svn commit: r115 - trunk/mapbender/http/javascripts/mod_dependentIframe.php
arnulf at osgeo.org
arnulf at osgeo.org
Wed Apr 19 19:09:51 EDT 2006
Author: arnulf
Date: 2006-04-19 23:09:51+0000
New Revision: 115
trunk/mapbender/http/javascripts/mod_dependentIframe.php (contents, props changed)
cleaned the code, added the prepared statements, bored to death
Modified: trunk/mapbender/http/javascripts/mod_dependentIframe.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_dependentIframe.php?view=diff&rev=115&p1=trunk/mapbender/http/javascripts/mod_dependentIframe.php&p2=trunk/mapbender/http/javascripts/mod_dependentIframe.php&r1=114&r2=115
--- trunk/mapbender/http/javascripts/mod_dependentIframe.php (original)
+++ trunk/mapbender/http/javascripts/mod_dependentIframe.php 2006-04-19 23:09:51+0000
@@ -1,6 +1,6 @@
<?php
-#$Id: mod_dependentIframe.php,v 1.8 2005/09/13 18:16:42 bjoern_heuser Exp $
-#$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_dependentIframe.php,v 1.8 2005/09/13 18:16:42 bjoern_heuser Exp $
+# $Id$
+# http://www.mapbender.org/index.php/Special:Search?search=mod_dependentIframe.php
# Copyright (C) 2002 CCGIS
# This program is free software; you can redistribute it and/or modify
@@ -21,8 +21,10 @@
require_once("../../conf/mapbender.conf");
$con = db_connect($DBSERVER,$OWNER,$PW);
db_select_db(DB,$con);
-$sql = "SELECT e_target FROM gui_element WHERE e_id = 'dependentIframe' AND fkey_gui_id = '".$gui_id."'";
-$res = db_query($sql);
+$sql = "SELECT e_target FROM gui_element WHERE e_id = 'dependentIframe' AND fkey_gui_id = $1 ";
+$v = array($gui_id);
+$t = array('s');
+$res = db_prep_query($sql, $v, $t);
$cnt = 0;
while($row = db_fetch_array($res)){
$e_target = $row["e_target"];
More information about the Mapbender_commits
