s:1:"N";s:2:"fi";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:1:"0";i:2;s:3:"542";i:3;s:3:"727";}}s:2:"fi";a:4:{s:1:"C";s:3:"174";s:2:"WX";s:3:"611";s:1:"N";s:2:"fi";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:1:"0";i:2;s:3:"542";i:3;s:3:"727";}}i:175;a:4:{s:1:"C";s:3:"175";s:2:"WX";s:3:"611";s:1:"N";s:2:"fl";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:1:"0";i:2;s:3:"542";i:3;s:3:"727";}}s:2:"fl";a:4:{s:1:"C";s:3:"175";s:2:"WX";s:3:"611";s:1:"N";s:2:"fl";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:1:"0";i:2;s:3:"542";i:3;s:3:"727";}}i:177;a:4:{s:1:"C";s:3:"177";s:2:"WX";s:3:"556";s:1:"N";s:6:"endash";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"227";i:2;s:3:"556";i:3;s:3:"333";}}s:6:"endash";a:4:{s:1:"C";s:3:"177";s:2:"WX";s:3:"556";s:1:"N";s:6:"endash";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"227";i:2;s:3:"556";i:3;s:3:"333";}}i:178;a:4:{s:1:"C";s:3:"178";s:2:"WX";s:3:"556";s:1:"N";s:6:"dagger";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:4:"-171";i:2;s:3:"520";i:3;s:3:"718";}}s:6:"dagger";a:4:{s:1:"C";s:3:"178";s:2:"WX";s:3:"556";s:1:"N";s:6:"dagger";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:4:"-171";i:2;s:3:"520";i:3;s:3:"718";}}i:179;a:4:{s:1:"C";s:3:"179";s:2:"WX";s:3:"556";s:1:"N";s:9:"daggerdbl";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:4:"-171";i:2;s:3:"520";i:3;s:3:"718";}}s:9:"daggerdbl";a:4:{s:1:"C";s:3:"179";s:2:"WX";s:3:"556";s:1:"N";s:9:"daggerdbl";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:4:"-171";i:2;s:3:"520";i:3;s:3:"718";}}i:180;a:4:{s:1:"C";s:3:"180";s:2:"WX";s:3:"278";s:1:"N";s:14:"periodcentered";s:1:"B";a:4:{i:0;s:2:"58";i:1;s:3:"172";i:2;s:3:"220";i:3;s:3:"334";}}s:14:"periodcentered";a:4:{s:1:"C";s:3:"180";s:2:"WX";s:3:"278";s:1:"N";s:14:"periodcentered";s:1:"B";a:4:{i:0;s:2:"58";i:1;s:3:"172";i:2;s:3:"220";i:3;s:3:"334";}}i:182;a:4:{s:1:"C";s:3:"182";s:2:"WX";s:3:"556";s:1:"N";s:9:"paragraph";s:1:"B";a:4:{i:0;s:2:"-8";i:1;s:4:"-191";i:2;s:3:"539";i:3;s:3:"700";}}s:9:"paragraph";a:4:{s:1:"C";s:3:"182";s:2:"WX";s:3:"556";s:1:"N";s:9:"paragraph";s:1:"B";a:4:{i:0;s:2:"-8";i:1;s:4:"-191";i:2;s:3:"539";i:3;s:3:"700";}}i:183;a:4:{s:1:"C";s:3:"183";s:2:"WX";s:3:"350";s:1:"N";s:6:"bullet";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:3:"194";i:2;s:3:"340";i:3;s:3:"524";}}s:6:"bullet";a:4:{s:1:"C";s:3:"183";s:2:"WX";s:3:"350";s:1:"N";s:6:"bullet";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:3:"194";i:2;s:3:"340";i:3;s:3:"524";}}i:184;a:4:{s:1:"C";s:3:"184";s:2:"WX";s:3:"278";s:1:"N";s:14:"quotesinglbase";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:4:"-146";i:2;s:3:"209";i:3;s:3:"127";}}s:14:"quotesinglbase";a:4:{s:1:"C";s:3:"184";s:2:"WX";s:3:"278";s:1:"N";s:14:"quotesinglbase";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:4:"-146";i:2;s:3:"209";i:3;s:3:"127";}}i:185;a:4:{s:1:"C";s:3:"185";s:2:"WX";s:3:"500";s:1:"N";s:12:"quotedblbase";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:4:"-146";i:2;s:3:"436";i:3;s:3:"127";}}s:12:"quotedblbase";a:4:{s:1:"C";s:3:"185";s:2:"WX";s:3:"500";s:1:"N";s:12:"quotedblbase";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:4:"-146";i:2;s:3:"436";i:3;s:3:"127";}}i:186;a:4:{s:1:"C";s:3:"186";s:2:"WX";s:3:"500";s:1:"N";s:13:"quotedblright";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:3:"445";i:2;s:3:"436";i:3;s:3:"718";}}s:13:"quotedblright";a:4:{s:1:"C";s:3:"186";s:2:"WX";s:3:"500";s:1:"N";s:13:"quotedblright";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:3:"445";i:2;s:3:"436";i:3;s:3:"718";}}i:187;a:4:{s:1:"C";s:3:"187";s:2:"WX";s:3:"556";s:1:"N";s:14:"guillemotright";s:1:"B";a:4:{i:0;s:2:"88";i:1;s:2:"76";i:2;s:3:"468";i:3;s:3:"484";}}s:14:"guillemotright";a:4:{s:1:"C";s:3:"187";s:2:"WX";s:3:"556";s:1:"N";s:14:"guillemotright";s:1:"B";a:4:{i:0;s:2:"88";i:1;s:2:"76";i:2;s:3:"468";i:3;s:3:"484";}}i:188;a:4:{s:1:"C";s:3:"188";s:2:"WX";s:4:"1000";s:1:"N";s:8:"ellipsis";s:1:"B";a:4:{i:0;s:2:"92";i:1;s:1:"0";i:2;s:3:"908";i:3;s:3:"146";}}s:8:"ellipsis";a:4:{s:1:"C";s:3:"188";s:2:"WX";s:4:"1000";s:1:"N";s:8:"ellipsis";s:1:"B";a:4:{i:0;s:2:"92";i:1;s:1:"0";i:2;s:3:"908";i:3;s:3:"146";}}i:189;a:4:{s:1:"C";s:3:"189";s:2:"WX";s:4:"1000";s:1:"N";s:11:"perthousand";s:1:"B";a:4:{i:0;s:2:"-3";i:1;s:3:"-19";i:2;s:4:"1003";i:3;s:3:"710";}}s:11:"perthousand";a:4:{s:1:"C";s:3:"189";s:2:"WX";s:4:"1000";s:1:"N";s:11:"perthousand";s:1:"B";a:4:{i:0;s:2:"-3";i:1;s:3:"-19";i:2;s:4:"1003";i:3;s:3:"710";}}i:191;a:4:{s:1:"C";s:3:"191";s:2:"WX";s:3:"611";s:1:"N";s:12:"questiondown";s:1:"B";a:4:{i:0;s:2:"55";i:1;s:4:"-195";i:2;s:3:"551";i:3;s:3:"532";}}s:12:"questiondown";a:4:{s:1:"C";s:3:"191";s:2:"WX";s:3:"611";s:1:"N";s:12:"questiondown";s:1:"B";a:4:{i:0;s:2:"55";i:1;s:4:"-195";i:2;s:3:"551";i:3;s:3:"532";}}i:193;a:4:{s:1:"C";s:3:"193";s:2:"WX";s:3:"333";s:1:"N";s:5:"grave";s:1:"B";a:4:{i:0;s:3:"-23";i:1;s:3:"604";i:2;s:3:"225";i:3;s:3:"750";}}s:5:"grave";a:4:{s:1:"C";s:3:"193";s:2:"WX";s:3:"333";s:1:"N";s:5:"grave";s:1:"B";a:4:{i:0;s:3:"-23";i:1;s:3:"604";i:2;s:3:"225";i:3;s:3:"750";}}i:194;a:4:{s:1:"C";s:3:"194";s:2:"WX";s:3:"333";s:1:"N";s:5:"acute";s:1:"B";a:4:{i:0;s:3:"108";i:1;s:3:"604";i:2;s:3:"356";i:3;s:3:"750";}}s:5:"acute";a:4:{s:1:"C";s:3:"194";s:2:"WX";s:3:"333";s:1:"N";s:5:"acute";s:1:"B";a:4:{i:0;s:3:"108";i:1;s:3:"604";i:2;s:3:"356";i:3;s:3:"750";}}i:195;a:4:{s:1:"C";s:3:"195";s:2:"WX";s:3:"333";s:1:"N";s:10:"circumflex";s:1:"B";a:4:{i:0;s:3:"-10";i:1;s:3:"604";i:2;s:3:"343";i:3;s:3:"750";}}s:10:"circumflex";a:4:{s:1:"C";s:3:"195";s:2:"WX";s:3:"333";s:1:"N";s:10:"circumflex";s:1:"B";a:4:{i:0;s:3:"-10";i:1;s:3:"604";i:2;s:3:"343";i:3;s:3:"750";}}i:196;a:4:{s:1:"C";s:3:"196";s:2:"WX";s:3:"333";s:1:"N";s:5:"tilde";s:1:"B";a:4:{i:0;s:3:"-17";i:1;s:3:"610";i:2;s:3:"350";i:3;s:3:"737";}}s:5:"tilde";a:4:{s:1:"C";s:3:"196";s:2:"WX";s:3:"333";s:1:"N";s:5:"tilde";s:1:"B";a:4:{i:0;s:3:"-17";i:1;s:3:"610";i:2;s:3:"350";i:3;s:3:"737";}}i:197;a:4:{s:1:"C";s:3:"197";s:2:"WX";s:3:"333";s:1:"N";s:6:"macron";s:1:"B";a:4:{i:0;s:2:"-6";i:1;s:3:"604";i:2;s:3:"339";i:3;s:3:"678";}}s:6:"macron";a:4:{s:1:"C";s:3:"197";s:2:"WX";s:3:"333";s:1:"N";s:6:"macron";s:1:"B";a:4:{i:0;s:2:"-6";i:1;s:3:"604";i:2;s:3:"339";i:3;s:3:"678";}}i:198;a:4:{s:1:"C";s:3:"198";s:2:"WX";s:3:"333";s:1:"N";s:5:"breve";s:1:"B";a:4:{i:0;s:2:"-2";i:1;s:3:"604";i:2;s:3:"335";i:3;s:3:"750";}}s:5:"breve";a:4:{s:1:"C";s:3:"198";s:2:"WX";s:3:"333";s:1:"N";s:5:"breve";s:1:"B";a:4:{i:0;s:2:"-2";i:1;s:3:"604";i:2;s:3:"335";i:3;s:3:"750";}}i:199;a:4:{s:1:"C";s:3:"199";s:2:"WX";s:3:"333";s:1:"N";s:9:"dotaccent";s:1:"B";a:4:{i:0;s:3:"104";i:1;s:3:"614";i:2;s:3:"230";i:3;s:3:"729";}}s:9:"dotaccent";a:4:{s:1:"C";s:3:"199";s:2:"WX";s:3:"333";s:1:"N";s:9:"dotaccent";s:1:"B";a:4:{i:0;s:3:"104";i:1;s:3:"614";i:2;s:3:"230";i:3;s:3:"729";}}i:200;a:4:{s:1:"C";s:3:"200";s:2:"WX";s:3:"333";s:1:"N";s:8:"dieresis";s:1:"B";a:4:{i:0;s:1:"6";i:1;s:3:"614";i:2;s:3:"327";i:3;s:3:"729";}}s:8:"dieresis";a:4:{s:1:"C";s:3:"200";s:2:"WX";s:3:"333";s:1:"N";s:8:"dieresis";s:1:"B";a:4:{i:0;s:1:"6";i:1;s:3:"614";i:2;s:3:"327";i:3;s:3:"729";}}i:202;a:4:{s:1:"C";s:3:"202";s:2:"WX";s:3:"333";s:1:"N";s:4:"ring";s:1:"B";a:4:{i:0;s:2:"59";i:1;s:3:"568";i:2;s:3:"275";i:3;s:3:"776";}}s:4:"ring";a:4:{s:1:"C";s:3:"202";s:2:"WX";s:3:"333";s:1:"N";s:4:"ring";s:1:"B";a:4:{i:0;s:2:"59";i:1;s:3:"568";i:2;s:3:"275";i:3;s:3:"776";}}i:203;a:4:{s:1:"C";s:3:"203";s:2:"WX";s:3:"333";s:1:"N";s:7:"cedilla";s:1:"B";a:4:{i:0;s:1:"6";i:1;s:4:"-228";i:2;s:3:"245";i:3;s:1:"0";}}s:7:"cedilla";a:4:{s:1:"C";s:3:"203";s:2:"WX";s:3:"333";s:1:"N";s:7:"cedilla";s:1:"B";a:4:{i:0;s:1:"6";i:1;s:4:"-228";i:2;s:3:"245";i:3;s:1:"0";}}i:205;a:4:{s:1:"C";s:3:"205";s:2:"WX";s:3:"333";s:1:"N";s:12:"hungarumlaut";s:1:"B";a:4:{i:0;s:1:"9";i:1;s:3:"604";i:2;s:3:"486";i:3;s:3:"750";}}s:12:"hungarumlaut";a:4:{s:1:"C";s:3:"205";s:2:"WX";s:3:"333";s:1:"N";s:12:"hungarumlaut";s:1:"B";a:4:{i:0;s:1:"9";i:1;s:3:"604";i:2;s:3:"486";i:3;s:3:"750";}}i:206;a:4:{s:1:"C";s:3:"206";s:2:"WX";s:3:"333";s:1:"N";s:6:"ogonek";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:4:"-228";i:2;s:3:"304";i:3;s:1:"0";}}s:6:"ogonek";a:4:{s:1:"C";s:3:"206";s:2:"WX";s:3:"333";s:1:"N";s:6:"ogonek";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:4:"-228";i:2;s:3:"304";i:3;s:1:"0";}}i:207;a:4:{s:1:"C";s:3:"207";s:2:"WX";s:3:"333";s:1:"N";s:5:"caron";s:1:"B";a:4:{i:0;s:3:"-10";i:1;s:3:"604";i:2;s:3:"343";i:3;s:3:"750";}}s:5:"caron";a:4:{s:1:"C";s:3:"207";s:2:"WX";s:3:"333";s:1:"N";s:5:"caron";s:1:"B";a:4:{i:0;s:3:"-10";i:1;s:3:"604";i:2;s:3:"343";i:3;s:3:"750";}}i:208;a:4:{s:1:"C";s:3:"208";s:2:"WX";s:4:"1000";s:1:"N";s:6:"emdash";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"227";i:2;s:4:"1000";i:3;s:3:"333";}}s:6:"emdash";a:4:{s:1:"C";s:3:"208";s:2:"WX";s:4:"1000";s:1:"N";s:6:"emdash";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"227";i:2;s:4:"1000";i:3;s:3:"333";}}i:225;a:4:{s:1:"C";s:3:"225";s:2:"WX";s:4:"1000";s:1:"N";s:2:"AE";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:1:"0";i:2;s:3:"954";i:3;s:3:"718";}}s:2:"AE";a:4:{s:1:"C";s:3:"225";s:2:"WX";s:4:"1000";s:1:"N";s:2:"AE";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:1:"0";i:2;s:3:"954";i:3;s:3:"718";}}i:227;a:4:{s:1:"C";s:3:"227";s:2:"WX";s:3:"370";s:1:"N";s:11:"ordfeminine";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"401";i:2;s:3:"347";i:3;s:3:"737";}}s:11:"ordfeminine";a:4:{s:1:"C";s:3:"227";s:2:"WX";s:3:"370";s:1:"N";s:11:"ordfeminine";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"401";i:2;s:3:"347";i:3;s:3:"737";}}i:232;a:4:{s:1:"C";s:3:"232";s:2:"WX";s:3:"611";s:1:"N";s:6:"Lslash";s:1:"B";a:4:{i:0;s:3:"-20";i:1;s:1:"0";i:2;s:3:"583";i:3;s:3:"718";}}s:6:"Lslash";a:4:{s:1:"C";s:3:"232";s:2:"WX";s:3:"611";s:1:"N";s:6:"Lslash";s:1:"B";a:4:{i:0;s:3:"-20";i:1;s:1:"0";i:2;s:3:"583";i:3;s:3:"718";}}i:233;a:4:{s:1:"C";s:3:"233";s:2:"WX";s:3:"778";s:1:"N";s:6:"Oslash";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:3:"-27";i:2;s:3:"744";i:3;s:3:"745";}}s:6:"Oslash";a:4:{s:1:"C";s:3:"233";s:2:"WX";s:3:"778";s:1:"N";s:6:"Oslash";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:3:"-27";i:2;s:3:"744";i:3;s:3:"745";}}i:234;a:4:{s:1:"C";s:3:"234";s:2:"WX";s:4:"1000";s:1:"N";s:2:"OE";s:1:"B";a:4:{i:0;s:2:"37";i:1;s:3:"-19";i:2;s:3:"961";i:3;s:3:"737";}}s:2:"OE";a:4:{s:1:"C";s:3:"234";s:2:"WX";s:4:"1000";s:1:"N";s:2:"OE";s:1:"B";a:4:{i:0;s:2:"37";i:1;s:3:"-19";i:2;s:3:"961";i:3;s:3:"737";}}i:235;a:4:{s:1:"C";s:3:"235";s:2:"WX";s:3:"365";s:1:"N";s:12:"ordmasculine";s:1:"B";a:4:{i:0;s:1:"6";i:1;s:3:"401";i:2;s:3:"360";i:3;s:3:"737";}}s:12:"ordmasculine";a:4:{s:1:"C";s:3:"235";s:2:"WX";s:3:"365";s:1:"N";s:12:"ordmasculine";s:1:"B";a:4:{i:0;s:1:"6";i:1;s:3:"401";i:2;s:3:"360";i:3;s:3:"737";}}i:241;a:4:{s:1:"C";s:3:"241";s:2:"WX";s:3:"889";s:1:"N";s:2:"ae";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:3:"-14";i:2;s:3:"858";i:3;s:3:"546";}}s:2:"ae";a:4:{s:1:"C";s:3:"241";s:2:"WX";s:3:"889";s:1:"N";s:2:"ae";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:3:"-14";i:2;s:3:"858";i:3;s:3:"546";}}i:245;a:4:{s:1:"C";s:3:"245";s:2:"WX";s:3:"278";s:1:"N";s:8:"dotlessi";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"209";i:3;s:3:"532";}}s:8:"dotlessi";a:4:{s:1:"C";s:3:"245";s:2:"WX";s:3:"278";s:1:"N";s:8:"dotlessi";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"209";i:3;s:3:"532";}}i:248;a:4:{s:1:"C";s:3:"248";s:2:"WX";s:3:"278";s:1:"N";s:6:"lslash";s:1:"B";a:4:{i:0;s:3:"-18";i:1;s:1:"0";i:2;s:3:"296";i:3;s:3:"718";}}s:6:"lslash";a:4:{s:1:"C";s:3:"248";s:2:"WX";s:3:"278";s:1:"N";s:6:"lslash";s:1:"B";a:4:{i:0;s:3:"-18";i:1;s:1:"0";i:2;s:3:"296";i:3;s:3:"718";}}i:249;a:4:{s:1:"C";s:3:"249";s:2:"WX";s:3:"611";s:1:"N";s:6:"oslash";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-29";i:2;s:3:"589";i:3;s:3:"560";}}s:6:"oslash";a:4:{s:1:"C";s:3:"249";s:2:"WX";s:3:"611";s:1:"N";s:6:"oslash";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-29";i:2;s:3:"589";i:3;s:3:"560";}}i:250;a:4:{s:1:"C";s:3:"250";s:2:"WX";s:3:"944";s:1:"N";s:2:"oe";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"912";i:3;s:3:"546";}}s:2:"oe";a:4:{s:1:"C";s:3:"250";s:2:"WX";s:3:"944";s:1:"N";s:2:"oe";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"912";i:3;s:3:"546";}}i:251;a:4:{s:1:"C";s:3:"251";s:2:"WX";s:3:"611";s:1:"N";s:10:"germandbls";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:3:"-14";i:2;s:3:"579";i:3;s:3:"731";}}s:10:"germandbls";a:4:{s:1:"C";s:3:"251";s:2:"WX";s:3:"611";s:1:"N";s:10:"germandbls";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:3:"-14";i:2;s:3:"579";i:3;s:3:"731";}}s:9:"Idieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:9:"Idieresis";s:1:"B";a:4:{i:0;s:3:"-21";i:1;s:1:"0";i:2;s:3:"300";i:3;s:3:"915";}}s:6:"eacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"eacute";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:3:"-14";i:2;s:3:"528";i:3;s:3:"750";}}s:6:"abreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"abreve";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:3:"-14";i:2;s:3:"527";i:3;s:3:"750";}}s:13:"uhungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:13:"uhungarumlaut";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:3:"-14";i:2;s:3:"625";i:3;s:3:"750";}}s:6:"ecaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"ecaron";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:3:"-14";i:2;s:3:"528";i:3;s:3:"750";}}s:9:"Ydieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:9:"Ydieresis";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:1:"0";i:2;s:3:"653";i:3;s:3:"915";}}s:6:"divide";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"584";s:1:"N";s:6:"divide";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"-42";i:2;s:3:"544";i:3;s:3:"548";}}s:6:"Yacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Yacute";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:1:"0";i:2;s:3:"653";i:3;s:3:"936";}}s:11:"Acircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:11:"Acircumflex";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"702";i:3;s:3:"936";}}s:6:"aacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"aacute";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:3:"-14";i:2;s:3:"527";i:3;s:3:"750";}}s:11:"Ucircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:11:"Ucircumflex";s:1:"B";a:4:{i:0;s:2:"72";i:1;s:3:"-19";i:2;s:3:"651";i:3;s:3:"936";}}s:6:"yacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"yacute";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:4:"-214";i:2;s:3:"539";i:3;s:3:"750";}}s:12:"scommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:12:"scommaaccent";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:4:"-228";i:2;s:3:"519";i:3;s:3:"546";}}s:11:"ecircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:11:"ecircumflex";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:3:"-14";i:2;s:3:"528";i:3;s:3:"750";}}s:5:"Uring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:5:"Uring";s:1:"B";a:4:{i:0;s:2:"72";i:1;s:3:"-19";i:2;s:3:"651";i:3;s:3:"962";}}s:9:"Udieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:9:"Udieresis";s:1:"B";a:4:{i:0;s:2:"72";i:1;s:3:"-19";i:2;s:3:"651";i:3;s:3:"915";}}s:7:"aogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:7:"aogonek";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:4:"-224";i:2;s:3:"545";i:3;s:3:"546";}}s:6:"Uacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Uacute";s:1:"B";a:4:{i:0;s:2:"72";i:1;s:3:"-19";i:2;s:3:"651";i:3;s:3:"936";}}s:7:"uogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:7:"uogonek";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:4:"-228";i:2;s:3:"545";i:3;s:3:"532";}}s:9:"Edieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:9:"Edieresis";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"621";i:3;s:3:"915";}}s:6:"Dcroat";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Dcroat";s:1:"B";a:4:{i:0;s:2:"-5";i:1;s:1:"0";i:2;s:3:"685";i:3;s:3:"718";}}s:11:"commaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"250";s:1:"N";s:11:"commaaccent";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:4:"-228";i:2;s:3:"199";i:3;s:3:"-50";}}s:9:"copyright";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"737";s:1:"N";s:9:"copyright";s:1:"B";a:4:{i:0;s:3:"-11";i:1;s:3:"-19";i:2;s:3:"749";i:3;s:3:"737";}}s:7:"Emacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:7:"Emacron";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"621";i:3;s:3:"864";}}s:6:"ccaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"ccaron";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"524";i:3;s:3:"750";}}s:5:"aring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:5:"aring";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:3:"-14";i:2;s:3:"527";i:3;s:3:"776";}}s:12:"Ncommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:12:"Ncommaaccent";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:4:"-228";i:2;s:3:"654";i:3;s:3:"718";}}s:6:"lacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:6:"lacute";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"329";i:3;s:3:"936";}}s:6:"agrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"agrave";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:3:"-14";i:2;s:3:"527";i:3;s:3:"750";}}s:12:"Tcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:12:"Tcommaaccent";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:4:"-228";i:2;s:3:"598";i:3;s:3:"718";}}s:6:"Cacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Cacute";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-19";i:2;s:3:"684";i:3;s:3:"936";}}s:6:"atilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"atilde";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:3:"-14";i:2;s:3:"527";i:3;s:3:"737";}}s:10:"Edotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:10:"Edotaccent";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"621";i:3;s:3:"915";}}s:6:"scaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"scaron";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-14";i:2;s:3:"519";i:3;s:3:"750";}}s:8:"scedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:8:"scedilla";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:4:"-228";i:2;s:3:"519";i:3;s:3:"546";}}s:6:"iacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:6:"iacute";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"329";i:3;s:3:"750";}}s:7:"lozenge";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"494";s:1:"N";s:7:"lozenge";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:1:"0";i:2;s:3:"484";i:3;s:3:"745";}}s:6:"Rcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Rcaron";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"677";i:3;s:3:"936";}}s:12:"Gcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:12:"Gcommaaccent";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:4:"-228";i:2;s:3:"713";i:3;s:3:"737";}}s:11:"ucircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:11:"ucircumflex";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:3:"-14";i:2;s:3:"545";i:3;s:3:"750";}}s:11:"acircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:11:"acircumflex";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:3:"-14";i:2;s:3:"527";i:3;s:3:"750";}}s:7:"Amacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:7:"Amacron";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"702";i:3;s:3:"864";}}s:6:"rcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:6:"rcaron";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:1:"0";i:2;s:3:"373";i:3;s:3:"750";}}s:8:"ccedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:8:"ccedilla";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:4:"-228";i:2;s:3:"524";i:3;s:3:"546";}}s:10:"Zdotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:10:"Zdotaccent";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"586";i:3;s:3:"915";}}s:5:"Thorn";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:5:"Thorn";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"627";i:3;s:3:"718";}}s:7:"Omacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:7:"Omacron";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-19";i:2;s:3:"734";i:3;s:3:"864";}}s:6:"Racute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Racute";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"677";i:3;s:3:"936";}}s:6:"Sacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Sacute";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:3:"-19";i:2;s:3:"629";i:3;s:3:"936";}}s:6:"dcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"743";s:1:"N";s:6:"dcaron";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"750";i:3;s:3:"718";}}s:7:"Umacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:7:"Umacron";s:1:"B";a:4:{i:0;s:2:"72";i:1;s:3:"-19";i:2;s:3:"651";i:3;s:3:"864";}}s:5:"uring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:5:"uring";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:3:"-14";i:2;s:3:"545";i:3;s:3:"776";}}s:13:"threesuperior";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"333";s:1:"N";s:13:"threesuperior";s:1:"B";a:4:{i:0;s:1:"8";i:1;s:3:"271";i:2;s:3:"326";i:3;s:3:"710";}}s:6:"Ograve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:6:"Ograve";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-19";i:2;s:3:"734";i:3;s:3:"936";}}s:6:"Agrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Agrave";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"702";i:3;s:3:"936";}}s:6:"Abreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Abreve";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"702";i:3;s:3:"936";}}s:8:"multiply";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"584";s:1:"N";s:8:"multiply";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:1:"1";i:2;s:3:"545";i:3;s:3:"505";}}s:6:"uacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"uacute";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:3:"-14";i:2;s:3:"545";i:3;s:3:"750";}}s:6:"Tcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"Tcaron";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"598";i:3;s:3:"936";}}s:11:"partialdiff";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"494";s:1:"N";s:11:"partialdiff";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:3:"-21";i:2;s:3:"494";i:3;s:3:"750";}}s:9:"ydieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:9:"ydieresis";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:4:"-214";i:2;s:3:"539";i:3;s:3:"729";}}s:6:"Nacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Nacute";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"654";i:3;s:3:"936";}}s:11:"icircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:11:"icircumflex";s:1:"B";a:4:{i:0;s:3:"-37";i:1;s:1:"0";i:2;s:3:"316";i:3;s:3:"750";}}s:11:"Ecircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:11:"Ecircumflex";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"621";i:3;s:3:"936";}}s:9:"adieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:9:"adieresis";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:3:"-14";i:2;s:3:"527";i:3;s:3:"729";}}s:9:"edieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:9:"edieresis";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:3:"-14";i:2;s:3:"528";i:3;s:3:"729";}}s:6:"cacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"cacute";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"524";i:3;s:3:"750";}}s:6:"nacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"nacute";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:1:"0";i:2;s:3:"546";i:3;s:3:"750";}}s:7:"umacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:7:"umacron";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:3:"-14";i:2;s:3:"545";i:3;s:3:"678";}}s:6:"Ncaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Ncaron";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"654";i:3;s:3:"936";}}s:6:"Iacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:6:"Iacute";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:1:"0";i:2;s:3:"329";i:3;s:3:"936";}}s:9:"plusminus";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"584";s:1:"N";s:9:"plusminus";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:1:"0";i:2;s:3:"544";i:3;s:3:"506";}}s:9:"brokenbar";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"280";s:1:"N";s:9:"brokenbar";s:1:"B";a:4:{i:0;s:2:"84";i:1;s:4:"-150";i:2;s:3:"196";i:3;s:3:"700";}}s:10:"registered";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"737";s:1:"N";s:10:"registered";s:1:"B";a:4:{i:0;s:3:"-11";i:1;s:3:"-19";i:2;s:3:"748";i:3;s:3:"737";}}s:6:"Gbreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:6:"Gbreve";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-19";i:2;s:3:"713";i:3;s:3:"936";}}s:10:"Idotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:10:"Idotaccent";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:1:"0";i:2;s:3:"214";i:3;s:3:"915";}}s:9:"summation";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"summation";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:3:"-10";i:2;s:3:"585";i:3;s:3:"706";}}s:6:"Egrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Egrave";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"621";i:3;s:3:"936";}}s:6:"racute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:6:"racute";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:1:"0";i:2;s:3:"384";i:3;s:3:"750";}}s:7:"omacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:7:"omacron";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"578";i:3;s:3:"678";}}s:6:"Zacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"Zacute";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"586";i:3;s:3:"936";}}s:6:"Zcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"Zcaron";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"586";i:3;s:3:"936";}}s:12:"greaterequal";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"549";s:1:"N";s:12:"greaterequal";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"523";i:3;s:3:"704";}}s:3:"Eth";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:3:"Eth";s:1:"B";a:4:{i:0;s:2:"-5";i:1;s:1:"0";i:2;s:3:"685";i:3;s:3:"718";}}s:8:"Ccedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:8:"Ccedilla";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:4:"-228";i:2;s:3:"684";i:3;s:3:"737";}}s:12:"lcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:12:"lcommaaccent";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:4:"-228";i:2;s:3:"213";i:3;s:3:"718";}}s:6:"tcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:6:"tcaron";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:2:"-6";i:2;s:3:"421";i:3;s:3:"878";}}s:7:"eogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:7:"eogonek";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:4:"-228";i:2;s:3:"528";i:3;s:3:"546";}}s:7:"Uogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:7:"Uogonek";s:1:"B";a:4:{i:0;s:2:"72";i:1;s:4:"-228";i:2;s:3:"651";i:3;s:3:"718";}}s:6:"Aacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Aacute";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"702";i:3;s:3:"936";}}s:9:"Adieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:9:"Adieresis";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"702";i:3;s:3:"915";}}s:6:"egrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"egrave";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:3:"-14";i:2;s:3:"528";i:3;s:3:"750";}}s:6:"zacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"zacute";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"480";i:3;s:3:"750";}}s:7:"iogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:7:"iogonek";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:4:"-224";i:2;s:3:"249";i:3;s:3:"725";}}s:6:"Oacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:6:"Oacute";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-19";i:2;s:3:"734";i:3;s:3:"936";}}s:6:"oacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"oacute";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"578";i:3;s:3:"750";}}s:7:"amacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:7:"amacron";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:3:"-14";i:2;s:3:"527";i:3;s:3:"678";}}s:6:"sacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"sacute";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-14";i:2;s:3:"519";i:3;s:3:"750";}}s:9:"idieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:9:"idieresis";s:1:"B";a:4:{i:0;s:3:"-21";i:1;s:1:"0";i:2;s:3:"300";i:3;s:3:"729";}}s:11:"Ocircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:11:"Ocircumflex";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-19";i:2;s:3:"734";i:3;s:3:"936";}}s:6:"Ugrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Ugrave";s:1:"B";a:4:{i:0;s:2:"72";i:1;s:3:"-19";i:2;s:3:"651";i:3;s:3:"936";}}s:5:"Delta";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"612";s:1:"N";s:5:"Delta";s:1:"B";a:4:{i:0;s:1:"6";i:1;s:1:"0";i:2;s:3:"608";i:3;s:3:"688";}}s:5:"thorn";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:5:"thorn";s:1:"B";a:4:{i:0;s:2:"62";i:1;s:4:"-208";i:2;s:3:"578";i:3;s:3:"718";}}s:11:"twosuperior";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"333";s:1:"N";s:11:"twosuperior";s:1:"B";a:4:{i:0;s:1:"9";i:1;s:3:"283";i:2;s:3:"324";i:3;s:3:"710";}}s:9:"Odieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:9:"Odieresis";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-19";i:2;s:3:"734";i:3;s:3:"915";}}s:2:"mu";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:2:"mu";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:4:"-207";i:2;s:3:"545";i:3;s:3:"532";}}s:6:"igrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:6:"igrave";s:1:"B";a:4:{i:0;s:3:"-50";i:1;s:1:"0";i:2;s:3:"209";i:3;s:3:"750";}}s:13:"ohungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:13:"ohungarumlaut";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"625";i:3;s:3:"750";}}s:7:"Eogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:7:"Eogonek";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:4:"-224";i:2;s:3:"639";i:3;s:3:"718";}}s:6:"dcroat";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"dcroat";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"650";i:3;s:3:"718";}}s:13:"threequarters";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"834";s:1:"N";s:13:"threequarters";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-19";i:2;s:3:"799";i:3;s:3:"710";}}s:8:"Scedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:8:"Scedilla";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:4:"-228";i:2;s:3:"629";i:3;s:3:"737";}}s:6:"lcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"400";s:1:"N";s:6:"lcaron";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"408";i:3;s:3:"718";}}s:12:"Kcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:12:"Kcommaaccent";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:4:"-228";i:2;s:3:"722";i:3;s:3:"718";}}s:6:"Lacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"Lacute";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"583";i:3;s:3:"936";}}s:9:"trademark";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:4:"1000";s:1:"N";s:9:"trademark";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"306";i:2;s:3:"956";i:3;s:3:"718";}}s:10:"edotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:10:"edotaccent";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:3:"-14";i:2;s:3:"528";i:3;s:3:"729";}}s:6:"Igrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:6:"Igrave";s:1:"B";a:4:{i:0;s:3:"-50";i:1;s:1:"0";i:2;s:3:"214";i:3;s:3:"936";}}s:7:"Imacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:7:"Imacron";s:1:"B";a:4:{i:0;s:3:"-33";i:1;s:1:"0";i:2;s:3:"312";i:3;s:3:"864";}}s:6:"Lcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"Lcaron";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"583";i:3;s:3:"718";}}s:7:"onehalf";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"834";s:1:"N";s:7:"onehalf";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:3:"-19";i:2;s:3:"794";i:3;s:3:"710";}}s:9:"lessequal";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"549";s:1:"N";s:9:"lessequal";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:1:"0";i:2;s:3:"526";i:3;s:3:"704";}}s:11:"ocircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:11:"ocircumflex";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"578";i:3;s:3:"750";}}s:6:"ntilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"ntilde";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:1:"0";i:2;s:3:"546";i:3;s:3:"737";}}s:13:"Uhungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:13:"Uhungarumlaut";s:1:"B";a:4:{i:0;s:2:"72";i:1;s:3:"-19";i:2;s:3:"681";i:3;s:3:"936";}}s:6:"Eacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Eacute";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"621";i:3;s:3:"936";}}s:7:"emacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:7:"emacron";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:3:"-14";i:2;s:3:"528";i:3;s:3:"678";}}s:6:"gbreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"gbreve";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:4:"-217";i:2;s:3:"553";i:3;s:3:"750";}}s:10:"onequarter";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"834";s:1:"N";s:10:"onequarter";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:3:"-19";i:2;s:3:"766";i:3;s:3:"710";}}s:6:"Scaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Scaron";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:3:"-19";i:2;s:3:"629";i:3;s:3:"936";}}s:12:"Scommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:12:"Scommaaccent";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:4:"-228";i:2;s:3:"629";i:3;s:3:"737";}}s:13:"Ohungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:13:"Ohungarumlaut";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-19";i:2;s:3:"734";i:3;s:3:"936";}}s:6:"degree";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"400";s:1:"N";s:6:"degree";s:1:"B";a:4:{i:0;s:2:"57";i:1;s:3:"426";i:2;s:3:"343";i:3;s:3:"712";}}s:6:"ograve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"ograve";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"578";i:3;s:3:"750";}}s:6:"Ccaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Ccaron";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-19";i:2;s:3:"684";i:3;s:3:"936";}}s:6:"ugrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"ugrave";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:3:"-14";i:2;s:3:"545";i:3;s:3:"750";}}s:7:"radical";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"549";s:1:"N";s:7:"radical";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:3:"-46";i:2;s:3:"512";i:3;s:3:"850";}}s:6:"Dcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Dcaron";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"685";i:3;s:3:"936";}}s:12:"rcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:12:"rcommaaccent";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:4:"-228";i:2;s:3:"373";i:3;s:3:"546";}}s:6:"Ntilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Ntilde";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"654";i:3;s:3:"923";}}s:6:"otilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"otilde";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"578";i:3;s:3:"737";}}s:12:"Rcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:12:"Rcommaaccent";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:4:"-228";i:2;s:3:"677";i:3;s:3:"718";}}s:12:"Lcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:12:"Lcommaaccent";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:4:"-228";i:2;s:3:"583";i:3;s:3:"718";}}s:6:"Atilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Atilde";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"702";i:3;s:3:"923";}}s:7:"Aogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:7:"Aogonek";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:4:"-224";i:2;s:3:"742";i:3;s:3:"718";}}s:5:"Aring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:5:"Aring";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"702";i:3;s:3:"962";}}s:6:"Otilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:6:"Otilde";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-19";i:2;s:3:"734";i:3;s:3:"923";}}s:10:"zdotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:10:"zdotaccent";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"480";i:3;s:3:"729";}}s:6:"Ecaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Ecaron";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"621";i:3;s:3:"936";}}s:7:"Iogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:7:"Iogonek";s:1:"B";a:4:{i:0;s:3:"-11";i:1;s:4:"-228";i:2;s:3:"222";i:3;s:3:"718";}}s:12:"kcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:12:"kcommaaccent";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:4:"-228";i:2;s:3:"562";i:3;s:3:"718";}}s:5:"minus";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"584";s:1:"N";s:5:"minus";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"197";i:2;s:3:"544";i:3;s:3:"309";}}s:11:"Icircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:11:"Icircumflex";s:1:"B";a:4:{i:0;s:3:"-37";i:1;s:1:"0";i:2;s:3:"316";i:3;s:3:"936";}}s:6:"ncaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"ncaron";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:1:"0";i:2;s:3:"546";i:3;s:3:"750";}}s:12:"tcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"333";s:1:"N";s:12:"tcommaaccent";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:4:"-228";i:2;s:3:"309";i:3;s:3:"676";}}s:10:"logicalnot";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"584";s:1:"N";s:10:"logicalnot";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"108";i:2;s:3:"544";i:3;s:3:"419";}}s:9:"odieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:9:"odieresis";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"578";i:3;s:3:"729";}}s:9:"udieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:9:"udieresis";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:3:"-14";i:2;s:3:"545";i:3;s:3:"729";}}s:8:"notequal";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"549";s:1:"N";s:8:"notequal";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:3:"-49";i:2;s:3:"540";i:3;s:3:"570";}}s:12:"gcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:12:"gcommaaccent";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:4:"-217";i:2;s:3:"553";i:3;s:3:"850";}}s:3:"eth";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:3:"eth";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"578";i:3;s:3:"737";}}s:6:"zcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"zcaron";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"480";i:3;s:3:"750";}}s:12:"ncommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:12:"ncommaaccent";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:4:"-228";i:2;s:3:"546";i:3;s:3:"546";}}s:11:"onesuperior";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"333";s:1:"N";s:11:"onesuperior";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:3:"283";i:2;s:3:"237";i:3;s:3:"710";}}s:7:"imacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:7:"imacron";s:1:"B";a:4:{i:0;s:2:"-8";i:1;s:1:"0";i:2;s:3:"285";i:3;s:3:"678";}}s:4:"Euro";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:4:"Euro";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}}s:3:"KPX";a:134:{s:1:"A";a:48:{s:1:"C";s:3:"-40";s:6:"Cacute";s:3:"-40";s:6:"Ccaron";s:3:"-40";s:8:"Ccedilla";s:3:"-40";s:1:"G";s:3:"-50";s:6:"Gbreve";s:3:"-50";s:12:"Gcommaaccent";s:3:"-50";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"Q";s:3:"-40";s:1:"T";s:3:"-90";s:6:"Tcaron";s:3:"-90";s:12:"Tcommaaccent";s:3:"-90";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-80";s:1:"W";s:3:"-60";s:1:"Y";s:4:"-110";s:6:"Yacute";s:4:"-110";s:9:"Ydieresis";s:4:"-110";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-40";s:1:"w";s:3:"-30";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:6:"Aacute";a:48:{s:1:"C";s:3:"-40";s:6:"Cacute";s:3:"-40";s:6:"Ccaron";s:3:"-40";s:8:"Ccedilla";s:3:"-40";s:1:"G";s:3:"-50";s:6:"Gbreve";s:3:"-50";s:12:"Gcommaaccent";s:3:"-50";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"Q";s:3:"-40";s:1:"T";s:3:"-90";s:6:"Tcaron";s:3:"-90";s:12:"Tcommaaccent";s:3:"-90";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-80";s:1:"W";s:3:"-60";s:1:"Y";s:4:"-110";s:6:"Yacute";s:4:"-110";s:9:"Ydieresis";s:4:"-110";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-40";s:1:"w";s:3:"-30";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:6:"Abreve";a:48:{s:1:"C";s:3:"-40";s:6:"Cacute";s:3:"-40";s:6:"Ccaron";s:3:"-40";s:8:"Ccedilla";s:3:"-40";s:1:"G";s:3:"-50";s:6:"Gbreve";s:3:"-50";s:12:"Gcommaaccent";s:3:"-50";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"Q";s:3:"-40";s:1:"T";s:3:"-90";s:6:"Tcaron";s:3:"-90";s:12:"Tcommaaccent";s:3:"-90";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-80";s:1:"W";s:3:"-60";s:1:"Y";s:4:"-110";s:6:"Yacute";s:4:"-110";s:9:"Ydieresis";s:4:"-110";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-40";s:1:"w";s:3:"-30";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:11:"Acircumflex";a:48:{s:1:"C";s:3:"-40";s:6:"Cacute";s:3:"-40";s:6:"Ccaron";s:3:"-40";s:8:"Ccedilla";s:3:"-40";s:1:"G";s:3:"-50";s:6:"Gbreve";s:3:"-50";s:12:"Gcommaaccent";s:3:"-50";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"Q";s:3:"-40";s:1:"T";s:3:"-90";s:6:"Tcaron";s:3:"-90";s:12:"Tcommaaccent";s:3:"-90";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-80";s:1:"W";s:3:"-60";s:1:"Y";s:4:"-110";s:6:"Yacute";s:4:"-110";s:9:"Ydieresis";s:4:"-110";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-40";s:1:"w";s:3:"-30";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:9:"Adieresis";a:48:{s:1:"C";s:3:"-40";s:6:"Cacute";s:3:"-40";s:6:"Ccaron";s:3:"-40";s:8:"Ccedilla";s:3:"-40";s:1:"G";s:3:"-50";s:6:"Gbreve";s:3:"-50";s:12:"Gcommaaccent";s:3:"-50";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"Q";s:3:"-40";s:1:"T";s:3:"-90";s:6:"Tcaron";s:3:"-90";s:12:"Tcommaaccent";s:3:"-90";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-80";s:1:"W";s:3:"-60";s:1:"Y";s:4:"-110";s:6:"Yacute";s:4:"-110";s:9:"Ydieresis";s:4:"-110";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-40";s:1:"w";s:3:"-30";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:6:"Agrave";a:48:{s:1:"C";s:3:"-40";s:6:"Cacute";s:3:"-40";s:6:"Ccaron";s:3:"-40";s:8:"Ccedilla";s:3:"-40";s:1:"G";s:3:"-50";s:6:"Gbreve";s:3:"-50";s:12:"Gcommaaccent";s:3:"-50";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"Q";s:3:"-40";s:1:"T";s:3:"-90";s:6:"Tcaron";s:3:"-90";s:12:"Tcommaaccent";s:3:"-90";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-80";s:1:"W";s:3:"-60";s:1:"Y";s:4:"-110";s:6:"Yacute";s:4:"-110";s:9:"Ydieresis";s:4:"-110";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-40";s:1:"w";s:3:"-30";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:7:"Amacron";a:48:{s:1:"C";s:3:"-40";s:6:"Cacute";s:3:"-40";s:6:"Ccaron";s:3:"-40";s:8:"Ccedilla";s:3:"-40";s:1:"G";s:3:"-50";s:6:"Gbreve";s:3:"-50";s:12:"Gcommaaccent";s:3:"-50";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"Q";s:3:"-40";s:1:"T";s:3:"-90";s:6:"Tcaron";s:3:"-90";s:12:"Tcommaaccent";s:3:"-90";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-80";s:1:"W";s:3:"-60";s:1:"Y";s:4:"-110";s:6:"Yacute";s:4:"-110";s:9:"Ydieresis";s:4:"-110";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-40";s:1:"w";s:3:"-30";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:7:"Aogonek";a:48:{s:1:"C";s:3:"-40";s:6:"Cacute";s:3:"-40";s:6:"Ccaron";s:3:"-40";s:8:"Ccedilla";s:3:"-40";s:1:"G";s:3:"-50";s:6:"Gbreve";s:3:"-50";s:12:"Gcommaaccent";s:3:"-50";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"Q";s:3:"-40";s:1:"T";s:3:"-90";s:6:"Tcaron";s:3:"-90";s:12:"Tcommaaccent";s:3:"-90";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-80";s:1:"W";s:3:"-60";s:1:"Y";s:4:"-110";s:6:"Yacute";s:4:"-110";s:9:"Ydieresis";s:4:"-110";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-40";s:1:"w";s:3:"-30";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:5:"Aring";a:48:{s:1:"C";s:3:"-40";s:6:"Cacute";s:3:"-40";s:6:"Ccaron";s:3:"-40";s:8:"Ccedilla";s:3:"-40";s:1:"G";s:3:"-50";s:6:"Gbreve";s:3:"-50";s:12:"Gcommaaccent";s:3:"-50";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"Q";s:3:"-40";s:1:"T";s:3:"-90";s:6:"Tcaron";s:3:"-90";s:12:"Tcommaaccent";s:3:"-90";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-80";s:1:"W";s:3:"-60";s:1:"Y";s:4:"-110";s:6:"Yacute";s:4:"-110";s:9:"Ydieresis";s:4:"-110";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-40";s:1:"w";s:3:"-30";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:6:"Atilde";a:48:{s:1:"C";s:3:"-40";s:6:"Cacute";s:3:"-40";s:6:"Ccaron";s:3:"-40";s:8:"Ccedilla";s:3:"-40";s:1:"G";s:3:"-50";s:6:"Gbreve";s:3:"-50";s:12:"Gcommaaccent";s:3:"-50";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"Q";s:3:"-40";s:1:"T";s:3:"-90";s:6:"Tcaron";s:3:"-90";s:12:"Tcommaaccent";s:3:"-90";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-80";s:1:"W";s:3:"-60";s:1:"Y";s:4:"-110";s:6:"Yacute";s:4:"-110";s:9:"Ydieresis";s:4:"-110";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-40";s:1:"w";s:3:"-30";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:1:"B";a:19:{s:1:"A";s:3:"-30";s:6:"Aacute";s:3:"-30";s:6:"Abreve";s:3:"-30";s:11:"Acircumflex";s:3:"-30";s:9:"Adieresis";s:3:"-30";s:6:"Agrave";s:3:"-30";s:7:"Amacron";s:3:"-30";s:7:"Aogonek";s:3:"-30";s:5:"Aring";s:3:"-30";s:6:"Atilde";s:3:"-30";s:1:"U";s:3:"-10";s:6:"Uacute";s:3:"-10";s:11:"Ucircumflex";s:3:"-10";s:9:"Udieresis";s:3:"-10";s:6:"Ugrave";s:3:"-10";s:13:"Uhungarumlaut";s:3:"-10";s:7:"Umacron";s:3:"-10";s:7:"Uogonek";s:3:"-10";s:5:"Uring";s:3:"-10";}s:1:"D";a:17:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:1:"V";s:3:"-40";s:1:"W";s:3:"-40";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-30";s:6:"period";s:3:"-30";}s:6:"Dcaron";a:17:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:1:"V";s:3:"-40";s:1:"W";s:3:"-40";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-30";s:6:"period";s:3:"-30";}s:6:"Dcroat";a:17:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:1:"V";s:3:"-40";s:1:"W";s:3:"-40";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-30";s:6:"period";s:3:"-30";}s:1:"F";a:22:{s:1:"A";s:3:"-80";s:6:"Aacute";s:3:"-80";s:6:"Abreve";s:3:"-80";s:11:"Acircumflex";s:3:"-80";s:9:"Adieresis";s:3:"-80";s:6:"Agrave";s:3:"-80";s:7:"Amacron";s:3:"-80";s:7:"Aogonek";s:3:"-80";s:5:"Aring";s:3:"-80";s:6:"Atilde";s:3:"-80";s:1:"a";s:3:"-20";s:6:"aacute";s:3:"-20";s:6:"abreve";s:3:"-20";s:11:"acircumflex";s:3:"-20";s:9:"adieresis";s:3:"-20";s:6:"agrave";s:3:"-20";s:7:"amacron";s:3:"-20";s:7:"aogonek";s:3:"-20";s:5:"aring";s:3:"-20";s:6:"atilde";s:3:"-20";s:5:"comma";s:4:"-100";s:6:"period";s:4:"-100";}s:1:"J";a:21:{s:1:"A";s:3:"-20";s:6:"Aacute";s:3:"-20";s:6:"Abreve";s:3:"-20";s:11:"Acircumflex";s:3:"-20";s:9:"Adieresis";s:3:"-20";s:6:"Agrave";s:3:"-20";s:7:"Amacron";s:3:"-20";s:7:"Aogonek";s:3:"-20";s:5:"Aring";s:3:"-20";s:6:"Atilde";s:3:"-20";s:5:"comma";s:3:"-20";s:6:"period";s:3:"-20";s:1:"u";s:3:"-20";s:6:"uacute";s:3:"-20";s:11:"ucircumflex";s:3:"-20";s:9:"udieresis";s:3:"-20";s:6:"ugrave";s:3:"-20";s:13:"uhungarumlaut";s:3:"-20";s:7:"umacron";s:3:"-20";s:7:"uogonek";s:3:"-20";s:5:"uring";s:3:"-20";}s:1:"K";a:39:{s:1:"O";s:3:"-30";s:6:"Oacute";s:3:"-30";s:11:"Ocircumflex";s:3:"-30";s:9:"Odieresis";s:3:"-30";s:6:"Ograve";s:3:"-30";s:13:"Ohungarumlaut";s:3:"-30";s:7:"Omacron";s:3:"-30";s:6:"Oslash";s:3:"-30";s:6:"Otilde";s:3:"-30";s:1:"e";s:3:"-15";s:6:"eacute";s:3:"-15";s:6:"ecaron";s:3:"-15";s:11:"ecircumflex";s:3:"-15";s:9:"edieresis";s:3:"-15";s:10:"edotaccent";s:3:"-15";s:6:"egrave";s:3:"-15";s:7:"emacron";s:3:"-15";s:7:"eogonek";s:3:"-15";s:1:"o";s:3:"-35";s:6:"oacute";s:3:"-35";s:11:"ocircumflex";s:3:"-35";s:9:"odieresis";s:3:"-35";s:6:"ograve";s:3:"-35";s:13:"ohungarumlaut";s:3:"-35";s:7:"omacron";s:3:"-35";s:6:"oslash";s:3:"-35";s:6:"otilde";s:3:"-35";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"y";s:3:"-40";s:6:"yacute";s:3:"-40";s:9:"ydieresis";s:3:"-40";}s:12:"Kcommaaccent";a:39:{s:1:"O";s:3:"-30";s:6:"Oacute";s:3:"-30";s:11:"Ocircumflex";s:3:"-30";s:9:"Odieresis";s:3:"-30";s:6:"Ograve";s:3:"-30";s:13:"Ohungarumlaut";s:3:"-30";s:7:"Omacron";s:3:"-30";s:6:"Oslash";s:3:"-30";s:6:"Otilde";s:3:"-30";s:1:"e";s:3:"-15";s:6:"eacute";s:3:"-15";s:6:"ecaron";s:3:"-15";s:11:"ecircumflex";s:3:"-15";s:9:"edieresis";s:3:"-15";s:10:"edotaccent";s:3:"-15";s:6:"egrave";s:3:"-15";s:7:"emacron";s:3:"-15";s:7:"eogonek";s:3:"-15";s:1:"o";s:3:"-35";s:6:"oacute";s:3:"-35";s:11:"ocircumflex";s:3:"-35";s:9:"odieresis";s:3:"-35";s:6:"ograve";s:3:"-35";s:13:"ohungarumlaut";s:3:"-35";s:7:"omacron";s:3:"-35";s:6:"oslash";s:3:"-35";s:6:"otilde";s:3:"-35";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"y";s:3:"-40";s:6:"yacute";s:3:"-40";s:9:"ydieresis";s:3:"-40";}s:1:"L";a:13:{s:1:"T";s:3:"-90";s:6:"Tcaron";s:3:"-90";s:12:"Tcommaaccent";s:3:"-90";s:1:"V";s:4:"-110";s:1:"W";s:3:"-80";s:1:"Y";s:4:"-120";s:6:"Yacute";s:4:"-120";s:9:"Ydieresis";s:4:"-120";s:13:"quotedblright";s:4:"-140";s:10:"quoteright";s:4:"-140";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:6:"Lacute";a:13:{s:1:"T";s:3:"-90";s:6:"Tcaron";s:3:"-90";s:12:"Tcommaaccent";s:3:"-90";s:1:"V";s:4:"-110";s:1:"W";s:3:"-80";s:1:"Y";s:4:"-120";s:6:"Yacute";s:4:"-120";s:9:"Ydieresis";s:4:"-120";s:13:"quotedblright";s:4:"-140";s:10:"quoteright";s:4:"-140";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:12:"Lcommaaccent";a:13:{s:1:"T";s:3:"-90";s:6:"Tcaron";s:3:"-90";s:12:"Tcommaaccent";s:3:"-90";s:1:"V";s:4:"-110";s:1:"W";s:3:"-80";s:1:"Y";s:4:"-120";s:6:"Yacute";s:4:"-120";s:9:"Ydieresis";s:4:"-120";s:13:"quotedblright";s:4:"-140";s:10:"quoteright";s:4:"-140";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:6:"Lslash";a:13:{s:1:"T";s:3:"-90";s:6:"Tcaron";s:3:"-90";s:12:"Tcommaaccent";s:3:"-90";s:1:"V";s:4:"-110";s:1:"W";s:3:"-80";s:1:"Y";s:4:"-120";s:6:"Yacute";s:4:"-120";s:9:"Ydieresis";s:4:"-120";s:13:"quotedblright";s:4:"-140";s:10:"quoteright";s:4:"-140";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:1:"O";a:21:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-50";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:6:"Oacute";a:21:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-50";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:11:"Ocircumflex";a:21:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-50";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:9:"Odieresis";a:21:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-50";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:6:"Ograve";a:21:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-50";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:13:"Ohungarumlaut";a:21:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-50";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:7:"Omacron";a:21:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-50";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:6:"Oslash";a:21:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-50";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:6:"Otilde";a:21:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-50";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:1:"P";a:40:{s:1:"A";s:4:"-100";s:6:"Aacute";s:4:"-100";s:6:"Abreve";s:4:"-100";s:11:"Acircumflex";s:4:"-100";s:9:"Adieresis";s:4:"-100";s:6:"Agrave";s:4:"-100";s:7:"Amacron";s:4:"-100";s:7:"Aogonek";s:4:"-100";s:5:"Aring";s:4:"-100";s:6:"Atilde";s:4:"-100";s:1:"a";s:3:"-30";s:6:"aacute";s:3:"-30";s:6:"abreve";s:3:"-30";s:11:"acircumflex";s:3:"-30";s:9:"adieresis";s:3:"-30";s:6:"agrave";s:3:"-30";s:7:"amacron";s:3:"-30";s:7:"aogonek";s:3:"-30";s:5:"aring";s:3:"-30";s:6:"atilde";s:3:"-30";s:5:"comma";s:4:"-120";s:1:"e";s:3:"-30";s:6:"eacute";s:3:"-30";s:6:"ecaron";s:3:"-30";s:11:"ecircumflex";s:3:"-30";s:9:"edieresis";s:3:"-30";s:10:"edotaccent";s:3:"-30";s:6:"egrave";s:3:"-30";s:7:"emacron";s:3:"-30";s:7:"eogonek";s:3:"-30";s:1:"o";s:3:"-40";s:6:"oacute";s:3:"-40";s:11:"ocircumflex";s:3:"-40";s:9:"odieresis";s:3:"-40";s:6:"ograve";s:3:"-40";s:13:"ohungarumlaut";s:3:"-40";s:7:"omacron";s:3:"-40";s:6:"oslash";s:3:"-40";s:6:"otilde";s:3:"-40";s:6:"period";s:4:"-120";}s:1:"Q";a:11:{s:1:"U";s:3:"-10";s:6:"Uacute";s:3:"-10";s:11:"Ucircumflex";s:3:"-10";s:9:"Udieresis";s:3:"-10";s:6:"Ugrave";s:3:"-10";s:13:"Uhungarumlaut";s:3:"-10";s:7:"Umacron";s:3:"-10";s:7:"Uogonek";s:3:"-10";s:5:"Uring";s:3:"-10";s:5:"comma";s:2:"20";s:6:"period";s:2:"20";}s:1:"R";a:26:{s:1:"O";s:3:"-20";s:6:"Oacute";s:3:"-20";s:11:"Ocircumflex";s:3:"-20";s:9:"Odieresis";s:3:"-20";s:6:"Ograve";s:3:"-20";s:13:"Ohungarumlaut";s:3:"-20";s:7:"Omacron";s:3:"-20";s:6:"Oslash";s:3:"-20";s:6:"Otilde";s:3:"-20";s:1:"T";s:3:"-20";s:6:"Tcaron";s:3:"-20";s:12:"Tcommaaccent";s:3:"-20";s:1:"U";s:3:"-20";s:6:"Uacute";s:3:"-20";s:11:"Ucircumflex";s:3:"-20";s:9:"Udieresis";s:3:"-20";s:6:"Ugrave";s:3:"-20";s:13:"Uhungarumlaut";s:3:"-20";s:7:"Umacron";s:3:"-20";s:7:"Uogonek";s:3:"-20";s:5:"Uring";s:3:"-20";s:1:"V";s:3:"-50";s:1:"W";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:6:"Racute";a:26:{s:1:"O";s:3:"-20";s:6:"Oacute";s:3:"-20";s:11:"Ocircumflex";s:3:"-20";s:9:"Odieresis";s:3:"-20";s:6:"Ograve";s:3:"-20";s:13:"Ohungarumlaut";s:3:"-20";s:7:"Omacron";s:3:"-20";s:6:"Oslash";s:3:"-20";s:6:"Otilde";s:3:"-20";s:1:"T";s:3:"-20";s:6:"Tcaron";s:3:"-20";s:12:"Tcommaaccent";s:3:"-20";s:1:"U";s:3:"-20";s:6:"Uacute";s:3:"-20";s:11:"Ucircumflex";s:3:"-20";s:9:"Udieresis";s:3:"-20";s:6:"Ugrave";s:3:"-20";s:13:"Uhungarumlaut";s:3:"-20";s:7:"Umacron";s:3:"-20";s:7:"Uogonek";s:3:"-20";s:5:"Uring";s:3:"-20";s:1:"V";s:3:"-50";s:1:"W";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:6:"Rcaron";a:26:{s:1:"O";s:3:"-20";s:6:"Oacute";s:3:"-20";s:11:"Ocircumflex";s:3:"-20";s:9:"Odieresis";s:3:"-20";s:6:"Ograve";s:3:"-20";s:13:"Ohungarumlaut";s:3:"-20";s:7:"Omacron";s:3:"-20";s:6:"Oslash";s:3:"-20";s:6:"Otilde";s:3:"-20";s:1:"T";s:3:"-20";s:6:"Tcaron";s:3:"-20";s:12:"Tcommaaccent";s:3:"-20";s:1:"U";s:3:"-20";s:6:"Uacute";s:3:"-20";s:11:"Ucircumflex";s:3:"-20";s:9:"Udieresis";s:3:"-20";s:6:"Ugrave";s:3:"-20";s:13:"Uhungarumlaut";s:3:"-20";s:7:"Umacron";s:3:"-20";s:7:"Uogonek";s:3:"-20";s:5:"Uring";s:3:"-20";s:1:"V";s:3:"-50";s:1:"W";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:12:"Rcommaaccent";a:26:{s:1:"O";s:3:"-20";s:6:"Oacute";s:3:"-20";s:11:"Ocircumflex";s:3:"-20";s:9:"Odieresis";s:3:"-20";s:6:"Ograve";s:3:"-20";s:13:"Ohungarumlaut";s:3:"-20";s:7:"Omacron";s:3:"-20";s:6:"Oslash";s:3:"-20";s:6:"Otilde";s:3:"-20";s:1:"T";s:3:"-20";s:6:"Tcaron";s:3:"-20";s:12:"Tcommaaccent";s:3:"-20";s:1:"U";s:3:"-20";s:6:"Uacute";s:3:"-20";s:11:"Ucircumflex";s:3:"-20";s:9:"Udieresis";s:3:"-20";s:6:"Ugrave";s:3:"-20";s:13:"Uhungarumlaut";s:3:"-20";s:7:"Umacron";s:3:"-20";s:7:"Uogonek";s:3:"-20";s:5:"Uring";s:3:"-20";s:1:"V";s:3:"-50";s:1:"W";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:1:"T";a:68:{s:1:"A";s:3:"-90";s:6:"Aacute";s:3:"-90";s:6:"Abreve";s:3:"-90";s:11:"Acircumflex";s:3:"-90";s:9:"Adieresis";s:3:"-90";s:6:"Agrave";s:3:"-90";s:7:"Amacron";s:3:"-90";s:7:"Aogonek";s:3:"-90";s:5:"Aring";s:3:"-90";s:6:"Atilde";s:3:"-90";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"a";s:3:"-80";s:6:"aacute";s:3:"-80";s:6:"abreve";s:3:"-80";s:11:"acircumflex";s:3:"-80";s:9:"adieresis";s:3:"-80";s:6:"agrave";s:3:"-80";s:7:"amacron";s:3:"-80";s:7:"aogonek";s:3:"-80";s:5:"aring";s:3:"-80";s:6:"atilde";s:3:"-80";s:5:"colon";s:3:"-40";s:5:"comma";s:3:"-80";s:1:"e";s:3:"-60";s:6:"eacute";s:3:"-60";s:6:"ecaron";s:3:"-60";s:11:"ecircumflex";s:3:"-60";s:9:"edieresis";s:3:"-60";s:10:"edotaccent";s:3:"-60";s:6:"egrave";s:3:"-60";s:7:"emacron";s:3:"-60";s:7:"eogonek";s:3:"-60";s:6:"hyphen";s:4:"-120";s:1:"o";s:3:"-80";s:6:"oacute";s:3:"-80";s:11:"ocircumflex";s:3:"-80";s:9:"odieresis";s:3:"-80";s:6:"ograve";s:3:"-80";s:13:"ohungarumlaut";s:3:"-80";s:7:"omacron";s:3:"-80";s:6:"oslash";s:3:"-80";s:6:"otilde";s:3:"-80";s:6:"period";s:3:"-80";s:1:"r";s:3:"-80";s:6:"racute";s:3:"-80";s:12:"rcommaaccent";s:3:"-80";s:9:"semicolon";s:3:"-40";s:1:"u";s:3:"-90";s:6:"uacute";s:3:"-90";s:11:"ucircumflex";s:3:"-90";s:9:"udieresis";s:3:"-90";s:6:"ugrave";s:3:"-90";s:13:"uhungarumlaut";s:3:"-90";s:7:"umacron";s:3:"-90";s:7:"uogonek";s:3:"-90";s:5:"uring";s:3:"-90";s:1:"w";s:3:"-60";s:1:"y";s:3:"-60";s:6:"yacute";s:3:"-60";s:9:"ydieresis";s:3:"-60";}s:6:"Tcaron";a:68:{s:1:"A";s:3:"-90";s:6:"Aacute";s:3:"-90";s:6:"Abreve";s:3:"-90";s:11:"Acircumflex";s:3:"-90";s:9:"Adieresis";s:3:"-90";s:6:"Agrave";s:3:"-90";s:7:"Amacron";s:3:"-90";s:7:"Aogonek";s:3:"-90";s:5:"Aring";s:3:"-90";s:6:"Atilde";s:3:"-90";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"a";s:3:"-80";s:6:"aacute";s:3:"-80";s:6:"abreve";s:3:"-80";s:11:"acircumflex";s:3:"-80";s:9:"adieresis";s:3:"-80";s:6:"agrave";s:3:"-80";s:7:"amacron";s:3:"-80";s:7:"aogonek";s:3:"-80";s:5:"aring";s:3:"-80";s:6:"atilde";s:3:"-80";s:5:"colon";s:3:"-40";s:5:"comma";s:3:"-80";s:1:"e";s:3:"-60";s:6:"eacute";s:3:"-60";s:6:"ecaron";s:3:"-60";s:11:"ecircumflex";s:3:"-60";s:9:"edieresis";s:3:"-60";s:10:"edotaccent";s:3:"-60";s:6:"egrave";s:3:"-60";s:7:"emacron";s:3:"-60";s:7:"eogonek";s:3:"-60";s:6:"hyphen";s:4:"-120";s:1:"o";s:3:"-80";s:6:"oacute";s:3:"-80";s:11:"ocircumflex";s:3:"-80";s:9:"odieresis";s:3:"-80";s:6:"ograve";s:3:"-80";s:13:"ohungarumlaut";s:3:"-80";s:7:"omacron";s:3:"-80";s:6:"oslash";s:3:"-80";s:6:"otilde";s:3:"-80";s:6:"period";s:3:"-80";s:1:"r";s:3:"-80";s:6:"racute";s:3:"-80";s:12:"rcommaaccent";s:3:"-80";s:9:"semicolon";s:3:"-40";s:1:"u";s:3:"-90";s:6:"uacute";s:3:"-90";s:11:"ucircumflex";s:3:"-90";s:9:"udieresis";s:3:"-90";s:6:"ugrave";s:3:"-90";s:13:"uhungarumlaut";s:3:"-90";s:7:"umacron";s:3:"-90";s:7:"uogonek";s:3:"-90";s:5:"uring";s:3:"-90";s:1:"w";s:3:"-60";s:1:"y";s:3:"-60";s:6:"yacute";s:3:"-60";s:9:"ydieresis";s:3:"-60";}s:12:"Tcommaaccent";a:68:{s:1:"A";s:3:"-90";s:6:"Aacute";s:3:"-90";s:6:"Abreve";s:3:"-90";s:11:"Acircumflex";s:3:"-90";s:9:"Adieresis";s:3:"-90";s:6:"Agrave";s:3:"-90";s:7:"Amacron";s:3:"-90";s:7:"Aogonek";s:3:"-90";s:5:"Aring";s:3:"-90";s:6:"Atilde";s:3:"-90";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"a";s:3:"-80";s:6:"aacute";s:3:"-80";s:6:"abreve";s:3:"-80";s:11:"acircumflex";s:3:"-80";s:9:"adieresis";s:3:"-80";s:6:"agrave";s:3:"-80";s:7:"amacron";s:3:"-80";s:7:"aogonek";s:3:"-80";s:5:"aring";s:3:"-80";s:6:"atilde";s:3:"-80";s:5:"colon";s:3:"-40";s:5:"comma";s:3:"-80";s:1:"e";s:3:"-60";s:6:"eacute";s:3:"-60";s:6:"ecaron";s:3:"-60";s:11:"ecircumflex";s:3:"-60";s:9:"edieresis";s:3:"-60";s:10:"edotaccent";s:3:"-60";s:6:"egrave";s:3:"-60";s:7:"emacron";s:3:"-60";s:7:"eogonek";s:3:"-60";s:6:"hyphen";s:4:"-120";s:1:"o";s:3:"-80";s:6:"oacute";s:3:"-80";s:11:"ocircumflex";s:3:"-80";s:9:"odieresis";s:3:"-80";s:6:"ograve";s:3:"-80";s:13:"ohungarumlaut";s:3:"-80";s:7:"omacron";s:3:"-80";s:6:"oslash";s:3:"-80";s:6:"otilde";s:3:"-80";s:6:"period";s:3:"-80";s:1:"r";s:3:"-80";s:6:"racute";s:3:"-80";s:12:"rcommaaccent";s:3:"-80";s:9:"semicolon";s:3:"-40";s:1:"u";s:3:"-90";s:6:"uacute";s:3:"-90";s:11:"ucircumflex";s:3:"-90";s:9:"udieresis";s:3:"-90";s:6:"ugrave";s:3:"-90";s:13:"uhungarumlaut";s:3:"-90";s:7:"umacron";s:3:"-90";s:7:"uogonek";s:3:"-90";s:5:"uring";s:3:"-90";s:1:"w";s:3:"-60";s:1:"y";s:3:"-60";s:6:"yacute";s:3:"-60";s:9:"ydieresis";s:3:"-60";}s:1:"U";a:12:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:5:"comma";s:3:"-30";s:6:"period";s:3:"-30";}s:6:"Uacute";a:12:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:5:"comma";s:3:"-30";s:6:"period";s:3:"-30";}s:11:"Ucircumflex";a:12:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:5:"comma";s:3:"-30";s:6:"period";s:3:"-30";}s:9:"Udieresis";a:12:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:5:"comma";s:3:"-30";s:6:"period";s:3:"-30";}s:6:"Ugrave";a:12:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:5:"comma";s:3:"-30";s:6:"period";s:3:"-30";}s:13:"Uhungarumlaut";a:12:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:5:"comma";s:3:"-30";s:6:"period";s:3:"-30";}s:7:"Umacron";a:12:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:5:"comma";s:3:"-30";s:6:"period";s:3:"-30";}s:7:"Uogonek";a:12:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:5:"comma";s:3:"-30";s:6:"period";s:3:"-30";}s:5:"Uring";a:12:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:5:"comma";s:3:"-30";s:6:"period";s:3:"-30";}s:1:"V";a:64:{s:1:"A";s:3:"-80";s:6:"Aacute";s:3:"-80";s:6:"Abreve";s:3:"-80";s:11:"Acircumflex";s:3:"-80";s:9:"Adieresis";s:3:"-80";s:6:"Agrave";s:3:"-80";s:7:"Amacron";s:3:"-80";s:7:"Aogonek";s:3:"-80";s:5:"Aring";s:3:"-80";s:6:"Atilde";s:3:"-80";s:1:"G";s:3:"-50";s:6:"Gbreve";s:3:"-50";s:12:"Gcommaaccent";s:3:"-50";s:1:"O";s:3:"-50";s:6:"Oacute";s:3:"-50";s:11:"Ocircumflex";s:3:"-50";s:9:"Odieresis";s:3:"-50";s:6:"Ograve";s:3:"-50";s:13:"Ohungarumlaut";s:3:"-50";s:7:"Omacron";s:3:"-50";s:6:"Oslash";s:3:"-50";s:6:"Otilde";s:3:"-50";s:1:"a";s:3:"-60";s:6:"aacute";s:3:"-60";s:6:"abreve";s:3:"-60";s:11:"acircumflex";s:3:"-60";s:9:"adieresis";s:3:"-60";s:6:"agrave";s:3:"-60";s:7:"amacron";s:3:"-60";s:7:"aogonek";s:3:"-60";s:5:"aring";s:3:"-60";s:6:"atilde";s:3:"-60";s:5:"colon";s:3:"-40";s:5:"comma";s:4:"-120";s:1:"e";s:3:"-50";s:6:"eacute";s:3:"-50";s:6:"ecaron";s:3:"-50";s:11:"ecircumflex";s:3:"-50";s:9:"edieresis";s:3:"-50";s:10:"edotaccent";s:3:"-50";s:6:"egrave";s:3:"-50";s:7:"emacron";s:3:"-50";s:7:"eogonek";s:3:"-50";s:6:"hyphen";s:3:"-80";s:1:"o";s:3:"-90";s:6:"oacute";s:3:"-90";s:11:"ocircumflex";s:3:"-90";s:9:"odieresis";s:3:"-90";s:6:"ograve";s:3:"-90";s:13:"ohungarumlaut";s:3:"-90";s:7:"omacron";s:3:"-90";s:6:"oslash";s:3:"-90";s:6:"otilde";s:3:"-90";s:6:"period";s:4:"-120";s:9:"semicolon";s:3:"-40";s:1:"u";s:3:"-60";s:6:"uacute";s:3:"-60";s:11:"ucircumflex";s:3:"-60";s:9:"udieresis";s:3:"-60";s:6:"ugrave";s:3:"-60";s:13:"uhungarumlaut";s:3:"-60";s:7:"umacron";s:3:"-60";s:7:"uogonek";s:3:"-60";s:5:"uring";s:3:"-60";}s:1:"W";a:64:{s:1:"A";s:3:"-60";s:6:"Aacute";s:3:"-60";s:6:"Abreve";s:3:"-60";s:11:"Acircumflex";s:3:"-60";s:9:"Adieresis";s:3:"-60";s:6:"Agrave";s:3:"-60";s:7:"Amacron";s:3:"-60";s:7:"Aogonek";s:3:"-60";s:5:"Aring";s:3:"-60";s:6:"Atilde";s:3:"-60";s:1:"O";s:3:"-20";s:6:"Oacute";s:3:"-20";s:11:"Ocircumflex";s:3:"-20";s:9:"Odieresis";s:3:"-20";s:6:"Ograve";s:3:"-20";s:13:"Ohungarumlaut";s:3:"-20";s:7:"Omacron";s:3:"-20";s:6:"Oslash";s:3:"-20";s:6:"Otilde";s:3:"-20";s:1:"a";s:3:"-40";s:6:"aacute";s:3:"-40";s:6:"abreve";s:3:"-40";s:11:"acircumflex";s:3:"-40";s:9:"adieresis";s:3:"-40";s:6:"agrave";s:3:"-40";s:7:"amacron";s:3:"-40";s:7:"aogonek";s:3:"-40";s:5:"aring";s:3:"-40";s:6:"atilde";s:3:"-40";s:5:"colon";s:3:"-10";s:5:"comma";s:3:"-80";s:1:"e";s:3:"-35";s:6:"eacute";s:3:"-35";s:6:"ecaron";s:3:"-35";s:11:"ecircumflex";s:3:"-35";s:9:"edieresis";s:3:"-35";s:10:"edotaccent";s:3:"-35";s:6:"egrave";s:3:"-35";s:7:"emacron";s:3:"-35";s:7:"eogonek";s:3:"-35";s:6:"hyphen";s:3:"-40";s:1:"o";s:3:"-60";s:6:"oacute";s:3:"-60";s:11:"ocircumflex";s:3:"-60";s:9:"odieresis";s:3:"-60";s:6:"ograve";s:3:"-60";s:13:"ohungarumlaut";s:3:"-60";s:7:"omacron";s:3:"-60";s:6:"oslash";s:3:"-60";s:6:"otilde";s:3:"-60";s:6:"period";s:3:"-80";s:9:"semicolon";s:3:"-10";s:1:"u";s:3:"-45";s:6:"uacute";s:3:"-45";s:11:"ucircumflex";s:3:"-45";s:9:"udieresis";s:3:"-45";s:6:"ugrave";s:3:"-45";s:13:"uhungarumlaut";s:3:"-45";s:7:"umacron";s:3:"-45";s:7:"uogonek";s:3:"-45";s:5:"uring";s:3:"-45";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:1:"Y";a:60:{s:1:"A";s:4:"-110";s:6:"Aacute";s:4:"-110";s:6:"Abreve";s:4:"-110";s:11:"Acircumflex";s:4:"-110";s:9:"Adieresis";s:4:"-110";s:6:"Agrave";s:4:"-110";s:7:"Amacron";s:4:"-110";s:7:"Aogonek";s:4:"-110";s:5:"Aring";s:4:"-110";s:6:"Atilde";s:4:"-110";s:1:"O";s:3:"-70";s:6:"Oacute";s:3:"-70";s:11:"Ocircumflex";s:3:"-70";s:9:"Odieresis";s:3:"-70";s:6:"Ograve";s:3:"-70";s:13:"Ohungarumlaut";s:3:"-70";s:7:"Omacron";s:3:"-70";s:6:"Oslash";s:3:"-70";s:6:"Otilde";s:3:"-70";s:1:"a";s:3:"-90";s:6:"aacute";s:3:"-90";s:6:"abreve";s:3:"-90";s:11:"acircumflex";s:3:"-90";s:9:"adieresis";s:3:"-90";s:6:"agrave";s:3:"-90";s:7:"amacron";s:3:"-90";s:7:"aogonek";s:3:"-90";s:5:"aring";s:3:"-90";s:6:"atilde";s:3:"-90";s:5:"colon";s:3:"-50";s:5:"comma";s:4:"-100";s:1:"e";s:3:"-80";s:6:"eacute";s:3:"-80";s:6:"ecaron";s:3:"-80";s:11:"ecircumflex";s:3:"-80";s:9:"edieresis";s:3:"-80";s:10:"edotaccent";s:3:"-80";s:6:"egrave";s:3:"-80";s:7:"emacron";s:3:"-80";s:7:"eogonek";s:3:"-80";s:1:"o";s:4:"-100";s:6:"oacute";s:4:"-100";s:11:"ocircumflex";s:4:"-100";s:9:"odieresis";s:4:"-100";s:6:"ograve";s:4:"-100";s:13:"ohungarumlaut";s:4:"-100";s:7:"omacron";s:4:"-100";s:6:"oslash";s:4:"-100";s:6:"otilde";s:4:"-100";s:6:"period";s:4:"-100";s:9:"semicolon";s:3:"-50";s:1:"u";s:4:"-100";s:6:"uacute";s:4:"-100";s:11:"ucircumflex";s:4:"-100";s:9:"udieresis";s:4:"-100";s:6:"ugrave";s:4:"-100";s:13:"uhungarumlaut";s:4:"-100";s:7:"umacron";s:4:"-100";s:7:"uogonek";s:4:"-100";s:5:"uring";s:4:"-100";}s:6:"Yacute";a:60:{s:1:"A";s:4:"-110";s:6:"Aacute";s:4:"-110";s:6:"Abreve";s:4:"-110";s:11:"Acircumflex";s:4:"-110";s:9:"Adieresis";s:4:"-110";s:6:"Agrave";s:4:"-110";s:7:"Amacron";s:4:"-110";s:7:"Aogonek";s:4:"-110";s:5:"Aring";s:4:"-110";s:6:"Atilde";s:4:"-110";s:1:"O";s:3:"-70";s:6:"Oacute";s:3:"-70";s:11:"Ocircumflex";s:3:"-70";s:9:"Odieresis";s:3:"-70";s:6:"Ograve";s:3:"-70";s:13:"Ohungarumlaut";s:3:"-70";s:7:"Omacron";s:3:"-70";s:6:"Oslash";s:3:"-70";s:6:"Otilde";s:3:"-70";s:1:"a";s:3:"-90";s:6:"aacute";s:3:"-90";s:6:"abreve";s:3:"-90";s:11:"acircumflex";s:3:"-90";s:9:"adieresis";s:3:"-90";s:6:"agrave";s:3:"-90";s:7:"amacron";s:3:"-90";s:7:"aogonek";s:3:"-90";s:5:"aring";s:3:"-90";s:6:"atilde";s:3:"-90";s:5:"colon";s:3:"-50";s:5:"comma";s:4:"-100";s:1:"e";s:3:"-80";s:6:"eacute";s:3:"-80";s:6:"ecaron";s:3:"-80";s:11:"ecircumflex";s:3:"-80";s:9:"edieresis";s:3:"-80";s:10:"edotaccent";s:3:"-80";s:6:"egrave";s:3:"-80";s:7:"emacron";s:3:"-80";s:7:"eogonek";s:3:"-80";s:1:"o";s:4:"-100";s:6:"oacute";s:4:"-100";s:11:"ocircumflex";s:4:"-100";s:9:"odieresis";s:4:"-100";s:6:"ograve";s:4:"-100";s:13:"ohungarumlaut";s:4:"-100";s:7:"omacron";s:4:"-100";s:6:"oslash";s:4:"-100";s:6:"otilde";s:4:"-100";s:6:"period";s:4:"-100";s:9:"semicolon";s:3:"-50";s:1:"u";s:4:"-100";s:6:"uacute";s:4:"-100";s:11:"ucircumflex";s:4:"-100";s:9:"udieresis";s:4:"-100";s:6:"ugrave";s:4:"-100";s:13:"uhungarumlaut";s:4:"-100";s:7:"umacron";s:4:"-100";s:7:"uogonek";s:4:"-100";s:5:"uring";s:4:"-100";}s:9:"Ydieresis";a:60:{s:1:"A";s:4:"-110";s:6:"Aacute";s:4:"-110";s:6:"Abreve";s:4:"-110";s:11:"Acircumflex";s:4:"-110";s:9:"Adieresis";s:4:"-110";s:6:"Agrave";s:4:"-110";s:7:"Amacron";s:4:"-110";s:7:"Aogonek";s:4:"-110";s:5:"Aring";s:4:"-110";s:6:"Atilde";s:4:"-110";s:1:"O";s:3:"-70";s:6:"Oacute";s:3:"-70";s:11:"Ocircumflex";s:3:"-70";s:9:"Odieresis";s:3:"-70";s:6:"Ograve";s:3:"-70";s:13:"Ohungarumlaut";s:3:"-70";s:7:"Omacron";s:3:"-70";s:6:"Oslash";s:3:"-70";s:6:"Otilde";s:3:"-70";s:1:"a";s:3:"-90";s:6:"aacute";s:3:"-90";s:6:"abreve";s:3:"-90";s:11:"acircumflex";s:3:"-90";s:9:"adieresis";s:3:"-90";s:6:"agrave";s:3:"-90";s:7:"amacron";s:3:"-90";s:7:"aogonek";s:3:"-90";s:5:"aring";s:3:"-90";s:6:"atilde";s:3:"-90";s:5:"colon";s:3:"-50";s:5:"comma";s:4:"-100";s:1:"e";s:3:"-80";s:6:"eacute";s:3:"-80";s:6:"ecaron";s:3:"-80";s:11:"ecircumflex";s:3:"-80";s:9:"edieresis";s:3:"-80";s:10:"edotaccent";s:3:"-80";s:6:"egrave";s:3:"-80";s:7:"emacron";s:3:"-80";s:7:"eogonek";s:3:"-80";s:1:"o";s:4:"-100";s:6:"oacute";s:4:"-100";s:11:"ocircumflex";s:4:"-100";s:9:"odieresis";s:4:"-100";s:6:"ograve";s:4:"-100";s:13:"ohungarumlaut";s:4:"-100";s:7:"omacron";s:4:"-100";s:6:"oslash";s:4:"-100";s:6:"otilde";s:4:"-100";s:6:"period";s:4:"-100";s:9:"semicolon";s:3:"-50";s:1:"u";s:4:"-100";s:6:"uacute";s:4:"-100";s:11:"ucircumflex";s:4:"-100";s:9:"udieresis";s:4:"-100";s:6:"ugrave";s:4:"-100";s:13:"uhungarumlaut";s:4:"-100";s:7:"umacron";s:4:"-100";s:7:"uogonek";s:4:"-100";s:5:"uring";s:4:"-100";}s:1:"a";a:8:{s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:6:"aacute";a:8:{s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:6:"abreve";a:8:{s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:11:"acircumflex";a:8:{s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:9:"adieresis";a:8:{s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:6:"agrave";a:8:{s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:7:"amacron";a:8:{s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:7:"aogonek";a:8:{s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:5:"aring";a:8:{s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:6:"atilde";a:8:{s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:1:"b";a:17:{s:1:"l";s:3:"-10";s:6:"lacute";s:3:"-10";s:12:"lcommaaccent";s:3:"-10";s:6:"lslash";s:3:"-10";s:1:"u";s:3:"-20";s:6:"uacute";s:3:"-20";s:11:"ucircumflex";s:3:"-20";s:9:"udieresis";s:3:"-20";s:6:"ugrave";s:3:"-20";s:13:"uhungarumlaut";s:3:"-20";s:7:"umacron";s:3:"-20";s:7:"uogonek";s:3:"-20";s:5:"uring";s:3:"-20";s:1:"v";s:3:"-20";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:1:"c";a:10:{s:1:"h";s:3:"-10";s:1:"k";s:3:"-20";s:12:"kcommaaccent";s:3:"-20";s:1:"l";s:3:"-20";s:6:"lacute";s:3:"-20";s:12:"lcommaaccent";s:3:"-20";s:6:"lslash";s:3:"-20";s:1:"y";s:3:"-10";s:6:"yacute";s:3:"-10";s:9:"ydieresis";s:3:"-10";}s:6:"cacute";a:10:{s:1:"h";s:3:"-10";s:1:"k";s:3:"-20";s:12:"kcommaaccent";s:3:"-20";s:1:"l";s:3:"-20";s:6:"lacute";s:3:"-20";s:12:"lcommaaccent";s:3:"-20";s:6:"lslash";s:3:"-20";s:1:"y";s:3:"-10";s:6:"yacute";s:3:"-10";s:9:"ydieresis";s:3:"-10";}s:6:"ccaron";a:10:{s:1:"h";s:3:"-10";s:1:"k";s:3:"-20";s:12:"kcommaaccent";s:3:"-20";s:1:"l";s:3:"-20";s:6:"lacute";s:3:"-20";s:12:"lcommaaccent";s:3:"-20";s:6:"lslash";s:3:"-20";s:1:"y";s:3:"-10";s:6:"yacute";s:3:"-10";s:9:"ydieresis";s:3:"-10";}s:8:"ccedilla";a:10:{s:1:"h";s:3:"-10";s:1:"k";s:3:"-20";s:12:"kcommaaccent";s:3:"-20";s:1:"l";s:3:"-20";s:6:"lacute";s:3:"-20";s:12:"lcommaaccent";s:3:"-20";s:6:"lslash";s:3:"-20";s:1:"y";s:3:"-10";s:6:"yacute";s:3:"-10";s:9:"ydieresis";s:3:"-10";}s:5:"colon";a:1:{s:5:"space";s:3:"-40";}s:5:"comma";a:3:{s:13:"quotedblright";s:4:"-120";s:10:"quoteright";s:4:"-120";s:5:"space";s:3:"-40";}s:1:"d";a:7:{s:1:"d";s:3:"-10";s:6:"dcroat";s:3:"-10";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:6:"dcroat";a:7:{s:1:"d";s:3:"-10";s:6:"dcroat";s:3:"-10";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:1:"e";a:8:{s:5:"comma";s:2:"10";s:6:"period";s:2:"20";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-15";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:6:"eacute";a:8:{s:5:"comma";s:2:"10";s:6:"period";s:2:"20";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-15";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:6:"ecaron";a:8:{s:5:"comma";s:2:"10";s:6:"period";s:2:"20";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-15";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:11:"ecircumflex";a:8:{s:5:"comma";s:2:"10";s:6:"period";s:2:"20";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-15";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:9:"edieresis";a:8:{s:5:"comma";s:2:"10";s:6:"period";s:2:"20";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-15";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:10:"edotaccent";a:8:{s:5:"comma";s:2:"10";s:6:"period";s:2:"20";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-15";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:6:"egrave";a:8:{s:5:"comma";s:2:"10";s:6:"period";s:2:"20";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-15";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:7:"emacron";a:8:{s:5:"comma";s:2:"10";s:6:"period";s:2:"20";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-15";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:7:"eogonek";a:8:{s:5:"comma";s:2:"10";s:6:"period";s:2:"20";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-15";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:1:"f";a:22:{s:5:"comma";s:3:"-10";s:1:"e";s:3:"-10";s:6:"eacute";s:3:"-10";s:6:"ecaron";s:3:"-10";s:11:"ecircumflex";s:3:"-10";s:9:"edieresis";s:3:"-10";s:10:"edotaccent";s:3:"-10";s:6:"egrave";s:3:"-10";s:7:"emacron";s:3:"-10";s:7:"eogonek";s:3:"-10";s:1:"o";s:3:"-20";s:6:"oacute";s:3:"-20";s:11:"ocircumflex";s:3:"-20";s:9:"odieresis";s:3:"-20";s:6:"ograve";s:3:"-20";s:13:"ohungarumlaut";s:3:"-20";s:7:"omacron";s:3:"-20";s:6:"oslash";s:3:"-20";s:6:"otilde";s:3:"-20";s:6:"period";s:3:"-10";s:13:"quotedblright";s:2:"30";s:10:"quoteright";s:2:"30";}s:1:"g";a:12:{s:1:"e";s:2:"10";s:6:"eacute";s:2:"10";s:6:"ecaron";s:2:"10";s:11:"ecircumflex";s:2:"10";s:9:"edieresis";s:2:"10";s:10:"edotaccent";s:2:"10";s:6:"egrave";s:2:"10";s:7:"emacron";s:2:"10";s:7:"eogonek";s:2:"10";s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";}s:6:"gbreve";a:12:{s:1:"e";s:2:"10";s:6:"eacute";s:2:"10";s:6:"ecaron";s:2:"10";s:11:"ecircumflex";s:2:"10";s:9:"edieresis";s:2:"10";s:10:"edotaccent";s:2:"10";s:6:"egrave";s:2:"10";s:7:"emacron";s:2:"10";s:7:"eogonek";s:2:"10";s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";}s:12:"gcommaaccent";a:12:{s:1:"e";s:2:"10";s:6:"eacute";s:2:"10";s:6:"ecaron";s:2:"10";s:11:"ecircumflex";s:2:"10";s:9:"edieresis";s:2:"10";s:10:"edotaccent";s:2:"10";s:6:"egrave";s:2:"10";s:7:"emacron";s:2:"10";s:7:"eogonek";s:2:"10";s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";}s:1:"h";a:3:{s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:1:"k";a:9:{s:1:"o";s:3:"-15";s:6:"oacute";s:3:"-15";s:11:"ocircumflex";s:3:"-15";s:9:"odieresis";s:3:"-15";s:6:"ograve";s:3:"-15";s:13:"ohungarumlaut";s:3:"-15";s:7:"omacron";s:3:"-15";s:6:"oslash";s:3:"-15";s:6:"otilde";s:3:"-15";}s:12:"kcommaaccent";a:9:{s:1:"o";s:3:"-15";s:6:"oacute";s:3:"-15";s:11:"ocircumflex";s:3:"-15";s:9:"odieresis";s:3:"-15";s:6:"ograve";s:3:"-15";s:13:"ohungarumlaut";s:3:"-15";s:7:"omacron";s:3:"-15";s:6:"oslash";s:3:"-15";s:6:"otilde";s:3:"-15";}s:1:"l";a:4:{s:1:"w";s:3:"-15";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:6:"lacute";a:4:{s:1:"w";s:3:"-15";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:12:"lcommaaccent";a:4:{s:1:"w";s:3:"-15";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:6:"lslash";a:4:{s:1:"w";s:3:"-15";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:1:"m";a:12:{s:1:"u";s:3:"-20";s:6:"uacute";s:3:"-20";s:11:"ucircumflex";s:3:"-20";s:9:"udieresis";s:3:"-20";s:6:"ugrave";s:3:"-20";s:13:"uhungarumlaut";s:3:"-20";s:7:"umacron";s:3:"-20";s:7:"uogonek";s:3:"-20";s:5:"uring";s:3:"-20";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:1:"n";a:13:{s:1:"u";s:3:"-10";s:6:"uacute";s:3:"-10";s:11:"ucircumflex";s:3:"-10";s:9:"udieresis";s:3:"-10";s:6:"ugrave";s:3:"-10";s:13:"uhungarumlaut";s:3:"-10";s:7:"umacron";s:3:"-10";s:7:"uogonek";s:3:"-10";s:5:"uring";s:3:"-10";s:1:"v";s:3:"-40";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:6:"nacute";a:13:{s:1:"u";s:3:"-10";s:6:"uacute";s:3:"-10";s:11:"ucircumflex";s:3:"-10";s:9:"udieresis";s:3:"-10";s:6:"ugrave";s:3:"-10";s:13:"uhungarumlaut";s:3:"-10";s:7:"umacron";s:3:"-10";s:7:"uogonek";s:3:"-10";s:5:"uring";s:3:"-10";s:1:"v";s:3:"-40";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:6:"ncaron";a:13:{s:1:"u";s:3:"-10";s:6:"uacute";s:3:"-10";s:11:"ucircumflex";s:3:"-10";s:9:"udieresis";s:3:"-10";s:6:"ugrave";s:3:"-10";s:13:"uhungarumlaut";s:3:"-10";s:7:"umacron";s:3:"-10";s:7:"uogonek";s:3:"-10";s:5:"uring";s:3:"-10";s:1:"v";s:3:"-40";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:12:"ncommaaccent";a:13:{s:1:"u";s:3:"-10";s:6:"uacute";s:3:"-10";s:11:"ucircumflex";s:3:"-10";s:9:"udieresis";s:3:"-10";s:6:"ugrave";s:3:"-10";s:13:"uhungarumlaut";s:3:"-10";s:7:"umacron";s:3:"-10";s:7:"uogonek";s:3:"-10";s:5:"uring";s:3:"-10";s:1:"v";s:3:"-40";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:6:"ntilde";a:13:{s:1:"u";s:3:"-10";s:6:"uacute";s:3:"-10";s:11:"ucircumflex";s:3:"-10";s:9:"udieresis";s:3:"-10";s:6:"ugrave";s:3:"-10";s:13:"uhungarumlaut";s:3:"-10";s:7:"umacron";s:3:"-10";s:7:"uogonek";s:3:"-10";s:5:"uring";s:3:"-10";s:1:"v";s:3:"-40";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:1:"o";a:6:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-15";s:1:"x";s:3:"-30";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:6:"oacute";a:6:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-15";s:1:"x";s:3:"-30";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:11:"ocircumflex";a:6:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-15";s:1:"x";s:3:"-30";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:9:"odieresis";a:6:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-15";s:1:"x";s:3:"-30";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:6:"ograve";a:6:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-15";s:1:"x";s:3:"-30";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:13:"ohungarumlaut";a:6:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-15";s:1:"x";s:3:"-30";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:7:"omacron";a:6:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-15";s:1:"x";s:3:"-30";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:6:"oslash";a:6:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-15";s:1:"x";s:3:"-30";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:6:"otilde";a:6:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-15";s:1:"x";s:3:"-30";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:1:"p";a:3:{s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:6:"period";a:3:{s:13:"quotedblright";s:4:"-120";s:10:"quoteright";s:4:"-120";s:5:"space";s:3:"-40";}s:13:"quotedblright";a:1:{s:5:"space";s:3:"-80";}s:9:"quoteleft";a:1:{s:9:"quoteleft";s:3:"-46";}s:10:"quoteright";a:18:{s:1:"d";s:3:"-80";s:6:"dcroat";s:3:"-80";s:1:"l";s:3:"-20";s:6:"lacute";s:3:"-20";s:12:"lcommaaccent";s:3:"-20";s:6:"lslash";s:3:"-20";s:10:"quoteright";s:3:"-46";s:1:"r";s:3:"-40";s:6:"racute";s:3:"-40";s:6:"rcaron";s:3:"-40";s:12:"rcommaaccent";s:3:"-40";s:1:"s";s:3:"-60";s:6:"sacute";s:3:"-60";s:6:"scaron";s:3:"-60";s:8:"scedilla";s:3:"-60";s:12:"scommaaccent";s:3:"-60";s:5:"space";s:3:"-80";s:1:"v";s:3:"-20";}s:1:"r";a:33:{s:1:"c";s:3:"-20";s:6:"cacute";s:3:"-20";s:6:"ccaron";s:3:"-20";s:8:"ccedilla";s:3:"-20";s:5:"comma";s:3:"-60";s:1:"d";s:3:"-20";s:6:"dcroat";s:3:"-20";s:1:"g";s:3:"-15";s:6:"gbreve";s:3:"-15";s:12:"gcommaaccent";s:3:"-15";s:6:"hyphen";s:3:"-20";s:1:"o";s:3:"-20";s:6:"oacute";s:3:"-20";s:11:"ocircumflex";s:3:"-20";s:9:"odieresis";s:3:"-20";s:6:"ograve";s:3:"-20";s:13:"ohungarumlaut";s:3:"-20";s:7:"omacron";s:3:"-20";s:6:"oslash";s:3:"-20";s:6:"otilde";s:3:"-20";s:6:"period";s:3:"-60";s:1:"q";s:3:"-20";s:1:"s";s:3:"-15";s:6:"sacute";s:3:"-15";s:6:"scaron";s:3:"-15";s:8:"scedilla";s:3:"-15";s:12:"scommaaccent";s:3:"-15";s:1:"t";s:2:"20";s:12:"tcommaaccent";s:2:"20";s:1:"v";s:2:"10";s:1:"y";s:2:"10";s:6:"yacute";s:2:"10";s:9:"ydieresis";s:2:"10";}s:6:"racute";a:33:{s:1:"c";s:3:"-20";s:6:"cacute";s:3:"-20";s:6:"ccaron";s:3:"-20";s:8:"ccedilla";s:3:"-20";s:5:"comma";s:3:"-60";s:1:"d";s:3:"-20";s:6:"dcroat";s:3:"-20";s:1:"g";s:3:"-15";s:6:"gbreve";s:3:"-15";s:12:"gcommaaccent";s:3:"-15";s:6:"hyphen";s:3:"-20";s:1:"o";s:3:"-20";s:6:"oacute";s:3:"-20";s:11:"ocircumflex";s:3:"-20";s:9:"odieresis";s:3:"-20";s:6:"ograve";s:3:"-20";s:13:"ohungarumlaut";s:3:"-20";s:7:"omacron";s:3:"-20";s:6:"oslash";s:3:"-20";s:6:"otilde";s:3:"-20";s:6:"period";s:3:"-60";s:1:"q";s:3:"-20";s:1:"s";s:3:"-15";s:6:"sacute";s:3:"-15";s:6:"scaron";s:3:"-15";s:8:"scedilla";s:3:"-15";s:12:"scommaaccent";s:3:"-15";s:1:"t";s:2:"20";s:12:"tcommaaccent";s:2:"20";s:1:"v";s:2:"10";s:1:"y";s:2:"10";s:6:"yacute";s:2:"10";s:9:"ydieresis";s:2:"10";}s:6:"rcaron";a:33:{s:1:"c";s:3:"-20";s:6:"cacute";s:3:"-20";s:6:"ccaron";s:3:"-20";s:8:"ccedilla";s:3:"-20";s:5:"comma";s:3:"-60";s:1:"d";s:3:"-20";s:6:"dcroat";s:3:"-20";s:1:"g";s:3:"-15";s:6:"gbreve";s:3:"-15";s:12:"gcommaaccent";s:3:"-15";s:6:"hyphen";s:3:"-20";s:1:"o";s:3:"-20";s:6:"oacute";s:3:"-20";s:11:"ocircumflex";s:3:"-20";s:9:"odieresis";s:3:"-20";s:6:"ograve";s:3:"-20";s:13:"ohungarumlaut";s:3:"-20";s:7:"omacron";s:3:"-20";s:6:"oslash";s:3:"-20";s:6:"otilde";s:3:"-20";s:6:"period";s:3:"-60";s:1:"q";s:3:"-20";s:1:"s";s:3:"-15";s:6:"sacute";s:3:"-15";s:6:"scaron";s:3:"-15";s:8:"scedilla";s:3:"-15";s:12:"scommaaccent";s:3:"-15";s:1:"t";s:2:"20";s:12:"tcommaaccent";s:2:"20";s:1:"v";s:2:"10";s:1:"y";s:2:"10";s:6:"yacute";s:2:"10";s:9:"ydieresis";s:2:"10";}s:12:"rcommaaccent";a:33:{s:1:"c";s:3:"-20";s:6:"cacute";s:3:"-20";s:6:"ccaron";s:3:"-20";s:8:"ccedilla";s:3:"-20";s:5:"comma";s:3:"-60";s:1:"d";s:3:"-20";s:6:"dcroat";s:3:"-20";s:1:"g";s:3:"-15";s:6:"gbreve";s:3:"-15";s:12:"gcommaaccent";s:3:"-15";s:6:"hyphen";s:3:"-20";s:1:"o";s:3:"-20";s:6:"oacute";s:3:"-20";s:11:"ocircumflex";s:3:"-20";s:9:"odieresis";s:3:"-20";s:6:"ograve";s:3:"-20";s:13:"ohungarumlaut";s:3:"-20";s:7:"omacron";s:3:"-20";s:6:"oslash";s:3:"-20";s:6:"otilde";s:3:"-20";s:6:"period";s:3:"-60";s:1:"q";s:3:"-20";s:1:"s";s:3:"-15";s:6:"sacute";s:3:"-15";s:6:"scaron";s:3:"-15";s:8:"scedilla";s:3:"-15";s:12:"scommaaccent";s:3:"-15";s:1:"t";s:2:"20";s:12:"tcommaaccent";s:2:"20";s:1:"v";s:2:"10";s:1:"y";s:2:"10";s:6:"yacute";s:2:"10";s:9:"ydieresis";s:2:"10";}s:1:"s";a:1:{s:1:"w";s:3:"-15";}s:6:"sacute";a:1:{s:1:"w";s:3:"-15";}s:6:"scaron";a:1:{s:1:"w";s:3:"-15";}s:8:"scedilla";a:1:{s:1:"w";s:3:"-15";}s:12:"scommaaccent";a:1:{s:1:"w";s:3:"-15";}s:9:"semicolon";a:1:{s:5:"space";s:3:"-40";}s:5:"space";a:10:{s:1:"T";s:4:"-100";s:6:"Tcaron";s:4:"-100";s:12:"Tcommaaccent";s:4:"-100";s:1:"V";s:3:"-80";s:1:"W";s:3:"-80";s:1:"Y";s:4:"-120";s:6:"Yacute";s:4:"-120";s:9:"Ydieresis";s:4:"-120";s:12:"quotedblleft";s:3:"-80";s:9:"quoteleft";s:3:"-60";}s:1:"v";a:21:{s:1:"a";s:3:"-20";s:6:"aacute";s:3:"-20";s:6:"abreve";s:3:"-20";s:11:"acircumflex";s:3:"-20";s:9:"adieresis";s:3:"-20";s:6:"agrave";s:3:"-20";s:7:"amacron";s:3:"-20";s:7:"aogonek";s:3:"-20";s:5:"aring";s:3:"-20";s:6:"atilde";s:3:"-20";s:5:"comma";s:3:"-80";s:1:"o";s:3:"-30";s:6:"oacute";s:3:"-30";s:11:"ocircumflex";s:3:"-30";s:9:"odieresis";s:3:"-30";s:6:"ograve";s:3:"-30";s:13:"ohungarumlaut";s:3:"-30";s:7:"omacron";s:3:"-30";s:6:"oslash";s:3:"-30";s:6:"otilde";s:3:"-30";s:6:"period";s:3:"-80";}s:1:"w";a:11:{s:5:"comma";s:3:"-40";s:1:"o";s:3:"-20";s:6:"oacute";s:3:"-20";s:11:"ocircumflex";s:3:"-20";s:9:"odieresis";s:3:"-20";s:6:"ograve";s:3:"-20";s:13:"ohungarumlaut";s:3:"-20";s:7:"omacron";s:3:"-20";s:6:"oslash";s:3:"-20";s:6:"otilde";s:3:"-20";s:6:"period";s:3:"-40";}s:1:"x";a:9:{s:1:"e";s:3:"-10";s:6:"eacute";s:3:"-10";s:6:"ecaron";s:3:"-10";s:11:"ecircumflex";s:3:"-10";s:9:"edieresis";s:3:"-10";s:10:"edotaccent";s:3:"-10";s:6:"egrave";s:3:"-10";s:7:"emacron";s:3:"-10";s:7:"eogonek";s:3:"-10";}s:1:"y";a:30:{s:1:"a";s:3:"-30";s:6:"aacute";s:3:"-30";s:6:"abreve";s:3:"-30";s:11:"acircumflex";s:3:"-30";s:9:"adieresis";s:3:"-30";s:6:"agrave";s:3:"-30";s:7:"amacron";s:3:"-30";s:7:"aogonek";s:3:"-30";s:5:"aring";s:3:"-30";s:6:"atilde";s:3:"-30";s:5:"comma";s:3:"-80";s:1:"e";s:3:"-10";s:6:"eacute";s:3:"-10";s:6:"ecaron";s:3:"-10";s:11:"ecircumflex";s:3:"-10";s:9:"edieresis";s:3:"-10";s:10:"edotaccent";s:3:"-10";s:6:"egrave";s:3:"-10";s:7:"emacron";s:3:"-10";s:7:"eogonek";s:3:"-10";s:1:"o";s:3:"-25";s:6:"oacute";s:3:"-25";s:11:"ocircumflex";s:3:"-25";s:9:"odieresis";s:3:"-25";s:6:"ograve";s:3:"-25";s:13:"ohungarumlaut";s:3:"-25";s:7:"omacron";s:3:"-25";s:6:"oslash";s:3:"-25";s:6:"otilde";s:3:"-25";s:6:"period";s:3:"-80";}s:6:"yacute";a:30:{s:1:"a";s:3:"-30";s:6:"aacute";s:3:"-30";s:6:"abreve";s:3:"-30";s:11:"acircumflex";s:3:"-30";s:9:"adieresis";s:3:"-30";s:6:"agrave";s:3:"-30";s:7:"amacron";s:3:"-30";s:7:"aogonek";s:3:"-30";s:5:"aring";s:3:"-30";s:6:"atilde";s:3:"-30";s:5:"comma";s:3:"-80";s:1:"e";s:3:"-10";s:6:"eacute";s:3:"-10";s:6:"ecaron";s:3:"-10";s:11:"ecircumflex";s:3:"-10";s:9:"edieresis";s:3:"-10";s:10:"edotaccent";s:3:"-10";s:6:"egrave";s:3:"-10";s:7:"emacron";s:3:"-10";s:7:"eogonek";s:3:"-10";s:1:"o";s:3:"-25";s:6:"oacute";s:3:"-25";s:11:"ocircumflex";s:3:"-25";s:9:"odieresis";s:3:"-25";s:6:"ograve";s:3:"-25";s:13:"ohungarumlaut";s:3:"-25";s:7:"omacron";s:3:"-25";s:6:"oslash";s:3:"-25";s:6:"otilde";s:3:"-25";s:6:"period";s:3:"-80";}s:9:"ydieresis";a:30:{s:1:"a";s:3:"-30";s:6:"aacute";s:3:"-30";s:6:"abreve";s:3:"-30";s:11:"acircumflex";s:3:"-30";s:9:"adieresis";s:3:"-30";s:6:"agrave";s:3:"-30";s:7:"amacron";s:3:"-30";s:7:"aogonek";s:3:"-30";s:5:"aring";s:3:"-30";s:6:"atilde";s:3:"-30";s:5:"comma";s:3:"-80";s:1:"e";s:3:"-10";s:6:"eacute";s:3:"-10";s:6:"ecaron";s:3:"-10";s:11:"ecircumflex";s:3:"-10";s:9:"edieresis";s:3:"-10";s:10:"edotaccent";s:3:"-10";s:6:"egrave";s:3:"-10";s:7:"emacron";s:3:"-10";s:7:"eogonek";s:3:"-10";s:1:"o";s:3:"-25";s:6:"oacute";s:3:"-25";s:11:"ocircumflex";s:3:"-25";s:9:"odieresis";s:3:"-25";s:6:"ograve";s:3:"-25";s:13:"ohungarumlaut";s:3:"-25";s:7:"omacron";s:3:"-25";s:6:"oslash";s:3:"-25";s:6:"otilde";s:3:"-25";s:6:"period";s:3:"-80";}s:1:"z";a:9:{s:1:"e";s:2:"10";s:6:"eacute";s:2:"10";s:6:"ecaron";s:2:"10";s:11:"ecircumflex";s:2:"10";s:9:"edieresis";s:2:"10";s:10:"edotaccent";s:2:"10";s:6:"egrave";s:2:"10";s:7:"emacron";s:2:"10";s:7:"eogonek";s:2:"10";}s:6:"zacute";a:9:{s:1:"e";s:2:"10";s:6:"eacute";s:2:"10";s:6:"ecaron";s:2:"10";s:11:"ecircumflex";s:2:"10";s:9:"edieresis";s:2:"10";s:10:"edotaccent";s:2:"10";s:6:"egrave";s:2:"10";s:7:"emacron";s:2:"10";s:7:"eogonek";s:2:"10";}s:6:"zcaron";a:9:{s:1:"e";s:2:"10";s:6:"eacute";s:2:"10";s:6:"ecaron";s:2:"10";s:11:"ecircumflex";s:2:"10";s:9:"edieresis";s:2:"10";s:10:"edotaccent";s:2:"10";s:6:"egrave";s:2:"10";s:7:"emacron";s:2:"10";s:7:"eogonek";s:2:"10";}s:10:"zdotaccent";a:9:{s:1:"e";s:2:"10";s:6:"eacute";s:2:"10";s:6:"ecaron";s:2:"10";s:11:"ecircumflex";s:2:"10";s:9:"edieresis";s:2:"10";s:10:"edotaccent";s:2:"10";s:6:"egrave";s:2:"10";s:7:"emacron";s:2:"10";s:7:"eogonek";s:2:"10";}}s:9:"_version_";i:1;}
\ No newline at end of file
Added: trunk/mapbender/http/classes/fonts/php_Helvetica-BoldOblique.afm
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/fonts/php_Helvetica-BoldOblique.afm?view=auto&rev=13
--- (empty file)
+++ trunk/mapbender/http/classes/fonts/php_Helvetica-BoldOblique.afm 2006-04-13 19:38:28+0000
@@ -0,0 +1 @@
+a:22:{s:8:"FontName";s:21:"Helvetica-BoldOblique";s:8:"FullName";s:22:"Helvetica Bold Oblique";s:10:"FamilyName";s:9:"Helvetica";s:6:"Weight";s:4:"Bold";s:11:"ItalicAngle";s:3:"-12";s:12:"IsFixedPitch";s:5:"false";s:12:"CharacterSet";s:13:"ExtendedRoman";s:8:"FontBBox";a:4:{i:0;s:4:"-174";i:1;s:4:"-228";i:2;s:4:"1114";i:3;s:3:"962";}s:17:"UnderlinePosition";s:4:"-100";s:18:"UnderlineThickness";s:2:"50";s:7:"Version";s:7:"002.000";s:14:"EncodingScheme";s:21:"AdobeStandardEncoding";s:9:"CapHeight";s:3:"718";s:7:"XHeight";s:3:"532";s:8:"Ascender";s:3:"718";s:9:"Descender";s:4:"-207";s:5:"StdHW";s:3:"118";s:5:"StdVW";s:3:"140";s:16:"StartCharMetrics";s:3:"315";s:1:"C";a:464:{i:32;a:4:{s:1:"C";s:2:"32";s:2:"WX";s:3:"278";s:1:"N";s:5:"space";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}s:5:"space";a:4:{s:1:"C";s:2:"32";s:2:"WX";s:3:"278";s:1:"N";s:5:"space";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}i:33;a:4:{s:1:"C";s:2:"33";s:2:"WX";s:3:"333";s:1:"N";s:6:"exclam";s:1:"B";a:4:{i:0;s:2:"94";i:1;s:1:"0";i:2;s:3:"397";i:3;s:3:"718";}}s:6:"exclam";a:4:{s:1:"C";s:2:"33";s:2:"WX";s:3:"333";s:1:"N";s:6:"exclam";s:1:"B";a:4:{i:0;s:2:"94";i:1;s:1:"0";i:2;s:3:"397";i:3;s:3:"718";}}i:34;a:4:{s:1:"C";s:2:"34";s:2:"WX";s:3:"474";s:1:"N";s:8:"quotedbl";s:1:"B";a:4:{i:0;s:3:"193";i:1;s:3:"447";i:2;s:3:"529";i:3;s:3:"718";}}s:8:"quotedbl";a:4:{s:1:"C";s:2:"34";s:2:"WX";s:3:"474";s:1:"N";s:8:"quotedbl";s:1:"B";a:4:{i:0;s:3:"193";i:1;s:3:"447";i:2;s:3:"529";i:3;s:3:"718";}}i:35;a:4:{s:1:"C";s:2:"35";s:2:"WX";s:3:"556";s:1:"N";s:10:"numbersign";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:1:"0";i:2;s:3:"644";i:3;s:3:"698";}}s:10:"numbersign";a:4:{s:1:"C";s:2:"35";s:2:"WX";s:3:"556";s:1:"N";s:10:"numbersign";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:1:"0";i:2;s:3:"644";i:3;s:3:"698";}}i:36;a:4:{s:1:"C";s:2:"36";s:2:"WX";s:3:"556";s:1:"N";s:6:"dollar";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:4:"-115";i:2;s:3:"622";i:3;s:3:"775";}}s:6:"dollar";a:4:{s:1:"C";s:2:"36";s:2:"WX";s:3:"556";s:1:"N";s:6:"dollar";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:4:"-115";i:2;s:3:"622";i:3;s:3:"775";}}i:37;a:4:{s:1:"C";s:2:"37";s:2:"WX";s:3:"889";s:1:"N";s:7:"percent";s:1:"B";a:4:{i:0;s:3:"136";i:1;s:3:"-19";i:2;s:3:"901";i:3;s:3:"710";}}s:7:"percent";a:4:{s:1:"C";s:2:"37";s:2:"WX";s:3:"889";s:1:"N";s:7:"percent";s:1:"B";a:4:{i:0;s:3:"136";i:1;s:3:"-19";i:2;s:3:"901";i:3;s:3:"710";}}i:38;a:4:{s:1:"C";s:2:"38";s:2:"WX";s:3:"722";s:1:"N";s:9:"ampersand";s:1:"B";a:4:{i:0;s:2:"89";i:1;s:3:"-19";i:2;s:3:"732";i:3;s:3:"718";}}s:9:"ampersand";a:4:{s:1:"C";s:2:"38";s:2:"WX";s:3:"722";s:1:"N";s:9:"ampersand";s:1:"B";a:4:{i:0;s:2:"89";i:1;s:3:"-19";i:2;s:3:"732";i:3;s:3:"718";}}i:39;a:4:{s:1:"C";s:2:"39";s:2:"WX";s:3:"278";s:1:"N";s:10:"quoteright";s:1:"B";a:4:{i:0;s:3:"167";i:1;s:3:"445";i:2;s:3:"362";i:3;s:3:"718";}}s:10:"quoteright";a:4:{s:1:"C";s:2:"39";s:2:"WX";s:3:"278";s:1:"N";s:10:"quoteright";s:1:"B";a:4:{i:0;s:3:"167";i:1;s:3:"445";i:2;s:3:"362";i:3;s:3:"718";}}i:40;a:4:{s:1:"C";s:2:"40";s:2:"WX";s:3:"333";s:1:"N";s:9:"parenleft";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:4:"-208";i:2;s:3:"470";i:3;s:3:"734";}}s:9:"parenleft";a:4:{s:1:"C";s:2:"40";s:2:"WX";s:3:"333";s:1:"N";s:9:"parenleft";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:4:"-208";i:2;s:3:"470";i:3;s:3:"734";}}i:41;a:4:{s:1:"C";s:2:"41";s:2:"WX";s:3:"333";s:1:"N";s:10:"parenright";s:1:"B";a:4:{i:0;s:3:"-25";i:1;s:4:"-208";i:2;s:3:"369";i:3;s:3:"734";}}s:10:"parenright";a:4:{s:1:"C";s:2:"41";s:2:"WX";s:3:"333";s:1:"N";s:10:"parenright";s:1:"B";a:4:{i:0;s:3:"-25";i:1;s:4:"-208";i:2;s:3:"369";i:3;s:3:"734";}}i:42;a:4:{s:1:"C";s:2:"42";s:2:"WX";s:3:"389";s:1:"N";s:8:"asterisk";s:1:"B";a:4:{i:0;s:3:"146";i:1;s:3:"387";i:2;s:3:"481";i:3;s:3:"718";}}s:8:"asterisk";a:4:{s:1:"C";s:2:"42";s:2:"WX";s:3:"389";s:1:"N";s:8:"asterisk";s:1:"B";a:4:{i:0;s:3:"146";i:1;s:3:"387";i:2;s:3:"481";i:3;s:3:"718";}}i:43;a:4:{s:1:"C";s:2:"43";s:2:"WX";s:3:"584";s:1:"N";s:4:"plus";s:1:"B";a:4:{i:0;s:2:"82";i:1;s:1:"0";i:2;s:3:"610";i:3;s:3:"506";}}s:4:"plus";a:4:{s:1:"C";s:2:"43";s:2:"WX";s:3:"584";s:1:"N";s:4:"plus";s:1:"B";a:4:{i:0;s:2:"82";i:1;s:1:"0";i:2;s:3:"610";i:3;s:3:"506";}}i:44;a:4:{s:1:"C";s:2:"44";s:2:"WX";s:3:"278";s:1:"N";s:5:"comma";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:4:"-168";i:2;s:3:"245";i:3;s:3:"146";}}s:5:"comma";a:4:{s:1:"C";s:2:"44";s:2:"WX";s:3:"278";s:1:"N";s:5:"comma";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:4:"-168";i:2;s:3:"245";i:3;s:3:"146";}}i:45;a:4:{s:1:"C";s:2:"45";s:2:"WX";s:3:"333";s:1:"N";s:6:"hyphen";s:1:"B";a:4:{i:0;s:2:"73";i:1;s:3:"215";i:2;s:3:"379";i:3;s:3:"345";}}s:6:"hyphen";a:4:{s:1:"C";s:2:"45";s:2:"WX";s:3:"333";s:1:"N";s:6:"hyphen";s:1:"B";a:4:{i:0;s:2:"73";i:1;s:3:"215";i:2;s:3:"379";i:3;s:3:"345";}}i:46;a:4:{s:1:"C";s:2:"46";s:2:"WX";s:3:"278";s:1:"N";s:6:"period";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:1:"0";i:2;s:3:"245";i:3;s:3:"146";}}s:6:"period";a:4:{s:1:"C";s:2:"46";s:2:"WX";s:3:"278";s:1:"N";s:6:"period";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:1:"0";i:2;s:3:"245";i:3;s:3:"146";}}i:47;a:4:{s:1:"C";s:2:"47";s:2:"WX";s:3:"278";s:1:"N";s:5:"slash";s:1:"B";a:4:{i:0;s:3:"-37";i:1;s:3:"-19";i:2;s:3:"468";i:3;s:3:"737";}}s:5:"slash";a:4:{s:1:"C";s:2:"47";s:2:"WX";s:3:"278";s:1:"N";s:5:"slash";s:1:"B";a:4:{i:0;s:3:"-37";i:1;s:3:"-19";i:2;s:3:"468";i:3;s:3:"737";}}i:48;a:4:{s:1:"C";s:2:"48";s:2:"WX";s:3:"556";s:1:"N";s:4:"zero";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:3:"-19";i:2;s:3:"617";i:3;s:3:"710";}}s:4:"zero";a:4:{s:1:"C";s:2:"48";s:2:"WX";s:3:"556";s:1:"N";s:4:"zero";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:3:"-19";i:2;s:3:"617";i:3;s:3:"710";}}i:49;a:4:{s:1:"C";s:2:"49";s:2:"WX";s:3:"556";s:1:"N";s:3:"one";s:1:"B";a:4:{i:0;s:3:"173";i:1;s:1:"0";i:2;s:3:"529";i:3;s:3:"710";}}s:3:"one";a:4:{s:1:"C";s:2:"49";s:2:"WX";s:3:"556";s:1:"N";s:3:"one";s:1:"B";a:4:{i:0;s:3:"173";i:1;s:1:"0";i:2;s:3:"529";i:3;s:3:"710";}}i:50;a:4:{s:1:"C";s:2:"50";s:2:"WX";s:3:"556";s:1:"N";s:3:"two";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"619";i:3;s:3:"710";}}s:3:"two";a:4:{s:1:"C";s:2:"50";s:2:"WX";s:3:"556";s:1:"N";s:3:"two";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"619";i:3;s:3:"710";}}i:51;a:4:{s:1:"C";s:2:"51";s:2:"WX";s:3:"556";s:1:"N";s:5:"three";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:3:"-19";i:2;s:3:"608";i:3;s:3:"710";}}s:5:"three";a:4:{s:1:"C";s:2:"51";s:2:"WX";s:3:"556";s:1:"N";s:5:"three";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:3:"-19";i:2;s:3:"608";i:3;s:3:"710";}}i:52;a:4:{s:1:"C";s:2:"52";s:2:"WX";s:3:"556";s:1:"N";s:4:"four";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:1:"0";i:2;s:3:"598";i:3;s:3:"710";}}s:4:"four";a:4:{s:1:"C";s:2:"52";s:2:"WX";s:3:"556";s:1:"N";s:4:"four";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:1:"0";i:2;s:3:"598";i:3;s:3:"710";}}i:53;a:4:{s:1:"C";s:2:"53";s:2:"WX";s:3:"556";s:1:"N";s:4:"five";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:3:"-19";i:2;s:3:"636";i:3;s:3:"698";}}s:4:"five";a:4:{s:1:"C";s:2:"53";s:2:"WX";s:3:"556";s:1:"N";s:4:"five";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:3:"-19";i:2;s:3:"636";i:3;s:3:"698";}}i:54;a:4:{s:1:"C";s:2:"54";s:2:"WX";s:3:"556";s:1:"N";s:3:"six";s:1:"B";a:4:{i:0;s:2:"85";i:1;s:3:"-19";i:2;s:3:"619";i:3;s:3:"710";}}s:3:"six";a:4:{s:1:"C";s:2:"54";s:2:"WX";s:3:"556";s:1:"N";s:3:"six";s:1:"B";a:4:{i:0;s:2:"85";i:1;s:3:"-19";i:2;s:3:"619";i:3;s:3:"710";}}i:55;a:4:{s:1:"C";s:2:"55";s:2:"WX";s:3:"556";s:1:"N";s:5:"seven";s:1:"B";a:4:{i:0;s:3:"125";i:1;s:1:"0";i:2;s:3:"676";i:3;s:3:"698";}}s:5:"seven";a:4:{s:1:"C";s:2:"55";s:2:"WX";s:3:"556";s:1:"N";s:5:"seven";s:1:"B";a:4:{i:0;s:3:"125";i:1;s:1:"0";i:2;s:3:"676";i:3;s:3:"698";}}i:56;a:4:{s:1:"C";s:2:"56";s:2:"WX";s:3:"556";s:1:"N";s:5:"eight";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:3:"-19";i:2;s:3:"616";i:3;s:3:"710";}}s:5:"eight";a:4:{s:1:"C";s:2:"56";s:2:"WX";s:3:"556";s:1:"N";s:5:"eight";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:3:"-19";i:2;s:3:"616";i:3;s:3:"710";}}i:57;a:4:{s:1:"C";s:2:"57";s:2:"WX";s:3:"556";s:1:"N";s:4:"nine";s:1:"B";a:4:{i:0;s:2:"78";i:1;s:3:"-19";i:2;s:3:"615";i:3;s:3:"710";}}s:4:"nine";a:4:{s:1:"C";s:2:"57";s:2:"WX";s:3:"556";s:1:"N";s:4:"nine";s:1:"B";a:4:{i:0;s:2:"78";i:1;s:3:"-19";i:2;s:3:"615";i:3;s:3:"710";}}i:58;a:4:{s:1:"C";s:2:"58";s:2:"WX";s:3:"333";s:1:"N";s:5:"colon";s:1:"B";a:4:{i:0;s:2:"92";i:1;s:1:"0";i:2;s:3:"351";i:3;s:3:"512";}}s:5:"colon";a:4:{s:1:"C";s:2:"58";s:2:"WX";s:3:"333";s:1:"N";s:5:"colon";s:1:"B";a:4:{i:0;s:2:"92";i:1;s:1:"0";i:2;s:3:"351";i:3;s:3:"512";}}i:59;a:4:{s:1:"C";s:2:"59";s:2:"WX";s:3:"333";s:1:"N";s:9:"semicolon";s:1:"B";a:4:{i:0;s:2:"56";i:1;s:4:"-168";i:2;s:3:"351";i:3;s:3:"512";}}s:9:"semicolon";a:4:{s:1:"C";s:2:"59";s:2:"WX";s:3:"333";s:1:"N";s:9:"semicolon";s:1:"B";a:4:{i:0;s:2:"56";i:1;s:4:"-168";i:2;s:3:"351";i:3;s:3:"512";}}i:60;a:4:{s:1:"C";s:2:"60";s:2:"WX";s:3:"584";s:1:"N";s:4:"less";s:1:"B";a:4:{i:0;s:2:"82";i:1;s:2:"-8";i:2;s:3:"655";i:3;s:3:"514";}}s:4:"less";a:4:{s:1:"C";s:2:"60";s:2:"WX";s:3:"584";s:1:"N";s:4:"less";s:1:"B";a:4:{i:0;s:2:"82";i:1;s:2:"-8";i:2;s:3:"655";i:3;s:3:"514";}}i:61;a:4:{s:1:"C";s:2:"61";s:2:"WX";s:3:"584";s:1:"N";s:5:"equal";s:1:"B";a:4:{i:0;s:2:"58";i:1;s:2:"87";i:2;s:3:"633";i:3;s:3:"419";}}s:5:"equal";a:4:{s:1:"C";s:2:"61";s:2:"WX";s:3:"584";s:1:"N";s:5:"equal";s:1:"B";a:4:{i:0;s:2:"58";i:1;s:2:"87";i:2;s:3:"633";i:3;s:3:"419";}}i:62;a:4:{s:1:"C";s:2:"62";s:2:"WX";s:3:"584";s:1:"N";s:7:"greater";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:2:"-8";i:2;s:3:"609";i:3;s:3:"514";}}s:7:"greater";a:4:{s:1:"C";s:2:"62";s:2:"WX";s:3:"584";s:1:"N";s:7:"greater";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:2:"-8";i:2;s:3:"609";i:3;s:3:"514";}}i:63;a:4:{s:1:"C";s:2:"63";s:2:"WX";s:3:"611";s:1:"N";s:8:"question";s:1:"B";a:4:{i:0;s:3:"165";i:1;s:1:"0";i:2;s:3:"671";i:3;s:3:"727";}}s:8:"question";a:4:{s:1:"C";s:2:"63";s:2:"WX";s:3:"611";s:1:"N";s:8:"question";s:1:"B";a:4:{i:0;s:3:"165";i:1;s:1:"0";i:2;s:3:"671";i:3;s:3:"727";}}i:64;a:4:{s:1:"C";s:2:"64";s:2:"WX";s:3:"975";s:1:"N";s:2:"at";s:1:"B";a:4:{i:0;s:3:"186";i:1;s:3:"-19";i:2;s:3:"954";i:3;s:3:"737";}}s:2:"at";a:4:{s:1:"C";s:2:"64";s:2:"WX";s:3:"975";s:1:"N";s:2:"at";s:1:"B";a:4:{i:0;s:3:"186";i:1;s:3:"-19";i:2;s:3:"954";i:3;s:3:"737";}}i:65;a:4:{s:1:"C";s:2:"65";s:2:"WX";s:3:"722";s:1:"N";s:1:"A";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"702";i:3;s:3:"718";}}s:1:"A";a:4:{s:1:"C";s:2:"65";s:2:"WX";s:3:"722";s:1:"N";s:1:"A";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"702";i:3;s:3:"718";}}i:66;a:4:{s:1:"C";s:2:"66";s:2:"WX";s:3:"722";s:1:"N";s:1:"B";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"764";i:3;s:3:"718";}}s:1:"B";a:4:{s:1:"C";s:2:"66";s:2:"WX";s:3:"722";s:1:"N";s:1:"B";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"764";i:3;s:3:"718";}}i:67;a:4:{s:1:"C";s:2:"67";s:2:"WX";s:3:"722";s:1:"N";s:1:"C";s:1:"B";a:4:{i:0;s:3:"107";i:1;s:3:"-19";i:2;s:3:"789";i:3;s:3:"737";}}s:1:"C";a:4:{s:1:"C";s:2:"67";s:2:"WX";s:3:"722";s:1:"N";s:1:"C";s:1:"B";a:4:{i:0;s:3:"107";i:1;s:3:"-19";i:2;s:3:"789";i:3;s:3:"737";}}i:68;a:4:{s:1:"C";s:2:"68";s:2:"WX";s:3:"722";s:1:"N";s:1:"D";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"777";i:3;s:3:"718";}}s:1:"D";a:4:{s:1:"C";s:2:"68";s:2:"WX";s:3:"722";s:1:"N";s:1:"D";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"777";i:3;s:3:"718";}}i:69;a:4:{s:1:"C";s:2:"69";s:2:"WX";s:3:"667";s:1:"N";s:1:"E";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"757";i:3;s:3:"718";}}s:1:"E";a:4:{s:1:"C";s:2:"69";s:2:"WX";s:3:"667";s:1:"N";s:1:"E";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"757";i:3;s:3:"718";}}i:70;a:4:{s:1:"C";s:2:"70";s:2:"WX";s:3:"611";s:1:"N";s:1:"F";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"740";i:3;s:3:"718";}}s:1:"F";a:4:{s:1:"C";s:2:"70";s:2:"WX";s:3:"611";s:1:"N";s:1:"F";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"740";i:3;s:3:"718";}}i:71;a:4:{s:1:"C";s:2:"71";s:2:"WX";s:3:"778";s:1:"N";s:1:"G";s:1:"B";a:4:{i:0;s:3:"108";i:1;s:3:"-19";i:2;s:3:"817";i:3;s:3:"737";}}s:1:"G";a:4:{s:1:"C";s:2:"71";s:2:"WX";s:3:"778";s:1:"N";s:1:"G";s:1:"B";a:4:{i:0;s:3:"108";i:1;s:3:"-19";i:2;s:3:"817";i:3;s:3:"737";}}i:72;a:4:{s:1:"C";s:2:"72";s:2:"WX";s:3:"722";s:1:"N";s:1:"H";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:1:"0";i:2;s:3:"804";i:3;s:3:"718";}}s:1:"H";a:4:{s:1:"C";s:2:"72";s:2:"WX";s:3:"722";s:1:"N";s:1:"H";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:1:"0";i:2;s:3:"804";i:3;s:3:"718";}}i:73;a:4:{s:1:"C";s:2:"73";s:2:"WX";s:3:"278";s:1:"N";s:1:"I";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:1:"0";i:2;s:3:"367";i:3;s:3:"718";}}s:1:"I";a:4:{s:1:"C";s:2:"73";s:2:"WX";s:3:"278";s:1:"N";s:1:"I";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:1:"0";i:2;s:3:"367";i:3;s:3:"718";}}i:74;a:4:{s:1:"C";s:2:"74";s:2:"WX";s:3:"556";s:1:"N";s:1:"J";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:3:"-18";i:2;s:3:"637";i:3;s:3:"718";}}s:1:"J";a:4:{s:1:"C";s:2:"74";s:2:"WX";s:3:"556";s:1:"N";s:1:"J";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:3:"-18";i:2;s:3:"637";i:3;s:3:"718";}}i:75;a:4:{s:1:"C";s:2:"75";s:2:"WX";s:3:"722";s:1:"N";s:1:"K";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:1:"0";i:2;s:3:"858";i:3;s:3:"718";}}s:1:"K";a:4:{s:1:"C";s:2:"75";s:2:"WX";s:3:"722";s:1:"N";s:1:"K";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:1:"0";i:2;s:3:"858";i:3;s:3:"718";}}i:76;a:4:{s:1:"C";s:2:"76";s:2:"WX";s:3:"611";s:1:"N";s:1:"L";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"611";i:3;s:3:"718";}}s:1:"L";a:4:{s:1:"C";s:2:"76";s:2:"WX";s:3:"611";s:1:"N";s:1:"L";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"611";i:3;s:3:"718";}}i:77;a:4:{s:1:"C";s:2:"77";s:2:"WX";s:3:"833";s:1:"N";s:1:"M";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"918";i:3;s:3:"718";}}s:1:"M";a:4:{s:1:"C";s:2:"77";s:2:"WX";s:3:"833";s:1:"N";s:1:"M";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"918";i:3;s:3:"718";}}i:78;a:4:{s:1:"C";s:2:"78";s:2:"WX";s:3:"722";s:1:"N";s:1:"N";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"807";i:3;s:3:"718";}}s:1:"N";a:4:{s:1:"C";s:2:"78";s:2:"WX";s:3:"722";s:1:"N";s:1:"N";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"807";i:3;s:3:"718";}}i:79;a:4:{s:1:"C";s:2:"79";s:2:"WX";s:3:"778";s:1:"N";s:1:"O";s:1:"B";a:4:{i:0;s:3:"107";i:1;s:3:"-19";i:2;s:3:"823";i:3;s:3:"737";}}s:1:"O";a:4:{s:1:"C";s:2:"79";s:2:"WX";s:3:"778";s:1:"N";s:1:"O";s:1:"B";a:4:{i:0;s:3:"107";i:1;s:3:"-19";i:2;s:3:"823";i:3;s:3:"737";}}i:80;a:4:{s:1:"C";s:2:"80";s:2:"WX";s:3:"667";s:1:"N";s:1:"P";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"738";i:3;s:3:"718";}}s:1:"P";a:4:{s:1:"C";s:2:"80";s:2:"WX";s:3:"667";s:1:"N";s:1:"P";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"738";i:3;s:3:"718";}}i:81;a:4:{s:1:"C";s:2:"81";s:2:"WX";s:3:"778";s:1:"N";s:1:"Q";s:1:"B";a:4:{i:0;s:3:"107";i:1;s:3:"-52";i:2;s:3:"823";i:3;s:3:"737";}}s:1:"Q";a:4:{s:1:"C";s:2:"81";s:2:"WX";s:3:"778";s:1:"N";s:1:"Q";s:1:"B";a:4:{i:0;s:3:"107";i:1;s:3:"-52";i:2;s:3:"823";i:3;s:3:"737";}}i:82;a:4:{s:1:"C";s:2:"82";s:2:"WX";s:3:"722";s:1:"N";s:1:"R";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"778";i:3;s:3:"718";}}s:1:"R";a:4:{s:1:"C";s:2:"82";s:2:"WX";s:3:"722";s:1:"N";s:1:"R";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"778";i:3;s:3:"718";}}i:83;a:4:{s:1:"C";s:2:"83";s:2:"WX";s:3:"667";s:1:"N";s:1:"S";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:3:"-19";i:2;s:3:"718";i:3;s:3:"737";}}s:1:"S";a:4:{s:1:"C";s:2:"83";s:2:"WX";s:3:"667";s:1:"N";s:1:"S";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:3:"-19";i:2;s:3:"718";i:3;s:3:"737";}}i:84;a:4:{s:1:"C";s:2:"84";s:2:"WX";s:3:"611";s:1:"N";s:1:"T";s:1:"B";a:4:{i:0;s:3:"140";i:1;s:1:"0";i:2;s:3:"751";i:3;s:3:"718";}}s:1:"T";a:4:{s:1:"C";s:2:"84";s:2:"WX";s:3:"611";s:1:"N";s:1:"T";s:1:"B";a:4:{i:0;s:3:"140";i:1;s:1:"0";i:2;s:3:"751";i:3;s:3:"718";}}i:85;a:4:{s:1:"C";s:2:"85";s:2:"WX";s:3:"722";s:1:"N";s:1:"U";s:1:"B";a:4:{i:0;s:3:"116";i:1;s:3:"-19";i:2;s:3:"804";i:3;s:3:"718";}}s:1:"U";a:4:{s:1:"C";s:2:"85";s:2:"WX";s:3:"722";s:1:"N";s:1:"U";s:1:"B";a:4:{i:0;s:3:"116";i:1;s:3:"-19";i:2;s:3:"804";i:3;s:3:"718";}}i:86;a:4:{s:1:"C";s:2:"86";s:2:"WX";s:3:"667";s:1:"N";s:1:"V";s:1:"B";a:4:{i:0;s:3:"172";i:1;s:1:"0";i:2;s:3:"801";i:3;s:3:"718";}}s:1:"V";a:4:{s:1:"C";s:2:"86";s:2:"WX";s:3:"667";s:1:"N";s:1:"V";s:1:"B";a:4:{i:0;s:3:"172";i:1;s:1:"0";i:2;s:3:"801";i:3;s:3:"718";}}i:87;a:4:{s:1:"C";s:2:"87";s:2:"WX";s:3:"944";s:1:"N";s:1:"W";s:1:"B";a:4:{i:0;s:3:"169";i:1;s:1:"0";i:2;s:4:"1082";i:3;s:3:"718";}}s:1:"W";a:4:{s:1:"C";s:2:"87";s:2:"WX";s:3:"944";s:1:"N";s:1:"W";s:1:"B";a:4:{i:0;s:3:"169";i:1;s:1:"0";i:2;s:4:"1082";i:3;s:3:"718";}}i:88;a:4:{s:1:"C";s:2:"88";s:2:"WX";s:3:"667";s:1:"N";s:1:"X";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"791";i:3;s:3:"718";}}s:1:"X";a:4:{s:1:"C";s:2:"88";s:2:"WX";s:3:"667";s:1:"N";s:1:"X";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"791";i:3;s:3:"718";}}i:89;a:4:{s:1:"C";s:2:"89";s:2:"WX";s:3:"667";s:1:"N";s:1:"Y";s:1:"B";a:4:{i:0;s:3:"168";i:1;s:1:"0";i:2;s:3:"806";i:3;s:3:"718";}}s:1:"Y";a:4:{s:1:"C";s:2:"89";s:2:"WX";s:3:"667";s:1:"N";s:1:"Y";s:1:"B";a:4:{i:0;s:3:"168";i:1;s:1:"0";i:2;s:3:"806";i:3;s:3:"718";}}i:90;a:4:{s:1:"C";s:2:"90";s:2:"WX";s:3:"611";s:1:"N";s:1:"Z";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"737";i:3;s:3:"718";}}s:1:"Z";a:4:{s:1:"C";s:2:"90";s:2:"WX";s:3:"611";s:1:"N";s:1:"Z";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"737";i:3;s:3:"718";}}i:91;a:4:{s:1:"C";s:2:"91";s:2:"WX";s:3:"333";s:1:"N";s:11:"bracketleft";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:4:"-196";i:2;s:3:"462";i:3;s:3:"722";}}s:11:"bracketleft";a:4:{s:1:"C";s:2:"91";s:2:"WX";s:3:"333";s:1:"N";s:11:"bracketleft";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:4:"-196";i:2;s:3:"462";i:3;s:3:"722";}}i:92;a:4:{s:1:"C";s:2:"92";s:2:"WX";s:3:"278";s:1:"N";s:9:"backslash";s:1:"B";a:4:{i:0;s:3:"124";i:1;s:3:"-19";i:2;s:3:"307";i:3;s:3:"737";}}s:9:"backslash";a:4:{s:1:"C";s:2:"92";s:2:"WX";s:3:"278";s:1:"N";s:9:"backslash";s:1:"B";a:4:{i:0;s:3:"124";i:1;s:3:"-19";i:2;s:3:"307";i:3;s:3:"737";}}i:93;a:4:{s:1:"C";s:2:"93";s:2:"WX";s:3:"333";s:1:"N";s:12:"bracketright";s:1:"B";a:4:{i:0;s:3:"-18";i:1;s:4:"-196";i:2;s:3:"423";i:3;s:3:"722";}}s:12:"bracketright";a:4:{s:1:"C";s:2:"93";s:2:"WX";s:3:"333";s:1:"N";s:12:"bracketright";s:1:"B";a:4:{i:0;s:3:"-18";i:1;s:4:"-196";i:2;s:3:"423";i:3;s:3:"722";}}i:94;a:4:{s:1:"C";s:2:"94";s:2:"WX";s:3:"584";s:1:"N";s:11:"asciicircum";s:1:"B";a:4:{i:0;s:3:"131";i:1;s:3:"323";i:2;s:3:"591";i:3;s:3:"698";}}s:11:"asciicircum";a:4:{s:1:"C";s:2:"94";s:2:"WX";s:3:"584";s:1:"N";s:11:"asciicircum";s:1:"B";a:4:{i:0;s:3:"131";i:1;s:3:"323";i:2;s:3:"591";i:3;s:3:"698";}}i:95;a:4:{s:1:"C";s:2:"95";s:2:"WX";s:3:"556";s:1:"N";s:10:"underscore";s:1:"B";a:4:{i:0;s:3:"-27";i:1;s:4:"-125";i:2;s:3:"540";i:3;s:3:"-75";}}s:10:"underscore";a:4:{s:1:"C";s:2:"95";s:2:"WX";s:3:"556";s:1:"N";s:10:"underscore";s:1:"B";a:4:{i:0;s:3:"-27";i:1;s:4:"-125";i:2;s:3:"540";i:3;s:3:"-75";}}i:96;a:4:{s:1:"C";s:2:"96";s:2:"WX";s:3:"278";s:1:"N";s:9:"quoteleft";s:1:"B";a:4:{i:0;s:3:"165";i:1;s:3:"454";i:2;s:3:"361";i:3;s:3:"727";}}s:9:"quoteleft";a:4:{s:1:"C";s:2:"96";s:2:"WX";s:3:"278";s:1:"N";s:9:"quoteleft";s:1:"B";a:4:{i:0;s:3:"165";i:1;s:3:"454";i:2;s:3:"361";i:3;s:3:"727";}}i:97;a:4:{s:1:"C";s:2:"97";s:2:"WX";s:3:"556";s:1:"N";s:1:"a";s:1:"B";a:4:{i:0;s:2:"55";i:1;s:3:"-14";i:2;s:3:"583";i:3;s:3:"546";}}s:1:"a";a:4:{s:1:"C";s:2:"97";s:2:"WX";s:3:"556";s:1:"N";s:1:"a";s:1:"B";a:4:{i:0;s:2:"55";i:1;s:3:"-14";i:2;s:3:"583";i:3;s:3:"546";}}i:98;a:4:{s:1:"C";s:2:"98";s:2:"WX";s:3:"611";s:1:"N";s:1:"b";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:3:"-14";i:2;s:3:"645";i:3;s:3:"718";}}s:1:"b";a:4:{s:1:"C";s:2:"98";s:2:"WX";s:3:"611";s:1:"N";s:1:"b";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:3:"-14";i:2;s:3:"645";i:3;s:3:"718";}}i:99;a:4:{s:1:"C";s:2:"99";s:2:"WX";s:3:"556";s:1:"N";s:1:"c";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:3:"-14";i:2;s:3:"599";i:3;s:3:"546";}}s:1:"c";a:4:{s:1:"C";s:2:"99";s:2:"WX";s:3:"556";s:1:"N";s:1:"c";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:3:"-14";i:2;s:3:"599";i:3;s:3:"546";}}i:100;a:4:{s:1:"C";s:3:"100";s:2:"WX";s:3:"611";s:1:"N";s:1:"d";s:1:"B";a:4:{i:0;s:2:"82";i:1;s:3:"-14";i:2;s:3:"704";i:3;s:3:"718";}}s:1:"d";a:4:{s:1:"C";s:3:"100";s:2:"WX";s:3:"611";s:1:"N";s:1:"d";s:1:"B";a:4:{i:0;s:2:"82";i:1;s:3:"-14";i:2;s:3:"704";i:3;s:3:"718";}}i:101;a:4:{s:1:"C";s:3:"101";s:2:"WX";s:3:"556";s:1:"N";s:1:"e";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:3:"-14";i:2;s:3:"593";i:3;s:3:"546";}}s:1:"e";a:4:{s:1:"C";s:3:"101";s:2:"WX";s:3:"556";s:1:"N";s:1:"e";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:3:"-14";i:2;s:3:"593";i:3;s:3:"546";}}i:102;a:5:{s:1:"C";s:3:"102";s:2:"WX";s:3:"333";s:1:"N";s:1:"f";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:1:"0";i:2;s:3:"469";i:3;s:3:"727";}s:1:"L";a:2:{i:0;s:1:"l";i:1;s:2:"fl";}}s:1:"f";a:5:{s:1:"C";s:3:"102";s:2:"WX";s:3:"333";s:1:"N";s:1:"f";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:1:"0";i:2;s:3:"469";i:3;s:3:"727";}s:1:"L";a:2:{i:0;s:1:"l";i:1;s:2:"fl";}}i:103;a:4:{s:1:"C";s:3:"103";s:2:"WX";s:3:"611";s:1:"N";s:1:"g";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:4:"-217";i:2;s:3:"666";i:3;s:3:"546";}}s:1:"g";a:4:{s:1:"C";s:3:"103";s:2:"WX";s:3:"611";s:1:"N";s:1:"g";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:4:"-217";i:2;s:3:"666";i:3;s:3:"546";}}i:104;a:4:{s:1:"C";s:3:"104";s:2:"WX";s:3:"611";s:1:"N";s:1:"h";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:1:"0";i:2;s:3:"629";i:3;s:3:"718";}}s:1:"h";a:4:{s:1:"C";s:3:"104";s:2:"WX";s:3:"611";s:1:"N";s:1:"h";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:1:"0";i:2;s:3:"629";i:3;s:3:"718";}}i:105;a:4:{s:1:"C";s:3:"105";s:2:"WX";s:3:"278";s:1:"N";s:1:"i";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"363";i:3;s:3:"725";}}s:1:"i";a:4:{s:1:"C";s:3:"105";s:2:"WX";s:3:"278";s:1:"N";s:1:"i";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"363";i:3;s:3:"725";}}i:106;a:4:{s:1:"C";s:3:"106";s:2:"WX";s:3:"278";s:1:"N";s:1:"j";s:1:"B";a:4:{i:0;s:3:"-42";i:1;s:4:"-214";i:2;s:3:"363";i:3;s:3:"725";}}s:1:"j";a:4:{s:1:"C";s:3:"106";s:2:"WX";s:3:"278";s:1:"N";s:1:"j";s:1:"B";a:4:{i:0;s:3:"-42";i:1;s:4:"-214";i:2;s:3:"363";i:3;s:3:"725";}}i:107;a:4:{s:1:"C";s:3:"107";s:2:"WX";s:3:"556";s:1:"N";s:1:"k";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"670";i:3;s:3:"718";}}s:1:"k";a:4:{s:1:"C";s:3:"107";s:2:"WX";s:3:"556";s:1:"N";s:1:"k";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"670";i:3;s:3:"718";}}i:108;a:4:{s:1:"C";s:3:"108";s:2:"WX";s:3:"278";s:1:"N";s:1:"l";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"362";i:3;s:3:"718";}}s:1:"l";a:4:{s:1:"C";s:3:"108";s:2:"WX";s:3:"278";s:1:"N";s:1:"l";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"362";i:3;s:3:"718";}}i:109;a:4:{s:1:"C";s:3:"109";s:2:"WX";s:3:"889";s:1:"N";s:1:"m";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:1:"0";i:2;s:3:"909";i:3;s:3:"546";}}s:1:"m";a:4:{s:1:"C";s:3:"109";s:2:"WX";s:3:"889";s:1:"N";s:1:"m";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:1:"0";i:2;s:3:"909";i:3;s:3:"546";}}i:110;a:4:{s:1:"C";s:3:"110";s:2:"WX";s:3:"611";s:1:"N";s:1:"n";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:1:"0";i:2;s:3:"629";i:3;s:3:"546";}}s:1:"n";a:4:{s:1:"C";s:3:"110";s:2:"WX";s:3:"611";s:1:"N";s:1:"n";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:1:"0";i:2;s:3:"629";i:3;s:3:"546";}}i:111;a:4:{s:1:"C";s:3:"111";s:2:"WX";s:3:"611";s:1:"N";s:1:"o";s:1:"B";a:4:{i:0;s:2:"82";i:1;s:3:"-14";i:2;s:3:"643";i:3;s:3:"546";}}s:1:"o";a:4:{s:1:"C";s:3:"111";s:2:"WX";s:3:"611";s:1:"N";s:1:"o";s:1:"B";a:4:{i:0;s:2:"82";i:1;s:3:"-14";i:2;s:3:"643";i:3;s:3:"546";}}i:112;a:4:{s:1:"C";s:3:"112";s:2:"WX";s:3:"611";s:1:"N";s:1:"p";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:4:"-207";i:2;s:3:"645";i:3;s:3:"546";}}s:1:"p";a:4:{s:1:"C";s:3:"112";s:2:"WX";s:3:"611";s:1:"N";s:1:"p";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:4:"-207";i:2;s:3:"645";i:3;s:3:"546";}}i:113;a:4:{s:1:"C";s:3:"113";s:2:"WX";s:3:"611";s:1:"N";s:1:"q";s:1:"B";a:4:{i:0;s:2:"80";i:1;s:4:"-207";i:2;s:3:"665";i:3;s:3:"546";}}s:1:"q";a:4:{s:1:"C";s:3:"113";s:2:"WX";s:3:"611";s:1:"N";s:1:"q";s:1:"B";a:4:{i:0;s:2:"80";i:1;s:4:"-207";i:2;s:3:"665";i:3;s:3:"546";}}i:114;a:4:{s:1:"C";s:3:"114";s:2:"WX";s:3:"389";s:1:"N";s:1:"r";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:1:"0";i:2;s:3:"489";i:3;s:3:"546";}}s:1:"r";a:4:{s:1:"C";s:3:"114";s:2:"WX";s:3:"389";s:1:"N";s:1:"r";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:1:"0";i:2;s:3:"489";i:3;s:3:"546";}}i:115;a:4:{s:1:"C";s:3:"115";s:2:"WX";s:3:"556";s:1:"N";s:1:"s";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:3:"-14";i:2;s:3:"584";i:3;s:3:"546";}}s:1:"s";a:4:{s:1:"C";s:3:"115";s:2:"WX";s:3:"556";s:1:"N";s:1:"s";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:3:"-14";i:2;s:3:"584";i:3;s:3:"546";}}i:116;a:4:{s:1:"C";s:3:"116";s:2:"WX";s:3:"333";s:1:"N";s:1:"t";s:1:"B";a:4:{i:0;s:3:"100";i:1;s:2:"-6";i:2;s:3:"422";i:3;s:3:"676";}}s:1:"t";a:4:{s:1:"C";s:3:"116";s:2:"WX";s:3:"333";s:1:"N";s:1:"t";s:1:"B";a:4:{i:0;s:3:"100";i:1;s:2:"-6";i:2;s:3:"422";i:3;s:3:"676";}}i:117;a:4:{s:1:"C";s:3:"117";s:2:"WX";s:3:"611";s:1:"N";s:1:"u";s:1:"B";a:4:{i:0;s:2:"98";i:1;s:3:"-14";i:2;s:3:"658";i:3;s:3:"532";}}s:1:"u";a:4:{s:1:"C";s:3:"117";s:2:"WX";s:3:"611";s:1:"N";s:1:"u";s:1:"B";a:4:{i:0;s:2:"98";i:1;s:3:"-14";i:2;s:3:"658";i:3;s:3:"532";}}i:118;a:4:{s:1:"C";s:3:"118";s:2:"WX";s:3:"556";s:1:"N";s:1:"v";s:1:"B";a:4:{i:0;s:3:"126";i:1;s:1:"0";i:2;s:3:"656";i:3;s:3:"532";}}s:1:"v";a:4:{s:1:"C";s:3:"118";s:2:"WX";s:3:"556";s:1:"N";s:1:"v";s:1:"B";a:4:{i:0;s:3:"126";i:1;s:1:"0";i:2;s:3:"656";i:3;s:3:"532";}}i:119;a:4:{s:1:"C";s:3:"119";s:2:"WX";s:3:"778";s:1:"N";s:1:"w";s:1:"B";a:4:{i:0;s:3:"123";i:1;s:1:"0";i:2;s:3:"882";i:3;s:3:"532";}}s:1:"w";a:4:{s:1:"C";s:3:"119";s:2:"WX";s:3:"778";s:1:"N";s:1:"w";s:1:"B";a:4:{i:0;s:3:"123";i:1;s:1:"0";i:2;s:3:"882";i:3;s:3:"532";}}i:120;a:4:{s:1:"C";s:3:"120";s:2:"WX";s:3:"556";s:1:"N";s:1:"x";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:1:"0";i:2;s:3:"648";i:3;s:3:"532";}}s:1:"x";a:4:{s:1:"C";s:3:"120";s:2:"WX";s:3:"556";s:1:"N";s:1:"x";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:1:"0";i:2;s:3:"648";i:3;s:3:"532";}}i:121;a:4:{s:1:"C";s:3:"121";s:2:"WX";s:3:"556";s:1:"N";s:1:"y";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:4:"-214";i:2;s:3:"652";i:3;s:3:"532";}}s:1:"y";a:4:{s:1:"C";s:3:"121";s:2:"WX";s:3:"556";s:1:"N";s:1:"y";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:4:"-214";i:2;s:3:"652";i:3;s:3:"532";}}i:122;a:4:{s:1:"C";s:3:"122";s:2:"WX";s:3:"500";s:1:"N";s:1:"z";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"583";i:3;s:3:"532";}}s:1:"z";a:4:{s:1:"C";s:3:"122";s:2:"WX";s:3:"500";s:1:"N";s:1:"z";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"583";i:3;s:3:"532";}}i:123;a:4:{s:1:"C";s:3:"123";s:2:"WX";s:3:"389";s:1:"N";s:9:"braceleft";s:1:"B";a:4:{i:0;s:2:"94";i:1;s:4:"-196";i:2;s:3:"518";i:3;s:3:"722";}}s:9:"braceleft";a:4:{s:1:"C";s:3:"123";s:2:"WX";s:3:"389";s:1:"N";s:9:"braceleft";s:1:"B";a:4:{i:0;s:2:"94";i:1;s:4:"-196";i:2;s:3:"518";i:3;s:3:"722";}}i:124;a:4:{s:1:"C";s:3:"124";s:2:"WX";s:3:"280";s:1:"N";s:3:"bar";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:4:"-225";i:2;s:3:"361";i:3;s:3:"775";}}s:3:"bar";a:4:{s:1:"C";s:3:"124";s:2:"WX";s:3:"280";s:1:"N";s:3:"bar";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:4:"-225";i:2;s:3:"361";i:3;s:3:"775";}}i:125;a:4:{s:1:"C";s:3:"125";s:2:"WX";s:3:"389";s:1:"N";s:10:"braceright";s:1:"B";a:4:{i:0;s:3:"-18";i:1;s:4:"-196";i:2;s:3:"407";i:3;s:3:"722";}}s:10:"braceright";a:4:{s:1:"C";s:3:"125";s:2:"WX";s:3:"389";s:1:"N";s:10:"braceright";s:1:"B";a:4:{i:0;s:3:"-18";i:1;s:4:"-196";i:2;s:3:"407";i:3;s:3:"722";}}i:126;a:4:{s:1:"C";s:3:"126";s:2:"WX";s:3:"584";s:1:"N";s:10:"asciitilde";s:1:"B";a:4:{i:0;s:3:"115";i:1;s:3:"163";i:2;s:3:"577";i:3;s:3:"343";}}s:10:"asciitilde";a:4:{s:1:"C";s:3:"126";s:2:"WX";s:3:"584";s:1:"N";s:10:"asciitilde";s:1:"B";a:4:{i:0;s:3:"115";i:1;s:3:"163";i:2;s:3:"577";i:3;s:3:"343";}}i:161;a:4:{s:1:"C";s:3:"161";s:2:"WX";s:3:"333";s:1:"N";s:10:"exclamdown";s:1:"B";a:4:{i:0;s:2:"50";i:1;s:4:"-186";i:2;s:3:"353";i:3;s:3:"532";}}s:10:"exclamdown";a:4:{s:1:"C";s:3:"161";s:2:"WX";s:3:"333";s:1:"N";s:10:"exclamdown";s:1:"B";a:4:{i:0;s:2:"50";i:1;s:4:"-186";i:2;s:3:"353";i:3;s:3:"532";}}i:162;a:4:{s:1:"C";s:3:"162";s:2:"WX";s:3:"556";s:1:"N";s:4:"cent";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:4:"-118";i:2;s:3:"599";i:3;s:3:"628";}}s:4:"cent";a:4:{s:1:"C";s:3:"162";s:2:"WX";s:3:"556";s:1:"N";s:4:"cent";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:4:"-118";i:2;s:3:"599";i:3;s:3:"628";}}i:163;a:4:{s:1:"C";s:3:"163";s:2:"WX";s:3:"556";s:1:"N";s:8:"sterling";s:1:"B";a:4:{i:0;s:2:"50";i:1;s:3:"-16";i:2;s:3:"635";i:3;s:3:"718";}}s:8:"sterling";a:4:{s:1:"C";s:3:"163";s:2:"WX";s:3:"556";s:1:"N";s:8:"sterling";s:1:"B";a:4:{i:0;s:2:"50";i:1;s:3:"-16";i:2;s:3:"635";i:3;s:3:"718";}}i:164;a:4:{s:1:"C";s:3:"164";s:2:"WX";s:3:"167";s:1:"N";s:8:"fraction";s:1:"B";a:4:{i:0;s:4:"-174";i:1;s:3:"-19";i:2;s:3:"487";i:3;s:3:"710";}}s:8:"fraction";a:4:{s:1:"C";s:3:"164";s:2:"WX";s:3:"167";s:1:"N";s:8:"fraction";s:1:"B";a:4:{i:0;s:4:"-174";i:1;s:3:"-19";i:2;s:3:"487";i:3;s:3:"710";}}i:165;a:4:{s:1:"C";s:3:"165";s:2:"WX";s:3:"556";s:1:"N";s:3:"yen";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:1:"0";i:2;s:3:"713";i:3;s:3:"698";}}s:3:"yen";a:4:{s:1:"C";s:3:"165";s:2:"WX";s:3:"556";s:1:"N";s:3:"yen";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:1:"0";i:2;s:3:"713";i:3;s:3:"698";}}i:166;a:4:{s:1:"C";s:3:"166";s:2:"WX";s:3:"556";s:1:"N";s:6:"florin";s:1:"B";a:4:{i:0;s:3:"-50";i:1;s:4:"-210";i:2;s:3:"669";i:3;s:3:"737";}}s:6:"florin";a:4:{s:1:"C";s:3:"166";s:2:"WX";s:3:"556";s:1:"N";s:6:"florin";s:1:"B";a:4:{i:0;s:3:"-50";i:1;s:4:"-210";i:2;s:3:"669";i:3;s:3:"737";}}i:167;a:4:{s:1:"C";s:3:"167";s:2:"WX";s:3:"556";s:1:"N";s:7:"section";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:4:"-184";i:2;s:3:"598";i:3;s:3:"727";}}s:7:"section";a:4:{s:1:"C";s:3:"167";s:2:"WX";s:3:"556";s:1:"N";s:7:"section";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:4:"-184";i:2;s:3:"598";i:3;s:3:"727";}}i:168;a:4:{s:1:"C";s:3:"168";s:2:"WX";s:3:"556";s:1:"N";s:8:"currency";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:2:"76";i:2;s:3:"680";i:3;s:3:"636";}}s:8:"currency";a:4:{s:1:"C";s:3:"168";s:2:"WX";s:3:"556";s:1:"N";s:8:"currency";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:2:"76";i:2;s:3:"680";i:3;s:3:"636";}}i:169;a:4:{s:1:"C";s:3:"169";s:2:"WX";s:3:"238";s:1:"N";s:11:"quotesingle";s:1:"B";a:4:{i:0;s:3:"165";i:1;s:3:"447";i:2;s:3:"321";i:3;s:3:"718";}}s:11:"quotesingle";a:4:{s:1:"C";s:3:"169";s:2:"WX";s:3:"238";s:1:"N";s:11:"quotesingle";s:1:"B";a:4:{i:0;s:3:"165";i:1;s:3:"447";i:2;s:3:"321";i:3;s:3:"718";}}i:170;a:4:{s:1:"C";s:3:"170";s:2:"WX";s:3:"500";s:1:"N";s:12:"quotedblleft";s:1:"B";a:4:{i:0;s:3:"160";i:1;s:3:"454";i:2;s:3:"588";i:3;s:3:"727";}}s:12:"quotedblleft";a:4:{s:1:"C";s:3:"170";s:2:"WX";s:3:"500";s:1:"N";s:12:"quotedblleft";s:1:"B";a:4:{i:0;s:3:"160";i:1;s:3:"454";i:2;s:3:"588";i:3;s:3:"727";}}i:171;a:4:{s:1:"C";s:3:"171";s:2:"WX";s:3:"556";s:1:"N";s:13:"guillemotleft";s:1:"B";a:4:{i:0;s:3:"135";i:1;s:2:"76";i:2;s:3:"571";i:3;s:3:"484";}}s:13:"guillemotleft";a:4:{s:1:"C";s:3:"171";s:2:"WX";s:3:"556";s:1:"N";s:13:"guillemotleft";s:1:"B";a:4:{i:0;s:3:"135";i:1;s:2:"76";i:2;s:3:"571";i:3;s:3:"484";}}i:172;a:4:{s:1:"C";s:3:"172";s:2:"WX";s:3:"333";s:1:"N";s:13:"guilsinglleft";s:1:"B";a:4:{i:0;s:3:"130";i:1;s:2:"76";i:2;s:3:"353";i:3;s:3:"484";}}s:13:"guilsinglleft";a:4:{s:1:"C";s:3:"172";s:2:"WX";s:3:"333";s:1:"N";s:13:"guilsinglleft";s:1:"B";a:4:{i:0;s:3:"130";i:1;s:2:"76";i:2;s:3:"353";i:3;s:3:"484";}}i:173;a:4:{s:1:"C";s:3:"173";s:2:"WX";s:3:"333";s:1:"N";s:14:"guilsinglright";s:1:"B";a:4:{i:0;s:2:"99";i:1;s:2:"76";i:2;s:3:"322";i:3;s:3:"484";}}s:14:"guilsinglright";a:4:{s:1:"C";s:3:"173";s:2:"WX";s:3:"333";s:1:"N";s:14:"guilsinglright";s:1:"B";a:4:{i:0;s:2:"99";i:1;s:2:"76";i:2;s:3:"322";i:3;s:3:"484";}}i:174;a:4:{s:1:"C";s:3:"174";s:2:"WX";s:3:"611";s:1:"N";s:2:"fi";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:1:"0";i:2;s:3:"696";i:3;s:3:"727";}}s:2:"fi";a:4:{s:1:"C";s:3:"174";s:2:"WX";s:3:"611";s:1:"N";s:2:"fi";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:1:"0";i:2;s:3:"696";i:3;s:3:"727";}}i:175;a:4:{s:1:"C";s:3:"175";s:2:"WX";s:3:"611";s:1:"N";s:2:"fl";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:1:"0";i:2;s:3:"695";i:3;s:3:"727";}}s:2:"fl";a:4:{s:1:"C";s:3:"175";s:2:"WX";s:3:"611";s:1:"N";s:2:"fl";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:1:"0";i:2;s:3:"695";i:3;s:3:"727";}}i:177;a:4:{s:1:"C";s:3:"177";s:2:"WX";s:3:"556";s:1:"N";s:6:"endash";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:3:"227";i:2;s:3:"627";i:3;s:3:"333";}}s:6:"endash";a:4:{s:1:"C";s:3:"177";s:2:"WX";s:3:"556";s:1:"N";s:6:"endash";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:3:"227";i:2;s:3:"627";i:3;s:3:"333";}}i:178;a:4:{s:1:"C";s:3:"178";s:2:"WX";s:3:"556";s:1:"N";s:6:"dagger";s:1:"B";a:4:{i:0;s:3:"118";i:1;s:4:"-171";i:2;s:3:"626";i:3;s:3:"718";}}s:6:"dagger";a:4:{s:1:"C";s:3:"178";s:2:"WX";s:3:"556";s:1:"N";s:6:"dagger";s:1:"B";a:4:{i:0;s:3:"118";i:1;s:4:"-171";i:2;s:3:"626";i:3;s:3:"718";}}i:179;a:4:{s:1:"C";s:3:"179";s:2:"WX";s:3:"556";s:1:"N";s:9:"daggerdbl";s:1:"B";a:4:{i:0;s:2:"46";i:1;s:4:"-171";i:2;s:3:"628";i:3;s:3:"718";}}s:9:"daggerdbl";a:4:{s:1:"C";s:3:"179";s:2:"WX";s:3:"556";s:1:"N";s:9:"daggerdbl";s:1:"B";a:4:{i:0;s:2:"46";i:1;s:4:"-171";i:2;s:3:"628";i:3;s:3:"718";}}i:180;a:4:{s:1:"C";s:3:"180";s:2:"WX";s:3:"278";s:1:"N";s:14:"periodcentered";s:1:"B";a:4:{i:0;s:3:"110";i:1;s:3:"172";i:2;s:3:"276";i:3;s:3:"334";}}s:14:"periodcentered";a:4:{s:1:"C";s:3:"180";s:2:"WX";s:3:"278";s:1:"N";s:14:"periodcentered";s:1:"B";a:4:{i:0;s:3:"110";i:1;s:3:"172";i:2;s:3:"276";i:3;s:3:"334";}}i:182;a:4:{s:1:"C";s:3:"182";s:2:"WX";s:3:"556";s:1:"N";s:9:"paragraph";s:1:"B";a:4:{i:0;s:2:"98";i:1;s:4:"-191";i:2;s:3:"688";i:3;s:3:"700";}}s:9:"paragraph";a:4:{s:1:"C";s:3:"182";s:2:"WX";s:3:"556";s:1:"N";s:9:"paragraph";s:1:"B";a:4:{i:0;s:2:"98";i:1;s:4:"-191";i:2;s:3:"688";i:3;s:3:"700";}}i:183;a:4:{s:1:"C";s:3:"183";s:2:"WX";s:3:"350";s:1:"N";s:6:"bullet";s:1:"B";a:4:{i:0;s:2:"83";i:1;s:3:"194";i:2;s:3:"420";i:3;s:3:"524";}}s:6:"bullet";a:4:{s:1:"C";s:3:"183";s:2:"WX";s:3:"350";s:1:"N";s:6:"bullet";s:1:"B";a:4:{i:0;s:2:"83";i:1;s:3:"194";i:2;s:3:"420";i:3;s:3:"524";}}i:184;a:4:{s:1:"C";s:3:"184";s:2:"WX";s:3:"278";s:1:"N";s:14:"quotesinglbase";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:4:"-146";i:2;s:3:"236";i:3;s:3:"127";}}s:14:"quotesinglbase";a:4:{s:1:"C";s:3:"184";s:2:"WX";s:3:"278";s:1:"N";s:14:"quotesinglbase";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:4:"-146";i:2;s:3:"236";i:3;s:3:"127";}}i:185;a:4:{s:1:"C";s:3:"185";s:2:"WX";s:3:"500";s:1:"N";s:12:"quotedblbase";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:4:"-146";i:2;s:3:"463";i:3;s:3:"127";}}s:12:"quotedblbase";a:4:{s:1:"C";s:3:"185";s:2:"WX";s:3:"500";s:1:"N";s:12:"quotedblbase";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:4:"-146";i:2;s:3:"463";i:3;s:3:"127";}}i:186;a:4:{s:1:"C";s:3:"186";s:2:"WX";s:3:"500";s:1:"N";s:13:"quotedblright";s:1:"B";a:4:{i:0;s:3:"162";i:1;s:3:"445";i:2;s:3:"589";i:3;s:3:"718";}}s:13:"quotedblright";a:4:{s:1:"C";s:3:"186";s:2:"WX";s:3:"500";s:1:"N";s:13:"quotedblright";s:1:"B";a:4:{i:0;s:3:"162";i:1;s:3:"445";i:2;s:3:"589";i:3;s:3:"718";}}i:187;a:4:{s:1:"C";s:3:"187";s:2:"WX";s:3:"556";s:1:"N";s:14:"guillemotright";s:1:"B";a:4:{i:0;s:3:"104";i:1;s:2:"76";i:2;s:3:"540";i:3;s:3:"484";}}s:14:"guillemotright";a:4:{s:1:"C";s:3:"187";s:2:"WX";s:3:"556";s:1:"N";s:14:"guillemotright";s:1:"B";a:4:{i:0;s:3:"104";i:1;s:2:"76";i:2;s:3:"540";i:3;s:3:"484";}}i:188;a:4:{s:1:"C";s:3:"188";s:2:"WX";s:4:"1000";s:1:"N";s:8:"ellipsis";s:1:"B";a:4:{i:0;s:2:"92";i:1;s:1:"0";i:2;s:3:"939";i:3;s:3:"146";}}s:8:"ellipsis";a:4:{s:1:"C";s:3:"188";s:2:"WX";s:4:"1000";s:1:"N";s:8:"ellipsis";s:1:"B";a:4:{i:0;s:2:"92";i:1;s:1:"0";i:2;s:3:"939";i:3;s:3:"146";}}i:189;a:4:{s:1:"C";s:3:"189";s:2:"WX";s:4:"1000";s:1:"N";s:11:"perthousand";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:3:"-19";i:2;s:4:"1038";i:3;s:3:"710";}}s:11:"perthousand";a:4:{s:1:"C";s:3:"189";s:2:"WX";s:4:"1000";s:1:"N";s:11:"perthousand";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:3:"-19";i:2;s:4:"1038";i:3;s:3:"710";}}i:191;a:4:{s:1:"C";s:3:"191";s:2:"WX";s:3:"611";s:1:"N";s:12:"questiondown";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:4:"-195";i:2;s:3:"559";i:3;s:3:"532";}}s:12:"questiondown";a:4:{s:1:"C";s:3:"191";s:2:"WX";s:3:"611";s:1:"N";s:12:"questiondown";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:4:"-195";i:2;s:3:"559";i:3;s:3:"532";}}i:193;a:4:{s:1:"C";s:3:"193";s:2:"WX";s:3:"333";s:1:"N";s:5:"grave";s:1:"B";a:4:{i:0;s:3:"136";i:1;s:3:"604";i:2;s:3:"353";i:3;s:3:"750";}}s:5:"grave";a:4:{s:1:"C";s:3:"193";s:2:"WX";s:3:"333";s:1:"N";s:5:"grave";s:1:"B";a:4:{i:0;s:3:"136";i:1;s:3:"604";i:2;s:3:"353";i:3;s:3:"750";}}i:194;a:4:{s:1:"C";s:3:"194";s:2:"WX";s:3:"333";s:1:"N";s:5:"acute";s:1:"B";a:4:{i:0;s:3:"236";i:1;s:3:"604";i:2;s:3:"515";i:3;s:3:"750";}}s:5:"acute";a:4:{s:1:"C";s:3:"194";s:2:"WX";s:3:"333";s:1:"N";s:5:"acute";s:1:"B";a:4:{i:0;s:3:"236";i:1;s:3:"604";i:2;s:3:"515";i:3;s:3:"750";}}i:195;a:4:{s:1:"C";s:3:"195";s:2:"WX";s:3:"333";s:1:"N";s:10:"circumflex";s:1:"B";a:4:{i:0;s:3:"118";i:1;s:3:"604";i:2;s:3:"471";i:3;s:3:"750";}}s:10:"circumflex";a:4:{s:1:"C";s:3:"195";s:2:"WX";s:3:"333";s:1:"N";s:10:"circumflex";s:1:"B";a:4:{i:0;s:3:"118";i:1;s:3:"604";i:2;s:3:"471";i:3;s:3:"750";}}i:196;a:4:{s:1:"C";s:3:"196";s:2:"WX";s:3:"333";s:1:"N";s:5:"tilde";s:1:"B";a:4:{i:0;s:3:"113";i:1;s:3:"610";i:2;s:3:"507";i:3;s:3:"737";}}s:5:"tilde";a:4:{s:1:"C";s:3:"196";s:2:"WX";s:3:"333";s:1:"N";s:5:"tilde";s:1:"B";a:4:{i:0;s:3:"113";i:1;s:3:"610";i:2;s:3:"507";i:3;s:3:"737";}}i:197;a:4:{s:1:"C";s:3:"197";s:2:"WX";s:3:"333";s:1:"N";s:6:"macron";s:1:"B";a:4:{i:0;s:3:"122";i:1;s:3:"604";i:2;s:3:"483";i:3;s:3:"678";}}s:6:"macron";a:4:{s:1:"C";s:3:"197";s:2:"WX";s:3:"333";s:1:"N";s:6:"macron";s:1:"B";a:4:{i:0;s:3:"122";i:1;s:3:"604";i:2;s:3:"483";i:3;s:3:"678";}}i:198;a:4:{s:1:"C";s:3:"198";s:2:"WX";s:3:"333";s:1:"N";s:5:"breve";s:1:"B";a:4:{i:0;s:3:"156";i:1;s:3:"604";i:2;s:3:"494";i:3;s:3:"750";}}s:5:"breve";a:4:{s:1:"C";s:3:"198";s:2:"WX";s:3:"333";s:1:"N";s:5:"breve";s:1:"B";a:4:{i:0;s:3:"156";i:1;s:3:"604";i:2;s:3:"494";i:3;s:3:"750";}}i:199;a:4:{s:1:"C";s:3:"199";s:2:"WX";s:3:"333";s:1:"N";s:9:"dotaccent";s:1:"B";a:4:{i:0;s:3:"235";i:1;s:3:"614";i:2;s:3:"385";i:3;s:3:"729";}}s:9:"dotaccent";a:4:{s:1:"C";s:3:"199";s:2:"WX";s:3:"333";s:1:"N";s:9:"dotaccent";s:1:"B";a:4:{i:0;s:3:"235";i:1;s:3:"614";i:2;s:3:"385";i:3;s:3:"729";}}i:200;a:4:{s:1:"C";s:3:"200";s:2:"WX";s:3:"333";s:1:"N";s:8:"dieresis";s:1:"B";a:4:{i:0;s:3:"137";i:1;s:3:"614";i:2;s:3:"482";i:3;s:3:"729";}}s:8:"dieresis";a:4:{s:1:"C";s:3:"200";s:2:"WX";s:3:"333";s:1:"N";s:8:"dieresis";s:1:"B";a:4:{i:0;s:3:"137";i:1;s:3:"614";i:2;s:3:"482";i:3;s:3:"729";}}i:202;a:4:{s:1:"C";s:3:"202";s:2:"WX";s:3:"333";s:1:"N";s:4:"ring";s:1:"B";a:4:{i:0;s:3:"200";i:1;s:3:"568";i:2;s:3:"420";i:3;s:3:"776";}}s:4:"ring";a:4:{s:1:"C";s:3:"202";s:2:"WX";s:3:"333";s:1:"N";s:4:"ring";s:1:"B";a:4:{i:0;s:3:"200";i:1;s:3:"568";i:2;s:3:"420";i:3;s:3:"776";}}i:203;a:4:{s:1:"C";s:3:"203";s:2:"WX";s:3:"333";s:1:"N";s:7:"cedilla";s:1:"B";a:4:{i:0;s:3:"-37";i:1;s:4:"-228";i:2;s:3:"220";i:3;s:1:"0";}}s:7:"cedilla";a:4:{s:1:"C";s:3:"203";s:2:"WX";s:3:"333";s:1:"N";s:7:"cedilla";s:1:"B";a:4:{i:0;s:3:"-37";i:1;s:4:"-228";i:2;s:3:"220";i:3;s:1:"0";}}i:205;a:4:{s:1:"C";s:3:"205";s:2:"WX";s:3:"333";s:1:"N";s:12:"hungarumlaut";s:1:"B";a:4:{i:0;s:3:"137";i:1;s:3:"604";i:2;s:3:"645";i:3;s:3:"750";}}s:12:"hungarumlaut";a:4:{s:1:"C";s:3:"205";s:2:"WX";s:3:"333";s:1:"N";s:12:"hungarumlaut";s:1:"B";a:4:{i:0;s:3:"137";i:1;s:3:"604";i:2;s:3:"645";i:3;s:3:"750";}}i:206;a:4:{s:1:"C";s:3:"206";s:2:"WX";s:3:"333";s:1:"N";s:6:"ogonek";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:4:"-228";i:2;s:3:"264";i:3;s:1:"0";}}s:6:"ogonek";a:4:{s:1:"C";s:3:"206";s:2:"WX";s:3:"333";s:1:"N";s:6:"ogonek";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:4:"-228";i:2;s:3:"264";i:3;s:1:"0";}}i:207;a:4:{s:1:"C";s:3:"207";s:2:"WX";s:3:"333";s:1:"N";s:5:"caron";s:1:"B";a:4:{i:0;s:3:"149";i:1;s:3:"604";i:2;s:3:"502";i:3;s:3:"750";}}s:5:"caron";a:4:{s:1:"C";s:3:"207";s:2:"WX";s:3:"333";s:1:"N";s:5:"caron";s:1:"B";a:4:{i:0;s:3:"149";i:1;s:3:"604";i:2;s:3:"502";i:3;s:3:"750";}}i:208;a:4:{s:1:"C";s:3:"208";s:2:"WX";s:4:"1000";s:1:"N";s:6:"emdash";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:3:"227";i:2;s:4:"1071";i:3;s:3:"333";}}s:6:"emdash";a:4:{s:1:"C";s:3:"208";s:2:"WX";s:4:"1000";s:1:"N";s:6:"emdash";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:3:"227";i:2;s:4:"1071";i:3;s:3:"333";}}i:225;a:4:{s:1:"C";s:3:"225";s:2:"WX";s:4:"1000";s:1:"N";s:2:"AE";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:1:"0";i:2;s:4:"1100";i:3;s:3:"718";}}s:2:"AE";a:4:{s:1:"C";s:3:"225";s:2:"WX";s:4:"1000";s:1:"N";s:2:"AE";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:1:"0";i:2;s:4:"1100";i:3;s:3:"718";}}i:227;a:4:{s:1:"C";s:3:"227";s:2:"WX";s:3:"370";s:1:"N";s:11:"ordfeminine";s:1:"B";a:4:{i:0;s:3:"125";i:1;s:3:"401";i:2;s:3:"465";i:3;s:3:"737";}}s:11:"ordfeminine";a:4:{s:1:"C";s:3:"227";s:2:"WX";s:3:"370";s:1:"N";s:11:"ordfeminine";s:1:"B";a:4:{i:0;s:3:"125";i:1;s:3:"401";i:2;s:3:"465";i:3;s:3:"737";}}i:232;a:4:{s:1:"C";s:3:"232";s:2:"WX";s:3:"611";s:1:"N";s:6:"Lslash";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:1:"0";i:2;s:3:"611";i:3;s:3:"718";}}s:6:"Lslash";a:4:{s:1:"C";s:3:"232";s:2:"WX";s:3:"611";s:1:"N";s:6:"Lslash";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:1:"0";i:2;s:3:"611";i:3;s:3:"718";}}i:233;a:4:{s:1:"C";s:3:"233";s:2:"WX";s:3:"778";s:1:"N";s:6:"Oslash";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-27";i:2;s:3:"894";i:3;s:3:"745";}}s:6:"Oslash";a:4:{s:1:"C";s:3:"233";s:2:"WX";s:3:"778";s:1:"N";s:6:"Oslash";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-27";i:2;s:3:"894";i:3;s:3:"745";}}i:234;a:4:{s:1:"C";s:3:"234";s:2:"WX";s:4:"1000";s:1:"N";s:2:"OE";s:1:"B";a:4:{i:0;s:2:"99";i:1;s:3:"-19";i:2;s:4:"1114";i:3;s:3:"737";}}s:2:"OE";a:4:{s:1:"C";s:3:"234";s:2:"WX";s:4:"1000";s:1:"N";s:2:"OE";s:1:"B";a:4:{i:0;s:2:"99";i:1;s:3:"-19";i:2;s:4:"1114";i:3;s:3:"737";}}i:235;a:4:{s:1:"C";s:3:"235";s:2:"WX";s:3:"365";s:1:"N";s:12:"ordmasculine";s:1:"B";a:4:{i:0;s:3:"123";i:1;s:3:"401";i:2;s:3:"485";i:3;s:3:"737";}}s:12:"ordmasculine";a:4:{s:1:"C";s:3:"235";s:2:"WX";s:3:"365";s:1:"N";s:12:"ordmasculine";s:1:"B";a:4:{i:0;s:3:"123";i:1;s:3:"401";i:2;s:3:"485";i:3;s:3:"737";}}i:241;a:4:{s:1:"C";s:3:"241";s:2:"WX";s:3:"889";s:1:"N";s:2:"ae";s:1:"B";a:4:{i:0;s:2:"56";i:1;s:3:"-14";i:2;s:3:"923";i:3;s:3:"546";}}s:2:"ae";a:4:{s:1:"C";s:3:"241";s:2:"WX";s:3:"889";s:1:"N";s:2:"ae";s:1:"B";a:4:{i:0;s:2:"56";i:1;s:3:"-14";i:2;s:3:"923";i:3;s:3:"546";}}i:245;a:4:{s:1:"C";s:3:"245";s:2:"WX";s:3:"278";s:1:"N";s:8:"dotlessi";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"322";i:3;s:3:"532";}}s:8:"dotlessi";a:4:{s:1:"C";s:3:"245";s:2:"WX";s:3:"278";s:1:"N";s:8:"dotlessi";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"322";i:3;s:3:"532";}}i:248;a:4:{s:1:"C";s:3:"248";s:2:"WX";s:3:"278";s:1:"N";s:6:"lslash";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:1:"0";i:2;s:3:"407";i:3;s:3:"718";}}s:6:"lslash";a:4:{s:1:"C";s:3:"248";s:2:"WX";s:3:"278";s:1:"N";s:6:"lslash";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:1:"0";i:2;s:3:"407";i:3;s:3:"718";}}i:249;a:4:{s:1:"C";s:3:"249";s:2:"WX";s:3:"611";s:1:"N";s:6:"oslash";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-29";i:2;s:3:"701";i:3;s:3:"560";}}s:6:"oslash";a:4:{s:1:"C";s:3:"249";s:2:"WX";s:3:"611";s:1:"N";s:6:"oslash";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-29";i:2;s:3:"701";i:3;s:3:"560";}}i:250;a:4:{s:1:"C";s:3:"250";s:2:"WX";s:3:"944";s:1:"N";s:2:"oe";s:1:"B";a:4:{i:0;s:2:"82";i:1;s:3:"-14";i:2;s:3:"977";i:3;s:3:"546";}}s:2:"oe";a:4:{s:1:"C";s:3:"250";s:2:"WX";s:3:"944";s:1:"N";s:2:"oe";s:1:"B";a:4:{i:0;s:2:"82";i:1;s:3:"-14";i:2;s:3:"977";i:3;s:3:"546";}}i:251;a:4:{s:1:"C";s:3:"251";s:2:"WX";s:3:"611";s:1:"N";s:10:"germandbls";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:3:"-14";i:2;s:3:"657";i:3;s:3:"731";}}s:10:"germandbls";a:4:{s:1:"C";s:3:"251";s:2:"WX";s:3:"611";s:1:"N";s:10:"germandbls";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:3:"-14";i:2;s:3:"657";i:3;s:3:"731";}}s:9:"Idieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:9:"Idieresis";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:1:"0";i:2;s:3:"494";i:3;s:3:"915";}}s:6:"eacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"eacute";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:3:"-14";i:2;s:3:"627";i:3;s:3:"750";}}s:6:"abreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"abreve";s:1:"B";a:4:{i:0;s:2:"55";i:1;s:3:"-14";i:2;s:3:"606";i:3;s:3:"750";}}s:13:"uhungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:13:"uhungarumlaut";s:1:"B";a:4:{i:0;s:2:"98";i:1;s:3:"-14";i:2;s:3:"784";i:3;s:3:"750";}}s:6:"ecaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"ecaron";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:3:"-14";i:2;s:3:"614";i:3;s:3:"750";}}s:9:"Ydieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:9:"Ydieresis";s:1:"B";a:4:{i:0;s:3:"168";i:1;s:1:"0";i:2;s:3:"806";i:3;s:3:"915";}}s:6:"divide";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"584";s:1:"N";s:6:"divide";s:1:"B";a:4:{i:0;s:2:"82";i:1;s:3:"-42";i:2;s:3:"610";i:3;s:3:"548";}}s:6:"Yacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Yacute";s:1:"B";a:4:{i:0;s:3:"168";i:1;s:1:"0";i:2;s:3:"806";i:3;s:3:"936";}}s:11:"Acircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:11:"Acircumflex";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"706";i:3;s:3:"936";}}s:6:"aacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"aacute";s:1:"B";a:4:{i:0;s:2:"55";i:1;s:3:"-14";i:2;s:3:"627";i:3;s:3:"750";}}s:11:"Ucircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:11:"Ucircumflex";s:1:"B";a:4:{i:0;s:3:"116";i:1;s:3:"-19";i:2;s:3:"804";i:3;s:3:"936";}}s:6:"yacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"yacute";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:4:"-214";i:2;s:3:"652";i:3;s:3:"750";}}s:12:"scommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:12:"scommaaccent";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:4:"-228";i:2;s:3:"584";i:3;s:3:"546";}}s:11:"ecircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:11:"ecircumflex";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:3:"-14";i:2;s:3:"593";i:3;s:3:"750";}}s:5:"Uring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:5:"Uring";s:1:"B";a:4:{i:0;s:3:"116";i:1;s:3:"-19";i:2;s:3:"804";i:3;s:3:"962";}}s:9:"Udieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:9:"Udieresis";s:1:"B";a:4:{i:0;s:3:"116";i:1;s:3:"-19";i:2;s:3:"804";i:3;s:3:"915";}}s:7:"aogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:7:"aogonek";s:1:"B";a:4:{i:0;s:2:"55";i:1;s:4:"-224";i:2;s:3:"583";i:3;s:3:"546";}}s:6:"Uacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Uacute";s:1:"B";a:4:{i:0;s:3:"116";i:1;s:3:"-19";i:2;s:3:"804";i:3;s:3:"936";}}s:7:"uogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:7:"uogonek";s:1:"B";a:4:{i:0;s:2:"98";i:1;s:4:"-228";i:2;s:3:"658";i:3;s:3:"532";}}s:9:"Edieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:9:"Edieresis";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"757";i:3;s:3:"915";}}s:6:"Dcroat";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Dcroat";s:1:"B";a:4:{i:0;s:2:"62";i:1;s:1:"0";i:2;s:3:"777";i:3;s:3:"718";}}s:11:"commaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"250";s:1:"N";s:11:"commaaccent";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:4:"-228";i:2;s:3:"188";i:3;s:3:"-50";}}s:9:"copyright";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"737";s:1:"N";s:9:"copyright";s:1:"B";a:4:{i:0;s:2:"56";i:1;s:3:"-19";i:2;s:3:"835";i:3;s:3:"737";}}s:7:"Emacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:7:"Emacron";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"757";i:3;s:3:"864";}}s:6:"ccaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"ccaron";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:3:"-14";i:2;s:3:"614";i:3;s:3:"750";}}s:5:"aring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:5:"aring";s:1:"B";a:4:{i:0;s:2:"55";i:1;s:3:"-14";i:2;s:3:"583";i:3;s:3:"776";}}s:12:"Ncommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:12:"Ncommaaccent";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:4:"-228";i:2;s:3:"807";i:3;s:3:"718";}}s:6:"lacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:6:"lacute";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"528";i:3;s:3:"936";}}s:6:"agrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"agrave";s:1:"B";a:4:{i:0;s:2:"55";i:1;s:3:"-14";i:2;s:3:"583";i:3;s:3:"750";}}s:12:"Tcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:12:"Tcommaaccent";s:1:"B";a:4:{i:0;s:3:"140";i:1;s:4:"-228";i:2;s:3:"751";i:3;s:3:"718";}}s:6:"Cacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Cacute";s:1:"B";a:4:{i:0;s:3:"107";i:1;s:3:"-19";i:2;s:3:"789";i:3;s:3:"936";}}s:6:"atilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"atilde";s:1:"B";a:4:{i:0;s:2:"55";i:1;s:3:"-14";i:2;s:3:"619";i:3;s:3:"737";}}s:10:"Edotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:10:"Edotaccent";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"757";i:3;s:3:"915";}}s:6:"scaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"scaron";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:3:"-14";i:2;s:3:"614";i:3;s:3:"750";}}s:8:"scedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:8:"scedilla";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:4:"-228";i:2;s:3:"584";i:3;s:3:"546";}}s:6:"iacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:6:"iacute";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"488";i:3;s:3:"750";}}s:7:"lozenge";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"494";s:1:"N";s:7:"lozenge";s:1:"B";a:4:{i:0;s:2:"90";i:1;s:1:"0";i:2;s:3:"564";i:3;s:3:"745";}}s:6:"Rcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Rcaron";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"778";i:3;s:3:"936";}}s:12:"Gcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:12:"Gcommaaccent";s:1:"B";a:4:{i:0;s:3:"108";i:1;s:4:"-228";i:2;s:3:"817";i:3;s:3:"737";}}s:11:"ucircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:11:"ucircumflex";s:1:"B";a:4:{i:0;s:2:"98";i:1;s:3:"-14";i:2;s:3:"658";i:3;s:3:"750";}}s:11:"acircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:11:"acircumflex";s:1:"B";a:4:{i:0;s:2:"55";i:1;s:3:"-14";i:2;s:3:"583";i:3;s:3:"750";}}s:7:"Amacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:7:"Amacron";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"718";i:3;s:3:"864";}}s:6:"rcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:6:"rcaron";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:1:"0";i:2;s:3:"530";i:3;s:3:"750";}}s:8:"ccedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:8:"ccedilla";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:4:"-228";i:2;s:3:"599";i:3;s:3:"546";}}s:10:"Zdotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:10:"Zdotaccent";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"737";i:3;s:3:"915";}}s:5:"Thorn";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:5:"Thorn";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"716";i:3;s:3:"718";}}s:7:"Omacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:7:"Omacron";s:1:"B";a:4:{i:0;s:3:"107";i:1;s:3:"-19";i:2;s:3:"823";i:3;s:3:"864";}}s:6:"Racute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Racute";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"778";i:3;s:3:"936";}}s:6:"Sacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Sacute";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:3:"-19";i:2;s:3:"722";i:3;s:3:"936";}}s:6:"dcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"743";s:1:"N";s:6:"dcaron";s:1:"B";a:4:{i:0;s:2:"82";i:1;s:3:"-14";i:2;s:3:"903";i:3;s:3:"718";}}s:7:"Umacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:7:"Umacron";s:1:"B";a:4:{i:0;s:3:"116";i:1;s:3:"-19";i:2;s:3:"804";i:3;s:3:"864";}}s:5:"uring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:5:"uring";s:1:"B";a:4:{i:0;s:2:"98";i:1;s:3:"-14";i:2;s:3:"658";i:3;s:3:"776";}}s:13:"threesuperior";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"333";s:1:"N";s:13:"threesuperior";s:1:"B";a:4:{i:0;s:2:"91";i:1;s:3:"271";i:2;s:3:"441";i:3;s:3:"710";}}s:6:"Ograve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:6:"Ograve";s:1:"B";a:4:{i:0;s:3:"107";i:1;s:3:"-19";i:2;s:3:"823";i:3;s:3:"936";}}s:6:"Agrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Agrave";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"702";i:3;s:3:"936";}}s:6:"Abreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Abreve";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"729";i:3;s:3:"936";}}s:8:"multiply";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"584";s:1:"N";s:8:"multiply";s:1:"B";a:4:{i:0;s:2:"57";i:1;s:1:"1";i:2;s:3:"635";i:3;s:3:"505";}}s:6:"uacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"uacute";s:1:"B";a:4:{i:0;s:2:"98";i:1;s:3:"-14";i:2;s:3:"658";i:3;s:3:"750";}}s:6:"Tcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"Tcaron";s:1:"B";a:4:{i:0;s:3:"140";i:1;s:1:"0";i:2;s:3:"751";i:3;s:3:"936";}}s:11:"partialdiff";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"494";s:1:"N";s:11:"partialdiff";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:3:"-21";i:2;s:3:"585";i:3;s:3:"750";}}s:9:"ydieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:9:"ydieresis";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:4:"-214";i:2;s:3:"652";i:3;s:3:"729";}}s:6:"Nacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Nacute";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"807";i:3;s:3:"936";}}s:11:"icircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:11:"icircumflex";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"444";i:3;s:3:"750";}}s:11:"Ecircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:11:"Ecircumflex";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"757";i:3;s:3:"936";}}s:9:"adieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:9:"adieresis";s:1:"B";a:4:{i:0;s:2:"55";i:1;s:3:"-14";i:2;s:3:"594";i:3;s:3:"729";}}s:9:"edieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:9:"edieresis";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:3:"-14";i:2;s:3:"594";i:3;s:3:"729";}}s:6:"cacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"cacute";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:3:"-14";i:2;s:3:"627";i:3;s:3:"750";}}s:6:"nacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"nacute";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:1:"0";i:2;s:3:"654";i:3;s:3:"750";}}s:7:"umacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:7:"umacron";s:1:"B";a:4:{i:0;s:2:"98";i:1;s:3:"-14";i:2;s:3:"658";i:3;s:3:"678";}}s:6:"Ncaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Ncaron";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"807";i:3;s:3:"936";}}s:6:"Iacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:6:"Iacute";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:1:"0";i:2;s:3:"528";i:3;s:3:"936";}}s:9:"plusminus";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"584";s:1:"N";s:9:"plusminus";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:1:"0";i:2;s:3:"625";i:3;s:3:"506";}}s:9:"brokenbar";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"280";s:1:"N";s:9:"brokenbar";s:1:"B";a:4:{i:0;s:2:"52";i:1;s:4:"-150";i:2;s:3:"345";i:3;s:3:"700";}}s:10:"registered";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"737";s:1:"N";s:10:"registered";s:1:"B";a:4:{i:0;s:2:"55";i:1;s:3:"-19";i:2;s:3:"834";i:3;s:3:"737";}}s:6:"Gbreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:6:"Gbreve";s:1:"B";a:4:{i:0;s:3:"108";i:1;s:3:"-19";i:2;s:3:"817";i:3;s:3:"936";}}s:10:"Idotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:10:"Idotaccent";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:1:"0";i:2;s:3:"397";i:3;s:3:"915";}}s:9:"summation";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"summation";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:3:"-10";i:2;s:3:"670";i:3;s:3:"706";}}s:6:"Egrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Egrave";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"757";i:3;s:3:"936";}}s:6:"racute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:6:"racute";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:1:"0";i:2;s:3:"543";i:3;s:3:"750";}}s:7:"omacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:7:"omacron";s:1:"B";a:4:{i:0;s:2:"82";i:1;s:3:"-14";i:2;s:3:"643";i:3;s:3:"678";}}s:6:"Zacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"Zacute";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"737";i:3;s:3:"936";}}s:6:"Zcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"Zcaron";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"737";i:3;s:3:"936";}}s:12:"greaterequal";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"549";s:1:"N";s:12:"greaterequal";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"629";i:3;s:3:"704";}}s:3:"Eth";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:3:"Eth";s:1:"B";a:4:{i:0;s:2:"62";i:1;s:1:"0";i:2;s:3:"777";i:3;s:3:"718";}}s:8:"Ccedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:8:"Ccedilla";s:1:"B";a:4:{i:0;s:3:"107";i:1;s:4:"-228";i:2;s:3:"789";i:3;s:3:"737";}}s:12:"lcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:12:"lcommaaccent";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:4:"-228";i:2;s:3:"362";i:3;s:3:"718";}}s:6:"tcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:6:"tcaron";s:1:"B";a:4:{i:0;s:3:"100";i:1;s:2:"-6";i:2;s:3:"608";i:3;s:3:"878";}}s:7:"eogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:7:"eogonek";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:4:"-228";i:2;s:3:"593";i:3;s:3:"546";}}s:7:"Uogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:7:"Uogonek";s:1:"B";a:4:{i:0;s:3:"116";i:1;s:4:"-228";i:2;s:3:"804";i:3;s:3:"718";}}s:6:"Aacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Aacute";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"750";i:3;s:3:"936";}}s:9:"Adieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:9:"Adieresis";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"716";i:3;s:3:"915";}}s:6:"egrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"egrave";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:3:"-14";i:2;s:3:"593";i:3;s:3:"750";}}s:6:"zacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"zacute";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"599";i:3;s:3:"750";}}s:7:"iogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:7:"iogonek";s:1:"B";a:4:{i:0;s:3:"-14";i:1;s:4:"-224";i:2;s:3:"363";i:3;s:3:"725";}}s:6:"Oacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:6:"Oacute";s:1:"B";a:4:{i:0;s:3:"107";i:1;s:3:"-19";i:2;s:3:"823";i:3;s:3:"936";}}s:6:"oacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"oacute";s:1:"B";a:4:{i:0;s:2:"82";i:1;s:3:"-14";i:2;s:3:"654";i:3;s:3:"750";}}s:7:"amacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:7:"amacron";s:1:"B";a:4:{i:0;s:2:"55";i:1;s:3:"-14";i:2;s:3:"595";i:3;s:3:"678";}}s:6:"sacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"sacute";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:3:"-14";i:2;s:3:"627";i:3;s:3:"750";}}s:9:"idieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:9:"idieresis";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"455";i:3;s:3:"729";}}s:11:"Ocircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:11:"Ocircumflex";s:1:"B";a:4:{i:0;s:3:"107";i:1;s:3:"-19";i:2;s:3:"823";i:3;s:3:"936";}}s:6:"Ugrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Ugrave";s:1:"B";a:4:{i:0;s:3:"116";i:1;s:3:"-19";i:2;s:3:"804";i:3;s:3:"936";}}s:5:"Delta";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"612";s:1:"N";s:5:"Delta";s:1:"B";a:4:{i:0;s:1:"6";i:1;s:1:"0";i:2;s:3:"608";i:3;s:3:"688";}}s:5:"thorn";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:5:"thorn";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:4:"-208";i:2;s:3:"645";i:3;s:3:"718";}}s:11:"twosuperior";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"333";s:1:"N";s:11:"twosuperior";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:3:"283";i:2;s:3:"449";i:3;s:3:"710";}}s:9:"Odieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:9:"Odieresis";s:1:"B";a:4:{i:0;s:3:"107";i:1;s:3:"-19";i:2;s:3:"823";i:3;s:3:"915";}}s:2:"mu";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:2:"mu";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:4:"-207";i:2;s:3:"658";i:3;s:3:"532";}}s:6:"igrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:6:"igrave";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"326";i:3;s:3:"750";}}s:13:"ohungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:13:"ohungarumlaut";s:1:"B";a:4:{i:0;s:2:"82";i:1;s:3:"-14";i:2;s:3:"784";i:3;s:3:"750";}}s:7:"Eogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:7:"Eogonek";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:4:"-224";i:2;s:3:"757";i:3;s:3:"718";}}s:6:"dcroat";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"dcroat";s:1:"B";a:4:{i:0;s:2:"82";i:1;s:3:"-14";i:2;s:3:"789";i:3;s:3:"718";}}s:13:"threequarters";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"834";s:1:"N";s:13:"threequarters";s:1:"B";a:4:{i:0;s:2:"99";i:1;s:3:"-19";i:2;s:3:"839";i:3;s:3:"710";}}s:8:"Scedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:8:"Scedilla";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:4:"-228";i:2;s:3:"718";i:3;s:3:"737";}}s:6:"lcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"400";s:1:"N";s:6:"lcaron";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"561";i:3;s:3:"718";}}s:12:"Kcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:12:"Kcommaaccent";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:4:"-228";i:2;s:3:"858";i:3;s:3:"718";}}s:6:"Lacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"Lacute";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"611";i:3;s:3:"936";}}s:9:"trademark";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:4:"1000";s:1:"N";s:9:"trademark";s:1:"B";a:4:{i:0;s:3:"179";i:1;s:3:"306";i:2;s:4:"1109";i:3;s:3:"718";}}s:10:"edotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:10:"edotaccent";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:3:"-14";i:2;s:3:"593";i:3;s:3:"729";}}s:6:"Igrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:6:"Igrave";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:1:"0";i:2;s:3:"367";i:3;s:3:"936";}}s:7:"Imacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:7:"Imacron";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:1:"0";i:2;s:3:"496";i:3;s:3:"864";}}s:6:"Lcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"Lcaron";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"643";i:3;s:3:"718";}}s:7:"onehalf";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"834";s:1:"N";s:7:"onehalf";s:1:"B";a:4:{i:0;s:3:"132";i:1;s:3:"-19";i:2;s:3:"858";i:3;s:3:"710";}}s:9:"lessequal";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"549";s:1:"N";s:9:"lessequal";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:1:"0";i:2;s:3:"676";i:3;s:3:"704";}}s:11:"ocircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:11:"ocircumflex";s:1:"B";a:4:{i:0;s:2:"82";i:1;s:3:"-14";i:2;s:3:"643";i:3;s:3:"750";}}s:6:"ntilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"ntilde";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:1:"0";i:2;s:3:"646";i:3;s:3:"737";}}s:13:"Uhungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:13:"Uhungarumlaut";s:1:"B";a:4:{i:0;s:3:"116";i:1;s:3:"-19";i:2;s:3:"880";i:3;s:3:"936";}}s:6:"Eacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Eacute";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"757";i:3;s:3:"936";}}s:7:"emacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:7:"emacron";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:3:"-14";i:2;s:3:"595";i:3;s:3:"678";}}s:6:"gbreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"gbreve";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:4:"-217";i:2;s:3:"666";i:3;s:3:"750";}}s:10:"onequarter";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"834";s:1:"N";s:10:"onequarter";s:1:"B";a:4:{i:0;s:3:"132";i:1;s:3:"-19";i:2;s:3:"806";i:3;s:3:"710";}}s:6:"Scaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Scaron";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:3:"-19";i:2;s:3:"718";i:3;s:3:"936";}}s:12:"Scommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:12:"Scommaaccent";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:4:"-228";i:2;s:3:"718";i:3;s:3:"737";}}s:13:"Ohungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:13:"Ohungarumlaut";s:1:"B";a:4:{i:0;s:3:"107";i:1;s:3:"-19";i:2;s:3:"908";i:3;s:3:"936";}}s:6:"degree";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"400";s:1:"N";s:6:"degree";s:1:"B";a:4:{i:0;s:3:"175";i:1;s:3:"426";i:2;s:3:"467";i:3;s:3:"712";}}s:6:"ograve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"ograve";s:1:"B";a:4:{i:0;s:2:"82";i:1;s:3:"-14";i:2;s:3:"643";i:3;s:3:"750";}}s:6:"Ccaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Ccaron";s:1:"B";a:4:{i:0;s:3:"107";i:1;s:3:"-19";i:2;s:3:"789";i:3;s:3:"936";}}s:6:"ugrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"ugrave";s:1:"B";a:4:{i:0;s:2:"98";i:1;s:3:"-14";i:2;s:3:"658";i:3;s:3:"750";}}s:7:"radical";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"549";s:1:"N";s:7:"radical";s:1:"B";a:4:{i:0;s:3:"112";i:1;s:3:"-46";i:2;s:3:"689";i:3;s:3:"850";}}s:6:"Dcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Dcaron";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"777";i:3;s:3:"936";}}s:12:"rcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:12:"rcommaaccent";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:4:"-228";i:2;s:3:"489";i:3;s:3:"546";}}s:6:"Ntilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Ntilde";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"807";i:3;s:3:"923";}}s:6:"otilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"otilde";s:1:"B";a:4:{i:0;s:2:"82";i:1;s:3:"-14";i:2;s:3:"646";i:3;s:3:"737";}}s:12:"Rcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:12:"Rcommaaccent";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:4:"-228";i:2;s:3:"778";i:3;s:3:"718";}}s:12:"Lcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:12:"Lcommaaccent";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:4:"-228";i:2;s:3:"611";i:3;s:3:"718";}}s:6:"Atilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Atilde";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"741";i:3;s:3:"923";}}s:7:"Aogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:7:"Aogonek";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:4:"-224";i:2;s:3:"702";i:3;s:3:"718";}}s:5:"Aring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:5:"Aring";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"702";i:3;s:3:"962";}}s:6:"Otilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:6:"Otilde";s:1:"B";a:4:{i:0;s:3:"107";i:1;s:3:"-19";i:2;s:3:"823";i:3;s:3:"923";}}s:10:"zdotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:10:"zdotaccent";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"583";i:3;s:3:"729";}}s:6:"Ecaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Ecaron";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"757";i:3;s:3:"936";}}s:7:"Iogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:7:"Iogonek";s:1:"B";a:4:{i:0;s:3:"-41";i:1;s:4:"-228";i:2;s:3:"367";i:3;s:3:"718";}}s:12:"kcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:12:"kcommaaccent";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:4:"-228";i:2;s:3:"670";i:3;s:3:"718";}}s:5:"minus";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"584";s:1:"N";s:5:"minus";s:1:"B";a:4:{i:0;s:2:"82";i:1;s:3:"197";i:2;s:3:"610";i:3;s:3:"309";}}s:11:"Icircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:11:"Icircumflex";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:1:"0";i:2;s:3:"484";i:3;s:3:"936";}}s:6:"ncaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"ncaron";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:1:"0";i:2;s:3:"641";i:3;s:3:"750";}}s:12:"tcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"333";s:1:"N";s:12:"tcommaaccent";s:1:"B";a:4:{i:0;s:2:"58";i:1;s:4:"-228";i:2;s:3:"422";i:3;s:3:"676";}}s:10:"logicalnot";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"584";s:1:"N";s:10:"logicalnot";s:1:"B";a:4:{i:0;s:3:"105";i:1;s:3:"108";i:2;s:3:"633";i:3;s:3:"419";}}s:9:"odieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:9:"odieresis";s:1:"B";a:4:{i:0;s:2:"82";i:1;s:3:"-14";i:2;s:3:"643";i:3;s:3:"729";}}s:9:"udieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:9:"udieresis";s:1:"B";a:4:{i:0;s:2:"98";i:1;s:3:"-14";i:2;s:3:"658";i:3;s:3:"729";}}s:8:"notequal";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"549";s:1:"N";s:8:"notequal";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:3:"-49";i:2;s:3:"630";i:3;s:3:"570";}}s:12:"gcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:12:"gcommaaccent";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:4:"-217";i:2;s:3:"666";i:3;s:3:"850";}}s:3:"eth";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:3:"eth";s:1:"B";a:4:{i:0;s:2:"82";i:1;s:3:"-14";i:2;s:3:"670";i:3;s:3:"737";}}s:6:"zcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"zcaron";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"586";i:3;s:3:"750";}}s:12:"ncommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:12:"ncommaaccent";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:4:"-228";i:2;s:3:"629";i:3;s:3:"546";}}s:11:"onesuperior";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"333";s:1:"N";s:11:"onesuperior";s:1:"B";a:4:{i:0;s:3:"148";i:1;s:3:"283";i:2;s:3:"388";i:3;s:3:"710";}}s:7:"imacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:7:"imacron";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"429";i:3;s:3:"678";}}s:4:"Euro";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:4:"Euro";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}}s:3:"KPX";a:134:{s:1:"A";a:48:{s:1:"C";s:3:"-40";s:6:"Cacute";s:3:"-40";s:6:"Ccaron";s:3:"-40";s:8:"Ccedilla";s:3:"-40";s:1:"G";s:3:"-50";s:6:"Gbreve";s:3:"-50";s:12:"Gcommaaccent";s:3:"-50";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"Q";s:3:"-40";s:1:"T";s:3:"-90";s:6:"Tcaron";s:3:"-90";s:12:"Tcommaaccent";s:3:"-90";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-80";s:1:"W";s:3:"-60";s:1:"Y";s:4:"-110";s:6:"Yacute";s:4:"-110";s:9:"Ydieresis";s:4:"-110";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-40";s:1:"w";s:3:"-30";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:6:"Aacute";a:48:{s:1:"C";s:3:"-40";s:6:"Cacute";s:3:"-40";s:6:"Ccaron";s:3:"-40";s:8:"Ccedilla";s:3:"-40";s:1:"G";s:3:"-50";s:6:"Gbreve";s:3:"-50";s:12:"Gcommaaccent";s:3:"-50";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"Q";s:3:"-40";s:1:"T";s:3:"-90";s:6:"Tcaron";s:3:"-90";s:12:"Tcommaaccent";s:3:"-90";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-80";s:1:"W";s:3:"-60";s:1:"Y";s:4:"-110";s:6:"Yacute";s:4:"-110";s:9:"Ydieresis";s:4:"-110";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-40";s:1:"w";s:3:"-30";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:6:"Abreve";a:48:{s:1:"C";s:3:"-40";s:6:"Cacute";s:3:"-40";s:6:"Ccaron";s:3:"-40";s:8:"Ccedilla";s:3:"-40";s:1:"G";s:3:"-50";s:6:"Gbreve";s:3:"-50";s:12:"Gcommaaccent";s:3:"-50";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"Q";s:3:"-40";s:1:"T";s:3:"-90";s:6:"Tcaron";s:3:"-90";s:12:"Tcommaaccent";s:3:"-90";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-80";s:1:"W";s:3:"-60";s:1:"Y";s:4:"-110";s:6:"Yacute";s:4:"-110";s:9:"Ydieresis";s:4:"-110";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-40";s:1:"w";s:3:"-30";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:11:"Acircumflex";a:48:{s:1:"C";s:3:"-40";s:6:"Cacute";s:3:"-40";s:6:"Ccaron";s:3:"-40";s:8:"Ccedilla";s:3:"-40";s:1:"G";s:3:"-50";s:6:"Gbreve";s:3:"-50";s:12:"Gcommaaccent";s:3:"-50";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"Q";s:3:"-40";s:1:"T";s:3:"-90";s:6:"Tcaron";s:3:"-90";s:12:"Tcommaaccent";s:3:"-90";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-80";s:1:"W";s:3:"-60";s:1:"Y";s:4:"-110";s:6:"Yacute";s:4:"-110";s:9:"Ydieresis";s:4:"-110";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-40";s:1:"w";s:3:"-30";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:9:"Adieresis";a:48:{s:1:"C";s:3:"-40";s:6:"Cacute";s:3:"-40";s:6:"Ccaron";s:3:"-40";s:8:"Ccedilla";s:3:"-40";s:1:"G";s:3:"-50";s:6:"Gbreve";s:3:"-50";s:12:"Gcommaaccent";s:3:"-50";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"Q";s:3:"-40";s:1:"T";s:3:"-90";s:6:"Tcaron";s:3:"-90";s:12:"Tcommaaccent";s:3:"-90";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-80";s:1:"W";s:3:"-60";s:1:"Y";s:4:"-110";s:6:"Yacute";s:4:"-110";s:9:"Ydieresis";s:4:"-110";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-40";s:1:"w";s:3:"-30";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:6:"Agrave";a:48:{s:1:"C";s:3:"-40";s:6:"Cacute";s:3:"-40";s:6:"Ccaron";s:3:"-40";s:8:"Ccedilla";s:3:"-40";s:1:"G";s:3:"-50";s:6:"Gbreve";s:3:"-50";s:12:"Gcommaaccent";s:3:"-50";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"Q";s:3:"-40";s:1:"T";s:3:"-90";s:6:"Tcaron";s:3:"-90";s:12:"Tcommaaccent";s:3:"-90";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-80";s:1:"W";s:3:"-60";s:1:"Y";s:4:"-110";s:6:"Yacute";s:4:"-110";s:9:"Ydieresis";s:4:"-110";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-40";s:1:"w";s:3:"-30";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:7:"Amacron";a:48:{s:1:"C";s:3:"-40";s:6:"Cacute";s:3:"-40";s:6:"Ccaron";s:3:"-40";s:8:"Ccedilla";s:3:"-40";s:1:"G";s:3:"-50";s:6:"Gbreve";s:3:"-50";s:12:"Gcommaaccent";s:3:"-50";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"Q";s:3:"-40";s:1:"T";s:3:"-90";s:6:"Tcaron";s:3:"-90";s:12:"Tcommaaccent";s:3:"-90";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-80";s:1:"W";s:3:"-60";s:1:"Y";s:4:"-110";s:6:"Yacute";s:4:"-110";s:9:"Ydieresis";s:4:"-110";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-40";s:1:"w";s:3:"-30";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:7:"Aogonek";a:48:{s:1:"C";s:3:"-40";s:6:"Cacute";s:3:"-40";s:6:"Ccaron";s:3:"-40";s:8:"Ccedilla";s:3:"-40";s:1:"G";s:3:"-50";s:6:"Gbreve";s:3:"-50";s:12:"Gcommaaccent";s:3:"-50";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"Q";s:3:"-40";s:1:"T";s:3:"-90";s:6:"Tcaron";s:3:"-90";s:12:"Tcommaaccent";s:3:"-90";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-80";s:1:"W";s:3:"-60";s:1:"Y";s:4:"-110";s:6:"Yacute";s:4:"-110";s:9:"Ydieresis";s:4:"-110";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-40";s:1:"w";s:3:"-30";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:5:"Aring";a:48:{s:1:"C";s:3:"-40";s:6:"Cacute";s:3:"-40";s:6:"Ccaron";s:3:"-40";s:8:"Ccedilla";s:3:"-40";s:1:"G";s:3:"-50";s:6:"Gbreve";s:3:"-50";s:12:"Gcommaaccent";s:3:"-50";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"Q";s:3:"-40";s:1:"T";s:3:"-90";s:6:"Tcaron";s:3:"-90";s:12:"Tcommaaccent";s:3:"-90";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-80";s:1:"W";s:3:"-60";s:1:"Y";s:4:"-110";s:6:"Yacute";s:4:"-110";s:9:"Ydieresis";s:4:"-110";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-40";s:1:"w";s:3:"-30";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:6:"Atilde";a:48:{s:1:"C";s:3:"-40";s:6:"Cacute";s:3:"-40";s:6:"Ccaron";s:3:"-40";s:8:"Ccedilla";s:3:"-40";s:1:"G";s:3:"-50";s:6:"Gbreve";s:3:"-50";s:12:"Gcommaaccent";s:3:"-50";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"Q";s:3:"-40";s:1:"T";s:3:"-90";s:6:"Tcaron";s:3:"-90";s:12:"Tcommaaccent";s:3:"-90";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-80";s:1:"W";s:3:"-60";s:1:"Y";s:4:"-110";s:6:"Yacute";s:4:"-110";s:9:"Ydieresis";s:4:"-110";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-40";s:1:"w";s:3:"-30";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:1:"B";a:19:{s:1:"A";s:3:"-30";s:6:"Aacute";s:3:"-30";s:6:"Abreve";s:3:"-30";s:11:"Acircumflex";s:3:"-30";s:9:"Adieresis";s:3:"-30";s:6:"Agrave";s:3:"-30";s:7:"Amacron";s:3:"-30";s:7:"Aogonek";s:3:"-30";s:5:"Aring";s:3:"-30";s:6:"Atilde";s:3:"-30";s:1:"U";s:3:"-10";s:6:"Uacute";s:3:"-10";s:11:"Ucircumflex";s:3:"-10";s:9:"Udieresis";s:3:"-10";s:6:"Ugrave";s:3:"-10";s:13:"Uhungarumlaut";s:3:"-10";s:7:"Umacron";s:3:"-10";s:7:"Uogonek";s:3:"-10";s:5:"Uring";s:3:"-10";}s:1:"D";a:17:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:1:"V";s:3:"-40";s:1:"W";s:3:"-40";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-30";s:6:"period";s:3:"-30";}s:6:"Dcaron";a:17:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:1:"V";s:3:"-40";s:1:"W";s:3:"-40";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-30";s:6:"period";s:3:"-30";}s:6:"Dcroat";a:17:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:1:"V";s:3:"-40";s:1:"W";s:3:"-40";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-30";s:6:"period";s:3:"-30";}s:1:"F";a:22:{s:1:"A";s:3:"-80";s:6:"Aacute";s:3:"-80";s:6:"Abreve";s:3:"-80";s:11:"Acircumflex";s:3:"-80";s:9:"Adieresis";s:3:"-80";s:6:"Agrave";s:3:"-80";s:7:"Amacron";s:3:"-80";s:7:"Aogonek";s:3:"-80";s:5:"Aring";s:3:"-80";s:6:"Atilde";s:3:"-80";s:1:"a";s:3:"-20";s:6:"aacute";s:3:"-20";s:6:"abreve";s:3:"-20";s:11:"acircumflex";s:3:"-20";s:9:"adieresis";s:3:"-20";s:6:"agrave";s:3:"-20";s:7:"amacron";s:3:"-20";s:7:"aogonek";s:3:"-20";s:5:"aring";s:3:"-20";s:6:"atilde";s:3:"-20";s:5:"comma";s:4:"-100";s:6:"period";s:4:"-100";}s:1:"J";a:21:{s:1:"A";s:3:"-20";s:6:"Aacute";s:3:"-20";s:6:"Abreve";s:3:"-20";s:11:"Acircumflex";s:3:"-20";s:9:"Adieresis";s:3:"-20";s:6:"Agrave";s:3:"-20";s:7:"Amacron";s:3:"-20";s:7:"Aogonek";s:3:"-20";s:5:"Aring";s:3:"-20";s:6:"Atilde";s:3:"-20";s:5:"comma";s:3:"-20";s:6:"period";s:3:"-20";s:1:"u";s:3:"-20";s:6:"uacute";s:3:"-20";s:11:"ucircumflex";s:3:"-20";s:9:"udieresis";s:3:"-20";s:6:"ugrave";s:3:"-20";s:13:"uhungarumlaut";s:3:"-20";s:7:"umacron";s:3:"-20";s:7:"uogonek";s:3:"-20";s:5:"uring";s:3:"-20";}s:1:"K";a:39:{s:1:"O";s:3:"-30";s:6:"Oacute";s:3:"-30";s:11:"Ocircumflex";s:3:"-30";s:9:"Odieresis";s:3:"-30";s:6:"Ograve";s:3:"-30";s:13:"Ohungarumlaut";s:3:"-30";s:7:"Omacron";s:3:"-30";s:6:"Oslash";s:3:"-30";s:6:"Otilde";s:3:"-30";s:1:"e";s:3:"-15";s:6:"eacute";s:3:"-15";s:6:"ecaron";s:3:"-15";s:11:"ecircumflex";s:3:"-15";s:9:"edieresis";s:3:"-15";s:10:"edotaccent";s:3:"-15";s:6:"egrave";s:3:"-15";s:7:"emacron";s:3:"-15";s:7:"eogonek";s:3:"-15";s:1:"o";s:3:"-35";s:6:"oacute";s:3:"-35";s:11:"ocircumflex";s:3:"-35";s:9:"odieresis";s:3:"-35";s:6:"ograve";s:3:"-35";s:13:"ohungarumlaut";s:3:"-35";s:7:"omacron";s:3:"-35";s:6:"oslash";s:3:"-35";s:6:"otilde";s:3:"-35";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"y";s:3:"-40";s:6:"yacute";s:3:"-40";s:9:"ydieresis";s:3:"-40";}s:12:"Kcommaaccent";a:39:{s:1:"O";s:3:"-30";s:6:"Oacute";s:3:"-30";s:11:"Ocircumflex";s:3:"-30";s:9:"Odieresis";s:3:"-30";s:6:"Ograve";s:3:"-30";s:13:"Ohungarumlaut";s:3:"-30";s:7:"Omacron";s:3:"-30";s:6:"Oslash";s:3:"-30";s:6:"Otilde";s:3:"-30";s:1:"e";s:3:"-15";s:6:"eacute";s:3:"-15";s:6:"ecaron";s:3:"-15";s:11:"ecircumflex";s:3:"-15";s:9:"edieresis";s:3:"-15";s:10:"edotaccent";s:3:"-15";s:6:"egrave";s:3:"-15";s:7:"emacron";s:3:"-15";s:7:"eogonek";s:3:"-15";s:1:"o";s:3:"-35";s:6:"oacute";s:3:"-35";s:11:"ocircumflex";s:3:"-35";s:9:"odieresis";s:3:"-35";s:6:"ograve";s:3:"-35";s:13:"ohungarumlaut";s:3:"-35";s:7:"omacron";s:3:"-35";s:6:"oslash";s:3:"-35";s:6:"otilde";s:3:"-35";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"y";s:3:"-40";s:6:"yacute";s:3:"-40";s:9:"ydieresis";s:3:"-40";}s:1:"L";a:13:{s:1:"T";s:3:"-90";s:6:"Tcaron";s:3:"-90";s:12:"Tcommaaccent";s:3:"-90";s:1:"V";s:4:"-110";s:1:"W";s:3:"-80";s:1:"Y";s:4:"-120";s:6:"Yacute";s:4:"-120";s:9:"Ydieresis";s:4:"-120";s:13:"quotedblright";s:4:"-140";s:10:"quoteright";s:4:"-140";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:6:"Lacute";a:13:{s:1:"T";s:3:"-90";s:6:"Tcaron";s:3:"-90";s:12:"Tcommaaccent";s:3:"-90";s:1:"V";s:4:"-110";s:1:"W";s:3:"-80";s:1:"Y";s:4:"-120";s:6:"Yacute";s:4:"-120";s:9:"Ydieresis";s:4:"-120";s:13:"quotedblright";s:4:"-140";s:10:"quoteright";s:4:"-140";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:12:"Lcommaaccent";a:13:{s:1:"T";s:3:"-90";s:6:"Tcaron";s:3:"-90";s:12:"Tcommaaccent";s:3:"-90";s:1:"V";s:4:"-110";s:1:"W";s:3:"-80";s:1:"Y";s:4:"-120";s:6:"Yacute";s:4:"-120";s:9:"Ydieresis";s:4:"-120";s:13:"quotedblright";s:4:"-140";s:10:"quoteright";s:4:"-140";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:6:"Lslash";a:13:{s:1:"T";s:3:"-90";s:6:"Tcaron";s:3:"-90";s:12:"Tcommaaccent";s:3:"-90";s:1:"V";s:4:"-110";s:1:"W";s:3:"-80";s:1:"Y";s:4:"-120";s:6:"Yacute";s:4:"-120";s:9:"Ydieresis";s:4:"-120";s:13:"quotedblright";s:4:"-140";s:10:"quoteright";s:4:"-140";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:1:"O";a:21:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-50";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:6:"Oacute";a:21:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-50";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:11:"Ocircumflex";a:21:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-50";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:9:"Odieresis";a:21:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-50";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:6:"Ograve";a:21:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-50";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:13:"Ohungarumlaut";a:21:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-50";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:7:"Omacron";a:21:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-50";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:6:"Oslash";a:21:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-50";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:6:"Otilde";a:21:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-50";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:1:"P";a:40:{s:1:"A";s:4:"-100";s:6:"Aacute";s:4:"-100";s:6:"Abreve";s:4:"-100";s:11:"Acircumflex";s:4:"-100";s:9:"Adieresis";s:4:"-100";s:6:"Agrave";s:4:"-100";s:7:"Amacron";s:4:"-100";s:7:"Aogonek";s:4:"-100";s:5:"Aring";s:4:"-100";s:6:"Atilde";s:4:"-100";s:1:"a";s:3:"-30";s:6:"aacute";s:3:"-30";s:6:"abreve";s:3:"-30";s:11:"acircumflex";s:3:"-30";s:9:"adieresis";s:3:"-30";s:6:"agrave";s:3:"-30";s:7:"amacron";s:3:"-30";s:7:"aogonek";s:3:"-30";s:5:"aring";s:3:"-30";s:6:"atilde";s:3:"-30";s:5:"comma";s:4:"-120";s:1:"e";s:3:"-30";s:6:"eacute";s:3:"-30";s:6:"ecaron";s:3:"-30";s:11:"ecircumflex";s:3:"-30";s:9:"edieresis";s:3:"-30";s:10:"edotaccent";s:3:"-30";s:6:"egrave";s:3:"-30";s:7:"emacron";s:3:"-30";s:7:"eogonek";s:3:"-30";s:1:"o";s:3:"-40";s:6:"oacute";s:3:"-40";s:11:"ocircumflex";s:3:"-40";s:9:"odieresis";s:3:"-40";s:6:"ograve";s:3:"-40";s:13:"ohungarumlaut";s:3:"-40";s:7:"omacron";s:3:"-40";s:6:"oslash";s:3:"-40";s:6:"otilde";s:3:"-40";s:6:"period";s:4:"-120";}s:1:"Q";a:11:{s:1:"U";s:3:"-10";s:6:"Uacute";s:3:"-10";s:11:"Ucircumflex";s:3:"-10";s:9:"Udieresis";s:3:"-10";s:6:"Ugrave";s:3:"-10";s:13:"Uhungarumlaut";s:3:"-10";s:7:"Umacron";s:3:"-10";s:7:"Uogonek";s:3:"-10";s:5:"Uring";s:3:"-10";s:5:"comma";s:2:"20";s:6:"period";s:2:"20";}s:1:"R";a:26:{s:1:"O";s:3:"-20";s:6:"Oacute";s:3:"-20";s:11:"Ocircumflex";s:3:"-20";s:9:"Odieresis";s:3:"-20";s:6:"Ograve";s:3:"-20";s:13:"Ohungarumlaut";s:3:"-20";s:7:"Omacron";s:3:"-20";s:6:"Oslash";s:3:"-20";s:6:"Otilde";s:3:"-20";s:1:"T";s:3:"-20";s:6:"Tcaron";s:3:"-20";s:12:"Tcommaaccent";s:3:"-20";s:1:"U";s:3:"-20";s:6:"Uacute";s:3:"-20";s:11:"Ucircumflex";s:3:"-20";s:9:"Udieresis";s:3:"-20";s:6:"Ugrave";s:3:"-20";s:13:"Uhungarumlaut";s:3:"-20";s:7:"Umacron";s:3:"-20";s:7:"Uogonek";s:3:"-20";s:5:"Uring";s:3:"-20";s:1:"V";s:3:"-50";s:1:"W";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:6:"Racute";a:26:{s:1:"O";s:3:"-20";s:6:"Oacute";s:3:"-20";s:11:"Ocircumflex";s:3:"-20";s:9:"Odieresis";s:3:"-20";s:6:"Ograve";s:3:"-20";s:13:"Ohungarumlaut";s:3:"-20";s:7:"Omacron";s:3:"-20";s:6:"Oslash";s:3:"-20";s:6:"Otilde";s:3:"-20";s:1:"T";s:3:"-20";s:6:"Tcaron";s:3:"-20";s:12:"Tcommaaccent";s:3:"-20";s:1:"U";s:3:"-20";s:6:"Uacute";s:3:"-20";s:11:"Ucircumflex";s:3:"-20";s:9:"Udieresis";s:3:"-20";s:6:"Ugrave";s:3:"-20";s:13:"Uhungarumlaut";s:3:"-20";s:7:"Umacron";s:3:"-20";s:7:"Uogonek";s:3:"-20";s:5:"Uring";s:3:"-20";s:1:"V";s:3:"-50";s:1:"W";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:6:"Rcaron";a:26:{s:1:"O";s:3:"-20";s:6:"Oacute";s:3:"-20";s:11:"Ocircumflex";s:3:"-20";s:9:"Odieresis";s:3:"-20";s:6:"Ograve";s:3:"-20";s:13:"Ohungarumlaut";s:3:"-20";s:7:"Omacron";s:3:"-20";s:6:"Oslash";s:3:"-20";s:6:"Otilde";s:3:"-20";s:1:"T";s:3:"-20";s:6:"Tcaron";s:3:"-20";s:12:"Tcommaaccent";s:3:"-20";s:1:"U";s:3:"-20";s:6:"Uacute";s:3:"-20";s:11:"Ucircumflex";s:3:"-20";s:9:"Udieresis";s:3:"-20";s:6:"Ugrave";s:3:"-20";s:13:"Uhungarumlaut";s:3:"-20";s:7:"Umacron";s:3:"-20";s:7:"Uogonek";s:3:"-20";s:5:"Uring";s:3:"-20";s:1:"V";s:3:"-50";s:1:"W";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:12:"Rcommaaccent";a:26:{s:1:"O";s:3:"-20";s:6:"Oacute";s:3:"-20";s:11:"Ocircumflex";s:3:"-20";s:9:"Odieresis";s:3:"-20";s:6:"Ograve";s:3:"-20";s:13:"Ohungarumlaut";s:3:"-20";s:7:"Omacron";s:3:"-20";s:6:"Oslash";s:3:"-20";s:6:"Otilde";s:3:"-20";s:1:"T";s:3:"-20";s:6:"Tcaron";s:3:"-20";s:12:"Tcommaaccent";s:3:"-20";s:1:"U";s:3:"-20";s:6:"Uacute";s:3:"-20";s:11:"Ucircumflex";s:3:"-20";s:9:"Udieresis";s:3:"-20";s:6:"Ugrave";s:3:"-20";s:13:"Uhungarumlaut";s:3:"-20";s:7:"Umacron";s:3:"-20";s:7:"Uogonek";s:3:"-20";s:5:"Uring";s:3:"-20";s:1:"V";s:3:"-50";s:1:"W";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:1:"T";a:68:{s:1:"A";s:3:"-90";s:6:"Aacute";s:3:"-90";s:6:"Abreve";s:3:"-90";s:11:"Acircumflex";s:3:"-90";s:9:"Adieresis";s:3:"-90";s:6:"Agrave";s:3:"-90";s:7:"Amacron";s:3:"-90";s:7:"Aogonek";s:3:"-90";s:5:"Aring";s:3:"-90";s:6:"Atilde";s:3:"-90";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"a";s:3:"-80";s:6:"aacute";s:3:"-80";s:6:"abreve";s:3:"-80";s:11:"acircumflex";s:3:"-80";s:9:"adieresis";s:3:"-80";s:6:"agrave";s:3:"-80";s:7:"amacron";s:3:"-80";s:7:"aogonek";s:3:"-80";s:5:"aring";s:3:"-80";s:6:"atilde";s:3:"-80";s:5:"colon";s:3:"-40";s:5:"comma";s:3:"-80";s:1:"e";s:3:"-60";s:6:"eacute";s:3:"-60";s:6:"ecaron";s:3:"-60";s:11:"ecircumflex";s:3:"-60";s:9:"edieresis";s:3:"-60";s:10:"edotaccent";s:3:"-60";s:6:"egrave";s:3:"-60";s:7:"emacron";s:3:"-60";s:7:"eogonek";s:3:"-60";s:6:"hyphen";s:4:"-120";s:1:"o";s:3:"-80";s:6:"oacute";s:3:"-80";s:11:"ocircumflex";s:3:"-80";s:9:"odieresis";s:3:"-80";s:6:"ograve";s:3:"-80";s:13:"ohungarumlaut";s:3:"-80";s:7:"omacron";s:3:"-80";s:6:"oslash";s:3:"-80";s:6:"otilde";s:3:"-80";s:6:"period";s:3:"-80";s:1:"r";s:3:"-80";s:6:"racute";s:3:"-80";s:12:"rcommaaccent";s:3:"-80";s:9:"semicolon";s:3:"-40";s:1:"u";s:3:"-90";s:6:"uacute";s:3:"-90";s:11:"ucircumflex";s:3:"-90";s:9:"udieresis";s:3:"-90";s:6:"ugrave";s:3:"-90";s:13:"uhungarumlaut";s:3:"-90";s:7:"umacron";s:3:"-90";s:7:"uogonek";s:3:"-90";s:5:"uring";s:3:"-90";s:1:"w";s:3:"-60";s:1:"y";s:3:"-60";s:6:"yacute";s:3:"-60";s:9:"ydieresis";s:3:"-60";}s:6:"Tcaron";a:68:{s:1:"A";s:3:"-90";s:6:"Aacute";s:3:"-90";s:6:"Abreve";s:3:"-90";s:11:"Acircumflex";s:3:"-90";s:9:"Adieresis";s:3:"-90";s:6:"Agrave";s:3:"-90";s:7:"Amacron";s:3:"-90";s:7:"Aogonek";s:3:"-90";s:5:"Aring";s:3:"-90";s:6:"Atilde";s:3:"-90";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"a";s:3:"-80";s:6:"aacute";s:3:"-80";s:6:"abreve";s:3:"-80";s:11:"acircumflex";s:3:"-80";s:9:"adieresis";s:3:"-80";s:6:"agrave";s:3:"-80";s:7:"amacron";s:3:"-80";s:7:"aogonek";s:3:"-80";s:5:"aring";s:3:"-80";s:6:"atilde";s:3:"-80";s:5:"colon";s:3:"-40";s:5:"comma";s:3:"-80";s:1:"e";s:3:"-60";s:6:"eacute";s:3:"-60";s:6:"ecaron";s:3:"-60";s:11:"ecircumflex";s:3:"-60";s:9:"edieresis";s:3:"-60";s:10:"edotaccent";s:3:"-60";s:6:"egrave";s:3:"-60";s:7:"emacron";s:3:"-60";s:7:"eogonek";s:3:"-60";s:6:"hyphen";s:4:"-120";s:1:"o";s:3:"-80";s:6:"oacute";s:3:"-80";s:11:"ocircumflex";s:3:"-80";s:9:"odieresis";s:3:"-80";s:6:"ograve";s:3:"-80";s:13:"ohungarumlaut";s:3:"-80";s:7:"omacron";s:3:"-80";s:6:"oslash";s:3:"-80";s:6:"otilde";s:3:"-80";s:6:"period";s:3:"-80";s:1:"r";s:3:"-80";s:6:"racute";s:3:"-80";s:12:"rcommaaccent";s:3:"-80";s:9:"semicolon";s:3:"-40";s:1:"u";s:3:"-90";s:6:"uacute";s:3:"-90";s:11:"ucircumflex";s:3:"-90";s:9:"udieresis";s:3:"-90";s:6:"ugrave";s:3:"-90";s:13:"uhungarumlaut";s:3:"-90";s:7:"umacron";s:3:"-90";s:7:"uogonek";s:3:"-90";s:5:"uring";s:3:"-90";s:1:"w";s:3:"-60";s:1:"y";s:3:"-60";s:6:"yacute";s:3:"-60";s:9:"ydieresis";s:3:"-60";}s:12:"Tcommaaccent";a:68:{s:1:"A";s:3:"-90";s:6:"Aacute";s:3:"-90";s:6:"Abreve";s:3:"-90";s:11:"Acircumflex";s:3:"-90";s:9:"Adieresis";s:3:"-90";s:6:"Agrave";s:3:"-90";s:7:"Amacron";s:3:"-90";s:7:"Aogonek";s:3:"-90";s:5:"Aring";s:3:"-90";s:6:"Atilde";s:3:"-90";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"a";s:3:"-80";s:6:"aacute";s:3:"-80";s:6:"abreve";s:3:"-80";s:11:"acircumflex";s:3:"-80";s:9:"adieresis";s:3:"-80";s:6:"agrave";s:3:"-80";s:7:"amacron";s:3:"-80";s:7:"aogonek";s:3:"-80";s:5:"aring";s:3:"-80";s:6:"atilde";s:3:"-80";s:5:"colon";s:3:"-40";s:5:"comma";s:3:"-80";s:1:"e";s:3:"-60";s:6:"eacute";s:3:"-60";s:6:"ecaron";s:3:"-60";s:11:"ecircumflex";s:3:"-60";s:9:"edieresis";s:3:"-60";s:10:"edotaccent";s:3:"-60";s:6:"egrave";s:3:"-60";s:7:"emacron";s:3:"-60";s:7:"eogonek";s:3:"-60";s:6:"hyphen";s:4:"-120";s:1:"o";s:3:"-80";s:6:"oacute";s:3:"-80";s:11:"ocircumflex";s:3:"-80";s:9:"odieresis";s:3:"-80";s:6:"ograve";s:3:"-80";s:13:"ohungarumlaut";s:3:"-80";s:7:"omacron";s:3:"-80";s:6:"oslash";s:3:"-80";s:6:"otilde";s:3:"-80";s:6:"period";s:3:"-80";s:1:"r";s:3:"-80";s:6:"racute";s:3:"-80";s:12:"rcommaaccent";s:3:"-80";s:9:"semicolon";s:3:"-40";s:1:"u";s:3:"-90";s:6:"uacute";s:3:"-90";s:11:"ucircumflex";s:3:"-90";s:9:"udieresis";s:3:"-90";s:6:"ugrave";s:3:"-90";s:13:"uhungarumlaut";s:3:"-90";s:7:"umacron";s:3:"-90";s:7:"uogonek";s:3:"-90";s:5:"uring";s:3:"-90";s:1:"w";s:3:"-60";s:1:"y";s:3:"-60";s:6:"yacute";s:3:"-60";s:9:"ydieresis";s:3:"-60";}s:1:"U";a:12:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:5:"comma";s:3:"-30";s:6:"period";s:3:"-30";}s:6:"Uacute";a:12:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:5:"comma";s:3:"-30";s:6:"period";s:3:"-30";}s:11:"Ucircumflex";a:12:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:5:"comma";s:3:"-30";s:6:"period";s:3:"-30";}s:9:"Udieresis";a:12:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:5:"comma";s:3:"-30";s:6:"period";s:3:"-30";}s:6:"Ugrave";a:12:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:5:"comma";s:3:"-30";s:6:"period";s:3:"-30";}s:13:"Uhungarumlaut";a:12:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:5:"comma";s:3:"-30";s:6:"period";s:3:"-30";}s:7:"Umacron";a:12:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:5:"comma";s:3:"-30";s:6:"period";s:3:"-30";}s:7:"Uogonek";a:12:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:5:"comma";s:3:"-30";s:6:"period";s:3:"-30";}s:5:"Uring";a:12:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:5:"comma";s:3:"-30";s:6:"period";s:3:"-30";}s:1:"V";a:64:{s:1:"A";s:3:"-80";s:6:"Aacute";s:3:"-80";s:6:"Abreve";s:3:"-80";s:11:"Acircumflex";s:3:"-80";s:9:"Adieresis";s:3:"-80";s:6:"Agrave";s:3:"-80";s:7:"Amacron";s:3:"-80";s:7:"Aogonek";s:3:"-80";s:5:"Aring";s:3:"-80";s:6:"Atilde";s:3:"-80";s:1:"G";s:3:"-50";s:6:"Gbreve";s:3:"-50";s:12:"Gcommaaccent";s:3:"-50";s:1:"O";s:3:"-50";s:6:"Oacute";s:3:"-50";s:11:"Ocircumflex";s:3:"-50";s:9:"Odieresis";s:3:"-50";s:6:"Ograve";s:3:"-50";s:13:"Ohungarumlaut";s:3:"-50";s:7:"Omacron";s:3:"-50";s:6:"Oslash";s:3:"-50";s:6:"Otilde";s:3:"-50";s:1:"a";s:3:"-60";s:6:"aacute";s:3:"-60";s:6:"abreve";s:3:"-60";s:11:"acircumflex";s:3:"-60";s:9:"adieresis";s:3:"-60";s:6:"agrave";s:3:"-60";s:7:"amacron";s:3:"-60";s:7:"aogonek";s:3:"-60";s:5:"aring";s:3:"-60";s:6:"atilde";s:3:"-60";s:5:"colon";s:3:"-40";s:5:"comma";s:4:"-120";s:1:"e";s:3:"-50";s:6:"eacute";s:3:"-50";s:6:"ecaron";s:3:"-50";s:11:"ecircumflex";s:3:"-50";s:9:"edieresis";s:3:"-50";s:10:"edotaccent";s:3:"-50";s:6:"egrave";s:3:"-50";s:7:"emacron";s:3:"-50";s:7:"eogonek";s:3:"-50";s:6:"hyphen";s:3:"-80";s:1:"o";s:3:"-90";s:6:"oacute";s:3:"-90";s:11:"ocircumflex";s:3:"-90";s:9:"odieresis";s:3:"-90";s:6:"ograve";s:3:"-90";s:13:"ohungarumlaut";s:3:"-90";s:7:"omacron";s:3:"-90";s:6:"oslash";s:3:"-90";s:6:"otilde";s:3:"-90";s:6:"period";s:4:"-120";s:9:"semicolon";s:3:"-40";s:1:"u";s:3:"-60";s:6:"uacute";s:3:"-60";s:11:"ucircumflex";s:3:"-60";s:9:"udieresis";s:3:"-60";s:6:"ugrave";s:3:"-60";s:13:"uhungarumlaut";s:3:"-60";s:7:"umacron";s:3:"-60";s:7:"uogonek";s:3:"-60";s:5:"uring";s:3:"-60";}s:1:"W";a:64:{s:1:"A";s:3:"-60";s:6:"Aacute";s:3:"-60";s:6:"Abreve";s:3:"-60";s:11:"Acircumflex";s:3:"-60";s:9:"Adieresis";s:3:"-60";s:6:"Agrave";s:3:"-60";s:7:"Amacron";s:3:"-60";s:7:"Aogonek";s:3:"-60";s:5:"Aring";s:3:"-60";s:6:"Atilde";s:3:"-60";s:1:"O";s:3:"-20";s:6:"Oacute";s:3:"-20";s:11:"Ocircumflex";s:3:"-20";s:9:"Odieresis";s:3:"-20";s:6:"Ograve";s:3:"-20";s:13:"Ohungarumlaut";s:3:"-20";s:7:"Omacron";s:3:"-20";s:6:"Oslash";s:3:"-20";s:6:"Otilde";s:3:"-20";s:1:"a";s:3:"-40";s:6:"aacute";s:3:"-40";s:6:"abreve";s:3:"-40";s:11:"acircumflex";s:3:"-40";s:9:"adieresis";s:3:"-40";s:6:"agrave";s:3:"-40";s:7:"amacron";s:3:"-40";s:7:"aogonek";s:3:"-40";s:5:"aring";s:3:"-40";s:6:"atilde";s:3:"-40";s:5:"colon";s:3:"-10";s:5:"comma";s:3:"-80";s:1:"e";s:3:"-35";s:6:"eacute";s:3:"-35";s:6:"ecaron";s:3:"-35";s:11:"ecircumflex";s:3:"-35";s:9:"edieresis";s:3:"-35";s:10:"edotaccent";s:3:"-35";s:6:"egrave";s:3:"-35";s:7:"emacron";s:3:"-35";s:7:"eogonek";s:3:"-35";s:6:"hyphen";s:3:"-40";s:1:"o";s:3:"-60";s:6:"oacute";s:3:"-60";s:11:"ocircumflex";s:3:"-60";s:9:"odieresis";s:3:"-60";s:6:"ograve";s:3:"-60";s:13:"ohungarumlaut";s:3:"-60";s:7:"omacron";s:3:"-60";s:6:"oslash";s:3:"-60";s:6:"otilde";s:3:"-60";s:6:"period";s:3:"-80";s:9:"semicolon";s:3:"-10";s:1:"u";s:3:"-45";s:6:"uacute";s:3:"-45";s:11:"ucircumflex";s:3:"-45";s:9:"udieresis";s:3:"-45";s:6:"ugrave";s:3:"-45";s:13:"uhungarumlaut";s:3:"-45";s:7:"umacron";s:3:"-45";s:7:"uogonek";s:3:"-45";s:5:"uring";s:3:"-45";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:1:"Y";a:60:{s:1:"A";s:4:"-110";s:6:"Aacute";s:4:"-110";s:6:"Abreve";s:4:"-110";s:11:"Acircumflex";s:4:"-110";s:9:"Adieresis";s:4:"-110";s:6:"Agrave";s:4:"-110";s:7:"Amacron";s:4:"-110";s:7:"Aogonek";s:4:"-110";s:5:"Aring";s:4:"-110";s:6:"Atilde";s:4:"-110";s:1:"O";s:3:"-70";s:6:"Oacute";s:3:"-70";s:11:"Ocircumflex";s:3:"-70";s:9:"Odieresis";s:3:"-70";s:6:"Ograve";s:3:"-70";s:13:"Ohungarumlaut";s:3:"-70";s:7:"Omacron";s:3:"-70";s:6:"Oslash";s:3:"-70";s:6:"Otilde";s:3:"-70";s:1:"a";s:3:"-90";s:6:"aacute";s:3:"-90";s:6:"abreve";s:3:"-90";s:11:"acircumflex";s:3:"-90";s:9:"adieresis";s:3:"-90";s:6:"agrave";s:3:"-90";s:7:"amacron";s:3:"-90";s:7:"aogonek";s:3:"-90";s:5:"aring";s:3:"-90";s:6:"atilde";s:3:"-90";s:5:"colon";s:3:"-50";s:5:"comma";s:4:"-100";s:1:"e";s:3:"-80";s:6:"eacute";s:3:"-80";s:6:"ecaron";s:3:"-80";s:11:"ecircumflex";s:3:"-80";s:9:"edieresis";s:3:"-80";s:10:"edotaccent";s:3:"-80";s:6:"egrave";s:3:"-80";s:7:"emacron";s:3:"-80";s:7:"eogonek";s:3:"-80";s:1:"o";s:4:"-100";s:6:"oacute";s:4:"-100";s:11:"ocircumflex";s:4:"-100";s:9:"odieresis";s:4:"-100";s:6:"ograve";s:4:"-100";s:13:"ohungarumlaut";s:4:"-100";s:7:"omacron";s:4:"-100";s:6:"oslash";s:4:"-100";s:6:"otilde";s:4:"-100";s:6:"period";s:4:"-100";s:9:"semicolon";s:3:"-50";s:1:"u";s:4:"-100";s:6:"uacute";s:4:"-100";s:11:"ucircumflex";s:4:"-100";s:9:"udieresis";s:4:"-100";s:6:"ugrave";s:4:"-100";s:13:"uhungarumlaut";s:4:"-100";s:7:"umacron";s:4:"-100";s:7:"uogonek";s:4:"-100";s:5:"uring";s:4:"-100";}s:6:"Yacute";a:60:{s:1:"A";s:4:"-110";s:6:"Aacute";s:4:"-110";s:6:"Abreve";s:4:"-110";s:11:"Acircumflex";s:4:"-110";s:9:"Adieresis";s:4:"-110";s:6:"Agrave";s:4:"-110";s:7:"Amacron";s:4:"-110";s:7:"Aogonek";s:4:"-110";s:5:"Aring";s:4:"-110";s:6:"Atilde";s:4:"-110";s:1:"O";s:3:"-70";s:6:"Oacute";s:3:"-70";s:11:"Ocircumflex";s:3:"-70";s:9:"Odieresis";s:3:"-70";s:6:"Ograve";s:3:"-70";s:13:"Ohungarumlaut";s:3:"-70";s:7:"Omacron";s:3:"-70";s:6:"Oslash";s:3:"-70";s:6:"Otilde";s:3:"-70";s:1:"a";s:3:"-90";s:6:"aacute";s:3:"-90";s:6:"abreve";s:3:"-90";s:11:"acircumflex";s:3:"-90";s:9:"adieresis";s:3:"-90";s:6:"agrave";s:3:"-90";s:7:"amacron";s:3:"-90";s:7:"aogonek";s:3:"-90";s:5:"aring";s:3:"-90";s:6:"atilde";s:3:"-90";s:5:"colon";s:3:"-50";s:5:"comma";s:4:"-100";s:1:"e";s:3:"-80";s:6:"eacute";s:3:"-80";s:6:"ecaron";s:3:"-80";s:11:"ecircumflex";s:3:"-80";s:9:"edieresis";s:3:"-80";s:10:"edotaccent";s:3:"-80";s:6:"egrave";s:3:"-80";s:7:"emacron";s:3:"-80";s:7:"eogonek";s:3:"-80";s:1:"o";s:4:"-100";s:6:"oacute";s:4:"-100";s:11:"ocircumflex";s:4:"-100";s:9:"odieresis";s:4:"-100";s:6:"ograve";s:4:"-100";s:13:"ohungarumlaut";s:4:"-100";s:7:"omacron";s:4:"-100";s:6:"oslash";s:4:"-100";s:6:"otilde";s:4:"-100";s:6:"period";s:4:"-100";s:9:"semicolon";s:3:"-50";s:1:"u";s:4:"-100";s:6:"uacute";s:4:"-100";s:11:"ucircumflex";s:4:"-100";s:9:"udieresis";s:4:"-100";s:6:"ugrave";s:4:"-100";s:13:"uhungarumlaut";s:4:"-100";s:7:"umacron";s:4:"-100";s:7:"uogonek";s:4:"-100";s:5:"uring";s:4:"-100";}s:9:"Ydieresis";a:60:{s:1:"A";s:4:"-110";s:6:"Aacute";s:4:"-110";s:6:"Abreve";s:4:"-110";s:11:"Acircumflex";s:4:"-110";s:9:"Adieresis";s:4:"-110";s:6:"Agrave";s:4:"-110";s:7:"Amacron";s:4:"-110";s:7:"Aogonek";s:4:"-110";s:5:"Aring";s:4:"-110";s:6:"Atilde";s:4:"-110";s:1:"O";s:3:"-70";s:6:"Oacute";s:3:"-70";s:11:"Ocircumflex";s:3:"-70";s:9:"Odieresis";s:3:"-70";s:6:"Ograve";s:3:"-70";s:13:"Ohungarumlaut";s:3:"-70";s:7:"Omacron";s:3:"-70";s:6:"Oslash";s:3:"-70";s:6:"Otilde";s:3:"-70";s:1:"a";s:3:"-90";s:6:"aacute";s:3:"-90";s:6:"abreve";s:3:"-90";s:11:"acircumflex";s:3:"-90";s:9:"adieresis";s:3:"-90";s:6:"agrave";s:3:"-90";s:7:"amacron";s:3:"-90";s:7:"aogonek";s:3:"-90";s:5:"aring";s:3:"-90";s:6:"atilde";s:3:"-90";s:5:"colon";s:3:"-50";s:5:"comma";s:4:"-100";s:1:"e";s:3:"-80";s:6:"eacute";s:3:"-80";s:6:"ecaron";s:3:"-80";s:11:"ecircumflex";s:3:"-80";s:9:"edieresis";s:3:"-80";s:10:"edotaccent";s:3:"-80";s:6:"egrave";s:3:"-80";s:7:"emacron";s:3:"-80";s:7:"eogonek";s:3:"-80";s:1:"o";s:4:"-100";s:6:"oacute";s:4:"-100";s:11:"ocircumflex";s:4:"-100";s:9:"odieresis";s:4:"-100";s:6:"ograve";s:4:"-100";s:13:"ohungarumlaut";s:4:"-100";s:7:"omacron";s:4:"-100";s:6:"oslash";s:4:"-100";s:6:"otilde";s:4:"-100";s:6:"period";s:4:"-100";s:9:"semicolon";s:3:"-50";s:1:"u";s:4:"-100";s:6:"uacute";s:4:"-100";s:11:"ucircumflex";s:4:"-100";s:9:"udieresis";s:4:"-100";s:6:"ugrave";s:4:"-100";s:13:"uhungarumlaut";s:4:"-100";s:7:"umacron";s:4:"-100";s:7:"uogonek";s:4:"-100";s:5:"uring";s:4:"-100";}s:1:"a";a:8:{s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:6:"aacute";a:8:{s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:6:"abreve";a:8:{s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:11:"acircumflex";a:8:{s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:9:"adieresis";a:8:{s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:6:"agrave";a:8:{s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:7:"amacron";a:8:{s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:7:"aogonek";a:8:{s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:5:"aring";a:8:{s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:6:"atilde";a:8:{s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:1:"b";a:17:{s:1:"l";s:3:"-10";s:6:"lacute";s:3:"-10";s:12:"lcommaaccent";s:3:"-10";s:6:"lslash";s:3:"-10";s:1:"u";s:3:"-20";s:6:"uacute";s:3:"-20";s:11:"ucircumflex";s:3:"-20";s:9:"udieresis";s:3:"-20";s:6:"ugrave";s:3:"-20";s:13:"uhungarumlaut";s:3:"-20";s:7:"umacron";s:3:"-20";s:7:"uogonek";s:3:"-20";s:5:"uring";s:3:"-20";s:1:"v";s:3:"-20";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:1:"c";a:10:{s:1:"h";s:3:"-10";s:1:"k";s:3:"-20";s:12:"kcommaaccent";s:3:"-20";s:1:"l";s:3:"-20";s:6:"lacute";s:3:"-20";s:12:"lcommaaccent";s:3:"-20";s:6:"lslash";s:3:"-20";s:1:"y";s:3:"-10";s:6:"yacute";s:3:"-10";s:9:"ydieresis";s:3:"-10";}s:6:"cacute";a:10:{s:1:"h";s:3:"-10";s:1:"k";s:3:"-20";s:12:"kcommaaccent";s:3:"-20";s:1:"l";s:3:"-20";s:6:"lacute";s:3:"-20";s:12:"lcommaaccent";s:3:"-20";s:6:"lslash";s:3:"-20";s:1:"y";s:3:"-10";s:6:"yacute";s:3:"-10";s:9:"ydieresis";s:3:"-10";}s:6:"ccaron";a:10:{s:1:"h";s:3:"-10";s:1:"k";s:3:"-20";s:12:"kcommaaccent";s:3:"-20";s:1:"l";s:3:"-20";s:6:"lacute";s:3:"-20";s:12:"lcommaaccent";s:3:"-20";s:6:"lslash";s:3:"-20";s:1:"y";s:3:"-10";s:6:"yacute";s:3:"-10";s:9:"ydieresis";s:3:"-10";}s:8:"ccedilla";a:10:{s:1:"h";s:3:"-10";s:1:"k";s:3:"-20";s:12:"kcommaaccent";s:3:"-20";s:1:"l";s:3:"-20";s:6:"lacute";s:3:"-20";s:12:"lcommaaccent";s:3:"-20";s:6:"lslash";s:3:"-20";s:1:"y";s:3:"-10";s:6:"yacute";s:3:"-10";s:9:"ydieresis";s:3:"-10";}s:5:"colon";a:1:{s:5:"space";s:3:"-40";}s:5:"comma";a:3:{s:13:"quotedblright";s:4:"-120";s:10:"quoteright";s:4:"-120";s:5:"space";s:3:"-40";}s:1:"d";a:7:{s:1:"d";s:3:"-10";s:6:"dcroat";s:3:"-10";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:6:"dcroat";a:7:{s:1:"d";s:3:"-10";s:6:"dcroat";s:3:"-10";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:1:"e";a:8:{s:5:"comma";s:2:"10";s:6:"period";s:2:"20";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-15";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:6:"eacute";a:8:{s:5:"comma";s:2:"10";s:6:"period";s:2:"20";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-15";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:6:"ecaron";a:8:{s:5:"comma";s:2:"10";s:6:"period";s:2:"20";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-15";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:11:"ecircumflex";a:8:{s:5:"comma";s:2:"10";s:6:"period";s:2:"20";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-15";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:9:"edieresis";a:8:{s:5:"comma";s:2:"10";s:6:"period";s:2:"20";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-15";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:10:"edotaccent";a:8:{s:5:"comma";s:2:"10";s:6:"period";s:2:"20";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-15";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:6:"egrave";a:8:{s:5:"comma";s:2:"10";s:6:"period";s:2:"20";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-15";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:7:"emacron";a:8:{s:5:"comma";s:2:"10";s:6:"period";s:2:"20";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-15";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:7:"eogonek";a:8:{s:5:"comma";s:2:"10";s:6:"period";s:2:"20";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-15";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:1:"f";a:22:{s:5:"comma";s:3:"-10";s:1:"e";s:3:"-10";s:6:"eacute";s:3:"-10";s:6:"ecaron";s:3:"-10";s:11:"ecircumflex";s:3:"-10";s:9:"edieresis";s:3:"-10";s:10:"edotaccent";s:3:"-10";s:6:"egrave";s:3:"-10";s:7:"emacron";s:3:"-10";s:7:"eogonek";s:3:"-10";s:1:"o";s:3:"-20";s:6:"oacute";s:3:"-20";s:11:"ocircumflex";s:3:"-20";s:9:"odieresis";s:3:"-20";s:6:"ograve";s:3:"-20";s:13:"ohungarumlaut";s:3:"-20";s:7:"omacron";s:3:"-20";s:6:"oslash";s:3:"-20";s:6:"otilde";s:3:"-20";s:6:"period";s:3:"-10";s:13:"quotedblright";s:2:"30";s:10:"quoteright";s:2:"30";}s:1:"g";a:12:{s:1:"e";s:2:"10";s:6:"eacute";s:2:"10";s:6:"ecaron";s:2:"10";s:11:"ecircumflex";s:2:"10";s:9:"edieresis";s:2:"10";s:10:"edotaccent";s:2:"10";s:6:"egrave";s:2:"10";s:7:"emacron";s:2:"10";s:7:"eogonek";s:2:"10";s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";}s:6:"gbreve";a:12:{s:1:"e";s:2:"10";s:6:"eacute";s:2:"10";s:6:"ecaron";s:2:"10";s:11:"ecircumflex";s:2:"10";s:9:"edieresis";s:2:"10";s:10:"edotaccent";s:2:"10";s:6:"egrave";s:2:"10";s:7:"emacron";s:2:"10";s:7:"eogonek";s:2:"10";s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";}s:12:"gcommaaccent";a:12:{s:1:"e";s:2:"10";s:6:"eacute";s:2:"10";s:6:"ecaron";s:2:"10";s:11:"ecircumflex";s:2:"10";s:9:"edieresis";s:2:"10";s:10:"edotaccent";s:2:"10";s:6:"egrave";s:2:"10";s:7:"emacron";s:2:"10";s:7:"eogonek";s:2:"10";s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";}s:1:"h";a:3:{s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:1:"k";a:9:{s:1:"o";s:3:"-15";s:6:"oacute";s:3:"-15";s:11:"ocircumflex";s:3:"-15";s:9:"odieresis";s:3:"-15";s:6:"ograve";s:3:"-15";s:13:"ohungarumlaut";s:3:"-15";s:7:"omacron";s:3:"-15";s:6:"oslash";s:3:"-15";s:6:"otilde";s:3:"-15";}s:12:"kcommaaccent";a:9:{s:1:"o";s:3:"-15";s:6:"oacute";s:3:"-15";s:11:"ocircumflex";s:3:"-15";s:9:"odieresis";s:3:"-15";s:6:"ograve";s:3:"-15";s:13:"ohungarumlaut";s:3:"-15";s:7:"omacron";s:3:"-15";s:6:"oslash";s:3:"-15";s:6:"otilde";s:3:"-15";}s:1:"l";a:4:{s:1:"w";s:3:"-15";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:6:"lacute";a:4:{s:1:"w";s:3:"-15";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:12:"lcommaaccent";a:4:{s:1:"w";s:3:"-15";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:6:"lslash";a:4:{s:1:"w";s:3:"-15";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:1:"m";a:12:{s:1:"u";s:3:"-20";s:6:"uacute";s:3:"-20";s:11:"ucircumflex";s:3:"-20";s:9:"udieresis";s:3:"-20";s:6:"ugrave";s:3:"-20";s:13:"uhungarumlaut";s:3:"-20";s:7:"umacron";s:3:"-20";s:7:"uogonek";s:3:"-20";s:5:"uring";s:3:"-20";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:1:"n";a:13:{s:1:"u";s:3:"-10";s:6:"uacute";s:3:"-10";s:11:"ucircumflex";s:3:"-10";s:9:"udieresis";s:3:"-10";s:6:"ugrave";s:3:"-10";s:13:"uhungarumlaut";s:3:"-10";s:7:"umacron";s:3:"-10";s:7:"uogonek";s:3:"-10";s:5:"uring";s:3:"-10";s:1:"v";s:3:"-40";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:6:"nacute";a:13:{s:1:"u";s:3:"-10";s:6:"uacute";s:3:"-10";s:11:"ucircumflex";s:3:"-10";s:9:"udieresis";s:3:"-10";s:6:"ugrave";s:3:"-10";s:13:"uhungarumlaut";s:3:"-10";s:7:"umacron";s:3:"-10";s:7:"uogonek";s:3:"-10";s:5:"uring";s:3:"-10";s:1:"v";s:3:"-40";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:6:"ncaron";a:13:{s:1:"u";s:3:"-10";s:6:"uacute";s:3:"-10";s:11:"ucircumflex";s:3:"-10";s:9:"udieresis";s:3:"-10";s:6:"ugrave";s:3:"-10";s:13:"uhungarumlaut";s:3:"-10";s:7:"umacron";s:3:"-10";s:7:"uogonek";s:3:"-10";s:5:"uring";s:3:"-10";s:1:"v";s:3:"-40";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:12:"ncommaaccent";a:13:{s:1:"u";s:3:"-10";s:6:"uacute";s:3:"-10";s:11:"ucircumflex";s:3:"-10";s:9:"udieresis";s:3:"-10";s:6:"ugrave";s:3:"-10";s:13:"uhungarumlaut";s:3:"-10";s:7:"umacron";s:3:"-10";s:7:"uogonek";s:3:"-10";s:5:"uring";s:3:"-10";s:1:"v";s:3:"-40";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:6:"ntilde";a:13:{s:1:"u";s:3:"-10";s:6:"uacute";s:3:"-10";s:11:"ucircumflex";s:3:"-10";s:9:"udieresis";s:3:"-10";s:6:"ugrave";s:3:"-10";s:13:"uhungarumlaut";s:3:"-10";s:7:"umacron";s:3:"-10";s:7:"uogonek";s:3:"-10";s:5:"uring";s:3:"-10";s:1:"v";s:3:"-40";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:1:"o";a:6:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-15";s:1:"x";s:3:"-30";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:6:"oacute";a:6:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-15";s:1:"x";s:3:"-30";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:11:"ocircumflex";a:6:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-15";s:1:"x";s:3:"-30";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:9:"odieresis";a:6:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-15";s:1:"x";s:3:"-30";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:6:"ograve";a:6:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-15";s:1:"x";s:3:"-30";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:13:"ohungarumlaut";a:6:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-15";s:1:"x";s:3:"-30";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:7:"omacron";a:6:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-15";s:1:"x";s:3:"-30";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:6:"oslash";a:6:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-15";s:1:"x";s:3:"-30";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:6:"otilde";a:6:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-15";s:1:"x";s:3:"-30";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:1:"p";a:3:{s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:6:"period";a:3:{s:13:"quotedblright";s:4:"-120";s:10:"quoteright";s:4:"-120";s:5:"space";s:3:"-40";}s:13:"quotedblright";a:1:{s:5:"space";s:3:"-80";}s:9:"quoteleft";a:1:{s:9:"quoteleft";s:3:"-46";}s:10:"quoteright";a:18:{s:1:"d";s:3:"-80";s:6:"dcroat";s:3:"-80";s:1:"l";s:3:"-20";s:6:"lacute";s:3:"-20";s:12:"lcommaaccent";s:3:"-20";s:6:"lslash";s:3:"-20";s:10:"quoteright";s:3:"-46";s:1:"r";s:3:"-40";s:6:"racute";s:3:"-40";s:6:"rcaron";s:3:"-40";s:12:"rcommaaccent";s:3:"-40";s:1:"s";s:3:"-60";s:6:"sacute";s:3:"-60";s:6:"scaron";s:3:"-60";s:8:"scedilla";s:3:"-60";s:12:"scommaaccent";s:3:"-60";s:5:"space";s:3:"-80";s:1:"v";s:3:"-20";}s:1:"r";a:33:{s:1:"c";s:3:"-20";s:6:"cacute";s:3:"-20";s:6:"ccaron";s:3:"-20";s:8:"ccedilla";s:3:"-20";s:5:"comma";s:3:"-60";s:1:"d";s:3:"-20";s:6:"dcroat";s:3:"-20";s:1:"g";s:3:"-15";s:6:"gbreve";s:3:"-15";s:12:"gcommaaccent";s:3:"-15";s:6:"hyphen";s:3:"-20";s:1:"o";s:3:"-20";s:6:"oacute";s:3:"-20";s:11:"ocircumflex";s:3:"-20";s:9:"odieresis";s:3:"-20";s:6:"ograve";s:3:"-20";s:13:"ohungarumlaut";s:3:"-20";s:7:"omacron";s:3:"-20";s:6:"oslash";s:3:"-20";s:6:"otilde";s:3:"-20";s:6:"period";s:3:"-60";s:1:"q";s:3:"-20";s:1:"s";s:3:"-15";s:6:"sacute";s:3:"-15";s:6:"scaron";s:3:"-15";s:8:"scedilla";s:3:"-15";s:12:"scommaaccent";s:3:"-15";s:1:"t";s:2:"20";s:12:"tcommaaccent";s:2:"20";s:1:"v";s:2:"10";s:1:"y";s:2:"10";s:6:"yacute";s:2:"10";s:9:"ydieresis";s:2:"10";}s:6:"racute";a:33:{s:1:"c";s:3:"-20";s:6:"cacute";s:3:"-20";s:6:"ccaron";s:3:"-20";s:8:"ccedilla";s:3:"-20";s:5:"comma";s:3:"-60";s:1:"d";s:3:"-20";s:6:"dcroat";s:3:"-20";s:1:"g";s:3:"-15";s:6:"gbreve";s:3:"-15";s:12:"gcommaaccent";s:3:"-15";s:6:"hyphen";s:3:"-20";s:1:"o";s:3:"-20";s:6:"oacute";s:3:"-20";s:11:"ocircumflex";s:3:"-20";s:9:"odieresis";s:3:"-20";s:6:"ograve";s:3:"-20";s:13:"ohungarumlaut";s:3:"-20";s:7:"omacron";s:3:"-20";s:6:"oslash";s:3:"-20";s:6:"otilde";s:3:"-20";s:6:"period";s:3:"-60";s:1:"q";s:3:"-20";s:1:"s";s:3:"-15";s:6:"sacute";s:3:"-15";s:6:"scaron";s:3:"-15";s:8:"scedilla";s:3:"-15";s:12:"scommaaccent";s:3:"-15";s:1:"t";s:2:"20";s:12:"tcommaaccent";s:2:"20";s:1:"v";s:2:"10";s:1:"y";s:2:"10";s:6:"yacute";s:2:"10";s:9:"ydieresis";s:2:"10";}s:6:"rcaron";a:33:{s:1:"c";s:3:"-20";s:6:"cacute";s:3:"-20";s:6:"ccaron";s:3:"-20";s:8:"ccedilla";s:3:"-20";s:5:"comma";s:3:"-60";s:1:"d";s:3:"-20";s:6:"dcroat";s:3:"-20";s:1:"g";s:3:"-15";s:6:"gbreve";s:3:"-15";s:12:"gcommaaccent";s:3:"-15";s:6:"hyphen";s:3:"-20";s:1:"o";s:3:"-20";s:6:"oacute";s:3:"-20";s:11:"ocircumflex";s:3:"-20";s:9:"odieresis";s:3:"-20";s:6:"ograve";s:3:"-20";s:13:"ohungarumlaut";s:3:"-20";s:7:"omacron";s:3:"-20";s:6:"oslash";s:3:"-20";s:6:"otilde";s:3:"-20";s:6:"period";s:3:"-60";s:1:"q";s:3:"-20";s:1:"s";s:3:"-15";s:6:"sacute";s:3:"-15";s:6:"scaron";s:3:"-15";s:8:"scedilla";s:3:"-15";s:12:"scommaaccent";s:3:"-15";s:1:"t";s:2:"20";s:12:"tcommaaccent";s:2:"20";s:1:"v";s:2:"10";s:1:"y";s:2:"10";s:6:"yacute";s:2:"10";s:9:"ydieresis";s:2:"10";}s:12:"rcommaaccent";a:33:{s:1:"c";s:3:"-20";s:6:"cacute";s:3:"-20";s:6:"ccaron";s:3:"-20";s:8:"ccedilla";s:3:"-20";s:5:"comma";s:3:"-60";s:1:"d";s:3:"-20";s:6:"dcroat";s:3:"-20";s:1:"g";s:3:"-15";s:6:"gbreve";s:3:"-15";s:12:"gcommaaccent";s:3:"-15";s:6:"hyphen";s:3:"-20";s:1:"o";s:3:"-20";s:6:"oacute";s:3:"-20";s:11:"ocircumflex";s:3:"-20";s:9:"odieresis";s:3:"-20";s:6:"ograve";s:3:"-20";s:13:"ohungarumlaut";s:3:"-20";s:7:"omacron";s:3:"-20";s:6:"oslash";s:3:"-20";s:6:"otilde";s:3:"-20";s:6:"period";s:3:"-60";s:1:"q";s:3:"-20";s:1:"s";s:3:"-15";s:6:"sacute";s:3:"-15";s:6:"scaron";s:3:"-15";s:8:"scedilla";s:3:"-15";s:12:"scommaaccent";s:3:"-15";s:1:"t";s:2:"20";s:12:"tcommaaccent";s:2:"20";s:1:"v";s:2:"10";s:1:"y";s:2:"10";s:6:"yacute";s:2:"10";s:9:"ydieresis";s:2:"10";}s:1:"s";a:1:{s:1:"w";s:3:"-15";}s:6:"sacute";a:1:{s:1:"w";s:3:"-15";}s:6:"scaron";a:1:{s:1:"w";s:3:"-15";}s:8:"scedilla";a:1:{s:1:"w";s:3:"-15";}s:12:"scommaaccent";a:1:{s:1:"w";s:3:"-15";}s:9:"semicolon";a:1:{s:5:"space";s:3:"-40";}s:5:"space";a:10:{s:1:"T";s:4:"-100";s:6:"Tcaron";s:4:"-100";s:12:"Tcommaaccent";s:4:"-100";s:1:"V";s:3:"-80";s:1:"W";s:3:"-80";s:1:"Y";s:4:"-120";s:6:"Yacute";s:4:"-120";s:9:"Ydieresis";s:4:"-120";s:12:"quotedblleft";s:3:"-80";s:9:"quoteleft";s:3:"-60";}s:1:"v";a:21:{s:1:"a";s:3:"-20";s:6:"aacute";s:3:"-20";s:6:"abreve";s:3:"-20";s:11:"acircumflex";s:3:"-20";s:9:"adieresis";s:3:"-20";s:6:"agrave";s:3:"-20";s:7:"amacron";s:3:"-20";s:7:"aogonek";s:3:"-20";s:5:"aring";s:3:"-20";s:6:"atilde";s:3:"-20";s:5:"comma";s:3:"-80";s:1:"o";s:3:"-30";s:6:"oacute";s:3:"-30";s:11:"ocircumflex";s:3:"-30";s:9:"odieresis";s:3:"-30";s:6:"ograve";s:3:"-30";s:13:"ohungarumlaut";s:3:"-30";s:7:"omacron";s:3:"-30";s:6:"oslash";s:3:"-30";s:6:"otilde";s:3:"-30";s:6:"period";s:3:"-80";}s:1:"w";a:11:{s:5:"comma";s:3:"-40";s:1:"o";s:3:"-20";s:6:"oacute";s:3:"-20";s:11:"ocircumflex";s:3:"-20";s:9:"odieresis";s:3:"-20";s:6:"ograve";s:3:"-20";s:13:"ohungarumlaut";s:3:"-20";s:7:"omacron";s:3:"-20";s:6:"oslash";s:3:"-20";s:6:"otilde";s:3:"-20";s:6:"period";s:3:"-40";}s:1:"x";a:9:{s:1:"e";s:3:"-10";s:6:"eacute";s:3:"-10";s:6:"ecaron";s:3:"-10";s:11:"ecircumflex";s:3:"-10";s:9:"edieresis";s:3:"-10";s:10:"edotaccent";s:3:"-10";s:6:"egrave";s:3:"-10";s:7:"emacron";s:3:"-10";s:7:"eogonek";s:3:"-10";}s:1:"y";a:30:{s:1:"a";s:3:"-30";s:6:"aacute";s:3:"-30";s:6:"abreve";s:3:"-30";s:11:"acircumflex";s:3:"-30";s:9:"adieresis";s:3:"-30";s:6:"agrave";s:3:"-30";s:7:"amacron";s:3:"-30";s:7:"aogonek";s:3:"-30";s:5:"aring";s:3:"-30";s:6:"atilde";s:3:"-30";s:5:"comma";s:3:"-80";s:1:"e";s:3:"-10";s:6:"eacute";s:3:"-10";s:6:"ecaron";s:3:"-10";s:11:"ecircumflex";s:3:"-10";s:9:"edieresis";s:3:"-10";s:10:"edotaccent";s:3:"-10";s:6:"egrave";s:3:"-10";s:7:"emacron";s:3:"-10";s:7:"eogonek";s:3:"-10";s:1:"o";s:3:"-25";s:6:"oacute";s:3:"-25";s:11:"ocircumflex";s:3:"-25";s:9:"odieresis";s:3:"-25";s:6:"ograve";s:3:"-25";s:13:"ohungarumlaut";s:3:"-25";s:7:"omacron";s:3:"-25";s:6:"oslash";s:3:"-25";s:6:"otilde";s:3:"-25";s:6:"period";s:3:"-80";}s:6:"yacute";a:30:{s:1:"a";s:3:"-30";s:6:"aacute";s:3:"-30";s:6:"abreve";s:3:"-30";s:11:"acircumflex";s:3:"-30";s:9:"adieresis";s:3:"-30";s:6:"agrave";s:3:"-30";s:7:"amacron";s:3:"-30";s:7:"aogonek";s:3:"-30";s:5:"aring";s:3:"-30";s:6:"atilde";s:3:"-30";s:5:"comma";s:3:"-80";s:1:"e";s:3:"-10";s:6:"eacute";s:3:"-10";s:6:"ecaron";s:3:"-10";s:11:"ecircumflex";s:3:"-10";s:9:"edieresis";s:3:"-10";s:10:"edotaccent";s:3:"-10";s:6:"egrave";s:3:"-10";s:7:"emacron";s:3:"-10";s:7:"eogonek";s:3:"-10";s:1:"o";s:3:"-25";s:6:"oacute";s:3:"-25";s:11:"ocircumflex";s:3:"-25";s:9:"odieresis";s:3:"-25";s:6:"ograve";s:3:"-25";s:13:"ohungarumlaut";s:3:"-25";s:7:"omacron";s:3:"-25";s:6:"oslash";s:3:"-25";s:6:"otilde";s:3:"-25";s:6:"period";s:3:"-80";}s:9:"ydieresis";a:30:{s:1:"a";s:3:"-30";s:6:"aacute";s:3:"-30";s:6:"abreve";s:3:"-30";s:11:"acircumflex";s:3:"-30";s:9:"adieresis";s:3:"-30";s:6:"agrave";s:3:"-30";s:7:"amacron";s:3:"-30";s:7:"aogonek";s:3:"-30";s:5:"aring";s:3:"-30";s:6:"atilde";s:3:"-30";s:5:"comma";s:3:"-80";s:1:"e";s:3:"-10";s:6:"eacute";s:3:"-10";s:6:"ecaron";s:3:"-10";s:11:"ecircumflex";s:3:"-10";s:9:"edieresis";s:3:"-10";s:10:"edotaccent";s:3:"-10";s:6:"egrave";s:3:"-10";s:7:"emacron";s:3:"-10";s:7:"eogonek";s:3:"-10";s:1:"o";s:3:"-25";s:6:"oacute";s:3:"-25";s:11:"ocircumflex";s:3:"-25";s:9:"odieresis";s:3:"-25";s:6:"ograve";s:3:"-25";s:13:"ohungarumlaut";s:3:"-25";s:7:"omacron";s:3:"-25";s:6:"oslash";s:3:"-25";s:6:"otilde";s:3:"-25";s:6:"period";s:3:"-80";}s:1:"z";a:9:{s:1:"e";s:2:"10";s:6:"eacute";s:2:"10";s:6:"ecaron";s:2:"10";s:11:"ecircumflex";s:2:"10";s:9:"edieresis";s:2:"10";s:10:"edotaccent";s:2:"10";s:6:"egrave";s:2:"10";s:7:"emacron";s:2:"10";s:7:"eogonek";s:2:"10";}s:6:"zacute";a:9:{s:1:"e";s:2:"10";s:6:"eacute";s:2:"10";s:6:"ecaron";s:2:"10";s:11:"ecircumflex";s:2:"10";s:9:"edieresis";s:2:"10";s:10:"edotaccent";s:2:"10";s:6:"egrave";s:2:"10";s:7:"emacron";s:2:"10";s:7:"eogonek";s:2:"10";}s:6:"zcaron";a:9:{s:1:"e";s:2:"10";s:6:"eacute";s:2:"10";s:6:"ecaron";s:2:"10";s:11:"ecircumflex";s:2:"10";s:9:"edieresis";s:2:"10";s:10:"edotaccent";s:2:"10";s:6:"egrave";s:2:"10";s:7:"emacron";s:2:"10";s:7:"eogonek";s:2:"10";}s:10:"zdotaccent";a:9:{s:1:"e";s:2:"10";s:6:"eacute";s:2:"10";s:6:"ecaron";s:2:"10";s:11:"ecircumflex";s:2:"10";s:9:"edieresis";s:2:"10";s:10:"edotaccent";s:2:"10";s:6:"egrave";s:2:"10";s:7:"emacron";s:2:"10";s:7:"eogonek";s:2:"10";}}s:9:"_version_";i:1;}
\ No newline at end of file
Added: trunk/mapbender/http/classes/fonts/php_Helvetica-Oblique.afm
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/fonts/php_Helvetica-Oblique.afm?view=auto&rev=13
--- (empty file)
+++ trunk/mapbender/http/classes/fonts/php_Helvetica-Oblique.afm 2006-04-13 19:38:28+0000
@@ -0,0 +1 @@
+a:22:{s:8:"FontName";s:17:"Helvetica-Oblique";s:8:"FullName";s:17:"Helvetica Oblique";s:10:"FamilyName";s:9:"Helvetica";s:6:"Weight";s:6:"Medium";s:11:"ItalicAngle";s:3:"-12";s:12:"IsFixedPitch";s:5:"false";s:12:"CharacterSet";s:13:"ExtendedRoman";s:8:"FontBBox";a:4:{i:0;s:4:"-170";i:1;s:4:"-225";i:2;s:4:"1116";i:3;s:3:"931";}s:17:"UnderlinePosition";s:4:"-100";s:18:"UnderlineThickness";s:2:"50";s:7:"Version";s:7:"002.000";s:14:"EncodingScheme";s:21:"AdobeStandardEncoding";s:9:"CapHeight";s:3:"718";s:7:"XHeight";s:3:"523";s:8:"Ascender";s:3:"718";s:9:"Descender";s:4:"-207";s:5:"StdHW";s:2:"76";s:5:"StdVW";s:2:"88";s:16:"StartCharMetrics";s:3:"315";s:1:"C";a:464:{i:32;a:4:{s:1:"C";s:2:"32";s:2:"WX";s:3:"278";s:1:"N";s:5:"space";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}s:5:"space";a:4:{s:1:"C";s:2:"32";s:2:"WX";s:3:"278";s:1:"N";s:5:"space";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}i:33;a:4:{s:1:"C";s:2:"33";s:2:"WX";s:3:"278";s:1:"N";s:6:"exclam";s:1:"B";a:4:{i:0;s:2:"90";i:1;s:1:"0";i:2;s:3:"340";i:3;s:3:"718";}}s:6:"exclam";a:4:{s:1:"C";s:2:"33";s:2:"WX";s:3:"278";s:1:"N";s:6:"exclam";s:1:"B";a:4:{i:0;s:2:"90";i:1;s:1:"0";i:2;s:3:"340";i:3;s:3:"718";}}i:34;a:4:{s:1:"C";s:2:"34";s:2:"WX";s:3:"355";s:1:"N";s:8:"quotedbl";s:1:"B";a:4:{i:0;s:3:"168";i:1;s:3:"463";i:2;s:3:"438";i:3;s:3:"718";}}s:8:"quotedbl";a:4:{s:1:"C";s:2:"34";s:2:"WX";s:3:"355";s:1:"N";s:8:"quotedbl";s:1:"B";a:4:{i:0;s:3:"168";i:1;s:3:"463";i:2;s:3:"438";i:3;s:3:"718";}}i:35;a:4:{s:1:"C";s:2:"35";s:2:"WX";s:3:"556";s:1:"N";s:10:"numbersign";s:1:"B";a:4:{i:0;s:2:"73";i:1;s:1:"0";i:2;s:3:"631";i:3;s:3:"688";}}s:10:"numbersign";a:4:{s:1:"C";s:2:"35";s:2:"WX";s:3:"556";s:1:"N";s:10:"numbersign";s:1:"B";a:4:{i:0;s:2:"73";i:1;s:1:"0";i:2;s:3:"631";i:3;s:3:"688";}}i:36;a:4:{s:1:"C";s:2:"36";s:2:"WX";s:3:"556";s:1:"N";s:6:"dollar";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:4:"-115";i:2;s:3:"617";i:3;s:3:"775";}}s:6:"dollar";a:4:{s:1:"C";s:2:"36";s:2:"WX";s:3:"556";s:1:"N";s:6:"dollar";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:4:"-115";i:2;s:3:"617";i:3;s:3:"775";}}i:37;a:4:{s:1:"C";s:2:"37";s:2:"WX";s:3:"889";s:1:"N";s:7:"percent";s:1:"B";a:4:{i:0;s:3:"147";i:1;s:3:"-19";i:2;s:3:"889";i:3;s:3:"703";}}s:7:"percent";a:4:{s:1:"C";s:2:"37";s:2:"WX";s:3:"889";s:1:"N";s:7:"percent";s:1:"B";a:4:{i:0;s:3:"147";i:1;s:3:"-19";i:2;s:3:"889";i:3;s:3:"703";}}i:38;a:4:{s:1:"C";s:2:"38";s:2:"WX";s:3:"667";s:1:"N";s:9:"ampersand";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:3:"-15";i:2;s:3:"647";i:3;s:3:"718";}}s:9:"ampersand";a:4:{s:1:"C";s:2:"38";s:2:"WX";s:3:"667";s:1:"N";s:9:"ampersand";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:3:"-15";i:2;s:3:"647";i:3;s:3:"718";}}i:39;a:4:{s:1:"C";s:2:"39";s:2:"WX";s:3:"222";s:1:"N";s:10:"quoteright";s:1:"B";a:4:{i:0;s:3:"151";i:1;s:3:"463";i:2;s:3:"310";i:3;s:3:"718";}}s:10:"quoteright";a:4:{s:1:"C";s:2:"39";s:2:"WX";s:3:"222";s:1:"N";s:10:"quoteright";s:1:"B";a:4:{i:0;s:3:"151";i:1;s:3:"463";i:2;s:3:"310";i:3;s:3:"718";}}i:40;a:4:{s:1:"C";s:2:"40";s:2:"WX";s:3:"333";s:1:"N";s:9:"parenleft";s:1:"B";a:4:{i:0;s:3:"108";i:1;s:4:"-207";i:2;s:3:"454";i:3;s:3:"733";}}s:9:"parenleft";a:4:{s:1:"C";s:2:"40";s:2:"WX";s:3:"333";s:1:"N";s:9:"parenleft";s:1:"B";a:4:{i:0;s:3:"108";i:1;s:4:"-207";i:2;s:3:"454";i:3;s:3:"733";}}i:41;a:4:{s:1:"C";s:2:"41";s:2:"WX";s:3:"333";s:1:"N";s:10:"parenright";s:1:"B";a:4:{i:0;s:2:"-9";i:1;s:4:"-207";i:2;s:3:"337";i:3;s:3:"733";}}s:10:"parenright";a:4:{s:1:"C";s:2:"41";s:2:"WX";s:3:"333";s:1:"N";s:10:"parenright";s:1:"B";a:4:{i:0;s:2:"-9";i:1;s:4:"-207";i:2;s:3:"337";i:3;s:3:"733";}}i:42;a:4:{s:1:"C";s:2:"42";s:2:"WX";s:3:"389";s:1:"N";s:8:"asterisk";s:1:"B";a:4:{i:0;s:3:"165";i:1;s:3:"431";i:2;s:3:"475";i:3;s:3:"718";}}s:8:"asterisk";a:4:{s:1:"C";s:2:"42";s:2:"WX";s:3:"389";s:1:"N";s:8:"asterisk";s:1:"B";a:4:{i:0;s:3:"165";i:1;s:3:"431";i:2;s:3:"475";i:3;s:3:"718";}}i:43;a:4:{s:1:"C";s:2:"43";s:2:"WX";s:3:"584";s:1:"N";s:4:"plus";s:1:"B";a:4:{i:0;s:2:"85";i:1;s:1:"0";i:2;s:3:"606";i:3;s:3:"505";}}s:4:"plus";a:4:{s:1:"C";s:2:"43";s:2:"WX";s:3:"584";s:1:"N";s:4:"plus";s:1:"B";a:4:{i:0;s:2:"85";i:1;s:1:"0";i:2;s:3:"606";i:3;s:3:"505";}}i:44;a:4:{s:1:"C";s:2:"44";s:2:"WX";s:3:"278";s:1:"N";s:5:"comma";s:1:"B";a:4:{i:0;s:2:"56";i:1;s:4:"-147";i:2;s:3:"214";i:3;s:3:"106";}}s:5:"comma";a:4:{s:1:"C";s:2:"44";s:2:"WX";s:3:"278";s:1:"N";s:5:"comma";s:1:"B";a:4:{i:0;s:2:"56";i:1;s:4:"-147";i:2;s:3:"214";i:3;s:3:"106";}}i:45;a:4:{s:1:"C";s:2:"45";s:2:"WX";s:3:"333";s:1:"N";s:6:"hyphen";s:1:"B";a:4:{i:0;s:2:"93";i:1;s:3:"232";i:2;s:3:"357";i:3;s:3:"322";}}s:6:"hyphen";a:4:{s:1:"C";s:2:"45";s:2:"WX";s:3:"333";s:1:"N";s:6:"hyphen";s:1:"B";a:4:{i:0;s:2:"93";i:1;s:3:"232";i:2;s:3:"357";i:3;s:3:"322";}}i:46;a:4:{s:1:"C";s:2:"46";s:2:"WX";s:3:"278";s:1:"N";s:6:"period";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:1:"0";i:2;s:3:"214";i:3;s:3:"106";}}s:6:"period";a:4:{s:1:"C";s:2:"46";s:2:"WX";s:3:"278";s:1:"N";s:6:"period";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:1:"0";i:2;s:3:"214";i:3;s:3:"106";}}i:47;a:4:{s:1:"C";s:2:"47";s:2:"WX";s:3:"278";s:1:"N";s:5:"slash";s:1:"B";a:4:{i:0;s:3:"-21";i:1;s:3:"-19";i:2;s:3:"452";i:3;s:3:"737";}}s:5:"slash";a:4:{s:1:"C";s:2:"47";s:2:"WX";s:3:"278";s:1:"N";s:5:"slash";s:1:"B";a:4:{i:0;s:3:"-21";i:1;s:3:"-19";i:2;s:3:"452";i:3;s:3:"737";}}i:48;a:4:{s:1:"C";s:2:"48";s:2:"WX";s:3:"556";s:1:"N";s:4:"zero";s:1:"B";a:4:{i:0;s:2:"93";i:1;s:3:"-19";i:2;s:3:"608";i:3;s:3:"703";}}s:4:"zero";a:4:{s:1:"C";s:2:"48";s:2:"WX";s:3:"556";s:1:"N";s:4:"zero";s:1:"B";a:4:{i:0;s:2:"93";i:1;s:3:"-19";i:2;s:3:"608";i:3;s:3:"703";}}i:49;a:4:{s:1:"C";s:2:"49";s:2:"WX";s:3:"556";s:1:"N";s:3:"one";s:1:"B";a:4:{i:0;s:3:"207";i:1;s:1:"0";i:2;s:3:"508";i:3;s:3:"703";}}s:3:"one";a:4:{s:1:"C";s:2:"49";s:2:"WX";s:3:"556";s:1:"N";s:3:"one";s:1:"B";a:4:{i:0;s:3:"207";i:1;s:1:"0";i:2;s:3:"508";i:3;s:3:"703";}}i:50;a:4:{s:1:"C";s:2:"50";s:2:"WX";s:3:"556";s:1:"N";s:3:"two";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"617";i:3;s:3:"703";}}s:3:"two";a:4:{s:1:"C";s:2:"50";s:2:"WX";s:3:"556";s:1:"N";s:3:"two";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"617";i:3;s:3:"703";}}i:51;a:4:{s:1:"C";s:2:"51";s:2:"WX";s:3:"556";s:1:"N";s:5:"three";s:1:"B";a:4:{i:0;s:2:"75";i:1;s:3:"-19";i:2;s:3:"610";i:3;s:3:"703";}}s:5:"three";a:4:{s:1:"C";s:2:"51";s:2:"WX";s:3:"556";s:1:"N";s:5:"three";s:1:"B";a:4:{i:0;s:2:"75";i:1;s:3:"-19";i:2;s:3:"610";i:3;s:3:"703";}}i:52;a:4:{s:1:"C";s:2:"52";s:2:"WX";s:3:"556";s:1:"N";s:4:"four";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:1:"0";i:2;s:3:"576";i:3;s:3:"703";}}s:4:"four";a:4:{s:1:"C";s:2:"52";s:2:"WX";s:3:"556";s:1:"N";s:4:"four";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:1:"0";i:2;s:3:"576";i:3;s:3:"703";}}i:53;a:4:{s:1:"C";s:2:"53";s:2:"WX";s:3:"556";s:1:"N";s:4:"five";s:1:"B";a:4:{i:0;s:2:"68";i:1;s:3:"-19";i:2;s:3:"621";i:3;s:3:"688";}}s:4:"five";a:4:{s:1:"C";s:2:"53";s:2:"WX";s:3:"556";s:1:"N";s:4:"five";s:1:"B";a:4:{i:0;s:2:"68";i:1;s:3:"-19";i:2;s:3:"621";i:3;s:3:"688";}}i:54;a:4:{s:1:"C";s:2:"54";s:2:"WX";s:3:"556";s:1:"N";s:3:"six";s:1:"B";a:4:{i:0;s:2:"91";i:1;s:3:"-19";i:2;s:3:"615";i:3;s:3:"703";}}s:3:"six";a:4:{s:1:"C";s:2:"54";s:2:"WX";s:3:"556";s:1:"N";s:3:"six";s:1:"B";a:4:{i:0;s:2:"91";i:1;s:3:"-19";i:2;s:3:"615";i:3;s:3:"703";}}i:55;a:4:{s:1:"C";s:2:"55";s:2:"WX";s:3:"556";s:1:"N";s:5:"seven";s:1:"B";a:4:{i:0;s:3:"137";i:1;s:1:"0";i:2;s:3:"669";i:3;s:3:"688";}}s:5:"seven";a:4:{s:1:"C";s:2:"55";s:2:"WX";s:3:"556";s:1:"N";s:5:"seven";s:1:"B";a:4:{i:0;s:3:"137";i:1;s:1:"0";i:2;s:3:"669";i:3;s:3:"688";}}i:56;a:4:{s:1:"C";s:2:"56";s:2:"WX";s:3:"556";s:1:"N";s:5:"eight";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"-19";i:2;s:3:"607";i:3;s:3:"703";}}s:5:"eight";a:4:{s:1:"C";s:2:"56";s:2:"WX";s:3:"556";s:1:"N";s:5:"eight";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"-19";i:2;s:3:"607";i:3;s:3:"703";}}i:57;a:4:{s:1:"C";s:2:"57";s:2:"WX";s:3:"556";s:1:"N";s:4:"nine";s:1:"B";a:4:{i:0;s:2:"82";i:1;s:3:"-19";i:2;s:3:"609";i:3;s:3:"703";}}s:4:"nine";a:4:{s:1:"C";s:2:"57";s:2:"WX";s:3:"556";s:1:"N";s:4:"nine";s:1:"B";a:4:{i:0;s:2:"82";i:1;s:3:"-19";i:2;s:3:"609";i:3;s:3:"703";}}i:58;a:4:{s:1:"C";s:2:"58";s:2:"WX";s:3:"278";s:1:"N";s:5:"colon";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:1:"0";i:2;s:3:"301";i:3;s:3:"516";}}s:5:"colon";a:4:{s:1:"C";s:2:"58";s:2:"WX";s:3:"278";s:1:"N";s:5:"colon";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:1:"0";i:2;s:3:"301";i:3;s:3:"516";}}i:59;a:4:{s:1:"C";s:2:"59";s:2:"WX";s:3:"278";s:1:"N";s:9:"semicolon";s:1:"B";a:4:{i:0;s:2:"56";i:1;s:4:"-147";i:2;s:3:"301";i:3;s:3:"516";}}s:9:"semicolon";a:4:{s:1:"C";s:2:"59";s:2:"WX";s:3:"278";s:1:"N";s:9:"semicolon";s:1:"B";a:4:{i:0;s:2:"56";i:1;s:4:"-147";i:2;s:3:"301";i:3;s:3:"516";}}i:60;a:4:{s:1:"C";s:2:"60";s:2:"WX";s:3:"584";s:1:"N";s:4:"less";s:1:"B";a:4:{i:0;s:2:"94";i:1;s:2:"11";i:2;s:3:"641";i:3;s:3:"495";}}s:4:"less";a:4:{s:1:"C";s:2:"60";s:2:"WX";s:3:"584";s:1:"N";s:4:"less";s:1:"B";a:4:{i:0;s:2:"94";i:1;s:2:"11";i:2;s:3:"641";i:3;s:3:"495";}}i:61;a:4:{s:1:"C";s:2:"61";s:2:"WX";s:3:"584";s:1:"N";s:5:"equal";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:3:"115";i:2;s:3:"628";i:3;s:3:"390";}}s:5:"equal";a:4:{s:1:"C";s:2:"61";s:2:"WX";s:3:"584";s:1:"N";s:5:"equal";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:3:"115";i:2;s:3:"628";i:3;s:3:"390";}}i:62;a:4:{s:1:"C";s:2:"62";s:2:"WX";s:3:"584";s:1:"N";s:7:"greater";s:1:"B";a:4:{i:0;s:2:"50";i:1;s:2:"11";i:2;s:3:"597";i:3;s:3:"495";}}s:7:"greater";a:4:{s:1:"C";s:2:"62";s:2:"WX";s:3:"584";s:1:"N";s:7:"greater";s:1:"B";a:4:{i:0;s:2:"50";i:1;s:2:"11";i:2;s:3:"597";i:3;s:3:"495";}}i:63;a:4:{s:1:"C";s:2:"63";s:2:"WX";s:3:"556";s:1:"N";s:8:"question";s:1:"B";a:4:{i:0;s:3:"161";i:1;s:1:"0";i:2;s:3:"610";i:3;s:3:"727";}}s:8:"question";a:4:{s:1:"C";s:2:"63";s:2:"WX";s:3:"556";s:1:"N";s:8:"question";s:1:"B";a:4:{i:0;s:3:"161";i:1;s:1:"0";i:2;s:3:"610";i:3;s:3:"727";}}i:64;a:4:{s:1:"C";s:2:"64";s:2:"WX";s:4:"1015";s:1:"N";s:2:"at";s:1:"B";a:4:{i:0;s:3:"215";i:1;s:3:"-19";i:2;s:3:"965";i:3;s:3:"737";}}s:2:"at";a:4:{s:1:"C";s:2:"64";s:2:"WX";s:4:"1015";s:1:"N";s:2:"at";s:1:"B";a:4:{i:0;s:3:"215";i:1;s:3:"-19";i:2;s:3:"965";i:3;s:3:"737";}}i:65;a:4:{s:1:"C";s:2:"65";s:2:"WX";s:3:"667";s:1:"N";s:1:"A";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"654";i:3;s:3:"718";}}s:1:"A";a:4:{s:1:"C";s:2:"65";s:2:"WX";s:3:"667";s:1:"N";s:1:"A";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"654";i:3;s:3:"718";}}i:66;a:4:{s:1:"C";s:2:"66";s:2:"WX";s:3:"667";s:1:"N";s:1:"B";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:1:"0";i:2;s:3:"712";i:3;s:3:"718";}}s:1:"B";a:4:{s:1:"C";s:2:"66";s:2:"WX";s:3:"667";s:1:"N";s:1:"B";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:1:"0";i:2;s:3:"712";i:3;s:3:"718";}}i:67;a:4:{s:1:"C";s:2:"67";s:2:"WX";s:3:"722";s:1:"N";s:1:"C";s:1:"B";a:4:{i:0;s:3:"108";i:1;s:3:"-19";i:2;s:3:"782";i:3;s:3:"737";}}s:1:"C";a:4:{s:1:"C";s:2:"67";s:2:"WX";s:3:"722";s:1:"N";s:1:"C";s:1:"B";a:4:{i:0;s:3:"108";i:1;s:3:"-19";i:2;s:3:"782";i:3;s:3:"737";}}i:68;a:4:{s:1:"C";s:2:"68";s:2:"WX";s:3:"722";s:1:"N";s:1:"D";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:1:"0";i:2;s:3:"764";i:3;s:3:"718";}}s:1:"D";a:4:{s:1:"C";s:2:"68";s:2:"WX";s:3:"722";s:1:"N";s:1:"D";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:1:"0";i:2;s:3:"764";i:3;s:3:"718";}}i:69;a:4:{s:1:"C";s:2:"69";s:2:"WX";s:3:"667";s:1:"N";s:1:"E";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"762";i:3;s:3:"718";}}s:1:"E";a:4:{s:1:"C";s:2:"69";s:2:"WX";s:3:"667";s:1:"N";s:1:"E";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"762";i:3;s:3:"718";}}i:70;a:4:{s:1:"C";s:2:"70";s:2:"WX";s:3:"611";s:1:"N";s:1:"F";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"736";i:3;s:3:"718";}}s:1:"F";a:4:{s:1:"C";s:2:"70";s:2:"WX";s:3:"611";s:1:"N";s:1:"F";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"736";i:3;s:3:"718";}}i:71;a:4:{s:1:"C";s:2:"71";s:2:"WX";s:3:"778";s:1:"N";s:1:"G";s:1:"B";a:4:{i:0;s:3:"111";i:1;s:3:"-19";i:2;s:3:"799";i:3;s:3:"737";}}s:1:"G";a:4:{s:1:"C";s:2:"71";s:2:"WX";s:3:"778";s:1:"N";s:1:"G";s:1:"B";a:4:{i:0;s:3:"111";i:1;s:3:"-19";i:2;s:3:"799";i:3;s:3:"737";}}i:72;a:4:{s:1:"C";s:2:"72";s:2:"WX";s:3:"722";s:1:"N";s:1:"H";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"799";i:3;s:3:"718";}}s:1:"H";a:4:{s:1:"C";s:2:"72";s:2:"WX";s:3:"722";s:1:"N";s:1:"H";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"799";i:3;s:3:"718";}}i:73;a:4:{s:1:"C";s:2:"73";s:2:"WX";s:3:"278";s:1:"N";s:1:"I";s:1:"B";a:4:{i:0;s:2:"91";i:1;s:1:"0";i:2;s:3:"341";i:3;s:3:"718";}}s:1:"I";a:4:{s:1:"C";s:2:"73";s:2:"WX";s:3:"278";s:1:"N";s:1:"I";s:1:"B";a:4:{i:0;s:2:"91";i:1;s:1:"0";i:2;s:3:"341";i:3;s:3:"718";}}i:74;a:4:{s:1:"C";s:2:"74";s:2:"WX";s:3:"500";s:1:"N";s:1:"J";s:1:"B";a:4:{i:0;s:2:"47";i:1;s:3:"-19";i:2;s:3:"581";i:3;s:3:"718";}}s:1:"J";a:4:{s:1:"C";s:2:"74";s:2:"WX";s:3:"500";s:1:"N";s:1:"J";s:1:"B";a:4:{i:0;s:2:"47";i:1;s:3:"-19";i:2;s:3:"581";i:3;s:3:"718";}}i:75;a:4:{s:1:"C";s:2:"75";s:2:"WX";s:3:"667";s:1:"N";s:1:"K";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"808";i:3;s:3:"718";}}s:1:"K";a:4:{s:1:"C";s:2:"75";s:2:"WX";s:3:"667";s:1:"N";s:1:"K";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"808";i:3;s:3:"718";}}i:76;a:4:{s:1:"C";s:2:"76";s:2:"WX";s:3:"556";s:1:"N";s:1:"L";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"555";i:3;s:3:"718";}}s:1:"L";a:4:{s:1:"C";s:2:"76";s:2:"WX";s:3:"556";s:1:"N";s:1:"L";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"555";i:3;s:3:"718";}}i:77;a:4:{s:1:"C";s:2:"77";s:2:"WX";s:3:"833";s:1:"N";s:1:"M";s:1:"B";a:4:{i:0;s:2:"73";i:1;s:1:"0";i:2;s:3:"914";i:3;s:3:"718";}}s:1:"M";a:4:{s:1:"C";s:2:"77";s:2:"WX";s:3:"833";s:1:"N";s:1:"M";s:1:"B";a:4:{i:0;s:2:"73";i:1;s:1:"0";i:2;s:3:"914";i:3;s:3:"718";}}i:78;a:4:{s:1:"C";s:2:"78";s:2:"WX";s:3:"722";s:1:"N";s:1:"N";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"799";i:3;s:3:"718";}}s:1:"N";a:4:{s:1:"C";s:2:"78";s:2:"WX";s:3:"722";s:1:"N";s:1:"N";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"799";i:3;s:3:"718";}}i:79;a:4:{s:1:"C";s:2:"79";s:2:"WX";s:3:"778";s:1:"N";s:1:"O";s:1:"B";a:4:{i:0;s:3:"105";i:1;s:3:"-19";i:2;s:3:"826";i:3;s:3:"737";}}s:1:"O";a:4:{s:1:"C";s:2:"79";s:2:"WX";s:3:"778";s:1:"N";s:1:"O";s:1:"B";a:4:{i:0;s:3:"105";i:1;s:3:"-19";i:2;s:3:"826";i:3;s:3:"737";}}i:80;a:4:{s:1:"C";s:2:"80";s:2:"WX";s:3:"667";s:1:"N";s:1:"P";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"737";i:3;s:3:"718";}}s:1:"P";a:4:{s:1:"C";s:2:"80";s:2:"WX";s:3:"667";s:1:"N";s:1:"P";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"737";i:3;s:3:"718";}}i:81;a:4:{s:1:"C";s:2:"81";s:2:"WX";s:3:"778";s:1:"N";s:1:"Q";s:1:"B";a:4:{i:0;s:3:"105";i:1;s:3:"-56";i:2;s:3:"826";i:3;s:3:"737";}}s:1:"Q";a:4:{s:1:"C";s:2:"81";s:2:"WX";s:3:"778";s:1:"N";s:1:"Q";s:1:"B";a:4:{i:0;s:3:"105";i:1;s:3:"-56";i:2;s:3:"826";i:3;s:3:"737";}}i:82;a:4:{s:1:"C";s:2:"82";s:2:"WX";s:3:"722";s:1:"N";s:1:"R";s:1:"B";a:4:{i:0;s:2:"88";i:1;s:1:"0";i:2;s:3:"773";i:3;s:3:"718";}}s:1:"R";a:4:{s:1:"C";s:2:"82";s:2:"WX";s:3:"722";s:1:"N";s:1:"R";s:1:"B";a:4:{i:0;s:2:"88";i:1;s:1:"0";i:2;s:3:"773";i:3;s:3:"718";}}i:83;a:4:{s:1:"C";s:2:"83";s:2:"WX";s:3:"667";s:1:"N";s:1:"S";s:1:"B";a:4:{i:0;s:2:"90";i:1;s:3:"-19";i:2;s:3:"713";i:3;s:3:"737";}}s:1:"S";a:4:{s:1:"C";s:2:"83";s:2:"WX";s:3:"667";s:1:"N";s:1:"S";s:1:"B";a:4:{i:0;s:2:"90";i:1;s:3:"-19";i:2;s:3:"713";i:3;s:3:"737";}}i:84;a:4:{s:1:"C";s:2:"84";s:2:"WX";s:3:"611";s:1:"N";s:1:"T";s:1:"B";a:4:{i:0;s:3:"148";i:1;s:1:"0";i:2;s:3:"750";i:3;s:3:"718";}}s:1:"T";a:4:{s:1:"C";s:2:"84";s:2:"WX";s:3:"611";s:1:"N";s:1:"T";s:1:"B";a:4:{i:0;s:3:"148";i:1;s:1:"0";i:2;s:3:"750";i:3;s:3:"718";}}i:85;a:4:{s:1:"C";s:2:"85";s:2:"WX";s:3:"722";s:1:"N";s:1:"U";s:1:"B";a:4:{i:0;s:3:"123";i:1;s:3:"-19";i:2;s:3:"797";i:3;s:3:"718";}}s:1:"U";a:4:{s:1:"C";s:2:"85";s:2:"WX";s:3:"722";s:1:"N";s:1:"U";s:1:"B";a:4:{i:0;s:3:"123";i:1;s:3:"-19";i:2;s:3:"797";i:3;s:3:"718";}}i:86;a:4:{s:1:"C";s:2:"86";s:2:"WX";s:3:"667";s:1:"N";s:1:"V";s:1:"B";a:4:{i:0;s:3:"173";i:1;s:1:"0";i:2;s:3:"800";i:3;s:3:"718";}}s:1:"V";a:4:{s:1:"C";s:2:"86";s:2:"WX";s:3:"667";s:1:"N";s:1:"V";s:1:"B";a:4:{i:0;s:3:"173";i:1;s:1:"0";i:2;s:3:"800";i:3;s:3:"718";}}i:87;a:4:{s:1:"C";s:2:"87";s:2:"WX";s:3:"944";s:1:"N";s:1:"W";s:1:"B";a:4:{i:0;s:3:"169";i:1;s:1:"0";i:2;s:4:"1081";i:3;s:3:"718";}}s:1:"W";a:4:{s:1:"C";s:2:"87";s:2:"WX";s:3:"944";s:1:"N";s:1:"W";s:1:"B";a:4:{i:0;s:3:"169";i:1;s:1:"0";i:2;s:4:"1081";i:3;s:3:"718";}}i:88;a:4:{s:1:"C";s:2:"88";s:2:"WX";s:3:"667";s:1:"N";s:1:"X";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:1:"0";i:2;s:3:"790";i:3;s:3:"718";}}s:1:"X";a:4:{s:1:"C";s:2:"88";s:2:"WX";s:3:"667";s:1:"N";s:1:"X";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:1:"0";i:2;s:3:"790";i:3;s:3:"718";}}i:89;a:4:{s:1:"C";s:2:"89";s:2:"WX";s:3:"667";s:1:"N";s:1:"Y";s:1:"B";a:4:{i:0;s:3:"167";i:1;s:1:"0";i:2;s:3:"806";i:3;s:3:"718";}}s:1:"Y";a:4:{s:1:"C";s:2:"89";s:2:"WX";s:3:"667";s:1:"N";s:1:"Y";s:1:"B";a:4:{i:0;s:3:"167";i:1;s:1:"0";i:2;s:3:"806";i:3;s:3:"718";}}i:90;a:4:{s:1:"C";s:2:"90";s:2:"WX";s:3:"611";s:1:"N";s:1:"Z";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:1:"0";i:2;s:3:"741";i:3;s:3:"718";}}s:1:"Z";a:4:{s:1:"C";s:2:"90";s:2:"WX";s:3:"611";s:1:"N";s:1:"Z";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:1:"0";i:2;s:3:"741";i:3;s:3:"718";}}i:91;a:4:{s:1:"C";s:2:"91";s:2:"WX";s:3:"278";s:1:"N";s:11:"bracketleft";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:4:"-196";i:2;s:3:"403";i:3;s:3:"722";}}s:11:"bracketleft";a:4:{s:1:"C";s:2:"91";s:2:"WX";s:3:"278";s:1:"N";s:11:"bracketleft";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:4:"-196";i:2;s:3:"403";i:3;s:3:"722";}}i:92;a:4:{s:1:"C";s:2:"92";s:2:"WX";s:3:"278";s:1:"N";s:9:"backslash";s:1:"B";a:4:{i:0;s:3:"140";i:1;s:3:"-19";i:2;s:3:"291";i:3;s:3:"737";}}s:9:"backslash";a:4:{s:1:"C";s:2:"92";s:2:"WX";s:3:"278";s:1:"N";s:9:"backslash";s:1:"B";a:4:{i:0;s:3:"140";i:1;s:3:"-19";i:2;s:3:"291";i:3;s:3:"737";}}i:93;a:4:{s:1:"C";s:2:"93";s:2:"WX";s:3:"278";s:1:"N";s:12:"bracketright";s:1:"B";a:4:{i:0;s:3:"-14";i:1;s:4:"-196";i:2;s:3:"368";i:3;s:3:"722";}}s:12:"bracketright";a:4:{s:1:"C";s:2:"93";s:2:"WX";s:3:"278";s:1:"N";s:12:"bracketright";s:1:"B";a:4:{i:0;s:3:"-14";i:1;s:4:"-196";i:2;s:3:"368";i:3;s:3:"722";}}i:94;a:4:{s:1:"C";s:2:"94";s:2:"WX";s:3:"469";s:1:"N";s:11:"asciicircum";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"264";i:2;s:3:"539";i:3;s:3:"688";}}s:11:"asciicircum";a:4:{s:1:"C";s:2:"94";s:2:"WX";s:3:"469";s:1:"N";s:11:"asciicircum";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"264";i:2;s:3:"539";i:3;s:3:"688";}}i:95;a:4:{s:1:"C";s:2:"95";s:2:"WX";s:3:"556";s:1:"N";s:10:"underscore";s:1:"B";a:4:{i:0;s:3:"-27";i:1;s:4:"-125";i:2;s:3:"540";i:3;s:3:"-75";}}s:10:"underscore";a:4:{s:1:"C";s:2:"95";s:2:"WX";s:3:"556";s:1:"N";s:10:"underscore";s:1:"B";a:4:{i:0;s:3:"-27";i:1;s:4:"-125";i:2;s:3:"540";i:3;s:3:"-75";}}i:96;a:4:{s:1:"C";s:2:"96";s:2:"WX";s:3:"222";s:1:"N";s:9:"quoteleft";s:1:"B";a:4:{i:0;s:3:"165";i:1;s:3:"470";i:2;s:3:"323";i:3;s:3:"725";}}s:9:"quoteleft";a:4:{s:1:"C";s:2:"96";s:2:"WX";s:3:"222";s:1:"N";s:9:"quoteleft";s:1:"B";a:4:{i:0;s:3:"165";i:1;s:3:"470";i:2;s:3:"323";i:3;s:3:"725";}}i:97;a:4:{s:1:"C";s:2:"97";s:2:"WX";s:3:"556";s:1:"N";s:1:"a";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:3:"-15";i:2;s:3:"559";i:3;s:3:"538";}}s:1:"a";a:4:{s:1:"C";s:2:"97";s:2:"WX";s:3:"556";s:1:"N";s:1:"a";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:3:"-15";i:2;s:3:"559";i:3;s:3:"538";}}i:98;a:4:{s:1:"C";s:2:"98";s:2:"WX";s:3:"556";s:1:"N";s:1:"b";s:1:"B";a:4:{i:0;s:2:"58";i:1;s:3:"-15";i:2;s:3:"584";i:3;s:3:"718";}}s:1:"b";a:4:{s:1:"C";s:2:"98";s:2:"WX";s:3:"556";s:1:"N";s:1:"b";s:1:"B";a:4:{i:0;s:2:"58";i:1;s:3:"-15";i:2;s:3:"584";i:3;s:3:"718";}}i:99;a:4:{s:1:"C";s:2:"99";s:2:"WX";s:3:"500";s:1:"N";s:1:"c";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"-15";i:2;s:3:"553";i:3;s:3:"538";}}s:1:"c";a:4:{s:1:"C";s:2:"99";s:2:"WX";s:3:"500";s:1:"N";s:1:"c";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"-15";i:2;s:3:"553";i:3;s:3:"538";}}i:100;a:4:{s:1:"C";s:3:"100";s:2:"WX";s:3:"556";s:1:"N";s:1:"d";s:1:"B";a:4:{i:0;s:2:"84";i:1;s:3:"-15";i:2;s:3:"652";i:3;s:3:"718";}}s:1:"d";a:4:{s:1:"C";s:3:"100";s:2:"WX";s:3:"556";s:1:"N";s:1:"d";s:1:"B";a:4:{i:0;s:2:"84";i:1;s:3:"-15";i:2;s:3:"652";i:3;s:3:"718";}}i:101;a:4:{s:1:"C";s:3:"101";s:2:"WX";s:3:"556";s:1:"N";s:1:"e";s:1:"B";a:4:{i:0;s:2:"84";i:1;s:3:"-15";i:2;s:3:"578";i:3;s:3:"538";}}s:1:"e";a:4:{s:1:"C";s:3:"101";s:2:"WX";s:3:"556";s:1:"N";s:1:"e";s:1:"B";a:4:{i:0;s:2:"84";i:1;s:3:"-15";i:2;s:3:"578";i:3;s:3:"538";}}i:102;a:5:{s:1:"C";s:3:"102";s:2:"WX";s:3:"278";s:1:"N";s:1:"f";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"416";i:3;s:3:"728";}s:1:"L";a:2:{i:0;s:1:"l";i:1;s:2:"fl";}}s:1:"f";a:5:{s:1:"C";s:3:"102";s:2:"WX";s:3:"278";s:1:"N";s:1:"f";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"416";i:3;s:3:"728";}s:1:"L";a:2:{i:0;s:1:"l";i:1;s:2:"fl";}}i:103;a:4:{s:1:"C";s:3:"103";s:2:"WX";s:3:"556";s:1:"N";s:1:"g";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:4:"-220";i:2;s:3:"610";i:3;s:3:"538";}}s:1:"g";a:4:{s:1:"C";s:3:"103";s:2:"WX";s:3:"556";s:1:"N";s:1:"g";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:4:"-220";i:2;s:3:"610";i:3;s:3:"538";}}i:104;a:4:{s:1:"C";s:3:"104";s:2:"WX";s:3:"556";s:1:"N";s:1:"h";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:1:"0";i:2;s:3:"573";i:3;s:3:"718";}}s:1:"h";a:4:{s:1:"C";s:3:"104";s:2:"WX";s:3:"556";s:1:"N";s:1:"h";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:1:"0";i:2;s:3:"573";i:3;s:3:"718";}}i:105;a:4:{s:1:"C";s:3:"105";s:2:"WX";s:3:"222";s:1:"N";s:1:"i";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:1:"0";i:2;s:3:"308";i:3;s:3:"718";}}s:1:"i";a:4:{s:1:"C";s:3:"105";s:2:"WX";s:3:"222";s:1:"N";s:1:"i";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:1:"0";i:2;s:3:"308";i:3;s:3:"718";}}i:106;a:4:{s:1:"C";s:3:"106";s:2:"WX";s:3:"222";s:1:"N";s:1:"j";s:1:"B";a:4:{i:0;s:3:"-60";i:1;s:4:"-210";i:2;s:3:"308";i:3;s:3:"718";}}s:1:"j";a:4:{s:1:"C";s:3:"106";s:2:"WX";s:3:"222";s:1:"N";s:1:"j";s:1:"B";a:4:{i:0;s:3:"-60";i:1;s:4:"-210";i:2;s:3:"308";i:3;s:3:"718";}}i:107;a:4:{s:1:"C";s:3:"107";s:2:"WX";s:3:"500";s:1:"N";s:1:"k";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:1:"0";i:2;s:3:"600";i:3;s:3:"718";}}s:1:"k";a:4:{s:1:"C";s:3:"107";s:2:"WX";s:3:"500";s:1:"N";s:1:"k";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:1:"0";i:2;s:3:"600";i:3;s:3:"718";}}i:108;a:4:{s:1:"C";s:3:"108";s:2:"WX";s:3:"222";s:1:"N";s:1:"l";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:1:"0";i:2;s:3:"308";i:3;s:3:"718";}}s:1:"l";a:4:{s:1:"C";s:3:"108";s:2:"WX";s:3:"222";s:1:"N";s:1:"l";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:1:"0";i:2;s:3:"308";i:3;s:3:"718";}}i:109;a:4:{s:1:"C";s:3:"109";s:2:"WX";s:3:"833";s:1:"N";s:1:"m";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:1:"0";i:2;s:3:"852";i:3;s:3:"538";}}s:1:"m";a:4:{s:1:"C";s:3:"109";s:2:"WX";s:3:"833";s:1:"N";s:1:"m";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:1:"0";i:2;s:3:"852";i:3;s:3:"538";}}i:110;a:4:{s:1:"C";s:3:"110";s:2:"WX";s:3:"556";s:1:"N";s:1:"n";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:1:"0";i:2;s:3:"573";i:3;s:3:"538";}}s:1:"n";a:4:{s:1:"C";s:3:"110";s:2:"WX";s:3:"556";s:1:"N";s:1:"n";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:1:"0";i:2;s:3:"573";i:3;s:3:"538";}}i:111;a:4:{s:1:"C";s:3:"111";s:2:"WX";s:3:"556";s:1:"N";s:1:"o";s:1:"B";a:4:{i:0;s:2:"83";i:1;s:3:"-14";i:2;s:3:"585";i:3;s:3:"538";}}s:1:"o";a:4:{s:1:"C";s:3:"111";s:2:"WX";s:3:"556";s:1:"N";s:1:"o";s:1:"B";a:4:{i:0;s:2:"83";i:1;s:3:"-14";i:2;s:3:"585";i:3;s:3:"538";}}i:112;a:4:{s:1:"C";s:3:"112";s:2:"WX";s:3:"556";s:1:"N";s:1:"p";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:4:"-207";i:2;s:3:"584";i:3;s:3:"538";}}s:1:"p";a:4:{s:1:"C";s:3:"112";s:2:"WX";s:3:"556";s:1:"N";s:1:"p";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:4:"-207";i:2;s:3:"584";i:3;s:3:"538";}}i:113;a:4:{s:1:"C";s:3:"113";s:2:"WX";s:3:"556";s:1:"N";s:1:"q";s:1:"B";a:4:{i:0;s:2:"84";i:1;s:4:"-207";i:2;s:3:"605";i:3;s:3:"538";}}s:1:"q";a:4:{s:1:"C";s:3:"113";s:2:"WX";s:3:"556";s:1:"N";s:1:"q";s:1:"B";a:4:{i:0;s:2:"84";i:1;s:4:"-207";i:2;s:3:"605";i:3;s:3:"538";}}i:114;a:4:{s:1:"C";s:3:"114";s:2:"WX";s:3:"333";s:1:"N";s:1:"r";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"446";i:3;s:3:"538";}}s:1:"r";a:4:{s:1:"C";s:3:"114";s:2:"WX";s:3:"333";s:1:"N";s:1:"r";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"446";i:3;s:3:"538";}}i:115;a:4:{s:1:"C";s:3:"115";s:2:"WX";s:3:"500";s:1:"N";s:1:"s";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:3:"-15";i:2;s:3:"529";i:3;s:3:"538";}}s:1:"s";a:4:{s:1:"C";s:3:"115";s:2:"WX";s:3:"500";s:1:"N";s:1:"s";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:3:"-15";i:2;s:3:"529";i:3;s:3:"538";}}i:116;a:4:{s:1:"C";s:3:"116";s:2:"WX";s:3:"278";s:1:"N";s:1:"t";s:1:"B";a:4:{i:0;s:3:"102";i:1;s:2:"-7";i:2;s:3:"368";i:3;s:3:"669";}}s:1:"t";a:4:{s:1:"C";s:3:"116";s:2:"WX";s:3:"278";s:1:"N";s:1:"t";s:1:"B";a:4:{i:0;s:3:"102";i:1;s:2:"-7";i:2;s:3:"368";i:3;s:3:"669";}}i:117;a:4:{s:1:"C";s:3:"117";s:2:"WX";s:3:"556";s:1:"N";s:1:"u";s:1:"B";a:4:{i:0;s:2:"94";i:1;s:3:"-15";i:2;s:3:"600";i:3;s:3:"523";}}s:1:"u";a:4:{s:1:"C";s:3:"117";s:2:"WX";s:3:"556";s:1:"N";s:1:"u";s:1:"B";a:4:{i:0;s:2:"94";i:1;s:3:"-15";i:2;s:3:"600";i:3;s:3:"523";}}i:118;a:4:{s:1:"C";s:3:"118";s:2:"WX";s:3:"500";s:1:"N";s:1:"v";s:1:"B";a:4:{i:0;s:3:"119";i:1;s:1:"0";i:2;s:3:"603";i:3;s:3:"523";}}s:1:"v";a:4:{s:1:"C";s:3:"118";s:2:"WX";s:3:"500";s:1:"N";s:1:"v";s:1:"B";a:4:{i:0;s:3:"119";i:1;s:1:"0";i:2;s:3:"603";i:3;s:3:"523";}}i:119;a:4:{s:1:"C";s:3:"119";s:2:"WX";s:3:"722";s:1:"N";s:1:"w";s:1:"B";a:4:{i:0;s:3:"125";i:1;s:1:"0";i:2;s:3:"820";i:3;s:3:"523";}}s:1:"w";a:4:{s:1:"C";s:3:"119";s:2:"WX";s:3:"722";s:1:"N";s:1:"w";s:1:"B";a:4:{i:0;s:3:"125";i:1;s:1:"0";i:2;s:3:"820";i:3;s:3:"523";}}i:120;a:4:{s:1:"C";s:3:"120";s:2:"WX";s:3:"500";s:1:"N";s:1:"x";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:1:"0";i:2;s:3:"594";i:3;s:3:"523";}}s:1:"x";a:4:{s:1:"C";s:3:"120";s:2:"WX";s:3:"500";s:1:"N";s:1:"x";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:1:"0";i:2;s:3:"594";i:3;s:3:"523";}}i:121;a:4:{s:1:"C";s:3:"121";s:2:"WX";s:3:"500";s:1:"N";s:1:"y";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:4:"-214";i:2;s:3:"600";i:3;s:3:"523";}}s:1:"y";a:4:{s:1:"C";s:3:"121";s:2:"WX";s:3:"500";s:1:"N";s:1:"y";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:4:"-214";i:2;s:3:"600";i:3;s:3:"523";}}i:122;a:4:{s:1:"C";s:3:"122";s:2:"WX";s:3:"500";s:1:"N";s:1:"z";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:1:"0";i:2;s:3:"571";i:3;s:3:"523";}}s:1:"z";a:4:{s:1:"C";s:3:"122";s:2:"WX";s:3:"500";s:1:"N";s:1:"z";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:1:"0";i:2;s:3:"571";i:3;s:3:"523";}}i:123;a:4:{s:1:"C";s:3:"123";s:2:"WX";s:3:"334";s:1:"N";s:9:"braceleft";s:1:"B";a:4:{i:0;s:2:"92";i:1;s:4:"-196";i:2;s:3:"445";i:3;s:3:"722";}}s:9:"braceleft";a:4:{s:1:"C";s:3:"123";s:2:"WX";s:3:"334";s:1:"N";s:9:"braceleft";s:1:"B";a:4:{i:0;s:2:"92";i:1;s:4:"-196";i:2;s:3:"445";i:3;s:3:"722";}}i:124;a:4:{s:1:"C";s:3:"124";s:2:"WX";s:3:"260";s:1:"N";s:3:"bar";s:1:"B";a:4:{i:0;s:2:"46";i:1;s:4:"-225";i:2;s:3:"332";i:3;s:3:"775";}}s:3:"bar";a:4:{s:1:"C";s:3:"124";s:2:"WX";s:3:"260";s:1:"N";s:3:"bar";s:1:"B";a:4:{i:0;s:2:"46";i:1;s:4:"-225";i:2;s:3:"332";i:3;s:3:"775";}}i:125;a:4:{s:1:"C";s:3:"125";s:2:"WX";s:3:"334";s:1:"N";s:10:"braceright";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:4:"-196";i:2;s:3:"354";i:3;s:3:"722";}}s:10:"braceright";a:4:{s:1:"C";s:3:"125";s:2:"WX";s:3:"334";s:1:"N";s:10:"braceright";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:4:"-196";i:2;s:3:"354";i:3;s:3:"722";}}i:126;a:4:{s:1:"C";s:3:"126";s:2:"WX";s:3:"584";s:1:"N";s:10:"asciitilde";s:1:"B";a:4:{i:0;s:3:"111";i:1;s:3:"180";i:2;s:3:"580";i:3;s:3:"326";}}s:10:"asciitilde";a:4:{s:1:"C";s:3:"126";s:2:"WX";s:3:"584";s:1:"N";s:10:"asciitilde";s:1:"B";a:4:{i:0;s:3:"111";i:1;s:3:"180";i:2;s:3:"580";i:3;s:3:"326";}}i:161;a:4:{s:1:"C";s:3:"161";s:2:"WX";s:3:"333";s:1:"N";s:10:"exclamdown";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:4:"-195";i:2;s:3:"326";i:3;s:3:"523";}}s:10:"exclamdown";a:4:{s:1:"C";s:3:"161";s:2:"WX";s:3:"333";s:1:"N";s:10:"exclamdown";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:4:"-195";i:2;s:3:"326";i:3;s:3:"523";}}i:162;a:4:{s:1:"C";s:3:"162";s:2:"WX";s:3:"556";s:1:"N";s:4:"cent";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:4:"-115";i:2;s:3:"584";i:3;s:3:"623";}}s:4:"cent";a:4:{s:1:"C";s:3:"162";s:2:"WX";s:3:"556";s:1:"N";s:4:"cent";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:4:"-115";i:2;s:3:"584";i:3;s:3:"623";}}i:163;a:4:{s:1:"C";s:3:"163";s:2:"WX";s:3:"556";s:1:"N";s:8:"sterling";s:1:"B";a:4:{i:0;s:2:"49";i:1;s:3:"-16";i:2;s:3:"634";i:3;s:3:"718";}}s:8:"sterling";a:4:{s:1:"C";s:3:"163";s:2:"WX";s:3:"556";s:1:"N";s:8:"sterling";s:1:"B";a:4:{i:0;s:2:"49";i:1;s:3:"-16";i:2;s:3:"634";i:3;s:3:"718";}}i:164;a:4:{s:1:"C";s:3:"164";s:2:"WX";s:3:"167";s:1:"N";s:8:"fraction";s:1:"B";a:4:{i:0;s:4:"-170";i:1;s:3:"-19";i:2;s:3:"482";i:3;s:3:"703";}}s:8:"fraction";a:4:{s:1:"C";s:3:"164";s:2:"WX";s:3:"167";s:1:"N";s:8:"fraction";s:1:"B";a:4:{i:0;s:4:"-170";i:1;s:3:"-19";i:2;s:3:"482";i:3;s:3:"703";}}i:165;a:4:{s:1:"C";s:3:"165";s:2:"WX";s:3:"556";s:1:"N";s:3:"yen";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:1:"0";i:2;s:3:"699";i:3;s:3:"688";}}s:3:"yen";a:4:{s:1:"C";s:3:"165";s:2:"WX";s:3:"556";s:1:"N";s:3:"yen";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:1:"0";i:2;s:3:"699";i:3;s:3:"688";}}i:166;a:4:{s:1:"C";s:3:"166";s:2:"WX";s:3:"556";s:1:"N";s:6:"florin";s:1:"B";a:4:{i:0;s:3:"-52";i:1;s:4:"-207";i:2;s:3:"654";i:3;s:3:"737";}}s:6:"florin";a:4:{s:1:"C";s:3:"166";s:2:"WX";s:3:"556";s:1:"N";s:6:"florin";s:1:"B";a:4:{i:0;s:3:"-52";i:1;s:4:"-207";i:2;s:3:"654";i:3;s:3:"737";}}i:167;a:4:{s:1:"C";s:3:"167";s:2:"WX";s:3:"556";s:1:"N";s:7:"section";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:4:"-191";i:2;s:3:"584";i:3;s:3:"737";}}s:7:"section";a:4:{s:1:"C";s:3:"167";s:2:"WX";s:3:"556";s:1:"N";s:7:"section";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:4:"-191";i:2;s:3:"584";i:3;s:3:"737";}}i:168;a:4:{s:1:"C";s:3:"168";s:2:"WX";s:3:"556";s:1:"N";s:8:"currency";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:2:"99";i:2;s:3:"646";i:3;s:3:"603";}}s:8:"currency";a:4:{s:1:"C";s:3:"168";s:2:"WX";s:3:"556";s:1:"N";s:8:"currency";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:2:"99";i:2;s:3:"646";i:3;s:3:"603";}}i:169;a:4:{s:1:"C";s:3:"169";s:2:"WX";s:3:"191";s:1:"N";s:11:"quotesingle";s:1:"B";a:4:{i:0;s:3:"157";i:1;s:3:"463";i:2;s:3:"285";i:3;s:3:"718";}}s:11:"quotesingle";a:4:{s:1:"C";s:3:"169";s:2:"WX";s:3:"191";s:1:"N";s:11:"quotesingle";s:1:"B";a:4:{i:0;s:3:"157";i:1;s:3:"463";i:2;s:3:"285";i:3;s:3:"718";}}i:170;a:4:{s:1:"C";s:3:"170";s:2:"WX";s:3:"333";s:1:"N";s:12:"quotedblleft";s:1:"B";a:4:{i:0;s:3:"138";i:1;s:3:"470";i:2;s:3:"461";i:3;s:3:"725";}}s:12:"quotedblleft";a:4:{s:1:"C";s:3:"170";s:2:"WX";s:3:"333";s:1:"N";s:12:"quotedblleft";s:1:"B";a:4:{i:0;s:3:"138";i:1;s:3:"470";i:2;s:3:"461";i:3;s:3:"725";}}i:171;a:4:{s:1:"C";s:3:"171";s:2:"WX";s:3:"556";s:1:"N";s:13:"guillemotleft";s:1:"B";a:4:{i:0;s:3:"146";i:1;s:3:"108";i:2;s:3:"554";i:3;s:3:"446";}}s:13:"guillemotleft";a:4:{s:1:"C";s:3:"171";s:2:"WX";s:3:"556";s:1:"N";s:13:"guillemotleft";s:1:"B";a:4:{i:0;s:3:"146";i:1;s:3:"108";i:2;s:3:"554";i:3;s:3:"446";}}i:172;a:4:{s:1:"C";s:3:"172";s:2:"WX";s:3:"333";s:1:"N";s:13:"guilsinglleft";s:1:"B";a:4:{i:0;s:3:"137";i:1;s:3:"108";i:2;s:3:"340";i:3;s:3:"446";}}s:13:"guilsinglleft";a:4:{s:1:"C";s:3:"172";s:2:"WX";s:3:"333";s:1:"N";s:13:"guilsinglleft";s:1:"B";a:4:{i:0;s:3:"137";i:1;s:3:"108";i:2;s:3:"340";i:3;s:3:"446";}}i:173;a:4:{s:1:"C";s:3:"173";s:2:"WX";s:3:"333";s:1:"N";s:14:"guilsinglright";s:1:"B";a:4:{i:0;s:3:"111";i:1;s:3:"108";i:2;s:3:"314";i:3;s:3:"446";}}s:14:"guilsinglright";a:4:{s:1:"C";s:3:"173";s:2:"WX";s:3:"333";s:1:"N";s:14:"guilsinglright";s:1:"B";a:4:{i:0;s:3:"111";i:1;s:3:"108";i:2;s:3:"314";i:3;s:3:"446";}}i:174;a:4:{s:1:"C";s:3:"174";s:2:"WX";s:3:"500";s:1:"N";s:2:"fi";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"587";i:3;s:3:"728";}}s:2:"fi";a:4:{s:1:"C";s:3:"174";s:2:"WX";s:3:"500";s:1:"N";s:2:"fi";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"587";i:3;s:3:"728";}}i:175;a:4:{s:1:"C";s:3:"175";s:2:"WX";s:3:"500";s:1:"N";s:2:"fl";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"585";i:3;s:3:"728";}}s:2:"fl";a:4:{s:1:"C";s:3:"175";s:2:"WX";s:3:"500";s:1:"N";s:2:"fl";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"585";i:3;s:3:"728";}}i:177;a:4:{s:1:"C";s:3:"177";s:2:"WX";s:3:"556";s:1:"N";s:6:"endash";s:1:"B";a:4:{i:0;s:2:"51";i:1;s:3:"240";i:2;s:3:"623";i:3;s:3:"313";}}s:6:"endash";a:4:{s:1:"C";s:3:"177";s:2:"WX";s:3:"556";s:1:"N";s:6:"endash";s:1:"B";a:4:{i:0;s:2:"51";i:1;s:3:"240";i:2;s:3:"623";i:3;s:3:"313";}}i:178;a:4:{s:1:"C";s:3:"178";s:2:"WX";s:3:"556";s:1:"N";s:6:"dagger";s:1:"B";a:4:{i:0;s:3:"135";i:1;s:4:"-159";i:2;s:3:"622";i:3;s:3:"718";}}s:6:"dagger";a:4:{s:1:"C";s:3:"178";s:2:"WX";s:3:"556";s:1:"N";s:6:"dagger";s:1:"B";a:4:{i:0;s:3:"135";i:1;s:4:"-159";i:2;s:3:"622";i:3;s:3:"718";}}i:179;a:4:{s:1:"C";s:3:"179";s:2:"WX";s:3:"556";s:1:"N";s:9:"daggerdbl";s:1:"B";a:4:{i:0;s:2:"52";i:1;s:4:"-159";i:2;s:3:"623";i:3;s:3:"718";}}s:9:"daggerdbl";a:4:{s:1:"C";s:3:"179";s:2:"WX";s:3:"556";s:1:"N";s:9:"daggerdbl";s:1:"B";a:4:{i:0;s:2:"52";i:1;s:4:"-159";i:2;s:3:"623";i:3;s:3:"718";}}i:180;a:4:{s:1:"C";s:3:"180";s:2:"WX";s:3:"278";s:1:"N";s:14:"periodcentered";s:1:"B";a:4:{i:0;s:3:"129";i:1;s:3:"190";i:2;s:3:"257";i:3;s:3:"315";}}s:14:"periodcentered";a:4:{s:1:"C";s:3:"180";s:2:"WX";s:3:"278";s:1:"N";s:14:"periodcentered";s:1:"B";a:4:{i:0;s:3:"129";i:1;s:3:"190";i:2;s:3:"257";i:3;s:3:"315";}}i:182;a:4:{s:1:"C";s:3:"182";s:2:"WX";s:3:"537";s:1:"N";s:9:"paragraph";s:1:"B";a:4:{i:0;s:3:"126";i:1;s:4:"-173";i:2;s:3:"650";i:3;s:3:"718";}}s:9:"paragraph";a:4:{s:1:"C";s:3:"182";s:2:"WX";s:3:"537";s:1:"N";s:9:"paragraph";s:1:"B";a:4:{i:0;s:3:"126";i:1;s:4:"-173";i:2;s:3:"650";i:3;s:3:"718";}}i:183;a:4:{s:1:"C";s:3:"183";s:2:"WX";s:3:"350";s:1:"N";s:6:"bullet";s:1:"B";a:4:{i:0;s:2:"91";i:1;s:3:"202";i:2;s:3:"413";i:3;s:3:"517";}}s:6:"bullet";a:4:{s:1:"C";s:3:"183";s:2:"WX";s:3:"350";s:1:"N";s:6:"bullet";s:1:"B";a:4:{i:0;s:2:"91";i:1;s:3:"202";i:2;s:3:"413";i:3;s:3:"517";}}i:184;a:4:{s:1:"C";s:3:"184";s:2:"WX";s:3:"222";s:1:"N";s:14:"quotesinglbase";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:4:"-149";i:2;s:3:"180";i:3;s:3:"106";}}s:14:"quotesinglbase";a:4:{s:1:"C";s:3:"184";s:2:"WX";s:3:"222";s:1:"N";s:14:"quotesinglbase";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:4:"-149";i:2;s:3:"180";i:3;s:3:"106";}}i:185;a:4:{s:1:"C";s:3:"185";s:2:"WX";s:3:"333";s:1:"N";s:12:"quotedblbase";s:1:"B";a:4:{i:0;s:2:"-6";i:1;s:4:"-149";i:2;s:3:"318";i:3;s:3:"106";}}s:12:"quotedblbase";a:4:{s:1:"C";s:3:"185";s:2:"WX";s:3:"333";s:1:"N";s:12:"quotedblbase";s:1:"B";a:4:{i:0;s:2:"-6";i:1;s:4:"-149";i:2;s:3:"318";i:3;s:3:"106";}}i:186;a:4:{s:1:"C";s:3:"186";s:2:"WX";s:3:"333";s:1:"N";s:13:"quotedblright";s:1:"B";a:4:{i:0;s:3:"124";i:1;s:3:"463";i:2;s:3:"448";i:3;s:3:"718";}}s:13:"quotedblright";a:4:{s:1:"C";s:3:"186";s:2:"WX";s:3:"333";s:1:"N";s:13:"quotedblright";s:1:"B";a:4:{i:0;s:3:"124";i:1;s:3:"463";i:2;s:3:"448";i:3;s:3:"718";}}i:187;a:4:{s:1:"C";s:3:"187";s:2:"WX";s:3:"556";s:1:"N";s:14:"guillemotright";s:1:"B";a:4:{i:0;s:3:"120";i:1;s:3:"108";i:2;s:3:"528";i:3;s:3:"446";}}s:14:"guillemotright";a:4:{s:1:"C";s:3:"187";s:2:"WX";s:3:"556";s:1:"N";s:14:"guillemotright";s:1:"B";a:4:{i:0;s:3:"120";i:1;s:3:"108";i:2;s:3:"528";i:3;s:3:"446";}}i:188;a:4:{s:1:"C";s:3:"188";s:2:"WX";s:4:"1000";s:1:"N";s:8:"ellipsis";s:1:"B";a:4:{i:0;s:3:"115";i:1;s:1:"0";i:2;s:3:"908";i:3;s:3:"106";}}s:8:"ellipsis";a:4:{s:1:"C";s:3:"188";s:2:"WX";s:4:"1000";s:1:"N";s:8:"ellipsis";s:1:"B";a:4:{i:0;s:3:"115";i:1;s:1:"0";i:2;s:3:"908";i:3;s:3:"106";}}i:189;a:4:{s:1:"C";s:3:"189";s:2:"WX";s:4:"1000";s:1:"N";s:11:"perthousand";s:1:"B";a:4:{i:0;s:2:"88";i:1;s:3:"-19";i:2;s:4:"1029";i:3;s:3:"703";}}s:11:"perthousand";a:4:{s:1:"C";s:3:"189";s:2:"WX";s:4:"1000";s:1:"N";s:11:"perthousand";s:1:"B";a:4:{i:0;s:2:"88";i:1;s:3:"-19";i:2;s:4:"1029";i:3;s:3:"703";}}i:191;a:4:{s:1:"C";s:3:"191";s:2:"WX";s:3:"611";s:1:"N";s:12:"questiondown";s:1:"B";a:4:{i:0;s:2:"85";i:1;s:4:"-201";i:2;s:3:"534";i:3;s:3:"525";}}s:12:"questiondown";a:4:{s:1:"C";s:3:"191";s:2:"WX";s:3:"611";s:1:"N";s:12:"questiondown";s:1:"B";a:4:{i:0;s:2:"85";i:1;s:4:"-201";i:2;s:3:"534";i:3;s:3:"525";}}i:193;a:4:{s:1:"C";s:3:"193";s:2:"WX";s:3:"333";s:1:"N";s:5:"grave";s:1:"B";a:4:{i:0;s:3:"170";i:1;s:3:"593";i:2;s:3:"337";i:3;s:3:"734";}}s:5:"grave";a:4:{s:1:"C";s:3:"193";s:2:"WX";s:3:"333";s:1:"N";s:5:"grave";s:1:"B";a:4:{i:0;s:3:"170";i:1;s:3:"593";i:2;s:3:"337";i:3;s:3:"734";}}i:194;a:4:{s:1:"C";s:3:"194";s:2:"WX";s:3:"333";s:1:"N";s:5:"acute";s:1:"B";a:4:{i:0;s:3:"248";i:1;s:3:"593";i:2;s:3:"475";i:3;s:3:"734";}}s:5:"acute";a:4:{s:1:"C";s:3:"194";s:2:"WX";s:3:"333";s:1:"N";s:5:"acute";s:1:"B";a:4:{i:0;s:3:"248";i:1;s:3:"593";i:2;s:3:"475";i:3;s:3:"734";}}i:195;a:4:{s:1:"C";s:3:"195";s:2:"WX";s:3:"333";s:1:"N";s:10:"circumflex";s:1:"B";a:4:{i:0;s:3:"147";i:1;s:3:"593";i:2;s:3:"438";i:3;s:3:"734";}}s:10:"circumflex";a:4:{s:1:"C";s:3:"195";s:2:"WX";s:3:"333";s:1:"N";s:10:"circumflex";s:1:"B";a:4:{i:0;s:3:"147";i:1;s:3:"593";i:2;s:3:"438";i:3;s:3:"734";}}i:196;a:4:{s:1:"C";s:3:"196";s:2:"WX";s:3:"333";s:1:"N";s:5:"tilde";s:1:"B";a:4:{i:0;s:3:"125";i:1;s:3:"606";i:2;s:3:"490";i:3;s:3:"722";}}s:5:"tilde";a:4:{s:1:"C";s:3:"196";s:2:"WX";s:3:"333";s:1:"N";s:5:"tilde";s:1:"B";a:4:{i:0;s:3:"125";i:1;s:3:"606";i:2;s:3:"490";i:3;s:3:"722";}}i:197;a:4:{s:1:"C";s:3:"197";s:2:"WX";s:3:"333";s:1:"N";s:6:"macron";s:1:"B";a:4:{i:0;s:3:"143";i:1;s:3:"627";i:2;s:3:"468";i:3;s:3:"684";}}s:6:"macron";a:4:{s:1:"C";s:3:"197";s:2:"WX";s:3:"333";s:1:"N";s:6:"macron";s:1:"B";a:4:{i:0;s:3:"143";i:1;s:3:"627";i:2;s:3:"468";i:3;s:3:"684";}}i:198;a:4:{s:1:"C";s:3:"198";s:2:"WX";s:3:"333";s:1:"N";s:5:"breve";s:1:"B";a:4:{i:0;s:3:"167";i:1;s:3:"595";i:2;s:3:"476";i:3;s:3:"731";}}s:5:"breve";a:4:{s:1:"C";s:3:"198";s:2:"WX";s:3:"333";s:1:"N";s:5:"breve";s:1:"B";a:4:{i:0;s:3:"167";i:1;s:3:"595";i:2;s:3:"476";i:3;s:3:"731";}}i:199;a:4:{s:1:"C";s:3:"199";s:2:"WX";s:3:"333";s:1:"N";s:9:"dotaccent";s:1:"B";a:4:{i:0;s:3:"249";i:1;s:3:"604";i:2;s:3:"362";i:3;s:3:"706";}}s:9:"dotaccent";a:4:{s:1:"C";s:3:"199";s:2:"WX";s:3:"333";s:1:"N";s:9:"dotaccent";s:1:"B";a:4:{i:0;s:3:"249";i:1;s:3:"604";i:2;s:3:"362";i:3;s:3:"706";}}i:200;a:4:{s:1:"C";s:3:"200";s:2:"WX";s:3:"333";s:1:"N";s:8:"dieresis";s:1:"B";a:4:{i:0;s:3:"168";i:1;s:3:"604";i:2;s:3:"443";i:3;s:3:"706";}}s:8:"dieresis";a:4:{s:1:"C";s:3:"200";s:2:"WX";s:3:"333";s:1:"N";s:8:"dieresis";s:1:"B";a:4:{i:0;s:3:"168";i:1;s:3:"604";i:2;s:3:"443";i:3;s:3:"706";}}i:202;a:4:{s:1:"C";s:3:"202";s:2:"WX";s:3:"333";s:1:"N";s:4:"ring";s:1:"B";a:4:{i:0;s:3:"214";i:1;s:3:"572";i:2;s:3:"402";i:3;s:3:"756";}}s:4:"ring";a:4:{s:1:"C";s:3:"202";s:2:"WX";s:3:"333";s:1:"N";s:4:"ring";s:1:"B";a:4:{i:0;s:3:"214";i:1;s:3:"572";i:2;s:3:"402";i:3;s:3:"756";}}i:203;a:4:{s:1:"C";s:3:"203";s:2:"WX";s:3:"333";s:1:"N";s:7:"cedilla";s:1:"B";a:4:{i:0;s:1:"2";i:1;s:4:"-225";i:2;s:3:"232";i:3;s:1:"0";}}s:7:"cedilla";a:4:{s:1:"C";s:3:"203";s:2:"WX";s:3:"333";s:1:"N";s:7:"cedilla";s:1:"B";a:4:{i:0;s:1:"2";i:1;s:4:"-225";i:2;s:3:"232";i:3;s:1:"0";}}i:205;a:4:{s:1:"C";s:3:"205";s:2:"WX";s:3:"333";s:1:"N";s:12:"hungarumlaut";s:1:"B";a:4:{i:0;s:3:"157";i:1;s:3:"593";i:2;s:3:"565";i:3;s:3:"734";}}s:12:"hungarumlaut";a:4:{s:1:"C";s:3:"205";s:2:"WX";s:3:"333";s:1:"N";s:12:"hungarumlaut";s:1:"B";a:4:{i:0;s:3:"157";i:1;s:3:"593";i:2;s:3:"565";i:3;s:3:"734";}}i:206;a:4:{s:1:"C";s:3:"206";s:2:"WX";s:3:"333";s:1:"N";s:6:"ogonek";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:4:"-225";i:2;s:3:"249";i:3;s:1:"0";}}s:6:"ogonek";a:4:{s:1:"C";s:3:"206";s:2:"WX";s:3:"333";s:1:"N";s:6:"ogonek";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:4:"-225";i:2;s:3:"249";i:3;s:1:"0";}}i:207;a:4:{s:1:"C";s:3:"207";s:2:"WX";s:3:"333";s:1:"N";s:5:"caron";s:1:"B";a:4:{i:0;s:3:"177";i:1;s:3:"593";i:2;s:3:"468";i:3;s:3:"734";}}s:5:"caron";a:4:{s:1:"C";s:3:"207";s:2:"WX";s:3:"333";s:1:"N";s:5:"caron";s:1:"B";a:4:{i:0;s:3:"177";i:1;s:3:"593";i:2;s:3:"468";i:3;s:3:"734";}}i:208;a:4:{s:1:"C";s:3:"208";s:2:"WX";s:4:"1000";s:1:"N";s:6:"emdash";s:1:"B";a:4:{i:0;s:2:"51";i:1;s:3:"240";i:2;s:4:"1067";i:3;s:3:"313";}}s:6:"emdash";a:4:{s:1:"C";s:3:"208";s:2:"WX";s:4:"1000";s:1:"N";s:6:"emdash";s:1:"B";a:4:{i:0;s:2:"51";i:1;s:3:"240";i:2;s:4:"1067";i:3;s:3:"313";}}i:225;a:4:{s:1:"C";s:3:"225";s:2:"WX";s:4:"1000";s:1:"N";s:2:"AE";s:1:"B";a:4:{i:0;s:1:"8";i:1;s:1:"0";i:2;s:4:"1097";i:3;s:3:"718";}}s:2:"AE";a:4:{s:1:"C";s:3:"225";s:2:"WX";s:4:"1000";s:1:"N";s:2:"AE";s:1:"B";a:4:{i:0;s:1:"8";i:1;s:1:"0";i:2;s:4:"1097";i:3;s:3:"718";}}i:227;a:4:{s:1:"C";s:3:"227";s:2:"WX";s:3:"370";s:1:"N";s:11:"ordfeminine";s:1:"B";a:4:{i:0;s:3:"127";i:1;s:3:"405";i:2;s:3:"449";i:3;s:3:"737";}}s:11:"ordfeminine";a:4:{s:1:"C";s:3:"227";s:2:"WX";s:3:"370";s:1:"N";s:11:"ordfeminine";s:1:"B";a:4:{i:0;s:3:"127";i:1;s:3:"405";i:2;s:3:"449";i:3;s:3:"737";}}i:232;a:4:{s:1:"C";s:3:"232";s:2:"WX";s:3:"556";s:1:"N";s:6:"Lslash";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:1:"0";i:2;s:3:"555";i:3;s:3:"718";}}s:6:"Lslash";a:4:{s:1:"C";s:3:"232";s:2:"WX";s:3:"556";s:1:"N";s:6:"Lslash";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:1:"0";i:2;s:3:"555";i:3;s:3:"718";}}i:233;a:4:{s:1:"C";s:3:"233";s:2:"WX";s:3:"778";s:1:"N";s:6:"Oslash";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:3:"-19";i:2;s:3:"890";i:3;s:3:"737";}}s:6:"Oslash";a:4:{s:1:"C";s:3:"233";s:2:"WX";s:3:"778";s:1:"N";s:6:"Oslash";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:3:"-19";i:2;s:3:"890";i:3;s:3:"737";}}i:234;a:4:{s:1:"C";s:3:"234";s:2:"WX";s:4:"1000";s:1:"N";s:2:"OE";s:1:"B";a:4:{i:0;s:2:"98";i:1;s:3:"-19";i:2;s:4:"1116";i:3;s:3:"737";}}s:2:"OE";a:4:{s:1:"C";s:3:"234";s:2:"WX";s:4:"1000";s:1:"N";s:2:"OE";s:1:"B";a:4:{i:0;s:2:"98";i:1;s:3:"-19";i:2;s:4:"1116";i:3;s:3:"737";}}i:235;a:4:{s:1:"C";s:3:"235";s:2:"WX";s:3:"365";s:1:"N";s:12:"ordmasculine";s:1:"B";a:4:{i:0;s:3:"141";i:1;s:3:"405";i:2;s:3:"468";i:3;s:3:"737";}}s:12:"ordmasculine";a:4:{s:1:"C";s:3:"235";s:2:"WX";s:3:"365";s:1:"N";s:12:"ordmasculine";s:1:"B";a:4:{i:0;s:3:"141";i:1;s:3:"405";i:2;s:3:"468";i:3;s:3:"737";}}i:241;a:4:{s:1:"C";s:3:"241";s:2:"WX";s:3:"889";s:1:"N";s:2:"ae";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:3:"-15";i:2;s:3:"909";i:3;s:3:"538";}}s:2:"ae";a:4:{s:1:"C";s:3:"241";s:2:"WX";s:3:"889";s:1:"N";s:2:"ae";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:3:"-15";i:2;s:3:"909";i:3;s:3:"538";}}i:245;a:4:{s:1:"C";s:3:"245";s:2:"WX";s:3:"278";s:1:"N";s:8:"dotlessi";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:1:"0";i:2;s:3:"294";i:3;s:3:"523";}}s:8:"dotlessi";a:4:{s:1:"C";s:3:"245";s:2:"WX";s:3:"278";s:1:"N";s:8:"dotlessi";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:1:"0";i:2;s:3:"294";i:3;s:3:"523";}}i:248;a:4:{s:1:"C";s:3:"248";s:2:"WX";s:3:"222";s:1:"N";s:6:"lslash";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:1:"0";i:2;s:3:"347";i:3;s:3:"718";}}s:6:"lslash";a:4:{s:1:"C";s:3:"248";s:2:"WX";s:3:"222";s:1:"N";s:6:"lslash";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:1:"0";i:2;s:3:"347";i:3;s:3:"718";}}i:249;a:4:{s:1:"C";s:3:"249";s:2:"WX";s:3:"611";s:1:"N";s:6:"oslash";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:3:"-22";i:2;s:3:"647";i:3;s:3:"545";}}s:6:"oslash";a:4:{s:1:"C";s:3:"249";s:2:"WX";s:3:"611";s:1:"N";s:6:"oslash";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:3:"-22";i:2;s:3:"647";i:3;s:3:"545";}}i:250;a:4:{s:1:"C";s:3:"250";s:2:"WX";s:3:"944";s:1:"N";s:2:"oe";s:1:"B";a:4:{i:0;s:2:"83";i:1;s:3:"-15";i:2;s:3:"964";i:3;s:3:"538";}}s:2:"oe";a:4:{s:1:"C";s:3:"250";s:2:"WX";s:3:"944";s:1:"N";s:2:"oe";s:1:"B";a:4:{i:0;s:2:"83";i:1;s:3:"-15";i:2;s:3:"964";i:3;s:3:"538";}}i:251;a:4:{s:1:"C";s:3:"251";s:2:"WX";s:3:"611";s:1:"N";s:10:"germandbls";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:3:"-15";i:2;s:3:"658";i:3;s:3:"728";}}s:10:"germandbls";a:4:{s:1:"C";s:3:"251";s:2:"WX";s:3:"611";s:1:"N";s:10:"germandbls";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:3:"-15";i:2;s:3:"658";i:3;s:3:"728";}}s:9:"Idieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:9:"Idieresis";s:1:"B";a:4:{i:0;s:2:"91";i:1;s:1:"0";i:2;s:3:"458";i:3;s:3:"901";}}s:6:"eacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"eacute";s:1:"B";a:4:{i:0;s:2:"84";i:1;s:3:"-15";i:2;s:3:"587";i:3;s:3:"734";}}s:6:"abreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"abreve";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:3:"-15";i:2;s:3:"578";i:3;s:3:"731";}}s:13:"uhungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:13:"uhungarumlaut";s:1:"B";a:4:{i:0;s:2:"94";i:1;s:3:"-15";i:2;s:3:"677";i:3;s:3:"734";}}s:6:"ecaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"ecaron";s:1:"B";a:4:{i:0;s:2:"84";i:1;s:3:"-15";i:2;s:3:"580";i:3;s:3:"734";}}s:9:"Ydieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:9:"Ydieresis";s:1:"B";a:4:{i:0;s:3:"167";i:1;s:1:"0";i:2;s:3:"806";i:3;s:3:"901";}}s:6:"divide";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"584";s:1:"N";s:6:"divide";s:1:"B";a:4:{i:0;s:2:"85";i:1;s:3:"-19";i:2;s:3:"606";i:3;s:3:"524";}}s:6:"Yacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Yacute";s:1:"B";a:4:{i:0;s:3:"167";i:1;s:1:"0";i:2;s:3:"806";i:3;s:3:"929";}}s:11:"Acircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:11:"Acircumflex";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"654";i:3;s:3:"929";}}s:6:"aacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"aacute";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:3:"-15";i:2;s:3:"587";i:3;s:3:"734";}}s:11:"Ucircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:11:"Ucircumflex";s:1:"B";a:4:{i:0;s:3:"123";i:1;s:3:"-19";i:2;s:3:"797";i:3;s:3:"929";}}s:6:"yacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"yacute";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:4:"-214";i:2;s:3:"600";i:3;s:3:"734";}}s:12:"scommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:12:"scommaaccent";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:4:"-225";i:2;s:3:"529";i:3;s:3:"538";}}s:11:"ecircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:11:"ecircumflex";s:1:"B";a:4:{i:0;s:2:"84";i:1;s:3:"-15";i:2;s:3:"578";i:3;s:3:"734";}}s:5:"Uring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:5:"Uring";s:1:"B";a:4:{i:0;s:3:"123";i:1;s:3:"-19";i:2;s:3:"797";i:3;s:3:"931";}}s:9:"Udieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:9:"Udieresis";s:1:"B";a:4:{i:0;s:3:"123";i:1;s:3:"-19";i:2;s:3:"797";i:3;s:3:"901";}}s:7:"aogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:7:"aogonek";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:4:"-220";i:2;s:3:"559";i:3;s:3:"538";}}s:6:"Uacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Uacute";s:1:"B";a:4:{i:0;s:3:"123";i:1;s:3:"-19";i:2;s:3:"797";i:3;s:3:"929";}}s:7:"uogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:7:"uogonek";s:1:"B";a:4:{i:0;s:2:"94";i:1;s:4:"-225";i:2;s:3:"600";i:3;s:3:"523";}}s:9:"Edieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:9:"Edieresis";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"762";i:3;s:3:"901";}}s:6:"Dcroat";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Dcroat";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"764";i:3;s:3:"718";}}s:11:"commaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"250";s:1:"N";s:11:"commaaccent";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:4:"-225";i:2;s:3:"172";i:3;s:3:"-40";}}s:9:"copyright";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"737";s:1:"N";s:9:"copyright";s:1:"B";a:4:{i:0;s:2:"54";i:1;s:3:"-19";i:2;s:3:"837";i:3;s:3:"737";}}s:7:"Emacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:7:"Emacron";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"762";i:3;s:3:"879";}}s:6:"ccaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"ccaron";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"-15";i:2;s:3:"553";i:3;s:3:"734";}}s:5:"aring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:5:"aring";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:3:"-15";i:2;s:3:"559";i:3;s:3:"756";}}s:12:"Ncommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:12:"Ncommaaccent";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:4:"-225";i:2;s:3:"799";i:3;s:3:"718";}}s:6:"lacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"222";s:1:"N";s:6:"lacute";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:1:"0";i:2;s:3:"461";i:3;s:3:"929";}}s:6:"agrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"agrave";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:3:"-15";i:2;s:3:"559";i:3;s:3:"734";}}s:12:"Tcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:12:"Tcommaaccent";s:1:"B";a:4:{i:0;s:3:"148";i:1;s:4:"-225";i:2;s:3:"750";i:3;s:3:"718";}}s:6:"Cacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Cacute";s:1:"B";a:4:{i:0;s:3:"108";i:1;s:3:"-19";i:2;s:3:"782";i:3;s:3:"929";}}s:6:"atilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"atilde";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:3:"-15";i:2;s:3:"592";i:3;s:3:"722";}}s:10:"Edotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:10:"Edotaccent";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"762";i:3;s:3:"901";}}s:6:"scaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"scaron";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:3:"-15";i:2;s:3:"552";i:3;s:3:"734";}}s:8:"scedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:8:"scedilla";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:4:"-225";i:2;s:3:"529";i:3;s:3:"538";}}s:6:"iacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:6:"iacute";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:1:"0";i:2;s:3:"448";i:3;s:3:"734";}}s:7:"lozenge";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"471";s:1:"N";s:7:"lozenge";s:1:"B";a:4:{i:0;s:2:"88";i:1;s:1:"0";i:2;s:3:"540";i:3;s:3:"728";}}s:6:"Rcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Rcaron";s:1:"B";a:4:{i:0;s:2:"88";i:1;s:1:"0";i:2;s:3:"773";i:3;s:3:"929";}}s:12:"Gcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:12:"Gcommaaccent";s:1:"B";a:4:{i:0;s:3:"111";i:1;s:4:"-225";i:2;s:3:"799";i:3;s:3:"737";}}s:11:"ucircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:11:"ucircumflex";s:1:"B";a:4:{i:0;s:2:"94";i:1;s:3:"-15";i:2;s:3:"600";i:3;s:3:"734";}}s:11:"acircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:11:"acircumflex";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:3:"-15";i:2;s:3:"559";i:3;s:3:"734";}}s:7:"Amacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:7:"Amacron";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"677";i:3;s:3:"879";}}s:6:"rcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"333";s:1:"N";s:6:"rcaron";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"508";i:3;s:3:"734";}}s:8:"ccedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:8:"ccedilla";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:4:"-225";i:2;s:3:"553";i:3;s:3:"538";}}s:10:"Zdotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:10:"Zdotaccent";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:1:"0";i:2;s:3:"741";i:3;s:3:"901";}}s:5:"Thorn";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:5:"Thorn";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"712";i:3;s:3:"718";}}s:7:"Omacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:7:"Omacron";s:1:"B";a:4:{i:0;s:3:"105";i:1;s:3:"-19";i:2;s:3:"826";i:3;s:3:"879";}}s:6:"Racute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Racute";s:1:"B";a:4:{i:0;s:2:"88";i:1;s:1:"0";i:2;s:3:"773";i:3;s:3:"929";}}s:6:"Sacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Sacute";s:1:"B";a:4:{i:0;s:2:"90";i:1;s:3:"-19";i:2;s:3:"713";i:3;s:3:"929";}}s:6:"dcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"643";s:1:"N";s:6:"dcaron";s:1:"B";a:4:{i:0;s:2:"84";i:1;s:3:"-15";i:2;s:3:"808";i:3;s:3:"718";}}s:7:"Umacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:7:"Umacron";s:1:"B";a:4:{i:0;s:3:"123";i:1;s:3:"-19";i:2;s:3:"797";i:3;s:3:"879";}}s:5:"uring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:5:"uring";s:1:"B";a:4:{i:0;s:2:"94";i:1;s:3:"-15";i:2;s:3:"600";i:3;s:3:"756";}}s:13:"threesuperior";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"333";s:1:"N";s:13:"threesuperior";s:1:"B";a:4:{i:0;s:2:"90";i:1;s:3:"270";i:2;s:3:"436";i:3;s:3:"703";}}s:6:"Ograve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:6:"Ograve";s:1:"B";a:4:{i:0;s:3:"105";i:1;s:3:"-19";i:2;s:3:"826";i:3;s:3:"929";}}s:6:"Agrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Agrave";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"654";i:3;s:3:"929";}}s:6:"Abreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Abreve";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"685";i:3;s:3:"926";}}s:8:"multiply";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"584";s:1:"N";s:8:"multiply";s:1:"B";a:4:{i:0;s:2:"50";i:1;s:1:"0";i:2;s:3:"642";i:3;s:3:"506";}}s:6:"uacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"uacute";s:1:"B";a:4:{i:0;s:2:"94";i:1;s:3:"-15";i:2;s:3:"600";i:3;s:3:"734";}}s:6:"Tcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"Tcaron";s:1:"B";a:4:{i:0;s:3:"148";i:1;s:1:"0";i:2;s:3:"750";i:3;s:3:"929";}}s:11:"partialdiff";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"476";s:1:"N";s:11:"partialdiff";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:3:"-38";i:2;s:3:"550";i:3;s:3:"714";}}s:9:"ydieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:9:"ydieresis";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:4:"-214";i:2;s:3:"600";i:3;s:3:"706";}}s:6:"Nacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Nacute";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"799";i:3;s:3:"929";}}s:11:"icircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:11:"icircumflex";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:1:"0";i:2;s:3:"411";i:3;s:3:"734";}}s:11:"Ecircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:11:"Ecircumflex";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"762";i:3;s:3:"929";}}s:9:"adieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:9:"adieresis";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:3:"-15";i:2;s:3:"559";i:3;s:3:"706";}}s:9:"edieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:9:"edieresis";s:1:"B";a:4:{i:0;s:2:"84";i:1;s:3:"-15";i:2;s:3:"578";i:3;s:3:"706";}}s:6:"cacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"cacute";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"-15";i:2;s:3:"559";i:3;s:3:"734";}}s:6:"nacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"nacute";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:1:"0";i:2;s:3:"587";i:3;s:3:"734";}}s:7:"umacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:7:"umacron";s:1:"B";a:4:{i:0;s:2:"94";i:1;s:3:"-15";i:2;s:3:"600";i:3;s:3:"684";}}s:6:"Ncaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Ncaron";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"799";i:3;s:3:"929";}}s:6:"Iacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:6:"Iacute";s:1:"B";a:4:{i:0;s:2:"91";i:1;s:1:"0";i:2;s:3:"489";i:3;s:3:"929";}}s:9:"plusminus";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"584";s:1:"N";s:9:"plusminus";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:1:"0";i:2;s:3:"618";i:3;s:3:"506";}}s:9:"brokenbar";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"260";s:1:"N";s:9:"brokenbar";s:1:"B";a:4:{i:0;s:2:"62";i:1;s:4:"-150";i:2;s:3:"316";i:3;s:3:"700";}}s:10:"registered";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"737";s:1:"N";s:10:"registered";s:1:"B";a:4:{i:0;s:2:"54";i:1;s:3:"-19";i:2;s:3:"837";i:3;s:3:"737";}}s:6:"Gbreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:6:"Gbreve";s:1:"B";a:4:{i:0;s:3:"111";i:1;s:3:"-19";i:2;s:3:"799";i:3;s:3:"926";}}s:10:"Idotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:10:"Idotaccent";s:1:"B";a:4:{i:0;s:2:"91";i:1;s:1:"0";i:2;s:3:"377";i:3;s:3:"901";}}s:9:"summation";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"summation";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:3:"-10";i:2;s:3:"671";i:3;s:3:"706";}}s:6:"Egrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Egrave";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"762";i:3;s:3:"929";}}s:6:"racute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"333";s:1:"N";s:6:"racute";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"475";i:3;s:3:"734";}}s:7:"omacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:7:"omacron";s:1:"B";a:4:{i:0;s:2:"83";i:1;s:3:"-14";i:2;s:3:"585";i:3;s:3:"684";}}s:6:"Zacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"Zacute";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:1:"0";i:2;s:3:"741";i:3;s:3:"929";}}s:6:"Zcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"Zcaron";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:1:"0";i:2;s:3:"741";i:3;s:3:"929";}}s:12:"greaterequal";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"549";s:1:"N";s:12:"greaterequal";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"620";i:3;s:3:"674";}}s:3:"Eth";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:3:"Eth";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:1:"0";i:2;s:3:"764";i:3;s:3:"718";}}s:8:"Ccedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:8:"Ccedilla";s:1:"B";a:4:{i:0;s:3:"108";i:1;s:4:"-225";i:2;s:3:"782";i:3;s:3:"737";}}s:12:"lcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"222";s:1:"N";s:12:"lcommaaccent";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:4:"-225";i:2;s:3:"308";i:3;s:3:"718";}}s:6:"tcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"317";s:1:"N";s:6:"tcaron";s:1:"B";a:4:{i:0;s:3:"102";i:1;s:2:"-7";i:2;s:3:"501";i:3;s:3:"808";}}s:7:"eogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:7:"eogonek";s:1:"B";a:4:{i:0;s:2:"84";i:1;s:4:"-225";i:2;s:3:"578";i:3;s:3:"538";}}s:7:"Uogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:7:"Uogonek";s:1:"B";a:4:{i:0;s:3:"123";i:1;s:4:"-225";i:2;s:3:"797";i:3;s:3:"718";}}s:6:"Aacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Aacute";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"683";i:3;s:3:"929";}}s:9:"Adieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:9:"Adieresis";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"654";i:3;s:3:"901";}}s:6:"egrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"egrave";s:1:"B";a:4:{i:0;s:2:"84";i:1;s:3:"-15";i:2;s:3:"578";i:3;s:3:"734";}}s:6:"zacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"zacute";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:1:"0";i:2;s:3:"571";i:3;s:3:"734";}}s:7:"iogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"222";s:1:"N";s:7:"iogonek";s:1:"B";a:4:{i:0;s:3:"-61";i:1;s:4:"-225";i:2;s:3:"308";i:3;s:3:"718";}}s:6:"Oacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:6:"Oacute";s:1:"B";a:4:{i:0;s:3:"105";i:1;s:3:"-19";i:2;s:3:"826";i:3;s:3:"929";}}s:6:"oacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"oacute";s:1:"B";a:4:{i:0;s:2:"83";i:1;s:3:"-14";i:2;s:3:"587";i:3;s:3:"734";}}s:7:"amacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:7:"amacron";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:3:"-15";i:2;s:3:"580";i:3;s:3:"684";}}s:6:"sacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"sacute";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:3:"-15";i:2;s:3:"559";i:3;s:3:"734";}}s:9:"idieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:9:"idieresis";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:1:"0";i:2;s:3:"416";i:3;s:3:"706";}}s:11:"Ocircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:11:"Ocircumflex";s:1:"B";a:4:{i:0;s:3:"105";i:1;s:3:"-19";i:2;s:3:"826";i:3;s:3:"929";}}s:6:"Ugrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Ugrave";s:1:"B";a:4:{i:0;s:3:"123";i:1;s:3:"-19";i:2;s:3:"797";i:3;s:3:"929";}}s:5:"Delta";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"612";s:1:"N";s:5:"Delta";s:1:"B";a:4:{i:0;s:1:"6";i:1;s:1:"0";i:2;s:3:"608";i:3;s:3:"688";}}s:5:"thorn";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:5:"thorn";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:4:"-207";i:2;s:3:"584";i:3;s:3:"718";}}s:11:"twosuperior";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"333";s:1:"N";s:11:"twosuperior";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:3:"281";i:2;s:3:"449";i:3;s:3:"703";}}s:9:"Odieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:9:"Odieresis";s:1:"B";a:4:{i:0;s:3:"105";i:1;s:3:"-19";i:2;s:3:"826";i:3;s:3:"901";}}s:2:"mu";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:2:"mu";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:4:"-207";i:2;s:3:"600";i:3;s:3:"523";}}s:6:"igrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:6:"igrave";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:1:"0";i:2;s:3:"310";i:3;s:3:"734";}}s:13:"ohungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:13:"ohungarumlaut";s:1:"B";a:4:{i:0;s:2:"83";i:1;s:3:"-14";i:2;s:3:"677";i:3;s:3:"734";}}s:7:"Eogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:7:"Eogonek";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:4:"-220";i:2;s:3:"762";i:3;s:3:"718";}}s:6:"dcroat";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"dcroat";s:1:"B";a:4:{i:0;s:2:"84";i:1;s:3:"-15";i:2;s:3:"689";i:3;s:3:"718";}}s:13:"threequarters";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"834";s:1:"N";s:13:"threequarters";s:1:"B";a:4:{i:0;s:3:"130";i:1;s:3:"-19";i:2;s:3:"861";i:3;s:3:"703";}}s:8:"Scedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:8:"Scedilla";s:1:"B";a:4:{i:0;s:2:"90";i:1;s:4:"-225";i:2;s:3:"713";i:3;s:3:"737";}}s:6:"lcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"299";s:1:"N";s:6:"lcaron";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:1:"0";i:2;s:3:"464";i:3;s:3:"718";}}s:12:"Kcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:12:"Kcommaaccent";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:4:"-225";i:2;s:3:"808";i:3;s:3:"718";}}s:6:"Lacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"Lacute";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"555";i:3;s:3:"929";}}s:9:"trademark";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:4:"1000";s:1:"N";s:9:"trademark";s:1:"B";a:4:{i:0;s:3:"186";i:1;s:3:"306";i:2;s:4:"1056";i:3;s:3:"718";}}s:10:"edotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:10:"edotaccent";s:1:"B";a:4:{i:0;s:2:"84";i:1;s:3:"-15";i:2;s:3:"578";i:3;s:3:"706";}}s:6:"Igrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:6:"Igrave";s:1:"B";a:4:{i:0;s:2:"91";i:1;s:1:"0";i:2;s:3:"351";i:3;s:3:"929";}}s:7:"Imacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:7:"Imacron";s:1:"B";a:4:{i:0;s:2:"91";i:1;s:1:"0";i:2;s:3:"483";i:3;s:3:"879";}}s:6:"Lcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"Lcaron";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"570";i:3;s:3:"718";}}s:7:"onehalf";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"834";s:1:"N";s:7:"onehalf";s:1:"B";a:4:{i:0;s:3:"114";i:1;s:3:"-19";i:2;s:3:"839";i:3;s:3:"703";}}s:9:"lessequal";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"549";s:1:"N";s:9:"lessequal";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"666";i:3;s:3:"674";}}s:11:"ocircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:11:"ocircumflex";s:1:"B";a:4:{i:0;s:2:"83";i:1;s:3:"-14";i:2;s:3:"585";i:3;s:3:"734";}}s:6:"ntilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"ntilde";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:1:"0";i:2;s:3:"592";i:3;s:3:"722";}}s:13:"Uhungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:13:"Uhungarumlaut";s:1:"B";a:4:{i:0;s:3:"123";i:1;s:3:"-19";i:2;s:3:"801";i:3;s:3:"929";}}s:6:"Eacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Eacute";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"762";i:3;s:3:"929";}}s:7:"emacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:7:"emacron";s:1:"B";a:4:{i:0;s:2:"84";i:1;s:3:"-15";i:2;s:3:"580";i:3;s:3:"684";}}s:6:"gbreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"gbreve";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:4:"-220";i:2;s:3:"610";i:3;s:3:"731";}}s:10:"onequarter";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"834";s:1:"N";s:10:"onequarter";s:1:"B";a:4:{i:0;s:3:"150";i:1;s:3:"-19";i:2;s:3:"802";i:3;s:3:"703";}}s:6:"Scaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Scaron";s:1:"B";a:4:{i:0;s:2:"90";i:1;s:3:"-19";i:2;s:3:"713";i:3;s:3:"929";}}s:12:"Scommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:12:"Scommaaccent";s:1:"B";a:4:{i:0;s:2:"90";i:1;s:4:"-225";i:2;s:3:"713";i:3;s:3:"737";}}s:13:"Ohungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:13:"Ohungarumlaut";s:1:"B";a:4:{i:0;s:3:"105";i:1;s:3:"-19";i:2;s:3:"829";i:3;s:3:"929";}}s:6:"degree";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"400";s:1:"N";s:6:"degree";s:1:"B";a:4:{i:0;s:3:"169";i:1;s:3:"411";i:2;s:3:"468";i:3;s:3:"703";}}s:6:"ograve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"ograve";s:1:"B";a:4:{i:0;s:2:"83";i:1;s:3:"-14";i:2;s:3:"585";i:3;s:3:"734";}}s:6:"Ccaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Ccaron";s:1:"B";a:4:{i:0;s:3:"108";i:1;s:3:"-19";i:2;s:3:"782";i:3;s:3:"929";}}s:6:"ugrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"ugrave";s:1:"B";a:4:{i:0;s:2:"94";i:1;s:3:"-15";i:2;s:3:"600";i:3;s:3:"734";}}s:7:"radical";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"453";s:1:"N";s:7:"radical";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:3:"-80";i:2;s:3:"617";i:3;s:3:"762";}}s:6:"Dcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Dcaron";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:1:"0";i:2;s:3:"764";i:3;s:3:"929";}}s:12:"rcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"333";s:1:"N";s:12:"rcommaaccent";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:4:"-225";i:2;s:3:"446";i:3;s:3:"538";}}s:6:"Ntilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Ntilde";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"799";i:3;s:3:"917";}}s:6:"otilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"otilde";s:1:"B";a:4:{i:0;s:2:"83";i:1;s:3:"-14";i:2;s:3:"602";i:3;s:3:"722";}}s:12:"Rcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:12:"Rcommaaccent";s:1:"B";a:4:{i:0;s:2:"88";i:1;s:4:"-225";i:2;s:3:"773";i:3;s:3:"718";}}s:12:"Lcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:12:"Lcommaaccent";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:4:"-225";i:2;s:3:"555";i:3;s:3:"718";}}s:6:"Atilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Atilde";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"699";i:3;s:3:"917";}}s:7:"Aogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:7:"Aogonek";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:4:"-225";i:2;s:3:"654";i:3;s:3:"718";}}s:5:"Aring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:5:"Aring";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"654";i:3;s:3:"931";}}s:6:"Otilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:6:"Otilde";s:1:"B";a:4:{i:0;s:3:"105";i:1;s:3:"-19";i:2;s:3:"826";i:3;s:3:"917";}}s:10:"zdotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:10:"zdotaccent";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:1:"0";i:2;s:3:"571";i:3;s:3:"706";}}s:6:"Ecaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Ecaron";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"762";i:3;s:3:"929";}}s:7:"Iogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:7:"Iogonek";s:1:"B";a:4:{i:0;s:3:"-33";i:1;s:4:"-225";i:2;s:3:"341";i:3;s:3:"718";}}s:12:"kcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:12:"kcommaaccent";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:4:"-225";i:2;s:3:"600";i:3;s:3:"718";}}s:5:"minus";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"584";s:1:"N";s:5:"minus";s:1:"B";a:4:{i:0;s:2:"85";i:1;s:3:"216";i:2;s:3:"606";i:3;s:3:"289";}}s:11:"Icircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:11:"Icircumflex";s:1:"B";a:4:{i:0;s:2:"91";i:1;s:1:"0";i:2;s:3:"452";i:3;s:3:"929";}}s:6:"ncaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"ncaron";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:1:"0";i:2;s:3:"580";i:3;s:3:"734";}}s:12:"tcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:12:"tcommaaccent";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:4:"-225";i:2;s:3:"368";i:3;s:3:"669";}}s:10:"logicalnot";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"584";s:1:"N";s:10:"logicalnot";s:1:"B";a:4:{i:0;s:3:"106";i:1;s:3:"108";i:2;s:3:"628";i:3;s:3:"390";}}s:9:"odieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:9:"odieresis";s:1:"B";a:4:{i:0;s:2:"83";i:1;s:3:"-14";i:2;s:3:"585";i:3;s:3:"706";}}s:9:"udieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:9:"udieresis";s:1:"B";a:4:{i:0;s:2:"94";i:1;s:3:"-15";i:2;s:3:"600";i:3;s:3:"706";}}s:8:"notequal";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"549";s:1:"N";s:8:"notequal";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-35";i:2;s:3:"623";i:3;s:3:"551";}}s:12:"gcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:12:"gcommaaccent";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:4:"-220";i:2;s:3:"610";i:3;s:3:"822";}}s:3:"eth";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:3:"eth";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:3:"-15";i:2;s:3:"617";i:3;s:3:"737";}}s:6:"zcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"zcaron";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:1:"0";i:2;s:3:"571";i:3;s:3:"734";}}s:12:"ncommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:12:"ncommaaccent";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:4:"-225";i:2;s:3:"573";i:3;s:3:"538";}}s:11:"onesuperior";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"333";s:1:"N";s:11:"onesuperior";s:1:"B";a:4:{i:0;s:3:"166";i:1;s:3:"281";i:2;s:3:"371";i:3;s:3:"703";}}s:7:"imacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:7:"imacron";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:1:"0";i:2;s:3:"417";i:3;s:3:"684";}}s:4:"Euro";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:4:"Euro";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}}s:3:"KPX";a:138:{s:1:"A";a:48:{s:1:"C";s:3:"-30";s:6:"Cacute";s:3:"-30";s:6:"Ccaron";s:3:"-30";s:8:"Ccedilla";s:3:"-30";s:1:"G";s:3:"-30";s:6:"Gbreve";s:3:"-30";s:12:"Gcommaaccent";s:3:"-30";s:1:"O";s:3:"-30";s:6:"Oacute";s:3:"-30";s:11:"Ocircumflex";s:3:"-30";s:9:"Odieresis";s:3:"-30";s:6:"Ograve";s:3:"-30";s:13:"Ohungarumlaut";s:3:"-30";s:7:"Omacron";s:3:"-30";s:6:"Oslash";s:3:"-30";s:6:"Otilde";s:3:"-30";s:1:"Q";s:3:"-30";s:1:"T";s:4:"-120";s:6:"Tcaron";s:4:"-120";s:12:"Tcommaaccent";s:4:"-120";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-70";s:1:"W";s:3:"-50";s:1:"Y";s:4:"-100";s:6:"Yacute";s:4:"-100";s:9:"Ydieresis";s:4:"-100";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-40";s:1:"w";s:3:"-40";s:1:"y";s:3:"-40";s:6:"yacute";s:3:"-40";s:9:"ydieresis";s:3:"-40";}s:6:"Aacute";a:48:{s:1:"C";s:3:"-30";s:6:"Cacute";s:3:"-30";s:6:"Ccaron";s:3:"-30";s:8:"Ccedilla";s:3:"-30";s:1:"G";s:3:"-30";s:6:"Gbreve";s:3:"-30";s:12:"Gcommaaccent";s:3:"-30";s:1:"O";s:3:"-30";s:6:"Oacute";s:3:"-30";s:11:"Ocircumflex";s:3:"-30";s:9:"Odieresis";s:3:"-30";s:6:"Ograve";s:3:"-30";s:13:"Ohungarumlaut";s:3:"-30";s:7:"Omacron";s:3:"-30";s:6:"Oslash";s:3:"-30";s:6:"Otilde";s:3:"-30";s:1:"Q";s:3:"-30";s:1:"T";s:4:"-120";s:6:"Tcaron";s:4:"-120";s:12:"Tcommaaccent";s:4:"-120";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-70";s:1:"W";s:3:"-50";s:1:"Y";s:4:"-100";s:6:"Yacute";s:4:"-100";s:9:"Ydieresis";s:4:"-100";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-40";s:1:"w";s:3:"-40";s:1:"y";s:3:"-40";s:6:"yacute";s:3:"-40";s:9:"ydieresis";s:3:"-40";}s:6:"Abreve";a:48:{s:1:"C";s:3:"-30";s:6:"Cacute";s:3:"-30";s:6:"Ccaron";s:3:"-30";s:8:"Ccedilla";s:3:"-30";s:1:"G";s:3:"-30";s:6:"Gbreve";s:3:"-30";s:12:"Gcommaaccent";s:3:"-30";s:1:"O";s:3:"-30";s:6:"Oacute";s:3:"-30";s:11:"Ocircumflex";s:3:"-30";s:9:"Odieresis";s:3:"-30";s:6:"Ograve";s:3:"-30";s:13:"Ohungarumlaut";s:3:"-30";s:7:"Omacron";s:3:"-30";s:6:"Oslash";s:3:"-30";s:6:"Otilde";s:3:"-30";s:1:"Q";s:3:"-30";s:1:"T";s:4:"-120";s:6:"Tcaron";s:4:"-120";s:12:"Tcommaaccent";s:4:"-120";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-70";s:1:"W";s:3:"-50";s:1:"Y";s:4:"-100";s:6:"Yacute";s:4:"-100";s:9:"Ydieresis";s:4:"-100";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-40";s:1:"w";s:3:"-40";s:1:"y";s:3:"-40";s:6:"yacute";s:3:"-40";s:9:"ydieresis";s:3:"-40";}s:11:"Acircumflex";a:48:{s:1:"C";s:3:"-30";s:6:"Cacute";s:3:"-30";s:6:"Ccaron";s:3:"-30";s:8:"Ccedilla";s:3:"-30";s:1:"G";s:3:"-30";s:6:"Gbreve";s:3:"-30";s:12:"Gcommaaccent";s:3:"-30";s:1:"O";s:3:"-30";s:6:"Oacute";s:3:"-30";s:11:"Ocircumflex";s:3:"-30";s:9:"Odieresis";s:3:"-30";s:6:"Ograve";s:3:"-30";s:13:"Ohungarumlaut";s:3:"-30";s:7:"Omacron";s:3:"-30";s:6:"Oslash";s:3:"-30";s:6:"Otilde";s:3:"-30";s:1:"Q";s:3:"-30";s:1:"T";s:4:"-120";s:6:"Tcaron";s:4:"-120";s:12:"Tcommaaccent";s:4:"-120";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-70";s:1:"W";s:3:"-50";s:1:"Y";s:4:"-100";s:6:"Yacute";s:4:"-100";s:9:"Ydieresis";s:4:"-100";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-40";s:1:"w";s:3:"-40";s:1:"y";s:3:"-40";s:6:"yacute";s:3:"-40";s:9:"ydieresis";s:3:"-40";}s:9:"Adieresis";a:48:{s:1:"C";s:3:"-30";s:6:"Cacute";s:3:"-30";s:6:"Ccaron";s:3:"-30";s:8:"Ccedilla";s:3:"-30";s:1:"G";s:3:"-30";s:6:"Gbreve";s:3:"-30";s:12:"Gcommaaccent";s:3:"-30";s:1:"O";s:3:"-30";s:6:"Oacute";s:3:"-30";s:11:"Ocircumflex";s:3:"-30";s:9:"Odieresis";s:3:"-30";s:6:"Ograve";s:3:"-30";s:13:"Ohungarumlaut";s:3:"-30";s:7:"Omacron";s:3:"-30";s:6:"Oslash";s:3:"-30";s:6:"Otilde";s:3:"-30";s:1:"Q";s:3:"-30";s:1:"T";s:4:"-120";s:6:"Tcaron";s:4:"-120";s:12:"Tcommaaccent";s:4:"-120";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-70";s:1:"W";s:3:"-50";s:1:"Y";s:4:"-100";s:6:"Yacute";s:4:"-100";s:9:"Ydieresis";s:4:"-100";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-40";s:1:"w";s:3:"-40";s:1:"y";s:3:"-40";s:6:"yacute";s:3:"-40";s:9:"ydieresis";s:3:"-40";}s:6:"Agrave";a:48:{s:1:"C";s:3:"-30";s:6:"Cacute";s:3:"-30";s:6:"Ccaron";s:3:"-30";s:8:"Ccedilla";s:3:"-30";s:1:"G";s:3:"-30";s:6:"Gbreve";s:3:"-30";s:12:"Gcommaaccent";s:3:"-30";s:1:"O";s:3:"-30";s:6:"Oacute";s:3:"-30";s:11:"Ocircumflex";s:3:"-30";s:9:"Odieresis";s:3:"-30";s:6:"Ograve";s:3:"-30";s:13:"Ohungarumlaut";s:3:"-30";s:7:"Omacron";s:3:"-30";s:6:"Oslash";s:3:"-30";s:6:"Otilde";s:3:"-30";s:1:"Q";s:3:"-30";s:1:"T";s:4:"-120";s:6:"Tcaron";s:4:"-120";s:12:"Tcommaaccent";s:4:"-120";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-70";s:1:"W";s:3:"-50";s:1:"Y";s:4:"-100";s:6:"Yacute";s:4:"-100";s:9:"Ydieresis";s:4:"-100";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-40";s:1:"w";s:3:"-40";s:1:"y";s:3:"-40";s:6:"yacute";s:3:"-40";s:9:"ydieresis";s:3:"-40";}s:7:"Amacron";a:48:{s:1:"C";s:3:"-30";s:6:"Cacute";s:3:"-30";s:6:"Ccaron";s:3:"-30";s:8:"Ccedilla";s:3:"-30";s:1:"G";s:3:"-30";s:6:"Gbreve";s:3:"-30";s:12:"Gcommaaccent";s:3:"-30";s:1:"O";s:3:"-30";s:6:"Oacute";s:3:"-30";s:11:"Ocircumflex";s:3:"-30";s:9:"Odieresis";s:3:"-30";s:6:"Ograve";s:3:"-30";s:13:"Ohungarumlaut";s:3:"-30";s:7:"Omacron";s:3:"-30";s:6:"Oslash";s:3:"-30";s:6:"Otilde";s:3:"-30";s:1:"Q";s:3:"-30";s:1:"T";s:4:"-120";s:6:"Tcaron";s:4:"-120";s:12:"Tcommaaccent";s:4:"-120";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-70";s:1:"W";s:3:"-50";s:1:"Y";s:4:"-100";s:6:"Yacute";s:4:"-100";s:9:"Ydieresis";s:4:"-100";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-40";s:1:"w";s:3:"-40";s:1:"y";s:3:"-40";s:6:"yacute";s:3:"-40";s:9:"ydieresis";s:3:"-40";}s:7:"Aogonek";a:48:{s:1:"C";s:3:"-30";s:6:"Cacute";s:3:"-30";s:6:"Ccaron";s:3:"-30";s:8:"Ccedilla";s:3:"-30";s:1:"G";s:3:"-30";s:6:"Gbreve";s:3:"-30";s:12:"Gcommaaccent";s:3:"-30";s:1:"O";s:3:"-30";s:6:"Oacute";s:3:"-30";s:11:"Ocircumflex";s:3:"-30";s:9:"Odieresis";s:3:"-30";s:6:"Ograve";s:3:"-30";s:13:"Ohungarumlaut";s:3:"-30";s:7:"Omacron";s:3:"-30";s:6:"Oslash";s:3:"-30";s:6:"Otilde";s:3:"-30";s:1:"Q";s:3:"-30";s:1:"T";s:4:"-120";s:6:"Tcaron";s:4:"-120";s:12:"Tcommaaccent";s:4:"-120";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-70";s:1:"W";s:3:"-50";s:1:"Y";s:4:"-100";s:6:"Yacute";s:4:"-100";s:9:"Ydieresis";s:4:"-100";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-40";s:1:"w";s:3:"-40";s:1:"y";s:3:"-40";s:6:"yacute";s:3:"-40";s:9:"ydieresis";s:3:"-40";}s:5:"Aring";a:48:{s:1:"C";s:3:"-30";s:6:"Cacute";s:3:"-30";s:6:"Ccaron";s:3:"-30";s:8:"Ccedilla";s:3:"-30";s:1:"G";s:3:"-30";s:6:"Gbreve";s:3:"-30";s:12:"Gcommaaccent";s:3:"-30";s:1:"O";s:3:"-30";s:6:"Oacute";s:3:"-30";s:11:"Ocircumflex";s:3:"-30";s:9:"Odieresis";s:3:"-30";s:6:"Ograve";s:3:"-30";s:13:"Ohungarumlaut";s:3:"-30";s:7:"Omacron";s:3:"-30";s:6:"Oslash";s:3:"-30";s:6:"Otilde";s:3:"-30";s:1:"Q";s:3:"-30";s:1:"T";s:4:"-120";s:6:"Tcaron";s:4:"-120";s:12:"Tcommaaccent";s:4:"-120";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-70";s:1:"W";s:3:"-50";s:1:"Y";s:4:"-100";s:6:"Yacute";s:4:"-100";s:9:"Ydieresis";s:4:"-100";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-40";s:1:"w";s:3:"-40";s:1:"y";s:3:"-40";s:6:"yacute";s:3:"-40";s:9:"ydieresis";s:3:"-40";}s:6:"Atilde";a:48:{s:1:"C";s:3:"-30";s:6:"Cacute";s:3:"-30";s:6:"Ccaron";s:3:"-30";s:8:"Ccedilla";s:3:"-30";s:1:"G";s:3:"-30";s:6:"Gbreve";s:3:"-30";s:12:"Gcommaaccent";s:3:"-30";s:1:"O";s:3:"-30";s:6:"Oacute";s:3:"-30";s:11:"Ocircumflex";s:3:"-30";s:9:"Odieresis";s:3:"-30";s:6:"Ograve";s:3:"-30";s:13:"Ohungarumlaut";s:3:"-30";s:7:"Omacron";s:3:"-30";s:6:"Oslash";s:3:"-30";s:6:"Otilde";s:3:"-30";s:1:"Q";s:3:"-30";s:1:"T";s:4:"-120";s:6:"Tcaron";s:4:"-120";s:12:"Tcommaaccent";s:4:"-120";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-70";s:1:"W";s:3:"-50";s:1:"Y";s:4:"-100";s:6:"Yacute";s:4:"-100";s:9:"Ydieresis";s:4:"-100";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-40";s:1:"w";s:3:"-40";s:1:"y";s:3:"-40";s:6:"yacute";s:3:"-40";s:9:"ydieresis";s:3:"-40";}s:1:"B";a:11:{s:1:"U";s:3:"-10";s:6:"Uacute";s:3:"-10";s:11:"Ucircumflex";s:3:"-10";s:9:"Udieresis";s:3:"-10";s:6:"Ugrave";s:3:"-10";s:13:"Uhungarumlaut";s:3:"-10";s:7:"Umacron";s:3:"-10";s:7:"Uogonek";s:3:"-10";s:5:"Uring";s:3:"-10";s:5:"comma";s:3:"-20";s:6:"period";s:3:"-20";}s:1:"C";a:2:{s:5:"comma";s:3:"-30";s:6:"period";s:3:"-30";}s:6:"Cacute";a:2:{s:5:"comma";s:3:"-30";s:6:"period";s:3:"-30";}s:6:"Ccaron";a:2:{s:5:"comma";s:3:"-30";s:6:"period";s:3:"-30";}s:8:"Ccedilla";a:2:{s:5:"comma";s:3:"-30";s:6:"period";s:3:"-30";}s:1:"D";a:17:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:1:"V";s:3:"-70";s:1:"W";s:3:"-40";s:1:"Y";s:3:"-90";s:6:"Yacute";s:3:"-90";s:9:"Ydieresis";s:3:"-90";s:5:"comma";s:3:"-70";s:6:"period";s:3:"-70";}s:6:"Dcaron";a:17:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:1:"V";s:3:"-70";s:1:"W";s:3:"-40";s:1:"Y";s:3:"-90";s:6:"Yacute";s:3:"-90";s:9:"Ydieresis";s:3:"-90";s:5:"comma";s:3:"-70";s:6:"period";s:3:"-70";}s:6:"Dcroat";a:17:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:1:"V";s:3:"-70";s:1:"W";s:3:"-40";s:1:"Y";s:3:"-90";s:6:"Yacute";s:3:"-90";s:9:"Ydieresis";s:3:"-90";s:5:"comma";s:3:"-70";s:6:"period";s:3:"-70";}s:1:"F";a:44:{s:1:"A";s:3:"-80";s:6:"Aacute";s:3:"-80";s:6:"Abreve";s:3:"-80";s:11:"Acircumflex";s:3:"-80";s:9:"Adieresis";s:3:"-80";s:6:"Agrave";s:3:"-80";s:7:"Amacron";s:3:"-80";s:7:"Aogonek";s:3:"-80";s:5:"Aring";s:3:"-80";s:6:"Atilde";s:3:"-80";s:1:"a";s:3:"-50";s:6:"aacute";s:3:"-50";s:6:"abreve";s:3:"-50";s:11:"acircumflex";s:3:"-50";s:9:"adieresis";s:3:"-50";s:6:"agrave";s:3:"-50";s:7:"amacron";s:3:"-50";s:7:"aogonek";s:3:"-50";s:5:"aring";s:3:"-50";s:6:"atilde";s:3:"-50";s:5:"comma";s:4:"-150";s:1:"e";s:3:"-30";s:6:"eacute";s:3:"-30";s:6:"ecaron";s:3:"-30";s:11:"ecircumflex";s:3:"-30";s:9:"edieresis";s:3:"-30";s:10:"edotaccent";s:3:"-30";s:6:"egrave";s:3:"-30";s:7:"emacron";s:3:"-30";s:7:"eogonek";s:3:"-30";s:1:"o";s:3:"-30";s:6:"oacute";s:3:"-30";s:11:"ocircumflex";s:3:"-30";s:9:"odieresis";s:3:"-30";s:6:"ograve";s:3:"-30";s:13:"ohungarumlaut";s:3:"-30";s:7:"omacron";s:3:"-30";s:6:"oslash";s:3:"-30";s:6:"otilde";s:3:"-30";s:6:"period";s:4:"-150";s:1:"r";s:3:"-45";s:6:"racute";s:3:"-45";s:6:"rcaron";s:3:"-45";s:12:"rcommaaccent";s:3:"-45";}s:1:"J";a:31:{s:1:"A";s:3:"-20";s:6:"Aacute";s:3:"-20";s:6:"Abreve";s:3:"-20";s:11:"Acircumflex";s:3:"-20";s:9:"Adieresis";s:3:"-20";s:6:"Agrave";s:3:"-20";s:7:"Amacron";s:3:"-20";s:7:"Aogonek";s:3:"-20";s:5:"Aring";s:3:"-20";s:6:"Atilde";s:3:"-20";s:1:"a";s:3:"-20";s:6:"aacute";s:3:"-20";s:6:"abreve";s:3:"-20";s:11:"acircumflex";s:3:"-20";s:9:"adieresis";s:3:"-20";s:6:"agrave";s:3:"-20";s:7:"amacron";s:3:"-20";s:7:"aogonek";s:3:"-20";s:5:"aring";s:3:"-20";s:6:"atilde";s:3:"-20";s:5:"comma";s:3:"-30";s:6:"period";s:3:"-30";s:1:"u";s:3:"-20";s:6:"uacute";s:3:"-20";s:11:"ucircumflex";s:3:"-20";s:9:"udieresis";s:3:"-20";s:6:"ugrave";s:3:"-20";s:13:"uhungarumlaut";s:3:"-20";s:7:"umacron";s:3:"-20";s:7:"uogonek";s:3:"-20";s:5:"uring";s:3:"-20";}s:1:"K";a:39:{s:1:"O";s:3:"-50";s:6:"Oacute";s:3:"-50";s:11:"Ocircumflex";s:3:"-50";s:9:"Odieresis";s:3:"-50";s:6:"Ograve";s:3:"-50";s:13:"Ohungarumlaut";s:3:"-50";s:7:"Omacron";s:3:"-50";s:6:"Oslash";s:3:"-50";s:6:"Otilde";s:3:"-50";s:1:"e";s:3:"-40";s:6:"eacute";s:3:"-40";s:6:"ecaron";s:3:"-40";s:11:"ecircumflex";s:3:"-40";s:9:"edieresis";s:3:"-40";s:10:"edotaccent";s:3:"-40";s:6:"egrave";s:3:"-40";s:7:"emacron";s:3:"-40";s:7:"eogonek";s:3:"-40";s:1:"o";s:3:"-40";s:6:"oacute";s:3:"-40";s:11:"ocircumflex";s:3:"-40";s:9:"odieresis";s:3:"-40";s:6:"ograve";s:3:"-40";s:13:"ohungarumlaut";s:3:"-40";s:7:"omacron";s:3:"-40";s:6:"oslash";s:3:"-40";s:6:"otilde";s:3:"-40";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"y";s:3:"-50";s:6:"yacute";s:3:"-50";s:9:"ydieresis";s:3:"-50";}s:12:"Kcommaaccent";a:39:{s:1:"O";s:3:"-50";s:6:"Oacute";s:3:"-50";s:11:"Ocircumflex";s:3:"-50";s:9:"Odieresis";s:3:"-50";s:6:"Ograve";s:3:"-50";s:13:"Ohungarumlaut";s:3:"-50";s:7:"Omacron";s:3:"-50";s:6:"Oslash";s:3:"-50";s:6:"Otilde";s:3:"-50";s:1:"e";s:3:"-40";s:6:"eacute";s:3:"-40";s:6:"ecaron";s:3:"-40";s:11:"ecircumflex";s:3:"-40";s:9:"edieresis";s:3:"-40";s:10:"edotaccent";s:3:"-40";s:6:"egrave";s:3:"-40";s:7:"emacron";s:3:"-40";s:7:"eogonek";s:3:"-40";s:1:"o";s:3:"-40";s:6:"oacute";s:3:"-40";s:11:"ocircumflex";s:3:"-40";s:9:"odieresis";s:3:"-40";s:6:"ograve";s:3:"-40";s:13:"ohungarumlaut";s:3:"-40";s:7:"omacron";s:3:"-40";s:6:"oslash";s:3:"-40";s:6:"otilde";s:3:"-40";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"y";s:3:"-50";s:6:"yacute";s:3:"-50";s:9:"ydieresis";s:3:"-50";}s:1:"L";a:13:{s:1:"T";s:4:"-110";s:6:"Tcaron";s:4:"-110";s:12:"Tcommaaccent";s:4:"-110";s:1:"V";s:4:"-110";s:1:"W";s:3:"-70";s:1:"Y";s:4:"-140";s:6:"Yacute";s:4:"-140";s:9:"Ydieresis";s:4:"-140";s:13:"quotedblright";s:4:"-140";s:10:"quoteright";s:4:"-160";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:6:"Lacute";a:13:{s:1:"T";s:4:"-110";s:6:"Tcaron";s:4:"-110";s:12:"Tcommaaccent";s:4:"-110";s:1:"V";s:4:"-110";s:1:"W";s:3:"-70";s:1:"Y";s:4:"-140";s:6:"Yacute";s:4:"-140";s:9:"Ydieresis";s:4:"-140";s:13:"quotedblright";s:4:"-140";s:10:"quoteright";s:4:"-160";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:6:"Lcaron";a:13:{s:1:"T";s:4:"-110";s:6:"Tcaron";s:4:"-110";s:12:"Tcommaaccent";s:4:"-110";s:1:"V";s:4:"-110";s:1:"W";s:3:"-70";s:1:"Y";s:4:"-140";s:6:"Yacute";s:4:"-140";s:9:"Ydieresis";s:4:"-140";s:13:"quotedblright";s:4:"-140";s:10:"quoteright";s:4:"-160";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:12:"Lcommaaccent";a:13:{s:1:"T";s:4:"-110";s:6:"Tcaron";s:4:"-110";s:12:"Tcommaaccent";s:4:"-110";s:1:"V";s:4:"-110";s:1:"W";s:3:"-70";s:1:"Y";s:4:"-140";s:6:"Yacute";s:4:"-140";s:9:"Ydieresis";s:4:"-140";s:13:"quotedblright";s:4:"-140";s:10:"quoteright";s:4:"-160";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:6:"Lslash";a:13:{s:1:"T";s:4:"-110";s:6:"Tcaron";s:4:"-110";s:12:"Tcommaaccent";s:4:"-110";s:1:"V";s:4:"-110";s:1:"W";s:3:"-70";s:1:"Y";s:4:"-140";s:6:"Yacute";s:4:"-140";s:9:"Ydieresis";s:4:"-140";s:13:"quotedblright";s:4:"-140";s:10:"quoteright";s:4:"-160";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:1:"O";a:21:{s:1:"A";s:3:"-20";s:6:"Aacute";s:3:"-20";s:6:"Abreve";s:3:"-20";s:11:"Acircumflex";s:3:"-20";s:9:"Adieresis";s:3:"-20";s:6:"Agrave";s:3:"-20";s:7:"Amacron";s:3:"-20";s:7:"Aogonek";s:3:"-20";s:5:"Aring";s:3:"-20";s:6:"Atilde";s:3:"-20";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-30";s:1:"X";s:3:"-60";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:6:"Oacute";a:21:{s:1:"A";s:3:"-20";s:6:"Aacute";s:3:"-20";s:6:"Abreve";s:3:"-20";s:11:"Acircumflex";s:3:"-20";s:9:"Adieresis";s:3:"-20";s:6:"Agrave";s:3:"-20";s:7:"Amacron";s:3:"-20";s:7:"Aogonek";s:3:"-20";s:5:"Aring";s:3:"-20";s:6:"Atilde";s:3:"-20";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-30";s:1:"X";s:3:"-60";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:11:"Ocircumflex";a:21:{s:1:"A";s:3:"-20";s:6:"Aacute";s:3:"-20";s:6:"Abreve";s:3:"-20";s:11:"Acircumflex";s:3:"-20";s:9:"Adieresis";s:3:"-20";s:6:"Agrave";s:3:"-20";s:7:"Amacron";s:3:"-20";s:7:"Aogonek";s:3:"-20";s:5:"Aring";s:3:"-20";s:6:"Atilde";s:3:"-20";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-30";s:1:"X";s:3:"-60";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:9:"Odieresis";a:21:{s:1:"A";s:3:"-20";s:6:"Aacute";s:3:"-20";s:6:"Abreve";s:3:"-20";s:11:"Acircumflex";s:3:"-20";s:9:"Adieresis";s:3:"-20";s:6:"Agrave";s:3:"-20";s:7:"Amacron";s:3:"-20";s:7:"Aogonek";s:3:"-20";s:5:"Aring";s:3:"-20";s:6:"Atilde";s:3:"-20";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-30";s:1:"X";s:3:"-60";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:6:"Ograve";a:21:{s:1:"A";s:3:"-20";s:6:"Aacute";s:3:"-20";s:6:"Abreve";s:3:"-20";s:11:"Acircumflex";s:3:"-20";s:9:"Adieresis";s:3:"-20";s:6:"Agrave";s:3:"-20";s:7:"Amacron";s:3:"-20";s:7:"Aogonek";s:3:"-20";s:5:"Aring";s:3:"-20";s:6:"Atilde";s:3:"-20";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-30";s:1:"X";s:3:"-60";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:13:"Ohungarumlaut";a:21:{s:1:"A";s:3:"-20";s:6:"Aacute";s:3:"-20";s:6:"Abreve";s:3:"-20";s:11:"Acircumflex";s:3:"-20";s:9:"Adieresis";s:3:"-20";s:6:"Agrave";s:3:"-20";s:7:"Amacron";s:3:"-20";s:7:"Aogonek";s:3:"-20";s:5:"Aring";s:3:"-20";s:6:"Atilde";s:3:"-20";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-30";s:1:"X";s:3:"-60";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:7:"Omacron";a:21:{s:1:"A";s:3:"-20";s:6:"Aacute";s:3:"-20";s:6:"Abreve";s:3:"-20";s:11:"Acircumflex";s:3:"-20";s:9:"Adieresis";s:3:"-20";s:6:"Agrave";s:3:"-20";s:7:"Amacron";s:3:"-20";s:7:"Aogonek";s:3:"-20";s:5:"Aring";s:3:"-20";s:6:"Atilde";s:3:"-20";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-30";s:1:"X";s:3:"-60";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:6:"Oslash";a:21:{s:1:"A";s:3:"-20";s:6:"Aacute";s:3:"-20";s:6:"Abreve";s:3:"-20";s:11:"Acircumflex";s:3:"-20";s:9:"Adieresis";s:3:"-20";s:6:"Agrave";s:3:"-20";s:7:"Amacron";s:3:"-20";s:7:"Aogonek";s:3:"-20";s:5:"Aring";s:3:"-20";s:6:"Atilde";s:3:"-20";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-30";s:1:"X";s:3:"-60";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:6:"Otilde";a:21:{s:1:"A";s:3:"-20";s:6:"Aacute";s:3:"-20";s:6:"Abreve";s:3:"-20";s:11:"Acircumflex";s:3:"-20";s:9:"Adieresis";s:3:"-20";s:6:"Agrave";s:3:"-20";s:7:"Amacron";s:3:"-20";s:7:"Aogonek";s:3:"-20";s:5:"Aring";s:3:"-20";s:6:"Atilde";s:3:"-20";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-30";s:1:"X";s:3:"-60";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:1:"P";a:40:{s:1:"A";s:4:"-120";s:6:"Aacute";s:4:"-120";s:6:"Abreve";s:4:"-120";s:11:"Acircumflex";s:4:"-120";s:9:"Adieresis";s:4:"-120";s:6:"Agrave";s:4:"-120";s:7:"Amacron";s:4:"-120";s:7:"Aogonek";s:4:"-120";s:5:"Aring";s:4:"-120";s:6:"Atilde";s:4:"-120";s:1:"a";s:3:"-40";s:6:"aacute";s:3:"-40";s:6:"abreve";s:3:"-40";s:11:"acircumflex";s:3:"-40";s:9:"adieresis";s:3:"-40";s:6:"agrave";s:3:"-40";s:7:"amacron";s:3:"-40";s:7:"aogonek";s:3:"-40";s:5:"aring";s:3:"-40";s:6:"atilde";s:3:"-40";s:5:"comma";s:4:"-180";s:1:"e";s:3:"-50";s:6:"eacute";s:3:"-50";s:6:"ecaron";s:3:"-50";s:11:"ecircumflex";s:3:"-50";s:9:"edieresis";s:3:"-50";s:10:"edotaccent";s:3:"-50";s:6:"egrave";s:3:"-50";s:7:"emacron";s:3:"-50";s:7:"eogonek";s:3:"-50";s:1:"o";s:3:"-50";s:6:"oacute";s:3:"-50";s:11:"ocircumflex";s:3:"-50";s:9:"odieresis";s:3:"-50";s:6:"ograve";s:3:"-50";s:13:"ohungarumlaut";s:3:"-50";s:7:"omacron";s:3:"-50";s:6:"oslash";s:3:"-50";s:6:"otilde";s:3:"-50";s:6:"period";s:4:"-180";}s:1:"Q";a:9:{s:1:"U";s:3:"-10";s:6:"Uacute";s:3:"-10";s:11:"Ucircumflex";s:3:"-10";s:9:"Udieresis";s:3:"-10";s:6:"Ugrave";s:3:"-10";s:13:"Uhungarumlaut";s:3:"-10";s:7:"Umacron";s:3:"-10";s:7:"Uogonek";s:3:"-10";s:5:"Uring";s:3:"-10";}s:1:"R";a:26:{s:1:"O";s:3:"-20";s:6:"Oacute";s:3:"-20";s:11:"Ocircumflex";s:3:"-20";s:9:"Odieresis";s:3:"-20";s:6:"Ograve";s:3:"-20";s:13:"Ohungarumlaut";s:3:"-20";s:7:"Omacron";s:3:"-20";s:6:"Oslash";s:3:"-20";s:6:"Otilde";s:3:"-20";s:1:"T";s:3:"-30";s:6:"Tcaron";s:3:"-30";s:12:"Tcommaaccent";s:3:"-30";s:1:"U";s:3:"-40";s:6:"Uacute";s:3:"-40";s:11:"Ucircumflex";s:3:"-40";s:9:"Udieresis";s:3:"-40";s:6:"Ugrave";s:3:"-40";s:13:"Uhungarumlaut";s:3:"-40";s:7:"Umacron";s:3:"-40";s:7:"Uogonek";s:3:"-40";s:5:"Uring";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-30";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:6:"Racute";a:26:{s:1:"O";s:3:"-20";s:6:"Oacute";s:3:"-20";s:11:"Ocircumflex";s:3:"-20";s:9:"Odieresis";s:3:"-20";s:6:"Ograve";s:3:"-20";s:13:"Ohungarumlaut";s:3:"-20";s:7:"Omacron";s:3:"-20";s:6:"Oslash";s:3:"-20";s:6:"Otilde";s:3:"-20";s:1:"T";s:3:"-30";s:6:"Tcaron";s:3:"-30";s:12:"Tcommaaccent";s:3:"-30";s:1:"U";s:3:"-40";s:6:"Uacute";s:3:"-40";s:11:"Ucircumflex";s:3:"-40";s:9:"Udieresis";s:3:"-40";s:6:"Ugrave";s:3:"-40";s:13:"Uhungarumlaut";s:3:"-40";s:7:"Umacron";s:3:"-40";s:7:"Uogonek";s:3:"-40";s:5:"Uring";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-30";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:6:"Rcaron";a:26:{s:1:"O";s:3:"-20";s:6:"Oacute";s:3:"-20";s:11:"Ocircumflex";s:3:"-20";s:9:"Odieresis";s:3:"-20";s:6:"Ograve";s:3:"-20";s:13:"Ohungarumlaut";s:3:"-20";s:7:"Omacron";s:3:"-20";s:6:"Oslash";s:3:"-20";s:6:"Otilde";s:3:"-20";s:1:"T";s:3:"-30";s:6:"Tcaron";s:3:"-30";s:12:"Tcommaaccent";s:3:"-30";s:1:"U";s:3:"-40";s:6:"Uacute";s:3:"-40";s:11:"Ucircumflex";s:3:"-40";s:9:"Udieresis";s:3:"-40";s:6:"Ugrave";s:3:"-40";s:13:"Uhungarumlaut";s:3:"-40";s:7:"Umacron";s:3:"-40";s:7:"Uogonek";s:3:"-40";s:5:"Uring";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-30";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:12:"Rcommaaccent";a:26:{s:1:"O";s:3:"-20";s:6:"Oacute";s:3:"-20";s:11:"Ocircumflex";s:3:"-20";s:9:"Odieresis";s:3:"-20";s:6:"Ograve";s:3:"-20";s:13:"Ohungarumlaut";s:3:"-20";s:7:"Omacron";s:3:"-20";s:6:"Oslash";s:3:"-20";s:6:"Otilde";s:3:"-20";s:1:"T";s:3:"-30";s:6:"Tcaron";s:3:"-30";s:12:"Tcommaaccent";s:3:"-30";s:1:"U";s:3:"-40";s:6:"Uacute";s:3:"-40";s:11:"Ucircumflex";s:3:"-40";s:9:"Udieresis";s:3:"-40";s:6:"Ugrave";s:3:"-40";s:13:"Uhungarumlaut";s:3:"-40";s:7:"Umacron";s:3:"-40";s:7:"Uogonek";s:3:"-40";s:5:"Uring";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-30";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:1:"S";a:2:{s:5:"comma";s:3:"-20";s:6:"period";s:3:"-20";}s:6:"Sacute";a:2:{s:5:"comma";s:3:"-20";s:6:"period";s:3:"-20";}s:6:"Scaron";a:2:{s:5:"comma";s:3:"-20";s:6:"period";s:3:"-20";}s:8:"Scedilla";a:2:{s:5:"comma";s:3:"-20";s:6:"period";s:3:"-20";}s:12:"Scommaaccent";a:2:{s:5:"comma";s:3:"-20";s:6:"period";s:3:"-20";}s:1:"T";a:69:{s:1:"A";s:4:"-120";s:6:"Aacute";s:4:"-120";s:6:"Abreve";s:4:"-120";s:11:"Acircumflex";s:4:"-120";s:9:"Adieresis";s:4:"-120";s:6:"Agrave";s:4:"-120";s:7:"Amacron";s:4:"-120";s:7:"Aogonek";s:4:"-120";s:5:"Aring";s:4:"-120";s:6:"Atilde";s:4:"-120";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"a";s:4:"-120";s:6:"aacute";s:4:"-120";s:6:"abreve";s:3:"-60";s:11:"acircumflex";s:4:"-120";s:9:"adieresis";s:4:"-120";s:6:"agrave";s:4:"-120";s:7:"amacron";s:3:"-60";s:7:"aogonek";s:4:"-120";s:5:"aring";s:4:"-120";s:6:"atilde";s:3:"-60";s:5:"colon";s:3:"-20";s:5:"comma";s:4:"-120";s:1:"e";s:4:"-120";s:6:"eacute";s:4:"-120";s:6:"ecaron";s:4:"-120";s:11:"ecircumflex";s:4:"-120";s:9:"edieresis";s:4:"-120";s:10:"edotaccent";s:4:"-120";s:6:"egrave";s:3:"-60";s:7:"emacron";s:3:"-60";s:7:"eogonek";s:4:"-120";s:6:"hyphen";s:4:"-140";s:1:"o";s:4:"-120";s:6:"oacute";s:4:"-120";s:11:"ocircumflex";s:4:"-120";s:9:"odieresis";s:4:"-120";s:6:"ograve";s:4:"-120";s:13:"ohungarumlaut";s:4:"-120";s:7:"omacron";s:3:"-60";s:6:"oslash";s:4:"-120";s:6:"otilde";s:3:"-60";s:6:"period";s:4:"-120";s:1:"r";s:4:"-120";s:6:"racute";s:4:"-120";s:6:"rcaron";s:4:"-120";s:12:"rcommaaccent";s:4:"-120";s:9:"semicolon";s:3:"-20";s:1:"u";s:4:"-120";s:6:"uacute";s:4:"-120";s:11:"ucircumflex";s:4:"-120";s:9:"udieresis";s:4:"-120";s:6:"ugrave";s:4:"-120";s:13:"uhungarumlaut";s:4:"-120";s:7:"umacron";s:3:"-60";s:7:"uogonek";s:4:"-120";s:5:"uring";s:4:"-120";s:1:"w";s:4:"-120";s:1:"y";s:4:"-120";s:6:"yacute";s:4:"-120";s:9:"ydieresis";s:3:"-60";}s:6:"Tcaron";a:69:{s:1:"A";s:4:"-120";s:6:"Aacute";s:4:"-120";s:6:"Abreve";s:4:"-120";s:11:"Acircumflex";s:4:"-120";s:9:"Adieresis";s:4:"-120";s:6:"Agrave";s:4:"-120";s:7:"Amacron";s:4:"-120";s:7:"Aogonek";s:4:"-120";s:5:"Aring";s:4:"-120";s:6:"Atilde";s:4:"-120";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"a";s:4:"-120";s:6:"aacute";s:4:"-120";s:6:"abreve";s:3:"-60";s:11:"acircumflex";s:4:"-120";s:9:"adieresis";s:4:"-120";s:6:"agrave";s:4:"-120";s:7:"amacron";s:3:"-60";s:7:"aogonek";s:4:"-120";s:5:"aring";s:4:"-120";s:6:"atilde";s:3:"-60";s:5:"colon";s:3:"-20";s:5:"comma";s:4:"-120";s:1:"e";s:4:"-120";s:6:"eacute";s:4:"-120";s:6:"ecaron";s:4:"-120";s:11:"ecircumflex";s:4:"-120";s:9:"edieresis";s:4:"-120";s:10:"edotaccent";s:4:"-120";s:6:"egrave";s:3:"-60";s:7:"emacron";s:3:"-60";s:7:"eogonek";s:4:"-120";s:6:"hyphen";s:4:"-140";s:1:"o";s:4:"-120";s:6:"oacute";s:4:"-120";s:11:"ocircumflex";s:4:"-120";s:9:"odieresis";s:4:"-120";s:6:"ograve";s:4:"-120";s:13:"ohungarumlaut";s:4:"-120";s:7:"omacron";s:3:"-60";s:6:"oslash";s:4:"-120";s:6:"otilde";s:3:"-60";s:6:"period";s:4:"-120";s:1:"r";s:4:"-120";s:6:"racute";s:4:"-120";s:6:"rcaron";s:4:"-120";s:12:"rcommaaccent";s:4:"-120";s:9:"semicolon";s:3:"-20";s:1:"u";s:4:"-120";s:6:"uacute";s:4:"-120";s:11:"ucircumflex";s:4:"-120";s:9:"udieresis";s:4:"-120";s:6:"ugrave";s:4:"-120";s:13:"uhungarumlaut";s:4:"-120";s:7:"umacron";s:3:"-60";s:7:"uogonek";s:4:"-120";s:5:"uring";s:4:"-120";s:1:"w";s:4:"-120";s:1:"y";s:4:"-120";s:6:"yacute";s:4:"-120";s:9:"ydieresis";s:3:"-60";}s:12:"Tcommaaccent";a:69:{s:1:"A";s:4:"-120";s:6:"Aacute";s:4:"-120";s:6:"Abreve";s:4:"-120";s:11:"Acircumflex";s:4:"-120";s:9:"Adieresis";s:4:"-120";s:6:"Agrave";s:4:"-120";s:7:"Amacron";s:4:"-120";s:7:"Aogonek";s:4:"-120";s:5:"Aring";s:4:"-120";s:6:"Atilde";s:4:"-120";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"a";s:4:"-120";s:6:"aacute";s:4:"-120";s:6:"abreve";s:3:"-60";s:11:"acircumflex";s:4:"-120";s:9:"adieresis";s:4:"-120";s:6:"agrave";s:4:"-120";s:7:"amacron";s:3:"-60";s:7:"aogonek";s:4:"-120";s:5:"aring";s:4:"-120";s:6:"atilde";s:3:"-60";s:5:"colon";s:3:"-20";s:5:"comma";s:4:"-120";s:1:"e";s:4:"-120";s:6:"eacute";s:4:"-120";s:6:"ecaron";s:4:"-120";s:11:"ecircumflex";s:4:"-120";s:9:"edieresis";s:4:"-120";s:10:"edotaccent";s:4:"-120";s:6:"egrave";s:3:"-60";s:7:"emacron";s:3:"-60";s:7:"eogonek";s:4:"-120";s:6:"hyphen";s:4:"-140";s:1:"o";s:4:"-120";s:6:"oacute";s:4:"-120";s:11:"ocircumflex";s:4:"-120";s:9:"odieresis";s:4:"-120";s:6:"ograve";s:4:"-120";s:13:"ohungarumlaut";s:4:"-120";s:7:"omacron";s:3:"-60";s:6:"oslash";s:4:"-120";s:6:"otilde";s:3:"-60";s:6:"period";s:4:"-120";s:1:"r";s:4:"-120";s:6:"racute";s:4:"-120";s:6:"rcaron";s:4:"-120";s:12:"rcommaaccent";s:4:"-120";s:9:"semicolon";s:3:"-20";s:1:"u";s:4:"-120";s:6:"uacute";s:4:"-120";s:11:"ucircumflex";s:4:"-120";s:9:"udieresis";s:4:"-120";s:6:"ugrave";s:4:"-120";s:13:"uhungarumlaut";s:4:"-120";s:7:"umacron";s:3:"-60";s:7:"uogonek";s:4:"-120";s:5:"uring";s:4:"-120";s:1:"w";s:4:"-120";s:1:"y";s:4:"-120";s:6:"yacute";s:4:"-120";s:9:"ydieresis";s:3:"-60";}s:1:"U";a:12:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:6:"Uacute";a:12:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:11:"Ucircumflex";a:12:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:9:"Udieresis";a:12:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:6:"Ugrave";a:12:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:13:"Uhungarumlaut";a:12:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:7:"Umacron";a:12:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:7:"Uogonek";a:12:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:5:"Uring";a:12:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:1:"V";a:64:{s:1:"A";s:3:"-80";s:6:"Aacute";s:3:"-80";s:6:"Abreve";s:3:"-80";s:11:"Acircumflex";s:3:"-80";s:9:"Adieresis";s:3:"-80";s:6:"Agrave";s:3:"-80";s:7:"Amacron";s:3:"-80";s:7:"Aogonek";s:3:"-80";s:5:"Aring";s:3:"-80";s:6:"Atilde";s:3:"-80";s:1:"G";s:3:"-40";s:6:"Gbreve";s:3:"-40";s:12:"Gcommaaccent";s:3:"-40";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"a";s:3:"-70";s:6:"aacute";s:3:"-70";s:6:"abreve";s:3:"-70";s:11:"acircumflex";s:3:"-70";s:9:"adieresis";s:3:"-70";s:6:"agrave";s:3:"-70";s:7:"amacron";s:3:"-70";s:7:"aogonek";s:3:"-70";s:5:"aring";s:3:"-70";s:6:"atilde";s:3:"-70";s:5:"colon";s:3:"-40";s:5:"comma";s:4:"-125";s:1:"e";s:3:"-80";s:6:"eacute";s:3:"-80";s:6:"ecaron";s:3:"-80";s:11:"ecircumflex";s:3:"-80";s:9:"edieresis";s:3:"-80";s:10:"edotaccent";s:3:"-80";s:6:"egrave";s:3:"-80";s:7:"emacron";s:3:"-80";s:7:"eogonek";s:3:"-80";s:6:"hyphen";s:3:"-80";s:1:"o";s:3:"-80";s:6:"oacute";s:3:"-80";s:11:"ocircumflex";s:3:"-80";s:9:"odieresis";s:3:"-80";s:6:"ograve";s:3:"-80";s:13:"ohungarumlaut";s:3:"-80";s:7:"omacron";s:3:"-80";s:6:"oslash";s:3:"-80";s:6:"otilde";s:3:"-80";s:6:"period";s:4:"-125";s:9:"semicolon";s:3:"-40";s:1:"u";s:3:"-70";s:6:"uacute";s:3:"-70";s:11:"ucircumflex";s:3:"-70";s:9:"udieresis";s:3:"-70";s:6:"ugrave";s:3:"-70";s:13:"uhungarumlaut";s:3:"-70";s:7:"umacron";s:3:"-70";s:7:"uogonek";s:3:"-70";s:5:"uring";s:3:"-70";}s:1:"W";a:62:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:1:"O";s:3:"-20";s:6:"Oacute";s:3:"-20";s:11:"Ocircumflex";s:3:"-20";s:9:"Odieresis";s:3:"-20";s:6:"Ograve";s:3:"-20";s:13:"Ohungarumlaut";s:3:"-20";s:7:"Omacron";s:3:"-20";s:6:"Oslash";s:3:"-20";s:6:"Otilde";s:3:"-20";s:1:"a";s:3:"-40";s:6:"aacute";s:3:"-40";s:6:"abreve";s:3:"-40";s:11:"acircumflex";s:3:"-40";s:9:"adieresis";s:3:"-40";s:6:"agrave";s:3:"-40";s:7:"amacron";s:3:"-40";s:7:"aogonek";s:3:"-40";s:5:"aring";s:3:"-40";s:6:"atilde";s:3:"-40";s:5:"comma";s:3:"-80";s:1:"e";s:3:"-30";s:6:"eacute";s:3:"-30";s:6:"ecaron";s:3:"-30";s:11:"ecircumflex";s:3:"-30";s:9:"edieresis";s:3:"-30";s:10:"edotaccent";s:3:"-30";s:6:"egrave";s:3:"-30";s:7:"emacron";s:3:"-30";s:7:"eogonek";s:3:"-30";s:6:"hyphen";s:3:"-40";s:1:"o";s:3:"-30";s:6:"oacute";s:3:"-30";s:11:"ocircumflex";s:3:"-30";s:9:"odieresis";s:3:"-30";s:6:"ograve";s:3:"-30";s:13:"ohungarumlaut";s:3:"-30";s:7:"omacron";s:3:"-30";s:6:"oslash";s:3:"-30";s:6:"otilde";s:3:"-30";s:6:"period";s:3:"-80";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:1:"Y";a:64:{s:1:"A";s:4:"-110";s:6:"Aacute";s:4:"-110";s:6:"Abreve";s:4:"-110";s:11:"Acircumflex";s:4:"-110";s:9:"Adieresis";s:4:"-110";s:6:"Agrave";s:4:"-110";s:7:"Amacron";s:4:"-110";s:7:"Aogonek";s:4:"-110";s:5:"Aring";s:4:"-110";s:6:"Atilde";s:4:"-110";s:1:"O";s:3:"-85";s:6:"Oacute";s:3:"-85";s:11:"Ocircumflex";s:3:"-85";s:9:"Odieresis";s:3:"-85";s:6:"Ograve";s:3:"-85";s:13:"Ohungarumlaut";s:3:"-85";s:7:"Omacron";s:3:"-85";s:6:"Oslash";s:3:"-85";s:6:"Otilde";s:3:"-85";s:1:"a";s:4:"-140";s:6:"aacute";s:4:"-140";s:6:"abreve";s:3:"-70";s:11:"acircumflex";s:4:"-140";s:9:"adieresis";s:4:"-140";s:6:"agrave";s:4:"-140";s:7:"amacron";s:3:"-70";s:7:"aogonek";s:4:"-140";s:5:"aring";s:4:"-140";s:6:"atilde";s:4:"-140";s:5:"colon";s:3:"-60";s:5:"comma";s:4:"-140";s:1:"e";s:4:"-140";s:6:"eacute";s:4:"-140";s:6:"ecaron";s:4:"-140";s:11:"ecircumflex";s:4:"-140";s:9:"edieresis";s:4:"-140";s:10:"edotaccent";s:4:"-140";s:6:"egrave";s:4:"-140";s:7:"emacron";s:3:"-70";s:7:"eogonek";s:4:"-140";s:6:"hyphen";s:4:"-140";s:1:"i";s:3:"-20";s:6:"iacute";s:3:"-20";s:7:"iogonek";s:3:"-20";s:1:"o";s:4:"-140";s:6:"oacute";s:4:"-140";s:11:"ocircumflex";s:4:"-140";s:9:"odieresis";s:4:"-140";s:6:"ograve";s:4:"-140";s:13:"ohungarumlaut";s:4:"-140";s:7:"omacron";s:4:"-140";s:6:"oslash";s:4:"-140";s:6:"otilde";s:4:"-140";s:6:"period";s:4:"-140";s:9:"semicolon";s:3:"-60";s:1:"u";s:4:"-110";s:6:"uacute";s:4:"-110";s:11:"ucircumflex";s:4:"-110";s:9:"udieresis";s:4:"-110";s:6:"ugrave";s:4:"-110";s:13:"uhungarumlaut";s:4:"-110";s:7:"umacron";s:4:"-110";s:7:"uogonek";s:4:"-110";s:5:"uring";s:4:"-110";}s:6:"Yacute";a:64:{s:1:"A";s:4:"-110";s:6:"Aacute";s:4:"-110";s:6:"Abreve";s:4:"-110";s:11:"Acircumflex";s:4:"-110";s:9:"Adieresis";s:4:"-110";s:6:"Agrave";s:4:"-110";s:7:"Amacron";s:4:"-110";s:7:"Aogonek";s:4:"-110";s:5:"Aring";s:4:"-110";s:6:"Atilde";s:4:"-110";s:1:"O";s:3:"-85";s:6:"Oacute";s:3:"-85";s:11:"Ocircumflex";s:3:"-85";s:9:"Odieresis";s:3:"-85";s:6:"Ograve";s:3:"-85";s:13:"Ohungarumlaut";s:3:"-85";s:7:"Omacron";s:3:"-85";s:6:"Oslash";s:3:"-85";s:6:"Otilde";s:3:"-85";s:1:"a";s:4:"-140";s:6:"aacute";s:4:"-140";s:6:"abreve";s:3:"-70";s:11:"acircumflex";s:4:"-140";s:9:"adieresis";s:4:"-140";s:6:"agrave";s:4:"-140";s:7:"amacron";s:3:"-70";s:7:"aogonek";s:4:"-140";s:5:"aring";s:4:"-140";s:6:"atilde";s:3:"-70";s:5:"colon";s:3:"-60";s:5:"comma";s:4:"-140";s:1:"e";s:4:"-140";s:6:"eacute";s:4:"-140";s:6:"ecaron";s:4:"-140";s:11:"ecircumflex";s:4:"-140";s:9:"edieresis";s:4:"-140";s:10:"edotaccent";s:4:"-140";s:6:"egrave";s:4:"-140";s:7:"emacron";s:3:"-70";s:7:"eogonek";s:4:"-140";s:6:"hyphen";s:4:"-140";s:1:"i";s:3:"-20";s:6:"iacute";s:3:"-20";s:7:"iogonek";s:3:"-20";s:1:"o";s:4:"-140";s:6:"oacute";s:4:"-140";s:11:"ocircumflex";s:4:"-140";s:9:"odieresis";s:4:"-140";s:6:"ograve";s:4:"-140";s:13:"ohungarumlaut";s:4:"-140";s:7:"omacron";s:3:"-70";s:6:"oslash";s:4:"-140";s:6:"otilde";s:4:"-140";s:6:"period";s:4:"-140";s:9:"semicolon";s:3:"-60";s:1:"u";s:4:"-110";s:6:"uacute";s:4:"-110";s:11:"ucircumflex";s:4:"-110";s:9:"udieresis";s:4:"-110";s:6:"ugrave";s:4:"-110";s:13:"uhungarumlaut";s:4:"-110";s:7:"umacron";s:4:"-110";s:7:"uogonek";s:4:"-110";s:5:"uring";s:4:"-110";}s:9:"Ydieresis";a:64:{s:1:"A";s:4:"-110";s:6:"Aacute";s:4:"-110";s:6:"Abreve";s:4:"-110";s:11:"Acircumflex";s:4:"-110";s:9:"Adieresis";s:4:"-110";s:6:"Agrave";s:4:"-110";s:7:"Amacron";s:4:"-110";s:7:"Aogonek";s:4:"-110";s:5:"Aring";s:4:"-110";s:6:"Atilde";s:4:"-110";s:1:"O";s:3:"-85";s:6:"Oacute";s:3:"-85";s:11:"Ocircumflex";s:3:"-85";s:9:"Odieresis";s:3:"-85";s:6:"Ograve";s:3:"-85";s:13:"Ohungarumlaut";s:3:"-85";s:7:"Omacron";s:3:"-85";s:6:"Oslash";s:3:"-85";s:6:"Otilde";s:3:"-85";s:1:"a";s:4:"-140";s:6:"aacute";s:4:"-140";s:6:"abreve";s:3:"-70";s:11:"acircumflex";s:4:"-140";s:9:"adieresis";s:4:"-140";s:6:"agrave";s:4:"-140";s:7:"amacron";s:3:"-70";s:7:"aogonek";s:4:"-140";s:5:"aring";s:4:"-140";s:6:"atilde";s:3:"-70";s:5:"colon";s:3:"-60";s:5:"comma";s:4:"-140";s:1:"e";s:4:"-140";s:6:"eacute";s:4:"-140";s:6:"ecaron";s:4:"-140";s:11:"ecircumflex";s:4:"-140";s:9:"edieresis";s:4:"-140";s:10:"edotaccent";s:4:"-140";s:6:"egrave";s:4:"-140";s:7:"emacron";s:3:"-70";s:7:"eogonek";s:4:"-140";s:6:"hyphen";s:4:"-140";s:1:"i";s:3:"-20";s:6:"iacute";s:3:"-20";s:7:"iogonek";s:3:"-20";s:1:"o";s:4:"-140";s:6:"oacute";s:4:"-140";s:11:"ocircumflex";s:4:"-140";s:9:"odieresis";s:4:"-140";s:6:"ograve";s:4:"-140";s:13:"ohungarumlaut";s:4:"-140";s:7:"omacron";s:4:"-140";s:6:"oslash";s:4:"-140";s:6:"otilde";s:4:"-140";s:6:"period";s:4:"-140";s:9:"semicolon";s:3:"-60";s:1:"u";s:4:"-110";s:6:"uacute";s:4:"-110";s:11:"ucircumflex";s:4:"-110";s:9:"udieresis";s:4:"-110";s:6:"ugrave";s:4:"-110";s:13:"uhungarumlaut";s:4:"-110";s:7:"umacron";s:4:"-110";s:7:"uogonek";s:4:"-110";s:5:"uring";s:4:"-110";}s:1:"a";a:5:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-20";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:6:"aacute";a:5:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-20";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:6:"abreve";a:5:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-20";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:11:"acircumflex";a:5:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-20";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:9:"adieresis";a:5:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-20";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:6:"agrave";a:5:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-20";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:7:"amacron";a:5:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-20";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:7:"aogonek";a:5:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-20";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:5:"aring";a:5:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-20";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:6:"atilde";a:5:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-20";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:1:"b";a:20:{s:1:"b";s:3:"-10";s:5:"comma";s:3:"-40";s:1:"l";s:3:"-20";s:6:"lacute";s:3:"-20";s:12:"lcommaaccent";s:3:"-20";s:6:"lslash";s:3:"-20";s:6:"period";s:3:"-40";s:1:"u";s:3:"-20";s:6:"uacute";s:3:"-20";s:11:"ucircumflex";s:3:"-20";s:9:"udieresis";s:3:"-20";s:6:"ugrave";s:3:"-20";s:13:"uhungarumlaut";s:3:"-20";s:7:"umacron";s:3:"-20";s:7:"uogonek";s:3:"-20";s:5:"uring";s:3:"-20";s:1:"v";s:3:"-20";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:1:"c";a:3:{s:5:"comma";s:3:"-15";s:1:"k";s:3:"-20";s:12:"kcommaaccent";s:3:"-20";}s:6:"cacute";a:3:{s:5:"comma";s:3:"-15";s:1:"k";s:3:"-20";s:12:"kcommaaccent";s:3:"-20";}s:6:"ccaron";a:3:{s:5:"comma";s:3:"-15";s:1:"k";s:3:"-20";s:12:"kcommaaccent";s:3:"-20";}s:8:"ccedilla";a:3:{s:5:"comma";s:3:"-15";s:1:"k";s:3:"-20";s:12:"kcommaaccent";s:3:"-20";}s:5:"colon";a:1:{s:5:"space";s:3:"-50";}s:5:"comma";a:2:{s:13:"quotedblright";s:4:"-100";s:10:"quoteright";s:4:"-100";}s:1:"e";a:8:{s:5:"comma";s:3:"-15";s:6:"period";s:3:"-15";s:1:"v";s:3:"-30";s:1:"w";s:3:"-20";s:1:"x";s:3:"-30";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:6:"eacute";a:8:{s:5:"comma";s:3:"-15";s:6:"period";s:3:"-15";s:1:"v";s:3:"-30";s:1:"w";s:3:"-20";s:1:"x";s:3:"-30";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:6:"ecaron";a:8:{s:5:"comma";s:3:"-15";s:6:"period";s:3:"-15";s:1:"v";s:3:"-30";s:1:"w";s:3:"-20";s:1:"x";s:3:"-30";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:11:"ecircumflex";a:8:{s:5:"comma";s:3:"-15";s:6:"period";s:3:"-15";s:1:"v";s:3:"-30";s:1:"w";s:3:"-20";s:1:"x";s:3:"-30";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:9:"edieresis";a:8:{s:5:"comma";s:3:"-15";s:6:"period";s:3:"-15";s:1:"v";s:3:"-30";s:1:"w";s:3:"-20";s:1:"x";s:3:"-30";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:10:"edotaccent";a:8:{s:5:"comma";s:3:"-15";s:6:"period";s:3:"-15";s:1:"v";s:3:"-30";s:1:"w";s:3:"-20";s:1:"x";s:3:"-30";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:6:"egrave";a:8:{s:5:"comma";s:3:"-15";s:6:"period";s:3:"-15";s:1:"v";s:3:"-30";s:1:"w";s:3:"-20";s:1:"x";s:3:"-30";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:7:"emacron";a:8:{s:5:"comma";s:3:"-15";s:6:"period";s:3:"-15";s:1:"v";s:3:"-30";s:1:"w";s:3:"-20";s:1:"x";s:3:"-30";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:7:"eogonek";a:8:{s:5:"comma";s:3:"-15";s:6:"period";s:3:"-15";s:1:"v";s:3:"-30";s:1:"w";s:3:"-20";s:1:"x";s:3:"-30";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:1:"f";a:33:{s:1:"a";s:3:"-30";s:6:"aacute";s:3:"-30";s:6:"abreve";s:3:"-30";s:11:"acircumflex";s:3:"-30";s:9:"adieresis";s:3:"-30";s:6:"agrave";s:3:"-30";s:7:"amacron";s:3:"-30";s:7:"aogonek";s:3:"-30";s:5:"aring";s:3:"-30";s:6:"atilde";s:3:"-30";s:5:"comma";s:3:"-30";s:8:"dotlessi";s:3:"-28";s:1:"e";s:3:"-30";s:6:"eacute";s:3:"-30";s:6:"ecaron";s:3:"-30";s:11:"ecircumflex";s:3:"-30";s:9:"edieresis";s:3:"-30";s:10:"edotaccent";s:3:"-30";s:6:"egrave";s:3:"-30";s:7:"emacron";s:3:"-30";s:7:"eogonek";s:3:"-30";s:1:"o";s:3:"-30";s:6:"oacute";s:3:"-30";s:11:"ocircumflex";s:3:"-30";s:9:"odieresis";s:3:"-30";s:6:"ograve";s:3:"-30";s:13:"ohungarumlaut";s:3:"-30";s:7:"omacron";s:3:"-30";s:6:"oslash";s:3:"-30";s:6:"otilde";s:3:"-30";s:6:"period";s:3:"-30";s:13:"quotedblright";s:2:"60";s:10:"quoteright";s:2:"50";}s:1:"g";a:4:{s:1:"r";s:3:"-10";s:6:"racute";s:3:"-10";s:6:"rcaron";s:3:"-10";s:12:"rcommaaccent";s:3:"-10";}s:6:"gbreve";a:4:{s:1:"r";s:3:"-10";s:6:"racute";s:3:"-10";s:6:"rcaron";s:3:"-10";s:12:"rcommaaccent";s:3:"-10";}s:12:"gcommaaccent";a:4:{s:1:"r";s:3:"-10";s:6:"racute";s:3:"-10";s:6:"rcaron";s:3:"-10";s:12:"rcommaaccent";s:3:"-10";}s:1:"h";a:3:{s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:1:"k";a:18:{s:1:"e";s:3:"-20";s:6:"eacute";s:3:"-20";s:6:"ecaron";s:3:"-20";s:11:"ecircumflex";s:3:"-20";s:9:"edieresis";s:3:"-20";s:10:"edotaccent";s:3:"-20";s:6:"egrave";s:3:"-20";s:7:"emacron";s:3:"-20";s:7:"eogonek";s:3:"-20";s:1:"o";s:3:"-20";s:6:"oacute";s:3:"-20";s:11:"ocircumflex";s:3:"-20";s:9:"odieresis";s:3:"-20";s:6:"ograve";s:3:"-20";s:13:"ohungarumlaut";s:3:"-20";s:7:"omacron";s:3:"-20";s:6:"oslash";s:3:"-20";s:6:"otilde";s:3:"-20";}s:12:"kcommaaccent";a:18:{s:1:"e";s:3:"-20";s:6:"eacute";s:3:"-20";s:6:"ecaron";s:3:"-20";s:11:"ecircumflex";s:3:"-20";s:9:"edieresis";s:3:"-20";s:10:"edotaccent";s:3:"-20";s:6:"egrave";s:3:"-20";s:7:"emacron";s:3:"-20";s:7:"eogonek";s:3:"-20";s:1:"o";s:3:"-20";s:6:"oacute";s:3:"-20";s:11:"ocircumflex";s:3:"-20";s:9:"odieresis";s:3:"-20";s:6:"ograve";s:3:"-20";s:13:"ohungarumlaut";s:3:"-20";s:7:"omacron";s:3:"-20";s:6:"oslash";s:3:"-20";s:6:"otilde";s:3:"-20";}s:1:"m";a:12:{s:1:"u";s:3:"-10";s:6:"uacute";s:3:"-10";s:11:"ucircumflex";s:3:"-10";s:9:"udieresis";s:3:"-10";s:6:"ugrave";s:3:"-10";s:13:"uhungarumlaut";s:3:"-10";s:7:"umacron";s:3:"-10";s:7:"uogonek";s:3:"-10";s:5:"uring";s:3:"-10";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:1:"n";a:13:{s:1:"u";s:3:"-10";s:6:"uacute";s:3:"-10";s:11:"ucircumflex";s:3:"-10";s:9:"udieresis";s:3:"-10";s:6:"ugrave";s:3:"-10";s:13:"uhungarumlaut";s:3:"-10";s:7:"umacron";s:3:"-10";s:7:"uogonek";s:3:"-10";s:5:"uring";s:3:"-10";s:1:"v";s:3:"-20";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:6:"nacute";a:13:{s:1:"u";s:3:"-10";s:6:"uacute";s:3:"-10";s:11:"ucircumflex";s:3:"-10";s:9:"udieresis";s:3:"-10";s:6:"ugrave";s:3:"-10";s:13:"uhungarumlaut";s:3:"-10";s:7:"umacron";s:3:"-10";s:7:"uogonek";s:3:"-10";s:5:"uring";s:3:"-10";s:1:"v";s:3:"-20";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:6:"ncaron";a:13:{s:1:"u";s:3:"-10";s:6:"uacute";s:3:"-10";s:11:"ucircumflex";s:3:"-10";s:9:"udieresis";s:3:"-10";s:6:"ugrave";s:3:"-10";s:13:"uhungarumlaut";s:3:"-10";s:7:"umacron";s:3:"-10";s:7:"uogonek";s:3:"-10";s:5:"uring";s:3:"-10";s:1:"v";s:3:"-20";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:12:"ncommaaccent";a:13:{s:1:"u";s:3:"-10";s:6:"uacute";s:3:"-10";s:11:"ucircumflex";s:3:"-10";s:9:"udieresis";s:3:"-10";s:6:"ugrave";s:3:"-10";s:13:"uhungarumlaut";s:3:"-10";s:7:"umacron";s:3:"-10";s:7:"uogonek";s:3:"-10";s:5:"uring";s:3:"-10";s:1:"v";s:3:"-20";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:6:"ntilde";a:13:{s:1:"u";s:3:"-10";s:6:"uacute";s:3:"-10";s:11:"ucircumflex";s:3:"-10";s:9:"udieresis";s:3:"-10";s:6:"ugrave";s:3:"-10";s:13:"uhungarumlaut";s:3:"-10";s:7:"umacron";s:3:"-10";s:7:"uogonek";s:3:"-10";s:5:"uring";s:3:"-10";s:1:"v";s:3:"-20";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:1:"o";a:8:{s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-30";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:6:"oacute";a:8:{s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-30";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:11:"ocircumflex";a:8:{s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-30";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:9:"odieresis";a:8:{s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-30";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:6:"ograve";a:8:{s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-30";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:13:"ohungarumlaut";a:8:{s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-30";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:7:"omacron";a:8:{s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-30";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:6:"oslash";a:94:{s:1:"a";s:3:"-55";s:6:"aacute";s:3:"-55";s:6:"abreve";s:3:"-55";s:11:"acircumflex";s:3:"-55";s:9:"adieresis";s:3:"-55";s:6:"agrave";s:3:"-55";s:7:"amacron";s:3:"-55";s:7:"aogonek";s:3:"-55";s:5:"aring";s:3:"-55";s:6:"atilde";s:3:"-55";s:1:"b";s:3:"-55";s:1:"c";s:3:"-55";s:6:"cacute";s:3:"-55";s:6:"ccaron";s:3:"-55";s:8:"ccedilla";s:3:"-55";s:5:"comma";s:3:"-95";s:1:"d";s:3:"-55";s:6:"dcroat";s:3:"-55";s:1:"e";s:3:"-55";s:6:"eacute";s:3:"-55";s:6:"ecaron";s:3:"-55";s:11:"ecircumflex";s:3:"-55";s:9:"edieresis";s:3:"-55";s:10:"edotaccent";s:3:"-55";s:6:"egrave";s:3:"-55";s:7:"emacron";s:3:"-55";s:7:"eogonek";s:3:"-55";s:1:"f";s:3:"-55";s:1:"g";s:3:"-55";s:6:"gbreve";s:3:"-55";s:12:"gcommaaccent";s:3:"-55";s:1:"h";s:3:"-55";s:1:"i";s:3:"-55";s:6:"iacute";s:3:"-55";s:11:"icircumflex";s:3:"-55";s:9:"idieresis";s:3:"-55";s:6:"igrave";s:3:"-55";s:7:"imacron";s:3:"-55";s:7:"iogonek";s:3:"-55";s:1:"j";s:3:"-55";s:1:"k";s:3:"-55";s:12:"kcommaaccent";s:3:"-55";s:1:"l";s:3:"-55";s:6:"lacute";s:3:"-55";s:12:"lcommaaccent";s:3:"-55";s:6:"lslash";s:3:"-55";s:1:"m";s:3:"-55";s:1:"n";s:3:"-55";s:6:"nacute";s:3:"-55";s:6:"ncaron";s:3:"-55";s:12:"ncommaaccent";s:3:"-55";s:6:"ntilde";s:3:"-55";s:1:"o";s:3:"-55";s:6:"oacute";s:3:"-55";s:11:"ocircumflex";s:3:"-55";s:9:"odieresis";s:3:"-55";s:6:"ograve";s:3:"-55";s:13:"ohungarumlaut";s:3:"-55";s:7:"omacron";s:3:"-55";s:6:"oslash";s:3:"-55";s:6:"otilde";s:3:"-55";s:1:"p";s:3:"-55";s:6:"period";s:3:"-95";s:1:"q";s:3:"-55";s:1:"r";s:3:"-55";s:6:"racute";s:3:"-55";s:6:"rcaron";s:3:"-55";s:12:"rcommaaccent";s:3:"-55";s:1:"s";s:3:"-55";s:6:"sacute";s:3:"-55";s:6:"scaron";s:3:"-55";s:8:"scedilla";s:3:"-55";s:12:"scommaaccent";s:3:"-55";s:1:"t";s:3:"-55";s:12:"tcommaaccent";s:3:"-55";s:1:"u";s:3:"-55";s:6:"uacute";s:3:"-55";s:11:"ucircumflex";s:3:"-55";s:9:"udieresis";s:3:"-55";s:6:"ugrave";s:3:"-55";s:13:"uhungarumlaut";s:3:"-55";s:7:"umacron";s:3:"-55";s:7:"uogonek";s:3:"-55";s:5:"uring";s:3:"-55";s:1:"v";s:3:"-70";s:1:"w";s:3:"-70";s:1:"x";s:3:"-85";s:1:"y";s:3:"-70";s:6:"yacute";s:3:"-70";s:9:"ydieresis";s:3:"-70";s:1:"z";s:3:"-55";s:6:"zacute";s:3:"-55";s:6:"zcaron";s:3:"-55";s:10:"zdotaccent";s:3:"-55";}s:6:"otilde";a:8:{s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-30";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:1:"p";a:5:{s:5:"comma";s:3:"-35";s:6:"period";s:3:"-35";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:6:"period";a:3:{s:13:"quotedblright";s:4:"-100";s:10:"quoteright";s:4:"-100";s:5:"space";s:3:"-60";}s:13:"quotedblright";a:1:{s:5:"space";s:3:"-40";}s:9:"quoteleft";a:1:{s:9:"quoteleft";s:3:"-57";}s:10:"quoteright";a:13:{s:1:"d";s:3:"-50";s:6:"dcroat";s:3:"-50";s:10:"quoteright";s:3:"-57";s:1:"r";s:3:"-50";s:6:"racute";s:3:"-50";s:6:"rcaron";s:3:"-50";s:12:"rcommaaccent";s:3:"-50";s:1:"s";s:3:"-50";s:6:"sacute";s:3:"-50";s:6:"scaron";s:3:"-50";s:8:"scedilla";s:3:"-50";s:12:"scommaaccent";s:3:"-50";s:5:"space";s:3:"-70";}s:1:"r";a:49:{s:1:"a";s:3:"-10";s:6:"aacute";s:3:"-10";s:6:"abreve";s:3:"-10";s:11:"acircumflex";s:3:"-10";s:9:"adieresis";s:3:"-10";s:6:"agrave";s:3:"-10";s:7:"amacron";s:3:"-10";s:7:"aogonek";s:3:"-10";s:5:"aring";s:3:"-10";s:6:"atilde";s:3:"-10";s:5:"colon";s:2:"30";s:5:"comma";s:3:"-50";s:1:"i";s:2:"15";s:6:"iacute";s:2:"15";s:11:"icircumflex";s:2:"15";s:9:"idieresis";s:2:"15";s:6:"igrave";s:2:"15";s:7:"imacron";s:2:"15";s:7:"iogonek";s:2:"15";s:1:"k";s:2:"15";s:12:"kcommaaccent";s:2:"15";s:1:"l";s:2:"15";s:6:"lacute";s:2:"15";s:12:"lcommaaccent";s:2:"15";s:6:"lslash";s:2:"15";s:1:"m";s:2:"25";s:1:"n";s:2:"25";s:6:"nacute";s:2:"25";s:6:"ncaron";s:2:"25";s:12:"ncommaaccent";s:2:"25";s:6:"ntilde";s:2:"25";s:1:"p";s:2:"30";s:6:"period";s:3:"-50";s:9:"semicolon";s:2:"30";s:1:"t";s:2:"40";s:12:"tcommaaccent";s:2:"40";s:1:"u";s:2:"15";s:6:"uacute";s:2:"15";s:11:"ucircumflex";s:2:"15";s:9:"udieresis";s:2:"15";s:6:"ugrave";s:2:"15";s:13:"uhungarumlaut";s:2:"15";s:7:"umacron";s:2:"15";s:7:"uogonek";s:2:"15";s:5:"uring";s:2:"15";s:1:"v";s:2:"30";s:1:"y";s:2:"30";s:6:"yacute";s:2:"30";s:9:"ydieresis";s:2:"30";}s:6:"racute";a:49:{s:1:"a";s:3:"-10";s:6:"aacute";s:3:"-10";s:6:"abreve";s:3:"-10";s:11:"acircumflex";s:3:"-10";s:9:"adieresis";s:3:"-10";s:6:"agrave";s:3:"-10";s:7:"amacron";s:3:"-10";s:7:"aogonek";s:3:"-10";s:5:"aring";s:3:"-10";s:6:"atilde";s:3:"-10";s:5:"colon";s:2:"30";s:5:"comma";s:3:"-50";s:1:"i";s:2:"15";s:6:"iacute";s:2:"15";s:11:"icircumflex";s:2:"15";s:9:"idieresis";s:2:"15";s:6:"igrave";s:2:"15";s:7:"imacron";s:2:"15";s:7:"iogonek";s:2:"15";s:1:"k";s:2:"15";s:12:"kcommaaccent";s:2:"15";s:1:"l";s:2:"15";s:6:"lacute";s:2:"15";s:12:"lcommaaccent";s:2:"15";s:6:"lslash";s:2:"15";s:1:"m";s:2:"25";s:1:"n";s:2:"25";s:6:"nacute";s:2:"25";s:6:"ncaron";s:2:"25";s:12:"ncommaaccent";s:2:"25";s:6:"ntilde";s:2:"25";s:1:"p";s:2:"30";s:6:"period";s:3:"-50";s:9:"semicolon";s:2:"30";s:1:"t";s:2:"40";s:12:"tcommaaccent";s:2:"40";s:1:"u";s:2:"15";s:6:"uacute";s:2:"15";s:11:"ucircumflex";s:2:"15";s:9:"udieresis";s:2:"15";s:6:"ugrave";s:2:"15";s:13:"uhungarumlaut";s:2:"15";s:7:"umacron";s:2:"15";s:7:"uogonek";s:2:"15";s:5:"uring";s:2:"15";s:1:"v";s:2:"30";s:1:"y";s:2:"30";s:6:"yacute";s:2:"30";s:9:"ydieresis";s:2:"30";}s:6:"rcaron";a:49:{s:1:"a";s:3:"-10";s:6:"aacute";s:3:"-10";s:6:"abreve";s:3:"-10";s:11:"acircumflex";s:3:"-10";s:9:"adieresis";s:3:"-10";s:6:"agrave";s:3:"-10";s:7:"amacron";s:3:"-10";s:7:"aogonek";s:3:"-10";s:5:"aring";s:3:"-10";s:6:"atilde";s:3:"-10";s:5:"colon";s:2:"30";s:5:"comma";s:3:"-50";s:1:"i";s:2:"15";s:6:"iacute";s:2:"15";s:11:"icircumflex";s:2:"15";s:9:"idieresis";s:2:"15";s:6:"igrave";s:2:"15";s:7:"imacron";s:2:"15";s:7:"iogonek";s:2:"15";s:1:"k";s:2:"15";s:12:"kcommaaccent";s:2:"15";s:1:"l";s:2:"15";s:6:"lacute";s:2:"15";s:12:"lcommaaccent";s:2:"15";s:6:"lslash";s:2:"15";s:1:"m";s:2:"25";s:1:"n";s:2:"25";s:6:"nacute";s:2:"25";s:6:"ncaron";s:2:"25";s:12:"ncommaaccent";s:2:"25";s:6:"ntilde";s:2:"25";s:1:"p";s:2:"30";s:6:"period";s:3:"-50";s:9:"semicolon";s:2:"30";s:1:"t";s:2:"40";s:12:"tcommaaccent";s:2:"40";s:1:"u";s:2:"15";s:6:"uacute";s:2:"15";s:11:"ucircumflex";s:2:"15";s:9:"udieresis";s:2:"15";s:6:"ugrave";s:2:"15";s:13:"uhungarumlaut";s:2:"15";s:7:"umacron";s:2:"15";s:7:"uogonek";s:2:"15";s:5:"uring";s:2:"15";s:1:"v";s:2:"30";s:1:"y";s:2:"30";s:6:"yacute";s:2:"30";s:9:"ydieresis";s:2:"30";}s:12:"rcommaaccent";a:49:{s:1:"a";s:3:"-10";s:6:"aacute";s:3:"-10";s:6:"abreve";s:3:"-10";s:11:"acircumflex";s:3:"-10";s:9:"adieresis";s:3:"-10";s:6:"agrave";s:3:"-10";s:7:"amacron";s:3:"-10";s:7:"aogonek";s:3:"-10";s:5:"aring";s:3:"-10";s:6:"atilde";s:3:"-10";s:5:"colon";s:2:"30";s:5:"comma";s:3:"-50";s:1:"i";s:2:"15";s:6:"iacute";s:2:"15";s:11:"icircumflex";s:2:"15";s:9:"idieresis";s:2:"15";s:6:"igrave";s:2:"15";s:7:"imacron";s:2:"15";s:7:"iogonek";s:2:"15";s:1:"k";s:2:"15";s:12:"kcommaaccent";s:2:"15";s:1:"l";s:2:"15";s:6:"lacute";s:2:"15";s:12:"lcommaaccent";s:2:"15";s:6:"lslash";s:2:"15";s:1:"m";s:2:"25";s:1:"n";s:2:"25";s:6:"nacute";s:2:"25";s:6:"ncaron";s:2:"25";s:12:"ncommaaccent";s:2:"25";s:6:"ntilde";s:2:"25";s:1:"p";s:2:"30";s:6:"period";s:3:"-50";s:9:"semicolon";s:2:"30";s:1:"t";s:2:"40";s:12:"tcommaaccent";s:2:"40";s:1:"u";s:2:"15";s:6:"uacute";s:2:"15";s:11:"ucircumflex";s:2:"15";s:9:"udieresis";s:2:"15";s:6:"ugrave";s:2:"15";s:13:"uhungarumlaut";s:2:"15";s:7:"umacron";s:2:"15";s:7:"uogonek";s:2:"15";s:5:"uring";s:2:"15";s:1:"v";s:2:"30";s:1:"y";s:2:"30";s:6:"yacute";s:2:"30";s:9:"ydieresis";s:2:"30";}s:1:"s";a:3:{s:5:"comma";s:3:"-15";s:6:"period";s:3:"-15";s:1:"w";s:3:"-30";}s:6:"sacute";a:3:{s:5:"comma";s:3:"-15";s:6:"period";s:3:"-15";s:1:"w";s:3:"-30";}s:6:"scaron";a:3:{s:5:"comma";s:3:"-15";s:6:"period";s:3:"-15";s:1:"w";s:3:"-30";}s:8:"scedilla";a:3:{s:5:"comma";s:3:"-15";s:6:"period";s:3:"-15";s:1:"w";s:3:"-30";}s:12:"scommaaccent";a:3:{s:5:"comma";s:3:"-15";s:6:"period";s:3:"-15";s:1:"w";s:3:"-30";}s:9:"semicolon";a:1:{s:5:"space";s:3:"-50";}s:5:"space";a:10:{s:1:"T";s:3:"-50";s:6:"Tcaron";s:3:"-50";s:12:"Tcommaaccent";s:3:"-50";s:1:"V";s:3:"-50";s:1:"W";s:3:"-40";s:1:"Y";s:3:"-90";s:6:"Yacute";s:3:"-90";s:9:"Ydieresis";s:3:"-90";s:12:"quotedblleft";s:3:"-30";s:9:"quoteleft";s:3:"-60";}s:1:"v";a:30:{s:1:"a";s:3:"-25";s:6:"aacute";s:3:"-25";s:6:"abreve";s:3:"-25";s:11:"acircumflex";s:3:"-25";s:9:"adieresis";s:3:"-25";s:6:"agrave";s:3:"-25";s:7:"amacron";s:3:"-25";s:7:"aogonek";s:3:"-25";s:5:"aring";s:3:"-25";s:6:"atilde";s:3:"-25";s:5:"comma";s:3:"-80";s:1:"e";s:3:"-25";s:6:"eacute";s:3:"-25";s:6:"ecaron";s:3:"-25";s:11:"ecircumflex";s:3:"-25";s:9:"edieresis";s:3:"-25";s:10:"edotaccent";s:3:"-25";s:6:"egrave";s:3:"-25";s:7:"emacron";s:3:"-25";s:7:"eogonek";s:3:"-25";s:1:"o";s:3:"-25";s:6:"oacute";s:3:"-25";s:11:"ocircumflex";s:3:"-25";s:9:"odieresis";s:3:"-25";s:6:"ograve";s:3:"-25";s:13:"ohungarumlaut";s:3:"-25";s:7:"omacron";s:3:"-25";s:6:"oslash";s:3:"-25";s:6:"otilde";s:3:"-25";s:6:"period";s:3:"-80";}s:1:"w";a:30:{s:1:"a";s:3:"-15";s:6:"aacute";s:3:"-15";s:6:"abreve";s:3:"-15";s:11:"acircumflex";s:3:"-15";s:9:"adieresis";s:3:"-15";s:6:"agrave";s:3:"-15";s:7:"amacron";s:3:"-15";s:7:"aogonek";s:3:"-15";s:5:"aring";s:3:"-15";s:6:"atilde";s:3:"-15";s:5:"comma";s:3:"-60";s:1:"e";s:3:"-10";s:6:"eacute";s:3:"-10";s:6:"ecaron";s:3:"-10";s:11:"ecircumflex";s:3:"-10";s:9:"edieresis";s:3:"-10";s:10:"edotaccent";s:3:"-10";s:6:"egrave";s:3:"-10";s:7:"emacron";s:3:"-10";s:7:"eogonek";s:3:"-10";s:1:"o";s:3:"-10";s:6:"oacute";s:3:"-10";s:11:"ocircumflex";s:3:"-10";s:9:"odieresis";s:3:"-10";s:6:"ograve";s:3:"-10";s:13:"ohungarumlaut";s:3:"-10";s:7:"omacron";s:3:"-10";s:6:"oslash";s:3:"-10";s:6:"otilde";s:3:"-10";s:6:"period";s:3:"-60";}s:1:"x";a:9:{s:1:"e";s:3:"-30";s:6:"eacute";s:3:"-30";s:6:"ecaron";s:3:"-30";s:11:"ecircumflex";s:3:"-30";s:9:"edieresis";s:3:"-30";s:10:"edotaccent";s:3:"-30";s:6:"egrave";s:3:"-30";s:7:"emacron";s:3:"-30";s:7:"eogonek";s:3:"-30";}s:1:"y";a:30:{s:1:"a";s:3:"-20";s:6:"aacute";s:3:"-20";s:6:"abreve";s:3:"-20";s:11:"acircumflex";s:3:"-20";s:9:"adieresis";s:3:"-20";s:6:"agrave";s:3:"-20";s:7:"amacron";s:3:"-20";s:7:"aogonek";s:3:"-20";s:5:"aring";s:3:"-20";s:6:"atilde";s:3:"-20";s:5:"comma";s:4:"-100";s:1:"e";s:3:"-20";s:6:"eacute";s:3:"-20";s:6:"ecaron";s:3:"-20";s:11:"ecircumflex";s:3:"-20";s:9:"edieresis";s:3:"-20";s:10:"edotaccent";s:3:"-20";s:6:"egrave";s:3:"-20";s:7:"emacron";s:3:"-20";s:7:"eogonek";s:3:"-20";s:1:"o";s:3:"-20";s:6:"oacute";s:3:"-20";s:11:"ocircumflex";s:3:"-20";s:9:"odieresis";s:3:"-20";s:6:"ograve";s:3:"-20";s:13:"ohungarumlaut";s:3:"-20";s:7:"omacron";s:3:"-20";s:6:"oslash";s:3:"-20";s:6:"otilde";s:3:"-20";s:6:"period";s:4:"-100";}s:6:"yacute";a:30:{s:1:"a";s:3:"-20";s:6:"aacute";s:3:"-20";s:6:"abreve";s:3:"-20";s:11:"acircumflex";s:3:"-20";s:9:"adieresis";s:3:"-20";s:6:"agrave";s:3:"-20";s:7:"amacron";s:3:"-20";s:7:"aogonek";s:3:"-20";s:5:"aring";s:3:"-20";s:6:"atilde";s:3:"-20";s:5:"comma";s:4:"-100";s:1:"e";s:3:"-20";s:6:"eacute";s:3:"-20";s:6:"ecaron";s:3:"-20";s:11:"ecircumflex";s:3:"-20";s:9:"edieresis";s:3:"-20";s:10:"edotaccent";s:3:"-20";s:6:"egrave";s:3:"-20";s:7:"emacron";s:3:"-20";s:7:"eogonek";s:3:"-20";s:1:"o";s:3:"-20";s:6:"oacute";s:3:"-20";s:11:"ocircumflex";s:3:"-20";s:9:"odieresis";s:3:"-20";s:6:"ograve";s:3:"-20";s:13:"ohungarumlaut";s:3:"-20";s:7:"omacron";s:3:"-20";s:6:"oslash";s:3:"-20";s:6:"otilde";s:3:"-20";s:6:"period";s:4:"-100";}s:9:"ydieresis";a:30:{s:1:"a";s:3:"-20";s:6:"aacute";s:3:"-20";s:6:"abreve";s:3:"-20";s:11:"acircumflex";s:3:"-20";s:9:"adieresis";s:3:"-20";s:6:"agrave";s:3:"-20";s:7:"amacron";s:3:"-20";s:7:"aogonek";s:3:"-20";s:5:"aring";s:3:"-20";s:6:"atilde";s:3:"-20";s:5:"comma";s:4:"-100";s:1:"e";s:3:"-20";s:6:"eacute";s:3:"-20";s:6:"ecaron";s:3:"-20";s:11:"ecircumflex";s:3:"-20";s:9:"edieresis";s:3:"-20";s:10:"edotaccent";s:3:"-20";s:6:"egrave";s:3:"-20";s:7:"emacron";s:3:"-20";s:7:"eogonek";s:3:"-20";s:1:"o";s:3:"-20";s:6:"oacute";s:3:"-20";s:11:"ocircumflex";s:3:"-20";s:9:"odieresis";s:3:"-20";s:6:"ograve";s:3:"-20";s:13:"ohungarumlaut";s:3:"-20";s:7:"omacron";s:3:"-20";s:6:"oslash";s:3:"-20";s:6:"otilde";s:3:"-20";s:6:"period";s:4:"-100";}s:1:"z";a:18:{s:1:"e";s:3:"-15";s:6:"eacute";s:3:"-15";s:6:"ecaron";s:3:"-15";s:11:"ecircumflex";s:3:"-15";s:9:"edieresis";s:3:"-15";s:10:"edotaccent";s:3:"-15";s:6:"egrave";s:3:"-15";s:7:"emacron";s:3:"-15";s:7:"eogonek";s:3:"-15";s:1:"o";s:3:"-15";s:6:"oacute";s:3:"-15";s:11:"ocircumflex";s:3:"-15";s:9:"odieresis";s:3:"-15";s:6:"ograve";s:3:"-15";s:13:"ohungarumlaut";s:3:"-15";s:7:"omacron";s:3:"-15";s:6:"oslash";s:3:"-15";s:6:"otilde";s:3:"-15";}s:6:"zacute";a:18:{s:1:"e";s:3:"-15";s:6:"eacute";s:3:"-15";s:6:"ecaron";s:3:"-15";s:11:"ecircumflex";s:3:"-15";s:9:"edieresis";s:3:"-15";s:10:"edotaccent";s:3:"-15";s:6:"egrave";s:3:"-15";s:7:"emacron";s:3:"-15";s:7:"eogonek";s:3:"-15";s:1:"o";s:3:"-15";s:6:"oacute";s:3:"-15";s:11:"ocircumflex";s:3:"-15";s:9:"odieresis";s:3:"-15";s:6:"ograve";s:3:"-15";s:13:"ohungarumlaut";s:3:"-15";s:7:"omacron";s:3:"-15";s:6:"oslash";s:3:"-15";s:6:"otilde";s:3:"-15";}s:6:"zcaron";a:18:{s:1:"e";s:3:"-15";s:6:"eacute";s:3:"-15";s:6:"ecaron";s:3:"-15";s:11:"ecircumflex";s:3:"-15";s:9:"edieresis";s:3:"-15";s:10:"edotaccent";s:3:"-15";s:6:"egrave";s:3:"-15";s:7:"emacron";s:3:"-15";s:7:"eogonek";s:3:"-15";s:1:"o";s:3:"-15";s:6:"oacute";s:3:"-15";s:11:"ocircumflex";s:3:"-15";s:9:"odieresis";s:3:"-15";s:6:"ograve";s:3:"-15";s:13:"ohungarumlaut";s:3:"-15";s:7:"omacron";s:3:"-15";s:6:"oslash";s:3:"-15";s:6:"otilde";s:3:"-15";}s:10:"zdotaccent";a:18:{s:1:"e";s:3:"-15";s:6:"eacute";s:3:"-15";s:6:"ecaron";s:3:"-15";s:11:"ecircumflex";s:3:"-15";s:9:"edieresis";s:3:"-15";s:10:"edotaccent";s:3:"-15";s:6:"egrave";s:3:"-15";s:7:"emacron";s:3:"-15";s:7:"eogonek";s:3:"-15";s:1:"o";s:3:"-15";s:6:"oacute";s:3:"-15";s:11:"ocircumflex";s:3:"-15";s:9:"odieresis";s:3:"-15";s:6:"ograve";s:3:"-15";s:13:"ohungarumlaut";s:3:"-15";s:7:"omacron";s:3:"-15";s:6:"oslash";s:3:"-15";s:6:"otilde";s:3:"-15";}}s:9:"_version_";i:1;}
\ No newline at end of file
Added: trunk/mapbender/http/classes/fonts/php_Helvetica.afm
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/fonts/php_Helvetica.afm?view=auto&rev=13
--- (empty file)
+++ trunk/mapbender/http/classes/fonts/php_Helvetica.afm 2006-04-13 19:38:28+0000
@@ -0,0 +1 @@
+a:22:{s:8:"FontName";s:9:"Helvetica";s:8:"FullName";s:9:"Helvetica";s:10:"FamilyName";s:9:"Helvetica";s:6:"Weight";s:6:"Medium";s:11:"ItalicAngle";s:1:"0";s:12:"IsFixedPitch";s:5:"false";s:12:"CharacterSet";s:13:"ExtendedRoman";s:8:"FontBBox";a:4:{i:0;s:4:"-166";i:1;s:4:"-225";i:2;s:4:"1000";i:3;s:3:"931";}s:17:"UnderlinePosition";s:4:"-100";s:18:"UnderlineThickness";s:2:"50";s:7:"Version";s:7:"002.000";s:14:"EncodingScheme";s:21:"AdobeStandardEncoding";s:9:"CapHeight";s:3:"718";s:7:"XHeight";s:3:"523";s:8:"Ascender";s:3:"718";s:9:"Descender";s:4:"-207";s:5:"StdHW";s:2:"76";s:5:"StdVW";s:2:"88";s:16:"StartCharMetrics";s:3:"315";s:1:"C";a:464:{i:32;a:4:{s:1:"C";s:2:"32";s:2:"WX";s:3:"278";s:1:"N";s:5:"space";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}s:5:"space";a:4:{s:1:"C";s:2:"32";s:2:"WX";s:3:"278";s:1:"N";s:5:"space";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}i:33;a:4:{s:1:"C";s:2:"33";s:2:"WX";s:3:"278";s:1:"N";s:6:"exclam";s:1:"B";a:4:{i:0;s:2:"90";i:1;s:1:"0";i:2;s:3:"187";i:3;s:3:"718";}}s:6:"exclam";a:4:{s:1:"C";s:2:"33";s:2:"WX";s:3:"278";s:1:"N";s:6:"exclam";s:1:"B";a:4:{i:0;s:2:"90";i:1;s:1:"0";i:2;s:3:"187";i:3;s:3:"718";}}i:34;a:4:{s:1:"C";s:2:"34";s:2:"WX";s:3:"355";s:1:"N";s:8:"quotedbl";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:3:"463";i:2;s:3:"285";i:3;s:3:"718";}}s:8:"quotedbl";a:4:{s:1:"C";s:2:"34";s:2:"WX";s:3:"355";s:1:"N";s:8:"quotedbl";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:3:"463";i:2;s:3:"285";i:3;s:3:"718";}}i:35;a:4:{s:1:"C";s:2:"35";s:2:"WX";s:3:"556";s:1:"N";s:10:"numbersign";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:1:"0";i:2;s:3:"529";i:3;s:3:"688";}}s:10:"numbersign";a:4:{s:1:"C";s:2:"35";s:2:"WX";s:3:"556";s:1:"N";s:10:"numbersign";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:1:"0";i:2;s:3:"529";i:3;s:3:"688";}}i:36;a:4:{s:1:"C";s:2:"36";s:2:"WX";s:3:"556";s:1:"N";s:6:"dollar";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:4:"-115";i:2;s:3:"520";i:3;s:3:"775";}}s:6:"dollar";a:4:{s:1:"C";s:2:"36";s:2:"WX";s:3:"556";s:1:"N";s:6:"dollar";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:4:"-115";i:2;s:3:"520";i:3;s:3:"775";}}i:37;a:4:{s:1:"C";s:2:"37";s:2:"WX";s:3:"889";s:1:"N";s:7:"percent";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:3:"-19";i:2;s:3:"850";i:3;s:3:"703";}}s:7:"percent";a:4:{s:1:"C";s:2:"37";s:2:"WX";s:3:"889";s:1:"N";s:7:"percent";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:3:"-19";i:2;s:3:"850";i:3;s:3:"703";}}i:38;a:4:{s:1:"C";s:2:"38";s:2:"WX";s:3:"667";s:1:"N";s:9:"ampersand";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-15";i:2;s:3:"645";i:3;s:3:"718";}}s:9:"ampersand";a:4:{s:1:"C";s:2:"38";s:2:"WX";s:3:"667";s:1:"N";s:9:"ampersand";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-15";i:2;s:3:"645";i:3;s:3:"718";}}i:39;a:4:{s:1:"C";s:2:"39";s:2:"WX";s:3:"222";s:1:"N";s:10:"quoteright";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:3:"463";i:2;s:3:"157";i:3;s:3:"718";}}s:10:"quoteright";a:4:{s:1:"C";s:2:"39";s:2:"WX";s:3:"222";s:1:"N";s:10:"quoteright";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:3:"463";i:2;s:3:"157";i:3;s:3:"718";}}i:40;a:4:{s:1:"C";s:2:"40";s:2:"WX";s:3:"333";s:1:"N";s:9:"parenleft";s:1:"B";a:4:{i:0;s:2:"68";i:1;s:4:"-207";i:2;s:3:"299";i:3;s:3:"733";}}s:9:"parenleft";a:4:{s:1:"C";s:2:"40";s:2:"WX";s:3:"333";s:1:"N";s:9:"parenleft";s:1:"B";a:4:{i:0;s:2:"68";i:1;s:4:"-207";i:2;s:3:"299";i:3;s:3:"733";}}i:41;a:4:{s:1:"C";s:2:"41";s:2:"WX";s:3:"333";s:1:"N";s:10:"parenright";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:4:"-207";i:2;s:3:"265";i:3;s:3:"733";}}s:10:"parenright";a:4:{s:1:"C";s:2:"41";s:2:"WX";s:3:"333";s:1:"N";s:10:"parenright";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:4:"-207";i:2;s:3:"265";i:3;s:3:"733";}}i:42;a:4:{s:1:"C";s:2:"42";s:2:"WX";s:3:"389";s:1:"N";s:8:"asterisk";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:3:"431";i:2;s:3:"349";i:3;s:3:"718";}}s:8:"asterisk";a:4:{s:1:"C";s:2:"42";s:2:"WX";s:3:"389";s:1:"N";s:8:"asterisk";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:3:"431";i:2;s:3:"349";i:3;s:3:"718";}}i:43;a:4:{s:1:"C";s:2:"43";s:2:"WX";s:3:"584";s:1:"N";s:4:"plus";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:1:"0";i:2;s:3:"545";i:3;s:3:"505";}}s:4:"plus";a:4:{s:1:"C";s:2:"43";s:2:"WX";s:3:"584";s:1:"N";s:4:"plus";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:1:"0";i:2;s:3:"545";i:3;s:3:"505";}}i:44;a:4:{s:1:"C";s:2:"44";s:2:"WX";s:3:"278";s:1:"N";s:5:"comma";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:4:"-147";i:2;s:3:"191";i:3;s:3:"106";}}s:5:"comma";a:4:{s:1:"C";s:2:"44";s:2:"WX";s:3:"278";s:1:"N";s:5:"comma";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:4:"-147";i:2;s:3:"191";i:3;s:3:"106";}}i:45;a:4:{s:1:"C";s:2:"45";s:2:"WX";s:3:"333";s:1:"N";s:6:"hyphen";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"232";i:2;s:3:"289";i:3;s:3:"322";}}s:6:"hyphen";a:4:{s:1:"C";s:2:"45";s:2:"WX";s:3:"333";s:1:"N";s:6:"hyphen";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"232";i:2;s:3:"289";i:3;s:3:"322";}}i:46;a:4:{s:1:"C";s:2:"46";s:2:"WX";s:3:"278";s:1:"N";s:6:"period";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:1:"0";i:2;s:3:"191";i:3;s:3:"106";}}s:6:"period";a:4:{s:1:"C";s:2:"46";s:2:"WX";s:3:"278";s:1:"N";s:6:"period";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:1:"0";i:2;s:3:"191";i:3;s:3:"106";}}i:47;a:4:{s:1:"C";s:2:"47";s:2:"WX";s:3:"278";s:1:"N";s:5:"slash";s:1:"B";a:4:{i:0;s:3:"-17";i:1;s:3:"-19";i:2;s:3:"295";i:3;s:3:"737";}}s:5:"slash";a:4:{s:1:"C";s:2:"47";s:2:"WX";s:3:"278";s:1:"N";s:5:"slash";s:1:"B";a:4:{i:0;s:3:"-17";i:1;s:3:"-19";i:2;s:3:"295";i:3;s:3:"737";}}i:48;a:4:{s:1:"C";s:2:"48";s:2:"WX";s:3:"556";s:1:"N";s:4:"zero";s:1:"B";a:4:{i:0;s:2:"37";i:1;s:3:"-19";i:2;s:3:"519";i:3;s:3:"703";}}s:4:"zero";a:4:{s:1:"C";s:2:"48";s:2:"WX";s:3:"556";s:1:"N";s:4:"zero";s:1:"B";a:4:{i:0;s:2:"37";i:1;s:3:"-19";i:2;s:3:"519";i:3;s:3:"703";}}i:49;a:4:{s:1:"C";s:2:"49";s:2:"WX";s:3:"556";s:1:"N";s:3:"one";s:1:"B";a:4:{i:0;s:3:"101";i:1;s:1:"0";i:2;s:3:"359";i:3;s:3:"703";}}s:3:"one";a:4:{s:1:"C";s:2:"49";s:2:"WX";s:3:"556";s:1:"N";s:3:"one";s:1:"B";a:4:{i:0;s:3:"101";i:1;s:1:"0";i:2;s:3:"359";i:3;s:3:"703";}}i:50;a:4:{s:1:"C";s:2:"50";s:2:"WX";s:3:"556";s:1:"N";s:3:"two";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"507";i:3;s:3:"703";}}s:3:"two";a:4:{s:1:"C";s:2:"50";s:2:"WX";s:3:"556";s:1:"N";s:3:"two";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"507";i:3;s:3:"703";}}i:51;a:4:{s:1:"C";s:2:"51";s:2:"WX";s:3:"556";s:1:"N";s:5:"three";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-19";i:2;s:3:"522";i:3;s:3:"703";}}s:5:"three";a:4:{s:1:"C";s:2:"51";s:2:"WX";s:3:"556";s:1:"N";s:5:"three";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-19";i:2;s:3:"522";i:3;s:3:"703";}}i:52;a:4:{s:1:"C";s:2:"52";s:2:"WX";s:3:"556";s:1:"N";s:4:"four";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"523";i:3;s:3:"703";}}s:4:"four";a:4:{s:1:"C";s:2:"52";s:2:"WX";s:3:"556";s:1:"N";s:4:"four";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"523";i:3;s:3:"703";}}i:53;a:4:{s:1:"C";s:2:"53";s:2:"WX";s:3:"556";s:1:"N";s:4:"five";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:3:"-19";i:2;s:3:"514";i:3;s:3:"688";}}s:4:"five";a:4:{s:1:"C";s:2:"53";s:2:"WX";s:3:"556";s:1:"N";s:4:"five";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:3:"-19";i:2;s:3:"514";i:3;s:3:"688";}}i:54;a:4:{s:1:"C";s:2:"54";s:2:"WX";s:3:"556";s:1:"N";s:3:"six";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:3:"-19";i:2;s:3:"518";i:3;s:3:"703";}}s:3:"six";a:4:{s:1:"C";s:2:"54";s:2:"WX";s:3:"556";s:1:"N";s:3:"six";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:3:"-19";i:2;s:3:"518";i:3;s:3:"703";}}i:55;a:4:{s:1:"C";s:2:"55";s:2:"WX";s:3:"556";s:1:"N";s:5:"seven";s:1:"B";a:4:{i:0;s:2:"37";i:1;s:1:"0";i:2;s:3:"523";i:3;s:3:"688";}}s:5:"seven";a:4:{s:1:"C";s:2:"55";s:2:"WX";s:3:"556";s:1:"N";s:5:"seven";s:1:"B";a:4:{i:0;s:2:"37";i:1;s:1:"0";i:2;s:3:"523";i:3;s:3:"688";}}i:56;a:4:{s:1:"C";s:2:"56";s:2:"WX";s:3:"556";s:1:"N";s:5:"eight";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:3:"-19";i:2;s:3:"517";i:3;s:3:"703";}}s:5:"eight";a:4:{s:1:"C";s:2:"56";s:2:"WX";s:3:"556";s:1:"N";s:5:"eight";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:3:"-19";i:2;s:3:"517";i:3;s:3:"703";}}i:57;a:4:{s:1:"C";s:2:"57";s:2:"WX";s:3:"556";s:1:"N";s:4:"nine";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-19";i:2;s:3:"514";i:3;s:3:"703";}}s:4:"nine";a:4:{s:1:"C";s:2:"57";s:2:"WX";s:3:"556";s:1:"N";s:4:"nine";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-19";i:2;s:3:"514";i:3;s:3:"703";}}i:58;a:4:{s:1:"C";s:2:"58";s:2:"WX";s:3:"278";s:1:"N";s:5:"colon";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:1:"0";i:2;s:3:"191";i:3;s:3:"516";}}s:5:"colon";a:4:{s:1:"C";s:2:"58";s:2:"WX";s:3:"278";s:1:"N";s:5:"colon";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:1:"0";i:2;s:3:"191";i:3;s:3:"516";}}i:59;a:4:{s:1:"C";s:2:"59";s:2:"WX";s:3:"278";s:1:"N";s:9:"semicolon";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:4:"-147";i:2;s:3:"191";i:3;s:3:"516";}}s:9:"semicolon";a:4:{s:1:"C";s:2:"59";s:2:"WX";s:3:"278";s:1:"N";s:9:"semicolon";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:4:"-147";i:2;s:3:"191";i:3;s:3:"516";}}i:60;a:4:{s:1:"C";s:2:"60";s:2:"WX";s:3:"584";s:1:"N";s:4:"less";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:2:"11";i:2;s:3:"536";i:3;s:3:"495";}}s:4:"less";a:4:{s:1:"C";s:2:"60";s:2:"WX";s:3:"584";s:1:"N";s:4:"less";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:2:"11";i:2;s:3:"536";i:3;s:3:"495";}}i:61;a:4:{s:1:"C";s:2:"61";s:2:"WX";s:3:"584";s:1:"N";s:5:"equal";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:3:"115";i:2;s:3:"545";i:3;s:3:"390";}}s:5:"equal";a:4:{s:1:"C";s:2:"61";s:2:"WX";s:3:"584";s:1:"N";s:5:"equal";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:3:"115";i:2;s:3:"545";i:3;s:3:"390";}}i:62;a:4:{s:1:"C";s:2:"62";s:2:"WX";s:3:"584";s:1:"N";s:7:"greater";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:2:"11";i:2;s:3:"536";i:3;s:3:"495";}}s:7:"greater";a:4:{s:1:"C";s:2:"62";s:2:"WX";s:3:"584";s:1:"N";s:7:"greater";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:2:"11";i:2;s:3:"536";i:3;s:3:"495";}}i:63;a:4:{s:1:"C";s:2:"63";s:2:"WX";s:3:"556";s:1:"N";s:8:"question";s:1:"B";a:4:{i:0;s:2:"56";i:1;s:1:"0";i:2;s:3:"492";i:3;s:3:"727";}}s:8:"question";a:4:{s:1:"C";s:2:"63";s:2:"WX";s:3:"556";s:1:"N";s:8:"question";s:1:"B";a:4:{i:0;s:2:"56";i:1;s:1:"0";i:2;s:3:"492";i:3;s:3:"727";}}i:64;a:4:{s:1:"C";s:2:"64";s:2:"WX";s:4:"1015";s:1:"N";s:2:"at";s:1:"B";a:4:{i:0;s:3:"147";i:1;s:3:"-19";i:2;s:3:"868";i:3;s:3:"737";}}s:2:"at";a:4:{s:1:"C";s:2:"64";s:2:"WX";s:4:"1015";s:1:"N";s:2:"at";s:1:"B";a:4:{i:0;s:3:"147";i:1;s:3:"-19";i:2;s:3:"868";i:3;s:3:"737";}}i:65;a:4:{s:1:"C";s:2:"65";s:2:"WX";s:3:"667";s:1:"N";s:1:"A";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"654";i:3;s:3:"718";}}s:1:"A";a:4:{s:1:"C";s:2:"65";s:2:"WX";s:3:"667";s:1:"N";s:1:"A";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"654";i:3;s:3:"718";}}i:66;a:4:{s:1:"C";s:2:"66";s:2:"WX";s:3:"667";s:1:"N";s:1:"B";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:1:"0";i:2;s:3:"627";i:3;s:3:"718";}}s:1:"B";a:4:{s:1:"C";s:2:"66";s:2:"WX";s:3:"667";s:1:"N";s:1:"B";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:1:"0";i:2;s:3:"627";i:3;s:3:"718";}}i:67;a:4:{s:1:"C";s:2:"67";s:2:"WX";s:3:"722";s:1:"N";s:1:"C";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-19";i:2;s:3:"681";i:3;s:3:"737";}}s:1:"C";a:4:{s:1:"C";s:2:"67";s:2:"WX";s:3:"722";s:1:"N";s:1:"C";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-19";i:2;s:3:"681";i:3;s:3:"737";}}i:68;a:4:{s:1:"C";s:2:"68";s:2:"WX";s:3:"722";s:1:"N";s:1:"D";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:1:"0";i:2;s:3:"674";i:3;s:3:"718";}}s:1:"D";a:4:{s:1:"C";s:2:"68";s:2:"WX";s:3:"722";s:1:"N";s:1:"D";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:1:"0";i:2;s:3:"674";i:3;s:3:"718";}}i:69;a:4:{s:1:"C";s:2:"69";s:2:"WX";s:3:"667";s:1:"N";s:1:"E";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"616";i:3;s:3:"718";}}s:1:"E";a:4:{s:1:"C";s:2:"69";s:2:"WX";s:3:"667";s:1:"N";s:1:"E";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"616";i:3;s:3:"718";}}i:70;a:4:{s:1:"C";s:2:"70";s:2:"WX";s:3:"611";s:1:"N";s:1:"F";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"583";i:3;s:3:"718";}}s:1:"F";a:4:{s:1:"C";s:2:"70";s:2:"WX";s:3:"611";s:1:"N";s:1:"F";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"583";i:3;s:3:"718";}}i:71;a:4:{s:1:"C";s:2:"71";s:2:"WX";s:3:"778";s:1:"N";s:1:"G";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:3:"-19";i:2;s:3:"704";i:3;s:3:"737";}}s:1:"G";a:4:{s:1:"C";s:2:"71";s:2:"WX";s:3:"778";s:1:"N";s:1:"G";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:3:"-19";i:2;s:3:"704";i:3;s:3:"737";}}i:72;a:4:{s:1:"C";s:2:"72";s:2:"WX";s:3:"722";s:1:"N";s:1:"H";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"646";i:3;s:3:"718";}}s:1:"H";a:4:{s:1:"C";s:2:"72";s:2:"WX";s:3:"722";s:1:"N";s:1:"H";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"646";i:3;s:3:"718";}}i:73;a:4:{s:1:"C";s:2:"73";s:2:"WX";s:3:"278";s:1:"N";s:1:"I";s:1:"B";a:4:{i:0;s:2:"91";i:1;s:1:"0";i:2;s:3:"188";i:3;s:3:"718";}}s:1:"I";a:4:{s:1:"C";s:2:"73";s:2:"WX";s:3:"278";s:1:"N";s:1:"I";s:1:"B";a:4:{i:0;s:2:"91";i:1;s:1:"0";i:2;s:3:"188";i:3;s:3:"718";}}i:74;a:4:{s:1:"C";s:2:"74";s:2:"WX";s:3:"500";s:1:"N";s:1:"J";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:3:"-19";i:2;s:3:"428";i:3;s:3:"718";}}s:1:"J";a:4:{s:1:"C";s:2:"74";s:2:"WX";s:3:"500";s:1:"N";s:1:"J";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:3:"-19";i:2;s:3:"428";i:3;s:3:"718";}}i:75;a:4:{s:1:"C";s:2:"75";s:2:"WX";s:3:"667";s:1:"N";s:1:"K";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"663";i:3;s:3:"718";}}s:1:"K";a:4:{s:1:"C";s:2:"75";s:2:"WX";s:3:"667";s:1:"N";s:1:"K";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"663";i:3;s:3:"718";}}i:76;a:4:{s:1:"C";s:2:"76";s:2:"WX";s:3:"556";s:1:"N";s:1:"L";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"537";i:3;s:3:"718";}}s:1:"L";a:4:{s:1:"C";s:2:"76";s:2:"WX";s:3:"556";s:1:"N";s:1:"L";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"537";i:3;s:3:"718";}}i:77;a:4:{s:1:"C";s:2:"77";s:2:"WX";s:3:"833";s:1:"N";s:1:"M";s:1:"B";a:4:{i:0;s:2:"73";i:1;s:1:"0";i:2;s:3:"761";i:3;s:3:"718";}}s:1:"M";a:4:{s:1:"C";s:2:"77";s:2:"WX";s:3:"833";s:1:"N";s:1:"M";s:1:"B";a:4:{i:0;s:2:"73";i:1;s:1:"0";i:2;s:3:"761";i:3;s:3:"718";}}i:78;a:4:{s:1:"C";s:2:"78";s:2:"WX";s:3:"722";s:1:"N";s:1:"N";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"646";i:3;s:3:"718";}}s:1:"N";a:4:{s:1:"C";s:2:"78";s:2:"WX";s:3:"722";s:1:"N";s:1:"N";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"646";i:3;s:3:"718";}}i:79;a:4:{s:1:"C";s:2:"79";s:2:"WX";s:3:"778";s:1:"N";s:1:"O";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:3:"-19";i:2;s:3:"739";i:3;s:3:"737";}}s:1:"O";a:4:{s:1:"C";s:2:"79";s:2:"WX";s:3:"778";s:1:"N";s:1:"O";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:3:"-19";i:2;s:3:"739";i:3;s:3:"737";}}i:80;a:4:{s:1:"C";s:2:"80";s:2:"WX";s:3:"667";s:1:"N";s:1:"P";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"622";i:3;s:3:"718";}}s:1:"P";a:4:{s:1:"C";s:2:"80";s:2:"WX";s:3:"667";s:1:"N";s:1:"P";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"622";i:3;s:3:"718";}}i:81;a:4:{s:1:"C";s:2:"81";s:2:"WX";s:3:"778";s:1:"N";s:1:"Q";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:3:"-56";i:2;s:3:"739";i:3;s:3:"737";}}s:1:"Q";a:4:{s:1:"C";s:2:"81";s:2:"WX";s:3:"778";s:1:"N";s:1:"Q";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:3:"-56";i:2;s:3:"739";i:3;s:3:"737";}}i:82;a:4:{s:1:"C";s:2:"82";s:2:"WX";s:3:"722";s:1:"N";s:1:"R";s:1:"B";a:4:{i:0;s:2:"88";i:1;s:1:"0";i:2;s:3:"684";i:3;s:3:"718";}}s:1:"R";a:4:{s:1:"C";s:2:"82";s:2:"WX";s:3:"722";s:1:"N";s:1:"R";s:1:"B";a:4:{i:0;s:2:"88";i:1;s:1:"0";i:2;s:3:"684";i:3;s:3:"718";}}i:83;a:4:{s:1:"C";s:2:"83";s:2:"WX";s:3:"667";s:1:"N";s:1:"S";s:1:"B";a:4:{i:0;s:2:"49";i:1;s:3:"-19";i:2;s:3:"620";i:3;s:3:"737";}}s:1:"S";a:4:{s:1:"C";s:2:"83";s:2:"WX";s:3:"667";s:1:"N";s:1:"S";s:1:"B";a:4:{i:0;s:2:"49";i:1;s:3:"-19";i:2;s:3:"620";i:3;s:3:"737";}}i:84;a:4:{s:1:"C";s:2:"84";s:2:"WX";s:3:"611";s:1:"N";s:1:"T";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"597";i:3;s:3:"718";}}s:1:"T";a:4:{s:1:"C";s:2:"84";s:2:"WX";s:3:"611";s:1:"N";s:1:"T";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"597";i:3;s:3:"718";}}i:85;a:4:{s:1:"C";s:2:"85";s:2:"WX";s:3:"722";s:1:"N";s:1:"U";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:3:"-19";i:2;s:3:"644";i:3;s:3:"718";}}s:1:"U";a:4:{s:1:"C";s:2:"85";s:2:"WX";s:3:"722";s:1:"N";s:1:"U";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:3:"-19";i:2;s:3:"644";i:3;s:3:"718";}}i:86;a:4:{s:1:"C";s:2:"86";s:2:"WX";s:3:"667";s:1:"N";s:1:"V";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"647";i:3;s:3:"718";}}s:1:"V";a:4:{s:1:"C";s:2:"86";s:2:"WX";s:3:"667";s:1:"N";s:1:"V";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"647";i:3;s:3:"718";}}i:87;a:4:{s:1:"C";s:2:"87";s:2:"WX";s:3:"944";s:1:"N";s:1:"W";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"928";i:3;s:3:"718";}}s:1:"W";a:4:{s:1:"C";s:2:"87";s:2:"WX";s:3:"944";s:1:"N";s:1:"W";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"928";i:3;s:3:"718";}}i:88;a:4:{s:1:"C";s:2:"88";s:2:"WX";s:3:"667";s:1:"N";s:1:"X";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:1:"0";i:2;s:3:"648";i:3;s:3:"718";}}s:1:"X";a:4:{s:1:"C";s:2:"88";s:2:"WX";s:3:"667";s:1:"N";s:1:"X";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:1:"0";i:2;s:3:"648";i:3;s:3:"718";}}i:89;a:4:{s:1:"C";s:2:"89";s:2:"WX";s:3:"667";s:1:"N";s:1:"Y";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"653";i:3;s:3:"718";}}s:1:"Y";a:4:{s:1:"C";s:2:"89";s:2:"WX";s:3:"667";s:1:"N";s:1:"Y";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"653";i:3;s:3:"718";}}i:90;a:4:{s:1:"C";s:2:"90";s:2:"WX";s:3:"611";s:1:"N";s:1:"Z";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:1:"0";i:2;s:3:"588";i:3;s:3:"718";}}s:1:"Z";a:4:{s:1:"C";s:2:"90";s:2:"WX";s:3:"611";s:1:"N";s:1:"Z";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:1:"0";i:2;s:3:"588";i:3;s:3:"718";}}i:91;a:4:{s:1:"C";s:2:"91";s:2:"WX";s:3:"278";s:1:"N";s:11:"bracketleft";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:4:"-196";i:2;s:3:"250";i:3;s:3:"722";}}s:11:"bracketleft";a:4:{s:1:"C";s:2:"91";s:2:"WX";s:3:"278";s:1:"N";s:11:"bracketleft";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:4:"-196";i:2;s:3:"250";i:3;s:3:"722";}}i:92;a:4:{s:1:"C";s:2:"92";s:2:"WX";s:3:"278";s:1:"N";s:9:"backslash";s:1:"B";a:4:{i:0;s:3:"-17";i:1;s:3:"-19";i:2;s:3:"295";i:3;s:3:"737";}}s:9:"backslash";a:4:{s:1:"C";s:2:"92";s:2:"WX";s:3:"278";s:1:"N";s:9:"backslash";s:1:"B";a:4:{i:0;s:3:"-17";i:1;s:3:"-19";i:2;s:3:"295";i:3;s:3:"737";}}i:93;a:4:{s:1:"C";s:2:"93";s:2:"WX";s:3:"278";s:1:"N";s:12:"bracketright";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:4:"-196";i:2;s:3:"215";i:3;s:3:"722";}}s:12:"bracketright";a:4:{s:1:"C";s:2:"93";s:2:"WX";s:3:"278";s:1:"N";s:12:"bracketright";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:4:"-196";i:2;s:3:"215";i:3;s:3:"722";}}i:94;a:4:{s:1:"C";s:2:"94";s:2:"WX";s:3:"469";s:1:"N";s:11:"asciicircum";s:1:"B";a:4:{i:0;s:3:"-14";i:1;s:3:"264";i:2;s:3:"483";i:3;s:3:"688";}}s:11:"asciicircum";a:4:{s:1:"C";s:2:"94";s:2:"WX";s:3:"469";s:1:"N";s:11:"asciicircum";s:1:"B";a:4:{i:0;s:3:"-14";i:1;s:3:"264";i:2;s:3:"483";i:3;s:3:"688";}}i:95;a:4:{s:1:"C";s:2:"95";s:2:"WX";s:3:"556";s:1:"N";s:10:"underscore";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:4:"-125";i:2;s:3:"556";i:3;s:3:"-75";}}s:10:"underscore";a:4:{s:1:"C";s:2:"95";s:2:"WX";s:3:"556";s:1:"N";s:10:"underscore";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:4:"-125";i:2;s:3:"556";i:3;s:3:"-75";}}i:96;a:4:{s:1:"C";s:2:"96";s:2:"WX";s:3:"222";s:1:"N";s:9:"quoteleft";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:3:"470";i:2;s:3:"169";i:3;s:3:"725";}}s:9:"quoteleft";a:4:{s:1:"C";s:2:"96";s:2:"WX";s:3:"222";s:1:"N";s:9:"quoteleft";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:3:"470";i:2;s:3:"169";i:3;s:3:"725";}}i:97;a:4:{s:1:"C";s:2:"97";s:2:"WX";s:3:"556";s:1:"N";s:1:"a";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:3:"-15";i:2;s:3:"530";i:3;s:3:"538";}}s:1:"a";a:4:{s:1:"C";s:2:"97";s:2:"WX";s:3:"556";s:1:"N";s:1:"a";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:3:"-15";i:2;s:3:"530";i:3;s:3:"538";}}i:98;a:4:{s:1:"C";s:2:"98";s:2:"WX";s:3:"556";s:1:"N";s:1:"b";s:1:"B";a:4:{i:0;s:2:"58";i:1;s:3:"-15";i:2;s:3:"517";i:3;s:3:"718";}}s:1:"b";a:4:{s:1:"C";s:2:"98";s:2:"WX";s:3:"556";s:1:"N";s:1:"b";s:1:"B";a:4:{i:0;s:2:"58";i:1;s:3:"-15";i:2;s:3:"517";i:3;s:3:"718";}}i:99;a:4:{s:1:"C";s:2:"99";s:2:"WX";s:3:"500";s:1:"N";s:1:"c";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-15";i:2;s:3:"477";i:3;s:3:"538";}}s:1:"c";a:4:{s:1:"C";s:2:"99";s:2:"WX";s:3:"500";s:1:"N";s:1:"c";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-15";i:2;s:3:"477";i:3;s:3:"538";}}i:100;a:4:{s:1:"C";s:3:"100";s:2:"WX";s:3:"556";s:1:"N";s:1:"d";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-15";i:2;s:3:"499";i:3;s:3:"718";}}s:1:"d";a:4:{s:1:"C";s:3:"100";s:2:"WX";s:3:"556";s:1:"N";s:1:"d";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-15";i:2;s:3:"499";i:3;s:3:"718";}}i:101;a:4:{s:1:"C";s:3:"101";s:2:"WX";s:3:"556";s:1:"N";s:1:"e";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"-15";i:2;s:3:"516";i:3;s:3:"538";}}s:1:"e";a:4:{s:1:"C";s:3:"101";s:2:"WX";s:3:"556";s:1:"N";s:1:"e";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"-15";i:2;s:3:"516";i:3;s:3:"538";}}i:102;a:5:{s:1:"C";s:3:"102";s:2:"WX";s:3:"278";s:1:"N";s:1:"f";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"262";i:3;s:3:"728";}s:1:"L";a:2:{i:0;s:1:"l";i:1;s:2:"fl";}}s:1:"f";a:5:{s:1:"C";s:3:"102";s:2:"WX";s:3:"278";s:1:"N";s:1:"f";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"262";i:3;s:3:"728";}s:1:"L";a:2:{i:0;s:1:"l";i:1;s:2:"fl";}}i:103;a:4:{s:1:"C";s:3:"103";s:2:"WX";s:3:"556";s:1:"N";s:1:"g";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:4:"-220";i:2;s:3:"499";i:3;s:3:"538";}}s:1:"g";a:4:{s:1:"C";s:3:"103";s:2:"WX";s:3:"556";s:1:"N";s:1:"g";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:4:"-220";i:2;s:3:"499";i:3;s:3:"538";}}i:104;a:4:{s:1:"C";s:3:"104";s:2:"WX";s:3:"556";s:1:"N";s:1:"h";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:1:"0";i:2;s:3:"491";i:3;s:3:"718";}}s:1:"h";a:4:{s:1:"C";s:3:"104";s:2:"WX";s:3:"556";s:1:"N";s:1:"h";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:1:"0";i:2;s:3:"491";i:3;s:3:"718";}}i:105;a:4:{s:1:"C";s:3:"105";s:2:"WX";s:3:"222";s:1:"N";s:1:"i";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:1:"0";i:2;s:3:"155";i:3;s:3:"718";}}s:1:"i";a:4:{s:1:"C";s:3:"105";s:2:"WX";s:3:"222";s:1:"N";s:1:"i";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:1:"0";i:2;s:3:"155";i:3;s:3:"718";}}i:106;a:4:{s:1:"C";s:3:"106";s:2:"WX";s:3:"222";s:1:"N";s:1:"j";s:1:"B";a:4:{i:0;s:3:"-16";i:1;s:4:"-210";i:2;s:3:"155";i:3;s:3:"718";}}s:1:"j";a:4:{s:1:"C";s:3:"106";s:2:"WX";s:3:"222";s:1:"N";s:1:"j";s:1:"B";a:4:{i:0;s:3:"-16";i:1;s:4:"-210";i:2;s:3:"155";i:3;s:3:"718";}}i:107;a:4:{s:1:"C";s:3:"107";s:2:"WX";s:3:"500";s:1:"N";s:1:"k";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:1:"0";i:2;s:3:"501";i:3;s:3:"718";}}s:1:"k";a:4:{s:1:"C";s:3:"107";s:2:"WX";s:3:"500";s:1:"N";s:1:"k";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:1:"0";i:2;s:3:"501";i:3;s:3:"718";}}i:108;a:4:{s:1:"C";s:3:"108";s:2:"WX";s:3:"222";s:1:"N";s:1:"l";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:1:"0";i:2;s:3:"155";i:3;s:3:"718";}}s:1:"l";a:4:{s:1:"C";s:3:"108";s:2:"WX";s:3:"222";s:1:"N";s:1:"l";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:1:"0";i:2;s:3:"155";i:3;s:3:"718";}}i:109;a:4:{s:1:"C";s:3:"109";s:2:"WX";s:3:"833";s:1:"N";s:1:"m";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:1:"0";i:2;s:3:"769";i:3;s:3:"538";}}s:1:"m";a:4:{s:1:"C";s:3:"109";s:2:"WX";s:3:"833";s:1:"N";s:1:"m";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:1:"0";i:2;s:3:"769";i:3;s:3:"538";}}i:110;a:4:{s:1:"C";s:3:"110";s:2:"WX";s:3:"556";s:1:"N";s:1:"n";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:1:"0";i:2;s:3:"491";i:3;s:3:"538";}}s:1:"n";a:4:{s:1:"C";s:3:"110";s:2:"WX";s:3:"556";s:1:"N";s:1:"n";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:1:"0";i:2;s:3:"491";i:3;s:3:"538";}}i:111;a:4:{s:1:"C";s:3:"111";s:2:"WX";s:3:"556";s:1:"N";s:1:"o";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"521";i:3;s:3:"538";}}s:1:"o";a:4:{s:1:"C";s:3:"111";s:2:"WX";s:3:"556";s:1:"N";s:1:"o";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"521";i:3;s:3:"538";}}i:112;a:4:{s:1:"C";s:3:"112";s:2:"WX";s:3:"556";s:1:"N";s:1:"p";s:1:"B";a:4:{i:0;s:2:"58";i:1;s:4:"-207";i:2;s:3:"517";i:3;s:3:"538";}}s:1:"p";a:4:{s:1:"C";s:3:"112";s:2:"WX";s:3:"556";s:1:"N";s:1:"p";s:1:"B";a:4:{i:0;s:2:"58";i:1;s:4:"-207";i:2;s:3:"517";i:3;s:3:"538";}}i:113;a:4:{s:1:"C";s:3:"113";s:2:"WX";s:3:"556";s:1:"N";s:1:"q";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:4:"-207";i:2;s:3:"494";i:3;s:3:"538";}}s:1:"q";a:4:{s:1:"C";s:3:"113";s:2:"WX";s:3:"556";s:1:"N";s:1:"q";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:4:"-207";i:2;s:3:"494";i:3;s:3:"538";}}i:114;a:4:{s:1:"C";s:3:"114";s:2:"WX";s:3:"333";s:1:"N";s:1:"r";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"332";i:3;s:3:"538";}}s:1:"r";a:4:{s:1:"C";s:3:"114";s:2:"WX";s:3:"333";s:1:"N";s:1:"r";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"332";i:3;s:3:"538";}}i:115;a:4:{s:1:"C";s:3:"115";s:2:"WX";s:3:"500";s:1:"N";s:1:"s";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:3:"-15";i:2;s:3:"464";i:3;s:3:"538";}}s:1:"s";a:4:{s:1:"C";s:3:"115";s:2:"WX";s:3:"500";s:1:"N";s:1:"s";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:3:"-15";i:2;s:3:"464";i:3;s:3:"538";}}i:116;a:4:{s:1:"C";s:3:"116";s:2:"WX";s:3:"278";s:1:"N";s:1:"t";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:2:"-7";i:2;s:3:"257";i:3;s:3:"669";}}s:1:"t";a:4:{s:1:"C";s:3:"116";s:2:"WX";s:3:"278";s:1:"N";s:1:"t";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:2:"-7";i:2;s:3:"257";i:3;s:3:"669";}}i:117;a:4:{s:1:"C";s:3:"117";s:2:"WX";s:3:"556";s:1:"N";s:1:"u";s:1:"B";a:4:{i:0;s:2:"68";i:1;s:3:"-15";i:2;s:3:"489";i:3;s:3:"523";}}s:1:"u";a:4:{s:1:"C";s:3:"117";s:2:"WX";s:3:"556";s:1:"N";s:1:"u";s:1:"B";a:4:{i:0;s:2:"68";i:1;s:3:"-15";i:2;s:3:"489";i:3;s:3:"523";}}i:118;a:4:{s:1:"C";s:3:"118";s:2:"WX";s:3:"500";s:1:"N";s:1:"v";s:1:"B";a:4:{i:0;s:1:"8";i:1;s:1:"0";i:2;s:3:"492";i:3;s:3:"523";}}s:1:"v";a:4:{s:1:"C";s:3:"118";s:2:"WX";s:3:"500";s:1:"N";s:1:"v";s:1:"B";a:4:{i:0;s:1:"8";i:1;s:1:"0";i:2;s:3:"492";i:3;s:3:"523";}}i:119;a:4:{s:1:"C";s:3:"119";s:2:"WX";s:3:"722";s:1:"N";s:1:"w";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"709";i:3;s:3:"523";}}s:1:"w";a:4:{s:1:"C";s:3:"119";s:2:"WX";s:3:"722";s:1:"N";s:1:"w";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"709";i:3;s:3:"523";}}i:120;a:4:{s:1:"C";s:3:"120";s:2:"WX";s:3:"500";s:1:"N";s:1:"x";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:1:"0";i:2;s:3:"490";i:3;s:3:"523";}}s:1:"x";a:4:{s:1:"C";s:3:"120";s:2:"WX";s:3:"500";s:1:"N";s:1:"x";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:1:"0";i:2;s:3:"490";i:3;s:3:"523";}}i:121;a:4:{s:1:"C";s:3:"121";s:2:"WX";s:3:"500";s:1:"N";s:1:"y";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:4:"-214";i:2;s:3:"489";i:3;s:3:"523";}}s:1:"y";a:4:{s:1:"C";s:3:"121";s:2:"WX";s:3:"500";s:1:"N";s:1:"y";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:4:"-214";i:2;s:3:"489";i:3;s:3:"523";}}i:122;a:4:{s:1:"C";s:3:"122";s:2:"WX";s:3:"500";s:1:"N";s:1:"z";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:1:"0";i:2;s:3:"469";i:3;s:3:"523";}}s:1:"z";a:4:{s:1:"C";s:3:"122";s:2:"WX";s:3:"500";s:1:"N";s:1:"z";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:1:"0";i:2;s:3:"469";i:3;s:3:"523";}}i:123;a:4:{s:1:"C";s:3:"123";s:2:"WX";s:3:"334";s:1:"N";s:9:"braceleft";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:4:"-196";i:2;s:3:"292";i:3;s:3:"722";}}s:9:"braceleft";a:4:{s:1:"C";s:3:"123";s:2:"WX";s:3:"334";s:1:"N";s:9:"braceleft";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:4:"-196";i:2;s:3:"292";i:3;s:3:"722";}}i:124;a:4:{s:1:"C";s:3:"124";s:2:"WX";s:3:"260";s:1:"N";s:3:"bar";s:1:"B";a:4:{i:0;s:2:"94";i:1;s:4:"-225";i:2;s:3:"167";i:3;s:3:"775";}}s:3:"bar";a:4:{s:1:"C";s:3:"124";s:2:"WX";s:3:"260";s:1:"N";s:3:"bar";s:1:"B";a:4:{i:0;s:2:"94";i:1;s:4:"-225";i:2;s:3:"167";i:3;s:3:"775";}}i:125;a:4:{s:1:"C";s:3:"125";s:2:"WX";s:3:"334";s:1:"N";s:10:"braceright";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:4:"-196";i:2;s:3:"292";i:3;s:3:"722";}}s:10:"braceright";a:4:{s:1:"C";s:3:"125";s:2:"WX";s:3:"334";s:1:"N";s:10:"braceright";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:4:"-196";i:2;s:3:"292";i:3;s:3:"722";}}i:126;a:4:{s:1:"C";s:3:"126";s:2:"WX";s:3:"584";s:1:"N";s:10:"asciitilde";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:3:"180";i:2;s:3:"523";i:3;s:3:"326";}}s:10:"asciitilde";a:4:{s:1:"C";s:3:"126";s:2:"WX";s:3:"584";s:1:"N";s:10:"asciitilde";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:3:"180";i:2;s:3:"523";i:3;s:3:"326";}}i:161;a:4:{s:1:"C";s:3:"161";s:2:"WX";s:3:"333";s:1:"N";s:10:"exclamdown";s:1:"B";a:4:{i:0;s:3:"118";i:1;s:4:"-195";i:2;s:3:"215";i:3;s:3:"523";}}s:10:"exclamdown";a:4:{s:1:"C";s:3:"161";s:2:"WX";s:3:"333";s:1:"N";s:10:"exclamdown";s:1:"B";a:4:{i:0;s:3:"118";i:1;s:4:"-195";i:2;s:3:"215";i:3;s:3:"523";}}i:162;a:4:{s:1:"C";s:3:"162";s:2:"WX";s:3:"556";s:1:"N";s:4:"cent";s:1:"B";a:4:{i:0;s:2:"51";i:1;s:4:"-115";i:2;s:3:"513";i:3;s:3:"623";}}s:4:"cent";a:4:{s:1:"C";s:3:"162";s:2:"WX";s:3:"556";s:1:"N";s:4:"cent";s:1:"B";a:4:{i:0;s:2:"51";i:1;s:4:"-115";i:2;s:3:"513";i:3;s:3:"623";}}i:163;a:4:{s:1:"C";s:3:"163";s:2:"WX";s:3:"556";s:1:"N";s:8:"sterling";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:3:"-16";i:2;s:3:"539";i:3;s:3:"718";}}s:8:"sterling";a:4:{s:1:"C";s:3:"163";s:2:"WX";s:3:"556";s:1:"N";s:8:"sterling";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:3:"-16";i:2;s:3:"539";i:3;s:3:"718";}}i:164;a:4:{s:1:"C";s:3:"164";s:2:"WX";s:3:"167";s:1:"N";s:8:"fraction";s:1:"B";a:4:{i:0;s:4:"-166";i:1;s:3:"-19";i:2;s:3:"333";i:3;s:3:"703";}}s:8:"fraction";a:4:{s:1:"C";s:3:"164";s:2:"WX";s:3:"167";s:1:"N";s:8:"fraction";s:1:"B";a:4:{i:0;s:4:"-166";i:1;s:3:"-19";i:2;s:3:"333";i:3;s:3:"703";}}i:165;a:4:{s:1:"C";s:3:"165";s:2:"WX";s:3:"556";s:1:"N";s:3:"yen";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:1:"0";i:2;s:3:"553";i:3;s:3:"688";}}s:3:"yen";a:4:{s:1:"C";s:3:"165";s:2:"WX";s:3:"556";s:1:"N";s:3:"yen";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:1:"0";i:2;s:3:"553";i:3;s:3:"688";}}i:166;a:4:{s:1:"C";s:3:"166";s:2:"WX";s:3:"556";s:1:"N";s:6:"florin";s:1:"B";a:4:{i:0;s:3:"-11";i:1;s:4:"-207";i:2;s:3:"501";i:3;s:3:"737";}}s:6:"florin";a:4:{s:1:"C";s:3:"166";s:2:"WX";s:3:"556";s:1:"N";s:6:"florin";s:1:"B";a:4:{i:0;s:3:"-11";i:1;s:4:"-207";i:2;s:3:"501";i:3;s:3:"737";}}i:167;a:4:{s:1:"C";s:3:"167";s:2:"WX";s:3:"556";s:1:"N";s:7:"section";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:4:"-191";i:2;s:3:"512";i:3;s:3:"737";}}s:7:"section";a:4:{s:1:"C";s:3:"167";s:2:"WX";s:3:"556";s:1:"N";s:7:"section";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:4:"-191";i:2;s:3:"512";i:3;s:3:"737";}}i:168;a:4:{s:1:"C";s:3:"168";s:2:"WX";s:3:"556";s:1:"N";s:8:"currency";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:2:"99";i:2;s:3:"528";i:3;s:3:"603";}}s:8:"currency";a:4:{s:1:"C";s:3:"168";s:2:"WX";s:3:"556";s:1:"N";s:8:"currency";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:2:"99";i:2;s:3:"528";i:3;s:3:"603";}}i:169;a:4:{s:1:"C";s:3:"169";s:2:"WX";s:3:"191";s:1:"N";s:11:"quotesingle";s:1:"B";a:4:{i:0;s:2:"59";i:1;s:3:"463";i:2;s:3:"132";i:3;s:3:"718";}}s:11:"quotesingle";a:4:{s:1:"C";s:3:"169";s:2:"WX";s:3:"191";s:1:"N";s:11:"quotesingle";s:1:"B";a:4:{i:0;s:2:"59";i:1;s:3:"463";i:2;s:3:"132";i:3;s:3:"718";}}i:170;a:4:{s:1:"C";s:3:"170";s:2:"WX";s:3:"333";s:1:"N";s:12:"quotedblleft";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:3:"470";i:2;s:3:"307";i:3;s:3:"725";}}s:12:"quotedblleft";a:4:{s:1:"C";s:3:"170";s:2:"WX";s:3:"333";s:1:"N";s:12:"quotedblleft";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:3:"470";i:2;s:3:"307";i:3;s:3:"725";}}i:171;a:4:{s:1:"C";s:3:"171";s:2:"WX";s:3:"556";s:1:"N";s:13:"guillemotleft";s:1:"B";a:4:{i:0;s:2:"97";i:1;s:3:"108";i:2;s:3:"459";i:3;s:3:"446";}}s:13:"guillemotleft";a:4:{s:1:"C";s:3:"171";s:2:"WX";s:3:"556";s:1:"N";s:13:"guillemotleft";s:1:"B";a:4:{i:0;s:2:"97";i:1;s:3:"108";i:2;s:3:"459";i:3;s:3:"446";}}i:172;a:4:{s:1:"C";s:3:"172";s:2:"WX";s:3:"333";s:1:"N";s:13:"guilsinglleft";s:1:"B";a:4:{i:0;s:2:"88";i:1;s:3:"108";i:2;s:3:"245";i:3;s:3:"446";}}s:13:"guilsinglleft";a:4:{s:1:"C";s:3:"172";s:2:"WX";s:3:"333";s:1:"N";s:13:"guilsinglleft";s:1:"B";a:4:{i:0;s:2:"88";i:1;s:3:"108";i:2;s:3:"245";i:3;s:3:"446";}}i:173;a:4:{s:1:"C";s:3:"173";s:2:"WX";s:3:"333";s:1:"N";s:14:"guilsinglright";s:1:"B";a:4:{i:0;s:2:"88";i:1;s:3:"108";i:2;s:3:"245";i:3;s:3:"446";}}s:14:"guilsinglright";a:4:{s:1:"C";s:3:"173";s:2:"WX";s:3:"333";s:1:"N";s:14:"guilsinglright";s:1:"B";a:4:{i:0;s:2:"88";i:1;s:3:"108";i:2;s:3:"245";i:3;s:3:"446";}}i:174;a:4:{s:1:"C";s:3:"174";s:2:"WX";s:3:"500";s:1:"N";s:2:"fi";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"434";i:3;s:3:"728";}}s:2:"fi";a:4:{s:1:"C";s:3:"174";s:2:"WX";s:3:"500";s:1:"N";s:2:"fi";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"434";i:3;s:3:"728";}}i:175;a:4:{s:1:"C";s:3:"175";s:2:"WX";s:3:"500";s:1:"N";s:2:"fl";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"432";i:3;s:3:"728";}}s:2:"fl";a:4:{s:1:"C";s:3:"175";s:2:"WX";s:3:"500";s:1:"N";s:2:"fl";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"432";i:3;s:3:"728";}}i:177;a:4:{s:1:"C";s:3:"177";s:2:"WX";s:3:"556";s:1:"N";s:6:"endash";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"240";i:2;s:3:"556";i:3;s:3:"313";}}s:6:"endash";a:4:{s:1:"C";s:3:"177";s:2:"WX";s:3:"556";s:1:"N";s:6:"endash";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"240";i:2;s:3:"556";i:3;s:3:"313";}}i:178;a:4:{s:1:"C";s:3:"178";s:2:"WX";s:3:"556";s:1:"N";s:6:"dagger";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:4:"-159";i:2;s:3:"514";i:3;s:3:"718";}}s:6:"dagger";a:4:{s:1:"C";s:3:"178";s:2:"WX";s:3:"556";s:1:"N";s:6:"dagger";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:4:"-159";i:2;s:3:"514";i:3;s:3:"718";}}i:179;a:4:{s:1:"C";s:3:"179";s:2:"WX";s:3:"556";s:1:"N";s:9:"daggerdbl";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:4:"-159";i:2;s:3:"514";i:3;s:3:"718";}}s:9:"daggerdbl";a:4:{s:1:"C";s:3:"179";s:2:"WX";s:3:"556";s:1:"N";s:9:"daggerdbl";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:4:"-159";i:2;s:3:"514";i:3;s:3:"718";}}i:180;a:4:{s:1:"C";s:3:"180";s:2:"WX";s:3:"278";s:1:"N";s:14:"periodcentered";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:3:"190";i:2;s:3:"202";i:3;s:3:"315";}}s:14:"periodcentered";a:4:{s:1:"C";s:3:"180";s:2:"WX";s:3:"278";s:1:"N";s:14:"periodcentered";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:3:"190";i:2;s:3:"202";i:3;s:3:"315";}}i:182;a:4:{s:1:"C";s:3:"182";s:2:"WX";s:3:"537";s:1:"N";s:9:"paragraph";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:4:"-173";i:2;s:3:"497";i:3;s:3:"718";}}s:9:"paragraph";a:4:{s:1:"C";s:3:"182";s:2:"WX";s:3:"537";s:1:"N";s:9:"paragraph";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:4:"-173";i:2;s:3:"497";i:3;s:3:"718";}}i:183;a:4:{s:1:"C";s:3:"183";s:2:"WX";s:3:"350";s:1:"N";s:6:"bullet";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:3:"202";i:2;s:3:"333";i:3;s:3:"517";}}s:6:"bullet";a:4:{s:1:"C";s:3:"183";s:2:"WX";s:3:"350";s:1:"N";s:6:"bullet";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:3:"202";i:2;s:3:"333";i:3;s:3:"517";}}i:184;a:4:{s:1:"C";s:3:"184";s:2:"WX";s:3:"222";s:1:"N";s:14:"quotesinglbase";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:4:"-149";i:2;s:3:"157";i:3;s:3:"106";}}s:14:"quotesinglbase";a:4:{s:1:"C";s:3:"184";s:2:"WX";s:3:"222";s:1:"N";s:14:"quotesinglbase";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:4:"-149";i:2;s:3:"157";i:3;s:3:"106";}}i:185;a:4:{s:1:"C";s:3:"185";s:2:"WX";s:3:"333";s:1:"N";s:12:"quotedblbase";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:4:"-149";i:2;s:3:"295";i:3;s:3:"106";}}s:12:"quotedblbase";a:4:{s:1:"C";s:3:"185";s:2:"WX";s:3:"333";s:1:"N";s:12:"quotedblbase";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:4:"-149";i:2;s:3:"295";i:3;s:3:"106";}}i:186;a:4:{s:1:"C";s:3:"186";s:2:"WX";s:3:"333";s:1:"N";s:13:"quotedblright";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:3:"463";i:2;s:3:"295";i:3;s:3:"718";}}s:13:"quotedblright";a:4:{s:1:"C";s:3:"186";s:2:"WX";s:3:"333";s:1:"N";s:13:"quotedblright";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:3:"463";i:2;s:3:"295";i:3;s:3:"718";}}i:187;a:4:{s:1:"C";s:3:"187";s:2:"WX";s:3:"556";s:1:"N";s:14:"guillemotright";s:1:"B";a:4:{i:0;s:2:"97";i:1;s:3:"108";i:2;s:3:"459";i:3;s:3:"446";}}s:14:"guillemotright";a:4:{s:1:"C";s:3:"187";s:2:"WX";s:3:"556";s:1:"N";s:14:"guillemotright";s:1:"B";a:4:{i:0;s:2:"97";i:1;s:3:"108";i:2;s:3:"459";i:3;s:3:"446";}}i:188;a:4:{s:1:"C";s:3:"188";s:2:"WX";s:4:"1000";s:1:"N";s:8:"ellipsis";s:1:"B";a:4:{i:0;s:3:"115";i:1;s:1:"0";i:2;s:3:"885";i:3;s:3:"106";}}s:8:"ellipsis";a:4:{s:1:"C";s:3:"188";s:2:"WX";s:4:"1000";s:1:"N";s:8:"ellipsis";s:1:"B";a:4:{i:0;s:3:"115";i:1;s:1:"0";i:2;s:3:"885";i:3;s:3:"106";}}i:189;a:4:{s:1:"C";s:3:"189";s:2:"WX";s:4:"1000";s:1:"N";s:11:"perthousand";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:3:"-19";i:2;s:3:"994";i:3;s:3:"703";}}s:11:"perthousand";a:4:{s:1:"C";s:3:"189";s:2:"WX";s:4:"1000";s:1:"N";s:11:"perthousand";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:3:"-19";i:2;s:3:"994";i:3;s:3:"703";}}i:191;a:4:{s:1:"C";s:3:"191";s:2:"WX";s:3:"611";s:1:"N";s:12:"questiondown";s:1:"B";a:4:{i:0;s:2:"91";i:1;s:4:"-201";i:2;s:3:"527";i:3;s:3:"525";}}s:12:"questiondown";a:4:{s:1:"C";s:3:"191";s:2:"WX";s:3:"611";s:1:"N";s:12:"questiondown";s:1:"B";a:4:{i:0;s:2:"91";i:1;s:4:"-201";i:2;s:3:"527";i:3;s:3:"525";}}i:193;a:4:{s:1:"C";s:3:"193";s:2:"WX";s:3:"333";s:1:"N";s:5:"grave";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:3:"593";i:2;s:3:"211";i:3;s:3:"734";}}s:5:"grave";a:4:{s:1:"C";s:3:"193";s:2:"WX";s:3:"333";s:1:"N";s:5:"grave";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:3:"593";i:2;s:3:"211";i:3;s:3:"734";}}i:194;a:4:{s:1:"C";s:3:"194";s:2:"WX";s:3:"333";s:1:"N";s:5:"acute";s:1:"B";a:4:{i:0;s:3:"122";i:1;s:3:"593";i:2;s:3:"319";i:3;s:3:"734";}}s:5:"acute";a:4:{s:1:"C";s:3:"194";s:2:"WX";s:3:"333";s:1:"N";s:5:"acute";s:1:"B";a:4:{i:0;s:3:"122";i:1;s:3:"593";i:2;s:3:"319";i:3;s:3:"734";}}i:195;a:4:{s:1:"C";s:3:"195";s:2:"WX";s:3:"333";s:1:"N";s:10:"circumflex";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:3:"593";i:2;s:3:"312";i:3;s:3:"734";}}s:10:"circumflex";a:4:{s:1:"C";s:3:"195";s:2:"WX";s:3:"333";s:1:"N";s:10:"circumflex";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:3:"593";i:2;s:3:"312";i:3;s:3:"734";}}i:196;a:4:{s:1:"C";s:3:"196";s:2:"WX";s:3:"333";s:1:"N";s:5:"tilde";s:1:"B";a:4:{i:0;s:2:"-4";i:1;s:3:"606";i:2;s:3:"337";i:3;s:3:"722";}}s:5:"tilde";a:4:{s:1:"C";s:3:"196";s:2:"WX";s:3:"333";s:1:"N";s:5:"tilde";s:1:"B";a:4:{i:0;s:2:"-4";i:1;s:3:"606";i:2;s:3:"337";i:3;s:3:"722";}}i:197;a:4:{s:1:"C";s:3:"197";s:2:"WX";s:3:"333";s:1:"N";s:6:"macron";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:3:"627";i:2;s:3:"323";i:3;s:3:"684";}}s:6:"macron";a:4:{s:1:"C";s:3:"197";s:2:"WX";s:3:"333";s:1:"N";s:6:"macron";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:3:"627";i:2;s:3:"323";i:3;s:3:"684";}}i:198;a:4:{s:1:"C";s:3:"198";s:2:"WX";s:3:"333";s:1:"N";s:5:"breve";s:1:"B";a:4:{i:0;s:2:"13";i:1;s:3:"595";i:2;s:3:"321";i:3;s:3:"731";}}s:5:"breve";a:4:{s:1:"C";s:3:"198";s:2:"WX";s:3:"333";s:1:"N";s:5:"breve";s:1:"B";a:4:{i:0;s:2:"13";i:1;s:3:"595";i:2;s:3:"321";i:3;s:3:"731";}}i:199;a:4:{s:1:"C";s:3:"199";s:2:"WX";s:3:"333";s:1:"N";s:9:"dotaccent";s:1:"B";a:4:{i:0;s:3:"121";i:1;s:3:"604";i:2;s:3:"212";i:3;s:3:"706";}}s:9:"dotaccent";a:4:{s:1:"C";s:3:"199";s:2:"WX";s:3:"333";s:1:"N";s:9:"dotaccent";s:1:"B";a:4:{i:0;s:3:"121";i:1;s:3:"604";i:2;s:3:"212";i:3;s:3:"706";}}i:200;a:4:{s:1:"C";s:3:"200";s:2:"WX";s:3:"333";s:1:"N";s:8:"dieresis";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"604";i:2;s:3:"293";i:3;s:3:"706";}}s:8:"dieresis";a:4:{s:1:"C";s:3:"200";s:2:"WX";s:3:"333";s:1:"N";s:8:"dieresis";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"604";i:2;s:3:"293";i:3;s:3:"706";}}i:202;a:4:{s:1:"C";s:3:"202";s:2:"WX";s:3:"333";s:1:"N";s:4:"ring";s:1:"B";a:4:{i:0;s:2:"75";i:1;s:3:"572";i:2;s:3:"259";i:3;s:3:"756";}}s:4:"ring";a:4:{s:1:"C";s:3:"202";s:2:"WX";s:3:"333";s:1:"N";s:4:"ring";s:1:"B";a:4:{i:0;s:2:"75";i:1;s:3:"572";i:2;s:3:"259";i:3;s:3:"756";}}i:203;a:4:{s:1:"C";s:3:"203";s:2:"WX";s:3:"333";s:1:"N";s:7:"cedilla";s:1:"B";a:4:{i:0;s:2:"45";i:1;s:4:"-225";i:2;s:3:"259";i:3;s:1:"0";}}s:7:"cedilla";a:4:{s:1:"C";s:3:"203";s:2:"WX";s:3:"333";s:1:"N";s:7:"cedilla";s:1:"B";a:4:{i:0;s:2:"45";i:1;s:4:"-225";i:2;s:3:"259";i:3;s:1:"0";}}i:205;a:4:{s:1:"C";s:3:"205";s:2:"WX";s:3:"333";s:1:"N";s:12:"hungarumlaut";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:3:"593";i:2;s:3:"409";i:3;s:3:"734";}}s:12:"hungarumlaut";a:4:{s:1:"C";s:3:"205";s:2:"WX";s:3:"333";s:1:"N";s:12:"hungarumlaut";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:3:"593";i:2;s:3:"409";i:3;s:3:"734";}}i:206;a:4:{s:1:"C";s:3:"206";s:2:"WX";s:3:"333";s:1:"N";s:6:"ogonek";s:1:"B";a:4:{i:0;s:2:"73";i:1;s:4:"-225";i:2;s:3:"287";i:3;s:1:"0";}}s:6:"ogonek";a:4:{s:1:"C";s:3:"206";s:2:"WX";s:3:"333";s:1:"N";s:6:"ogonek";s:1:"B";a:4:{i:0;s:2:"73";i:1;s:4:"-225";i:2;s:3:"287";i:3;s:1:"0";}}i:207;a:4:{s:1:"C";s:3:"207";s:2:"WX";s:3:"333";s:1:"N";s:5:"caron";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:3:"593";i:2;s:3:"312";i:3;s:3:"734";}}s:5:"caron";a:4:{s:1:"C";s:3:"207";s:2:"WX";s:3:"333";s:1:"N";s:5:"caron";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:3:"593";i:2;s:3:"312";i:3;s:3:"734";}}i:208;a:4:{s:1:"C";s:3:"208";s:2:"WX";s:4:"1000";s:1:"N";s:6:"emdash";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"240";i:2;s:4:"1000";i:3;s:3:"313";}}s:6:"emdash";a:4:{s:1:"C";s:3:"208";s:2:"WX";s:4:"1000";s:1:"N";s:6:"emdash";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"240";i:2;s:4:"1000";i:3;s:3:"313";}}i:225;a:4:{s:1:"C";s:3:"225";s:2:"WX";s:4:"1000";s:1:"N";s:2:"AE";s:1:"B";a:4:{i:0;s:1:"8";i:1;s:1:"0";i:2;s:3:"951";i:3;s:3:"718";}}s:2:"AE";a:4:{s:1:"C";s:3:"225";s:2:"WX";s:4:"1000";s:1:"N";s:2:"AE";s:1:"B";a:4:{i:0;s:1:"8";i:1;s:1:"0";i:2;s:3:"951";i:3;s:3:"718";}}i:227;a:4:{s:1:"C";s:3:"227";s:2:"WX";s:3:"370";s:1:"N";s:11:"ordfeminine";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:3:"405";i:2;s:3:"346";i:3;s:3:"737";}}s:11:"ordfeminine";a:4:{s:1:"C";s:3:"227";s:2:"WX";s:3:"370";s:1:"N";s:11:"ordfeminine";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:3:"405";i:2;s:3:"346";i:3;s:3:"737";}}i:232;a:4:{s:1:"C";s:3:"232";s:2:"WX";s:3:"556";s:1:"N";s:6:"Lslash";s:1:"B";a:4:{i:0;s:3:"-20";i:1;s:1:"0";i:2;s:3:"537";i:3;s:3:"718";}}s:6:"Lslash";a:4:{s:1:"C";s:3:"232";s:2:"WX";s:3:"556";s:1:"N";s:6:"Lslash";s:1:"B";a:4:{i:0;s:3:"-20";i:1;s:1:"0";i:2;s:3:"537";i:3;s:3:"718";}}i:233;a:4:{s:1:"C";s:3:"233";s:2:"WX";s:3:"778";s:1:"N";s:6:"Oslash";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:3:"-19";i:2;s:3:"740";i:3;s:3:"737";}}s:6:"Oslash";a:4:{s:1:"C";s:3:"233";s:2:"WX";s:3:"778";s:1:"N";s:6:"Oslash";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:3:"-19";i:2;s:3:"740";i:3;s:3:"737";}}i:234;a:4:{s:1:"C";s:3:"234";s:2:"WX";s:4:"1000";s:1:"N";s:2:"OE";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:3:"-19";i:2;s:3:"965";i:3;s:3:"737";}}s:2:"OE";a:4:{s:1:"C";s:3:"234";s:2:"WX";s:4:"1000";s:1:"N";s:2:"OE";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:3:"-19";i:2;s:3:"965";i:3;s:3:"737";}}i:235;a:4:{s:1:"C";s:3:"235";s:2:"WX";s:3:"365";s:1:"N";s:12:"ordmasculine";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"405";i:2;s:3:"341";i:3;s:3:"737";}}s:12:"ordmasculine";a:4:{s:1:"C";s:3:"235";s:2:"WX";s:3:"365";s:1:"N";s:12:"ordmasculine";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"405";i:2;s:3:"341";i:3;s:3:"737";}}i:241;a:4:{s:1:"C";s:3:"241";s:2:"WX";s:3:"889";s:1:"N";s:2:"ae";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:3:"-15";i:2;s:3:"847";i:3;s:3:"538";}}s:2:"ae";a:4:{s:1:"C";s:3:"241";s:2:"WX";s:3:"889";s:1:"N";s:2:"ae";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:3:"-15";i:2;s:3:"847";i:3;s:3:"538";}}i:245;a:4:{s:1:"C";s:3:"245";s:2:"WX";s:3:"278";s:1:"N";s:8:"dotlessi";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:1:"0";i:2;s:3:"183";i:3;s:3:"523";}}s:8:"dotlessi";a:4:{s:1:"C";s:3:"245";s:2:"WX";s:3:"278";s:1:"N";s:8:"dotlessi";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:1:"0";i:2;s:3:"183";i:3;s:3:"523";}}i:248;a:4:{s:1:"C";s:3:"248";s:2:"WX";s:3:"222";s:1:"N";s:6:"lslash";s:1:"B";a:4:{i:0;s:3:"-20";i:1;s:1:"0";i:2;s:3:"242";i:3;s:3:"718";}}s:6:"lslash";a:4:{s:1:"C";s:3:"248";s:2:"WX";s:3:"222";s:1:"N";s:6:"lslash";s:1:"B";a:4:{i:0;s:3:"-20";i:1;s:1:"0";i:2;s:3:"242";i:3;s:3:"718";}}i:249;a:4:{s:1:"C";s:3:"249";s:2:"WX";s:3:"611";s:1:"N";s:6:"oslash";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:3:"-22";i:2;s:3:"537";i:3;s:3:"545";}}s:6:"oslash";a:4:{s:1:"C";s:3:"249";s:2:"WX";s:3:"611";s:1:"N";s:6:"oslash";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:3:"-22";i:2;s:3:"537";i:3;s:3:"545";}}i:250;a:4:{s:1:"C";s:3:"250";s:2:"WX";s:3:"944";s:1:"N";s:2:"oe";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-15";i:2;s:3:"902";i:3;s:3:"538";}}s:2:"oe";a:4:{s:1:"C";s:3:"250";s:2:"WX";s:3:"944";s:1:"N";s:2:"oe";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-15";i:2;s:3:"902";i:3;s:3:"538";}}i:251;a:4:{s:1:"C";s:3:"251";s:2:"WX";s:3:"611";s:1:"N";s:10:"germandbls";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:3:"-15";i:2;s:3:"571";i:3;s:3:"728";}}s:10:"germandbls";a:4:{s:1:"C";s:3:"251";s:2:"WX";s:3:"611";s:1:"N";s:10:"germandbls";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:3:"-15";i:2;s:3:"571";i:3;s:3:"728";}}s:9:"Idieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:9:"Idieresis";s:1:"B";a:4:{i:0;s:2:"13";i:1;s:1:"0";i:2;s:3:"266";i:3;s:3:"901";}}s:6:"eacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"eacute";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"-15";i:2;s:3:"516";i:3;s:3:"734";}}s:6:"abreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"abreve";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:3:"-15";i:2;s:3:"530";i:3;s:3:"731";}}s:13:"uhungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:13:"uhungarumlaut";s:1:"B";a:4:{i:0;s:2:"68";i:1;s:3:"-15";i:2;s:3:"521";i:3;s:3:"734";}}s:6:"ecaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"ecaron";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"-15";i:2;s:3:"516";i:3;s:3:"734";}}s:9:"Ydieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:9:"Ydieresis";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"653";i:3;s:3:"901";}}s:6:"divide";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"584";s:1:"N";s:6:"divide";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:3:"-19";i:2;s:3:"545";i:3;s:3:"524";}}s:6:"Yacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Yacute";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"653";i:3;s:3:"929";}}s:11:"Acircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:11:"Acircumflex";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"654";i:3;s:3:"929";}}s:6:"aacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"aacute";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:3:"-15";i:2;s:3:"530";i:3;s:3:"734";}}s:11:"Ucircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:11:"Ucircumflex";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:3:"-19";i:2;s:3:"644";i:3;s:3:"929";}}s:6:"yacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"yacute";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:4:"-214";i:2;s:3:"489";i:3;s:3:"734";}}s:12:"scommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:12:"scommaaccent";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:4:"-225";i:2;s:3:"464";i:3;s:3:"538";}}s:11:"ecircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:11:"ecircumflex";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"-15";i:2;s:3:"516";i:3;s:3:"734";}}s:5:"Uring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:5:"Uring";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:3:"-19";i:2;s:3:"644";i:3;s:3:"931";}}s:9:"Udieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:9:"Udieresis";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:3:"-19";i:2;s:3:"644";i:3;s:3:"901";}}s:7:"aogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:7:"aogonek";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:4:"-220";i:2;s:3:"547";i:3;s:3:"538";}}s:6:"Uacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Uacute";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:3:"-19";i:2;s:3:"644";i:3;s:3:"929";}}s:7:"uogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:7:"uogonek";s:1:"B";a:4:{i:0;s:2:"68";i:1;s:4:"-225";i:2;s:3:"519";i:3;s:3:"523";}}s:9:"Edieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:9:"Edieresis";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"616";i:3;s:3:"901";}}s:6:"Dcroat";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Dcroat";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:3:"674";i:3;s:3:"718";}}s:11:"commaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"250";s:1:"N";s:11:"commaaccent";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:4:"-225";i:2;s:3:"181";i:3;s:3:"-40";}}s:9:"copyright";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"737";s:1:"N";s:9:"copyright";s:1:"B";a:4:{i:0;s:3:"-14";i:1;s:3:"-19";i:2;s:3:"752";i:3;s:3:"737";}}s:7:"Emacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:7:"Emacron";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"616";i:3;s:3:"879";}}s:6:"ccaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"ccaron";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-15";i:2;s:3:"477";i:3;s:3:"734";}}s:5:"aring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:5:"aring";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:3:"-15";i:2;s:3:"530";i:3;s:3:"756";}}s:12:"Ncommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:12:"Ncommaaccent";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:4:"-225";i:2;s:3:"646";i:3;s:3:"718";}}s:6:"lacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"222";s:1:"N";s:6:"lacute";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:1:"0";i:2;s:3:"264";i:3;s:3:"929";}}s:6:"agrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"agrave";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:3:"-15";i:2;s:3:"530";i:3;s:3:"734";}}s:12:"Tcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:12:"Tcommaaccent";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:4:"-225";i:2;s:3:"597";i:3;s:3:"718";}}s:6:"Cacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Cacute";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-19";i:2;s:3:"681";i:3;s:3:"929";}}s:6:"atilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"atilde";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:3:"-15";i:2;s:3:"530";i:3;s:3:"722";}}s:10:"Edotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:10:"Edotaccent";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"616";i:3;s:3:"901";}}s:6:"scaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"scaron";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:3:"-15";i:2;s:3:"464";i:3;s:3:"734";}}s:8:"scedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:8:"scedilla";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:4:"-225";i:2;s:3:"464";i:3;s:3:"538";}}s:6:"iacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:6:"iacute";s:1:"B";a:4:{i:0;s:2:"95";i:1;s:1:"0";i:2;s:3:"292";i:3;s:3:"734";}}s:7:"lozenge";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"471";s:1:"N";s:7:"lozenge";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:1:"0";i:2;s:3:"462";i:3;s:3:"728";}}s:6:"Rcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Rcaron";s:1:"B";a:4:{i:0;s:2:"88";i:1;s:1:"0";i:2;s:3:"684";i:3;s:3:"929";}}s:12:"Gcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:12:"Gcommaaccent";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:4:"-225";i:2;s:3:"704";i:3;s:3:"737";}}s:11:"ucircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:11:"ucircumflex";s:1:"B";a:4:{i:0;s:2:"68";i:1;s:3:"-15";i:2;s:3:"489";i:3;s:3:"734";}}s:11:"acircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:11:"acircumflex";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:3:"-15";i:2;s:3:"530";i:3;s:3:"734";}}s:7:"Amacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:7:"Amacron";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"654";i:3;s:3:"879";}}s:6:"rcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"333";s:1:"N";s:6:"rcaron";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:1:"0";i:2;s:3:"352";i:3;s:3:"734";}}s:8:"ccedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:8:"ccedilla";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:4:"-225";i:2;s:3:"477";i:3;s:3:"538";}}s:10:"Zdotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:10:"Zdotaccent";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:1:"0";i:2;s:3:"588";i:3;s:3:"901";}}s:5:"Thorn";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:5:"Thorn";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"622";i:3;s:3:"718";}}s:7:"Omacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:7:"Omacron";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:3:"-19";i:2;s:3:"739";i:3;s:3:"879";}}s:6:"Racute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Racute";s:1:"B";a:4:{i:0;s:2:"88";i:1;s:1:"0";i:2;s:3:"684";i:3;s:3:"929";}}s:6:"Sacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Sacute";s:1:"B";a:4:{i:0;s:2:"49";i:1;s:3:"-19";i:2;s:3:"620";i:3;s:3:"929";}}s:6:"dcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"643";s:1:"N";s:6:"dcaron";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-15";i:2;s:3:"655";i:3;s:3:"718";}}s:7:"Umacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:7:"Umacron";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:3:"-19";i:2;s:3:"644";i:3;s:3:"879";}}s:5:"uring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:5:"uring";s:1:"B";a:4:{i:0;s:2:"68";i:1;s:3:"-15";i:2;s:3:"489";i:3;s:3:"756";}}s:13:"threesuperior";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"333";s:1:"N";s:13:"threesuperior";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:3:"270";i:2;s:3:"325";i:3;s:3:"703";}}s:6:"Ograve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:6:"Ograve";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:3:"-19";i:2;s:3:"739";i:3;s:3:"929";}}s:6:"Agrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Agrave";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"654";i:3;s:3:"929";}}s:6:"Abreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Abreve";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"654";i:3;s:3:"926";}}s:8:"multiply";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"584";s:1:"N";s:8:"multiply";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:1:"0";i:2;s:3:"545";i:3;s:3:"506";}}s:6:"uacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"uacute";s:1:"B";a:4:{i:0;s:2:"68";i:1;s:3:"-15";i:2;s:3:"489";i:3;s:3:"734";}}s:6:"Tcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"Tcaron";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"597";i:3;s:3:"929";}}s:11:"partialdiff";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"476";s:1:"N";s:11:"partialdiff";s:1:"B";a:4:{i:0;s:2:"13";i:1;s:3:"-38";i:2;s:3:"463";i:3;s:3:"714";}}s:9:"ydieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:9:"ydieresis";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:4:"-214";i:2;s:3:"489";i:3;s:3:"706";}}s:6:"Nacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Nacute";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"646";i:3;s:3:"929";}}s:11:"icircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:11:"icircumflex";s:1:"B";a:4:{i:0;s:2:"-6";i:1;s:1:"0";i:2;s:3:"285";i:3;s:3:"734";}}s:11:"Ecircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:11:"Ecircumflex";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"616";i:3;s:3:"929";}}s:9:"adieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:9:"adieresis";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:3:"-15";i:2;s:3:"530";i:3;s:3:"706";}}s:9:"edieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:9:"edieresis";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"-15";i:2;s:3:"516";i:3;s:3:"706";}}s:6:"cacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"cacute";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-15";i:2;s:3:"477";i:3;s:3:"734";}}s:6:"nacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"nacute";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:1:"0";i:2;s:3:"491";i:3;s:3:"734";}}s:7:"umacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:7:"umacron";s:1:"B";a:4:{i:0;s:2:"68";i:1;s:3:"-15";i:2;s:3:"489";i:3;s:3:"684";}}s:6:"Ncaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Ncaron";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"646";i:3;s:3:"929";}}s:6:"Iacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:6:"Iacute";s:1:"B";a:4:{i:0;s:2:"91";i:1;s:1:"0";i:2;s:3:"292";i:3;s:3:"929";}}s:9:"plusminus";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"584";s:1:"N";s:9:"plusminus";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:1:"0";i:2;s:3:"545";i:3;s:3:"506";}}s:9:"brokenbar";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"260";s:1:"N";s:9:"brokenbar";s:1:"B";a:4:{i:0;s:2:"94";i:1;s:4:"-150";i:2;s:3:"167";i:3;s:3:"700";}}s:10:"registered";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"737";s:1:"N";s:10:"registered";s:1:"B";a:4:{i:0;s:3:"-14";i:1;s:3:"-19";i:2;s:3:"752";i:3;s:3:"737";}}s:6:"Gbreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:6:"Gbreve";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:3:"-19";i:2;s:3:"704";i:3;s:3:"926";}}s:10:"Idotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:10:"Idotaccent";s:1:"B";a:4:{i:0;s:2:"91";i:1;s:1:"0";i:2;s:3:"188";i:3;s:3:"901";}}s:9:"summation";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"summation";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:3:"-10";i:2;s:3:"586";i:3;s:3:"706";}}s:6:"Egrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Egrave";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"616";i:3;s:3:"929";}}s:6:"racute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"333";s:1:"N";s:6:"racute";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:1:"0";i:2;s:3:"332";i:3;s:3:"734";}}s:7:"omacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:7:"omacron";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"521";i:3;s:3:"684";}}s:6:"Zacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"Zacute";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:1:"0";i:2;s:3:"588";i:3;s:3:"929";}}s:6:"Zcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"Zcaron";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:1:"0";i:2;s:3:"588";i:3;s:3:"929";}}s:12:"greaterequal";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"549";s:1:"N";s:12:"greaterequal";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"523";i:3;s:3:"674";}}s:3:"Eth";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:3:"Eth";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:3:"674";i:3;s:3:"718";}}s:8:"Ccedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:8:"Ccedilla";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:4:"-225";i:2;s:3:"681";i:3;s:3:"737";}}s:12:"lcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"222";s:1:"N";s:12:"lcommaaccent";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:4:"-225";i:2;s:3:"167";i:3;s:3:"718";}}s:6:"tcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"317";s:1:"N";s:6:"tcaron";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:2:"-7";i:2;s:3:"329";i:3;s:3:"808";}}s:7:"eogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:7:"eogonek";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:4:"-225";i:2;s:3:"516";i:3;s:3:"538";}}s:7:"Uogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:7:"Uogonek";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:4:"-225";i:2;s:3:"644";i:3;s:3:"718";}}s:6:"Aacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Aacute";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"654";i:3;s:3:"929";}}s:9:"Adieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:9:"Adieresis";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"654";i:3;s:3:"901";}}s:6:"egrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"egrave";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"-15";i:2;s:3:"516";i:3;s:3:"734";}}s:6:"zacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"zacute";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:1:"0";i:2;s:3:"469";i:3;s:3:"734";}}s:7:"iogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"222";s:1:"N";s:7:"iogonek";s:1:"B";a:4:{i:0;s:3:"-31";i:1;s:4:"-225";i:2;s:3:"183";i:3;s:3:"718";}}s:6:"Oacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:6:"Oacute";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:3:"-19";i:2;s:3:"739";i:3;s:3:"929";}}s:6:"oacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"oacute";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"521";i:3;s:3:"734";}}s:7:"amacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:7:"amacron";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:3:"-15";i:2;s:3:"530";i:3;s:3:"684";}}s:6:"sacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"sacute";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:3:"-15";i:2;s:3:"464";i:3;s:3:"734";}}s:9:"idieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:9:"idieresis";s:1:"B";a:4:{i:0;s:2:"13";i:1;s:1:"0";i:2;s:3:"266";i:3;s:3:"706";}}s:11:"Ocircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:11:"Ocircumflex";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:3:"-19";i:2;s:3:"739";i:3;s:3:"929";}}s:6:"Ugrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Ugrave";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:3:"-19";i:2;s:3:"644";i:3;s:3:"929";}}s:5:"Delta";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"612";s:1:"N";s:5:"Delta";s:1:"B";a:4:{i:0;s:1:"6";i:1;s:1:"0";i:2;s:3:"608";i:3;s:3:"688";}}s:5:"thorn";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:5:"thorn";s:1:"B";a:4:{i:0;s:2:"58";i:1;s:4:"-207";i:2;s:3:"517";i:3;s:3:"718";}}s:11:"twosuperior";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"333";s:1:"N";s:11:"twosuperior";s:1:"B";a:4:{i:0;s:1:"4";i:1;s:3:"281";i:2;s:3:"323";i:3;s:3:"703";}}s:9:"Odieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:9:"Odieresis";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:3:"-19";i:2;s:3:"739";i:3;s:3:"901";}}s:2:"mu";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:2:"mu";s:1:"B";a:4:{i:0;s:2:"68";i:1;s:4:"-207";i:2;s:3:"489";i:3;s:3:"523";}}s:6:"igrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:6:"igrave";s:1:"B";a:4:{i:0;s:3:"-13";i:1;s:1:"0";i:2;s:3:"184";i:3;s:3:"734";}}s:13:"ohungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:13:"ohungarumlaut";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"521";i:3;s:3:"734";}}s:7:"Eogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:7:"Eogonek";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:4:"-220";i:2;s:3:"633";i:3;s:3:"718";}}s:6:"dcroat";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"dcroat";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-15";i:2;s:3:"550";i:3;s:3:"718";}}s:13:"threequarters";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"834";s:1:"N";s:13:"threequarters";s:1:"B";a:4:{i:0;s:2:"45";i:1;s:3:"-19";i:2;s:3:"810";i:3;s:3:"703";}}s:8:"Scedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:8:"Scedilla";s:1:"B";a:4:{i:0;s:2:"49";i:1;s:4:"-225";i:2;s:3:"620";i:3;s:3:"737";}}s:6:"lcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"299";s:1:"N";s:6:"lcaron";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:1:"0";i:2;s:3:"311";i:3;s:3:"718";}}s:12:"Kcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:12:"Kcommaaccent";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:4:"-225";i:2;s:3:"663";i:3;s:3:"718";}}s:6:"Lacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"Lacute";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"537";i:3;s:3:"929";}}s:9:"trademark";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:4:"1000";s:1:"N";s:9:"trademark";s:1:"B";a:4:{i:0;s:2:"46";i:1;s:3:"306";i:2;s:3:"903";i:3;s:3:"718";}}s:10:"edotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:10:"edotaccent";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"-15";i:2;s:3:"516";i:3;s:3:"706";}}s:6:"Igrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:6:"Igrave";s:1:"B";a:4:{i:0;s:3:"-13";i:1;s:1:"0";i:2;s:3:"188";i:3;s:3:"929";}}s:7:"Imacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:7:"Imacron";s:1:"B";a:4:{i:0;s:3:"-17";i:1;s:1:"0";i:2;s:3:"296";i:3;s:3:"879";}}s:6:"Lcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"Lcaron";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"537";i:3;s:3:"718";}}s:7:"onehalf";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"834";s:1:"N";s:7:"onehalf";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:3:"-19";i:2;s:3:"773";i:3;s:3:"703";}}s:9:"lessequal";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"549";s:1:"N";s:9:"lessequal";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"523";i:3;s:3:"674";}}s:11:"ocircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:11:"ocircumflex";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"521";i:3;s:3:"734";}}s:6:"ntilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"ntilde";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:1:"0";i:2;s:3:"491";i:3;s:3:"722";}}s:13:"Uhungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:13:"Uhungarumlaut";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:3:"-19";i:2;s:3:"644";i:3;s:3:"929";}}s:6:"Eacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Eacute";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"616";i:3;s:3:"929";}}s:7:"emacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:7:"emacron";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"-15";i:2;s:3:"516";i:3;s:3:"684";}}s:6:"gbreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"gbreve";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:4:"-220";i:2;s:3:"499";i:3;s:3:"731";}}s:10:"onequarter";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"834";s:1:"N";s:10:"onequarter";s:1:"B";a:4:{i:0;s:2:"73";i:1;s:3:"-19";i:2;s:3:"756";i:3;s:3:"703";}}s:6:"Scaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Scaron";s:1:"B";a:4:{i:0;s:2:"49";i:1;s:3:"-19";i:2;s:3:"620";i:3;s:3:"929";}}s:12:"Scommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:12:"Scommaaccent";s:1:"B";a:4:{i:0;s:2:"49";i:1;s:4:"-225";i:2;s:3:"620";i:3;s:3:"737";}}s:13:"Ohungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:13:"Ohungarumlaut";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:3:"-19";i:2;s:3:"739";i:3;s:3:"929";}}s:6:"degree";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"400";s:1:"N";s:6:"degree";s:1:"B";a:4:{i:0;s:2:"54";i:1;s:3:"411";i:2;s:3:"346";i:3;s:3:"703";}}s:6:"ograve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"ograve";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"521";i:3;s:3:"734";}}s:6:"Ccaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Ccaron";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-19";i:2;s:3:"681";i:3;s:3:"929";}}s:6:"ugrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"ugrave";s:1:"B";a:4:{i:0;s:2:"68";i:1;s:3:"-15";i:2;s:3:"489";i:3;s:3:"734";}}s:7:"radical";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"453";s:1:"N";s:7:"radical";s:1:"B";a:4:{i:0;s:2:"-4";i:1;s:3:"-80";i:2;s:3:"458";i:3;s:3:"762";}}s:6:"Dcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Dcaron";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:1:"0";i:2;s:3:"674";i:3;s:3:"929";}}s:12:"rcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"333";s:1:"N";s:12:"rcommaaccent";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:4:"-225";i:2;s:3:"332";i:3;s:3:"538";}}s:6:"Ntilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Ntilde";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"646";i:3;s:3:"917";}}s:6:"otilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"otilde";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"521";i:3;s:3:"722";}}s:12:"Rcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:12:"Rcommaaccent";s:1:"B";a:4:{i:0;s:2:"88";i:1;s:4:"-225";i:2;s:3:"684";i:3;s:3:"718";}}s:12:"Lcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:12:"Lcommaaccent";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:4:"-225";i:2;s:3:"537";i:3;s:3:"718";}}s:6:"Atilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Atilde";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"654";i:3;s:3:"917";}}s:7:"Aogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:7:"Aogonek";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:4:"-225";i:2;s:3:"654";i:3;s:3:"718";}}s:5:"Aring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:5:"Aring";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"654";i:3;s:3:"931";}}s:6:"Otilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:6:"Otilde";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:3:"-19";i:2;s:3:"739";i:3;s:3:"917";}}s:10:"zdotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:10:"zdotaccent";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:1:"0";i:2;s:3:"469";i:3;s:3:"706";}}s:6:"Ecaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Ecaron";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"616";i:3;s:3:"929";}}s:7:"Iogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:7:"Iogonek";s:1:"B";a:4:{i:0;s:2:"-3";i:1;s:4:"-225";i:2;s:3:"211";i:3;s:3:"718";}}s:12:"kcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:12:"kcommaaccent";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:4:"-225";i:2;s:3:"501";i:3;s:3:"718";}}s:5:"minus";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"584";s:1:"N";s:5:"minus";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:3:"216";i:2;s:3:"545";i:3;s:3:"289";}}s:11:"Icircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:11:"Icircumflex";s:1:"B";a:4:{i:0;s:2:"-6";i:1;s:1:"0";i:2;s:3:"285";i:3;s:3:"929";}}s:6:"ncaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"ncaron";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:1:"0";i:2;s:3:"491";i:3;s:3:"734";}}s:12:"tcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:12:"tcommaaccent";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:4:"-225";i:2;s:3:"257";i:3;s:3:"669";}}s:10:"logicalnot";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"584";s:1:"N";s:10:"logicalnot";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:3:"108";i:2;s:3:"545";i:3;s:3:"390";}}s:9:"odieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:9:"odieresis";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"521";i:3;s:3:"706";}}s:9:"udieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:9:"udieresis";s:1:"B";a:4:{i:0;s:2:"68";i:1;s:3:"-15";i:2;s:3:"489";i:3;s:3:"706";}}s:8:"notequal";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"549";s:1:"N";s:8:"notequal";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:3:"-35";i:2;s:3:"537";i:3;s:3:"551";}}s:12:"gcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:12:"gcommaaccent";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:4:"-220";i:2;s:3:"499";i:3;s:3:"822";}}s:3:"eth";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:3:"eth";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-15";i:2;s:3:"522";i:3;s:3:"737";}}s:6:"zcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"zcaron";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:1:"0";i:2;s:3:"469";i:3;s:3:"734";}}s:12:"ncommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:12:"ncommaaccent";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:4:"-225";i:2;s:3:"491";i:3;s:3:"538";}}s:11:"onesuperior";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"333";s:1:"N";s:11:"onesuperior";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:3:"281";i:2;s:3:"222";i:3;s:3:"703";}}s:7:"imacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:7:"imacron";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:1:"0";i:2;s:3:"272";i:3;s:3:"684";}}s:4:"Euro";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:4:"Euro";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}}s:3:"KPX";a:138:{s:1:"A";a:48:{s:1:"C";s:3:"-30";s:6:"Cacute";s:3:"-30";s:6:"Ccaron";s:3:"-30";s:8:"Ccedilla";s:3:"-30";s:1:"G";s:3:"-30";s:6:"Gbreve";s:3:"-30";s:12:"Gcommaaccent";s:3:"-30";s:1:"O";s:3:"-30";s:6:"Oacute";s:3:"-30";s:11:"Ocircumflex";s:3:"-30";s:9:"Odieresis";s:3:"-30";s:6:"Ograve";s:3:"-30";s:13:"Ohungarumlaut";s:3:"-30";s:7:"Omacron";s:3:"-30";s:6:"Oslash";s:3:"-30";s:6:"Otilde";s:3:"-30";s:1:"Q";s:3:"-30";s:1:"T";s:4:"-120";s:6:"Tcaron";s:4:"-120";s:12:"Tcommaaccent";s:4:"-120";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-70";s:1:"W";s:3:"-50";s:1:"Y";s:4:"-100";s:6:"Yacute";s:4:"-100";s:9:"Ydieresis";s:4:"-100";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-40";s:1:"w";s:3:"-40";s:1:"y";s:3:"-40";s:6:"yacute";s:3:"-40";s:9:"ydieresis";s:3:"-40";}s:6:"Aacute";a:48:{s:1:"C";s:3:"-30";s:6:"Cacute";s:3:"-30";s:6:"Ccaron";s:3:"-30";s:8:"Ccedilla";s:3:"-30";s:1:"G";s:3:"-30";s:6:"Gbreve";s:3:"-30";s:12:"Gcommaaccent";s:3:"-30";s:1:"O";s:3:"-30";s:6:"Oacute";s:3:"-30";s:11:"Ocircumflex";s:3:"-30";s:9:"Odieresis";s:3:"-30";s:6:"Ograve";s:3:"-30";s:13:"Ohungarumlaut";s:3:"-30";s:7:"Omacron";s:3:"-30";s:6:"Oslash";s:3:"-30";s:6:"Otilde";s:3:"-30";s:1:"Q";s:3:"-30";s:1:"T";s:4:"-120";s:6:"Tcaron";s:4:"-120";s:12:"Tcommaaccent";s:4:"-120";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-70";s:1:"W";s:3:"-50";s:1:"Y";s:4:"-100";s:6:"Yacute";s:4:"-100";s:9:"Ydieresis";s:4:"-100";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-40";s:1:"w";s:3:"-40";s:1:"y";s:3:"-40";s:6:"yacute";s:3:"-40";s:9:"ydieresis";s:3:"-40";}s:6:"Abreve";a:48:{s:1:"C";s:3:"-30";s:6:"Cacute";s:3:"-30";s:6:"Ccaron";s:3:"-30";s:8:"Ccedilla";s:3:"-30";s:1:"G";s:3:"-30";s:6:"Gbreve";s:3:"-30";s:12:"Gcommaaccent";s:3:"-30";s:1:"O";s:3:"-30";s:6:"Oacute";s:3:"-30";s:11:"Ocircumflex";s:3:"-30";s:9:"Odieresis";s:3:"-30";s:6:"Ograve";s:3:"-30";s:13:"Ohungarumlaut";s:3:"-30";s:7:"Omacron";s:3:"-30";s:6:"Oslash";s:3:"-30";s:6:"Otilde";s:3:"-30";s:1:"Q";s:3:"-30";s:1:"T";s:4:"-120";s:6:"Tcaron";s:4:"-120";s:12:"Tcommaaccent";s:4:"-120";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-70";s:1:"W";s:3:"-50";s:1:"Y";s:4:"-100";s:6:"Yacute";s:4:"-100";s:9:"Ydieresis";s:4:"-100";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-40";s:1:"w";s:3:"-40";s:1:"y";s:3:"-40";s:6:"yacute";s:3:"-40";s:9:"ydieresis";s:3:"-40";}s:11:"Acircumflex";a:48:{s:1:"C";s:3:"-30";s:6:"Cacute";s:3:"-30";s:6:"Ccaron";s:3:"-30";s:8:"Ccedilla";s:3:"-30";s:1:"G";s:3:"-30";s:6:"Gbreve";s:3:"-30";s:12:"Gcommaaccent";s:3:"-30";s:1:"O";s:3:"-30";s:6:"Oacute";s:3:"-30";s:11:"Ocircumflex";s:3:"-30";s:9:"Odieresis";s:3:"-30";s:6:"Ograve";s:3:"-30";s:13:"Ohungarumlaut";s:3:"-30";s:7:"Omacron";s:3:"-30";s:6:"Oslash";s:3:"-30";s:6:"Otilde";s:3:"-30";s:1:"Q";s:3:"-30";s:1:"T";s:4:"-120";s:6:"Tcaron";s:4:"-120";s:12:"Tcommaaccent";s:4:"-120";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-70";s:1:"W";s:3:"-50";s:1:"Y";s:4:"-100";s:6:"Yacute";s:4:"-100";s:9:"Ydieresis";s:4:"-100";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-40";s:1:"w";s:3:"-40";s:1:"y";s:3:"-40";s:6:"yacute";s:3:"-40";s:9:"ydieresis";s:3:"-40";}s:9:"Adieresis";a:48:{s:1:"C";s:3:"-30";s:6:"Cacute";s:3:"-30";s:6:"Ccaron";s:3:"-30";s:8:"Ccedilla";s:3:"-30";s:1:"G";s:3:"-30";s:6:"Gbreve";s:3:"-30";s:12:"Gcommaaccent";s:3:"-30";s:1:"O";s:3:"-30";s:6:"Oacute";s:3:"-30";s:11:"Ocircumflex";s:3:"-30";s:9:"Odieresis";s:3:"-30";s:6:"Ograve";s:3:"-30";s:13:"Ohungarumlaut";s:3:"-30";s:7:"Omacron";s:3:"-30";s:6:"Oslash";s:3:"-30";s:6:"Otilde";s:3:"-30";s:1:"Q";s:3:"-30";s:1:"T";s:4:"-120";s:6:"Tcaron";s:4:"-120";s:12:"Tcommaaccent";s:4:"-120";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-70";s:1:"W";s:3:"-50";s:1:"Y";s:4:"-100";s:6:"Yacute";s:4:"-100";s:9:"Ydieresis";s:4:"-100";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-40";s:1:"w";s:3:"-40";s:1:"y";s:3:"-40";s:6:"yacute";s:3:"-40";s:9:"ydieresis";s:3:"-40";}s:6:"Agrave";a:48:{s:1:"C";s:3:"-30";s:6:"Cacute";s:3:"-30";s:6:"Ccaron";s:3:"-30";s:8:"Ccedilla";s:3:"-30";s:1:"G";s:3:"-30";s:6:"Gbreve";s:3:"-30";s:12:"Gcommaaccent";s:3:"-30";s:1:"O";s:3:"-30";s:6:"Oacute";s:3:"-30";s:11:"Ocircumflex";s:3:"-30";s:9:"Odieresis";s:3:"-30";s:6:"Ograve";s:3:"-30";s:13:"Ohungarumlaut";s:3:"-30";s:7:"Omacron";s:3:"-30";s:6:"Oslash";s:3:"-30";s:6:"Otilde";s:3:"-30";s:1:"Q";s:3:"-30";s:1:"T";s:4:"-120";s:6:"Tcaron";s:4:"-120";s:12:"Tcommaaccent";s:4:"-120";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-70";s:1:"W";s:3:"-50";s:1:"Y";s:4:"-100";s:6:"Yacute";s:4:"-100";s:9:"Ydieresis";s:4:"-100";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-40";s:1:"w";s:3:"-40";s:1:"y";s:3:"-40";s:6:"yacute";s:3:"-40";s:9:"ydieresis";s:3:"-40";}s:7:"Amacron";a:48:{s:1:"C";s:3:"-30";s:6:"Cacute";s:3:"-30";s:6:"Ccaron";s:3:"-30";s:8:"Ccedilla";s:3:"-30";s:1:"G";s:3:"-30";s:6:"Gbreve";s:3:"-30";s:12:"Gcommaaccent";s:3:"-30";s:1:"O";s:3:"-30";s:6:"Oacute";s:3:"-30";s:11:"Ocircumflex";s:3:"-30";s:9:"Odieresis";s:3:"-30";s:6:"Ograve";s:3:"-30";s:13:"Ohungarumlaut";s:3:"-30";s:7:"Omacron";s:3:"-30";s:6:"Oslash";s:3:"-30";s:6:"Otilde";s:3:"-30";s:1:"Q";s:3:"-30";s:1:"T";s:4:"-120";s:6:"Tcaron";s:4:"-120";s:12:"Tcommaaccent";s:4:"-120";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-70";s:1:"W";s:3:"-50";s:1:"Y";s:4:"-100";s:6:"Yacute";s:4:"-100";s:9:"Ydieresis";s:4:"-100";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-40";s:1:"w";s:3:"-40";s:1:"y";s:3:"-40";s:6:"yacute";s:3:"-40";s:9:"ydieresis";s:3:"-40";}s:7:"Aogonek";a:48:{s:1:"C";s:3:"-30";s:6:"Cacute";s:3:"-30";s:6:"Ccaron";s:3:"-30";s:8:"Ccedilla";s:3:"-30";s:1:"G";s:3:"-30";s:6:"Gbreve";s:3:"-30";s:12:"Gcommaaccent";s:3:"-30";s:1:"O";s:3:"-30";s:6:"Oacute";s:3:"-30";s:11:"Ocircumflex";s:3:"-30";s:9:"Odieresis";s:3:"-30";s:6:"Ograve";s:3:"-30";s:13:"Ohungarumlaut";s:3:"-30";s:7:"Omacron";s:3:"-30";s:6:"Oslash";s:3:"-30";s:6:"Otilde";s:3:"-30";s:1:"Q";s:3:"-30";s:1:"T";s:4:"-120";s:6:"Tcaron";s:4:"-120";s:12:"Tcommaaccent";s:4:"-120";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-70";s:1:"W";s:3:"-50";s:1:"Y";s:4:"-100";s:6:"Yacute";s:4:"-100";s:9:"Ydieresis";s:4:"-100";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-40";s:1:"w";s:3:"-40";s:1:"y";s:3:"-40";s:6:"yacute";s:3:"-40";s:9:"ydieresis";s:3:"-40";}s:5:"Aring";a:48:{s:1:"C";s:3:"-30";s:6:"Cacute";s:3:"-30";s:6:"Ccaron";s:3:"-30";s:8:"Ccedilla";s:3:"-30";s:1:"G";s:3:"-30";s:6:"Gbreve";s:3:"-30";s:12:"Gcommaaccent";s:3:"-30";s:1:"O";s:3:"-30";s:6:"Oacute";s:3:"-30";s:11:"Ocircumflex";s:3:"-30";s:9:"Odieresis";s:3:"-30";s:6:"Ograve";s:3:"-30";s:13:"Ohungarumlaut";s:3:"-30";s:7:"Omacron";s:3:"-30";s:6:"Oslash";s:3:"-30";s:6:"Otilde";s:3:"-30";s:1:"Q";s:3:"-30";s:1:"T";s:4:"-120";s:6:"Tcaron";s:4:"-120";s:12:"Tcommaaccent";s:4:"-120";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-70";s:1:"W";s:3:"-50";s:1:"Y";s:4:"-100";s:6:"Yacute";s:4:"-100";s:9:"Ydieresis";s:4:"-100";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-40";s:1:"w";s:3:"-40";s:1:"y";s:3:"-40";s:6:"yacute";s:3:"-40";s:9:"ydieresis";s:3:"-40";}s:6:"Atilde";a:48:{s:1:"C";s:3:"-30";s:6:"Cacute";s:3:"-30";s:6:"Ccaron";s:3:"-30";s:8:"Ccedilla";s:3:"-30";s:1:"G";s:3:"-30";s:6:"Gbreve";s:3:"-30";s:12:"Gcommaaccent";s:3:"-30";s:1:"O";s:3:"-30";s:6:"Oacute";s:3:"-30";s:11:"Ocircumflex";s:3:"-30";s:9:"Odieresis";s:3:"-30";s:6:"Ograve";s:3:"-30";s:13:"Ohungarumlaut";s:3:"-30";s:7:"Omacron";s:3:"-30";s:6:"Oslash";s:3:"-30";s:6:"Otilde";s:3:"-30";s:1:"Q";s:3:"-30";s:1:"T";s:4:"-120";s:6:"Tcaron";s:4:"-120";s:12:"Tcommaaccent";s:4:"-120";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-70";s:1:"W";s:3:"-50";s:1:"Y";s:4:"-100";s:6:"Yacute";s:4:"-100";s:9:"Ydieresis";s:4:"-100";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-40";s:1:"w";s:3:"-40";s:1:"y";s:3:"-40";s:6:"yacute";s:3:"-40";s:9:"ydieresis";s:3:"-40";}s:1:"B";a:11:{s:1:"U";s:3:"-10";s:6:"Uacute";s:3:"-10";s:11:"Ucircumflex";s:3:"-10";s:9:"Udieresis";s:3:"-10";s:6:"Ugrave";s:3:"-10";s:13:"Uhungarumlaut";s:3:"-10";s:7:"Umacron";s:3:"-10";s:7:"Uogonek";s:3:"-10";s:5:"Uring";s:3:"-10";s:5:"comma";s:3:"-20";s:6:"period";s:3:"-20";}s:1:"C";a:2:{s:5:"comma";s:3:"-30";s:6:"period";s:3:"-30";}s:6:"Cacute";a:2:{s:5:"comma";s:3:"-30";s:6:"period";s:3:"-30";}s:6:"Ccaron";a:2:{s:5:"comma";s:3:"-30";s:6:"period";s:3:"-30";}s:8:"Ccedilla";a:2:{s:5:"comma";s:3:"-30";s:6:"period";s:3:"-30";}s:1:"D";a:17:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:1:"V";s:3:"-70";s:1:"W";s:3:"-40";s:1:"Y";s:3:"-90";s:6:"Yacute";s:3:"-90";s:9:"Ydieresis";s:3:"-90";s:5:"comma";s:3:"-70";s:6:"period";s:3:"-70";}s:6:"Dcaron";a:17:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:1:"V";s:3:"-70";s:1:"W";s:3:"-40";s:1:"Y";s:3:"-90";s:6:"Yacute";s:3:"-90";s:9:"Ydieresis";s:3:"-90";s:5:"comma";s:3:"-70";s:6:"period";s:3:"-70";}s:6:"Dcroat";a:17:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:1:"V";s:3:"-70";s:1:"W";s:3:"-40";s:1:"Y";s:3:"-90";s:6:"Yacute";s:3:"-90";s:9:"Ydieresis";s:3:"-90";s:5:"comma";s:3:"-70";s:6:"period";s:3:"-70";}s:1:"F";a:44:{s:1:"A";s:3:"-80";s:6:"Aacute";s:3:"-80";s:6:"Abreve";s:3:"-80";s:11:"Acircumflex";s:3:"-80";s:9:"Adieresis";s:3:"-80";s:6:"Agrave";s:3:"-80";s:7:"Amacron";s:3:"-80";s:7:"Aogonek";s:3:"-80";s:5:"Aring";s:3:"-80";s:6:"Atilde";s:3:"-80";s:1:"a";s:3:"-50";s:6:"aacute";s:3:"-50";s:6:"abreve";s:3:"-50";s:11:"acircumflex";s:3:"-50";s:9:"adieresis";s:3:"-50";s:6:"agrave";s:3:"-50";s:7:"amacron";s:3:"-50";s:7:"aogonek";s:3:"-50";s:5:"aring";s:3:"-50";s:6:"atilde";s:3:"-50";s:5:"comma";s:4:"-150";s:1:"e";s:3:"-30";s:6:"eacute";s:3:"-30";s:6:"ecaron";s:3:"-30";s:11:"ecircumflex";s:3:"-30";s:9:"edieresis";s:3:"-30";s:10:"edotaccent";s:3:"-30";s:6:"egrave";s:3:"-30";s:7:"emacron";s:3:"-30";s:7:"eogonek";s:3:"-30";s:1:"o";s:3:"-30";s:6:"oacute";s:3:"-30";s:11:"ocircumflex";s:3:"-30";s:9:"odieresis";s:3:"-30";s:6:"ograve";s:3:"-30";s:13:"ohungarumlaut";s:3:"-30";s:7:"omacron";s:3:"-30";s:6:"oslash";s:3:"-30";s:6:"otilde";s:3:"-30";s:6:"period";s:4:"-150";s:1:"r";s:3:"-45";s:6:"racute";s:3:"-45";s:6:"rcaron";s:3:"-45";s:12:"rcommaaccent";s:3:"-45";}s:1:"J";a:31:{s:1:"A";s:3:"-20";s:6:"Aacute";s:3:"-20";s:6:"Abreve";s:3:"-20";s:11:"Acircumflex";s:3:"-20";s:9:"Adieresis";s:3:"-20";s:6:"Agrave";s:3:"-20";s:7:"Amacron";s:3:"-20";s:7:"Aogonek";s:3:"-20";s:5:"Aring";s:3:"-20";s:6:"Atilde";s:3:"-20";s:1:"a";s:3:"-20";s:6:"aacute";s:3:"-20";s:6:"abreve";s:3:"-20";s:11:"acircumflex";s:3:"-20";s:9:"adieresis";s:3:"-20";s:6:"agrave";s:3:"-20";s:7:"amacron";s:3:"-20";s:7:"aogonek";s:3:"-20";s:5:"aring";s:3:"-20";s:6:"atilde";s:3:"-20";s:5:"comma";s:3:"-30";s:6:"period";s:3:"-30";s:1:"u";s:3:"-20";s:6:"uacute";s:3:"-20";s:11:"ucircumflex";s:3:"-20";s:9:"udieresis";s:3:"-20";s:6:"ugrave";s:3:"-20";s:13:"uhungarumlaut";s:3:"-20";s:7:"umacron";s:3:"-20";s:7:"uogonek";s:3:"-20";s:5:"uring";s:3:"-20";}s:1:"K";a:39:{s:1:"O";s:3:"-50";s:6:"Oacute";s:3:"-50";s:11:"Ocircumflex";s:3:"-50";s:9:"Odieresis";s:3:"-50";s:6:"Ograve";s:3:"-50";s:13:"Ohungarumlaut";s:3:"-50";s:7:"Omacron";s:3:"-50";s:6:"Oslash";s:3:"-50";s:6:"Otilde";s:3:"-50";s:1:"e";s:3:"-40";s:6:"eacute";s:3:"-40";s:6:"ecaron";s:3:"-40";s:11:"ecircumflex";s:3:"-40";s:9:"edieresis";s:3:"-40";s:10:"edotaccent";s:3:"-40";s:6:"egrave";s:3:"-40";s:7:"emacron";s:3:"-40";s:7:"eogonek";s:3:"-40";s:1:"o";s:3:"-40";s:6:"oacute";s:3:"-40";s:11:"ocircumflex";s:3:"-40";s:9:"odieresis";s:3:"-40";s:6:"ograve";s:3:"-40";s:13:"ohungarumlaut";s:3:"-40";s:7:"omacron";s:3:"-40";s:6:"oslash";s:3:"-40";s:6:"otilde";s:3:"-40";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"y";s:3:"-50";s:6:"yacute";s:3:"-50";s:9:"ydieresis";s:3:"-50";}s:12:"Kcommaaccent";a:39:{s:1:"O";s:3:"-50";s:6:"Oacute";s:3:"-50";s:11:"Ocircumflex";s:3:"-50";s:9:"Odieresis";s:3:"-50";s:6:"Ograve";s:3:"-50";s:13:"Ohungarumlaut";s:3:"-50";s:7:"Omacron";s:3:"-50";s:6:"Oslash";s:3:"-50";s:6:"Otilde";s:3:"-50";s:1:"e";s:3:"-40";s:6:"eacute";s:3:"-40";s:6:"ecaron";s:3:"-40";s:11:"ecircumflex";s:3:"-40";s:9:"edieresis";s:3:"-40";s:10:"edotaccent";s:3:"-40";s:6:"egrave";s:3:"-40";s:7:"emacron";s:3:"-40";s:7:"eogonek";s:3:"-40";s:1:"o";s:3:"-40";s:6:"oacute";s:3:"-40";s:11:"ocircumflex";s:3:"-40";s:9:"odieresis";s:3:"-40";s:6:"ograve";s:3:"-40";s:13:"ohungarumlaut";s:3:"-40";s:7:"omacron";s:3:"-40";s:6:"oslash";s:3:"-40";s:6:"otilde";s:3:"-40";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"y";s:3:"-50";s:6:"yacute";s:3:"-50";s:9:"ydieresis";s:3:"-50";}s:1:"L";a:13:{s:1:"T";s:4:"-110";s:6:"Tcaron";s:4:"-110";s:12:"Tcommaaccent";s:4:"-110";s:1:"V";s:4:"-110";s:1:"W";s:3:"-70";s:1:"Y";s:4:"-140";s:6:"Yacute";s:4:"-140";s:9:"Ydieresis";s:4:"-140";s:13:"quotedblright";s:4:"-140";s:10:"quoteright";s:4:"-160";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:6:"Lacute";a:13:{s:1:"T";s:4:"-110";s:6:"Tcaron";s:4:"-110";s:12:"Tcommaaccent";s:4:"-110";s:1:"V";s:4:"-110";s:1:"W";s:3:"-70";s:1:"Y";s:4:"-140";s:6:"Yacute";s:4:"-140";s:9:"Ydieresis";s:4:"-140";s:13:"quotedblright";s:4:"-140";s:10:"quoteright";s:4:"-160";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:6:"Lcaron";a:13:{s:1:"T";s:4:"-110";s:6:"Tcaron";s:4:"-110";s:12:"Tcommaaccent";s:4:"-110";s:1:"V";s:4:"-110";s:1:"W";s:3:"-70";s:1:"Y";s:4:"-140";s:6:"Yacute";s:4:"-140";s:9:"Ydieresis";s:4:"-140";s:13:"quotedblright";s:4:"-140";s:10:"quoteright";s:4:"-160";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:12:"Lcommaaccent";a:13:{s:1:"T";s:4:"-110";s:6:"Tcaron";s:4:"-110";s:12:"Tcommaaccent";s:4:"-110";s:1:"V";s:4:"-110";s:1:"W";s:3:"-70";s:1:"Y";s:4:"-140";s:6:"Yacute";s:4:"-140";s:9:"Ydieresis";s:4:"-140";s:13:"quotedblright";s:4:"-140";s:10:"quoteright";s:4:"-160";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:6:"Lslash";a:13:{s:1:"T";s:4:"-110";s:6:"Tcaron";s:4:"-110";s:12:"Tcommaaccent";s:4:"-110";s:1:"V";s:4:"-110";s:1:"W";s:3:"-70";s:1:"Y";s:4:"-140";s:6:"Yacute";s:4:"-140";s:9:"Ydieresis";s:4:"-140";s:13:"quotedblright";s:4:"-140";s:10:"quoteright";s:4:"-160";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:1:"O";a:21:{s:1:"A";s:3:"-20";s:6:"Aacute";s:3:"-20";s:6:"Abreve";s:3:"-20";s:11:"Acircumflex";s:3:"-20";s:9:"Adieresis";s:3:"-20";s:6:"Agrave";s:3:"-20";s:7:"Amacron";s:3:"-20";s:7:"Aogonek";s:3:"-20";s:5:"Aring";s:3:"-20";s:6:"Atilde";s:3:"-20";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-30";s:1:"X";s:3:"-60";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:6:"Oacute";a:21:{s:1:"A";s:3:"-20";s:6:"Aacute";s:3:"-20";s:6:"Abreve";s:3:"-20";s:11:"Acircumflex";s:3:"-20";s:9:"Adieresis";s:3:"-20";s:6:"Agrave";s:3:"-20";s:7:"Amacron";s:3:"-20";s:7:"Aogonek";s:3:"-20";s:5:"Aring";s:3:"-20";s:6:"Atilde";s:3:"-20";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-30";s:1:"X";s:3:"-60";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:11:"Ocircumflex";a:21:{s:1:"A";s:3:"-20";s:6:"Aacute";s:3:"-20";s:6:"Abreve";s:3:"-20";s:11:"Acircumflex";s:3:"-20";s:9:"Adieresis";s:3:"-20";s:6:"Agrave";s:3:"-20";s:7:"Amacron";s:3:"-20";s:7:"Aogonek";s:3:"-20";s:5:"Aring";s:3:"-20";s:6:"Atilde";s:3:"-20";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-30";s:1:"X";s:3:"-60";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:9:"Odieresis";a:21:{s:1:"A";s:3:"-20";s:6:"Aacute";s:3:"-20";s:6:"Abreve";s:3:"-20";s:11:"Acircumflex";s:3:"-20";s:9:"Adieresis";s:3:"-20";s:6:"Agrave";s:3:"-20";s:7:"Amacron";s:3:"-20";s:7:"Aogonek";s:3:"-20";s:5:"Aring";s:3:"-20";s:6:"Atilde";s:3:"-20";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-30";s:1:"X";s:3:"-60";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:6:"Ograve";a:21:{s:1:"A";s:3:"-20";s:6:"Aacute";s:3:"-20";s:6:"Abreve";s:3:"-20";s:11:"Acircumflex";s:3:"-20";s:9:"Adieresis";s:3:"-20";s:6:"Agrave";s:3:"-20";s:7:"Amacron";s:3:"-20";s:7:"Aogonek";s:3:"-20";s:5:"Aring";s:3:"-20";s:6:"Atilde";s:3:"-20";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-30";s:1:"X";s:3:"-60";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:13:"Ohungarumlaut";a:21:{s:1:"A";s:3:"-20";s:6:"Aacute";s:3:"-20";s:6:"Abreve";s:3:"-20";s:11:"Acircumflex";s:3:"-20";s:9:"Adieresis";s:3:"-20";s:6:"Agrave";s:3:"-20";s:7:"Amacron";s:3:"-20";s:7:"Aogonek";s:3:"-20";s:5:"Aring";s:3:"-20";s:6:"Atilde";s:3:"-20";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-30";s:1:"X";s:3:"-60";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:7:"Omacron";a:21:{s:1:"A";s:3:"-20";s:6:"Aacute";s:3:"-20";s:6:"Abreve";s:3:"-20";s:11:"Acircumflex";s:3:"-20";s:9:"Adieresis";s:3:"-20";s:6:"Agrave";s:3:"-20";s:7:"Amacron";s:3:"-20";s:7:"Aogonek";s:3:"-20";s:5:"Aring";s:3:"-20";s:6:"Atilde";s:3:"-20";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-30";s:1:"X";s:3:"-60";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:6:"Oslash";a:21:{s:1:"A";s:3:"-20";s:6:"Aacute";s:3:"-20";s:6:"Abreve";s:3:"-20";s:11:"Acircumflex";s:3:"-20";s:9:"Adieresis";s:3:"-20";s:6:"Agrave";s:3:"-20";s:7:"Amacron";s:3:"-20";s:7:"Aogonek";s:3:"-20";s:5:"Aring";s:3:"-20";s:6:"Atilde";s:3:"-20";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-30";s:1:"X";s:3:"-60";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:6:"Otilde";a:21:{s:1:"A";s:3:"-20";s:6:"Aacute";s:3:"-20";s:6:"Abreve";s:3:"-20";s:11:"Acircumflex";s:3:"-20";s:9:"Adieresis";s:3:"-20";s:6:"Agrave";s:3:"-20";s:7:"Amacron";s:3:"-20";s:7:"Aogonek";s:3:"-20";s:5:"Aring";s:3:"-20";s:6:"Atilde";s:3:"-20";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-30";s:1:"X";s:3:"-60";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:1:"P";a:40:{s:1:"A";s:4:"-120";s:6:"Aacute";s:4:"-120";s:6:"Abreve";s:4:"-120";s:11:"Acircumflex";s:4:"-120";s:9:"Adieresis";s:4:"-120";s:6:"Agrave";s:4:"-120";s:7:"Amacron";s:4:"-120";s:7:"Aogonek";s:4:"-120";s:5:"Aring";s:4:"-120";s:6:"Atilde";s:4:"-120";s:1:"a";s:3:"-40";s:6:"aacute";s:3:"-40";s:6:"abreve";s:3:"-40";s:11:"acircumflex";s:3:"-40";s:9:"adieresis";s:3:"-40";s:6:"agrave";s:3:"-40";s:7:"amacron";s:3:"-40";s:7:"aogonek";s:3:"-40";s:5:"aring";s:3:"-40";s:6:"atilde";s:3:"-40";s:5:"comma";s:4:"-180";s:1:"e";s:3:"-50";s:6:"eacute";s:3:"-50";s:6:"ecaron";s:3:"-50";s:11:"ecircumflex";s:3:"-50";s:9:"edieresis";s:3:"-50";s:10:"edotaccent";s:3:"-50";s:6:"egrave";s:3:"-50";s:7:"emacron";s:3:"-50";s:7:"eogonek";s:3:"-50";s:1:"o";s:3:"-50";s:6:"oacute";s:3:"-50";s:11:"ocircumflex";s:3:"-50";s:9:"odieresis";s:3:"-50";s:6:"ograve";s:3:"-50";s:13:"ohungarumlaut";s:3:"-50";s:7:"omacron";s:3:"-50";s:6:"oslash";s:3:"-50";s:6:"otilde";s:3:"-50";s:6:"period";s:4:"-180";}s:1:"Q";a:9:{s:1:"U";s:3:"-10";s:6:"Uacute";s:3:"-10";s:11:"Ucircumflex";s:3:"-10";s:9:"Udieresis";s:3:"-10";s:6:"Ugrave";s:3:"-10";s:13:"Uhungarumlaut";s:3:"-10";s:7:"Umacron";s:3:"-10";s:7:"Uogonek";s:3:"-10";s:5:"Uring";s:3:"-10";}s:1:"R";a:26:{s:1:"O";s:3:"-20";s:6:"Oacute";s:3:"-20";s:11:"Ocircumflex";s:3:"-20";s:9:"Odieresis";s:3:"-20";s:6:"Ograve";s:3:"-20";s:13:"Ohungarumlaut";s:3:"-20";s:7:"Omacron";s:3:"-20";s:6:"Oslash";s:3:"-20";s:6:"Otilde";s:3:"-20";s:1:"T";s:3:"-30";s:6:"Tcaron";s:3:"-30";s:12:"Tcommaaccent";s:3:"-30";s:1:"U";s:3:"-40";s:6:"Uacute";s:3:"-40";s:11:"Ucircumflex";s:3:"-40";s:9:"Udieresis";s:3:"-40";s:6:"Ugrave";s:3:"-40";s:13:"Uhungarumlaut";s:3:"-40";s:7:"Umacron";s:3:"-40";s:7:"Uogonek";s:3:"-40";s:5:"Uring";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-30";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:6:"Racute";a:26:{s:1:"O";s:3:"-20";s:6:"Oacute";s:3:"-20";s:11:"Ocircumflex";s:3:"-20";s:9:"Odieresis";s:3:"-20";s:6:"Ograve";s:3:"-20";s:13:"Ohungarumlaut";s:3:"-20";s:7:"Omacron";s:3:"-20";s:6:"Oslash";s:3:"-20";s:6:"Otilde";s:3:"-20";s:1:"T";s:3:"-30";s:6:"Tcaron";s:3:"-30";s:12:"Tcommaaccent";s:3:"-30";s:1:"U";s:3:"-40";s:6:"Uacute";s:3:"-40";s:11:"Ucircumflex";s:3:"-40";s:9:"Udieresis";s:3:"-40";s:6:"Ugrave";s:3:"-40";s:13:"Uhungarumlaut";s:3:"-40";s:7:"Umacron";s:3:"-40";s:7:"Uogonek";s:3:"-40";s:5:"Uring";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-30";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:6:"Rcaron";a:26:{s:1:"O";s:3:"-20";s:6:"Oacute";s:3:"-20";s:11:"Ocircumflex";s:3:"-20";s:9:"Odieresis";s:3:"-20";s:6:"Ograve";s:3:"-20";s:13:"Ohungarumlaut";s:3:"-20";s:7:"Omacron";s:3:"-20";s:6:"Oslash";s:3:"-20";s:6:"Otilde";s:3:"-20";s:1:"T";s:3:"-30";s:6:"Tcaron";s:3:"-30";s:12:"Tcommaaccent";s:3:"-30";s:1:"U";s:3:"-40";s:6:"Uacute";s:3:"-40";s:11:"Ucircumflex";s:3:"-40";s:9:"Udieresis";s:3:"-40";s:6:"Ugrave";s:3:"-40";s:13:"Uhungarumlaut";s:3:"-40";s:7:"Umacron";s:3:"-40";s:7:"Uogonek";s:3:"-40";s:5:"Uring";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-30";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:12:"Rcommaaccent";a:26:{s:1:"O";s:3:"-20";s:6:"Oacute";s:3:"-20";s:11:"Ocircumflex";s:3:"-20";s:9:"Odieresis";s:3:"-20";s:6:"Ograve";s:3:"-20";s:13:"Ohungarumlaut";s:3:"-20";s:7:"Omacron";s:3:"-20";s:6:"Oslash";s:3:"-20";s:6:"Otilde";s:3:"-20";s:1:"T";s:3:"-30";s:6:"Tcaron";s:3:"-30";s:12:"Tcommaaccent";s:3:"-30";s:1:"U";s:3:"-40";s:6:"Uacute";s:3:"-40";s:11:"Ucircumflex";s:3:"-40";s:9:"Udieresis";s:3:"-40";s:6:"Ugrave";s:3:"-40";s:13:"Uhungarumlaut";s:3:"-40";s:7:"Umacron";s:3:"-40";s:7:"Uogonek";s:3:"-40";s:5:"Uring";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-30";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:1:"S";a:2:{s:5:"comma";s:3:"-20";s:6:"period";s:3:"-20";}s:6:"Sacute";a:2:{s:5:"comma";s:3:"-20";s:6:"period";s:3:"-20";}s:6:"Scaron";a:2:{s:5:"comma";s:3:"-20";s:6:"period";s:3:"-20";}s:8:"Scedilla";a:2:{s:5:"comma";s:3:"-20";s:6:"period";s:3:"-20";}s:12:"Scommaaccent";a:2:{s:5:"comma";s:3:"-20";s:6:"period";s:3:"-20";}s:1:"T";a:69:{s:1:"A";s:4:"-120";s:6:"Aacute";s:4:"-120";s:6:"Abreve";s:4:"-120";s:11:"Acircumflex";s:4:"-120";s:9:"Adieresis";s:4:"-120";s:6:"Agrave";s:4:"-120";s:7:"Amacron";s:4:"-120";s:7:"Aogonek";s:4:"-120";s:5:"Aring";s:4:"-120";s:6:"Atilde";s:4:"-120";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"a";s:4:"-120";s:6:"aacute";s:4:"-120";s:6:"abreve";s:3:"-60";s:11:"acircumflex";s:4:"-120";s:9:"adieresis";s:4:"-120";s:6:"agrave";s:4:"-120";s:7:"amacron";s:3:"-60";s:7:"aogonek";s:4:"-120";s:5:"aring";s:4:"-120";s:6:"atilde";s:3:"-60";s:5:"colon";s:3:"-20";s:5:"comma";s:4:"-120";s:1:"e";s:4:"-120";s:6:"eacute";s:4:"-120";s:6:"ecaron";s:4:"-120";s:11:"ecircumflex";s:4:"-120";s:9:"edieresis";s:4:"-120";s:10:"edotaccent";s:4:"-120";s:6:"egrave";s:3:"-60";s:7:"emacron";s:3:"-60";s:7:"eogonek";s:4:"-120";s:6:"hyphen";s:4:"-140";s:1:"o";s:4:"-120";s:6:"oacute";s:4:"-120";s:11:"ocircumflex";s:4:"-120";s:9:"odieresis";s:4:"-120";s:6:"ograve";s:4:"-120";s:13:"ohungarumlaut";s:4:"-120";s:7:"omacron";s:3:"-60";s:6:"oslash";s:4:"-120";s:6:"otilde";s:3:"-60";s:6:"period";s:4:"-120";s:1:"r";s:4:"-120";s:6:"racute";s:4:"-120";s:6:"rcaron";s:4:"-120";s:12:"rcommaaccent";s:4:"-120";s:9:"semicolon";s:3:"-20";s:1:"u";s:4:"-120";s:6:"uacute";s:4:"-120";s:11:"ucircumflex";s:4:"-120";s:9:"udieresis";s:4:"-120";s:6:"ugrave";s:4:"-120";s:13:"uhungarumlaut";s:4:"-120";s:7:"umacron";s:3:"-60";s:7:"uogonek";s:4:"-120";s:5:"uring";s:4:"-120";s:1:"w";s:4:"-120";s:1:"y";s:4:"-120";s:6:"yacute";s:4:"-120";s:9:"ydieresis";s:3:"-60";}s:6:"Tcaron";a:69:{s:1:"A";s:4:"-120";s:6:"Aacute";s:4:"-120";s:6:"Abreve";s:4:"-120";s:11:"Acircumflex";s:4:"-120";s:9:"Adieresis";s:4:"-120";s:6:"Agrave";s:4:"-120";s:7:"Amacron";s:4:"-120";s:7:"Aogonek";s:4:"-120";s:5:"Aring";s:4:"-120";s:6:"Atilde";s:4:"-120";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"a";s:4:"-120";s:6:"aacute";s:4:"-120";s:6:"abreve";s:3:"-60";s:11:"acircumflex";s:4:"-120";s:9:"adieresis";s:4:"-120";s:6:"agrave";s:4:"-120";s:7:"amacron";s:3:"-60";s:7:"aogonek";s:4:"-120";s:5:"aring";s:4:"-120";s:6:"atilde";s:3:"-60";s:5:"colon";s:3:"-20";s:5:"comma";s:4:"-120";s:1:"e";s:4:"-120";s:6:"eacute";s:4:"-120";s:6:"ecaron";s:4:"-120";s:11:"ecircumflex";s:4:"-120";s:9:"edieresis";s:4:"-120";s:10:"edotaccent";s:4:"-120";s:6:"egrave";s:3:"-60";s:7:"emacron";s:3:"-60";s:7:"eogonek";s:4:"-120";s:6:"hyphen";s:4:"-140";s:1:"o";s:4:"-120";s:6:"oacute";s:4:"-120";s:11:"ocircumflex";s:4:"-120";s:9:"odieresis";s:4:"-120";s:6:"ograve";s:4:"-120";s:13:"ohungarumlaut";s:4:"-120";s:7:"omacron";s:3:"-60";s:6:"oslash";s:4:"-120";s:6:"otilde";s:3:"-60";s:6:"period";s:4:"-120";s:1:"r";s:4:"-120";s:6:"racute";s:4:"-120";s:6:"rcaron";s:4:"-120";s:12:"rcommaaccent";s:4:"-120";s:9:"semicolon";s:3:"-20";s:1:"u";s:4:"-120";s:6:"uacute";s:4:"-120";s:11:"ucircumflex";s:4:"-120";s:9:"udieresis";s:4:"-120";s:6:"ugrave";s:4:"-120";s:13:"uhungarumlaut";s:4:"-120";s:7:"umacron";s:3:"-60";s:7:"uogonek";s:4:"-120";s:5:"uring";s:4:"-120";s:1:"w";s:4:"-120";s:1:"y";s:4:"-120";s:6:"yacute";s:4:"-120";s:9:"ydieresis";s:3:"-60";}s:12:"Tcommaaccent";a:69:{s:1:"A";s:4:"-120";s:6:"Aacute";s:4:"-120";s:6:"Abreve";s:4:"-120";s:11:"Acircumflex";s:4:"-120";s:9:"Adieresis";s:4:"-120";s:6:"Agrave";s:4:"-120";s:7:"Amacron";s:4:"-120";s:7:"Aogonek";s:4:"-120";s:5:"Aring";s:4:"-120";s:6:"Atilde";s:4:"-120";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"a";s:4:"-120";s:6:"aacute";s:4:"-120";s:6:"abreve";s:3:"-60";s:11:"acircumflex";s:4:"-120";s:9:"adieresis";s:4:"-120";s:6:"agrave";s:4:"-120";s:7:"amacron";s:3:"-60";s:7:"aogonek";s:4:"-120";s:5:"aring";s:4:"-120";s:6:"atilde";s:3:"-60";s:5:"colon";s:3:"-20";s:5:"comma";s:4:"-120";s:1:"e";s:4:"-120";s:6:"eacute";s:4:"-120";s:6:"ecaron";s:4:"-120";s:11:"ecircumflex";s:4:"-120";s:9:"edieresis";s:4:"-120";s:10:"edotaccent";s:4:"-120";s:6:"egrave";s:3:"-60";s:7:"emacron";s:3:"-60";s:7:"eogonek";s:4:"-120";s:6:"hyphen";s:4:"-140";s:1:"o";s:4:"-120";s:6:"oacute";s:4:"-120";s:11:"ocircumflex";s:4:"-120";s:9:"odieresis";s:4:"-120";s:6:"ograve";s:4:"-120";s:13:"ohungarumlaut";s:4:"-120";s:7:"omacron";s:3:"-60";s:6:"oslash";s:4:"-120";s:6:"otilde";s:3:"-60";s:6:"period";s:4:"-120";s:1:"r";s:4:"-120";s:6:"racute";s:4:"-120";s:6:"rcaron";s:4:"-120";s:12:"rcommaaccent";s:4:"-120";s:9:"semicolon";s:3:"-20";s:1:"u";s:4:"-120";s:6:"uacute";s:4:"-120";s:11:"ucircumflex";s:4:"-120";s:9:"udieresis";s:4:"-120";s:6:"ugrave";s:4:"-120";s:13:"uhungarumlaut";s:4:"-120";s:7:"umacron";s:3:"-60";s:7:"uogonek";s:4:"-120";s:5:"uring";s:4:"-120";s:1:"w";s:4:"-120";s:1:"y";s:4:"-120";s:6:"yacute";s:4:"-120";s:9:"ydieresis";s:3:"-60";}s:1:"U";a:12:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:6:"Uacute";a:12:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:11:"Ucircumflex";a:12:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:9:"Udieresis";a:12:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:6:"Ugrave";a:12:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:13:"Uhungarumlaut";a:12:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:7:"Umacron";a:12:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:7:"Uogonek";a:12:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:5:"Uring";a:12:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";}s:1:"V";a:64:{s:1:"A";s:3:"-80";s:6:"Aacute";s:3:"-80";s:6:"Abreve";s:3:"-80";s:11:"Acircumflex";s:3:"-80";s:9:"Adieresis";s:3:"-80";s:6:"Agrave";s:3:"-80";s:7:"Amacron";s:3:"-80";s:7:"Aogonek";s:3:"-80";s:5:"Aring";s:3:"-80";s:6:"Atilde";s:3:"-80";s:1:"G";s:3:"-40";s:6:"Gbreve";s:3:"-40";s:12:"Gcommaaccent";s:3:"-40";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"a";s:3:"-70";s:6:"aacute";s:3:"-70";s:6:"abreve";s:3:"-70";s:11:"acircumflex";s:3:"-70";s:9:"adieresis";s:3:"-70";s:6:"agrave";s:3:"-70";s:7:"amacron";s:3:"-70";s:7:"aogonek";s:3:"-70";s:5:"aring";s:3:"-70";s:6:"atilde";s:3:"-70";s:5:"colon";s:3:"-40";s:5:"comma";s:4:"-125";s:1:"e";s:3:"-80";s:6:"eacute";s:3:"-80";s:6:"ecaron";s:3:"-80";s:11:"ecircumflex";s:3:"-80";s:9:"edieresis";s:3:"-80";s:10:"edotaccent";s:3:"-80";s:6:"egrave";s:3:"-80";s:7:"emacron";s:3:"-80";s:7:"eogonek";s:3:"-80";s:6:"hyphen";s:3:"-80";s:1:"o";s:3:"-80";s:6:"oacute";s:3:"-80";s:11:"ocircumflex";s:3:"-80";s:9:"odieresis";s:3:"-80";s:6:"ograve";s:3:"-80";s:13:"ohungarumlaut";s:3:"-80";s:7:"omacron";s:3:"-80";s:6:"oslash";s:3:"-80";s:6:"otilde";s:3:"-80";s:6:"period";s:4:"-125";s:9:"semicolon";s:3:"-40";s:1:"u";s:3:"-70";s:6:"uacute";s:3:"-70";s:11:"ucircumflex";s:3:"-70";s:9:"udieresis";s:3:"-70";s:6:"ugrave";s:3:"-70";s:13:"uhungarumlaut";s:3:"-70";s:7:"umacron";s:3:"-70";s:7:"uogonek";s:3:"-70";s:5:"uring";s:3:"-70";}s:1:"W";a:62:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:1:"O";s:3:"-20";s:6:"Oacute";s:3:"-20";s:11:"Ocircumflex";s:3:"-20";s:9:"Odieresis";s:3:"-20";s:6:"Ograve";s:3:"-20";s:13:"Ohungarumlaut";s:3:"-20";s:7:"Omacron";s:3:"-20";s:6:"Oslash";s:3:"-20";s:6:"Otilde";s:3:"-20";s:1:"a";s:3:"-40";s:6:"aacute";s:3:"-40";s:6:"abreve";s:3:"-40";s:11:"acircumflex";s:3:"-40";s:9:"adieresis";s:3:"-40";s:6:"agrave";s:3:"-40";s:7:"amacron";s:3:"-40";s:7:"aogonek";s:3:"-40";s:5:"aring";s:3:"-40";s:6:"atilde";s:3:"-40";s:5:"comma";s:3:"-80";s:1:"e";s:3:"-30";s:6:"eacute";s:3:"-30";s:6:"ecaron";s:3:"-30";s:11:"ecircumflex";s:3:"-30";s:9:"edieresis";s:3:"-30";s:10:"edotaccent";s:3:"-30";s:6:"egrave";s:3:"-30";s:7:"emacron";s:3:"-30";s:7:"eogonek";s:3:"-30";s:6:"hyphen";s:3:"-40";s:1:"o";s:3:"-30";s:6:"oacute";s:3:"-30";s:11:"ocircumflex";s:3:"-30";s:9:"odieresis";s:3:"-30";s:6:"ograve";s:3:"-30";s:13:"ohungarumlaut";s:3:"-30";s:7:"omacron";s:3:"-30";s:6:"oslash";s:3:"-30";s:6:"otilde";s:3:"-30";s:6:"period";s:3:"-80";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:1:"Y";a:64:{s:1:"A";s:4:"-110";s:6:"Aacute";s:4:"-110";s:6:"Abreve";s:4:"-110";s:11:"Acircumflex";s:4:"-110";s:9:"Adieresis";s:4:"-110";s:6:"Agrave";s:4:"-110";s:7:"Amacron";s:4:"-110";s:7:"Aogonek";s:4:"-110";s:5:"Aring";s:4:"-110";s:6:"Atilde";s:4:"-110";s:1:"O";s:3:"-85";s:6:"Oacute";s:3:"-85";s:11:"Ocircumflex";s:3:"-85";s:9:"Odieresis";s:3:"-85";s:6:"Ograve";s:3:"-85";s:13:"Ohungarumlaut";s:3:"-85";s:7:"Omacron";s:3:"-85";s:6:"Oslash";s:3:"-85";s:6:"Otilde";s:3:"-85";s:1:"a";s:4:"-140";s:6:"aacute";s:4:"-140";s:6:"abreve";s:3:"-70";s:11:"acircumflex";s:4:"-140";s:9:"adieresis";s:4:"-140";s:6:"agrave";s:4:"-140";s:7:"amacron";s:3:"-70";s:7:"aogonek";s:4:"-140";s:5:"aring";s:4:"-140";s:6:"atilde";s:4:"-140";s:5:"colon";s:3:"-60";s:5:"comma";s:4:"-140";s:1:"e";s:4:"-140";s:6:"eacute";s:4:"-140";s:6:"ecaron";s:4:"-140";s:11:"ecircumflex";s:4:"-140";s:9:"edieresis";s:4:"-140";s:10:"edotaccent";s:4:"-140";s:6:"egrave";s:4:"-140";s:7:"emacron";s:3:"-70";s:7:"eogonek";s:4:"-140";s:6:"hyphen";s:4:"-140";s:1:"i";s:3:"-20";s:6:"iacute";s:3:"-20";s:7:"iogonek";s:3:"-20";s:1:"o";s:4:"-140";s:6:"oacute";s:4:"-140";s:11:"ocircumflex";s:4:"-140";s:9:"odieresis";s:4:"-140";s:6:"ograve";s:4:"-140";s:13:"ohungarumlaut";s:4:"-140";s:7:"omacron";s:4:"-140";s:6:"oslash";s:4:"-140";s:6:"otilde";s:4:"-140";s:6:"period";s:4:"-140";s:9:"semicolon";s:3:"-60";s:1:"u";s:4:"-110";s:6:"uacute";s:4:"-110";s:11:"ucircumflex";s:4:"-110";s:9:"udieresis";s:4:"-110";s:6:"ugrave";s:4:"-110";s:13:"uhungarumlaut";s:4:"-110";s:7:"umacron";s:4:"-110";s:7:"uogonek";s:4:"-110";s:5:"uring";s:4:"-110";}s:6:"Yacute";a:64:{s:1:"A";s:4:"-110";s:6:"Aacute";s:4:"-110";s:6:"Abreve";s:4:"-110";s:11:"Acircumflex";s:4:"-110";s:9:"Adieresis";s:4:"-110";s:6:"Agrave";s:4:"-110";s:7:"Amacron";s:4:"-110";s:7:"Aogonek";s:4:"-110";s:5:"Aring";s:4:"-110";s:6:"Atilde";s:4:"-110";s:1:"O";s:3:"-85";s:6:"Oacute";s:3:"-85";s:11:"Ocircumflex";s:3:"-85";s:9:"Odieresis";s:3:"-85";s:6:"Ograve";s:3:"-85";s:13:"Ohungarumlaut";s:3:"-85";s:7:"Omacron";s:3:"-85";s:6:"Oslash";s:3:"-85";s:6:"Otilde";s:3:"-85";s:1:"a";s:4:"-140";s:6:"aacute";s:4:"-140";s:6:"abreve";s:3:"-70";s:11:"acircumflex";s:4:"-140";s:9:"adieresis";s:4:"-140";s:6:"agrave";s:4:"-140";s:7:"amacron";s:3:"-70";s:7:"aogonek";s:4:"-140";s:5:"aring";s:4:"-140";s:6:"atilde";s:3:"-70";s:5:"colon";s:3:"-60";s:5:"comma";s:4:"-140";s:1:"e";s:4:"-140";s:6:"eacute";s:4:"-140";s:6:"ecaron";s:4:"-140";s:11:"ecircumflex";s:4:"-140";s:9:"edieresis";s:4:"-140";s:10:"edotaccent";s:4:"-140";s:6:"egrave";s:4:"-140";s:7:"emacron";s:3:"-70";s:7:"eogonek";s:4:"-140";s:6:"hyphen";s:4:"-140";s:1:"i";s:3:"-20";s:6:"iacute";s:3:"-20";s:7:"iogonek";s:3:"-20";s:1:"o";s:4:"-140";s:6:"oacute";s:4:"-140";s:11:"ocircumflex";s:4:"-140";s:9:"odieresis";s:4:"-140";s:6:"ograve";s:4:"-140";s:13:"ohungarumlaut";s:4:"-140";s:7:"omacron";s:3:"-70";s:6:"oslash";s:4:"-140";s:6:"otilde";s:4:"-140";s:6:"period";s:4:"-140";s:9:"semicolon";s:3:"-60";s:1:"u";s:4:"-110";s:6:"uacute";s:4:"-110";s:11:"ucircumflex";s:4:"-110";s:9:"udieresis";s:4:"-110";s:6:"ugrave";s:4:"-110";s:13:"uhungarumlaut";s:4:"-110";s:7:"umacron";s:4:"-110";s:7:"uogonek";s:4:"-110";s:5:"uring";s:4:"-110";}s:9:"Ydieresis";a:64:{s:1:"A";s:4:"-110";s:6:"Aacute";s:4:"-110";s:6:"Abreve";s:4:"-110";s:11:"Acircumflex";s:4:"-110";s:9:"Adieresis";s:4:"-110";s:6:"Agrave";s:4:"-110";s:7:"Amacron";s:4:"-110";s:7:"Aogonek";s:4:"-110";s:5:"Aring";s:4:"-110";s:6:"Atilde";s:4:"-110";s:1:"O";s:3:"-85";s:6:"Oacute";s:3:"-85";s:11:"Ocircumflex";s:3:"-85";s:9:"Odieresis";s:3:"-85";s:6:"Ograve";s:3:"-85";s:13:"Ohungarumlaut";s:3:"-85";s:7:"Omacron";s:3:"-85";s:6:"Oslash";s:3:"-85";s:6:"Otilde";s:3:"-85";s:1:"a";s:4:"-140";s:6:"aacute";s:4:"-140";s:6:"abreve";s:3:"-70";s:11:"acircumflex";s:4:"-140";s:9:"adieresis";s:4:"-140";s:6:"agrave";s:4:"-140";s:7:"amacron";s:3:"-70";s:7:"aogonek";s:4:"-140";s:5:"aring";s:4:"-140";s:6:"atilde";s:3:"-70";s:5:"colon";s:3:"-60";s:5:"comma";s:4:"-140";s:1:"e";s:4:"-140";s:6:"eacute";s:4:"-140";s:6:"ecaron";s:4:"-140";s:11:"ecircumflex";s:4:"-140";s:9:"edieresis";s:4:"-140";s:10:"edotaccent";s:4:"-140";s:6:"egrave";s:4:"-140";s:7:"emacron";s:3:"-70";s:7:"eogonek";s:4:"-140";s:6:"hyphen";s:4:"-140";s:1:"i";s:3:"-20";s:6:"iacute";s:3:"-20";s:7:"iogonek";s:3:"-20";s:1:"o";s:4:"-140";s:6:"oacute";s:4:"-140";s:11:"ocircumflex";s:4:"-140";s:9:"odieresis";s:4:"-140";s:6:"ograve";s:4:"-140";s:13:"ohungarumlaut";s:4:"-140";s:7:"omacron";s:4:"-140";s:6:"oslash";s:4:"-140";s:6:"otilde";s:4:"-140";s:6:"period";s:4:"-140";s:9:"semicolon";s:3:"-60";s:1:"u";s:4:"-110";s:6:"uacute";s:4:"-110";s:11:"ucircumflex";s:4:"-110";s:9:"udieresis";s:4:"-110";s:6:"ugrave";s:4:"-110";s:13:"uhungarumlaut";s:4:"-110";s:7:"umacron";s:4:"-110";s:7:"uogonek";s:4:"-110";s:5:"uring";s:4:"-110";}s:1:"a";a:5:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-20";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:6:"aacute";a:5:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-20";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:6:"abreve";a:5:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-20";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:11:"acircumflex";a:5:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-20";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:9:"adieresis";a:5:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-20";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:6:"agrave";a:5:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-20";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:7:"amacron";a:5:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-20";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:7:"aogonek";a:5:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-20";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:5:"aring";a:5:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-20";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:6:"atilde";a:5:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-20";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:1:"b";a:20:{s:1:"b";s:3:"-10";s:5:"comma";s:3:"-40";s:1:"l";s:3:"-20";s:6:"lacute";s:3:"-20";s:12:"lcommaaccent";s:3:"-20";s:6:"lslash";s:3:"-20";s:6:"period";s:3:"-40";s:1:"u";s:3:"-20";s:6:"uacute";s:3:"-20";s:11:"ucircumflex";s:3:"-20";s:9:"udieresis";s:3:"-20";s:6:"ugrave";s:3:"-20";s:13:"uhungarumlaut";s:3:"-20";s:7:"umacron";s:3:"-20";s:7:"uogonek";s:3:"-20";s:5:"uring";s:3:"-20";s:1:"v";s:3:"-20";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:1:"c";a:3:{s:5:"comma";s:3:"-15";s:1:"k";s:3:"-20";s:12:"kcommaaccent";s:3:"-20";}s:6:"cacute";a:3:{s:5:"comma";s:3:"-15";s:1:"k";s:3:"-20";s:12:"kcommaaccent";s:3:"-20";}s:6:"ccaron";a:3:{s:5:"comma";s:3:"-15";s:1:"k";s:3:"-20";s:12:"kcommaaccent";s:3:"-20";}s:8:"ccedilla";a:3:{s:5:"comma";s:3:"-15";s:1:"k";s:3:"-20";s:12:"kcommaaccent";s:3:"-20";}s:5:"colon";a:1:{s:5:"space";s:3:"-50";}s:5:"comma";a:2:{s:13:"quotedblright";s:4:"-100";s:10:"quoteright";s:4:"-100";}s:1:"e";a:8:{s:5:"comma";s:3:"-15";s:6:"period";s:3:"-15";s:1:"v";s:3:"-30";s:1:"w";s:3:"-20";s:1:"x";s:3:"-30";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:6:"eacute";a:8:{s:5:"comma";s:3:"-15";s:6:"period";s:3:"-15";s:1:"v";s:3:"-30";s:1:"w";s:3:"-20";s:1:"x";s:3:"-30";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:6:"ecaron";a:8:{s:5:"comma";s:3:"-15";s:6:"period";s:3:"-15";s:1:"v";s:3:"-30";s:1:"w";s:3:"-20";s:1:"x";s:3:"-30";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:11:"ecircumflex";a:8:{s:5:"comma";s:3:"-15";s:6:"period";s:3:"-15";s:1:"v";s:3:"-30";s:1:"w";s:3:"-20";s:1:"x";s:3:"-30";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:9:"edieresis";a:8:{s:5:"comma";s:3:"-15";s:6:"period";s:3:"-15";s:1:"v";s:3:"-30";s:1:"w";s:3:"-20";s:1:"x";s:3:"-30";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:10:"edotaccent";a:8:{s:5:"comma";s:3:"-15";s:6:"period";s:3:"-15";s:1:"v";s:3:"-30";s:1:"w";s:3:"-20";s:1:"x";s:3:"-30";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:6:"egrave";a:8:{s:5:"comma";s:3:"-15";s:6:"period";s:3:"-15";s:1:"v";s:3:"-30";s:1:"w";s:3:"-20";s:1:"x";s:3:"-30";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:7:"emacron";a:8:{s:5:"comma";s:3:"-15";s:6:"period";s:3:"-15";s:1:"v";s:3:"-30";s:1:"w";s:3:"-20";s:1:"x";s:3:"-30";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:7:"eogonek";a:8:{s:5:"comma";s:3:"-15";s:6:"period";s:3:"-15";s:1:"v";s:3:"-30";s:1:"w";s:3:"-20";s:1:"x";s:3:"-30";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:1:"f";a:33:{s:1:"a";s:3:"-30";s:6:"aacute";s:3:"-30";s:6:"abreve";s:3:"-30";s:11:"acircumflex";s:3:"-30";s:9:"adieresis";s:3:"-30";s:6:"agrave";s:3:"-30";s:7:"amacron";s:3:"-30";s:7:"aogonek";s:3:"-30";s:5:"aring";s:3:"-30";s:6:"atilde";s:3:"-30";s:5:"comma";s:3:"-30";s:8:"dotlessi";s:3:"-28";s:1:"e";s:3:"-30";s:6:"eacute";s:3:"-30";s:6:"ecaron";s:3:"-30";s:11:"ecircumflex";s:3:"-30";s:9:"edieresis";s:3:"-30";s:10:"edotaccent";s:3:"-30";s:6:"egrave";s:3:"-30";s:7:"emacron";s:3:"-30";s:7:"eogonek";s:3:"-30";s:1:"o";s:3:"-30";s:6:"oacute";s:3:"-30";s:11:"ocircumflex";s:3:"-30";s:9:"odieresis";s:3:"-30";s:6:"ograve";s:3:"-30";s:13:"ohungarumlaut";s:3:"-30";s:7:"omacron";s:3:"-30";s:6:"oslash";s:3:"-30";s:6:"otilde";s:3:"-30";s:6:"period";s:3:"-30";s:13:"quotedblright";s:2:"60";s:10:"quoteright";s:2:"50";}s:1:"g";a:4:{s:1:"r";s:3:"-10";s:6:"racute";s:3:"-10";s:6:"rcaron";s:3:"-10";s:12:"rcommaaccent";s:3:"-10";}s:6:"gbreve";a:4:{s:1:"r";s:3:"-10";s:6:"racute";s:3:"-10";s:6:"rcaron";s:3:"-10";s:12:"rcommaaccent";s:3:"-10";}s:12:"gcommaaccent";a:4:{s:1:"r";s:3:"-10";s:6:"racute";s:3:"-10";s:6:"rcaron";s:3:"-10";s:12:"rcommaaccent";s:3:"-10";}s:1:"h";a:3:{s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:1:"k";a:18:{s:1:"e";s:3:"-20";s:6:"eacute";s:3:"-20";s:6:"ecaron";s:3:"-20";s:11:"ecircumflex";s:3:"-20";s:9:"edieresis";s:3:"-20";s:10:"edotaccent";s:3:"-20";s:6:"egrave";s:3:"-20";s:7:"emacron";s:3:"-20";s:7:"eogonek";s:3:"-20";s:1:"o";s:3:"-20";s:6:"oacute";s:3:"-20";s:11:"ocircumflex";s:3:"-20";s:9:"odieresis";s:3:"-20";s:6:"ograve";s:3:"-20";s:13:"ohungarumlaut";s:3:"-20";s:7:"omacron";s:3:"-20";s:6:"oslash";s:3:"-20";s:6:"otilde";s:3:"-20";}s:12:"kcommaaccent";a:18:{s:1:"e";s:3:"-20";s:6:"eacute";s:3:"-20";s:6:"ecaron";s:3:"-20";s:11:"ecircumflex";s:3:"-20";s:9:"edieresis";s:3:"-20";s:10:"edotaccent";s:3:"-20";s:6:"egrave";s:3:"-20";s:7:"emacron";s:3:"-20";s:7:"eogonek";s:3:"-20";s:1:"o";s:3:"-20";s:6:"oacute";s:3:"-20";s:11:"ocircumflex";s:3:"-20";s:9:"odieresis";s:3:"-20";s:6:"ograve";s:3:"-20";s:13:"ohungarumlaut";s:3:"-20";s:7:"omacron";s:3:"-20";s:6:"oslash";s:3:"-20";s:6:"otilde";s:3:"-20";}s:1:"m";a:12:{s:1:"u";s:3:"-10";s:6:"uacute";s:3:"-10";s:11:"ucircumflex";s:3:"-10";s:9:"udieresis";s:3:"-10";s:6:"ugrave";s:3:"-10";s:13:"uhungarumlaut";s:3:"-10";s:7:"umacron";s:3:"-10";s:7:"uogonek";s:3:"-10";s:5:"uring";s:3:"-10";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:1:"n";a:13:{s:1:"u";s:3:"-10";s:6:"uacute";s:3:"-10";s:11:"ucircumflex";s:3:"-10";s:9:"udieresis";s:3:"-10";s:6:"ugrave";s:3:"-10";s:13:"uhungarumlaut";s:3:"-10";s:7:"umacron";s:3:"-10";s:7:"uogonek";s:3:"-10";s:5:"uring";s:3:"-10";s:1:"v";s:3:"-20";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:6:"nacute";a:13:{s:1:"u";s:3:"-10";s:6:"uacute";s:3:"-10";s:11:"ucircumflex";s:3:"-10";s:9:"udieresis";s:3:"-10";s:6:"ugrave";s:3:"-10";s:13:"uhungarumlaut";s:3:"-10";s:7:"umacron";s:3:"-10";s:7:"uogonek";s:3:"-10";s:5:"uring";s:3:"-10";s:1:"v";s:3:"-20";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:6:"ncaron";a:13:{s:1:"u";s:3:"-10";s:6:"uacute";s:3:"-10";s:11:"ucircumflex";s:3:"-10";s:9:"udieresis";s:3:"-10";s:6:"ugrave";s:3:"-10";s:13:"uhungarumlaut";s:3:"-10";s:7:"umacron";s:3:"-10";s:7:"uogonek";s:3:"-10";s:5:"uring";s:3:"-10";s:1:"v";s:3:"-20";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:12:"ncommaaccent";a:13:{s:1:"u";s:3:"-10";s:6:"uacute";s:3:"-10";s:11:"ucircumflex";s:3:"-10";s:9:"udieresis";s:3:"-10";s:6:"ugrave";s:3:"-10";s:13:"uhungarumlaut";s:3:"-10";s:7:"umacron";s:3:"-10";s:7:"uogonek";s:3:"-10";s:5:"uring";s:3:"-10";s:1:"v";s:3:"-20";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:6:"ntilde";a:13:{s:1:"u";s:3:"-10";s:6:"uacute";s:3:"-10";s:11:"ucircumflex";s:3:"-10";s:9:"udieresis";s:3:"-10";s:6:"ugrave";s:3:"-10";s:13:"uhungarumlaut";s:3:"-10";s:7:"umacron";s:3:"-10";s:7:"uogonek";s:3:"-10";s:5:"uring";s:3:"-10";s:1:"v";s:3:"-20";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:1:"o";a:8:{s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-30";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:6:"oacute";a:8:{s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-30";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:11:"ocircumflex";a:8:{s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-30";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:9:"odieresis";a:8:{s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-30";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:6:"ograve";a:8:{s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-30";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:13:"ohungarumlaut";a:8:{s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-30";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:7:"omacron";a:8:{s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-30";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:6:"oslash";a:94:{s:1:"a";s:3:"-55";s:6:"aacute";s:3:"-55";s:6:"abreve";s:3:"-55";s:11:"acircumflex";s:3:"-55";s:9:"adieresis";s:3:"-55";s:6:"agrave";s:3:"-55";s:7:"amacron";s:3:"-55";s:7:"aogonek";s:3:"-55";s:5:"aring";s:3:"-55";s:6:"atilde";s:3:"-55";s:1:"b";s:3:"-55";s:1:"c";s:3:"-55";s:6:"cacute";s:3:"-55";s:6:"ccaron";s:3:"-55";s:8:"ccedilla";s:3:"-55";s:5:"comma";s:3:"-95";s:1:"d";s:3:"-55";s:6:"dcroat";s:3:"-55";s:1:"e";s:3:"-55";s:6:"eacute";s:3:"-55";s:6:"ecaron";s:3:"-55";s:11:"ecircumflex";s:3:"-55";s:9:"edieresis";s:3:"-55";s:10:"edotaccent";s:3:"-55";s:6:"egrave";s:3:"-55";s:7:"emacron";s:3:"-55";s:7:"eogonek";s:3:"-55";s:1:"f";s:3:"-55";s:1:"g";s:3:"-55";s:6:"gbreve";s:3:"-55";s:12:"gcommaaccent";s:3:"-55";s:1:"h";s:3:"-55";s:1:"i";s:3:"-55";s:6:"iacute";s:3:"-55";s:11:"icircumflex";s:3:"-55";s:9:"idieresis";s:3:"-55";s:6:"igrave";s:3:"-55";s:7:"imacron";s:3:"-55";s:7:"iogonek";s:3:"-55";s:1:"j";s:3:"-55";s:1:"k";s:3:"-55";s:12:"kcommaaccent";s:3:"-55";s:1:"l";s:3:"-55";s:6:"lacute";s:3:"-55";s:12:"lcommaaccent";s:3:"-55";s:6:"lslash";s:3:"-55";s:1:"m";s:3:"-55";s:1:"n";s:3:"-55";s:6:"nacute";s:3:"-55";s:6:"ncaron";s:3:"-55";s:12:"ncommaaccent";s:3:"-55";s:6:"ntilde";s:3:"-55";s:1:"o";s:3:"-55";s:6:"oacute";s:3:"-55";s:11:"ocircumflex";s:3:"-55";s:9:"odieresis";s:3:"-55";s:6:"ograve";s:3:"-55";s:13:"ohungarumlaut";s:3:"-55";s:7:"omacron";s:3:"-55";s:6:"oslash";s:3:"-55";s:6:"otilde";s:3:"-55";s:1:"p";s:3:"-55";s:6:"period";s:3:"-95";s:1:"q";s:3:"-55";s:1:"r";s:3:"-55";s:6:"racute";s:3:"-55";s:6:"rcaron";s:3:"-55";s:12:"rcommaaccent";s:3:"-55";s:1:"s";s:3:"-55";s:6:"sacute";s:3:"-55";s:6:"scaron";s:3:"-55";s:8:"scedilla";s:3:"-55";s:12:"scommaaccent";s:3:"-55";s:1:"t";s:3:"-55";s:12:"tcommaaccent";s:3:"-55";s:1:"u";s:3:"-55";s:6:"uacute";s:3:"-55";s:11:"ucircumflex";s:3:"-55";s:9:"udieresis";s:3:"-55";s:6:"ugrave";s:3:"-55";s:13:"uhungarumlaut";s:3:"-55";s:7:"umacron";s:3:"-55";s:7:"uogonek";s:3:"-55";s:5:"uring";s:3:"-55";s:1:"v";s:3:"-70";s:1:"w";s:3:"-70";s:1:"x";s:3:"-85";s:1:"y";s:3:"-70";s:6:"yacute";s:3:"-70";s:9:"ydieresis";s:3:"-70";s:1:"z";s:3:"-55";s:6:"zacute";s:3:"-55";s:6:"zcaron";s:3:"-55";s:10:"zdotaccent";s:3:"-55";}s:6:"otilde";a:8:{s:5:"comma";s:3:"-40";s:6:"period";s:3:"-40";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-30";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:1:"p";a:5:{s:5:"comma";s:3:"-35";s:6:"period";s:3:"-35";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:6:"period";a:3:{s:13:"quotedblright";s:4:"-100";s:10:"quoteright";s:4:"-100";s:5:"space";s:3:"-60";}s:13:"quotedblright";a:1:{s:5:"space";s:3:"-40";}s:9:"quoteleft";a:1:{s:9:"quoteleft";s:3:"-57";}s:10:"quoteright";a:13:{s:1:"d";s:3:"-50";s:6:"dcroat";s:3:"-50";s:10:"quoteright";s:3:"-57";s:1:"r";s:3:"-50";s:6:"racute";s:3:"-50";s:6:"rcaron";s:3:"-50";s:12:"rcommaaccent";s:3:"-50";s:1:"s";s:3:"-50";s:6:"sacute";s:3:"-50";s:6:"scaron";s:3:"-50";s:8:"scedilla";s:3:"-50";s:12:"scommaaccent";s:3:"-50";s:5:"space";s:3:"-70";}s:1:"r";a:49:{s:1:"a";s:3:"-10";s:6:"aacute";s:3:"-10";s:6:"abreve";s:3:"-10";s:11:"acircumflex";s:3:"-10";s:9:"adieresis";s:3:"-10";s:6:"agrave";s:3:"-10";s:7:"amacron";s:3:"-10";s:7:"aogonek";s:3:"-10";s:5:"aring";s:3:"-10";s:6:"atilde";s:3:"-10";s:5:"colon";s:2:"30";s:5:"comma";s:3:"-50";s:1:"i";s:2:"15";s:6:"iacute";s:2:"15";s:11:"icircumflex";s:2:"15";s:9:"idieresis";s:2:"15";s:6:"igrave";s:2:"15";s:7:"imacron";s:2:"15";s:7:"iogonek";s:2:"15";s:1:"k";s:2:"15";s:12:"kcommaaccent";s:2:"15";s:1:"l";s:2:"15";s:6:"lacute";s:2:"15";s:12:"lcommaaccent";s:2:"15";s:6:"lslash";s:2:"15";s:1:"m";s:2:"25";s:1:"n";s:2:"25";s:6:"nacute";s:2:"25";s:6:"ncaron";s:2:"25";s:12:"ncommaaccent";s:2:"25";s:6:"ntilde";s:2:"25";s:1:"p";s:2:"30";s:6:"period";s:3:"-50";s:9:"semicolon";s:2:"30";s:1:"t";s:2:"40";s:12:"tcommaaccent";s:2:"40";s:1:"u";s:2:"15";s:6:"uacute";s:2:"15";s:11:"ucircumflex";s:2:"15";s:9:"udieresis";s:2:"15";s:6:"ugrave";s:2:"15";s:13:"uhungarumlaut";s:2:"15";s:7:"umacron";s:2:"15";s:7:"uogonek";s:2:"15";s:5:"uring";s:2:"15";s:1:"v";s:2:"30";s:1:"y";s:2:"30";s:6:"yacute";s:2:"30";s:9:"ydieresis";s:2:"30";}s:6:"racute";a:49:{s:1:"a";s:3:"-10";s:6:"aacute";s:3:"-10";s:6:"abreve";s:3:"-10";s:11:"acircumflex";s:3:"-10";s:9:"adieresis";s:3:"-10";s:6:"agrave";s:3:"-10";s:7:"amacron";s:3:"-10";s:7:"aogonek";s:3:"-10";s:5:"aring";s:3:"-10";s:6:"atilde";s:3:"-10";s:5:"colon";s:2:"30";s:5:"comma";s:3:"-50";s:1:"i";s:2:"15";s:6:"iacute";s:2:"15";s:11:"icircumflex";s:2:"15";s:9:"idieresis";s:2:"15";s:6:"igrave";s:2:"15";s:7:"imacron";s:2:"15";s:7:"iogonek";s:2:"15";s:1:"k";s:2:"15";s:12:"kcommaaccent";s:2:"15";s:1:"l";s:2:"15";s:6:"lacute";s:2:"15";s:12:"lcommaaccent";s:2:"15";s:6:"lslash";s:2:"15";s:1:"m";s:2:"25";s:1:"n";s:2:"25";s:6:"nacute";s:2:"25";s:6:"ncaron";s:2:"25";s:12:"ncommaaccent";s:2:"25";s:6:"ntilde";s:2:"25";s:1:"p";s:2:"30";s:6:"period";s:3:"-50";s:9:"semicolon";s:2:"30";s:1:"t";s:2:"40";s:12:"tcommaaccent";s:2:"40";s:1:"u";s:2:"15";s:6:"uacute";s:2:"15";s:11:"ucircumflex";s:2:"15";s:9:"udieresis";s:2:"15";s:6:"ugrave";s:2:"15";s:13:"uhungarumlaut";s:2:"15";s:7:"umacron";s:2:"15";s:7:"uogonek";s:2:"15";s:5:"uring";s:2:"15";s:1:"v";s:2:"30";s:1:"y";s:2:"30";s:6:"yacute";s:2:"30";s:9:"ydieresis";s:2:"30";}s:6:"rcaron";a:49:{s:1:"a";s:3:"-10";s:6:"aacute";s:3:"-10";s:6:"abreve";s:3:"-10";s:11:"acircumflex";s:3:"-10";s:9:"adieresis";s:3:"-10";s:6:"agrave";s:3:"-10";s:7:"amacron";s:3:"-10";s:7:"aogonek";s:3:"-10";s:5:"aring";s:3:"-10";s:6:"atilde";s:3:"-10";s:5:"colon";s:2:"30";s:5:"comma";s:3:"-50";s:1:"i";s:2:"15";s:6:"iacute";s:2:"15";s:11:"icircumflex";s:2:"15";s:9:"idieresis";s:2:"15";s:6:"igrave";s:2:"15";s:7:"imacron";s:2:"15";s:7:"iogonek";s:2:"15";s:1:"k";s:2:"15";s:12:"kcommaaccent";s:2:"15";s:1:"l";s:2:"15";s:6:"lacute";s:2:"15";s:12:"lcommaaccent";s:2:"15";s:6:"lslash";s:2:"15";s:1:"m";s:2:"25";s:1:"n";s:2:"25";s:6:"nacute";s:2:"25";s:6:"ncaron";s:2:"25";s:12:"ncommaaccent";s:2:"25";s:6:"ntilde";s:2:"25";s:1:"p";s:2:"30";s:6:"period";s:3:"-50";s:9:"semicolon";s:2:"30";s:1:"t";s:2:"40";s:12:"tcommaaccent";s:2:"40";s:1:"u";s:2:"15";s:6:"uacute";s:2:"15";s:11:"ucircumflex";s:2:"15";s:9:"udieresis";s:2:"15";s:6:"ugrave";s:2:"15";s:13:"uhungarumlaut";s:2:"15";s:7:"umacron";s:2:"15";s:7:"uogonek";s:2:"15";s:5:"uring";s:2:"15";s:1:"v";s:2:"30";s:1:"y";s:2:"30";s:6:"yacute";s:2:"30";s:9:"ydieresis";s:2:"30";}s:12:"rcommaaccent";a:49:{s:1:"a";s:3:"-10";s:6:"aacute";s:3:"-10";s:6:"abreve";s:3:"-10";s:11:"acircumflex";s:3:"-10";s:9:"adieresis";s:3:"-10";s:6:"agrave";s:3:"-10";s:7:"amacron";s:3:"-10";s:7:"aogonek";s:3:"-10";s:5:"aring";s:3:"-10";s:6:"atilde";s:3:"-10";s:5:"colon";s:2:"30";s:5:"comma";s:3:"-50";s:1:"i";s:2:"15";s:6:"iacute";s:2:"15";s:11:"icircumflex";s:2:"15";s:9:"idieresis";s:2:"15";s:6:"igrave";s:2:"15";s:7:"imacron";s:2:"15";s:7:"iogonek";s:2:"15";s:1:"k";s:2:"15";s:12:"kcommaaccent";s:2:"15";s:1:"l";s:2:"15";s:6:"lacute";s:2:"15";s:12:"lcommaaccent";s:2:"15";s:6:"lslash";s:2:"15";s:1:"m";s:2:"25";s:1:"n";s:2:"25";s:6:"nacute";s:2:"25";s:6:"ncaron";s:2:"25";s:12:"ncommaaccent";s:2:"25";s:6:"ntilde";s:2:"25";s:1:"p";s:2:"30";s:6:"period";s:3:"-50";s:9:"semicolon";s:2:"30";s:1:"t";s:2:"40";s:12:"tcommaaccent";s:2:"40";s:1:"u";s:2:"15";s:6:"uacute";s:2:"15";s:11:"ucircumflex";s:2:"15";s:9:"udieresis";s:2:"15";s:6:"ugrave";s:2:"15";s:13:"uhungarumlaut";s:2:"15";s:7:"umacron";s:2:"15";s:7:"uogonek";s:2:"15";s:5:"uring";s:2:"15";s:1:"v";s:2:"30";s:1:"y";s:2:"30";s:6:"yacute";s:2:"30";s:9:"ydieresis";s:2:"30";}s:1:"s";a:3:{s:5:"comma";s:3:"-15";s:6:"period";s:3:"-15";s:1:"w";s:3:"-30";}s:6:"sacute";a:3:{s:5:"comma";s:3:"-15";s:6:"period";s:3:"-15";s:1:"w";s:3:"-30";}s:6:"scaron";a:3:{s:5:"comma";s:3:"-15";s:6:"period";s:3:"-15";s:1:"w";s:3:"-30";}s:8:"scedilla";a:3:{s:5:"comma";s:3:"-15";s:6:"period";s:3:"-15";s:1:"w";s:3:"-30";}s:12:"scommaaccent";a:3:{s:5:"comma";s:3:"-15";s:6:"period";s:3:"-15";s:1:"w";s:3:"-30";}s:9:"semicolon";a:1:{s:5:"space";s:3:"-50";}s:5:"space";a:10:{s:1:"T";s:3:"-50";s:6:"Tcaron";s:3:"-50";s:12:"Tcommaaccent";s:3:"-50";s:1:"V";s:3:"-50";s:1:"W";s:3:"-40";s:1:"Y";s:3:"-90";s:6:"Yacute";s:3:"-90";s:9:"Ydieresis";s:3:"-90";s:12:"quotedblleft";s:3:"-30";s:9:"quoteleft";s:3:"-60";}s:1:"v";a:30:{s:1:"a";s:3:"-25";s:6:"aacute";s:3:"-25";s:6:"abreve";s:3:"-25";s:11:"acircumflex";s:3:"-25";s:9:"adieresis";s:3:"-25";s:6:"agrave";s:3:"-25";s:7:"amacron";s:3:"-25";s:7:"aogonek";s:3:"-25";s:5:"aring";s:3:"-25";s:6:"atilde";s:3:"-25";s:5:"comma";s:3:"-80";s:1:"e";s:3:"-25";s:6:"eacute";s:3:"-25";s:6:"ecaron";s:3:"-25";s:11:"ecircumflex";s:3:"-25";s:9:"edieresis";s:3:"-25";s:10:"edotaccent";s:3:"-25";s:6:"egrave";s:3:"-25";s:7:"emacron";s:3:"-25";s:7:"eogonek";s:3:"-25";s:1:"o";s:3:"-25";s:6:"oacute";s:3:"-25";s:11:"ocircumflex";s:3:"-25";s:9:"odieresis";s:3:"-25";s:6:"ograve";s:3:"-25";s:13:"ohungarumlaut";s:3:"-25";s:7:"omacron";s:3:"-25";s:6:"oslash";s:3:"-25";s:6:"otilde";s:3:"-25";s:6:"period";s:3:"-80";}s:1:"w";a:30:{s:1:"a";s:3:"-15";s:6:"aacute";s:3:"-15";s:6:"abreve";s:3:"-15";s:11:"acircumflex";s:3:"-15";s:9:"adieresis";s:3:"-15";s:6:"agrave";s:3:"-15";s:7:"amacron";s:3:"-15";s:7:"aogonek";s:3:"-15";s:5:"aring";s:3:"-15";s:6:"atilde";s:3:"-15";s:5:"comma";s:3:"-60";s:1:"e";s:3:"-10";s:6:"eacute";s:3:"-10";s:6:"ecaron";s:3:"-10";s:11:"ecircumflex";s:3:"-10";s:9:"edieresis";s:3:"-10";s:10:"edotaccent";s:3:"-10";s:6:"egrave";s:3:"-10";s:7:"emacron";s:3:"-10";s:7:"eogonek";s:3:"-10";s:1:"o";s:3:"-10";s:6:"oacute";s:3:"-10";s:11:"ocircumflex";s:3:"-10";s:9:"odieresis";s:3:"-10";s:6:"ograve";s:3:"-10";s:13:"ohungarumlaut";s:3:"-10";s:7:"omacron";s:3:"-10";s:6:"oslash";s:3:"-10";s:6:"otilde";s:3:"-10";s:6:"period";s:3:"-60";}s:1:"x";a:9:{s:1:"e";s:3:"-30";s:6:"eacute";s:3:"-30";s:6:"ecaron";s:3:"-30";s:11:"ecircumflex";s:3:"-30";s:9:"edieresis";s:3:"-30";s:10:"edotaccent";s:3:"-30";s:6:"egrave";s:3:"-30";s:7:"emacron";s:3:"-30";s:7:"eogonek";s:3:"-30";}s:1:"y";a:30:{s:1:"a";s:3:"-20";s:6:"aacute";s:3:"-20";s:6:"abreve";s:3:"-20";s:11:"acircumflex";s:3:"-20";s:9:"adieresis";s:3:"-20";s:6:"agrave";s:3:"-20";s:7:"amacron";s:3:"-20";s:7:"aogonek";s:3:"-20";s:5:"aring";s:3:"-20";s:6:"atilde";s:3:"-20";s:5:"comma";s:4:"-100";s:1:"e";s:3:"-20";s:6:"eacute";s:3:"-20";s:6:"ecaron";s:3:"-20";s:11:"ecircumflex";s:3:"-20";s:9:"edieresis";s:3:"-20";s:10:"edotaccent";s:3:"-20";s:6:"egrave";s:3:"-20";s:7:"emacron";s:3:"-20";s:7:"eogonek";s:3:"-20";s:1:"o";s:3:"-20";s:6:"oacute";s:3:"-20";s:11:"ocircumflex";s:3:"-20";s:9:"odieresis";s:3:"-20";s:6:"ograve";s:3:"-20";s:13:"ohungarumlaut";s:3:"-20";s:7:"omacron";s:3:"-20";s:6:"oslash";s:3:"-20";s:6:"otilde";s:3:"-20";s:6:"period";s:4:"-100";}s:6:"yacute";a:30:{s:1:"a";s:3:"-20";s:6:"aacute";s:3:"-20";s:6:"abreve";s:3:"-20";s:11:"acircumflex";s:3:"-20";s:9:"adieresis";s:3:"-20";s:6:"agrave";s:3:"-20";s:7:"amacron";s:3:"-20";s:7:"aogonek";s:3:"-20";s:5:"aring";s:3:"-20";s:6:"atilde";s:3:"-20";s:5:"comma";s:4:"-100";s:1:"e";s:3:"-20";s:6:"eacute";s:3:"-20";s:6:"ecaron";s:3:"-20";s:11:"ecircumflex";s:3:"-20";s:9:"edieresis";s:3:"-20";s:10:"edotaccent";s:3:"-20";s:6:"egrave";s:3:"-20";s:7:"emacron";s:3:"-20";s:7:"eogonek";s:3:"-20";s:1:"o";s:3:"-20";s:6:"oacute";s:3:"-20";s:11:"ocircumflex";s:3:"-20";s:9:"odieresis";s:3:"-20";s:6:"ograve";s:3:"-20";s:13:"ohungarumlaut";s:3:"-20";s:7:"omacron";s:3:"-20";s:6:"oslash";s:3:"-20";s:6:"otilde";s:3:"-20";s:6:"period";s:4:"-100";}s:9:"ydieresis";a:30:{s:1:"a";s:3:"-20";s:6:"aacute";s:3:"-20";s:6:"abreve";s:3:"-20";s:11:"acircumflex";s:3:"-20";s:9:"adieresis";s:3:"-20";s:6:"agrave";s:3:"-20";s:7:"amacron";s:3:"-20";s:7:"aogonek";s:3:"-20";s:5:"aring";s:3:"-20";s:6:"atilde";s:3:"-20";s:5:"comma";s:4:"-100";s:1:"e";s:3:"-20";s:6:"eacute";s:3:"-20";s:6:"ecaron";s:3:"-20";s:11:"ecircumflex";s:3:"-20";s:9:"edieresis";s:3:"-20";s:10:"edotaccent";s:3:"-20";s:6:"egrave";s:3:"-20";s:7:"emacron";s:3:"-20";s:7:"eogonek";s:3:"-20";s:1:"o";s:3:"-20";s:6:"oacute";s:3:"-20";s:11:"ocircumflex";s:3:"-20";s:9:"odieresis";s:3:"-20";s:6:"ograve";s:3:"-20";s:13:"ohungarumlaut";s:3:"-20";s:7:"omacron";s:3:"-20";s:6:"oslash";s:3:"-20";s:6:"otilde";s:3:"-20";s:6:"period";s:4:"-100";}s:1:"z";a:18:{s:1:"e";s:3:"-15";s:6:"eacute";s:3:"-15";s:6:"ecaron";s:3:"-15";s:11:"ecircumflex";s:3:"-15";s:9:"edieresis";s:3:"-15";s:10:"edotaccent";s:3:"-15";s:6:"egrave";s:3:"-15";s:7:"emacron";s:3:"-15";s:7:"eogonek";s:3:"-15";s:1:"o";s:3:"-15";s:6:"oacute";s:3:"-15";s:11:"ocircumflex";s:3:"-15";s:9:"odieresis";s:3:"-15";s:6:"ograve";s:3:"-15";s:13:"ohungarumlaut";s:3:"-15";s:7:"omacron";s:3:"-15";s:6:"oslash";s:3:"-15";s:6:"otilde";s:3:"-15";}s:6:"zacute";a:18:{s:1:"e";s:3:"-15";s:6:"eacute";s:3:"-15";s:6:"ecaron";s:3:"-15";s:11:"ecircumflex";s:3:"-15";s:9:"edieresis";s:3:"-15";s:10:"edotaccent";s:3:"-15";s:6:"egrave";s:3:"-15";s:7:"emacron";s:3:"-15";s:7:"eogonek";s:3:"-15";s:1:"o";s:3:"-15";s:6:"oacute";s:3:"-15";s:11:"ocircumflex";s:3:"-15";s:9:"odieresis";s:3:"-15";s:6:"ograve";s:3:"-15";s:13:"ohungarumlaut";s:3:"-15";s:7:"omacron";s:3:"-15";s:6:"oslash";s:3:"-15";s:6:"otilde";s:3:"-15";}s:6:"zcaron";a:18:{s:1:"e";s:3:"-15";s:6:"eacute";s:3:"-15";s:6:"ecaron";s:3:"-15";s:11:"ecircumflex";s:3:"-15";s:9:"edieresis";s:3:"-15";s:10:"edotaccent";s:3:"-15";s:6:"egrave";s:3:"-15";s:7:"emacron";s:3:"-15";s:7:"eogonek";s:3:"-15";s:1:"o";s:3:"-15";s:6:"oacute";s:3:"-15";s:11:"ocircumflex";s:3:"-15";s:9:"odieresis";s:3:"-15";s:6:"ograve";s:3:"-15";s:13:"ohungarumlaut";s:3:"-15";s:7:"omacron";s:3:"-15";s:6:"oslash";s:3:"-15";s:6:"otilde";s:3:"-15";}s:10:"zdotaccent";a:18:{s:1:"e";s:3:"-15";s:6:"eacute";s:3:"-15";s:6:"ecaron";s:3:"-15";s:11:"ecircumflex";s:3:"-15";s:9:"edieresis";s:3:"-15";s:10:"edotaccent";s:3:"-15";s:6:"egrave";s:3:"-15";s:7:"emacron";s:3:"-15";s:7:"eogonek";s:3:"-15";s:1:"o";s:3:"-15";s:6:"oacute";s:3:"-15";s:11:"ocircumflex";s:3:"-15";s:9:"odieresis";s:3:"-15";s:6:"ograve";s:3:"-15";s:13:"ohungarumlaut";s:3:"-15";s:7:"omacron";s:3:"-15";s:6:"oslash";s:3:"-15";s:6:"otilde";s:3:"-15";}}s:9:"_version_";i:1;}
\ No newline at end of file
Added: trunk/mapbender/http/classes/fonts/php_Symbol.afm
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/fonts/php_Symbol.afm?view=auto&rev=13
--- (empty file)
+++ trunk/mapbender/http/classes/fonts/php_Symbol.afm 2006-04-13 19:38:28+0000
@@ -0,0 +1 @@
+a:17:{s:8:"FontName";s:6:"Symbol";s:8:"FullName";s:6:"Symbol";s:10:"FamilyName";s:6:"Symbol";s:6:"Weight";s:6:"Medium";s:11:"ItalicAngle";s:1:"0";s:12:"IsFixedPitch";s:5:"false";s:12:"CharacterSet";s:7:"Special";s:8:"FontBBox";a:4:{i:0;s:4:"-180";i:1;s:4:"-293";i:2;s:4:"1090";i:3;s:4:"1010";}s:17:"UnderlinePosition";s:4:"-100";s:18:"UnderlineThickness";s:2:"50";s:7:"Version";s:7:"001.008";s:14:"EncodingScheme";s:12:"FontSpecific";s:5:"StdHW";s:2:"92";s:5:"StdVW";s:2:"85";s:16:"StartCharMetrics";s:3:"190";s:1:"C";a:379:{i:32;a:4:{s:1:"C";s:2:"32";s:2:"WX";s:3:"250";s:1:"N";s:5:"space";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}s:5:"space";a:4:{s:1:"C";s:2:"32";s:2:"WX";s:3:"250";s:1:"N";s:5:"space";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}i:33;a:4:{s:1:"C";s:2:"33";s:2:"WX";s:3:"333";s:1:"N";s:6:"exclam";s:1:"B";a:4:{i:0;s:3:"128";i:1;s:3:"-17";i:2;s:3:"240";i:3;s:3:"672";}}s:6:"exclam";a:4:{s:1:"C";s:2:"33";s:2:"WX";s:3:"333";s:1:"N";s:6:"exclam";s:1:"B";a:4:{i:0;s:3:"128";i:1;s:3:"-17";i:2;s:3:"240";i:3;s:3:"672";}}i:34;a:4:{s:1:"C";s:2:"34";s:2:"WX";s:3:"713";s:1:"N";s:9:"universal";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:1:"0";i:2;s:3:"681";i:3;s:3:"705";}}s:9:"universal";a:4:{s:1:"C";s:2:"34";s:2:"WX";s:3:"713";s:1:"N";s:9:"universal";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:1:"0";i:2;s:3:"681";i:3;s:3:"705";}}i:35;a:4:{s:1:"C";s:2:"35";s:2:"WX";s:3:"500";s:1:"N";s:10:"numbersign";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:3:"-16";i:2;s:3:"481";i:3;s:3:"673";}}s:10:"numbersign";a:4:{s:1:"C";s:2:"35";s:2:"WX";s:3:"500";s:1:"N";s:10:"numbersign";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:3:"-16";i:2;s:3:"481";i:3;s:3:"673";}}i:36;a:4:{s:1:"C";s:2:"36";s:2:"WX";s:3:"549";s:1:"N";s:11:"existential";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"478";i:3;s:3:"707";}}s:11:"existential";a:4:{s:1:"C";s:2:"36";s:2:"WX";s:3:"549";s:1:"N";s:11:"existential";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"478";i:3;s:3:"707";}}i:37;a:4:{s:1:"C";s:2:"37";s:2:"WX";s:3:"833";s:1:"N";s:7:"percent";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:3:"-36";i:2;s:3:"771";i:3;s:3:"655";}}s:7:"percent";a:4:{s:1:"C";s:2:"37";s:2:"WX";s:3:"833";s:1:"N";s:7:"percent";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:3:"-36";i:2;s:3:"771";i:3;s:3:"655";}}i:38;a:4:{s:1:"C";s:2:"38";s:2:"WX";s:3:"778";s:1:"N";s:9:"ampersand";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:3:"-18";i:2;s:3:"750";i:3;s:3:"661";}}s:9:"ampersand";a:4:{s:1:"C";s:2:"38";s:2:"WX";s:3:"778";s:1:"N";s:9:"ampersand";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:3:"-18";i:2;s:3:"750";i:3;s:3:"661";}}i:39;a:4:{s:1:"C";s:2:"39";s:2:"WX";s:3:"439";s:1:"N";s:8:"suchthat";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:3:"-17";i:2;s:3:"414";i:3;s:3:"500";}}s:8:"suchthat";a:4:{s:1:"C";s:2:"39";s:2:"WX";s:3:"439";s:1:"N";s:8:"suchthat";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:3:"-17";i:2;s:3:"414";i:3;s:3:"500";}}i:40;a:4:{s:1:"C";s:2:"40";s:2:"WX";s:3:"333";s:1:"N";s:9:"parenleft";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:4:"-191";i:2;s:3:"300";i:3;s:3:"673";}}s:9:"parenleft";a:4:{s:1:"C";s:2:"40";s:2:"WX";s:3:"333";s:1:"N";s:9:"parenleft";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:4:"-191";i:2;s:3:"300";i:3;s:3:"673";}}i:41;a:4:{s:1:"C";s:2:"41";s:2:"WX";s:3:"333";s:1:"N";s:10:"parenright";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:4:"-191";i:2;s:3:"277";i:3;s:3:"673";}}s:10:"parenright";a:4:{s:1:"C";s:2:"41";s:2:"WX";s:3:"333";s:1:"N";s:10:"parenright";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:4:"-191";i:2;s:3:"277";i:3;s:3:"673";}}i:42;a:4:{s:1:"C";s:2:"42";s:2:"WX";s:3:"500";s:1:"N";s:12:"asteriskmath";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:3:"134";i:2;s:3:"427";i:3;s:3:"551";}}s:12:"asteriskmath";a:4:{s:1:"C";s:2:"42";s:2:"WX";s:3:"500";s:1:"N";s:12:"asteriskmath";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:3:"134";i:2;s:3:"427";i:3;s:3:"551";}}i:43;a:4:{s:1:"C";s:2:"43";s:2:"WX";s:3:"549";s:1:"N";s:4:"plus";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:1:"0";i:2;s:3:"539";i:3;s:3:"533";}}s:4:"plus";a:4:{s:1:"C";s:2:"43";s:2:"WX";s:3:"549";s:1:"N";s:4:"plus";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:1:"0";i:2;s:3:"539";i:3;s:3:"533";}}i:44;a:4:{s:1:"C";s:2:"44";s:2:"WX";s:3:"250";s:1:"N";s:5:"comma";s:1:"B";a:4:{i:0;s:2:"56";i:1;s:4:"-152";i:2;s:3:"194";i:3;s:3:"104";}}s:5:"comma";a:4:{s:1:"C";s:2:"44";s:2:"WX";s:3:"250";s:1:"N";s:5:"comma";s:1:"B";a:4:{i:0;s:2:"56";i:1;s:4:"-152";i:2;s:3:"194";i:3;s:3:"104";}}i:45;a:4:{s:1:"C";s:2:"45";s:2:"WX";s:3:"549";s:1:"N";s:5:"minus";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:3:"233";i:2;s:3:"535";i:3;s:3:"288";}}s:5:"minus";a:4:{s:1:"C";s:2:"45";s:2:"WX";s:3:"549";s:1:"N";s:5:"minus";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:3:"233";i:2;s:3:"535";i:3;s:3:"288";}}i:46;a:4:{s:1:"C";s:2:"46";s:2:"WX";s:3:"250";s:1:"N";s:6:"period";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:3:"-17";i:2;s:3:"181";i:3;s:2:"95";}}s:6:"period";a:4:{s:1:"C";s:2:"46";s:2:"WX";s:3:"250";s:1:"N";s:6:"period";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:3:"-17";i:2;s:3:"181";i:3;s:2:"95";}}i:47;a:4:{s:1:"C";s:2:"47";s:2:"WX";s:3:"278";s:1:"N";s:5:"slash";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"-18";i:2;s:3:"254";i:3;s:3:"646";}}s:5:"slash";a:4:{s:1:"C";s:2:"47";s:2:"WX";s:3:"278";s:1:"N";s:5:"slash";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"-18";i:2;s:3:"254";i:3;s:3:"646";}}i:48;a:4:{s:1:"C";s:2:"48";s:2:"WX";s:3:"500";s:1:"N";s:4:"zero";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:3:"-14";i:2;s:3:"476";i:3;s:3:"685";}}s:4:"zero";a:4:{s:1:"C";s:2:"48";s:2:"WX";s:3:"500";s:1:"N";s:4:"zero";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:3:"-14";i:2;s:3:"476";i:3;s:3:"685";}}i:49;a:4:{s:1:"C";s:2:"49";s:2:"WX";s:3:"500";s:1:"N";s:3:"one";s:1:"B";a:4:{i:0;s:3:"117";i:1;s:1:"0";i:2;s:3:"390";i:3;s:3:"673";}}s:3:"one";a:4:{s:1:"C";s:2:"49";s:2:"WX";s:3:"500";s:1:"N";s:3:"one";s:1:"B";a:4:{i:0;s:3:"117";i:1;s:1:"0";i:2;s:3:"390";i:3;s:3:"673";}}i:50;a:4:{s:1:"C";s:2:"50";s:2:"WX";s:3:"500";s:1:"N";s:3:"two";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"475";i:3;s:3:"685";}}s:3:"two";a:4:{s:1:"C";s:2:"50";s:2:"WX";s:3:"500";s:1:"N";s:3:"two";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"475";i:3;s:3:"685";}}i:51;a:4:{s:1:"C";s:2:"51";s:2:"WX";s:3:"500";s:1:"N";s:5:"three";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:3:"-14";i:2;s:3:"435";i:3;s:3:"685";}}s:5:"three";a:4:{s:1:"C";s:2:"51";s:2:"WX";s:3:"500";s:1:"N";s:5:"three";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:3:"-14";i:2;s:3:"435";i:3;s:3:"685";}}i:52;a:4:{s:1:"C";s:2:"52";s:2:"WX";s:3:"500";s:1:"N";s:4:"four";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:1:"0";i:2;s:3:"469";i:3;s:3:"685";}}s:4:"four";a:4:{s:1:"C";s:2:"52";s:2:"WX";s:3:"500";s:1:"N";s:4:"four";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:1:"0";i:2;s:3:"469";i:3;s:3:"685";}}i:53;a:4:{s:1:"C";s:2:"53";s:2:"WX";s:3:"500";s:1:"N";s:4:"five";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:3:"-14";i:2;s:3:"445";i:3;s:3:"690";}}s:4:"five";a:4:{s:1:"C";s:2:"53";s:2:"WX";s:3:"500";s:1:"N";s:4:"five";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:3:"-14";i:2;s:3:"445";i:3;s:3:"690";}}i:54;a:4:{s:1:"C";s:2:"54";s:2:"WX";s:3:"500";s:1:"N";s:3:"six";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"468";i:3;s:3:"685";}}s:3:"six";a:4:{s:1:"C";s:2:"54";s:2:"WX";s:3:"500";s:1:"N";s:3:"six";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"468";i:3;s:3:"685";}}i:55;a:4:{s:1:"C";s:2:"55";s:2:"WX";s:3:"500";s:1:"N";s:5:"seven";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:3:"-16";i:2;s:3:"448";i:3;s:3:"673";}}s:5:"seven";a:4:{s:1:"C";s:2:"55";s:2:"WX";s:3:"500";s:1:"N";s:5:"seven";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:3:"-16";i:2;s:3:"448";i:3;s:3:"673";}}i:56;a:4:{s:1:"C";s:2:"56";s:2:"WX";s:3:"500";s:1:"N";s:5:"eight";s:1:"B";a:4:{i:0;s:2:"56";i:1;s:3:"-14";i:2;s:3:"445";i:3;s:3:"685";}}s:5:"eight";a:4:{s:1:"C";s:2:"56";s:2:"WX";s:3:"500";s:1:"N";s:5:"eight";s:1:"B";a:4:{i:0;s:2:"56";i:1;s:3:"-14";i:2;s:3:"445";i:3;s:3:"685";}}i:57;a:4:{s:1:"C";s:2:"57";s:2:"WX";s:3:"500";s:1:"N";s:4:"nine";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-18";i:2;s:3:"459";i:3;s:3:"685";}}s:4:"nine";a:4:{s:1:"C";s:2:"57";s:2:"WX";s:3:"500";s:1:"N";s:4:"nine";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-18";i:2;s:3:"459";i:3;s:3:"685";}}i:58;a:4:{s:1:"C";s:2:"58";s:2:"WX";s:3:"278";s:1:"N";s:5:"colon";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:3:"-17";i:2;s:3:"193";i:3;s:3:"460";}}s:5:"colon";a:4:{s:1:"C";s:2:"58";s:2:"WX";s:3:"278";s:1:"N";s:5:"colon";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:3:"-17";i:2;s:3:"193";i:3;s:3:"460";}}i:59;a:4:{s:1:"C";s:2:"59";s:2:"WX";s:3:"278";s:1:"N";s:9:"semicolon";s:1:"B";a:4:{i:0;s:2:"83";i:1;s:4:"-152";i:2;s:3:"221";i:3;s:3:"460";}}s:9:"semicolon";a:4:{s:1:"C";s:2:"59";s:2:"WX";s:3:"278";s:1:"N";s:9:"semicolon";s:1:"B";a:4:{i:0;s:2:"83";i:1;s:4:"-152";i:2;s:3:"221";i:3;s:3:"460";}}i:60;a:4:{s:1:"C";s:2:"60";s:2:"WX";s:3:"549";s:1:"N";s:4:"less";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"523";i:3;s:3:"522";}}s:4:"less";a:4:{s:1:"C";s:2:"60";s:2:"WX";s:3:"549";s:1:"N";s:4:"less";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"523";i:3;s:3:"522";}}i:61;a:4:{s:1:"C";s:2:"61";s:2:"WX";s:3:"549";s:1:"N";s:5:"equal";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:3:"141";i:2;s:3:"537";i:3;s:3:"390";}}s:5:"equal";a:4:{s:1:"C";s:2:"61";s:2:"WX";s:3:"549";s:1:"N";s:5:"equal";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:3:"141";i:2;s:3:"537";i:3;s:3:"390";}}i:62;a:4:{s:1:"C";s:2:"62";s:2:"WX";s:3:"549";s:1:"N";s:7:"greater";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"523";i:3;s:3:"522";}}s:7:"greater";a:4:{s:1:"C";s:2:"62";s:2:"WX";s:3:"549";s:1:"N";s:7:"greater";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"523";i:3;s:3:"522";}}i:63;a:4:{s:1:"C";s:2:"63";s:2:"WX";s:3:"444";s:1:"N";s:8:"question";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:3:"-17";i:2;s:3:"412";i:3;s:3:"686";}}s:8:"question";a:4:{s:1:"C";s:2:"63";s:2:"WX";s:3:"444";s:1:"N";s:8:"question";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:3:"-17";i:2;s:3:"412";i:3;s:3:"686";}}i:64;a:4:{s:1:"C";s:2:"64";s:2:"WX";s:3:"549";s:1:"N";s:9:"congruent";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:1:"0";i:2;s:3:"537";i:3;s:3:"475";}}s:9:"congruent";a:4:{s:1:"C";s:2:"64";s:2:"WX";s:3:"549";s:1:"N";s:9:"congruent";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:1:"0";i:2;s:3:"537";i:3;s:3:"475";}}i:65;a:4:{s:1:"C";s:2:"65";s:2:"WX";s:3:"722";s:1:"N";s:5:"Alpha";s:1:"B";a:4:{i:0;s:1:"4";i:1;s:1:"0";i:2;s:3:"684";i:3;s:3:"673";}}s:5:"Alpha";a:4:{s:1:"C";s:2:"65";s:2:"WX";s:3:"722";s:1:"N";s:5:"Alpha";s:1:"B";a:4:{i:0;s:1:"4";i:1;s:1:"0";i:2;s:3:"684";i:3;s:3:"673";}}i:66;a:4:{s:1:"C";s:2:"66";s:2:"WX";s:3:"667";s:1:"N";s:4:"Beta";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:1:"0";i:2;s:3:"592";i:3;s:3:"673";}}s:4:"Beta";a:4:{s:1:"C";s:2:"66";s:2:"WX";s:3:"667";s:1:"N";s:4:"Beta";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:1:"0";i:2;s:3:"592";i:3;s:3:"673";}}i:67;a:4:{s:1:"C";s:2:"67";s:2:"WX";s:3:"722";s:1:"N";s:3:"Chi";s:1:"B";a:4:{i:0;s:2:"-9";i:1;s:1:"0";i:2;s:3:"704";i:3;s:3:"673";}}s:3:"Chi";a:4:{s:1:"C";s:2:"67";s:2:"WX";s:3:"722";s:1:"N";s:3:"Chi";s:1:"B";a:4:{i:0;s:2:"-9";i:1;s:1:"0";i:2;s:3:"704";i:3;s:3:"673";}}i:68;a:4:{s:1:"C";s:2:"68";s:2:"WX";s:3:"612";s:1:"N";s:5:"Delta";s:1:"B";a:4:{i:0;s:1:"6";i:1;s:1:"0";i:2;s:3:"608";i:3;s:3:"688";}}s:5:"Delta";a:4:{s:1:"C";s:2:"68";s:2:"WX";s:3:"612";s:1:"N";s:5:"Delta";s:1:"B";a:4:{i:0;s:1:"6";i:1;s:1:"0";i:2;s:3:"608";i:3;s:3:"688";}}i:69;a:4:{s:1:"C";s:2:"69";s:2:"WX";s:3:"611";s:1:"N";s:7:"Epsilon";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:1:"0";i:2;s:3:"617";i:3;s:3:"673";}}s:7:"Epsilon";a:4:{s:1:"C";s:2:"69";s:2:"WX";s:3:"611";s:1:"N";s:7:"Epsilon";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:1:"0";i:2;s:3:"617";i:3;s:3:"673";}}i:70;a:4:{s:1:"C";s:2:"70";s:2:"WX";s:3:"763";s:1:"N";s:3:"Phi";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"741";i:3;s:3:"673";}}s:3:"Phi";a:4:{s:1:"C";s:2:"70";s:2:"WX";s:3:"763";s:1:"N";s:3:"Phi";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"741";i:3;s:3:"673";}}i:71;a:4:{s:1:"C";s:2:"71";s:2:"WX";s:3:"603";s:1:"N";s:5:"Gamma";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:1:"0";i:2;s:3:"609";i:3;s:3:"673";}}s:5:"Gamma";a:4:{s:1:"C";s:2:"71";s:2:"WX";s:3:"603";s:1:"N";s:5:"Gamma";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:1:"0";i:2;s:3:"609";i:3;s:3:"673";}}i:72;a:4:{s:1:"C";s:2:"72";s:2:"WX";s:3:"722";s:1:"N";s:3:"Eta";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:1:"0";i:2;s:3:"729";i:3;s:3:"673";}}s:3:"Eta";a:4:{s:1:"C";s:2:"72";s:2:"WX";s:3:"722";s:1:"N";s:3:"Eta";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:1:"0";i:2;s:3:"729";i:3;s:3:"673";}}i:73;a:4:{s:1:"C";s:2:"73";s:2:"WX";s:3:"333";s:1:"N";s:4:"Iota";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:1:"0";i:2;s:3:"316";i:3;s:3:"673";}}s:4:"Iota";a:4:{s:1:"C";s:2:"73";s:2:"WX";s:3:"333";s:1:"N";s:4:"Iota";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:1:"0";i:2;s:3:"316";i:3;s:3:"673";}}i:74;a:4:{s:1:"C";s:2:"74";s:2:"WX";s:3:"631";s:1:"N";s:6:"theta1";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:3:"-18";i:2;s:3:"623";i:3;s:3:"689";}}s:6:"theta1";a:4:{s:1:"C";s:2:"74";s:2:"WX";s:3:"631";s:1:"N";s:6:"theta1";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:3:"-18";i:2;s:3:"623";i:3;s:3:"689";}}i:75;a:4:{s:1:"C";s:2:"75";s:2:"WX";s:3:"722";s:1:"N";s:5:"Kappa";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"722";i:3;s:3:"673";}}s:5:"Kappa";a:4:{s:1:"C";s:2:"75";s:2:"WX";s:3:"722";s:1:"N";s:5:"Kappa";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"722";i:3;s:3:"673";}}i:76;a:4:{s:1:"C";s:2:"76";s:2:"WX";s:3:"686";s:1:"N";s:6:"Lambda";s:1:"B";a:4:{i:0;s:1:"6";i:1;s:1:"0";i:2;s:3:"680";i:3;s:3:"688";}}s:6:"Lambda";a:4:{s:1:"C";s:2:"76";s:2:"WX";s:3:"686";s:1:"N";s:6:"Lambda";s:1:"B";a:4:{i:0;s:1:"6";i:1;s:1:"0";i:2;s:3:"680";i:3;s:3:"688";}}i:77;a:4:{s:1:"C";s:2:"77";s:2:"WX";s:3:"889";s:1:"N";s:2:"Mu";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:1:"0";i:2;s:3:"887";i:3;s:3:"673";}}s:2:"Mu";a:4:{s:1:"C";s:2:"77";s:2:"WX";s:3:"889";s:1:"N";s:2:"Mu";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:1:"0";i:2;s:3:"887";i:3;s:3:"673";}}i:78;a:4:{s:1:"C";s:2:"78";s:2:"WX";s:3:"722";s:1:"N";s:2:"Nu";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:2:"-8";i:2;s:3:"720";i:3;s:3:"673";}}s:2:"Nu";a:4:{s:1:"C";s:2:"78";s:2:"WX";s:3:"722";s:1:"N";s:2:"Nu";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:2:"-8";i:2;s:3:"720";i:3;s:3:"673";}}i:79;a:4:{s:1:"C";s:2:"79";s:2:"WX";s:3:"722";s:1:"N";s:7:"Omicron";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:3:"-17";i:2;s:3:"715";i:3;s:3:"685";}}s:7:"Omicron";a:4:{s:1:"C";s:2:"79";s:2:"WX";s:3:"722";s:1:"N";s:7:"Omicron";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:3:"-17";i:2;s:3:"715";i:3;s:3:"685";}}i:80;a:4:{s:1:"C";s:2:"80";s:2:"WX";s:3:"768";s:1:"N";s:2:"Pi";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"745";i:3;s:3:"673";}}s:2:"Pi";a:4:{s:1:"C";s:2:"80";s:2:"WX";s:3:"768";s:1:"N";s:2:"Pi";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"745";i:3;s:3:"673";}}i:81;a:4:{s:1:"C";s:2:"81";s:2:"WX";s:3:"741";s:1:"N";s:5:"Theta";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:3:"-17";i:2;s:3:"715";i:3;s:3:"685";}}s:5:"Theta";a:4:{s:1:"C";s:2:"81";s:2:"WX";s:3:"741";s:1:"N";s:5:"Theta";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:3:"-17";i:2;s:3:"715";i:3;s:3:"685";}}i:82;a:4:{s:1:"C";s:2:"82";s:2:"WX";s:3:"556";s:1:"N";s:3:"Rho";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:1:"0";i:2;s:3:"563";i:3;s:3:"673";}}s:3:"Rho";a:4:{s:1:"C";s:2:"82";s:2:"WX";s:3:"556";s:1:"N";s:3:"Rho";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:1:"0";i:2;s:3:"563";i:3;s:3:"673";}}i:83;a:4:{s:1:"C";s:2:"83";s:2:"WX";s:3:"592";s:1:"N";s:5:"Sigma";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:1:"0";i:2;s:3:"589";i:3;s:3:"673";}}s:5:"Sigma";a:4:{s:1:"C";s:2:"83";s:2:"WX";s:3:"592";s:1:"N";s:5:"Sigma";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:1:"0";i:2;s:3:"589";i:3;s:3:"673";}}i:84;a:4:{s:1:"C";s:2:"84";s:2:"WX";s:3:"611";s:1:"N";s:3:"Tau";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:1:"0";i:2;s:3:"607";i:3;s:3:"673";}}s:3:"Tau";a:4:{s:1:"C";s:2:"84";s:2:"WX";s:3:"611";s:1:"N";s:3:"Tau";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:1:"0";i:2;s:3:"607";i:3;s:3:"673";}}i:85;a:4:{s:1:"C";s:2:"85";s:2:"WX";s:3:"690";s:1:"N";s:7:"Upsilon";s:1:"B";a:4:{i:0;s:2:"-8";i:1;s:1:"0";i:2;s:3:"694";i:3;s:3:"673";}}s:7:"Upsilon";a:4:{s:1:"C";s:2:"85";s:2:"WX";s:3:"690";s:1:"N";s:7:"Upsilon";s:1:"B";a:4:{i:0;s:2:"-8";i:1;s:1:"0";i:2;s:3:"694";i:3;s:3:"673";}}i:86;a:4:{s:1:"C";s:2:"86";s:2:"WX";s:3:"439";s:1:"N";s:6:"sigma1";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:4:"-233";i:2;s:3:"436";i:3;s:3:"500";}}s:6:"sigma1";a:4:{s:1:"C";s:2:"86";s:2:"WX";s:3:"439";s:1:"N";s:6:"sigma1";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:4:"-233";i:2;s:3:"436";i:3;s:3:"500";}}i:87;a:4:{s:1:"C";s:2:"87";s:2:"WX";s:3:"768";s:1:"N";s:5:"Omega";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:1:"0";i:2;s:3:"736";i:3;s:3:"688";}}s:5:"Omega";a:4:{s:1:"C";s:2:"87";s:2:"WX";s:3:"768";s:1:"N";s:5:"Omega";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:1:"0";i:2;s:3:"736";i:3;s:3:"688";}}i:88;a:4:{s:1:"C";s:2:"88";s:2:"WX";s:3:"645";s:1:"N";s:2:"Xi";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:1:"0";i:2;s:3:"599";i:3;s:3:"673";}}s:2:"Xi";a:4:{s:1:"C";s:2:"88";s:2:"WX";s:3:"645";s:1:"N";s:2:"Xi";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:1:"0";i:2;s:3:"599";i:3;s:3:"673";}}i:89;a:4:{s:1:"C";s:2:"89";s:2:"WX";s:3:"795";s:1:"N";s:3:"Psi";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:1:"0";i:2;s:3:"781";i:3;s:3:"684";}}s:3:"Psi";a:4:{s:1:"C";s:2:"89";s:2:"WX";s:3:"795";s:1:"N";s:3:"Psi";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:1:"0";i:2;s:3:"781";i:3;s:3:"684";}}i:90;a:4:{s:1:"C";s:2:"90";s:2:"WX";s:3:"611";s:1:"N";s:4:"Zeta";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:1:"0";i:2;s:3:"636";i:3;s:3:"673";}}s:4:"Zeta";a:4:{s:1:"C";s:2:"90";s:2:"WX";s:3:"611";s:1:"N";s:4:"Zeta";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:1:"0";i:2;s:3:"636";i:3;s:3:"673";}}i:91;a:4:{s:1:"C";s:2:"91";s:2:"WX";s:3:"333";s:1:"N";s:11:"bracketleft";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:4:"-155";i:2;s:3:"299";i:3;s:3:"674";}}s:11:"bracketleft";a:4:{s:1:"C";s:2:"91";s:2:"WX";s:3:"333";s:1:"N";s:11:"bracketleft";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:4:"-155";i:2;s:3:"299";i:3;s:3:"674";}}i:92;a:4:{s:1:"C";s:2:"92";s:2:"WX";s:3:"863";s:1:"N";s:9:"therefore";s:1:"B";a:4:{i:0;s:3:"163";i:1;s:1:"0";i:2;s:3:"701";i:3;s:3:"487";}}s:9:"therefore";a:4:{s:1:"C";s:2:"92";s:2:"WX";s:3:"863";s:1:"N";s:9:"therefore";s:1:"B";a:4:{i:0;s:3:"163";i:1;s:1:"0";i:2;s:3:"701";i:3;s:3:"487";}}i:93;a:4:{s:1:"C";s:2:"93";s:2:"WX";s:3:"333";s:1:"N";s:12:"bracketright";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:4:"-155";i:2;s:3:"246";i:3;s:3:"674";}}s:12:"bracketright";a:4:{s:1:"C";s:2:"93";s:2:"WX";s:3:"333";s:1:"N";s:12:"bracketright";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:4:"-155";i:2;s:3:"246";i:3;s:3:"674";}}i:94;a:4:{s:1:"C";s:2:"94";s:2:"WX";s:3:"658";s:1:"N";s:13:"perpendicular";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:1:"0";i:2;s:3:"652";i:3;s:3:"674";}}s:13:"perpendicular";a:4:{s:1:"C";s:2:"94";s:2:"WX";s:3:"658";s:1:"N";s:13:"perpendicular";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:1:"0";i:2;s:3:"652";i:3;s:3:"674";}}i:95;a:4:{s:1:"C";s:2:"95";s:2:"WX";s:3:"500";s:1:"N";s:10:"underscore";s:1:"B";a:4:{i:0;s:2:"-2";i:1;s:4:"-125";i:2;s:3:"502";i:3;s:3:"-75";}}s:10:"underscore";a:4:{s:1:"C";s:2:"95";s:2:"WX";s:3:"500";s:1:"N";s:10:"underscore";s:1:"B";a:4:{i:0;s:2:"-2";i:1;s:4:"-125";i:2;s:3:"502";i:3;s:3:"-75";}}i:96;a:4:{s:1:"C";s:2:"96";s:2:"WX";s:3:"500";s:1:"N";s:9:"radicalex";s:1:"B";a:4:{i:0;s:3:"480";i:1;s:3:"881";i:2;s:4:"1090";i:3;s:3:"917";}}s:9:"radicalex";a:4:{s:1:"C";s:2:"96";s:2:"WX";s:3:"500";s:1:"N";s:9:"radicalex";s:1:"B";a:4:{i:0;s:3:"480";i:1;s:3:"881";i:2;s:4:"1090";i:3;s:3:"917";}}i:97;a:4:{s:1:"C";s:2:"97";s:2:"WX";s:3:"631";s:1:"N";s:5:"alpha";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:3:"-18";i:2;s:3:"622";i:3;s:3:"500";}}s:5:"alpha";a:4:{s:1:"C";s:2:"97";s:2:"WX";s:3:"631";s:1:"N";s:5:"alpha";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:3:"-18";i:2;s:3:"622";i:3;s:3:"500";}}i:98;a:4:{s:1:"C";s:2:"98";s:2:"WX";s:3:"549";s:1:"N";s:4:"beta";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:4:"-223";i:2;s:3:"515";i:3;s:3:"741";}}s:4:"beta";a:4:{s:1:"C";s:2:"98";s:2:"WX";s:3:"549";s:1:"N";s:4:"beta";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:4:"-223";i:2;s:3:"515";i:3;s:3:"741";}}i:99;a:4:{s:1:"C";s:2:"99";s:2:"WX";s:3:"549";s:1:"N";s:3:"chi";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:4:"-231";i:2;s:3:"522";i:3;s:3:"499";}}s:3:"chi";a:4:{s:1:"C";s:2:"99";s:2:"WX";s:3:"549";s:1:"N";s:3:"chi";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:4:"-231";i:2;s:3:"522";i:3;s:3:"499";}}i:100;a:4:{s:1:"C";s:3:"100";s:2:"WX";s:3:"494";s:1:"N";s:5:"delta";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"-19";i:2;s:3:"481";i:3;s:3:"740";}}s:5:"delta";a:4:{s:1:"C";s:3:"100";s:2:"WX";s:3:"494";s:1:"N";s:5:"delta";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"-19";i:2;s:3:"481";i:3;s:3:"740";}}i:101;a:4:{s:1:"C";s:3:"101";s:2:"WX";s:3:"439";s:1:"N";s:7:"epsilon";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-19";i:2;s:3:"427";i:3;s:3:"502";}}s:7:"epsilon";a:4:{s:1:"C";s:3:"101";s:2:"WX";s:3:"439";s:1:"N";s:7:"epsilon";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-19";i:2;s:3:"427";i:3;s:3:"502";}}i:102;a:4:{s:1:"C";s:3:"102";s:2:"WX";s:3:"521";s:1:"N";s:3:"phi";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:4:"-224";i:2;s:3:"492";i:3;s:3:"673";}}s:3:"phi";a:4:{s:1:"C";s:3:"102";s:2:"WX";s:3:"521";s:1:"N";s:3:"phi";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:4:"-224";i:2;s:3:"492";i:3;s:3:"673";}}i:103;a:4:{s:1:"C";s:3:"103";s:2:"WX";s:3:"411";s:1:"N";s:5:"gamma";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:4:"-225";i:2;s:3:"484";i:3;s:3:"499";}}s:5:"gamma";a:4:{s:1:"C";s:3:"103";s:2:"WX";s:3:"411";s:1:"N";s:5:"gamma";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:4:"-225";i:2;s:3:"484";i:3;s:3:"499";}}i:104;a:4:{s:1:"C";s:3:"104";s:2:"WX";s:3:"603";s:1:"N";s:3:"eta";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:4:"-202";i:2;s:3:"527";i:3;s:3:"514";}}s:3:"eta";a:4:{s:1:"C";s:3:"104";s:2:"WX";s:3:"603";s:1:"N";s:3:"eta";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:4:"-202";i:2;s:3:"527";i:3;s:3:"514";}}i:105;a:4:{s:1:"C";s:3:"105";s:2:"WX";s:3:"329";s:1:"N";s:4:"iota";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"-17";i:2;s:3:"301";i:3;s:3:"503";}}s:4:"iota";a:4:{s:1:"C";s:3:"105";s:2:"WX";s:3:"329";s:1:"N";s:4:"iota";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"-17";i:2;s:3:"301";i:3;s:3:"503";}}i:106;a:4:{s:1:"C";s:3:"106";s:2:"WX";s:3:"603";s:1:"N";s:4:"phi1";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:4:"-224";i:2;s:3:"587";i:3;s:3:"499";}}s:4:"phi1";a:4:{s:1:"C";s:3:"106";s:2:"WX";s:3:"603";s:1:"N";s:4:"phi1";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:4:"-224";i:2;s:3:"587";i:3;s:3:"499";}}i:107;a:4:{s:1:"C";s:3:"107";s:2:"WX";s:3:"549";s:1:"N";s:5:"kappa";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:1:"0";i:2;s:3:"558";i:3;s:3:"501";}}s:5:"kappa";a:4:{s:1:"C";s:3:"107";s:2:"WX";s:3:"549";s:1:"N";s:5:"kappa";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:1:"0";i:2;s:3:"558";i:3;s:3:"501";}}i:108;a:4:{s:1:"C";s:3:"108";s:2:"WX";s:3:"549";s:1:"N";s:6:"lambda";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:3:"-17";i:2;s:3:"548";i:3;s:3:"739";}}s:6:"lambda";a:4:{s:1:"C";s:3:"108";s:2:"WX";s:3:"549";s:1:"N";s:6:"lambda";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:3:"-17";i:2;s:3:"548";i:3;s:3:"739";}}i:109;a:4:{s:1:"C";s:3:"109";s:2:"WX";s:3:"576";s:1:"N";s:2:"mu";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:4:"-223";i:2;s:3:"567";i:3;s:3:"500";}}s:2:"mu";a:4:{s:1:"C";s:3:"109";s:2:"WX";s:3:"576";s:1:"N";s:2:"mu";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:4:"-223";i:2;s:3:"567";i:3;s:3:"500";}}i:110;a:4:{s:1:"C";s:3:"110";s:2:"WX";s:3:"521";s:1:"N";s:2:"nu";s:1:"B";a:4:{i:0;s:2:"-9";i:1;s:3:"-16";i:2;s:3:"475";i:3;s:3:"507";}}s:2:"nu";a:4:{s:1:"C";s:3:"110";s:2:"WX";s:3:"521";s:1:"N";s:2:"nu";s:1:"B";a:4:{i:0;s:2:"-9";i:1;s:3:"-16";i:2;s:3:"475";i:3;s:3:"507";}}i:111;a:4:{s:1:"C";s:3:"111";s:2:"WX";s:3:"549";s:1:"N";s:7:"omicron";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-19";i:2;s:3:"501";i:3;s:3:"499";}}s:7:"omicron";a:4:{s:1:"C";s:3:"111";s:2:"WX";s:3:"549";s:1:"N";s:7:"omicron";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-19";i:2;s:3:"501";i:3;s:3:"499";}}i:112;a:4:{s:1:"C";s:3:"112";s:2:"WX";s:3:"549";s:1:"N";s:2:"pi";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:3:"-19";i:2;s:3:"530";i:3;s:3:"487";}}s:2:"pi";a:4:{s:1:"C";s:3:"112";s:2:"WX";s:3:"549";s:1:"N";s:2:"pi";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:3:"-19";i:2;s:3:"530";i:3;s:3:"487";}}i:113;a:4:{s:1:"C";s:3:"113";s:2:"WX";s:3:"521";s:1:"N";s:5:"theta";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:3:"-17";i:2;s:3:"485";i:3;s:3:"690";}}s:5:"theta";a:4:{s:1:"C";s:3:"113";s:2:"WX";s:3:"521";s:1:"N";s:5:"theta";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:3:"-17";i:2;s:3:"485";i:3;s:3:"690";}}i:114;a:4:{s:1:"C";s:3:"114";s:2:"WX";s:3:"549";s:1:"N";s:3:"rho";s:1:"B";a:4:{i:0;s:2:"50";i:1;s:4:"-230";i:2;s:3:"490";i:3;s:3:"499";}}s:3:"rho";a:4:{s:1:"C";s:3:"114";s:2:"WX";s:3:"549";s:1:"N";s:3:"rho";s:1:"B";a:4:{i:0;s:2:"50";i:1;s:4:"-230";i:2;s:3:"490";i:3;s:3:"499";}}i:115;a:4:{s:1:"C";s:3:"115";s:2:"WX";s:3:"603";s:1:"N";s:5:"sigma";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-21";i:2;s:3:"588";i:3;s:3:"500";}}s:5:"sigma";a:4:{s:1:"C";s:3:"115";s:2:"WX";s:3:"603";s:1:"N";s:5:"sigma";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-21";i:2;s:3:"588";i:3;s:3:"500";}}i:116;a:4:{s:1:"C";s:3:"116";s:2:"WX";s:3:"439";s:1:"N";s:3:"tau";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:3:"-19";i:2;s:3:"418";i:3;s:3:"500";}}s:3:"tau";a:4:{s:1:"C";s:3:"116";s:2:"WX";s:3:"439";s:1:"N";s:3:"tau";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:3:"-19";i:2;s:3:"418";i:3;s:3:"500";}}i:117;a:4:{s:1:"C";s:3:"117";s:2:"WX";s:3:"576";s:1:"N";s:7:"upsilon";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:3:"-18";i:2;s:3:"535";i:3;s:3:"507";}}s:7:"upsilon";a:4:{s:1:"C";s:3:"117";s:2:"WX";s:3:"576";s:1:"N";s:7:"upsilon";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:3:"-18";i:2;s:3:"535";i:3;s:3:"507";}}i:118;a:4:{s:1:"C";s:3:"118";s:2:"WX";s:3:"713";s:1:"N";s:6:"omega1";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:3:"-18";i:2;s:3:"671";i:3;s:3:"583";}}s:6:"omega1";a:4:{s:1:"C";s:3:"118";s:2:"WX";s:3:"713";s:1:"N";s:6:"omega1";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:3:"-18";i:2;s:3:"671";i:3;s:3:"583";}}i:119;a:4:{s:1:"C";s:3:"119";s:2:"WX";s:3:"686";s:1:"N";s:5:"omega";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-17";i:2;s:3:"684";i:3;s:3:"500";}}s:5:"omega";a:4:{s:1:"C";s:3:"119";s:2:"WX";s:3:"686";s:1:"N";s:5:"omega";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-17";i:2;s:3:"684";i:3;s:3:"500";}}i:120;a:4:{s:1:"C";s:3:"120";s:2:"WX";s:3:"493";s:1:"N";s:2:"xi";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:4:"-224";i:2;s:3:"469";i:3;s:3:"766";}}s:2:"xi";a:4:{s:1:"C";s:3:"120";s:2:"WX";s:3:"493";s:1:"N";s:2:"xi";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:4:"-224";i:2;s:3:"469";i:3;s:3:"766";}}i:121;a:4:{s:1:"C";s:3:"121";s:2:"WX";s:3:"686";s:1:"N";s:3:"psi";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:4:"-228";i:2;s:3:"701";i:3;s:3:"500";}}s:3:"psi";a:4:{s:1:"C";s:3:"121";s:2:"WX";s:3:"686";s:1:"N";s:3:"psi";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:4:"-228";i:2;s:3:"701";i:3;s:3:"500";}}i:122;a:4:{s:1:"C";s:3:"122";s:2:"WX";s:3:"494";s:1:"N";s:4:"zeta";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:4:"-225";i:2;s:3:"467";i:3;s:3:"756";}}s:4:"zeta";a:4:{s:1:"C";s:3:"122";s:2:"WX";s:3:"494";s:1:"N";s:4:"zeta";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:4:"-225";i:2;s:3:"467";i:3;s:3:"756";}}i:123;a:4:{s:1:"C";s:3:"123";s:2:"WX";s:3:"480";s:1:"N";s:9:"braceleft";s:1:"B";a:4:{i:0;s:2:"58";i:1;s:4:"-183";i:2;s:3:"397";i:3;s:3:"673";}}s:9:"braceleft";a:4:{s:1:"C";s:3:"123";s:2:"WX";s:3:"480";s:1:"N";s:9:"braceleft";s:1:"B";a:4:{i:0;s:2:"58";i:1;s:4:"-183";i:2;s:3:"397";i:3;s:3:"673";}}i:124;a:4:{s:1:"C";s:3:"124";s:2:"WX";s:3:"200";s:1:"N";s:3:"bar";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:4:"-293";i:2;s:3:"135";i:3;s:3:"707";}}s:3:"bar";a:4:{s:1:"C";s:3:"124";s:2:"WX";s:3:"200";s:1:"N";s:3:"bar";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:4:"-293";i:2;s:3:"135";i:3;s:3:"707";}}i:125;a:4:{s:1:"C";s:3:"125";s:2:"WX";s:3:"480";s:1:"N";s:10:"braceright";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:4:"-183";i:2;s:3:"418";i:3;s:3:"673";}}s:10:"braceright";a:4:{s:1:"C";s:3:"125";s:2:"WX";s:3:"480";s:1:"N";s:10:"braceright";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:4:"-183";i:2;s:3:"418";i:3;s:3:"673";}}i:126;a:4:{s:1:"C";s:3:"126";s:2:"WX";s:3:"549";s:1:"N";s:7:"similar";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:3:"203";i:2;s:3:"529";i:3;s:3:"307";}}s:7:"similar";a:4:{s:1:"C";s:3:"126";s:2:"WX";s:3:"549";s:1:"N";s:7:"similar";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:3:"203";i:2;s:3:"529";i:3;s:3:"307";}}i:160;a:4:{s:1:"C";s:3:"160";s:2:"WX";s:3:"750";s:1:"N";s:4:"Euro";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:3:"-12";i:2;s:3:"714";i:3;s:3:"685";}}s:4:"Euro";a:4:{s:1:"C";s:3:"160";s:2:"WX";s:3:"750";s:1:"N";s:4:"Euro";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:3:"-12";i:2;s:3:"714";i:3;s:3:"685";}}i:161;a:4:{s:1:"C";s:3:"161";s:2:"WX";s:3:"620";s:1:"N";s:8:"Upsilon1";s:1:"B";a:4:{i:0;s:2:"-2";i:1;s:1:"0";i:2;s:3:"610";i:3;s:3:"685";}}s:8:"Upsilon1";a:4:{s:1:"C";s:3:"161";s:2:"WX";s:3:"620";s:1:"N";s:8:"Upsilon1";s:1:"B";a:4:{i:0;s:2:"-2";i:1;s:1:"0";i:2;s:3:"610";i:3;s:3:"685";}}i:162;a:4:{s:1:"C";s:3:"162";s:2:"WX";s:3:"247";s:1:"N";s:6:"minute";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:3:"459";i:2;s:3:"228";i:3;s:3:"735";}}s:6:"minute";a:4:{s:1:"C";s:3:"162";s:2:"WX";s:3:"247";s:1:"N";s:6:"minute";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:3:"459";i:2;s:3:"228";i:3;s:3:"735";}}i:163;a:4:{s:1:"C";s:3:"163";s:2:"WX";s:3:"549";s:1:"N";s:9:"lessequal";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:1:"0";i:2;s:3:"526";i:3;s:3:"639";}}s:9:"lessequal";a:4:{s:1:"C";s:3:"163";s:2:"WX";s:3:"549";s:1:"N";s:9:"lessequal";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:1:"0";i:2;s:3:"526";i:3;s:3:"639";}}i:164;a:4:{s:1:"C";s:3:"164";s:2:"WX";s:3:"167";s:1:"N";s:8:"fraction";s:1:"B";a:4:{i:0;s:4:"-180";i:1;s:3:"-12";i:2;s:3:"340";i:3;s:3:"677";}}s:8:"fraction";a:4:{s:1:"C";s:3:"164";s:2:"WX";s:3:"167";s:1:"N";s:8:"fraction";s:1:"B";a:4:{i:0;s:4:"-180";i:1;s:3:"-12";i:2;s:3:"340";i:3;s:3:"677";}}i:165;a:4:{s:1:"C";s:3:"165";s:2:"WX";s:3:"713";s:1:"N";s:8:"infinity";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:3:"124";i:2;s:3:"688";i:3;s:3:"404";}}s:8:"infinity";a:4:{s:1:"C";s:3:"165";s:2:"WX";s:3:"713";s:1:"N";s:8:"infinity";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:3:"124";i:2;s:3:"688";i:3;s:3:"404";}}i:166;a:4:{s:1:"C";s:3:"166";s:2:"WX";s:3:"500";s:1:"N";s:6:"florin";s:1:"B";a:4:{i:0;s:1:"2";i:1;s:4:"-193";i:2;s:3:"494";i:3;s:3:"686";}}s:6:"florin";a:4:{s:1:"C";s:3:"166";s:2:"WX";s:3:"500";s:1:"N";s:6:"florin";s:1:"B";a:4:{i:0;s:1:"2";i:1;s:4:"-193";i:2;s:3:"494";i:3;s:3:"686";}}i:167;a:4:{s:1:"C";s:3:"167";s:2:"WX";s:3:"753";s:1:"N";s:4:"club";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:3:"-26";i:2;s:3:"660";i:3;s:3:"533";}}s:4:"club";a:4:{s:1:"C";s:3:"167";s:2:"WX";s:3:"753";s:1:"N";s:4:"club";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:3:"-26";i:2;s:3:"660";i:3;s:3:"533";}}i:168;a:4:{s:1:"C";s:3:"168";s:2:"WX";s:3:"753";s:1:"N";s:7:"diamond";s:1:"B";a:4:{i:0;s:3:"142";i:1;s:3:"-36";i:2;s:3:"600";i:3;s:3:"550";}}s:7:"diamond";a:4:{s:1:"C";s:3:"168";s:2:"WX";s:3:"753";s:1:"N";s:7:"diamond";s:1:"B";a:4:{i:0;s:3:"142";i:1;s:3:"-36";i:2;s:3:"600";i:3;s:3:"550";}}i:169;a:4:{s:1:"C";s:3:"169";s:2:"WX";s:3:"753";s:1:"N";s:5:"heart";s:1:"B";a:4:{i:0;s:3:"117";i:1;s:3:"-33";i:2;s:3:"631";i:3;s:3:"532";}}s:5:"heart";a:4:{s:1:"C";s:3:"169";s:2:"WX";s:3:"753";s:1:"N";s:5:"heart";s:1:"B";a:4:{i:0;s:3:"117";i:1;s:3:"-33";i:2;s:3:"631";i:3;s:3:"532";}}i:170;a:4:{s:1:"C";s:3:"170";s:2:"WX";s:3:"753";s:1:"N";s:5:"spade";s:1:"B";a:4:{i:0;s:3:"113";i:1;s:3:"-36";i:2;s:3:"629";i:3;s:3:"548";}}s:5:"spade";a:4:{s:1:"C";s:3:"170";s:2:"WX";s:3:"753";s:1:"N";s:5:"spade";s:1:"B";a:4:{i:0;s:3:"113";i:1;s:3:"-36";i:2;s:3:"629";i:3;s:3:"548";}}i:171;a:4:{s:1:"C";s:3:"171";s:2:"WX";s:4:"1042";s:1:"N";s:9:"arrowboth";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:3:"-15";i:2;s:4:"1024";i:3;s:3:"511";}}s:9:"arrowboth";a:4:{s:1:"C";s:3:"171";s:2:"WX";s:4:"1042";s:1:"N";s:9:"arrowboth";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:3:"-15";i:2;s:4:"1024";i:3;s:3:"511";}}i:172;a:4:{s:1:"C";s:3:"172";s:2:"WX";s:3:"987";s:1:"N";s:9:"arrowleft";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:3:"-15";i:2;s:3:"942";i:3;s:3:"511";}}s:9:"arrowleft";a:4:{s:1:"C";s:3:"172";s:2:"WX";s:3:"987";s:1:"N";s:9:"arrowleft";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:3:"-15";i:2;s:3:"942";i:3;s:3:"511";}}i:173;a:4:{s:1:"C";s:3:"173";s:2:"WX";s:3:"603";s:1:"N";s:7:"arrowup";s:1:"B";a:4:{i:0;s:2:"45";i:1;s:1:"0";i:2;s:3:"571";i:3;s:3:"910";}}s:7:"arrowup";a:4:{s:1:"C";s:3:"173";s:2:"WX";s:3:"603";s:1:"N";s:7:"arrowup";s:1:"B";a:4:{i:0;s:2:"45";i:1;s:1:"0";i:2;s:3:"571";i:3;s:3:"910";}}i:174;a:4:{s:1:"C";s:3:"174";s:2:"WX";s:3:"987";s:1:"N";s:10:"arrowright";s:1:"B";a:4:{i:0;s:2:"49";i:1;s:3:"-15";i:2;s:3:"959";i:3;s:3:"511";}}s:10:"arrowright";a:4:{s:1:"C";s:3:"174";s:2:"WX";s:3:"987";s:1:"N";s:10:"arrowright";s:1:"B";a:4:{i:0;s:2:"49";i:1;s:3:"-15";i:2;s:3:"959";i:3;s:3:"511";}}i:175;a:4:{s:1:"C";s:3:"175";s:2:"WX";s:3:"603";s:1:"N";s:9:"arrowdown";s:1:"B";a:4:{i:0;s:2:"45";i:1;s:3:"-22";i:2;s:3:"571";i:3;s:3:"888";}}s:9:"arrowdown";a:4:{s:1:"C";s:3:"175";s:2:"WX";s:3:"603";s:1:"N";s:9:"arrowdown";s:1:"B";a:4:{i:0;s:2:"45";i:1;s:3:"-22";i:2;s:3:"571";i:3;s:3:"888";}}i:176;a:4:{s:1:"C";s:3:"176";s:2:"WX";s:3:"400";s:1:"N";s:6:"degree";s:1:"B";a:4:{i:0;s:2:"50";i:1;s:3:"385";i:2;s:3:"350";i:3;s:3:"685";}}s:6:"degree";a:4:{s:1:"C";s:3:"176";s:2:"WX";s:3:"400";s:1:"N";s:6:"degree";s:1:"B";a:4:{i:0;s:2:"50";i:1;s:3:"385";i:2;s:3:"350";i:3;s:3:"685";}}i:177;a:4:{s:1:"C";s:3:"177";s:2:"WX";s:3:"549";s:1:"N";s:9:"plusminus";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:1:"0";i:2;s:3:"539";i:3;s:3:"645";}}s:9:"plusminus";a:4:{s:1:"C";s:3:"177";s:2:"WX";s:3:"549";s:1:"N";s:9:"plusminus";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:1:"0";i:2;s:3:"539";i:3;s:3:"645";}}i:178;a:4:{s:1:"C";s:3:"178";s:2:"WX";s:3:"411";s:1:"N";s:6:"second";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:3:"459";i:2;s:3:"413";i:3;s:3:"737";}}s:6:"second";a:4:{s:1:"C";s:3:"178";s:2:"WX";s:3:"411";s:1:"N";s:6:"second";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:3:"459";i:2;s:3:"413";i:3;s:3:"737";}}i:179;a:4:{s:1:"C";s:3:"179";s:2:"WX";s:3:"549";s:1:"N";s:12:"greaterequal";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:1:"0";i:2;s:3:"526";i:3;s:3:"639";}}s:12:"greaterequal";a:4:{s:1:"C";s:3:"179";s:2:"WX";s:3:"549";s:1:"N";s:12:"greaterequal";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:1:"0";i:2;s:3:"526";i:3;s:3:"639";}}i:180;a:4:{s:1:"C";s:3:"180";s:2:"WX";s:3:"549";s:1:"N";s:8:"multiply";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:1:"8";i:2;s:3:"533";i:3;s:3:"524";}}s:8:"multiply";a:4:{s:1:"C";s:3:"180";s:2:"WX";s:3:"549";s:1:"N";s:8:"multiply";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:1:"8";i:2;s:3:"533";i:3;s:3:"524";}}i:181;a:4:{s:1:"C";s:3:"181";s:2:"WX";s:3:"713";s:1:"N";s:12:"proportional";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:3:"123";i:2;s:3:"639";i:3;s:3:"404";}}s:12:"proportional";a:4:{s:1:"C";s:3:"181";s:2:"WX";s:3:"713";s:1:"N";s:12:"proportional";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:3:"123";i:2;s:3:"639";i:3;s:3:"404";}}i:182;a:4:{s:1:"C";s:3:"182";s:2:"WX";s:3:"494";s:1:"N";s:11:"partialdiff";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:3:"-20";i:2;s:3:"462";i:3;s:3:"746";}}s:11:"partialdiff";a:4:{s:1:"C";s:3:"182";s:2:"WX";s:3:"494";s:1:"N";s:11:"partialdiff";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:3:"-20";i:2;s:3:"462";i:3;s:3:"746";}}i:183;a:4:{s:1:"C";s:3:"183";s:2:"WX";s:3:"460";s:1:"N";s:6:"bullet";s:1:"B";a:4:{i:0;s:2:"50";i:1;s:3:"113";i:2;s:3:"410";i:3;s:3:"473";}}s:6:"bullet";a:4:{s:1:"C";s:3:"183";s:2:"WX";s:3:"460";s:1:"N";s:6:"bullet";s:1:"B";a:4:{i:0;s:2:"50";i:1;s:3:"113";i:2;s:3:"410";i:3;s:3:"473";}}i:184;a:4:{s:1:"C";s:3:"184";s:2:"WX";s:3:"549";s:1:"N";s:6:"divide";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:2:"71";i:2;s:3:"536";i:3;s:3:"456";}}s:6:"divide";a:4:{s:1:"C";s:3:"184";s:2:"WX";s:3:"549";s:1:"N";s:6:"divide";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:2:"71";i:2;s:3:"536";i:3;s:3:"456";}}i:185;a:4:{s:1:"C";s:3:"185";s:2:"WX";s:3:"549";s:1:"N";s:8:"notequal";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:3:"-25";i:2;s:3:"540";i:3;s:3:"549";}}s:8:"notequal";a:4:{s:1:"C";s:3:"185";s:2:"WX";s:3:"549";s:1:"N";s:8:"notequal";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:3:"-25";i:2;s:3:"540";i:3;s:3:"549";}}i:186;a:4:{s:1:"C";s:3:"186";s:2:"WX";s:3:"549";s:1:"N";s:11:"equivalence";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:2:"82";i:2;s:3:"538";i:3;s:3:"443";}}s:11:"equivalence";a:4:{s:1:"C";s:3:"186";s:2:"WX";s:3:"549";s:1:"N";s:11:"equivalence";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:2:"82";i:2;s:3:"538";i:3;s:3:"443";}}i:187;a:4:{s:1:"C";s:3:"187";s:2:"WX";s:3:"549";s:1:"N";s:11:"approxequal";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:3:"135";i:2;s:3:"527";i:3;s:3:"394";}}s:11:"approxequal";a:4:{s:1:"C";s:3:"187";s:2:"WX";s:3:"549";s:1:"N";s:11:"approxequal";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:3:"135";i:2;s:3:"527";i:3;s:3:"394";}}i:188;a:4:{s:1:"C";s:3:"188";s:2:"WX";s:4:"1000";s:1:"N";s:8:"ellipsis";s:1:"B";a:4:{i:0;s:3:"111";i:1;s:3:"-17";i:2;s:3:"889";i:3;s:2:"95";}}s:8:"ellipsis";a:4:{s:1:"C";s:3:"188";s:2:"WX";s:4:"1000";s:1:"N";s:8:"ellipsis";s:1:"B";a:4:{i:0;s:3:"111";i:1;s:3:"-17";i:2;s:3:"889";i:3;s:2:"95";}}i:189;a:4:{s:1:"C";s:3:"189";s:2:"WX";s:3:"603";s:1:"N";s:11:"arrowvertex";s:1:"B";a:4:{i:0;s:3:"280";i:1;s:4:"-120";i:2;s:3:"336";i:3;s:4:"1010";}}s:11:"arrowvertex";a:4:{s:1:"C";s:3:"189";s:2:"WX";s:3:"603";s:1:"N";s:11:"arrowvertex";s:1:"B";a:4:{i:0;s:3:"280";i:1;s:4:"-120";i:2;s:3:"336";i:3;s:4:"1010";}}i:190;a:4:{s:1:"C";s:3:"190";s:2:"WX";s:4:"1000";s:1:"N";s:12:"arrowhorizex";s:1:"B";a:4:{i:0;s:3:"-60";i:1;s:3:"220";i:2;s:4:"1050";i:3;s:3:"276";}}s:12:"arrowhorizex";a:4:{s:1:"C";s:3:"190";s:2:"WX";s:4:"1000";s:1:"N";s:12:"arrowhorizex";s:1:"B";a:4:{i:0;s:3:"-60";i:1;s:3:"220";i:2;s:4:"1050";i:3;s:3:"276";}}i:191;a:4:{s:1:"C";s:3:"191";s:2:"WX";s:3:"658";s:1:"N";s:14:"carriagereturn";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:3:"-16";i:2;s:3:"602";i:3;s:3:"629";}}s:14:"carriagereturn";a:4:{s:1:"C";s:3:"191";s:2:"WX";s:3:"658";s:1:"N";s:14:"carriagereturn";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:3:"-16";i:2;s:3:"602";i:3;s:3:"629";}}i:192;a:4:{s:1:"C";s:3:"192";s:2:"WX";s:3:"823";s:1:"N";s:5:"aleph";s:1:"B";a:4:{i:0;s:3:"175";i:1;s:3:"-18";i:2;s:3:"661";i:3;s:3:"658";}}s:5:"aleph";a:4:{s:1:"C";s:3:"192";s:2:"WX";s:3:"823";s:1:"N";s:5:"aleph";s:1:"B";a:4:{i:0;s:3:"175";i:1;s:3:"-18";i:2;s:3:"661";i:3;s:3:"658";}}i:193;a:4:{s:1:"C";s:3:"193";s:2:"WX";s:3:"686";s:1:"N";s:8:"Ifraktur";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:3:"-53";i:2;s:3:"578";i:3;s:3:"740";}}s:8:"Ifraktur";a:4:{s:1:"C";s:3:"193";s:2:"WX";s:3:"686";s:1:"N";s:8:"Ifraktur";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:3:"-53";i:2;s:3:"578";i:3;s:3:"740";}}i:194;a:4:{s:1:"C";s:3:"194";s:2:"WX";s:3:"795";s:1:"N";s:8:"Rfraktur";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:3:"-15";i:2;s:3:"759";i:3;s:3:"734";}}s:8:"Rfraktur";a:4:{s:1:"C";s:3:"194";s:2:"WX";s:3:"795";s:1:"N";s:8:"Rfraktur";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:3:"-15";i:2;s:3:"759";i:3;s:3:"734";}}i:195;a:4:{s:1:"C";s:3:"195";s:2:"WX";s:3:"987";s:1:"N";s:11:"weierstrass";s:1:"B";a:4:{i:0;s:3:"159";i:1;s:4:"-211";i:2;s:3:"870";i:3;s:3:"573";}}s:11:"weierstrass";a:4:{s:1:"C";s:3:"195";s:2:"WX";s:3:"987";s:1:"N";s:11:"weierstrass";s:1:"B";a:4:{i:0;s:3:"159";i:1;s:4:"-211";i:2;s:3:"870";i:3;s:3:"573";}}i:196;a:4:{s:1:"C";s:3:"196";s:2:"WX";s:3:"768";s:1:"N";s:14:"circlemultiply";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:3:"-17";i:2;s:3:"733";i:3;s:3:"673";}}s:14:"circlemultiply";a:4:{s:1:"C";s:3:"196";s:2:"WX";s:3:"768";s:1:"N";s:14:"circlemultiply";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:3:"-17";i:2;s:3:"733";i:3;s:3:"673";}}i:197;a:4:{s:1:"C";s:3:"197";s:2:"WX";s:3:"768";s:1:"N";s:10:"circleplus";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:3:"-15";i:2;s:3:"733";i:3;s:3:"675";}}s:10:"circleplus";a:4:{s:1:"C";s:3:"197";s:2:"WX";s:3:"768";s:1:"N";s:10:"circleplus";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:3:"-15";i:2;s:3:"733";i:3;s:3:"675";}}i:198;a:4:{s:1:"C";s:3:"198";s:2:"WX";s:3:"823";s:1:"N";s:8:"emptyset";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:3:"-24";i:2;s:3:"781";i:3;s:3:"719";}}s:8:"emptyset";a:4:{s:1:"C";s:3:"198";s:2:"WX";s:3:"823";s:1:"N";s:8:"emptyset";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:3:"-24";i:2;s:3:"781";i:3;s:3:"719";}}i:199;a:4:{s:1:"C";s:3:"199";s:2:"WX";s:3:"768";s:1:"N";s:12:"intersection";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:1:"0";i:2;s:3:"732";i:3;s:3:"509";}}s:12:"intersection";a:4:{s:1:"C";s:3:"199";s:2:"WX";s:3:"768";s:1:"N";s:12:"intersection";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:1:"0";i:2;s:3:"732";i:3;s:3:"509";}}i:200;a:4:{s:1:"C";s:3:"200";s:2:"WX";s:3:"768";s:1:"N";s:5:"union";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"-17";i:2;s:3:"732";i:3;s:3:"492";}}s:5:"union";a:4:{s:1:"C";s:3:"200";s:2:"WX";s:3:"768";s:1:"N";s:5:"union";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"-17";i:2;s:3:"732";i:3;s:3:"492";}}i:201;a:4:{s:1:"C";s:3:"201";s:2:"WX";s:3:"713";s:1:"N";s:14:"propersuperset";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"673";i:3;s:3:"470";}}s:14:"propersuperset";a:4:{s:1:"C";s:3:"201";s:2:"WX";s:3:"713";s:1:"N";s:14:"propersuperset";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"673";i:3;s:3:"470";}}i:202;a:4:{s:1:"C";s:3:"202";s:2:"WX";s:3:"713";s:1:"N";s:14:"reflexsuperset";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:4:"-125";i:2;s:3:"673";i:3;s:3:"470";}}s:14:"reflexsuperset";a:4:{s:1:"C";s:3:"202";s:2:"WX";s:3:"713";s:1:"N";s:14:"reflexsuperset";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:4:"-125";i:2;s:3:"673";i:3;s:3:"470";}}i:203;a:4:{s:1:"C";s:3:"203";s:2:"WX";s:3:"713";s:1:"N";s:9:"notsubset";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:3:"-70";i:2;s:3:"690";i:3;s:3:"540";}}s:9:"notsubset";a:4:{s:1:"C";s:3:"203";s:2:"WX";s:3:"713";s:1:"N";s:9:"notsubset";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:3:"-70";i:2;s:3:"690";i:3;s:3:"540";}}i:204;a:4:{s:1:"C";s:3:"204";s:2:"WX";s:3:"713";s:1:"N";s:12:"propersubset";s:1:"B";a:4:{i:0;s:2:"37";i:1;s:1:"0";i:2;s:3:"690";i:3;s:3:"470";}}s:12:"propersubset";a:4:{s:1:"C";s:3:"204";s:2:"WX";s:3:"713";s:1:"N";s:12:"propersubset";s:1:"B";a:4:{i:0;s:2:"37";i:1;s:1:"0";i:2;s:3:"690";i:3;s:3:"470";}}i:205;a:4:{s:1:"C";s:3:"205";s:2:"WX";s:3:"713";s:1:"N";s:12:"reflexsubset";s:1:"B";a:4:{i:0;s:2:"37";i:1;s:4:"-125";i:2;s:3:"690";i:3;s:3:"470";}}s:12:"reflexsubset";a:4:{s:1:"C";s:3:"205";s:2:"WX";s:3:"713";s:1:"N";s:12:"reflexsubset";s:1:"B";a:4:{i:0;s:2:"37";i:1;s:4:"-125";i:2;s:3:"690";i:3;s:3:"470";}}i:206;a:4:{s:1:"C";s:3:"206";s:2:"WX";s:3:"713";s:1:"N";s:7:"element";s:1:"B";a:4:{i:0;s:2:"45";i:1;s:1:"0";i:2;s:3:"505";i:3;s:3:"468";}}s:7:"element";a:4:{s:1:"C";s:3:"206";s:2:"WX";s:3:"713";s:1:"N";s:7:"element";s:1:"B";a:4:{i:0;s:2:"45";i:1;s:1:"0";i:2;s:3:"505";i:3;s:3:"468";}}i:207;a:4:{s:1:"C";s:3:"207";s:2:"WX";s:3:"713";s:1:"N";s:10:"notelement";s:1:"B";a:4:{i:0;s:2:"45";i:1;s:3:"-58";i:2;s:3:"505";i:3;s:3:"555";}}s:10:"notelement";a:4:{s:1:"C";s:3:"207";s:2:"WX";s:3:"713";s:1:"N";s:10:"notelement";s:1:"B";a:4:{i:0;s:2:"45";i:1;s:3:"-58";i:2;s:3:"505";i:3;s:3:"555";}}i:208;a:4:{s:1:"C";s:3:"208";s:2:"WX";s:3:"768";s:1:"N";s:5:"angle";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"738";i:3;s:3:"673";}}s:5:"angle";a:4:{s:1:"C";s:3:"208";s:2:"WX";s:3:"768";s:1:"N";s:5:"angle";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"738";i:3;s:3:"673";}}i:209;a:4:{s:1:"C";s:3:"209";s:2:"WX";s:3:"713";s:1:"N";s:8:"gradient";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:3:"-19";i:2;s:3:"681";i:3;s:3:"718";}}s:8:"gradient";a:4:{s:1:"C";s:3:"209";s:2:"WX";s:3:"713";s:1:"N";s:8:"gradient";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:3:"-19";i:2;s:3:"681";i:3;s:3:"718";}}i:210;a:4:{s:1:"C";s:3:"210";s:2:"WX";s:3:"790";s:1:"N";s:13:"registerserif";s:1:"B";a:4:{i:0;s:2:"50";i:1;s:3:"-17";i:2;s:3:"740";i:3;s:3:"673";}}s:13:"registerserif";a:4:{s:1:"C";s:3:"210";s:2:"WX";s:3:"790";s:1:"N";s:13:"registerserif";s:1:"B";a:4:{i:0;s:2:"50";i:1;s:3:"-17";i:2;s:3:"740";i:3;s:3:"673";}}i:211;a:4:{s:1:"C";s:3:"211";s:2:"WX";s:3:"790";s:1:"N";s:14:"copyrightserif";s:1:"B";a:4:{i:0;s:2:"51";i:1;s:3:"-15";i:2;s:3:"741";i:3;s:3:"675";}}s:14:"copyrightserif";a:4:{s:1:"C";s:3:"211";s:2:"WX";s:3:"790";s:1:"N";s:14:"copyrightserif";s:1:"B";a:4:{i:0;s:2:"51";i:1;s:3:"-15";i:2;s:3:"741";i:3;s:3:"675";}}i:212;a:4:{s:1:"C";s:3:"212";s:2:"WX";s:3:"890";s:1:"N";s:14:"trademarkserif";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:3:"293";i:2;s:3:"855";i:3;s:3:"673";}}s:14:"trademarkserif";a:4:{s:1:"C";s:3:"212";s:2:"WX";s:3:"890";s:1:"N";s:14:"trademarkserif";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:3:"293";i:2;s:3:"855";i:3;s:3:"673";}}i:213;a:4:{s:1:"C";s:3:"213";s:2:"WX";s:3:"823";s:1:"N";s:7:"product";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:4:"-101";i:2;s:3:"803";i:3;s:3:"751";}}s:7:"product";a:4:{s:1:"C";s:3:"213";s:2:"WX";s:3:"823";s:1:"N";s:7:"product";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:4:"-101";i:2;s:3:"803";i:3;s:3:"751";}}i:214;a:4:{s:1:"C";s:3:"214";s:2:"WX";s:3:"549";s:1:"N";s:7:"radical";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:3:"-38";i:2;s:3:"515";i:3;s:3:"917";}}s:7:"radical";a:4:{s:1:"C";s:3:"214";s:2:"WX";s:3:"549";s:1:"N";s:7:"radical";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:3:"-38";i:2;s:3:"515";i:3;s:3:"917";}}i:215;a:4:{s:1:"C";s:3:"215";s:2:"WX";s:3:"250";s:1:"N";s:7:"dotmath";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:3:"210";i:2;s:3:"169";i:3;s:3:"310";}}s:7:"dotmath";a:4:{s:1:"C";s:3:"215";s:2:"WX";s:3:"250";s:1:"N";s:7:"dotmath";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:3:"210";i:2;s:3:"169";i:3;s:3:"310";}}i:216;a:4:{s:1:"C";s:3:"216";s:2:"WX";s:3:"713";s:1:"N";s:10:"logicalnot";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:1:"0";i:2;s:3:"680";i:3;s:3:"288";}}s:10:"logicalnot";a:4:{s:1:"C";s:3:"216";s:2:"WX";s:3:"713";s:1:"N";s:10:"logicalnot";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:1:"0";i:2;s:3:"680";i:3;s:3:"288";}}i:217;a:4:{s:1:"C";s:3:"217";s:2:"WX";s:3:"603";s:1:"N";s:10:"logicaland";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:1:"0";i:2;s:3:"583";i:3;s:3:"454";}}s:10:"logicaland";a:4:{s:1:"C";s:3:"217";s:2:"WX";s:3:"603";s:1:"N";s:10:"logicaland";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:1:"0";i:2;s:3:"583";i:3;s:3:"454";}}i:218;a:4:{s:1:"C";s:3:"218";s:2:"WX";s:3:"603";s:1:"N";s:9:"logicalor";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:1:"0";i:2;s:3:"578";i:3;s:3:"477";}}s:9:"logicalor";a:4:{s:1:"C";s:3:"218";s:2:"WX";s:3:"603";s:1:"N";s:9:"logicalor";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:1:"0";i:2;s:3:"578";i:3;s:3:"477";}}i:219;a:4:{s:1:"C";s:3:"219";s:2:"WX";s:4:"1042";s:1:"N";s:12:"arrowdblboth";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:3:"-20";i:2;s:4:"1023";i:3;s:3:"510";}}s:12:"arrowdblboth";a:4:{s:1:"C";s:3:"219";s:2:"WX";s:4:"1042";s:1:"N";s:12:"arrowdblboth";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:3:"-20";i:2;s:4:"1023";i:3;s:3:"510";}}i:220;a:4:{s:1:"C";s:3:"220";s:2:"WX";s:3:"987";s:1:"N";s:12:"arrowdblleft";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-15";i:2;s:3:"939";i:3;s:3:"513";}}s:12:"arrowdblleft";a:4:{s:1:"C";s:3:"220";s:2:"WX";s:3:"987";s:1:"N";s:12:"arrowdblleft";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-15";i:2;s:3:"939";i:3;s:3:"513";}}i:221;a:4:{s:1:"C";s:3:"221";s:2:"WX";s:3:"603";s:1:"N";s:10:"arrowdblup";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:1:"2";i:2;s:3:"567";i:3;s:3:"911";}}s:10:"arrowdblup";a:4:{s:1:"C";s:3:"221";s:2:"WX";s:3:"603";s:1:"N";s:10:"arrowdblup";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:1:"2";i:2;s:3:"567";i:3;s:3:"911";}}i:222;a:4:{s:1:"C";s:3:"222";s:2:"WX";s:3:"987";s:1:"N";s:13:"arrowdblright";s:1:"B";a:4:{i:0;s:2:"45";i:1;s:3:"-20";i:2;s:3:"954";i:3;s:3:"508";}}s:13:"arrowdblright";a:4:{s:1:"C";s:3:"222";s:2:"WX";s:3:"987";s:1:"N";s:13:"arrowdblright";s:1:"B";a:4:{i:0;s:2:"45";i:1;s:3:"-20";i:2;s:3:"954";i:3;s:3:"508";}}i:223;a:4:{s:1:"C";s:3:"223";s:2:"WX";s:3:"603";s:1:"N";s:12:"arrowdbldown";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-19";i:2;s:3:"572";i:3;s:3:"890";}}s:12:"arrowdbldown";a:4:{s:1:"C";s:3:"223";s:2:"WX";s:3:"603";s:1:"N";s:12:"arrowdbldown";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-19";i:2;s:3:"572";i:3;s:3:"890";}}i:224;a:4:{s:1:"C";s:3:"224";s:2:"WX";s:3:"494";s:1:"N";s:7:"lozenge";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:1:"0";i:2;s:3:"466";i:3;s:3:"745";}}s:7:"lozenge";a:4:{s:1:"C";s:3:"224";s:2:"WX";s:3:"494";s:1:"N";s:7:"lozenge";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:1:"0";i:2;s:3:"466";i:3;s:3:"745";}}i:225;a:4:{s:1:"C";s:3:"225";s:2:"WX";s:3:"329";s:1:"N";s:9:"angleleft";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:4:"-198";i:2;s:3:"306";i:3;s:3:"746";}}s:9:"angleleft";a:4:{s:1:"C";s:3:"225";s:2:"WX";s:3:"329";s:1:"N";s:9:"angleleft";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:4:"-198";i:2;s:3:"306";i:3;s:3:"746";}}i:226;a:4:{s:1:"C";s:3:"226";s:2:"WX";s:3:"790";s:1:"N";s:12:"registersans";s:1:"B";a:4:{i:0;s:2:"50";i:1;s:3:"-20";i:2;s:3:"740";i:3;s:3:"670";}}s:12:"registersans";a:4:{s:1:"C";s:3:"226";s:2:"WX";s:3:"790";s:1:"N";s:12:"registersans";s:1:"B";a:4:{i:0;s:2:"50";i:1;s:3:"-20";i:2;s:3:"740";i:3;s:3:"670";}}i:227;a:4:{s:1:"C";s:3:"227";s:2:"WX";s:3:"790";s:1:"N";s:13:"copyrightsans";s:1:"B";a:4:{i:0;s:2:"49";i:1;s:3:"-15";i:2;s:3:"739";i:3;s:3:"675";}}s:13:"copyrightsans";a:4:{s:1:"C";s:3:"227";s:2:"WX";s:3:"790";s:1:"N";s:13:"copyrightsans";s:1:"B";a:4:{i:0;s:2:"49";i:1;s:3:"-15";i:2;s:3:"739";i:3;s:3:"675";}}i:228;a:4:{s:1:"C";s:3:"228";s:2:"WX";s:3:"786";s:1:"N";s:13:"trademarksans";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:3:"293";i:2;s:3:"725";i:3;s:3:"673";}}s:13:"trademarksans";a:4:{s:1:"C";s:3:"228";s:2:"WX";s:3:"786";s:1:"N";s:13:"trademarksans";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:3:"293";i:2;s:3:"725";i:3;s:3:"673";}}i:229;a:4:{s:1:"C";s:3:"229";s:2:"WX";s:3:"713";s:1:"N";s:9:"summation";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:4:"-108";i:2;s:3:"695";i:3;s:3:"752";}}s:9:"summation";a:4:{s:1:"C";s:3:"229";s:2:"WX";s:3:"713";s:1:"N";s:9:"summation";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:4:"-108";i:2;s:3:"695";i:3;s:3:"752";}}i:230;a:4:{s:1:"C";s:3:"230";s:2:"WX";s:3:"384";s:1:"N";s:11:"parenlefttp";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:4:"-293";i:2;s:3:"436";i:3;s:3:"926";}}s:11:"parenlefttp";a:4:{s:1:"C";s:3:"230";s:2:"WX";s:3:"384";s:1:"N";s:11:"parenlefttp";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:4:"-293";i:2;s:3:"436";i:3;s:3:"926";}}i:231;a:4:{s:1:"C";s:3:"231";s:2:"WX";s:3:"384";s:1:"N";s:11:"parenleftex";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:3:"-85";i:2;s:3:"108";i:3;s:3:"925";}}s:11:"parenleftex";a:4:{s:1:"C";s:3:"231";s:2:"WX";s:3:"384";s:1:"N";s:11:"parenleftex";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:3:"-85";i:2;s:3:"108";i:3;s:3:"925";}}i:232;a:4:{s:1:"C";s:3:"232";s:2:"WX";s:3:"384";s:1:"N";s:11:"parenleftbt";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:4:"-293";i:2;s:3:"436";i:3;s:3:"926";}}s:11:"parenleftbt";a:4:{s:1:"C";s:3:"232";s:2:"WX";s:3:"384";s:1:"N";s:11:"parenleftbt";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:4:"-293";i:2;s:3:"436";i:3;s:3:"926";}}i:233;a:4:{s:1:"C";s:3:"233";s:2:"WX";s:3:"384";s:1:"N";s:13:"bracketlefttp";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"-80";i:2;s:3:"349";i:3;s:3:"926";}}s:13:"bracketlefttp";a:4:{s:1:"C";s:3:"233";s:2:"WX";s:3:"384";s:1:"N";s:13:"bracketlefttp";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"-80";i:2;s:3:"349";i:3;s:3:"926";}}i:234;a:4:{s:1:"C";s:3:"234";s:2:"WX";s:3:"384";s:1:"N";s:13:"bracketleftex";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"-79";i:2;s:2:"77";i:3;s:3:"925";}}s:13:"bracketleftex";a:4:{s:1:"C";s:3:"234";s:2:"WX";s:3:"384";s:1:"N";s:13:"bracketleftex";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"-79";i:2;s:2:"77";i:3;s:3:"925";}}i:235;a:4:{s:1:"C";s:3:"235";s:2:"WX";s:3:"384";s:1:"N";s:13:"bracketleftbt";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"-80";i:2;s:3:"349";i:3;s:3:"926";}}s:13:"bracketleftbt";a:4:{s:1:"C";s:3:"235";s:2:"WX";s:3:"384";s:1:"N";s:13:"bracketleftbt";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"-80";i:2;s:3:"349";i:3;s:3:"926";}}i:236;a:4:{s:1:"C";s:3:"236";s:2:"WX";s:3:"494";s:1:"N";s:11:"bracelefttp";s:1:"B";a:4:{i:0;s:3:"209";i:1;s:3:"-85";i:2;s:3:"445";i:3;s:3:"925";}}s:11:"bracelefttp";a:4:{s:1:"C";s:3:"236";s:2:"WX";s:3:"494";s:1:"N";s:11:"bracelefttp";s:1:"B";a:4:{i:0;s:3:"209";i:1;s:3:"-85";i:2;s:3:"445";i:3;s:3:"925";}}i:237;a:4:{s:1:"C";s:3:"237";s:2:"WX";s:3:"494";s:1:"N";s:12:"braceleftmid";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:3:"-85";i:2;s:3:"284";i:3;s:3:"935";}}s:12:"braceleftmid";a:4:{s:1:"C";s:3:"237";s:2:"WX";s:3:"494";s:1:"N";s:12:"braceleftmid";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:3:"-85";i:2;s:3:"284";i:3;s:3:"935";}}i:238;a:4:{s:1:"C";s:3:"238";s:2:"WX";s:3:"494";s:1:"N";s:11:"braceleftbt";s:1:"B";a:4:{i:0;s:3:"209";i:1;s:3:"-75";i:2;s:3:"445";i:3;s:3:"935";}}s:11:"braceleftbt";a:4:{s:1:"C";s:3:"238";s:2:"WX";s:3:"494";s:1:"N";s:11:"braceleftbt";s:1:"B";a:4:{i:0;s:3:"209";i:1;s:3:"-75";i:2;s:3:"445";i:3;s:3:"935";}}i:239;a:4:{s:1:"C";s:3:"239";s:2:"WX";s:3:"494";s:1:"N";s:7:"braceex";s:1:"B";a:4:{i:0;s:3:"209";i:1;s:3:"-85";i:2;s:3:"284";i:3;s:3:"935";}}s:7:"braceex";a:4:{s:1:"C";s:3:"239";s:2:"WX";s:3:"494";s:1:"N";s:7:"braceex";s:1:"B";a:4:{i:0;s:3:"209";i:1;s:3:"-85";i:2;s:3:"284";i:3;s:3:"935";}}i:241;a:4:{s:1:"C";s:3:"241";s:2:"WX";s:3:"329";s:1:"N";s:10:"angleright";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:4:"-198";i:2;s:3:"302";i:3;s:3:"746";}}s:10:"angleright";a:4:{s:1:"C";s:3:"241";s:2:"WX";s:3:"329";s:1:"N";s:10:"angleright";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:4:"-198";i:2;s:3:"302";i:3;s:3:"746";}}i:242;a:4:{s:1:"C";s:3:"242";s:2:"WX";s:3:"274";s:1:"N";s:8:"integral";s:1:"B";a:4:{i:0;s:1:"2";i:1;s:4:"-107";i:2;s:3:"291";i:3;s:3:"916";}}s:8:"integral";a:4:{s:1:"C";s:3:"242";s:2:"WX";s:3:"274";s:1:"N";s:8:"integral";s:1:"B";a:4:{i:0;s:1:"2";i:1;s:4:"-107";i:2;s:3:"291";i:3;s:3:"916";}}i:243;a:4:{s:1:"C";s:3:"243";s:2:"WX";s:3:"686";s:1:"N";s:10:"integraltp";s:1:"B";a:4:{i:0;s:3:"308";i:1;s:3:"-88";i:2;s:3:"675";i:3;s:3:"920";}}s:10:"integraltp";a:4:{s:1:"C";s:3:"243";s:2:"WX";s:3:"686";s:1:"N";s:10:"integraltp";s:1:"B";a:4:{i:0;s:3:"308";i:1;s:3:"-88";i:2;s:3:"675";i:3;s:3:"920";}}i:244;a:4:{s:1:"C";s:3:"244";s:2:"WX";s:3:"686";s:1:"N";s:10:"integralex";s:1:"B";a:4:{i:0;s:3:"308";i:1;s:3:"-88";i:2;s:3:"378";i:3;s:3:"975";}}s:10:"integralex";a:4:{s:1:"C";s:3:"244";s:2:"WX";s:3:"686";s:1:"N";s:10:"integralex";s:1:"B";a:4:{i:0;s:3:"308";i:1;s:3:"-88";i:2;s:3:"378";i:3;s:3:"975";}}i:245;a:4:{s:1:"C";s:3:"245";s:2:"WX";s:3:"686";s:1:"N";s:10:"integralbt";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:3:"-87";i:2;s:3:"378";i:3;s:3:"921";}}s:10:"integralbt";a:4:{s:1:"C";s:3:"245";s:2:"WX";s:3:"686";s:1:"N";s:10:"integralbt";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:3:"-87";i:2;s:3:"378";i:3;s:3:"921";}}i:246;a:4:{s:1:"C";s:3:"246";s:2:"WX";s:3:"384";s:1:"N";s:12:"parenrighttp";s:1:"B";a:4:{i:0;s:2:"54";i:1;s:4:"-293";i:2;s:3:"466";i:3;s:3:"926";}}s:12:"parenrighttp";a:4:{s:1:"C";s:3:"246";s:2:"WX";s:3:"384";s:1:"N";s:12:"parenrighttp";s:1:"B";a:4:{i:0;s:2:"54";i:1;s:4:"-293";i:2;s:3:"466";i:3;s:3:"926";}}i:247;a:4:{s:1:"C";s:3:"247";s:2:"WX";s:3:"384";s:1:"N";s:12:"parenrightex";s:1:"B";a:4:{i:0;s:3:"382";i:1;s:3:"-85";i:2;s:3:"466";i:3;s:3:"925";}}s:12:"parenrightex";a:4:{s:1:"C";s:3:"247";s:2:"WX";s:3:"384";s:1:"N";s:12:"parenrightex";s:1:"B";a:4:{i:0;s:3:"382";i:1;s:3:"-85";i:2;s:3:"466";i:3;s:3:"925";}}i:248;a:4:{s:1:"C";s:3:"248";s:2:"WX";s:3:"384";s:1:"N";s:12:"parenrightbt";s:1:"B";a:4:{i:0;s:2:"54";i:1;s:4:"-293";i:2;s:3:"466";i:3;s:3:"926";}}s:12:"parenrightbt";a:4:{s:1:"C";s:3:"248";s:2:"WX";s:3:"384";s:1:"N";s:12:"parenrightbt";s:1:"B";a:4:{i:0;s:2:"54";i:1;s:4:"-293";i:2;s:3:"466";i:3;s:3:"926";}}i:249;a:4:{s:1:"C";s:3:"249";s:2:"WX";s:3:"384";s:1:"N";s:14:"bracketrighttp";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-80";i:2;s:3:"371";i:3;s:3:"926";}}s:14:"bracketrighttp";a:4:{s:1:"C";s:3:"249";s:2:"WX";s:3:"384";s:1:"N";s:14:"bracketrighttp";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-80";i:2;s:3:"371";i:3;s:3:"926";}}i:250;a:4:{s:1:"C";s:3:"250";s:2:"WX";s:3:"384";s:1:"N";s:14:"bracketrightex";s:1:"B";a:4:{i:0;s:3:"294";i:1;s:3:"-79";i:2;s:3:"371";i:3;s:3:"925";}}s:14:"bracketrightex";a:4:{s:1:"C";s:3:"250";s:2:"WX";s:3:"384";s:1:"N";s:14:"bracketrightex";s:1:"B";a:4:{i:0;s:3:"294";i:1;s:3:"-79";i:2;s:3:"371";i:3;s:3:"925";}}i:251;a:4:{s:1:"C";s:3:"251";s:2:"WX";s:3:"384";s:1:"N";s:14:"bracketrightbt";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-80";i:2;s:3:"371";i:3;s:3:"926";}}s:14:"bracketrightbt";a:4:{s:1:"C";s:3:"251";s:2:"WX";s:3:"384";s:1:"N";s:14:"bracketrightbt";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-80";i:2;s:3:"371";i:3;s:3:"926";}}i:252;a:4:{s:1:"C";s:3:"252";s:2:"WX";s:3:"494";s:1:"N";s:12:"bracerighttp";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:3:"-85";i:2;s:3:"284";i:3;s:3:"925";}}s:12:"bracerighttp";a:4:{s:1:"C";s:3:"252";s:2:"WX";s:3:"494";s:1:"N";s:12:"bracerighttp";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:3:"-85";i:2;s:3:"284";i:3;s:3:"925";}}i:253;a:4:{s:1:"C";s:3:"253";s:2:"WX";s:3:"494";s:1:"N";s:13:"bracerightmid";s:1:"B";a:4:{i:0;s:3:"209";i:1;s:3:"-85";i:2;s:3:"473";i:3;s:3:"935";}}s:13:"bracerightmid";a:4:{s:1:"C";s:3:"253";s:2:"WX";s:3:"494";s:1:"N";s:13:"bracerightmid";s:1:"B";a:4:{i:0;s:3:"209";i:1;s:3:"-85";i:2;s:3:"473";i:3;s:3:"935";}}i:254;a:4:{s:1:"C";s:3:"254";s:2:"WX";s:3:"494";s:1:"N";s:12:"bracerightbt";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:3:"-75";i:2;s:3:"284";i:3;s:3:"935";}}s:12:"bracerightbt";a:4:{s:1:"C";s:3:"254";s:2:"WX";s:3:"494";s:1:"N";s:12:"bracerightbt";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:3:"-75";i:2;s:3:"284";i:3;s:3:"935";}}s:5:"apple";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"790";s:1:"N";s:5:"apple";s:1:"B";a:4:{i:0;s:2:"56";i:1;s:2:"-3";i:2;s:3:"733";i:3;s:3:"808";}}}s:9:"_version_";i:1;}
Added: trunk/mapbender/http/classes/fonts/php_Times-Bold.afm
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/fonts/php_Times-Bold.afm?view=auto&rev=13
--- (empty file)
+++ trunk/mapbender/http/classes/fonts/php_Times-Bold.afm 2006-04-13 19:38:28+0000
@@ -0,0 +1 @@
+a:22:{s:8:"FontName";s:10:"Times-Bold";s:8:"FullName";s:10:"Times Bold";s:10:"FamilyName";s:5:"Times";s:6:"Weight";s:4:"Bold";s:11:"ItalicAngle";s:1:"0";s:12:"IsFixedPitch";s:5:"false";s:12:"CharacterSet";s:13:"ExtendedRoman";s:8:"FontBBox";a:4:{i:0;s:4:"-168";i:1;s:4:"-218";i:2;s:4:"1000";i:3;s:3:"935";}s:17:"UnderlinePosition";s:4:"-100";s:18:"UnderlineThickness";s:2:"50";s:7:"Version";s:7:"002.000";s:14:"EncodingScheme";s:21:"AdobeStandardEncoding";s:9:"CapHeight";s:3:"676";s:7:"XHeight";s:3:"461";s:8:"Ascender";s:3:"683";s:9:"Descender";s:4:"-217";s:5:"StdHW";s:2:"44";s:5:"StdVW";s:3:"139";s:16:"StartCharMetrics";s:3:"315";s:1:"C";a:464:{i:32;a:4:{s:1:"C";s:2:"32";s:2:"WX";s:3:"250";s:1:"N";s:5:"space";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}s:5:"space";a:4:{s:1:"C";s:2:"32";s:2:"WX";s:3:"250";s:1:"N";s:5:"space";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}i:33;a:4:{s:1:"C";s:2:"33";s:2:"WX";s:3:"333";s:1:"N";s:6:"exclam";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:3:"-13";i:2;s:3:"251";i:3;s:3:"691";}}s:6:"exclam";a:4:{s:1:"C";s:2:"33";s:2:"WX";s:3:"333";s:1:"N";s:6:"exclam";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:3:"-13";i:2;s:3:"251";i:3;s:3:"691";}}i:34;a:4:{s:1:"C";s:2:"34";s:2:"WX";s:3:"555";s:1:"N";s:8:"quotedbl";s:1:"B";a:4:{i:0;s:2:"83";i:1;s:3:"404";i:2;s:3:"472";i:3;s:3:"691";}}s:8:"quotedbl";a:4:{s:1:"C";s:2:"34";s:2:"WX";s:3:"555";s:1:"N";s:8:"quotedbl";s:1:"B";a:4:{i:0;s:2:"83";i:1;s:3:"404";i:2;s:3:"472";i:3;s:3:"691";}}i:35;a:4:{s:1:"C";s:2:"35";s:2:"WX";s:3:"500";s:1:"N";s:10:"numbersign";s:1:"B";a:4:{i:0;s:1:"4";i:1;s:1:"0";i:2;s:3:"496";i:3;s:3:"700";}}s:10:"numbersign";a:4:{s:1:"C";s:2:"35";s:2:"WX";s:3:"500";s:1:"N";s:10:"numbersign";s:1:"B";a:4:{i:0;s:1:"4";i:1;s:1:"0";i:2;s:3:"496";i:3;s:3:"700";}}i:36;a:4:{s:1:"C";s:2:"36";s:2:"WX";s:3:"500";s:1:"N";s:6:"dollar";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:3:"-99";i:2;s:3:"472";i:3;s:3:"750";}}s:6:"dollar";a:4:{s:1:"C";s:2:"36";s:2:"WX";s:3:"500";s:1:"N";s:6:"dollar";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:3:"-99";i:2;s:3:"472";i:3;s:3:"750";}}i:37;a:4:{s:1:"C";s:2:"37";s:2:"WX";s:4:"1000";s:1:"N";s:7:"percent";s:1:"B";a:4:{i:0;s:3:"124";i:1;s:3:"-14";i:2;s:3:"877";i:3;s:3:"692";}}s:7:"percent";a:4:{s:1:"C";s:2:"37";s:2:"WX";s:4:"1000";s:1:"N";s:7:"percent";s:1:"B";a:4:{i:0;s:3:"124";i:1;s:3:"-14";i:2;s:3:"877";i:3;s:3:"692";}}i:38;a:4:{s:1:"C";s:2:"38";s:2:"WX";s:3:"833";s:1:"N";s:9:"ampersand";s:1:"B";a:4:{i:0;s:2:"62";i:1;s:3:"-16";i:2;s:3:"787";i:3;s:3:"691";}}s:9:"ampersand";a:4:{s:1:"C";s:2:"38";s:2:"WX";s:3:"833";s:1:"N";s:9:"ampersand";s:1:"B";a:4:{i:0;s:2:"62";i:1;s:3:"-16";i:2;s:3:"787";i:3;s:3:"691";}}i:39;a:4:{s:1:"C";s:2:"39";s:2:"WX";s:3:"333";s:1:"N";s:10:"quoteright";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:3:"356";i:2;s:3:"263";i:3;s:3:"691";}}s:10:"quoteright";a:4:{s:1:"C";s:2:"39";s:2:"WX";s:3:"333";s:1:"N";s:10:"quoteright";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:3:"356";i:2;s:3:"263";i:3;s:3:"691";}}i:40;a:4:{s:1:"C";s:2:"40";s:2:"WX";s:3:"333";s:1:"N";s:9:"parenleft";s:1:"B";a:4:{i:0;s:2:"46";i:1;s:4:"-168";i:2;s:3:"306";i:3;s:3:"694";}}s:9:"parenleft";a:4:{s:1:"C";s:2:"40";s:2:"WX";s:3:"333";s:1:"N";s:9:"parenleft";s:1:"B";a:4:{i:0;s:2:"46";i:1;s:4:"-168";i:2;s:3:"306";i:3;s:3:"694";}}i:41;a:4:{s:1:"C";s:2:"41";s:2:"WX";s:3:"333";s:1:"N";s:10:"parenright";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:4:"-168";i:2;s:3:"287";i:3;s:3:"694";}}s:10:"parenright";a:4:{s:1:"C";s:2:"41";s:2:"WX";s:3:"333";s:1:"N";s:10:"parenright";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:4:"-168";i:2;s:3:"287";i:3;s:3:"694";}}i:42;a:4:{s:1:"C";s:2:"42";s:2:"WX";s:3:"500";s:1:"N";s:8:"asterisk";s:1:"B";a:4:{i:0;s:2:"56";i:1;s:3:"255";i:2;s:3:"447";i:3;s:3:"691";}}s:8:"asterisk";a:4:{s:1:"C";s:2:"42";s:2:"WX";s:3:"500";s:1:"N";s:8:"asterisk";s:1:"B";a:4:{i:0;s:2:"56";i:1;s:3:"255";i:2;s:3:"447";i:3;s:3:"691";}}i:43;a:4:{s:1:"C";s:2:"43";s:2:"WX";s:3:"570";s:1:"N";s:4:"plus";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:1:"0";i:2;s:3:"537";i:3;s:3:"506";}}s:4:"plus";a:4:{s:1:"C";s:2:"43";s:2:"WX";s:3:"570";s:1:"N";s:4:"plus";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:1:"0";i:2;s:3:"537";i:3;s:3:"506";}}i:44;a:4:{s:1:"C";s:2:"44";s:2:"WX";s:3:"250";s:1:"N";s:5:"comma";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:4:"-180";i:2;s:3:"223";i:3;s:3:"155";}}s:5:"comma";a:4:{s:1:"C";s:2:"44";s:2:"WX";s:3:"250";s:1:"N";s:5:"comma";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:4:"-180";i:2;s:3:"223";i:3;s:3:"155";}}i:45;a:4:{s:1:"C";s:2:"45";s:2:"WX";s:3:"333";s:1:"N";s:6:"hyphen";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"171";i:2;s:3:"287";i:3;s:3:"287";}}s:6:"hyphen";a:4:{s:1:"C";s:2:"45";s:2:"WX";s:3:"333";s:1:"N";s:6:"hyphen";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"171";i:2;s:3:"287";i:3;s:3:"287";}}i:46;a:4:{s:1:"C";s:2:"46";s:2:"WX";s:3:"250";s:1:"N";s:6:"period";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:3:"-13";i:2;s:3:"210";i:3;s:3:"156";}}s:6:"period";a:4:{s:1:"C";s:2:"46";s:2:"WX";s:3:"250";s:1:"N";s:6:"period";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:3:"-13";i:2;s:3:"210";i:3;s:3:"156";}}i:47;a:4:{s:1:"C";s:2:"47";s:2:"WX";s:3:"278";s:1:"N";s:5:"slash";s:1:"B";a:4:{i:0;s:3:"-24";i:1;s:3:"-19";i:2;s:3:"302";i:3;s:3:"691";}}s:5:"slash";a:4:{s:1:"C";s:2:"47";s:2:"WX";s:3:"278";s:1:"N";s:5:"slash";s:1:"B";a:4:{i:0;s:3:"-24";i:1;s:3:"-19";i:2;s:3:"302";i:3;s:3:"691";}}i:48;a:4:{s:1:"C";s:2:"48";s:2:"WX";s:3:"500";s:1:"N";s:4:"zero";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:3:"-13";i:2;s:3:"476";i:3;s:3:"688";}}s:4:"zero";a:4:{s:1:"C";s:2:"48";s:2:"WX";s:3:"500";s:1:"N";s:4:"zero";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:3:"-13";i:2;s:3:"476";i:3;s:3:"688";}}i:49;a:4:{s:1:"C";s:2:"49";s:2:"WX";s:3:"500";s:1:"N";s:3:"one";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:1:"0";i:2;s:3:"442";i:3;s:3:"688";}}s:3:"one";a:4:{s:1:"C";s:2:"49";s:2:"WX";s:3:"500";s:1:"N";s:3:"one";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:1:"0";i:2;s:3:"442";i:3;s:3:"688";}}i:50;a:4:{s:1:"C";s:2:"50";s:2:"WX";s:3:"500";s:1:"N";s:3:"two";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:1:"0";i:2;s:3:"478";i:3;s:3:"688";}}s:3:"two";a:4:{s:1:"C";s:2:"50";s:2:"WX";s:3:"500";s:1:"N";s:3:"two";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:1:"0";i:2;s:3:"478";i:3;s:3:"688";}}i:51;a:4:{s:1:"C";s:2:"51";s:2:"WX";s:3:"500";s:1:"N";s:5:"three";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-14";i:2;s:3:"468";i:3;s:3:"688";}}s:5:"three";a:4:{s:1:"C";s:2:"51";s:2:"WX";s:3:"500";s:1:"N";s:5:"three";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-14";i:2;s:3:"468";i:3;s:3:"688";}}i:52;a:4:{s:1:"C";s:2:"52";s:2:"WX";s:3:"500";s:1:"N";s:4:"four";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:1:"0";i:2;s:3:"475";i:3;s:3:"688";}}s:4:"four";a:4:{s:1:"C";s:2:"52";s:2:"WX";s:3:"500";s:1:"N";s:4:"four";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:1:"0";i:2;s:3:"475";i:3;s:3:"688";}}i:53;a:4:{s:1:"C";s:2:"53";s:2:"WX";s:3:"500";s:1:"N";s:4:"five";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:2:"-8";i:2;s:3:"470";i:3;s:3:"676";}}s:4:"five";a:4:{s:1:"C";s:2:"53";s:2:"WX";s:3:"500";s:1:"N";s:4:"five";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:2:"-8";i:2;s:3:"470";i:3;s:3:"676";}}i:54;a:4:{s:1:"C";s:2:"54";s:2:"WX";s:3:"500";s:1:"N";s:3:"six";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:3:"-13";i:2;s:3:"475";i:3;s:3:"688";}}s:3:"six";a:4:{s:1:"C";s:2:"54";s:2:"WX";s:3:"500";s:1:"N";s:3:"six";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:3:"-13";i:2;s:3:"475";i:3;s:3:"688";}}i:55;a:4:{s:1:"C";s:2:"55";s:2:"WX";s:3:"500";s:1:"N";s:5:"seven";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:1:"0";i:2;s:3:"477";i:3;s:3:"676";}}s:5:"seven";a:4:{s:1:"C";s:2:"55";s:2:"WX";s:3:"500";s:1:"N";s:5:"seven";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:1:"0";i:2;s:3:"477";i:3;s:3:"676";}}i:56;a:4:{s:1:"C";s:2:"56";s:2:"WX";s:3:"500";s:1:"N";s:5:"eight";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:3:"-13";i:2;s:3:"472";i:3;s:3:"688";}}s:5:"eight";a:4:{s:1:"C";s:2:"56";s:2:"WX";s:3:"500";s:1:"N";s:5:"eight";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:3:"-13";i:2;s:3:"472";i:3;s:3:"688";}}i:57;a:4:{s:1:"C";s:2:"57";s:2:"WX";s:3:"500";s:1:"N";s:4:"nine";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:3:"-13";i:2;s:3:"473";i:3;s:3:"688";}}s:4:"nine";a:4:{s:1:"C";s:2:"57";s:2:"WX";s:3:"500";s:1:"N";s:4:"nine";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:3:"-13";i:2;s:3:"473";i:3;s:3:"688";}}i:58;a:4:{s:1:"C";s:2:"58";s:2:"WX";s:3:"333";s:1:"N";s:5:"colon";s:1:"B";a:4:{i:0;s:2:"82";i:1;s:3:"-13";i:2;s:3:"251";i:3;s:3:"472";}}s:5:"colon";a:4:{s:1:"C";s:2:"58";s:2:"WX";s:3:"333";s:1:"N";s:5:"colon";s:1:"B";a:4:{i:0;s:2:"82";i:1;s:3:"-13";i:2;s:3:"251";i:3;s:3:"472";}}i:59;a:4:{s:1:"C";s:2:"59";s:2:"WX";s:3:"333";s:1:"N";s:9:"semicolon";s:1:"B";a:4:{i:0;s:2:"82";i:1;s:4:"-180";i:2;s:3:"266";i:3;s:3:"472";}}s:9:"semicolon";a:4:{s:1:"C";s:2:"59";s:2:"WX";s:3:"333";s:1:"N";s:9:"semicolon";s:1:"B";a:4:{i:0;s:2:"82";i:1;s:4:"-180";i:2;s:3:"266";i:3;s:3:"472";}}i:60;a:4:{s:1:"C";s:2:"60";s:2:"WX";s:3:"570";s:1:"N";s:4:"less";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:2:"-8";i:2;s:3:"539";i:3;s:3:"514";}}s:4:"less";a:4:{s:1:"C";s:2:"60";s:2:"WX";s:3:"570";s:1:"N";s:4:"less";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:2:"-8";i:2;s:3:"539";i:3;s:3:"514";}}i:61;a:4:{s:1:"C";s:2:"61";s:2:"WX";s:3:"570";s:1:"N";s:5:"equal";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:3:"107";i:2;s:3:"537";i:3;s:3:"399";}}s:5:"equal";a:4:{s:1:"C";s:2:"61";s:2:"WX";s:3:"570";s:1:"N";s:5:"equal";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:3:"107";i:2;s:3:"537";i:3;s:3:"399";}}i:62;a:4:{s:1:"C";s:2:"62";s:2:"WX";s:3:"570";s:1:"N";s:7:"greater";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:2:"-8";i:2;s:3:"539";i:3;s:3:"514";}}s:7:"greater";a:4:{s:1:"C";s:2:"62";s:2:"WX";s:3:"570";s:1:"N";s:7:"greater";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:2:"-8";i:2;s:3:"539";i:3;s:3:"514";}}i:63;a:4:{s:1:"C";s:2:"63";s:2:"WX";s:3:"500";s:1:"N";s:8:"question";s:1:"B";a:4:{i:0;s:2:"57";i:1;s:3:"-13";i:2;s:3:"445";i:3;s:3:"689";}}s:8:"question";a:4:{s:1:"C";s:2:"63";s:2:"WX";s:3:"500";s:1:"N";s:8:"question";s:1:"B";a:4:{i:0;s:2:"57";i:1;s:3:"-13";i:2;s:3:"445";i:3;s:3:"689";}}i:64;a:4:{s:1:"C";s:2:"64";s:2:"WX";s:3:"930";s:1:"N";s:2:"at";s:1:"B";a:4:{i:0;s:3:"108";i:1;s:3:"-19";i:2;s:3:"822";i:3;s:3:"691";}}s:2:"at";a:4:{s:1:"C";s:2:"64";s:2:"WX";s:3:"930";s:1:"N";s:2:"at";s:1:"B";a:4:{i:0;s:3:"108";i:1;s:3:"-19";i:2;s:3:"822";i:3;s:3:"691";}}i:65;a:4:{s:1:"C";s:2:"65";s:2:"WX";s:3:"722";s:1:"N";s:1:"A";s:1:"B";a:4:{i:0;s:1:"9";i:1;s:1:"0";i:2;s:3:"689";i:3;s:3:"690";}}s:1:"A";a:4:{s:1:"C";s:2:"65";s:2:"WX";s:3:"722";s:1:"N";s:1:"A";s:1:"B";a:4:{i:0;s:1:"9";i:1;s:1:"0";i:2;s:3:"689";i:3;s:3:"690";}}i:66;a:4:{s:1:"C";s:2:"66";s:2:"WX";s:3:"667";s:1:"N";s:1:"B";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"619";i:3;s:3:"676";}}s:1:"B";a:4:{s:1:"C";s:2:"66";s:2:"WX";s:3:"667";s:1:"N";s:1:"B";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"619";i:3;s:3:"676";}}i:67;a:4:{s:1:"C";s:2:"67";s:2:"WX";s:3:"722";s:1:"N";s:1:"C";s:1:"B";a:4:{i:0;s:2:"49";i:1;s:3:"-19";i:2;s:3:"687";i:3;s:3:"691";}}s:1:"C";a:4:{s:1:"C";s:2:"67";s:2:"WX";s:3:"722";s:1:"N";s:1:"C";s:1:"B";a:4:{i:0;s:2:"49";i:1;s:3:"-19";i:2;s:3:"687";i:3;s:3:"691";}}i:68;a:4:{s:1:"C";s:2:"68";s:2:"WX";s:3:"722";s:1:"N";s:1:"D";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"690";i:3;s:3:"676";}}s:1:"D";a:4:{s:1:"C";s:2:"68";s:2:"WX";s:3:"722";s:1:"N";s:1:"D";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"690";i:3;s:3:"676";}}i:69;a:4:{s:1:"C";s:2:"69";s:2:"WX";s:3:"667";s:1:"N";s:1:"E";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"641";i:3;s:3:"676";}}s:1:"E";a:4:{s:1:"C";s:2:"69";s:2:"WX";s:3:"667";s:1:"N";s:1:"E";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"641";i:3;s:3:"676";}}i:70;a:4:{s:1:"C";s:2:"70";s:2:"WX";s:3:"611";s:1:"N";s:1:"F";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"583";i:3;s:3:"676";}}s:1:"F";a:4:{s:1:"C";s:2:"70";s:2:"WX";s:3:"611";s:1:"N";s:1:"F";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"583";i:3;s:3:"676";}}i:71;a:4:{s:1:"C";s:2:"71";s:2:"WX";s:3:"778";s:1:"N";s:1:"G";s:1:"B";a:4:{i:0;s:2:"37";i:1;s:3:"-19";i:2;s:3:"755";i:3;s:3:"691";}}s:1:"G";a:4:{s:1:"C";s:2:"71";s:2:"WX";s:3:"778";s:1:"N";s:1:"G";s:1:"B";a:4:{i:0;s:2:"37";i:1;s:3:"-19";i:2;s:3:"755";i:3;s:3:"691";}}i:72;a:4:{s:1:"C";s:2:"72";s:2:"WX";s:3:"778";s:1:"N";s:1:"H";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:1:"0";i:2;s:3:"759";i:3;s:3:"676";}}s:1:"H";a:4:{s:1:"C";s:2:"72";s:2:"WX";s:3:"778";s:1:"N";s:1:"H";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:1:"0";i:2;s:3:"759";i:3;s:3:"676";}}i:73;a:4:{s:1:"C";s:2:"73";s:2:"WX";s:3:"389";s:1:"N";s:1:"I";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"370";i:3;s:3:"676";}}s:1:"I";a:4:{s:1:"C";s:2:"73";s:2:"WX";s:3:"389";s:1:"N";s:1:"I";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"370";i:3;s:3:"676";}}i:74;a:4:{s:1:"C";s:2:"74";s:2:"WX";s:3:"500";s:1:"N";s:1:"J";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:3:"-96";i:2;s:3:"479";i:3;s:3:"676";}}s:1:"J";a:4:{s:1:"C";s:2:"74";s:2:"WX";s:3:"500";s:1:"N";s:1:"J";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:3:"-96";i:2;s:3:"479";i:3;s:3:"676";}}i:75;a:4:{s:1:"C";s:2:"75";s:2:"WX";s:3:"778";s:1:"N";s:1:"K";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:1:"0";i:2;s:3:"769";i:3;s:3:"676";}}s:1:"K";a:4:{s:1:"C";s:2:"75";s:2:"WX";s:3:"778";s:1:"N";s:1:"K";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:1:"0";i:2;s:3:"769";i:3;s:3:"676";}}i:76;a:4:{s:1:"C";s:2:"76";s:2:"WX";s:3:"667";s:1:"N";s:1:"L";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:1:"0";i:2;s:3:"638";i:3;s:3:"676";}}s:1:"L";a:4:{s:1:"C";s:2:"76";s:2:"WX";s:3:"667";s:1:"N";s:1:"L";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:1:"0";i:2;s:3:"638";i:3;s:3:"676";}}i:77;a:4:{s:1:"C";s:2:"77";s:2:"WX";s:3:"944";s:1:"N";s:1:"M";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"921";i:3;s:3:"676";}}s:1:"M";a:4:{s:1:"C";s:2:"77";s:2:"WX";s:3:"944";s:1:"N";s:1:"M";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"921";i:3;s:3:"676";}}i:78;a:4:{s:1:"C";s:2:"78";s:2:"WX";s:3:"722";s:1:"N";s:1:"N";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-18";i:2;s:3:"701";i:3;s:3:"676";}}s:1:"N";a:4:{s:1:"C";s:2:"78";s:2:"WX";s:3:"722";s:1:"N";s:1:"N";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-18";i:2;s:3:"701";i:3;s:3:"676";}}i:79;a:4:{s:1:"C";s:2:"79";s:2:"WX";s:3:"778";s:1:"N";s:1:"O";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-19";i:2;s:3:"743";i:3;s:3:"691";}}s:1:"O";a:4:{s:1:"C";s:2:"79";s:2:"WX";s:3:"778";s:1:"N";s:1:"O";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-19";i:2;s:3:"743";i:3;s:3:"691";}}i:80;a:4:{s:1:"C";s:2:"80";s:2:"WX";s:3:"611";s:1:"N";s:1:"P";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"600";i:3;s:3:"676";}}s:1:"P";a:4:{s:1:"C";s:2:"80";s:2:"WX";s:3:"611";s:1:"N";s:1:"P";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"600";i:3;s:3:"676";}}i:81;a:4:{s:1:"C";s:2:"81";s:2:"WX";s:3:"778";s:1:"N";s:1:"Q";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:4:"-176";i:2;s:3:"743";i:3;s:3:"691";}}s:1:"Q";a:4:{s:1:"C";s:2:"81";s:2:"WX";s:3:"778";s:1:"N";s:1:"Q";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:4:"-176";i:2;s:3:"743";i:3;s:3:"691";}}i:82;a:4:{s:1:"C";s:2:"82";s:2:"WX";s:3:"722";s:1:"N";s:1:"R";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"715";i:3;s:3:"676";}}s:1:"R";a:4:{s:1:"C";s:2:"82";s:2:"WX";s:3:"722";s:1:"N";s:1:"R";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"715";i:3;s:3:"676";}}i:83;a:4:{s:1:"C";s:2:"83";s:2:"WX";s:3:"556";s:1:"N";s:1:"S";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-19";i:2;s:3:"513";i:3;s:3:"692";}}s:1:"S";a:4:{s:1:"C";s:2:"83";s:2:"WX";s:3:"556";s:1:"N";s:1:"S";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-19";i:2;s:3:"513";i:3;s:3:"692";}}i:84;a:4:{s:1:"C";s:2:"84";s:2:"WX";s:3:"667";s:1:"N";s:1:"T";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:1:"0";i:2;s:3:"636";i:3;s:3:"676";}}s:1:"T";a:4:{s:1:"C";s:2:"84";s:2:"WX";s:3:"667";s:1:"N";s:1:"T";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:1:"0";i:2;s:3:"636";i:3;s:3:"676";}}i:85;a:4:{s:1:"C";s:2:"85";s:2:"WX";s:3:"722";s:1:"N";s:1:"U";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-19";i:2;s:3:"701";i:3;s:3:"676";}}s:1:"U";a:4:{s:1:"C";s:2:"85";s:2:"WX";s:3:"722";s:1:"N";s:1:"U";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-19";i:2;s:3:"701";i:3;s:3:"676";}}i:86;a:4:{s:1:"C";s:2:"86";s:2:"WX";s:3:"722";s:1:"N";s:1:"V";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-18";i:2;s:3:"701";i:3;s:3:"676";}}s:1:"V";a:4:{s:1:"C";s:2:"86";s:2:"WX";s:3:"722";s:1:"N";s:1:"V";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-18";i:2;s:3:"701";i:3;s:3:"676";}}i:87;a:4:{s:1:"C";s:2:"87";s:2:"WX";s:4:"1000";s:1:"N";s:1:"W";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:3:"-15";i:2;s:3:"981";i:3;s:3:"676";}}s:1:"W";a:4:{s:1:"C";s:2:"87";s:2:"WX";s:4:"1000";s:1:"N";s:1:"W";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:3:"-15";i:2;s:3:"981";i:3;s:3:"676";}}i:88;a:4:{s:1:"C";s:2:"88";s:2:"WX";s:3:"722";s:1:"N";s:1:"X";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"699";i:3;s:3:"676";}}s:1:"X";a:4:{s:1:"C";s:2:"88";s:2:"WX";s:3:"722";s:1:"N";s:1:"X";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"699";i:3;s:3:"676";}}i:89;a:4:{s:1:"C";s:2:"89";s:2:"WX";s:3:"722";s:1:"N";s:1:"Y";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:1:"0";i:2;s:3:"699";i:3;s:3:"676";}}s:1:"Y";a:4:{s:1:"C";s:2:"89";s:2:"WX";s:3:"722";s:1:"N";s:1:"Y";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:1:"0";i:2;s:3:"699";i:3;s:3:"676";}}i:90;a:4:{s:1:"C";s:2:"90";s:2:"WX";s:3:"667";s:1:"N";s:1:"Z";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:1:"0";i:2;s:3:"634";i:3;s:3:"676";}}s:1:"Z";a:4:{s:1:"C";s:2:"90";s:2:"WX";s:3:"667";s:1:"N";s:1:"Z";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:1:"0";i:2;s:3:"634";i:3;s:3:"676";}}i:91;a:4:{s:1:"C";s:2:"91";s:2:"WX";s:3:"333";s:1:"N";s:11:"bracketleft";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:4:"-149";i:2;s:3:"301";i:3;s:3:"678";}}s:11:"bracketleft";a:4:{s:1:"C";s:2:"91";s:2:"WX";s:3:"333";s:1:"N";s:11:"bracketleft";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:4:"-149";i:2;s:3:"301";i:3;s:3:"678";}}i:92;a:4:{s:1:"C";s:2:"92";s:2:"WX";s:3:"278";s:1:"N";s:9:"backslash";s:1:"B";a:4:{i:0;s:3:"-25";i:1;s:3:"-19";i:2;s:3:"303";i:3;s:3:"691";}}s:9:"backslash";a:4:{s:1:"C";s:2:"92";s:2:"WX";s:3:"278";s:1:"N";s:9:"backslash";s:1:"B";a:4:{i:0;s:3:"-25";i:1;s:3:"-19";i:2;s:3:"303";i:3;s:3:"691";}}i:93;a:4:{s:1:"C";s:2:"93";s:2:"WX";s:3:"333";s:1:"N";s:12:"bracketright";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:4:"-149";i:2;s:3:"266";i:3;s:3:"678";}}s:12:"bracketright";a:4:{s:1:"C";s:2:"93";s:2:"WX";s:3:"333";s:1:"N";s:12:"bracketright";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:4:"-149";i:2;s:3:"266";i:3;s:3:"678";}}i:94;a:4:{s:1:"C";s:2:"94";s:2:"WX";s:3:"581";s:1:"N";s:11:"asciicircum";s:1:"B";a:4:{i:0;s:2:"73";i:1;s:3:"311";i:2;s:3:"509";i:3;s:3:"676";}}s:11:"asciicircum";a:4:{s:1:"C";s:2:"94";s:2:"WX";s:3:"581";s:1:"N";s:11:"asciicircum";s:1:"B";a:4:{i:0;s:2:"73";i:1;s:3:"311";i:2;s:3:"509";i:3;s:3:"676";}}i:95;a:4:{s:1:"C";s:2:"95";s:2:"WX";s:3:"500";s:1:"N";s:10:"underscore";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:4:"-125";i:2;s:3:"500";i:3;s:3:"-75";}}s:10:"underscore";a:4:{s:1:"C";s:2:"95";s:2:"WX";s:3:"500";s:1:"N";s:10:"underscore";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:4:"-125";i:2;s:3:"500";i:3;s:3:"-75";}}i:96;a:4:{s:1:"C";s:2:"96";s:2:"WX";s:3:"333";s:1:"N";s:9:"quoteleft";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:3:"356";i:2;s:3:"254";i:3;s:3:"691";}}s:9:"quoteleft";a:4:{s:1:"C";s:2:"96";s:2:"WX";s:3:"333";s:1:"N";s:9:"quoteleft";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:3:"356";i:2;s:3:"254";i:3;s:3:"691";}}i:97;a:4:{s:1:"C";s:2:"97";s:2:"WX";s:3:"500";s:1:"N";s:1:"a";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-14";i:2;s:3:"488";i:3;s:3:"473";}}s:1:"a";a:4:{s:1:"C";s:2:"97";s:2:"WX";s:3:"500";s:1:"N";s:1:"a";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-14";i:2;s:3:"488";i:3;s:3:"473";}}i:98;a:4:{s:1:"C";s:2:"98";s:2:"WX";s:3:"556";s:1:"N";s:1:"b";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:3:"-14";i:2;s:3:"521";i:3;s:3:"676";}}s:1:"b";a:4:{s:1:"C";s:2:"98";s:2:"WX";s:3:"556";s:1:"N";s:1:"b";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:3:"-14";i:2;s:3:"521";i:3;s:3:"676";}}i:99;a:4:{s:1:"C";s:2:"99";s:2:"WX";s:3:"444";s:1:"N";s:1:"c";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-14";i:2;s:3:"430";i:3;s:3:"473";}}s:1:"c";a:4:{s:1:"C";s:2:"99";s:2:"WX";s:3:"444";s:1:"N";s:1:"c";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-14";i:2;s:3:"430";i:3;s:3:"473";}}i:100;a:4:{s:1:"C";s:3:"100";s:2:"WX";s:3:"556";s:1:"N";s:1:"d";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-14";i:2;s:3:"534";i:3;s:3:"676";}}s:1:"d";a:4:{s:1:"C";s:3:"100";s:2:"WX";s:3:"556";s:1:"N";s:1:"d";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-14";i:2;s:3:"534";i:3;s:3:"676";}}i:101;a:4:{s:1:"C";s:3:"101";s:2:"WX";s:3:"444";s:1:"N";s:1:"e";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-14";i:2;s:3:"426";i:3;s:3:"473";}}s:1:"e";a:4:{s:1:"C";s:3:"101";s:2:"WX";s:3:"444";s:1:"N";s:1:"e";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-14";i:2;s:3:"426";i:3;s:3:"473";}}i:102;a:5:{s:1:"C";s:3:"102";s:2:"WX";s:3:"333";s:1:"N";s:1:"f";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"389";i:3;s:3:"691";}s:1:"L";a:2:{i:0;s:1:"l";i:1;s:2:"fl";}}s:1:"f";a:5:{s:1:"C";s:3:"102";s:2:"WX";s:3:"333";s:1:"N";s:1:"f";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"389";i:3;s:3:"691";}s:1:"L";a:2:{i:0;s:1:"l";i:1;s:2:"fl";}}i:103;a:4:{s:1:"C";s:3:"103";s:2:"WX";s:3:"500";s:1:"N";s:1:"g";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:4:"-206";i:2;s:3:"483";i:3;s:3:"473";}}s:1:"g";a:4:{s:1:"C";s:3:"103";s:2:"WX";s:3:"500";s:1:"N";s:1:"g";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:4:"-206";i:2;s:3:"483";i:3;s:3:"473";}}i:104;a:4:{s:1:"C";s:3:"104";s:2:"WX";s:3:"556";s:1:"N";s:1:"h";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"534";i:3;s:3:"676";}}s:1:"h";a:4:{s:1:"C";s:3:"104";s:2:"WX";s:3:"556";s:1:"N";s:1:"h";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"534";i:3;s:3:"676";}}i:105;a:4:{s:1:"C";s:3:"105";s:2:"WX";s:3:"278";s:1:"N";s:1:"i";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"255";i:3;s:3:"691";}}s:1:"i";a:4:{s:1:"C";s:3:"105";s:2:"WX";s:3:"278";s:1:"N";s:1:"i";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"255";i:3;s:3:"691";}}i:106;a:4:{s:1:"C";s:3:"106";s:2:"WX";s:3:"333";s:1:"N";s:1:"j";s:1:"B";a:4:{i:0;s:3:"-57";i:1;s:4:"-203";i:2;s:3:"263";i:3;s:3:"691";}}s:1:"j";a:4:{s:1:"C";s:3:"106";s:2:"WX";s:3:"333";s:1:"N";s:1:"j";s:1:"B";a:4:{i:0;s:3:"-57";i:1;s:4:"-203";i:2;s:3:"263";i:3;s:3:"691";}}i:107;a:4:{s:1:"C";s:3:"107";s:2:"WX";s:3:"556";s:1:"N";s:1:"k";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:1:"0";i:2;s:3:"543";i:3;s:3:"676";}}s:1:"k";a:4:{s:1:"C";s:3:"107";s:2:"WX";s:3:"556";s:1:"N";s:1:"k";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:1:"0";i:2;s:3:"543";i:3;s:3:"676";}}i:108;a:4:{s:1:"C";s:3:"108";s:2:"WX";s:3:"278";s:1:"N";s:1:"l";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"255";i:3;s:3:"676";}}s:1:"l";a:4:{s:1:"C";s:3:"108";s:2:"WX";s:3:"278";s:1:"N";s:1:"l";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"255";i:3;s:3:"676";}}i:109;a:4:{s:1:"C";s:3:"109";s:2:"WX";s:3:"833";s:1:"N";s:1:"m";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"814";i:3;s:3:"473";}}s:1:"m";a:4:{s:1:"C";s:3:"109";s:2:"WX";s:3:"833";s:1:"N";s:1:"m";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"814";i:3;s:3:"473";}}i:110;a:4:{s:1:"C";s:3:"110";s:2:"WX";s:3:"556";s:1:"N";s:1:"n";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:1:"0";i:2;s:3:"539";i:3;s:3:"473";}}s:1:"n";a:4:{s:1:"C";s:3:"110";s:2:"WX";s:3:"556";s:1:"N";s:1:"n";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:1:"0";i:2;s:3:"539";i:3;s:3:"473";}}i:111;a:4:{s:1:"C";s:3:"111";s:2:"WX";s:3:"500";s:1:"N";s:1:"o";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-14";i:2;s:3:"476";i:3;s:3:"473";}}s:1:"o";a:4:{s:1:"C";s:3:"111";s:2:"WX";s:3:"500";s:1:"N";s:1:"o";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-14";i:2;s:3:"476";i:3;s:3:"473";}}i:112;a:4:{s:1:"C";s:3:"112";s:2:"WX";s:3:"556";s:1:"N";s:1:"p";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:4:"-205";i:2;s:3:"524";i:3;s:3:"473";}}s:1:"p";a:4:{s:1:"C";s:3:"112";s:2:"WX";s:3:"556";s:1:"N";s:1:"p";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:4:"-205";i:2;s:3:"524";i:3;s:3:"473";}}i:113;a:4:{s:1:"C";s:3:"113";s:2:"WX";s:3:"556";s:1:"N";s:1:"q";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:4:"-205";i:2;s:3:"536";i:3;s:3:"473";}}s:1:"q";a:4:{s:1:"C";s:3:"113";s:2:"WX";s:3:"556";s:1:"N";s:1:"q";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:4:"-205";i:2;s:3:"536";i:3;s:3:"473";}}i:114;a:4:{s:1:"C";s:3:"114";s:2:"WX";s:3:"444";s:1:"N";s:1:"r";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:1:"0";i:2;s:3:"434";i:3;s:3:"473";}}s:1:"r";a:4:{s:1:"C";s:3:"114";s:2:"WX";s:3:"444";s:1:"N";s:1:"r";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:1:"0";i:2;s:3:"434";i:3;s:3:"473";}}i:115;a:4:{s:1:"C";s:3:"115";s:2:"WX";s:3:"389";s:1:"N";s:1:"s";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-14";i:2;s:3:"361";i:3;s:3:"473";}}s:1:"s";a:4:{s:1:"C";s:3:"115";s:2:"WX";s:3:"389";s:1:"N";s:1:"s";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-14";i:2;s:3:"361";i:3;s:3:"473";}}i:116;a:4:{s:1:"C";s:3:"116";s:2:"WX";s:3:"333";s:1:"N";s:1:"t";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:3:"-12";i:2;s:3:"332";i:3;s:3:"630";}}s:1:"t";a:4:{s:1:"C";s:3:"116";s:2:"WX";s:3:"333";s:1:"N";s:1:"t";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:3:"-12";i:2;s:3:"332";i:3;s:3:"630";}}i:117;a:4:{s:1:"C";s:3:"117";s:2:"WX";s:3:"556";s:1:"N";s:1:"u";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-14";i:2;s:3:"537";i:3;s:3:"461";}}s:1:"u";a:4:{s:1:"C";s:3:"117";s:2:"WX";s:3:"556";s:1:"N";s:1:"u";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-14";i:2;s:3:"537";i:3;s:3:"461";}}i:118;a:4:{s:1:"C";s:3:"118";s:2:"WX";s:3:"500";s:1:"N";s:1:"v";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:3:"-14";i:2;s:3:"485";i:3;s:3:"461";}}s:1:"v";a:4:{s:1:"C";s:3:"118";s:2:"WX";s:3:"500";s:1:"N";s:1:"v";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:3:"-14";i:2;s:3:"485";i:3;s:3:"461";}}i:119;a:4:{s:1:"C";s:3:"119";s:2:"WX";s:3:"722";s:1:"N";s:1:"w";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:3:"-14";i:2;s:3:"707";i:3;s:3:"461";}}s:1:"w";a:4:{s:1:"C";s:3:"119";s:2:"WX";s:3:"722";s:1:"N";s:1:"w";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:3:"-14";i:2;s:3:"707";i:3;s:3:"461";}}i:120;a:4:{s:1:"C";s:3:"120";s:2:"WX";s:3:"500";s:1:"N";s:1:"x";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"484";i:3;s:3:"461";}}s:1:"x";a:4:{s:1:"C";s:3:"120";s:2:"WX";s:3:"500";s:1:"N";s:1:"x";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"484";i:3;s:3:"461";}}i:121;a:4:{s:1:"C";s:3:"121";s:2:"WX";s:3:"500";s:1:"N";s:1:"y";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:4:"-205";i:2;s:3:"480";i:3;s:3:"461";}}s:1:"y";a:4:{s:1:"C";s:3:"121";s:2:"WX";s:3:"500";s:1:"N";s:1:"y";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:4:"-205";i:2;s:3:"480";i:3;s:3:"461";}}i:122;a:4:{s:1:"C";s:3:"122";s:2:"WX";s:3:"444";s:1:"N";s:1:"z";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:1:"0";i:2;s:3:"420";i:3;s:3:"461";}}s:1:"z";a:4:{s:1:"C";s:3:"122";s:2:"WX";s:3:"444";s:1:"N";s:1:"z";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:1:"0";i:2;s:3:"420";i:3;s:3:"461";}}i:123;a:4:{s:1:"C";s:3:"123";s:2:"WX";s:3:"394";s:1:"N";s:9:"braceleft";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:4:"-175";i:2;s:3:"340";i:3;s:3:"698";}}s:9:"braceleft";a:4:{s:1:"C";s:3:"123";s:2:"WX";s:3:"394";s:1:"N";s:9:"braceleft";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:4:"-175";i:2;s:3:"340";i:3;s:3:"698";}}i:124;a:4:{s:1:"C";s:3:"124";s:2:"WX";s:3:"220";s:1:"N";s:3:"bar";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:4:"-218";i:2;s:3:"154";i:3;s:3:"782";}}s:3:"bar";a:4:{s:1:"C";s:3:"124";s:2:"WX";s:3:"220";s:1:"N";s:3:"bar";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:4:"-218";i:2;s:3:"154";i:3;s:3:"782";}}i:125;a:4:{s:1:"C";s:3:"125";s:2:"WX";s:3:"394";s:1:"N";s:10:"braceright";s:1:"B";a:4:{i:0;s:2:"54";i:1;s:4:"-175";i:2;s:3:"372";i:3;s:3:"698";}}s:10:"braceright";a:4:{s:1:"C";s:3:"125";s:2:"WX";s:3:"394";s:1:"N";s:10:"braceright";s:1:"B";a:4:{i:0;s:2:"54";i:1;s:4:"-175";i:2;s:3:"372";i:3;s:3:"698";}}i:126;a:4:{s:1:"C";s:3:"126";s:2:"WX";s:3:"520";s:1:"N";s:10:"asciitilde";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:3:"173";i:2;s:3:"491";i:3;s:3:"333";}}s:10:"asciitilde";a:4:{s:1:"C";s:3:"126";s:2:"WX";s:3:"520";s:1:"N";s:10:"asciitilde";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:3:"173";i:2;s:3:"491";i:3;s:3:"333";}}i:161;a:4:{s:1:"C";s:3:"161";s:2:"WX";s:3:"333";s:1:"N";s:10:"exclamdown";s:1:"B";a:4:{i:0;s:2:"82";i:1;s:4:"-203";i:2;s:3:"252";i:3;s:3:"501";}}s:10:"exclamdown";a:4:{s:1:"C";s:3:"161";s:2:"WX";s:3:"333";s:1:"N";s:10:"exclamdown";s:1:"B";a:4:{i:0;s:2:"82";i:1;s:4:"-203";i:2;s:3:"252";i:3;s:3:"501";}}i:162;a:4:{s:1:"C";s:3:"162";s:2:"WX";s:3:"500";s:1:"N";s:4:"cent";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:4:"-140";i:2;s:3:"458";i:3;s:3:"588";}}s:4:"cent";a:4:{s:1:"C";s:3:"162";s:2:"WX";s:3:"500";s:1:"N";s:4:"cent";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:4:"-140";i:2;s:3:"458";i:3;s:3:"588";}}i:163;a:4:{s:1:"C";s:3:"163";s:2:"WX";s:3:"500";s:1:"N";s:8:"sterling";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:3:"-14";i:2;s:3:"477";i:3;s:3:"684";}}s:8:"sterling";a:4:{s:1:"C";s:3:"163";s:2:"WX";s:3:"500";s:1:"N";s:8:"sterling";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:3:"-14";i:2;s:3:"477";i:3;s:3:"684";}}i:164;a:4:{s:1:"C";s:3:"164";s:2:"WX";s:3:"167";s:1:"N";s:8:"fraction";s:1:"B";a:4:{i:0;s:4:"-168";i:1;s:3:"-12";i:2;s:3:"329";i:3;s:3:"688";}}s:8:"fraction";a:4:{s:1:"C";s:3:"164";s:2:"WX";s:3:"167";s:1:"N";s:8:"fraction";s:1:"B";a:4:{i:0;s:4:"-168";i:1;s:3:"-12";i:2;s:3:"329";i:3;s:3:"688";}}i:165;a:4:{s:1:"C";s:3:"165";s:2:"WX";s:3:"500";s:1:"N";s:3:"yen";s:1:"B";a:4:{i:0;s:3:"-64";i:1;s:1:"0";i:2;s:3:"547";i:3;s:3:"676";}}s:3:"yen";a:4:{s:1:"C";s:3:"165";s:2:"WX";s:3:"500";s:1:"N";s:3:"yen";s:1:"B";a:4:{i:0;s:3:"-64";i:1;s:1:"0";i:2;s:3:"547";i:3;s:3:"676";}}i:166;a:4:{s:1:"C";s:3:"166";s:2:"WX";s:3:"500";s:1:"N";s:6:"florin";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:4:"-155";i:2;s:3:"498";i:3;s:3:"706";}}s:6:"florin";a:4:{s:1:"C";s:3:"166";s:2:"WX";s:3:"500";s:1:"N";s:6:"florin";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:4:"-155";i:2;s:3:"498";i:3;s:3:"706";}}i:167;a:4:{s:1:"C";s:3:"167";s:2:"WX";s:3:"500";s:1:"N";s:7:"section";s:1:"B";a:4:{i:0;s:2:"57";i:1;s:4:"-132";i:2;s:3:"443";i:3;s:3:"691";}}s:7:"section";a:4:{s:1:"C";s:3:"167";s:2:"WX";s:3:"500";s:1:"N";s:7:"section";s:1:"B";a:4:{i:0;s:2:"57";i:1;s:4:"-132";i:2;s:3:"443";i:3;s:3:"691";}}i:168;a:4:{s:1:"C";s:3:"168";s:2:"WX";s:3:"500";s:1:"N";s:8:"currency";s:1:"B";a:4:{i:0;s:3:"-26";i:1;s:2:"61";i:2;s:3:"526";i:3;s:3:"613";}}s:8:"currency";a:4:{s:1:"C";s:3:"168";s:2:"WX";s:3:"500";s:1:"N";s:8:"currency";s:1:"B";a:4:{i:0;s:3:"-26";i:1;s:2:"61";i:2;s:3:"526";i:3;s:3:"613";}}i:169;a:4:{s:1:"C";s:3:"169";s:2:"WX";s:3:"278";s:1:"N";s:11:"quotesingle";s:1:"B";a:4:{i:0;s:2:"75";i:1;s:3:"404";i:2;s:3:"204";i:3;s:3:"691";}}s:11:"quotesingle";a:4:{s:1:"C";s:3:"169";s:2:"WX";s:3:"278";s:1:"N";s:11:"quotesingle";s:1:"B";a:4:{i:0;s:2:"75";i:1;s:3:"404";i:2;s:3:"204";i:3;s:3:"691";}}i:170;a:4:{s:1:"C";s:3:"170";s:2:"WX";s:3:"500";s:1:"N";s:12:"quotedblleft";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:3:"356";i:2;s:3:"486";i:3;s:3:"691";}}s:12:"quotedblleft";a:4:{s:1:"C";s:3:"170";s:2:"WX";s:3:"500";s:1:"N";s:12:"quotedblleft";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:3:"356";i:2;s:3:"486";i:3;s:3:"691";}}i:171;a:4:{s:1:"C";s:3:"171";s:2:"WX";s:3:"500";s:1:"N";s:13:"guillemotleft";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:2:"36";i:2;s:3:"473";i:3;s:3:"415";}}s:13:"guillemotleft";a:4:{s:1:"C";s:3:"171";s:2:"WX";s:3:"500";s:1:"N";s:13:"guillemotleft";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:2:"36";i:2;s:3:"473";i:3;s:3:"415";}}i:172;a:4:{s:1:"C";s:3:"172";s:2:"WX";s:3:"333";s:1:"N";s:13:"guilsinglleft";s:1:"B";a:4:{i:0;s:2:"51";i:1;s:2:"36";i:2;s:3:"305";i:3;s:3:"415";}}s:13:"guilsinglleft";a:4:{s:1:"C";s:3:"172";s:2:"WX";s:3:"333";s:1:"N";s:13:"guilsinglleft";s:1:"B";a:4:{i:0;s:2:"51";i:1;s:2:"36";i:2;s:3:"305";i:3;s:3:"415";}}i:173;a:4:{s:1:"C";s:3:"173";s:2:"WX";s:3:"333";s:1:"N";s:14:"guilsinglright";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:2:"36";i:2;s:3:"282";i:3;s:3:"415";}}s:14:"guilsinglright";a:4:{s:1:"C";s:3:"173";s:2:"WX";s:3:"333";s:1:"N";s:14:"guilsinglright";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:2:"36";i:2;s:3:"282";i:3;s:3:"415";}}i:174;a:4:{s:1:"C";s:3:"174";s:2:"WX";s:3:"556";s:1:"N";s:2:"fi";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"536";i:3;s:3:"691";}}s:2:"fi";a:4:{s:1:"C";s:3:"174";s:2:"WX";s:3:"556";s:1:"N";s:2:"fi";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"536";i:3;s:3:"691";}}i:175;a:4:{s:1:"C";s:3:"175";s:2:"WX";s:3:"556";s:1:"N";s:2:"fl";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"536";i:3;s:3:"691";}}s:2:"fl";a:4:{s:1:"C";s:3:"175";s:2:"WX";s:3:"556";s:1:"N";s:2:"fl";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"536";i:3;s:3:"691";}}i:177;a:4:{s:1:"C";s:3:"177";s:2:"WX";s:3:"500";s:1:"N";s:6:"endash";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"181";i:2;s:3:"500";i:3;s:3:"271";}}s:6:"endash";a:4:{s:1:"C";s:3:"177";s:2:"WX";s:3:"500";s:1:"N";s:6:"endash";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"181";i:2;s:3:"500";i:3;s:3:"271";}}i:178;a:4:{s:1:"C";s:3:"178";s:2:"WX";s:3:"500";s:1:"N";s:6:"dagger";s:1:"B";a:4:{i:0;s:2:"47";i:1;s:4:"-134";i:2;s:3:"453";i:3;s:3:"691";}}s:6:"dagger";a:4:{s:1:"C";s:3:"178";s:2:"WX";s:3:"500";s:1:"N";s:6:"dagger";s:1:"B";a:4:{i:0;s:2:"47";i:1;s:4:"-134";i:2;s:3:"453";i:3;s:3:"691";}}i:179;a:4:{s:1:"C";s:3:"179";s:2:"WX";s:3:"500";s:1:"N";s:9:"daggerdbl";s:1:"B";a:4:{i:0;s:2:"45";i:1;s:4:"-132";i:2;s:3:"456";i:3;s:3:"691";}}s:9:"daggerdbl";a:4:{s:1:"C";s:3:"179";s:2:"WX";s:3:"500";s:1:"N";s:9:"daggerdbl";s:1:"B";a:4:{i:0;s:2:"45";i:1;s:4:"-132";i:2;s:3:"456";i:3;s:3:"691";}}i:180;a:4:{s:1:"C";s:3:"180";s:2:"WX";s:3:"250";s:1:"N";s:14:"periodcentered";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:3:"248";i:2;s:3:"210";i:3;s:3:"417";}}s:14:"periodcentered";a:4:{s:1:"C";s:3:"180";s:2:"WX";s:3:"250";s:1:"N";s:14:"periodcentered";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:3:"248";i:2;s:3:"210";i:3;s:3:"417";}}i:182;a:4:{s:1:"C";s:3:"182";s:2:"WX";s:3:"540";s:1:"N";s:9:"paragraph";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:4:"-186";i:2;s:3:"519";i:3;s:3:"676";}}s:9:"paragraph";a:4:{s:1:"C";s:3:"182";s:2:"WX";s:3:"540";s:1:"N";s:9:"paragraph";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:4:"-186";i:2;s:3:"519";i:3;s:3:"676";}}i:183;a:4:{s:1:"C";s:3:"183";s:2:"WX";s:3:"350";s:1:"N";s:6:"bullet";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"198";i:2;s:3:"315";i:3;s:3:"478";}}s:6:"bullet";a:4:{s:1:"C";s:3:"183";s:2:"WX";s:3:"350";s:1:"N";s:6:"bullet";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"198";i:2;s:3:"315";i:3;s:3:"478";}}i:184;a:4:{s:1:"C";s:3:"184";s:2:"WX";s:3:"333";s:1:"N";s:14:"quotesinglbase";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:4:"-180";i:2;s:3:"263";i:3;s:3:"155";}}s:14:"quotesinglbase";a:4:{s:1:"C";s:3:"184";s:2:"WX";s:3:"333";s:1:"N";s:14:"quotesinglbase";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:4:"-180";i:2;s:3:"263";i:3;s:3:"155";}}i:185;a:4:{s:1:"C";s:3:"185";s:2:"WX";s:3:"500";s:1:"N";s:12:"quotedblbase";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:4:"-180";i:2;s:3:"468";i:3;s:3:"155";}}s:12:"quotedblbase";a:4:{s:1:"C";s:3:"185";s:2:"WX";s:3:"500";s:1:"N";s:12:"quotedblbase";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:4:"-180";i:2;s:3:"468";i:3;s:3:"155";}}i:186;a:4:{s:1:"C";s:3:"186";s:2:"WX";s:3:"500";s:1:"N";s:13:"quotedblright";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:3:"356";i:2;s:3:"468";i:3;s:3:"691";}}s:13:"quotedblright";a:4:{s:1:"C";s:3:"186";s:2:"WX";s:3:"500";s:1:"N";s:13:"quotedblright";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:3:"356";i:2;s:3:"468";i:3;s:3:"691";}}i:187;a:4:{s:1:"C";s:3:"187";s:2:"WX";s:3:"500";s:1:"N";s:14:"guillemotright";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:2:"36";i:2;s:3:"477";i:3;s:3:"415";}}s:14:"guillemotright";a:4:{s:1:"C";s:3:"187";s:2:"WX";s:3:"500";s:1:"N";s:14:"guillemotright";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:2:"36";i:2;s:3:"477";i:3;s:3:"415";}}i:188;a:4:{s:1:"C";s:3:"188";s:2:"WX";s:4:"1000";s:1:"N";s:8:"ellipsis";s:1:"B";a:4:{i:0;s:2:"82";i:1;s:3:"-13";i:2;s:3:"917";i:3;s:3:"156";}}s:8:"ellipsis";a:4:{s:1:"C";s:3:"188";s:2:"WX";s:4:"1000";s:1:"N";s:8:"ellipsis";s:1:"B";a:4:{i:0;s:2:"82";i:1;s:3:"-13";i:2;s:3:"917";i:3;s:3:"156";}}i:189;a:4:{s:1:"C";s:3:"189";s:2:"WX";s:4:"1000";s:1:"N";s:11:"perthousand";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:3:"-29";i:2;s:3:"995";i:3;s:3:"706";}}s:11:"perthousand";a:4:{s:1:"C";s:3:"189";s:2:"WX";s:4:"1000";s:1:"N";s:11:"perthousand";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:3:"-29";i:2;s:3:"995";i:3;s:3:"706";}}i:191;a:4:{s:1:"C";s:3:"191";s:2:"WX";s:3:"500";s:1:"N";s:12:"questiondown";s:1:"B";a:4:{i:0;s:2:"55";i:1;s:4:"-201";i:2;s:3:"443";i:3;s:3:"501";}}s:12:"questiondown";a:4:{s:1:"C";s:3:"191";s:2:"WX";s:3:"500";s:1:"N";s:12:"questiondown";s:1:"B";a:4:{i:0;s:2:"55";i:1;s:4:"-201";i:2;s:3:"443";i:3;s:3:"501";}}i:193;a:4:{s:1:"C";s:3:"193";s:2:"WX";s:3:"333";s:1:"N";s:5:"grave";s:1:"B";a:4:{i:0;s:1:"8";i:1;s:3:"528";i:2;s:3:"246";i:3;s:3:"713";}}s:5:"grave";a:4:{s:1:"C";s:3:"193";s:2:"WX";s:3:"333";s:1:"N";s:5:"grave";s:1:"B";a:4:{i:0;s:1:"8";i:1;s:3:"528";i:2;s:3:"246";i:3;s:3:"713";}}i:194;a:4:{s:1:"C";s:3:"194";s:2:"WX";s:3:"333";s:1:"N";s:5:"acute";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:3:"528";i:2;s:3:"324";i:3;s:3:"713";}}s:5:"acute";a:4:{s:1:"C";s:3:"194";s:2:"WX";s:3:"333";s:1:"N";s:5:"acute";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:3:"528";i:2;s:3:"324";i:3;s:3:"713";}}i:195;a:4:{s:1:"C";s:3:"195";s:2:"WX";s:3:"333";s:1:"N";s:10:"circumflex";s:1:"B";a:4:{i:0;s:2:"-2";i:1;s:3:"528";i:2;s:3:"335";i:3;s:3:"704";}}s:10:"circumflex";a:4:{s:1:"C";s:3:"195";s:2:"WX";s:3:"333";s:1:"N";s:10:"circumflex";s:1:"B";a:4:{i:0;s:2:"-2";i:1;s:3:"528";i:2;s:3:"335";i:3;s:3:"704";}}i:196;a:4:{s:1:"C";s:3:"196";s:2:"WX";s:3:"333";s:1:"N";s:5:"tilde";s:1:"B";a:4:{i:0;s:3:"-16";i:1;s:3:"547";i:2;s:3:"349";i:3;s:3:"674";}}s:5:"tilde";a:4:{s:1:"C";s:3:"196";s:2:"WX";s:3:"333";s:1:"N";s:5:"tilde";s:1:"B";a:4:{i:0;s:3:"-16";i:1;s:3:"547";i:2;s:3:"349";i:3;s:3:"674";}}i:197;a:4:{s:1:"C";s:3:"197";s:2:"WX";s:3:"333";s:1:"N";s:6:"macron";s:1:"B";a:4:{i:0;s:1:"1";i:1;s:3:"565";i:2;s:3:"331";i:3;s:3:"637";}}s:6:"macron";a:4:{s:1:"C";s:3:"197";s:2:"WX";s:3:"333";s:1:"N";s:6:"macron";s:1:"B";a:4:{i:0;s:1:"1";i:1;s:3:"565";i:2;s:3:"331";i:3;s:3:"637";}}i:198;a:4:{s:1:"C";s:3:"198";s:2:"WX";s:3:"333";s:1:"N";s:5:"breve";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:3:"528";i:2;s:3:"318";i:3;s:3:"691";}}s:5:"breve";a:4:{s:1:"C";s:3:"198";s:2:"WX";s:3:"333";s:1:"N";s:5:"breve";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:3:"528";i:2;s:3:"318";i:3;s:3:"691";}}i:199;a:4:{s:1:"C";s:3:"199";s:2:"WX";s:3:"333";s:1:"N";s:9:"dotaccent";s:1:"B";a:4:{i:0;s:3:"103";i:1;s:3:"536";i:2;s:3:"258";i:3;s:3:"691";}}s:9:"dotaccent";a:4:{s:1:"C";s:3:"199";s:2:"WX";s:3:"333";s:1:"N";s:9:"dotaccent";s:1:"B";a:4:{i:0;s:3:"103";i:1;s:3:"536";i:2;s:3:"258";i:3;s:3:"691";}}i:200;a:4:{s:1:"C";s:3:"200";s:2:"WX";s:3:"333";s:1:"N";s:8:"dieresis";s:1:"B";a:4:{i:0;s:2:"-2";i:1;s:3:"537";i:2;s:3:"335";i:3;s:3:"667";}}s:8:"dieresis";a:4:{s:1:"C";s:3:"200";s:2:"WX";s:3:"333";s:1:"N";s:8:"dieresis";s:1:"B";a:4:{i:0;s:2:"-2";i:1;s:3:"537";i:2;s:3:"335";i:3;s:3:"667";}}i:202;a:4:{s:1:"C";s:3:"202";s:2:"WX";s:3:"333";s:1:"N";s:4:"ring";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:3:"527";i:2;s:3:"273";i:3;s:3:"740";}}s:4:"ring";a:4:{s:1:"C";s:3:"202";s:2:"WX";s:3:"333";s:1:"N";s:4:"ring";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:3:"527";i:2;s:3:"273";i:3;s:3:"740";}}i:203;a:4:{s:1:"C";s:3:"203";s:2:"WX";s:3:"333";s:1:"N";s:7:"cedilla";s:1:"B";a:4:{i:0;s:2:"68";i:1;s:4:"-218";i:2;s:3:"294";i:3;s:1:"0";}}s:7:"cedilla";a:4:{s:1:"C";s:3:"203";s:2:"WX";s:3:"333";s:1:"N";s:7:"cedilla";s:1:"B";a:4:{i:0;s:2:"68";i:1;s:4:"-218";i:2;s:3:"294";i:3;s:1:"0";}}i:205;a:4:{s:1:"C";s:3:"205";s:2:"WX";s:3:"333";s:1:"N";s:12:"hungarumlaut";s:1:"B";a:4:{i:0;s:3:"-13";i:1;s:3:"528";i:2;s:3:"425";i:3;s:3:"713";}}s:12:"hungarumlaut";a:4:{s:1:"C";s:3:"205";s:2:"WX";s:3:"333";s:1:"N";s:12:"hungarumlaut";s:1:"B";a:4:{i:0;s:3:"-13";i:1;s:3:"528";i:2;s:3:"425";i:3;s:3:"713";}}i:206;a:4:{s:1:"C";s:3:"206";s:2:"WX";s:3:"333";s:1:"N";s:6:"ogonek";s:1:"B";a:4:{i:0;s:2:"90";i:1;s:4:"-193";i:2;s:3:"319";i:3;s:2:"24";}}s:6:"ogonek";a:4:{s:1:"C";s:3:"206";s:2:"WX";s:3:"333";s:1:"N";s:6:"ogonek";s:1:"B";a:4:{i:0;s:2:"90";i:1;s:4:"-193";i:2;s:3:"319";i:3;s:2:"24";}}i:207;a:4:{s:1:"C";s:3:"207";s:2:"WX";s:3:"333";s:1:"N";s:5:"caron";s:1:"B";a:4:{i:0;s:2:"-2";i:1;s:3:"528";i:2;s:3:"335";i:3;s:3:"704";}}s:5:"caron";a:4:{s:1:"C";s:3:"207";s:2:"WX";s:3:"333";s:1:"N";s:5:"caron";s:1:"B";a:4:{i:0;s:2:"-2";i:1;s:3:"528";i:2;s:3:"335";i:3;s:3:"704";}}i:208;a:4:{s:1:"C";s:3:"208";s:2:"WX";s:4:"1000";s:1:"N";s:6:"emdash";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"181";i:2;s:4:"1000";i:3;s:3:"271";}}s:6:"emdash";a:4:{s:1:"C";s:3:"208";s:2:"WX";s:4:"1000";s:1:"N";s:6:"emdash";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"181";i:2;s:4:"1000";i:3;s:3:"271";}}i:225;a:4:{s:1:"C";s:3:"225";s:2:"WX";s:4:"1000";s:1:"N";s:2:"AE";s:1:"B";a:4:{i:0;s:1:"4";i:1;s:1:"0";i:2;s:3:"951";i:3;s:3:"676";}}s:2:"AE";a:4:{s:1:"C";s:3:"225";s:2:"WX";s:4:"1000";s:1:"N";s:2:"AE";s:1:"B";a:4:{i:0;s:1:"4";i:1;s:1:"0";i:2;s:3:"951";i:3;s:3:"676";}}i:227;a:4:{s:1:"C";s:3:"227";s:2:"WX";s:3:"300";s:1:"N";s:11:"ordfeminine";s:1:"B";a:4:{i:0;s:2:"-1";i:1;s:3:"397";i:2;s:3:"301";i:3;s:3:"688";}}s:11:"ordfeminine";a:4:{s:1:"C";s:3:"227";s:2:"WX";s:3:"300";s:1:"N";s:11:"ordfeminine";s:1:"B";a:4:{i:0;s:2:"-1";i:1;s:3:"397";i:2;s:3:"301";i:3;s:3:"688";}}i:232;a:4:{s:1:"C";s:3:"232";s:2:"WX";s:3:"667";s:1:"N";s:6:"Lslash";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:1:"0";i:2;s:3:"638";i:3;s:3:"676";}}s:6:"Lslash";a:4:{s:1:"C";s:3:"232";s:2:"WX";s:3:"667";s:1:"N";s:6:"Lslash";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:1:"0";i:2;s:3:"638";i:3;s:3:"676";}}i:233;a:4:{s:1:"C";s:3:"233";s:2:"WX";s:3:"778";s:1:"N";s:6:"Oslash";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-74";i:2;s:3:"743";i:3;s:3:"737";}}s:6:"Oslash";a:4:{s:1:"C";s:3:"233";s:2:"WX";s:3:"778";s:1:"N";s:6:"Oslash";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-74";i:2;s:3:"743";i:3;s:3:"737";}}i:234;a:4:{s:1:"C";s:3:"234";s:2:"WX";s:4:"1000";s:1:"N";s:2:"OE";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:2:"-5";i:2;s:3:"981";i:3;s:3:"684";}}s:2:"OE";a:4:{s:1:"C";s:3:"234";s:2:"WX";s:4:"1000";s:1:"N";s:2:"OE";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:2:"-5";i:2;s:3:"981";i:3;s:3:"684";}}i:235;a:4:{s:1:"C";s:3:"235";s:2:"WX";s:3:"330";s:1:"N";s:12:"ordmasculine";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:3:"397";i:2;s:3:"312";i:3;s:3:"688";}}s:12:"ordmasculine";a:4:{s:1:"C";s:3:"235";s:2:"WX";s:3:"330";s:1:"N";s:12:"ordmasculine";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:3:"397";i:2;s:3:"312";i:3;s:3:"688";}}i:241;a:4:{s:1:"C";s:3:"241";s:2:"WX";s:3:"722";s:1:"N";s:2:"ae";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:3:"-14";i:2;s:3:"693";i:3;s:3:"473";}}s:2:"ae";a:4:{s:1:"C";s:3:"241";s:2:"WX";s:3:"722";s:1:"N";s:2:"ae";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:3:"-14";i:2;s:3:"693";i:3;s:3:"473";}}i:245;a:4:{s:1:"C";s:3:"245";s:2:"WX";s:3:"278";s:1:"N";s:8:"dotlessi";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"255";i:3;s:3:"461";}}s:8:"dotlessi";a:4:{s:1:"C";s:3:"245";s:2:"WX";s:3:"278";s:1:"N";s:8:"dotlessi";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"255";i:3;s:3:"461";}}i:248;a:4:{s:1:"C";s:3:"248";s:2:"WX";s:3:"278";s:1:"N";s:6:"lslash";s:1:"B";a:4:{i:0;s:3:"-22";i:1;s:1:"0";i:2;s:3:"303";i:3;s:3:"676";}}s:6:"lslash";a:4:{s:1:"C";s:3:"248";s:2:"WX";s:3:"278";s:1:"N";s:6:"lslash";s:1:"B";a:4:{i:0;s:3:"-22";i:1;s:1:"0";i:2;s:3:"303";i:3;s:3:"676";}}i:249;a:4:{s:1:"C";s:3:"249";s:2:"WX";s:3:"500";s:1:"N";s:6:"oslash";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-92";i:2;s:3:"476";i:3;s:3:"549";}}s:6:"oslash";a:4:{s:1:"C";s:3:"249";s:2:"WX";s:3:"500";s:1:"N";s:6:"oslash";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-92";i:2;s:3:"476";i:3;s:3:"549";}}i:250;a:4:{s:1:"C";s:3:"250";s:2:"WX";s:3:"722";s:1:"N";s:2:"oe";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-14";i:2;s:3:"696";i:3;s:3:"473";}}s:2:"oe";a:4:{s:1:"C";s:3:"250";s:2:"WX";s:3:"722";s:1:"N";s:2:"oe";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-14";i:2;s:3:"696";i:3;s:3:"473";}}i:251;a:4:{s:1:"C";s:3:"251";s:2:"WX";s:3:"556";s:1:"N";s:10:"germandbls";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:3:"-12";i:2;s:3:"517";i:3;s:3:"691";}}s:10:"germandbls";a:4:{s:1:"C";s:3:"251";s:2:"WX";s:3:"556";s:1:"N";s:10:"germandbls";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:3:"-12";i:2;s:3:"517";i:3;s:3:"691";}}s:9:"Idieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:9:"Idieresis";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"370";i:3;s:3:"877";}}s:6:"eacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:6:"eacute";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-14";i:2;s:3:"426";i:3;s:3:"713";}}s:6:"abreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"abreve";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-14";i:2;s:3:"488";i:3;s:3:"691";}}s:13:"uhungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:13:"uhungarumlaut";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-14";i:2;s:3:"557";i:3;s:3:"713";}}s:6:"ecaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:6:"ecaron";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-14";i:2;s:3:"426";i:3;s:3:"704";}}s:9:"Ydieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:9:"Ydieresis";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:1:"0";i:2;s:3:"699";i:3;s:3:"877";}}s:6:"divide";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"570";s:1:"N";s:6:"divide";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:3:"-31";i:2;s:3:"537";i:3;s:3:"537";}}s:6:"Yacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Yacute";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:1:"0";i:2;s:3:"699";i:3;s:3:"923";}}s:11:"Acircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:11:"Acircumflex";s:1:"B";a:4:{i:0;s:1:"9";i:1;s:1:"0";i:2;s:3:"689";i:3;s:3:"914";}}s:6:"aacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"aacute";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-14";i:2;s:3:"488";i:3;s:3:"713";}}s:11:"Ucircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:11:"Ucircumflex";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-19";i:2;s:3:"701";i:3;s:3:"914";}}s:6:"yacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"yacute";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:4:"-205";i:2;s:3:"480";i:3;s:3:"713";}}s:12:"scommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:12:"scommaaccent";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:4:"-218";i:2;s:3:"361";i:3;s:3:"473";}}s:11:"ecircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:11:"ecircumflex";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-14";i:2;s:3:"426";i:3;s:3:"704";}}s:5:"Uring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:5:"Uring";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-19";i:2;s:3:"701";i:3;s:3:"935";}}s:9:"Udieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:9:"Udieresis";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-19";i:2;s:3:"701";i:3;s:3:"877";}}s:7:"aogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:7:"aogonek";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:4:"-193";i:2;s:3:"504";i:3;s:3:"473";}}s:6:"Uacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Uacute";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-19";i:2;s:3:"701";i:3;s:3:"923";}}s:7:"uogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:7:"uogonek";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:4:"-193";i:2;s:3:"539";i:3;s:3:"461";}}s:9:"Edieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:9:"Edieresis";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"641";i:3;s:3:"877";}}s:6:"Dcroat";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Dcroat";s:1:"B";a:4:{i:0;s:1:"6";i:1;s:1:"0";i:2;s:3:"690";i:3;s:3:"676";}}s:11:"commaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"250";s:1:"N";s:11:"commaaccent";s:1:"B";a:4:{i:0;s:2:"47";i:1;s:4:"-218";i:2;s:3:"203";i:3;s:3:"-50";}}s:9:"copyright";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"747";s:1:"N";s:9:"copyright";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:3:"-19";i:2;s:3:"721";i:3;s:3:"691";}}s:7:"Emacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:7:"Emacron";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"641";i:3;s:3:"847";}}s:6:"ccaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:6:"ccaron";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-14";i:2;s:3:"430";i:3;s:3:"704";}}s:5:"aring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:5:"aring";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-14";i:2;s:3:"488";i:3;s:3:"740";}}s:12:"Ncommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:12:"Ncommaaccent";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:4:"-188";i:2;s:3:"701";i:3;s:3:"676";}}s:6:"lacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:6:"lacute";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"297";i:3;s:3:"923";}}s:6:"agrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"agrave";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-14";i:2;s:3:"488";i:3;s:3:"713";}}s:12:"Tcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:12:"Tcommaaccent";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:4:"-218";i:2;s:3:"636";i:3;s:3:"676";}}s:6:"Cacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Cacute";s:1:"B";a:4:{i:0;s:2:"49";i:1;s:3:"-19";i:2;s:3:"687";i:3;s:3:"923";}}s:6:"atilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"atilde";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-14";i:2;s:3:"488";i:3;s:3:"674";}}s:10:"Edotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:10:"Edotaccent";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"641";i:3;s:3:"901";}}s:6:"scaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:6:"scaron";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-14";i:2;s:3:"363";i:3;s:3:"704";}}s:8:"scedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:8:"scedilla";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:4:"-218";i:2;s:3:"361";i:3;s:3:"473";}}s:6:"iacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:6:"iacute";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"289";i:3;s:3:"713";}}s:7:"lozenge";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"494";s:1:"N";s:7:"lozenge";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:1:"0";i:2;s:3:"484";i:3;s:3:"745";}}s:6:"Rcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Rcaron";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"715";i:3;s:3:"914";}}s:12:"Gcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:12:"Gcommaaccent";s:1:"B";a:4:{i:0;s:2:"37";i:1;s:4:"-218";i:2;s:3:"755";i:3;s:3:"691";}}s:11:"ucircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:11:"ucircumflex";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-14";i:2;s:3:"537";i:3;s:3:"704";}}s:11:"acircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:11:"acircumflex";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-14";i:2;s:3:"488";i:3;s:3:"704";}}s:7:"Amacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:7:"Amacron";s:1:"B";a:4:{i:0;s:1:"9";i:1;s:1:"0";i:2;s:3:"689";i:3;s:3:"847";}}s:6:"rcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:6:"rcaron";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:1:"0";i:2;s:3:"434";i:3;s:3:"704";}}s:8:"ccedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:8:"ccedilla";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:4:"-218";i:2;s:3:"430";i:3;s:3:"473";}}s:10:"Zdotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:10:"Zdotaccent";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:1:"0";i:2;s:3:"634";i:3;s:3:"901";}}s:5:"Thorn";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:5:"Thorn";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"600";i:3;s:3:"676";}}s:7:"Omacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:7:"Omacron";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-19";i:2;s:3:"743";i:3;s:3:"847";}}s:6:"Racute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Racute";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"715";i:3;s:3:"923";}}s:6:"Sacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"Sacute";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-19";i:2;s:3:"513";i:3;s:3:"923";}}s:6:"dcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"672";s:1:"N";s:6:"dcaron";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-14";i:2;s:3:"681";i:3;s:3:"682";}}s:7:"Umacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:7:"Umacron";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-19";i:2;s:3:"701";i:3;s:3:"847";}}s:5:"uring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:5:"uring";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-14";i:2;s:3:"537";i:3;s:3:"740";}}s:13:"threesuperior";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"300";s:1:"N";s:13:"threesuperior";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:3:"268";i:2;s:3:"297";i:3;s:3:"688";}}s:6:"Ograve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:6:"Ograve";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-19";i:2;s:3:"743";i:3;s:3:"923";}}s:6:"Agrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Agrave";s:1:"B";a:4:{i:0;s:1:"9";i:1;s:1:"0";i:2;s:3:"689";i:3;s:3:"923";}}s:6:"Abreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Abreve";s:1:"B";a:4:{i:0;s:1:"9";i:1;s:1:"0";i:2;s:3:"689";i:3;s:3:"901";}}s:8:"multiply";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"570";s:1:"N";s:8:"multiply";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:2:"16";i:2;s:3:"522";i:3;s:3:"490";}}s:6:"uacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"uacute";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-14";i:2;s:3:"537";i:3;s:3:"713";}}s:6:"Tcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Tcaron";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:1:"0";i:2;s:3:"636";i:3;s:3:"914";}}s:11:"partialdiff";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"494";s:1:"N";s:11:"partialdiff";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:3:"-21";i:2;s:3:"494";i:3;s:3:"750";}}s:9:"ydieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:9:"ydieresis";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:4:"-205";i:2;s:3:"480";i:3;s:3:"667";}}s:6:"Nacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Nacute";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-18";i:2;s:3:"701";i:3;s:3:"923";}}s:11:"icircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:11:"icircumflex";s:1:"B";a:4:{i:0;s:3:"-37";i:1;s:1:"0";i:2;s:3:"300";i:3;s:3:"704";}}s:11:"Ecircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:11:"Ecircumflex";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"641";i:3;s:3:"914";}}s:9:"adieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:9:"adieresis";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-14";i:2;s:3:"488";i:3;s:3:"667";}}s:9:"edieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:9:"edieresis";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-14";i:2;s:3:"426";i:3;s:3:"667";}}s:6:"cacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:6:"cacute";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-14";i:2;s:3:"430";i:3;s:3:"713";}}s:6:"nacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"nacute";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:1:"0";i:2;s:3:"539";i:3;s:3:"713";}}s:7:"umacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:7:"umacron";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-14";i:2;s:3:"537";i:3;s:3:"637";}}s:6:"Ncaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Ncaron";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-18";i:2;s:3:"701";i:3;s:3:"914";}}s:6:"Iacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:6:"Iacute";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"370";i:3;s:3:"923";}}s:9:"plusminus";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"570";s:1:"N";s:9:"plusminus";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:1:"0";i:2;s:3:"537";i:3;s:3:"506";}}s:9:"brokenbar";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"220";s:1:"N";s:9:"brokenbar";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:4:"-143";i:2;s:3:"154";i:3;s:3:"707";}}s:10:"registered";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"747";s:1:"N";s:10:"registered";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:3:"-19";i:2;s:3:"721";i:3;s:3:"691";}}s:6:"Gbreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:6:"Gbreve";s:1:"B";a:4:{i:0;s:2:"37";i:1;s:3:"-19";i:2;s:3:"755";i:3;s:3:"901";}}s:10:"Idotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:10:"Idotaccent";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"370";i:3;s:3:"901";}}s:9:"summation";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"summation";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:3:"-10";i:2;s:3:"585";i:3;s:3:"706";}}s:6:"Egrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Egrave";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"641";i:3;s:3:"923";}}s:6:"racute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:6:"racute";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:1:"0";i:2;s:3:"434";i:3;s:3:"713";}}s:7:"omacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:7:"omacron";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-14";i:2;s:3:"476";i:3;s:3:"637";}}s:6:"Zacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Zacute";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:1:"0";i:2;s:3:"634";i:3;s:3:"923";}}s:6:"Zcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Zcaron";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:1:"0";i:2;s:3:"634";i:3;s:3:"914";}}s:12:"greaterequal";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"549";s:1:"N";s:12:"greaterequal";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"523";i:3;s:3:"704";}}s:3:"Eth";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:3:"Eth";s:1:"B";a:4:{i:0;s:1:"6";i:1;s:1:"0";i:2;s:3:"690";i:3;s:3:"676";}}s:8:"Ccedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:8:"Ccedilla";s:1:"B";a:4:{i:0;s:2:"49";i:1;s:4:"-218";i:2;s:3:"687";i:3;s:3:"691";}}s:12:"lcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:12:"lcommaaccent";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:4:"-218";i:2;s:3:"255";i:3;s:3:"676";}}s:6:"tcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"416";s:1:"N";s:6:"tcaron";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:3:"-12";i:2;s:3:"425";i:3;s:3:"815";}}s:7:"eogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:7:"eogonek";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:4:"-193";i:2;s:3:"426";i:3;s:3:"473";}}s:7:"Uogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:7:"Uogonek";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:4:"-193";i:2;s:3:"701";i:3;s:3:"676";}}s:6:"Aacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Aacute";s:1:"B";a:4:{i:0;s:1:"9";i:1;s:1:"0";i:2;s:3:"689";i:3;s:3:"923";}}s:9:"Adieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:9:"Adieresis";s:1:"B";a:4:{i:0;s:1:"9";i:1;s:1:"0";i:2;s:3:"689";i:3;s:3:"877";}}s:6:"egrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:6:"egrave";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-14";i:2;s:3:"426";i:3;s:3:"713";}}s:6:"zacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:6:"zacute";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:1:"0";i:2;s:3:"420";i:3;s:3:"713";}}s:7:"iogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:7:"iogonek";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:4:"-193";i:2;s:3:"274";i:3;s:3:"691";}}s:6:"Oacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:6:"Oacute";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-19";i:2;s:3:"743";i:3;s:3:"923";}}s:6:"oacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"oacute";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-14";i:2;s:3:"476";i:3;s:3:"713";}}s:7:"amacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:7:"amacron";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-14";i:2;s:3:"488";i:3;s:3:"637";}}s:6:"sacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:6:"sacute";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-14";i:2;s:3:"361";i:3;s:3:"713";}}s:9:"idieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:9:"idieresis";s:1:"B";a:4:{i:0;s:3:"-37";i:1;s:1:"0";i:2;s:3:"300";i:3;s:3:"667";}}s:11:"Ocircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:11:"Ocircumflex";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-19";i:2;s:3:"743";i:3;s:3:"914";}}s:6:"Ugrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Ugrave";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-19";i:2;s:3:"701";i:3;s:3:"923";}}s:5:"Delta";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"612";s:1:"N";s:5:"Delta";s:1:"B";a:4:{i:0;s:1:"6";i:1;s:1:"0";i:2;s:3:"608";i:3;s:3:"688";}}s:5:"thorn";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:5:"thorn";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:4:"-205";i:2;s:3:"524";i:3;s:3:"676";}}s:11:"twosuperior";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"300";s:1:"N";s:11:"twosuperior";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"275";i:2;s:3:"300";i:3;s:3:"688";}}s:9:"Odieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:9:"Odieresis";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-19";i:2;s:3:"743";i:3;s:3:"877";}}s:2:"mu";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:2:"mu";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:4:"-206";i:2;s:3:"536";i:3;s:3:"461";}}s:6:"igrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:6:"igrave";s:1:"B";a:4:{i:0;s:3:"-27";i:1;s:1:"0";i:2;s:3:"255";i:3;s:3:"713";}}s:13:"ohungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:13:"ohungarumlaut";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-14";i:2;s:3:"529";i:3;s:3:"713";}}s:7:"Eogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:7:"Eogonek";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:4:"-193";i:2;s:3:"644";i:3;s:3:"676";}}s:6:"dcroat";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"dcroat";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-14";i:2;s:3:"534";i:3;s:3:"676";}}s:13:"threequarters";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"750";s:1:"N";s:13:"threequarters";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:3:"-12";i:2;s:3:"733";i:3;s:3:"688";}}s:8:"Scedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:8:"Scedilla";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:4:"-218";i:2;s:3:"513";i:3;s:3:"692";}}s:6:"lcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"394";s:1:"N";s:6:"lcaron";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"412";i:3;s:3:"682";}}s:12:"Kcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:12:"Kcommaaccent";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:4:"-218";i:2;s:3:"769";i:3;s:3:"676";}}s:6:"Lacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Lacute";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:1:"0";i:2;s:3:"638";i:3;s:3:"923";}}s:9:"trademark";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:4:"1000";s:1:"N";s:9:"trademark";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:3:"271";i:2;s:3:"977";i:3;s:3:"676";}}s:10:"edotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:10:"edotaccent";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-14";i:2;s:3:"426";i:3;s:3:"691";}}s:6:"Igrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:6:"Igrave";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"370";i:3;s:3:"923";}}s:7:"Imacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:7:"Imacron";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"370";i:3;s:3:"847";}}s:6:"Lcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Lcaron";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:1:"0";i:2;s:3:"652";i:3;s:3:"682";}}s:7:"onehalf";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"750";s:1:"N";s:7:"onehalf";s:1:"B";a:4:{i:0;s:2:"-7";i:1;s:3:"-12";i:2;s:3:"775";i:3;s:3:"688";}}s:9:"lessequal";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"549";s:1:"N";s:9:"lessequal";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:1:"0";i:2;s:3:"526";i:3;s:3:"704";}}s:11:"ocircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:11:"ocircumflex";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-14";i:2;s:3:"476";i:3;s:3:"704";}}s:6:"ntilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"ntilde";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:1:"0";i:2;s:3:"539";i:3;s:3:"674";}}s:13:"Uhungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:13:"Uhungarumlaut";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-19";i:2;s:3:"701";i:3;s:3:"923";}}s:6:"Eacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Eacute";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"641";i:3;s:3:"923";}}s:7:"emacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:7:"emacron";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-14";i:2;s:3:"426";i:3;s:3:"637";}}s:6:"gbreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"gbreve";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:4:"-206";i:2;s:3:"483";i:3;s:3:"691";}}s:10:"onequarter";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"750";s:1:"N";s:10:"onequarter";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:3:"-12";i:2;s:3:"743";i:3;s:3:"688";}}s:6:"Scaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"Scaron";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-19";i:2;s:3:"513";i:3;s:3:"914";}}s:12:"Scommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:12:"Scommaaccent";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:4:"-218";i:2;s:3:"513";i:3;s:3:"692";}}s:13:"Ohungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:13:"Ohungarumlaut";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-19";i:2;s:3:"743";i:3;s:3:"923";}}s:6:"degree";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"400";s:1:"N";s:6:"degree";s:1:"B";a:4:{i:0;s:2:"57";i:1;s:3:"402";i:2;s:3:"343";i:3;s:3:"688";}}s:6:"ograve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"ograve";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-14";i:2;s:3:"476";i:3;s:3:"713";}}s:6:"Ccaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Ccaron";s:1:"B";a:4:{i:0;s:2:"49";i:1;s:3:"-19";i:2;s:3:"687";i:3;s:3:"914";}}s:6:"ugrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"ugrave";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-14";i:2;s:3:"537";i:3;s:3:"713";}}s:7:"radical";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"549";s:1:"N";s:7:"radical";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:3:"-46";i:2;s:3:"512";i:3;s:3:"850";}}s:6:"Dcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Dcaron";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:1:"0";i:2;s:3:"690";i:3;s:3:"914";}}s:12:"rcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:12:"rcommaaccent";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:4:"-218";i:2;s:3:"434";i:3;s:3:"473";}}s:6:"Ntilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Ntilde";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-18";i:2;s:3:"701";i:3;s:3:"884";}}s:6:"otilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"otilde";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-14";i:2;s:3:"476";i:3;s:3:"674";}}s:12:"Rcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:12:"Rcommaaccent";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:4:"-218";i:2;s:3:"715";i:3;s:3:"676";}}s:12:"Lcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:12:"Lcommaaccent";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:4:"-218";i:2;s:3:"638";i:3;s:3:"676";}}s:6:"Atilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Atilde";s:1:"B";a:4:{i:0;s:1:"9";i:1;s:1:"0";i:2;s:3:"689";i:3;s:3:"884";}}s:7:"Aogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:7:"Aogonek";s:1:"B";a:4:{i:0;s:1:"9";i:1;s:4:"-193";i:2;s:3:"699";i:3;s:3:"690";}}s:5:"Aring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:5:"Aring";s:1:"B";a:4:{i:0;s:1:"9";i:1;s:1:"0";i:2;s:3:"689";i:3;s:3:"935";}}s:6:"Otilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"778";s:1:"N";s:6:"Otilde";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-19";i:2;s:3:"743";i:3;s:3:"884";}}s:10:"zdotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:10:"zdotaccent";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:1:"0";i:2;s:3:"420";i:3;s:3:"691";}}s:6:"Ecaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Ecaron";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"641";i:3;s:3:"914";}}s:7:"Iogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:7:"Iogonek";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:4:"-193";i:2;s:3:"370";i:3;s:3:"676";}}s:12:"kcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:12:"kcommaaccent";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:4:"-218";i:2;s:3:"543";i:3;s:3:"676";}}s:5:"minus";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"570";s:1:"N";s:5:"minus";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:3:"209";i:2;s:3:"537";i:3;s:3:"297";}}s:11:"Icircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:11:"Icircumflex";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"370";i:3;s:3:"914";}}s:6:"ncaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"ncaron";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:1:"0";i:2;s:3:"539";i:3;s:3:"704";}}s:12:"tcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"333";s:1:"N";s:12:"tcommaaccent";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:4:"-218";i:2;s:3:"332";i:3;s:3:"630";}}s:10:"logicalnot";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"570";s:1:"N";s:10:"logicalnot";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:3:"108";i:2;s:3:"537";i:3;s:3:"399";}}s:9:"odieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:9:"odieresis";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-14";i:2;s:3:"476";i:3;s:3:"667";}}s:9:"udieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:9:"udieresis";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-14";i:2;s:3:"537";i:3;s:3:"667";}}s:8:"notequal";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"549";s:1:"N";s:8:"notequal";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:3:"-49";i:2;s:3:"540";i:3;s:3:"570";}}s:12:"gcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:12:"gcommaaccent";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:4:"-206";i:2;s:3:"483";i:3;s:3:"829";}}s:3:"eth";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:3:"eth";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-14";i:2;s:3:"476";i:3;s:3:"691";}}s:6:"zcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:6:"zcaron";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:1:"0";i:2;s:3:"420";i:3;s:3:"704";}}s:12:"ncommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:12:"ncommaaccent";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:4:"-218";i:2;s:3:"539";i:3;s:3:"473";}}s:11:"onesuperior";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"300";s:1:"N";s:11:"onesuperior";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:3:"275";i:2;s:3:"273";i:3;s:3:"688";}}s:7:"imacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:7:"imacron";s:1:"B";a:4:{i:0;s:2:"-8";i:1;s:1:"0";i:2;s:3:"272";i:3;s:3:"637";}}s:4:"Euro";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:4:"Euro";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}}s:3:"KPX";a:124:{s:1:"A";a:50:{s:1:"C";s:3:"-55";s:6:"Cacute";s:3:"-55";s:6:"Ccaron";s:3:"-55";s:8:"Ccedilla";s:3:"-55";s:1:"G";s:3:"-55";s:6:"Gbreve";s:3:"-55";s:12:"Gcommaaccent";s:3:"-55";s:1:"O";s:3:"-45";s:6:"Oacute";s:3:"-45";s:11:"Ocircumflex";s:3:"-45";s:9:"Odieresis";s:3:"-45";s:6:"Ograve";s:3:"-45";s:13:"Ohungarumlaut";s:3:"-45";s:7:"Omacron";s:3:"-45";s:6:"Oslash";s:3:"-45";s:6:"Otilde";s:3:"-45";s:1:"Q";s:3:"-45";s:1:"T";s:3:"-95";s:6:"Tcaron";s:3:"-95";s:12:"Tcommaaccent";s:3:"-95";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:4:"-145";s:1:"W";s:4:"-130";s:1:"Y";s:4:"-100";s:6:"Yacute";s:4:"-100";s:9:"Ydieresis";s:4:"-100";s:1:"p";s:3:"-25";s:10:"quoteright";s:3:"-74";s:1:"u";s:3:"-50";s:6:"uacute";s:3:"-50";s:11:"ucircumflex";s:3:"-50";s:9:"udieresis";s:3:"-50";s:6:"ugrave";s:3:"-50";s:13:"uhungarumlaut";s:3:"-50";s:7:"umacron";s:3:"-50";s:7:"uogonek";s:3:"-50";s:5:"uring";s:3:"-50";s:1:"v";s:4:"-100";s:1:"w";s:3:"-90";s:1:"y";s:3:"-74";s:6:"yacute";s:3:"-74";s:9:"ydieresis";s:3:"-74";}s:6:"Aacute";a:50:{s:1:"C";s:3:"-55";s:6:"Cacute";s:3:"-55";s:6:"Ccaron";s:3:"-55";s:8:"Ccedilla";s:3:"-55";s:1:"G";s:3:"-55";s:6:"Gbreve";s:3:"-55";s:12:"Gcommaaccent";s:3:"-55";s:1:"O";s:3:"-45";s:6:"Oacute";s:3:"-45";s:11:"Ocircumflex";s:3:"-45";s:9:"Odieresis";s:3:"-45";s:6:"Ograve";s:3:"-45";s:13:"Ohungarumlaut";s:3:"-45";s:7:"Omacron";s:3:"-45";s:6:"Oslash";s:3:"-45";s:6:"Otilde";s:3:"-45";s:1:"Q";s:3:"-45";s:1:"T";s:3:"-95";s:6:"Tcaron";s:3:"-95";s:12:"Tcommaaccent";s:3:"-95";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:4:"-145";s:1:"W";s:4:"-130";s:1:"Y";s:4:"-100";s:6:"Yacute";s:4:"-100";s:9:"Ydieresis";s:4:"-100";s:1:"p";s:3:"-25";s:10:"quoteright";s:3:"-74";s:1:"u";s:3:"-50";s:6:"uacute";s:3:"-50";s:11:"ucircumflex";s:3:"-50";s:9:"udieresis";s:3:"-50";s:6:"ugrave";s:3:"-50";s:13:"uhungarumlaut";s:3:"-50";s:7:"umacron";s:3:"-50";s:7:"uogonek";s:3:"-50";s:5:"uring";s:3:"-50";s:1:"v";s:4:"-100";s:1:"w";s:3:"-90";s:1:"y";s:3:"-74";s:6:"yacute";s:3:"-74";s:9:"ydieresis";s:3:"-74";}s:6:"Abreve";a:50:{s:1:"C";s:3:"-55";s:6:"Cacute";s:3:"-55";s:6:"Ccaron";s:3:"-55";s:8:"Ccedilla";s:3:"-55";s:1:"G";s:3:"-55";s:6:"Gbreve";s:3:"-55";s:12:"Gcommaaccent";s:3:"-55";s:1:"O";s:3:"-45";s:6:"Oacute";s:3:"-45";s:11:"Ocircumflex";s:3:"-45";s:9:"Odieresis";s:3:"-45";s:6:"Ograve";s:3:"-45";s:13:"Ohungarumlaut";s:3:"-45";s:7:"Omacron";s:3:"-45";s:6:"Oslash";s:3:"-45";s:6:"Otilde";s:3:"-45";s:1:"Q";s:3:"-45";s:1:"T";s:3:"-95";s:6:"Tcaron";s:3:"-95";s:12:"Tcommaaccent";s:3:"-95";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:4:"-145";s:1:"W";s:4:"-130";s:1:"Y";s:4:"-100";s:6:"Yacute";s:4:"-100";s:9:"Ydieresis";s:4:"-100";s:1:"p";s:3:"-25";s:10:"quoteright";s:3:"-74";s:1:"u";s:3:"-50";s:6:"uacute";s:3:"-50";s:11:"ucircumflex";s:3:"-50";s:9:"udieresis";s:3:"-50";s:6:"ugrave";s:3:"-50";s:13:"uhungarumlaut";s:3:"-50";s:7:"umacron";s:3:"-50";s:7:"uogonek";s:3:"-50";s:5:"uring";s:3:"-50";s:1:"v";s:4:"-100";s:1:"w";s:3:"-90";s:1:"y";s:3:"-74";s:6:"yacute";s:3:"-74";s:9:"ydieresis";s:3:"-74";}s:11:"Acircumflex";a:50:{s:1:"C";s:3:"-55";s:6:"Cacute";s:3:"-55";s:6:"Ccaron";s:3:"-55";s:8:"Ccedilla";s:3:"-55";s:1:"G";s:3:"-55";s:6:"Gbreve";s:3:"-55";s:12:"Gcommaaccent";s:3:"-55";s:1:"O";s:3:"-45";s:6:"Oacute";s:3:"-45";s:11:"Ocircumflex";s:3:"-45";s:9:"Odieresis";s:3:"-45";s:6:"Ograve";s:3:"-45";s:13:"Ohungarumlaut";s:3:"-45";s:7:"Omacron";s:3:"-45";s:6:"Oslash";s:3:"-45";s:6:"Otilde";s:3:"-45";s:1:"Q";s:3:"-45";s:1:"T";s:3:"-95";s:6:"Tcaron";s:3:"-95";s:12:"Tcommaaccent";s:3:"-95";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:4:"-145";s:1:"W";s:4:"-130";s:1:"Y";s:4:"-100";s:6:"Yacute";s:4:"-100";s:9:"Ydieresis";s:4:"-100";s:1:"p";s:3:"-25";s:10:"quoteright";s:3:"-74";s:1:"u";s:3:"-50";s:6:"uacute";s:3:"-50";s:11:"ucircumflex";s:3:"-50";s:9:"udieresis";s:3:"-50";s:6:"ugrave";s:3:"-50";s:13:"uhungarumlaut";s:3:"-50";s:7:"umacron";s:3:"-50";s:7:"uogonek";s:3:"-50";s:5:"uring";s:3:"-50";s:1:"v";s:4:"-100";s:1:"w";s:3:"-90";s:1:"y";s:3:"-74";s:6:"yacute";s:3:"-74";s:9:"ydieresis";s:3:"-74";}s:9:"Adieresis";a:50:{s:1:"C";s:3:"-55";s:6:"Cacute";s:3:"-55";s:6:"Ccaron";s:3:"-55";s:8:"Ccedilla";s:3:"-55";s:1:"G";s:3:"-55";s:6:"Gbreve";s:3:"-55";s:12:"Gcommaaccent";s:3:"-55";s:1:"O";s:3:"-45";s:6:"Oacute";s:3:"-45";s:11:"Ocircumflex";s:3:"-45";s:9:"Odieresis";s:3:"-45";s:6:"Ograve";s:3:"-45";s:13:"Ohungarumlaut";s:3:"-45";s:7:"Omacron";s:3:"-45";s:6:"Oslash";s:3:"-45";s:6:"Otilde";s:3:"-45";s:1:"Q";s:3:"-45";s:1:"T";s:3:"-95";s:6:"Tcaron";s:3:"-95";s:12:"Tcommaaccent";s:3:"-95";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:4:"-145";s:1:"W";s:4:"-130";s:1:"Y";s:4:"-100";s:6:"Yacute";s:4:"-100";s:9:"Ydieresis";s:4:"-100";s:1:"p";s:3:"-25";s:10:"quoteright";s:3:"-74";s:1:"u";s:3:"-50";s:6:"uacute";s:3:"-50";s:11:"ucircumflex";s:3:"-50";s:9:"udieresis";s:3:"-50";s:6:"ugrave";s:3:"-50";s:13:"uhungarumlaut";s:3:"-50";s:7:"umacron";s:3:"-50";s:7:"uogonek";s:3:"-50";s:5:"uring";s:3:"-50";s:1:"v";s:4:"-100";s:1:"w";s:3:"-90";s:1:"y";s:3:"-74";s:6:"yacute";s:3:"-74";s:9:"ydieresis";s:3:"-74";}s:6:"Agrave";a:50:{s:1:"C";s:3:"-55";s:6:"Cacute";s:3:"-55";s:6:"Ccaron";s:3:"-55";s:8:"Ccedilla";s:3:"-55";s:1:"G";s:3:"-55";s:6:"Gbreve";s:3:"-55";s:12:"Gcommaaccent";s:3:"-55";s:1:"O";s:3:"-45";s:6:"Oacute";s:3:"-45";s:11:"Ocircumflex";s:3:"-45";s:9:"Odieresis";s:3:"-45";s:6:"Ograve";s:3:"-45";s:13:"Ohungarumlaut";s:3:"-45";s:7:"Omacron";s:3:"-45";s:6:"Oslash";s:3:"-45";s:6:"Otilde";s:3:"-45";s:1:"Q";s:3:"-45";s:1:"T";s:3:"-95";s:6:"Tcaron";s:3:"-95";s:12:"Tcommaaccent";s:3:"-95";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:4:"-145";s:1:"W";s:4:"-130";s:1:"Y";s:4:"-100";s:6:"Yacute";s:4:"-100";s:9:"Ydieresis";s:4:"-100";s:1:"p";s:3:"-25";s:10:"quoteright";s:3:"-74";s:1:"u";s:3:"-50";s:6:"uacute";s:3:"-50";s:11:"ucircumflex";s:3:"-50";s:9:"udieresis";s:3:"-50";s:6:"ugrave";s:3:"-50";s:13:"uhungarumlaut";s:3:"-50";s:7:"umacron";s:3:"-50";s:7:"uogonek";s:3:"-50";s:5:"uring";s:3:"-50";s:1:"v";s:4:"-100";s:1:"w";s:3:"-90";s:1:"y";s:3:"-74";s:6:"yacute";s:3:"-74";s:9:"ydieresis";s:3:"-74";}s:7:"Amacron";a:50:{s:1:"C";s:3:"-55";s:6:"Cacute";s:3:"-55";s:6:"Ccaron";s:3:"-55";s:8:"Ccedilla";s:3:"-55";s:1:"G";s:3:"-55";s:6:"Gbreve";s:3:"-55";s:12:"Gcommaaccent";s:3:"-55";s:1:"O";s:3:"-45";s:6:"Oacute";s:3:"-45";s:11:"Ocircumflex";s:3:"-45";s:9:"Odieresis";s:3:"-45";s:6:"Ograve";s:3:"-45";s:13:"Ohungarumlaut";s:3:"-45";s:7:"Omacron";s:3:"-45";s:6:"Oslash";s:3:"-45";s:6:"Otilde";s:3:"-45";s:1:"Q";s:3:"-45";s:1:"T";s:3:"-95";s:6:"Tcaron";s:3:"-95";s:12:"Tcommaaccent";s:3:"-95";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:4:"-145";s:1:"W";s:4:"-130";s:1:"Y";s:4:"-100";s:6:"Yacute";s:4:"-100";s:9:"Ydieresis";s:4:"-100";s:1:"p";s:3:"-25";s:10:"quoteright";s:3:"-74";s:1:"u";s:3:"-50";s:6:"uacute";s:3:"-50";s:11:"ucircumflex";s:3:"-50";s:9:"udieresis";s:3:"-50";s:6:"ugrave";s:3:"-50";s:13:"uhungarumlaut";s:3:"-50";s:7:"umacron";s:3:"-50";s:7:"uogonek";s:3:"-50";s:5:"uring";s:3:"-50";s:1:"v";s:4:"-100";s:1:"w";s:3:"-90";s:1:"y";s:3:"-74";s:6:"yacute";s:3:"-74";s:9:"ydieresis";s:3:"-74";}s:7:"Aogonek";a:50:{s:1:"C";s:3:"-55";s:6:"Cacute";s:3:"-55";s:6:"Ccaron";s:3:"-55";s:8:"Ccedilla";s:3:"-55";s:1:"G";s:3:"-55";s:6:"Gbreve";s:3:"-55";s:12:"Gcommaaccent";s:3:"-55";s:1:"O";s:3:"-45";s:6:"Oacute";s:3:"-45";s:11:"Ocircumflex";s:3:"-45";s:9:"Odieresis";s:3:"-45";s:6:"Ograve";s:3:"-45";s:13:"Ohungarumlaut";s:3:"-45";s:7:"Omacron";s:3:"-45";s:6:"Oslash";s:3:"-45";s:6:"Otilde";s:3:"-45";s:1:"Q";s:3:"-45";s:1:"T";s:3:"-95";s:6:"Tcaron";s:3:"-95";s:12:"Tcommaaccent";s:3:"-95";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:4:"-145";s:1:"W";s:4:"-130";s:1:"Y";s:4:"-100";s:6:"Yacute";s:4:"-100";s:9:"Ydieresis";s:4:"-100";s:1:"p";s:3:"-25";s:10:"quoteright";s:3:"-74";s:1:"u";s:3:"-50";s:6:"uacute";s:3:"-50";s:11:"ucircumflex";s:3:"-50";s:9:"udieresis";s:3:"-50";s:6:"ugrave";s:3:"-50";s:13:"uhungarumlaut";s:3:"-50";s:7:"umacron";s:3:"-50";s:7:"uogonek";s:3:"-50";s:5:"uring";s:3:"-50";s:1:"v";s:4:"-100";s:1:"w";s:3:"-90";s:1:"y";s:3:"-34";s:6:"yacute";s:3:"-34";s:9:"ydieresis";s:3:"-34";}s:5:"Aring";a:50:{s:1:"C";s:3:"-55";s:6:"Cacute";s:3:"-55";s:6:"Ccaron";s:3:"-55";s:8:"Ccedilla";s:3:"-55";s:1:"G";s:3:"-55";s:6:"Gbreve";s:3:"-55";s:12:"Gcommaaccent";s:3:"-55";s:1:"O";s:3:"-45";s:6:"Oacute";s:3:"-45";s:11:"Ocircumflex";s:3:"-45";s:9:"Odieresis";s:3:"-45";s:6:"Ograve";s:3:"-45";s:13:"Ohungarumlaut";s:3:"-45";s:7:"Omacron";s:3:"-45";s:6:"Oslash";s:3:"-45";s:6:"Otilde";s:3:"-45";s:1:"Q";s:3:"-45";s:1:"T";s:3:"-95";s:6:"Tcaron";s:3:"-95";s:12:"Tcommaaccent";s:3:"-95";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:4:"-145";s:1:"W";s:4:"-130";s:1:"Y";s:4:"-100";s:6:"Yacute";s:4:"-100";s:9:"Ydieresis";s:4:"-100";s:1:"p";s:3:"-25";s:10:"quoteright";s:3:"-74";s:1:"u";s:3:"-50";s:6:"uacute";s:3:"-50";s:11:"ucircumflex";s:3:"-50";s:9:"udieresis";s:3:"-50";s:6:"ugrave";s:3:"-50";s:13:"uhungarumlaut";s:3:"-50";s:7:"umacron";s:3:"-50";s:7:"uogonek";s:3:"-50";s:5:"uring";s:3:"-50";s:1:"v";s:4:"-100";s:1:"w";s:3:"-90";s:1:"y";s:3:"-74";s:6:"yacute";s:3:"-74";s:9:"ydieresis";s:3:"-74";}s:6:"Atilde";a:50:{s:1:"C";s:3:"-55";s:6:"Cacute";s:3:"-55";s:6:"Ccaron";s:3:"-55";s:8:"Ccedilla";s:3:"-55";s:1:"G";s:3:"-55";s:6:"Gbreve";s:3:"-55";s:12:"Gcommaaccent";s:3:"-55";s:1:"O";s:3:"-45";s:6:"Oacute";s:3:"-45";s:11:"Ocircumflex";s:3:"-45";s:9:"Odieresis";s:3:"-45";s:6:"Ograve";s:3:"-45";s:13:"Ohungarumlaut";s:3:"-45";s:7:"Omacron";s:3:"-45";s:6:"Oslash";s:3:"-45";s:6:"Otilde";s:3:"-45";s:1:"Q";s:3:"-45";s:1:"T";s:3:"-95";s:6:"Tcaron";s:3:"-95";s:12:"Tcommaaccent";s:3:"-95";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:4:"-145";s:1:"W";s:4:"-130";s:1:"Y";s:4:"-100";s:6:"Yacute";s:4:"-100";s:9:"Ydieresis";s:4:"-100";s:1:"p";s:3:"-25";s:10:"quoteright";s:3:"-74";s:1:"u";s:3:"-50";s:6:"uacute";s:3:"-50";s:11:"ucircumflex";s:3:"-50";s:9:"udieresis";s:3:"-50";s:6:"ugrave";s:3:"-50";s:13:"uhungarumlaut";s:3:"-50";s:7:"umacron";s:3:"-50";s:7:"uogonek";s:3:"-50";s:5:"uring";s:3:"-50";s:1:"v";s:4:"-100";s:1:"w";s:3:"-90";s:1:"y";s:3:"-74";s:6:"yacute";s:3:"-74";s:9:"ydieresis";s:3:"-74";}s:1:"B";a:19:{s:1:"A";s:3:"-30";s:6:"Aacute";s:3:"-30";s:6:"Abreve";s:3:"-30";s:11:"Acircumflex";s:3:"-30";s:9:"Adieresis";s:3:"-30";s:6:"Agrave";s:3:"-30";s:7:"Amacron";s:3:"-30";s:7:"Aogonek";s:3:"-30";s:5:"Aring";s:3:"-30";s:6:"Atilde";s:3:"-30";s:1:"U";s:3:"-10";s:6:"Uacute";s:3:"-10";s:11:"Ucircumflex";s:3:"-10";s:9:"Udieresis";s:3:"-10";s:6:"Ugrave";s:3:"-10";s:13:"Uhungarumlaut";s:3:"-10";s:7:"Umacron";s:3:"-10";s:7:"Uogonek";s:3:"-10";s:5:"Uring";s:3:"-10";}s:1:"D";a:16:{s:1:"A";s:3:"-35";s:6:"Aacute";s:3:"-35";s:6:"Abreve";s:3:"-35";s:11:"Acircumflex";s:3:"-35";s:9:"Adieresis";s:3:"-35";s:6:"Agrave";s:3:"-35";s:7:"Amacron";s:3:"-35";s:7:"Aogonek";s:3:"-35";s:5:"Aring";s:3:"-35";s:6:"Atilde";s:3:"-35";s:1:"V";s:3:"-40";s:1:"W";s:3:"-40";s:1:"Y";s:3:"-40";s:6:"Yacute";s:3:"-40";s:9:"Ydieresis";s:3:"-40";s:6:"period";s:3:"-20";}s:6:"Dcaron";a:16:{s:1:"A";s:3:"-35";s:6:"Aacute";s:3:"-35";s:6:"Abreve";s:3:"-35";s:11:"Acircumflex";s:3:"-35";s:9:"Adieresis";s:3:"-35";s:6:"Agrave";s:3:"-35";s:7:"Amacron";s:3:"-35";s:7:"Aogonek";s:3:"-35";s:5:"Aring";s:3:"-35";s:6:"Atilde";s:3:"-35";s:1:"V";s:3:"-40";s:1:"W";s:3:"-40";s:1:"Y";s:3:"-40";s:6:"Yacute";s:3:"-40";s:9:"Ydieresis";s:3:"-40";s:6:"period";s:3:"-20";}s:6:"Dcroat";a:16:{s:1:"A";s:3:"-35";s:6:"Aacute";s:3:"-35";s:6:"Abreve";s:3:"-35";s:11:"Acircumflex";s:3:"-35";s:9:"Adieresis";s:3:"-35";s:6:"Agrave";s:3:"-35";s:7:"Amacron";s:3:"-35";s:7:"Aogonek";s:3:"-35";s:5:"Aring";s:3:"-35";s:6:"Atilde";s:3:"-35";s:1:"V";s:3:"-40";s:1:"W";s:3:"-40";s:1:"Y";s:3:"-40";s:6:"Yacute";s:3:"-40";s:9:"Ydieresis";s:3:"-40";s:6:"period";s:3:"-20";}s:1:"F";a:40:{s:1:"A";s:3:"-90";s:6:"Aacute";s:3:"-90";s:6:"Abreve";s:3:"-90";s:11:"Acircumflex";s:3:"-90";s:9:"Adieresis";s:3:"-90";s:6:"Agrave";s:3:"-90";s:7:"Amacron";s:3:"-90";s:7:"Aogonek";s:3:"-90";s:5:"Aring";s:3:"-90";s:6:"Atilde";s:3:"-90";s:1:"a";s:3:"-25";s:6:"aacute";s:3:"-25";s:6:"abreve";s:3:"-25";s:11:"acircumflex";s:3:"-25";s:9:"adieresis";s:3:"-25";s:6:"agrave";s:3:"-25";s:7:"amacron";s:3:"-25";s:7:"aogonek";s:3:"-25";s:5:"aring";s:3:"-25";s:6:"atilde";s:3:"-25";s:5:"comma";s:3:"-92";s:1:"e";s:3:"-25";s:6:"eacute";s:3:"-25";s:6:"ecaron";s:3:"-25";s:11:"ecircumflex";s:3:"-25";s:9:"edieresis";s:3:"-25";s:10:"edotaccent";s:3:"-25";s:6:"egrave";s:3:"-25";s:7:"emacron";s:3:"-25";s:7:"eogonek";s:3:"-25";s:1:"o";s:3:"-25";s:6:"oacute";s:3:"-25";s:11:"ocircumflex";s:3:"-25";s:9:"odieresis";s:3:"-25";s:6:"ograve";s:3:"-25";s:13:"ohungarumlaut";s:3:"-25";s:7:"omacron";s:3:"-25";s:6:"oslash";s:3:"-25";s:6:"otilde";s:3:"-25";s:6:"period";s:4:"-110";}s:1:"J";a:48:{s:1:"A";s:3:"-30";s:6:"Aacute";s:3:"-30";s:6:"Abreve";s:3:"-30";s:11:"Acircumflex";s:3:"-30";s:9:"Adieresis";s:3:"-30";s:6:"Agrave";s:3:"-30";s:7:"Amacron";s:3:"-30";s:7:"Aogonek";s:3:"-30";s:5:"Aring";s:3:"-30";s:6:"Atilde";s:3:"-30";s:1:"a";s:3:"-15";s:6:"aacute";s:3:"-15";s:6:"abreve";s:3:"-15";s:11:"acircumflex";s:3:"-15";s:9:"adieresis";s:3:"-15";s:6:"agrave";s:3:"-15";s:7:"amacron";s:3:"-15";s:7:"aogonek";s:3:"-15";s:5:"aring";s:3:"-15";s:6:"atilde";s:3:"-15";s:1:"e";s:3:"-15";s:6:"eacute";s:3:"-15";s:6:"ecaron";s:3:"-15";s:11:"ecircumflex";s:3:"-15";s:9:"edieresis";s:3:"-15";s:10:"edotaccent";s:3:"-15";s:6:"egrave";s:3:"-15";s:7:"emacron";s:3:"-15";s:7:"eogonek";s:3:"-15";s:1:"o";s:3:"-15";s:6:"oacute";s:3:"-15";s:11:"ocircumflex";s:3:"-15";s:9:"odieresis";s:3:"-15";s:6:"ograve";s:3:"-15";s:13:"ohungarumlaut";s:3:"-15";s:7:"omacron";s:3:"-15";s:6:"oslash";s:3:"-15";s:6:"otilde";s:3:"-15";s:6:"period";s:3:"-20";s:1:"u";s:3:"-15";s:6:"uacute";s:3:"-15";s:11:"ucircumflex";s:3:"-15";s:9:"udieresis";s:3:"-15";s:6:"ugrave";s:3:"-15";s:13:"uhungarumlaut";s:3:"-15";s:7:"umacron";s:3:"-15";s:7:"uogonek";s:3:"-15";s:5:"uring";s:3:"-15";}s:1:"K";a:39:{s:1:"O";s:3:"-30";s:6:"Oacute";s:3:"-30";s:11:"Ocircumflex";s:3:"-30";s:9:"Odieresis";s:3:"-30";s:6:"Ograve";s:3:"-30";s:13:"Ohungarumlaut";s:3:"-30";s:7:"Omacron";s:3:"-30";s:6:"Oslash";s:3:"-30";s:6:"Otilde";s:3:"-30";s:1:"e";s:3:"-25";s:6:"eacute";s:3:"-25";s:6:"ecaron";s:3:"-25";s:11:"ecircumflex";s:3:"-25";s:9:"edieresis";s:3:"-25";s:10:"edotaccent";s:3:"-25";s:6:"egrave";s:3:"-25";s:7:"emacron";s:3:"-25";s:7:"eogonek";s:3:"-25";s:1:"o";s:3:"-25";s:6:"oacute";s:3:"-25";s:11:"ocircumflex";s:3:"-25";s:9:"odieresis";s:3:"-25";s:6:"ograve";s:3:"-25";s:13:"ohungarumlaut";s:3:"-25";s:7:"omacron";s:3:"-25";s:6:"oslash";s:3:"-25";s:6:"otilde";s:3:"-25";s:1:"u";s:3:"-15";s:6:"uacute";s:3:"-15";s:11:"ucircumflex";s:3:"-15";s:9:"udieresis";s:3:"-15";s:6:"ugrave";s:3:"-15";s:13:"uhungarumlaut";s:3:"-15";s:7:"umacron";s:3:"-15";s:7:"uogonek";s:3:"-15";s:5:"uring";s:3:"-15";s:1:"y";s:3:"-45";s:6:"yacute";s:3:"-45";s:9:"ydieresis";s:3:"-45";}s:12:"Kcommaaccent";a:39:{s:1:"O";s:3:"-30";s:6:"Oacute";s:3:"-30";s:11:"Ocircumflex";s:3:"-30";s:9:"Odieresis";s:3:"-30";s:6:"Ograve";s:3:"-30";s:13:"Ohungarumlaut";s:3:"-30";s:7:"Omacron";s:3:"-30";s:6:"Oslash";s:3:"-30";s:6:"Otilde";s:3:"-30";s:1:"e";s:3:"-25";s:6:"eacute";s:3:"-25";s:6:"ecaron";s:3:"-25";s:11:"ecircumflex";s:3:"-25";s:9:"edieresis";s:3:"-25";s:10:"edotaccent";s:3:"-25";s:6:"egrave";s:3:"-25";s:7:"emacron";s:3:"-25";s:7:"eogonek";s:3:"-25";s:1:"o";s:3:"-25";s:6:"oacute";s:3:"-25";s:11:"ocircumflex";s:3:"-25";s:9:"odieresis";s:3:"-25";s:6:"ograve";s:3:"-25";s:13:"ohungarumlaut";s:3:"-25";s:7:"omacron";s:3:"-25";s:6:"oslash";s:3:"-25";s:6:"otilde";s:3:"-25";s:1:"u";s:3:"-15";s:6:"uacute";s:3:"-15";s:11:"ucircumflex";s:3:"-15";s:9:"udieresis";s:3:"-15";s:6:"ugrave";s:3:"-15";s:13:"uhungarumlaut";s:3:"-15";s:7:"umacron";s:3:"-15";s:7:"uogonek";s:3:"-15";s:5:"uring";s:3:"-15";s:1:"y";s:3:"-45";s:6:"yacute";s:3:"-45";s:9:"ydieresis";s:3:"-45";}s:1:"L";a:13:{s:1:"T";s:3:"-92";s:6:"Tcaron";s:3:"-92";s:12:"Tcommaaccent";s:3:"-92";s:1:"V";s:3:"-92";s:1:"W";s:3:"-92";s:1:"Y";s:3:"-92";s:6:"Yacute";s:3:"-92";s:9:"Ydieresis";s:3:"-92";s:13:"quotedblright";s:3:"-20";s:10:"quoteright";s:4:"-110";s:1:"y";s:3:"-55";s:6:"yacute";s:3:"-55";s:9:"ydieresis";s:3:"-55";}s:6:"Lacute";a:13:{s:1:"T";s:3:"-92";s:6:"Tcaron";s:3:"-92";s:12:"Tcommaaccent";s:3:"-92";s:1:"V";s:3:"-92";s:1:"W";s:3:"-92";s:1:"Y";s:3:"-92";s:6:"Yacute";s:3:"-92";s:9:"Ydieresis";s:3:"-92";s:13:"quotedblright";s:3:"-20";s:10:"quoteright";s:4:"-110";s:1:"y";s:3:"-55";s:6:"yacute";s:3:"-55";s:9:"ydieresis";s:3:"-55";}s:12:"Lcommaaccent";a:13:{s:1:"T";s:3:"-92";s:6:"Tcaron";s:3:"-92";s:12:"Tcommaaccent";s:3:"-92";s:1:"V";s:3:"-92";s:1:"W";s:3:"-92";s:1:"Y";s:3:"-92";s:6:"Yacute";s:3:"-92";s:9:"Ydieresis";s:3:"-92";s:13:"quotedblright";s:3:"-20";s:10:"quoteright";s:4:"-110";s:1:"y";s:3:"-55";s:6:"yacute";s:3:"-55";s:9:"ydieresis";s:3:"-55";}s:6:"Lslash";a:13:{s:1:"T";s:3:"-92";s:6:"Tcaron";s:3:"-92";s:12:"Tcommaaccent";s:3:"-92";s:1:"V";s:3:"-92";s:1:"W";s:3:"-92";s:1:"Y";s:3:"-92";s:6:"Yacute";s:3:"-92";s:9:"Ydieresis";s:3:"-92";s:13:"quotedblright";s:3:"-20";s:10:"quoteright";s:4:"-110";s:1:"y";s:3:"-55";s:6:"yacute";s:3:"-55";s:9:"ydieresis";s:3:"-55";}s:1:"N";a:10:{s:1:"A";s:3:"-20";s:6:"Aacute";s:3:"-20";s:6:"Abreve";s:3:"-20";s:11:"Acircumflex";s:3:"-20";s:9:"Adieresis";s:3:"-20";s:6:"Agrave";s:3:"-20";s:7:"Amacron";s:3:"-20";s:7:"Aogonek";s:3:"-20";s:5:"Aring";s:3:"-20";s:6:"Atilde";s:3:"-20";}s:6:"Nacute";a:10:{s:1:"A";s:3:"-20";s:6:"Aacute";s:3:"-20";s:6:"Abreve";s:3:"-20";s:11:"Acircumflex";s:3:"-20";s:9:"Adieresis";s:3:"-20";s:6:"Agrave";s:3:"-20";s:7:"Amacron";s:3:"-20";s:7:"Aogonek";s:3:"-20";s:5:"Aring";s:3:"-20";s:6:"Atilde";s:3:"-20";}s:6:"Ncaron";a:10:{s:1:"A";s:3:"-20";s:6:"Aacute";s:3:"-20";s:6:"Abreve";s:3:"-20";s:11:"Acircumflex";s:3:"-20";s:9:"Adieresis";s:3:"-20";s:6:"Agrave";s:3:"-20";s:7:"Amacron";s:3:"-20";s:7:"Aogonek";s:3:"-20";s:5:"Aring";s:3:"-20";s:6:"Atilde";s:3:"-20";}s:12:"Ncommaaccent";a:10:{s:1:"A";s:3:"-20";s:6:"Aacute";s:3:"-20";s:6:"Abreve";s:3:"-20";s:11:"Acircumflex";s:3:"-20";s:9:"Adieresis";s:3:"-20";s:6:"Agrave";s:3:"-20";s:7:"Amacron";s:3:"-20";s:7:"Aogonek";s:3:"-20";s:5:"Aring";s:3:"-20";s:6:"Atilde";s:3:"-20";}s:6:"Ntilde";a:10:{s:1:"A";s:3:"-20";s:6:"Aacute";s:3:"-20";s:6:"Abreve";s:3:"-20";s:11:"Acircumflex";s:3:"-20";s:9:"Adieresis";s:3:"-20";s:6:"Agrave";s:3:"-20";s:7:"Amacron";s:3:"-20";s:7:"Aogonek";s:3:"-20";s:5:"Aring";s:3:"-20";s:6:"Atilde";s:3:"-20";}s:1:"O";a:19:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:6:"Oacute";a:19:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:11:"Ocircumflex";a:19:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:9:"Odieresis";a:19:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:6:"Ograve";a:19:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:13:"Ohungarumlaut";a:19:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:7:"Omacron";a:19:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:6:"Oslash";a:19:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:6:"Otilde";a:19:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:1:"P";a:40:{s:1:"A";s:3:"-74";s:6:"Aacute";s:3:"-74";s:6:"Abreve";s:3:"-74";s:11:"Acircumflex";s:3:"-74";s:9:"Adieresis";s:3:"-74";s:6:"Agrave";s:3:"-74";s:7:"Amacron";s:3:"-74";s:7:"Aogonek";s:3:"-74";s:5:"Aring";s:3:"-74";s:6:"Atilde";s:3:"-74";s:1:"a";s:3:"-10";s:6:"aacute";s:3:"-10";s:6:"abreve";s:3:"-10";s:11:"acircumflex";s:3:"-10";s:9:"adieresis";s:3:"-10";s:6:"agrave";s:3:"-10";s:7:"amacron";s:3:"-10";s:7:"aogonek";s:3:"-10";s:5:"aring";s:3:"-10";s:6:"atilde";s:3:"-10";s:5:"comma";s:3:"-92";s:1:"e";s:3:"-20";s:6:"eacute";s:3:"-20";s:6:"ecaron";s:3:"-20";s:11:"ecircumflex";s:3:"-20";s:9:"edieresis";s:3:"-20";s:10:"edotaccent";s:3:"-20";s:6:"egrave";s:3:"-20";s:7:"emacron";s:3:"-20";s:7:"eogonek";s:3:"-20";s:1:"o";s:3:"-20";s:6:"oacute";s:3:"-20";s:11:"ocircumflex";s:3:"-20";s:9:"odieresis";s:3:"-20";s:6:"ograve";s:3:"-20";s:13:"ohungarumlaut";s:3:"-20";s:7:"omacron";s:3:"-20";s:6:"oslash";s:3:"-20";s:6:"otilde";s:3:"-20";s:6:"period";s:4:"-110";}s:1:"Q";a:10:{s:1:"U";s:3:"-10";s:6:"Uacute";s:3:"-10";s:11:"Ucircumflex";s:3:"-10";s:9:"Udieresis";s:3:"-10";s:6:"Ugrave";s:3:"-10";s:13:"Uhungarumlaut";s:3:"-10";s:7:"Umacron";s:3:"-10";s:7:"Uogonek";s:3:"-10";s:5:"Uring";s:3:"-10";s:6:"period";s:3:"-20";}s:1:"R";a:26:{s:1:"O";s:3:"-30";s:6:"Oacute";s:3:"-30";s:11:"Ocircumflex";s:3:"-30";s:9:"Odieresis";s:3:"-30";s:6:"Ograve";s:3:"-30";s:13:"Ohungarumlaut";s:3:"-30";s:7:"Omacron";s:3:"-30";s:6:"Oslash";s:3:"-30";s:6:"Otilde";s:3:"-30";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"U";s:3:"-30";s:6:"Uacute";s:3:"-30";s:11:"Ucircumflex";s:3:"-30";s:9:"Udieresis";s:3:"-30";s:6:"Ugrave";s:3:"-30";s:13:"Uhungarumlaut";s:3:"-30";s:7:"Umacron";s:3:"-30";s:7:"Uogonek";s:3:"-30";s:5:"Uring";s:3:"-30";s:1:"V";s:3:"-55";s:1:"W";s:3:"-35";s:1:"Y";s:3:"-35";s:6:"Yacute";s:3:"-35";s:9:"Ydieresis";s:3:"-35";}s:6:"Racute";a:26:{s:1:"O";s:3:"-30";s:6:"Oacute";s:3:"-30";s:11:"Ocircumflex";s:3:"-30";s:9:"Odieresis";s:3:"-30";s:6:"Ograve";s:3:"-30";s:13:"Ohungarumlaut";s:3:"-30";s:7:"Omacron";s:3:"-30";s:6:"Oslash";s:3:"-30";s:6:"Otilde";s:3:"-30";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"U";s:3:"-30";s:6:"Uacute";s:3:"-30";s:11:"Ucircumflex";s:3:"-30";s:9:"Udieresis";s:3:"-30";s:6:"Ugrave";s:3:"-30";s:13:"Uhungarumlaut";s:3:"-30";s:7:"Umacron";s:3:"-30";s:7:"Uogonek";s:3:"-30";s:5:"Uring";s:3:"-30";s:1:"V";s:3:"-55";s:1:"W";s:3:"-35";s:1:"Y";s:3:"-35";s:6:"Yacute";s:3:"-35";s:9:"Ydieresis";s:3:"-35";}s:6:"Rcaron";a:26:{s:1:"O";s:3:"-30";s:6:"Oacute";s:3:"-30";s:11:"Ocircumflex";s:3:"-30";s:9:"Odieresis";s:3:"-30";s:6:"Ograve";s:3:"-30";s:13:"Ohungarumlaut";s:3:"-30";s:7:"Omacron";s:3:"-30";s:6:"Oslash";s:3:"-30";s:6:"Otilde";s:3:"-30";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"U";s:3:"-30";s:6:"Uacute";s:3:"-30";s:11:"Ucircumflex";s:3:"-30";s:9:"Udieresis";s:3:"-30";s:6:"Ugrave";s:3:"-30";s:13:"Uhungarumlaut";s:3:"-30";s:7:"Umacron";s:3:"-30";s:7:"Uogonek";s:3:"-30";s:5:"Uring";s:3:"-30";s:1:"V";s:3:"-55";s:1:"W";s:3:"-35";s:1:"Y";s:3:"-35";s:6:"Yacute";s:3:"-35";s:9:"Ydieresis";s:3:"-35";}s:12:"Rcommaaccent";a:26:{s:1:"O";s:3:"-30";s:6:"Oacute";s:3:"-30";s:11:"Ocircumflex";s:3:"-30";s:9:"Odieresis";s:3:"-30";s:6:"Ograve";s:3:"-30";s:13:"Ohungarumlaut";s:3:"-30";s:7:"Omacron";s:3:"-30";s:6:"Oslash";s:3:"-30";s:6:"Otilde";s:3:"-30";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"U";s:3:"-30";s:6:"Uacute";s:3:"-30";s:11:"Ucircumflex";s:3:"-30";s:9:"Udieresis";s:3:"-30";s:6:"Ugrave";s:3:"-30";s:13:"Uhungarumlaut";s:3:"-30";s:7:"Umacron";s:3:"-30";s:7:"Uogonek";s:3:"-30";s:5:"Uring";s:3:"-30";s:1:"V";s:3:"-55";s:1:"W";s:3:"-35";s:1:"Y";s:3:"-35";s:6:"Yacute";s:3:"-35";s:9:"Ydieresis";s:3:"-35";}s:1:"T";a:72:{s:1:"A";s:3:"-90";s:6:"Aacute";s:3:"-90";s:6:"Abreve";s:3:"-90";s:11:"Acircumflex";s:3:"-90";s:9:"Adieresis";s:3:"-90";s:6:"Agrave";s:3:"-90";s:7:"Amacron";s:3:"-90";s:7:"Aogonek";s:3:"-90";s:5:"Aring";s:3:"-90";s:6:"Atilde";s:3:"-90";s:1:"O";s:3:"-18";s:6:"Oacute";s:3:"-18";s:11:"Ocircumflex";s:3:"-18";s:9:"Odieresis";s:3:"-18";s:6:"Ograve";s:3:"-18";s:13:"Ohungarumlaut";s:3:"-18";s:7:"Omacron";s:3:"-18";s:6:"Oslash";s:3:"-18";s:6:"Otilde";s:3:"-18";s:1:"a";s:3:"-92";s:6:"aacute";s:3:"-92";s:6:"abreve";s:3:"-52";s:11:"acircumflex";s:3:"-52";s:9:"adieresis";s:3:"-52";s:6:"agrave";s:3:"-52";s:7:"amacron";s:3:"-52";s:7:"aogonek";s:3:"-92";s:5:"aring";s:3:"-92";s:6:"atilde";s:3:"-52";s:5:"colon";s:3:"-74";s:5:"comma";s:3:"-74";s:1:"e";s:3:"-92";s:6:"eacute";s:3:"-92";s:6:"ecaron";s:3:"-92";s:11:"ecircumflex";s:3:"-92";s:9:"edieresis";s:3:"-52";s:10:"edotaccent";s:3:"-92";s:6:"egrave";s:3:"-52";s:7:"emacron";s:3:"-52";s:7:"eogonek";s:3:"-92";s:6:"hyphen";s:3:"-92";s:1:"i";s:3:"-18";s:6:"iacute";s:3:"-18";s:7:"iogonek";s:3:"-18";s:1:"o";s:3:"-92";s:6:"oacute";s:3:"-92";s:11:"ocircumflex";s:3:"-92";s:9:"odieresis";s:3:"-92";s:6:"ograve";s:3:"-92";s:13:"ohungarumlaut";s:3:"-92";s:7:"omacron";s:3:"-92";s:6:"oslash";s:3:"-92";s:6:"otilde";s:3:"-92";s:6:"period";s:3:"-90";s:1:"r";s:3:"-74";s:6:"racute";s:3:"-74";s:6:"rcaron";s:3:"-74";s:12:"rcommaaccent";s:3:"-74";s:9:"semicolon";s:3:"-74";s:1:"u";s:3:"-92";s:6:"uacute";s:3:"-92";s:11:"ucircumflex";s:3:"-92";s:9:"udieresis";s:3:"-92";s:6:"ugrave";s:3:"-92";s:13:"uhungarumlaut";s:3:"-92";s:7:"umacron";s:3:"-92";s:7:"uogonek";s:3:"-92";s:5:"uring";s:3:"-92";s:1:"w";s:3:"-74";s:1:"y";s:3:"-34";s:6:"yacute";s:3:"-34";s:9:"ydieresis";s:3:"-34";}s:6:"Tcaron";a:72:{s:1:"A";s:3:"-90";s:6:"Aacute";s:3:"-90";s:6:"Abreve";s:3:"-90";s:11:"Acircumflex";s:3:"-90";s:9:"Adieresis";s:3:"-90";s:6:"Agrave";s:3:"-90";s:7:"Amacron";s:3:"-90";s:7:"Aogonek";s:3:"-90";s:5:"Aring";s:3:"-90";s:6:"Atilde";s:3:"-90";s:1:"O";s:3:"-18";s:6:"Oacute";s:3:"-18";s:11:"Ocircumflex";s:3:"-18";s:9:"Odieresis";s:3:"-18";s:6:"Ograve";s:3:"-18";s:13:"Ohungarumlaut";s:3:"-18";s:7:"Omacron";s:3:"-18";s:6:"Oslash";s:3:"-18";s:6:"Otilde";s:3:"-18";s:1:"a";s:3:"-92";s:6:"aacute";s:3:"-92";s:6:"abreve";s:3:"-52";s:11:"acircumflex";s:3:"-52";s:9:"adieresis";s:3:"-52";s:6:"agrave";s:3:"-52";s:7:"amacron";s:3:"-52";s:7:"aogonek";s:3:"-92";s:5:"aring";s:3:"-92";s:6:"atilde";s:3:"-52";s:5:"colon";s:3:"-74";s:5:"comma";s:3:"-74";s:1:"e";s:3:"-92";s:6:"eacute";s:3:"-92";s:6:"ecaron";s:3:"-92";s:11:"ecircumflex";s:3:"-92";s:9:"edieresis";s:3:"-52";s:10:"edotaccent";s:3:"-92";s:6:"egrave";s:3:"-52";s:7:"emacron";s:3:"-52";s:7:"eogonek";s:3:"-92";s:6:"hyphen";s:3:"-92";s:1:"i";s:3:"-18";s:6:"iacute";s:3:"-18";s:7:"iogonek";s:3:"-18";s:1:"o";s:3:"-92";s:6:"oacute";s:3:"-92";s:11:"ocircumflex";s:3:"-92";s:9:"odieresis";s:3:"-92";s:6:"ograve";s:3:"-92";s:13:"ohungarumlaut";s:3:"-92";s:7:"omacron";s:3:"-92";s:6:"oslash";s:3:"-92";s:6:"otilde";s:3:"-92";s:6:"period";s:3:"-90";s:1:"r";s:3:"-74";s:6:"racute";s:3:"-74";s:6:"rcaron";s:3:"-74";s:12:"rcommaaccent";s:3:"-74";s:9:"semicolon";s:3:"-74";s:1:"u";s:3:"-92";s:6:"uacute";s:3:"-92";s:11:"ucircumflex";s:3:"-92";s:9:"udieresis";s:3:"-92";s:6:"ugrave";s:3:"-92";s:13:"uhungarumlaut";s:3:"-92";s:7:"umacron";s:3:"-92";s:7:"uogonek";s:3:"-92";s:5:"uring";s:3:"-92";s:1:"w";s:3:"-74";s:1:"y";s:3:"-34";s:6:"yacute";s:3:"-34";s:9:"ydieresis";s:3:"-34";}s:12:"Tcommaaccent";a:72:{s:1:"A";s:3:"-90";s:6:"Aacute";s:3:"-90";s:6:"Abreve";s:3:"-90";s:11:"Acircumflex";s:3:"-90";s:9:"Adieresis";s:3:"-90";s:6:"Agrave";s:3:"-90";s:7:"Amacron";s:3:"-90";s:7:"Aogonek";s:3:"-90";s:5:"Aring";s:3:"-90";s:6:"Atilde";s:3:"-90";s:1:"O";s:3:"-18";s:6:"Oacute";s:3:"-18";s:11:"Ocircumflex";s:3:"-18";s:9:"Odieresis";s:3:"-18";s:6:"Ograve";s:3:"-18";s:13:"Ohungarumlaut";s:3:"-18";s:7:"Omacron";s:3:"-18";s:6:"Oslash";s:3:"-18";s:6:"Otilde";s:3:"-18";s:1:"a";s:3:"-92";s:6:"aacute";s:3:"-92";s:6:"abreve";s:3:"-52";s:11:"acircumflex";s:3:"-52";s:9:"adieresis";s:3:"-52";s:6:"agrave";s:3:"-52";s:7:"amacron";s:3:"-52";s:7:"aogonek";s:3:"-92";s:5:"aring";s:3:"-92";s:6:"atilde";s:3:"-52";s:5:"colon";s:3:"-74";s:5:"comma";s:3:"-74";s:1:"e";s:3:"-92";s:6:"eacute";s:3:"-92";s:6:"ecaron";s:3:"-92";s:11:"ecircumflex";s:3:"-92";s:9:"edieresis";s:3:"-52";s:10:"edotaccent";s:3:"-92";s:6:"egrave";s:3:"-52";s:7:"emacron";s:3:"-52";s:7:"eogonek";s:3:"-92";s:6:"hyphen";s:3:"-92";s:1:"i";s:3:"-18";s:6:"iacute";s:3:"-18";s:7:"iogonek";s:3:"-18";s:1:"o";s:3:"-92";s:6:"oacute";s:3:"-92";s:11:"ocircumflex";s:3:"-92";s:9:"odieresis";s:3:"-92";s:6:"ograve";s:3:"-92";s:13:"ohungarumlaut";s:3:"-92";s:7:"omacron";s:3:"-92";s:6:"oslash";s:3:"-92";s:6:"otilde";s:3:"-92";s:6:"period";s:3:"-90";s:1:"r";s:3:"-74";s:6:"racute";s:3:"-74";s:6:"rcaron";s:3:"-74";s:12:"rcommaaccent";s:3:"-74";s:9:"semicolon";s:3:"-74";s:1:"u";s:3:"-92";s:6:"uacute";s:3:"-92";s:11:"ucircumflex";s:3:"-92";s:9:"udieresis";s:3:"-92";s:6:"ugrave";s:3:"-92";s:13:"uhungarumlaut";s:3:"-92";s:7:"umacron";s:3:"-92";s:7:"uogonek";s:3:"-92";s:5:"uring";s:3:"-92";s:1:"w";s:3:"-74";s:1:"y";s:3:"-34";s:6:"yacute";s:3:"-34";s:9:"ydieresis";s:3:"-34";}s:1:"U";a:12:{s:1:"A";s:3:"-60";s:6:"Aacute";s:3:"-60";s:6:"Abreve";s:3:"-60";s:11:"Acircumflex";s:3:"-60";s:9:"Adieresis";s:3:"-60";s:6:"Agrave";s:3:"-60";s:7:"Amacron";s:3:"-60";s:7:"Aogonek";s:3:"-60";s:5:"Aring";s:3:"-60";s:6:"Atilde";s:3:"-60";s:5:"comma";s:3:"-50";s:6:"period";s:3:"-50";}s:6:"Uacute";a:12:{s:1:"A";s:3:"-60";s:6:"Aacute";s:3:"-60";s:6:"Abreve";s:3:"-60";s:11:"Acircumflex";s:3:"-60";s:9:"Adieresis";s:3:"-60";s:6:"Agrave";s:3:"-60";s:7:"Amacron";s:3:"-60";s:7:"Aogonek";s:3:"-60";s:5:"Aring";s:3:"-60";s:6:"Atilde";s:3:"-60";s:5:"comma";s:3:"-50";s:6:"period";s:3:"-50";}s:11:"Ucircumflex";a:12:{s:1:"A";s:3:"-60";s:6:"Aacute";s:3:"-60";s:6:"Abreve";s:3:"-60";s:11:"Acircumflex";s:3:"-60";s:9:"Adieresis";s:3:"-60";s:6:"Agrave";s:3:"-60";s:7:"Amacron";s:3:"-60";s:7:"Aogonek";s:3:"-60";s:5:"Aring";s:3:"-60";s:6:"Atilde";s:3:"-60";s:5:"comma";s:3:"-50";s:6:"period";s:3:"-50";}s:9:"Udieresis";a:12:{s:1:"A";s:3:"-60";s:6:"Aacute";s:3:"-60";s:6:"Abreve";s:3:"-60";s:11:"Acircumflex";s:3:"-60";s:9:"Adieresis";s:3:"-60";s:6:"Agrave";s:3:"-60";s:7:"Amacron";s:3:"-60";s:7:"Aogonek";s:3:"-60";s:5:"Aring";s:3:"-60";s:6:"Atilde";s:3:"-60";s:5:"comma";s:3:"-50";s:6:"period";s:3:"-50";}s:6:"Ugrave";a:12:{s:1:"A";s:3:"-60";s:6:"Aacute";s:3:"-60";s:6:"Abreve";s:3:"-60";s:11:"Acircumflex";s:3:"-60";s:9:"Adieresis";s:3:"-60";s:6:"Agrave";s:3:"-60";s:7:"Amacron";s:3:"-60";s:7:"Aogonek";s:3:"-60";s:5:"Aring";s:3:"-60";s:6:"Atilde";s:3:"-60";s:5:"comma";s:3:"-50";s:6:"period";s:3:"-50";}s:13:"Uhungarumlaut";a:12:{s:1:"A";s:3:"-60";s:6:"Aacute";s:3:"-60";s:6:"Abreve";s:3:"-60";s:11:"Acircumflex";s:3:"-60";s:9:"Adieresis";s:3:"-60";s:6:"Agrave";s:3:"-60";s:7:"Amacron";s:3:"-60";s:7:"Aogonek";s:3:"-60";s:5:"Aring";s:3:"-60";s:6:"Atilde";s:3:"-60";s:5:"comma";s:3:"-50";s:6:"period";s:3:"-50";}s:7:"Umacron";a:12:{s:1:"A";s:3:"-60";s:6:"Aacute";s:3:"-60";s:6:"Abreve";s:3:"-60";s:11:"Acircumflex";s:3:"-60";s:9:"Adieresis";s:3:"-60";s:6:"Agrave";s:3:"-60";s:7:"Amacron";s:3:"-60";s:7:"Aogonek";s:3:"-60";s:5:"Aring";s:3:"-60";s:6:"Atilde";s:3:"-60";s:5:"comma";s:3:"-50";s:6:"period";s:3:"-50";}s:7:"Uogonek";a:12:{s:1:"A";s:3:"-60";s:6:"Aacute";s:3:"-60";s:6:"Abreve";s:3:"-60";s:11:"Acircumflex";s:3:"-60";s:9:"Adieresis";s:3:"-60";s:6:"Agrave";s:3:"-60";s:7:"Amacron";s:3:"-60";s:7:"Aogonek";s:3:"-60";s:5:"Aring";s:3:"-60";s:6:"Atilde";s:3:"-60";s:5:"comma";s:3:"-50";s:6:"period";s:3:"-50";}s:5:"Uring";a:12:{s:1:"A";s:3:"-60";s:6:"Aacute";s:3:"-60";s:6:"Abreve";s:3:"-60";s:11:"Acircumflex";s:3:"-60";s:9:"Adieresis";s:3:"-60";s:6:"Agrave";s:3:"-60";s:7:"Amacron";s:3:"-60";s:7:"Aogonek";s:3:"-60";s:5:"Aring";s:3:"-60";s:6:"Atilde";s:3:"-60";s:5:"comma";s:3:"-50";s:6:"period";s:3:"-50";}s:1:"V";a:71:{s:1:"A";s:4:"-135";s:6:"Aacute";s:4:"-135";s:6:"Abreve";s:4:"-135";s:11:"Acircumflex";s:4:"-135";s:9:"Adieresis";s:4:"-135";s:6:"Agrave";s:4:"-135";s:7:"Amacron";s:4:"-135";s:7:"Aogonek";s:4:"-135";s:5:"Aring";s:4:"-135";s:6:"Atilde";s:4:"-135";s:1:"G";s:3:"-30";s:6:"Gbreve";s:3:"-30";s:12:"Gcommaaccent";s:3:"-30";s:1:"O";s:3:"-45";s:6:"Oacute";s:3:"-45";s:11:"Ocircumflex";s:3:"-45";s:9:"Odieresis";s:3:"-45";s:6:"Ograve";s:3:"-45";s:13:"Ohungarumlaut";s:3:"-45";s:7:"Omacron";s:3:"-45";s:6:"Oslash";s:3:"-45";s:6:"Otilde";s:3:"-45";s:1:"a";s:3:"-92";s:6:"aacute";s:3:"-92";s:6:"abreve";s:3:"-92";s:11:"acircumflex";s:3:"-92";s:9:"adieresis";s:3:"-92";s:6:"agrave";s:3:"-92";s:7:"amacron";s:3:"-92";s:7:"aogonek";s:3:"-92";s:5:"aring";s:3:"-92";s:6:"atilde";s:3:"-92";s:5:"colon";s:3:"-92";s:5:"comma";s:4:"-129";s:1:"e";s:4:"-100";s:6:"eacute";s:4:"-100";s:6:"ecaron";s:4:"-100";s:11:"ecircumflex";s:4:"-100";s:9:"edieresis";s:4:"-100";s:10:"edotaccent";s:4:"-100";s:6:"egrave";s:4:"-100";s:7:"emacron";s:4:"-100";s:7:"eogonek";s:4:"-100";s:6:"hyphen";s:3:"-74";s:1:"i";s:3:"-37";s:6:"iacute";s:3:"-37";s:11:"icircumflex";s:3:"-37";s:9:"idieresis";s:3:"-37";s:6:"igrave";s:3:"-37";s:7:"imacron";s:3:"-37";s:7:"iogonek";s:3:"-37";s:1:"o";s:4:"-100";s:6:"oacute";s:4:"-100";s:11:"ocircumflex";s:4:"-100";s:9:"odieresis";s:4:"-100";s:6:"ograve";s:4:"-100";s:13:"ohungarumlaut";s:4:"-100";s:7:"omacron";s:4:"-100";s:6:"oslash";s:4:"-100";s:6:"otilde";s:4:"-100";s:6:"period";s:4:"-145";s:9:"semicolon";s:3:"-92";s:1:"u";s:3:"-92";s:6:"uacute";s:3:"-92";s:11:"ucircumflex";s:3:"-92";s:9:"udieresis";s:3:"-92";s:6:"ugrave";s:3:"-92";s:13:"uhungarumlaut";s:3:"-92";s:7:"umacron";s:3:"-92";s:7:"uogonek";s:3:"-92";s:5:"uring";s:3:"-92";}s:1:"W";a:67:{s:1:"A";s:4:"-120";s:6:"Aacute";s:4:"-120";s:6:"Abreve";s:4:"-120";s:11:"Acircumflex";s:4:"-120";s:9:"Adieresis";s:4:"-120";s:6:"Agrave";s:4:"-120";s:7:"Amacron";s:4:"-120";s:7:"Aogonek";s:4:"-120";s:5:"Aring";s:4:"-120";s:6:"Atilde";s:4:"-120";s:1:"O";s:3:"-10";s:6:"Oacute";s:3:"-10";s:11:"Ocircumflex";s:3:"-10";s:9:"Odieresis";s:3:"-10";s:6:"Ograve";s:3:"-10";s:13:"Ohungarumlaut";s:3:"-10";s:7:"Omacron";s:3:"-10";s:6:"Oslash";s:3:"-10";s:6:"Otilde";s:3:"-10";s:1:"a";s:3:"-65";s:6:"aacute";s:3:"-65";s:6:"abreve";s:3:"-65";s:11:"acircumflex";s:3:"-65";s:9:"adieresis";s:3:"-65";s:6:"agrave";s:3:"-65";s:7:"amacron";s:3:"-65";s:7:"aogonek";s:3:"-65";s:5:"aring";s:3:"-65";s:6:"atilde";s:3:"-65";s:5:"colon";s:3:"-55";s:5:"comma";s:3:"-92";s:1:"e";s:3:"-65";s:6:"eacute";s:3:"-65";s:6:"ecaron";s:3:"-65";s:11:"ecircumflex";s:3:"-65";s:9:"edieresis";s:3:"-65";s:10:"edotaccent";s:3:"-65";s:6:"egrave";s:3:"-65";s:7:"emacron";s:3:"-65";s:7:"eogonek";s:3:"-65";s:6:"hyphen";s:3:"-37";s:1:"i";s:3:"-18";s:6:"iacute";s:3:"-18";s:7:"iogonek";s:3:"-18";s:1:"o";s:3:"-75";s:6:"oacute";s:3:"-75";s:11:"ocircumflex";s:3:"-75";s:9:"odieresis";s:3:"-75";s:6:"ograve";s:3:"-75";s:13:"ohungarumlaut";s:3:"-75";s:7:"omacron";s:3:"-75";s:6:"oslash";s:3:"-75";s:6:"otilde";s:3:"-75";s:6:"period";s:3:"-92";s:9:"semicolon";s:3:"-55";s:1:"u";s:3:"-50";s:6:"uacute";s:3:"-50";s:11:"ucircumflex";s:3:"-50";s:9:"udieresis";s:3:"-50";s:6:"ugrave";s:3:"-50";s:13:"uhungarumlaut";s:3:"-50";s:7:"umacron";s:3:"-50";s:7:"uogonek";s:3:"-50";s:5:"uring";s:3:"-50";s:1:"y";s:3:"-60";s:6:"yacute";s:3:"-60";s:9:"ydieresis";s:3:"-60";}s:1:"Y";a:64:{s:1:"A";s:4:"-110";s:6:"Aacute";s:4:"-110";s:6:"Abreve";s:4:"-110";s:11:"Acircumflex";s:4:"-110";s:9:"Adieresis";s:4:"-110";s:6:"Agrave";s:4:"-110";s:7:"Amacron";s:4:"-110";s:7:"Aogonek";s:4:"-110";s:5:"Aring";s:4:"-110";s:6:"Atilde";s:4:"-110";s:1:"O";s:3:"-35";s:6:"Oacute";s:3:"-35";s:11:"Ocircumflex";s:3:"-35";s:9:"Odieresis";s:3:"-35";s:6:"Ograve";s:3:"-35";s:13:"Ohungarumlaut";s:3:"-35";s:7:"Omacron";s:3:"-35";s:6:"Oslash";s:3:"-35";s:6:"Otilde";s:3:"-35";s:1:"a";s:3:"-85";s:6:"aacute";s:3:"-85";s:6:"abreve";s:3:"-85";s:11:"acircumflex";s:3:"-85";s:9:"adieresis";s:3:"-85";s:6:"agrave";s:3:"-85";s:7:"amacron";s:3:"-85";s:7:"aogonek";s:3:"-85";s:5:"aring";s:3:"-85";s:6:"atilde";s:3:"-85";s:5:"colon";s:3:"-92";s:5:"comma";s:3:"-92";s:1:"e";s:4:"-111";s:6:"eacute";s:4:"-111";s:6:"ecaron";s:4:"-111";s:11:"ecircumflex";s:4:"-111";s:9:"edieresis";s:3:"-71";s:10:"edotaccent";s:4:"-111";s:6:"egrave";s:3:"-71";s:7:"emacron";s:3:"-71";s:7:"eogonek";s:4:"-111";s:6:"hyphen";s:3:"-92";s:1:"i";s:3:"-37";s:6:"iacute";s:3:"-37";s:7:"iogonek";s:3:"-37";s:1:"o";s:4:"-111";s:6:"oacute";s:4:"-111";s:11:"ocircumflex";s:4:"-111";s:9:"odieresis";s:4:"-111";s:6:"ograve";s:4:"-111";s:13:"ohungarumlaut";s:4:"-111";s:7:"omacron";s:4:"-111";s:6:"oslash";s:4:"-111";s:6:"otilde";s:4:"-111";s:6:"period";s:3:"-92";s:9:"semicolon";s:3:"-92";s:1:"u";s:3:"-92";s:6:"uacute";s:3:"-92";s:11:"ucircumflex";s:3:"-92";s:9:"udieresis";s:3:"-92";s:6:"ugrave";s:3:"-92";s:13:"uhungarumlaut";s:3:"-92";s:7:"umacron";s:3:"-92";s:7:"uogonek";s:3:"-92";s:5:"uring";s:3:"-92";}s:6:"Yacute";a:64:{s:1:"A";s:4:"-110";s:6:"Aacute";s:4:"-110";s:6:"Abreve";s:4:"-110";s:11:"Acircumflex";s:4:"-110";s:9:"Adieresis";s:4:"-110";s:6:"Agrave";s:4:"-110";s:7:"Amacron";s:4:"-110";s:7:"Aogonek";s:4:"-110";s:5:"Aring";s:4:"-110";s:6:"Atilde";s:4:"-110";s:1:"O";s:3:"-35";s:6:"Oacute";s:3:"-35";s:11:"Ocircumflex";s:3:"-35";s:9:"Odieresis";s:3:"-35";s:6:"Ograve";s:3:"-35";s:13:"Ohungarumlaut";s:3:"-35";s:7:"Omacron";s:3:"-35";s:6:"Oslash";s:3:"-35";s:6:"Otilde";s:3:"-35";s:1:"a";s:3:"-85";s:6:"aacute";s:3:"-85";s:6:"abreve";s:3:"-85";s:11:"acircumflex";s:3:"-85";s:9:"adieresis";s:3:"-85";s:6:"agrave";s:3:"-85";s:7:"amacron";s:3:"-85";s:7:"aogonek";s:3:"-85";s:5:"aring";s:3:"-85";s:6:"atilde";s:3:"-85";s:5:"colon";s:3:"-92";s:5:"comma";s:3:"-92";s:1:"e";s:4:"-111";s:6:"eacute";s:4:"-111";s:6:"ecaron";s:4:"-111";s:11:"ecircumflex";s:4:"-111";s:9:"edieresis";s:3:"-71";s:10:"edotaccent";s:4:"-111";s:6:"egrave";s:3:"-71";s:7:"emacron";s:3:"-71";s:7:"eogonek";s:4:"-111";s:6:"hyphen";s:3:"-92";s:1:"i";s:3:"-37";s:6:"iacute";s:3:"-37";s:7:"iogonek";s:3:"-37";s:1:"o";s:4:"-111";s:6:"oacute";s:4:"-111";s:11:"ocircumflex";s:4:"-111";s:9:"odieresis";s:4:"-111";s:6:"ograve";s:4:"-111";s:13:"ohungarumlaut";s:4:"-111";s:7:"omacron";s:4:"-111";s:6:"oslash";s:4:"-111";s:6:"otilde";s:4:"-111";s:6:"period";s:3:"-92";s:9:"semicolon";s:3:"-92";s:1:"u";s:3:"-92";s:6:"uacute";s:3:"-92";s:11:"ucircumflex";s:3:"-92";s:9:"udieresis";s:3:"-92";s:6:"ugrave";s:3:"-92";s:13:"uhungarumlaut";s:3:"-92";s:7:"umacron";s:3:"-92";s:7:"uogonek";s:3:"-92";s:5:"uring";s:3:"-92";}s:9:"Ydieresis";a:64:{s:1:"A";s:4:"-110";s:6:"Aacute";s:4:"-110";s:6:"Abreve";s:4:"-110";s:11:"Acircumflex";s:4:"-110";s:9:"Adieresis";s:4:"-110";s:6:"Agrave";s:4:"-110";s:7:"Amacron";s:4:"-110";s:7:"Aogonek";s:4:"-110";s:5:"Aring";s:4:"-110";s:6:"Atilde";s:4:"-110";s:1:"O";s:3:"-35";s:6:"Oacute";s:3:"-35";s:11:"Ocircumflex";s:3:"-35";s:9:"Odieresis";s:3:"-35";s:6:"Ograve";s:3:"-35";s:13:"Ohungarumlaut";s:3:"-35";s:7:"Omacron";s:3:"-35";s:6:"Oslash";s:3:"-35";s:6:"Otilde";s:3:"-35";s:1:"a";s:3:"-85";s:6:"aacute";s:3:"-85";s:6:"abreve";s:3:"-85";s:11:"acircumflex";s:3:"-85";s:9:"adieresis";s:3:"-85";s:6:"agrave";s:3:"-85";s:7:"amacron";s:3:"-85";s:7:"aogonek";s:3:"-85";s:5:"aring";s:3:"-85";s:6:"atilde";s:3:"-85";s:5:"colon";s:3:"-92";s:5:"comma";s:3:"-92";s:1:"e";s:4:"-111";s:6:"eacute";s:4:"-111";s:6:"ecaron";s:4:"-111";s:11:"ecircumflex";s:4:"-111";s:9:"edieresis";s:3:"-71";s:10:"edotaccent";s:4:"-111";s:6:"egrave";s:3:"-71";s:7:"emacron";s:3:"-71";s:7:"eogonek";s:4:"-111";s:6:"hyphen";s:3:"-92";s:1:"i";s:3:"-37";s:6:"iacute";s:3:"-37";s:7:"iogonek";s:3:"-37";s:1:"o";s:4:"-111";s:6:"oacute";s:4:"-111";s:11:"ocircumflex";s:4:"-111";s:9:"odieresis";s:4:"-111";s:6:"ograve";s:4:"-111";s:13:"ohungarumlaut";s:4:"-111";s:7:"omacron";s:4:"-111";s:6:"oslash";s:4:"-111";s:6:"otilde";s:4:"-111";s:6:"period";s:3:"-92";s:9:"semicolon";s:3:"-92";s:1:"u";s:3:"-92";s:6:"uacute";s:3:"-92";s:11:"ucircumflex";s:3:"-92";s:9:"udieresis";s:3:"-92";s:6:"ugrave";s:3:"-92";s:13:"uhungarumlaut";s:3:"-92";s:7:"umacron";s:3:"-92";s:7:"uogonek";s:3:"-92";s:5:"uring";s:3:"-92";}s:1:"a";a:1:{s:1:"v";s:3:"-25";}s:6:"aacute";a:1:{s:1:"v";s:3:"-25";}s:6:"abreve";a:1:{s:1:"v";s:3:"-25";}s:11:"acircumflex";a:1:{s:1:"v";s:3:"-25";}s:9:"adieresis";a:1:{s:1:"v";s:3:"-25";}s:6:"agrave";a:1:{s:1:"v";s:3:"-25";}s:7:"amacron";a:1:{s:1:"v";s:3:"-25";}s:7:"aogonek";a:1:{s:1:"v";s:3:"-25";}s:5:"aring";a:1:{s:1:"v";s:3:"-25";}s:6:"atilde";a:1:{s:1:"v";s:3:"-25";}s:1:"b";a:12:{s:1:"b";s:3:"-10";s:6:"period";s:3:"-40";s:1:"u";s:3:"-20";s:6:"uacute";s:3:"-20";s:11:"ucircumflex";s:3:"-20";s:9:"udieresis";s:3:"-20";s:6:"ugrave";s:3:"-20";s:13:"uhungarumlaut";s:3:"-20";s:7:"umacron";s:3:"-20";s:7:"uogonek";s:3:"-20";s:5:"uring";s:3:"-20";s:1:"v";s:3:"-15";}s:5:"comma";a:2:{s:13:"quotedblright";s:3:"-45";s:10:"quoteright";s:3:"-55";}s:1:"d";a:1:{s:1:"w";s:3:"-15";}s:6:"dcroat";a:1:{s:1:"w";s:3:"-15";}s:1:"e";a:1:{s:1:"v";s:3:"-15";}s:6:"eacute";a:1:{s:1:"v";s:3:"-15";}s:6:"ecaron";a:1:{s:1:"v";s:3:"-15";}s:11:"ecircumflex";a:1:{s:1:"v";s:3:"-15";}s:9:"edieresis";a:1:{s:1:"v";s:3:"-15";}s:10:"edotaccent";a:1:{s:1:"v";s:3:"-15";}s:6:"egrave";a:1:{s:1:"v";s:3:"-15";}s:7:"emacron";a:1:{s:1:"v";s:3:"-15";}s:7:"eogonek";a:1:{s:1:"v";s:3:"-15";}s:1:"f";a:15:{s:5:"comma";s:3:"-15";s:8:"dotlessi";s:3:"-35";s:1:"i";s:3:"-25";s:1:"o";s:3:"-25";s:6:"oacute";s:3:"-25";s:11:"ocircumflex";s:3:"-25";s:9:"odieresis";s:3:"-25";s:6:"ograve";s:3:"-25";s:13:"ohungarumlaut";s:3:"-25";s:7:"omacron";s:3:"-25";s:6:"oslash";s:3:"-25";s:6:"otilde";s:3:"-25";s:6:"period";s:3:"-15";s:13:"quotedblright";s:2:"50";s:10:"quoteright";s:2:"55";}s:1:"g";a:1:{s:6:"period";s:3:"-15";}s:6:"gbreve";a:1:{s:6:"period";s:3:"-15";}s:12:"gcommaaccent";a:1:{s:6:"period";s:3:"-15";}s:1:"h";a:3:{s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:1:"i";a:1:{s:1:"v";s:3:"-10";}s:6:"iacute";a:1:{s:1:"v";s:3:"-10";}s:11:"icircumflex";a:1:{s:1:"v";s:3:"-10";}s:9:"idieresis";a:1:{s:1:"v";s:3:"-10";}s:6:"igrave";a:1:{s:1:"v";s:3:"-10";}s:7:"imacron";a:1:{s:1:"v";s:3:"-10";}s:7:"iogonek";a:1:{s:1:"v";s:3:"-10";}s:1:"k";a:21:{s:1:"e";s:3:"-10";s:6:"eacute";s:3:"-10";s:6:"ecaron";s:3:"-10";s:11:"ecircumflex";s:3:"-10";s:9:"edieresis";s:3:"-10";s:10:"edotaccent";s:3:"-10";s:6:"egrave";s:3:"-10";s:7:"emacron";s:3:"-10";s:7:"eogonek";s:3:"-10";s:1:"o";s:3:"-15";s:6:"oacute";s:3:"-15";s:11:"ocircumflex";s:3:"-15";s:9:"odieresis";s:3:"-15";s:6:"ograve";s:3:"-15";s:13:"ohungarumlaut";s:3:"-15";s:7:"omacron";s:3:"-15";s:6:"oslash";s:3:"-15";s:6:"otilde";s:3:"-15";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:12:"kcommaaccent";a:21:{s:1:"e";s:3:"-10";s:6:"eacute";s:3:"-10";s:6:"ecaron";s:3:"-10";s:11:"ecircumflex";s:3:"-10";s:9:"edieresis";s:3:"-10";s:10:"edotaccent";s:3:"-10";s:6:"egrave";s:3:"-10";s:7:"emacron";s:3:"-10";s:7:"eogonek";s:3:"-10";s:1:"o";s:3:"-15";s:6:"oacute";s:3:"-15";s:11:"ocircumflex";s:3:"-15";s:9:"odieresis";s:3:"-15";s:6:"ograve";s:3:"-15";s:13:"ohungarumlaut";s:3:"-15";s:7:"omacron";s:3:"-15";s:6:"oslash";s:3:"-15";s:6:"otilde";s:3:"-15";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:1:"n";a:1:{s:1:"v";s:3:"-40";}s:6:"nacute";a:1:{s:1:"v";s:3:"-40";}s:6:"ncaron";a:1:{s:1:"v";s:3:"-40";}s:12:"ncommaaccent";a:1:{s:1:"v";s:3:"-40";}s:6:"ntilde";a:1:{s:1:"v";s:3:"-40";}s:1:"o";a:2:{s:1:"v";s:3:"-10";s:1:"w";s:3:"-10";}s:6:"oacute";a:2:{s:1:"v";s:3:"-10";s:1:"w";s:3:"-10";}s:11:"ocircumflex";a:2:{s:1:"v";s:3:"-10";s:1:"w";s:3:"-10";}s:9:"odieresis";a:2:{s:1:"v";s:3:"-10";s:1:"w";s:3:"-10";}s:6:"ograve";a:2:{s:1:"v";s:3:"-10";s:1:"w";s:3:"-10";}s:13:"ohungarumlaut";a:2:{s:1:"v";s:3:"-10";s:1:"w";s:3:"-10";}s:7:"omacron";a:2:{s:1:"v";s:3:"-10";s:1:"w";s:3:"-10";}s:6:"oslash";a:2:{s:1:"v";s:3:"-10";s:1:"w";s:3:"-10";}s:6:"otilde";a:2:{s:1:"v";s:3:"-10";s:1:"w";s:3:"-10";}s:6:"period";a:2:{s:13:"quotedblright";s:3:"-55";s:10:"quoteright";s:3:"-55";}s:12:"quotedblleft";a:10:{s:1:"A";s:3:"-10";s:6:"Aacute";s:3:"-10";s:6:"Abreve";s:3:"-10";s:11:"Acircumflex";s:3:"-10";s:9:"Adieresis";s:3:"-10";s:6:"Agrave";s:3:"-10";s:7:"Amacron";s:3:"-10";s:7:"Aogonek";s:3:"-10";s:5:"Aring";s:3:"-10";s:6:"Atilde";s:3:"-10";}s:9:"quoteleft";a:11:{s:1:"A";s:3:"-10";s:6:"Aacute";s:3:"-10";s:6:"Abreve";s:3:"-10";s:11:"Acircumflex";s:3:"-10";s:9:"Adieresis";s:3:"-10";s:6:"Agrave";s:3:"-10";s:7:"Amacron";s:3:"-10";s:7:"Aogonek";s:3:"-10";s:5:"Aring";s:3:"-10";s:6:"Atilde";s:3:"-10";s:9:"quoteleft";s:3:"-63";}s:10:"quoteright";a:14:{s:1:"d";s:3:"-20";s:6:"dcroat";s:3:"-20";s:10:"quoteright";s:3:"-63";s:1:"r";s:3:"-20";s:6:"racute";s:3:"-20";s:6:"rcaron";s:3:"-20";s:12:"rcommaaccent";s:3:"-20";s:1:"s";s:3:"-37";s:6:"sacute";s:3:"-37";s:6:"scaron";s:3:"-37";s:8:"scedilla";s:3:"-37";s:12:"scommaaccent";s:3:"-37";s:5:"space";s:3:"-74";s:1:"v";s:3:"-20";}s:1:"r";a:36:{s:1:"c";s:3:"-18";s:6:"cacute";s:3:"-18";s:6:"ccaron";s:3:"-18";s:8:"ccedilla";s:3:"-18";s:5:"comma";s:3:"-92";s:1:"e";s:3:"-18";s:6:"eacute";s:3:"-18";s:6:"ecaron";s:3:"-18";s:11:"ecircumflex";s:3:"-18";s:9:"edieresis";s:3:"-18";s:10:"edotaccent";s:3:"-18";s:6:"egrave";s:3:"-18";s:7:"emacron";s:3:"-18";s:7:"eogonek";s:3:"-18";s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";s:6:"hyphen";s:3:"-37";s:1:"n";s:3:"-15";s:6:"nacute";s:3:"-15";s:6:"ncaron";s:3:"-15";s:12:"ncommaaccent";s:3:"-15";s:6:"ntilde";s:3:"-15";s:1:"o";s:3:"-18";s:6:"oacute";s:3:"-18";s:11:"ocircumflex";s:3:"-18";s:9:"odieresis";s:3:"-18";s:6:"ograve";s:3:"-18";s:13:"ohungarumlaut";s:3:"-18";s:7:"omacron";s:3:"-18";s:6:"oslash";s:3:"-18";s:6:"otilde";s:3:"-18";s:1:"p";s:3:"-10";s:6:"period";s:4:"-100";s:1:"q";s:3:"-18";s:1:"v";s:3:"-10";}s:6:"racute";a:36:{s:1:"c";s:3:"-18";s:6:"cacute";s:3:"-18";s:6:"ccaron";s:3:"-18";s:8:"ccedilla";s:3:"-18";s:5:"comma";s:3:"-92";s:1:"e";s:3:"-18";s:6:"eacute";s:3:"-18";s:6:"ecaron";s:3:"-18";s:11:"ecircumflex";s:3:"-18";s:9:"edieresis";s:3:"-18";s:10:"edotaccent";s:3:"-18";s:6:"egrave";s:3:"-18";s:7:"emacron";s:3:"-18";s:7:"eogonek";s:3:"-18";s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";s:6:"hyphen";s:3:"-37";s:1:"n";s:3:"-15";s:6:"nacute";s:3:"-15";s:6:"ncaron";s:3:"-15";s:12:"ncommaaccent";s:3:"-15";s:6:"ntilde";s:3:"-15";s:1:"o";s:3:"-18";s:6:"oacute";s:3:"-18";s:11:"ocircumflex";s:3:"-18";s:9:"odieresis";s:3:"-18";s:6:"ograve";s:3:"-18";s:13:"ohungarumlaut";s:3:"-18";s:7:"omacron";s:3:"-18";s:6:"oslash";s:3:"-18";s:6:"otilde";s:3:"-18";s:1:"p";s:3:"-10";s:6:"period";s:4:"-100";s:1:"q";s:3:"-18";s:1:"v";s:3:"-10";}s:6:"rcaron";a:36:{s:1:"c";s:3:"-18";s:6:"cacute";s:3:"-18";s:6:"ccaron";s:3:"-18";s:8:"ccedilla";s:3:"-18";s:5:"comma";s:3:"-92";s:1:"e";s:3:"-18";s:6:"eacute";s:3:"-18";s:6:"ecaron";s:3:"-18";s:11:"ecircumflex";s:3:"-18";s:9:"edieresis";s:3:"-18";s:10:"edotaccent";s:3:"-18";s:6:"egrave";s:3:"-18";s:7:"emacron";s:3:"-18";s:7:"eogonek";s:3:"-18";s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";s:6:"hyphen";s:3:"-37";s:1:"n";s:3:"-15";s:6:"nacute";s:3:"-15";s:6:"ncaron";s:3:"-15";s:12:"ncommaaccent";s:3:"-15";s:6:"ntilde";s:3:"-15";s:1:"o";s:3:"-18";s:6:"oacute";s:3:"-18";s:11:"ocircumflex";s:3:"-18";s:9:"odieresis";s:3:"-18";s:6:"ograve";s:3:"-18";s:13:"ohungarumlaut";s:3:"-18";s:7:"omacron";s:3:"-18";s:6:"oslash";s:3:"-18";s:6:"otilde";s:3:"-18";s:1:"p";s:3:"-10";s:6:"period";s:4:"-100";s:1:"q";s:3:"-18";s:1:"v";s:3:"-10";}s:12:"rcommaaccent";a:36:{s:1:"c";s:3:"-18";s:6:"cacute";s:3:"-18";s:6:"ccaron";s:3:"-18";s:8:"ccedilla";s:3:"-18";s:5:"comma";s:3:"-92";s:1:"e";s:3:"-18";s:6:"eacute";s:3:"-18";s:6:"ecaron";s:3:"-18";s:11:"ecircumflex";s:3:"-18";s:9:"edieresis";s:3:"-18";s:10:"edotaccent";s:3:"-18";s:6:"egrave";s:3:"-18";s:7:"emacron";s:3:"-18";s:7:"eogonek";s:3:"-18";s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";s:6:"hyphen";s:3:"-37";s:1:"n";s:3:"-15";s:6:"nacute";s:3:"-15";s:6:"ncaron";s:3:"-15";s:12:"ncommaaccent";s:3:"-15";s:6:"ntilde";s:3:"-15";s:1:"o";s:3:"-18";s:6:"oacute";s:3:"-18";s:11:"ocircumflex";s:3:"-18";s:9:"odieresis";s:3:"-18";s:6:"ograve";s:3:"-18";s:13:"ohungarumlaut";s:3:"-18";s:7:"omacron";s:3:"-18";s:6:"oslash";s:3:"-18";s:6:"otilde";s:3:"-18";s:1:"p";s:3:"-10";s:6:"period";s:4:"-100";s:1:"q";s:3:"-18";s:1:"v";s:3:"-10";}s:5:"space";a:18:{s:1:"A";s:3:"-55";s:6:"Aacute";s:3:"-55";s:6:"Abreve";s:3:"-55";s:11:"Acircumflex";s:3:"-55";s:9:"Adieresis";s:3:"-55";s:6:"Agrave";s:3:"-55";s:7:"Amacron";s:3:"-55";s:7:"Aogonek";s:3:"-55";s:5:"Aring";s:3:"-55";s:6:"Atilde";s:3:"-55";s:1:"T";s:3:"-30";s:6:"Tcaron";s:3:"-30";s:12:"Tcommaaccent";s:3:"-30";s:1:"V";s:3:"-45";s:1:"W";s:3:"-30";s:1:"Y";s:3:"-55";s:6:"Yacute";s:3:"-55";s:9:"Ydieresis";s:3:"-55";}s:1:"v";a:30:{s:1:"a";s:3:"-10";s:6:"aacute";s:3:"-10";s:6:"abreve";s:3:"-10";s:11:"acircumflex";s:3:"-10";s:9:"adieresis";s:3:"-10";s:6:"agrave";s:3:"-10";s:7:"amacron";s:3:"-10";s:7:"aogonek";s:3:"-10";s:5:"aring";s:3:"-10";s:6:"atilde";s:3:"-10";s:5:"comma";s:3:"-55";s:1:"e";s:3:"-10";s:6:"eacute";s:3:"-10";s:6:"ecaron";s:3:"-10";s:11:"ecircumflex";s:3:"-10";s:9:"edieresis";s:3:"-10";s:10:"edotaccent";s:3:"-10";s:6:"egrave";s:3:"-10";s:7:"emacron";s:3:"-10";s:7:"eogonek";s:3:"-10";s:1:"o";s:3:"-10";s:6:"oacute";s:3:"-10";s:11:"ocircumflex";s:3:"-10";s:9:"odieresis";s:3:"-10";s:6:"ograve";s:3:"-10";s:13:"ohungarumlaut";s:3:"-10";s:7:"omacron";s:3:"-10";s:6:"oslash";s:3:"-10";s:6:"otilde";s:3:"-10";s:6:"period";s:3:"-70";}s:1:"w";a:11:{s:5:"comma";s:3:"-55";s:1:"o";s:3:"-10";s:6:"oacute";s:3:"-10";s:11:"ocircumflex";s:3:"-10";s:9:"odieresis";s:3:"-10";s:6:"ograve";s:3:"-10";s:13:"ohungarumlaut";s:3:"-10";s:7:"omacron";s:3:"-10";s:6:"oslash";s:3:"-10";s:6:"otilde";s:3:"-10";s:6:"period";s:3:"-70";}s:1:"y";a:20:{s:5:"comma";s:3:"-55";s:1:"e";s:3:"-10";s:6:"eacute";s:3:"-10";s:6:"ecaron";s:3:"-10";s:11:"ecircumflex";s:3:"-10";s:9:"edieresis";s:3:"-10";s:10:"edotaccent";s:3:"-10";s:6:"egrave";s:3:"-10";s:7:"emacron";s:3:"-10";s:7:"eogonek";s:3:"-10";s:1:"o";s:3:"-25";s:6:"oacute";s:3:"-25";s:11:"ocircumflex";s:3:"-25";s:9:"odieresis";s:3:"-25";s:6:"ograve";s:3:"-25";s:13:"ohungarumlaut";s:3:"-25";s:7:"omacron";s:3:"-25";s:6:"oslash";s:3:"-25";s:6:"otilde";s:3:"-25";s:6:"period";s:3:"-70";}s:6:"yacute";a:20:{s:5:"comma";s:3:"-55";s:1:"e";s:3:"-10";s:6:"eacute";s:3:"-10";s:6:"ecaron";s:3:"-10";s:11:"ecircumflex";s:3:"-10";s:9:"edieresis";s:3:"-10";s:10:"edotaccent";s:3:"-10";s:6:"egrave";s:3:"-10";s:7:"emacron";s:3:"-10";s:7:"eogonek";s:3:"-10";s:1:"o";s:3:"-25";s:6:"oacute";s:3:"-25";s:11:"ocircumflex";s:3:"-25";s:9:"odieresis";s:3:"-25";s:6:"ograve";s:3:"-25";s:13:"ohungarumlaut";s:3:"-25";s:7:"omacron";s:3:"-25";s:6:"oslash";s:3:"-25";s:6:"otilde";s:3:"-25";s:6:"period";s:3:"-70";}s:9:"ydieresis";a:20:{s:5:"comma";s:3:"-55";s:1:"e";s:3:"-10";s:6:"eacute";s:3:"-10";s:6:"ecaron";s:3:"-10";s:11:"ecircumflex";s:3:"-10";s:9:"edieresis";s:3:"-10";s:10:"edotaccent";s:3:"-10";s:6:"egrave";s:3:"-10";s:7:"emacron";s:3:"-10";s:7:"eogonek";s:3:"-10";s:1:"o";s:3:"-25";s:6:"oacute";s:3:"-25";s:11:"ocircumflex";s:3:"-25";s:9:"odieresis";s:3:"-25";s:6:"ograve";s:3:"-25";s:13:"ohungarumlaut";s:3:"-25";s:7:"omacron";s:3:"-25";s:6:"oslash";s:3:"-25";s:6:"otilde";s:3:"-25";s:6:"period";s:3:"-70";}}s:9:"_version_";i:1;}
\ No newline at end of file
Added: trunk/mapbender/http/classes/fonts/php_Times-Roman.afm
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/fonts/php_Times-Roman.afm?view=auto&rev=13
--- (empty file)
+++ trunk/mapbender/http/classes/fonts/php_Times-Roman.afm 2006-04-13 19:38:28+0000
@@ -0,0 +1 @@
+a:22:{s:8:"FontName";s:11:"Times-Roman";s:8:"FullName";s:11:"Times Roman";s:10:"FamilyName";s:5:"Times";s:6:"Weight";s:5:"Roman";s:11:"ItalicAngle";s:1:"0";s:12:"IsFixedPitch";s:5:"false";s:12:"CharacterSet";s:13:"ExtendedRoman";s:8:"FontBBox";a:4:{i:0;s:4:"-168";i:1;s:4:"-218";i:2;s:4:"1000";i:3;s:3:"898";}s:17:"UnderlinePosition";s:4:"-100";s:18:"UnderlineThickness";s:2:"50";s:7:"Version";s:7:"002.000";s:14:"EncodingScheme";s:21:"AdobeStandardEncoding";s:9:"CapHeight";s:3:"662";s:7:"XHeight";s:3:"450";s:8:"Ascender";s:3:"683";s:9:"Descender";s:4:"-217";s:5:"StdHW";s:2:"28";s:5:"StdVW";s:2:"84";s:16:"StartCharMetrics";s:3:"315";s:1:"C";a:464:{i:32;a:4:{s:1:"C";s:2:"32";s:2:"WX";s:3:"250";s:1:"N";s:5:"space";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}s:5:"space";a:4:{s:1:"C";s:2:"32";s:2:"WX";s:3:"250";s:1:"N";s:5:"space";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}i:33;a:4:{s:1:"C";s:2:"33";s:2:"WX";s:3:"333";s:1:"N";s:6:"exclam";s:1:"B";a:4:{i:0;s:3:"130";i:1;s:2:"-9";i:2;s:3:"238";i:3;s:3:"676";}}s:6:"exclam";a:4:{s:1:"C";s:2:"33";s:2:"WX";s:3:"333";s:1:"N";s:6:"exclam";s:1:"B";a:4:{i:0;s:3:"130";i:1;s:2:"-9";i:2;s:3:"238";i:3;s:3:"676";}}i:34;a:4:{s:1:"C";s:2:"34";s:2:"WX";s:3:"408";s:1:"N";s:8:"quotedbl";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:3:"431";i:2;s:3:"331";i:3;s:3:"676";}}s:8:"quotedbl";a:4:{s:1:"C";s:2:"34";s:2:"WX";s:3:"408";s:1:"N";s:8:"quotedbl";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:3:"431";i:2;s:3:"331";i:3;s:3:"676";}}i:35;a:4:{s:1:"C";s:2:"35";s:2:"WX";s:3:"500";s:1:"N";s:10:"numbersign";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:1:"0";i:2;s:3:"496";i:3;s:3:"662";}}s:10:"numbersign";a:4:{s:1:"C";s:2:"35";s:2:"WX";s:3:"500";s:1:"N";s:10:"numbersign";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:1:"0";i:2;s:3:"496";i:3;s:3:"662";}}i:36;a:4:{s:1:"C";s:2:"36";s:2:"WX";s:3:"500";s:1:"N";s:6:"dollar";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-87";i:2;s:3:"457";i:3;s:3:"727";}}s:6:"dollar";a:4:{s:1:"C";s:2:"36";s:2:"WX";s:3:"500";s:1:"N";s:6:"dollar";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-87";i:2;s:3:"457";i:3;s:3:"727";}}i:37;a:4:{s:1:"C";s:2:"37";s:2:"WX";s:3:"833";s:1:"N";s:7:"percent";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:3:"-13";i:2;s:3:"772";i:3;s:3:"676";}}s:7:"percent";a:4:{s:1:"C";s:2:"37";s:2:"WX";s:3:"833";s:1:"N";s:7:"percent";s:1:"B";a:4:{i:0;s:2:"61";i:1;s:3:"-13";i:2;s:3:"772";i:3;s:3:"676";}}i:38;a:4:{s:1:"C";s:2:"38";s:2:"WX";s:3:"778";s:1:"N";s:9:"ampersand";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"750";i:3;s:3:"676";}}s:9:"ampersand";a:4:{s:1:"C";s:2:"38";s:2:"WX";s:3:"778";s:1:"N";s:9:"ampersand";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"750";i:3;s:3:"676";}}i:39;a:4:{s:1:"C";s:2:"39";s:2:"WX";s:3:"333";s:1:"N";s:10:"quoteright";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:3:"433";i:2;s:3:"218";i:3;s:3:"676";}}s:10:"quoteright";a:4:{s:1:"C";s:2:"39";s:2:"WX";s:3:"333";s:1:"N";s:10:"quoteright";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:3:"433";i:2;s:3:"218";i:3;s:3:"676";}}i:40;a:4:{s:1:"C";s:2:"40";s:2:"WX";s:3:"333";s:1:"N";s:9:"parenleft";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:4:"-177";i:2;s:3:"304";i:3;s:3:"676";}}s:9:"parenleft";a:4:{s:1:"C";s:2:"40";s:2:"WX";s:3:"333";s:1:"N";s:9:"parenleft";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:4:"-177";i:2;s:3:"304";i:3;s:3:"676";}}i:41;a:4:{s:1:"C";s:2:"41";s:2:"WX";s:3:"333";s:1:"N";s:10:"parenright";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:4:"-177";i:2;s:3:"285";i:3;s:3:"676";}}s:10:"parenright";a:4:{s:1:"C";s:2:"41";s:2:"WX";s:3:"333";s:1:"N";s:10:"parenright";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:4:"-177";i:2;s:3:"285";i:3;s:3:"676";}}i:42;a:4:{s:1:"C";s:2:"42";s:2:"WX";s:3:"500";s:1:"N";s:8:"asterisk";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:3:"265";i:2;s:3:"432";i:3;s:3:"676";}}s:8:"asterisk";a:4:{s:1:"C";s:2:"42";s:2:"WX";s:3:"500";s:1:"N";s:8:"asterisk";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:3:"265";i:2;s:3:"432";i:3;s:3:"676";}}i:43;a:4:{s:1:"C";s:2:"43";s:2:"WX";s:3:"564";s:1:"N";s:4:"plus";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:1:"0";i:2;s:3:"534";i:3;s:3:"506";}}s:4:"plus";a:4:{s:1:"C";s:2:"43";s:2:"WX";s:3:"564";s:1:"N";s:4:"plus";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:1:"0";i:2;s:3:"534";i:3;s:3:"506";}}i:44;a:4:{s:1:"C";s:2:"44";s:2:"WX";s:3:"250";s:1:"N";s:5:"comma";s:1:"B";a:4:{i:0;s:2:"56";i:1;s:4:"-141";i:2;s:3:"195";i:3;s:3:"102";}}s:5:"comma";a:4:{s:1:"C";s:2:"44";s:2:"WX";s:3:"250";s:1:"N";s:5:"comma";s:1:"B";a:4:{i:0;s:2:"56";i:1;s:4:"-141";i:2;s:3:"195";i:3;s:3:"102";}}i:45;a:4:{s:1:"C";s:2:"45";s:2:"WX";s:3:"333";s:1:"N";s:6:"hyphen";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:3:"194";i:2;s:3:"285";i:3;s:3:"257";}}s:6:"hyphen";a:4:{s:1:"C";s:2:"45";s:2:"WX";s:3:"333";s:1:"N";s:6:"hyphen";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:3:"194";i:2;s:3:"285";i:3;s:3:"257";}}i:46;a:4:{s:1:"C";s:2:"46";s:2:"WX";s:3:"250";s:1:"N";s:6:"period";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:3:"-11";i:2;s:3:"181";i:3;s:3:"100";}}s:6:"period";a:4:{s:1:"C";s:2:"46";s:2:"WX";s:3:"250";s:1:"N";s:6:"period";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:3:"-11";i:2;s:3:"181";i:3;s:3:"100";}}i:47;a:4:{s:1:"C";s:2:"47";s:2:"WX";s:3:"278";s:1:"N";s:5:"slash";s:1:"B";a:4:{i:0;s:2:"-9";i:1;s:3:"-14";i:2;s:3:"287";i:3;s:3:"676";}}s:5:"slash";a:4:{s:1:"C";s:2:"47";s:2:"WX";s:3:"278";s:1:"N";s:5:"slash";s:1:"B";a:4:{i:0;s:2:"-9";i:1;s:3:"-14";i:2;s:3:"287";i:3;s:3:"676";}}i:48;a:4:{s:1:"C";s:2:"48";s:2:"WX";s:3:"500";s:1:"N";s:4:"zero";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:3:"-14";i:2;s:3:"476";i:3;s:3:"676";}}s:4:"zero";a:4:{s:1:"C";s:2:"48";s:2:"WX";s:3:"500";s:1:"N";s:4:"zero";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:3:"-14";i:2;s:3:"476";i:3;s:3:"676";}}i:49;a:4:{s:1:"C";s:2:"49";s:2:"WX";s:3:"500";s:1:"N";s:3:"one";s:1:"B";a:4:{i:0;s:3:"111";i:1;s:1:"0";i:2;s:3:"394";i:3;s:3:"676";}}s:3:"one";a:4:{s:1:"C";s:2:"49";s:2:"WX";s:3:"500";s:1:"N";s:3:"one";s:1:"B";a:4:{i:0;s:3:"111";i:1;s:1:"0";i:2;s:3:"394";i:3;s:3:"676";}}i:50;a:4:{s:1:"C";s:2:"50";s:2:"WX";s:3:"500";s:1:"N";s:3:"two";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:1:"0";i:2;s:3:"475";i:3;s:3:"676";}}s:3:"two";a:4:{s:1:"C";s:2:"50";s:2:"WX";s:3:"500";s:1:"N";s:3:"two";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:1:"0";i:2;s:3:"475";i:3;s:3:"676";}}i:51;a:4:{s:1:"C";s:2:"51";s:2:"WX";s:3:"500";s:1:"N";s:5:"three";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:3:"-14";i:2;s:3:"431";i:3;s:3:"676";}}s:5:"three";a:4:{s:1:"C";s:2:"51";s:2:"WX";s:3:"500";s:1:"N";s:5:"three";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:3:"-14";i:2;s:3:"431";i:3;s:3:"676";}}i:52;a:4:{s:1:"C";s:2:"52";s:2:"WX";s:3:"500";s:1:"N";s:4:"four";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"472";i:3;s:3:"676";}}s:4:"four";a:4:{s:1:"C";s:2:"52";s:2:"WX";s:3:"500";s:1:"N";s:4:"four";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"472";i:3;s:3:"676";}}i:53;a:4:{s:1:"C";s:2:"53";s:2:"WX";s:3:"500";s:1:"N";s:4:"five";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:3:"-14";i:2;s:3:"438";i:3;s:3:"688";}}s:4:"five";a:4:{s:1:"C";s:2:"53";s:2:"WX";s:3:"500";s:1:"N";s:4:"five";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:3:"-14";i:2;s:3:"438";i:3;s:3:"688";}}i:54;a:4:{s:1:"C";s:2:"54";s:2:"WX";s:3:"500";s:1:"N";s:3:"six";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"468";i:3;s:3:"684";}}s:3:"six";a:4:{s:1:"C";s:2:"54";s:2:"WX";s:3:"500";s:1:"N";s:3:"six";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"468";i:3;s:3:"684";}}i:55;a:4:{s:1:"C";s:2:"55";s:2:"WX";s:3:"500";s:1:"N";s:5:"seven";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:2:"-8";i:2;s:3:"449";i:3;s:3:"662";}}s:5:"seven";a:4:{s:1:"C";s:2:"55";s:2:"WX";s:3:"500";s:1:"N";s:5:"seven";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:2:"-8";i:2;s:3:"449";i:3;s:3:"662";}}i:56;a:4:{s:1:"C";s:2:"56";s:2:"WX";s:3:"500";s:1:"N";s:5:"eight";s:1:"B";a:4:{i:0;s:2:"56";i:1;s:3:"-14";i:2;s:3:"445";i:3;s:3:"676";}}s:5:"eight";a:4:{s:1:"C";s:2:"56";s:2:"WX";s:3:"500";s:1:"N";s:5:"eight";s:1:"B";a:4:{i:0;s:2:"56";i:1;s:3:"-14";i:2;s:3:"445";i:3;s:3:"676";}}i:57;a:4:{s:1:"C";s:2:"57";s:2:"WX";s:3:"500";s:1:"N";s:4:"nine";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-22";i:2;s:3:"459";i:3;s:3:"676";}}s:4:"nine";a:4:{s:1:"C";s:2:"57";s:2:"WX";s:3:"500";s:1:"N";s:4:"nine";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-22";i:2;s:3:"459";i:3;s:3:"676";}}i:58;a:4:{s:1:"C";s:2:"58";s:2:"WX";s:3:"278";s:1:"N";s:5:"colon";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:3:"-11";i:2;s:3:"192";i:3;s:3:"459";}}s:5:"colon";a:4:{s:1:"C";s:2:"58";s:2:"WX";s:3:"278";s:1:"N";s:5:"colon";s:1:"B";a:4:{i:0;s:2:"81";i:1;s:3:"-11";i:2;s:3:"192";i:3;s:3:"459";}}i:59;a:4:{s:1:"C";s:2:"59";s:2:"WX";s:3:"278";s:1:"N";s:9:"semicolon";s:1:"B";a:4:{i:0;s:2:"80";i:1;s:4:"-141";i:2;s:3:"219";i:3;s:3:"459";}}s:9:"semicolon";a:4:{s:1:"C";s:2:"59";s:2:"WX";s:3:"278";s:1:"N";s:9:"semicolon";s:1:"B";a:4:{i:0;s:2:"80";i:1;s:4:"-141";i:2;s:3:"219";i:3;s:3:"459";}}i:60;a:4:{s:1:"C";s:2:"60";s:2:"WX";s:3:"564";s:1:"N";s:4:"less";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:2:"-8";i:2;s:3:"536";i:3;s:3:"514";}}s:4:"less";a:4:{s:1:"C";s:2:"60";s:2:"WX";s:3:"564";s:1:"N";s:4:"less";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:2:"-8";i:2;s:3:"536";i:3;s:3:"514";}}i:61;a:4:{s:1:"C";s:2:"61";s:2:"WX";s:3:"564";s:1:"N";s:5:"equal";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"120";i:2;s:3:"534";i:3;s:3:"386";}}s:5:"equal";a:4:{s:1:"C";s:2:"61";s:2:"WX";s:3:"564";s:1:"N";s:5:"equal";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"120";i:2;s:3:"534";i:3;s:3:"386";}}i:62;a:4:{s:1:"C";s:2:"62";s:2:"WX";s:3:"564";s:1:"N";s:7:"greater";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:2:"-8";i:2;s:3:"536";i:3;s:3:"514";}}s:7:"greater";a:4:{s:1:"C";s:2:"62";s:2:"WX";s:3:"564";s:1:"N";s:7:"greater";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:2:"-8";i:2;s:3:"536";i:3;s:3:"514";}}i:63;a:4:{s:1:"C";s:2:"63";s:2:"WX";s:3:"444";s:1:"N";s:8:"question";s:1:"B";a:4:{i:0;s:2:"68";i:1;s:2:"-8";i:2;s:3:"414";i:3;s:3:"676";}}s:8:"question";a:4:{s:1:"C";s:2:"63";s:2:"WX";s:3:"444";s:1:"N";s:8:"question";s:1:"B";a:4:{i:0;s:2:"68";i:1;s:2:"-8";i:2;s:3:"414";i:3;s:3:"676";}}i:64;a:4:{s:1:"C";s:2:"64";s:2:"WX";s:3:"921";s:1:"N";s:2:"at";s:1:"B";a:4:{i:0;s:3:"116";i:1;s:3:"-14";i:2;s:3:"809";i:3;s:3:"676";}}s:2:"at";a:4:{s:1:"C";s:2:"64";s:2:"WX";s:3:"921";s:1:"N";s:2:"at";s:1:"B";a:4:{i:0;s:3:"116";i:1;s:3:"-14";i:2;s:3:"809";i:3;s:3:"676";}}i:65;a:4:{s:1:"C";s:2:"65";s:2:"WX";s:3:"722";s:1:"N";s:1:"A";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:1:"0";i:2;s:3:"706";i:3;s:3:"674";}}s:1:"A";a:4:{s:1:"C";s:2:"65";s:2:"WX";s:3:"722";s:1:"N";s:1:"A";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:1:"0";i:2;s:3:"706";i:3;s:3:"674";}}i:66;a:4:{s:1:"C";s:2:"66";s:2:"WX";s:3:"667";s:1:"N";s:1:"B";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:1:"0";i:2;s:3:"593";i:3;s:3:"662";}}s:1:"B";a:4:{s:1:"C";s:2:"66";s:2:"WX";s:3:"667";s:1:"N";s:1:"B";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:1:"0";i:2;s:3:"593";i:3;s:3:"662";}}i:67;a:4:{s:1:"C";s:2:"67";s:2:"WX";s:3:"667";s:1:"N";s:1:"C";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:3:"-14";i:2;s:3:"633";i:3;s:3:"676";}}s:1:"C";a:4:{s:1:"C";s:2:"67";s:2:"WX";s:3:"667";s:1:"N";s:1:"C";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:3:"-14";i:2;s:3:"633";i:3;s:3:"676";}}i:68;a:4:{s:1:"C";s:2:"68";s:2:"WX";s:3:"722";s:1:"N";s:1:"D";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"685";i:3;s:3:"662";}}s:1:"D";a:4:{s:1:"C";s:2:"68";s:2:"WX";s:3:"722";s:1:"N";s:1:"D";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"685";i:3;s:3:"662";}}i:69;a:4:{s:1:"C";s:2:"69";s:2:"WX";s:3:"611";s:1:"N";s:1:"E";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"597";i:3;s:3:"662";}}s:1:"E";a:4:{s:1:"C";s:2:"69";s:2:"WX";s:3:"611";s:1:"N";s:1:"E";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"597";i:3;s:3:"662";}}i:70;a:4:{s:1:"C";s:2:"70";s:2:"WX";s:3:"556";s:1:"N";s:1:"F";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"546";i:3;s:3:"662";}}s:1:"F";a:4:{s:1:"C";s:2:"70";s:2:"WX";s:3:"556";s:1:"N";s:1:"F";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"546";i:3;s:3:"662";}}i:71;a:4:{s:1:"C";s:2:"71";s:2:"WX";s:3:"722";s:1:"N";s:1:"G";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:3:"-14";i:2;s:3:"709";i:3;s:3:"676";}}s:1:"G";a:4:{s:1:"C";s:2:"71";s:2:"WX";s:3:"722";s:1:"N";s:1:"G";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:3:"-14";i:2;s:3:"709";i:3;s:3:"676";}}i:72;a:4:{s:1:"C";s:2:"72";s:2:"WX";s:3:"722";s:1:"N";s:1:"H";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:1:"0";i:2;s:3:"702";i:3;s:3:"662";}}s:1:"H";a:4:{s:1:"C";s:2:"72";s:2:"WX";s:3:"722";s:1:"N";s:1:"H";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:1:"0";i:2;s:3:"702";i:3;s:3:"662";}}i:73;a:4:{s:1:"C";s:2:"73";s:2:"WX";s:3:"333";s:1:"N";s:1:"I";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:1:"0";i:2;s:3:"315";i:3;s:3:"662";}}s:1:"I";a:4:{s:1:"C";s:2:"73";s:2:"WX";s:3:"333";s:1:"N";s:1:"I";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:1:"0";i:2;s:3:"315";i:3;s:3:"662";}}i:74;a:4:{s:1:"C";s:2:"74";s:2:"WX";s:3:"389";s:1:"N";s:1:"J";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:3:"-14";i:2;s:3:"370";i:3;s:3:"662";}}s:1:"J";a:4:{s:1:"C";s:2:"74";s:2:"WX";s:3:"389";s:1:"N";s:1:"J";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:3:"-14";i:2;s:3:"370";i:3;s:3:"662";}}i:75;a:4:{s:1:"C";s:2:"75";s:2:"WX";s:3:"722";s:1:"N";s:1:"K";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:1:"0";i:2;s:3:"723";i:3;s:3:"662";}}s:1:"K";a:4:{s:1:"C";s:2:"75";s:2:"WX";s:3:"722";s:1:"N";s:1:"K";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:1:"0";i:2;s:3:"723";i:3;s:3:"662";}}i:76;a:4:{s:1:"C";s:2:"76";s:2:"WX";s:3:"611";s:1:"N";s:1:"L";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"598";i:3;s:3:"662";}}s:1:"L";a:4:{s:1:"C";s:2:"76";s:2:"WX";s:3:"611";s:1:"N";s:1:"L";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"598";i:3;s:3:"662";}}i:77;a:4:{s:1:"C";s:2:"77";s:2:"WX";s:3:"889";s:1:"N";s:1:"M";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"863";i:3;s:3:"662";}}s:1:"M";a:4:{s:1:"C";s:2:"77";s:2:"WX";s:3:"889";s:1:"N";s:1:"M";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"863";i:3;s:3:"662";}}i:78;a:4:{s:1:"C";s:2:"78";s:2:"WX";s:3:"722";s:1:"N";s:1:"N";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:3:"-11";i:2;s:3:"707";i:3;s:3:"662";}}s:1:"N";a:4:{s:1:"C";s:2:"78";s:2:"WX";s:3:"722";s:1:"N";s:1:"N";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:3:"-11";i:2;s:3:"707";i:3;s:3:"662";}}i:79;a:4:{s:1:"C";s:2:"79";s:2:"WX";s:3:"722";s:1:"N";s:1:"O";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"688";i:3;s:3:"676";}}s:1:"O";a:4:{s:1:"C";s:2:"79";s:2:"WX";s:3:"722";s:1:"N";s:1:"O";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"688";i:3;s:3:"676";}}i:80;a:4:{s:1:"C";s:2:"80";s:2:"WX";s:3:"556";s:1:"N";s:1:"P";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"542";i:3;s:3:"662";}}s:1:"P";a:4:{s:1:"C";s:2:"80";s:2:"WX";s:3:"556";s:1:"N";s:1:"P";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"542";i:3;s:3:"662";}}i:81;a:4:{s:1:"C";s:2:"81";s:2:"WX";s:3:"722";s:1:"N";s:1:"Q";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:4:"-178";i:2;s:3:"701";i:3;s:3:"676";}}s:1:"Q";a:4:{s:1:"C";s:2:"81";s:2:"WX";s:3:"722";s:1:"N";s:1:"Q";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:4:"-178";i:2;s:3:"701";i:3;s:3:"676";}}i:82;a:4:{s:1:"C";s:2:"82";s:2:"WX";s:3:"667";s:1:"N";s:1:"R";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:1:"0";i:2;s:3:"659";i:3;s:3:"662";}}s:1:"R";a:4:{s:1:"C";s:2:"82";s:2:"WX";s:3:"667";s:1:"N";s:1:"R";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:1:"0";i:2;s:3:"659";i:3;s:3:"662";}}i:83;a:4:{s:1:"C";s:2:"83";s:2:"WX";s:3:"556";s:1:"N";s:1:"S";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-14";i:2;s:3:"491";i:3;s:3:"676";}}s:1:"S";a:4:{s:1:"C";s:2:"83";s:2:"WX";s:3:"556";s:1:"N";s:1:"S";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-14";i:2;s:3:"491";i:3;s:3:"676";}}i:84;a:4:{s:1:"C";s:2:"84";s:2:"WX";s:3:"611";s:1:"N";s:1:"T";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:1:"0";i:2;s:3:"593";i:3;s:3:"662";}}s:1:"T";a:4:{s:1:"C";s:2:"84";s:2:"WX";s:3:"611";s:1:"N";s:1:"T";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:1:"0";i:2;s:3:"593";i:3;s:3:"662";}}i:85;a:4:{s:1:"C";s:2:"85";s:2:"WX";s:3:"722";s:1:"N";s:1:"U";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:3:"-14";i:2;s:3:"705";i:3;s:3:"662";}}s:1:"U";a:4:{s:1:"C";s:2:"85";s:2:"WX";s:3:"722";s:1:"N";s:1:"U";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:3:"-14";i:2;s:3:"705";i:3;s:3:"662";}}i:86;a:4:{s:1:"C";s:2:"86";s:2:"WX";s:3:"722";s:1:"N";s:1:"V";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-11";i:2;s:3:"697";i:3;s:3:"662";}}s:1:"V";a:4:{s:1:"C";s:2:"86";s:2:"WX";s:3:"722";s:1:"N";s:1:"V";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-11";i:2;s:3:"697";i:3;s:3:"662";}}i:87;a:4:{s:1:"C";s:2:"87";s:2:"WX";s:3:"944";s:1:"N";s:1:"W";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:3:"-11";i:2;s:3:"932";i:3;s:3:"662";}}s:1:"W";a:4:{s:1:"C";s:2:"87";s:2:"WX";s:3:"944";s:1:"N";s:1:"W";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:3:"-11";i:2;s:3:"932";i:3;s:3:"662";}}i:88;a:4:{s:1:"C";s:2:"88";s:2:"WX";s:3:"722";s:1:"N";s:1:"X";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:1:"0";i:2;s:3:"704";i:3;s:3:"662";}}s:1:"X";a:4:{s:1:"C";s:2:"88";s:2:"WX";s:3:"722";s:1:"N";s:1:"X";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:1:"0";i:2;s:3:"704";i:3;s:3:"662";}}i:89;a:4:{s:1:"C";s:2:"89";s:2:"WX";s:3:"722";s:1:"N";s:1:"Y";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:1:"0";i:2;s:3:"703";i:3;s:3:"662";}}s:1:"Y";a:4:{s:1:"C";s:2:"89";s:2:"WX";s:3:"722";s:1:"N";s:1:"Y";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:1:"0";i:2;s:3:"703";i:3;s:3:"662";}}i:90;a:4:{s:1:"C";s:2:"90";s:2:"WX";s:3:"611";s:1:"N";s:1:"Z";s:1:"B";a:4:{i:0;s:1:"9";i:1;s:1:"0";i:2;s:3:"597";i:3;s:3:"662";}}s:1:"Z";a:4:{s:1:"C";s:2:"90";s:2:"WX";s:3:"611";s:1:"N";s:1:"Z";s:1:"B";a:4:{i:0;s:1:"9";i:1;s:1:"0";i:2;s:3:"597";i:3;s:3:"662";}}i:91;a:4:{s:1:"C";s:2:"91";s:2:"WX";s:3:"333";s:1:"N";s:11:"bracketleft";s:1:"B";a:4:{i:0;s:2:"88";i:1;s:4:"-156";i:2;s:3:"299";i:3;s:3:"662";}}s:11:"bracketleft";a:4:{s:1:"C";s:2:"91";s:2:"WX";s:3:"333";s:1:"N";s:11:"bracketleft";s:1:"B";a:4:{i:0;s:2:"88";i:1;s:4:"-156";i:2;s:3:"299";i:3;s:3:"662";}}i:92;a:4:{s:1:"C";s:2:"92";s:2:"WX";s:3:"278";s:1:"N";s:9:"backslash";s:1:"B";a:4:{i:0;s:2:"-9";i:1;s:3:"-14";i:2;s:3:"287";i:3;s:3:"676";}}s:9:"backslash";a:4:{s:1:"C";s:2:"92";s:2:"WX";s:3:"278";s:1:"N";s:9:"backslash";s:1:"B";a:4:{i:0;s:2:"-9";i:1;s:3:"-14";i:2;s:3:"287";i:3;s:3:"676";}}i:93;a:4:{s:1:"C";s:2:"93";s:2:"WX";s:3:"333";s:1:"N";s:12:"bracketright";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:4:"-156";i:2;s:3:"245";i:3;s:3:"662";}}s:12:"bracketright";a:4:{s:1:"C";s:2:"93";s:2:"WX";s:3:"333";s:1:"N";s:12:"bracketright";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:4:"-156";i:2;s:3:"245";i:3;s:3:"662";}}i:94;a:4:{s:1:"C";s:2:"94";s:2:"WX";s:3:"469";s:1:"N";s:11:"asciicircum";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:3:"297";i:2;s:3:"446";i:3;s:3:"662";}}s:11:"asciicircum";a:4:{s:1:"C";s:2:"94";s:2:"WX";s:3:"469";s:1:"N";s:11:"asciicircum";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:3:"297";i:2;s:3:"446";i:3;s:3:"662";}}i:95;a:4:{s:1:"C";s:2:"95";s:2:"WX";s:3:"500";s:1:"N";s:10:"underscore";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:4:"-125";i:2;s:3:"500";i:3;s:3:"-75";}}s:10:"underscore";a:4:{s:1:"C";s:2:"95";s:2:"WX";s:3:"500";s:1:"N";s:10:"underscore";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:4:"-125";i:2;s:3:"500";i:3;s:3:"-75";}}i:96;a:4:{s:1:"C";s:2:"96";s:2:"WX";s:3:"333";s:1:"N";s:9:"quoteleft";s:1:"B";a:4:{i:0;s:3:"115";i:1;s:3:"433";i:2;s:3:"254";i:3;s:3:"676";}}s:9:"quoteleft";a:4:{s:1:"C";s:2:"96";s:2:"WX";s:3:"333";s:1:"N";s:9:"quoteleft";s:1:"B";a:4:{i:0;s:3:"115";i:1;s:3:"433";i:2;s:3:"254";i:3;s:3:"676";}}i:97;a:4:{s:1:"C";s:2:"97";s:2:"WX";s:3:"444";s:1:"N";s:1:"a";s:1:"B";a:4:{i:0;s:2:"37";i:1;s:3:"-10";i:2;s:3:"442";i:3;s:3:"460";}}s:1:"a";a:4:{s:1:"C";s:2:"97";s:2:"WX";s:3:"444";s:1:"N";s:1:"a";s:1:"B";a:4:{i:0;s:2:"37";i:1;s:3:"-10";i:2;s:3:"442";i:3;s:3:"460";}}i:98;a:4:{s:1:"C";s:2:"98";s:2:"WX";s:3:"500";s:1:"N";s:1:"b";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:3:"-10";i:2;s:3:"468";i:3;s:3:"683";}}s:1:"b";a:4:{s:1:"C";s:2:"98";s:2:"WX";s:3:"500";s:1:"N";s:1:"b";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:3:"-10";i:2;s:3:"468";i:3;s:3:"683";}}i:99;a:4:{s:1:"C";s:2:"99";s:2:"WX";s:3:"444";s:1:"N";s:1:"c";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-10";i:2;s:3:"412";i:3;s:3:"460";}}s:1:"c";a:4:{s:1:"C";s:2:"99";s:2:"WX";s:3:"444";s:1:"N";s:1:"c";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-10";i:2;s:3:"412";i:3;s:3:"460";}}i:100;a:4:{s:1:"C";s:3:"100";s:2:"WX";s:3:"500";s:1:"N";s:1:"d";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:3:"-10";i:2;s:3:"491";i:3;s:3:"683";}}s:1:"d";a:4:{s:1:"C";s:3:"100";s:2:"WX";s:3:"500";s:1:"N";s:1:"d";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:3:"-10";i:2;s:3:"491";i:3;s:3:"683";}}i:101;a:4:{s:1:"C";s:3:"101";s:2:"WX";s:3:"444";s:1:"N";s:1:"e";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-10";i:2;s:3:"424";i:3;s:3:"460";}}s:1:"e";a:4:{s:1:"C";s:3:"101";s:2:"WX";s:3:"444";s:1:"N";s:1:"e";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-10";i:2;s:3:"424";i:3;s:3:"460";}}i:102;a:5:{s:1:"C";s:3:"102";s:2:"WX";s:3:"333";s:1:"N";s:1:"f";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"383";i:3;s:3:"683";}s:1:"L";a:2:{i:0;s:1:"l";i:1;s:2:"fl";}}s:1:"f";a:5:{s:1:"C";s:3:"102";s:2:"WX";s:3:"333";s:1:"N";s:1:"f";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:1:"0";i:2;s:3:"383";i:3;s:3:"683";}s:1:"L";a:2:{i:0;s:1:"l";i:1;s:2:"fl";}}i:103;a:4:{s:1:"C";s:3:"103";s:2:"WX";s:3:"500";s:1:"N";s:1:"g";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:4:"-218";i:2;s:3:"470";i:3;s:3:"460";}}s:1:"g";a:4:{s:1:"C";s:3:"103";s:2:"WX";s:3:"500";s:1:"N";s:1:"g";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:4:"-218";i:2;s:3:"470";i:3;s:3:"460";}}i:104;a:4:{s:1:"C";s:3:"104";s:2:"WX";s:3:"500";s:1:"N";s:1:"h";s:1:"B";a:4:{i:0;s:1:"9";i:1;s:1:"0";i:2;s:3:"487";i:3;s:3:"683";}}s:1:"h";a:4:{s:1:"C";s:3:"104";s:2:"WX";s:3:"500";s:1:"N";s:1:"h";s:1:"B";a:4:{i:0;s:1:"9";i:1;s:1:"0";i:2;s:3:"487";i:3;s:3:"683";}}i:105;a:4:{s:1:"C";s:3:"105";s:2:"WX";s:3:"278";s:1:"N";s:1:"i";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"253";i:3;s:3:"683";}}s:1:"i";a:4:{s:1:"C";s:3:"105";s:2:"WX";s:3:"278";s:1:"N";s:1:"i";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"253";i:3;s:3:"683";}}i:106;a:4:{s:1:"C";s:3:"106";s:2:"WX";s:3:"278";s:1:"N";s:1:"j";s:1:"B";a:4:{i:0;s:3:"-70";i:1;s:4:"-218";i:2;s:3:"194";i:3;s:3:"683";}}s:1:"j";a:4:{s:1:"C";s:3:"106";s:2:"WX";s:3:"278";s:1:"N";s:1:"j";s:1:"B";a:4:{i:0;s:3:"-70";i:1;s:4:"-218";i:2;s:3:"194";i:3;s:3:"683";}}i:107;a:4:{s:1:"C";s:3:"107";s:2:"WX";s:3:"500";s:1:"N";s:1:"k";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:1:"0";i:2;s:3:"505";i:3;s:3:"683";}}s:1:"k";a:4:{s:1:"C";s:3:"107";s:2:"WX";s:3:"500";s:1:"N";s:1:"k";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:1:"0";i:2;s:3:"505";i:3;s:3:"683";}}i:108;a:4:{s:1:"C";s:3:"108";s:2:"WX";s:3:"278";s:1:"N";s:1:"l";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:1:"0";i:2;s:3:"257";i:3;s:3:"683";}}s:1:"l";a:4:{s:1:"C";s:3:"108";s:2:"WX";s:3:"278";s:1:"N";s:1:"l";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:1:"0";i:2;s:3:"257";i:3;s:3:"683";}}i:109;a:4:{s:1:"C";s:3:"109";s:2:"WX";s:3:"778";s:1:"N";s:1:"m";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"775";i:3;s:3:"460";}}s:1:"m";a:4:{s:1:"C";s:3:"109";s:2:"WX";s:3:"778";s:1:"N";s:1:"m";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"775";i:3;s:3:"460";}}i:110;a:4:{s:1:"C";s:3:"110";s:2:"WX";s:3:"500";s:1:"N";s:1:"n";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"485";i:3;s:3:"460";}}s:1:"n";a:4:{s:1:"C";s:3:"110";s:2:"WX";s:3:"500";s:1:"N";s:1:"n";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"485";i:3;s:3:"460";}}i:111;a:4:{s:1:"C";s:3:"111";s:2:"WX";s:3:"500";s:1:"N";s:1:"o";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:3:"-10";i:2;s:3:"470";i:3;s:3:"460";}}s:1:"o";a:4:{s:1:"C";s:3:"111";s:2:"WX";s:3:"500";s:1:"N";s:1:"o";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:3:"-10";i:2;s:3:"470";i:3;s:3:"460";}}i:112;a:4:{s:1:"C";s:3:"112";s:2:"WX";s:3:"500";s:1:"N";s:1:"p";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:4:"-217";i:2;s:3:"470";i:3;s:3:"460";}}s:1:"p";a:4:{s:1:"C";s:3:"112";s:2:"WX";s:3:"500";s:1:"N";s:1:"p";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:4:"-217";i:2;s:3:"470";i:3;s:3:"460";}}i:113;a:4:{s:1:"C";s:3:"113";s:2:"WX";s:3:"500";s:1:"N";s:1:"q";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:4:"-217";i:2;s:3:"488";i:3;s:3:"460";}}s:1:"q";a:4:{s:1:"C";s:3:"113";s:2:"WX";s:3:"500";s:1:"N";s:1:"q";s:1:"B";a:4:{i:0;s:2:"24";i:1;s:4:"-217";i:2;s:3:"488";i:3;s:3:"460";}}i:114;a:4:{s:1:"C";s:3:"114";s:2:"WX";s:3:"333";s:1:"N";s:1:"r";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:1:"0";i:2;s:3:"335";i:3;s:3:"460";}}s:1:"r";a:4:{s:1:"C";s:3:"114";s:2:"WX";s:3:"333";s:1:"N";s:1:"r";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:1:"0";i:2;s:3:"335";i:3;s:3:"460";}}i:115;a:4:{s:1:"C";s:3:"115";s:2:"WX";s:3:"389";s:1:"N";s:1:"s";s:1:"B";a:4:{i:0;s:2:"51";i:1;s:3:"-10";i:2;s:3:"348";i:3;s:3:"460";}}s:1:"s";a:4:{s:1:"C";s:3:"115";s:2:"WX";s:3:"389";s:1:"N";s:1:"s";s:1:"B";a:4:{i:0;s:2:"51";i:1;s:3:"-10";i:2;s:3:"348";i:3;s:3:"460";}}i:116;a:4:{s:1:"C";s:3:"116";s:2:"WX";s:3:"278";s:1:"N";s:1:"t";s:1:"B";a:4:{i:0;s:2:"13";i:1;s:3:"-10";i:2;s:3:"279";i:3;s:3:"579";}}s:1:"t";a:4:{s:1:"C";s:3:"116";s:2:"WX";s:3:"278";s:1:"N";s:1:"t";s:1:"B";a:4:{i:0;s:2:"13";i:1;s:3:"-10";i:2;s:3:"279";i:3;s:3:"579";}}i:117;a:4:{s:1:"C";s:3:"117";s:2:"WX";s:3:"500";s:1:"N";s:1:"u";s:1:"B";a:4:{i:0;s:1:"9";i:1;s:3:"-10";i:2;s:3:"479";i:3;s:3:"450";}}s:1:"u";a:4:{s:1:"C";s:3:"117";s:2:"WX";s:3:"500";s:1:"N";s:1:"u";s:1:"B";a:4:{i:0;s:1:"9";i:1;s:3:"-10";i:2;s:3:"479";i:3;s:3:"450";}}i:118;a:4:{s:1:"C";s:3:"118";s:2:"WX";s:3:"500";s:1:"N";s:1:"v";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:3:"-14";i:2;s:3:"477";i:3;s:3:"450";}}s:1:"v";a:4:{s:1:"C";s:3:"118";s:2:"WX";s:3:"500";s:1:"N";s:1:"v";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:3:"-14";i:2;s:3:"477";i:3;s:3:"450";}}i:119;a:4:{s:1:"C";s:3:"119";s:2:"WX";s:3:"722";s:1:"N";s:1:"w";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:3:"-14";i:2;s:3:"694";i:3;s:3:"450";}}s:1:"w";a:4:{s:1:"C";s:3:"119";s:2:"WX";s:3:"722";s:1:"N";s:1:"w";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:3:"-14";i:2;s:3:"694";i:3;s:3:"450";}}i:120;a:4:{s:1:"C";s:3:"120";s:2:"WX";s:3:"500";s:1:"N";s:1:"x";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:1:"0";i:2;s:3:"479";i:3;s:3:"450";}}s:1:"x";a:4:{s:1:"C";s:3:"120";s:2:"WX";s:3:"500";s:1:"N";s:1:"x";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:1:"0";i:2;s:3:"479";i:3;s:3:"450";}}i:121;a:4:{s:1:"C";s:3:"121";s:2:"WX";s:3:"500";s:1:"N";s:1:"y";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:4:"-218";i:2;s:3:"475";i:3;s:3:"450";}}s:1:"y";a:4:{s:1:"C";s:3:"121";s:2:"WX";s:3:"500";s:1:"N";s:1:"y";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:4:"-218";i:2;s:3:"475";i:3;s:3:"450";}}i:122;a:4:{s:1:"C";s:3:"122";s:2:"WX";s:3:"444";s:1:"N";s:1:"z";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:1:"0";i:2;s:3:"418";i:3;s:3:"450";}}s:1:"z";a:4:{s:1:"C";s:3:"122";s:2:"WX";s:3:"444";s:1:"N";s:1:"z";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:1:"0";i:2;s:3:"418";i:3;s:3:"450";}}i:123;a:4:{s:1:"C";s:3:"123";s:2:"WX";s:3:"480";s:1:"N";s:9:"braceleft";s:1:"B";a:4:{i:0;s:3:"100";i:1;s:4:"-181";i:2;s:3:"350";i:3;s:3:"680";}}s:9:"braceleft";a:4:{s:1:"C";s:3:"123";s:2:"WX";s:3:"480";s:1:"N";s:9:"braceleft";s:1:"B";a:4:{i:0;s:3:"100";i:1;s:4:"-181";i:2;s:3:"350";i:3;s:3:"680";}}i:124;a:4:{s:1:"C";s:3:"124";s:2:"WX";s:3:"200";s:1:"N";s:3:"bar";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:4:"-218";i:2;s:3:"133";i:3;s:3:"782";}}s:3:"bar";a:4:{s:1:"C";s:3:"124";s:2:"WX";s:3:"200";s:1:"N";s:3:"bar";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:4:"-218";i:2;s:3:"133";i:3;s:3:"782";}}i:125;a:4:{s:1:"C";s:3:"125";s:2:"WX";s:3:"480";s:1:"N";s:10:"braceright";s:1:"B";a:4:{i:0;s:3:"130";i:1;s:4:"-181";i:2;s:3:"380";i:3;s:3:"680";}}s:10:"braceright";a:4:{s:1:"C";s:3:"125";s:2:"WX";s:3:"480";s:1:"N";s:10:"braceright";s:1:"B";a:4:{i:0;s:3:"130";i:1;s:4:"-181";i:2;s:3:"380";i:3;s:3:"680";}}i:126;a:4:{s:1:"C";s:3:"126";s:2:"WX";s:3:"541";s:1:"N";s:10:"asciitilde";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"183";i:2;s:3:"502";i:3;s:3:"323";}}s:10:"asciitilde";a:4:{s:1:"C";s:3:"126";s:2:"WX";s:3:"541";s:1:"N";s:10:"asciitilde";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"183";i:2;s:3:"502";i:3;s:3:"323";}}i:161;a:4:{s:1:"C";s:3:"161";s:2:"WX";s:3:"333";s:1:"N";s:10:"exclamdown";s:1:"B";a:4:{i:0;s:2:"97";i:1;s:4:"-218";i:2;s:3:"205";i:3;s:3:"467";}}s:10:"exclamdown";a:4:{s:1:"C";s:3:"161";s:2:"WX";s:3:"333";s:1:"N";s:10:"exclamdown";s:1:"B";a:4:{i:0;s:2:"97";i:1;s:4:"-218";i:2;s:3:"205";i:3;s:3:"467";}}i:162;a:4:{s:1:"C";s:3:"162";s:2:"WX";s:3:"500";s:1:"N";s:4:"cent";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:4:"-138";i:2;s:3:"448";i:3;s:3:"579";}}s:4:"cent";a:4:{s:1:"C";s:3:"162";s:2:"WX";s:3:"500";s:1:"N";s:4:"cent";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:4:"-138";i:2;s:3:"448";i:3;s:3:"579";}}i:163;a:4:{s:1:"C";s:3:"163";s:2:"WX";s:3:"500";s:1:"N";s:8:"sterling";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:2:"-8";i:2;s:3:"490";i:3;s:3:"676";}}s:8:"sterling";a:4:{s:1:"C";s:3:"163";s:2:"WX";s:3:"500";s:1:"N";s:8:"sterling";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:2:"-8";i:2;s:3:"490";i:3;s:3:"676";}}i:164;a:4:{s:1:"C";s:3:"164";s:2:"WX";s:3:"167";s:1:"N";s:8:"fraction";s:1:"B";a:4:{i:0;s:4:"-168";i:1;s:3:"-14";i:2;s:3:"331";i:3;s:3:"676";}}s:8:"fraction";a:4:{s:1:"C";s:3:"164";s:2:"WX";s:3:"167";s:1:"N";s:8:"fraction";s:1:"B";a:4:{i:0;s:4:"-168";i:1;s:3:"-14";i:2;s:3:"331";i:3;s:3:"676";}}i:165;a:4:{s:1:"C";s:3:"165";s:2:"WX";s:3:"500";s:1:"N";s:3:"yen";s:1:"B";a:4:{i:0;s:3:"-53";i:1;s:1:"0";i:2;s:3:"512";i:3;s:3:"662";}}s:3:"yen";a:4:{s:1:"C";s:3:"165";s:2:"WX";s:3:"500";s:1:"N";s:3:"yen";s:1:"B";a:4:{i:0;s:3:"-53";i:1;s:1:"0";i:2;s:3:"512";i:3;s:3:"662";}}i:166;a:4:{s:1:"C";s:3:"166";s:2:"WX";s:3:"500";s:1:"N";s:6:"florin";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:4:"-189";i:2;s:3:"490";i:3;s:3:"676";}}s:6:"florin";a:4:{s:1:"C";s:3:"166";s:2:"WX";s:3:"500";s:1:"N";s:6:"florin";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:4:"-189";i:2;s:3:"490";i:3;s:3:"676";}}i:167;a:4:{s:1:"C";s:3:"167";s:2:"WX";s:3:"500";s:1:"N";s:7:"section";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:4:"-148";i:2;s:3:"426";i:3;s:3:"676";}}s:7:"section";a:4:{s:1:"C";s:3:"167";s:2:"WX";s:3:"500";s:1:"N";s:7:"section";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:4:"-148";i:2;s:3:"426";i:3;s:3:"676";}}i:168;a:4:{s:1:"C";s:3:"168";s:2:"WX";s:3:"500";s:1:"N";s:8:"currency";s:1:"B";a:4:{i:0;s:3:"-22";i:1;s:2:"58";i:2;s:3:"522";i:3;s:3:"602";}}s:8:"currency";a:4:{s:1:"C";s:3:"168";s:2:"WX";s:3:"500";s:1:"N";s:8:"currency";s:1:"B";a:4:{i:0;s:3:"-22";i:1;s:2:"58";i:2;s:3:"522";i:3;s:3:"602";}}i:169;a:4:{s:1:"C";s:3:"169";s:2:"WX";s:3:"180";s:1:"N";s:11:"quotesingle";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:3:"431";i:2;s:3:"133";i:3;s:3:"676";}}s:11:"quotesingle";a:4:{s:1:"C";s:3:"169";s:2:"WX";s:3:"180";s:1:"N";s:11:"quotesingle";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:3:"431";i:2;s:3:"133";i:3;s:3:"676";}}i:170;a:4:{s:1:"C";s:3:"170";s:2:"WX";s:3:"444";s:1:"N";s:12:"quotedblleft";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:3:"433";i:2;s:3:"414";i:3;s:3:"676";}}s:12:"quotedblleft";a:4:{s:1:"C";s:3:"170";s:2:"WX";s:3:"444";s:1:"N";s:12:"quotedblleft";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:3:"433";i:2;s:3:"414";i:3;s:3:"676";}}i:171;a:4:{s:1:"C";s:3:"171";s:2:"WX";s:3:"500";s:1:"N";s:13:"guillemotleft";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:2:"33";i:2;s:3:"456";i:3;s:3:"416";}}s:13:"guillemotleft";a:4:{s:1:"C";s:3:"171";s:2:"WX";s:3:"500";s:1:"N";s:13:"guillemotleft";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:2:"33";i:2;s:3:"456";i:3;s:3:"416";}}i:172;a:4:{s:1:"C";s:3:"172";s:2:"WX";s:3:"333";s:1:"N";s:13:"guilsinglleft";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:2:"33";i:2;s:3:"285";i:3;s:3:"416";}}s:13:"guilsinglleft";a:4:{s:1:"C";s:3:"172";s:2:"WX";s:3:"333";s:1:"N";s:13:"guilsinglleft";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:2:"33";i:2;s:3:"285";i:3;s:3:"416";}}i:173;a:4:{s:1:"C";s:3:"173";s:2:"WX";s:3:"333";s:1:"N";s:14:"guilsinglright";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:2:"33";i:2;s:3:"270";i:3;s:3:"416";}}s:14:"guilsinglright";a:4:{s:1:"C";s:3:"173";s:2:"WX";s:3:"333";s:1:"N";s:14:"guilsinglright";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:2:"33";i:2;s:3:"270";i:3;s:3:"416";}}i:174;a:4:{s:1:"C";s:3:"174";s:2:"WX";s:3:"556";s:1:"N";s:2:"fi";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:1:"0";i:2;s:3:"521";i:3;s:3:"683";}}s:2:"fi";a:4:{s:1:"C";s:3:"174";s:2:"WX";s:3:"556";s:1:"N";s:2:"fi";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:1:"0";i:2;s:3:"521";i:3;s:3:"683";}}i:175;a:4:{s:1:"C";s:3:"175";s:2:"WX";s:3:"556";s:1:"N";s:2:"fl";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:1:"0";i:2;s:3:"521";i:3;s:3:"683";}}s:2:"fl";a:4:{s:1:"C";s:3:"175";s:2:"WX";s:3:"556";s:1:"N";s:2:"fl";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:1:"0";i:2;s:3:"521";i:3;s:3:"683";}}i:177;a:4:{s:1:"C";s:3:"177";s:2:"WX";s:3:"500";s:1:"N";s:6:"endash";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"201";i:2;s:3:"500";i:3;s:3:"250";}}s:6:"endash";a:4:{s:1:"C";s:3:"177";s:2:"WX";s:3:"500";s:1:"N";s:6:"endash";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"201";i:2;s:3:"500";i:3;s:3:"250";}}i:178;a:4:{s:1:"C";s:3:"178";s:2:"WX";s:3:"500";s:1:"N";s:6:"dagger";s:1:"B";a:4:{i:0;s:2:"59";i:1;s:4:"-149";i:2;s:3:"442";i:3;s:3:"676";}}s:6:"dagger";a:4:{s:1:"C";s:3:"178";s:2:"WX";s:3:"500";s:1:"N";s:6:"dagger";s:1:"B";a:4:{i:0;s:2:"59";i:1;s:4:"-149";i:2;s:3:"442";i:3;s:3:"676";}}i:179;a:4:{s:1:"C";s:3:"179";s:2:"WX";s:3:"500";s:1:"N";s:9:"daggerdbl";s:1:"B";a:4:{i:0;s:2:"58";i:1;s:4:"-153";i:2;s:3:"442";i:3;s:3:"676";}}s:9:"daggerdbl";a:4:{s:1:"C";s:3:"179";s:2:"WX";s:3:"500";s:1:"N";s:9:"daggerdbl";s:1:"B";a:4:{i:0;s:2:"58";i:1;s:4:"-153";i:2;s:3:"442";i:3;s:3:"676";}}i:180;a:4:{s:1:"C";s:3:"180";s:2:"WX";s:3:"250";s:1:"N";s:14:"periodcentered";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:3:"199";i:2;s:3:"181";i:3;s:3:"310";}}s:14:"periodcentered";a:4:{s:1:"C";s:3:"180";s:2:"WX";s:3:"250";s:1:"N";s:14:"periodcentered";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:3:"199";i:2;s:3:"181";i:3;s:3:"310";}}i:182;a:4:{s:1:"C";s:3:"182";s:2:"WX";s:3:"453";s:1:"N";s:9:"paragraph";s:1:"B";a:4:{i:0;s:3:"-22";i:1;s:4:"-154";i:2;s:3:"450";i:3;s:3:"662";}}s:9:"paragraph";a:4:{s:1:"C";s:3:"182";s:2:"WX";s:3:"453";s:1:"N";s:9:"paragraph";s:1:"B";a:4:{i:0;s:3:"-22";i:1;s:4:"-154";i:2;s:3:"450";i:3;s:3:"662";}}i:183;a:4:{s:1:"C";s:3:"183";s:2:"WX";s:3:"350";s:1:"N";s:6:"bullet";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"196";i:2;s:3:"310";i:3;s:3:"466";}}s:6:"bullet";a:4:{s:1:"C";s:3:"183";s:2:"WX";s:3:"350";s:1:"N";s:6:"bullet";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"196";i:2;s:3:"310";i:3;s:3:"466";}}i:184;a:4:{s:1:"C";s:3:"184";s:2:"WX";s:3:"333";s:1:"N";s:14:"quotesinglbase";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:4:"-141";i:2;s:3:"218";i:3;s:3:"102";}}s:14:"quotesinglbase";a:4:{s:1:"C";s:3:"184";s:2:"WX";s:3:"333";s:1:"N";s:14:"quotesinglbase";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:4:"-141";i:2;s:3:"218";i:3;s:3:"102";}}i:185;a:4:{s:1:"C";s:3:"185";s:2:"WX";s:3:"444";s:1:"N";s:12:"quotedblbase";s:1:"B";a:4:{i:0;s:2:"45";i:1;s:4:"-141";i:2;s:3:"416";i:3;s:3:"102";}}s:12:"quotedblbase";a:4:{s:1:"C";s:3:"185";s:2:"WX";s:3:"444";s:1:"N";s:12:"quotedblbase";s:1:"B";a:4:{i:0;s:2:"45";i:1;s:4:"-141";i:2;s:3:"416";i:3;s:3:"102";}}i:186;a:4:{s:1:"C";s:3:"186";s:2:"WX";s:3:"444";s:1:"N";s:13:"quotedblright";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"433";i:2;s:3:"401";i:3;s:3:"676";}}s:13:"quotedblright";a:4:{s:1:"C";s:3:"186";s:2:"WX";s:3:"444";s:1:"N";s:13:"quotedblright";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"433";i:2;s:3:"401";i:3;s:3:"676";}}i:187;a:4:{s:1:"C";s:3:"187";s:2:"WX";s:3:"500";s:1:"N";s:14:"guillemotright";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:2:"33";i:2;s:3:"458";i:3;s:3:"416";}}s:14:"guillemotright";a:4:{s:1:"C";s:3:"187";s:2:"WX";s:3:"500";s:1:"N";s:14:"guillemotright";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:2:"33";i:2;s:3:"458";i:3;s:3:"416";}}i:188;a:4:{s:1:"C";s:3:"188";s:2:"WX";s:4:"1000";s:1:"N";s:8:"ellipsis";s:1:"B";a:4:{i:0;s:3:"111";i:1;s:3:"-11";i:2;s:3:"888";i:3;s:3:"100";}}s:8:"ellipsis";a:4:{s:1:"C";s:3:"188";s:2:"WX";s:4:"1000";s:1:"N";s:8:"ellipsis";s:1:"B";a:4:{i:0;s:3:"111";i:1;s:3:"-11";i:2;s:3:"888";i:3;s:3:"100";}}i:189;a:4:{s:1:"C";s:3:"189";s:2:"WX";s:4:"1000";s:1:"N";s:11:"perthousand";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:3:"-19";i:2;s:3:"994";i:3;s:3:"706";}}s:11:"perthousand";a:4:{s:1:"C";s:3:"189";s:2:"WX";s:4:"1000";s:1:"N";s:11:"perthousand";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:3:"-19";i:2;s:3:"994";i:3;s:3:"706";}}i:191;a:4:{s:1:"C";s:3:"191";s:2:"WX";s:3:"444";s:1:"N";s:12:"questiondown";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:4:"-218";i:2;s:3:"376";i:3;s:3:"466";}}s:12:"questiondown";a:4:{s:1:"C";s:3:"191";s:2:"WX";s:3:"444";s:1:"N";s:12:"questiondown";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:4:"-218";i:2;s:3:"376";i:3;s:3:"466";}}i:193;a:4:{s:1:"C";s:3:"193";s:2:"WX";s:3:"333";s:1:"N";s:5:"grave";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:3:"507";i:2;s:3:"242";i:3;s:3:"678";}}s:5:"grave";a:4:{s:1:"C";s:3:"193";s:2:"WX";s:3:"333";s:1:"N";s:5:"grave";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:3:"507";i:2;s:3:"242";i:3;s:3:"678";}}i:194;a:4:{s:1:"C";s:3:"194";s:2:"WX";s:3:"333";s:1:"N";s:5:"acute";s:1:"B";a:4:{i:0;s:2:"93";i:1;s:3:"507";i:2;s:3:"317";i:3;s:3:"678";}}s:5:"acute";a:4:{s:1:"C";s:3:"194";s:2:"WX";s:3:"333";s:1:"N";s:5:"acute";s:1:"B";a:4:{i:0;s:2:"93";i:1;s:3:"507";i:2;s:3:"317";i:3;s:3:"678";}}i:195;a:4:{s:1:"C";s:3:"195";s:2:"WX";s:3:"333";s:1:"N";s:10:"circumflex";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:3:"507";i:2;s:3:"322";i:3;s:3:"674";}}s:10:"circumflex";a:4:{s:1:"C";s:3:"195";s:2:"WX";s:3:"333";s:1:"N";s:10:"circumflex";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:3:"507";i:2;s:3:"322";i:3;s:3:"674";}}i:196;a:4:{s:1:"C";s:3:"196";s:2:"WX";s:3:"333";s:1:"N";s:5:"tilde";s:1:"B";a:4:{i:0;s:1:"1";i:1;s:3:"532";i:2;s:3:"331";i:3;s:3:"638";}}s:5:"tilde";a:4:{s:1:"C";s:3:"196";s:2:"WX";s:3:"333";s:1:"N";s:5:"tilde";s:1:"B";a:4:{i:0;s:1:"1";i:1;s:3:"532";i:2;s:3:"331";i:3;s:3:"638";}}i:197;a:4:{s:1:"C";s:3:"197";s:2:"WX";s:3:"333";s:1:"N";s:6:"macron";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:3:"547";i:2;s:3:"322";i:3;s:3:"601";}}s:6:"macron";a:4:{s:1:"C";s:3:"197";s:2:"WX";s:3:"333";s:1:"N";s:6:"macron";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:3:"547";i:2;s:3:"322";i:3;s:3:"601";}}i:198;a:4:{s:1:"C";s:3:"198";s:2:"WX";s:3:"333";s:1:"N";s:5:"breve";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:3:"507";i:2;s:3:"307";i:3;s:3:"664";}}s:5:"breve";a:4:{s:1:"C";s:3:"198";s:2:"WX";s:3:"333";s:1:"N";s:5:"breve";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:3:"507";i:2;s:3:"307";i:3;s:3:"664";}}i:199;a:4:{s:1:"C";s:3:"199";s:2:"WX";s:3:"333";s:1:"N";s:9:"dotaccent";s:1:"B";a:4:{i:0;s:3:"118";i:1;s:3:"581";i:2;s:3:"216";i:3;s:3:"681";}}s:9:"dotaccent";a:4:{s:1:"C";s:3:"199";s:2:"WX";s:3:"333";s:1:"N";s:9:"dotaccent";s:1:"B";a:4:{i:0;s:3:"118";i:1;s:3:"581";i:2;s:3:"216";i:3;s:3:"681";}}i:200;a:4:{s:1:"C";s:3:"200";s:2:"WX";s:3:"333";s:1:"N";s:8:"dieresis";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:3:"581";i:2;s:3:"315";i:3;s:3:"681";}}s:8:"dieresis";a:4:{s:1:"C";s:3:"200";s:2:"WX";s:3:"333";s:1:"N";s:8:"dieresis";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:3:"581";i:2;s:3:"315";i:3;s:3:"681";}}i:202;a:4:{s:1:"C";s:3:"202";s:2:"WX";s:3:"333";s:1:"N";s:4:"ring";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:3:"512";i:2;s:3:"266";i:3;s:3:"711";}}s:4:"ring";a:4:{s:1:"C";s:3:"202";s:2:"WX";s:3:"333";s:1:"N";s:4:"ring";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:3:"512";i:2;s:3:"266";i:3;s:3:"711";}}i:203;a:4:{s:1:"C";s:3:"203";s:2:"WX";s:3:"333";s:1:"N";s:7:"cedilla";s:1:"B";a:4:{i:0;s:2:"52";i:1;s:4:"-215";i:2;s:3:"261";i:3;s:1:"0";}}s:7:"cedilla";a:4:{s:1:"C";s:3:"203";s:2:"WX";s:3:"333";s:1:"N";s:7:"cedilla";s:1:"B";a:4:{i:0;s:2:"52";i:1;s:4:"-215";i:2;s:3:"261";i:3;s:1:"0";}}i:205;a:4:{s:1:"C";s:3:"205";s:2:"WX";s:3:"333";s:1:"N";s:12:"hungarumlaut";s:1:"B";a:4:{i:0;s:2:"-3";i:1;s:3:"507";i:2;s:3:"377";i:3;s:3:"678";}}s:12:"hungarumlaut";a:4:{s:1:"C";s:3:"205";s:2:"WX";s:3:"333";s:1:"N";s:12:"hungarumlaut";s:1:"B";a:4:{i:0;s:2:"-3";i:1;s:3:"507";i:2;s:3:"377";i:3;s:3:"678";}}i:206;a:4:{s:1:"C";s:3:"206";s:2:"WX";s:3:"333";s:1:"N";s:6:"ogonek";s:1:"B";a:4:{i:0;s:2:"62";i:1;s:4:"-165";i:2;s:3:"243";i:3;s:1:"0";}}s:6:"ogonek";a:4:{s:1:"C";s:3:"206";s:2:"WX";s:3:"333";s:1:"N";s:6:"ogonek";s:1:"B";a:4:{i:0;s:2:"62";i:1;s:4:"-165";i:2;s:3:"243";i:3;s:1:"0";}}i:207;a:4:{s:1:"C";s:3:"207";s:2:"WX";s:3:"333";s:1:"N";s:5:"caron";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:3:"507";i:2;s:3:"322";i:3;s:3:"674";}}s:5:"caron";a:4:{s:1:"C";s:3:"207";s:2:"WX";s:3:"333";s:1:"N";s:5:"caron";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:3:"507";i:2;s:3:"322";i:3;s:3:"674";}}i:208;a:4:{s:1:"C";s:3:"208";s:2:"WX";s:4:"1000";s:1:"N";s:6:"emdash";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"201";i:2;s:4:"1000";i:3;s:3:"250";}}s:6:"emdash";a:4:{s:1:"C";s:3:"208";s:2:"WX";s:4:"1000";s:1:"N";s:6:"emdash";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"201";i:2;s:4:"1000";i:3;s:3:"250";}}i:225;a:4:{s:1:"C";s:3:"225";s:2:"WX";s:3:"889";s:1:"N";s:2:"AE";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:3:"863";i:3;s:3:"662";}}s:2:"AE";a:4:{s:1:"C";s:3:"225";s:2:"WX";s:3:"889";s:1:"N";s:2:"AE";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:3:"863";i:3;s:3:"662";}}i:227;a:4:{s:1:"C";s:3:"227";s:2:"WX";s:3:"276";s:1:"N";s:11:"ordfeminine";s:1:"B";a:4:{i:0;s:1:"4";i:1;s:3:"394";i:2;s:3:"270";i:3;s:3:"676";}}s:11:"ordfeminine";a:4:{s:1:"C";s:3:"227";s:2:"WX";s:3:"276";s:1:"N";s:11:"ordfeminine";s:1:"B";a:4:{i:0;s:1:"4";i:1;s:3:"394";i:2;s:3:"270";i:3;s:3:"676";}}i:232;a:4:{s:1:"C";s:3:"232";s:2:"WX";s:3:"611";s:1:"N";s:6:"Lslash";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"598";i:3;s:3:"662";}}s:6:"Lslash";a:4:{s:1:"C";s:3:"232";s:2:"WX";s:3:"611";s:1:"N";s:6:"Lslash";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"598";i:3;s:3:"662";}}i:233;a:4:{s:1:"C";s:3:"233";s:2:"WX";s:3:"722";s:1:"N";s:6:"Oslash";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-80";i:2;s:3:"688";i:3;s:3:"734";}}s:6:"Oslash";a:4:{s:1:"C";s:3:"233";s:2:"WX";s:3:"722";s:1:"N";s:6:"Oslash";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-80";i:2;s:3:"688";i:3;s:3:"734";}}i:234;a:4:{s:1:"C";s:3:"234";s:2:"WX";s:3:"889";s:1:"N";s:2:"OE";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:2:"-6";i:2;s:3:"885";i:3;s:3:"668";}}s:2:"OE";a:4:{s:1:"C";s:3:"234";s:2:"WX";s:3:"889";s:1:"N";s:2:"OE";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:2:"-6";i:2;s:3:"885";i:3;s:3:"668";}}i:235;a:4:{s:1:"C";s:3:"235";s:2:"WX";s:3:"310";s:1:"N";s:12:"ordmasculine";s:1:"B";a:4:{i:0;s:1:"6";i:1;s:3:"394";i:2;s:3:"304";i:3;s:3:"676";}}s:12:"ordmasculine";a:4:{s:1:"C";s:3:"235";s:2:"WX";s:3:"310";s:1:"N";s:12:"ordmasculine";s:1:"B";a:4:{i:0;s:1:"6";i:1;s:3:"394";i:2;s:3:"304";i:3;s:3:"676";}}i:241;a:4:{s:1:"C";s:3:"241";s:2:"WX";s:3:"667";s:1:"N";s:2:"ae";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:3:"-10";i:2;s:3:"632";i:3;s:3:"460";}}s:2:"ae";a:4:{s:1:"C";s:3:"241";s:2:"WX";s:3:"667";s:1:"N";s:2:"ae";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:3:"-10";i:2;s:3:"632";i:3;s:3:"460";}}i:245;a:4:{s:1:"C";s:3:"245";s:2:"WX";s:3:"278";s:1:"N";s:8:"dotlessi";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"253";i:3;s:3:"460";}}s:8:"dotlessi";a:4:{s:1:"C";s:3:"245";s:2:"WX";s:3:"278";s:1:"N";s:8:"dotlessi";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"253";i:3;s:3:"460";}}i:248;a:4:{s:1:"C";s:3:"248";s:2:"WX";s:3:"278";s:1:"N";s:6:"lslash";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:1:"0";i:2;s:3:"259";i:3;s:3:"683";}}s:6:"lslash";a:4:{s:1:"C";s:3:"248";s:2:"WX";s:3:"278";s:1:"N";s:6:"lslash";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:1:"0";i:2;s:3:"259";i:3;s:3:"683";}}i:249;a:4:{s:1:"C";s:3:"249";s:2:"WX";s:3:"500";s:1:"N";s:6:"oslash";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:4:"-112";i:2;s:3:"470";i:3;s:3:"551";}}s:6:"oslash";a:4:{s:1:"C";s:3:"249";s:2:"WX";s:3:"500";s:1:"N";s:6:"oslash";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:4:"-112";i:2;s:3:"470";i:3;s:3:"551";}}i:250;a:4:{s:1:"C";s:3:"250";s:2:"WX";s:3:"722";s:1:"N";s:2:"oe";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-10";i:2;s:3:"690";i:3;s:3:"460";}}s:2:"oe";a:4:{s:1:"C";s:3:"250";s:2:"WX";s:3:"722";s:1:"N";s:2:"oe";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-10";i:2;s:3:"690";i:3;s:3:"460";}}i:251;a:4:{s:1:"C";s:3:"251";s:2:"WX";s:3:"500";s:1:"N";s:10:"germandbls";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:2:"-9";i:2;s:3:"468";i:3;s:3:"683";}}s:10:"germandbls";a:4:{s:1:"C";s:3:"251";s:2:"WX";s:3:"500";s:1:"N";s:10:"germandbls";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:2:"-9";i:2;s:3:"468";i:3;s:3:"683";}}s:9:"Idieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"333";s:1:"N";s:9:"Idieresis";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:1:"0";i:2;s:3:"315";i:3;s:3:"835";}}s:6:"eacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:6:"eacute";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-10";i:2;s:3:"424";i:3;s:3:"678";}}s:6:"abreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:6:"abreve";s:1:"B";a:4:{i:0;s:2:"37";i:1;s:3:"-10";i:2;s:3:"442";i:3;s:3:"664";}}s:13:"uhungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:13:"uhungarumlaut";s:1:"B";a:4:{i:0;s:1:"9";i:1;s:3:"-10";i:2;s:3:"501";i:3;s:3:"678";}}s:6:"ecaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:6:"ecaron";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-10";i:2;s:3:"424";i:3;s:3:"674";}}s:9:"Ydieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:9:"Ydieresis";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:1:"0";i:2;s:3:"703";i:3;s:3:"835";}}s:6:"divide";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"564";s:1:"N";s:6:"divide";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-10";i:2;s:3:"534";i:3;s:3:"516";}}s:6:"Yacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Yacute";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:1:"0";i:2;s:3:"703";i:3;s:3:"890";}}s:11:"Acircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:11:"Acircumflex";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:1:"0";i:2;s:3:"706";i:3;s:3:"886";}}s:6:"aacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:6:"aacute";s:1:"B";a:4:{i:0;s:2:"37";i:1;s:3:"-10";i:2;s:3:"442";i:3;s:3:"678";}}s:11:"Ucircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:11:"Ucircumflex";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:3:"-14";i:2;s:3:"705";i:3;s:3:"886";}}s:6:"yacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"yacute";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:4:"-218";i:2;s:3:"475";i:3;s:3:"678";}}s:12:"scommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:12:"scommaaccent";s:1:"B";a:4:{i:0;s:2:"51";i:1;s:4:"-218";i:2;s:3:"348";i:3;s:3:"460";}}s:11:"ecircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:11:"ecircumflex";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-10";i:2;s:3:"424";i:3;s:3:"674";}}s:5:"Uring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:5:"Uring";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:3:"-14";i:2;s:3:"705";i:3;s:3:"898";}}s:9:"Udieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:9:"Udieresis";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:3:"-14";i:2;s:3:"705";i:3;s:3:"835";}}s:7:"aogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:7:"aogonek";s:1:"B";a:4:{i:0;s:2:"37";i:1;s:4:"-165";i:2;s:3:"469";i:3;s:3:"460";}}s:6:"Uacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Uacute";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:3:"-14";i:2;s:3:"705";i:3;s:3:"890";}}s:7:"uogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:7:"uogonek";s:1:"B";a:4:{i:0;s:1:"9";i:1;s:4:"-155";i:2;s:3:"487";i:3;s:3:"450";}}s:9:"Edieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:9:"Edieresis";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"597";i:3;s:3:"835";}}s:6:"Dcroat";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Dcroat";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"685";i:3;s:3:"662";}}s:11:"commaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"250";s:1:"N";s:11:"commaaccent";s:1:"B";a:4:{i:0;s:2:"59";i:1;s:4:"-218";i:2;s:3:"184";i:3;s:3:"-50";}}s:9:"copyright";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"760";s:1:"N";s:9:"copyright";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:3:"-14";i:2;s:3:"722";i:3;s:3:"676";}}s:7:"Emacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:7:"Emacron";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"597";i:3;s:3:"813";}}s:6:"ccaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:6:"ccaron";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-10";i:2;s:3:"412";i:3;s:3:"674";}}s:5:"aring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:5:"aring";s:1:"B";a:4:{i:0;s:2:"37";i:1;s:3:"-10";i:2;s:3:"442";i:3;s:3:"711";}}s:12:"Ncommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:12:"Ncommaaccent";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:4:"-198";i:2;s:3:"707";i:3;s:3:"662";}}s:6:"lacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:6:"lacute";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:1:"0";i:2;s:3:"290";i:3;s:3:"890";}}s:6:"agrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:6:"agrave";s:1:"B";a:4:{i:0;s:2:"37";i:1;s:3:"-10";i:2;s:3:"442";i:3;s:3:"678";}}s:12:"Tcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:12:"Tcommaaccent";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:4:"-218";i:2;s:3:"593";i:3;s:3:"662";}}s:6:"Cacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Cacute";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:3:"-14";i:2;s:3:"633";i:3;s:3:"890";}}s:6:"atilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:6:"atilde";s:1:"B";a:4:{i:0;s:2:"37";i:1;s:3:"-10";i:2;s:3:"442";i:3;s:3:"638";}}s:10:"Edotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:10:"Edotaccent";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"597";i:3;s:3:"835";}}s:6:"scaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:6:"scaron";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:3:"-10";i:2;s:3:"350";i:3;s:3:"674";}}s:8:"scedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:8:"scedilla";s:1:"B";a:4:{i:0;s:2:"51";i:1;s:4:"-215";i:2;s:3:"348";i:3;s:3:"460";}}s:6:"iacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:6:"iacute";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"290";i:3;s:3:"678";}}s:7:"lozenge";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"471";s:1:"N";s:7:"lozenge";s:1:"B";a:4:{i:0;s:2:"13";i:1;s:1:"0";i:2;s:3:"459";i:3;s:3:"724";}}s:6:"Rcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Rcaron";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:1:"0";i:2;s:3:"659";i:3;s:3:"886";}}s:12:"Gcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:12:"Gcommaaccent";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:4:"-218";i:2;s:3:"709";i:3;s:3:"676";}}s:11:"ucircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:11:"ucircumflex";s:1:"B";a:4:{i:0;s:1:"9";i:1;s:3:"-10";i:2;s:3:"479";i:3;s:3:"674";}}s:11:"acircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:11:"acircumflex";s:1:"B";a:4:{i:0;s:2:"37";i:1;s:3:"-10";i:2;s:3:"442";i:3;s:3:"674";}}s:7:"Amacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:7:"Amacron";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:1:"0";i:2;s:3:"706";i:3;s:3:"813";}}s:6:"rcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"333";s:1:"N";s:6:"rcaron";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:1:"0";i:2;s:3:"335";i:3;s:3:"674";}}s:8:"ccedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:8:"ccedilla";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:4:"-215";i:2;s:3:"412";i:3;s:3:"460";}}s:10:"Zdotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:10:"Zdotaccent";s:1:"B";a:4:{i:0;s:1:"9";i:1;s:1:"0";i:2;s:3:"597";i:3;s:3:"835";}}s:5:"Thorn";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:5:"Thorn";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"542";i:3;s:3:"662";}}s:7:"Omacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:7:"Omacron";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"688";i:3;s:3:"813";}}s:6:"Racute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Racute";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:1:"0";i:2;s:3:"659";i:3;s:3:"890";}}s:6:"Sacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"Sacute";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-14";i:2;s:3:"491";i:3;s:3:"890";}}s:6:"dcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"588";s:1:"N";s:6:"dcaron";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:3:"-10";i:2;s:3:"589";i:3;s:3:"695";}}s:7:"Umacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:7:"Umacron";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:3:"-14";i:2;s:3:"705";i:3;s:3:"813";}}s:5:"uring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:5:"uring";s:1:"B";a:4:{i:0;s:1:"9";i:1;s:3:"-10";i:2;s:3:"479";i:3;s:3:"711";}}s:13:"threesuperior";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"300";s:1:"N";s:13:"threesuperior";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:3:"262";i:2;s:3:"291";i:3;s:3:"676";}}s:6:"Ograve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Ograve";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"688";i:3;s:3:"890";}}s:6:"Agrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Agrave";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:1:"0";i:2;s:3:"706";i:3;s:3:"890";}}s:6:"Abreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Abreve";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:1:"0";i:2;s:3:"706";i:3;s:3:"876";}}s:8:"multiply";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"564";s:1:"N";s:8:"multiply";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:1:"8";i:2;s:3:"527";i:3;s:3:"497";}}s:6:"uacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"uacute";s:1:"B";a:4:{i:0;s:1:"9";i:1;s:3:"-10";i:2;s:3:"479";i:3;s:3:"678";}}s:6:"Tcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"Tcaron";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:1:"0";i:2;s:3:"593";i:3;s:3:"886";}}s:11:"partialdiff";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"476";s:1:"N";s:11:"partialdiff";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:3:"-38";i:2;s:3:"459";i:3;s:3:"710";}}s:9:"ydieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:9:"ydieresis";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:4:"-218";i:2;s:3:"475";i:3;s:3:"623";}}s:6:"Nacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Nacute";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:3:"-11";i:2;s:3:"707";i:3;s:3:"890";}}s:11:"icircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:11:"icircumflex";s:1:"B";a:4:{i:0;s:3:"-16";i:1;s:1:"0";i:2;s:3:"295";i:3;s:3:"674";}}s:11:"Ecircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:11:"Ecircumflex";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"597";i:3;s:3:"886";}}s:9:"adieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:9:"adieresis";s:1:"B";a:4:{i:0;s:2:"37";i:1;s:3:"-10";i:2;s:3:"442";i:3;s:3:"623";}}s:9:"edieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:9:"edieresis";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-10";i:2;s:3:"424";i:3;s:3:"623";}}s:6:"cacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:6:"cacute";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-10";i:2;s:3:"413";i:3;s:3:"678";}}s:6:"nacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"nacute";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"485";i:3;s:3:"678";}}s:7:"umacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:7:"umacron";s:1:"B";a:4:{i:0;s:1:"9";i:1;s:3:"-10";i:2;s:3:"479";i:3;s:3:"601";}}s:6:"Ncaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Ncaron";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:3:"-11";i:2;s:3:"707";i:3;s:3:"886";}}s:6:"Iacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"333";s:1:"N";s:6:"Iacute";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:1:"0";i:2;s:3:"317";i:3;s:3:"890";}}s:9:"plusminus";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"564";s:1:"N";s:9:"plusminus";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:1:"0";i:2;s:3:"534";i:3;s:3:"506";}}s:9:"brokenbar";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"200";s:1:"N";s:9:"brokenbar";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:4:"-143";i:2;s:3:"133";i:3;s:3:"707";}}s:10:"registered";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"760";s:1:"N";s:10:"registered";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:3:"-14";i:2;s:3:"722";i:3;s:3:"676";}}s:6:"Gbreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Gbreve";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:3:"-14";i:2;s:3:"709";i:3;s:3:"876";}}s:10:"Idotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"333";s:1:"N";s:10:"Idotaccent";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:1:"0";i:2;s:3:"315";i:3;s:3:"835";}}s:9:"summation";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"summation";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:3:"-10";i:2;s:3:"585";i:3;s:3:"706";}}s:6:"Egrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"Egrave";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"597";i:3;s:3:"890";}}s:6:"racute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"333";s:1:"N";s:6:"racute";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:1:"0";i:2;s:3:"335";i:3;s:3:"678";}}s:7:"omacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:7:"omacron";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:3:"-10";i:2;s:3:"470";i:3;s:3:"601";}}s:6:"Zacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"Zacute";s:1:"B";a:4:{i:0;s:1:"9";i:1;s:1:"0";i:2;s:3:"597";i:3;s:3:"890";}}s:6:"Zcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"Zcaron";s:1:"B";a:4:{i:0;s:1:"9";i:1;s:1:"0";i:2;s:3:"597";i:3;s:3:"886";}}s:12:"greaterequal";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"549";s:1:"N";s:12:"greaterequal";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"523";i:3;s:3:"666";}}s:3:"Eth";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:3:"Eth";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"685";i:3;s:3:"662";}}s:8:"Ccedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:8:"Ccedilla";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:4:"-215";i:2;s:3:"633";i:3;s:3:"676";}}s:12:"lcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:12:"lcommaaccent";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:4:"-218";i:2;s:3:"257";i:3;s:3:"683";}}s:6:"tcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"326";s:1:"N";s:6:"tcaron";s:1:"B";a:4:{i:0;s:2:"13";i:1;s:3:"-10";i:2;s:3:"318";i:3;s:3:"722";}}s:7:"eogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:7:"eogonek";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:4:"-165";i:2;s:3:"424";i:3;s:3:"460";}}s:7:"Uogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:7:"Uogonek";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:4:"-165";i:2;s:3:"705";i:3;s:3:"662";}}s:6:"Aacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Aacute";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:1:"0";i:2;s:3:"706";i:3;s:3:"890";}}s:9:"Adieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:9:"Adieresis";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:1:"0";i:2;s:3:"706";i:3;s:3:"835";}}s:6:"egrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:6:"egrave";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-10";i:2;s:3:"424";i:3;s:3:"678";}}s:6:"zacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:6:"zacute";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:1:"0";i:2;s:3:"418";i:3;s:3:"678";}}s:7:"iogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:7:"iogonek";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:4:"-165";i:2;s:3:"265";i:3;s:3:"683";}}s:6:"Oacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Oacute";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"688";i:3;s:3:"890";}}s:6:"oacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"oacute";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:3:"-10";i:2;s:3:"470";i:3;s:3:"678";}}s:7:"amacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:7:"amacron";s:1:"B";a:4:{i:0;s:2:"37";i:1;s:3:"-10";i:2;s:3:"442";i:3;s:3:"601";}}s:6:"sacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:6:"sacute";s:1:"B";a:4:{i:0;s:2:"51";i:1;s:3:"-10";i:2;s:3:"348";i:3;s:3:"678";}}s:9:"idieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:9:"idieresis";s:1:"B";a:4:{i:0;s:2:"-9";i:1;s:1:"0";i:2;s:3:"288";i:3;s:3:"623";}}s:11:"Ocircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:11:"Ocircumflex";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"688";i:3;s:3:"886";}}s:6:"Ugrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Ugrave";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:3:"-14";i:2;s:3:"705";i:3;s:3:"890";}}s:5:"Delta";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"612";s:1:"N";s:5:"Delta";s:1:"B";a:4:{i:0;s:1:"6";i:1;s:1:"0";i:2;s:3:"608";i:3;s:3:"688";}}s:5:"thorn";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:5:"thorn";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:4:"-217";i:2;s:3:"470";i:3;s:3:"683";}}s:11:"twosuperior";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"300";s:1:"N";s:11:"twosuperior";s:1:"B";a:4:{i:0;s:1:"1";i:1;s:3:"270";i:2;s:3:"296";i:3;s:3:"676";}}s:9:"Odieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:9:"Odieresis";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"688";i:3;s:3:"835";}}s:2:"mu";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:2:"mu";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:4:"-218";i:2;s:3:"512";i:3;s:3:"450";}}s:6:"igrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:6:"igrave";s:1:"B";a:4:{i:0;s:2:"-8";i:1;s:1:"0";i:2;s:3:"253";i:3;s:3:"678";}}s:13:"ohungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:13:"ohungarumlaut";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:3:"-10";i:2;s:3:"491";i:3;s:3:"678";}}s:7:"Eogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:7:"Eogonek";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:4:"-165";i:2;s:3:"597";i:3;s:3:"662";}}s:6:"dcroat";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"dcroat";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:3:"-10";i:2;s:3:"500";i:3;s:3:"683";}}s:13:"threequarters";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"750";s:1:"N";s:13:"threequarters";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:3:"-14";i:2;s:3:"718";i:3;s:3:"676";}}s:8:"Scedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:8:"Scedilla";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:4:"-215";i:2;s:3:"491";i:3;s:3:"676";}}s:6:"lcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"344";s:1:"N";s:6:"lcaron";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:1:"0";i:2;s:3:"347";i:3;s:3:"695";}}s:12:"Kcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:12:"Kcommaaccent";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:4:"-198";i:2;s:3:"723";i:3;s:3:"662";}}s:6:"Lacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"Lacute";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"598";i:3;s:3:"890";}}s:9:"trademark";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"980";s:1:"N";s:9:"trademark";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"256";i:2;s:3:"957";i:3;s:3:"662";}}s:10:"edotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:10:"edotaccent";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-10";i:2;s:3:"424";i:3;s:3:"623";}}s:6:"Igrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"333";s:1:"N";s:6:"Igrave";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:1:"0";i:2;s:3:"315";i:3;s:3:"890";}}s:7:"Imacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"333";s:1:"N";s:7:"Imacron";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:1:"0";i:2;s:3:"322";i:3;s:3:"813";}}s:6:"Lcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"Lcaron";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"598";i:3;s:3:"676";}}s:7:"onehalf";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"750";s:1:"N";s:7:"onehalf";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:3:"-14";i:2;s:3:"746";i:3;s:3:"676";}}s:9:"lessequal";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"549";s:1:"N";s:9:"lessequal";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"523";i:3;s:3:"666";}}s:11:"ocircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:11:"ocircumflex";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:3:"-10";i:2;s:3:"470";i:3;s:3:"674";}}s:6:"ntilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"ntilde";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"485";i:3;s:3:"638";}}s:13:"Uhungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:13:"Uhungarumlaut";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:3:"-14";i:2;s:3:"705";i:3;s:3:"890";}}s:6:"Eacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"Eacute";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"597";i:3;s:3:"890";}}s:7:"emacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:7:"emacron";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-10";i:2;s:3:"424";i:3;s:3:"601";}}s:6:"gbreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"gbreve";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:4:"-218";i:2;s:3:"470";i:3;s:3:"664";}}s:10:"onequarter";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"750";s:1:"N";s:10:"onequarter";s:1:"B";a:4:{i:0;s:2:"37";i:1;s:3:"-14";i:2;s:3:"718";i:3;s:3:"676";}}s:6:"Scaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"Scaron";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-14";i:2;s:3:"491";i:3;s:3:"886";}}s:12:"Scommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:12:"Scommaaccent";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:4:"-218";i:2;s:3:"491";i:3;s:3:"676";}}s:13:"Ohungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:13:"Ohungarumlaut";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"688";i:3;s:3:"890";}}s:6:"degree";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"400";s:1:"N";s:6:"degree";s:1:"B";a:4:{i:0;s:2:"57";i:1;s:3:"390";i:2;s:3:"343";i:3;s:3:"676";}}s:6:"ograve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"ograve";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:3:"-10";i:2;s:3:"470";i:3;s:3:"678";}}s:6:"Ccaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Ccaron";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:3:"-14";i:2;s:3:"633";i:3;s:3:"886";}}s:6:"ugrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"ugrave";s:1:"B";a:4:{i:0;s:1:"9";i:1;s:3:"-10";i:2;s:3:"479";i:3;s:3:"678";}}s:7:"radical";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"453";s:1:"N";s:7:"radical";s:1:"B";a:4:{i:0;s:1:"2";i:1;s:3:"-60";i:2;s:3:"452";i:3;s:3:"768";}}s:6:"Dcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Dcaron";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"685";i:3;s:3:"886";}}s:12:"rcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"333";s:1:"N";s:12:"rcommaaccent";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:4:"-218";i:2;s:3:"335";i:3;s:3:"460";}}s:6:"Ntilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Ntilde";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:3:"-11";i:2;s:3:"707";i:3;s:3:"850";}}s:6:"otilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"otilde";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:3:"-10";i:2;s:3:"470";i:3;s:3:"638";}}s:12:"Rcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:12:"Rcommaaccent";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:4:"-198";i:2;s:3:"659";i:3;s:3:"662";}}s:12:"Lcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:12:"Lcommaaccent";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:4:"-218";i:2;s:3:"598";i:3;s:3:"662";}}s:6:"Atilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Atilde";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:1:"0";i:2;s:3:"706";i:3;s:3:"850";}}s:7:"Aogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:7:"Aogonek";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:4:"-165";i:2;s:3:"738";i:3;s:3:"674";}}s:5:"Aring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:5:"Aring";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:1:"0";i:2;s:3:"706";i:3;s:3:"898";}}s:6:"Otilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Otilde";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"688";i:3;s:3:"850";}}s:10:"zdotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:10:"zdotaccent";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:1:"0";i:2;s:3:"418";i:3;s:3:"623";}}s:6:"Ecaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"Ecaron";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"597";i:3;s:3:"886";}}s:7:"Iogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"333";s:1:"N";s:7:"Iogonek";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:4:"-165";i:2;s:3:"315";i:3;s:3:"662";}}s:12:"kcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:12:"kcommaaccent";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:4:"-218";i:2;s:3:"505";i:3;s:3:"683";}}s:5:"minus";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"564";s:1:"N";s:5:"minus";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"220";i:2;s:3:"534";i:3;s:3:"286";}}s:11:"Icircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"333";s:1:"N";s:11:"Icircumflex";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:1:"0";i:2;s:3:"322";i:3;s:3:"886";}}s:6:"ncaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"ncaron";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"485";i:3;s:3:"674";}}s:12:"tcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:12:"tcommaaccent";s:1:"B";a:4:{i:0;s:2:"13";i:1;s:4:"-218";i:2;s:3:"279";i:3;s:3:"579";}}s:10:"logicalnot";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"564";s:1:"N";s:10:"logicalnot";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"108";i:2;s:3:"534";i:3;s:3:"386";}}s:9:"odieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:9:"odieresis";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:3:"-10";i:2;s:3:"470";i:3;s:3:"623";}}s:9:"udieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:9:"udieresis";s:1:"B";a:4:{i:0;s:1:"9";i:1;s:3:"-10";i:2;s:3:"479";i:3;s:3:"623";}}s:8:"notequal";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"549";s:1:"N";s:8:"notequal";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:3:"-31";i:2;s:3:"537";i:3;s:3:"547";}}s:12:"gcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:12:"gcommaaccent";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:4:"-218";i:2;s:3:"470";i:3;s:3:"749";}}s:3:"eth";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:3:"eth";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:3:"-10";i:2;s:3:"471";i:3;s:3:"686";}}s:6:"zcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:6:"zcaron";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:1:"0";i:2;s:3:"418";i:3;s:3:"674";}}s:12:"ncommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:12:"ncommaaccent";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:4:"-218";i:2;s:3:"485";i:3;s:3:"460";}}s:11:"onesuperior";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"300";s:1:"N";s:11:"onesuperior";s:1:"B";a:4:{i:0;s:2:"57";i:1;s:3:"270";i:2;s:3:"248";i:3;s:3:"676";}}s:7:"imacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:7:"imacron";s:1:"B";a:4:{i:0;s:1:"6";i:1;s:1:"0";i:2;s:3:"271";i:3;s:3:"601";}}s:4:"Euro";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:4:"Euro";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}}s:3:"KPX";a:133:{s:1:"A";a:40:{s:1:"C";s:3:"-40";s:6:"Cacute";s:3:"-40";s:6:"Ccaron";s:3:"-40";s:8:"Ccedilla";s:3:"-40";s:1:"G";s:3:"-40";s:6:"Gbreve";s:3:"-40";s:12:"Gcommaaccent";s:3:"-40";s:1:"O";s:3:"-55";s:6:"Oacute";s:3:"-55";s:11:"Ocircumflex";s:3:"-55";s:9:"Odieresis";s:3:"-55";s:6:"Ograve";s:3:"-55";s:13:"Ohungarumlaut";s:3:"-55";s:7:"Omacron";s:3:"-55";s:6:"Oslash";s:3:"-55";s:6:"Otilde";s:3:"-55";s:1:"Q";s:3:"-55";s:1:"T";s:4:"-111";s:6:"Tcaron";s:4:"-111";s:12:"Tcommaaccent";s:4:"-111";s:1:"U";s:3:"-55";s:6:"Uacute";s:3:"-55";s:11:"Ucircumflex";s:3:"-55";s:9:"Udieresis";s:3:"-55";s:6:"Ugrave";s:3:"-55";s:13:"Uhungarumlaut";s:3:"-55";s:7:"Umacron";s:3:"-55";s:7:"Uogonek";s:3:"-55";s:5:"Uring";s:3:"-55";s:1:"V";s:4:"-135";s:1:"W";s:3:"-90";s:1:"Y";s:4:"-105";s:6:"Yacute";s:4:"-105";s:9:"Ydieresis";s:4:"-105";s:10:"quoteright";s:4:"-111";s:1:"v";s:3:"-74";s:1:"w";s:3:"-92";s:1:"y";s:3:"-92";s:6:"yacute";s:3:"-92";s:9:"ydieresis";s:3:"-92";}s:6:"Aacute";a:40:{s:1:"C";s:3:"-40";s:6:"Cacute";s:3:"-40";s:6:"Ccaron";s:3:"-40";s:8:"Ccedilla";s:3:"-40";s:1:"G";s:3:"-40";s:6:"Gbreve";s:3:"-40";s:12:"Gcommaaccent";s:3:"-40";s:1:"O";s:3:"-55";s:6:"Oacute";s:3:"-55";s:11:"Ocircumflex";s:3:"-55";s:9:"Odieresis";s:3:"-55";s:6:"Ograve";s:3:"-55";s:13:"Ohungarumlaut";s:3:"-55";s:7:"Omacron";s:3:"-55";s:6:"Oslash";s:3:"-55";s:6:"Otilde";s:3:"-55";s:1:"Q";s:3:"-55";s:1:"T";s:4:"-111";s:6:"Tcaron";s:4:"-111";s:12:"Tcommaaccent";s:4:"-111";s:1:"U";s:3:"-55";s:6:"Uacute";s:3:"-55";s:11:"Ucircumflex";s:3:"-55";s:9:"Udieresis";s:3:"-55";s:6:"Ugrave";s:3:"-55";s:13:"Uhungarumlaut";s:3:"-55";s:7:"Umacron";s:3:"-55";s:7:"Uogonek";s:3:"-55";s:5:"Uring";s:3:"-55";s:1:"V";s:4:"-135";s:1:"W";s:3:"-90";s:1:"Y";s:4:"-105";s:6:"Yacute";s:4:"-105";s:9:"Ydieresis";s:4:"-105";s:10:"quoteright";s:4:"-111";s:1:"v";s:3:"-74";s:1:"w";s:3:"-92";s:1:"y";s:3:"-92";s:6:"yacute";s:3:"-92";s:9:"ydieresis";s:3:"-92";}s:6:"Abreve";a:40:{s:1:"C";s:3:"-40";s:6:"Cacute";s:3:"-40";s:6:"Ccaron";s:3:"-40";s:8:"Ccedilla";s:3:"-40";s:1:"G";s:3:"-40";s:6:"Gbreve";s:3:"-40";s:12:"Gcommaaccent";s:3:"-40";s:1:"O";s:3:"-55";s:6:"Oacute";s:3:"-55";s:11:"Ocircumflex";s:3:"-55";s:9:"Odieresis";s:3:"-55";s:6:"Ograve";s:3:"-55";s:13:"Ohungarumlaut";s:3:"-55";s:7:"Omacron";s:3:"-55";s:6:"Oslash";s:3:"-55";s:6:"Otilde";s:3:"-55";s:1:"Q";s:3:"-55";s:1:"T";s:4:"-111";s:6:"Tcaron";s:4:"-111";s:12:"Tcommaaccent";s:4:"-111";s:1:"U";s:3:"-55";s:6:"Uacute";s:3:"-55";s:11:"Ucircumflex";s:3:"-55";s:9:"Udieresis";s:3:"-55";s:6:"Ugrave";s:3:"-55";s:13:"Uhungarumlaut";s:3:"-55";s:7:"Umacron";s:3:"-55";s:7:"Uogonek";s:3:"-55";s:5:"Uring";s:3:"-55";s:1:"V";s:4:"-135";s:1:"W";s:3:"-90";s:1:"Y";s:4:"-105";s:6:"Yacute";s:4:"-105";s:9:"Ydieresis";s:4:"-105";s:10:"quoteright";s:4:"-111";s:1:"v";s:3:"-74";s:1:"w";s:3:"-92";s:1:"y";s:3:"-92";s:6:"yacute";s:3:"-92";s:9:"ydieresis";s:3:"-92";}s:11:"Acircumflex";a:40:{s:1:"C";s:3:"-40";s:6:"Cacute";s:3:"-40";s:6:"Ccaron";s:3:"-40";s:8:"Ccedilla";s:3:"-40";s:1:"G";s:3:"-40";s:6:"Gbreve";s:3:"-40";s:12:"Gcommaaccent";s:3:"-40";s:1:"O";s:3:"-55";s:6:"Oacute";s:3:"-55";s:11:"Ocircumflex";s:3:"-55";s:9:"Odieresis";s:3:"-55";s:6:"Ograve";s:3:"-55";s:13:"Ohungarumlaut";s:3:"-55";s:7:"Omacron";s:3:"-55";s:6:"Oslash";s:3:"-55";s:6:"Otilde";s:3:"-55";s:1:"Q";s:3:"-55";s:1:"T";s:4:"-111";s:6:"Tcaron";s:4:"-111";s:12:"Tcommaaccent";s:4:"-111";s:1:"U";s:3:"-55";s:6:"Uacute";s:3:"-55";s:11:"Ucircumflex";s:3:"-55";s:9:"Udieresis";s:3:"-55";s:6:"Ugrave";s:3:"-55";s:13:"Uhungarumlaut";s:3:"-55";s:7:"Umacron";s:3:"-55";s:7:"Uogonek";s:3:"-55";s:5:"Uring";s:3:"-55";s:1:"V";s:4:"-135";s:1:"W";s:3:"-90";s:1:"Y";s:4:"-105";s:6:"Yacute";s:4:"-105";s:9:"Ydieresis";s:4:"-105";s:10:"quoteright";s:4:"-111";s:1:"v";s:3:"-74";s:1:"w";s:3:"-92";s:1:"y";s:3:"-92";s:6:"yacute";s:3:"-92";s:9:"ydieresis";s:3:"-92";}s:9:"Adieresis";a:40:{s:1:"C";s:3:"-40";s:6:"Cacute";s:3:"-40";s:6:"Ccaron";s:3:"-40";s:8:"Ccedilla";s:3:"-40";s:1:"G";s:3:"-40";s:6:"Gbreve";s:3:"-40";s:12:"Gcommaaccent";s:3:"-40";s:1:"O";s:3:"-55";s:6:"Oacute";s:3:"-55";s:11:"Ocircumflex";s:3:"-55";s:9:"Odieresis";s:3:"-55";s:6:"Ograve";s:3:"-55";s:13:"Ohungarumlaut";s:3:"-55";s:7:"Omacron";s:3:"-55";s:6:"Oslash";s:3:"-55";s:6:"Otilde";s:3:"-55";s:1:"Q";s:3:"-55";s:1:"T";s:4:"-111";s:6:"Tcaron";s:4:"-111";s:12:"Tcommaaccent";s:4:"-111";s:1:"U";s:3:"-55";s:6:"Uacute";s:3:"-55";s:11:"Ucircumflex";s:3:"-55";s:9:"Udieresis";s:3:"-55";s:6:"Ugrave";s:3:"-55";s:13:"Uhungarumlaut";s:3:"-55";s:7:"Umacron";s:3:"-55";s:7:"Uogonek";s:3:"-55";s:5:"Uring";s:3:"-55";s:1:"V";s:4:"-135";s:1:"W";s:3:"-90";s:1:"Y";s:4:"-105";s:6:"Yacute";s:4:"-105";s:9:"Ydieresis";s:4:"-105";s:10:"quoteright";s:4:"-111";s:1:"v";s:3:"-74";s:1:"w";s:3:"-92";s:1:"y";s:3:"-92";s:6:"yacute";s:3:"-92";s:9:"ydieresis";s:3:"-92";}s:6:"Agrave";a:40:{s:1:"C";s:3:"-40";s:6:"Cacute";s:3:"-40";s:6:"Ccaron";s:3:"-40";s:8:"Ccedilla";s:3:"-40";s:1:"G";s:3:"-40";s:6:"Gbreve";s:3:"-40";s:12:"Gcommaaccent";s:3:"-40";s:1:"O";s:3:"-55";s:6:"Oacute";s:3:"-55";s:11:"Ocircumflex";s:3:"-55";s:9:"Odieresis";s:3:"-55";s:6:"Ograve";s:3:"-55";s:13:"Ohungarumlaut";s:3:"-55";s:7:"Omacron";s:3:"-55";s:6:"Oslash";s:3:"-55";s:6:"Otilde";s:3:"-55";s:1:"Q";s:3:"-55";s:1:"T";s:4:"-111";s:6:"Tcaron";s:4:"-111";s:12:"Tcommaaccent";s:4:"-111";s:1:"U";s:3:"-55";s:6:"Uacute";s:3:"-55";s:11:"Ucircumflex";s:3:"-55";s:9:"Udieresis";s:3:"-55";s:6:"Ugrave";s:3:"-55";s:13:"Uhungarumlaut";s:3:"-55";s:7:"Umacron";s:3:"-55";s:7:"Uogonek";s:3:"-55";s:5:"Uring";s:3:"-55";s:1:"V";s:4:"-135";s:1:"W";s:3:"-90";s:1:"Y";s:4:"-105";s:6:"Yacute";s:4:"-105";s:9:"Ydieresis";s:4:"-105";s:10:"quoteright";s:4:"-111";s:1:"v";s:3:"-74";s:1:"w";s:3:"-92";s:1:"y";s:3:"-92";s:6:"yacute";s:3:"-92";s:9:"ydieresis";s:3:"-92";}s:7:"Amacron";a:40:{s:1:"C";s:3:"-40";s:6:"Cacute";s:3:"-40";s:6:"Ccaron";s:3:"-40";s:8:"Ccedilla";s:3:"-40";s:1:"G";s:3:"-40";s:6:"Gbreve";s:3:"-40";s:12:"Gcommaaccent";s:3:"-40";s:1:"O";s:3:"-55";s:6:"Oacute";s:3:"-55";s:11:"Ocircumflex";s:3:"-55";s:9:"Odieresis";s:3:"-55";s:6:"Ograve";s:3:"-55";s:13:"Ohungarumlaut";s:3:"-55";s:7:"Omacron";s:3:"-55";s:6:"Oslash";s:3:"-55";s:6:"Otilde";s:3:"-55";s:1:"Q";s:3:"-55";s:1:"T";s:4:"-111";s:6:"Tcaron";s:4:"-111";s:12:"Tcommaaccent";s:4:"-111";s:1:"U";s:3:"-55";s:6:"Uacute";s:3:"-55";s:11:"Ucircumflex";s:3:"-55";s:9:"Udieresis";s:3:"-55";s:6:"Ugrave";s:3:"-55";s:13:"Uhungarumlaut";s:3:"-55";s:7:"Umacron";s:3:"-55";s:7:"Uogonek";s:3:"-55";s:5:"Uring";s:3:"-55";s:1:"V";s:4:"-135";s:1:"W";s:3:"-90";s:1:"Y";s:4:"-105";s:6:"Yacute";s:4:"-105";s:9:"Ydieresis";s:4:"-105";s:10:"quoteright";s:4:"-111";s:1:"v";s:3:"-74";s:1:"w";s:3:"-92";s:1:"y";s:3:"-92";s:6:"yacute";s:3:"-92";s:9:"ydieresis";s:3:"-92";}s:7:"Aogonek";a:40:{s:1:"C";s:3:"-40";s:6:"Cacute";s:3:"-40";s:6:"Ccaron";s:3:"-40";s:8:"Ccedilla";s:3:"-40";s:1:"G";s:3:"-40";s:6:"Gbreve";s:3:"-40";s:12:"Gcommaaccent";s:3:"-40";s:1:"O";s:3:"-55";s:6:"Oacute";s:3:"-55";s:11:"Ocircumflex";s:3:"-55";s:9:"Odieresis";s:3:"-55";s:6:"Ograve";s:3:"-55";s:13:"Ohungarumlaut";s:3:"-55";s:7:"Omacron";s:3:"-55";s:6:"Oslash";s:3:"-55";s:6:"Otilde";s:3:"-55";s:1:"Q";s:3:"-55";s:1:"T";s:4:"-111";s:6:"Tcaron";s:4:"-111";s:12:"Tcommaaccent";s:4:"-111";s:1:"U";s:3:"-55";s:6:"Uacute";s:3:"-55";s:11:"Ucircumflex";s:3:"-55";s:9:"Udieresis";s:3:"-55";s:6:"Ugrave";s:3:"-55";s:13:"Uhungarumlaut";s:3:"-55";s:7:"Umacron";s:3:"-55";s:7:"Uogonek";s:3:"-55";s:5:"Uring";s:3:"-55";s:1:"V";s:4:"-135";s:1:"W";s:3:"-90";s:1:"Y";s:4:"-105";s:6:"Yacute";s:4:"-105";s:9:"Ydieresis";s:4:"-105";s:10:"quoteright";s:4:"-111";s:1:"v";s:3:"-74";s:1:"w";s:3:"-52";s:1:"y";s:3:"-52";s:6:"yacute";s:3:"-52";s:9:"ydieresis";s:3:"-52";}s:5:"Aring";a:40:{s:1:"C";s:3:"-40";s:6:"Cacute";s:3:"-40";s:6:"Ccaron";s:3:"-40";s:8:"Ccedilla";s:3:"-40";s:1:"G";s:3:"-40";s:6:"Gbreve";s:3:"-40";s:12:"Gcommaaccent";s:3:"-40";s:1:"O";s:3:"-55";s:6:"Oacute";s:3:"-55";s:11:"Ocircumflex";s:3:"-55";s:9:"Odieresis";s:3:"-55";s:6:"Ograve";s:3:"-55";s:13:"Ohungarumlaut";s:3:"-55";s:7:"Omacron";s:3:"-55";s:6:"Oslash";s:3:"-55";s:6:"Otilde";s:3:"-55";s:1:"Q";s:3:"-55";s:1:"T";s:4:"-111";s:6:"Tcaron";s:4:"-111";s:12:"Tcommaaccent";s:4:"-111";s:1:"U";s:3:"-55";s:6:"Uacute";s:3:"-55";s:11:"Ucircumflex";s:3:"-55";s:9:"Udieresis";s:3:"-55";s:6:"Ugrave";s:3:"-55";s:13:"Uhungarumlaut";s:3:"-55";s:7:"Umacron";s:3:"-55";s:7:"Uogonek";s:3:"-55";s:5:"Uring";s:3:"-55";s:1:"V";s:4:"-135";s:1:"W";s:3:"-90";s:1:"Y";s:4:"-105";s:6:"Yacute";s:4:"-105";s:9:"Ydieresis";s:4:"-105";s:10:"quoteright";s:4:"-111";s:1:"v";s:3:"-74";s:1:"w";s:3:"-92";s:1:"y";s:3:"-92";s:6:"yacute";s:3:"-92";s:9:"ydieresis";s:3:"-92";}s:6:"Atilde";a:40:{s:1:"C";s:3:"-40";s:6:"Cacute";s:3:"-40";s:6:"Ccaron";s:3:"-40";s:8:"Ccedilla";s:3:"-40";s:1:"G";s:3:"-40";s:6:"Gbreve";s:3:"-40";s:12:"Gcommaaccent";s:3:"-40";s:1:"O";s:3:"-55";s:6:"Oacute";s:3:"-55";s:11:"Ocircumflex";s:3:"-55";s:9:"Odieresis";s:3:"-55";s:6:"Ograve";s:3:"-55";s:13:"Ohungarumlaut";s:3:"-55";s:7:"Omacron";s:3:"-55";s:6:"Oslash";s:3:"-55";s:6:"Otilde";s:3:"-55";s:1:"Q";s:3:"-55";s:1:"T";s:4:"-111";s:6:"Tcaron";s:4:"-111";s:12:"Tcommaaccent";s:4:"-111";s:1:"U";s:3:"-55";s:6:"Uacute";s:3:"-55";s:11:"Ucircumflex";s:3:"-55";s:9:"Udieresis";s:3:"-55";s:6:"Ugrave";s:3:"-55";s:13:"Uhungarumlaut";s:3:"-55";s:7:"Umacron";s:3:"-55";s:7:"Uogonek";s:3:"-55";s:5:"Uring";s:3:"-55";s:1:"V";s:4:"-135";s:1:"W";s:3:"-90";s:1:"Y";s:4:"-105";s:6:"Yacute";s:4:"-105";s:9:"Ydieresis";s:4:"-105";s:10:"quoteright";s:4:"-111";s:1:"v";s:3:"-74";s:1:"w";s:3:"-92";s:1:"y";s:3:"-92";s:6:"yacute";s:3:"-92";s:9:"ydieresis";s:3:"-92";}s:1:"B";a:19:{s:1:"A";s:3:"-35";s:6:"Aacute";s:3:"-35";s:6:"Abreve";s:3:"-35";s:11:"Acircumflex";s:3:"-35";s:9:"Adieresis";s:3:"-35";s:6:"Agrave";s:3:"-35";s:7:"Amacron";s:3:"-35";s:7:"Aogonek";s:3:"-35";s:5:"Aring";s:3:"-35";s:6:"Atilde";s:3:"-35";s:1:"U";s:3:"-10";s:6:"Uacute";s:3:"-10";s:11:"Ucircumflex";s:3:"-10";s:9:"Udieresis";s:3:"-10";s:6:"Ugrave";s:3:"-10";s:13:"Uhungarumlaut";s:3:"-10";s:7:"Umacron";s:3:"-10";s:7:"Uogonek";s:3:"-10";s:5:"Uring";s:3:"-10";}s:1:"D";a:15:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:1:"V";s:3:"-40";s:1:"W";s:3:"-30";s:1:"Y";s:3:"-55";s:6:"Yacute";s:3:"-55";s:9:"Ydieresis";s:3:"-55";}s:6:"Dcaron";a:15:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:1:"V";s:3:"-40";s:1:"W";s:3:"-30";s:1:"Y";s:3:"-55";s:6:"Yacute";s:3:"-55";s:9:"Ydieresis";s:3:"-55";}s:6:"Dcroat";a:15:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:1:"V";s:3:"-40";s:1:"W";s:3:"-30";s:1:"Y";s:3:"-55";s:6:"Yacute";s:3:"-55";s:9:"Ydieresis";s:3:"-55";}s:1:"F";a:31:{s:1:"A";s:3:"-74";s:6:"Aacute";s:3:"-74";s:6:"Abreve";s:3:"-74";s:11:"Acircumflex";s:3:"-74";s:9:"Adieresis";s:3:"-74";s:6:"Agrave";s:3:"-74";s:7:"Amacron";s:3:"-74";s:7:"Aogonek";s:3:"-74";s:5:"Aring";s:3:"-74";s:6:"Atilde";s:3:"-74";s:1:"a";s:3:"-15";s:6:"aacute";s:3:"-15";s:6:"abreve";s:3:"-15";s:11:"acircumflex";s:3:"-15";s:9:"adieresis";s:3:"-15";s:6:"agrave";s:3:"-15";s:7:"amacron";s:3:"-15";s:7:"aogonek";s:3:"-15";s:5:"aring";s:3:"-15";s:6:"atilde";s:3:"-15";s:5:"comma";s:3:"-80";s:1:"o";s:3:"-15";s:6:"oacute";s:3:"-15";s:11:"ocircumflex";s:3:"-15";s:9:"odieresis";s:3:"-15";s:6:"ograve";s:3:"-15";s:13:"ohungarumlaut";s:3:"-15";s:7:"omacron";s:3:"-15";s:6:"oslash";s:3:"-15";s:6:"otilde";s:3:"-15";s:6:"period";s:3:"-80";}s:1:"J";a:10:{s:1:"A";s:3:"-60";s:6:"Aacute";s:3:"-60";s:6:"Abreve";s:3:"-60";s:11:"Acircumflex";s:3:"-60";s:9:"Adieresis";s:3:"-60";s:6:"Agrave";s:3:"-60";s:7:"Amacron";s:3:"-60";s:7:"Aogonek";s:3:"-60";s:5:"Aring";s:3:"-60";s:6:"Atilde";s:3:"-60";}s:1:"K";a:39:{s:1:"O";s:3:"-30";s:6:"Oacute";s:3:"-30";s:11:"Ocircumflex";s:3:"-30";s:9:"Odieresis";s:3:"-30";s:6:"Ograve";s:3:"-30";s:13:"Ohungarumlaut";s:3:"-30";s:7:"Omacron";s:3:"-30";s:6:"Oslash";s:3:"-30";s:6:"Otilde";s:3:"-30";s:1:"e";s:3:"-25";s:6:"eacute";s:3:"-25";s:6:"ecaron";s:3:"-25";s:11:"ecircumflex";s:3:"-25";s:9:"edieresis";s:3:"-25";s:10:"edotaccent";s:3:"-25";s:6:"egrave";s:3:"-25";s:7:"emacron";s:3:"-25";s:7:"eogonek";s:3:"-25";s:1:"o";s:3:"-35";s:6:"oacute";s:3:"-35";s:11:"ocircumflex";s:3:"-35";s:9:"odieresis";s:3:"-35";s:6:"ograve";s:3:"-35";s:13:"ohungarumlaut";s:3:"-35";s:7:"omacron";s:3:"-35";s:6:"oslash";s:3:"-35";s:6:"otilde";s:3:"-35";s:1:"u";s:3:"-15";s:6:"uacute";s:3:"-15";s:11:"ucircumflex";s:3:"-15";s:9:"udieresis";s:3:"-15";s:6:"ugrave";s:3:"-15";s:13:"uhungarumlaut";s:3:"-15";s:7:"umacron";s:3:"-15";s:7:"uogonek";s:3:"-15";s:5:"uring";s:3:"-15";s:1:"y";s:3:"-25";s:6:"yacute";s:3:"-25";s:9:"ydieresis";s:3:"-25";}s:12:"Kcommaaccent";a:39:{s:1:"O";s:3:"-30";s:6:"Oacute";s:3:"-30";s:11:"Ocircumflex";s:3:"-30";s:9:"Odieresis";s:3:"-30";s:6:"Ograve";s:3:"-30";s:13:"Ohungarumlaut";s:3:"-30";s:7:"Omacron";s:3:"-30";s:6:"Oslash";s:3:"-30";s:6:"Otilde";s:3:"-30";s:1:"e";s:3:"-25";s:6:"eacute";s:3:"-25";s:6:"ecaron";s:3:"-25";s:11:"ecircumflex";s:3:"-25";s:9:"edieresis";s:3:"-25";s:10:"edotaccent";s:3:"-25";s:6:"egrave";s:3:"-25";s:7:"emacron";s:3:"-25";s:7:"eogonek";s:3:"-25";s:1:"o";s:3:"-35";s:6:"oacute";s:3:"-35";s:11:"ocircumflex";s:3:"-35";s:9:"odieresis";s:3:"-35";s:6:"ograve";s:3:"-35";s:13:"ohungarumlaut";s:3:"-35";s:7:"omacron";s:3:"-35";s:6:"oslash";s:3:"-35";s:6:"otilde";s:3:"-35";s:1:"u";s:3:"-15";s:6:"uacute";s:3:"-15";s:11:"ucircumflex";s:3:"-15";s:9:"udieresis";s:3:"-15";s:6:"ugrave";s:3:"-15";s:13:"uhungarumlaut";s:3:"-15";s:7:"umacron";s:3:"-15";s:7:"uogonek";s:3:"-15";s:5:"uring";s:3:"-15";s:1:"y";s:3:"-25";s:6:"yacute";s:3:"-25";s:9:"ydieresis";s:3:"-25";}s:1:"L";a:12:{s:1:"T";s:3:"-92";s:6:"Tcaron";s:3:"-92";s:12:"Tcommaaccent";s:3:"-92";s:1:"V";s:4:"-100";s:1:"W";s:3:"-74";s:1:"Y";s:4:"-100";s:6:"Yacute";s:4:"-100";s:9:"Ydieresis";s:4:"-100";s:10:"quoteright";s:3:"-92";s:1:"y";s:3:"-55";s:6:"yacute";s:3:"-55";s:9:"ydieresis";s:3:"-55";}s:6:"Lacute";a:12:{s:1:"T";s:3:"-92";s:6:"Tcaron";s:3:"-92";s:12:"Tcommaaccent";s:3:"-92";s:1:"V";s:4:"-100";s:1:"W";s:3:"-74";s:1:"Y";s:4:"-100";s:6:"Yacute";s:4:"-100";s:9:"Ydieresis";s:4:"-100";s:10:"quoteright";s:3:"-92";s:1:"y";s:3:"-55";s:6:"yacute";s:3:"-55";s:9:"ydieresis";s:3:"-55";}s:6:"Lcaron";a:4:{s:10:"quoteright";s:3:"-92";s:1:"y";s:3:"-55";s:6:"yacute";s:3:"-55";s:9:"ydieresis";s:3:"-55";}s:12:"Lcommaaccent";a:12:{s:1:"T";s:3:"-92";s:6:"Tcaron";s:3:"-92";s:12:"Tcommaaccent";s:3:"-92";s:1:"V";s:4:"-100";s:1:"W";s:3:"-74";s:1:"Y";s:4:"-100";s:6:"Yacute";s:4:"-100";s:9:"Ydieresis";s:4:"-100";s:10:"quoteright";s:3:"-92";s:1:"y";s:3:"-55";s:6:"yacute";s:3:"-55";s:9:"ydieresis";s:3:"-55";}s:6:"Lslash";a:12:{s:1:"T";s:3:"-92";s:6:"Tcaron";s:3:"-92";s:12:"Tcommaaccent";s:3:"-92";s:1:"V";s:4:"-100";s:1:"W";s:3:"-74";s:1:"Y";s:4:"-100";s:6:"Yacute";s:4:"-100";s:9:"Ydieresis";s:4:"-100";s:10:"quoteright";s:3:"-92";s:1:"y";s:3:"-55";s:6:"yacute";s:3:"-55";s:9:"ydieresis";s:3:"-55";}s:1:"N";a:10:{s:1:"A";s:3:"-35";s:6:"Aacute";s:3:"-35";s:6:"Abreve";s:3:"-35";s:11:"Acircumflex";s:3:"-35";s:9:"Adieresis";s:3:"-35";s:6:"Agrave";s:3:"-35";s:7:"Amacron";s:3:"-35";s:7:"Aogonek";s:3:"-35";s:5:"Aring";s:3:"-35";s:6:"Atilde";s:3:"-35";}s:6:"Nacute";a:10:{s:1:"A";s:3:"-35";s:6:"Aacute";s:3:"-35";s:6:"Abreve";s:3:"-35";s:11:"Acircumflex";s:3:"-35";s:9:"Adieresis";s:3:"-35";s:6:"Agrave";s:3:"-35";s:7:"Amacron";s:3:"-35";s:7:"Aogonek";s:3:"-35";s:5:"Aring";s:3:"-35";s:6:"Atilde";s:3:"-35";}s:6:"Ncaron";a:10:{s:1:"A";s:3:"-35";s:6:"Aacute";s:3:"-35";s:6:"Abreve";s:3:"-35";s:11:"Acircumflex";s:3:"-35";s:9:"Adieresis";s:3:"-35";s:6:"Agrave";s:3:"-35";s:7:"Amacron";s:3:"-35";s:7:"Aogonek";s:3:"-35";s:5:"Aring";s:3:"-35";s:6:"Atilde";s:3:"-35";}s:12:"Ncommaaccent";a:10:{s:1:"A";s:3:"-35";s:6:"Aacute";s:3:"-35";s:6:"Abreve";s:3:"-35";s:11:"Acircumflex";s:3:"-35";s:9:"Adieresis";s:3:"-35";s:6:"Agrave";s:3:"-35";s:7:"Amacron";s:3:"-35";s:7:"Aogonek";s:3:"-35";s:5:"Aring";s:3:"-35";s:6:"Atilde";s:3:"-35";}s:6:"Ntilde";a:10:{s:1:"A";s:3:"-35";s:6:"Aacute";s:3:"-35";s:6:"Abreve";s:3:"-35";s:11:"Acircumflex";s:3:"-35";s:9:"Adieresis";s:3:"-35";s:6:"Agrave";s:3:"-35";s:7:"Amacron";s:3:"-35";s:7:"Aogonek";s:3:"-35";s:5:"Aring";s:3:"-35";s:6:"Atilde";s:3:"-35";}s:1:"O";a:19:{s:1:"A";s:3:"-35";s:6:"Aacute";s:3:"-35";s:6:"Abreve";s:3:"-35";s:11:"Acircumflex";s:3:"-35";s:9:"Adieresis";s:3:"-35";s:6:"Agrave";s:3:"-35";s:7:"Amacron";s:3:"-35";s:7:"Aogonek";s:3:"-35";s:5:"Aring";s:3:"-35";s:6:"Atilde";s:3:"-35";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-35";s:1:"X";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:6:"Oacute";a:19:{s:1:"A";s:3:"-35";s:6:"Aacute";s:3:"-35";s:6:"Abreve";s:3:"-35";s:11:"Acircumflex";s:3:"-35";s:9:"Adieresis";s:3:"-35";s:6:"Agrave";s:3:"-35";s:7:"Amacron";s:3:"-35";s:7:"Aogonek";s:3:"-35";s:5:"Aring";s:3:"-35";s:6:"Atilde";s:3:"-35";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-35";s:1:"X";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:11:"Ocircumflex";a:19:{s:1:"A";s:3:"-35";s:6:"Aacute";s:3:"-35";s:6:"Abreve";s:3:"-35";s:11:"Acircumflex";s:3:"-35";s:9:"Adieresis";s:3:"-35";s:6:"Agrave";s:3:"-35";s:7:"Amacron";s:3:"-35";s:7:"Aogonek";s:3:"-35";s:5:"Aring";s:3:"-35";s:6:"Atilde";s:3:"-35";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-35";s:1:"X";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:9:"Odieresis";a:19:{s:1:"A";s:3:"-35";s:6:"Aacute";s:3:"-35";s:6:"Abreve";s:3:"-35";s:11:"Acircumflex";s:3:"-35";s:9:"Adieresis";s:3:"-35";s:6:"Agrave";s:3:"-35";s:7:"Amacron";s:3:"-35";s:7:"Aogonek";s:3:"-35";s:5:"Aring";s:3:"-35";s:6:"Atilde";s:3:"-35";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-35";s:1:"X";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:6:"Ograve";a:19:{s:1:"A";s:3:"-35";s:6:"Aacute";s:3:"-35";s:6:"Abreve";s:3:"-35";s:11:"Acircumflex";s:3:"-35";s:9:"Adieresis";s:3:"-35";s:6:"Agrave";s:3:"-35";s:7:"Amacron";s:3:"-35";s:7:"Aogonek";s:3:"-35";s:5:"Aring";s:3:"-35";s:6:"Atilde";s:3:"-35";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-35";s:1:"X";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:13:"Ohungarumlaut";a:19:{s:1:"A";s:3:"-35";s:6:"Aacute";s:3:"-35";s:6:"Abreve";s:3:"-35";s:11:"Acircumflex";s:3:"-35";s:9:"Adieresis";s:3:"-35";s:6:"Agrave";s:3:"-35";s:7:"Amacron";s:3:"-35";s:7:"Aogonek";s:3:"-35";s:5:"Aring";s:3:"-35";s:6:"Atilde";s:3:"-35";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-35";s:1:"X";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:7:"Omacron";a:19:{s:1:"A";s:3:"-35";s:6:"Aacute";s:3:"-35";s:6:"Abreve";s:3:"-35";s:11:"Acircumflex";s:3:"-35";s:9:"Adieresis";s:3:"-35";s:6:"Agrave";s:3:"-35";s:7:"Amacron";s:3:"-35";s:7:"Aogonek";s:3:"-35";s:5:"Aring";s:3:"-35";s:6:"Atilde";s:3:"-35";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-35";s:1:"X";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:6:"Oslash";a:19:{s:1:"A";s:3:"-35";s:6:"Aacute";s:3:"-35";s:6:"Abreve";s:3:"-35";s:11:"Acircumflex";s:3:"-35";s:9:"Adieresis";s:3:"-35";s:6:"Agrave";s:3:"-35";s:7:"Amacron";s:3:"-35";s:7:"Aogonek";s:3:"-35";s:5:"Aring";s:3:"-35";s:6:"Atilde";s:3:"-35";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-35";s:1:"X";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:6:"Otilde";a:19:{s:1:"A";s:3:"-35";s:6:"Aacute";s:3:"-35";s:6:"Abreve";s:3:"-35";s:11:"Acircumflex";s:3:"-35";s:9:"Adieresis";s:3:"-35";s:6:"Agrave";s:3:"-35";s:7:"Amacron";s:3:"-35";s:7:"Aogonek";s:3:"-35";s:5:"Aring";s:3:"-35";s:6:"Atilde";s:3:"-35";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-35";s:1:"X";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:1:"P";a:22:{s:1:"A";s:3:"-92";s:6:"Aacute";s:3:"-92";s:6:"Abreve";s:3:"-92";s:11:"Acircumflex";s:3:"-92";s:9:"Adieresis";s:3:"-92";s:6:"Agrave";s:3:"-92";s:7:"Amacron";s:3:"-92";s:7:"Aogonek";s:3:"-92";s:5:"Aring";s:3:"-92";s:6:"Atilde";s:3:"-92";s:1:"a";s:3:"-15";s:6:"aacute";s:3:"-15";s:6:"abreve";s:3:"-15";s:11:"acircumflex";s:3:"-15";s:9:"adieresis";s:3:"-15";s:6:"agrave";s:3:"-15";s:7:"amacron";s:3:"-15";s:7:"aogonek";s:3:"-15";s:5:"aring";s:3:"-15";s:6:"atilde";s:3:"-15";s:5:"comma";s:4:"-111";s:6:"period";s:4:"-111";}s:1:"Q";a:9:{s:1:"U";s:3:"-10";s:6:"Uacute";s:3:"-10";s:11:"Ucircumflex";s:3:"-10";s:9:"Udieresis";s:3:"-10";s:6:"Ugrave";s:3:"-10";s:13:"Uhungarumlaut";s:3:"-10";s:7:"Umacron";s:3:"-10";s:7:"Uogonek";s:3:"-10";s:5:"Uring";s:3:"-10";}s:1:"R";a:26:{s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"T";s:3:"-60";s:6:"Tcaron";s:3:"-60";s:12:"Tcommaaccent";s:3:"-60";s:1:"U";s:3:"-40";s:6:"Uacute";s:3:"-40";s:11:"Ucircumflex";s:3:"-40";s:9:"Udieresis";s:3:"-40";s:6:"Ugrave";s:3:"-40";s:13:"Uhungarumlaut";s:3:"-40";s:7:"Umacron";s:3:"-40";s:7:"Uogonek";s:3:"-40";s:5:"Uring";s:3:"-40";s:1:"V";s:3:"-80";s:1:"W";s:3:"-55";s:1:"Y";s:3:"-65";s:6:"Yacute";s:3:"-65";s:9:"Ydieresis";s:3:"-65";}s:6:"Racute";a:26:{s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"T";s:3:"-60";s:6:"Tcaron";s:3:"-60";s:12:"Tcommaaccent";s:3:"-60";s:1:"U";s:3:"-40";s:6:"Uacute";s:3:"-40";s:11:"Ucircumflex";s:3:"-40";s:9:"Udieresis";s:3:"-40";s:6:"Ugrave";s:3:"-40";s:13:"Uhungarumlaut";s:3:"-40";s:7:"Umacron";s:3:"-40";s:7:"Uogonek";s:3:"-40";s:5:"Uring";s:3:"-40";s:1:"V";s:3:"-80";s:1:"W";s:3:"-55";s:1:"Y";s:3:"-65";s:6:"Yacute";s:3:"-65";s:9:"Ydieresis";s:3:"-65";}s:6:"Rcaron";a:26:{s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"T";s:3:"-60";s:6:"Tcaron";s:3:"-60";s:12:"Tcommaaccent";s:3:"-60";s:1:"U";s:3:"-40";s:6:"Uacute";s:3:"-40";s:11:"Ucircumflex";s:3:"-40";s:9:"Udieresis";s:3:"-40";s:6:"Ugrave";s:3:"-40";s:13:"Uhungarumlaut";s:3:"-40";s:7:"Umacron";s:3:"-40";s:7:"Uogonek";s:3:"-40";s:5:"Uring";s:3:"-40";s:1:"V";s:3:"-80";s:1:"W";s:3:"-55";s:1:"Y";s:3:"-65";s:6:"Yacute";s:3:"-65";s:9:"Ydieresis";s:3:"-65";}s:12:"Rcommaaccent";a:26:{s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"T";s:3:"-60";s:6:"Tcaron";s:3:"-60";s:12:"Tcommaaccent";s:3:"-60";s:1:"U";s:3:"-40";s:6:"Uacute";s:3:"-40";s:11:"Ucircumflex";s:3:"-40";s:9:"Udieresis";s:3:"-40";s:6:"Ugrave";s:3:"-40";s:13:"Uhungarumlaut";s:3:"-40";s:7:"Umacron";s:3:"-40";s:7:"Uogonek";s:3:"-40";s:5:"Uring";s:3:"-40";s:1:"V";s:3:"-80";s:1:"W";s:3:"-55";s:1:"Y";s:3:"-65";s:6:"Yacute";s:3:"-65";s:9:"Ydieresis";s:3:"-65";}s:1:"T";a:72:{s:1:"A";s:3:"-93";s:6:"Aacute";s:3:"-93";s:6:"Abreve";s:3:"-93";s:11:"Acircumflex";s:3:"-93";s:9:"Adieresis";s:3:"-93";s:6:"Agrave";s:3:"-93";s:7:"Amacron";s:3:"-93";s:7:"Aogonek";s:3:"-93";s:5:"Aring";s:3:"-93";s:6:"Atilde";s:3:"-93";s:1:"O";s:3:"-18";s:6:"Oacute";s:3:"-18";s:11:"Ocircumflex";s:3:"-18";s:9:"Odieresis";s:3:"-18";s:6:"Ograve";s:3:"-18";s:13:"Ohungarumlaut";s:3:"-18";s:7:"Omacron";s:3:"-18";s:6:"Oslash";s:3:"-18";s:6:"Otilde";s:3:"-18";s:1:"a";s:3:"-80";s:6:"aacute";s:3:"-80";s:6:"abreve";s:3:"-80";s:11:"acircumflex";s:3:"-80";s:9:"adieresis";s:3:"-40";s:6:"agrave";s:3:"-40";s:7:"amacron";s:3:"-40";s:7:"aogonek";s:3:"-80";s:5:"aring";s:3:"-80";s:6:"atilde";s:3:"-40";s:5:"colon";s:3:"-50";s:5:"comma";s:3:"-74";s:1:"e";s:3:"-70";s:6:"eacute";s:3:"-70";s:6:"ecaron";s:3:"-70";s:11:"ecircumflex";s:3:"-70";s:9:"edieresis";s:3:"-30";s:10:"edotaccent";s:3:"-70";s:6:"egrave";s:3:"-70";s:7:"emacron";s:3:"-30";s:7:"eogonek";s:3:"-70";s:6:"hyphen";s:3:"-92";s:1:"i";s:3:"-35";s:6:"iacute";s:3:"-35";s:7:"iogonek";s:3:"-35";s:1:"o";s:3:"-80";s:6:"oacute";s:3:"-80";s:11:"ocircumflex";s:3:"-80";s:9:"odieresis";s:3:"-80";s:6:"ograve";s:3:"-80";s:13:"ohungarumlaut";s:3:"-80";s:7:"omacron";s:3:"-80";s:6:"oslash";s:3:"-80";s:6:"otilde";s:3:"-80";s:6:"period";s:3:"-74";s:1:"r";s:3:"-35";s:6:"racute";s:3:"-35";s:6:"rcaron";s:3:"-35";s:12:"rcommaaccent";s:3:"-35";s:9:"semicolon";s:3:"-55";s:1:"u";s:3:"-45";s:6:"uacute";s:3:"-45";s:11:"ucircumflex";s:3:"-45";s:9:"udieresis";s:3:"-45";s:6:"ugrave";s:3:"-45";s:13:"uhungarumlaut";s:3:"-45";s:7:"umacron";s:3:"-45";s:7:"uogonek";s:3:"-45";s:5:"uring";s:3:"-45";s:1:"w";s:3:"-80";s:1:"y";s:3:"-80";s:6:"yacute";s:3:"-80";s:9:"ydieresis";s:3:"-80";}s:6:"Tcaron";a:72:{s:1:"A";s:3:"-93";s:6:"Aacute";s:3:"-93";s:6:"Abreve";s:3:"-93";s:11:"Acircumflex";s:3:"-93";s:9:"Adieresis";s:3:"-93";s:6:"Agrave";s:3:"-93";s:7:"Amacron";s:3:"-93";s:7:"Aogonek";s:3:"-93";s:5:"Aring";s:3:"-93";s:6:"Atilde";s:3:"-93";s:1:"O";s:3:"-18";s:6:"Oacute";s:3:"-18";s:11:"Ocircumflex";s:3:"-18";s:9:"Odieresis";s:3:"-18";s:6:"Ograve";s:3:"-18";s:13:"Ohungarumlaut";s:3:"-18";s:7:"Omacron";s:3:"-18";s:6:"Oslash";s:3:"-18";s:6:"Otilde";s:3:"-18";s:1:"a";s:3:"-80";s:6:"aacute";s:3:"-80";s:6:"abreve";s:3:"-80";s:11:"acircumflex";s:3:"-80";s:9:"adieresis";s:3:"-40";s:6:"agrave";s:3:"-40";s:7:"amacron";s:3:"-40";s:7:"aogonek";s:3:"-80";s:5:"aring";s:3:"-80";s:6:"atilde";s:3:"-40";s:5:"colon";s:3:"-50";s:5:"comma";s:3:"-74";s:1:"e";s:3:"-70";s:6:"eacute";s:3:"-70";s:6:"ecaron";s:3:"-70";s:11:"ecircumflex";s:3:"-30";s:9:"edieresis";s:3:"-30";s:10:"edotaccent";s:3:"-70";s:6:"egrave";s:3:"-70";s:7:"emacron";s:3:"-30";s:7:"eogonek";s:3:"-70";s:6:"hyphen";s:3:"-92";s:1:"i";s:3:"-35";s:6:"iacute";s:3:"-35";s:7:"iogonek";s:3:"-35";s:1:"o";s:3:"-80";s:6:"oacute";s:3:"-80";s:11:"ocircumflex";s:3:"-80";s:9:"odieresis";s:3:"-80";s:6:"ograve";s:3:"-80";s:13:"ohungarumlaut";s:3:"-80";s:7:"omacron";s:3:"-80";s:6:"oslash";s:3:"-80";s:6:"otilde";s:3:"-80";s:6:"period";s:3:"-74";s:1:"r";s:3:"-35";s:6:"racute";s:3:"-35";s:6:"rcaron";s:3:"-35";s:12:"rcommaaccent";s:3:"-35";s:9:"semicolon";s:3:"-55";s:1:"u";s:3:"-45";s:6:"uacute";s:3:"-45";s:11:"ucircumflex";s:3:"-45";s:9:"udieresis";s:3:"-45";s:6:"ugrave";s:3:"-45";s:13:"uhungarumlaut";s:3:"-45";s:7:"umacron";s:3:"-45";s:7:"uogonek";s:3:"-45";s:5:"uring";s:3:"-45";s:1:"w";s:3:"-80";s:1:"y";s:3:"-80";s:6:"yacute";s:3:"-80";s:9:"ydieresis";s:3:"-80";}s:12:"Tcommaaccent";a:72:{s:1:"A";s:3:"-93";s:6:"Aacute";s:3:"-93";s:6:"Abreve";s:3:"-93";s:11:"Acircumflex";s:3:"-93";s:9:"Adieresis";s:3:"-93";s:6:"Agrave";s:3:"-93";s:7:"Amacron";s:3:"-93";s:7:"Aogonek";s:3:"-93";s:5:"Aring";s:3:"-93";s:6:"Atilde";s:3:"-93";s:1:"O";s:3:"-18";s:6:"Oacute";s:3:"-18";s:11:"Ocircumflex";s:3:"-18";s:9:"Odieresis";s:3:"-18";s:6:"Ograve";s:3:"-18";s:13:"Ohungarumlaut";s:3:"-18";s:7:"Omacron";s:3:"-18";s:6:"Oslash";s:3:"-18";s:6:"Otilde";s:3:"-18";s:1:"a";s:3:"-80";s:6:"aacute";s:3:"-80";s:6:"abreve";s:3:"-80";s:11:"acircumflex";s:3:"-80";s:9:"adieresis";s:3:"-40";s:6:"agrave";s:3:"-40";s:7:"amacron";s:3:"-40";s:7:"aogonek";s:3:"-80";s:5:"aring";s:3:"-80";s:6:"atilde";s:3:"-40";s:5:"colon";s:3:"-50";s:5:"comma";s:3:"-74";s:1:"e";s:3:"-70";s:6:"eacute";s:3:"-70";s:6:"ecaron";s:3:"-70";s:11:"ecircumflex";s:3:"-30";s:9:"edieresis";s:3:"-30";s:10:"edotaccent";s:3:"-70";s:6:"egrave";s:3:"-30";s:7:"emacron";s:3:"-70";s:7:"eogonek";s:3:"-70";s:6:"hyphen";s:3:"-92";s:1:"i";s:3:"-35";s:6:"iacute";s:3:"-35";s:7:"iogonek";s:3:"-35";s:1:"o";s:3:"-80";s:6:"oacute";s:3:"-80";s:11:"ocircumflex";s:3:"-80";s:9:"odieresis";s:3:"-80";s:6:"ograve";s:3:"-80";s:13:"ohungarumlaut";s:3:"-80";s:7:"omacron";s:3:"-80";s:6:"oslash";s:3:"-80";s:6:"otilde";s:3:"-80";s:6:"period";s:3:"-74";s:1:"r";s:3:"-35";s:6:"racute";s:3:"-35";s:6:"rcaron";s:3:"-35";s:12:"rcommaaccent";s:3:"-35";s:9:"semicolon";s:3:"-55";s:1:"u";s:3:"-45";s:6:"uacute";s:3:"-45";s:11:"ucircumflex";s:3:"-45";s:9:"udieresis";s:3:"-45";s:6:"ugrave";s:3:"-45";s:13:"uhungarumlaut";s:3:"-45";s:7:"umacron";s:3:"-45";s:7:"uogonek";s:3:"-45";s:5:"uring";s:3:"-45";s:1:"w";s:3:"-80";s:1:"y";s:3:"-80";s:6:"yacute";s:3:"-80";s:9:"ydieresis";s:3:"-80";}s:1:"U";a:10:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";}s:6:"Uacute";a:10:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";}s:11:"Ucircumflex";a:10:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";}s:9:"Udieresis";a:10:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";}s:6:"Ugrave";a:10:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";}s:13:"Uhungarumlaut";a:10:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";}s:7:"Umacron";a:10:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";}s:7:"Uogonek";a:10:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";}s:5:"Uring";a:10:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";}s:1:"V";a:71:{s:1:"A";s:4:"-135";s:6:"Aacute";s:4:"-135";s:6:"Abreve";s:4:"-135";s:11:"Acircumflex";s:4:"-135";s:9:"Adieresis";s:4:"-135";s:6:"Agrave";s:4:"-135";s:7:"Amacron";s:4:"-135";s:7:"Aogonek";s:4:"-135";s:5:"Aring";s:4:"-135";s:6:"Atilde";s:4:"-135";s:1:"G";s:3:"-15";s:6:"Gbreve";s:3:"-15";s:12:"Gcommaaccent";s:3:"-15";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"a";s:4:"-111";s:6:"aacute";s:4:"-111";s:6:"abreve";s:4:"-111";s:11:"acircumflex";s:3:"-71";s:9:"adieresis";s:3:"-71";s:6:"agrave";s:3:"-71";s:7:"amacron";s:3:"-71";s:7:"aogonek";s:4:"-111";s:5:"aring";s:4:"-111";s:6:"atilde";s:3:"-71";s:5:"colon";s:3:"-74";s:5:"comma";s:4:"-129";s:1:"e";s:4:"-111";s:6:"eacute";s:4:"-111";s:6:"ecaron";s:3:"-71";s:11:"ecircumflex";s:3:"-71";s:9:"edieresis";s:3:"-71";s:10:"edotaccent";s:4:"-111";s:6:"egrave";s:3:"-71";s:7:"emacron";s:3:"-71";s:7:"eogonek";s:4:"-111";s:6:"hyphen";s:4:"-100";s:1:"i";s:3:"-60";s:6:"iacute";s:3:"-60";s:11:"icircumflex";s:3:"-20";s:9:"idieresis";s:3:"-20";s:6:"igrave";s:3:"-20";s:7:"imacron";s:3:"-20";s:7:"iogonek";s:3:"-60";s:1:"o";s:4:"-129";s:6:"oacute";s:4:"-129";s:11:"ocircumflex";s:4:"-129";s:9:"odieresis";s:3:"-89";s:6:"ograve";s:3:"-89";s:13:"ohungarumlaut";s:4:"-129";s:7:"omacron";s:3:"-89";s:6:"oslash";s:4:"-129";s:6:"otilde";s:3:"-89";s:6:"period";s:4:"-129";s:9:"semicolon";s:3:"-74";s:1:"u";s:3:"-75";s:6:"uacute";s:3:"-75";s:11:"ucircumflex";s:3:"-75";s:9:"udieresis";s:3:"-75";s:6:"ugrave";s:3:"-75";s:13:"uhungarumlaut";s:3:"-75";s:7:"umacron";s:3:"-75";s:7:"uogonek";s:3:"-75";s:5:"uring";s:3:"-75";}s:1:"W";a:67:{s:1:"A";s:4:"-120";s:6:"Aacute";s:4:"-120";s:6:"Abreve";s:4:"-120";s:11:"Acircumflex";s:4:"-120";s:9:"Adieresis";s:4:"-120";s:6:"Agrave";s:4:"-120";s:7:"Amacron";s:4:"-120";s:7:"Aogonek";s:4:"-120";s:5:"Aring";s:4:"-120";s:6:"Atilde";s:4:"-120";s:1:"O";s:3:"-10";s:6:"Oacute";s:3:"-10";s:11:"Ocircumflex";s:3:"-10";s:9:"Odieresis";s:3:"-10";s:6:"Ograve";s:3:"-10";s:13:"Ohungarumlaut";s:3:"-10";s:7:"Omacron";s:3:"-10";s:6:"Oslash";s:3:"-10";s:6:"Otilde";s:3:"-10";s:1:"a";s:3:"-80";s:6:"aacute";s:3:"-80";s:6:"abreve";s:3:"-80";s:11:"acircumflex";s:3:"-80";s:9:"adieresis";s:3:"-80";s:6:"agrave";s:3:"-80";s:7:"amacron";s:3:"-80";s:7:"aogonek";s:3:"-80";s:5:"aring";s:3:"-80";s:6:"atilde";s:3:"-80";s:5:"colon";s:3:"-37";s:5:"comma";s:3:"-92";s:1:"e";s:3:"-80";s:6:"eacute";s:3:"-80";s:6:"ecaron";s:3:"-80";s:11:"ecircumflex";s:3:"-80";s:9:"edieresis";s:3:"-40";s:10:"edotaccent";s:3:"-80";s:6:"egrave";s:3:"-40";s:7:"emacron";s:3:"-40";s:7:"eogonek";s:3:"-80";s:6:"hyphen";s:3:"-65";s:1:"i";s:3:"-40";s:6:"iacute";s:3:"-40";s:7:"iogonek";s:3:"-40";s:1:"o";s:3:"-80";s:6:"oacute";s:3:"-80";s:11:"ocircumflex";s:3:"-80";s:9:"odieresis";s:3:"-80";s:6:"ograve";s:3:"-80";s:13:"ohungarumlaut";s:3:"-80";s:7:"omacron";s:3:"-80";s:6:"oslash";s:3:"-80";s:6:"otilde";s:3:"-80";s:6:"period";s:3:"-92";s:9:"semicolon";s:3:"-37";s:1:"u";s:3:"-50";s:6:"uacute";s:3:"-50";s:11:"ucircumflex";s:3:"-50";s:9:"udieresis";s:3:"-50";s:6:"ugrave";s:3:"-50";s:13:"uhungarumlaut";s:3:"-50";s:7:"umacron";s:3:"-50";s:7:"uogonek";s:3:"-50";s:5:"uring";s:3:"-50";s:1:"y";s:3:"-73";s:6:"yacute";s:3:"-73";s:9:"ydieresis";s:3:"-73";}s:1:"Y";a:64:{s:1:"A";s:4:"-120";s:6:"Aacute";s:4:"-120";s:6:"Abreve";s:4:"-120";s:11:"Acircumflex";s:4:"-120";s:9:"Adieresis";s:4:"-120";s:6:"Agrave";s:4:"-120";s:7:"Amacron";s:4:"-120";s:7:"Aogonek";s:4:"-120";s:5:"Aring";s:4:"-120";s:6:"Atilde";s:4:"-120";s:1:"O";s:3:"-30";s:6:"Oacute";s:3:"-30";s:11:"Ocircumflex";s:3:"-30";s:9:"Odieresis";s:3:"-30";s:6:"Ograve";s:3:"-30";s:13:"Ohungarumlaut";s:3:"-30";s:7:"Omacron";s:3:"-30";s:6:"Oslash";s:3:"-30";s:6:"Otilde";s:3:"-30";s:1:"a";s:4:"-100";s:6:"aacute";s:4:"-100";s:6:"abreve";s:4:"-100";s:11:"acircumflex";s:4:"-100";s:9:"adieresis";s:3:"-60";s:6:"agrave";s:3:"-60";s:7:"amacron";s:3:"-60";s:7:"aogonek";s:4:"-100";s:5:"aring";s:4:"-100";s:6:"atilde";s:3:"-60";s:5:"colon";s:3:"-92";s:5:"comma";s:4:"-129";s:1:"e";s:4:"-100";s:6:"eacute";s:4:"-100";s:6:"ecaron";s:4:"-100";s:11:"ecircumflex";s:4:"-100";s:9:"edieresis";s:3:"-60";s:10:"edotaccent";s:4:"-100";s:6:"egrave";s:3:"-60";s:7:"emacron";s:3:"-60";s:7:"eogonek";s:4:"-100";s:6:"hyphen";s:4:"-111";s:1:"i";s:3:"-55";s:6:"iacute";s:3:"-55";s:7:"iogonek";s:3:"-55";s:1:"o";s:4:"-110";s:6:"oacute";s:4:"-110";s:11:"ocircumflex";s:4:"-110";s:9:"odieresis";s:3:"-70";s:6:"ograve";s:3:"-70";s:13:"ohungarumlaut";s:4:"-110";s:7:"omacron";s:3:"-70";s:6:"oslash";s:4:"-110";s:6:"otilde";s:3:"-70";s:6:"period";s:4:"-129";s:9:"semicolon";s:3:"-92";s:1:"u";s:4:"-111";s:6:"uacute";s:4:"-111";s:11:"ucircumflex";s:4:"-111";s:9:"udieresis";s:3:"-71";s:6:"ugrave";s:3:"-71";s:13:"uhungarumlaut";s:4:"-111";s:7:"umacron";s:3:"-71";s:7:"uogonek";s:4:"-111";s:5:"uring";s:4:"-111";}s:6:"Yacute";a:64:{s:1:"A";s:4:"-120";s:6:"Aacute";s:4:"-120";s:6:"Abreve";s:4:"-120";s:11:"Acircumflex";s:4:"-120";s:9:"Adieresis";s:4:"-120";s:6:"Agrave";s:4:"-120";s:7:"Amacron";s:4:"-120";s:7:"Aogonek";s:4:"-120";s:5:"Aring";s:4:"-120";s:6:"Atilde";s:4:"-120";s:1:"O";s:3:"-30";s:6:"Oacute";s:3:"-30";s:11:"Ocircumflex";s:3:"-30";s:9:"Odieresis";s:3:"-30";s:6:"Ograve";s:3:"-30";s:13:"Ohungarumlaut";s:3:"-30";s:7:"Omacron";s:3:"-30";s:6:"Oslash";s:3:"-30";s:6:"Otilde";s:3:"-30";s:1:"a";s:4:"-100";s:6:"aacute";s:4:"-100";s:6:"abreve";s:4:"-100";s:11:"acircumflex";s:4:"-100";s:9:"adieresis";s:3:"-60";s:6:"agrave";s:3:"-60";s:7:"amacron";s:3:"-60";s:7:"aogonek";s:4:"-100";s:5:"aring";s:4:"-100";s:6:"atilde";s:3:"-60";s:5:"colon";s:3:"-92";s:5:"comma";s:4:"-129";s:1:"e";s:4:"-100";s:6:"eacute";s:4:"-100";s:6:"ecaron";s:4:"-100";s:11:"ecircumflex";s:4:"-100";s:9:"edieresis";s:3:"-60";s:10:"edotaccent";s:4:"-100";s:6:"egrave";s:3:"-60";s:7:"emacron";s:3:"-60";s:7:"eogonek";s:4:"-100";s:6:"hyphen";s:4:"-111";s:1:"i";s:3:"-55";s:6:"iacute";s:3:"-55";s:7:"iogonek";s:3:"-55";s:1:"o";s:4:"-110";s:6:"oacute";s:4:"-110";s:11:"ocircumflex";s:4:"-110";s:9:"odieresis";s:3:"-70";s:6:"ograve";s:3:"-70";s:13:"ohungarumlaut";s:4:"-110";s:7:"omacron";s:3:"-70";s:6:"oslash";s:4:"-110";s:6:"otilde";s:3:"-70";s:6:"period";s:4:"-129";s:9:"semicolon";s:3:"-92";s:1:"u";s:4:"-111";s:6:"uacute";s:4:"-111";s:11:"ucircumflex";s:4:"-111";s:9:"udieresis";s:3:"-71";s:6:"ugrave";s:3:"-71";s:13:"uhungarumlaut";s:4:"-111";s:7:"umacron";s:3:"-71";s:7:"uogonek";s:4:"-111";s:5:"uring";s:4:"-111";}s:9:"Ydieresis";a:64:{s:1:"A";s:4:"-120";s:6:"Aacute";s:4:"-120";s:6:"Abreve";s:4:"-120";s:11:"Acircumflex";s:4:"-120";s:9:"Adieresis";s:4:"-120";s:6:"Agrave";s:4:"-120";s:7:"Amacron";s:4:"-120";s:7:"Aogonek";s:4:"-120";s:5:"Aring";s:4:"-120";s:6:"Atilde";s:4:"-120";s:1:"O";s:3:"-30";s:6:"Oacute";s:3:"-30";s:11:"Ocircumflex";s:3:"-30";s:9:"Odieresis";s:3:"-30";s:6:"Ograve";s:3:"-30";s:13:"Ohungarumlaut";s:3:"-30";s:7:"Omacron";s:3:"-30";s:6:"Oslash";s:3:"-30";s:6:"Otilde";s:3:"-30";s:1:"a";s:4:"-100";s:6:"aacute";s:4:"-100";s:6:"abreve";s:4:"-100";s:11:"acircumflex";s:4:"-100";s:9:"adieresis";s:3:"-60";s:6:"agrave";s:3:"-60";s:7:"amacron";s:3:"-60";s:7:"aogonek";s:4:"-100";s:5:"aring";s:4:"-100";s:6:"atilde";s:4:"-100";s:5:"colon";s:3:"-92";s:5:"comma";s:4:"-129";s:1:"e";s:4:"-100";s:6:"eacute";s:4:"-100";s:6:"ecaron";s:4:"-100";s:11:"ecircumflex";s:4:"-100";s:9:"edieresis";s:3:"-60";s:10:"edotaccent";s:4:"-100";s:6:"egrave";s:3:"-60";s:7:"emacron";s:3:"-60";s:7:"eogonek";s:4:"-100";s:6:"hyphen";s:4:"-111";s:1:"i";s:3:"-55";s:6:"iacute";s:3:"-55";s:7:"iogonek";s:3:"-55";s:1:"o";s:4:"-110";s:6:"oacute";s:4:"-110";s:11:"ocircumflex";s:4:"-110";s:9:"odieresis";s:3:"-70";s:6:"ograve";s:3:"-70";s:13:"ohungarumlaut";s:4:"-110";s:7:"omacron";s:3:"-70";s:6:"oslash";s:4:"-110";s:6:"otilde";s:3:"-70";s:6:"period";s:4:"-129";s:9:"semicolon";s:3:"-92";s:1:"u";s:4:"-111";s:6:"uacute";s:4:"-111";s:11:"ucircumflex";s:4:"-111";s:9:"udieresis";s:3:"-71";s:6:"ugrave";s:3:"-71";s:13:"uhungarumlaut";s:4:"-111";s:7:"umacron";s:3:"-71";s:7:"uogonek";s:4:"-111";s:5:"uring";s:4:"-111";}s:1:"a";a:2:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-15";}s:6:"aacute";a:2:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-15";}s:6:"abreve";a:2:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-15";}s:11:"acircumflex";a:2:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-15";}s:9:"adieresis";a:2:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-15";}s:6:"agrave";a:2:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-15";}s:7:"amacron";a:2:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-15";}s:7:"aogonek";a:2:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-15";}s:5:"aring";a:2:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-15";}s:6:"atilde";a:2:{s:1:"v";s:3:"-20";s:1:"w";s:3:"-15";}s:1:"b";a:11:{s:6:"period";s:3:"-40";s:1:"u";s:3:"-20";s:6:"uacute";s:3:"-20";s:11:"ucircumflex";s:3:"-20";s:9:"udieresis";s:3:"-20";s:6:"ugrave";s:3:"-20";s:13:"uhungarumlaut";s:3:"-20";s:7:"umacron";s:3:"-20";s:7:"uogonek";s:3:"-20";s:5:"uring";s:3:"-20";s:1:"v";s:3:"-15";}s:1:"c";a:3:{s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:6:"cacute";a:3:{s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:6:"ccaron";a:3:{s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:8:"ccedilla";a:3:{s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:5:"comma";a:2:{s:13:"quotedblright";s:3:"-70";s:10:"quoteright";s:3:"-70";}s:1:"e";a:9:{s:1:"g";s:3:"-15";s:6:"gbreve";s:3:"-15";s:12:"gcommaaccent";s:3:"-15";s:1:"v";s:3:"-25";s:1:"w";s:3:"-25";s:1:"x";s:3:"-15";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:6:"eacute";a:9:{s:1:"g";s:3:"-15";s:6:"gbreve";s:3:"-15";s:12:"gcommaaccent";s:3:"-15";s:1:"v";s:3:"-25";s:1:"w";s:3:"-25";s:1:"x";s:3:"-15";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:6:"ecaron";a:9:{s:1:"g";s:3:"-15";s:6:"gbreve";s:3:"-15";s:12:"gcommaaccent";s:3:"-15";s:1:"v";s:3:"-25";s:1:"w";s:3:"-25";s:1:"x";s:3:"-15";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:11:"ecircumflex";a:9:{s:1:"g";s:3:"-15";s:6:"gbreve";s:3:"-15";s:12:"gcommaaccent";s:3:"-15";s:1:"v";s:3:"-25";s:1:"w";s:3:"-25";s:1:"x";s:3:"-15";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:9:"edieresis";a:9:{s:1:"g";s:3:"-15";s:6:"gbreve";s:3:"-15";s:12:"gcommaaccent";s:3:"-15";s:1:"v";s:3:"-25";s:1:"w";s:3:"-25";s:1:"x";s:3:"-15";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:10:"edotaccent";a:9:{s:1:"g";s:3:"-15";s:6:"gbreve";s:3:"-15";s:12:"gcommaaccent";s:3:"-15";s:1:"v";s:3:"-25";s:1:"w";s:3:"-25";s:1:"x";s:3:"-15";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:6:"egrave";a:9:{s:1:"g";s:3:"-15";s:6:"gbreve";s:3:"-15";s:12:"gcommaaccent";s:3:"-15";s:1:"v";s:3:"-25";s:1:"w";s:3:"-25";s:1:"x";s:3:"-15";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:7:"emacron";a:9:{s:1:"g";s:3:"-15";s:6:"gbreve";s:3:"-15";s:12:"gcommaaccent";s:3:"-15";s:1:"v";s:3:"-25";s:1:"w";s:3:"-25";s:1:"x";s:3:"-15";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:7:"eogonek";a:9:{s:1:"g";s:3:"-15";s:6:"gbreve";s:3:"-15";s:12:"gcommaaccent";s:3:"-15";s:1:"v";s:3:"-25";s:1:"w";s:3:"-25";s:1:"x";s:3:"-15";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:1:"f";a:15:{s:1:"a";s:3:"-10";s:6:"aacute";s:3:"-10";s:6:"abreve";s:3:"-10";s:11:"acircumflex";s:3:"-10";s:9:"adieresis";s:3:"-10";s:6:"agrave";s:3:"-10";s:7:"amacron";s:3:"-10";s:7:"aogonek";s:3:"-10";s:5:"aring";s:3:"-10";s:6:"atilde";s:3:"-10";s:8:"dotlessi";s:3:"-50";s:1:"f";s:3:"-25";s:1:"i";s:3:"-20";s:6:"iacute";s:3:"-20";s:10:"quoteright";s:2:"55";}s:1:"g";a:10:{s:1:"a";s:2:"-5";s:6:"aacute";s:2:"-5";s:6:"abreve";s:2:"-5";s:11:"acircumflex";s:2:"-5";s:9:"adieresis";s:2:"-5";s:6:"agrave";s:2:"-5";s:7:"amacron";s:2:"-5";s:7:"aogonek";s:2:"-5";s:5:"aring";s:2:"-5";s:6:"atilde";s:2:"-5";}s:6:"gbreve";a:10:{s:1:"a";s:2:"-5";s:6:"aacute";s:2:"-5";s:6:"abreve";s:2:"-5";s:11:"acircumflex";s:2:"-5";s:9:"adieresis";s:2:"-5";s:6:"agrave";s:2:"-5";s:7:"amacron";s:2:"-5";s:7:"aogonek";s:2:"-5";s:5:"aring";s:2:"-5";s:6:"atilde";s:2:"-5";}s:12:"gcommaaccent";a:10:{s:1:"a";s:2:"-5";s:6:"aacute";s:2:"-5";s:6:"abreve";s:2:"-5";s:11:"acircumflex";s:2:"-5";s:9:"adieresis";s:2:"-5";s:6:"agrave";s:2:"-5";s:7:"amacron";s:2:"-5";s:7:"aogonek";s:2:"-5";s:5:"aring";s:2:"-5";s:6:"atilde";s:2:"-5";}s:1:"h";a:3:{s:1:"y";s:2:"-5";s:6:"yacute";s:2:"-5";s:9:"ydieresis";s:2:"-5";}s:1:"i";a:1:{s:1:"v";s:3:"-25";}s:6:"iacute";a:1:{s:1:"v";s:3:"-25";}s:11:"icircumflex";a:1:{s:1:"v";s:3:"-25";}s:9:"idieresis";a:1:{s:1:"v";s:3:"-25";}s:6:"igrave";a:1:{s:1:"v";s:3:"-25";}s:7:"imacron";a:1:{s:1:"v";s:3:"-25";}s:7:"iogonek";a:1:{s:1:"v";s:3:"-25";}s:1:"k";a:21:{s:1:"e";s:3:"-10";s:6:"eacute";s:3:"-10";s:6:"ecaron";s:3:"-10";s:11:"ecircumflex";s:3:"-10";s:9:"edieresis";s:3:"-10";s:10:"edotaccent";s:3:"-10";s:6:"egrave";s:3:"-10";s:7:"emacron";s:3:"-10";s:7:"eogonek";s:3:"-10";s:1:"o";s:3:"-10";s:6:"oacute";s:3:"-10";s:11:"ocircumflex";s:3:"-10";s:9:"odieresis";s:3:"-10";s:6:"ograve";s:3:"-10";s:13:"ohungarumlaut";s:3:"-10";s:7:"omacron";s:3:"-10";s:6:"oslash";s:3:"-10";s:6:"otilde";s:3:"-10";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:12:"kcommaaccent";a:21:{s:1:"e";s:3:"-10";s:6:"eacute";s:3:"-10";s:6:"ecaron";s:3:"-10";s:11:"ecircumflex";s:3:"-10";s:9:"edieresis";s:3:"-10";s:10:"edotaccent";s:3:"-10";s:6:"egrave";s:3:"-10";s:7:"emacron";s:3:"-10";s:7:"eogonek";s:3:"-10";s:1:"o";s:3:"-10";s:6:"oacute";s:3:"-10";s:11:"ocircumflex";s:3:"-10";s:9:"odieresis";s:3:"-10";s:6:"ograve";s:3:"-10";s:13:"ohungarumlaut";s:3:"-10";s:7:"omacron";s:3:"-10";s:6:"oslash";s:3:"-10";s:6:"otilde";s:3:"-10";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:1:"l";a:1:{s:1:"w";s:3:"-10";}s:6:"lacute";a:1:{s:1:"w";s:3:"-10";}s:12:"lcommaaccent";a:1:{s:1:"w";s:3:"-10";}s:6:"lslash";a:1:{s:1:"w";s:3:"-10";}s:1:"n";a:4:{s:1:"v";s:3:"-40";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:6:"nacute";a:4:{s:1:"v";s:3:"-40";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:6:"ncaron";a:4:{s:1:"v";s:3:"-40";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:12:"ncommaaccent";a:4:{s:1:"v";s:3:"-40";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:6:"ntilde";a:4:{s:1:"v";s:3:"-40";s:1:"y";s:3:"-15";s:6:"yacute";s:3:"-15";s:9:"ydieresis";s:3:"-15";}s:1:"o";a:5:{s:1:"v";s:3:"-15";s:1:"w";s:3:"-25";s:1:"y";s:3:"-10";s:6:"yacute";s:3:"-10";s:9:"ydieresis";s:3:"-10";}s:6:"oacute";a:5:{s:1:"v";s:3:"-15";s:1:"w";s:3:"-25";s:1:"y";s:3:"-10";s:6:"yacute";s:3:"-10";s:9:"ydieresis";s:3:"-10";}s:11:"ocircumflex";a:5:{s:1:"v";s:3:"-15";s:1:"w";s:3:"-25";s:1:"y";s:3:"-10";s:6:"yacute";s:3:"-10";s:9:"ydieresis";s:3:"-10";}s:9:"odieresis";a:5:{s:1:"v";s:3:"-15";s:1:"w";s:3:"-25";s:1:"y";s:3:"-10";s:6:"yacute";s:3:"-10";s:9:"ydieresis";s:3:"-10";}s:6:"ograve";a:5:{s:1:"v";s:3:"-15";s:1:"w";s:3:"-25";s:1:"y";s:3:"-10";s:6:"yacute";s:3:"-10";s:9:"ydieresis";s:3:"-10";}s:13:"ohungarumlaut";a:5:{s:1:"v";s:3:"-15";s:1:"w";s:3:"-25";s:1:"y";s:3:"-10";s:6:"yacute";s:3:"-10";s:9:"ydieresis";s:3:"-10";}s:7:"omacron";a:5:{s:1:"v";s:3:"-15";s:1:"w";s:3:"-25";s:1:"y";s:3:"-10";s:6:"yacute";s:3:"-10";s:9:"ydieresis";s:3:"-10";}s:6:"oslash";a:5:{s:1:"v";s:3:"-15";s:1:"w";s:3:"-25";s:1:"y";s:3:"-10";s:6:"yacute";s:3:"-10";s:9:"ydieresis";s:3:"-10";}s:6:"otilde";a:5:{s:1:"v";s:3:"-15";s:1:"w";s:3:"-25";s:1:"y";s:3:"-10";s:6:"yacute";s:3:"-10";s:9:"ydieresis";s:3:"-10";}s:1:"p";a:3:{s:1:"y";s:3:"-10";s:6:"yacute";s:3:"-10";s:9:"ydieresis";s:3:"-10";}s:6:"period";a:2:{s:13:"quotedblright";s:3:"-70";s:10:"quoteright";s:3:"-70";}s:12:"quotedblleft";a:10:{s:1:"A";s:3:"-80";s:6:"Aacute";s:3:"-80";s:6:"Abreve";s:3:"-80";s:11:"Acircumflex";s:3:"-80";s:9:"Adieresis";s:3:"-80";s:6:"Agrave";s:3:"-80";s:7:"Amacron";s:3:"-80";s:7:"Aogonek";s:3:"-80";s:5:"Aring";s:3:"-80";s:6:"Atilde";s:3:"-80";}s:9:"quoteleft";a:11:{s:1:"A";s:3:"-80";s:6:"Aacute";s:3:"-80";s:6:"Abreve";s:3:"-80";s:11:"Acircumflex";s:3:"-80";s:9:"Adieresis";s:3:"-80";s:6:"Agrave";s:3:"-80";s:7:"Amacron";s:3:"-80";s:7:"Aogonek";s:3:"-80";s:5:"Aring";s:3:"-80";s:6:"Atilde";s:3:"-80";s:9:"quoteleft";s:3:"-74";}s:10:"quoteright";a:20:{s:1:"d";s:3:"-50";s:6:"dcroat";s:3:"-50";s:1:"l";s:3:"-10";s:6:"lacute";s:3:"-10";s:12:"lcommaaccent";s:3:"-10";s:6:"lslash";s:3:"-10";s:10:"quoteright";s:3:"-74";s:1:"r";s:3:"-50";s:6:"racute";s:3:"-50";s:6:"rcaron";s:3:"-50";s:12:"rcommaaccent";s:3:"-50";s:1:"s";s:3:"-55";s:6:"sacute";s:3:"-55";s:6:"scaron";s:3:"-55";s:8:"scedilla";s:3:"-55";s:12:"scommaaccent";s:3:"-55";s:5:"space";s:3:"-74";s:1:"t";s:3:"-18";s:12:"tcommaaccent";s:3:"-18";s:1:"v";s:3:"-50";}s:1:"r";a:6:{s:5:"comma";s:3:"-40";s:1:"g";s:3:"-18";s:6:"gbreve";s:3:"-18";s:12:"gcommaaccent";s:3:"-18";s:6:"hyphen";s:3:"-20";s:6:"period";s:3:"-55";}s:6:"racute";a:6:{s:5:"comma";s:3:"-40";s:1:"g";s:3:"-18";s:6:"gbreve";s:3:"-18";s:12:"gcommaaccent";s:3:"-18";s:6:"hyphen";s:3:"-20";s:6:"period";s:3:"-55";}s:6:"rcaron";a:6:{s:5:"comma";s:3:"-40";s:1:"g";s:3:"-18";s:6:"gbreve";s:3:"-18";s:12:"gcommaaccent";s:3:"-18";s:6:"hyphen";s:3:"-20";s:6:"period";s:3:"-55";}s:12:"rcommaaccent";a:6:{s:5:"comma";s:3:"-40";s:1:"g";s:3:"-18";s:6:"gbreve";s:3:"-18";s:12:"gcommaaccent";s:3:"-18";s:6:"hyphen";s:3:"-20";s:6:"period";s:3:"-55";}s:5:"space";a:18:{s:1:"A";s:3:"-55";s:6:"Aacute";s:3:"-55";s:6:"Abreve";s:3:"-55";s:11:"Acircumflex";s:3:"-55";s:9:"Adieresis";s:3:"-55";s:6:"Agrave";s:3:"-55";s:7:"Amacron";s:3:"-55";s:7:"Aogonek";s:3:"-55";s:5:"Aring";s:3:"-55";s:6:"Atilde";s:3:"-55";s:1:"T";s:3:"-18";s:6:"Tcaron";s:3:"-18";s:12:"Tcommaaccent";s:3:"-18";s:1:"V";s:3:"-50";s:1:"W";s:3:"-30";s:1:"Y";s:3:"-90";s:6:"Yacute";s:3:"-90";s:9:"Ydieresis";s:3:"-90";}s:1:"v";a:30:{s:1:"a";s:3:"-25";s:6:"aacute";s:3:"-25";s:6:"abreve";s:3:"-25";s:11:"acircumflex";s:3:"-25";s:9:"adieresis";s:3:"-25";s:6:"agrave";s:3:"-25";s:7:"amacron";s:3:"-25";s:7:"aogonek";s:3:"-25";s:5:"aring";s:3:"-25";s:6:"atilde";s:3:"-25";s:5:"comma";s:3:"-65";s:1:"e";s:3:"-15";s:6:"eacute";s:3:"-15";s:6:"ecaron";s:3:"-15";s:11:"ecircumflex";s:3:"-15";s:9:"edieresis";s:3:"-15";s:10:"edotaccent";s:3:"-15";s:6:"egrave";s:3:"-15";s:7:"emacron";s:3:"-15";s:7:"eogonek";s:3:"-15";s:1:"o";s:3:"-20";s:6:"oacute";s:3:"-20";s:11:"ocircumflex";s:3:"-20";s:9:"odieresis";s:3:"-20";s:6:"ograve";s:3:"-20";s:13:"ohungarumlaut";s:3:"-20";s:7:"omacron";s:3:"-20";s:6:"oslash";s:3:"-20";s:6:"otilde";s:3:"-20";s:6:"period";s:3:"-65";}s:1:"w";a:21:{s:1:"a";s:3:"-10";s:6:"aacute";s:3:"-10";s:6:"abreve";s:3:"-10";s:11:"acircumflex";s:3:"-10";s:9:"adieresis";s:3:"-10";s:6:"agrave";s:3:"-10";s:7:"amacron";s:3:"-10";s:7:"aogonek";s:3:"-10";s:5:"aring";s:3:"-10";s:6:"atilde";s:3:"-10";s:5:"comma";s:3:"-65";s:1:"o";s:3:"-10";s:6:"oacute";s:3:"-10";s:11:"ocircumflex";s:3:"-10";s:9:"odieresis";s:3:"-10";s:6:"ograve";s:3:"-10";s:13:"ohungarumlaut";s:3:"-10";s:7:"omacron";s:3:"-10";s:6:"oslash";s:3:"-10";s:6:"otilde";s:3:"-10";s:6:"period";s:3:"-65";}s:1:"x";a:9:{s:1:"e";s:3:"-15";s:6:"eacute";s:3:"-15";s:6:"ecaron";s:3:"-15";s:11:"ecircumflex";s:3:"-15";s:9:"edieresis";s:3:"-15";s:10:"edotaccent";s:3:"-15";s:6:"egrave";s:3:"-15";s:7:"emacron";s:3:"-15";s:7:"eogonek";s:3:"-15";}s:1:"y";a:2:{s:5:"comma";s:3:"-65";s:6:"period";s:3:"-65";}s:6:"yacute";a:2:{s:5:"comma";s:3:"-65";s:6:"period";s:3:"-65";}s:9:"ydieresis";a:2:{s:5:"comma";s:3:"-65";s:6:"period";s:3:"-65";}}s:9:"_version_";i:1;}
\ No newline at end of file
Added: trunk/mapbender/http/classes/fonts/php_a0100131.afm
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/fonts/php_a0100131.afm?view=auto&rev=13
--- (empty file)
+++ trunk/mapbender/http/classes/fonts/php_a0100131.afm 2006-04-13 19:38:28+0000
@@ -0,0 +1 @@
+a:19:{s:8:"FontName";s:15:"URWGothicL-Book";s:8:"FullName";s:17:"URW Gothic L Book";s:10:"FamilyName";s:12:"URW Gothic L";s:6:"Weight";s:4:"Book";s:11:"ItalicAngle";s:3:"0.0";s:12:"IsFixedPitch";s:5:"false";s:17:"UnderlinePosition";s:3:"-96";s:18:"UnderlineThickness";s:2:"58";s:7:"Version";s:4:"1.05";s:14:"EncodingScheme";s:21:"AdobeStandardEncoding";s:8:"FontBBox";a:4:{i:0;s:4:"-115";i:1;s:4:"-240";i:2;s:4:"1151";i:3;s:3:"976";}s:9:"CapHeight";s:3:"739";s:7:"XHeight";s:3:"547";s:9:"Descender";s:4:"-192";s:8:"Ascender";s:3:"739";s:16:"StartCharMetrics";s:3:"316";s:1:"C";a:465:{i:32;a:4:{s:1:"C";s:2:"32";s:2:"WX";s:3:"277";s:1:"N";s:5:"space";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}s:5:"space";a:4:{s:1:"C";s:2:"32";s:2:"WX";s:3:"277";s:1:"N";s:5:"space";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}i:33;a:4:{s:1:"C";s:2:"33";s:2:"WX";s:3:"295";s:1:"N";s:6:"exclam";s:1:"B";a:4:{i:0;s:3:"111";i:1;s:1:"0";i:2;s:3:"185";i:3;s:3:"739";}}s:6:"exclam";a:4:{s:1:"C";s:2:"33";s:2:"WX";s:3:"295";s:1:"N";s:6:"exclam";s:1:"B";a:4:{i:0;s:3:"111";i:1;s:1:"0";i:2;s:3:"185";i:3;s:3:"739";}}i:34;a:4:{s:1:"C";s:2:"34";s:2:"WX";s:3:"309";s:1:"N";s:8:"quotedbl";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"513";i:2;s:3:"237";i:3;s:3:"739";}}s:8:"quotedbl";a:4:{s:1:"C";s:2:"34";s:2:"WX";s:3:"309";s:1:"N";s:8:"quotedbl";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"513";i:2;s:3:"237";i:3;s:3:"739";}}i:35;a:4:{s:1:"C";s:2:"35";s:2:"WX";s:3:"554";s:1:"N";s:10:"numbersign";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:1:"0";i:2;s:3:"549";i:3;s:3:"739";}}s:10:"numbersign";a:4:{s:1:"C";s:2:"35";s:2:"WX";s:3:"554";s:1:"N";s:10:"numbersign";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:1:"0";i:2;s:3:"549";i:3;s:3:"739";}}i:36;a:4:{s:1:"C";s:2:"36";s:2:"WX";s:3:"554";s:1:"N";s:6:"dollar";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:3:"-56";i:2;s:3:"479";i:3;s:3:"810";}}s:6:"dollar";a:4:{s:1:"C";s:2:"36";s:2:"WX";s:3:"554";s:1:"N";s:6:"dollar";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:3:"-56";i:2;s:3:"479";i:3;s:3:"810";}}i:37;a:4:{s:1:"C";s:2:"37";s:2:"WX";s:3:"775";s:1:"N";s:7:"percent";s:1:"B";a:4:{i:0;s:2:"13";i:1;s:3:"-13";i:2;s:3:"752";i:3;s:3:"749";}}s:7:"percent";a:4:{s:1:"C";s:2:"37";s:2:"WX";s:3:"775";s:1:"N";s:7:"percent";s:1:"B";a:4:{i:0;s:2:"13";i:1;s:3:"-13";i:2;s:3:"752";i:3;s:3:"749";}}i:38;a:4:{s:1:"C";s:2:"38";s:2:"WX";s:3:"757";s:1:"N";s:9:"ampersand";s:1:"B";a:4:{i:0;s:2:"57";i:1;s:3:"-13";i:2;s:3:"735";i:3;s:3:"752";}}s:9:"ampersand";a:4:{s:1:"C";s:2:"38";s:2:"WX";s:3:"757";s:1:"N";s:9:"ampersand";s:1:"B";a:4:{i:0;s:2:"57";i:1;s:3:"-13";i:2;s:3:"735";i:3;s:3:"752";}}i:39;a:4:{s:1:"C";s:2:"39";s:2:"WX";s:3:"351";s:1:"N";s:10:"quoteright";s:1:"B";a:4:{i:0;s:2:"91";i:1;s:3:"547";i:2;s:3:"253";i:3;s:3:"739";}}s:10:"quoteright";a:4:{s:1:"C";s:2:"39";s:2:"WX";s:3:"351";s:1:"N";s:10:"quoteright";s:1:"B";a:4:{i:0;s:2:"91";i:1;s:3:"547";i:2;s:3:"253";i:3;s:3:"739";}}i:40;a:4:{s:1:"C";s:2:"40";s:2:"WX";s:3:"369";s:1:"N";s:9:"parenleft";s:1:"B";a:4:{i:0;s:2:"57";i:1;s:4:"-125";i:2;s:3:"335";i:3;s:3:"739";}}s:9:"parenleft";a:4:{s:1:"C";s:2:"40";s:2:"WX";s:3:"369";s:1:"N";s:9:"parenleft";s:1:"B";a:4:{i:0;s:2:"57";i:1;s:4:"-125";i:2;s:3:"335";i:3;s:3:"739";}}i:41;a:4:{s:1:"C";s:2:"41";s:2:"WX";s:3:"369";s:1:"N";s:10:"parenright";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:4:"-125";i:2;s:3:"312";i:3;s:3:"739";}}s:10:"parenright";a:4:{s:1:"C";s:2:"41";s:2:"WX";s:3:"369";s:1:"N";s:10:"parenright";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:4:"-125";i:2;s:3:"312";i:3;s:3:"739";}}i:42;a:4:{s:1:"C";s:2:"42";s:2:"WX";s:3:"425";s:1:"N";s:8:"asterisk";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:3:"468";i:2;s:3:"360";i:3;s:3:"752";}}s:8:"asterisk";a:4:{s:1:"C";s:2:"42";s:2:"WX";s:3:"425";s:1:"N";s:8:"asterisk";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:3:"468";i:2;s:3:"360";i:3;s:3:"752";}}i:43;a:4:{s:1:"C";s:2:"43";s:2:"WX";s:3:"606";s:1:"N";s:4:"plus";s:1:"B";a:4:{i:0;s:2:"51";i:1;s:2:"49";i:2;s:3:"555";i:3;s:3:"557";}}s:4:"plus";a:4:{s:1:"C";s:2:"43";s:2:"WX";s:3:"606";s:1:"N";s:4:"plus";s:1:"B";a:4:{i:0;s:2:"51";i:1;s:2:"49";i:2;s:3:"555";i:3;s:3:"557";}}i:44;a:4:{s:1:"C";s:2:"44";s:2:"WX";s:3:"277";s:1:"N";s:5:"comma";s:1:"B";a:4:{i:0;s:2:"91";i:1;s:3:"-67";i:2;s:3:"253";i:3;s:3:"126";}}s:5:"comma";a:4:{s:1:"C";s:2:"44";s:2:"WX";s:3:"277";s:1:"N";s:5:"comma";s:1:"B";a:4:{i:0;s:2:"91";i:1;s:3:"-67";i:2;s:3:"253";i:3;s:3:"126";}}i:45;a:4:{s:1:"C";s:2:"45";s:2:"WX";s:3:"332";s:1:"N";s:6:"hyphen";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:3:"233";i:2;s:3:"302";i:3;s:3:"296";}}s:6:"hyphen";a:4:{s:1:"C";s:2:"45";s:2:"WX";s:3:"332";s:1:"N";s:6:"hyphen";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:3:"233";i:2;s:3:"302";i:3;s:3:"296";}}i:46;a:4:{s:1:"C";s:2:"46";s:2:"WX";s:3:"277";s:1:"N";s:6:"period";s:1:"B";a:4:{i:0;s:3:"101";i:1;s:1:"0";i:2;s:3:"175";i:3;s:3:"126";}}s:6:"period";a:4:{s:1:"C";s:2:"46";s:2:"WX";s:3:"277";s:1:"N";s:6:"period";s:1:"B";a:4:{i:0;s:3:"101";i:1;s:1:"0";i:2;s:3:"175";i:3;s:3:"126";}}i:47;a:4:{s:1:"C";s:2:"47";s:2:"WX";s:3:"437";s:1:"N";s:5:"slash";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:4:"-128";i:2;s:3:"397";i:3;s:3:"739";}}s:5:"slash";a:4:{s:1:"C";s:2:"47";s:2:"WX";s:3:"437";s:1:"N";s:5:"slash";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:4:"-128";i:2;s:3:"397";i:3;s:3:"739";}}i:48;a:4:{s:1:"C";s:2:"48";s:2:"WX";s:3:"554";s:1:"N";s:4:"zero";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-13";i:2;s:3:"525";i:3;s:3:"752";}}s:4:"zero";a:4:{s:1:"C";s:2:"48";s:2:"WX";s:3:"554";s:1:"N";s:4:"zero";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-13";i:2;s:3:"525";i:3;s:3:"752";}}i:49;a:4:{s:1:"C";s:2:"49";s:2:"WX";s:3:"554";s:1:"N";s:3:"one";s:1:"B";a:4:{i:0;s:3:"155";i:1;s:1:"0";i:2;s:3:"354";i:3;s:3:"739";}}s:3:"one";a:4:{s:1:"C";s:2:"49";s:2:"WX";s:3:"554";s:1:"N";s:3:"one";s:1:"B";a:4:{i:0;s:3:"155";i:1;s:1:"0";i:2;s:3:"354";i:3;s:3:"739";}}i:50;a:4:{s:1:"C";s:2:"50";s:2:"WX";s:3:"554";s:1:"N";s:3:"two";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:1:"0";i:2;s:3:"506";i:3;s:3:"752";}}s:3:"two";a:4:{s:1:"C";s:2:"50";s:2:"WX";s:3:"554";s:1:"N";s:3:"two";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:1:"0";i:2;s:3:"506";i:3;s:3:"752";}}i:51;a:4:{s:1:"C";s:2:"51";s:2:"WX";s:3:"554";s:1:"N";s:5:"three";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:3:"-13";i:2;s:3:"504";i:3;s:3:"752";}}s:5:"three";a:4:{s:1:"C";s:2:"51";s:2:"WX";s:3:"554";s:1:"N";s:5:"three";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:3:"-13";i:2;s:3:"504";i:3;s:3:"752";}}i:52;a:4:{s:1:"C";s:2:"52";s:2:"WX";s:3:"554";s:1:"N";s:4:"four";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"527";i:3;s:3:"739";}}s:4:"four";a:4:{s:1:"C";s:2:"52";s:2:"WX";s:3:"554";s:1:"N";s:4:"four";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"527";i:3;s:3:"739";}}i:53;a:4:{s:1:"C";s:2:"53";s:2:"WX";s:3:"554";s:1:"N";s:4:"five";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:3:"-13";i:2;s:3:"528";i:3;s:3:"739";}}s:4:"five";a:4:{s:1:"C";s:2:"53";s:2:"WX";s:3:"554";s:1:"N";s:4:"five";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:3:"-13";i:2;s:3:"528";i:3;s:3:"739";}}i:54;a:4:{s:1:"C";s:2:"54";s:2:"WX";s:3:"554";s:1:"N";s:3:"six";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-13";i:2;s:3:"529";i:3;s:3:"739";}}s:3:"six";a:4:{s:1:"C";s:2:"54";s:2:"WX";s:3:"554";s:1:"N";s:3:"six";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-13";i:2;s:3:"529";i:3;s:3:"739";}}i:55;a:4:{s:1:"C";s:2:"55";s:2:"WX";s:3:"554";s:1:"N";s:5:"seven";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:1:"0";i:2;s:3:"490";i:3;s:3:"739";}}s:5:"seven";a:4:{s:1:"C";s:2:"55";s:2:"WX";s:3:"554";s:1:"N";s:5:"seven";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:1:"0";i:2;s:3:"490";i:3;s:3:"739";}}i:56;a:4:{s:1:"C";s:2:"56";s:2:"WX";s:3:"554";s:1:"N";s:5:"eight";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"512";i:3;s:3:"752";}}s:5:"eight";a:4:{s:1:"C";s:2:"56";s:2:"WX";s:3:"554";s:1:"N";s:5:"eight";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"512";i:3;s:3:"752";}}i:57;a:4:{s:1:"C";s:2:"57";s:2:"WX";s:3:"554";s:1:"N";s:4:"nine";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"529";i:3;s:3:"752";}}s:4:"nine";a:4:{s:1:"C";s:2:"57";s:2:"WX";s:3:"554";s:1:"N";s:4:"nine";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"529";i:3;s:3:"752";}}i:58;a:4:{s:1:"C";s:2:"58";s:2:"WX";s:3:"277";s:1:"N";s:5:"colon";s:1:"B";a:4:{i:0;s:3:"101";i:1;s:1:"0";i:2;s:3:"175";i:3;s:3:"507";}}s:5:"colon";a:4:{s:1:"C";s:2:"58";s:2:"WX";s:3:"277";s:1:"N";s:5:"colon";s:1:"B";a:4:{i:0;s:3:"101";i:1;s:1:"0";i:2;s:3:"175";i:3;s:3:"507";}}i:59;a:4:{s:1:"C";s:2:"59";s:2:"WX";s:3:"277";s:1:"N";s:9:"semicolon";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:3:"-67";i:2;s:3:"203";i:3;s:3:"507";}}s:9:"semicolon";a:4:{s:1:"C";s:2:"59";s:2:"WX";s:3:"277";s:1:"N";s:9:"semicolon";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:3:"-67";i:2;s:3:"203";i:3;s:3:"507";}}i:60;a:4:{s:1:"C";s:2:"60";s:2:"WX";s:3:"606";s:1:"N";s:4:"less";s:1:"B";a:4:{i:0;s:2:"49";i:1;s:2:"37";i:2;s:3:"558";i:3;s:3:"565";}}s:4:"less";a:4:{s:1:"C";s:2:"60";s:2:"WX";s:3:"606";s:1:"N";s:4:"less";s:1:"B";a:4:{i:0;s:2:"49";i:1;s:2:"37";i:2;s:3:"558";i:3;s:3:"565";}}i:61;a:4:{s:1:"C";s:2:"61";s:2:"WX";s:3:"606";s:1:"N";s:5:"equal";s:1:"B";a:4:{i:0;s:2:"51";i:1;s:3:"164";i:2;s:3:"555";i:3;s:3:"436";}}s:5:"equal";a:4:{s:1:"C";s:2:"61";s:2:"WX";s:3:"606";s:1:"N";s:5:"equal";s:1:"B";a:4:{i:0;s:2:"51";i:1;s:3:"164";i:2;s:3:"555";i:3;s:3:"436";}}i:62;a:4:{s:1:"C";s:2:"62";s:2:"WX";s:3:"606";s:1:"N";s:7:"greater";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:2:"37";i:2;s:3:"557";i:3;s:3:"565";}}s:7:"greater";a:4:{s:1:"C";s:2:"62";s:2:"WX";s:3:"606";s:1:"N";s:7:"greater";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:2:"37";i:2;s:3:"557";i:3;s:3:"565";}}i:63;a:4:{s:1:"C";s:2:"63";s:2:"WX";s:3:"591";s:1:"N";s:8:"question";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:1:"0";i:2;s:3:"525";i:3;s:3:"752";}}s:8:"question";a:4:{s:1:"C";s:2:"63";s:2:"WX";s:3:"591";s:1:"N";s:8:"question";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:1:"0";i:2;s:3:"525";i:3;s:3:"752";}}i:64;a:4:{s:1:"C";s:2:"64";s:2:"WX";s:3:"867";s:1:"N";s:2:"at";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:3:"-13";i:2;s:3:"797";i:3;s:3:"752";}}s:2:"at";a:4:{s:1:"C";s:2:"64";s:2:"WX";s:3:"867";s:1:"N";s:2:"at";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:3:"-13";i:2;s:3:"797";i:3;s:3:"752";}}i:65;a:4:{s:1:"C";s:2:"65";s:2:"WX";s:3:"740";s:1:"N";s:1:"A";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:1:"0";i:2;s:3:"729";i:3;s:3:"739";}}s:1:"A";a:4:{s:1:"C";s:2:"65";s:2:"WX";s:3:"740";s:1:"N";s:1:"A";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:1:"0";i:2;s:3:"729";i:3;s:3:"739";}}i:66;a:4:{s:1:"C";s:2:"66";s:2:"WX";s:3:"574";s:1:"N";s:1:"B";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"544";i:3;s:3:"739";}}s:1:"B";a:4:{s:1:"C";s:2:"66";s:2:"WX";s:3:"574";s:1:"N";s:1:"B";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"544";i:3;s:3:"739";}}i:67;a:4:{s:1:"C";s:2:"67";s:2:"WX";s:3:"813";s:1:"N";s:1:"C";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-13";i:2;s:3:"770";i:3;s:3:"752";}}s:1:"C";a:4:{s:1:"C";s:2:"67";s:2:"WX";s:3:"813";s:1:"N";s:1:"C";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-13";i:2;s:3:"770";i:3;s:3:"752";}}i:68;a:4:{s:1:"C";s:2:"68";s:2:"WX";s:3:"744";s:1:"N";s:1:"D";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"700";i:3;s:3:"739";}}s:1:"D";a:4:{s:1:"C";s:2:"68";s:2:"WX";s:3:"744";s:1:"N";s:1:"D";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"700";i:3;s:3:"739";}}i:69;a:4:{s:1:"C";s:2:"69";s:2:"WX";s:3:"536";s:1:"N";s:1:"E";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"480";i:3;s:3:"739";}}s:1:"E";a:4:{s:1:"C";s:2:"69";s:2:"WX";s:3:"536";s:1:"N";s:1:"E";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"480";i:3;s:3:"739";}}i:70;a:4:{s:1:"C";s:2:"70";s:2:"WX";s:3:"485";s:1:"N";s:1:"F";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"451";i:3;s:3:"739";}}s:1:"F";a:4:{s:1:"C";s:2:"70";s:2:"WX";s:3:"485";s:1:"N";s:1:"F";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"451";i:3;s:3:"739";}}i:71;a:4:{s:1:"C";s:2:"71";s:2:"WX";s:3:"872";s:1:"N";s:1:"G";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-13";i:2;s:3:"831";i:3;s:3:"752";}}s:1:"G";a:4:{s:1:"C";s:2:"71";s:2:"WX";s:3:"872";s:1:"N";s:1:"G";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-13";i:2;s:3:"831";i:3;s:3:"752";}}i:72;a:4:{s:1:"C";s:2:"72";s:2:"WX";s:3:"683";s:1:"N";s:1:"H";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"607";i:3;s:3:"739";}}s:1:"H";a:4:{s:1:"C";s:2:"72";s:2:"WX";s:3:"683";s:1:"N";s:1:"H";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"607";i:3;s:3:"739";}}i:73;a:4:{s:1:"C";s:2:"73";s:2:"WX";s:3:"226";s:1:"N";s:1:"I";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"150";i:3;s:3:"739";}}s:1:"I";a:4:{s:1:"C";s:2:"73";s:2:"WX";s:3:"226";s:1:"N";s:1:"I";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"150";i:3;s:3:"739";}}i:74;a:4:{s:1:"C";s:2:"74";s:2:"WX";s:3:"482";s:1:"N";s:1:"J";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:3:"-14";i:2;s:3:"406";i:3;s:3:"739";}}s:1:"J";a:4:{s:1:"C";s:2:"74";s:2:"WX";s:3:"482";s:1:"N";s:1:"J";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:3:"-14";i:2;s:3:"406";i:3;s:3:"739";}}i:75;a:4:{s:1:"C";s:2:"75";s:2:"WX";s:3:"591";s:1:"N";s:1:"K";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"585";i:3;s:3:"739";}}s:1:"K";a:4:{s:1:"C";s:2:"75";s:2:"WX";s:3:"591";s:1:"N";s:1:"K";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"585";i:3;s:3:"739";}}i:76;a:4:{s:1:"C";s:2:"76";s:2:"WX";s:3:"462";s:1:"N";s:1:"L";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"456";i:3;s:3:"739";}}s:1:"L";a:4:{s:1:"C";s:2:"76";s:2:"WX";s:3:"462";s:1:"N";s:1:"L";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"456";i:3;s:3:"739";}}i:77;a:4:{s:1:"C";s:2:"77";s:2:"WX";s:3:"919";s:1:"N";s:1:"M";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"843";i:3;s:3:"739";}}s:1:"M";a:4:{s:1:"C";s:2:"77";s:2:"WX";s:3:"919";s:1:"N";s:1:"M";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"843";i:3;s:3:"739";}}i:78;a:4:{s:1:"C";s:2:"78";s:2:"WX";s:3:"740";s:1:"N";s:1:"N";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"664";i:3;s:3:"739";}}s:1:"N";a:4:{s:1:"C";s:2:"78";s:2:"WX";s:3:"740";s:1:"N";s:1:"N";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"664";i:3;s:3:"739";}}i:79;a:4:{s:1:"C";s:2:"79";s:2:"WX";s:3:"869";s:1:"N";s:1:"O";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-13";i:2;s:3:"825";i:3;s:3:"752";}}s:1:"O";a:4:{s:1:"C";s:2:"79";s:2:"WX";s:3:"869";s:1:"N";s:1:"O";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-13";i:2;s:3:"825";i:3;s:3:"752";}}i:80;a:4:{s:1:"C";s:2:"80";s:2:"WX";s:3:"592";s:1:"N";s:1:"P";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"565";i:3;s:3:"739";}}s:1:"P";a:4:{s:1:"C";s:2:"80";s:2:"WX";s:3:"592";s:1:"N";s:1:"P";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"565";i:3;s:3:"739";}}i:81;a:4:{s:1:"C";s:2:"81";s:2:"WX";s:3:"871";s:1:"N";s:1:"Q";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-13";i:2;s:3:"839";i:3;s:3:"752";}}s:1:"Q";a:4:{s:1:"C";s:2:"81";s:2:"WX";s:3:"871";s:1:"N";s:1:"Q";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-13";i:2;s:3:"839";i:3;s:3:"752";}}i:82;a:4:{s:1:"C";s:2:"82";s:2:"WX";s:3:"607";s:1:"N";s:1:"R";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"577";i:3;s:3:"739";}}s:1:"R";a:4:{s:1:"C";s:2:"82";s:2:"WX";s:3:"607";s:1:"N";s:1:"R";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"577";i:3;s:3:"739";}}i:83;a:4:{s:1:"C";s:2:"83";s:2:"WX";s:3:"498";s:1:"N";s:1:"S";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-13";i:2;s:3:"476";i:3;s:3:"752";}}s:1:"S";a:4:{s:1:"C";s:2:"83";s:2:"WX";s:3:"498";s:1:"N";s:1:"S";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-13";i:2;s:3:"476";i:3;s:3:"752";}}i:84;a:4:{s:1:"C";s:2:"84";s:2:"WX";s:3:"426";s:1:"N";s:1:"T";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:1:"0";i:2;s:3:"419";i:3;s:3:"739";}}s:1:"T";a:4:{s:1:"C";s:2:"84";s:2:"WX";s:3:"426";s:1:"N";s:1:"T";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:1:"0";i:2;s:3:"419";i:3;s:3:"739";}}i:85;a:4:{s:1:"C";s:2:"85";s:2:"WX";s:3:"655";s:1:"N";s:1:"U";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:3:"-13";i:2;s:3:"579";i:3;s:3:"739";}}s:1:"U";a:4:{s:1:"C";s:2:"85";s:2:"WX";s:3:"655";s:1:"N";s:1:"U";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:3:"-13";i:2;s:3:"579";i:3;s:3:"739";}}i:86;a:4:{s:1:"C";s:2:"86";s:2:"WX";s:3:"702";s:1:"N";s:1:"V";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:1:"0";i:2;s:3:"692";i:3;s:3:"739";}}s:1:"V";a:4:{s:1:"C";s:2:"86";s:2:"WX";s:3:"702";s:1:"N";s:1:"V";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:1:"0";i:2;s:3:"692";i:3;s:3:"739";}}i:87;a:4:{s:1:"C";s:2:"87";s:2:"WX";s:3:"960";s:1:"N";s:1:"W";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:1:"0";i:2;s:3:"950";i:3;s:3:"739";}}s:1:"W";a:4:{s:1:"C";s:2:"87";s:2:"WX";s:3:"960";s:1:"N";s:1:"W";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:1:"0";i:2;s:3:"950";i:3;s:3:"739";}}i:88;a:4:{s:1:"C";s:2:"88";s:2:"WX";s:3:"609";s:1:"N";s:1:"X";s:1:"B";a:4:{i:0;s:1:"8";i:1;s:1:"0";i:2;s:3:"601";i:3;s:3:"739";}}s:1:"X";a:4:{s:1:"C";s:2:"88";s:2:"WX";s:3:"609";s:1:"N";s:1:"X";s:1:"B";a:4:{i:0;s:1:"8";i:1;s:1:"0";i:2;s:3:"601";i:3;s:3:"739";}}i:89;a:4:{s:1:"C";s:2:"89";s:2:"WX";s:3:"592";s:1:"N";s:1:"Y";s:1:"B";a:4:{i:0;s:1:"2";i:1;s:1:"0";i:2;s:3:"590";i:3;s:3:"739";}}s:1:"Y";a:4:{s:1:"C";s:2:"89";s:2:"WX";s:3:"592";s:1:"N";s:1:"Y";s:1:"B";a:4:{i:0;s:1:"2";i:1;s:1:"0";i:2;s:3:"590";i:3;s:3:"739";}}i:90;a:4:{s:1:"C";s:2:"90";s:2:"WX";s:3:"480";s:1:"N";s:1:"Z";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:1:"0";i:2;s:3:"474";i:3;s:3:"739";}}s:1:"Z";a:4:{s:1:"C";s:2:"90";s:2:"WX";s:3:"480";s:1:"N";s:1:"Z";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:1:"0";i:2;s:3:"474";i:3;s:3:"739";}}i:91;a:4:{s:1:"C";s:2:"91";s:2:"WX";s:3:"351";s:1:"N";s:11:"bracketleft";s:1:"B";a:4:{i:0;s:3:"112";i:1;s:4:"-125";i:2;s:3:"313";i:3;s:3:"739";}}s:11:"bracketleft";a:4:{s:1:"C";s:2:"91";s:2:"WX";s:3:"351";s:1:"N";s:11:"bracketleft";s:1:"B";a:4:{i:0;s:3:"112";i:1;s:4:"-125";i:2;s:3:"313";i:3;s:3:"739";}}i:92;a:4:{s:1:"C";s:2:"92";s:2:"WX";s:3:"605";s:1:"N";s:9:"backslash";s:1:"B";a:4:{i:0;s:2:"84";i:1;s:1:"0";i:2;s:3:"464";i:3;s:3:"739";}}s:9:"backslash";a:4:{s:1:"C";s:2:"92";s:2:"WX";s:3:"605";s:1:"N";s:9:"backslash";s:1:"B";a:4:{i:0;s:2:"84";i:1;s:1:"0";i:2;s:3:"464";i:3;s:3:"739";}}i:93;a:4:{s:1:"C";s:2:"93";s:2:"WX";s:3:"351";s:1:"N";s:12:"bracketright";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:4:"-125";i:2;s:3:"239";i:3;s:3:"739";}}s:12:"bracketright";a:4:{s:1:"C";s:2:"93";s:2:"WX";s:3:"351";s:1:"N";s:12:"bracketright";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:4:"-125";i:2;s:3:"239";i:3;s:3:"739";}}i:94;a:4:{s:1:"C";s:2:"94";s:2:"WX";s:3:"606";s:1:"N";s:11:"asciicircum";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:3:"180";i:2;s:3:"588";i:3;s:3:"739";}}s:11:"asciicircum";a:4:{s:1:"C";s:2:"94";s:2:"WX";s:3:"606";s:1:"N";s:11:"asciicircum";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:3:"180";i:2;s:3:"588";i:3;s:3:"739";}}i:95;a:4:{s:1:"C";s:2:"95";s:2:"WX";s:3:"500";s:1:"N";s:10:"underscore";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:4:"-125";i:2;s:3:"500";i:3;s:3:"-67";}}s:10:"underscore";a:4:{s:1:"C";s:2:"95";s:2:"WX";s:3:"500";s:1:"N";s:10:"underscore";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:4:"-125";i:2;s:3:"500";i:3;s:3:"-67";}}i:96;a:4:{s:1:"C";s:2:"96";s:2:"WX";s:3:"351";s:1:"N";s:9:"quoteleft";s:1:"B";a:4:{i:0;s:2:"98";i:1;s:3:"547";i:2;s:3:"260";i:3;s:3:"739";}}s:9:"quoteleft";a:4:{s:1:"C";s:2:"96";s:2:"WX";s:3:"351";s:1:"N";s:9:"quoteleft";s:1:"B";a:4:{i:0;s:2:"98";i:1;s:3:"547";i:2;s:3:"260";i:3;s:3:"739";}}i:97;a:4:{s:1:"C";s:2:"97";s:2:"WX";s:3:"683";s:1:"N";s:1:"a";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"620";i:3;s:3:"560";}}s:1:"a";a:4:{s:1:"C";s:2:"97";s:2:"WX";s:3:"683";s:1:"N";s:1:"a";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"620";i:3;s:3:"560";}}i:98;a:4:{s:1:"C";s:2:"98";s:2:"WX";s:3:"682";s:1:"N";s:1:"b";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:3:"-13";i:2;s:3:"640";i:3;s:3:"739";}}s:1:"b";a:4:{s:1:"C";s:2:"98";s:2:"WX";s:3:"682";s:1:"N";s:1:"b";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:3:"-13";i:2;s:3:"640";i:3;s:3:"739";}}i:99;a:4:{s:1:"C";s:2:"99";s:2:"WX";s:3:"647";s:1:"N";s:1:"c";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"608";i:3;s:3:"560";}}s:1:"c";a:4:{s:1:"C";s:2:"99";s:2:"WX";s:3:"647";s:1:"N";s:1:"c";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"608";i:3;s:3:"560";}}i:100;a:4:{s:1:"C";s:3:"100";s:2:"WX";s:3:"685";s:1:"N";s:1:"d";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"622";i:3;s:3:"739";}}s:1:"d";a:4:{s:1:"C";s:3:"100";s:2:"WX";s:3:"685";s:1:"N";s:1:"d";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"622";i:3;s:3:"739";}}i:101;a:4:{s:1:"C";s:3:"101";s:2:"WX";s:3:"650";s:1:"N";s:1:"e";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"611";i:3;s:3:"560";}}s:1:"e";a:4:{s:1:"C";s:3:"101";s:2:"WX";s:3:"650";s:1:"N";s:1:"e";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"611";i:3;s:3:"560";}}i:102;a:4:{s:1:"C";s:3:"102";s:2:"WX";s:3:"314";s:1:"N";s:1:"f";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"311";i:3;s:3:"739";}}s:1:"f";a:4:{s:1:"C";s:3:"102";s:2:"WX";s:3:"314";s:1:"N";s:1:"f";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:1:"0";i:2;s:3:"311";i:3;s:3:"739";}}i:103;a:4:{s:1:"C";s:3:"103";s:2:"WX";s:3:"673";s:1:"N";s:1:"g";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:4:"-215";i:2;s:3:"610";i:3;s:3:"560";}}s:1:"g";a:4:{s:1:"C";s:3:"103";s:2:"WX";s:3:"673";s:1:"N";s:1:"g";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:4:"-215";i:2;s:3:"610";i:3;s:3:"560";}}i:104;a:4:{s:1:"C";s:3:"104";s:2:"WX";s:3:"610";s:1:"N";s:1:"h";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:1:"0";i:2;s:3:"547";i:3;s:3:"739";}}s:1:"h";a:4:{s:1:"C";s:3:"104";s:2:"WX";s:3:"610";s:1:"N";s:1:"h";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:1:"0";i:2;s:3:"547";i:3;s:3:"739";}}i:105;a:4:{s:1:"C";s:3:"105";s:2:"WX";s:3:"200";s:1:"N";s:1:"i";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:1:"0";i:2;s:3:"137";i:3;s:3:"739";}}s:1:"i";a:4:{s:1:"C";s:3:"105";s:2:"WX";s:3:"200";s:1:"N";s:1:"i";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:1:"0";i:2;s:3:"137";i:3;s:3:"739";}}i:106;a:4:{s:1:"C";s:3:"106";s:2:"WX";s:3:"203";s:1:"N";s:1:"j";s:1:"B";a:4:{i:0;s:3:"-45";i:1;s:4:"-192";i:2;s:3:"140";i:3;s:3:"739";}}s:1:"j";a:4:{s:1:"C";s:3:"106";s:2:"WX";s:3:"203";s:1:"N";s:1:"j";s:1:"B";a:4:{i:0;s:3:"-45";i:1;s:4:"-192";i:2;s:3:"140";i:3;s:3:"739";}}i:107;a:4:{s:1:"C";s:3:"107";s:2:"WX";s:3:"502";s:1:"N";s:1:"k";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:1:"0";i:2;s:3:"497";i:3;s:3:"739";}}s:1:"k";a:4:{s:1:"C";s:3:"107";s:2:"WX";s:3:"502";s:1:"N";s:1:"k";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:1:"0";i:2;s:3:"497";i:3;s:3:"739";}}i:108;a:4:{s:1:"C";s:3:"108";s:2:"WX";s:3:"200";s:1:"N";s:1:"l";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:1:"0";i:2;s:3:"137";i:3;s:3:"739";}}s:1:"l";a:4:{s:1:"C";s:3:"108";s:2:"WX";s:3:"200";s:1:"N";s:1:"l";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:1:"0";i:2;s:3:"137";i:3;s:3:"739";}}i:109;a:4:{s:1:"C";s:3:"109";s:2:"WX";s:3:"938";s:1:"N";s:1:"m";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:1:"0";i:2;s:3:"875";i:3;s:3:"561";}}s:1:"m";a:4:{s:1:"C";s:3:"109";s:2:"WX";s:3:"938";s:1:"N";s:1:"m";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:1:"0";i:2;s:3:"875";i:3;s:3:"561";}}i:110;a:4:{s:1:"C";s:3:"110";s:2:"WX";s:3:"610";s:1:"N";s:1:"n";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:1:"0";i:2;s:3:"547";i:3;s:3:"560";}}s:1:"n";a:4:{s:1:"C";s:3:"110";s:2:"WX";s:3:"610";s:1:"N";s:1:"n";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:1:"0";i:2;s:3:"547";i:3;s:3:"560";}}i:111;a:4:{s:1:"C";s:3:"111";s:2:"WX";s:3:"655";s:1:"N";s:1:"o";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"613";i:3;s:3:"560";}}s:1:"o";a:4:{s:1:"C";s:3:"111";s:2:"WX";s:3:"655";s:1:"N";s:1:"o";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"613";i:3;s:3:"560";}}i:112;a:4:{s:1:"C";s:3:"112";s:2:"WX";s:3:"682";s:1:"N";s:1:"p";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:4:"-192";i:2;s:3:"640";i:3;s:3:"560";}}s:1:"p";a:4:{s:1:"C";s:3:"112";s:2:"WX";s:3:"682";s:1:"N";s:1:"p";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:4:"-192";i:2;s:3:"640";i:3;s:3:"560";}}i:113;a:4:{s:1:"C";s:3:"113";s:2:"WX";s:3:"682";s:1:"N";s:1:"q";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:4:"-192";i:2;s:3:"619";i:3;s:3:"560";}}s:1:"q";a:4:{s:1:"C";s:3:"113";s:2:"WX";s:3:"682";s:1:"N";s:1:"q";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:4:"-192";i:2;s:3:"619";i:3;s:3:"560";}}i:114;a:4:{s:1:"C";s:3:"114";s:2:"WX";s:3:"301";s:1:"N";s:1:"r";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:1:"0";i:2;s:3:"292";i:3;s:3:"560";}}s:1:"r";a:4:{s:1:"C";s:3:"114";s:2:"WX";s:3:"301";s:1:"N";s:1:"r";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:1:"0";i:2;s:3:"292";i:3;s:3:"560";}}i:115;a:4:{s:1:"C";s:3:"115";s:2:"WX";s:3:"388";s:1:"N";s:1:"s";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:3:"-13";i:2;s:3:"361";i:3;s:3:"560";}}s:1:"s";a:4:{s:1:"C";s:3:"115";s:2:"WX";s:3:"388";s:1:"N";s:1:"s";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:3:"-13";i:2;s:3:"361";i:3;s:3:"560";}}i:116;a:4:{s:1:"C";s:3:"116";s:2:"WX";s:3:"339";s:1:"N";s:1:"t";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"327";i:3;s:3:"739";}}s:1:"t";a:4:{s:1:"C";s:3:"116";s:2:"WX";s:3:"339";s:1:"N";s:1:"t";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"327";i:3;s:3:"739";}}i:117;a:4:{s:1:"C";s:3:"117";s:2:"WX";s:3:"608";s:1:"N";s:1:"u";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:3:"-13";i:2;s:3:"545";i:3;s:3:"547";}}s:1:"u";a:4:{s:1:"C";s:3:"117";s:2:"WX";s:3:"608";s:1:"N";s:1:"u";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:3:"-13";i:2;s:3:"545";i:3;s:3:"547";}}i:118;a:4:{s:1:"C";s:3:"118";s:2:"WX";s:3:"554";s:1:"N";s:1:"v";s:1:"B";a:4:{i:0;s:1:"8";i:1;s:1:"0";i:2;s:3:"546";i:3;s:3:"547";}}s:1:"v";a:4:{s:1:"C";s:3:"118";s:2:"WX";s:3:"554";s:1:"N";s:1:"v";s:1:"B";a:4:{i:0;s:1:"8";i:1;s:1:"0";i:2;s:3:"546";i:3;s:3:"547";}}i:119;a:4:{s:1:"C";s:3:"119";s:2:"WX";s:3:"831";s:1:"N";s:1:"w";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:1:"0";i:2;s:3:"824";i:3;s:3:"547";}}s:1:"w";a:4:{s:1:"C";s:3:"119";s:2:"WX";s:3:"831";s:1:"N";s:1:"w";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:1:"0";i:2;s:3:"824";i:3;s:3:"547";}}i:120;a:4:{s:1:"C";s:3:"120";s:2:"WX";s:3:"480";s:1:"N";s:1:"x";s:1:"B";a:4:{i:0;s:1:"8";i:1;s:1:"0";i:2;s:3:"472";i:3;s:3:"547";}}s:1:"x";a:4:{s:1:"C";s:3:"120";s:2:"WX";s:3:"480";s:1:"N";s:1:"x";s:1:"B";a:4:{i:0;s:1:"8";i:1;s:1:"0";i:2;s:3:"472";i:3;s:3:"547";}}i:121;a:4:{s:1:"C";s:3:"121";s:2:"WX";s:3:"536";s:1:"N";s:1:"y";s:1:"B";a:4:{i:0;s:1:"9";i:1;s:4:"-192";i:2;s:3:"527";i:3;s:3:"547";}}s:1:"y";a:4:{s:1:"C";s:3:"121";s:2:"WX";s:3:"536";s:1:"N";s:1:"y";s:1:"B";a:4:{i:0;s:1:"9";i:1;s:4:"-192";i:2;s:3:"527";i:3;s:3:"547";}}i:122;a:4:{s:1:"C";s:3:"122";s:2:"WX";s:3:"425";s:1:"N";s:1:"z";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:1:"0";i:2;s:3:"415";i:3;s:3:"547";}}s:1:"z";a:4:{s:1:"C";s:3:"122";s:2:"WX";s:3:"425";s:1:"N";s:1:"z";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:1:"0";i:2;s:3:"415";i:3;s:3:"547";}}i:123;a:4:{s:1:"C";s:3:"123";s:2:"WX";s:3:"351";s:1:"N";s:9:"braceleft";s:1:"B";a:4:{i:0;s:2:"37";i:1;s:4:"-126";i:2;s:3:"271";i:3;s:3:"739";}}s:9:"braceleft";a:4:{s:1:"C";s:3:"123";s:2:"WX";s:3:"351";s:1:"N";s:9:"braceleft";s:1:"B";a:4:{i:0;s:2:"37";i:1;s:4:"-126";i:2;s:3:"271";i:3;s:3:"739";}}i:124;a:4:{s:1:"C";s:3:"124";s:2:"WX";s:3:"672";s:1:"N";s:3:"bar";s:1:"B";a:4:{i:0;s:3:"304";i:1;s:1:"0";i:2;s:3:"368";i:3;s:3:"739";}}s:3:"bar";a:4:{s:1:"C";s:3:"124";s:2:"WX";s:3:"672";s:1:"N";s:3:"bar";s:1:"B";a:4:{i:0;s:3:"304";i:1;s:1:"0";i:2;s:3:"368";i:3;s:3:"739";}}i:125;a:4:{s:1:"C";s:3:"125";s:2:"WX";s:3:"351";s:1:"N";s:10:"braceright";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:4:"-126";i:2;s:3:"269";i:3;s:3:"739";}}s:10:"braceright";a:4:{s:1:"C";s:3:"125";s:2:"WX";s:3:"351";s:1:"N";s:10:"braceright";s:1:"B";a:4:{i:0;s:2:"38";i:1;s:4:"-126";i:2;s:3:"269";i:3;s:3:"739";}}i:126;a:4:{s:1:"C";s:3:"126";s:2:"WX";s:3:"606";s:1:"N";s:10:"asciitilde";s:1:"B";a:4:{i:0;s:2:"51";i:1;s:3:"210";i:2;s:3:"555";i:3;s:3:"390";}}s:10:"asciitilde";a:4:{s:1:"C";s:3:"126";s:2:"WX";s:3:"606";s:1:"N";s:10:"asciitilde";s:1:"B";a:4:{i:0;s:2:"51";i:1;s:3:"210";i:2;s:3:"555";i:3;s:3:"390";}}i:161;a:4:{s:1:"C";s:3:"161";s:2:"WX";s:3:"295";s:1:"N";s:10:"exclamdown";s:1:"B";a:4:{i:0;s:3:"111";i:1;s:4:"-192";i:2;s:3:"185";i:3;s:3:"547";}}s:10:"exclamdown";a:4:{s:1:"C";s:3:"161";s:2:"WX";s:3:"295";s:1:"N";s:10:"exclamdown";s:1:"B";a:4:{i:0;s:3:"111";i:1;s:4:"-192";i:2;s:3:"185";i:3;s:3:"547";}}i:162;a:4:{s:1:"C";s:3:"162";s:2:"WX";s:3:"554";s:1:"N";s:4:"cent";s:1:"B";a:4:{i:0;s:2:"45";i:1;s:2:"62";i:2;s:3:"509";i:3;s:3:"707";}}s:4:"cent";a:4:{s:1:"C";s:3:"162";s:2:"WX";s:3:"554";s:1:"N";s:4:"cent";s:1:"B";a:4:{i:0;s:2:"45";i:1;s:2:"62";i:2;s:3:"509";i:3;s:3:"707";}}i:163;a:4:{s:1:"C";s:3:"163";s:2:"WX";s:3:"554";s:1:"N";s:8:"sterling";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:1:"0";i:2;s:3:"592";i:3;s:3:"752";}}s:8:"sterling";a:4:{s:1:"C";s:3:"163";s:2:"WX";s:3:"554";s:1:"N";s:8:"sterling";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:1:"0";i:2;s:3:"592";i:3;s:3:"752";}}i:164;a:4:{s:1:"C";s:3:"164";s:2:"WX";s:3:"166";s:1:"N";s:8:"fraction";s:1:"B";a:4:{i:0;s:4:"-115";i:1;s:1:"0";i:2;s:3:"281";i:3;s:3:"739";}}s:8:"fraction";a:4:{s:1:"C";s:3:"164";s:2:"WX";s:3:"166";s:1:"N";s:8:"fraction";s:1:"B";a:4:{i:0;s:4:"-115";i:1;s:1:"0";i:2;s:3:"281";i:3;s:3:"739";}}i:165;a:4:{s:1:"C";s:3:"165";s:2:"WX";s:3:"554";s:1:"N";s:3:"yen";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:3:"589";i:3;s:3:"739";}}s:3:"yen";a:4:{s:1:"C";s:3:"165";s:2:"WX";s:3:"554";s:1:"N";s:3:"yen";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:3:"589";i:3;s:3:"739";}}i:166;a:4:{s:1:"C";s:3:"166";s:2:"WX";s:3:"554";s:1:"N";s:6:"florin";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:4:"-153";i:2;s:3:"546";i:3;s:3:"818";}}s:6:"florin";a:4:{s:1:"C";s:3:"166";s:2:"WX";s:3:"554";s:1:"N";s:6:"florin";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:4:"-153";i:2;s:3:"546";i:3;s:3:"818";}}i:167;a:4:{s:1:"C";s:3:"167";s:2:"WX";s:3:"615";s:1:"N";s:7:"section";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:4:"-141";i:2;s:3:"529";i:3;s:3:"752";}}s:7:"section";a:4:{s:1:"C";s:3:"167";s:2:"WX";s:3:"615";s:1:"N";s:7:"section";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:4:"-141";i:2;s:3:"529";i:3;s:3:"752";}}i:168;a:4:{s:1:"C";s:3:"168";s:2:"WX";s:3:"554";s:1:"N";s:8:"currency";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:2:"50";i:2;s:3:"528";i:3;s:3:"553";}}s:8:"currency";a:4:{s:1:"C";s:3:"168";s:2:"WX";s:3:"554";s:1:"N";s:8:"currency";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:2:"50";i:2;s:3:"528";i:3;s:3:"553";}}i:169;a:4:{s:1:"C";s:3:"169";s:2:"WX";s:3:"198";s:1:"N";s:11:"quotesingle";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"513";i:2;s:3:"124";i:3;s:3:"739";}}s:11:"quotesingle";a:4:{s:1:"C";s:3:"169";s:2:"WX";s:3:"198";s:1:"N";s:11:"quotesingle";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"513";i:2;s:3:"124";i:3;s:3:"739";}}i:170;a:4:{s:1:"C";s:3:"170";s:2:"WX";s:3:"502";s:1:"N";s:12:"quotedblleft";s:1:"B";a:4:{i:0;s:2:"96";i:1;s:3:"547";i:2;s:3:"406";i:3;s:3:"739";}}s:12:"quotedblleft";a:4:{s:1:"C";s:3:"170";s:2:"WX";s:3:"502";s:1:"N";s:12:"quotedblleft";s:1:"B";a:4:{i:0;s:2:"96";i:1;s:3:"547";i:2;s:3:"406";i:3;s:3:"739";}}i:171;a:4:{s:1:"C";s:3:"171";s:2:"WX";s:3:"425";s:1:"N";s:13:"guillemotleft";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:2:"99";i:2;s:3:"385";i:3;s:3:"499";}}s:13:"guillemotleft";a:4:{s:1:"C";s:3:"171";s:2:"WX";s:3:"425";s:1:"N";s:13:"guillemotleft";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:2:"99";i:2;s:3:"385";i:3;s:3:"499";}}i:172;a:4:{s:1:"C";s:3:"172";s:2:"WX";s:3:"251";s:1:"N";s:13:"guilsinglleft";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:2:"99";i:2;s:3:"211";i:3;s:3:"499";}}s:13:"guilsinglleft";a:4:{s:1:"C";s:3:"172";s:2:"WX";s:3:"251";s:1:"N";s:13:"guilsinglleft";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:2:"99";i:2;s:3:"211";i:3;s:3:"499";}}i:173;a:4:{s:1:"C";s:3:"173";s:2:"WX";s:3:"251";s:1:"N";s:14:"guilsinglright";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:2:"99";i:2;s:3:"211";i:3;s:3:"499";}}s:14:"guilsinglright";a:4:{s:1:"C";s:3:"173";s:2:"WX";s:3:"251";s:1:"N";s:14:"guilsinglright";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:2:"99";i:2;s:3:"211";i:3;s:3:"499";}}i:174;a:4:{s:1:"C";s:3:"174";s:2:"WX";s:3:"487";s:1:"N";s:2:"fi";s:1:"B";a:4:{i:0;s:2:"13";i:1;s:1:"0";i:2;s:3:"424";i:3;s:3:"739";}}s:2:"fi";a:4:{s:1:"C";s:3:"174";s:2:"WX";s:3:"487";s:1:"N";s:2:"fi";s:1:"B";a:4:{i:0;s:2:"13";i:1;s:1:"0";i:2;s:3:"424";i:3;s:3:"739";}}i:175;a:4:{s:1:"C";s:3:"175";s:2:"WX";s:3:"485";s:1:"N";s:2:"fl";s:1:"B";a:4:{i:0;s:2:"13";i:1;s:1:"0";i:2;s:3:"422";i:3;s:3:"739";}}s:2:"fl";a:4:{s:1:"C";s:3:"175";s:2:"WX";s:3:"485";s:1:"N";s:2:"fl";s:1:"B";a:4:{i:0;s:2:"13";i:1;s:1:"0";i:2;s:3:"422";i:3;s:3:"739";}}i:177;a:4:{s:1:"C";s:3:"177";s:2:"WX";s:3:"500";s:1:"N";s:6:"endash";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"233";i:2;s:3:"500";i:3;s:3:"296";}}s:6:"endash";a:4:{s:1:"C";s:3:"177";s:2:"WX";s:3:"500";s:1:"N";s:6:"endash";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"233";i:2;s:3:"500";i:3;s:3:"296";}}i:178;a:4:{s:1:"C";s:3:"178";s:2:"WX";s:3:"553";s:1:"N";s:6:"dagger";s:1:"B";a:4:{i:0;s:2:"59";i:1;s:4:"-133";i:2;s:3:"494";i:3;s:3:"739";}}s:6:"dagger";a:4:{s:1:"C";s:3:"178";s:2:"WX";s:3:"553";s:1:"N";s:6:"dagger";s:1:"B";a:4:{i:0;s:2:"59";i:1;s:4:"-133";i:2;s:3:"494";i:3;s:3:"739";}}i:179;a:4:{s:1:"C";s:3:"179";s:2:"WX";s:3:"553";s:1:"N";s:9:"daggerdbl";s:1:"B";a:4:{i:0;s:2:"59";i:1;s:4:"-133";i:2;s:3:"494";i:3;s:3:"739";}}s:9:"daggerdbl";a:4:{s:1:"C";s:3:"179";s:2:"WX";s:3:"553";s:1:"N";s:9:"daggerdbl";s:1:"B";a:4:{i:0;s:2:"59";i:1;s:4:"-133";i:2;s:3:"494";i:3;s:3:"739";}}i:180;a:4:{s:1:"C";s:3:"180";s:2:"WX";s:3:"277";s:1:"N";s:14:"periodcentered";s:1:"B";a:4:{i:0;s:3:"101";i:1;s:3:"229";i:2;s:3:"175";i:3;s:3:"355";}}s:14:"periodcentered";a:4:{s:1:"C";s:3:"180";s:2:"WX";s:3:"277";s:1:"N";s:14:"periodcentered";s:1:"B";a:4:{i:0;s:3:"101";i:1;s:3:"229";i:2;s:3:"175";i:3;s:3:"355";}}i:182;a:4:{s:1:"C";s:3:"182";s:2:"WX";s:3:"564";s:1:"N";s:9:"paragraph";s:1:"B";a:4:{i:0;s:2:"37";i:1;s:4:"-133";i:2;s:3:"491";i:3;s:3:"739";}}s:9:"paragraph";a:4:{s:1:"C";s:3:"182";s:2:"WX";s:3:"564";s:1:"N";s:9:"paragraph";s:1:"B";a:4:{i:0;s:2:"37";i:1;s:4:"-133";i:2;s:3:"491";i:3;s:3:"739";}}i:183;a:4:{s:1:"C";s:3:"183";s:2:"WX";s:3:"606";s:1:"N";s:6:"bullet";s:1:"B";a:4:{i:0;s:3:"118";i:1;s:3:"118";i:2;s:3:"488";i:3;s:3:"488";}}s:6:"bullet";a:4:{s:1:"C";s:3:"183";s:2:"WX";s:3:"606";s:1:"N";s:6:"bullet";s:1:"B";a:4:{i:0;s:3:"118";i:1;s:3:"118";i:2;s:3:"488";i:3;s:3:"488";}}i:184;a:4:{s:1:"C";s:3:"184";s:2:"WX";s:3:"354";s:1:"N";s:14:"quotesinglbase";s:1:"B";a:4:{i:0;s:2:"89";i:1;s:3:"-67";i:2;s:3:"251";i:3;s:3:"126";}}s:14:"quotesinglbase";a:4:{s:1:"C";s:3:"184";s:2:"WX";s:3:"354";s:1:"N";s:14:"quotesinglbase";s:1:"B";a:4:{i:0;s:2:"89";i:1;s:3:"-67";i:2;s:3:"251";i:3;s:3:"126";}}i:185;a:4:{s:1:"C";s:3:"185";s:2:"WX";s:3:"502";s:1:"N";s:12:"quotedblbase";s:1:"B";a:4:{i:0;s:2:"89";i:1;s:3:"-67";i:2;s:3:"398";i:3;s:3:"126";}}s:12:"quotedblbase";a:4:{s:1:"C";s:3:"185";s:2:"WX";s:3:"502";s:1:"N";s:12:"quotedblbase";s:1:"B";a:4:{i:0;s:2:"89";i:1;s:3:"-67";i:2;s:3:"398";i:3;s:3:"126";}}i:186;a:4:{s:1:"C";s:3:"186";s:2:"WX";s:3:"484";s:1:"N";s:13:"quotedblright";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:3:"547";i:2;s:3:"393";i:3;s:3:"739";}}s:13:"quotedblright";a:4:{s:1:"C";s:3:"186";s:2:"WX";s:3:"484";s:1:"N";s:13:"quotedblright";s:1:"B";a:4:{i:0;s:2:"87";i:1;s:3:"547";i:2;s:3:"393";i:3;s:3:"739";}}i:187;a:4:{s:1:"C";s:3:"187";s:2:"WX";s:3:"425";s:1:"N";s:14:"guillemotright";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:2:"99";i:2;s:3:"385";i:3;s:3:"499";}}s:14:"guillemotright";a:4:{s:1:"C";s:3:"187";s:2:"WX";s:3:"425";s:1:"N";s:14:"guillemotright";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:2:"99";i:2;s:3:"385";i:3;s:3:"499";}}i:188;a:4:{s:1:"C";s:3:"188";s:2:"WX";s:4:"1000";s:1:"N";s:8:"ellipsis";s:1:"B";a:4:{i:0;s:3:"130";i:1;s:1:"0";i:2;s:3:"870";i:3;s:3:"126";}}s:8:"ellipsis";a:4:{s:1:"C";s:3:"188";s:2:"WX";s:4:"1000";s:1:"N";s:8:"ellipsis";s:1:"B";a:4:{i:0;s:3:"130";i:1;s:1:"0";i:2;s:3:"870";i:3;s:3:"126";}}i:189;a:4:{s:1:"C";s:3:"189";s:2:"WX";s:4:"1174";s:1:"N";s:11:"perthousand";s:1:"B";a:4:{i:0;s:2:"13";i:1;s:3:"-13";i:2;s:4:"1151";i:3;s:3:"749";}}s:11:"perthousand";a:4:{s:1:"C";s:3:"189";s:2:"WX";s:4:"1174";s:1:"N";s:11:"perthousand";s:1:"B";a:4:{i:0;s:2:"13";i:1;s:3:"-13";i:2;s:4:"1151";i:3;s:3:"749";}}i:191;a:4:{s:1:"C";s:3:"191";s:2:"WX";s:3:"591";s:1:"N";s:12:"questiondown";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:4:"-205";i:2;s:3:"526";i:3;s:3:"547";}}s:12:"questiondown";a:4:{s:1:"C";s:3:"191";s:2:"WX";s:3:"591";s:1:"N";s:12:"questiondown";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:4:"-205";i:2;s:3:"526";i:3;s:3:"547";}}i:193;a:4:{s:1:"C";s:3:"193";s:2:"WX";s:3:"378";s:1:"N";s:5:"grave";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"610";i:2;s:3:"304";i:3;s:3:"776";}}s:5:"grave";a:4:{s:1:"C";s:3:"193";s:2:"WX";s:3:"378";s:1:"N";s:5:"grave";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"610";i:2;s:3:"304";i:3;s:3:"776";}}i:194;a:4:{s:1:"C";s:3:"194";s:2:"WX";s:3:"375";s:1:"N";s:5:"acute";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"610";i:2;s:3:"301";i:3;s:3:"782";}}s:5:"acute";a:4:{s:1:"C";s:3:"194";s:2:"WX";s:3:"375";s:1:"N";s:5:"acute";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"610";i:2;s:3:"301";i:3;s:3:"782";}}i:195;a:4:{s:1:"C";s:3:"195";s:2:"WX";s:3:"502";s:1:"N";s:10:"circumflex";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"623";i:2;s:3:"428";i:3;s:3:"749";}}s:10:"circumflex";a:4:{s:1:"C";s:3:"195";s:2:"WX";s:3:"502";s:1:"N";s:10:"circumflex";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"623";i:2;s:3:"428";i:3;s:3:"749";}}i:196;a:4:{s:1:"C";s:3:"196";s:2:"WX";s:3:"439";s:1:"N";s:5:"tilde";s:1:"B";a:4:{i:0;s:2:"75";i:1;s:3:"633";i:2;s:3:"365";i:3;s:3:"728";}}s:5:"tilde";a:4:{s:1:"C";s:3:"196";s:2:"WX";s:3:"439";s:1:"N";s:5:"tilde";s:1:"B";a:4:{i:0;s:2:"75";i:1;s:3:"633";i:2;s:3:"365";i:3;s:3:"728";}}i:197;a:4:{s:1:"C";s:3:"197";s:2:"WX";s:3:"485";s:1:"N";s:6:"macron";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"643";i:2;s:3:"411";i:3;s:3:"707";}}s:6:"macron";a:4:{s:1:"C";s:3:"197";s:2:"WX";s:3:"485";s:1:"N";s:6:"macron";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"643";i:2;s:3:"411";i:3;s:3:"707";}}i:198;a:4:{s:1:"C";s:3:"198";s:2:"WX";s:3:"453";s:1:"N";s:5:"breve";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"623";i:2;s:3:"378";i:3;s:3:"743";}}s:5:"breve";a:4:{s:1:"C";s:3:"198";s:2:"WX";s:3:"453";s:1:"N";s:5:"breve";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"623";i:2;s:3:"378";i:3;s:3:"743";}}i:199;a:4:{s:1:"C";s:3:"199";s:2:"WX";s:3:"222";s:1:"N";s:9:"dotaccent";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"623";i:2;s:3:"148";i:3;s:3:"749";}}s:9:"dotaccent";a:4:{s:1:"C";s:3:"199";s:2:"WX";s:3:"222";s:1:"N";s:9:"dotaccent";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"623";i:2;s:3:"148";i:3;s:3:"749";}}i:200;a:4:{s:1:"C";s:3:"200";s:2:"WX";s:3:"369";s:1:"N";s:8:"dieresis";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"623";i:2;s:3:"295";i:3;s:3:"749";}}s:8:"dieresis";a:4:{s:1:"C";s:3:"200";s:2:"WX";s:3:"369";s:1:"N";s:8:"dieresis";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"623";i:2;s:3:"295";i:3;s:3:"749";}}i:202;a:4:{s:1:"C";s:3:"202";s:2:"WX";s:3:"332";s:1:"N";s:4:"ring";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"610";i:2;s:3:"258";i:3;s:3:"794";}}s:4:"ring";a:4:{s:1:"C";s:3:"202";s:2:"WX";s:3:"332";s:1:"N";s:4:"ring";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"610";i:2;s:3:"258";i:3;s:3:"794";}}i:203;a:4:{s:1:"C";s:3:"203";s:2:"WX";s:3:"324";s:1:"N";s:7:"cedilla";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:4:"-213";i:2;s:3:"250";i:3;s:1:"0";}}s:7:"cedilla";a:4:{s:1:"C";s:3:"203";s:2:"WX";s:3:"324";s:1:"N";s:7:"cedilla";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:4:"-213";i:2;s:3:"250";i:3;s:1:"0";}}i:205;a:4:{s:1:"C";s:3:"205";s:2:"WX";s:3:"552";s:1:"N";s:12:"hungarumlaut";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"610";i:2;s:3:"479";i:3;s:3:"780";}}s:12:"hungarumlaut";a:4:{s:1:"C";s:3:"205";s:2:"WX";s:3:"552";s:1:"N";s:12:"hungarumlaut";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"610";i:2;s:3:"479";i:3;s:3:"780";}}i:206;a:4:{s:1:"C";s:3:"206";s:2:"WX";s:3:"302";s:1:"N";s:6:"ogonek";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:4:"-191";i:2;s:3:"228";i:3;s:1:"0";}}s:6:"ogonek";a:4:{s:1:"C";s:3:"206";s:2:"WX";s:3:"302";s:1:"N";s:6:"ogonek";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:4:"-191";i:2;s:3:"228";i:3;s:1:"0";}}i:207;a:4:{s:1:"C";s:3:"207";s:2:"WX";s:3:"502";s:1:"N";s:5:"caron";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"623";i:2;s:3:"428";i:3;s:3:"749";}}s:5:"caron";a:4:{s:1:"C";s:3:"207";s:2:"WX";s:3:"502";s:1:"N";s:5:"caron";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"623";i:2;s:3:"428";i:3;s:3:"749";}}i:208;a:4:{s:1:"C";s:3:"208";s:2:"WX";s:4:"1000";s:1:"N";s:6:"emdash";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"233";i:2;s:4:"1000";i:3;s:3:"296";}}s:6:"emdash";a:4:{s:1:"C";s:3:"208";s:2:"WX";s:4:"1000";s:1:"N";s:6:"emdash";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"233";i:2;s:4:"1000";i:3;s:3:"296";}}i:225;a:4:{s:1:"C";s:3:"225";s:2:"WX";s:3:"992";s:1:"N";s:2:"AE";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:1:"0";i:2;s:3:"936";i:3;s:3:"739";}}s:2:"AE";a:4:{s:1:"C";s:3:"225";s:2:"WX";s:3:"992";s:1:"N";s:2:"AE";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:1:"0";i:2;s:3:"936";i:3;s:3:"739";}}i:227;a:4:{s:1:"C";s:3:"227";s:2:"WX";s:3:"369";s:1:"N";s:11:"ordfeminine";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:3:"319";i:2;s:3:"339";i:3;s:3:"745";}}s:11:"ordfeminine";a:4:{s:1:"C";s:3:"227";s:2:"WX";s:3:"369";s:1:"N";s:11:"ordfeminine";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:3:"319";i:2;s:3:"339";i:3;s:3:"745";}}i:232;a:4:{s:1:"C";s:3:"232";s:2:"WX";s:3:"517";s:1:"N";s:6:"Lslash";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"502";i:3;s:3:"739";}}s:6:"Lslash";a:4:{s:1:"C";s:3:"232";s:2:"WX";s:3:"517";s:1:"N";s:6:"Lslash";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"502";i:3;s:3:"739";}}i:233;a:4:{s:1:"C";s:3:"233";s:2:"WX";s:3:"868";s:1:"N";s:6:"Oslash";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-83";i:2;s:3:"824";i:3;s:3:"821";}}s:6:"Oslash";a:4:{s:1:"C";s:3:"233";s:2:"WX";s:3:"868";s:1:"N";s:6:"Oslash";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-83";i:2;s:3:"824";i:3;s:3:"821";}}i:234;a:4:{s:1:"C";s:3:"234";s:2:"WX";s:4:"1194";s:1:"N";s:2:"OE";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-13";i:2;s:4:"1138";i:3;s:3:"752";}}s:2:"OE";a:4:{s:1:"C";s:3:"234";s:2:"WX";s:4:"1194";s:1:"N";s:2:"OE";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-13";i:2;s:4:"1138";i:3;s:3:"752";}}i:235;a:4:{s:1:"C";s:3:"235";s:2:"WX";s:3:"369";s:1:"N";s:12:"ordmasculine";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:3:"319";i:2;s:3:"337";i:3;s:3:"745";}}s:12:"ordmasculine";a:4:{s:1:"C";s:3:"235";s:2:"WX";s:3:"369";s:1:"N";s:12:"ordmasculine";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:3:"319";i:2;s:3:"337";i:3;s:3:"745";}}i:241;a:4:{s:1:"C";s:3:"241";s:2:"WX";s:4:"1157";s:1:"N";s:2:"ae";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:4:"1118";i:3;s:3:"560";}}s:2:"ae";a:4:{s:1:"C";s:3:"241";s:2:"WX";s:4:"1157";s:1:"N";s:2:"ae";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:4:"1118";i:3;s:3:"560";}}i:245;a:4:{s:1:"C";s:3:"245";s:2:"WX";s:3:"200";s:1:"N";s:8:"dotlessi";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:1:"0";i:2;s:3:"137";i:3;s:3:"547";}}s:8:"dotlessi";a:4:{s:1:"C";s:3:"245";s:2:"WX";s:3:"200";s:1:"N";s:8:"dotlessi";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:1:"0";i:2;s:3:"137";i:3;s:3:"547";}}i:248;a:4:{s:1:"C";s:3:"248";s:2:"WX";s:3:"300";s:1:"N";s:6:"lslash";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:1:"0";i:2;s:3:"270";i:3;s:3:"739";}}s:6:"lslash";a:4:{s:1:"C";s:3:"248";s:2:"WX";s:3:"300";s:1:"N";s:6:"lslash";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:1:"0";i:2;s:3:"270";i:3;s:3:"739";}}i:249;a:4:{s:1:"C";s:3:"249";s:2:"WX";s:3:"653";s:1:"N";s:6:"oslash";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-39";i:2;s:3:"611";i:3;s:3:"594";}}s:6:"oslash";a:4:{s:1:"C";s:3:"249";s:2:"WX";s:3:"653";s:1:"N";s:6:"oslash";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-39";i:2;s:3:"611";i:3;s:3:"594";}}i:250;a:4:{s:1:"C";s:3:"250";s:2:"WX";s:4:"1137";s:1:"N";s:2:"oe";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:4:"1098";i:3;s:3:"560";}}s:2:"oe";a:4:{s:1:"C";s:3:"250";s:2:"WX";s:4:"1137";s:1:"N";s:2:"oe";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:4:"1098";i:3;s:3:"560";}}i:251;a:4:{s:1:"C";s:3:"251";s:2:"WX";s:3:"554";s:1:"N";s:10:"germandbls";s:1:"B";a:4:{i:0;s:2:"59";i:1;s:3:"-13";i:2;s:3:"524";i:3;s:3:"752";}}s:10:"germandbls";a:4:{s:1:"C";s:3:"251";s:2:"WX";s:3:"554";s:1:"N";s:10:"germandbls";s:1:"B";a:4:{i:0;s:2:"59";i:1;s:3:"-13";i:2;s:3:"524";i:3;s:3:"752";}}s:9:"Udieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"655";s:1:"N";s:9:"Udieresis";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:3:"-13";i:2;s:3:"579";i:3;s:3:"931";}}s:6:"Uacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"655";s:1:"N";s:6:"Uacute";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:3:"-13";i:2;s:3:"579";i:3;s:3:"964";}}s:8:"Scedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"498";s:1:"N";s:8:"Scedilla";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:4:"-213";i:2;s:3:"476";i:3;s:3:"752";}}s:6:"Tcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"426";s:1:"N";s:6:"Tcaron";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:1:"0";i:2;s:3:"419";i:3;s:3:"931";}}s:6:"Scaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"498";s:1:"N";s:6:"Scaron";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-13";i:2;s:3:"476";i:3;s:3:"931";}}s:6:"Rcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"607";s:1:"N";s:6:"Rcaron";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"577";i:3;s:3:"931";}}s:6:"Racute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"607";s:1:"N";s:6:"Racute";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"577";i:3;s:3:"964";}}s:6:"Sacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"498";s:1:"N";s:6:"Sacute";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-13";i:2;s:3:"476";i:3;s:3:"964";}}s:6:"Otilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"869";s:1:"N";s:6:"Otilde";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-13";i:2;s:3:"825";i:3;s:3:"910";}}s:11:"ucircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"608";s:1:"N";s:11:"ucircumflex";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:3:"-13";i:2;s:3:"545";i:3;s:3:"749";}}s:13:"Ohungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"869";s:1:"N";s:13:"Ohungarumlaut";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-13";i:2;s:3:"825";i:3;s:3:"962";}}s:13:"Uhungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"655";s:1:"N";s:13:"Uhungarumlaut";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:3:"-13";i:2;s:3:"579";i:3;s:3:"962";}}s:6:"Yacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"592";s:1:"N";s:6:"Yacute";s:1:"B";a:4:{i:0;s:1:"2";i:1;s:1:"0";i:2;s:3:"590";i:3;s:3:"964";}}s:3:"Eth";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"790";s:1:"N";s:3:"Eth";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"746";i:3;s:3:"739";}}s:6:"Dcroat";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"790";s:1:"N";s:6:"Dcroat";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"746";i:3;s:3:"739";}}s:6:"Zacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"480";s:1:"N";s:6:"Zacute";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:1:"0";i:2;s:3:"474";i:3;s:3:"964";}}s:5:"Uring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"655";s:1:"N";s:5:"Uring";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:3:"-13";i:2;s:3:"579";i:3;s:3:"976";}}s:6:"gbreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"673";s:1:"N";s:6:"gbreve";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:4:"-215";i:2;s:3:"610";i:3;s:3:"743";}}s:7:"eogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"650";s:1:"N";s:7:"eogonek";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:4:"-191";i:2;s:3:"611";i:3;s:3:"560";}}s:10:"edotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"650";s:1:"N";s:10:"edotaccent";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"611";i:3;s:3:"749";}}s:6:"ecaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"650";s:1:"N";s:6:"ecaron";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"611";i:3;s:3:"749";}}s:6:"Ugrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"655";s:1:"N";s:6:"Ugrave";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:3:"-13";i:2;s:3:"579";i:3;s:3:"958";}}s:5:"Thorn";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"592";s:1:"N";s:5:"Thorn";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"565";i:3;s:3:"739";}}s:6:"eacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"650";s:1:"N";s:6:"eacute";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"611";i:3;s:3:"782";}}s:9:"edieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"650";s:1:"N";s:9:"edieresis";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"611";i:3;s:3:"749";}}s:6:"dcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"725";s:1:"N";s:6:"dcaron";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"765";i:3;s:3:"739";}}s:8:"ccedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"647";s:1:"N";s:8:"ccedilla";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:4:"-224";i:2;s:3:"608";i:3;s:3:"560";}}s:6:"ccaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"647";s:1:"N";s:6:"ccaron";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"608";i:3;s:3:"749";}}s:6:"cacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"647";s:1:"N";s:6:"cacute";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"608";i:3;s:3:"782";}}s:7:"aogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"683";s:1:"N";s:7:"aogonek";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:4:"-191";i:2;s:3:"651";i:3;s:3:"560";}}s:5:"aring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"683";s:1:"N";s:5:"aring";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"620";i:3;s:3:"794";}}s:6:"atilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"683";s:1:"N";s:6:"atilde";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"620";i:3;s:3:"728";}}s:6:"abreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"683";s:1:"N";s:6:"abreve";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"620";i:3;s:3:"743";}}s:6:"egrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"650";s:1:"N";s:6:"egrave";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"611";i:3;s:3:"776";}}s:6:"agrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"683";s:1:"N";s:6:"agrave";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"620";i:3;s:3:"776";}}s:6:"aacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"683";s:1:"N";s:6:"aacute";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"620";i:3;s:3:"782";}}s:9:"adieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"683";s:1:"N";s:9:"adieresis";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"620";i:3;s:3:"749";}}s:7:"Uogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"655";s:1:"N";s:7:"Uogonek";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:4:"-191";i:2;s:3:"579";i:3;s:3:"739";}}s:6:"ugrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"608";s:1:"N";s:6:"ugrave";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:3:"-13";i:2;s:3:"545";i:3;s:3:"776";}}s:6:"uacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"608";s:1:"N";s:6:"uacute";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:3:"-13";i:2;s:3:"545";i:3;s:3:"782";}}s:9:"udieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"608";s:1:"N";s:9:"udieresis";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:3:"-13";i:2;s:3:"545";i:3;s:3:"749";}}s:6:"tcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"339";s:1:"N";s:6:"tcaron";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"379";i:3;s:3:"739";}}s:12:"scommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"388";s:1:"N";s:12:"scommaaccent";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:4:"-225";i:2;s:3:"361";i:3;s:3:"560";}}s:6:"Zcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"480";s:1:"N";s:6:"Zcaron";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:1:"0";i:2;s:3:"474";i:3;s:3:"931";}}s:11:"ecircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"650";s:1:"N";s:11:"ecircumflex";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"611";i:3;s:3:"749";}}s:11:"Ucircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"655";s:1:"N";s:11:"Ucircumflex";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:3:"-13";i:2;s:3:"579";i:3;s:3:"931";}}s:11:"acircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"683";s:1:"N";s:11:"acircumflex";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"620";i:3;s:3:"749";}}s:10:"Zdotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"480";s:1:"N";s:10:"Zdotaccent";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:1:"0";i:2;s:3:"474";i:3;s:3:"931";}}s:6:"scaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"388";s:1:"N";s:6:"scaron";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:3:"-13";i:2;s:3:"371";i:3;s:3:"749";}}s:7:"Amacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"740";s:1:"N";s:7:"Amacron";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:1:"0";i:2;s:3:"729";i:3;s:3:"889";}}s:6:"sacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"388";s:1:"N";s:6:"sacute";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:3:"-13";i:2;s:3:"361";i:3;s:3:"782";}}s:12:"Tcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"426";s:1:"N";s:12:"Tcommaaccent";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:4:"-225";i:2;s:3:"419";i:3;s:3:"739";}}s:9:"Ydieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"592";s:1:"N";s:9:"Ydieresis";s:1:"B";a:4:{i:0;s:1:"2";i:1;s:1:"0";i:2;s:3:"590";i:3;s:3:"931";}}s:5:"thorn";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"682";s:1:"N";s:5:"thorn";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:4:"-192";i:2;s:3:"640";i:3;s:3:"739";}}s:7:"Emacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"536";s:1:"N";s:7:"Emacron";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"480";i:3;s:3:"889";}}s:6:"Ograve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"869";s:1:"N";s:6:"Ograve";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-13";i:2;s:3:"825";i:3;s:3:"958";}}s:6:"Oacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"869";s:1:"N";s:6:"Oacute";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-13";i:2;s:3:"825";i:3;s:3:"964";}}s:9:"Odieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"869";s:1:"N";s:9:"Odieresis";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-13";i:2;s:3:"825";i:3;s:3:"931";}}s:6:"Ntilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"740";s:1:"N";s:6:"Ntilde";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"664";i:3;s:3:"910";}}s:6:"Ncaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"740";s:1:"N";s:6:"Ncaron";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"664";i:3;s:3:"931";}}s:6:"Nacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"740";s:1:"N";s:6:"Nacute";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"664";i:3;s:3:"964";}}s:6:"Lcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"462";s:1:"N";s:6:"Lcaron";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"456";i:3;s:3:"739";}}s:6:"Lacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"462";s:1:"N";s:6:"Lacute";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"456";i:3;s:3:"964";}}s:10:"Idotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"226";s:1:"N";s:10:"Idotaccent";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"150";i:3;s:3:"931";}}s:6:"racute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"301";s:1:"N";s:6:"racute";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:1:"0";i:2;s:3:"324";i:3;s:3:"782";}}s:11:"Icircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"226";s:1:"N";s:11:"Icircumflex";s:1:"B";a:4:{i:0;s:3:"-64";i:1;s:1:"0";i:2;s:3:"290";i:3;s:3:"931";}}s:13:"ohungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"655";s:1:"N";s:13:"ohungarumlaut";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"613";i:3;s:3:"780";}}s:6:"otilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"655";s:1:"N";s:6:"otilde";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"613";i:3;s:3:"728";}}s:4:"Euro";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"554";s:1:"N";s:4:"Euro";s:1:"B";a:4:{i:0;s:3:"-32";i:1;s:3:"-13";i:2;s:3:"573";i:3;s:3:"752";}}s:11:"ocircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"655";s:1:"N";s:11:"ocircumflex";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"613";i:3;s:3:"749";}}s:11:"onesuperior";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"332";s:1:"N";s:11:"onesuperior";s:1:"B";a:4:{i:0;s:2:"98";i:1;s:3:"288";i:2;s:3:"233";i:3;s:3:"739";}}s:11:"twosuperior";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"332";s:1:"N";s:11:"twosuperior";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:3:"288";i:2;s:3:"320";i:3;s:3:"747";}}s:13:"threesuperior";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"332";s:1:"N";s:13:"threesuperior";s:1:"B";a:4:{i:0;s:2:"13";i:1;s:3:"280";i:2;s:3:"319";i:3;s:3:"747";}}s:6:"Igrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"226";s:1:"N";s:6:"Igrave";s:1:"B";a:4:{i:0;s:2:"-2";i:1;s:1:"0";i:2;s:3:"228";i:3;s:3:"958";}}s:6:"Iacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"226";s:1:"N";s:6:"Iacute";s:1:"B";a:4:{i:0;s:2:"-1";i:1;s:1:"0";i:2;s:3:"226";i:3;s:3:"964";}}s:7:"Imacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"226";s:1:"N";s:7:"Imacron";s:1:"B";a:4:{i:0;s:3:"-56";i:1;s:1:"0";i:2;s:3:"281";i:3;s:3:"889";}}s:7:"Iogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"226";s:1:"N";s:7:"Iogonek";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:4:"-191";i:2;s:3:"181";i:3;s:3:"739";}}s:9:"Idieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"226";s:1:"N";s:9:"Idieresis";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:1:"0";i:2;s:3:"224";i:3;s:3:"931";}}s:6:"Gbreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"872";s:1:"N";s:6:"Gbreve";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-13";i:2;s:3:"831";i:3;s:3:"925";}}s:7:"Umacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"655";s:1:"N";s:7:"Umacron";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:3:"-13";i:2;s:3:"579";i:3;s:3:"889";}}s:12:"Kcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"591";s:1:"N";s:12:"Kcommaaccent";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:4:"-225";i:2;s:3:"585";i:3;s:3:"739";}}s:6:"ograve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"655";s:1:"N";s:6:"ograve";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"613";i:3;s:3:"776";}}s:12:"Scommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"498";s:1:"N";s:12:"Scommaaccent";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:4:"-225";i:2;s:3:"476";i:3;s:3:"752";}}s:7:"Eogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"536";s:1:"N";s:7:"Eogonek";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:4:"-191";i:2;s:3:"511";i:3;s:3:"739";}}s:6:"oacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"655";s:1:"N";s:6:"oacute";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"613";i:3;s:3:"782";}}s:10:"Edotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"536";s:1:"N";s:10:"Edotaccent";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"480";i:3;s:3:"931";}}s:7:"iogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"200";s:1:"N";s:7:"iogonek";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:4:"-191";i:2;s:3:"168";i:3;s:3:"739";}}s:12:"gcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"673";s:1:"N";s:12:"gcommaaccent";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:4:"-215";i:2;s:3:"610";i:3;s:3:"790";}}s:9:"odieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"655";s:1:"N";s:9:"odieresis";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"613";i:3;s:3:"749";}}s:6:"ntilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"610";s:1:"N";s:6:"ntilde";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:1:"0";i:2;s:3:"547";i:3;s:3:"728";}}s:6:"ncaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"610";s:1:"N";s:6:"ncaron";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:1:"0";i:2;s:3:"547";i:3;s:3:"749";}}s:6:"Ecaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"536";s:1:"N";s:6:"Ecaron";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"480";i:3;s:3:"931";}}s:11:"Ecircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"536";s:1:"N";s:11:"Ecircumflex";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"480";i:3;s:3:"931";}}s:8:"scedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"388";s:1:"N";s:8:"scedilla";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:4:"-213";i:2;s:3:"361";i:3;s:3:"560";}}s:6:"rcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"301";s:1:"N";s:6:"rcaron";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:1:"0";i:2;s:3:"364";i:3;s:3:"749";}}s:6:"Egrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"536";s:1:"N";s:6:"Egrave";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"480";i:3;s:3:"958";}}s:6:"Eacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"536";s:1:"N";s:6:"Eacute";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"480";i:3;s:3:"964";}}s:12:"Gcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"872";s:1:"N";s:12:"Gcommaaccent";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:4:"-225";i:2;s:3:"831";i:3;s:3:"752";}}s:12:"Rcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"607";s:1:"N";s:12:"Rcommaaccent";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:4:"-225";i:2;s:3:"577";i:3;s:3:"739";}}s:9:"Edieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"536";s:1:"N";s:9:"Edieresis";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"480";i:3;s:3:"931";}}s:6:"nacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"610";s:1:"N";s:6:"nacute";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:1:"0";i:2;s:3:"547";i:3;s:3:"782";}}s:7:"uogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"608";s:1:"N";s:7:"uogonek";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:4:"-191";i:2;s:3:"576";i:3;s:3:"547";}}s:7:"umacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"608";s:1:"N";s:7:"umacron";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:3:"-13";i:2;s:3:"545";i:3;s:3:"707";}}s:6:"Dcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"744";s:1:"N";s:6:"Dcaron";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"700";i:3;s:3:"931";}}s:6:"lcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"245";s:1:"N";s:6:"lcaron";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:1:"0";i:2;s:3:"285";i:3;s:3:"739";}}s:6:"Ccaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"813";s:1:"N";s:6:"Ccaron";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-13";i:2;s:3:"770";i:3;s:3:"931";}}s:6:"Cacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"813";s:1:"N";s:6:"Cacute";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-13";i:2;s:3:"770";i:3;s:3:"964";}}s:8:"Ccedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"813";s:1:"N";s:8:"Ccedilla";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:4:"-240";i:2;s:3:"770";i:3;s:3:"752";}}s:6:"degree";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"400";s:1:"N";s:6:"degree";s:1:"B";a:4:{i:0;s:2:"50";i:1;s:3:"380";i:2;s:3:"350";i:3;s:3:"686";}}s:7:"Aogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"740";s:1:"N";s:7:"Aogonek";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:4:"-191";i:2;s:3:"760";i:3;s:3:"739";}}s:5:"minus";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"606";s:1:"N";s:5:"minus";s:1:"B";a:4:{i:0;s:2:"51";i:1;s:3:"267";i:2;s:3:"555";i:3;s:3:"341";}}s:8:"multiply";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"606";s:1:"N";s:8:"multiply";s:1:"B";a:4:{i:0;s:2:"51";i:1;s:2:"48";i:2;s:3:"555";i:3;s:3:"551";}}s:6:"divide";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"606";s:1:"N";s:6:"divide";s:1:"B";a:4:{i:0;s:2:"51";i:1;s:3:"112";i:2;s:3:"555";i:3;s:3:"496";}}s:5:"Aring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"740";s:1:"N";s:5:"Aring";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:1:"0";i:2;s:3:"729";i:3;s:3:"976";}}s:9:"trademark";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:4:"1000";s:1:"N";s:9:"trademark";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:3:"340";i:2;s:3:"938";i:3;s:3:"739";}}s:12:"rcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"301";s:1:"N";s:12:"rcommaaccent";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:4:"-225";i:2;s:3:"292";i:3;s:3:"560";}}s:6:"lacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"200";s:1:"N";s:6:"lacute";s:1:"B";a:4:{i:0;s:3:"-14";i:1;s:1:"0";i:2;s:3:"213";i:3;s:3:"964";}}s:7:"omacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"655";s:1:"N";s:7:"omacron";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"613";i:3;s:3:"707";}}s:6:"Atilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"740";s:1:"N";s:6:"Atilde";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:1:"0";i:2;s:3:"729";i:3;s:3:"910";}}s:11:"icircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"200";s:1:"N";s:11:"icircumflex";s:1:"B";a:4:{i:0;s:3:"-77";i:1;s:1:"0";i:2;s:3:"277";i:3;s:3:"749";}}s:6:"igrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"200";s:1:"N";s:6:"igrave";s:1:"B";a:4:{i:0;s:3:"-15";i:1;s:1:"0";i:2;s:3:"215";i:3;s:3:"776";}}s:12:"ncommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"610";s:1:"N";s:12:"ncommaaccent";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:4:"-225";i:2;s:3:"547";i:3;s:3:"560";}}s:12:"lcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"200";s:1:"N";s:12:"lcommaaccent";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:4:"-225";i:2;s:3:"148";i:3;s:3:"739";}}s:9:"plusminus";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"606";s:1:"N";s:9:"plusminus";s:1:"B";a:4:{i:0;s:2:"51";i:1;s:1:"0";i:2;s:3:"555";i:3;s:3:"585";}}s:7:"onehalf";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"831";s:1:"N";s:7:"onehalf";s:1:"B";a:4:{i:0;s:2:"96";i:1;s:1:"0";i:2;s:3:"814";i:3;s:3:"739";}}s:10:"onequarter";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"831";s:1:"N";s:10:"onequarter";s:1:"B";a:4:{i:0;s:3:"101";i:1;s:1:"0";i:2;s:3:"803";i:3;s:3:"739";}}s:13:"threequarters";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"831";s:1:"N";s:13:"threequarters";s:1:"B";a:4:{i:0;s:2:"13";i:1;s:1:"0";i:2;s:3:"803";i:3;s:3:"747";}}s:6:"iacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"200";s:1:"N";s:6:"iacute";s:1:"B";a:4:{i:0;s:3:"-13";i:1;s:1:"0";i:2;s:3:"214";i:3;s:3:"782";}}s:6:"Abreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"740";s:1:"N";s:6:"Abreve";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:1:"0";i:2;s:3:"729";i:3;s:3:"925";}}s:12:"kcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"502";s:1:"N";s:12:"kcommaaccent";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:4:"-225";i:2;s:3:"497";i:3;s:3:"739";}}s:7:"Omacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"869";s:1:"N";s:7:"Omacron";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-13";i:2;s:3:"825";i:3;s:3:"889";}}s:7:"imacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"200";s:1:"N";s:7:"imacron";s:1:"B";a:4:{i:0;s:3:"-69";i:1;s:1:"0";i:2;s:3:"268";i:3;s:3:"707";}}s:7:"emacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"650";s:1:"N";s:7:"emacron";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"611";i:3;s:3:"707";}}s:7:"amacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"683";s:1:"N";s:7:"amacron";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"620";i:3;s:3:"707";}}s:12:"tcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"339";s:1:"N";s:12:"tcommaaccent";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:4:"-225";i:2;s:3:"327";i:3;s:3:"739";}}s:9:"ydieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"536";s:1:"N";s:9:"ydieresis";s:1:"B";a:4:{i:0;s:1:"9";i:1;s:4:"-192";i:2;s:3:"527";i:3;s:3:"749";}}s:10:"zdotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"425";s:1:"N";s:10:"zdotaccent";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:1:"0";i:2;s:3:"415";i:3;s:3:"749";}}s:6:"zcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"425";s:1:"N";s:6:"zcaron";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:1:"0";i:2;s:3:"415";i:3;s:3:"749";}}s:6:"zacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"425";s:1:"N";s:6:"zacute";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:1:"0";i:2;s:3:"415";i:3;s:3:"782";}}s:6:"yacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"536";s:1:"N";s:6:"yacute";s:1:"B";a:4:{i:0;s:1:"9";i:1;s:4:"-192";i:2;s:3:"527";i:3;s:3:"782";}}s:13:"uhungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"608";s:1:"N";s:13:"uhungarumlaut";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:3:"-13";i:2;s:3:"547";i:3;s:3:"780";}}s:3:"eth";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"655";s:1:"N";s:3:"eth";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"613";i:3;s:3:"756";}}s:5:"uring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"608";s:1:"N";s:5:"uring";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:3:"-13";i:2;s:3:"545";i:3;s:3:"794";}}s:11:"Ocircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"869";s:1:"N";s:11:"Ocircumflex";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-13";i:2;s:3:"825";i:3;s:3:"931";}}s:11:"commaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"351";s:1:"N";s:11:"commaaccent";s:1:"B";a:4:{i:0;s:3:"101";i:1;s:4:"-225";i:2;s:3:"223";i:3;s:3:"-53";}}s:9:"copyright";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"747";s:1:"N";s:9:"copyright";s:1:"B";a:4:{i:0;s:2:"-9";i:1;s:3:"-13";i:2;s:3:"755";i:3;s:3:"752";}}s:10:"registered";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"747";s:1:"N";s:10:"registered";s:1:"B";a:4:{i:0;s:2:"-9";i:1;s:3:"-13";i:2;s:3:"755";i:3;s:3:"752";}}s:11:"Acircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"740";s:1:"N";s:11:"Acircumflex";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:1:"0";i:2;s:3:"729";i:3;s:3:"931";}}s:9:"idieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"200";s:1:"N";s:9:"idieresis";s:1:"B";a:4:{i:0;s:3:"-10";i:1;s:1:"0";i:2;s:3:"211";i:3;s:3:"749";}}s:7:"lozenge";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"494";s:1:"N";s:7:"lozenge";s:1:"B";a:4:{i:0;s:2:"18";i:1;s:1:"0";i:2;s:3:"466";i:3;s:3:"740";}}s:5:"Delta";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"612";s:1:"N";s:5:"Delta";s:1:"B";a:4:{i:0;s:1:"6";i:1;s:1:"0";i:2;s:3:"608";i:3;s:3:"688";}}s:8:"notequal";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"549";s:1:"N";s:8:"notequal";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:2:"42";i:2;s:3:"529";i:3;s:3:"558";}}s:7:"radical";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"549";s:1:"N";s:7:"radical";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:3:"-35";i:2;s:3:"515";i:3;s:3:"913";}}s:6:"Agrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"740";s:1:"N";s:6:"Agrave";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:1:"0";i:2;s:3:"729";i:3;s:3:"958";}}s:6:"Aacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"740";s:1:"N";s:6:"Aacute";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:1:"0";i:2;s:3:"729";i:3;s:3:"964";}}s:9:"lessequal";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"549";s:1:"N";s:9:"lessequal";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"530";i:3;s:3:"646";}}s:12:"greaterequal";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"549";s:1:"N";s:12:"greaterequal";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"530";i:3;s:3:"646";}}s:10:"logicalnot";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"606";s:1:"N";s:10:"logicalnot";s:1:"B";a:4:{i:0;s:2:"51";i:1;s:3:"148";i:2;s:3:"555";i:3;s:3:"436";}}s:9:"summation";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"713";s:1:"N";s:9:"summation";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:4:"-123";i:2;s:3:"695";i:3;s:3:"752";}}s:11:"partialdiff";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"494";s:1:"N";s:11:"partialdiff";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:3:"-10";i:2;s:3:"462";i:3;s:3:"753";}}s:12:"Ncommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"740";s:1:"N";s:12:"Ncommaaccent";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:4:"-225";i:2;s:3:"664";i:3;s:3:"739";}}s:6:"dcroat";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"685";s:1:"N";s:6:"dcroat";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"685";i:3;s:3:"739";}}s:9:"brokenbar";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"672";s:1:"N";s:9:"brokenbar";s:1:"B";a:4:{i:0;s:3:"304";i:1;s:1:"0";i:2;s:3:"368";i:3;s:3:"739";}}s:12:"Lcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"462";s:1:"N";s:12:"Lcommaaccent";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:4:"-225";i:2;s:3:"456";i:3;s:3:"739";}}s:9:"Adieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"740";s:1:"N";s:9:"Adieresis";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:1:"0";i:2;s:3:"729";i:3;s:3:"931";}}s:2:"mu";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"608";s:1:"N";s:2:"mu";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:4:"-192";i:2;s:3:"545";i:3;s:3:"547";}}s:7:".notdef";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"277";s:1:"N";s:7:".notdef";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}}s:3:"KPX";a:92:{s:1:"A";a:36:{s:1:"C";s:3:"-36";s:8:"Ccedilla";s:3:"-37";s:1:"G";s:3:"-38";s:1:"O";s:3:"-38";s:9:"Odieresis";s:3:"-38";s:1:"Q";s:3:"-38";s:1:"T";s:3:"-50";s:1:"U";s:3:"-29";s:6:"Uacute";s:3:"-29";s:11:"Ucircumflex";s:3:"-29";s:9:"Udieresis";s:3:"-29";s:6:"Ugrave";s:3:"-29";s:1:"V";s:3:"-72";s:1:"W";s:3:"-47";s:1:"Y";s:3:"-77";s:1:"a";s:3:"-20";s:1:"b";s:1:"5";s:1:"c";s:3:"-22";s:8:"ccedilla";s:3:"-22";s:5:"comma";s:2:"-5";s:1:"d";s:3:"-21";s:1:"e";s:3:"-21";s:1:"g";s:3:"-23";s:13:"guillemotleft";s:3:"-22";s:13:"guilsinglleft";s:3:"-22";s:6:"hyphen";s:2:"13";s:1:"o";s:3:"-20";s:6:"period";s:2:"13";s:1:"q";s:3:"-21";s:13:"quotedblright";s:3:"-90";s:10:"quoteright";s:3:"-92";s:1:"t";s:3:"-28";s:1:"u";s:3:"-15";s:1:"v";s:3:"-39";s:1:"w";s:3:"-33";s:1:"y";s:3:"-37";}s:6:"Aacute";a:28:{s:1:"C";s:3:"-36";s:1:"G";s:3:"-38";s:1:"O";s:3:"-38";s:1:"Q";s:3:"-38";s:1:"T";s:3:"-50";s:1:"U";s:3:"-29";s:1:"V";s:3:"-72";s:1:"W";s:3:"-47";s:1:"Y";s:3:"-77";s:1:"a";s:3:"-20";s:1:"b";s:1:"5";s:1:"c";s:3:"-22";s:5:"comma";s:2:"-5";s:1:"d";s:3:"-21";s:1:"e";s:3:"-21";s:1:"g";s:3:"-23";s:13:"guillemotleft";s:3:"-22";s:13:"guilsinglleft";s:3:"-22";s:6:"hyphen";s:2:"13";s:1:"o";s:3:"-20";s:6:"period";s:2:"13";s:1:"q";s:3:"-21";s:10:"quoteright";s:3:"-92";s:1:"t";s:3:"-28";s:1:"u";s:3:"-15";s:1:"v";s:3:"-39";s:1:"w";s:3:"-33";s:1:"y";s:3:"-37";}s:11:"Acircumflex";a:11:{s:1:"C";s:3:"-36";s:1:"G";s:3:"-38";s:1:"O";s:3:"-38";s:1:"Q";s:3:"-38";s:1:"T";s:3:"-50";s:1:"U";s:3:"-29";s:1:"V";s:3:"-72";s:1:"W";s:3:"-47";s:1:"Y";s:3:"-77";s:5:"comma";s:2:"-5";s:6:"period";s:2:"13";}s:9:"Adieresis";a:28:{s:1:"C";s:3:"-36";s:1:"G";s:3:"-38";s:1:"O";s:3:"-38";s:1:"Q";s:3:"-38";s:1:"T";s:3:"-50";s:1:"U";s:3:"-29";s:1:"V";s:3:"-72";s:1:"W";s:3:"-47";s:1:"Y";s:3:"-77";s:1:"a";s:3:"-20";s:1:"b";s:1:"5";s:1:"c";s:3:"-22";s:5:"comma";s:2:"-5";s:1:"d";s:3:"-21";s:1:"g";s:3:"-23";s:13:"guillemotleft";s:3:"-22";s:13:"guilsinglleft";s:3:"-22";s:6:"hyphen";s:2:"13";s:1:"o";s:3:"-20";s:6:"period";s:2:"13";s:1:"q";s:3:"-21";s:13:"quotedblright";s:3:"-90";s:10:"quoteright";s:3:"-92";s:1:"t";s:3:"-28";s:1:"u";s:3:"-15";s:1:"v";s:3:"-39";s:1:"w";s:3:"-33";s:1:"y";s:3:"-37";}s:6:"Agrave";a:11:{s:1:"C";s:3:"-36";s:1:"G";s:3:"-38";s:1:"O";s:3:"-38";s:1:"Q";s:3:"-38";s:1:"T";s:3:"-50";s:1:"U";s:3:"-29";s:1:"V";s:3:"-72";s:1:"W";s:3:"-47";s:1:"Y";s:3:"-77";s:5:"comma";s:2:"-5";s:6:"period";s:2:"13";}s:5:"Aring";a:29:{s:1:"C";s:3:"-36";s:1:"G";s:3:"-38";s:1:"O";s:3:"-38";s:1:"Q";s:3:"-38";s:1:"T";s:3:"-50";s:1:"U";s:3:"-29";s:1:"V";s:3:"-72";s:1:"W";s:3:"-47";s:1:"Y";s:3:"-77";s:1:"a";s:3:"-20";s:1:"b";s:1:"5";s:1:"c";s:3:"-22";s:5:"comma";s:2:"-5";s:1:"d";s:3:"-21";s:1:"e";s:3:"-21";s:1:"g";s:3:"-23";s:13:"guillemotleft";s:3:"-22";s:13:"guilsinglleft";s:3:"-22";s:6:"hyphen";s:2:"13";s:1:"o";s:3:"-20";s:6:"period";s:2:"13";s:1:"q";s:3:"-21";s:13:"quotedblright";s:3:"-90";s:10:"quoteright";s:3:"-92";s:1:"t";s:3:"-28";s:1:"u";s:3:"-15";s:1:"v";s:3:"-39";s:1:"w";s:3:"-33";s:1:"y";s:3:"-37";}s:6:"Atilde";a:11:{s:1:"C";s:3:"-36";s:1:"G";s:3:"-38";s:1:"O";s:3:"-38";s:1:"Q";s:3:"-38";s:1:"T";s:3:"-50";s:1:"U";s:3:"-29";s:1:"V";s:3:"-72";s:1:"W";s:3:"-47";s:1:"Y";s:3:"-77";s:5:"comma";s:2:"-5";s:6:"period";s:2:"13";}s:1:"B";a:17:{s:1:"A";s:2:"-8";s:2:"AE";s:3:"-21";s:6:"Aacute";s:2:"-8";s:11:"Acircumflex";s:2:"-8";s:9:"Adieresis";s:2:"-8";s:5:"Aring";s:2:"-8";s:6:"Atilde";s:2:"-8";s:1:"O";s:1:"6";s:2:"OE";s:1:"7";s:6:"Oacute";s:1:"6";s:11:"Ocircumflex";s:1:"6";s:9:"Odieresis";s:1:"6";s:6:"Ograve";s:1:"6";s:6:"Oslash";s:1:"9";s:1:"V";s:3:"-24";s:1:"W";s:2:"-2";s:1:"Y";s:3:"-26";}s:1:"C";a:10:{s:1:"A";s:3:"-22";s:2:"AE";s:3:"-45";s:6:"Aacute";s:3:"-22";s:9:"Adieresis";s:3:"-22";s:5:"Aring";s:3:"-22";s:1:"H";s:1:"0";s:1:"K";s:1:"0";s:1:"O";s:3:"-18";s:6:"Oacute";s:3:"-18";s:9:"Odieresis";s:3:"-18";}s:8:"Ccedilla";a:1:{s:1:"A";s:3:"-22";}s:1:"D";a:13:{s:1:"A";s:3:"-37";s:6:"Aacute";s:3:"-37";s:11:"Acircumflex";s:3:"-37";s:9:"Adieresis";s:3:"-37";s:6:"Agrave";s:3:"-37";s:5:"Aring";s:3:"-37";s:6:"Atilde";s:3:"-37";s:1:"J";s:2:"-5";s:1:"T";s:3:"-40";s:1:"V";s:3:"-36";s:1:"W";s:3:"-14";s:1:"X";s:3:"-29";s:1:"Y";s:3:"-44";}s:1:"F";a:29:{s:1:"A";s:3:"-56";s:6:"Aacute";s:3:"-56";s:11:"Acircumflex";s:3:"-56";s:9:"Adieresis";s:3:"-56";s:6:"Agrave";s:3:"-56";s:5:"Aring";s:3:"-56";s:6:"Atilde";s:3:"-56";s:1:"J";s:3:"-55";s:1:"O";s:1:"0";s:9:"Odieresis";s:1:"0";s:1:"a";s:2:"-3";s:6:"aacute";s:2:"-3";s:9:"adieresis";s:2:"-3";s:2:"ae";s:2:"-3";s:5:"aring";s:2:"-3";s:5:"comma";s:3:"-98";s:1:"e";s:2:"-3";s:6:"eacute";s:2:"-3";s:6:"hyphen";s:2:"23";s:1:"i";s:2:"-5";s:1:"j";s:2:"-7";s:1:"o";s:2:"-3";s:6:"oacute";s:2:"-3";s:9:"odieresis";s:2:"-3";s:2:"oe";s:2:"-3";s:6:"oslash";s:2:"-5";s:6:"period";s:3:"-80";s:1:"r";s:3:"-11";s:1:"u";s:3:"-11";}s:1:"G";a:12:{s:1:"A";s:3:"-40";s:2:"AE";s:3:"-64";s:6:"Aacute";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:1:"T";s:3:"-45";s:1:"V";s:3:"-43";s:1:"W";s:3:"-22";s:1:"Y";s:3:"-48";}s:1:"J";a:4:{s:1:"A";s:3:"-27";s:2:"AE";s:3:"-39";s:9:"Adieresis";s:3:"-27";s:5:"Aring";s:3:"-27";}s:1:"K";a:20:{s:1:"C";s:3:"-36";s:1:"G";s:3:"-38";s:1:"O";s:3:"-38";s:2:"OE";s:3:"-37";s:6:"Oacute";s:3:"-38";s:9:"Odieresis";s:3:"-38";s:1:"S";s:3:"-16";s:1:"T";s:2:"37";s:1:"a";s:3:"-44";s:9:"adieresis";s:3:"-44";s:2:"ae";s:3:"-44";s:5:"aring";s:3:"-44";s:1:"e";s:3:"-45";s:6:"hyphen";s:3:"-29";s:1:"o";s:3:"-44";s:6:"oacute";s:3:"-44";s:9:"odieresis";s:3:"-44";s:1:"u";s:3:"-38";s:9:"udieresis";s:3:"-38";s:1:"y";s:3:"-44";}s:1:"L";a:27:{s:1:"A";s:2:"34";s:2:"AE";s:2:"34";s:6:"Aacute";s:2:"34";s:9:"Adieresis";s:2:"34";s:5:"Aring";s:2:"34";s:1:"C";s:3:"-46";s:8:"Ccedilla";s:3:"-49";s:1:"G";s:3:"-48";s:1:"O";s:3:"-49";s:6:"Oacute";s:3:"-49";s:11:"Ocircumflex";s:3:"-49";s:9:"Odieresis";s:3:"-49";s:6:"Ograve";s:3:"-49";s:6:"Otilde";s:3:"-49";s:1:"S";s:1:"7";s:1:"T";s:3:"-47";s:1:"U";s:3:"-25";s:9:"Udieresis";s:3:"-25";s:1:"V";s:4:"-100";s:1:"W";s:3:"-59";s:1:"Y";s:3:"-88";s:6:"hyphen";s:3:"-79";s:13:"quotedblright";s:4:"-114";s:10:"quoteright";s:4:"-116";s:1:"u";s:3:"-14";s:9:"udieresis";s:3:"-14";s:1:"y";s:3:"-59";}s:1:"N";a:26:{s:1:"A";s:1:"0";s:2:"AE";s:2:"-1";s:6:"Aacute";s:1:"0";s:9:"Adieresis";s:1:"0";s:5:"Aring";s:1:"0";s:1:"C";s:2:"10";s:8:"Ccedilla";s:2:"11";s:1:"G";s:1:"9";s:1:"O";s:1:"9";s:6:"Oacute";s:1:"9";s:9:"Odieresis";s:1:"9";s:1:"a";s:1:"8";s:6:"aacute";s:1:"8";s:9:"adieresis";s:1:"8";s:2:"ae";s:1:"7";s:5:"aring";s:1:"8";s:5:"comma";s:3:"-15";s:1:"e";s:1:"7";s:6:"eacute";s:1:"7";s:1:"o";s:1:"8";s:6:"oacute";s:1:"8";s:9:"odieresis";s:1:"8";s:6:"oslash";s:1:"9";s:6:"period";s:1:"3";s:1:"u";s:2:"13";s:9:"udieresis";s:2:"13";}s:1:"O";a:10:{s:1:"A";s:3:"-39";s:2:"AE";s:3:"-68";s:6:"Aacute";s:3:"-39";s:9:"Adieresis";s:3:"-39";s:5:"Aring";s:3:"-39";s:1:"T";s:3:"-42";s:1:"V";s:3:"-38";s:1:"W";s:3:"-16";s:1:"X";s:3:"-31";s:1:"Y";s:3:"-46";}s:6:"Oacute";a:5:{s:1:"A";s:3:"-39";s:1:"T";s:3:"-42";s:1:"V";s:3:"-38";s:1:"W";s:3:"-16";s:1:"Y";s:3:"-46";}s:11:"Ocircumflex";a:3:{s:1:"T";s:3:"-42";s:1:"V";s:3:"-38";s:1:"Y";s:3:"-46";}s:9:"Odieresis";a:6:{s:1:"A";s:3:"-39";s:1:"T";s:3:"-42";s:1:"V";s:3:"-38";s:1:"W";s:3:"-16";s:1:"X";s:3:"-31";s:1:"Y";s:3:"-46";}s:6:"Ograve";a:3:{s:1:"T";s:3:"-42";s:1:"V";s:3:"-38";s:1:"Y";s:3:"-46";}s:6:"Oslash";a:1:{s:1:"A";s:3:"-36";}s:6:"Otilde";a:3:{s:1:"T";s:3:"-42";s:1:"V";s:3:"-38";s:1:"Y";s:3:"-46";}s:1:"P";a:21:{s:1:"A";s:3:"-61";s:2:"AE";s:4:"-108";s:6:"Aacute";s:3:"-61";s:9:"Adieresis";s:3:"-61";s:5:"Aring";s:3:"-61";s:1:"J";s:3:"-68";s:1:"a";s:3:"-16";s:6:"aacute";s:3:"-16";s:9:"adieresis";s:3:"-16";s:2:"ae";s:3:"-16";s:5:"aring";s:3:"-16";s:5:"comma";s:4:"-125";s:1:"e";s:3:"-15";s:6:"eacute";s:3:"-15";s:6:"hyphen";s:2:"-4";s:1:"o";s:3:"-15";s:6:"oacute";s:3:"-15";s:9:"odieresis";s:3:"-15";s:2:"oe";s:3:"-15";s:6:"oslash";s:3:"-19";s:6:"period";s:4:"-106";}s:1:"R";a:29:{s:1:"C";s:1:"2";s:8:"Ccedilla";s:1:"3";s:1:"G";s:1:"1";s:1:"O";s:1:"2";s:2:"OE";s:1:"2";s:6:"Oacute";s:1:"2";s:9:"Odieresis";s:1:"2";s:1:"T";s:2:"-4";s:1:"U";s:2:"11";s:9:"Udieresis";s:2:"11";s:1:"V";s:3:"-11";s:1:"W";s:2:"-3";s:1:"Y";s:3:"-14";s:1:"a";s:2:"-7";s:6:"aacute";s:2:"-7";s:9:"adieresis";s:2:"-7";s:2:"ae";s:2:"-7";s:5:"aring";s:2:"-7";s:1:"e";s:2:"-7";s:6:"eacute";s:2:"-7";s:6:"hyphen";s:1:"3";s:1:"o";s:2:"-7";s:6:"oacute";s:2:"-7";s:9:"odieresis";s:2:"-7";s:2:"oe";s:2:"-7";s:1:"u";s:1:"7";s:6:"uacute";s:1:"7";s:9:"udieresis";s:1:"7";s:1:"y";s:2:"20";}s:1:"S";a:10:{s:1:"A";s:2:"-5";s:2:"AE";s:3:"-16";s:6:"Aacute";s:2:"-5";s:9:"Adieresis";s:2:"-5";s:5:"Aring";s:2:"-5";s:1:"T";s:1:"3";s:1:"V";s:2:"-9";s:1:"W";s:1:"3";s:1:"Y";s:3:"-10";s:1:"t";s:2:"17";}s:1:"T";a:45:{s:1:"A";s:3:"-50";s:2:"AE";s:3:"-51";s:6:"Aacute";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:1:"C";s:3:"-40";s:1:"G";s:3:"-41";s:1:"J";s:3:"-49";s:1:"O";s:3:"-42";s:2:"OE";s:3:"-40";s:6:"Oacute";s:3:"-42";s:11:"Ocircumflex";s:3:"-42";s:9:"Odieresis";s:3:"-42";s:6:"Ograve";s:3:"-42";s:6:"Oslash";s:3:"-38";s:6:"Otilde";s:3:"-42";s:1:"S";s:1:"0";s:1:"V";s:2:"34";s:1:"W";s:2:"35";s:1:"Y";s:2:"38";s:1:"a";s:3:"-48";s:2:"ae";s:3:"-48";s:1:"c";s:3:"-49";s:5:"colon";s:3:"-53";s:5:"comma";s:3:"-65";s:1:"e";s:3:"-48";s:1:"g";s:3:"-48";s:13:"guillemotleft";s:3:"-42";s:13:"guilsinglleft";s:3:"-42";s:6:"hyphen";s:3:"-11";s:1:"i";s:1:"8";s:1:"j";s:1:"6";s:1:"o";s:3:"-48";s:6:"oslash";s:3:"-45";s:6:"period";s:3:"-47";s:1:"r";s:3:"-33";s:1:"s";s:3:"-32";s:9:"semicolon";s:3:"-62";s:1:"u";s:3:"-40";s:1:"v";s:3:"-50";s:1:"w";s:3:"-49";s:1:"y";s:3:"-50";}s:1:"U";a:13:{s:1:"A";s:3:"-30";s:2:"AE";s:3:"-50";s:6:"Aacute";s:3:"-30";s:11:"Acircumflex";s:3:"-30";s:9:"Adieresis";s:3:"-30";s:5:"Aring";s:3:"-30";s:6:"Atilde";s:3:"-30";s:5:"comma";s:3:"-36";s:1:"m";s:2:"13";s:1:"n";s:2:"13";s:1:"p";s:2:"13";s:6:"period";s:3:"-15";s:1:"r";s:2:"13";}s:6:"Uacute";a:7:{s:1:"A";s:3:"-30";s:5:"comma";s:3:"-36";s:1:"m";s:2:"13";s:1:"n";s:2:"13";s:1:"p";s:2:"13";s:6:"period";s:3:"-15";s:1:"r";s:2:"13";}s:11:"Ucircumflex";a:1:{s:1:"A";s:3:"-30";}s:9:"Udieresis";a:8:{s:1:"A";s:3:"-30";s:1:"b";s:2:"13";s:5:"comma";s:3:"-36";s:1:"m";s:2:"13";s:1:"n";s:2:"13";s:1:"p";s:2:"13";s:6:"period";s:3:"-15";s:1:"r";s:2:"13";}s:6:"Ugrave";a:1:{s:1:"A";s:3:"-30";}s:1:"V";a:36:{s:1:"A";s:3:"-72";s:2:"AE";s:4:"-118";s:6:"Aacute";s:3:"-72";s:11:"Acircumflex";s:3:"-72";s:9:"Adieresis";s:3:"-72";s:6:"Agrave";s:3:"-72";s:5:"Aring";s:3:"-72";s:6:"Atilde";s:3:"-72";s:1:"C";s:3:"-37";s:1:"G";s:3:"-38";s:1:"O";s:3:"-39";s:6:"Oacute";s:3:"-39";s:11:"Ocircumflex";s:3:"-39";s:9:"Odieresis";s:3:"-39";s:6:"Ograve";s:3:"-39";s:6:"Oslash";s:3:"-35";s:6:"Otilde";s:3:"-39";s:1:"S";s:3:"-12";s:1:"T";s:2:"35";s:1:"a";s:3:"-59";s:2:"ae";s:3:"-59";s:5:"colon";s:3:"-60";s:5:"comma";s:4:"-110";s:1:"e";s:3:"-59";s:1:"g";s:3:"-59";s:13:"guillemotleft";s:3:"-49";s:13:"guilsinglleft";s:3:"-49";s:6:"hyphen";s:3:"-25";s:1:"i";s:1:"6";s:1:"o";s:3:"-59";s:6:"oslash";s:3:"-58";s:6:"period";s:3:"-92";s:1:"r";s:3:"-32";s:9:"semicolon";s:3:"-70";s:1:"u";s:3:"-34";s:1:"y";s:2:"-8";}s:1:"W";a:36:{s:1:"A";s:3:"-48";s:2:"AE";s:3:"-73";s:6:"Aacute";s:3:"-48";s:11:"Acircumflex";s:3:"-48";s:9:"Adieresis";s:3:"-48";s:6:"Agrave";s:3:"-48";s:5:"Aring";s:3:"-48";s:6:"Atilde";s:3:"-48";s:1:"C";s:3:"-14";s:1:"G";s:3:"-15";s:1:"O";s:3:"-16";s:6:"Oacute";s:3:"-16";s:11:"Ocircumflex";s:3:"-16";s:9:"Odieresis";s:3:"-16";s:6:"Ograve";s:3:"-16";s:6:"Oslash";s:3:"-12";s:6:"Otilde";s:3:"-16";s:1:"S";s:1:"0";s:1:"T";s:2:"35";s:1:"a";s:3:"-30";s:2:"ae";s:3:"-30";s:5:"colon";s:3:"-38";s:5:"comma";s:3:"-71";s:1:"e";s:3:"-30";s:1:"g";s:3:"-30";s:13:"guillemotleft";s:3:"-21";s:13:"guilsinglleft";s:3:"-21";s:6:"hyphen";s:1:"3";s:1:"i";s:1:"6";s:1:"o";s:3:"-30";s:6:"oslash";s:3:"-28";s:6:"period";s:3:"-53";s:1:"r";s:3:"-15";s:9:"semicolon";s:3:"-47";s:1:"u";s:3:"-21";s:1:"y";s:1:"4";}s:1:"X";a:10:{s:1:"C";s:3:"-29";s:1:"O";s:3:"-31";s:9:"Odieresis";s:3:"-31";s:1:"Q";s:3:"-30";s:1:"a";s:3:"-36";s:1:"e";s:3:"-37";s:6:"hyphen";s:3:"-17";s:1:"o";s:3:"-36";s:1:"u";s:3:"-29";s:1:"y";s:3:"-37";}s:1:"Y";a:36:{s:1:"A";s:3:"-78";s:2:"AE";s:3:"-93";s:6:"Aacute";s:3:"-78";s:11:"Acircumflex";s:3:"-78";s:9:"Adieresis";s:3:"-78";s:6:"Agrave";s:3:"-78";s:5:"Aring";s:3:"-78";s:6:"Atilde";s:3:"-78";s:1:"C";s:3:"-44";s:1:"G";s:3:"-46";s:1:"O";s:3:"-46";s:6:"Oacute";s:3:"-46";s:11:"Ocircumflex";s:3:"-46";s:9:"Odieresis";s:3:"-46";s:6:"Ograve";s:3:"-46";s:6:"Oslash";s:3:"-42";s:6:"Otilde";s:3:"-46";s:1:"S";s:3:"-13";s:1:"T";s:2:"39";s:1:"a";s:3:"-68";s:2:"ae";s:3:"-68";s:5:"colon";s:3:"-69";s:5:"comma";s:4:"-107";s:1:"e";s:3:"-68";s:1:"g";s:3:"-68";s:13:"guillemotleft";s:3:"-63";s:13:"guilsinglleft";s:3:"-62";s:6:"hyphen";s:3:"-45";s:1:"i";s:2:"10";s:1:"o";s:3:"-68";s:6:"oslash";s:3:"-66";s:1:"p";s:3:"-38";s:6:"period";s:3:"-89";s:9:"semicolon";s:3:"-78";s:1:"u";s:3:"-40";s:1:"v";s:3:"-14";}s:1:"Z";a:2:{s:1:"v";s:2:"-8";s:1:"y";s:2:"-8";}s:1:"a";a:5:{s:1:"j";s:2:"14";s:10:"quoteright";s:2:"-7";s:1:"v";s:1:"5";s:1:"w";s:1:"6";s:1:"y";s:1:"5";}s:6:"aacute";a:3:{s:1:"v";s:1:"5";s:1:"w";s:1:"6";s:1:"y";s:1:"5";}s:9:"adieresis";a:3:{s:1:"v";s:1:"5";s:1:"w";s:1:"6";s:1:"y";s:1:"5";}s:2:"ae";a:3:{s:1:"v";s:3:"-23";s:1:"w";s:3:"-20";s:1:"y";s:3:"-22";}s:6:"agrave";a:3:{s:1:"v";s:1:"5";s:1:"w";s:1:"6";s:1:"y";s:1:"5";}s:5:"aring";a:3:{s:1:"v";s:1:"5";s:1:"w";s:1:"6";s:1:"y";s:1:"5";}s:1:"b";a:3:{s:1:"v";s:3:"-25";s:1:"w";s:3:"-19";s:1:"y";s:3:"-23";}s:1:"c";a:2:{s:1:"h";s:2:"-4";s:1:"k";s:2:"-4";}s:5:"comma";a:3:{s:3:"one";s:3:"-64";s:13:"quotedblright";s:3:"-17";s:10:"quoteright";s:3:"-19";}s:1:"e";a:6:{s:10:"quoteright";s:3:"-31";s:1:"t";s:3:"-23";s:1:"v";s:3:"-24";s:1:"w";s:3:"-20";s:1:"x";s:3:"-20";s:1:"y";s:3:"-23";}s:6:"eacute";a:3:{s:1:"v";s:3:"-24";s:1:"w";s:3:"-20";s:1:"y";s:3:"-23";}s:11:"ecircumflex";a:3:{s:1:"v";s:3:"-24";s:1:"w";s:3:"-20";s:1:"y";s:3:"-23";}s:5:"eight";a:3:{s:4:"four";s:2:"17";s:3:"one";s:3:"-84";s:5:"seven";s:3:"-43";}s:1:"f";a:19:{s:1:"a";s:3:"-20";s:6:"aacute";s:3:"-20";s:9:"adieresis";s:3:"-20";s:2:"ae";s:3:"-21";s:5:"aring";s:3:"-20";s:1:"e";s:3:"-19";s:6:"eacute";s:3:"-19";s:1:"f";s:2:"32";s:1:"i";s:1:"9";s:1:"j";s:1:"7";s:1:"l";s:1:"9";s:1:"o";s:3:"-19";s:6:"oacute";s:3:"-19";s:9:"odieresis";s:3:"-19";s:2:"oe";s:3:"-19";s:6:"oslash";s:3:"-24";s:10:"quoteright";s:2:"-5";s:1:"s";s:2:"13";s:1:"t";s:2:"34";}s:4:"five";a:3:{s:4:"four";s:2:"24";s:3:"one";s:3:"-77";s:5:"seven";s:3:"-32";}s:4:"four";a:3:{s:4:"four";s:2:"24";s:3:"one";s:3:"-81";s:5:"seven";s:3:"-35";}s:1:"g";a:10:{s:1:"a";s:1:"7";s:9:"adieresis";s:1:"7";s:2:"ae";s:1:"7";s:5:"aring";s:1:"7";s:1:"e";s:1:"7";s:6:"eacute";s:1:"7";s:1:"l";s:2:"16";s:6:"oacute";s:1:"7";s:9:"odieresis";s:1:"7";s:1:"r";s:2:"16";}s:14:"guillemotright";a:9:{s:1:"A";s:3:"-22";s:2:"AE";s:3:"-60";s:6:"Aacute";s:3:"-22";s:9:"Adieresis";s:3:"-22";s:5:"Aring";s:3:"-22";s:1:"T";s:3:"-42";s:1:"V";s:3:"-48";s:1:"W";s:3:"-21";s:1:"Y";s:3:"-62";}s:14:"guilsinglright";a:9:{s:1:"A";s:3:"-22";s:2:"AE";s:3:"-60";s:6:"Aacute";s:3:"-22";s:9:"Adieresis";s:3:"-22";s:5:"Aring";s:3:"-22";s:1:"T";s:3:"-41";s:1:"V";s:3:"-48";s:1:"W";s:3:"-21";s:1:"Y";s:3:"-61";}s:1:"h";a:2:{s:10:"quoteright";s:3:"-30";s:1:"y";s:3:"-17";}s:6:"hyphen";a:9:{s:1:"A";s:2:"13";s:2:"AE";s:3:"-21";s:6:"Aacute";s:2:"13";s:9:"Adieresis";s:2:"13";s:5:"Aring";s:2:"13";s:1:"T";s:3:"-11";s:1:"V";s:3:"-24";s:1:"W";s:1:"4";s:1:"Y";s:3:"-43";}s:1:"i";a:2:{s:1:"T";s:1:"8";s:1:"j";s:2:"13";}s:1:"k";a:17:{s:1:"a";s:3:"-28";s:6:"aacute";s:3:"-28";s:9:"adieresis";s:3:"-28";s:2:"ae";s:3:"-28";s:5:"aring";s:3:"-28";s:5:"comma";s:3:"-21";s:1:"e";s:3:"-28";s:6:"eacute";s:3:"-28";s:1:"g";s:3:"-29";s:6:"hyphen";s:3:"-36";s:1:"o";s:3:"-28";s:6:"oacute";s:3:"-28";s:9:"odieresis";s:3:"-28";s:6:"period";s:2:"-7";s:1:"s";s:2:"-5";s:1:"u";s:1:"1";s:9:"udieresis";s:1:"1";}s:1:"l";a:2:{s:1:"v";s:1:"5";s:1:"y";s:1:"5";}s:1:"m";a:4:{s:1:"p";s:2:"14";s:1:"v";s:3:"-17";s:1:"w";s:3:"-12";s:1:"y";s:3:"-15";}s:1:"n";a:6:{s:1:"T";s:3:"-41";s:1:"p";s:2:"13";s:10:"quoteright";s:3:"-30";s:1:"v";s:3:"-19";s:1:"w";s:3:"-14";s:1:"y";s:3:"-17";}s:4:"nine";a:3:{s:4:"four";s:3:"-33";s:3:"one";s:3:"-77";s:5:"seven";s:3:"-31";}s:1:"o";a:7:{s:1:"T";s:3:"-47";s:10:"quoteright";s:3:"-31";s:1:"t";s:3:"-22";s:1:"v";s:3:"-24";s:1:"w";s:3:"-18";s:1:"x";s:3:"-18";s:1:"y";s:3:"-21";}s:6:"oacute";a:3:{s:1:"v";s:3:"-24";s:1:"w";s:3:"-18";s:1:"y";s:3:"-21";}s:11:"ocircumflex";a:1:{s:1:"t";s:3:"-22";}s:9:"odieresis";a:5:{s:1:"t";s:3:"-22";s:1:"v";s:3:"-24";s:1:"w";s:3:"-18";s:1:"x";s:3:"-18";s:1:"y";s:3:"-21";}s:6:"ograve";a:3:{s:1:"v";s:3:"-24";s:1:"w";s:3:"-18";s:1:"y";s:3:"-21";}s:3:"one";a:12:{s:5:"comma";s:3:"-77";s:5:"eight";s:3:"-46";s:4:"five";s:3:"-46";s:4:"four";s:3:"-62";s:4:"nine";s:3:"-52";s:3:"one";s:4:"-133";s:6:"period";s:3:"-58";s:5:"seven";s:3:"-88";s:3:"six";s:3:"-49";s:5:"three";s:3:"-55";s:3:"two";s:3:"-51";s:4:"zero";s:3:"-27";}s:1:"p";a:2:{s:1:"t";s:3:"-23";s:1:"y";s:3:"-23";}s:6:"period";a:3:{s:3:"one";s:4:"-100";s:13:"quotedblright";s:3:"-56";s:10:"quoteright";s:3:"-58";}s:1:"q";a:2:{s:1:"c";s:1:"7";s:1:"u";s:2:"13";}s:12:"quotedblbase";a:6:{s:1:"A";s:1:"6";s:2:"AE";s:2:"-8";s:1:"T";s:3:"-52";s:1:"V";s:3:"-96";s:1:"W";s:3:"-57";s:1:"Y";s:3:"-93";}s:12:"quotedblleft";a:9:{s:1:"A";s:3:"-95";s:2:"AE";s:4:"-172";s:6:"Aacute";s:3:"-95";s:9:"Adieresis";s:3:"-95";s:5:"Aring";s:3:"-95";s:1:"T";s:3:"-19";s:1:"V";s:1:"3";s:1:"W";s:2:"12";s:1:"Y";s:1:"0";}s:13:"quotedblright";a:9:{s:1:"A";s:4:"-101";s:2:"AE";s:4:"-179";s:6:"Aacute";s:4:"-101";s:9:"Adieresis";s:4:"-101";s:5:"Aring";s:4:"-101";s:1:"T";s:2:"-5";s:1:"V";s:1:"0";s:1:"W";s:1:"7";s:1:"Y";s:2:"-4";}s:9:"quoteleft";a:9:{s:1:"A";s:3:"-92";s:2:"AE";s:4:"-170";s:6:"Aacute";s:3:"-92";s:9:"Adieresis";s:3:"-92";s:5:"Aring";s:3:"-92";s:1:"T";s:3:"-17";s:1:"V";s:1:"6";s:1:"W";s:2:"14";s:1:"Y";s:1:"2";}s:10:"quoteright";a:15:{s:1:"A";s:4:"-105";s:2:"AE";s:4:"-183";s:6:"Aacute";s:4:"-105";s:9:"Adieresis";s:4:"-105";s:5:"Aring";s:4:"-105";s:5:"comma";s:4:"-100";s:1:"d";s:3:"-56";s:1:"o";s:3:"-55";s:6:"period";s:3:"-80";s:1:"r";s:3:"-30";s:1:"s";s:3:"-27";s:1:"t";s:3:"-32";s:1:"v";s:3:"-21";s:1:"w";s:3:"-19";s:1:"y";s:3:"-21";}s:1:"r";a:47:{s:1:"a";s:3:"-28";s:6:"aacute";s:3:"-28";s:11:"acircumflex";s:3:"-28";s:9:"adieresis";s:3:"-28";s:2:"ae";s:3:"-28";s:6:"agrave";s:3:"-28";s:5:"aring";s:3:"-28";s:1:"c";s:3:"-30";s:8:"ccedilla";s:3:"-25";s:5:"colon";s:3:"-12";s:5:"comma";s:3:"-70";s:1:"d";s:3:"-29";s:1:"e";s:3:"-28";s:6:"eacute";s:3:"-28";s:11:"ecircumflex";s:3:"-28";s:6:"egrave";s:3:"-28";s:1:"f";s:2:"29";s:1:"g";s:3:"-18";s:1:"h";s:1:"6";s:6:"hyphen";s:3:"-19";s:1:"i";s:1:"6";s:1:"j";s:1:"4";s:1:"k";s:1:"6";s:1:"l";s:1:"6";s:1:"m";s:1:"6";s:1:"n";s:1:"6";s:1:"o";s:3:"-28";s:6:"oacute";s:3:"-28";s:11:"ocircumflex";s:3:"-28";s:9:"odieresis";s:3:"-28";s:2:"oe";s:3:"-27";s:6:"ograve";s:3:"-28";s:6:"oslash";s:3:"-33";s:1:"p";s:1:"6";s:6:"period";s:3:"-53";s:1:"q";s:3:"-29";s:10:"quoteright";s:2:"-8";s:1:"r";s:1:"6";s:1:"s";s:1:"8";s:9:"semicolon";s:3:"-24";s:1:"t";s:2:"31";s:1:"u";s:1:"6";s:1:"v";s:2:"32";s:1:"w";s:2:"33";s:1:"x";s:2:"31";s:1:"y";s:2:"32";s:1:"z";s:2:"27";}s:1:"s";a:2:{s:10:"quoteright";s:3:"-16";s:1:"t";s:1:"8";}s:5:"seven";a:11:{s:5:"colon";s:3:"-75";s:5:"comma";s:4:"-133";s:5:"eight";s:3:"-41";s:4:"five";s:3:"-47";s:4:"four";s:3:"-81";s:3:"one";s:3:"-65";s:6:"period";s:4:"-115";s:5:"seven";s:3:"-20";s:3:"six";s:3:"-60";s:5:"three";s:3:"-42";s:3:"two";s:3:"-27";}s:3:"six";a:3:{s:4:"four";s:2:"24";s:3:"one";s:3:"-94";s:5:"seven";s:3:"-64";}s:1:"t";a:15:{s:1:"S";s:2:"14";s:1:"a";s:3:"-25";s:6:"aacute";s:3:"-25";s:9:"adieresis";s:3:"-25";s:2:"ae";s:3:"-25";s:5:"aring";s:3:"-25";s:5:"colon";s:3:"-13";s:1:"e";s:3:"-24";s:6:"eacute";s:3:"-24";s:1:"h";s:1:"4";s:1:"o";s:3:"-24";s:6:"oacute";s:3:"-24";s:9:"odieresis";s:3:"-24";s:10:"quoteright";s:2:"-9";s:9:"semicolon";s:3:"-25";}s:5:"three";a:3:{s:4:"four";s:2:"12";s:3:"one";s:3:"-91";s:5:"seven";s:3:"-51";}s:3:"two";a:3:{s:4:"four";s:3:"-19";s:3:"one";s:3:"-81";s:5:"seven";s:3:"-35";}s:1:"u";a:1:{s:10:"quoteright";s:2:"-7";}s:1:"v";a:26:{s:1:"a";s:3:"-25";s:6:"aacute";s:3:"-25";s:11:"acircumflex";s:3:"-25";s:9:"adieresis";s:3:"-25";s:2:"ae";s:3:"-25";s:6:"agrave";s:3:"-25";s:5:"aring";s:3:"-25";s:6:"atilde";s:3:"-25";s:1:"c";s:3:"-26";s:5:"colon";s:3:"-21";s:5:"comma";s:3:"-87";s:1:"e";s:3:"-25";s:6:"eacute";s:3:"-25";s:11:"ecircumflex";s:3:"-25";s:6:"egrave";s:3:"-25";s:1:"g";s:3:"-21";s:6:"hyphen";s:1:"0";s:1:"l";s:1:"6";s:1:"o";s:3:"-25";s:6:"oacute";s:3:"-25";s:9:"odieresis";s:3:"-25";s:6:"ograve";s:3:"-25";s:6:"oslash";s:3:"-24";s:6:"period";s:3:"-70";s:1:"s";s:2:"-2";s:9:"semicolon";s:3:"-31";}s:1:"w";a:26:{s:1:"a";s:3:"-20";s:6:"aacute";s:3:"-20";s:11:"acircumflex";s:3:"-20";s:9:"adieresis";s:3:"-20";s:2:"ae";s:3:"-20";s:6:"agrave";s:3:"-20";s:5:"aring";s:3:"-20";s:6:"atilde";s:3:"-20";s:1:"c";s:3:"-21";s:5:"colon";s:3:"-19";s:5:"comma";s:3:"-79";s:1:"e";s:3:"-20";s:6:"eacute";s:3:"-20";s:11:"ecircumflex";s:3:"-20";s:6:"egrave";s:3:"-20";s:1:"g";s:3:"-18";s:6:"hyphen";s:1:"6";s:1:"l";s:1:"7";s:1:"o";s:3:"-20";s:6:"oacute";s:3:"-20";s:9:"odieresis";s:3:"-20";s:6:"ograve";s:3:"-20";s:6:"oslash";s:3:"-19";s:6:"period";s:3:"-62";s:1:"s";s:1:"0";s:9:"semicolon";s:3:"-29";}s:1:"x";a:6:{s:1:"a";s:3:"-19";s:1:"c";s:3:"-20";s:1:"e";s:3:"-19";s:6:"eacute";s:3:"-19";s:1:"o";s:3:"-19";s:1:"q";s:3:"-19";}s:1:"y";a:26:{s:1:"a";s:3:"-26";s:6:"aacute";s:3:"-26";s:11:"acircumflex";s:3:"-26";s:9:"adieresis";s:3:"-26";s:2:"ae";s:3:"-26";s:6:"agrave";s:3:"-26";s:5:"aring";s:3:"-26";s:6:"atilde";s:3:"-26";s:1:"c";s:3:"-27";s:5:"colon";s:3:"-21";s:5:"comma";s:3:"-89";s:1:"e";s:3:"-26";s:6:"eacute";s:3:"-26";s:11:"ecircumflex";s:3:"-26";s:6:"egrave";s:3:"-26";s:1:"g";s:3:"-22";s:6:"hyphen";s:1:"0";s:1:"l";s:1:"6";s:1:"o";s:3:"-26";s:6:"oacute";s:3:"-26";s:9:"odieresis";s:3:"-26";s:6:"ograve";s:3:"-26";s:6:"oslash";s:3:"-25";s:6:"period";s:3:"-72";s:1:"s";s:2:"-3";s:9:"semicolon";s:3:"-31";}s:4:"zero";a:3:{s:4:"four";s:2:"22";s:3:"one";s:3:"-66";s:5:"seven";s:3:"-30";}}s:9:"_version_";i:1;}
\ No newline at end of file
Added: trunk/mapbender/http/classes/fonts/php_a010013l.afm
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/fonts/php_a010013l.afm?view=auto&rev=13
--- (empty file)
+++ trunk/mapbender/http/classes/fonts/php_a010013l.afm 2006-04-13 19:38:28+0000
@@ -0,0 +1 @@
+a:19:{s:8:"FontName";s:15:"URWGothicL-Book";s:8:"FullName";s:17:"URW Gothic L Book";s:10:"FamilyName";s:12:"URW Gothic L";s:6:"Weight";s:4:"Book";s:11:"ItalicAngle";s:3:"0.0";s:12:"IsFixedPitch";s:5:"false";s:17:"UnderlinePosition";s:3:"-96";s:18:"UnderlineThickness";s:2:"58";s:7:"Version";s:4:"1.05";s:14:"EncodingScheme";s:21:"AdobeStandardEncoding";s:8:"FontBBox";a:4:{i:0;s:4:"-115";i:1;s:4:"-240";i:2;s:4:"1151";i:3;s:3:"976";}s:9:"CapHeight";s:3:"739";s:7:"XHeight";s:3:"547";s:9:"Descender";s:4:"-192";s:8:"Ascender";s:3:"739";s:16:"StartCharMetrics";s:3:"316";s:1:"C";a:465:{i:32;a:4:{s:1:"C";s:2:"32";s:2:"WX";s:3:"277";s:1:"N";s:5:"space";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}s:5:"space";a:4:{s:1:"C";s:2:"32";s:2:"WX";s:3:"277";s:1:"N";s:5:"space";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}i:33;a:4:{s:1:"C";s:2:"33";s:2:"WX";s:3:"295";s:1:"N";s:6:"exclam";s:1:"B";a:4:{i:0;s:3:"111";i:1;s:1:"0";i:2;s:3:"185";i:3;s:3:"739";}}s:6:"exclam";a:4:{s:1:"C";s:2:"33";s:2:"WX";s:3:"295";s:1:"N";s:6:"exclam";s:1:"B";a:4:{i:0;s:3:"111";i:1;s:1:"0";i:2;s:3:"185";i:3;s:3:"739";}}i:34;a:4:{s:1:"C";s:2:"34";s:2:"WX";s:3:"309";s:1:"N";s:8:"quotedbl";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"513";i:2;s:3:"237";i:3;s:3:"739";}}s:8:"quotedbl";a:4:{s:1:"C";s:2:"34";s:2:"WX";s:3:"309";s:1:"N";s:8:"quotedbl";s:1:"B";a:4:{i:0;s:2:"74";i:1;s:3:"513";i:2;s:3:"237";i:3;s:3:"739";}}i:35;a:4:{s:1:"C";s:2:"35";s:2:"WX";s:3:"554";s:1:"N";s:10:"numbersign";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:1:"0";i:2;s:3:"549";i:3;s:3:"739";}}s:10:"numbersign";a:4:{s:1:"C";s:2:"35";s:2:"WX";s:3:"554";s:1:"N";s:10:"numbersign";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:1:"0";i:2;s:3:"549";i:3;s:3:"739";}}i:36;a:4:{s:1:"C";s:2:"36";s:2:"WX";s:3:"554";s:1:"N";s:6:"dollar";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:3:"-56";i:2;s:3:"479";i:3;s:3:"810";}}s:6:"dollar";a:4:{s:1:"C";s:2:"36";s:2:"WX";s:3:"554";s:1:"N";s:6:"dollar";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:3:"-56";i:2;s:3:"479";i:3;s:3:"810";}}i:37;a:4:{s:1:"C";s:2:"37";s:2:"WX";s:3:"775";s:1:"N";s:7:"percent";s:1:"B";a:4:{i:0;s:2:"13";i:1;s:3:"-13";i:2;s:3:"752";i:3;s:3:"749";}}s:7:"percent";a:4:{s:1:"C";s:2:"37";s:2:"WX";s:3:"775";s:1:"N";s:7:"percent";s:1:"B";a:4:{i:0;s:2:"13";i:1;s:3:"-13";i:2;s:3:"752";i:3;s:3:"749";}}i:38;a:4:{s:1:"C";s:2:"38";s:2:"WX";s:3:"757";s:1:"N";s:9:"ampersand";s:1:"B";a:4:{i:0;s:2:"57";i:1;s:3:"-13";i:2;s:3:"735";i:3;s:3:"752";}}s:9:"ampersand";a:4:{s:1:"C";s:2:"38";s:2:"WX";s:3:"757";s:1:"N";s:9:"ampersand";s:1:"B";a:4:{i:0;s:2:"57";i:1;s:3:"-13";i:2;s:3:"735";i:3;s:3:"752";}}i:39;a:4:{s:1:"C";s:2:"39";s:2:"WX";s:3:"351";s:1:"N";s:10:"quoteright";s:1:"B";a:4:{i:0;s:2:"91";i:1;s:3:"547";i:2;s:3:"253";i:3;s:3:"739";}}s:10:"quoteright";a:4:{s:1:"C";s:2:"39";s:2:"WX";s:3:"351";s:1:"N";s:10:"quoteright";s:1:"B";a:4:{i:0;s:2:"91";i:1;s:3:"547";i:2;s:3:"253";i:3;s:3:"739";}}i:40;a:4:{s:1:"C";s:2:"40";s:2:"WX";s:3:"369";s:1:"N";s:9:"parenleft";s:1:"B";a:4:{i:0;s:2:"57";i:1;s:4:"-125";i:2;s:3:"335";i:3;s:3:"739";}}s:9:"parenleft";a:4:{s:1:"C";s:2:"40";s:2:"WX";s:3:"369";s:1:"N";s:9:"parenleft";s:1:"B";a:4:{i:0;s:2:"57";i:1;s:4:"-125";i:2;s:3:"335";i:3;s:3:"739";}}i:41;a:4:{s:1:"C";s:2:"41";s:2:"WX";s:3:"369";s:1:"N";s:10:"parenright";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:4:"-125";i:2;s:3:"312";i:3;s:3:"739";}}s:10:"parenright";a:4:{s:1:"C";s:2:"41";s:2:"WX";s:3:"369";s:1:"N";s:10:"parenright";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:4:"-125";i:2;s:3:"312";i:3;s:3:"739";}}i:42;a:4:{s:1:"C";s:2:"42";s:2:"WX";s:3:"425";s:1:"N";s:8:"asterisk";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:3:"468";i:2;s:3:"360";i:3;s:3:"752";}}s:8:"asterisk";a:4:{s:1:"C";s:2:"42";s:2:"WX";s:3:"425";s:1:"N";s:8:"asterisk";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:3:"468";i:2;s:3:"360";i:3;s:3:"752";}}i:43;a:4:{s:1:"C";s:2:"43";s:2:"WX";s:3:"606";s:1:"N";s:4:"plus";s:1:"B";a:4:{i:0;s:2:"51";i:1;s:2:"49";i:2;s:3:"555";i:3;s:3:"557";}}s:4:"plus";a:4:{s:1:"C";s:2:"43";s:2:"WX";s:3:"606";s:1:"N";s:4:"plus";s:1:"B";a:4:{i:0;s:2:"51";i:1;s:2:"49";i:2;s:3:"555";i:3;s:3:"557";}}i:44;a:4:{s:1:"C";s:2:"44";s:2:"WX";s:3:"277";s:1:"N";s:5:"comma";s:1:"B";a:4:{i:0;s:2:"91";i:1;s:3:"-67";i:2;s:3:"253";i:3;s:3:"126";}}s:5:"comma";a:4:{s:1:"C";s:2:"44";s:2:"WX";s:3:"277";s:1:"N";s:5:"comma";s:1:"B";a:4:{i:0;s:2:"91";i:1;s:3:"-67";i:2;s:3:"253";i:3;s:3:"126";}}i:45;a:4:{s:1:"C";s:2:"45";s:2:"WX";s:3:"332";s:1:"N";s:6:"hyphen";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:3:"233";i:2;s:3:"302";i:3;s:3:"296";}}s:6:"hyphen";a:4:{s:1:"C";s:2:"45";s:2:"WX";s:3:"332";s:1:"N";s:6:"hyphen";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:3:"233";i:2;s:3:"302";i:3;s:3:"296";}}i:46;a:4:{s:1:"C";s:2:"46";s:2:"WX";s:3:"277";s:1:"N";s:6:"period";s:1:"B";a:4:{i:0;s:3:"101";i:1;s:1:"0";i:2;s:3:"175";i:3;s:3:"126";}}s:6:"period";a:4:{s:1:"C";s:2:"46";s:2:"WX";s:3:"277";s:1:"N";s:6:"period";s:1:"B";a:4:{i:0;s:3:"101";i:1;s:1:"0";i:2;s:3:"175";i:3;s:3:"126";}}i:47;a:4:{s:1:"C";s:2:"47";s:2:"WX";s:3:"437";s:1:"N";s:5:"slash";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:4:"-128";i:2;s:3:"397";i:3;s:3:"739";}}s:5:"slash";a:4:{s:1:"C";s:2:"47";s:2:"WX";s:3:"437";s:1:"N";s:5:"slash";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:4:"-128";i:2;s:3:"397";i:3;s:3:"739";}}i:48;a:4:{s:1:"C";s:2:"48";s:2:"WX";s:3:"554";s:1:"N";s:4:"zero";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-13";i:2;s:3:"525";i:3;s:3:"752";}}s:4:"zero";a:4:{s:1:"C";s:2:"48";s:2:"WX";s:3:"554";s:1:"N";s:4:"zero";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-13";i:2;s:3:"525";i:3;s:3:"752";}}i:49;a:4:{s:1:"C";s:2:"49";s:2:"WX";s:3:"554";s:1:"N";s:3:"one";s:1:"B";a:4:{i:0;s:3:"155";i:1;s:1:"0";i:2;s:3:"354";i:3;s:3:"739";}}s:3:"one";a:4:{s:1:"C";s:2:"49";s:2:"WX";s:3:"554";s:1:"N";s:3:"one";s:1:"B";a:4:{i:0;s:3:"155";i:1;s:1:"0";i:2;s:3:"354";i:3;s:3:"739";}}i:50;a:4:{s:1:"C";s:2:"50";s:2:"WX";s:3:"554";s:1:"N";s:3:"two";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:1:"0";i:2;s:3:"506";i:3;s:3:"752";}}s:3:"two";a:4:{s:1:"C";s:2:"50";s:2:"WX";s:3:"554";s:1:"N";s:3:"two";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:1:"0";i:2;s:3:"506";i:3;s:3:"752";}}i:51;a:4:{s:1:"C";s:2:"51";s:2:"WX";s:3:"554";s:1:"N";s:5:"three";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:3:"-13";i:2;s:3:"504";i:3;s:3:"752";}}s:5:"three";a:4:{s:1:"C";s:2:"51";s:2:"WX";s:3:"554";s:1:"N";s:5:"three";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:3:"-13";i:2;s:3:"504";i:3;s:3:"752";}}i:52;a:4:{s:1:"C";s:2:"52";s:2:"WX";s:3:"554";s:1:"N";s:4:"four";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"527";i:3;s:3:"739";}}s:4:"four";a:4:{s:1:"C";s:2:"52";s:2:"WX";s:3:"554";s:1:"N";s:4:"four";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"527";i:3;s:3:"739";}}i:53;a:4:{s:1:"C";s:2:"53";s:2:"WX";s:3:"554";s:1:"N";s:4:"five";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:3:"-13";i:2;s:3:"528";i:3;s:3:"739";}}s:4:"five";a:4:{s:1:"C";s:2:"53";s:2:"WX";s:3:"554";s:1:"N";s:4:"five";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:3:"-13";i:2;s:3:"528";i:3;s:3:"739";}}i:54;a:4:{s:1:"C";s:2:"54";s:2:"WX";s:3:"554";s:1:"N";s:3:"six";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-13";i:2;s:3:"529";i:3;s:3:"739";}}s:3:"six";a:4:{s:1:"C";s:2:"54";s:2:"WX";s:3:"554";s:1:"N";s:3:"six";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-13";i:2;s:3:"529";i:3;s:3:"739";}}i:55;a:4:{s:1:"C";s:2:"55";s:2:"WX";s:3:"554";s:1:"N";s:5:"seven";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:1:"0";i:2;s:3:"490";i:3;s:3:"739";}}s:5:"seven";a:4:{s:1:"C";s:2:"55";s:2:"WX";s:3:"554";s:1:"N";s:5:"seven";s:1:"B";a:4:{i:0;s:2:"64";i:1;s:1:"0";i:2;s:3:"490";i:3;s:3:"739";}}i:56;a:4:{s:1:"C";s:2:"56";s:2:"WX";s:3:"554";s:1:"N";s:5:"eight";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"512";i:3;s:3:"752";}}s:5:"eight";a:4:{s:1:"C";s:2:"56";s:2:"WX";s:3:"554";s:1:"N";s:5:"eight";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-13";i:2;s:3:"512";i:3;s:3:"752";}}i:57;a:4:{s:1:"C";s:2:"57";s:2:"WX";s:3:"554";s:1:"N";s:4:"nine";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"529";i:3;s:3:"752";}}s:4:"nine";a:4:{s:1:"C";s:2:"57";s:2:"WX";s:3:"554";s:1:"N";s:4:"nine";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:1:"0";i:2;s:3:"529";i:3;s:3:"752";}}i:58;a:4:{s:1:"C";s:2:"58";s:2:"WX";s:3:"277";s:1:"N";s:5:"colon";s:1:"B";a:4:{i:0;s:3:"101";i:1;s:1:"0";i:2;s:3:"175";i:3;s:3:"507";}}s:5:"colon";a:4:{s:1:"C";s:2:"58";s:2:"WX";s:3:"277";s:1:"N";s:5:"colon";s:1:"B";a:4:{i:0;s:3:"101";i:1;s:1:"0";i:2;s:3:"175";i:3;s:3:"507";}}i:59;a:4:{s:1:"C";s:2:"59";s:2:"WX";s:3:"277";s:1:"N";s:9:"semicolon";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:3:"-67";i:2;s:3:"203";i:3;s:3:"507";}}s:9:"semicolon";a:4:{s:1:"C";s:2:"59";s:2:"WX";s:3:"277";s:1:"N";s:9:"semicolon";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:3:"-67";i:2;s:3:"203";i:3;s:3:"507";}}i:60;a:4:{s:1:"C";s:2:"60";s:2:"WX";s:3:"606";s:1:"N";s:4:"less";s:1:"B";a:4:{i:0;s:2:"49";i:1;s:2:"37";i:2;s:3:"558";i:3;s:3:"565";}}s:4:"less";a:4:{s:1:"C";s:2:"60";s:2:"WX";s:3:"606";s:1:"N";s:4:"less";s:1:"B";a:4:{i:0;s:2:"49";i:1;s:2:"37";i:2;s:3:"558";i:3;s:3:"565";}}i:61;a:4:{s:1:"C";s:2:"61";s:2:"WX";s:3:"606";s:1:"N";s:5:"equal";s:1:"B";a:4:{i:0;s:2:"51";i:1;s:3:"164";i:2;s:3:"555";i:3;s:3:"436";}}s:5:"equal";a:4:{s:1:"C";s:2:"61";s:2:"WX";s:3:"606";s:1:"N";s:5:"equal";s:1:"B";a:4:{i:0;s:2:"51";i:1;s:3:"164";i:2;s:3:"555";i:3;s:3:"436";}}i:62;a:4:{s:1:"C";s:2:"62";s:2:"WX";s:3:"606";s:1:"N";s:7:"greater";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:2:"37";i:2;s:3:"557";i:3;s:3:"565";}}s:7:"greater";a:4:{s:1:"C";s:2:"62";s:2:"WX";s:3:"606";s:1:"N";s:7:"greater";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:2:"37";i:2;s:3:"557";i:3;s:3:"565";}}i:63;a:4:{s:1:"C";s:2:"63";s:2:"WX";s:3:"591";s:1:"N";s:8:"question";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:1:"0";i:2;s:3:"525";i:3;s:3:"752";}}s:8:"question";a:4:{s:1:"C";s:2:"63";s:2:"WX";s:3:"591";s:1:"N";s:8:"question";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:1:"0";i:2;s:3:"525";i:3;s:3:"752";}}i:64;a:4:{s:1:"C";s:2:"64";s:2:"WX";s:3:"867";s:1:"N";s:2:"at";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:3:"-13";i:2;s:3:"797";i:3;s:3:"752";}}s:2:"at";a:4:{s:1:"C";s:2:"64";s:2:"WX";s:3:"867";s:1:"N";s:2:"at";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:3:"-13";i:2;s:3:"797";i:3;s:3:"752";}}i:65;a:4:{s:1:"C";s:2:"65";s:2:"WX";s:3:"740";s:1:"N";s:1:"A";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:1:"0";i:2;s:3:"729";i:3;s:3:"739";}}s:1:"A";a:4:{s:1:"C";s:2:"65";s:2:"WX";s:3:"740";s:1:"N";s:1:"A";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:1:"0";i:2;s:3:"729";i:3;s:3:"739";}}i:66;a:4:{s:1:"C";s:2:"66";s:2:"WX";s:3:"574";s:1:"N";s:1:"B";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"544";i:3;s:3:"739";}}s:1:"B";a:4:{s:1:"C";s:2:"66";s:2:"WX";s:3:"574";s:1:"N";s:1:"B";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"544";i:3;s:3:"739";}}i:67;a:4:{s:1:"C";s:2:"67";s:2:"WX";s:3:"813";s:1:"N";s:1:"C";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-13";i:2;s:3:"770";i:3;s:3:"752";}}s:1:"C";a:4:{s:1:"C";s:2:"67";s:2:"WX";s:3:"813";s:1:"N";s:1:"C";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-13";i:2;s:3:"770";i:3;s:3:"752";}}i:68;a:4:{s:1:"C";s:2:"68";s:2:"WX";s:3:"744";s:1:"N";s:1:"D";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"700";i:3;s:3:"739";}}s:1:"D";a:4:{s:1:"C";s:2:"68";s:2:"WX";s:3:"744";s:1:"N";s:1:"D";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"700";i:3;s:3:"739";}}i:69;a:4:{s:1:"C";s:2:"69";s:2:"WX";s:3:"536";s:1:"N";s:1:"E";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"480";i:3;s:3:"739";}}s:1:"E";a:4:{s:1:"C";s:2:"69";s:2:"WX";s:3:"536";s:1:"N";s:1:"E";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"480";i:3;s:3:"739";}}i:70;a:4:{s:1:"C";s:2:"70";s:2:"WX";s:3:"485";s:1:"N";s:1:"F";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"451";i:3;s:3:"739";}}s:1:"F";a:4:{s:1:"C";s:2:"70";s:2:"WX";s:3:"485";s:1:"N";s:1:"F";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"451";i:3;s:3:"739";}}i:71;a:4:{s:1:"C";s:2:"71";s:2:"WX";s:3:"872";s:1:"N";s:1:"G";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-13";i:2;s:3:"831";i:3;s:3:"752";}}s:1:"G";a:4:{s:1:"C";s:2:"71";s:2:"WX";s:3:"872";s:1:"N";s:1:"G";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-13";i:2;s:3:"831";i:3;s:3:"752";}}i:72;a:4:{s:1:"C";s:2:"72";s:2:"WX";s:3:"683";s:1:"N";s:1:"H";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"607";i:3;s:3:"739";}}s:1:"H";a:4:{s:1:"C";s:2:"72";s:2:"WX";s:3:"683";s:1:"N";s:1:"H";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"607";i:3;s:3:"739";}}i:73;a:4:{s:1:"C";s:2:"73";s:2:"WX";s:3:"226";s:1:"N";s:1:"I";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"150";i:3;s:3:"739";}}s:1:"I";a:4:{s:1:"C";s:2:"73";s:2:"WX";s:3:"226";s:1:"N";s:1:"I";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"150";i:3;s:3:"739";}}i:74;a:4:{s:1:"C";s:2:"74";s:2:"WX";s:3:"482";s:1:"N";s:1:"J";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:3:"-14";i:2;s:3:"406";i:3;s:3:"739";}}s:1:"J";a:4:{s:1:"C";s:2:"74";s:2:"WX";s:3:"482";s:1:"N";s:1:"J";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:3:"-14";i:2;s:3:"406";i:3;s:3:"739";}}i:75;a:4:{s:1:"C";s:2:"75";s:2:"WX";s:3:"591";s:1:"N";s:1:"K";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"585";i:3;s:3:"739";}}s:1:"K";a:4:{s:1:"C";s:2:"75";s:2:"WX";s:3:"591";s:1:"N";s:1:"K";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"585";i:3;s:3:"739";}}i:76;a:4:{s:1:"C";s:2:"76";s:2:"WX";s:3:"462";s:1:"N";s:1:"L";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"456";i:3;s:3:"739";}}s:1:"L";a:4:{s:1:"C";s:2:"76";s:2:"WX";s:3:"462";s:1:"N";s:1:"L";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"456";i:3;s:3:"739";}}i:77;a:4:{s:1:"C";s:2:"77";s:2:"WX";s:3:"919";s:1:"N";s:1:"M";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"843";i:3;s:3:"739";}}s:1:"M";a:4:{s:1:"C";s:2:"77";s:2:"WX";s:3:"919";s:1:"N";s:1:"M";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"843";i:3;s:3:"739";}}i:78;a:4:{s:1:"C";s:2:"78";s:2:"WX";s:3:"740";s:1:"N";s:1:"N";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"664";i:3;s:3:"739";}}s:1:"N";a:4:{s:1:"C";s:2:"78";s:2:"WX";s:3:"740";s:1:"N";s:1:"N";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"664";i:3;s:3:"739";}}i:79;a:4:{s:1:"C";s:2:"79";s:2:"WX";s:3:"869";s:1:"N";s:1:"O";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-13";i:2;s:3:"825";i:3;s:3:"752";}}s:1:"O";a:4:{s:1:"C";s:2:"79";s:2:"WX";s:3:"869";s:1:"N";s:1:"O";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-13";i:2;s:3:"825";i:3;s:3:"752";}}i:80;a:4:{s:1:"C";s:2:"80";s:2:"WX";s:3:"592";s:1:"N";s:1:"P";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"565";i:3;s:3:"739";}}s:1:"P";a:4:{s:1:"C";s:2:"80";s:2:"WX";s:3:"592";s:1:"N";s:1:"P";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"565";i:3;s:3:"739";}}i:81;a:4:{s:1:"C";s:2:"81";s:2:"WX";s:3:"871";s:1:"N";s:1:"Q";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-13";i:2;s:3:"839";i:3;s:3:"752";}}s:1:"Q";a:4:{s:1:"C";s:2:"81";s:2:"WX";s:3:"871";s:1:"N";s:1:"Q";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:3:"-13";i:2;s:3:"839";i:3;s:3:"752";}}i:82;a:4:{s:1:"C";s:2:"82";s:2:"WX";s:3:"607";s:1:"N";s:1:"R";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"577";i:3;s:3:"739";}}s:1:"R";a:4:{s:1:"C";s:2:"82";s:2:"WX";s:3:"607";s:1:"N";s:1:"R";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:1:"0";i:2;s:3:"577";i:3;s:3:"739";}}i:83;a:4:{s:1:"C";s:2:"83";s:2:"WX";s:3:"498";s:1:"N";s:1:"S";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-13";i:2;s:3:"476";i:3;s:3:"752";}}s:1:"S";a:4:{s:1:"C";s:2:"83";s:2:"WX";s:3:"498";s:1:"N";s:1:"S";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:3:"-13";i:2;s:3:"476";i:3;s:3:"752";}}i:84;a:4:{s:1:"C";s:2:"84";s:2:"WX";s:3:"426";s:1:"N";s:1:"T";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:1:"0";i:2;s:3:"419";i:3;s:3:"739";}}s:1:"T";a:4:{s:1:"C";s:2:"84";s:2:"WX";s:3:"426";s:1:"N";s:1:"T";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:1:"0";i:2;s:3:"419";i:3;s:3:"739";}}i:85;a:4:{s:1:"C";s:2:"85";s:2:"WX";s:3:"655";s:1:"N";s:1:"U";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:3:"-13";i:2;s:3:"579";i:3;s:3:"739";}}s:1:"U";a:4:{s:1:"C";s:2:"85";s:2:"WX";s:3:"655";s:1:"N";s:1:"U";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:3:"-13";i:2;s:3:"579";i:3;s:3:"739";}}i:86;a:4:{s:1:"C";s:2:"86";s:2:"WX";s:3:"702";s:1:"N";s:1:"V";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:1:"0";i:2;s:3:"692";i:3;s:3:"739";}}s:1:"V";a:4:{s:1:"C";s:2:"86";s:2:"WX";s:3:"702";s:1:"N";s:1:"V";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:1:"0";i:2;s:3:"692";i:3;s:3:"739";}}i:87;a:4:{s:1:"C";s:2:"87";s:2:"WX";s:3:"960";s:1:
