svn commit: r89 - trunk/mapbender/http/javascripts/mod_addWMS.php
arnulf at osgeo.org
arnulf at osgeo.org
Wed Apr 19 07:48:31 EDT 2006
Author: arnulf
Date: 2006-04-19 11:48:30+0000
New Revision: 89
trunk/mapbender/http/javascripts/mod_addWMS.php (contents, props changed)
code cleaned, added prepared statements
Modified: trunk/mapbender/http/javascripts/mod_addWMS.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_addWMS.php?view=diff&rev=89&p1=trunk/mapbender/http/javascripts/mod_addWMS.php&p2=trunk/mapbender/http/javascripts/mod_addWMS.php&r1=88&r2=89
--- trunk/mapbender/http/javascripts/mod_addWMS.php (original)
+++ trunk/mapbender/http/javascripts/mod_addWMS.php 2006-04-19 11:48:30+0000
@@ -1,6 +1,6 @@
<?php
-#$Id: mod_addWMS.php,v 1.8 2005/09/13 18:16:42 bjoern_heuser Exp $
-#$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_addWMS.php,v 1.8 2005/09/13 18:16:42 bjoern_heuser Exp $
+# $Id$
+# http://www.mapbender.org/index.php/AddWMS
# Copyright (C) 2002 CCGIS
# This program is free software; you can redistribute it and/or modify
@@ -17,18 +17,19 @@
# along with this program; if not, write to the Free Software
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
$gui_id = $_REQUEST["gui_id"];
require_once("../../conf/mapbender.conf");
$con = db_connect($DBSERVER,$OWNER,$PW);
db_select_db(DB,$con);
-$sql = "SELECT e_requires, e_target FROM gui_element WHERE e_id = 'addWMS' AND fkey_gui_id = '".$gui_id."'";
-$res = db_query($sql);
+$sql = "SELECT e_requires, e_target FROM gui_element WHERE e_id = 'addWMS' AND fkey_gui_id = $1 ";
+$v = array($gui_id);
+$t = array("s");
+$res = db_prep_query($sql, $v, $t);
$cnt = 0;
-while($row = db_fetch_array($res)){
- $e_target = $row["e_target"];
- $e_require = $row["e_requires"];
- $cnt++;
+while($row = db_fetch_array($res)){
+ $e_target = $row["e_target"];
+ $e_require = $row["e_requires"];
+ $cnt++;
if($cnt > 1){ echo "alert('addWMS: ID not unique!');";}
echo "var mod_addWMS_data = '".$e_require."';";
@@ -38,16 +39,16 @@
function mod_addWMS(){
- var load = prompt("Capabilities - URL:","");
- if(load){
- mod_addWMS_load(load);
+ var load = prompt("Capabilities - URL:","");
+ if(load){
+ mod_addWMS_load(load);
function mod_addWMS_load(caps){
- window.frames[mod_addWMS_data].document.location.href = "../php/mod_createJSObjFromXML.php?caps=" + escape(caps);
+ window.frames[mod_addWMS_data].document.location.href = "../php/mod_createJSObjFromXML.php?caps=" + escape(caps);
function mod_addWMS_refresh(){
- mb_mapObjaddWMS(mod_addWMS_target2);
- window.frames[mod_addWMS_target1].document.location.reload();
- zoom(mod_addWMS_target2, true, 1.0); // div-tags have to be created
+ mb_mapObjaddWMS(mod_addWMS_target2);
+ window.frames[mod_addWMS_target1].document.location.reload();
+ zoom(mod_addWMS_target2, true, 1.0);
\ No newline at end of file
More information about the Mapbender_commits
