svn commit: r43 - trunk/mapbender/http/classes/class_geomColl.php
uli at osgeo.org
uli at osgeo.org
Thu Apr 13 16:54:44 EDT 2006
Author: uli
Date: 2006-04-13 20:54:44+0000
New Revision: 43
Added:
import Mapbender source without history
Added: trunk/mapbender/http/classes/class_geomColl.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/class_geomColl.php?view=auto&rev=43
--- (empty file)
+++ trunk/mapbender/http/classes/class_geomColl.php 2006-04-13 20:54:44+0000
@@ -0,0 +1,88 @@
+<?php
+# $Id: map.php,v 1.13 2005/09/13 14:08:41 uli_rothstein Exp $
+# $Header: /cvsroot/mapbender/mapbender/http/javascripts/map.php,v 1.13 2005/09/13 14:08:41 uli_rothstein Exp $
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+class geomColl {
+ var $cnt_member;
+ var $member = array();
+ function geomColl () {
+ $this->cnt_member = -1;
+ function addGeometryMember($type) {
+ $this->cnt_member++;
+ $this->member[$this->cnt_member] = new gmlMember($type);
+ function addPolygon () {
+ $this->member[$this->cnt_member]->addPolygon();
+ function addLine () {
+ $this->member[$this->cnt_member]->addLine();
+ function addPoint () {
+ $this->member[$this->cnt_member]->addPoint();
+# function addCoordinates ($coord, $pos) {
+# $this->member[$this->cnt_member]->addCoordinates($coord, $pos);
+ function addCoordinates ($coord) {
+ $this->member[$this->cnt_member]->addCoordinates($coord);
+ function addLabel($label) {
+ $this->member[$this->cnt_member]->addLabel($label);
+ function addAttribute($attribTag, $attrib) {
+ $this->member[$this->cnt_member]->setAttribute($attribTag, $attrib);
+ function addToPng($image, $bbox, $width, $height, $line, $text, $label) {
+ for($i=0; $i <= $this->cnt_member; $i++){
+ $image = $this->member[$i]->addToPng($image, $bbox, $width, $height, $line, $text, $label);
+ return $image;
+ function getAllGeom() {
+ return $this->member;
+ function getMember($index) {
+ return $this->member[$index];
+ function getGeomCollSize() {
+ return count($this->member);
+ function getJavaObjStr($bbox, $width, $height) {
+ $javaObjStr = "";
+ $javaObjStr .= $this->member[$i]->getJavaObjStr($bbox, $width, $height);
+ return $javaObjStr;
\ No newline at end of file
More information about the Mapbender_commits
