svn commit: r58 - trunk/mapbender/resources: . db db/mysql db/mysql/iso db/mysql/utf8 db/postgresql db/postgresql/iso db/postgresql/utf8 db/update
uli at osgeo.org
uli at osgeo.org
Thu Apr 13 17:12:53 EDT 2006
Author: uli
Date: 2006-04-13 21:12:53+0000
New Revision: 58
Added:
trunk/mapbender/resources/
trunk/mapbender/resources/db/
trunk/mapbender/resources/db/ReadMe.txt
trunk/mapbender/resources/db/mysql/
trunk/mapbender/resources/db/mysql/iso/
trunk/mapbender/resources/db/mysql/iso/mysql_data.sql
trunk/mapbender/resources/db/mysql/mysql_schema.sql
trunk/mapbender/resources/db/mysql/utf8/
trunk/mapbender/resources/db/mysql/utf8/mysql_data.sql
trunk/mapbender/resources/db/postgresql/
trunk/mapbender/resources/db/postgresql/iso/
trunk/mapbender/resources/db/postgresql/iso/pgsql_data.sql
trunk/mapbender/resources/db/postgresql/pgsql_schema.sql
trunk/mapbender/resources/db/postgresql/pgsql_serial_set_sequences.sql
trunk/mapbender/resources/db/postgresql/pgsql_serial_set_sequences_7x.sql
trunk/mapbender/resources/db/postgresql/utf8/
trunk/mapbender/resources/db/postgresql/utf8/pgsql_data.sql
trunk/mapbender/resources/db/update/
trunk/mapbender/resources/db/update/update_guis_iso.sql
trunk/mapbender/resources/db/update/update_guis_utf8.sql
trunk/mapbender/resources/db/update/update_postgresql_db.sql
import Mapbender source without history
Added: trunk/mapbender/resources/db/ReadMe.txt
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/resources/db/ReadMe.txt?view=auto&rev=58
--- (empty file)
+++ trunk/mapbender/resources/db/ReadMe.txt 2006-04-13 21:12:53+0000
@@ -0,0 +1,96 @@
+Read the description in the Mapbender Wiki
+http://www.mapbender.org/index.php/Installation
+Every Mapbender User is invited to let the Mapbender Wiki grow.
+If you want an account to edit any of these Wiki pages please write an email to info at mapbender.org and request for an ID and password.
+You need a valid email address to be able to edit this Wiki.
+-- 1. Database:
+-- MySQL --
+-- Create a Database:
+-- select the encoding to run your databse: UTF8 or Latin is possible (choose in the mapbender.conf)
+-- To Show the possible character sets:
+SHOW CHARACTER SET;
+SHOW COLLATION;
+-- database with utf8 encoding
+create database mapbender CHARACTER SET utf8 COLLATE utf8_general_ci ;
+-- database with ISO-8859-1 encoding
+create database mapbender CHARACTER SET latin1 COLLATE latin1_german1_ci ;
+-- select the database mapbender
+use mapbender
+--If you want to run Mapbender with MySQL load the following files:
+1. mysql_schema.sql (creates tables, keys, constraints)
+2. mysql_data.sql (loads data)
+-- run the scripts as follow:
+source mysql_schema.sql
+source mysql_data.sql (make sure, that you use the right sql for the right encoding)
+-- To Update the password of the user root use the following sql
+UPDATE mb_user set mb_user_password = password('root') where mb_user_name = 'root';
+-- PostgreSQL --
+-- Create a Database with Latin1 or UTF8 encoding
+If you want to run Mapbender with PostgreSQL load the following files:
+1. pgsql_schema.sql (creates tables, keys, constraints)
+2. pgsql_data.sql (loads data)
+3. pgsql_serial_set_sequences_7x.sql or pgsql_serial_set_sequences.sql
+(depending on wich postgresql version you use, sets the values for the sequences)
+- Zählerstand der Sequenz für Serial-Felder (Autowerte)
+-- How to load the sqls in PostgreSQL:
+psql -f pgsql_schema.sql <dbname>
+psql -f pgsql_data.sql <dbname>
+psql -f pgsql_serial_set_sequences.sql <dbname>
+Passwordencryption in PostgreSQL with md5
+If you want to get encrypted passwords you have to choose MD5 true (see mapbender.conf, default is false).
+You only can choose md5, when your PostgreSQL supports the function md5(). You can check this with the following SQL : Select md5('root');
+At the moment in the database mb_user.mb_user_password = 'root' (see pgsql_data.sql)
+If you want to use md5 send the following SQL to set the password in md5-encoding:
+UPDATE mb_user set mb_user_password = md5('root') where mb_user_name = 'root';
+-- 2. mapbender configuration
+configure the file mapbender.conf
+-- check the database connection
+http://localhost/tools/mapbender_setup.php
+-- 3. print configuration
+to use the pdfprint configure the files:
+mapbender_2.2.1\http\print\printPDF.conf (if you use the print in an iframe)
+mapbender_2.2.1\http\print\printPDF_b.conf (if you use the print with a button - b for button)
Added: trunk/mapbender/resources/db/mysql/iso/mysql_data.sql
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/resources/db/mysql/iso/mysql_data.sql?view=auto&rev=58
--- (empty file)
+++ trunk/mapbender/resources/db/mysql/iso/mysql_data.sql 2006-04-13 21:12:53+0000
@@ -0,0 +1,8135 @@
+-- mysql data iso-8859-1
+-- Mapbender (Version: 2.2.3)
+-- 2006-03-10
+SET FOREIGN_KEY_CHECKS=0;
+-- Daten für Tabelle `gui`
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('admin1', 'admin1', 'all administration modules', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('admin2_de', 'admin2_de', 'admin GUI in Deutsch', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('admin2_en', 'admin2_en', 'admin GUI in english', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('gui', 'gui', 'client element collection', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('gui1', 'gui1', 'client element collection', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('wms_africa', 'wms_africa', 'Container for Africa data', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('wms_australia', 'wms_australia', 'Container for Australia data', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('wms_europe', 'wms_europe', 'container for europe data', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('wms_gdi_de', 'wms_gdi_de', 'WMS Dienste Germany', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('wms_germany', 'wms_germany', 'container for germany data', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('wms_north_america', 'wms_north_america', 'Container for north America data', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('wms_worldwide', 'wms_worldwide', 'Container for world wide data', 1);
+-- Daten für Tabelle `gui_element`
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'AdminFrame', 0002, 1, 'the frame for administration modules', 'iframe', '', 'frameborder = "0"', 200, 20, 800, 800, 0, '', '', 'iframe', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'body', 0001, 1, 'navigation', 'body', '', 'onload=''mod_adminNavigation_init()''', 0, 0, 0, 0, 0, '', '', '', 'mod_adminNavigation.js', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'CreateTreeGDE', 0002, 1, 'create a foldertree for a individual geodataexplorer', 'a', '', 'href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ', 10, 810, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'CREATE TREE_GDE', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'deleteGui', 0002, 1, 'delete gui', 'a', '', 'href = "../php/mod_deleteGUI.php?sessionID" target = "AdminFrame" ', 10, 150, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'DELETE GUI', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'deleteWMS', 0002, 1, 'delete wms', 'a', '', 'href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ', 10, 110, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'DELETE WMS', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'delete_filteredGui', 0002, 1, 'delete guis of this admin', 'a', '', 'href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ', 10, 790, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'DELETE myGUI', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'editElements', 0002, 1, 'edit gui elements', 'a', '', 'href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ', 10, 170, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;', 'EDIT GUI-ELEMENTS', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'editFilteredGroup', 0002, 1, 'edit group of this admin', 'a', '', 'href = "../php/mod_editFilteredGroup.php?sessionID" target = "AdminFrame" ', 10, 530, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'EDIT myGROUP', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'editFilteredUser', 0002, 1, 'save, edit, delete user where this admin is owner', 'a', '', 'href = "../php/mod_editFilteredUser.php?sessionID" target="AdminFrame"', 10, 350, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'EDIT myUSER', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'editGroup', 0002, 1, 'edit group', 'a', '', 'href = "../php/mod_editGroup.php?sessionID" target = "AdminFrame" ', 10, 510, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'EDIT GROUP', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'editGUI_WMS', 0002, 1, 'edit the elements of the gui', 'a', '', 'href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"', 10, 90, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'EDIT GUI-WMS', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'editUser', 0002, 1, 'save, edit, delete user', 'a', '', 'href = "../php/mod_editUser.php?sessionID" target="AdminFrame"', 10, 330, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'EDIT USER', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'exportGUI', 0002, 1, 'export gui, create SQLL', 'a', '', 'href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ', 10, 310, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'EXPORT GUI', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'filteredGoup_filteredUser', 0002, 1, 'allocate the groups of this admin to user where the admin is owner', 'a', '', 'href = "../php/mod_filteredGroup_filteredUser.php?sessionID&e_id_css=filteredGoup_filteredUser" target = "AdminFrame" ', 10, 590, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myGROUP -> myUSER\r\n', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'filteredGroup_filteredGui', 0002, 1, 'allocate groups of this admin to guis of this admin', 'a', '', 'href = "../php/mod_filteredGroup_filteredGui.php?sessionID&e_id_css=filteredGroup_filteredGui" target = "AdminFrame" ', 10, 730, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myGROUP -> myGUI', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'filteredGroup_Gui', 0002, 1, 'allocate groups of this admin to guis', 'a', '', 'href = "../php/mod_filteredGroup_Gui.php?sessionID&e_id_css=filteredGroup_Gui" target = "AdminFrame" ', 10, 750, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myGROUP -> GUI', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'filteredGroup_User', 0002, 1, 'allocate groups of this admin to user', 'a', '', 'href = "../php/mod_filteredGroup_User.php?sessionID&e_id_css=filteredGroup_User" target = "AdminFrame" ', 10, 690, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myGROUP -> USER', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'filteredGui_filteredGroup', 0002, 1, 'allocate guis of this admin to groups where this admin is owner', 'a', '', 'href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target = "AdminFrame" ', 10, 290, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myGUI -> myGROUP', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'filteredGui_filteredUser', 0002, 1, 'allocate the user where the admin is owner to his guis ', 'a', '', 'href = "../php/mod_filteredGui_filteredUser.php?sessionID&e_id_css=filteredGui_filteredUser" target = "AdminFrame" ', 10, 230, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myGUI -> myUSER', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'filteredGui_Group', 0002, 1, 'allocate guis to groups', 'a', '', 'href = "../php/mod_filteredGui_group.php?sessionID&e_id_css=filteredGui_Group" target = "AdminFrame" ', 10, 270, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myGUI -> GROUP ', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'filteredGui_user', 0002, 1, 'allocate the guis of this admin to a user', 'a', '', 'href = "../php/mod_filteredGui_User.php?sessionID&e_id_css=filteredGui_user" target = "AdminFrame" ', 10, 210, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myGUI -> USER ', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'filteredUser_filteredGroup', 0002, 1, 'allocate user where this admin is owner to groups where this admin is owner', 'a', '', 'href = "../php/mod_filteredUser_filteredGroup.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ', 10, 490, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myUSER -> myGROUP', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'filteredUser_filteredGui', 0002, 1, 'allocate admins user to guis of this admin', 'a', '', 'href = "../php/mod_filteredUser_filteredGui.php?sessionID&e_id_css=filteredUser_filteredGui" target = "AdminFrame" ', 10, 410, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myUSER -> myGUI', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'filteredUser_Group', 0002, 1, 'allocate user of this admin to groups', 'a', '', 'href = "../php/mod_filteredUser_Group.php?sessionID&e_id_css=filteredUser_Group" target = "AdminFrame" ', 10, 670, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myUSER -> GROUP', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'filteredUser_Gui', 0002, 1, 'allocate user of this admin to guis', 'a', '', 'href = "../php/mod_filteredUser_Gui.php?sessionID&e_id_css=filteredUser_Gui" target = "AdminFrame" ', 10, 770, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myUSER -> GUI', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'getStyles', 0002, 1, 'load styles from wms', 'a', '', 'href = \\"../php/mod_getStyles.php?sessionID\\" target = \\"AdminFrame\\" ', 10, 890, 200, 20, NULL, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GET_STYLES', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'Group_filteredGui', 0002, 1, 'allocate Groups to the guis of this admin', 'a', '', 'href = "../php/mod_group_filteredGui.php?sessionID&e_id_css=Group_filteredGui" target = "AdminFrame" ', 10, 710, 200, 20, NULL, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GROUP -> myGUI', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'group_filteredUser', 0002, 1, 'allocate groups to user where this admin is owner', 'a', '', 'href = "../php/mod_group_filteredUser.php?sessionID&e_id_css=group_filteredUser" target = "AdminFrame" ', 10, 570, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GROUP -> myUSER', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'Group_Gui', 0002, 1, 'allocate groups to guis', 'a', '', 'href = "../php/mod_group_gui.php?sessionID&e_id_css=Group_Gui" target = "AdminFrame" ', 10, 610, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GROUP -> GUI', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'Group_User', 0002, 1, 'allocate groups to user', 'a', '', 'href = "../php/mod_group_user.php?sessionID&e_id_css=Group_User" target = "AdminFrame" ', 10, 550, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;', 'GROUP -> USER', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'gui_filteredGroup', 0002, 1, 'allocate guis to groups of this admin', 'a', '', 'href = "../php/mod_gui_filteredGroup.php?sessionID&e_id_css=gui_filteredGroup" target = "AdminFrame" ', 10, 650, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GUI -> myGROUP', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'gui_filteredUser', 0002, 1, 'allocate guis to user of this admin', 'a', '', 'href = "../php/mod_gui_filteredUser.php?sessionID&e_id_css=gui_filteredUser" target = "AdminFrame" ', 10, 630, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GUI -> myUSER', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'Gui_Group', 0002, 1, 'allocate guis to groups', 'a', '', 'href = "../php/mod_gui_group.php?sessionID&e_id_css=Gui_Group" target = "AdminFrame" ', 10, 250, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GUI -> GROUP', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'gui_owner', 0002, 1, 'set owner', 'a', '', 'href = "../php/mod_gui_owner.php?sessionID&e_id_css=gui_owner" target = "AdminFrame" ', 10, 870, 200, 20, NULL, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GUI -> OWNER', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'Gui_User', 0002, 1, 'allocate a gui to user', 'a', '', 'href = "../php/mod_gui_user.php?sessionID&e_id_css=Gui_User" target = "AdminFrame" ', 10, 190, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GUI -> USER', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'loadWFS', 0002, 1, 'load capabilities in a gui', 'a', '', 'href = "../php/mod_loadWFSCapabilities.php?sessionID" target="AdminFrame"', 10, 830, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'LOAD WFS', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'loadWMS', 0002, 1, 'load capabilities in a gui', 'a', '', 'href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"', 10, 30, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'LOAD WMS', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'loadWMSList', 0002, 1, 'load wms from a list', 'a', '', 'href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"', 10, 50, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'LOAD myWMS', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'logout', 0002, 1, 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0''\r\nonmouseover=''this.src="../img/button_gray/logout_over.png"''\r\nonmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"', 180, 2, 24, 24, 1, '', '', 'img', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'myGUIlist', 0002, 1, 'go back to your GUI list', 'img', '../img/button_gray/home_off.png', 'onClick="window.location.href=''login.php?sessionID''" border=''0''\r\nonmouseover=''this.src="../img/button_gray/home_over.png"''\r\nonmouseout=''this.src="../img/button_gray/home_off.png"'' title="move back to your GUI list / zurück zur GUI Liste"', 150, 2, 24, 24, 1, '', '', 'img', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'newGui', 0002, 1, 'create a new gui', 'a', '', 'href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ', 10, 130, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;', 'NEW GUI', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'rename_copy_Gui', 0002, 1, 'rename and copy gui', 'a', '', 'href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ', 10, 470, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'RENAME COPY GUI', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'showLoggedUser', 0002, 1, 'displays the logged admin', 'iframe', '../php/mod_showLoggedUser.php?sessionID', 'frameborder="0" scrolling=''no''', 10, 2, 200, 30, 0, '', '', 'iframe', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'updateWMSs', 0002, 1, 'edit the elements of the gui', 'a', '', 'href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"', 10, 70, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'UPDATE WMS', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'user_filteredGroup', 0002, 1, 'allocate user to groups where this admin is owner', 'a', '', 'href = "../php/mod_user_filteredGroup.php?sessionID&e_id_css=user_filteredGroup" target = "AdminFrame" ', 10, 450, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'USER -> myGROUP', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'user_filteredGui', 0002, 1, 'allocate guis of this admin to user', 'a', '', 'href = "../php/mod_user_filteredGui.php?sessionID&e_id_css=user_filteredGui" target = "AdminFrame" ', 10, 390, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'USER-> myGUI', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'User_Group', 0002, 1, 'allocat user to groups', 'a', '', 'href = "../php/mod_user_group.php?sessionID&e_id_css=User_Group" target = "AdminFrame" ', 10, 430, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'USER -> GROUP', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'user_gui', 0002, 1, 'allocate guis to user', 'a', '', 'href = "../php/mod_user_gui.php?sessionID&e_id_css=user_gui" target = "AdminFrame" ', 10, 370, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'USER -> GUI ', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin1', 'wfs_conf', 0002, 1, 'create and edit a gazetteer module', 'a', '', 'href=\\"../php/mod_wfs_conf.php?sessionID\\"\\'' target=\\"AdminFrame\\"', 10, 850, 200, 20, NULL, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'WFS CONF', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_de', 'AdminFrame', 0002, 1, 'Bereich für Administrationsmodule', 'iframe', '', 'frameborder = "0"', 200, 20, 800, 800, 0, '', '', 'iframe', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_de', 'body', 0001, 1, 'Navigation', 'body', '', 'onload=''mod_adminNavigation_init()''', 0, 0, 180, 20, 0, '', '', '', 'mod_adminNavigation.js', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_de', 'CreateTreeGDE', 0002, 1, 'Ordnerbaum konfigurieren', 'a', '', 'href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ', 10, 280, 180, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Ordnerbaum konfigurieren', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_de', 'deleteWMS', 0002, 1, '!Vollständig löschen!', 'a', '', 'href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ', 10, 100, 180, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', '!Vollständig löschen!', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_de', 'delete_filteredGui', 0002, 1, 'GUI löschen', 'a', '', 'href = "../php/mod_deleteFilteredGUI?sessionID" target = "AdminFrame" ', 110, 240, 80, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GUI löschen', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_de', 'editElements', 0002, 1, 'Oberflächenelemente editieren', 'a', '', 'href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ', 10, 260, 180, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;', 'Oberflächenelemente editieren', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_de', 'editFilteredGroup', 0002, 1, 'Gruppe anlegen und editieren', 'a', '', 'href = "../php/mod_editFilteredGroup.php?sessionID" target = "AdminFrame" ', 10, 400, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Gruppe anlegen und editieren', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_de', 'editFilteredUser', 0002, 1, 'Benutzer anlegen und editieren', 'a', '', 'href = "../php/mod_editFilteredUser.php?sessionID" target="AdminFrame"', 10, 380, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Benutzer anlegen und editieren', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_de', 'editGUI_WMS', 0002, 1, 'WMS GUI Einstellungen', 'a', '', 'href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"', 10, 180, 180, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'WMS GUI Einstellungen', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_de', 'exportGUI', 0002, 1, 'Oberfläche (GUI) exportieren, SQL erzeugen', 'a', '', 'href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ', 10, 300, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Oberfläche exportieren (SQL)', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_de', 'filteredGoup_filteredUser', 0002, 1, 'Gruppe mit Benutzern bestücken', 'a', '', 'href = "../php/mod_filteredGroup_filteredUser.php?sessionID&e_id_css=filteredGoup_filteredUser" target = "AdminFrame" ', 10, 440, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Gruppe mit Benutzern bestücken\r\n', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_de', 'filteredGroup_filteredGui', 0002, 1, 'Einzelner Gruppe mehrere Oberflaechen zuordnen', 'a', '', 'href = "../php/mod_filteredGroup_filteredGui.php?sessionID&e_id_css=filteredGroup_filteredGui" target = "AdminFrame" ', 10, 570, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Einzelner Gruppe mehrere <br>Oberflächen zuordnen', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_de', 'filteredGui_filteredGroup', 0002, 1, 'Einzelner Oberfläche mehrere Gruppen zuordnen', 'a', '', 'href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target = "AdminFrame" ', 10, 605, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Einzelner Oberfläche mehrere<br> Gruppen zuordnen', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_de', 'filteredGui_filteredUser', 0002, 1, 'Oberfläche mehreren Benutzer zuordnen ', 'a', '', 'href = "../php/mod_filteredGui_filteredUser.php?sessionID&e_id_css=filteredGui_filteredUser" target = "AdminFrame" ', 10, 535, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Oberfläche mehreren Benutzern <br> zuordnen', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_de', 'filteredUser_filteredGroup', 0002, 1, 'Benutzer in Gruppen eintragen', 'a', '', 'href = "../php/mod_filteredUser_filteredGroup.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ', 10, 420, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Benutzer in Gruppen eintragen', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_de', 'filteredUser_filteredGui', 0002, 1, 'Einem Nutzer Zugriff auf mehrere Oberflächen erteilen', 'a', '', 'href = "../php/mod_filteredUser_filteredGui.php?sessionID&e_id_css=filteredUser_filteredGui" target = "AdminFrame" ', 10, 500, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Einem Nutzer Zugriff auf <br> mehrere Oberflächen erteilen', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_de', 'gui_owner', 0002, 1, 'GUI editieren Benutzer/Gruppe zuordnen', 'a', '', 'href = "../php/mod_gui_owner.php?sessionID" target = "AdminFrame" ', 10, 640, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GUI editieren Benutzer/Gruppe zuordnen', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_de', 'layout_0', 0003, 1, 'Hintergrund WMS Verwaltung Rahmen', 'div', '', '', 3, 35, 190, 90, 1, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #008000;background-color:red;', '', 'div', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_de', 'layout_1', 0003, 1, 'Hintergrund WMS Management', 'div', '', '', 5, 37, 186, 86, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 14px; text-decoration : none; color: #000080;background-color:white;', ' WMS Verwaltung', 'div', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_de', 'layout_1a', 0003, 1, 'Hintergrund WMS Zuordnung Rahmen', 'div', '', '', 3, 135, 190, 70, 1, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #008000;background-color:red;', '', 'div', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_de', 'layout_1b', 0003, 1, 'Hintergrund WMS Zuordnung', 'div', '', '', 5, 137, 186, 66, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 14px; text-decoration : none; color: #000080;background-color:white;', ' WMS Zuordnung', 'div', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_de', 'layout_1c', 0003, 1, 'Hintergrund Oberflächenverwaltung Rahmen', 'div', '', '', 3, 215, 190, 130, 1, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #008000;background-color:red;', '', 'div', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_de', 'layout_1d', 0003, 1, 'Hintergrund Oberflächenverwaltung', 'div', '', '', 5, 217, 186, 126, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 14px; text-decoration : none; color: #000080;background-color:white;', ' Oberflächenverwaltung', 'div', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_de', 'layout_2', 0003, 1, 'Hintergrund Benutzerverwaltung Rahmen', 'div', '', '', 3, 355, 190, 110, 1, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #008000;background-color:red;', '', 'div', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_de', 'layout_3', 0003, 1, 'Hintergrund Benutzerverwaltung', 'div', '', '', 5, 357, 186, 106, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 14px; text-decoration : none; color: #000080;background-color:white;', ' Benutzerverwaltung', 'div', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_de', 'layout_4', 0003, 1, 'Hintergrund Benutzerzugriff erteilen Rahmen', 'div', '', '', 3, 475, 190, 200, 1, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #008000;background-color:red;', '', 'div', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_de', 'layout_5', 0003, 1, 'Hintergrund Benutzerzugriff erteilen', 'div', '', '', 5, 477, 186, 196, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 14px; text-decoration : none; color: #000080;background-color:white;', ' Benutzerzugriff erteilen', 'div', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_de', 'loadWMS', 0002, 1, 'Capabilities hochladen', 'a', '', 'href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"', 10, 60, 180, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Capabilities hochladen', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_de', 'loadWMSList', 0002, 1, 'WMS in GUI einbinden', 'a', '', 'href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"', 10, 160, 180, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'WMS in GUI einbinden', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_de', 'logout', 0002, 1, 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0''\r\nonmouseover=''this.src="../img/button_gray/logout_over.png"''\r\nonmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"', 180, 2, 24, 24, 2, '', '', 'img', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_de', 'myGUIlist', 0002, 1, 'Zurück zur eigenen GUI Liste', 'img', '../img/button_gray/home_off.png', 'onClick="window.location.href=''login.php?sessionID''" border=''0''\r\nonmouseover=''this.src="../img/button_gray/home_over.png"''\r\nonmouseout=''this.src="../img/button_gray/home_off.png"'' title="move back to your GUI list / zurück zur GUI Liste"', 150, 2, 24, 24, 2, '', '', 'img', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_de', 'newGui', 0002, 1, 'GUI erzeugen', 'a', '', 'href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ', 10, 240, 85, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;', 'GUI erzeugen', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_de', 'rename_copy_Gui', 0002, 1, 'GUI umbenennen/ kopieren', 'a', '', 'href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ', 10, 320, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GUI umbenennen/kopieren', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_de', 'showLoggedUser', 0002, 1, 'Anzeige des eingeloggten Benutzers', 'iframe', '../php/mod_showLoggedUser.php?sessionID', 'frameborder="0" scrolling=''no''', 1, 1, 200, 30, 1, 'background-color:lightgrey;', '', 'iframe', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_de', 'updateWMSs', 0002, 1, 'Hochgeladene aktualisieren', 'a', '', 'href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"', 10, 80, 180, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Hochgeladene aktualisieren', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_en', 'AdminFrame', 0002, 1, 'the frame for administration modules', 'iframe', '', 'frameborder = "0"', 200, 20, 800, 800, 0, '', '', 'iframe', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_en', 'body', 0001, 1, 'navigation', 'body', '', 'onload=''mod_adminNavigation_init()''', 0, 0, 0, 0, 0, '', '', '', 'mod_adminNavigation.js', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_en', 'CreateTreeGDE', 0002, 1, 'TreeGDE set up', 'a', '', 'href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ', 10, 280, 180, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'TreeGDE set up', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_en', 'deleteWMS', 0002, 1, '!Delete completely!', 'a', '', 'href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ', 10, 100, 180, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', '!Delete completely!', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_en', 'delete_filteredGui', 0002, 1, 'Delete GUI', 'a', '', 'href = "../php/mod_deleteFilteredGUI?sessionID" target = "AdminFrame" ', 110, 240, 80, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Delete GUI', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_en', 'editElements', 0002, 1, 'Edit GUI elements', 'a', '', 'href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ', 10, 260, 180, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;', 'Edit GUI elements', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_en', 'editFilteredGroup', 0002, 1, 'Create and edit group', 'a', '', 'href = "../php/mod_editFilteredGroup.php?sessionID" target = "AdminFrame" ', 10, 400, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Create and edit group', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_en', 'editFilteredUser', 0002, 1, 'Create and edit user', 'a', '', 'href = "../php/mod_editFilteredUser.php?sessionID" target="AdminFrame"', 10, 380, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Create and edit user', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_en', 'editGUI_WMS', 0002, 1, 'WMS GUI settings', 'a', '', 'href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"', 10, 180, 180, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'WMS GUI settings', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_en', 'exportGUI', 0002, 1, 'export GUI, create SQL', 'a', '', 'href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ', 10, 300, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Export GUI (SQL)', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_en', 'filteredGoup_filteredUser', 0002, 1, 'Add several users to one group', 'a', '', 'href = "../php/mod_filteredGroup_filteredUser.php?sessionID&e_id_css=filteredGoup_filteredUser" target = "AdminFrame" ', 10, 440, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Add several users to one group\r\n', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_en', 'filteredGroup_filteredGui', 0002, 1, 'Allow one group access to several GUIs', 'a', '', 'href = "../php/mod_filteredGroup_filteredGui.php?sessionID&e_id_css=filteredGroup_filteredGui" target = "AdminFrame" ', 10, 570, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Allow one group access to <br> several GUIs', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_en', 'filteredGui_filteredGroup', 0002, 1, 'Allow several groups access to one GUI', 'a', '', 'href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target = "AdminFrame" ', 10, 605, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Allow several groups access <br> to one GUI', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_en', 'filteredGui_filteredUser', 0002, 1, 'Allow several users access to one GUI ', 'a', '', 'href = "../php/mod_filteredGui_filteredUser.php?sessionID&e_id_css=filteredGui_filteredUser" target = "AdminFrame" ', 10, 535, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Allow several users access to <br> one GUI', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_en', 'filteredUser_filteredGroup', 0002, 1, 'Add one user to serveral groups', 'a', '', 'href = "../php/mod_filteredUser_filteredGroup.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ', 10, 420, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Add one user to serveral groups', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_en', 'filteredUser_filteredGui', 0002, 1, 'Allow one user to access several GUIs', 'a', '', 'href = "../php/mod_filteredUser_filteredGui.php?sessionID&e_id_css=filteredUser_filteredGui" target = "AdminFrame" ', 10, 500, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Allow one user to access <br> several GUIs', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_en', 'gui_owner', 0002, 1, 'Edit GUI assign to user/ group', 'a', '', 'href = "../php/mod_gui_owner.php?sessionID" target = "AdminFrame" ', 10, 640, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Edit GUI assign to user/ group', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_en', 'layout_0', 0003, 1, 'WMS Management border', 'div', '', '', 3, 35, 190, 90, 1, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #008000;background-color:red;', '', 'div', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_en', 'layout_1', 0003, 1, 'WMS Management caption', 'div', '', '', 5, 37, 186, 86, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 14px; text-decoration : none; color: #000080;background-color:white;', ' WMS Management', 'div', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_en', 'layout_1a', 0003, 1, 'Configure WMS Access border', 'div', '', '', 3, 135, 190, 70, 1, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #008000;background-color:red;', '', 'div', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_en', 'layout_1b', 0003, 1, 'Configure WMS Access', 'div', '', '', 5, 137, 186, 66, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 14px; text-decoration : none; color: #000080;background-color:white;', ' Configure WMS Access', 'div', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_en', 'layout_1c', 0003, 1, 'GUI Management border', 'div', '', '', 3, 215, 190, 130, 1, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #008000;background-color:red;', '', 'div', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_en', 'layout_1d', 0003, 1, 'GUI Management caption', 'div', '', '', 5, 217, 186, 126, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 14px; text-decoration : none; color: #000080;background-color:white;', ' GUI Management ', 'div', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_en', 'layout_2', 0003, 1, 'User Management border', 'div', '', '', 3, 355, 190, 110, 1, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #008000;background-color:red;', '', 'div', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_en', 'layout_3', 0003, 1, 'User Management caption', 'div', '', '', 5, 357, 186, 106, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 14px; text-decoration : none; color: #000080;background-color:white;', ' User Management ', 'div', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_en', 'layout_4', 0003, 1, 'Authorization background', 'div', '', '', 3, 475, 190, 190, 1, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #008000;background-color:red;', '', 'div', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_en', 'layout_5', 0003, 1, 'Authorization caption', 'div', '', '', 5, 477, 186, 186, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 14px; text-decoration : none; color: #000080;background-color:white;', ' Authorization', 'div', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_en', 'loadWMS', 0002, 1, 'Load Capabilities', 'a', '', 'href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"', 10, 60, 180, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Load Capabilities', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_en', 'loadWMSList', 0002, 1, 'Link WMS into GUI', 'a', '', 'href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"', 10, 160, 180, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Link WMS into GUI', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_en', 'logout', 0002, 1, 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0''\r\nonmouseover=''this.src="../img/button_gray/logout_over.png"''\r\nonmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"', 180, 2, 24, 24, 2, '', '', 'img', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_en', 'myGUIlist', 0002, 1, 'go back to your GUI list', 'img', '../img/button_gray/home_off.png', 'onClick="window.location.href=''login.php?sessionID''" border=''0''\r\nonmouseover=''this.src="../img/button_gray/home_over.png"''\r\nonmouseout=''this.src="../img/button_gray/home_off.png"'' title="move back to your GUI list / zurück zur GUI Liste"', 150, 2, 24, 24, 2, '', '', 'img', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_en', 'newGui', 0002, 1, 'Create new GUI', 'a', '', 'href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ', 10, 240, 90, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;', 'Create new GUI', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_en', 'rename_copy_Gui', 0002, 1, 'Rename/ copy GUI', 'a', '', 'href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ', 10, 320, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Rename / copy GUI', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_en', 'showLoggedUser', 0002, 1, 'Logged User:', 'iframe', '../php/mod_showLoggedUser.php?sessionID', 'frameborder="0" scrolling=''no''', 1, 1, 200, 30, 1, 'background-color:lightgrey;', '', 'iframe', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('admin2_en', 'updateWMSs', 0002, 1, 'Update with Capabilities', 'a', '', 'href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"', 10, 80, 180, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Update Capabilities', 'a', '', '', '', 'AdminFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'addWMS', 0002, 1, 'add a WMS to the running application', 'img', '../img/button_gray/add_off.png', 'onclick=''mod_addWMS()'' \r\nonmouseover=''this.src = this.src.replace(/_off/,"_over");'' \r\nonmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS"', 515, 10, 24, 24, 1, '', '', '', 'mod_addWMS.php', '', 'treeGDE,mapframe1', 'loadData');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'addWMSfromfilteredList', 0002, 1, 'add a WMS to the running application from a filtered list', 'img', '../img/button_gray/add_filtered_list_off.png', 'onclick=''window.open("../javascripts/mod_addWMSfromfilteredList.php?sessionID","printWin","width=500, height=600, left=300, resizable=yes, scrollbars=yes")'' \r\nonmouseover=''this.src = this.src.replace(/_off/,"_over");'' \r\nonmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS from filtered list"', 490, 10, 24, 24, 1, '', '', '', '', '', 'treeGDE,mapframe1', 'loadData');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'back', 0002, 1, 'History.back()', 'img', '../img/button_gray/back_off_disabled.png', 'onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()" title="Back"', 360, 10, 24, 24, 1, '', '', '', 'mod_back.php', '', 'mapframe1,overview0', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'body', 0001, 1, 'body (obligatory)', 'body', '', 'bgcolor="#FFFFFF" onload="init()"', 0, 0, 0, 0, 0, '', '', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'copyright', 0002, 1, 'a Copyright in the map', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_copyright.php', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'dependentDiv', 0002, 1, 'displays infos in a sticky div-tag', 'div', '', '', 81, -19, 1, 1, 0, 'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;', '', 'div', 'mod_dependentDiv.php', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'dragMapSize', 0002, 1, 'drag & drop Mapsize', 'div', '', '', 81, -19, 0, 0, 2, 'background-color:#B8C1C7; font-size:1px; cursor:move; width:10; height:10;', '', 'div', 'mod_dragMapSize.php', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'featureInfo1', 0002, 0, 'FeatureInfoRequest', 'img', '../img/button_gray/query_off.png', 'onmouseover = "mb_regButton(''init_featureInfo1'')"', 140, 40, 24, 24, 1, '', '', '', 'mod_featureInfo.php', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'FeatureInfoRedirect', 0002, 1, 'redirect featureInfoRequests in an iframe for each wms', 'iframe', '../html/mod_blank.html', 'frameborder="0"', 83, -17, 1, 1, 0, '', '', 'iframe', 'mod_featureInfoRedirect.php', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'featureInfoTunnel', 0002, 1, 'FeatureInfoRequest with local path', 'img', '../img/button_gray/query_off.png', 'onmouseover = "mb_regButton(''init_featureInfoTunnel'')" title="Query"', 425, 10, 24, 24, 1, '', '', '', 'mod_featureInfoTunnel.php', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'forward', 0002, 1, 'History.forward()', 'img', '../img/button_gray/forward_off_disabled.png', 'onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()" title="Forward"', 385, 10, 24, 24, 1, '', '', '', 'mod_forward.php', '', 'mapframe1,overview0', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'Gazetteer_mbUser', 0002, 1, 'a gazetteer for rivers of germany', 'iframe', '../php/mod_wfs_gazetteer.php?sessionID&wfs_conf=1&target=mapframe1,overview&resultFrame=wfsresult', 'frameborder = "0"', 10, 600, 300, 150, 4, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1,overview', 'wz-graphics');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'help', 0002, 1, 'button help', 'img', '../img/button_gray/help_off.png', 'onmouseover=''this.src = this.src.replace(/_off/,"_over");'' \r\nonmouseout=''this.src = this.src.replace(/_over/, "_off");''\r\nonclick=''window.open("http://www.mapbender.org/index.php/Using_Mapbender","Hilfe","width=800, height=800, resizable=yes,scrollbars=yes, menubar=yes, toolbar=yes, location=yes")'' title="Help"', 620, 10, 24, 24, 1, '', '', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'imprint', 0002, 1, 'Information about the owner of the gui', 'iframe', '../html/tab_imprint.html', 'frameborder = "0" ', 1, 1, 1, 1, 5, 'visibility:hidden;', '', 'iframe', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'keyHandler', 0002, 1, 'onkeydownevent (only IE)', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_key.php', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'layout_back', 0003, 1, 'layout, background for buttons', 'div', '', '', 360, 10, 51, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'layout_featureInfo', 0003, 1, 'layout, background for FeatureInfo', 'div', '', '', 425, 10, 51, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'layout_help', 0003, 1, 'layout, background for Help-button', 'div', '', '', 620, 10, 26, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'layout_logout', 0003, 1, 'layout, background for Logout-button', 'div', '', '', 660, 10, 26, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'layout_metadata', 0003, 1, 'layout, background for Metadata', 'div', '', '', 580, 10, 26, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'layout_wms', 0003, 1, 'layout, background for wms', 'div', '', '', 490, 10, 76, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'layout_zoom', 0003, 1, 'layout, background for Zoom-button', 'div', '', '', 220, 10, 126, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'legend', 0002, 1, 'legend', 'iframe', '../javascripts/mod_legend.php?sessionID&e_id_css=legend', 'frameborder=''0''', 1, 1, 1, 1, 3, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'loadData', 0002, 1, 'IFRAME, um Daten zu laden', 'iframe', '../html/mod_blank.html', 'frameborder = "0" ', 0, 0, 1, 1, 0, 'visibility:visible', '', 'iframe', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'loadwmc', 0002, 0, 'load workspace from WMC', 'img', '../img/button_wmc/wmc_load.png', 'onclick=''mod_loadwmc()'' onmouseover=''mod_loadwmc_init(this)''\r\ntitle=''Load a web map context document''', 760, 10, 24, 24, 1, '', '', '', 'mod_loadwmc.php', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'logo', 0002, 1, 'Logo', 'img', '../img/mapbender_logo.png', '', 20, 20, 180, 26, 5, '', '', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'logout', 0002, 1, 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0''\r\nonmouseover=''this.src="../img/button_gray/logout_over.png"''\r\nonmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"', 660, 10, 24, 24, 1, '', '', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'mapbender', 0002, 1, 'Mapbender-Logo', 'div', '', 'onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"', 81, -19, 1, 1, 30, 'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;', '<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr>\r\n<script language="javascript">\r\nmb_registerSubFunctions("mod_mapbender()");\r\nfunction mod_mapbender(){\r\ndocument.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90;\r\ndocument.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1;\r\n}\r\n</script>', 'div', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'mapframe1', 0002, 1, 'frame for a map', 'iframe', '../php/mod_map1.php?sessionID', 'scrolling="no" frameborder=''0'' ', 230, 55, 500, 450, 2, '', '', 'iframe', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'metadata', 0002, 1, 'shows informations about the wms and the requests of the gui', 'img', '../img/button_gray/metadata_off.png', 'onClick="window.location.href=''javascript:mod_displayObj()''"\r\nborder=''0''\r\nonmouseover=''this.src="../img/button_gray/metadata_over.png"''\r\nonmouseout=''this.src="../img/button_gray/metadata_off.png"'' title="Show service metadata"', 580, 10, 24, 24, 1, '', '', '', 'mod_displayObj.js', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'navFrame', 0002, 1, 'navigation mapborder', 'div', '', '', 0, 0, 0, 0, 0, 'font-size:1px;', '<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div>\r\n<div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div>\r\n<div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div>\r\n<div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div>\r\n<div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div>\r\n<div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div>\r\n<div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div>\r\n<div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div>\r\n', 'div', 'mod_navFrame.php', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'overview', 0002, 1, 'OverviewFrame', 'iframe', '../php/mod_mapOV.php?wms=0&sessionID', 'scrolling="no" frameborder=''0'' ', 30, 65, 150, 130, 100, '', '', 'iframe', '', 'mod_box1.js', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'pan1', 0002, 1, 'pan', 'img', '../img/button_gray/pan_off.png', 'onmouseover = "mb_regButton(''init_mod_pan'')" title="Pan"', 270, 10, 24, 24, 1, '', '', '', 'mod_pan.php', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'printPDF', 0002, 1, 'pdf print', 'iframe', '../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF.conf', 'frameborder = "0" ', 1, 1, 2, 2, 5, 'visibility:hidden', '', 'iframe', '', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'sandclock', 0002, 1, 'displays a sand clock while waiting for requests', 'div', '', '', 80, 0, 0, 0, 0, '', '', 'div', 'mod_sandclock.php', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'savewmc', 0002, 0, 'save workspace as WMC', 'img', '../img/button_wmc/wmc_save.png', 'onclick=''mod_savewmc()'' onmouseover=''mod_savewmc_init(this)''\r\ntitle=''Save workspace as web map context document''', 730, 10, 24, 24, 1, '', '', '', 'mod_savewmc.php', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'selArea1', 0002, 1, 'zoombox', 'img', '../img/button_gray/selArea_off.png', 'onmouseover = "mb_regButton(''init_selArea1'')" title="Zoom by rectangle"', 295, 10, 24, 24, 1, '', '', '', 'mod_selArea1.php', 'mod_box1.js', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'setBackground', 0002, 1, 'switch background-wms', 'form', '', '', 30, 210, 0, 0, 1, '', '<select style=''font-family: Arial, sans-serif; font-size:12''\r\nname=''mod_setBackground_list''\r\nonchange=''mod_setBackground_change(this)'' ><option\r\nvalue=''0''></option></select>', 'form', 'mod_setBackground.php', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'setBBOX', 0002, 0, 'set extent for mapframe and overviewframe', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_setBBOX1.php', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'showCoords_div', 0002, 1, 'displays coodinates by onmouseover', 'img', '../img/button_gray/coords_off.png', 'onmouseover = "mb_regButton(''init_mod_showCoords_div'')" title="Coordinates" ', 450, 10, 24, 24, 1, 'background-color:white; font-family: Arial, Helvetica, sans-serif;font-size:10px;', '', '', 'mod_coords_div.php', '', 'mapframe1', 'dependendDiv');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'tabs', 0002, 1, 'vertical tabs to handle iframes', 'div', '', '', 10, 240, 200, 20, 2, 'font-family: Arial,Helvetica;font-weight:bold;', '', 'div', 'mod_tab.php', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'treeGDE', 0002, 1, 'dircetory structure, checkbox for visible, checkbox for querylayer', 'iframe', '../html/mod_sync_treefolder.php?sessionID&e_id_css=treeGDE', 'frameborder = "0" ', 1, 1, 1, 1, 4, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'wfsresult', 0002, 1, 'display the list of wfs results', 'iframe', '../html/mod_blank.html', 'frameborder = "0"', 10, 730, 200, 150, 4, '', '', 'iframe', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'WMS_preferences', 0002, 1, 'configures the preferences of each loaded wms', 'img', '../img/button_gray/preferences_off.png', 'onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")'' \r\nonmouseover=''this.src = this.src.replace(/_off/,"_over");'' \r\nonmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="WMS preferences"', 540, 10, 24, 24, 1, '', '', '', '', '', 'mapframe1,treeGDE', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'zoomFull', 0002, 1, 'zoom to full extent button', 'img', '../img/button_gray/zoomFull_off.png', 'onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)" title="Display complete map"', 320, 10, 24, 24, 2, '', '', 'img', 'mod_zoomFull.php', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'zoomIn1', 0002, 1, 'zoomIn button', 'img', '../img/button_gray/zoomIn2_off.png', 'onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)'' title="Zoom in"', 220, 10, 24, 24, 1, '', '', '', 'mod_zoomIn1.php', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui', 'zoomOut1', 0002, 1, 'zoomOut button', 'img', '../img/button_gray/zoomOut2_off.png', 'onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)'' title="Zoom out"', 245, 10, 24, 24, 1, '', '', '', 'mod_zoomOut1.php', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'addWMS', 0002, 1, 'add a WMS to the running application', 'img', '../img/button_blink_red/add_off.png', 'onclick=''mod_addWMS()'' \r\nonmouseover=''this.src = this.src.replace(/_off/,"_over");'' \r\nonmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS"', 645, 60, 24, 24, 1, '', '', '', 'mod_addWMS.php', '', 'treeGDE,mapframe1', 'loadData');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'addWMSfromfilteredList', 0002, 1, 'add a WMS to the running application from a filtered list', 'img', '../img/button_blink_red/add_filtered_list_off.png', 'onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")'' \r\nonmouseover=''this.src = this.src.replace(/_off/,"_over");'' \r\nonmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS from filtered list"', 620, 60, 24, 24, 1, '', '', '', '', '', 'treeGDE,mapframe1', 'loadData');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'addWMSfromList', 0002, 1, 'add a WMS to the running application from a list', 'img', '../img/button_blink_red/addlist_off.png', 'onclick=''window.open("../javascripts/mod_addWMSfromList.php?sessionID","printWin","width=500, height=600, left=300, resizable=yes, scrollbars=yes")'' \r\nonmouseover=''this.src = this.src.replace(/_off/,"_over");'' \r\nonmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS from List"', 595, 60, 24, 24, 1, '', '', '', '', '', 'treeGDE,mapframe1', 'loadData');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'back', 0002, 1, 'History.back()', 'img', '../img/button_blink_red/back_off_disabled.png', 'onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()" title="Back"', 400, 60, 24, 24, 1, '', '', '', 'mod_back.php', '', 'mapframe1,overview', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'body', 0001, 1, 'body (obligatory)', 'body', '', 'bgcolor="#FFFFFF" onload="init()"', 0, 0, 0, 0, 0, '', '', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'center1', 0002, 1, 'Center button', 'img', '../img/button_blink_red/center_off.png', 'onmouseover = "mb_regButton(''init_gui1_center'')" title="Set map center"', 310, 60, 24, 24, 1, '', '', '', 'mod_center1.php', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'changeEPSG', 0002, 1, 'change EPSG, Postgres required, overview is targed for full extent', 'iframe', '../php/mod_changeEPSG.php?sessionID', 'scrolling="no" frameborder=''0'' ', 432, 25, 102, 24, 1, '', '', 'iframe', '', '', 'overview', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'changePassword_button', 0002, 1, 'button: change password of logged user', 'img', '../img/button_blink_red/change_password_off.png', 'onclick="window.open(''../php/mod_changePassword.php?sessionID'','''',''width=300, height=300, menubar=no,toolbar=no,location=no,status=no,resizable=yes'');"\r\nborder=''0''\r\nonmouseover=''this.src="../img/button_blink_red/change_password_over.png"''\r\nonmouseout=''this.src="../img/button_blink_red/change_password_off.png"'' title="Change password"', 750, 60, 24, 24, 1, 'cursor:hand', '', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'closePolygon', 0003, 1, 'close Polygon ', 'div', '', ' title="Close Polygon"', 0, 0, 0, 0, 0, '', '', 'div', 'mod_closePolygon.js', '', 'mapframe1', 'measure');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'copyright', 0002, 1, 'a Copyright in the map', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_copyright.php', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'dependentDiv', 0002, 1, 'displays infos in a sticky div-tag', 'div', '', '', -59, 1, 1, 1, 0, 'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;', '', 'div', 'mod_dependentDiv.php', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'dragMapSize', 0002, 1, 'drag & drop Mapsize', 'div', '', '', -59, 1, 0, 0, 2, 'background-color:#B8C1C7; font-size:1px; cursor:move; width:10; height:10;', '', 'div', 'mod_dragMapSize.php', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'featureInfo1', 0002, 1, 'FeatureInfoRequest', 'img', '../img/button_blink_red/query_off.png', 'onmouseover = "mb_regButton(''init_featureInfo1'')" title="Query"', 465, 60, 24, 24, 1, '', '', '', 'mod_featureInfo.php', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'forward', 0002, 1, 'History.forward()', 'img', '../img/button_blink_red/forward_off_disabled.png', 'onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()" title="Forward"', 425, 60, 24, 24, 1, '', '', '', 'mod_forward.php', '', 'mapframe1,overview', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'getArea', 0003, 1, 'Calculation of area, Postgis required', 'div', '', ' title="Get Area"', 0, 0, 0, 0, 0, '', '', 'div', 'mod_getArea.php', '', 'mapframe1', 'measure');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'help', 0002, 1, 'button help', 'img', '../img/button_blink_red/help_off.png', 'onmouseover=''this.src = this.src.replace(/_off/,"_over");'' \r\nonmouseout=''this.src = this.src.replace(/_over/, "_off");''\r\nonclick=''window.open("http://www.mapbender.org/index.php/Using_Mapbender","Hilfe","width=800, height=800, resizable=yes,scrollbars=yes, menubar=yes, toolbar=yes, location=yes")'' title="Help"', 790, 60, 24, 24, 1, '', '', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'keyHandler', 0002, 1, 'onkeydownevent (only IE)', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_key.php', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'layout_1', 0003, 1, 'layout, background for buttons', 'div', '', '', 208, 58, 670, 28, 0, 'background-color:#FFFFFF;', '', 'div', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'legend', 0002, 1, 'legend', 'iframe', '../javascripts/mod_legend.php?sessionID&wms_legend = yes', 'frameborder=''0''', -59, 200, 180, 600, 3, '', '', 'iframe', '', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'loadData', 0002, 1, 'IFRAME to load data', 'iframe', '../html/mod_blank.html', 'frameborder = "0" ', 0, 0, 1, 1, 0, 'visibility:visible', '', 'iframe', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'loadwmc', 0002, 1, 'load workspace from WMC', 'img', '../img/button_gray/wmc_load_over.png', 'onclick=''mod_loadwmc()'' onmouseover=''mod_loadwmc_init(this)''\r\ntitle="Load a web map context document"', 895, 60, 24, 24, 1, '', '', '', 'mod_loadwmc.php', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'logout', 0002, 1, 'Logout', 'img', '../img/button_blink_red/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0''\r\nonmouseover=''this.src="../img/button_blink_red/logout_over.png"''\r\nonmouseout=''this.src="../img/button_blink_red/logout_off.png"'' title="Logout"', 830, 60, 24, 24, 1, '', '', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'mapbender', 0002, 1, 'Mapbender-Logo', 'div', '', 'onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"', -59, 1, 1, 1, 30, 'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;', '<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr>\r\n<script language="javascript">\r\nmb_registerSubFunctions("mod_mapbender()");\r\nfunction mod_mapbender(){\r\ndocument.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90;\r\ndocument.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1;\r\n}\r\n</script>', 'div', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'mapframe1', 0002, 1, 'Frame for a map', 'iframe', '../php/mod_map1.php?sessionID', 'scrolling="no" frameborder=''0'' ', 220, 105, 625, 400, 2, '', '', 'iframe', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'measure', 0002, 1, 'Measure', 'img', '../img/button_blink_red/measure_off.png', 'onmouseover = "mb_regButton(''init_mod_measure'')" title="Measure distance"', 515, 60, 24, 24, 1, '', '', '', 'mod_measure.php', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'metadata', 0002, 1, 'shows informations about the wms and the requests of the gui', 'img', '../img/button_blink_red/metadata_off.png', 'onClick="window.location.href=''javascript:mod_displayObj()''"\r\nborder=''0''\r\nonmouseover=''this.src="../img/button_blink_red/metadata_over.png"''\r\nonmouseout=''this.src="../img/button_blink_red/metadata_off.png"'' title="Show SQL"', 710, 60, 24, 24, 1, '', '', '', 'mod_displayObj.js', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'navFrame', 0002, 1, 'navigation mapborder', 'div', '', '', 0, 0, 0, 0, 10, 'font-size:1px;', '<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div>\r\n<div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div>\r\n<div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div>\r\n<div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div>\r\n<div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div>\r\n<div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div>\r\n<div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div>\r\n<div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div>\r\n', 'div', 'mod_navFrame.php', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'overview', 0002, 1, 'OverviewFrame', 'iframe', '../php/mod_mapOV.php?wms=0&sessionID', 'scrolling="no" frameborder=''0'' ', 15, 25, 150, 150, 2, '', '', 'iframe', '', 'mod_box1.js', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'pan1', 0002, 1, 'pan', 'img', '../img/button_blink_red/pan_off.png', 'onmouseover = "mb_regButton(''init_mod_pan'')" title="Pan"', 260, 60, 24, 24, 1, '', '', '', 'mod_pan.php', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'print1', 0002, 0, 'start print GUI', 'img', '../img/button_blink_red/print_off.png', 'onclick=''window.open("../print/mod_printPDF.php?target=mapframe1&sessionID","printWin","width=300, height=400, resizable=yes ")'' \r\nonmouseover=''this.src = this.src.replace(/_off/,"_over");'' \r\nonmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Print"', 555, 60, 24, 24, 1, '', '', '', '', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'printPDF', 0002, 1, 'start print GUI', 'img', '../img/button_blink_red/print_off.png', 'onclick=''window.open("../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF_b.conf","printWin","width=180, height=200, resizable=yes ")'' \r\nonmouseover=''this.src = this.src.replace(/_off/,"_over");'' \r\nonmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Print"', 555, 60, 24, 24, 1, '', '', '', '', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'repaint', 0002, 1, 'refresh a mapobject', 'img', '../img/button_blink_red/repaint_off.png', 'onclick=''mod_repaint()'' onmouseover=''mod_repaint_init(this)'' title="Redraw"', 360, 60, 24, 24, 1, '', '', '', 'mod_repaint.php', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'rubber', 0003, 1, 'deletes temporary (digitized) objects', 'div', '', ' title="Rubber"', 0, 0, 0, 0, 0, '', '', 'div', 'mod_rubber.js', '', 'mapframe1', 'measure');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'sandclock', 0002, 1, 'displays a sand clock while waiting for requests', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_sandclock.php', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'savewmc', 0002, 1, 'save workspace as WMC', 'img', '../img/button_gray/wmc_save_over.png', 'onclick=''mod_savewmc()'' onmouseover=''mod_savewmc_init(this)''\r\ntitle="Save workspace as web map context document"', 870, 60, 24, 24, 1, '', '', '', 'mod_savewmc.php', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'scalebar', 0002, 1, 'scalebar', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_scalebar.php', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'scaleSelect', 0002, 1, 'Scale-Selectbox', 'select', '', 'onchange=''mod_scaleSelect(this)''', 555, 25, 100, 20, 1, '', '<option value = ''''>Scale</option>\r\n<option value=''100''>1 : 100</option>\r\n<option value=''250''>1 : 250</option>\r\n<option value=''500''>1 : 500</option>\r\n<option value=''1000''>1 : 1000</option>\r\n<option value=''2500''>1 : 2500</option>\r\n<option value=''5000''>1 : 5000</option>\r\n<option value=''10000''>1 : 10000</option>\r\n<option value=''25000''>1 : 25000</option>\r\n<option value=''30000''>1 : 30000</option>\r\n<option value=''50000''>1 : 50000</option>\r\n<option value=''75000''>1 : 75000</option>\r\n<option value=''100000''>1 : 100000</option>\r\n<option value=''200000''>1 : 200000</option>\r\n<option value=''300000''>1 : 300000</option>\r\n<option value=''400000''>1 : 400000</option>\r\n<option value=''500000''>1 : 500000</option>\r\n<option value=''600000''>1 : 600000</option>\r\n<option value=''700000''>1 : 700000</option>\r\n<option value=''800000''>1 : 800000</option>\r\n<option value=''900000''>1 : 900000</option>\r\n<option value=''1000000''>1 : 1000000</option>', 'select', 'mod_scaleSel.php', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'scaleText', 0002, 1, 'Scale-description field', 'form', '', 'onsubmit=''return mod_scaleText()''', 672, 25, 100, 30, 0, '', '<input type="text">', 'form', 'mod_scaleText.php', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'selArea1', 0002, 1, 'zoombox', 'img', '../img/button_blink_red/selArea_off.png', 'onmouseover = "mb_regButton(''init_selArea1'')" title="Zoom by rectangle"', 285, 60, 24, 24, 1, '', '', '', 'mod_selArea1.php', 'mod_box1.js', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'setBackground', 0002, 0, 'switch background-wms', 'form', '', '', 15, 190, 0, 0, 1, '', '<select style=''font-family: Arial, sans-serif; font-size:12''\r\nname=''mod_setBackground_list''\r\nonchange=''mod_setBackground_change(this)'' ><option\r\nvalue=''0''></option></select>', 'form', 'mod_setBackground.php', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'setBackground_all', 0002, 0, 'switch all background-wms', 'form', '', '', 157, 190, 40, 20, 1, '', '<input type=''checkbox'' onclick=''mod_setBackground_all_init(this)''> <font face="Arial, sans-serif" size="2">all</font>', 'form', 'mod_setBackground_all.php', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'setBBOX', 0002, 0, 'set Extent for mapframe and overviewframe', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_setBBOX1.php', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'setScaleHint', 0001, 0, 'set scaleHint for mapframes', 'div', '', '', 1, 1, 1, 1, 0, 'visibility:hidden;', '', 'div', 'mod_scaleHint.php', '', 'mapframe1,100,10000000', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'showCoords_div', 0002, 1, 'displays coordinates by onmouseover', 'img', '../img/button_blink_red/coords_off.png', 'onmouseover = "mb_regButton(''init_mod_showCoords_div'')" title="Coordinates"', 490, 60, 24, 24, 1, 'background-color:white; font-family: Arial, Helvetica, sans-serif;font-size:10px;', '', '', 'mod_coords_div.php', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'treeConfGDE', 0002, 0, 'configurable directory tree', 'iframe', '../php/mod_treefolderClient.php?sessionID', 'frameborder = "0" ', 0, 180, 250, 500, 0, 'visibility:visible', '', 'iframe', 'mod_treeConf.js', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'treeGDE', 0002, 1, 'directory tree, checkbox for visible, checkbox for querylayer,', 'iframe', '../html/mod_sync_treefolder.php?sessionID&e_id_css=treeGDE', 'frameborder = "0" ', 10, 220, 200, 300, NULL, 'visibility:visible', '', 'iframe', '', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'treeGDE_1', 0002, 0, 'directory tree, checkbox for visible, checkbox for querylayer, no immediate refreshing, with nested layers', 'iframe', '../html/mod_sync_treefolder_1.html', 'frameborder = "0" ', 0, 180, 250, 500, 0, 'visibility:visible', '', 'iframe', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'wfs_gazetteer', 0002, 0, 'gazetteer using wfs', 'iframe', '../php/mod_wfs_gazetteer.php?sessionID&color=255,0,255', 'frameborder = "0" ', -50, 490, 250, 300, 0, 'visibility:visible', '', 'iframe', '', '', 'mapframe1,overview', 'wfs');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'WMS_preferences', 0002, 1, 'configure the preferences of each loaded wms', 'img', '../img/button_blink_red/preferences_off.png', 'onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")'' \r\nonmouseover=''this.src = this.src.replace(/_off/,"_over");'' \r\nonmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="WMS preferences"', 670, 60, 24, 24, 1, '', '', '', '', '', 'mapframe1,treeGDE', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'zoomCoords', 0002, 1, 'zoom to coordinate', 'iframe', '../php/mod_zoomCoords_en.php?sessionID', 'frameborder = "0" ', 205, 7, 220, 45, 0, '', '', 'iframe', '', '', 'mapframe1,overview', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'zoomFull', 0002, 1, 'zoom to full extent button', 'img', '../img/button_blink_red/zoomFull_off.png', 'onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)" title="Display complete map"', 335, 60, 24, 24, 2, '', '', 'img', 'mod_zoomFull.php', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'zoomIn1', 0002, 1, 'zoomIn button', 'img', '../img/button_blink_red/zoomIn2_off.png', 'onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)'' title="Zoom in"', 210, 60, 24, 24, 1, '', '', '', 'mod_zoomIn1.php', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('gui1', 'zoomOut1', 0002, 1, 'zoomOut button', 'img', '../img/button_blink_red/zoomOut2_off.png', 'onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)'' title="Zoom out"', 235, 60, 24, 24, 1, '', '', '', 'mod_zoomOut1.php', '', 'mapframe1', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('wms_africa', 'body', 0001, 1, 'obligatory body', 'body', '', '', 0, 0, 0, 0, 0, '', '', 'body', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('wms_africa', 'content', 0002, 1, 'text', 'div', '', '', 10, 50, 500, 30, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'This GUI is an OGC service catalog container and does not provide a map user interface. Please use the (<a href=\\''javascript:history.back()\\''>back</a>) link to select another GUI form your list or log off to log on using another account (identity).\r\n<br><br>\r\nDiese GUI ist ein OGC Service Katalog Behälter (Eimer, Container, nimm was Du meinst) und beinhaltet keine Kartenoberfläche. Verwenden Sie diesen (<a href=\\''javascript:history.back()\\''>back</a>) Verweis, um aus der Liste eine andere GUI auszuwählen oder melden Sie sich ab, um sich mit einer anderen Kennung anzumelden. ', 'div', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('wms_africa', 'logout', 0002, 1, 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick=\\"window.location.href=\\''../php/mod_logout.php?sessionID\\''\\" border=\\''0\\''\r\nonmouseover=\\''this.src=\\"../img/button_gray/logout_over.png\\"\\''\r\nonmouseout=\\''this.src=\\"../img/button_gray/logout_off.png\\"\\'' title=\\"Logout\\"', 5, 5, 24, 24, 1, '', '', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('wms_australia', 'body', 0001, 1, 'obligatory body', 'body', '', '', 0, 0, 0, 0, 0, '', '', 'body', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('wms_australia', 'content', 0002, 1, 'text', 'div', '', '', 10, 50, 500, 30, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'This GUI is an OGC service catalog container and does not provide a map user interface. Please use the (<a href=\\''javascript:history.back()\\''>back</a>) link to select another GUI form your list or log off to log on using another account (identity).\r\n<br><br>\r\nDiese GUI ist ein OGC Service Katalog Behälter (Eimer, Container, nimm was Du meinst) und beinhaltet keine Kartenoberfläche. Verwenden Sie diesen (<a href=\\''javascript:history.back()\\''>back</a>) Verweis, um aus der Liste eine andere GUI auszuwählen oder melden Sie sich ab, um sich mit einer anderen Kennung anzumelden. ', 'a', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('wms_australia', 'logout', 0002, 1, 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick=\\"window.location.href=\\''../php/mod_logout.php?sessionID\\''\\" border=\\''0\\''\r\nonmouseover=\\''this.src=\\"../img/button_gray/logout_over.png\\"\\''\r\nonmouseout=\\''this.src=\\"../img/button_gray/logout_off.png\\"\\'' title=\\"Logout\\"', 10, 10, 24, 24, 1, '', '', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('wms_europe', 'body', 0001, 1, 'obligatory body', 'body', '', '', 0, 0, 0, 0, 0, '', '', 'body', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('wms_europe', 'content', 0002, 1, 'text', 'div', '', '', 10, 50, 500, 30, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'This GUI is an OGC service catalog container and does not provide a map user interface. Please use the (<a href=\\''javascript:history.back()\\''>back</a>) link to select another GUI form your list or log off to log on using another account (identity).\r\n<br><br>\r\nDiese GUI ist ein OGC Service Katalog Behälter (Eimer, Container, nimm was Du meinst) und beinhaltet keine Kartenoberfläche. Verwenden Sie diesen (<a href=\\''javascript:history.back()\\''>back</a>) Verweis, um aus der Liste eine andere GUI auszuwählen oder melden Sie sich ab, um sich mit einer anderen Kennung anzumelden. ', 'a', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('wms_europe', 'logout', 0002, 1, 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick=\\"window.location.href=\\''../php/mod_logout.php?sessionID\\''\\" border=\\''0\\''\r\nonmouseover=\\''this.src=\\"../img/button_gray/logout_over.png\\"\\''\r\nonmouseout=\\''this.src=\\"../img/button_gray/logout_off.png\\"\\'' title=\\"Logout\\"', 500, 5, 24, 24, 1, '', '', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('wms_gdi_de', 'body', 0001, 1, 'obligatory body', 'body', '', '', 0, 0, 0, 0, 0, '', '', 'body', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('wms_gdi_de', 'content', 0002, 1, 'text', 'div', '', '', 10, 50, 500, 30, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'This GUI is an OGC service catalog container and does not provide a map user interface. Please use the (<a href=\\''javascript:history.back()\\''>back</a>) link to select another GUI form your list or log off to log on using another account (identity).\r\n<br><br>\r\nDiese GUI ist ein OGC Service Katalog Behälter (Eimer, Container, nimm was Du meinst) und beinhaltet keine Kartenoberfläche. Verwenden Sie diesen (<a href=\\''javascript:history.back()\\''>back</a>) Verweis, um aus der Liste eine andere GUI auszuwählen oder melden Sie sich ab, um sich mit einer anderen Kennung anzumelden. ', 'a', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('wms_gdi_de', 'logout', 0002, 1, 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick=\\"window.location.href=\\''../php/mod_logout.php?sessionID\\''\\" border=\\''0\\''\r\nonmouseover=\\''this.src=\\"../img/button_gray/logout_over.png\\"\\''\r\nonmouseout=\\''this.src=\\"../img/button_gray/logout_off.png\\"\\'' title=\\"Logout\\"', 500, 5, 24, 24, 1, '', '', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('wms_germany', 'body', 0001, 1, 'obligatory body', 'body', '', '', 0, 0, 0, 0, 0, '', '', 'body', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('wms_germany', 'content', 0002, 1, 'text', 'div', '', '', 10, 50, 500, 30, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'This GUI is an OGC service catalog container and does not provide a map user interface. Please use the (<a href=\\''javascript:history.back()\\''>back</a>) link to select another GUI form your list or log off to log on using another account (identity).\r\n<br><br>\r\nDiese GUI ist ein OGC Service Katalog Behälter (Eimer, Container, nimm was Du meinst) und beinhaltet keine Kartenoberfläche. Verwenden Sie diesen (<a href=\\''javascript:history.back()\\''>back</a>) Verweis, um aus der Liste eine andere GUI auszuwählen oder melden Sie sich ab, um sich mit einer anderen Kennung anzumelden. ', 'a', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('wms_germany', 'logout', 0002, 1, 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick=\\"window.location.href=\\''../php/mod_logout.php?sessionID\\''\\" border=\\''0\\''\r\nonmouseover=\\''this.src=\\"../img/button_gray/logout_over.png\\"\\''\r\nonmouseout=\\''this.src=\\"../img/button_gray/logout_off.png\\"\\'' title=\\"Logout\\"', 50, 5, 24, 24, 1, '', '', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('wms_north_america', 'body', 0001, 1, 'obligatory body', 'body', '', '', 0, 0, 0, 0, 0, '', '', 'body', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('wms_north_america', 'content', 0002, 1, 'text', 'div', '', '', 10, 50, 500, 30, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'This GUI is an OGC service catalog container and does not provide a map user interface. Please use the (<a href=\\''javascript:history.back()\\''>back</a>) link to select another GUI form your list or log off to log on using another account (identity).\r\n<br><br>\r\nDiese GUI ist ein OGC Service Katalog Behälter (Eimer, Container, nimm was Du meinst) und beinhaltet keine Kartenoberfläche. Verwenden Sie diesen (<a href=\\''javascript:history.back()\\''>back</a>) Verweis, um aus der Liste eine andere GUI auszuwählen oder melden Sie sich ab, um sich mit einer anderen Kennung anzumelden. ', 'a', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('wms_north_america', 'logout', 0002, 1, 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick=\\"window.location.href=\\''../php/mod_logout.php?sessionID\\''\\" border=\\''0\\''\r\nonmouseover=\\''this.src=\\"../img/button_gray/logout_over.png\\"\\''\r\nonmouseout=\\''this.src=\\"../img/button_gray/logout_off.png\\"\\'' title=\\"Logout\\"', 50, 5, 24, 24, 1, '', '', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('wms_worldwide', 'body', 0001, 1, 'obligatory body', 'body', '', '', 0, 0, 0, 0, 0, '', '', 'body', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('wms_worldwide', 'content', 0002, 1, 'text', 'div', '', '', 10, 50, 500, 30, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'This GUI is an OGC service catalog container and does not provide a map user interface. Please use the (<a href=\\''javascript:history.back()\\''>back</a>) link to select another GUI form your list or log off to log on using another account (identity).\r\n<br><br>\r\nDiese GUI ist ein OGC Service Katalog Behälter (Eimer, Container, nimm was Du meinst) und beinhaltet keine Kartenoberfläche. Verwenden Sie diesen (<a href=\\''javascript:history.back()\\''>back</a>) Verweis, um aus der Liste eine andere GUI auszuwählen oder melden Sie sich ab, um sich mit einer anderen Kennung anzumelden. ', 'a', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires) VALUES ('wms_worldwide', 'logout', 0002, 1, 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick=\\"window.location.href=\\''../php/mod_logout.php?sessionID\\''\\" border=\\''0\\''\r\nonmouseover=\\''this.src=\\"../img/button_gray/logout_over.png\\"\\''\r\nonmouseout=\\''this.src=\\"../img/button_gray/logout_off.png\\"\\'' title=\\"Logout\\"', 50, 5, 24, 24, 1, '', '', '', '', '', '', '');
+-- Daten für Tabelle `gui_element_vars`
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGoup_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGroup_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGroup_Gui', 'file css', '../css/administration_alloc.css', 'file', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGroup_User', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGui_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGui_user', 'file css', '../css/administration_alloc.css', 'a file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredUser_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredUser_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredUser_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredUser_Gui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Group_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'group_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Group_Gui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Group_User', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'gui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'gui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Gui_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Gui_User', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'user_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'user_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'User_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'user_gui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGoup_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGroup_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredUser_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredUser_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'gui_owner', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGoup_filteredUser', 'css_file_filteredGroup_filterdUser', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGroup_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredUser_filteredGroup', 'css_filteredUser_filteredGroup', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredUser_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'gui_owner', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'css_file_legend', '../css/legend.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'legendlink', 'false', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'showlayertitle', 'false', 'show the layer title in the legend', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'showwmstitle', 'false', 'show the wms title in the legend', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'stickylegend', 'false', 'decide wether your legend should stick on the mapframe1', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'logout', 'logout_location', '', 'webside to show after logout', 'php_var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'open_tab', '0', 'define which tab should be opened when a gui is opened', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[0]', '200', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[1]', '260', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[2]', '200', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[3]', '340', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[4]', '180', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[0]', 'treeGDE', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[1]', 'legend', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[2]', 'printPDF', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[3]', 'Gazetteer_mbUser', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[4]', 'imprint', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_prefix', ' ', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_style', 'position:absolute;visibility:visible;border: 1px solid white;font-size:12;color:#343434;background-color:#CFD2D4;cursor:pointer;', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_titles[0]', 'Maps', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_titles[1]', 'Legend', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_titles[2]', 'Print', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_titles[3]', 'WFS Search', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_titles[4]', 'Imprint', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'cssfile', '../css/treeGDE.css', 'global stylesheets', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'imagedir', '../img/tree', 'image directory', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'metadatalink', 'true', 'link for layer-metadata', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'body', 'css_class_bg', 'body{\r\nbackground-color: #ffffff;\r\n}', '', 'text/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'css_file_legend', '../css/legend.css', '', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'legendlink', 'false', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'showlayertitle', 'true', 'show the layer title in the legend', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'showwmstitle', 'true', 'show the wms title in the legend', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'stickylegend', 'true', 'parameter to decide wether the legend should stick on the mapframe1', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'logout', 'logout_location', 'http://www.mapbender.org/', 'webside to show after logout', 'php_var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'cssfile', '../css/treeGDE.css', 'global stylesheets', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'ficheckbox', 'false', 'checkbox for featureInfo requests', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'imagedir', '../img/tree', 'image directory', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'metadatalink', 'true', 'link for layer-metadata', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('wms_gdi_de', 'body', 'file css', '../css/mapbender.css', 'file css', 'file/css');
+-- Daten für Tabelle `gui_layer`
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 9890, 615, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 9891, 615, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 9892, 615, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 9893, 615, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 9894, 615, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 9895, 615, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 9896, 615, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 9897, 615, 1, 1, 1, 0, 0, 0, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 9898, 615, 1, 1, 1, 0, 0, 0, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 9899, 615, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 9900, 615, 1, 1, 1, 0, 0, 0, 0, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14167, 776, 0, 0, 0, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14168, 776, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14169, 776, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14170, 776, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14171, 776, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14172, 776, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14173, 776, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14174, 776, 1, 1, 1, 0, 0, 0, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14175, 776, 1, 1, 1, 1, 1, 0, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14176, 776, 1, 1, 1, 1, 1, 0, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14177, 777, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14178, 777, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14179, 777, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14180, 777, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14181, 778, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14182, 778, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14183, 778, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14184, 778, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14185, 778, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14186, 778, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14187, 778, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14188, 778, 1, 1, 1, 0, 0, 0, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14189, 778, 1, 1, 1, 0, 0, 0, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14190, 778, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14191, 778, 1, 1, 1, 0, 0, 0, 0, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14192, 778, 1, 1, 1, 0, 0, 0, 0, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14193, 778, 1, 1, 1, 0, 0, 0, 0, 12, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14194, 778, 1, 1, 1, 0, 0, 0, 0, 13, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14195, 778, 1, 1, 1, 0, 0, 0, 0, 14, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14196, 778, 1, 1, 1, 0, 0, 0, 0, 15, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14197, 779, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14198, 779, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14199, 779, 1, 1, 1, 0, 0, 1000000, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14200, 779, 1, 1, 1, 0, 0, 1000000, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14201, 779, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14202, 779, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14203, 779, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14204, 779, 1, 1, 1, 0, 0, 0, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14205, 779, 1, 1, 1, 0, 0, 0, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14206, 779, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14207, 779, 1, 1, 1, 0, 0, 0, 0, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14208, 779, 1, 1, 1, 0, 0, 0, 0, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14209, 779, 1, 1, 1, 0, 0, 0, 0, 12, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14210, 779, 1, 1, 1, 0, 0, 0, 0, 13, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14211, 779, 1, 1, 1, 0, 0, 0, 0, 14, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14212, 779, 1, 1, 1, 0, 0, 0, 0, 15, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14213, 779, 1, 1, 1, 0, 0, 0, 0, 16, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14214, 779, 1, 1, 1, 0, 0, 0, 0, 17, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14215, 779, 1, 1, 1, 0, 0, 0, 0, 18, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14216, 779, 1, 1, 1, 0, 0, 0, 0, 19, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14217, 779, 1, 1, 1, 0, 0, 0, 0, 20, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14218, 779, 1, 1, 1, 0, 0, 0, 0, 21, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14219, 779, 1, 1, 1, 0, 0, 0, 0, 22, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14220, 779, 1, 1, 1, 0, 0, 0, 0, 23, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14221, 779, 1, 1, 1, 0, 0, 0, 0, 24, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14222, 779, 1, 1, 1, 0, 0, 0, 0, 25, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14223, 779, 1, 1, 1, 0, 0, 0, 0, 26, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14224, 779, 1, 1, 1, 0, 0, 0, 0, 27, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14225, 779, 1, 1, 1, 0, 0, 0, 0, 28, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14226, 779, 1, 1, 1, 0, 0, 0, 0, 29, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14227, 779, 1, 1, 1, 0, 0, 0, 0, 30, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14228, 779, 1, 1, 1, 0, 0, 0, 0, 31, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 11541, 706, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 11542, 706, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 11543, 706, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 11544, 706, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 11545, 706, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 11546, 706, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 11547, 706, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 10106, 634, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 10107, 634, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 10108, 634, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 10109, 634, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 10110, 634, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13667, 739, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13668, 739, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13669, 739, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13670, 739, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13671, 739, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13672, 739, 1, 1, 1, 1, 1, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13673, 739, 1, 1, 1, 1, 1, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13674, 739, 1, 1, 1, 1, 1, 0, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13675, 739, 1, 1, 1, 1, 1, 0, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13676, 739, 1, 1, 1, 1, 1, 0, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13677, 739, 1, 1, 1, 1, 1, 0, 0, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13678, 739, 1, 1, 1, 1, 1, 0, 0, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13679, 739, 1, 1, 1, 1, 1, 0, 0, 12, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13680, 739, 1, 1, 1, 1, 1, 0, 0, 13, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13681, 739, 1, 1, 1, 1, 1, 0, 0, 14, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13682, 739, 1, 1, 1, 1, 1, 0, 0, 15, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13683, 739, 1, 1, 1, 1, 1, 0, 0, 16, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13684, 739, 1, 1, 1, 1, 1, 0, 0, 17, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13685, 739, 1, 1, 1, 1, 1, 0, 0, 18, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13686, 739, 1, 1, 1, 1, 1, 0, 0, 19, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13687, 739, 1, 1, 1, 1, 1, 0, 0, 20, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13688, 739, 1, 1, 1, 1, 1, 0, 0, 21, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13689, 739, 1, 1, 1, 1, 1, 0, 0, 22, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13690, 739, 1, 1, 1, 1, 1, 0, 0, 23, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13691, 739, 1, 1, 1, 1, 1, 0, 0, 24, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13692, 739, 1, 1, 1, 1, 1, 0, 0, 25, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13693, 739, 1, 1, 1, 1, 1, 0, 0, 26, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13694, 739, 1, 1, 1, 1, 1, 0, 0, 27, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13695, 739, 1, 1, 1, 1, 1, 0, 0, 28, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13696, 739, 1, 1, 1, 1, 1, 0, 0, 29, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13697, 739, 1, 1, 1, 1, 1, 0, 0, 30, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13698, 739, 1, 1, 1, 1, 1, 0, 0, 31, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13699, 739, 1, 1, 1, 1, 1, 0, 0, 32, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13700, 739, 1, 1, 1, 1, 1, 0, 0, 33, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13701, 739, 1, 1, 1, 1, 1, 0, 0, 34, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13702, 739, 1, 1, 1, 1, 1, 0, 0, 35, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13703, 739, 1, 1, 1, 1, 1, 0, 0, 36, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13704, 739, 1, 1, 1, 1, 1, 0, 0, 37, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13705, 739, 1, 1, 1, 1, 1, 0, 0, 38, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13706, 739, 1, 1, 1, 1, 1, 0, 0, 39, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13707, 739, 1, 1, 1, 1, 1, 0, 0, 40, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13708, 739, 1, 1, 1, 1, 1, 0, 0, 41, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13709, 739, 1, 1, 1, 1, 1, 0, 0, 42, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13710, 739, 1, 1, 1, 1, 1, 0, 0, 43, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13711, 739, 1, 1, 1, 1, 1, 0, 0, 44, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13712, 739, 1, 1, 1, 1, 1, 0, 0, 45, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13713, 739, 1, 1, 1, 1, 1, 0, 0, 46, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13714, 739, 1, 1, 1, 1, 1, 0, 0, 47, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13715, 739, 1, 1, 1, 1, 1, 0, 0, 48, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13716, 739, 1, 1, 1, 1, 1, 0, 0, 49, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13717, 739, 1, 1, 1, 1, 1, 0, 0, 50, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13718, 739, 1, 1, 1, 1, 1, 0, 0, 51, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13719, 739, 1, 1, 1, 1, 1, 0, 0, 52, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13720, 739, 1, 1, 1, 1, 1, 0, 0, 53, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13721, 739, 1, 1, 1, 1, 1, 0, 0, 54, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13722, 739, 1, 1, 1, 1, 1, 0, 0, 55, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13723, 739, 1, 1, 1, 1, 1, 0, 0, 56, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13724, 739, 1, 1, 1, 1, 1, 0, 0, 57, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13725, 739, 1, 1, 1, 1, 1, 0, 0, 58, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13726, 739, 1, 1, 1, 1, 1, 0, 0, 59, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13727, 739, 1, 1, 1, 1, 1, 0, 0, 60, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13728, 739, 1, 1, 1, 1, 1, 0, 0, 61, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13729, 739, 1, 1, 1, 1, 1, 0, 0, 62, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13730, 739, 1, 1, 1, 1, 1, 0, 0, 63, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13731, 739, 1, 1, 1, 1, 1, 0, 0, 64, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13732, 739, 1, 1, 1, 1, 1, 0, 0, 65, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13733, 739, 1, 1, 1, 1, 1, 0, 0, 66, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13734, 739, 1, 1, 1, 1, 1, 0, 0, 67, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13735, 739, 1, 1, 1, 1, 1, 0, 0, 68, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13736, 739, 1, 1, 1, 1, 1, 0, 0, 69, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13737, 739, 1, 1, 1, 1, 1, 0, 0, 70, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13738, 739, 1, 1, 1, 1, 1, 0, 0, 71, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13739, 739, 1, 1, 1, 1, 1, 0, 0, 72, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13740, 739, 1, 1, 1, 1, 1, 0, 0, 73, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13741, 739, 1, 1, 1, 1, 1, 0, 0, 74, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13742, 739, 1, 1, 1, 1, 1, 0, 0, 75, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13743, 739, 1, 1, 1, 1, 1, 0, 0, 76, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13744, 739, 1, 1, 1, 1, 1, 0, 0, 77, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 11629, 717, 1, 1, 1, 1, 1, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 11630, 717, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3401, 329, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3402, 329, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3403, 329, 1, 1, 1, 0, 0, 1, 50000, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3404, 329, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3405, 329, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3406, 329, 1, 1, 1, 0, 0, 1, 2500, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3407, 329, 1, 1, 1, 0, 0, 1, 2500, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3408, 329, 1, 1, 1, 0, 0, 1, 2500, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3409, 329, 1, 1, 1, 0, 0, 1, 2500, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10028, 624, 1, 1, 1, 1, 1, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10029, 624, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10030, 624, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10031, 624, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10032, 624, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10033, 624, 1, 1, 1, 1, 1, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10034, 624, 1, 1, 1, 1, 1, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10035, 624, 1, 1, 1, 1, 1, 0, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10036, 624, 1, 1, 1, 1, 1, 0, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10037, 624, 1, 1, 1, 1, 1, 0, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10038, 624, 1, 1, 1, 1, 1, 0, 0, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10039, 624, 1, 1, 1, 1, 1, 0, 0, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10040, 624, 1, 1, 1, 1, 1, 0, 0, 12, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10041, 624, 1, 1, 1, 1, 1, 0, 0, 13, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10042, 624, 1, 1, 1, 1, 1, 0, 0, 14, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10043, 624, 1, 1, 1, 1, 1, 0, 0, 15, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10044, 624, 1, 1, 1, 1, 1, 0, 0, 16, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10045, 624, 1, 1, 1, 1, 1, 0, 0, 17, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10046, 624, 1, 1, 1, 1, 1, 0, 0, 18, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10369, 648, 1, 1, 1, 1, 1, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10370, 648, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10371, 648, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3470, 336, 1, 1, 1, 0, 0, 138, 27683, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3471, 336, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3472, 336, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3384, 328, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3385, 328, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3386, 328, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3387, 328, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3388, 328, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3389, 328, 1, 1, 1, 1, 1, 0, 100220, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3390, 328, 1, 1, 1, 1, 1, 0, 53451, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3391, 328, 1, 1, 1, 1, 1, 0, 24720, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3392, 328, 1, 1, 1, 1, 1, 0, 24720, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3393, 328, 1, 1, 1, 1, 1, 0, 233847, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3394, 328, 1, 1, 1, 1, 1, 0, 53451, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3395, 328, 1, 1, 1, 1, 1, 0, 24720, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3396, 328, 1, 1, 1, 1, 1, 0, 0, 12, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3397, 328, 1, 1, 1, 1, 1, 0, 53451, 13, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3398, 328, 1, 1, 1, 1, 1, 0, 0, 14, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3399, 328, 1, 1, 1, 1, 1, 0, 0, 15, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3400, 328, 1, 1, 1, 0, 0, 0, 24720, 16, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 5575, 486, 1, 1, 1, 0, 0, 1, 1000000000, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 5576, 486, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 5577, 486, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 5578, 486, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14104, 767, 1, 1, 1, 0, 0, 500, 250001, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14105, 767, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14106, 767, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14107, 767, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14108, 767, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14109, 767, 1, 1, 1, 1, 1, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14110, 767, 1, 1, 1, 1, 1, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14111, 767, 1, 1, 1, 1, 1, 0, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14112, 767, 1, 1, 1, 1, 1, 0, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14113, 767, 1, 1, 1, 1, 1, 0, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14114, 767, 1, 1, 1, 1, 1, 0, 0, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14115, 767, 1, 1, 1, 1, 1, 0, 0, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10987, 670, 1, 1, 1, 1, 1, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10988, 670, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10989, 670, 1, 1, 1, 0, 0, 37494, 187472, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10990, 670, 1, 1, 1, 0, 0, 37494, 187472, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10991, 671, 1, 1, 1, 1, 1, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10992, 671, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10993, 671, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10994, 671, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10995, 671, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14028, 760, 1, 1, 1, 0, 0, 25001, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14029, 760, 1, 1, 1, 1, 1, 25001, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14030, 760, 1, 1, 1, 0, 0, 25001, 150000, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14031, 760, 1, 1, 1, 0, 0, 25001, 2000000, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14032, 760, 1, 1, 1, 0, 0, 25001, 600000, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14033, 760, 1, 1, 1, 0, 0, 25001, 200000, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14034, 760, 1, 1, 1, 0, 0, 25001, 150000, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14035, 760, 1, 1, 1, 0, 0, 25001, 250001, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14036, 760, 1, 1, 1, 0, 0, 25001, 250001, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14037, 760, 1, 1, 1, 0, 0, 25001, 100000, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14038, 760, 1, 1, 1, 0, 0, 25001, 250001, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14039, 760, 1, 1, 1, 0, 0, 25001, 749999, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14040, 760, 1, 1, 1, 0, 0, 25001, 0, 12, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14041, 760, 1, 1, 1, 0, 0, 25001, 100000, 13, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14042, 760, 1, 1, 1, 0, 0, 2000000, 0, 14, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14058, 762, 1, 1, 1, 0, 0, 100, 50000, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14059, 762, 1, 1, 1, 0, 0, 100, 50000, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14060, 762, 1, 1, 1, 0, 0, 1000, 50000, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14061, 762, 1, 1, 1, 0, 0, 1000, 50000, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14062, 762, 1, 1, 1, 0, 0, 1000, 50000, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14063, 762, 1, 1, 1, 0, 0, 1000, 50000, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14064, 762, 1, 1, 1, 0, 0, 1000, 50000, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14065, 762, 1, 1, 1, 0, 0, 1000, 50000, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14066, 762, 1, 1, 1, 0, 0, 1000, 50000, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14067, 762, 1, 1, 1, 0, 0, 1000, 20000, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14068, 762, 1, 1, 1, 0, 0, 1000, 20000, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14069, 762, 1, 1, 1, 0, 0, 1000, 50000, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14006, 758, 1, 1, 1, 0, 0, 25001, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14007, 758, 1, 1, 1, 1, 1, 200000, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14008, 758, 1, 1, 1, 0, 0, 200000, 1000000, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14009, 758, 1, 1, 1, 0, 0, 200000, 749999, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14010, 758, 1, 1, 1, 0, 0, 200000, 749999, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14011, 758, 1, 1, 1, 0, 0, 200000, 749999, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14012, 758, 1, 1, 1, 0, 0, 200000, 749999, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14013, 758, 1, 1, 1, 0, 0, 200000, 400000, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14014, 758, 1, 1, 1, 0, 0, 200000, 1000000, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14015, 758, 1, 1, 1, 0, 0, 200000, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14016, 758, 1, 1, 1, 0, 0, 1000000, 0, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14082, 764, 1, 1, 1, 0, 0, 50000, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14083, 764, 1, 1, 1, 1, 1, 50000, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14084, 764, 1, 1, 1, 1, 1, 50000, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14085, 764, 1, 1, 1, 1, 1, 50000, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14086, 764, 1, 1, 1, 1, 1, 50000, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14087, 764, 1, 1, 1, 1, 1, 50000, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14088, 765, 1, 1, 1, 0, 0, 50000, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14089, 765, 1, 1, 1, 0, 0, 50000, 1000000, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14090, 765, 1, 1, 1, 1, 1, 50000, 1000000, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14091, 765, 1, 1, 1, 1, 1, 50000, 1000000, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14092, 765, 1, 1, 1, 1, 1, 50000, 1000000, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14093, 765, 1, 1, 1, 1, 1, 50000, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14094, 765, 1, 1, 1, 1, 1, 50000, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14095, 765, 1, 1, 1, 0, 0, 50000, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14096, 765, 1, 1, 1, 0, 0, 50000, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14097, 765, 1, 1, 1, 0, 0, 50000, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14098, 765, 1, 1, 1, 0, 0, 50000, 0, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14099, 765, 1, 1, 1, 0, 0, 50000, 0, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14100, 765, 1, 1, 1, 0, 0, 50000, 0, 12, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7491, 583, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7492, 583, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7493, 583, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7494, 583, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7495, 583, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7496, 583, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7497, 583, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7498, 583, 1, 1, 1, 0, 0, 0, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7499, 583, 1, 1, 1, 0, 0, 0, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7500, 583, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7501, 583, 1, 1, 1, 0, 0, 0, 0, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7502, 583, 1, 1, 1, 0, 0, 0, 0, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7503, 583, 1, 1, 1, 0, 0, 0, 0, 12, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7504, 583, 1, 1, 1, 0, 0, 0, 0, 13, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7505, 583, 1, 1, 1, 0, 0, 0, 0, 14, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7506, 583, 1, 1, 1, 0, 0, 0, 0, 15, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7507, 583, 1, 1, 1, 0, 0, 0, 0, 16, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7508, 583, 1, 1, 1, 0, 0, 0, 0, 17, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7509, 583, 1, 1, 1, 1, 1, 0, 0, 18, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7510, 583, 1, 1, 1, 1, 1, 0, 0, 19, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7511, 583, 1, 1, 1, 1, 1, 0, 0, 20, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7512, 583, 1, 1, 1, 1, 1, 0, 0, 21, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7513, 583, 1, 1, 1, 1, 1, 0, 0, 22, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7514, 583, 1, 1, 1, 1, 1, 0, 0, 23, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7515, 583, 1, 1, 1, 1, 1, 0, 0, 24, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7516, 583, 1, 1, 1, 1, 1, 0, 0, 25, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7517, 584, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7518, 584, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7519, 584, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7520, 584, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7521, 584, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7522, 584, 1, 1, 1, 1, 1, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7523, 584, 1, 1, 1, 1, 1, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7524, 584, 1, 1, 1, 1, 1, 0, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7525, 584, 1, 1, 1, 1, 1, 0, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7526, 584, 1, 1, 1, 1, 1, 0, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7527, 584, 1, 1, 1, 1, 1, 0, 0, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10415, 655, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10416, 655, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10417, 655, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10418, 655, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10419, 655, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10420, 655, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10421, 655, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10422, 655, 1, 1, 1, 0, 0, 0, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10423, 655, 1, 1, 1, 0, 0, 0, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10424, 655, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10425, 655, 1, 1, 1, 0, 0, 0, 0, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10426, 655, 1, 1, 1, 0, 0, 0, 0, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10427, 655, 1, 1, 1, 0, 0, 0, 0, 12, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10428, 655, 1, 1, 1, 0, 0, 0, 0, 13, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10429, 655, 1, 1, 1, 0, 0, 0, 0, 14, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10430, 655, 1, 1, 1, 0, 0, 0, 0, 15, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10431, 655, 1, 1, 1, 0, 0, 0, 0, 16, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10432, 655, 1, 1, 1, 0, 0, 0, 0, 17, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10433, 655, 1, 1, 1, 0, 0, 0, 0, 18, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10434, 655, 1, 1, 1, 0, 0, 0, 0, 19, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10435, 655, 1, 1, 1, 0, 0, 0, 0, 20, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10436, 655, 1, 1, 1, 0, 0, 0, 0, 21, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10437, 655, 1, 1, 1, 0, 0, 0, 0, 22, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10438, 655, 1, 1, 1, 0, 0, 0, 0, 23, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10439, 655, 1, 1, 1, 0, 0, 0, 0, 24, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9877, 614, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9878, 614, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9879, 614, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9880, 614, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9881, 614, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9882, 614, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9883, 614, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9884, 614, 1, 1, 1, 0, 0, 0, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9885, 614, 1, 1, 1, 0, 0, 0, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9886, 614, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9887, 614, 1, 1, 1, 0, 0, 0, 0, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9888, 614, 1, 1, 1, 0, 0, 0, 0, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9889, 614, 1, 1, 1, 0, 0, 0, 0, 12, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9901, 616, 1, 1, 1, 1, 1, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9902, 616, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9903, 616, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9904, 616, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9905, 616, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9906, 616, 1, 1, 1, 1, 1, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9907, 616, 1, 1, 1, 1, 1, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9908, 616, 1, 1, 1, 1, 1, 0, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9909, 616, 1, 1, 1, 1, 1, 0, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9910, 616, 1, 1, 1, 1, 1, 0, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9911, 616, 1, 1, 1, 1, 1, 0, 0, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9912, 616, 1, 1, 1, 1, 1, 0, 0, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9913, 616, 1, 1, 1, 1, 1, 0, 0, 12, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9914, 616, 1, 1, 1, 1, 1, 0, 0, 13, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9915, 616, 1, 1, 1, 1, 1, 0, 0, 14, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9916, 616, 1, 1, 1, 1, 1, 0, 0, 15, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9917, 616, 1, 1, 1, 1, 1, 0, 0, 16, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9918, 616, 1, 1, 1, 1, 1, 0, 0, 17, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9919, 616, 1, 1, 1, 1, 1, 0, 0, 18, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9920, 616, 1, 1, 1, 1, 1, 0, 0, 19, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9921, 617, 1, 1, 1, 1, 1, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9922, 617, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9923, 617, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9924, 617, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9925, 617, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9926, 617, 1, 1, 1, 1, 1, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9927, 617, 1, 1, 1, 1, 1, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9928, 617, 1, 1, 1, 1, 1, 0, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9929, 617, 1, 1, 1, 1, 1, 0, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10047, 625, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10048, 625, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10049, 625, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10050, 625, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10051, 625, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10052, 625, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10053, 625, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10054, 625, 1, 1, 1, 0, 0, 0, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10055, 625, 1, 1, 1, 0, 0, 0, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10056, 625, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10057, 625, 1, 1, 1, 1, 1, 0, 0, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10058, 625, 1, 1, 1, 0, 0, 0, 0, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10194, 645, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10195, 645, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10196, 645, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10197, 645, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10198, 645, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10199, 645, 1, 1, 1, 1, 1, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10200, 645, 1, 1, 1, 1, 1, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7255, 525, 1, 1, 1, 0, 0, 0, 119999880, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7256, 525, 0, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7257, 525, 0, 1, 1, 0, 0, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7258, 525, 1, 1, 1, 0, 0, 0, 11999988, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7259, 525, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7260, 525, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7261, 525, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7262, 525, 1, 1, 1, 0, 0, 0, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7263, 525, 1, 1, 1, 0, 0, 0, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7264, 525, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7265, 525, 1, 1, 1, 0, 0, 0, 0, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7266, 525, 1, 1, 1, 1, 1, 0, 0, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7267, 525, 1, 1, 1, 1, 1, 0, 0, 12, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9663, 612, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9664, 612, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9665, 612, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9666, 612, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9667, 612, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9668, 612, 1, 1, 1, 1, 1, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9669, 612, 1, 1, 1, 1, 1, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9670, 612, 1, 1, 1, 1, 1, 0, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9671, 612, 1, 1, 1, 1, 1, 0, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9672, 612, 1, 1, 1, 1, 1, 0, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9673, 612, 1, 1, 1, 1, 1, 0, 0, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9674, 612, 1, 1, 1, 0, 0, 0, 0, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9675, 612, 1, 1, 1, 1, 1, 0, 0, 12, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9676, 612, 1, 1, 1, 1, 1, 0, 0, 13, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9677, 612, 1, 1, 1, 1, 1, 0, 0, 14, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9678, 612, 1, 1, 1, 1, 1, 0, 0, 15, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9679, 612, 1, 1, 1, 1, 1, 0, 0, 16, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9680, 612, 1, 1, 1, 1, 1, 0, 0, 17, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9681, 612, 1, 1, 1, 1, 1, 0, 0, 18, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9682, 612, 1, 1, 1, 1, 1, 0, 0, 19, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9683, 612, 1, 1, 1, 1, 1, 0, 0, 20, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9684, 612, 1, 1, 1, 1, 1, 0, 0, 21, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9685, 612, 1, 1, 1, 1, 1, 0, 0, 22, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9686, 612, 1, 1, 1, 1, 1, 0, 0, 23, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9687, 612, 1, 1, 1, 0, 0, 0, 0, 24, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9688, 612, 1, 1, 1, 1, 1, 0, 0, 25, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9689, 612, 1, 1, 1, 1, 1, 0, 0, 26, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9690, 612, 1, 1, 1, 0, 0, 0, 0, 27, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9691, 612, 1, 1, 1, 1, 1, 0, 0, 28, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9692, 612, 1, 1, 1, 1, 1, 0, 0, 29, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9693, 612, 1, 1, 1, 0, 0, 0, 0, 30, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9694, 612, 1, 1, 1, 1, 1, 0, 0, 31, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9695, 612, 1, 1, 1, 1, 1, 0, 0, 32, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9696, 612, 1, 1, 1, 0, 0, 0, 0, 33, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9697, 612, 1, 1, 1, 1, 1, 0, 0, 34, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9698, 612, 1, 1, 1, 1, 1, 0, 0, 35, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9699, 612, 1, 1, 1, 1, 1, 0, 0, 36, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9700, 612, 1, 1, 1, 1, 1, 0, 0, 37, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9701, 612, 1, 1, 1, 0, 0, 0, 0, 38, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9702, 612, 1, 1, 1, 1, 1, 0, 0, 39, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9703, 612, 1, 1, 1, 1, 1, 0, 0, 40, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9704, 612, 1, 1, 1, 1, 1, 0, 0, 41, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9705, 612, 1, 1, 1, 0, 0, 0, 0, 42, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9706, 612, 1, 1, 1, 1, 1, 0, 0, 43, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9707, 612, 1, 1, 1, 0, 0, 0, 0, 44, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9708, 612, 1, 1, 1, 1, 1, 0, 0, 45, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9709, 612, 1, 1, 1, 1, 1, 0, 0, 46, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9710, 612, 1, 1, 1, 1, 1, 0, 0, 47, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9711, 612, 1, 1, 1, 1, 1, 0, 0, 48, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9712, 612, 1, 1, 1, 1, 1, 0, 0, 49, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9713, 612, 1, 1, 1, 1, 1, 0, 0, 50, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9714, 612, 1, 1, 1, 1, 1, 0, 0, 51, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9715, 612, 1, 1, 1, 0, 0, 0, 0, 52, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9716, 612, 1, 1, 1, 1, 1, 0, 0, 53, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9717, 612, 1, 1, 1, 1, 1, 0, 0, 54, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9718, 612, 1, 1, 1, 1, 1, 0, 0, 55, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9719, 612, 1, 1, 1, 1, 1, 0, 0, 56, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9720, 612, 1, 1, 1, 1, 1, 0, 0, 57, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9721, 612, 1, 1, 1, 1, 1, 0, 0, 58, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9722, 612, 1, 1, 1, 0, 0, 0, 0, 59, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9723, 612, 1, 1, 1, 1, 1, 0, 0, 60, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9724, 612, 1, 1, 1, 1, 1, 0, 0, 61, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9725, 612, 1, 1, 1, 1, 1, 0, 0, 62, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9726, 612, 1, 1, 1, 1, 1, 0, 0, 63, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9727, 612, 1, 1, 1, 1, 1, 0, 0, 64, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9728, 612, 1, 1, 1, 0, 0, 0, 0, 65, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9729, 612, 1, 1, 1, 1, 1, 0, 0, 66, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9730, 612, 1, 1, 1, 1, 1, 0, 0, 67, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9731, 612, 1, 1, 1, 1, 1, 0, 0, 68, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9732, 612, 1, 1, 1, 1, 1, 0, 0, 69, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9733, 612, 1, 1, 1, 1, 1, 0, 0, 70, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9734, 612, 1, 1, 1, 0, 0, 0, 0, 71, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9735, 612, 1, 1, 1, 1, 1, 0, 0, 72, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9736, 612, 1, 1, 1, 1, 1, 0, 0, 73, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9737, 612, 1, 1, 1, 1, 1, 0, 0, 74, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9738, 612, 1, 1, 1, 1, 1, 0, 0, 75, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9739, 612, 1, 1, 1, 1, 1, 0, 0, 76, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9740, 612, 1, 1, 1, 1, 1, 0, 0, 77, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9741, 612, 1, 1, 1, 1, 1, 0, 0, 78, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9742, 612, 1, 1, 1, 1, 1, 0, 0, 79, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9743, 612, 1, 1, 1, 1, 1, 0, 0, 80, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9744, 612, 1, 1, 1, 1, 1, 0, 0, 81, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9745, 612, 1, 1, 1, 0, 0, 0, 0, 82, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9746, 612, 1, 1, 1, 1, 1, 0, 0, 83, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9747, 612, 1, 1, 1, 1, 1, 0, 0, 84, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9748, 612, 1, 1, 1, 1, 1, 0, 0, 85, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9749, 612, 1, 1, 1, 1, 1, 0, 0, 86, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9750, 612, 1, 1, 1, 1, 1, 0, 0, 87, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9751, 612, 1, 1, 1, 0, 0, 0, 0, 88, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9752, 612, 1, 1, 1, 1, 1, 0, 0, 89, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9753, 612, 1, 1, 1, 1, 1, 0, 0, 90, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9754, 612, 1, 1, 1, 1, 1, 0, 0, 91, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9755, 612, 1, 1, 1, 1, 1, 0, 0, 92, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9756, 612, 1, 1, 1, 1, 1, 0, 0, 93, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9757, 612, 1, 1, 1, 0, 0, 0, 0, 94, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9758, 612, 1, 1, 1, 0, 0, 0, 0, 95, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9759, 612, 1, 1, 1, 0, 0, 0, 0, 96, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9760, 612, 1, 1, 1, 1, 1, 0, 0, 97, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9761, 612, 1, 1, 1, 1, 1, 0, 0, 98, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9762, 612, 1, 1, 1, 1, 1, 0, 0, 99, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9763, 612, 1, 1, 1, 1, 1, 0, 0, 100, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9764, 612, 1, 1, 1, 1, 1, 0, 0, 101, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9765, 612, 1, 1, 1, 1, 1, 0, 0, 102, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9766, 612, 1, 1, 1, 1, 1, 0, 0, 103, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9767, 612, 1, 1, 1, 1, 1, 0, 0, 104, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9768, 612, 1, 1, 1, 0, 0, 0, 0, 105, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9769, 612, 1, 1, 1, 1, 1, 0, 0, 106, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9770, 612, 1, 1, 1, 1, 1, 0, 0, 107, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9771, 612, 1, 1, 1, 0, 0, 0, 0, 108, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9772, 612, 1, 1, 1, 1, 1, 0, 0, 109, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9773, 612, 1, 1, 1, 1, 1, 0, 0, 110, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9774, 612, 1, 1, 1, 1, 1, 0, 0, 111, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9775, 612, 1, 1, 1, 0, 0, 0, 0, 112, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9776, 612, 1, 1, 1, 1, 1, 0, 0, 113, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9777, 612, 1, 1, 1, 1, 1, 0, 0, 114, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9778, 612, 1, 1, 1, 0, 0, 0, 0, 115, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9779, 612, 1, 1, 1, 1, 1, 0, 0, 116, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9780, 612, 1, 1, 1, 1, 1, 0, 0, 117, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9781, 612, 1, 1, 1, 1, 1, 0, 0, 118, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9782, 612, 1, 1, 1, 1, 1, 0, 0, 119, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9783, 612, 1, 1, 1, 1, 1, 0, 0, 120, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9784, 612, 1, 1, 1, 1, 1, 0, 0, 121, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9785, 612, 1, 1, 1, 1, 1, 0, 0, 122, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9786, 612, 1, 1, 1, 0, 0, 0, 0, 123, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9787, 612, 1, 1, 1, 1, 1, 0, 0, 124, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9788, 612, 1, 1, 1, 1, 1, 0, 0, 125, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9789, 612, 1, 1, 1, 1, 1, 0, 0, 126, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9790, 612, 1, 1, 1, 1, 1, 0, 0, 127, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9791, 612, 1, 1, 1, 1, 1, 0, 0, 128, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9792, 612, 1, 1, 1, 1, 1, 0, 0, 129, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9793, 612, 1, 1, 1, 0, 0, 0, 0, 130, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9794, 612, 1, 1, 1, 1, 1, 0, 0, 131, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9795, 612, 1, 1, 1, 1, 1, 0, 0, 132, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9796, 612, 1, 1, 1, 1, 1, 0, 0, 133, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9797, 612, 1, 1, 1, 1, 1, 0, 0, 134, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9798, 612, 1, 1, 1, 1, 1, 0, 0, 135, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9799, 612, 1, 1, 1, 0, 0, 0, 0, 136, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9800, 612, 1, 1, 1, 1, 1, 0, 0, 137, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9801, 612, 1, 1, 1, 1, 1, 0, 0, 138, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9802, 612, 1, 1, 1, 1, 1, 0, 0, 139, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9803, 612, 1, 1, 1, 1, 1, 0, 0, 140, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9804, 612, 1, 1, 1, 1, 1, 0, 0, 141, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9805, 612, 1, 1, 1, 0, 0, 0, 0, 142, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9806, 612, 1, 1, 1, 1, 1, 0, 0, 143, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9807, 612, 1, 1, 1, 1, 1, 0, 0, 144, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9808, 612, 1, 1, 1, 1, 1, 0, 0, 145, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9809, 612, 1, 1, 1, 1, 1, 0, 0, 146, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9810, 612, 1, 1, 1, 1, 1, 0, 0, 147, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9811, 612, 1, 1, 1, 1, 1, 0, 0, 148, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9812, 612, 1, 1, 1, 1, 1, 0, 0, 149, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9813, 612, 1, 1, 1, 1, 1, 0, 0, 150, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9814, 612, 1, 1, 1, 1, 1, 0, 0, 151, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9815, 612, 1, 1, 1, 1, 1, 0, 0, 152, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9816, 612, 1, 1, 1, 0, 0, 0, 0, 153, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9817, 612, 1, 1, 1, 1, 1, 0, 0, 154, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9818, 612, 1, 1, 1, 1, 1, 0, 0, 155, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9819, 612, 1, 1, 1, 1, 1, 0, 0, 156, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9820, 612, 1, 1, 1, 1, 1, 0, 0, 157, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9821, 612, 1, 1, 1, 1, 1, 0, 0, 158, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9822, 612, 1, 1, 1, 0, 0, 0, 0, 159, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9823, 612, 1, 1, 1, 1, 1, 0, 0, 160, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9824, 612, 1, 1, 1, 1, 1, 0, 0, 161, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9825, 612, 1, 1, 1, 1, 1, 0, 0, 162, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9826, 612, 1, 1, 1, 1, 1, 0, 0, 163, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9827, 612, 1, 1, 1, 1, 1, 0, 0, 164, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9828, 612, 1, 1, 1, 0, 0, 0, 0, 165, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9829, 612, 1, 1, 1, 0, 0, 0, 0, 166, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9830, 612, 1, 1, 1, 1, 1, 0, 0, 167, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9831, 612, 1, 1, 1, 1, 1, 0, 0, 168, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9832, 612, 1, 1, 1, 0, 0, 0, 0, 169, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9833, 612, 1, 1, 1, 0, 0, 0, 0, 170, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9834, 612, 1, 1, 1, 1, 1, 0, 0, 171, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9835, 612, 1, 1, 1, 1, 1, 0, 0, 172, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9836, 612, 1, 1, 1, 0, 0, 0, 0, 173, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9837, 612, 1, 1, 1, 1, 1, 0, 0, 174, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9838, 612, 1, 1, 1, 1, 1, 0, 0, 175, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9839, 612, 1, 1, 1, 1, 1, 0, 0, 176, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9840, 612, 1, 1, 1, 1, 1, 0, 0, 177, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9841, 612, 1, 1, 1, 1, 1, 0, 0, 178, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9842, 612, 1, 1, 1, 0, 0, 0, 0, 179, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9843, 612, 1, 1, 1, 1, 1, 0, 0, 180, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9844, 612, 1, 1, 1, 1, 1, 0, 0, 181, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9845, 612, 1, 1, 1, 1, 1, 0, 0, 182, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9846, 612, 1, 1, 1, 0, 0, 0, 0, 183, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9847, 612, 1, 1, 1, 1, 1, 0, 2147483647, 184, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9848, 612, 1, 1, 1, 1, 1, 0, 0, 185, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9849, 612, 1, 1, 1, 1, 1, 0, 2147483647, 186, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9850, 612, 1, 1, 1, 1, 1, 0, 2147483647, 187, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9851, 612, 1, 1, 1, 1, 1, 0, 2147483647, 188, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9852, 612, 1, 1, 1, 1, 1, 0, 2147483647, 189, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9853, 612, 1, 1, 1, 1, 1, 0, 2147483647, 190, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9854, 612, 1, 1, 1, 1, 1, 0, 2147483647, 191, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9855, 612, 1, 1, 1, 1, 1, 0, 2147483647, 192, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9856, 612, 1, 1, 1, 1, 1, 0, 2147483647, 193, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9857, 612, 1, 1, 1, 1, 1, 0, 0, 194, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9858, 612, 1, 1, 1, 1, 1, 0, 2147483647, 195, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9859, 612, 1, 1, 1, 1, 1, 0, 2147483647, 196, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9860, 612, 1, 1, 1, 0, 0, 0, 2147483647, 197, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9861, 612, 1, 1, 1, 1, 1, 0, 2147483647, 198, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9862, 612, 1, 1, 1, 1, 1, 0, 2147483647, 199, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9863, 612, 1, 1, 1, 0, 0, 0, 0, 200, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9864, 612, 1, 1, 1, 0, 0, 0, 0, 201, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9865, 612, 1, 1, 1, 0, 0, 0, 0, 202, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9866, 612, 1, 1, 1, 1, 1, 2147483647, 2147483647, 203, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9867, 612, 1, 1, 1, 1, 1, 2147483647, 2147483647, 204, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9868, 612, 1, 1, 1, 1, 1, 2147483647, 2147483647, 205, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9869, 612, 1, 1, 1, 0, 0, 0, 0, 206, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9870, 612, 1, 1, 1, 1, 1, 2147483647, 2147483647, 207, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9871, 612, 1, 1, 1, 0, 0, 0, 0, 208, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9872, 612, 1, 1, 1, 0, 0, 0, 0, 209, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9873, 612, 1, 1, 1, 0, 0, 0, 0, 210, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9874, 612, 1, 1, 1, 0, 0, 0, 0, 211, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9875, 613, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9876, 613, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10165, 640, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10166, 640, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10167, 640, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10168, 640, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10169, 640, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10170, 640, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10171, 640, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10172, 640, 1, 1, 1, 0, 0, 0, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10173, 640, 1, 1, 1, 0, 0, 0, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10174, 640, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10175, 640, 1, 1, 1, 0, 0, 0, 0, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10176, 640, 1, 1, 1, 0, 0, 0, 0, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10177, 640, 1, 1, 1, 0, 0, 0, 0, 12, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10178, 640, 1, 1, 1, 0, 0, 0, 0, 13, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10179, 640, 1, 1, 1, 0, 0, 0, 0, 14, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10153, 637, 0, 0, 0, 0, 0, 50000, 149999900, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10154, 637, 1, 1, 1, 0, 0, 50000, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10155, 637, 1, 1, 1, 0, 0, 50000, 10000000, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10156, 637, 1, 1, 1, 0, 0, 50000, 2000000, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10157, 637, 1, 1, 1, 0, 0, 50000, 1000000, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10158, 637, 1, 1, 1, 0, 0, 50000, 749999, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10159, 637, 1, 1, 1, 0, 0, 4999990, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10160, 637, 1, 1, 1, 0, 0, 0, 4999990, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 13775, 101, 1, 1, 1, 0, 0, 1, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 13776, 101, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 13777, 101, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2712, 250, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2713, 250, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2714, 250, 1, 1, 1, 1, 0, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2715, 250, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2716, 250, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2717, 250, 1, 1, 1, 1, 0, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2718, 250, 1, 1, 1, 1, 0, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2719, 250, 1, 1, 1, 1, 0, 0, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2720, 250, 1, 1, 1, 1, 0, 0, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2721, 250, 1, 1, 1, 1, 0, 0, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2722, 250, 1, 1, 1, 1, 0, 0, 0, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2723, 250, 1, 1, 1, 1, 0, 0, 0, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2724, 250, 1, 1, 1, 1, 0, 0, 0, 12, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2725, 250, 1, 1, 1, 1, 0, 0, 0, 13, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2726, 250, 1, 1, 1, 1, 0, 0, 0, 14, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2727, 250, 1, 1, 1, 1, 0, 0, 0, 15, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2728, 250, 1, 1, 1, 1, 0, 0, 0, 16, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2729, 250, 1, 1, 1, 1, 0, 0, 0, 17, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2730, 250, 1, 1, 1, 0, 0, 0, 0, 18, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2731, 250, 1, 1, 1, 1, 0, 0, 0, 19, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2732, 250, 1, 1, 1, 1, 0, 0, 0, 20, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 13751, 86, 1, 1, 1, 0, 0, 1, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 13752, 86, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 13753, 86, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 13754, 86, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 13755, 86, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14251, 785, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14252, 785, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14253, 785, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14254, 785, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14255, 786, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14256, 786, 1, 1, 1, 0, 0, 1, 125000, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14257, 787, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14258, 787, 1, 1, 1, 0, 0, 20, 400880, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14259, 787, 1, 1, 1, 0, 0, 20, 80176, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14260, 787, 1, 1, 1, 0, 0, 20, 801759, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14261, 788, 1, 1, 1, 0, 0, 10000, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14262, 788, 1, 1, 1, 0, 0, 50000, 2000000, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14263, 788, 1, 1, 1, 0, 0, 10000, 50000, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14264, 789, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14265, 789, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14266, 789, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14267, 789, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14268, 789, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14269, 789, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14270, 789, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14271, 789, 1, 1, 1, 0, 0, 0, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14272, 789, 1, 1, 1, 0, 0, 0, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14273, 789, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14274, 789, 1, 1, 1, 0, 0, 0, 0, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14275, 789, 1, 1, 1, 0, 0, 0, 0, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14276, 789, 1, 1, 1, 0, 0, 0, 0, 12, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14277, 790, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14278, 790, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14279, 790, 1, 1, 1, 0, 0, 0, 847059, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14280, 790, 1, 1, 1, 0, 0, 0, 795580, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14281, 790, 1, 1, 1, 0, 0, 0, 423530, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14287, 792, 1, 1, 1, 0, 0, 200, 200440, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14288, 792, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14289, 792, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14290, 792, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14291, 792, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14292, 792, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14293, 792, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14294, 792, 1, 1, 1, 0, 0, 0, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14295, 792, 1, 1, 1, 0, 0, 0, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14296, 792, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14297, 793, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14298, 793, 1, 1, 1, 0, 0, 601, 50110, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14299, 793, 1, 1, 1, 0, 0, 1203, 150330, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14300, 793, 1, 1, 1, 0, 0, 40088, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14301, 794, 1, 1, 1, 0, 0, 25001, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14302, 794, 1, 1, 1, 1, 1, 25001, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14303, 794, 1, 1, 1, 0, 0, 25001, 150000, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14304, 794, 1, 1, 1, 0, 0, 25001, 2000000, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14305, 794, 1, 1, 1, 0, 0, 25001, 600000, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14306, 794, 1, 1, 1, 0, 0, 25001, 200000, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14307, 794, 1, 1, 1, 0, 0, 25001, 150000, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14308, 794, 1, 1, 1, 0, 0, 25001, 250001, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14309, 794, 1, 1, 1, 0, 0, 25001, 250001, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14310, 794, 1, 1, 1, 0, 0, 25001, 100000, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14311, 794, 1, 1, 1, 0, 0, 25001, 250001, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14312, 794, 1, 1, 1, 0, 0, 25001, 749999, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14313, 794, 1, 1, 1, 0, 0, 25001, 0, 12, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14314, 794, 1, 1, 1, 0, 0, 25001, 100000, 13, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14315, 794, 1, 1, 1, 0, 0, 2000000, 0, 14, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14331, 796, 1, 1, 1, 0, 0, 200, 200440, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14332, 796, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14333, 796, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14334, 796, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14335, 796, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14336, 796, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14337, 796, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14338, 796, 1, 1, 1, 0, 0, 0, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14339, 796, 1, 1, 1, 0, 0, 0, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14340, 796, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14341, 797, 1, 1, 1, 0, 0, 50000, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14342, 797, 1, 1, 1, 1, 1, 50000, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14343, 797, 1, 1, 1, 1, 1, 50000, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14344, 797, 1, 1, 1, 1, 1, 50000, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14345, 797, 1, 1, 1, 1, 1, 50000, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14346, 797, 1, 1, 1, 1, 1, 50000, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14347, 798, 1, 1, 1, 0, 0, 50000, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14348, 798, 1, 1, 1, 0, 0, 50000, 1000000, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14349, 798, 1, 1, 1, 1, 1, 50000, 1000000, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14350, 798, 1, 1, 1, 1, 1, 50000, 1000000, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14351, 798, 1, 1, 1, 1, 1, 50000, 1000000, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14352, 798, 1, 1, 1, 1, 1, 50000, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14353, 798, 1, 1, 1, 1, 1, 50000, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14354, 798, 1, 1, 1, 0, 0, 50000, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14355, 798, 1, 1, 1, 0, 0, 50000, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14356, 798, 1, 1, 1, 0, 0, 50000, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14357, 798, 1, 1, 1, 0, 0, 50000, 0, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14358, 798, 1, 1, 1, 0, 0, 50000, 0, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14359, 798, 1, 1, 1, 0, 0, 50000, 0, 12, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14360, 799, 1, 1, 1, 0, 0, 10000, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14361, 799, 1, 1, 1, 0, 0, 50000, 2000000, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14362, 799, 1, 1, 1, 0, 0, 10000, 50000, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2712, 250, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2713, 250, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2714, 250, 1, 1, 1, 1, 0, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2715, 250, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2716, 250, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2717, 250, 1, 1, 1, 1, 0, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2718, 250, 1, 1, 1, 1, 0, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2719, 250, 1, 1, 1, 1, 0, 0, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2720, 250, 1, 1, 1, 1, 0, 0, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2721, 250, 1, 1, 1, 1, 0, 0, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2722, 250, 1, 1, 1, 1, 0, 0, 0, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2723, 250, 1, 1, 1, 1, 0, 0, 0, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2724, 250, 1, 1, 1, 1, 0, 0, 0, 12, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2725, 250, 1, 1, 1, 1, 0, 0, 0, 13, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2726, 250, 1, 1, 1, 1, 0, 0, 0, 14, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2727, 250, 1, 1, 1, 1, 0, 0, 0, 15, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2728, 250, 1, 1, 1, 1, 0, 0, 0, 16, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2729, 250, 1, 1, 1, 1, 0, 0, 0, 17, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2730, 250, 1, 1, 1, 0, 0, 0, 0, 18, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2731, 250, 1, 1, 1, 1, 0, 0, 0, 19, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2732, 250, 1, 1, 1, 1, 0, 0, 0, 20, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14363, 800, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14364, 800, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14365, 800, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14366, 800, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10165, 640, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10166, 640, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10167, 640, 1, 1, 0, 0, 0, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10168, 640, 1, 1, 0, 0, 0, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10169, 640, 1, 1, 0, 0, 0, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10170, 640, 1, 1, 0, 0, 0, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10171, 640, 1, 1, 0, 0, 0, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10172, 640, 1, 1, 0, 0, 0, 0, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10173, 640, 1, 1, 0, 0, 0, 0, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10174, 640, 1, 1, 0, 0, 0, 0, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10175, 640, 1, 1, 0, 0, 0, 0, 0, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10176, 640, 1, 1, 0, 0, 0, 0, 0, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10177, 640, 1, 1, 0, 0, 0, 0, 0, 12, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10178, 640, 1, 1, 0, 0, 0, 0, 0, 13, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10179, 640, 1, 1, 0, 0, 0, 0, 0, 14, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14370, 824, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14371, 824, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14372, 824, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14373, 824, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14374, 824, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14375, 824, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14376, 824, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14377, 824, 1, 1, 1, 0, 0, 0, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14378, 824, 1, 1, 1, 0, 0, 0, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14379, 824, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14380, 824, 1, 1, 1, 0, 0, 0, 0, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14381, 824, 1, 1, 1, 0, 0, 0, 0, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14382, 824, 1, 1, 1, 0, 0, 0, 0, 12, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14383, 824, 1, 1, 1, 0, 0, 0, 0, 13, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14384, 824, 1, 1, 1, 0, 0, 0, 0, 14, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14385, 824, 1, 1, 1, 0, 0, 0, 0, 15, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14386, 824, 1, 1, 1, 0, 0, 0, 0, 16, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14387, 824, 1, 1, 1, 0, 0, 0, 0, 17, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14388, 824, 1, 1, 1, 0, 0, 0, 0, 18, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14389, 824, 1, 1, 1, 0, 0, 0, 0, 19, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14390, 824, 1, 1, 1, 0, 0, 0, 0, 20, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14391, 824, 1, 1, 1, 0, 0, 0, 0, 21, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14392, 824, 1, 1, 1, 0, 0, 0, 0, 22, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14393, 824, 1, 1, 1, 0, 0, 0, 0, 23, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14394, 824, 1, 1, 1, 0, 0, 0, 0, 24, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14395, 824, 1, 1, 1, 0, 0, 0, 0, 25, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14396, 824, 1, 1, 1, 0, 0, 0, 0, 26, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14397, 824, 1, 1, 1, 0, 0, 0, 0, 27, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14398, 824, 1, 1, 1, 0, 0, 0, 0, 28, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14399, 824, 1, 1, 1, 0, 0, 0, 0, 29, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14400, 824, 1, 1, 1, 0, 0, 0, 0, 30, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14401, 824, 1, 1, 1, 0, 0, 0, 0, 31, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14402, 824, 1, 1, 1, 0, 0, 0, 0, 32, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14403, 824, 1, 1, 1, 0, 0, 0, 0, 33, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14404, 824, 1, 1, 1, 0, 0, 0, 0, 34, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14405, 824, 1, 1, 1, 0, 0, 0, 0, 35, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14406, 824, 1, 1, 1, 0, 0, 0, 0, 36, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14407, 824, 1, 1, 1, 0, 0, 0, 0, 37, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14408, 824, 1, 1, 1, 0, 0, 0, 0, 38, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14409, 824, 1, 1, 1, 0, 0, 0, 0, 39, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14410, 824, 1, 1, 1, 0, 0, 0, 0, 40, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14411, 824, 1, 1, 1, 0, 0, 0, 0, 41, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14412, 824, 1, 1, 1, 0, 0, 0, 0, 42, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14413, 824, 1, 1, 1, 0, 0, 0, 0, 43, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14414, 824, 1, 1, 1, 0, 0, 0, 0, 44, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14415, 824, 1, 1, 1, 0, 0, 0, 0, 45, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14416, 824, 1, 1, 1, 0, 0, 0, 0, 46, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14417, 824, 1, 1, 1, 0, 0, 0, 0, 47, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14418, 824, 1, 1, 1, 0, 0, 0, 0, 48, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14419, 824, 1, 1, 1, 0, 0, 0, 0, 49, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14420, 824, 1, 1, 1, 0, 0, 0, 0, 50, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14421, 824, 1, 1, 1, 0, 0, 0, 0, 51, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14422, 824, 1, 1, 1, 0, 0, 0, 0, 52, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14423, 824, 1, 1, 1, 0, 0, 0, 0, 53, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14424, 824, 1, 1, 1, 0, 0, 0, 0, 54, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14425, 824, 1, 1, 1, 0, 0, 0, 0, 55, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14426, 824, 1, 1, 1, 0, 0, 0, 0, 56, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14427, 824, 1, 1, 1, 0, 0, 0, 0, 57, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14428, 824, 1, 1, 1, 0, 0, 0, 0, 58, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14429, 824, 1, 1, 1, 0, 0, 0, 0, 59, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14430, 824, 1, 1, 1, 0, 0, 0, 0, 60, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14431, 824, 1, 1, 1, 0, 0, 0, 0, 61, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14432, 824, 1, 1, 1, 0, 0, 0, 0, 62, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14433, 824, 1, 1, 1, 0, 0, 0, 0, 63, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14434, 824, 1, 1, 1, 0, 0, 0, 0, 64, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14435, 824, 1, 1, 1, 0, 0, 0, 0, 65, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14436, 824, 1, 1, 1, 0, 0, 0, 0, 66, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14437, 824, 1, 1, 1, 0, 0, 0, 0, 67, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14438, 824, 1, 1, 1, 0, 0, 0, 0, 68, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14439, 824, 1, 1, 1, 0, 0, 0, 0, 69, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14440, 824, 1, 1, 1, 0, 0, 0, 0, 70, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14441, 824, 1, 1, 1, 0, 0, 0, 0, 71, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14442, 824, 1, 1, 1, 0, 0, 0, 0, 72, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14443, 824, 1, 1, 1, 0, 0, 0, 0, 73, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14444, 824, 1, 1, 1, 0, 0, 0, 0, 74, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14445, 824, 1, 1, 1, 0, 0, 0, 0, 75, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14446, 824, 1, 1, 1, 0, 0, 0, 0, 76, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14447, 824, 1, 1, 1, 0, 0, 0, 0, 77, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14448, 824, 1, 1, 1, 0, 0, 0, 0, 78, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14449, 824, 1, 1, 1, 0, 0, 0, 0, 79, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14450, 824, 1, 1, 1, 0, 0, 0, 0, 80, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14451, 824, 1, 1, 1, 0, 0, 0, 0, 81, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14452, 824, 1, 1, 1, 0, 0, 0, 0, 82, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14453, 824, 1, 1, 1, 0, 0, 0, 0, 83, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14454, 824, 1, 1, 1, 0, 0, 0, 0, 84, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14455, 824, 1, 1, 1, 0, 0, 0, 0, 85, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14456, 824, 1, 1, 1, 0, 0, 0, 0, 86, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14457, 824, 1, 1, 1, 0, 0, 0, 0, 87, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14458, 824, 1, 1, 1, 0, 0, 0, 0, 88, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14459, 824, 1, 1, 1, 0, 0, 0, 0, 89, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14460, 824, 1, 1, 1, 0, 0, 0, 0, 90, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14461, 824, 1, 1, 1, 0, 0, 0, 0, 91, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14462, 824, 1, 1, 1, 0, 0, 0, 0, 92, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14463, 824, 1, 1, 1, 0, 0, 0, 0, 93, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14464, 824, 1, 1, 1, 0, 0, 0, 0, 94, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14465, 824, 1, 1, 1, 0, 0, 0, 0, 95, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14466, 824, 1, 1, 1, 0, 0, 0, 0, 96, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14467, 824, 1, 1, 1, 0, 0, 0, 0, 97, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14468, 824, 1, 1, 1, 0, 0, 0, 0, 98, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14469, 824, 1, 1, 1, 0, 0, 0, 0, 99, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14470, 824, 1, 1, 1, 0, 0, 0, 0, 100, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14471, 824, 1, 1, 1, 0, 0, 0, 0, 101, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14472, 824, 1, 1, 1, 0, 0, 0, 0, 102, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14473, 824, 1, 1, 1, 0, 0, 0, 0, 103, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14474, 824, 1, 1, 1, 0, 0, 0, 0, 104, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14475, 824, 1, 1, 1, 0, 0, 0, 0, 105, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14476, 824, 1, 1, 1, 0, 0, 0, 0, 106, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14477, 824, 1, 1, 1, 0, 0, 0, 0, 107, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14478, 824, 1, 1, 1, 0, 0, 0, 0, 108, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14479, 824, 1, 1, 1, 0, 0, 0, 0, 109, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14480, 824, 1, 1, 1, 0, 0, 0, 0, 110, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14481, 824, 1, 1, 1, 0, 0, 0, 0, 111, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14482, 824, 1, 1, 1, 0, 0, 0, 0, 112, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14483, 824, 1, 1, 1, 0, 0, 0, 0, 113, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14484, 824, 1, 1, 1, 0, 0, 0, 0, 114, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14485, 824, 1, 1, 1, 0, 0, 0, 0, 115, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14486, 824, 1, 1, 1, 0, 0, 0, 0, 116, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14487, 824, 1, 1, 1, 0, 0, 0, 0, 117, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14488, 824, 1, 1, 1, 0, 0, 0, 0, 118, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14489, 824, 1, 1, 1, 0, 0, 0, 0, 119, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14490, 824, 1, 1, 1, 0, 0, 0, 0, 120, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14491, 824, 1, 1, 1, 0, 0, 0, 0, 121, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14492, 824, 1, 1, 1, 0, 0, 0, 0, 122, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14493, 824, 1, 1, 1, 0, 0, 0, 0, 123, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14494, 824, 1, 1, 1, 0, 0, 0, 0, 124, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14495, 824, 1, 1, 1, 0, 0, 0, 0, 125, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14496, 824, 1, 1, 1, 0, 0, 0, 0, 126, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14497, 824, 1, 1, 1, 0, 0, 0, 0, 127, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14498, 824, 1, 1, 1, 0, 0, 0, 0, 128, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14499, 824, 1, 1, 1, 0, 0, 0, 0, 129, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14500, 824, 1, 1, 1, 0, 0, 0, 0, 130, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14501, 824, 1, 1, 1, 0, 0, 0, 0, 131, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14502, 824, 1, 1, 1, 0, 0, 0, 0, 132, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14503, 824, 1, 1, 1, 0, 0, 0, 0, 133, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14504, 824, 1, 1, 1, 0, 0, 0, 0, 134, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14505, 824, 1, 1, 1, 0, 0, 0, 0, 135, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14506, 824, 1, 1, 1, 0, 0, 0, 0, 136, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14507, 824, 1, 1, 1, 0, 0, 0, 0, 137, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14508, 824, 1, 1, 1, 0, 0, 0, 0, 138, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14509, 824, 1, 1, 1, 0, 0, 0, 0, 139, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14510, 824, 1, 1, 1, 0, 0, 0, 0, 140, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14511, 824, 1, 1, 1, 0, 0, 0, 0, 141, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14512, 824, 1, 1, 1, 0, 0, 0, 0, 142, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14513, 824, 1, 1, 1, 0, 0, 0, 0, 143, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14514, 824, 1, 1, 1, 0, 0, 0, 0, 144, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14515, 824, 1, 1, 1, 0, 0, 0, 0, 145, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14516, 824, 1, 1, 1, 0, 0, 0, 0, 146, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14517, 824, 1, 1, 1, 0, 0, 0, 0, 147, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14518, 824, 1, 1, 1, 0, 0, 0, 0, 148, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14519, 824, 1, 1, 1, 0, 0, 0, 0, 149, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14520, 824, 1, 1, 1, 0, 0, 0, 0, 150, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 14525, 827, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 14526, 827, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14527, 828, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14528, 828, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14529, 828, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14530, 828, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14531, 828, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14532, 828, 1, 1, 1, 1, 1, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14533, 828, 1, 1, 1, 1, 1, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14534, 829, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14535, 829, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14550, 831, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14551, 831, 1, 1, 1, 0, 0, 0, 125000, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14552, 831, 1, 1, 1, 0, 0, 0, 30000, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14553, 831, 1, 1, 1, 0, 0, 0, 499999, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14554, 831, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14555, 831, 1, 1, 1, 0, 0, 0, 100000, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14556, 831, 1, 1, 1, 0, 0, 0, 100000, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14557, 832, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14558, 832, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14559, 832, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14560, 832, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14561, 833, 1, 1, 1, 1, 1, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14562, 833, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14563, 833, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14564, 833, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14565, 833, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14566, 833, 1, 1, 1, 1, 1, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14567, 833, 1, 1, 1, 1, 1, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14568, 833, 1, 1, 1, 1, 1, 0, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14569, 833, 1, 1, 1, 1, 1, 0, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14570, 833, 1, 1, 1, 1, 1, 0, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14571, 833, 1, 1, 1, 1, 1, 0, 0, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14572, 833, 1, 1, 1, 1, 1, 0, 0, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14573, 833, 1, 1, 1, 1, 1, 0, 0, 12, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14574, 833, 1, 1, 1, 1, 1, 0, 0, 13, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14575, 833, 1, 1, 1, 1, 1, 0, 0, 14, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14576, 833, 1, 1, 1, 1, 1, 0, 0, 15, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14577, 833, 1, 1, 1, 1, 1, 0, 0, 16, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14578, 833, 1, 1, 1, 1, 1, 0, 0, 17, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14579, 833, 1, 1, 1, 1, 1, 0, 0, 18, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14580, 833, 1, 1, 1, 1, 1, 0, 0, 19, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14581, 833, 1, 1, 1, 1, 1, 0, 0, 20, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14582, 833, 1, 1, 1, 1, 1, 0, 0, 21, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14583, 833, 1, 1, 1, 1, 1, 0, 0, 22, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14584, 833, 1, 1, 1, 1, 1, 0, 0, 23, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14585, 833, 1, 1, 1, 1, 1, 0, 0, 24, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14586, 833, 1, 1, 1, 1, 1, 0, 0, 25, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14587, 833, 1, 1, 1, 1, 1, 0, 0, 26, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14588, 833, 1, 1, 1, 1, 1, 0, 0, 27, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14589, 833, 1, 1, 1, 1, 1, 0, 0, 28, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14590, 833, 1, 1, 1, 1, 1, 0, 0, 29, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14591, 833, 1, 1, 1, 1, 1, 0, 0, 30, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14592, 833, 1, 1, 1, 1, 1, 0, 0, 31, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14593, 833, 1, 1, 1, 1, 1, 0, 0, 32, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14594, 833, 1, 1, 1, 1, 1, 0, 0, 33, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14595, 833, 1, 1, 1, 1, 1, 0, 0, 34, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14596, 833, 1, 1, 1, 1, 1, 0, 0, 35, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14597, 833, 1, 1, 1, 1, 1, 0, 0, 36, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14598, 833, 1, 1, 1, 1, 1, 0, 0, 37, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14599, 833, 1, 1, 1, 1, 1, 0, 0, 38, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14600, 833, 1, 1, 1, 1, 1, 0, 0, 39, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14601, 833, 1, 1, 1, 1, 1, 0, 0, 40, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14602, 833, 1, 1, 1, 1, 1, 0, 0, 41, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14603, 833, 1, 1, 1, 1, 1, 0, 0, 42, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14604, 833, 1, 1, 1, 1, 1, 0, 0, 43, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14605, 833, 1, 1, 1, 1, 1, 0, 0, 44, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14606, 833, 1, 1, 1, 1, 1, 0, 0, 45, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14607, 833, 1, 1, 1, 1, 1, 0, 0, 46, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14608, 833, 1, 1, 1, 1, 1, 0, 0, 47, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14609, 833, 1, 1, 1, 1, 1, 0, 0, 48, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14610, 833, 1, 1, 1, 1, 1, 0, 0, 49, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14611, 833, 1, 1, 1, 1, 1, 0, 0, 50, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14612, 833, 1, 1, 1, 1, 1, 0, 0, 51, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14613, 833, 1, 1, 1, 1, 1, 0, 0, 52, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14614, 833, 1, 1, 1, 1, 1, 0, 0, 53, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14615, 833, 1, 1, 1, 1, 1, 0, 0, 54, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14616, 833, 1, 1, 1, 1, 1, 0, 0, 55, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14617, 833, 1, 1, 1, 1, 1, 0, 0, 56, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14618, 833, 1, 1, 1, 1, 1, 0, 0, 57, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14619, 833, 1, 1, 1, 1, 1, 0, 0, 58, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14620, 833, 1, 1, 1, 1, 1, 0, 0, 59, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14621, 833, 1, 1, 1, 1, 1, 0, 0, 60, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14622, 833, 1, 1, 1, 1, 1, 0, 0, 61, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14623, 833, 1, 1, 1, 1, 1, 0, 0, 62, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14624, 833, 1, 1, 1, 1, 1, 0, 0, 63, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14625, 833, 1, 1, 1, 1, 1, 0, 0, 64, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14626, 833, 1, 1, 1, 1, 1, 0, 0, 65, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14627, 833, 1, 1, 1, 1, 1, 0, 0, 66, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14628, 833, 1, 1, 1, 1, 1, 0, 0, 67, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14629, 833, 1, 1, 1, 1, 1, 0, 0, 68, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14630, 833, 1, 1, 1, 1, 1, 0, 0, 69, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14631, 833, 1, 1, 1, 1, 1, 0, 0, 70, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14632, 833, 1, 1, 1, 1, 1, 0, 0, 71, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14633, 833, 1, 1, 1, 1, 1, 0, 0, 72, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14634, 833, 1, 1, 1, 1, 1, 0, 0, 73, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14635, 833, 1, 1, 1, 1, 1, 0, 0, 74, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14636, 833, 1, 1, 1, 1, 1, 0, 0, 75, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14637, 833, 1, 1, 1, 1, 1, 0, 0, 76, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14638, 833, 1, 1, 1, 1, 1, 0, 0, 77, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14639, 833, 1, 1, 1, 1, 1, 0, 0, 78, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14640, 833, 1, 1, 1, 1, 1, 0, 0, 79, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14641, 833, 1, 1, 1, 1, 1, 0, 0, 80, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14642, 833, 1, 1, 1, 1, 1, 0, 0, 81, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14643, 833, 1, 1, 1, 1, 1, 0, 0, 82, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14644, 833, 1, 1, 1, 1, 1, 0, 0, 83, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14645, 833, 1, 1, 1, 1, 1, 0, 0, 84, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14646, 833, 1, 1, 1, 1, 1, 0, 0, 85, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14647, 833, 1, 1, 1, 1, 1, 0, 0, 86, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14648, 833, 1, 1, 1, 1, 1, 0, 0, 87, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14649, 833, 1, 1, 1, 1, 1, 0, 0, 88, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14650, 833, 1, 1, 1, 1, 1, 0, 0, 89, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14651, 833, 1, 1, 1, 1, 1, 0, 0, 90, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14652, 833, 1, 1, 1, 1, 1, 0, 0, 91, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14653, 833, 1, 1, 1, 1, 1, 0, 0, 92, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14654, 833, 1, 1, 1, 1, 1, 0, 0, 93, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14655, 833, 1, 1, 1, 1, 1, 0, 0, 94, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14656, 833, 1, 1, 1, 1, 1, 0, 0, 95, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14657, 833, 1, 1, 1, 1, 1, 0, 0, 96, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14658, 833, 1, 1, 1, 1, 1, 0, 0, 97, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14659, 833, 1, 1, 1, 1, 1, 0, 0, 98, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14660, 833, 1, 1, 1, 1, 1, 0, 0, 99, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14661, 833, 1, 1, 1, 1, 1, 0, 0, 100, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14662, 833, 1, 1, 1, 1, 1, 0, 0, 101, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14663, 833, 1, 1, 1, 1, 1, 0, 0, 102, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14664, 833, 1, 1, 1, 1, 1, 0, 0, 103, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14665, 833, 1, 1, 1, 1, 1, 0, 0, 104, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14666, 833, 1, 1, 1, 1, 1, 0, 0, 105, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14667, 833, 1, 1, 1, 1, 1, 0, 0, 106, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14668, 833, 1, 1, 1, 1, 1, 0, 0, 107, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14669, 833, 1, 1, 1, 1, 1, 0, 0, 108, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14670, 833, 1, 1, 1, 1, 1, 0, 0, 109, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14671, 833, 1, 1, 1, 1, 1, 0, 0, 110, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14672, 833, 1, 1, 1, 1, 1, 0, 0, 111, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14673, 833, 1, 1, 1, 1, 1, 0, 0, 112, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14674, 833, 1, 1, 1, 1, 1, 0, 0, 113, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14675, 833, 1, 1, 1, 1, 1, 0, 0, 114, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14676, 833, 1, 1, 1, 1, 1, 0, 0, 115, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14677, 833, 1, 1, 1, 1, 1, 0, 0, 116, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14678, 833, 1, 1, 1, 1, 1, 0, 0, 117, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14679, 833, 1, 1, 1, 1, 1, 0, 0, 118, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14680, 833, 1, 1, 1, 1, 1, 0, 0, 119, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14681, 833, 1, 1, 1, 1, 1, 0, 0, 120, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14682, 833, 1, 1, 1, 1, 1, 0, 0, 121, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14683, 833, 1, 1, 1, 1, 1, 0, 0, 122, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14684, 833, 1, 1, 1, 1, 1, 0, 0, 123, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14685, 833, 1, 1, 1, 1, 1, 0, 0, 124, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14686, 833, 1, 1, 1, 1, 1, 0, 0, 125, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14687, 833, 1, 1, 1, 1, 1, 0, 0, 126, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14688, 833, 1, 1, 1, 1, 1, 0, 0, 127, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14689, 833, 1, 1, 1, 1, 1, 0, 0, 128, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14690, 833, 1, 1, 1, 1, 1, 0, 0, 129, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14691, 833, 1, 1, 1, 1, 1, 0, 0, 130, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14692, 833, 1, 1, 1, 1, 1, 0, 0, 131, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14693, 833, 1, 1, 1, 1, 1, 0, 0, 132, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14694, 833, 1, 1, 1, 1, 1, 0, 0, 133, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14695, 833, 1, 1, 1, 1, 1, 0, 0, 134, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14696, 833, 1, 1, 1, 1, 1, 0, 0, 135, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14697, 833, 1, 1, 1, 1, 1, 0, 0, 136, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14698, 833, 1, 1, 1, 1, 1, 0, 0, 137, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14699, 833, 1, 1, 1, 1, 1, 0, 0, 138, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14700, 833, 1, 1, 1, 1, 1, 0, 0, 139, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14701, 833, 1, 1, 1, 1, 1, 0, 0, 140, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14702, 833, 1, 1, 1, 1, 1, 0, 0, 141, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14703, 833, 1, 1, 1, 1, 1, 0, 0, 142, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14704, 833, 1, 1, 1, 1, 1, 0, 0, 143, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14705, 833, 1, 1, 1, 1, 1, 0, 0, 144, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14706, 833, 1, 1, 1, 1, 1, 0, 0, 145, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14707, 833, 1, 1, 1, 1, 1, 0, 0, 146, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14708, 833, 1, 1, 1, 1, 1, 0, 0, 147, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14709, 833, 1, 1, 1, 1, 1, 0, 0, 148, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14710, 833, 1, 1, 1, 1, 1, 0, 0, 149, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14711, 833, 1, 1, 1, 1, 1, 0, 0, 150, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14712, 833, 1, 1, 1, 1, 1, 0, 0, 151, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14713, 833, 1, 1, 1, 1, 1, 0, 0, 152, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14714, 833, 1, 1, 1, 1, 1, 0, 0, 153, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14715, 833, 1, 1, 1, 1, 1, 0, 0, 154, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14716, 833, 1, 1, 1, 1, 1, 0, 0, 155, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14717, 833, 1, 1, 1, 1, 1, 0, 0, 156, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14718, 833, 1, 1, 1, 1, 1, 0, 0, 157, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14719, 833, 1, 1, 1, 1, 1, 0, 0, 158, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14720, 833, 1, 1, 1, 1, 1, 0, 0, 159, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14721, 833, 1, 1, 1, 1, 1, 0, 0, 160, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14722, 833, 1, 1, 1, 1, 1, 0, 0, 161, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14723, 833, 1, 1, 1, 1, 1, 0, 0, 162, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14724, 833, 1, 1, 1, 1, 1, 0, 0, 163, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14725, 833, 1, 1, 1, 1, 1, 0, 0, 164, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14726, 833, 1, 1, 1, 1, 1, 0, 0, 165, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14727, 833, 1, 1, 1, 1, 1, 0, 0, 166, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14728, 833, 1, 1, 1, 1, 1, 0, 0, 167, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14729, 833, 1, 1, 1, 1, 1, 0, 0, 168, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14730, 833, 1, 1, 1, 1, 1, 0, 0, 169, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14731, 833, 1, 1, 1, 1, 1, 0, 0, 170, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14732, 833, 1, 1, 1, 1, 1, 0, 0, 171, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14733, 833, 1, 1, 1, 1, 1, 0, 0, 172, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14734, 833, 1, 1, 1, 1, 1, 0, 0, 173, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14735, 833, 1, 1, 1, 1, 1, 0, 0, 174, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14736, 833, 1, 1, 1, 1, 1, 0, 0, 175, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14737, 833, 1, 1, 1, 1, 1, 0, 0, 176, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14738, 833, 1, 1, 1, 1, 1, 0, 0, 177, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14739, 833, 1, 1, 1, 1, 1, 0, 0, 178, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14740, 833, 1, 1, 1, 1, 1, 0, 0, 179, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14741, 833, 1, 1, 1, 1, 1, 0, 0, 180, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14742, 833, 1, 1, 1, 1, 1, 0, 0, 181, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14743, 833, 1, 1, 1, 1, 1, 0, 0, 182, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14744, 833, 1, 1, 1, 1, 1, 0, 0, 183, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14745, 833, 1, 1, 1, 1, 1, 0, 0, 184, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14746, 833, 1, 1, 1, 1, 1, 0, 0, 185, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14747, 833, 1, 1, 1, 1, 1, 0, 0, 186, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14748, 833, 1, 1, 1, 1, 1, 0, 0, 187, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14749, 833, 1, 1, 1, 1, 1, 0, 0, 188, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14750, 833, 1, 1, 1, 1, 1, 0, 0, 189, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14751, 833, 1, 1, 1, 1, 1, 0, 0, 190, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14752, 833, 1, 1, 1, 1, 1, 0, 0, 191, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14753, 833, 1, 1, 1, 1, 1, 0, 0, 192, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14754, 833, 1, 1, 1, 1, 1, 0, 0, 193, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14755, 833, 1, 1, 1, 1, 1, 0, 0, 194, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14756, 833, 1, 1, 1, 1, 1, 0, 0, 195, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14757, 833, 1, 1, 1, 1, 1, 0, 0, 196, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14758, 834, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14759, 834, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14760, 835, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14761, 835, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14762, 835, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14763, 835, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14764, 835, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14765, 835, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14766, 835, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14767, 835, 1, 1, 1, 1, 1, 0, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14768, 835, 1, 1, 1, 1, 1, 0, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14769, 835, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14770, 835, 1, 1, 1, 0, 0, 0, 0, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14771, 835, 1, 1, 1, 0, 0, 0, 0, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14772, 835, 1, 1, 1, 1, 1, 0, 0, 12, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14773, 835, 1, 1, 1, 0, 0, 0, 0, 13, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14774, 835, 1, 1, 1, 1, 1, 0, 0, 14, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14775, 835, 1, 1, 1, 0, 0, 0, 0, 15, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14776, 835, 1, 1, 1, 1, 1, 0, 0, 16, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14777, 835, 1, 1, 1, 1, 1, 0, 0, 17, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14778, 835, 1, 1, 1, 1, 1, 0, 0, 18, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14779, 835, 1, 1, 1, 0, 0, 0, 0, 19, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14780, 835, 1, 1, 1, 1, 1, 0, 0, 20, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14781, 835, 1, 1, 1, 0, 0, 0, 0, 21, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14782, 835, 1, 1, 1, 0, 0, 0, 0, 22, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14783, 835, 1, 1, 1, 0, 0, 0, 0, 23, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14784, 835, 1, 1, 1, 0, 0, 0, 0, 24, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14785, 835, 1, 1, 1, 0, 0, 0, 0, 25, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14786, 835, 1, 1, 1, 1, 1, 0, 0, 26, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14787, 835, 1, 1, 1, 1, 1, 0, 0, 27, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14788, 835, 1, 1, 1, 1, 1, 0, 0, 28, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14789, 835, 1, 1, 1, 1, 1, 0, 0, 29, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14790, 835, 1, 1, 1, 1, 1, 0, 0, 30, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14791, 835, 1, 1, 1, 1, 1, 0, 0, 31, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14792, 835, 1, 1, 1, 1, 1, 0, 0, 32, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14793, 835, 1, 1, 1, 1, 1, 0, 0, 33, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14794, 835, 1, 1, 1, 1, 1, 0, 0, 34, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14795, 835, 1, 1, 1, 1, 1, 0, 0, 35, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14796, 835, 1, 1, 1, 1, 1, 0, 0, 36, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14797, 835, 1, 1, 1, 0, 0, 0, 0, 37, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14798, 835, 1, 1, 1, 1, 1, 0, 0, 38, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14799, 835, 1, 1, 1, 1, 1, 0, 0, 39, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14800, 836, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14801, 836, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14802, 836, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14803, 837, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14804, 837, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14805, 837, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14806, 837, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14842, 840, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14843, 840, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14844, 840, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14845, 840, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14846, 840, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14847, 840, 1, 1, 1, 1, 1, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14848, 840, 1, 1, 1, 1, 1, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14849, 840, 1, 1, 1, 0, 0, 0, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14850, 840, 1, 1, 1, 1, 1, 0, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14851, 841, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14852, 841, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14853, 841, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14854, 841, 1, 1, 1, 0, 0, 44999930, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14855, 841, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14856, 841, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14857, 841, 1, 1, 1, 0, 0, 9000006, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14858, 841, 1, 1, 1, 0, 0, 3000002, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14859, 841, 1, 1, 1, 0, 0, 0, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14860, 841, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14861, 841, 1, 1, 1, 0, 0, 20000000, 0, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14862, 841, 1, 1, 1, 0, 0, 1700000, 0, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14863, 841, 1, 1, 1, 0, 0, 0, 1700000, 12, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14864, 841, 1, 1, 1, 0, 0, 0, 0, 13, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14865, 841, 1, 1, 1, 0, 0, 20000000, 0, 14, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14866, 841, 1, 1, 1, 0, 0, 0, 0, 15, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14867, 841, 1, 1, 1, 0, 0, 0, 0, 16, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14868, 841, 1, 1, 1, 0, 0, 11999988, 0, 17, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14869, 841, 1, 1, 1, 0, 0, 0, 0, 18, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14870, 841, 1, 1, 1, 0, 0, 0, 0, 19, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14871, 841, 1, 1, 1, 0, 0, 0, 0, 20, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14872, 841, 1, 1, 1, 0, 0, 0, 0, 21, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14873, 841, 1, 1, 1, 0, 0, 0, 0, 22, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14874, 841, 1, 1, 1, 0, 0, 0, 0, 23, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14875, 841, 1, 1, 1, 0, 0, 0, 0, 24, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14876, 841, 1, 1, 1, 0, 0, 0, 0, 25, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14877, 841, 1, 1, 1, 0, 0, 0, 0, 26, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14878, 841, 1, 1, 1, 0, 0, 0, 0, 27, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14879, 841, 1, 1, 1, 0, 0, 0, 0, 28, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14880, 841, 1, 1, 1, 0, 0, 0, 0, 29, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14881, 841, 1, 1, 1, 0, 0, 0, 0, 30, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14882, 841, 1, 1, 1, 0, 0, 0, 0, 31, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14883, 841, 1, 1, 1, 0, 0, 0, 0, 32, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14884, 841, 1, 1, 1, 0, 0, 0, 0, 33, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14885, 841, 1, 1, 1, 0, 0, 0, 0, 34, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14886, 841, 1, 1, 1, 0, 0, 0, 0, 35, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14887, 841, 1, 1, 1, 0, 0, 0, 0, 36, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14888, 841, 1, 1, 1, 0, 0, 0, 0, 37, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14889, 841, 1, 1, 1, 0, 0, 0, 0, 38, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14890, 841, 1, 1, 1, 0, 0, 0, 0, 39, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14891, 841, 1, 1, 1, 0, 0, 0, 0, 40, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14892, 841, 1, 1, 1, 0, 0, 0, 0, 41, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14893, 841, 1, 1, 1, 0, 0, 0, 0, 42, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14894, 842, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14895, 842, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14896, 842, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14897, 842, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14898, 842, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14899, 842, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14900, 842, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14901, 842, 1, 1, 1, 1, 1, 0, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14902, 842, 1, 1, 1, 1, 1, 0, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14903, 842, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14904, 842, 1, 1, 1, 0, 0, 0, 0, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14905, 842, 1, 1, 1, 0, 0, 0, 0, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14906, 842, 1, 1, 1, 1, 1, 0, 0, 12, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14907, 842, 1, 1, 1, 0, 0, 0, 0, 13, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14908, 842, 1, 1, 1, 1, 1, 0, 0, 14, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14909, 842, 1, 1, 1, 0, 0, 0, 0, 15, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14910, 842, 1, 1, 1, 1, 1, 0, 0, 16, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14911, 842, 1, 1, 1, 1, 1, 0, 0, 17, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14912, 842, 1, 1, 1, 1, 1, 0, 0, 18, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14913, 842, 1, 1, 1, 0, 0, 0, 0, 19, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14914, 842, 1, 1, 1, 1, 1, 0, 0, 20, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14915, 842, 1, 1, 1, 0, 0, 0, 0, 21, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14916, 842, 1, 1, 1, 0, 0, 0, 0, 22, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14917, 842, 1, 1, 1, 0, 0, 0, 0, 23, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14918, 842, 1, 1, 1, 0, 0, 0, 0, 24, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14919, 842, 1, 1, 1, 0, 0, 0, 0, 25, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14920, 842, 1, 1, 1, 1, 1, 0, 0, 26, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14921, 842, 1, 1, 1, 1, 1, 0, 0, 27, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14922, 842, 1, 1, 1, 1, 1, 0, 0, 28, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14923, 842, 1, 1, 1, 1, 1, 0, 0, 29, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14924, 842, 1, 1, 1, 1, 1, 0, 0, 30, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14925, 842, 1, 1, 1, 1, 1, 0, 0, 31, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14926, 842, 1, 1, 1, 1, 1, 0, 0, 32, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14927, 842, 1, 1, 1, 1, 1, 0, 0, 33, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14928, 842, 1, 1, 1, 1, 1, 0, 0, 34, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14929, 842, 1, 1, 1, 1, 1, 0, 0, 35, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14930, 842, 1, 1, 1, 1, 1, 0, 0, 36, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14931, 842, 1, 1, 1, 0, 0, 0, 0, 37, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14932, 842, 1, 1, 1, 1, 1, 0, 0, 38, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14933, 842, 1, 1, 1, 1, 1, 0, 0, 39, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14934, 843, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14935, 843, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14936, 843, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14937, 843, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14938, 843, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14939, 843, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14940, 843, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14941, 843, 1, 1, 1, 0, 0, 0, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14942, 843, 1, 1, 1, 0, 0, 0, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14943, 843, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14944, 843, 1, 1, 1, 0, 0, 0, 0, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14945, 843, 1, 1, 1, 0, 0, 0, 0, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14946, 843, 1, 1, 1, 0, 0, 0, 0, 12, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14947, 843, 1, 1, 1, 0, 0, 0, 0, 13, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14948, 843, 1, 1, 1, 0, 0, 0, 0, 14, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14949, 843, 1, 1, 1, 0, 0, 0, 0, 15, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14950, 843, 1, 1, 1, 0, 0, 0, 0, 16, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14951, 844, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14952, 844, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14953, 844, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14954, 844, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14955, 844, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14956, 844, 1, 1, 1, 1, 1, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14957, 844, 1, 1, 1, 1, 1, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14958, 844, 1, 1, 1, 1, 1, 0, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14959, 844, 1, 1, 1, 1, 1, 0, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14960, 844, 1, 1, 1, 1, 1, 0, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14961, 844, 1, 1, 1, 1, 1, 0, 0, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14962, 844, 1, 1, 1, 1, 1, 0, 0, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14963, 844, 1, 1, 1, 1, 1, 0, 0, 12, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14964, 844, 1, 1, 1, 1, 1, 0, 0, 13, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14965, 844, 1, 1, 1, 1, 1, 0, 0, 14, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14966, 844, 1, 1, 1, 1, 1, 0, 0, 15, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14967, 844, 1, 1, 1, 1, 1, 0, 0, 16, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14968, 844, 1, 1, 1, 1, 1, 0, 0, 17, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14969, 844, 1, 1, 1, 1, 1, 0, 0, 18, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14970, 844, 1, 1, 1, 1, 1, 0, 0, 19, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14971, 844, 1, 1, 1, 1, 1, 0, 0, 20, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14972, 844, 1, 1, 1, 1, 1, 0, 0, 21, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14973, 844, 1, 1, 1, 1, 1, 0, 0, 22, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14974, 844, 1, 1, 1, 1, 1, 0, 0, 23, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14975, 844, 1, 1, 1, 1, 1, 0, 0, 24, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14976, 844, 1, 1, 1, 1, 1, 0, 0, 25, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14977, 844, 1, 1, 1, 1, 1, 0, 0, 26, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14978, 844, 1, 1, 1, 1, 1, 0, 0, 27, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14979, 844, 1, 1, 1, 1, 1, 0, 0, 28, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14980, 844, 1, 1, 1, 1, 1, 0, 0, 29, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14981, 844, 1, 1, 1, 1, 1, 0, 0, 30, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14982, 844, 1, 1, 1, 1, 1, 0, 0, 31, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14983, 844, 1, 1, 1, 1, 1, 0, 0, 32, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14984, 844, 1, 1, 1, 1, 1, 0, 0, 33, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14985, 844, 1, 1, 1, 1, 1, 0, 0, 34, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14986, 844, 1, 1, 1, 1, 1, 0, 0, 35, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14987, 844, 1, 1, 1, 1, 1, 0, 0, 36, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14988, 844, 1, 1, 1, 1, 1, 0, 0, 37, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14989, 844, 1, 1, 1, 1, 1, 0, 0, 38, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14990, 844, 1, 1, 1, 1, 1, 0, 0, 39, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14991, 844, 1, 1, 1, 1, 1, 0, 0, 40, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14992, 844, 1, 1, 1, 1, 1, 0, 0, 41, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14993, 844, 1, 1, 1, 1, 1, 0, 0, 42, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14994, 844, 1, 1, 1, 1, 1, 0, 0, 43, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14995, 844, 1, 1, 1, 1, 1, 0, 0, 44, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14996, 844, 1, 1, 1, 1, 1, 0, 0, 45, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14997, 844, 1, 1, 1, 1, 1, 0, 0, 46, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14998, 844, 1, 1, 1, 1, 1, 0, 0, 47, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14999, 844, 1, 1, 1, 1, 1, 0, 0, 48, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15000, 844, 1, 1, 1, 1, 1, 0, 0, 49, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15001, 844, 1, 1, 1, 1, 1, 0, 0, 50, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15002, 844, 1, 1, 1, 1, 1, 0, 0, 51, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15003, 844, 1, 1, 1, 1, 1, 0, 0, 52, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15004, 844, 1, 1, 1, 1, 1, 0, 0, 53, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15005, 844, 1, 1, 1, 1, 1, 0, 0, 54, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15006, 844, 1, 1, 1, 1, 1, 0, 0, 55, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15007, 844, 1, 1, 1, 1, 1, 0, 0, 56, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15008, 844, 1, 1, 1, 1, 1, 0, 0, 57, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15009, 844, 1, 1, 1, 1, 1, 0, 0, 58, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15010, 844, 1, 1, 1, 1, 1, 0, 0, 59, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 15337, 407, 1, 1, 1, 0, 0, 1, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 15338, 407, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 15339, 407, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 15337, 407, 1, 1, 1, 0, 0, 1, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 15338, 407, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 15339, 407, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18085, 863, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18086, 863, 1, 1, 1, 1, 1, 0, 0, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18087, 864, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18088, 864, 1, 1, 1, 1, 1, 200, 74989, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18089, 864, 1, 1, 1, 1, 1, 200, 74989, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18090, 864, 1, 1, 1, 1, 1, 0, 0, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18091, 864, 1, 1, 1, 1, 1, 0, 0, 4, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18092, 864, 1, 1, 1, 1, 1, 200, 74989, 5, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18093, 864, 1, 1, 1, 1, 1, 200, 74989, 6, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18094, 864, 1, 1, 1, 1, 1, 200, 74989, 7, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18095, 864, 1, 1, 1, 1, 1, 200, 56242, 8, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18096, 864, 1, 1, 1, 1, 1, 200, 56242, 9, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18097, 864, 1, 1, 1, 1, 1, 200, 56242, 10, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18098, 864, 1, 1, 1, 1, 1, 200, 37494, 11, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18099, 864, 1, 1, 1, 1, 1, 200, 37494, 12, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18100, 864, 1, 1, 1, 1, 1, 200, 37494, 13, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18101, 864, 1, 1, 1, 1, 1, 200, 11248, 14, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18102, 864, 1, 1, 1, 1, 1, 200, 11248, 15, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18103, 864, 1, 1, 1, 1, 1, 200, 11248, 16, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18104, 864, 1, 1, 1, 1, 1, 200, 18747, 17, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18105, 864, 1, 1, 1, 1, 1, 74990, 0, 18, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18119, 866, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18120, 866, 1, 1, 1, 1, 1, 200, 749888, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18121, 866, 1, 1, 1, 1, 1, 200, 749888, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18122, 866, 1, 1, 1, 1, 1, 200, 749888, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18123, 866, 1, 1, 1, 1, 1, 200, 749888, 4, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18124, 866, 1, 1, 1, 1, 1, 200, 749888, 5, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18125, 866, 1, 1, 1, 1, 1, 200, 749888, 6, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18126, 866, 1, 1, 1, 1, 1, 200, 374944, 7, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18127, 866, 1, 1, 1, 1, 1, 200, 374944, 8, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18128, 866, 1, 1, 1, 1, 1, 200, 374944, 9, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18129, 866, 1, 1, 1, 1, 1, 200, 374944, 10, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18130, 866, 1, 1, 1, 1, 1, 200, 374944, 11, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18131, 866, 1, 1, 1, 1, 1, 200, 374944, 12, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18132, 867, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18133, 867, 1, 1, 1, 1, 1, 22497, 0, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18134, 867, 1, 1, 1, 1, 1, 22497, 0, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18135, 867, 1, 1, 1, 1, 1, 22497, 0, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18136, 867, 1, 1, 1, 1, 1, 22497, 0, 4, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18137, 867, 1, 1, 1, 1, 1, 22497, 0, 5, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18138, 867, 1, 1, 1, 1, 1, 22497, 74989, 6, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18139, 867, 1, 1, 1, 1, 1, 22497, 0, 7, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18140, 867, 1, 1, 1, 1, 1, 22497, 0, 8, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18141, 867, 1, 1, 1, 1, 1, 22497, 0, 9, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18142, 867, 1, 1, 1, 1, 1, 22497, 0, 10, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18143, 868, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18144, 868, 1, 1, 1, 0, 0, 26075, 0, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18145, 869, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18146, 869, 1, 1, 1, 1, 1, 0, 150214, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18147, 869, 1, 1, 1, 1, 1, 0, 150214, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18148, 869, 1, 1, 1, 1, 1, 0, 0, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18149, 869, 1, 1, 1, 1, 1, 0, 150214, 4, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18150, 869, 1, 1, 1, 1, 1, 0, 150214, 5, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18151, 869, 1, 1, 1, 1, 1, 0, 150214, 6, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18152, 869, 1, 1, 1, 1, 1, 0, 150214, 7, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18153, 869, 1, 1, 1, 1, 1, 0, 150214, 8, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18154, 869, 1, 1, 1, 1, 1, 0, 150214, 9, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18155, 869, 1, 1, 1, 1, 1, 0, 150214, 10, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18156, 870, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18157, 870, 1, 1, 1, 1, 1, 200, 374944, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18158, 870, 1, 1, 1, 1, 1, 200, 374944, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18159, 871, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18160, 871, 1, 1, 1, 0, 0, 2400, 2000000, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18161, 871, 1, 1, 1, 0, 0, 375, 3900, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18162, 871, 1, 1, 1, 0, 0, 1, 3900, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18163, 871, 1, 1, 1, 0, 0, 0, 0, 4, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18164, 871, 1, 1, 1, 0, 0, 1, 2500, 5, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18165, 871, 1, 1, 1, 0, 0, 1, 2500, 6, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18166, 871, 1, 1, 1, 0, 0, 1, 2500, 7, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18167, 871, 1, 1, 1, 0, 0, 1, 2500, 8, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18168, 872, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18169, 872, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18170, 872, 1, 1, 1, 0, 0, 0, 0, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18171, 872, 1, 1, 1, 0, 0, 0, 0, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18172, 872, 1, 1, 1, 0, 0, 0, 0, 4, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18173, 872, 1, 1, 1, 0, 0, 0, 0, 5, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18174, 872, 1, 1, 1, 0, 0, 0, 0, 6, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18175, 872, 1, 1, 1, 0, 0, 0, 0, 7, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18176, 872, 1, 1, 1, 0, 0, 0, 0, 8, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18177, 872, 1, 1, 1, 0, 0, 0, 0, 9, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18178, 872, 1, 1, 1, 0, 0, 0, 0, 10, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18179, 872, 1, 1, 1, 0, 0, 0, 0, 11, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18180, 872, 1, 1, 1, 0, 0, 0, 0, 12, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18181, 872, 1, 1, 1, 0, 0, 0, 0, 13, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18182, 872, 1, 1, 1, 0, 0, 0, 0, 14, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18183, 872, 1, 1, 1, 0, 0, 0, 0, 15, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18184, 872, 1, 1, 1, 0, 0, 0, 0, 16, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18185, 872, 1, 1, 1, 0, 0, 0, 0, 17, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18186, 872, 1, 1, 1, 0, 0, 0, 0, 18, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18187, 872, 1, 1, 1, 0, 0, 0, 0, 19, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18188, 872, 1, 1, 1, 0, 0, 0, 0, 20, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18189, 872, 1, 1, 1, 0, 0, 0, 0, 21, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18190, 872, 1, 1, 1, 0, 0, 0, 0, 22, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18191, 872, 1, 1, 1, 0, 0, 0, 0, 23, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18192, 872, 1, 1, 1, 0, 0, 0, 0, 24, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18193, 872, 1, 1, 1, 0, 0, 0, 0, 25, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18194, 872, 1, 1, 1, 0, 0, 0, 0, 26, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18195, 872, 1, 1, 1, 0, 0, 0, 0, 27, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18196, 872, 1, 1, 1, 0, 0, 0, 0, 28, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18205, 881, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18206, 881, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18207, 881, 1, 1, 1, 0, 0, 0, 0, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18208, 881, 1, 1, 1, 0, 0, 0, 300000, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18209, 881, 1, 1, 1, 0, 0, 0, 0, 4, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18210, 881, 1, 1, 1, 0, 0, 0, 300000, 5, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18211, 881, 1, 1, 1, 0, 0, 0, 300000, 6, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18212, 881, 1, 1, 1, 0, 0, 0, 0, 7, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18213, 881, 1, 1, 1, 0, 0, 0, 300000, 8, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18214, 881, 1, 1, 1, 0, 0, 0, 300000, 9, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18215, 881, 1, 1, 1, 0, 0, 0, 0, 10, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18216, 881, 1, 1, 1, 0, 0, 0, 100000, 11, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18217, 881, 1, 1, 1, 0, 0, 0, 100000, 12, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18218, 882, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18219, 882, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18220, 882, 1, 1, 1, 0, 0, 135001, 300000, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18221, 882, 1, 1, 1, 0, 0, 20001, 135000, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18222, 882, 1, 1, 1, 0, 0, 12001, 20000, 4, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18223, 882, 1, 1, 1, 0, 0, 2751, 12000, 5, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18224, 882, 1, 1, 1, 0, 0, 0, 2750, 6, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18225, 882, 1, 1, 1, 0, 0, 300000, 1000000, 7, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18226, 882, 1, 1, 1, 0, 0, 0, 0, 8, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18227, 882, 1, 1, 1, 0, 0, 0, 300000, 9, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18228, 882, 1, 1, 1, 0, 0, 0, 300000, 10, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18229, 882, 1, 1, 1, 0, 0, 0, 0, 11, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18230, 882, 1, 1, 1, 0, 0, 0, 300000, 12, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18231, 882, 1, 1, 1, 0, 0, 0, 300000, 13, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18232, 882, 1, 1, 1, 0, 0, 0, 0, 14, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18233, 882, 1, 1, 1, 0, 0, 0, 300000, 15, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18234, 882, 1, 1, 1, 0, 0, 0, 300000, 16, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18235, 883, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18236, 883, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18237, 883, 1, 1, 1, 0, 0, 0, 0, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18238, 883, 1, 1, 1, 0, 0, 0, 0, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18239, 883, 1, 1, 1, 0, 0, 0, 0, 4, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18240, 883, 1, 1, 1, 0, 0, 0, 0, 5, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18241, 884, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18242, 884, 1, 1, 1, 1, 1, 0, 0, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18243, 884, 1, 1, 1, 1, 1, 0, 0, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18244, 884, 1, 1, 1, 1, 1, 0, 0, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18245, 884, 1, 1, 1, 1, 1, 0, 0, 4, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18246, 885, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18247, 885, 1, 1, 1, 1, 1, 0, 0, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18248, 885, 1, 1, 1, 0, 0, 0, 0, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18249, 885, 1, 1, 1, 0, 0, 0, 0, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18250, 885, 1, 1, 1, 0, 0, 0, 0, 4, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18251, 885, 1, 1, 1, 0, 0, 0, 0, 5, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18252, 885, 1, 1, 1, 1, 1, 0, 0, 6, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18253, 885, 1, 1, 1, 0, 0, 0, 0, 7, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18254, 885, 1, 1, 1, 0, 0, 0, 0, 8, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18255, 885, 1, 1, 1, 0, 0, 0, 0, 9, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18256, 885, 1, 1, 1, 0, 0, 0, 0, 10, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18257, 885, 1, 1, 1, 1, 1, 0, 0, 11, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18258, 885, 1, 1, 1, 0, 0, 0, 0, 12, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18259, 885, 1, 1, 1, 0, 0, 0, 0, 13, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18260, 885, 1, 1, 1, 0, 0, 0, 0, 14, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18261, 885, 1, 1, 1, 0, 0, 0, 0, 15, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18262, 885, 1, 1, 1, 0, 0, 0, 0, 16, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18263, 885, 1, 1, 1, 1, 1, 0, 0, 17, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18264, 885, 1, 1, 1, 0, 0, 0, 0, 18, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18265, 885, 1, 1, 1, 0, 0, 0, 0, 19, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18266, 885, 1, 1, 1, 0, 0, 0, 0, 20, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18267, 885, 1, 1, 1, 0, 0, 0, 0, 21, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18268, 885, 1, 1, 1, 1, 1, 0, 0, 22, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18269, 885, 1, 1, 1, 0, 0, 0, 0, 23, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18270, 885, 1, 1, 1, 0, 0, 0, 0, 24, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18271, 885, 1, 1, 1, 0, 0, 0, 0, 25, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18272, 885, 1, 1, 1, 0, 0, 0, 0, 26, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18274, 887, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18275, 887, 1, 1, 1, 1, 1, 0, 0, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18276, 888, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18277, 888, 1, 1, 1, 1, 1, 37494, 374944, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18278, 888, 1, 1, 1, 0, 0, 37494, 187472, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18279, 888, 1, 1, 1, 0, 0, 37494, 187472, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19006, 893, 1, 1, 1, 0, 0, 1, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19007, 893, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19008, 893, 1, 1, 1, 0, 0, 749999, 0, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19009, 893, 1, 1, 1, 0, 0, 749999, 0, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19010, 893, 1, 1, 1, 0, 0, 0, 0, 4, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19011, 893, 1, 1, 1, 1, 1, 0, 0, 5, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19012, 893, 1, 1, 1, 0, 0, 0, 0, 6, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19013, 893, 1, 1, 1, 0, 0, 0, 1250001, 7, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19014, 893, 1, 1, 1, 0, 0, 0, 0, 8, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19015, 893, 1, 1, 1, 1, 1, 0, 0, 9, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19016, 893, 1, 1, 1, 0, 0, 0, 350000, 10, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19017, 893, 1, 1, 1, 0, 0, 0, 0, 11, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19018, 893, 1, 1, 1, 0, 0, 1000000, 0, 12, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19006, 893, 1, 1, 1, 0, 0, 1, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19007, 893, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19008, 893, 1, 1, 1, 0, 0, 749999, 0, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19009, 893, 1, 1, 1, 0, 0, 749999, 0, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19010, 893, 1, 1, 1, 0, 0, 0, 0, 4, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19011, 893, 1, 1, 1, 1, 1, 0, 0, 5, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19012, 893, 1, 1, 1, 0, 0, 0, 0, 6, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19013, 893, 1, 1, 1, 0, 0, 0, 1250001, 7, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19014, 893, 1, 1, 1, 0, 0, 0, 0, 8, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19015, 893, 1, 1, 1, 1, 1, 0, 0, 9, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19016, 893, 1, 1, 1, 0, 0, 0, 350000, 10, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19017, 893, 1, 1, 1, 0, 0, 0, 0, 11, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19018, 893, 1, 1, 1, 0, 0, 1000000, 0, 12, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19006, 893, 1, 1, 1, 0, 0, 1, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19007, 893, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19008, 893, 1, 1, 1, 0, 0, 749999, 0, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19009, 893, 1, 1, 1, 0, 0, 749999, 0, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19010, 893, 1, 1, 1, 0, 0, 0, 0, 4, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19011, 893, 1, 1, 1, 1, 1, 0, 0, 5, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19012, 893, 1, 1, 1, 0, 0, 0, 0, 6, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19013, 893, 1, 1, 1, 0, 0, 0, 1250001, 7, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19014, 893, 1, 1, 1, 0, 0, 0, 0, 8, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19015, 893, 1, 1, 1, 1, 1, 0, 0, 9, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19016, 893, 1, 1, 1, 0, 0, 0, 350000, 10, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19017, 893, 1, 1, 1, 0, 0, 0, 0, 11, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19018, 893, 1, 1, 1, 0, 0, 1000000, 0, 12, NULL, NULL);
+-- Daten für Tabelle `gui_mb_group`
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('admin1', 20, '');
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('admin2_de', 20, '');
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('admin2_en', 20, '');
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('gui', 20, '');
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('gui1', 20, '');
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('wms_africa', 20, '');
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('wms_australia', 20, '');
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('wms_europe', 20, '');
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('wms_germany', 20, '');
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('wms_north_america', 20, '');
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('wms_worldwide', 20, '');
+-- Daten für Tabelle `gui_mb_user`
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('admin1', 1, 'owner');
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('admin2_de', 1, 'owner');
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('admin2_en', 1, 'owner');
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('gui', 1, 'owner');
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('gui1', 1, 'owner');
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('wms_africa', 1, 'owner');
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('wms_australia', 1, 'owner');
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('wms_europe', 1, 'owner');
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('wms_gdi_de', 1, 'owner');
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('wms_germany', 1, 'owner');
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('wms_north_america', 1, 'owner');
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('wms_worldwide', 1, 'owner');
+-- Daten für Tabelle `gui_treegde`
+INSERT INTO gui_treegde (fkey_gui_id, fkey_layer_id, id, lft, rgt, my_layer_title, layer, wms_id) VALUES ('admin1', '', 4, 1, 4, 'new', '', '');
+INSERT INTO gui_treegde (fkey_gui_id, fkey_layer_id, id, lft, rgt, my_layer_title, layer, wms_id) VALUES ('admin1', '', 5, 2, 3, 'new', '', '');
+INSERT INTO gui_treegde (fkey_gui_id, fkey_layer_id, id, lft, rgt, my_layer_title, layer, wms_id) VALUES ('gui', '', 11, 1, 4, 'Verkehr', '', '');
+INSERT INTO gui_treegde (fkey_gui_id, fkey_layer_id, id, lft, rgt, my_layer_title, layer, wms_id) VALUES ('gui', '15348', 12, 2, 3, 'Strassen', 'Strassen', '118');
+INSERT INTO gui_treegde (fkey_gui_id, fkey_layer_id, id, lft, rgt, my_layer_title, layer, wms_id) VALUES ('gui1', '', 11, 1, 4, 'new', '', '');
+INSERT INTO gui_treegde (fkey_gui_id, fkey_layer_id, id, lft, rgt, my_layer_title, layer, wms_id) VALUES ('gui1', '', 12, 2, 3, 'new', '', '');
+INSERT INTO gui_treegde (fkey_gui_id, fkey_layer_id, id, lft, rgt, my_layer_title, layer, wms_id) VALUES ('wms_africa', NULL, 98, 1, 4, 'new', '', NULL);
+INSERT INTO gui_treegde (fkey_gui_id, fkey_layer_id, id, lft, rgt, my_layer_title, layer, wms_id) VALUES ('wms_africa', NULL, 99, 2, 3, 'new', '', NULL);
+-- Daten für Tabelle `gui_wfs`
+INSERT INTO gui_wfs (fkey_gui_id, fkey_wfs_id) VALUES ('gui', 1);
+-- Daten für Tabelle `gui_wms`
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('gui', 407, 4, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('gui', 250, 0, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 0);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('gui', 640, 1, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 0);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('gui1', 407, 1, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_africa', 615, 0, 'PNG', 'mime', 'INIMAGE', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_africa', 776, 1, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_africa', 777, 2, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_africa', 778, 3, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_africa', 779, 4, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_australia', 706, 0, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_australia', 634, 1, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:26915', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_australia', 827, 2, 'png', '', 'inimage', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_europe', 739, 0, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_europe', 824, 1, 'image/png', '', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_europe', 828, 2, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:23030', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_europe', 829, 3, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:31297', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 717, 1, 'image/jpeg', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31492', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 329, 2, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:31467', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 624, 3, 'IMAGE/PNG', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 648, 4, 'IMAGE/PNG', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 336, 5, 'IMAGE/PNG', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 328, 6, 'IMAGE/PNG', 'application/vnd.ogc.gml', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:31466', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 486, 7, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31467', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 767, 8, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:25833', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 670, 9, 'IMAGE/PNG', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 671, 10, 'IMAGE/PNG', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 760, 11, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:25833', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 762, 12, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:25833', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 758, 13, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:25833', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 764, 14, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:25833', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 765, 15, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:25833', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 785, 16, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 786, 17, 'IMAGE/PNG', 'text/plain', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:31468', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 787, 18, 'IMAGE/PNG', '', 'application/vnd.ogc.se_xml', 'EPSG:31464', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 788, 19, 'IMAGE/PNG', 'text/plain', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:25833', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 789, 20, 'IMAGE/PNG', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 790, 21, 'IMAGE/PNG', '', 'application/vnd.ogc.se_xml', 'EPSG:31467', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 792, 22, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:31468', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 793, 23, 'IMAGE/PNG', '', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:31467', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 794, 24, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:25833', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 796, 25, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:31468', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 797, 26, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:25833', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 798, 27, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:25833', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 799, 28, 'IMAGE/PNG', 'text/plain', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:25833', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_north_america', 583, 0, 'image/gif', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_north_america', 584, 1, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_north_america', 655, 2, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_north_america', 614, 3, 'PNG', 'mime', 'INIMAGE', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_north_america', 616, 4, 'IMAGE/PNG', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:26920', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_north_america', 617, 5, 'IMAGE/PNG', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_north_america', 625, 6, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:42304', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_north_america', 645, 7, 'IMAGE/PNG', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_north_america', 525, 8, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_north_america', 800, 9, 'image/jpeg', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_north_america', 831, 10, 'image/png', 'text/plain', 'application/vnd.ogc.se_inimage', 'EPSG:26915', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_north_america', 832, 11, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_north_america', 833, 12, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_north_america', 834, 13, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:102257', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_north_america', 835, 14, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_north_america', 836, 15, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_north_america', 837, 16, 'image/jpeg', '', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_worldwide', 612, 0, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', '', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_worldwide', 613, 1, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_worldwide', 640, 2, 'IMAGE/PNG', '', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_worldwide', 637, 3, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_worldwide', 101, 4, 'image/gif', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_worldwide', 250, 5, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 0);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_worldwide', 86, 6, 'image/gif', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_worldwide', 840, 7, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:27700', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_worldwide', 841, 8, 'image/png', 'text/plain', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_worldwide', 842, 9, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_worldwide', 843, 10, 'png', 'mime', 'inimage', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_worldwide', 844, 11, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_gdi_de', 863, 0, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31492', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_gdi_de', 864, 1, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_gdi_de', 866, 2, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_gdi_de', 867, 3, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_gdi_de', 868, 4, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31492', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_gdi_de', 869, 5, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_gdi_de', 870, 6, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_gdi_de', 871, 7, 'image/png', 'text/plain', 'application/vnd.ogc.se_inimage', 'EPSG:31467', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_gdi_de', 872, 8, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_gdi_de', 881, 9, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:31467', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_gdi_de', 882, 10, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:31467', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_gdi_de', 883, 11, 'png', 'mime', 'WMS_XML', 'EPSG:31467', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_gdi_de', 884, 12, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_gdi_de', 885, 13, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_gdi_de', 887, 14, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:31492', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_gdi_de', 888, 15, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 893, 29, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:31467', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('gui1', 893, 0, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:31467', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('gui', 893, 3, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:31467', 1);
+-- Daten für Tabelle `layer`
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2712, 250, 0, '', '', 'Demis World Map', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2713, 250, 1, '0', 'Bathymetry', 'Bathymetry', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2714, 250, 2, '0', 'Countries', 'Countries', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2715, 250, 3, '0', 'Topography', 'Topography', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2716, 250, 4, '0', 'Hillshading', 'Hillshading', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2717, 250, 5, '0', 'Builtup areas', 'Builtup areas', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2718, 250, 6, '0', 'Coastlines', 'Coastlines', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2719, 250, 7, '0', 'Waterbodies', 'Waterbodies', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2720, 250, 8, '0', 'Inundated', 'Inundated', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2721, 250, 9, '0', 'Rivers', 'Rivers', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2722, 250, 10, '0', 'Streams', 'Streams', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2723, 250, 11, '0', 'Railroads', 'Railroads', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2724, 250, 12, '0', 'Highways', 'Highways', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2725, 250, 13, '0', 'Roads', 'Roads', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2726, 250, 14, '0', 'Trails', 'Trails', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2727, 250, 15, '0', 'Borders', 'Borders', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2728, 250, 16, '0', 'Cities', 'Cities', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2729, 250, 17, '0', 'Settlements', 'Settlements', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2730, 250, 18, '0', 'Spot elevations', 'Spot elevations', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2731, 250, 19, '0', 'Airports', 'Airports', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2732, 250, 20, '0', 'Ocean features', 'Ocean features', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3384, 328, 0, '', '', 'SW!ACE: Layers des Smallworld GIS', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3385, 328, 1, '0', 'Autobahn', 'Autobahn', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3386, 328, 2, '0', 'Bundesstr.', 'Bundesstr.', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3387, 328, 3, '0', 'Landesstr.', 'Landesstr.', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3388, 328, 4, '0', 'Kreisstr.', 'Kreisstr.', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3389, 328, 5, '0', 'AS Nr.', 'AS Nr.', 1, 0, 100220, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3390, 328, 6, '0', 'AS Name', 'AS Name', 1, 0, 53451, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3391, 328, 7, '0', 'Bauwerke', 'Bauwerke', 1, 0, 24720, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3392, 328, 8, '0', 'BW-Nr.', 'BW-Nr.', 1, 0, 24720, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3393, 328, 9, '0', 'Aeste', 'Aeste', 1, 0, 233847, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3394, 328, 10, '0', 'Netzkn.', 'Netzkn.', 1, 0, 53451, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3395, 328, 11, '0', 'Nullpkt.', 'Nullpkt.', 1, 0, 24720, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3396, 328, 12, '0', 'Str. Bez.', 'Str. Bez.', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3397, 328, 13, '0', 'Abs.Nr.', 'Abs.Nr.', 1, 0, 53451, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3398, 328, 14, '0', 'Durchlaesse', 'Durchlaesse', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3399, 328, 15, '0', 'Kreuzungen', 'Kreuzungen', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3400, 328, 16, '0', 'DGK 5', 'DGK 5', 0, 0, 24720, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3401, 329, 0, '', 'MUENSTER', 'Geobasisdaten Muenster', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3402, 329, 1, '0', 'splan', 'Stadtplan', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3403, 329, 2, '0', 'luftb', 'Luftbilder', 0, 1, 50000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3404, 329, 3, '0', 'dgk5dbr', 'DGK5', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3405, 329, 4, '0', 'Stadtgrundkarte', 'Stadtgrundkarte', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3406, 329, 5, '4', 'flst', 'Flurstuecke', 0, 1, 2500, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3407, 329, 6, '4', 'gebaeude', 'Gebaeude', 0, 1, 2500, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3408, 329, 7, '4', 'linien', 'Topographie', 0, 1, 2500, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3409, 329, 8, '4', 'texte', 'Beschriftung', 0, 1, 2500, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3470, 336, 0, '', '', 'DTK10', 0, 138, 27683, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3471, 336, 1, '0', 'DTK10:Gesamt', 'Gesamt', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3472, 336, 2, '0', 'DTK10:GesamtRS', 'GesamtRS', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (5575, 486, 0, '', 'PLZ_441', 'PLZ_441', 0, 1, 1000000000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (5576, 486, 1, '0', 'Nationalborder', 'National Border', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (5577, 486, 2, '0', 'Postcodeareas', 'Post Code Areas', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (5578, 486, 3, '0', 'Postcodelabels', 'Post Code Labels', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7255, 525, 0, '', 'Middle_America', 'Middle America', 0, 0, 119999880, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7256, 525, 1, '0', 'North_and_South_American_States', 'America', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7257, 525, 2, '0', 'Middle_American_States_AREA', 'State Area', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7258, 525, 3, '0', 'Middle_America_DEM_surface', 'Elevation Model', 0, 0, 11999988, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7259, 525, 4, '0', 'National_borders', 'Borders', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7260, 525, 5, '0', 'Lakes_and_temporary_inundated_areas', 'Lakes', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7261, 525, 6, '0', 'Temporary_and_permanent_rivers_and_streams', 'Rivers', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7262, 525, 7, '0', 'Larger_cities_polygon', 'Cities', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7263, 525, 8, '0', 'Roads', 'Roads', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7264, 525, 9, '0', 'Railway_systems', 'Rails', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7265, 525, 10, '0', 'Smaller_cities_and_villages_point', 'Places', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7266, 525, 11, '0', 'Archaeological_maya_sites', 'Maya Sites', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7267, 525, 12, '0', 'Archaeological_maya_records', 'Maya Records', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7491, 583, 0, '', 'canada_base', 'Atlas of Canada WMS', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7492, 583, 1, '0', 'roc_2m', 'Regions outside Canada (1:2 000 000)', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7493, 583, 2, '0', 'roc_7.5m', 'Regions outside Canada (1:7 500 000)', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7494, 583, 3, '0', 'roc_15m', 'Regions outside Canada (1:15 000 000)', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7495, 583, 4, '0', 'wa_2m', 'Water areas (1:2 000 000)', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7496, 583, 5, '0', 'wa_7.5m', 'Water areas (1:7 500 000)', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7497, 583, 6, '0', 'wa_15m', 'Water areas (1:15 000 000)', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7498, 583, 7, '0', 'wa_60m', 'Water areas (1:60 000 000)', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7499, 583, 8, '0', 'drain_2m', 'Drainage (1:2 000 000)', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7500, 583, 9, '0', 'drain_7.5m', 'Drainage (1:7 500 000)', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7501, 583, 10, '0', 'drain_15m', 'Drainage (1:15 000 000)', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7502, 583, 11, '0', 'drain_60m', 'Drainage (1:60 000 000)', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7503, 583, 12, '0', 'roads_2m', 'Road network (1:2 000 000)', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7504, 583, 13, '0', 'roads_7.5m', 'Road network (1:7 500 000)', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7505, 583, 14, '0', 'roads_15m', 'Road network (1:15 000 000)', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7506, 583, 15, '0', 'nat_bounds', 'Provincial and Territorial Boundaries', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7507, 583, 16, '0', 'int_bounds', 'Boundaries', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7508, 583, 17, '0', 'can_7.5m', 'Landmass outline (1:7 500 000)', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7509, 583, 18, '0', 'places_symb_2m', 'Populated Places (symbols 1:2M)', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7510, 583, 19, '0', 'places_labels_2m', 'Populated Places (labels 1:2M)', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7511, 583, 20, '0', 'places_symb_7.5m', 'Populated Places (symbols 1:7.5M)', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7512, 583, 21, '0', 'places_labels_7.5m', 'Populated Places (labels 1:7.5M)', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7513, 583, 22, '0', 'places_symb_15m', 'Populated Places (symbols 1:15M)', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7514, 583, 23, '0', 'places_labels_15m', 'Populated Places (labels 1:15M)', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7515, 583, 24, '0', 'cap_symb_e', 'Capitals (symbols)', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7516, 583, 25, '0', 'cap_labels', 'Capitals (Canada)', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7517, 584, 0, '', 'BSC_WMS', 'Bird Studies Canada WMS/WFS Server', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7518, 584, 1, '0', 'IBA', 'Canadian Important Bird Areas', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7519, 584, 2, '0', 'CBC_PT', 'Canadian Christmas Bird Count Locations', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7520, 584, 3, '0', 'CBC_PY', 'Canadian Christmas Bird Count Locations', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7521, 584, 4, '0', 'MMP', 'Marsh Monitoring Program Route Locations', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7522, 584, 5, '0', 'CLLS', 'Canadian Lakes Loon Survey Locations', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7523, 584, 6, '0', 'OBBA_SQUARE', 'Ontario Breeding Bird Atlas 10 km Squares', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7524, 584, 7, '0', 'OBBA_REGION', 'Ontario Breeding Bird Atlas Administrative Regions', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7525, 584, 8, '0', 'OBBA_BLOCK', 'Ontario Breeding Bird Atlas 100 km Blocks', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7526, 584, 9, '0', 'OWLS', 'Nocturnal Owl Survey Locations', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7527, 584, 10, '0', 'BBS_PT', 'Breeding Bird Survey Route Start Points', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9663, 612, 0, '', '', 'European Space Agency', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9664, 612, 1, '0', '', 'European Space Agency', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9665, 612, 2, '1', '', 'BOUNDARIES', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9666, 612, 3, '2', 'BARRIERL_1M:MapAdmin', 'Barrier Line Features', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9667, 612, 4, '2', 'BNDTXT_1M:MapAdmin', 'Boundaries Coverage Text', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9668, 612, 5, '2', 'COASTL_1M:MapAdmin', 'Coastlines', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9669, 612, 6, '2', 'DEPTHL_1M:MapAdmin', 'Depth Contours', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9670, 612, 7, '2', 'OCEANSEA_1M:MapAdmin', 'Oceans/Seas', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9671, 612, 8, '2', 'POLBNDA_1M:MapAdmin', 'Administrative Areas', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9672, 612, 9, '2', 'POLBNDL_1M:MapAdmin', 'Political Boundaries', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9673, 612, 10, '2', 'POLBNDP_1M:MapAdmin', 'Political Boundary Point Features', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9674, 612, 11, '1', '', 'BURNSCARS', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9675, 612, 12, '11', 'GLOBSCAR012002:MapAdmin', 'GLOBSCAR012002', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9676, 612, 13, '11', 'GLOBSCAR022002:MapAdmin', 'GLOBSCAR022002', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9677, 612, 14, '11', 'GLOBSCAR032002:MapAdmin', 'GLOBSCAR032002', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9678, 612, 15, '11', 'GLOBSCAR042002:MapAdmin', 'GLOBSCAR042002', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9679, 612, 16, '11', 'GLOBSCAR052002:MapAdmin', 'GLOBSCAR052002', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9680, 612, 17, '11', 'GLOBSCAR062002:MapAdmin', 'GLOBSCAR062002', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9681, 612, 18, '11', 'GLOBSCAR072002:MapAdmin', 'GLOBSCAR072002', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9682, 612, 19, '11', 'GLOBSCAR082002:MapAdmin', 'GLOBSCAR082002', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9683, 612, 20, '11', 'GLOBSCAR092002:MapAdmin', 'GLOBSCAR092002', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9684, 612, 21, '11', 'GLOBSCAR102002:MapAdmin', 'GLOBSCAR102002', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9685, 612, 22, '11', 'GLOBSCAR112002:MapAdmin', 'GLOBSCAR112002', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9686, 612, 23, '11', 'GLOBSCAR122002:MapAdmin', 'GLOBSCAR122002', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9687, 612, 24, '1', '', 'DATA QUALITY', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9688, 612, 25, '24', 'DQLINE_TRANS_1M:MapAdmin', 'Data Quality Line Features', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9689, 612, 26, '24', 'DQLINE_UTIL_1M:MapAdmin', 'Data Quality Line Features', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9690, 612, 27, '1', '', 'DIGITAL TERRAIN', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9691, 612, 28, '27', 'ETOPO5:MapAdmin', 'Global 5 Minute Elevations', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9692, 612, 29, '27', 'GTOPO30:MapAdmin', 'Global 30 Second Elevations', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9693, 612, 30, '1', '', 'ELEVATION', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9694, 612, 31, '30', 'CONTOURL_1M:MapAdmin', 'Elevation Contours', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9695, 612, 32, '30', 'ELEVP_1M:MapAdmin', 'Spot Elevations', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9696, 612, 33, '1', '', 'ENVISAT', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9697, 612, 34, '33', 'AATSR:MapAdmin', 'AATSR', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9698, 612, 35, '33', 'ASAR:MapAdmin', 'ASAR', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9699, 612, 36, '33', 'ASAR_WSM:MapAdmin', 'ASAR_WSM', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9700, 612, 37, '33', 'MERIS_RR:MapAdmin', 'MERIS_RR', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9701, 612, 38, '1', '', 'EO_MAPS', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9702, 612, 39, '38', 'WORLD_DMSP_NIGHT:MapAdmin', 'WORLD_DMSP_NIGHT', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9703, 612, 40, '38', 'WORLD_MODIS_1KM:MapAdmin', 'WORLD_MODIS_1KM', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9704, 612, 41, '38', 'WORLD_MODIS_5KM:MapAdmin', 'WORLD_MODIS_5KM', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9705, 612, 42, '1', '', 'GISD', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9706, 612, 43, '42', 'GISD_ROI:MapAdmin', 'GISD_ROI', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9707, 612, 44, '1', '', 'HYDROGRAPHY', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9708, 612, 45, '44', 'AQUECANL_1M:MapAdmin', 'Aqueducts/Canals/Flumes/Penstocks', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9709, 612, 46, '44', 'DANGERP_1M:MapAdmin', 'Danger Point Features', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9710, 612, 47, '44', 'HYDROTXT_1M:MapAdmin', 'Hydrography Coverage Text', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9711, 612, 48, '44', 'INWATERA_1M:MapAdmin', 'Inland Water Areas', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9712, 612, 49, '44', 'MISCL_1M:MapAdmin', 'Miscellaneous Line Features', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9713, 612, 50, '44', 'MISCP_1M:MapAdmin', 'Miscellaneous Point Features', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9714, 612, 51, '44', 'WATRCRSL_1M:MapAdmin', 'Water Courses', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9715, 612, 52, '1', '', 'INDUSTRY', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9716, 612, 53, '52', 'EXTRACTA_1M:MapAdmin', 'Extraction Areas', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9717, 612, 54, '52', 'EXTRACTP_1M:MapAdmin', 'Extraction Point Features', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9718, 612, 55, '52', 'FISHINDA_1M:MapAdmin', 'Fish Hatcheries/Fish Farms', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9719, 612, 56, '52', 'INDTXT_1M:MapAdmin', 'Industry Coverage Text', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9720, 612, 57, '52', 'MISINDP_1M:MapAdmin', 'Miscellaneous Industry Point Features', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9721, 612, 58, '52', 'STORAGEP_1M:MapAdmin', 'Storage Point Features', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9722, 612, 59, '1', '', 'PHYSIOGRAPHY', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9723, 612, 60, '59', 'GROUNDA_1M:MapAdmin', 'Ground Surface Areas', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9724, 612, 61, '59', 'LANDICEA_1M:MapAdmin', 'Snow/Ice Fields and Glaciers', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9725, 612, 62, '59', 'LNDFRML_1M:MapAdmin', 'Landform Line Features', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9726, 612, 63, '59', 'PHYSTXT_1M:MapAdmin', 'Physiography Coverage Text', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9727, 612, 64, '59', 'SEAICEA_1M:MapAdmin', 'Sea Ice Areas', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9728, 612, 65, '1', '', 'POPULATION', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9729, 612, 66, '65', 'BUILTUPA_1M:MapAdmin', 'Built-Up Areas', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9730, 612, 67, '65', 'BUILTUPP_1M:MapAdmin', 'Built-Up Area Points', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9731, 612, 68, '65', 'MISPOPA_1M:MapAdmin', 'Miscellaneous Population Areas', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9732, 612, 69, '65', 'MISPOPP_1M:MapAdmin', 'Miscellaneous Population Points', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9733, 612, 70, '65', 'POPTXT_1M:MapAdmin', 'Population Coverage Text', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9734, 612, 71, '1', '', 'TRANSPORTATION', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9735, 612, 72, '71', 'AEROFACP_1M:MapAdmin', 'Airport Facilities Points', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9736, 612, 73, '71', 'DQLINE_TRANS_1M:MapAdmin', 'Data Quality Line Features', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9737, 612, 74, '71', 'MISTRANL_1M:MapAdmin', 'Miscellaneous Transportation Line Features', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9738, 612, 75, '71', 'RAILRDL_1M:MapAdmin', 'Railroads', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9739, 612, 76, '71', 'ROADL_1M:MapAdmin', 'Roads', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9740, 612, 77, '71', 'RRYARDP_1M:MapAdmin', 'Railroad Yard Points', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9741, 612, 78, '71', 'TRAILL_1M:MapAdmin', 'Trails and Tracks', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9742, 612, 79, '71', 'TRANSTRC_1M:MapAdmin', 'Transportation Structures Points', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9743, 612, 80, '71', 'TRANSTRL_1M:MapAdmin', 'Transportation Structures Lines', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9744, 612, 81, '71', 'TRANSTXT_1M:MapAdmin', 'Transportation Coverage Text', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9745, 612, 82, '1', '', 'UTILITIES', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9746, 612, 83, '82', 'DQLINE_UTIL_1M:MapAdmin', 'Data Quality Line Features', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9747, 612, 84, '82', 'PIPEL_1M:MapAdmin', 'Pipelines', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9748, 612, 85, '82', 'UTILL_1M:MapAdmin', 'Power Transmission/Telephone/Telegraph Lines', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9749, 612, 86, '82', 'UTILP_1M:MapAdmin', 'Utility Point Features', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9750, 612, 87, '82', 'UTILTXT_1M:MapAdmin', 'Utilities Coverage Text', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9751, 612, 88, '1', '', 'VEGETATION', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9752, 612, 89, '88', 'CROPA_1M:MapAdmin', 'Croplands', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9753, 612, 90, '88', 'GRASSA_1M:MapAdmin', 'Grasslands', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9754, 612, 91, '88', 'SWAMPA_1M:MapAdmin', 'Marshs/Swamps', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9755, 612, 92, '88', 'TREESA_1M:MapAdmin', 'Trees', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9756, 612, 93, '88', 'TUNDRAA_1M:MapAdmin', 'Tundra', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9757, 612, 94, '0', '', 'CubeWerx Inc.', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9758, 612, 95, '94', '', 'CubeWerx Inc.', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9759, 612, 96, '95', '', 'Boundaries', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9760, 612, 97, '96', 'BARRIERL_1M:Foundation:CubeWerx', 'Barrier Line Features', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9761, 612, 98, '96', 'BNDTXT_1M:Foundation:CubeWerx', 'Boundaries Coverage Text', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9762, 612, 99, '96', 'COASTL_1M:Foundation:CubeWerx', 'Coastlines', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9763, 612, 100, '96', 'DEPTHL_1M:Foundation:CubeWerx', 'Depth Contours', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9764, 612, 101, '96', 'OCEANSEA_1M:Foundation:CubeWerx', 'Oceans/Seas', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9765, 612, 102, '96', 'POLBNDA_1M:Foundation:CubeWerx', 'Administrative Areas', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9766, 612, 103, '96', 'POLBNDL_1M:Foundation:CubeWerx', 'Political Boundaries', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9767, 612, 104, '96', 'POLBNDP_1M:Foundation:CubeWerx', 'Political Boundary Point Features', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9768, 612, 105, '95', '', 'Data Quality', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9769, 612, 106, '105', 'DQLINE_TRANS_1M:Foundation:CubeWerx', 'Data Quality Line Features', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9770, 612, 107, '105', 'DQLINE_UTIL_1M:Foundation:CubeWerx', 'Data Quality Line Features', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9771, 612, 108, '95', '', 'Digital Terrain', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9772, 612, 109, '108', 'ETOPO2:Foundation:CubeWerx', 'Global 2 Minute Elevations', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9773, 612, 110, '108', 'GTOPO30:Foundation:CubeWerx', 'Global 30 Second Elevations', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9774, 612, 111, '108', 'RELIEF:Foundation:CubeWerx', 'Two Minute Shaded Relief', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9775, 612, 112, '95', '', 'Elevation', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9776, 612, 113, '112', 'CONTOURL_1M:Foundation:CubeWerx', 'Elevation Contours', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9777, 612, 114, '112', 'ELEVP_1M:Foundation:CubeWerx', 'Spot Elevations', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9778, 612, 115, '95', '', 'Hydrography', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9779, 612, 116, '115', 'AQUECANL_1M:Foundation:CubeWerx', 'Aqueducts/Canals/Flumes/Penstocks', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9780, 612, 117, '115', 'DANGERP_1M:Foundation:CubeWerx', 'Danger Point Features', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9781, 612, 118, '115', 'HYDROTXT_1M:Foundation:CubeWerx', 'Hydrography Coverage Text', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9782, 612, 119, '115', 'INWATERA_1M:Foundation:CubeWerx', 'Inland Water Areas', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9783, 612, 120, '115', 'MISCL_1M:Foundation:CubeWerx', 'Miscellaneous Line Features', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9784, 612, 121, '115', 'MISCP_1M:Foundation:CubeWerx', 'Miscellaneous Point Features', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9785, 612, 122, '115', 'WATRCRSL_1M:Foundation:CubeWerx', 'Water Courses', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9786, 612, 123, '95', '', 'Industry', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9787, 612, 124, '123', 'EXTRACTA_1M:Foundation:CubeWerx', 'Extraction Areas', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9788, 612, 125, '123', 'EXTRACTP_1M:Foundation:CubeWerx', 'Extraction Point Features', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9789, 612, 126, '123', 'FISHINDA_1M:Foundation:CubeWerx', 'Fish Hatcheries/Fish Farms', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9790, 612, 127, '123', 'INDTXT_1M:Foundation:CubeWerx', 'Industry Coverage Text', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9791, 612, 128, '123', 'MISINDP_1M:Foundation:CubeWerx', 'Miscellaneous Industry Point Features', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9792, 612, 129, '123', 'STORAGEP_1M:Foundation:CubeWerx', 'Storage Point Features', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9793, 612, 130, '95', '', 'Physiography', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9794, 612, 131, '130', 'GROUNDA_1M:Foundation:CubeWerx', 'Ground Surface Areas', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9795, 612, 132, '130', 'LANDICEA_1M:Foundation:CubeWerx', 'Snow/Ice Fields and Glaciers', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9796, 612, 133, '130', 'LNDFRML_1M:Foundation:CubeWerx', 'Landform Line Features', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9797, 612, 134, '130', 'PHYSTXT_1M:Foundation:CubeWerx', 'Physiography Coverage Text', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9798, 612, 135, '130', 'SEAICEA_1M:Foundation:CubeWerx', 'Sea Ice Areas', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9799, 612, 136, '95', '', 'Population', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9800, 612, 137, '136', 'BUILTUPA_1M:Foundation:CubeWerx', 'Built-Up Areas', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9801, 612, 138, '136', 'BUILTUPP_1M:Foundation:CubeWerx', 'Built-Up Area Points', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9802, 612, 139, '136', 'MISPOPA_1M:Foundation:CubeWerx', 'Miscellaneous Population Areas', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9803, 612, 140, '136', 'MISPOPP_1M:Foundation:CubeWerx', 'Miscellaneous Population Points', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9804, 612, 141, '136', 'POPTXT_1M:Foundation:CubeWerx', 'Population Coverage Text', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9805, 612, 142, '95', '', 'Transportation', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9806, 612, 143, '142', 'AEROFACP_1M:Foundation:CubeWerx', 'Airport Facilities Points', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9807, 612, 144, '142', 'DQLINE_TRANS_1M:Foundation:CubeWerx', 'Data Quality Line Features', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9808, 612, 145, '142', 'MISTRANL_1M:Foundation:CubeWerx', 'Miscellaneous Transportation Line Features', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9809, 612, 146, '142', 'RAILRDL_1M:Foundation:CubeWerx', 'Railroads', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9810, 612, 147, '142', 'ROADL_1M:Foundation:CubeWerx', 'Roads', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9811, 612, 148, '142', 'RRYARDP_1M:Foundation:CubeWerx', 'Railroad Yard Points', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9812, 612, 149, '142', 'TRAILL_1M:Foundation:CubeWerx', 'Trails and Tracks', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9813, 612, 150, '142', 'TRANSTRC_1M:Foundation:CubeWerx', 'Transportation Structures Points', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9814, 612, 151, '142', 'TRANSTRL_1M:Foundation:CubeWerx', 'Transportation Structures Lines', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9815, 612, 152, '142', 'TRANSTXT_1M:Foundation:CubeWerx', 'Transportation Coverage Text', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9816, 612, 153, '95', '', 'Utilities', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9817, 612, 154, '153', 'DQLINE_UTIL_1M:Foundation:CubeWerx', 'Data Quality Line Features', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9818, 612, 155, '153', 'PIPEL_1M:Foundation:CubeWerx', 'Pipelines', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9819, 612, 156, '153', 'UTILL_1M:Foundation:CubeWerx', 'Power Transmission/Telephone/Telegraph Lines', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9820, 612, 157, '153', 'UTILP_1M:Foundation:CubeWerx', 'Utility Point Features', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9821, 612, 158, '153', 'UTILTXT_1M:Foundation:CubeWerx', 'Utilities Coverage Text', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9822, 612, 159, '95', '', 'Vegetation', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9823, 612, 160, '159', 'CROPA_1M:Foundation:CubeWerx', 'Croplands', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9824, 612, 161, '159', 'GRASSA_1M:Foundation:CubeWerx', 'Grasslands', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9825, 612, 162, '159', 'SWAMPA_1M:Foundation:CubeWerx', 'Marshs/Swamps', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9826, 612, 163, '159', 'TREESA_1M:Foundation:CubeWerx', 'Trees', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9827, 612, 164, '159', 'TUNDRAA_1M:Foundation:CubeWerx', 'Tundra', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9828, 612, 165, '94', '', 'CubeWerx Inc.', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9829, 612, 166, '165', '', 'Shuttle Rader Topography Mission Data', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9830, 612, 167, '166', 'ONEARCSEC:SRTM:CubeWerx', 'One Arc Second SRTM', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9831, 612, 168, '166', 'THREEARCSEC:SRTM:CubeWerx', 'Three Arc Second SRTM', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9832, 612, 169, '94', '', 'CubeWerx Inc.', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9833, 612, 170, '169', '', 'Canadian Geology', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9834, 612, 171, '170', 'AGE_ROCK_TYPE_CA:GSC:CubeWerx', 'Canadian Age Rock Type', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9835, 612, 172, '170', 'FAULTS_CA:GSC:CubeWerx', 'Canadian Fault Lines', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9836, 612, 173, '169', '', 'World Geology', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9837, 612, 174, '173', 'AGE_ROCK_TYPE:GSC:CubeWerx', 'World Age Rock Type', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9838, 612, 175, '173', 'FAULTS:GSC:CubeWerx', 'World Fault Lines', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9839, 612, 176, '173', 'FELSIC_MAGMATIC:GSC:CubeWerx', 'Felsic Magmatic', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9840, 612, 177, '173', 'MAFIC_MAGMATIC:GSC:CubeWerx', 'Mafic Magmatic', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9841, 612, 178, '173', 'PRECAMBRIAN:GSC:CubeWerx', 'Precambrian', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9842, 612, 179, '0', '', 'World Map', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9843, 612, 180, '179', 'Bathymetry:DEMIS', 'Bathymetry', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9844, 612, 181, '179', 'Countries:DEMIS', 'Countries', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9845, 612, 182, '179', 'Topography:DEMIS', 'Topography', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9846, 612, 183, '179', 'Hillshading:DEMIS', 'Hillshading', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9847, 612, 184, '179', 'Builtup areas:DEMIS', 'Builtup areas', 1, 0, 2147483647, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9848, 612, 185, '179', 'Coastlines:DEMIS', 'Coastlines', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9849, 612, 186, '179', 'Waterbodies:DEMIS', 'Waterbodies', 1, 0, 2147483647, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9850, 612, 187, '179', 'Inundated:DEMIS', 'Inundated', 1, 0, 2147483647, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9851, 612, 188, '179', 'Rivers:DEMIS', 'Rivers', 1, 0, 2147483647, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9852, 612, 189, '179', 'Streams:DEMIS', 'Streams', 1, 0, 2147483647, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9853, 612, 190, '179', 'Railroads:DEMIS', 'Railroads', 1, 0, 2147483647, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9854, 612, 191, '179', 'Highways:DEMIS', 'Highways', 1, 0, 2147483647, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9855, 612, 192, '179', 'Roads:DEMIS', 'Roads', 1, 0, 2147483647, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9856, 612, 193, '179', 'Trails:DEMIS', 'Trails', 1, 0, 2147483647, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9857, 612, 194, '179', 'Borders:DEMIS', 'Borders', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9858, 612, 195, '179', 'Cities:DEMIS', 'Cities', 1, 0, 2147483647, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9859, 612, 196, '179', 'Settlements:DEMIS', 'Settlements', 1, 0, 2147483647, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9860, 612, 197, '179', 'Spot elevations:DEMIS', 'Spot elevations', 0, 0, 2147483647, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9861, 612, 198, '179', 'Airports:DEMIS', 'Airports', 1, 0, 2147483647, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9862, 612, 199, '179', 'Ocean features:DEMIS', 'Ocean features', 1, 0, 2147483647, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9863, 612, 200, '0', '', 'Spacemetric Image Server', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9864, 612, 201, '200', '', 'GLCF Satellite Images', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9865, 612, 202, '201', '', 'Landsat ETM Scenes', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9866, 612, 203, '202', 'LANDSAT_TM_GLCF_432:TEST', 'Landsat ETM Band 432 Scenes', 1, 2147483647, 2147483647, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9867, 612, 204, '202', 'LANDSAT_TM_GLCF_432_STRETCH:TEST', 'Landsat ETM Band 432 Scenes, Stretched', 1, 2147483647, 2147483647, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9868, 612, 205, '202', 'LANDSAT_TM_GLCF_742:TEST', 'Landsat ETM Band 742 Scenes', 1, 2147483647, 2147483647, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9869, 612, 206, '200', '', 'DMC Scenes', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9870, 612, 207, '206', 'DMC_QL:TEST', 'DMC Quicklooks', 1, 2147483647, 2147483647, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9871, 612, 208, '0', '', 'TEST2 (X)', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9872, 612, 209, '0', '', 'map annotations', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9873, 612, 210, '209', 'graticule', 'Lat/Lon Graticule', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9874, 612, 211, '209', 'crosshairs', 'Crosshairs', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9875, 613, 0, '', '', 'ArcIMS MapService', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9876, 613, 1, '0', 'Shaded Relief Imagery', 'Shaded Relief Imagery', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9877, 614, 0, '', '', 'ArcIMS Map Server', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9878, 614, 1, '0', '250K Topo Map', '250K Topo Map', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9879, 614, 2, '0', '100K Topo Map', '100K Topo Map', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9880, 614, 3, '0', '24K Topo Map', '24K Topo Map', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9881, 614, 4, '0', 'General Topo Map', 'General Topo Map', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9882, 614, 5, '0', 'Road', 'Road', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9883, 614, 6, '0', '24K Quad', '24K Quad', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9884, 614, 7, '0', '100K Quad', '100K Quad', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9885, 614, 8, '0', '250K Quad', '250K Quad', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9886, 614, 9, '0', 'County', 'County', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9887, 614, 10, '0', 'State', 'State', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9888, 614, 11, '0', 'City', 'City', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9889, 614, 12, '0', 'Geographic Name', 'Geographic Name', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9890, 615, 0, '', '', 'ArcIMS Map Server', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9891, 615, 1, '0', 'Population', 'Population', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9892, 615, 2, '0', 'Landuse', 'Landuse', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9893, 615, 3, '0', 'Countries', 'Countries', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9894, 615, 4, '0', 'Landsat images', 'Landsat images', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9895, 615, 5, '0', 'Watersheds', 'Watersheds', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9896, 615, 6, '0', 'Rivers', 'Rivers', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9897, 615, 7, '0', 'Ramsar sites (Polygons)', 'Ramsar sites (Polygons)', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9898, 615, 8, '0', 'Ramsar sites', 'Ramsar sites', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9899, 615, 9, '0', 'Ramsar sites (Points)', 'Ramsar sites (Points)', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9900, 615, 10, '0', 'Cities', 'Cities', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9901, 616, 0, '', '', 'GeoNovaSDE', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9902, 616, 1, '0', '10k_Drainage_polygons', '10k_Drainage Polygons', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9903, 616, 2, '0', 'ST_POINT', 'ST_POINT', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9904, 616, 3, '0', 'WA_POINT', 'WA_POINT', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9905, 616, 4, '0', 'ST_LINE', 'ST_LINE', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9906, 616, 5, '0', 'LF_POINT', 'LF_POINT', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9907, 616, 6, '0', 'UT_LINE', 'UT_LINE', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9908, 616, 7, '0', 'LF_LINE', 'LF_LINE', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9909, 616, 8, '0', 'RR_POINT', 'RR_POINT', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9910, 616, 9, '0', 'RR_LINE', 'RR_LINE', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9911, 616, 10, '0', 'DA_POINT', 'DA_POINT', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9912, 616, 11, '0', 'DL_LINE', 'DL_LINE', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9913, 616, 12, '0', 'DA_POLY', 'DA_POLY', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9914, 616, 13, '0', 'DA_LINE', 'DA_LINE', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9915, 616, 14, '0', 'LC_POINT', 'LC_POINT', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9916, 616, 15, '0', 'LC_LINE', 'LC_LINE', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9917, 616, 16, '0', 'UT_POINT', 'UT_POINT', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9918, 616, 17, '0', 'WA_LINE', 'WA_LINE', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9919, 616, 18, '0', 'COAST', 'COAST', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9920, 616, 19, '0', 'ROADS', 'ROADS', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9921, 617, 0, '', '', 'Geobase_NRN_NewfoundlandAndLabrador_I_Detail', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9922, 617, 1, '0', 'NewfoundlandLabrador', 'Provincial Boundary', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9923, 617, 2, '0', 'Water', 'Water', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9924, 617, 3, '0', 'Highways', 'Highways', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9925, 617, 4, '0', 'highwaysMjrRoads', 'Highways and Major Roads', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9926, 617, 5, '0', 'allroads', 'All Roads', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9927, 617, 6, '0', 'FerrySeg', 'FERRYSEG', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9928, 617, 7, '0', 'Junction', 'JUNCTION', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9929, 617, 8, '0', 'BlkPassage', 'BLKPASSAGE', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10028, 624, 0, '', '', 'gewstat', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10029, 624, 1, '0', 'Uebrige Gewaesser groesser 12 m Breite 3', 'Uebrige Gewaesser groesser 12 m Breite', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10030, 624, 2, '0', 'Uebrige Gewaesser kleiner 12 m Breite 2', 'Uebrige Gewaesser kleiner 12 m Breite', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10031, 624, 3, '0', 'Kanaele groesser 12 m Breite 2', 'Kanaele groesser 12 m Breite', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10032, 624, 4, '0', 'Kanaele kleiner 12m Breite', 'Kanaele kleiner 12 m Breite', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10033, 624, 5, '0', 'Unterirdisch verlaufende Gewaesser', 'Unterirdisch verlaufende Gewaesser', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10034, 624, 6, '0', 'Fliessgewaesser groesser 12 m Breite', 'Fliessgewaesser groesser 12 m Breite', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10035, 624, 7, '0', 'Fliessgewaesser kleiner 12 m Breite', 'Fliessgewaesser kleiner 12 m Breite', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10036, 624, 8, '0', 'St_Kanaele 1000 m', 'St_Kanaele 1000 m', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10037, 624, 9, '0', 'St_Rhein und Weser 1000 m', 'St_Rhein und Weser 1000 m', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10038, 624, 10, '0', 'St_Fliessgewaesser 1000 m', 'St_Fliessgewaesser 1000 m', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10039, 624, 11, '0', 'St_Kanaele 500 m', 'St_Kanaele 500 m', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10040, 624, 12, '0', 'St_Rhein und Weser 500 m', 'St_Rhein und Weser 500 m', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10041, 624, 13, '0', 'St_Fliessgewaesser 500 m', 'St_Fliessgewaesser 500 m', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10042, 624, 14, '0', 'St_Kanaele 100 m', 'St_Kanaele 100 m', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10043, 624, 15, '0', 'St_Rhein und Weser 100 m', 'St_Rhein und Weser 100 m', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10044, 624, 16, '0', 'St_Fliessgewaesser 100 m', 'St_Fliessgewaesser 100 m', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10045, 624, 17, '0', 'Stationierungslinie', 'Stationierungslinie', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10046, 624, 18, '0', 'Fluesse', 'Fluesse', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10047, 625, 0, '', 'DEMO', 'GMap WMS Demo Server', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10048, 625, 1, '0', 'bathymetry', 'Elevation/Bathymetry', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10049, 625, 2, '0', 'land_fn', 'Foreign Lands', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10050, 625, 3, '0', 'park', 'Parks', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10051, 625, 4, '0', 'drain_fn', 'Water', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10052, 625, 5, '0', 'drainage', 'Drainage', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10053, 625, 6, '0', 'prov_bound', 'Province', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10054, 625, 7, '0', 'fedlimit', 'Federal Limit', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10055, 625, 8, '0', 'rail', 'Railroads', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10056, 625, 9, '0', 'road', 'Roads', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10057, 625, 10, '0', 'popplace', 'Cities', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10058, 625, 11, '0', 'grid', 'Grid', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10106, 634, 0, '', 'Location', 'Point locations', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10107, 634, 1, '0', 'city_austral', 'Australasian Cities', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10108, 634, 2, '0', 'capital_aus', 'Australian Capital Cities', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10109, 634, 3, '0', 'town_aus', ' Some Australian towns', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10110, 634, 4, '0', 'wastewet', ' Wastewater artificial wetlands listed as', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10153, 637, 0, '', 'Bathymetry', 'MapServer WMS Demo', 0, 50000, 149999900, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10154, 637, 1, '0', 'etopo2', 'etopo2', 0, 50000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10155, 637, 2, '0', 'ecbathy', 'ecbathy', 0, 50000, 10000000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10156, 637, 3, '0', 'gom', 'gom', 0, 50000, 2000000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10157, 637, 4, '0', 'bbay', 'bbay', 0, 50000, 1000000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10158, 637, 5, '0', 'gomctr', 'gomctr', 0, 50000, 749999, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10159, 637, 6, '0', 'world_line_simp', 'world_line_simp', 0, 4999990, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10160, 637, 7, '0', 'world_line', 'world_line', 0, 0, 4999990, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10165, 640, 0, '', '', 'OnEarth Web Map Server', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10166, 640, 1, '0', 'global_mosaic', 'WMS Global Mosaic, pan sharpened', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10167, 640, 2, '0', 'global_mosaic_base', 'WMS Global Mosaic, not pan sharpened', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10168, 640, 3, '0', 'us_landsat_wgs84', 'CONUS mosaic of 1990 MRLC dataset', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10169, 640, 4, '0', 'us_overlays', 'Progressive US overlay map, white background', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10170, 640, 5, '0', 'us90_overlays', 'MRLC US mosaic with progressive overlay map', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10171, 640, 6, '0', 'daily_terra', 'Daily composite of MODIS-TERRA images', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10172, 640, 7, '0', 'daily_aqua', 'Daily composite of MODIS-AQUA images', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10173, 640, 8, '0', 'modis', 'Blue Marble, Global MODIS derived image', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10174, 640, 9, '0', 'huemapped_srtm', 'SRTM derived global elevation, 3 arc-second, hue m', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10175, 640, 10, '0', 'srtmplus', 'Global 1km elevation, seamless SRTM land elevation', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10176, 640, 11, '0', 'worldwind_dem', 'SRTM derived global elevation, 3 arc-second', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10177, 640, 12, '0', 'us_ned', 'United States elevation, 30m', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10178, 640, 13, '0', 'us_elevation', 'Digital Elevation Map of the United States, DTED d', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10179, 640, 14, '0', 'us_colordem', 'Digital Elevation Map of the United States, DTED d', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10194, 645, 0, '', '', 'ArcIMS MapService', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10195, 645, 1, '0', 'HDM:LANDMASS', 'Land Areas', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10196, 645, 2, '0', 'HDM:DFIRM_BFE', 'DFIRM Base Flood Elevations', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10197, 645, 3, '0', 'HDM:DFIRM_XSECTION', 'DFIRM Cross Sections', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10198, 645, 4, '0', 'HDM:DFIRM_FLD_AR', 'DFIRM Flood Hazard Areas', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10199, 645, 5, '0', 'HDM:Q3_COUNTYMAP', 'Flood Data Availability', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10200, 645, 6, '0', 'HDM:Q3_FLOOD', 'Q3 Flood Hazards', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10369, 648, 0, '', '', 'hangneigung', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10370, 648, 1, '0', 'hangneigung', 'Hangneigung', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10371, 648, 2, '0', 'Fliessgewaesser', 'Fliessgewaesser', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10415, 655, 0, '', 'SEACOOS Remotely-Sensed Imagery', 'SEACOOS Remotely-Sensed Imagery', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10416, 655, 1, '0', 'modis_ergb_low', 'MODIS Enhanced RGB, courtesy USF Institute for Mar', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10417, 655, 2, '0', 'modis_rgb_composite_low', 'MODIS Low Resolution RGB Composite, courtesy USF I', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10418, 655, 3, '0', 'modis_rgb_low', 'MODIS Low Resolution RGB, courtesy USF Institute f', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10419, 655, 4, '0', 'modis_rgb_hi_chesapeake_bay', 'MODIS High Resolution RGB, courtesy USF Institute', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10420, 655, 5, '0', 'modis_rgb_hi_florida_bay', 'MODIS High Resolution RGB, courtesy USF Institute', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10421, 655, 6, '0', 'modis_rgb_hi_miss_plume', 'MODIS High Resolution RGB, courtesy USF Institute', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10422, 655, 7, '0', 'modis_rgb_hi_suwannee_river', 'MODIS High Resolution RGB, courtesy USF Institute', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10423, 655, 8, '0', 'modis_rgb_hi_tampa_bay', 'MODIS High Resolution RGB, courtesy USF Institute', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10424, 655, 9, '0', 'oi_sst', 'Optimally Interpolated SST, courtesy USF Ocean Cir', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10425, 655, 10, '0', 'modis_sst', 'MODIS SST, courtesy USF Institute for Marine Remot', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10426, 655, 11, '0', 'avhrr_sst', 'AVHRR SST, courtesy USF Institute for Marine Remot', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10427, 655, 12, '0', 'modis_chl', 'MODIS Chl-A, courtesy USF Institute for Marine Rem', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10428, 655, 13, '0', 'jpl_sea_surface_height_composite', 'TBA', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10429, 655, 14, '0', 'tamu_level_III', 'Texas Mesonet Radar, courtesy Texas A and M Univer', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10430, 655, 15, '0', 'tamu_usrad', 'Texas Mesonet Radar, courtesy Texas A and M Univer', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10431, 655, 16, '0', 'surface_currents_radar', 'Surface currents (Radar) (EXPERIMENTAL), courtesy', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10432, 655, 17, '0', 'depth_averaged_currents', 'Depth-averaged currents (EXPERIMENTAL), courtesy U', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10433, 655, 18, '0', 'sea_surface_elevation', 'Sea surface elevation (EXPERIMENTAL), courtesy Uni', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10434, 655, 19, '0', 'opaque_legend_background', 'Opaque legend background', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10435, 655, 20, '0', 'modis_chl_legend_full_range', 'MODIS Chl-A Legend, courtesy USF Institute for Mar', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10436, 655, 21, '0', 'sst_legend_full_range', 'SST Legend, courtesy USF Institute for Marine Remo', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10437, 655, 22, '0', 'tamu_level_III_legend_full_range', 'Texas Mesonet Radar Legend, courtesy Texas A and M', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10438, 655, 23, '0', 'current_velocity_legend', 'Current velocity legend', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10439, 655, 24, '0', 'water_level_legend', 'Elevation legend', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10987, 670, 0, '', '', 'waldtyp', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10988, 670, 1, '0', 'Waldtyp', 'Waldtyp', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10989, 670, 2, '0', 'Waldtyp_50', 'Waldtyp_50', 0, 37494, 187472, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10990, 670, 3, '0', 'Waldtyp_Real', 'Waldtyp_Real', 0, 37494, 187472, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10991, 671, 0, '', '', 'wsg', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10992, 671, 1, '0', 'Trinkwasser Zone 1 punktfoermig', 'Trinkwasser Zone 1 punktfoermig', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10993, 671, 2, '0', 'Trinkwasserschutzgebiete', 'Trinkwasserschutzgebiete', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10994, 671, 3, '0', 'Heilquellen Zone 1 punktfoermig', 'Heilquellen Zone 1 punktfoermig', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10995, 671, 4, '0', 'Heilquellenschutzgebiete', 'Heilquellenschutzgebiete', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (11541, 706, 0, '', '', 'WA_Atlas_GN_WMS', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (11542, 706, 1, '0', 'Australia Base Map', 'Australia Base Map', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (11543, 706, 2, '0', 'WA Base Map', 'WA Base Map', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (11544, 706, 3, '0', 'WA Base Map - Detailed', 'WA Base Map - Detailed', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (11545, 706, 4, '0', 'Bathymetry - Above Chart Datum', 'Bathymetry - Above Chart Datum', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (11546, 706, 5, '0', 'State Geological Polygons', 'State Geological Polygons', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (11547, 706, 6, '0', 'Beards Vegetation', 'Beards Vegetation', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (11629, 717, 0, '', '', 'forstamtsgr', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (11630, 717, 1, '0', '0', 'Forstamtsgrenzen', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13667, 739, 0, '', '', 'Eusoils_Ex', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13668, 739, 1, '0', '55', 'ERODI. Soil erodibility class', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13669, 739, 2, '0', '70', 'TXEROD. Textural factor of soil erodibility', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13670, 739, 3, '0', '48', 'CRUSTING. Soil crusting class', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13671, 739, 4, '0', '64', 'PHYSCHIM.Physi-chemical factor of soil', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13672, 739, 5, '0', '71', 'TXTCRUST. Textural factor of soil crusting', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13673, 739, 6, '0', '41', 'ATC. Accumulated temperature class', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13674, 739, 7, '0', '72', 'USE. Regrouped land use', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13675, 739, 8, '0', '39', 'AGLIM2NNI. 2nd Limitation to agricultural use', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13676, 739, 9, '0', '38', 'AGLIM1NNI. Dom.Limitation to agricultural use', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13677, 739, 10, '0', '53', 'EAWC_SUB. Subsoil easily avail.water capac.', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13678, 739, 11, '0', '54', 'EAWC_TOP. Topsoil easily avail.water capac.', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13679, 739, 12, '0', '42', 'AWC_SUB. Subsoil avail.water capacity', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13680, 739, 13, '0', '43', 'AWC_TOP. Topsoil avail.water capacity', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13681, 739, 14, '0', '56', 'HG. Hydro-geological class', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13682, 739, 15, '0', '51', 'DIMP. Depth to an impermeable layer', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13683, 739, 16, '0', '49', 'DGH. Depth to a gleyed horizon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13684, 739, 17, '0', '65', 'PMH. Parent material hydro-geological', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13685, 739, 18, '0', '61', 'PD_SUB. Subsoil Packing Density', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13686, 739, 19, '0', '62', 'PD_TOP. Topsoil packing density', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13687, 739, 20, '0', '66', 'STR_SUB. Subsoil structure', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13688, 739, 21, '0', '67', 'STR_TOP. Topsoil structure', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13689, 739, 22, '0', '68', 'TD. Rule inferred subsoil texture', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13690, 739, 23, '0', '73', 'VS. Volume of stones', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13691, 739, 24, '0', '52', 'DR. Depth to rock', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13692, 739, 25, '0', '44', 'BS_SUB. Base Subsoil Saturation', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13693, 739, 26, '0', '45', 'BS_TOP. Base Topsoil Saturation', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13694, 739, 27, '0', '46', 'CEC_SUB. Subsoil Cation Exch.Capacity', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13695, 739, 28, '0', '47', 'CEC_TOP. Topsoil Cation Exch.Capacity', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13696, 739, 29, '0', '58', 'MIN_SUB. Subsoil Mineralogy', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13697, 739, 30, '0', '59', 'MIN_TOP. Topsoil Mineralogy', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13698, 739, 31, '0', '57', 'MIN. Profile Mineralogy', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13699, 739, 32, '0', '50', 'DIFF. Soil Profile Differentiation', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13700, 739, 33, '0', '40', 'ALT. Elevation', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13701, 739, 34, '0', '63', 'PEAT', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13702, 739, 35, '0', '60', 'OC_TOP. Topsoil Organic Carbon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13703, 739, 36, '0', '69', 'TEXT. Dominant Surface Textural', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13704, 739, 37, '0', '21', 'SLOPESE. Secondary Slope class', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13705, 739, 38, '0', '20', 'SLOPEDO. Dominant Slope Class', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13706, 739, 39, '0', '37', 'ZMIN. Minimun elevetaion above sea', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13707, 739, 40, '0', '36', 'ZMAX. Maximun elevetaion above sea', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13708, 739, 41, '0', '30', 'WM2. Type of Water Manag.System', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13709, 739, 42, '0', '29', 'WM1. Presence of Water Manag.System', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13710, 739, 43, '0', '31', 'WR. Annual average soil water regime', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13711, 739, 44, '0', '10', 'IL. Impermeable Layer', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13712, 739, 45, '0', '19', 'ROO. Depth Class of obstacle to roots', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13713, 739, 46, '0', '2', 'AGLIM2. Sec.limitation to agr.use', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13714, 739, 47, '0', '1', 'AGLIM1. Dom.limitation to agr.use', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13715, 739, 48, '0', '28', 'USESE. Secondary Land Use', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13716, 739, 49, '0', '27', 'USEDO. Dominant Land Use', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13717, 739, 50, '0', '6', 'FAO85LV3. 3rd Level Soil Code 1974 FAO', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13718, 739, 51, '0', '5', 'FAO85LV2. 2nd Level Soil Code 1974 FAO', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13719, 739, 52, '0', '4', 'FAO85LV1. Soil Major Group 1974 FAO', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13720, 739, 53, '0', '3', 'FAO85FU. Full Soil Code 1974 FAO', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13721, 739, 54, '0', '9', 'FAO90LV2. 2nd level Soil Code 1990 FAO', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13722, 739, 55, '0', '8', 'FAO90LV1. Soil Major Group 1990 FAO', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13723, 739, 56, '0', '7', 'FAO90FU. Full Soil Code 1990 FAO', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13724, 739, 57, '0', '18', 'PARMASE3. 3rd level Sec.Par.Material', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13725, 739, 58, '0', '17', 'PARMASE2. 2nd level Sec.Par.Material', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13726, 739, 59, '0', '16', 'PARMASE1. Major Group Sec.Par.Material', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13727, 739, 60, '0', '15', 'PARMASE. Secondary Parent Material', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13728, 739, 61, '0', '14', 'PARMADO3. 3rd level Dom.Par.Material', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13729, 739, 62, '0', '13', 'PARMADO2. 2nd level Dom.Par.Material', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13730, 739, 63, '0', '12', 'PARMADO1. Major Group Dom.Par.Material', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13731, 739, 64, '0', '11', 'PARMADO. Dominant Parent Material', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13732, 739, 65, '0', '26', 'TXSUBSE. Sec.Sub-surface text.class', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13733, 739, 66, '0', '25', 'TXSUBDO. Dom.Sub-surface text.class', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13734, 739, 67, '0', '22', 'TXDEPCHG. Depth class to a text.change', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13735, 739, 68, '0', '24', 'TXSRFSE. Sec.surface text.class', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13736, 739, 69, '0', '23', 'TXSRFDO. Dom.surface text.class', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13737, 739, 70, '0', '33', 'WRBADJ2. 2nd Soil Adjective Code', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13738, 739, 71, '0', '32', 'WRBADJ1. First Soil Adjective Code', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13739, 739, 72, '0', '35', 'WRBLV1. Soil reference group', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13740, 739, 73, '0', '34', 'WRBFU. Full soil Code', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13741, 739, 74, '0', '97', 'Eurasia Lakes-Inland Waters', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13742, 739, 75, '0', '98', 'European Cities', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13743, 739, 76, '0', '0', 'Country Boundaries', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13744, 739, 77, '0', '99', 'Soil Polygon Outlines', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13751, 86, 0, '', 'World_map', 'World Map', 0, 1, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13752, 86, 1, '0', 'Countries', 'Countries', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13753, 86, 2, '0', 'Countrynames', 'Countrynames', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13754, 86, 3, '0', 'Citypoints', 'Citypoints', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13755, 86, 4, '0', 'City', 'Citynames', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13775, 101, 0, '', 'UMN_Mapserver', 'UMN Mapserver', 0, 1, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13776, 101, 1, '0', 'UMN_USER', 'UMN User', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13777, 101, 2, '0', 'UMN_USER_NAMES', 'UMN Info', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14006, 758, 0, '', 'Brandenburg', 'DNM 250/2', 0, 25001, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14007, 758, 1, '0', 'kreis', 'Landkreise und kreisfreie Städte', 1, 200000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14008, 758, 2, '0', 'orte', 'Zentren', 0, 200000, 1000000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14009, 758, 3, '0', 'korte', 'Orte', 0, 200000, 749999, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14010, 758, 4, '0', 'lwas', 'Flüsse und Kanäle', 0, 200000, 749999, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14011, 758, 5, '0', 'fwas', 'Seen', 0, 200000, 749999, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14012, 758, 6, '0', 'ebahn', 'Eisenbahnen', 0, 200000, 749999, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14013, 758, 7, '0', 'lstr', 'Landesstraßen', 0, 200000, 400000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14014, 758, 8, '0', 'bstr', 'Bundesstraßen', 0, 200000, 1000000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14015, 758, 9, '0', 'astr', 'Autobahnen', 0, 200000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14016, 758, 10, '0', 'kfz', 'Kfz-Zeichen', 0, 1000000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14028, 760, 0, '', 'Brandenburg', 'DNM 100/2', 0, 25001, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14029, 760, 1, '0', 'kreis', 'Landkreise und kreisfreie Städte', 1, 25001, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14030, 760, 2, '0', 'wald', 'Wald', 0, 25001, 150000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14031, 760, 3, '0', 'ozen', 'Oberzentren', 0, 25001, 2000000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14032, 760, 4, '0', 'mzen', 'Mittelzentren', 0, 25001, 600000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14033, 760, 5, '0', 'uzen', 'Unterzentren', 0, 25001, 200000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14034, 760, 6, '0', 'lwas', 'Flüsse und Kanäle', 0, 25001, 150000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14035, 760, 7, '0', 'fwas', 'Seen', 0, 25001, 250001, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14036, 760, 8, '0', 'ebahn', 'Eisenbahnen', 0, 25001, 250001, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14037, 760, 9, '0', 'kstr', 'Kreisstraßen', 0, 25001, 100000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14038, 760, 10, '0', 'lstr', 'Landesstraßen', 0, 25001, 250001, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14039, 760, 11, '0', 'bstr', 'Bundesstraßen', 0, 25001, 749999, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14040, 760, 12, '0', 'astr', 'Autobahnen', 0, 25001, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14041, 760, 13, '0', 'nfwas', 'Namen der Seen', 0, 25001, 100000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14042, 760, 14, '0', 'kfz', 'Kfz-Zeichen', 0, 2000000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14058, 762, 0, '', 'Brandenburg', 'DNM 25/2', 0, 100, 50000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14059, 762, 1, '0', 'land', 'Landkreise und kreisfreie Städte', 0, 100, 50000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14060, 762, 2, '0', 'ort', 'Ortschaften', 0, 1000, 50000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14061, 762, 3, '0', 'wald', 'Waldflächen', 0, 1000, 50000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14062, 762, 4, '0', 'gruen', 'Grünflächen', 0, 1000, 50000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14063, 762, 5, '0', 'lwas', 'Flüsse und Kanäle', 0, 1000, 50000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14064, 762, 6, '0', 'fwas', 'Seen, Teiche', 0, 1000, 50000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14065, 762, 7, '0', 'ebahn', 'Eisenbahnverbindungen', 0, 1000, 50000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14066, 762, 8, '0', 'str', 'Straßen', 0, 1000, 50000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14067, 762, 9, '0', 'haus', 'Gebäude', 0, 1000, 20000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14068, 762, 10, '0', 'nfwas', 'Namen der Seen, Teiche', 0, 1000, 20000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14069, 762, 11, '0', 'nort', 'Ortsnamen', 0, 1000, 50000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14082, 764, 0, '', 'Brandenburg', 'DNM FÜK', 0, 50000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14083, 764, 1, '0', 'flur', 'Flur', 1, 50000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14084, 764, 2, '0', 'gema', 'Gemarkung', 1, 50000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14085, 764, 3, '0', 'geme', 'Gemeinde', 1, 50000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14086, 764, 4, '0', 'stadt', 'Kreisfreie Städte', 1, 50000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14087, 764, 5, '0', 'kreis', 'Landkreise', 1, 50000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14088, 765, 0, '', 'Brandenburg', 'DNM VG', 0, 50000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14089, 765, 1, '0', 'berlin', 'Berliner Bezirke', 0, 50000, 1000000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14090, 765, 2, '0', 'geme', 'Gemeinde', 1, 50000, 1000000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14091, 765, 3, '0', 'kamt', 'Amtsfreie Gemeinde', 1, 50000, 1000000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14092, 765, 4, '0', 'amt', 'Ämter', 1, 50000, 1000000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14093, 765, 5, '0', 'stadt', 'Kreisfreie Städte', 1, 50000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14094, 765, 6, '0', 'kreis', 'Landkreise', 1, 50000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14095, 765, 7, '0', 'land', 'Land', 0, 50000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14096, 765, 8, '0', 'staat', 'Deutschland', 0, 50000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14097, 765, 9, '0', 'ngeme', 'Namen der Gemeinden', 0, 50000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14098, 765, 10, '0', 'nkamt', 'Namen der amtfreien Gemeinden', 0, 50000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14099, 765, 11, '0', 'namt', 'Namen der Ämter', 0, 50000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14100, 765, 12, '0', 'nkreis', 'KFZ Kennzeichen der Kreise', 0, 50000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14104, 767, 0, '', 'SLUBFURT', 'SLUBFURT', 0, 500, 250001, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14105, 767, 1, '0', 'Mentalscape', 'Mentalscape', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14106, 767, 2, '0', 'Districts', 'Districts', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14107, 767, 3, '0', 'Odra', 'Odra', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14108, 767, 4, '0', 'Paths', 'Paths', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14109, 767, 5, '0', 'Edges', 'Edges', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14110, 767, 6, '0', 'Nodes', 'Nodes', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14111, 767, 7, '0', 'Landmarks', 'Landmarks', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14112, 767, 8, '0', 'CityWall', 'CityWall', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14113, 767, 9, '0', 'HotSpots', 'HotSpots', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14114, 767, 10, '0', 'HotSpots-2', 'HotSpots-2', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14115, 767, 11, '0', 'SDE-W', 'SDE-W', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14167, 776, 0, '', 'infoprix', 'Infoprix', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14168, 776, 1, '0', 'Weltlaender', 'Etats', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14169, 776, 2, '0', 'Departmt', 'Departements', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14170, 776, 3, '0', 'Sousprefneu', 'Sous Prefectures', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14171, 776, 4, '0', 'rivlc', 'Rivieres et lacs', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14172, 776, 5, '0', 'Route2', 'Voies de communication', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14173, 776, 6, '0', 'localits', 'Localités', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14174, 776, 7, '0', 'Villes', 'Villes', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14175, 776, 8, '0', 'Maerkte1', 'Marches', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14176, 776, 9, '0', 'Nouveaux-Marches', 'Nouveaux-Marches', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14177, 777, 0, '', 'Africa', 'Lieu / Locations', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14178, 777, 1, '0', 'adminareas', 'Pays / Countries', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14179, 777, 2, '0', 'provinceboundaries', 'Départ./ Provinces', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14180, 777, 3, '0', 'populateplace', 'Villes / Towns', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14181, 778, 0, '', 'benin2', 'Pendjari National Parc', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14182, 778, 1, '0', 'zoneseri', 'Zone Seri', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14183, 778, 2, '0', 'zoneest', 'Zone Est', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14184, 778, 3, '0', 'zonepnp', 'Zone Pnp', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14185, 778, 4, '0', 'zonezck', 'Zone Zck', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14186, 778, 5, '0', 'zonezcp', 'Zone Zcp', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14187, 778, 6, '0', 'ldcpendjari', 'Limite du Complexe pendjari', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14188, 778, 7, '0', 'maresextension', 'Mares Extension', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14189, 778, 8, '0', 'piste1', 'Piste 1', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14190, 778, 9, '0', 'pistepodiega', 'Piste podiéga', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14191, 778, 10, '0', 'agglom', 'Agglomeration Areas', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14192, 778, 11, '0', 'coursdeauperm', 'Cours deau permanent', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14193, 778, 12, '0', 'cCoursdeau2003', 'Cours d eau 2003', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14194, 778, 13, '0', 'coursdeautemp', 'Cours d eau temporaire', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14195, 778, 14, '0', 'escarpement', 'Escarpements', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14196, 778, 15, '0', 'mar', 'Mares', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14197, 779, 0, '', 'Ruanda24', 'Ruanda', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14198, 779, 1, '0', 'Countries', 'Countries', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14199, 779, 2, '1', 'Countries', 'Country Names', 0, 1000000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14200, 779, 3, '0', 'Country', 'Country Names', 0, 1000000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14201, 779, 4, '0', 'Cities', 'Cities', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14202, 779, 5, '4', 'Cities', 'Cities', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14203, 779, 6, '0', 'City', 'City Names', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14204, 779, 7, '0', 'Landsat', 'Sat-Image', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14205, 779, 8, '0', 'Dry Savannah', 'Dry Savannah', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14206, 779, 9, '8', 'Dry Savannah', 'Ruanda2', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14207, 779, 10, '0', 'Swamps', 'Swamps', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14208, 779, 11, '10', 'Swamps', 'Ruanda2', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14209, 779, 12, '0', 'Lakes', 'Lakes', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14210, 779, 13, '12', 'Lakes', 'Lakes', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14211, 779, 14, '0', 'Lake Names', 'Lake Names', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14212, 779, 15, '0', 'Dry Swamp', 'Dry Swamp', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14213, 779, 16, '15', 'Dry Swamp', 'Ruanda2', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14214, 779, 17, '0', 'Forests', 'Forests', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14215, 779, 18, '17', 'Forests', 'Ruanda2', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14216, 779, 19, '0', 'Islands', 'Islands', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14217, 779, 20, '19', 'Islands', 'Ruanda2', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14218, 779, 21, '0', 'Valleys', 'Valleys', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14219, 779, 22, '21', 'Valleys', 'Ruanda2', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14220, 779, 23, '0', 'Vegetation.shp', 'Vegetation', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14221, 779, 24, '0', 'Akagera-river', 'Akagera-river', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14222, 779, 25, '24', 'Akagera-river', 'Ruanda2', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14223, 779, 26, '0', 'Parc Limit', 'Parc Limit', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14224, 779, 27, '26', 'Parc Limit', 'Parc Limit', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14225, 779, 28, '0', 'Lanes', 'Lanes', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14226, 779, 29, '28', 'Lanes', 'Ruanda2', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14227, 779, 30, '0', 'Infrastructure', 'Infrastructure', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14228, 779, 31, '0', 'Places', 'Places', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14251, 785, 0, '', '', 'dtk200_500_1000_a10_gk3_wms', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14252, 785, 1, '0', 'DTK200-V', 'Digitale Topographische Karte 1:200.000', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14253, 785, 2, '0', 'DTK500-V', 'Digitale Topographische Karte 1:500.000', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14254, 785, 3, '0', 'DTK1000', 'Digitale Topographische Karte 1:1.000.000', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14255, 786, 0, '', 'MS', 'Luftbild', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14256, 786, 1, '0', 'ortho', 'Luftbild', 0, 1, 125000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14257, 787, 0, '', '', 'OGC-Dienst der Bayerischen Vermessungsverwaltung', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14258, 787, 1, '0', 'DOP', 'DOP', 0, 20, 400880, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14259, 787, 2, '0', 'TK50', 'TK50', 0, 20, 80176, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14260, 787, 3, '0', 'UK500', 'UK500', 0, 20, 801759, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14261, 788, 0, '', 'DOP', 'Digitale Orthophotos mit einer reduzierten Bodenau', 0, 10000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14262, 788, 1, '0', 'dop25', 'DOP 25m', 0, 50000, 2000000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14263, 788, 2, '0', 'dop5', 'DOP 5m', 0, 10000, 50000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14264, 789, 0, '', '', 'Rasterdaten_tk100_tk50', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14265, 789, 1, '0', 'UEB', 'Uebersicht Sachsen', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14266, 789, 2, '0', 'tk100', 'Topog. Karte 1:100000', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14267, 789, 3, '2', 'tk100s', 'tk100-Schriften', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14268, 789, 4, '2', 'tk100w', 'tk100-Gewaesser', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14269, 789, 5, '2', 'tk100g', 'tk100-Grundriss', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14270, 789, 6, '2', 'tk100i', 'tk100-Hoehenlinien', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14271, 789, 7, '2', 'tk100v', 'tk100-Vegetation', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14272, 789, 8, '0', 'tk50', 'Topog. Karte 1:50000', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14273, 789, 9, '8', 'tk50w', 'tk50-Gewaesser', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14274, 789, 10, '8', 'tk50g', 'tk50-Grundriss', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14275, 789, 11, '8', 'tk50i', 'tk50-Hoehenlinien', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14276, 789, 12, '8', 'tk50v', 'tk50-Vegetation', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14277, 790, 0, '', '', 'LGN - WMS', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14278, 790, 1, '0', 'DUEKN5000', 'Uebersichtskarte 1:5000000', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14279, 790, 2, '0', 'DUEKN1000', 'Uebersichtskarte 1:1000000', 0, 0, 847059, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14280, 790, 3, '0', 'DUEKN500', 'Uebersichtskarte 1:500000', 0, 0, 795580, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14281, 790, 4, '0', 'TK100', 'Topographische Karte 1:100000', 0, 0, 423530, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14287, 792, 0, '', '', 'TKVV', 0, 200, 200440, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14288, 792, 1, '0', 'Thueringer_Orthofotos', 'Thueringer_Orthofotos', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14289, 792, 2, '1', 'Orthophotos_TH-2m', 'Orthophotos_TH-2m', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14290, 792, 3, '0', 'TK50', 'TK50', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14291, 792, 4, '3', 'Top.Karte_50_gesamt', 'Top.Karte_50_gesamt', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14292, 792, 5, '3', 'Grundriss', 'Grundriss', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14293, 792, 6, '3', 'Gewaesser', 'Gewaesser', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14294, 792, 7, '3', 'Hoehenschichten', 'Hoehenschichten', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14295, 792, 8, '3', 'Strassen', 'Strassen', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14296, 792, 9, '3', 'Wald', 'Wald', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14297, 793, 0, '', '', 'OGC-Dienst des Hessischen Landesvermessungsamtes', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14298, 793, 1, '0', 'ATKIS50', 'ATKIS50', 0, 601, 50110, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14299, 793, 2, '0', 'ATKIS100', 'ATKIS100', 0, 1203, 150330, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14300, 793, 3, '0', 'DOP2SW', 'DOP2SW', 0, 40088, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14301, 794, 0, '', 'Brandenburg', 'DNM 100/2', 0, 25001, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14302, 794, 1, '0', 'kreis', 'Landkreise und kreisfreie Städte', 1, 25001, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14303, 794, 2, '0', 'wald', 'Wald', 0, 25001, 150000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14304, 794, 3, '0', 'ozen', 'Oberzentren', 0, 25001, 2000000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14305, 794, 4, '0', 'mzen', 'Mittelzentren', 0, 25001, 600000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14306, 794, 5, '0', 'uzen', 'Unterzentren', 0, 25001, 200000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14307, 794, 6, '0', 'lwas', 'Flüsse und Kanäle', 0, 25001, 150000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14308, 794, 7, '0', 'fwas', 'Seen', 0, 25001, 250001, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14309, 794, 8, '0', 'ebahn', 'Eisenbahnen', 0, 25001, 250001, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14310, 794, 9, '0', 'kstr', 'Kreisstraßen', 0, 25001, 100000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14311, 794, 10, '0', 'lstr', 'Landesstraßen', 0, 25001, 250001, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14312, 794, 11, '0', 'bstr', 'Bundesstraßen', 0, 25001, 749999, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14313, 794, 12, '0', 'astr', 'Autobahnen', 0, 25001, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14314, 794, 13, '0', 'nfwas', 'Namen der Seen', 0, 25001, 100000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14315, 794, 14, '0', 'kfz', 'Kfz-Zeichen', 0, 2000000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14331, 796, 0, '', '', 'TKVV', 0, 200, 200440, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14332, 796, 1, '0', 'Thueringer_Orthofotos', 'Thueringer_Orthofotos', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14333, 796, 2, '1', 'Orthophotos_TH-2m', 'Orthophotos_TH-2m', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14334, 796, 3, '0', 'TK50', 'TK50', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14335, 796, 4, '3', 'Top.Karte_50_gesamt', 'Top.Karte_50_gesamt', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14336, 796, 5, '3', 'Grundriss', 'Grundriss', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14337, 796, 6, '3', 'Gewaesser', 'Gewaesser', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14338, 796, 7, '3', 'Hoehenschichten', 'Hoehenschichten', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14339, 796, 8, '3', 'Strassen', 'Strassen', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14340, 796, 9, '3', 'Wald', 'Wald', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14341, 797, 0, '', 'Brandenburg', 'DNM FÜK', 0, 50000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14342, 797, 1, '0', 'flur', 'Flur', 1, 50000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14343, 797, 2, '0', 'gema', 'Gemarkung', 1, 50000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14344, 797, 3, '0', 'geme', 'Gemeinde', 1, 50000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14345, 797, 4, '0', 'stadt', 'Kreisfreie Städte', 1, 50000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14346, 797, 5, '0', 'kreis', 'Landkreise', 1, 50000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14347, 798, 0, '', 'Brandenburg', 'DNM VG', 0, 50000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14348, 798, 1, '0', 'berlin', 'Berliner Bezirke', 0, 50000, 1000000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14349, 798, 2, '0', 'geme', 'Gemeinde', 1, 50000, 1000000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14350, 798, 3, '0', 'kamt', 'Amtsfreie Gemeinde', 1, 50000, 1000000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14351, 798, 4, '0', 'amt', 'Ämter', 1, 50000, 1000000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14352, 798, 5, '0', 'stadt', 'Kreisfreie Städte', 1, 50000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14353, 798, 6, '0', 'kreis', 'Landkreise', 1, 50000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14354, 798, 7, '0', 'land', 'Land', 0, 50000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14355, 798, 8, '0', 'staat', 'Deutschland', 0, 50000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14356, 798, 9, '0', 'ngeme', 'Namen der Gemeinden', 0, 50000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14357, 798, 10, '0', 'nkamt', 'Namen der amtfreien Gemeinden', 0, 50000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14358, 798, 11, '0', 'namt', 'Namen der Ämter', 0, 50000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14359, 798, 12, '0', 'nkreis', 'KFZ Kennzeichen der Kreise', 0, 50000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14360, 799, 0, '', 'DOP', 'Digitale Orthophotos mit einer reduzierten Bodenau', 0, 10000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14361, 799, 1, '0', 'dop25', 'DOP 25m', 0, 50000, 2000000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14362, 799, 2, '0', 'dop5', 'DOP 5m', 0, 10000, 50000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14363, 800, 0, '', '', 'WMS', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14364, 800, 1, '0', 'doq', '1991 doq', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14365, 800, 2, '0', 'fsa', '2003 fsa', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14366, 800, 3, '0', 'metro', '2004 NGA', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14370, 824, 0, '', '', 'ECW Images', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14371, 824, 1, '0', '/l7ecw_stretched/orthol7_20123xs190600.ecw', 'orthol7_20123xs190600.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14372, 824, 2, '0', '/l7ecw_stretched/orthol7_20124xs190600.ecw', 'orthol7_20124xs190600.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14373, 824, 3, '0', '/l7ecw_stretched/orthol7_20125xs190600.ecw', 'orthol7_20125xs190600.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14374, 824, 4, '0', '/l7ecw_stretched/orthol7_20222xs120501.ecw', 'orthol7_20222xs120501.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14375, 824, 5, '0', '/l7ecw_stretched/orthol7_20223xs120501.ecw', 'orthol7_20223xs120501.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14376, 824, 6, '0', '/l7ecw_stretched/orthol7_20224xs120501.ecw', 'orthol7_20224xs120501.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14377, 824, 7, '0', '/l7ecw_stretched/orthol7_20225xs120501.ecw', 'orthol7_20225xs120501.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14378, 824, 8, '0', '/l7ecw_stretched/orthol7_20323xs170600.ecw', 'orthol7_20323xs170600.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14379, 824, 9, '0', '/l7ecw_stretched/orthol7_20324xs170600.ecw', 'orthol7_20324xs170600.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14380, 824, 10, '0', '/l7ecw_stretched/orthol7_20325xs300400.ecw', 'orthol7_20325xs300400.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14381, 824, 11, '0', '/l7ecw_stretched/orthol7_20421xs070500.ecw', 'orthol7_20421xs070500.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14382, 824, 12, '0', '/l7ecw_stretched/orthol7_20422xs070500.ecw', 'orthol7_20422xs070500.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14383, 824, 13, '0', '/l7ecw_stretched/orthol7_20423xs100999.ecw', 'orthol7_20423xs100999.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14384, 824, 14, '0', '/l7ecw_stretched/orthol7_20424xs240799.ecw', 'orthol7_20424xs240799.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14385, 824, 15, '0', '/l7ecw_stretched/orthol7_20425xs240799.ecw', 'orthol7_20425xs240799.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14386, 824, 16, '0', '/l7ecw_stretched/orthol7_20520xs170700.ecw', 'orthol7_20520xs170700.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14387, 824, 17, '0', '/l7ecw_stretched/orthol7_20521xs170700.ecw', 'orthol7_20521xs170700.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14388, 824, 18, '0', '/l7ecw_stretched/orthol7_20522xs170700.ecw', 'orthol7_20522xs170700.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14389, 824, 19, '0', '/l7ecw_stretched/orthol7_20619xs180300.ecw', 'orthol7_20619xs180300.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14390, 824, 20, '0', '/l7ecw_stretched/orthol7_20620xs050500.ecw', 'orthol7_20620xs050500.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14391, 824, 21, '0', '/l7ecw_stretched/orthol7_20621xs250800.ecw', 'orthol7_20621xs250800.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14392, 824, 22, '0', '/l7ecw_stretched/orthol7_20622xs240501.ecw', 'orthol7_20622xs240501.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14393, 824, 23, '0', '/l7ecw_stretched/orthol7_20719xs290799.ecw', 'orthol7_20719xs290799.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14394, 824, 24, '0', '/l7ecw_stretched/orthol7_20720xs120500.ecw', 'orthol7_20720xs120500.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14395, 824, 25, '0', '/landmap/ls5/stif/ecw/ortholandsat5_201_23.ecw', 'ortholandsat5_201_23.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14396, 824, 26, '0', '/landmap/ls5/stif/ecw/ortholandsat5_201_24.ecw', 'ortholandsat5_201_24.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14397, 824, 27, '0', '/landmap/ls5/stif/ecw/ortholandsat5_202_22.ecw', 'ortholandsat5_202_22.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14398, 824, 28, '0', '/landmap/ls5/stif/ecw/ortholandsat5_202_23.ecw', 'ortholandsat5_202_23.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14399, 824, 29, '0', '/landmap/ls5/stif/ecw/ortholandsat5_202_24.ecw', 'ortholandsat5_202_24.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14400, 824, 30, '0', '/landmap/ls5/stif/ecw/ortholandsat5_202_25.ecw', 'ortholandsat5_202_25.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14401, 824, 31, '0', '/landmap/ls5/stif/ecw/ortholandsat5_203_22.ecw', 'ortholandsat5_203_22.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14402, 824, 32, '0', '/landmap/ls5/stif/ecw/ortholandsat5_203_23.ecw', 'ortholandsat5_203_23.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14403, 824, 33, '0', '/landmap/ls5/stif/ecw/ortholandsat5_203_24.ecw', 'ortholandsat5_203_24.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14404, 824, 34, '0', '/landmap/ls5/stif/ecw/ortholandsat5_203_25.ecw', 'ortholandsat5_203_25.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14405, 824, 35, '0', '/landmap/ls5/stif/ecw/ortholandsat5_204_20q1.ecw', 'ortholandsat5_204_20q1.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14406, 824, 36, '0', '/landmap/ls5/stif/ecw/ortholandsat5_204_20q3.ecw', 'ortholandsat5_204_20q3.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14407, 824, 37, '0', '/landmap/ls5/stif/ecw/ortholandsat5_204_21.ecw', 'ortholandsat5_204_21.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14408, 824, 38, '0', '/landmap/ls5/stif/ecw/ortholandsat5_204_22.ecw', 'ortholandsat5_204_22.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14409, 824, 39, '0', '/landmap/ls5/stif/ecw/ortholandsat5_204_23.ecw', 'ortholandsat5_204_23.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14410, 824, 40, '0', '/landmap/ls5/stif/ecw/ortholandsat5_204_24.ecw', 'ortholandsat5_204_24.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14411, 824, 41, '0', '/landmap/ls5/stif/ecw/ortholandsat5_204_25.ecw', 'ortholandsat5_204_25.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14412, 824, 42, '0', '/landmap/ls5/stif/ecw/ortholandsat5_205_18q1.ecw', 'ortholandsat5_205_18q1.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14413, 824, 43, '0', '/landmap/ls5/stif/ecw/ortholandsat5_205_18q2.ecw', 'ortholandsat5_205_18q2.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14414, 824, 44, '0', '/landmap/ls5/stif/ecw/ortholandsat5_205_20.ecw', 'ortholandsat5_205_20.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14415, 824, 45, '0', '/landmap/ls5/stif/ecw/ortholandsat5_205_21.ecw', 'ortholandsat5_205_21.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14416, 824, 46, '0', '/landmap/ls5/stif/ecw/ortholandsat5_205_22.ecw', 'ortholandsat5_205_22.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14417, 824, 47, '0', '/landmap/ls5/stif/ecw/ortholandsat5_206_18.ecw', 'ortholandsat5_206_18.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14418, 824, 48, '0', '/landmap/ls5/stif/ecw/ortholandsat5_206_19.ecw', 'ortholandsat5_206_19.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14419, 824, 49, '0', '/landmap/ls5/stif/ecw/ortholandsat5_206_20.ecw', 'ortholandsat5_206_20.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14420, 824, 50, '0', '/landmap/ls5/stif/ecw/ortholandsat5_206_21.ecw', 'ortholandsat5_206_21.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14421, 824, 51, '0', '/landmap/ls5/stif/ecw/ortholandsat5_206_22.ecw', 'ortholandsat5_206_22.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14422, 824, 52, '0', '/landmap/ls5/stif/ecw/ortholandsat5_207_20.ecw', 'ortholandsat5_207_20.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14423, 824, 53, '0', '/landmap/ls5/stif/ecw/ortholandsat5_207_21.ecw', 'ortholandsat5_207_21.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14424, 824, 54, '0', '/landmap/ls5/stif/ecw/ortholandsat5_207_22.ecw', 'ortholandsat5_207_22.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14425, 824, 55, '0', '/landmap/ls5/stif/ecw/ortholandsat5_208_19.ecw', 'ortholandsat5_208_19.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14426, 824, 56, '0', '/landmap/ls5/stif/ecw/ortholandsat5_208_20.ecw', 'ortholandsat5_208_20.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14427, 824, 57, '0', '/landmap/mosaics/landsat/hs.ecw', 'hs.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14428, 824, 58, '0', '/landmap/mosaics/landsat/hs2.ecw', 'hs2.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14429, 824, 59, '0', '/landmap/mosaics/landsat/hs3.ecw', 'hs3.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14430, 824, 60, '0', '/landmap/mosaics/landsat/l5mosaic.ecw', 'l5mosaic.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14431, 824, 61, '0', '/landmap/mosaics/landsat/l5mosaicb742.ecw', 'l5mosaicb742.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14432, 824, 62, '0', '/landmap/mosaics/landsat/l5mosaic_geodetic.ecw', 'l5mosaic_geodetic.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14433, 824, 63, '0', '/landmap/mosaics/landsat/l5mosaic_geodetic1.ecw', 'l5mosaic_geodetic1.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14434, 824, 64, '0', '/landmap/mosaics/landsat/l5mosaic_UTM.ecw', 'l5mosaic_UTM.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14435, 824, 65, '0', '/landmap/mosaics/landsat/l7b123.ecw', 'l7b123.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14436, 824, 66, '0', '/landmap/mosaics/landsat/l7bpan.ecw', 'l7bpan.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14437, 824, 67, '0', '/landmap/mosaics/landsat/l7bpan_s.ecw', 'l7bpan_s.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14438, 824, 68, '0', '/landmap/mosaics/landsat/l7bpan_s_geo.becw.ecw', 'l7bpan_s_geo.becw.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14439, 824, 69, '0', '/landmap/mosaics/landsat/l7bpan_s_geo.ecw', 'l7bpan_s_geo.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14440, 824, 70, '0', '/landmap/mosaics/landsat/landsat7m25.ecw', 'landsat7m25.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14441, 824, 71, '0', '/landmap/mosaics/landsat/landsat7m25r.ecw', 'landsat7m25r.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14442, 824, 72, '0', '/landmap/mosaics/landsat/landsat7m25_123.ecw', 'landsat7m25_123.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14443, 824, 73, '0', '/landmap/mosaics/landsat/landsat_mosaic_15m.ecw', 'landsat_mosaic_15m.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14444, 824, 74, '0', '/landmap/mosaics/spot/orthospot13_231.ecw', 'orthospot13_231.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14445, 824, 75, '0', '/landmap/mosaics/spot/orthospot13_232.ecw', 'orthospot13_232.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14446, 824, 76, '0', '/landmap/mosaics/spot/orthospot13_233.ecw', 'orthospot13_233.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14447, 824, 77, '0', '/landmap/mosaics/spot/orthospot13_234.ecw', 'orthospot13_234.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14448, 824, 78, '0', '/landmap/mosaics/spot/orthospot13_235.ecw', 'orthospot13_235.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14449, 824, 79, '0', '/landmap/mosaics/spot/orthospot14_230.ecw', 'orthospot14_230.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14450, 824, 80, '0', '/landmap/mosaics/spot/orthospot14_231.ecw', 'orthospot14_231.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14451, 824, 81, '0', '/landmap/mosaics/spot/orthospot14_232.ecw', 'orthospot14_232.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14452, 824, 82, '0', '/landmap/mosaics/spot/orthospot14_232_ecw.ecw', 'orthospot14_232_ecw.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14453, 824, 83, '0', '/landmap/mosaics/spot/orthospot14_233.ecw', 'orthospot14_233.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14454, 824, 84, '0', '/landmap/mosaics/spot/orthospot14_234.ecw', 'orthospot14_234.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14455, 824, 85, '0', '/landmap/mosaics/spot/orthospot14_235.ecw', 'orthospot14_235.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14456, 824, 86, '0', '/landmap/mosaics/spot/orthospot14_236.ecw', 'orthospot14_236.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14457, 824, 87, '0', '/landmap/mosaics/spot/orthospot17_230.ecw', 'orthospot17_230.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14458, 824, 88, '0', '/landmap/mosaics/spot/orthospot17_231.ecw', 'orthospot17_231.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14459, 824, 89, '0', '/landmap/mosaics/spot/orthospot17_232.ecw', 'orthospot17_232.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14460, 824, 90, '0', '/landmap/mosaics/spot/orthospot17_233.ecw', 'orthospot17_233.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14461, 824, 91, '0', '/landmap/mosaics/spot/orthospot17_234.ecw', 'orthospot17_234.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14462, 824, 92, '0', '/landmap/mosaics/spot/orthospot17_235.ecw', 'orthospot17_235.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14463, 824, 93, '0', '/landmap/mosaics/spot/orthospot17_236.ecw', 'orthospot17_236.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14464, 824, 94, '0', '/landmap/mosaics/spot/orthospot17_237.ecw', 'orthospot17_237.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14465, 824, 95, '0', '/landmap/mosaics/spot/orthospot17_238.ecw', 'orthospot17_238.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14466, 824, 96, '0', '/landmap/mosaics/spot/orthospot17_239.ecw', 'orthospot17_239.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14467, 824, 97, '0', '/landmap/mosaics/spot/orthospot17_240.ecw', 'orthospot17_240.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14468, 824, 98, '0', '/landmap/mosaics/spot/orthospot18_229.ecw', 'orthospot18_229.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14469, 824, 99, '0', '/landmap/mosaics/spot/orthospot18_231.ecw', 'orthospot18_231.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14470, 824, 100, '0', '/landmap/mosaics/spot/orthospot18_232.ecw', 'orthospot18_232.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14471, 824, 101, '0', '/landmap/mosaics/spot/orthospot18_233.ecw', 'orthospot18_233.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14472, 824, 102, '0', '/landmap/mosaics/spot/orthospot18_234.ecw', 'orthospot18_234.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14473, 824, 103, '0', '/landmap/mosaics/spot/orthospot18_235.ecw', 'orthospot18_235.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14474, 824, 104, '0', '/landmap/mosaics/spot/orthospot18_236.ecw', 'orthospot18_236.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14475, 824, 105, '0', '/landmap/mosaics/spot/orthospot18_237.ecw', 'orthospot18_237.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14476, 824, 106, '0', '/landmap/mosaics/spot/orthospot18_238.ecw', 'orthospot18_238.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14477, 824, 107, '0', '/landmap/mosaics/spot/orthospot25_237.ecw', 'orthospot25_237.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14478, 824, 108, '0', '/landmap/mosaics/spot/orthospot25_238.ecw', 'orthospot25_238.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14479, 824, 109, '0', '/landmap/mosaics/spot/orthospot25_241.ecw', 'orthospot25_241.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14480, 824, 110, '0', '/landmap/mosaics/spot/orthospot25_242.ecw', 'orthospot25_242.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14481, 824, 111, '0', '/landmap/mosaics/spot/orthospot25_243.ecw', 'orthospot25_243.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14482, 824, 112, '0', '/landmap/mosaics/spot/orthospot25_244.ecw', 'orthospot25_244.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14483, 824, 113, '0', '/landmap/mosaics/spot/orthospot25_245.ecw', 'orthospot25_245.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14484, 824, 114, '0', '/landmap/mosaics/spot/orthospot25_247.ecw', 'orthospot25_247.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14485, 824, 115, '0', '/landmap/mosaics/spot/orthospot25_248.ecw', 'orthospot25_248.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14486, 824, 116, '0', '/landmap/mosaics/spot/orthospot26_239.ecw', 'orthospot26_239.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14487, 824, 117, '0', '/landmap/mosaics/spot/orthospot26_240.ecw', 'orthospot26_240.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14488, 824, 118, '0', '/landmap/mosaics/spot/orthospot26_241.ecw', 'orthospot26_241.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14489, 824, 119, '0', '/landmap/mosaics/spot/orthospot26_242.ecw', 'orthospot26_242.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14490, 824, 120, '0', '/landmap/mosaics/spot/orthospot26_243.ecw', 'orthospot26_243.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14491, 824, 121, '0', '/landmap/mosaics/spot/orthospot26_244.ecw', 'orthospot26_244.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14492, 824, 122, '0', '/landmap/mosaics/spot/orthospot26_245.ecw', 'orthospot26_245.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14493, 824, 123, '0', '/landmap/mosaics/spot/orthospot26_246.ecw', 'orthospot26_246.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14494, 824, 124, '0', '/landmap/mosaics/spot/orthospot26_247.ecw', 'orthospot26_247.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14495, 824, 125, '0', '/landmap/mosaics/spot/orthospot26_248.ecw', 'orthospot26_248.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14496, 824, 126, '0', '/landmap/mosaics/spot/orthospot28_246.ecw', 'orthospot28_246.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14497, 824, 127, '0', '/landmap/mosaics/spot/orthospot28_247.ecw', 'orthospot28_247.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14498, 824, 128, '0', '/landmap/mosaics/spot/orthospot29_239.ecw', 'orthospot29_239.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14499, 824, 129, '0', '/landmap/mosaics/spot/orthospot29_240.ecw', 'orthospot29_240.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14500, 824, 130, '0', '/landmap/mosaics/spot/orthospot29_241.ecw', 'orthospot29_241.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14501, 824, 131, '0', '/landmap/mosaics/spot/orthospot29_242.ecw', 'orthospot29_242.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14502, 824, 132, '0', '/landmap/mosaics/spot/orthospot29_243.ecw', 'orthospot29_243.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14503, 824, 133, '0', '/landmap/mosaics/spot/orthospot29_244.ecw', 'orthospot29_244.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14504, 824, 134, '0', '/landmap/mosaics/spot/orthospot29_245.ecw', 'orthospot29_245.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14505, 824, 135, '0', '/landmap/mosaics/spot/orthospot30_242.ecw', 'orthospot30_242.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14506, 824, 136, '0', '/landmap/mosaics/spot/orthospot30_243.ecw', 'orthospot30_243.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14507, 824, 137, '0', '/landmap/mosaics/spot/orthospot30_245.ecw', 'orthospot30_245.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14508, 824, 138, '0', '/landmap/mosaics/spot/orthospot30_246.ecw', 'orthospot30_246.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14509, 824, 139, '0', '/landmap/mosaics/spot/orthospot30_247.ecw', 'orthospot30_247.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14510, 824, 140, '0', '/landmap/mosaics/spot/orthospot32_246.ecw', 'orthospot32_246.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14511, 824, 141, '0', '/landmap/mosaics/spot/orthospot32_247.ecw', 'orthospot32_247.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14512, 824, 142, '0', '/landmap/mosaics/spot/orthospot33_243.ecw', 'orthospot33_243.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14513, 824, 143, '0', '/landmap/mosaics/spot/orthospot33_244.ecw', 'orthospot33_244.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14514, 824, 144, '0', '/landmap/mosaics/spot/orthospot33_245.ecw', 'orthospot33_245.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14515, 824, 145, '0', '/landmap/mosaics/spot/orthospot34_243.ecw', 'orthospot34_243.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14516, 824, 146, '0', '/landmap/mosaics/spot/orthospot34_244.ecw', 'orthospot34_244.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14517, 824, 147, '0', '/landmap/mosaics/spot/orthospot34_245.ecw', 'orthospot34_245.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14518, 824, 148, '0', '/landmap/mosaics/spot/orthospot34_246.ecw', 'orthospot34_246.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14519, 824, 149, '0', '/landmap/mosaics/spot/orthospot34_247.ecw', 'orthospot34_247.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14520, 824, 150, '0', '/landmap/orthospot/UK_Orthospot/mosaics.ecw', 'mosaics.ecw', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14525, 827, 0, '', '', 'Test Imagery', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14526, 827, 1, '0', 'dlwc_landsat_2000_mosaic', 'NSW Landsat 2000 Mosaic', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14527, 828, 0, '', '', 'IDERIOJA', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14528, 828, 1, '0', 'ortofoto', 'Ortofoto', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14529, 828, 2, '0', 'Cuadricula', 'Cuadricula 5k', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14530, 828, 3, '0', 'Nucleos', 'Nucleos Urbanos', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14531, 828, 4, '0', 'Rios', 'Rios', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14532, 828, 5, '0', 'municipios', 'Terminos Municipales', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14533, 828, 6, '0', 'Carreteras', 'Carreteras', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14534, 829, 0, '', '', 'at_etm7_lambert', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14535, 829, 1, '0', '0', 'etm7_lambert', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14550, 831, 0, '', 'DELI', 'MNDNR Data Deli WMS Server', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14551, 831, 1, '0', 'L380000020906', '1:100k Digital Raster Graphic - Collars Removed', 0, 0, 125000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14552, 831, 2, '0', 'L380000030906', '1:24k Digital Raster Graphic - Collars Removed', 0, 0, 30000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14553, 831, 3, '0', 'L380000010906', '1:250k Digital Raster Graphic - Collars Removed', 0, 0, 499999, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14554, 831, 4, '0', 'L390002440906', 'GAP Land Cover - Image', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14555, 831, 5, '0', 'L390002400906', 'Public Waters Inventory Maps', 0, 0, 100000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14556, 831, 6, '0', 'L370000050906', 'USGS Digital Orthophoto Quad (DOQ) - 3 meter', 0, 0, 100000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14557, 832, 0, '', '', 'ArcIMS MapService', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14558, 832, 1, '0', 'overview', 'Wetland Overview', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14559, 832, 2, '0', 'wetlands_low', 'Wetlands Low Res', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14560, 832, 3, '0', 'wetlands', 'Wetlands High Res', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14561, 833, 0, '', '', 'encdirect', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14562, 833, 1, '0', '4', 'ENCNAMES_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14563, 833, 2, '0', 'LAND', 'LAND', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14564, 833, 3, '0', 'QUALITY OF DATA(M_QUAL)', 'QUALITY OF DATA', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14565, 833, 4, '0', 'NAVIGATIONAL SYSTEM OF MARKS(M_NSYS)', 'NAVIGATIONAL SYSTEM OF MARKS', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14566, 833, 5, '0', 'HORIZONTAL DATUM OF DATA(M_SDAT)', 'HORIZONTAL DATUM OF DATA', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14567, 833, 6, '0', 'NAUTICAL PUBLICATION INFORMATION(M_NPUB)', 'NAUTICAL PUBLICATION INFORMATION', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14568, 833, 7, '0', 'COMPLIATION OF SCALE DATA(M_CSCL)', 'COMPLIATION OF SCALE DATA', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14569, 833, 8, '0', 'COVERAGE(M_COVR)', 'COVERAGE', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14570, 833, 9, '0', 'ACCURACY(M_ACCY)', 'ACCURACY', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14571, 833, 10, '0', 'LAND AREA(LNDARE)', 'LAND AREA_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14572, 833, 11, '0', 'DEPTH AREA(DEPARE)', 'DEPTH AREA_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14573, 833, 12, '0', 'ICE AREA(ICEARE)', 'ICE AREA', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14574, 833, 13, '0', 'HARBOR FACILITY_POLYGON(HRBFAC)', 'HARBOR FACILITY_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14575, 833, 14, '0', 'SEA AREA(SEAARE)', 'SEA AREA_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14576, 833, 15, '0', 'PYLONS_polygon(PYLONS)', 'PYLONS_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14577, 833, 16, '0', 'SEABED AREA_polygon(SBDARE)', 'SEABED AREA_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14578, 833, 17, '0', 'PONTOON(PONTON)', 'PONTOON_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14579, 833, 18, '0', 'WEED, KELP(WEDKLP)', 'WEED, KELP_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14580, 833, 19, '0', 'OFFSHORE PRODUCTION AREA(OSPARE)', 'OFFSHORE PRODUCTION AREA', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14581, 833, 20, '0', 'VEGATATION(VEGATN)', 'VEGATATION_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14582, 833, 21, '0', 'TWO_WAY ROUTE PART(TWRTPT)', 'TWO_WAY ROUTE PART', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14583, 833, 22, '0', 'SWEPTH AREA(SWPARE)', 'SWEPTH AREA', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14584, 833, 23, '0', 'SEA PLANE LANDING AREA(SLPARE)', 'SEA PLANE LANDING AREA_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14585, 833, 24, '0', 'WATER TURBULENCE(WATTUR)', 'WATER TURBULENCE_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14586, 833, 25, '0', 'SLOPING GROUND(SLOGRD)', 'SLOPING GROUND_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14587, 833, 26, '0', 'PRODUCTION AREA(PRDARE)', 'PRODUCTION AREA_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14588, 833, 27, '0', 'RUNWAY(RUNWAY)', 'RUNWAY_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14589, 833, 28, '0', 'RECOMMENDED TRACK(RECTRC)', 'RECOMMENDED TRACK_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14590, 833, 29, '0', 'RAPIDS(RAPIDS)', 'RAPIDS_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14591, 833, 30, '0', 'MILITARY PRACTICE AREA(MIPARE)', 'MILITARY PRACTICE AREA_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14592, 833, 31, '0', 'PRECAUTIONARY AREA_polygon(PRCARE)', 'PRECAUTIONARY AREA_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14593, 833, 32, '0', 'PILOT BOARDING AREA(PILBOP)', 'PILOT BOARDING AREA_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14594, 833, 33, '0', 'OFFSHORE PLATFORM(OFSPLF)', 'OFFSHORE PLATFORM_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14595, 833, 34, '0', 'LOCAL MAGNETIC ANOMALY(LOCMAG)', 'LOCAL MAGNETIC ANOMALY_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14596, 833, 35, '0', 'LOCK BASIN(LOKBSN)', 'LOCK BASIN', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14597, 833, 36, '0', 'MOORING FACILITY(MORFAC)', 'MOORING FACILITY_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14598, 833, 37, '0', 'GATE(GATCON)', 'GATE_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14599, 833, 38, '0', 'HARBOR AREA(HRBARE)', 'HARBOR AREA', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14600, 833, 39, '0', 'GRIDIRON(GRIDRN)', 'GRIDIRON_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14601, 833, 40, '0', 'LOG POND(LOGPON)', 'LOG POND_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14602, 833, 41, '0', 'LANDMARK(LNDMRK)', 'LANDMARK_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14603, 833, 42, '0', 'FERRY ROUTE(FERYRT)', 'FERRY ROUTE_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14604, 833, 43, '0', 'HULK_polygon(HULKES)', 'HULK_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14605, 833, 44, '0', 'FISH FACILITY(FSHFAC)', 'FISH FACILITY_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14606, 833, 45, '0', 'FLOATING DOCK_polygon(FLODOC)', 'FLOATING DOCK_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14607, 833, 46, '0', 'RIVERS(RIVERS)', 'RIVERS_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14608, 833, 47, '0', 'UNSURVEYED AREA(UNSARE)', 'UNSURVEYED AREA', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14609, 833, 48, '0', 'LAKE(LAKARE)', 'LAKE', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14610, 833, 49, '0', 'SHORELINE CONSTRUCTION(SLCONS)', 'SHORELINE CONSTRUCTION_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14611, 833, 50, '0', 'TRAFFIC SEPARATION ZONE(TSEZNE)', 'TRAFFIC SEPARATION ZONE', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14612, 833, 51, '0', 'OBSTRUCTION(OBSTRN)', 'OBSTRUCTION_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14613, 833, 52, '0', 'TRAFFIC SEPARATION SCHEME LANE PART(TSSLPT)', 'TRAFFIC SEPARATION SCHEME LANE PART', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14614, 833, 53, '0', 'LAND REGION(LNDRGN)', 'LAND REGION_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14615, 833, 54, '0', 'WRECKS_polygon(WRECKS)', 'WRECKS_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14616, 833, 55, '0', 'MARINE FARM, CULTURE(MARCUL)', 'MARINE FARM, CULTURE_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14617, 833, 56, '0', 'INSHORE TRAFFIC ZONE(ISTZNE)', 'INSHORE TRAFFIC ZONE', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14618, 833, 57, '0', 'DEEP WATER ROUTE PART(DWRTPT)', 'DEEP WATER ROUTE PART', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14619, 833, 58, '0', 'DREDGED AREA(DRGARE)', 'DREDGED AREA', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14620, 833, 59, '0', 'DUMPING GROUND(DMPGRD)', 'DUMPING GROUND_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14621, 833, 60, '0', 'FAIRWAY_polygon(FAIRWY)', 'FAIRWAY', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14622, 833, 61, '0', 'ANCHOR BERTH(ACHBRT)', 'ANCHOR BERTH_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14623, 833, 62, '0', 'DRY DOCK(DRYDOC)', 'DRY DOCK', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14624, 833, 63, '0', 'RESTRICTED AREA(RESARE)', 'RESTRICTED AREA', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14625, 833, 64, '0', 'DOCK AREA(DOCARE)', 'DOCK AREA', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14626, 833, 65, '0', 'DIKE(DYKON)', 'DIKE_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14627, 833, 66, '0', 'BERTHS(BERTHS)', 'BERTHS_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14628, 833, 67, '0', 'DAM(DAMCON)', 'DAM_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14629, 833, 68, '0', 'ANCHORAGE AREA(ACHARE)', 'ANCHORAGE AREA_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14630, 833, 69, '0', 'CANALS(CANALS)', 'CANALS_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14631, 833, 70, '0', 'CAUSEWAY(CAUSWY)', 'CAUSEWAY_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14632, 833, 71, '0', 'CABLE AREA(CBLARE)', 'CABLE AREA', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14633, 833, 72, '0', 'BUILT-UP AREA(BUAARE)', 'BUILT-UP AREA_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14634, 833, 73, '0', 'SILO, TANK(SILTNK)', 'SILO, TANK_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14635, 833, 74, '0', 'FORTIFIED STRUCTURE(FORSTC)', 'FORTIFIED STRUCTURE_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14636, 833, 75, '0', 'TUNNEL(TUNNEL)', 'TUNNEL_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14637, 833, 76, '0', 'CONVEYOR(CONVYR)', 'CONVEYOR_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14638, 833, 77, '0', 'BUILDING(BUISGL)', 'BUILDING_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14639, 833, 78, '0', 'CRANES(CRANES)', 'CRANES_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14640, 833, 79, '0', 'ADMINISTRATION AREA_polygon(ADMARE)', 'ADMINISTRATION AREA', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14641, 833, 80, '0', 'AIRARE(AIRARE)', 'AIRPORT_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14642, 833, 81, '0', 'TRAFFIC SEPARATION SCHEME BOUNDARY(TSSBND)', 'TRAFFIC SEPARATION SCHEME BOUNDARY', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14643, 833, 82, '0', 'CAUTION AREA(CTNARE)', 'CAUTION AREA_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14644, 833, 83, '0', 'BRIDGE_polygon(BRIDGE)', 'BRIDGE_polygon', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14645, 833, 84, '0', 'SLOPE_TOPLINE(SLOTOP', 'SLOPE TOPLINE', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14646, 833, 85, '0', 'WATER FALL_line(WATFAL)', 'WATER FALL_line', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14647, 833, 86, '0', 'SHORELINE CONSTRUCTION_line(SLCONS)', 'SHORELINE CONSTRUCTION_line', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14648, 833, 87, '0', 'RIVERS_line(RIVERS)', 'RIVERS_line', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14649, 833, 88, '0', 'SUBMARINE_ON LAND PIPELINE_line(PIPSOL)', 'SUBMARINE_ON LAND PIPELINE_line', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14650, 833, 89, '0', 'OVERHEAD PIPELINE(PIPOHD)', 'OVERHEAD PIPELINE', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14651, 833, 90, '0', 'OBSTRUCTION_line(OBSTRN)', 'OBSTRUCTION_line', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14652, 833, 91, '0', 'NAVIGATION LINE(NAVLNE)', 'NAVIGATION LINE', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14653, 833, 92, '0', 'LAND ELEVATION_line(LNDELV)', 'LAND ELEVATION_line', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14654, 833, 93, '0', 'ROAD_line(ROADWY)', 'ROAD_line', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14655, 833, 94, '0', 'FENCE LINE_line(FNCLNE)', 'FENCE LINE', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14656, 833, 95, '0', 'OIL BARRIER_line(OILBAR)', 'OIL BARRIER', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14657, 833, 96, '0', 'FERRY ROUTE_line(FERYRT)', 'FERRY ROUTE_line', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14658, 833, 97, '0', 'DIKE_line(DYKCON)', 'DIKE_line', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14659, 833, 98, '0', 'SAND WAVES_line(SNDWAV)', 'SAND WAVES_line', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14660, 833, 99, '0', 'RECOMMENDED TRACK_line(RECTRC)', 'RECOMMENDED TRACK_line', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14661, 833, 100, '0', 'DEPTH AREA_line(DEPARE)', 'DEPTH AREA_line', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14662, 833, 101, '0', '1', 'WATER TURBULENCE_line', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14663, 833, 102, '0', 'DEPTH CONTOUR(DEPCNT)', 'DEPTH CONTOUR', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14664, 833, 103, '0', 'CONVEYOR_line(CONVYR)', 'CONVEYOR_line', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14665, 833, 104, '0', 'DAM_line(DAMCON)', 'DAM_line', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14666, 833, 105, '0', 'COASTLINE(COALNE)', 'COASTLINE', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14667, 833, 106, '0', 'LAND AREA_line(LNDAARE)', 'LAND AREA_line', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14668, 833, 107, '0', 'FISH FACILITY_line(FSHFAC)', 'FISH FACILITY_line', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14669, 833, 108, '0', 'MOORING FACILITY_line(MORFAC)', 'MOORING FACILITY_line', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14670, 833, 109, '0', 'GATE_line(GATCON)', 'GATE_line', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14671, 833, 110, '0', 'TUNNEL_line(TUNNEL)', 'TUNNEL_line', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14672, 833, 111, '0', 'SUBMARINE CABLE(CLBSUB)', 'SUBMARINE CABLE', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14673, 833, 112, '0', 'SLOPE TOPLINE_line(SLOTOP)', 'SLOPE TOPLINE_line', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14674, 833, 113, '0', 'RAILWAY_line(RAILWY)', 'RAILWAY', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14675, 833, 114, '0', 'TRAFFIC SEPARATION LINE(TSELNE)', 'TRAFFIC SEPARATION LINE', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14676, 833, 115, '0', 'VEGATATION_line(VEGATN)', 'VEGATATION_line', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14677, 833, 116, '0', 'OVERHEAD CABLE(CBLOHD)', 'OVERHEAD CABLE', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14678, 833, 117, '0', 'PONTOON_line(PONTON)', 'PONTOON_line', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14679, 833, 118, '0', 'CANALS_line(CANALS)', 'CANALS_line', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14680, 833, 119, '0', 'RECOMMENDED ROUTE CENTERLINE_line(RCRTCL)', 'RECOMMENDED ROUTE CENTERLINE_line', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14681, 833, 120, '0', 'BRIDGE_line(BRIDGE)', 'BRIDGE_line', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14682, 833, 121, '0', 'WRECKS_point(WRECKS)', 'WRECKS_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14683, 833, 122, '0', 'WEED, KELP_point(WEDKLP)', 'WEED, KELP_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14684, 833, 123, '0', 'WATER TURBULENCE_point(WATTUR)', 'WATER TURBULENCE_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14685, 833, 124, '0', 'ROCK AWASH, UNDERWATER_POINT(UWTROC)', 'ROCK AWASH, UNDERWATER', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14686, 833, 125, '0', 'TOPMARK_point(TOPMAR)', 'TOPMARK', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14687, 833, 126, '0', 'SHORELINE CONSTRUCTION_point(SLCONS)', 'SHORELINE CONSTRUCTION_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14688, 833, 127, '0', 'SILO, TANK_point(SILTNK)', 'SILO, TANK_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14689, 833, 128, '0', 'SEA AREA_point(SEAARE)', 'SEA AREA_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14690, 833, 129, '0', 'SEABED AREA_point(SBDARE)', 'SEABED AREA_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14691, 833, 130, '0', 'RADAR TRANSPONDER BEACON_POINT(RTPBCN)', 'RADAR TRANSPONDER BEACON', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14692, 833, 131, '0', 'RESCUE STATION_POINT(RCSTA)', 'RESCUE STATION', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14693, 833, 132, '0', 'PYLONS_point(PYLONS)', 'PYLONS_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14694, 833, 133, '0', 'PILE_point(PILPNT)', 'PILE', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14695, 833, 134, '0', 'OFFSHORE PLATFORM_point(OFSPLF_point)', 'OFFSHORE PLATFORM_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14696, 833, 135, '0', 'MOORING FACILITY_point(MORFAC_point)', 'MOORING FACILITY_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14697, 833, 136, '0', 'LAND REGION_point(LNDRGN_point)', 'LAND REGION_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14698, 833, 137, '0', 'LANDMARK_point(LNDMARK)', 'LANDMARK_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14699, 833, 138, '0', 'LAND AREA_point(LNDARE)', 'LAND AREA_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14700, 833, 139, '0', 'FOGSIG_point(FOGSIG)', 'FOG SIGNAL', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14701, 833, 140, '0', 'DAYMARK_point(DAYMAR)', 'DAYMARK', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14702, 833, 141, '0', 'CAUTION AREA_point(CNTARE)', 'CAUTION AREA_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14703, 833, 142, '0', 'COASTGUARD STATION_point(CGUSTA)', 'COASTGUARD STATION', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14704, 833, 143, '0', 'BUILDING_point(BUISGL)', 'BUILDING_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14705, 833, 144, '0', 'BUILT-UP AREA_point(BUAARE)', 'BUILT-UP AREA_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14706, 833, 145, '0', 'INSTALLATION(BOYINB)', 'INSTALLATION BUOY', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14707, 833, 146, '0', 'SPECIAL PURPOSE BUOY_point(BOYSPP)', 'SPECIAL PURPOSE BUOY', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14708, 833, 147, '0', 'SAFE WATER BUOY(BOYSAW)', 'SAFE WATER BUOY', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14709, 833, 148, '0', 'LATERAL BUOY_point(BOYLAT)', 'LATERAL BUOY', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14710, 833, 149, '0', 'SPECIAL PURPOSE BEACON_point(BCNSPP)', 'SPECIAL PURPOSE BEACON', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14711, 833, 150, '0', 'SAFE WATER BEACON_point(BCNSAW)', 'SAFE WATER BEACON', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14712, 833, 151, '0', 'LATERAL BEACON_point(BCNLAT)', 'LATERAL BEACON', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14713, 833, 152, '0', 'LAND ELEVATION_point(LNDELV)', 'LAND ELEVATION_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14714, 833, 153, '0', 'ANCHOR BERTH_point(ACHBRT)', 'ANCHOR BERTH_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14715, 833, 154, '0', 'ANCHORAGE AREA_point(ANCARE)', 'ANCHORAGE AREA_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14716, 833, 155, '0', 'AIRPORT_point(AIRARE)', 'AIRPORT_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14717, 833, 156, '0', 'ISOLATED DANGER BEACON(BCNISD)', 'ISOLATED DANGER BEACON', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14718, 833, 157, '0', 'BERTHS_point(BERTHS)', 'BERTHS_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14719, 833, 158, '0', 'CARDINAL BUOY_point(BOYCAR)', 'CARDINAL BUOY', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14720, 833, 159, '0', 'ISOLATED DANGER BUOY_point(BOYISD)', 'ISOLATED DANGER BUOY', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14721, 833, 160, '0', 'CRANES_point(CRANES)', 'CRANES_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14722, 833, 161, '0', 'CONTROL POINT(CTRPNT)', 'CONTROL POINT', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14723, 833, 162, '0', 'CURRENT_point(CURENT)', 'CURRENT', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14724, 833, 163, '0', 'DAM_point(DAMCON)', 'DAM_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14725, 833, 164, '0', 'DISTANCE MARK_point(DISMAR)', 'DISTANCE MARK', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14726, 833, 165, '0', 'DUMPING GROUND_point(DMPGRD)', 'DUMPING GROUND_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14727, 833, 166, '0', 'FORTIFIED STRUCTURE_point(FORSTC)', 'FORTIFIED STRUCTURE_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14728, 833, 167, '0', 'FISH FACILITY_point(FSHFAC)', 'FISH FACILITY_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14729, 833, 168, '0', 'GATE_point(GATCON)', 'GATE_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14730, 833, 169, '0', 'HARBOR FACILITY_point(HRBFAC)', 'HARBOR FACILITY_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14731, 833, 170, '0', 'LOCAL MAGNETIC ANOMALY_point(LOCMAG)', 'LOCAL MAGNETIC ANOMALY_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14732, 833, 171, '0', 'LOG POND_point(LOGPON)', 'LOG POND_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14733, 833, 172, '0', 'MAGNETIC VARIATION_point(MAGVAR)', 'MAGNETIC VARIATION_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14734, 833, 173, '0', 'PILOT BOARDING POINT_point(PILBOP)', 'PILOT BOARDING POINT_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14735, 833, 174, '0', 'SUBMARINE_ON LAND PIPELINE_point(PISOL)', 'SUBMARINE_ON LAND PIPELINE_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14736, 833, 175, '0', 'PRODUCTION AREA_point(PRDARE)', 'PRODUCTION AREA_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14737, 833, 176, '0', 'RADIO CALLING IN POINT_point(RDOCAL)', 'RADIO CALLING IN POINT_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14738, 833, 177, '0', 'RETRO REFLECTOR_point(RETRFL)', 'RETRO REFLECTOR', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14739, 833, 178, '0', 'WARNING SIGNAL STATION_point(SISTAW)', 'WARNING SIGNAL STATION', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14740, 833, 179, '0', 'TRAFFIC SIGNAL STATION_point(SISTAT)', 'TRAFFIC SIGNAL STATION', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14741, 833, 180, '0', 'SLOPING GROUND_point(SLOGRD)', 'SLOPING GROUND_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14742, 833, 181, '0', 'SMALL CRAFT FACILITY_point(SMCFAC)', 'SMALL CRAFT FACILITY_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14743, 833, 182, '0', 'SAND WAVES_point(SNDWAV)', 'SAND WAVES_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14744, 833, 183, '0', 'SEA PLANE LANDING AREA_point(SPLARE)', 'SEA PLANE LANDING AREA_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14745, 833, 184, '0', 'SPRING_point(SPRING)', 'SPRING', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14746, 833, 185, '0', 'TIDAL STREAM_point(TS_FEB)', 'TIDAL STREAM_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14747, 833, 186, '0', 'SEABED AREA_line(SBDARE)', 'SEABED AREA_line', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14748, 833, 187, '0', 'TUNNEL_point(TUNNEL)', 'TUNNEL_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14749, 833, 188, '0', 'VEGATATION_point(VEGATN)', 'VEGATATION_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14750, 833, 189, '0', 'WATER FALL', 'WATER FALL_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14751, 833, 190, '0', 'RADIO STATION(RDOSTA)', 'RADIO STATION', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14752, 833, 191, '0', 'OBSTRUCTION_point(OBSTRN)', 'OBSTRUCTION_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14753, 833, 192, '0', 'LIGHTS_point(LIGHTS)', 'LIGHTS', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14754, 833, 193, '0', 'LIGHT FLOAT_point(LITFLT)', 'LIGHT FLOAT', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14755, 833, 194, '0', 'HULK_point(HULKES)', 'HULKES_point', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14756, 833, 195, '0', 'SOUNDINGS', 'SOUNDINGS', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14757, 833, 196, '0', '0', 'ENC INDEX', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14758, 834, 0, '', '', 'DE_aerial02', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14759, 834, 1, '0', 'ortho2002', '2002 Aerial Imagery', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14760, 835, 0, '', 'Tsunami_Disaster_Map', 'Tsunami_Diasaster_Data', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14761, 835, 1, '0', 'Satellite_Imagery', 'Satellite_Imagery', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14762, 835, 2, '1', 'GAEL_WORLD_MARCH', 'ENVISAT MERIS mosaic', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14763, 835, 3, '1', 'srtm_tiles', 'SRTM 90m DEM - unclassified', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14764, 835, 4, '1', 'thai-LandsatTrue', 'Landsat Mosaic of Thailand', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14765, 835, 5, '1', 'sri_landsat', 'Landsat Mosaic of Sri Lanka', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14766, 835, 6, '0', 'Physical_Geography', 'Physical_Geography', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14767, 835, 7, '6', 'GTOPO30:Foundation', 'Global 30 Second Elevations', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14768, 835, 8, '6', 'RELIEF:Foundation', 'Two Minute Shaded Relief', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14769, 835, 9, '6', 'Bathymetry', 'Bathymetry', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14770, 835, 10, '6', 'Topography', 'Topography', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14771, 835, 11, '6', 'Hillshading', 'Hillshading', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14772, 835, 12, '6', 'CONTOURL_ELEV_1M:Foundation', 'Elevation Contours', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14773, 835, 13, '0', 'Disaster_Info', 'Disaster_Info', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14774, 835, 14, '13', 'locations', 'Disaster Point Locations', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14775, 835, 15, '13', 'faults', 'Fault Lines', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14776, 835, 16, '13', 'Wave_Heights', 'Wave Heights', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14777, 835, 17, '13', 'earthquakes', 'Recent Earthquakes', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14778, 835, 18, '13', 'epicenter', 'Epicenter of the Earthquake', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14779, 835, 19, '0', 'Political', 'Political', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14780, 835, 20, '19', 'World_WMS-WorldGen', 'World Countries', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14781, 835, 21, '19', 'Coastlines', 'Coastlines', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14782, 835, 22, '19', 'Borders', 'Borders', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14783, 835, 23, '19', 'oceans', 'World Oceans Labels', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14784, 835, 24, '19', 'Cities', 'World Cities', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14785, 835, 25, '0', 'Affected_Country_Statistics', 'Affected_Country_Statistics', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14786, 835, 26, '25', 'gdp', 'Gross Domestic Product (GDP)', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14787, 835, 27, '25', 'gdpper', 'Gross Domestic Product (GDP) per capita', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14788, 835, 28, '25', 'extdebt', 'External Debt', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14789, 835, 29, '25', 'density', 'Population Density (per sq. km)', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14790, 835, 30, '25', 'population', '2004 Population', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14791, 835, 31, '25', 'deaths', 'Total Deaths Per Country', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14792, 835, 32, '25', 'SriLanka_deaths', 'Sri Lanka Total Deaths by Region', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14793, 835, 33, '25', 'SriLanka_injured', 'Sri Lanka Total injuries by Region', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14794, 835, 34, '25', 'SriLanka_missing', 'Sri Lanka Total missing persons by Region', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14795, 835, 35, '25', 'SriLanka_displaced', 'Sri Lanka Total Displaced Population by Region', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14796, 835, 36, '25', 'SriLanka_camps', 'Sri Lanka Total camps by Region', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14797, 835, 37, '0', 'Infrastructure', 'Infrastructure', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14798, 835, 38, '37', 'BUILTUPA_POP_1M:Foundation', 'Built-Up Areas', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14799, 835, 39, '37', 'ROADL_TRANS_1M:Foundation', 'Roads', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14800, 836, 0, '', '', 'NDOP', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14801, 836, 1, '0', 'States', 'State Boundaries', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14802, 836, 2, '0', 'Projects', 'NDOP Projects', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14803, 837, 0, '', '', 'U.S. Geological Survey', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14804, 837, 1, '0', 'DOQ', 'USGS Digital Ortho-Quadrangles', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14805, 837, 2, '0', 'DRG', 'USGS Raster Graphics (Topo Maps)', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14806, 837, 3, '0', 'UrbanArea', 'USGS Urban Areas Ortho-Imagery', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14842, 840, 0, '', '', 'World', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14843, 840, 1, '0', 'GLOBEImage', 'GlobeImage', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14844, 840, 2, '0', 'ADMIN', 'Admin', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14845, 840, 3, '0', 'COUNTRY', ' Country', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14846, 840, 4, '0', 'Lakes', ' Lakes', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14847, 840, 5, '0', 'RAILWAY', ' Railway', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14848, 840, 6, '0', 'WorldGridLines', ' World Grid Lines', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14849, 840, 7, '0', 'OCEAN_TEXT', ' Ocean Label', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14850, 840, 8, '0', 'CAPITALS', ' Capitals', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14851, 841, 0, '', 'ICEDSWMS', 'ICEDS (Integrated CEOS European Data Server) WMS', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14852, 841, 1, '0', 'GRID', 'MAPDRESSING GRID', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14853, 841, 2, '0', 'lights', 'DMSP/NOAA human settlements night lights of the wo', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14854, 841, 3, '2', 'lights_1', 'DMSP/NOAA human settlements night lights (300 arcs', 0, 44999930, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14855, 841, 4, '2', 'lights_2', 'DMSP/NOAA human settlements night lights (30 arcse', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14856, 841, 5, '0', 'landsat5', 'LANDSAT 5 mosaic for Africa and Europe', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14857, 841, 6, '5', 'landsat_1', 'LANDSAT 5 mosaic for Africa and Europe (100 arscse', 0, 9000006, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14858, 841, 7, '5', 'landsat_2', 'LANDSAT 5 mosaic for Africa and Europe (10 arscsec', 0, 3000002, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14859, 841, 8, '5', 'landsat_3', 'LANDSAT 5 mosaic for Africa and Europe (1 arscsec.', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14860, 841, 9, '0', 'srtm', 'Hillshaded SRTM3 mosaic', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14861, 841, 10, '9', 'srtm3_1', 'Hillshaded SRTM3 mosaic (180 arscsec. level)', 0, 20000000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14862, 841, 11, '9', 'srtm3_2', 'Hillshaded SRTM3 mosaic (30 arscsec. level)', 0, 1700000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14863, 841, 12, '9', 'srtm3_3', 'Hillshaded SRTM3 mosaic (3 arscsec. level)', 0, 0, 1700000, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14864, 841, 13, '0', 'srtm30', 'Hillshaded SRTM30 mosaic', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14865, 841, 14, '13', 'srtm30_1', 'Hillshaded SRTM30 mosaic (300 arscsec. level)', 0, 20000000, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14866, 841, 15, '13', 'srtm30_2', 'Hillshaded SRTM30 mosaic (30 arscsec. level)', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14867, 841, 16, '0', 'bluemarble', 'Global MODIS Blue Marble', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14868, 841, 17, '16', 'bluemarble_1', 'Global MODIS Blue Marble (300 arcsec. level)', 0, 11999988, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14869, 841, 18, '16', 'bluemarble_2', 'Global MODIS Blue Marble (30 arcsec. level)', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14870, 841, 19, '0', 'globe', 'Cascaded data from GLOBE', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14871, 841, 20, '19', 'rivers', 'Cascaded Rivers from GLOBE', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14872, 841, 21, '19', 'coastlines', 'Cascaded Coastlines from GLOBE', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14873, 841, 22, '0', 'demis', 'Cascaded data from Demis', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14874, 841, 23, '22', 'bathymetry', 'Cascaded Bathymetry from Demis', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14875, 841, 24, '0', 'onearth', 'Cascaded data from OnEarth', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14876, 841, 25, '24', 'landsat7', 'Cascaded Landsat7 from OnEarth', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14877, 841, 26, '24', 'terra', 'Cascaded daily MODIS Terra from OnEarth', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14878, 841, 27, '24', 'aqua', 'Cascaded daily MODIS Aqua from OnEarth', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14879, 841, 28, '0', 'metarweather', 'Cascaded World Hourly METAR Weather Reports from C', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14880, 841, 29, '0', 'noaa', 'Cascaded NOAA World Natural Hazards data', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14881, 841, 30, '29', 'earthquakes', 'Cascaded NOAA Significant Earthquakes', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14882, 841, 31, '29', 'tsunamievents', 'Cascaded NOAA Tsunami Events', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14883, 841, 32, '29', 'volcanoes', 'Cascaded NOAA Volcanoes', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14884, 841, 33, '29', 'plateboundaries', 'Cascaded NOAA Plate Boundaries', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14885, 841, 34, '29', 'countries', 'Cascaded NOAA Countries', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14886, 841, 35, '29', 'cities', 'Cascaded NOAA Cities', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14887, 841, 36, '0', 'sigafrique', 'Cascaded SIGAFRIQUE data', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14888, 841, 37, '36', 'geofault10', 'Cascaded geologic faults 10 m', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14889, 841, 38, '36', 'geoform10', 'Cascaded geologic formations 10 m', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14890, 841, 39, '36', 'towns', 'Cascaded towns', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14891, 841, 40, '36', 'mainrivers', 'Cascaded main water courses and inland water bodie', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14892, 841, 41, '36', 'water', 'Cascaded water courses', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14893, 841, 42, '36', 'railway', 'Cascaded railway network', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14894, 842, 0, '', 'Tsunami_Disaster_Map', 'Tsunami_Diasaster_Data', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14895, 842, 1, '0', 'Satellite_Imagery', 'Satellite_Imagery', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14896, 842, 2, '1', 'GAEL_WORLD_MARCH', 'ENVISAT MERIS mosaic', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14897, 842, 3, '1', 'srtm_tiles', 'SRTM 90m DEM - unclassified', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14898, 842, 4, '1', 'thai-LandsatTrue', 'Landsat Mosaic of Thailand', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14899, 842, 5, '1', 'sri_landsat', 'Landsat Mosaic of Sri Lanka', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14900, 842, 6, '0', 'Physical_Geography', 'Physical_Geography', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14901, 842, 7, '6', 'GTOPO30:Foundation', 'Global 30 Second Elevations', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14902, 842, 8, '6', 'RELIEF:Foundation', 'Two Minute Shaded Relief', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14903, 842, 9, '6', 'Bathymetry', 'Bathymetry', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14904, 842, 10, '6', 'Topography', 'Topography', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14905, 842, 11, '6', 'Hillshading', 'Hillshading', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14906, 842, 12, '6', 'CONTOURL_ELEV_1M:Foundation', 'Elevation Contours', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14907, 842, 13, '0', 'Disaster_Info', 'Disaster_Info', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14908, 842, 14, '13', 'locations', 'Disaster Point Locations', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14909, 842, 15, '13', 'faults', 'Fault Lines', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14910, 842, 16, '13', 'Wave_Heights', 'Wave Heights', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14911, 842, 17, '13', 'earthquakes', 'Recent Earthquakes', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14912, 842, 18, '13', 'epicenter', 'Epicenter of the Earthquake', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14913, 842, 19, '0', 'Political', 'Political', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14914, 842, 20, '19', 'World_WMS-WorldGen', 'World Countries', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14915, 842, 21, '19', 'Coastlines', 'Coastlines', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14916, 842, 22, '19', 'Borders', 'Borders', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14917, 842, 23, '19', 'oceans', 'World Oceans Labels', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14918, 842, 24, '19', 'Cities', 'World Cities', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14919, 842, 25, '0', 'Affected_Country_Statistics', 'Affected_Country_Statistics', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14920, 842, 26, '25', 'gdp', 'Gross Domestic Product (GDP)', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14921, 842, 27, '25', 'gdpper', 'Gross Domestic Product (GDP) per capita', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14922, 842, 28, '25', 'extdebt', 'External Debt', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14923, 842, 29, '25', 'density', 'Population Density (per sq. km)', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14924, 842, 30, '25', 'population', '2004 Population', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14925, 842, 31, '25', 'deaths', 'Total Deaths Per Country', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14926, 842, 32, '25', 'SriLanka_deaths', 'Sri Lanka Total Deaths by Region', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14927, 842, 33, '25', 'SriLanka_injured', 'Sri Lanka Total injuries by Region', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14928, 842, 34, '25', 'SriLanka_missing', 'Sri Lanka Total missing persons by Region', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14929, 842, 35, '25', 'SriLanka_displaced', 'Sri Lanka Total Displaced Population by Region', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14930, 842, 36, '25', 'SriLanka_camps', 'Sri Lanka Total camps by Region', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14931, 842, 37, '0', 'Infrastructure', 'Infrastructure', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14932, 842, 38, '37', 'BUILTUPA_POP_1M:Foundation', 'Built-Up Areas', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14933, 842, 39, '37', 'ROADL_TRANS_1M:Foundation', 'Roads', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14934, 843, 0, '', '', 'hazards', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14935, 843, 1, '0', 'Ambient Population 2002 (per 30 arc seconds)', 'Ambient Population 2002 (per 30 arc seconds)', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14936, 843, 2, '0', 'Elevation/Bathymetry', 'Elevation/Bathymetry', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14937, 843, 3, '0', 'Continents', 'Continents', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14938, 843, 4, '0', 'Lakes', 'Lakes', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14939, 843, 5, '0', 'Rivers', 'Rivers', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14940, 843, 6, '0', 'Countries', 'Countries', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14941, 843, 7, '0', 'States', 'States', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14942, 843, 8, '0', 'Cities', 'Cities', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14943, 843, 9, '0', 'Plate Boundaries', 'Plate Boundaries', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14944, 843, 10, '0', 'Volcanoes', 'Volcanoes', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14945, 843, 11, '0', 'Tsunami Events with runups', 'Tsunami Events with runups', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14946, 843, 12, '0', 'Tsunami Events with slides', 'Tsunami Events with slides', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14947, 843, 13, '0', 'Tsunami Events', 'Tsunami Events', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14948, 843, 14, '0', 'Tsunami Runups', 'Tsunami Runups', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14949, 843, 15, '0', 'Significant Earthquakes with slides', 'Significant Earthquakes with slides', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14950, 843, 16, '0', 'Significant Earthquakes', 'Significant Earthquakes', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14951, 844, 0, '', '', 'CustomWeather Map Server', 0, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14952, 844, 1, '0', 'cite:BasicPolygons', 'cite:BasicPolygons', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14953, 844, 2, '0', 'cite:Bridges', 'cite:Bridges', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14954, 844, 3, '0', 'cite:BuildingCenters', 'cite:BuildingCenters', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14955, 844, 4, '0', 'cite:Buildings', 'cite:Buildings', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14956, 844, 5, '0', 'cite:DividedRoutes', 'cite:DividedRoutes', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14957, 844, 6, '0', 'cite:Forests', 'cite:Forests', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14958, 844, 7, '0', 'cite:Lakes', 'cite:Lakes', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14959, 844, 8, '0', 'cite:MapNeatline', 'cite:MapNeatline', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14960, 844, 9, '0', 'cite:NamedPlaces', 'cite:NamedPlaces', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14961, 844, 10, '0', 'cite:Ponds', 'cite:Ponds', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14962, 844, 11, '0', 'cite:RoadSegments', 'cite:RoadSegments', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14963, 844, 12, '0', 'cite:Streams', 'cite:Streams', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14964, 844, 13, '0', 'airport_delay', 'airport_delay', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14965, 844, 14, '0', 'anim', 'anim', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14966, 844, 15, '0', 'au_radar', 'au_radar', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14967, 844, 16, '0', 'au_radar_stations', 'au_radar_stations', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14968, 844, 17, '0', 'base', 'base', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14969, 844, 18, '0', 'borders', 'borders', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14970, 844, 19, '0', 'coasts', 'coasts', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14971, 844, 20, '0', 'conditions', 'conditions', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14972, 844, 21, '0', 'contour_fire_danger', 'contour_fire_danger', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14973, 844, 22, '0', 'contour_high', 'contour_high', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14974, 844, 23, '0', 'contour_jet_stream', 'contour_jet_stream', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14975, 844, 24, '0', 'contour_low', 'contour_low', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14976, 844, 25, '0', 'contour_precip', 'contour_precip', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14977, 844, 26, '0', 'contour_pressure', 'contour_pressure', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14978, 844, 27, '0', 'contour_syn_precip', 'contour_syn_precip', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14979, 844, 28, '0', 'conus_ir_satellite_4km', 'conus_ir_satellite_4km', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14980, 844, 29, '0', 'counties', 'counties', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14981, 844, 30, '0', 'earthquakes', 'earthquakes', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14982, 844, 31, '0', 'eqc', 'eqc', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14983, 844, 32, '0', 'forecasts', 'forecasts', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14984, 844, 33, '0', 'frontlines', 'frontlines', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14985, 844, 34, '0', 'future_lightning', 'future_lightning', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14986, 844, 35, '0', 'gazetteer', 'gazetteer', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14987, 844, 36, '0', 'geom', 'geom', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14988, 844, 37, '0', 'global_ir_satellite_10km', 'global_ir_satellite_10km', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14989, 844, 38, '0', 'hurricanes', 'hurricanes', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14990, 844, 39, '0', 'interstates', 'interstates', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14991, 844, 40, '0', 'jetstream', 'jetstream', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14992, 844, 41, '0', 'label', 'label', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14993, 844, 42, '0', 'land_sea_mask', 'land_sea_mask', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14994, 844, 43, '0', 'legend', 'legend', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14995, 844, 44, '0', 'lightning', 'lightning', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14996, 844, 45, '0', 'maple', 'maple', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14997, 844, 46, '0', 'maple_raster', 'maple_raster', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14998, 844, 47, '0', 'marine_zones', 'marine_zones', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14999, 844, 48, '0', 'pacus_ir_satellite_4km', 'pacus_ir_satellite_4km', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15000, 844, 49, '0', 'post_borders', 'post_borders', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15001, 844, 50, '0', 'radar', 'radar', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15002, 844, 51, '0', 'radar_mask', 'radar_mask', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15003, 844, 52, '0', 'rivers', 'rivers', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15004, 844, 53, '0', 'severe_warnings', 'severe_warnings', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15005, 844, 54, '0', 'severe_watches', 'severe_watches', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15006, 844, 55, '0', 'state_borders', 'state_borders', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15007, 844, 56, '0', 'storm_track', 'storm_track', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15008, 844, 57, '0', 'template', 'template', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15009, 844, 58, '0', 'wide_conus_ir_satellite_4km', 'wide_conus_ir_satellite_4km', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15010, 844, 59, '0', 'zones', 'zones', 1, 0, 0, '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15337, 407, 0, '', 'Mapbender', 'Mapbender User', 0, 1, 0, '', 'http://wms1.ccgis.de/mapbender22/metadata/metadata.php?layer=Schulen');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15338, 407, 1, '0', 'Mapbender_User', 'Mapbender User', 0, 0, 0, '', 'http://wms1.ccgis.de/mapbender22/metadata/metadata.php?layer=Rathaus');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15339, 407, 2, '0', 'Mapbender_Names', 'Mapbender Info', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15735, 854, 0, '', 'wesseling_stadtkarte', 'Stadtkarte', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15736, 854, 1, '0', 'Nutzung', 'Nutzung', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15737, 854, 2, '1', 'wes_dsk_patch1', 'wes_dsk_patch1', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15738, 854, 3, '1', 'atkis_wes_1_umn_pl', 'atkis_wes_1_umn_pl', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15739, 854, 4, '1', 'atkis_wes_1_umn_l', 'atkis_wes_1_umn_l', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15740, 854, 5, '1', 'atkis_wes_3_layer1_pl', 'atkis_wes_3_layer1_pl', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15741, 854, 6, '1', 'atkis_wes_3_layer2_pl', 'atkis_wes_3_layer2_pl', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15742, 854, 7, '1', 'atkis_wes_3_layer3_pl', 'atkis_wes_3_layer3_pl', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15743, 854, 8, '1', 'atkis_wes_3_layer4_pl', 'atkis_wes_3_layer4_pl', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15744, 854, 9, '1', 'atkis_wes_3_layer5_pl', 'atkis_wes_3_layer5_pl', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15745, 854, 10, '1', 'atkis_wes_3_layer6_l', 'atkis_wes_3_layer6_l', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15746, 854, 11, '1', 'Flüsse', 'Flüsse', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15747, 854, 12, '0', 'Strassen', 'Strassen', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15748, 854, 13, '12', 'WES_DSK_füllung1', 'WES_DSK_füllung1', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15749, 854, 14, '12', 'WES_DSK_umring', 'WES_DSK_umring', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15750, 854, 15, '12', 'WES_DSK_füllung2', 'WES_DSK_füllung2', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15751, 854, 16, '0', 'Stadtgrenze', 'Stadtgrenze', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15752, 854, 17, '0', 'Strassennamen', 'Strassennamen', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15753, 854, 18, '17', 'wes_dsk_strnamen_umn_1_t', 'wes_dsk_strnamen_umn_1_t', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15754, 854, 19, '17', 'wes_dsk_strnamen_umn_2_t', 'wes_dsk_strnamen_umn_2_t', 0, 0, 4000, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15755, 854, 20, '0', 'wes_dsk_patch', 'wes_dsk_patch', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15798, 855, 0, '', '', 'World Map', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15799, 855, 1, '0', 'Bathymetry', 'Bathymetry', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15800, 855, 2, '0', 'Countries', 'Countries', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15801, 855, 3, '0', 'Topography', 'Topography', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15802, 855, 4, '0', 'Hillshading', 'Hillshading', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15803, 855, 5, '0', 'Builtup areas', 'Builtup areas', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15804, 855, 6, '0', 'Coastlines', 'Coastlines', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15805, 855, 7, '0', 'Waterbodies', 'Waterbodies', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15806, 855, 8, '0', 'Inundated', 'Inundated', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15807, 855, 9, '0', 'Rivers', 'Rivers', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15808, 855, 10, '0', 'Streams', 'Streams', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15809, 855, 11, '0', 'Railroads', 'Railroads', 1, 0, 1683694, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15810, 855, 12, '0', 'Highways', 'Highways', 1, 0, 1403078, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15811, 855, 13, '0', 'Roads', 'Roads', 1, 0, 841847, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15812, 855, 14, '0', 'Trails', 'Trails', 1, 0, 561231, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15813, 855, 15, '0', 'Borders', 'Borders', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15814, 855, 16, '0', 'Cities', 'Cities', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15815, 855, 17, '0', 'Settlements', 'Settlements', 1, 0, 1122463, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15816, 855, 18, '0', 'Spot elevations', 'Spot elevations', 0, 0, 561231, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15817, 855, 19, '0', 'Airports', 'Airports', 1, 0, 1122463, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15818, 855, 20, '0', 'Ocean features', 'Ocean features', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18068, 859, 0, '', '', 'Geobasisdaten', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18069, 859, 1, '0', '1', 'Digitale Orthophotos', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18070, 860, 0, '', '', 'Grundkarte REK', 0, 2, 13840, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18071, 860, 1, '0', 'LIKA_TAUSEND:Gebaeude', 'Gebaeude', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18072, 860, 2, '0', 'LIKA_TAUSEND:Grundkarte', 'Grundkarte', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18073, 860, 3, '0', 'LIKA_TAUSEND:Leer', 'Leer', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18074, 860, 4, '0', 'LIKA_TAUSEND:Strasse_HsNr', 'Strasse_HsNr', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18075, 861, 0, '', '', 'Grundkarte REK', 0, 2, 13840, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18076, 861, 1, '0', 'LIKA_TAUSEND:Gebaeude', 'Gebaeude', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18077, 861, 2, '0', 'LIKA_TAUSEND:Grundkarte', 'Grundkarte', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18078, 861, 3, '0', 'LIKA_TAUSEND:Leer', 'Leer', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18079, 861, 4, '0', 'LIKA_TAUSEND:Strasse_HsNr', 'Strasse_HsNr', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18080, 862, 0, '', '', 'Grundkarte REK', 0, 2, 13840, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18081, 862, 1, '0', 'LIKA_TAUSEND:Gebaeude', 'Gebaeude', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18082, 862, 2, '0', 'LIKA_TAUSEND:Grundkarte', 'Grundkarte', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18083, 862, 3, '0', 'LIKA_TAUSEND:Leer', 'Leer', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18084, 862, 4, '0', 'LIKA_TAUSEND:Strasse_HsNr', 'Strasse_HsNr', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18085, 863, 0, '', '', 'forstamtsgr', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18086, 863, 1, '0', '0', 'Forstamtsgrenzen', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18087, 864, 0, '', '', 'gewstat', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18088, 864, 1, '0', 'Uebrige Gewaesser groesser 12 m Breite 3', 'Uebrige Gewaesser groesser 12 m Breite', 1, 200, 74989, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18089, 864, 2, '0', 'Uebrige Gewaesser kleiner 12 m Breite 2', 'Uebrige Gewaesser kleiner 12 m Breite', 1, 200, 74989, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18090, 864, 3, '0', 'Kanaele groesser 12 m Breite 2', 'Kanaele groesser 12 m Breite', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18091, 864, 4, '0', 'Kanaele kleiner 12m Breite', 'Kanaele kleiner 12 m Breite', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18092, 864, 5, '0', 'Unterirdisch verlaufende Gewaesser', 'Unterirdisch verlaufende Gewaesser', 1, 200, 74989, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18093, 864, 6, '0', 'Fliessgewaesser groesser 12 m Breite', 'Fliessgewaesser groesser 12 m Breite', 1, 200, 74989, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18094, 864, 7, '0', 'Fliessgewaesser kleiner 12 m Breite', 'Fliessgewaesser kleiner 12 m Breite', 1, 200, 74989, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18095, 864, 8, '0', 'St_Kanaele 1000 m', 'St_Kanaele 1000 m', 1, 200, 56242, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18096, 864, 9, '0', 'St_Rhein und Weser 1000 m', 'St_Rhein und Weser 1000 m', 1, 200, 56242, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18097, 864, 10, '0', 'St_Fliessgewaesser 1000 m', 'St_Fliessgewaesser 1000 m', 1, 200, 56242, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18098, 864, 11, '0', 'St_Kanaele 500 m', 'St_Kanaele 500 m', 1, 200, 37494, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18099, 864, 12, '0', 'St_Rhein und Weser 500 m', 'St_Rhein und Weser 500 m', 1, 200, 37494, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18100, 864, 13, '0', 'St_Fliessgewaesser 500 m', 'St_Fliessgewaesser 500 m', 1, 200, 37494, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18101, 864, 14, '0', 'St_Kanaele 100 m', 'St_Kanaele 100 m', 1, 200, 11248, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18102, 864, 15, '0', 'St_Rhein und Weser 100 m', 'St_Rhein und Weser 100 m', 1, 200, 11248, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18103, 864, 16, '0', 'St_Fliessgewaesser 100 m', 'St_Fliessgewaesser 100 m', 1, 200, 11248, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18104, 864, 17, '0', 'Stationierungslinie', 'Stationierungslinie', 1, 200, 18747, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18105, 864, 18, '0', 'Fluesse', 'Fluesse', 1, 74990, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18119, 866, 0, '', '', 'hochwasser', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18120, 866, 1, '0', '8', 'rhein-hq100-odeich', 1, 200, 749888, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18121, 866, 2, '0', '9', 'rhein-hq100-mdeich', 1, 200, 749888, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18122, 866, 3, '0', '6', 'rhein-hq200-odeich', 1, 200, 749888, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18123, 866, 4, '0', '7', 'rhein-hq200-mdeich', 1, 200, 749888, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18124, 866, 5, '0', '4', 'rhein-hq500-odeich', 1, 200, 749888, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18125, 866, 6, '0', '5', 'rhein-hq500-mdeich', 1, 200, 749888, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18126, 866, 7, '0', '0', 'vereinf_Verfahren', 1, 200, 374944, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18127, 866, 8, '0', '1', 'Sonstige_UESG', 1, 200, 374944, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18128, 866, 9, '0', '2', 'Historische_UESG', 1, 200, 374944, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18129, 866, 10, '0', '3', 'neuere_Berechnungsverfahren', 1, 200, 374944, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18130, 866, 11, '0', '18', 'Seen', 1, 200, 374944, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18131, 866, 12, '0', '19', 'Talsperre', 1, 200, 374944, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18132, 867, 0, '', '', 'stobo', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18133, 867, 1, '0', 'Bleibelastung der Ackerboeden in mg pro kg', 'Bleibelastung der Ackerboeden in mg pro kg', 1, 22497, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18134, 867, 2, '0', 'Cadmiumbelastung der Ackerboeden in mg pro kg', 'Cadmiumbelastung der Ackerboeden in mg pro kg', 1, 22497, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18135, 867, 3, '0', 'Zinkbelastung der Ackerboeden in mg pro kg', 'Zinkbelastung der Ackerboeden in mg pro kg', 1, 22497, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18136, 867, 4, '0', 'Bleibelastung der Gartenboeden in mg pro kg', 'Bleibelastung der Gartenboeden in mg pro kg', 1, 22497, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18137, 867, 5, '0', 'Cadmiumbelastung der Gartenboeden in mg pro kg', 'Cadmiumbelastung der Gartenboeden in mg pro kg', 1, 22497, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18138, 867, 6, '0', 'Zinkbelastung der Gartenboeden in mg pro kg', 'Zinkbelastung der Gartenboeden in mg pro kg', 1, 22497, 74989, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18139, 867, 7, '0', 'Bleibelastung der Gruenlandboeden in mg pro kg', 'Bleibelastung der Gruenlandboeden in mg pro kg', 1, 22497, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18140, 867, 8, '0', 'Cadmiumbelastung der Gruenlandboeden in mg pro kg', 'Cadmiumbelastung der Gruenlandboeden in mg pro kg', 1, 22497, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18141, 867, 9, '0', 'Zinkbelastung der Gruenlandboeden in mg pro kg', 'Zinkbelastung der Gruenlandboeden in mg pro kg', 1, 22497, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18142, 867, 10, '0', 'Probenahmenstandorte in NRW differenziert nach Nutzungen', 'Probenahmenstandorte in NRW differenziert nach Nutzungen', 1, 22497, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18143, 868, 0, '', '', 'Gelaendemodell', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18144, 868, 1, '0', 'DGM50', 'DGM50', 0, 26075, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18145, 869, 0, '', '', 'linfos', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18146, 869, 1, '0', '51', 'Vegetationstypen', 1, 0, 150214, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18147, 869, 2, '0', '49', 'Vegetationsaufnahmen', 1, 0, 150214, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18148, 869, 3, '0', '45', 'Naturraeumliche Haupteinheiten', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18149, 869, 4, '0', '43', 'Landschaftsschutzgebiete', 1, 0, 150214, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18150, 869, 5, '0', '42', 'Stand der Landschaftsplanung', 1, 0, 150214, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18151, 869, 6, '0', '32', 'FFH-Gebiete', 1, 0, 150214, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18152, 869, 7, '0', '31', 'Vogelschutzgebiete', 1, 0, 150214, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18153, 869, 8, '0', '28', 'Biotoptypen', 1, 0, 150214, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18154, 869, 9, '0', '3', 'Biotopkataster', 1, 0, 150214, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18155, 869, 10, '0', '1', 'Naturschutzgebiete', 1, 0, 150214, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18156, 870, 0, '', '', 'hangneigung', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18157, 870, 1, '0', 'hangneigung', 'Hangneigung', 1, 200, 374944, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18158, 870, 2, '0', 'Fliessgewaesser', 'Fliessgewaesser', 1, 200, 374944, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18159, 871, 0, '', 'MUENSTER', 'Geobasisdaten Muenster', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18160, 871, 1, '0', 'splan', 'Stadtplan', 0, 2400, 2000000, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18161, 871, 2, '0', 'luftb', 'Luftbilder', 0, 375, 3900, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18162, 871, 3, '0', 'dgk5dbr', 'DGK5', 0, 1, 3900, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18163, 871, 4, '0', 'Stadtgrundkarte', 'Stadtgrundkarte', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18164, 871, 5, '4', 'flst', 'Flurstuecke', 0, 1, 2500, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18165, 871, 6, '4', 'gebaeude', 'Gebaeude', 0, 1, 2500, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18166, 871, 7, '4', 'linien', 'Topographie', 0, 1, 2500, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18167, 871, 8, '4', 'texte', 'Beschriftung', 0, 1, 2500, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18168, 872, 0, '', '', 'WV_WMS', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18169, 872, 1, '0', 'rheinplus', 'rheinplus', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18170, 872, 2, '0', 'uesgobwup', 'uesgobwup', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18171, 872, 3, '0', 'uesgmorsbach', 'uesgmorsbach', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18172, 872, 4, '0', 'klaerwerkseinzugsgebiete', 'klaerwerkseinzugsgebiete', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18173, 872, 5, '0', 'entwaesserungssystem', 'entwaesserungssystem', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18174, 872, 6, '0', 'gezgross', 'gezgross', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18175, 872, 7, '0', 'gezklein', 'gezklein', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18176, 872, 8, '0', 'ueberleitungsgebiete', 'ueberleitungsgebiete', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18177, 872, 9, '0', 'verbandsgebiet', 'verbandsgebiet', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18178, 872, 10, '0', 'gsg5', 'gsg5', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18179, 872, 11, '0', 'gsg3', 'gsg3', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18180, 872, 12, '0', 'gsg1', 'gsg1', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18181, 872, 13, '0', 'gewaesser', 'gewaesser', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18182, 872, 14, '0', 'verrohrungen', 'verrohrungen', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18183, 872, 15, '0', 'verlaufaenderungen', 'verlaufaenderungen', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18184, 872, 16, '0', 'gewaesserbeschriftung', 'gewaesserbeschriftung', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18185, 872, 17, '0', 'talsperren', 'talsperren', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18186, 872, 18, '0', 'sammler', 'sammler', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18187, 872, 19, '0', 'stationierung', 'stationierung', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18188, 872, 20, '0', 'fotos_am_gewaesser', 'fotos_am_gewaesser', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18189, 872, 21, '0', 'limnologie', 'limnologie', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18190, 872, 22, '0', 'niederschlagsstationen', 'niederschlagsstationen', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18191, 872, 23, '0', 'pegel', 'pegel', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18192, 872, 24, '0', 'wehre', 'wehre', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18193, 872, 25, '0', 'fischaufstiege', 'fischaufstiege', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18194, 872, 26, '0', 'hrb', 'hrb', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18195, 872, 27, '0', 'regenbeckenwv', 'regenbeckenwv', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18196, 872, 28, '0', 'klaerwerke', 'klaerwerke', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18205, 881, 0, '', 'Gebietsgliederung', 'Gebietsgliederung', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18206, 881, 1, '0', 'Stadtbezirke', 'Stadtbezirke', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18207, 881, 2, '1', 'stadtbezirke_pl', 'stadtbezirke_pl', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18208, 881, 3, '1', 'stadtbezirke_t', 'stadtbezirke_t', 0, 0, 300000, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18209, 881, 4, '0', 'Statistische_Bezirke', 'Statistische_Bezirke', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18210, 881, 5, '4', 'statist_bez_pl', 'statist_bez_pl', 0, 0, 300000, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18211, 881, 6, '4', 'statist_bez_t', 'statist_bez_t', 0, 0, 300000, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18212, 881, 7, '0', 'Verkehrszellen', 'Verkehrszellen', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18213, 881, 8, '7', 'verkehrszellen_pl', 'verkehrszellen_pl', 0, 0, 300000, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18214, 881, 9, '7', 'verkehrszellen_t', 'verkehrszellen_t', 0, 0, 300000, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18215, 881, 10, '0', 'Baubloecke', 'Baubloecke', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18216, 881, 11, '10', 'baubloecke_pl', 'baubloecke_pl', 0, 0, 100000, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18217, 881, 12, '10', 'baubloecke_t', 'baubloecke_t', 0, 0, 100000, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18218, 882, 0, '', 'Wahlen', 'Wahlen', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18219, 882, 1, '0', 'HINTERGRUNDKARTE', 'HINTERGRUNDKARTE', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18220, 882, 2, '1', 'stadtplan_grau_zoomst_1', 'stadtplan_grau_zoomst_1', 0, 135001, 300000, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18221, 882, 3, '1', 'stadtplan_zoom3_01', '02_stadtplan', 0, 20001, 135000, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18222, 882, 4, '1', 'stadtplan_zoom3_02', '03_stadtplan', 0, 12001, 20000, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18223, 882, 5, '1', 'stadtplan_zoom3_03', '04_stadtplan', 0, 2751, 12000, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18224, 882, 6, '1', 'dgk5_liste', 'Deutsche Grundkarte', 0, 0, 2750, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18225, 882, 7, '0', 'stadtplan_72dpi', 'stadtplan_uebersicht', 0, 300000, 1000000, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18226, 882, 8, '0', 'Stadtbezirke', 'Stadtbezirke', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18227, 882, 9, '8', 'stadtbezirke_pl', 'stadtbezirke_pl', 0, 0, 300000, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18228, 882, 10, '8', 'stadtbezirke_t', 'stadtbezirke_t', 0, 0, 300000, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18229, 882, 11, '0', 'Wahlbezirke', 'Wahlbezirke', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18230, 882, 12, '11', 'wahlbezirke_pl', 'wahlbezirke_pl', 0, 0, 300000, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18231, 882, 13, '11', 'wahlbezirke_t', 'wahlbezirke_t', 0, 0, 300000, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18232, 882, 14, '0', 'Stimmbezirke', 'Stimmbezirke', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18233, 882, 15, '14', 'stimmbezirke_pl', 'stimmbezirke_pl', 0, 0, 300000, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18234, 882, 16, '14', 'stimmbezirke_t', 'stimmbezirke_t', 0, 0, 300000, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18235, 883, 0, '', '', 'Luftbilder', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18236, 883, 1, '0', '1', '$_nav_uebersicht', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18237, 883, 2, '0', '2', 'Stadtplan', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18238, 883, 3, '0', '5', 'Luftbilder 1999', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18239, 883, 4, '0', '8', 'Flurstuecksstruktur', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18240, 883, 5, '0', '9', 'Texte', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18241, 884, 0, '', '', 'wsg', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18242, 884, 1, '0', 'Trinkwasser Zone 1 punktfoermig', 'Trinkwasser Zone 1 punktfoermig', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18243, 884, 2, '0', 'Trinkwasserschutzgebiete', 'Trinkwasserschutzgebiete', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18244, 884, 3, '0', 'Heilquellen Zone 1 punktfoermig', 'Heilquellen Zone 1 punktfoermig', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18245, 884, 4, '0', 'Heilquellenschutzgebiete', 'Heilquellenschutzgebiete', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18246, 885, 0, '', '', 'Landesbetrieb Straßenbau NRW', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18247, 885, 1, '0', 'Strassen', 'Alle Straßen', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18248, 885, 2, '1', 'Autobahnen', 'Autobahnen', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18249, 885, 3, '1', 'Bundesstrassen', 'Bundesstraßen', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18250, 885, 4, '1', 'Landesstrassen', 'Landesstraßen', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18251, 885, 5, '1', 'Kreisstrassen', 'Kreisstraßen', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18252, 885, 6, '0', 'NKStrassen', 'Netzknoten, alle Straßen', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18253, 885, 7, '6', 'NKAutobahnen', 'Netzknoten, Autobahnen', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18254, 885, 8, '6', 'NKBundesstrassen', 'Netzknoten, Bundesstraßen', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18255, 885, 9, '6', 'NKLandesstrassen', 'Netzknoten, Landesstraßen', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18256, 885, 10, '6', 'NKKreisstrassen', 'Netzknoten, Kreisstraßen', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18257, 885, 11, '0', 'NPStrassen', 'Nullpunkte, alle Straßen', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18258, 885, 12, '11', 'NPAutobahnen', 'Nullpunkte, Autobahnen', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18259, 885, 13, '11', 'NPBundesstrassen', 'Nullpunkte, Bundesstraßen', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18260, 885, 14, '11', 'NPLandesstrassen', 'Nullpunkte, Landesstraßen', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18261, 885, 15, '11', 'NPKreisstrassen', 'Nullpunkte, Kreisstraßen', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18262, 885, 16, '0', 'TKBlaetter', 'TK-Blattschnitte', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18263, 885, 17, '0', 'mZstBereichStrassen', 'Zst-Bereiche alle Straßen', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18264, 885, 18, '17', 'mZstBereichAutobahnen', 'Zst-Bereiche Autobahnen', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18265, 885, 19, '17', 'mZstBereichBundesstrassen', 'Zst-Bereiche Bundesstraßen', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18266, 885, 20, '17', 'mZstBereichLandesstrassen', 'Zst-Bereiche Landesstraßen', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18267, 885, 21, '17', 'mZstBereichKreisstrassen', 'Zst-Bereiche Kreisstraßen', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18268, 885, 22, '0', 'mZstOrtStrassen', 'Zst-Orte alle Straßen', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18269, 885, 23, '22', 'mZstOrtAutobahnen', 'Zst-Orte Autobahnen', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18270, 885, 24, '22', 'mZstOrtBundesstrassen', 'Zst-Orte Bundesstrassen', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18271, 885, 25, '22', 'mZstOrtLandesstrassen', 'Zst-Orte Landesstrassen', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18272, 885, 26, '22', 'mZstOrtKreisstrassen', 'Zst-Orte Kreisstrassen', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18274, 887, 0, '', '', 'BK50', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18275, 887, 1, '0', 'bk50', 'bk50', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18276, 888, 0, '', '', 'waldtyp', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18277, 888, 1, '0', 'Waldtyp', 'Waldtyp', 1, 37494, 374944, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18278, 888, 2, '0', 'Waldtyp_50', 'Waldtyp_50', 0, 37494, 187472, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18279, 888, 3, '0', 'Waldtyp_Real', 'Waldtyp_Real', 0, 37494, 187472, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19006, 893, 0, '', 'Germany', 'Germany', 0, 1, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19007, 893, 1, '0', 'Topographie', 'topography', 0, 0, 0, 'http://www.ccgis.de', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19008, 893, 2, '0', 'Grenze', 'border', 0, 749999, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19009, 893, 3, '0', 'Bundeslaender', 'federal states', 0, 749999, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19010, 893, 4, '0', 'Staedte', 'places', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19011, 893, 5, '0', 'Postleitzahlbereiche', 'postcode areas', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19012, 893, 6, '0', 'Bahnlinien', 'railroad lines', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19013, 893, 7, '0', 'Fluesse', 'rivers', 0, 0, 1250001, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19014, 893, 8, '0', 'Strassen', 'roads', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19015, 893, 9, '0', 'Staedtepunkte', 'places as point', 1, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19016, 893, 10, '0', 'Postleitzahlbereichname', 'postcode areas (names)', 0, 0, 350000, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19017, 893, 11, '0', 'Staedtenamen', 'places (names)', 0, 0, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19018, 893, 12, '0', 'Bundeslaendernamen', 'federal states (names)', 0, 1000000, 0, '', '');
+-- Daten für Tabelle `layer_epsg`
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (2712, 'EPSG:4326', -99, -80, 73, 89);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (2713, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (2714, 'EPSG:4326', -184, -90, 180, 85);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (2715, 'EPSG:4326', -179.999999999999, -90.0000000017335, 179.999999996401, 89.9999999999998);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (2716, 'EPSG:4326', -179.999999999999, -90.0000000017335, 179.999999996401, 89.9999999999998);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (2717, 'EPSG:4326', -180, -55, 180, 75);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (2718, 'EPSG:4326', -184, -90, 180, 85);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (2719, 'EPSG:4326', -184, -75, 180, 85);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (2720, 'EPSG:4326', -180, -50, 180, 80);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (2721, 'EPSG:4326', -180, -55, 180, 85);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (2722, 'EPSG:4326', -180, -55, 180, 85);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (2723, 'EPSG:4326', -170, -55, 180, 80);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (2724, 'EPSG:4326', -175, -55, 180, 75);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (2725, 'EPSG:4326', -184, -55, 180, 75);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (2726, 'EPSG:4326', -184, -50, 180, 80);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (2727, 'EPSG:4326', -184, -60, 176, 75);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (2728, 'EPSG:4326', -180, -55, 180, 75);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (2729, 'EPSG:4326', -180, -55, 180, 85);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (2730, 'EPSG:4326', -179.983093261719, -89.83837890625, 179.991439819336, 83.5204086303711);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (2731, 'EPSG:4326', -184, -55, 180, 80);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (2732, 'EPSG:4326', -180, -62.9231796264648, 179.999420166016, 68.6906585693359);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3384, 'EPSG:4326', 5.65296386, 50.31247805, 9.61606634, 52.54258946);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3384, 'EPSG:31466', 2475321.11, 5575227.309, 2745328.607, 5829431.962);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3384, 'EPSG:31467', 3261687.612, 5580528.47, 3541868.629, 5823459.987);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3384, 'EPSG:31468', 4048175.555, 5594462.941, 4338378.788, 5825949.424);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3384, 'EPSG:31469', 4834899.688, 5617086.054, 5135004.608, 5836908.636);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3401, 'EPSG:4326', 7.39549, 51.8027, 7.83995, 52.0774);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3401, 'EPSG:31467', 3390000, 5742000, 3420000, 5772000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3470, 'EPSG:4326', 5.8031, 50.2977, 9.5947, 52.5087);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3470, 'EPSG:31466', 2485974, 5573974, 2744025, 5826025);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3470, 'EPSG:31462', 2485974, 5573974, 2744025, 5826025);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3470, 'EPSG:31492', 2485974, 5573974, 2744025, 5826025);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3470, 'EPSG:31467', 3272288.35, 5578845.76, 3540425.56, 5820112.55);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3470, 'EPSG:25831', 699574.5, 5575923.94, 947262.22, 5838522.66);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3470, 'EPSG:25832', 272304.53, 5577057.88, 540337.89, 5818225.97);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3470, 'EPSG:25833', 845502.74, 5612745.05, 133297.98, 5831803.78);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (5575, 'EPSG:4326', 5.60075, 47.2441, 15.425, 55.0317);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (5575, 'EPSG:31467', 3282450, 5248260, 3912240, 6100130);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (5576, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (5577, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (5578, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7255, 'EPSG:4326', -117, 8, -82, 36);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7256, 'EPSG:4326', -179.227, -56.5109, 158.807, 83.6747);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7257, 'EPSG:4326', -117.114, 12.9824, -83.1554, 32.7206);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7259, 'EPSG:4326', -117.114, 12.9824, -83.1554, 32.7206);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7260, 'EPSG:4326', -116.911, 13.1565, -83.2092, 32.717);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7261, 'EPSG:4326', -117.052, 12.988, -83.2, 32.717);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7262, 'EPSG:4326', -117.069, 13.1115, -85.8812, 32.6601);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7263, 'EPSG:4326', -117.119, 13.003, -83.2309, 32.711);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7264, 'EPSG:4326', -117.025, 13.2639, -86.1376, 32.6582);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7265, 'EPSG:4326', -117.048, 13.0238, -83.2254, 32.6768);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7266, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7267, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7491, 'EPSG:4326', -178.838, 31.8844, 179.94, 89.8254);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7491, 'EPSG:42304', -2750560, -936638, 3583870, 4673120);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7492, 'EPSG:4326', -178.838, 31.8844, 179.94, 89.8254);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7493, 'EPSG:4326', -178.838, 31.8844, 179.94, 89.8254);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7494, 'EPSG:4326', -178.838, 31.8844, 179.94, 89.8254);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7495, 'EPSG:4326', -178.838, 31.8844, 179.94, 89.8254);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7496, 'EPSG:4326', -178.838, 31.8844, 179.94, 89.8254);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7497, 'EPSG:4326', -178.838, 31.8844, 179.94, 89.8254);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7498, 'EPSG:4326', -178.838, 31.8844, 179.94, 89.8254);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7499, 'EPSG:4326', -178.838, 31.8844, 179.94, 89.8254);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7500, 'EPSG:4326', -178.838, 31.8844, 179.94, 89.8254);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7501, 'EPSG:4326', -178.838, 31.8844, 179.94, 89.8254);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7502, 'EPSG:4326', -178.838, 31.8844, 179.94, 89.8254);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7503, 'EPSG:4326', -154.144, 34.3231, -31.7891, 73.7913);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7504, 'EPSG:4326', -154.144, 34.3231, -31.7891, 73.7913);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7505, 'EPSG:4326', -153.902, 34.4595, -32.1291, 73.7918);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7506, 'EPSG:4326', -179.805, 42.0819, 178.866, 89.9488);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7507, 'EPSG:4326', -179.96, 34.2409, 178.833, 89.9051);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7508, 'EPSG:4326', -173.537, 35.8452, -11.9603, 83.8009);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7509, 'EPSG:4326', -172.301, 36.4991, -13.1758, 83.484);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7510, 'EPSG:4326', -172.301, 36.4991, -13.1758, 83.484);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7511, 'EPSG:4326', -171.906, 36.6984, -13.5376, 83.4825);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7512, 'EPSG:4326', -171.906, 36.6984, -13.5376, 83.4825);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7513, 'EPSG:4326', -171.12, 37.3234, -14.1977, 83.4839);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7514, 'EPSG:4326', -171.12, 37.3234, -14.1977, 83.4839);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7515, 'EPSG:4326', -135.917, 38.1197, -42.5821, 66.7758);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7516, 'EPSG:4326', -135.917, 38.1197, -42.5821, 66.7758);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7517, 'EPSG:4326', -141, 41, -52, 78);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7518, 'EPSG:4326', -141.238, 41.6718, -52.667, 78.1059);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7519, 'EPSG:4326', -137.517, 42.0317, -52.7, 65.2784);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7520, 'EPSG:4326', -137.745, 41.9265, -52.5407, 65.39);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7521, 'EPSG:4326', -99.5513, 40.4143, -66.4431, 50.3027);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7522, 'EPSG:4326', -137.1, 42.4667, -52.7, 62.91);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7523, 'EPSG:4326', -95.2926, 41.6296, -74.2355, 56.9225);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7524, 'EPSG:4326', -95.2926, 41.6296, -74.2355, 56.9225);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7525, 'EPSG:4326', -96, 41.5286, -73.7075, 57.7329);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7526, 'EPSG:4326', -94.9897, 43.2858, -74.755, 51.7095);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7527, 'EPSG:4326', -140.952, 42.0986, -52.8184, 68.0856);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9666, 'EPSG:4326', 0, 0, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9667, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9668, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9669, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9670, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9671, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9672, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9673, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9675, 'EPSG:4326', -180, -90, 180, 45);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9676, 'EPSG:4326', -180, -90, 180, 45);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9677, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9678, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9679, 'EPSG:4326', -180, -45, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9680, 'EPSG:4326', -180, -45, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9681, 'EPSG:4326', -180, -45, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9682, 'EPSG:4326', -180, -45, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9683, 'EPSG:4326', -180, -45, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9684, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9685, 'EPSG:4326', -180, -90, 180, 45);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9686, 'EPSG:4326', -180, -90, 180, 45);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9688, 'EPSG:4326', -90, -45, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9689, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9691, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9692, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9694, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9695, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9697, 'EPSG:4326', 0, -45, 90, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9698, 'EPSG:4326', 0, 0, 90, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9699, 'EPSG:4326', 0, 0, 90, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9700, 'EPSG:4326', -90, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9702, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9703, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9704, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9706, 'EPSG:4326', -90, -45, 90, 45);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9708, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9709, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9710, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9711, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9712, 'EPSG:4326', -90, -45, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9713, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9714, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9716, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9717, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9718, 'EPSG:4326', 0, -45, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9719, 'EPSG:4326', -180, -45, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9720, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9721, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9723, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9724, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9725, 'EPSG:4326', 0, -45, 180, 45);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9726, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9727, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9729, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9730, 'EPSG:4326', -90, -45, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9731, 'EPSG:4326', 0, -45, 180, 45);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9732, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9733, 'EPSG:4326', -90, -45, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9735, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9736, 'EPSG:4326', -90, -45, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9737, 'EPSG:4326', -180, -45, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9738, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9739, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9740, 'EPSG:4326', -180, -45, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9741, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9742, 'EPSG:4326', -180, -45, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9743, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9744, 'EPSG:4326', -180, -45, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9746, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9747, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9748, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9749, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9750, 'EPSG:4326', -180, -45, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9752, 'EPSG:4326', -180, 0, 0, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9753, 'EPSG:4326', -180, 0, 0, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9754, 'EPSG:4326', -180, -45, 0, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9755, 'EPSG:4326', -180, 0, 0, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9756, 'EPSG:4326', -180, 0, 0, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9757, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9758, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9759, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9760, 'EPSG:4326', 9.54319477081299, 32.2058334350586, 119.997001647949, 52.90283203125);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9761, 'EPSG:4326', -179.909469620325, -82.9724044678733, 179.911941527389, 83.618995626457);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9762, 'EPSG:4326', -179.999420166016, -85.582763671875, 179.9999, 83.6274185180664);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9763, 'EPSG:4326', -179.9999, -78.1118240356445, 179.999969482422, 89.9186553955078);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9764, 'EPSG:4326', -179.9999, -85.582763671875, 179.999969482422, 89.9999);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9765, 'EPSG:4326', -179.9999, -89.9999, 179.9999, 83.6274185180664);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9766, 'EPSG:4326', -179.9999, -89.9999, 179.9999, 89.997917175293);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9767, 'EPSG:4326', -179.991973866709, -77.9279632447287, 179.856246965937, 83.6733627459034);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9768, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9769, 'EPSG:4326', -74.856918334961, -32.850154876709, 179.348114013672, 73.9765243530273);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9770, 'EPSG:4326', -159.769439697266, -53.7913970947266, 178.448303222656, 69.7912216186523);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9771, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9772, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9773, 'EPSG:4326', -180, -89.999999999988, 179.999999999984, 85.733333333335);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9774, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9775, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9776, 'EPSG:4326', -179.999420166016, -88.9542388916016, 179.999420166016, 83.5941696166992);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9777, 'EPSG:4326', -179.998489371501, -89.8383789276704, 179.992340072058, 83.5204086033627);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9778, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9779, 'EPSG:4326', -122.004005432129, -45.6619415283203, 177.989562988281, 58.5494728088379);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9780, 'EPSG:4326', -178.965972927399, -54.9324951181188, 178.452606168576, 71.4137801947072);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9781, 'EPSG:4326', -179.942245460115, -70.7184143224731, 179.72499080468, 82.7138214139268);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9782, 'EPSG:4326', -179.999420166016, -70.9172515869141, 179.9999, 83.5759506225586);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9783, 'EPSG:4326', -7.94513893127441, -37.1427764892578, 144.668533325195, 56.8571662902832);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9784, 'EPSG:4326', -179.991973866709, -73.9846038585529, 179.856246965937, 83.6733627459034);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9785, 'EPSG:4326', -179.999420166016, -55, 179.9999, 83.623046875);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9786, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9787, 'EPSG:4326', -131.269302368164, -48.0415916442871, 158.857467651367, 63.6904182434082);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9788, 'EPSG:4326', -167.528930674307, -53.181308764033, 175.347671541385, 75.4231567075476);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9789, 'EPSG:4326', 20.6402492523193, -7.79213905334473, 162.09294128418, 59.9833602905274);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9790, 'EPSG:4326', -131.303222668357, -41.0020981030539, 169.563095108606, 64.8489685216919);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9791, 'EPSG:4326', -169.677917459048, -46.5901946788654, 174.464172343723, 71.0141906468198);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9792, 'EPSG:4326', -164.431106583215, -70.2329864585772, 170.260772709735, 69.6751403762028);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9793, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9794, 'EPSG:4326', -179.582321166992, -85.7026901245117, 179.849975585938, 82.6487579345703);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9795, 'EPSG:4326', -179.442779541016, -87.4625091552734, 179.831909179688, 83.5644226074219);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9796, 'EPSG:4326', 79.9577484130859, -37.2615852355957, 150.848724365234, 42.4208068847656);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9797, 'EPSG:4326', -179.923385591246, -87.4566039768979, 179.627944962122, 88.5763778770342);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9798, 'EPSG:4326', -179.999420166016, -89.9994277954102, 179.9999, 89.9999);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9799, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9800, 'EPSG:4326', -179.129608154297, -53.167423248291, 178.443252563477, 70.9927215576172);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9801, 'EPSG:4326', -84.8929824633524, -38.9450721954927, 133.667388916947, 64.1353378118947);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9802, 'EPSG:4326', 25.203592300415, -8.67711067199707, 120.379692077637, 23.4393615722656);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9803, 'EPSG:4326', -179.98931881506, -86.4852066105232, 179.996978784911, 81.8230590457097);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9804, 'EPSG:4326', -58.4966392675415, -34.8679313482717, 153.187316902913, 59.8631133651361);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9805, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9806, 'EPSG:4326', -179.878326407634, -54.9311103438959, 179.339859033935, 79.5294418511912);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9807, 'EPSG:4326', -74.856918334961, -32.850154876709, 179.348114013672, 73.9765243530273);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9808, 'EPSG:4326', -124.787292480469, -30.7493667602539, 141.380554199219, 64.9872741699219);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9809, 'EPSG:4326', -165.244674682617, -53.138427734375, 179.609893798828, 78.16796875);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9810, 'EPSG:4326', -179.999420166016, -54.8880233764648, 179.9999, 74.740592956543);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9811, 'EPSG:4326', -148.866836582311, -43.6799964727834, 149.593505845405, 63.6882248008624);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9812, 'EPSG:4326', -179.999420166016, -47.162166595459, 179.9999, 77.2239837646484);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9813, 'EPSG:4326', -124.029273991473, -31.4281540224329, 154.642608663999, 63.0295295873657);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9814, 'EPSG:4326', -149.702819824219, -50.3082847595215, 179.451965332031, 69.6709136962891);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9815, 'EPSG:4326', -167.325347908773, -44.7975158924237, 177.578002936207, 76.9732436863706);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9816, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9817, 'EPSG:4326', -159.769439697266, -53.7913970947266, 178.448303222656, 69.7912216186523);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9818, 'EPSG:4326', -150.71989440918, -53.7913970947266, 177.974609375, 70.6666641235352);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9819, 'EPSG:4326', -179.948303222656, -51.9939651489258, 179.9999, 71.1174163818359);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9820, 'EPSG:4326', -158.631637603976, -45.7761955400929, 176.14938356448, 75.544586176984);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9821, 'EPSG:4326', -148.744964632206, -32.5369033729658, 155.010223430581, 65.5288238497451);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9822, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9823, 'EPSG:4326', -123.152442932129, 18.9949569702148, -61.9560737609863, 58.6110038757324);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9824, 'EPSG:4326', -124.205703735352, 24.5680294036865, -70.9565353393555, 54.9354667663574);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9825, 'EPSG:4326', -168.095977783203, -27.6065120697021, -14.0277805328369, 75.0072631835938);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9826, 'EPSG:4326', -139.997573852539, 25.281270980835, -52.6617202758789, 66.7187652587891);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9827, 'EPSG:4326', -140.496292114258, 53.4538917541504, -58.5955696105957, 67.8282012939453);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9828, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9829, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9830, 'EPSG:4326', -155.000138888889, 16.9998611111114, -63.9998611111114, 60.4312500000002);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9831, 'EPSG:4326', -180, -90, 180, 67.5);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9832, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9833, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9834, 'EPSG:4326', -143.4193834, 32.80806774, -10.30835952, 83.7749511);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9835, 'EPSG:4326', -141.747323, 42.75222705, -52.95665124, 83.14517952);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9836, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9837, 'EPSG:4326', -179.9989999, -84.30888267, 179.9993808, 83.62360026);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9838, 'EPSG:4326', -165.8402708, -84.84944787, 179.2562476, 82.81369782);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9839, 'EPSG:4326', -179.9989999, -84.79229076, 179.9993808, 83.62360026);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9840, 'EPSG:4326', -179.9989999, -84.30888267, 179.9993808, 83.62360026);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9841, 'EPSG:4326', -179.9989999, -84.30888267, 179.9993808, 83.62360026);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9842, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9842, 'EPSG:4326', -184, -90.0000000017335, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9843, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9844, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9844, 'EPSG:4326', -184, -90, 180, 85);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9845, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9845, 'EPSG:4326', -179.999999999999, -90.0000000017335, 179.999999996401, 89.9999999999998);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9846, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9846, 'EPSG:4326', -179.999999999999, -90.0000000017335, 179.999999996401, 89.9999999999998);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9847, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9847, 'EPSG:4326', -180, -55, 180, 75);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9848, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9848, 'EPSG:4326', -184, -90, 180, 85);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9849, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9849, 'EPSG:4326', -184, -75, 180, 85);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9850, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9850, 'EPSG:4326', -180, -50, 180, 80);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9851, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9851, 'EPSG:4326', -180, -55, 180, 85);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9852, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9852, 'EPSG:4326', -180, -55, 180, 85);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9853, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9853, 'EPSG:4326', -170, -55, 180, 80);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9854, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9854, 'EPSG:4326', -175, -55, 180, 75);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9855, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9855, 'EPSG:4326', -184, -55, 180, 75);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9856, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9856, 'EPSG:4326', -184, -50, 180, 80);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9857, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9857, 'EPSG:4326', -184, -60, 176, 75);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9858, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9858, 'EPSG:4326', -180, -55, 180, 75);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9859, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9859, 'EPSG:4326', -180, -55, 180, 85);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9860, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9860, 'EPSG:4326', -179.983093261719, -89.83837890625, 179.991439819336, 83.5204086303711);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9861, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9861, 'EPSG:4326', -184, -55, 180, 80);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9862, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9862, 'EPSG:4326', -180, -62.9231796264648, 179.999420166016, 68.6906585693359);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9863, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9864, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9865, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9866, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9867, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9868, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9869, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9870, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9873, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9874, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9875, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9876, 'EPSG:4326', -179.995833333116, -89.9958333331045, 179.995852108556, 89.9958427208476);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9877, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9878, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9879, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9880, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9881, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9882, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9883, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9884, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9885, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9886, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9887, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9888, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9889, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9890, 'EPSG:4326', -4810601.5, -5769556, 5262368.5, 4734162.5);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9891, 'EPSG:4326', -4708082, -4345438, 4051932, 3830884);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9892, 'EPSG:4326', -4078050, -4399070, 3433950, 3816930);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9893, 'EPSG:4326', -4708264.5, -4339414.5, 4114750.2, 3834475.2);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9894, 'EPSG:4326', -4810601.5, -5769556, 5262368.5, 4734162.5);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9895, 'EPSG:4326', -3975499.8, -4345500, 3968500.2, 3597500);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9896, 'EPSG:4326', -3929000, -4332000, 3363000, 3556000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9897, 'EPSG:4326', -3918171.8, -4332588, 3959946.2, 3834456.2);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9898, 'EPSG:4326', -3887826.5, -4329412.5, 3945989.2, 3835184);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9899, 'EPSG:4326', -3801453.2, -3784234.5, 3316692.8, 3681196.8);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9900, 'EPSG:4326', -3903968.5, -4243231, 3930238.8, 3771816);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9901, 'EPSG:4326', -68, 40, -58, 53);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9901, 'EPSG:26920', 216535.49, 4789364.945, 793699.11, 5232628.755);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9902, 'EPSG:4326', -68, 40, -58, 53);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9902, 'EPSG:26920', 228320.7, 4802966, 774201.3, 5237025.9);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9903, 'EPSG:4326', -68, 40, -58, 53);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9903, 'EPSG:26920', 229152.5, 4807479.3, 757488.1, 5234290.3);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9904, 'EPSG:4326', -68, 40, -58, 53);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9904, 'EPSG:26920', 428940, 4961065.1, 444626, 4972201);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9905, 'EPSG:4326', -68, 40, -58, 53);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9905, 'EPSG:26920', 232461.3, 4809678.6, 758158.3, 5208676);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9906, 'EPSG:4326', -68, 40, -58, 53);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9906, 'EPSG:26920', 228983, 4807499, 766916, 5234379);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9907, 'EPSG:4326', -68, 40, -58, 53);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9907, 'EPSG:26920', 244152.599712, 4813918.299712, 757094.999712, 5195698.799712);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9908, 'EPSG:4326', -68, 40, -58, 53);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9908, 'EPSG:26920', 228949, 4807490.4, 757195.6, 5234413.7);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9909, 'EPSG:4326', -68, 40, -58, 53);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9909, 'EPSG:26920', 430626, 4961481, 444381, 4971528);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9910, 'EPSG:4326', -68, 40, -58, 53);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9910, 'EPSG:26920', 229131.8, 4808860.3, 758595.9, 5234285.1);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9911, 'EPSG:4326', -68, 40, -58, 53);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9911, 'EPSG:26920', 434806, 4961093, 444497, 4971764);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9912, 'EPSG:4326', -68, 40, -58, 53);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9912, 'EPSG:26920', 228320.7, 4802966, 774201.3, 5237025.9);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9913, 'EPSG:4326', -68, 40, -58, 53);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9913, 'EPSG:26920', 229886.1, 4808865.3, 757478.8, 5234267.4);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9914, 'EPSG:4326', -68, 40, -58, 53);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9914, 'EPSG:26920', 229886.1, 4808865.3, 757478.8, 5234267.4);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9915, 'EPSG:4326', -68, 40, -58, 53);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9915, 'EPSG:26920', 231763.6, 4808892, 755978.6, 5231454.5);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9916, 'EPSG:4326', -68, 40, -58, 53);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9916, 'EPSG:26920', 229085.8, 4808860.3, 756071.2, 5233896.8);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9917, 'EPSG:4326', -68, 40, -58, 53);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9917, 'EPSG:26920', 235441.5, 4808890.3, 758061, 5234322.1);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9918, 'EPSG:4326', -68, 40, -58, 53);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9918, 'EPSG:26920', 228896.4, 4807428.7, 767464.4, 5234433.9);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9919, 'EPSG:4326', -68, 40, -58, 53);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9919, 'EPSG:26920', 242770.2, 4809513.3, 767464.4, 5212480.4);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9920, 'EPSG:4326', -68, 40, -58, 53);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9920, 'EPSG:26920', 229312.028, 4810238.61, 746738.692, 5210865.083);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9921, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9921, 'EPSG:4269', -67.8216852877975, 46.6148344572241, -52.6380157753285, 60.3777440127988);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9922, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9922, 'EPSG:4269', -67.8216852877976, 46.6148344572241, -52.6380157753286, 60.3777440127988);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9923, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9923, 'EPSG:4269', -67.770967920156, 46.8002004553093, -52.6702669060924, 60.0813394676784);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9924, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9924, 'EPSG:4269', -67.1125683504731, 46.7071411661886, -52.6247294619803, 53.6390101726444);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9925, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9925, 'EPSG:4269', -67.1455203505038, 46.6175450411052, -52.6247294619803, 53.9598710479432);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9926, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9926, 'EPSG:4269', -67.1455203505038, 46.6175450411052, -52.6247294619803, 53.9598710479432);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9927, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9927, 'EPSG:4269', -60.4007280942222, 46.3738282908782, -52.8568828371965, 54.2500275482135);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9928, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9928, 'EPSG:4269', -67.1455203505038, 46.3738282908782, -52.6247294619803, 53.9598710479432);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9929, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9929, 'EPSG:4269', -67.138189975497, 46.6465264161321, -52.6954219620461, 53.8695525478591);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10028, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10028, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10028, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10028, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10028, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10047, 'EPSG:4326', -172.367, 35.6673, -11.5624, 83.8293);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10047, 'EPSG:42304', -2200000, -712631, 3072800, 3840000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10049, 'EPSG:4326', -178.838, 31.8844, 179.94, 89.8254);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10049, 'EPSG:42304', -2750560, -936638, 3583870, 4673120);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10050, 'EPSG:4326', -173.433, 41.4271, -13.3643, 83.7466);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10050, 'EPSG:42304', -2346800, -67422.4, 2840370, 3830120);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10051, 'EPSG:4326', -179.973, 35.2464, 179.92, 88.06);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10051, 'EPSG:42304', -2750560, -936638, 2758820, 4367270);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10052, 'EPSG:4326', -169.629, 39.2232, -15.1085, 83.0129);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10052, 'EPSG:42304', -2169400, -386968, 2797470, 3743360);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10053, 'EPSG:4326', -173.537, 35.8775, -11.9603, 83.8009);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10053, 'EPSG:42304', -2340600, -719746, 3009430, 3836610);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10054, 'EPSG:4326', -179.96, 34.2409, 178.833, 89.9051);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10054, 'EPSG:42304', -2693580, -724162, 3385190, 4654500);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10055, 'EPSG:4326', -137.447, 37.7146, -46.6233, 66.7201);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10055, 'EPSG:42304', -2145720, -680853, 2616060, 1930970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10056, 'EPSG:4326', -148.059, 35.882, -33.7745, 72.5503);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10056, 'EPSG:42304', -2303690, -724118, 3000530, 2564970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10057, 'EPSG:4326', -172.301, 36.3541, -12.9698, 83.4832);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10057, 'EPSG:42304', -2303860, -681503, 2961770, 3798860);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10058, 'EPSG:4326', -178.838, 31.8844, 179.94, 89.8254);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10058, 'EPSG:42304', -2750560, -936639, 3583870, 4673120);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10106, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10106, 'EPSG:26915', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10107, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10107, 'EPSG:26915', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10108, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10108, 'EPSG:26915', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10109, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10109, 'EPSG:26915', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10110, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10110, 'EPSG:26915', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10153, 'EPSG:4326', -180, 90, 180, -90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10154, 'EPSG:4326', -180, 90, 180, -90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10155, 'EPSG:4326', -82, 48, -65, 20);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10156, 'EPSG:4326', -71, 46, -63, 39);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10157, 'EPSG:4326', -71.3333, 42.1675, -70.3325, 41.1667);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10158, 'EPSG:4326', -71, 46, -63, 39);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10159, 'EPSG:4326', -180, 90, 180, -90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10160, 'EPSG:4326', -180, 90, 180, -90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10165, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10166, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10167, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10168, 'EPSG:4326', -127, 23, -66, 50);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10169, 'EPSG:4326', -127, 23, -66, 50);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10170, 'EPSG:4326', -127, 23, -66, 50);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10171, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10172, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10173, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10174, 'EPSG:4326', -180, -80, 180, 80);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10175, 'EPSG:4326', -180, -80, 180, 80);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10176, 'EPSG:4326', -180, -80, 180, 80);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10177, 'EPSG:4326', -125, 23, -66, 50);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10178, 'EPSG:4326', -127, 23, -66, 50);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10179, 'EPSG:4326', -127, 23, -66, 50);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10194, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10195, 'EPSG:4326', -180, -90, 180, 83.6236);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10196, 'EPSG:4326', -122.21081, 31.14334, -71.01736, 43.65886);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10197, 'EPSG:4326', -122.21037, 31.1451, -71.00945, 43.65702);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10198, 'EPSG:4326', -122.78509, 29.08256, -67.45407, 47.52992);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10199, 'EPSG:4326', -179.144744965676, 17.68105, 179.776672368596, 71.3792);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10200, 'EPSG:4326', -159.78819, 17.67432, -64.56137, 65.45318);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10369, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10369, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10369, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10369, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10369, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10415, 'EPSG:4326', -91.5, 22, -71.5, 36.5);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10415, 'EPSG:4269', -91.5, 22, -71.5, 36.5);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10416, 'EPSG:4326', -125, -5, -45, 55);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10416, 'EPSG:4269', -125, -5, -45, 55);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10417, 'EPSG:4326', -125, -5, -45, 55);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10417, 'EPSG:4269', -125, -5, -45, 55);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10418, 'EPSG:4326', -125, -5, -45, 55);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10418, 'EPSG:4269', -125, -5, -45, 55);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10419, 'EPSG:4326', -78, 34, -74, 40);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10419, 'EPSG:4269', -78, 34, -74, 40);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10420, 'EPSG:4326', -83, 24.4, -80.4, 26.2);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10420, 'EPSG:4269', -83, 24.4, -80.4, 26.2);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10421, 'EPSG:4326', -94.5, 28, -87, 31);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10421, 'EPSG:4269', -94.5, 28, -87, 31);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10422, 'EPSG:4326', -84.5, 27.5, -82.5, 30.2);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10422, 'EPSG:4269', -84.5, 27.5, -82.5, 30.2);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10423, 'EPSG:4326', -83.5, 26.2, -81.7, 28.4);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10423, 'EPSG:4269', -83.5, 26.2, -81.7, 28.4);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10424, 'EPSG:4326', -98, 8, -59, 40);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10424, 'EPSG:4269', -98, 8, -59, 40);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10425, 'EPSG:4326', -125, -5, -45, 55);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10425, 'EPSG:4269', -125, -5, -45, 55);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10426, 'EPSG:4326', -125, -5, -45, 55);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10426, 'EPSG:4269', -125, -5, -45, 55);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10427, 'EPSG:4326', -125, -5, -45, 55);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10427, 'EPSG:4269', -125, -5, -45, 55);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10428, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10428, 'EPSG:4269', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10429, 'EPSG:4326', -96.83, 24.7, -79.9, 37.42);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10429, 'EPSG:4269', -96.83, 24.7, -79.9, 37.42);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10430, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10430, 'EPSG:4269', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10431, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10431, 'EPSG:4269', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10432, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10432, 'EPSG:4269', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10433, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10433, 'EPSG:4269', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10434, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10434, 'EPSG:4269', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10435, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10435, 'EPSG:4269', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10436, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10436, 'EPSG:4269', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10437, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10437, 'EPSG:4269', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10438, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10438, 'EPSG:4269', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10439, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10439, 'EPSG:4269', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10987, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10987, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10987, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10987, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10987, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10989, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10989, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10989, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10989, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10989, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10990, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10990, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10990, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10990, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10990, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10991, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10991, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10991, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10991, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10991, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (11541, 'EPSG:4326', 112.91251, -43.65854, 153.63974, -9.74799);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (11542, 'EPSG:4326', 112.921135, -43.65854, 153.63974, -9.74799);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (11543, 'EPSG:4326', 112.921486, -35.193977, 129.00192, -13.689232);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (11544, 'EPSG:4326', 112.92093, -35.189938, 129.00125, -13.689241);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (11545, 'EPSG:4326', 112.92148, -35.189888, 129.00331, -13.689232);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (11546, 'EPSG:4326', 112.91251, -35.18963, 129.00137, -13.73345);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (11547, 'EPSG:4326', 112.91661, -35.136295, 129.00142, -13.739199);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (11629, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (11629, 'EPSG:31492', 2490669.9, 5576388.9, 2738505.35221098, 5825350.11602884);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (11629, 'EPSG:31466', 2490669.9, 5576388.9, 2738505.35221098, 5825350.11602884);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (11629, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (11629, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (11629, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13667, 'EPSG:4326', -20, 50, 25, 55);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13667, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13668, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13669, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13670, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13671, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13672, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13673, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13674, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13675, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13676, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13677, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13678, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13679, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13680, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13681, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13682, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13683, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13684, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13685, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13686, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13687, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13688, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13689, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13690, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13691, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13692, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13693, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13694, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13695, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13696, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13697, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13698, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13699, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13700, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13701, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13702, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13703, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13704, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13705, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13706, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13707, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13708, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13709, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13710, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13711, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13712, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13713, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13714, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13715, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13716, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13717, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13718, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13719, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13720, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13721, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13722, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13723, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13724, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13725, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13726, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13727, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13728, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13729, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13730, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13731, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13732, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13733, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13734, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13735, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13736, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13737, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13738, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13739, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13740, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13741, 'EPSG:4326', -25.7961120368, 29.9999999273, 179.9994202991, 80.1056137547);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13742, 'EPSG:4326', -25.6848999849, 30.401059272, 158.7402800889, 70.6916174679);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13743, 'EPSG:4326', -180, 17.649013537, 180, 81.8573678413);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13744, 'EPSG:4326', -180, 34.8091863661, 180, 81.8584523731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13751, 'EPSG:4326', -140, -80, 170, 80);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13752, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13753, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13754, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13755, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13775, 'EPSG:4326', -11, 35, 32, 72);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13776, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13777, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14006, 'EPSG:4326', 10.8594, 51.1966, 15.0908, 53.6627);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14006, 'EPSG:25833', 3226000, 5679000, 3506000, 5946000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14007, 'EPSG:4326', 11.2317, 51.3099, 14.7656, 53.5639);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14007, 'EPSG:25833', 3250120, 5690400, 3483680, 5935030);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14008, 'EPSG:4326', 11.2372, 51.3182, 14.7621, 53.5505);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14008, 'EPSG:25833', 3250400, 5691310, 3483440, 5933540);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14009, 'EPSG:4326', 11.2372, 51.3182, 14.7621, 53.5505);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14009, 'EPSG:25833', 3250400, 5691310, 3483440, 5933540);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14010, 'EPSG:4326', 11.3337, 51.3295, 14.6826, 53.4539);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14010, 'EPSG:25833', 3256270, 5692280, 3477910, 5922820);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14011, 'EPSG:4326', 11.4649, 51.3602, 14.5452, 53.421);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14011, 'EPSG:25833', 3264830, 5695300, 3468370, 5919220);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14012, 'EPSG:4326', 11.6415, 51.3704, 14.7364, 53.4637);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14012, 'EPSG:25833', 3276830, 5695890, 3481670, 5923900);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14013, 'EPSG:4326', 11.3234, 51.318, 14.7561, 53.5644);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14013, 'EPSG:25833', 3256210, 5691000, 3483030, 5935090);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14014, 'EPSG:4326', 11.2485, 51.3577, 14.747, 53.4523);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14014, 'EPSG:25833', 3250580, 5695700, 3482410, 5922620);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14015, 'EPSG:4326', 11.9737, 51.3325, 14.7536, 53.3347);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14015, 'EPSG:25833', 3298320, 5690780, 3482850, 5909540);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14016, 'EPSG:4326', 11.2317, 51.3099, 14.7656, 53.5639);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14016, 'EPSG:25833', 3250120, 5690400, 3483680, 5935030);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14028, 'EPSG:4326', 10.8594, 51.1966, 15.0908, 53.6627);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14028, 'EPSG:25833', 3226000, 5679000, 3506000, 5946000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14029, 'EPSG:4326', 11.2317, 51.3099, 14.7656, 53.5639);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14029, 'EPSG:25833', 3250120, 5690400, 3483680, 5935030);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14030, 'EPSG:4326', 11.252, 51.3159, 14.7666, 53.5337);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14030, 'EPSG:25833', 3251290, 5691010, 3483750, 5931680);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14031, 'EPSG:4326', 11.2409, 51.3202, 14.7615, 53.5484);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14031, 'EPSG:25833', 3250640, 5691520, 3483400, 5933310);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14032, 'EPSG:4326', 11.2409, 51.3202, 14.7615, 53.5484);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14032, 'EPSG:25833', 3250640, 5691520, 3483400, 5933310);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14033, 'EPSG:4326', 11.2409, 51.3202, 14.7615, 53.5484);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14033, 'EPSG:25833', 3250640, 5691520, 3483400, 5933310);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14034, 'EPSG:4326', 11.2394, 51.3212, 14.7654, 53.5254);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14034, 'EPSG:25833', 3250400, 5691640, 3483670, 5930750);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14035, 'EPSG:4326', 11.232, 51.3302, 14.759, 53.5607);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14035, 'EPSG:25833', 3250120, 5692660, 3483230, 5934670);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14036, 'EPSG:4326', 11.6383, 51.3336, 14.736, 53.5297);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14036, 'EPSG:25833', 3276950, 5691790, 3481630, 5931240);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14037, 'EPSG:4326', 11.2393, 51.3127, 14.7641, 53.5593);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14037, 'EPSG:25833', 3250600, 5690680, 3483580, 5934520);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14038, 'EPSG:4326', 11.3238, 51.3172, 14.7548, 53.5632);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14038, 'EPSG:25833', 3256240, 5690920, 3482930, 5934960);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14039, 'EPSG:4326', 11.2459, 51.3585, 14.7403, 53.4965);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14039, 'EPSG:25833', 3250670, 5695780, 3481940, 5927540);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14040, 'EPSG:4326', 11.9598, 51.3326, 14.7545, 53.5259);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14040, 'EPSG:25833', 3298310, 5690790, 3482910, 5930810);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14041, 'EPSG:4326', 11.232, 51.3302, 14.759, 53.5607);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14041, 'EPSG:25833', 3250120, 5692660, 3483230, 5934670);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14042, 'EPSG:4326', 11.2317, 51.3099, 14.7656, 53.5639);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14042, 'EPSG:25833', 3250120, 5690400, 3483680, 5935030);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14058, 'EPSG:4326', 10.8594, 51.1966, 15.0908, 53.6627);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14058, 'EPSG:25833', 3226000, 5679000, 3506000, 5946000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14059, 'EPSG:4326', 11.2317, 51.3099, 14.7656, 53.5639);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14059, 'EPSG:25833', 3250120, 5690400, 3483680, 5935030);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14060, 'EPSG:4326', 11.2508, 51.3204, 14.7645, 53.5478);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14060, 'EPSG:25833', 3251300, 5691500, 3483610, 5933240);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14061, 'EPSG:4326', 11.2411, 51.3136, 14.7667, 53.5599);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14061, 'EPSG:25833', 3250720, 5690780, 3483760, 5934580);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14062, 'EPSG:4326', 11.2339, 51.3128, 14.7662, 53.5648);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14062, 'EPSG:25833', 3250270, 5690710, 3483720, 5935130);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14063, 'EPSG:4326', 11.253, 51.3161, 14.7408, 53.5563);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14063, 'EPSG:25833', 3251490, 5691020, 3481950, 5934200);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14064, 'EPSG:4326', 11.2333, 51.322, 14.767, 53.5504);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14064, 'EPSG:25833', 3250150, 5691740, 3483780, 5933530);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14065, 'EPSG:4326', 11.6373, 51.3335, 14.7373, 53.5295);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14065, 'EPSG:25833', 3276890, 5691790, 3481720, 5931210);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14066, 'EPSG:4326', 11.2383, 51.3132, 14.7641, 53.5635);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14066, 'EPSG:25833', 3250550, 5690740, 3483580, 5934980);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14067, 'EPSG:4326', 11.2386, 51.3159, 14.7642, 53.5646);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14067, 'EPSG:25833', 3250580, 5691040, 3483590, 5935110);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14068, 'EPSG:4326', 11.2333, 51.322, 14.767, 53.5504);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14068, 'EPSG:25833', 3250150, 5691740, 3483780, 5933530);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14069, 'EPSG:4326', 11.2409, 51.3202, 14.7615, 53.5484);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14069, 'EPSG:25833', 3250640, 5691520, 3483400, 5933310);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14082, 'EPSG:4326', 10.8594, 51.1966, 15.0908, 53.6627);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14082, 'EPSG:25833', 3226000, 5679000, 3506000, 5946000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14083, 'EPSG:4326', 11.2317, 51.3099, 14.7656, 53.5639);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14083, 'EPSG:25833', 3250120, 5690400, 3483680, 5935030);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14084, 'EPSG:4326', 11.2317, 51.3099, 14.7656, 53.5639);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14084, 'EPSG:25833', 3250120, 5690400, 3483680, 5935030);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14085, 'EPSG:4326', 11.2317, 51.3099, 14.7656, 53.5639);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14085, 'EPSG:25833', 3250120, 5690390, 3483680, 5935030);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14086, 'EPSG:4326', 12.3551, 51.6655, 14.607, 52.5623);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14086, 'EPSG:25833', 3320610, 5727020, 3472840, 5823650);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14087, 'EPSG:4326', 11.2317, 51.3099, 14.7656, 53.5639);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14087, 'EPSG:25833', 3250120, 5690390, 3483680, 5935030);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14088, 'EPSG:4326', 10.8594, 51.1966, 15.0908, 53.6627);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14088, 'EPSG:25833', 3226000, 5679000, 3506000, 5946000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14089, 'EPSG:4326', 13.0773, 52.3311, 13.7647, 52.6794);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14089, 'EPSG:25833', 3369990, 5799580, 3415840, 5837330);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14090, 'EPSG:4326', 11.2317, 51.3099, 14.7656, 53.5639);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14090, 'EPSG:25833', 3250120, 5690390, 3483680, 5935030);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14091, 'EPSG:4326', 11.5254, 51.3507, 14.7581, 53.5638);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14091, 'EPSG:25833', 3269640, 5694020, 3483170, 5935030);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14092, 'EPSG:4326', 11.2423, 51.3099, 14.7656, 53.4443);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14092, 'EPSG:25833', 3250120, 5690390, 3483680, 5921730);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14093, 'EPSG:4326', 12.3551, 51.6655, 14.607, 52.5623);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14093, 'EPSG:25833', 3320610, 5727020, 3472840, 5823650);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14094, 'EPSG:4326', 11.2317, 51.3099, 14.7656, 53.5639);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14094, 'EPSG:25833', 3250120, 5690390, 3483680, 5935030);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14095, 'EPSG:4326', 11.2317, 51.3099, 14.7656, 53.5639);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14095, 'EPSG:25833', 3250120, 5690390, 3483680, 5935030);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14096, 'EPSG:4326', 14.1131, 51.5791, 14.7644, 53.3307);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14096, 'EPSG:25833', 3440930, 5714570, 3483680, 5909090);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14097, 'EPSG:4326', 11.2317, 51.3099, 14.7656, 53.5639);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14097, 'EPSG:25833', 3250120, 5690390, 3483680, 5935030);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14098, 'EPSG:4326', 11.5254, 51.3507, 14.7581, 53.5638);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14098, 'EPSG:25833', 3269640, 5694020, 3483170, 5935030);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14099, 'EPSG:4326', 11.2423, 51.3099, 14.7656, 53.4443);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14099, 'EPSG:25833', 3250120, 5690390, 3483680, 5921730);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14100, 'EPSG:4326', 11.2317, 51.3099, 14.7656, 53.5639);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14100, 'EPSG:25833', 3250120, 5690390, 3483680, 5935030);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14104, 'EPSG:4326', 14.5302, 52.3306, 14.5791, 52.3605);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14104, 'EPSG:25833', 468004, 5797910, 471315, 5801220);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14105, 'EPSG:4326', 14.3624, 52.2429, 14.625, 52.4112);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14106, 'EPSG:4326', 14.3624, 52.2429, 14.625, 52.4112);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14107, 'EPSG:4326', 14.3624, 52.2429, 14.625, 52.4112);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14108, 'EPSG:4326', 14.3624, 52.2429, 14.625, 52.4112);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14109, 'EPSG:4326', 14.3624, 52.2429, 14.625, 52.4112);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14110, 'EPSG:4326', 14.3624, 52.2429, 14.625, 52.4112);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14111, 'EPSG:4326', 14.3624, 52.4101, 15, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14112, 'EPSG:4326', 14.3624, 52.2429, 14.625, 52.4112);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14113, 'EPSG:4326', 14.3624, 52.2429, 14.625, 52.4112);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14114, 'EPSG:4326', 14.3624, 52.2429, 14.625, 52.4112);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14115, 'EPSG:4326', 14.3624, 52.2429, 14.625, 52.4112);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14167, 'EPSG:4326', 0.366, 5.909, 4.423, 12.911);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14168, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14169, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14170, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14171, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14172, 'EPSG:4326', -179.936, -8252670000000, 153.193, 8252670000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14172, 'EPSG:25231', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14173, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14174, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14175, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14176, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14177, 'EPSG:4326', -22.86, -6.1, 27.97, 36.54);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14178, 'EPSG:4326', -17.5352, -5.02722, 27.4634, 35.928);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14179, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14180, 'EPSG:4326', -17.4803, -4.96579, 26.9616, 35.895);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14181, 'EPSG:4326', 0.91, 10.453, 2.072, 11.529);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14182, 'EPSG:4326', 0.962469, 10.6204, 2.00181, 11.4801);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14183, 'EPSG:4326', 1.27346, 10.4927, 1.76609, 11.1076);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14184, 'EPSG:4326', 1.12983, 10.9843, 1.9267, 11.4801);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14185, 'EPSG:4326', 1.73947, 11.1024, 2.00181, 11.4218);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14186, 'EPSG:4326', 0.962469, 10.6204, 1.57366, 11.1786);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14187, 'EPSG:4326', 0.962469, 10.6204, 2.00181, 11.4801);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14188, 'EPSG:4326', 1.0616, 10.6778, 1.94439, 11.4611);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14189, 'EPSG:4326', 0.96663, 10.6204, 1.93321, 11.4585);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14190, 'EPSG:4326', 0.96663, 10.6204, 2.01903, 11.4585);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14191, 'EPSG:4326', 0.964048, 10.5019, 1.96181, 11.3143);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14192, 'EPSG:4326', 0.945717, 10.7865, 1.9267, 11.4801);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14193, 'EPSG:4326', 1.02488, 10.6298, 1.99342, 11.4638);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14194, 'EPSG:4326', 0.969064, 10.6466, 1.99566, 11.4683);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14195, 'EPSG:4326', 1.38508, 11.0838, 1.7935, 11.4268);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14196, 'EPSG:4326', 1.35097, 10.8472, 1.73523, 11.4592);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14197, 'EPSG:4326', 30.25, -2, 31, -1.3);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14199, 'EPSG:4326', 27.9676, -3.71489, 33.6046, 0.300413);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14200, 'EPSG:4326', 27.9676, -3.71489, 33.6046, 0.300413);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14202, 'EPSG:4326', 29.5336, -3.26908, 29.9915, -2.11794);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14203, 'EPSG:4326', 29.5336, -3.26908, 29.9915, -2.11794);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14206, 'EPSG:4326', 30.5423, -1.9648, 30.839, -1.33586);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14208, 'EPSG:4326', 30.5568, -2.00118, 30.8467, -1.32298);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14210, 'EPSG:4326', 30.5379, -2.00072, 30.8292, -1.35215);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14211, 'EPSG:4326', 30.5379, -2.00072, 30.8292, -1.35215);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14213, 'EPSG:4326', 30.5299, -2.00013, 30.7223, -1.32277);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14215, 'EPSG:4326', 30.5323, -2.00009, 30.7961, -1.32731);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14217, 'EPSG:4326', 30.6509, -2.08422, 30.8224, -1.40838);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14219, 'EPSG:4326', 30.5543, -1.97712, 30.6606, -1.50009);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14220, 'EPSG:4326', 30.5299, -2.08422, 30.8467, -1.32277);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14222, 'EPSG:4326', 30.5539, -2.07797, 30.8983, -1.2954);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14224, 'EPSG:4326', 30.5423, -1.96405, 30.8387, -1.3225);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14226, 'EPSG:4326', 30.5, -2.00003, 30.7816, -1.38682);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14227, 'EPSG:4326', 30.5473, -1.88667, 30.7818, -1.39639);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14228, 'EPSG:4326', 30.5495, -1.88786, 30.7839, -1.39727);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14251, 'EPSG:4326', 6.00184962, 46.95, 16.12339886, 55.0960681);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14251, 'EPSG:31463', 3271885.7914, 5206662.53894249, 3956235.7914, 6130259.0977);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14251, 'EPSG:31467', 3271885.7914, 5206662.53894249, 3956235.7914, 6130259.0977);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14252, 'EPSG:4326', 6.07358734, 47.161701, 16.05521058, 55.0960681);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14252, 'EPSG:31463', 3278185.6428, 5228939.0977, 3950085.6428, 6130259.0977);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14252, 'EPSG:31467', 3278185.6428, 5228939.0977, 3950085.6428, 6130259.0977);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14253, 'EPSG:4326', 6.00184962, 46.959702, 16.12339886, 54.9369973);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14253, 'EPSG:31463', 3271885.7914, 5206690.9778, 3956235.7914, 6113040.9778);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14253, 'EPSG:31467', 3271885.7914, 5206690.9778, 3956235.7914, 6113040.9778);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14254, 'EPSG:4326', 6.00242837, 46.95, 16.12332498, 54.937);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14254, 'EPSG:31463', 3271928.81349429, 5206662.53894249, 3956228.81349429, 6113062.53894249);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14254, 'EPSG:31467', 3271928.81349429, 5206662.53894249, 3956228.81349429, 6113062.53894249);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14255, 'EPSG:4326', 11.7651, 50.0294, 15.1358, 51.8592);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14255, 'EPSG:31468', 4483820, 5547910, 4716180, 5747080);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14257, 'EPSG:4326', 9.1024741, 47.0828299, 13.9781535, 50.6100606);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14257, 'EPSG:31464', 4280000, 5220000, 4640000, 5610000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14257, 'EPSG:31468', 4280000, 5220000, 4640000, 5610000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14257, 'EPSG:31494', 4280000, 5220000, 4640000, 5610000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14258, 'EPSG:4326', 9.1024741, 47.0828299, 13.9781535, 50.6100606);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14258, 'EPSG:31464', 4280000, 5220000, 4640000, 5610000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14258, 'EPSG:31468', 4280000, 5220000, 4640000, 5610000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14258, 'EPSG:31494', 4280000, 5220000, 4640000, 5610000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14259, 'EPSG:4326', 9.1024741, 47.0828299, 13.9781535, 50.6100606);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14259, 'EPSG:31464', 4280000, 5220000, 4640000, 5610000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14259, 'EPSG:31468', 4280000, 5220000, 4640000, 5610000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14259, 'EPSG:31494', 4280000, 5220000, 4640000, 5610000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14260, 'EPSG:4326', 9.1024741, 47.0828299, 13.9781535, 50.6100606);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14260, 'EPSG:31464', 4280000, 5220000, 4640000, 5610000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14260, 'EPSG:31468', 4280000, 5220000, 4640000, 5610000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14260, 'EPSG:31494', 4280000, 5220000, 4640000, 5610000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14261, 'EPSG:4326', 11.0754, 51.3018, 14.8564, 53.6087);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14261, 'EPSG:25833', 3240000, 5690000, 3490000, 5940000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14264, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14264, 'EPSG:31468', 4483816, 5547914, 4716183, 5747085);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14264, 'EPSG:31494', 4483816, 5547914, 4716183, 5747085);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14265, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14265, 'EPSG:31468', 4483816, 5547914, 4716183, 5747085);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14265, 'EPSG:31494', 4483816, 5547914, 4716183, 5747085);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14266, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14266, 'EPSG:31468', 4483816, 5547914, 4716183, 5747085);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14266, 'EPSG:31494', 4483816, 5547914, 4716183, 5747085);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14272, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14272, 'EPSG:31468', 4483816, 5547914, 4716183, 5747085);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14272, 'EPSG:31494', 4483816, 5547914, 4716183, 5747085);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14277, 'EPSG:4326', 6.18036450167723, 50.5027959436762, 13.6833327054812, 54.940306551493);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14277, 'EPSG:31467', 3300000, 5600000, 3800000, 6100000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14277, 'EPSG:31493', 3300000, 5600000, 3800000, 6100000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14278, 'EPSG:4326', 6.18036450167723, 50.5027959436762, 13.6833327054812, 54.940306551493);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14278, 'EPSG:31467', 3300000, 5600000, 3800000, 6100000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14278, 'EPSG:31493', 3300000, 5600000, 3800000, 6100000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14279, 'EPSG:4326', 6.18036450167723, 50.5027959436762, 13.6833327054812, 54.940306551493);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14279, 'EPSG:31467', 3300000, 5600000, 3800000, 6100000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14279, 'EPSG:31493', 3300000, 5600000, 3800000, 6100000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14280, 'EPSG:4326', 6.18036450167723, 50.5027959436762, 13.6833327054812, 54.940306551493);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14280, 'EPSG:31467', 3300000, 5600000, 3800000, 6100000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14280, 'EPSG:31493', 3300000, 5600000, 3800000, 6100000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14281, 'EPSG:4326', 6.18036450167723, 50.5027959436762, 13.6833327054812, 54.940306551493);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14281, 'EPSG:31467', 3300000, 5600000, 3800000, 6100000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14281, 'EPSG:31493', 3300000, 5600000, 3800000, 6100000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14287, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14287, 'EPSG:31468', 4500038.05625261, -10000959.9491005, 4500018.65616468, 10000963.6477023);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14288, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14289, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14290, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14291, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14292, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14293, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14294, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14295, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14296, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14297, 'EPSG:4326', 9.1024741, 47.0828299, 13.9781535, 50.6100606);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14297, 'EPSG:31467', 3400000, 5470000, 3600000, 5730000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14297, 'EPSG:31466', 2617899, 5470356, 2807329, 5738376);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14297, 'EPSG:31468', 4182142, 5478309, 4392607, 5730152);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14297, 'EPSG:31469', 4964419, 5495318, 5185283, 5738832);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14298, 'EPSG:4326', 9.1024741, 47.0828299, 13.9781535, 50.6100606);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14298, 'EPSG:31467', 3400000, 5470000, 3600000, 5730000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14298, 'EPSG:31466', 2617899, 5470356, 2807329, 5738376);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14298, 'EPSG:31468', 4182142, 5478309, 4392607, 5730152);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14298, 'EPSG:31469', 4964419, 5495318, 5185283, 5738832);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14299, 'EPSG:4326', 9.1024741, 47.0828299, 13.9781535, 50.6100606);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14299, 'EPSG:31467', 3400000, 5470000, 3600000, 5730000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14299, 'EPSG:31466', 2617899, 5470356, 2807329, 5738376);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14299, 'EPSG:31468', 4182142, 5478309, 4392607, 5730152);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14299, 'EPSG:31469', 4964419, 5495318, 5185283, 5738832);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14300, 'EPSG:4326', 9.1024741, 47.0828299, 13.9781535, 50.6100606);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14300, 'EPSG:31467', 3400000, 5470000, 3600000, 5730000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14300, 'EPSG:31466', 2617899, 5470356, 2807329, 5738376);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14300, 'EPSG:31468', 4182142, 5478309, 4392607, 5730152);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14300, 'EPSG:31469', 4964419, 5495318, 5185283, 5738832);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14301, 'EPSG:4326', 10.8594, 51.1966, 15.0908, 53.6627);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14301, 'EPSG:25833', 3226000, 5679000, 3506000, 5946000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14302, 'EPSG:4326', 11.2317, 51.3099, 14.7656, 53.5639);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14302, 'EPSG:25833', 3250120, 5690400, 3483680, 5935030);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14303, 'EPSG:4326', 11.252, 51.3159, 14.7666, 53.5337);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14303, 'EPSG:25833', 3251290, 5691010, 3483750, 5931680);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14304, 'EPSG:4326', 11.2409, 51.3202, 14.7615, 53.5484);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14304, 'EPSG:25833', 3250640, 5691520, 3483400, 5933310);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14305, 'EPSG:4326', 11.2409, 51.3202, 14.7615, 53.5484);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14305, 'EPSG:25833', 3250640, 5691520, 3483400, 5933310);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14306, 'EPSG:4326', 11.2409, 51.3202, 14.7615, 53.5484);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14306, 'EPSG:25833', 3250640, 5691520, 3483400, 5933310);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14307, 'EPSG:4326', 11.2394, 51.3212, 14.7654, 53.5254);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14307, 'EPSG:25833', 3250400, 5691640, 3483670, 5930750);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14308, 'EPSG:4326', 11.232, 51.3302, 14.759, 53.5607);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14308, 'EPSG:25833', 3250120, 5692660, 3483230, 5934670);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14309, 'EPSG:4326', 11.6416, 51.3336, 14.736, 53.4882);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14309, 'EPSG:25833', 3276960, 5691790, 3481630, 5926610);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14310, 'EPSG:4326', 11.2393, 51.3127, 14.7641, 53.5593);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14310, 'EPSG:25833', 3250600, 5690680, 3483580, 5934520);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14311, 'EPSG:4326', 11.3238, 51.3172, 14.7548, 53.5632);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14311, 'EPSG:25833', 3256240, 5690920, 3482930, 5934960);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14312, 'EPSG:4326', 11.2459, 51.3585, 14.7403, 53.4965);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14312, 'EPSG:25833', 3250670, 5695780, 3481940, 5927540);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14313, 'EPSG:4326', 11.9598, 51.3326, 14.7545, 53.5259);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14313, 'EPSG:25833', 3298310, 5690790, 3482910, 5930810);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14314, 'EPSG:4326', 11.232, 51.3302, 14.759, 53.5607);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14314, 'EPSG:25833', 3250120, 5692660, 3483230, 5934670);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14315, 'EPSG:4326', 11.2317, 51.3099, 14.7656, 53.5639);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14315, 'EPSG:25833', 3250120, 5690400, 3483680, 5935030);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14331, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14331, 'EPSG:31468', 4500038.05625261, -10000959.9491005, 4500018.65616468, 10000963.6477023);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14332, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14333, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14334, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14335, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14336, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14337, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14338, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14339, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14340, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14341, 'EPSG:4326', 10.8594, 51.1966, 15.0908, 53.6627);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14341, 'EPSG:25833', 3226000, 5679000, 3506000, 5946000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14342, 'EPSG:4326', 11.2317, 51.3099, 14.7656, 53.5639);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14342, 'EPSG:25833', 3250120, 5690400, 3483680, 5935030);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14343, 'EPSG:4326', 11.2317, 51.3099, 14.7656, 53.5639);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14343, 'EPSG:25833', 3250120, 5690400, 3483680, 5935030);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14344, 'EPSG:4326', 11.2317, 51.3099, 14.7656, 53.5639);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14344, 'EPSG:25833', 3250120, 5690390, 3483680, 5935030);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14345, 'EPSG:4326', 12.3551, 51.6655, 14.607, 52.5623);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14345, 'EPSG:25833', 3320610, 5727020, 3472840, 5823650);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14346, 'EPSG:4326', 11.2317, 51.3099, 14.7656, 53.5639);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14346, 'EPSG:25833', 3250120, 5690390, 3483680, 5935030);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14347, 'EPSG:4326', 10.8594, 51.1966, 15.0908, 53.6627);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14347, 'EPSG:25833', 3226000, 5679000, 3506000, 5946000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14348, 'EPSG:4326', 13.0773, 52.3311, 13.7647, 52.6794);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14348, 'EPSG:25833', 3369990, 5799580, 3415840, 5837330);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14349, 'EPSG:4326', 11.2317, 51.3099, 14.7656, 53.5639);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14349, 'EPSG:25833', 3250120, 5690390, 3483680, 5935030);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14350, 'EPSG:4326', 11.5254, 51.3507, 14.7581, 53.5638);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14350, 'EPSG:25833', 3269640, 5694020, 3483170, 5935030);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14351, 'EPSG:4326', 11.2423, 51.3099, 14.7656, 53.4443);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14351, 'EPSG:25833', 3250120, 5690390, 3483680, 5921730);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14352, 'EPSG:4326', 12.3551, 51.6655, 14.607, 52.5623);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14352, 'EPSG:25833', 3320610, 5727020, 3472840, 5823650);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14353, 'EPSG:4326', 11.2317, 51.3099, 14.7656, 53.5639);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14353, 'EPSG:25833', 3250120, 5690390, 3483680, 5935030);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14354, 'EPSG:4326', 11.2317, 51.3099, 14.7656, 53.5639);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14354, 'EPSG:25833', 3250120, 5690390, 3483680, 5935030);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14355, 'EPSG:4326', 14.1131, 51.5791, 14.7644, 53.3307);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14355, 'EPSG:25833', 3440930, 5714570, 3483680, 5909090);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14356, 'EPSG:4326', 11.2317, 51.3099, 14.7656, 53.5639);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14356, 'EPSG:25833', 3250120, 5690390, 3483680, 5935030);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14357, 'EPSG:4326', 11.5254, 51.3507, 14.7581, 53.5638);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14357, 'EPSG:25833', 3269640, 5694020, 3483170, 5935030);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14358, 'EPSG:4326', 11.2423, 51.3099, 14.7656, 53.4443);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14358, 'EPSG:25833', 3250120, 5690390, 3483680, 5921730);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14359, 'EPSG:4326', 11.2317, 51.3099, 14.7656, 53.5639);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14359, 'EPSG:25833', 3250120, 5690390, 3483680, 5935030);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14360, 'EPSG:4326', 11.0754, 51.3018, 14.8564, 53.6087);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14360, 'EPSG:25833', 3240000, 5690000, 3490000, 5940000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14363, 'EPSG:4326', -96.8329648913099, 43.4354233336639, -89.3971941330158, 49.3476309343152);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14363, 'EPSG:26915', 189783.56, 4816309.33, 761653.524114166, 5472346.5);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14364, 'EPSG:4326', -96.8329648913099, 43.4354233336639, -89.3971941330158, 49.3476309343152);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14364, 'EPSG:26915', 189783.56, 4816309.33, 761653.524114166, 5472346.5);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14365, 'EPSG:4326', -96.6896094858591, 43.4678610757743, -90.2662440768246, 48.8960809237559);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14365, 'EPSG:26915', 201546.545454836, 4819387.71744188, 700359.227135391, 5419506.69963278);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14366, 'EPSG:4326', -96.5808680438111, 43.4957271572427, -90.2692873942091, 48.8402253233196);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14366, 'EPSG:26915', 210476.580151152, 4822098.3048364, 700359.227135391, 5413290.56497099);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14370, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14371, 'EPSG:27700', 486600, 252275, 699975, 468500);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14372, 'EPSG:27700', 448175, 94725, 687950, 311275);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14373, 'EPSG:27700', 394575, 0, 664700, 166775);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14374, 'EPSG:27700', 416675, 401275, 673000, 629925);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14375, 'EPSG:27700', 374700, 241850, 630925, 472075);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14376, 'EPSG:27700', 333375, 85600, 588825, 314850);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14377, 'EPSG:27700', 290975, 0, 547150, 157000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14378, 'EPSG:27700', 273575, 241775, 527050, 469275);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14379, 'EPSG:27700', 227900, 85175, 481800, 312825);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14380, 'EPSG:27700', 183300, -70850, 437550, 156050);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14381, 'EPSG:27700', 266375, 552450, 521275, 783075);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14382, 'EPSG:27700', 219975, 400225, 467925, 626850);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14383, 'EPSG:27700', 175100, 239575, 427200, 473675);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14384, 'EPSG:27700', 126200, 83475, 378750, 317625);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14385, 'EPSG:27700', 77250, 0, 330325, 162500);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14386, 'EPSG:27700', 219000, 707075, 478650, 940925);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14387, 'EPSG:27700', 167650, 551900, 426000, 785850);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14388, 'EPSG:27700', 116450, 397125, 375275, 631050);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14389, 'EPSG:27700', 175700, 857400, 443275, 1101625);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14390, 'EPSG:27700', 126050, 706000, 383125, 946625);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14391, 'EPSG:27700', 65825, 550675, 333075, 795300);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14392, 'EPSG:27700', 10650, 396500, 278750, 641475);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14393, 'EPSG:27700', 91625, 860925, 351000, 1104650);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14394, 'EPSG:27700', 32175, 708775, 292100, 952800);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14395, 'EPSG:27700', 464375, 163875, 699975, 374800);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14396, 'EPSG:27700', 435900, 47625, 676025, 258875);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14397, 'EPSG:27700', 424525, 409575, 668000, 623200);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14398, 'EPSG:27700', 382600, 250575, 625550, 464975);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14399, 'EPSG:27700', 340850, 93675, 583925, 308375);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14400, 'EPSG:27700', 299000, 0, 539525, 150800);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14401, 'EPSG:27700', 329100, 404825, 574400, 622500);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14402, 'EPSG:27700', 282200, 247525, 527700, 465400);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14403, 'EPSG:27700', 237275, 91900, 482800, 310025);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14404, 'EPSG:27700', 191700, 0, 437125, 153250);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14405, 'EPSG:27700', 348325, 823675, 473900, 936200);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14406, 'EPSG:27700', 323650, 741500, 449825, 854375);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14407, 'EPSG:27700', 276350, 559700, 523700, 780575);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14408, 'EPSG:27700', 228375, 403850, 476250, 625050);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14409, 'EPSG:27700', 180000, 247250, 428125, 468575);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14410, 'EPSG:27700', 131650, 92700, 379675, 314325);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14411, 'EPSG:27700', 82325, 0, 330400, 157925);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14412, 'EPSG:27700', 350800, 1133025, 479125, 1247450);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14413, 'EPSG:27700', 436100, 1109000, 565675, 1223575);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14414, 'EPSG:27700', 228050, 714075, 477700, 938500);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14415, 'EPSG:27700', 171975, 558775, 422000, 783275);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14416, 'EPSG:27700', 120775, 404750, 371150, 629325);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14417, 'EPSG:27700', 342950, 1089300, 471475, 1205800);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14418, 'EPSG:27700', 188325, 866975, 440625, 1094800);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14419, 'EPSG:27700', 134950, 714550, 387275, 942350);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14420, 'EPSG:27700', 80425, 560500, 332925, 788500);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14421, 'EPSG:27700', 14100, 402875, 293850, 639375);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14422, 'EPSG:27700', 35225, 717325, 289775, 948325);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14423, 'EPSG:27700', -22650, 565225, 229150, 795750);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14424, 'EPSG:27700', -81025, 413325, 171250, 643925);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14425, 'EPSG:27700', 71600, 881350, 203525, 1001425);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14426, 'EPSG:27700', -53200, 722525, 201225, 956175);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14427, 'EPSG:27700', 31.574083, -37.5, 700006.574083, 1268962.5);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14428, 'EPSG:27700', -312469.469464, -105151.706531, 774980.530536, 1381198.293469);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14429, 'EPSG:27700', -312469.469464, -105151.706531, 774980.530536, 1381198.293469);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14430, 'EPSG:27700', 0, 0, 700000, 1050000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14431, 'EPSG:27700', 12.5, -12.5, 700012.5, 1049987.5);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14432, 'EPSG:4326', -9.002056, 59.336366, 3.258564, 68.905961);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14433, 'EPSG:4326', -9.002056, 59.336366, 3.258564, 68.905961);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14434, 'EPSG:32630', 156942.393222, 6582441.602458, 871792.393222, 7642216.602458);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14435, 'EPSG:27700', 12.5, -12.5, 700012.5, 1049987.5);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14436, 'EPSG:27700', 7.5, -7.5, 700012.5, 1049992.5);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14437, 'EPSG:27700', 7.5, -7.5, 700012.5, 1049992.5);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14438, 'EPSG:4326', -9.001912, 59.336298, 3.258566, 68.905819);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14439, 'EPSG:4326', -9.001912, 59.336298, 3.258604, 68.905808);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14440, 'EPSG:27700', 0, -50000, 700000, 1050000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14441, 'EPSG:27700', 0, -50000, 700000, 1050000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14442, 'EPSG:27700', 0, -50000, 700000, 1050000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14443, 'EPSG:27700', 0, 0, 700005, 1050000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14444, 'EPSG:27700', 123740, 897710, 203690, 975720);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14445, 'NONE', 103940, 848210, 183190, 926230);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14446, 'NONE', 103940, 848210, 183190, 926230);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14447, 'NONE', 67370, 747860, 146130, 825980);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14448, 'NONE', 47560, 698410, 126340, 776050);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14449, 'NONE', 200130, 940360, 301000, 1029170);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14450, 'NONE', 175690, 890780, 277160, 979040);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14451, 'NONE', 152030, 841230, 253240, 929480);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14452, 'NONE', 152030, 841230, 253240, 929480);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14453, 'NONE', 127820, 791580, 229280, 879250);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14454, 'NONE', 104490, 741880, 205250, 830490);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14455, 'NONE', 78300, 692100, 181280, 781390);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14456, 'NONE', 55820, 642360, 157140, 730960);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14457, 'NONE', 273390, 939850, 370350, 1025680);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14458, 'NONE', 236100, 891900, 321430, 972170);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14459, 'NONE', 226100, 842490, 303870, 918970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14460, 'NONE', 197150, 787360, 304840, 879760);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14461, 'NONE', 189400, 742130, 267880, 818660);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14462, 'NONE', 157090, 689460, 256010, 768920);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14463, 'NONE', 142350, 638990, 242050, 718410);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14464, 'NONE', 139130, 591590, 217130, 667580);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14465, 'NONE', 89640, 536810, 183830, 622760);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14466, 'NONE', 83720, 489290, 170480, 569770);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14467, 'EPSG:27700', 63760, 439010, 149630, 519350);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14468, 'NONE', 305510, 989790, 392690, 1051930);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14469, 'NONE', 290280, 892340, 367990, 968580);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14470, 'NONE', 286490, 841370, 364260, 917650);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14471, 'NONE', 268070, 790950, 345900, 867310);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14472, 'NONE', 249620, 740420, 327440, 816890);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14473, 'NONE', 229990, 689690, 309130, 767010);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14474, 'NONE', 210600, 639150, 289710, 716410);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14475, 'NONE', 191110, 588480, 270240, 665760);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14476, 'NONE', 171530, 537820, 250740, 615080);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14477, 'EPSG:27700', 372285, 585825, 452305, 661295);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14478, 'EPSG:27700', 363075, 532905, 453345, 613135);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14479, 'NONE', 306290, 379790, 382270, 454230);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14480, 'EPSG:27700', 290155, 328175, 366095, 402575);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14481, 'EPSG:27700', 263525, 274805, 365795, 350935);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14482, 'NONE', 241985, 220855, 346325, 308285);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14483, 'NONE', 215225, 169935, 318445, 255545);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14484, 'EPSG:27700', 204265, 66455, 314905, 143535);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14485, 'EPSG:27700', 192185, 13825, 302855, 91385);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14486, 'EPSG:27700', 384115, 481895, 490035, 557045);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14487, 'EPSG:27700', 415425, 430165, 516485, 505425);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14488, 'EPSG:27700', 395285, 378665, 487295, 459645);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14489, 'EPSG:27700', 382195, 327535, 472515, 401805);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14490, 'EPSG:27700', 369655, 275075, 460955, 349795);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14491, 'EPSG:27700', 298485, 222695, 393765, 298335);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14492, 'EPSG:27700', 285865, 170815, 381335, 246325);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14493, 'EPSG:27700', 273055, 118845, 369455, 194205);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14494, 'EPSG:27700', 273615, 67725, 349975, 142005);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14495, 'EPSG:27700', 228105, 15175, 311035, 92355);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14496, 'EPSG:27700', 363875, 119695, 439405, 193345);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14497, 'EPSG:27700', 320525, 63345, 425545, 148685);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14498, 'EPSG:27700', 460295, 483945, 559265, 557405);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14499, 'EPSG:27700', 449585, 432215, 546835, 505605);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14500, 'EPSG:27700', 454015, 380335, 549445, 453825);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14501, 'EPSG:27700', 445435, 328675, 535395, 401355);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14502, 'EPSG:27700', 416595, 275435, 514075, 349465);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14503, 'EPSG:27700', 395425, 224355, 470815, 297945);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14504, 'EPSG:27700', 379585, 172065, 455125, 245655);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14505, 'EPSG:27700', 484175, 324145, 570855, 396985);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14506, 'EPSG:27700', 466305, 277375, 549985, 353585);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14507, 'EPSG:27700', 423085, 169225, 527255, 253025);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14508, 'EPSG:27700', 395145, 117095, 497405, 200595);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14509, 'EPSG:27700', 375955, 64485, 478535, 147925);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14510, 'EPSG:27700', 469545, 120505, 556875, 197375);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14511, 'EPSG:27700', 452755, 67715, 540195, 144495);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14512, 'EPSG:27700', 519645, 278735, 606495, 355645);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14513, 'EPSG:27700', 550735, 228995, 631185, 300415);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14514, 'EPSG:27700', 511705, 174305, 590525, 247605);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14515, 'EPSG:27700', 570665, 278265, 678125, 362725);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14516, 'EPSG:27700', 568425, 228065, 654825, 304685);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14517, 'EPSG:27700', 572335, 176865, 649505, 248635);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14518, 'EPSG:27700', 561825, 124745, 639645, 197645);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14519, 'EPSG:27700', 520145, 69005, 607175, 145365);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14520, 'EPSG:27700', 375960, 64480, 497410, 200590);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14525, 'EPSG:4326', 140.537, -37.636, 156.659, -27.898);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14525, 'EPSG:4202', 140.537, -37.636, 156.659, -27.898);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14526, 'EPSG:4326', 140.537, -37.636, 156.659, -27.898);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14526, 'EPSG:4202', 140.537, -37.636, 156.659, -27.898);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14527, 'EPSG:4326', -3.1503, 41.9024, -1.6448, 42.6531);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14527, 'EPSG:23030', 488000, 4640000, 612000, 4722500);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14527, 'EPSG:25830', 487892.2243, 4639790.9922, 611892.363, 4722291.9192);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14527, 'EPSG:4258', -3.1503, 41.9024, -1.6448, 42.6531);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14534, 'EPSG:4326', 8.785390846, 45.9248788321, 17.6062161051, 49.4022813601);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14534, 'EPSG:31297', 58924.5, 224170.5, 720024.5, 632545.5);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14535, 'EPSG:4326', 8.6226502162, 45.8310324329, 17.7539230344, 49.5098520322);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14550, 'EPSG:4326', -93.0888, 44.9554, -93.0761, 44.9644);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14550, 'EPSG:26915', 493000, 4978000, 494000, 4979000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14551, 'EPSG:4326', -97.3732, 43.3076, -89.2598, 49.5221);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14551, 'EPSG:26915', 183000, 4802400, 771000, 5485500);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14552, 'EPSG:4326', -97.3732, 43.3076, -89.2598, 49.5221);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14552, 'EPSG:26915', 183000, 4802400, 771000, 5485500);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14553, 'EPSG:4326', -97.3732, 43.3076, -89.2598, 49.5221);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14553, 'EPSG:26915', 183000, 4802400, 771000, 5485500);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14554, 'EPSG:4326', -97.3732, 43.3076, -89.2598, 49.5221);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14554, 'EPSG:26915', 183000, 4802400, 771000, 5485500);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14555, 'EPSG:4326', -97.3732, 43.3076, -89.2598, 49.5221);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14555, 'EPSG:26915', 183000, 4802400, 771000, 5485500);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14556, 'EPSG:4326', -97.3732, 43.3076, -89.2598, 49.5221);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14556, 'EPSG:26915', 183000, 4802400, 771000, 5485500);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14557, 'EPSG:4326', -180, 15, -60, 70);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14558, 'EPSG:4326', -168.0028, 13.16666, 145.84166, 70.74974);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14559, 'EPSG:4326', -168.002790909091, 13.1666636363636, 145.841663636364, 70.7497454545455);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14560, 'EPSG:4326', -168.00279, 13.166667, 145.841667, 70.749748);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14561, 'EPSG:4326', -179.417007446289, 2.01963041071291, -59.484196186877, 83.115061);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14562, 'EPSG:4326', -179.133315, 17.6306782, 174.14553505, 65.634111);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14563, 'EPSG:4326', -178.314587, -16.808033, 179.911314, 83.115061);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14564, 'EPSG:4326', -179.416673, 17.570499, 174.599997, 65.649221);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14565, 'EPSG:4326', -179.416673, 17.570499, 174.599997, 65.649221);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14566, 'EPSG:4326', -123.690444, 28.9010332, -71.0727931, 46.257853);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14567, 'EPSG:4326', -179.416673, 17.570499, 174.599997, 65.649221);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14568, 'EPSG:4326', -177.210799, 17.674404, -64.730146, 61.26251);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14569, 'EPSG:4326', -179.434339, 17.570499, 174.6100157, 65.67628);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14570, 'EPSG:4326', -177.824998, 17.6313607, 173.559592, 65.649221);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14571, 'EPSG:4326', -179.072439, 17.6739318, 174.523309, 65.649221);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14572, 'EPSG:4326', -179.416673, 17.570499, 174.599997, 65.649221);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14573, 'EPSG:4326', -149.798707, 59.8840864, -146.183655, 61.182685);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14574, 'EPSG:4326', -159.360993, 21.2991522, -68.2187339, 61.1221932);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14575, 'EPSG:4326', -179.416673, 17.570499, 174.599997, 65.649221);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14576, 'EPSG:4326', -123.873845, 17.9921576, -66.7459442, 48.4590284);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14577, 'EPSG:4326', -178.839298, 17.674091, 174.180624, 61.266866);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14578, 'EPSG:4326', -151.666636, 25.7553372, -71.0338287, 61.1274767);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14579, 'EPSG:4326', -151.343633, 29.5548897, -70.003014, 59.5858981);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14580, 'EPSG:4326', -82.691356, 25.7480285, -70.1621819, 43.7195551);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14581, 'EPSG:4326', -158.0212405, 17.6946007, -64.6434756, 46.533644);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14582, 'EPSG:4326', -123.818004, 38.79251, -74.67054, 48.66038);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14583, 'EPSG:4326', -177.061473, 18.082528, 173.3485039, 52.8443511);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14584, 'EPSG:4326', -97.287952, 25.7672562, -73.7157316, 48.159469);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14585, 'EPSG:4326', -170.215519, 17.7614408, -64.6467576, 57.237724);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14586, 'EPSG:4326', -122.2551493, 18.483704, -66.558643, 41.7279576);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14587, 'EPSG:4326', -151.789743, 17.9501286, -65.8380233, 60.814276);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14588, 'EPSG:4326', -167.941909, 21.34911, -70.9513069, 65.562148);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14589, 'EPSG:4326', -122.408295, 25.7822109, -76.0221937, 47.671176);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14590, 'EPSG:4326', -92.29425, 43.1073571, -77.627636, 46.663967);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14591, 'EPSG:4326', -159.40218, 18.2563204, 174.599997, 59.7331829);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14592, 'EPSG:4326', -147.0730777, 25.751391, -69.904706, 60.852508);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14593, 'EPSG:4326', -123.3998729, 18.2883333, -64.9183333, 48.1696688);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14594, 'EPSG:4326', -123.7860787, 17.9805842, -66.7415825, 47.7040453);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14595, 'EPSG:4326', -178.873329, 32.8312246, -68.0998244, 57.411646);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14596, 'EPSG:4326', -122.1065921, 38.0823454, -72.5005361, 40.8898247);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14597, 'EPSG:4326', -95.13073, 28.4088089, -74.0677561, 40.6790985);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14598, 'EPSG:4326', -122.6382455, 27.925092, -70.737668, 47.666166);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14599, 'EPSG:4326', -122.7278243, 32.6199413, -67.3108402, 48.1594339);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14600, 'EPSG:4326', -146.3454318, 42.3533034, -71.0417298, 61.1254001);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14601, 'EPSG:4326', -145.7959601, 30.378355, -76.5755729, 60.622014);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14602, 'EPSG:4326', -122.2534793, 25.771918, -74.0734215, 46.7856622);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14603, 'EPSG:4326', -157.9590393, 21.3597944, -76.4982694, 44.1739514);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14604, 'EPSG:4326', -176.5133997, 17.9948141, -66.7606123, 61.2333697);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14605, 'EPSG:4326', -147.420406, 35.9975122, -70.599447, 61.019103);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14606, 'EPSG:4326', -157.8828484, 21.3171389, -74.00661, 60.536307);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14607, 'EPSG:4326', -178.001689, 17.695848, 173.200504, 65.51871);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14608, 'EPSG:4326', -175.253428, 18.4140795, -65.991309, 65.554206);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14609, 'EPSG:4326', -174.1787696, 17.6830969, -64.431643, 65.380829);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14610, 'EPSG:4326', -177.200609, 17.711646, 173.212346, 61.1276888);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14611, 'EPSG:4326', -147.0297143, 29.1568333, -69.749446, 60.977114);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14612, 'EPSG:4326', -179.077072, 17.6539615, 174.524761, 61.332782);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14613, 'EPSG:4326', -147.0698428, 29.1283333, -69.7407904, 60.982194);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14614, 'EPSG:4326', -179.072439, 17.6739318, 174.15604, 65.623835);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14615, 'EPSG:4326', -177.200147, 18.1877687, -64.9515631, 61.241274);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14616, 'EPSG:4326', -148.0650501, 27.487141, -67.3134345, 60.908454);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14617, 'EPSG:4326', -174.907222, 18.2880276, -64.8996109, 60.4705648);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14618, 'EPSG:4326', -122.763315, 36.825537, -68.822799, 48.626737);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14619, 'EPSG:4326', -169.674085, 17.676023, -64.6982881, 61.208652);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14620, 'EPSG:4326', -176.860337, 17.7508513, 174.158795, 61.245271);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14621, 'EPSG:4326', -169.674085, 17.676023, -64.6982881, 61.208652);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14622, 'EPSG:4326', -123.4673803, 18.3117528, -64.9257177, 48.4186387);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14623, 'EPSG:4326', -157.9665207, 18.2282544, -65.6042951, 47.743673);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14624, 'EPSG:4326', -176.6291833, 17.6299957, -64.43, 65.625554);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14625, 'EPSG:4326', -81.0801506, 32.0972356, -73.339399, 40.927002);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14626, 'EPSG:4326', -122.681372, 27.8191419, -83.114875, 48.788484);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14627, 'EPSG:4326', -93.2158176, 28.4081635, -76.3167954, 41.8497536);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14628, 'EPSG:4326', -123.92672, 29.6723537, -69.863496, 48.441498);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14629, 'EPSG:4326', -159.3592806, 17.972252, -64.9199829, 60.665665);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14630, 'EPSG:4326', -158.0877294, 18.426144, -66.157441, 48.13442);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14631, 'EPSG:4326', -84.292804, 24.664888, -76.094405, 46.484041);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14632, 'EPSG:4326', -166.731926, 17.7462122, -64.6644242, 61.314511);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14633, 'EPSG:4326', -165.8090521, 17.7080551, 173.19011, 61.231266);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14634, 'EPSG:4326', -170.284168, 17.9780524, -64.9223943, 61.234919);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14635, 'EPSG:4326', -88.076425, 17.7149487, -64.7013962, 43.4666544);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14636, 'EPSG:4326', -122.3914585, 26.1151904, -71.0264112, 43.0299206);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14637, 'EPSG:4326', -123.095614, 37.2501975, -70.8759418, 47.549616);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14638, 'EPSG:4326', -176.6559769, 17.6873138, -64.663057, 61.234715);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14639, 'EPSG:4326', -91.1088486, 29.6420746, -91.096811, 29.6592541);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14640, 'EPSG:4326', -152.5732901, 17.6872476, -64.8535236, 57.7845831);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14641, 'EPSG:4326', -158.5209454, 18.1305005, -64.9618192, 61.1989739);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14642, 'EPSG:4326', -147.0698333, 29.1283333, -69.7407904, 60.982194);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14643, 'EPSG:4326', -179.416673, 17.6087823, 174.0845155, 65.312253);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14644, 'EPSG:4326', -176.6544199, 17.7496394, 173.201945, 61.1378759);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14645, 'EPSG:4326', -148.0938699, 18.0572715, -65.3164388, 60.4267627);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14646, 'EPSG:4326', -153.911021, 43.0709713, -79.0629366, 60.3648036);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14647, 'EPSG:4326', -178.045759, 17.6854024, 173.21361, 65.265551);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14648, 'EPSG:4326', -179.048086, 17.685261, 174.007275, 65.60981);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14649, 'EPSG:4326', -176.6278829, 17.676686, -64.708627, 61.211802);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14650, 'EPSG:4326', -122.523863, 17.9979716, -66.7532528, 48.766551);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14651, 'EPSG:4326', -149.3678271, 17.9708975, -66.7334902, 61.1230702);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14652, 'EPSG:4326', -178.049746, 17.67583, -64.6927626, 61.20275);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14653, 'EPSG:4326', -146.990253, 27.8042147, -73.6370117, 61.146139);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14654, 'EPSG:4326', -146.6869049, 24.6480357, -70.959444, 60.8717728);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14655, 'EPSG:4326', -122.591879, 17.937532, -65.2985433, 47.596386);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14656, 'EPSG:4326', -148.033334, 29.5330238, -71.0335922, 60.061138);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14657, 'EPSG:4326', -123.3914764, 27.839755, -76.050362, 48.732299);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14658, 'EPSG:4326', -146.2696194, 17.9489078, -65.8279805, 61.1205746);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14659, 'EPSG:4326', -75.22134, 38.98867, -75.21623, 38.9887);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14660, 'EPSG:4326', -178.049746, 17.67583, -64.6950602, 61.248568);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14661, 'EPSG:4326', -179.072439, 17.6739318, 174.523309, 65.649221);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14662, 'EPSG:4326', -170.661619, 17.7574698, -64.6980856, 60.226378);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14663, 'EPSG:4326', -179.416673, 17.630239, 174.599997, 65.649221);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14664, 'EPSG:4326', -122.6594316, 18.4334516, -66.1102009, 47.562051);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14665, 'EPSG:4326', -122.7433395, 17.982406, -66.135955, 47.665315);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14666, 'EPSG:4326', -179.072439, 17.6739318, 174.523309, 65.649221);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14667, 'EPSG:4326', -149.55974, 29.083678, -70.9721527, 59.601398);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14668, 'EPSG:4326', -122.5126668, 24.561927, -73.3745157, 47.5965147);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14669, 'EPSG:4326', -122.2532378, 28.4088639, -73.9026212, 40.8042336);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14670, 'EPSG:4326', -157.8832969, 18.2282544, -65.6042951, 48.786388);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14671, 'EPSG:4326', -122.2593229, 26.1152014, -73.4129217, 43.286807);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14672, 'EPSG:4326', -158.380582, 17.581349, -64.366252, 61.1245863);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14673, 'EPSG:4326', -148.0938699, 18.0572715, -65.3164388, 60.4267627);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14674, 'EPSG:4326', -122.262313, 25.7922958, -70.7086074, 47.078293);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14675, 'EPSG:4326', -122.633333, 37.7660248, -122.494338, 37.8128126);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14676, 'EPSG:4326', -82.9506589, 26.0352901, -80.1100902, 41.5158947);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14677, 'EPSG:4326', -157.8772442, 17.9547564, -66.0757866, 61.226394);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14678, 'EPSG:4326', -146.6828918, 18.4653277, -66.0860491, 61.1272952);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14679, 'EPSG:4326', -122.573226, 25.539578, -75.311999, 39.039603);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14680, 'EPSG:4326', -146.872782, 28.231378, -75.8914166, 60.6626383);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14681, 'EPSG:4326', -158.192592, 18.079929, 173.9227238, 60.776747);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14682, 'EPSG:4326', -178.049635, 17.673659, 174.075384, 61.294486);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14683, 'EPSG:4326', -178.733544, 17.6431778, 173.505148, 65.208855);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14684, 'EPSG:4326', -179.076601, 17.660007, 174.533146, 60.678122);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14685, 'EPSG:4326', -179.069498, 17.6610427, 174.521003, 65.479245);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14686, 'EPSG:4326', -157.8798056, 17.8991308, -66.010892, 57.7342433);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14687, 'EPSG:4326', -157.9783406, 17.9719611, -66.6154278, 48.752823);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14688, 'EPSG:4326', -177.200091, 17.693466, -64.602102, 65.245406);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14689, 'EPSG:4326', -175.044787, 17.75181, -64.703253, 61.202901);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14690, 'EPSG:4326', -178.975612, 17.615882, 174.223789, 65.546943);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14691, 'EPSG:4326', -158.127972, 21.2805, -68.1236051, 61.252777);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14692, 'EPSG:4326', -123.802231, 18.3397812, -64.9303895, 47.746255);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14693, 'EPSG:4326', -157.8772442, 17.9547564, -66.9052232, 48.6367073);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14694, 'EPSG:4326', -176.8086915, 17.688093, -64.609962, 65.559117);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14695, 'EPSG:4326', -176.6530797, 17.7557125, -64.6840563, 61.076092);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14696, 'EPSG:4326', -176.5954016, 17.65, 173.164823, 61.1291725);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14697, 'EPSG:4326', -176.8097509, 17.7539111, -64.8676262, 65.366769);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14698, 'EPSG:4326', -178.653026, 17.6937107, 173.8616688, 65.584097);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14699, 'EPSG:4326', -178.966774, 17.6833863, 174.179322, 65.535323);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14700, 'EPSG:4326', -176.5696319, 24.461296, -66.8724781, 61.1499719);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14701, 'EPSG:4326', -176.6604831, 17.682348, -64.63702, 65.633376);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14702, 'EPSG:4326', -176.63695, 17.675389, 172.898781, 61.245317);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14703, 'EPSG:4326', -146.352357, 17.9791883, -66.1157412, 61.123989);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14704, 'EPSG:4326', -178.036983, 17.6876002, -64.377471, 65.24589);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14705, 'EPSG:4326', -174.200918, 17.6867832, -64.438711, 65.606036);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14706, 'EPSG:4326', -90.0238568, 28.8626462, -89.9998514, 28.8879445);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14707, 'EPSG:4326', -158.313336, 17.6864821, -64.605697, 61.1083333);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14708, 'EPSG:4326', -157.8798056, 17.8991308, -66.010892, 60.321669);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14709, 'EPSG:4326', -176.610184, 17.6504347, -64.602473, 61.203333);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14710, 'EPSG:4326', -178.047715, 17.6777122, -64.6927626, 65.633376);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14711, 'EPSG:4326', -88.885851, 27.7238428, -67.4864676, 44.5399757);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14712, 'EPSG:4326', -176.6297043, 17.682348, -64.63702, 65.272565);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14713, 'EPSG:4326', -179.055189, 17.706557, 174.52292, 65.648978);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14714, 'EPSG:4326', -152.5477753, 18.199757, -65.574907, 57.7549659);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14715, 'EPSG:4326', -176.523072, 17.7104601, -64.430822, 61.047209);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14716, 'EPSG:4326', -166.362252, 27.884673, -77.219701, 65.249149);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14717, 'EPSG:4326', -94.8988661, 29.2644444, -70.960392, 42.295704);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14718, 'EPSG:4326', -158.0001617, 18.2229886, -65.6174178, 61.0900198);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14719, 'EPSG:4326', -123.301345, 41.7152983, -76.3733588, 48.64985);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14720, 'EPSG:4326', -123.0460333, 18.151343, -65.44412, 48.764979);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14721, 'EPSG:4326', -176.6528501, 17.9806485, -66.7629241, 51.8541401);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14722, 'EPSG:4326', -159.3624861, 17.9976859, -64.7471764, 58.38923);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14723, 'EPSG:4326', -122.8198671, 25.573464, -79.422667, 48.5871667);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14724, 'EPSG:4326', -76.384292, 37.910739, -76.384292, 37.910739);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14725, 'EPSG:4326', -124.0934667, 24.636474, -75.8920201, 46.262453);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14726, 'EPSG:4326', -123.940825, 24.712079, -70.9739331, 48.1403474);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14727, 'EPSG:4326', -80.6435367, 18.3255289, -64.933019, 43.8771718);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14728, 'EPSG:4326', -147.525442, 38.889013, -72.368917, 61.01579);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14729, 'EPSG:4326', -91.5189, 29.374109, -76.9378194, 37.4066767);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14730, 'EPSG:4326', -157.9715185, 18.3399639, -65.6201278, 61.1243534);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14731, 'EPSG:4326', -158.192993, 21.444734, -66.9093671, 59.63959);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14732, 'EPSG:4326', -122.4290233, 42.1137312, -84.29508, 47.2594324);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14733, 'EPSG:4326', -97.522882, 27.7854884, -73.5829244, 40.976648);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14734, 'EPSG:4326', -157.9398655, 17.634996, -64.705002, 60.8166667);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14735, 'EPSG:4326', -122.249712, 28.82865, -75.7040753, 47.67296);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14736, 'EPSG:4326', -123.767969, 28.949106, -70.7465404, 48.1694277);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14737, 'EPSG:4326', -147.018726, 40.8022424, -66.9182415, 61.090477);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14738, 'EPSG:4326', -146.38059, 25.516666, -74.96657, 61.090604);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14739, 'EPSG:4326', -148.008741, 24.662074, -69.940312, 60.067188);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14740, 'EPSG:4326', -157.9645212, 21.30704, -70.4961647, 47.667485);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14741, 'EPSG:4326', -122.2291712, 26.236652, 173.427385, 52.850471);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14742, 'EPSG:4326', -170.281534, 17.7463228, -64.6955461, 60.777161);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14743, 'EPSG:4326', -152.699779, 37.8285374, -71.728264, 60.091699);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14744, 'EPSG:4326', -152.5303706, 57.7114742, -152.5131859, 57.7227939);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14745, 'EPSG:4326', -66.0801394, 18.4580093, -66.0801394, 18.4580093);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14746, 'EPSG:4326', -123.1386582, 47.2651037, -122.4836313, 48.2478539);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14747, 'EPSG:4326', -169.758465, 21.2986567, -74.1566506, 60.902732);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14748, 'EPSG:4326', -76.5769267, 39.2454792, -76.5664968, 39.2636238);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14749, 'EPSG:4326', -158.387432, 17.677633, -64.654847, 59.8078702);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14750, 'EPSG:4326', -178.028112, 48.345073, 173.352744, 60.5298375);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14751, 'EPSG:4326', -176.613675, 17.7224974, 174.0602883, 65.244757);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14752, 'EPSG:4326', -178.143703, 17.675205, 173.910749, 65.556816);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14753, 'EPSG:4326', -176.6604831, 17.65, 173.180375, 65.633376);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14754, 'EPSG:4326', -122.2265199, 29.922454, -72.0538178, 48.0037033);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14755, 'EPSG:4326', -91.1925, 29.922037, -89.970623, 30.460778);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14756, 'EPSG:4326', -179.412702706026, 17.5731099607713, 174.594502081743, 65.6484117109221);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14757, 'EPSG:4326', -179.417007446289, 17.570499420166, 174.599990844727, 65.6492233276367);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14758, 'EPSG:4326', -75.8848418733, 38.3741058346, -74.9910506181, 39.8751126213);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14758, 'EPSG:102257', 166499.875, 50000.125, 232799.875, 204700.125);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14759, 'EPSG:4326', -75.8080759734, 38.449822323, -75.0334387781, 39.8432887294);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14759, 'EPSG:102257', 166499.874927962, 50000.1249279622, 321199.874927962, 204700.124927962);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14760, 'EPSG:4326', 21.0123, -34.4092, 133.253, 49.6596);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14774, 'EPSG:4326', 79.7488, 5.53607, 95.3772, 13.3426);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14775, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14776, 'EPSG:4326', 72.8939, -0.69, 98.777, 13.0211);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14777, 'EPSG:4326', -173.83, -19.1, 167.76, 53.28);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14778, 'EPSG:4326', 95.85, 3.32, 95.85, 3.32);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14783, 'EPSG:4326', 63.108, -13.8714, 95.4388, 15.632);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14786, 'EPSG:4326', 29.5869, -11.7404, 141.007, 35.5056);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14787, 'EPSG:4326', 29.5869, -11.7404, 141.007, 35.5056);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14788, 'EPSG:4326', 29.5869, -11.7404, 141.007, 35.5056);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14789, 'EPSG:4326', 29.5869, -11.7404, 141.007, 35.5056);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14790, 'EPSG:4326', 29.5869, -11.7404, 141.007, 35.5056);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14791, 'EPSG:4326', 29.5869, -11.7404, 141.007, 35.5056);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14792, 'EPSG:4326', 79.6529, 5.91683, 81.8813, 9.83136);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14793, 'EPSG:4326', 79.6529, 5.91683, 81.8813, 9.83136);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14794, 'EPSG:4326', 79.6529, 5.91683, 81.8813, 9.83136);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14795, 'EPSG:4326', 79.6529, 5.91683, 81.8813, 9.83136);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14796, 'EPSG:4326', 79.6529, 5.91683, 81.8813, 9.83136);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14800, 'EPSG:4326', -97.4903487384206, 0.00015941433421543, -97.4893223327877, 0.00064396532019009);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14800, 'EPSG:4269', -179.133392775029, 17.6746917518371, -64.5661616683301, 71.3980488018476);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14801, 'EPSG:4326', -97.4903487384206, 0.00015941433421543, -97.4893223327877, 0.00064396532019009);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14801, 'EPSG:4269', -179.133392775029, 17.6746917518371, -64.5661616683301, 71.3980488018476);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14802, 'EPSG:4326', -97.4897835821368, 0.000162348531666944, -97.4893312588231, 0.000441965361495106);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14802, 'EPSG:4269', -116.050735716279, 18, -65.5625, 49.0018077806253);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14803, 'EPSG:4326', -168.67, 17.84, -65.15, 71.55);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14804, 'EPSG:26905', 552600, 6540200, 670200, 6794800);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14804, 'EPSG:26906', 332200, 6653000, 440600, 6822600);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14804, 'EPSG:26910', 364600, 3751400, 777800, 5433600);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14804, 'EPSG:26911', 189600, 3564600, 783400, 5432200);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14804, 'EPSG:26912', 216600, 3463800, 784600, 5436200);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14804, 'EPSG:26913', 215400, 3201800, 790600, 5437600);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14804, 'EPSG:26914', 204400, 2855400, 794000, 5436400);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14804, 'EPSG:26915', 206000, 3162400, 792400, 5478800);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14804, 'EPSG:26916', 207800, 3196000, 789600, 5345400);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14804, 'EPSG:26917', 210200, 2709400, 778200, 5112800);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14804, 'EPSG:26918', 222000, 3744800, 753000, 4992000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14804, 'EPSG:26919', 247200, 1976600, 818200, 5247600);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14804, 'EPSG:26920', 181800, 1985200, 269400, 2048600);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14805, 'EPSG:26904', 366800, 2170400, 816000, 2460400);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14805, 'EPSG:26905', 178000, 2086800, 317600, 2307600);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14805, 'EPSG:26910', 359600, 3745600, 776800, 5432800);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14805, 'EPSG:26911', 218000, 3569200, 783600, 5432800);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14805, 'EPSG:26912', 216000, 3455600, 785200, 5432800);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14805, 'EPSG:26913', 214800, 3204800, 791200, 5432800);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14805, 'EPSG:26914', 208800, 2847200, 795200, 5432800);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14805, 'EPSG:26915', 205200, 3154000, 792800, 5473200);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14805, 'EPSG:26916', 207200, 3194400, 790800, 5350800);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14805, 'EPSG:26917', 209600, 2708000, 778800, 5113600);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14805, 'EPSG:26918', 217200, 3736400, 754000, 4997600);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14805, 'EPSG:26919', 246800, 4540800, 669200, 5261600);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14806, 'EPSG:26906', 332200, 6653000, 440600, 6822600);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14806, 'EPSG:26910', 364600, 3751400, 777800, 5433600);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14806, 'EPSG:26911', 189600, 3564600, 783400, 5432200);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14806, 'EPSG:26912', 216600, 3463800, 784600, 5436200);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14806, 'EPSG:26913', 215400, 3201800, 790600, 5437600);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14806, 'EPSG:26914', 204400, 2855400, 794000, 5436400);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14806, 'EPSG:26915', 206000, 3162400, 792400, 5478800);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14806, 'EPSG:26916', 207800, 3196000, 789600, 5345400);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14806, 'EPSG:26917', 210200, 2709400, 778200, 5112800);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14806, 'EPSG:26918', 222000, 3744800, 753000, 4992000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14806, 'EPSG:26919', 247200, 1976600, 818200, 5247600);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14842, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14842, 'EPSG:27700', -345532424.5141, -513987011.1625, 349465159.6083, 458560849.5658);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14842, 'EPSG:32616', -345353751.1062, -463997395.1213, 334988226.6129, 493120011.7148);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14842, 'EPSG:4267', -179.9985, -89.9986, 180.0001, 89.9986);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14851, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14852, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14854, 'EPSG:4326', -180, -60, 180, 75);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14855, 'EPSG:4326', -180, -60, 180, 75);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14857, 'EPSG:4326', -30, -35, 65, 80);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14858, 'EPSG:4326', -30, -35, 65, 80);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14859, 'EPSG:4326', -30, -35, 65, 80);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14861, 'EPSG:4326', -180, -56, 180, 60.418);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14862, 'EPSG:4326', -180, -56, 180, 60.418);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14863, 'EPSG:4326', -180, -56, 180, 60.418);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14865, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14866, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14868, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14869, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14871, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14872, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14874, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14876, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14877, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14878, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14879, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14881, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14882, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14883, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14884, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14885, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14886, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14888, 'EPSG:4326', -25, -40, 60, 40);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14889, 'EPSG:4326', -25, -40, 60, 40);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14890, 'EPSG:4326', -25.616, -37.4204, 60.4559, 37.3496);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14891, 'EPSG:4326', -25.616, -37.4204, 60.4559, 37.3496);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14892, 'EPSG:4326', -25.616, -37.4204, 60.4559, 37.3496);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14893, 'EPSG:4326', -25.616, -37.4204, 60.4559, 37.3496);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14894, 'EPSG:4326', 21.0123, -34.4092, 133.253, 49.6596);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14908, 'EPSG:4326', 79.7488, 5.53607, 95.3772, 13.3426);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14909, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14910, 'EPSG:4326', 72.8939, -0.69, 98.777, 13.0211);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14911, 'EPSG:4326', -173.83, -19.1, 167.76, 53.28);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14912, 'EPSG:4326', 95.85, 3.32, 95.85, 3.32);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14917, 'EPSG:4326', 63.108, -13.8714, 95.4388, 15.632);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14920, 'EPSG:4326', 29.5869, -11.7404, 141.007, 35.5056);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14921, 'EPSG:4326', 29.5869, -11.7404, 141.007, 35.5056);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14922, 'EPSG:4326', 29.5869, -11.7404, 141.007, 35.5056);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14923, 'EPSG:4326', 29.5869, -11.7404, 141.007, 35.5056);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14924, 'EPSG:4326', 29.5869, -11.7404, 141.007, 35.5056);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14925, 'EPSG:4326', 29.5869, -11.7404, 141.007, 35.5056);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14926, 'EPSG:4326', 79.6529, 5.91683, 81.8813, 9.83136);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14927, 'EPSG:4326', 79.6529, 5.91683, 81.8813, 9.83136);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14928, 'EPSG:4326', 79.6529, 5.91683, 81.8813, 9.83136);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14929, 'EPSG:4326', 79.6529, 5.91683, 81.8813, 9.83136);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14930, 'EPSG:4326', 79.6529, 5.91683, 81.8813, 9.83136);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14934, 'EPSG:4326', -180, -90.00833, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14935, 'EPSG:4326', -180, -90.00833, 180, 84);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14936, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14937, 'EPSG:4326', -180, -90, 180, 83.6236);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14938, 'EPSG:4326', -125.12332, -16.606266, 109.965, 67.046936);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14939, 'EPSG:4326', -164.88744, -36.969444, 160.7636, 71.39249);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14940, 'EPSG:4326', -180, -90, 180, 83.6236);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14941, 'EPSG:4326', -178.2176, 18.921785, -66.96927, 71.406235);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14942, 'EPSG:4326', -176.15157, -54.792, 179.2219, 78.2);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14943, 'EPSG:4326', -179.9401, -65.6182, 179.935, 86.8);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14944, 'EPSG:4326', -179.97, -78.25, 179.62, 88.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14945, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14946, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14947, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14948, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14949, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14950, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14951, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14952, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14953, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14954, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14955, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14956, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14957, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14958, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14959, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14960, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14961, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14962, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14963, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14964, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14965, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14966, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14967, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14968, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14969, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14970, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14971, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14972, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14973, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14974, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14975, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14976, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14977, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14978, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14979, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14980, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14981, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14982, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14983, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14984, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14985, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14986, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14987, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14988, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14989, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14990, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14991, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14992, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14993, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14994, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14995, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14996, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14997, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14998, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14999, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15000, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15001, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15002, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15003, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15004, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15005, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15006, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15007, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15008, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15009, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15010, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15337, 'EPSG:4326', 7, 42, 12, 59);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15338, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15339, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15735, 'EPSG:4326', 6.92615, 50.7877, 7.03399, 50.856);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15735, 'EPSG:31466', 2565300, 5628400, 2572800, 5635900);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15737, 'EPSG:4326', -3.69276, 45.2759, 18.4979, 55.4172);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15737, 'EPSG:31466', 1881290, 5066220, 3302060, 6143050);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15738, 'EPSG:4326', -180, -3.40166e+032, 174.615, 3.40166e+032);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15738, 'EPSG:31466', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15739, 'EPSG:4326', -180, -3.40166e+032, 174.615, 3.40166e+032);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15739, 'EPSG:31466', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15740, 'EPSG:4326', -180, -3.40166e+032, 174.615, 3.40166e+032);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15740, 'EPSG:31466', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15741, 'EPSG:4326', -180, -3.40166e+032, 174.615, 3.40166e+032);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15741, 'EPSG:31466', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15742, 'EPSG:4326', -180, -3.40166e+032, 174.615, 3.40166e+032);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15742, 'EPSG:31466', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15743, 'EPSG:4326', -180, -3.40166e+032, 174.615, 3.40166e+032);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15743, 'EPSG:31466', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15744, 'EPSG:4326', -180, -3.40166e+032, 174.615, 3.40166e+032);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15744, 'EPSG:31466', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15745, 'EPSG:4326', -180, -3.40166e+032, 174.615, 3.40166e+032);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15745, 'EPSG:31466', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15746, 'EPSG:4326', -180, -3.40166e+032, 174.615, 3.40166e+032);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15746, 'EPSG:31466', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15748, 'EPSG:4326', -180, -3.40166e+032, 174.615, 3.40166e+032);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15748, 'EPSG:31466', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15749, 'EPSG:4326', -180, -3.40166e+032, 174.615, 3.40166e+032);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15749, 'EPSG:31466', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15750, 'EPSG:4326', -180, -3.40166e+032, 174.615, 3.40166e+032);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15750, 'EPSG:31466', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15751, 'EPSG:4326', -180, -3.40166e+032, 174.615, 3.40166e+032);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15751, 'EPSG:31466', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15753, 'EPSG:4326', -180, -3.40166e+032, 174.615, 3.40166e+032);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15753, 'EPSG:31466', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15754, 'EPSG:4326', -180, -3.40166e+032, 174.615, 3.40166e+032);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15754, 'EPSG:31466', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15755, 'EPSG:4326', 6.78544, 50.7166, 7.16614, 50.9379);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15755, 'EPSG:31466', 2555460, 5620630, 2581960, 5644900);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15798, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15798, 'EPSG:4326', -184, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15799, 'EPSG:4326', -180, -90, 180, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15800, 'EPSG:4326', -184, -90, 180, 85);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15801, 'EPSG:4326', -180, -59.99999999998, 179.999999999984, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15802, 'EPSG:4326', -180, -59.99999999998, 179.999999999984, 90);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15803, 'EPSG:4326', -180, -55, 180, 75);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15804, 'EPSG:4326', -184, -90, 180, 85);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15805, 'EPSG:4326', -184, -75, 180, 85);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15806, 'EPSG:4326', -180, -50, 180, 80);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15807, 'EPSG:4326', -180, -55, 180, 85);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15808, 'EPSG:4326', -180, -55, 180, 85);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15809, 'EPSG:4326', -170, -55, 180, 80);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15810, 'EPSG:4326', -175, -55, 180, 75);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15811, 'EPSG:4326', -184, -55, 180, 75);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15812, 'EPSG:4326', -184, -50, 180, 80);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15813, 'EPSG:4326', -184, -60, 176, 75);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15814, 'EPSG:4326', -180, -55, 180, 75);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15815, 'EPSG:4326', -180, -55, 180, 85);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15816, 'EPSG:4326', -179.983093261719, -89.83837890625, 179.991439819336, 83.5204086303711);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15817, 'EPSG:4326', -184, -55, 180, 80);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15818, 'EPSG:4326', -180, -62.9231796264648, 179.999420166016, 68.6906585693359);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18068, 'EPSG:4326', 7.46, 47.49, 10.57, 49.81);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18068, 'EPSG:31467', 3383722, 5262500, 3616277, 5521500);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18069, 'EPSG:4326', 7.46, 47.49, 10.57, 49.81);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18069, 'EPSG:31467', 3383722, 5262500, 3616277, 5521500);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18070, 'EPSG:4326', 6.4505, 50.7149, 7.0359, 51.0604);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18070, 'EPSG:31466', 2531814, 5620466, 2572624, 5659316);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18070, 'EPSG:31462', 2531814, 5620466, 2572624, 5659316);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18070, 'EPSG:31492', 2531814, 5620466, 2572624, 5659316);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18075, 'EPSG:4326', 6.4505, 50.7149, 7.0359, 51.0604);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18075, 'EPSG:31466', 2531814, 5620466, 2572624, 5659316);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18075, 'EPSG:31462', 2531814, 5620466, 2572624, 5659316);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18075, 'EPSG:31492', 2531814, 5620466, 2572624, 5659316);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18080, 'EPSG:4326', 6.4505, 50.7149, 7.0359, 51.0604);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18080, 'EPSG:31466', 2531814, 5620466, 2572624, 5659316);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18080, 'EPSG:31462', 2531814, 5620466, 2572624, 5659316);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18080, 'EPSG:31492', 2531814, 5620466, 2572624, 5659316);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18085, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18085, 'EPSG:31492', 2490669.9, 5576388.9, 2738505.35221098, 5825350.11602884);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18085, 'EPSG:31466', 2490669.9, 5576388.9, 2738505.35221098, 5825350.11602884);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18085, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18085, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18085, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18086, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18086, 'EPSG:31492', 2490669.9, 5576388.9, 2738505.35221098, 5825350.11602884);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18086, 'EPSG:31466', 2490669.9, 5576388.9, 2738505.35221098, 5825350.11602884);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18086, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18086, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18086, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18087, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18087, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18087, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18087, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18087, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18088, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18088, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18088, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18088, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18088, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18089, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18089, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18089, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18089, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18089, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18090, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18090, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18090, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18090, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18090, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18091, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18091, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18091, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18091, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18091, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18092, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18092, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18092, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18092, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18092, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18093, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18093, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18093, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18093, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18093, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18094, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18094, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18094, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18094, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18094, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18095, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18095, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18095, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18095, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18095, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18096, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18096, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18096, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18096, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18096, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18097, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18097, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18097, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18097, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18097, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18098, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18098, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18098, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18098, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18098, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18099, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18099, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18099, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18099, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18099, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18100, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18100, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18100, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18100, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18100, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18101, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18101, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18101, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18101, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18101, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18102, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18102, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18102, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18102, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18102, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18103, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18103, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18103, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18103, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18103, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18104, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18104, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18104, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18104, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18104, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18105, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18105, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18105, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18105, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18105, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18119, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18119, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18119, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18119, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18119, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18120, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18120, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18120, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18120, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18120, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18121, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18121, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18121, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18121, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18121, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18122, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18122, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18122, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18122, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18122, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18123, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18123, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18123, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18123, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18123, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18124, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18124, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18124, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18124, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18124, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18125, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18125, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18125, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18125, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18125, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18126, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18126, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18126, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18126, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18126, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18127, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18127, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18127, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18127, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18127, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18128, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18128, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18128, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18128, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18128, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18129, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18129, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18129, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18129, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18129, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18130, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18130, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18130, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18130, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18130, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18131, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18131, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18131, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18131, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18131, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18132, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18132, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18132, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18132, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18132, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18133, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18133, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18133, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18133, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18133, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18134, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18134, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18134, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18134, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18134, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18135, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18135, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18135, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18135, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18135, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18136, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18136, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18136, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18136, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18136, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18137, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18137, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18137, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18137, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18137, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18138, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18138, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18138, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18138, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18138, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18139, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18139, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18139, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18139, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18139, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18140, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18140, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18140, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18140, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18140, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18141, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18141, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18141, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18141, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18141, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18142, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18142, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18142, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18142, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18142, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18143, 'EPSG:4326', 5.8682, 50.3189, 8.6519, 52.5054);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18143, 'EPSG:31492', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18145, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18145, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18145, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18145, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18145, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18146, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18146, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18146, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18146, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18146, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18147, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18147, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18147, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18147, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18147, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18148, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18148, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18148, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18148, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18148, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18149, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18149, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18149, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18149, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18149, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18150, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18150, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18150, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18150, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18150, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18151, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18151, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18151, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18151, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18151, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18152, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18152, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18152, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18152, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18152, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18153, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18153, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18153, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18153, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18153, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18154, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18154, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18154, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18154, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18154, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18155, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18155, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18155, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18155, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18155, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18156, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18156, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18156, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18156, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18156, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18157, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18157, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18157, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18157, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18157, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18158, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18158, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18158, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18158, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18158, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18159, 'EPSG:4326', 7.39549, 51.8027, 7.83995, 52.0774);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18159, 'EPSG:31467', 3390000, 5742000, 3420000, 5772000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18164, 'EPSG:4326', -180, -4.52677e+032, 176.991, 4.52677e+032);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18164, 'EPSG:31467', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18165, 'EPSG:4326', -180, -4.52677e+032, 176.991, 4.52677e+032);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18165, 'EPSG:31467', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18166, 'EPSG:4326', -180, -4.52677e+032, 176.991, 4.52677e+032);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18166, 'EPSG:31467', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18167, 'EPSG:4326', -180, -4.52677e+032, 176.991, 4.52677e+032);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18167, 'EPSG:31467', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18168, 'EPSG:4326', 2546442.5, 5629738.5, 2612351.5, 5690679);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18169, 'EPSG:4326', 2546442.5, 5629738.5, 2574239, 5690679);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18170, 'EPSG:4326', 2593889.2, 5662005.5, 2609059, 5669772);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18171, 'EPSG:4326', 2579495.5, 5670734.5, 2586469.8, 5679051.5);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18172, 'EPSG:4326', 2563368.2, 5652735.5, 2612351.5, 5687238.5);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18173, 'EPSG:4326', 2563368.2, 5652735.5, 2612351.5, 5687238.5);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18174, 'EPSG:4326', 2566194.5, 5650761, 2612288.8, 5687441.5);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18175, 'EPSG:4326', 2566194.5, 5650761, 2612288.8, 5687441.5);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18176, 'EPSG:4326', 2563139.2, 5653338, 2598613, 5687438.5);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18177, 'EPSG:4326', 2566194, 5650736.5, 2612255.8, 5687418.5);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18178, 'EPSG:4326', 2566094, 5650929.5, 2611978.2, 5687202.5);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18179, 'EPSG:4326', 2566094, 5650892, 2612015.5, 5687211);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18180, 'EPSG:4326', 2566094, 5650866, 2612040.5, 5687229.5);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18181, 'EPSG:4326', 2565684, 5650966.5, 2611954.8, 5687197);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18182, 'EPSG:4326', 2568289.8, 5650979.5, 2611939.5, 5687154);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18183, 'EPSG:4326', 2567540.2, 5651123.5, 2610584, 5686884.5);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18184, 'EPSG:4326', 2565684, 5650966.5, 2611954.8, 5687197);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18185, 'EPSG:4326', 2574368.5, 5657951.5, 2609796.2, 5680451.5);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18186, 'EPSG:4326', 2568024, 5657404.5, 2610590.5, 5676478.5);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18187, 'EPSG:4326', 2566160.2, 5650970.5, 2611941.8, 5687151);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18188, 'EPSG:4326', 2566094, 5650970.5, 2611941, 5687106.5);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18189, 'EPSG:4326', 2568246.5, 5655120.5, 2610520, 5682874.5);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18190, 'EPSG:4326', 2568200.5, 5655310, 2609614.8, 5684705);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18191, 'EPSG:4326', 2569725.2, 5652906.5, 2610202.8, 5683943.5);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18192, 'EPSG:4326', 2567619.8, 5655330.5, 2610201.8, 5682797);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18193, 'EPSG:4326', 2567619.8, 5655330.5, 2607229.8, 5682797);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18194, 'EPSG:4326', 2574521.2, 5654207.5, 2598042.2, 5685821);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18195, 'EPSG:4326', 2571850.8, 5655250, 2610579, 5684825);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18196, 'EPSG:4326', 2568205.8, 5655293, 2606643.5, 5684697);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18205, 'EPSG:4326', 8.37676, 51.9156, 8.68781, 52.1168);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18205, 'EPSG:31467', 3457310, 5753550, 3478520, 5775790);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18207, 'EPSG:4326', -180, -4.52677e+032, 176.991, 4.52677e+032);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18207, 'EPSG:31467', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18208, 'EPSG:4326', -180, -4.52677e+032, 176.991, 4.52677e+032);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18208, 'EPSG:31467', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18210, 'EPSG:4326', -180, -4.52677e+032, 176.991, 4.52677e+032);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18210, 'EPSG:31467', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18211, 'EPSG:4326', -180, -4.52677e+032, 176.991, 4.52677e+032);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18211, 'EPSG:31467', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18213, 'EPSG:4326', -180, -4.52677e+032, 176.991, 4.52677e+032);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18213, 'EPSG:31467', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18214, 'EPSG:4326', -180, -4.52677e+032, 176.991, 4.52677e+032);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18214, 'EPSG:31467', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18216, 'EPSG:4326', -180, -4.52677e+032, 176.991, 4.52677e+032);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18216, 'EPSG:31467', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18217, 'EPSG:4326', -180, -4.52677e+032, 176.991, 4.52677e+032);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18217, 'EPSG:31467', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18218, 'EPSG:4326', 8.37676, 51.9156, 8.68781, 52.1168);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18218, 'EPSG:31467', 3457310, 5753550, 3478520, 5775790);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18227, 'EPSG:4326', -180, -4.52677e+032, 176.991, 4.52677e+032);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18227, 'EPSG:31467', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18228, 'EPSG:4326', -180, -4.52677e+032, 176.991, 4.52677e+032);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18228, 'EPSG:31467', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18230, 'EPSG:4326', -180, -4.52677e+032, 176.991, 4.52677e+032);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18230, 'EPSG:31467', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18231, 'EPSG:4326', -180, -4.52677e+032, 176.991, 4.52677e+032);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18231, 'EPSG:31467', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18233, 'EPSG:4326', -180, -4.52677e+032, 176.991, 4.52677e+032);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18233, 'EPSG:31467', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18234, 'EPSG:4326', -180, -4.52677e+032, 176.991, 4.52677e+032);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18234, 'EPSG:31467', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18235, 'EPSG:4326', 8.35451189433807, 51.9089799444053, 8.69098195743338, 52.1193351046263);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18235, 'EPSG:31467', 3455652, 5752972, 3478906, 5776226);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18236, 'EPSG:4326', 8.35451189433807, 51.9089799444053, 8.69098195743338, 52.1193351046263);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18236, 'EPSG:31467', 3455652, 5752972, 3478906, 5776226);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18237, 'EPSG:4326', 8.35451189433807, 51.9089799444053, 8.69098195743338, 52.1193351046263);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18237, 'EPSG:31467', 3455652, 5752972, 3478906, 5776226);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18238, 'EPSG:4326', 8.35451189433807, 51.9089799444053, 8.69098195743338, 52.1193351046263);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18238, 'EPSG:31467', 3455652, 5752972, 3478906, 5776226);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18239, 'EPSG:4326', 8.35451189433807, 51.9089799444053, 8.69098195743338, 52.1193351046263);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18239, 'EPSG:31467', 3455652, 5752972, 3478906, 5776226);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18240, 'EPSG:4326', 8.35451189433807, 51.9089799444053, 8.69098195743338, 52.1193351046263);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18240, 'EPSG:31467', 3455652, 5752972, 3478906, 5776226);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18241, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18241, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18241, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18241, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18241, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18242, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18242, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18242, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18242, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18242, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18243, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18243, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18243, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18243, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18243, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18244, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18244, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18244, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18244, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18244, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18245, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18245, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18245, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18245, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18245, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18246, 'EPSG:4326', 5.86214438119609, 50.2758785264961, 9.51136899529965, 52.5503363944171);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18246, 'EPSG:31466', 2490217.39732242, 5571104.84471283, 2750321.92833604, 5829939.37824083);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18246, 'EPSG:31467', 3276415.28939716, 5571218.70445849, 3536527.86806821, 5828768.60697208);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18246, 'EPSG:31468', 4062726.19199224, 5574053.87943491, 4331309.71462349, 5841861.56505894);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18246, 'EPSG:31469', 4849263.53311334, 5585514.90270094, 5127978.02983409, 5863474.23398516);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18246, 'EPSG:25831', 694051.604464286, 5573226.16336796, 963792.436617757, 5842194.02530665);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18246, 'EPSG:25832', 276430.655067927, 5569430.14485848, 536439.384865941, 5826879.37234734);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18246, 'EPSG:25833', -150612.77949327, 5583728.8589265, 127992.233617833, 5861578.77999188);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18274, 'EPSG:4326', 5.8682, 50.3189, 8.6519, 52.5054);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18274, 'EPSG:31492', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18275, 'EPSG:4326', 2738496, 77673, 5821724, 625065);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18276, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18276, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18276, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18276, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18276, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18277, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18277, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18277, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18277, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18277, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18278, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18278, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18278, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18278, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18278, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18279, 'EPSG:4326', 5.673, 49.9944, 10.142, 52.7691);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18279, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18279, 'EPSG:31467', 3261513.05, 5545534.73, 3577127.98, 5849530.15);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18279, 'EPSG:25832', 261533.79, 5543758.24, 577026.2, 5847631.27);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18279, 'EPSG:25833', -149462, 5580271.61, 127822, 5858091.88);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19006, 'EPSG:4326', 5.60075, 47.2441, 15.425, 55.0317);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19006, 'EPSG:31467', 3282450, 5248260, 3912240, 6100130);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19007, 'EPSG:4326', 5.86563, 47.2758, 15, 55.0556);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19008, 'EPSG:4326', 5.86563, 47.2758, 15, 55.0556);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19009, 'EPSG:4326', 5.86417, 47.2747, 15.0389, 55.0567);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19010, 'EPSG:4326', 6.05223, 47.4825, 14.9981, 54.9405);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19011, 'EPSG:4326', 5.86629, 47.2736, 15.0486, 55.0583);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19012, 'EPSG:4326', 5.98259, 47.4064, 15, 54.9045);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19013, 'EPSG:4326', 5.95192, 47.2864, 14.9759, 54.9107);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19014, 'EPSG:4326', 5.90508, 47.3136, 14.9981, 55.0157);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19015, 'EPSG:4326', 6.01667, 47.4, 15, 54.9);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19016, 'EPSG:4326', 5.86629, 47.2736, 15.0486, 55.0583);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19017, 'EPSG:4326', 6.01667, 47.4, 15, 54.9);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19018, 'EPSG:4326', 5.86417, 47.2747, 15.0389, 55.0567);
+-- Daten für Tabelle `layer_style`
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (5576, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (5577, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (5578, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (7256, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (7257, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (7259, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (7260, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (7261, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (7262, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (7263, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (7264, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (7265, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (7266, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (7267, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9666, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9667, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9668, 'white', 'white', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9669, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9670, '0xb8d8f6', '0xb8d8f6', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9671, 'transparent/black', 'transparent/black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9672, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9673, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9675, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9676, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9677, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9678, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9679, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9680, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9681, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9682, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9683, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9684, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9685, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9686, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9688, 'grey50', 'grey50', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9689, 'grey10', 'grey10', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9691, 'COLORMAP_ETOPO5', 'COLORMAP_ETOPO5', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9692, 'classic', 'classic', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9692, 'classic shaded', 'classic shaded', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9692, 'desaturated', 'desaturated', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9692, 'desaturated shaded', 'desaturated shaded', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9692, 'color', 'color', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9692, 'color shaded', 'color shaded', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9694, 'chocolate', 'chocolate', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9695, 'sandybrown', 'sandybrown', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9697, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9698, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9699, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9700, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9702, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9703, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9704, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9706, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9708, 'darkblue', 'darkblue', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9709, 'darkblue', 'darkblue', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9710, 'black/white', 'black/white', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9711, '0xb8d8f6/0x101040', '0xb8d8f6/0x101040', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9712, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9713, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9714, '0x101040', '0x101040', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9716, 'pink', 'pink', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9717, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9718, 'lightgreen', 'lightgreen', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9719, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9720, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9721, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9723, 'brown', 'brown', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9724, 'snow4', 'snow4', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9725, 'wheat', 'wheat', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9726, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9727, 'powderblue', 'powderblue', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9729, '0xff8080', '0xff8080', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9730, 'purple', 'purple', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9731, 'purple', 'purple', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9732, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9733, '0x0000FF', '0x0000FF', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9735, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9736, 'grey50', 'grey50', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9737, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9738, '0x760000', '0x760000', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9739, '0xaa1818', '0xaa1818', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9740, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9741, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9742, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9743, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9744, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9746, 'grey10', 'grey10', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9747, 'grey10', 'grey10', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9748, 'grey10', 'grey10', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9749, 'grey10', 'grey10', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9750, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9752, '0xf5deb3', '0xf5deb3', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9753, '0x00df00', '0x00df00', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9754, '0x78bb3e', '0x78bb3e', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9755, '0x28a028', '0x28a028', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9756, '0xaaa24e', '0xaaa24e', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9760, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9761, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9762, 'navy', 'navy', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9763, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9764, '0xb8d8f6', '0xb8d8f6', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9765, 'transparent/black', 'transparent/black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9766, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9767, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9769, 'grey50', 'grey50', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9770, 'grey10', 'grey10', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9772, 'Classic', 'Classic', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9772, 'Classic Shaded', 'Classic Shaded', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9773, 'classic shaded', 'classic shaded', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9773, 'desaturated', 'desaturated', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9773, 'desaturated shaded', 'desaturated shaded', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9773, 'color', 'color', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9773, 'color shaded', 'color shaded', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9773, 'SHADE', 'SHADE', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9773, 'classic', 'classic', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9773, 'ELEV_NOSHADE', 'Elevations No Shade', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9773, 'Low Elevation Spread', 'Low Elevation Spread', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9774, 'RELIEF', 'RELIEF', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9776, 'chocolate', 'chocolate', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9777, 'sandybrown', 'sandybrown', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9779, 'darkblue', 'darkblue', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9780, 'darkblue', 'darkblue', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9781, 'black/white', 'black/white', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9782, '0xb8d8f6/navy', '0xb8d8f6/navy', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9783, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9784, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9785, 'navy', 'navy', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9787, 'pink', 'pink', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9788, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9789, 'lightgreen', 'lightgreen', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9790, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9791, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9792, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9794, 'brown', 'brown', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9795, 'snow4', 'snow4', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9796, 'wheat', 'wheat', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9797, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9798, 'powderblue', 'powderblue', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9800, '0xfe8080', '0xfe8080', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9801, 'purple', 'purple', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9802, 'purple', 'purple', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9803, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9804, '0x0000FE', '0x0000FE', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9806, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9807, 'grey50', 'grey50', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9808, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9809, '0x760000', '0x760000', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9810, '0xaa1818', '0xaa1818', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9811, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9812, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9813, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9814, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9815, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9817, 'grey10', 'grey10', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9818, 'grey10', 'grey10', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9819, 'grey10', 'grey10', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9820, 'grey10', 'grey10', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9821, 'black', 'black', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9823, '0xf5deb3', '0xf5deb3', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9824, '0x00df00', '0x00df00', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9825, '0x78bb3e', '0x78bb3e', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9826, '0x28a028', '0x28a028', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9827, '0xaaa24e', '0xaaa24e', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9830, 'Classic', 'Classic', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9830, 'Landscape', 'Landscape', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9830, 'Low Relief Spread', 'Low Relief Spread', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9831, 'Classic', 'Classic', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9831, 'Landscape', 'Landscape', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9831, 'Topographic', 'Topographic', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9834, 'COLORMAP_ROX', 'COLORMAP_ROX', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9835, 'red', 'red', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9837, 'COLORMAP_GEN', 'COLORMAP_GEN', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9838, 'red', 'red', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9839, 'COLORMAP_FLS', 'COLORMAP_FLS', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9840, 'COLORMAP_MAF', 'COLORMAP_MAF', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9841, 'COLORMAP_PRE', 'COLORMAP_PRE', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9864, 'footprint', 'Footprints', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9864, 'orthorectification', 'Orthorectification', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9864, 'ellipsoid', 'Ellipsoidcorrected', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9869, 'footprint', 'Footprints', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9869, 'orthorectification', 'Orthorectification', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9869, 'ellipsoid', 'Ellipsoidcorrected', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9873, '10 degree', '10 degree', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9873, '5 degree', '5 degree', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9873, '2 degree', '2 degree', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9873, '1 degree', '1 degree', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9873, '0.2 degree', '0.2 degree', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9874, 'red wire', 'red wire', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9874, 'green wire', 'green wire', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9874, 'blue wire', 'blue wire', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9874, 'yellow wire', 'yellow wire', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9874, 'magenta wire', 'magenta wire', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9874, 'cyan wire', 'cyan wire', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9874, 'black wire', 'black wire', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (9874, 'white wire', 'white wire', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10029, '', '', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10030, '', '', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10031, '', '', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10032, '', '', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10033, '', '', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10034, '', '', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10035, '', '', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10036, '', '', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10037, '', '', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10038, '', '', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10039, '', '', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10040, '', '', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10041, '', '', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10042, '', '', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10043, '', '', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10044, '', '', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10045, '', '', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10046, '', '', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10107, 'bluedot', 'Australasian Cities', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10108, 'bluedot', 'Australian Captial Cities', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10109, 'bluedot', 'Some Australian towns', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10110, 'bluedot', 'Wastewater artificial wetlands', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10166, 'pseudo', 'Pseudo-color image, pan sharpened (Uses IR and Vis', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10166, 'visual', 'Real-color image, pan sharpened (Uses the visual b', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10167, 'pseudo', 'Pseudo-color image (Uses IR and Visual bands, 542', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10167, 'visual', 'Real-color image (Uses the visual bands, 321 mappi', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10167, 'Pan', 'Pan-chromatic band, grayscale', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10167, 'Red', 'Visual Red band, grayscale', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10167, 'Green', 'Visual Green band, grayscale', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10167, 'Blue', 'Visual Blue band, grayscale', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10167, 'IR1', ' Near IR band 1, (Landsat band 4), grayscale', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10167, 'IR2', ' Near IR band 2, (Landsat band 5), grayscale', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10167, 'IR3', ' Near IR band 2, (Landsat band 7), grayscale', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10167, 'ThL', ' Thermal band, low gain, grayscale', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10167, 'ThH', ' Thermal band, high gain, grayscale', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10168, 'pseudo', 'Pseudo-color image (Uses IR and Visual bands, 542', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10168, 'visual', 'Real-color image (Uses the visual bands, 321 mappi', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10168, 'Red', 'Visual Red band, grayscale', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10168, 'Green', 'Visual Green band, grayscale', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10168, 'Blue', 'Visual Blue band, grayscale', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10168, 'IR1', ' Near IR band 1, (Landsat band 4), grayscale', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10168, 'IR2', ' Near IR band 2, (Landsat band 5), grayscale', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10168, 'IR3', ' Near IR band 2, (Landsat band 7), grayscale', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10169, 'default', 'Progressive vector derived overlay data', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10170, 'default', 'Progressive vector derived overlay data, MRLC back', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10171, 'default', 'visual', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10172, 'default', 'visual', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10173, 'default', 'Default MODIS Image, color', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10174, 'default', 'Default Elevation Style,', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10175, 'default', 'Default Elevation Style, scaled to 8 bit using a n', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10175, 'short_int', 'short int elevation values when format is image/pn', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10176, 'default', 'Default Elevation Style, scaled to 8 bit using a n', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10176, 'short_int', 'short int elevation values when format is image/pn', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10177, 'default', 'Default Elevation', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10178, 'default', 'Default Elevation', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10178, 'short_int', 'short int elevation values when format is image/pn', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10179, 'default', 'Default Color Elevation', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10195, 'Normal', 'Normal', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10196, 'Normal', 'Normal', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10197, 'Normal', 'Normal', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10198, 'Normal', 'Normal', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10199, 'Normal', 'Normal', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10200, 'Normal', 'Normal', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10370, '', '', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10371, '', '', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10988, '', '', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10992, '', '', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10993, '', '', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10994, '', '', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10995, '', '', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (11630, '', 'Forstamtsgrenzen', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (13752, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (13754, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (13776, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (13777, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14106, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14108, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14109, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14110, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14111, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14168, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14169, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14170, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14171, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14172, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14173, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14174, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14175, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14176, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14187, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14191, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14257, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14257, 'invert', 'invert', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14265, 'default', 'Uebersicht Sachsen, default style', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14266, 'default', 'Topog. Karte 1:100000, default style', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14267, 'default', 'tk100-Schriften, default style', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14268, 'default', 'tk100-Gewaesser, default style', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14269, 'default', 'tk100-Grundriss, default style', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14270, 'default', 'tk100-Hoehenlinien, default style', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14271, 'default', 'tk100-Vegetation, default style', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14272, 'default', 'Topog. Karte 1:50000, default style', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14273, 'default', 'tk50-Gewaesser, default style', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14274, 'default', 'tk50-Grundriss, default style', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14275, 'default', 'tk50-Hoehenlinien, default style', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14276, 'default', 'tk50-Vegetation, default style', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14288, 'default:Thueringer_Orthofotos', 'default:Thueringer_Orthofotos', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14289, 'default:Orthophotos_TH-2m', 'default:Orthophotos_TH-2m', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14290, 'default:TK50', 'default:TK50', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14291, 'default:Top.Karte_50_gesamt', 'default:Top.Karte_50_gesamt', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14292, 'default:Grundriss', 'default:Grundriss', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14293, 'default:Gewaesser', 'default:Gewaesser', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14294, 'default:Hoehenschichten', 'default:Hoehenschichten', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14295, 'default:Strassen', 'default:Strassen', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14296, 'default:Wald', 'default:Wald', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14297, 'default', 'default', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14297, 'invert', 'invert', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14332, 'default:Thueringer_Orthofotos', 'default:Thueringer_Orthofotos', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14333, 'default:Orthophotos_TH-2m', 'default:Orthophotos_TH-2m', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14334, 'default:TK50', 'default:TK50', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14335, 'default:Top.Karte_50_gesamt', 'default:Top.Karte_50_gesamt', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14336, 'default:Grundriss', 'default:Grundriss', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14337, 'default:Gewaesser', 'default:Gewaesser', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14338, 'default:Hoehenschichten', 'default:Hoehenschichten', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14339, 'default:Strassen', 'default:Strassen', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14340, 'default:Wald', 'default:Wald', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14526, 'default', 'Image with no additional enhancement', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14528, 'Default', 'Default', 'http://wms.larioja.org/Legends/ortofoto_Default.png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14529, 'Default', 'Default', 'http://wms.larioja.org/Legends/Cuadricula_Default.png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14530, 'Default', 'Default', 'http://wms.larioja.org/Legends/Nucleos_Default.png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14531, 'Default', 'Default', 'http://wms.larioja.org/Legends/Rios_Default.png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14532, 'Default', 'Default', 'http://wms.larioja.org/Legends/municipios_Default.png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14533, 'Default', 'Default', 'http://wms.larioja.org/Legends/Carreteras_Default.png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14774, 'default', 'default', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=locations&format=image/png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14776, 'default', 'default', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Wave_Heights&format=image/png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14777, 'default', 'default', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=earthquakes&format=image/png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14778, 'default', 'default', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=epicenter&format=image/png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14783, 'default', 'default', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=oceans&format=image/png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14786, 'default', 'default', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=gdp&format=image/png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14787, 'default', 'default', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=gdpper&format=image/png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14788, 'default', 'default', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=extdebt&format=image/png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14789, 'default', 'default', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=density&format=image/png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14790, 'default', 'default', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=population&format=image/png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14791, 'default', 'default', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=deaths&format=image/png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14792, 'default', 'default', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=SriLanka_deaths&format=image/png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14793, 'default', 'default', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=SriLanka_injured&format=image/png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14794, 'default', 'default', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=SriLanka_missing&format=image/png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14795, 'default', 'default', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=SriLanka_displaced&format=image/png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14796, 'default', 'default', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=SriLanka_camps&format=image/png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14804, 'UTMGrid', 'Goldedrod Grid Lines on UTM coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14804, 'GeoGrid', 'Goldenrod Grid Lines on Geographic coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14804, 'UTMGrid_Red', 'Red Grid Lines on UTM coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14804, 'GeoGrid_Red', 'Red Grid Lines on Geographic coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14804, 'UTMGrid_Green', 'Green Grid Lines on UTM coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14804, 'GeoGrid_Green', 'Green Grid Lines on Geographic coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14804, 'UTMGrid_Blue', 'Blue Grid Lines on UTM coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14804, 'GeoGrid_Blue', 'Blue Grid Lines on Geographic coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14804, 'UTMGrid_Cyan', 'Cyan Grid Lines on UTM coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14804, 'GeoGrid_Cyan', 'Cyan Grid Lines on Geographic coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14804, 'UTMGrid_Magenta', 'Magenta Grid Lines on UTM coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14804, 'GeoGrid_Magenta', 'Magenta Grid Lines on Geographic coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14804, 'UTMGrid_White', 'White Grid Lines on UTM coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14804, 'GeoGrid_White', 'White Grid Lines on Geographic coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14804, 'UTMGrid_Black', 'Black Grid Lines on UTM coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14804, 'GeoGrid_Black', 'Black Grid Lines on Geographic coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14804, 'UTMGrid_Gray', 'Gray Grid Lines on UTM coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14804, 'GeoGrid_Gray', 'Gray Grid Lines on Geographic coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14805, 'UTMGrid', 'Goldenrod Grid Lines on UTM coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14805, 'GeoGrid', 'Goldenrod Grid Lines on Geographic coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14805, 'UTMGrid_Red', 'Red Grid Lines on UTM coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14805, 'GeoGrid_Red', 'Red Grid Lines on Geographic coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14805, 'UTMGrid_Green', 'Green Grid Lines on UTM coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14805, 'GeoGrid_Green', 'Green Grid Lines on Geographic coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14805, 'UTMGrid_Blue', 'Blue Grid Lines on UTM coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14805, 'GeoGrid_Blue', 'Blue Grid Lines on Geographic coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14805, 'UTMGrid_Cyan', 'Cyan Grid Lines on UTM coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14805, 'GeoGrid_Cyan', 'Cyan Grid Lines on Geographic coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14805, 'UTMGrid_Magenta', 'Magenta Grid Lines on UTM coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14805, 'GeoGrid_Magenta', 'Magenta Grid Lines on Geographic coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14805, 'UTMGrid_White', 'White Grid Lines on UTM coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14805, 'GeoGrid_White', 'White Grid Lines on Geographic coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14805, 'UTMGrid_Black', 'Black Grid Lines on UTM coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14805, 'GeoGrid_Black', 'Black Grid Lines on Geographic coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14805, 'UTMGrid_Gray', 'Gray Grid Lines on UTM coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14805, 'GeoGrid_Gray', 'Gray Grid Lines on Geographic coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14806, 'UTMGrid', 'Goldedrod Grid Lines on UTM coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14806, 'GeoGrid', 'Goldenrod Grid Lines on Geographic coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14806, 'UTMGrid_Red', 'Red Grid Lines on UTM coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14806, 'GeoGrid_Red', 'Red Grid Lines on Geographic coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14806, 'UTMGrid_Green', 'Green Grid Lines on UTM coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14806, 'GeoGrid_Green', 'Green Grid Lines on Geographic coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14806, 'UTMGrid_Blue', 'Blue Grid Lines on UTM coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14806, 'GeoGrid_Blue', 'Blue Grid Lines on Geographic coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14806, 'UTMGrid_Cyan', 'Cyan Grid Lines on UTM coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14806, 'GeoGrid_Cyan', 'Cyan Grid Lines on Geographic coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14806, 'UTMGrid_Magenta', 'Magenta Grid Lines on UTM coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14806, 'GeoGrid_Magenta', 'Magenta Grid Lines on Geographic coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14806, 'UTMGrid_White', 'White Grid Lines on UTM coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14806, 'GeoGrid_White', 'White Grid Lines on Geographic coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14806, 'UTMGrid_Black', 'Black Grid Lines on UTM coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14806, 'GeoGrid_Black', 'Black Grid Lines on Geographic coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14806, 'UTMGrid_Gray', 'Gray Grid Lines on UTM coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14806, 'GeoGrid_Gray', 'Gray Grid Lines on Geographic coordinates', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14843, 'Default', 'Default', 'http://maps1.intergraph.com/wms/world/Legends/GLOBEImage_Default.png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14844, 'Transparent', 'Transparent', 'http://maps1.intergraph.com/wms/world/Legends/ADMIN_Transparent.png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14845, 'Transparent', 'Transparent', 'http://maps1.intergraph.com/wms/world/Legends/COUNTRY_Transparent.png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14846, 'LightBlue', 'LightBlue', 'http://maps1.intergraph.com/wms/world/Legends/Lakes_LightBlue.png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14847, 'Brown', 'Brown', 'http://maps1.intergraph.com/wms/world/Legends/RAILWAY_Brown.png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14848, 'Default', 'Default', 'http://maps1.intergraph.com/wms/world/Legends/WorldGridLines_Default.png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14849, 'Darkblue', 'Darkblue', 'http://maps1.intergraph.com/wms/world/Legends/OCEAN_TEXT_Darkblue.png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14850, 'Red', 'Red', 'http://maps1.intergraph.com/wms/world/Legends/CAPITALS_Red.png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14908, 'default', 'default', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=locations&format=image/png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14910, 'default', 'default', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Wave_Heights&format=image/png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14911, 'default', 'default', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=earthquakes&format=image/png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14912, 'default', 'default', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=epicenter&format=image/png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14917, 'default', 'default', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=oceans&format=image/png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14920, 'default', 'default', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=gdp&format=image/png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14921, 'default', 'default', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=gdpper&format=image/png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14922, 'default', 'default', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=extdebt&format=image/png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14923, 'default', 'default', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=density&format=image/png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14924, 'default', 'default', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=population&format=image/png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14925, 'default', 'default', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=deaths&format=image/png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14926, 'default', 'default', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=SriLanka_deaths&format=image/png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14927, 'default', 'default', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=SriLanka_injured&format=image/png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14928, 'default', 'default', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=SriLanka_missing&format=image/png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14929, 'default', 'default', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=SriLanka_displaced&format=image/png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14930, 'default', 'default', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=SriLanka_camps&format=image/png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14951, 'Simple', 'Simple Map Style', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (15338, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/mapbender_user/mapbender_user.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Mapbender_User&format=image/png', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (15738, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=atkis_wes_1_umn_pl&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (15739, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=atkis_wes_1_umn_l&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (15740, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=atkis_wes_3_layer1_pl&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (15741, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=atkis_wes_3_layer2_pl&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (15742, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=atkis_wes_3_layer3_pl&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (15743, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=atkis_wes_3_layer4_pl&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (15744, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=atkis_wes_3_layer5_pl&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (15745, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=atkis_wes_3_layer6_l&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (15746, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Flüsse&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (15748, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=WES_DSK_füllung1&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (15749, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=WES_DSK_umring&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (15750, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=WES_DSK_füllung2&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (15751, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Stadtgrenze&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (15753, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=wes_dsk_strnamen_umn_1_t&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (15754, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=wes_dsk_strnamen_umn_2_t&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18086, '', 'Forstamtsgrenzen', 'http://www.gis2.nrw.de/verbundprojekt/Legend/Fortsamtsgr/Forstamtsgrenze.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18088, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/gewstat/uebrigeGewaessergroesser12mBreite.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18089, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/gewstat/uebrigeGewaesserkleiner12mBreite.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18090, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/gewstat/Kanaelegroesser12mBreite.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18091, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/gewstat/Kanaelekleiner12mBreite.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18092, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/gewstat/unterirdischeGewaesser.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18093, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/gewstat/Fliessgewaessergroesser12mBreite.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18094, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/gewstat/Fliessgewaesserkleiner12mBreite_trs.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18095, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/gewstat/STAT_EIG_1kmPkt_Kanal.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18096, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/gewstat/STAT_EIG_1kmPkt_RhuW.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18097, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/gewstat/STAT_EIG_1kmPkt_Fliessgew.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18098, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/gewstat/STAT_EIG_500mPkt_Kanal.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18099, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/gewstat/STAT_EIG_500mPkt_RhuW.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18100, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/gewstat/STAT_EIG_500mPkt_Fliessgew.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18101, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/gewstat/STAT_EIG_100mPkt_Kanal.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18102, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/gewstat/STAT_EIG_100mPkt_RhuW.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18103, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/gewstat/STAT_EIG_100mPkt_Fliessgew.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18104, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/gewstat/Stationierungslinie.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18105, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/gewstat/Fluesse.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18120, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/Hochwasser/rhein_hq100_odeich_trs.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18121, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/Hochwasser/rhein_hq100_mdeich_trs.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18122, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/Hochwasser/rhein_hq200_odeich_trs.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18123, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/Hochwasser/rhein_hq200_mdeich_trs.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18124, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/Hochwasser/rhein_hq500_odeich_trs.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18125, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/Hochwasser/rhein_hq500_mdeich_trs.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18126, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/Hochwasser/UESG_vereinfVerfahren_trs.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18127, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/Hochwasser/sonstigeUESG_trs.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18128, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/Hochwasser/historischeUESG_trs.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18129, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/Hochwasser/NeueBerechngsverf_trs.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18130, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/Hochwasser/Seen_trs.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18131, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/Hochwasser/Talsperre_trs.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18133, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/stobo/Blei_Acker_trs.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18134, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/stobo/Cadmium_Acker_trs.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18135, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/stobo/Zink_Acker_trs.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18136, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/stobo/Blei_Garten_trs.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18137, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/stobo/Cadmium_Garten_trs.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18138, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/stobo/Zink_Garten_trs.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18139, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/stobo/Blei_Gruenland_trs.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18140, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/stobo/Cadmium_Gruenland_trs.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18141, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/stobo/Zink_Gruenland_trs.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18142, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/stobo/Nutzung_trs.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18146, '', 'Vegetationstypen', 'http://www.gis2.nrw.de/verbundprojekt/Legend/linfos/Vegtyp.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18147, '', 'Vegetationsaufnahmen', 'http://www.gis2.nrw.de/verbundprojekt/Legend/linfos/Vegaufnahme_trs.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18148, '', 'Naturräumliche Haupteinheiten', 'http://www.gis2.nrw.de/verbundprojekt/Legend/linfos/Naturraum.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18149, '', 'Landschaftsschutzgebiete', 'http://www.gis2.nrw.de/verbundprojekt/Legend/linfos/LSSG.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18150, '', 'Stand der Landschaftsplanung', 'http://www.gis2.nrw.de/verbundprojekt/Legend/linfos/LSPlan.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18151, '', 'FFH-Gebiete', 'http://www.gis2.nrw.de/verbundprojekt/Legend/linfos/FFH.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18152, '', 'Vogelschutzgebiete', 'http://www.gis2.nrw.de/verbundprojekt/Legend/linfos/VSG.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18153, '', 'Biotoptypen', 'http://www.gis2.nrw.de/verbundprojekt/Legend/linfos/Biotoptyp.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18154, '', 'Biotopkataster', 'http://www.gis2.nrw.de/verbundprojekt/Legend/linfos/Biotopkataster.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18155, '', 'Naturschutzgebiete', 'http://www.gis2.nrw.de/verbundprojekt/Legend/linfos/NSG.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18157, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/hangneigung/hangneigung_trs.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18158, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/hangneigung/fliessgewaesser_trs.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18207, 'default', 'default', 'http://212.8.208.50/umn/wms_gebgli.asp?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=stadtbezirke_pl&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18208, 'default', 'default', 'http://212.8.208.50/umn/wms_gebgli.asp?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=stadtbezirke_t&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18210, 'default', 'default', 'http://212.8.208.50/umn/wms_gebgli.asp?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=statist_bez_pl&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18211, 'default', 'default', 'http://212.8.208.50/umn/wms_gebgli.asp?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=statist_bez_t&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18213, 'default', 'default', 'http://212.8.208.50/umn/wms_gebgli.asp?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=verkehrszellen_pl&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18214, 'default', 'default', 'http://212.8.208.50/umn/wms_gebgli.asp?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=verkehrszellen_t&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18216, 'default', 'default', 'http://212.8.208.50/umn/wms_gebgli.asp?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=baubloecke_pl&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18217, 'default', 'default', 'http://212.8.208.50/umn/wms_gebgli.asp?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=baubloecke_t&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18227, 'default', 'default', 'http://212.8.208.50/umn/wms_wahlen.asp?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=stadtbezirke_pl&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18228, 'default', 'default', 'http://212.8.208.50/umn/wms_wahlen.asp?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=stadtbezirke_t&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18230, 'default', 'default', 'http://212.8.208.50/umn/wms_wahlen.asp?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=wahlbezirke_pl&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18231, 'default', 'default', 'http://212.8.208.50/umn/wms_wahlen.asp?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=wahlbezirke_t&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18233, 'default', 'default', 'http://212.8.208.50/umn/wms_wahlen.asp?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=stimmbezirke_pl&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18234, 'default', 'default', 'http://212.8.208.50/umn/wms_wahlen.asp?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=stimmbezirke_t&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18236, 'default', '1, default style', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18237, 'default', '2, default style', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18238, 'default', '5, default style', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18239, 'default', '8, default style', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18240, 'default', '9, default style', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18242, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/wsg/TrinkwasserZ1pkt_trs.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18243, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/wsg/twsg_trs.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18244, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/wsg/HeilquellenZ1pkt_trs.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18245, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/wsg/hsg_trs.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18247, 'OhneKennung', 'Ohne Straßennamen', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18247, 'MitKennung', 'Mit Straßennamen', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18247, 'NurKennung', 'Nur Straßennamen', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18252, 'OhneKennung', 'Ohne Netzknotenkennung', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18252, 'MitKennungKurz', 'Mit 3-stelliger Kennung', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18252, 'MitKennungLang', 'Mit 7-stelliger Kennung', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18252, 'MitNamen', 'Mit Netzknotennamen', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18252, 'NurKennungKurz', 'Nur 3-stellige Kennung', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18252, 'NurKennungLang', 'Nur 7-stellige Kennung', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18252, 'NurName', 'Nur Netzknotenname', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18257, 'OhneKennung', 'Ohne Nullpunktskennung', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18257, 'MitKennungBuchstabe', 'Mit Nullpunkts-Buchstabe', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18257, 'MitKennungKurz', 'Mit 3-stelliger Kennung und Buchstabe', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18257, 'MitKennungLang', 'Mit 7-stelliger Kennung und Buchstabe', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18257, 'NurKennungBuchstabe', 'Nur Nullpunkts-Buchstabe', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18257, 'NurKennungKurz', 'Nur 3-stellige Kennung und Buchstabe', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18257, 'NurKennungLang', 'Nur 7-stellige Kennung und Buchstabe', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18263, 'alleBereiche', 'alle Bereiche', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18268, 'MitKennung', 'mit Kennung', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18268, 'MitDTV', 'mit DTV-Wert', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18268, 'MitKennung+DTV', 'mit Kennung und DTV-Wert', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18268, 'OhneBeschriftung', 'ohne Beschriftung', '', '');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18277, '', '', 'http://www.gis2.nrw.de/verbundprojekt/Legend/Waldtyp/Waldtyp_trs.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19007, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Topographie&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19008, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Grenze&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19009, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Bundeslaender&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19010, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Staedte&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19011, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Postleitzahlbereiche&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19012, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Bahnlinien&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19013, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Fluesse&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19014, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Strassen&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19015, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Staedtepunkte&format=image/png', 'image/png');
+-- Daten für Tabelle `mb_group`
+INSERT INTO mb_group (mb_group_id, mb_group_name, mb_group_owner, mb_group_description) VALUES (20, 'mapbender_release', 1, 'group for the mapbender release, only user is root');
+-- Daten für Tabelle `mb_log`
+-- Daten für Tabelle `mb_user`
+INSERT INTO mb_user (mb_user_id, mb_user_name, mb_user_password, mb_user_owner, mb_user_description, mb_user_login_count, mb_user_email, mb_user_phone, mb_user_department, mb_user_resolution, mb_user_organisation_name, mb_user_position_name, mb_user_phone1, mb_user_facsimile, mb_user_delivery_point, mb_user_city, mb_user_postal_code, mb_user_country, mb_user_online_resource) VALUES (1, 'root', 'root', 1, 'root', 0, '', '', '', 72, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL);
+-- Daten für Tabelle `mb_user_mb_group`
+INSERT INTO mb_user_mb_group (fkey_mb_user_id, fkey_mb_group_id) VALUES (1, 20);
+-- Daten für Tabelle `mb_user_wmc`
+-- Daten für Tabelle `wfs`
+INSERT INTO wfs (wfs_id, wfs_version, wfs_name, wfs_title, wfs_abstract, wfs_getcapabilities, wfs_describefeaturetype, wfs_getfeature, wfs_transaction) VALUES (1, '1.0.0', 'My GeoServer WFS', 'My GeoServer WFS', 'This is a description of your Web Feature Server.The GeoServer is a full transactional Web Feature Server, you may wish to limitGeoServer to a Basic service level to prevent modificaiton of your geographicdata.', 'http://wms1.ccgis.de:80/geoserver/wfs/GetCapabilities?', 'http://wms1.ccgis.de:80/geoserver/wfs/DescribeFeatureType?', 'http://wms1.ccgis.de:80/geoserver/wfs/GetFeature?', 'http://wms1.ccgis.de:80/geoserver/wfs/Transaction?');
+-- Daten für Tabelle `wfs_conf`
+INSERT INTO wfs_conf (wfs_conf_id, wfs_conf_abstract, fkey_wfs_id, fkey_featuretype_id, g_label, g_label_id, g_button, g_button_id, g_style, g_buffer, g_res_style, g_use_wzgraphics) VALUES (1, 'Mapbender User', 1, 4, 'Mapbender_User:', 'a', 'OK', 'b', '.a{\r\n font-weight:bold;\r\n}\r\n.b{\r\n width:40px;\r\n}\r\n.c{\r\n position:absolute;\r\n width:100px;\r\n left:75px;\r\n}', 0.01, '.even{\r\ncolor:blue;\r\n}\r\n.uneven{\r\ncolor:red;\r\n}', 0);
+-- Daten für Tabelle `wfs_conf_element`
+INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (1, 1, 46, 0, 1, 0, 0, '', 0, '', '', 0, 0);
+INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (2, 1, 47, 0, 0, 1, 1, 'c', 0, 'Firstname:', '', 1, 2);
+INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (3, 1, 48, 0, 0, 1, 2, 'c', 0, 'Lastname:', '', 1, 1);
+INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (4, 1, 49, 0, 0, 0, 0, '', 0, '', '', 0, 0);
+INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (5, 1, 50, 0, 0, 0, 0, '', 0, '', '', 0, 0);
+INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (6, 1, 51, 0, 0, 0, 0, '', 0, '', '', 0, 0);
+INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (7, 1, 52, 0, 0, 0, 0, '', 0, '', '', 0, 0);
+INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (8, 1, 53, 0, 0, 0, 0, '', 0, '', '', 0, 0);
+INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (9, 1, 54, 0, 0, 0, 0, '', 0, '', '', 0, 0);
+INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (10, 1, 55, 0, 0, 0, 0, '', 0, '', '', 0, 0);
+INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (11, 1, 56, 1, 0, 0, 0, '', 0, '', '', 0, 0);
+-- Daten für Tabelle `wfs_element`
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (1, 1, 'gid', 'int');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (1, 2, 'objectid', 'int');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (1, 3, 'area', 'double');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (1, 4, 'perimeter', 'double');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (1, 5, 'pppoint_', 'int');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (1, 6, 'pppoint_id', 'int');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (1, 7, 'pppttype', 'int');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (1, 8, 'ppptname', 'string');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (1, 9, 'ppptflag', 'int');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (1, 10, 'polygonid', 'int');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (1, 11, 'scale', 'double');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (1, 12, 'angle', 'int');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (1, 13, 'name_neu1', 'string');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (1, 14, 'name_typ', 'int');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (1, 15, 'the_geom', 'PointPropertyType');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (2, 16, 'rc', 'int');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (2, 17, 'ufi', 'int');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (2, 18, 'uni', 'int');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (2, 19, 'lat', 'string');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (2, 20, 'long', 'string');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (2, 21, 'dms_lat', 'int');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (2, 22, 'dms_long', 'int');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (2, 23, 'utm', 'string');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (2, 24, 'jog', 'string');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (2, 25, 'fc', 'string');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (2, 26, 'dsg', 'string');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (2, 27, 'pc', 'string');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (2, 28, 'cc1', 'string');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (2, 29, 'adm1', 'int');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (2, 30, 'adm2', 'string');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (2, 31, 'dim', 'string');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (2, 32, 'cc2', 'string');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (2, 33, 'nt', 'string');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (2, 34, 'lc', 'string');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (2, 35, 'short_form', 'string');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (2, 36, 'generic', 'string');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (2, 37, 'sort_name', 'string');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (2, 38, 'full_name', 'string');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (2, 39, 'full_name_nd', 'string');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (2, 40, 'modify_date', 'string');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (2, 41, 'the_geom', 'PointPropertyType');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (3, 42, 'plz99', 'string');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (3, 43, 'plz99_n', 'int');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (3, 44, 'plzort99', 'string');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (3, 45, 'the_geom', 'MultiPolygonPropertyType');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (4, 46, 'gid', 'int');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (4, 47, 'firstname', 'string');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (4, 48, 'lastname', 'string');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (4, 49, 'usertype', 'int');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (4, 50, 'orga', 'string');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (4, 51, 'url', 'string');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (4, 52, 'town', 'string');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (4, 53, 'email', 'string');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (4, 54, 'fullname', 'string');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (4, 55, 'urlmap', 'string');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (4, 56, 'the_geom', 'PointPropertyType');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (5, 57, 'objectid', 'int');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (5, 58, 'fnode_', 'int');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (5, 59, 'tnode_', 'int');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (5, 60, 'lpoly_', 'int');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (5, 61, 'rpoly_', 'int');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (5, 62, 'length', 'double');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (5, 63, 'dnnet_', 'int');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (5, 64, 'dnnet_id', 'int');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (5, 65, 'dnlntype', 'int');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (5, 66, 'dnlnstat', 'int');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (5, 67, 'shape_leng', 'decimal');
+INSERT INTO wfs_element (fkey_featuretype_id, element_id, element_name, element_type) VALUES (5, 68, 'the_geom', 'MultiLineStringPropertyType');
+-- Daten für Tabelle `wfs_featuretype`
+INSERT INTO wfs_featuretype (fkey_wfs_id, featuretype_id, featuretype_name, featuretype_title, featuretype_srs) VALUES (1, 1, 'topp:staedte', 'staedte_Type', 'EPSG:4326');
+INSERT INTO wfs_featuretype (fkey_wfs_id, featuretype_id, featuretype_name, featuretype_title, featuretype_srs) VALUES (1, 2, 'topp:ortschaften', 'ortschaften_Type', 'EPSG:4326');
+INSERT INTO wfs_featuretype (fkey_wfs_id, featuretype_id, featuretype_name, featuretype_title, featuretype_srs) VALUES (1, 3, 'topp:post_code_areas', 'post_code_areas_Type', 'EPSG:4326');
+INSERT INTO wfs_featuretype (fkey_wfs_id, featuretype_id, featuretype_name, featuretype_title, featuretype_srs) VALUES (1, 4, 'topp:mapbender_user', 'mapbender_user_Type', 'EPSG:4326');
+INSERT INTO wfs_featuretype (fkey_wfs_id, featuretype_id, featuretype_name, featuretype_title, featuretype_srs) VALUES (1, 5, 'topp:rivers', 'rivers_Type', 'EPSG:4326');
+-- Daten für Tabelle `wms`
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (86, '1.1.1', 'World Map', 'World Map in WGS84 Reference System', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/world/world_map.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/world/world_map.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/world/world_map.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/world/world_map.map&', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (101, '1.1.1', 'UMN Mapserver', 'UMN User Overview (UMN MapServer/Postgis)', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/umn_user.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/umn_user.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/umn_user.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/umn_user.map&', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (250, '1.1.1', 'Demis World Map', 'None', 'http://www2.demis.nl/wms/wms.asp?wms=WorldMap&', 'http://www2.demis.nl/wms/wms.asp?wms=WorldMap&', 'http://www2.demis.nl/wms/wms.asp?wms=WorldMap&', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (328, '1.1.0', 'OSIRIS-WMS, GIS Consult GmbH', 'Web Map Service auf Basis des Smallworld GIS', 'http://services.gis-consult.de/NWSIB-online/GCGisService', 'http://services.gis-consult.de/NWSIB-online/GCGisService', 'http://services.gis-consult.de/NWSIB-online/GCGisService', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (329, '1.1.0', 'Geobasisdaten Muenster', 'Geobasisdaten Muenster', 'http://geo.stadt-muenster.de/cgi-bin/geobasis?', 'http://geo.stadt-muenster.de/cgi-bin/geobasis?', 'http://geo.stadt-muenster.de/cgi-bin/geobasis?', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (336, '1.1.0', 'NRW: DTK10', 'Nutzungsbedingungen: Sämtliche Rechte an diesem Produkt liegen beim Landesvermessungsamt NRW. Die Nutzung ist bis auf Widerruf kostenfrei. Der Nutzer muss sich vor jeder Nutzung beim Landesvermessungsamt NRW identifizieren und seine spezielle Nutzung mit', 'http://www.geoserver.nrw.de:80/GeoOgcWms1.3/servlet/DTK10', 'http://www.geoserver.nrw.de:80/GeoOgcWms1.3/servlet/DTK10', 'http://www.geoserver.nrw.de:80/GeoOgcWms1.3/servlet/DTK10', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (407, '1.1.1', 'Mapbender User', 'Mapbender User Overview (Mapbender User/Postgis)', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/mapbender_user/mapbender_user.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/mapbender_user/mapbender_user.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/mapbender_user/mapbender_user.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/mapbender_user/mapbender_user.map&', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (486, '1.1.1', 'PLZ_441', 'PLZ (post code areas Germany) served with UMN MapServer 4.4.1', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany_demo/PLZ_441.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany_demo/PLZ_441.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany_demo/PLZ_441.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany_demo/PLZ_441.map&', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (525, '1.1.1', 'Middle America', 'Middle_America', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/middle_america/middle_america.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/middle_america/middle_america.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/middle_america/middle_america.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/middle_america/middle_america.map&', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (583, '1.1.0', 'Atlas of Canada WMS', 'The Atlas of Canadas Web Mapping Service (WMS) is an Internet-based service designed to provide developers of on-line mapping tools access to the Atlas of Canadas base layers. By using this service, developers gain access to our most current and accurat', 'http://atlas.gc.ca:80/cgi-bin/atlaswms_en?', 'http://atlas.gc.ca:80/cgi-bin/atlaswms_en?', 'http://atlas.gc.ca:80/cgi-bin/atlaswms_en?', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (584, '1.1.1', 'Bird Studies Canada WMS/WFS Server', 'Bird Studies Canada WMS/WFS Server for bird distribution and abundance data, and related information. Bird Studies Canada gratefully acknowledges the support of Environment Canada - Canadian Information System for the Environment in developing this servi', 'http://www.bsc-eoc.org/cgi-bin/bsc_ows.asp?', 'http://www.bsc-eoc.org/cgi-bin/bsc_ows.asp?', 'http://www.bsc-eoc.org/cgi-bin/bsc_ows.asp?', 'http://www.bsc-eoc.org/cgi-bin/bsc_ows.asp?', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (612, '1.1.2', 'ESA CubeSERV', 'European Space Agency CubeSERV map server.', 'http://mapserv2.esrin.esa.it/cubestor/cubeserv/cubeserv.cgi?', 'http://mapserv2.esrin.esa.it/cubestor/cubeserv/cubeserv.cgi?', 'http://mapserv2.esrin.esa.it/cubestor/cubeserv/cubeserv.cgi?', 'http://mapserv2.esrin.esa.it/cubestor/cubeserv/cubeserv.cgi?', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (613, '1.1.1', 'ESRI Co. Map Server', 'OGC - Web Map Server.', 'http://www.geographynetwork.com/ogc/com.esri.ogc.wms.WMSServlet?', 'http://www.geographynetwork.com/ogc/com.esri.ogc.wms.WMSServlet?', 'http://www.geographynetwork.com/ogc/com.esri.ogc.wms.WMSServlet?', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (614, '1.0.0', 'ESRI Inc. Map Server', 'WMT Map Server maintained by ESRI Inc.', 'http://inside3.uidaho.edu:80/servlet/com.esri.wms.Esrimap?servicename=WMS_WebMapCAP', 'http://inside3.uidaho.edu:80/servlet/com.esri.wms.Esrimap?servicename=WMS_WebMapCAP', 'http://inside3.uidaho.edu:80/servlet/com.esri.wms.Esrimap?servicename=WMS_WebMapCAP', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (615, '1.0.0', 'ESRI Inc. Map Server', 'WMT Map Server maintained by ESRI Inc.', 'http://maps.ciesin.org:80/servlet/com.esri.wms.Esrimap?', 'http://maps.ciesin.org:80/servlet/com.esri.wms.Esrimap?', 'http://maps.ciesin.org:80/servlet/com.esri.wms.Esrimap?', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (616, '1.1.1', 'ESRI Web Map Service', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS', 'http://142.176.62.108/wmsconnector/com.esri.wsit.WMSServlet/GeoNovaSDE?', 'http://142.176.62.108/wmsconnector/com.esri.wsit.WMSServlet/GeoNovaSDE?', 'http://142.176.62.108/wmsconnector/com.esri.wsit.WMSServlet/GeoNovaSDE?', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (617, '1.1.1', 'ESRI Web Map Service', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS', 'http://www.geographynetwork.ca/wmsconnector/com.esri.wsit.WMSServlet/Geobase_NRN_NewfoundlandAndLabrador_I_Detail?', 'http://www.geographynetwork.ca/wmsconnector/com.esri.wsit.WMSServlet/Geobase_NRN_NewfoundlandAndLabrador_I_Detail?', 'http://www.geographynetwork.ca/wmsconnector/com.esri.wsit.WMSServlet/Geobase_NRN_NewfoundlandAndLabrador_I_Detail?', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (624, '1.1.0', 'Gewaesserstationierungskarte des Landes NRW', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS', 'http://www.gis2.nrw.de/wmsconnector/wms/gewstat?', 'http://www.gis2.nrw.de/wmsconnector/wms/gewstat?', 'http://www.gis2.nrw.de/wmsconnector/wms/gewstat?', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (625, '1.1.1', 'GMap WMS Demo Server', 'This demonstration server was setup by DM Solutions Group (http://www.dmsolutions.ca/) and is powered by the UMN MapServer (http://mapserver.gis.umn.edu/). This server uses Canadian source data (c)2000, Government of Canada with permission from Natural R', 'http://dev1.dmsolutions.ca/cgi-bin/mswms_gmap?', 'http://dev1.dmsolutions.ca/cgi-bin/mswms_gmap?', 'http://dev1.dmsolutions.ca/cgi-bin/mswms_gmap?', 'http://dev1.dmsolutions.ca/cgi-bin/mswms_gmap?', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (634, '1.1.0', 'Location mapserver', 'This service provides approximate point locations for various themes.', 'http://www.indexgeo.com.au/cgi-bin/wms-location', 'http://www.indexgeo.com.au/cgi-bin/wms-location', 'http://www.indexgeo.com.au/cgi-bin/wms-location', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (637, '1.1.1', 'MapServer WMS Demo', 'This is a UMN WMS MapServer demonstration application for global elevation data.', 'http://cooa.whoi.edu/cw/etopo2_wms?', 'http://cooa.whoi.edu/cw/etopo2_wms?', 'http://cooa.whoi.edu/cw/etopo2_wms?', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (640, '1.1.1', 'JPL World Map Service', 'WMS Server maintained by JPL, worldwide satellite imagery.', 'http://wms.jpl.nasa.gov/wms.cgi?', 'http://wms.jpl.nasa.gov/wms.cgi?', '', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (645, '1.1.1', 'Multi-Hazard Mapping Initiative WMS Map Server (HDM)', 'This map server is provided by the Multi-Hazard Mapping Initiative and hosted by Harvard Design & Mapping Co., Inc.', 'http://www.hazardmaps.gov/ogc/wms?', 'http://www.hazardmaps.gov/ogc/wms?', 'http://www.hazardmaps.gov/ogc/wms?', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (648, '1.1.0', 'Neigungsklassen zur Gelaendebefahrbarkeit', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS', 'http://www.gis2.nrw.de/wmsconnector/wms/hangneigung?', 'http://www.gis2.nrw.de/wmsconnector/wms/hangneigung?', 'http://www.gis2.nrw.de/wmsconnector/wms/hangneigung?', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (655, '1.1.1', 'SEACOOS Remotely-Sensed Imagery', 'The SouthEast Atlantic Coastal Ocean Observing System (SEACOOS) is a regional partnership that has initiated an integrated coastal ocean observing system for a four-state region of the southeast U.S. SEACOOS brings together many organizations witha veste', 'http://nautilus.baruch.sc.edu/wms/seacoos_rs?', 'http://nautilus.baruch.sc.edu/wms/seacoos_rs?', 'http://nautilus.baruch.sc.edu/wms/seacoos_rs?', 'http://nautilus.baruch.sc.edu/wms/seacoos_rs?', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (670, '1.1.0', 'Waldtypenkarte NRW', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS', 'http://www.gis2.nrw.de/wmsconnector/wms/waldtyp?', 'http://www.gis2.nrw.de/wmsconnector/wms/waldtyp?', 'http://www.gis2.nrw.de/wmsconnector/wms/waldtyp?', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (671, '1.1.0', 'Wasserschutzgebiete NRW', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS', 'http://www.gis2.nrw.de/wmsconnector/wms/wsg?', 'http://www.gis2.nrw.de/wmsconnector/wms/wsg?', 'http://www.gis2.nrw.de/wmsconnector/wms/wsg?', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (706, '1.1.0', 'WMS Map Server Australien', 'WMS Map Server Australien', 'http://atlas.walis.wa.gov.au:80/servlet/com.esri.wms.Esrimap?', 'http://atlas.walis.wa.gov.au:80/servlet/com.esri.wms.Esrimap?', 'http://atlas.walis.wa.gov.au:80/servlet/com.esri.wms.Esrimap?', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (717, '1.1.0', 'Forstliche Verwaltungsgrenzen NRW', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS', 'http://www.gis2.nrw.de/wmsconnector/wms/forstamtsgr?', 'http://www.gis2.nrw.de/wmsconnector/wms/forstamtsgr?', 'http://www.gis2.nrw.de/wmsconnector/wms/forstamtsgr?', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (739, '1.1.1', 'Web Map Service Eusoils_Ex', 'ArcIMS 9.0 SP2 - Eusoils_Ex Web Map Service', 'http://eusoils.jrc.it:80/wmsconnector/com.esri.wms.Esrimap/Eusoils_Ex?', 'http://eusoils.jrc.it:80/wmsconnector/com.esri.wms.Esrimap/Eusoils_Ex?', 'http://eusoils.jrc.it:80/wmsconnector/com.esri.wms.Esrimap/Eusoils_Ex?', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (758, '1.1.0', 'DNM 250/2', '2. Generation des Digitalen Navigationsmodells 1:250.000 als topographische Basisnavigationsdaten der Brandenburger Landesvermessung', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNM250n.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNM250n.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNM250n.map&', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (760, '1.1.0', 'DNM 100/2', '2. Generation des Digitalen Navigationsmodells 1:100.000 als topographische Basisnavigationsdaten der Brandenburger Landesvermessung', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNM100n.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNM100n.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNM100n.map&', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (762, '1.1.0', 'DNM 25/2', '2. Generation des Digitalen Navigationsmodells 1:25.000 als topographische Basisnavigationsdaten der Brandenburger Landesvermessung', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNM25.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNM25.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNM25.map&', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (764, '1.1.0', 'DNM FÜK', 'Digitales Navigationsmodell Flurübersichtskarte der Brandenburger Landesvermessung', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNMFUEK.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNMFUEK.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNMFUEK.map&', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (765, '1.1.0', 'DNM VG', 'Digitales Navigationsmodell Verwaltungsgrenzen als Basisnavigationsdaten der Brandenburger Landesvermessung', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNMVG.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNMVG.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNMVG.map&', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (767, '1.1.1', 'SLUBFURT', 'Slubfurter Mental Map Survey 2000 - 2002: Border regions pose a challenge to spatial planning policies and practices. Many border regions are experiencing social and cultural convergence and fragmentation as well as a growing concern for the natural envir', 'http://odragis.org/cgi-bin/slubfurtwms?', 'http://odragis.org/cgi-bin/slubfurtwms?', 'http://odragis.org/cgi-bin/slubfurtwms?', 'http://odragis.org/cgi-bin/slubfurtwms?', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (776, '1.1.1', 'Infoprix', 'Boundaries and markets in Africa (this service is intended for academic use and can go offline any time. If you are interested in more data, contact us at http://www.terrestris.de)', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/webapps/benin/infoprix.map&', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/webapps/benin/infoprix.map&', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/webapps/benin/infoprix.map&', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/webapps/benin/infoprix.map&', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (777, '1.1.1', 'Lieu / Locations', 'Boundaries and Cities of Africa', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/resimao/resimao.map&', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/resimao/resimao.map&', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/resimao/resimao.map&', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/resimao/resimao.map&', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (778, '1.1.1', 'Pendjari National Parc', 'Pendjari', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/webapps/benin/pendjari.map&', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/webapps/benin/pendjari.map&', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/webapps/benin/pendjari.map&', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/webapps/benin/pendjari.map&', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (779, '1.1.0', 'Ruanda', '', 'http://www.terrestris.de/cgi-bin/mapserv?map=/var/www/html/ruanda/Ruanda1.map&', 'http://www.terrestris.de/cgi-bin/mapserv?map=/var/www/html/ruanda/Ruanda1.map&', 'http://www.terrestris.de/cgi-bin/mapserv?map=/var/www/html/ruanda/Ruanda1.map&', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (785, '1.1.0', 'WMS Map Server', 'WMS Map Server', 'http://gdz1.leipzig.ifag.de:80/servlet/com.esri.wms.Esrimap?servicename=dtk200_500_1000_a10_gk3_wms', 'http://gdz1.leipzig.ifag.de:80/servlet/com.esri.wms.Esrimap?servicename=dtk200_500_1000_a10_gk3_wms', 'http://gdz1.leipzig.ifag.de:80/servlet/com.esri.wms.Esrimap?servicename=dtk200_500_1000_a10_gk3_wms', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (786, '1.1.0', 'Luftbild', '', 'http://www.landesvermessung.sachsen.de/ias/basiskarte/service/SRVDOPFREE/WMSFREE_TK/WMSFREE_TK/wmsservice?', 'http://www.landesvermessung.sachsen.de/ias/basiskarte/service/SRVDOPFREE/WMSFREE_TK/WMSFREE_TK/wmsservice?', 'http://www.landesvermessung.sachsen.de/ias/basiskarte/service/SRVDOPFREE/WMSFREE_TK/WMSFREE_TK/wmsservice?', 'http://www.landesvermessung.sachsen.de/ias/basiskarte/service/SRVDOPFREE/WMSFREE_TK/WMSFREE_TK/wmsservice?', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (787, '1.1.1', 'Bavarian WMS MAP Server', 'Bavarian WMS MAP Server', 'http://deutschlandviewer.bayern.de/ogc/getogc.cgi?', 'http://deutschlandviewer.bayern.de/ogc/getogc.cgi?', '', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (788, '1.1.1', 'Digitale Orthophotos mit einer reduzierten Bodenauflösung von 5 und 25m', 'Die Daten umfassen das Gebiet der Länder Brandenburg und Berlin', 'http://geoservice.geobasis-bb.de/ows/dop.php?', 'http://geoservice.geobasis-bb.de/ows/dop.php?', 'http://geoservice.geobasis-bb.de/ows/dop.php?', 'http://geoservice.geobasis-bb.de/ows/dop.php?', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (789, '1.1.0', 'TopKarten100_TopKarten50', 'SICAD Internet Suite V6.0A05 at www.landesvermessung.sachsen.de/sims/sicad-', 'http://www.landesvermessung.sachsen.de/sims/sicad/GetCapabilities.pl?datasource=freetk:de:', 'http://www.landesvermessung.sachsen.de/sims/sicad/ShowMap.pl?datasource=freetk:de:', 'http://www.landesvermessung.sachsen.de/sims/sicad/ShowOnlineAlpha.pl?datasource=freetk:de:', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (790, '1.1.1', 'Mapserver Niedersachsen 4.7.4', '', 'http://www.lgn21.niedersachsen.de/freezoneogc/mapserverogc?', 'http://www.lgn21.niedersachsen.de/freezoneogc/mapserverogc?', '', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (792, '1.1.1', 'WMS-Thueringen', 'wms reference implementation', 'http://www.webmap-test.thueringen.de/deegreewms/wms?', 'http://www.webmap-test.thueringen.de/deegreewms/wms?', 'http://www.webmap-test.thueringen.de/deegreewms/wms?', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (793, '1.1.0', 'WMS Hessen', 'WMT Map Server, Copyright (c) Hessisches Landesvermessungsamt', 'http://wmssrv.geo.hessen.de/ias/cgi-bin/siscgi.exe?', 'http://wmssrv.geo.hessen.de/ias/cgi-bin/siscgi.exe?', '', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (794, '1.1.0', 'DNM 100/2', '2. Generation des Digitalen Navigationsmodells 1:100.000 als topographische Basisnavigationsdaten der Brandenburger Landesvermessung', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNM100n.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNM100n.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNM100n.map&', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (796, '1.1.1', 'WMS-Thueringen', 'wms reference implementation', 'http://www.webmap-test.thueringen.de/deegreewms/wms?', 'http://www.webmap-test.thueringen.de/deegreewms/wms?', 'http://www.webmap-test.thueringen.de/deegreewms/wms?', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (797, '1.1.0', 'DNM FÜK', 'Digitales Navigationsmodell Flurübersichtskarte der Brandenburger Landesvermessung', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNMFUEK.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNMFUEK.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNMFUEK.map&', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (798, '1.1.0', 'DNM VG', 'Digitales Navigationsmodell Verwaltungsgrenzen als Basisnavigationsdaten der Brandenburger Landesvermessung', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNMVG.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNMVG.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNMVG.map&', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (799, '1.1.1', 'Digitale Orthophotos mit einer reduzierten Bodenauflösung von 5 und 25m', 'Die Daten umfassen das Gebiet der Länder Brandenburg und Berlin', 'http://geoservice.geobasis-bb.de/ows/dop.php?', 'http://geoservice.geobasis-bb.de/ows/dop.php?', 'http://geoservice.geobasis-bb.de/ows/dop.php?', 'http://geoservice.geobasis-bb.de/ows/dop.php?', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (800, '1.1.1', 'OGCConnector v0.3', '', 'http://geoint.lmic.state.mn.us/cgi-bin/wms', 'http://geoint.lmic.state.mn.us/cgi-bin/wms', 'http://geoint.lmic.state.mn.us/cgi-bin/wms', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (824, '1.1.1', 'Image Web Server', 'WMS Version 1.1.1', 'http://camber.mc.man.ac.uk/ecwp/ecw_wms.dll', 'http://camber.mc.man.ac.uk/ecwp/ecw_wms.dll', '', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (827, '1.0.0', 'NSW DIPNR Image Server', 'NSW DIPNR Image Server Web Map Service interface used to serve large raster images (up to 100 Gigabytes per image). It is currently used to serve the NSW Landsat 2000 Mosaic, and can also serve scanned maps and aerial photography.', 'http://atlas.canri.nsw.gov.au/proxy/wms?', 'http://atlas.canri.nsw.gov.au/proxy/wms?', '', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (828, '1.1.1', 'IDERIOJA', 'IDE Gobierno de La Rioja', 'http://wms.larioja.org/request.asp', 'http://wms.larioja.org/request.asp', 'http://wms.larioja.org/request.asp', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (829, '1.1.1', 'WMS Geography Salzburgat_etm7_lambert', 'Dep. Geography - University Salzburg, Austria: at_etm7_lambert Web Map Service', 'http://maps.geo.sbg.ac.at:80/wmsconnector/com.esri.wms.Esrimap/at_etm7_lambert?', 'http://maps.geo.sbg.ac.at:80/wmsconnector/com.esri.wms.Esrimap/at_etm7_lambert?', 'http://maps.geo.sbg.ac.at:80/wmsconnector/com.esri.wms.Esrimap/at_etm7_lambert?', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (831, '1.1.1', 'MNDNR Data Deli WMS Server', '', 'http://maps.dnr.state.mn.us/cgi-bin/wms?map=DELI_WMS_MAPFILE&', 'http://maps.dnr.state.mn.us/cgi-bin/wms?map=DELI_WMS_MAPFILE&', 'http://maps.dnr.state.mn.us/cgi-bin/wms?map=DELI_WMS_MAPFILE&', 'http://maps.dnr.state.mn.us/cgi-bin/wms?map=DELI_WMS_MAPFILE&', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (832, '1.1.0', 'Technology Applications Team Wms Service', 'This is an OGC compliant MapService served by the USGS Technology Applications Team (TAT) from the USGSs Fort Collins Science Center', 'http://mapper.tat.fws.gov/ogcwms/WmsServlet?SERVICENAME=nwi_wms&', 'http://mapper.tat.fws.gov/ogcwms/WmsServlet?SERVICENAME=nwi_wms&', 'http://mapper.tat.fws.gov/ogcwms/WmsServlet?SERVICENAME=nwi_wms&', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (833, '1.1.1', 'ESRI Web Map Service', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS', 'http://ocs-spatial.ncd.noaa.gov/wmsconnector/com.esri.wsit.WMSServlet/encdirect?', 'http://ocs-spatial.ncd.noaa.gov/wmsconnector/com.esri.wsit.WMSServlet/encdirect?', 'http://ocs-spatial.ncd.noaa.gov/wmsconnector/com.esri.wsit.WMSServlet/encdirect?', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (834, '1.1.1', 'Delaware 2002 Aerial Imagery WMS Service', 'The Delaware 2002 Aerial Imagery Map Service serves statewide orthophotography as captured in 2002. The State of Delaware contracted with EarthData International to develop 0.25-meter resolution color infrared digital ortho-photos for the entire state. Ma', 'http://datamil.delaware.gov:80/wmsconnector/com.esri.wms.Esrimap/DE_aerial02?', 'http://datamil.delaware.gov:80/wmsconnector/com.esri.wms.Esrimap/DE_aerial02?', 'http://datamil.delaware.gov:80/wmsconnector/com.esri.wms.Esrimap/DE_aerial02?', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (835, '1.1.1', 'Tsunami_Diasaster_Data', 'This WMS server contains data used in http://www.mapsherpa.com/tsunami/. Much of the reference data is cascaded from other WMS servers. Before using this data in your live application, please consult the metadata url for each layer to check to see if you', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (836, '1.1.1', 'NDOP (OGCConnector v1.2)', '', 'http://mcmcwebmap.usgs.gov:80/OGCConnector/servlet/OGCConnector?ServiceName=NDOP', 'http://mcmcwebmap.usgs.gov:80/OGCConnector/servlet/OGCConnector?ServiceName=NDOP', 'http://mcmcwebmap.usgs.gov:80/OGCConnector/servlet/OGCConnector?ServiceName=NDOP', 'http://mcmcwebmap.usgs.gov:80/OGCConnector/servlet/OGCConnector?ServiceName=NDOP', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (837, '1.1.1', 'Microsoft TerraServer Map Server', 'WMT Map Server maintained by Microsoft Corporation. Data returned provided by US Geological Survey. Contact: tbarclay at microsoft.com or gylee at usgs.gov.', 'http://terraservice.net/ogccapabilities.ashx', 'http://terraservice.net/ogcmap.ashx', '', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (840, '1.1.1', 'Intergraph World Map', '', 'http://maps1.intergraph.com/wms/world/request.asp', 'http://maps1.intergraph.com/wms/world/request.asp', 'http://maps1.intergraph.com/wms/world/request.asp', 'http://maps1.intergraph.com/wms/world/request.asp', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (841, '1.1.1', 'ICEDS (Integrated CEOS European Data Server) WMS', 'Integrated CEOS European Data Server (ICEDS) Web Map Service, maintained by the Geomatic Engineering Dept at UCL', 'http://iceds.ge.ucl.ac.uk/cgi-bin/icedswms?', 'http://iceds.ge.ucl.ac.uk/cgi-bin/icedswms?', 'http://iceds.ge.ucl.ac.uk/cgi-bin/icedswms?', 'http://iceds.ge.ucl.ac.uk/cgi-bin/icedswms?', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (842, '1.1.1', 'Tsunami_Diasaster_Data', 'This WMS server contains data used in http://www.mapsherpa.com/tsunami/. Much of the reference data is cascaded from other WMS servers. Before using this data in your live application, please consult the metadata url for each layer to check to see if you', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (843, '1.0.0', 'WMS Map Server', 'WMS Map Server', 'http://map.ngdc.noaa.gov:80/servlet/com.esri.wms.Esrimap?servicename=hazards', 'http://map.ngdc.noaa.gov:80/servlet/com.esri.wms.Esrimap?servicename=hazards', 'http://map.ngdc.noaa.gov:80/servlet/com.esri.wms.Esrimap?servicename=hazards', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (844, '1.1.1', 'CustomWeather Map Server', 'CustomWeather WMT Map Server. Contact: info at customweather.com. Doppler, Satellite, Severe Watches and Warnings, Hurricanes, Frontlines, ContourMaps, and More.', 'http://maps.customweather.com/image?', 'http://maps.customweather.com/image?', 'http://maps.customweather.com/image?', '', '', '');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (854, '1.1.1', 'Stadtkarte', 'Stadtkarte SPA Wesseling', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&', NULL, '<?xml version=''1.0'' encoding="ISO-8859-1" standalone="no" ?>\n<!DOCTYPE WMT_MS_Capabilities SYSTEM "http://schemas.opengeospatial.net/wms/1.1.1/WMS_MS_Capabilities.dtd"\n [\n <!ELEMENT VendorSpecificCapabilities EMPTY>\n ]> <!-- end of DOCTYPE declaration -->\n\n<WMT_MS_Capabilities version="1.1.1">\n\n<!-- MapServer version 4.4.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE -->\n\n<Service>\n <Name>OGC:WMS</Name>\n <Title>Stadtkarte</Title>\n <Abstract>Stadtkarte SPA Wesseling</Abstract>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&"/>\n <AccessConstraints>none</AccessConstraints>\n</Service>\n\n<Capability>\n <Request>\n <GetCapabilities>\n <Format>application/vnd.ogc.wms_xml</Format>\n <DCPType>\n <HTTP>\n <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&"/></Get>\n <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&"/></Post>\n </HTTP>\n </DCPType>\n </GetCapabilities>\n <GetMap>\n <Format>image/gif</Format>\n <Format>image/png</Format>\n <Format>image/png; mode=24bit</Format>\n <Format>image/jpeg</Format>\n <Format>image/wbmp</Format>\n <Format>image/tiff</Format>\n <DCPType>\n <HTTP>\n <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&"/></Get>\n <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&"/></Post>\n </HTTP>\n </DCPType>\n </GetMap>\n <GetFeatureInfo>\n <Format>text/plain</Format>\n <Format>application/vnd.ogc.gml</Format>\n <DCPType>\n <HTTP>\n <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&"/></Get>\n <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&"/></Post>\n </HTTP>\n </DCPType>\n </GetFeatureInfo>\n <DescribeLayer>\n <Format>text/xml</Format>\n <DCPType>\n <HTTP>\n <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&"/></Get>\n <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&"/></Post>\n </HTTP>\n </DCPType>\n </DescribeLayer>\n <GetLegendGraphic>\n <Format>image/gif</Format>\n <Format>image/png</Format>\n <Format>image/png; mode=24bit</Format>\n <Format>image/jpeg</Format>\n <Format>image/wbmp</Format>\n <DCPType>\n <HTTP>\n <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&"/></Get>\n <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&"/></Post>\n </HTTP>\n </DCPType>\n </GetLegendGraphic>\n </Request>\n <Exception>\n <Format>application/vnd.ogc.se_xml</Format>\n <Format>application/vnd.ogc.se_inimage</Format>\n <Format>application/vnd.ogc.se_blank</Format>\n </Exception>\n <VendorSpecificCapabilities />\n <UserDefinedSymbolization SupportSLD="1" UserLayer="0" UserStyle="1" RemoteWFS="0"/>\n <Layer>\n <Name>wesseling_stadtkarte</Name>\n <Title>Stadtkarte</Title>\n <SRS>epsg:31466</SRS>\n <LatLonBoundingBox minx="6.92615" miny="50.7877" maxx="7.03399" maxy="50.856" />\n <BoundingBox SRS="EPSG:31466"\n minx="2.5653e+06" miny="5.6284e+06" maxx="2.5728e+06" maxy="5.6359e+06" />\n <ScaleHint min="0" max="4989.03" />\n <Layer>\n <Name>Nutzung</Name>\n <Title>Nutzung</Title>\n <Abstract>Nutzung</Abstract>\n <Layer queryable="0" opaque="0" cascaded="0">\n <Name>wes_dsk_patch1</Name>\n <Title>wes_dsk_patch1</Title>\n <SRS>epsg:31466</SRS>\n <LatLonBoundingBox minx="-3.69276" miny="45.2759" maxx="18.4979" maxy="55.4172" />\n <BoundingBox SRS="EPSG:31466"\n minx="1.88129e+06" miny="5.06622e+06" maxx="3.30206e+06" maxy="6.14305e+06" />\n </Layer>\n <Layer queryable="0" opaque="0" cascaded="0">\n <Name>atkis_wes_1_umn_pl</Name>\n <Title>atkis_wes_1_umn_pl</Title>\n <SRS>epsg:31466</SRS>\n <LatLonBoundingBox minx="-180" miny="-3.40166e+32" maxx="174.615" maxy="3.40166e+32" />\n <BoundingBox SRS="EPSG:31466"\n minx="-2.5e+07" miny="-2.5e+07" maxx="2.5e+07" maxy="2.5e+07" />\n <Style>\n <Name>default</Name>\n <Title>default</Title>\n <LegendURL width="20" height="10">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=atkis_wes_1_umn_pl&format=image/png"/>\n </LegendURL>\n </Style>\n </Layer>\n <Layer queryable="0" opaque="0" cascaded="0">\n <Name>atkis_wes_1_umn_l</Name>\n <Title>atkis_wes_1_umn_l</Title>\n <SRS>epsg:31466</SRS>\n <LatLonBoundingBox minx="-180" miny="-3.40166e+32" maxx="174.615" maxy="3.40166e+32" />\n <BoundingBox SRS="EPSG:31466"\n minx="-2.5e+07" miny="-2.5e+07" maxx="2.5e+07" maxy="2.5e+07" />\n <Style>\n <Name>default</Name>\n <Title>default</Title>\n <LegendURL width="20" height="10">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=atkis_wes_1_umn_l&format=image/png"/>\n </LegendURL>\n </Style>\n </Layer>\n <Layer queryable="0" opaque="0" cascaded="0">\n <Name>atkis_wes_3_layer1_pl</Name>\n <Title>atkis_wes_3_layer1_pl</Title>\n <SRS>epsg:31466</SRS>\n <LatLonBoundingBox minx="-180" miny="-3.40166e+32" maxx="174.615" maxy="3.40166e+32" />\n <BoundingBox SRS="EPSG:31466"\n minx="-2.5e+07" miny="-2.5e+07" maxx="2.5e+07" maxy="2.5e+07" />\n <Style>\n <Name>default</Name>\n <Title>default</Title>\n <LegendURL width="20" height="10">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=atkis_wes_3_layer1_pl&format=image/png"/>\n </LegendURL>\n </Style>\n </Layer>\n <Layer queryable="0" opaque="0" cascaded="0">\n <Name>atkis_wes_3_layer2_pl</Name>\n <Title>atkis_wes_3_layer2_pl</Title>\n <SRS>epsg:31466</SRS>\n <LatLonBoundingBox minx="-180" miny="-3.40166e+32" maxx="174.615" maxy="3.40166e+32" />\n <BoundingBox SRS="EPSG:31466"\n minx="-2.5e+07" miny="-2.5e+07" maxx="2.5e+07" maxy="2.5e+07" />\n <Style>\n <Name>default</Name>\n <Title>default</Title>\n <LegendURL width="20" height="10">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=atkis_wes_3_layer2_pl&format=image/png"/>\n </LegendURL>\n </Style>\n </Layer>\n <Layer queryable="0" opaque="0" cascaded="0">\n <Name>atkis_wes_3_layer3_pl</Name>\n <Title>atkis_wes_3_layer3_pl</Title>\n <SRS>epsg:31466</SRS>\n <LatLonBoundingBox minx="-180" miny="-3.40166e+32" maxx="174.615" maxy="3.40166e+32" />\n <BoundingBox SRS="EPSG:31466"\n minx="-2.5e+07" miny="-2.5e+07" maxx="2.5e+07" maxy="2.5e+07" />\n <Style>\n <Name>default</Name>\n <Title>default</Title>\n <LegendURL width="20" height="10">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=atkis_wes_3_layer3_pl&format=image/png"/>\n </LegendURL>\n </Style>\n </Layer>\n <Layer queryable="0" opaque="0" cascaded="0">\n <Name>atkis_wes_3_layer4_pl</Name>\n <Title>atkis_wes_3_layer4_pl</Title>\n <SRS>epsg:31466</SRS>\n <LatLonBoundingBox minx="-180" miny="-3.40166e+32" maxx="174.615" maxy="3.40166e+32" />\n <BoundingBox SRS="EPSG:31466"\n minx="-2.5e+07" miny="-2.5e+07" maxx="2.5e+07" maxy="2.5e+07" />\n <Style>\n <Name>default</Name>\n <Title>default</Title>\n <LegendURL width="20" height="10">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=atkis_wes_3_layer4_pl&format=image/png"/>\n </LegendURL>\n </Style>\n </Layer>\n <Layer queryable="0" opaque="0" cascaded="0">\n <Name>atkis_wes_3_layer5_pl</Name>\n <Title>atkis_wes_3_layer5_pl</Title>\n <SRS>epsg:31466</SRS>\n <LatLonBoundingBox minx="-180" miny="-3.40166e+32" maxx="174.615" maxy="3.40166e+32" />\n <BoundingBox SRS="EPSG:31466"\n minx="-2.5e+07" miny="-2.5e+07" maxx="2.5e+07" maxy="2.5e+07" />\n <Style>\n <Name>default</Name>\n <Title>default</Title>\n <LegendURL width="20" height="10">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=atkis_wes_3_layer5_pl&format=image/png"/>\n </LegendURL>\n </Style>\n </Layer>\n <Layer queryable="0" opaque="0" cascaded="0">\n <Name>atkis_wes_3_layer6_l</Name>\n <Title>atkis_wes_3_layer6_l</Title>\n <SRS>epsg:31466</SRS>\n <LatLonBoundingBox minx="-180" miny="-3.40166e+32" maxx="174.615" maxy="3.40166e+32" />\n <BoundingBox SRS="EPSG:31466"\n minx="-2.5e+07" miny="-2.5e+07" maxx="2.5e+07" maxy="2.5e+07" />\n <Style>\n <Name>default</Name>\n <Title>default</Title>\n <LegendURL width="20" height="10">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=atkis_wes_3_layer6_l&format=image/png"/>\n </LegendURL>\n </Style>\n </Layer>\n <Layer queryable="0" opaque="0" cascaded="0">\n<!-- WARNING: The layer name ''Flüsse'' might contain spaces or invalid characters or may start with a number. This could lead to potential problems. -->\n <Name>Flüsse</Name>\n <Title>Flüsse</Title>\n <SRS>epsg:31466</SRS>\n <LatLonBoundingBox minx="-180" miny="-3.40166e+32" maxx="174.615" maxy="3.40166e+32" />\n <BoundingBox SRS="EPSG:31466"\n minx="-2.5e+07" miny="-2.5e+07" maxx="2.5e+07" maxy="2.5e+07" />\n <Style>\n <Name>default</Name>\n <Title>default</Title>\n <LegendURL width="20" height="10">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Flüsse&format=image/png"/>\n </LegendURL>\n </Style>\n </Layer>\n </Layer>\n <Layer>\n <Name>Strassen</Name>\n <Title>Strassen</Title>\n <Abstract>Strassen</Abstract>\n <Layer queryable="0" opaque="0" cascaded="0">\n<!-- WARNING: The layer name ''WES_DSK_füllung1'' might contain spaces or invalid characters or may start with a number. This could lead to potential problems. -->\n <Name>WES_DSK_füllung1</Name>\n <Title>WES_DSK_füllung1</Title>\n <SRS>epsg:31466</SRS>\n <LatLonBoundingBox minx="-180" miny="-3.40166e+32" maxx="174.615" maxy="3.40166e+32" />\n <BoundingBox SRS="EPSG:31466"\n minx="-2.5e+07" miny="-2.5e+07" maxx="2.5e+07" maxy="2.5e+07" />\n <Style>\n <Name>default</Name>\n <Title>default</Title>\n <LegendURL width="20" height="10">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=WES_DSK_füllung1&format=image/png"/>\n </LegendURL>\n </Style>\n </Layer>\n <Layer queryable="0" opaque="0" cascaded="0">\n <Name>WES_DSK_umring</Name>\n <Title>WES_DSK_umring</Title>\n <SRS>epsg:31466</SRS>\n <LatLonBoundingBox minx="-180" miny="-3.40166e+32" maxx="174.615" maxy="3.40166e+32" />\n <BoundingBox SRS="EPSG:31466"\n minx="-2.5e+07" miny="-2.5e+07" maxx="2.5e+07" maxy="2.5e+07" />\n <Style>\n <Name>default</Name>\n <Title>default</Title>\n <LegendURL width="20" height="10">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=WES_DSK_umring&format=image/png"/>\n </LegendURL>\n </Style>\n </Layer>\n <Layer queryable="0" opaque="0" cascaded="0">\n<!-- WARNING: The layer name ''WES_DSK_füllung2'' might contain spaces or invalid characters or may start with a number. This could lead to potential problems. -->\n <Name>WES_DSK_füllung2</Name>\n <Title>WES_DSK_füllung2</Title>\n <SRS>epsg:31466</SRS>\n <LatLonBoundingBox minx="-180" miny="-3.40166e+32" maxx="174.615" maxy="3.40166e+32" />\n <BoundingBox SRS="EPSG:31466"\n minx="-2.5e+07" miny="-2.5e+07" maxx="2.5e+07" maxy="2.5e+07" />\n <Style>\n <Name>default</Name>\n <Title>default</Title>\n <LegendURL width="20" height="10">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=WES_DSK_füllung2&format=image/png"/>\n </LegendURL>\n </Style>\n </Layer>\n </Layer>\n <Layer queryable="0" opaque="0" cascaded="0">\n <Name>Stadtgrenze</Name>\n <Title>Stadtgrenze</Title>\n <SRS>epsg:31466</SRS>\n <LatLonBoundingBox minx="-180" miny="-3.40166e+32" maxx="174.615" maxy="3.40166e+32" />\n <BoundingBox SRS="EPSG:31466"\n minx="-2.5e+07" miny="-2.5e+07" maxx="2.5e+07" maxy="2.5e+07" />\n <Style>\n <Name>default</Name>\n <Title>default</Title>\n <LegendURL width="20" height="10">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Stadtgrenze&format=image/png"/>\n </LegendURL>\n </Style>\n </Layer>\n <Layer>\n <Name>Strassennamen</Name>\n <Title>Strassennamen</Title>\n <Abstract>Strassennamen</Abstract>\n <Layer queryable="0" opaque="0" cascaded="0">\n <Name>wes_dsk_strnamen_umn_1_t</Name>\n <Title>wes_dsk_strnamen_umn_1_t</Title>\n <SRS>epsg:31466</SRS>\n <LatLonBoundingBox minx="-180" miny="-3.40166e+32" maxx="174.615" maxy="3.40166e+32" />\n <BoundingBox SRS="EPSG:31466"\n minx="-2.5e+07" miny="-2.5e+07" maxx="2.5e+07" maxy="2.5e+07" />\n <Style>\n <Name>default</Name>\n <Title>default</Title>\n <LegendURL width="20" height="10">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=wes_dsk_strnamen_umn_1_t&format=image/png"/>\n </LegendURL>\n </Style>\n </Layer>\n <Layer queryable="0" opaque="0" cascaded="0">\n <Name>wes_dsk_strnamen_umn_2_t</Name>\n <Title>wes_dsk_strnamen_umn_2_t</Title>\n <SRS>epsg:31466</SRS>\n <LatLonBoundingBox minx="-180" miny="-3.40166e+32" maxx="174.615" maxy="3.40166e+32" />\n <BoundingBox SRS="EPSG:31466"\n minx="-2.5e+07" miny="-2.5e+07" maxx="2.5e+07" maxy="2.5e+07" />\n <Style>\n <Name>default</Name>\n <Title>default</Title>\n <LegendURL width="20" height="10">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=wes_dsk_strnamen_umn_2_t&format=image/png"/>\n </LegendURL>\n </Style>\n <ScaleHint min="0" max="1.99561" />\n </Layer>\n </Layer>\n <Layer queryable="0" opaque="0" cascaded="0">\n <Name>wes_dsk_patch</Name>\n <Title>wes_dsk_patch</Title>\n <SRS>epsg:31466</SRS>\n <LatLonBoundingBox minx="6.78544" miny="50.7166" maxx="7.16614" maxy="50.9379" />\n <BoundingBox SRS="EPSG:31466"\n minx="2.55546e+06" miny="5.62063e+06" maxx="2.58196e+06" maxy="5.6449e+06" />\n </Layer>\n </Layer>\n</Capability>\n</WMT_MS_Capabilities>\n');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (855, '1.1.1', 'World Map', 'None', 'http://www2.demis.nl/wms/wms.asp?wms=WorldMap&', 'http://www2.demis.nl/wms/wms.asp?wms=WorldMap&', 'http://www2.demis.nl/wms/wms.asp?wms=WorldMap&', '', NULL, '<?xml version="1.0"?>\r\n<!DOCTYPE WMT_MS_Capabilities SYSTEM "http://www2.demis.nl/wms/capabilities_1_1_1.dtd" [\r\n <!-- Vendor-specific elements are defined here if needed. -->\r\n <!-- If not needed, just leave this EMPTY declaration. Do not\r\n delete the declaration entirely. -->\r\n <!ELEMENT VendorSpecificCapabilities EMPTY>\r\n ]>\r\n<WMT_MS_Capabilities version="1.1.1">\r\n <!-- Service Metadata -->\r\n <Service>\r\n <!-- The WMT-defined name for this type of service -->\r\n <Name>OGC:WMS</Name>\r\n <!-- Human-readable title for pick lists -->\r\n <Title>World Map</Title>\r\n <!-- Narrative description providing additional information -->\r\n <Abstract>None</Abstract>\r\n <!-- Top-level web address of service or service provider. See also OnlineResource\r\n elements under <DCPType>. -->\r\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://www2.demis.nl"/>\r\n <!-- Contact information -->\r\n <ContactInformation>\r\n <ContactPersonPrimary>\r\n <ContactPerson></ContactPerson>\r\n <ContactOrganization></ContactOrganization>\r\n </ContactPersonPrimary>\r\n <ContactElectronicMailAddress></ContactElectronicMailAddress>\r\n </ContactInformation>\r\n <!-- Fees or access constraints imposed. -->\r\n <Fees>none</Fees>\r\n <AccessConstraints>none</AccessConstraints>\r\n </Service>\r\n <Capability>\r\n <Request>\r\n <GetCapabilities>\r\n <Format>application/vnd.ogc.wms_xml</Format>\r\n <DCPType>\r\n <HTTP>\r\n <Get>\r\n <!-- The URL here for invoking GetCapabilities using HTTP GET\r\n is only a prefix to which a query string is appended. -->\r\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://www2.demis.nl/wms/wms.asp?wms=WorldMap&"/>\r\n </Get>\r\n </HTTP>\r\n </DCPType>\r\n </GetCapabilities>\r\n <GetMap>\r\n <Format>image/png</Format>\r\n <Format>image/jpeg</Format>\r\n <Format>image/gif</Format>\r\n <Format>image/bmp</Format>\r\n <Format>image/swf</Format>\r\n <DCPType>\r\n <HTTP>\r\n <Get>\r\n <!-- The URL here for invoking GetCapabilities using HTTP GET\r\n is only a prefix to which a query string is appended. -->\r\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://www2.demis.nl/wms/wms.asp?wms=WorldMap&"/>\r\n </Get>\r\n </HTTP>\r\n </DCPType>\r\n </GetMap>\r\n <GetFeatureInfo>\r\n <Format>text/xml</Format>\r\n <Format>text/plain</Format>\r\n <Format>text/html</Format>\r\n <Format>text/swf</Format>\r\n <Format>application/vnd.ogc.gml</Format>\r\n <DCPType>\r\n <HTTP>\r\n <Get>\r\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://www2.demis.nl/wms/wms.asp?wms=WorldMap&"/>\r\n </Get>\r\n </HTTP>\r\n </DCPType>\r\n </GetFeatureInfo>\r\n </Request>\r\n <Exception>\r\n <Format>application/vnd.ogc.se_inimage</Format>\r\n <Format>application/vnd.ogc.se_blank</Format>\r\n <Format>application/vnd.ogc.se_xml</Format>\r\n <Format>text/xml</Format>\r\n <Format>text/plain</Format>\r\n </Exception>\r\n <VendorSpecificCapabilities/>\r\n <Layer>\r\n <Title>World Map</Title>\r\n <SRS>EPSG:4326</SRS>\r\n <LatLonBoundingBox minx="-180" miny="-90" maxx="180" maxy="90"/>\r\n <BoundingBox SRS="EPSG:4326" minx="-184" miny="-90" maxx="180" maxy="90"/>\r\n <Layer queryable="1" opaque="1">\r\n <Name>Bathymetry</Name>\r\n <Title>Bathymetry</Title>\r\n <BoundingBox SRS="EPSG:4326" minx="-180" miny="-90" maxx="180" maxy="90"/>\r\n </Layer>\r\n <Layer queryable="1" opaque="0">\r\n <Name>Countries</Name>\r\n <Title>Countries</Title>\r\n <BoundingBox SRS="EPSG:4326" minx="-184" miny="-90" maxx="180" maxy="85"/>\r\n </Layer>\r\n <Layer queryable="1" opaque="1">\r\n <Name>Topography</Name>\r\n <Title>Topography</Title>\r\n <BoundingBox SRS="EPSG:4326" minx="-180" miny="-59.99999999998" maxx="179.999999999984" maxy="90"/>\r\n </Layer>\r\n <Layer queryable="0" opaque="1">\r\n <Name>Hillshading</Name>\r\n <Title>Hillshading</Title>\r\n <BoundingBox SRS="EPSG:4326" minx="-180" miny="-59.99999999998" maxx="179.999999999984" maxy="90"/>\r\n </Layer>\r\n <Layer queryable="1" opaque="0">\r\n <Name>Builtup areas</Name>\r\n <Title>Builtup areas</Title>\r\n <BoundingBox SRS="EPSG:4326" minx="-180" miny="-55" maxx="180" maxy="75"/>\r\n <ScaleHint min="0" max="1400"/>\r\n </Layer>\r\n <Layer queryable="1" opaque="0">\r\n <Name>Coastlines</Name>\r\n <Title>Coastlines</Title>\r\n <BoundingBox SRS="EPSG:4326" minx="-184" miny="-90" maxx="180" maxy="85"/>\r\n </Layer>\r\n <Layer queryable="1" opaque="0">\r\n <Name>Waterbodies</Name>\r\n <Title>Waterbodies</Title>\r\n <BoundingBox SRS="EPSG:4326" minx="-184" miny="-75" maxx="180" maxy="85"/>\r\n <ScaleHint min="0" max="5600"/>\r\n </Layer>\r\n <Layer queryable="1" opaque="0">\r\n <Name>Inundated</Name>\r\n <Title>Inundated</Title>\r\n <BoundingBox SRS="EPSG:4326" minx="-180" miny="-50" maxx="180" maxy="80"/>\r\n <ScaleHint min="0" max="1400"/>\r\n </Layer>\r\n <Layer queryable="1" opaque="0">\r\n <Name>Rivers</Name>\r\n <Title>Rivers</Title>\r\n <BoundingBox SRS="EPSG:4326" minx="-180" miny="-55" maxx="180" maxy="85"/>\r\n <ScaleHint min="0" max="11200"/>\r\n </Layer>\r\n <Layer queryable="1" opaque="0">\r\n <Name>Streams</Name>\r\n <Title>Streams</Title>\r\n <BoundingBox SRS="EPSG:4326" minx="-180" miny="-55" maxx="180" maxy="85"/>\r\n <ScaleHint min="0" max="5600"/>\r\n </Layer>\r\n <Layer queryable="1" opaque="0">\r\n <Name>Railroads</Name>\r\n <Title>Railroads</Title>\r\n <BoundingBox SRS="EPSG:4326" minx="-170" miny="-55" maxx="180" maxy="80"/>\r\n <ScaleHint min="0" max="840"/>\r\n </Layer>\r\n <Layer queryable="1" opaque="0">\r\n <Name>Highways</Name>\r\n <Title>Highways</Title>\r\n <BoundingBox SRS="EPSG:4326" minx="-175" miny="-55" maxx="180" maxy="75"/>\r\n <ScaleHint min="0" max="700"/>\r\n </Layer>\r\n <Layer queryable="1" opaque="0">\r\n <Name>Roads</Name>\r\n <Title>Roads</Title>\r\n <BoundingBox SRS="EPSG:4326" minx="-184" miny="-55" maxx="180" maxy="75"/>\r\n <ScaleHint min="0" max="420"/>\r\n </Layer>\r\n <Layer queryable="1" opaque="0">\r\n <Name>Trails</Name>\r\n <Title>Trails</Title>\r\n <BoundingBox SRS="EPSG:4326" minx="-184" miny="-50" maxx="180" maxy="80"/>\r\n <ScaleHint min="0" max="280"/>\r\n </Layer>\r\n <Layer queryable="1" opaque="0">\r\n <Name>Borders</Name>\r\n <Title>Borders</Title>\r\n <BoundingBox SRS="EPSG:4326" minx="-184" miny="-60" maxx="176" maxy="75"/>\r\n </Layer>\r\n <Layer queryable="1" opaque="0">\r\n <Name>Cities</Name>\r\n <Title>Cities</Title>\r\n <BoundingBox SRS="EPSG:4326" minx="-180" miny="-55" maxx="180" maxy="75"/>\r\n <ScaleHint min="0" max="28000"/>\r\n </Layer>\r\n <Layer queryable="1" opaque="0">\r\n <Name>Settlements</Name>\r\n <Title>Settlements</Title>\r\n <BoundingBox SRS="EPSG:4326" minx="-180" miny="-55" maxx="180" maxy="85"/>\r\n <ScaleHint min="0" max="560"/>\r\n </Layer>\r\n <Layer queryable="0" opaque="0">\r\n <Name>Spot elevations</Name>\r\n <Title>Spot elevations</Title>\r\n <BoundingBox SRS="EPSG:4326" minx="-179.983093261719" miny="-89.83837890625" maxx="179.991439819336" maxy="83.5204086303711"/>\r\n <ScaleHint min="0" max="280"/>\r\n </Layer>\r\n <Layer queryable="1" opaque="0">\r\n <Name>Airports</Name>\r\n <Title>Airports</Title>\r\n <BoundingBox SRS="EPSG:4326" minx="-184" miny="-55" maxx="180" maxy="80"/>\r\n <ScaleHint min="0" max="560"/>\r\n </Layer>\r\n <Layer queryable="1" opaque="0">\r\n <Name>Ocean features</Name>\r\n <Title>Ocean features</Title>\r\n <BoundingBox SRS="EPSG:4326" minx="-180" miny="-62.9231796264648" maxx="179.999420166016" maxy="68.6906585693359"/>\r\n <ScaleHint min="0" max="2800"/>\r\n </Layer>\r\n </Layer>\r\n </Capability>\r\n</WMT_MS_Capabilities>\r\n\r\n');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (859, '1.1.1', 'Baden Württemberg, Digitale Orthophotos', 'Digitale Orthophotos SW Landesvermessung Baden Württemberg', 'http://www.rds.lv-bw.de/wmsconnector/com.esri.wms.Esrimap?ServiceName=geo600', 'http://www.rds.lv-bw.de/wmsconnector/com.esri.wms.Esrimap?ServiceName=geo600', 'http://www.rds.lv-bw.de/wmsconnector/com.esri.wms.Esrimap?ServiceName=geo600', '', NULL, '<?xml version="1.0" encoding="UTF-8"?>\r\n<!DOCTYPE WMT_MS_Capabilities SYSTEM "http://schemas.opengis.net/wms/1.1.1/WMS_MS_Capabilities.dtd">\r\n<WMT_MS_Capabilities version="1.1.1">\r\n<Service>\r\n<Name>OGC:WMS</Name>\r\n<Title>Baden Württemberg, Digitale Orthophotos</Title>\r\n<Abstract>Digitale Orthophotos SW Landesvermessung Baden Württemberg</Abstract>\r\n<KeywordList>\r\n<Keyword>MapServer, GeoServer, Mapbender, Open Source, Free Software</Keyword>\r\n</KeywordList>\r\n<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.rds.lv-bw.de/wmsconnector/com.esri.wms.Esrimap?ServiceName=geo600" xlink:type="simple"/>\r\n<ContactInformation>\r\n<ContactPersonPrimary>\r\n<ContactPerson/>\r\n<ContactOrganization/>\r\n</ContactPersonPrimary>\r\n<ContactPosition/>\r\n<ContactAddress>\r\n<AddressType>postal</AddressType>\r\n<Address/>\r\n<City/>\r\n<StateOrProvince/>\r\n<PostCode/>\r\n<Country/>\r\n</ContactAddress>\r\n<ContactVoiceTelephone/>\r\n<ContactFacsimileTelephone/>\r\n<ContactElectronicMailAddress/>\r\n</ContactInformation>\r\n<Fees>none</Fees>\r\n<AccessConstraints>none</AccessConstraints>\r\n</Service>\r\n<Capability>\r\n<Request>\r\n<GetCapabilities>\r\n<Format>application/vnd.ogc.wms_xml</Format>\r\n<DCPType>\r\n<HTTP>\r\n<Get>\r\n<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.rds.lv-bw.de/wmsconnector/com.esri.wms.Esrimap?ServiceName=geo600" xlink:type="simple"/>\r\n</Get>\r\n</HTTP>\r\n</DCPType>\r\n</GetCapabilities>\r\n<GetMap>\r\n<Format>image/png</Format>\r\n<Format>image/jpeg</Format>\r\n<DCPType>\r\n<HTTP>\r\n<Get>\r\n<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.rds.lv-bw.de/wmsconnector/com.esri.wms.Esrimap?ServiceName=geo600" xlink:type="simple"/>\r\n</Get>\r\n</HTTP>\r\n</DCPType>\r\n</GetMap>\r\n<GetFeatureInfo>\r\n<Format>application/vnd.ogc.wms_xml</Format>\r\n<Format>text/xml</Format>\r\n<Format>text/html</Format>\r\n<Format>text/plain</Format>\r\n<DCPType>\r\n<HTTP>\r\n<Get>\r\n<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.rds.lv-bw.de/wmsconnector/com.esri.wms.Esrimap?ServiceName=geo600" xlink:type="simple"/>\r\n</Get>\r\n</HTTP>\r\n</DCPType>\r\n</GetFeatureInfo>\r\n</Request>\r\n<Exception>\r\n<Format>application/vnd.ogc.se_xml</Format>\r\n<Format>application/vnd.ogc.se_inimage</Format>\r\n<Format>application/vnd.ogc.se_blank</Format>\r\n</Exception>\r\n<Layer queryable="0" opaque="0" noSubsets="0">\r\n<Title>Geobasisdaten</Title>\r\n<SRS>EPSG:4326</SRS>\r\n<LatLonBoundingBox minx="7.46" miny="47.49" maxx="10.57" maxy="49.81"/>\r\n<BoundingBox SRS="EPSG:31467" minx="3383722" miny="5262500" maxx="3616277" maxy="5521500" /> \r\n<Layer queryable="0">\r\n<Name>1</Name>\r\n<Title>Digitale Orthophotos</Title>\r\n<SRS>EPSG:4326</SRS>\r\n<LatLonBoundingBox minx="7.46" miny="47.49" maxx="10.57" maxy="49.81"/>\r\n<BoundingBox SRS="EPSG:31467" minx="3383722" miny="5262500" maxx="3616277" maxy="5521500" /> \r\n</Layer>\r\n</Layer>\r\n</Capability>\r\n</WMT_MS_Capabilities>\r\n');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (860, '1.1.0', 'Rhein-Erft-Kreis Projekt umn_grundkarte', 'WMT Map Server maintained by KDVZ Rhein-Erft-Rur. \nContact: www.kdvz-frechen.de. \nHigh-quality maps conform to ALK norm.', 'http://geoserver.rhein-erft-kreis.de:80/GeoOgcWms1.2/servlet/umn_grundkarte', 'http://geoserver.rhein-erft-kreis.de:80/GeoOgcWms1.2/servlet/umn_grundkarte', 'http://geoserver.rhein-erft-kreis.de:80/GeoOgcWms1.2/servlet/umn_grundkarte', '', NULL, '<?xml version="1.0" encoding="ISO-8859-1" standalone="no" ?> \n<!-- The DTD (Document Type Definition) given here must correspond to the version number declared in the WMT_MS_Capabilities element below. -->\n<!DOCTYPE WMT_MS_Capabilities SYSTEM \n "http://www.digitalearth.gov/wmt/xml/capabilities_1_1_0.dtd"\n [\n <!-- other vendor-specific elements defined here -->\n <!ELEMENT VendorSpecificCapabilities EMPTY> \n ]> <!-- end of DOCTYPE declaration -->\n\n<!-- The version number listed in the WMT_MS_Capabilities element here must correspond to the DTD declared above. See the WMT specification document for how to respond when a client requests a version number not implemented by the server. -->\n\n<WMT_MS_Capabilities version="1.1.0" updateSequence="0">\n<!-- Service Metadata -->\n<Service>\n <!-- The WMT-defined name for this type of service -->\n <Name>OGC:WMS</Name>\n <!-- Human-readable title for pick lists -->\n <Title>Rhein-Erft-Kreis Projekt "umn_grundkarte"</Title>\n <!-- Narrative description providing additional information -->\n <Abstract>WMT Map Server maintained by KDVZ Rhein-Erft-Rur. \nContact: www.kdvz-frechen.de. \nHigh-quality maps conform to ALK norm.</Abstract>\n \n<!-- Top-level web address of service or service provider. See also OnlineResource\n elements under <DCPType>. -->\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"\n xlink:href="http://www.rhein-erft-kreis.de"\n xlink:type="simple" />\n \n <!-- Contact information -->\n <ContactInformation>\n <ContactPersonPrimary>\n <ContactPerson> Herr Wolff / Herr Herzogenrath</ContactPerson>\n <ContactOrganization>Vermessungs- und Katasteramt Rhein-Erft-Kreis</ContactOrganization>\n </ContactPersonPrimary>\n <ContactPosition></ContactPosition>\n <ContactAddress>\n <AddressType></AddressType>\n <Address>Willy-Brandt-Platz 1</Address>\n <City>Bergheim</City>\n <StateOrProvince>NRW</StateOrProvince>\n <PostCode>50124</PostCode>\n <Country>Deutschland</Country>\n </ContactAddress>\n <ContactVoiceTelephone>+49 2271 83 2770</ContactVoiceTelephone>\n <ContactFacsimileTelephone>+49 2271 83 2300</ContactFacsimileTelephone>\n <ContactElectronicMailAddress>johann.wolff at rhein-erft-kreis.de</ContactElectronicMailAddress>\n </ContactInformation>\n <Fees>none</Fees>\n <AccessConstraints>none</AccessConstraints>\n</Service>\n<Capability>\n <Request>\n <GetCapabilities>\n <Format>application/vnd.ogc.wms_xml</Format>\n <DCPType>\n <HTTP>\n <Get>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"\n xlink:href="http://geoserver.rhein-erft-kreis.de:80/GeoOgcWms1.2/servlet/umn_grundkarte"\n xlink:type="simple" />\n </Get>\n <Post>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"\n xlink:href="http://geoserver.rhein-erft-kreis.de:80/GeoOgcWms1.2/servlet/umn_grundkarte"\n xlink:type="simple" />\n </Post>\n </HTTP>\n </DCPType>\n </GetCapabilities>\n <GetMap>\n <Format>image/gif</Format>\n <Format>image/png</Format>\n <Format>image/bmp</Format>\n <Format>image/jpeg</Format>\n <Format>image/tiff</Format>\n <DCPType>\n <HTTP>\n <Get>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"\n xlink:href="http://geoserver.rhein-erft-kreis.de:80/GeoOgcWms1.2/servlet/umn_grundkarte"\n xlink:type="simple" />\n </Get>\n </HTTP>\n </DCPType>\n </GetMap>\n <GetFeatureInfo>\n <Format>text/html</Format>\n <Format>text/plain</Format>\n <DCPType>\n <HTTP>\n <Get>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"\n xlink:href="http://geoserver.rhein-erft-kreis.de:80/GeoOgcWms1.2/servlet/umn_grundkarte"\n xlink:type="simple" />\n </Get>\n <Post>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"\n xlink:href="http://geoserver.rhein-erft-kreis.de:80/GeoOgcWms1.2/servlet/umn_grundkarte"\n xlink:type="simple" />\n </Post>\n </HTTP>\n </DCPType>\n </GetFeatureInfo>\n </Request>\n <Exception>\n <Format>application/vnd.ogc.se_xml</Format>\n </Exception>\n <Layer queryable="0" opaque="1">\n <Title>Grundkarte REK</Title>\n <SRS>EPSG:31466 EPSG:31462 EPSG:31492</SRS>\n <LatLonBoundingBox minx="6.4505" miny="50.7149" maxx="7.0359" maxy="51.0604"></LatLonBoundingBox>\n <BoundingBox SRS="EPSG:31466" minx="2531814.0" miny="5620466.0" maxx="2572624.0" maxy="5659316.0"></BoundingBox>\n <BoundingBox SRS="EPSG:31462" minx="2531814.0" miny="5620466.0" maxx="2572624.0" maxy="5659316.0"></BoundingBox>\n <BoundingBox SRS="EPSG:31492" minx="2531814.0" miny="5620466.0" maxx="2572624.0" maxy="5659316.0"></BoundingBox>\n <ScaleHint min="0.0010" max="6.905"></ScaleHint>\n <Layer queryable="1" opaque="1">\n <Name>LIKA_TAUSEND:Gebaeude</Name>\n <Title>Gebaeude</Title>\n </Layer>\n <Layer queryable="1" opaque="1">\n <Name>LIKA_TAUSEND:Grundkarte</Name>\n <Title>Grundkarte</Title>\n </Layer>\n <Layer queryable="1" opaque="1">\n <Name>LIKA_TAUSEND:Leer</Name>\n <Title>Leer</Title>\n </Layer>\n <Layer queryable="1" opaque="1">\n <Name>LIKA_TAUSEND:Strasse_HsNr</Name>\n <Title>Strasse_HsNr</Title>\n </Layer>\n </Layer></Capability>\n</WMT_MS_Capabilities>\n');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (861, '1.1.0', 'Rhein-Erft-Kreis Projekt umn_grundkarte', 'WMT Map Server maintained by KDVZ Rhein-Erft-Rur. Contact: www.kdvz-frechen.de. High-quality maps conform to ALK norm.', 'http://geoserver.rhein-erft-kreis.de:80/GeoOgcWms1.2/servlet/umn_grundkarte', 'http://geoserver.rhein-erft-kreis.de:80/GeoOgcWms1.2/servlet/umn_grundkarte', 'http://geoserver.rhein-erft-kreis.de:80/GeoOgcWms1.2/servlet/umn_grundkarte', '', NULL, '<?xml version="1.0" encoding="ISO-8859-1" standalone="no" ?> \n<!-- The DTD (Document Type Definition) given here must correspond to the version number declared in the WMT_MS_Capabilities element below. -->\n<!DOCTYPE WMT_MS_Capabilities SYSTEM \n "http://www.digitalearth.gov/wmt/xml/capabilities_1_1_0.dtd"\n [\n <!-- other vendor-specific elements defined here -->\n <!ELEMENT VendorSpecificCapabilities EMPTY> \n ]> <!-- end of DOCTYPE declaration -->\n\n<!-- The version number listed in the WMT_MS_Capabilities element here must correspond to the DTD declared above. See the WMT specification document for how to respond when a client requests a version number not implemented by the server. -->\n\n<WMT_MS_Capabilities version="1.1.0" updateSequence="0">\n<!-- Service Metadata -->\n<Service>\n <!-- The WMT-defined name for this type of service -->\n <Name>OGC:WMS</Name>\n <!-- Human-readable title for pick lists -->\n <Title>Rhein-Erft-Kreis Projekt "umn_grundkarte"</Title>\n <!-- Narrative description providing additional information -->\n <Abstract>WMT Map Server maintained by KDVZ Rhein-Erft-Rur. \nContact: www.kdvz-frechen.de. \nHigh-quality maps conform to ALK norm.</Abstract>\n \n<!-- Top-level web address of service or service provider. See also OnlineResource\n elements under <DCPType>. -->\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"\n xlink:href="http://www.rhein-erft-kreis.de"\n xlink:type="simple" />\n \n <!-- Contact information -->\n <ContactInformation>\n <ContactPersonPrimary>\n <ContactPerson> Herr Wolff / Herr Herzogenrath</ContactPerson>\n <ContactOrganization>Vermessungs- und Katasteramt Rhein-Erft-Kreis</ContactOrganization>\n </ContactPersonPrimary>\n <ContactPosition></ContactPosition>\n <ContactAddress>\n <AddressType></AddressType>\n <Address>Willy-Brandt-Platz 1</Address>\n <City>Bergheim</City>\n <StateOrProvince>NRW</StateOrProvince>\n <PostCode>50124</PostCode>\n <Country>Deutschland</Country>\n </ContactAddress>\n <ContactVoiceTelephone>+49 2271 83 2770</ContactVoiceTelephone>\n <ContactFacsimileTelephone>+49 2271 83 2300</ContactFacsimileTelephone>\n <ContactElectronicMailAddress>johann.wolff at rhein-erft-kreis.de</ContactElectronicMailAddress>\n </ContactInformation>\n <Fees>none</Fees>\n <AccessConstraints>none</AccessConstraints>\n</Service>\n<Capability>\n <Request>\n <GetCapabilities>\n <Format>application/vnd.ogc.wms_xml</Format>\n <DCPType>\n <HTTP>\n <Get>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"\n xlink:href="http://geoserver.rhein-erft-kreis.de:80/GeoOgcWms1.2/servlet/umn_grundkarte"\n xlink:type="simple" />\n </Get>\n <Post>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"\n xlink:href="http://geoserver.rhein-erft-kreis.de:80/GeoOgcWms1.2/servlet/umn_grundkarte"\n xlink:type="simple" />\n </Post>\n </HTTP>\n </DCPType>\n </GetCapabilities>\n <GetMap>\n <Format>image/gif</Format>\n <Format>image/png</Format>\n <Format>image/bmp</Format>\n <Format>image/jpeg</Format>\n <Format>image/tiff</Format>\n <DCPType>\n <HTTP>\n <Get>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"\n xlink:href="http://geoserver.rhein-erft-kreis.de:80/GeoOgcWms1.2/servlet/umn_grundkarte"\n xlink:type="simple" />\n </Get>\n </HTTP>\n </DCPType>\n </GetMap>\n <GetFeatureInfo>\n <Format>text/html</Format>\n <Format>text/plain</Format>\n <DCPType>\n <HTTP>\n <Get>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"\n xlink:href="http://geoserver.rhein-erft-kreis.de:80/GeoOgcWms1.2/servlet/umn_grundkarte"\n xlink:type="simple" />\n </Get>\n <Post>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"\n xlink:href="http://geoserver.rhein-erft-kreis.de:80/GeoOgcWms1.2/servlet/umn_grundkarte"\n xlink:type="simple" />\n </Post>\n </HTTP>\n </DCPType>\n </GetFeatureInfo>\n </Request>\n <Exception>\n <Format>application/vnd.ogc.se_xml</Format>\n </Exception>\n <Layer queryable="0" opaque="1">\n <Title>Grundkarte REK</Title>\n <SRS>EPSG:31466 EPSG:31462 EPSG:31492</SRS>\n <LatLonBoundingBox minx="6.4505" miny="50.7149" maxx="7.0359" maxy="51.0604"></LatLonBoundingBox>\n <BoundingBox SRS="EPSG:31466" minx="2531814.0" miny="5620466.0" maxx="2572624.0" maxy="5659316.0"></BoundingBox>\n <BoundingBox SRS="EPSG:31462" minx="2531814.0" miny="5620466.0" maxx="2572624.0" maxy="5659316.0"></BoundingBox>\n <BoundingBox SRS="EPSG:31492" minx="2531814.0" miny="5620466.0" maxx="2572624.0" maxy="5659316.0"></BoundingBox>\n <ScaleHint min="0.0010" max="6.905"></ScaleHint>\n <Layer queryable="1" opaque="1">\n <Name>LIKA_TAUSEND:Gebaeude</Name>\n <Title>Gebaeude</Title>\n </Layer>\n <Layer queryable="1" opaque="1">\n <Name>LIKA_TAUSEND:Grundkarte</Name>\n <Title>Grundkarte</Title>\n </Layer>\n <Layer queryable="1" opaque="1">\n <Name>LIKA_TAUSEND:Leer</Name>\n <Title>Leer</Title>\n </Layer>\n <Layer queryable="1" opaque="1">\n <Name>LIKA_TAUSEND:Strasse_HsNr</Name>\n <Title>Strasse_HsNr</Title>\n </Layer>\n </Layer></Capability>\n</WMT_MS_Capabilities>\n');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (862, '1.1.0', 'Rhein-Erft-Kreis Projekt umn_grundkarte', 'WMT Map Server maintained by KDVZ Rhein-Erft-Rur. \nContact: www.kdvz-frechen.de. \nHigh-quality maps conform to ALK norm.', 'http://geoserver.rhein-erft-kreis.de:80/GeoOgcWms1.2/servlet/umn_grundkarte', 'http://geoserver.rhein-erft-kreis.de:80/GeoOgcWms1.2/servlet/umn_grundkarte', 'http://geoserver.rhein-erft-kreis.de:80/GeoOgcWms1.2/servlet/umn_grundkarte', '', NULL, '<?xml version="1.0" encoding="ISO-8859-1" standalone="no" ?> \n<!-- The DTD (Document Type Definition) given here must correspond to the version number declared in the WMT_MS_Capabilities element below. -->\n<!DOCTYPE WMT_MS_Capabilities SYSTEM \n "http://www.digitalearth.gov/wmt/xml/capabilities_1_1_0.dtd"\n [\n <!-- other vendor-specific elements defined here -->\n <!ELEMENT VendorSpecificCapabilities EMPTY> \n ]> <!-- end of DOCTYPE declaration -->\n\n<!-- The version number listed in the WMT_MS_Capabilities element here must correspond to the DTD declared above. See the WMT specification document for how to respond when a client requests a version number not implemented by the server. -->\n\n<WMT_MS_Capabilities version="1.1.0" updateSequence="0">\n<!-- Service Metadata -->\n<Service>\n <!-- The WMT-defined name for this type of service -->\n <Name>OGC:WMS</Name>\n <!-- Human-readable title for pick lists -->\n <Title>Rhein-Erft-Kreis Projekt "umn_grundkarte"</Title>\n <!-- Narrative description providing additional information -->\n <Abstract>WMT Map Server maintained by KDVZ Rhein-Erft-Rur. \nContact: www.kdvz-frechen.de. \nHigh-quality maps conform to ALK norm.</Abstract>\n \n<!-- Top-level web address of service or service provider. See also OnlineResource\n elements under <DCPType>. -->\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"\n xlink:href="http://www.rhein-erft-kreis.de"\n xlink:type="simple" />\n \n <!-- Contact information -->\n <ContactInformation>\n <ContactPersonPrimary>\n <ContactPerson> Herr Wolff / Herr Herzogenrath</ContactPerson>\n <ContactOrganization>Vermessungs- und Katasteramt Rhein-Erft-Kreis</ContactOrganization>\n </ContactPersonPrimary>\n <ContactPosition></ContactPosition>\n <ContactAddress>\n <AddressType></AddressType>\n <Address>Willy-Brandt-Platz 1</Address>\n <City>Bergheim</City>\n <StateOrProvince>NRW</StateOrProvince>\n <PostCode>50124</PostCode>\n <Country>Deutschland</Country>\n </ContactAddress>\n <ContactVoiceTelephone>+49 2271 83 2770</ContactVoiceTelephone>\n <ContactFacsimileTelephone>+49 2271 83 2300</ContactFacsimileTelephone>\n <ContactElectronicMailAddress>johann.wolff at rhein-erft-kreis.de</ContactElectronicMailAddress>\n </ContactInformation>\n <Fees>none</Fees>\n <AccessConstraints>none</AccessConstraints>\n</Service>\n<Capability>\n <Request>\n <GetCapabilities>\n <Format>application/vnd.ogc.wms_xml</Format>\n <DCPType>\n <HTTP>\n <Get>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"\n xlink:href="http://geoserver.rhein-erft-kreis.de:80/GeoOgcWms1.2/servlet/umn_grundkarte"\n xlink:type="simple" />\n </Get>\n <Post>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"\n xlink:href="http://geoserver.rhein-erft-kreis.de:80/GeoOgcWms1.2/servlet/umn_grundkarte"\n xlink:type="simple" />\n </Post>\n </HTTP>\n </DCPType>\n </GetCapabilities>\n <GetMap>\n <Format>image/gif</Format>\n <Format>image/png</Format>\n <Format>image/bmp</Format>\n <Format>image/jpeg</Format>\n <Format>image/tiff</Format>\n <DCPType>\n <HTTP>\n <Get>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"\n xlink:href="http://geoserver.rhein-erft-kreis.de:80/GeoOgcWms1.2/servlet/umn_grundkarte"\n xlink:type="simple" />\n </Get>\n </HTTP>\n </DCPType>\n </GetMap>\n <GetFeatureInfo>\n <Format>text/html</Format>\n <Format>text/plain</Format>\n <DCPType>\n <HTTP>\n <Get>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"\n xlink:href="http://geoserver.rhein-erft-kreis.de:80/GeoOgcWms1.2/servlet/umn_grundkarte"\n xlink:type="simple" />\n </Get>\n <Post>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"\n xlink:href="http://geoserver.rhein-erft-kreis.de:80/GeoOgcWms1.2/servlet/umn_grundkarte"\n xlink:type="simple" />\n </Post>\n </HTTP>\n </DCPType>\n </GetFeatureInfo>\n </Request>\n <Exception>\n <Format>application/vnd.ogc.se_xml</Format>\n </Exception>\n <Layer queryable="0" opaque="1">\n <Title>Grundkarte REK</Title>\n <SRS>EPSG:31466 EPSG:31462 EPSG:31492</SRS>\n <LatLonBoundingBox minx="6.4505" miny="50.7149" maxx="7.0359" maxy="51.0604"></LatLonBoundingBox>\n <BoundingBox SRS="EPSG:31466" minx="2531814.0" miny="5620466.0" maxx="2572624.0" maxy="5659316.0"></BoundingBox>\n <BoundingBox SRS="EPSG:31462" minx="2531814.0" miny="5620466.0" maxx="2572624.0" maxy="5659316.0"></BoundingBox>\n <BoundingBox SRS="EPSG:31492" minx="2531814.0" miny="5620466.0" maxx="2572624.0" maxy="5659316.0"></BoundingBox>\n <ScaleHint min="0.0010" max="6.905"></ScaleHint>\n <Layer queryable="1" opaque="1">\n <Name>LIKA_TAUSEND:Gebaeude</Name>\n <Title>Gebaeude</Title>\n </Layer>\n <Layer queryable="1" opaque="1">\n <Name>LIKA_TAUSEND:Grundkarte</Name>\n <Title>Grundkarte</Title>\n </Layer>\n <Layer queryable="1" opaque="1">\n <Name>LIKA_TAUSEND:Leer</Name>\n <Title>Leer</Title>\n </Layer>\n <Layer queryable="1" opaque="1">\n <Name>LIKA_TAUSEND:Strasse_HsNr</Name>\n <Title>Strasse_HsNr</Title>\n </Layer>\n </Layer></Capability>\n</WMT_MS_Capabilities>\n');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (863, '1.1.1', 'Forstliche Verwaltungsgrenzen NRW', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS', 'http://www.gis2.nrw.de/wmsconnector/wms/forstamtsgr?', 'http://www.gis2.nrw.de/wmsconnector/wms/forstamtsgr?', 'http://www.gis2.nrw.de/wmsconnector/wms/forstamtsgr?', '', NULL, '<?xml version="1.0" encoding="UTF-8"?>\n<!DOCTYPE WMT_MS_Capabilities\n SYSTEM "http://www.gis2.nrw.de/wmsconnector/schema/wms/1.1.1/capabilities_1_1_1.dtd">\n<WMT_MS_Capabilities updateSequence="0" version="1.1.1">\n <Service>\n <Name>OGC:WMS</Name>\n <Title>Forstliche Verwaltungsgrenzen NRW</Title>\n <Abstract>This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS</Abstract>\n <KeywordList>\n <Keyword>WMS</Keyword>\n <Keyword>Web Mapping</Keyword>\n <Keyword>GIS</Keyword>\n <Keyword>GDI NRW</Keyword>\n </KeywordList>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/wmsconnector/wms/forstamtsgr?" xlink:type="simple"/>\n <ContactInformation>\n <ContactPersonPrimary>\n <ContactPerson>Guenter Spelsberg</ContactPerson>\n <ContactOrganization>LOEBF NRW</ContactOrganization>\n </ContactPersonPrimary>\n <ContactPosition/>\n <ContactAddress>\n <AddressType/>\n <Address>Castroper Str. 312-314</Address>\n <City>Recklinghausen</City>\n <StateOrProvince>NRW</StateOrProvince>\n <PostCode>45665</PostCode>\n <Country>Germany</Country>\n </ContactAddress>\n <ContactVoiceTelephone>49 (2361) 305 1</ContactVoiceTelephone>\n <ContactFacsimileTelephone>49 (2361) 305 370</ContactFacsimileTelephone>\n <ContactElectronicMailAddress>guenter.spelsberg at loebf.nrw.de</ContactElectronicMailAddress>\n </ContactInformation>\n <Fees>siehe http://www.geocatalog.de</Fees>\n <AccessConstraints>siehe http://www.geocatalog.de</AccessConstraints>\n </Service>\n <Capability>\n <Request>\n <GetCapabilities>\n <Format>application/vnd.ogc.wms_xml</Format>\n <DCPType>\n <HTTP>\n <Get>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/wmsconnector/wms/forstamtsgr?" xlink:type="simple"/>\n </Get>\n </HTTP>\n </DCPType>\n <DCPType>\n <HTTP>\n <Post>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/wmsconnector/wms/forstamtsgr?" xlink:type="simple"/>\n </Post>\n </HTTP>\n </DCPType>\n </GetCapabilities>\n <GetMap>\n <Format>image/png</Format>\n <Format>image/jpeg</Format>\n <Format>image/gif</Format>\n <DCPType>\n <HTTP>\n <Get>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/wmsconnector/wms/forstamtsgr?" xlink:type="simple"/>\n </Get>\n </HTTP>\n </DCPType>\n </GetMap>\n <GetFeatureInfo>\n <Format>text/html</Format>\n <Format>text/xml</Format>\n <Format>text/plain</Format>\n <Format>application/vnd.esri.xml</Format>\n <DCPType>\n <HTTP>\n <Get>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/wmsconnector/wms/forstamtsgr?" xlink:type="simple"/>\n </Get>\n </HTTP>\n </DCPType>\n </GetFeatureInfo>\n </Request>\n <Exception>\n <Format>application/vnd.ogc.se_xml</Format>\n </Exception>\n <VendorSpecificCapabilities/>\n <UserDefinedSymbolization RemoteWFS="0" SupportSLD="1" UserLayer="1" UserStyle="1"/>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Title>forstamtsgr</Title>\n <SRS>EPSG:4326</SRS>\n <SRS>EPSG:31492</SRS>\n <SRS>EPSG:25832</SRS>\n <SRS>EPSG:25833</SRS>\n <SRS>EPSG:31466</SRS>\n <SRS>EPSG:31467</SRS>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31492" maxx="2738505.35221098" maxy="5825350.11602884" minx="2490669.9" miny="5576388.9"/>\n <BoundingBox SRS="EPSG:31466" maxx="2738505.35221098" maxy="5825350.11602884" minx="2490669.9" miny="5576388.9"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>0</Name>\n <Title>Forstamtsgrenzen</Title>\n <Style>\n <Name/> \n <Title>Forstamtsgrenzen</Title>\n <LegendURL height="29" width="57">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/Fortsamtsgr/Forstamtsgrenze.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31492" maxx="2738505.35221098" maxy="5825350.11602884" minx="2490669.9" miny="5576388.9"/>\n <BoundingBox SRS="EPSG:31466" maxx="2738505.35221098" maxy="5825350.11602884" minx="2490669.9" miny="5576388.9"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n </Layer>\n </Layer>\n </Capability>\n</WMT_MS_Capabilities>');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (864, '1.1.1', 'Gewaesserstationierungskarte des Landes NRW', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS', 'http://www.gis2.nrw.de/wmsconnector/wms/gewstat?', 'http://www.gis2.nrw.de/wmsconnector/wms/gewstat?', 'http://www.gis2.nrw.de/wmsconnector/wms/gewstat?', '', NULL, '<?xml version="1.0" encoding="UTF-8"?>\n<!DOCTYPE WMT_MS_Capabilities\n SYSTEM "http://www.gis2.nrw.de/wmsconnector/schema/wms/1.1.1/capabilities_1_1_1.dtd">\n<WMT_MS_Capabilities updateSequence="0" version="1.1.1">\n <Service>\n <Name>OGC:WMS</Name>\n <Title>Gewaesserstationierungskarte des Landes NRW</Title>\n <Abstract>This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS</Abstract>\n <KeywordList>\n <Keyword>WMS</Keyword>\n <Keyword>Web Mapping</Keyword>\n <Keyword>GIS</Keyword>\n <Keyword>GDI NRW</Keyword>\n </KeywordList>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/wmsconnector/wms/gewstat?" xlink:type="simple"/>\n <ContactInformation>\n <ContactPersonPrimary>\n <ContactPerson>Ludger Neuhann</ContactPerson>\n <ContactOrganization>Landesumweltamt NRW</ContactOrganization>\n\n </ContactPersonPrimary>\n <ContactPosition/>\n <ContactAddress>\n <AddressType>postal</AddressType>\n <Address>Postfach 10 23 63</Address>\n <City>Essen</City>\n <StateOrProvince>NRW</StateOrProvince>\n <PostCode>45023</PostCode>\n <Country>Germany</Country>\n </ContactAddress>\n <ContactVoiceTelephone>+49 211 1590-2219</ContactVoiceTelephone>\n <ContactFacsimileTelephone>+49 201 7995-1448</ContactFacsimileTelephone>\n <ContactElectronicMailAddress>ludger.neuhann at lua.nrw.de</ContactElectronicMailAddress>\n </ContactInformation>\n <Fees>siehe http://www.geocatalog.de</Fees>\n <AccessConstraints>siehe http://www.geocatalog.de</AccessConstraints>\n </Service>\n <Capability>\n <Request>\n <GetCapabilities>\n <Format>application/vnd.ogc.wms_xml</Format>\n <DCPType>\n <HTTP>\n <Get>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/wmsconnector/wms/gewstat?" xlink:type="simple"/>\n </Get>\n </HTTP>\n </DCPType>\n <DCPType>\n <HTTP>\n <Post>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/wmsconnector/wms/gewstat?" xlink:type="simple"/>\n </Post>\n </HTTP>\n </DCPType>\n </GetCapabilities>\n <GetMap>\n <Format>image/png</Format>\n <Format>image/jpeg</Format>\n <Format>image/gif</Format>\n <DCPType>\n <HTTP>\n <Get>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/wmsconnector/wms/gewstat?" xlink:type="simple"/>\n </Get>\n </HTTP>\n </DCPType>\n </GetMap>\n <GetFeatureInfo>\n <Format>text/html</Format>\n <Format>text/xml</Format>\n <Format>text/plain</Format>\n <Format>application/vnd.esri.xml</Format>\n <DCPType>\n <HTTP>\n <Get>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/wmsconnector/wms/gewstat?" xlink:type="simple"/>\n </Get>\n </HTTP>\n </DCPType>\n </GetFeatureInfo>\n </Request>\n <Exception>\n <Format>application/vnd.ogc.se_xml</Format>\n </Exception>\n <VendorSpecificCapabilities/>\n <UserDefinedSymbolization RemoteWFS="0" SupportSLD="1" UserLayer="1" UserStyle="1"/>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Title>gewstat</Title>\n <SRS>EPSG:4326</SRS>\n <SRS>EPSG:25832</SRS>\n <SRS>EPSG:25833</SRS>\n <SRS>EPSG:31466</SRS>\n <SRS>EPSG:31467</SRS>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>Uebrige Gewaesser groesser 12 m Breite 3</Name>\n <Title>Uebrige Gewaesser groesser 12 m Breite</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="28" width="318">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/gewstat/uebrigeGewaessergroesser12mBreite.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="37.4121581576496" min="0.1"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>Uebrige Gewaesser kleiner 12 m Breite 2</Name>\n <Title>Uebrige Gewaesser kleiner 12 m Breite</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="28" width="318">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/gewstat/uebrigeGewaesserkleiner12mBreite.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="37.4121581576496" min="0.1"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>Kanaele groesser 12 m Breite 2</Name>\n <Title>Kanaele groesser 12 m Breite</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="28" width="318">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/gewstat/Kanaelegroesser12mBreite.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>Kanaele kleiner 12m Breite</Name>\n <Title>Kanaele kleiner 12 m Breite</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="28" width="318">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/gewstat/Kanaelekleiner12mBreite.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>Unterirdisch verlaufende Gewaesser</Name>\n <Title>Unterirdisch verlaufende Gewaesser</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="28" width="328">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/gewstat/unterirdischeGewaesser.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="37.4121581576496" min="0.1"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>Fliessgewaesser groesser 12 m Breite</Name>\n <Title>Fliessgewaesser groesser 12 m Breite</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="28" width="318">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/gewstat/Fliessgewaessergroesser12mBreite.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="37.4121581576496" min="0.1"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>Fliessgewaesser kleiner 12 m Breite</Name>\n <Title>Fliessgewaesser kleiner 12 m Breite</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="146" width="318">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/gewstat/Fliessgewaesserkleiner12mBreite_trs.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="37.4121581576496" min="0.1"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>St_Kanaele 1000 m</Name>\n <Title>St_Kanaele 1000 m</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="28" width="318">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/gewstat/STAT_EIG_1kmPkt_Kanal.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="28.059118618237267" min="0.1"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>St_Rhein und Weser 1000 m</Name>\n <Title>St_Rhein und Weser 1000 m</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="28" width="318">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/gewstat/STAT_EIG_1kmPkt_RhuW.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="28.059118618237267" min="0.1"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>St_Fliessgewaesser 1000 m</Name>\n <Title>St_Fliessgewaesser 1000 m</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="12" width="14">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/gewstat/STAT_EIG_1kmPkt_Fliessgew.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="28.059118618237267" min="0.1"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>St_Kanaele 500 m</Name>\n <Title>St_Kanaele 500 m</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="28" width="318">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/gewstat/STAT_EIG_500mPkt_Kanal.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="18.7060790788248" min="0.1"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>St_Rhein und Weser 500 m</Name>\n <Title>St_Rhein und Weser 500 m</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="28" width="318">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/gewstat/STAT_EIG_500mPkt_RhuW.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="18.7060790788248" min="0.1"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>St_Fliessgewaesser 500 m</Name>\n <Title>St_Fliessgewaesser 500 m</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="28" width="318">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/gewstat/STAT_EIG_500mPkt_Fliessgew.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="18.7060790788248" min="0.1"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>St_Kanaele 100 m</Name>\n <Title>St_Kanaele 100 m</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="28" width="318">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/gewstat/STAT_EIG_100mPkt_Kanal.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="5.611823723647454" min="0.1"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>St_Rhein und Weser 100 m</Name>\n <Title>St_Rhein und Weser 100 m</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="28" width="318">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/gewstat/STAT_EIG_100mPkt_RhuW.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="5.611823723647454" min="0.1"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>St_Fliessgewaesser 100 m</Name>\n <Title>St_Fliessgewaesser 100 m</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="28" width="318">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/gewstat/STAT_EIG_100mPkt_Fliessgew.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="5.611823723647454" min="0.1"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>Stationierungslinie</Name>\n <Title>Stationierungslinie</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="28" width="318">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/gewstat/Stationierungslinie.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="9.353039539412414" min="0.1"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>Fluesse</Name>\n <Title>Fluesse</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="28" width="318">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/gewstat/Fluesse.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="Infinity" min="37.41253227923117"/>\n </Layer>\n </Layer>\n </Capability>\n</WMT_MS_Capabilities>');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (866, '1.1.0', 'Digitale Karte der hochwassergefaehrdeten Bereiche NRW', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS', 'http://www.gis2.nrw.de/wmsconnector/wms/hochwasser?', 'http://www.gis2.nrw.de/wmsconnector/wms/hochwasser?', 'http://www.gis2.nrw.de/wmsconnector/wms/hochwasser?', '', NULL, '<?xml version="1.0" encoding="UTF-8"?>\n<!DOCTYPE WMT_MS_Capabilities\n SYSTEM "http://www.gis2.nrw.de/wmsconnector/schema/wms/1.1.0/capabilities_1_1_0.dtd">\n<WMT_MS_Capabilities updateSequence="0" version="1.1.0">\n <Service>\n <Name>OGC:WMS</Name>\n <Title>Digitale Karte der hochwassergefaehrdeten Bereiche NRW</Title>\n <Abstract>This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS</Abstract>\n <KeywordList>\n <Keyword>WMS</Keyword>\n <Keyword>Web Mapping</Keyword>\n <Keyword>GIS</Keyword>\n <Keyword>GDI NRW</Keyword>\n </KeywordList>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/wmsconnector/wms/hochwasser?" xlink:type="simple"/>\n <ContactInformation>\n <ContactPersonPrimary>\n <ContactPerson>Bernd Mehlig</ContactPerson>\n <ContactOrganization>Landesumweltamt NRW</ContactOrganization>\n </ContactPersonPrimary>\n <ContactPosition/>\n <ContactAddress>\n <AddressType>postal</AddressType>\n <Address>Postfach 10 23 63</Address>\n <City>Essen</City>\n <StateOrProvince>NRW</StateOrProvince>\n <PostCode>45023</PostCode>\n <Country>Germany</Country>\n </ContactAddress>\n <ContactVoiceTelephone>+49 211 1590-2214</ContactVoiceTelephone>\n <ContactFacsimileTelephone>+49 211 1590-2176</ContactFacsimileTelephone>\n <ContactElectronicMailAddress>bernd.mehlig at lua.nrw.de</ContactElectronicMailAddress>\n </ContactInformation>\n <Fees>siehe http://www.geocatalog.de</Fees>\n <AccessConstraints>siehe http://www.geocatalog.de</AccessConstraints>\n </Service>\n <Capability>\n <Request>\n <GetCapabilities>\n <Format>application/vnd.ogc.wms_xml</Format>\n <DCPType>\n <HTTP>\n <Get>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/wmsconnector/wms/hochwasser?" xlink:type="simple"/>\n </Get>\n </HTTP>\n </DCPType>\n <DCPType>\n <HTTP>\n <Post>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/wmsconnector/wms/hochwasser?" xlink:type="simple"/>\n </Post>\n </HTTP>\n </DCPType>\n </GetCapabilities>\n <GetMap>\n <Format>image/jpeg</Format>\n <Format>image/png</Format>\n <Format>image/gif</Format>\n <DCPType>\n <HTTP>\n <Get>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/wmsconnector/wms/hochwasser?" xlink:type="simple"/>\n </Get>\n </HTTP>\n </DCPType>\n </GetMap>\n <GetFeatureInfo>\n <Format>text/html</Format>\n <Format>text/xml</Format>\n <Format>text/plain</Format>\n <Format>application/vnd.esri.xml</Format>\n <DCPType>\n <HTTP>\n <Get>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/wmsconnector/wms/hochwasser?" xlink:type="simple"/>\n </Get>\n </HTTP>\n </DCPType>\n </GetFeatureInfo>\n </Request>\n <Exception>\n <Format>application/vnd.ogc.se_xml</Format>\n </Exception>\n <VendorSpecificCapabilities/>\n <UserDefinedSymbolization RemoteWFS="0" SupportSLD="1" UserLayer="1" UserStyle="1"/>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Title>hochwasser</Title>\n <SRS>EPSG:4326 EPSG:25832 EPSG:25833 EPSG:31466 EPSG:31467</SRS>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>8</Name>\n <Title>rhein-hq100-odeich</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="28" width="448">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/Hochwasser/rhein_hq100_odeich_trs.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="374.12158157649594" min="0.1"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>9</Name>\n <Title>rhein-hq100-mdeich</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="28" width="448">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/Hochwasser/rhein_hq100_mdeich_trs.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="374.12158157649594" min="0.1"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>6</Name>\n <Title>rhein-hq200-odeich</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="28" width="448">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/Hochwasser/rhein_hq200_odeich_trs.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="374.12158157649594" min="0.1"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>7</Name>\n <Title>rhein-hq200-mdeich</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="28" width="448">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/Hochwasser/rhein_hq200_mdeich_trs.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="374.12158157649594" min="0.1"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>4</Name>\n <Title>rhein-hq500-odeich</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="28" width="448">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/Hochwasser/rhein_hq500_odeich_trs.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="374.12158157649594" min="0.1"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>5</Name>\n <Title>rhein-hq500-mdeich</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="28" width="448">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/Hochwasser/rhein_hq500_mdeich_trs.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="374.12158157649594" min="0.1"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>0</Name>\n <Title>vereinf_Verfahren</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="28" width="305">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/Hochwasser/UESG_vereinfVerfahren_trs.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="187.06079078824797" min="0.1"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>1</Name>\n <Title>Sonstige_UESG</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="356" width="459">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/Hochwasser/sonstigeUESG_trs.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="187.06079078824797" min="0.1"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>2</Name>\n <Title>Historische_UESG</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="181" width="390">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/Hochwasser/historischeUESG_trs.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="187.06079078824797" min="0.1"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>3</Name>\n <Title>neuere_Berechnungsverfahren</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="685" width="390">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/Hochwasser/NeueBerechngsverf_trs.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="187.06079078824797" min="0.1"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>18</Name>\n <Title>Seen</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="28" width="157">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/Hochwasser/Seen_trs.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="187.06079078824797" min="0.1"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>19</Name>\n <Title>Talsperre</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="28" width="157">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/Hochwasser/Talsperre_trs.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="187.06079078824797" min="0.1"/>\n </Layer>\n </Layer>\n </Capability>\n</WMT_MS_Capabilities>');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (867, '1.1.0', 'FIS Stobo NRW', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS', 'http://www.gis2.nrw.de/wmsconnector/wms/stobo?', 'http://www.gis2.nrw.de/wmsconnector/wms/stobo?', 'http://www.gis2.nrw.de/wmsconnector/wms/stobo?', '', NULL, '<?xml version="1.0" encoding="UTF-8"?>\n<!DOCTYPE WMT_MS_Capabilities\n SYSTEM "http://www.gis2.nrw.de/wmsconnector/schema/wms/1.1.0/capabilities_1_1_0.dtd">\n<WMT_MS_Capabilities updateSequence="0" version="1.1.0">\n <Service>\n <Name>OGC:WMS</Name>\n <Title>FIS Stobo NRW</Title>\n <Abstract>This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS</Abstract>\n <KeywordList>\n <Keyword>WMS</Keyword>\n <Keyword>Web Mapping</Keyword>\n <Keyword>GIS</Keyword>\n <Keyword>GDI NRW</Keyword>\n </KeywordList>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/wmsconnector/wms/stobo?" xlink:type="simple"/>\n <ContactInformation>\n <ContactPersonPrimary>\n <ContactPerson>Kartin Heidbrink</ContactPerson>\n <ContactOrganization>Landesumweltamt NRW</ContactOrganization>\n </ContactPersonPrimary>\n <ContactPosition/>\n <ContactAddress>\n <AddressType>postal</AddressType>\n <Address>Postfach 10 23 63</Address>\n <City>Essen</City>\n <StateOrProvince>NRW</StateOrProvince>\n <PostCode>45023</PostCode>\n <Country>Germany</Country>\n </ContactAddress>\n <ContactVoiceTelephone>+49 211 1590-0</ContactVoiceTelephone>\n <ContactFacsimileTelephone>+49 201 7995-1448</ContactFacsimileTelephone>\n <ContactElectronicMailAddress>kartin.heidbrink at lua.nrw.de</ContactElectronicMailAddress>\n </ContactInformation>\n <Fees>siehe http://www.geocatalog.de</Fees>\n <AccessConstraints>siehe http://www.geocatalog.de</AccessConstraints>\n </Service>\n <Capability>\n <Request>\n <GetCapabilities>\n <Format>application/vnd.ogc.wms_xml</Format>\n <DCPType>\n <HTTP>\n <Get>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/wmsconnector/wms/stobo?" xlink:type="simple"/>\n </Get>\n </HTTP>\n </DCPType>\n <DCPType>\n <HTTP>\n <Post>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/wmsconnector/wms/stobo?" xlink:type="simple"/>\n </Post>\n </HTTP>\n </DCPType>\n </GetCapabilities>\n <GetMap>\n <Format>image/jpeg</Format>\n <Format>image/png</Format>\n <Format>image/gif</Format>\n <DCPType>\n <HTTP>\n <Get>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/wmsconnector/wms/stobo?" xlink:type="simple"/>\n </Get>\n </HTTP>\n </DCPType>\n </GetMap>\n <GetFeatureInfo>\n <Format>text/html</Format>\n <Format>text/xml</Format>\n <Format>text/plain</Format>\n <Format>application/vnd.esri.xml</Format>\n <DCPType>\n <HTTP>\n <Get>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/wmsconnector/wms/stobo?" xlink:type="simple"/>\n </Get>\n </HTTP>\n </DCPType>\n </GetFeatureInfo>\n </Request>\n <Exception>\n <Format>application/vnd.ogc.se_xml</Format>\n </Exception>\n <VendorSpecificCapabilities/>\n <UserDefinedSymbolization RemoteWFS="0" SupportSLD="1" UserLayer="1" UserStyle="1"/>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Title>stobo</Title>\n <SRS>EPSG:4326 EPSG:25832 EPSG:25833 EPSG:31466 EPSG:31467</SRS>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>Bleibelastung der Ackerboeden in mg pro kg</Name>\n <Title>Bleibelastung der Ackerboeden in mg pro kg</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="547" width="380">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/stobo/Blei_Acker_trs.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="Infinity" min="11.223647447294894"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>Cadmiumbelastung der Ackerboeden in mg pro kg</Name>\n <Title>Cadmiumbelastung der Ackerboeden in mg pro kg</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="547" width="380">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/stobo/Cadmium_Acker_trs.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="Infinity" min="11.223647447294894"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>Zinkbelastung der Ackerboeden in mg pro kg</Name>\n <Title>Zinkbelastung der Ackerboeden in mg pro kg</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="467" width="380">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/stobo/Zink_Acker_trs.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="Infinity" min="11.223647447294894"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>Bleibelastung der Gartenboeden in mg pro kg</Name>\n <Title>Bleibelastung der Gartenboeden in mg pro kg</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="547" width="380">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/stobo/Blei_Garten_trs.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="Infinity" min="11.223647447294894"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>Cadmiumbelastung der Gartenboeden in mg pro kg</Name>\n <Title>Cadmiumbelastung der Gartenboeden in mg pro kg</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="547" width="380">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/stobo/Cadmium_Garten_trs.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="Infinity" min="11.223647447294894"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>Zinkbelastung der Gartenboeden in mg pro kg</Name>\n <Title>Zinkbelastung der Gartenboeden in mg pro kg</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="467" width="380">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/stobo/Zink_Garten_trs.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="37.4121581576496" min="11.223647447294894"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>Bleibelastung der Gruenlandboeden in mg pro kg</Name>\n <Title>Bleibelastung der Gruenlandboeden in mg pro kg</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="547" width="380">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/stobo/Blei_Gruenland_trs.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="Infinity" min="11.223647447294894"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>Cadmiumbelastung der Gruenlandboeden in mg pro kg</Name>\n <Title>Cadmiumbelastung der Gruenlandboeden in mg pro kg</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="547" width="380">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/stobo/Cadmium_Gruenland_trs.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="Infinity" min="11.223647447294894"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>Zinkbelastung der Gruenlandboeden in mg pro kg</Name>\n <Title>Zinkbelastung der Gruenlandboeden in mg pro kg</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="467" width="380">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/stobo/Zink_Gruenland_trs.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="Infinity" min="11.223647447294894"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>Probenahmenstandorte in NRW differenziert nach Nutzungen</Name>\n <Title>Probenahmenstandorte in NRW differenziert nach Nutzungen</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="252" width="235">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/stobo/Nutzung_trs.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="Infinity" min="11.223647447294894"/>\n </Layer>\n </Layer>\n </Capability>\n</WMT_MS_Capabilities>');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (868, '1.1.0', 'DGM50', 'Nutzungsbedingungen: Sämtliche Rechte an diesem Produkt liegen beim Landesvermessungsamt NRW. Die Nutzung ist bis auf Widerruf kostenfrei. Der Nutzer muss sich vor jeder Nutzung beim Landesvermessungsamt NRW identifizieren und seine spezielle Nutzung mit', 'http://www.gis.nrw.de:80/wms/DGM50', 'http://www.gis.nrw.de:80/wms/DGM50', 'http://www.gis.nrw.de:80/wms/DGM50', '', NULL, '<?xml version="1.0" encoding="ISO-8859-1" standalone="yes" ?>\r\n\r\n<!DOCTYPE WMT_MS_Capabilities SYSTEM "http://www.digitalearth.gov/wmt/xml/capabilities_1_1_0.dtd"[<!ELEMENT VendorSpecificCapabilities EMPTY>]>\r\n<WMT_MS_Capabilities version="1.1.0" updateSequence="0"> \r\n\r\n<Service>\r\n <!-- The WMT-defined name for this type of service -->\r\n <Name>OGC:WMS</Name>\r\n <!-- Human-readable title for pick lists -->\r\n <Title>DGM50</Title>\r\n <!-- Narrative description providing additional information -->\r\n <Abstract>Nutzungsbedingungen: Sämtliche Rechte an diesem Produkt liegen beim Landesvermessungsamt NRW. Die Nutzung ist bis auf Widerruf kostenfrei. Der Nutzer muss sich vor jeder Nutzung beim Landesvermessungsamt NRW identifizieren und seine spezielle Nutzung mit Angabe des Verwendungszwecks und Umfang der Nutzung anmelden (Kontaktmöglichkeiten zum Landesvermessungsamt NRW siehe unten). Die Nutzung ist ausschließlich für Testzwecke und im Rahmen von GDI-Projekten zulässig; die Nutzung für kommerzielle Anwendungen ist ausdrücklich ausgeschlossen. Die mittelbare oder unmittelbare Weitergabe der Daten an Dritte ist auch in Verbindung mit weiteren Daten ohne ausdrückliche Genehmigung durch das Landesvermessungsamt NRW nicht zulässig. Der Nutzer ist verpflichtet, einen deutlichen Copyright-Hinweis auf das Landesvermessungsamt NRW als Dateneigentümer bei Visualisierungen jeder Art anzubringen.</Abstract>\r\n \r\n<!-- Top-level web address of service or service provider. See also OnlineResource\r\n elements under <DCPType>. -->\r\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"\r\n xlink:href="http://www.gis.nrw.de:80/wms/DGM50?"\r\n xlink:type="simple" />\r\n \r\n <!-- Contact information -->\r\n <ContactInformation>\r\n <ContactPersonPrimary>\r\n <ContactPerson>Karin Landsberg</ContactPerson> \r\n <ContactOrganization>Landesvermessungsamt NRW</ContactOrganization> \r\n </ContactPersonPrimary>\r\n <ContactPosition>Geodatenvertrieb</ContactPosition> \r\n <ContactAddress>\r\n <AddressType /> \r\n <Address>Muffendorfer Str. 19-21</Address> \r\n <City>Bonn</City> \r\n <StateOrProvince>NRW</StateOrProvince> \r\n <PostCode>53177</PostCode> \r\n <Country>Germany</Country> \r\n </ContactAddress>\r\n <ContactVoiceTelephone>49 (228) 846 9320</ContactVoiceTelephone> \r\n <ContactFacsimileTelephone>49 (228) 846 9002</ContactFacsimileTelephone> \r\n <ContactElectronicMailAddress>landsberg at lverma.nrw.de</ContactElectronicMailAddress> \r\n </ContactInformation>\r\n <Fees>none</Fees>\r\n <AccessConstraints>none</AccessConstraints>\r\n</Service>\r\n\r\n <Capability> \r\n\r\n <Request> \r\n <GetCapabilities> \r\n <Format>application/vnd.ogc.wms_xml</Format> \r\n <DCPType> \r\n <HTTP> \r\n <Get> \r\n <OnlineResource xlink:href="http://www.gis.nrw.de:80/wms/DGM50" xlink:type="simple" xmlns:xlink="http://www.w3.org/1999/xlink"/> \r\n </Get> \r\n </HTTP> \r\n </DCPType> \r\n <DCPType> \r\n <HTTP> \r\n <Post> \r\n <OnlineResource xlink:href="http://www.gis.nrw.de:80/wms/DGM50" xlink:type="simple" xmlns:xlink="http://www.w3.org/1999/xlink"/> \r\n </Post> \r\n </HTTP> \r\n </DCPType> \r\n \r\n </GetCapabilities> \r\n <GetMap> \r\n <Format>image/jpeg</Format>\r\n <Format>image/png</Format>\r\n <DCPType> \r\n <HTTP> \r\n <Get> \r\n <OnlineResource xlink:href="http://www.gis.nrw.de:80/wms/DGM50" xlink:type="simple" xmlns:xlink="http://www.w3.org/1999/xlink"/> \r\n </Get> \r\n </HTTP> \r\n </DCPType> \r\n </GetMap> \r\n <GetFeatureInfo> \r\n <Format>application/vnd.ogc.gml</Format> \r\n <Format>text/html</Format>\r\n <DCPType> \r\n <HTTP> \r\n <Get> \r\n <OnlineResource xlink:href="http://www.gis.nrw.de:80/wms/DGM50" xlink:type="simple" xmlns:xlink="http://www.w3.org/1999/xlink"/> \r\n </Get> \r\n </HTTP> \r\n </DCPType> \r\n </GetFeatureInfo> \r\n </Request> \r\n\r\n <Exception> \r\n <Format>application/vnd.ogc.se_xml</Format> \r\n </Exception> \r\n\r\n <Layer queryable="0" opaque="0" noSubsets="0">\r\n <Title>Gelaendemodell</Title> \r\n \r\n <SRS>EPSG:31492</SRS>\r\n <LatLonBoundingBox maxx="8.6519" maxy="52.5054" minx="5.8682" miny="50.3189" />\r\n \r\n <BoundingBox SRS="EPSG:31492" minx="2476553.0" miny="5540279.0" maxx="2779499.0" maxy="5856970.0"></BoundingBox> \r\n\r\n <Layer queryable="0" noSubsets="0">\r\n <Name>DGM50</Name>\r\n <Title>DGM50</Title>\r\n <ScaleHint min="13.009" max="2602"></ScaleHint>\r\n <SRS>EPSG:31492</SRS>\r\n </Layer>\r\n\r\n\r\n </Layer>\r\n \r\n </Capability> \r\n</WMT_MS_Capabilities>\r\n\r\n');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (869, '1.1.0', 'LINFOS NRW', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS', 'http://www.gis2.nrw.de/wmsconnector/wms/linfos?', 'http://www.gis2.nrw.de/wmsconnector/wms/linfos?', 'http://www.gis2.nrw.de/wmsconnector/linfos?', '', NULL, '<?xml version="1.0" encoding="UTF-8"?>\n<!DOCTYPE WMT_MS_Capabilities\n SYSTEM "http://www.gis2.nrw.de/wmsconnector/schema/wms/1.1.0/capabilities_1_1_0.dtd">\n<WMT_MS_Capabilities updateSequence="0" version="1.1.0">\n <Service>\n <Name>OGC:WMS</Name>\n <Title>LINFOS NRW</Title>\n <Abstract>This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS</Abstract>\n <KeywordList>\n <Keyword>WMS</Keyword>\n <Keyword>Web Mapping</Keyword>\n <Keyword>GIS</Keyword>\n <Keyword>GDI NRW</Keyword>\n </KeywordList>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/wmsconnector/wms/linfos?" xlink:type="simple"/>\n <ContactInformation>\n <ContactPersonPrimary>\n <ContactPerson>Dr. Dirk Hinterlang</ContactPerson>\n \n <ContactOrganization>LOEBF NRW</ContactOrganization>\n\n </ContactPersonPrimary>\n <ContactPosition/>\n <ContactAddress>\n <AddressType/>\n <Address>Castroper Str. 312-314</Address>\n <City>Recklinghausen</City>\n <StateOrProvince>NRW</StateOrProvince>\n <PostCode>45665</PostCode>\n <Country>Germany</Country>\n </ContactAddress>\n <ContactVoiceTelephone>49 (2361) 305 202</ContactVoiceTelephone>\n <ContactFacsimileTelephone>49 (2361) 305 431</ContactFacsimileTelephone>\n <ContactElectronicMailAddress>dirk.hinterlang at loebf.nrw.de</ContactElectronicMailAddress>\n </ContactInformation>\n <Fees>siehe http://www.geocatalog.de</Fees>\n <AccessConstraints>siehe http://www.geocatalog.de</AccessConstraints>\n </Service>\n <Capability>\n <Request>\n <GetCapabilities>\n <Format>application/vnd.ogc.wms_xml</Format>\n <DCPType>\n <HTTP>\n <Get>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/wmsconnector/wms/linfos?" xlink:type="simple"/>\n </Get>\n </HTTP>\n </DCPType>\n <DCPType>\n <HTTP>\n <Post>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/wmsconnector/wms/linfos?" xlink:type="simple"/>\n </Post>\n </HTTP>\n </DCPType>\n </GetCapabilities>\n <GetMap>\n <Format>image/jpeg</Format>\n <Format>image/png</Format>\n <Format>image/gif</Format>\n <DCPType>\n <HTTP>\n <Get>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/wmsconnector/wms/linfos?" xlink:type="simple"/>\n </Get>\n </HTTP>\n </DCPType>\n </GetMap>\n <GetFeatureInfo>\n <Format>text/html</Format>\n <Format>text/xml</Format>\n <Format>text/plain</Format>\n <Format>application/vnd.esri.xml</Format>\n <DCPType>\n <HTTP>\n <Get>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/wmsconnector/linfos?" xlink:type="simple"/>\n </Get>\n </HTTP>\n </DCPType>\n </GetFeatureInfo>\n </Request>\n <Exception>\n <Format>application/vnd.ogc.se_xml</Format>\n </Exception>\n <VendorSpecificCapabilities/>\n <UserDefinedSymbolization RemoteWFS="0" SupportSLD="1" UserLayer="1" UserStyle="1"/>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Title>linfos</Title>\n <SRS>EPSG:4326 EPSG:25832 EPSG:25833 EPSG:31466 EPSG:31467</SRS>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>51</Name>\n <Title>Vegetationstypen</Title>\n <Style>\n <Name/> \n <Title>Vegetationstypen</Title>\n <LegendURL height="29" width="57">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/linfos/Vegtyp.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="74.942" min="0"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>49</Name>\n <Title>Vegetationsaufnahmen</Title>\n <Style>\n <Name/> \n <Title>Vegetationsaufnahmen</Title>\n <LegendURL height="29" width="57">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/linfos/Vegaufnahme_trs.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="74.942" min="0"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>45</Name>\n <Title>Naturraeumliche Haupteinheiten</Title>\n <Style>\n <Name/> \n <Title>Naturräumliche Haupteinheiten</Title>\n <LegendURL height="36" width="63">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/linfos/Naturraum.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="1122.716" min="0"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>43</Name>\n <Title>Landschaftsschutzgebiete</Title>\n <Style>\n <Name/> \n <Title>Landschaftsschutzgebiete</Title>\n <LegendURL height="29" width="57">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/linfos/LSSG.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="74.942" min="0"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>42</Name>\n <Title>Stand der Landschaftsplanung</Title>\n <Style>\n <Name/> \n <Title>Stand der Landschaftsplanung</Title>\n <LegendURL height="29" width="57">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/linfos/LSPlan.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="74.942" min="0"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>32</Name>\n <Title>FFH-Gebiete</Title>\n <Style>\n <Name/> \n <Title>FFH-Gebiete</Title>\n <LegendURL height="29" width="57">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/linfos/FFH.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="74.942" min="0"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>31</Name>\n <Title>Vogelschutzgebiete</Title>\n <Style>\n <Name/> \n <Title>Vogelschutzgebiete</Title>\n <LegendURL height="29" width="57">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/linfos/VSG.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="74.942" min="0"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>28</Name>\n <Title>Biotoptypen</Title>\n <Style>\n <Name/> \n <Title>Biotoptypen</Title>\n <LegendURL height="29" width="57">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/linfos/Biotoptyp.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="74.942" min="0"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>3</Name>\n <Title>Biotopkataster</Title>\n <Style>\n <Name/> \n <Title>Biotopkataster</Title>\n <LegendURL height="29" width="57">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/linfos/Biotopkataster.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="74.942" min="0"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>1</Name>\n <Title>Naturschutzgebiete</Title>\n <Style>\n <Name/> \n <Title>Naturschutzgebiete</Title>\n <LegendURL height="29" width="57">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/linfos/NSG.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="74.942" min="0"/>\n </Layer>\n </Layer>\n </Capability>\n</WMT_MS_Capabilities>');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (870, '1.1.0', 'Neigungsklassen zur Gelaendebefahrbarkeit', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS', 'http://www.gis2.nrw.de/wmsconnector/wms/hangneigung?', 'http://www.gis2.nrw.de/wmsconnector/wms/hangneigung?', 'http://www.gis2.nrw.de/wmsconnector/wms/hangneigung?', '', NULL, '<?xml version="1.0" encoding="UTF-8"?>\n<!DOCTYPE WMT_MS_Capabilities\n SYSTEM "http://www.gis2.nrw.de/wmsconnector/schema/wms/1.1.0/capabilities_1_1_0.dtd">\n<WMT_MS_Capabilities updateSequence="0" version="1.1.0">\n <Service>\n <Name>OGC:WMS</Name>\n <Title>Neigungsklassen zur Gelaendebefahrbarkeit</Title>\n <Abstract>This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS</Abstract>\n <KeywordList>\n <Keyword>WMS</Keyword>\n <Keyword>Web Mapping</Keyword>\n <Keyword>GIS</Keyword>\n <Keyword>GDI NRW</Keyword>\n </KeywordList>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/wmsconnector/wms/hangneigung?" xlink:type="simple"/>\n <ContactInformation>\n <ContactPersonPrimary>\n <ContactPerson>Frank Franken</ContactPerson>\n <ContactOrganization>LOEBF NRW</ContactOrganization>\n\n </ContactPersonPrimary>\n <ContactPosition/>\n <ContactAddress>\n <AddressType/>\n <Address>Castroper Str. 312-314</Address>\n <City>Recklinghausen</City>\n <StateOrProvince>NRW</StateOrProvince>\n <PostCode>45665</PostCode>\n <Country>Germany</Country>\n </ContactAddress>\n <ContactVoiceTelephone>49 (2361) 305 250</ContactVoiceTelephone>\n <ContactFacsimileTelephone>49 (2361) 305 370</ContactFacsimileTelephone>\n <ContactElectronicMailAddress>frank.franken at loebf.nrw.de</ContactElectronicMailAddress>\n </ContactInformation>\n <Fees>siehe http://www.geocatalog.de</Fees>\n <AccessConstraints>siehe http://www.geocatalog.de</AccessConstraints>\n </Service>\n <Capability>\n <Request>\n <GetCapabilities>\n <Format>application/vnd.ogc.wms_xml</Format>\n <DCPType>\n <HTTP>\n <Get>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/wmsconnector/wms/hangneigung?" xlink:type="simple"/>\n </Get>\n </HTTP>\n </DCPType>\n <DCPType>\n <HTTP>\n <Post>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/wmsconnector/wms/hangneigung?" xlink:type="simple"/>\n </Post>\n </HTTP>\n </DCPType>\n </GetCapabilities>\n <GetMap>\n <Format>image/jpeg</Format>\n <Format>image/png</Format>\n <Format>image/gif</Format>\n <DCPType>\n <HTTP>\n <Get>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/wmsconnector/wms/hangneigung?" xlink:type="simple"/>\n </Get>\n </HTTP>\n </DCPType>\n </GetMap>\n <GetFeatureInfo>\n <Format>text/html</Format>\n <Format>text/xml</Format>\n <Format>text/plain</Format>\n <Format>application/vnd.esri.xml</Format>\n <DCPType>\n <HTTP>\n <Get>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/wmsconnector/wms/hangneigung?" xlink:type="simple"/>\n </Get>\n </HTTP>\n </DCPType>\n </GetFeatureInfo>\n </Request>\n <Exception>\n <Format>application/vnd.ogc.se_xml</Format>\n </Exception>\n <VendorSpecificCapabilities/>\n <UserDefinedSymbolization RemoteWFS="0" SupportSLD="1" UserLayer="1" UserStyle="1"/>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Title>hangneigung</Title>\n <SRS>EPSG:4326 EPSG:25832 EPSG:25833 EPSG:31466 EPSG:31467</SRS>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>hangneigung</Name>\n <Title>Hangneigung</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="109" width="358">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/hangneigung/hangneigung_trs.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="187.06079078824797" min="0.1"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>Fliessgewaesser</Name>\n <Title>Fliessgewaesser</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="28" width="199">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/hangneigung/fliessgewaesser_trs.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="187.06079078824797" min="0.1"/>\n </Layer>\n </Layer>\n </Capability>\n</WMT_MS_Capabilities>');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (871, '1.1.0', 'Geobasisdaten Muenster', 'Geobasisdaten Muenster', 'http://geo.stadt-muenster.de/cgi-bin/geobasis?', 'http://geo.stadt-muenster.de/cgi-bin/geobasis?', 'http://geo.stadt-muenster.de/cgi-bin/geobasis?', 'http://geo.stadt-muenster.de/cgi-bin/geobasis?', NULL, '<?xml version="1.0" encoding="ISO-8859-1" standalone="no" ?>\r\n<!DOCTYPE WMT_MS_Capabilities SYSTEM "http://schemas.opengeospatial.net/wms/1.1.0/capabilities_1_1_0.dtd"\r\n [\r\n <!ELEMENT VendorSpecificCapabilities EMPTY>\r\n ]> <!-- end of DOCTYPE declaration -->\r\n\r\n<WMT_MS_Capabilities version="1.1.0">\r\n\r\n<!-- MapServer version 4.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE -->\r\n\r\n<Service>\r\n <Name>OGC:WMS</Name>\r\n <Title>Geobasisdaten Muenster</Title>\r\n <Abstract>Geobasisdaten Muenster</Abstract>\r\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://geo.stadt-muenster.de/cgi-bin/geobasis?"/>\r\n <ContactInformation>\r\n <ContactPersonPrimary>\r\n <ContactPerson>Norbert Dephoff</ContactPerson>\r\n <ContactOrganization>Vermessungs- und Katasteramt</ContactOrganization>\r\n </ContactPersonPrimary>\r\n <ContactAddress>\r\n <AddressType></AddressType>\r\n <Address>Albersloher Weg 33</Address>\r\n <City>Münster</City>\r\n <StateOrProvince></StateOrProvince>\r\n <PostCode>48155</PostCode>\r\n <Country>Germany</Country>\r\n </ContactAddress>\r\n <ContactElectronicMailAddress>dephoffn at stadt-muenster.de</ContactElectronicMailAddress>\r\n </ContactInformation>\r\n <Fees>none</Fees>\r\n <AccessConstraints>none</AccessConstraints>\r\n</Service>\r\n\r\n<Capability>\r\n <Request>\r\n <GetCapabilities>\r\n <Format>application/vnd.ogc.wms_xml</Format>\r\n <DCPType>\r\n <HTTP>\r\n <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://geo.stadt-muenster.de/cgi-bin/geobasis?"/></Get>\r\n <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://geo.stadt-muenster.de/cgi-bin/geobasis?"/></Post>\r\n </HTTP>\r\n </DCPType>\r\n </GetCapabilities>\r\n <GetMap>\r\n <Format>image/gif</Format>\r\n <Format>image/png</Format>\r\n <Format>image/jpeg</Format>\r\n <Format>image/wbmp</Format>\r\n <Format>image/tiff</Format>\r\n <DCPType>\r\n <HTTP>\r\n <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://geo.stadt-muenster.de/cgi-bin/geobasis?"/></Get>\r\n <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://geo.stadt-muenster.de/cgi-bin/geobasis?"/></Post>\r\n </HTTP>\r\n </DCPType>\r\n </GetMap>\r\n <GetFeatureInfo>\r\n <Format>text/plain</Format>\r\n <Format>application/vnd.ogc.gml</Format>\r\n <DCPType>\r\n <HTTP>\r\n <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://geo.stadt-muenster.de/cgi-bin/geobasis?"/></Get>\r\n <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://geo.stadt-muenster.de/cgi-bin/geobasis?"/></Post>\r\n </HTTP>\r\n </DCPType>\r\n </GetFeatureInfo>\r\n <DescribeLayer>\r\n <Format>text/xml</Format>\r\n <DCPType>\r\n <HTTP>\r\n <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://geo.stadt-muenster.de/cgi-bin/geobasis?"/></Get>\r\n <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://geo.stadt-muenster.de/cgi-bin/geobasis?"/></Post>\r\n </HTTP>\r\n </DCPType>\r\n </DescribeLayer>\r\n <GetLegendGraphic>\r\n <Format>image/gif</Format>\r\n <Format>image/png</Format>\r\n <Format>image/jpeg</Format>\r\n <Format>image/wbmp</Format>\r\n <DCPType>\r\n <HTTP>\r\n <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://geo.stadt-muenster.de/cgi-bin/geobasis?"/></Get>\r\n <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://geo.stadt-muenster.de/cgi-bin/geobasis?"/></Post>\r\n </HTTP>\r\n </DCPType>\r\n </GetLegendGraphic>\r\n </Request>\r\n <Exception>\r\n <Format>application/vnd.ogc.se_xml</Format>\r\n <Format>application/vnd.ogc.se_inimage</Format>\r\n <Format>application/vnd.ogc.se_blank</Format>\r\n </Exception>\r\n <VendorSpecificCapabilities />\r\n <UserDefinedSymbolization SupportSLD="1" UserLayer="0" UserStyle="1" RemoteWFS="0"/>\r\n <Layer>\r\n <Name>MUENSTER</Name>\r\n <Title>Geobasisdaten Muenster</Title>\r\n <SRS>EPSG:4326 EPSG:25832 EPSG:31466 EPSG:31467</SRS>\r\n <LatLonBoundingBox minx="7.39549" miny="51.8027" maxx="7.83995" maxy="52.0774" />\r\n <BoundingBox SRS="EPSG:31467"\r\n minx="3.39e+006" miny="5.742e+006" maxx="3.42e+006" maxy="5.772e+006" />\r\n <Layer queryable="0" opaque="0" cascaded="1">\r\n <Name>splan</Name>\r\n <Title>Stadtplan</Title>\r\n <Abstract>Stadtplan</Abstract>\r\n <SRS>EPSG:31467</SRS>\r\n <ScaleHint min="1.19737" max="997.806" />\r\n </Layer>\r\n <Layer queryable="0" opaque="0" cascaded="1">\r\n <Name>luftb</Name>\r\n <Title>Luftbilder</Title>\r\n <Abstract>Luftbilder</Abstract>\r\n <SRS>EPSG:31467</SRS>\r\n <ScaleHint min="0.187089" max="1.94572" />\r\n </Layer>\r\n <Layer queryable="0" opaque="0" cascaded="1">\r\n <Name>dgk5dbr</Name>\r\n <Title>DGK5</Title>\r\n <Abstract>DGK5</Abstract>\r\n <SRS>EPSG:31467</SRS>\r\n <ScaleHint min="0.000498903" max="1.94572" />\r\n </Layer>\r\n <Layer>\r\n <Name>Stadtgrundkarte</Name>\r\n <Title>Stadtgrundkarte</Title>\r\n <Abstract>Stadtgrundkarte</Abstract>\r\n <Layer queryable="0" opaque="0" cascaded="0">\r\n <Name>flst</Name>\r\n <Title>Flurstuecke</Title>\r\n <SRS>EPSG:31467</SRS>\r\n <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />\r\n <BoundingBox SRS="EPSG:31467"\r\n minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />\r\n <ScaleHint min="0.000498903" max="1.24726" />\r\n </Layer>\r\n <Layer queryable="0" opaque="0" cascaded="0">\r\n <Name>gebaeude</Name>\r\n <Title>Gebaeude</Title>\r\n <SRS>EPSG:31467</SRS>\r\n <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />\r\n <BoundingBox SRS="EPSG:31467"\r\n minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />\r\n <ScaleHint min="0.000498903" max="1.24726" />\r\n </Layer>\r\n <Layer queryable="0" opaque="0" cascaded="0">\r\n <Name>linien</Name>\r\n <Title>Topographie</Title>\r\n <SRS>EPSG:31467</SRS>\r\n <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />\r\n <BoundingBox SRS="EPSG:31467"\r\n minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />\r\n <ScaleHint min="0.000498903" max="1.24726" />\r\n </Layer>\r\n <Layer queryable="0" opaque="0" cascaded="0">\r\n <Name>texte</Name>\r\n <Title>Beschriftung</Title>\r\n <SRS>EPSG:31467</SRS>\r\n <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />\r\n <BoundingBox SRS="EPSG:31467"\r\n minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />\r\n <ScaleHint min="0.000498903" max="1.24726" />\r\n </Layer>\r\n </Layer>\r\n </Layer>\r\n</Capability>\r\n</WMT_MS_Capabilities>\r\n');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (872, '1.1.0', 'WMS Map Server', 'WMS Map Server', 'http://fluggs.wupperverband.de:80/servlet/com.esri.wms.Esrimap?', 'http://fluggs.wupperverband.de:80/servlet/com.esri.wms.Esrimap?', 'http://fluggs.wupperverband.de:80/servlet/com.esri.wms.Esrimap?', '', NULL, '<?xml version="1.0" encoding="UTF-8" standalone="yes" ?>\r\n<!DOCTYPE WMT_MS_Capabilities SYSTEM "http://www.digitalearth.gov/wmt/xml/capabilities_1_1_0.dtd" \n>\r\n\n<!-- This document is compliant to WMT_MS_Capabilities DTD version 1.1 -->\r\n<!-- Generated on Fri Nov 04 14:22:58 CET 2005 -->\n\r\n<WMT_MS_Capabilities version="1.1.0" updateSequence="0">\r\n<Service>\r\n<Name>OGC:WMS</Name>\r\n<Title>WMS Map Server</Title>\r\n<Abstract>WMS Map Server</Abstract>\r\n<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://fluggs.wupperverband.de:80/servlet/com.esri.wms.Esrimap?"/>\r\n<Fees></Fees>\r\n<AccessConstraints></AccessConstraints>\r\n</Service>\r\n<Capability>\r\n<Request>\r\n<GetCapabilities>\r\n<Format>application/vnd.ogc.wms_xml</Format>\r\n<DCPType>\r\n<HTTP>\r\n<Get>\r\n<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://fluggs.wupperverband.de:80/servlet/com.esri.wms.Esrimap?"/>\r\n</Get>\r\n</HTTP>\r\n</DCPType>\r\n</GetCapabilities>\r\n<GetMap>\r\n<Format>image/jpeg</Format>\r\n<Format>image/gif</Format>\r\n<Format>image/png</Format>\r\n<DCPType>\r\n<HTTP>\r\n<Get>\r\n<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://fluggs.wupperverband.de:80/servlet/com.esri.wms.Esrimap?"/>\r\n</Get>\r\n</HTTP>\r\n</DCPType>\r\n</GetMap>\r\n<GetFeatureInfo>\r\n<Format>application/vnd.ogc.wms_xml</Format>\r\n<Format>text/plain</Format>\r\n<Format>text/html</Format>\r\n<DCPType>\r\n<HTTP>\r\n<Get>\r\n<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://fluggs.wupperverband.de:80/servlet/com.esri.wms.Esrimap?"/>\r\n</Get>\r\n</HTTP>\r\n</DCPType>\r\n</GetFeatureInfo>\r\n</Request>\r\n<Exception>\r\n<Format>application/vnd.ogc.se_xml</Format>\r\n<Format>application/vnd.ogc.se_inimage</Format>\r\n<Format>application/vnd.ogc.se_blank</Format>\r\n</Exception>\r\n<Layer>\r\n<Title>WV_WMS</Title>\r\n<SRS>EPSG:4326</SRS>\r\n<Layer>\r\n<Name>rheinplus</Name>\r\n<Title>rheinplus</Title>\r\n<SRS>EPSG:4326</SRS>\r\n<LatLonBoundingBox minx="2546442.5" miny="5629738.5" maxx="2574239.0" maxy="5690679.0"/>\r\n</Layer>\r\n<Layer>\r\n<Name>uesgobwup</Name>\r\n<Title>uesgobwup</Title>\r\n<SRS>EPSG:4326</SRS>\r\n<LatLonBoundingBox minx="2593889.2" miny="5662005.5" maxx="2609059.0" maxy="5669772.0"/>\r\n</Layer>\r\n<Layer>\r\n<Name>uesgmorsbach</Name>\r\n<Title>uesgmorsbach</Title>\r\n<SRS>EPSG:4326</SRS>\r\n<LatLonBoundingBox minx="2579495.5" miny="5670734.5" maxx="2586469.8" maxy="5679051.5"/>\r\n</Layer>\r\n<Layer>\r\n<Name>klaerwerkseinzugsgebiete</Name>\r\n<Title>klaerwerkseinzugsgebiete</Title>\r\n<SRS>EPSG:4326</SRS>\r\n<LatLonBoundingBox minx="2563368.2" miny="5652735.5" maxx="2612351.5" maxy="5687238.5"/>\r\n</Layer>\r\n<Layer>\r\n<Name>entwaesserungssystem</Name>\r\n<Title>entwaesserungssystem</Title>\r\n<SRS>EPSG:4326</SRS>\r\n<LatLonBoundingBox minx="2563368.2" miny="5652735.5" maxx="2612351.5" maxy="5687238.5"/>\r\n</Layer>\r\n<Layer>\r\n<Name>gezgross</Name>\r\n<Title>gezgross</Title>\r\n<SRS>EPSG:4326</SRS>\r\n<LatLonBoundingBox minx="2566194.5" miny="5650761.0" maxx="2612288.8" maxy="5687441.5"/>\r\n</Layer>\r\n<Layer>\r\n<Name>gezklein</Name>\r\n<Title>gezklein</Title>\r\n<SRS>EPSG:4326</SRS>\r\n<LatLonBoundingBox minx="2566194.5" miny="5650761.0" maxx="2612288.8" maxy="5687441.5"/>\r\n</Layer>\r\n<Layer>\r\n<Name>ueberleitungsgebiete</Name>\r\n<Title>ueberleitungsgebiete</Title>\r\n<SRS>EPSG:4326</SRS>\r\n<LatLonBoundingBox minx="2563139.2" miny="5653338.0" maxx="2598613.0" maxy="5687438.5"/>\r\n</Layer>\r\n<Layer>\r\n<Name>verbandsgebiet</Name>\r\n<Title>verbandsgebiet</Title>\r\n<SRS>EPSG:4326</SRS>\r\n<LatLonBoundingBox minx="2566194.0" miny="5650736.5" maxx="2612255.8" maxy="5687418.5"/>\r\n</Layer>\r\n<Layer>\r\n<Name>gsg5</Name>\r\n<Title>gsg5</Title>\r\n<SRS>EPSG:4326</SRS>\r\n<LatLonBoundingBox minx="2566094.0" miny="5650929.5" maxx="2611978.2" maxy="5687202.5"/>\r\n</Layer>\r\n<Layer>\r\n<Name>gsg3</Name>\r\n<Title>gsg3</Title>\r\n<SRS>EPSG:4326</SRS>\r\n<LatLonBoundingBox minx="2566094.0" miny="5650892.0" maxx="2612015.5" maxy="5687211.0"/>\r\n</Layer>\r\n<Layer>\r\n<Name>gsg1</Name>\r\n<Title>gsg1</Title>\r\n<SRS>EPSG:4326</SRS>\r\n<LatLonBoundingBox minx="2566094.0" miny="5650866.0" maxx="2612040.5" maxy="5687229.5"/>\r\n</Layer>\r\n<Layer>\r\n<Name>gewaesser</Name>\r\n<Title>gewaesser</Title>\r\n<SRS>EPSG:4326</SRS>\r\n<LatLonBoundingBox minx="2565684.0" miny="5650966.5" maxx="2611954.8" maxy="5687197.0"/>\r\n</Layer>\r\n<Layer>\r\n<Name>verrohrungen</Name>\r\n<Title>verrohrungen</Title>\r\n<SRS>EPSG:4326</SRS>\r\n<LatLonBoundingBox minx="2568289.8" miny="5650979.5" maxx="2611939.5" maxy="5687154.0"/>\r\n</Layer>\r\n<Layer>\r\n<Name>verlaufaenderungen</Name>\r\n<Title>verlaufaenderungen</Title>\r\n<SRS>EPSG:4326</SRS>\r\n<LatLonBoundingBox minx="2567540.2" miny="5651123.5" maxx="2610584.0" maxy="5686884.5"/>\r\n</Layer>\r\n<Layer>\r\n<Name>gewaesserbeschriftung</Name>\r\n<Title>gewaesserbeschriftung</Title>\r\n<SRS>EPSG:4326</SRS>\r\n<LatLonBoundingBox minx="2565684.0" miny="5650966.5" maxx="2611954.8" maxy="5687197.0"/>\r\n</Layer>\r\n<Layer>\r\n<Name>talsperren</Name>\r\n<Title>talsperren</Title>\r\n<SRS>EPSG:4326</SRS>\r\n<LatLonBoundingBox minx="2574368.5" miny="5657951.5" maxx="2609796.2" maxy="5680451.5"/>\r\n</Layer>\r\n<Layer>\r\n<Name>sammler</Name>\r\n<Title>sammler</Title>\r\n<SRS>EPSG:4326</SRS>\r\n<LatLonBoundingBox minx="2568024.0" miny="5657404.5" maxx="2610590.5" maxy="5676478.5"/>\r\n</Layer>\r\n<Layer>\r\n<Name>stationierung</Name>\r\n<Title>stationierung</Title>\r\n<SRS>EPSG:4326</SRS>\r\n<LatLonBoundingBox minx="2566160.2" miny="5650970.5" maxx="2611941.8" maxy="5687151.0"/>\r\n</Layer>\r\n<Layer>\r\n<Name>fotos_am_gewaesser</Name>\r\n<Title>fotos_am_gewaesser</Title>\r\n<SRS>EPSG:4326</SRS>\r\n<LatLonBoundingBox minx="2566094.0" miny="5650970.5" maxx="2611941.0" maxy="5687106.5"/>\r\n</Layer>\r\n<Layer>\r\n<Name>limnologie</Name>\r\n<Title>limnologie</Title>\r\n<SRS>EPSG:4326</SRS>\r\n<LatLonBoundingBox minx="2568246.5" miny="5655120.5" maxx="2610520.0" maxy="5682874.5"/>\r\n</Layer>\r\n<Layer>\r\n<Name>niederschlagsstationen</Name>\r\n<Title>niederschlagsstationen</Title>\r\n<SRS>EPSG:4326</SRS>\r\n<LatLonBoundingBox minx="2568200.5" miny="5655310.0" maxx="2609614.8" maxy="5684705.0"/>\r\n</Layer>\r\n<Layer>\r\n<Name>pegel</Name>\r\n<Title>pegel</Title>\r\n<SRS>EPSG:4326</SRS>\r\n<LatLonBoundingBox minx="2569725.2" miny="5652906.5" maxx="2610202.8" maxy="5683943.5"/>\r\n</Layer>\r\n<Layer>\r\n<Name>wehre</Name>\r\n<Title>wehre</Title>\r\n<SRS>EPSG:4326</SRS>\r\n<LatLonBoundingBox minx="2567619.8" miny="5655330.5" maxx="2610201.8" maxy="5682797.0"/>\r\n</Layer>\r\n<Layer>\r\n<Name>fischaufstiege</Name>\r\n<Title>fischaufstiege</Title>\r\n<SRS>EPSG:4326</SRS>\r\n<LatLonBoundingBox minx="2567619.8" miny="5655330.5" maxx="2607229.8" maxy="5682797.0"/>\r\n</Layer>\r\n<Layer>\r\n<Name>hrb</Name>\r\n<Title>hrb</Title>\r\n<SRS>EPSG:4326</SRS>\r\n<LatLonBoundingBox minx="2574521.2" miny="5654207.5" maxx="2598042.2" maxy="5685821.0"/>\r\n</Layer>\r\n<Layer>\r\n<Name>regenbeckenwv</Name>\r\n<Title>regenbeckenwv</Title>\r\n<SRS>EPSG:4326</SRS>\r\n<LatLonBoundingBox minx="2571850.8" miny="5655250.0" maxx="2610579.0" maxy="5684825.0"/>\r\n</Layer>\r\n<Layer>\r\n<Name>klaerwerke</Name>\r\n<Title>klaerwerke</Title>\r\n<SRS>EPSG:4326</SRS>\r\n<LatLonBoundingBox minx="2568205.8" miny="5655293.0" maxx="2606643.5" maxy="5684697.0"/>\r\n</Layer>\r\n</Layer>\r\n</Capability>\r\n</WMT_MS_Capabilities>\r\n');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (881, '1.1.0', 'Gebietsgliederung', '', 'http://212.8.208.50/umn/wms_gebgli.asp?', 'http://212.8.208.50/umn/wms_gebgli.asp?', 'http://212.8.208.50/umn/wms_gebgli.asp?', 'http://212.8.208.50/umn/wms_gebgli.asp?', NULL, '<?xml version="1.0" encoding="ISO-8859-1" standalone="no" ?>\r\n<!DOCTYPE WMT_MS_Capabilities SYSTEM "http://schemas.opengeospatial.net/wms/1.1.0/capabilities_1_1_0.dtd"\r\n [\r\n <!ELEMENT VendorSpecificCapabilities EMPTY>\r\n ]> <!-- end of DOCTYPE declaration -->\r\n\r\n<WMT_MS_Capabilities version="1.1.0">\r\n\r\n<!-- MapServer version 4.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG -->\r\n\r\n<Service>\r\n <Name>OGC:WMS</Name>\r\n <Title>Gebietsgliederung</Title>\r\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?"/>\r\n</Service>\r\n\r\n<Capability>\r\n <Request>\r\n <GetCapabilities>\r\n <Format>application/vnd.ogc.wms_xml</Format>\r\n <DCPType>\r\n <HTTP>\r\n <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?"/></Get>\r\n <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?"/></Post>\r\n </HTTP>\r\n </DCPType>\r\n </GetCapabilities>\r\n <GetMap>\r\n <Format>image/gif</Format>\r\n <Format>image/png</Format>\r\n <Format>image/jpeg</Format>\r\n <Format>image/tiff</Format>\r\n <DCPType>\r\n <HTTP>\r\n <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?"/></Get>\r\n <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?"/></Post>\r\n </HTTP>\r\n </DCPType>\r\n </GetMap>\r\n <GetFeatureInfo>\r\n <Format>text/plain</Format>\r\n <Format>text/html</Format>\r\n <Format>application/vnd.ogc.gml</Format>\r\n <DCPType>\r\n <HTTP>\r\n <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?"/></Get>\r\n <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?"/></Post>\r\n </HTTP>\r\n </DCPType>\r\n </GetFeatureInfo>\r\n <DescribeLayer>\r\n <Format>text/xml</Format>\r\n <DCPType>\r\n <HTTP>\r\n <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?"/></Get>\r\n <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?"/></Post>\r\n </HTTP>\r\n </DCPType>\r\n </DescribeLayer>\r\n <GetLegendGraphic>\r\n <Format>image/gif</Format>\r\n <Format>image/png</Format>\r\n <Format>image/jpeg</Format>\r\n <DCPType>\r\n <HTTP>\r\n <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?"/></Get>\r\n <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?"/></Post>\r\n </HTTP>\r\n </DCPType>\r\n </GetLegendGraphic>\r\n </Request>\r\n <Exception>\r\n <Format>application/vnd.ogc.se_xml</Format>\r\n <Format>application/vnd.ogc.se_inimage</Format>\r\n <Format>application/vnd.ogc.se_blank</Format>\r\n </Exception>\r\n <VendorSpecificCapabilities />\r\n <UserDefinedSymbolization SupportSLD="1" UserLayer="0" UserStyle="1" RemoteWFS="0"/>\r\n <Layer>\r\n <Name>Gebietsgliederung</Name>\r\n <Title>Gebietsgliederung</Title>\r\n <SRS>epsg:31467</SRS>\r\n <LatLonBoundingBox minx="8.37676" miny="51.9156" maxx="8.68781" maxy="52.1168" />\r\n <BoundingBox SRS="EPSG:31467"\r\n minx="3.45731e+006" miny="5.75355e+006" maxx="3.47852e+006" maxy="5.77579e+006" />\r\n <Layer>\r\n <Name>Stadtbezirke</Name>\r\n <Title>Stadtbezirke</Title>\r\n <Abstract>Stadtbezirke</Abstract>\r\n <Layer queryable="0" opaque="0" cascaded="0">\r\n <Name>stadtbezirke_pl</Name>\r\n <Title>stadtbezirke_pl</Title>\r\n <SRS>EPSG:31467</SRS>\r\n <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />\r\n <BoundingBox SRS="EPSG:31467"\r\n minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />\r\n <Style>\r\n <Name>default</Name>\r\n <Title>default</Title>\r\n <LegendURL width="18" height="12">\r\n <Format>image/png</Format>\r\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=stadtbezirke_pl&format=image/png"/>\r\n </LegendURL>\r\n </Style>\r\n <ScaleHint min="0" max="4989.03" />\r\n </Layer>\r\n <Layer queryable="0" opaque="0" cascaded="0">\r\n <Name>stadtbezirke_t</Name>\r\n <Title>stadtbezirke_t</Title>\r\n <SRS>EPSG:31467</SRS>\r\n <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />\r\n <BoundingBox SRS="EPSG:31467"\r\n minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />\r\n <Style>\r\n <Name>default</Name>\r\n <Title>default</Title>\r\n <LegendURL width="18" height="12">\r\n <Format>image/png</Format>\r\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=stadtbezirke_t&format=image/png"/>\r\n </LegendURL>\r\n </Style>\r\n <ScaleHint min="0" max="149.671" />\r\n </Layer>\r\n </Layer>\r\n <Layer>\r\n <Name>Statistische_Bezirke</Name>\r\n <Title>Statistische_Bezirke</Title>\r\n <Abstract>Statistische_Bezirke</Abstract>\r\n <Layer queryable="0" opaque="0" cascaded="0">\r\n <Name>statist_bez_pl</Name>\r\n <Title>statist_bez_pl</Title>\r\n <SRS>EPSG:31467</SRS>\r\n <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />\r\n <BoundingBox SRS="EPSG:31467"\r\n minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />\r\n <Style>\r\n <Name>default</Name>\r\n <Title>default</Title>\r\n <LegendURL width="18" height="12">\r\n <Format>image/png</Format>\r\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=statist_bez_pl&format=image/png"/>\r\n </LegendURL>\r\n </Style>\r\n <ScaleHint min="0" max="149.671" />\r\n </Layer>\r\n <Layer queryable="0" opaque="0" cascaded="0">\r\n <Name>statist_bez_t</Name>\r\n <Title>statist_bez_t</Title>\r\n <SRS>EPSG:31467</SRS>\r\n <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />\r\n <BoundingBox SRS="EPSG:31467"\r\n minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />\r\n <Style>\r\n <Name>default</Name>\r\n <Title>default</Title>\r\n <LegendURL width="18" height="12">\r\n <Format>image/png</Format>\r\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=statist_bez_t&format=image/png"/>\r\n </LegendURL>\r\n </Style>\r\n <ScaleHint min="0" max="149.671" />\r\n </Layer>\r\n </Layer>\r\n <Layer>\r\n <Name>Verkehrszellen</Name>\r\n <Title>Verkehrszellen</Title>\r\n <Abstract>Verkehrszellen</Abstract>\r\n <Layer queryable="0" opaque="0" cascaded="0">\r\n <Name>verkehrszellen_pl</Name>\r\n <Title>verkehrszellen_pl</Title>\r\n <SRS>EPSG:31467</SRS>\r\n <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />\r\n <BoundingBox SRS="EPSG:31467"\r\n minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />\r\n <Style>\r\n <Name>default</Name>\r\n <Title>default</Title>\r\n <LegendURL width="18" height="12">\r\n <Format>image/png</Format>\r\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=verkehrszellen_pl&format=image/png"/>\r\n </LegendURL>\r\n </Style>\r\n <ScaleHint min="0" max="149.671" />\r\n </Layer>\r\n <Layer queryable="0" opaque="0" cascaded="0">\r\n <Name>verkehrszellen_t</Name>\r\n <Title>verkehrszellen_t</Title>\r\n <SRS>EPSG:31467</SRS>\r\n <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />\r\n <BoundingBox SRS="EPSG:31467"\r\n minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />\r\n <Style>\r\n <Name>default</Name>\r\n <Title>default</Title>\r\n <LegendURL width="18" height="12">\r\n <Format>image/png</Format>\r\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=verkehrszellen_t&format=image/png"/>\r\n </LegendURL>\r\n </Style>\r\n <ScaleHint min="0" max="149.671" />\r\n </Layer>\r\n </Layer>\r\n <Layer>\r\n <Name>Baubloecke</Name>\r\n <Title>Baubloecke</Title>\r\n <Abstract>Baubloecke</Abstract>\r\n <Layer queryable="0" opaque="0" cascaded="0">\r\n <Name>baubloecke_pl</Name>\r\n <Title>baubloecke_pl</Title>\r\n <SRS>EPSG:31467</SRS>\r\n <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />\r\n <BoundingBox SRS="EPSG:31467"\r\n minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />\r\n <Style>\r\n <Name>default</Name>\r\n <Title>default</Title>\r\n <LegendURL width="18" height="12">\r\n <Format>image/png</Format>\r\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=baubloecke_pl&format=image/png"/>\r\n </LegendURL>\r\n </Style>\r\n <ScaleHint min="0" max="49.8903" />\r\n </Layer>\r\n <Layer queryable="0" opaque="0" cascaded="0">\r\n <Name>baubloecke_t</Name>\r\n <Title>baubloecke_t</Title>\r\n <SRS>EPSG:31467</SRS>\r\n <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />\r\n <BoundingBox SRS="EPSG:31467"\r\n minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />\r\n <Style>\r\n <Name>default</Name>\r\n <Title>default</Title>\r\n <LegendURL width="18" height="12">\r\n <Format>image/png</Format>\r\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=baubloecke_t&format=image/png"/>\r\n </LegendURL>\r\n </Style>\r\n <ScaleHint min="0" max="49.8903" />\r\n </Layer>\r\n </Layer>\r\n </Layer>\r\n</Capability>\r\n</WMT_MS_Capabilities>\r\n');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (882, '1.1.0', 'Wahlen', '', 'http://212.8.208.50/umn/wms_wahlen.asp?', 'http://212.8.208.50/umn/wms_wahlen.asp?', 'http://212.8.208.50/umn/wms_wahlen.asp?', 'http://212.8.208.50/umn/wms_wahlen.asp?', NULL, '<?xml version="1.0" encoding="ISO-8859-1" standalone="no" ?>\r\n<!DOCTYPE WMT_MS_Capabilities SYSTEM "http://schemas.opengeospatial.net/wms/1.1.0/capabilities_1_1_0.dtd"\r\n [\r\n <!ELEMENT VendorSpecificCapabilities EMPTY>\r\n ]> <!-- end of DOCTYPE declaration -->\r\n\r\n<WMT_MS_Capabilities version="1.1.0">\r\n\r\n<!-- MapServer version 4.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG -->\r\n\r\n<Service>\r\n <Name>OGC:WMS</Name>\r\n <Title>Wahlen</Title>\r\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?"/>\r\n</Service>\r\n\r\n<Capability>\r\n <Request>\r\n <GetCapabilities>\r\n <Format>application/vnd.ogc.wms_xml</Format>\r\n <DCPType>\r\n <HTTP>\r\n <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?"/></Get>\r\n <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?"/></Post>\r\n </HTTP>\r\n </DCPType>\r\n </GetCapabilities>\r\n <GetMap>\r\n <Format>image/gif</Format>\r\n <Format>image/png</Format>\r\n <Format>image/jpeg</Format>\r\n <Format>image/tiff</Format>\r\n <DCPType>\r\n <HTTP>\r\n <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?"/></Get>\r\n <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?"/></Post>\r\n </HTTP>\r\n </DCPType>\r\n </GetMap>\r\n <GetFeatureInfo>\r\n <Format>text/plain</Format>\r\n <Format>text/html</Format>\r\n <Format>application/vnd.ogc.gml</Format>\r\n <DCPType>\r\n <HTTP>\r\n <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?"/></Get>\r\n <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?"/></Post>\r\n </HTTP>\r\n </DCPType>\r\n </GetFeatureInfo>\r\n <DescribeLayer>\r\n <Format>text/xml</Format>\r\n <DCPType>\r\n <HTTP>\r\n <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?"/></Get>\r\n <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?"/></Post>\r\n </HTTP>\r\n </DCPType>\r\n </DescribeLayer>\r\n <GetLegendGraphic>\r\n <Format>image/gif</Format>\r\n <Format>image/png</Format>\r\n <Format>image/jpeg</Format>\r\n <DCPType>\r\n <HTTP>\r\n <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?"/></Get>\r\n <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?"/></Post>\r\n </HTTP>\r\n </DCPType>\r\n </GetLegendGraphic>\r\n </Request>\r\n <Exception>\r\n <Format>application/vnd.ogc.se_xml</Format>\r\n <Format>application/vnd.ogc.se_inimage</Format>\r\n <Format>application/vnd.ogc.se_blank</Format>\r\n </Exception>\r\n <VendorSpecificCapabilities />\r\n <UserDefinedSymbolization SupportSLD="1" UserLayer="0" UserStyle="1" RemoteWFS="0"/>\r\n <Layer>\r\n <Name>Wahlen</Name>\r\n <Title>Wahlen</Title>\r\n <SRS>epsg:31467</SRS>\r\n <LatLonBoundingBox minx="8.37676" miny="51.9156" maxx="8.68781" maxy="52.1168" />\r\n <BoundingBox SRS="EPSG:31467"\r\n minx="3.45731e+006" miny="5.75355e+006" maxx="3.47852e+006" maxy="5.77579e+006" />\r\n <Layer>\r\n <Name>HINTERGRUNDKARTE</Name>\r\n <Title>HINTERGRUNDKARTE</Title>\r\n <Abstract>HINTERGRUNDKARTE</Abstract>\r\n <Layer queryable="0" opaque="0" cascaded="0">\r\n <Name>stadtplan_grau_zoomst_1</Name>\r\n <Title>stadtplan_grau_zoomst_1</Title>\r\n <SRS>EPSG:31467</SRS>\r\n <ScaleHint min="67.3524" max="149.671" />\r\n </Layer>\r\n <Layer queryable="0" opaque="0" cascaded="0">\r\n <Name>stadtplan_zoom3_01</Name>\r\n <Title>02_stadtplan</Title>\r\n <SRS>EPSG:31467</SRS>\r\n <ScaleHint min="9.97856" max="67.3519" />\r\n </Layer>\r\n <Layer queryable="0" opaque="0" cascaded="0">\r\n <Name>stadtplan_zoom3_02</Name>\r\n <Title>03_stadtplan</Title>\r\n <SRS>EPSG:31467</SRS>\r\n <ScaleHint min="5.98733" max="9.97806" />\r\n </Layer>\r\n <Layer queryable="0" opaque="0" cascaded="0">\r\n <Name>stadtplan_zoom3_03</Name>\r\n <Title>04_stadtplan</Title>\r\n <SRS>EPSG:31467</SRS>\r\n <ScaleHint min="1.37248" max="5.98683" />\r\n </Layer>\r\n <Layer queryable="0" opaque="0" cascaded="0">\r\n <Name>dgk5_liste</Name>\r\n <Title>Deutsche Grundkarte</Title>\r\n <SRS>EPSG:31467</SRS>\r\n <ScaleHint min="0" max="1.37198" />\r\n </Layer>\r\n </Layer>\r\n <Layer queryable="0" opaque="0" cascaded="0">\r\n <Name>stadtplan_72dpi</Name>\r\n <Title>stadtplan_uebersicht</Title>\r\n <SRS>EPSG:31467</SRS>\r\n <ScaleHint min="149.671" max="498.903" />\r\n </Layer>\r\n <Layer>\r\n <Name>Stadtbezirke</Name>\r\n <Title>Stadtbezirke</Title>\r\n <Abstract>Stadtbezirke</Abstract>\r\n <Layer queryable="0" opaque="0" cascaded="0">\r\n <Name>stadtbezirke_pl</Name>\r\n <Title>stadtbezirke_pl</Title>\r\n <SRS>EPSG:31467</SRS>\r\n <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />\r\n <BoundingBox SRS="EPSG:31467"\r\n minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />\r\n <Style>\r\n <Name>default</Name>\r\n <Title>default</Title>\r\n <LegendURL width="18" height="12">\r\n <Format>image/png</Format>\r\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=stadtbezirke_pl&format=image/png"/>\r\n </LegendURL>\r\n </Style>\r\n <ScaleHint min="0" max="149.671" />\r\n </Layer>\r\n <Layer queryable="0" opaque="0" cascaded="0">\r\n <Name>stadtbezirke_t</Name>\r\n <Title>stadtbezirke_t</Title>\r\n <SRS>EPSG:31467</SRS>\r\n <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />\r\n <BoundingBox SRS="EPSG:31467"\r\n minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />\r\n <Style>\r\n <Name>default</Name>\r\n <Title>default</Title>\r\n <LegendURL width="18" height="12">\r\n <Format>image/png</Format>\r\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=stadtbezirke_t&format=image/png"/>\r\n </LegendURL>\r\n </Style>\r\n <ScaleHint min="0" max="149.671" />\r\n </Layer>\r\n </Layer>\r\n <Layer>\r\n <Name>Wahlbezirke</Name>\r\n <Title>Wahlbezirke</Title>\r\n <Abstract>Wahlbezirke</Abstract>\r\n <Layer queryable="0" opaque="0" cascaded="0">\r\n <Name>wahlbezirke_pl</Name>\r\n <Title>wahlbezirke_pl</Title>\r\n <SRS>EPSG:31467</SRS>\r\n <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />\r\n <BoundingBox SRS="EPSG:31467"\r\n minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />\r\n <Style>\r\n <Name>default</Name>\r\n <Title>default</Title>\r\n <LegendURL width="18" height="12">\r\n <Format>image/png</Format>\r\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=wahlbezirke_pl&format=image/png"/>\r\n </LegendURL>\r\n </Style>\r\n <ScaleHint min="0" max="149.671" />\r\n </Layer>\r\n <Layer queryable="0" opaque="0" cascaded="0">\r\n <Name>wahlbezirke_t</Name>\r\n <Title>wahlbezirke_t</Title>\r\n <SRS>EPSG:31467</SRS>\r\n <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />\r\n <BoundingBox SRS="EPSG:31467"\r\n minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />\r\n <Style>\r\n <Name>default</Name>\r\n <Title>default</Title>\r\n <LegendURL width="18" height="12">\r\n <Format>image/png</Format>\r\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=wahlbezirke_t&format=image/png"/>\r\n </LegendURL>\r\n </Style>\r\n <ScaleHint min="0" max="149.671" />\r\n </Layer>\r\n </Layer>\r\n <Layer>\r\n <Name>Stimmbezirke</Name>\r\n <Title>Stimmbezirke</Title>\r\n <Abstract>Stimmbezirke</Abstract>\r\n <Layer queryable="0" opaque="0" cascaded="0">\r\n <Name>stimmbezirke_pl</Name>\r\n <Title>stimmbezirke_pl</Title>\r\n <SRS>EPSG:31467</SRS>\r\n <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />\r\n <BoundingBox SRS="EPSG:31467"\r\n minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />\r\n <Style>\r\n <Name>default</Name>\r\n <Title>default</Title>\r\n <LegendURL width="18" height="12">\r\n <Format>image/png</Format>\r\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=stimmbezirke_pl&format=image/png"/>\r\n </LegendURL>\r\n </Style>\r\n <ScaleHint min="0" max="149.671" />\r\n </Layer>\r\n <Layer queryable="0" opaque="0" cascaded="0">\r\n <Name>stimmbezirke_t</Name>\r\n <Title>stimmbezirke_t</Title>\r\n <SRS>EPSG:31467</SRS>\r\n <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />\r\n <BoundingBox SRS="EPSG:31467"\r\n minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />\r\n <Style>\r\n <Name>default</Name>\r\n <Title>default</Title>\r\n <LegendURL width="18" height="12">\r\n <Format>image/png</Format>\r\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=stimmbezirke_t&format=image/png"/>\r\n </LegendURL>\r\n </Style>\r\n <ScaleHint min="0" max="149.671" />\r\n </Layer>\r\n </Layer>\r\n </Layer>\r\n</Capability>\r\n</WMT_MS_Capabilities>\r\n');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (883, '1.0.0', 'SICAD/SD-IMS V5.1-Luftbilder', 'SICAD/SD Internet Map Services V5.1 at http://192.168.252.12:80-Luftbilder', 'http://212.8.208.50/mapserver/isserver/sdims/bin/wms/getCapabilities.pl?dataSource=Luftbilder', 'http://212.8.208.50/mapserver/isserver/sdims/bin/wms/getMap.pl?dataSource=Luftbilder', 'http://212.8.208.50/mapserver/isserver/sdims/bin/wms/getFeatureInfo.pl?dataSource=Luftbilder', '', NULL, '<?xml version="1.0" encoding="ISO-8859-1" standalone="no"?>\n<!DOCTYPE WMT_MS_Capabilities SYSTEM "http://212.8.208.50/mapserver/isserver/sdims/bin/wms/capabilities1.0.0.dtd" >\n<WMT_MS_Capabilities version="1.0.0" updateSequence="1">\n <Service>\n <Name>GetMap</Name>\n <Title>SICAD/SD-IMS V5.1-Luftbilder</Title>\n <Abstract>SICAD/SD Internet Map Services V5.1 at http://192.168.252.12:80-Luftbilder</Abstract>\n <Keywords/>\n <OnlineResource>http://192.168.252.12:80</OnlineResource>\n <Fees>none</Fees>\n <AccessConstraints>none</AccessConstraints>\n </Service>\n <Capability>\n <Request>\n <Map>\n <Format>\n <JPEG /><PNG /><GIF />\n </Format>\n <DCPType>\n <HTTP>\n <Get onlineResource="http://212.8.208.50/mapserver/isserver/sdims/bin/wms/getMap.pl?dataSource=Luftbilder"/>\n </HTTP>\n </DCPType>\n </Map>\n <Capabilities>\n <Format>\n <WMS_XML/>\n </Format>\n <DCPType>\n <HTTP>\n <Get onlineResource="http://212.8.208.50/mapserver/isserver/sdims/bin/wms/getCapabilities.pl?dataSource=Luftbilder"/>\n </HTTP>\n </DCPType>\n </Capabilities>\n <FeatureInfo>\n <Format>\n <MIME/>\n </Format>\n <DCPType>\n <HTTP>\n <Get onlineResource="http://212.8.208.50/mapserver/isserver/sdims/bin/wms/getFeatureInfo.pl?dataSource=Luftbilder"/>\n </HTTP>\n </DCPType>\n </FeatureInfo>\n </Request>\n <Exception>\n <Format>\n <WMS_XML/>\n </Format>\n </Exception>\n<Layer queryable="0">\n<Title>Luftbilder</Title>\n<Abstract>Vermessungs- und Katasteramt -- Author: -- last update: 26.08.05 - 10:33:39</Abstract>\n<SRS>EPSG:31467 EPSG:4326</SRS>\n<LatLonBoundingBox minx="8.35451189433807" miny="51.9089799444053" maxx="8.69098195743338" maxy="52.1193351046263"/> <BoundingBox SRS="EPSG:31467" minx="3455652" miny="5752972" maxx="3478906" maxy="5776226"/>\n <BoundingBox SRS="EPSG:4326" minx="8.35451189433807" miny="51.9089799444053" maxx="8.69098195743338" maxy="52.1193351046263"/>\n <Layer queryable="0">\n <Name>1</Name>\n <Title>$_nav_uebersicht</Title>\n <Abstract/>\n <SRS>EPSG:31467 EPSG:4326</SRS>\n <LatLonBoundingBox minx="8.35451189433807" miny="51.9089799444053" maxx="8.69098195743338" maxy="52.1193351046263"/>\n <BoundingBox SRS="EPSG:31467" minx="3455652" miny="5752972" maxx="3478906" maxy="5776226"/>\n <BoundingBox SRS="EPSG:4326" minx="8.35451189433807" miny="51.9089799444053" maxx="8.69098195743338" maxy="52.1193351046263"/>\n <Style>\n <Name>default</Name>\n <Title>1, default style</Title>\n <Abstract>1</Abstract>\n </Style>\n </Layer>\n <Layer queryable="0">\n <Name>2</Name>\n <Title>Stadtplan </Title>\n <Abstract/>\n <SRS>EPSG:31467 EPSG:4326</SRS>\n <LatLonBoundingBox minx="8.35451189433807" miny="51.9089799444053" maxx="8.69098195743338" maxy="52.1193351046263"/>\n <BoundingBox SRS="EPSG:31467" minx="3455652" miny="5752972" maxx="3478906" maxy="5776226"/>\n <BoundingBox SRS="EPSG:4326" minx="8.35451189433807" miny="51.9089799444053" maxx="8.69098195743338" maxy="52.1193351046263"/>\n <Style>\n <Name>default</Name>\n <Title>2, default style</Title>\n <Abstract>2</Abstract>\n </Style>\n </Layer>\n <Layer queryable="0">\n <Name>5</Name>\n <Title>Luftbilder 1999</Title>\n <Abstract/>\n <SRS>EPSG:31467 EPSG:4326</SRS>\n <LatLonBoundingBox minx="8.35451189433807" miny="51.9089799444053" maxx="8.69098195743338" maxy="52.1193351046263"/>\n <BoundingBox SRS="EPSG:31467" minx="3455652" miny="5752972" maxx="3478906" maxy="5776226"/>\n <BoundingBox SRS="EPSG:4326" minx="8.35451189433807" miny="51.9089799444053" maxx="8.69098195743338" maxy="52.1193351046263"/>\n <Style>\n <Name>default</Name>\n <Title>5, default style</Title>\n <Abstract>5</Abstract>\n </Style>\n </Layer>\n <Layer queryable="0">\n <Name>8</Name>\n <Title>Flurstuecksstruktur</Title>\n <Abstract/>\n <SRS>EPSG:31467 EPSG:4326</SRS>\n <LatLonBoundingBox minx="8.35451189433807" miny="51.9089799444053" maxx="8.69098195743338" maxy="52.1193351046263"/>\n <BoundingBox SRS="EPSG:31467" minx="3455652" miny="5752972" maxx="3478906" maxy="5776226"/>\n <BoundingBox SRS="EPSG:4326" minx="8.35451189433807" miny="51.9089799444053" maxx="8.69098195743338" maxy="52.1193351046263"/>\n <Style>\n <Name>default</Name>\n <Title>8, default style</Title>\n <Abstract>8</Abstract>\n </Style>\n </Layer>\n <Layer queryable="0">\n <Name>9</Name>\n <Title>Texte</Title>\n <Abstract/>\n <SRS>EPSG:31467 EPSG:4326</SRS>\n <LatLonBoundingBox minx="8.35451189433807" miny="51.9089799444053" maxx="8.69098195743338" maxy="52.1193351046263"/>\n <BoundingBox SRS="EPSG:31467" minx="3455652" miny="5752972" maxx="3478906" maxy="5776226"/>\n <BoundingBox SRS="EPSG:4326" minx="8.35451189433807" miny="51.9089799444053" maxx="8.69098195743338" maxy="52.1193351046263"/>\n <Style>\n <Name>default</Name>\n <Title>9, default style</Title>\n <Abstract>9</Abstract>\n </Style>\n </Layer>\n</Layer></Capability></WMT_MS_Capabilities>');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (884, '1.1.0', 'Wasserschutzgebiete NRW', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS', 'http://www.gis2.nrw.de/wmsconnector/wms/wsg?', 'http://www.gis2.nrw.de/wmsconnector/wms/wsg?', 'http://www.gis2.nrw.de/wmsconnector/wms/wsg?', '', NULL, '<?xml version="1.0" encoding="UTF-8"?>\n<!DOCTYPE WMT_MS_Capabilities\n SYSTEM "http://www.gis2.nrw.de/wmsconnector/schema/wms/1.1.0/capabilities_1_1_0.dtd">\n<WMT_MS_Capabilities updateSequence="0" version="1.1.0">\n <Service>\n <Name>OGC:WMS</Name>\n <Title>Wasserschutzgebiete NRW</Title>\n <Abstract>This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS</Abstract>\n <KeywordList>\n <Keyword>WMS</Keyword>\n <Keyword>Web Mapping</Keyword>\n <Keyword>GIS</Keyword>\n <Keyword>GDI NRW</Keyword>\n </KeywordList>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/wmsconnector/wms/wsg?" xlink:type="simple"/>\n <ContactInformation>\n <ContactPersonPrimary>\n <ContactPerson>Stephanie Kempkes</ContactPerson>\n <ContactOrganization>Landesumweltamt NRW</ContactOrganization>\n </ContactPersonPrimary>\n <ContactPosition/>\n <ContactAddress>\n <AddressType>postal</AddressType>\n <Address>Postfach 10 23 63</Address>\n <City>Essen</City>\n <StateOrProvince>NRW</StateOrProvince>\n <PostCode>45023</PostCode>\n <Country>Germany</Country>\n </ContactAddress>\n <ContactVoiceTelephone>+49 211 1590-2202</ContactVoiceTelephone>\n <ContactFacsimileTelephone>+49 211 1590-2176</ContactFacsimileTelephone>\n <ContactElectronicMailAddress>Stephanie.Kempkes at lua.nrw.de</ContactElectronicMailAddress>\n </ContactInformation>\n <Fees>siehe http://www.geocatalog.de</Fees>\n <AccessConstraints>siehe http://www.geocatalog.de</AccessConstraints>\n </Service>\n <Capability>\n <Request>\n <GetCapabilities>\n <Format>application/vnd.ogc.wms_xml</Format>\n <DCPType>\n <HTTP>\n <Get>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/wmsconnector/wms/wsg?" xlink:type="simple"/>\n </Get>\n </HTTP>\n </DCPType>\n <DCPType>\n <HTTP>\n <Post>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/wmsconnector/wms/wsg?" xlink:type="simple"/>\n </Post>\n </HTTP>\n </DCPType>\n </GetCapabilities>\n <GetMap>\n <Format>image/jpeg</Format>\n <Format>image/png</Format>\n <Format>image/gif</Format>\n <DCPType>\n <HTTP>\n <Get>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/wmsconnector/wms/wsg?" xlink:type="simple"/>\n </Get>\n </HTTP>\n </DCPType>\n </GetMap>\n <GetFeatureInfo>\n <Format>text/html</Format>\n <Format>text/xml</Format>\n <Format>text/plain</Format>\n <Format>application/vnd.esri.xml</Format>\n <DCPType>\n <HTTP>\n <Get>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/wmsconnector/wms/wsg?" xlink:type="simple"/>\n </Get>\n </HTTP>\n </DCPType>\n </GetFeatureInfo>\n </Request>\n <Exception>\n <Format>application/vnd.ogc.se_xml</Format>\n </Exception>\n <VendorSpecificCapabilities/>\n <UserDefinedSymbolization RemoteWFS="0" SupportSLD="1" UserLayer="1" UserStyle="1"/>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Title>wsg</Title>\n <SRS>EPSG:4326 EPSG:25832 EPSG:25833 EPSG:31466 EPSG:31467</SRS>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n \n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>Trinkwasser Zone 1 punktfoermig</Name>\n <Title>Trinkwasser Zone 1 punktfoermig</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="28" width="319">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/wsg/TrinkwasserZ1pkt_trs.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n </Layer>\n \n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>Trinkwasserschutzgebiete</Name>\n <Title>Trinkwasserschutzgebiete</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="568" width="319">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/wsg/twsg_trs.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n </Layer>\n \n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>Heilquellen Zone 1 punktfoermig</Name>\n <Title>Heilquellen Zone 1 punktfoermig</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="28" width="319">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/wsg/HeilquellenZ1pkt_trs.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>Heilquellenschutzgebiete</Name>\n <Title>Heilquellenschutzgebiete</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="835" width="260">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/wsg/hsg_trs.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n </Layer>\n \n \n </Layer>\n </Capability>\n</WMT_MS_Capabilities>');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (885, '1.1.1', 'XtraServer/WMS fuer GDI NRW Verbundprojekt 2004', 'Xtra Web Map Server von interactive instruments bereitgestellt im Rahmen des GDI NRW Verbundprojekts 2004. Der Server präsentiert das Netz der klassifizierten Straßen im Stand 2000 basierend auf dem OKSTRA-Standard im Bereich des Bundeslandes Nordrhein We', 'http://xtra.interactive-instruments.de/cgi-bin/wms?', 'http://xtra.interactive-instruments.de/cgi-bin/wms?', 'http://xtra.interactive-instruments.de/cgi-bin/wms?', '', NULL, '<?xml version="1.0" encoding="ISO-8859-1"?>\n<!DOCTYPE WMT_MS_Capabilities SYSTEM "http://www.interactive-instruments.de/schema/WMS_CapabilitiesResponse.DTD"\n[<!ELEMENT VendorSpecificCapabilities EMPTY>]>\n<WMT_MS_Capabilities version="1.1.1" updateSequence="0">\n\n <Service>\n <Name>WMS</Name>\n <Title>XtraServer/WMS fuer GDI NRW Verbundprojekt 2004</Title>\n <Abstract>Xtra Web Map Server von interactive instruments bereitgestellt im Rahmen des GDI NRW Verbundprojekts 2004. Der Server präsentiert das Netz der klassifizierten Straßen im Stand 2000 basierend auf dem OKSTRA-Standard im Bereich des Bundeslandes Nordrhein Westfalen. Referenziert auf das Straßennetz sind Daten aus der Straßenverkehrszählung 2000.</Abstract>\n <KeywordList>\n <Keyword>Strassen</Keyword>\n <Keyword>Straßen</Keyword>\n <Keyword>OKSTRA</Keyword>\n <Keyword>Straßenverkehrszählung</Keyword>\n <Keyword>DTV</Keyword>\n <Keyword>Zählstelle</Keyword>\n </KeywordList>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://www.interactive-instruments.de/"/>\n <ContactInformation>\n <ContactPersonPrimary>\n <ContactPerson>Reinhard Erstling</ContactPerson>\n <ContactOrganization>interactive instruments</ContactOrganization>\n </ContactPersonPrimary>\n <ContactPosition>Geschäftsführer</ContactPosition>\n <ContactAddress>\n <AddressType>postal</AddressType>\n <Address>interactive instruments GmbH</Address>\n <City>Bonn</City>\n <StateOrProvince>D</StateOrProvince>\n <PostCode>53115</PostCode>\n <Country>Germany</Country>\n </ContactAddress>\n <ContactVoiceTelephone>+49 228 91410-71</ContactVoiceTelephone>\n <ContactFacsimileTelephone>+49 228 91410-90</ContactFacsimileTelephone>\n <ContactElectronicMailAddress>erstling at interactive-instruments.de</ContactElectronicMailAddress>\n </ContactInformation>\n <Fees>none</Fees>\n <AccessConstraints>\n Die von diesem Dienst bereitgestellten Daten wurden vom Ministerium für\n Verkehr, Energie und Landesplanung (MVEL) und dem Landesbetrieb Straßenbau \n des Landes NRW zur Verfügung gestellt. Zur Nutzung der Daten über das GDI NRW \n Verbundprojekt hinaus ist eine Vereinbarung erforderlich. Die im Bestand\n enthaltenen Zähldaten der Bundesfernstraßen aus den Straßenverkehrszählungen \n 1995 und 2000 sind kein Bestandteil des Verbundprojekts und stehen nur \n vorläufig und vorbehaltlich einer Zustimmung des Bundesministeriums für \n Verkehr, Bau- und Wohnungswesen zur Verfügung.\n </AccessConstraints>\n </Service>\n\n <Capability>\n\n <Request>\n <GetCapabilities>\n <Format>application/vnd.ogc.wms_xml</Format>\n <DCPType>\n <HTTP>\n <Get>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://xtra.interactive-instruments.de/cgi-bin/wms?"/>\n </Get>\n </HTTP>\n </DCPType>\n </GetCapabilities>\n <GetMap>\n <Format>image/png</Format>\n <Format>image/jpeg</Format>\n <DCPType>\n <HTTP>\n <Get>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://xtra.interactive-instruments.de/cgi-bin/wms?"/>\n </Get>\n </HTTP>\n </DCPType>\n </GetMap>\n <GetFeatureInfo>\n <Format>application/vnd.ogc.gml</Format>\n <Format>text/html</Format>\n <Format>application/vnd.ii.vinfo_html</Format>\n <DCPType>\n <HTTP>\n <Get>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://xtra.interactive-instruments.de/cgi-bin/wms?"/>\n </Get>\n </HTTP>\n </DCPType>\n </GetFeatureInfo>\n <DescribeLayer>\n <Format>application/vnd.ogc.wms_xml</Format>\n <DCPType>\n <HTTP>\n <Get>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://xtra.interactive-instruments.de/cgi-bin/wms?"/>\n </Get>\n </HTTP>\n </DCPType>\n </DescribeLayer>\n </Request>\n\n <Exception>\n <Format>application/vnd.ogc.se_xml</Format>\n </Exception>\n\n <UserDefinedSymbolization\n SupportSLD="1"\n UserLayer="0"\n UserStyle="1"\n RemoteWFS="0" />\n\n <Layer queryable="0">\n <Title>OKSTRA(c)-Straßendaten aus NRW</Title>\n <SRS>EPSG:31466 EPSG:31467 EPSG:31468 EPSG:31469 EPSG:4326 EPSG:25831 EPSG:25832 EPSG:25833</SRS>\n <LatLonBoundingBox minx="5.86214438119609" miny="50.2758785264961" maxx="9.51136899529965" maxy="52.5503363944171"/>\n <BoundingBox SRS="EPSG:31466" minx="2490217.39732242" miny="5571104.84471283" maxx="2750321.92833604" maxy="5829939.37824083" resx="1" resy="1"/>\n <BoundingBox SRS="EPSG:31467" minx="3276415.28939716" miny="5571218.70445849" maxx="3536527.86806821" maxy="5828768.60697208" resx="1" resy="1"/>\n <BoundingBox SRS="EPSG:31468" minx="4062726.19199224" miny="5574053.87943491" maxx="4331309.71462349" maxy="5841861.56505894" resx="1" resy="1"/>\n <BoundingBox SRS="EPSG:31469" minx="4849263.53311334" miny="5585514.90270094" maxx="5127978.02983409" maxy="5863474.23398516" resx="1" resy="1"/>\n <BoundingBox SRS="EPSG:4326" minx="5.86214438119609" miny="50.2758785264961" maxx="9.51136899529965" maxy="52.5503363944171" resx="1" resy="1"/>\n <BoundingBox SRS="EPSG:25831" minx="694051.604464286" miny="5573226.16336796" maxx="963792.436617757" maxy="5842194.02530665" resx="1" resy="1"/>\n <BoundingBox SRS="EPSG:25832" minx="276430.655067927" miny="5569430.14485848" maxx="536439.384865941" maxy="5826879.37234734" resx="1" resy="1"/>\n <BoundingBox SRS="EPSG:25833" minx="-150612.77949327" miny="5583728.8589265" maxx="127992.233617833" maxy="5861578.77999188" resx="1" resy="1"/>\n <Attribution>\n <Title>Landesbetrieb Straßenbau NRW</Title>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://www.strassen.nrw.de/"/>\n </Attribution>\n\n <Layer queryable="1">\n <Name>Strassen</Name>\n <Title>Alle Straßen</Title>\n <Style>\n <Name>OhneKennung</Name>\n <Title>Ohne Straßennamen</Title>\n </Style>\n <Style>\n <Name>MitKennung</Name>\n <Title>Mit Straßennamen</Title>\n </Style>\n <Style>\n <Name>NurKennung</Name>\n <Title>Nur Straßennamen</Title>\n </Style>\n <Layer>\n <Name>Autobahnen</Name>\n <Title>Autobahnen</Title>\n </Layer>\n <Layer>\n <Name>Bundesstrassen</Name>\n <Title>Bundesstraßen</Title>\n </Layer>\n <Layer>\n <Name>Landesstrassen</Name>\n <Title>Landesstraßen</Title>\n </Layer>\n <Layer>\n <Name>Kreisstrassen</Name>\n <Title>Kreisstraßen</Title>\n </Layer>\n </Layer>\n\n <Layer queryable="1">\n <Name>NKStrassen</Name>\n <Title>Netzknoten, alle Straßen</Title>\n <Style>\n <Name>OhneKennung</Name>\n <Title>Ohne Netzknotenkennung</Title>\n </Style>\n <Style>\n <Name>MitKennungKurz</Name>\n <Title>Mit 3-stelliger Kennung</Title>\n </Style>\n <Style>\n <Name>MitKennungLang</Name>\n <Title>Mit 7-stelliger Kennung</Title>\n </Style>\n <Style>\n <Name>MitNamen</Name>\n <Title>Mit Netzknotennamen</Title>\n </Style>\n <Style>\n <Name>NurKennungKurz</Name>\n <Title>Nur 3-stellige Kennung</Title>\n </Style>\n <Style>\n <Name>NurKennungLang</Name>\n <Title>Nur 7-stellige Kennung</Title>\n </Style>\n <Style>\n <Name>NurName</Name>\n <Title>Nur Netzknotenname</Title>\n </Style>\n <Layer>\n <Name>NKAutobahnen</Name>\n <Title>Netzknoten, Autobahnen</Title>\n </Layer>\n\n <Layer>\n <Name>NKBundesstrassen</Name>\n <Title>Netzknoten, Bundesstraßen</Title>\n </Layer>\n\n <Layer>\n <Name>NKLandesstrassen</Name>\n <Title>Netzknoten, Landesstraßen</Title>\n </Layer>\n\n <Layer>\n <Name>NKKreisstrassen</Name>\n <Title>Netzknoten, Kreisstraßen</Title>\n </Layer>\n\n </Layer>\n\n <Layer queryable="1">\n <Name>NPStrassen</Name>\n <Title>Nullpunkte, alle Straßen</Title>\n <Style>\n <Name>OhneKennung</Name>\n <Title>Ohne Nullpunktskennung</Title>\n </Style>\n <Style>\n <Name>MitKennungBuchstabe</Name>\n <Title>Mit Nullpunkts-Buchstabe</Title>\n </Style>\n <Style>\n <Name>MitKennungKurz</Name>\n <Title>Mit 3-stelliger Kennung und Buchstabe</Title>\n </Style>\n <Style>\n <Name>MitKennungLang</Name>\n <Title>Mit 7-stelliger Kennung und Buchstabe</Title>\n </Style>\n <Style>\n <Name>NurKennungBuchstabe</Name>\n <Title>Nur Nullpunkts-Buchstabe</Title>\n </Style>\n <Style>\n <Name>NurKennungKurz</Name>\n <Title>Nur 3-stellige Kennung und Buchstabe</Title>\n </Style>\n <Style>\n <Name>NurKennungLang</Name>\n <Title>Nur 7-stellige Kennung und Buchstabe</Title>\n </Style>\n <Layer>\n <Name>NPAutobahnen</Name>\n <Title>Nullpunkte, Autobahnen</Title>\n </Layer>\n\n <Layer>\n <Name>NPBundesstrassen</Name>\n <Title>Nullpunkte, Bundesstraßen</Title>\n </Layer>\n\n <Layer>\n <Name>NPLandesstrassen</Name>\n <Title>Nullpunkte, Landesstraßen</Title>\n </Layer>\n\n <Layer>\n <Name>NPKreisstrassen</Name>\n <Title>Nullpunkte, Kreisstraßen</Title>\n </Layer>\n </Layer>\n\n <Layer queryable="0">\n <Name>TKBlaetter</Name>\n <Title>TK-Blattschnitte</Title>\n </Layer>\n\n <Layer queryable="1">\n <Name>mZstBereichStrassen</Name>\n <Title>Zst-Bereiche alle Straßen</Title>\n <Style>\n <Name>alleBereiche</Name>\n <Title>alle Bereiche</Title>\n </Style>\n <Layer>\n <Name>mZstBereichAutobahnen</Name>\n <Title>Zst-Bereiche Autobahnen</Title>\n </Layer>\n <Layer>\n <Name>mZstBereichBundesstrassen</Name>\n <Title>Zst-Bereiche Bundesstraßen</Title>\n </Layer>\n <Layer>\n <Name>mZstBereichLandesstrassen</Name>\n <Title>Zst-Bereiche Landesstraßen</Title>\n </Layer>\n <Layer>\n <Name>mZstBereichKreisstrassen</Name>\n <Title>Zst-Bereiche Kreisstraßen</Title>\n </Layer>\n </Layer>\n\n <Layer queryable="1">\n <Name>mZstOrtStrassen</Name>\n <Title>Zst-Orte alle Straßen</Title>\n <Style>\n <Name>MitKennung</Name>\n <Title>mit Kennung</Title>\n </Style>\n <Style>\n <Name>MitDTV</Name>\n <Title>mit DTV-Wert</Title>\n </Style>\n <Style>\n <Name>MitKennung+DTV</Name>\n <Title>mit Kennung und DTV-Wert</Title>\n </Style>\n <Style>\n <Name>OhneBeschriftung</Name>\n <Title>ohne Beschriftung</Title>\n </Style>\n <Layer>\n <Name>mZstOrtAutobahnen</Name>\n <Title>Zst-Orte Autobahnen</Title>\n </Layer>\n <Layer>\n <Name>mZstOrtBundesstrassen</Name>\n <Title>Zst-Orte Bundesstrassen</Title>\n </Layer>\n <Layer>\n <Name>mZstOrtLandesstrassen</Name>\n <Title>Zst-Orte Landesstrassen</Title>\n </Layer>\n <Layer>\n <Name>mZstOrtKreisstrassen</Name>\n <Title>Zst-Orte Kreisstrassen</Title>\n </Layer>\n </Layer>\n\n\n </Layer>\n\n </Capability>\n <Filter_Capabilities>\n <Spatial_Capabilities>\n <Spatial_Operators>\n <BBOX/>\n <Disjoint/>\n <Intersect/>\n </Spatial_Operators>\n </Spatial_Capabilities>\n <Scalar_Capabilities>\n <Logical_Operators/>\n <Comparison_Operators>\n <Simple_Comparisons/>\n </Comparison_Operators>\n <Arithmetic_Operators>\n <Simple_Arithmetic/>\n <Functions>\n <Function_Names>\n </Function_Names>\n </Functions>\n </Arithmetic_Operators>\n </Scalar_Capabilities>\n </Filter_Capabilities>\n\n</WMT_MS_Capabilities>');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (887, '1.1.0', 'NRW: Bodenkarte BK50', 'WMS Map Server', 'http://www.gis.nrw.de:80/wms/BK50', 'http://www.gis.nrw.de:80/wms/BK50', 'http://www.gis.nrw.de:80/wms/BK50', '', NULL, '<?xml version="1.0" encoding="UTF-8" standalone="yes" ?>\r\n<!DOCTYPE WMT_MS_Capabilities SYSTEM "http://www.digitalearth.gov/wmt/xml/capabilities_1_1_0.dtd" >\r\n\r\n\r\n<WMT_MS_Capabilities version="1.1.0" updateSequence="0">\r\n<Service>\r\n<Name>OGC:WMS</Name>\r\n<Title>NRW: Bodenkarte BK50</Title>\r\n<Abstract>WMS Map Server</Abstract>\r\n<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://www.gis.nrw.de:80/wms/BK50?"/>\r\n<Fees></Fees>\r\n<AccessConstraints></AccessConstraints>\r\n</Service>\r\n<Capability>\r\n<Request>\r\n<GetCapabilities>\r\n<Format>application/vnd.ogc.wms_xml</Format>\r\n<DCPType>\r\n<HTTP>\r\n<Get>\r\n<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://www.gis.nrw.de:80/wms/BK50"/>\r\n</Get>\r\n</HTTP>\r\n</DCPType>\r\n</GetCapabilities>\r\n<GetMap>\r\n<Format>image/jpeg</Format>\r\n<Format>image/png</Format>\r\n<DCPType>\r\n<HTTP>\r\n<Get>\r\n<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://www.gis.nrw.de:80/wms/BK50"/>\r\n</Get>\r\n</HTTP>\r\n</DCPType>\r\n</GetMap>\r\n<GetFeatureInfo>\r\n<Format>application/vnd.ogc.wms_xml</Format>\r\n<Format>text/plain</Format>\r\n<Format>text/html</Format>\r\n<DCPType>\r\n<HTTP>\r\n<Get>\r\n<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://www.gis.nrw.de:80/wms/BK50"/>\r\n</Get>\r\n</HTTP>\r\n</DCPType>\r\n</GetFeatureInfo>\r\n</Request>\r\n<Exception>\r\n<Format>application/vnd.ogc.se_xml</Format>\r\n<Format>application/vnd.ogc.se_inimage</Format>\r\n<Format>application/vnd.ogc.se_blank</Format>\r\n</Exception>\r\n<Layer queryable="1">\r\n<Title>BK50</Title>\r\n<SRS>EPSG:31492</SRS>\r\n <LatLonBoundingBox maxx="8.6519" maxy="52.5054" minx="5.8682" miny="50.3189" /> \r\n <BoundingBox SRS="EPSG:31492" minx="2476553.0" miny="5540279.0" maxx="2779499.0" maxy="5856970.0" />\r\n<Layer queryable="1">\r\n<Name>bk50</Name>\r\n<Title>bk50</Title>\r\n<SRS>EPSG:31492</SRS>\r\n<LatLonBoundingBox minx="2738496.0" miny="77673.0" maxx="5821724.0" maxy="625065.0"/>\r\n</Layer>\r\n</Layer>\r\n</Capability>\r\n</WMT_MS_Capabilities>\r\n');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (888, '1.1.0', 'Waldtypenkarte NRW', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS', 'http://www.gis2.nrw.de/wmsconnector/wms/waldtyp?', 'http://www.gis2.nrw.de/wmsconnector/wms/waldtyp?', 'http://www.gis2.nrw.de/wmsconnector/wms/waldtyp?', '', NULL, '<?xml version="1.0" encoding="UTF-8"?>\n<!DOCTYPE WMT_MS_Capabilities\n SYSTEM "http://www.gis2.nrw.de/wmsconnector/schema/wms/1.1.0/capabilities_1_1_0.dtd">\n<WMT_MS_Capabilities updateSequence="0" version="1.1.0">\n <Service>\n <Name>OGC:WMS</Name>\n <Title>Waldtypenkarte NRW</Title>\n <Abstract>This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS</Abstract>\n <KeywordList>\n <Keyword>WMS</Keyword>\n <Keyword>Web Mapping</Keyword>\n <Keyword>GIS</Keyword>\n <Keyword>GDI NRW</Keyword>\n </KeywordList>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/wmsconnector/wms/waldtyp?" xlink:type="simple"/>\n <ContactInformation>\n <ContactPersonPrimary>\n <ContactPerson>Dr. Norbert Asche</ContactPerson>\n <ContactOrganization>LOEBF NRW</ContactOrganization>\n </ContactPersonPrimary>\n <ContactPosition/>\n <ContactAddress>\n <AddressType/>\n <Address>Castroper Str. 312-314</Address>\n <City>Recklinghausen</City>\n <StateOrProvince>NRW</StateOrProvince>\n <PostCode>45665</PostCode>\n <Country>Germany</Country>\n </ContactAddress>\n <ContactVoiceTelephone>+49 (2361) 305-234</ContactVoiceTelephone>\n <ContactFacsimileTelephone>+49 (2361) 305-538</ContactFacsimileTelephone>\n <ContactElectronicMailAddress>norbert.asche at loebf.nrw.de</ContactElectronicMailAddress>\n </ContactInformation>\n <Fees>siehe http://www.geocatalog.de</Fees>\n <AccessConstraints>siehe http://www.geocatalog.de</AccessConstraints>\n </Service>\n <Capability>\n <Request>\n <GetCapabilities>\n <Format>application/vnd.ogc.wms_xml</Format>\n <DCPType>\n <HTTP>\n <Get>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/wmsconnector/wms/waldtyp?" xlink:type="simple"/>\n </Get>\n </HTTP>\n </DCPType>\n <DCPType>\n <HTTP>\n <Post>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/wmsconnector/wms/waldtyp?" xlink:type="simple"/>\n </Post>\n </HTTP>\n </DCPType>\n </GetCapabilities>\n <GetMap>\n <Format>image/jpeg</Format>\n <Format>image/png</Format>\n <Format>image/gif</Format>\n <DCPType>\n <HTTP>\n <Get>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/wmsconnector/wms/waldtyp?" xlink:type="simple"/>\n </Get>\n </HTTP>\n </DCPType>\n </GetMap>\n <GetFeatureInfo>\n <Format>text/html</Format>\n <Format>text/xml</Format>\n <Format>text/plain</Format>\n <Format>application/vnd.esri.xml</Format>\n <DCPType>\n <HTTP>\n <Get>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/wmsconnector/wms/waldtyp?" xlink:type="simple"/>\n </Get>\n </HTTP>\n </DCPType>\n </GetFeatureInfo>\n </Request>\n <Exception>\n <Format>application/vnd.ogc.se_xml</Format>\n </Exception>\n <VendorSpecificCapabilities/>\n <UserDefinedSymbolization RemoteWFS="0" SupportSLD="1" UserLayer="1" UserStyle="1"/>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Title>waldtyp</Title>\n <SRS>EPSG:4326 EPSG:25832 EPSG:25833 EPSG:31466 EPSG:31467</SRS>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <Layer noSubsets="0" opaque="0" queryable="1">\n <Name>Waldtyp</Name>\n <Title>Waldtyp</Title>\n <Style>\n <Name/> \n <Title/>\n <LegendURL height="466" width="319">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.gis2.nrw.de/verbundprojekt/Legend/Waldtyp/Waldtyp_trs.png" xlink:type="simple"/>\n </LegendURL>\n </Style>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="187.06079078824797" min="18.7060790788248"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="0">\n <Name>Waldtyp_50</Name>\n <Title>Waldtyp_50</Title>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="93.53039539412413" min="18.7060790788248"/>\n </Layer>\n <Layer noSubsets="0" opaque="0" queryable="0">\n <Name>Waldtyp_Real</Name>\n <Title>Waldtyp_Real</Title>\n <LatLonBoundingBox maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:4326" maxx="10.142" maxy="52.7691" minx="5.673" miny="49.9944"/>\n <BoundingBox SRS="EPSG:31466" maxx="2779499.0" maxy="5856970.0" minx="2476553.0" miny="5540279.0"/>\n <BoundingBox SRS="EPSG:31467" maxx="3577127.98" maxy="5849530.15" minx="3261513.05" miny="5545534.73"/>\n <BoundingBox SRS="EPSG:25832" maxx="577026.2" maxy="5847631.27" minx="261533.79" miny="5543758.24"/>\n <BoundingBox SRS="EPSG:25833" maxx="127822.0" maxy="5858091.88" minx="-149462.0" miny="5580271.61"/>\n <ScaleHint max="93.53039539412413" min="18.7060790788248"/>\n </Layer>\n </Layer>\n </Capability>\n</WMT_MS_Capabilities>');
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc) VALUES (893, '1.1.1', 'Germany', 'Germany', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&', NULL, '<?xml version="1.0" encoding="ISO-8859-1" standalone="no" ?>\n<!DOCTYPE WMT_MS_Capabilities SYSTEM "http://schemas.opengeospatial.net/wms/1.1.1/WMS_MS_Capabilities.dtd"\n [\n <!ELEMENT VendorSpecificCapabilities EMPTY>\n ]> <!-- end of DOCTYPE declaration -->\n\n<WMT_MS_Capabilities version="1.1.1">\n\n<!-- MapServer version 4.4.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE -->\n\n<Service>\n <Name>OGC:WMS</Name>\n <Title>Germany</Title>\n <Abstract>Germany</Abstract>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&"/>\n <AccessConstraints>none</AccessConstraints>\n</Service>\n\n<Capability>\n <Request>\n <GetCapabilities>\n <Format>application/vnd.ogc.wms_xml</Format>\n <DCPType>\n <HTTP>\n <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&"/></Get>\n <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&"/></Post>\n </HTTP>\n </DCPType>\n </GetCapabilities>\n <GetMap>\n <Format>image/png</Format>\n <Format>image/gif</Format>\n <Format>image/png; mode=24bit</Format>\n <Format>image/jpeg</Format>\n <Format>image/wbmp</Format>\n <Format>image/tiff</Format>\n <DCPType>\n <HTTP>\n <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&"/></Get>\n <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&"/></Post>\n </HTTP>\n </DCPType>\n </GetMap>\n <GetFeatureInfo>\n <Format>text/plain</Format>\n <Format>text/html</Format>\n <Format>application/vnd.ogc.gml</Format>\n <DCPType>\n <HTTP>\n <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&"/></Get>\n <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&"/></Post>\n </HTTP>\n </DCPType>\n </GetFeatureInfo>\n <DescribeLayer>\n <Format>text/xml</Format>\n <DCPType>\n <HTTP>\n <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&"/></Get>\n <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&"/></Post>\n </HTTP>\n </DCPType>\n </DescribeLayer>\n <GetLegendGraphic>\n <Format>image/png</Format>\n <Format>image/gif</Format>\n <Format>image/png; mode=24bit</Format>\n <Format>image/jpeg</Format>\n <Format>image/wbmp</Format>\n <DCPType>\n <HTTP>\n <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&"/></Get>\n <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&"/></Post>\n </HTTP>\n </DCPType>\n </GetLegendGraphic>\n </Request>\n <Exception>\n <Format>application/vnd.ogc.se_xml</Format>\n <Format>application/vnd.ogc.se_inimage</Format>\n <Format>application/vnd.ogc.se_blank</Format>\n </Exception>\n <VendorSpecificCapabilities />\n <UserDefinedSymbolization SupportSLD="1" UserLayer="0" UserStyle="1" RemoteWFS="0"/>\n <Layer>\n <Name>Germany</Name>\n <Title>Germany</Title>\n <SRS>epsg:4326 epsg:31467 epsg:31466 epsg:31468 epsg:31469 epsg:31492 epsg:31493 epsg:31494 epsg:31495 epsg:31462 epsg:31463 epsg:31464 epsg:31465 epsg:25832 epsg:25833 epsg:31287 epsg:32633</SRS>\n <LatLonBoundingBox minx="5.60075" miny="47.2441" maxx="15.425" maxy="55.0317" />\n <BoundingBox SRS="EPSG:31467"\n minx="3.28245e+06" miny="5.24826e+06" maxx="3.91224e+06" maxy="6.10013e+06" />\n <ScaleHint min="0.000498903" max="4.98903e+13" />\n <Layer queryable="0" opaque="0" cascaded="0">\n <Name>Topographie</Name>\n <Title>topography</Title>\n <SRS>epsg:4326</SRS>\n <LatLonBoundingBox minx="5.86563" miny="47.2758" maxx="15" maxy="55.0556" />\n <BoundingBox SRS="EPSG:4326"\n minx="5.86563" miny="47.2758" maxx="15" maxy="55.0556" />\n <DataURL>\n <Format>text/html</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://www.ccgis.de"/>\n </DataURL>\n <Style>\n <Name>default</Name>\n <Title>default</Title>\n <LegendURL width="20" height="10">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Topographie&format=image/png"/>\n </LegendURL>\n </Style>\n </Layer>\n <Layer queryable="0" opaque="0" cascaded="0">\n <Name>Grenze</Name>\n <Title>border</Title>\n <SRS>epsg:4326</SRS>\n <LatLonBoundingBox minx="5.86563" miny="47.2758" maxx="15" maxy="55.0556" />\n <BoundingBox SRS="EPSG:4326"\n minx="5.86563" miny="47.2758" maxx="15" maxy="55.0556" />\n <Style>\n <Name>default</Name>\n <Title>default</Title>\n <LegendURL width="20" height="10">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Grenze&format=image/png"/>\n </LegendURL>\n </Style>\n <ScaleHint min="374.177" max="4.98903e+13" />\n </Layer>\n <Layer queryable="0" opaque="0" cascaded="0">\n <Name>Bundeslaender</Name>\n <Title>federal states</Title>\n <SRS>epsg:4326</SRS>\n <LatLonBoundingBox minx="5.86417" miny="47.2747" maxx="15.0389" maxy="55.0567" />\n <BoundingBox SRS="EPSG:4326"\n minx="5.86417" miny="47.2747" maxx="15.0389" maxy="55.0567" />\n <Style>\n <Name>default</Name>\n <Title>default</Title>\n <LegendURL width="20" height="10">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Bundeslaender&format=image/png"/>\n </LegendURL>\n </Style>\n <ScaleHint min="374.177" max="449013" />\n </Layer>\n <Layer queryable="0" opaque="0" cascaded="0">\n <Name>Staedte</Name>\n <Title>places</Title>\n <SRS>epsg:4326</SRS>\n <LatLonBoundingBox minx="6.05223" miny="47.4825" maxx="14.9981" maxy="54.9405" />\n <BoundingBox SRS="EPSG:4326"\n minx="6.05223" miny="47.4825" maxx="14.9981" maxy="54.9405" />\n <Style>\n <Name>default</Name>\n <Title>default</Title>\n <LegendURL width="20" height="10">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Staedte&format=image/png"/>\n </LegendURL>\n </Style>\n <ScaleHint min="0" max="4490.13" />\n </Layer>\n <Layer queryable="1" opaque="0" cascaded="0">\n <Name>Postleitzahlbereiche</Name>\n <Title>postcode areas</Title>\n <SRS>epsg:4326</SRS>\n <LatLonBoundingBox minx="5.86629" miny="47.2736" maxx="15.0486" maxy="55.0583" />\n <BoundingBox SRS="EPSG:4326"\n minx="5.86629" miny="47.2736" maxx="15.0486" maxy="55.0583" />\n <Style>\n <Name>default</Name>\n <Title>default</Title>\n <LegendURL width="20" height="10">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Postleitzahlbereiche&format=image/png"/>\n </LegendURL>\n </Style>\n </Layer>\n <Layer queryable="0" opaque="0" cascaded="0">\n <Name>Bahnlinien</Name>\n <Title>railroad lines</Title>\n <SRS>epsg:4326</SRS>\n <LatLonBoundingBox minx="5.98259" miny="47.4064" maxx="15" maxy="54.9045" />\n <BoundingBox SRS="EPSG:4326"\n minx="5.98259" miny="47.4064" maxx="15" maxy="54.9045" />\n <Style>\n <Name>default</Name>\n <Title>default</Title>\n <LegendURL width="20" height="10">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Bahnlinien&format=image/png"/>\n </LegendURL>\n </Style>\n </Layer>\n <Layer queryable="0" opaque="0" cascaded="0">\n <Name>Fluesse</Name>\n <Title>rivers</Title>\n <SRS>epsg:4326</SRS>\n <LatLonBoundingBox minx="5.95192" miny="47.2864" maxx="14.9759" maxy="54.9107" />\n <BoundingBox SRS="EPSG:4326"\n minx="5.95192" miny="47.2864" maxx="14.9759" maxy="54.9107" />\n <Style>\n <Name>default</Name>\n <Title>default</Title>\n <LegendURL width="20" height="10">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Fluesse&format=image/png"/>\n </LegendURL>\n </Style>\n <ScaleHint min="0" max="623.629" />\n </Layer>\n <Layer queryable="0" opaque="0" cascaded="0">\n <Name>Strassen</Name>\n <Title>roads</Title>\n <SRS>epsg:4326</SRS>\n <LatLonBoundingBox minx="5.90508" miny="47.3136" maxx="14.9981" maxy="55.0157" />\n <BoundingBox SRS="EPSG:4326"\n minx="5.90508" miny="47.3136" maxx="14.9981" maxy="55.0157" />\n <Style>\n <Name>default</Name>\n <Title>default</Title>\n <LegendURL width="20" height="10">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Strassen&format=image/png"/>\n </LegendURL>\n </Style>\n </Layer>\n <Layer queryable="1" opaque="0" cascaded="0">\n <Name>Staedtepunkte</Name>\n <Title>places as point</Title>\n <SRS>epsg:4326</SRS>\n <LatLonBoundingBox minx="6.01667" miny="47.4" maxx="15" maxy="54.9" />\n <BoundingBox SRS="EPSG:4326"\n minx="6.01667" miny="47.4" maxx="15" maxy="54.9" />\n <Style>\n <Name>default</Name>\n <Title>default</Title>\n <LegendURL width="20" height="10">\n <Format>image/png</Format>\n <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Staedtepunkte&format=image/png"/>\n </LegendURL>\n </Style>\n </Layer>\n <Layer queryable="0" opaque="0" cascaded="0">\n <Name>Postleitzahlbereichname</Name>\n <Title>postcode areas (names)</Title>\n <SRS>epsg:4326</SRS>\n <LatLonBoundingBox minx="5.86629" miny="47.2736" maxx="15.0486" maxy="55.0583" />\n <BoundingBox SRS="EPSG:4326"\n minx="5.86629" miny="47.2736" maxx="15.0486" maxy="55.0583" />\n <ScaleHint min="0" max="174.616" />\n </Layer>\n <Layer queryable="0" opaque="0" cascaded="0">\n <Name>Staedtenamen</Name>\n <Title>places (names)</Title>\n <SRS>epsg:4326</SRS>\n <LatLonBoundingBox minx="6.01667" miny="47.4" maxx="15" maxy="54.9" />\n <BoundingBox SRS="EPSG:4326"\n minx="6.01667" miny="47.4" maxx="15" maxy="54.9" />\n </Layer>\n <Layer queryable="0" opaque="0" cascaded="0">\n <Name>Bundeslaendernamen</Name>\n <Title>federal states (names)</Title>\n <SRS>epsg:4326</SRS>\n <LatLonBoundingBox minx="5.86417" miny="47.2747" maxx="15.0389" maxy="55.0567" />\n <BoundingBox SRS="EPSG:4326"\n minx="5.86417" miny="47.2747" maxx="15.0389" maxy="55.0567" />\n <ScaleHint min="498.903" max="39912.2" />\n </Layer>\n </Layer>\n</Capability>\n</WMT_MS_Capabilities>\n');
+-- Daten für Tabelle `wms_format`
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (86, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (86, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (86, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (86, 'map', 'image/wbmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (86, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (86, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (86, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (86, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (86, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (86, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (86, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (101, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (101, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (101, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (101, 'map', 'image/wbmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (101, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (101, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (101, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (101, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (101, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (101, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (101, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (250, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (250, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (250, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (250, 'map', 'image/bmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (250, 'map', 'image/swf');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (250, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (250, 'featureinfo', 'text/swf');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (250, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (250, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (250, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (250, 'exception', 'text/xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (250, 'exception', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (328, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (328, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (328, 'map', 'image/tif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (328, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (328, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (328, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (328, 'exception', 'text/vnd.wap.wml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (328, 'exception', 'application/msword');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (328, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (328, 'exception', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (328, 'exception', 'application/vnd.ms-excel');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (328, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (329, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (329, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (329, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (329, 'map', 'image/wbmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (329, 'map', 'application/x-shockwave-flash');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (329, 'map', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (329, 'map', 'application/x-pdf');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (329, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (329, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (329, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (329, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (329, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (329, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (329, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (336, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (336, 'map', 'image/bmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (336, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (336, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (336, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (336, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (336, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (486, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (486, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (486, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (486, 'map', 'image/wbmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (486, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (486, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (486, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (486, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (486, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (486, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (486, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (525, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (525, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (525, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (525, 'map', 'image/wbmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (525, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (525, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (525, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (525, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (525, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (525, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (525, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (583, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (583, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (583, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (583, 'map', 'image/wbmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (583, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (583, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (583, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (583, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (583, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (583, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (584, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (584, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (584, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (584, 'map', 'image/wbmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (584, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (584, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (584, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (584, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (584, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (584, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (584, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (612, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (612, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (612, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (612, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (612, 'map', 'image/ppm');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (612, 'map', 'application/x-cubestor-wkb');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (612, 'map', 'application/x-cubestor-gml.1');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (612, 'map', 'application/x-cubestor-gml.2');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (612, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (612, 'featureinfo', 'application/x-cubestor-gml.1');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (612, 'featureinfo', 'application/x-cubestor-any');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (612, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (612, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (612, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (612, 'exception', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (612, 'exception', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (613, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (613, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (613, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (613, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (613, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (613, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (613, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (613, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (614, 'map', 'JPEG');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (614, 'map', 'GIF');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (614, 'map', 'PNG');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (614, 'featureinfo', 'ARCXML');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (614, 'featureinfo', 'MIME');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (614, 'exception', 'BLANK');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (614, 'exception', 'INIMAGE');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (614, 'exception', 'WMS_XML');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (615, 'map', 'JPEG');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (615, 'map', 'GIF');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (615, 'map', 'PNG');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (615, 'featureinfo', 'ARCXML');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (615, 'featureinfo', 'MIME');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (615, 'exception', 'BLANK');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (615, 'exception', 'INIMAGE');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (615, 'exception', 'WMS_XML');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (616, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (616, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (616, 'featureinfo', 'text/xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (616, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (616, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (616, 'featureinfo', 'application/vnd.esri.xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (616, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (617, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (617, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (617, 'featureinfo', 'text/xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (617, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (617, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (617, 'featureinfo', 'application/vnd.esri.xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (617, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (624, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (624, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (624, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (624, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (624, 'featureinfo', 'text/xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (624, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (624, 'featureinfo', 'application/vnd.esri.xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (624, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (625, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (625, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (625, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (625, 'map', 'image/wbmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (625, 'map', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (625, 'map', 'application/x-pdf');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (625, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (625, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (625, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (625, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (625, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (625, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (625, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (634, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (634, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (634, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (634, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (634, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (634, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (634, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (634, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (634, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (637, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (637, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (637, 'map', 'image/wbmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (637, 'map', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (637, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (637, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (637, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (637, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (637, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (637, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (637, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (640, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (640, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (640, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (645, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (645, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (645, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (645, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (645, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (645, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (648, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (648, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (648, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (648, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (648, 'featureinfo', 'text/xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (648, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (648, 'featureinfo', 'application/vnd.esri.xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (648, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (655, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (655, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (655, 'map', 'image/wbmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (655, 'map', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (655, 'map', 'application/x-pdf');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (655, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (655, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (655, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (655, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (655, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (655, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (655, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (670, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (670, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (670, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (670, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (670, 'featureinfo', 'text/xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (670, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (670, 'featureinfo', 'application/vnd.esri.xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (670, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (671, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (671, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (671, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (671, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (671, 'featureinfo', 'text/xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (671, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (671, 'featureinfo', 'application/vnd.esri.xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (671, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (706, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (706, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (706, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (706, 'featureinfo', 'application/vnd.ogc.wms_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (706, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (706, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (706, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (706, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (706, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (717, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (717, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (717, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (717, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (717, 'featureinfo', 'text/xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (717, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (717, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (739, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (739, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (739, 'featureinfo', 'application/vnd.ogc.wms_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (739, 'featureinfo', 'text/xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (739, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (739, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (739, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (739, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (739, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (758, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (758, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (758, 'map', 'image/wbmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (758, 'map', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (758, 'map', 'application/x-pdf');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (758, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (758, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (758, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (758, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (758, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (758, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (758, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (760, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (760, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (760, 'map', 'image/wbmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (760, 'map', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (760, 'map', 'application/x-pdf');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (760, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (760, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (760, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (760, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (760, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (760, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (760, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (762, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (762, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (762, 'map', 'image/wbmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (762, 'map', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (762, 'map', 'application/x-pdf');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (762, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (762, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (762, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (762, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (762, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (762, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (762, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (764, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (764, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (764, 'map', 'image/wbmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (764, 'map', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (764, 'map', 'application/x-pdf');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (764, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (764, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (764, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (764, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (764, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (764, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (764, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (765, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (765, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (765, 'map', 'image/wbmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (765, 'map', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (765, 'map', 'application/x-pdf');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (765, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (765, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (765, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (765, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (765, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (765, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (765, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (767, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (767, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (767, 'map', 'image/png; mode=24bit');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (767, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (767, 'map', 'image/wbmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (767, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (767, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (767, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (767, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (767, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (767, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (767, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (776, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (776, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (776, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (776, 'map', 'image/wbmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (776, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (776, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (776, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (776, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (776, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (776, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (776, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (777, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (777, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (777, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (777, 'map', 'image/wbmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (777, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (777, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (777, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (777, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (777, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (777, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (777, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (778, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (778, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (778, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (778, 'map', 'image/wbmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (778, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (778, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (778, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (778, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (778, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (778, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (778, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (779, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (779, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (779, 'map', 'image/wbmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (779, 'map', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (779, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (779, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (779, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (779, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (779, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (779, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (779, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (785, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (785, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (785, 'featureinfo', 'application/vnd.ogc.wms_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (785, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (785, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (785, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (785, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (785, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (786, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (786, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (786, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (786, 'map', 'image/png; mode=24bit');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (786, 'map', 'image/wbmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (786, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (786, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (786, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (786, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (786, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (786, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (787, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (787, 'map', 'image/jpg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (787, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (787, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (787, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (787, 'exception', 'text/xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (788, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (788, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (788, 'map', 'image/wbmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (788, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (788, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (788, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (788, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (788, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (788, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (789, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (789, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (789, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (789, 'map', 'image/wbmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (789, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (789, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (790, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (790, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (790, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (792, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (792, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (792, 'map', 'image/tif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (792, 'map', 'image/svg+xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (792, 'map', 'image/bmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (792, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (792, 'map', 'image/jpg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (792, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (792, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (792, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (792, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (792, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (792, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (793, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (793, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (793, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (793, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (793, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (793, 'exception', 'text/xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (794, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (794, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (794, 'map', 'image/wbmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (794, 'map', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (794, 'map', 'application/x-pdf');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (794, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (794, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (794, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (794, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (794, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (794, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (794, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (796, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (796, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (796, 'map', 'image/tif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (796, 'map', 'image/svg+xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (796, 'map', 'image/bmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (796, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (796, 'map', 'image/jpg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (796, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (796, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (796, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (796, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (796, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (796, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (797, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (797, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (797, 'map', 'image/wbmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (797, 'map', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (797, 'map', 'application/x-pdf');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (797, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (797, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (797, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (797, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (797, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (797, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (797, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (798, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (798, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (798, 'map', 'image/wbmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (798, 'map', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (798, 'map', 'application/x-pdf');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (798, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (798, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (798, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (798, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (798, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (798, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (798, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (799, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (799, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (799, 'map', 'image/wbmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (799, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (799, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (799, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (799, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (799, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (799, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (800, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (800, 'featureinfo', 'application/vnd.ogc.wms_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (800, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (800, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (800, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (800, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (800, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (824, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (824, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (824, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (827, 'map', 'JPEG');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (827, 'map', 'PNG');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (827, 'exception', 'WMS_XML');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (827, 'exception', 'INIMAGE');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (827, 'exception', 'BLANK');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (828, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (828, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (828, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (828, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (828, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (829, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (829, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (829, 'featureinfo', 'application/vnd.ogc.wms_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (829, 'featureinfo', 'text/xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (829, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (829, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (829, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (829, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (829, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (831, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (831, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (831, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (831, 'map', 'image/wbmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (831, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (831, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (831, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (831, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (831, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (831, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (832, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (832, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (832, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (832, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (832, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (832, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (832, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (832, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (832, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (833, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (833, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (833, 'featureinfo', 'text/xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (833, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (833, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (833, 'featureinfo', 'application/vnd.esri.xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (833, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (834, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (834, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (834, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (834, 'featureinfo', 'application/vnd.ogc.wms_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (834, 'featureinfo', 'text/xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (834, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (834, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (834, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (834, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (834, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (835, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (835, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (835, 'map', 'image/png; mode=24bit');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (835, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (835, 'map', 'image/wbmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (835, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (835, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (835, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (835, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (835, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (835, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (835, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (836, 'map', 'image/jpg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (836, 'map', 'image/png8');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (836, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (836, 'map', 'image/png24');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (836, 'featureinfo', 'application/vnd.ogc.wms_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (836, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (836, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (836, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (836, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (836, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (837, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (837, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (837, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (837, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (837, 'exception', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (840, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (840, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (840, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (840, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (840, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (840, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (841, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (841, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (841, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (841, 'map', 'image/wbmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (841, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (841, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (841, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (841, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (841, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (841, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (842, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (842, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (842, 'map', 'image/png; mode=24bit');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (842, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (842, 'map', 'image/wbmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (842, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (842, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (842, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (842, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (842, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (842, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (842, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (843, 'map', 'JPEG');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (843, 'map', 'GIF');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (843, 'map', 'PNG');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (843, 'featureinfo', 'ARCXML');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (843, 'featureinfo', 'MIME');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (843, 'exception', 'BLANK');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (843, 'exception', 'INIMAGE');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (843, 'exception', 'WMS_XML');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (844, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (844, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (844, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (844, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (844, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (844, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (844, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (844, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (407, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (407, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (407, 'map', 'image/png; mode=24bit');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (407, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (407, 'map', 'image/wbmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (407, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (407, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (407, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (407, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (407, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (407, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (407, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (854, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (854, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (854, 'map', 'image/png; mode=24bit');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (854, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (854, 'map', 'image/wbmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (854, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (854, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (854, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (854, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (854, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (854, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (855, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (855, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (855, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (855, 'map', 'image/bmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (855, 'map', 'image/swf');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (855, 'featureinfo', 'text/xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (855, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (855, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (855, 'featureinfo', 'text/swf');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (855, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (855, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (855, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (855, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (855, 'exception', 'text/xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (855, 'exception', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (859, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (859, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (859, 'featureinfo', 'application/vnd.ogc.wms_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (859, 'featureinfo', 'text/xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (859, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (859, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (859, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (859, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (859, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (860, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (860, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (860, 'map', 'image/bmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (860, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (860, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (860, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (860, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (860, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (861, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (861, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (861, 'map', 'image/bmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (861, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (861, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (861, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (861, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (861, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (862, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (862, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (862, 'map', 'image/bmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (862, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (862, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (862, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (862, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (862, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (863, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (863, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (863, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (863, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (863, 'featureinfo', 'text/xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (863, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (863, 'featureinfo', 'application/vnd.esri.xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (863, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (864, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (864, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (864, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (864, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (864, 'featureinfo', 'text/xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (864, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (864, 'featureinfo', 'application/vnd.esri.xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (864, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (866, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (866, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (866, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (866, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (866, 'featureinfo', 'text/xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (866, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (866, 'featureinfo', 'application/vnd.esri.xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (866, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (867, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (867, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (867, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (867, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (867, 'featureinfo', 'text/xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (867, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (867, 'featureinfo', 'application/vnd.esri.xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (867, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (868, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (868, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (868, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (868, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (868, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (869, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (869, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (869, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (869, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (869, 'featureinfo', 'text/xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (869, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (869, 'featureinfo', 'application/vnd.esri.xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (869, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (870, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (870, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (870, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (870, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (870, 'featureinfo', 'text/xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (870, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (870, 'featureinfo', 'application/vnd.esri.xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (870, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (871, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (871, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (871, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (871, 'map', 'image/wbmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (871, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (871, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (871, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (871, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (871, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (871, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (872, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (872, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (872, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (872, 'featureinfo', 'application/vnd.ogc.wms_xml');
