svn commit: r87 - trunk/mapbender/http/javascripts/mod_addWMSfromfilteredList.php
arnulf at osgeo.org
arnulf at osgeo.org
Wed Apr 19 04:23:50 EDT 2006
Author: arnulf
Date: 2006-04-19 08:23:49+0000
New Revision: 87
trunk/mapbender/http/javascripts/mod_addWMSfromfilteredList.php (contents, props changed)
code cleaning in progress
Modified: trunk/mapbender/http/javascripts/mod_addWMSfromfilteredList.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_addWMSfromfilteredList.php?view=diff&rev=87&p1=trunk/mapbender/http/javascripts/mod_addWMSfromfilteredList.php&p2=trunk/mapbender/http/javascripts/mod_addWMSfromfilteredList.php&r1=86&r2=87
--- trunk/mapbender/http/javascripts/mod_addWMSfromfilteredList.php (original)
+++ trunk/mapbender/http/javascripts/mod_addWMSfromfilteredList.php 2006-04-19 08:23:49+0000
@@ -1,6 +1,5 @@
<?php
-#$Id: mod_addWMSfromfilteredList.php,v 1.14 2006/03/10 12:53:25 astrid_emde Exp $
-#$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_addWMSfromfilteredList.php,v 1.14 2006/03/10 12:53:25 astrid_emde Exp $
+# $Id$
# Copyright (C) 2002 CCGIS
# This program is free software; you can redistribute it and/or modify
@@ -34,48 +33,31 @@
<link rel="stylesheet" type="text/css" href="../css/administration_alloc.css">
<STYLE TYPE="text/css">
- body{
- font-family:Verdana, Geneva, Arial, Helvetica, sans-serif;
- font-size:10pt
+ body{
+ font-family:Verdana, Geneva, Arial, Helvetica, sans-serif;
+ font-size:10pt
- table{
- font-size:11;
+ table{
+ font-size:11;
.wms_button{
- color: black;
- border: solid thin;
- height:22px;
- width:60px;
+ color: black;
+ border: solid thin;
+ height:22px;
+ width:60px;
</STYLE>
<script type="text/javascript">
<?php
-#$con = db_connect($DBSERVER,$OWNER,$PW);
-#db_select_db(DB,$con);
-#$sql = "SELECT e_requires, e_target FROM gui_element WHERE e_id = 'addWMSfromfilteredList' AND fkey_gui_id = '".$gui_id."'";
-#echo "var sql_x = ".$sql.";";
-#$res = db_query($sql);
-#$cnt = 0;
-#while($row = db_fetch_array($res)){
-# $e_target = $row["e_target"];
-# $e_require = $row["e_requires"];
-# $cnt++;
-#if($cnt > 1){ echo "alert('addWMSfromfilteredList: ID not unique!');";}
-#echo "var mod_addWMSfromfilteredList_data = 'loadData';";
-#$target = explode(",", $e_target);
-#echo "var mod_addWMSfromfilteredList_target1 = 'treeGDE';";
-#echo "var mod_addWMSfromfilteredList_target2 = 'mapframe1';";
/*get infos from gui_element ********************************************************************************************/
@@ -84,9 +66,9 @@
$res_target = db_query($sql_target);
$cnt_target = 0;
while($row = db_fetch_array($res_target)){
- $e_target = $row["e_target"];
- $e_require = $row["e_requires"];
- $cnt_target++;
+ $e_target = $row["e_target"];
+ $e_require = $row["e_requires"];
+ $cnt_target++;
if($cnt_target > 1){ echo "alert('addWMS: ID not unique!');";}
echo "<script language='Javascript'>";
@@ -99,66 +81,48 @@
-function mod_addWMSfromfilteredList(pointer_name,version)
- //alert(pointer_name);
- //alert(version);
- var mywms = pointer_name;
- if(mywms.indexOf("?") > -1){pointer_name += "&";}
- if(mywms.indexOf("?") == -1){pointer_name += "?";}
+function mod_addWMSfromfilteredList(pointer_name,version){
+ var mywms = pointer_name;
+ if(mywms.indexOf("?") > -1){pointer_name += "&";}
+ if(mywms.indexOf("?") == -1){pointer_name += "?";}
- if (version == '1.0.0')
- var cap = pointer_name + "REQUEST=capabilities&WMTVER=1.0.0";
- var load = cap;
- else if (version == '1.1.0')
- var cap = pointer_name + "REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.0";
- var load = cap;
- else if (version == '1.1.1')
- var cap = pointer_name + "REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1";
- var load = cap;
- if(load)
- // if the mapfile WMS ONLINE RESOURCE is set relative, without any host
-// if(rest.charAt(0) == '/' && rest.charAt(1) == 'c')
- if(load.charAt(0) == '/' && load.charAt(1) == 'c')
- window.opener.mod_addWMS_load('http://localhost' + load);
- else
- window.opener.mod_addWMS_load(load);
+ if (version == '1.0.0'){
+ var cap = pointer_name + "REQUEST=capabilities&WMTVER=1.0.0";
+ var load = cap;
+ else if (version == '1.1.0'){
+ var cap = pointer_name + "REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.0";
+ var load = cap;
+ else if (version == '1.1.1'){
+ var cap = pointer_name + "REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1";
+ var load = cap;
+ if(load){
+ if(load.charAt(0) == '/' && load.charAt(1) == 'c'){
+ window.opener.mod_addWMS_load('http://localhost' + load);
+ else{
+ window.opener.mod_addWMS_load(load);
+function mod_show_group_wms(wert){
+ document.form1.show_group_wms.value = wert;
+ document.form1.submit();
-function mod_show_group_wms(wert)
- document.form1.show_group_wms.value = wert;
- document.form1.submit();
-function mod_show_gui_wms(wert2)
- document.form1.show_gui_wms.value = wert2;
+function mod_show_gui_wms(wert2){
+ document.form1.show_gui_wms.value = wert2;
-function mod_show_wms(wert3)
- document.form1.wms_show.value = wert3;
+function mod_show_wms(wert3){
+ document.form1.wms_show.value = wert3;
</script>
@@ -173,9 +137,7 @@
require_once("../classes/class_wms.php");
require_once("../php/mb_getGUIs.php");
$fieldHeight = 20;
$cnt_gui = 0;
$cnt_gui_wms = 0;
$cnt_wms = 0;
@@ -188,49 +150,45 @@
$cnt_show_gui_wms = 0;
$cnt_group_name = 0;
$cnt_gui_table = 0;
$exists = false;
$logged_user_name=$_SESSION["mb_user_name"];
$logged_user_id=$_SESSION["mb_user_id"];
$logged_gui_id=$_SESSION["mb_user_gui"];
###### SQL #####################################################################################
/*get group from logged user ********************************************************************************************/
-$sql_user_group = "SELECT * FROM mb_user_mb_group WHERE fkey_mb_user_id='".$logged_user_id."'";
-$res_user_group = db_query($sql_user_group);
- while($row = db_fetch_array($res_user_group)){
- $user_id[$cnt_user_group] = $row["fkey_mb_user_id"];
- $group_id[$cnt_user_group] = $row["fkey_mb_group_id"];
- $cnt_user_group++;
+$sql_user_group = "SELECT * FROM mb_user_mb_group WHERE fkey_mb_user_id= $1 ";
+$array_values = array($logged_user_id);
+$array_types = array('s');
+$res_user_group = db_prep_query($sql_user_group, $array_values, $array_types);
+while($row = db_fetch_array($res_user_group)){
+ $user_id[$cnt_user_group] = $row["fkey_mb_user_id"];
+ $group_id[$cnt_user_group] = $row["fkey_mb_group_id"];
+ $cnt_user_group++;
+# recheck
/*get group name ********************************************************************************************/
-if(count($group_id) > 0)
+if(count($group_id) > 0){
$sql_group = "SELECT mb_group_id, mb_group_name, mb_group_description FROM mb_group WHERE mb_group_id IN (";
for($i=0; $i < count($group_id); $i++){
- if($i>0){ $sql_group .= ",";}
- $sql_group .= "'".$group_id[$i]."'";
+ if($i>0){ $sql_group .= ",";}
+ $sql_group .= "'".$group_id[$i]."'";
$sql_group.= ") ORDER BY mb_group_name";
$res_group = db_query($sql_group);
while($row = db_fetch_array($res_group)){
- $mb_group_description[$cnt_group] = $row["mb_group_description"];
+ $mb_group_description[$cnt_group] = $row["mb_group_description"];
$my_group_name[$cnt_group] = $row["mb_group_name"];
$my_group_id[$cnt_group] = $row["mb_group_id"];
- $cnt_group++;
+ $cnt_group++;
-/*get goup name ********************************************************************************************/
+/*get group name ********************************************************************************************/
/*get allocated gui ********************************************************************************************/
More information about the Mapbender_commits
