svn commit: r41 - trunk/mapbender/http/print
uli at osgeo.org
uli at osgeo.org
Thu Apr 13 16:50:52 EDT 2006
Author: uli
Date: 2006-04-13 20:50:52+0000
New Revision: 41
Added:
trunk/mapbender/http/print/mod_printPDF.php
trunk/mapbender/http/print/mod_printPDF_pdf.php
trunk/mapbender/http/print/printPDF.conf
trunk/mapbender/http/print/printPDF_b.conf
import Mapbender source without history
Added: trunk/mapbender/http/print/mod_printPDF.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/print/mod_printPDF.php?view=auto&rev=41
--- (empty file)
+++ trunk/mapbender/http/print/mod_printPDF.php 2006-04-13 20:50:52+0000
@@ -0,0 +1,367 @@
+<?php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+session_start();
+require_once("../../conf/mapbender.conf");
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<meta http-equiv="cache-control" content="no-cache">
+<meta http-equiv="pragma" content="no-cache">
+<meta http-equiv="expires" content="0">
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+<title>Print PDF</title>
+</head>
+<style type="text/css">
+select{
+ width:150px;
+input{
+ width:150px;
+.mycheck{
+ width:15px;
+div{
+ font-family : Arial, Helvetica, sans-serif;
+ font-size: 12px;
+</style>
+<?php
+require_once("../print/".$_REQUEST["conf"]);
+echo "<script type='text/javascript'>";
+echo "var target = '".$_REQUEST["target"]."';";
+echo "var comment = '".$label_comment."';";
+echo "var comment_length = ".$comment_length.";";
+echo "var label_button = '".$label_button."';";
+echo "var type = '".$type."';";
+echo "</script>";
+<script type="text/javascript">
+var size;
+var format;
+var map_width;
+var map_height;
+if(type=='window'){
+ var pt = window.opener;
+else if(type == 'iframe'){
+ var pt = parent;
+function mod_legend_print(){
+ var mod_legend_target = target;
+ var ind = pt.getMapObjIndexByName(mod_legend_target);
+ var layers;
+ document.forms[0].layers.value = "";
+ document.forms[0].wms_id.value = "";
+ document.forms[0].wms_title.value = "";
+ document.forms[0].legendurl.value = "";
+ for(var i=0; i<pt.mb_mapObj[ind].wms.length; i++){
+ layers = pt.mb_checkScale(mod_legend_target,ind,i);
+ var layer = layers[0].split(",");
+ var title = layers[2].split(",");
+ var temp_legendurl = layers[3].split(",");
+ var layerparent= layers[4].split(",");
+ if(pt.mb_mapObj[ind].wms[i].wms_getlegendurl != "" && pt.mb_mapObj[ind].layers[i] != "" && pt.mb_mapObj[ind].layers[i]){
+ if(i>0){
+ document.forms[0].layers.value += "___";
+ document.forms[0].wms_id.value += "___";
+ document.forms[0].wms_title.value += "___";
+ document.forms[0].legendurl.value += "___";
+ //document.forms[0].layers.value += pt.mb_mapObj[ind].wms[i].objLayer[ii].layer_title; //pt.mb_mapObj[ind].layers[i] ;
+ document.forms[0].wms_id.value += pt.mb_mapObj[ind].wms[i].wms_id;
+ document.forms[0].wms_title.value += pt.mb_mapObj[ind].wms[i].wms_title;
+ //---------- legendurl ----------
+ tmp_name = "";
+ for(var j=0; j<layer.length; j++){
+ if(layerparent[j] == 0){
+ if(j>0){
+ document.forms[0].layers.value += ",";
+ var l = pt.mb_getchildsbyname(ind,i,layer[j]);
+ //prompt ("l: ",l);
+ if (l) {
+ document.forms[0].layers.value += title[j];
+ if(j>0){
+ document.forms[0].legendurl.value += ",";
+ for (var k=0; k<l["name"].length; k++){
+ if (tmp_name != l["title"][k]) {
+ document.forms[0].layers.value += "*"
+ if(k>0){
+ document.forms[0].legendurl.value += "*";
+ }else{
+ document.forms[0].legendurl.value += '1*';
+ //prompt (l["name"].length+"l: " ,tmp_name+"---"+l["legendurl"][k]);
+ if (l["legendurl"][k] != '' || !l["legendurl"][k]==true){
+ document.forms[0].layers.value += l["name"][k];
+ document.forms[0].legendurl.value += l["legendurl"][k];
+ }else{
+ document.forms[0].layers.value += '0';
+ document.forms[0].legendurl.value += '0';
+ tmp_name = l["title"][k];
+ } // if
+ } // for var k=0
+ } // if (l)
+ else{
+ //prompt (!temp_legendurl[j] ,temp_legendurl[j] + !temp_legendurl[j]);
+ if(j>0){
+ if (temp_legendurl[j]!= '' || !temp_legendurl[j] == 'true'){
+ document.forms[0].legendurl.value += temp_legendurl[j];
+ }else{
+ document.forms[0].legendurl.value +='0';
+ }// else (l)
+ }//check parent==0
+ }//for var j=0
+ //document.forms[0].legendurl.value += layers[3];
+ } else{
+ if(i>0){
+ document.forms[0].layers.value += "0";
+ document.forms[0].wms_id.value += "0";
+ document.forms[0].wms_title.value += "0";
+ document.forms[0].legendurl.value += "0";
+function validate(){
+ size = document.form1.size.options[document.form1.size.selectedIndex].value;
+ format = document.form1.format.options[document.form1.format.selectedIndex].value;
+ if(size != "" && format != ""){
+ var ind = pt.getMapObjIndexByName(target);
+ var coord = pt.mb_mapObj[ind].extent.split(",");
+ var centerX = parseFloat(coord[0]) + (parseFloat(coord[2]) - parseFloat(coord[0]))/2
+ var centerY = parseFloat(coord[1]) + (parseFloat(coord[3]) - parseFloat(coord[1]))/2
+ if(size == "A4" && format == "portrait"){
+ map_width = <?php echo $a4p_map_width; ?>;
+ map_height = <?php echo $a4p_map_height; ?>;
+ if(size == "A4" && format == "landscape"){
+ map_width = <?php echo $a4l_map_width; ?>;
+ map_height = <?php echo $a4l_map_height; ?>;
+ if(size == "A3" && format == "portrait"){
+ map_width = <?php echo $a3p_map_width; ?>;
+ map_height = <?php echo $a3p_map_height; ?>;
+ if(size == "A3" && format == "landscape"){
+ map_width = <?php echo $a3l_map_width; ?>;
+ map_height = <?php echo $a3l_map_height; ?>;
+ var pos = pt.makeClickPos2RealWorldPos(target, map_width , map_height);
+ pt.mb_mapObj[ind].extent = coord[0] + "," + pos[1] + "," + pos[0] + "," + coord[3];
+ pt.mb_mapObj[ind].width = Math.round(map_width);
+ pt.mb_mapObj[ind].height = Math.round(map_height);
+ pt.document.getElementById(target).style.width = Math.round(map_width);
+ pt.document.getElementById(target).style.height = Math.round(map_height);
+ pt.window.frames[target].document.getElementById("maps").style.width = Math.round(map_width);
+ pt.window.frames[target].document.getElementById("maps").style.height = Math.round(map_height);
+ //pt.setMapRequest(target);
+ pt.mb_repaintScale(target, null, null, pt.mb_getScale(target));
+ document.form1.map_url.value = '';
+ if(pt.mb_mapObj[ind].wms[i].gui_wms_visible > 0){
+ if(pt.mb_mapObj[ind].wms[i].mapURL != false && pt.mb_mapObj[ind].wms[i].mapURL != 'false' && pt.mb_mapObj[ind].wms[i].mapURL != ''){
+ if(document.form1.map_url.value != ""){
+ document.form1.map_url.value += "___";
+ document.form1.map_url.value += pt.mb_mapObj[ind].wms[i].mapURL;
+ //overview_url
+ var ind_overview = pt.getMapObjIndexByName('overview');
+ //alert ("länge: " + length+ " - " + ind_overview + name + pt.mb_mapObj[ind_overview].wms.length);
+ if(pt.mb_mapObj[ind_overview].mapURL != false ){
+ document.forms[0].overview_url.value = pt.mb_mapObj[ind_overview].mapURL;
+function refreshParams(){
+ var f = document.form1;
+ f.map_url.value = "";
+ if(f.map_url.value != ""){
+ f.map_url.value += "___";
+ f.map_url.value += pt.mb_mapObj[ind].wms[i].mapURL;
+ f.map_scale.value = pt.mb_getScale(target);
+ mod_legend_print();
+function printMap(){
+ if(size != "" && (format == "portrait" || format == "landscape")){
+ refreshParams();
+ if(document.form1.c1.value != comment){
+ document.form1.comment1.value = document.form1.c1.value;
+ if(document.form1.c2.value != comment){
+ document.form1.comment2.value = document.form1.c2.value;
+ if(document.form1.mylegendcheckbox.checked == 0){
+ document.form1.mylegend.value = 'false';
+ }else{
+ document.form1.mylegend.value = 'true';
+ document.form1.submit();
+ else{
+ alert("Das Format ist noch nicht ausgewählt.");
+function valCom(obj){
+ if(obj.value.length > comment_length){
+ obj.value = obj.value.substr(0,comment_length);
+</script>
+<body>
+<form name='form1' method='POST' action='../print/mod_printPDF_pdf.php?<?php echo SID; ?>' target="_blank">
+<table border='0'>
+<tr>
+ <td>
+ <select name='size' onchange='validate()'>
+<?php
+ if($a4 == true && $a3 == true){
+ echo "<option value=''>".$label_format."</option>";
+ if($a4 == true){
+ echo "<option value='A4'>".$label_format_a4."</option>";
+ if($a3 == true){
+ echo "<option value='A3'>".$label_format_a3."</option>";
+ </select>
+ </td>
+</tr>
+<tr>
+ <td>
+ <select name='format' onchange='validate()'>
+ <option value=''><?php echo $label_orientation; ?></option>
+ <option value='portrait'><?php echo $label_portrait; ?></option>
+ <option value='landscape'><?php echo $label_landscape; ?></option>
+ </select>
+ </td>
+</tr>
+<?php
+if($highquality == true){
+ echo "<tr>";
+ echo "<td>";
+ echo "<select name='quality'>";
+ echo "<option value='1'>".$label_72dpi."</option>";
+ echo "<option value='2'>".$label_288dpi."</option>";
+ echo "</select>";
+ echo "</td>";
+ echo "</tr>";
+<tr>
+ <td>
+ <input type='text' name='c1' value='<?php echo $label_comment; ?>' onkeydown="valCom(this)">
+ </td>
+</tr>
+<tr>
+ <td>
+ <input type='text' name='c2' value='<?php echo $label_comment; ?>' onkeydown="valCom(this)">
+ </td>
+</tr>
+<?php
+if($legend == true){
+ echo "<tr>";
+ echo "<td>";
+ echo "<div><input type='checkbox' class='mycheck' name='mylegendcheckbox' value='false'>".$label_legend."</div>";
+ echo "</td>";
+ echo "</tr>";
+<table>
+<input type='hidden' name='map_url' value=''>
+<input type='hidden' name='overview_url' value=''>
+<input type='hidden' name='wms_title' value=''>
+<input type='hidden' name='wms_id' value=''>
+<input type='hidden' name='layers' value=''>
+<input type='hidden' name='legendurl' value=''>
+<input type='hidden' name='map_scale' value=''>
+<input type='button' name='print' value="<?php echo $label_button; ?>" onclick='printMap()'>
+<input type='hidden' name='conf' value='<?php echo $_REQUEST["conf"]; ?>'>
+<input type='hidden' name='comment1' value=''>
+<input type='hidden' name='comment2' value=''>
+<input type='hidden' name='mylegend' value='true'>
+</form>
+</body>
+</html>
Added: trunk/mapbender/http/print/mod_printPDF_pdf.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/print/mod_printPDF_pdf.php?view=auto&rev=41
--- (empty file)
+++ trunk/mapbender/http/print/mod_printPDF_pdf.php 2006-04-13 20:50:52+0000
@@ -0,0 +1,697 @@
+<?php
+#require_once("../php/mb_validateSession.php");
+ob_start();
+session_start();
+ini_set('error_reporting', 'E_ALL & ~ E_NOTICE');
+include ('../classes/class.ezpdf.php');
+include ('../classes/class_stripRequest.php');
+include ('../classes/class_weldMaps2PNG.php');
+include ('../classes/class_weldOverview2PNG.php');
+include ('../print/'.$_REQUEST["conf"]);
+include ('../classes/class_SaveLegend.php');
+if($log == true){
+ include ('../classes/class_log.php');
+#Globals
+$factor = intval($_REQUEST["quality"]);
+#$date = date("d.m.Y",strtotime("now"));
+$linewidth_dashed = 0.5;
+$linewidth = 0.5;
+// DURATION TIME:
+function microtime_float(){
+ list($usec, $sec) = explode(" ", microtime());
+ return ((float)$usec + (float)$sec);
+$time_start = microtime_float();
+// END DURATION TIME
+$time_end = microtime_float();
+$time = $time_end - $time_start;
+$size = $_REQUEST["size"];
+$format = $_REQUEST["format"];
+$map_scale = $_REQUEST["map_scale"];
+$overview_url = $_REQUEST["overview_url"];
+function setscalebar($scale){
+ $mb_resolution = 28.35;
+ if($scale < 16){
+ $value = "10";
+ $unit = "cm";
+ $scalefactor = 10/$scale;
+ $img_width = round($scalefactor * $mb_resolution);
+ if($scale >= 16 && $scale < 151){
+ $value = "1";
+ $unit = "Meter";
+ $scalefactor = 100/$scale;
+ if($scale >= 151 && $scale < 1550 ){
+ $value = "10";
+ $unit = "Meter";
+ $scalefactor = 1000/$scale;
+ if($scale >= 1550 && $scale < 15050){
+ $value = "100";
+ $unit = "Meter";
+ $scalefactor = 10000/$scale;
+ if($scale < 150050 && $scale >= 15050){
+ $value = "1";
+ $unit = "Kilometer";
+ $scalefactor = 100000/$scale;
+ if($scale < 1500050 && $scale >= 150050){
+ $value = "10";
+ $scalefactor = 1000000/$scale;
+ if($scale < 15000050 && $scale >= 1500050){
+ $value = "100";
+ $scalefactor = 10000000/$scale;
+ if($scale < 150000001 && $scale >= 15000001){
+ $value = "1000";
+ $scalefactor = 100000000/$scale;
+ if($scale >= 150000001){
+ $value = "1000";
+ $array_scale[0] = $unit;
+ $array_scale[1] = $img_width;
+ $array_scale[2] = $value;
+ return $array_scale;
+$border = 0.8 * $DPC;
+if($matching == true){
+ $urls = str_replace($pattern,$replacement,$_REQUEST["map_url"]);
+else{
+ $urls = $_REQUEST["map_url"];
+$array_urls = explode("___", $urls);
+$myURL = new stripRequest($array_urls[0]);
+$map_width = round($myURL->get("width"));
+$map_height = round($myURL->get("height"));
+$map_extent = $myURL->get("BBOX");
+if($factor>1){
+ for($i=0; $i<count($array_urls); $i++){
+ $m = new stripRequest($array_urls[$i]);
+ $m->set('width',(intval($m->get('width'))*4));
+ $m->set('height',(intval($m->get('height'))*4));
+ if(in_array($m->get('map'),$highqualitymapfiles)){
+ $m->set('map',str_replace(".map","_4.map",$m->get('map')));
+ $array_urls[$i] = $m->url;
+$coord = split(",",$map_extent);
+// analyse overview url and draw rectangle with position
+$o_url = new stripRequest($overview_url);
+$overview_width = round($o_url->get("width"));
+$overview_height = round($o_url->get("height"));
+if($factor>1){
+ $o_url->set('width',(intval($o_url->get('width'))*4));
+ $o_url->set('height',(intval($o_url->get('height'))*4));
+ if(in_array($o_url->get('map'),$highqualitymapfiles)){
+ $o_url->set('map',str_replace(".map","_4.map",$o_url->get('map')));
+ $overview_url = $o_url->url;
+if ($size == "A4" && $format == "portrait"){
+ $overview_left = $a4p_overviewOffset_left;
+ $overview_bottom =$a4p_overviewOffset_bottom;
+}elseif ($size == "A4" && $format == "landscape"){
+ $overview_left = $a4l_overviewOffset_left;
+ $overview_bottom =$a4l_overviewOffset_bottom;
+}elseif ($size == "A3" && $format == "portrait"){
+ $overview_left = $a3p_overviewOffset_left;
+ $overview_bottom =$a3p_overviewOffset_bottom;
+}elseif ($size == "A3" && $format == "landscape"){
+ $overview_left = $a3l_overviewOffset_left;
+ $overview_bottom = $a3l_overviewOffset_bottom;
+$o_extent = $o_url->get("BBOX");
+$o_new = new stripRequest($overview_url);
+$o_new->set('width',50);
+$o_new->set('height',50);
+//$o->set('BBOX',$overview_extent);
+$o_url_new =$o_new->url;
+$array_overview[0] = $overview_url;
+$array_overview[1] = $o_url;
+ * north arrow
+if($size == "A4" && $format == "portrait"){
+ $northarrow_left = $a4p_northarrow_left;
+ $northarrow_bottom = $a4p_northarrow_bottom;
+ $northarrow_left = $a4l_northarrow_left;
+ $northarrow_bottom = $a4l_northarrow_bottom;
+ $northarrow_left = $a3p_northarrow_left;
+ $northarrow_bottom = $a3p_northarrow_bottom;
+ $northarrow_left = $a3l_northarrow_left;
+ $northarrow_bottom = $a3l_northarrow_bottom;
+ * special image
+ $specialImage_left = $a4p_special_left;
+ $specialImage_bottom = $a4p_special_bottom;
+ $specialImage_left = $a4l_special_left;
+ $specialImage_bottom = $a4l_special_bottom;
+ $specialImage_left = $a3p_special_left;
+ $specialImage_bottom = $a3p_special_bottom;
+ $specialImage_left = $a3l_special_left;
+ $specialImage_bottom = $a3l_special_bottom;
+if($log == true){
+ $l = new log("printPDF",$array_urls);
+$pdf = new Cezpdf();
+$pdf->Cezpdf(strtolower($size),$format);
+$diff=array(196=>'Adieresis',228=>'adieresis',
+ 214=>'Odieresis',246=>'odieresis',
+ 220=>'Udieresis',252=>'udieresis',
+ 223=>'germandbls');
+$pdf->selectFont('../classes/fonts/Helvetica.afm', array('encoding'=>'WinAnsiEncoding','differences'=>$diff));
+ $mapOffset_left = $a4p_mapOffset_left;
+ $mapOffset_bottom = $a4p_mapOffset_bottom;
+ $header_height = $a4p_header_height;
+ $footer_height = $a4p_footer_height;
+else{
+ $mapOffset_left = $a4l_mapOffset_left;
+ $mapOffset_bottom = $a4l_mapOffset_bottom;
+ $header_height = $a4l_header_height;
+ $header_width = $a4l_header_width;
+$i = new weldMaps2PNG(implode("___",$array_urls),$filename);
+$pdf->addPngFromFile($filename, $mapOffset_left, $mapOffset_bottom, $map_width, $map_height);
+if($unlink == true){
+ unlink($filename);
+# dashed line
+$pdf->setLineStyle($linewidth_dashed, '','', array(2,2));
+$pdf->line($mapOffset_left - $linewidth_dashed, $mapOffset_bottom - $linewidth_dashed, $mapOffset_left - $linewidth_dashed, $mapOffset_bottom + $map_height + $linewidth_dashed);
+$pdf->line($mapOffset_left - $linewidth_dashed, $mapOffset_bottom + $map_height + $linewidth_dashed, $mapOffset_left + $map_width + $linewidth_dashed, $mapOffset_bottom + $map_height + $linewidth_dashed);
+$pdf->line($mapOffset_left + $map_width + $linewidth_dashed, $mapOffset_bottom + $map_height + $linewidth_dashed, $mapOffset_left + $map_width + $linewidth_dashed, $mapOffset_bottom -$linewidth_dashed);
+$pdf->line($mapOffset_left + $map_width + $linewidth_dashed, $mapOffset_bottom -$linewidth_dashed, $mapOffset_left - $linewidth_dashed, $mapOffset_bottom - $linewidth_dashed);
+#line
+$pdf->setLineStyle($linewidth, '', '', array());
+$pdf->line($mapOffset_left - $border, $mapOffset_bottom - $border, $mapOffset_left - $border, $mapOffset_bottom + $map_height + $border);
+$pdf->line($mapOffset_left - $border, $mapOffset_bottom + $map_height + $border, $mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border);
+$pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border, $mapOffset_left + $map_width + $border, $mapOffset_bottom -$border);
+$pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom -$border, $mapOffset_left - $border, $mapOffset_bottom - $border);
+ #header:
+ $pdf->line($mapOffset_left - $border, $mapOffset_bottom + $map_height + $border, $mapOffset_left - $border, $mapOffset_bottom + $map_height + $border + $header_height);
+ $pdf->line($mapOffset_left - $border, $mapOffset_bottom + $map_height + $border + $header_height, $mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border + $header_height);
+ $pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border + $header_height, $mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border);
+ $pdf->line( $mapOffset_left + $map_width/2, $mapOffset_bottom + $map_height + $border, $mapOffset_left + $map_width/2, $mapOffset_bottom + $map_height + $border + $header_height);
+ #header-text
+ $mySize = 9;
+ $length = $pdf->getTextWidth($mySize, $text1);
+ $pdf->addText($mapOffset_left - ($border/2) + ($map_width/4) - ($length/2),$mapOffset_bottom + $map_height + $border + 60,$mySize,$text1);
+ $mySize = 8;
+ $length = $pdf->getTextWidth($mySize, $text2);
+ $pdf->addText($mapOffset_left - ($border/2) + ($map_width/4) - ($length/2),$mapOffset_bottom + $map_height + $border + 45,$mySize,$text2);
+ $length = $pdf->getTextWidth($mySize, $text3);
+ $pdf->addText($mapOffset_left - ($border/2) + ($map_width/4) - ($length/2),$mapOffset_bottom + $map_height + $border + 35,$mySize,$text3);
+ $mySize = 9;
+ $length = $pdf->getTextWidth($mySize, $text4);
+ $pdf->addText($mapOffset_left - ($border/2) + ($map_width/4) - ($length/2),$mapOffset_bottom + $map_height + $border + 20,$mySize,$text4);
+ $mySize = 8;
+ $length = $pdf->getTextWidth($mySize, $text5);
+ $pdf->addText($mapOffset_left - ($border/2) + ($map_width/4) - ($length/2),$mapOffset_bottom + $map_height + $border + 10,$mySize,$text5);
+ $mySize = 9;
+ $length = $pdf->getTextWidth($mySize, $text6);
+ $pdf->addText($mapOffset_left + ($border/2) + ($map_width/4*3) - ($length/2),$mapOffset_bottom + $map_height + $border + 60,$mySize,$text6);
+ $length = $pdf->getTextWidth($mySize, $text7);
+ $pdf->addText($mapOffset_left + ($border/2) + ($map_width/4*3) - ($length/2),$mapOffset_bottom + $map_height + $border + 50,$mySize,$text7);
+ $length = $pdf->getTextWidth($mySize, $text8);
+ $pdf->addText($mapOffset_left + ($border/2) + ($map_width/4*3) - ($length/2),$mapOffset_bottom + $map_height + $border + 30,$mySize,$text8);
+ $length = $pdf->getTextWidth($mySize, $text9);
+ $pdf->addText($mapOffset_left + ($border/2) + ($map_width/4*3) - ($length/2),$mapOffset_bottom + $map_height + $border + 20,$mySize,$text9);
+ $length = $pdf->getTextWidth($mySize, $text10);
+ $pdf->addText($mapOffset_left + ($border/2) + ($map_width/4*3) - ($length/2),$mapOffset_bottom + $map_height + $border + 10,$mySize,$text10);
+ //special image on the map-page
+ if ($special == true){
+ $pdf->addPngFromFile($specialImage, $specialImage_left, $specialImage_bottom , $specialImage_width, $specialImage_height);
+ #footer
+ $pdf->line($mapOffset_left - $border, $mapOffset_bottom - $border, $mapOffset_left - $border, $mapOffset_bottom - $border - $footer_height);
+ $pdf->line($mapOffset_left - $border, $mapOffset_bottom - $border - $footer_height, $mapOffset_left + $map_width + $border, $mapOffset_bottom - $border - $footer_height);
+ $pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom - $border - $footer_height, $mapOffset_left + $map_width + $border, $mapOffset_bottom - $border);
+ $mySize = 8;
+ $length = $pdf->getTextWidth($mySize, $text11);
+ $pdf->addText( $mapOffset_left + $map_width/2 - ($length/2),$mapOffset_bottom - $border - 10,$mySize,$text11);
+ $mySize = 6;
+ $length = $pdf->getTextWidth($mySize, $text12);
+ $pdf->addText( $mapOffset_left + $map_width/2 - ($length/2),$mapOffset_bottom - $border - 18,$mySize,$text12);
+ $length = $pdf->getTextWidth($mySize, $text13);
+ $pdf->addText( $mapOffset_left + $map_width/2 - ($length/2),$mapOffset_bottom - $border - 25,$mySize,$text13);
+else{
+ $pdf->setColor(1,1,1);
+ $ll = array($mapOffset_left + $map_width - $header_width + $border - $linewidth, $mapOffset_bottom - $border + 1);
+ $pdf->filledRectangle($ll[0], $ll[1], $header_width,$header_height);
+ $pdf->line($ll[0], $ll[1], $ll[0], $ll[1] + $header_height);
+ $pdf->line($ll[0], $ll[1] + $header_height, $ll[0] + $header_width, $ll[1] + $header_height);
+ $pdf->line($ll[0] + 2, $ll[1] + 2, $ll[0] + 2, $ll[1] + $header_height - 2);
+ $pdf->line($ll[0] + 2, $ll[1] + $header_height - 2, $ll[0] - 2 + $header_width, $ll[1] + $header_height - 2);
+ $pdf->line($ll[0] - 2 + $header_width, $ll[1] + $header_height - 2, $ll[0] - 2 + $header_width, $ll[1] + 2);
+ $pdf->line($ll[0] - 2 + $header_width, $ll[1] + 2, $ll[0] + 2, $ll[1] + 2);
+ $pdf->line($ll[0] + 2, $ll[1] + 110 , $ll[0] - 2 + $header_width, $ll[1] + 110);
+ $pdf->line($ll[0] + 2, $ll[1] + 40 , $ll[0] - 2 + $header_width, $ll[1] + 40);
+ $pdf->setColor(0,0,0);
+ $mySize = 9;
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,185,$mySize,$text1);
+ $mySize = 8;
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,175,$mySize,$text2);
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,165,$mySize,$text3);
+ $mySize = 9;
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,155,$mySize,$text4);
+ $mySize = 8;
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,145,$mySize,$text5);
+ $mySize = 9;
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,125,$mySize,$text6);
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,115,$mySize,$text7);
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,95,$mySize,$text8);
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,85,$mySize,$text9);
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,75,$mySize,$text10);
+ $mySize = 8;
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,60,$mySize,$text11);
+ $mySize = 6;
+ $length = $pdf->getTextWidth($mySize, $text14);
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,53,$mySize,$text14);
+ $length = $pdf->getTextWidth($mySize, $text15);
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,47,$mySize,$text15);
+ $length = $pdf->getTextWidth($mySize, $text16);
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,41,$mySize,$text16);
+ $length = $pdf->getTextWidth($mySize, $text17);
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,35,$mySize,$text17);
+#Coordinates
+$myMinx = "R ".substr(round($coord[0]), 0, 4)." ".substr(round($coord[0]), 4, 3)."";
+$myMiny = "H ".substr(round($coord[1]), 0, 4)." ".substr(round($coord[1]), 4, 3)."";
+$myMaxx = "R ".substr(round($coord[2]), 0, 4)." ".substr(round($coord[2]), 4, 3)."";
+$myMaxy = "H ".substr(round($coord[3]), 0, 4)." ".substr(round($coord[3]), 4, 3)."";
+$mySize = 9;
+$pdf->addText($mapOffset_left - 3, $mapOffset_bottom, $mySize, $myMinx, -90);
+$pdf->addText($mapOffset_left, $mapOffset_bottom - ($pdf->getFontHeight($mySize)), $mySize, $myMiny);
+$pdf->addText($mapOffset_left + $map_width - ($pdf->getTextWidth($mySize, $myMaxx)), $mapOffset_bottom + $map_height + 3, $mySize, $myMaxx);
+$pdf->addText($mapOffset_left + $map_width + 3, $mapOffset_bottom + $map_height, $mySize, $myMaxy, 90);
+if ($overview==true){
+ // analyse request, draw rectancle
+ if($size == "A4" && $format == "portrait"){
+ $i = new weldOverview2PNG($overview_url,$array_urls[0] ,$filename);
+ $pdf->addPngFromFile($filename, $overview_left,$overview_bottom, $overview_width, $overview_height);
+ if($unlink == true){
+ else{
+ $i = new weldOverview2PNG($overview_url,$array_urls[0],$filename);
+ //$pdf->addPngFromFile($filename, $mapOffset_left,$mapOffset_bottom, $overview_width, $overview_height);
+if ($northarrow==true){
+ $pdf->addPngFromFile($northarrowImage, $northarrow_left, $northarrow_bottom , $northarrowImage_width, $northarrowImage_height);
+if($scalebar == true){
+ if ($size == "A4" && $format == "portrait"){
+ $scalebar_left = $a4p_scalebar_left;
+ $scalebar_bottom = $a4p_scalebar_bottom;
+ }elseif ($size == "A4" && $format == "landscape"){
+ $scalebar_left = $a4l_scalebar_left;
+ $scalebar_bottom = $a4l_scalebar_bottom;
+ }elseif ($size == "A3" && $format == "portrait"){
+ $scalebar_left = $a3p_scalebar_left;
+ $scalebar_bottom = $a3p_scalebar_bottom;
+ }elseif ($size == "A3" && $format == "landscape"){
+ $scalebar_left = $a3l_scalebar_left;
+ $scalebar_bottom = $a3l_scalebar_bottom;
+ $array_scalebar = setscalebar($map_scale);
+ $scalebar_left = $scalebar_left + $header_width/2 - $array_scalebar[1]/2;
+ $pdf->setLineStyle($scalebar_height, '','', array());
+ #$pdf->line($scalebar_left, $scalebar_bottom , $scalebar_left - 200 + $array_scalebar[1], $scalebar_bottom);
+ $pdf->filledRectangle($scalebar_left, $scalebar_bottom, $array_scalebar[1],$scalebar_height);
+ $pdf->filledRectangle($scalebar_left + $array_scalebar[1]/4 + 1 , $scalebar_bottom + 1, $array_scalebar[1]/4 - 1 ,$scalebar_height-2);
+ $pdf->filledRectangle($scalebar_left + 3*($array_scalebar[1]/4) + 1 , $scalebar_bottom + 1, $array_scalebar[1]/4 - 2 ,$scalebar_height-2);
+ #$pdf->setColor(1,0,1);
+ #$pdf->filledRectangle($scalebar_left , $scalebar_bottom - 20, 1 * $DPC ,$scalebar_height-2);
+ # value - Einheiten
+ $mySize = 8;
+ $scalebar_height_half = 0.5 * $scalebar_height;
+ $myText = 0;
+ $length = $pdf->getTextWidth($mySize, $myText);
+ $pdf->addText($scalebar_left - $length/2 ,$scalebar_bottom + 9 ,$mySize,$myText);
+ $myText = $array_scalebar[2]/2;
+ $pdf->addText($scalebar_left + $array_scalebar[1]/2 - $length/2 ,$scalebar_bottom + 9 ,$mySize,$myText);
+ $myText = $array_scalebar[2];
+ $pdf->addText($scalebar_left + $array_scalebar[1] - $length/2 - $length/4 ,$scalebar_bottom + 9 ,$mySize,$myText);
+ $mySize = 8;
+ $myText = $array_scalebar[0];
+ #$pdf->addText($scalebar_left + $scalebar_width + 5,$scalebar_bottom - $scalebar_height_half ,$mySize,$myText);
+ #units
+ $pdf->addText($scalebar_left + $array_scalebar[1]/2 - $length/2 ,$scalebar_bottom - 12 ,$mySize,$myText);
+ new page for legend
+if ($legend == true && $_REQUEST["mylegend"]=='true'){
+ $pdf->ezNewPage();
+ //Pageborder (top, bottom, left, right)
+ $pdf->ezSetMargins(50,50,80,30);
+ } else {
+ $pdf->ezSetMargins(60,35,60,60);
+ //Requests
+ $my_wms_id = explode("___",$_REQUEST["wms_id"]);
+ $my_wms_title = explode("___",$_REQUEST["wms_title"]);
+ $my_layers = explode("___",$_REQUEST["layers"]);
+ $my_legend = explode("___",$_REQUEST["legendurl"]);
+ //frames (x1, y1, x2, y2)
+ #line
+ $pdf->setLineStyle($linewidth, '', '', array());
+ //left
+ $pdf->line($mapOffset_left - $border, $mapOffset_bottom - $border - $footer_height, $mapOffset_left - $border, $mapOffset_bottom + $map_height + $border + $header_height);
+ //right
+ //top
+ $pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border + $header_height, $mapOffset_left + $map_width + $border, $mapOffset_bottom - $border - $footer_height);
+ //bottom
+ $pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom -$border - $footer_height, $mapOffset_left - $border, $mapOffset_bottom - $border - $footer_height);
+ if ($legendImage!=''){
+ //image on top of page
+ $pdf->addPngFromFile($legendImage, $mapOffset_left + $map_width + $border - $legendImage_width -6, $mapOffset_bottom + $map_height + $border + $header_height - $legendImage_height - 4 , $legendImage_width, $legendImage_height);
+ } else {
+ //left
+ $pdf->line($mapOffset_left - $border, $mapOffset_bottom - $border, $mapOffset_left - $border, $mapOffset_bottom + $map_height + $border);
+ //right
+ $pdf->line($mapOffset_left - $border, $mapOffset_bottom + $map_height + $border , $mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border);
+ //top
+ $pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border , $mapOffset_left + $map_width + $border, $mapOffset_bottom - $border);
+ //bottom
+ $pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom -$border , $mapOffset_left - $border, $mapOffset_bottom - $border);
+ $pdf->addPngFromFile($legendImage, $mapOffset_left + $map_width + $border - $legendImage_width -6, $mapOffset_bottom + $map_height + $border - $legendImage_height -4 , $legendImage_width, $legendImage_height);
+ //line under legend (only landscape)
+ //$pdf->line($mapOffset_left - $border, $mapOffset_bottom + $map_height + $border - $legendImage_height - 4 , $mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border - $legendImage_height - 6);
+ //columns
+ $pdf->ezColumnsStart(array ('num'=>2, 'gap'=>10));
+ } else {
+ $pdf->ezColumnsStart(array ('num'=>3, 'gap'=>10));
+ //header from printPDF.conf
+ //$pdf->ezText("<b>".$titel."</b>", 13);
+ $pdf->ezText("<b><u>".$legendText."</u></b>", 13);
+ //Seitenränder (top, bottom, left, right)
+ $pdf->ezSetMargins(70,35,80,30);
+ } else {
+ $pdf->ezSetMargins(100,35,60,60);
+ //generate the legend---------------------------------------------
+ // gesamthöhe Legende / height of the legend
+ $sum_legend_height = 0;
+ for($i=0; $i<count($my_wms_id); $i++){
+ if ($my_wms_id[$i] != '0'){ //wms_id not 0
+ $layer = explode(",",$my_layers[$i]);
+ $my_legendurls = explode(",",$my_legend[$i]);
+ $wms_y_position = $pdf->ezText("<b>".$my_wms_title[$i]."</b>", 12, array('spacing'=>1.2));
+ $wms_zeilenhoehe = $pdf->getFontHeight(12);
+ // add this to the height of the legend /addiere dies zur Gesamthöhe Legende
+ $sum_legend_height += $wms_zeilenhoehe;
+ //Layer
+ $l = 0; #l temporary parameter to count the layer /Hilfvariable zum durchzählen der angezeigten Layer
+ for($j=0; $j<count($my_legendurls); $j++){
+ // url with grouped layers------------------
+ $temp_url = explode('*',$my_legendurls[$j]);
+ $temp_layers = explode('*',$layer[$j]);
+ for ($q=0; $q <count($temp_url);$q++){
+ if($temp_url[$q] == '1' ){ // Layertitle for the parent of grouped layers
+ $layer_y_position = $pdf->ezText($temp_layers[$q], 11, array('spacing'=>1.2));
+ $layer_zeilenhoehe = $pdf->getFontHeight(12);
+ $sum_legend_height += $layer_zeilenhoehe;
+ }elseif($temp_url[$q] != '0' ){
+ $funktionsaufruf = new SaveLegend($temp_url[$q],$legendFilename);
+ $imgsize = getimagesize($legendFilename);
+ // add this to the height of the legend /addiere dies zur Gesamthöhe der Legende
+ $sum_legend_height += $imgsize[1];
+ //calculate text + picture / Berechnung Größe Schrift + Bild
+ if($l == 0){
+ $y_position = $wms_y_position;
+ $wms_y_position = '';
+ }else{
+ $y_position = $pdf->ezText("", 1, array('spacing'=>1.2));
+ $layer_zeilenhoehe = $pdf->getFontHeight(11);
+ $next_position = $y_position - $layer_zeilenhoehe - $imgsize[1];
+ // add this to the height of the legend / addiere dies zur Gesamthöhe Legende
+ $l = $l+1;
+ // if text + picture are smaler then the lower margin + textsize, then set a space
+ //wenn Schrift + Bild kleiner der unteren Margin + Zeilenhöhe, dann Abstand setzen
+ if($size == "A4" && $format == "portrait" && $next_position <= 35 +$layer_zeilenhoehe){ //90 $layer_zeilenhoehe
+ $space = $layer_zeilenhoehe + $imgsize[1];
+ $pdf->ezSetDy(-$space);
+ if($size == "A4" && $format == "landscape" && $next_position <= 35+$layer_zeilenhoehe){//50
+ //write the header layername / Überschrift schreiben
+ $legend = $temp_layers[$q]."\n"; //$layer[$j]."\n";
+ $pdf->ezText($legend, 11, array('spacing'=>1.2));
+ //$pdf->ezText($url, 9, array('spacing'=>1.2));
+ //print the picture / Bild schreiben
+ $pdf->ezImage($legendFilename, 0, 'width', 'none', 'left');
+ unlink($legendFilename);
+ } //if legendurl
+ }// for legendurl
+ #line
+ //left
+ //right
+ //top
+ //bottom
+ } else {
+ //left
+ //right
+ //top
+ //bottom
+ }// for layers
+ } //if wms_id not 0
+ }// for wms
+$pdf->ezText($legendFooter, 11);
+}//legend true
+ end of legend
+ob_clean();
+if($download == false){
+ $pdf->ezStream();
+else{
+ $content = $pdf->ezOutput();
+ $fp = fopen($downloadFile,'w');
+ fwrite($fp,$content);
+ fclose($fp);
+ echo "<html><head></head><body><a href='".$downloadFile."'>".$downloadText."</a></body></html>";
Added: trunk/mapbender/http/print/printPDF.conf
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/print/printPDF.conf?view=auto&rev=41
--- (empty file)
+++ trunk/mapbender/http/print/printPDF.conf 2006-04-13 20:50:52+0000
@@ -0,0 +1,233 @@
+<?php
+include_once("../../conf/mapbender.conf");
+# filename for temporary imagefiles
+$filename = TMPDIR."/map_".substr(md5(uniqid(rand())),0,7).".png";
+* DOWNLOAD
+$download = false;
+$downloadFile = TMPDIR."/map_".substr(md5(uniqid(rand())),0,7).".pdf";
+$downloadText = "Download: Karte als PDF...";
+*run print as iframe or window
+$type = 'iframe';
+* Legend
+$legend=true;
+$label_legend = 'print legend';
+$legendFilename = TMPDIR."/legend_".substr(md5(uniqid(rand())),0,7).".png";
+$legendText = "Legende";
+$legendFooter = "powerded by Mapbender";
+$legendImage = "./img/mapbender_logo.png";
+$legendImage_width = 90;
+$legendImage_height = 13;
+# log requests, class 'class_log.php' required
+$log = false;
+# delete images:
+$unlink = true;
+# labeling
+$text1 = "Druckansicht";
+$text2 = "- Mapbender2 -";
+$text3 = "";
+$text4 = "Maßstab 1 : " . $_REQUEST["map_scale"];
+$text5 = "Datum: " . date("d.m.Y",strtotime("now"));;
+$text6 = "Notizen:";
+$text7 = "";
+$text8 = $_REQUEST["comment1"];
+$text9 = $_REQUEST["comment2"];
+$text10 = "";
+$text11 = "Der Auszug ist maschinell erzeugt, er ist ohne Unterschrift gültig.";
+$text12 = "Dieser Auszug ist gesetzlich geschützt (§ 3 Abs. 1 VermKatG NW). Vervielfältigungen, Umarbeitungen, Veröffentlichungen oder die Weitergabe an Dritte nur mit Zustimmung des";
+$text13 = "Herausgebers, ausgenommen Vervielfältigungen und Umarbeitungen zur innerdienstlichen Verwendung bei Behörden oder zum eigenen Gebrauch.";
+$text14 = "Dieser Auszug ist gesetzlich geschützt (§ 3 Abs. 1 VermKatG NW). Vervielfältigungen,";
+$text15 = "Umarbeitungen, Veröffentlichungen oder die Weitergabe an Dritte nur mit Zustimmung";
+$text16 = "des Herausgebers, ausgenommen Vervielfältigungen und Umarbeitungen zur inner-";
+$text17 = "dienstlichen Verwendung bei Behörden oder zum eigenen Gebrauch.";
+* Labeling for buttons, textfields ...
+$label_format = "Format:";
+$label_format_a4 = "A4";
+$label_format_a3 = "A3";
+$label_orientation = "Orientation: ";
+$label_portrait = "portrait";
+$label_landscape = "landscape";
+$label_72dpi = "Quality: 72 dpi";
+$label_288dpi = "Quality: 288 dpi";
+$label_comment = "Comment (max. 30)";
+$comment_length = 30;
+$label_button = 'print';
+* default
+* url string matching and replacement
+$matching = false;
+$pattern = "192.168.2.113";
+$replacement = "192.168.2.5";
+* high quality printing 288dpi
+* highquality mapfiles will be supplemented with "_4"
+* example: germany.map -> germany_4.map
+$highquality = false;
+$highqualitymapfiles = array(
+ "/data/umn/germany/germany.map",
+ "/data/umn/germany/germany_demo.map"
+# Dots per cm (72 dpi):
+# 28.346456692913385826771653543307
+$DPC = 28.35;
+# available formats:
+$a4 = true;
+$a3 = true;
+# dimensions of the map:
+# A4 portrait
+$a4p_mapOffset_left = 3.3 * $DPC;
+$a4p_mapOffset_bottom = 3 * $DPC;
+$a4p_map_width = 15.7 * $DPC;
+$a4p_map_height = 22 * $DPC;
+$a4p_page_width = 21 * $DPC;
+$a4p_page_height = 29.7 * $DPC;
+$a4p_header_height = 2.6 * $DPC;
+$a4p_footer_height = 1.12 * $DPC;
+# A4 landscape
+$a4l_mapOffset_left = 2.3 * $DPC;
+$a4l_mapOffset_bottom = 1.8 * $DPC;
+$a4l_map_width = 25.2 * $DPC;
+$a4l_map_height = 16.4 * $DPC;
+$a4l_page_width = 29.7 * $DPC;
+$a4l_page_height = 21 * $DPC;
+$a4l_header_width = 8.5 * $DPC;
+$a4l_header_height = 6 * $DPC;
+# A3 protrait
+$a3p_mapOffset_left = 3.3 * $DPC;
+$a3p_mapOffset_bottom = 3 * $DPC;
+$a3p_map_width = 24.1 * $DPC;
+$a3p_map_height = 36.7 * $DPC;
+$a3p_page_width = 29.7 * $DPC;
+$a3p_page_height = 42 * $DPC;
+$a3p_header_width = 8.5 * $DPC;
+$a3p_header_height = 6 * $DPC;
+# A3 landscape
+$a3l_mapOffset_left = 2.3 * $DPC;
+$a3l_mapOffset_bottom = 1.8 * $DPC;
+$a3l_map_width = 37.4 * $DPC;
+$a3l_map_height = 25.4 * $DPC;
+$a3l_page_width = 42 * $DPC;
+$a3l_page_height = 29.7 * $DPC;
+$a3l_header_width = 8.5 * $DPC;
+$a3l_header_height = 6 * $DPC;
+* Overview
+$overview = true;
+$a4p_overviewOffset_left = $a4p_mapOffset_left;
+$a4p_overviewOffset_bottom = $a4p_mapOffset_bottom;
+$a4l_overviewOffset_left = $a4l_mapOffset_left;
+$a4l_overviewOffset_bottom = $a4l_mapOffset_bottom;
+$a3p_overviewOffset_left = $a3p_mapOffset_left;
+$a3p_overviewOffset_bottom = $a3p_mapOffset_bottom;
+$a3l_overviewOffset_left = $a3l_mapOffset_left;
+$a3l_overviewOffset_bottom = $a3l_mapOffset_bottom;
+* Northarrow
+$northarrow = true;
+$northarrowImage = "./img/northarrow.png";
+$a4p_northarrow_left = $a4p_mapOffset_left + 160;
+$a4p_northarrow_bottom = $a4p_mapOffset_bottom +2 ;
+$a4l_northarrow_left = $a4l_mapOffset_left + 5;
+$a4l_northarrow_bottom = $a4l_mapOffset_bottom + $a4l_map_height - 40;
+$a3p_northarrow_left = $a3p_mapOffset_left +5;
+$a3p_northarrow_bottom = $a3p_mapOffset_bottom + $a3p_map_height - 80;
+$a3l_northarrow_left = $a3l_mapOffset_left + 5;
+$a3l_northarrow_bottom = $a3l_mapOffset_bottom + $a3l_map_height - 40;
+$northarrowImage_width = 15;
+$northarrowImage_height = 35;
+* special image for the map-page
+$special = true;
+$specialImage = "./img/mapbender_logo.png";
+$a4p_special_left = $a4p_mapOffset_left + $a4p_map_width/2 + 100;
+$a4p_special_bottom = $a4p_mapOffset_bottom + $a4p_map_height + 65;
+$a4l_special_left = $a4l_mapOffset_left + $a4l_map_width - $a4l_header_width + 0.8 * $DPC + 10 ;
+$a4l_special_bottom = $a4l_mapOffset_bottom + 54;
+$a3p_special_left = $a3p_mapOffset_left + $a3p_map_width - $a3p_header_width ;
+$a3p_special_bottom = $a3p_mapOffset_bottom + 30;
+$a3l_special_left = $a3l_mapOffset_left + $a3l_map_width - $a3l_header_width + 0.8 * $DPC + 10;
+$a3l_special_bottom = $a3l_mapOffset_bottom + 60;
+$specialImage_width = 90;
+$specialImage_height = 13;
+* dynamic scalebar
+$scalebar = true;
+$units = "Meter";
+$a4p_scalebar_left = $a4p_mapOffset_left + 2 * $a4p_map_width/3;
+$a4p_scalebar_bottom = $a4p_mapOffset_bottom + 0.5 * $DPC;
+$a4l_scalebar_left = $a4l_mapOffset_left + $a4l_map_width/4 ;
+$a4l_scalebar_bottom = $a4l_mapOffset_bottom + + 0.5 * $DPC;
+$a3p_scalebar_left = $a3p_mapOffset_left + $a3p_map_width/4 ;
+$a3p_scalebar_bottom = $a3p_mapOffset_bottom + 0.5 * $DPC;
+$a3l_scalebar_left = $a3l_mapOffset_left + $a3l_map_width/4 ;
+$a3l_scalebar_bottom = $a3l_mapOffset_bottom + + 0.5 * $DPC;
+$scalebar_width = 3 * $DPC;
+$scalebar_height = 0.18 * $DPC;
\ No newline at end of file
Added: trunk/mapbender/http/print/printPDF_b.conf
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/print/printPDF_b.conf?view=auto&rev=41
--- (empty file)
+++ trunk/mapbender/http/print/printPDF_b.conf 2006-04-13 20:50:52+0000
@@ -0,0 +1,236 @@
+<?php
+* DOWNLOAD
+$download = true;
+* run print as iframe or window
+$type = 'window';
+* Legend
+$legend=true;
+$legendFooter = "powered by Mapbender";
+$log = false;
+# delete images:
+$unlink = true;
+# labeling
+$text3 = "";
+$text7 = "";
+$text10 = "";
+* default
+$matching = false;
+$DPC = 28.35;
+$a4 = true;
+$a3 = true;
+# A4 portrait
+# A4 landscape
+# A3 portrait
+# A3 landscape
+* Overview
+$overview = true;
+* Northarrow
+$special = true;
+* dynamic scalebar
+$scalebar = true;
+$units = "Meter";
More information about the Mapbender_commits
