svn commit: r54 - trunk/mapbender/http/classes: . fonts phpmailer-1.72 phpmailer-1.72/phpdoc
uli at osgeo.org uli at osgeo.org
Thu Apr 13 17:05:54 EDT 2006
Author: uli
Date: 2006-04-13 21:05:53+0000
New Revision: 54
Added:
   trunk/mapbender/http/classes/class_wfs.php
   trunk/mapbender/http/classes/class_wfs_conf.php
   trunk/mapbender/http/classes/fonts/Courier-Oblique.afm
   trunk/mapbender/http/classes/fonts/Helvetica.afm
   trunk/mapbender/http/classes/fonts/Times-Bold.afm
   trunk/mapbender/http/classes/fonts/ZapfDingbats.afm
   trunk/mapbender/http/classes/fonts/php_Times-BoldItalic.afm
   trunk/mapbender/http/classes/fonts/php_Times-Italic.afm
   trunk/mapbender/http/classes/fonts/php_ZapfDingbats.afm
   trunk/mapbender/http/classes/phpmailer-1.72/LICENSE
   trunk/mapbender/http/classes/phpmailer-1.72/phpdoc/deprecated-list.html
   trunk/mapbender/http/classes/phpmailer-1.72/phpdoc/index-all.html
Added: trunk/mapbender/http/classes/class_wfs.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/class_wfs.php?view=auto&rev=54
--- (empty file)
+++ trunk/mapbender/http/classes/class_wfs.php	2006-04-13 21:05:53+0000
@@ -0,0 +1,376 @@
+<?php
+# $Id: class_wfs.php,v 1.15 2006/03/09 13:55:46 uli_rothstein Exp $
+# $Header: /cvsroot/mapbender/mapbender/http/classes/class_wfs.php,v 1.15 2006/03/09 13:55:46 uli_rothstein Exp $
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+* class for wfs-objects
+include_once("../../conf/mapbender.conf");
+require_once("class_connector.php");
+class wfs {
+  var $wfs_id;
+  var $wfs_version;
+  var $wfs_name;
+  var $wfs_title;
+  var $wfs_abstract;
+  var $wfs_getcapabilities;
+  var $wfs_describefeaturetype;
+  var $wfs_getfeature;
+  //neu
+  var $wfs_transaction;
+  var $wfs_featuretype = array();
+function wfs() {
+function createObjFromXML($url){
+	$x = new connector($url);
+	$data = $x->file;
+	#$data = implode("",file($url));
+	if(!$data){
+		echo "Unable to open document: ".$url;
+		die;
+	# for temporary wms a id has to be created...
+	$this->wfs_id = "id_" . substr(md5(rand()),0,6);
+	$parser = xml_parser_create(CHARSET);
+	xml_parser_set_option($parser,XML_OPTION_CASE_FOLDING,0);
+	xml_parser_set_option($parser,XML_OPTION_SKIP_WHITE,1);
+	xml_parser_set_option($parser,XML_OPTION_TARGET_ENCODING,CHARSET);
+	xml_parse_into_struct($parser,$data,$values,$tags);
+	xml_parser_free($parser);
+	$section = false;
+	$request = false;
+	$featuretype_name = false;
+ 	$featuretype_title = false;
+ 	$featuretype_srs = false;
+	foreach ($values as $element) {
+		if(strtoupper($element[tag]) == "WFS_CAPABILITIES" && $element[type] == "open"){
+			$this->wfs_version = $element[attributes][version];
+		if(strtoupper($element[tag]) == "NAME"  && $element[level] == '3'){
+			$this->wfs_name = $element[value];
+		if(strtoupper($element[tag]) == "TITLE"  && $element[level] == '3'){
+			$this->wfs_title = $element[value];
+		if(strtoupper($element[tag]) == "ABSTRACT" && $element[level] == '3'){
+			$this->wfs_abstract = $element[value];
+		/*capability section*/
+		if($this->wfs_version == "1.0.0"){
+			# getCapabilities
+			if(strtoupper($element[tag]) == "GETCAPABILITIES" && $element[type] == "open"){
+				$section = "getcapabilities";
+			if($section == "getcapabilities" && strtoupper($element[tag]) == "GET"){
+				$this->wfs_getcapabilities = $element[attributes][onlineResource];
+			# descriptFeatureType
+			if(strtoupper($element[tag]) == "DESCRIBEFEATURETYPE" && $element[type] == "open"){
+				$section = "describefeaturetype";
+			if($section == "describefeaturetype" && strtoupper($element[tag]) == "GET"){
+				$this->wfs_describefeaturetype = $element[attributes][onlineResource];
+			# getFeature
+			if(strtoupper($element[tag]) == "GETFEATURE" && $element[type] == "open"){
+				$section = "getfeature";
+			if($section == "getfeature" && strtoupper($element[tag]) == "GET"){
+				$this->wfs_getfeature = $element[attributes][onlineResource];
+			if(strtoupper($element[tag]) == "GETFEATURE" && $element[type] == "close"){
+				$section = "";
+			# transaction
+			if(strtoupper($element[tag]) == "TRANSACTION" && $element[type] == "open"){
+				$section = "transaction";
+			if($section == "transaction" && strtoupper($element[tag]) == "GET"){
+				$this->wfs_transaction = $element[attributes][onlineResource];
+			if(strtoupper($element[tag]) == "TRANSACTION" && $element[type] == "close"){
+				$section = "";
+		if(strtoupper($element[tag]) == "FEATURETYPE" && $element[type] == "open"){
+			$section = "featuretype";
+		if($section == "featuretype" && strtoupper($element[tag]) == "NAME"){
+			$featuretype_name = $element[value];
+		if($section == "featuretype" && strtoupper($element[tag]) == "TITLE"){
+			$featuretype_title = $element[value];
+		if($section == "featuretype" && strtoupper($element[tag]) == "SRS"){
+			$featuretype_srs = $element[value];
+			$this->addFeaturetype($featuretype_name,$featuretype_title,$featuretype_srs,$this->wfs_describefeaturetype,$this->wfs_version);
+function displayWFS(){
+	echo "id: " . $this->wfs_id . " <br>";
+	echo "version: " . $this->wfs_version . " <br>";
+	echo "name: " . $this->wfs_name . " <br>";
+	echo "title: " . $this->wfs_title . " <br>";
+	echo "abstract: " . $this->wfs_abstract . " <br>";
+	echo "capabilitiesrequest: " . $this->wfs_getcapabilities . " <br>";
+	echo "describefeaturetype: " . $this->wfs_describefeaturetype . " <br>";
+	echo "getfeature: " . $this->wfs_getfeature . " <br>";
+	echo "transaction: " . $this->wfs_transaction . " <br>";
+	for($i=0; $i<count($this->wfs_featuretype); $i++){
+		echo "<hr>";
+		echo "name: ". $this->wfs_featuretype[$i]->featuretype_name . "<br>";
+		echo "title: ". $this->wfs_featuretype[$i]->featuretype_title . "<br>";
+		echo "srs: ". $this->wfs_featuretype[$i]->featuretype_srs . "<br>";
+		for($j=0; $j<count($this->wfs_featuretype[$i]->featuretype_element);$j++){
+			echo " element: " . $this->wfs_featuretype[$i]->featuretype_element[$j]["name"] ." - ".$this->wfs_featuretype[$i]->featuretype_element[$j]["type"]."<br>";
+function addFeaturetype($name,$title,$srs,$url,$version){
+	$this->wfs_featuretype[count($this->wfs_featuretype)] = new featuretype($name,$title,$srs,$url,$version);
+function createJsObjFromWFS($parent){
+	if(!$this->wfs_title || $this->wfs_title == ""){
+		echo "alert('Error: no valid capabilities-document !!');";
+		die; exit;
+		if($parent){
+			echo "parent.";
+		print("add_wfs('".
+		$this->wfs_id ."','".
+		$this->wfs_version ."','".
+		$this->wfs_title ."','".
+		$this->wfs_abstract ."','".
+		$this->wfs_getcapabilities ."','" .
+		$this->wfs_describefeaturetype ."');");
+		if($parent){
+			echo "parent.";
+		print ("wfs_add_featuretype('".
+			$this->wfs_featuretype[$i]->featuretype_name ."','".
+			$this->wfs_featuretype[$i]->featuretype_title . "','".
+			$this->wfs_featuretype[$i]->featuretype_srs ."','".
+			$this->wfs_featuretype[$i]->featuretype_geomtype ."');");
+			if($parent){
+			echo "parent.";
+			print("wfs_add_featuretype_element('".$this->wfs_featuretype[$i]->featuretype_element[$j]["name"]."', '".$this->wfs_featuretype[$i]->featuretype_element[$j]["type"]."', ".$j.", ".$i.");");
+* wfs2db
+* this function exports the information from the xml to the mapbender database
+function wfs2db($gui_id){
+	global $DBSERVER,$DB,$OWNER,$PW;
+	$con = db_connect($DBSERVER,$OWNER,$PW);
+	db_select_db($DB,$con);
+	# TABLE wfs
+	$sql = "INSERT INTO wfs (wfs_version, wfs_name, wfs_title, wfs_abstract, wfs_getcapabilities, wfs_describefeaturetype, wfs_getfeature, wfs_transaction) ";
+	$sql .= "VALUES(";
+		$sql .= "'" . $this->wfs_version ."', ";
+		$sql .= "'" . db_escape_string(str_replace("'","",$this->wfs_name)) ."', ";
+		$sql .= "'" . db_escape_string(str_replace("'","",$this->wfs_title)) ."', ";
+		$sql .= "'" . db_escape_string(str_replace("'","",$this->wfs_abstract)) .  "', ";
+		$sql .= "'" . $this->wfs_getcapabilities ."', ";
+		$sql .= "'" . $this->wfs_describefeaturetype . "', ";
+		$sql .= "'". $this->wfs_getfeature . "', ";
+		$sql .= "'". $this->wfs_transaction . "'";
+	$sql .= ");";
+	#echo "sql wfs: <br>".$sql;
+	$res = db_query($sql)or die(db_error());
+	$myWFS = db_insert_id($con,'wfs','wfs_id');
+	#echo "<br> myWFS: ".$myWFS;
+	# TABLE wfs_featuretype
+		$sql = "INSERT INTO wfs_featuretype(fkey_wfs_id, featuretype_name, featuretype_title, featuretype_srs) ";
+			$sql .= $myWFS . ",";
+			$sql .= "'".$this->wfs_featuretype[$i]->featuretype_name . "',";
+			$sql .= "'".$this->wfs_featuretype[$i]->featuretype_title."',";
+			$sql .= "'".$this->wfs_featuretype[$i]->featuretype_srs."'";
+		$sql .= ")";
+		#$res = mysql_query($sql) or $this->cleanDB($myWFS,$sql);
+		$res = db_query($sql) or $this->cleanDB($myWFS,$sql);
+		# save the id of each featuretype:
+		$this->wfs_featuretype[$i]->mysql_id = db_insert_id($con,'wfs_featuretype','featuretype_id');
+			$sql = "INSERT INTO wfs_element(fkey_featuretype_id, element_name,element_type) ";
+			$sql .= "'" .$this->wfs_featuretype[$i]->mysql_id. "', ";
+			$sql .= "'" .$this->wfs_featuretype[$i]->featuretype_element[$j]["name"]. "', ";
+			$sql .= "'" .$this->wfs_featuretype[$i]->featuretype_element[$j]["type"]. "' ";
+			$sql .= ")";
+	# TABLE gui_wfs
+	$sql ="INSERT INTO gui_wfs (fkey_gui_id, fkey_wfs_id)";
+		$sql .= "'" . $gui_id . "', ";
+		$sql .= $myWFS;
+	$sql .= ");";
+function cleanDB($wfsid,$sql){
+	$s = "DELETE FROM wfs WHERE wfs_id = ".$wfsid;
+	$res = db_query($s);
+	echo "<br>Error in :".$sql."<br>";
+	echo "<br>Db cleaned.<br>";
+	die;
+* creatObjfromDB
+function createObjFromDB________($wfs_id){
+	global $server,$db,$owner,$pw;
+	$con = mysql_connect($server,$owner,$pw);
+	mysql_select_db($db, $con);
+	$sql = "SELECT * FROM wfs WHERE wfs_id = ".$wfs_id.";";
+	$res = mysql_query($sql);
+	$cnt = 0;
+	while(mysql_fetch_row($res)){
+		$this->wfs_id = mysql_result($res, $cnt, "wfs_id");
+		$this->wfs_version = mysql_result($res, $cnt, "wfs_version");
+		$this->wfs_title = mysql_result($res, $cnt, "wfs_title");
+		$this->wfs_abstract = mysql_result($res, $cnt, "wfs_abstract");
+		$this->wfs_getcapabilities = mysql_result($res, $cnt, "wfs_getcapabilities");
+		$this->wfs_describefeaturetype = mysql_result($res, $cnt, "wfs_describefeaturetype");
+		$sql_fe = "SELECT * FROM wfs_featuretype WHERE fkey_wfs_id = " . $this->wfs_id . " ORDER BY featuretype_id";
+		$res_fe = mysql_query($sql_fe);
+		$cnt_fe = 0;
+		while(mysql_fetch_row($res_fe)){
+			$c = count($this->wfs_featuretype);
+			$this->wfs_featuretype[$c]->featuretype_name = mysql_result($res_fe, $cnt_fe, "featuretype_name");
+			$this->wfs_featuretype[$c]->featuretype_title = mysql_result($res_fe, $cnt_fe, "featuretype_title");
+			$this->wfs_featuretype[$c]->featuretype_srs = mysql_result($res_fe, $cnt_fe, "featuretype_srs");
+			$this->wfs_featuretype[$c]->featuretype_geomtype = mysql_result($res_fe, $cnt_fe, "featuretype_geomtype");
+			$sql_el = "SELECT * FROM wfs_element WHERE fkey_featuretype_id = ". mysql_result($res_fe, $cnt_fe, "featuretype_id")." ORDER BY element_id";
+			$res_el = mysql_query($sql_el);
+			$cnt_el = 0;
+			while(mysql_fetch_row($res_el)){
+				$z = count($this->wfs_featuretype[$c]->featuretype_element);
+				$this->wfs_featuretype[$c]->featuretype_element[$z]["name"] = mysql_result($res_el, $cnt_el, "element_name");
+				$this->wfs_featuretype[$c]->featuretype_element[$z]["type"] = mysql_result($res_el, $cnt_el, "element_type");
+				$cnt_el++;
+			$cnt_fe++;
+		$cnt++;
+/** end createObjfromDB **/
+class featuretype extends wfs{
+	var $featuretype_element = array();
+	function featuretype($name,$title,$srs,$url,$version){
+		$url .= "&SERVICE=WFS&VERSION=".$version."&REQUEST=DescribeFeatureType&TYPENAME=".$name;
+		$this->featuretype_name = $name;
+		$this->featuretype_title = $title;
+		$this->featuretype_srs = $srs;
+		$data = implode("",file($url));
+		$parser = xml_parser_create();
+			if($this->sepNameSpace($element[tag]) == "complexContent" && $element[type] == "open"){
+				$section = "complexcontent";
+				echo "complexcontent";
+			if($section == "complexcontent" && $this->sepNameSpace($element[tag]) == "element" && $element[attributes][name]){
+				$cnt = count($this->featuretype_element);
+				$this->featuretype_element[$cnt]["name"] = $element[attributes]["name"];
+				$this->featuretype_element[$cnt]["type"] = $this->sepNameSpace($element[attributes]["type"]);
+				echo "element: ".$this->featuretype_element[$cnt]["name"]."<br>";
+			if($this->sepNameSpace($element[tag]) == "complexContent" && $element[type] == "close"){
+				$section = "";
+	function sepNameSpace($s){
+		$c = strpos($s,":");
+		if($c>0){
+			return substr($s,$c+1);
+		else{
+			return $s;
\ No newline at end of file
Added: trunk/mapbender/http/classes/class_wfs_conf.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/class_wfs_conf.php?view=auto&rev=54
--- (empty file)
+++ trunk/mapbender/http/classes/class_wfs_conf.php	2006-04-13 21:05:53+0000
@@ -0,0 +1,101 @@
+<?php
+class wfs_conf{
+	var $wfs_id;
+	var $wfs_name;
+	var $wfs_title;
+	var $features;
+	var $elements;
+	function getallwfs(){
+		$this->wfs_id = array();
+		$this->wfs_name = array();
+		$this->wfs_title = array();
+		$this->wfs_abstract = array();
+		$sql = "SELECT * FROM wfs"; // include permission handling
+		$res = db_query($sql);
+		$cnt = 0;
+		while ($row = db_fetch_array($res)){
+			$this->wfs_version[$cnt] = $row["wfs_version"];
+			$this->wfs_id[$cnt] = $row["wfs_id"];
+			$this->wfs_name[$cnt] = $row["wfs_name"];
+			$this->wfs_title[$cnt] = $row["wfs_title"];
+			$this->wfs_abstract[$cnt] = $row["wfs_abstract"];
+			$this->wfs_getcapabilities[$cnt] = $row["wfs_getcapabilities"];
+			$this->wfs_describefeaturetype[$cnt] = $row["wfs_describefeaturetype"];
+			$this->wfs_getfeature[$cnt] = $row["wfs_getfeature"];
+			$cnt++;
+	function getfeatures($wfsid){
+		$this->features = new features($wfsid);
+	function getelements($feature){
+		$this->elements = new elements($feature);
+class features extends wfs_conf{
+	var $featuretype_id;
+	var $featuretype_name;
+	var $featuretype_title;
+	var $featuretype_srs;
+	function features($id){
+		$featuretype_id = array();
+		$featuretype_name = array();
+		$featuretype_title = array();
+		$featuretype_srs = array();
+		$sql = "SELECT * FROM wfs_featuretype WHERE fkey_wfs_id = ".$id;
+		$cnt = 0;
+			$this->featuretype_id[$cnt] = $row["featuretype_id"];
+			$this->featuretype_name[$cnt] = $row["featuretype_name"];
+			$this->featuretype_title[$cnt] = $row["featuretype_title"];
+			$this->featuretype_srs[$cnt] = $row["featuretype_srs"];
+			$cnt++;
+class elements extends wfs_conf{
+	var $element_id;
+	var $element_name;
+	var $element_type;
+	function elements($fid){
+		$element_id = array();
+		$element_name = array();
+		$element_type = array();
+		$sql = "SELECT * FROM wfs_element WHERE fkey_featuretype_id = ".$fid;
+		$cnt = 0;
+			$this->element_id[$cnt] = $row["element_id"];
+			$this->element_name[$cnt] = $row["element_name"];
+			$this->element_type[$cnt] = $row["element_type"];
+			$cnt++;
Added: trunk/mapbender/http/classes/fonts/Courier-Oblique.afm
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/fonts/Courier-Oblique.afm?view=auto&rev=54
--- (empty file)
+++ trunk/mapbender/http/classes/fonts/Courier-Oblique.afm	2006-04-13 21:05:53+0000
@@ -0,0 +1,342 @@
+StartFontMetrics 4.1
+Comment Copyright (c) 1989, 1990, 1991, 1992, 1993, 1997 Adobe Systems Incorporated.  All Rights Reserved.
+Comment Creation Date: Thu May  1 17:37:52 1997
+Comment UniqueID 43051
+Comment VMusage 16248 75829
+FontName Courier-Oblique
+FullName Courier Oblique
+FamilyName Courier
+Weight Medium
+ItalicAngle -12
+IsFixedPitch true
+CharacterSet ExtendedRoman
+FontBBox -27 -250 849 805
+UnderlinePosition -100
+UnderlineThickness 50
+Version 003.000
+Notice Copyright (c) 1989, 1990, 1991, 1992, 1993, 1997 Adobe Systems Incorporated.  All Rights Reserved.
+EncodingScheme AdobeStandardEncoding
+CapHeight 562
+XHeight 426
+Ascender 629
+Descender -157
+StdHW 51
+StdVW 51
+StartCharMetrics 315
+C 32 ; WX 600 ; N space ; B 0 0 0 0 ;
+C 33 ; WX 600 ; N exclam ; B 243 -15 464 572 ;
+C 34 ; WX 600 ; N quotedbl ; B 273 328 532 562 ;
+C 35 ; WX 600 ; N numbersign ; B 133 -32 596 639 ;
+C 36 ; WX 600 ; N dollar ; B 108 -126 596 662 ;
+C 37 ; WX 600 ; N percent ; B 134 -15 599 622 ;
+C 38 ; WX 600 ; N ampersand ; B 87 -15 580 543 ;
+C 39 ; WX 600 ; N quoteright ; B 283 328 495 562 ;
+C 40 ; WX 600 ; N parenleft ; B 313 -108 572 622 ;
+C 41 ; WX 600 ; N parenright ; B 137 -108 396 622 ;
+C 42 ; WX 600 ; N asterisk ; B 212 257 580 607 ;
+C 43 ; WX 600 ; N plus ; B 129 44 580 470 ;
+C 44 ; WX 600 ; N comma ; B 157 -112 370 122 ;
+C 45 ; WX 600 ; N hyphen ; B 152 231 558 285 ;
+C 46 ; WX 600 ; N period ; B 238 -15 382 109 ;
+C 47 ; WX 600 ; N slash ; B 112 -80 604 629 ;
+C 48 ; WX 600 ; N zero ; B 154 -15 575 622 ;
+C 49 ; WX 600 ; N one ; B 98 0 515 622 ;
+C 50 ; WX 600 ; N two ; B 70 0 568 622 ;
+C 51 ; WX 600 ; N three ; B 82 -15 538 622 ;
+C 52 ; WX 600 ; N four ; B 108 0 541 622 ;
+C 53 ; WX 600 ; N five ; B 99 -15 589 607 ;
+C 54 ; WX 600 ; N six ; B 155 -15 629 622 ;
+C 55 ; WX 600 ; N seven ; B 182 0 612 607 ;
+C 56 ; WX 600 ; N eight ; B 132 -15 588 622 ;
+C 57 ; WX 600 ; N nine ; B 93 -15 574 622 ;
+C 58 ; WX 600 ; N colon ; B 238 -15 441 385 ;
+C 59 ; WX 600 ; N semicolon ; B 157 -112 441 385 ;
+C 60 ; WX 600 ; N less ; B 96 42 610 472 ;
+C 61 ; WX 600 ; N equal ; B 109 138 600 376 ;
+C 62 ; WX 600 ; N greater ; B 85 42 599 472 ;
+C 63 ; WX 600 ; N question ; B 222 -15 583 572 ;
+C 64 ; WX 600 ; N at ; B 127 -15 582 622 ;
+C 65 ; WX 600 ; N A ; B 3 0 607 562 ;
+C 66 ; WX 600 ; N B ; B 43 0 616 562 ;
+C 67 ; WX 600 ; N C ; B 93 -18 655 580 ;
+C 68 ; WX 600 ; N D ; B 43 0 645 562 ;
+C 69 ; WX 600 ; N E ; B 53 0 660 562 ;
+C 70 ; WX 600 ; N F ; B 53 0 660 562 ;
+C 71 ; WX 600 ; N G ; B 83 -18 645 580 ;
+C 72 ; WX 600 ; N H ; B 32 0 687 562 ;
+C 73 ; WX 600 ; N I ; B 96 0 623 562 ;
+C 74 ; WX 600 ; N J ; B 52 -18 685 562 ;
+C 75 ; WX 600 ; N K ; B 38 0 671 562 ;
+C 76 ; WX 600 ; N L ; B 47 0 607 562 ;
+C 77 ; WX 600 ; N M ; B 4 0 715 562 ;
+C 78 ; WX 600 ; N N ; B 7 -13 712 562 ;
+C 79 ; WX 600 ; N O ; B 94 -18 625 580 ;
+C 80 ; WX 600 ; N P ; B 79 0 644 562 ;
+C 81 ; WX 600 ; N Q ; B 95 -138 625 580 ;
+C 82 ; WX 600 ; N R ; B 38 0 598 562 ;
+C 83 ; WX 600 ; N S ; B 76 -20 650 580 ;
+C 84 ; WX 600 ; N T ; B 108 0 665 562 ;
+C 85 ; WX 600 ; N U ; B 125 -18 702 562 ;
+C 86 ; WX 600 ; N V ; B 105 -13 723 562 ;
+C 87 ; WX 600 ; N W ; B 106 -13 722 562 ;
+C 88 ; WX 600 ; N X ; B 23 0 675 562 ;
+C 89 ; WX 600 ; N Y ; B 133 0 695 562 ;
+C 90 ; WX 600 ; N Z ; B 86 0 610 562 ;
+C 91 ; WX 600 ; N bracketleft ; B 246 -108 574 622 ;
+C 92 ; WX 600 ; N backslash ; B 249 -80 468 629 ;
+C 93 ; WX 600 ; N bracketright ; B 135 -108 463 622 ;
+C 94 ; WX 600 ; N asciicircum ; B 175 354 587 622 ;
+C 95 ; WX 600 ; N underscore ; B -27 -125 584 -75 ;
+C 96 ; WX 600 ; N quoteleft ; B 343 328 457 562 ;
+C 97 ; WX 600 ; N a ; B 76 -15 569 441 ;
+C 98 ; WX 600 ; N b ; B 29 -15 625 629 ;
+C 99 ; WX 600 ; N c ; B 106 -15 608 441 ;
+C 100 ; WX 600 ; N d ; B 85 -15 640 629 ;
+C 101 ; WX 600 ; N e ; B 106 -15 598 441 ;
+C 102 ; WX 600 ; N f ; B 114 0 662 629 ; L i fi ; L l fl ;
+C 103 ; WX 600 ; N g ; B 61 -157 657 441 ;
+C 104 ; WX 600 ; N h ; B 33 0 592 629 ;
+C 105 ; WX 600 ; N i ; B 95 0 515 657 ;
+C 106 ; WX 600 ; N j ; B 52 -157 550 657 ;
+C 107 ; WX 600 ; N k ; B 58 0 633 629 ;
+C 108 ; WX 600 ; N l ; B 95 0 515 629 ;
+C 109 ; WX 600 ; N m ; B -5 0 615 441 ;
+C 110 ; WX 600 ; N n ; B 26 0 585 441 ;
+C 111 ; WX 600 ; N o ; B 102 -15 588 441 ;
+C 112 ; WX 600 ; N p ; B -24 -157 605 441 ;
+C 113 ; WX 600 ; N q ; B 85 -157 682 441 ;
+C 114 ; WX 600 ; N r ; B 60 0 636 441 ;
+C 115 ; WX 600 ; N s ; B 78 -15 584 441 ;
+C 116 ; WX 600 ; N t ; B 167 -15 561 561 ;
+C 117 ; WX 600 ; N u ; B 101 -15 572 426 ;
+C 118 ; WX 600 ; N v ; B 90 -10 681 426 ;
+C 119 ; WX 600 ; N w ; B 76 -10 695 426 ;
+C 120 ; WX 600 ; N x ; B 20 0 655 426 ;
+C 121 ; WX 600 ; N y ; B -4 -157 683 426 ;
+C 122 ; WX 600 ; N z ; B 99 0 593 426 ;
+C 123 ; WX 600 ; N braceleft ; B 233 -108 569 622 ;
+C 124 ; WX 600 ; N bar ; B 222 -250 485 750 ;
+C 125 ; WX 600 ; N braceright ; B 140 -108 477 622 ;
+C 126 ; WX 600 ; N asciitilde ; B 116 197 600 320 ;
+C 161 ; WX 600 ; N exclamdown ; B 225 -157 445 430 ;
+C 162 ; WX 600 ; N cent ; B 151 -49 588 614 ;
+C 163 ; WX 600 ; N sterling ; B 124 -21 621 611 ;
+C 164 ; WX 600 ; N fraction ; B 84 -57 646 665 ;
+C 165 ; WX 600 ; N yen ; B 120 0 693 562 ;
+C 166 ; WX 600 ; N florin ; B -26 -143 671 622 ;
+C 167 ; WX 600 ; N section ; B 104 -78 590 580 ;
+C 168 ; WX 600 ; N currency ; B 94 58 628 506 ;
+C 169 ; WX 600 ; N quotesingle ; B 345 328 460 562 ;
+C 170 ; WX 600 ; N quotedblleft ; B 262 328 541 562 ;
+C 171 ; WX 600 ; N guillemotleft ; B 92 70 652 446 ;
+C 172 ; WX 600 ; N guilsinglleft ; B 204 70 540 446 ;
+C 173 ; WX 600 ; N guilsinglright ; B 170 70 506 446 ;
+C 174 ; WX 600 ; N fi ; B 3 0 619 629 ;
+C 175 ; WX 600 ; N fl ; B 3 0 619 629 ;
+C 177 ; WX 600 ; N endash ; B 124 231 586 285 ;
+C 178 ; WX 600 ; N dagger ; B 217 -78 546 580 ;
+C 179 ; WX 600 ; N daggerdbl ; B 163 -78 546 580 ;
+C 180 ; WX 600 ; N periodcentered ; B 275 189 434 327 ;
+C 182 ; WX 600 ; N paragraph ; B 100 -78 630 562 ;
+C 183 ; WX 600 ; N bullet ; B 224 130 485 383 ;
+C 184 ; WX 600 ; N quotesinglbase ; B 185 -134 397 100 ;
+C 185 ; WX 600 ; N quotedblbase ; B 115 -134 478 100 ;
+C 186 ; WX 600 ; N quotedblright ; B 213 328 576 562 ;
+C 187 ; WX 600 ; N guillemotright ; B 58 70 618 446 ;
+C 188 ; WX 600 ; N ellipsis ; B 46 -15 575 111 ;
+C 189 ; WX 600 ; N perthousand ; B 59 -15 627 622 ;
+C 191 ; WX 600 ; N questiondown ; B 105 -157 466 430 ;
+C 193 ; WX 600 ; N grave ; B 294 497 484 672 ;
+C 194 ; WX 600 ; N acute ; B 348 497 612 672 ;
+C 195 ; WX 600 ; N circumflex ; B 229 477 581 654 ;
+C 196 ; WX 600 ; N tilde ; B 212 489 629 606 ;
+C 197 ; WX 600 ; N macron ; B 232 525 600 565 ;
+C 198 ; WX 600 ; N breve ; B 279 501 576 609 ;
+C 199 ; WX 600 ; N dotaccent ; B 373 537 478 640 ;
+C 200 ; WX 600 ; N dieresis ; B 272 537 579 640 ;
+C 202 ; WX 600 ; N ring ; B 332 463 500 627 ;
+C 203 ; WX 600 ; N cedilla ; B 197 -151 344 10 ;
+C 205 ; WX 600 ; N hungarumlaut ; B 239 497 683 672 ;
+C 206 ; WX 600 ; N ogonek ; B 189 -172 377 4 ;
+C 207 ; WX 600 ; N caron ; B 262 492 614 669 ;
+C 208 ; WX 600 ; N emdash ; B 49 231 661 285 ;
+C 225 ; WX 600 ; N AE ; B 3 0 655 562 ;
+C 227 ; WX 600 ; N ordfeminine ; B 209 249 512 580 ;
+C 232 ; WX 600 ; N Lslash ; B 47 0 607 562 ;
+C 233 ; WX 600 ; N Oslash ; B 94 -80 625 629 ;
+C 234 ; WX 600 ; N OE ; B 59 0 672 562 ;
+C 235 ; WX 600 ; N ordmasculine ; B 210 249 535 580 ;
+C 241 ; WX 600 ; N ae ; B 41 -15 626 441 ;
+C 245 ; WX 600 ; N dotlessi ; B 95 0 515 426 ;
+C 248 ; WX 600 ; N lslash ; B 95 0 587 629 ;
+C 249 ; WX 600 ; N oslash ; B 102 -80 588 506 ;
+C 250 ; WX 600 ; N oe ; B 54 -15 615 441 ;
+C 251 ; WX 600 ; N germandbls ; B 48 -15 617 629 ;
+C -1 ; WX 600 ; N Idieresis ; B 96 0 623 753 ;
+C -1 ; WX 600 ; N eacute ; B 106 -15 612 672 ;
+C -1 ; WX 600 ; N abreve ; B 76 -15 576 609 ;
+C -1 ; WX 600 ; N uhungarumlaut ; B 101 -15 723 672 ;
+C -1 ; WX 600 ; N ecaron ; B 106 -15 614 669 ;
+C -1 ; WX 600 ; N Ydieresis ; B 133 0 695 753 ;
+C -1 ; WX 600 ; N divide ; B 136 48 573 467 ;
+C -1 ; WX 600 ; N Yacute ; B 133 0 695 805 ;
+C -1 ; WX 600 ; N Acircumflex ; B 3 0 607 787 ;
+C -1 ; WX 600 ; N aacute ; B 76 -15 612 672 ;
+C -1 ; WX 600 ; N Ucircumflex ; B 125 -18 702 787 ;
+C -1 ; WX 600 ; N yacute ; B -4 -157 683 672 ;
+C -1 ; WX 600 ; N scommaaccent ; B 78 -250 584 441 ;
+C -1 ; WX 600 ; N ecircumflex ; B 106 -15 598 654 ;
+C -1 ; WX 600 ; N Uring ; B 125 -18 702 760 ;
+C -1 ; WX 600 ; N Udieresis ; B 125 -18 702 753 ;
+C -1 ; WX 600 ; N aogonek ; B 76 -172 569 441 ;
+C -1 ; WX 600 ; N Uacute ; B 125 -18 702 805 ;
+C -1 ; WX 600 ; N uogonek ; B 101 -172 572 426 ;
+C -1 ; WX 600 ; N Edieresis ; B 53 0 660 753 ;
+C -1 ; WX 600 ; N Dcroat ; B 43 0 645 562 ;
+C -1 ; WX 600 ; N commaaccent ; B 145 -250 323 -58 ;
+C -1 ; WX 600 ; N copyright ; B 53 -18 667 580 ;
+C -1 ; WX 600 ; N Emacron ; B 53 0 660 698 ;
+C -1 ; WX 600 ; N ccaron ; B 106 -15 614 669 ;
+C -1 ; WX 600 ; N aring ; B 76 -15 569 627 ;
+C -1 ; WX 600 ; N Ncommaaccent ; B 7 -250 712 562 ;
+C -1 ; WX 600 ; N lacute ; B 95 0 640 805 ;
+C -1 ; WX 600 ; N agrave ; B 76 -15 569 672 ;
+C -1 ; WX 600 ; N Tcommaaccent ; B 108 -250 665 562 ;
+C -1 ; WX 600 ; N Cacute ; B 93 -18 655 805 ;
+C -1 ; WX 600 ; N atilde ; B 76 -15 629 606 ;
+C -1 ; WX 600 ; N Edotaccent ; B 53 0 660 753 ;
+C -1 ; WX 600 ; N scaron ; B 78 -15 614 669 ;
+C -1 ; WX 600 ; N scedilla ; B 78 -151 584 441 ;
+C -1 ; WX 600 ; N iacute ; B 95 0 612 672 ;
+C -1 ; WX 600 ; N lozenge ; B 94 0 519 706 ;
+C -1 ; WX 600 ; N Rcaron ; B 38 0 642 802 ;
+C -1 ; WX 600 ; N Gcommaaccent ; B 83 -250 645 580 ;
+C -1 ; WX 600 ; N ucircumflex ; B 101 -15 572 654 ;
+C -1 ; WX 600 ; N acircumflex ; B 76 -15 581 654 ;
+C -1 ; WX 600 ; N Amacron ; B 3 0 607 698 ;
+C -1 ; WX 600 ; N rcaron ; B 60 0 636 669 ;
+C -1 ; WX 600 ; N ccedilla ; B 106 -151 614 441 ;
+C -1 ; WX 600 ; N Zdotaccent ; B 86 0 610 753 ;
+C -1 ; WX 600 ; N Thorn ; B 79 0 606 562 ;
+C -1 ; WX 600 ; N Omacron ; B 94 -18 628 698 ;
+C -1 ; WX 600 ; N Racute ; B 38 0 670 805 ;
+C -1 ; WX 600 ; N Sacute ; B 76 -20 650 805 ;
+C -1 ; WX 600 ; N dcaron ; B 85 -15 849 629 ;
+C -1 ; WX 600 ; N Umacron ; B 125 -18 702 698 ;
+C -1 ; WX 600 ; N uring ; B 101 -15 572 627 ;
+C -1 ; WX 600 ; N threesuperior ; B 213 240 501 622 ;
+C -1 ; WX 600 ; N Ograve ; B 94 -18 625 805 ;
+C -1 ; WX 600 ; N Agrave ; B 3 0 607 805 ;
+C -1 ; WX 600 ; N Abreve ; B 3 0 607 732 ;
+C -1 ; WX 600 ; N multiply ; B 103 43 607 470 ;
+C -1 ; WX 600 ; N uacute ; B 101 -15 602 672 ;
+C -1 ; WX 600 ; N Tcaron ; B 108 0 665 802 ;
+C -1 ; WX 600 ; N partialdiff ; B 45 -38 546 710 ;
+C -1 ; WX 600 ; N ydieresis ; B -4 -157 683 620 ;
+C -1 ; WX 600 ; N Nacute ; B 7 -13 712 805 ;
+C -1 ; WX 600 ; N icircumflex ; B 95 0 551 654 ;
+C -1 ; WX 600 ; N Ecircumflex ; B 53 0 660 787 ;
+C -1 ; WX 600 ; N adieresis ; B 76 -15 575 620 ;
+C -1 ; WX 600 ; N edieresis ; B 106 -15 598 620 ;
+C -1 ; WX 600 ; N cacute ; B 106 -15 612 672 ;
+C -1 ; WX 600 ; N nacute ; B 26 0 602 672 ;
+C -1 ; WX 600 ; N umacron ; B 101 -15 600 565 ;
+C -1 ; WX 600 ; N Ncaron ; B 7 -13 712 802 ;
+C -1 ; WX 600 ; N Iacute ; B 96 0 640 805 ;
+C -1 ; WX 600 ; N plusminus ; B 96 44 594 558 ;
+C -1 ; WX 600 ; N brokenbar ; B 238 -175 469 675 ;
+C -1 ; WX 600 ; N registered ; B 53 -18 667 580 ;
+C -1 ; WX 600 ; N Gbreve ; B 83 -18 645 732 ;
+C -1 ; WX 600 ; N Idotaccent ; B 96 0 623 753 ;
+C -1 ; WX 600 ; N summation ; B 15 -10 670 706 ;
+C -1 ; WX 600 ; N Egrave ; B 53 0 660 805 ;
+C -1 ; WX 600 ; N racute ; B 60 0 636 672 ;
+C -1 ; WX 600 ; N omacron ; B 102 -15 600 565 ;
+C -1 ; WX 600 ; N Zacute ; B 86 0 670 805 ;
+C -1 ; WX 600 ; N Zcaron ; B 86 0 642 802 ;
+C -1 ; WX 600 ; N greaterequal ; B 98 0 594 710 ;
+C -1 ; WX 600 ; N Eth ; B 43 0 645 562 ;
+C -1 ; WX 600 ; N Ccedilla ; B 93 -151 658 580 ;
+C -1 ; WX 600 ; N lcommaaccent ; B 95 -250 515 629 ;
+C -1 ; WX 600 ; N tcaron ; B 167 -15 587 717 ;
+C -1 ; WX 600 ; N eogonek ; B 106 -172 598 441 ;
+C -1 ; WX 600 ; N Uogonek ; B 124 -172 702 562 ;
+C -1 ; WX 600 ; N Aacute ; B 3 0 660 805 ;
+C -1 ; WX 600 ; N Adieresis ; B 3 0 607 753 ;
+C -1 ; WX 600 ; N egrave ; B 106 -15 598 672 ;
+C -1 ; WX 600 ; N zacute ; B 99 0 612 672 ;
+C -1 ; WX 600 ; N iogonek ; B 95 -172 515 657 ;
+C -1 ; WX 600 ; N Oacute ; B 94 -18 640 805 ;
+C -1 ; WX 600 ; N oacute ; B 102 -15 612 672 ;
+C -1 ; WX 600 ; N amacron ; B 76 -15 600 565 ;
+C -1 ; WX 600 ; N sacute ; B 78 -15 612 672 ;
+C -1 ; WX 600 ; N idieresis ; B 95 0 545 620 ;
+C -1 ; WX 600 ; N Ocircumflex ; B 94 -18 625 787 ;
+C -1 ; WX 600 ; N Ugrave ; B 125 -18 702 805 ;
+C -1 ; WX 600 ; N Delta ; B 6 0 598 688 ;
+C -1 ; WX 600 ; N thorn ; B -24 -157 605 629 ;
+C -1 ; WX 600 ; N twosuperior ; B 230 249 535 622 ;
+C -1 ; WX 600 ; N Odieresis ; B 94 -18 625 753 ;
+C -1 ; WX 600 ; N mu ; B 72 -157 572 426 ;
+C -1 ; WX 600 ; N igrave ; B 95 0 515 672 ;
+C -1 ; WX 600 ; N ohungarumlaut ; B 102 -15 723 672 ;
+C -1 ; WX 600 ; N Eogonek ; B 53 -172 660 562 ;
+C -1 ; WX 600 ; N dcroat ; B 85 -15 704 629 ;
+C -1 ; WX 600 ; N threequarters ; B 73 -56 659 666 ;
+C -1 ; WX 600 ; N Scedilla ; B 76 -151 650 580 ;
+C -1 ; WX 600 ; N lcaron ; B 95 0 667 629 ;
+C -1 ; WX 600 ; N Kcommaaccent ; B 38 -250 671 562 ;
+C -1 ; WX 600 ; N Lacute ; B 47 0 607 805 ;
+C -1 ; WX 600 ; N trademark ; B 75 263 742 562 ;
+C -1 ; WX 600 ; N edotaccent ; B 106 -15 598 620 ;
+C -1 ; WX 600 ; N Igrave ; B 96 0 623 805 ;
+C -1 ; WX 600 ; N Imacron ; B 96 0 628 698 ;
+C -1 ; WX 600 ; N Lcaron ; B 47 0 632 562 ;
+C -1 ; WX 600 ; N onehalf ; B 65 -57 669 665 ;
+C -1 ; WX 600 ; N lessequal ; B 98 0 645 710 ;
+C -1 ; WX 600 ; N ocircumflex ; B 102 -15 588 654 ;
+C -1 ; WX 600 ; N ntilde ; B 26 0 629 606 ;
+C -1 ; WX 600 ; N Uhungarumlaut ; B 125 -18 761 805 ;
+C -1 ; WX 600 ; N Eacute ; B 53 0 670 805 ;
+C -1 ; WX 600 ; N emacron ; B 106 -15 600 565 ;
+C -1 ; WX 600 ; N gbreve ; B 61 -157 657 609 ;
+C -1 ; WX 600 ; N onequarter ; B 65 -57 674 665 ;
+C -1 ; WX 600 ; N Scaron ; B 76 -20 672 802 ;
+C -1 ; WX 600 ; N Scommaaccent ; B 76 -250 650 580 ;
+C -1 ; WX 600 ; N Ohungarumlaut ; B 94 -18 751 805 ;
+C -1 ; WX 600 ; N degree ; B 214 269 576 622 ;
+C -1 ; WX 600 ; N ograve ; B 102 -15 588 672 ;
+C -1 ; WX 600 ; N Ccaron ; B 93 -18 672 802 ;
+C -1 ; WX 600 ; N ugrave ; B 101 -15 572 672 ;
+C -1 ; WX 600 ; N radical ; B 85 -15 765 792 ;
+C -1 ; WX 600 ; N Dcaron ; B 43 0 645 802 ;
+C -1 ; WX 600 ; N rcommaaccent ; B 60 -250 636 441 ;
+C -1 ; WX 600 ; N Ntilde ; B 7 -13 712 729 ;
+C -1 ; WX 600 ; N otilde ; B 102 -15 629 606 ;
+C -1 ; WX 600 ; N Rcommaaccent ; B 38 -250 598 562 ;
+C -1 ; WX 600 ; N Lcommaaccent ; B 47 -250 607 562 ;
+C -1 ; WX 600 ; N Atilde ; B 3 0 655 729 ;
+C -1 ; WX 600 ; N Aogonek ; B 3 -172 607 562 ;
+C -1 ; WX 600 ; N Aring ; B 3 0 607 750 ;
+C -1 ; WX 600 ; N Otilde ; B 94 -18 655 729 ;
+C -1 ; WX 600 ; N zdotaccent ; B 99 0 593 620 ;
+C -1 ; WX 600 ; N Ecaron ; B 53 0 660 802 ;
+C -1 ; WX 600 ; N Iogonek ; B 96 -172 623 562 ;
+C -1 ; WX 600 ; N kcommaaccent ; B 58 -250 633 629 ;
+C -1 ; WX 600 ; N minus ; B 129 232 580 283 ;
+C -1 ; WX 600 ; N Icircumflex ; B 96 0 623 787 ;
+C -1 ; WX 600 ; N ncaron ; B 26 0 614 669 ;
+C -1 ; WX 600 ; N tcommaaccent ; B 165 -250 561 561 ;
+C -1 ; WX 600 ; N logicalnot ; B 155 108 591 369 ;
+C -1 ; WX 600 ; N odieresis ; B 102 -15 588 620 ;
+C -1 ; WX 600 ; N udieresis ; B 101 -15 575 620 ;
+C -1 ; WX 600 ; N notequal ; B 43 -16 621 529 ;
+C -1 ; WX 600 ; N gcommaaccent ; B 61 -157 657 708 ;
+C -1 ; WX 600 ; N eth ; B 102 -15 639 629 ;
+C -1 ; WX 600 ; N zcaron ; B 99 0 624 669 ;
+C -1 ; WX 600 ; N ncommaaccent ; B 26 -250 585 441 ;
+C -1 ; WX 600 ; N onesuperior ; B 231 249 491 622 ;
+C -1 ; WX 600 ; N imacron ; B 95 0 543 565 ;
+C -1 ; WX 600 ; N Euro ; B 0 0 0 0 ;
+EndCharMetrics
+EndFontMetrics
Added: trunk/mapbender/http/classes/fonts/Helvetica.afm
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/fonts/Helvetica.afm?view=auto&rev=54
--- (empty file)
+++ trunk/mapbender/http/classes/fonts/Helvetica.afm	2006-04-13 21:05:53+0000
@@ -0,0 +1,3051 @@
+Comment Copyright (c) 1985, 1987, 1989, 1990, 1997 Adobe Systems Incorporated.  All Rights Reserved.
+Comment Creation Date: Thu May  1 12:38:23 1997
+Comment UniqueID 43054
+Comment VMusage 37069 48094
+FontName Helvetica
+FullName Helvetica
+FamilyName Helvetica
+Weight Medium
+ItalicAngle 0
+IsFixedPitch false
+FontBBox -166 -225 1000 931
+Version 002.000
+Notice Copyright (c) 1985, 1987, 1989, 1990, 1997 Adobe Systems Incorporated.  All Rights Reserved.Helvetica is a trademark of Linotype-Hell AG and/or its subsidiaries.
+CapHeight 718
+XHeight 523
+Ascender 718
+Descender -207
+StdHW 76
+StdVW 88
+C 32 ; WX 278 ; N space ; B 0 0 0 0 ;
+C 33 ; WX 278 ; N exclam ; B 90 0 187 718 ;
+C 34 ; WX 355 ; N quotedbl ; B 70 463 285 718 ;
+C 35 ; WX 556 ; N numbersign ; B 28 0 529 688 ;
+C 36 ; WX 556 ; N dollar ; B 32 -115 520 775 ;
+C 37 ; WX 889 ; N percent ; B 39 -19 850 703 ;
+C 38 ; WX 667 ; N ampersand ; B 44 -15 645 718 ;
+C 39 ; WX 222 ; N quoteright ; B 53 463 157 718 ;
+C 40 ; WX 333 ; N parenleft ; B 68 -207 299 733 ;
+C 41 ; WX 333 ; N parenright ; B 34 -207 265 733 ;
+C 42 ; WX 389 ; N asterisk ; B 39 431 349 718 ;
+C 43 ; WX 584 ; N plus ; B 39 0 545 505 ;
+C 44 ; WX 278 ; N comma ; B 87 -147 191 106 ;
+C 45 ; WX 333 ; N hyphen ; B 44 232 289 322 ;
+C 46 ; WX 278 ; N period ; B 87 0 191 106 ;
+C 47 ; WX 278 ; N slash ; B -17 -19 295 737 ;
+C 48 ; WX 556 ; N zero ; B 37 -19 519 703 ;
+C 49 ; WX 556 ; N one ; B 101 0 359 703 ;
+C 50 ; WX 556 ; N two ; B 26 0 507 703 ;
+C 51 ; WX 556 ; N three ; B 34 -19 522 703 ;
+C 52 ; WX 556 ; N four ; B 25 0 523 703 ;
+C 53 ; WX 556 ; N five ; B 32 -19 514 688 ;
+C 54 ; WX 556 ; N six ; B 38 -19 518 703 ;
+C 55 ; WX 556 ; N seven ; B 37 0 523 688 ;
+C 56 ; WX 556 ; N eight ; B 38 -19 517 703 ;
+C 57 ; WX 556 ; N nine ; B 42 -19 514 703 ;
+C 58 ; WX 278 ; N colon ; B 87 0 191 516 ;
+C 59 ; WX 278 ; N semicolon ; B 87 -147 191 516 ;
+C 60 ; WX 584 ; N less ; B 48 11 536 495 ;
+C 61 ; WX 584 ; N equal ; B 39 115 545 390 ;
+C 62 ; WX 584 ; N greater ; B 48 11 536 495 ;
+C 63 ; WX 556 ; N question ; B 56 0 492 727 ;
+C 64 ; WX 1015 ; N at ; B 147 -19 868 737 ;
+C 65 ; WX 667 ; N A ; B 14 0 654 718 ;
+C 66 ; WX 667 ; N B ; B 74 0 627 718 ;
+C 67 ; WX 722 ; N C ; B 44 -19 681 737 ;
+C 68 ; WX 722 ; N D ; B 81 0 674 718 ;
+C 69 ; WX 667 ; N E ; B 86 0 616 718 ;
+C 70 ; WX 611 ; N F ; B 86 0 583 718 ;
+C 71 ; WX 778 ; N G ; B 48 -19 704 737 ;
+C 72 ; WX 722 ; N H ; B 77 0 646 718 ;
+C 73 ; WX 278 ; N I ; B 91 0 188 718 ;
+C 74 ; WX 500 ; N J ; B 17 -19 428 718 ;
+C 75 ; WX 667 ; N K ; B 76 0 663 718 ;
+C 76 ; WX 556 ; N L ; B 76 0 537 718 ;
+C 77 ; WX 833 ; N M ; B 73 0 761 718 ;
+C 78 ; WX 722 ; N N ; B 76 0 646 718 ;
+C 79 ; WX 778 ; N O ; B 39 -19 739 737 ;
+C 80 ; WX 667 ; N P ; B 86 0 622 718 ;
+C 81 ; WX 778 ; N Q ; B 39 -56 739 737 ;
+C 82 ; WX 722 ; N R ; B 88 0 684 718 ;
+C 83 ; WX 667 ; N S ; B 49 -19 620 737 ;
+C 84 ; WX 611 ; N T ; B 14 0 597 718 ;
+C 85 ; WX 722 ; N U ; B 79 -19 644 718 ;
+C 86 ; WX 667 ; N V ; B 20 0 647 718 ;
+C 87 ; WX 944 ; N W ; B 16 0 928 718 ;
+C 88 ; WX 667 ; N X ; B 19 0 648 718 ;
+C 89 ; WX 667 ; N Y ; B 14 0 653 718 ;
+C 90 ; WX 611 ; N Z ; B 23 0 588 718 ;
+C 91 ; WX 278 ; N bracketleft ; B 63 -196 250 722 ;
+C 92 ; WX 278 ; N backslash ; B -17 -19 295 737 ;
+C 93 ; WX 278 ; N bracketright ; B 28 -196 215 722 ;
+C 94 ; WX 469 ; N asciicircum ; B -14 264 483 688 ;
+C 95 ; WX 556 ; N underscore ; B 0 -125 556 -75 ;
+C 96 ; WX 222 ; N quoteleft ; B 65 470 169 725 ;
+C 97 ; WX 556 ; N a ; B 36 -15 530 538 ;
+C 98 ; WX 556 ; N b ; B 58 -15 517 718 ;
+C 99 ; WX 500 ; N c ; B 30 -15 477 538 ;
+C 100 ; WX 556 ; N d ; B 35 -15 499 718 ;
+C 101 ; WX 556 ; N e ; B 40 -15 516 538 ;
+C 102 ; WX 278 ; N f ; B 14 0 262 728 ; L i fi ; L l fl ;
+C 103 ; WX 556 ; N g ; B 40 -220 499 538 ;
+C 104 ; WX 556 ; N h ; B 65 0 491 718 ;
+C 105 ; WX 222 ; N i ; B 67 0 155 718 ;
+C 106 ; WX 222 ; N j ; B -16 -210 155 718 ;
+C 107 ; WX 500 ; N k ; B 67 0 501 718 ;
+C 108 ; WX 222 ; N l ; B 67 0 155 718 ;
+C 109 ; WX 833 ; N m ; B 65 0 769 538 ;
+C 110 ; WX 556 ; N n ; B 65 0 491 538 ;
+C 111 ; WX 556 ; N o ; B 35 -14 521 538 ;
+C 112 ; WX 556 ; N p ; B 58 -207 517 538 ;
+C 113 ; WX 556 ; N q ; B 35 -207 494 538 ;
+C 114 ; WX 333 ; N r ; B 77 0 332 538 ;
+C 115 ; WX 500 ; N s ; B 32 -15 464 538 ;
+C 116 ; WX 278 ; N t ; B 14 -7 257 669 ;
+C 117 ; WX 556 ; N u ; B 68 -15 489 523 ;
+C 118 ; WX 500 ; N v ; B 8 0 492 523 ;
+C 119 ; WX 722 ; N w ; B 14 0 709 523 ;
+C 120 ; WX 500 ; N x ; B 11 0 490 523 ;
+C 121 ; WX 500 ; N y ; B 11 -214 489 523 ;
+C 122 ; WX 500 ; N z ; B 31 0 469 523 ;
+C 123 ; WX 334 ; N braceleft ; B 42 -196 292 722 ;
+C 124 ; WX 260 ; N bar ; B 94 -225 167 775 ;
+C 125 ; WX 334 ; N braceright ; B 42 -196 292 722 ;
+C 126 ; WX 584 ; N asciitilde ; B 61 180 523 326 ;
+C 161 ; WX 333 ; N exclamdown ; B 118 -195 215 523 ;
+C 162 ; WX 556 ; N cent ; B 51 -115 513 623 ;
+C 163 ; WX 556 ; N sterling ; B 33 -16 539 718 ;
+C 164 ; WX 167 ; N fraction ; B -166 -19 333 703 ;
+C 165 ; WX 556 ; N yen ; B 3 0 553 688 ;
+C 166 ; WX 556 ; N florin ; B -11 -207 501 737 ;
+C 167 ; WX 556 ; N section ; B 43 -191 512 737 ;
+C 168 ; WX 556 ; N currency ; B 28 99 528 603 ;
+C 169 ; WX 191 ; N quotesingle ; B 59 463 132 718 ;
+C 170 ; WX 333 ; N quotedblleft ; B 38 470 307 725 ;
+C 171 ; WX 556 ; N guillemotleft ; B 97 108 459 446 ;
+C 172 ; WX 333 ; N guilsinglleft ; B 88 108 245 446 ;
+C 173 ; WX 333 ; N guilsinglright ; B 88 108 245 446 ;
+C 174 ; WX 500 ; N fi ; B 14 0 434 728 ;
+C 175 ; WX 500 ; N fl ; B 14 0 432 728 ;
+C 177 ; WX 556 ; N endash ; B 0 240 556 313 ;
+C 178 ; WX 556 ; N dagger ; B 43 -159 514 718 ;
+C 179 ; WX 556 ; N daggerdbl ; B 43 -159 514 718 ;
+C 180 ; WX 278 ; N periodcentered ; B 77 190 202 315 ;
+C 182 ; WX 537 ; N paragraph ; B 18 -173 497 718 ;
+C 183 ; WX 350 ; N bullet ; B 18 202 333 517 ;
+C 184 ; WX 222 ; N quotesinglbase ; B 53 -149 157 106 ;
+C 185 ; WX 333 ; N quotedblbase ; B 26 -149 295 106 ;
+C 186 ; WX 333 ; N quotedblright ; B 26 463 295 718 ;
+C 187 ; WX 556 ; N guillemotright ; B 97 108 459 446 ;
+C 188 ; WX 1000 ; N ellipsis ; B 115 0 885 106 ;
+C 189 ; WX 1000 ; N perthousand ; B 7 -19 994 703 ;
+C 191 ; WX 611 ; N questiondown ; B 91 -201 527 525 ;
+C 193 ; WX 333 ; N grave ; B 14 593 211 734 ;
+C 194 ; WX 333 ; N acute ; B 122 593 319 734 ;
+C 195 ; WX 333 ; N circumflex ; B 21 593 312 734 ;
+C 196 ; WX 333 ; N tilde ; B -4 606 337 722 ;
+C 197 ; WX 333 ; N macron ; B 10 627 323 684 ;
+C 198 ; WX 333 ; N breve ; B 13 595 321 731 ;
+C 199 ; WX 333 ; N dotaccent ; B 121 604 212 706 ;
+C 200 ; WX 333 ; N dieresis ; B 40 604 293 706 ;
+C 202 ; WX 333 ; N ring ; B 75 572 259 756 ;
+C 203 ; WX 333 ; N cedilla ; B 45 -225 259 0 ;
+C 205 ; WX 333 ; N hungarumlaut ; B 31 593 409 734 ;
+C 206 ; WX 333 ; N ogonek ; B 73 -225 287 0 ;
+C 207 ; WX 333 ; N caron ; B 21 593 312 734 ;
+C 208 ; WX 1000 ; N emdash ; B 0 240 1000 313 ;
+C 225 ; WX 1000 ; N AE ; B 8 0 951 718 ;
+C 227 ; WX 370 ; N ordfeminine ; B 24 405 346 737 ;
+C 232 ; WX 556 ; N Lslash ; B -20 0 537 718 ;
+C 233 ; WX 778 ; N Oslash ; B 39 -19 740 737 ;
+C 234 ; WX 1000 ; N OE ; B 36 -19 965 737 ;
+C 235 ; WX 365 ; N ordmasculine ; B 25 405 341 737 ;
+C 241 ; WX 889 ; N ae ; B 36 -15 847 538 ;
+C 245 ; WX 278 ; N dotlessi ; B 95 0 183 523 ;
+C 248 ; WX 222 ; N lslash ; B -20 0 242 718 ;
+C 249 ; WX 611 ; N oslash ; B 28 -22 537 545 ;
+C 250 ; WX 944 ; N oe ; B 35 -15 902 538 ;
+C 251 ; WX 611 ; N germandbls ; B 67 -15 571 728 ;
+C -1 ; WX 278 ; N Idieresis ; B 13 0 266 901 ;
+C -1 ; WX 556 ; N eacute ; B 40 -15 516 734 ;
+C -1 ; WX 556 ; N abreve ; B 36 -15 530 731 ;
+C -1 ; WX 556 ; N uhungarumlaut ; B 68 -15 521 734 ;
+C -1 ; WX 556 ; N ecaron ; B 40 -15 516 734 ;
+C -1 ; WX 667 ; N Ydieresis ; B 14 0 653 901 ;
+C -1 ; WX 584 ; N divide ; B 39 -19 545 524 ;
+C -1 ; WX 667 ; N Yacute ; B 14 0 653 929 ;
+C -1 ; WX 667 ; N Acircumflex ; B 14 0 654 929 ;
+C -1 ; WX 556 ; N aacute ; B 36 -15 530 734 ;
+C -1 ; WX 722 ; N Ucircumflex ; B 79 -19 644 929 ;
+C -1 ; WX 500 ; N yacute ; B 11 -214 489 734 ;
+C -1 ; WX 500 ; N scommaaccent ; B 32 -225 464 538 ;
+C -1 ; WX 556 ; N ecircumflex ; B 40 -15 516 734 ;
+C -1 ; WX 722 ; N Uring ; B 79 -19 644 931 ;
+C -1 ; WX 722 ; N Udieresis ; B 79 -19 644 901 ;
+C -1 ; WX 556 ; N aogonek ; B 36 -220 547 538 ;
+C -1 ; WX 722 ; N Uacute ; B 79 -19 644 929 ;
+C -1 ; WX 556 ; N uogonek ; B 68 -225 519 523 ;
+C -1 ; WX 667 ; N Edieresis ; B 86 0 616 901 ;
+C -1 ; WX 722 ; N Dcroat ; B 0 0 674 718 ;
+C -1 ; WX 250 ; N commaaccent ; B 87 -225 181 -40 ;
+C -1 ; WX 737 ; N copyright ; B -14 -19 752 737 ;
+C -1 ; WX 667 ; N Emacron ; B 86 0 616 879 ;
+C -1 ; WX 500 ; N ccaron ; B 30 -15 477 734 ;
+C -1 ; WX 556 ; N aring ; B 36 -15 530 756 ;
+C -1 ; WX 722 ; N Ncommaaccent ; B 76 -225 646 718 ;
+C -1 ; WX 222 ; N lacute ; B 67 0 264 929 ;
+C -1 ; WX 556 ; N agrave ; B 36 -15 530 734 ;
+C -1 ; WX 611 ; N Tcommaaccent ; B 14 -225 597 718 ;
+C -1 ; WX 722 ; N Cacute ; B 44 -19 681 929 ;
+C -1 ; WX 556 ; N atilde ; B 36 -15 530 722 ;
+C -1 ; WX 667 ; N Edotaccent ; B 86 0 616 901 ;
+C -1 ; WX 500 ; N scaron ; B 32 -15 464 734 ;
+C -1 ; WX 500 ; N scedilla ; B 32 -225 464 538 ;
+C -1 ; WX 278 ; N iacute ; B 95 0 292 734 ;
+C -1 ; WX 471 ; N lozenge ; B 10 0 462 728 ;
+C -1 ; WX 722 ; N Rcaron ; B 88 0 684 929 ;
+C -1 ; WX 778 ; N Gcommaaccent ; B 48 -225 704 737 ;
+C -1 ; WX 556 ; N ucircumflex ; B 68 -15 489 734 ;
+C -1 ; WX 556 ; N acircumflex ; B 36 -15 530 734 ;
+C -1 ; WX 667 ; N Amacron ; B 14 0 654 879 ;
+C -1 ; WX 333 ; N rcaron ; B 61 0 352 734 ;
+C -1 ; WX 500 ; N ccedilla ; B 30 -225 477 538 ;
+C -1 ; WX 611 ; N Zdotaccent ; B 23 0 588 901 ;
+C -1 ; WX 667 ; N Thorn ; B 86 0 622 718 ;
+C -1 ; WX 778 ; N Omacron ; B 39 -19 739 879 ;
+C -1 ; WX 722 ; N Racute ; B 88 0 684 929 ;
+C -1 ; WX 667 ; N Sacute ; B 49 -19 620 929 ;
+C -1 ; WX 643 ; N dcaron ; B 35 -15 655 718 ;
+C -1 ; WX 722 ; N Umacron ; B 79 -19 644 879 ;
+C -1 ; WX 556 ; N uring ; B 68 -15 489 756 ;
+C -1 ; WX 333 ; N threesuperior ; B 5 270 325 703 ;
+C -1 ; WX 778 ; N Ograve ; B 39 -19 739 929 ;
+C -1 ; WX 667 ; N Agrave ; B 14 0 654 929 ;
+C -1 ; WX 667 ; N Abreve ; B 14 0 654 926 ;
+C -1 ; WX 584 ; N multiply ; B 39 0 545 506 ;
+C -1 ; WX 556 ; N uacute ; B 68 -15 489 734 ;
+C -1 ; WX 611 ; N Tcaron ; B 14 0 597 929 ;
+C -1 ; WX 476 ; N partialdiff ; B 13 -38 463 714 ;
+C -1 ; WX 500 ; N ydieresis ; B 11 -214 489 706 ;
+C -1 ; WX 722 ; N Nacute ; B 76 0 646 929 ;
+C -1 ; WX 278 ; N icircumflex ; B -6 0 285 734 ;
+C -1 ; WX 667 ; N Ecircumflex ; B 86 0 616 929 ;
+C -1 ; WX 556 ; N adieresis ; B 36 -15 530 706 ;
+C -1 ; WX 556 ; N edieresis ; B 40 -15 516 706 ;
+C -1 ; WX 500 ; N cacute ; B 30 -15 477 734 ;
+C -1 ; WX 556 ; N nacute ; B 65 0 491 734 ;
+C -1 ; WX 556 ; N umacron ; B 68 -15 489 684 ;
+C -1 ; WX 722 ; N Ncaron ; B 76 0 646 929 ;
+C -1 ; WX 278 ; N Iacute ; B 91 0 292 929 ;
+C -1 ; WX 584 ; N plusminus ; B 39 0 545 506 ;
+C -1 ; WX 260 ; N brokenbar ; B 94 -150 167 700 ;
+C -1 ; WX 737 ; N registered ; B -14 -19 752 737 ;
+C -1 ; WX 778 ; N Gbreve ; B 48 -19 704 926 ;
+C -1 ; WX 278 ; N Idotaccent ; B 91 0 188 901 ;
+C -1 ; WX 600 ; N summation ; B 15 -10 586 706 ;
+C -1 ; WX 667 ; N Egrave ; B 86 0 616 929 ;
+C -1 ; WX 333 ; N racute ; B 77 0 332 734 ;
+C -1 ; WX 556 ; N omacron ; B 35 -14 521 684 ;
+C -1 ; WX 611 ; N Zacute ; B 23 0 588 929 ;
+C -1 ; WX 611 ; N Zcaron ; B 23 0 588 929 ;
+C -1 ; WX 549 ; N greaterequal ; B 26 0 523 674 ;
+C -1 ; WX 722 ; N Eth ; B 0 0 674 718 ;
+C -1 ; WX 722 ; N Ccedilla ; B 44 -225 681 737 ;
+C -1 ; WX 222 ; N lcommaaccent ; B 67 -225 167 718 ;
+C -1 ; WX 317 ; N tcaron ; B 14 -7 329 808 ;
+C -1 ; WX 556 ; N eogonek ; B 40 -225 516 538 ;
+C -1 ; WX 722 ; N Uogonek ; B 79 -225 644 718 ;
+C -1 ; WX 667 ; N Aacute ; B 14 0 654 929 ;
+C -1 ; WX 667 ; N Adieresis ; B 14 0 654 901 ;
+C -1 ; WX 556 ; N egrave ; B 40 -15 516 734 ;
+C -1 ; WX 500 ; N zacute ; B 31 0 469 734 ;
+C -1 ; WX 222 ; N iogonek ; B -31 -225 183 718 ;
+C -1 ; WX 778 ; N Oacute ; B 39 -19 739 929 ;
+C -1 ; WX 556 ; N oacute ; B 35 -14 521 734 ;
+C -1 ; WX 556 ; N amacron ; B 36 -15 530 684 ;
+C -1 ; WX 500 ; N sacute ; B 32 -15 464 734 ;
+C -1 ; WX 278 ; N idieresis ; B 13 0 266 706 ;
+C -1 ; WX 778 ; N Ocircumflex ; B 39 -19 739 929 ;
+C -1 ; WX 722 ; N Ugrave ; B 79 -19 644 929 ;
+C -1 ; WX 612 ; N Delta ; B 6 0 608 688 ;
+C -1 ; WX 556 ; N thorn ; B 58 -207 517 718 ;
+C -1 ; WX 333 ; N twosuperior ; B 4 281 323 703 ;
+C -1 ; WX 778 ; N Odieresis ; B 39 -19 739 901 ;
+C -1 ; WX 556 ; N mu ; B 68 -207 489 523 ;
+C -1 ; WX 278 ; N igrave ; B -13 0 184 734 ;
+C -1 ; WX 556 ; N ohungarumlaut ; B 35 -14 521 734 ;
+C -1 ; WX 667 ; N Eogonek ; B 86 -220 633 718 ;
+C -1 ; WX 556 ; N dcroat ; B 35 -15 550 718 ;
+C -1 ; WX 834 ; N threequarters ; B 45 -19 810 703 ;
+C -1 ; WX 667 ; N Scedilla ; B 49 -225 620 737 ;
+C -1 ; WX 299 ; N lcaron ; B 67 0 311 718 ;
+C -1 ; WX 667 ; N Kcommaaccent ; B 76 -225 663 718 ;
+C -1 ; WX 556 ; N Lacute ; B 76 0 537 929 ;
+C -1 ; WX 1000 ; N trademark ; B 46 306 903 718 ;
+C -1 ; WX 556 ; N edotaccent ; B 40 -15 516 706 ;
+C -1 ; WX 278 ; N Igrave ; B -13 0 188 929 ;
+C -1 ; WX 278 ; N Imacron ; B -17 0 296 879 ;
+C -1 ; WX 556 ; N Lcaron ; B 76 0 537 718 ;
+C -1 ; WX 834 ; N onehalf ; B 43 -19 773 703 ;
+C -1 ; WX 549 ; N lessequal ; B 26 0 523 674 ;
+C -1 ; WX 556 ; N ocircumflex ; B 35 -14 521 734 ;
+C -1 ; WX 556 ; N ntilde ; B 65 0 491 722 ;
+C -1 ; WX 722 ; N Uhungarumlaut ; B 79 -19 644 929 ;
+C -1 ; WX 667 ; N Eacute ; B 86 0 616 929 ;
+C -1 ; WX 556 ; N emacron ; B 40 -15 516 684 ;
+C -1 ; WX 556 ; N gbreve ; B 40 -220 499 731 ;
+C -1 ; WX 834 ; N onequarter ; B 73 -19 756 703 ;
+C -1 ; WX 667 ; N Scaron ; B 49 -19 620 929 ;
+C -1 ; WX 667 ; N Scommaaccent ; B 49 -225 620 737 ;
+C -1 ; WX 778 ; N Ohungarumlaut ; B 39 -19 739 929 ;
+C -1 ; WX 400 ; N degree ; B 54 411 346 703 ;
+C -1 ; WX 556 ; N ograve ; B 35 -14 521 734 ;
+C -1 ; WX 722 ; N Ccaron ; B 44 -19 681 929 ;
+C -1 ; WX 556 ; N ugrave ; B 68 -15 489 734 ;
+C -1 ; WX 453 ; N radical ; B -4 -80 458 762 ;
+C -1 ; WX 722 ; N Dcaron ; B 81 0 674 929 ;
+C -1 ; WX 333 ; N rcommaaccent ; B 77 -225 332 538 ;
+C -1 ; WX 722 ; N Ntilde ; B 76 0 646 917 ;
+C -1 ; WX 556 ; N otilde ; B 35 -14 521 722 ;
+C -1 ; WX 722 ; N Rcommaaccent ; B 88 -225 684 718 ;
+C -1 ; WX 556 ; N Lcommaaccent ; B 76 -225 537 718 ;
+C -1 ; WX 667 ; N Atilde ; B 14 0 654 917 ;
+C -1 ; WX 667 ; N Aogonek ; B 14 -225 654 718 ;
+C -1 ; WX 667 ; N Aring ; B 14 0 654 931 ;
+C -1 ; WX 778 ; N Otilde ; B 39 -19 739 917 ;
+C -1 ; WX 500 ; N zdotaccent ; B 31 0 469 706 ;
+C -1 ; WX 667 ; N Ecaron ; B 86 0 616 929 ;
+C -1 ; WX 278 ; N Iogonek ; B -3 -225 211 718 ;
+C -1 ; WX 500 ; N kcommaaccent ; B 67 -225 501 718 ;
+C -1 ; WX 584 ; N minus ; B 39 216 545 289 ;
+C -1 ; WX 278 ; N Icircumflex ; B -6 0 285 929 ;
+C -1 ; WX 556 ; N ncaron ; B 65 0 491 734 ;
+C -1 ; WX 278 ; N tcommaaccent ; B 14 -225 257 669 ;
+C -1 ; WX 584 ; N logicalnot ; B 39 108 545 390 ;
+C -1 ; WX 556 ; N odieresis ; B 35 -14 521 706 ;
+C -1 ; WX 556 ; N udieresis ; B 68 -15 489 706 ;
+C -1 ; WX 549 ; N notequal ; B 12 -35 537 551 ;
+C -1 ; WX 556 ; N gcommaaccent ; B 40 -220 499 822 ;
+C -1 ; WX 556 ; N eth ; B 35 -15 522 737 ;
+C -1 ; WX 500 ; N zcaron ; B 31 0 469 734 ;
+C -1 ; WX 556 ; N ncommaaccent ; B 65 -225 491 538 ;
+C -1 ; WX 333 ; N onesuperior ; B 43 281 222 703 ;
+C -1 ; WX 278 ; N imacron ; B 5 0 272 684 ;
+C -1 ; WX 556 ; N Euro ; B 0 0 0 0 ;
+EndCharMetrics
+StartKernData
+StartKernPairs 2705
+KPX A C -30
+KPX A Cacute -30
+KPX A Ccaron -30
+KPX A Ccedilla -30
+KPX A G -30
+KPX A Gbreve -30
+KPX A Gcommaaccent -30
+KPX A O -30
+KPX A Oacute -30
+KPX A Ocircumflex -30
+KPX A Odieresis -30
+KPX A Ograve -30
+KPX A Ohungarumlaut -30
+KPX A Omacron -30
+KPX A Oslash -30
+KPX A Otilde -30
+KPX A Q -30
+KPX A T -120
+KPX A Tcaron -120
+KPX A Tcommaaccent -120
+KPX A U -50
+KPX A Uacute -50
+KPX A Ucircumflex -50
+KPX A Udieresis -50
+KPX A Ugrave -50
+KPX A Uhungarumlaut -50
+KPX A Umacron -50
+KPX A Uogonek -50
+KPX A Uring -50
+KPX A V -70
+KPX A W -50
+KPX A Y -100
+KPX A Yacute -100
+KPX A Ydieresis -100
+KPX A u -30
+KPX A uacute -30
+KPX A ucircumflex -30
+KPX A udieresis -30
+KPX A ugrave -30
+KPX A uhungarumlaut -30
+KPX A umacron -30
+KPX A uogonek -30
+KPX A uring -30
+KPX A v -40
+KPX A w -40
+KPX A y -40
+KPX A yacute -40
+KPX A ydieresis -40
+KPX Aacute C -30
+KPX Aacute Cacute -30
+KPX Aacute Ccaron -30
+KPX Aacute Ccedilla -30
+KPX Aacute G -30
+KPX Aacute Gbreve -30
+KPX Aacute Gcommaaccent -30
+KPX Aacute O -30
+KPX Aacute Oacute -30
+KPX Aacute Ocircumflex -30
+KPX Aacute Odieresis -30
+KPX Aacute Ograve -30
+KPX Aacute Ohungarumlaut -30
+KPX Aacute Omacron -30
+KPX Aacute Oslash -30
+KPX Aacute Otilde -30
+KPX Aacute Q -30
+KPX Aacute T -120
+KPX Aacute Tcaron -120
+KPX Aacute Tcommaaccent -120
+KPX Aacute U -50
+KPX Aacute Uacute -50
+KPX Aacute Ucircumflex -50
+KPX Aacute Udieresis -50
+KPX Aacute Ugrave -50
+KPX Aacute Uhungarumlaut -50
+KPX Aacute Umacron -50
+KPX Aacute Uogonek -50
+KPX Aacute Uring -50
+KPX Aacute V -70
+KPX Aacute W -50
+KPX Aacute Y -100
+KPX Aacute Yacute -100
+KPX Aacute Ydieresis -100
+KPX Aacute u -30
+KPX Aacute uacute -30
+KPX Aacute ucircumflex -30
+KPX Aacute udieresis -30
+KPX Aacute ugrave -30
+KPX Aacute uhungarumlaut -30
+KPX Aacute umacron -30
+KPX Aacute uogonek -30
+KPX Aacute uring -30
+KPX Aacute v -40
+KPX Aacute w -40
+KPX Aacute y -40
+KPX Aacute yacute -40
+KPX Aacute ydieresis -40
+KPX Abreve C -30
+KPX Abreve Cacute -30
+KPX Abreve Ccaron -30
+KPX Abreve Ccedilla -30
+KPX Abreve G -30
+KPX Abreve Gbreve -30
+KPX Abreve Gcommaaccent -30
+KPX Abreve O -30
+KPX Abreve Oacute -30
+KPX Abreve Ocircumflex -30
+KPX Abreve Odieresis -30
+KPX Abreve Ograve -30
+KPX Abreve Ohungarumlaut -30
+KPX Abreve Omacron -30
+KPX Abreve Oslash -30
+KPX Abreve Otilde -30
+KPX Abreve Q -30
+KPX Abreve T -120
+KPX Abreve Tcaron -120
+KPX Abreve Tcommaaccent -120
+KPX Abreve U -50
+KPX Abreve Uacute -50
+KPX Abreve Ucircumflex -50
+KPX Abreve Udieresis -50
+KPX Abreve Ugrave -50
+KPX Abreve Uhungarumlaut -50
+KPX Abreve Umacron -50
+KPX Abreve Uogonek -50
+KPX Abreve Uring -50
+KPX Abreve V -70
+KPX Abreve W -50
+KPX Abreve Y -100
+KPX Abreve Yacute -100
+KPX Abreve Ydieresis -100
+KPX Abreve u -30
+KPX Abreve uacute -30
+KPX Abreve ucircumflex -30
+KPX Abreve udieresis -30
+KPX Abreve ugrave -30
+KPX Abreve uhungarumlaut -30
+KPX Abreve umacron -30
+KPX Abreve uogonek -30
+KPX Abreve uring -30
+KPX Abreve v -40
+KPX Abreve w -40
+KPX Abreve y -40
+KPX Abreve yacute -40
+KPX Abreve ydieresis -40
+KPX Acircumflex C -30
+KPX Acircumflex Cacute -30
+KPX Acircumflex Ccaron -30
+KPX Acircumflex Ccedilla -30
+KPX Acircumflex G -30
+KPX Acircumflex Gbreve -30
+KPX Acircumflex Gcommaaccent -30
+KPX Acircumflex O -30
+KPX Acircumflex Oacute -30
+KPX Acircumflex Ocircumflex -30
+KPX Acircumflex Odieresis -30
+KPX Acircumflex Ograve -30
+KPX Acircumflex Ohungarumlaut -30
+KPX Acircumflex Omacron -30
+KPX Acircumflex Oslash -30
+KPX Acircumflex Otilde -30
+KPX Acircumflex Q -30
+KPX Acircumflex T -120
+KPX Acircumflex Tcaron -120
+KPX Acircumflex Tcommaaccent -120
+KPX Acircumflex U -50
+KPX Acircumflex Uacute -50
+KPX Acircumflex Ucircumflex -50
+KPX Acircumflex Udieresis -50
+KPX Acircumflex Ugrave -50
+KPX Acircumflex Uhungarumlaut -50
+KPX Acircumflex Umacron -50
+KPX Acircumflex Uogonek -50
+KPX Acircumflex Uring -50
+KPX Acircumflex V -70
+KPX Acircumflex W -50
+KPX Acircumflex Y -100
+KPX Acircumflex Yacute -100
+KPX Acircumflex Ydieresis -100
+KPX Acircumflex u -30
+KPX Acircumflex uacute -30
+KPX Acircumflex ucircumflex -30
+KPX Acircumflex udieresis -30
+KPX Acircumflex ugrave -30
+KPX Acircumflex uhungarumlaut -30
+KPX Acircumflex umacron -30
+KPX Acircumflex uogonek -30
+KPX Acircumflex uring -30
+KPX Acircumflex v -40
+KPX Acircumflex w -40
+KPX Acircumflex y -40
+KPX Acircumflex yacute -40
+KPX Acircumflex ydieresis -40
+KPX Adieresis C -30
+KPX Adieresis Cacute -30
+KPX Adieresis Ccaron -30
+KPX Adieresis Ccedilla -30
+KPX Adieresis G -30
+KPX Adieresis Gbreve -30
+KPX Adieresis Gcommaaccent -30
+KPX Adieresis O -30
+KPX Adieresis Oacute -30
+KPX Adieresis Ocircumflex -30
+KPX Adieresis Odieresis -30
+KPX Adieresis Ograve -30
+KPX Adieresis Ohungarumlaut -30
+KPX Adieresis Omacron -30
+KPX Adieresis Oslash -30
+KPX Adieresis Otilde -30
+KPX Adieresis Q -30
+KPX Adieresis T -120
+KPX Adieresis Tcaron -120
+KPX Adieresis Tcommaaccent -120
+KPX Adieresis U -50
+KPX Adieresis Uacute -50
+KPX Adieresis Ucircumflex -50
+KPX Adieresis Udieresis -50
+KPX Adieresis Ugrave -50
+KPX Adieresis Uhungarumlaut -50
+KPX Adieresis Umacron -50
+KPX Adieresis Uogonek -50
+KPX Adieresis Uring -50
+KPX Adieresis V -70
+KPX Adieresis W -50
+KPX Adieresis Y -100
+KPX Adieresis Yacute -100
+KPX Adieresis Ydieresis -100
+KPX Adieresis u -30
+KPX Adieresis uacute -30
+KPX Adieresis ucircumflex -30
+KPX Adieresis udieresis -30
+KPX Adieresis ugrave -30
+KPX Adieresis uhungarumlaut -30
+KPX Adieresis umacron -30
+KPX Adieresis uogonek -30
+KPX Adieresis uring -30
+KPX Adieresis v -40
+KPX Adieresis w -40
+KPX Adieresis y -40
+KPX Adieresis yacute -40
+KPX Adieresis ydieresis -40
+KPX Agrave C -30
+KPX Agrave Cacute -30
+KPX Agrave Ccaron -30
+KPX Agrave Ccedilla -30
+KPX Agrave G -30
+KPX Agrave Gbreve -30
+KPX Agrave Gcommaaccent -30
+KPX Agrave O -30
+KPX Agrave Oacute -30
+KPX Agrave Ocircumflex -30
+KPX Agrave Odieresis -30
+KPX Agrave Ograve -30
+KPX Agrave Ohungarumlaut -30
+KPX Agrave Omacron -30
+KPX Agrave Oslash -30
+KPX Agrave Otilde -30
+KPX Agrave Q -30
+KPX Agrave T -120
+KPX Agrave Tcaron -120
+KPX Agrave Tcommaaccent -120
+KPX Agrave U -50
+KPX Agrave Uacute -50
+KPX Agrave Ucircumflex -50
+KPX Agrave Udieresis -50
+KPX Agrave Ugrave -50
+KPX Agrave Uhungarumlaut -50
+KPX Agrave Umacron -50
+KPX Agrave Uogonek -50
+KPX Agrave Uring -50
+KPX Agrave V -70
+KPX Agrave W -50
+KPX Agrave Y -100
+KPX Agrave Yacute -100
+KPX Agrave Ydieresis -100
+KPX Agrave u -30
+KPX Agrave uacute -30
+KPX Agrave ucircumflex -30
+KPX Agrave udieresis -30
+KPX Agrave ugrave -30
+KPX Agrave uhungarumlaut -30
+KPX Agrave umacron -30
+KPX Agrave uogonek -30
+KPX Agrave uring -30
+KPX Agrave v -40
+KPX Agrave w -40
+KPX Agrave y -40
+KPX Agrave yacute -40
+KPX Agrave ydieresis -40
+KPX Amacron C -30
+KPX Amacron Cacute -30
+KPX Amacron Ccaron -30
+KPX Amacron Ccedilla -30
+KPX Amacron G -30
+KPX Amacron Gbreve -30
+KPX Amacron Gcommaaccent -30
+KPX Amacron O -30
+KPX Amacron Oacute -30
+KPX Amacron Ocircumflex -30
+KPX Amacron Odieresis -30
+KPX Amacron Ograve -30
+KPX Amacron Ohungarumlaut -30
+KPX Amacron Omacron -30
+KPX Amacron Oslash -30
+KPX Amacron Otilde -30
+KPX Amacron Q -30
+KPX Amacron T -120
+KPX Amacron Tcaron -120
+KPX Amacron Tcommaaccent -120
+KPX Amacron U -50
+KPX Amacron Uacute -50
+KPX Amacron Ucircumflex -50
+KPX Amacron Udieresis -50
+KPX Amacron Ugrave -50
+KPX Amacron Uhungarumlaut -50
+KPX Amacron Umacron -50
+KPX Amacron Uogonek -50
+KPX Amacron Uring -50
+KPX Amacron V -70
+KPX Amacron W -50
+KPX Amacron Y -100
+KPX Amacron Yacute -100
+KPX Amacron Ydieresis -100
+KPX Amacron u -30
+KPX Amacron uacute -30
+KPX Amacron ucircumflex -30
+KPX Amacron udieresis -30
+KPX Amacron ugrave -30
+KPX Amacron uhungarumlaut -30
+KPX Amacron umacron -30
+KPX Amacron uogonek -30
+KPX Amacron uring -30
+KPX Amacron v -40
+KPX Amacron w -40
+KPX Amacron y -40
+KPX Amacron yacute -40
+KPX Amacron ydieresis -40
+KPX Aogonek C -30
+KPX Aogonek Cacute -30
+KPX Aogonek Ccaron -30
+KPX Aogonek Ccedilla -30
+KPX Aogonek G -30
+KPX Aogonek Gbreve -30
+KPX Aogonek Gcommaaccent -30
+KPX Aogonek O -30
+KPX Aogonek Oacute -30
+KPX Aogonek Ocircumflex -30
+KPX Aogonek Odieresis -30
+KPX Aogonek Ograve -30
+KPX Aogonek Ohungarumlaut -30
+KPX Aogonek Omacron -30
+KPX Aogonek Oslash -30
+KPX Aogonek Otilde -30
+KPX Aogonek Q -30
+KPX Aogonek T -120
+KPX Aogonek Tcaron -120
+KPX Aogonek Tcommaaccent -120
+KPX Aogonek U -50
+KPX Aogonek Uacute -50
+KPX Aogonek Ucircumflex -50
+KPX Aogonek Udieresis -50
+KPX Aogonek Ugrave -50
+KPX Aogonek Uhungarumlaut -50
+KPX Aogonek Umacron -50
+KPX Aogonek Uogonek -50
+KPX Aogonek Uring -50
+KPX Aogonek V -70
+KPX Aogonek W -50
+KPX Aogonek Y -100
+KPX Aogonek Yacute -100
+KPX Aogonek Ydieresis -100
+KPX Aogonek u -30
+KPX Aogonek uacute -30
+KPX Aogonek ucircumflex -30
+KPX Aogonek udieresis -30
+KPX Aogonek ugrave -30
+KPX Aogonek uhungarumlaut -30
+KPX Aogonek umacron -30
+KPX Aogonek uogonek -30
+KPX Aogonek uring -30
+KPX Aogonek v -40
+KPX Aogonek w -40
+KPX Aogonek y -40
+KPX Aogonek yacute -40
+KPX Aogonek ydieresis -40
+KPX Aring C -30
+KPX Aring Cacute -30
+KPX Aring Ccaron -30
+KPX Aring Ccedilla -30
+KPX Aring G -30
+KPX Aring Gbreve -30
+KPX Aring Gcommaaccent -30
+KPX Aring O -30
+KPX Aring Oacute -30
+KPX Aring Ocircumflex -30
+KPX Aring Odieresis -30
+KPX Aring Ograve -30
+KPX Aring Ohungarumlaut -30
+KPX Aring Omacron -30
+KPX Aring Oslash -30
+KPX Aring Otilde -30
+KPX Aring Q -30
+KPX Aring T -120
+KPX Aring Tcaron -120
+KPX Aring Tcommaaccent -120
+KPX Aring U -50
+KPX Aring Uacute -50
+KPX Aring Ucircumflex -50
+KPX Aring Udieresis -50
+KPX Aring Ugrave -50
+KPX Aring Uhungarumlaut -50
+KPX Aring Umacron -50
+KPX Aring Uogonek -50
+KPX Aring Uring -50
+KPX Aring V -70
+KPX Aring W -50
+KPX Aring Y -100
+KPX Aring Yacute -100
+KPX Aring Ydieresis -100
+KPX Aring u -30
+KPX Aring uacute -30
+KPX Aring ucircumflex -30
+KPX Aring udieresis -30
+KPX Aring ugrave -30
+KPX Aring uhungarumlaut -30
+KPX Aring umacron -30
+KPX Aring uogonek -30
+KPX Aring uring -30
+KPX Aring v -40
+KPX Aring w -40
+KPX Aring y -40
+KPX Aring yacute -40
+KPX Aring ydieresis -40
+KPX Atilde C -30
+KPX Atilde Cacute -30
+KPX Atilde Ccaron -30
+KPX Atilde Ccedilla -30
+KPX Atilde G -30
+KPX Atilde Gbreve -30
+KPX Atilde Gcommaaccent -30
+KPX Atilde O -30
+KPX Atilde Oacute -30
+KPX Atilde Ocircumflex -30
+KPX Atilde Odieresis -30
+KPX Atilde Ograve -30
+KPX Atilde Ohungarumlaut -30
+KPX Atilde Omacron -30
+KPX Atilde Oslash -30
+KPX Atilde Otilde -30
+KPX Atilde Q -30
+KPX Atilde T -120
+KPX Atilde Tcaron -120
+KPX Atilde Tcommaaccent -120
+KPX Atilde U -50
+KPX Atilde Uacute -50
+KPX Atilde Ucircumflex -50
+KPX Atilde Udieresis -50
+KPX Atilde Ugrave -50
+KPX Atilde Uhungarumlaut -50
+KPX Atilde Umacron -50
+KPX Atilde Uogonek -50
+KPX Atilde Uring -50
+KPX Atilde V -70
+KPX Atilde W -50
+KPX Atilde Y -100
+KPX Atilde Yacute -100
+KPX Atilde Ydieresis -100
+KPX Atilde u -30
+KPX Atilde uacute -30
+KPX Atilde ucircumflex -30
+KPX Atilde udieresis -30
+KPX Atilde ugrave -30
+KPX Atilde uhungarumlaut -30
+KPX Atilde umacron -30
+KPX Atilde uogonek -30
+KPX Atilde uring -30
+KPX Atilde v -40
+KPX Atilde w -40
+KPX Atilde y -40
+KPX Atilde yacute -40
+KPX Atilde ydieresis -40
+KPX B U -10
+KPX B Uacute -10
+KPX B Ucircumflex -10
+KPX B Udieresis -10
+KPX B Ugrave -10
+KPX B Uhungarumlaut -10
+KPX B Umacron -10
+KPX B Uogonek -10
+KPX B Uring -10
+KPX B comma -20
+KPX B period -20
+KPX C comma -30
+KPX C period -30
+KPX Cacute comma -30
+KPX Cacute period -30
+KPX Ccaron comma -30
+KPX Ccaron period -30
+KPX Ccedilla comma -30
+KPX Ccedilla period -30
+KPX D A -40
+KPX D Aacute -40
+KPX D Abreve -40
+KPX D Acircumflex -40
+KPX D Adieresis -40
+KPX D Agrave -40
+KPX D Amacron -40
+KPX D Aogonek -40
+KPX D Aring -40
+KPX D Atilde -40
+KPX D V -70
+KPX D W -40
+KPX D Y -90
+KPX D Yacute -90
+KPX D Ydieresis -90
+KPX D comma -70
+KPX D period -70
+KPX Dcaron A -40
+KPX Dcaron Aacute -40
+KPX Dcaron Abreve -40
+KPX Dcaron Acircumflex -40
+KPX Dcaron Adieresis -40
+KPX Dcaron Agrave -40
+KPX Dcaron Amacron -40
+KPX Dcaron Aogonek -40
+KPX Dcaron Aring -40
+KPX Dcaron Atilde -40
+KPX Dcaron V -70
+KPX Dcaron W -40
+KPX Dcaron Y -90
+KPX Dcaron Yacute -90
+KPX Dcaron Ydieresis -90
+KPX Dcaron comma -70
+KPX Dcaron period -70
+KPX Dcroat A -40
+KPX Dcroat Aacute -40
+KPX Dcroat Abreve -40
+KPX Dcroat Acircumflex -40
+KPX Dcroat Adieresis -40
+KPX Dcroat Agrave -40
+KPX Dcroat Amacron -40
+KPX Dcroat Aogonek -40
+KPX Dcroat Aring -40
+KPX Dcroat Atilde -40
+KPX Dcroat V -70
+KPX Dcroat W -40
+KPX Dcroat Y -90
+KPX Dcroat Yacute -90
+KPX Dcroat Ydieresis -90
+KPX Dcroat comma -70
+KPX Dcroat period -70
+KPX F A -80
+KPX F Aacute -80
+KPX F Abreve -80
+KPX F Acircumflex -80
+KPX F Adieresis -80
+KPX F Agrave -80
+KPX F Amacron -80
+KPX F Aogonek -80
+KPX F Aring -80
+KPX F Atilde -80
+KPX F a -50
+KPX F aacute -50
+KPX F abreve -50
+KPX F acircumflex -50
+KPX F adieresis -50
+KPX F agrave -50
+KPX F amacron -50
+KPX F aogonek -50
+KPX F aring -50
+KPX F atilde -50
+KPX F comma -150
+KPX F e -30
+KPX F eacute -30
+KPX F ecaron -30
+KPX F ecircumflex -30
+KPX F edieresis -30
+KPX F edotaccent -30
+KPX F egrave -30
+KPX F emacron -30
+KPX F eogonek -30
+KPX F o -30
+KPX F oacute -30
+KPX F ocircumflex -30
+KPX F odieresis -30
+KPX F ograve -30
+KPX F ohungarumlaut -30
+KPX F omacron -30
+KPX F oslash -30
+KPX F otilde -30
+KPX F period -150
+KPX F r -45
+KPX F racute -45
+KPX F rcaron -45
+KPX F rcommaaccent -45
+KPX J A -20
+KPX J Aacute -20
+KPX J Abreve -20
+KPX J Acircumflex -20
+KPX J Adieresis -20
+KPX J Agrave -20
+KPX J Amacron -20
+KPX J Aogonek -20
+KPX J Aring -20
+KPX J Atilde -20
+KPX J a -20
+KPX J aacute -20
+KPX J abreve -20
+KPX J acircumflex -20
+KPX J adieresis -20
+KPX J agrave -20
+KPX J amacron -20
+KPX J aogonek -20
+KPX J aring -20
+KPX J atilde -20
+KPX J comma -30
+KPX J period -30
+KPX J u -20
+KPX J uacute -20
+KPX J ucircumflex -20
+KPX J udieresis -20
+KPX J ugrave -20
+KPX J uhungarumlaut -20
+KPX J umacron -20
+KPX J uogonek -20
+KPX J uring -20
+KPX K O -50
+KPX K Oacute -50
+KPX K Ocircumflex -50
+KPX K Odieresis -50
+KPX K Ograve -50
+KPX K Ohungarumlaut -50
+KPX K Omacron -50
+KPX K Oslash -50
+KPX K Otilde -50
+KPX K e -40
+KPX K eacute -40
+KPX K ecaron -40
+KPX K ecircumflex -40
+KPX K edieresis -40
+KPX K edotaccent -40
+KPX K egrave -40
+KPX K emacron -40
+KPX K eogonek -40
+KPX K o -40
+KPX K oacute -40
+KPX K ocircumflex -40
+KPX K odieresis -40
+KPX K ograve -40
+KPX K ohungarumlaut -40
+KPX K omacron -40
+KPX K oslash -40
+KPX K otilde -40
+KPX K u -30
+KPX K uacute -30
+KPX K ucircumflex -30
+KPX K udieresis -30
+KPX K ugrave -30
+KPX K uhungarumlaut -30
+KPX K umacron -30
+KPX K uogonek -30
+KPX K uring -30
+KPX K y -50
+KPX K yacute -50
+KPX K ydieresis -50
+KPX Kcommaaccent O -50
+KPX Kcommaaccent Oacute -50
+KPX Kcommaaccent Ocircumflex -50
+KPX Kcommaaccent Odieresis -50
+KPX Kcommaaccent Ograve -50
+KPX Kcommaaccent Ohungarumlaut -50
+KPX Kcommaaccent Omacron -50
+KPX Kcommaaccent Oslash -50
+KPX Kcommaaccent Otilde -50
+KPX Kcommaaccent e -40
+KPX Kcommaaccent eacute -40
+KPX Kcommaaccent ecaron -40
+KPX Kcommaaccent ecircumflex -40
+KPX Kcommaaccent edieresis -40
+KPX Kcommaaccent edotaccent -40
+KPX Kcommaaccent egrave -40
+KPX Kcommaaccent emacron -40
+KPX Kcommaaccent eogonek -40
+KPX Kcommaaccent o -40
+KPX Kcommaaccent oacute -40
+KPX Kcommaaccent ocircumflex -40
+KPX Kcommaaccent odieresis -40
+KPX Kcommaaccent ograve -40
+KPX Kcommaaccent ohungarumlaut -40
+KPX Kcommaaccent omacron -40
+KPX Kcommaaccent oslash -40
+KPX Kcommaaccent otilde -40
+KPX Kcommaaccent u -30
+KPX Kcommaaccent uacute -30
+KPX Kcommaaccent ucircumflex -30
+KPX Kcommaaccent udieresis -30
+KPX Kcommaaccent ugrave -30
+KPX Kcommaaccent uhungarumlaut -30
+KPX Kcommaaccent umacron -30
+KPX Kcommaaccent uogonek -30
+KPX Kcommaaccent uring -30
+KPX Kcommaaccent y -50
+KPX Kcommaaccent yacute -50
+KPX Kcommaaccent ydieresis -50
+KPX L T -110
+KPX L Tcaron -110
+KPX L Tcommaaccent -110
+KPX L V -110
+KPX L W -70
+KPX L Y -140
+KPX L Yacute -140
+KPX L Ydieresis -140
+KPX L quotedblright -140
+KPX L quoteright -160
+KPX L y -30
+KPX L yacute -30
+KPX L ydieresis -30
+KPX Lacute T -110
+KPX Lacute Tcaron -110
+KPX Lacute Tcommaaccent -110
+KPX Lacute V -110
+KPX Lacute W -70
+KPX Lacute Y -140
+KPX Lacute Yacute -140
+KPX Lacute Ydieresis -140
+KPX Lacute quotedblright -140
+KPX Lacute quoteright -160
+KPX Lacute y -30
+KPX Lacute yacute -30
+KPX Lacute ydieresis -30
+KPX Lcaron T -110
+KPX Lcaron Tcaron -110
+KPX Lcaron Tcommaaccent -110
+KPX Lcaron V -110
+KPX Lcaron W -70
+KPX Lcaron Y -140
+KPX Lcaron Yacute -140
+KPX Lcaron Ydieresis -140
+KPX Lcaron quotedblright -140
+KPX Lcaron quoteright -160
+KPX Lcaron y -30
+KPX Lcaron yacute -30
+KPX Lcaron ydieresis -30
+KPX Lcommaaccent T -110
+KPX Lcommaaccent Tcaron -110
+KPX Lcommaaccent Tcommaaccent -110
+KPX Lcommaaccent V -110
+KPX Lcommaaccent W -70
+KPX Lcommaaccent Y -140
+KPX Lcommaaccent Yacute -140
+KPX Lcommaaccent Ydieresis -140
+KPX Lcommaaccent quotedblright -140
+KPX Lcommaaccent quoteright -160
+KPX Lcommaaccent y -30
+KPX Lcommaaccent yacute -30
+KPX Lcommaaccent ydieresis -30
+KPX Lslash T -110
+KPX Lslash Tcaron -110
+KPX Lslash Tcommaaccent -110
+KPX Lslash V -110
+KPX Lslash W -70
+KPX Lslash Y -140
+KPX Lslash Yacute -140
+KPX Lslash Ydieresis -140
+KPX Lslash quotedblright -140
+KPX Lslash quoteright -160
+KPX Lslash y -30
+KPX Lslash yacute -30
+KPX Lslash ydieresis -30
+KPX O A -20
+KPX O Aacute -20
+KPX O Abreve -20
+KPX O Acircumflex -20
+KPX O Adieresis -20
+KPX O Agrave -20
+KPX O Amacron -20
+KPX O Aogonek -20
+KPX O Aring -20
+KPX O Atilde -20
+KPX O T -40
+KPX O Tcaron -40
+KPX O Tcommaaccent -40
+KPX O V -50
+KPX O W -30
+KPX O X -60
+KPX O Y -70
+KPX O Yacute -70
+KPX O Ydieresis -70
+KPX O comma -40
+KPX O period -40
+KPX Oacute A -20
+KPX Oacute Aacute -20
+KPX Oacute Abreve -20
+KPX Oacute Acircumflex -20
+KPX Oacute Adieresis -20
+KPX Oacute Agrave -20
+KPX Oacute Amacron -20
+KPX Oacute Aogonek -20
+KPX Oacute Aring -20
+KPX Oacute Atilde -20
+KPX Oacute T -40
+KPX Oacute Tcaron -40
+KPX Oacute Tcommaaccent -40
+KPX Oacute V -50
+KPX Oacute W -30
+KPX Oacute X -60
+KPX Oacute Y -70
+KPX Oacute Yacute -70
+KPX Oacute Ydieresis -70
+KPX Oacute comma -40
+KPX Oacute period -40
+KPX Ocircumflex A -20
+KPX Ocircumflex Aacute -20
+KPX Ocircumflex Abreve -20
+KPX Ocircumflex Acircumflex -20
+KPX Ocircumflex Adieresis -20
+KPX Ocircumflex Agrave -20
+KPX Ocircumflex Amacron -20
+KPX Ocircumflex Aogonek -20
+KPX Ocircumflex Aring -20
+KPX Ocircumflex Atilde -20
+KPX Ocircumflex T -40
+KPX Ocircumflex Tcaron -40
+KPX Ocircumflex Tcommaaccent -40
+KPX Ocircumflex V -50
+KPX Ocircumflex W -30
+KPX Ocircumflex X -60
+KPX Ocircumflex Y -70
+KPX Ocircumflex Yacute -70
+KPX Ocircumflex Ydieresis -70
+KPX Ocircumflex comma -40
+KPX Ocircumflex period -40
+KPX Odieresis A -20
+KPX Odieresis Aacute -20
+KPX Odieresis Abreve -20
+KPX Odieresis Acircumflex -20
+KPX Odieresis Adieresis -20
+KPX Odieresis Agrave -20
+KPX Odieresis Amacron -20
+KPX Odieresis Aogonek -20
+KPX Odieresis Aring -20
+KPX Odieresis Atilde -20
+KPX Odieresis T -40
+KPX Odieresis Tcaron -40
+KPX Odieresis Tcommaaccent -40
+KPX Odieresis V -50
+KPX Odieresis W -30
+KPX Odieresis X -60
+KPX Odieresis Y -70
+KPX Odieresis Yacute -70
+KPX Odieresis Ydieresis -70
+KPX Odieresis comma -40
+KPX Odieresis period -40
+KPX Ograve A -20
+KPX Ograve Aacute -20
+KPX Ograve Abreve -20
+KPX Ograve Acircumflex -20
+KPX Ograve Adieresis -20
+KPX Ograve Agrave -20
+KPX Ograve Amacron -20
+KPX Ograve Aogonek -20
+KPX Ograve Aring -20
+KPX Ograve Atilde -20
+KPX Ograve T -40
+KPX Ograve Tcaron -40
+KPX Ograve Tcommaaccent -40
+KPX Ograve V -50
+KPX Ograve W -30
+KPX Ograve X -60
+KPX Ograve Y -70
+KPX Ograve Yacute -70
+KPX Ograve Ydieresis -70
+KPX Ograve comma -40
+KPX Ograve period -40
+KPX Ohungarumlaut A -20
+KPX Ohungarumlaut Aacute -20
+KPX Ohungarumlaut Abreve -20
+KPX Ohungarumlaut Acircumflex -20
+KPX Ohungarumlaut Adieresis -20
+KPX Ohungarumlaut Agrave -20
+KPX Ohungarumlaut Amacron -20
+KPX Ohungarumlaut Aogonek -20
+KPX Ohungarumlaut Aring -20
+KPX Ohungarumlaut Atilde -20
+KPX Ohungarumlaut T -40
+KPX Ohungarumlaut Tcaron -40
+KPX Ohungarumlaut Tcommaaccent -40
+KPX Ohungarumlaut V -50
+KPX Ohungarumlaut W -30
+KPX Ohungarumlaut X -60
+KPX Ohungarumlaut Y -70
+KPX Ohungarumlaut Yacute -70
+KPX Ohungarumlaut Ydieresis -70
+KPX Ohungarumlaut comma -40
+KPX Ohungarumlaut period -40
+KPX Omacron A -20
+KPX Omacron Aacute -20
+KPX Omacron Abreve -20
+KPX Omacron Acircumflex -20
+KPX Omacron Adieresis -20
+KPX Omacron Agrave -20
+KPX Omacron Amacron -20
+KPX Omacron Aogonek -20
+KPX Omacron Aring -20
+KPX Omacron Atilde -20
+KPX Omacron T -40
+KPX Omacron Tcaron -40
+KPX Omacron Tcommaaccent -40
+KPX Omacron V -50
+KPX Omacron W -30
+KPX Omacron X -60
+KPX Omacron Y -70
+KPX Omacron Yacute -70
+KPX Omacron Ydieresis -70
+KPX Omacron comma -40
+KPX Omacron period -40
+KPX Oslash A -20
+KPX Oslash Aacute -20
+KPX Oslash Abreve -20
+KPX Oslash Acircumflex -20
+KPX Oslash Adieresis -20
+KPX Oslash Agrave -20
+KPX Oslash Amacron -20
+KPX Oslash Aogonek -20
+KPX Oslash Aring -20
+KPX Oslash Atilde -20
+KPX Oslash T -40
+KPX Oslash Tcaron -40
+KPX Oslash Tcommaaccent -40
+KPX Oslash V -50
+KPX Oslash W -30
+KPX Oslash X -60
+KPX Oslash Y -70
+KPX Oslash Yacute -70
+KPX Oslash Ydieresis -70
+KPX Oslash comma -40
+KPX Oslash period -40
+KPX Otilde A -20
+KPX Otilde Aacute -20
+KPX Otilde Abreve -20
+KPX Otilde Acircumflex -20
+KPX Otilde Adieresis -20
+KPX Otilde Agrave -20
+KPX Otilde Amacron -20
+KPX Otilde Aogonek -20
+KPX Otilde Aring -20
+KPX Otilde Atilde -20
+KPX Otilde T -40
+KPX Otilde Tcaron -40
+KPX Otilde Tcommaaccent -40
+KPX Otilde V -50
+KPX Otilde W -30
+KPX Otilde X -60
+KPX Otilde Y -70
+KPX Otilde Yacute -70
+KPX Otilde Ydieresis -70
+KPX Otilde comma -40
+KPX Otilde period -40
+KPX P A -120
+KPX P Aacute -120
+KPX P Abreve -120
+KPX P Acircumflex -120
+KPX P Adieresis -120
+KPX P Agrave -120
+KPX P Amacron -120
+KPX P Aogonek -120
+KPX P Aring -120
+KPX P Atilde -120
+KPX P a -40
+KPX P aacute -40
+KPX P abreve -40
+KPX P acircumflex -40
+KPX P adieresis -40
+KPX P agrave -40
+KPX P amacron -40
+KPX P aogonek -40
+KPX P aring -40
+KPX P atilde -40
+KPX P comma -180
+KPX P e -50
+KPX P eacute -50
+KPX P ecaron -50
+KPX P ecircumflex -50
+KPX P edieresis -50
+KPX P edotaccent -50
+KPX P egrave -50
+KPX P emacron -50
+KPX P eogonek -50
+KPX P o -50
+KPX P oacute -50
+KPX P ocircumflex -50
+KPX P odieresis -50
+KPX P ograve -50
+KPX P ohungarumlaut -50
+KPX P omacron -50
+KPX P oslash -50
+KPX P otilde -50
+KPX P period -180
+KPX Q U -10
+KPX Q Uacute -10
+KPX Q Ucircumflex -10
+KPX Q Udieresis -10
+KPX Q Ugrave -10
+KPX Q Uhungarumlaut -10
+KPX Q Umacron -10
+KPX Q Uogonek -10
+KPX Q Uring -10
+KPX R O -20
+KPX R Oacute -20
+KPX R Ocircumflex -20
+KPX R Odieresis -20
+KPX R Ograve -20
+KPX R Ohungarumlaut -20
+KPX R Omacron -20
+KPX R Oslash -20
+KPX R Otilde -20
+KPX R T -30
+KPX R Tcaron -30
+KPX R Tcommaaccent -30
+KPX R U -40
+KPX R Uacute -40
+KPX R Ucircumflex -40
+KPX R Udieresis -40
+KPX R Ugrave -40
+KPX R Uhungarumlaut -40
+KPX R Umacron -40
+KPX R Uogonek -40
+KPX R Uring -40
+KPX R V -50
+KPX R W -30
+KPX R Y -50
+KPX R Yacute -50
+KPX R Ydieresis -50
+KPX Racute O -20
+KPX Racute Oacute -20
+KPX Racute Ocircumflex -20
+KPX Racute Odieresis -20
+KPX Racute Ograve -20
+KPX Racute Ohungarumlaut -20
+KPX Racute Omacron -20
+KPX Racute Oslash -20
+KPX Racute Otilde -20
+KPX Racute T -30
+KPX Racute Tcaron -30
+KPX Racute Tcommaaccent -30
+KPX Racute U -40
+KPX Racute Uacute -40
+KPX Racute Ucircumflex -40
+KPX Racute Udieresis -40
+KPX Racute Ugrave -40
+KPX Racute Uhungarumlaut -40
+KPX Racute Umacron -40
+KPX Racute Uogonek -40
+KPX Racute Uring -40
+KPX Racute V -50
+KPX Racute W -30
+KPX Racute Y -50
+KPX Racute Yacute -50
+KPX Racute Ydieresis -50
+KPX Rcaron O -20
+KPX Rcaron Oacute -20
+KPX Rcaron Ocircumflex -20
+KPX Rcaron Odieresis -20
+KPX Rcaron Ograve -20
+KPX Rcaron Ohungarumlaut -20
+KPX Rcaron Omacron -20
+KPX Rcaron Oslash -20
+KPX Rcaron Otilde -20
+KPX Rcaron T -30
+KPX Rcaron Tcaron -30
+KPX Rcaron Tcommaaccent -30
+KPX Rcaron U -40
+KPX Rcaron Uacute -40
+KPX Rcaron Ucircumflex -40
+KPX Rcaron Udieresis -40
+KPX Rcaron Ugrave -40
+KPX Rcaron Uhungarumlaut -40
+KPX Rcaron Umacron -40
+KPX Rcaron Uogonek -40
+KPX Rcaron Uring -40
+KPX Rcaron V -50
+KPX Rcaron W -30
+KPX Rcaron Y -50
+KPX Rcaron Yacute -50
+KPX Rcaron Ydieresis -50
+KPX Rcommaaccent O -20
+KPX Rcommaaccent Oacute -20
+KPX Rcommaaccent Ocircumflex -20
+KPX Rcommaaccent Odieresis -20
+KPX Rcommaaccent Ograve -20
+KPX Rcommaaccent Ohungarumlaut -20
+KPX Rcommaaccent Omacron -20
+KPX Rcommaaccent Oslash -20
+KPX Rcommaaccent Otilde -20
+KPX Rcommaaccent T -30
+KPX Rcommaaccent Tcaron -30
+KPX Rcommaaccent Tcommaaccent -30
+KPX Rcommaaccent U -40
+KPX Rcommaaccent Uacute -40
+KPX Rcommaaccent Ucircumflex -40
+KPX Rcommaaccent Udieresis -40
+KPX Rcommaaccent Ugrave -40
+KPX Rcommaaccent Uhungarumlaut -40
+KPX Rcommaaccent Umacron -40
+KPX Rcommaaccent Uogonek -40
+KPX Rcommaaccent Uring -40
+KPX Rcommaaccent V -50
+KPX Rcommaaccent W -30
+KPX Rcommaaccent Y -50
+KPX Rcommaaccent Yacute -50
+KPX Rcommaaccent Ydieresis -50
+KPX S comma -20
+KPX S period -20
+KPX Sacute comma -20
+KPX Sacute period -20
+KPX Scaron comma -20
+KPX Scaron period -20
+KPX Scedilla comma -20
+KPX Scedilla period -20
+KPX Scommaaccent comma -20
+KPX Scommaaccent period -20
+KPX T A -120
+KPX T Aacute -120
+KPX T Abreve -120
+KPX T Acircumflex -120
+KPX T Adieresis -120
+KPX T Agrave -120
+KPX T Amacron -120
+KPX T Aogonek -120
+KPX T Aring -120
+KPX T Atilde -120
+KPX T O -40
+KPX T Oacute -40
+KPX T Ocircumflex -40
+KPX T Odieresis -40
+KPX T Ograve -40
+KPX T Ohungarumlaut -40
+KPX T Omacron -40
+KPX T Oslash -40
+KPX T Otilde -40
+KPX T a -120
+KPX T aacute -120
+KPX T abreve -60
+KPX T acircumflex -120
+KPX T adieresis -120
+KPX T agrave -120
+KPX T amacron -60
+KPX T aogonek -120
+KPX T aring -120
+KPX T atilde -60
+KPX T colon -20
+KPX T comma -120
+KPX T e -120
+KPX T eacute -120
+KPX T ecaron -120
+KPX T ecircumflex -120
+KPX T edieresis -120
+KPX T edotaccent -120
+KPX T egrave -60
+KPX T emacron -60
+KPX T eogonek -120
+KPX T hyphen -140
+KPX T o -120
+KPX T oacute -120
+KPX T ocircumflex -120
+KPX T odieresis -120
+KPX T ograve -120
+KPX T ohungarumlaut -120
+KPX T omacron -60
+KPX T oslash -120
+KPX T otilde -60
+KPX T period -120
+KPX T r -120
+KPX T racute -120
+KPX T rcaron -120
+KPX T rcommaaccent -120
+KPX T semicolon -20
+KPX T u -120
+KPX T uacute -120
+KPX T ucircumflex -120
+KPX T udieresis -120
+KPX T ugrave -120
+KPX T uhungarumlaut -120
+KPX T umacron -60
+KPX T uogonek -120
+KPX T uring -120
+KPX T w -120
+KPX T y -120
+KPX T yacute -120
+KPX T ydieresis -60
+KPX Tcaron A -120
+KPX Tcaron Aacute -120
+KPX Tcaron Abreve -120
+KPX Tcaron Acircumflex -120
+KPX Tcaron Adieresis -120
+KPX Tcaron Agrave -120
+KPX Tcaron Amacron -120
+KPX Tcaron Aogonek -120
+KPX Tcaron Aring -120
+KPX Tcaron Atilde -120
+KPX Tcaron O -40
+KPX Tcaron Oacute -40
+KPX Tcaron Ocircumflex -40
+KPX Tcaron Odieresis -40
+KPX Tcaron Ograve -40
+KPX Tcaron Ohungarumlaut -40
+KPX Tcaron Omacron -40
+KPX Tcaron Oslash -40
+KPX Tcaron Otilde -40
+KPX Tcaron a -120
+KPX Tcaron aacute -120
+KPX Tcaron abreve -60
+KPX Tcaron acircumflex -120
+KPX Tcaron adieresis -120
+KPX Tcaron agrave -120
+KPX Tcaron amacron -60
+KPX Tcaron aogonek -120
+KPX Tcaron aring -120
+KPX Tcaron atilde -60
+KPX Tcaron colon -20
+KPX Tcaron comma -120
+KPX Tcaron e -120
+KPX Tcaron eacute -120
+KPX Tcaron ecaron -120
+KPX Tcaron ecircumflex -120
+KPX Tcaron edieresis -120
+KPX Tcaron edotaccent -120
+KPX Tcaron egrave -60
+KPX Tcaron emacron -60
+KPX Tcaron eogonek -120
+KPX Tcaron hyphen -140
+KPX Tcaron o -120
+KPX Tcaron oacute -120
+KPX Tcaron ocircumflex -120
+KPX Tcaron odieresis -120
+KPX Tcaron ograve -120
+KPX Tcaron ohungarumlaut -120
+KPX Tcaron omacron -60
+KPX Tcaron oslash -120
+KPX Tcaron otilde -60
+KPX Tcaron period -120
+KPX Tcaron r -120
+KPX Tcaron racute -120
+KPX Tcaron rcaron -120
+KPX Tcaron rcommaaccent -120
+KPX Tcaron semicolon -20
+KPX Tcaron u -120
+KPX Tcaron uacute -120
+KPX Tcaron ucircumflex -120
+KPX Tcaron udieresis -120
+KPX Tcaron ugrave -120
+KPX Tcaron uhungarumlaut -120
+KPX Tcaron umacron -60
+KPX Tcaron uogonek -120
+KPX Tcaron uring -120
+KPX Tcaron w -120
+KPX Tcaron y -120
+KPX Tcaron yacute -120
+KPX Tcaron ydieresis -60
+KPX Tcommaaccent A -120
+KPX Tcommaaccent Aacute -120
+KPX Tcommaaccent Abreve -120
+KPX Tcommaaccent Acircumflex -120
+KPX Tcommaaccent Adieresis -120
+KPX Tcommaaccent Agrave -120
+KPX Tcommaaccent Amacron -120
+KPX Tcommaaccent Aogonek -120
+KPX Tcommaaccent Aring -120
+KPX Tcommaaccent Atilde -120
+KPX Tcommaaccent O -40
+KPX Tcommaaccent Oacute -40
+KPX Tcommaaccent Ocircumflex -40
+KPX Tcommaaccent Odieresis -40
+KPX Tcommaaccent Ograve -40
+KPX Tcommaaccent Ohungarumlaut -40
+KPX Tcommaaccent Omacron -40
+KPX Tcommaaccent Oslash -40
+KPX Tcommaaccent Otilde -40
+KPX Tcommaaccent a -120
+KPX Tcommaaccent aacute -120
+KPX Tcommaaccent abreve -60
+KPX Tcommaaccent acircumflex -120
+KPX Tcommaaccent adieresis -120
+KPX Tcommaaccent agrave -120
+KPX Tcommaaccent amacron -60
+KPX Tcommaaccent aogonek -120
+KPX Tcommaaccent aring -120
+KPX Tcommaaccent atilde -60
+KPX Tcommaaccent colon -20
+KPX Tcommaaccent comma -120
+KPX Tcommaaccent e -120
+KPX Tcommaaccent eacute -120
+KPX Tcommaaccent ecaron -120
+KPX Tcommaaccent ecircumflex -120
+KPX Tcommaaccent edieresis -120
+KPX Tcommaaccent edotaccent -120
+KPX Tcommaaccent egrave -60
+KPX Tcommaaccent emacron -60
+KPX Tcommaaccent eogonek -120
+KPX Tcommaaccent hyphen -140
+KPX Tcommaaccent o -120
+KPX Tcommaaccent oacute -120
+KPX Tcommaaccent ocircumflex -120
+KPX Tcommaaccent odieresis -120
+KPX Tcommaaccent ograve -120
+KPX Tcommaaccent ohungarumlaut -120
+KPX Tcommaaccent omacron -60
+KPX Tcommaaccent oslash -120
+KPX Tcommaaccent otilde -60
+KPX Tcommaaccent period -120
+KPX Tcommaaccent r -120
+KPX Tcommaaccent racute -120
+KPX Tcommaaccent rcaron -120
+KPX Tcommaaccent rcommaaccent -120
+KPX Tcommaaccent semicolon -20
+KPX Tcommaaccent u -120
+KPX Tcommaaccent uacute -120
+KPX Tcommaaccent ucircumflex -120
+KPX Tcommaaccent udieresis -120
+KPX Tcommaaccent ugrave -120
+KPX Tcommaaccent uhungarumlaut -120
+KPX Tcommaaccent umacron -60
+KPX Tcommaaccent uogonek -120
+KPX Tcommaaccent uring -120
+KPX Tcommaaccent w -120
+KPX Tcommaaccent y -120
+KPX Tcommaaccent yacute -120
+KPX Tcommaaccent ydieresis -60
+KPX U A -40
+KPX U Aacute -40
+KPX U Abreve -40
+KPX U Acircumflex -40
+KPX U Adieresis -40
+KPX U Agrave -40
+KPX U Amacron -40
+KPX U Aogonek -40
+KPX U Aring -40
+KPX U Atilde -40
+KPX U comma -40
+KPX U period -40
+KPX Uacute A -40
+KPX Uacute Aacute -40
+KPX Uacute Abreve -40
+KPX Uacute Acircumflex -40
+KPX Uacute Adieresis -40
+KPX Uacute Agrave -40
+KPX Uacute Amacron -40
+KPX Uacute Aogonek -40
+KPX Uacute Aring -40
+KPX Uacute Atilde -40
+KPX Uacute comma -40
+KPX Uacute period -40
+KPX Ucircumflex A -40
+KPX Ucircumflex Aacute -40
+KPX Ucircumflex Abreve -40
+KPX Ucircumflex Acircumflex -40
+KPX Ucircumflex Adieresis -40
+KPX Ucircumflex Agrave -40
+KPX Ucircumflex Amacron -40
+KPX Ucircumflex Aogonek -40
+KPX Ucircumflex Aring -40
+KPX Ucircumflex Atilde -40
+KPX Ucircumflex comma -40
+KPX Ucircumflex period -40
+KPX Udieresis A -40
+KPX Udieresis Aacute -40
+KPX Udieresis Abreve -40
+KPX Udieresis Acircumflex -40
+KPX Udieresis Adieresis -40
+KPX Udieresis Agrave -40
+KPX Udieresis Amacron -40
+KPX Udieresis Aogonek -40
+KPX Udieresis Aring -40
+KPX Udieresis Atilde -40
+KPX Udieresis comma -40
+KPX Udieresis period -40
+KPX Ugrave A -40
+KPX Ugrave Aacute -40
+KPX Ugrave Abreve -40
+KPX Ugrave Acircumflex -40
+KPX Ugrave Adieresis -40
+KPX Ugrave Agrave -40
+KPX Ugrave Amacron -40
+KPX Ugrave Aogonek -40
+KPX Ugrave Aring -40
+KPX Ugrave Atilde -40
+KPX Ugrave comma -40
+KPX Ugrave period -40
+KPX Uhungarumlaut A -40
+KPX Uhungarumlaut Aacute -40
+KPX Uhungarumlaut Abreve -40
+KPX Uhungarumlaut Acircumflex -40
+KPX Uhungarumlaut Adieresis -40
+KPX Uhungarumlaut Agrave -40
+KPX Uhungarumlaut Amacron -40
+KPX Uhungarumlaut Aogonek -40
+KPX Uhungarumlaut Aring -40
+KPX Uhungarumlaut Atilde -40
+KPX Uhungarumlaut comma -40
+KPX Uhungarumlaut period -40
+KPX Umacron A -40
+KPX Umacron Aacute -40
+KPX Umacron Abreve -40
+KPX Umacron Acircumflex -40
+KPX Umacron Adieresis -40
+KPX Umacron Agrave -40
+KPX Umacron Amacron -40
+KPX Umacron Aogonek -40
+KPX Umacron Aring -40
+KPX Umacron Atilde -40
+KPX Umacron comma -40
+KPX Umacron period -40
+KPX Uogonek A -40
+KPX Uogonek Aacute -40
+KPX Uogonek Abreve -40
+KPX Uogonek Acircumflex -40
+KPX Uogonek Adieresis -40
+KPX Uogonek Agrave -40
+KPX Uogonek Amacron -40
+KPX Uogonek Aogonek -40
+KPX Uogonek Aring -40
+KPX Uogonek Atilde -40
+KPX Uogonek comma -40
+KPX Uogonek period -40
+KPX Uring A -40
+KPX Uring Aacute -40
+KPX Uring Abreve -40
+KPX Uring Acircumflex -40
+KPX Uring Adieresis -40
+KPX Uring Agrave -40
+KPX Uring Amacron -40
+KPX Uring Aogonek -40
+KPX Uring Aring -40
+KPX Uring Atilde -40
+KPX Uring comma -40
+KPX Uring period -40
+KPX V A -80
+KPX V Aacute -80
+KPX V Abreve -80
+KPX V Acircumflex -80
+KPX V Adieresis -80
+KPX V Agrave -80
+KPX V Amacron -80
+KPX V Aogonek -80
+KPX V Aring -80
+KPX V Atilde -80
+KPX V G -40
+KPX V Gbreve -40
+KPX V Gcommaaccent -40
+KPX V O -40
+KPX V Oacute -40
+KPX V Ocircumflex -40
+KPX V Odieresis -40
+KPX V Ograve -40
+KPX V Ohungarumlaut -40
+KPX V Omacron -40
+KPX V Oslash -40
+KPX V Otilde -40
+KPX V a -70
+KPX V aacute -70
+KPX V abreve -70
+KPX V acircumflex -70
+KPX V adieresis -70
+KPX V agrave -70
+KPX V amacron -70
+KPX V aogonek -70
+KPX V aring -70
+KPX V atilde -70
+KPX V colon -40
+KPX V comma -125
+KPX V e -80
+KPX V eacute -80
+KPX V ecaron -80
+KPX V ecircumflex -80
+KPX V edieresis -80
+KPX V edotaccent -80
+KPX V egrave -80
+KPX V emacron -80
+KPX V eogonek -80
+KPX V hyphen -80
+KPX V o -80
+KPX V oacute -80
+KPX V ocircumflex -80
+KPX V odieresis -80
+KPX V ograve -80
+KPX V ohungarumlaut -80
+KPX V omacron -80
+KPX V oslash -80
+KPX V otilde -80
+KPX V period -125
+KPX V semicolon -40
+KPX V u -70
+KPX V uacute -70
+KPX V ucircumflex -70
+KPX V udieresis -70
+KPX V ugrave -70
+KPX V uhungarumlaut -70
+KPX V umacron -70
+KPX V uogonek -70
+KPX V uring -70
+KPX W A -50
+KPX W Aacute -50
+KPX W Abreve -50
+KPX W Acircumflex -50
+KPX W Adieresis -50
+KPX W Agrave -50
+KPX W Amacron -50
+KPX W Aogonek -50
+KPX W Aring -50
+KPX W Atilde -50
+KPX W O -20
+KPX W Oacute -20
+KPX W Ocircumflex -20
+KPX W Odieresis -20
+KPX W Ograve -20
+KPX W Ohungarumlaut -20
+KPX W Omacron -20
+KPX W Oslash -20
+KPX W Otilde -20
+KPX W a -40
+KPX W aacute -40
+KPX W abreve -40
+KPX W acircumflex -40
+KPX W adieresis -40
+KPX W agrave -40
+KPX W amacron -40
+KPX W aogonek -40
+KPX W aring -40
+KPX W atilde -40
+KPX W comma -80
+KPX W e -30
+KPX W eacute -30
+KPX W ecaron -30
+KPX W ecircumflex -30
+KPX W edieresis -30
+KPX W edotaccent -30
+KPX W egrave -30
+KPX W emacron -30
+KPX W eogonek -30
+KPX W hyphen -40
+KPX W o -30
+KPX W oacute -30
+KPX W ocircumflex -30
+KPX W odieresis -30
+KPX W ograve -30
+KPX W ohungarumlaut -30
+KPX W omacron -30
+KPX W oslash -30
+KPX W otilde -30
+KPX W period -80
+KPX W u -30
+KPX W uacute -30
+KPX W ucircumflex -30
+KPX W udieresis -30
+KPX W ugrave -30
+KPX W uhungarumlaut -30
+KPX W umacron -30
+KPX W uogonek -30
+KPX W uring -30
+KPX W y -20
+KPX W yacute -20
+KPX W ydieresis -20
+KPX Y A -110
+KPX Y Aacute -110
+KPX Y Abreve -110
+KPX Y Acircumflex -110
+KPX Y Adieresis -110
+KPX Y Agrave -110
+KPX Y Amacron -110
+KPX Y Aogonek -110
+KPX Y Aring -110
+KPX Y Atilde -110
+KPX Y O -85
+KPX Y Oacute -85
+KPX Y Ocircumflex -85
+KPX Y Odieresis -85
+KPX Y Ograve -85
+KPX Y Ohungarumlaut -85
+KPX Y Omacron -85
+KPX Y Oslash -85
+KPX Y Otilde -85
+KPX Y a -140
+KPX Y aacute -140
+KPX Y abreve -70
+KPX Y acircumflex -140
+KPX Y adieresis -140
+KPX Y agrave -140
+KPX Y amacron -70
+KPX Y aogonek -140
+KPX Y aring -140
+KPX Y atilde -140
+KPX Y colon -60
+KPX Y comma -140
+KPX Y e -140
+KPX Y eacute -140
+KPX Y ecaron -140
+KPX Y ecircumflex -140
+KPX Y edieresis -140
+KPX Y edotaccent -140
+KPX Y egrave -140
+KPX Y emacron -70
+KPX Y eogonek -140
+KPX Y hyphen -140
+KPX Y i -20
+KPX Y iacute -20
+KPX Y iogonek -20
+KPX Y o -140
+KPX Y oacute -140
+KPX Y ocircumflex -140
+KPX Y odieresis -140
+KPX Y ograve -140
+KPX Y ohungarumlaut -140
+KPX Y omacron -140
+KPX Y oslash -140
+KPX Y otilde -140
+KPX Y period -140
+KPX Y semicolon -60
+KPX Y u -110
+KPX Y uacute -110
+KPX Y ucircumflex -110
+KPX Y udieresis -110
+KPX Y ugrave -110
+KPX Y uhungarumlaut -110
+KPX Y umacron -110
+KPX Y uogonek -110
+KPX Y uring -110
+KPX Yacute A -110
+KPX Yacute Aacute -110
+KPX Yacute Abreve -110
+KPX Yacute Acircumflex -110
+KPX Yacute Adieresis -110
+KPX Yacute Agrave -110
+KPX Yacute Amacron -110
+KPX Yacute Aogonek -110
+KPX Yacute Aring -110
+KPX Yacute Atilde -110
+KPX Yacute O -85
+KPX Yacute Oacute -85
+KPX Yacute Ocircumflex -85
+KPX Yacute Odieresis -85
+KPX Yacute Ograve -85
+KPX Yacute Ohungarumlaut -85
+KPX Yacute Omacron -85
+KPX Yacute Oslash -85
+KPX Yacute Otilde -85
+KPX Yacute a -140
+KPX Yacute aacute -140
+KPX Yacute abreve -70
+KPX Yacute acircumflex -140
+KPX Yacute adieresis -140
+KPX Yacute agrave -140
+KPX Yacute amacron -70
+KPX Yacute aogonek -140
+KPX Yacute aring -140
+KPX Yacute atilde -70
+KPX Yacute colon -60
+KPX Yacute comma -140
+KPX Yacute e -140
+KPX Yacute eacute -140
+KPX Yacute ecaron -140
+KPX Yacute ecircumflex -140
+KPX Yacute edieresis -140
+KPX Yacute edotaccent -140
+KPX Yacute egrave -140
+KPX Yacute emacron -70
+KPX Yacute eogonek -140
+KPX Yacute hyphen -140
+KPX Yacute i -20
+KPX Yacute iacute -20
+KPX Yacute iogonek -20
+KPX Yacute o -140
+KPX Yacute oacute -140
+KPX Yacute ocircumflex -140
+KPX Yacute odieresis -140
+KPX Yacute ograve -140
+KPX Yacute ohungarumlaut -140
+KPX Yacute omacron -70
+KPX Yacute oslash -140
+KPX Yacute otilde -140
+KPX Yacute period -140
+KPX Yacute semicolon -60
+KPX Yacute u -110
+KPX Yacute uacute -110
+KPX Yacute ucircumflex -110
+KPX Yacute udieresis -110
+KPX Yacute ugrave -110
+KPX Yacute uhungarumlaut -110
+KPX Yacute umacron -110
+KPX Yacute uogonek -110
+KPX Yacute uring -110
+KPX Ydieresis A -110
+KPX Ydieresis Aacute -110
+KPX Ydieresis Abreve -110
+KPX Ydieresis Acircumflex -110
+KPX Ydieresis Adieresis -110
+KPX Ydieresis Agrave -110
+KPX Ydieresis Amacron -110
+KPX Ydieresis Aogonek -110
+KPX Ydieresis Aring -110
+KPX Ydieresis Atilde -110
+KPX Ydieresis O -85
+KPX Ydieresis Oacute -85
+KPX Ydieresis Ocircumflex -85
+KPX Ydieresis Odieresis -85
+KPX Ydieresis Ograve -85
+KPX Ydieresis Ohungarumlaut -85
+KPX Ydieresis Omacron -85
+KPX Ydieresis Oslash -85
+KPX Ydieresis Otilde -85
+KPX Ydieresis a -140
+KPX Ydieresis aacute -140
+KPX Ydieresis abreve -70
+KPX Ydieresis acircumflex -140
+KPX Ydieresis adieresis -140
+KPX Ydieresis agrave -140
+KPX Ydieresis amacron -70
+KPX Ydieresis aogonek -140
+KPX Ydieresis aring -140
+KPX Ydieresis atilde -70
+KPX Ydieresis colon -60
+KPX Ydieresis comma -140
+KPX Ydieresis e -140
+KPX Ydieresis eacute -140
+KPX Ydieresis ecaron -140
+KPX Ydieresis ecircumflex -140
+KPX Ydieresis edieresis -140
+KPX Ydieresis edotaccent -140
+KPX Ydieresis egrave -140
+KPX Ydieresis emacron -70
+KPX Ydieresis eogonek -140
+KPX Ydieresis hyphen -140
+KPX Ydieresis i -20
+KPX Ydieresis iacute -20
+KPX Ydieresis iogonek -20
+KPX Ydieresis o -140
+KPX Ydieresis oacute -140
+KPX Ydieresis ocircumflex -140
+KPX Ydieresis odieresis -140
+KPX Ydieresis ograve -140
+KPX Ydieresis ohungarumlaut -140
+KPX Ydieresis omacron -140
+KPX Ydieresis oslash -140
+KPX Ydieresis otilde -140
+KPX Ydieresis period -140
+KPX Ydieresis semicolon -60
+KPX Ydieresis u -110
+KPX Ydieresis uacute -110
+KPX Ydieresis ucircumflex -110
+KPX Ydieresis udieresis -110
+KPX Ydieresis ugrave -110
+KPX Ydieresis uhungarumlaut -110
+KPX Ydieresis umacron -110
+KPX Ydieresis uogonek -110
+KPX Ydieresis uring -110
+KPX a v -20
+KPX a w -20
+KPX a y -30
+KPX a yacute -30
+KPX a ydieresis -30
+KPX aacute v -20
+KPX aacute w -20
+KPX aacute y -30
+KPX aacute yacute -30
+KPX aacute ydieresis -30
+KPX abreve v -20
+KPX abreve w -20
+KPX abreve y -30
+KPX abreve yacute -30
+KPX abreve ydieresis -30
+KPX acircumflex v -20
+KPX acircumflex w -20
+KPX acircumflex y -30
+KPX acircumflex yacute -30
+KPX acircumflex ydieresis -30
+KPX adieresis v -20
+KPX adieresis w -20
+KPX adieresis y -30
+KPX adieresis yacute -30
+KPX adieresis ydieresis -30
+KPX agrave v -20
+KPX agrave w -20
+KPX agrave y -30
+KPX agrave yacute -30
+KPX agrave ydieresis -30
+KPX amacron v -20
+KPX amacron w -20
+KPX amacron y -30
+KPX amacron yacute -30
+KPX amacron ydieresis -30
+KPX aogonek v -20
+KPX aogonek w -20
+KPX aogonek y -30
+KPX aogonek yacute -30
+KPX aogonek ydieresis -30
+KPX aring v -20
+KPX aring w -20
+KPX aring y -30
+KPX aring yacute -30
+KPX aring ydieresis -30
+KPX atilde v -20
+KPX atilde w -20
+KPX atilde y -30
+KPX atilde yacute -30
+KPX atilde ydieresis -30
+KPX b b -10
+KPX b comma -40
+KPX b l -20
+KPX b lacute -20
+KPX b lcommaaccent -20
+KPX b lslash -20
+KPX b period -40
+KPX b u -20
+KPX b uacute -20
+KPX b ucircumflex -20
+KPX b udieresis -20
+KPX b ugrave -20
+KPX b uhungarumlaut -20
+KPX b umacron -20
+KPX b uogonek -20
+KPX b uring -20
+KPX b v -20
+KPX b y -20
+KPX b yacute -20
+KPX b ydieresis -20
+KPX c comma -15
+KPX c k -20
+KPX c kcommaaccent -20
+KPX cacute comma -15
+KPX cacute k -20
+KPX cacute kcommaaccent -20
+KPX ccaron comma -15
+KPX ccaron k -20
+KPX ccaron kcommaaccent -20
+KPX ccedilla comma -15
+KPX ccedilla k -20
+KPX ccedilla kcommaaccent -20
+KPX colon space -50
+KPX comma quotedblright -100
+KPX comma quoteright -100
+KPX e comma -15
+KPX e period -15
+KPX e v -30
+KPX e w -20
+KPX e x -30
+KPX e y -20
+KPX e yacute -20
+KPX e ydieresis -20
+KPX eacute comma -15
+KPX eacute period -15
+KPX eacute v -30
+KPX eacute w -20
+KPX eacute x -30
+KPX eacute y -20
+KPX eacute yacute -20
+KPX eacute ydieresis -20
+KPX ecaron comma -15
+KPX ecaron period -15
+KPX ecaron v -30
+KPX ecaron w -20
+KPX ecaron x -30
+KPX ecaron y -20
+KPX ecaron yacute -20
+KPX ecaron ydieresis -20
+KPX ecircumflex comma -15
+KPX ecircumflex period -15
+KPX ecircumflex v -30
+KPX ecircumflex w -20
+KPX ecircumflex x -30
+KPX ecircumflex y -20
+KPX ecircumflex yacute -20
+KPX ecircumflex ydieresis -20
+KPX edieresis comma -15
+KPX edieresis period -15
+KPX edieresis v -30
+KPX edieresis w -20
+KPX edieresis x -30
+KPX edieresis y -20
+KPX edieresis yacute -20
+KPX edieresis ydieresis -20
+KPX edotaccent comma -15
+KPX edotaccent period -15
+KPX edotaccent v -30
+KPX edotaccent w -20
+KPX edotaccent x -30
+KPX edotaccent y -20
+KPX edotaccent yacute -20
+KPX edotaccent ydieresis -20
+KPX egrave comma -15
+KPX egrave period -15
+KPX egrave v -30
+KPX egrave w -20
+KPX egrave x -30
+KPX egrave y -20
+KPX egrave yacute -20
+KPX egrave ydieresis -20
+KPX emacron comma -15
+KPX emacron period -15
+KPX emacron v -30
+KPX emacron w -20
+KPX emacron x -30
+KPX emacron y -20
+KPX emacron yacute -20
+KPX emacron ydieresis -20
+KPX eogonek comma -15
+KPX eogonek period -15
+KPX eogonek v -30
+KPX eogonek w -20
+KPX eogonek x -30
+KPX eogonek y -20
+KPX eogonek yacute -20
+KPX eogonek ydieresis -20
+KPX f a -30
+KPX f aacute -30
+KPX f abreve -30
+KPX f acircumflex -30
+KPX f adieresis -30
+KPX f agrave -30
+KPX f amacron -30
+KPX f aogonek -30
+KPX f aring -30
+KPX f atilde -30
+KPX f comma -30
+KPX f dotlessi -28
+KPX f e -30
+KPX f eacute -30
+KPX f ecaron -30
+KPX f ecircumflex -30
+KPX f edieresis -30
+KPX f edotaccent -30
+KPX f egrave -30
+KPX f emacron -30
+KPX f eogonek -30
+KPX f o -30
+KPX f oacute -30
+KPX f ocircumflex -30
+KPX f odieresis -30
+KPX f ograve -30
+KPX f ohungarumlaut -30
+KPX f omacron -30
+KPX f oslash -30
+KPX f otilde -30
+KPX f period -30
+KPX f quotedblright 60
+KPX f quoteright 50
+KPX g r -10
+KPX g racute -10
+KPX g rcaron -10
+KPX g rcommaaccent -10
+KPX gbreve r -10
+KPX gbreve racute -10
+KPX gbreve rcaron -10
+KPX gbreve rcommaaccent -10
+KPX gcommaaccent r -10
+KPX gcommaaccent racute -10
+KPX gcommaaccent rcaron -10
+KPX gcommaaccent rcommaaccent -10
+KPX h y -30
+KPX h yacute -30
+KPX h ydieresis -30
+KPX k e -20
+KPX k eacute -20
+KPX k ecaron -20
+KPX k ecircumflex -20
+KPX k edieresis -20
+KPX k edotaccent -20
+KPX k egrave -20
+KPX k emacron -20
+KPX k eogonek -20
+KPX k o -20
+KPX k oacute -20
+KPX k ocircumflex -20
+KPX k odieresis -20
+KPX k ograve -20
+KPX k ohungarumlaut -20
+KPX k omacron -20
+KPX k oslash -20
+KPX k otilde -20
+KPX kcommaaccent e -20
+KPX kcommaaccent eacute -20
+KPX kcommaaccent ecaron -20
+KPX kcommaaccent ecircumflex -20
+KPX kcommaaccent edieresis -20
+KPX kcommaaccent edotaccent -20
+KPX kcommaaccent egrave -20
+KPX kcommaaccent emacron -20
+KPX kcommaaccent eogonek -20
+KPX kcommaaccent o -20
+KPX kcommaaccent oacute -20
+KPX kcommaaccent ocircumflex -20
+KPX kcommaaccent odieresis -20
+KPX kcommaaccent ograve -20
+KPX kcommaaccent ohungarumlaut -20
+KPX kcommaaccent omacron -20
+KPX kcommaaccent oslash -20
+KPX kcommaaccent otilde -20
+KPX m u -10
+KPX m uacute -10
+KPX m ucircumflex -10
+KPX m udieresis -10
+KPX m ugrave -10
+KPX m uhungarumlaut -10
+KPX m umacron -10
+KPX m uogonek -10
+KPX m uring -10
+KPX m y -15
+KPX m yacute -15
+KPX m ydieresis -15
+KPX n u -10
+KPX n uacute -10
+KPX n ucircumflex -10
+KPX n udieresis -10
+KPX n ugrave -10
+KPX n uhungarumlaut -10
+KPX n umacron -10
+KPX n uogonek -10
+KPX n uring -10
+KPX n v -20
+KPX n y -15
+KPX n yacute -15
+KPX n ydieresis -15
+KPX nacute u -10
+KPX nacute uacute -10
+KPX nacute ucircumflex -10
+KPX nacute udieresis -10
+KPX nacute ugrave -10
+KPX nacute uhungarumlaut -10
+KPX nacute umacron -10
+KPX nacute uogonek -10
+KPX nacute uring -10
+KPX nacute v -20
+KPX nacute y -15
+KPX nacute yacute -15
+KPX nacute ydieresis -15
+KPX ncaron u -10
+KPX ncaron uacute -10
+KPX ncaron ucircumflex -10
+KPX ncaron udieresis -10
+KPX ncaron ugrave -10
+KPX ncaron uhungarumlaut -10
+KPX ncaron umacron -10
+KPX ncaron uogonek -10
+KPX ncaron uring -10
+KPX ncaron v -20
+KPX ncaron y -15
+KPX ncaron yacute -15
+KPX ncaron ydieresis -15
+KPX ncommaaccent u -10
+KPX ncommaaccent uacute -10
+KPX ncommaaccent ucircumflex -10
+KPX ncommaaccent udieresis -10
+KPX ncommaaccent ugrave -10
+KPX ncommaaccent uhungarumlaut -10
+KPX ncommaaccent umacron -10
+KPX ncommaaccent uogonek -10
+KPX ncommaaccent uring -10
+KPX ncommaaccent v -20
+KPX ncommaaccent y -15
+KPX ncommaaccent yacute -15
+KPX ncommaaccent ydieresis -15
+KPX ntilde u -10
+KPX ntilde uacute -10
+KPX ntilde ucircumflex -10
+KPX ntilde udieresis -10
+KPX ntilde ugrave -10
+KPX ntilde uhungarumlaut -10
+KPX ntilde umacron -10
+KPX ntilde uogonek -10
+KPX ntilde uring -10
+KPX ntilde v -20
+KPX ntilde y -15
+KPX ntilde yacute -15
+KPX ntilde ydieresis -15
+KPX o comma -40
+KPX o period -40
+KPX o v -15
+KPX o w -15
+KPX o x -30
+KPX o y -30
+KPX o yacute -30
+KPX o ydieresis -30
+KPX oacute comma -40
+KPX oacute period -40
+KPX oacute v -15
+KPX oacute w -15
+KPX oacute x -30
+KPX oacute y -30
+KPX oacute yacute -30
+KPX oacute ydieresis -30
+KPX ocircumflex comma -40
+KPX ocircumflex period -40
+KPX ocircumflex v -15
+KPX ocircumflex w -15
+KPX ocircumflex x -30
+KPX ocircumflex y -30
+KPX ocircumflex yacute -30
+KPX ocircumflex ydieresis -30
+KPX odieresis comma -40
+KPX odieresis period -40
+KPX odieresis v -15
+KPX odieresis w -15
+KPX odieresis x -30
+KPX odieresis y -30
+KPX odieresis yacute -30
+KPX odieresis ydieresis -30
+KPX ograve comma -40
+KPX ograve period -40
+KPX ograve v -15
+KPX ograve w -15
+KPX ograve x -30
+KPX ograve y -30
+KPX ograve yacute -30
+KPX ograve ydieresis -30
+KPX ohungarumlaut comma -40
+KPX ohungarumlaut period -40
+KPX ohungarumlaut v -15
+KPX ohungarumlaut w -15
+KPX ohungarumlaut x -30
+KPX ohungarumlaut y -30
+KPX ohungarumlaut yacute -30
+KPX ohungarumlaut ydieresis -30
+KPX omacron comma -40
+KPX omacron period -40
+KPX omacron v -15
+KPX omacron w -15
+KPX omacron x -30
+KPX omacron y -30
+KPX omacron yacute -30
+KPX omacron ydieresis -30
+KPX oslash a -55
+KPX oslash aacute -55
+KPX oslash abreve -55
+KPX oslash acircumflex -55
+KPX oslash adieresis -55
+KPX oslash agrave -55
+KPX oslash amacron -55
+KPX oslash aogonek -55
+KPX oslash aring -55
+KPX oslash atilde -55
+KPX oslash b -55
+KPX oslash c -55
+KPX oslash cacute -55
+KPX oslash ccaron -55
+KPX oslash ccedilla -55
+KPX oslash comma -95
+KPX oslash d -55
+KPX oslash dcroat -55
+KPX oslash e -55
+KPX oslash eacute -55
+KPX oslash ecaron -55
+KPX oslash ecircumflex -55
+KPX oslash edieresis -55
+KPX oslash edotaccent -55
+KPX oslash egrave -55
+KPX oslash emacron -55
+KPX oslash eogonek -55
+KPX oslash f -55
+KPX oslash g -55
+KPX oslash gbreve -55
+KPX oslash gcommaaccent -55
+KPX oslash h -55
+KPX oslash i -55
+KPX oslash iacute -55
+KPX oslash icircumflex -55
+KPX oslash idieresis -55
+KPX oslash igrave -55
+KPX oslash imacron -55
+KPX oslash iogonek -55
+KPX oslash j -55
+KPX oslash k -55
+KPX oslash kcommaaccent -55
+KPX oslash l -55
+KPX oslash lacute -55
+KPX oslash lcommaaccent -55
+KPX oslash lslash -55
+KPX oslash m -55
+KPX oslash n -55
+KPX oslash nacute -55
+KPX oslash ncaron -55
+KPX oslash ncommaaccent -55
+KPX oslash ntilde -55
+KPX oslash o -55
+KPX oslash oacute -55
+KPX oslash ocircumflex -55
+KPX oslash odieresis -55
+KPX oslash ograve -55
+KPX oslash ohungarumlaut -55
+KPX oslash omacron -55
+KPX oslash oslash -55
+KPX oslash otilde -55
+KPX oslash p -55
+KPX oslash period -95
+KPX oslash q -55
+KPX oslash r -55
+KPX oslash racute -55
+KPX oslash rcaron -55
+KPX oslash rcommaaccent -55
+KPX oslash s -55
+KPX oslash sacute -55
+KPX oslash scaron -55
+KPX oslash scedilla -55
+KPX oslash scommaaccent -55
+KPX oslash t -55
+KPX oslash tcommaaccent -55
+KPX oslash u -55
+KPX oslash uacute -55
+KPX oslash ucircumflex -55
+KPX oslash udieresis -55
+KPX oslash ugrave -55
+KPX oslash uhungarumlaut -55
+KPX oslash umacron -55
+KPX oslash uogonek -55
+KPX oslash uring -55
+KPX oslash v -70
+KPX oslash w -70
+KPX oslash x -85
+KPX oslash y -70
+KPX oslash yacute -70
+KPX oslash ydieresis -70
+KPX oslash z -55
+KPX oslash zacute -55
+KPX oslash zcaron -55
+KPX oslash zdotaccent -55
+KPX otilde comma -40
+KPX otilde period -40
+KPX otilde v -15
+KPX otilde w -15
+KPX otilde x -30
+KPX otilde y -30
+KPX otilde yacute -30
+KPX otilde ydieresis -30
+KPX p comma -35
+KPX p period -35
+KPX p y -30
+KPX p yacute -30
+KPX p ydieresis -30
+KPX period quotedblright -100
+KPX period quoteright -100
+KPX period space -60
+KPX quotedblright space -40
+KPX quoteleft quoteleft -57
+KPX quoteright d -50
+KPX quoteright dcroat -50
+KPX quoteright quoteright -57
+KPX quoteright r -50
+KPX quoteright racute -50
+KPX quoteright rcaron -50
+KPX quoteright rcommaaccent -50
+KPX quoteright s -50
+KPX quoteright sacute -50
+KPX quoteright scaron -50
+KPX quoteright scedilla -50
+KPX quoteright scommaaccent -50
+KPX quoteright space -70
+KPX r a -10
+KPX r aacute -10
+KPX r abreve -10
+KPX r acircumflex -10
+KPX r adieresis -10
+KPX r agrave -10
+KPX r amacron -10
+KPX r aogonek -10
+KPX r aring -10
+KPX r atilde -10
+KPX r colon 30
+KPX r comma -50
+KPX r i 15
+KPX r iacute 15
+KPX r icircumflex 15
+KPX r idieresis 15
+KPX r igrave 15
+KPX r imacron 15
+KPX r iogonek 15
+KPX r k 15
+KPX r kcommaaccent 15
+KPX r l 15
+KPX r lacute 15
+KPX r lcommaaccent 15
+KPX r lslash 15
+KPX r m 25
+KPX r n 25
+KPX r nacute 25
+KPX r ncaron 25
+KPX r ncommaaccent 25
+KPX r ntilde 25
+KPX r p 30
+KPX r period -50
+KPX r semicolon 30
+KPX r t 40
+KPX r tcommaaccent 40
+KPX r u 15
+KPX r uacute 15
+KPX r ucircumflex 15
+KPX r udieresis 15
+KPX r ugrave 15
+KPX r uhungarumlaut 15
+KPX r umacron 15
+KPX r uogonek 15
+KPX r uring 15
+KPX r v 30
+KPX r y 30
+KPX r yacute 30
+KPX r ydieresis 30
+KPX racute a -10
+KPX racute aacute -10
+KPX racute abreve -10
+KPX racute acircumflex -10
+KPX racute adieresis -10
+KPX racute agrave -10
+KPX racute amacron -10
+KPX racute aogonek -10
+KPX racute aring -10
+KPX racute atilde -10
+KPX racute colon 30
+KPX racute comma -50
+KPX racute i 15
+KPX racute iacute 15
+KPX racute icircumflex 15
+KPX racute idieresis 15
+KPX racute igrave 15
+KPX racute imacron 15
+KPX racute iogonek 15
+KPX racute k 15
+KPX racute kcommaaccent 15
+KPX racute l 15
+KPX racute lacute 15
+KPX racute lcommaaccent 15
+KPX racute lslash 15
+KPX racute m 25
+KPX racute n 25
+KPX racute nacute 25
+KPX racute ncaron 25
+KPX racute ncommaaccent 25
+KPX racute ntilde 25
+KPX racute p 30
+KPX racute period -50
+KPX racute semicolon 30
+KPX racute t 40
+KPX racute tcommaaccent 40
+KPX racute u 15
+KPX racute uacute 15
+KPX racute ucircumflex 15
+KPX racute udieresis 15
+KPX racute ugrave 15
+KPX racute uhungarumlaut 15
+KPX racute umacron 15
+KPX racute uogonek 15
+KPX racute uring 15
+KPX racute v 30
+KPX racute y 30
+KPX racute yacute 30
+KPX racute ydieresis 30
+KPX rcaron a -10
+KPX rcaron aacute -10
+KPX rcaron abreve -10
+KPX rcaron acircumflex -10
+KPX rcaron adieresis -10
+KPX rcaron agrave -10
+KPX rcaron amacron -10
+KPX rcaron aogonek -10
+KPX rcaron aring -10
+KPX rcaron atilde -10
+KPX rcaron colon 30
+KPX rcaron comma -50
+KPX rcaron i 15
+KPX rcaron iacute 15
+KPX rcaron icircumflex 15
+KPX rcaron idieresis 15
+KPX rcaron igrave 15
+KPX rcaron imacron 15
+KPX rcaron iogonek 15
+KPX rcaron k 15
+KPX rcaron kcommaaccent 15
+KPX rcaron l 15
+KPX rcaron lacute 15
+KPX rcaron lcommaaccent 15
+KPX rcaron lslash 15
+KPX rcaron m 25
+KPX rcaron n 25
+KPX rcaron nacute 25
+KPX rcaron ncaron 25
+KPX rcaron ncommaaccent 25
+KPX rcaron ntilde 25
+KPX rcaron p 30
+KPX rcaron period -50
+KPX rcaron semicolon 30
+KPX rcaron t 40
+KPX rcaron tcommaaccent 40
+KPX rcaron u 15
+KPX rcaron uacute 15
+KPX rcaron ucircumflex 15
+KPX rcaron udieresis 15
+KPX rcaron ugrave 15
+KPX rcaron uhungarumlaut 15
+KPX rcaron umacron 15
+KPX rcaron uogonek 15
+KPX rcaron uring 15
+KPX rcaron v 30
+KPX rcaron y 30
+KPX rcaron yacute 30
+KPX rcaron ydieresis 30
+KPX rcommaaccent a -10
+KPX rcommaaccent aacute -10
+KPX rcommaaccent abreve -10
+KPX rcommaaccent acircumflex -10
+KPX rcommaaccent adieresis -10
+KPX rcommaaccent agrave -10
+KPX rcommaaccent amacron -10
+KPX rcommaaccent aogonek -10
+KPX rcommaaccent aring -10
+KPX rcommaaccent atilde -10
+KPX rcommaaccent colon 30
+KPX rcommaaccent comma -50
+KPX rcommaaccent i 15
+KPX rcommaaccent iacute 15
+KPX rcommaaccent icircumflex 15
+KPX rcommaaccent idieresis 15
+KPX rcommaaccent igrave 15
+KPX rcommaaccent imacron 15
+KPX rcommaaccent iogonek 15
+KPX rcommaaccent k 15
+KPX rcommaaccent kcommaaccent 15
+KPX rcommaaccent l 15
+KPX rcommaaccent lacute 15
+KPX rcommaaccent lcommaaccent 15
+KPX rcommaaccent lslash 15
+KPX rcommaaccent m 25
+KPX rcommaaccent n 25
+KPX rcommaaccent nacute 25
+KPX rcommaaccent ncaron 25
+KPX rcommaaccent ncommaaccent 25
+KPX rcommaaccent ntilde 25
+KPX rcommaaccent p 30
+KPX rcommaaccent period -50
+KPX rcommaaccent semicolon 30
+KPX rcommaaccent t 40
+KPX rcommaaccent tcommaaccent 40
+KPX rcommaaccent u 15
+KPX rcommaaccent uacute 15
+KPX rcommaaccent ucircumflex 15
+KPX rcommaaccent udieresis 15
+KPX rcommaaccent ugrave 15
+KPX rcommaaccent uhungarumlaut 15
+KPX rcommaaccent umacron 15
+KPX rcommaaccent uogonek 15
+KPX rcommaaccent uring 15
+KPX rcommaaccent v 30
+KPX rcommaaccent y 30
+KPX rcommaaccent yacute 30
+KPX rcommaaccent ydieresis 30
+KPX s comma -15
+KPX s period -15
+KPX s w -30
+KPX sacute comma -15
+KPX sacute period -15
+KPX sacute w -30
+KPX scaron comma -15
+KPX scaron period -15
+KPX scaron w -30
+KPX scedilla comma -15
+KPX scedilla period -15
+KPX scedilla w -30
+KPX scommaaccent comma -15
+KPX scommaaccent period -15
+KPX scommaaccent w -30
+KPX semicolon space -50
+KPX space T -50
+KPX space Tcaron -50
+KPX space Tcommaaccent -50
+KPX space V -50
+KPX space W -40
+KPX space Y -90
+KPX space Yacute -90
+KPX space Ydieresis -90
+KPX space quotedblleft -30
+KPX space quoteleft -60
+KPX v a -25
+KPX v aacute -25
+KPX v abreve -25
+KPX v acircumflex -25
+KPX v adieresis -25
+KPX v agrave -25
+KPX v amacron -25
+KPX v aogonek -25
+KPX v aring -25
+KPX v atilde -25
+KPX v comma -80
+KPX v e -25
+KPX v eacute -25
+KPX v ecaron -25
+KPX v ecircumflex -25
+KPX v edieresis -25
+KPX v edotaccent -25
+KPX v egrave -25
+KPX v emacron -25
+KPX v eogonek -25
+KPX v o -25
+KPX v oacute -25
+KPX v ocircumflex -25
+KPX v odieresis -25
+KPX v ograve -25
+KPX v ohungarumlaut -25
+KPX v omacron -25
+KPX v oslash -25
+KPX v otilde -25
+KPX v period -80
+KPX w a -15
+KPX w aacute -15
+KPX w abreve -15
+KPX w acircumflex -15
+KPX w adieresis -15
+KPX w agrave -15
+KPX w amacron -15
+KPX w aogonek -15
+KPX w aring -15
+KPX w atilde -15
+KPX w comma -60
+KPX w e -10
+KPX w eacute -10
+KPX w ecaron -10
+KPX w ecircumflex -10
+KPX w edieresis -10
+KPX w edotaccent -10
+KPX w egrave -10
+KPX w emacron -10
+KPX w eogonek -10
+KPX w o -10
+KPX w oacute -10
+KPX w ocircumflex -10
+KPX w odieresis -10
+KPX w ograve -10
+KPX w ohungarumlaut -10
+KPX w omacron -10
+KPX w oslash -10
+KPX w otilde -10
+KPX w period -60
+KPX x e -30
+KPX x eacute -30
+KPX x ecaron -30
+KPX x ecircumflex -30
+KPX x edieresis -30
+KPX x edotaccent -30
+KPX x egrave -30
+KPX x emacron -30
+KPX x eogonek -30
+KPX y a -20
+KPX y aacute -20
+KPX y abreve -20
+KPX y acircumflex -20
+KPX y adieresis -20
+KPX y agrave -20
+KPX y amacron -20
+KPX y aogonek -20
+KPX y aring -20
+KPX y atilde -20
+KPX y comma -100
+KPX y e -20
+KPX y eacute -20
+KPX y ecaron -20
+KPX y ecircumflex -20
+KPX y edieresis -20
+KPX y edotaccent -20
+KPX y egrave -20
+KPX y emacron -20
+KPX y eogonek -20
+KPX y o -20
+KPX y oacute -20
+KPX y ocircumflex -20
+KPX y odieresis -20
+KPX y ograve -20
+KPX y ohungarumlaut -20
+KPX y omacron -20
+KPX y oslash -20
+KPX y otilde -20
+KPX y period -100
+KPX yacute a -20
+KPX yacute aacute -20
+KPX yacute abreve -20
+KPX yacute acircumflex -20
+KPX yacute adieresis -20
+KPX yacute agrave -20
+KPX yacute amacron -20
+KPX yacute aogonek -20
+KPX yacute aring -20
+KPX yacute atilde -20
+KPX yacute comma -100
+KPX yacute e -20
+KPX yacute eacute -20
+KPX yacute ecaron -20
+KPX yacute ecircumflex -20
+KPX yacute edieresis -20
+KPX yacute edotaccent -20
+KPX yacute egrave -20
+KPX yacute emacron -20
+KPX yacute eogonek -20
+KPX yacute o -20
+KPX yacute oacute -20
+KPX yacute ocircumflex -20
+KPX yacute odieresis -20
+KPX yacute ograve -20
+KPX yacute ohungarumlaut -20
+KPX yacute omacron -20
+KPX yacute oslash -20
+KPX yacute otilde -20
+KPX yacute period -100
+KPX ydieresis a -20
+KPX ydieresis aacute -20
+KPX ydieresis abreve -20
+KPX ydieresis acircumflex -20
+KPX ydieresis adieresis -20
+KPX ydieresis agrave -20
+KPX ydieresis amacron -20
+KPX ydieresis aogonek -20
+KPX ydieresis aring -20
+KPX ydieresis atilde -20
+KPX ydieresis comma -100
+KPX ydieresis e -20
+KPX ydieresis eacute -20
+KPX ydieresis ecaron -20
+KPX ydieresis ecircumflex -20
+KPX ydieresis edieresis -20
+KPX ydieresis edotaccent -20
+KPX ydieresis egrave -20
+KPX ydieresis emacron -20
+KPX ydieresis eogonek -20
+KPX ydieresis o -20
+KPX ydieresis oacute -20
+KPX ydieresis ocircumflex -20
+KPX ydieresis odieresis -20
+KPX ydieresis ograve -20
+KPX ydieresis ohungarumlaut -20
+KPX ydieresis omacron -20
+KPX ydieresis oslash -20
+KPX ydieresis otilde -20
+KPX ydieresis period -100
+KPX z e -15
+KPX z eacute -15
+KPX z ecaron -15
+KPX z ecircumflex -15
+KPX z edieresis -15
+KPX z edotaccent -15
+KPX z egrave -15
+KPX z emacron -15
+KPX z eogonek -15
+KPX z o -15
+KPX z oacute -15
+KPX z ocircumflex -15
+KPX z odieresis -15
+KPX z ograve -15
+KPX z ohungarumlaut -15
+KPX z omacron -15
+KPX z oslash -15
+KPX z otilde -15
+KPX zacute e -15
+KPX zacute eacute -15
+KPX zacute ecaron -15
+KPX zacute ecircumflex -15
+KPX zacute edieresis -15
+KPX zacute edotaccent -15
+KPX zacute egrave -15
+KPX zacute emacron -15
+KPX zacute eogonek -15
+KPX zacute o -15
+KPX zacute oacute -15
+KPX zacute ocircumflex -15
+KPX zacute odieresis -15
+KPX zacute ograve -15
+KPX zacute ohungarumlaut -15
+KPX zacute omacron -15
+KPX zacute oslash -15
+KPX zacute otilde -15
+KPX zcaron e -15
+KPX zcaron eacute -15
+KPX zcaron ecaron -15
+KPX zcaron ecircumflex -15
+KPX zcaron edieresis -15
+KPX zcaron edotaccent -15
+KPX zcaron egrave -15
+KPX zcaron emacron -15
+KPX zcaron eogonek -15
+KPX zcaron o -15
+KPX zcaron oacute -15
+KPX zcaron ocircumflex -15
+KPX zcaron odieresis -15
+KPX zcaron ograve -15
+KPX zcaron ohungarumlaut -15
+KPX zcaron omacron -15
+KPX zcaron oslash -15
+KPX zcaron otilde -15
+KPX zdotaccent e -15
+KPX zdotaccent eacute -15
+KPX zdotaccent ecaron -15
+KPX zdotaccent ecircumflex -15
+KPX zdotaccent edieresis -15
+KPX zdotaccent edotaccent -15
+KPX zdotaccent egrave -15
+KPX zdotaccent emacron -15
+KPX zdotaccent eogonek -15
+KPX zdotaccent o -15
+KPX zdotaccent oacute -15
+KPX zdotaccent ocircumflex -15
+KPX zdotaccent odieresis -15
+KPX zdotaccent ograve -15
+KPX zdotaccent ohungarumlaut -15
+KPX zdotaccent omacron -15
+KPX zdotaccent oslash -15
+KPX zdotaccent otilde -15
+EndKernPairs
+EndKernData
+EndFontMetrics
Added: trunk/mapbender/http/classes/fonts/Times-Bold.afm
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/fonts/Times-Bold.afm?view=auto&rev=54
--- (empty file)
+++ trunk/mapbender/http/classes/fonts/Times-Bold.afm	2006-04-13 21:05:53+0000
@@ -0,0 +1,2588 @@
+StartFontMetrics 4.1
+Comment Copyright (c) 1985, 1987, 1989, 1990, 1993, 1997 Adobe Systems Incorporated.  All Rights Reserved.
+Comment Creation Date: Thu May  1 12:52:56 1997
+Comment UniqueID 43065
+Comment VMusage 41636 52661
+FontName Times-Bold
+FullName Times Bold
+FamilyName Times
+Weight Bold
+ItalicAngle 0
+IsFixedPitch false
+CharacterSet ExtendedRoman
+FontBBox -168 -218 1000 935
+UnderlinePosition -100
+UnderlineThickness 50
+Version 002.000
+Notice Copyright (c) 1985, 1987, 1989, 1990, 1993, 1997 Adobe Systems Incorporated.  All Rights Reserved.Times is a trademark of Linotype-Hell AG and/or its subsidiaries.
+EncodingScheme AdobeStandardEncoding
+CapHeight 676
+XHeight 461
+Ascender 683
+Descender -217
+StdHW 44
+StdVW 139
+StartCharMetrics 315
+C 32 ; WX 250 ; N space ; B 0 0 0 0 ;
+C 33 ; WX 333 ; N exclam ; B 81 -13 251 691 ;
+C 34 ; WX 555 ; N quotedbl ; B 83 404 472 691 ;
+C 35 ; WX 500 ; N numbersign ; B 4 0 496 700 ;
+C 36 ; WX 500 ; N dollar ; B 29 -99 472 750 ;
+C 37 ; WX 1000 ; N percent ; B 124 -14 877 692 ;
+C 38 ; WX 833 ; N ampersand ; B 62 -16 787 691 ;
+C 39 ; WX 333 ; N quoteright ; B 79 356 263 691 ;
+C 40 ; WX 333 ; N parenleft ; B 46 -168 306 694 ;
+C 41 ; WX 333 ; N parenright ; B 27 -168 287 694 ;
+C 42 ; WX 500 ; N asterisk ; B 56 255 447 691 ;
+C 43 ; WX 570 ; N plus ; B 33 0 537 506 ;
+C 44 ; WX 250 ; N comma ; B 39 -180 223 155 ;
+C 45 ; WX 333 ; N hyphen ; B 44 171 287 287 ;
+C 46 ; WX 250 ; N period ; B 41 -13 210 156 ;
+C 47 ; WX 278 ; N slash ; B -24 -19 302 691 ;
+C 48 ; WX 500 ; N zero ; B 24 -13 476 688 ;
+C 49 ; WX 500 ; N one ; B 65 0 442 688 ;
+C 50 ; WX 500 ; N two ; B 17 0 478 688 ;
+C 51 ; WX 500 ; N three ; B 16 -14 468 688 ;
+C 52 ; WX 500 ; N four ; B 19 0 475 688 ;
+C 53 ; WX 500 ; N five ; B 22 -8 470 676 ;
+C 54 ; WX 500 ; N six ; B 28 -13 475 688 ;
+C 55 ; WX 500 ; N seven ; B 17 0 477 676 ;
+C 56 ; WX 500 ; N eight ; B 28 -13 472 688 ;
+C 57 ; WX 500 ; N nine ; B 26 -13 473 688 ;
+C 58 ; WX 333 ; N colon ; B 82 -13 251 472 ;
+C 59 ; WX 333 ; N semicolon ; B 82 -180 266 472 ;
+C 60 ; WX 570 ; N less ; B 31 -8 539 514 ;
+C 61 ; WX 570 ; N equal ; B 33 107 537 399 ;
+C 62 ; WX 570 ; N greater ; B 31 -8 539 514 ;
+C 63 ; WX 500 ; N question ; B 57 -13 445 689 ;
+C 64 ; WX 930 ; N at ; B 108 -19 822 691 ;
+C 65 ; WX 722 ; N A ; B 9 0 689 690 ;
+C 66 ; WX 667 ; N B ; B 16 0 619 676 ;
+C 67 ; WX 722 ; N C ; B 49 -19 687 691 ;
+C 68 ; WX 722 ; N D ; B 14 0 690 676 ;
+C 69 ; WX 667 ; N E ; B 16 0 641 676 ;
+C 70 ; WX 611 ; N F ; B 16 0 583 676 ;
+C 71 ; WX 778 ; N G ; B 37 -19 755 691 ;
+C 72 ; WX 778 ; N H ; B 21 0 759 676 ;
+C 73 ; WX 389 ; N I ; B 20 0 370 676 ;
+C 74 ; WX 500 ; N J ; B 3 -96 479 676 ;
+C 75 ; WX 778 ; N K ; B 30 0 769 676 ;
+C 76 ; WX 667 ; N L ; B 19 0 638 676 ;
+C 77 ; WX 944 ; N M ; B 14 0 921 676 ;
+C 78 ; WX 722 ; N N ; B 16 -18 701 676 ;
+C 79 ; WX 778 ; N O ; B 35 -19 743 691 ;
+C 80 ; WX 611 ; N P ; B 16 0 600 676 ;
+C 81 ; WX 778 ; N Q ; B 35 -176 743 691 ;
+C 82 ; WX 722 ; N R ; B 26 0 715 676 ;
+C 83 ; WX 556 ; N S ; B 35 -19 513 692 ;
+C 84 ; WX 667 ; N T ; B 31 0 636 676 ;
+C 85 ; WX 722 ; N U ; B 16 -19 701 676 ;
+C 86 ; WX 722 ; N V ; B 16 -18 701 676 ;
+C 87 ; WX 1000 ; N W ; B 19 -15 981 676 ;
+C 88 ; WX 722 ; N X ; B 16 0 699 676 ;
+C 89 ; WX 722 ; N Y ; B 15 0 699 676 ;
+C 90 ; WX 667 ; N Z ; B 28 0 634 676 ;
+C 91 ; WX 333 ; N bracketleft ; B 67 -149 301 678 ;
+C 92 ; WX 278 ; N backslash ; B -25 -19 303 691 ;
+C 93 ; WX 333 ; N bracketright ; B 32 -149 266 678 ;
+C 94 ; WX 581 ; N asciicircum ; B 73 311 509 676 ;
+C 95 ; WX 500 ; N underscore ; B 0 -125 500 -75 ;
+C 96 ; WX 333 ; N quoteleft ; B 70 356 254 691 ;
+C 97 ; WX 500 ; N a ; B 25 -14 488 473 ;
+C 98 ; WX 556 ; N b ; B 17 -14 521 676 ;
+C 99 ; WX 444 ; N c ; B 25 -14 430 473 ;
+C 100 ; WX 556 ; N d ; B 25 -14 534 676 ;
+C 101 ; WX 444 ; N e ; B 25 -14 426 473 ;
+C 102 ; WX 333 ; N f ; B 14 0 389 691 ; L i fi ; L l fl ;
+C 103 ; WX 500 ; N g ; B 28 -206 483 473 ;
+C 104 ; WX 556 ; N h ; B 16 0 534 676 ;
+C 105 ; WX 278 ; N i ; B 16 0 255 691 ;
+C 106 ; WX 333 ; N j ; B -57 -203 263 691 ;
+C 107 ; WX 556 ; N k ; B 22 0 543 676 ;
+C 108 ; WX 278 ; N l ; B 16 0 255 676 ;
+C 109 ; WX 833 ; N m ; B 16 0 814 473 ;
+C 110 ; WX 556 ; N n ; B 21 0 539 473 ;
+C 111 ; WX 500 ; N o ; B 25 -14 476 473 ;
+C 112 ; WX 556 ; N p ; B 19 -205 524 473 ;
+C 113 ; WX 556 ; N q ; B 34 -205 536 473 ;
+C 114 ; WX 444 ; N r ; B 29 0 434 473 ;
+C 115 ; WX 389 ; N s ; B 25 -14 361 473 ;
+C 116 ; WX 333 ; N t ; B 20 -12 332 630 ;
+C 117 ; WX 556 ; N u ; B 16 -14 537 461 ;
+C 118 ; WX 500 ; N v ; B 21 -14 485 461 ;
+C 119 ; WX 722 ; N w ; B 23 -14 707 461 ;
+C 120 ; WX 500 ; N x ; B 12 0 484 461 ;
+C 121 ; WX 500 ; N y ; B 16 -205 480 461 ;
+C 122 ; WX 444 ; N z ; B 21 0 420 461 ;
+C 123 ; WX 394 ; N braceleft ; B 22 -175 340 698 ;
+C 124 ; WX 220 ; N bar ; B 66 -218 154 782 ;
+C 125 ; WX 394 ; N braceright ; B 54 -175 372 698 ;
+C 126 ; WX 520 ; N asciitilde ; B 29 173 491 333 ;
+C 161 ; WX 333 ; N exclamdown ; B 82 -203 252 501 ;
+C 162 ; WX 500 ; N cent ; B 53 -140 458 588 ;
+C 163 ; WX 500 ; N sterling ; B 21 -14 477 684 ;
+C 164 ; WX 167 ; N fraction ; B -168 -12 329 688 ;
+C 165 ; WX 500 ; N yen ; B -64 0 547 676 ;
+C 166 ; WX 500 ; N florin ; B 0 -155 498 706 ;
+C 167 ; WX 500 ; N section ; B 57 -132 443 691 ;
+C 168 ; WX 500 ; N currency ; B -26 61 526 613 ;
+C 169 ; WX 278 ; N quotesingle ; B 75 404 204 691 ;
+C 170 ; WX 500 ; N quotedblleft ; B 32 356 486 691 ;
+C 171 ; WX 500 ; N guillemotleft ; B 23 36 473 415 ;
+C 172 ; WX 333 ; N guilsinglleft ; B 51 36 305 415 ;
+C 173 ; WX 333 ; N guilsinglright ; B 28 36 282 415 ;
+C 174 ; WX 556 ; N fi ; B 14 0 536 691 ;
+C 175 ; WX 556 ; N fl ; B 14 0 536 691 ;
+C 177 ; WX 500 ; N endash ; B 0 181 500 271 ;
+C 178 ; WX 500 ; N dagger ; B 47 -134 453 691 ;
+C 179 ; WX 500 ; N daggerdbl ; B 45 -132 456 691 ;
+C 180 ; WX 250 ; N periodcentered ; B 41 248 210 417 ;
+C 182 ; WX 540 ; N paragraph ; B 0 -186 519 676 ;
+C 183 ; WX 350 ; N bullet ; B 35 198 315 478 ;
+C 184 ; WX 333 ; N quotesinglbase ; B 79 -180 263 155 ;
+C 185 ; WX 500 ; N quotedblbase ; B 14 -180 468 155 ;
+C 186 ; WX 500 ; N quotedblright ; B 14 356 468 691 ;
+C 187 ; WX 500 ; N guillemotright ; B 27 36 477 415 ;
+C 188 ; WX 1000 ; N ellipsis ; B 82 -13 917 156 ;
+C 189 ; WX 1000 ; N perthousand ; B 7 -29 995 706 ;
+C 191 ; WX 500 ; N questiondown ; B 55 -201 443 501 ;
+C 193 ; WX 333 ; N grave ; B 8 528 246 713 ;
+C 194 ; WX 333 ; N acute ; B 86 528 324 713 ;
+C 195 ; WX 333 ; N circumflex ; B -2 528 335 704 ;
+C 196 ; WX 333 ; N tilde ; B -16 547 349 674 ;
+C 197 ; WX 333 ; N macron ; B 1 565 331 637 ;
+C 198 ; WX 333 ; N breve ; B 15 528 318 691 ;
+C 199 ; WX 333 ; N dotaccent ; B 103 536 258 691 ;
+C 200 ; WX 333 ; N dieresis ; B -2 537 335 667 ;
+C 202 ; WX 333 ; N ring ; B 60 527 273 740 ;
+C 203 ; WX 333 ; N cedilla ; B 68 -218 294 0 ;
+C 205 ; WX 333 ; N hungarumlaut ; B -13 528 425 713 ;
+C 206 ; WX 333 ; N ogonek ; B 90 -193 319 24 ;
+C 207 ; WX 333 ; N caron ; B -2 528 335 704 ;
+C 208 ; WX 1000 ; N emdash ; B 0 181 1000 271 ;
+C 225 ; WX 1000 ; N AE ; B 4 0 951 676 ;
+C 227 ; WX 300 ; N ordfeminine ; B -1 397 301 688 ;
+C 232 ; WX 667 ; N Lslash ; B 19 0 638 676 ;
+C 233 ; WX 778 ; N Oslash ; B 35 -74 743 737 ;
+C 234 ; WX 1000 ; N OE ; B 22 -5 981 684 ;
+C 235 ; WX 330 ; N ordmasculine ; B 18 397 312 688 ;
+C 241 ; WX 722 ; N ae ; B 33 -14 693 473 ;
+C 245 ; WX 278 ; N dotlessi ; B 16 0 255 461 ;
+C 248 ; WX 278 ; N lslash ; B -22 0 303 676 ;
+C 249 ; WX 500 ; N oslash ; B 25 -92 476 549 ;
+C 250 ; WX 722 ; N oe ; B 22 -14 696 473 ;
+C 251 ; WX 556 ; N germandbls ; B 19 -12 517 691 ;
+C -1 ; WX 389 ; N Idieresis ; B 20 0 370 877 ;
+C -1 ; WX 444 ; N eacute ; B 25 -14 426 713 ;
+C -1 ; WX 500 ; N abreve ; B 25 -14 488 691 ;
+C -1 ; WX 556 ; N uhungarumlaut ; B 16 -14 557 713 ;
+C -1 ; WX 444 ; N ecaron ; B 25 -14 426 704 ;
+C -1 ; WX 722 ; N Ydieresis ; B 15 0 699 877 ;
+C -1 ; WX 570 ; N divide ; B 33 -31 537 537 ;
+C -1 ; WX 722 ; N Yacute ; B 15 0 699 923 ;
+C -1 ; WX 722 ; N Acircumflex ; B 9 0 689 914 ;
+C -1 ; WX 500 ; N aacute ; B 25 -14 488 713 ;
+C -1 ; WX 722 ; N Ucircumflex ; B 16 -19 701 914 ;
+C -1 ; WX 500 ; N yacute ; B 16 -205 480 713 ;
+C -1 ; WX 389 ; N scommaaccent ; B 25 -218 361 473 ;
+C -1 ; WX 444 ; N ecircumflex ; B 25 -14 426 704 ;
+C -1 ; WX 722 ; N Uring ; B 16 -19 701 935 ;
+C -1 ; WX 722 ; N Udieresis ; B 16 -19 701 877 ;
+C -1 ; WX 500 ; N aogonek ; B 25 -193 504 473 ;
+C -1 ; WX 722 ; N Uacute ; B 16 -19 701 923 ;
+C -1 ; WX 556 ; N uogonek ; B 16 -193 539 461 ;
+C -1 ; WX 667 ; N Edieresis ; B 16 0 641 877 ;
+C -1 ; WX 722 ; N Dcroat ; B 6 0 690 676 ;
+C -1 ; WX 250 ; N commaaccent ; B 47 -218 203 -50 ;
+C -1 ; WX 747 ; N copyright ; B 26 -19 721 691 ;
+C -1 ; WX 667 ; N Emacron ; B 16 0 641 847 ;
+C -1 ; WX 444 ; N ccaron ; B 25 -14 430 704 ;
+C -1 ; WX 500 ; N aring ; B 25 -14 488 740 ;
+C -1 ; WX 722 ; N Ncommaaccent ; B 16 -188 701 676 ;
+C -1 ; WX 278 ; N lacute ; B 16 0 297 923 ;
+C -1 ; WX 500 ; N agrave ; B 25 -14 488 713 ;
+C -1 ; WX 667 ; N Tcommaaccent ; B 31 -218 636 676 ;
+C -1 ; WX 722 ; N Cacute ; B 49 -19 687 923 ;
+C -1 ; WX 500 ; N atilde ; B 25 -14 488 674 ;
+C -1 ; WX 667 ; N Edotaccent ; B 16 0 641 901 ;
+C -1 ; WX 389 ; N scaron ; B 25 -14 363 704 ;
+C -1 ; WX 389 ; N scedilla ; B 25 -218 361 473 ;
+C -1 ; WX 278 ; N iacute ; B 16 0 289 713 ;
+C -1 ; WX 494 ; N lozenge ; B 10 0 484 745 ;
+C -1 ; WX 722 ; N Rcaron ; B 26 0 715 914 ;
+C -1 ; WX 778 ; N Gcommaaccent ; B 37 -218 755 691 ;
+C -1 ; WX 556 ; N ucircumflex ; B 16 -14 537 704 ;
+C -1 ; WX 500 ; N acircumflex ; B 25 -14 488 704 ;
+C -1 ; WX 722 ; N Amacron ; B 9 0 689 847 ;
+C -1 ; WX 444 ; N rcaron ; B 29 0 434 704 ;
+C -1 ; WX 444 ; N ccedilla ; B 25 -218 430 473 ;
+C -1 ; WX 667 ; N Zdotaccent ; B 28 0 634 901 ;
+C -1 ; WX 611 ; N Thorn ; B 16 0 600 676 ;
+C -1 ; WX 778 ; N Omacron ; B 35 -19 743 847 ;
+C -1 ; WX 722 ; N Racute ; B 26 0 715 923 ;
+C -1 ; WX 556 ; N Sacute ; B 35 -19 513 923 ;
+C -1 ; WX 672 ; N dcaron ; B 25 -14 681 682 ;
+C -1 ; WX 722 ; N Umacron ; B 16 -19 701 847 ;
+C -1 ; WX 556 ; N uring ; B 16 -14 537 740 ;
+C -1 ; WX 300 ; N threesuperior ; B 3 268 297 688 ;
+C -1 ; WX 778 ; N Ograve ; B 35 -19 743 923 ;
+C -1 ; WX 722 ; N Agrave ; B 9 0 689 923 ;
+C -1 ; WX 722 ; N Abreve ; B 9 0 689 901 ;
+C -1 ; WX 570 ; N multiply ; B 48 16 522 490 ;
+C -1 ; WX 556 ; N uacute ; B 16 -14 537 713 ;
+C -1 ; WX 667 ; N Tcaron ; B 31 0 636 914 ;
+C -1 ; WX 494 ; N partialdiff ; B 11 -21 494 750 ;
+C -1 ; WX 500 ; N ydieresis ; B 16 -205 480 667 ;
+C -1 ; WX 722 ; N Nacute ; B 16 -18 701 923 ;
+C -1 ; WX 278 ; N icircumflex ; B -37 0 300 704 ;
+C -1 ; WX 667 ; N Ecircumflex ; B 16 0 641 914 ;
+C -1 ; WX 500 ; N adieresis ; B 25 -14 488 667 ;
+C -1 ; WX 444 ; N edieresis ; B 25 -14 426 667 ;
+C -1 ; WX 444 ; N cacute ; B 25 -14 430 713 ;
+C -1 ; WX 556 ; N nacute ; B 21 0 539 713 ;
+C -1 ; WX 556 ; N umacron ; B 16 -14 537 637 ;
+C -1 ; WX 722 ; N Ncaron ; B 16 -18 701 914 ;
+C -1 ; WX 389 ; N Iacute ; B 20 0 370 923 ;
+C -1 ; WX 570 ; N plusminus ; B 33 0 537 506 ;
+C -1 ; WX 220 ; N brokenbar ; B 66 -143 154 707 ;
+C -1 ; WX 747 ; N registered ; B 26 -19 721 691 ;
+C -1 ; WX 778 ; N Gbreve ; B 37 -19 755 901 ;
+C -1 ; WX 389 ; N Idotaccent ; B 20 0 370 901 ;
+C -1 ; WX 600 ; N summation ; B 14 -10 585 706 ;
+C -1 ; WX 667 ; N Egrave ; B 16 0 641 923 ;
+C -1 ; WX 444 ; N racute ; B 29 0 434 713 ;
+C -1 ; WX 500 ; N omacron ; B 25 -14 476 637 ;
+C -1 ; WX 667 ; N Zacute ; B 28 0 634 923 ;
+C -1 ; WX 667 ; N Zcaron ; B 28 0 634 914 ;
+C -1 ; WX 549 ; N greaterequal ; B 26 0 523 704 ;
+C -1 ; WX 722 ; N Eth ; B 6 0 690 676 ;
+C -1 ; WX 722 ; N Ccedilla ; B 49 -218 687 691 ;
+C -1 ; WX 278 ; N lcommaaccent ; B 16 -218 255 676 ;
+C -1 ; WX 416 ; N tcaron ; B 20 -12 425 815 ;
+C -1 ; WX 444 ; N eogonek ; B 25 -193 426 473 ;
+C -1 ; WX 722 ; N Uogonek ; B 16 -193 701 676 ;
+C -1 ; WX 722 ; N Aacute ; B 9 0 689 923 ;
+C -1 ; WX 722 ; N Adieresis ; B 9 0 689 877 ;
+C -1 ; WX 444 ; N egrave ; B 25 -14 426 713 ;
+C -1 ; WX 444 ; N zacute ; B 21 0 420 713 ;
+C -1 ; WX 278 ; N iogonek ; B 16 -193 274 691 ;
+C -1 ; WX 778 ; N Oacute ; B 35 -19 743 923 ;
+C -1 ; WX 500 ; N oacute ; B 25 -14 476 713 ;
+C -1 ; WX 500 ; N amacron ; B 25 -14 488 637 ;
+C -1 ; WX 389 ; N sacute ; B 25 -14 361 713 ;
+C -1 ; WX 278 ; N idieresis ; B -37 0 300 667 ;
+C -1 ; WX 778 ; N Ocircumflex ; B 35 -19 743 914 ;
+C -1 ; WX 722 ; N Ugrave ; B 16 -19 701 923 ;
+C -1 ; WX 612 ; N Delta ; B 6 0 608 688 ;
+C -1 ; WX 556 ; N thorn ; B 19 -205 524 676 ;
+C -1 ; WX 300 ; N twosuperior ; B 0 275 300 688 ;
+C -1 ; WX 778 ; N Odieresis ; B 35 -19 743 877 ;
+C -1 ; WX 556 ; N mu ; B 33 -206 536 461 ;
+C -1 ; WX 278 ; N igrave ; B -27 0 255 713 ;
+C -1 ; WX 500 ; N ohungarumlaut ; B 25 -14 529 713 ;
+C -1 ; WX 667 ; N Eogonek ; B 16 -193 644 676 ;
+C -1 ; WX 556 ; N dcroat ; B 25 -14 534 676 ;
+C -1 ; WX 750 ; N threequarters ; B 23 -12 733 688 ;
+C -1 ; WX 556 ; N Scedilla ; B 35 -218 513 692 ;
+C -1 ; WX 394 ; N lcaron ; B 16 0 412 682 ;
+C -1 ; WX 778 ; N Kcommaaccent ; B 30 -218 769 676 ;
+C -1 ; WX 667 ; N Lacute ; B 19 0 638 923 ;
+C -1 ; WX 1000 ; N trademark ; B 24 271 977 676 ;
+C -1 ; WX 444 ; N edotaccent ; B 25 -14 426 691 ;
+C -1 ; WX 389 ; N Igrave ; B 20 0 370 923 ;
+C -1 ; WX 389 ; N Imacron ; B 20 0 370 847 ;
+C -1 ; WX 667 ; N Lcaron ; B 19 0 652 682 ;
+C -1 ; WX 750 ; N onehalf ; B -7 -12 775 688 ;
+C -1 ; WX 549 ; N lessequal ; B 29 0 526 704 ;
+C -1 ; WX 500 ; N ocircumflex ; B 25 -14 476 704 ;
+C -1 ; WX 556 ; N ntilde ; B 21 0 539 674 ;
+C -1 ; WX 722 ; N Uhungarumlaut ; B 16 -19 701 923 ;
+C -1 ; WX 667 ; N Eacute ; B 16 0 641 923 ;
+C -1 ; WX 444 ; N emacron ; B 25 -14 426 637 ;
+C -1 ; WX 500 ; N gbreve ; B 28 -206 483 691 ;
+C -1 ; WX 750 ; N onequarter ; B 28 -12 743 688 ;
+C -1 ; WX 556 ; N Scaron ; B 35 -19 513 914 ;
+C -1 ; WX 556 ; N Scommaaccent ; B 35 -218 513 692 ;
+C -1 ; WX 778 ; N Ohungarumlaut ; B 35 -19 743 923 ;
+C -1 ; WX 400 ; N degree ; B 57 402 343 688 ;
+C -1 ; WX 500 ; N ograve ; B 25 -14 476 713 ;
+C -1 ; WX 722 ; N Ccaron ; B 49 -19 687 914 ;
+C -1 ; WX 556 ; N ugrave ; B 16 -14 537 713 ;
+C -1 ; WX 549 ; N radical ; B 10 -46 512 850 ;
+C -1 ; WX 722 ; N Dcaron ; B 14 0 690 914 ;
+C -1 ; WX 444 ; N rcommaaccent ; B 29 -218 434 473 ;
+C -1 ; WX 722 ; N Ntilde ; B 16 -18 701 884 ;
+C -1 ; WX 500 ; N otilde ; B 25 -14 476 674 ;
+C -1 ; WX 722 ; N Rcommaaccent ; B 26 -218 715 676 ;
+C -1 ; WX 667 ; N Lcommaaccent ; B 19 -218 638 676 ;
+C -1 ; WX 722 ; N Atilde ; B 9 0 689 884 ;
+C -1 ; WX 722 ; N Aogonek ; B 9 -193 699 690 ;
+C -1 ; WX 722 ; N Aring ; B 9 0 689 935 ;
+C -1 ; WX 778 ; N Otilde ; B 35 -19 743 884 ;
+C -1 ; WX 444 ; N zdotaccent ; B 21 0 420 691 ;
+C -1 ; WX 667 ; N Ecaron ; B 16 0 641 914 ;
+C -1 ; WX 389 ; N Iogonek ; B 20 -193 370 676 ;
+C -1 ; WX 556 ; N kcommaaccent ; B 22 -218 543 676 ;
+C -1 ; WX 570 ; N minus ; B 33 209 537 297 ;
+C -1 ; WX 389 ; N Icircumflex ; B 20 0 370 914 ;
+C -1 ; WX 556 ; N ncaron ; B 21 0 539 704 ;
+C -1 ; WX 333 ; N tcommaaccent ; B 20 -218 332 630 ;
+C -1 ; WX 570 ; N logicalnot ; B 33 108 537 399 ;
+C -1 ; WX 500 ; N odieresis ; B 25 -14 476 667 ;
+C -1 ; WX 556 ; N udieresis ; B 16 -14 537 667 ;
+C -1 ; WX 549 ; N notequal ; B 15 -49 540 570 ;
+C -1 ; WX 500 ; N gcommaaccent ; B 28 -206 483 829 ;
+C -1 ; WX 500 ; N eth ; B 25 -14 476 691 ;
+C -1 ; WX 444 ; N zcaron ; B 21 0 420 704 ;
+C -1 ; WX 556 ; N ncommaaccent ; B 21 -218 539 473 ;
+C -1 ; WX 300 ; N onesuperior ; B 28 275 273 688 ;
+C -1 ; WX 278 ; N imacron ; B -8 0 272 637 ;
+C -1 ; WX 500 ; N Euro ; B 0 0 0 0 ;
+EndCharMetrics
+StartKernData
+StartKernPairs 2242
+KPX A C -55
+KPX A Cacute -55
+KPX A Ccaron -55
+KPX A Ccedilla -55
+KPX A G -55
+KPX A Gbreve -55
+KPX A Gcommaaccent -55
+KPX A O -45
+KPX A Oacute -45
+KPX A Ocircumflex -45
+KPX A Odieresis -45
+KPX A Ograve -45
+KPX A Ohungarumlaut -45
+KPX A Omacron -45
+KPX A Oslash -45
+KPX A Otilde -45
+KPX A Q -45
+KPX A T -95
+KPX A Tcaron -95
+KPX A Tcommaaccent -95
+KPX A U -50
+KPX A Uacute -50
+KPX A Ucircumflex -50
+KPX A Udieresis -50
+KPX A Ugrave -50
+KPX A Uhungarumlaut -50
+KPX A Umacron -50
+KPX A Uogonek -50
+KPX A Uring -50
+KPX A V -145
+KPX A W -130
+KPX A Y -100
+KPX A Yacute -100
+KPX A Ydieresis -100
+KPX A p -25
+KPX A quoteright -74
+KPX A u -50
+KPX A uacute -50
+KPX A ucircumflex -50
+KPX A udieresis -50
+KPX A ugrave -50
+KPX A uhungarumlaut -50
+KPX A umacron -50
+KPX A uogonek -50
+KPX A uring -50
+KPX A v -100
+KPX A w -90
+KPX A y -74
+KPX A yacute -74
+KPX A ydieresis -74
+KPX Aacute C -55
+KPX Aacute Cacute -55
+KPX Aacute Ccaron -55
+KPX Aacute Ccedilla -55
+KPX Aacute G -55
+KPX Aacute Gbreve -55
+KPX Aacute Gcommaaccent -55
+KPX Aacute O -45
+KPX Aacute Oacute -45
+KPX Aacute Ocircumflex -45
+KPX Aacute Odieresis -45
+KPX Aacute Ograve -45
+KPX Aacute Ohungarumlaut -45
+KPX Aacute Omacron -45
+KPX Aacute Oslash -45
+KPX Aacute Otilde -45
+KPX Aacute Q -45
+KPX Aacute T -95
+KPX Aacute Tcaron -95
+KPX Aacute Tcommaaccent -95
+KPX Aacute U -50
+KPX Aacute Uacute -50
+KPX Aacute Ucircumflex -50
+KPX Aacute Udieresis -50
+KPX Aacute Ugrave -50
+KPX Aacute Uhungarumlaut -50
+KPX Aacute Umacron -50
+KPX Aacute Uogonek -50
+KPX Aacute Uring -50
+KPX Aacute V -145
+KPX Aacute W -130
+KPX Aacute Y -100
+KPX Aacute Yacute -100
+KPX Aacute Ydieresis -100
+KPX Aacute p -25
+KPX Aacute quoteright -74
+KPX Aacute u -50
+KPX Aacute uacute -50
+KPX Aacute ucircumflex -50
+KPX Aacute udieresis -50
+KPX Aacute ugrave -50
+KPX Aacute uhungarumlaut -50
+KPX Aacute umacron -50
+KPX Aacute uogonek -50
+KPX Aacute uring -50
+KPX Aacute v -100
+KPX Aacute w -90
+KPX Aacute y -74
+KPX Aacute yacute -74
+KPX Aacute ydieresis -74
+KPX Abreve C -55
+KPX Abreve Cacute -55
+KPX Abreve Ccaron -55
+KPX Abreve Ccedilla -55
+KPX Abreve G -55
+KPX Abreve Gbreve -55
+KPX Abreve Gcommaaccent -55
+KPX Abreve O -45
+KPX Abreve Oacute -45
+KPX Abreve Ocircumflex -45
+KPX Abreve Odieresis -45
+KPX Abreve Ograve -45
+KPX Abreve Ohungarumlaut -45
+KPX Abreve Omacron -45
+KPX Abreve Oslash -45
+KPX Abreve Otilde -45
+KPX Abreve Q -45
+KPX Abreve T -95
+KPX Abreve Tcaron -95
+KPX Abreve Tcommaaccent -95
+KPX Abreve U -50
+KPX Abreve Uacute -50
+KPX Abreve Ucircumflex -50
+KPX Abreve Udieresis -50
+KPX Abreve Ugrave -50
+KPX Abreve Uhungarumlaut -50
+KPX Abreve Umacron -50
+KPX Abreve Uogonek -50
+KPX Abreve Uring -50
+KPX Abreve V -145
+KPX Abreve W -130
+KPX Abreve Y -100
+KPX Abreve Yacute -100
+KPX Abreve Ydieresis -100
+KPX Abreve p -25
+KPX Abreve quoteright -74
+KPX Abreve u -50
+KPX Abreve uacute -50
+KPX Abreve ucircumflex -50
+KPX Abreve udieresis -50
+KPX Abreve ugrave -50
+KPX Abreve uhungarumlaut -50
+KPX Abreve umacron -50
+KPX Abreve uogonek -50
+KPX Abreve uring -50
+KPX Abreve v -100
+KPX Abreve w -90
+KPX Abreve y -74
+KPX Abreve yacute -74
+KPX Abreve ydieresis -74
+KPX Acircumflex C -55
+KPX Acircumflex Cacute -55
+KPX Acircumflex Ccaron -55
+KPX Acircumflex Ccedilla -55
+KPX Acircumflex G -55
+KPX Acircumflex Gbreve -55
+KPX Acircumflex Gcommaaccent -55
+KPX Acircumflex O -45
+KPX Acircumflex Oacute -45
+KPX Acircumflex Ocircumflex -45
+KPX Acircumflex Odieresis -45
+KPX Acircumflex Ograve -45
+KPX Acircumflex Ohungarumlaut -45
+KPX Acircumflex Omacron -45
+KPX Acircumflex Oslash -45
+KPX Acircumflex Otilde -45
+KPX Acircumflex Q -45
+KPX Acircumflex T -95
+KPX Acircumflex Tcaron -95
+KPX Acircumflex Tcommaaccent -95
+KPX Acircumflex U -50
+KPX Acircumflex Uacute -50
+KPX Acircumflex Ucircumflex -50
+KPX Acircumflex Udieresis -50
+KPX Acircumflex Ugrave -50
+KPX Acircumflex Uhungarumlaut -50
+KPX Acircumflex Umacron -50
+KPX Acircumflex Uogonek -50
+KPX Acircumflex Uring -50
+KPX Acircumflex V -145
+KPX Acircumflex W -130
+KPX Acircumflex Y -100
+KPX Acircumflex Yacute -100
+KPX Acircumflex Ydieresis -100
+KPX Acircumflex p -25
+KPX Acircumflex quoteright -74
+KPX Acircumflex u -50
+KPX Acircumflex uacute -50
+KPX Acircumflex ucircumflex -50
+KPX Acircumflex udieresis -50
+KPX Acircumflex ugrave -50
+KPX Acircumflex uhungarumlaut -50
+KPX Acircumflex umacron -50
+KPX Acircumflex uogonek -50
+KPX Acircumflex uring -50
+KPX Acircumflex v -100
+KPX Acircumflex w -90
+KPX Acircumflex y -74
+KPX Acircumflex yacute -74
+KPX Acircumflex ydieresis -74
+KPX Adieresis C -55
+KPX Adieresis Cacute -55
+KPX Adieresis Ccaron -55
+KPX Adieresis Ccedilla -55
+KPX Adieresis G -55
+KPX Adieresis Gbreve -55
+KPX Adieresis Gcommaaccent -55
+KPX Adieresis O -45
+KPX Adieresis Oacute -45
+KPX Adieresis Ocircumflex -45
+KPX Adieresis Odieresis -45
+KPX Adieresis Ograve -45
+KPX Adieresis Ohungarumlaut -45
+KPX Adieresis Omacron -45
+KPX Adieresis Oslash -45
+KPX Adieresis Otilde -45
+KPX Adieresis Q -45
+KPX Adieresis T -95
+KPX Adieresis Tcaron -95
+KPX Adieresis Tcommaaccent -95
+KPX Adieresis U -50
+KPX Adieresis Uacute -50
+KPX Adieresis Ucircumflex -50
+KPX Adieresis Udieresis -50
+KPX Adieresis Ugrave -50
+KPX Adieresis Uhungarumlaut -50
+KPX Adieresis Umacron -50
+KPX Adieresis Uogonek -50
+KPX Adieresis Uring -50
+KPX Adieresis V -145
+KPX Adieresis W -130
+KPX Adieresis Y -100
+KPX Adieresis Yacute -100
+KPX Adieresis Ydieresis -100
+KPX Adieresis p -25
+KPX Adieresis quoteright -74
+KPX Adieresis u -50
+KPX Adieresis uacute -50
+KPX Adieresis ucircumflex -50
+KPX Adieresis udieresis -50
+KPX Adieresis ugrave -50
+KPX Adieresis uhungarumlaut -50
+KPX Adieresis umacron -50
+KPX Adieresis uogonek -50
+KPX Adieresis uring -50
+KPX Adieresis v -100
+KPX Adieresis w -90
+KPX Adieresis y -74
+KPX Adieresis yacute -74
+KPX Adieresis ydieresis -74
+KPX Agrave C -55
+KPX Agrave Cacute -55
+KPX Agrave Ccaron -55
+KPX Agrave Ccedilla -55
+KPX Agrave G -55
+KPX Agrave Gbreve -55
+KPX Agrave Gcommaaccent -55
+KPX Agrave O -45
+KPX Agrave Oacute -45
+KPX Agrave Ocircumflex -45
+KPX Agrave Odieresis -45
+KPX Agrave Ograve -45
+KPX Agrave Ohungarumlaut -45
+KPX Agrave Omacron -45
+KPX Agrave Oslash -45
+KPX Agrave Otilde -45
+KPX Agrave Q -45
+KPX Agrave T -95
+KPX Agrave Tcaron -95
+KPX Agrave Tcommaaccent -95
+KPX Agrave U -50
+KPX Agrave Uacute -50
+KPX Agrave Ucircumflex -50
+KPX Agrave Udieresis -50
+KPX Agrave Ugrave -50
+KPX Agrave Uhungarumlaut -50
+KPX Agrave Umacron -50
+KPX Agrave Uogonek -50
+KPX Agrave Uring -50
+KPX Agrave V -145
+KPX Agrave W -130
+KPX Agrave Y -100
+KPX Agrave Yacute -100
+KPX Agrave Ydieresis -100
+KPX Agrave p -25
+KPX Agrave quoteright -74
+KPX Agrave u -50
+KPX Agrave uacute -50
+KPX Agrave ucircumflex -50
+KPX Agrave udieresis -50
+KPX Agrave ugrave -50
+KPX Agrave uhungarumlaut -50
+KPX Agrave umacron -50
+KPX Agrave uogonek -50
+KPX Agrave uring -50
+KPX Agrave v -100
+KPX Agrave w -90
+KPX Agrave y -74
+KPX Agrave yacute -74
+KPX Agrave ydieresis -74
+KPX Amacron C -55
+KPX Amacron Cacute -55
+KPX Amacron Ccaron -55
+KPX Amacron Ccedilla -55
+KPX Amacron G -55
+KPX Amacron Gbreve -55
+KPX Amacron Gcommaaccent -55
+KPX Amacron O -45
+KPX Amacron Oacute -45
+KPX Amacron Ocircumflex -45
+KPX Amacron Odieresis -45
+KPX Amacron Ograve -45
+KPX Amacron Ohungarumlaut -45
+KPX Amacron Omacron -45
+KPX Amacron Oslash -45
+KPX Amacron Otilde -45
+KPX Amacron Q -45
+KPX Amacron T -95
+KPX Amacron Tcaron -95
+KPX Amacron Tcommaaccent -95
+KPX Amacron U -50
+KPX Amacron Uacute -50
+KPX Amacron Ucircumflex -50
+KPX Amacron Udieresis -50
+KPX Amacron Ugrave -50
+KPX Amacron Uhungarumlaut -50
+KPX Amacron Umacron -50
+KPX Amacron Uogonek -50
+KPX Amacron Uring -50
+KPX Amacron V -145
+KPX Amacron W -130
+KPX Amacron Y -100
+KPX Amacron Yacute -100
+KPX Amacron Ydieresis -100
+KPX Amacron p -25
+KPX Amacron quoteright -74
+KPX Amacron u -50
+KPX Amacron uacute -50
+KPX Amacron ucircumflex -50
+KPX Amacron udieresis -50
+KPX Amacron ugrave -50
+KPX Amacron uhungarumlaut -50
+KPX Amacron umacron -50
+KPX Amacron uogonek -50
+KPX Amacron uring -50
+KPX Amacron v -100
+KPX Amacron w -90
+KPX Amacron y -74
+KPX Amacron yacute -74
+KPX Amacron ydieresis -74
+KPX Aogonek C -55
+KPX Aogonek Cacute -55
+KPX Aogonek Ccaron -55
+KPX Aogonek Ccedilla -55
+KPX Aogonek G -55
+KPX Aogonek Gbreve -55
+KPX Aogonek Gcommaaccent -55
+KPX Aogonek O -45
+KPX Aogonek Oacute -45
+KPX Aogonek Ocircumflex -45
+KPX Aogonek Odieresis -45
+KPX Aogonek Ograve -45
+KPX Aogonek Ohungarumlaut -45
+KPX Aogonek Omacron -45
+KPX Aogonek Oslash -45
+KPX Aogonek Otilde -45
+KPX Aogonek Q -45
+KPX Aogonek T -95
+KPX Aogonek Tcaron -95
+KPX Aogonek Tcommaaccent -95
+KPX Aogonek U -50
+KPX Aogonek Uacute -50
+KPX Aogonek Ucircumflex -50
+KPX Aogonek Udieresis -50
+KPX Aogonek Ugrave -50
+KPX Aogonek Uhungarumlaut -50
+KPX Aogonek Umacron -50
+KPX Aogonek Uogonek -50
+KPX Aogonek Uring -50
+KPX Aogonek V -145
+KPX Aogonek W -130
+KPX Aogonek Y -100
+KPX Aogonek Yacute -100
+KPX Aogonek Ydieresis -100
+KPX Aogonek p -25
+KPX Aogonek quoteright -74
+KPX Aogonek u -50
+KPX Aogonek uacute -50
+KPX Aogonek ucircumflex -50
+KPX Aogonek udieresis -50
+KPX Aogonek ugrave -50
+KPX Aogonek uhungarumlaut -50
+KPX Aogonek umacron -50
+KPX Aogonek uogonek -50
+KPX Aogonek uring -50
+KPX Aogonek v -100
+KPX Aogonek w -90
+KPX Aogonek y -34
+KPX Aogonek yacute -34
+KPX Aogonek ydieresis -34
+KPX Aring C -55
+KPX Aring Cacute -55
+KPX Aring Ccaron -55
+KPX Aring Ccedilla -55
+KPX Aring G -55
+KPX Aring Gbreve -55
+KPX Aring Gcommaaccent -55
+KPX Aring O -45
+KPX Aring Oacute -45
+KPX Aring Ocircumflex -45
+KPX Aring Odieresis -45
+KPX Aring Ograve -45
+KPX Aring Ohungarumlaut -45
+KPX Aring Omacron -45
+KPX Aring Oslash -45
+KPX Aring Otilde -45
+KPX Aring Q -45
+KPX Aring T -95
+KPX Aring Tcaron -95
+KPX Aring Tcommaaccent -95
+KPX Aring U -50
+KPX Aring Uacute -50
+KPX Aring Ucircumflex -50
+KPX Aring Udieresis -50
+KPX Aring Ugrave -50
+KPX Aring Uhungarumlaut -50
+KPX Aring Umacron -50
+KPX Aring Uogonek -50
+KPX Aring Uring -50
+KPX Aring V -145
+KPX Aring W -130
+KPX Aring Y -100
+KPX Aring Yacute -100
+KPX Aring Ydieresis -100
+KPX Aring p -25
+KPX Aring quoteright -74
+KPX Aring u -50
+KPX Aring uacute -50
+KPX Aring ucircumflex -50
+KPX Aring udieresis -50
+KPX Aring ugrave -50
+KPX Aring uhungarumlaut -50
+KPX Aring umacron -50
+KPX Aring uogonek -50
+KPX Aring uring -50
+KPX Aring v -100
+KPX Aring w -90
+KPX Aring y -74
+KPX Aring yacute -74
+KPX Aring ydieresis -74
+KPX Atilde C -55
+KPX Atilde Cacute -55
+KPX Atilde Ccaron -55
+KPX Atilde Ccedilla -55
+KPX Atilde G -55
+KPX Atilde Gbreve -55
+KPX Atilde Gcommaaccent -55
+KPX Atilde O -45
+KPX Atilde Oacute -45
+KPX Atilde Ocircumflex -45
+KPX Atilde Odieresis -45
+KPX Atilde Ograve -45
+KPX Atilde Ohungarumlaut -45
+KPX Atilde Omacron -45
+KPX Atilde Oslash -45
+KPX Atilde Otilde -45
+KPX Atilde Q -45
+KPX Atilde T -95
+KPX Atilde Tcaron -95
+KPX Atilde Tcommaaccent -95
+KPX Atilde U -50
+KPX Atilde Uacute -50
+KPX Atilde Ucircumflex -50
+KPX Atilde Udieresis -50
+KPX Atilde Ugrave -50
+KPX Atilde Uhungarumlaut -50
+KPX Atilde Umacron -50
+KPX Atilde Uogonek -50
+KPX Atilde Uring -50
+KPX Atilde V -145
+KPX Atilde W -130
+KPX Atilde Y -100
+KPX Atilde Yacute -100
+KPX Atilde Ydieresis -100
+KPX Atilde p -25
+KPX Atilde quoteright -74
+KPX Atilde u -50
+KPX Atilde uacute -50
+KPX Atilde ucircumflex -50
+KPX Atilde udieresis -50
+KPX Atilde ugrave -50
+KPX Atilde uhungarumlaut -50
+KPX Atilde umacron -50
+KPX Atilde uogonek -50
+KPX Atilde uring -50
+KPX Atilde v -100
+KPX Atilde w -90
+KPX Atilde y -74
+KPX Atilde yacute -74
+KPX Atilde ydieresis -74
+KPX B A -30
+KPX B Aacute -30
+KPX B Abreve -30
+KPX B Acircumflex -30
+KPX B Adieresis -30
+KPX B Agrave -30
+KPX B Amacron -30
+KPX B Aogonek -30
+KPX B Aring -30
+KPX B Atilde -30
+KPX B U -10
+KPX B Uacute -10
+KPX B Ucircumflex -10
+KPX B Udieresis -10
+KPX B Ugrave -10
+KPX B Uhungarumlaut -10
+KPX B Umacron -10
+KPX B Uogonek -10
+KPX B Uring -10
+KPX D A -35
+KPX D Aacute -35
+KPX D Abreve -35
+KPX D Acircumflex -35
+KPX D Adieresis -35
+KPX D Agrave -35
+KPX D Amacron -35
+KPX D Aogonek -35
+KPX D Aring -35
+KPX D Atilde -35
+KPX D V -40
+KPX D W -40
+KPX D Y -40
+KPX D Yacute -40
+KPX D Ydieresis -40
+KPX D period -20
+KPX Dcaron A -35
+KPX Dcaron Aacute -35
+KPX Dcaron Abreve -35
+KPX Dcaron Acircumflex -35
+KPX Dcaron Adieresis -35
+KPX Dcaron Agrave -35
+KPX Dcaron Amacron -35
+KPX Dcaron Aogonek -35
+KPX Dcaron Aring -35
+KPX Dcaron Atilde -35
+KPX Dcaron V -40
+KPX Dcaron W -40
+KPX Dcaron Y -40
+KPX Dcaron Yacute -40
+KPX Dcaron Ydieresis -40
+KPX Dcaron period -20
+KPX Dcroat A -35
+KPX Dcroat Aacute -35
+KPX Dcroat Abreve -35
+KPX Dcroat Acircumflex -35
+KPX Dcroat Adieresis -35
+KPX Dcroat Agrave -35
+KPX Dcroat Amacron -35
+KPX Dcroat Aogonek -35
+KPX Dcroat Aring -35
+KPX Dcroat Atilde -35
+KPX Dcroat V -40
+KPX Dcroat W -40
+KPX Dcroat Y -40
+KPX Dcroat Yacute -40
+KPX Dcroat Ydieresis -40
+KPX Dcroat period -20
+KPX F A -90
+KPX F Aacute -90
+KPX F Abreve -90
+KPX F Acircumflex -90
+KPX F Adieresis -90
+KPX F Agrave -90
+KPX F Amacron -90
+KPX F Aogonek -90
+KPX F Aring -90
+KPX F Atilde -90
+KPX F a -25
+KPX F aacute -25
+KPX F abreve -25
+KPX F acircumflex -25
+KPX F adieresis -25
+KPX F agrave -25
+KPX F amacron -25
+KPX F aogonek -25
+KPX F aring -25
+KPX F atilde -25
+KPX F comma -92
+KPX F e -25
+KPX F eacute -25
+KPX F ecaron -25
+KPX F ecircumflex -25
+KPX F edieresis -25
+KPX F edotaccent -25
+KPX F egrave -25
+KPX F emacron -25
+KPX F eogonek -25
+KPX F o -25
+KPX F oacute -25
+KPX F ocircumflex -25
+KPX F odieresis -25
+KPX F ograve -25
+KPX F ohungarumlaut -25
+KPX F omacron -25
+KPX F oslash -25
+KPX F otilde -25
+KPX F period -110
+KPX J A -30
+KPX J Aacute -30
+KPX J Abreve -30
+KPX J Acircumflex -30
+KPX J Adieresis -30
+KPX J Agrave -30
+KPX J Amacron -30
+KPX J Aogonek -30
+KPX J Aring -30
+KPX J Atilde -30
+KPX J a -15
+KPX J aacute -15
+KPX J abreve -15
+KPX J acircumflex -15
+KPX J adieresis -15
+KPX J agrave -15
+KPX J amacron -15
+KPX J aogonek -15
+KPX J aring -15
+KPX J atilde -15
+KPX J e -15
+KPX J eacute -15
+KPX J ecaron -15
+KPX J ecircumflex -15
+KPX J edieresis -15
+KPX J edotaccent -15
+KPX J egrave -15
+KPX J emacron -15
+KPX J eogonek -15
+KPX J o -15
+KPX J oacute -15
+KPX J ocircumflex -15
+KPX J odieresis -15
+KPX J ograve -15
+KPX J ohungarumlaut -15
+KPX J omacron -15
+KPX J oslash -15
+KPX J otilde -15
+KPX J period -20
+KPX J u -15
+KPX J uacute -15
+KPX J ucircumflex -15
+KPX J udieresis -15
+KPX J ugrave -15
+KPX J uhungarumlaut -15
+KPX J umacron -15
+KPX J uogonek -15
+KPX J uring -15
+KPX K O -30
+KPX K Oacute -30
+KPX K Ocircumflex -30
+KPX K Odieresis -30
+KPX K Ograve -30
+KPX K Ohungarumlaut -30
+KPX K Omacron -30
+KPX K Oslash -30
+KPX K Otilde -30
+KPX K e -25
+KPX K eacute -25
+KPX K ecaron -25
+KPX K ecircumflex -25
+KPX K edieresis -25
+KPX K edotaccent -25
+KPX K egrave -25
+KPX K emacron -25
+KPX K eogonek -25
+KPX K o -25
+KPX K oacute -25
+KPX K ocircumflex -25
+KPX K odieresis -25
+KPX K ograve -25
+KPX K ohungarumlaut -25
+KPX K omacron -25
+KPX K oslash -25
+KPX K otilde -25
+KPX K u -15
+KPX K uacute -15
+KPX K ucircumflex -15
+KPX K udieresis -15
+KPX K ugrave -15
+KPX K uhungarumlaut -15
+KPX K umacron -15
+KPX K uogonek -15
+KPX K uring -15
+KPX K y -45
+KPX K yacute -45
+KPX K ydieresis -45
+KPX Kcommaaccent O -30
+KPX Kcommaaccent Oacute -30
+KPX Kcommaaccent Ocircumflex -30
+KPX Kcommaaccent Odieresis -30
+KPX Kcommaaccent Ograve -30
+KPX Kcommaaccent Ohungarumlaut -30
+KPX Kcommaaccent Omacron -30
+KPX Kcommaaccent Oslash -30
+KPX Kcommaaccent Otilde -30
+KPX Kcommaaccent e -25
+KPX Kcommaaccent eacute -25
+KPX Kcommaaccent ecaron -25
+KPX Kcommaaccent ecircumflex -25
+KPX Kcommaaccent edieresis -25
+KPX Kcommaaccent edotaccent -25
+KPX Kcommaaccent egrave -25
+KPX Kcommaaccent emacron -25
+KPX Kcommaaccent eogonek -25
+KPX Kcommaaccent o -25
+KPX Kcommaaccent oacute -25
+KPX Kcommaaccent ocircumflex -25
+KPX Kcommaaccent odieresis -25
+KPX Kcommaaccent ograve -25
+KPX Kcommaaccent ohungarumlaut -25
+KPX Kcommaaccent omacron -25
+KPX Kcommaaccent oslash -25
+KPX Kcommaaccent otilde -25
+KPX Kcommaaccent u -15
+KPX Kcommaaccent uacute -15
+KPX Kcommaaccent ucircumflex -15
+KPX Kcommaaccent udieresis -15
+KPX Kcommaaccent ugrave -15
+KPX Kcommaaccent uhungarumlaut -15
+KPX Kcommaaccent umacron -15
+KPX Kcommaaccent uogonek -15
+KPX Kcommaaccent uring -15
+KPX Kcommaaccent y -45
+KPX Kcommaaccent yacute -45
+KPX Kcommaaccent ydieresis -45
+KPX L T -92
+KPX L Tcaron -92
+KPX L Tcommaaccent -92
+KPX L V -92
+KPX L W -92
+KPX L Y -92
+KPX L Yacute -92
+KPX L Ydieresis -92
+KPX L quotedblright -20
+KPX L quoteright -110
+KPX L y -55
+KPX L yacute -55
+KPX L ydieresis -55
+KPX Lacute T -92
+KPX Lacute Tcaron -92
+KPX Lacute Tcommaaccent -92
+KPX Lacute V -92
+KPX Lacute W -92
+KPX Lacute Y -92
+KPX Lacute Yacute -92
+KPX Lacute Ydieresis -92
+KPX Lacute quotedblright -20
+KPX Lacute quoteright -110
+KPX Lacute y -55
+KPX Lacute yacute -55
+KPX Lacute ydieresis -55
+KPX Lcommaaccent T -92
+KPX Lcommaaccent Tcaron -92
+KPX Lcommaaccent Tcommaaccent -92
+KPX Lcommaaccent V -92
+KPX Lcommaaccent W -92
+KPX Lcommaaccent Y -92
+KPX Lcommaaccent Yacute -92
+KPX Lcommaaccent Ydieresis -92
+KPX Lcommaaccent quotedblright -20
+KPX Lcommaaccent quoteright -110
+KPX Lcommaaccent y -55
+KPX Lcommaaccent yacute -55
+KPX Lcommaaccent ydieresis -55
+KPX Lslash T -92
+KPX Lslash Tcaron -92
+KPX Lslash Tcommaaccent -92
+KPX Lslash V -92
+KPX Lslash W -92
+KPX Lslash Y -92
+KPX Lslash Yacute -92
+KPX Lslash Ydieresis -92
+KPX Lslash quotedblright -20
+KPX Lslash quoteright -110
+KPX Lslash y -55
+KPX Lslash yacute -55
+KPX Lslash ydieresis -55
+KPX N A -20
+KPX N Aacute -20
+KPX N Abreve -20
+KPX N Acircumflex -20
+KPX N Adieresis -20
+KPX N Agrave -20
+KPX N Amacron -20
+KPX N Aogonek -20
+KPX N Aring -20
+KPX N Atilde -20
+KPX Nacute A -20
+KPX Nacute Aacute -20
+KPX Nacute Abreve -20
+KPX Nacute Acircumflex -20
+KPX Nacute Adieresis -20
+KPX Nacute Agrave -20
+KPX Nacute Amacron -20
+KPX Nacute Aogonek -20
+KPX Nacute Aring -20
+KPX Nacute Atilde -20
+KPX Ncaron A -20
+KPX Ncaron Aacute -20
+KPX Ncaron Abreve -20
+KPX Ncaron Acircumflex -20
+KPX Ncaron Adieresis -20
+KPX Ncaron Agrave -20
+KPX Ncaron Amacron -20
+KPX Ncaron Aogonek -20
+KPX Ncaron Aring -20
+KPX Ncaron Atilde -20
+KPX Ncommaaccent A -20
+KPX Ncommaaccent Aacute -20
+KPX Ncommaaccent Abreve -20
+KPX Ncommaaccent Acircumflex -20
+KPX Ncommaaccent Adieresis -20
+KPX Ncommaaccent Agrave -20
+KPX Ncommaaccent Amacron -20
+KPX Ncommaaccent Aogonek -20
+KPX Ncommaaccent Aring -20
+KPX Ncommaaccent Atilde -20
+KPX Ntilde A -20
+KPX Ntilde Aacute -20
+KPX Ntilde Abreve -20
+KPX Ntilde Acircumflex -20
+KPX Ntilde Adieresis -20
+KPX Ntilde Agrave -20
+KPX Ntilde Amacron -20
+KPX Ntilde Aogonek -20
+KPX Ntilde Aring -20
+KPX Ntilde Atilde -20
+KPX O A -40
+KPX O Aacute -40
+KPX O Abreve -40
+KPX O Acircumflex -40
+KPX O Adieresis -40
+KPX O Agrave -40
+KPX O Amacron -40
+KPX O Aogonek -40
+KPX O Aring -40
+KPX O Atilde -40
+KPX O T -40
+KPX O Tcaron -40
+KPX O Tcommaaccent -40
+KPX O V -50
+KPX O W -50
+KPX O X -40
+KPX O Y -50
+KPX O Yacute -50
+KPX O Ydieresis -50
+KPX Oacute A -40
+KPX Oacute Aacute -40
+KPX Oacute Abreve -40
+KPX Oacute Acircumflex -40
+KPX Oacute Adieresis -40
+KPX Oacute Agrave -40
+KPX Oacute Amacron -40
+KPX Oacute Aogonek -40
+KPX Oacute Aring -40
+KPX Oacute Atilde -40
+KPX Oacute T -40
+KPX Oacute Tcaron -40
+KPX Oacute Tcommaaccent -40
+KPX Oacute V -50
+KPX Oacute W -50
+KPX Oacute X -40
+KPX Oacute Y -50
+KPX Oacute Yacute -50
+KPX Oacute Ydieresis -50
+KPX Ocircumflex A -40
+KPX Ocircumflex Aacute -40
+KPX Ocircumflex Abreve -40
+KPX Ocircumflex Acircumflex -40
+KPX Ocircumflex Adieresis -40
+KPX Ocircumflex Agrave -40
+KPX Ocircumflex Amacron -40
+KPX Ocircumflex Aogonek -40
+KPX Ocircumflex Aring -40
+KPX Ocircumflex Atilde -40
+KPX Ocircumflex T -40
+KPX Ocircumflex Tcaron -40
+KPX Ocircumflex Tcommaaccent -40
+KPX Ocircumflex V -50
+KPX Ocircumflex W -50
+KPX Ocircumflex X -40
+KPX Ocircumflex Y -50
+KPX Ocircumflex Yacute -50
+KPX Ocircumflex Ydieresis -50
+KPX Odieresis A -40
+KPX Odieresis Aacute -40
+KPX Odieresis Abreve -40
+KPX Odieresis Acircumflex -40
+KPX Odieresis Adieresis -40
+KPX Odieresis Agrave -40
+KPX Odieresis Amacron -40
+KPX Odieresis Aogonek -40
+KPX Odieresis Aring -40
+KPX Odieresis Atilde -40
+KPX Odieresis T -40
+KPX Odieresis Tcaron -40
+KPX Odieresis Tcommaaccent -40
+KPX Odieresis V -50
+KPX Odieresis W -50
+KPX Odieresis X -40
+KPX Odieresis Y -50
+KPX Odieresis Yacute -50
+KPX Odieresis Ydieresis -50
+KPX Ograve A -40
+KPX Ograve Aacute -40
+KPX Ograve Abreve -40
+KPX Ograve Acircumflex -40
+KPX Ograve Adieresis -40
+KPX Ograve Agrave -40
+KPX Ograve Amacron -40
+KPX Ograve Aogonek -40
+KPX Ograve Aring -40
+KPX Ograve Atilde -40
+KPX Ograve T -40
+KPX Ograve Tcaron -40
+KPX Ograve Tcommaaccent -40
+KPX Ograve V -50
+KPX Ograve W -50
+KPX Ograve X -40
+KPX Ograve Y -50
+KPX Ograve Yacute -50
+KPX Ograve Ydieresis -50
+KPX Ohungarumlaut A -40
+KPX Ohungarumlaut Aacute -40
+KPX Ohungarumlaut Abreve -40
+KPX Ohungarumlaut Acircumflex -40
+KPX Ohungarumlaut Adieresis -40
+KPX Ohungarumlaut Agrave -40
+KPX Ohungarumlaut Amacron -40
+KPX Ohungarumlaut Aogonek -40
+KPX Ohungarumlaut Aring -40
+KPX Ohungarumlaut Atilde -40
+KPX Ohungarumlaut T -40
+KPX Ohungarumlaut Tcaron -40
+KPX Ohungarumlaut Tcommaaccent -40
+KPX Ohungarumlaut V -50
+KPX Ohungarumlaut W -50
+KPX Ohungarumlaut X -40
+KPX Ohungarumlaut Y -50
+KPX Ohungarumlaut Yacute -50
+KPX Ohungarumlaut Ydieresis -50
+KPX Omacron A -40
+KPX Omacron Aacute -40
+KPX Omacron Abreve -40
+KPX Omacron Acircumflex -40
+KPX Omacron Adieresis -40
+KPX Omacron Agrave -40
+KPX Omacron Amacron -40
+KPX Omacron Aogonek -40
+KPX Omacron Aring -40
+KPX Omacron Atilde -40
+KPX Omacron T -40
+KPX Omacron Tcaron -40
+KPX Omacron Tcommaaccent -40
+KPX Omacron V -50
+KPX Omacron W -50
+KPX Omacron X -40
+KPX Omacron Y -50
+KPX Omacron Yacute -50
+KPX Omacron Ydieresis -50
+KPX Oslash A -40
+KPX Oslash Aacute -40
+KPX Oslash Abreve -40
+KPX Oslash Acircumflex -40
+KPX Oslash Adieresis -40
+KPX Oslash Agrave -40
+KPX Oslash Amacron -40
+KPX Oslash Aogonek -40
+KPX Oslash Aring -40
+KPX Oslash Atilde -40
+KPX Oslash T -40
+KPX Oslash Tcaron -40
+KPX Oslash Tcommaaccent -40
+KPX Oslash V -50
+KPX Oslash W -50
+KPX Oslash X -40
+KPX Oslash Y -50
+KPX Oslash Yacute -50
+KPX Oslash Ydieresis -50
+KPX Otilde A -40
+KPX Otilde Aacute -40
+KPX Otilde Abreve -40
+KPX Otilde Acircumflex -40
+KPX Otilde Adieresis -40
+KPX Otilde Agrave -40
+KPX Otilde Amacron -40
+KPX Otilde Aogonek -40
+KPX Otilde Aring -40
+KPX Otilde Atilde -40
+KPX Otilde T -40
+KPX Otilde Tcaron -40
+KPX Otilde Tcommaaccent -40
+KPX Otilde V -50
+KPX Otilde W -50
+KPX Otilde X -40
+KPX Otilde Y -50
+KPX Otilde Yacute -50
+KPX Otilde Ydieresis -50
+KPX P A -74
+KPX P Aacute -74
+KPX P Abreve -74
+KPX P Acircumflex -74
+KPX P Adieresis -74
+KPX P Agrave -74
+KPX P Amacron -74
+KPX P Aogonek -74
+KPX P Aring -74
+KPX P Atilde -74
+KPX P a -10
+KPX P aacute -10
+KPX P abreve -10
+KPX P acircumflex -10
+KPX P adieresis -10
+KPX P agrave -10
+KPX P amacron -10
+KPX P aogonek -10
+KPX P aring -10
+KPX P atilde -10
+KPX P comma -92
+KPX P e -20
+KPX P eacute -20
+KPX P ecaron -20
+KPX P ecircumflex -20
+KPX P edieresis -20
+KPX P edotaccent -20
+KPX P egrave -20
+KPX P emacron -20
+KPX P eogonek -20
+KPX P o -20
+KPX P oacute -20
+KPX P ocircumflex -20
+KPX P odieresis -20
+KPX P ograve -20
+KPX P ohungarumlaut -20
+KPX P omacron -20
+KPX P oslash -20
+KPX P otilde -20
+KPX P period -110
+KPX Q U -10
+KPX Q Uacute -10
+KPX Q Ucircumflex -10
+KPX Q Udieresis -10
+KPX Q Ugrave -10
+KPX Q Uhungarumlaut -10
+KPX Q Umacron -10
+KPX Q Uogonek -10
+KPX Q Uring -10
+KPX Q period -20
+KPX R O -30
+KPX R Oacute -30
+KPX R Ocircumflex -30
+KPX R Odieresis -30
+KPX R Ograve -30
+KPX R Ohungarumlaut -30
+KPX R Omacron -30
+KPX R Oslash -30
+KPX R Otilde -30
+KPX R T -40
+KPX R Tcaron -40
+KPX R Tcommaaccent -40
+KPX R U -30
+KPX R Uacute -30
+KPX R Ucircumflex -30
+KPX R Udieresis -30
+KPX R Ugrave -30
+KPX R Uhungarumlaut -30
+KPX R Umacron -30
+KPX R Uogonek -30
+KPX R Uring -30
+KPX R V -55
+KPX R W -35
+KPX R Y -35
+KPX R Yacute -35
+KPX R Ydieresis -35
+KPX Racute O -30
+KPX Racute Oacute -30
+KPX Racute Ocircumflex -30
+KPX Racute Odieresis -30
+KPX Racute Ograve -30
+KPX Racute Ohungarumlaut -30
+KPX Racute Omacron -30
+KPX Racute Oslash -30
+KPX Racute Otilde -30
+KPX Racute T -40
+KPX Racute Tcaron -40
+KPX Racute Tcommaaccent -40
+KPX Racute U -30
+KPX Racute Uacute -30
+KPX Racute Ucircumflex -30
+KPX Racute Udieresis -30
+KPX Racute Ugrave -30
+KPX Racute Uhungarumlaut -30
+KPX Racute Umacron -30
+KPX Racute Uogonek -30
+KPX Racute Uring -30
+KPX Racute V -55
+KPX Racute W -35
+KPX Racute Y -35
+KPX Racute Yacute -35
+KPX Racute Ydieresis -35
+KPX Rcaron O -30
+KPX Rcaron Oacute -30
+KPX Rcaron Ocircumflex -30
+KPX Rcaron Odieresis -30
+KPX Rcaron Ograve -30
+KPX Rcaron Ohungarumlaut -30
+KPX Rcaron Omacron -30
+KPX Rcaron Oslash -30
+KPX Rcaron Otilde -30
+KPX Rcaron T -40
+KPX Rcaron Tcaron -40
+KPX Rcaron Tcommaaccent -40
+KPX Rcaron U -30
+KPX Rcaron Uacute -30
+KPX Rcaron Ucircumflex -30
+KPX Rcaron Udieresis -30
+KPX Rcaron Ugrave -30
+KPX Rcaron Uhungarumlaut -30
+KPX Rcaron Umacron -30
+KPX Rcaron Uogonek -30
+KPX Rcaron Uring -30
+KPX Rcaron V -55
+KPX Rcaron W -35
+KPX Rcaron Y -35
+KPX Rcaron Yacute -35
+KPX Rcaron Ydieresis -35
+KPX Rcommaaccent O -30
+KPX Rcommaaccent Oacute -30
+KPX Rcommaaccent Ocircumflex -30
+KPX Rcommaaccent Odieresis -30
+KPX Rcommaaccent Ograve -30
+KPX Rcommaaccent Ohungarumlaut -30
+KPX Rcommaaccent Omacron -30
+KPX Rcommaaccent Oslash -30
+KPX Rcommaaccent Otilde -30
+KPX Rcommaaccent T -40
+KPX Rcommaaccent Tcaron -40
+KPX Rcommaaccent Tcommaaccent -40
+KPX Rcommaaccent U -30
+KPX Rcommaaccent Uacute -30
+KPX Rcommaaccent Ucircumflex -30
+KPX Rcommaaccent Udieresis -30
+KPX Rcommaaccent Ugrave -30
+KPX Rcommaaccent Uhungarumlaut -30
+KPX Rcommaaccent Umacron -30
+KPX Rcommaaccent Uogonek -30
+KPX Rcommaaccent Uring -30
+KPX Rcommaaccent V -55
+KPX Rcommaaccent W -35
+KPX Rcommaaccent Y -35
+KPX Rcommaaccent Yacute -35
+KPX Rcommaaccent Ydieresis -35
+KPX T A -90
+KPX T Aacute -90
+KPX T Abreve -90
+KPX T Acircumflex -90
+KPX T Adieresis -90
+KPX T Agrave -90
+KPX T Amacron -90
+KPX T Aogonek -90
+KPX T Aring -90
+KPX T Atilde -90
+KPX T O -18
+KPX T Oacute -18
+KPX T Ocircumflex -18
+KPX T Odieresis -18
+KPX T Ograve -18
+KPX T Ohungarumlaut -18
+KPX T Omacron -18
+KPX T Oslash -18
+KPX T Otilde -18
+KPX T a -92
+KPX T aacute -92
+KPX T abreve -52
+KPX T acircumflex -52
+KPX T adieresis -52
+KPX T agrave -52
+KPX T amacron -52
+KPX T aogonek -92
+KPX T aring -92
+KPX T atilde -52
+KPX T colon -74
+KPX T comma -74
+KPX T e -92
+KPX T eacute -92
+KPX T ecaron -92
+KPX T ecircumflex -92
+KPX T edieresis -52
+KPX T edotaccent -92
+KPX T egrave -52
+KPX T emacron -52
+KPX T eogonek -92
+KPX T hyphen -92
+KPX T i -18
+KPX T iacute -18
+KPX T iogonek -18
+KPX T o -92
+KPX T oacute -92
+KPX T ocircumflex -92
+KPX T odieresis -92
+KPX T ograve -92
+KPX T ohungarumlaut -92
+KPX T omacron -92
+KPX T oslash -92
+KPX T otilde -92
+KPX T period -90
+KPX T r -74
+KPX T racute -74
+KPX T rcaron -74
+KPX T rcommaaccent -74
+KPX T semicolon -74
+KPX T u -92
+KPX T uacute -92
+KPX T ucircumflex -92
+KPX T udieresis -92
+KPX T ugrave -92
+KPX T uhungarumlaut -92
+KPX T umacron -92
+KPX T uogonek -92
+KPX T uring -92
+KPX T w -74
+KPX T y -34
+KPX T yacute -34
+KPX T ydieresis -34
+KPX Tcaron A -90
+KPX Tcaron Aacute -90
+KPX Tcaron Abreve -90
+KPX Tcaron Acircumflex -90
+KPX Tcaron Adieresis -90
+KPX Tcaron Agrave -90
+KPX Tcaron Amacron -90
+KPX Tcaron Aogonek -90
+KPX Tcaron Aring -90
+KPX Tcaron Atilde -90
+KPX Tcaron O -18
+KPX Tcaron Oacute -18
+KPX Tcaron Ocircumflex -18
+KPX Tcaron Odieresis -18
+KPX Tcaron Ograve -18
+KPX Tcaron Ohungarumlaut -18
+KPX Tcaron Omacron -18
+KPX Tcaron Oslash -18
+KPX Tcaron Otilde -18
+KPX Tcaron a -92
+KPX Tcaron aacute -92
+KPX Tcaron abreve -52
+KPX Tcaron acircumflex -52
+KPX Tcaron adieresis -52
+KPX Tcaron agrave -52
+KPX Tcaron amacron -52
+KPX Tcaron aogonek -92
+KPX Tcaron aring -92
+KPX Tcaron atilde -52
+KPX Tcaron colon -74
+KPX Tcaron comma -74
+KPX Tcaron e -92
+KPX Tcaron eacute -92
+KPX Tcaron ecaron -92
+KPX Tcaron ecircumflex -92
+KPX Tcaron edieresis -52
+KPX Tcaron edotaccent -92
+KPX Tcaron egrave -52
+KPX Tcaron emacron -52
+KPX Tcaron eogonek -92
+KPX Tcaron hyphen -92
+KPX Tcaron i -18
+KPX Tcaron iacute -18
+KPX Tcaron iogonek -18
+KPX Tcaron o -92
+KPX Tcaron oacute -92
+KPX Tcaron ocircumflex -92
+KPX Tcaron odieresis -92
+KPX Tcaron ograve -92
+KPX Tcaron ohungarumlaut -92
+KPX Tcaron omacron -92
+KPX Tcaron oslash -92
+KPX Tcaron otilde -92
+KPX Tcaron period -90
+KPX Tcaron r -74
+KPX Tcaron racute -74
+KPX Tcaron rcaron -74
+KPX Tcaron rcommaaccent -74
+KPX Tcaron semicolon -74
+KPX Tcaron u -92
+KPX Tcaron uacute -92
+KPX Tcaron ucircumflex -92
+KPX Tcaron udieresis -92
+KPX Tcaron ugrave -92
+KPX Tcaron uhungarumlaut -92
+KPX Tcaron umacron -92
+KPX Tcaron uogonek -92
+KPX Tcaron uring -92
+KPX Tcaron w -74
+KPX Tcaron y -34
+KPX Tcaron yacute -34
+KPX Tcaron ydieresis -34
+KPX Tcommaaccent A -90
+KPX Tcommaaccent Aacute -90
+KPX Tcommaaccent Abreve -90
+KPX Tcommaaccent Acircumflex -90
+KPX Tcommaaccent Adieresis -90
+KPX Tcommaaccent Agrave -90
+KPX Tcommaaccent Amacron -90
+KPX Tcommaaccent Aogonek -90
+KPX Tcommaaccent Aring -90
+KPX Tcommaaccent Atilde -90
+KPX Tcommaaccent O -18
+KPX Tcommaaccent Oacute -18
+KPX Tcommaaccent Ocircumflex -18
+KPX Tcommaaccent Odieresis -18
+KPX Tcommaaccent Ograve -18
+KPX Tcommaaccent Ohungarumlaut -18
+KPX Tcommaaccent Omacron -18
+KPX Tcommaaccent Oslash -18
+KPX Tcommaaccent Otilde -18
+KPX Tcommaaccent a -92
+KPX Tcommaaccent aacute -92
+KPX Tcommaaccent abreve -52
+KPX Tcommaaccent acircumflex -52
+KPX Tcommaaccent adieresis -52
+KPX Tcommaaccent agrave -52
+KPX Tcommaaccent amacron -52
+KPX Tcommaaccent aogonek -92
+KPX Tcommaaccent aring -92
+KPX Tcommaaccent atilde -52
+KPX Tcommaaccent colon -74
+KPX Tcommaaccent comma -74
+KPX Tcommaaccent e -92
+KPX Tcommaaccent eacute -92
+KPX Tcommaaccent ecaron -92
+KPX Tcommaaccent ecircumflex -92
+KPX Tcommaaccent edieresis -52
+KPX Tcommaaccent edotaccent -92
+KPX Tcommaaccent egrave -52
+KPX Tcommaaccent emacron -52
+KPX Tcommaaccent eogonek -92
+KPX Tcommaaccent hyphen -92
+KPX Tcommaaccent i -18
+KPX Tcommaaccent iacute -18
+KPX Tcommaaccent iogonek -18
+KPX Tcommaaccent o -92
+KPX Tcommaaccent oacute -92
+KPX Tcommaaccent ocircumflex -92
+KPX Tcommaaccent odieresis -92
+KPX Tcommaaccent ograve -92
+KPX Tcommaaccent ohungarumlaut -92
+KPX Tcommaaccent omacron -92
+KPX Tcommaaccent oslash -92
+KPX Tcommaaccent otilde -92
+KPX Tcommaaccent period -90
+KPX Tcommaaccent r -74
+KPX Tcommaaccent racute -74
+KPX Tcommaaccent rcaron -74
+KPX Tcommaaccent rcommaaccent -74
+KPX Tcommaaccent semicolon -74
+KPX Tcommaaccent u -92
+KPX Tcommaaccent uacute -92
+KPX Tcommaaccent ucircumflex -92
+KPX Tcommaaccent udieresis -92
+KPX Tcommaaccent ugrave -92
+KPX Tcommaaccent uhungarumlaut -92
+KPX Tcommaaccent umacron -92
+KPX Tcommaaccent uogonek -92
+KPX Tcommaaccent uring -92
+KPX Tcommaaccent w -74
+KPX Tcommaaccent y -34
+KPX Tcommaaccent yacute -34
+KPX Tcommaaccent ydieresis -34
+KPX U A -60
+KPX U Aacute -60
+KPX U Abreve -60
+KPX U Acircumflex -60
+KPX U Adieresis -60
+KPX U Agrave -60
+KPX U Amacron -60
+KPX U Aogonek -60
+KPX U Aring -60
+KPX U Atilde -60
+KPX U comma -50
+KPX U period -50
+KPX Uacute A -60
+KPX Uacute Aacute -60
+KPX Uacute Abreve -60
+KPX Uacute Acircumflex -60
+KPX Uacute Adieresis -60
+KPX Uacute Agrave -60
+KPX Uacute Amacron -60
+KPX Uacute Aogonek -60
+KPX Uacute Aring -60
+KPX Uacute Atilde -60
+KPX Uacute comma -50
+KPX Uacute period -50
+KPX Ucircumflex A -60
+KPX Ucircumflex Aacute -60
+KPX Ucircumflex Abreve -60
+KPX Ucircumflex Acircumflex -60
+KPX Ucircumflex Adieresis -60
+KPX Ucircumflex Agrave -60
+KPX Ucircumflex Amacron -60
+KPX Ucircumflex Aogonek -60
+KPX Ucircumflex Aring -60
+KPX Ucircumflex Atilde -60
+KPX Ucircumflex comma -50
+KPX Ucircumflex period -50
+KPX Udieresis A -60
+KPX Udieresis Aacute -60
+KPX Udieresis Abreve -60
+KPX Udieresis Acircumflex -60
+KPX Udieresis Adieresis -60
+KPX Udieresis Agrave -60
+KPX Udieresis Amacron -60
+KPX Udieresis Aogonek -60
+KPX Udieresis Aring -60
+KPX Udieresis Atilde -60
+KPX Udieresis comma -50
+KPX Udieresis period -50
+KPX Ugrave A -60
+KPX Ugrave Aacute -60
+KPX Ugrave Abreve -60
+KPX Ugrave Acircumflex -60
+KPX Ugrave Adieresis -60
+KPX Ugrave Agrave -60
+KPX Ugrave Amacron -60
+KPX Ugrave Aogonek -60
+KPX Ugrave Aring -60
+KPX Ugrave Atilde -60
+KPX Ugrave comma -50
+KPX Ugrave period -50
+KPX Uhungarumlaut A -60
+KPX Uhungarumlaut Aacute -60
+KPX Uhungarumlaut Abreve -60
+KPX Uhungarumlaut Acircumflex -60
+KPX Uhungarumlaut Adieresis -60
+KPX Uhungarumlaut Agrave -60
+KPX Uhungarumlaut Amacron -60
+KPX Uhungarumlaut Aogonek -60
+KPX Uhungarumlaut Aring -60
+KPX Uhungarumlaut Atilde -60
+KPX Uhungarumlaut comma -50
+KPX Uhungarumlaut period -50
+KPX Umacron A -60
+KPX Umacron Aacute -60
+KPX Umacron Abreve -60
+KPX Umacron Acircumflex -60
+KPX Umacron Adieresis -60
+KPX Umacron Agrave -60
+KPX Umacron Amacron -60
+KPX Umacron Aogonek -60
+KPX Umacron Aring -60
+KPX Umacron Atilde -60
+KPX Umacron comma -50
+KPX Umacron period -50
+KPX Uogonek A -60
+KPX Uogonek Aacute -60
+KPX Uogonek Abreve -60
+KPX Uogonek Acircumflex -60
+KPX Uogonek Adieresis -60
+KPX Uogonek Agrave -60
+KPX Uogonek Amacron -60
+KPX Uogonek Aogonek -60
+KPX Uogonek Aring -60
+KPX Uogonek Atilde -60
+KPX Uogonek comma -50
+KPX Uogonek period -50
+KPX Uring A -60
+KPX Uring Aacute -60
+KPX Uring Abreve -60
+KPX Uring Acircumflex -60
+KPX Uring Adieresis -60
+KPX Uring Agrave -60
+KPX Uring Amacron -60
+KPX Uring Aogonek -60
+KPX Uring Aring -60
+KPX Uring Atilde -60
+KPX Uring comma -50
+KPX Uring period -50
+KPX V A -135
+KPX V Aacute -135
+KPX V Abreve -135
+KPX V Acircumflex -135
+KPX V Adieresis -135
+KPX V Agrave -135
+KPX V Amacron -135
+KPX V Aogonek -135
+KPX V Aring -135
+KPX V Atilde -135
+KPX V G -30
+KPX V Gbreve -30
+KPX V Gcommaaccent -30
+KPX V O -45
+KPX V Oacute -45
+KPX V Ocircumflex -45
+KPX V Odieresis -45
+KPX V Ograve -45
+KPX V Ohungarumlaut -45
+KPX V Omacron -45
+KPX V Oslash -45
+KPX V Otilde -45
+KPX V a -92
+KPX V aacute -92
+KPX V abreve -92
+KPX V acircumflex -92
+KPX V adieresis -92
+KPX V agrave -92
+KPX V amacron -92
+KPX V aogonek -92
+KPX V aring -92
+KPX V atilde -92
+KPX V colon -92
+KPX V comma -129
+KPX V e -100
+KPX V eacute -100
+KPX V ecaron -100
+KPX V ecircumflex -100
+KPX V edieresis -100
+KPX V edotaccent -100
+KPX V egrave -100
+KPX V emacron -100
+KPX V eogonek -100
+KPX V hyphen -74
+KPX V i -37
+KPX V iacute -37
+KPX V icircumflex -37
+KPX V idieresis -37
+KPX V igrave -37
+KPX V imacron -37
+KPX V iogonek -37
+KPX V o -100
+KPX V oacute -100
+KPX V ocircumflex -100
+KPX V odieresis -100
+KPX V ograve -100
+KPX V ohungarumlaut -100
+KPX V omacron -100
+KPX V oslash -100
+KPX V otilde -100
+KPX V period -145
+KPX V semicolon -92
+KPX V u -92
+KPX V uacute -92
+KPX V ucircumflex -92
+KPX V udieresis -92
+KPX V ugrave -92
+KPX V uhungarumlaut -92
+KPX V umacron -92
+KPX V uogonek -92
+KPX V uring -92
+KPX W A -120
+KPX W Aacute -120
+KPX W Abreve -120
+KPX W Acircumflex -120
+KPX W Adieresis -120
+KPX W Agrave -120
+KPX W Amacron -120
+KPX W Aogonek -120
+KPX W Aring -120
+KPX W Atilde -120
+KPX W O -10
+KPX W Oacute -10
+KPX W Ocircumflex -10
+KPX W Odieresis -10
+KPX W Ograve -10
+KPX W Ohungarumlaut -10
+KPX W Omacron -10
+KPX W Oslash -10
+KPX W Otilde -10
+KPX W a -65
+KPX W aacute -65
+KPX W abreve -65
+KPX W acircumflex -65
+KPX W adieresis -65
+KPX W agrave -65
+KPX W amacron -65
+KPX W aogonek -65
+KPX W aring -65
+KPX W atilde -65
+KPX W colon -55
+KPX W comma -92
+KPX W e -65
+KPX W eacute -65
+KPX W ecaron -65
+KPX W ecircumflex -65
+KPX W edieresis -65
+KPX W edotaccent -65
+KPX W egrave -65
+KPX W emacron -65
+KPX W eogonek -65
+KPX W hyphen -37
+KPX W i -18
+KPX W iacute -18
+KPX W iogonek -18
+KPX W o -75
+KPX W oacute -75
+KPX W ocircumflex -75
+KPX W odieresis -75
+KPX W ograve -75
+KPX W ohungarumlaut -75
+KPX W omacron -75
+KPX W oslash -75
+KPX W otilde -75
+KPX W period -92
+KPX W semicolon -55
+KPX W u -50
+KPX W uacute -50
+KPX W ucircumflex -50
+KPX W udieresis -50
+KPX W ugrave -50
+KPX W uhungarumlaut -50
+KPX W umacron -50
+KPX W uogonek -50
+KPX W uring -50
+KPX W y -60
+KPX W yacute -60
+KPX W ydieresis -60
+KPX Y A -110
+KPX Y Aacute -110
+KPX Y Abreve -110
+KPX Y Acircumflex -110
+KPX Y Adieresis -110
+KPX Y Agrave -110
+KPX Y Amacron -110
+KPX Y Aogonek -110
+KPX Y Aring -110
+KPX Y Atilde -110
+KPX Y O -35
+KPX Y Oacute -35
+KPX Y Ocircumflex -35
+KPX Y Odieresis -35
+KPX Y Ograve -35
+KPX Y Ohungarumlaut -35
+KPX Y Omacron -35
+KPX Y Oslash -35
+KPX Y Otilde -35
+KPX Y a -85
+KPX Y aacute -85
+KPX Y abreve -85
+KPX Y acircumflex -85
+KPX Y adieresis -85
+KPX Y agrave -85
+KPX Y amacron -85
+KPX Y aogonek -85
+KPX Y aring -85
+KPX Y atilde -85
+KPX Y colon -92
+KPX Y comma -92
+KPX Y e -111
+KPX Y eacute -111
+KPX Y ecaron -111
+KPX Y ecircumflex -111
+KPX Y edieresis -71
+KPX Y edotaccent -111
+KPX Y egrave -71
+KPX Y emacron -71
+KPX Y eogonek -111
+KPX Y hyphen -92
+KPX Y i -37
+KPX Y iacute -37
+KPX Y iogonek -37
+KPX Y o -111
+KPX Y oacute -111
+KPX Y ocircumflex -111
+KPX Y odieresis -111
+KPX Y ograve -111
+KPX Y ohungarumlaut -111
+KPX Y omacron -111
+KPX Y oslash -111
+KPX Y otilde -111
+KPX Y period -92
+KPX Y semicolon -92
+KPX Y u -92
+KPX Y uacute -92
+KPX Y ucircumflex -92
+KPX Y udieresis -92
+KPX Y ugrave -92
+KPX Y uhungarumlaut -92
+KPX Y umacron -92
+KPX Y uogonek -92
+KPX Y uring -92
+KPX Yacute A -110
+KPX Yacute Aacute -110
+KPX Yacute Abreve -110
+KPX Yacute Acircumflex -110
+KPX Yacute Adieresis -110
+KPX Yacute Agrave -110
+KPX Yacute Amacron -110
+KPX Yacute Aogonek -110
+KPX Yacute Aring -110
+KPX Yacute Atilde -110
+KPX Yacute O -35
+KPX Yacute Oacute -35
+KPX Yacute Ocircumflex -35
+KPX Yacute Odieresis -35
+KPX Yacute Ograve -35
+KPX Yacute Ohungarumlaut -35
+KPX Yacute Omacron -35
+KPX Yacute Oslash -35
+KPX Yacute Otilde -35
+KPX Yacute a -85
+KPX Yacute aacute -85
+KPX Yacute abreve -85
+KPX Yacute acircumflex -85
+KPX Yacute adieresis -85
+KPX Yacute agrave -85
+KPX Yacute amacron -85
+KPX Yacute aogonek -85
+KPX Yacute aring -85
+KPX Yacute atilde -85
+KPX Yacute colon -92
+KPX Yacute comma -92
+KPX Yacute e -111
+KPX Yacute eacute -111
+KPX Yacute ecaron -111
+KPX Yacute ecircumflex -111
+KPX Yacute edieresis -71
+KPX Yacute edotaccent -111
+KPX Yacute egrave -71
+KPX Yacute emacron -71
+KPX Yacute eogonek -111
+KPX Yacute hyphen -92
+KPX Yacute i -37
+KPX Yacute iacute -37
+KPX Yacute iogonek -37
+KPX Yacute o -111
+KPX Yacute oacute -111
+KPX Yacute ocircumflex -111
+KPX Yacute odieresis -111
+KPX Yacute ograve -111
+KPX Yacute ohungarumlaut -111
+KPX Yacute omacron -111
+KPX Yacute oslash -111
+KPX Yacute otilde -111
+KPX Yacute period -92
+KPX Yacute semicolon -92
+KPX Yacute u -92
+KPX Yacute uacute -92
+KPX Yacute ucircumflex -92
+KPX Yacute udieresis -92
+KPX Yacute ugrave -92
+KPX Yacute uhungarumlaut -92
+KPX Yacute umacron -92
+KPX Yacute uogonek -92
+KPX Yacute uring -92
+KPX Ydieresis A -110
+KPX Ydieresis Aacute -110
+KPX Ydieresis Abreve -110
+KPX Ydieresis Acircumflex -110
+KPX Ydieresis Adieresis -110
+KPX Ydieresis Agrave -110
+KPX Ydieresis Amacron -110
+KPX Ydieresis Aogonek -110
+KPX Ydieresis Aring -110
+KPX Ydieresis Atilde -110
+KPX Ydieresis O -35
+KPX Ydieresis Oacute -35
+KPX Ydieresis Ocircumflex -35
+KPX Ydieresis Odieresis -35
+KPX Ydieresis Ograve -35
+KPX Ydieresis Ohungarumlaut -35
+KPX Ydieresis Omacron -35
+KPX Ydieresis Oslash -35
+KPX Ydieresis Otilde -35
+KPX Ydieresis a -85
+KPX Ydieresis aacute -85
+KPX Ydieresis abreve -85
+KPX Ydieresis acircumflex -85
+KPX Ydieresis adieresis -85
+KPX Ydieresis agrave -85
+KPX Ydieresis amacron -85
+KPX Ydieresis aogonek -85
+KPX Ydieresis aring -85
+KPX Ydieresis atilde -85
+KPX Ydieresis colon -92
+KPX Ydieresis comma -92
+KPX Ydieresis e -111
+KPX Ydieresis eacute -111
+KPX Ydieresis ecaron -111
+KPX Ydieresis ecircumflex -111
+KPX Ydieresis edieresis -71
+KPX Ydieresis edotaccent -111
+KPX Ydieresis egrave -71
+KPX Ydieresis emacron -71
+KPX Ydieresis eogonek -111
+KPX Ydieresis hyphen -92
+KPX Ydieresis i -37
+KPX Ydieresis iacute -37
+KPX Ydieresis iogonek -37
+KPX Ydieresis o -111
+KPX Ydieresis oacute -111
+KPX Ydieresis ocircumflex -111
+KPX Ydieresis odieresis -111
+KPX Ydieresis ograve -111
+KPX Ydieresis ohungarumlaut -111
+KPX Ydieresis omacron -111
+KPX Ydieresis oslash -111
+KPX Ydieresis otilde -111
+KPX Ydieresis period -92
+KPX Ydieresis semicolon -92
+KPX Ydieresis u -92
+KPX Ydieresis uacute -92
+KPX Ydieresis ucircumflex -92
+KPX Ydieresis udieresis -92
+KPX Ydieresis ugrave -92
+KPX Ydieresis uhungarumlaut -92
+KPX Ydieresis umacron -92
+KPX Ydieresis uogonek -92
+KPX Ydieresis uring -92
+KPX a v -25
+KPX aacute v -25
+KPX abreve v -25
+KPX acircumflex v -25
+KPX adieresis v -25
+KPX agrave v -25
+KPX amacron v -25
+KPX aogonek v -25
+KPX aring v -25
+KPX atilde v -25
+KPX b b -10
+KPX b period -40
+KPX b u -20
+KPX b uacute -20
+KPX b ucircumflex -20
+KPX b udieresis -20
+KPX b ugrave -20
+KPX b uhungarumlaut -20
+KPX b umacron -20
+KPX b uogonek -20
+KPX b uring -20
+KPX b v -15
+KPX comma quotedblright -45
+KPX comma quoteright -55
+KPX d w -15
+KPX dcroat w -15
+KPX e v -15
+KPX eacute v -15
+KPX ecaron v -15
+KPX ecircumflex v -15
+KPX edieresis v -15
+KPX edotaccent v -15
+KPX egrave v -15
+KPX emacron v -15
+KPX eogonek v -15
+KPX f comma -15
+KPX f dotlessi -35
+KPX f i -25
+KPX f o -25
+KPX f oacute -25
+KPX f ocircumflex -25
+KPX f odieresis -25
+KPX f ograve -25
+KPX f ohungarumlaut -25
+KPX f omacron -25
+KPX f oslash -25
+KPX f otilde -25
+KPX f period -15
+KPX f quotedblright 50
+KPX f quoteright 55
+KPX g period -15
+KPX gbreve period -15
+KPX gcommaaccent period -15
+KPX h y -15
+KPX h yacute -15
+KPX h ydieresis -15
+KPX i v -10
+KPX iacute v -10
+KPX icircumflex v -10
+KPX idieresis v -10
+KPX igrave v -10
+KPX imacron v -10
+KPX iogonek v -10
+KPX k e -10
+KPX k eacute -10
+KPX k ecaron -10
+KPX k ecircumflex -10
+KPX k edieresis -10
+KPX k edotaccent -10
+KPX k egrave -10
+KPX k emacron -10
+KPX k eogonek -10
+KPX k o -15
+KPX k oacute -15
+KPX k ocircumflex -15
+KPX k odieresis -15
+KPX k ograve -15
+KPX k ohungarumlaut -15
+KPX k omacron -15
+KPX k oslash -15
+KPX k otilde -15
+KPX k y -15
+KPX k yacute -15
+KPX k ydieresis -15
+KPX kcommaaccent e -10
+KPX kcommaaccent eacute -10
+KPX kcommaaccent ecaron -10
+KPX kcommaaccent ecircumflex -10
+KPX kcommaaccent edieresis -10
+KPX kcommaaccent edotaccent -10
+KPX kcommaaccent egrave -10
+KPX kcommaaccent emacron -10
+KPX kcommaaccent eogonek -10
+KPX kcommaaccent o -15
+KPX kcommaaccent oacute -15
+KPX kcommaaccent ocircumflex -15
+KPX kcommaaccent odieresis -15
+KPX kcommaaccent ograve -15
+KPX kcommaaccent ohungarumlaut -15
+KPX kcommaaccent omacron -15
+KPX kcommaaccent oslash -15
+KPX kcommaaccent otilde -15
+KPX kcommaaccent y -15
+KPX kcommaaccent yacute -15
+KPX kcommaaccent ydieresis -15
+KPX n v -40
+KPX nacute v -40
+KPX ncaron v -40
+KPX ncommaaccent v -40
+KPX ntilde v -40
+KPX o v -10
+KPX o w -10
+KPX oacute v -10
+KPX oacute w -10
+KPX ocircumflex v -10
+KPX ocircumflex w -10
+KPX odieresis v -10
+KPX odieresis w -10
+KPX ograve v -10
+KPX ograve w -10
+KPX ohungarumlaut v -10
+KPX ohungarumlaut w -10
+KPX omacron v -10
+KPX omacron w -10
+KPX oslash v -10
+KPX oslash w -10
+KPX otilde v -10
+KPX otilde w -10
+KPX period quotedblright -55
+KPX period quoteright -55
+KPX quotedblleft A -10
+KPX quotedblleft Aacute -10
+KPX quotedblleft Abreve -10
+KPX quotedblleft Acircumflex -10
+KPX quotedblleft Adieresis -10
+KPX quotedblleft Agrave -10
+KPX quotedblleft Amacron -10
+KPX quotedblleft Aogonek -10
+KPX quotedblleft Aring -10
+KPX quotedblleft Atilde -10
+KPX quoteleft A -10
+KPX quoteleft Aacute -10
+KPX quoteleft Abreve -10
+KPX quoteleft Acircumflex -10
+KPX quoteleft Adieresis -10
+KPX quoteleft Agrave -10
+KPX quoteleft Amacron -10
+KPX quoteleft Aogonek -10
+KPX quoteleft Aring -10
+KPX quoteleft Atilde -10
+KPX quoteleft quoteleft -63
+KPX quoteright d -20
+KPX quoteright dcroat -20
+KPX quoteright quoteright -63
+KPX quoteright r -20
+KPX quoteright racute -20
+KPX quoteright rcaron -20
+KPX quoteright rcommaaccent -20
+KPX quoteright s -37
+KPX quoteright sacute -37
+KPX quoteright scaron -37
+KPX quoteright scedilla -37
+KPX quoteright scommaaccent -37
+KPX quoteright space -74
+KPX quoteright v -20
+KPX r c -18
+KPX r cacute -18
+KPX r ccaron -18
+KPX r ccedilla -18
+KPX r comma -92
+KPX r e -18
+KPX r eacute -18
+KPX r ecaron -18
+KPX r ecircumflex -18
+KPX r edieresis -18
+KPX r edotaccent -18
+KPX r egrave -18
+KPX r emacron -18
+KPX r eogonek -18
+KPX r g -10
+KPX r gbreve -10
+KPX r gcommaaccent -10
+KPX r hyphen -37
+KPX r n -15
+KPX r nacute -15
+KPX r ncaron -15
+KPX r ncommaaccent -15
+KPX r ntilde -15
+KPX r o -18
+KPX r oacute -18
+KPX r ocircumflex -18
+KPX r odieresis -18
+KPX r ograve -18
+KPX r ohungarumlaut -18
+KPX r omacron -18
+KPX r oslash -18
+KPX r otilde -18
+KPX r p -10
+KPX r period -100
+KPX r q -18
+KPX r v -10
+KPX racute c -18
+KPX racute cacute -18
+KPX racute ccaron -18
+KPX racute ccedilla -18
+KPX racute comma -92
+KPX racute e -18
+KPX racute eacute -18
+KPX racute ecaron -18
+KPX racute ecircumflex -18
+KPX racute edieresis -18
+KPX racute edotaccent -18
+KPX racute egrave -18
+KPX racute emacron -18
+KPX racute eogonek -18
+KPX racute g -10
+KPX racute gbreve -10
+KPX racute gcommaaccent -10
+KPX racute hyphen -37
+KPX racute n -15
+KPX racute nacute -15
+KPX racute ncaron -15
+KPX racute ncommaaccent -15
+KPX racute ntilde -15
+KPX racute o -18
+KPX racute oacute -18
+KPX racute ocircumflex -18
+KPX racute odieresis -18
+KPX racute ograve -18
+KPX racute ohungarumlaut -18
+KPX racute omacron -18
+KPX racute oslash -18
+KPX racute otilde -18
+KPX racute p -10
+KPX racute period -100
+KPX racute q -18
+KPX racute v -10
+KPX rcaron c -18
+KPX rcaron cacute -18
+KPX rcaron ccaron -18
+KPX rcaron ccedilla -18
+KPX rcaron comma -92
+KPX rcaron e -18
+KPX rcaron eacute -18
+KPX rcaron ecaron -18
+KPX rcaron ecircumflex -18
+KPX rcaron edieresis -18
+KPX rcaron edotaccent -18
+KPX rcaron egrave -18
+KPX rcaron emacron -18
+KPX rcaron eogonek -18
+KPX rcaron g -10
+KPX rcaron gbreve -10
+KPX rcaron gcommaaccent -10
+KPX rcaron hyphen -37
+KPX rcaron n -15
+KPX rcaron nacute -15
+KPX rcaron ncaron -15
+KPX rcaron ncommaaccent -15
+KPX rcaron ntilde -15
+KPX rcaron o -18
+KPX rcaron oacute -18
+KPX rcaron ocircumflex -18
+KPX rcaron odieresis -18
+KPX rcaron ograve -18
+KPX rcaron ohungarumlaut -18
+KPX rcaron omacron -18
+KPX rcaron oslash -18
+KPX rcaron otilde -18
+KPX rcaron p -10
+KPX rcaron period -100
+KPX rcaron q -18
+KPX rcaron v -10
+KPX rcommaaccent c -18
+KPX rcommaaccent cacute -18
+KPX rcommaaccent ccaron -18
+KPX rcommaaccent ccedilla -18
+KPX rcommaaccent comma -92
+KPX rcommaaccent e -18
+KPX rcommaaccent eacute -18
+KPX rcommaaccent ecaron -18
+KPX rcommaaccent ecircumflex -18
+KPX rcommaaccent edieresis -18
+KPX rcommaaccent edotaccent -18
+KPX rcommaaccent egrave -18
+KPX rcommaaccent emacron -18
+KPX rcommaaccent eogonek -18
+KPX rcommaaccent g -10
+KPX rcommaaccent gbreve -10
+KPX rcommaaccent gcommaaccent -10
+KPX rcommaaccent hyphen -37
+KPX rcommaaccent n -15
+KPX rcommaaccent nacute -15
+KPX rcommaaccent ncaron -15
+KPX rcommaaccent ncommaaccent -15
+KPX rcommaaccent ntilde -15
+KPX rcommaaccent o -18
+KPX rcommaaccent oacute -18
+KPX rcommaaccent ocircumflex -18
+KPX rcommaaccent odieresis -18
+KPX rcommaaccent ograve -18
+KPX rcommaaccent ohungarumlaut -18
+KPX rcommaaccent omacron -18
+KPX rcommaaccent oslash -18
+KPX rcommaaccent otilde -18
+KPX rcommaaccent p -10
+KPX rcommaaccent period -100
+KPX rcommaaccent q -18
+KPX rcommaaccent v -10
+KPX space A -55
+KPX space Aacute -55
+KPX space Abreve -55
+KPX space Acircumflex -55
+KPX space Adieresis -55
+KPX space Agrave -55
+KPX space Amacron -55
+KPX space Aogonek -55
+KPX space Aring -55
+KPX space Atilde -55
+KPX space T -30
+KPX space Tcaron -30
+KPX space Tcommaaccent -30
+KPX space V -45
+KPX space W -30
+KPX space Y -55
+KPX space Yacute -55
+KPX space Ydieresis -55
+KPX v a -10
+KPX v aacute -10
+KPX v abreve -10
+KPX v acircumflex -10
+KPX v adieresis -10
+KPX v agrave -10
+KPX v amacron -10
+KPX v aogonek -10
+KPX v aring -10
+KPX v atilde -10
+KPX v comma -55
+KPX v e -10
+KPX v eacute -10
+KPX v ecaron -10
+KPX v ecircumflex -10
+KPX v edieresis -10
+KPX v edotaccent -10
+KPX v egrave -10
+KPX v emacron -10
+KPX v eogonek -10
+KPX v o -10
+KPX v oacute -10
+KPX v ocircumflex -10
+KPX v odieresis -10
+KPX v ograve -10
+KPX v ohungarumlaut -10
+KPX v omacron -10
+KPX v oslash -10
+KPX v otilde -10
+KPX v period -70
+KPX w comma -55
+KPX w o -10
+KPX w oacute -10
+KPX w ocircumflex -10
+KPX w odieresis -10
+KPX w ograve -10
+KPX w ohungarumlaut -10
+KPX w omacron -10
+KPX w oslash -10
+KPX w otilde -10
+KPX w period -70
+KPX y comma -55
+KPX y e -10
+KPX y eacute -10
+KPX y ecaron -10
+KPX y ecircumflex -10
+KPX y edieresis -10
+KPX y edotaccent -10
+KPX y egrave -10
+KPX y emacron -10
+KPX y eogonek -10
+KPX y o -25
+KPX y oacute -25
+KPX y ocircumflex -25
+KPX y odieresis -25
+KPX y ograve -25
+KPX y ohungarumlaut -25
+KPX y omacron -25
+KPX y oslash -25
+KPX y otilde -25
+KPX y period -70
+KPX yacute comma -55
+KPX yacute e -10
+KPX yacute eacute -10
+KPX yacute ecaron -10
+KPX yacute ecircumflex -10
+KPX yacute edieresis -10
+KPX yacute edotaccent -10
+KPX yacute egrave -10
+KPX yacute emacron -10
+KPX yacute eogonek -10
+KPX yacute o -25
+KPX yacute oacute -25
+KPX yacute ocircumflex -25
+KPX yacute odieresis -25
+KPX yacute ograve -25
+KPX yacute ohungarumlaut -25
+KPX yacute omacron -25
+KPX yacute oslash -25
+KPX yacute otilde -25
+KPX yacute period -70
+KPX ydieresis comma -55
+KPX ydieresis e -10
+KPX ydieresis eacute -10
+KPX ydieresis ecaron -10
+KPX ydieresis ecircumflex -10
+KPX ydieresis edieresis -10
+KPX ydieresis edotaccent -10
+KPX ydieresis egrave -10
+KPX ydieresis emacron -10
+KPX ydieresis eogonek -10
+KPX ydieresis o -25
+KPX ydieresis oacute -25
+KPX ydieresis ocircumflex -25
+KPX ydieresis odieresis -25
+KPX ydieresis ograve -25
+KPX ydieresis ohungarumlaut -25
+KPX ydieresis omacron -25
+KPX ydieresis oslash -25
+KPX ydieresis otilde -25
+KPX ydieresis period -70
+EndKernPairs
+EndKernData
+EndFontMetrics
Added: trunk/mapbender/http/classes/fonts/ZapfDingbats.afm
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/fonts/ZapfDingbats.afm?view=auto&rev=54
--- (empty file)
+++ trunk/mapbender/http/classes/fonts/ZapfDingbats.afm	2006-04-13 21:05:53+0000
@@ -0,0 +1,225 @@
+StartFontMetrics 4.1
+Comment Copyright (c) 1985, 1987, 1988, 1989, 1997 Adobe Systems Incorporated. All Rights Reserved.
+Comment Creation Date: Thu May  1 15:14:13 1997
+Comment UniqueID 43082
+Comment VMusage 45775 55535
+FontName ZapfDingbats
+FullName ITC Zapf Dingbats
+FamilyName ZapfDingbats
+Weight Medium
+ItalicAngle 0
+IsFixedPitch false
+CharacterSet Special
+FontBBox -1 -143 981 820
+UnderlinePosition -100
+UnderlineThickness 50
+Version 002.000
+Notice Copyright (c) 1985, 1987, 1988, 1989, 1997 Adobe Systems Incorporated. All Rights Reserved.ITC Zapf Dingbats is a registered trademark of International Typeface Corporation.
+EncodingScheme FontSpecific
+StdHW 28
+StdVW 90
+StartCharMetrics 202
+C 32 ; WX 278 ; N space ; B 0 0 0 0 ;
+C 33 ; WX 974 ; N a1 ; B 35 72 939 621 ;
+C 34 ; WX 961 ; N a2 ; B 35 81 927 611 ;
+C 35 ; WX 974 ; N a202 ; B 35 72 939 621 ;
+C 36 ; WX 980 ; N a3 ; B 35 0 945 692 ;
+C 37 ; WX 719 ; N a4 ; B 34 139 685 566 ;
+C 38 ; WX 789 ; N a5 ; B 35 -14 755 705 ;
+C 39 ; WX 790 ; N a119 ; B 35 -14 755 705 ;
+C 40 ; WX 791 ; N a118 ; B 35 -13 761 705 ;
+C 41 ; WX 690 ; N a117 ; B 34 138 655 553 ;
+C 42 ; WX 960 ; N a11 ; B 35 123 925 568 ;
+C 43 ; WX 939 ; N a12 ; B 35 134 904 559 ;
+C 44 ; WX 549 ; N a13 ; B 29 -11 516 705 ;
+C 45 ; WX 855 ; N a14 ; B 34 59 820 632 ;
+C 46 ; WX 911 ; N a15 ; B 35 50 876 642 ;
+C 47 ; WX 933 ; N a16 ; B 35 139 899 550 ;
+C 48 ; WX 911 ; N a105 ; B 35 50 876 642 ;
+C 49 ; WX 945 ; N a17 ; B 35 139 909 553 ;
+C 50 ; WX 974 ; N a18 ; B 35 104 938 587 ;
+C 51 ; WX 755 ; N a19 ; B 34 -13 721 705 ;
+C 52 ; WX 846 ; N a20 ; B 36 -14 811 705 ;
+C 53 ; WX 762 ; N a21 ; B 35 0 727 692 ;
+C 54 ; WX 761 ; N a22 ; B 35 0 727 692 ;
+C 55 ; WX 571 ; N a23 ; B -1 -68 571 661 ;
+C 56 ; WX 677 ; N a24 ; B 36 -13 642 705 ;
+C 57 ; WX 763 ; N a25 ; B 35 0 728 692 ;
+C 58 ; WX 760 ; N a26 ; B 35 0 726 692 ;
+C 59 ; WX 759 ; N a27 ; B 35 0 725 692 ;
+C 60 ; WX 754 ; N a28 ; B 35 0 720 692 ;
+C 61 ; WX 494 ; N a6 ; B 35 0 460 692 ;
+C 62 ; WX 552 ; N a7 ; B 35 0 517 692 ;
+C 63 ; WX 537 ; N a8 ; B 35 0 503 692 ;
+C 64 ; WX 577 ; N a9 ; B 35 96 542 596 ;
+C 65 ; WX 692 ; N a10 ; B 35 -14 657 705 ;
+C 66 ; WX 786 ; N a29 ; B 35 -14 751 705 ;
+C 67 ; WX 788 ; N a30 ; B 35 -14 752 705 ;
+C 68 ; WX 788 ; N a31 ; B 35 -14 753 705 ;
+C 69 ; WX 790 ; N a32 ; B 35 -14 756 705 ;
+C 70 ; WX 793 ; N a33 ; B 35 -13 759 705 ;
+C 71 ; WX 794 ; N a34 ; B 35 -13 759 705 ;
+C 72 ; WX 816 ; N a35 ; B 35 -14 782 705 ;
+C 73 ; WX 823 ; N a36 ; B 35 -14 787 705 ;
+C 74 ; WX 789 ; N a37 ; B 35 -14 754 705 ;
+C 75 ; WX 841 ; N a38 ; B 35 -14 807 705 ;
+C 76 ; WX 823 ; N a39 ; B 35 -14 789 705 ;
+C 77 ; WX 833 ; N a40 ; B 35 -14 798 705 ;
+C 78 ; WX 816 ; N a41 ; B 35 -13 782 705 ;
+C 79 ; WX 831 ; N a42 ; B 35 -14 796 705 ;
+C 80 ; WX 923 ; N a43 ; B 35 -14 888 705 ;
+C 81 ; WX 744 ; N a44 ; B 35 0 710 692 ;
+C 82 ; WX 723 ; N a45 ; B 35 0 688 692 ;
+C 83 ; WX 749 ; N a46 ; B 35 0 714 692 ;
+C 84 ; WX 790 ; N a47 ; B 34 -14 756 705 ;
+C 85 ; WX 792 ; N a48 ; B 35 -14 758 705 ;
+C 86 ; WX 695 ; N a49 ; B 35 -14 661 706 ;
+C 87 ; WX 776 ; N a50 ; B 35 -6 741 699 ;
+C 88 ; WX 768 ; N a51 ; B 35 -7 734 699 ;
+C 89 ; WX 792 ; N a52 ; B 35 -14 757 705 ;
+C 90 ; WX 759 ; N a53 ; B 35 0 725 692 ;
+C 91 ; WX 707 ; N a54 ; B 35 -13 672 704 ;
+C 92 ; WX 708 ; N a55 ; B 35 -14 672 705 ;
+C 93 ; WX 682 ; N a56 ; B 35 -14 647 705 ;
+C 94 ; WX 701 ; N a57 ; B 35 -14 666 705 ;
+C 95 ; WX 826 ; N a58 ; B 35 -14 791 705 ;
+C 96 ; WX 815 ; N a59 ; B 35 -14 780 705 ;
+C 97 ; WX 789 ; N a60 ; B 35 -14 754 705 ;
+C 98 ; WX 789 ; N a61 ; B 35 -14 754 705 ;
+C 99 ; WX 707 ; N a62 ; B 34 -14 673 705 ;
+C 100 ; WX 687 ; N a63 ; B 36 0 651 692 ;
+C 101 ; WX 696 ; N a64 ; B 35 0 661 691 ;
+C 102 ; WX 689 ; N a65 ; B 35 0 655 692 ;
+C 103 ; WX 786 ; N a66 ; B 34 -14 751 705 ;
+C 104 ; WX 787 ; N a67 ; B 35 -14 752 705 ;
+C 105 ; WX 713 ; N a68 ; B 35 -14 678 705 ;
+C 106 ; WX 791 ; N a69 ; B 35 -14 756 705 ;
+C 107 ; WX 785 ; N a70 ; B 36 -14 751 705 ;
+C 108 ; WX 791 ; N a71 ; B 35 -14 757 705 ;
+C 109 ; WX 873 ; N a72 ; B 35 -14 838 705 ;
+C 110 ; WX 761 ; N a73 ; B 35 0 726 692 ;
+C 111 ; WX 762 ; N a74 ; B 35 0 727 692 ;
+C 112 ; WX 762 ; N a203 ; B 35 0 727 692 ;
+C 113 ; WX 759 ; N a75 ; B 35 0 725 692 ;
+C 114 ; WX 759 ; N a204 ; B 35 0 725 692 ;
+C 115 ; WX 892 ; N a76 ; B 35 0 858 705 ;
+C 116 ; WX 892 ; N a77 ; B 35 -14 858 692 ;
+C 117 ; WX 788 ; N a78 ; B 35 -14 754 705 ;
+C 118 ; WX 784 ; N a79 ; B 35 -14 749 705 ;
+C 119 ; WX 438 ; N a81 ; B 35 -14 403 705 ;
+C 120 ; WX 138 ; N a82 ; B 35 0 104 692 ;
+C 121 ; WX 277 ; N a83 ; B 35 0 242 692 ;
+C 122 ; WX 415 ; N a84 ; B 35 0 380 692 ;
+C 123 ; WX 392 ; N a97 ; B 35 263 357 705 ;
+C 124 ; WX 392 ; N a98 ; B 34 263 357 705 ;
+C 125 ; WX 668 ; N a99 ; B 35 263 633 705 ;
+C 126 ; WX 668 ; N a100 ; B 36 263 634 705 ;
+C 128 ; WX 390 ; N a89 ; B 35 -14 356 705 ;
+C 129 ; WX 390 ; N a90 ; B 35 -14 355 705 ;
+C 130 ; WX 317 ; N a93 ; B 35 0 283 692 ;
+C 131 ; WX 317 ; N a94 ; B 35 0 283 692 ;
+C 132 ; WX 276 ; N a91 ; B 35 0 242 692 ;
+C 133 ; WX 276 ; N a92 ; B 35 0 242 692 ;
+C 134 ; WX 509 ; N a205 ; B 35 0 475 692 ;
+C 135 ; WX 509 ; N a85 ; B 35 0 475 692 ;
+C 136 ; WX 410 ; N a206 ; B 35 0 375 692 ;
+C 137 ; WX 410 ; N a86 ; B 35 0 375 692 ;
+C 138 ; WX 234 ; N a87 ; B 35 -14 199 705 ;
+C 139 ; WX 234 ; N a88 ; B 35 -14 199 705 ;
+C 140 ; WX 334 ; N a95 ; B 35 0 299 692 ;
+C 141 ; WX 334 ; N a96 ; B 35 0 299 692 ;
+C 161 ; WX 732 ; N a101 ; B 35 -143 697 806 ;
+C 162 ; WX 544 ; N a102 ; B 56 -14 488 706 ;
+C 163 ; WX 544 ; N a103 ; B 34 -14 508 705 ;
+C 164 ; WX 910 ; N a104 ; B 35 40 875 651 ;
+C 165 ; WX 667 ; N a106 ; B 35 -14 633 705 ;
+C 166 ; WX 760 ; N a107 ; B 35 -14 726 705 ;
+C 167 ; WX 760 ; N a108 ; B 0 121 758 569 ;
+C 168 ; WX 776 ; N a112 ; B 35 0 741 705 ;
+C 169 ; WX 595 ; N a111 ; B 34 -14 560 705 ;
+C 170 ; WX 694 ; N a110 ; B 35 -14 659 705 ;
+C 171 ; WX 626 ; N a109 ; B 34 0 591 705 ;
+C 172 ; WX 788 ; N a120 ; B 35 -14 754 705 ;
+C 173 ; WX 788 ; N a121 ; B 35 -14 754 705 ;
+C 174 ; WX 788 ; N a122 ; B 35 -14 754 705 ;
+C 175 ; WX 788 ; N a123 ; B 35 -14 754 705 ;
+C 176 ; WX 788 ; N a124 ; B 35 -14 754 705 ;
+C 177 ; WX 788 ; N a125 ; B 35 -14 754 705 ;
+C 178 ; WX 788 ; N a126 ; B 35 -14 754 705 ;
+C 179 ; WX 788 ; N a127 ; B 35 -14 754 705 ;
+C 180 ; WX 788 ; N a128 ; B 35 -14 754 705 ;
+C 181 ; WX 788 ; N a129 ; B 35 -14 754 705 ;
+C 182 ; WX 788 ; N a130 ; B 35 -14 754 705 ;
+C 183 ; WX 788 ; N a131 ; B 35 -14 754 705 ;
+C 184 ; WX 788 ; N a132 ; B 35 -14 754 705 ;
+C 185 ; WX 788 ; N a133 ; B 35 -14 754 705 ;
+C 186 ; WX 788 ; N a134 ; B 35 -14 754 705 ;
+C 187 ; WX 788 ; N a135 ; B 35 -14 754 705 ;
+C 188 ; WX 788 ; N a136 ; B 35 -14 754 705 ;
+C 189 ; WX 788 ; N a137 ; B 35 -14 754 705 ;
+C 190 ; WX 788 ; N a138 ; B 35 -14 754 705 ;
+C 191 ; WX 788 ; N a139 ; B 35 -14 754 705 ;
+C 192 ; WX 788 ; N a140 ; B 35 -14 754 705 ;
+C 193 ; WX 788 ; N a141 ; B 35 -14 754 705 ;
+C 194 ; WX 788 ; N a142 ; B 35 -14 754 705 ;
+C 195 ; WX 788 ; N a143 ; B 35 -14 754 705 ;
+C 196 ; WX 788 ; N a144 ; B 35 -14 754 705 ;
+C 197 ; WX 788 ; N a145 ; B 35 -14 754 705 ;
+C 198 ; WX 788 ; N a146 ; B 35 -14 754 705 ;
+C 199 ; WX 788 ; N a147 ; B 35 -14 754 705 ;
+C 200 ; WX 788 ; N a148 ; B 35 -14 754 705 ;
+C 201 ; WX 788 ; N a149 ; B 35 -14 754 705 ;
+C 202 ; WX 788 ; N a150 ; B 35 -14 754 705 ;
+C 203 ; WX 788 ; N a151 ; B 35 -14 754 705 ;
+C 204 ; WX 788 ; N a152 ; B 35 -14 754 705 ;
+C 205 ; WX 788 ; N a153 ; B 35 -14 754 705 ;
+C 206 ; WX 788 ; N a154 ; B 35 -14 754 705 ;
+C 207 ; WX 788 ; N a155 ; B 35 -14 754 705 ;
+C 208 ; WX 788 ; N a156 ; B 35 -14 754 705 ;
+C 209 ; WX 788 ; N a157 ; B 35 -14 754 705 ;
+C 210 ; WX 788 ; N a158 ; B 35 -14 754 705 ;
+C 211 ; WX 788 ; N a159 ; B 35 -14 754 705 ;
+C 212 ; WX 894 ; N a160 ; B 35 58 860 634 ;
+C 213 ; WX 838 ; N a161 ; B 35 152 803 540 ;
+C 214 ; WX 1016 ; N a163 ; B 34 152 981 540 ;
+C 215 ; WX 458 ; N a164 ; B 35 -127 422 820 ;
+C 216 ; WX 748 ; N a196 ; B 35 94 698 597 ;
+C 217 ; WX 924 ; N a165 ; B 35 140 890 552 ;
+C 218 ; WX 748 ; N a192 ; B 35 94 698 597 ;
+C 219 ; WX 918 ; N a166 ; B 35 166 884 526 ;
+C 220 ; WX 927 ; N a167 ; B 35 32 892 660 ;
+C 221 ; WX 928 ; N a168 ; B 35 129 891 562 ;
+C 222 ; WX 928 ; N a169 ; B 35 128 893 563 ;
+C 223 ; WX 834 ; N a170 ; B 35 155 799 537 ;
+C 224 ; WX 873 ; N a171 ; B 35 93 838 599 ;
+C 225 ; WX 828 ; N a172 ; B 35 104 791 588 ;
+C 226 ; WX 924 ; N a173 ; B 35 98 889 594 ;
+C 227 ; WX 924 ; N a162 ; B 35 98 889 594 ;
+C 228 ; WX 917 ; N a174 ; B 35 0 882 692 ;
+C 229 ; WX 930 ; N a175 ; B 35 84 896 608 ;
+C 230 ; WX 931 ; N a176 ; B 35 84 896 608 ;
+C 231 ; WX 463 ; N a177 ; B 35 -99 429 791 ;
+C 232 ; WX 883 ; N a178 ; B 35 71 848 623 ;
+C 233 ; WX 836 ; N a179 ; B 35 44 802 648 ;
+C 234 ; WX 836 ; N a193 ; B 35 44 802 648 ;
+C 235 ; WX 867 ; N a180 ; B 35 101 832 591 ;
+C 236 ; WX 867 ; N a199 ; B 35 101 832 591 ;
+C 237 ; WX 696 ; N a181 ; B 35 44 661 648 ;
+C 238 ; WX 696 ; N a200 ; B 35 44 661 648 ;
+C 239 ; WX 874 ; N a182 ; B 35 77 840 619 ;
+C 241 ; WX 874 ; N a201 ; B 35 73 840 615 ;
+C 242 ; WX 760 ; N a183 ; B 35 0 725 692 ;
+C 243 ; WX 946 ; N a184 ; B 35 160 911 533 ;
+C 244 ; WX 771 ; N a197 ; B 34 37 736 655 ;
+C 245 ; WX 865 ; N a185 ; B 35 207 830 481 ;
+C 246 ; WX 771 ; N a194 ; B 34 37 736 655 ;
+C 247 ; WX 888 ; N a198 ; B 34 -19 853 712 ;
+C 248 ; WX 967 ; N a186 ; B 35 124 932 568 ;
+C 249 ; WX 888 ; N a195 ; B 34 -19 853 712 ;
+C 250 ; WX 831 ; N a187 ; B 35 113 796 579 ;
+C 251 ; WX 873 ; N a188 ; B 36 118 838 578 ;
+C 252 ; WX 927 ; N a189 ; B 35 150 891 542 ;
+C 253 ; WX 970 ; N a190 ; B 35 76 931 616 ;
+C 254 ; WX 918 ; N a191 ; B 34 99 884 593 ;
+EndCharMetrics
+EndFontMetrics
Added: trunk/mapbender/http/classes/fonts/php_Times-BoldItalic.afm
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/fonts/php_Times-BoldItalic.afm?view=auto&rev=54
--- (empty file)
+++ trunk/mapbender/http/classes/fonts/php_Times-BoldItalic.afm	2006-04-13 21:05:53+0000
@@ -0,0 +1 @@
+a:22:{s:8:"FontName";s:16:"Times-BoldItalic";s:8:"FullName";s:17:"Times Bold Italic";s:10:"FamilyName";s:5:"Times";s:6:"Weight";s:4:"Bold";s:11:"ItalicAngle";s:3:"-15";s:12:"IsFixedPitch";s:5:"false";s:12:"CharacterSet";s:13:"ExtendedRoman";s:8:"FontBBox";a:4:{i:0;s:4:"-200";i:1;s:4:"-218";i:2;s:3:"996";i:3;s:3:"921";}s:17:"UnderlinePosition";s:4:"-100";s:18:"UnderlineThickness";s:2:"50";s:7:"Version";s:7:"002.000";s:14:"EncodingScheme";s:21:"AdobeStandardEncoding";s:9:"CapHeight";s:3:"669";s:7:"XHeight";s:3:"462";s:8:"Ascender";s:3:"683";s:9:"Descender";s:4:"-217";s:5:"StdHW";s:2:"42";s:5:"StdVW";s:3:"121";s:16:"StartCharMetrics";s:3:"315";s:1:"C";a:464:{i:32;a:4:{s:1:"C";s:2:"32";s:2:"WX";s:3:"250";s:1:"N";s:5:"space";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}s:5:"space";a:4:{s:1:"C";s:2:"32";s:2:"WX";s:3:"250";s:1:"N";s:5:"space";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}i:33;a:4:{s:1:"C";s:2:"33";s:2:"WX";s:3:"389";s:1:"N";s:6:"exclam";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:3:"-13";i:2;s:3:"370";i:3;s:3:"684";}}s:6:"exclam";a:4:{s:1:"C";s:2:"33";s:2:"WX";s:3:"389";s:1:"N";s:6:"exclam";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:3:"-13";i:2;s:3:"370";i:3;s:3:"684";}}i:34;a:4:{s:1:"C";s:2:"34";s:2:"WX";s:3:"555";s:1:"N";s:8:"quotedbl";s:1:"B";a:4:{i:0;s:3:"136";i:1;s:3:"398";i:2;s:3:"536";i:3;s:3:"685";}}s:8:"quotedbl";a:4:{s:1:"C";s:2:"34";s:2:"WX";s:3:"555";s:1:"N";s:8:"quotedbl";s:1:"B";a:4:{i:0;s:3:"136";i:1;s:3:"398";i:2;s:3:"536";i:3;s:3:"685";}}i:35;a:4:{s:1:"C";s:2:"35";s:2:"WX";s:3:"500";s:1:"N";s:10:"numbersign";s:1:"B";a:4:{i:0;s:3:"-33";i:1;s:1:"0";i:2;s:3:"533";i:3;s:3:"700";}}s:10:"numbersign";a:4:{s:1:"C";s:2:"35";s:2:"WX";s:3:"500";s:1:"N";s:10:"numbersign";s:1:"B";a:4:{i:0;s:3:"-33";i:1;s:1:"0";i:2;s:3:"533";i:3;s:3:"700";}}i:36;a:4:{s:1:"C";s:2:"36";s:2:"WX";s:3:"500";s:1:"N";s:6:"dollar";s:1:"B";a:4:{i:0;s:3:"-20";i:1;s:4:"-100";i:2;s:3:"497";i:3;s:3:"733";}}s:6:"dollar";a:4:{s:1:"C";s:2:"36";s:2:"WX";s:3:"500";s:1:"N";s:6:"dollar";s:1:"B";a:4:{i:0;s:3:"-20";i:1;s:4:"-100";i:2;s:3:"497";i:3;s:3:"733";}}i:37;a:4:{s:1:"C";s:2:"37";s:2:"WX";s:3:"833";s:1:"N";s:7:"percent";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:3:"-10";i:2;s:3:"793";i:3;s:3:"692";}}s:7:"percent";a:4:{s:1:"C";s:2:"37";s:2:"WX";s:3:"833";s:1:"N";s:7:"percent";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:3:"-10";i:2;s:3:"793";i:3;s:3:"692";}}i:38;a:4:{s:1:"C";s:2:"38";s:2:"WX";s:3:"778";s:1:"N";s:9:"ampersand";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:3:"-19";i:2;s:3:"699";i:3;s:3:"682";}}s:9:"ampersand";a:4:{s:1:"C";s:2:"38";s:2:"WX";s:3:"778";s:1:"N";s:9:"ampersand";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:3:"-19";i:2;s:3:"699";i:3;s:3:"682";}}i:39;a:4:{s:1:"C";s:2:"39";s:2:"WX";s:3:"333";s:1:"N";s:10:"quoteright";s:1:"B";a:4:{i:0;s:2:"98";i:1;s:3:"369";i:2;s:3:"302";i:3;s:3:"685";}}s:10:"quoteright";a:4:{s:1:"C";s:2:"39";s:2:"WX";s:3:"333";s:1:"N";s:10:"quoteright";s:1:"B";a:4:{i:0;s:2:"98";i:1;s:3:"369";i:2;s:3:"302";i:3;s:3:"685";}}i:40;a:4:{s:1:"C";s:2:"40";s:2:"WX";s:3:"333";s:1:"N";s:9:"parenleft";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:4:"-179";i:2;s:3:"344";i:3;s:3:"685";}}s:9:"parenleft";a:4:{s:1:"C";s:2:"40";s:2:"WX";s:3:"333";s:1:"N";s:9:"parenleft";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:4:"-179";i:2;s:3:"344";i:3;s:3:"685";}}i:41;a:4:{s:1:"C";s:2:"41";s:2:"WX";s:3:"333";s:1:"N";s:10:"parenright";s:1:"B";a:4:{i:0;s:3:"-44";i:1;s:4:"-179";i:2;s:3:"271";i:3;s:3:"685";}}s:10:"parenright";a:4:{s:1:"C";s:2:"41";s:2:"WX";s:3:"333";s:1:"N";s:10:"parenright";s:1:"B";a:4:{i:0;s:3:"-44";i:1;s:4:"-179";i:2;s:3:"271";i:3;s:3:"685";}}i:42;a:4:{s:1:"C";s:2:"42";s:2:"WX";s:3:"500";s:1:"N";s:8:"asterisk";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:3:"249";i:2;s:3:"456";i:3;s:3:"685";}}s:8:"asterisk";a:4:{s:1:"C";s:2:"42";s:2:"WX";s:3:"500";s:1:"N";s:8:"asterisk";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:3:"249";i:2;s:3:"456";i:3;s:3:"685";}}i:43;a:4:{s:1:"C";s:2:"43";s:2:"WX";s:3:"570";s:1:"N";s:4:"plus";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:1:"0";i:2;s:3:"537";i:3;s:3:"506";}}s:4:"plus";a:4:{s:1:"C";s:2:"43";s:2:"WX";s:3:"570";s:1:"N";s:4:"plus";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:1:"0";i:2;s:3:"537";i:3;s:3:"506";}}i:44;a:4:{s:1:"C";s:2:"44";s:2:"WX";s:3:"250";s:1:"N";s:5:"comma";s:1:"B";a:4:{i:0;s:3:"-60";i:1;s:4:"-182";i:2;s:3:"144";i:3;s:3:"134";}}s:5:"comma";a:4:{s:1:"C";s:2:"44";s:2:"WX";s:3:"250";s:1:"N";s:5:"comma";s:1:"B";a:4:{i:0;s:3:"-60";i:1;s:4:"-182";i:2;s:3:"144";i:3;s:3:"134";}}i:45;a:4:{s:1:"C";s:2:"45";s:2:"WX";s:3:"333";s:1:"N";s:6:"hyphen";s:1:"B";a:4:{i:0;s:1:"2";i:1;s:3:"166";i:2;s:3:"271";i:3;s:3:"282";}}s:6:"hyphen";a:4:{s:1:"C";s:2:"45";s:2:"WX";s:3:"333";s:1:"N";s:6:"hyphen";s:1:"B";a:4:{i:0;s:1:"2";i:1;s:3:"166";i:2;s:3:"271";i:3;s:3:"282";}}i:46;a:4:{s:1:"C";s:2:"46";s:2:"WX";s:3:"250";s:1:"N";s:6:"period";s:1:"B";a:4:{i:0;s:2:"-9";i:1;s:3:"-13";i:2;s:3:"139";i:3;s:3:"135";}}s:6:"period";a:4:{s:1:"C";s:2:"46";s:2:"WX";s:3:"250";s:1:"N";s:6:"period";s:1:"B";a:4:{i:0;s:2:"-9";i:1;s:3:"-13";i:2;s:3:"139";i:3;s:3:"135";}}i:47;a:4:{s:1:"C";s:2:"47";s:2:"WX";s:3:"278";s:1:"N";s:5:"slash";s:1:"B";a:4:{i:0;s:3:"-64";i:1;s:3:"-18";i:2;s:3:"342";i:3;s:3:"685";}}s:5:"slash";a:4:{s:1:"C";s:2:"47";s:2:"WX";s:3:"278";s:1:"N";s:5:"slash";s:1:"B";a:4:{i:0;s:3:"-64";i:1;s:3:"-18";i:2;s:3:"342";i:3;s:3:"685";}}i:48;a:4:{s:1:"C";s:2:"48";s:2:"WX";s:3:"500";s:1:"N";s:4:"zero";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:3:"-14";i:2;s:3:"477";i:3;s:3:"683";}}s:4:"zero";a:4:{s:1:"C";s:2:"48";s:2:"WX";s:3:"500";s:1:"N";s:4:"zero";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:3:"-14";i:2;s:3:"477";i:3;s:3:"683";}}i:49;a:4:{s:1:"C";s:2:"49";s:2:"WX";s:3:"500";s:1:"N";s:3:"one";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:1:"0";i:2;s:3:"419";i:3;s:3:"683";}}s:3:"one";a:4:{s:1:"C";s:2:"49";s:2:"WX";s:3:"500";s:1:"N";s:3:"one";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:1:"0";i:2;s:3:"419";i:3;s:3:"683";}}i:50;a:4:{s:1:"C";s:2:"50";s:2:"WX";s:3:"500";s:1:"N";s:3:"two";s:1:"B";a:4:{i:0;s:3:"-27";i:1;s:1:"0";i:2;s:3:"446";i:3;s:3:"683";}}s:3:"two";a:4:{s:1:"C";s:2:"50";s:2:"WX";s:3:"500";s:1:"N";s:3:"two";s:1:"B";a:4:{i:0;s:3:"-27";i:1;s:1:"0";i:2;s:3:"446";i:3;s:3:"683";}}i:51;a:4:{s:1:"C";s:2:"51";s:2:"WX";s:3:"500";s:1:"N";s:5:"three";s:1:"B";a:4:{i:0;s:3:"-15";i:1;s:3:"-13";i:2;s:3:"450";i:3;s:3:"683";}}s:5:"three";a:4:{s:1:"C";s:2:"51";s:2:"WX";s:3:"500";s:1:"N";s:5:"three";s:1:"B";a:4:{i:0;s:3:"-15";i:1;s:3:"-13";i:2;s:3:"450";i:3;s:3:"683";}}i:52;a:4:{s:1:"C";s:2:"52";s:2:"WX";s:3:"500";s:1:"N";s:4:"four";s:1:"B";a:4:{i:0;s:3:"-15";i:1;s:1:"0";i:2;s:3:"503";i:3;s:3:"683";}}s:4:"four";a:4:{s:1:"C";s:2:"52";s:2:"WX";s:3:"500";s:1:"N";s:4:"four";s:1:"B";a:4:{i:0;s:3:"-15";i:1;s:1:"0";i:2;s:3:"503";i:3;s:3:"683";}}i:53;a:4:{s:1:"C";s:2:"53";s:2:"WX";s:3:"500";s:1:"N";s:4:"five";s:1:"B";a:4:{i:0;s:3:"-11";i:1;s:3:"-13";i:2;s:3:"487";i:3;s:3:"669";}}s:4:"five";a:4:{s:1:"C";s:2:"53";s:2:"WX";s:3:"500";s:1:"N";s:4:"five";s:1:"B";a:4:{i:0;s:3:"-11";i:1;s:3:"-13";i:2;s:3:"487";i:3;s:3:"669";}}i:54;a:4:{s:1:"C";s:2:"54";s:2:"WX";s:3:"500";s:1:"N";s:3:"six";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:3:"-15";i:2;s:3:"509";i:3;s:3:"679";}}s:3:"six";a:4:{s:1:"C";s:2:"54";s:2:"WX";s:3:"500";s:1:"N";s:3:"six";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:3:"-15";i:2;s:3:"509";i:3;s:3:"679";}}i:55;a:4:{s:1:"C";s:2:"55";s:2:"WX";s:3:"500";s:1:"N";s:5:"seven";s:1:"B";a:4:{i:0;s:2:"52";i:1;s:1:"0";i:2;s:3:"525";i:3;s:3:"669";}}s:5:"seven";a:4:{s:1:"C";s:2:"55";s:2:"WX";s:3:"500";s:1:"N";s:5:"seven";s:1:"B";a:4:{i:0;s:2:"52";i:1;s:1:"0";i:2;s:3:"525";i:3;s:3:"669";}}i:56;a:4:{s:1:"C";s:2:"56";s:2:"WX";s:3:"500";s:1:"N";s:5:"eight";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:3:"-13";i:2;s:3:"476";i:3;s:3:"683";}}s:5:"eight";a:4:{s:1:"C";s:2:"56";s:2:"WX";s:3:"500";s:1:"N";s:5:"eight";s:1:"B";a:4:{i:0;s:1:"3";i:1;s:3:"-13";i:2;s:3:"476";i:3;s:3:"683";}}i:57;a:4:{s:1:"C";s:2:"57";s:2:"WX";s:3:"500";s:1:"N";s:4:"nine";s:1:"B";a:4:{i:0;s:3:"-12";i:1;s:3:"-10";i:2;s:3:"475";i:3;s:3:"683";}}s:4:"nine";a:4:{s:1:"C";s:2:"57";s:2:"WX";s:3:"500";s:1:"N";s:4:"nine";s:1:"B";a:4:{i:0;s:3:"-12";i:1;s:3:"-10";i:2;s:3:"475";i:3;s:3:"683";}}i:58;a:4:{s:1:"C";s:2:"58";s:2:"WX";s:3:"333";s:1:"N";s:5:"colon";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:3:"-13";i:2;s:3:"264";i:3;s:3:"459";}}s:5:"colon";a:4:{s:1:"C";s:2:"58";s:2:"WX";s:3:"333";s:1:"N";s:5:"colon";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:3:"-13";i:2;s:3:"264";i:3;s:3:"459";}}i:59;a:4:{s:1:"C";s:2:"59";s:2:"WX";s:3:"333";s:1:"N";s:9:"semicolon";s:1:"B";a:4:{i:0;s:3:"-25";i:1;s:4:"-183";i:2;s:3:"264";i:3;s:3:"459";}}s:9:"semicolon";a:4:{s:1:"C";s:2:"59";s:2:"WX";s:3:"333";s:1:"N";s:9:"semicolon";s:1:"B";a:4:{i:0;s:3:"-25";i:1;s:4:"-183";i:2;s:3:"264";i:3;s:3:"459";}}i:60;a:4:{s:1:"C";s:2:"60";s:2:"WX";s:3:"570";s:1:"N";s:4:"less";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:2:"-8";i:2;s:3:"539";i:3;s:3:"514";}}s:4:"less";a:4:{s:1:"C";s:2:"60";s:2:"WX";s:3:"570";s:1:"N";s:4:"less";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:2:"-8";i:2;s:3:"539";i:3;s:3:"514";}}i:61;a:4:{s:1:"C";s:2:"61";s:2:"WX";s:3:"570";s:1:"N";s:5:"equal";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:3:"107";i:2;s:3:"537";i:3;s:3:"399";}}s:5:"equal";a:4:{s:1:"C";s:2:"61";s:2:"WX";s:3:"570";s:1:"N";s:5:"equal";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:3:"107";i:2;s:3:"537";i:3;s:3:"399";}}i:62;a:4:{s:1:"C";s:2:"62";s:2:"WX";s:3:"570";s:1:"N";s:7:"greater";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:2:"-8";i:2;s:3:"539";i:3;s:3:"514";}}s:7:"greater";a:4:{s:1:"C";s:2:"62";s:2:"WX";s:3:"570";s:1:"N";s:7:"greater";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:2:"-8";i:2;s:3:"539";i:3;s:3:"514";}}i:63;a:4:{s:1:"C";s:2:"63";s:2:"WX";s:3:"500";s:1:"N";s:8:"question";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:3:"-13";i:2;s:3:"470";i:3;s:3:"684";}}s:8:"question";a:4:{s:1:"C";s:2:"63";s:2:"WX";s:3:"500";s:1:"N";s:8:"question";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:3:"-13";i:2;s:3:"470";i:3;s:3:"684";}}i:64;a:4:{s:1:"C";s:2:"64";s:2:"WX";s:3:"832";s:1:"N";s:2:"at";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:3:"-18";i:2;s:3:"770";i:3;s:3:"685";}}s:2:"at";a:4:{s:1:"C";s:2:"64";s:2:"WX";s:3:"832";s:1:"N";s:2:"at";s:1:"B";a:4:{i:0;s:2:"63";i:1;s:3:"-18";i:2;s:3:"770";i:3;s:3:"685";}}i:65;a:4:{s:1:"C";s:2:"65";s:2:"WX";s:3:"667";s:1:"N";s:1:"A";s:1:"B";a:4:{i:0;s:3:"-67";i:1;s:1:"0";i:2;s:3:"593";i:3;s:3:"683";}}s:1:"A";a:4:{s:1:"C";s:2:"65";s:2:"WX";s:3:"667";s:1:"N";s:1:"A";s:1:"B";a:4:{i:0;s:3:"-67";i:1;s:1:"0";i:2;s:3:"593";i:3;s:3:"683";}}i:66;a:4:{s:1:"C";s:2:"66";s:2:"WX";s:3:"667";s:1:"N";s:1:"B";s:1:"B";a:4:{i:0;s:3:"-24";i:1;s:1:"0";i:2;s:3:"624";i:3;s:3:"669";}}s:1:"B";a:4:{s:1:"C";s:2:"66";s:2:"WX";s:3:"667";s:1:"N";s:1:"B";s:1:"B";a:4:{i:0;s:3:"-24";i:1;s:1:"0";i:2;s:3:"624";i:3;s:3:"669";}}i:67;a:4:{s:1:"C";s:2:"67";s:2:"WX";s:3:"667";s:1:"N";s:1:"C";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:3:"-18";i:2;s:3:"677";i:3;s:3:"685";}}s:1:"C";a:4:{s:1:"C";s:2:"67";s:2:"WX";s:3:"667";s:1:"N";s:1:"C";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:3:"-18";i:2;s:3:"677";i:3;s:3:"685";}}i:68;a:4:{s:1:"C";s:2:"68";s:2:"WX";s:3:"722";s:1:"N";s:1:"D";s:1:"B";a:4:{i:0;s:3:"-46";i:1;s:1:"0";i:2;s:3:"685";i:3;s:3:"669";}}s:1:"D";a:4:{s:1:"C";s:2:"68";s:2:"WX";s:3:"722";s:1:"N";s:1:"D";s:1:"B";a:4:{i:0;s:3:"-46";i:1;s:1:"0";i:2;s:3:"685";i:3;s:3:"669";}}i:69;a:4:{s:1:"C";s:2:"69";s:2:"WX";s:3:"667";s:1:"N";s:1:"E";s:1:"B";a:4:{i:0;s:3:"-27";i:1;s:1:"0";i:2;s:3:"653";i:3;s:3:"669";}}s:1:"E";a:4:{s:1:"C";s:2:"69";s:2:"WX";s:3:"667";s:1:"N";s:1:"E";s:1:"B";a:4:{i:0;s:3:"-27";i:1;s:1:"0";i:2;s:3:"653";i:3;s:3:"669";}}i:70;a:4:{s:1:"C";s:2:"70";s:2:"WX";s:3:"667";s:1:"N";s:1:"F";s:1:"B";a:4:{i:0;s:3:"-13";i:1;s:1:"0";i:2;s:3:"660";i:3;s:3:"669";}}s:1:"F";a:4:{s:1:"C";s:2:"70";s:2:"WX";s:3:"667";s:1:"N";s:1:"F";s:1:"B";a:4:{i:0;s:3:"-13";i:1;s:1:"0";i:2;s:3:"660";i:3;s:3:"669";}}i:71;a:4:{s:1:"C";s:2:"71";s:2:"WX";s:3:"722";s:1:"N";s:1:"G";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:3:"-18";i:2;s:3:"706";i:3;s:3:"685";}}s:1:"G";a:4:{s:1:"C";s:2:"71";s:2:"WX";s:3:"722";s:1:"N";s:1:"G";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:3:"-18";i:2;s:3:"706";i:3;s:3:"685";}}i:72;a:4:{s:1:"C";s:2:"72";s:2:"WX";s:3:"778";s:1:"N";s:1:"H";s:1:"B";a:4:{i:0;s:3:"-24";i:1;s:1:"0";i:2;s:3:"799";i:3;s:3:"669";}}s:1:"H";a:4:{s:1:"C";s:2:"72";s:2:"WX";s:3:"778";s:1:"N";s:1:"H";s:1:"B";a:4:{i:0;s:3:"-24";i:1;s:1:"0";i:2;s:3:"799";i:3;s:3:"669";}}i:73;a:4:{s:1:"C";s:2:"73";s:2:"WX";s:3:"389";s:1:"N";s:1:"I";s:1:"B";a:4:{i:0;s:3:"-32";i:1;s:1:"0";i:2;s:3:"406";i:3;s:3:"669";}}s:1:"I";a:4:{s:1:"C";s:2:"73";s:2:"WX";s:3:"389";s:1:"N";s:1:"I";s:1:"B";a:4:{i:0;s:3:"-32";i:1;s:1:"0";i:2;s:3:"406";i:3;s:3:"669";}}i:74;a:4:{s:1:"C";s:2:"74";s:2:"WX";s:3:"500";s:1:"N";s:1:"J";s:1:"B";a:4:{i:0;s:3:"-46";i:1;s:3:"-99";i:2;s:3:"524";i:3;s:3:"669";}}s:1:"J";a:4:{s:1:"C";s:2:"74";s:2:"WX";s:3:"500";s:1:"N";s:1:"J";s:1:"B";a:4:{i:0;s:3:"-46";i:1;s:3:"-99";i:2;s:3:"524";i:3;s:3:"669";}}i:75;a:4:{s:1:"C";s:2:"75";s:2:"WX";s:3:"667";s:1:"N";s:1:"K";s:1:"B";a:4:{i:0;s:3:"-21";i:1;s:1:"0";i:2;s:3:"702";i:3;s:3:"669";}}s:1:"K";a:4:{s:1:"C";s:2:"75";s:2:"WX";s:3:"667";s:1:"N";s:1:"K";s:1:"B";a:4:{i:0;s:3:"-21";i:1;s:1:"0";i:2;s:3:"702";i:3;s:3:"669";}}i:76;a:4:{s:1:"C";s:2:"76";s:2:"WX";s:3:"611";s:1:"N";s:1:"L";s:1:"B";a:4:{i:0;s:3:"-22";i:1;s:1:"0";i:2;s:3:"590";i:3;s:3:"669";}}s:1:"L";a:4:{s:1:"C";s:2:"76";s:2:"WX";s:3:"611";s:1:"N";s:1:"L";s:1:"B";a:4:{i:0;s:3:"-22";i:1;s:1:"0";i:2;s:3:"590";i:3;s:3:"669";}}i:77;a:4:{s:1:"C";s:2:"77";s:2:"WX";s:3:"889";s:1:"N";s:1:"M";s:1:"B";a:4:{i:0;s:3:"-29";i:1;s:3:"-12";i:2;s:3:"917";i:3;s:3:"669";}}s:1:"M";a:4:{s:1:"C";s:2:"77";s:2:"WX";s:3:"889";s:1:"N";s:1:"M";s:1:"B";a:4:{i:0;s:3:"-29";i:1;s:3:"-12";i:2;s:3:"917";i:3;s:3:"669";}}i:78;a:4:{s:1:"C";s:2:"78";s:2:"WX";s:3:"722";s:1:"N";s:1:"N";s:1:"B";a:4:{i:0;s:3:"-27";i:1;s:3:"-15";i:2;s:3:"748";i:3;s:3:"669";}}s:1:"N";a:4:{s:1:"C";s:2:"78";s:2:"WX";s:3:"722";s:1:"N";s:1:"N";s:1:"B";a:4:{i:0;s:3:"-27";i:1;s:3:"-15";i:2;s:3:"748";i:3;s:3:"669";}}i:79;a:4:{s:1:"C";s:2:"79";s:2:"WX";s:3:"722";s:1:"N";s:1:"O";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:3:"-18";i:2;s:3:"691";i:3;s:3:"685";}}s:1:"O";a:4:{s:1:"C";s:2:"79";s:2:"WX";s:3:"722";s:1:"N";s:1:"O";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:3:"-18";i:2;s:3:"691";i:3;s:3:"685";}}i:80;a:4:{s:1:"C";s:2:"80";s:2:"WX";s:3:"611";s:1:"N";s:1:"P";s:1:"B";a:4:{i:0;s:3:"-27";i:1;s:1:"0";i:2;s:3:"613";i:3;s:3:"669";}}s:1:"P";a:4:{s:1:"C";s:2:"80";s:2:"WX";s:3:"611";s:1:"N";s:1:"P";s:1:"B";a:4:{i:0;s:3:"-27";i:1;s:1:"0";i:2;s:3:"613";i:3;s:3:"669";}}i:81;a:4:{s:1:"C";s:2:"81";s:2:"WX";s:3:"722";s:1:"N";s:1:"Q";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:4:"-208";i:2;s:3:"691";i:3;s:3:"685";}}s:1:"Q";a:4:{s:1:"C";s:2:"81";s:2:"WX";s:3:"722";s:1:"N";s:1:"Q";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:4:"-208";i:2;s:3:"691";i:3;s:3:"685";}}i:82;a:4:{s:1:"C";s:2:"82";s:2:"WX";s:3:"667";s:1:"N";s:1:"R";s:1:"B";a:4:{i:0;s:3:"-29";i:1;s:1:"0";i:2;s:3:"623";i:3;s:3:"669";}}s:1:"R";a:4:{s:1:"C";s:2:"82";s:2:"WX";s:3:"667";s:1:"N";s:1:"R";s:1:"B";a:4:{i:0;s:3:"-29";i:1;s:1:"0";i:2;s:3:"623";i:3;s:3:"669";}}i:83;a:4:{s:1:"C";s:2:"83";s:2:"WX";s:3:"556";s:1:"N";s:1:"S";s:1:"B";a:4:{i:0;s:1:"2";i:1;s:3:"-18";i:2;s:3:"526";i:3;s:3:"685";}}s:1:"S";a:4:{s:1:"C";s:2:"83";s:2:"WX";s:3:"556";s:1:"N";s:1:"S";s:1:"B";a:4:{i:0;s:1:"2";i:1;s:3:"-18";i:2;s:3:"526";i:3;s:3:"685";}}i:84;a:4:{s:1:"C";s:2:"84";s:2:"WX";s:3:"611";s:1:"N";s:1:"T";s:1:"B";a:4:{i:0;s:2:"50";i:1;s:1:"0";i:2;s:3:"650";i:3;s:3:"669";}}s:1:"T";a:4:{s:1:"C";s:2:"84";s:2:"WX";s:3:"611";s:1:"N";s:1:"T";s:1:"B";a:4:{i:0;s:2:"50";i:1;s:1:"0";i:2;s:3:"650";i:3;s:3:"669";}}i:85;a:4:{s:1:"C";s:2:"85";s:2:"WX";s:3:"722";s:1:"N";s:1:"U";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:3:"-18";i:2;s:3:"744";i:3;s:3:"669";}}s:1:"U";a:4:{s:1:"C";s:2:"85";s:2:"WX";s:3:"722";s:1:"N";s:1:"U";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:3:"-18";i:2;s:3:"744";i:3;s:3:"669";}}i:86;a:4:{s:1:"C";s:2:"86";s:2:"WX";s:3:"667";s:1:"N";s:1:"V";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:3:"-18";i:2;s:3:"715";i:3;s:3:"669";}}s:1:"V";a:4:{s:1:"C";s:2:"86";s:2:"WX";s:3:"667";s:1:"N";s:1:"V";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:3:"-18";i:2;s:3:"715";i:3;s:3:"669";}}i:87;a:4:{s:1:"C";s:2:"87";s:2:"WX";s:3:"889";s:1:"N";s:1:"W";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:3:"-18";i:2;s:3:"940";i:3;s:3:"669";}}s:1:"W";a:4:{s:1:"C";s:2:"87";s:2:"WX";s:3:"889";s:1:"N";s:1:"W";s:1:"B";a:4:{i:0;s:2:"65";i:1;s:3:"-18";i:2;s:3:"940";i:3;s:3:"669";}}i:88;a:4:{s:1:"C";s:2:"88";s:2:"WX";s:3:"667";s:1:"N";s:1:"X";s:1:"B";a:4:{i:0;s:3:"-24";i:1;s:1:"0";i:2;s:3:"694";i:3;s:3:"669";}}s:1:"X";a:4:{s:1:"C";s:2:"88";s:2:"WX";s:3:"667";s:1:"N";s:1:"X";s:1:"B";a:4:{i:0;s:3:"-24";i:1;s:1:"0";i:2;s:3:"694";i:3;s:3:"669";}}i:89;a:4:{s:1:"C";s:2:"89";s:2:"WX";s:3:"611";s:1:"N";s:1:"Y";s:1:"B";a:4:{i:0;s:2:"73";i:1;s:1:"0";i:2;s:3:"659";i:3;s:3:"669";}}s:1:"Y";a:4:{s:1:"C";s:2:"89";s:2:"WX";s:3:"611";s:1:"N";s:1:"Y";s:1:"B";a:4:{i:0;s:2:"73";i:1;s:1:"0";i:2;s:3:"659";i:3;s:3:"669";}}i:90;a:4:{s:1:"C";s:2:"90";s:2:"WX";s:3:"611";s:1:"N";s:1:"Z";s:1:"B";a:4:{i:0;s:3:"-11";i:1;s:1:"0";i:2;s:3:"590";i:3;s:3:"669";}}s:1:"Z";a:4:{s:1:"C";s:2:"90";s:2:"WX";s:3:"611";s:1:"N";s:1:"Z";s:1:"B";a:4:{i:0;s:3:"-11";i:1;s:1:"0";i:2;s:3:"590";i:3;s:3:"669";}}i:91;a:4:{s:1:"C";s:2:"91";s:2:"WX";s:3:"333";s:1:"N";s:11:"bracketleft";s:1:"B";a:4:{i:0;s:3:"-37";i:1;s:4:"-159";i:2;s:3:"362";i:3;s:3:"674";}}s:11:"bracketleft";a:4:{s:1:"C";s:2:"91";s:2:"WX";s:3:"333";s:1:"N";s:11:"bracketleft";s:1:"B";a:4:{i:0;s:3:"-37";i:1;s:4:"-159";i:2;s:3:"362";i:3;s:3:"674";}}i:92;a:4:{s:1:"C";s:2:"92";s:2:"WX";s:3:"278";s:1:"N";s:9:"backslash";s:1:"B";a:4:{i:0;s:2:"-1";i:1;s:3:"-18";i:2;s:3:"279";i:3;s:3:"685";}}s:9:"backslash";a:4:{s:1:"C";s:2:"92";s:2:"WX";s:3:"278";s:1:"N";s:9:"backslash";s:1:"B";a:4:{i:0;s:2:"-1";i:1;s:3:"-18";i:2;s:3:"279";i:3;s:3:"685";}}i:93;a:4:{s:1:"C";s:2:"93";s:2:"WX";s:3:"333";s:1:"N";s:12:"bracketright";s:1:"B";a:4:{i:0;s:3:"-56";i:1;s:4:"-157";i:2;s:3:"343";i:3;s:3:"674";}}s:12:"bracketright";a:4:{s:1:"C";s:2:"93";s:2:"WX";s:3:"333";s:1:"N";s:12:"bracketright";s:1:"B";a:4:{i:0;s:3:"-56";i:1;s:4:"-157";i:2;s:3:"343";i:3;s:3:"674";}}i:94;a:4:{s:1:"C";s:2:"94";s:2:"WX";s:3:"570";s:1:"N";s:11:"asciicircum";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:3:"304";i:2;s:3:"503";i:3;s:3:"669";}}s:11:"asciicircum";a:4:{s:1:"C";s:2:"94";s:2:"WX";s:3:"570";s:1:"N";s:11:"asciicircum";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:3:"304";i:2;s:3:"503";i:3;s:3:"669";}}i:95;a:4:{s:1:"C";s:2:"95";s:2:"WX";s:3:"500";s:1:"N";s:10:"underscore";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:4:"-125";i:2;s:3:"500";i:3;s:3:"-75";}}s:10:"underscore";a:4:{s:1:"C";s:2:"95";s:2:"WX";s:3:"500";s:1:"N";s:10:"underscore";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:4:"-125";i:2;s:3:"500";i:3;s:3:"-75";}}i:96;a:4:{s:1:"C";s:2:"96";s:2:"WX";s:3:"333";s:1:"N";s:9:"quoteleft";s:1:"B";a:4:{i:0;s:3:"128";i:1;s:3:"369";i:2;s:3:"332";i:3;s:3:"685";}}s:9:"quoteleft";a:4:{s:1:"C";s:2:"96";s:2:"WX";s:3:"333";s:1:"N";s:9:"quoteleft";s:1:"B";a:4:{i:0;s:3:"128";i:1;s:3:"369";i:2;s:3:"332";i:3;s:3:"685";}}i:97;a:4:{s:1:"C";s:2:"97";s:2:"WX";s:3:"500";s:1:"N";s:1:"a";s:1:"B";a:4:{i:0;s:3:"-21";i:1;s:3:"-14";i:2;s:3:"455";i:3;s:3:"462";}}s:1:"a";a:4:{s:1:"C";s:2:"97";s:2:"WX";s:3:"500";s:1:"N";s:1:"a";s:1:"B";a:4:{i:0;s:3:"-21";i:1;s:3:"-14";i:2;s:3:"455";i:3;s:3:"462";}}i:98;a:4:{s:1:"C";s:2:"98";s:2:"WX";s:3:"500";s:1:"N";s:1:"b";s:1:"B";a:4:{i:0;s:3:"-14";i:1;s:3:"-13";i:2;s:3:"444";i:3;s:3:"699";}}s:1:"b";a:4:{s:1:"C";s:2:"98";s:2:"WX";s:3:"500";s:1:"N";s:1:"b";s:1:"B";a:4:{i:0;s:3:"-14";i:1;s:3:"-13";i:2;s:3:"444";i:3;s:3:"699";}}i:99;a:4:{s:1:"C";s:2:"99";s:2:"WX";s:3:"444";s:1:"N";s:1:"c";s:1:"B";a:4:{i:0;s:2:"-5";i:1;s:3:"-13";i:2;s:3:"392";i:3;s:3:"462";}}s:1:"c";a:4:{s:1:"C";s:2:"99";s:2:"WX";s:3:"444";s:1:"N";s:1:"c";s:1:"B";a:4:{i:0;s:2:"-5";i:1;s:3:"-13";i:2;s:3:"392";i:3;s:3:"462";}}i:100;a:4:{s:1:"C";s:3:"100";s:2:"WX";s:3:"500";s:1:"N";s:1:"d";s:1:"B";a:4:{i:0;s:3:"-21";i:1;s:3:"-13";i:2;s:3:"517";i:3;s:3:"699";}}s:1:"d";a:4:{s:1:"C";s:3:"100";s:2:"WX";s:3:"500";s:1:"N";s:1:"d";s:1:"B";a:4:{i:0;s:3:"-21";i:1;s:3:"-13";i:2;s:3:"517";i:3;s:3:"699";}}i:101;a:4:{s:1:"C";s:3:"101";s:2:"WX";s:3:"444";s:1:"N";s:1:"e";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:3:"-13";i:2;s:3:"398";i:3;s:3:"462";}}s:1:"e";a:4:{s:1:"C";s:3:"101";s:2:"WX";s:3:"444";s:1:"N";s:1:"e";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:3:"-13";i:2;s:3:"398";i:3;s:3:"462";}}i:102;a:5:{s:1:"C";s:3:"102";s:2:"WX";s:3:"333";s:1:"N";s:1:"f";s:1:"B";a:4:{i:0;s:4:"-169";i:1;s:4:"-205";i:2;s:3:"446";i:3;s:3:"698";}s:1:"L";a:2:{i:0;s:1:"l";i:1;s:2:"fl";}}s:1:"f";a:5:{s:1:"C";s:3:"102";s:2:"WX";s:3:"333";s:1:"N";s:1:"f";s:1:"B";a:4:{i:0;s:4:"-169";i:1;s:4:"-205";i:2;s:3:"446";i:3;s:3:"698";}s:1:"L";a:2:{i:0;s:1:"l";i:1;s:2:"fl";}}i:103;a:4:{s:1:"C";s:3:"103";s:2:"WX";s:3:"500";s:1:"N";s:1:"g";s:1:"B";a:4:{i:0;s:3:"-52";i:1;s:4:"-203";i:2;s:3:"478";i:3;s:3:"462";}}s:1:"g";a:4:{s:1:"C";s:3:"103";s:2:"WX";s:3:"500";s:1:"N";s:1:"g";s:1:"B";a:4:{i:0;s:3:"-52";i:1;s:4:"-203";i:2;s:3:"478";i:3;s:3:"462";}}i:104;a:4:{s:1:"C";s:3:"104";s:2:"WX";s:3:"556";s:1:"N";s:1:"h";s:1:"B";a:4:{i:0;s:3:"-13";i:1;s:2:"-9";i:2;s:3:"498";i:3;s:3:"699";}}s:1:"h";a:4:{s:1:"C";s:3:"104";s:2:"WX";s:3:"556";s:1:"N";s:1:"h";s:1:"B";a:4:{i:0;s:3:"-13";i:1;s:2:"-9";i:2;s:3:"498";i:3;s:3:"699";}}i:105;a:4:{s:1:"C";s:3:"105";s:2:"WX";s:3:"278";s:1:"N";s:1:"i";s:1:"B";a:4:{i:0;s:1:"2";i:1;s:2:"-9";i:2;s:3:"263";i:3;s:3:"684";}}s:1:"i";a:4:{s:1:"C";s:3:"105";s:2:"WX";s:3:"278";s:1:"N";s:1:"i";s:1:"B";a:4:{i:0;s:1:"2";i:1;s:2:"-9";i:2;s:3:"263";i:3;s:3:"684";}}i:106;a:4:{s:1:"C";s:3:"106";s:2:"WX";s:3:"278";s:1:"N";s:1:"j";s:1:"B";a:4:{i:0;s:4:"-189";i:1;s:4:"-207";i:2;s:3:"279";i:3;s:3:"684";}}s:1:"j";a:4:{s:1:"C";s:3:"106";s:2:"WX";s:3:"278";s:1:"N";s:1:"j";s:1:"B";a:4:{i:0;s:4:"-189";i:1;s:4:"-207";i:2;s:3:"279";i:3;s:3:"684";}}i:107;a:4:{s:1:"C";s:3:"107";s:2:"WX";s:3:"500";s:1:"N";s:1:"k";s:1:"B";a:4:{i:0;s:3:"-23";i:1;s:2:"-8";i:2;s:3:"483";i:3;s:3:"699";}}s:1:"k";a:4:{s:1:"C";s:3:"107";s:2:"WX";s:3:"500";s:1:"N";s:1:"k";s:1:"B";a:4:{i:0;s:3:"-23";i:1;s:2:"-8";i:2;s:3:"483";i:3;s:3:"699";}}i:108;a:4:{s:1:"C";s:3:"108";s:2:"WX";s:3:"278";s:1:"N";s:1:"l";s:1:"B";a:4:{i:0;s:1:"2";i:1;s:2:"-9";i:2;s:3:"290";i:3;s:3:"699";}}s:1:"l";a:4:{s:1:"C";s:3:"108";s:2:"WX";s:3:"278";s:1:"N";s:1:"l";s:1:"B";a:4:{i:0;s:1:"2";i:1;s:2:"-9";i:2;s:3:"290";i:3;s:3:"699";}}i:109;a:4:{s:1:"C";s:3:"109";s:2:"WX";s:3:"778";s:1:"N";s:1:"m";s:1:"B";a:4:{i:0;s:3:"-14";i:1;s:2:"-9";i:2;s:3:"722";i:3;s:3:"462";}}s:1:"m";a:4:{s:1:"C";s:3:"109";s:2:"WX";s:3:"778";s:1:"N";s:1:"m";s:1:"B";a:4:{i:0;s:3:"-14";i:1;s:2:"-9";i:2;s:3:"722";i:3;s:3:"462";}}i:110;a:4:{s:1:"C";s:3:"110";s:2:"WX";s:3:"556";s:1:"N";s:1:"n";s:1:"B";a:4:{i:0;s:2:"-6";i:1;s:2:"-9";i:2;s:3:"493";i:3;s:3:"462";}}s:1:"n";a:4:{s:1:"C";s:3:"110";s:2:"WX";s:3:"556";s:1:"N";s:1:"n";s:1:"B";a:4:{i:0;s:2:"-6";i:1;s:2:"-9";i:2;s:3:"493";i:3;s:3:"462";}}i:111;a:4:{s:1:"C";s:3:"111";s:2:"WX";s:3:"500";s:1:"N";s:1:"o";s:1:"B";a:4:{i:0;s:2:"-3";i:1;s:3:"-13";i:2;s:3:"441";i:3;s:3:"462";}}s:1:"o";a:4:{s:1:"C";s:3:"111";s:2:"WX";s:3:"500";s:1:"N";s:1:"o";s:1:"B";a:4:{i:0;s:2:"-3";i:1;s:3:"-13";i:2;s:3:"441";i:3;s:3:"462";}}i:112;a:4:{s:1:"C";s:3:"112";s:2:"WX";s:3:"500";s:1:"N";s:1:"p";s:1:"B";a:4:{i:0;s:4:"-120";i:1;s:4:"-205";i:2;s:3:"446";i:3;s:3:"462";}}s:1:"p";a:4:{s:1:"C";s:3:"112";s:2:"WX";s:3:"500";s:1:"N";s:1:"p";s:1:"B";a:4:{i:0;s:4:"-120";i:1;s:4:"-205";i:2;s:3:"446";i:3;s:3:"462";}}i:113;a:4:{s:1:"C";s:3:"113";s:2:"WX";s:3:"500";s:1:"N";s:1:"q";s:1:"B";a:4:{i:0;s:1:"1";i:1;s:4:"-205";i:2;s:3:"471";i:3;s:3:"462";}}s:1:"q";a:4:{s:1:"C";s:3:"113";s:2:"WX";s:3:"500";s:1:"N";s:1:"q";s:1:"B";a:4:{i:0;s:1:"1";i:1;s:4:"-205";i:2;s:3:"471";i:3;s:3:"462";}}i:114;a:4:{s:1:"C";s:3:"114";s:2:"WX";s:3:"389";s:1:"N";s:1:"r";s:1:"B";a:4:{i:0;s:3:"-21";i:1;s:1:"0";i:2;s:3:"389";i:3;s:3:"462";}}s:1:"r";a:4:{s:1:"C";s:3:"114";s:2:"WX";s:3:"389";s:1:"N";s:1:"r";s:1:"B";a:4:{i:0;s:3:"-21";i:1;s:1:"0";i:2;s:3:"389";i:3;s:3:"462";}}i:115;a:4:{s:1:"C";s:3:"115";s:2:"WX";s:3:"389";s:1:"N";s:1:"s";s:1:"B";a:4:{i:0;s:3:"-19";i:1;s:3:"-13";i:2;s:3:"333";i:3;s:3:"462";}}s:1:"s";a:4:{s:1:"C";s:3:"115";s:2:"WX";s:3:"389";s:1:"N";s:1:"s";s:1:"B";a:4:{i:0;s:3:"-19";i:1;s:3:"-13";i:2;s:3:"333";i:3;s:3:"462";}}i:116;a:4:{s:1:"C";s:3:"116";s:2:"WX";s:3:"278";s:1:"N";s:1:"t";s:1:"B";a:4:{i:0;s:3:"-11";i:1;s:2:"-9";i:2;s:3:"281";i:3;s:3:"594";}}s:1:"t";a:4:{s:1:"C";s:3:"116";s:2:"WX";s:3:"278";s:1:"N";s:1:"t";s:1:"B";a:4:{i:0;s:3:"-11";i:1;s:2:"-9";i:2;s:3:"281";i:3;s:3:"594";}}i:117;a:4:{s:1:"C";s:3:"117";s:2:"WX";s:3:"556";s:1:"N";s:1:"u";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:2:"-9";i:2;s:3:"492";i:3;s:3:"462";}}s:1:"u";a:4:{s:1:"C";s:3:"117";s:2:"WX";s:3:"556";s:1:"N";s:1:"u";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:2:"-9";i:2;s:3:"492";i:3;s:3:"462";}}i:118;a:4:{s:1:"C";s:3:"118";s:2:"WX";s:3:"444";s:1:"N";s:1:"v";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-13";i:2;s:3:"401";i:3;s:3:"462";}}s:1:"v";a:4:{s:1:"C";s:3:"118";s:2:"WX";s:3:"444";s:1:"N";s:1:"v";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-13";i:2;s:3:"401";i:3;s:3:"462";}}i:119;a:4:{s:1:"C";s:3:"119";s:2:"WX";s:3:"667";s:1:"N";s:1:"w";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-13";i:2;s:3:"614";i:3;s:3:"462";}}s:1:"w";a:4:{s:1:"C";s:3:"119";s:2:"WX";s:3:"667";s:1:"N";s:1:"w";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-13";i:2;s:3:"614";i:3;s:3:"462";}}i:120;a:4:{s:1:"C";s:3:"120";s:2:"WX";s:3:"500";s:1:"N";s:1:"x";s:1:"B";a:4:{i:0;s:3:"-46";i:1;s:3:"-13";i:2;s:3:"469";i:3;s:3:"462";}}s:1:"x";a:4:{s:1:"C";s:3:"120";s:2:"WX";s:3:"500";s:1:"N";s:1:"x";s:1:"B";a:4:{i:0;s:3:"-46";i:1;s:3:"-13";i:2;s:3:"469";i:3;s:3:"462";}}i:121;a:4:{s:1:"C";s:3:"121";s:2:"WX";s:3:"444";s:1:"N";s:1:"y";s:1:"B";a:4:{i:0;s:3:"-94";i:1;s:4:"-205";i:2;s:3:"392";i:3;s:3:"462";}}s:1:"y";a:4:{s:1:"C";s:3:"121";s:2:"WX";s:3:"444";s:1:"N";s:1:"y";s:1:"B";a:4:{i:0;s:3:"-94";i:1;s:4:"-205";i:2;s:3:"392";i:3;s:3:"462";}}i:122;a:4:{s:1:"C";s:3:"122";s:2:"WX";s:3:"389";s:1:"N";s:1:"z";s:1:"B";a:4:{i:0;s:3:"-43";i:1;s:3:"-78";i:2;s:3:"368";i:3;s:3:"449";}}s:1:"z";a:4:{s:1:"C";s:3:"122";s:2:"WX";s:3:"389";s:1:"N";s:1:"z";s:1:"B";a:4:{i:0;s:3:"-43";i:1;s:3:"-78";i:2;s:3:"368";i:3;s:3:"449";}}i:123;a:4:{s:1:"C";s:3:"123";s:2:"WX";s:3:"348";s:1:"N";s:9:"braceleft";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:4:"-187";i:2;s:3:"436";i:3;s:3:"686";}}s:9:"braceleft";a:4:{s:1:"C";s:3:"123";s:2:"WX";s:3:"348";s:1:"N";s:9:"braceleft";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:4:"-187";i:2;s:3:"436";i:3;s:3:"686";}}i:124;a:4:{s:1:"C";s:3:"124";s:2:"WX";s:3:"220";s:1:"N";s:3:"bar";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:4:"-218";i:2;s:3:"154";i:3;s:3:"782";}}s:3:"bar";a:4:{s:1:"C";s:3:"124";s:2:"WX";s:3:"220";s:1:"N";s:3:"bar";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:4:"-218";i:2;s:3:"154";i:3;s:3:"782";}}i:125;a:4:{s:1:"C";s:3:"125";s:2:"WX";s:3:"348";s:1:"N";s:10:"braceright";s:1:"B";a:4:{i:0;s:4:"-129";i:1;s:4:"-187";i:2;s:3:"302";i:3;s:3:"686";}}s:10:"braceright";a:4:{s:1:"C";s:3:"125";s:2:"WX";s:3:"348";s:1:"N";s:10:"braceright";s:1:"B";a:4:{i:0;s:4:"-129";i:1;s:4:"-187";i:2;s:3:"302";i:3;s:3:"686";}}i:126;a:4:{s:1:"C";s:3:"126";s:2:"WX";s:3:"570";s:1:"N";s:10:"asciitilde";s:1:"B";a:4:{i:0;s:2:"54";i:1;s:3:"173";i:2;s:3:"516";i:3;s:3:"333";}}s:10:"asciitilde";a:4:{s:1:"C";s:3:"126";s:2:"WX";s:3:"570";s:1:"N";s:10:"asciitilde";s:1:"B";a:4:{i:0;s:2:"54";i:1;s:3:"173";i:2;s:3:"516";i:3;s:3:"333";}}i:161;a:4:{s:1:"C";s:3:"161";s:2:"WX";s:3:"389";s:1:"N";s:10:"exclamdown";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:4:"-205";i:2;s:3:"322";i:3;s:3:"492";}}s:10:"exclamdown";a:4:{s:1:"C";s:3:"161";s:2:"WX";s:3:"389";s:1:"N";s:10:"exclamdown";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:4:"-205";i:2;s:3:"322";i:3;s:3:"492";}}i:162;a:4:{s:1:"C";s:3:"162";s:2:"WX";s:3:"500";s:1:"N";s:4:"cent";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:4:"-143";i:2;s:3:"439";i:3;s:3:"576";}}s:4:"cent";a:4:{s:1:"C";s:3:"162";s:2:"WX";s:3:"500";s:1:"N";s:4:"cent";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:4:"-143";i:2;s:3:"439";i:3;s:3:"576";}}i:163;a:4:{s:1:"C";s:3:"163";s:2:"WX";s:3:"500";s:1:"N";s:8:"sterling";s:1:"B";a:4:{i:0;s:3:"-32";i:1;s:3:"-12";i:2;s:3:"510";i:3;s:3:"683";}}s:8:"sterling";a:4:{s:1:"C";s:3:"163";s:2:"WX";s:3:"500";s:1:"N";s:8:"sterling";s:1:"B";a:4:{i:0;s:3:"-32";i:1;s:3:"-12";i:2;s:3:"510";i:3;s:3:"683";}}i:164;a:4:{s:1:"C";s:3:"164";s:2:"WX";s:3:"167";s:1:"N";s:8:"fraction";s:1:"B";a:4:{i:0;s:4:"-169";i:1;s:3:"-14";i:2;s:3:"324";i:3;s:3:"683";}}s:8:"fraction";a:4:{s:1:"C";s:3:"164";s:2:"WX";s:3:"167";s:1:"N";s:8:"fraction";s:1:"B";a:4:{i:0;s:4:"-169";i:1;s:3:"-14";i:2;s:3:"324";i:3;s:3:"683";}}i:165;a:4:{s:1:"C";s:3:"165";s:2:"WX";s:3:"500";s:1:"N";s:3:"yen";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:1:"0";i:2;s:3:"628";i:3;s:3:"669";}}s:3:"yen";a:4:{s:1:"C";s:3:"165";s:2:"WX";s:3:"500";s:1:"N";s:3:"yen";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:1:"0";i:2;s:3:"628";i:3;s:3:"669";}}i:166;a:4:{s:1:"C";s:3:"166";s:2:"WX";s:3:"500";s:1:"N";s:6:"florin";s:1:"B";a:4:{i:0;s:3:"-87";i:1;s:4:"-156";i:2;s:3:"537";i:3;s:3:"707";}}s:6:"florin";a:4:{s:1:"C";s:3:"166";s:2:"WX";s:3:"500";s:1:"N";s:6:"florin";s:1:"B";a:4:{i:0;s:3:"-87";i:1;s:4:"-156";i:2;s:3:"537";i:3;s:3:"707";}}i:167;a:4:{s:1:"C";s:3:"167";s:2:"WX";s:3:"500";s:1:"N";s:7:"section";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:4:"-143";i:2;s:3:"459";i:3;s:3:"685";}}s:7:"section";a:4:{s:1:"C";s:3:"167";s:2:"WX";s:3:"500";s:1:"N";s:7:"section";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:4:"-143";i:2;s:3:"459";i:3;s:3:"685";}}i:168;a:4:{s:1:"C";s:3:"168";s:2:"WX";s:3:"500";s:1:"N";s:8:"currency";s:1:"B";a:4:{i:0;s:3:"-26";i:1;s:2:"34";i:2;s:3:"526";i:3;s:3:"586";}}s:8:"currency";a:4:{s:1:"C";s:3:"168";s:2:"WX";s:3:"500";s:1:"N";s:8:"currency";s:1:"B";a:4:{i:0;s:3:"-26";i:1;s:2:"34";i:2;s:3:"526";i:3;s:3:"586";}}i:169;a:4:{s:1:"C";s:3:"169";s:2:"WX";s:3:"278";s:1:"N";s:11:"quotesingle";s:1:"B";a:4:{i:0;s:3:"128";i:1;s:3:"398";i:2;s:3:"268";i:3;s:3:"685";}}s:11:"quotesingle";a:4:{s:1:"C";s:3:"169";s:2:"WX";s:3:"278";s:1:"N";s:11:"quotesingle";s:1:"B";a:4:{i:0;s:3:"128";i:1;s:3:"398";i:2;s:3:"268";i:3;s:3:"685";}}i:170;a:4:{s:1:"C";s:3:"170";s:2:"WX";s:3:"500";s:1:"N";s:12:"quotedblleft";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:3:"369";i:2;s:3:"513";i:3;s:3:"685";}}s:12:"quotedblleft";a:4:{s:1:"C";s:3:"170";s:2:"WX";s:3:"500";s:1:"N";s:12:"quotedblleft";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:3:"369";i:2;s:3:"513";i:3;s:3:"685";}}i:171;a:4:{s:1:"C";s:3:"171";s:2:"WX";s:3:"500";s:1:"N";s:13:"guillemotleft";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:2:"32";i:2;s:3:"468";i:3;s:3:"415";}}s:13:"guillemotleft";a:4:{s:1:"C";s:3:"171";s:2:"WX";s:3:"500";s:1:"N";s:13:"guillemotleft";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:2:"32";i:2;s:3:"468";i:3;s:3:"415";}}i:172;a:4:{s:1:"C";s:3:"172";s:2:"WX";s:3:"333";s:1:"N";s:13:"guilsinglleft";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:2:"32";i:2;s:3:"303";i:3;s:3:"415";}}s:13:"guilsinglleft";a:4:{s:1:"C";s:3:"172";s:2:"WX";s:3:"333";s:1:"N";s:13:"guilsinglleft";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:2:"32";i:2;s:3:"303";i:3;s:3:"415";}}i:173;a:4:{s:1:"C";s:3:"173";s:2:"WX";s:3:"333";s:1:"N";s:14:"guilsinglright";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:2:"32";i:2;s:3:"281";i:3;s:3:"415";}}s:14:"guilsinglright";a:4:{s:1:"C";s:3:"173";s:2:"WX";s:3:"333";s:1:"N";s:14:"guilsinglright";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:2:"32";i:2;s:3:"281";i:3;s:3:"415";}}i:174;a:4:{s:1:"C";s:3:"174";s:2:"WX";s:3:"556";s:1:"N";s:2:"fi";s:1:"B";a:4:{i:0;s:4:"-188";i:1;s:4:"-205";i:2;s:3:"514";i:3;s:3:"703";}}s:2:"fi";a:4:{s:1:"C";s:3:"174";s:2:"WX";s:3:"556";s:1:"N";s:2:"fi";s:1:"B";a:4:{i:0;s:4:"-188";i:1;s:4:"-205";i:2;s:3:"514";i:3;s:3:"703";}}i:175;a:4:{s:1:"C";s:3:"175";s:2:"WX";s:3:"556";s:1:"N";s:2:"fl";s:1:"B";a:4:{i:0;s:4:"-186";i:1;s:4:"-205";i:2;s:3:"553";i:3;s:3:"704";}}s:2:"fl";a:4:{s:1:"C";s:3:"175";s:2:"WX";s:3:"556";s:1:"N";s:2:"fl";s:1:"B";a:4:{i:0;s:4:"-186";i:1;s:4:"-205";i:2;s:3:"553";i:3;s:3:"704";}}i:177;a:4:{s:1:"C";s:3:"177";s:2:"WX";s:3:"500";s:1:"N";s:6:"endash";s:1:"B";a:4:{i:0;s:3:"-40";i:1;s:3:"178";i:2;s:3:"477";i:3;s:3:"269";}}s:6:"endash";a:4:{s:1:"C";s:3:"177";s:2:"WX";s:3:"500";s:1:"N";s:6:"endash";s:1:"B";a:4:{i:0;s:3:"-40";i:1;s:3:"178";i:2;s:3:"477";i:3;s:3:"269";}}i:178;a:4:{s:1:"C";s:3:"178";s:2:"WX";s:3:"500";s:1:"N";s:6:"dagger";s:1:"B";a:4:{i:0;s:2:"91";i:1;s:4:"-145";i:2;s:3:"494";i:3;s:3:"685";}}s:6:"dagger";a:4:{s:1:"C";s:3:"178";s:2:"WX";s:3:"500";s:1:"N";s:6:"dagger";s:1:"B";a:4:{i:0;s:2:"91";i:1;s:4:"-145";i:2;s:3:"494";i:3;s:3:"685";}}i:179;a:4:{s:1:"C";s:3:"179";s:2:"WX";s:3:"500";s:1:"N";s:9:"daggerdbl";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:4:"-139";i:2;s:3:"493";i:3;s:3:"685";}}s:9:"daggerdbl";a:4:{s:1:"C";s:3:"179";s:2:"WX";s:3:"500";s:1:"N";s:9:"daggerdbl";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:4:"-139";i:2;s:3:"493";i:3;s:3:"685";}}i:180;a:4:{s:1:"C";s:3:"180";s:2:"WX";s:3:"250";s:1:"N";s:14:"periodcentered";s:1:"B";a:4:{i:0;s:2:"51";i:1;s:3:"257";i:2;s:3:"199";i:3;s:3:"405";}}s:14:"periodcentered";a:4:{s:1:"C";s:3:"180";s:2:"WX";s:3:"250";s:1:"N";s:14:"periodcentered";s:1:"B";a:4:{i:0;s:2:"51";i:1;s:3:"257";i:2;s:3:"199";i:3;s:3:"405";}}i:182;a:4:{s:1:"C";s:3:"182";s:2:"WX";s:3:"500";s:1:"N";s:9:"paragraph";s:1:"B";a:4:{i:0;s:3:"-57";i:1;s:4:"-193";i:2;s:3:"562";i:3;s:3:"669";}}s:9:"paragraph";a:4:{s:1:"C";s:3:"182";s:2:"WX";s:3:"500";s:1:"N";s:9:"paragraph";s:1:"B";a:4:{i:0;s:3:"-57";i:1;s:4:"-193";i:2;s:3:"562";i:3;s:3:"669";}}i:183;a:4:{s:1:"C";s:3:"183";s:2:"WX";s:3:"350";s:1:"N";s:6:"bullet";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"175";i:2;s:3:"350";i:3;s:3:"525";}}s:6:"bullet";a:4:{s:1:"C";s:3:"183";s:2:"WX";s:3:"350";s:1:"N";s:6:"bullet";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"175";i:2;s:3:"350";i:3;s:3:"525";}}i:184;a:4:{s:1:"C";s:3:"184";s:2:"WX";s:3:"333";s:1:"N";s:14:"quotesinglbase";s:1:"B";a:4:{i:0;s:2:"-5";i:1;s:4:"-182";i:2;s:3:"199";i:3;s:3:"134";}}s:14:"quotesinglbase";a:4:{s:1:"C";s:3:"184";s:2:"WX";s:3:"333";s:1:"N";s:14:"quotesinglbase";s:1:"B";a:4:{i:0;s:2:"-5";i:1;s:4:"-182";i:2;s:3:"199";i:3;s:3:"134";}}i:185;a:4:{s:1:"C";s:3:"185";s:2:"WX";s:3:"500";s:1:"N";s:12:"quotedblbase";s:1:"B";a:4:{i:0;s:3:"-57";i:1;s:4:"-182";i:2;s:3:"403";i:3;s:3:"134";}}s:12:"quotedblbase";a:4:{s:1:"C";s:3:"185";s:2:"WX";s:3:"500";s:1:"N";s:12:"quotedblbase";s:1:"B";a:4:{i:0;s:3:"-57";i:1;s:4:"-182";i:2;s:3:"403";i:3;s:3:"134";}}i:186;a:4:{s:1:"C";s:3:"186";s:2:"WX";s:3:"500";s:1:"N";s:13:"quotedblright";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:3:"369";i:2;s:3:"513";i:3;s:3:"685";}}s:13:"quotedblright";a:4:{s:1:"C";s:3:"186";s:2:"WX";s:3:"500";s:1:"N";s:13:"quotedblright";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:3:"369";i:2;s:3:"513";i:3;s:3:"685";}}i:187;a:4:{s:1:"C";s:3:"187";s:2:"WX";s:3:"500";s:1:"N";s:14:"guillemotright";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:2:"32";i:2;s:3:"468";i:3;s:3:"415";}}s:14:"guillemotright";a:4:{s:1:"C";s:3:"187";s:2:"WX";s:3:"500";s:1:"N";s:14:"guillemotright";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:2:"32";i:2;s:3:"468";i:3;s:3:"415";}}i:188;a:4:{s:1:"C";s:3:"188";s:2:"WX";s:4:"1000";s:1:"N";s:8:"ellipsis";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"-13";i:2;s:3:"852";i:3;s:3:"135";}}s:8:"ellipsis";a:4:{s:1:"C";s:3:"188";s:2:"WX";s:4:"1000";s:1:"N";s:8:"ellipsis";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"-13";i:2;s:3:"852";i:3;s:3:"135";}}i:189;a:4:{s:1:"C";s:3:"189";s:2:"WX";s:4:"1000";s:1:"N";s:11:"perthousand";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:3:"-29";i:2;s:3:"996";i:3;s:3:"706";}}s:11:"perthousand";a:4:{s:1:"C";s:3:"189";s:2:"WX";s:4:"1000";s:1:"N";s:11:"perthousand";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:3:"-29";i:2;s:3:"996";i:3;s:3:"706";}}i:191;a:4:{s:1:"C";s:3:"191";s:2:"WX";s:3:"500";s:1:"N";s:12:"questiondown";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:4:"-205";i:2;s:3:"421";i:3;s:3:"492";}}s:12:"questiondown";a:4:{s:1:"C";s:3:"191";s:2:"WX";s:3:"500";s:1:"N";s:12:"questiondown";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:4:"-205";i:2;s:3:"421";i:3;s:3:"492";}}i:193;a:4:{s:1:"C";s:3:"193";s:2:"WX";s:3:"333";s:1:"N";s:5:"grave";s:1:"B";a:4:{i:0;s:2:"85";i:1;s:3:"516";i:2;s:3:"297";i:3;s:3:"697";}}s:5:"grave";a:4:{s:1:"C";s:3:"193";s:2:"WX";s:3:"333";s:1:"N";s:5:"grave";s:1:"B";a:4:{i:0;s:2:"85";i:1;s:3:"516";i:2;s:3:"297";i:3;s:3:"697";}}i:194;a:4:{s:1:"C";s:3:"194";s:2:"WX";s:3:"333";s:1:"N";s:5:"acute";s:1:"B";a:4:{i:0;s:3:"139";i:1;s:3:"516";i:2;s:3:"379";i:3;s:3:"697";}}s:5:"acute";a:4:{s:1:"C";s:3:"194";s:2:"WX";s:3:"333";s:1:"N";s:5:"acute";s:1:"B";a:4:{i:0;s:3:"139";i:1;s:3:"516";i:2;s:3:"379";i:3;s:3:"697";}}i:195;a:4:{s:1:"C";s:3:"195";s:2:"WX";s:3:"333";s:1:"N";s:10:"circumflex";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"516";i:2;s:3:"367";i:3;s:3:"690";}}s:10:"circumflex";a:4:{s:1:"C";s:3:"195";s:2:"WX";s:3:"333";s:1:"N";s:10:"circumflex";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"516";i:2;s:3:"367";i:3;s:3:"690";}}i:196;a:4:{s:1:"C";s:3:"196";s:2:"WX";s:3:"333";s:1:"N";s:5:"tilde";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:3:"536";i:2;s:3:"407";i:3;s:3:"655";}}s:5:"tilde";a:4:{s:1:"C";s:3:"196";s:2:"WX";s:3:"333";s:1:"N";s:5:"tilde";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:3:"536";i:2;s:3:"407";i:3;s:3:"655";}}i:197;a:4:{s:1:"C";s:3:"197";s:2:"WX";s:3:"333";s:1:"N";s:6:"macron";s:1:"B";a:4:{i:0;s:2:"51";i:1;s:3:"553";i:2;s:3:"393";i:3;s:3:"623";}}s:6:"macron";a:4:{s:1:"C";s:3:"197";s:2:"WX";s:3:"333";s:1:"N";s:6:"macron";s:1:"B";a:4:{i:0;s:2:"51";i:1;s:3:"553";i:2;s:3:"393";i:3;s:3:"623";}}i:198;a:4:{s:1:"C";s:3:"198";s:2:"WX";s:3:"333";s:1:"N";s:5:"breve";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:3:"516";i:2;s:3:"387";i:3;s:3:"678";}}s:5:"breve";a:4:{s:1:"C";s:3:"198";s:2:"WX";s:3:"333";s:1:"N";s:5:"breve";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:3:"516";i:2;s:3:"387";i:3;s:3:"678";}}i:199;a:4:{s:1:"C";s:3:"199";s:2:"WX";s:3:"333";s:1:"N";s:9:"dotaccent";s:1:"B";a:4:{i:0;s:3:"163";i:1;s:3:"550";i:2;s:3:"298";i:3;s:3:"684";}}s:9:"dotaccent";a:4:{s:1:"C";s:3:"199";s:2:"WX";s:3:"333";s:1:"N";s:9:"dotaccent";s:1:"B";a:4:{i:0;s:3:"163";i:1;s:3:"550";i:2;s:3:"298";i:3;s:3:"684";}}i:200;a:4:{s:1:"C";s:3:"200";s:2:"WX";s:3:"333";s:1:"N";s:8:"dieresis";s:1:"B";a:4:{i:0;s:2:"55";i:1;s:3:"550";i:2;s:3:"402";i:3;s:3:"684";}}s:8:"dieresis";a:4:{s:1:"C";s:3:"200";s:2:"WX";s:3:"333";s:1:"N";s:8:"dieresis";s:1:"B";a:4:{i:0;s:2:"55";i:1;s:3:"550";i:2;s:3:"402";i:3;s:3:"684";}}i:202;a:4:{s:1:"C";s:3:"202";s:2:"WX";s:3:"333";s:1:"N";s:4:"ring";s:1:"B";a:4:{i:0;s:3:"127";i:1;s:3:"516";i:2;s:3:"340";i:3;s:3:"729";}}s:4:"ring";a:4:{s:1:"C";s:3:"202";s:2:"WX";s:3:"333";s:1:"N";s:4:"ring";s:1:"B";a:4:{i:0;s:3:"127";i:1;s:3:"516";i:2;s:3:"340";i:3;s:3:"729";}}i:203;a:4:{s:1:"C";s:3:"203";s:2:"WX";s:3:"333";s:1:"N";s:7:"cedilla";s:1:"B";a:4:{i:0;s:3:"-80";i:1;s:4:"-218";i:2;s:3:"156";i:3;s:1:"5";}}s:7:"cedilla";a:4:{s:1:"C";s:3:"203";s:2:"WX";s:3:"333";s:1:"N";s:7:"cedilla";s:1:"B";a:4:{i:0;s:3:"-80";i:1;s:4:"-218";i:2;s:3:"156";i:3;s:1:"5";}}i:205;a:4:{s:1:"C";s:3:"205";s:2:"WX";s:3:"333";s:1:"N";s:12:"hungarumlaut";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:3:"516";i:2;s:3:"498";i:3;s:3:"697";}}s:12:"hungarumlaut";a:4:{s:1:"C";s:3:"205";s:2:"WX";s:3:"333";s:1:"N";s:12:"hungarumlaut";s:1:"B";a:4:{i:0;s:2:"69";i:1;s:3:"516";i:2;s:3:"498";i:3;s:3:"697";}}i:206;a:4:{s:1:"C";s:3:"206";s:2:"WX";s:3:"333";s:1:"N";s:6:"ogonek";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:4:"-183";i:2;s:3:"244";i:3;s:2:"34";}}s:6:"ogonek";a:4:{s:1:"C";s:3:"206";s:2:"WX";s:3:"333";s:1:"N";s:6:"ogonek";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:4:"-183";i:2;s:3:"244";i:3;s:2:"34";}}i:207;a:4:{s:1:"C";s:3:"207";s:2:"WX";s:3:"333";s:1:"N";s:5:"caron";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:3:"516";i:2;s:3:"411";i:3;s:3:"690";}}s:5:"caron";a:4:{s:1:"C";s:3:"207";s:2:"WX";s:3:"333";s:1:"N";s:5:"caron";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:3:"516";i:2;s:3:"411";i:3;s:3:"690";}}i:208;a:4:{s:1:"C";s:3:"208";s:2:"WX";s:4:"1000";s:1:"N";s:6:"emdash";s:1:"B";a:4:{i:0;s:3:"-40";i:1;s:3:"178";i:2;s:3:"977";i:3;s:3:"269";}}s:6:"emdash";a:4:{s:1:"C";s:3:"208";s:2:"WX";s:4:"1000";s:1:"N";s:6:"emdash";s:1:"B";a:4:{i:0;s:3:"-40";i:1;s:3:"178";i:2;s:3:"977";i:3;s:3:"269";}}i:225;a:4:{s:1:"C";s:3:"225";s:2:"WX";s:3:"944";s:1:"N";s:2:"AE";s:1:"B";a:4:{i:0;s:3:"-64";i:1;s:1:"0";i:2;s:3:"918";i:3;s:3:"669";}}s:2:"AE";a:4:{s:1:"C";s:3:"225";s:2:"WX";s:3:"944";s:1:"N";s:2:"AE";s:1:"B";a:4:{i:0;s:3:"-64";i:1;s:1:"0";i:2;s:3:"918";i:3;s:3:"669";}}i:227;a:4:{s:1:"C";s:3:"227";s:2:"WX";s:3:"266";s:1:"N";s:11:"ordfeminine";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"399";i:2;s:3:"330";i:3;s:3:"685";}}s:11:"ordfeminine";a:4:{s:1:"C";s:3:"227";s:2:"WX";s:3:"266";s:1:"N";s:11:"ordfeminine";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"399";i:2;s:3:"330";i:3;s:3:"685";}}i:232;a:4:{s:1:"C";s:3:"232";s:2:"WX";s:3:"611";s:1:"N";s:6:"Lslash";s:1:"B";a:4:{i:0;s:3:"-22";i:1;s:1:"0";i:2;s:3:"590";i:3;s:3:"669";}}s:6:"Lslash";a:4:{s:1:"C";s:3:"232";s:2:"WX";s:3:"611";s:1:"N";s:6:"Lslash";s:1:"B";a:4:{i:0;s:3:"-22";i:1;s:1:"0";i:2;s:3:"590";i:3;s:3:"669";}}i:233;a:4:{s:1:"C";s:3:"233";s:2:"WX";s:3:"722";s:1:"N";s:6:"Oslash";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:4:"-125";i:2;s:3:"691";i:3;s:3:"764";}}s:6:"Oslash";a:4:{s:1:"C";s:3:"233";s:2:"WX";s:3:"722";s:1:"N";s:6:"Oslash";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:4:"-125";i:2;s:3:"691";i:3;s:3:"764";}}i:234;a:4:{s:1:"C";s:3:"234";s:2:"WX";s:3:"944";s:1:"N";s:2:"OE";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:2:"-8";i:2;s:3:"946";i:3;s:3:"677";}}s:2:"OE";a:4:{s:1:"C";s:3:"234";s:2:"WX";s:3:"944";s:1:"N";s:2:"OE";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:2:"-8";i:2;s:3:"946";i:3;s:3:"677";}}i:235;a:4:{s:1:"C";s:3:"235";s:2:"WX";s:3:"300";s:1:"N";s:12:"ordmasculine";s:1:"B";a:4:{i:0;s:2:"56";i:1;s:3:"400";i:2;s:3:"347";i:3;s:3:"685";}}s:12:"ordmasculine";a:4:{s:1:"C";s:3:"235";s:2:"WX";s:3:"300";s:1:"N";s:12:"ordmasculine";s:1:"B";a:4:{i:0;s:2:"56";i:1;s:3:"400";i:2;s:3:"347";i:3;s:3:"685";}}i:241;a:4:{s:1:"C";s:3:"241";s:2:"WX";s:3:"722";s:1:"N";s:2:"ae";s:1:"B";a:4:{i:0;s:2:"-5";i:1;s:3:"-13";i:2;s:3:"673";i:3;s:3:"462";}}s:2:"ae";a:4:{s:1:"C";s:3:"241";s:2:"WX";s:3:"722";s:1:"N";s:2:"ae";s:1:"B";a:4:{i:0;s:2:"-5";i:1;s:3:"-13";i:2;s:3:"673";i:3;s:3:"462";}}i:245;a:4:{s:1:"C";s:3:"245";s:2:"WX";s:3:"278";s:1:"N";s:8:"dotlessi";s:1:"B";a:4:{i:0;s:1:"2";i:1;s:2:"-9";i:2;s:3:"238";i:3;s:3:"462";}}s:8:"dotlessi";a:4:{s:1:"C";s:3:"245";s:2:"WX";s:3:"278";s:1:"N";s:8:"dotlessi";s:1:"B";a:4:{i:0;s:1:"2";i:1;s:2:"-9";i:2;s:3:"238";i:3;s:3:"462";}}i:248;a:4:{s:1:"C";s:3:"248";s:2:"WX";s:3:"278";s:1:"N";s:6:"lslash";s:1:"B";a:4:{i:0;s:2:"-7";i:1;s:2:"-9";i:2;s:3:"307";i:3;s:3:"699";}}s:6:"lslash";a:4:{s:1:"C";s:3:"248";s:2:"WX";s:3:"278";s:1:"N";s:6:"lslash";s:1:"B";a:4:{i:0;s:2:"-7";i:1;s:2:"-9";i:2;s:3:"307";i:3;s:3:"699";}}i:249;a:4:{s:1:"C";s:3:"249";s:2:"WX";s:3:"500";s:1:"N";s:6:"oslash";s:1:"B";a:4:{i:0;s:2:"-3";i:1;s:4:"-119";i:2;s:3:"441";i:3;s:3:"560";}}s:6:"oslash";a:4:{s:1:"C";s:3:"249";s:2:"WX";s:3:"500";s:1:"N";s:6:"oslash";s:1:"B";a:4:{i:0;s:2:"-3";i:1;s:4:"-119";i:2;s:3:"441";i:3;s:3:"560";}}i:250;a:4:{s:1:"C";s:3:"250";s:2:"WX";s:3:"722";s:1:"N";s:2:"oe";s:1:"B";a:4:{i:0;s:1:"6";i:1;s:3:"-13";i:2;s:3:"674";i:3;s:3:"462";}}s:2:"oe";a:4:{s:1:"C";s:3:"250";s:2:"WX";s:3:"722";s:1:"N";s:2:"oe";s:1:"B";a:4:{i:0;s:1:"6";i:1;s:3:"-13";i:2;s:3:"674";i:3;s:3:"462";}}i:251;a:4:{s:1:"C";s:3:"251";s:2:"WX";s:3:"500";s:1:"N";s:10:"germandbls";s:1:"B";a:4:{i:0;s:4:"-200";i:1;s:4:"-200";i:2;s:3:"473";i:3;s:3:"705";}}s:10:"germandbls";a:4:{s:1:"C";s:3:"251";s:2:"WX";s:3:"500";s:1:"N";s:10:"germandbls";s:1:"B";a:4:{i:0;s:4:"-200";i:1;s:4:"-200";i:2;s:3:"473";i:3;s:3:"705";}}s:9:"Idieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:9:"Idieresis";s:1:"B";a:4:{i:0;s:3:"-32";i:1;s:1:"0";i:2;s:3:"450";i:3;s:3:"862";}}s:6:"eacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:6:"eacute";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:3:"-13";i:2;s:3:"435";i:3;s:3:"697";}}s:6:"abreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"abreve";s:1:"B";a:4:{i:0;s:3:"-21";i:1;s:3:"-14";i:2;s:3:"471";i:3;s:3:"678";}}s:13:"uhungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:13:"uhungarumlaut";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:2:"-9";i:2;s:3:"610";i:3;s:3:"697";}}s:6:"ecaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:6:"ecaron";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:3:"-13";i:2;s:3:"467";i:3;s:3:"690";}}s:9:"Ydieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:9:"Ydieresis";s:1:"B";a:4:{i:0;s:2:"73";i:1;s:1:"0";i:2;s:3:"659";i:3;s:3:"862";}}s:6:"divide";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"570";s:1:"N";s:6:"divide";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:3:"-29";i:2;s:3:"537";i:3;s:3:"535";}}s:6:"Yacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"Yacute";s:1:"B";a:4:{i:0;s:2:"73";i:1;s:1:"0";i:2;s:3:"659";i:3;s:3:"904";}}s:11:"Acircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:11:"Acircumflex";s:1:"B";a:4:{i:0;s:3:"-67";i:1;s:1:"0";i:2;s:3:"593";i:3;s:3:"897";}}s:6:"aacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"aacute";s:1:"B";a:4:{i:0;s:3:"-21";i:1;s:3:"-14";i:2;s:3:"463";i:3;s:3:"697";}}s:11:"Ucircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:11:"Ucircumflex";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:3:"-18";i:2;s:3:"744";i:3;s:3:"897";}}s:6:"yacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:6:"yacute";s:1:"B";a:4:{i:0;s:3:"-94";i:1;s:4:"-205";i:2;s:3:"435";i:3;s:3:"697";}}s:12:"scommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:12:"scommaaccent";s:1:"B";a:4:{i:0;s:3:"-19";i:1;s:4:"-218";i:2;s:3:"333";i:3;s:3:"462";}}s:11:"ecircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:11:"ecircumflex";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:3:"-13";i:2;s:3:"423";i:3;s:3:"690";}}s:5:"Uring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:5:"Uring";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:3:"-18";i:2;s:3:"744";i:3;s:3:"921";}}s:9:"Udieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:9:"Udieresis";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:3:"-18";i:2;s:3:"744";i:3;s:3:"862";}}s:7:"aogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:7:"aogonek";s:1:"B";a:4:{i:0;s:3:"-21";i:1;s:4:"-183";i:2;s:3:"455";i:3;s:3:"462";}}s:6:"Uacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Uacute";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:3:"-18";i:2;s:3:"744";i:3;s:3:"904";}}s:7:"uogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:7:"uogonek";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:4:"-183";i:2;s:3:"492";i:3;s:3:"462";}}s:9:"Edieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:9:"Edieresis";s:1:"B";a:4:{i:0;s:3:"-27";i:1;s:1:"0";i:2;s:3:"653";i:3;s:3:"862";}}s:6:"Dcroat";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Dcroat";s:1:"B";a:4:{i:0;s:3:"-31";i:1;s:1:"0";i:2;s:3:"700";i:3;s:3:"669";}}s:11:"commaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"250";s:1:"N";s:11:"commaaccent";s:1:"B";a:4:{i:0;s:3:"-36";i:1;s:4:"-218";i:2;s:3:"131";i:3;s:3:"-50";}}s:9:"copyright";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"747";s:1:"N";s:9:"copyright";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-18";i:2;s:3:"718";i:3;s:3:"685";}}s:7:"Emacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:7:"Emacron";s:1:"B";a:4:{i:0;s:3:"-27";i:1;s:1:"0";i:2;s:3:"653";i:3;s:3:"830";}}s:6:"ccaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:6:"ccaron";s:1:"B";a:4:{i:0;s:2:"-5";i:1;s:3:"-13";i:2;s:3:"467";i:3;s:3:"690";}}s:5:"aring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:5:"aring";s:1:"B";a:4:{i:0;s:3:"-21";i:1;s:3:"-14";i:2;s:3:"455";i:3;s:3:"729";}}s:12:"Ncommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:12:"Ncommaaccent";s:1:"B";a:4:{i:0;s:3:"-27";i:1;s:4:"-218";i:2;s:3:"748";i:3;s:3:"669";}}s:6:"lacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:6:"lacute";s:1:"B";a:4:{i:0;s:1:"2";i:1;s:2:"-9";i:2;s:3:"392";i:3;s:3:"904";}}s:6:"agrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"agrave";s:1:"B";a:4:{i:0;s:3:"-21";i:1;s:3:"-14";i:2;s:3:"455";i:3;s:3:"697";}}s:12:"Tcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:12:"Tcommaaccent";s:1:"B";a:4:{i:0;s:2:"50";i:1;s:4:"-218";i:2;s:3:"650";i:3;s:3:"669";}}s:6:"Cacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Cacute";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:3:"-18";i:2;s:3:"677";i:3;s:3:"904";}}s:6:"atilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"atilde";s:1:"B";a:4:{i:0;s:3:"-21";i:1;s:3:"-14";i:2;s:3:"491";i:3;s:3:"655";}}s:10:"Edotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:10:"Edotaccent";s:1:"B";a:4:{i:0;s:3:"-27";i:1;s:1:"0";i:2;s:3:"653";i:3;s:3:"862";}}s:6:"scaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:6:"scaron";s:1:"B";a:4:{i:0;s:3:"-19";i:1;s:3:"-13";i:2;s:3:"424";i:3;s:3:"690";}}s:8:"scedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:8:"scedilla";s:1:"B";a:4:{i:0;s:3:"-19";i:1;s:4:"-218";i:2;s:3:"333";i:3;s:3:"462";}}s:6:"iacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:6:"iacute";s:1:"B";a:4:{i:0;s:1:"2";i:1;s:2:"-9";i:2;s:3:"352";i:3;s:3:"697";}}s:7:"lozenge";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"494";s:1:"N";s:7:"lozenge";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:1:"0";i:2;s:3:"484";i:3;s:3:"745";}}s:6:"Rcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Rcaron";s:1:"B";a:4:{i:0;s:3:"-29";i:1;s:1:"0";i:2;s:3:"623";i:3;s:3:"897";}}s:12:"Gcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:12:"Gcommaaccent";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:4:"-218";i:2;s:3:"706";i:3;s:3:"685";}}s:11:"ucircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:11:"ucircumflex";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:2:"-9";i:2;s:3:"492";i:3;s:3:"690";}}s:11:"acircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:11:"acircumflex";s:1:"B";a:4:{i:0;s:3:"-21";i:1;s:3:"-14";i:2;s:3:"455";i:3;s:3:"690";}}s:7:"Amacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:7:"Amacron";s:1:"B";a:4:{i:0;s:3:"-67";i:1;s:1:"0";i:2;s:3:"593";i:3;s:3:"830";}}s:6:"rcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:6:"rcaron";s:1:"B";a:4:{i:0;s:3:"-21";i:1;s:1:"0";i:2;s:3:"424";i:3;s:3:"690";}}s:8:"ccedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:8:"ccedilla";s:1:"B";a:4:{i:0;s:2:"-5";i:1;s:4:"-218";i:2;s:3:"392";i:3;s:3:"462";}}s:10:"Zdotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:10:"Zdotaccent";s:1:"B";a:4:{i:0;s:3:"-11";i:1;s:1:"0";i:2;s:3:"590";i:3;s:3:"862";}}s:5:"Thorn";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:5:"Thorn";s:1:"B";a:4:{i:0;s:3:"-27";i:1;s:1:"0";i:2;s:3:"573";i:3;s:3:"669";}}s:7:"Omacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:7:"Omacron";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:3:"-18";i:2;s:3:"691";i:3;s:3:"830";}}s:6:"Racute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Racute";s:1:"B";a:4:{i:0;s:3:"-29";i:1;s:1:"0";i:2;s:3:"623";i:3;s:3:"904";}}s:6:"Sacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"Sacute";s:1:"B";a:4:{i:0;s:1:"2";i:1;s:3:"-18";i:2;s:3:"531";i:3;s:3:"904";}}s:6:"dcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"608";s:1:"N";s:6:"dcaron";s:1:"B";a:4:{i:0;s:3:"-21";i:1;s:3:"-13";i:2;s:3:"675";i:3;s:3:"708";}}s:7:"Umacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:7:"Umacron";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:3:"-18";i:2;s:3:"744";i:3;s:3:"830";}}s:5:"uring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:5:"uring";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:2:"-9";i:2;s:3:"492";i:3;s:3:"729";}}s:13:"threesuperior";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"300";s:1:"N";s:13:"threesuperior";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:3:"265";i:2;s:3:"321";i:3;s:3:"683";}}s:6:"Ograve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Ograve";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:3:"-18";i:2;s:3:"691";i:3;s:3:"904";}}s:6:"Agrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Agrave";s:1:"B";a:4:{i:0;s:3:"-67";i:1;s:1:"0";i:2;s:3:"593";i:3;s:3:"904";}}s:6:"Abreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Abreve";s:1:"B";a:4:{i:0;s:3:"-67";i:1;s:1:"0";i:2;s:3:"593";i:3;s:3:"885";}}s:8:"multiply";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"570";s:1:"N";s:8:"multiply";s:1:"B";a:4:{i:0;s:2:"48";i:1;s:2:"16";i:2;s:3:"522";i:3;s:3:"490";}}s:6:"uacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"uacute";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:2:"-9";i:2;s:3:"492";i:3;s:3:"697";}}s:6:"Tcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"Tcaron";s:1:"B";a:4:{i:0;s:2:"50";i:1;s:1:"0";i:2;s:3:"650";i:3;s:3:"897";}}s:11:"partialdiff";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"494";s:1:"N";s:11:"partialdiff";s:1:"B";a:4:{i:0;s:2:"11";i:1;s:3:"-21";i:2;s:3:"494";i:3;s:3:"750";}}s:9:"ydieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:9:"ydieresis";s:1:"B";a:4:{i:0;s:3:"-94";i:1;s:4:"-205";i:2;s:3:"443";i:3;s:3:"655";}}s:6:"Nacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Nacute";s:1:"B";a:4:{i:0;s:3:"-27";i:1;s:3:"-15";i:2;s:3:"748";i:3;s:3:"904";}}s:11:"icircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:11:"icircumflex";s:1:"B";a:4:{i:0;s:2:"-3";i:1;s:2:"-9";i:2;s:3:"324";i:3;s:3:"690";}}s:11:"Ecircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:11:"Ecircumflex";s:1:"B";a:4:{i:0;s:3:"-27";i:1;s:1:"0";i:2;s:3:"653";i:3;s:3:"897";}}s:9:"adieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:9:"adieresis";s:1:"B";a:4:{i:0;s:3:"-21";i:1;s:3:"-14";i:2;s:3:"476";i:3;s:3:"655";}}s:9:"edieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:9:"edieresis";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:3:"-13";i:2;s:3:"448";i:3;s:3:"655";}}s:6:"cacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:6:"cacute";s:1:"B";a:4:{i:0;s:2:"-5";i:1;s:3:"-13";i:2;s:3:"435";i:3;s:3:"697";}}s:6:"nacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"nacute";s:1:"B";a:4:{i:0;s:2:"-6";i:1;s:2:"-9";i:2;s:3:"493";i:3;s:3:"697";}}s:7:"umacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:7:"umacron";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:2:"-9";i:2;s:3:"492";i:3;s:3:"623";}}s:6:"Ncaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Ncaron";s:1:"B";a:4:{i:0;s:3:"-27";i:1;s:3:"-15";i:2;s:3:"748";i:3;s:3:"897";}}s:6:"Iacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:6:"Iacute";s:1:"B";a:4:{i:0;s:3:"-32";i:1;s:1:"0";i:2;s:3:"432";i:3;s:3:"904";}}s:9:"plusminus";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"570";s:1:"N";s:9:"plusminus";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:1:"0";i:2;s:3:"537";i:3;s:3:"506";}}s:9:"brokenbar";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"220";s:1:"N";s:9:"brokenbar";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:4:"-143";i:2;s:3:"154";i:3;s:3:"707";}}s:10:"registered";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"747";s:1:"N";s:10:"registered";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-18";i:2;s:3:"718";i:3;s:3:"685";}}s:6:"Gbreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Gbreve";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:3:"-18";i:2;s:3:"706";i:3;s:3:"885";}}s:10:"Idotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:10:"Idotaccent";s:1:"B";a:4:{i:0;s:3:"-32";i:1;s:1:"0";i:2;s:3:"406";i:3;s:3:"862";}}s:9:"summation";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"summation";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:3:"-10";i:2;s:3:"585";i:3;s:3:"706";}}s:6:"Egrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Egrave";s:1:"B";a:4:{i:0;s:3:"-27";i:1;s:1:"0";i:2;s:3:"653";i:3;s:3:"904";}}s:6:"racute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:6:"racute";s:1:"B";a:4:{i:0;s:3:"-21";i:1;s:1:"0";i:2;s:3:"407";i:3;s:3:"697";}}s:7:"omacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:7:"omacron";s:1:"B";a:4:{i:0;s:2:"-3";i:1;s:3:"-13";i:2;s:3:"462";i:3;s:3:"623";}}s:6:"Zacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"Zacute";s:1:"B";a:4:{i:0;s:3:"-11";i:1;s:1:"0";i:2;s:3:"590";i:3;s:3:"904";}}s:6:"Zcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"Zcaron";s:1:"B";a:4:{i:0;s:3:"-11";i:1;s:1:"0";i:2;s:3:"590";i:3;s:3:"897";}}s:12:"greaterequal";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"549";s:1:"N";s:12:"greaterequal";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"523";i:3;s:3:"704";}}s:3:"Eth";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:3:"Eth";s:1:"B";a:4:{i:0;s:3:"-31";i:1;s:1:"0";i:2;s:3:"700";i:3;s:3:"669";}}s:8:"Ccedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:8:"Ccedilla";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:4:"-218";i:2;s:3:"677";i:3;s:3:"685";}}s:12:"lcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:12:"lcommaaccent";s:1:"B";a:4:{i:0;s:3:"-42";i:1;s:4:"-218";i:2;s:3:"290";i:3;s:3:"699";}}s:6:"tcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"366";s:1:"N";s:6:"tcaron";s:1:"B";a:4:{i:0;s:3:"-11";i:1;s:2:"-9";i:2;s:3:"434";i:3;s:3:"754";}}s:7:"eogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:7:"eogonek";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:4:"-183";i:2;s:3:"398";i:3;s:3:"462";}}s:7:"Uogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:7:"Uogonek";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:4:"-183";i:2;s:3:"744";i:3;s:3:"669";}}s:6:"Aacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Aacute";s:1:"B";a:4:{i:0;s:3:"-67";i:1;s:1:"0";i:2;s:3:"593";i:3;s:3:"904";}}s:9:"Adieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:9:"Adieresis";s:1:"B";a:4:{i:0;s:3:"-67";i:1;s:1:"0";i:2;s:3:"593";i:3;s:3:"862";}}s:6:"egrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:6:"egrave";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:3:"-13";i:2;s:3:"398";i:3;s:3:"697";}}s:6:"zacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:6:"zacute";s:1:"B";a:4:{i:0;s:3:"-43";i:1;s:3:"-78";i:2;s:3:"407";i:3;s:3:"697";}}s:7:"iogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:7:"iogonek";s:1:"B";a:4:{i:0;s:3:"-20";i:1;s:4:"-183";i:2;s:3:"263";i:3;s:3:"684";}}s:6:"Oacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Oacute";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:3:"-18";i:2;s:3:"691";i:3;s:3:"904";}}s:6:"oacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"oacute";s:1:"B";a:4:{i:0;s:2:"-3";i:1;s:3:"-13";i:2;s:3:"463";i:3;s:3:"697";}}s:7:"amacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:7:"amacron";s:1:"B";a:4:{i:0;s:3:"-21";i:1;s:3:"-14";i:2;s:3:"467";i:3;s:3:"623";}}s:6:"sacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:6:"sacute";s:1:"B";a:4:{i:0;s:3:"-19";i:1;s:3:"-13";i:2;s:3:"407";i:3;s:3:"697";}}s:9:"idieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:9:"idieresis";s:1:"B";a:4:{i:0;s:1:"2";i:1;s:2:"-9";i:2;s:3:"364";i:3;s:3:"655";}}s:11:"Ocircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:11:"Ocircumflex";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:3:"-18";i:2;s:3:"691";i:3;s:3:"897";}}s:6:"Ugrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Ugrave";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:3:"-18";i:2;s:3:"744";i:3;s:3:"904";}}s:5:"Delta";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"612";s:1:"N";s:5:"Delta";s:1:"B";a:4:{i:0;s:1:"6";i:1;s:1:"0";i:2;s:3:"608";i:3;s:3:"688";}}s:5:"thorn";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:5:"thorn";s:1:"B";a:4:{i:0;s:4:"-120";i:1;s:4:"-205";i:2;s:3:"446";i:3;s:3:"699";}}s:11:"twosuperior";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"300";s:1:"N";s:11:"twosuperior";s:1:"B";a:4:{i:0;s:1:"2";i:1;s:3:"274";i:2;s:3:"313";i:3;s:3:"683";}}s:9:"Odieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:9:"Odieresis";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:3:"-18";i:2;s:3:"691";i:3;s:3:"862";}}s:2:"mu";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"576";s:1:"N";s:2:"mu";s:1:"B";a:4:{i:0;s:3:"-60";i:1;s:4:"-207";i:2;s:3:"516";i:3;s:3:"449";}}s:6:"igrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:6:"igrave";s:1:"B";a:4:{i:0;s:1:"2";i:1;s:2:"-9";i:2;s:3:"259";i:3;s:3:"697";}}s:13:"ohungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:13:"ohungarumlaut";s:1:"B";a:4:{i:0;s:2:"-3";i:1;s:3:"-13";i:2;s:3:"582";i:3;s:3:"697";}}s:7:"Eogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:7:"Eogonek";s:1:"B";a:4:{i:0;s:3:"-27";i:1;s:4:"-183";i:2;s:3:"653";i:3;s:3:"669";}}s:6:"dcroat";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"dcroat";s:1:"B";a:4:{i:0;s:3:"-21";i:1;s:3:"-13";i:2;s:3:"552";i:3;s:3:"699";}}s:13:"threequarters";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"750";s:1:"N";s:13:"threequarters";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:3:"-14";i:2;s:3:"726";i:3;s:3:"683";}}s:8:"Scedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:8:"Scedilla";s:1:"B";a:4:{i:0;s:1:"2";i:1;s:4:"-218";i:2;s:3:"526";i:3;s:3:"685";}}s:6:"lcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"382";s:1:"N";s:6:"lcaron";s:1:"B";a:4:{i:0;s:1:"2";i:1;s:2:"-9";i:2;s:3:"448";i:3;s:3:"708";}}s:12:"Kcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:12:"Kcommaaccent";s:1:"B";a:4:{i:0;s:3:"-21";i:1;s:4:"-218";i:2;s:3:"702";i:3;s:3:"669";}}s:6:"Lacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"Lacute";s:1:"B";a:4:{i:0;s:3:"-22";i:1;s:1:"0";i:2;s:3:"590";i:3;s:3:"904";}}s:9:"trademark";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:4:"1000";s:1:"N";s:9:"trademark";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:3:"263";i:2;s:3:"968";i:3;s:3:"669";}}s:10:"edotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:10:"edotaccent";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:3:"-13";i:2;s:3:"398";i:3;s:3:"655";}}s:6:"Igrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:6:"Igrave";s:1:"B";a:4:{i:0;s:3:"-32";i:1;s:1:"0";i:2;s:3:"406";i:3;s:3:"904";}}s:7:"Imacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:7:"Imacron";s:1:"B";a:4:{i:0;s:3:"-32";i:1;s:1:"0";i:2;s:3:"461";i:3;s:3:"830";}}s:6:"Lcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"Lcaron";s:1:"B";a:4:{i:0;s:3:"-22";i:1;s:1:"0";i:2;s:3:"671";i:3;s:3:"718";}}s:7:"onehalf";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"750";s:1:"N";s:7:"onehalf";s:1:"B";a:4:{i:0;s:2:"-9";i:1;s:3:"-14";i:2;s:3:"723";i:3;s:3:"683";}}s:9:"lessequal";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"549";s:1:"N";s:9:"lessequal";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:1:"0";i:2;s:3:"526";i:3;s:3:"704";}}s:11:"ocircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:11:"ocircumflex";s:1:"B";a:4:{i:0;s:2:"-3";i:1;s:3:"-13";i:2;s:3:"451";i:3;s:3:"690";}}s:6:"ntilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"ntilde";s:1:"B";a:4:{i:0;s:2:"-6";i:1;s:2:"-9";i:2;s:3:"504";i:3;s:3:"655";}}s:13:"Uhungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:13:"Uhungarumlaut";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:3:"-18";i:2;s:3:"744";i:3;s:3:"904";}}s:6:"Eacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Eacute";s:1:"B";a:4:{i:0;s:3:"-27";i:1;s:1:"0";i:2;s:3:"653";i:3;s:3:"904";}}s:7:"emacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:7:"emacron";s:1:"B";a:4:{i:0;s:1:"5";i:1;s:3:"-13";i:2;s:3:"439";i:3;s:3:"623";}}s:6:"gbreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"gbreve";s:1:"B";a:4:{i:0;s:3:"-52";i:1;s:4:"-203";i:2;s:3:"478";i:3;s:3:"678";}}s:10:"onequarter";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"750";s:1:"N";s:10:"onequarter";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:3:"-14";i:2;s:3:"721";i:3;s:3:"683";}}s:6:"Scaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"Scaron";s:1:"B";a:4:{i:0;s:1:"2";i:1;s:3:"-18";i:2;s:3:"553";i:3;s:3:"897";}}s:12:"Scommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:12:"Scommaaccent";s:1:"B";a:4:{i:0;s:1:"2";i:1;s:4:"-218";i:2;s:3:"526";i:3;s:3:"685";}}s:13:"Ohungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:13:"Ohungarumlaut";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:3:"-18";i:2;s:3:"723";i:3;s:3:"904";}}s:6:"degree";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"400";s:1:"N";s:6:"degree";s:1:"B";a:4:{i:0;s:2:"83";i:1;s:3:"397";i:2;s:3:"369";i:3;s:3:"683";}}s:6:"ograve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"ograve";s:1:"B";a:4:{i:0;s:2:"-3";i:1;s:3:"-13";i:2;s:3:"441";i:3;s:3:"697";}}s:6:"Ccaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Ccaron";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:3:"-18";i:2;s:3:"677";i:3;s:3:"897";}}s:6:"ugrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"ugrave";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:2:"-9";i:2;s:3:"492";i:3;s:3:"697";}}s:7:"radical";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"549";s:1:"N";s:7:"radical";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:3:"-46";i:2;s:3:"512";i:3;s:3:"850";}}s:6:"Dcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Dcaron";s:1:"B";a:4:{i:0;s:3:"-46";i:1;s:1:"0";i:2;s:3:"685";i:3;s:3:"897";}}s:12:"rcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:12:"rcommaaccent";s:1:"B";a:4:{i:0;s:3:"-67";i:1;s:4:"-218";i:2;s:3:"389";i:3;s:3:"462";}}s:6:"Ntilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Ntilde";s:1:"B";a:4:{i:0;s:3:"-27";i:1;s:3:"-15";i:2;s:3:"748";i:3;s:3:"862";}}s:6:"otilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"otilde";s:1:"B";a:4:{i:0;s:2:"-3";i:1;s:3:"-13";i:2;s:3:"491";i:3;s:3:"655";}}s:12:"Rcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:12:"Rcommaaccent";s:1:"B";a:4:{i:0;s:3:"-29";i:1;s:4:"-218";i:2;s:3:"623";i:3;s:3:"669";}}s:12:"Lcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:12:"Lcommaaccent";s:1:"B";a:4:{i:0;s:3:"-22";i:1;s:4:"-218";i:2;s:3:"590";i:3;s:3:"669";}}s:6:"Atilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Atilde";s:1:"B";a:4:{i:0;s:3:"-67";i:1;s:1:"0";i:2;s:3:"593";i:3;s:3:"862";}}s:7:"Aogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:7:"Aogonek";s:1:"B";a:4:{i:0;s:3:"-67";i:1;s:4:"-183";i:2;s:3:"604";i:3;s:3:"683";}}s:5:"Aring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:5:"Aring";s:1:"B";a:4:{i:0;s:3:"-67";i:1;s:1:"0";i:2;s:3:"593";i:3;s:3:"921";}}s:6:"Otilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Otilde";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:3:"-18";i:2;s:3:"691";i:3;s:3:"862";}}s:10:"zdotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:10:"zdotaccent";s:1:"B";a:4:{i:0;s:3:"-43";i:1;s:3:"-78";i:2;s:3:"368";i:3;s:3:"655";}}s:6:"Ecaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Ecaron";s:1:"B";a:4:{i:0;s:3:"-27";i:1;s:1:"0";i:2;s:3:"653";i:3;s:3:"897";}}s:7:"Iogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:7:"Iogonek";s:1:"B";a:4:{i:0;s:3:"-32";i:1;s:4:"-183";i:2;s:3:"406";i:3;s:3:"669";}}s:12:"kcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:12:"kcommaaccent";s:1:"B";a:4:{i:0;s:3:"-23";i:1;s:4:"-218";i:2;s:3:"483";i:3;s:3:"699";}}s:5:"minus";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"606";s:1:"N";s:5:"minus";s:1:"B";a:4:{i:0;s:2:"51";i:1;s:3:"209";i:2;s:3:"555";i:3;s:3:"297";}}s:11:"Icircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:11:"Icircumflex";s:1:"B";a:4:{i:0;s:3:"-32";i:1;s:1:"0";i:2;s:3:"450";i:3;s:3:"897";}}s:6:"ncaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"ncaron";s:1:"B";a:4:{i:0;s:2:"-6";i:1;s:2:"-9";i:2;s:3:"523";i:3;s:3:"690";}}s:12:"tcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:12:"tcommaaccent";s:1:"B";a:4:{i:0;s:3:"-62";i:1;s:4:"-218";i:2;s:3:"281";i:3;s:3:"594";}}s:10:"logicalnot";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"606";s:1:"N";s:10:"logicalnot";s:1:"B";a:4:{i:0;s:2:"51";i:1;s:3:"108";i:2;s:3:"555";i:3;s:3:"399";}}s:9:"odieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:9:"odieresis";s:1:"B";a:4:{i:0;s:2:"-3";i:1;s:3:"-13";i:2;s:3:"471";i:3;s:3:"655";}}s:9:"udieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:9:"udieresis";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:2:"-9";i:2;s:3:"499";i:3;s:3:"655";}}s:8:"notequal";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"549";s:1:"N";s:8:"notequal";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:3:"-49";i:2;s:3:"540";i:3;s:3:"570";}}s:12:"gcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:12:"gcommaaccent";s:1:"B";a:4:{i:0;s:3:"-52";i:1;s:4:"-203";i:2;s:3:"478";i:3;s:3:"767";}}s:3:"eth";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:3:"eth";s:1:"B";a:4:{i:0;s:2:"-3";i:1;s:3:"-13";i:2;s:3:"454";i:3;s:3:"699";}}s:6:"zcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:6:"zcaron";s:1:"B";a:4:{i:0;s:3:"-43";i:1;s:3:"-78";i:2;s:3:"424";i:3;s:3:"690";}}s:12:"ncommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:12:"ncommaaccent";s:1:"B";a:4:{i:0;s:2:"-6";i:1;s:4:"-218";i:2;s:3:"493";i:3;s:3:"462";}}s:11:"onesuperior";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"300";s:1:"N";s:11:"onesuperior";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"274";i:2;s:3:"301";i:3;s:3:"683";}}s:7:"imacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:7:"imacron";s:1:"B";a:4:{i:0;s:1:"2";i:1;s:2:"-9";i:2;s:3:"294";i:3;s:3:"623";}}s:4:"Euro";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:4:"Euro";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}}s:3:"KPX";a:105:{s:1:"A";a:49:{s:1:"C";s:3:"-65";s:6:"Cacute";s:3:"-65";s:6:"Ccaron";s:3:"-65";s:8:"Ccedilla";s:3:"-65";s:1:"G";s:3:"-60";s:6:"Gbreve";s:3:"-60";s:12:"Gcommaaccent";s:3:"-60";s:1:"O";s:3:"-50";s:6:"Oacute";s:3:"-50";s:11:"Ocircumflex";s:3:"-50";s:9:"Odieresis";s:3:"-50";s:6:"Ograve";s:3:"-50";s:13:"Ohungarumlaut";s:3:"-50";s:7:"Omacron";s:3:"-50";s:6:"Oslash";s:3:"-50";s:6:"Otilde";s:3:"-50";s:1:"Q";s:3:"-55";s:1:"T";s:3:"-55";s:6:"Tcaron";s:3:"-55";s:12:"Tcommaaccent";s:3:"-55";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-95";s:1:"W";s:4:"-100";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:10:"quoteright";s:3:"-74";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-74";s:1:"w";s:3:"-74";s:1:"y";s:3:"-74";s:6:"yacute";s:3:"-74";s:9:"ydieresis";s:3:"-74";}s:6:"Aacute";a:49:{s:1:"C";s:3:"-65";s:6:"Cacute";s:3:"-65";s:6:"Ccaron";s:3:"-65";s:8:"Ccedilla";s:3:"-65";s:1:"G";s:3:"-60";s:6:"Gbreve";s:3:"-60";s:12:"Gcommaaccent";s:3:"-60";s:1:"O";s:3:"-50";s:6:"Oacute";s:3:"-50";s:11:"Ocircumflex";s:3:"-50";s:9:"Odieresis";s:3:"-50";s:6:"Ograve";s:3:"-50";s:13:"Ohungarumlaut";s:3:"-50";s:7:"Omacron";s:3:"-50";s:6:"Oslash";s:3:"-50";s:6:"Otilde";s:3:"-50";s:1:"Q";s:3:"-55";s:1:"T";s:3:"-55";s:6:"Tcaron";s:3:"-55";s:12:"Tcommaaccent";s:3:"-55";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-95";s:1:"W";s:4:"-100";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:10:"quoteright";s:3:"-74";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-74";s:1:"w";s:3:"-74";s:1:"y";s:3:"-74";s:6:"yacute";s:3:"-74";s:9:"ydieresis";s:3:"-74";}s:6:"Abreve";a:49:{s:1:"C";s:3:"-65";s:6:"Cacute";s:3:"-65";s:6:"Ccaron";s:3:"-65";s:8:"Ccedilla";s:3:"-65";s:1:"G";s:3:"-60";s:6:"Gbreve";s:3:"-60";s:12:"Gcommaaccent";s:3:"-60";s:1:"O";s:3:"-50";s:6:"Oacute";s:3:"-50";s:11:"Ocircumflex";s:3:"-50";s:9:"Odieresis";s:3:"-50";s:6:"Ograve";s:3:"-50";s:13:"Ohungarumlaut";s:3:"-50";s:7:"Omacron";s:3:"-50";s:6:"Oslash";s:3:"-50";s:6:"Otilde";s:3:"-50";s:1:"Q";s:3:"-55";s:1:"T";s:3:"-55";s:6:"Tcaron";s:3:"-55";s:12:"Tcommaaccent";s:3:"-55";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-95";s:1:"W";s:4:"-100";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:10:"quoteright";s:3:"-74";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-74";s:1:"w";s:3:"-74";s:1:"y";s:3:"-74";s:6:"yacute";s:3:"-74";s:9:"ydieresis";s:3:"-74";}s:11:"Acircumflex";a:49:{s:1:"C";s:3:"-65";s:6:"Cacute";s:3:"-65";s:6:"Ccaron";s:3:"-65";s:8:"Ccedilla";s:3:"-65";s:1:"G";s:3:"-60";s:6:"Gbreve";s:3:"-60";s:12:"Gcommaaccent";s:3:"-60";s:1:"O";s:3:"-50";s:6:"Oacute";s:3:"-50";s:11:"Ocircumflex";s:3:"-50";s:9:"Odieresis";s:3:"-50";s:6:"Ograve";s:3:"-50";s:13:"Ohungarumlaut";s:3:"-50";s:7:"Omacron";s:3:"-50";s:6:"Oslash";s:3:"-50";s:6:"Otilde";s:3:"-50";s:1:"Q";s:3:"-55";s:1:"T";s:3:"-55";s:6:"Tcaron";s:3:"-55";s:12:"Tcommaaccent";s:3:"-55";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-95";s:1:"W";s:4:"-100";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:10:"quoteright";s:3:"-74";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-74";s:1:"w";s:3:"-74";s:1:"y";s:3:"-74";s:6:"yacute";s:3:"-74";s:9:"ydieresis";s:3:"-74";}s:9:"Adieresis";a:49:{s:1:"C";s:3:"-65";s:6:"Cacute";s:3:"-65";s:6:"Ccaron";s:3:"-65";s:8:"Ccedilla";s:3:"-65";s:1:"G";s:3:"-60";s:6:"Gbreve";s:3:"-60";s:12:"Gcommaaccent";s:3:"-60";s:1:"O";s:3:"-50";s:6:"Oacute";s:3:"-50";s:11:"Ocircumflex";s:3:"-50";s:9:"Odieresis";s:3:"-50";s:6:"Ograve";s:3:"-50";s:13:"Ohungarumlaut";s:3:"-50";s:7:"Omacron";s:3:"-50";s:6:"Oslash";s:3:"-50";s:6:"Otilde";s:3:"-50";s:1:"Q";s:3:"-55";s:1:"T";s:3:"-55";s:6:"Tcaron";s:3:"-55";s:12:"Tcommaaccent";s:3:"-55";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-95";s:1:"W";s:4:"-100";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:10:"quoteright";s:3:"-74";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-74";s:1:"w";s:3:"-74";s:1:"y";s:3:"-74";s:6:"yacute";s:3:"-74";s:9:"ydieresis";s:3:"-74";}s:6:"Agrave";a:49:{s:1:"C";s:3:"-65";s:6:"Cacute";s:3:"-65";s:6:"Ccaron";s:3:"-65";s:8:"Ccedilla";s:3:"-65";s:1:"G";s:3:"-60";s:6:"Gbreve";s:3:"-60";s:12:"Gcommaaccent";s:3:"-60";s:1:"O";s:3:"-50";s:6:"Oacute";s:3:"-50";s:11:"Ocircumflex";s:3:"-50";s:9:"Odieresis";s:3:"-50";s:6:"Ograve";s:3:"-50";s:13:"Ohungarumlaut";s:3:"-50";s:7:"Omacron";s:3:"-50";s:6:"Oslash";s:3:"-50";s:6:"Otilde";s:3:"-50";s:1:"Q";s:3:"-55";s:1:"T";s:3:"-55";s:6:"Tcaron";s:3:"-55";s:12:"Tcommaaccent";s:3:"-55";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-95";s:1:"W";s:4:"-100";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:10:"quoteright";s:3:"-74";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-74";s:1:"w";s:3:"-74";s:1:"y";s:3:"-74";s:6:"yacute";s:3:"-74";s:9:"ydieresis";s:3:"-74";}s:7:"Amacron";a:49:{s:1:"C";s:3:"-65";s:6:"Cacute";s:3:"-65";s:6:"Ccaron";s:3:"-65";s:8:"Ccedilla";s:3:"-65";s:1:"G";s:3:"-60";s:6:"Gbreve";s:3:"-60";s:12:"Gcommaaccent";s:3:"-60";s:1:"O";s:3:"-50";s:6:"Oacute";s:3:"-50";s:11:"Ocircumflex";s:3:"-50";s:9:"Odieresis";s:3:"-50";s:6:"Ograve";s:3:"-50";s:13:"Ohungarumlaut";s:3:"-50";s:7:"Omacron";s:3:"-50";s:6:"Oslash";s:3:"-50";s:6:"Otilde";s:3:"-50";s:1:"Q";s:3:"-55";s:1:"T";s:3:"-55";s:6:"Tcaron";s:3:"-55";s:12:"Tcommaaccent";s:3:"-55";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-95";s:1:"W";s:4:"-100";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:10:"quoteright";s:3:"-74";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-74";s:1:"w";s:3:"-74";s:1:"y";s:3:"-74";s:6:"yacute";s:3:"-74";s:9:"ydieresis";s:3:"-74";}s:7:"Aogonek";a:49:{s:1:"C";s:3:"-65";s:6:"Cacute";s:3:"-65";s:6:"Ccaron";s:3:"-65";s:8:"Ccedilla";s:3:"-65";s:1:"G";s:3:"-60";s:6:"Gbreve";s:3:"-60";s:12:"Gcommaaccent";s:3:"-60";s:1:"O";s:3:"-50";s:6:"Oacute";s:3:"-50";s:11:"Ocircumflex";s:3:"-50";s:9:"Odieresis";s:3:"-50";s:6:"Ograve";s:3:"-50";s:13:"Ohungarumlaut";s:3:"-50";s:7:"Omacron";s:3:"-50";s:6:"Oslash";s:3:"-50";s:6:"Otilde";s:3:"-50";s:1:"Q";s:3:"-55";s:1:"T";s:3:"-55";s:6:"Tcaron";s:3:"-55";s:12:"Tcommaaccent";s:3:"-55";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-95";s:1:"W";s:4:"-100";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:10:"quoteright";s:3:"-74";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-74";s:1:"w";s:3:"-74";s:1:"y";s:3:"-34";s:6:"yacute";s:3:"-34";s:9:"ydieresis";s:3:"-34";}s:5:"Aring";a:49:{s:1:"C";s:3:"-65";s:6:"Cacute";s:3:"-65";s:6:"Ccaron";s:3:"-65";s:8:"Ccedilla";s:3:"-65";s:1:"G";s:3:"-60";s:6:"Gbreve";s:3:"-60";s:12:"Gcommaaccent";s:3:"-60";s:1:"O";s:3:"-50";s:6:"Oacute";s:3:"-50";s:11:"Ocircumflex";s:3:"-50";s:9:"Odieresis";s:3:"-50";s:6:"Ograve";s:3:"-50";s:13:"Ohungarumlaut";s:3:"-50";s:7:"Omacron";s:3:"-50";s:6:"Oslash";s:3:"-50";s:6:"Otilde";s:3:"-50";s:1:"Q";s:3:"-55";s:1:"T";s:3:"-55";s:6:"Tcaron";s:3:"-55";s:12:"Tcommaaccent";s:3:"-55";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-95";s:1:"W";s:4:"-100";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:10:"quoteright";s:3:"-74";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-74";s:1:"w";s:3:"-74";s:1:"y";s:3:"-74";s:6:"yacute";s:3:"-74";s:9:"ydieresis";s:3:"-74";}s:6:"Atilde";a:49:{s:1:"C";s:3:"-65";s:6:"Cacute";s:3:"-65";s:6:"Ccaron";s:3:"-65";s:8:"Ccedilla";s:3:"-65";s:1:"G";s:3:"-60";s:6:"Gbreve";s:3:"-60";s:12:"Gcommaaccent";s:3:"-60";s:1:"O";s:3:"-50";s:6:"Oacute";s:3:"-50";s:11:"Ocircumflex";s:3:"-50";s:9:"Odieresis";s:3:"-50";s:6:"Ograve";s:3:"-50";s:13:"Ohungarumlaut";s:3:"-50";s:7:"Omacron";s:3:"-50";s:6:"Oslash";s:3:"-50";s:6:"Otilde";s:3:"-50";s:1:"Q";s:3:"-55";s:1:"T";s:3:"-55";s:6:"Tcaron";s:3:"-55";s:12:"Tcommaaccent";s:3:"-55";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:3:"-95";s:1:"W";s:4:"-100";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";s:10:"quoteright";s:3:"-74";s:1:"u";s:3:"-30";s:6:"uacute";s:3:"-30";s:11:"ucircumflex";s:3:"-30";s:9:"udieresis";s:3:"-30";s:6:"ugrave";s:3:"-30";s:13:"uhungarumlaut";s:3:"-30";s:7:"umacron";s:3:"-30";s:7:"uogonek";s:3:"-30";s:5:"uring";s:3:"-30";s:1:"v";s:3:"-74";s:1:"w";s:3:"-74";s:1:"y";s:3:"-74";s:6:"yacute";s:3:"-74";s:9:"ydieresis";s:3:"-74";}s:1:"B";a:19:{s:1:"A";s:3:"-25";s:6:"Aacute";s:3:"-25";s:6:"Abreve";s:3:"-25";s:11:"Acircumflex";s:3:"-25";s:9:"Adieresis";s:3:"-25";s:6:"Agrave";s:3:"-25";s:7:"Amacron";s:3:"-25";s:7:"Aogonek";s:3:"-25";s:5:"Aring";s:3:"-25";s:6:"Atilde";s:3:"-25";s:1:"U";s:3:"-10";s:6:"Uacute";s:3:"-10";s:11:"Ucircumflex";s:3:"-10";s:9:"Udieresis";s:3:"-10";s:6:"Ugrave";s:3:"-10";s:13:"Uhungarumlaut";s:3:"-10";s:7:"Umacron";s:3:"-10";s:7:"Uogonek";s:3:"-10";s:5:"Uring";s:3:"-10";}s:1:"D";a:15:{s:1:"A";s:3:"-25";s:6:"Aacute";s:3:"-25";s:6:"Abreve";s:3:"-25";s:11:"Acircumflex";s:3:"-25";s:9:"Adieresis";s:3:"-25";s:6:"Agrave";s:3:"-25";s:7:"Amacron";s:3:"-25";s:7:"Aogonek";s:3:"-25";s:5:"Aring";s:3:"-25";s:6:"Atilde";s:3:"-25";s:1:"V";s:3:"-50";s:1:"W";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:6:"Dcaron";a:15:{s:1:"A";s:3:"-25";s:6:"Aacute";s:3:"-25";s:6:"Abreve";s:3:"-25";s:11:"Acircumflex";s:3:"-25";s:9:"Adieresis";s:3:"-25";s:6:"Agrave";s:3:"-25";s:7:"Amacron";s:3:"-25";s:7:"Aogonek";s:3:"-25";s:5:"Aring";s:3:"-25";s:6:"Atilde";s:3:"-25";s:1:"V";s:3:"-50";s:1:"W";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:6:"Dcroat";a:15:{s:1:"A";s:3:"-25";s:6:"Aacute";s:3:"-25";s:6:"Abreve";s:3:"-25";s:11:"Acircumflex";s:3:"-25";s:9:"Adieresis";s:3:"-25";s:6:"Agrave";s:3:"-25";s:7:"Amacron";s:3:"-25";s:7:"Aogonek";s:3:"-25";s:5:"Aring";s:3:"-25";s:6:"Atilde";s:3:"-25";s:1:"V";s:3:"-50";s:1:"W";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:1:"F";a:51:{s:1:"A";s:4:"-100";s:6:"Aacute";s:4:"-100";s:6:"Abreve";s:4:"-100";s:11:"Acircumflex";s:4:"-100";s:9:"Adieresis";s:4:"-100";s:6:"Agrave";s:4:"-100";s:7:"Amacron";s:4:"-100";s:7:"Aogonek";s:4:"-100";s:5:"Aring";s:4:"-100";s:6:"Atilde";s:4:"-100";s:1:"a";s:3:"-95";s:6:"aacute";s:3:"-95";s:6:"abreve";s:3:"-95";s:11:"acircumflex";s:3:"-95";s:9:"adieresis";s:3:"-95";s:6:"agrave";s:3:"-95";s:7:"amacron";s:3:"-95";s:7:"aogonek";s:3:"-95";s:5:"aring";s:3:"-95";s:6:"atilde";s:3:"-95";s:5:"comma";s:4:"-129";s:1:"e";s:4:"-100";s:6:"eacute";s:4:"-100";s:6:"ecaron";s:4:"-100";s:11:"ecircumflex";s:4:"-100";s:9:"edieresis";s:4:"-100";s:10:"edotaccent";s:4:"-100";s:6:"egrave";s:4:"-100";s:7:"emacron";s:4:"-100";s:7:"eogonek";s:4:"-100";s:1:"i";s:3:"-40";s:6:"iacute";s:3:"-40";s:11:"icircumflex";s:3:"-40";s:9:"idieresis";s:3:"-40";s:6:"igrave";s:3:"-40";s:7:"imacron";s:3:"-40";s:7:"iogonek";s:3:"-40";s:1:"o";s:3:"-70";s:6:"oacute";s:3:"-70";s:11:"ocircumflex";s:3:"-70";s:9:"odieresis";s:3:"-70";s:6:"ograve";s:3:"-70";s:13:"ohungarumlaut";s:3:"-70";s:7:"omacron";s:3:"-70";s:6:"oslash";s:3:"-70";s:6:"otilde";s:3:"-70";s:6:"period";s:4:"-129";s:1:"r";s:3:"-50";s:6:"racute";s:3:"-50";s:6:"rcaron";s:3:"-50";s:12:"rcommaaccent";s:3:"-50";}s:1:"J";a:49:{s:1:"A";s:3:"-25";s:6:"Aacute";s:3:"-25";s:6:"Abreve";s:3:"-25";s:11:"Acircumflex";s:3:"-25";s:9:"Adieresis";s:3:"-25";s:6:"Agrave";s:3:"-25";s:7:"Amacron";s:3:"-25";s:7:"Aogonek";s:3:"-25";s:5:"Aring";s:3:"-25";s:6:"Atilde";s:3:"-25";s:1:"a";s:3:"-40";s:6:"aacute";s:3:"-40";s:6:"abreve";s:3:"-40";s:11:"acircumflex";s:3:"-40";s:9:"adieresis";s:3:"-40";s:6:"agrave";s:3:"-40";s:7:"amacron";s:3:"-40";s:7:"aogonek";s:3:"-40";s:5:"aring";s:3:"-40";s:6:"atilde";s:3:"-40";s:5:"comma";s:3:"-10";s:1:"e";s:3:"-40";s:6:"eacute";s:3:"-40";s:6:"ecaron";s:3:"-40";s:11:"ecircumflex";s:3:"-40";s:9:"edieresis";s:3:"-40";s:10:"edotaccent";s:3:"-40";s:6:"egrave";s:3:"-40";s:7:"emacron";s:3:"-40";s:7:"eogonek";s:3:"-40";s:1:"o";s:3:"-40";s:6:"oacute";s:3:"-40";s:11:"ocircumflex";s:3:"-40";s:9:"odieresis";s:3:"-40";s:6:"ograve";s:3:"-40";s:13:"ohungarumlaut";s:3:"-40";s:7:"omacron";s:3:"-40";s:6:"oslash";s:3:"-40";s:6:"otilde";s:3:"-40";s:6:"period";s:3:"-10";s:1:"u";s:3:"-40";s:6:"uacute";s:3:"-40";s:11:"ucircumflex";s:3:"-40";s:9:"udieresis";s:3:"-40";s:6:"ugrave";s:3:"-40";s:13:"uhungarumlaut";s:3:"-40";s:7:"umacron";s:3:"-40";s:7:"uogonek";s:3:"-40";s:5:"uring";s:3:"-40";}s:1:"K";a:39:{s:1:"O";s:3:"-30";s:6:"Oacute";s:3:"-30";s:11:"Ocircumflex";s:3:"-30";s:9:"Odieresis";s:3:"-30";s:6:"Ograve";s:3:"-30";s:13:"Ohungarumlaut";s:3:"-30";s:7:"Omacron";s:3:"-30";s:6:"Oslash";s:3:"-30";s:6:"Otilde";s:3:"-30";s:1:"e";s:3:"-25";s:6:"eacute";s:3:"-25";s:6:"ecaron";s:3:"-25";s:11:"ecircumflex";s:3:"-25";s:9:"edieresis";s:3:"-25";s:10:"edotaccent";s:3:"-25";s:6:"egrave";s:3:"-25";s:7:"emacron";s:3:"-25";s:7:"eogonek";s:3:"-25";s:1:"o";s:3:"-25";s:6:"oacute";s:3:"-25";s:11:"ocircumflex";s:3:"-25";s:9:"odieresis";s:3:"-25";s:6:"ograve";s:3:"-25";s:13:"ohungarumlaut";s:3:"-25";s:7:"omacron";s:3:"-25";s:6:"oslash";s:3:"-25";s:6:"otilde";s:3:"-25";s:1:"u";s:3:"-20";s:6:"uacute";s:3:"-20";s:11:"ucircumflex";s:3:"-20";s:9:"udieresis";s:3:"-20";s:6:"ugrave";s:3:"-20";s:13:"uhungarumlaut";s:3:"-20";s:7:"umacron";s:3:"-20";s:7:"uogonek";s:3:"-20";s:5:"uring";s:3:"-20";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:12:"Kcommaaccent";a:39:{s:1:"O";s:3:"-30";s:6:"Oacute";s:3:"-30";s:11:"Ocircumflex";s:3:"-30";s:9:"Odieresis";s:3:"-30";s:6:"Ograve";s:3:"-30";s:13:"Ohungarumlaut";s:3:"-30";s:7:"Omacron";s:3:"-30";s:6:"Oslash";s:3:"-30";s:6:"Otilde";s:3:"-30";s:1:"e";s:3:"-25";s:6:"eacute";s:3:"-25";s:6:"ecaron";s:3:"-25";s:11:"ecircumflex";s:3:"-25";s:9:"edieresis";s:3:"-25";s:10:"edotaccent";s:3:"-25";s:6:"egrave";s:3:"-25";s:7:"emacron";s:3:"-25";s:7:"eogonek";s:3:"-25";s:1:"o";s:3:"-25";s:6:"oacute";s:3:"-25";s:11:"ocircumflex";s:3:"-25";s:9:"odieresis";s:3:"-25";s:6:"ograve";s:3:"-25";s:13:"ohungarumlaut";s:3:"-25";s:7:"omacron";s:3:"-25";s:6:"oslash";s:3:"-25";s:6:"otilde";s:3:"-25";s:1:"u";s:3:"-20";s:6:"uacute";s:3:"-20";s:11:"ucircumflex";s:3:"-20";s:9:"udieresis";s:3:"-20";s:6:"ugrave";s:3:"-20";s:13:"uhungarumlaut";s:3:"-20";s:7:"umacron";s:3:"-20";s:7:"uogonek";s:3:"-20";s:5:"uring";s:3:"-20";s:1:"y";s:3:"-20";s:6:"yacute";s:3:"-20";s:9:"ydieresis";s:3:"-20";}s:1:"L";a:12:{s:1:"T";s:3:"-18";s:6:"Tcaron";s:3:"-18";s:12:"Tcommaaccent";s:3:"-18";s:1:"V";s:3:"-37";s:1:"W";s:3:"-37";s:1:"Y";s:3:"-37";s:6:"Yacute";s:3:"-37";s:9:"Ydieresis";s:3:"-37";s:10:"quoteright";s:3:"-55";s:1:"y";s:3:"-37";s:6:"yacute";s:3:"-37";s:9:"ydieresis";s:3:"-37";}s:6:"Lacute";a:12:{s:1:"T";s:3:"-18";s:6:"Tcaron";s:3:"-18";s:12:"Tcommaaccent";s:3:"-18";s:1:"V";s:3:"-37";s:1:"W";s:3:"-37";s:1:"Y";s:3:"-37";s:6:"Yacute";s:3:"-37";s:9:"Ydieresis";s:3:"-37";s:10:"quoteright";s:3:"-55";s:1:"y";s:3:"-37";s:6:"yacute";s:3:"-37";s:9:"ydieresis";s:3:"-37";}s:12:"Lcommaaccent";a:12:{s:1:"T";s:3:"-18";s:6:"Tcaron";s:3:"-18";s:12:"Tcommaaccent";s:3:"-18";s:1:"V";s:3:"-37";s:1:"W";s:3:"-37";s:1:"Y";s:3:"-37";s:6:"Yacute";s:3:"-37";s:9:"Ydieresis";s:3:"-37";s:10:"quoteright";s:3:"-55";s:1:"y";s:3:"-37";s:6:"yacute";s:3:"-37";s:9:"ydieresis";s:3:"-37";}s:6:"Lslash";a:12:{s:1:"T";s:3:"-18";s:6:"Tcaron";s:3:"-18";s:12:"Tcommaaccent";s:3:"-18";s:1:"V";s:3:"-37";s:1:"W";s:3:"-37";s:1:"Y";s:3:"-37";s:6:"Yacute";s:3:"-37";s:9:"Ydieresis";s:3:"-37";s:10:"quoteright";s:3:"-55";s:1:"y";s:3:"-37";s:6:"yacute";s:3:"-37";s:9:"ydieresis";s:3:"-37";}s:1:"N";a:10:{s:1:"A";s:3:"-30";s:6:"Aacute";s:3:"-30";s:6:"Abreve";s:3:"-30";s:11:"Acircumflex";s:3:"-30";s:9:"Adieresis";s:3:"-30";s:6:"Agrave";s:3:"-30";s:7:"Amacron";s:3:"-30";s:7:"Aogonek";s:3:"-30";s:5:"Aring";s:3:"-30";s:6:"Atilde";s:3:"-30";}s:6:"Nacute";a:10:{s:1:"A";s:3:"-30";s:6:"Aacute";s:3:"-30";s:6:"Abreve";s:3:"-30";s:11:"Acircumflex";s:3:"-30";s:9:"Adieresis";s:3:"-30";s:6:"Agrave";s:3:"-30";s:7:"Amacron";s:3:"-30";s:7:"Aogonek";s:3:"-30";s:5:"Aring";s:3:"-30";s:6:"Atilde";s:3:"-30";}s:6:"Ncaron";a:10:{s:1:"A";s:3:"-30";s:6:"Aacute";s:3:"-30";s:6:"Abreve";s:3:"-30";s:11:"Acircumflex";s:3:"-30";s:9:"Adieresis";s:3:"-30";s:6:"Agrave";s:3:"-30";s:7:"Amacron";s:3:"-30";s:7:"Aogonek";s:3:"-30";s:5:"Aring";s:3:"-30";s:6:"Atilde";s:3:"-30";}s:12:"Ncommaaccent";a:10:{s:1:"A";s:3:"-30";s:6:"Aacute";s:3:"-30";s:6:"Abreve";s:3:"-30";s:11:"Acircumflex";s:3:"-30";s:9:"Adieresis";s:3:"-30";s:6:"Agrave";s:3:"-30";s:7:"Amacron";s:3:"-30";s:7:"Aogonek";s:3:"-30";s:5:"Aring";s:3:"-30";s:6:"Atilde";s:3:"-30";}s:6:"Ntilde";a:10:{s:1:"A";s:3:"-30";s:6:"Aacute";s:3:"-30";s:6:"Abreve";s:3:"-30";s:11:"Acircumflex";s:3:"-30";s:9:"Adieresis";s:3:"-30";s:6:"Agrave";s:3:"-30";s:7:"Amacron";s:3:"-30";s:7:"Aogonek";s:3:"-30";s:5:"Aring";s:3:"-30";s:6:"Atilde";s:3:"-30";}s:1:"O";a:19:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:6:"Oacute";a:19:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:11:"Ocircumflex";a:19:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:9:"Odieresis";a:19:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:6:"Ograve";a:19:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:13:"Ohungarumlaut";a:19:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:7:"Omacron";a:19:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:6:"Oslash";a:19:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:6:"Otilde";a:19:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:1:"P";a:40:{s:1:"A";s:3:"-85";s:6:"Aacute";s:3:"-85";s:6:"Abreve";s:3:"-85";s:11:"Acircumflex";s:3:"-85";s:9:"Adieresis";s:3:"-85";s:6:"Agrave";s:3:"-85";s:7:"Amacron";s:3:"-85";s:7:"Aogonek";s:3:"-85";s:5:"Aring";s:3:"-85";s:6:"Atilde";s:3:"-85";s:1:"a";s:3:"-40";s:6:"aacute";s:3:"-40";s:6:"abreve";s:3:"-40";s:11:"acircumflex";s:3:"-40";s:9:"adieresis";s:3:"-40";s:6:"agrave";s:3:"-40";s:7:"amacron";s:3:"-40";s:7:"aogonek";s:3:"-40";s:5:"aring";s:3:"-40";s:6:"atilde";s:3:"-40";s:5:"comma";s:4:"-129";s:1:"e";s:3:"-50";s:6:"eacute";s:3:"-50";s:6:"ecaron";s:3:"-50";s:11:"ecircumflex";s:3:"-50";s:9:"edieresis";s:3:"-50";s:10:"edotaccent";s:3:"-50";s:6:"egrave";s:3:"-50";s:7:"emacron";s:3:"-50";s:7:"eogonek";s:3:"-50";s:1:"o";s:3:"-55";s:6:"oacute";s:3:"-55";s:11:"ocircumflex";s:3:"-55";s:9:"odieresis";s:3:"-55";s:6:"ograve";s:3:"-55";s:13:"ohungarumlaut";s:3:"-55";s:7:"omacron";s:3:"-55";s:6:"oslash";s:3:"-55";s:6:"otilde";s:3:"-55";s:6:"period";s:4:"-129";}s:1:"Q";a:9:{s:1:"U";s:3:"-10";s:6:"Uacute";s:3:"-10";s:11:"Ucircumflex";s:3:"-10";s:9:"Udieresis";s:3:"-10";s:6:"Ugrave";s:3:"-10";s:13:"Uhungarumlaut";s:3:"-10";s:7:"Umacron";s:3:"-10";s:7:"Uogonek";s:3:"-10";s:5:"Uring";s:3:"-10";}s:1:"R";a:26:{s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"T";s:3:"-30";s:6:"Tcaron";s:3:"-30";s:12:"Tcommaaccent";s:3:"-30";s:1:"U";s:3:"-40";s:6:"Uacute";s:3:"-40";s:11:"Ucircumflex";s:3:"-40";s:9:"Udieresis";s:3:"-40";s:6:"Ugrave";s:3:"-40";s:13:"Uhungarumlaut";s:3:"-40";s:7:"Umacron";s:3:"-40";s:7:"Uogonek";s:3:"-40";s:5:"Uring";s:3:"-40";s:1:"V";s:3:"-18";s:1:"W";s:3:"-18";s:1:"Y";s:3:"-18";s:6:"Yacute";s:3:"-18";s:9:"Ydieresis";s:3:"-18";}s:6:"Racute";a:26:{s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"T";s:3:"-30";s:6:"Tcaron";s:3:"-30";s:12:"Tcommaaccent";s:3:"-30";s:1:"U";s:3:"-40";s:6:"Uacute";s:3:"-40";s:11:"Ucircumflex";s:3:"-40";s:9:"Udieresis";s:3:"-40";s:6:"Ugrave";s:3:"-40";s:13:"Uhungarumlaut";s:3:"-40";s:7:"Umacron";s:3:"-40";s:7:"Uogonek";s:3:"-40";s:5:"Uring";s:3:"-40";s:1:"V";s:3:"-18";s:1:"W";s:3:"-18";s:1:"Y";s:3:"-18";s:6:"Yacute";s:3:"-18";s:9:"Ydieresis";s:3:"-18";}s:6:"Rcaron";a:26:{s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"T";s:3:"-30";s:6:"Tcaron";s:3:"-30";s:12:"Tcommaaccent";s:3:"-30";s:1:"U";s:3:"-40";s:6:"Uacute";s:3:"-40";s:11:"Ucircumflex";s:3:"-40";s:9:"Udieresis";s:3:"-40";s:6:"Ugrave";s:3:"-40";s:13:"Uhungarumlaut";s:3:"-40";s:7:"Umacron";s:3:"-40";s:7:"Uogonek";s:3:"-40";s:5:"Uring";s:3:"-40";s:1:"V";s:3:"-18";s:1:"W";s:3:"-18";s:1:"Y";s:3:"-18";s:6:"Yacute";s:3:"-18";s:9:"Ydieresis";s:3:"-18";}s:12:"Rcommaaccent";a:26:{s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"T";s:3:"-30";s:6:"Tcaron";s:3:"-30";s:12:"Tcommaaccent";s:3:"-30";s:1:"U";s:3:"-40";s:6:"Uacute";s:3:"-40";s:11:"Ucircumflex";s:3:"-40";s:9:"Udieresis";s:3:"-40";s:6:"Ugrave";s:3:"-40";s:13:"Uhungarumlaut";s:3:"-40";s:7:"Umacron";s:3:"-40";s:7:"Uogonek";s:3:"-40";s:5:"Uring";s:3:"-40";s:1:"V";s:3:"-18";s:1:"W";s:3:"-18";s:1:"Y";s:3:"-18";s:6:"Yacute";s:3:"-18";s:9:"Ydieresis";s:3:"-18";}s:1:"T";a:72:{s:1:"A";s:3:"-55";s:6:"Aacute";s:3:"-55";s:6:"Abreve";s:3:"-55";s:11:"Acircumflex";s:3:"-55";s:9:"Adieresis";s:3:"-55";s:6:"Agrave";s:3:"-55";s:7:"Amacron";s:3:"-55";s:7:"Aogonek";s:3:"-55";s:5:"Aring";s:3:"-55";s:6:"Atilde";s:3:"-55";s:1:"O";s:3:"-18";s:6:"Oacute";s:3:"-18";s:11:"Ocircumflex";s:3:"-18";s:9:"Odieresis";s:3:"-18";s:6:"Ograve";s:3:"-18";s:13:"Ohungarumlaut";s:3:"-18";s:7:"Omacron";s:3:"-18";s:6:"Oslash";s:3:"-18";s:6:"Otilde";s:3:"-18";s:1:"a";s:3:"-92";s:6:"aacute";s:3:"-92";s:6:"abreve";s:3:"-92";s:11:"acircumflex";s:3:"-92";s:9:"adieresis";s:3:"-92";s:6:"agrave";s:3:"-92";s:7:"amacron";s:3:"-92";s:7:"aogonek";s:3:"-92";s:5:"aring";s:3:"-92";s:6:"atilde";s:3:"-92";s:5:"colon";s:3:"-74";s:5:"comma";s:3:"-92";s:1:"e";s:3:"-92";s:6:"eacute";s:3:"-92";s:6:"ecaron";s:3:"-92";s:11:"ecircumflex";s:3:"-92";s:9:"edieresis";s:3:"-52";s:10:"edotaccent";s:3:"-92";s:6:"egrave";s:3:"-52";s:7:"emacron";s:3:"-52";s:7:"eogonek";s:3:"-92";s:6:"hyphen";s:3:"-92";s:1:"i";s:3:"-37";s:6:"iacute";s:3:"-37";s:7:"iogonek";s:3:"-37";s:1:"o";s:3:"-95";s:6:"oacute";s:3:"-95";s:11:"ocircumflex";s:3:"-95";s:9:"odieresis";s:3:"-95";s:6:"ograve";s:3:"-95";s:13:"ohungarumlaut";s:3:"-95";s:7:"omacron";s:3:"-95";s:6:"oslash";s:3:"-95";s:6:"otilde";s:3:"-95";s:6:"period";s:3:"-92";s:1:"r";s:3:"-37";s:6:"racute";s:3:"-37";s:6:"rcaron";s:3:"-37";s:12:"rcommaaccent";s:3:"-37";s:9:"semicolon";s:3:"-74";s:1:"u";s:3:"-37";s:6:"uacute";s:3:"-37";s:11:"ucircumflex";s:3:"-37";s:9:"udieresis";s:3:"-37";s:6:"ugrave";s:3:"-37";s:13:"uhungarumlaut";s:3:"-37";s:7:"umacron";s:3:"-37";s:7:"uogonek";s:3:"-37";s:5:"uring";s:3:"-37";s:1:"w";s:3:"-37";s:1:"y";s:3:"-37";s:6:"yacute";s:3:"-37";s:9:"ydieresis";s:3:"-37";}s:6:"Tcaron";a:72:{s:1:"A";s:3:"-55";s:6:"Aacute";s:3:"-55";s:6:"Abreve";s:3:"-55";s:11:"Acircumflex";s:3:"-55";s:9:"Adieresis";s:3:"-55";s:6:"Agrave";s:3:"-55";s:7:"Amacron";s:3:"-55";s:7:"Aogonek";s:3:"-55";s:5:"Aring";s:3:"-55";s:6:"Atilde";s:3:"-55";s:1:"O";s:3:"-18";s:6:"Oacute";s:3:"-18";s:11:"Ocircumflex";s:3:"-18";s:9:"Odieresis";s:3:"-18";s:6:"Ograve";s:3:"-18";s:13:"Ohungarumlaut";s:3:"-18";s:7:"Omacron";s:3:"-18";s:6:"Oslash";s:3:"-18";s:6:"Otilde";s:3:"-18";s:1:"a";s:3:"-92";s:6:"aacute";s:3:"-92";s:6:"abreve";s:3:"-92";s:11:"acircumflex";s:3:"-92";s:9:"adieresis";s:3:"-92";s:6:"agrave";s:3:"-92";s:7:"amacron";s:3:"-92";s:7:"aogonek";s:3:"-92";s:5:"aring";s:3:"-92";s:6:"atilde";s:3:"-92";s:5:"colon";s:3:"-74";s:5:"comma";s:3:"-92";s:1:"e";s:3:"-92";s:6:"eacute";s:3:"-92";s:6:"ecaron";s:3:"-92";s:11:"ecircumflex";s:3:"-92";s:9:"edieresis";s:3:"-52";s:10:"edotaccent";s:3:"-92";s:6:"egrave";s:3:"-52";s:7:"emacron";s:3:"-52";s:7:"eogonek";s:3:"-92";s:6:"hyphen";s:3:"-92";s:1:"i";s:3:"-37";s:6:"iacute";s:3:"-37";s:7:"iogonek";s:3:"-37";s:1:"o";s:3:"-95";s:6:"oacute";s:3:"-95";s:11:"ocircumflex";s:3:"-95";s:9:"odieresis";s:3:"-95";s:6:"ograve";s:3:"-95";s:13:"ohungarumlaut";s:3:"-95";s:7:"omacron";s:3:"-95";s:6:"oslash";s:3:"-95";s:6:"otilde";s:3:"-95";s:6:"period";s:3:"-92";s:1:"r";s:3:"-37";s:6:"racute";s:3:"-37";s:6:"rcaron";s:3:"-37";s:12:"rcommaaccent";s:3:"-37";s:9:"semicolon";s:3:"-74";s:1:"u";s:3:"-37";s:6:"uacute";s:3:"-37";s:11:"ucircumflex";s:3:"-37";s:9:"udieresis";s:3:"-37";s:6:"ugrave";s:3:"-37";s:13:"uhungarumlaut";s:3:"-37";s:7:"umacron";s:3:"-37";s:7:"uogonek";s:3:"-37";s:5:"uring";s:3:"-37";s:1:"w";s:3:"-37";s:1:"y";s:3:"-37";s:6:"yacute";s:3:"-37";s:9:"ydieresis";s:3:"-37";}s:12:"Tcommaaccent";a:72:{s:1:"A";s:3:"-55";s:6:"Aacute";s:3:"-55";s:6:"Abreve";s:3:"-55";s:11:"Acircumflex";s:3:"-55";s:9:"Adieresis";s:3:"-55";s:6:"Agrave";s:3:"-55";s:7:"Amacron";s:3:"-55";s:7:"Aogonek";s:3:"-55";s:5:"Aring";s:3:"-55";s:6:"Atilde";s:3:"-55";s:1:"O";s:3:"-18";s:6:"Oacute";s:3:"-18";s:11:"Ocircumflex";s:3:"-18";s:9:"Odieresis";s:3:"-18";s:6:"Ograve";s:3:"-18";s:13:"Ohungarumlaut";s:3:"-18";s:7:"Omacron";s:3:"-18";s:6:"Oslash";s:3:"-18";s:6:"Otilde";s:3:"-18";s:1:"a";s:3:"-92";s:6:"aacute";s:3:"-92";s:6:"abreve";s:3:"-92";s:11:"acircumflex";s:3:"-92";s:9:"adieresis";s:3:"-92";s:6:"agrave";s:3:"-92";s:7:"amacron";s:3:"-92";s:7:"aogonek";s:3:"-92";s:5:"aring";s:3:"-92";s:6:"atilde";s:3:"-92";s:5:"colon";s:3:"-74";s:5:"comma";s:3:"-92";s:1:"e";s:3:"-92";s:6:"eacute";s:3:"-92";s:6:"ecaron";s:3:"-92";s:11:"ecircumflex";s:3:"-92";s:9:"edieresis";s:3:"-52";s:10:"edotaccent";s:3:"-92";s:6:"egrave";s:3:"-52";s:7:"emacron";s:3:"-52";s:7:"eogonek";s:3:"-92";s:6:"hyphen";s:3:"-92";s:1:"i";s:3:"-37";s:6:"iacute";s:3:"-37";s:7:"iogonek";s:3:"-37";s:1:"o";s:3:"-95";s:6:"oacute";s:3:"-95";s:11:"ocircumflex";s:3:"-95";s:9:"odieresis";s:3:"-95";s:6:"ograve";s:3:"-95";s:13:"ohungarumlaut";s:3:"-95";s:7:"omacron";s:3:"-95";s:6:"oslash";s:3:"-95";s:6:"otilde";s:3:"-95";s:6:"period";s:3:"-92";s:1:"r";s:3:"-37";s:6:"racute";s:3:"-37";s:6:"rcaron";s:3:"-37";s:12:"rcommaaccent";s:3:"-37";s:9:"semicolon";s:3:"-74";s:1:"u";s:3:"-37";s:6:"uacute";s:3:"-37";s:11:"ucircumflex";s:3:"-37";s:9:"udieresis";s:3:"-37";s:6:"ugrave";s:3:"-37";s:13:"uhungarumlaut";s:3:"-37";s:7:"umacron";s:3:"-37";s:7:"uogonek";s:3:"-37";s:5:"uring";s:3:"-37";s:1:"w";s:3:"-37";s:1:"y";s:3:"-37";s:6:"yacute";s:3:"-37";s:9:"ydieresis";s:3:"-37";}s:1:"U";a:10:{s:1:"A";s:3:"-45";s:6:"Aacute";s:3:"-45";s:6:"Abreve";s:3:"-45";s:11:"Acircumflex";s:3:"-45";s:9:"Adieresis";s:3:"-45";s:6:"Agrave";s:3:"-45";s:7:"Amacron";s:3:"-45";s:7:"Aogonek";s:3:"-45";s:5:"Aring";s:3:"-45";s:6:"Atilde";s:3:"-45";}s:6:"Uacute";a:10:{s:1:"A";s:3:"-45";s:6:"Aacute";s:3:"-45";s:6:"Abreve";s:3:"-45";s:11:"Acircumflex";s:3:"-45";s:9:"Adieresis";s:3:"-45";s:6:"Agrave";s:3:"-45";s:7:"Amacron";s:3:"-45";s:7:"Aogonek";s:3:"-45";s:5:"Aring";s:3:"-45";s:6:"Atilde";s:3:"-45";}s:11:"Ucircumflex";a:10:{s:1:"A";s:3:"-45";s:6:"Aacute";s:3:"-45";s:6:"Abreve";s:3:"-45";s:11:"Acircumflex";s:3:"-45";s:9:"Adieresis";s:3:"-45";s:6:"Agrave";s:3:"-45";s:7:"Amacron";s:3:"-45";s:7:"Aogonek";s:3:"-45";s:5:"Aring";s:3:"-45";s:6:"Atilde";s:3:"-45";}s:9:"Udieresis";a:10:{s:1:"A";s:3:"-45";s:6:"Aacute";s:3:"-45";s:6:"Abreve";s:3:"-45";s:11:"Acircumflex";s:3:"-45";s:9:"Adieresis";s:3:"-45";s:6:"Agrave";s:3:"-45";s:7:"Amacron";s:3:"-45";s:7:"Aogonek";s:3:"-45";s:5:"Aring";s:3:"-45";s:6:"Atilde";s:3:"-45";}s:6:"Ugrave";a:10:{s:1:"A";s:3:"-45";s:6:"Aacute";s:3:"-45";s:6:"Abreve";s:3:"-45";s:11:"Acircumflex";s:3:"-45";s:9:"Adieresis";s:3:"-45";s:6:"Agrave";s:3:"-45";s:7:"Amacron";s:3:"-45";s:7:"Aogonek";s:3:"-45";s:5:"Aring";s:3:"-45";s:6:"Atilde";s:3:"-45";}s:13:"Uhungarumlaut";a:10:{s:1:"A";s:3:"-45";s:6:"Aacute";s:3:"-45";s:6:"Abreve";s:3:"-45";s:11:"Acircumflex";s:3:"-45";s:9:"Adieresis";s:3:"-45";s:6:"Agrave";s:3:"-45";s:7:"Amacron";s:3:"-45";s:7:"Aogonek";s:3:"-45";s:5:"Aring";s:3:"-45";s:6:"Atilde";s:3:"-45";}s:7:"Umacron";a:10:{s:1:"A";s:3:"-45";s:6:"Aacute";s:3:"-45";s:6:"Abreve";s:3:"-45";s:11:"Acircumflex";s:3:"-45";s:9:"Adieresis";s:3:"-45";s:6:"Agrave";s:3:"-45";s:7:"Amacron";s:3:"-45";s:7:"Aogonek";s:3:"-45";s:5:"Aring";s:3:"-45";s:6:"Atilde";s:3:"-45";}s:7:"Uogonek";a:10:{s:1:"A";s:3:"-45";s:6:"Aacute";s:3:"-45";s:6:"Abreve";s:3:"-45";s:11:"Acircumflex";s:3:"-45";s:9:"Adieresis";s:3:"-45";s:6:"Agrave";s:3:"-45";s:7:"Amacron";s:3:"-45";s:7:"Aogonek";s:3:"-45";s:5:"Aring";s:3:"-45";s:6:"Atilde";s:3:"-45";}s:5:"Uring";a:10:{s:1:"A";s:3:"-45";s:6:"Aacute";s:3:"-45";s:6:"Abreve";s:3:"-45";s:11:"Acircumflex";s:3:"-45";s:9:"Adieresis";s:3:"-45";s:6:"Agrave";s:3:"-45";s:7:"Amacron";s:3:"-45";s:7:"Aogonek";s:3:"-45";s:5:"Aring";s:3:"-45";s:6:"Atilde";s:3:"-45";}s:1:"V";a:67:{s:1:"A";s:3:"-85";s:6:"Aacute";s:3:"-85";s:6:"Abreve";s:3:"-85";s:11:"Acircumflex";s:3:"-85";s:9:"Adieresis";s:3:"-85";s:6:"Agrave";s:3:"-85";s:7:"Amacron";s:3:"-85";s:7:"Aogonek";s:3:"-85";s:5:"Aring";s:3:"-85";s:6:"Atilde";s:3:"-85";s:1:"G";s:3:"-10";s:6:"Gbreve";s:3:"-10";s:12:"Gcommaaccent";s:3:"-10";s:1:"O";s:3:"-30";s:6:"Oacute";s:3:"-30";s:11:"Ocircumflex";s:3:"-30";s:9:"Odieresis";s:3:"-30";s:6:"Ograve";s:3:"-30";s:13:"Ohungarumlaut";s:3:"-30";s:7:"Omacron";s:3:"-30";s:6:"Oslash";s:3:"-30";s:6:"Otilde";s:3:"-30";s:1:"a";s:4:"-111";s:6:"aacute";s:4:"-111";s:6:"abreve";s:4:"-111";s:11:"acircumflex";s:4:"-111";s:9:"adieresis";s:4:"-111";s:6:"agrave";s:4:"-111";s:7:"amacron";s:4:"-111";s:7:"aogonek";s:4:"-111";s:5:"aring";s:4:"-111";s:6:"atilde";s:4:"-111";s:5:"colon";s:3:"-74";s:5:"comma";s:4:"-129";s:1:"e";s:4:"-111";s:6:"eacute";s:4:"-111";s:6:"ecaron";s:4:"-111";s:11:"ecircumflex";s:4:"-111";s:9:"edieresis";s:3:"-71";s:10:"edotaccent";s:4:"-111";s:6:"egrave";s:3:"-71";s:7:"emacron";s:3:"-71";s:7:"eogonek";s:4:"-111";s:6:"hyphen";s:3:"-70";s:1:"i";s:3:"-55";s:6:"iacute";s:3:"-55";s:7:"iogonek";s:3:"-55";s:1:"o";s:4:"-111";s:6:"oacute";s:4:"-111";s:11:"ocircumflex";s:4:"-111";s:9:"odieresis";s:4:"-111";s:6:"ograve";s:4:"-111";s:13:"ohungarumlaut";s:4:"-111";s:7:"omacron";s:4:"-111";s:6:"oslash";s:4:"-111";s:6:"otilde";s:4:"-111";s:6:"period";s:4:"-129";s:9:"semicolon";s:3:"-74";s:1:"u";s:3:"-55";s:6:"uacute";s:3:"-55";s:11:"ucircumflex";s:3:"-55";s:9:"udieresis";s:3:"-55";s:6:"ugrave";s:3:"-55";s:13:"uhungarumlaut";s:3:"-55";s:7:"umacron";s:3:"-55";s:7:"uogonek";s:3:"-55";s:5:"uring";s:3:"-55";}s:1:"W";a:67:{s:1:"A";s:3:"-74";s:6:"Aacute";s:3:"-74";s:6:"Abreve";s:3:"-74";s:11:"Acircumflex";s:3:"-74";s:9:"Adieresis";s:3:"-74";s:6:"Agrave";s:3:"-74";s:7:"Amacron";s:3:"-74";s:7:"Aogonek";s:3:"-74";s:5:"Aring";s:3:"-74";s:6:"Atilde";s:3:"-74";s:1:"O";s:3:"-15";s:6:"Oacute";s:3:"-15";s:11:"Ocircumflex";s:3:"-15";s:9:"Odieresis";s:3:"-15";s:6:"Ograve";s:3:"-15";s:13:"Ohungarumlaut";s:3:"-15";s:7:"Omacron";s:3:"-15";s:6:"Oslash";s:3:"-15";s:6:"Otilde";s:3:"-15";s:1:"a";s:3:"-85";s:6:"aacute";s:3:"-85";s:6:"abreve";s:3:"-85";s:11:"acircumflex";s:3:"-85";s:9:"adieresis";s:3:"-85";s:6:"agrave";s:3:"-85";s:7:"amacron";s:3:"-85";s:7:"aogonek";s:3:"-85";s:5:"aring";s:3:"-85";s:6:"atilde";s:3:"-85";s:5:"colon";s:3:"-55";s:5:"comma";s:3:"-74";s:1:"e";s:3:"-90";s:6:"eacute";s:3:"-90";s:6:"ecaron";s:3:"-90";s:11:"ecircumflex";s:3:"-90";s:9:"edieresis";s:3:"-50";s:10:"edotaccent";s:3:"-90";s:6:"egrave";s:3:"-50";s:7:"emacron";s:3:"-50";s:7:"eogonek";s:3:"-90";s:6:"hyphen";s:3:"-50";s:1:"i";s:3:"-37";s:6:"iacute";s:3:"-37";s:7:"iogonek";s:3:"-37";s:1:"o";s:3:"-80";s:6:"oacute";s:3:"-80";s:11:"ocircumflex";s:3:"-80";s:9:"odieresis";s:3:"-80";s:6:"ograve";s:3:"-80";s:13:"ohungarumlaut";s:3:"-80";s:7:"omacron";s:3:"-80";s:6:"oslash";s:3:"-80";s:6:"otilde";s:3:"-80";s:6:"period";s:3:"-74";s:9:"semicolon";s:3:"-55";s:1:"u";s:3:"-55";s:6:"uacute";s:3:"-55";s:11:"ucircumflex";s:3:"-55";s:9:"udieresis";s:3:"-55";s:6:"ugrave";s:3:"-55";s:13:"uhungarumlaut";s:3:"-55";s:7:"umacron";s:3:"-55";s:7:"uogonek";s:3:"-55";s:5:"uring";s:3:"-55";s:1:"y";s:3:"-55";s:6:"yacute";s:3:"-55";s:9:"ydieresis";s:3:"-55";}s:1:"Y";a:64:{s:1:"A";s:3:"-74";s:6:"Aacute";s:3:"-74";s:6:"Abreve";s:3:"-74";s:11:"Acircumflex";s:3:"-74";s:9:"Adieresis";s:3:"-74";s:6:"Agrave";s:3:"-74";s:7:"Amacron";s:3:"-74";s:7:"Aogonek";s:3:"-74";s:5:"Aring";s:3:"-74";s:6:"Atilde";s:3:"-74";s:1:"O";s:3:"-25";s:6:"Oacute";s:3:"-25";s:11:"Ocircumflex";s:3:"-25";s:9:"Odieresis";s:3:"-25";s:6:"Ograve";s:3:"-25";s:13:"Ohungarumlaut";s:3:"-25";s:7:"Omacron";s:3:"-25";s:6:"Oslash";s:3:"-25";s:6:"Otilde";s:3:"-25";s:1:"a";s:3:"-92";s:6:"aacute";s:3:"-92";s:6:"abreve";s:3:"-92";s:11:"acircumflex";s:3:"-92";s:9:"adieresis";s:3:"-92";s:6:"agrave";s:3:"-92";s:7:"amacron";s:3:"-92";s:7:"aogonek";s:3:"-92";s:5:"aring";s:3:"-92";s:6:"atilde";s:3:"-92";s:5:"colon";s:3:"-92";s:5:"comma";s:3:"-92";s:1:"e";s:4:"-111";s:6:"eacute";s:4:"-111";s:6:"ecaron";s:4:"-111";s:11:"ecircumflex";s:3:"-71";s:9:"edieresis";s:3:"-71";s:10:"edotaccent";s:4:"-111";s:6:"egrave";s:3:"-71";s:7:"emacron";s:3:"-71";s:7:"eogonek";s:4:"-111";s:6:"hyphen";s:3:"-92";s:1:"i";s:3:"-55";s:6:"iacute";s:3:"-55";s:7:"iogonek";s:3:"-55";s:1:"o";s:4:"-111";s:6:"oacute";s:4:"-111";s:11:"ocircumflex";s:4:"-111";s:9:"odieresis";s:4:"-111";s:6:"ograve";s:4:"-111";s:13:"ohungarumlaut";s:4:"-111";s:7:"omacron";s:4:"-111";s:6:"oslash";s:4:"-111";s:6:"otilde";s:4:"-111";s:6:"period";s:3:"-74";s:9:"semicolon";s:3:"-92";s:1:"u";s:3:"-92";s:6:"uacute";s:3:"-92";s:11:"ucircumflex";s:3:"-92";s:9:"udieresis";s:3:"-92";s:6:"ugrave";s:3:"-92";s:13:"uhungarumlaut";s:3:"-92";s:7:"umacron";s:3:"-92";s:7:"uogonek";s:3:"-92";s:5:"uring";s:3:"-92";}s:6:"Yacute";a:64:{s:1:"A";s:3:"-74";s:6:"Aacute";s:3:"-74";s:6:"Abreve";s:3:"-74";s:11:"Acircumflex";s:3:"-74";s:9:"Adieresis";s:3:"-74";s:6:"Agrave";s:3:"-74";s:7:"Amacron";s:3:"-74";s:7:"Aogonek";s:3:"-74";s:5:"Aring";s:3:"-74";s:6:"Atilde";s:3:"-74";s:1:"O";s:3:"-25";s:6:"Oacute";s:3:"-25";s:11:"Ocircumflex";s:3:"-25";s:9:"Odieresis";s:3:"-25";s:6:"Ograve";s:3:"-25";s:13:"Ohungarumlaut";s:3:"-25";s:7:"Omacron";s:3:"-25";s:6:"Oslash";s:3:"-25";s:6:"Otilde";s:3:"-25";s:1:"a";s:3:"-92";s:6:"aacute";s:3:"-92";s:6:"abreve";s:3:"-92";s:11:"acircumflex";s:3:"-92";s:9:"adieresis";s:3:"-92";s:6:"agrave";s:3:"-92";s:7:"amacron";s:3:"-92";s:7:"aogonek";s:3:"-92";s:5:"aring";s:3:"-92";s:6:"atilde";s:3:"-92";s:5:"colon";s:3:"-92";s:5:"comma";s:3:"-92";s:1:"e";s:4:"-111";s:6:"eacute";s:4:"-111";s:6:"ecaron";s:4:"-111";s:11:"ecircumflex";s:3:"-71";s:9:"edieresis";s:3:"-71";s:10:"edotaccent";s:4:"-111";s:6:"egrave";s:3:"-71";s:7:"emacron";s:3:"-71";s:7:"eogonek";s:4:"-111";s:6:"hyphen";s:3:"-92";s:1:"i";s:3:"-55";s:6:"iacute";s:3:"-55";s:7:"iogonek";s:3:"-55";s:1:"o";s:4:"-111";s:6:"oacute";s:4:"-111";s:11:"ocircumflex";s:4:"-111";s:9:"odieresis";s:4:"-111";s:6:"ograve";s:4:"-111";s:13:"ohungarumlaut";s:4:"-111";s:7:"omacron";s:4:"-111";s:6:"oslash";s:4:"-111";s:6:"otilde";s:4:"-111";s:6:"period";s:3:"-74";s:9:"semicolon";s:3:"-92";s:1:"u";s:3:"-92";s:6:"uacute";s:3:"-92";s:11:"ucircumflex";s:3:"-92";s:9:"udieresis";s:3:"-92";s:6:"ugrave";s:3:"-92";s:13:"uhungarumlaut";s:3:"-92";s:7:"umacron";s:3:"-92";s:7:"uogonek";s:3:"-92";s:5:"uring";s:3:"-92";}s:9:"Ydieresis";a:64:{s:1:"A";s:3:"-74";s:6:"Aacute";s:3:"-74";s:6:"Abreve";s:3:"-74";s:11:"Acircumflex";s:3:"-74";s:9:"Adieresis";s:3:"-74";s:6:"Agrave";s:3:"-74";s:7:"Amacron";s:3:"-74";s:7:"Aogonek";s:3:"-74";s:5:"Aring";s:3:"-74";s:6:"Atilde";s:3:"-74";s:1:"O";s:3:"-25";s:6:"Oacute";s:3:"-25";s:11:"Ocircumflex";s:3:"-25";s:9:"Odieresis";s:3:"-25";s:6:"Ograve";s:3:"-25";s:13:"Ohungarumlaut";s:3:"-25";s:7:"Omacron";s:3:"-25";s:6:"Oslash";s:3:"-25";s:6:"Otilde";s:3:"-25";s:1:"a";s:3:"-92";s:6:"aacute";s:3:"-92";s:6:"abreve";s:3:"-92";s:11:"acircumflex";s:3:"-92";s:9:"adieresis";s:3:"-92";s:6:"agrave";s:3:"-92";s:7:"amacron";s:3:"-92";s:7:"aogonek";s:3:"-92";s:5:"aring";s:3:"-92";s:6:"atilde";s:3:"-92";s:5:"colon";s:3:"-92";s:5:"comma";s:3:"-92";s:1:"e";s:4:"-111";s:6:"eacute";s:4:"-111";s:6:"ecaron";s:4:"-111";s:11:"ecircumflex";s:3:"-71";s:9:"edieresis";s:3:"-71";s:10:"edotaccent";s:4:"-111";s:6:"egrave";s:3:"-71";s:7:"emacron";s:3:"-71";s:7:"eogonek";s:4:"-111";s:6:"hyphen";s:3:"-92";s:1:"i";s:3:"-55";s:6:"iacute";s:3:"-55";s:7:"iogonek";s:3:"-55";s:1:"o";s:4:"-111";s:6:"oacute";s:4:"-111";s:11:"ocircumflex";s:4:"-111";s:9:"odieresis";s:4:"-111";s:6:"ograve";s:4:"-111";s:13:"ohungarumlaut";s:4:"-111";s:7:"omacron";s:4:"-111";s:6:"oslash";s:4:"-111";s:6:"otilde";s:4:"-111";s:6:"period";s:3:"-74";s:9:"semicolon";s:3:"-92";s:1:"u";s:3:"-92";s:6:"uacute";s:3:"-92";s:11:"ucircumflex";s:3:"-92";s:9:"udieresis";s:3:"-92";s:6:"ugrave";s:3:"-92";s:13:"uhungarumlaut";s:3:"-92";s:7:"umacron";s:3:"-92";s:7:"uogonek";s:3:"-92";s:5:"uring";s:3:"-92";}s:1:"b";a:11:{s:1:"b";s:3:"-10";s:6:"period";s:3:"-40";s:1:"u";s:3:"-20";s:6:"uacute";s:3:"-20";s:11:"ucircumflex";s:3:"-20";s:9:"udieresis";s:3:"-20";s:6:"ugrave";s:3:"-20";s:13:"uhungarumlaut";s:3:"-20";s:7:"umacron";s:3:"-20";s:7:"uogonek";s:3:"-20";s:5:"uring";s:3:"-20";}s:1:"c";a:3:{s:1:"h";s:3:"-10";s:1:"k";s:3:"-10";s:12:"kcommaaccent";s:3:"-10";}s:6:"cacute";a:3:{s:1:"h";s:3:"-10";s:1:"k";s:3:"-10";s:12:"kcommaaccent";s:3:"-10";}s:6:"ccaron";a:3:{s:1:"h";s:3:"-10";s:1:"k";s:3:"-10";s:12:"kcommaaccent";s:3:"-10";}s:8:"ccedilla";a:3:{s:1:"h";s:3:"-10";s:1:"k";s:3:"-10";s:12:"kcommaaccent";s:3:"-10";}s:5:"comma";a:2:{s:13:"quotedblright";s:3:"-95";s:10:"quoteright";s:3:"-95";}s:1:"e";a:1:{s:1:"b";s:3:"-10";}s:6:"eacute";a:1:{s:1:"b";s:3:"-10";}s:6:"ecaron";a:1:{s:1:"b";s:3:"-10";}s:11:"ecircumflex";a:1:{s:1:"b";s:3:"-10";}s:9:"edieresis";a:1:{s:1:"b";s:3:"-10";}s:10:"edotaccent";a:1:{s:1:"b";s:3:"-10";}s:6:"egrave";a:1:{s:1:"b";s:3:"-10";}s:7:"emacron";a:1:{s:1:"b";s:3:"-10";}s:7:"eogonek";a:1:{s:1:"b";s:3:"-10";}s:1:"f";a:16:{s:5:"comma";s:3:"-10";s:8:"dotlessi";s:3:"-30";s:1:"e";s:3:"-10";s:6:"eacute";s:3:"-10";s:10:"edotaccent";s:3:"-10";s:7:"eogonek";s:3:"-10";s:1:"f";s:3:"-18";s:1:"o";s:3:"-10";s:6:"oacute";s:3:"-10";s:11:"ocircumflex";s:3:"-10";s:6:"ograve";s:3:"-10";s:13:"ohungarumlaut";s:3:"-10";s:6:"oslash";s:3:"-10";s:6:"otilde";s:3:"-10";s:6:"period";s:3:"-10";s:10:"quoteright";s:2:"55";}s:1:"k";a:18:{s:1:"e";s:3:"-30";s:6:"eacute";s:3:"-30";s:6:"ecaron";s:3:"-30";s:11:"ecircumflex";s:3:"-30";s:9:"edieresis";s:3:"-30";s:10:"edotaccent";s:3:"-30";s:6:"egrave";s:3:"-30";s:7:"emacron";s:3:"-30";s:7:"eogonek";s:3:"-30";s:1:"o";s:3:"-10";s:6:"oacute";s:3:"-10";s:11:"ocircumflex";s:3:"-10";s:9:"odieresis";s:3:"-10";s:6:"ograve";s:3:"-10";s:13:"ohungarumlaut";s:3:"-10";s:7:"omacron";s:3:"-10";s:6:"oslash";s:3:"-10";s:6:"otilde";s:3:"-10";}s:12:"kcommaaccent";a:18:{s:1:"e";s:3:"-30";s:6:"eacute";s:3:"-30";s:6:"ecaron";s:3:"-30";s:11:"ecircumflex";s:3:"-30";s:9:"edieresis";s:3:"-30";s:10:"edotaccent";s:3:"-30";s:6:"egrave";s:3:"-30";s:7:"emacron";s:3:"-30";s:7:"eogonek";s:3:"-30";s:1:"o";s:3:"-10";s:6:"oacute";s:3:"-10";s:11:"ocircumflex";s:3:"-10";s:9:"odieresis";s:3:"-10";s:6:"ograve";s:3:"-10";s:13:"ohungarumlaut";s:3:"-10";s:7:"omacron";s:3:"-10";s:6:"oslash";s:3:"-10";s:6:"otilde";s:3:"-10";}s:1:"n";a:1:{s:1:"v";s:3:"-40";}s:6:"nacute";a:1:{s:1:"v";s:3:"-40";}s:6:"ncaron";a:1:{s:1:"v";s:3:"-40";}s:12:"ncommaaccent";a:1:{s:1:"v";s:3:"-40";}s:6:"ntilde";a:1:{s:1:"v";s:3:"-40";}s:1:"o";a:6:{s:1:"v";s:3:"-15";s:1:"w";s:3:"-25";s:1:"x";s:3:"-10";s:1:"y";s:3:"-10";s:6:"yacute";s:3:"-10";s:9:"ydieresis";s:3:"-10";}s:6:"oacute";a:6:{s:1:"v";s:3:"-15";s:1:"w";s:3:"-25";s:1:"x";s:3:"-10";s:1:"y";s:3:"-10";s:6:"yacute";s:3:"-10";s:9:"ydieresis";s:3:"-10";}s:11:"ocircumflex";a:6:{s:1:"v";s:3:"-15";s:1:"w";s:3:"-25";s:1:"x";s:3:"-10";s:1:"y";s:3:"-10";s:6:"yacute";s:3:"-10";s:9:"ydieresis";s:3:"-10";}s:9:"odieresis";a:6:{s:1:"v";s:3:"-15";s:1:"w";s:3:"-25";s:1:"x";s:3:"-10";s:1:"y";s:3:"-10";s:6:"yacute";s:3:"-10";s:9:"ydieresis";s:3:"-10";}s:6:"ograve";a:6:{s:1:"v";s:3:"-15";s:1:"w";s:3:"-25";s:1:"x";s:3:"-10";s:1:"y";s:3:"-10";s:6:"yacute";s:3:"-10";s:9:"ydieresis";s:3:"-10";}s:13:"ohungarumlaut";a:6:{s:1:"v";s:3:"-15";s:1:"w";s:3:"-25";s:1:"x";s:3:"-10";s:1:"y";s:3:"-10";s:6:"yacute";s:3:"-10";s:9:"ydieresis";s:3:"-10";}s:7:"omacron";a:6:{s:1:"v";s:3:"-15";s:1:"w";s:3:"-25";s:1:"x";s:3:"-10";s:1:"y";s:3:"-10";s:6:"yacute";s:3:"-10";s:9:"ydieresis";s:3:"-10";}s:6:"oslash";a:6:{s:1:"v";s:3:"-15";s:1:"w";s:3:"-25";s:1:"x";s:3:"-10";s:1:"y";s:3:"-10";s:6:"yacute";s:3:"-10";s:9:"ydieresis";s:3:"-10";}s:6:"otilde";a:6:{s:1:"v";s:3:"-15";s:1:"w";s:3:"-25";s:1:"x";s:3:"-10";s:1:"y";s:3:"-10";s:6:"yacute";s:3:"-10";s:9:"ydieresis";s:3:"-10";}s:6:"period";a:2:{s:13:"quotedblright";s:3:"-95";s:10:"quoteright";s:3:"-95";}s:9:"quoteleft";a:1:{s:9:"quoteleft";s:3:"-74";}s:10:"quoteright";a:16:{s:1:"d";s:3:"-15";s:6:"dcroat";s:3:"-15";s:10:"quoteright";s:3:"-74";s:1:"r";s:3:"-15";s:6:"racute";s:3:"-15";s:6:"rcaron";s:3:"-15";s:12:"rcommaaccent";s:3:"-15";s:1:"s";s:3:"-74";s:6:"sacute";s:3:"-74";s:6:"scaron";s:3:"-74";s:8:"scedilla";s:3:"-74";s:12:"scommaaccent";s:3:"-74";s:5:"space";s:3:"-74";s:1:"t";s:3:"-37";s:12:"tcommaaccent";s:3:"-37";s:1:"v";s:3:"-15";}s:1:"r";a:2:{s:5:"comma";s:3:"-65";s:6:"period";s:3:"-65";}s:6:"racute";a:2:{s:5:"comma";s:3:"-65";s:6:"period";s:3:"-65";}s:6:"rcaron";a:2:{s:5:"comma";s:3:"-65";s:6:"period";s:3:"-65";}s:12:"rcommaaccent";a:2:{s:5:"comma";s:3:"-65";s:6:"period";s:3:"-65";}s:5:"space";a:15:{s:1:"A";s:3:"-37";s:6:"Aacute";s:3:"-37";s:6:"Abreve";s:3:"-37";s:11:"Acircumflex";s:3:"-37";s:9:"Adieresis";s:3:"-37";s:6:"Agrave";s:3:"-37";s:7:"Amacron";s:3:"-37";s:7:"Aogonek";s:3:"-37";s:5:"Aring";s:3:"-37";s:6:"Atilde";s:3:"-37";s:1:"V";s:3:"-70";s:1:"W";s:3:"-70";s:1:"Y";s:3:"-70";s:6:"Yacute";s:3:"-70";s:9:"Ydieresis";s:3:"-70";}s:1:"v";a:20:{s:5:"comma";s:3:"-37";s:1:"e";s:3:"-15";s:6:"eacute";s:3:"-15";s:6:"ecaron";s:3:"-15";s:11:"ecircumflex";s:3:"-15";s:9:"edieresis";s:3:"-15";s:10:"edotaccent";s:3:"-15";s:6:"egrave";s:3:"-15";s:7:"emacron";s:3:"-15";s:7:"eogonek";s:3:"-15";s:1:"o";s:3:"-15";s:6:"oacute";s:3:"-15";s:11:"ocircumflex";s:3:"-15";s:9:"odieresis";s:3:"-15";s:6:"ograve";s:3:"-15";s:13:"ohungarumlaut";s:3:"-15";s:7:"omacron";s:3:"-15";s:6:"oslash";s:3:"-15";s:6:"otilde";s:3:"-15";s:6:"period";s:3:"-37";}s:1:"w";a:30:{s:1:"a";s:3:"-10";s:6:"aacute";s:3:"-10";s:6:"abreve";s:3:"-10";s:11:"acircumflex";s:3:"-10";s:9:"adieresis";s:3:"-10";s:6:"agrave";s:3:"-10";s:7:"amacron";s:3:"-10";s:7:"aogonek";s:3:"-10";s:5:"aring";s:3:"-10";s:6:"atilde";s:3:"-10";s:5:"comma";s:3:"-37";s:1:"e";s:3:"-10";s:6:"eacute";s:3:"-10";s:6:"ecaron";s:3:"-10";s:11:"ecircumflex";s:3:"-10";s:9:"edieresis";s:3:"-10";s:10:"edotaccent";s:3:"-10";s:6:"egrave";s:3:"-10";s:7:"emacron";s:3:"-10";s:7:"eogonek";s:3:"-10";s:1:"o";s:3:"-15";s:6:"oacute";s:3:"-15";s:11:"ocircumflex";s:3:"-15";s:9:"odieresis";s:3:"-15";s:6:"ograve";s:3:"-15";s:13:"ohungarumlaut";s:3:"-15";s:7:"omacron";s:3:"-15";s:6:"oslash";s:3:"-15";s:6:"otilde";s:3:"-15";s:6:"period";s:3:"-37";}s:1:"x";a:9:{s:1:"e";s:3:"-10";s:6:"eacute";s:3:"-10";s:6:"ecaron";s:3:"-10";s:11:"ecircumflex";s:3:"-10";s:9:"edieresis";s:3:"-10";s:10:"edotaccent";s:3:"-10";s:6:"egrave";s:3:"-10";s:7:"emacron";s:3:"-10";s:7:"eogonek";s:3:"-10";}s:1:"y";a:2:{s:5:"comma";s:3:"-37";s:6:"period";s:3:"-37";}s:6:"yacute";a:2:{s:5:"comma";s:3:"-37";s:6:"period";s:3:"-37";}s:9:"ydieresis";a:2:{s:5:"comma";s:3:"-37";s:6:"period";s:3:"-37";}}s:9:"_version_";i:1;}
\ No newline at end of file
Added: trunk/mapbender/http/classes/fonts/php_Times-Italic.afm
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/fonts/php_Times-Italic.afm?view=auto&rev=54
--- (empty file)
+++ trunk/mapbender/http/classes/fonts/php_Times-Italic.afm	2006-04-13 21:05:53+0000
@@ -0,0 +1 @@
+a:22:{s:8:"FontName";s:12:"Times-Italic";s:8:"FullName";s:12:"Times Italic";s:10:"FamilyName";s:5:"Times";s:6:"Weight";s:6:"Medium";s:11:"ItalicAngle";s:5:"-15.5";s:12:"IsFixedPitch";s:5:"false";s:12:"CharacterSet";s:13:"ExtendedRoman";s:8:"FontBBox";a:4:{i:0;s:4:"-169";i:1;s:4:"-217";i:2;s:4:"1010";i:3;s:3:"883";}s:17:"UnderlinePosition";s:4:"-100";s:18:"UnderlineThickness";s:2:"50";s:7:"Version";s:7:"002.000";s:14:"EncodingScheme";s:21:"AdobeStandardEncoding";s:9:"CapHeight";s:3:"653";s:7:"XHeight";s:3:"441";s:8:"Ascender";s:3:"683";s:9:"Descender";s:4:"-217";s:5:"StdHW";s:2:"32";s:5:"StdVW";s:2:"76";s:16:"StartCharMetrics";s:3:"315";s:1:"C";a:464:{i:32;a:4:{s:1:"C";s:2:"32";s:2:"WX";s:3:"250";s:1:"N";s:5:"space";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}s:5:"space";a:4:{s:1:"C";s:2:"32";s:2:"WX";s:3:"250";s:1:"N";s:5:"space";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}i:33;a:4:{s:1:"C";s:2:"33";s:2:"WX";s:3:"333";s:1:"N";s:6:"exclam";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:3:"-11";i:2;s:3:"302";i:3;s:3:"667";}}s:6:"exclam";a:4:{s:1:"C";s:2:"33";s:2:"WX";s:3:"333";s:1:"N";s:6:"exclam";s:1:"B";a:4:{i:0;s:2:"39";i:1;s:3:"-11";i:2;s:3:"302";i:3;s:3:"667";}}i:34;a:4:{s:1:"C";s:2:"34";s:2:"WX";s:3:"420";s:1:"N";s:8:"quotedbl";s:1:"B";a:4:{i:0;s:3:"144";i:1;s:3:"421";i:2;s:3:"432";i:3;s:3:"666";}}s:8:"quotedbl";a:4:{s:1:"C";s:2:"34";s:2:"WX";s:3:"420";s:1:"N";s:8:"quotedbl";s:1:"B";a:4:{i:0;s:3:"144";i:1;s:3:"421";i:2;s:3:"432";i:3;s:3:"666";}}i:35;a:4:{s:1:"C";s:2:"35";s:2:"WX";s:3:"500";s:1:"N";s:10:"numbersign";s:1:"B";a:4:{i:0;s:1:"2";i:1;s:1:"0";i:2;s:3:"540";i:3;s:3:"676";}}s:10:"numbersign";a:4:{s:1:"C";s:2:"35";s:2:"WX";s:3:"500";s:1:"N";s:10:"numbersign";s:1:"B";a:4:{i:0;s:1:"2";i:1;s:1:"0";i:2;s:3:"540";i:3;s:3:"676";}}i:36;a:4:{s:1:"C";s:2:"36";s:2:"WX";s:3:"500";s:1:"N";s:6:"dollar";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:3:"-89";i:2;s:3:"497";i:3;s:3:"731";}}s:6:"dollar";a:4:{s:1:"C";s:2:"36";s:2:"WX";s:3:"500";s:1:"N";s:6:"dollar";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:3:"-89";i:2;s:3:"497";i:3;s:3:"731";}}i:37;a:4:{s:1:"C";s:2:"37";s:2:"WX";s:3:"833";s:1:"N";s:7:"percent";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:3:"-13";i:2;s:3:"790";i:3;s:3:"676";}}s:7:"percent";a:4:{s:1:"C";s:2:"37";s:2:"WX";s:3:"833";s:1:"N";s:7:"percent";s:1:"B";a:4:{i:0;s:2:"79";i:1;s:3:"-13";i:2;s:3:"790";i:3;s:3:"676";}}i:38;a:4:{s:1:"C";s:2:"38";s:2:"WX";s:3:"778";s:1:"N";s:9:"ampersand";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:3:"-18";i:2;s:3:"723";i:3;s:3:"666";}}s:9:"ampersand";a:4:{s:1:"C";s:2:"38";s:2:"WX";s:3:"778";s:1:"N";s:9:"ampersand";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:3:"-18";i:2;s:3:"723";i:3;s:3:"666";}}i:39;a:4:{s:1:"C";s:2:"39";s:2:"WX";s:3:"333";s:1:"N";s:10:"quoteright";s:1:"B";a:4:{i:0;s:3:"151";i:1;s:3:"436";i:2;s:3:"290";i:3;s:3:"666";}}s:10:"quoteright";a:4:{s:1:"C";s:2:"39";s:2:"WX";s:3:"333";s:1:"N";s:10:"quoteright";s:1:"B";a:4:{i:0;s:3:"151";i:1;s:3:"436";i:2;s:3:"290";i:3;s:3:"666";}}i:40;a:4:{s:1:"C";s:2:"40";s:2:"WX";s:3:"333";s:1:"N";s:9:"parenleft";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:4:"-181";i:2;s:3:"315";i:3;s:3:"669";}}s:9:"parenleft";a:4:{s:1:"C";s:2:"40";s:2:"WX";s:3:"333";s:1:"N";s:9:"parenleft";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:4:"-181";i:2;s:3:"315";i:3;s:3:"669";}}i:41;a:4:{s:1:"C";s:2:"41";s:2:"WX";s:3:"333";s:1:"N";s:10:"parenright";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:4:"-180";i:2;s:3:"289";i:3;s:3:"669";}}s:10:"parenright";a:4:{s:1:"C";s:2:"41";s:2:"WX";s:3:"333";s:1:"N";s:10:"parenright";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:4:"-180";i:2;s:3:"289";i:3;s:3:"669";}}i:42;a:4:{s:1:"C";s:2:"42";s:2:"WX";s:3:"500";s:1:"N";s:8:"asterisk";s:1:"B";a:4:{i:0;s:3:"128";i:1;s:3:"255";i:2;s:3:"492";i:3;s:3:"666";}}s:8:"asterisk";a:4:{s:1:"C";s:2:"42";s:2:"WX";s:3:"500";s:1:"N";s:8:"asterisk";s:1:"B";a:4:{i:0;s:3:"128";i:1;s:3:"255";i:2;s:3:"492";i:3;s:3:"666";}}i:43;a:4:{s:1:"C";s:2:"43";s:2:"WX";s:3:"675";s:1:"N";s:4:"plus";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"590";i:3;s:3:"506";}}s:4:"plus";a:4:{s:1:"C";s:2:"43";s:2:"WX";s:3:"675";s:1:"N";s:4:"plus";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"590";i:3;s:3:"506";}}i:44;a:4:{s:1:"C";s:2:"44";s:2:"WX";s:3:"250";s:1:"N";s:5:"comma";s:1:"B";a:4:{i:0;s:2:"-4";i:1;s:4:"-129";i:2;s:3:"135";i:3;s:3:"101";}}s:5:"comma";a:4:{s:1:"C";s:2:"44";s:2:"WX";s:3:"250";s:1:"N";s:5:"comma";s:1:"B";a:4:{i:0;s:2:"-4";i:1;s:4:"-129";i:2;s:3:"135";i:3;s:3:"101";}}i:45;a:4:{s:1:"C";s:2:"45";s:2:"WX";s:3:"333";s:1:"N";s:6:"hyphen";s:1:"B";a:4:{i:0;s:2:"49";i:1;s:3:"192";i:2;s:3:"282";i:3;s:3:"255";}}s:6:"hyphen";a:4:{s:1:"C";s:2:"45";s:2:"WX";s:3:"333";s:1:"N";s:6:"hyphen";s:1:"B";a:4:{i:0;s:2:"49";i:1;s:3:"192";i:2;s:3:"282";i:3;s:3:"255";}}i:46;a:4:{s:1:"C";s:2:"46";s:2:"WX";s:3:"250";s:1:"N";s:6:"period";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:3:"-11";i:2;s:3:"138";i:3;s:3:"100";}}s:6:"period";a:4:{s:1:"C";s:2:"46";s:2:"WX";s:3:"250";s:1:"N";s:6:"period";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:3:"-11";i:2;s:3:"138";i:3;s:3:"100";}}i:47;a:4:{s:1:"C";s:2:"47";s:2:"WX";s:3:"278";s:1:"N";s:5:"slash";s:1:"B";a:4:{i:0;s:3:"-65";i:1;s:3:"-18";i:2;s:3:"386";i:3;s:3:"666";}}s:5:"slash";a:4:{s:1:"C";s:2:"47";s:2:"WX";s:3:"278";s:1:"N";s:5:"slash";s:1:"B";a:4:{i:0;s:3:"-65";i:1;s:3:"-18";i:2;s:3:"386";i:3;s:3:"666";}}i:48;a:4:{s:1:"C";s:2:"48";s:2:"WX";s:3:"500";s:1:"N";s:4:"zero";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:2:"-7";i:2;s:3:"497";i:3;s:3:"676";}}s:4:"zero";a:4:{s:1:"C";s:2:"48";s:2:"WX";s:3:"500";s:1:"N";s:4:"zero";s:1:"B";a:4:{i:0;s:2:"32";i:1;s:2:"-7";i:2;s:3:"497";i:3;s:3:"676";}}i:49;a:4:{s:1:"C";s:2:"49";s:2:"WX";s:3:"500";s:1:"N";s:3:"one";s:1:"B";a:4:{i:0;s:2:"49";i:1;s:1:"0";i:2;s:3:"409";i:3;s:3:"676";}}s:3:"one";a:4:{s:1:"C";s:2:"49";s:2:"WX";s:3:"500";s:1:"N";s:3:"one";s:1:"B";a:4:{i:0;s:2:"49";i:1;s:1:"0";i:2;s:3:"409";i:3;s:3:"676";}}i:50;a:4:{s:1:"C";s:2:"50";s:2:"WX";s:3:"500";s:1:"N";s:3:"two";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"452";i:3;s:3:"676";}}s:3:"two";a:4:{s:1:"C";s:2:"50";s:2:"WX";s:3:"500";s:1:"N";s:3:"two";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:1:"0";i:2;s:3:"452";i:3;s:3:"676";}}i:51;a:4:{s:1:"C";s:2:"51";s:2:"WX";s:3:"500";s:1:"N";s:5:"three";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:2:"-7";i:2;s:3:"465";i:3;s:3:"676";}}s:5:"three";a:4:{s:1:"C";s:2:"51";s:2:"WX";s:3:"500";s:1:"N";s:5:"three";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:2:"-7";i:2;s:3:"465";i:3;s:3:"676";}}i:52;a:4:{s:1:"C";s:2:"52";s:2:"WX";s:3:"500";s:1:"N";s:4:"four";s:1:"B";a:4:{i:0;s:1:"1";i:1;s:1:"0";i:2;s:3:"479";i:3;s:3:"676";}}s:4:"four";a:4:{s:1:"C";s:2:"52";s:2:"WX";s:3:"500";s:1:"N";s:4:"four";s:1:"B";a:4:{i:0;s:1:"1";i:1;s:1:"0";i:2;s:3:"479";i:3;s:3:"676";}}i:53;a:4:{s:1:"C";s:2:"53";s:2:"WX";s:3:"500";s:1:"N";s:4:"five";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:2:"-7";i:2;s:3:"491";i:3;s:3:"666";}}s:4:"five";a:4:{s:1:"C";s:2:"53";s:2:"WX";s:3:"500";s:1:"N";s:4:"five";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:2:"-7";i:2;s:3:"491";i:3;s:3:"666";}}i:54;a:4:{s:1:"C";s:2:"54";s:2:"WX";s:3:"500";s:1:"N";s:3:"six";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:2:"-7";i:2;s:3:"521";i:3;s:3:"686";}}s:3:"six";a:4:{s:1:"C";s:2:"54";s:2:"WX";s:3:"500";s:1:"N";s:3:"six";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:2:"-7";i:2;s:3:"521";i:3;s:3:"686";}}i:55;a:4:{s:1:"C";s:2:"55";s:2:"WX";s:3:"500";s:1:"N";s:5:"seven";s:1:"B";a:4:{i:0;s:2:"75";i:1;s:2:"-8";i:2;s:3:"537";i:3;s:3:"666";}}s:5:"seven";a:4:{s:1:"C";s:2:"55";s:2:"WX";s:3:"500";s:1:"N";s:5:"seven";s:1:"B";a:4:{i:0;s:2:"75";i:1;s:2:"-8";i:2;s:3:"537";i:3;s:3:"666";}}i:56;a:4:{s:1:"C";s:2:"56";s:2:"WX";s:3:"500";s:1:"N";s:5:"eight";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:2:"-7";i:2;s:3:"493";i:3;s:3:"676";}}s:5:"eight";a:4:{s:1:"C";s:2:"56";s:2:"WX";s:3:"500";s:1:"N";s:5:"eight";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:2:"-7";i:2;s:3:"493";i:3;s:3:"676";}}i:57;a:4:{s:1:"C";s:2:"57";s:2:"WX";s:3:"500";s:1:"N";s:4:"nine";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:3:"-17";i:2;s:3:"492";i:3;s:3:"676";}}s:4:"nine";a:4:{s:1:"C";s:2:"57";s:2:"WX";s:3:"500";s:1:"N";s:4:"nine";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:3:"-17";i:2;s:3:"492";i:3;s:3:"676";}}i:58;a:4:{s:1:"C";s:2:"58";s:2:"WX";s:3:"333";s:1:"N";s:5:"colon";s:1:"B";a:4:{i:0;s:2:"50";i:1;s:3:"-11";i:2;s:3:"261";i:3;s:3:"441";}}s:5:"colon";a:4:{s:1:"C";s:2:"58";s:2:"WX";s:3:"333";s:1:"N";s:5:"colon";s:1:"B";a:4:{i:0;s:2:"50";i:1;s:3:"-11";i:2;s:3:"261";i:3;s:3:"441";}}i:59;a:4:{s:1:"C";s:2:"59";s:2:"WX";s:3:"333";s:1:"N";s:9:"semicolon";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:4:"-129";i:2;s:3:"261";i:3;s:3:"441";}}s:9:"semicolon";a:4:{s:1:"C";s:2:"59";s:2:"WX";s:3:"333";s:1:"N";s:9:"semicolon";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:4:"-129";i:2;s:3:"261";i:3;s:3:"441";}}i:60;a:4:{s:1:"C";s:2:"60";s:2:"WX";s:3:"675";s:1:"N";s:4:"less";s:1:"B";a:4:{i:0;s:2:"84";i:1;s:2:"-8";i:2;s:3:"592";i:3;s:3:"514";}}s:4:"less";a:4:{s:1:"C";s:2:"60";s:2:"WX";s:3:"675";s:1:"N";s:4:"less";s:1:"B";a:4:{i:0;s:2:"84";i:1;s:2:"-8";i:2;s:3:"592";i:3;s:3:"514";}}i:61;a:4:{s:1:"C";s:2:"61";s:2:"WX";s:3:"675";s:1:"N";s:5:"equal";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:3:"120";i:2;s:3:"590";i:3;s:3:"386";}}s:5:"equal";a:4:{s:1:"C";s:2:"61";s:2:"WX";s:3:"675";s:1:"N";s:5:"equal";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:3:"120";i:2;s:3:"590";i:3;s:3:"386";}}i:62;a:4:{s:1:"C";s:2:"62";s:2:"WX";s:3:"675";s:1:"N";s:7:"greater";s:1:"B";a:4:{i:0;s:2:"84";i:1;s:2:"-8";i:2;s:3:"592";i:3;s:3:"514";}}s:7:"greater";a:4:{s:1:"C";s:2:"62";s:2:"WX";s:3:"675";s:1:"N";s:7:"greater";s:1:"B";a:4:{i:0;s:2:"84";i:1;s:2:"-8";i:2;s:3:"592";i:3;s:3:"514";}}i:63;a:4:{s:1:"C";s:2:"63";s:2:"WX";s:3:"500";s:1:"N";s:8:"question";s:1:"B";a:4:{i:0;s:3:"132";i:1;s:3:"-12";i:2;s:3:"472";i:3;s:3:"664";}}s:8:"question";a:4:{s:1:"C";s:2:"63";s:2:"WX";s:3:"500";s:1:"N";s:8:"question";s:1:"B";a:4:{i:0;s:3:"132";i:1;s:3:"-12";i:2;s:3:"472";i:3;s:3:"664";}}i:64;a:4:{s:1:"C";s:2:"64";s:2:"WX";s:3:"920";s:1:"N";s:2:"at";s:1:"B";a:4:{i:0;s:3:"118";i:1;s:3:"-18";i:2;s:3:"806";i:3;s:3:"666";}}s:2:"at";a:4:{s:1:"C";s:2:"64";s:2:"WX";s:3:"920";s:1:"N";s:2:"at";s:1:"B";a:4:{i:0;s:3:"118";i:1;s:3:"-18";i:2;s:3:"806";i:3;s:3:"666";}}i:65;a:4:{s:1:"C";s:2:"65";s:2:"WX";s:3:"611";s:1:"N";s:1:"A";s:1:"B";a:4:{i:0;s:3:"-51";i:1;s:1:"0";i:2;s:3:"564";i:3;s:3:"668";}}s:1:"A";a:4:{s:1:"C";s:2:"65";s:2:"WX";s:3:"611";s:1:"N";s:1:"A";s:1:"B";a:4:{i:0;s:3:"-51";i:1;s:1:"0";i:2;s:3:"564";i:3;s:3:"668";}}i:66;a:4:{s:1:"C";s:2:"66";s:2:"WX";s:3:"611";s:1:"N";s:1:"B";s:1:"B";a:4:{i:0;s:2:"-8";i:1;s:1:"0";i:2;s:3:"588";i:3;s:3:"653";}}s:1:"B";a:4:{s:1:"C";s:2:"66";s:2:"WX";s:3:"611";s:1:"N";s:1:"B";s:1:"B";a:4:{i:0;s:2:"-8";i:1;s:1:"0";i:2;s:3:"588";i:3;s:3:"653";}}i:67;a:4:{s:1:"C";s:2:"67";s:2:"WX";s:3:"667";s:1:"N";s:1:"C";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:3:"-18";i:2;s:3:"689";i:3;s:3:"666";}}s:1:"C";a:4:{s:1:"C";s:2:"67";s:2:"WX";s:3:"667";s:1:"N";s:1:"C";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:3:"-18";i:2;s:3:"689";i:3;s:3:"666";}}i:68;a:4:{s:1:"C";s:2:"68";s:2:"WX";s:3:"722";s:1:"N";s:1:"D";s:1:"B";a:4:{i:0;s:2:"-8";i:1;s:1:"0";i:2;s:3:"700";i:3;s:3:"653";}}s:1:"D";a:4:{s:1:"C";s:2:"68";s:2:"WX";s:3:"722";s:1:"N";s:1:"D";s:1:"B";a:4:{i:0;s:2:"-8";i:1;s:1:"0";i:2;s:3:"700";i:3;s:3:"653";}}i:69;a:4:{s:1:"C";s:2:"69";s:2:"WX";s:3:"611";s:1:"N";s:1:"E";s:1:"B";a:4:{i:0;s:2:"-1";i:1;s:1:"0";i:2;s:3:"634";i:3;s:3:"653";}}s:1:"E";a:4:{s:1:"C";s:2:"69";s:2:"WX";s:3:"611";s:1:"N";s:1:"E";s:1:"B";a:4:{i:0;s:2:"-1";i:1;s:1:"0";i:2;s:3:"634";i:3;s:3:"653";}}i:70;a:4:{s:1:"C";s:2:"70";s:2:"WX";s:3:"611";s:1:"N";s:1:"F";s:1:"B";a:4:{i:0;s:1:"8";i:1;s:1:"0";i:2;s:3:"645";i:3;s:3:"653";}}s:1:"F";a:4:{s:1:"C";s:2:"70";s:2:"WX";s:3:"611";s:1:"N";s:1:"F";s:1:"B";a:4:{i:0;s:1:"8";i:1;s:1:"0";i:2;s:3:"645";i:3;s:3:"653";}}i:71;a:4:{s:1:"C";s:2:"71";s:2:"WX";s:3:"722";s:1:"N";s:1:"G";s:1:"B";a:4:{i:0;s:2:"52";i:1;s:3:"-18";i:2;s:3:"722";i:3;s:3:"666";}}s:1:"G";a:4:{s:1:"C";s:2:"71";s:2:"WX";s:3:"722";s:1:"N";s:1:"G";s:1:"B";a:4:{i:0;s:2:"52";i:1;s:3:"-18";i:2;s:3:"722";i:3;s:3:"666";}}i:72;a:4:{s:1:"C";s:2:"72";s:2:"WX";s:3:"722";s:1:"N";s:1:"H";s:1:"B";a:4:{i:0;s:2:"-8";i:1;s:1:"0";i:2;s:3:"767";i:3;s:3:"653";}}s:1:"H";a:4:{s:1:"C";s:2:"72";s:2:"WX";s:3:"722";s:1:"N";s:1:"H";s:1:"B";a:4:{i:0;s:2:"-8";i:1;s:1:"0";i:2;s:3:"767";i:3;s:3:"653";}}i:73;a:4:{s:1:"C";s:2:"73";s:2:"WX";s:3:"333";s:1:"N";s:1:"I";s:1:"B";a:4:{i:0;s:2:"-8";i:1;s:1:"0";i:2;s:3:"384";i:3;s:3:"653";}}s:1:"I";a:4:{s:1:"C";s:2:"73";s:2:"WX";s:3:"333";s:1:"N";s:1:"I";s:1:"B";a:4:{i:0;s:2:"-8";i:1;s:1:"0";i:2;s:3:"384";i:3;s:3:"653";}}i:74;a:4:{s:1:"C";s:2:"74";s:2:"WX";s:3:"444";s:1:"N";s:1:"J";s:1:"B";a:4:{i:0;s:2:"-6";i:1;s:3:"-18";i:2;s:3:"491";i:3;s:3:"653";}}s:1:"J";a:4:{s:1:"C";s:2:"74";s:2:"WX";s:3:"444";s:1:"N";s:1:"J";s:1:"B";a:4:{i:0;s:2:"-6";i:1;s:3:"-18";i:2;s:3:"491";i:3;s:3:"653";}}i:75;a:4:{s:1:"C";s:2:"75";s:2:"WX";s:3:"667";s:1:"N";s:1:"K";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:1:"0";i:2;s:3:"722";i:3;s:3:"653";}}s:1:"K";a:4:{s:1:"C";s:2:"75";s:2:"WX";s:3:"667";s:1:"N";s:1:"K";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:1:"0";i:2;s:3:"722";i:3;s:3:"653";}}i:76;a:4:{s:1:"C";s:2:"76";s:2:"WX";s:3:"556";s:1:"N";s:1:"L";s:1:"B";a:4:{i:0;s:2:"-8";i:1;s:1:"0";i:2;s:3:"559";i:3;s:3:"653";}}s:1:"L";a:4:{s:1:"C";s:2:"76";s:2:"WX";s:3:"556";s:1:"N";s:1:"L";s:1:"B";a:4:{i:0;s:2:"-8";i:1;s:1:"0";i:2;s:3:"559";i:3;s:3:"653";}}i:77;a:4:{s:1:"C";s:2:"77";s:2:"WX";s:3:"833";s:1:"N";s:1:"M";s:1:"B";a:4:{i:0;s:3:"-18";i:1;s:1:"0";i:2;s:3:"873";i:3;s:3:"653";}}s:1:"M";a:4:{s:1:"C";s:2:"77";s:2:"WX";s:3:"833";s:1:"N";s:1:"M";s:1:"B";a:4:{i:0;s:3:"-18";i:1;s:1:"0";i:2;s:3:"873";i:3;s:3:"653";}}i:78;a:4:{s:1:"C";s:2:"78";s:2:"WX";s:3:"667";s:1:"N";s:1:"N";s:1:"B";a:4:{i:0;s:3:"-20";i:1;s:3:"-15";i:2;s:3:"727";i:3;s:3:"653";}}s:1:"N";a:4:{s:1:"C";s:2:"78";s:2:"WX";s:3:"667";s:1:"N";s:1:"N";s:1:"B";a:4:{i:0;s:3:"-20";i:1;s:3:"-15";i:2;s:3:"727";i:3;s:3:"653";}}i:79;a:4:{s:1:"C";s:2:"79";s:2:"WX";s:3:"722";s:1:"N";s:1:"O";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:3:"-18";i:2;s:3:"699";i:3;s:3:"666";}}s:1:"O";a:4:{s:1:"C";s:2:"79";s:2:"WX";s:3:"722";s:1:"N";s:1:"O";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:3:"-18";i:2;s:3:"699";i:3;s:3:"666";}}i:80;a:4:{s:1:"C";s:2:"80";s:2:"WX";s:3:"611";s:1:"N";s:1:"P";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:3:"605";i:3;s:3:"653";}}s:1:"P";a:4:{s:1:"C";s:2:"80";s:2:"WX";s:3:"611";s:1:"N";s:1:"P";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:3:"605";i:3;s:3:"653";}}i:81;a:4:{s:1:"C";s:2:"81";s:2:"WX";s:3:"722";s:1:"N";s:1:"Q";s:1:"B";a:4:{i:0;s:2:"59";i:1;s:4:"-182";i:2;s:3:"699";i:3;s:3:"666";}}s:1:"Q";a:4:{s:1:"C";s:2:"81";s:2:"WX";s:3:"722";s:1:"N";s:1:"Q";s:1:"B";a:4:{i:0;s:2:"59";i:1;s:4:"-182";i:2;s:3:"699";i:3;s:3:"666";}}i:82;a:4:{s:1:"C";s:2:"82";s:2:"WX";s:3:"611";s:1:"N";s:1:"R";s:1:"B";a:4:{i:0;s:3:"-13";i:1;s:1:"0";i:2;s:3:"588";i:3;s:3:"653";}}s:1:"R";a:4:{s:1:"C";s:2:"82";s:2:"WX";s:3:"611";s:1:"N";s:1:"R";s:1:"B";a:4:{i:0;s:3:"-13";i:1;s:1:"0";i:2;s:3:"588";i:3;s:3:"653";}}i:83;a:4:{s:1:"C";s:2:"83";s:2:"WX";s:3:"500";s:1:"N";s:1:"S";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:3:"-18";i:2;s:3:"508";i:3;s:3:"667";}}s:1:"S";a:4:{s:1:"C";s:2:"83";s:2:"WX";s:3:"500";s:1:"N";s:1:"S";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:3:"-18";i:2;s:3:"508";i:3;s:3:"667";}}i:84;a:4:{s:1:"C";s:2:"84";s:2:"WX";s:3:"556";s:1:"N";s:1:"T";s:1:"B";a:4:{i:0;s:2:"59";i:1;s:1:"0";i:2;s:3:"633";i:3;s:3:"653";}}s:1:"T";a:4:{s:1:"C";s:2:"84";s:2:"WX";s:3:"556";s:1:"N";s:1:"T";s:1:"B";a:4:{i:0;s:2:"59";i:1;s:1:"0";i:2;s:3:"633";i:3;s:3:"653";}}i:85;a:4:{s:1:"C";s:2:"85";s:2:"WX";s:3:"722";s:1:"N";s:1:"U";s:1:"B";a:4:{i:0;s:3:"102";i:1;s:3:"-18";i:2;s:3:"765";i:3;s:3:"653";}}s:1:"U";a:4:{s:1:"C";s:2:"85";s:2:"WX";s:3:"722";s:1:"N";s:1:"U";s:1:"B";a:4:{i:0;s:3:"102";i:1;s:3:"-18";i:2;s:3:"765";i:3;s:3:"653";}}i:86;a:4:{s:1:"C";s:2:"86";s:2:"WX";s:3:"611";s:1:"N";s:1:"V";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:3:"-18";i:2;s:3:"688";i:3;s:3:"653";}}s:1:"V";a:4:{s:1:"C";s:2:"86";s:2:"WX";s:3:"611";s:1:"N";s:1:"V";s:1:"B";a:4:{i:0;s:2:"76";i:1;s:3:"-18";i:2;s:3:"688";i:3;s:3:"653";}}i:87;a:4:{s:1:"C";s:2:"87";s:2:"WX";s:3:"833";s:1:"N";s:1:"W";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:3:"-18";i:2;s:3:"906";i:3;s:3:"653";}}s:1:"W";a:4:{s:1:"C";s:2:"87";s:2:"WX";s:3:"833";s:1:"N";s:1:"W";s:1:"B";a:4:{i:0;s:2:"71";i:1;s:3:"-18";i:2;s:3:"906";i:3;s:3:"653";}}i:88;a:4:{s:1:"C";s:2:"88";s:2:"WX";s:3:"611";s:1:"N";s:1:"X";s:1:"B";a:4:{i:0;s:3:"-29";i:1;s:1:"0";i:2;s:3:"655";i:3;s:3:"653";}}s:1:"X";a:4:{s:1:"C";s:2:"88";s:2:"WX";s:3:"611";s:1:"N";s:1:"X";s:1:"B";a:4:{i:0;s:3:"-29";i:1;s:1:"0";i:2;s:3:"655";i:3;s:3:"653";}}i:89;a:4:{s:1:"C";s:2:"89";s:2:"WX";s:3:"556";s:1:"N";s:1:"Y";s:1:"B";a:4:{i:0;s:2:"78";i:1;s:1:"0";i:2;s:3:"633";i:3;s:3:"653";}}s:1:"Y";a:4:{s:1:"C";s:2:"89";s:2:"WX";s:3:"556";s:1:"N";s:1:"Y";s:1:"B";a:4:{i:0;s:2:"78";i:1;s:1:"0";i:2;s:3:"633";i:3;s:3:"653";}}i:90;a:4:{s:1:"C";s:2:"90";s:2:"WX";s:3:"556";s:1:"N";s:1:"Z";s:1:"B";a:4:{i:0;s:2:"-6";i:1;s:1:"0";i:2;s:3:"606";i:3;s:3:"653";}}s:1:"Z";a:4:{s:1:"C";s:2:"90";s:2:"WX";s:3:"556";s:1:"N";s:1:"Z";s:1:"B";a:4:{i:0;s:2:"-6";i:1;s:1:"0";i:2;s:3:"606";i:3;s:3:"653";}}i:91;a:4:{s:1:"C";s:2:"91";s:2:"WX";s:3:"389";s:1:"N";s:11:"bracketleft";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:4:"-153";i:2;s:3:"391";i:3;s:3:"663";}}s:11:"bracketleft";a:4:{s:1:"C";s:2:"91";s:2:"WX";s:3:"389";s:1:"N";s:11:"bracketleft";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:4:"-153";i:2;s:3:"391";i:3;s:3:"663";}}i:92;a:4:{s:1:"C";s:2:"92";s:2:"WX";s:3:"278";s:1:"N";s:9:"backslash";s:1:"B";a:4:{i:0;s:3:"-41";i:1;s:3:"-18";i:2;s:3:"319";i:3;s:3:"666";}}s:9:"backslash";a:4:{s:1:"C";s:2:"92";s:2:"WX";s:3:"278";s:1:"N";s:9:"backslash";s:1:"B";a:4:{i:0;s:3:"-41";i:1;s:3:"-18";i:2;s:3:"319";i:3;s:3:"666";}}i:93;a:4:{s:1:"C";s:2:"93";s:2:"WX";s:3:"389";s:1:"N";s:12:"bracketright";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:4:"-153";i:2;s:3:"382";i:3;s:3:"663";}}s:12:"bracketright";a:4:{s:1:"C";s:2:"93";s:2:"WX";s:3:"389";s:1:"N";s:12:"bracketright";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:4:"-153";i:2;s:3:"382";i:3;s:3:"663";}}i:94;a:4:{s:1:"C";s:2:"94";s:2:"WX";s:3:"422";s:1:"N";s:11:"asciicircum";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"301";i:2;s:3:"422";i:3;s:3:"666";}}s:11:"asciicircum";a:4:{s:1:"C";s:2:"94";s:2:"WX";s:3:"422";s:1:"N";s:11:"asciicircum";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"301";i:2;s:3:"422";i:3;s:3:"666";}}i:95;a:4:{s:1:"C";s:2:"95";s:2:"WX";s:3:"500";s:1:"N";s:10:"underscore";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:4:"-125";i:2;s:3:"500";i:3;s:3:"-75";}}s:10:"underscore";a:4:{s:1:"C";s:2:"95";s:2:"WX";s:3:"500";s:1:"N";s:10:"underscore";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:4:"-125";i:2;s:3:"500";i:3;s:3:"-75";}}i:96;a:4:{s:1:"C";s:2:"96";s:2:"WX";s:3:"333";s:1:"N";s:9:"quoteleft";s:1:"B";a:4:{i:0;s:3:"171";i:1;s:3:"436";i:2;s:3:"310";i:3;s:3:"666";}}s:9:"quoteleft";a:4:{s:1:"C";s:2:"96";s:2:"WX";s:3:"333";s:1:"N";s:9:"quoteleft";s:1:"B";a:4:{i:0;s:3:"171";i:1;s:3:"436";i:2;s:3:"310";i:3;s:3:"666";}}i:97;a:4:{s:1:"C";s:2:"97";s:2:"WX";s:3:"500";s:1:"N";s:1:"a";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:3:"-11";i:2;s:3:"476";i:3;s:3:"441";}}s:1:"a";a:4:{s:1:"C";s:2:"97";s:2:"WX";s:3:"500";s:1:"N";s:1:"a";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:3:"-11";i:2;s:3:"476";i:3;s:3:"441";}}i:98;a:4:{s:1:"C";s:2:"98";s:2:"WX";s:3:"500";s:1:"N";s:1:"b";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:3:"-11";i:2;s:3:"473";i:3;s:3:"683";}}s:1:"b";a:4:{s:1:"C";s:2:"98";s:2:"WX";s:3:"500";s:1:"N";s:1:"b";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:3:"-11";i:2;s:3:"473";i:3;s:3:"683";}}i:99;a:4:{s:1:"C";s:2:"99";s:2:"WX";s:3:"444";s:1:"N";s:1:"c";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-11";i:2;s:3:"425";i:3;s:3:"441";}}s:1:"c";a:4:{s:1:"C";s:2:"99";s:2:"WX";s:3:"444";s:1:"N";s:1:"c";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-11";i:2;s:3:"425";i:3;s:3:"441";}}i:100;a:4:{s:1:"C";s:3:"100";s:2:"WX";s:3:"500";s:1:"N";s:1:"d";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:3:"-13";i:2;s:3:"527";i:3;s:3:"683";}}s:1:"d";a:4:{s:1:"C";s:3:"100";s:2:"WX";s:3:"500";s:1:"N";s:1:"d";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:3:"-13";i:2;s:3:"527";i:3;s:3:"683";}}i:101;a:4:{s:1:"C";s:3:"101";s:2:"WX";s:3:"444";s:1:"N";s:1:"e";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:3:"-11";i:2;s:3:"412";i:3;s:3:"441";}}s:1:"e";a:4:{s:1:"C";s:3:"101";s:2:"WX";s:3:"444";s:1:"N";s:1:"e";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:3:"-11";i:2;s:3:"412";i:3;s:3:"441";}}i:102;a:5:{s:1:"C";s:3:"102";s:2:"WX";s:3:"278";s:1:"N";s:1:"f";s:1:"B";a:4:{i:0;s:4:"-147";i:1;s:4:"-207";i:2;s:3:"424";i:3;s:3:"678";}s:1:"L";a:2:{i:0;s:1:"l";i:1;s:2:"fl";}}s:1:"f";a:5:{s:1:"C";s:3:"102";s:2:"WX";s:3:"278";s:1:"N";s:1:"f";s:1:"B";a:4:{i:0;s:4:"-147";i:1;s:4:"-207";i:2;s:3:"424";i:3;s:3:"678";}s:1:"L";a:2:{i:0;s:1:"l";i:1;s:2:"fl";}}i:103;a:4:{s:1:"C";s:3:"103";s:2:"WX";s:3:"500";s:1:"N";s:1:"g";s:1:"B";a:4:{i:0;s:1:"8";i:1;s:4:"-206";i:2;s:3:"472";i:3;s:3:"441";}}s:1:"g";a:4:{s:1:"C";s:3:"103";s:2:"WX";s:3:"500";s:1:"N";s:1:"g";s:1:"B";a:4:{i:0;s:1:"8";i:1;s:4:"-206";i:2;s:3:"472";i:3;s:3:"441";}}i:104;a:4:{s:1:"C";s:3:"104";s:2:"WX";s:3:"500";s:1:"N";s:1:"h";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:2:"-9";i:2;s:3:"478";i:3;s:3:"683";}}s:1:"h";a:4:{s:1:"C";s:3:"104";s:2:"WX";s:3:"500";s:1:"N";s:1:"h";s:1:"B";a:4:{i:0;s:2:"19";i:1;s:2:"-9";i:2;s:3:"478";i:3;s:3:"683";}}i:105;a:4:{s:1:"C";s:3:"105";s:2:"WX";s:3:"278";s:1:"N";s:1:"i";s:1:"B";a:4:{i:0;s:2:"49";i:1;s:3:"-11";i:2;s:3:"264";i:3;s:3:"654";}}s:1:"i";a:4:{s:1:"C";s:3:"105";s:2:"WX";s:3:"278";s:1:"N";s:1:"i";s:1:"B";a:4:{i:0;s:2:"49";i:1;s:3:"-11";i:2;s:3:"264";i:3;s:3:"654";}}i:106;a:4:{s:1:"C";s:3:"106";s:2:"WX";s:3:"278";s:1:"N";s:1:"j";s:1:"B";a:4:{i:0;s:4:"-124";i:1;s:4:"-207";i:2;s:3:"276";i:3;s:3:"654";}}s:1:"j";a:4:{s:1:"C";s:3:"106";s:2:"WX";s:3:"278";s:1:"N";s:1:"j";s:1:"B";a:4:{i:0;s:4:"-124";i:1;s:4:"-207";i:2;s:3:"276";i:3;s:3:"654";}}i:107;a:4:{s:1:"C";s:3:"107";s:2:"WX";s:3:"444";s:1:"N";s:1:"k";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:3:"-11";i:2;s:3:"461";i:3;s:3:"683";}}s:1:"k";a:4:{s:1:"C";s:3:"107";s:2:"WX";s:3:"444";s:1:"N";s:1:"k";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:3:"-11";i:2;s:3:"461";i:3;s:3:"683";}}i:108;a:4:{s:1:"C";s:3:"108";s:2:"WX";s:3:"278";s:1:"N";s:1:"l";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:3:"-11";i:2;s:3:"279";i:3;s:3:"683";}}s:1:"l";a:4:{s:1:"C";s:3:"108";s:2:"WX";s:3:"278";s:1:"N";s:1:"l";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:3:"-11";i:2;s:3:"279";i:3;s:3:"683";}}i:109;a:4:{s:1:"C";s:3:"109";s:2:"WX";s:3:"722";s:1:"N";s:1:"m";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:2:"-9";i:2;s:3:"704";i:3;s:3:"441";}}s:1:"m";a:4:{s:1:"C";s:3:"109";s:2:"WX";s:3:"722";s:1:"N";s:1:"m";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:2:"-9";i:2;s:3:"704";i:3;s:3:"441";}}i:110;a:4:{s:1:"C";s:3:"110";s:2:"WX";s:3:"500";s:1:"N";s:1:"n";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:2:"-9";i:2;s:3:"474";i:3;s:3:"441";}}s:1:"n";a:4:{s:1:"C";s:3:"110";s:2:"WX";s:3:"500";s:1:"N";s:1:"n";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:2:"-9";i:2;s:3:"474";i:3;s:3:"441";}}i:111;a:4:{s:1:"C";s:3:"111";s:2:"WX";s:3:"500";s:1:"N";s:1:"o";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:3:"-11";i:2;s:3:"468";i:3;s:3:"441";}}s:1:"o";a:4:{s:1:"C";s:3:"111";s:2:"WX";s:3:"500";s:1:"N";s:1:"o";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:3:"-11";i:2;s:3:"468";i:3;s:3:"441";}}i:112;a:4:{s:1:"C";s:3:"112";s:2:"WX";s:3:"500";s:1:"N";s:1:"p";s:1:"B";a:4:{i:0;s:3:"-75";i:1;s:4:"-205";i:2;s:3:"469";i:3;s:3:"441";}}s:1:"p";a:4:{s:1:"C";s:3:"112";s:2:"WX";s:3:"500";s:1:"N";s:1:"p";s:1:"B";a:4:{i:0;s:3:"-75";i:1;s:4:"-205";i:2;s:3:"469";i:3;s:3:"441";}}i:113;a:4:{s:1:"C";s:3:"113";s:2:"WX";s:3:"500";s:1:"N";s:1:"q";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:4:"-209";i:2;s:3:"483";i:3;s:3:"441";}}s:1:"q";a:4:{s:1:"C";s:3:"113";s:2:"WX";s:3:"500";s:1:"N";s:1:"q";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:4:"-209";i:2;s:3:"483";i:3;s:3:"441";}}i:114;a:4:{s:1:"C";s:3:"114";s:2:"WX";s:3:"389";s:1:"N";s:1:"r";s:1:"B";a:4:{i:0;s:2:"45";i:1;s:1:"0";i:2;s:3:"412";i:3;s:3:"441";}}s:1:"r";a:4:{s:1:"C";s:3:"114";s:2:"WX";s:3:"389";s:1:"N";s:1:"r";s:1:"B";a:4:{i:0;s:2:"45";i:1;s:1:"0";i:2;s:3:"412";i:3;s:3:"441";}}i:115;a:4:{s:1:"C";s:3:"115";s:2:"WX";s:3:"389";s:1:"N";s:1:"s";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-13";i:2;s:3:"366";i:3;s:3:"442";}}s:1:"s";a:4:{s:1:"C";s:3:"115";s:2:"WX";s:3:"389";s:1:"N";s:1:"s";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-13";i:2;s:3:"366";i:3;s:3:"442";}}i:116;a:4:{s:1:"C";s:3:"116";s:2:"WX";s:3:"278";s:1:"N";s:1:"t";s:1:"B";a:4:{i:0;s:2:"37";i:1;s:3:"-11";i:2;s:3:"296";i:3;s:3:"546";}}s:1:"t";a:4:{s:1:"C";s:3:"116";s:2:"WX";s:3:"278";s:1:"N";s:1:"t";s:1:"B";a:4:{i:0;s:2:"37";i:1;s:3:"-11";i:2;s:3:"296";i:3;s:3:"546";}}i:117;a:4:{s:1:"C";s:3:"117";s:2:"WX";s:3:"500";s:1:"N";s:1:"u";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-11";i:2;s:3:"475";i:3;s:3:"441";}}s:1:"u";a:4:{s:1:"C";s:3:"117";s:2:"WX";s:3:"500";s:1:"N";s:1:"u";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-11";i:2;s:3:"475";i:3;s:3:"441";}}i:118;a:4:{s:1:"C";s:3:"118";s:2:"WX";s:3:"444";s:1:"N";s:1:"v";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:3:"-18";i:2;s:3:"426";i:3;s:3:"441";}}s:1:"v";a:4:{s:1:"C";s:3:"118";s:2:"WX";s:3:"444";s:1:"N";s:1:"v";s:1:"B";a:4:{i:0;s:2:"21";i:1;s:3:"-18";i:2;s:3:"426";i:3;s:3:"441";}}i:119;a:4:{s:1:"C";s:3:"119";s:2:"WX";s:3:"667";s:1:"N";s:1:"w";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-18";i:2;s:3:"648";i:3;s:3:"441";}}s:1:"w";a:4:{s:1:"C";s:3:"119";s:2:"WX";s:3:"667";s:1:"N";s:1:"w";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-18";i:2;s:3:"648";i:3;s:3:"441";}}i:120;a:4:{s:1:"C";s:3:"120";s:2:"WX";s:3:"444";s:1:"N";s:1:"x";s:1:"B";a:4:{i:0;s:3:"-27";i:1;s:3:"-11";i:2;s:3:"447";i:3;s:3:"441";}}s:1:"x";a:4:{s:1:"C";s:3:"120";s:2:"WX";s:3:"444";s:1:"N";s:1:"x";s:1:"B";a:4:{i:0;s:3:"-27";i:1;s:3:"-11";i:2;s:3:"447";i:3;s:3:"441";}}i:121;a:4:{s:1:"C";s:3:"121";s:2:"WX";s:3:"444";s:1:"N";s:1:"y";s:1:"B";a:4:{i:0;s:3:"-24";i:1;s:4:"-206";i:2;s:3:"426";i:3;s:3:"441";}}s:1:"y";a:4:{s:1:"C";s:3:"121";s:2:"WX";s:3:"444";s:1:"N";s:1:"y";s:1:"B";a:4:{i:0;s:3:"-24";i:1;s:4:"-206";i:2;s:3:"426";i:3;s:3:"441";}}i:122;a:4:{s:1:"C";s:3:"122";s:2:"WX";s:3:"389";s:1:"N";s:1:"z";s:1:"B";a:4:{i:0;s:2:"-2";i:1;s:3:"-81";i:2;s:3:"380";i:3;s:3:"428";}}s:1:"z";a:4:{s:1:"C";s:3:"122";s:2:"WX";s:3:"389";s:1:"N";s:1:"z";s:1:"B";a:4:{i:0;s:2:"-2";i:1;s:3:"-81";i:2;s:3:"380";i:3;s:3:"428";}}i:123;a:4:{s:1:"C";s:3:"123";s:2:"WX";s:3:"400";s:1:"N";s:9:"braceleft";s:1:"B";a:4:{i:0;s:2:"51";i:1;s:4:"-177";i:2;s:3:"407";i:3;s:3:"687";}}s:9:"braceleft";a:4:{s:1:"C";s:3:"123";s:2:"WX";s:3:"400";s:1:"N";s:9:"braceleft";s:1:"B";a:4:{i:0;s:2:"51";i:1;s:4:"-177";i:2;s:3:"407";i:3;s:3:"687";}}i:124;a:4:{s:1:"C";s:3:"124";s:2:"WX";s:3:"275";s:1:"N";s:3:"bar";s:1:"B";a:4:{i:0;s:3:"105";i:1;s:4:"-217";i:2;s:3:"171";i:3;s:3:"783";}}s:3:"bar";a:4:{s:1:"C";s:3:"124";s:2:"WX";s:3:"275";s:1:"N";s:3:"bar";s:1:"B";a:4:{i:0;s:3:"105";i:1;s:4:"-217";i:2;s:3:"171";i:3;s:3:"783";}}i:125;a:4:{s:1:"C";s:3:"125";s:2:"WX";s:3:"400";s:1:"N";s:10:"braceright";s:1:"B";a:4:{i:0;s:2:"-7";i:1;s:4:"-177";i:2;s:3:"349";i:3;s:3:"687";}}s:10:"braceright";a:4:{s:1:"C";s:3:"125";s:2:"WX";s:3:"400";s:1:"N";s:10:"braceright";s:1:"B";a:4:{i:0;s:2:"-7";i:1;s:4:"-177";i:2;s:3:"349";i:3;s:3:"687";}}i:126;a:4:{s:1:"C";s:3:"126";s:2:"WX";s:3:"541";s:1:"N";s:10:"asciitilde";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"183";i:2;s:3:"502";i:3;s:3:"323";}}s:10:"asciitilde";a:4:{s:1:"C";s:3:"126";s:2:"WX";s:3:"541";s:1:"N";s:10:"asciitilde";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"183";i:2;s:3:"502";i:3;s:3:"323";}}i:161;a:4:{s:1:"C";s:3:"161";s:2:"WX";s:3:"389";s:1:"N";s:10:"exclamdown";s:1:"B";a:4:{i:0;s:2:"59";i:1;s:4:"-205";i:2;s:3:"322";i:3;s:3:"473";}}s:10:"exclamdown";a:4:{s:1:"C";s:3:"161";s:2:"WX";s:3:"389";s:1:"N";s:10:"exclamdown";s:1:"B";a:4:{i:0;s:2:"59";i:1;s:4:"-205";i:2;s:3:"322";i:3;s:3:"473";}}i:162;a:4:{s:1:"C";s:3:"162";s:2:"WX";s:3:"500";s:1:"N";s:4:"cent";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:4:"-143";i:2;s:3:"472";i:3;s:3:"560";}}s:4:"cent";a:4:{s:1:"C";s:3:"162";s:2:"WX";s:3:"500";s:1:"N";s:4:"cent";s:1:"B";a:4:{i:0;s:2:"77";i:1;s:4:"-143";i:2;s:3:"472";i:3;s:3:"560";}}i:163;a:4:{s:1:"C";s:3:"163";s:2:"WX";s:3:"500";s:1:"N";s:8:"sterling";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:2:"-6";i:2;s:3:"517";i:3;s:3:"670";}}s:8:"sterling";a:4:{s:1:"C";s:3:"163";s:2:"WX";s:3:"500";s:1:"N";s:8:"sterling";s:1:"B";a:4:{i:0;s:2:"10";i:1;s:2:"-6";i:2;s:3:"517";i:3;s:3:"670";}}i:164;a:4:{s:1:"C";s:3:"164";s:2:"WX";s:3:"167";s:1:"N";s:8:"fraction";s:1:"B";a:4:{i:0;s:4:"-169";i:1;s:3:"-10";i:2;s:3:"337";i:3;s:3:"676";}}s:8:"fraction";a:4:{s:1:"C";s:3:"164";s:2:"WX";s:3:"167";s:1:"N";s:8:"fraction";s:1:"B";a:4:{i:0;s:4:"-169";i:1;s:3:"-10";i:2;s:3:"337";i:3;s:3:"676";}}i:165;a:4:{s:1:"C";s:3:"165";s:2:"WX";s:3:"500";s:1:"N";s:3:"yen";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:1:"0";i:2;s:3:"603";i:3;s:3:"653";}}s:3:"yen";a:4:{s:1:"C";s:3:"165";s:2:"WX";s:3:"500";s:1:"N";s:3:"yen";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:1:"0";i:2;s:3:"603";i:3;s:3:"653";}}i:166;a:4:{s:1:"C";s:3:"166";s:2:"WX";s:3:"500";s:1:"N";s:6:"florin";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:4:"-182";i:2;s:3:"507";i:3;s:3:"682";}}s:6:"florin";a:4:{s:1:"C";s:3:"166";s:2:"WX";s:3:"500";s:1:"N";s:6:"florin";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:4:"-182";i:2;s:3:"507";i:3;s:3:"682";}}i:167;a:4:{s:1:"C";s:3:"167";s:2:"WX";s:3:"500";s:1:"N";s:7:"section";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:4:"-162";i:2;s:3:"461";i:3;s:3:"666";}}s:7:"section";a:4:{s:1:"C";s:3:"167";s:2:"WX";s:3:"500";s:1:"N";s:7:"section";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:4:"-162";i:2;s:3:"461";i:3;s:3:"666";}}i:168;a:4:{s:1:"C";s:3:"168";s:2:"WX";s:3:"500";s:1:"N";s:8:"currency";s:1:"B";a:4:{i:0;s:3:"-22";i:1;s:2:"53";i:2;s:3:"522";i:3;s:3:"597";}}s:8:"currency";a:4:{s:1:"C";s:3:"168";s:2:"WX";s:3:"500";s:1:"N";s:8:"currency";s:1:"B";a:4:{i:0;s:3:"-22";i:1;s:2:"53";i:2;s:3:"522";i:3;s:3:"597";}}i:169;a:4:{s:1:"C";s:3:"169";s:2:"WX";s:3:"214";s:1:"N";s:11:"quotesingle";s:1:"B";a:4:{i:0;s:3:"132";i:1;s:3:"421";i:2;s:3:"241";i:3;s:3:"666";}}s:11:"quotesingle";a:4:{s:1:"C";s:3:"169";s:2:"WX";s:3:"214";s:1:"N";s:11:"quotesingle";s:1:"B";a:4:{i:0;s:3:"132";i:1;s:3:"421";i:2;s:3:"241";i:3;s:3:"666";}}i:170;a:4:{s:1:"C";s:3:"170";s:2:"WX";s:3:"556";s:1:"N";s:12:"quotedblleft";s:1:"B";a:4:{i:0;s:3:"166";i:1;s:3:"436";i:2;s:3:"514";i:3;s:3:"666";}}s:12:"quotedblleft";a:4:{s:1:"C";s:3:"170";s:2:"WX";s:3:"556";s:1:"N";s:12:"quotedblleft";s:1:"B";a:4:{i:0;s:3:"166";i:1;s:3:"436";i:2;s:3:"514";i:3;s:3:"666";}}i:171;a:4:{s:1:"C";s:3:"171";s:2:"WX";s:3:"500";s:1:"N";s:13:"guillemotleft";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:2:"37";i:2;s:3:"445";i:3;s:3:"403";}}s:13:"guillemotleft";a:4:{s:1:"C";s:3:"171";s:2:"WX";s:3:"500";s:1:"N";s:13:"guillemotleft";s:1:"B";a:4:{i:0;s:2:"53";i:1;s:2:"37";i:2;s:3:"445";i:3;s:3:"403";}}i:172;a:4:{s:1:"C";s:3:"172";s:2:"WX";s:3:"333";s:1:"N";s:13:"guilsinglleft";s:1:"B";a:4:{i:0;s:2:"51";i:1;s:2:"37";i:2;s:3:"281";i:3;s:3:"403";}}s:13:"guilsinglleft";a:4:{s:1:"C";s:3:"172";s:2:"WX";s:3:"333";s:1:"N";s:13:"guilsinglleft";s:1:"B";a:4:{i:0;s:2:"51";i:1;s:2:"37";i:2;s:3:"281";i:3;s:3:"403";}}i:173;a:4:{s:1:"C";s:3:"173";s:2:"WX";s:3:"333";s:1:"N";s:14:"guilsinglright";s:1:"B";a:4:{i:0;s:2:"52";i:1;s:2:"37";i:2;s:3:"282";i:3;s:3:"403";}}s:14:"guilsinglright";a:4:{s:1:"C";s:3:"173";s:2:"WX";s:3:"333";s:1:"N";s:14:"guilsinglright";s:1:"B";a:4:{i:0;s:2:"52";i:1;s:2:"37";i:2;s:3:"282";i:3;s:3:"403";}}i:174;a:4:{s:1:"C";s:3:"174";s:2:"WX";s:3:"500";s:1:"N";s:2:"fi";s:1:"B";a:4:{i:0;s:4:"-141";i:1;s:4:"-207";i:2;s:3:"481";i:3;s:3:"681";}}s:2:"fi";a:4:{s:1:"C";s:3:"174";s:2:"WX";s:3:"500";s:1:"N";s:2:"fi";s:1:"B";a:4:{i:0;s:4:"-141";i:1;s:4:"-207";i:2;s:3:"481";i:3;s:3:"681";}}i:175;a:4:{s:1:"C";s:3:"175";s:2:"WX";s:3:"500";s:1:"N";s:2:"fl";s:1:"B";a:4:{i:0;s:4:"-141";i:1;s:4:"-204";i:2;s:3:"518";i:3;s:3:"682";}}s:2:"fl";a:4:{s:1:"C";s:3:"175";s:2:"WX";s:3:"500";s:1:"N";s:2:"fl";s:1:"B";a:4:{i:0;s:4:"-141";i:1;s:4:"-204";i:2;s:3:"518";i:3;s:3:"682";}}i:177;a:4:{s:1:"C";s:3:"177";s:2:"WX";s:3:"500";s:1:"N";s:6:"endash";s:1:"B";a:4:{i:0;s:2:"-6";i:1;s:3:"197";i:2;s:3:"505";i:3;s:3:"243";}}s:6:"endash";a:4:{s:1:"C";s:3:"177";s:2:"WX";s:3:"500";s:1:"N";s:6:"endash";s:1:"B";a:4:{i:0;s:2:"-6";i:1;s:3:"197";i:2;s:3:"505";i:3;s:3:"243";}}i:178;a:4:{s:1:"C";s:3:"178";s:2:"WX";s:3:"500";s:1:"N";s:6:"dagger";s:1:"B";a:4:{i:0;s:3:"101";i:1;s:4:"-159";i:2;s:3:"488";i:3;s:3:"666";}}s:6:"dagger";a:4:{s:1:"C";s:3:"178";s:2:"WX";s:3:"500";s:1:"N";s:6:"dagger";s:1:"B";a:4:{i:0;s:3:"101";i:1;s:4:"-159";i:2;s:3:"488";i:3;s:3:"666";}}i:179;a:4:{s:1:"C";s:3:"179";s:2:"WX";s:3:"500";s:1:"N";s:9:"daggerdbl";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:4:"-143";i:2;s:3:"491";i:3;s:3:"666";}}s:9:"daggerdbl";a:4:{s:1:"C";s:3:"179";s:2:"WX";s:3:"500";s:1:"N";s:9:"daggerdbl";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:4:"-143";i:2;s:3:"491";i:3;s:3:"666";}}i:180;a:4:{s:1:"C";s:3:"180";s:2:"WX";s:3:"250";s:1:"N";s:14:"periodcentered";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:3:"199";i:2;s:3:"181";i:3;s:3:"310";}}s:14:"periodcentered";a:4:{s:1:"C";s:3:"180";s:2:"WX";s:3:"250";s:1:"N";s:14:"periodcentered";s:1:"B";a:4:{i:0;s:2:"70";i:1;s:3:"199";i:2;s:3:"181";i:3;s:3:"310";}}i:182;a:4:{s:1:"C";s:3:"182";s:2:"WX";s:3:"523";s:1:"N";s:9:"paragraph";s:1:"B";a:4:{i:0;s:2:"55";i:1;s:4:"-123";i:2;s:3:"616";i:3;s:3:"653";}}s:9:"paragraph";a:4:{s:1:"C";s:3:"182";s:2:"WX";s:3:"523";s:1:"N";s:9:"paragraph";s:1:"B";a:4:{i:0;s:2:"55";i:1;s:4:"-123";i:2;s:3:"616";i:3;s:3:"653";}}i:183;a:4:{s:1:"C";s:3:"183";s:2:"WX";s:3:"350";s:1:"N";s:6:"bullet";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"191";i:2;s:3:"310";i:3;s:3:"461";}}s:6:"bullet";a:4:{s:1:"C";s:3:"183";s:2:"WX";s:3:"350";s:1:"N";s:6:"bullet";s:1:"B";a:4:{i:0;s:2:"40";i:1;s:3:"191";i:2;s:3:"310";i:3;s:3:"461";}}i:184;a:4:{s:1:"C";s:3:"184";s:2:"WX";s:3:"333";s:1:"N";s:14:"quotesinglbase";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:4:"-129";i:2;s:3:"183";i:3;s:3:"101";}}s:14:"quotesinglbase";a:4:{s:1:"C";s:3:"184";s:2:"WX";s:3:"333";s:1:"N";s:14:"quotesinglbase";s:1:"B";a:4:{i:0;s:2:"44";i:1;s:4:"-129";i:2;s:3:"183";i:3;s:3:"101";}}i:185;a:4:{s:1:"C";s:3:"185";s:2:"WX";s:3:"556";s:1:"N";s:12:"quotedblbase";s:1:"B";a:4:{i:0;s:2:"57";i:1;s:4:"-129";i:2;s:3:"405";i:3;s:3:"101";}}s:12:"quotedblbase";a:4:{s:1:"C";s:3:"185";s:2:"WX";s:3:"556";s:1:"N";s:12:"quotedblbase";s:1:"B";a:4:{i:0;s:2:"57";i:1;s:4:"-129";i:2;s:3:"405";i:3;s:3:"101";}}i:186;a:4:{s:1:"C";s:3:"186";s:2:"WX";s:3:"556";s:1:"N";s:13:"quotedblright";s:1:"B";a:4:{i:0;s:3:"151";i:1;s:3:"436";i:2;s:3:"499";i:3;s:3:"666";}}s:13:"quotedblright";a:4:{s:1:"C";s:3:"186";s:2:"WX";s:3:"556";s:1:"N";s:13:"quotedblright";s:1:"B";a:4:{i:0;s:3:"151";i:1;s:3:"436";i:2;s:3:"499";i:3;s:3:"666";}}i:187;a:4:{s:1:"C";s:3:"187";s:2:"WX";s:3:"500";s:1:"N";s:14:"guillemotright";s:1:"B";a:4:{i:0;s:2:"55";i:1;s:2:"37";i:2;s:3:"447";i:3;s:3:"403";}}s:14:"guillemotright";a:4:{s:1:"C";s:3:"187";s:2:"WX";s:3:"500";s:1:"N";s:14:"guillemotright";s:1:"B";a:4:{i:0;s:2:"55";i:1;s:2:"37";i:2;s:3:"447";i:3;s:3:"403";}}i:188;a:4:{s:1:"C";s:3:"188";s:2:"WX";s:3:"889";s:1:"N";s:8:"ellipsis";s:1:"B";a:4:{i:0;s:2:"57";i:1;s:3:"-11";i:2;s:3:"762";i:3;s:3:"100";}}s:8:"ellipsis";a:4:{s:1:"C";s:3:"188";s:2:"WX";s:3:"889";s:1:"N";s:8:"ellipsis";s:1:"B";a:4:{i:0;s:2:"57";i:1;s:3:"-11";i:2;s:3:"762";i:3;s:3:"100";}}i:189;a:4:{s:1:"C";s:3:"189";s:2:"WX";s:4:"1000";s:1:"N";s:11:"perthousand";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-19";i:2;s:4:"1010";i:3;s:3:"706";}}s:11:"perthousand";a:4:{s:1:"C";s:3:"189";s:2:"WX";s:4:"1000";s:1:"N";s:11:"perthousand";s:1:"B";a:4:{i:0;s:2:"25";i:1;s:3:"-19";i:2;s:4:"1010";i:3;s:3:"706";}}i:191;a:4:{s:1:"C";s:3:"191";s:2:"WX";s:3:"500";s:1:"N";s:12:"questiondown";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:4:"-205";i:2;s:3:"368";i:3;s:3:"471";}}s:12:"questiondown";a:4:{s:1:"C";s:3:"191";s:2:"WX";s:3:"500";s:1:"N";s:12:"questiondown";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:4:"-205";i:2;s:3:"368";i:3;s:3:"471";}}i:193;a:4:{s:1:"C";s:3:"193";s:2:"WX";s:3:"333";s:1:"N";s:5:"grave";s:1:"B";a:4:{i:0;s:3:"121";i:1;s:3:"492";i:2;s:3:"311";i:3;s:3:"664";}}s:5:"grave";a:4:{s:1:"C";s:3:"193";s:2:"WX";s:3:"333";s:1:"N";s:5:"grave";s:1:"B";a:4:{i:0;s:3:"121";i:1;s:3:"492";i:2;s:3:"311";i:3;s:3:"664";}}i:194;a:4:{s:1:"C";s:3:"194";s:2:"WX";s:3:"333";s:1:"N";s:5:"acute";s:1:"B";a:4:{i:0;s:3:"180";i:1;s:3:"494";i:2;s:3:"403";i:3;s:3:"664";}}s:5:"acute";a:4:{s:1:"C";s:3:"194";s:2:"WX";s:3:"333";s:1:"N";s:5:"acute";s:1:"B";a:4:{i:0;s:3:"180";i:1;s:3:"494";i:2;s:3:"403";i:3;s:3:"664";}}i:195;a:4:{s:1:"C";s:3:"195";s:2:"WX";s:3:"333";s:1:"N";s:10:"circumflex";s:1:"B";a:4:{i:0;s:2:"91";i:1;s:3:"492";i:2;s:3:"385";i:3;s:3:"661";}}s:10:"circumflex";a:4:{s:1:"C";s:3:"195";s:2:"WX";s:3:"333";s:1:"N";s:10:"circumflex";s:1:"B";a:4:{i:0;s:2:"91";i:1;s:3:"492";i:2;s:3:"385";i:3;s:3:"661";}}i:196;a:4:{s:1:"C";s:3:"196";s:2:"WX";s:3:"333";s:1:"N";s:5:"tilde";s:1:"B";a:4:{i:0;s:3:"100";i:1;s:3:"517";i:2;s:3:"427";i:3;s:3:"624";}}s:5:"tilde";a:4:{s:1:"C";s:3:"196";s:2:"WX";s:3:"333";s:1:"N";s:5:"tilde";s:1:"B";a:4:{i:0;s:3:"100";i:1;s:3:"517";i:2;s:3:"427";i:3;s:3:"624";}}i:197;a:4:{s:1:"C";s:3:"197";s:2:"WX";s:3:"333";s:1:"N";s:6:"macron";s:1:"B";a:4:{i:0;s:2:"99";i:1;s:3:"532";i:2;s:3:"411";i:3;s:3:"583";}}s:6:"macron";a:4:{s:1:"C";s:3:"197";s:2:"WX";s:3:"333";s:1:"N";s:6:"macron";s:1:"B";a:4:{i:0;s:2:"99";i:1;s:3:"532";i:2;s:3:"411";i:3;s:3:"583";}}i:198;a:4:{s:1:"C";s:3:"198";s:2:"WX";s:3:"333";s:1:"N";s:5:"breve";s:1:"B";a:4:{i:0;s:3:"117";i:1;s:3:"492";i:2;s:3:"418";i:3;s:3:"650";}}s:5:"breve";a:4:{s:1:"C";s:3:"198";s:2:"WX";s:3:"333";s:1:"N";s:5:"breve";s:1:"B";a:4:{i:0;s:3:"117";i:1;s:3:"492";i:2;s:3:"418";i:3;s:3:"650";}}i:199;a:4:{s:1:"C";s:3:"199";s:2:"WX";s:3:"333";s:1:"N";s:9:"dotaccent";s:1:"B";a:4:{i:0;s:3:"207";i:1;s:3:"548";i:2;s:3:"305";i:3;s:3:"646";}}s:9:"dotaccent";a:4:{s:1:"C";s:3:"199";s:2:"WX";s:3:"333";s:1:"N";s:9:"dotaccent";s:1:"B";a:4:{i:0;s:3:"207";i:1;s:3:"548";i:2;s:3:"305";i:3;s:3:"646";}}i:200;a:4:{s:1:"C";s:3:"200";s:2:"WX";s:3:"333";s:1:"N";s:8:"dieresis";s:1:"B";a:4:{i:0;s:3:"107";i:1;s:3:"548";i:2;s:3:"405";i:3;s:3:"646";}}s:8:"dieresis";a:4:{s:1:"C";s:3:"200";s:2:"WX";s:3:"333";s:1:"N";s:8:"dieresis";s:1:"B";a:4:{i:0;s:3:"107";i:1;s:3:"548";i:2;s:3:"405";i:3;s:3:"646";}}i:202;a:4:{s:1:"C";s:3:"202";s:2:"WX";s:3:"333";s:1:"N";s:4:"ring";s:1:"B";a:4:{i:0;s:3:"155";i:1;s:3:"492";i:2;s:3:"355";i:3;s:3:"691";}}s:4:"ring";a:4:{s:1:"C";s:3:"202";s:2:"WX";s:3:"333";s:1:"N";s:4:"ring";s:1:"B";a:4:{i:0;s:3:"155";i:1;s:3:"492";i:2;s:3:"355";i:3;s:3:"691";}}i:203;a:4:{s:1:"C";s:3:"203";s:2:"WX";s:3:"333";s:1:"N";s:7:"cedilla";s:1:"B";a:4:{i:0;s:3:"-30";i:1;s:4:"-217";i:2;s:3:"182";i:3;s:1:"0";}}s:7:"cedilla";a:4:{s:1:"C";s:3:"203";s:2:"WX";s:3:"333";s:1:"N";s:7:"cedilla";s:1:"B";a:4:{i:0;s:3:"-30";i:1;s:4:"-217";i:2;s:3:"182";i:3;s:1:"0";}}i:205;a:4:{s:1:"C";s:3:"205";s:2:"WX";s:3:"333";s:1:"N";s:12:"hungarumlaut";s:1:"B";a:4:{i:0;s:2:"93";i:1;s:3:"494";i:2;s:3:"486";i:3;s:3:"664";}}s:12:"hungarumlaut";a:4:{s:1:"C";s:3:"205";s:2:"WX";s:3:"333";s:1:"N";s:12:"hungarumlaut";s:1:"B";a:4:{i:0;s:2:"93";i:1;s:3:"494";i:2;s:3:"486";i:3;s:3:"664";}}i:206;a:4:{s:1:"C";s:3:"206";s:2:"WX";s:3:"333";s:1:"N";s:6:"ogonek";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:4:"-169";i:2;s:3:"203";i:3;s:2:"40";}}s:6:"ogonek";a:4:{s:1:"C";s:3:"206";s:2:"WX";s:3:"333";s:1:"N";s:6:"ogonek";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:4:"-169";i:2;s:3:"203";i:3;s:2:"40";}}i:207;a:4:{s:1:"C";s:3:"207";s:2:"WX";s:3:"333";s:1:"N";s:5:"caron";s:1:"B";a:4:{i:0;s:3:"121";i:1;s:3:"492";i:2;s:3:"426";i:3;s:3:"661";}}s:5:"caron";a:4:{s:1:"C";s:3:"207";s:2:"WX";s:3:"333";s:1:"N";s:5:"caron";s:1:"B";a:4:{i:0;s:3:"121";i:1;s:3:"492";i:2;s:3:"426";i:3;s:3:"661";}}i:208;a:4:{s:1:"C";s:3:"208";s:2:"WX";s:3:"889";s:1:"N";s:6:"emdash";s:1:"B";a:4:{i:0;s:2:"-6";i:1;s:3:"197";i:2;s:3:"894";i:3;s:3:"243";}}s:6:"emdash";a:4:{s:1:"C";s:3:"208";s:2:"WX";s:3:"889";s:1:"N";s:6:"emdash";s:1:"B";a:4:{i:0;s:2:"-6";i:1;s:3:"197";i:2;s:3:"894";i:3;s:3:"243";}}i:225;a:4:{s:1:"C";s:3:"225";s:2:"WX";s:3:"889";s:1:"N";s:2:"AE";s:1:"B";a:4:{i:0;s:3:"-27";i:1;s:1:"0";i:2;s:3:"911";i:3;s:3:"653";}}s:2:"AE";a:4:{s:1:"C";s:3:"225";s:2:"WX";s:3:"889";s:1:"N";s:2:"AE";s:1:"B";a:4:{i:0;s:3:"-27";i:1;s:1:"0";i:2;s:3:"911";i:3;s:3:"653";}}i:227;a:4:{s:1:"C";s:3:"227";s:2:"WX";s:3:"276";s:1:"N";s:11:"ordfeminine";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"406";i:2;s:3:"352";i:3;s:3:"676";}}s:11:"ordfeminine";a:4:{s:1:"C";s:3:"227";s:2:"WX";s:3:"276";s:1:"N";s:11:"ordfeminine";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"406";i:2;s:3:"352";i:3;s:3:"676";}}i:232;a:4:{s:1:"C";s:3:"232";s:2:"WX";s:3:"556";s:1:"N";s:6:"Lslash";s:1:"B";a:4:{i:0;s:2:"-8";i:1;s:1:"0";i:2;s:3:"559";i:3;s:3:"653";}}s:6:"Lslash";a:4:{s:1:"C";s:3:"232";s:2:"WX";s:3:"556";s:1:"N";s:6:"Lslash";s:1:"B";a:4:{i:0;s:2:"-8";i:1;s:1:"0";i:2;s:3:"559";i:3;s:3:"653";}}i:233;a:4:{s:1:"C";s:3:"233";s:2:"WX";s:3:"722";s:1:"N";s:6:"Oslash";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:4:"-105";i:2;s:3:"699";i:3;s:3:"722";}}s:6:"Oslash";a:4:{s:1:"C";s:3:"233";s:2:"WX";s:3:"722";s:1:"N";s:6:"Oslash";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:4:"-105";i:2;s:3:"699";i:3;s:3:"722";}}i:234;a:4:{s:1:"C";s:3:"234";s:2:"WX";s:3:"944";s:1:"N";s:2:"OE";s:1:"B";a:4:{i:0;s:2:"49";i:1;s:2:"-8";i:2;s:3:"964";i:3;s:3:"666";}}s:2:"OE";a:4:{s:1:"C";s:3:"234";s:2:"WX";s:3:"944";s:1:"N";s:2:"OE";s:1:"B";a:4:{i:0;s:2:"49";i:1;s:2:"-8";i:2;s:3:"964";i:3;s:3:"666";}}i:235;a:4:{s:1:"C";s:3:"235";s:2:"WX";s:3:"310";s:1:"N";s:12:"ordmasculine";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:3:"406";i:2;s:3:"362";i:3;s:3:"676";}}s:12:"ordmasculine";a:4:{s:1:"C";s:3:"235";s:2:"WX";s:3:"310";s:1:"N";s:12:"ordmasculine";s:1:"B";a:4:{i:0;s:2:"67";i:1;s:3:"406";i:2;s:3:"362";i:3;s:3:"676";}}i:241;a:4:{s:1:"C";s:3:"241";s:2:"WX";s:3:"667";s:1:"N";s:2:"ae";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:3:"-11";i:2;s:3:"640";i:3;s:3:"441";}}s:2:"ae";a:4:{s:1:"C";s:3:"241";s:2:"WX";s:3:"667";s:1:"N";s:2:"ae";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:3:"-11";i:2;s:3:"640";i:3;s:3:"441";}}i:245;a:4:{s:1:"C";s:3:"245";s:2:"WX";s:3:"278";s:1:"N";s:8:"dotlessi";s:1:"B";a:4:{i:0;s:2:"49";i:1;s:3:"-11";i:2;s:3:"235";i:3;s:3:"441";}}s:8:"dotlessi";a:4:{s:1:"C";s:3:"245";s:2:"WX";s:3:"278";s:1:"N";s:8:"dotlessi";s:1:"B";a:4:{i:0;s:2:"49";i:1;s:3:"-11";i:2;s:3:"235";i:3;s:3:"441";}}i:248;a:4:{s:1:"C";s:3:"248";s:2:"WX";s:3:"278";s:1:"N";s:6:"lslash";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:3:"-11";i:2;s:3:"312";i:3;s:3:"683";}}s:6:"lslash";a:4:{s:1:"C";s:3:"248";s:2:"WX";s:3:"278";s:1:"N";s:6:"lslash";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:3:"-11";i:2;s:3:"312";i:3;s:3:"683";}}i:249;a:4:{s:1:"C";s:3:"249";s:2:"WX";s:3:"500";s:1:"N";s:6:"oslash";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:4:"-135";i:2;s:3:"469";i:3;s:3:"554";}}s:6:"oslash";a:4:{s:1:"C";s:3:"249";s:2:"WX";s:3:"500";s:1:"N";s:6:"oslash";s:1:"B";a:4:{i:0;s:2:"28";i:1;s:4:"-135";i:2;s:3:"469";i:3;s:3:"554";}}i:250;a:4:{s:1:"C";s:3:"250";s:2:"WX";s:3:"667";s:1:"N";s:2:"oe";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:3:"-12";i:2;s:3:"646";i:3;s:3:"441";}}s:2:"oe";a:4:{s:1:"C";s:3:"250";s:2:"WX";s:3:"667";s:1:"N";s:2:"oe";s:1:"B";a:4:{i:0;s:2:"20";i:1;s:3:"-12";i:2;s:3:"646";i:3;s:3:"441";}}i:251;a:4:{s:1:"C";s:3:"251";s:2:"WX";s:3:"500";s:1:"N";s:10:"germandbls";s:1:"B";a:4:{i:0;s:4:"-168";i:1;s:4:"-207";i:2;s:3:"493";i:3;s:3:"679";}}s:10:"germandbls";a:4:{s:1:"C";s:3:"251";s:2:"WX";s:3:"500";s:1:"N";s:10:"germandbls";s:1:"B";a:4:{i:0;s:4:"-168";i:1;s:4:"-207";i:2;s:3:"493";i:3;s:3:"679";}}s:9:"Idieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"333";s:1:"N";s:9:"Idieresis";s:1:"B";a:4:{i:0;s:2:"-8";i:1;s:1:"0";i:2;s:3:"435";i:3;s:3:"818";}}s:6:"eacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:6:"eacute";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:3:"-11";i:2;s:3:"459";i:3;s:3:"664";}}s:6:"abreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"abreve";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:3:"-11";i:2;s:3:"502";i:3;s:3:"650";}}s:13:"uhungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:13:"uhungarumlaut";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-11";i:2;s:3:"580";i:3;s:3:"664";}}s:6:"ecaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:6:"ecaron";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:3:"-11";i:2;s:3:"482";i:3;s:3:"661";}}s:9:"Ydieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:9:"Ydieresis";s:1:"B";a:4:{i:0;s:2:"78";i:1;s:1:"0";i:2;s:3:"633";i:3;s:3:"818";}}s:6:"divide";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"675";s:1:"N";s:6:"divide";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:3:"-11";i:2;s:3:"590";i:3;s:3:"517";}}s:6:"Yacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"Yacute";s:1:"B";a:4:{i:0;s:2:"78";i:1;s:1:"0";i:2;s:3:"633";i:3;s:3:"876";}}s:11:"Acircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:11:"Acircumflex";s:1:"B";a:4:{i:0;s:3:"-51";i:1;s:1:"0";i:2;s:3:"564";i:3;s:3:"873";}}s:6:"aacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"aacute";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:3:"-11";i:2;s:3:"487";i:3;s:3:"664";}}s:11:"Ucircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:11:"Ucircumflex";s:1:"B";a:4:{i:0;s:3:"102";i:1;s:3:"-18";i:2;s:3:"765";i:3;s:3:"873";}}s:6:"yacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:6:"yacute";s:1:"B";a:4:{i:0;s:3:"-24";i:1;s:4:"-206";i:2;s:3:"459";i:3;s:3:"664";}}s:12:"scommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:12:"scommaaccent";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:4:"-217";i:2;s:3:"366";i:3;s:3:"442";}}s:11:"ecircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:11:"ecircumflex";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:3:"-11";i:2;s:3:"441";i:3;s:3:"661";}}s:5:"Uring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:5:"Uring";s:1:"B";a:4:{i:0;s:3:"102";i:1;s:3:"-18";i:2;s:3:"765";i:3;s:3:"883";}}s:9:"Udieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:9:"Udieresis";s:1:"B";a:4:{i:0;s:3:"102";i:1;s:3:"-18";i:2;s:3:"765";i:3;s:3:"818";}}s:7:"aogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:7:"aogonek";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:4:"-169";i:2;s:3:"476";i:3;s:3:"441";}}s:6:"Uacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Uacute";s:1:"B";a:4:{i:0;s:3:"102";i:1;s:3:"-18";i:2;s:3:"765";i:3;s:3:"876";}}s:7:"uogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:7:"uogonek";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:4:"-169";i:2;s:3:"477";i:3;s:3:"441";}}s:9:"Edieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:9:"Edieresis";s:1:"B";a:4:{i:0;s:2:"-1";i:1;s:1:"0";i:2;s:3:"634";i:3;s:3:"818";}}s:6:"Dcroat";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Dcroat";s:1:"B";a:4:{i:0;s:2:"-8";i:1;s:1:"0";i:2;s:3:"700";i:3;s:3:"653";}}s:11:"commaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"250";s:1:"N";s:11:"commaaccent";s:1:"B";a:4:{i:0;s:1:"8";i:1;s:4:"-217";i:2;s:3:"133";i:3;s:3:"-50";}}s:9:"copyright";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"760";s:1:"N";s:9:"copyright";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:3:"-18";i:2;s:3:"719";i:3;s:3:"666";}}s:7:"Emacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:7:"Emacron";s:1:"B";a:4:{i:0;s:2:"-1";i:1;s:1:"0";i:2;s:3:"634";i:3;s:3:"795";}}s:6:"ccaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:6:"ccaron";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-11";i:2;s:3:"482";i:3;s:3:"661";}}s:5:"aring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:5:"aring";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:3:"-11";i:2;s:3:"476";i:3;s:3:"691";}}s:12:"Ncommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:12:"Ncommaaccent";s:1:"B";a:4:{i:0;s:3:"-20";i:1;s:4:"-187";i:2;s:3:"727";i:3;s:3:"653";}}s:6:"lacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:6:"lacute";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:3:"-11";i:2;s:3:"395";i:3;s:3:"876";}}s:6:"agrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"agrave";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:3:"-11";i:2;s:3:"476";i:3;s:3:"664";}}s:12:"Tcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:12:"Tcommaaccent";s:1:"B";a:4:{i:0;s:2:"59";i:1;s:4:"-217";i:2;s:3:"633";i:3;s:3:"653";}}s:6:"Cacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Cacute";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:3:"-18";i:2;s:3:"690";i:3;s:3:"876";}}s:6:"atilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"atilde";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:3:"-11";i:2;s:3:"511";i:3;s:3:"624";}}s:10:"Edotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:10:"Edotaccent";s:1:"B";a:4:{i:0;s:2:"-1";i:1;s:1:"0";i:2;s:3:"634";i:3;s:3:"818";}}s:6:"scaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:6:"scaron";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-13";i:2;s:3:"454";i:3;s:3:"661";}}s:8:"scedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:8:"scedilla";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:4:"-217";i:2;s:3:"366";i:3;s:3:"442";}}s:6:"iacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:6:"iacute";s:1:"B";a:4:{i:0;s:2:"49";i:1;s:3:"-11";i:2;s:3:"355";i:3;s:3:"664";}}s:7:"lozenge";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"471";s:1:"N";s:7:"lozenge";s:1:"B";a:4:{i:0;s:2:"13";i:1;s:1:"0";i:2;s:3:"459";i:3;s:3:"724";}}s:6:"Rcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"Rcaron";s:1:"B";a:4:{i:0;s:3:"-13";i:1;s:1:"0";i:2;s:3:"588";i:3;s:3:"873";}}s:12:"Gcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:12:"Gcommaaccent";s:1:"B";a:4:{i:0;s:2:"52";i:1;s:4:"-217";i:2;s:3:"722";i:3;s:3:"666";}}s:11:"ucircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:11:"ucircumflex";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-11";i:2;s:3:"475";i:3;s:3:"661";}}s:11:"acircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:11:"acircumflex";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:3:"-11";i:2;s:3:"476";i:3;s:3:"661";}}s:7:"Amacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:7:"Amacron";s:1:"B";a:4:{i:0;s:3:"-51";i:1;s:1:"0";i:2;s:3:"564";i:3;s:3:"795";}}s:6:"rcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:6:"rcaron";s:1:"B";a:4:{i:0;s:2:"45";i:1;s:1:"0";i:2;s:3:"434";i:3;s:3:"661";}}s:8:"ccedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:8:"ccedilla";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:4:"-217";i:2;s:3:"425";i:3;s:3:"441";}}s:10:"Zdotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:10:"Zdotaccent";s:1:"B";a:4:{i:0;s:2:"-6";i:1;s:1:"0";i:2;s:3:"606";i:3;s:3:"818";}}s:5:"Thorn";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:5:"Thorn";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:3:"569";i:3;s:3:"653";}}s:7:"Omacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:7:"Omacron";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:3:"-18";i:2;s:3:"699";i:3;s:3:"795";}}s:6:"Racute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"Racute";s:1:"B";a:4:{i:0;s:3:"-13";i:1;s:1:"0";i:2;s:3:"588";i:3;s:3:"876";}}s:6:"Sacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"Sacute";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:3:"-18";i:2;s:3:"508";i:3;s:3:"876";}}s:6:"dcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"544";s:1:"N";s:6:"dcaron";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:3:"-13";i:2;s:3:"658";i:3;s:3:"683";}}s:7:"Umacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:7:"Umacron";s:1:"B";a:4:{i:0;s:3:"102";i:1;s:3:"-18";i:2;s:3:"765";i:3;s:3:"795";}}s:5:"uring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:5:"uring";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-11";i:2;s:3:"475";i:3;s:3:"691";}}s:13:"threesuperior";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"300";s:1:"N";s:13:"threesuperior";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:3:"268";i:2;s:3:"339";i:3;s:3:"676";}}s:6:"Ograve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Ograve";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:3:"-18";i:2;s:3:"699";i:3;s:3:"876";}}s:6:"Agrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"Agrave";s:1:"B";a:4:{i:0;s:3:"-51";i:1;s:1:"0";i:2;s:3:"564";i:3;s:3:"876";}}s:6:"Abreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"Abreve";s:1:"B";a:4:{i:0;s:3:"-51";i:1;s:1:"0";i:2;s:3:"564";i:3;s:3:"862";}}s:8:"multiply";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"675";s:1:"N";s:8:"multiply";s:1:"B";a:4:{i:0;s:2:"93";i:1;s:1:"8";i:2;s:3:"582";i:3;s:3:"497";}}s:6:"uacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"uacute";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-11";i:2;s:3:"477";i:3;s:3:"664";}}s:6:"Tcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"Tcaron";s:1:"B";a:4:{i:0;s:2:"59";i:1;s:1:"0";i:2;s:3:"633";i:3;s:3:"873";}}s:11:"partialdiff";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"476";s:1:"N";s:11:"partialdiff";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:3:"-38";i:2;s:3:"459";i:3;s:3:"710";}}s:9:"ydieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:9:"ydieresis";s:1:"B";a:4:{i:0;s:3:"-24";i:1;s:4:"-206";i:2;s:3:"441";i:3;s:3:"606";}}s:6:"Nacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Nacute";s:1:"B";a:4:{i:0;s:3:"-20";i:1;s:3:"-15";i:2;s:3:"727";i:3;s:3:"876";}}s:11:"icircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:11:"icircumflex";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:3:"-11";i:2;s:3:"327";i:3;s:3:"661";}}s:11:"Ecircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:11:"Ecircumflex";s:1:"B";a:4:{i:0;s:2:"-1";i:1;s:1:"0";i:2;s:3:"634";i:3;s:3:"873";}}s:9:"adieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:9:"adieresis";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:3:"-11";i:2;s:3:"489";i:3;s:3:"606";}}s:9:"edieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:9:"edieresis";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:3:"-11";i:2;s:3:"451";i:3;s:3:"606";}}s:6:"cacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:6:"cacute";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"-11";i:2;s:3:"459";i:3;s:3:"664";}}s:6:"nacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"nacute";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:2:"-9";i:2;s:3:"477";i:3;s:3:"664";}}s:7:"umacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:7:"umacron";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-11";i:2;s:3:"485";i:3;s:3:"583";}}s:6:"Ncaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Ncaron";s:1:"B";a:4:{i:0;s:3:"-20";i:1;s:3:"-15";i:2;s:3:"727";i:3;s:3:"873";}}s:6:"Iacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"333";s:1:"N";s:6:"Iacute";s:1:"B";a:4:{i:0;s:2:"-8";i:1;s:1:"0";i:2;s:3:"433";i:3;s:3:"876";}}s:9:"plusminus";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"675";s:1:"N";s:9:"plusminus";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:1:"0";i:2;s:3:"590";i:3;s:3:"506";}}s:9:"brokenbar";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"275";s:1:"N";s:9:"brokenbar";s:1:"B";a:4:{i:0;s:3:"105";i:1;s:4:"-142";i:2;s:3:"171";i:3;s:3:"708";}}s:10:"registered";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"760";s:1:"N";s:10:"registered";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:3:"-18";i:2;s:3:"719";i:3;s:3:"666";}}s:6:"Gbreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Gbreve";s:1:"B";a:4:{i:0;s:2:"52";i:1;s:3:"-18";i:2;s:3:"722";i:3;s:3:"862";}}s:10:"Idotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"333";s:1:"N";s:10:"Idotaccent";s:1:"B";a:4:{i:0;s:2:"-8";i:1;s:1:"0";i:2;s:3:"384";i:3;s:3:"818";}}s:9:"summation";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"600";s:1:"N";s:9:"summation";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:3:"-10";i:2;s:3:"585";i:3;s:3:"706";}}s:6:"Egrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"Egrave";s:1:"B";a:4:{i:0;s:2:"-1";i:1;s:1:"0";i:2;s:3:"634";i:3;s:3:"876";}}s:6:"racute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:6:"racute";s:1:"B";a:4:{i:0;s:2:"45";i:1;s:1:"0";i:2;s:3:"431";i:3;s:3:"664";}}s:7:"omacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:7:"omacron";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:3:"-11";i:2;s:3:"495";i:3;s:3:"583";}}s:6:"Zacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"Zacute";s:1:"B";a:4:{i:0;s:2:"-6";i:1;s:1:"0";i:2;s:3:"606";i:3;s:3:"876";}}s:6:"Zcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"Zcaron";s:1:"B";a:4:{i:0;s:2:"-6";i:1;s:1:"0";i:2;s:3:"606";i:3;s:3:"873";}}s:12:"greaterequal";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"549";s:1:"N";s:12:"greaterequal";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"523";i:3;s:3:"658";}}s:3:"Eth";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:3:"Eth";s:1:"B";a:4:{i:0;s:2:"-8";i:1;s:1:"0";i:2;s:3:"700";i:3;s:3:"653";}}s:8:"Ccedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:8:"Ccedilla";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:4:"-217";i:2;s:3:"689";i:3;s:3:"666";}}s:12:"lcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:12:"lcommaaccent";s:1:"B";a:4:{i:0;s:2:"22";i:1;s:4:"-217";i:2;s:3:"279";i:3;s:3:"683";}}s:6:"tcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"300";s:1:"N";s:6:"tcaron";s:1:"B";a:4:{i:0;s:2:"37";i:1;s:3:"-11";i:2;s:3:"407";i:3;s:3:"681";}}s:7:"eogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:7:"eogonek";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:4:"-169";i:2;s:3:"412";i:3;s:3:"441";}}s:7:"Uogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:7:"Uogonek";s:1:"B";a:4:{i:0;s:3:"102";i:1;s:4:"-184";i:2;s:3:"765";i:3;s:3:"653";}}s:6:"Aacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"Aacute";s:1:"B";a:4:{i:0;s:3:"-51";i:1;s:1:"0";i:2;s:3:"564";i:3;s:3:"876";}}s:9:"Adieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:9:"Adieresis";s:1:"B";a:4:{i:0;s:3:"-51";i:1;s:1:"0";i:2;s:3:"564";i:3;s:3:"818";}}s:6:"egrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:6:"egrave";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:3:"-11";i:2;s:3:"412";i:3;s:3:"664";}}s:6:"zacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:6:"zacute";s:1:"B";a:4:{i:0;s:2:"-2";i:1;s:3:"-81";i:2;s:3:"431";i:3;s:3:"664";}}s:7:"iogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:7:"iogonek";s:1:"B";a:4:{i:0;s:2:"49";i:1;s:4:"-169";i:2;s:3:"264";i:3;s:3:"654";}}s:6:"Oacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Oacute";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:3:"-18";i:2;s:3:"699";i:3;s:3:"876";}}s:6:"oacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"oacute";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:3:"-11";i:2;s:3:"487";i:3;s:3:"664";}}s:7:"amacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:7:"amacron";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:3:"-11";i:2;s:3:"495";i:3;s:3:"583";}}s:6:"sacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:6:"sacute";s:1:"B";a:4:{i:0;s:2:"16";i:1;s:3:"-13";i:2;s:3:"431";i:3;s:3:"664";}}s:9:"idieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:9:"idieresis";s:1:"B";a:4:{i:0;s:2:"49";i:1;s:3:"-11";i:2;s:3:"352";i:3;s:3:"606";}}s:11:"Ocircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:11:"Ocircumflex";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:3:"-18";i:2;s:3:"699";i:3;s:3:"873";}}s:6:"Ugrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Ugrave";s:1:"B";a:4:{i:0;s:3:"102";i:1;s:3:"-18";i:2;s:3:"765";i:3;s:3:"876";}}s:5:"Delta";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"612";s:1:"N";s:5:"Delta";s:1:"B";a:4:{i:0;s:1:"6";i:1;s:1:"0";i:2;s:3:"608";i:3;s:3:"688";}}s:5:"thorn";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:5:"thorn";s:1:"B";a:4:{i:0;s:3:"-75";i:1;s:4:"-205";i:2;s:3:"469";i:3;s:3:"683";}}s:11:"twosuperior";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"300";s:1:"N";s:11:"twosuperior";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:3:"271";i:2;s:3:"324";i:3;s:3:"676";}}s:9:"Odieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:9:"Odieresis";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:3:"-18";i:2;s:3:"699";i:3;s:3:"818";}}s:2:"mu";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:2:"mu";s:1:"B";a:4:{i:0;s:3:"-30";i:1;s:4:"-209";i:2;s:3:"497";i:3;s:3:"428";}}s:6:"igrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:6:"igrave";s:1:"B";a:4:{i:0;s:2:"49";i:1;s:3:"-11";i:2;s:3:"284";i:3;s:3:"664";}}s:13:"ohungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:13:"ohungarumlaut";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:3:"-11";i:2;s:3:"590";i:3;s:3:"664";}}s:7:"Eogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:7:"Eogonek";s:1:"B";a:4:{i:0;s:2:"-1";i:1;s:4:"-169";i:2;s:3:"634";i:3;s:3:"653";}}s:6:"dcroat";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"dcroat";s:1:"B";a:4:{i:0;s:2:"15";i:1;s:3:"-13";i:2;s:3:"572";i:3;s:3:"683";}}s:13:"threequarters";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"750";s:1:"N";s:13:"threequarters";s:1:"B";a:4:{i:0;s:2:"23";i:1;s:3:"-10";i:2;s:3:"736";i:3;s:3:"676";}}s:8:"Scedilla";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:8:"Scedilla";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:4:"-217";i:2;s:3:"508";i:3;s:3:"667";}}s:6:"lcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"300";s:1:"N";s:6:"lcaron";s:1:"B";a:4:{i:0;s:2:"41";i:1;s:3:"-11";i:2;s:3:"407";i:3;s:3:"683";}}s:12:"Kcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:12:"Kcommaaccent";s:1:"B";a:4:{i:0;s:1:"7";i:1;s:4:"-217";i:2;s:3:"722";i:3;s:3:"653";}}s:6:"Lacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:6:"Lacute";s:1:"B";a:4:{i:0;s:2:"-8";i:1;s:1:"0";i:2;s:3:"559";i:3;s:3:"876";}}s:9:"trademark";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"980";s:1:"N";s:9:"trademark";s:1:"B";a:4:{i:0;s:2:"30";i:1;s:3:"247";i:2;s:3:"957";i:3;s:3:"653";}}s:10:"edotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:10:"edotaccent";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:3:"-11";i:2;s:3:"412";i:3;s:3:"606";}}s:6:"Igrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"333";s:1:"N";s:6:"Igrave";s:1:"B";a:4:{i:0;s:2:"-8";i:1;s:1:"0";i:2;s:3:"384";i:3;s:3:"876";}}s:7:"Imacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"333";s:1:"N";s:7:"Imacron";s:1:"B";a:4:{i:0;s:2:"-8";i:1;s:1:"0";i:2;s:3:"441";i:3;s:3:"795";}}s:6:"Lcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"Lcaron";s:1:"B";a:4:{i:0;s:2:"-8";i:1;s:1:"0";i:2;s:3:"586";i:3;s:3:"653";}}s:7:"onehalf";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"750";s:1:"N";s:7:"onehalf";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-10";i:2;s:3:"749";i:3;s:3:"676";}}s:9:"lessequal";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"549";s:1:"N";s:9:"lessequal";s:1:"B";a:4:{i:0;s:2:"26";i:1;s:1:"0";i:2;s:3:"523";i:3;s:3:"658";}}s:11:"ocircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:11:"ocircumflex";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:3:"-11";i:2;s:3:"468";i:3;s:3:"661";}}s:6:"ntilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"ntilde";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:2:"-9";i:2;s:3:"476";i:3;s:3:"624";}}s:13:"Uhungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:13:"Uhungarumlaut";s:1:"B";a:4:{i:0;s:3:"102";i:1;s:3:"-18";i:2;s:3:"765";i:3;s:3:"876";}}s:6:"Eacute";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"Eacute";s:1:"B";a:4:{i:0;s:2:"-1";i:1;s:1:"0";i:2;s:3:"634";i:3;s:3:"876";}}s:7:"emacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:7:"emacron";s:1:"B";a:4:{i:0;s:2:"31";i:1;s:3:"-11";i:2;s:3:"457";i:3;s:3:"583";}}s:6:"gbreve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"gbreve";s:1:"B";a:4:{i:0;s:1:"8";i:1;s:4:"-206";i:2;s:3:"487";i:3;s:3:"650";}}s:10:"onequarter";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"750";s:1:"N";s:10:"onequarter";s:1:"B";a:4:{i:0;s:2:"33";i:1;s:3:"-10";i:2;s:3:"736";i:3;s:3:"676";}}s:6:"Scaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"Scaron";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:3:"-18";i:2;s:3:"520";i:3;s:3:"873";}}s:12:"Scommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:12:"Scommaaccent";s:1:"B";a:4:{i:0;s:2:"17";i:1;s:4:"-217";i:2;s:3:"508";i:3;s:3:"667";}}s:13:"Ohungarumlaut";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:13:"Ohungarumlaut";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:3:"-18";i:2;s:3:"699";i:3;s:3:"876";}}s:6:"degree";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"400";s:1:"N";s:6:"degree";s:1:"B";a:4:{i:0;s:3:"101";i:1;s:3:"390";i:2;s:3:"387";i:3;s:3:"676";}}s:6:"ograve";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"ograve";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:3:"-11";i:2;s:3:"468";i:3;s:3:"664";}}s:6:"Ccaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Ccaron";s:1:"B";a:4:{i:0;s:2:"66";i:1;s:3:"-18";i:2;s:3:"689";i:3;s:3:"873";}}s:6:"ugrave";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"ugrave";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-11";i:2;s:3:"475";i:3;s:3:"664";}}s:7:"radical";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"453";s:1:"N";s:7:"radical";s:1:"B";a:4:{i:0;s:1:"2";i:1;s:3:"-60";i:2;s:3:"452";i:3;s:3:"768";}}s:6:"Dcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Dcaron";s:1:"B";a:4:{i:0;s:2:"-8";i:1;s:1:"0";i:2;s:3:"700";i:3;s:3:"873";}}s:12:"rcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:12:"rcommaaccent";s:1:"B";a:4:{i:0;s:2:"-3";i:1;s:4:"-217";i:2;s:3:"412";i:3;s:3:"441";}}s:6:"Ntilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"667";s:1:"N";s:6:"Ntilde";s:1:"B";a:4:{i:0;s:3:"-20";i:1;s:3:"-15";i:2;s:3:"727";i:3;s:3:"836";}}s:6:"otilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"otilde";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:3:"-11";i:2;s:3:"496";i:3;s:3:"624";}}s:12:"Rcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:12:"Rcommaaccent";s:1:"B";a:4:{i:0;s:3:"-13";i:1;s:4:"-187";i:2;s:3:"588";i:3;s:3:"653";}}s:12:"Lcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"556";s:1:"N";s:12:"Lcommaaccent";s:1:"B";a:4:{i:0;s:2:"-8";i:1;s:4:"-217";i:2;s:3:"559";i:3;s:3:"653";}}s:6:"Atilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"Atilde";s:1:"B";a:4:{i:0;s:3:"-51";i:1;s:1:"0";i:2;s:3:"566";i:3;s:3:"836";}}s:7:"Aogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:7:"Aogonek";s:1:"B";a:4:{i:0;s:3:"-51";i:1;s:4:"-169";i:2;s:3:"566";i:3;s:3:"668";}}s:5:"Aring";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:5:"Aring";s:1:"B";a:4:{i:0;s:3:"-51";i:1;s:1:"0";i:2;s:3:"564";i:3;s:3:"883";}}s:6:"Otilde";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"722";s:1:"N";s:6:"Otilde";s:1:"B";a:4:{i:0;s:2:"60";i:1;s:3:"-18";i:2;s:3:"699";i:3;s:3:"836";}}s:10:"zdotaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:10:"zdotaccent";s:1:"B";a:4:{i:0;s:2:"-2";i:1;s:3:"-81";i:2;s:3:"380";i:3;s:3:"606";}}s:6:"Ecaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"611";s:1:"N";s:6:"Ecaron";s:1:"B";a:4:{i:0;s:2:"-1";i:1;s:1:"0";i:2;s:3:"634";i:3;s:3:"873";}}s:7:"Iogonek";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"333";s:1:"N";s:7:"Iogonek";s:1:"B";a:4:{i:0;s:2:"-8";i:1;s:4:"-169";i:2;s:3:"384";i:3;s:3:"653";}}s:12:"kcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"444";s:1:"N";s:12:"kcommaaccent";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:4:"-187";i:2;s:3:"461";i:3;s:3:"683";}}s:5:"minus";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"675";s:1:"N";s:5:"minus";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:3:"220";i:2;s:3:"590";i:3;s:3:"286";}}s:11:"Icircumflex";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"333";s:1:"N";s:11:"Icircumflex";s:1:"B";a:4:{i:0;s:2:"-8";i:1;s:1:"0";i:2;s:3:"425";i:3;s:3:"873";}}s:6:"ncaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:6:"ncaron";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:2:"-9";i:2;s:3:"510";i:3;s:3:"661";}}s:12:"tcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:12:"tcommaaccent";s:1:"B";a:4:{i:0;s:1:"2";i:1;s:4:"-217";i:2;s:3:"296";i:3;s:3:"546";}}s:10:"logicalnot";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"675";s:1:"N";s:10:"logicalnot";s:1:"B";a:4:{i:0;s:2:"86";i:1;s:3:"108";i:2;s:3:"590";i:3;s:3:"386";}}s:9:"odieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:9:"odieresis";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:3:"-11";i:2;s:3:"489";i:3;s:3:"606";}}s:9:"udieresis";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:9:"udieresis";s:1:"B";a:4:{i:0;s:2:"42";i:1;s:3:"-11";i:2;s:3:"479";i:3;s:3:"606";}}s:8:"notequal";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"549";s:1:"N";s:8:"notequal";s:1:"B";a:4:{i:0;s:2:"12";i:1;s:3:"-29";i:2;s:3:"537";i:3;s:3:"541";}}s:12:"gcommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:12:"gcommaaccent";s:1:"B";a:4:{i:0;s:1:"8";i:1;s:4:"-206";i:2;s:3:"472";i:3;s:3:"706";}}s:3:"eth";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:3:"eth";s:1:"B";a:4:{i:0;s:2:"27";i:1;s:3:"-11";i:2;s:3:"482";i:3;s:3:"683";}}s:6:"zcaron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"389";s:1:"N";s:6:"zcaron";s:1:"B";a:4:{i:0;s:2:"-2";i:1;s:3:"-81";i:2;s:3:"434";i:3;s:3:"661";}}s:12:"ncommaaccent";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:12:"ncommaaccent";s:1:"B";a:4:{i:0;s:2:"14";i:1;s:4:"-187";i:2;s:3:"474";i:3;s:3:"441";}}s:11:"onesuperior";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"300";s:1:"N";s:11:"onesuperior";s:1:"B";a:4:{i:0;s:2:"43";i:1;s:3:"271";i:2;s:3:"284";i:3;s:3:"676";}}s:7:"imacron";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"278";s:1:"N";s:7:"imacron";s:1:"B";a:4:{i:0;s:2:"46";i:1;s:3:"-11";i:2;s:3:"311";i:3;s:3:"583";}}s:4:"Euro";a:4:{s:1:"C";s:2:"-1";s:2:"WX";s:3:"500";s:1:"N";s:4:"Euro";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}}s:3:"KPX";a:117:{s:1:"A";a:49:{s:1:"C";s:3:"-30";s:6:"Cacute";s:3:"-30";s:6:"Ccaron";s:3:"-30";s:8:"Ccedilla";s:3:"-30";s:1:"G";s:3:"-35";s:6:"Gbreve";s:3:"-35";s:12:"Gcommaaccent";s:3:"-35";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"Q";s:3:"-40";s:1:"T";s:3:"-37";s:6:"Tcaron";s:3:"-37";s:12:"Tcommaaccent";s:3:"-37";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:4:"-105";s:1:"W";s:3:"-95";s:1:"Y";s:3:"-55";s:6:"Yacute";s:3:"-55";s:9:"Ydieresis";s:3:"-55";s:10:"quoteright";s:3:"-37";s:1:"u";s:3:"-20";s:6:"uacute";s:3:"-20";s:11:"ucircumflex";s:3:"-20";s:9:"udieresis";s:3:"-20";s:6:"ugrave";s:3:"-20";s:13:"uhungarumlaut";s:3:"-20";s:7:"umacron";s:3:"-20";s:7:"uogonek";s:3:"-20";s:5:"uring";s:3:"-20";s:1:"v";s:3:"-55";s:1:"w";s:3:"-55";s:1:"y";s:3:"-55";s:6:"yacute";s:3:"-55";s:9:"ydieresis";s:3:"-55";}s:6:"Aacute";a:49:{s:1:"C";s:3:"-30";s:6:"Cacute";s:3:"-30";s:6:"Ccaron";s:3:"-30";s:8:"Ccedilla";s:3:"-30";s:1:"G";s:3:"-35";s:6:"Gbreve";s:3:"-35";s:12:"Gcommaaccent";s:3:"-35";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"Q";s:3:"-40";s:1:"T";s:3:"-37";s:6:"Tcaron";s:3:"-37";s:12:"Tcommaaccent";s:3:"-37";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:4:"-105";s:1:"W";s:3:"-95";s:1:"Y";s:3:"-55";s:6:"Yacute";s:3:"-55";s:9:"Ydieresis";s:3:"-55";s:10:"quoteright";s:3:"-37";s:1:"u";s:3:"-20";s:6:"uacute";s:3:"-20";s:11:"ucircumflex";s:3:"-20";s:9:"udieresis";s:3:"-20";s:6:"ugrave";s:3:"-20";s:13:"uhungarumlaut";s:3:"-20";s:7:"umacron";s:3:"-20";s:7:"uogonek";s:3:"-20";s:5:"uring";s:3:"-20";s:1:"v";s:3:"-55";s:1:"w";s:3:"-55";s:1:"y";s:3:"-55";s:6:"yacute";s:3:"-55";s:9:"ydieresis";s:3:"-55";}s:6:"Abreve";a:49:{s:1:"C";s:3:"-30";s:6:"Cacute";s:3:"-30";s:6:"Ccaron";s:3:"-30";s:8:"Ccedilla";s:3:"-30";s:1:"G";s:3:"-35";s:6:"Gbreve";s:3:"-35";s:12:"Gcommaaccent";s:3:"-35";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"Q";s:3:"-40";s:1:"T";s:3:"-37";s:6:"Tcaron";s:3:"-37";s:12:"Tcommaaccent";s:3:"-37";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:4:"-105";s:1:"W";s:3:"-95";s:1:"Y";s:3:"-55";s:6:"Yacute";s:3:"-55";s:9:"Ydieresis";s:3:"-55";s:10:"quoteright";s:3:"-37";s:1:"u";s:3:"-20";s:6:"uacute";s:3:"-20";s:11:"ucircumflex";s:3:"-20";s:9:"udieresis";s:3:"-20";s:6:"ugrave";s:3:"-20";s:13:"uhungarumlaut";s:3:"-20";s:7:"umacron";s:3:"-20";s:7:"uogonek";s:3:"-20";s:5:"uring";s:3:"-20";s:1:"v";s:3:"-55";s:1:"w";s:3:"-55";s:1:"y";s:3:"-55";s:6:"yacute";s:3:"-55";s:9:"ydieresis";s:3:"-55";}s:11:"Acircumflex";a:49:{s:1:"C";s:3:"-30";s:6:"Cacute";s:3:"-30";s:6:"Ccaron";s:3:"-30";s:8:"Ccedilla";s:3:"-30";s:1:"G";s:3:"-35";s:6:"Gbreve";s:3:"-35";s:12:"Gcommaaccent";s:3:"-35";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"Q";s:3:"-40";s:1:"T";s:3:"-37";s:6:"Tcaron";s:3:"-37";s:12:"Tcommaaccent";s:3:"-37";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:4:"-105";s:1:"W";s:3:"-95";s:1:"Y";s:3:"-55";s:6:"Yacute";s:3:"-55";s:9:"Ydieresis";s:3:"-55";s:10:"quoteright";s:3:"-37";s:1:"u";s:3:"-20";s:6:"uacute";s:3:"-20";s:11:"ucircumflex";s:3:"-20";s:9:"udieresis";s:3:"-20";s:6:"ugrave";s:3:"-20";s:13:"uhungarumlaut";s:3:"-20";s:7:"umacron";s:3:"-20";s:7:"uogonek";s:3:"-20";s:5:"uring";s:3:"-20";s:1:"v";s:3:"-55";s:1:"w";s:3:"-55";s:1:"y";s:3:"-55";s:6:"yacute";s:3:"-55";s:9:"ydieresis";s:3:"-55";}s:9:"Adieresis";a:49:{s:1:"C";s:3:"-30";s:6:"Cacute";s:3:"-30";s:6:"Ccaron";s:3:"-30";s:8:"Ccedilla";s:3:"-30";s:1:"G";s:3:"-35";s:6:"Gbreve";s:3:"-35";s:12:"Gcommaaccent";s:3:"-35";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"Q";s:3:"-40";s:1:"T";s:3:"-37";s:6:"Tcaron";s:3:"-37";s:12:"Tcommaaccent";s:3:"-37";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:4:"-105";s:1:"W";s:3:"-95";s:1:"Y";s:3:"-55";s:6:"Yacute";s:3:"-55";s:9:"Ydieresis";s:3:"-55";s:10:"quoteright";s:3:"-37";s:1:"u";s:3:"-20";s:6:"uacute";s:3:"-20";s:11:"ucircumflex";s:3:"-20";s:9:"udieresis";s:3:"-20";s:6:"ugrave";s:3:"-20";s:13:"uhungarumlaut";s:3:"-20";s:7:"umacron";s:3:"-20";s:7:"uogonek";s:3:"-20";s:5:"uring";s:3:"-20";s:1:"v";s:3:"-55";s:1:"w";s:3:"-55";s:1:"y";s:3:"-55";s:6:"yacute";s:3:"-55";s:9:"ydieresis";s:3:"-55";}s:6:"Agrave";a:49:{s:1:"C";s:3:"-30";s:6:"Cacute";s:3:"-30";s:6:"Ccaron";s:3:"-30";s:8:"Ccedilla";s:3:"-30";s:1:"G";s:3:"-35";s:6:"Gbreve";s:3:"-35";s:12:"Gcommaaccent";s:3:"-35";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"Q";s:3:"-40";s:1:"T";s:3:"-37";s:6:"Tcaron";s:3:"-37";s:12:"Tcommaaccent";s:3:"-37";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:4:"-105";s:1:"W";s:3:"-95";s:1:"Y";s:3:"-55";s:6:"Yacute";s:3:"-55";s:9:"Ydieresis";s:3:"-55";s:10:"quoteright";s:3:"-37";s:1:"u";s:3:"-20";s:6:"uacute";s:3:"-20";s:11:"ucircumflex";s:3:"-20";s:9:"udieresis";s:3:"-20";s:6:"ugrave";s:3:"-20";s:13:"uhungarumlaut";s:3:"-20";s:7:"umacron";s:3:"-20";s:7:"uogonek";s:3:"-20";s:5:"uring";s:3:"-20";s:1:"v";s:3:"-55";s:1:"w";s:3:"-55";s:1:"y";s:3:"-55";s:6:"yacute";s:3:"-55";s:9:"ydieresis";s:3:"-55";}s:7:"Amacron";a:49:{s:1:"C";s:3:"-30";s:6:"Cacute";s:3:"-30";s:6:"Ccaron";s:3:"-30";s:8:"Ccedilla";s:3:"-30";s:1:"G";s:3:"-35";s:6:"Gbreve";s:3:"-35";s:12:"Gcommaaccent";s:3:"-35";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"Q";s:3:"-40";s:1:"T";s:3:"-37";s:6:"Tcaron";s:3:"-37";s:12:"Tcommaaccent";s:3:"-37";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:4:"-105";s:1:"W";s:3:"-95";s:1:"Y";s:3:"-55";s:6:"Yacute";s:3:"-55";s:9:"Ydieresis";s:3:"-55";s:10:"quoteright";s:3:"-37";s:1:"u";s:3:"-20";s:6:"uacute";s:3:"-20";s:11:"ucircumflex";s:3:"-20";s:9:"udieresis";s:3:"-20";s:6:"ugrave";s:3:"-20";s:13:"uhungarumlaut";s:3:"-20";s:7:"umacron";s:3:"-20";s:7:"uogonek";s:3:"-20";s:5:"uring";s:3:"-20";s:1:"v";s:3:"-55";s:1:"w";s:3:"-55";s:1:"y";s:3:"-55";s:6:"yacute";s:3:"-55";s:9:"ydieresis";s:3:"-55";}s:7:"Aogonek";a:49:{s:1:"C";s:3:"-30";s:6:"Cacute";s:3:"-30";s:6:"Ccaron";s:3:"-30";s:8:"Ccedilla";s:3:"-30";s:1:"G";s:3:"-35";s:6:"Gbreve";s:3:"-35";s:12:"Gcommaaccent";s:3:"-35";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"Q";s:3:"-40";s:1:"T";s:3:"-37";s:6:"Tcaron";s:3:"-37";s:12:"Tcommaaccent";s:3:"-37";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:4:"-105";s:1:"W";s:3:"-95";s:1:"Y";s:3:"-55";s:6:"Yacute";s:3:"-55";s:9:"Ydieresis";s:3:"-55";s:10:"quoteright";s:3:"-37";s:1:"u";s:3:"-20";s:6:"uacute";s:3:"-20";s:11:"ucircumflex";s:3:"-20";s:9:"udieresis";s:3:"-20";s:6:"ugrave";s:3:"-20";s:13:"uhungarumlaut";s:3:"-20";s:7:"umacron";s:3:"-20";s:7:"uogonek";s:3:"-20";s:5:"uring";s:3:"-20";s:1:"v";s:3:"-55";s:1:"w";s:3:"-55";s:1:"y";s:3:"-55";s:6:"yacute";s:3:"-55";s:9:"ydieresis";s:3:"-55";}s:5:"Aring";a:49:{s:1:"C";s:3:"-30";s:6:"Cacute";s:3:"-30";s:6:"Ccaron";s:3:"-30";s:8:"Ccedilla";s:3:"-30";s:1:"G";s:3:"-35";s:6:"Gbreve";s:3:"-35";s:12:"Gcommaaccent";s:3:"-35";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"Q";s:3:"-40";s:1:"T";s:3:"-37";s:6:"Tcaron";s:3:"-37";s:12:"Tcommaaccent";s:3:"-37";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:4:"-105";s:1:"W";s:3:"-95";s:1:"Y";s:3:"-55";s:6:"Yacute";s:3:"-55";s:9:"Ydieresis";s:3:"-55";s:10:"quoteright";s:3:"-37";s:1:"u";s:3:"-20";s:6:"uacute";s:3:"-20";s:11:"ucircumflex";s:3:"-20";s:9:"udieresis";s:3:"-20";s:6:"ugrave";s:3:"-20";s:13:"uhungarumlaut";s:3:"-20";s:7:"umacron";s:3:"-20";s:7:"uogonek";s:3:"-20";s:5:"uring";s:3:"-20";s:1:"v";s:3:"-55";s:1:"w";s:3:"-55";s:1:"y";s:3:"-55";s:6:"yacute";s:3:"-55";s:9:"ydieresis";s:3:"-55";}s:6:"Atilde";a:49:{s:1:"C";s:3:"-30";s:6:"Cacute";s:3:"-30";s:6:"Ccaron";s:3:"-30";s:8:"Ccedilla";s:3:"-30";s:1:"G";s:3:"-35";s:6:"Gbreve";s:3:"-35";s:12:"Gcommaaccent";s:3:"-35";s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"Q";s:3:"-40";s:1:"T";s:3:"-37";s:6:"Tcaron";s:3:"-37";s:12:"Tcommaaccent";s:3:"-37";s:1:"U";s:3:"-50";s:6:"Uacute";s:3:"-50";s:11:"Ucircumflex";s:3:"-50";s:9:"Udieresis";s:3:"-50";s:6:"Ugrave";s:3:"-50";s:13:"Uhungarumlaut";s:3:"-50";s:7:"Umacron";s:3:"-50";s:7:"Uogonek";s:3:"-50";s:5:"Uring";s:3:"-50";s:1:"V";s:4:"-105";s:1:"W";s:3:"-95";s:1:"Y";s:3:"-55";s:6:"Yacute";s:3:"-55";s:9:"Ydieresis";s:3:"-55";s:10:"quoteright";s:3:"-37";s:1:"u";s:3:"-20";s:6:"uacute";s:3:"-20";s:11:"ucircumflex";s:3:"-20";s:9:"udieresis";s:3:"-20";s:6:"ugrave";s:3:"-20";s:13:"uhungarumlaut";s:3:"-20";s:7:"umacron";s:3:"-20";s:7:"uogonek";s:3:"-20";s:5:"uring";s:3:"-20";s:1:"v";s:3:"-55";s:1:"w";s:3:"-55";s:1:"y";s:3:"-55";s:6:"yacute";s:3:"-55";s:9:"ydieresis";s:3:"-55";}s:1:"B";a:19:{s:1:"A";s:3:"-25";s:6:"Aacute";s:3:"-25";s:6:"Abreve";s:3:"-25";s:11:"Acircumflex";s:3:"-25";s:9:"Adieresis";s:3:"-25";s:6:"Agrave";s:3:"-25";s:7:"Amacron";s:3:"-25";s:7:"Aogonek";s:3:"-25";s:5:"Aring";s:3:"-25";s:6:"Atilde";s:3:"-25";s:1:"U";s:3:"-10";s:6:"Uacute";s:3:"-10";s:11:"Ucircumflex";s:3:"-10";s:9:"Udieresis";s:3:"-10";s:6:"Ugrave";s:3:"-10";s:13:"Uhungarumlaut";s:3:"-10";s:7:"Umacron";s:3:"-10";s:7:"Uogonek";s:3:"-10";s:5:"Uring";s:3:"-10";}s:1:"D";a:15:{s:1:"A";s:3:"-35";s:6:"Aacute";s:3:"-35";s:6:"Abreve";s:3:"-35";s:11:"Acircumflex";s:3:"-35";s:9:"Adieresis";s:3:"-35";s:6:"Agrave";s:3:"-35";s:7:"Amacron";s:3:"-35";s:7:"Aogonek";s:3:"-35";s:5:"Aring";s:3:"-35";s:6:"Atilde";s:3:"-35";s:1:"V";s:3:"-40";s:1:"W";s:3:"-40";s:1:"Y";s:3:"-40";s:6:"Yacute";s:3:"-40";s:9:"Ydieresis";s:3:"-40";}s:6:"Dcaron";a:15:{s:1:"A";s:3:"-35";s:6:"Aacute";s:3:"-35";s:6:"Abreve";s:3:"-35";s:11:"Acircumflex";s:3:"-35";s:9:"Adieresis";s:3:"-35";s:6:"Agrave";s:3:"-35";s:7:"Amacron";s:3:"-35";s:7:"Aogonek";s:3:"-35";s:5:"Aring";s:3:"-35";s:6:"Atilde";s:3:"-35";s:1:"V";s:3:"-40";s:1:"W";s:3:"-40";s:1:"Y";s:3:"-40";s:6:"Yacute";s:3:"-40";s:9:"Ydieresis";s:3:"-40";}s:6:"Dcroat";a:15:{s:1:"A";s:3:"-35";s:6:"Aacute";s:3:"-35";s:6:"Abreve";s:3:"-35";s:11:"Acircumflex";s:3:"-35";s:9:"Adieresis";s:3:"-35";s:6:"Agrave";s:3:"-35";s:7:"Amacron";s:3:"-35";s:7:"Aogonek";s:3:"-35";s:5:"Aring";s:3:"-35";s:6:"Atilde";s:3:"-35";s:1:"V";s:3:"-40";s:1:"W";s:3:"-40";s:1:"Y";s:3:"-40";s:6:"Yacute";s:3:"-40";s:9:"Ydieresis";s:3:"-40";}s:1:"F";a:51:{s:1:"A";s:4:"-115";s:6:"Aacute";s:4:"-115";s:6:"Abreve";s:4:"-115";s:11:"Acircumflex";s:4:"-115";s:9:"Adieresis";s:4:"-115";s:6:"Agrave";s:4:"-115";s:7:"Amacron";s:4:"-115";s:7:"Aogonek";s:4:"-115";s:5:"Aring";s:4:"-115";s:6:"Atilde";s:4:"-115";s:1:"a";s:3:"-75";s:6:"aacute";s:3:"-75";s:6:"abreve";s:3:"-75";s:11:"acircumflex";s:3:"-75";s:9:"adieresis";s:3:"-75";s:6:"agrave";s:3:"-75";s:7:"amacron";s:3:"-75";s:7:"aogonek";s:3:"-75";s:5:"aring";s:3:"-75";s:6:"atilde";s:3:"-75";s:5:"comma";s:4:"-135";s:1:"e";s:3:"-75";s:6:"eacute";s:3:"-75";s:6:"ecaron";s:3:"-75";s:11:"ecircumflex";s:3:"-75";s:9:"edieresis";s:3:"-75";s:10:"edotaccent";s:3:"-75";s:6:"egrave";s:3:"-75";s:7:"emacron";s:3:"-75";s:7:"eogonek";s:3:"-75";s:1:"i";s:3:"-45";s:6:"iacute";s:3:"-45";s:11:"icircumflex";s:3:"-45";s:9:"idieresis";s:3:"-45";s:6:"igrave";s:3:"-45";s:7:"imacron";s:3:"-45";s:7:"iogonek";s:3:"-45";s:1:"o";s:4:"-105";s:6:"oacute";s:4:"-105";s:11:"ocircumflex";s:4:"-105";s:9:"odieresis";s:4:"-105";s:6:"ograve";s:4:"-105";s:13:"ohungarumlaut";s:4:"-105";s:7:"omacron";s:4:"-105";s:6:"oslash";s:4:"-105";s:6:"otilde";s:4:"-105";s:6:"period";s:4:"-135";s:1:"r";s:3:"-55";s:6:"racute";s:3:"-55";s:6:"rcaron";s:3:"-55";s:12:"rcommaaccent";s:3:"-55";}s:1:"J";a:49:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:1:"a";s:3:"-35";s:6:"aacute";s:3:"-35";s:6:"abreve";s:3:"-35";s:11:"acircumflex";s:3:"-35";s:9:"adieresis";s:3:"-35";s:6:"agrave";s:3:"-35";s:7:"amacron";s:3:"-35";s:7:"aogonek";s:3:"-35";s:5:"aring";s:3:"-35";s:6:"atilde";s:3:"-35";s:5:"comma";s:3:"-25";s:1:"e";s:3:"-25";s:6:"eacute";s:3:"-25";s:6:"ecaron";s:3:"-25";s:11:"ecircumflex";s:3:"-25";s:9:"edieresis";s:3:"-25";s:10:"edotaccent";s:3:"-25";s:6:"egrave";s:3:"-25";s:7:"emacron";s:3:"-25";s:7:"eogonek";s:3:"-25";s:1:"o";s:3:"-25";s:6:"oacute";s:3:"-25";s:11:"ocircumflex";s:3:"-25";s:9:"odieresis";s:3:"-25";s:6:"ograve";s:3:"-25";s:13:"ohungarumlaut";s:3:"-25";s:7:"omacron";s:3:"-25";s:6:"oslash";s:3:"-25";s:6:"otilde";s:3:"-25";s:6:"period";s:3:"-25";s:1:"u";s:3:"-35";s:6:"uacute";s:3:"-35";s:11:"ucircumflex";s:3:"-35";s:9:"udieresis";s:3:"-35";s:6:"ugrave";s:3:"-35";s:13:"uhungarumlaut";s:3:"-35";s:7:"umacron";s:3:"-35";s:7:"uogonek";s:3:"-35";s:5:"uring";s:3:"-35";}s:1:"K";a:39:{s:1:"O";s:3:"-50";s:6:"Oacute";s:3:"-50";s:11:"Ocircumflex";s:3:"-50";s:9:"Odieresis";s:3:"-50";s:6:"Ograve";s:3:"-50";s:13:"Ohungarumlaut";s:3:"-50";s:7:"Omacron";s:3:"-50";s:6:"Oslash";s:3:"-50";s:6:"Otilde";s:3:"-50";s:1:"e";s:3:"-35";s:6:"eacute";s:3:"-35";s:6:"ecaron";s:3:"-35";s:11:"ecircumflex";s:3:"-35";s:9:"edieresis";s:3:"-35";s:10:"edotaccent";s:3:"-35";s:6:"egrave";s:3:"-35";s:7:"emacron";s:3:"-35";s:7:"eogonek";s:3:"-35";s:1:"o";s:3:"-40";s:6:"oacute";s:3:"-40";s:11:"ocircumflex";s:3:"-40";s:9:"odieresis";s:3:"-40";s:6:"ograve";s:3:"-40";s:13:"ohungarumlaut";s:3:"-40";s:7:"omacron";s:3:"-40";s:6:"oslash";s:3:"-40";s:6:"otilde";s:3:"-40";s:1:"u";s:3:"-40";s:6:"uacute";s:3:"-40";s:11:"ucircumflex";s:3:"-40";s:9:"udieresis";s:3:"-40";s:6:"ugrave";s:3:"-40";s:13:"uhungarumlaut";s:3:"-40";s:7:"umacron";s:3:"-40";s:7:"uogonek";s:3:"-40";s:5:"uring";s:3:"-40";s:1:"y";s:3:"-40";s:6:"yacute";s:3:"-40";s:9:"ydieresis";s:3:"-40";}s:12:"Kcommaaccent";a:39:{s:1:"O";s:3:"-50";s:6:"Oacute";s:3:"-50";s:11:"Ocircumflex";s:3:"-50";s:9:"Odieresis";s:3:"-50";s:6:"Ograve";s:3:"-50";s:13:"Ohungarumlaut";s:3:"-50";s:7:"Omacron";s:3:"-50";s:6:"Oslash";s:3:"-50";s:6:"Otilde";s:3:"-50";s:1:"e";s:3:"-35";s:6:"eacute";s:3:"-35";s:6:"ecaron";s:3:"-35";s:11:"ecircumflex";s:3:"-35";s:9:"edieresis";s:3:"-35";s:10:"edotaccent";s:3:"-35";s:6:"egrave";s:3:"-35";s:7:"emacron";s:3:"-35";s:7:"eogonek";s:3:"-35";s:1:"o";s:3:"-40";s:6:"oacute";s:3:"-40";s:11:"ocircumflex";s:3:"-40";s:9:"odieresis";s:3:"-40";s:6:"ograve";s:3:"-40";s:13:"ohungarumlaut";s:3:"-40";s:7:"omacron";s:3:"-40";s:6:"oslash";s:3:"-40";s:6:"otilde";s:3:"-40";s:1:"u";s:3:"-40";s:6:"uacute";s:3:"-40";s:11:"ucircumflex";s:3:"-40";s:9:"udieresis";s:3:"-40";s:6:"ugrave";s:3:"-40";s:13:"uhungarumlaut";s:3:"-40";s:7:"umacron";s:3:"-40";s:7:"uogonek";s:3:"-40";s:5:"uring";s:3:"-40";s:1:"y";s:3:"-40";s:6:"yacute";s:3:"-40";s:9:"ydieresis";s:3:"-40";}s:1:"L";a:12:{s:1:"T";s:3:"-20";s:6:"Tcaron";s:3:"-20";s:12:"Tcommaaccent";s:3:"-20";s:1:"V";s:3:"-55";s:1:"W";s:3:"-55";s:1:"Y";s:3:"-20";s:6:"Yacute";s:3:"-20";s:9:"Ydieresis";s:3:"-20";s:10:"quoteright";s:3:"-37";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:6:"Lacute";a:12:{s:1:"T";s:3:"-20";s:6:"Tcaron";s:3:"-20";s:12:"Tcommaaccent";s:3:"-20";s:1:"V";s:3:"-55";s:1:"W";s:3:"-55";s:1:"Y";s:3:"-20";s:6:"Yacute";s:3:"-20";s:9:"Ydieresis";s:3:"-20";s:10:"quoteright";s:3:"-37";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:12:"Lcommaaccent";a:12:{s:1:"T";s:3:"-20";s:6:"Tcaron";s:3:"-20";s:12:"Tcommaaccent";s:3:"-20";s:1:"V";s:3:"-55";s:1:"W";s:3:"-55";s:1:"Y";s:3:"-20";s:6:"Yacute";s:3:"-20";s:9:"Ydieresis";s:3:"-20";s:10:"quoteright";s:3:"-37";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:6:"Lslash";a:12:{s:1:"T";s:3:"-20";s:6:"Tcaron";s:3:"-20";s:12:"Tcommaaccent";s:3:"-20";s:1:"V";s:3:"-55";s:1:"W";s:3:"-55";s:1:"Y";s:3:"-20";s:6:"Yacute";s:3:"-20";s:9:"Ydieresis";s:3:"-20";s:10:"quoteright";s:3:"-37";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:1:"N";a:10:{s:1:"A";s:3:"-27";s:6:"Aacute";s:3:"-27";s:6:"Abreve";s:3:"-27";s:11:"Acircumflex";s:3:"-27";s:9:"Adieresis";s:3:"-27";s:6:"Agrave";s:3:"-27";s:7:"Amacron";s:3:"-27";s:7:"Aogonek";s:3:"-27";s:5:"Aring";s:3:"-27";s:6:"Atilde";s:3:"-27";}s:6:"Nacute";a:10:{s:1:"A";s:3:"-27";s:6:"Aacute";s:3:"-27";s:6:"Abreve";s:3:"-27";s:11:"Acircumflex";s:3:"-27";s:9:"Adieresis";s:3:"-27";s:6:"Agrave";s:3:"-27";s:7:"Amacron";s:3:"-27";s:7:"Aogonek";s:3:"-27";s:5:"Aring";s:3:"-27";s:6:"Atilde";s:3:"-27";}s:6:"Ncaron";a:10:{s:1:"A";s:3:"-27";s:6:"Aacute";s:3:"-27";s:6:"Abreve";s:3:"-27";s:11:"Acircumflex";s:3:"-27";s:9:"Adieresis";s:3:"-27";s:6:"Agrave";s:3:"-27";s:7:"Amacron";s:3:"-27";s:7:"Aogonek";s:3:"-27";s:5:"Aring";s:3:"-27";s:6:"Atilde";s:3:"-27";}s:12:"Ncommaaccent";a:10:{s:1:"A";s:3:"-27";s:6:"Aacute";s:3:"-27";s:6:"Abreve";s:3:"-27";s:11:"Acircumflex";s:3:"-27";s:9:"Adieresis";s:3:"-27";s:6:"Agrave";s:3:"-27";s:7:"Amacron";s:3:"-27";s:7:"Aogonek";s:3:"-27";s:5:"Aring";s:3:"-27";s:6:"Atilde";s:3:"-27";}s:6:"Ntilde";a:10:{s:1:"A";s:3:"-27";s:6:"Aacute";s:3:"-27";s:6:"Abreve";s:3:"-27";s:11:"Acircumflex";s:3:"-27";s:9:"Adieresis";s:3:"-27";s:6:"Agrave";s:3:"-27";s:7:"Amacron";s:3:"-27";s:7:"Aogonek";s:3:"-27";s:5:"Aring";s:3:"-27";s:6:"Atilde";s:3:"-27";}s:1:"O";a:19:{s:1:"A";s:3:"-55";s:6:"Aacute";s:3:"-55";s:6:"Abreve";s:3:"-55";s:11:"Acircumflex";s:3:"-55";s:9:"Adieresis";s:3:"-55";s:6:"Agrave";s:3:"-55";s:7:"Amacron";s:3:"-55";s:7:"Aogonek";s:3:"-55";s:5:"Aring";s:3:"-55";s:6:"Atilde";s:3:"-55";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:6:"Oacute";a:19:{s:1:"A";s:3:"-55";s:6:"Aacute";s:3:"-55";s:6:"Abreve";s:3:"-55";s:11:"Acircumflex";s:3:"-55";s:9:"Adieresis";s:3:"-55";s:6:"Agrave";s:3:"-55";s:7:"Amacron";s:3:"-55";s:7:"Aogonek";s:3:"-55";s:5:"Aring";s:3:"-55";s:6:"Atilde";s:3:"-55";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:11:"Ocircumflex";a:19:{s:1:"A";s:3:"-55";s:6:"Aacute";s:3:"-55";s:6:"Abreve";s:3:"-55";s:11:"Acircumflex";s:3:"-55";s:9:"Adieresis";s:3:"-55";s:6:"Agrave";s:3:"-55";s:7:"Amacron";s:3:"-55";s:7:"Aogonek";s:3:"-55";s:5:"Aring";s:3:"-55";s:6:"Atilde";s:3:"-55";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:9:"Odieresis";a:19:{s:1:"A";s:3:"-55";s:6:"Aacute";s:3:"-55";s:6:"Abreve";s:3:"-55";s:11:"Acircumflex";s:3:"-55";s:9:"Adieresis";s:3:"-55";s:6:"Agrave";s:3:"-55";s:7:"Amacron";s:3:"-55";s:7:"Aogonek";s:3:"-55";s:5:"Aring";s:3:"-55";s:6:"Atilde";s:3:"-55";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:6:"Ograve";a:19:{s:1:"A";s:3:"-55";s:6:"Aacute";s:3:"-55";s:6:"Abreve";s:3:"-55";s:11:"Acircumflex";s:3:"-55";s:9:"Adieresis";s:3:"-55";s:6:"Agrave";s:3:"-55";s:7:"Amacron";s:3:"-55";s:7:"Aogonek";s:3:"-55";s:5:"Aring";s:3:"-55";s:6:"Atilde";s:3:"-55";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:13:"Ohungarumlaut";a:19:{s:1:"A";s:3:"-55";s:6:"Aacute";s:3:"-55";s:6:"Abreve";s:3:"-55";s:11:"Acircumflex";s:3:"-55";s:9:"Adieresis";s:3:"-55";s:6:"Agrave";s:3:"-55";s:7:"Amacron";s:3:"-55";s:7:"Aogonek";s:3:"-55";s:5:"Aring";s:3:"-55";s:6:"Atilde";s:3:"-55";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:7:"Omacron";a:19:{s:1:"A";s:3:"-55";s:6:"Aacute";s:3:"-55";s:6:"Abreve";s:3:"-55";s:11:"Acircumflex";s:3:"-55";s:9:"Adieresis";s:3:"-55";s:6:"Agrave";s:3:"-55";s:7:"Amacron";s:3:"-55";s:7:"Aogonek";s:3:"-55";s:5:"Aring";s:3:"-55";s:6:"Atilde";s:3:"-55";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:6:"Oslash";a:19:{s:1:"A";s:3:"-55";s:6:"Aacute";s:3:"-55";s:6:"Abreve";s:3:"-55";s:11:"Acircumflex";s:3:"-55";s:9:"Adieresis";s:3:"-55";s:6:"Agrave";s:3:"-55";s:7:"Amacron";s:3:"-55";s:7:"Aogonek";s:3:"-55";s:5:"Aring";s:3:"-55";s:6:"Atilde";s:3:"-55";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:6:"Otilde";a:19:{s:1:"A";s:3:"-55";s:6:"Aacute";s:3:"-55";s:6:"Abreve";s:3:"-55";s:11:"Acircumflex";s:3:"-55";s:9:"Adieresis";s:3:"-55";s:6:"Agrave";s:3:"-55";s:7:"Amacron";s:3:"-55";s:7:"Aogonek";s:3:"-55";s:5:"Aring";s:3:"-55";s:6:"Atilde";s:3:"-55";s:1:"T";s:3:"-40";s:6:"Tcaron";s:3:"-40";s:12:"Tcommaaccent";s:3:"-40";s:1:"V";s:3:"-50";s:1:"W";s:3:"-50";s:1:"X";s:3:"-40";s:1:"Y";s:3:"-50";s:6:"Yacute";s:3:"-50";s:9:"Ydieresis";s:3:"-50";}s:1:"P";a:40:{s:1:"A";s:3:"-90";s:6:"Aacute";s:3:"-90";s:6:"Abreve";s:3:"-90";s:11:"Acircumflex";s:3:"-90";s:9:"Adieresis";s:3:"-90";s:6:"Agrave";s:3:"-90";s:7:"Amacron";s:3:"-90";s:7:"Aogonek";s:3:"-90";s:5:"Aring";s:3:"-90";s:6:"Atilde";s:3:"-90";s:1:"a";s:3:"-80";s:6:"aacute";s:3:"-80";s:6:"abreve";s:3:"-80";s:11:"acircumflex";s:3:"-80";s:9:"adieresis";s:3:"-80";s:6:"agrave";s:3:"-80";s:7:"amacron";s:3:"-80";s:7:"aogonek";s:3:"-80";s:5:"aring";s:3:"-80";s:6:"atilde";s:3:"-80";s:5:"comma";s:4:"-135";s:1:"e";s:3:"-80";s:6:"eacute";s:3:"-80";s:6:"ecaron";s:3:"-80";s:11:"ecircumflex";s:3:"-80";s:9:"edieresis";s:3:"-80";s:10:"edotaccent";s:3:"-80";s:6:"egrave";s:3:"-80";s:7:"emacron";s:3:"-80";s:7:"eogonek";s:3:"-80";s:1:"o";s:3:"-80";s:6:"oacute";s:3:"-80";s:11:"ocircumflex";s:3:"-80";s:9:"odieresis";s:3:"-80";s:6:"ograve";s:3:"-80";s:13:"ohungarumlaut";s:3:"-80";s:7:"omacron";s:3:"-80";s:6:"oslash";s:3:"-80";s:6:"otilde";s:3:"-80";s:6:"period";s:4:"-135";}s:1:"Q";a:9:{s:1:"U";s:3:"-10";s:6:"Uacute";s:3:"-10";s:11:"Ucircumflex";s:3:"-10";s:9:"Udieresis";s:3:"-10";s:6:"Ugrave";s:3:"-10";s:13:"Uhungarumlaut";s:3:"-10";s:7:"Umacron";s:3:"-10";s:7:"Uogonek";s:3:"-10";s:5:"Uring";s:3:"-10";}s:1:"R";a:23:{s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"U";s:3:"-40";s:6:"Uacute";s:3:"-40";s:11:"Ucircumflex";s:3:"-40";s:9:"Udieresis";s:3:"-40";s:6:"Ugrave";s:3:"-40";s:13:"Uhungarumlaut";s:3:"-40";s:7:"Umacron";s:3:"-40";s:7:"Uogonek";s:3:"-40";s:5:"Uring";s:3:"-40";s:1:"V";s:3:"-18";s:1:"W";s:3:"-18";s:1:"Y";s:3:"-18";s:6:"Yacute";s:3:"-18";s:9:"Ydieresis";s:3:"-18";}s:6:"Racute";a:23:{s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"U";s:3:"-40";s:6:"Uacute";s:3:"-40";s:11:"Ucircumflex";s:3:"-40";s:9:"Udieresis";s:3:"-40";s:6:"Ugrave";s:3:"-40";s:13:"Uhungarumlaut";s:3:"-40";s:7:"Umacron";s:3:"-40";s:7:"Uogonek";s:3:"-40";s:5:"Uring";s:3:"-40";s:1:"V";s:3:"-18";s:1:"W";s:3:"-18";s:1:"Y";s:3:"-18";s:6:"Yacute";s:3:"-18";s:9:"Ydieresis";s:3:"-18";}s:6:"Rcaron";a:23:{s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"U";s:3:"-40";s:6:"Uacute";s:3:"-40";s:11:"Ucircumflex";s:3:"-40";s:9:"Udieresis";s:3:"-40";s:6:"Ugrave";s:3:"-40";s:13:"Uhungarumlaut";s:3:"-40";s:7:"Umacron";s:3:"-40";s:7:"Uogonek";s:3:"-40";s:5:"Uring";s:3:"-40";s:1:"V";s:3:"-18";s:1:"W";s:3:"-18";s:1:"Y";s:3:"-18";s:6:"Yacute";s:3:"-18";s:9:"Ydieresis";s:3:"-18";}s:12:"Rcommaaccent";a:23:{s:1:"O";s:3:"-40";s:6:"Oacute";s:3:"-40";s:11:"Ocircumflex";s:3:"-40";s:9:"Odieresis";s:3:"-40";s:6:"Ograve";s:3:"-40";s:13:"Ohungarumlaut";s:3:"-40";s:7:"Omacron";s:3:"-40";s:6:"Oslash";s:3:"-40";s:6:"Otilde";s:3:"-40";s:1:"U";s:3:"-40";s:6:"Uacute";s:3:"-40";s:11:"Ucircumflex";s:3:"-40";s:9:"Udieresis";s:3:"-40";s:6:"Ugrave";s:3:"-40";s:13:"Uhungarumlaut";s:3:"-40";s:7:"Umacron";s:3:"-40";s:7:"Uogonek";s:3:"-40";s:5:"Uring";s:3:"-40";s:1:"V";s:3:"-18";s:1:"W";s:3:"-18";s:1:"Y";s:3:"-18";s:6:"Yacute";s:3:"-18";s:9:"Ydieresis";s:3:"-18";}s:1:"T";a:72:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:1:"O";s:3:"-18";s:6:"Oacute";s:3:"-18";s:11:"Ocircumflex";s:3:"-18";s:9:"Odieresis";s:3:"-18";s:6:"Ograve";s:3:"-18";s:13:"Ohungarumlaut";s:3:"-18";s:7:"Omacron";s:3:"-18";s:6:"Oslash";s:3:"-18";s:6:"Otilde";s:3:"-18";s:1:"a";s:3:"-92";s:6:"aacute";s:3:"-92";s:6:"abreve";s:3:"-92";s:11:"acircumflex";s:3:"-92";s:9:"adieresis";s:3:"-92";s:6:"agrave";s:3:"-92";s:7:"amacron";s:3:"-92";s:7:"aogonek";s:3:"-92";s:5:"aring";s:3:"-92";s:6:"atilde";s:3:"-92";s:5:"colon";s:3:"-55";s:5:"comma";s:3:"-74";s:1:"e";s:3:"-92";s:6:"eacute";s:3:"-92";s:6:"ecaron";s:3:"-92";s:11:"ecircumflex";s:3:"-52";s:9:"edieresis";s:3:"-52";s:10:"edotaccent";s:3:"-92";s:6:"egrave";s:3:"-52";s:7:"emacron";s:3:"-52";s:7:"eogonek";s:3:"-92";s:6:"hyphen";s:3:"-74";s:1:"i";s:3:"-55";s:6:"iacute";s:3:"-55";s:7:"iogonek";s:3:"-55";s:1:"o";s:3:"-92";s:6:"oacute";s:3:"-92";s:11:"ocircumflex";s:3:"-92";s:9:"odieresis";s:3:"-92";s:6:"ograve";s:3:"-92";s:13:"ohungarumlaut";s:3:"-92";s:7:"omacron";s:3:"-92";s:6:"oslash";s:3:"-92";s:6:"otilde";s:3:"-92";s:6:"period";s:3:"-74";s:1:"r";s:3:"-55";s:6:"racute";s:3:"-55";s:6:"rcaron";s:3:"-55";s:12:"rcommaaccent";s:3:"-55";s:9:"semicolon";s:3:"-65";s:1:"u";s:3:"-55";s:6:"uacute";s:3:"-55";s:11:"ucircumflex";s:3:"-55";s:9:"udieresis";s:3:"-55";s:6:"ugrave";s:3:"-55";s:13:"uhungarumlaut";s:3:"-55";s:7:"umacron";s:3:"-55";s:7:"uogonek";s:3:"-55";s:5:"uring";s:3:"-55";s:1:"w";s:3:"-74";s:1:"y";s:3:"-74";s:6:"yacute";s:3:"-74";s:9:"ydieresis";s:3:"-34";}s:6:"Tcaron";a:72:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:1:"O";s:3:"-18";s:6:"Oacute";s:3:"-18";s:11:"Ocircumflex";s:3:"-18";s:9:"Odieresis";s:3:"-18";s:6:"Ograve";s:3:"-18";s:13:"Ohungarumlaut";s:3:"-18";s:7:"Omacron";s:3:"-18";s:6:"Oslash";s:3:"-18";s:6:"Otilde";s:3:"-18";s:1:"a";s:3:"-92";s:6:"aacute";s:3:"-92";s:6:"abreve";s:3:"-92";s:11:"acircumflex";s:3:"-92";s:9:"adieresis";s:3:"-92";s:6:"agrave";s:3:"-92";s:7:"amacron";s:3:"-92";s:7:"aogonek";s:3:"-92";s:5:"aring";s:3:"-92";s:6:"atilde";s:3:"-92";s:5:"colon";s:3:"-55";s:5:"comma";s:3:"-74";s:1:"e";s:3:"-92";s:6:"eacute";s:3:"-92";s:6:"ecaron";s:3:"-92";s:11:"ecircumflex";s:3:"-52";s:9:"edieresis";s:3:"-52";s:10:"edotaccent";s:3:"-92";s:6:"egrave";s:3:"-52";s:7:"emacron";s:3:"-52";s:7:"eogonek";s:3:"-92";s:6:"hyphen";s:3:"-74";s:1:"i";s:3:"-55";s:6:"iacute";s:3:"-55";s:7:"iogonek";s:3:"-55";s:1:"o";s:3:"-92";s:6:"oacute";s:3:"-92";s:11:"ocircumflex";s:3:"-92";s:9:"odieresis";s:3:"-92";s:6:"ograve";s:3:"-92";s:13:"ohungarumlaut";s:3:"-92";s:7:"omacron";s:3:"-92";s:6:"oslash";s:3:"-92";s:6:"otilde";s:3:"-92";s:6:"period";s:3:"-74";s:1:"r";s:3:"-55";s:6:"racute";s:3:"-55";s:6:"rcaron";s:3:"-55";s:12:"rcommaaccent";s:3:"-55";s:9:"semicolon";s:3:"-65";s:1:"u";s:3:"-55";s:6:"uacute";s:3:"-55";s:11:"ucircumflex";s:3:"-55";s:9:"udieresis";s:3:"-55";s:6:"ugrave";s:3:"-55";s:13:"uhungarumlaut";s:3:"-55";s:7:"umacron";s:3:"-55";s:7:"uogonek";s:3:"-55";s:5:"uring";s:3:"-55";s:1:"w";s:3:"-74";s:1:"y";s:3:"-74";s:6:"yacute";s:3:"-74";s:9:"ydieresis";s:3:"-34";}s:12:"Tcommaaccent";a:72:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:1:"O";s:3:"-18";s:6:"Oacute";s:3:"-18";s:11:"Ocircumflex";s:3:"-18";s:9:"Odieresis";s:3:"-18";s:6:"Ograve";s:3:"-18";s:13:"Ohungarumlaut";s:3:"-18";s:7:"Omacron";s:3:"-18";s:6:"Oslash";s:3:"-18";s:6:"Otilde";s:3:"-18";s:1:"a";s:3:"-92";s:6:"aacute";s:3:"-92";s:6:"abreve";s:3:"-92";s:11:"acircumflex";s:3:"-92";s:9:"adieresis";s:3:"-92";s:6:"agrave";s:3:"-92";s:7:"amacron";s:3:"-92";s:7:"aogonek";s:3:"-92";s:5:"aring";s:3:"-92";s:6:"atilde";s:3:"-92";s:5:"colon";s:3:"-55";s:5:"comma";s:3:"-74";s:1:"e";s:3:"-92";s:6:"eacute";s:3:"-92";s:6:"ecaron";s:3:"-92";s:11:"ecircumflex";s:3:"-52";s:9:"edieresis";s:3:"-52";s:10:"edotaccent";s:3:"-92";s:6:"egrave";s:3:"-52";s:7:"emacron";s:3:"-52";s:7:"eogonek";s:3:"-92";s:6:"hyphen";s:3:"-74";s:1:"i";s:3:"-55";s:6:"iacute";s:3:"-55";s:7:"iogonek";s:3:"-55";s:1:"o";s:3:"-92";s:6:"oacute";s:3:"-92";s:11:"ocircumflex";s:3:"-92";s:9:"odieresis";s:3:"-92";s:6:"ograve";s:3:"-92";s:13:"ohungarumlaut";s:3:"-92";s:7:"omacron";s:3:"-92";s:6:"oslash";s:3:"-92";s:6:"otilde";s:3:"-92";s:6:"period";s:3:"-74";s:1:"r";s:3:"-55";s:6:"racute";s:3:"-55";s:6:"rcaron";s:3:"-55";s:12:"rcommaaccent";s:3:"-55";s:9:"semicolon";s:3:"-65";s:1:"u";s:3:"-55";s:6:"uacute";s:3:"-55";s:11:"ucircumflex";s:3:"-55";s:9:"udieresis";s:3:"-55";s:6:"ugrave";s:3:"-55";s:13:"uhungarumlaut";s:3:"-55";s:7:"umacron";s:3:"-55";s:7:"uogonek";s:3:"-55";s:5:"uring";s:3:"-55";s:1:"w";s:3:"-74";s:1:"y";s:3:"-74";s:6:"yacute";s:3:"-74";s:9:"ydieresis";s:3:"-34";}s:1:"U";a:12:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:5:"comma";s:3:"-25";s:6:"period";s:3:"-25";}s:6:"Uacute";a:12:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:5:"comma";s:3:"-25";s:6:"period";s:3:"-25";}s:11:"Ucircumflex";a:12:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:5:"comma";s:3:"-25";s:6:"period";s:3:"-25";}s:9:"Udieresis";a:12:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:5:"comma";s:3:"-25";s:6:"period";s:3:"-25";}s:6:"Ugrave";a:12:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:5:"comma";s:3:"-25";s:6:"period";s:3:"-25";}s:13:"Uhungarumlaut";a:12:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:5:"comma";s:3:"-25";s:6:"period";s:3:"-25";}s:7:"Umacron";a:12:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:5:"comma";s:3:"-25";s:6:"period";s:3:"-25";}s:7:"Uogonek";a:12:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:5:"comma";s:3:"-25";s:6:"period";s:3:"-25";}s:5:"Uring";a:12:{s:1:"A";s:3:"-40";s:6:"Aacute";s:3:"-40";s:6:"Abreve";s:3:"-40";s:11:"Acircumflex";s:3:"-40";s:9:"Adieresis";s:3:"-40";s:6:"Agrave";s:3:"-40";s:7:"Amacron";s:3:"-40";s:7:"Aogonek";s:3:"-40";s:5:"Aring";s:3:"-40";s:6:"Atilde";s:3:"-40";s:5:"comma";s:3:"-25";s:6:"period";s:3:"-25";}s:1:"V";a:68:{s:1:"A";s:3:"-60";s:6:"Aacute";s:3:"-60";s:6:"Abreve";s:3:"-60";s:11:"Acircumflex";s:3:"-60";s:9:"Adieresis";s:3:"-60";s:6:"Agrave";s:3:"-60";s:7:"Amacron";s:3:"-60";s:7:"Aogonek";s:3:"-60";s:5:"Aring";s:3:"-60";s:6:"Atilde";s:3:"-60";s:1:"O";s:3:"-30";s:6:"Oacute";s:3:"-30";s:11:"Ocircumflex";s:3:"-30";s:9:"Odieresis";s:3:"-30";s:6:"Ograve";s:3:"-30";s:13:"Ohungarumlaut";s:3:"-30";s:7:"Omacron";s:3:"-30";s:6:"Oslash";s:3:"-30";s:6:"Otilde";s:3:"-30";s:1:"a";s:4:"-111";s:6:"aacute";s:4:"-111";s:6:"abreve";s:4:"-111";s:11:"acircumflex";s:4:"-111";s:9:"adieresis";s:4:"-111";s:6:"agrave";s:4:"-111";s:7:"amacron";s:4:"-111";s:7:"aogonek";s:4:"-111";s:5:"aring";s:4:"-111";s:6:"atilde";s:4:"-111";s:5:"colon";s:3:"-65";s:5:"comma";s:4:"-129";s:1:"e";s:4:"-111";s:6:"eacute";s:4:"-111";s:6:"ecaron";s:4:"-111";s:11:"ecircumflex";s:4:"-111";s:9:"edieresis";s:3:"-71";s:10:"edotaccent";s:4:"-111";s:6:"egrave";s:3:"-71";s:7:"emacron";s:3:"-71";s:7:"eogonek";s:4:"-111";s:6:"hyphen";s:3:"-55";s:1:"i";s:3:"-74";s:6:"iacute";s:3:"-74";s:11:"icircumflex";s:3:"-34";s:9:"idieresis";s:3:"-34";s:6:"igrave";s:3:"-34";s:7:"imacron";s:3:"-34";s:7:"iogonek";s:3:"-74";s:1:"o";s:4:"-111";s:6:"oacute";s:4:"-111";s:11:"ocircumflex";s:4:"-111";s:9:"odieresis";s:4:"-111";s:6:"ograve";s:4:"-111";s:13:"ohungarumlaut";s:4:"-111";s:7:"omacron";s:4:"-111";s:6:"oslash";s:4:"-111";s:6:"otilde";s:4:"-111";s:6:"period";s:4:"-129";s:9:"semicolon";s:3:"-74";s:1:"u";s:3:"-74";s:6:"uacute";s:3:"-74";s:11:"ucircumflex";s:3:"-74";s:9:"udieresis";s:3:"-74";s:6:"ugrave";s:3:"-74";s:13:"uhungarumlaut";s:3:"-74";s:7:"umacron";s:3:"-74";s:7:"uogonek";s:3:"-74";s:5:"uring";s:3:"-74";}s:1:"W";a:67:{s:1:"A";s:3:"-60";s:6:"Aacute";s:3:"-60";s:6:"Abreve";s:3:"-60";s:11:"Acircumflex";s:3:"-60";s:9:"Adieresis";s:3:"-60";s:6:"Agrave";s:3:"-60";s:7:"Amacron";s:3:"-60";s:7:"Aogonek";s:3:"-60";s:5:"Aring";s:3:"-60";s:6:"Atilde";s:3:"-60";s:1:"O";s:3:"-25";s:6:"Oacute";s:3:"-25";s:11:"Ocircumflex";s:3:"-25";s:9:"Odieresis";s:3:"-25";s:6:"Ograve";s:3:"-25";s:13:"Ohungarumlaut";s:3:"-25";s:7:"Omacron";s:3:"-25";s:6:"Oslash";s:3:"-25";s:6:"Otilde";s:3:"-25";s:1:"a";s:3:"-92";s:6:"aacute";s:3:"-92";s:6:"abreve";s:3:"-92";s:11:"acircumflex";s:3:"-92";s:9:"adieresis";s:3:"-92";s:6:"agrave";s:3:"-92";s:7:"amacron";s:3:"-92";s:7:"aogonek";s:3:"-92";s:5:"aring";s:3:"-92";s:6:"atilde";s:3:"-92";s:5:"colon";s:3:"-65";s:5:"comma";s:3:"-92";s:1:"e";s:3:"-92";s:6:"eacute";s:3:"-92";s:6:"ecaron";s:3:"-92";s:11:"ecircumflex";s:3:"-92";s:9:"edieresis";s:3:"-52";s:10:"edotaccent";s:3:"-92";s:6:"egrave";s:3:"-52";s:7:"emacron";s:3:"-52";s:7:"eogonek";s:3:"-92";s:6:"hyphen";s:3:"-37";s:1:"i";s:3:"-55";s:6:"iacute";s:3:"-55";s:7:"iogonek";s:3:"-55";s:1:"o";s:3:"-92";s:6:"oacute";s:3:"-92";s:11:"ocircumflex";s:3:"-92";s:9:"odieresis";s:3:"-92";s:6:"ograve";s:3:"-92";s:13:"ohungarumlaut";s:3:"-92";s:7:"omacron";s:3:"-92";s:6:"oslash";s:3:"-92";s:6:"otilde";s:3:"-92";s:6:"period";s:3:"-92";s:9:"semicolon";s:3:"-65";s:1:"u";s:3:"-55";s:6:"uacute";s:3:"-55";s:11:"ucircumflex";s:3:"-55";s:9:"udieresis";s:3:"-55";s:6:"ugrave";s:3:"-55";s:13:"uhungarumlaut";s:3:"-55";s:7:"umacron";s:3:"-55";s:7:"uogonek";s:3:"-55";s:5:"uring";s:3:"-55";s:1:"y";s:3:"-70";s:6:"yacute";s:3:"-70";s:9:"ydieresis";s:3:"-70";}s:1:"Y";a:68:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:1:"O";s:3:"-15";s:6:"Oacute";s:3:"-15";s:11:"Ocircumflex";s:3:"-15";s:9:"Odieresis";s:3:"-15";s:6:"Ograve";s:3:"-15";s:13:"Ohungarumlaut";s:3:"-15";s:7:"Omacron";s:3:"-15";s:6:"Oslash";s:3:"-15";s:6:"Otilde";s:3:"-15";s:1:"a";s:3:"-92";s:6:"aacute";s:3:"-92";s:6:"abreve";s:3:"-92";s:11:"acircumflex";s:3:"-92";s:9:"adieresis";s:3:"-92";s:6:"agrave";s:3:"-92";s:7:"amacron";s:3:"-92";s:7:"aogonek";s:3:"-92";s:5:"aring";s:3:"-92";s:6:"atilde";s:3:"-92";s:5:"colon";s:3:"-65";s:5:"comma";s:3:"-92";s:1:"e";s:3:"-92";s:6:"eacute";s:3:"-92";s:6:"ecaron";s:3:"-92";s:11:"ecircumflex";s:3:"-92";s:9:"edieresis";s:3:"-52";s:10:"edotaccent";s:3:"-92";s:6:"egrave";s:3:"-52";s:7:"emacron";s:3:"-52";s:7:"eogonek";s:3:"-92";s:6:"hyphen";s:3:"-74";s:1:"i";s:3:"-74";s:6:"iacute";s:3:"-74";s:11:"icircumflex";s:3:"-34";s:9:"idieresis";s:3:"-34";s:6:"igrave";s:3:"-34";s:7:"imacron";s:3:"-34";s:7:"iogonek";s:3:"-74";s:1:"o";s:3:"-92";s:6:"oacute";s:3:"-92";s:11:"ocircumflex";s:3:"-92";s:9:"odieresis";s:3:"-92";s:6:"ograve";s:3:"-92";s:13:"ohungarumlaut";s:3:"-92";s:7:"omacron";s:3:"-92";s:6:"oslash";s:3:"-92";s:6:"otilde";s:3:"-92";s:6:"period";s:3:"-92";s:9:"semicolon";s:3:"-65";s:1:"u";s:3:"-92";s:6:"uacute";s:3:"-92";s:11:"ucircumflex";s:3:"-92";s:9:"udieresis";s:3:"-92";s:6:"ugrave";s:3:"-92";s:13:"uhungarumlaut";s:3:"-92";s:7:"umacron";s:3:"-92";s:7:"uogonek";s:3:"-92";s:5:"uring";s:3:"-92";}s:6:"Yacute";a:68:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:1:"O";s:3:"-15";s:6:"Oacute";s:3:"-15";s:11:"Ocircumflex";s:3:"-15";s:9:"Odieresis";s:3:"-15";s:6:"Ograve";s:3:"-15";s:13:"Ohungarumlaut";s:3:"-15";s:7:"Omacron";s:3:"-15";s:6:"Oslash";s:3:"-15";s:6:"Otilde";s:3:"-15";s:1:"a";s:3:"-92";s:6:"aacute";s:3:"-92";s:6:"abreve";s:3:"-92";s:11:"acircumflex";s:3:"-92";s:9:"adieresis";s:3:"-92";s:6:"agrave";s:3:"-92";s:7:"amacron";s:3:"-92";s:7:"aogonek";s:3:"-92";s:5:"aring";s:3:"-92";s:6:"atilde";s:3:"-92";s:5:"colon";s:3:"-65";s:5:"comma";s:3:"-92";s:1:"e";s:3:"-92";s:6:"eacute";s:3:"-92";s:6:"ecaron";s:3:"-92";s:11:"ecircumflex";s:3:"-92";s:9:"edieresis";s:3:"-52";s:10:"edotaccent";s:3:"-92";s:6:"egrave";s:3:"-52";s:7:"emacron";s:3:"-52";s:7:"eogonek";s:3:"-92";s:6:"hyphen";s:3:"-74";s:1:"i";s:3:"-74";s:6:"iacute";s:3:"-74";s:11:"icircumflex";s:3:"-34";s:9:"idieresis";s:3:"-34";s:6:"igrave";s:3:"-34";s:7:"imacron";s:3:"-34";s:7:"iogonek";s:3:"-74";s:1:"o";s:3:"-92";s:6:"oacute";s:3:"-92";s:11:"ocircumflex";s:3:"-92";s:9:"odieresis";s:3:"-92";s:6:"ograve";s:3:"-92";s:13:"ohungarumlaut";s:3:"-92";s:7:"omacron";s:3:"-92";s:6:"oslash";s:3:"-92";s:6:"otilde";s:3:"-92";s:6:"period";s:3:"-92";s:9:"semicolon";s:3:"-65";s:1:"u";s:3:"-92";s:6:"uacute";s:3:"-92";s:11:"ucircumflex";s:3:"-92";s:9:"udieresis";s:3:"-92";s:6:"ugrave";s:3:"-92";s:13:"uhungarumlaut";s:3:"-92";s:7:"umacron";s:3:"-92";s:7:"uogonek";s:3:"-92";s:5:"uring";s:3:"-92";}s:9:"Ydieresis";a:68:{s:1:"A";s:3:"-50";s:6:"Aacute";s:3:"-50";s:6:"Abreve";s:3:"-50";s:11:"Acircumflex";s:3:"-50";s:9:"Adieresis";s:3:"-50";s:6:"Agrave";s:3:"-50";s:7:"Amacron";s:3:"-50";s:7:"Aogonek";s:3:"-50";s:5:"Aring";s:3:"-50";s:6:"Atilde";s:3:"-50";s:1:"O";s:3:"-15";s:6:"Oacute";s:3:"-15";s:11:"Ocircumflex";s:3:"-15";s:9:"Odieresis";s:3:"-15";s:6:"Ograve";s:3:"-15";s:13:"Ohungarumlaut";s:3:"-15";s:7:"Omacron";s:3:"-15";s:6:"Oslash";s:3:"-15";s:6:"Otilde";s:3:"-15";s:1:"a";s:3:"-92";s:6:"aacute";s:3:"-92";s:6:"abreve";s:3:"-92";s:11:"acircumflex";s:3:"-92";s:9:"adieresis";s:3:"-92";s:6:"agrave";s:3:"-92";s:7:"amacron";s:3:"-92";s:7:"aogonek";s:3:"-92";s:5:"aring";s:3:"-92";s:6:"atilde";s:3:"-92";s:5:"colon";s:3:"-65";s:5:"comma";s:3:"-92";s:1:"e";s:3:"-92";s:6:"eacute";s:3:"-92";s:6:"ecaron";s:3:"-92";s:11:"ecircumflex";s:3:"-92";s:9:"edieresis";s:3:"-52";s:10:"edotaccent";s:3:"-92";s:6:"egrave";s:3:"-52";s:7:"emacron";s:3:"-52";s:7:"eogonek";s:3:"-92";s:6:"hyphen";s:3:"-74";s:1:"i";s:3:"-74";s:6:"iacute";s:3:"-74";s:11:"icircumflex";s:3:"-34";s:9:"idieresis";s:3:"-34";s:6:"igrave";s:3:"-34";s:7:"imacron";s:3:"-34";s:7:"iogonek";s:3:"-74";s:1:"o";s:3:"-92";s:6:"oacute";s:3:"-92";s:11:"ocircumflex";s:3:"-92";s:9:"odieresis";s:3:"-92";s:6:"ograve";s:3:"-92";s:13:"ohungarumlaut";s:3:"-92";s:7:"omacron";s:3:"-92";s:6:"oslash";s:3:"-92";s:6:"otilde";s:3:"-92";s:6:"period";s:3:"-92";s:9:"semicolon";s:3:"-65";s:1:"u";s:3:"-92";s:6:"uacute";s:3:"-92";s:11:"ucircumflex";s:3:"-92";s:9:"udieresis";s:3:"-92";s:6:"ugrave";s:3:"-92";s:13:"uhungarumlaut";s:3:"-92";s:7:"umacron";s:3:"-92";s:7:"uogonek";s:3:"-92";s:5:"uring";s:3:"-92";}s:1:"a";a:3:{s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";}s:6:"aacute";a:3:{s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";}s:6:"abreve";a:3:{s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";}s:11:"acircumflex";a:3:{s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";}s:9:"adieresis";a:3:{s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";}s:6:"agrave";a:3:{s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";}s:7:"amacron";a:3:{s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";}s:7:"aogonek";a:3:{s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";}s:5:"aring";a:3:{s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";}s:6:"atilde";a:3:{s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";}s:1:"b";a:10:{s:6:"period";s:3:"-40";s:1:"u";s:3:"-20";s:6:"uacute";s:3:"-20";s:11:"ucircumflex";s:3:"-20";s:9:"udieresis";s:3:"-20";s:6:"ugrave";s:3:"-20";s:13:"uhungarumlaut";s:3:"-20";s:7:"umacron";s:3:"-20";s:7:"uogonek";s:3:"-20";s:5:"uring";s:3:"-20";}s:1:"c";a:3:{s:1:"h";s:3:"-15";s:1:"k";s:3:"-20";s:12:"kcommaaccent";s:3:"-20";}s:6:"cacute";a:3:{s:1:"h";s:3:"-15";s:1:"k";s:3:"-20";s:12:"kcommaaccent";s:3:"-20";}s:6:"ccaron";a:3:{s:1:"h";s:3:"-15";s:1:"k";s:3:"-20";s:12:"kcommaaccent";s:3:"-20";}s:8:"ccedilla";a:3:{s:1:"h";s:3:"-15";s:1:"k";s:3:"-20";s:12:"kcommaaccent";s:3:"-20";}s:5:"comma";a:2:{s:13:"quotedblright";s:4:"-140";s:10:"quoteright";s:4:"-140";}s:1:"e";a:11:{s:5:"comma";s:3:"-10";s:1:"g";s:3:"-40";s:6:"gbreve";s:3:"-40";s:12:"gcommaaccent";s:3:"-40";s:6:"period";s:3:"-15";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-20";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:6:"eacute";a:11:{s:5:"comma";s:3:"-10";s:1:"g";s:3:"-40";s:6:"gbreve";s:3:"-40";s:12:"gcommaaccent";s:3:"-40";s:6:"period";s:3:"-15";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-20";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:6:"ecaron";a:11:{s:5:"comma";s:3:"-10";s:1:"g";s:3:"-40";s:6:"gbreve";s:3:"-40";s:12:"gcommaaccent";s:3:"-40";s:6:"period";s:3:"-15";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-20";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:11:"ecircumflex";a:11:{s:5:"comma";s:3:"-10";s:1:"g";s:3:"-40";s:6:"gbreve";s:3:"-40";s:12:"gcommaaccent";s:3:"-40";s:6:"period";s:3:"-15";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-20";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:9:"edieresis";a:11:{s:5:"comma";s:3:"-10";s:1:"g";s:3:"-40";s:6:"gbreve";s:3:"-40";s:12:"gcommaaccent";s:3:"-40";s:6:"period";s:3:"-15";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-20";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:10:"edotaccent";a:11:{s:5:"comma";s:3:"-10";s:1:"g";s:3:"-40";s:6:"gbreve";s:3:"-40";s:12:"gcommaaccent";s:3:"-40";s:6:"period";s:3:"-15";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-20";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:6:"egrave";a:11:{s:5:"comma";s:3:"-10";s:1:"g";s:3:"-40";s:6:"gbreve";s:3:"-40";s:12:"gcommaaccent";s:3:"-40";s:6:"period";s:3:"-15";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-20";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:7:"emacron";a:11:{s:5:"comma";s:3:"-10";s:1:"g";s:3:"-40";s:6:"gbreve";s:3:"-40";s:12:"gcommaaccent";s:3:"-40";s:6:"period";s:3:"-15";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-20";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:7:"eogonek";a:11:{s:5:"comma";s:3:"-10";s:1:"g";s:3:"-40";s:6:"gbreve";s:3:"-40";s:12:"gcommaaccent";s:3:"-40";s:6:"period";s:3:"-15";s:1:"v";s:3:"-15";s:1:"w";s:3:"-15";s:1:"x";s:3:"-20";s:1:"y";s:3:"-30";s:6:"yacute";s:3:"-30";s:9:"ydieresis";s:3:"-30";}s:1:"f";a:7:{s:5:"comma";s:3:"-10";s:8:"dotlessi";s:3:"-60";s:1:"f";s:3:"-18";s:1:"i";s:3:"-20";s:7:"iogonek";s:3:"-20";s:6:"period";s:3:"-15";s:10:"quoteright";s:2:"92";}s:1:"g";a:14:{s:5:"comma";s:3:"-10";s:1:"e";s:3:"-10";s:6:"eacute";s:3:"-10";s:6:"ecaron";s:3:"-10";s:11:"ecircumflex";s:3:"-10";s:9:"edieresis";s:3:"-10";s:10:"edotaccent";s:3:"-10";s:6:"egrave";s:3:"-10";s:7:"emacron";s:3:"-10";s:7:"eogonek";s:3:"-10";s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";s:6:"period";s:3:"-15";}s:6:"gbreve";a:14:{s:5:"comma";s:3:"-10";s:1:"e";s:3:"-10";s:6:"eacute";s:3:"-10";s:6:"ecaron";s:3:"-10";s:11:"ecircumflex";s:3:"-10";s:9:"edieresis";s:3:"-10";s:10:"edotaccent";s:3:"-10";s:6:"egrave";s:3:"-10";s:7:"emacron";s:3:"-10";s:7:"eogonek";s:3:"-10";s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";s:6:"period";s:3:"-15";}s:12:"gcommaaccent";a:14:{s:5:"comma";s:3:"-10";s:1:"e";s:3:"-10";s:6:"eacute";s:3:"-10";s:6:"ecaron";s:3:"-10";s:11:"ecircumflex";s:3:"-10";s:9:"edieresis";s:3:"-10";s:10:"edotaccent";s:3:"-10";s:6:"egrave";s:3:"-10";s:7:"emacron";s:3:"-10";s:7:"eogonek";s:3:"-10";s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";s:6:"period";s:3:"-15";}s:1:"k";a:21:{s:1:"e";s:3:"-10";s:6:"eacute";s:3:"-10";s:6:"ecaron";s:3:"-10";s:11:"ecircumflex";s:3:"-10";s:9:"edieresis";s:3:"-10";s:10:"edotaccent";s:3:"-10";s:6:"egrave";s:3:"-10";s:7:"emacron";s:3:"-10";s:7:"eogonek";s:3:"-10";s:1:"o";s:3:"-10";s:6:"oacute";s:3:"-10";s:11:"ocircumflex";s:3:"-10";s:9:"odieresis";s:3:"-10";s:6:"ograve";s:3:"-10";s:13:"ohungarumlaut";s:3:"-10";s:7:"omacron";s:3:"-10";s:6:"oslash";s:3:"-10";s:6:"otilde";s:3:"-10";s:1:"y";s:3:"-10";s:6:"yacute";s:3:"-10";s:9:"ydieresis";s:3:"-10";}s:12:"kcommaaccent";a:21:{s:1:"e";s:3:"-10";s:6:"eacute";s:3:"-10";s:6:"ecaron";s:3:"-10";s:11:"ecircumflex";s:3:"-10";s:9:"edieresis";s:3:"-10";s:10:"edotaccent";s:3:"-10";s:6:"egrave";s:3:"-10";s:7:"emacron";s:3:"-10";s:7:"eogonek";s:3:"-10";s:1:"o";s:3:"-10";s:6:"oacute";s:3:"-10";s:11:"ocircumflex";s:3:"-10";s:9:"odieresis";s:3:"-10";s:6:"ograve";s:3:"-10";s:13:"ohungarumlaut";s:3:"-10";s:7:"omacron";s:3:"-10";s:6:"oslash";s:3:"-10";s:6:"otilde";s:3:"-10";s:1:"y";s:3:"-10";s:6:"yacute";s:3:"-10";s:9:"ydieresis";s:3:"-10";}s:1:"n";a:1:{s:1:"v";s:3:"-40";}s:6:"nacute";a:1:{s:1:"v";s:3:"-40";}s:6:"ncaron";a:1:{s:1:"v";s:3:"-40";}s:12:"ncommaaccent";a:1:{s:1:"v";s:3:"-40";}s:6:"ntilde";a:1:{s:1:"v";s:3:"-40";}s:1:"o";a:4:{s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";s:1:"v";s:3:"-10";}s:6:"oacute";a:4:{s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";s:1:"v";s:3:"-10";}s:11:"ocircumflex";a:4:{s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";s:1:"v";s:3:"-10";}s:9:"odieresis";a:4:{s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";s:1:"v";s:3:"-10";}s:6:"ograve";a:4:{s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";s:1:"v";s:3:"-10";}s:13:"ohungarumlaut";a:4:{s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";s:1:"v";s:3:"-10";}s:7:"omacron";a:4:{s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";s:1:"v";s:3:"-10";}s:6:"oslash";a:4:{s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";s:1:"v";s:3:"-10";}s:6:"otilde";a:4:{s:1:"g";s:3:"-10";s:6:"gbreve";s:3:"-10";s:12:"gcommaaccent";s:3:"-10";s:1:"v";s:3:"-10";}s:6:"period";a:2:{s:13:"quotedblright";s:4:"-140";s:10:"quoteright";s:4:"-140";}s:9:"quoteleft";a:1:{s:9:"quoteleft";s:4:"-111";}s:10:"quoteright";a:16:{s:1:"d";s:3:"-25";s:6:"dcroat";s:3:"-25";s:10:"quoteright";s:4:"-111";s:1:"r";s:3:"-25";s:6:"racute";s:3:"-25";s:6:"rcaron";s:3:"-25";s:12:"rcommaaccent";s:3:"-25";s:1:"s";s:3:"-40";s:6:"sacute";s:3:"-40";s:6:"scaron";s:3:"-40";s:8:"scedilla";s:3:"-40";s:12:"scommaaccent";s:3:"-40";s:5:"space";s:4:"-111";s:1:"t";s:3:"-30";s:12:"tcommaaccent";s:3:"-30";s:1:"v";s:3:"-10";}s:1:"r";a:46:{s:1:"a";s:3:"-15";s:6:"aacute";s:3:"-15";s:6:"abreve";s:3:"-15";s:11:"acircumflex";s:3:"-15";s:9:"adieresis";s:3:"-15";s:6:"agrave";s:3:"-15";s:7:"amacron";s:3:"-15";s:7:"aogonek";s:3:"-15";s:5:"aring";s:3:"-15";s:6:"atilde";s:3:"-15";s:1:"c";s:3:"-37";s:6:"cacute";s:3:"-37";s:6:"ccaron";s:3:"-37";s:8:"ccedilla";s:3:"-37";s:5:"comma";s:4:"-111";s:1:"d";s:3:"-37";s:6:"dcroat";s:3:"-37";s:1:"e";s:3:"-37";s:6:"eacute";s:3:"-37";s:6:"ecaron";s:3:"-37";s:11:"ecircumflex";s:3:"-37";s:9:"edieresis";s:3:"-37";s:10:"edotaccent";s:3:"-37";s:6:"egrave";s:3:"-37";s:7:"emacron";s:3:"-37";s:7:"eogonek";s:3:"-37";s:1:"g";s:3:"-37";s:6:"gbreve";s:3:"-37";s:12:"gcommaaccent";s:3:"-37";s:6:"hyphen";s:3:"-20";s:1:"o";s:3:"-45";s:6:"oacute";s:3:"-45";s:11:"ocircumflex";s:3:"-45";s:9:"odieresis";s:3:"-45";s:6:"ograve";s:3:"-45";s:13:"ohungarumlaut";s:3:"-45";s:7:"omacron";s:3:"-45";s:6:"oslash";s:3:"-45";s:6:"otilde";s:3:"-45";s:6:"period";s:4:"-111";s:1:"q";s:3:"-37";s:1:"s";s:3:"-10";s:6:"sacute";s:3:"-10";s:6:"scaron";s:3:"-10";s:8:"scedilla";s:3:"-10";s:12:"scommaaccent";s:3:"-10";}s:6:"racute";a:46:{s:1:"a";s:3:"-15";s:6:"aacute";s:3:"-15";s:6:"abreve";s:3:"-15";s:11:"acircumflex";s:3:"-15";s:9:"adieresis";s:3:"-15";s:6:"agrave";s:3:"-15";s:7:"amacron";s:3:"-15";s:7:"aogonek";s:3:"-15";s:5:"aring";s:3:"-15";s:6:"atilde";s:3:"-15";s:1:"c";s:3:"-37";s:6:"cacute";s:3:"-37";s:6:"ccaron";s:3:"-37";s:8:"ccedilla";s:3:"-37";s:5:"comma";s:4:"-111";s:1:"d";s:3:"-37";s:6:"dcroat";s:3:"-37";s:1:"e";s:3:"-37";s:6:"eacute";s:3:"-37";s:6:"ecaron";s:3:"-37";s:11:"ecircumflex";s:3:"-37";s:9:"edieresis";s:3:"-37";s:10:"edotaccent";s:3:"-37";s:6:"egrave";s:3:"-37";s:7:"emacron";s:3:"-37";s:7:"eogonek";s:3:"-37";s:1:"g";s:3:"-37";s:6:"gbreve";s:3:"-37";s:12:"gcommaaccent";s:3:"-37";s:6:"hyphen";s:3:"-20";s:1:"o";s:3:"-45";s:6:"oacute";s:3:"-45";s:11:"ocircumflex";s:3:"-45";s:9:"odieresis";s:3:"-45";s:6:"ograve";s:3:"-45";s:13:"ohungarumlaut";s:3:"-45";s:7:"omacron";s:3:"-45";s:6:"oslash";s:3:"-45";s:6:"otilde";s:3:"-45";s:6:"period";s:4:"-111";s:1:"q";s:3:"-37";s:1:"s";s:3:"-10";s:6:"sacute";s:3:"-10";s:6:"scaron";s:3:"-10";s:8:"scedilla";s:3:"-10";s:12:"scommaaccent";s:3:"-10";}s:6:"rcaron";a:46:{s:1:"a";s:3:"-15";s:6:"aacute";s:3:"-15";s:6:"abreve";s:3:"-15";s:11:"acircumflex";s:3:"-15";s:9:"adieresis";s:3:"-15";s:6:"agrave";s:3:"-15";s:7:"amacron";s:3:"-15";s:7:"aogonek";s:3:"-15";s:5:"aring";s:3:"-15";s:6:"atilde";s:3:"-15";s:1:"c";s:3:"-37";s:6:"cacute";s:3:"-37";s:6:"ccaron";s:3:"-37";s:8:"ccedilla";s:3:"-37";s:5:"comma";s:4:"-111";s:1:"d";s:3:"-37";s:6:"dcroat";s:3:"-37";s:1:"e";s:3:"-37";s:6:"eacute";s:3:"-37";s:6:"ecaron";s:3:"-37";s:11:"ecircumflex";s:3:"-37";s:9:"edieresis";s:3:"-37";s:10:"edotaccent";s:3:"-37";s:6:"egrave";s:3:"-37";s:7:"emacron";s:3:"-37";s:7:"eogonek";s:3:"-37";s:1:"g";s:3:"-37";s:6:"gbreve";s:3:"-37";s:12:"gcommaaccent";s:3:"-37";s:6:"hyphen";s:3:"-20";s:1:"o";s:3:"-45";s:6:"oacute";s:3:"-45";s:11:"ocircumflex";s:3:"-45";s:9:"odieresis";s:3:"-45";s:6:"ograve";s:3:"-45";s:13:"ohungarumlaut";s:3:"-45";s:7:"omacron";s:3:"-45";s:6:"oslash";s:3:"-45";s:6:"otilde";s:3:"-45";s:6:"period";s:4:"-111";s:1:"q";s:3:"-37";s:1:"s";s:3:"-10";s:6:"sacute";s:3:"-10";s:6:"scaron";s:3:"-10";s:8:"scedilla";s:3:"-10";s:12:"scommaaccent";s:3:"-10";}s:12:"rcommaaccent";a:46:{s:1:"a";s:3:"-15";s:6:"aacute";s:3:"-15";s:6:"abreve";s:3:"-15";s:11:"acircumflex";s:3:"-15";s:9:"adieresis";s:3:"-15";s:6:"agrave";s:3:"-15";s:7:"amacron";s:3:"-15";s:7:"aogonek";s:3:"-15";s:5:"aring";s:3:"-15";s:6:"atilde";s:3:"-15";s:1:"c";s:3:"-37";s:6:"cacute";s:3:"-37";s:6:"ccaron";s:3:"-37";s:8:"ccedilla";s:3:"-37";s:5:"comma";s:4:"-111";s:1:"d";s:3:"-37";s:6:"dcroat";s:3:"-37";s:1:"e";s:3:"-37";s:6:"eacute";s:3:"-37";s:6:"ecaron";s:3:"-37";s:11:"ecircumflex";s:3:"-37";s:9:"edieresis";s:3:"-37";s:10:"edotaccent";s:3:"-37";s:6:"egrave";s:3:"-37";s:7:"emacron";s:3:"-37";s:7:"eogonek";s:3:"-37";s:1:"g";s:3:"-37";s:6:"gbreve";s:3:"-37";s:12:"gcommaaccent";s:3:"-37";s:6:"hyphen";s:3:"-20";s:1:"o";s:3:"-45";s:6:"oacute";s:3:"-45";s:11:"ocircumflex";s:3:"-45";s:9:"odieresis";s:3:"-45";s:6:"ograve";s:3:"-45";s:13:"ohungarumlaut";s:3:"-45";s:7:"omacron";s:3:"-45";s:6:"oslash";s:3:"-45";s:6:"otilde";s:3:"-45";s:6:"period";s:4:"-111";s:1:"q";s:3:"-37";s:1:"s";s:3:"-10";s:6:"sacute";s:3:"-10";s:6:"scaron";s:3:"-10";s:8:"scedilla";s:3:"-10";s:12:"scommaaccent";s:3:"-10";}s:5:"space";a:18:{s:1:"A";s:3:"-18";s:6:"Aacute";s:3:"-18";s:6:"Abreve";s:3:"-18";s:11:"Acircumflex";s:3:"-18";s:9:"Adieresis";s:3:"-18";s:6:"Agrave";s:3:"-18";s:7:"Amacron";s:3:"-18";s:7:"Aogonek";s:3:"-18";s:5:"Aring";s:3:"-18";s:6:"Atilde";s:3:"-18";s:1:"T";s:3:"-18";s:6:"Tcaron";s:3:"-18";s:12:"Tcommaaccent";s:3:"-18";s:1:"V";s:3:"-35";s:1:"W";s:3:"-40";s:1:"Y";s:3:"-75";s:6:"Yacute";s:3:"-75";s:9:"Ydieresis";s:3:"-75";}s:1:"v";a:2:{s:5:"comma";s:3:"-74";s:6:"period";s:3:"-74";}s:1:"w";a:2:{s:5:"comma";s:3:"-74";s:6:"period";s:3:"-74";}s:1:"y";a:2:{s:5:"comma";s:3:"-55";s:6:"period";s:3:"-55";}s:6:"yacute";a:2:{s:5:"comma";s:3:"-55";s:6:"period";s:3:"-55";}s:9:"ydieresis";a:2:{s:5:"comma";s:3:"-55";s:6:"period";s:3:"-55";}}s:9:"_version_";i:1;}
\ No newline at end of file
Added: trunk/mapbender/http/classes/fonts/php_ZapfDingbats.afm
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/fonts/php_ZapfDingbats.afm?view=auto&rev=54
--- (empty file)
+++ trunk/mapbender/http/classes/fonts/php_ZapfDingbats.afm	2006-04-13 21:05:53+0000
@@ -0,0 +1 @@
+a:17:{s:8:"FontName";s:12:"ZapfDingbats";s:8:"FullName";s:17:"ITC Zapf Dingbats";s:10:"FamilyName";s:12:"ZapfDingbats";s:6:"Weight";s:6:"Medium";s:11:"ItalicAngle";s:1:"0";s:12:"IsFixedPitch";s:5:"false";s:12:"CharacterSet";s:7:"Special";s:8:"FontBBox";a:4:{i:0;s:2:"-1";i:1;s:4:"-143";i:2;s:3:"981";i:3;s:3:"820";}s:17:"UnderlinePosition";s:4:"-100";s:18:"UnderlineThickness";s:2:"50";s:7:"Version";s:7:"002.000";s:14:"EncodingScheme";s:12:"FontSpecific";s:5:"StdHW";s:2:"28";s:5:"StdVW";s:2:"90";s:16:"StartCharMetrics";s:3:"202";s:1:"C";a:404:{i:32;a:4:{s:1:"C";s:2:"32";s:2:"WX";s:3:"278";s:1:"N";s:5:"space";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}s:5:"space";a:4:{s:1:"C";s:2:"32";s:2:"WX";s:3:"278";s:1:"N";s:5:"space";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:1:"0";i:2;s:1:"0";i:3;s:1:"0";}}i:33;a:4:{s:1:"C";s:2:"33";s:2:"WX";s:3:"974";s:1:"N";s:2:"a1";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"72";i:2;s:3:"939";i:3;s:3:"621";}}s:2:"a1";a:4:{s:1:"C";s:2:"33";s:2:"WX";s:3:"974";s:1:"N";s:2:"a1";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"72";i:2;s:3:"939";i:3;s:3:"621";}}i:34;a:4:{s:1:"C";s:2:"34";s:2:"WX";s:3:"961";s:1:"N";s:2:"a2";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"81";i:2;s:3:"927";i:3;s:3:"611";}}s:2:"a2";a:4:{s:1:"C";s:2:"34";s:2:"WX";s:3:"961";s:1:"N";s:2:"a2";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"81";i:2;s:3:"927";i:3;s:3:"611";}}i:35;a:4:{s:1:"C";s:2:"35";s:2:"WX";s:3:"974";s:1:"N";s:4:"a202";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"72";i:2;s:3:"939";i:3;s:3:"621";}}s:4:"a202";a:4:{s:1:"C";s:2:"35";s:2:"WX";s:3:"974";s:1:"N";s:4:"a202";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"72";i:2;s:3:"939";i:3;s:3:"621";}}i:36;a:4:{s:1:"C";s:2:"36";s:2:"WX";s:3:"980";s:1:"N";s:2:"a3";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"945";i:3;s:3:"692";}}s:2:"a3";a:4:{s:1:"C";s:2:"36";s:2:"WX";s:3:"980";s:1:"N";s:2:"a3";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"945";i:3;s:3:"692";}}i:37;a:4:{s:1:"C";s:2:"37";s:2:"WX";s:3:"719";s:1:"N";s:2:"a4";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"139";i:2;s:3:"685";i:3;s:3:"566";}}s:2:"a4";a:4:{s:1:"C";s:2:"37";s:2:"WX";s:3:"719";s:1:"N";s:2:"a4";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"139";i:2;s:3:"685";i:3;s:3:"566";}}i:38;a:4:{s:1:"C";s:2:"38";s:2:"WX";s:3:"789";s:1:"N";s:2:"a5";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"755";i:3;s:3:"705";}}s:2:"a5";a:4:{s:1:"C";s:2:"38";s:2:"WX";s:3:"789";s:1:"N";s:2:"a5";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"755";i:3;s:3:"705";}}i:39;a:4:{s:1:"C";s:2:"39";s:2:"WX";s:3:"790";s:1:"N";s:4:"a119";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"755";i:3;s:3:"705";}}s:4:"a119";a:4:{s:1:"C";s:2:"39";s:2:"WX";s:3:"790";s:1:"N";s:4:"a119";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"755";i:3;s:3:"705";}}i:40;a:4:{s:1:"C";s:2:"40";s:2:"WX";s:3:"791";s:1:"N";s:4:"a118";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-13";i:2;s:3:"761";i:3;s:3:"705";}}s:4:"a118";a:4:{s:1:"C";s:2:"40";s:2:"WX";s:3:"791";s:1:"N";s:4:"a118";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-13";i:2;s:3:"761";i:3;s:3:"705";}}i:41;a:4:{s:1:"C";s:2:"41";s:2:"WX";s:3:"690";s:1:"N";s:4:"a117";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"138";i:2;s:3:"655";i:3;s:3:"553";}}s:4:"a117";a:4:{s:1:"C";s:2:"41";s:2:"WX";s:3:"690";s:1:"N";s:4:"a117";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"138";i:2;s:3:"655";i:3;s:3:"553";}}i:42;a:4:{s:1:"C";s:2:"42";s:2:"WX";s:3:"960";s:1:"N";s:3:"a11";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"123";i:2;s:3:"925";i:3;s:3:"568";}}s:3:"a11";a:4:{s:1:"C";s:2:"42";s:2:"WX";s:3:"960";s:1:"N";s:3:"a11";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"123";i:2;s:3:"925";i:3;s:3:"568";}}i:43;a:4:{s:1:"C";s:2:"43";s:2:"WX";s:3:"939";s:1:"N";s:3:"a12";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"134";i:2;s:3:"904";i:3;s:3:"559";}}s:3:"a12";a:4:{s:1:"C";s:2:"43";s:2:"WX";s:3:"939";s:1:"N";s:3:"a12";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"134";i:2;s:3:"904";i:3;s:3:"559";}}i:44;a:4:{s:1:"C";s:2:"44";s:2:"WX";s:3:"549";s:1:"N";s:3:"a13";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:3:"-11";i:2;s:3:"516";i:3;s:3:"705";}}s:3:"a13";a:4:{s:1:"C";s:2:"44";s:2:"WX";s:3:"549";s:1:"N";s:3:"a13";s:1:"B";a:4:{i:0;s:2:"29";i:1;s:3:"-11";i:2;s:3:"516";i:3;s:3:"705";}}i:45;a:4:{s:1:"C";s:2:"45";s:2:"WX";s:3:"855";s:1:"N";s:3:"a14";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:2:"59";i:2;s:3:"820";i:3;s:3:"632";}}s:3:"a14";a:4:{s:1:"C";s:2:"45";s:2:"WX";s:3:"855";s:1:"N";s:3:"a14";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:2:"59";i:2;s:3:"820";i:3;s:3:"632";}}i:46;a:4:{s:1:"C";s:2:"46";s:2:"WX";s:3:"911";s:1:"N";s:3:"a15";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"50";i:2;s:3:"876";i:3;s:3:"642";}}s:3:"a15";a:4:{s:1:"C";s:2:"46";s:2:"WX";s:3:"911";s:1:"N";s:3:"a15";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"50";i:2;s:3:"876";i:3;s:3:"642";}}i:47;a:4:{s:1:"C";s:2:"47";s:2:"WX";s:3:"933";s:1:"N";s:3:"a16";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"139";i:2;s:3:"899";i:3;s:3:"550";}}s:3:"a16";a:4:{s:1:"C";s:2:"47";s:2:"WX";s:3:"933";s:1:"N";s:3:"a16";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"139";i:2;s:3:"899";i:3;s:3:"550";}}i:48;a:4:{s:1:"C";s:2:"48";s:2:"WX";s:3:"911";s:1:"N";s:4:"a105";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"50";i:2;s:3:"876";i:3;s:3:"642";}}s:4:"a105";a:4:{s:1:"C";s:2:"48";s:2:"WX";s:3:"911";s:1:"N";s:4:"a105";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"50";i:2;s:3:"876";i:3;s:3:"642";}}i:49;a:4:{s:1:"C";s:2:"49";s:2:"WX";s:3:"945";s:1:"N";s:3:"a17";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"139";i:2;s:3:"909";i:3;s:3:"553";}}s:3:"a17";a:4:{s:1:"C";s:2:"49";s:2:"WX";s:3:"945";s:1:"N";s:3:"a17";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"139";i:2;s:3:"909";i:3;s:3:"553";}}i:50;a:4:{s:1:"C";s:2:"50";s:2:"WX";s:3:"974";s:1:"N";s:3:"a18";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"104";i:2;s:3:"938";i:3;s:3:"587";}}s:3:"a18";a:4:{s:1:"C";s:2:"50";s:2:"WX";s:3:"974";s:1:"N";s:3:"a18";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"104";i:2;s:3:"938";i:3;s:3:"587";}}i:51;a:4:{s:1:"C";s:2:"51";s:2:"WX";s:3:"755";s:1:"N";s:3:"a19";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-13";i:2;s:3:"721";i:3;s:3:"705";}}s:3:"a19";a:4:{s:1:"C";s:2:"51";s:2:"WX";s:3:"755";s:1:"N";s:3:"a19";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-13";i:2;s:3:"721";i:3;s:3:"705";}}i:52;a:4:{s:1:"C";s:2:"52";s:2:"WX";s:3:"846";s:1:"N";s:3:"a20";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:3:"-14";i:2;s:3:"811";i:3;s:3:"705";}}s:3:"a20";a:4:{s:1:"C";s:2:"52";s:2:"WX";s:3:"846";s:1:"N";s:3:"a20";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:3:"-14";i:2;s:3:"811";i:3;s:3:"705";}}i:53;a:4:{s:1:"C";s:2:"53";s:2:"WX";s:3:"762";s:1:"N";s:3:"a21";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"727";i:3;s:3:"692";}}s:3:"a21";a:4:{s:1:"C";s:2:"53";s:2:"WX";s:3:"762";s:1:"N";s:3:"a21";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"727";i:3;s:3:"692";}}i:54;a:4:{s:1:"C";s:2:"54";s:2:"WX";s:3:"761";s:1:"N";s:3:"a22";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"727";i:3;s:3:"692";}}s:3:"a22";a:4:{s:1:"C";s:2:"54";s:2:"WX";s:3:"761";s:1:"N";s:3:"a22";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"727";i:3;s:3:"692";}}i:55;a:4:{s:1:"C";s:2:"55";s:2:"WX";s:3:"571";s:1:"N";s:3:"a23";s:1:"B";a:4:{i:0;s:2:"-1";i:1;s:3:"-68";i:2;s:3:"571";i:3;s:3:"661";}}s:3:"a23";a:4:{s:1:"C";s:2:"55";s:2:"WX";s:3:"571";s:1:"N";s:3:"a23";s:1:"B";a:4:{i:0;s:2:"-1";i:1;s:3:"-68";i:2;s:3:"571";i:3;s:3:"661";}}i:56;a:4:{s:1:"C";s:2:"56";s:2:"WX";s:3:"677";s:1:"N";s:3:"a24";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:3:"-13";i:2;s:3:"642";i:3;s:3:"705";}}s:3:"a24";a:4:{s:1:"C";s:2:"56";s:2:"WX";s:3:"677";s:1:"N";s:3:"a24";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:3:"-13";i:2;s:3:"642";i:3;s:3:"705";}}i:57;a:4:{s:1:"C";s:2:"57";s:2:"WX";s:3:"763";s:1:"N";s:3:"a25";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"728";i:3;s:3:"692";}}s:3:"a25";a:4:{s:1:"C";s:2:"57";s:2:"WX";s:3:"763";s:1:"N";s:3:"a25";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"728";i:3;s:3:"692";}}i:58;a:4:{s:1:"C";s:2:"58";s:2:"WX";s:3:"760";s:1:"N";s:3:"a26";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"726";i:3;s:3:"692";}}s:3:"a26";a:4:{s:1:"C";s:2:"58";s:2:"WX";s:3:"760";s:1:"N";s:3:"a26";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"726";i:3;s:3:"692";}}i:59;a:4:{s:1:"C";s:2:"59";s:2:"WX";s:3:"759";s:1:"N";s:3:"a27";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"725";i:3;s:3:"692";}}s:3:"a27";a:4:{s:1:"C";s:2:"59";s:2:"WX";s:3:"759";s:1:"N";s:3:"a27";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"725";i:3;s:3:"692";}}i:60;a:4:{s:1:"C";s:2:"60";s:2:"WX";s:3:"754";s:1:"N";s:3:"a28";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"720";i:3;s:3:"692";}}s:3:"a28";a:4:{s:1:"C";s:2:"60";s:2:"WX";s:3:"754";s:1:"N";s:3:"a28";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"720";i:3;s:3:"692";}}i:61;a:4:{s:1:"C";s:2:"61";s:2:"WX";s:3:"494";s:1:"N";s:2:"a6";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"460";i:3;s:3:"692";}}s:2:"a6";a:4:{s:1:"C";s:2:"61";s:2:"WX";s:3:"494";s:1:"N";s:2:"a6";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"460";i:3;s:3:"692";}}i:62;a:4:{s:1:"C";s:2:"62";s:2:"WX";s:3:"552";s:1:"N";s:2:"a7";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"517";i:3;s:3:"692";}}s:2:"a7";a:4:{s:1:"C";s:2:"62";s:2:"WX";s:3:"552";s:1:"N";s:2:"a7";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"517";i:3;s:3:"692";}}i:63;a:4:{s:1:"C";s:2:"63";s:2:"WX";s:3:"537";s:1:"N";s:2:"a8";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"503";i:3;s:3:"692";}}s:2:"a8";a:4:{s:1:"C";s:2:"63";s:2:"WX";s:3:"537";s:1:"N";s:2:"a8";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"503";i:3;s:3:"692";}}i:64;a:4:{s:1:"C";s:2:"64";s:2:"WX";s:3:"577";s:1:"N";s:2:"a9";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"96";i:2;s:3:"542";i:3;s:3:"596";}}s:2:"a9";a:4:{s:1:"C";s:2:"64";s:2:"WX";s:3:"577";s:1:"N";s:2:"a9";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"96";i:2;s:3:"542";i:3;s:3:"596";}}i:65;a:4:{s:1:"C";s:2:"65";s:2:"WX";s:3:"692";s:1:"N";s:3:"a10";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"657";i:3;s:3:"705";}}s:3:"a10";a:4:{s:1:"C";s:2:"65";s:2:"WX";s:3:"692";s:1:"N";s:3:"a10";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"657";i:3;s:3:"705";}}i:66;a:4:{s:1:"C";s:2:"66";s:2:"WX";s:3:"786";s:1:"N";s:3:"a29";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"751";i:3;s:3:"705";}}s:3:"a29";a:4:{s:1:"C";s:2:"66";s:2:"WX";s:3:"786";s:1:"N";s:3:"a29";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"751";i:3;s:3:"705";}}i:67;a:4:{s:1:"C";s:2:"67";s:2:"WX";s:3:"788";s:1:"N";s:3:"a30";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"752";i:3;s:3:"705";}}s:3:"a30";a:4:{s:1:"C";s:2:"67";s:2:"WX";s:3:"788";s:1:"N";s:3:"a30";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"752";i:3;s:3:"705";}}i:68;a:4:{s:1:"C";s:2:"68";s:2:"WX";s:3:"788";s:1:"N";s:3:"a31";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"753";i:3;s:3:"705";}}s:3:"a31";a:4:{s:1:"C";s:2:"68";s:2:"WX";s:3:"788";s:1:"N";s:3:"a31";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"753";i:3;s:3:"705";}}i:69;a:4:{s:1:"C";s:2:"69";s:2:"WX";s:3:"790";s:1:"N";s:3:"a32";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"756";i:3;s:3:"705";}}s:3:"a32";a:4:{s:1:"C";s:2:"69";s:2:"WX";s:3:"790";s:1:"N";s:3:"a32";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"756";i:3;s:3:"705";}}i:70;a:4:{s:1:"C";s:2:"70";s:2:"WX";s:3:"793";s:1:"N";s:3:"a33";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-13";i:2;s:3:"759";i:3;s:3:"705";}}s:3:"a33";a:4:{s:1:"C";s:2:"70";s:2:"WX";s:3:"793";s:1:"N";s:3:"a33";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-13";i:2;s:3:"759";i:3;s:3:"705";}}i:71;a:4:{s:1:"C";s:2:"71";s:2:"WX";s:3:"794";s:1:"N";s:3:"a34";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-13";i:2;s:3:"759";i:3;s:3:"705";}}s:3:"a34";a:4:{s:1:"C";s:2:"71";s:2:"WX";s:3:"794";s:1:"N";s:3:"a34";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-13";i:2;s:3:"759";i:3;s:3:"705";}}i:72;a:4:{s:1:"C";s:2:"72";s:2:"WX";s:3:"816";s:1:"N";s:3:"a35";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"782";i:3;s:3:"705";}}s:3:"a35";a:4:{s:1:"C";s:2:"72";s:2:"WX";s:3:"816";s:1:"N";s:3:"a35";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"782";i:3;s:3:"705";}}i:73;a:4:{s:1:"C";s:2:"73";s:2:"WX";s:3:"823";s:1:"N";s:3:"a36";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"787";i:3;s:3:"705";}}s:3:"a36";a:4:{s:1:"C";s:2:"73";s:2:"WX";s:3:"823";s:1:"N";s:3:"a36";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"787";i:3;s:3:"705";}}i:74;a:4:{s:1:"C";s:2:"74";s:2:"WX";s:3:"789";s:1:"N";s:3:"a37";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:3:"a37";a:4:{s:1:"C";s:2:"74";s:2:"WX";s:3:"789";s:1:"N";s:3:"a37";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:75;a:4:{s:1:"C";s:2:"75";s:2:"WX";s:3:"841";s:1:"N";s:3:"a38";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"807";i:3;s:3:"705";}}s:3:"a38";a:4:{s:1:"C";s:2:"75";s:2:"WX";s:3:"841";s:1:"N";s:3:"a38";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"807";i:3;s:3:"705";}}i:76;a:4:{s:1:"C";s:2:"76";s:2:"WX";s:3:"823";s:1:"N";s:3:"a39";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"789";i:3;s:3:"705";}}s:3:"a39";a:4:{s:1:"C";s:2:"76";s:2:"WX";s:3:"823";s:1:"N";s:3:"a39";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"789";i:3;s:3:"705";}}i:77;a:4:{s:1:"C";s:2:"77";s:2:"WX";s:3:"833";s:1:"N";s:3:"a40";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"798";i:3;s:3:"705";}}s:3:"a40";a:4:{s:1:"C";s:2:"77";s:2:"WX";s:3:"833";s:1:"N";s:3:"a40";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"798";i:3;s:3:"705";}}i:78;a:4:{s:1:"C";s:2:"78";s:2:"WX";s:3:"816";s:1:"N";s:3:"a41";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-13";i:2;s:3:"782";i:3;s:3:"705";}}s:3:"a41";a:4:{s:1:"C";s:2:"78";s:2:"WX";s:3:"816";s:1:"N";s:3:"a41";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-13";i:2;s:3:"782";i:3;s:3:"705";}}i:79;a:4:{s:1:"C";s:2:"79";s:2:"WX";s:3:"831";s:1:"N";s:3:"a42";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"796";i:3;s:3:"705";}}s:3:"a42";a:4:{s:1:"C";s:2:"79";s:2:"WX";s:3:"831";s:1:"N";s:3:"a42";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"796";i:3;s:3:"705";}}i:80;a:4:{s:1:"C";s:2:"80";s:2:"WX";s:3:"923";s:1:"N";s:3:"a43";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"888";i:3;s:3:"705";}}s:3:"a43";a:4:{s:1:"C";s:2:"80";s:2:"WX";s:3:"923";s:1:"N";s:3:"a43";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"888";i:3;s:3:"705";}}i:81;a:4:{s:1:"C";s:2:"81";s:2:"WX";s:3:"744";s:1:"N";s:3:"a44";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"710";i:3;s:3:"692";}}s:3:"a44";a:4:{s:1:"C";s:2:"81";s:2:"WX";s:3:"744";s:1:"N";s:3:"a44";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"710";i:3;s:3:"692";}}i:82;a:4:{s:1:"C";s:2:"82";s:2:"WX";s:3:"723";s:1:"N";s:3:"a45";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"688";i:3;s:3:"692";}}s:3:"a45";a:4:{s:1:"C";s:2:"82";s:2:"WX";s:3:"723";s:1:"N";s:3:"a45";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"688";i:3;s:3:"692";}}i:83;a:4:{s:1:"C";s:2:"83";s:2:"WX";s:3:"749";s:1:"N";s:3:"a46";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"714";i:3;s:3:"692";}}s:3:"a46";a:4:{s:1:"C";s:2:"83";s:2:"WX";s:3:"749";s:1:"N";s:3:"a46";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"714";i:3;s:3:"692";}}i:84;a:4:{s:1:"C";s:2:"84";s:2:"WX";s:3:"790";s:1:"N";s:3:"a47";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"756";i:3;s:3:"705";}}s:3:"a47";a:4:{s:1:"C";s:2:"84";s:2:"WX";s:3:"790";s:1:"N";s:3:"a47";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"756";i:3;s:3:"705";}}i:85;a:4:{s:1:"C";s:2:"85";s:2:"WX";s:3:"792";s:1:"N";s:3:"a48";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"758";i:3;s:3:"705";}}s:3:"a48";a:4:{s:1:"C";s:2:"85";s:2:"WX";s:3:"792";s:1:"N";s:3:"a48";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"758";i:3;s:3:"705";}}i:86;a:4:{s:1:"C";s:2:"86";s:2:"WX";s:3:"695";s:1:"N";s:3:"a49";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"661";i:3;s:3:"706";}}s:3:"a49";a:4:{s:1:"C";s:2:"86";s:2:"WX";s:3:"695";s:1:"N";s:3:"a49";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"661";i:3;s:3:"706";}}i:87;a:4:{s:1:"C";s:2:"87";s:2:"WX";s:3:"776";s:1:"N";s:3:"a50";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"-6";i:2;s:3:"741";i:3;s:3:"699";}}s:3:"a50";a:4:{s:1:"C";s:2:"87";s:2:"WX";s:3:"776";s:1:"N";s:3:"a50";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"-6";i:2;s:3:"741";i:3;s:3:"699";}}i:88;a:4:{s:1:"C";s:2:"88";s:2:"WX";s:3:"768";s:1:"N";s:3:"a51";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"-7";i:2;s:3:"734";i:3;s:3:"699";}}s:3:"a51";a:4:{s:1:"C";s:2:"88";s:2:"WX";s:3:"768";s:1:"N";s:3:"a51";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"-7";i:2;s:3:"734";i:3;s:3:"699";}}i:89;a:4:{s:1:"C";s:2:"89";s:2:"WX";s:3:"792";s:1:"N";s:3:"a52";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"757";i:3;s:3:"705";}}s:3:"a52";a:4:{s:1:"C";s:2:"89";s:2:"WX";s:3:"792";s:1:"N";s:3:"a52";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"757";i:3;s:3:"705";}}i:90;a:4:{s:1:"C";s:2:"90";s:2:"WX";s:3:"759";s:1:"N";s:3:"a53";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"725";i:3;s:3:"692";}}s:3:"a53";a:4:{s:1:"C";s:2:"90";s:2:"WX";s:3:"759";s:1:"N";s:3:"a53";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"725";i:3;s:3:"692";}}i:91;a:4:{s:1:"C";s:2:"91";s:2:"WX";s:3:"707";s:1:"N";s:3:"a54";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-13";i:2;s:3:"672";i:3;s:3:"704";}}s:3:"a54";a:4:{s:1:"C";s:2:"91";s:2:"WX";s:3:"707";s:1:"N";s:3:"a54";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-13";i:2;s:3:"672";i:3;s:3:"704";}}i:92;a:4:{s:1:"C";s:2:"92";s:2:"WX";s:3:"708";s:1:"N";s:3:"a55";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"672";i:3;s:3:"705";}}s:3:"a55";a:4:{s:1:"C";s:2:"92";s:2:"WX";s:3:"708";s:1:"N";s:3:"a55";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"672";i:3;s:3:"705";}}i:93;a:4:{s:1:"C";s:2:"93";s:2:"WX";s:3:"682";s:1:"N";s:3:"a56";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"647";i:3;s:3:"705";}}s:3:"a56";a:4:{s:1:"C";s:2:"93";s:2:"WX";s:3:"682";s:1:"N";s:3:"a56";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"647";i:3;s:3:"705";}}i:94;a:4:{s:1:"C";s:2:"94";s:2:"WX";s:3:"701";s:1:"N";s:3:"a57";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"666";i:3;s:3:"705";}}s:3:"a57";a:4:{s:1:"C";s:2:"94";s:2:"WX";s:3:"701";s:1:"N";s:3:"a57";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"666";i:3;s:3:"705";}}i:95;a:4:{s:1:"C";s:2:"95";s:2:"WX";s:3:"826";s:1:"N";s:3:"a58";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"791";i:3;s:3:"705";}}s:3:"a58";a:4:{s:1:"C";s:2:"95";s:2:"WX";s:3:"826";s:1:"N";s:3:"a58";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"791";i:3;s:3:"705";}}i:96;a:4:{s:1:"C";s:2:"96";s:2:"WX";s:3:"815";s:1:"N";s:3:"a59";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"780";i:3;s:3:"705";}}s:3:"a59";a:4:{s:1:"C";s:2:"96";s:2:"WX";s:3:"815";s:1:"N";s:3:"a59";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"780";i:3;s:3:"705";}}i:97;a:4:{s:1:"C";s:2:"97";s:2:"WX";s:3:"789";s:1:"N";s:3:"a60";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:3:"a60";a:4:{s:1:"C";s:2:"97";s:2:"WX";s:3:"789";s:1:"N";s:3:"a60";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:98;a:4:{s:1:"C";s:2:"98";s:2:"WX";s:3:"789";s:1:"N";s:3:"a61";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:3:"a61";a:4:{s:1:"C";s:2:"98";s:2:"WX";s:3:"789";s:1:"N";s:3:"a61";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:99;a:4:{s:1:"C";s:2:"99";s:2:"WX";s:3:"707";s:1:"N";s:3:"a62";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"673";i:3;s:3:"705";}}s:3:"a62";a:4:{s:1:"C";s:2:"99";s:2:"WX";s:3:"707";s:1:"N";s:3:"a62";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"673";i:3;s:3:"705";}}i:100;a:4:{s:1:"C";s:3:"100";s:2:"WX";s:3:"687";s:1:"N";s:3:"a63";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:1:"0";i:2;s:3:"651";i:3;s:3:"692";}}s:3:"a63";a:4:{s:1:"C";s:3:"100";s:2:"WX";s:3:"687";s:1:"N";s:3:"a63";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:1:"0";i:2;s:3:"651";i:3;s:3:"692";}}i:101;a:4:{s:1:"C";s:3:"101";s:2:"WX";s:3:"696";s:1:"N";s:3:"a64";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"661";i:3;s:3:"691";}}s:3:"a64";a:4:{s:1:"C";s:3:"101";s:2:"WX";s:3:"696";s:1:"N";s:3:"a64";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"661";i:3;s:3:"691";}}i:102;a:4:{s:1:"C";s:3:"102";s:2:"WX";s:3:"689";s:1:"N";s:3:"a65";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"655";i:3;s:3:"692";}}s:3:"a65";a:4:{s:1:"C";s:3:"102";s:2:"WX";s:3:"689";s:1:"N";s:3:"a65";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"655";i:3;s:3:"692";}}i:103;a:4:{s:1:"C";s:3:"103";s:2:"WX";s:3:"786";s:1:"N";s:3:"a66";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"751";i:3;s:3:"705";}}s:3:"a66";a:4:{s:1:"C";s:3:"103";s:2:"WX";s:3:"786";s:1:"N";s:3:"a66";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"751";i:3;s:3:"705";}}i:104;a:4:{s:1:"C";s:3:"104";s:2:"WX";s:3:"787";s:1:"N";s:3:"a67";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"752";i:3;s:3:"705";}}s:3:"a67";a:4:{s:1:"C";s:3:"104";s:2:"WX";s:3:"787";s:1:"N";s:3:"a67";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"752";i:3;s:3:"705";}}i:105;a:4:{s:1:"C";s:3:"105";s:2:"WX";s:3:"713";s:1:"N";s:3:"a68";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"678";i:3;s:3:"705";}}s:3:"a68";a:4:{s:1:"C";s:3:"105";s:2:"WX";s:3:"713";s:1:"N";s:3:"a68";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"678";i:3;s:3:"705";}}i:106;a:4:{s:1:"C";s:3:"106";s:2:"WX";s:3:"791";s:1:"N";s:3:"a69";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"756";i:3;s:3:"705";}}s:3:"a69";a:4:{s:1:"C";s:3:"106";s:2:"WX";s:3:"791";s:1:"N";s:3:"a69";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"756";i:3;s:3:"705";}}i:107;a:4:{s:1:"C";s:3:"107";s:2:"WX";s:3:"785";s:1:"N";s:3:"a70";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:3:"-14";i:2;s:3:"751";i:3;s:3:"705";}}s:3:"a70";a:4:{s:1:"C";s:3:"107";s:2:"WX";s:3:"785";s:1:"N";s:3:"a70";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:3:"-14";i:2;s:3:"751";i:3;s:3:"705";}}i:108;a:4:{s:1:"C";s:3:"108";s:2:"WX";s:3:"791";s:1:"N";s:3:"a71";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"757";i:3;s:3:"705";}}s:3:"a71";a:4:{s:1:"C";s:3:"108";s:2:"WX";s:3:"791";s:1:"N";s:3:"a71";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"757";i:3;s:3:"705";}}i:109;a:4:{s:1:"C";s:3:"109";s:2:"WX";s:3:"873";s:1:"N";s:3:"a72";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"838";i:3;s:3:"705";}}s:3:"a72";a:4:{s:1:"C";s:3:"109";s:2:"WX";s:3:"873";s:1:"N";s:3:"a72";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"838";i:3;s:3:"705";}}i:110;a:4:{s:1:"C";s:3:"110";s:2:"WX";s:3:"761";s:1:"N";s:3:"a73";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"726";i:3;s:3:"692";}}s:3:"a73";a:4:{s:1:"C";s:3:"110";s:2:"WX";s:3:"761";s:1:"N";s:3:"a73";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"726";i:3;s:3:"692";}}i:111;a:4:{s:1:"C";s:3:"111";s:2:"WX";s:3:"762";s:1:"N";s:3:"a74";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"727";i:3;s:3:"692";}}s:3:"a74";a:4:{s:1:"C";s:3:"111";s:2:"WX";s:3:"762";s:1:"N";s:3:"a74";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"727";i:3;s:3:"692";}}i:112;a:4:{s:1:"C";s:3:"112";s:2:"WX";s:3:"762";s:1:"N";s:4:"a203";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"727";i:3;s:3:"692";}}s:4:"a203";a:4:{s:1:"C";s:3:"112";s:2:"WX";s:3:"762";s:1:"N";s:4:"a203";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"727";i:3;s:3:"692";}}i:113;a:4:{s:1:"C";s:3:"113";s:2:"WX";s:3:"759";s:1:"N";s:3:"a75";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"725";i:3;s:3:"692";}}s:3:"a75";a:4:{s:1:"C";s:3:"113";s:2:"WX";s:3:"759";s:1:"N";s:3:"a75";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"725";i:3;s:3:"692";}}i:114;a:4:{s:1:"C";s:3:"114";s:2:"WX";s:3:"759";s:1:"N";s:4:"a204";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"725";i:3;s:3:"692";}}s:4:"a204";a:4:{s:1:"C";s:3:"114";s:2:"WX";s:3:"759";s:1:"N";s:4:"a204";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"725";i:3;s:3:"692";}}i:115;a:4:{s:1:"C";s:3:"115";s:2:"WX";s:3:"892";s:1:"N";s:3:"a76";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"858";i:3;s:3:"705";}}s:3:"a76";a:4:{s:1:"C";s:3:"115";s:2:"WX";s:3:"892";s:1:"N";s:3:"a76";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"858";i:3;s:3:"705";}}i:116;a:4:{s:1:"C";s:3:"116";s:2:"WX";s:3:"892";s:1:"N";s:3:"a77";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"858";i:3;s:3:"692";}}s:3:"a77";a:4:{s:1:"C";s:3:"116";s:2:"WX";s:3:"892";s:1:"N";s:3:"a77";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"858";i:3;s:3:"692";}}i:117;a:4:{s:1:"C";s:3:"117";s:2:"WX";s:3:"788";s:1:"N";s:3:"a78";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:3:"a78";a:4:{s:1:"C";s:3:"117";s:2:"WX";s:3:"788";s:1:"N";s:3:"a78";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:118;a:4:{s:1:"C";s:3:"118";s:2:"WX";s:3:"784";s:1:"N";s:3:"a79";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"749";i:3;s:3:"705";}}s:3:"a79";a:4:{s:1:"C";s:3:"118";s:2:"WX";s:3:"784";s:1:"N";s:3:"a79";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"749";i:3;s:3:"705";}}i:119;a:4:{s:1:"C";s:3:"119";s:2:"WX";s:3:"438";s:1:"N";s:3:"a81";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"403";i:3;s:3:"705";}}s:3:"a81";a:4:{s:1:"C";s:3:"119";s:2:"WX";s:3:"438";s:1:"N";s:3:"a81";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"403";i:3;s:3:"705";}}i:120;a:4:{s:1:"C";s:3:"120";s:2:"WX";s:3:"138";s:1:"N";s:3:"a82";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"104";i:3;s:3:"692";}}s:3:"a82";a:4:{s:1:"C";s:3:"120";s:2:"WX";s:3:"138";s:1:"N";s:3:"a82";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"104";i:3;s:3:"692";}}i:121;a:4:{s:1:"C";s:3:"121";s:2:"WX";s:3:"277";s:1:"N";s:3:"a83";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"242";i:3;s:3:"692";}}s:3:"a83";a:4:{s:1:"C";s:3:"121";s:2:"WX";s:3:"277";s:1:"N";s:3:"a83";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"242";i:3;s:3:"692";}}i:122;a:4:{s:1:"C";s:3:"122";s:2:"WX";s:3:"415";s:1:"N";s:3:"a84";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"380";i:3;s:3:"692";}}s:3:"a84";a:4:{s:1:"C";s:3:"122";s:2:"WX";s:3:"415";s:1:"N";s:3:"a84";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"380";i:3;s:3:"692";}}i:123;a:4:{s:1:"C";s:3:"123";s:2:"WX";s:3:"392";s:1:"N";s:3:"a97";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"263";i:2;s:3:"357";i:3;s:3:"705";}}s:3:"a97";a:4:{s:1:"C";s:3:"123";s:2:"WX";s:3:"392";s:1:"N";s:3:"a97";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"263";i:2;s:3:"357";i:3;s:3:"705";}}i:124;a:4:{s:1:"C";s:3:"124";s:2:"WX";s:3:"392";s:1:"N";s:3:"a98";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"263";i:2;s:3:"357";i:3;s:3:"705";}}s:3:"a98";a:4:{s:1:"C";s:3:"124";s:2:"WX";s:3:"392";s:1:"N";s:3:"a98";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"263";i:2;s:3:"357";i:3;s:3:"705";}}i:125;a:4:{s:1:"C";s:3:"125";s:2:"WX";s:3:"668";s:1:"N";s:3:"a99";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"263";i:2;s:3:"633";i:3;s:3:"705";}}s:3:"a99";a:4:{s:1:"C";s:3:"125";s:2:"WX";s:3:"668";s:1:"N";s:3:"a99";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"263";i:2;s:3:"633";i:3;s:3:"705";}}i:126;a:4:{s:1:"C";s:3:"126";s:2:"WX";s:3:"668";s:1:"N";s:4:"a100";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:3:"263";i:2;s:3:"634";i:3;s:3:"705";}}s:4:"a100";a:4:{s:1:"C";s:3:"126";s:2:"WX";s:3:"668";s:1:"N";s:4:"a100";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:3:"263";i:2;s:3:"634";i:3;s:3:"705";}}i:128;a:4:{s:1:"C";s:3:"128";s:2:"WX";s:3:"390";s:1:"N";s:3:"a89";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"356";i:3;s:3:"705";}}s:3:"a89";a:4:{s:1:"C";s:3:"128";s:2:"WX";s:3:"390";s:1:"N";s:3:"a89";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"356";i:3;s:3:"705";}}i:129;a:4:{s:1:"C";s:3:"129";s:2:"WX";s:3:"390";s:1:"N";s:3:"a90";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"355";i:3;s:3:"705";}}s:3:"a90";a:4:{s:1:"C";s:3:"129";s:2:"WX";s:3:"390";s:1:"N";s:3:"a90";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"355";i:3;s:3:"705";}}i:130;a:4:{s:1:"C";s:3:"130";s:2:"WX";s:3:"317";s:1:"N";s:3:"a93";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"283";i:3;s:3:"692";}}s:3:"a93";a:4:{s:1:"C";s:3:"130";s:2:"WX";s:3:"317";s:1:"N";s:3:"a93";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"283";i:3;s:3:"692";}}i:131;a:4:{s:1:"C";s:3:"131";s:2:"WX";s:3:"317";s:1:"N";s:3:"a94";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"283";i:3;s:3:"692";}}s:3:"a94";a:4:{s:1:"C";s:3:"131";s:2:"WX";s:3:"317";s:1:"N";s:3:"a94";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"283";i:3;s:3:"692";}}i:132;a:4:{s:1:"C";s:3:"132";s:2:"WX";s:3:"276";s:1:"N";s:3:"a91";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"242";i:3;s:3:"692";}}s:3:"a91";a:4:{s:1:"C";s:3:"132";s:2:"WX";s:3:"276";s:1:"N";s:3:"a91";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"242";i:3;s:3:"692";}}i:133;a:4:{s:1:"C";s:3:"133";s:2:"WX";s:3:"276";s:1:"N";s:3:"a92";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"242";i:3;s:3:"692";}}s:3:"a92";a:4:{s:1:"C";s:3:"133";s:2:"WX";s:3:"276";s:1:"N";s:3:"a92";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"242";i:3;s:3:"692";}}i:134;a:4:{s:1:"C";s:3:"134";s:2:"WX";s:3:"509";s:1:"N";s:4:"a205";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"475";i:3;s:3:"692";}}s:4:"a205";a:4:{s:1:"C";s:3:"134";s:2:"WX";s:3:"509";s:1:"N";s:4:"a205";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"475";i:3;s:3:"692";}}i:135;a:4:{s:1:"C";s:3:"135";s:2:"WX";s:3:"509";s:1:"N";s:3:"a85";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"475";i:3;s:3:"692";}}s:3:"a85";a:4:{s:1:"C";s:3:"135";s:2:"WX";s:3:"509";s:1:"N";s:3:"a85";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"475";i:3;s:3:"692";}}i:136;a:4:{s:1:"C";s:3:"136";s:2:"WX";s:3:"410";s:1:"N";s:4:"a206";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"375";i:3;s:3:"692";}}s:4:"a206";a:4:{s:1:"C";s:3:"136";s:2:"WX";s:3:"410";s:1:"N";s:4:"a206";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"375";i:3;s:3:"692";}}i:137;a:4:{s:1:"C";s:3:"137";s:2:"WX";s:3:"410";s:1:"N";s:3:"a86";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"375";i:3;s:3:"692";}}s:3:"a86";a:4:{s:1:"C";s:3:"137";s:2:"WX";s:3:"410";s:1:"N";s:3:"a86";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"375";i:3;s:3:"692";}}i:138;a:4:{s:1:"C";s:3:"138";s:2:"WX";s:3:"234";s:1:"N";s:3:"a87";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"199";i:3;s:3:"705";}}s:3:"a87";a:4:{s:1:"C";s:3:"138";s:2:"WX";s:3:"234";s:1:"N";s:3:"a87";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"199";i:3;s:3:"705";}}i:139;a:4:{s:1:"C";s:3:"139";s:2:"WX";s:3:"234";s:1:"N";s:3:"a88";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"199";i:3;s:3:"705";}}s:3:"a88";a:4:{s:1:"C";s:3:"139";s:2:"WX";s:3:"234";s:1:"N";s:3:"a88";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"199";i:3;s:3:"705";}}i:140;a:4:{s:1:"C";s:3:"140";s:2:"WX";s:3:"334";s:1:"N";s:3:"a95";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"299";i:3;s:3:"692";}}s:3:"a95";a:4:{s:1:"C";s:3:"140";s:2:"WX";s:3:"334";s:1:"N";s:3:"a95";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"299";i:3;s:3:"692";}}i:141;a:4:{s:1:"C";s:3:"141";s:2:"WX";s:3:"334";s:1:"N";s:3:"a96";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"299";i:3;s:3:"692";}}s:3:"a96";a:4:{s:1:"C";s:3:"141";s:2:"WX";s:3:"334";s:1:"N";s:3:"a96";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"299";i:3;s:3:"692";}}i:161;a:4:{s:1:"C";s:3:"161";s:2:"WX";s:3:"732";s:1:"N";s:4:"a101";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:4:"-143";i:2;s:3:"697";i:3;s:3:"806";}}s:4:"a101";a:4:{s:1:"C";s:3:"161";s:2:"WX";s:3:"732";s:1:"N";s:4:"a101";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:4:"-143";i:2;s:3:"697";i:3;s:3:"806";}}i:162;a:4:{s:1:"C";s:3:"162";s:2:"WX";s:3:"544";s:1:"N";s:4:"a102";s:1:"B";a:4:{i:0;s:2:"56";i:1;s:3:"-14";i:2;s:3:"488";i:3;s:3:"706";}}s:4:"a102";a:4:{s:1:"C";s:3:"162";s:2:"WX";s:3:"544";s:1:"N";s:4:"a102";s:1:"B";a:4:{i:0;s:2:"56";i:1;s:3:"-14";i:2;s:3:"488";i:3;s:3:"706";}}i:163;a:4:{s:1:"C";s:3:"163";s:2:"WX";s:3:"544";s:1:"N";s:4:"a103";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"508";i:3;s:3:"705";}}s:4:"a103";a:4:{s:1:"C";s:3:"163";s:2:"WX";s:3:"544";s:1:"N";s:4:"a103";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"508";i:3;s:3:"705";}}i:164;a:4:{s:1:"C";s:3:"164";s:2:"WX";s:3:"910";s:1:"N";s:4:"a104";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"40";i:2;s:3:"875";i:3;s:3:"651";}}s:4:"a104";a:4:{s:1:"C";s:3:"164";s:2:"WX";s:3:"910";s:1:"N";s:4:"a104";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"40";i:2;s:3:"875";i:3;s:3:"651";}}i:165;a:4:{s:1:"C";s:3:"165";s:2:"WX";s:3:"667";s:1:"N";s:4:"a106";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"633";i:3;s:3:"705";}}s:4:"a106";a:4:{s:1:"C";s:3:"165";s:2:"WX";s:3:"667";s:1:"N";s:4:"a106";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"633";i:3;s:3:"705";}}i:166;a:4:{s:1:"C";s:3:"166";s:2:"WX";s:3:"760";s:1:"N";s:4:"a107";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"726";i:3;s:3:"705";}}s:4:"a107";a:4:{s:1:"C";s:3:"166";s:2:"WX";s:3:"760";s:1:"N";s:4:"a107";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"726";i:3;s:3:"705";}}i:167;a:4:{s:1:"C";s:3:"167";s:2:"WX";s:3:"760";s:1:"N";s:4:"a108";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"121";i:2;s:3:"758";i:3;s:3:"569";}}s:4:"a108";a:4:{s:1:"C";s:3:"167";s:2:"WX";s:3:"760";s:1:"N";s:4:"a108";s:1:"B";a:4:{i:0;s:1:"0";i:1;s:3:"121";i:2;s:3:"758";i:3;s:3:"569";}}i:168;a:4:{s:1:"C";s:3:"168";s:2:"WX";s:3:"776";s:1:"N";s:4:"a112";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"741";i:3;s:3:"705";}}s:4:"a112";a:4:{s:1:"C";s:3:"168";s:2:"WX";s:3:"776";s:1:"N";s:4:"a112";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"741";i:3;s:3:"705";}}i:169;a:4:{s:1:"C";s:3:"169";s:2:"WX";s:3:"595";s:1:"N";s:4:"a111";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"560";i:3;s:3:"705";}}s:4:"a111";a:4:{s:1:"C";s:3:"169";s:2:"WX";s:3:"595";s:1:"N";s:4:"a111";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-14";i:2;s:3:"560";i:3;s:3:"705";}}i:170;a:4:{s:1:"C";s:3:"170";s:2:"WX";s:3:"694";s:1:"N";s:4:"a110";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"659";i:3;s:3:"705";}}s:4:"a110";a:4:{s:1:"C";s:3:"170";s:2:"WX";s:3:"694";s:1:"N";s:4:"a110";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"659";i:3;s:3:"705";}}i:171;a:4:{s:1:"C";s:3:"171";s:2:"WX";s:3:"626";s:1:"N";s:4:"a109";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:1:"0";i:2;s:3:"591";i:3;s:3:"705";}}s:4:"a109";a:4:{s:1:"C";s:3:"171";s:2:"WX";s:3:"626";s:1:"N";s:4:"a109";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:1:"0";i:2;s:3:"591";i:3;s:3:"705";}}i:172;a:4:{s:1:"C";s:3:"172";s:2:"WX";s:3:"788";s:1:"N";s:4:"a120";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:4:"a120";a:4:{s:1:"C";s:3:"172";s:2:"WX";s:3:"788";s:1:"N";s:4:"a120";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:173;a:4:{s:1:"C";s:3:"173";s:2:"WX";s:3:"788";s:1:"N";s:4:"a121";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:4:"a121";a:4:{s:1:"C";s:3:"173";s:2:"WX";s:3:"788";s:1:"N";s:4:"a121";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:174;a:4:{s:1:"C";s:3:"174";s:2:"WX";s:3:"788";s:1:"N";s:4:"a122";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:4:"a122";a:4:{s:1:"C";s:3:"174";s:2:"WX";s:3:"788";s:1:"N";s:4:"a122";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:175;a:4:{s:1:"C";s:3:"175";s:2:"WX";s:3:"788";s:1:"N";s:4:"a123";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:4:"a123";a:4:{s:1:"C";s:3:"175";s:2:"WX";s:3:"788";s:1:"N";s:4:"a123";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:176;a:4:{s:1:"C";s:3:"176";s:2:"WX";s:3:"788";s:1:"N";s:4:"a124";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:4:"a124";a:4:{s:1:"C";s:3:"176";s:2:"WX";s:3:"788";s:1:"N";s:4:"a124";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:177;a:4:{s:1:"C";s:3:"177";s:2:"WX";s:3:"788";s:1:"N";s:4:"a125";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:4:"a125";a:4:{s:1:"C";s:3:"177";s:2:"WX";s:3:"788";s:1:"N";s:4:"a125";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:178;a:4:{s:1:"C";s:3:"178";s:2:"WX";s:3:"788";s:1:"N";s:4:"a126";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:4:"a126";a:4:{s:1:"C";s:3:"178";s:2:"WX";s:3:"788";s:1:"N";s:4:"a126";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:179;a:4:{s:1:"C";s:3:"179";s:2:"WX";s:3:"788";s:1:"N";s:4:"a127";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:4:"a127";a:4:{s:1:"C";s:3:"179";s:2:"WX";s:3:"788";s:1:"N";s:4:"a127";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:180;a:4:{s:1:"C";s:3:"180";s:2:"WX";s:3:"788";s:1:"N";s:4:"a128";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:4:"a128";a:4:{s:1:"C";s:3:"180";s:2:"WX";s:3:"788";s:1:"N";s:4:"a128";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:181;a:4:{s:1:"C";s:3:"181";s:2:"WX";s:3:"788";s:1:"N";s:4:"a129";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:4:"a129";a:4:{s:1:"C";s:3:"181";s:2:"WX";s:3:"788";s:1:"N";s:4:"a129";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:182;a:4:{s:1:"C";s:3:"182";s:2:"WX";s:3:"788";s:1:"N";s:4:"a130";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:4:"a130";a:4:{s:1:"C";s:3:"182";s:2:"WX";s:3:"788";s:1:"N";s:4:"a130";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:183;a:4:{s:1:"C";s:3:"183";s:2:"WX";s:3:"788";s:1:"N";s:4:"a131";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:4:"a131";a:4:{s:1:"C";s:3:"183";s:2:"WX";s:3:"788";s:1:"N";s:4:"a131";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:184;a:4:{s:1:"C";s:3:"184";s:2:"WX";s:3:"788";s:1:"N";s:4:"a132";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:4:"a132";a:4:{s:1:"C";s:3:"184";s:2:"WX";s:3:"788";s:1:"N";s:4:"a132";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:185;a:4:{s:1:"C";s:3:"185";s:2:"WX";s:3:"788";s:1:"N";s:4:"a133";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:4:"a133";a:4:{s:1:"C";s:3:"185";s:2:"WX";s:3:"788";s:1:"N";s:4:"a133";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:186;a:4:{s:1:"C";s:3:"186";s:2:"WX";s:3:"788";s:1:"N";s:4:"a134";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:4:"a134";a:4:{s:1:"C";s:3:"186";s:2:"WX";s:3:"788";s:1:"N";s:4:"a134";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:187;a:4:{s:1:"C";s:3:"187";s:2:"WX";s:3:"788";s:1:"N";s:4:"a135";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:4:"a135";a:4:{s:1:"C";s:3:"187";s:2:"WX";s:3:"788";s:1:"N";s:4:"a135";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:188;a:4:{s:1:"C";s:3:"188";s:2:"WX";s:3:"788";s:1:"N";s:4:"a136";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:4:"a136";a:4:{s:1:"C";s:3:"188";s:2:"WX";s:3:"788";s:1:"N";s:4:"a136";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:189;a:4:{s:1:"C";s:3:"189";s:2:"WX";s:3:"788";s:1:"N";s:4:"a137";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:4:"a137";a:4:{s:1:"C";s:3:"189";s:2:"WX";s:3:"788";s:1:"N";s:4:"a137";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:190;a:4:{s:1:"C";s:3:"190";s:2:"WX";s:3:"788";s:1:"N";s:4:"a138";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:4:"a138";a:4:{s:1:"C";s:3:"190";s:2:"WX";s:3:"788";s:1:"N";s:4:"a138";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:191;a:4:{s:1:"C";s:3:"191";s:2:"WX";s:3:"788";s:1:"N";s:4:"a139";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:4:"a139";a:4:{s:1:"C";s:3:"191";s:2:"WX";s:3:"788";s:1:"N";s:4:"a139";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:192;a:4:{s:1:"C";s:3:"192";s:2:"WX";s:3:"788";s:1:"N";s:4:"a140";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:4:"a140";a:4:{s:1:"C";s:3:"192";s:2:"WX";s:3:"788";s:1:"N";s:4:"a140";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:193;a:4:{s:1:"C";s:3:"193";s:2:"WX";s:3:"788";s:1:"N";s:4:"a141";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:4:"a141";a:4:{s:1:"C";s:3:"193";s:2:"WX";s:3:"788";s:1:"N";s:4:"a141";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:194;a:4:{s:1:"C";s:3:"194";s:2:"WX";s:3:"788";s:1:"N";s:4:"a142";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:4:"a142";a:4:{s:1:"C";s:3:"194";s:2:"WX";s:3:"788";s:1:"N";s:4:"a142";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:195;a:4:{s:1:"C";s:3:"195";s:2:"WX";s:3:"788";s:1:"N";s:4:"a143";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:4:"a143";a:4:{s:1:"C";s:3:"195";s:2:"WX";s:3:"788";s:1:"N";s:4:"a143";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:196;a:4:{s:1:"C";s:3:"196";s:2:"WX";s:3:"788";s:1:"N";s:4:"a144";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:4:"a144";a:4:{s:1:"C";s:3:"196";s:2:"WX";s:3:"788";s:1:"N";s:4:"a144";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:197;a:4:{s:1:"C";s:3:"197";s:2:"WX";s:3:"788";s:1:"N";s:4:"a145";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:4:"a145";a:4:{s:1:"C";s:3:"197";s:2:"WX";s:3:"788";s:1:"N";s:4:"a145";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:198;a:4:{s:1:"C";s:3:"198";s:2:"WX";s:3:"788";s:1:"N";s:4:"a146";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:4:"a146";a:4:{s:1:"C";s:3:"198";s:2:"WX";s:3:"788";s:1:"N";s:4:"a146";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:199;a:4:{s:1:"C";s:3:"199";s:2:"WX";s:3:"788";s:1:"N";s:4:"a147";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:4:"a147";a:4:{s:1:"C";s:3:"199";s:2:"WX";s:3:"788";s:1:"N";s:4:"a147";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:200;a:4:{s:1:"C";s:3:"200";s:2:"WX";s:3:"788";s:1:"N";s:4:"a148";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:4:"a148";a:4:{s:1:"C";s:3:"200";s:2:"WX";s:3:"788";s:1:"N";s:4:"a148";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:201;a:4:{s:1:"C";s:3:"201";s:2:"WX";s:3:"788";s:1:"N";s:4:"a149";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:4:"a149";a:4:{s:1:"C";s:3:"201";s:2:"WX";s:3:"788";s:1:"N";s:4:"a149";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:202;a:4:{s:1:"C";s:3:"202";s:2:"WX";s:3:"788";s:1:"N";s:4:"a150";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:4:"a150";a:4:{s:1:"C";s:3:"202";s:2:"WX";s:3:"788";s:1:"N";s:4:"a150";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:203;a:4:{s:1:"C";s:3:"203";s:2:"WX";s:3:"788";s:1:"N";s:4:"a151";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:4:"a151";a:4:{s:1:"C";s:3:"203";s:2:"WX";s:3:"788";s:1:"N";s:4:"a151";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:204;a:4:{s:1:"C";s:3:"204";s:2:"WX";s:3:"788";s:1:"N";s:4:"a152";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:4:"a152";a:4:{s:1:"C";s:3:"204";s:2:"WX";s:3:"788";s:1:"N";s:4:"a152";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:205;a:4:{s:1:"C";s:3:"205";s:2:"WX";s:3:"788";s:1:"N";s:4:"a153";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:4:"a153";a:4:{s:1:"C";s:3:"205";s:2:"WX";s:3:"788";s:1:"N";s:4:"a153";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:206;a:4:{s:1:"C";s:3:"206";s:2:"WX";s:3:"788";s:1:"N";s:4:"a154";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:4:"a154";a:4:{s:1:"C";s:3:"206";s:2:"WX";s:3:"788";s:1:"N";s:4:"a154";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:207;a:4:{s:1:"C";s:3:"207";s:2:"WX";s:3:"788";s:1:"N";s:4:"a155";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:4:"a155";a:4:{s:1:"C";s:3:"207";s:2:"WX";s:3:"788";s:1:"N";s:4:"a155";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:208;a:4:{s:1:"C";s:3:"208";s:2:"WX";s:3:"788";s:1:"N";s:4:"a156";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:4:"a156";a:4:{s:1:"C";s:3:"208";s:2:"WX";s:3:"788";s:1:"N";s:4:"a156";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:209;a:4:{s:1:"C";s:3:"209";s:2:"WX";s:3:"788";s:1:"N";s:4:"a157";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:4:"a157";a:4:{s:1:"C";s:3:"209";s:2:"WX";s:3:"788";s:1:"N";s:4:"a157";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:210;a:4:{s:1:"C";s:3:"210";s:2:"WX";s:3:"788";s:1:"N";s:4:"a158";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:4:"a158";a:4:{s:1:"C";s:3:"210";s:2:"WX";s:3:"788";s:1:"N";s:4:"a158";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:211;a:4:{s:1:"C";s:3:"211";s:2:"WX";s:3:"788";s:1:"N";s:4:"a159";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}s:4:"a159";a:4:{s:1:"C";s:3:"211";s:2:"WX";s:3:"788";s:1:"N";s:4:"a159";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-14";i:2;s:3:"754";i:3;s:3:"705";}}i:212;a:4:{s:1:"C";s:3:"212";s:2:"WX";s:3:"894";s:1:"N";s:4:"a160";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"58";i:2;s:3:"860";i:3;s:3:"634";}}s:4:"a160";a:4:{s:1:"C";s:3:"212";s:2:"WX";s:3:"894";s:1:"N";s:4:"a160";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"58";i:2;s:3:"860";i:3;s:3:"634";}}i:213;a:4:{s:1:"C";s:3:"213";s:2:"WX";s:3:"838";s:1:"N";s:4:"a161";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"152";i:2;s:3:"803";i:3;s:3:"540";}}s:4:"a161";a:4:{s:1:"C";s:3:"213";s:2:"WX";s:3:"838";s:1:"N";s:4:"a161";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"152";i:2;s:3:"803";i:3;s:3:"540";}}i:214;a:4:{s:1:"C";s:3:"214";s:2:"WX";s:4:"1016";s:1:"N";s:4:"a163";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"152";i:2;s:3:"981";i:3;s:3:"540";}}s:4:"a163";a:4:{s:1:"C";s:3:"214";s:2:"WX";s:4:"1016";s:1:"N";s:4:"a163";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"152";i:2;s:3:"981";i:3;s:3:"540";}}i:215;a:4:{s:1:"C";s:3:"215";s:2:"WX";s:3:"458";s:1:"N";s:4:"a164";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:4:"-127";i:2;s:3:"422";i:3;s:3:"820";}}s:4:"a164";a:4:{s:1:"C";s:3:"215";s:2:"WX";s:3:"458";s:1:"N";s:4:"a164";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:4:"-127";i:2;s:3:"422";i:3;s:3:"820";}}i:216;a:4:{s:1:"C";s:3:"216";s:2:"WX";s:3:"748";s:1:"N";s:4:"a196";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"94";i:2;s:3:"698";i:3;s:3:"597";}}s:4:"a196";a:4:{s:1:"C";s:3:"216";s:2:"WX";s:3:"748";s:1:"N";s:4:"a196";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"94";i:2;s:3:"698";i:3;s:3:"597";}}i:217;a:4:{s:1:"C";s:3:"217";s:2:"WX";s:3:"924";s:1:"N";s:4:"a165";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"140";i:2;s:3:"890";i:3;s:3:"552";}}s:4:"a165";a:4:{s:1:"C";s:3:"217";s:2:"WX";s:3:"924";s:1:"N";s:4:"a165";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"140";i:2;s:3:"890";i:3;s:3:"552";}}i:218;a:4:{s:1:"C";s:3:"218";s:2:"WX";s:3:"748";s:1:"N";s:4:"a192";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"94";i:2;s:3:"698";i:3;s:3:"597";}}s:4:"a192";a:4:{s:1:"C";s:3:"218";s:2:"WX";s:3:"748";s:1:"N";s:4:"a192";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"94";i:2;s:3:"698";i:3;s:3:"597";}}i:219;a:4:{s:1:"C";s:3:"219";s:2:"WX";s:3:"918";s:1:"N";s:4:"a166";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"166";i:2;s:3:"884";i:3;s:3:"526";}}s:4:"a166";a:4:{s:1:"C";s:3:"219";s:2:"WX";s:3:"918";s:1:"N";s:4:"a166";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"166";i:2;s:3:"884";i:3;s:3:"526";}}i:220;a:4:{s:1:"C";s:3:"220";s:2:"WX";s:3:"927";s:1:"N";s:4:"a167";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"32";i:2;s:3:"892";i:3;s:3:"660";}}s:4:"a167";a:4:{s:1:"C";s:3:"220";s:2:"WX";s:3:"927";s:1:"N";s:4:"a167";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"32";i:2;s:3:"892";i:3;s:3:"660";}}i:221;a:4:{s:1:"C";s:3:"221";s:2:"WX";s:3:"928";s:1:"N";s:4:"a168";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"129";i:2;s:3:"891";i:3;s:3:"562";}}s:4:"a168";a:4:{s:1:"C";s:3:"221";s:2:"WX";s:3:"928";s:1:"N";s:4:"a168";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"129";i:2;s:3:"891";i:3;s:3:"562";}}i:222;a:4:{s:1:"C";s:3:"222";s:2:"WX";s:3:"928";s:1:"N";s:4:"a169";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"128";i:2;s:3:"893";i:3;s:3:"563";}}s:4:"a169";a:4:{s:1:"C";s:3:"222";s:2:"WX";s:3:"928";s:1:"N";s:4:"a169";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"128";i:2;s:3:"893";i:3;s:3:"563";}}i:223;a:4:{s:1:"C";s:3:"223";s:2:"WX";s:3:"834";s:1:"N";s:4:"a170";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"155";i:2;s:3:"799";i:3;s:3:"537";}}s:4:"a170";a:4:{s:1:"C";s:3:"223";s:2:"WX";s:3:"834";s:1:"N";s:4:"a170";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"155";i:2;s:3:"799";i:3;s:3:"537";}}i:224;a:4:{s:1:"C";s:3:"224";s:2:"WX";s:3:"873";s:1:"N";s:4:"a171";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"93";i:2;s:3:"838";i:3;s:3:"599";}}s:4:"a171";a:4:{s:1:"C";s:3:"224";s:2:"WX";s:3:"873";s:1:"N";s:4:"a171";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"93";i:2;s:3:"838";i:3;s:3:"599";}}i:225;a:4:{s:1:"C";s:3:"225";s:2:"WX";s:3:"828";s:1:"N";s:4:"a172";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"104";i:2;s:3:"791";i:3;s:3:"588";}}s:4:"a172";a:4:{s:1:"C";s:3:"225";s:2:"WX";s:3:"828";s:1:"N";s:4:"a172";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"104";i:2;s:3:"791";i:3;s:3:"588";}}i:226;a:4:{s:1:"C";s:3:"226";s:2:"WX";s:3:"924";s:1:"N";s:4:"a173";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"98";i:2;s:3:"889";i:3;s:3:"594";}}s:4:"a173";a:4:{s:1:"C";s:3:"226";s:2:"WX";s:3:"924";s:1:"N";s:4:"a173";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"98";i:2;s:3:"889";i:3;s:3:"594";}}i:227;a:4:{s:1:"C";s:3:"227";s:2:"WX";s:3:"924";s:1:"N";s:4:"a162";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"98";i:2;s:3:"889";i:3;s:3:"594";}}s:4:"a162";a:4:{s:1:"C";s:3:"227";s:2:"WX";s:3:"924";s:1:"N";s:4:"a162";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"98";i:2;s:3:"889";i:3;s:3:"594";}}i:228;a:4:{s:1:"C";s:3:"228";s:2:"WX";s:3:"917";s:1:"N";s:4:"a174";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"882";i:3;s:3:"692";}}s:4:"a174";a:4:{s:1:"C";s:3:"228";s:2:"WX";s:3:"917";s:1:"N";s:4:"a174";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"882";i:3;s:3:"692";}}i:229;a:4:{s:1:"C";s:3:"229";s:2:"WX";s:3:"930";s:1:"N";s:4:"a175";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"84";i:2;s:3:"896";i:3;s:3:"608";}}s:4:"a175";a:4:{s:1:"C";s:3:"229";s:2:"WX";s:3:"930";s:1:"N";s:4:"a175";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"84";i:2;s:3:"896";i:3;s:3:"608";}}i:230;a:4:{s:1:"C";s:3:"230";s:2:"WX";s:3:"931";s:1:"N";s:4:"a176";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"84";i:2;s:3:"896";i:3;s:3:"608";}}s:4:"a176";a:4:{s:1:"C";s:3:"230";s:2:"WX";s:3:"931";s:1:"N";s:4:"a176";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"84";i:2;s:3:"896";i:3;s:3:"608";}}i:231;a:4:{s:1:"C";s:3:"231";s:2:"WX";s:3:"463";s:1:"N";s:4:"a177";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-99";i:2;s:3:"429";i:3;s:3:"791";}}s:4:"a177";a:4:{s:1:"C";s:3:"231";s:2:"WX";s:3:"463";s:1:"N";s:4:"a177";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"-99";i:2;s:3:"429";i:3;s:3:"791";}}i:232;a:4:{s:1:"C";s:3:"232";s:2:"WX";s:3:"883";s:1:"N";s:4:"a178";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"71";i:2;s:3:"848";i:3;s:3:"623";}}s:4:"a178";a:4:{s:1:"C";s:3:"232";s:2:"WX";s:3:"883";s:1:"N";s:4:"a178";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"71";i:2;s:3:"848";i:3;s:3:"623";}}i:233;a:4:{s:1:"C";s:3:"233";s:2:"WX";s:3:"836";s:1:"N";s:4:"a179";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"44";i:2;s:3:"802";i:3;s:3:"648";}}s:4:"a179";a:4:{s:1:"C";s:3:"233";s:2:"WX";s:3:"836";s:1:"N";s:4:"a179";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"44";i:2;s:3:"802";i:3;s:3:"648";}}i:234;a:4:{s:1:"C";s:3:"234";s:2:"WX";s:3:"836";s:1:"N";s:4:"a193";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"44";i:2;s:3:"802";i:3;s:3:"648";}}s:4:"a193";a:4:{s:1:"C";s:3:"234";s:2:"WX";s:3:"836";s:1:"N";s:4:"a193";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"44";i:2;s:3:"802";i:3;s:3:"648";}}i:235;a:4:{s:1:"C";s:3:"235";s:2:"WX";s:3:"867";s:1:"N";s:4:"a180";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"101";i:2;s:3:"832";i:3;s:3:"591";}}s:4:"a180";a:4:{s:1:"C";s:3:"235";s:2:"WX";s:3:"867";s:1:"N";s:4:"a180";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"101";i:2;s:3:"832";i:3;s:3:"591";}}i:236;a:4:{s:1:"C";s:3:"236";s:2:"WX";s:3:"867";s:1:"N";s:4:"a199";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"101";i:2;s:3:"832";i:3;s:3:"591";}}s:4:"a199";a:4:{s:1:"C";s:3:"236";s:2:"WX";s:3:"867";s:1:"N";s:4:"a199";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"101";i:2;s:3:"832";i:3;s:3:"591";}}i:237;a:4:{s:1:"C";s:3:"237";s:2:"WX";s:3:"696";s:1:"N";s:4:"a181";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"44";i:2;s:3:"661";i:3;s:3:"648";}}s:4:"a181";a:4:{s:1:"C";s:3:"237";s:2:"WX";s:3:"696";s:1:"N";s:4:"a181";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"44";i:2;s:3:"661";i:3;s:3:"648";}}i:238;a:4:{s:1:"C";s:3:"238";s:2:"WX";s:3:"696";s:1:"N";s:4:"a200";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"44";i:2;s:3:"661";i:3;s:3:"648";}}s:4:"a200";a:4:{s:1:"C";s:3:"238";s:2:"WX";s:3:"696";s:1:"N";s:4:"a200";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"44";i:2;s:3:"661";i:3;s:3:"648";}}i:239;a:4:{s:1:"C";s:3:"239";s:2:"WX";s:3:"874";s:1:"N";s:4:"a182";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"77";i:2;s:3:"840";i:3;s:3:"619";}}s:4:"a182";a:4:{s:1:"C";s:3:"239";s:2:"WX";s:3:"874";s:1:"N";s:4:"a182";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"77";i:2;s:3:"840";i:3;s:3:"619";}}i:241;a:4:{s:1:"C";s:3:"241";s:2:"WX";s:3:"874";s:1:"N";s:4:"a201";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"73";i:2;s:3:"840";i:3;s:3:"615";}}s:4:"a201";a:4:{s:1:"C";s:3:"241";s:2:"WX";s:3:"874";s:1:"N";s:4:"a201";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"73";i:2;s:3:"840";i:3;s:3:"615";}}i:242;a:4:{s:1:"C";s:3:"242";s:2:"WX";s:3:"760";s:1:"N";s:4:"a183";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"725";i:3;s:3:"692";}}s:4:"a183";a:4:{s:1:"C";s:3:"242";s:2:"WX";s:3:"760";s:1:"N";s:4:"a183";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:1:"0";i:2;s:3:"725";i:3;s:3:"692";}}i:243;a:4:{s:1:"C";s:3:"243";s:2:"WX";s:3:"946";s:1:"N";s:4:"a184";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"160";i:2;s:3:"911";i:3;s:3:"533";}}s:4:"a184";a:4:{s:1:"C";s:3:"243";s:2:"WX";s:3:"946";s:1:"N";s:4:"a184";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"160";i:2;s:3:"911";i:3;s:3:"533";}}i:244;a:4:{s:1:"C";s:3:"244";s:2:"WX";s:3:"771";s:1:"N";s:4:"a197";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:2:"37";i:2;s:3:"736";i:3;s:3:"655";}}s:4:"a197";a:4:{s:1:"C";s:3:"244";s:2:"WX";s:3:"771";s:1:"N";s:4:"a197";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:2:"37";i:2;s:3:"736";i:3;s:3:"655";}}i:245;a:4:{s:1:"C";s:3:"245";s:2:"WX";s:3:"865";s:1:"N";s:4:"a185";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"207";i:2;s:3:"830";i:3;s:3:"481";}}s:4:"a185";a:4:{s:1:"C";s:3:"245";s:2:"WX";s:3:"865";s:1:"N";s:4:"a185";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"207";i:2;s:3:"830";i:3;s:3:"481";}}i:246;a:4:{s:1:"C";s:3:"246";s:2:"WX";s:3:"771";s:1:"N";s:4:"a194";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:2:"37";i:2;s:3:"736";i:3;s:3:"655";}}s:4:"a194";a:4:{s:1:"C";s:3:"246";s:2:"WX";s:3:"771";s:1:"N";s:4:"a194";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:2:"37";i:2;s:3:"736";i:3;s:3:"655";}}i:247;a:4:{s:1:"C";s:3:"247";s:2:"WX";s:3:"888";s:1:"N";s:4:"a198";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-19";i:2;s:3:"853";i:3;s:3:"712";}}s:4:"a198";a:4:{s:1:"C";s:3:"247";s:2:"WX";s:3:"888";s:1:"N";s:4:"a198";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-19";i:2;s:3:"853";i:3;s:3:"712";}}i:248;a:4:{s:1:"C";s:3:"248";s:2:"WX";s:3:"967";s:1:"N";s:4:"a186";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"124";i:2;s:3:"932";i:3;s:3:"568";}}s:4:"a186";a:4:{s:1:"C";s:3:"248";s:2:"WX";s:3:"967";s:1:"N";s:4:"a186";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"124";i:2;s:3:"932";i:3;s:3:"568";}}i:249;a:4:{s:1:"C";s:3:"249";s:2:"WX";s:3:"888";s:1:"N";s:4:"a195";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-19";i:2;s:3:"853";i:3;s:3:"712";}}s:4:"a195";a:4:{s:1:"C";s:3:"249";s:2:"WX";s:3:"888";s:1:"N";s:4:"a195";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:3:"-19";i:2;s:3:"853";i:3;s:3:"712";}}i:250;a:4:{s:1:"C";s:3:"250";s:2:"WX";s:3:"831";s:1:"N";s:4:"a187";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"113";i:2;s:3:"796";i:3;s:3:"579";}}s:4:"a187";a:4:{s:1:"C";s:3:"250";s:2:"WX";s:3:"831";s:1:"N";s:4:"a187";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"113";i:2;s:3:"796";i:3;s:3:"579";}}i:251;a:4:{s:1:"C";s:3:"251";s:2:"WX";s:3:"873";s:1:"N";s:4:"a188";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:3:"118";i:2;s:3:"838";i:3;s:3:"578";}}s:4:"a188";a:4:{s:1:"C";s:3:"251";s:2:"WX";s:3:"873";s:1:"N";s:4:"a188";s:1:"B";a:4:{i:0;s:2:"36";i:1;s:3:"118";i:2;s:3:"838";i:3;s:3:"578";}}i:252;a:4:{s:1:"C";s:3:"252";s:2:"WX";s:3:"927";s:1:"N";s:4:"a189";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"150";i:2;s:3:"891";i:3;s:3:"542";}}s:4:"a189";a:4:{s:1:"C";s:3:"252";s:2:"WX";s:3:"927";s:1:"N";s:4:"a189";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:3:"150";i:2;s:3:"891";i:3;s:3:"542";}}i:253;a:4:{s:1:"C";s:3:"253";s:2:"WX";s:3:"970";s:1:"N";s:4:"a190";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"76";i:2;s:3:"931";i:3;s:3:"616";}}s:4:"a190";a:4:{s:1:"C";s:3:"253";s:2:"WX";s:3:"970";s:1:"N";s:4:"a190";s:1:"B";a:4:{i:0;s:2:"35";i:1;s:2:"76";i:2;s:3:"931";i:3;s:3:"616";}}i:254;a:4:{s:1:"C";s:3:"254";s:2:"WX";s:3:"918";s:1:"N";s:4:"a191";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:2:"99";i:2;s:3:"884";i:3;s:3:"593";}}s:4:"a191";a:4:{s:1:"C";s:3:"254";s:2:"WX";s:3:"918";s:1:"N";s:4:"a191";s:1:"B";a:4:{i:0;s:2:"34";i:1;s:2:"99";i:2;s:3:"884";i:3;s:3:"593";}}}s:9:"_version_";i:1;}
Added: trunk/mapbender/http/classes/phpmailer-1.72/LICENSE
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/phpmailer-1.72/LICENSE?view=auto&rev=54
--- (empty file)
+++ trunk/mapbender/http/classes/phpmailer-1.72/LICENSE	2006-04-13 21:05:53+0000
@@ -0,0 +1,504 @@
+		  GNU LESSER GENERAL PUBLIC LICENSE
+		       Version 2.1, February 1999
+ Copyright (C) 1991, 1999 Free Software Foundation, Inc.
+     59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
+ Everyone is permitted to copy and distribute verbatim copies
+ of this license document, but changing it is not allowed.
+[This is the first released version of the Lesser GPL.  It also counts
+ as the successor of the GNU Library Public License, version 2, hence
+ the version number 2.1.]
+			    Preamble
+  The licenses for most software are designed to take away your
+freedom to share and change it.  By contrast, the GNU General Public
+Licenses are intended to guarantee your freedom to share and change
+free software--to make sure the software is free for all its users.
+  This license, the Lesser General Public License, applies to some
+specially designated software packages--typically libraries--of the
+Free Software Foundation and other authors who decide to use it.  You
+can use it too, but we suggest you first think carefully about whether
+this license or the ordinary General Public License is the better
+strategy to use in any particular case, based on the explanations below.
+  When we speak of free software, we are referring to freedom of use,
+not price.  Our General Public Licenses are designed to make sure that
+you have the freedom to distribute copies of free software (and charge
+for this service if you wish); that you receive source code or can get
+it if you want it; that you can change the software and use pieces of
+it in new free programs; and that you are informed that you can do
+these things.
+  To protect your rights, we need to make restrictions that forbid
+distributors to deny you these rights or to ask you to surrender these
+rights.  These restrictions translate to certain responsibilities for
+you if you distribute copies of the library or if you modify it.
+  For example, if you distribute copies of the library, whether gratis
+or for a fee, you must give the recipients all the rights that we gave
+you.  You must make sure that they, too, receive or can get the source
+code.  If you link other code with the library, you must provide
+complete object files to the recipients, so that they can relink them
+with the library after making changes to the library and recompiling
+it.  And you must show them these terms so they know their rights.
+  We protect your rights with a two-step method: (1) we copyright the
+library, and (2) we offer you this license, which gives you legal
+permission to copy, distribute and/or modify the library.
+  To protect each distributor, we want to make it very clear that
+there is no warranty for the free library.  Also, if the library is
+modified by someone else and passed on, the recipients should know
+that what they have is not the original version, so that the original
+author's reputation will not be affected by problems that might be
+introduced by others.
+  Finally, software patents pose a constant threat to the existence of
+any free program.  We wish to make sure that a company cannot
+effectively restrict the users of a free program by obtaining a
+restrictive license from a patent holder.  Therefore, we insist that
+any patent license obtained for a version of the library must be
+consistent with the full freedom of use specified in this license.
+  Most GNU software, including some libraries, is covered by the
+ordinary GNU General Public License.  This license, the GNU Lesser
+General Public License, applies to certain designated libraries, and
+is quite different from the ordinary General Public License.  We use
+this license for certain libraries in order to permit linking those
+libraries into non-free programs.
+  When a program is linked with a library, whether statically or using
+a shared library, the combination of the two is legally speaking a
+combined work, a derivative of the original library.  The ordinary
+General Public License therefore permits such linking only if the
+entire combination fits its criteria of freedom.  The Lesser General
+Public License permits more lax criteria for linking other code with
+the library.
+  We call this license the "Lesser" General Public License because it
+does Less to protect the user's freedom than the ordinary General
+Public License.  It also provides other free software developers Less
+of an advantage over competing non-free programs.  These disadvantages
+are the reason we use the ordinary General Public License for many
+libraries.  However, the Lesser license provides advantages in certain
+special circumstances.
+  For example, on rare occasions, there may be a special need to
+encourage the widest possible use of a certain library, so that it becomes
+a de-facto standard.  To achieve this, non-free programs must be
+allowed to use the library.  A more frequent case is that a free
+library does the same job as widely used non-free libraries.  In this
+case, there is little to gain by limiting the free library to free
+software only, so we use the Lesser General Public License.
+  In other cases, permission to use a particular library in non-free
+programs enables a greater number of people to use a large body of
+free software.  For example, permission to use the GNU C Library in
+non-free programs enables many more people to use the whole GNU
+operating system, as well as its variant, the GNU/Linux operating
+system.
+  Although the Lesser General Public License is Less protective of the
+users' freedom, it does ensure that the user of a program that is
+linked with the Library has the freedom and the wherewithal to run
+that program using a modified version of the Library.
+  The precise terms and conditions for copying, distribution and
+modification follow.  Pay close attention to the difference between a
+"work based on the library" and a "work that uses the library".  The
+former contains code derived from the library, whereas the latter must
+be combined with the library in order to run.
+   TERMS AND CONDITIONS FOR COPYING, DISTRIBUTION AND MODIFICATION
+  0. This License Agreement applies to any software library or other
+program which contains a notice placed by the copyright holder or
+other authorized party saying it may be distributed under the terms of
+this Lesser General Public License (also called "this License").
+Each licensee is addressed as "you".
+  A "library" means a collection of software functions and/or data
+prepared so as to be conveniently linked with application programs
+(which use some of those functions and data) to form executables.
+  The "Library", below, refers to any such software library or work
+which has been distributed under these terms.  A "work based on the
+Library" means either the Library or any derivative work under
+copyright law: that is to say, a work containing the Library or a
+portion of it, either verbatim or with modifications and/or translated
+straightforwardly into another language.  (Hereinafter, translation is
+included without limitation in the term "modification".)
+  "Source code" for a work means the preferred form of the work for
+making modifications to it.  For a library, complete source code means
+all the source code for all modules it contains, plus any associated
+interface definition files, plus the scripts used to control compilation
+and installation of the library.
+  Activities other than copying, distribution and modification are not
+covered by this License; they are outside its scope.  The act of
+running a program using the Library is not restricted, and output from
+such a program is covered only if its contents constitute a work based
+on the Library (independent of the use of the Library in a tool for
+writing it).  Whether that is true depends on what the Library does
+and what the program that uses the Library does.
+  1. You may copy and distribute verbatim copies of the Library's
+complete source code as you receive it, in any medium, provided that
+you conspicuously and appropriately publish on each copy an
+appropriate copyright notice and disclaimer of warranty; keep intact
+all the notices that refer to this License and to the absence of any
+warranty; and distribute a copy of this License along with the
+Library.
+  You may charge a fee for the physical act of transferring a copy,
+and you may at your option offer warranty protection in exchange for a
+fee.
+  2. You may modify your copy or copies of the Library or any portion
+of it, thus forming a work based on the Library, and copy and
+distribute such modifications or work under the terms of Section 1
+above, provided that you also meet all of these conditions:
+    a) The modified work must itself be a software library.
+    b) You must cause the files modified to carry prominent notices
+    stating that you changed the files and the date of any change.
+    c) You must cause the whole of the work to be licensed at no
+    charge to all third parties under the terms of this License.
+    d) If a facility in the modified Library refers to a function or a
+    table of data to be supplied by an application program that uses
+    the facility, other than as an argument passed when the facility
+    is invoked, then you must make a good faith effort to ensure that,
+    in the event an application does not supply such function or
+    table, the facility still operates, and performs whatever part of
+    its purpose remains meaningful.
+    (For example, a function in a library to compute square roots has
+    a purpose that is entirely well-defined independent of the
+    application.  Therefore, Subsection 2d requires that any
+    application-supplied function or table used by this function must
+    be optional: if the application does not supply it, the square
+    root function must still compute square roots.)
+These requirements apply to the modified work as a whole.  If
+identifiable sections of that work are not derived from the Library,
+and can be reasonably considered independent and separate works in
+themselves, then this License, and its terms, do not apply to those
+sections when you distribute them as separate works.  But when you
+distribute the same sections as part of a whole which is a work based
+on the Library, the distribution of the whole must be on the terms of
+this License, whose permissions for other licensees extend to the
+entire whole, and thus to each and every part regardless of who wrote
+it.
+Thus, it is not the intent of this section to claim rights or contest
+your rights to work written entirely by you; rather, the intent is to
+exercise the right to control the distribution of derivative or
+collective works based on the Library.
+In addition, mere aggregation of another work not based on the Library
+with the Library (or with a work based on the Library) on a volume of
+a storage or distribution medium does not bring the other work under
+the scope of this License.
+  3. You may opt to apply the terms of the ordinary GNU General Public
+License instead of this License to a given copy of the Library.  To do
+this, you must alter all the notices that refer to this License, so
+that they refer to the ordinary GNU General Public License, version 2,
+instead of to this License.  (If a newer version than version 2 of the
+ordinary GNU General Public License has appeared, then you can specify
+that version instead if you wish.)  Do not make any other change in
+these notices.
+  Once this change is made in a given copy, it is irreversible for
+that copy, so the ordinary GNU General Public License applies to all
+subsequent copies and derivative works made from that copy.
+  This option is useful when you wish to copy part of the code of
+the Library into a program that is not a library.
+  4. You may copy and distribute the Library (or a portion or
+derivative of it, under Section 2) in object code or executable form
+under the terms of Sections 1 and 2 above provided that you accompany
+it with the complete corresponding machine-readable source code, which
+must be distributed under the terms of Sections 1 and 2 above on a
+medium customarily used for software interchange.
+  If distribution of object code is made by offering access to copy
+from a designated place, then offering equivalent access to copy the
+source code from the same place satisfies the requirement to
+distribute the source code, even though third parties are not
+compelled to copy the source along with the object code.
+  5. A program that contains no derivative of any portion of the
+Library, but is designed to work with the Library by being compiled or
+linked with it, is called a "work that uses the Library".  Such a
+work, in isolation, is not a derivative work of the Library, and
+therefore falls outside the scope of this License.
+  However, linking a "work that uses the Library" with the Library
+creates an executable that is a derivative of the Library (because it
+contains portions of the Library), rather than a "work that uses the
+library".  The executable is therefore covered by this License.
+Section 6 states terms for distribution of such executables.
+  When a "work that uses the Library" uses material from a header file
+that is part of the Library, the object code for the work may be a
+derivative work of the Library even though the source code is not.
+Whether this is true is especially significant if the work can be
+linked without the Library, or if the work is itself a library.  The
+threshold for this to be true is not precisely defined by law.
+  If such an object file uses only numerical parameters, data
+structure layouts and accessors, and small macros and small inline
+functions (ten lines or less in length), then the use of the object
+file is unrestricted, regardless of whether it is legally a derivative
+work.  (Executables containing this object code plus portions of the
+Library will still fall under Section 6.)
+  Otherwise, if the work is a derivative of the Library, you may
+distribute the object code for the work under the terms of Section 6.
+Any executables containing that work also fall under Section 6,
+whether or not they are linked directly with the Library itself.
+  6. As an exception to the Sections above, you may also combine or
+link a "work that uses the Library" with the Library to produce a
+work containing portions of the Library, and distribute that work
+under terms of your choice, provided that the terms permit
+modification of the work for the customer's own use and reverse
+engineering for debugging such modifications.
+  You must give prominent notice with each copy of the work that the
+Library is used in it and that the Library and its use are covered by
+this License.  You must supply a copy of this License.  If the work
+during execution displays copyright notices, you must include the
+copyright notice for the Library among them, as well as a reference
+directing the user to the copy of this License.  Also, you must do one
+of these things:
+    a) Accompany the work with the complete corresponding
+    machine-readable source code for the Library including whatever
+    changes were used in the work (which must be distributed under
+    Sections 1 and 2 above); and, if the work is an executable linked
+    with the Library, with the complete machine-readable "work that
+    uses the Library", as object code and/or source code, so that the
+    user can modify the Library and then relink to produce a modified
+    executable containing the modified Library.  (It is understood
+    that the user who changes the contents of definitions files in the
+    Library will not necessarily be able to recompile the application
+    to use the modified definitions.)
+    b) Use a suitable shared library mechanism for linking with the
+    Library.  A suitable mechanism is one that (1) uses at run time a
+    copy of the library already present on the user's computer system,
+    rather than copying library functions into the executable, and (2)
+    will operate properly with a modified version of the library, if
+    the user installs one, as long as the modified version is
+    interface-compatible with the version that the work was made with.
+    c) Accompany the work with a written offer, valid for at
+    least three years, to give the same user the materials
+    specified in Subsection 6a, above, for a charge no more
+    than the cost of performing this distribution.
+    d) If distribution of the work is made by offering access to copy
+    from a designated place, offer equivalent access to copy the above
+    specified materials from the same place.
+    e) Verify that the user has already received a copy of these
+    materials or that you have already sent this user a copy.
+  For an executable, the required form of the "work that uses the
+Library" must include any data and utility programs needed for
+reproducing the executable from it.  However, as a special exception,
+the materials to be distributed need not include anything that is
+normally distributed (in either source or binary form) with the major
+components (compiler, kernel, and so on) of the operating system on
+which the executable runs, unless that component itself accompanies
+the executable.
+  It may happen that this requirement contradicts the license
+restrictions of other proprietary libraries that do not normally
+accompany the operating system.  Such a contradiction means you cannot
+use both them and the Library together in an executable that you
+distribute.
+  7. You may place library facilities that are a work based on the
+Library side-by-side in a single library together with other library
+facilities not covered by this License, and distribute such a combined
+library, provided that the separate distribution of the work based on
+the Library and of the other library facilities is otherwise
+permitted, and provided that you do these two things:
+    a) Accompany the combined library with a copy of the same work
+    based on the Library, uncombined with any other library
+    facilities.  This must be distributed under the terms of the
+    Sections above.
+    b) Give prominent notice with the combined library of the fact
+    that part of it is a work based on the Library, and explaining
+    where to find the accompanying uncombined form of the same work.
+  8. You may not copy, modify, sublicense, link with, or distribute
+the Library except as expressly provided under this License.  Any
+attempt otherwise to copy, modify, sublicense, link with, or
+distribute the Library is void, and will automatically terminate your
+rights under this License.  However, parties who have received copies,
+or rights, from you under this License will not have their licenses
+terminated so long as such parties remain in full compliance.
+  9. You are not required to accept this License, since you have not
+signed it.  However, nothing else grants you permission to modify or
+distribute the Library or its derivative works.  These actions are
+prohibited by law if you do not accept this License.  Therefore, by
+modifying or distributing the Library (or any work based on the
+Library), you indicate your acceptance of this License to do so, and
+all its terms and conditions for copying, distributing or modifying
+the Library or works based on it.
+  10. Each time you redistribute the Library (or any work based on the
+Library), the recipient automatically receives a license from the
+original licensor to copy, distribute, link with or modify the Library
+subject to these terms and conditions.  You may not impose any further
+restrictions on the recipients' exercise of the rights granted herein.
+You are not responsible for enforcing compliance by third parties with
+this License.
+  11. If, as a consequence of a court judgment or allegation of patent
+infringement or for any other reason (not limited to patent issues),
+conditions are imposed on you (whether by court order, agreement or
+otherwise) that contradict the conditions of this License, they do not
+excuse you from the conditions of this License.  If you cannot
+distribute so as to satisfy simultaneously your obligations under this
+License and any other pertinent obligations, then as a consequence you
+may not distribute the Library at all.  For example, if a patent
+license would not permit royalty-free redistribution of the Library by
+all those who receive copies directly or indirectly through you, then
+the only way you could satisfy both it and this License would be to
+refrain entirely from distribution of the Library.
+If any portion of this section is held invalid or unenforceable under any
+particular circumstance, the balance of the section is intended to apply,
+and the section as a whole is intended to apply in other circumstances.
+It is not the purpose of this section to induce you to infringe any
+patents or other property right claims or to contest validity of any
+such claims; this section has the sole purpose of protecting the
+integrity of the free software distribution system which is
+implemented by public license practices.  Many people have made
+generous contributions to the wide range of software distributed
+through that system in reliance on consistent application of that
+system; it is up to the author/donor to decide if he or she is willing
+to distribute software through any other system and a licensee cannot
+impose that choice.
+This section is intended to make thoroughly clear what is believed to
+be a consequence of the rest of this License.
+  12. If the distribution and/or use of the Library is restricted in
+certain countries either by patents or by copyrighted interfaces, the
+original copyright holder who places the Library under this License may add
+an explicit geographical distribution limitation excluding those countries,
+so that distribution is permitted only in or among countries not thus
+excluded.  In such case, this License incorporates the limitation as if
+written in the body of this License.
+  13. The Free Software Foundation may publish revised and/or new
+versions of the Lesser General Public License from time to time.
+Such new versions will be similar in spirit to the present version,
+but may differ in detail to address new problems or concerns.
+Each version is given a distinguishing version number.  If the Library
+specifies a version number of this License which applies to it and
+"any later version", you have the option of following the terms and
+conditions either of that version or of any later version published by
+the Free Software Foundation.  If the Library does not specify a
+license version number, you may choose any version ever published by
+  14. If you wish to incorporate parts of the Library into other free
+programs whose distribution conditions are incompatible with these,
+write to the author to ask for permission.  For software which is
+copyrighted by the Free Software Foundation, write to the Free
+Software Foundation; we sometimes make exceptions for this.  Our
+decision will be guided by the two goals of preserving the free status
+of all derivatives of our free software and of promoting the sharing
+and reuse of software generally.
+			    NO WARRANTY
+  15. BECAUSE THE LIBRARY IS LICENSED FREE OF CHARGE, THERE IS NO
+WARRANTY FOR THE LIBRARY, TO THE EXTENT PERMITTED BY APPLICABLE LAW.
+EXCEPT WHEN OTHERWISE STATED IN WRITING THE COPYRIGHT HOLDERS AND/OR
+OTHER PARTIES PROVIDE THE LIBRARY "AS IS" WITHOUT WARRANTY OF ANY
+KIND, EITHER EXPRESSED OR IMPLIED, INCLUDING, BUT NOT LIMITED TO, THE
+IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
+PURPOSE.  THE ENTIRE RISK AS TO THE QUALITY AND PERFORMANCE OF THE
+LIBRARY IS WITH YOU.  SHOULD THE LIBRARY PROVE DEFECTIVE, YOU ASSUME
+THE COST OF ALL NECESSARY SERVICING, REPAIR OR CORRECTION.
+  16. IN NO EVENT UNLESS REQUIRED BY APPLICABLE LAW OR AGREED TO IN
+WRITING WILL ANY COPYRIGHT HOLDER, OR ANY OTHER PARTY WHO MAY MODIFY
+AND/OR REDISTRIBUTE THE LIBRARY AS PERMITTED ABOVE, BE LIABLE TO YOU
+FOR DAMAGES, INCLUDING ANY GENERAL, SPECIAL, INCIDENTAL OR
+CONSEQUENTIAL DAMAGES ARISING OUT OF THE USE OR INABILITY TO USE THE
+LIBRARY (INCLUDING BUT NOT LIMITED TO LOSS OF DATA OR DATA BEING
+RENDERED INACCURATE OR LOSSES SUSTAINED BY YOU OR THIRD PARTIES OR A
+FAILURE OF THE LIBRARY TO OPERATE WITH ANY OTHER SOFTWARE), EVEN IF
+SUCH HOLDER OR OTHER PARTY HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH
+DAMAGES.
+		     END OF TERMS AND CONDITIONS
+           How to Apply These Terms to Your New Libraries
+  If you develop a new library, and you want it to be of the greatest
+possible use to the public, we recommend making it free software that
+everyone can redistribute and change.  You can do so by permitting
+redistribution under these terms (or, alternatively, under the terms of the
+ordinary General Public License).
+  To apply these terms, attach the following notices to the library.  It is
+safest to attach them to the start of each source file to most effectively
+convey the exclusion of warranty; and each file should have at least the
+"copyright" line and a pointer to where the full notice is found.
+    <one line to give the library's name and a brief idea of what it does.>
+    Copyright (C) <year>  <name of author>
+    This library is free software; you can redistribute it and/or
+    modify it under the terms of the GNU Lesser General Public
+    License as published by the Free Software Foundation; either
+    version 2.1 of the License, or (at your option) any later version.
+    This library is distributed in the hope that it will be useful,
+    but WITHOUT ANY WARRANTY; without even the implied warranty of
+    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+    Lesser General Public License for more details.
+    You should have received a copy of the GNU Lesser General Public
+    License along with this library; if not, write to the Free Software
+    Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
+Also add information on how to contact you by electronic and paper mail.
+You should also get your employer (if you work as a programmer) or your
+school, if any, to sign a "copyright disclaimer" for the library, if
+necessary.  Here is a sample; alter the names:
+  Yoyodyne, Inc., hereby disclaims all copyright interest in the
+  library `Frob' (a library for tweaking knobs) written by James Random Hacker.
+  <signature of Ty Coon>, 1 April 1990
+  Ty Coon, President of Vice
+That's all there is to it!
Added: trunk/mapbender/http/classes/phpmailer-1.72/phpdoc/deprecated-list.html
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/phpmailer-1.72/phpdoc/deprecated-list.html?view=auto&rev=54
--- (empty file)
+++ trunk/mapbender/http/classes/phpmailer-1.72/phpdoc/deprecated-list.html	2006-04-13 21:05:53+0000
@@ -0,0 +1,87 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Frameset//EN""http://www.w3.org/TR/REC-html40/frameset.dtd">
+<!--NewPage-->
+<HTML>
+<HEAD>
+<!-- Generated by javadoc on Tue Jun 05 13:47:44 EDT 2001 -->
+<TITLE>
+: Deprecated List
+</TITLE>
+<LINK REL ="stylesheet" TYPE="text/css" HREF="stylesheet.css" TITLE="Style">
+</HEAD>
+<BODY BGCOLOR="white">
+<!-- ========== START OF NAVBAR ========== -->
+<A NAME="navbar_top"><!-- --></A>
+<TABLE BORDER="0" WIDTH="100%" CELLPADDING="1" CELLSPACING="0">
+<TR>
+<TD COLSPAN=2 BGCOLOR="#EEEEFF" CLASS="NavBarCell1">
+<A NAME="navbar_top_firstrow"><!-- --></A>
+<TABLE BORDER="0" CELLPADDING="0" CELLSPACING="3">
+  <TR ALIGN="center" VALIGN="top">
+  <TD BGCOLOR="#EEEEFF" CLASS="NavBarCell1">    <FONT CLASS="NavBarFont1">Class</FONT>&nbsp;</TD>
+  <TD BGCOLOR="#EEEEFF" CLASS="NavBarCell1">    <A HREF="overview-tree.html"><FONT CLASS="NavBarFont1"><B>Tree</B></FONT></A>&nbsp;</TD>
+  <TD BGCOLOR="#FFFFFF" CLASS="NavBarCell1Rev"> &nbsp;<FONT CLASS="NavBarFont1Rev"><B>Deprecated</B></FONT>&nbsp;</TD>
+  <TD BGCOLOR="#EEEEFF" CLASS="NavBarCell1">    <A HREF="index-all.html"><FONT CLASS="NavBarFont1"><B>Index</B></FONT></A>&nbsp;</TD>
+  <TD BGCOLOR="#EEEEFF" CLASS="NavBarCell1">    <A HREF="help-doc.html"><FONT CLASS="NavBarFont1"><B>Help</B></FONT></A>&nbsp;</TD>
+  </TR>
+</TABLE>
+</TD>
+<TD ALIGN="right" VALIGN="top" ROWSPAN=3><EM>
+</EM>
+</TD>
+</TR>
+<TR>
+<TD BGCOLOR="white" CLASS="NavBarCell2"><FONT SIZE="-2">
+&nbsp;PREV&nbsp;
+&nbsp;NEXT</FONT></TD>
+  <A HREF="index.html" TARGET="_top"><B>FRAMES</B></A>  &nbsp;
+&nbsp;<A HREF="deprecated-list.html" TARGET="_top"><B>NO FRAMES</B></A></FONT></TD>
+</TR>
+</TABLE>
+<!-- =========== END OF NAVBAR =========== -->
+<HR>
+<CENTER>
+<H2>
+<B>Deprecated API</B></H2>
+</CENTER>
+<HR>
+<A NAME="navbar_bottom"><!-- --></A>
+<TR>
+<A NAME="navbar_bottom_firstrow"><!-- --></A>
+  </TR>
+</TABLE>
+</TD>
+</EM>
+</TD>
+</TR>
+<TR>
+&nbsp;PREV&nbsp;
+</TR>
+</TABLE>
+<HR>
+</BODY>
+</HTML>
Added: trunk/mapbender/http/classes/phpmailer-1.72/phpdoc/index-all.html
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/phpmailer-1.72/phpdoc/index-all.html?view=auto&rev=54
--- (empty file)
+++ trunk/mapbender/http/classes/phpmailer-1.72/phpdoc/index-all.html	2006-04-13 21:05:53+0000
@@ -0,0 +1,293 @@
+<!--NewPage-->
+<HTML>
+<HEAD>
+<!-- Generated by javadoc on Sat Mar 30 14:15:49 EST 2002 -->
+<TITLE>
+: Index
+</TITLE>
+</HEAD>
+<TR>
+  <TD BGCOLOR="#EEEEFF" CLASS="NavBarCell1">    <A HREF="deprecated-list.html"><FONT CLASS="NavBarFont1"><B>Deprecated</B></FONT></A>&nbsp;</TD>
+  <TD BGCOLOR="#FFFFFF" CLASS="NavBarCell1Rev"> &nbsp;<FONT CLASS="NavBarFont1Rev"><B>Index</B></FONT>&nbsp;</TD>
+  </TR>
+</TABLE>
+</TD>
+</EM>
+</TD>
+</TR>
+<TR>
+&nbsp;PREV&nbsp;
+&nbsp;<A HREF="index-all.html" TARGET="_top"><B>NO FRAMES</B></A></FONT></TD>
+</TR>
+</TABLE>
+<A HREF="#_$_">$</A> <A HREF="#_A_">A</A> <A HREF="#_B_">B</A> <A HREF="#_C_">C</A> <A HREF="#_G_">G</A> <A HREF="#_I_">I</A> <A HREF="#_P_">P</A> <A HREF="#_S_">S</A> <HR>
+<A NAME="_$_"><!-- --></A><H2>
+<B>$</B></H2>
+<DL>
+<DT><A HREF="phpmailer.html#$AltBody"><B>$AltBody</B></A> -
+Variable in class <A HREF="phpmailer.html">phpmailer</A>
+<DD>Sets the text-only body of the message.
+<DT><A HREF="phpmailer.html#$Body"><B>$Body</B></A> -
+<DD>Sets the Body of the message.
+<DT><A HREF="phpmailer.html#$CharSet"><B>$CharSet</B></A> -
+<DD>Sets the CharSet of the message.
+<DT><A HREF="Boundary.html#$CharSet"><B>$CharSet</B></A> -
+Variable in class <A HREF="Boundary.html">Boundary</A>
+<DD>Sets the Char set.
+<DT><A HREF="phpmailer.html#$ConfirmReadingTo"><B>$ConfirmReadingTo</B></A> -
+<DD>Sets the email address that a reading confirmation will be sent.
+<DT><A HREF="phpmailer.html#$ContentType"><B>$ContentType</B></A> -
+<DD>Sets the Content-type of the message.
+<DT><A HREF="Boundary.html#$ContentType"><B>$ContentType</B></A> -
+<DD>Sets the boundary Content Type.
+<DT><A HREF="Boundary.html#$Disposition"><B>$Disposition</B></A> -
+<DD>Sets an attachment disposition.
+<DT><A HREF="phpmailer.html#$Encoding"><B>$Encoding</B></A> -
+<DD>Sets the Encoding of the message.
+<DT><A HREF="Boundary.html#$Encoding"><B>$Encoding</B></A> -
+<DD>Sets the Encoding.
+<DT><A HREF="phpmailer.html#$ErrorInfo"><B>$ErrorInfo</B></A> -
+<DD>Holds the most recent mailer error message.
+<DT><A HREF="Boundary.html#$FileName"><B>$FileName</B></A> -
+<DD>Sets an attachment file name.
+<DT><A HREF="phpmailer.html#$From"><B>$From</B></A> -
+<DD>Sets the From email address for the message.
+<DT><A HREF="phpmailer.html#$FromName"><B>$FromName</B></A> -
+<DD>Sets the From name of the message.
+<DT><A HREF="phpmailer.html#$Helo"><B>$Helo</B></A> -
+<DD>Sets the SMTP HELO of the message.
+<DT><A HREF="phpmailer.html#$Host"><B>$Host</B></A> -
+<DD>Sets the SMTP hosts.
+<DT><A HREF="phpmailer.html#$LE"><B>$LE</B></A> -
+<DD>Sets the line endings of the message.
+<DT><A HREF="Boundary.html#$LE"><B>$LE</B></A> -
+<DT><A HREF="phpmailer.html#$Mailer"><B>$Mailer</B></A> -
+<DD>Method to send mail: ("mail", "sendmail", or "smtp").
+<DT><A HREF="phpmailer.html#$Password"><B>$Password</B></A> -
+<DD>Sets SMTP password.
+<DT><A HREF="phpmailer.html#$PluginDir"><B>$PluginDir</B></A> -
+<DD>Path to phpmailer plugins.
+<DT><A HREF="phpmailer.html#$Port"><B>$Port</B></A> -
+<DD>Sets the default SMTP server port.
+<DT><A HREF="phpmailer.html#$Priority"><B>$Priority</B></A> -
+<DD>Email priority (1 = High, 3 = Normal, 5 = low).
+<DT><A HREF="phpmailer.html#$Sender"><B>$Sender</B></A> -
+<DD>Sets the Sender email of the message.
+<DT><A HREF="phpmailer.html#$Sendmail"><B>$Sendmail</B></A> -
+<DD>Sets the path of the sendmail program.
+<DT><A HREF="phpmailer.html#$SMTPAuth"><B>$SMTPAuth</B></A> -
+<DD>Sets SMTP authentication.
+<DT><A HREF="phpmailer.html#$Subject"><B>$Subject</B></A> -
+<DD>Sets the Subject of the message.
+<DT><A HREF="phpmailer.html#$UseMSMailHeaders"><B>$UseMSMailHeaders</B></A> -
+<DD>Turns Microsoft mail client headers on and off.
+<DT><A HREF="phpmailer.html#$Username"><B>$Username</B></A> -
+<DD>Sets SMTP username.
+<DT><A HREF="phpmailer.html#$Version"><B>$Version</B></A> -
+<DD>Holds phpmailer version.
+<DT><A HREF="phpmailer.html#$WordWrap"><B>$WordWrap</B></A> -
+<DD>Sets word wrapping on the body of the message to a given number of
+ characters.
+</DL>
+<HR>
+<A NAME="_A_"><!-- --></A><H2>
+<B>A</B></H2>
+<DL>
+<DT><A HREF="phpmailer.html#AddAddress(var, var)"><B>AddAddress(var, var)</B></A> -
+Method in class <A HREF="phpmailer.html">phpmailer</A>
+<DD>Adds a "To" address.
+<DT><A HREF="phpmailer.html#AddAttachment(var, var, var, var)"><B>AddAttachment(var, var, var, var)</B></A> -
+<DD>Adds an attachment from a path on the filesystem.
+<DT><A HREF="phpmailer.html#AddBCC(var, var)"><B>AddBCC(var, var)</B></A> -
+<DD>Adds a "Bcc" address.
+<DT><A HREF="phpmailer.html#AddCC(var, var)"><B>AddCC(var, var)</B></A> -
+<DD>Adds a "Cc" address.
+<DT><A HREF="phpmailer.html#AddCustomHeader(var)"><B>AddCustomHeader(var)</B></A> -
+<DD>Adds a custom header.
+<DT><A HREF="phpmailer.html#AddEmbeddedImage(var, var, var, var, var)"><B>AddEmbeddedImage(var, var, var, var, var)</B></A> -
+<DD>Adds an embedded attachment.
+<DT><A HREF="phpmailer.html#AddReplyTo(var, var)"><B>AddReplyTo(var, var)</B></A> -
+<DD>Adds a "Reply-to" address.
+<DT><A HREF="phpmailer.html#AddStringAttachment(var, var, var, var)"><B>AddStringAttachment(var, var, var, var)</B></A> -
+<DD>Adds a string or binary attachment (non-filesystem) to the list.
+</DL>
+<HR>
+<A NAME="_B_"><!-- --></A><H2>
+<B>B</B></H2>
+<DL>
+<DT><A HREF="Boundary.html"><B>Boundary</B></A> - class <A HREF="Boundary.html">Boundary</A>.<DD>Boundary - MIME message boundary class<DT><A HREF="Boundary.html#Boundary(var)"><B>Boundary(var)</B></A> -
+Constructor for class <A HREF="Boundary.html">Boundary</A>
+<DD>Main constructor.
+</DL>
+<HR>
+<A NAME="_C_"><!-- --></A><H2>
+<B>C</B></H2>
+<DL>
+<DT><A HREF="phpmailer.html#ClearAddresses()"><B>ClearAddresses()</B></A> -
+<DD>Clears all recipients assigned in the TO array.
+<DT><A HREF="phpmailer.html#ClearAllRecipients()"><B>ClearAllRecipients()</B></A> -
+<DD>Clears all recipients assigned in the TO, CC and BCC
+ array.
+<DT><A HREF="phpmailer.html#ClearAttachments()"><B>ClearAttachments()</B></A> -
+<DD>Clears all previously set filesystem, string, and binary
+ attachments.
+<DT><A HREF="phpmailer.html#ClearBCCs()"><B>ClearBCCs()</B></A> -
+<DD>Clears all recipients assigned in the BCC array.
+<DT><A HREF="phpmailer.html#ClearCCs()"><B>ClearCCs()</B></A> -
+<DD>Clears all recipients assigned in the CC array.
+<DT><A HREF="phpmailer.html#ClearCustomHeaders()"><B>ClearCustomHeaders()</B></A> -
+<DD>Clears all custom headers.
+<DT><A HREF="phpmailer.html#ClearReplyTos()"><B>ClearReplyTos()</B></A> -
+<DD>Clears all recipients assigned in the ReplyTo array.
+</DL>
+<HR>
+<A NAME="_G_"><!-- --></A><H2>
+<B>G</B></H2>
+<DL>
+<DT><A HREF="Boundary.html#GetSource(var)"><B>GetSource(var)</B></A> -
+Method in class <A HREF="Boundary.html">Boundary</A>
+<DD>Returns the source of the boundary.
+</DL>
+<HR>
+<A NAME="_I_"><!-- --></A><H2>
+<B>I</B></H2>
+<DL>
+<DT><A HREF="phpmailer.html#IsHTML(var)"><B>IsHTML(var)</B></A> -
+<DD>Sets message type to HTML.
+<DT><A HREF="phpmailer.html#IsMail()"><B>IsMail()</B></A> -
+<DD>Sets Mailer to send message using PHP mail() function.
+<DT><A HREF="phpmailer.html#IsQmail()"><B>IsQmail()</B></A> -
+<DD>Sets Mailer to send message using the qmail MTA.
+<DT><A HREF="phpmailer.html#IsSendmail()"><B>IsSendmail()</B></A> -
+<DD>Sets Mailer to send message using the $Sendmail program.
+<DT><A HREF="phpmailer.html#IsSMTP()"><B>IsSMTP()</B></A> -
+<DD>Sets Mailer to send message using SMTP.
+</DL>
+<HR>
+<A NAME="_P_"><!-- --></A><H2>
+<B>P</B></H2>
+<DL>
+<DT><A HREF="phpmailer.html"><B>phpmailer</B></A> - class <A HREF="phpmailer.html">phpmailer</A>.<DD>phpmailer - PHP email transport class<DT><A HREF="phpmailer.html#phpmailer()"><B>phpmailer()</B></A> -
+Constructor for class <A HREF="phpmailer.html">phpmailer</A>
+<DD>&nbsp;
+</DL>
+<HR>
+<A NAME="_S_"><!-- --></A><H2>
+<B>S</B></H2>
+<DL>
+<DT><A HREF="phpmailer.html#Send()"><B>Send()</B></A> -
+<DD>Creates message and assigns Mailer.
+<DT><A HREF="phpmailer.html#SendToQueue(var, var)"><B>SendToQueue(var, var)</B></A> -
+<DD>Sends mail message to an assigned queue directory.
+</DL>
+<HR>
+<TR>
+  </TR>
+</TABLE>
+</TD>
+</EM>
+</TD>
+</TR>
+<TR>
+&nbsp;PREV&nbsp;
+</TR>
+</TABLE>
+<HR>
+</BODY>
+</HTML>
More information about the Mapbender_commits mailing list
