svn commit: r18 - trunk/mapbender/http/frames
uli at osgeo.org
uli at osgeo.org
Thu Apr 13 15:51:45 EDT 2006
Author: uli
Date: 2006-04-13 19:51:45+0000
New Revision: 18
Added:
trunk/mapbender/http/frames/frameset.html
trunk/mapbender/http/frames/index.php
trunk/mapbender/http/frames/login.php
import Mapbender source without history
Added: trunk/mapbender/http/frames/frameset.html
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/frames/frameset.html?view=auto&rev=18
--- (empty file)
+++ trunk/mapbender/http/frames/frameset.html 2006-04-13 19:51:45+0000
@@ -0,0 +1,21 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+Licensing: See the GNU General Public License for more details.
+http://www.gnu.org/copyleft/gpl.html
+or:
+mapbender/licence/
+<meta name="author-mail" content="info at ccgis.de">
+<meta name="author" content="U. Rothstein">
+<meta http-equiv="cache-control" content="no-cache">
+<meta http-equiv="pragma" content="no-cache">
+<meta http-equiv="expires" content="0">
+<meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
+<title>Mapbender_</title>
+</head>
+<body bgcolor="#ff0000">
+<iframe id="mapbender_app" name="mapbender_app" width="1000" height="800" src="http://localhost/frames/login.php"></iframe>
+</body>
+</html>
Added: trunk/mapbender/http/frames/index.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/frames/index.php?view=auto&rev=18
--- (empty file)
+++ trunk/mapbender/http/frames/index.php 2006-04-13 19:51:45+0000
@@ -0,0 +1,148 @@
+<?php
+#$Id: index.php,v 1.25 2006/03/09 12:25:36 uli_rothstein Exp $
+#$Header: /cvsroot/mapbender/mapbender/http/frames/index.php,v 1.25 2006/03/09 12:25:36 uli_rothstein Exp $
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+session_start();
+import_request_variables("PG");
+require("../php/mb_validateSession.php");
+$_SESSION["mb_user_gui"] = $_REQUEST["gui_id"];
+require_once("../../conf/mapbender.conf");
+$con = db_connect($DBSERVER,$OWNER,$PW);
+db_select_db(DB,$con);
+<html>
+<head>
+or:
+mapbender/licence/
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+<title>MB2 - <?php echo $_REQUEST["gui_id"];?></title>
+<?php
+ $sql = "SELECT * FROM gui_element_vars WHERE fkey_e_id = 'body' AND fkey_gui_id = '".$gui_id."' and var_type='file/css'";
+ $res = db_query($sql);
+ $cnt = 0;
+ while($row = db_fetch_array($res)){
+ echo "<link rel=\"stylesheet\" type=\"text/css\" href=\"".$row["var_value"]."\" />\n";
+<style type="text/css">
+<?php
+ $sql = "SELECT * FROM gui_element_vars WHERE fkey_e_id = 'body' AND fkey_gui_id = '".$gui_id."' and var_type='text/css'";
+ $cnt = 0;
+ echo $row["var_value"];
+</style>
+<script type='text/javascript' src="../javascripts/map_obj.js"></script>
+<script type='text/javascript' src="../javascripts/wfs_obj.js"></script>
+<?php
+echo "<script type='text/javascript' src='../javascripts/map.php?gui_id=".$_REQUEST["gui_id"]."&".strip_tags(SID)."&mb_myBBOX=".$_REQUEST["mb_myBBOX"]."'></script>";
+echo "<script type='text/javascript' src='../php/mod_createJSObjFromDB.php?". strip_tags (SID)."'></script>";
+$frame = "";
+include("../../conf/mapbender.conf");
+db_select_db($DB,$con);
+require_once("../php/mb_validateInput.php");
+$gui = mb_validateInput($_REQUEST["gui_id"]);
+$sql = "SELECT DISTINCT e_mb_mod, e_pos FROM gui_element WHERE e_public = 1 AND fkey_gui_id = '".$gui."' ORDER BY e_pos";
+$res = db_query($sql);
+$cnt = 0;
+while($row = db_fetch_array($res)){
+ if($row["e_mb_mod"] != ""){
+ echo "<script type='text/javascript' src='../javascripts/".trim($row["e_mb_mod"])."?gui_id=".$gui."'></script> ";
+ $cnt++;
+</head>
+<?php
+$sql = "SELECT * FROM gui_element WHERE e_public = 1 AND fkey_gui_id = '".$gui."' ORDER BY e_pos";
+$i = 0;
+while(db_fetch_row($res)){
+ echo "<".db_result($res,$i,"e_element")." ";
+ if(db_result($res,$i,"e_id") != ""){
+ echo " id='".db_result($res,$i,"e_id")."'";
+ echo " name='".db_result($res,$i,"e_id")."'";
+ if(db_result($res,$i,"e_attributes") != ""){
+ echo " ".stripslashes(preg_replace("/sessionID/",strip_tags(SID),db_result($res,$i,"e_attributes")));
+ if(db_result($res,$i,"e_src") != ""){
+ if(db_result($res,$i,"e_closetag") == "iframe" && db_result($res,$i,"e_id") != 'loadData'){
+ echo " src = '".preg_replace("/sessionID/",strip_tags(SID),db_result($res,$i,"e_src"));
+ if(strpos(db_result($res,$i,"e_src"), "?")) {
+ echo "&";
+ else {
+ echo "?";
+ echo "e_id_css=".db_result($res,$i,"e_id")."&e_id=".db_result($res,$i,"e_id")."'";
+ else{
+ echo " src = '".preg_replace("/sessionID/",strip_tags(SID),db_result($res,$i,"e_src"))."'";
+ echo " style = '";
+ if(db_result($res,$i,"e_left") != "" && db_result($res,$i,"e_top") != ""){
+ echo "position:absolute;";
+ echo "left:".db_result($res,$i,"e_left").";";
+ echo "top:".db_result($res,$i,"e_top").";";
+ if(db_result($res,$i,"e_width") != "" && db_result($res,$i,"e_height") != ""){
+ echo "width:".db_result($res,$i,"e_width").";";
+ echo "height:".db_result($res,$i,"e_height").";";
+ if(db_result($res,$i,"e_z_index") != ""){
+ echo "z-index:".db_result($res,$i,"e_z_index").";";
+ if(db_result($res,$i,"e_more_styles") != ""){
+ echo db_result($res,$i,"e_more_styles");
+ echo "' >";
+ if(db_result($res,$i,"e_content") != ""){
+ echo " ".stripslashes(db_result($res,$i,"e_content"));
+ if(db_result($res,$i,"e_closetag") != "" && db_result($res,$i,"e_closetag") != "body"){
+ echo " </".db_result($res,$i,"e_closetag").">";
+ $i++;
+<form id='sendData' name='sendData' action='' method='POST' target='loadData' style='position:absolute;left:800px'>
+<input type='hidden' name='data'>
+</form>
+</body>
+</html>
\ No newline at end of file
Added: trunk/mapbender/http/frames/login.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/frames/login.php?view=auto&rev=18
--- (empty file)
+++ trunk/mapbender/http/frames/login.php 2006-04-13 19:51:45+0000
@@ -0,0 +1,183 @@
+<?php
+ob_start();
+include_once("../../conf/mapbender.conf");
+<html>
+<head>
+or:
+mapbender/licence/
+<?php
+<title>Login</title>
+<?php
+$css_folder = "";
+echo "<link rel=\"stylesheet\" type=\"text/css\" href=\"../css/" . $css_folder . "login.css\">";
+$con = db_connect(DBSERVER,OWNER,PW);
+$name = mb_validateInput($_REQUEST["name"]);
+$password = mb_validateInput($_REQUEST["password"]);
+$loginMax = MAXLOGIN;
+if(!isset($name) || $name == ''){
+ echo "<script type='text/javascript'>";
+ echo "<!--". chr(13).chr(10);
+ echo "function setFocus(){";
+ echo "if(document.loginForm){";
+ echo "document.loginForm.name.focus();";
+ echo "}";
+ echo "}";
+ echo "// -->". chr(13).chr(10);
+ echo "</script>";
+else{
+ echo "document.loginForm.password.focus();";
+ echo "}";
+ echo "}";
+ echo "</script>";
+echo "</head>";
+echo "<body onload='setFocus()'>";
+session_start();
+if(isset($_REQUEST["password"]) && isset($_REQUEST["name"])){
+ session_unset();
+ session_destroy();
+if(isset($_SESSION["mb_user_password"]) && isset($_SESSION["mb_user_name"])){
+ $name = $_SESSION["mb_user_name"];
+ $password = $_SESSION["mb_user_password"];
+if(!isset($name) || $name == '' || !isset($password) || $password == ''){
+ echo "<form name='loginForm' action ='" . $PHP_SELF . "' method='POST'>";
+ echo "<table>";
+ echo "<tr><td>Name: </td><td><input type='text' name='name' class='login_text' value='".$name."'></td></tr>";
+ echo "<tr><td>Password: </td><td><input type='password' name='password' class='login_text'></td></tr>";
+ echo "<tr><td></td><td><input type='submit' class='login_submit' value='login' title='anmelden'>";
+ echo " <a href='../php/mod_forgottenPassword.php' title='Passwort vergessen?' target='_blank'>Forgot your password?</a>";
+ echo "</td></tr></table>";
+ echo "</form>";
+ session_unset();
+session_start();
+if(isset($name) && $name != '' && isset($password) && $password != ''){
+ $sql_count = "SELECT mb_user_login_count FROM mb_user WHERE mb_user_name = '".$name."'";
+ $res_count = db_query($sql_count);
+ if($row = db_fetch_array($res_count)){
+ if($row["mb_user_login_count"] > $loginMax){
+ echo "Permission denied. Login failed ".$loginMax." times. Your account has been deactivated. Please contact your administrator!";
+ die();
+ if(SYS_DBTYPE == "mysql") {
+ $passwd_tmp = "password('".$password."')";
+ else {
+ if(MD5 == 'true'){
+ $passwd_tmp = "md5('".$password."')";
+ }else{
+ $passwd_tmp = $password;
+ if(SYS_DBTYPE == "pgsql" && MD5 == 'false')
+ $sql = "SELECT * FROM mb_user WHERE mb_user_name = '".$name."' AND mb_user_password = '".$passwd_tmp."';";
+ else{
+ $sql = "SELECT * FROM mb_user WHERE mb_user_name = '".$name."' AND mb_user_password = ".$passwd_tmp.";";
+ $row = db_fetch_array($res);
+ // if given user data is found in database, set session data (db_fetch_array returns false if no row is found)
+ if ($row) {
+ include_once("../../conf/session.conf");
+ if($_SESSION["mb_user_id"]){
+ if($row["mb_user_login_count"] < $loginMax){
+ $sql_del_cnt = "UPDATE mb_user SET mb_user_login_count = 0 WHERE mb_user_name = '".$name."'";
+ db_query($sql_del_cnt);
+ #Session variables, defined in session.conf
+ #include("../../conf/mapbender.conf");
+ #check guis
+ require_once("../php/mb_getGUIs.php");
+ $arrayGUIs = mb_getGUIs($row["mb_user_id"]);
+ $_SESSION["mb_user_guis"] = $arrayGUIs;
+ $_SESSION["mb_login"] = $login;
+ # a gui is explicitly ordered
+ if((isset($_REQUEST["mb_user_myGui"]) || isset($_SESSION["mb_user_myGui"])) && in_array($_REQUEST["mb_user_myGui"], $arrayGUIs)){
+ unset($arrayGUIs);
+ if(isset($_REQUEST["mb_user_myGui"])){ $arrayGUIs[0] = $_REQUEST["mb_user_myGui"];}
+ else{ $arrayGUIs[0] = $_SESSION["mb_user_myGui"];}
+ #only one gui is provided
+ if(count($arrayGUIs) == 1){
+ $myURL = "Location: http://".$_SERVER['HTTP_HOST'].dirname($_SERVER['PHP_SELF'])."/index.php?".strip_tags (SID)."&gui_id=".$arrayGUIs[0];
+ # params for the initial call
+ if(isset($_REQUEST["mb_myBBOX"])){
+ $myURL .= "&mb_myBBOX=".$_REQUEST["mb_myBBOX"];
+ header ($myURL);
+ exit;
+ # list all guis of this user and his groups
+ else{
+ require_once("../php/mb_listGUIs.php");
+ mb_listGUIs($arrayGUIs);
+ else{
+ $sql_set_cnt = "UPDATE mb_user SET mb_user_login_count = (mb_user_login_count + 1) WHERE mb_user_name = '".$name."'";
+ db_query($sql_set_cnt);
+ header ("Location: http://".$_SERVER['HTTP_HOST'].dirname($_SERVER['PHP_SELF'])."/login.php?name=".$name);
+ exit();
+ob_end_flush();
+</body>
+</html>
More information about the Mapbender_commits
