svn commit: r126 - trunk/mapbender/http/php
arnulf at osgeo.org
arnulf at osgeo.org
Sun Apr 23 05:09:27 EDT 2006
Author: arnulf
Date: 2006-04-23 09:09:27+0000
New Revision: 126
trunk/mapbender/http/php/mod_zoomCoords.php (contents, props changed)
trunk/mapbender/http/php/nestedSets.php (contents, props changed)
code cleaned, SVN headers added
Modified: trunk/mapbender/http/php/mod_zoomCoords.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_zoomCoords.php?view=diff&rev=126&p1=trunk/mapbender/http/php/mod_zoomCoords.php&p2=trunk/mapbender/http/php/mod_zoomCoords.php&r1=125&r2=126
--- trunk/mapbender/http/php/mod_zoomCoords.php (original)
+++ trunk/mapbender/http/php/mod_zoomCoords.php 2006-04-23 09:09:27+0000
@@ -1,15 +1,29 @@
<?php
-/* version 2.0.0*/
-session_start();
+# $Id$
+# http://www.mapbender.org/index.php/ZoomCoords
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+session_start();
import_request_variables("PG");
require_once("../php/mb_validateSession.php");
require_once("../../conf/mapbender.conf");
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<!-- version 2.0.0 -->
<html>
<head>
<meta http-equiv="cache-control" content="no-cache">
@@ -24,7 +38,6 @@
<style type="text/css">
body{
font-family : Arial, Helvetica, sans-serif;
font-size: 11px;
@@ -77,8 +90,8 @@
$res = db_query($sql);
$cnt = 0;
while($row = db_fetch_array($res)){
- $e_target = $row["e_target"];
- $cnt++;
+ $e_target = $row["e_target"];
+ $cnt++;
echo '<script type="text/javascript">';
@@ -91,57 +104,38 @@
function zoomCoordinate(){
- var coordx = document.form1.X.value;
- var coordy = document.form1.Y.value;
- coordx = coordx.replace(",",".");
- coordy = coordy.replace(",",".");
- var valid = true;
- /* if(parseFloat(coordx) < 5.88 || parseFloat(coordx) > 15){
- alert("Eingabe unzulässig!");
- document.form1.X.select();
- document.form1.X.focus();
- valid = false;
- return false;
- if(parseFloat(coordy) < 46.62 || parseFloat(coordy) > 55.71){
- document.form1.Y.select();
- document.form1.Y.focus();
- valid = false;
- return false;
- setPermanentMarker(coordx,coordy);
- parent.mb_hideHighlight(target[0]);
- parent.mb_hideHighlight(target[1]);
- parent.zoom(target[0],true, 1.0,coordx,coordy);
+ var coordx = document.form1.X.value;
+ var coordy = document.form1.Y.value;
+ coordx = coordx.replace(",",".");
+ coordy = coordy.replace(",",".");
+ var valid = true;
+ setPermanentMarker(coordx,coordy);
+ parent.mb_hideHighlight(target[0]);
+ parent.mb_hideHighlight(target[1]);
+ parent.zoom(target[0],true, 1.0,coordx,coordy);
function highlight(x, y){
- x=x.replace(",",".");
- y=y.replace(",",".");
- document.form1.X.value=x;
- document.form1.Y.value=y;
- if (isNaN(x)==true || isNaN(y)==true){
- else{
- parent.mb_showHighlight(target[0],x,y);
- parent.mb_showHighlight(target[1],x,y);
+ x=x.replace(",",".");
+ y=y.replace(",",".");
+ document.form1.X.value=x;
+ document.form1.Y.value=y;
+ if (isNaN(x)==true || isNaN(y)==true){
+ else{
+ parent.mb_showHighlight(target[0],x,y);
+ parent.mb_showHighlight(target[1],x,y);
function hideHighlight(){
function setPermanentMarker(x,y){
- parent.mod_permanentHighlight_x = parseFloat(x);
- parent.mod_permanentHighlight_y = parseFloat(y);
+ parent.mod_permanentHighlight_x = parseFloat(x);
+ parent.mod_permanentHighlight_y = parseFloat(y);
</script>
@@ -149,16 +143,13 @@
<body bgcolor='#ffffff' onload=''>
<?php
-echo "<form name='form1' action='" . $PHP_SELF . "?".SID."' method='post'>";
-#coordinates
- #deutsche Version
- echo "<span class='labelx'>Länge:</span>";
- echo "<span class='labely'>Breite:</span>";
- echo "<input class='textx' type='text' name='X'>";
- echo "<input class='texty' type='text' name='Y'>";
- echo "<input class='send' type='button' value='ok' onclick='zoomCoordinate();' onmouseover='highlight(document.form1.X.value, document.form1.Y.value)' onmouseout='hideHighlight(document.form1.X.value, document.form1.Y.value)' >";
+# needs intl'!
+ echo "<form name='form1' action='" . $PHP_SELF . "?".SID."' method='post'>";
+ echo "<span class='labelx'>Länge:</span>";
+ echo "<span class='labely'>Breite:</span>";
+ echo "<input class='textx' type='text' name='X'>";
+ echo "<input class='texty' type='text' name='Y'>";
+ echo "<input class='send' type='button' value='ok' onclick='zoomCoordinate();' onmouseover='highlight(document.form1.X.value, document.form1.Y.value)' onmouseout='hideHighlight(document.form1.X.value, document.form1.Y.value)' >";
</form>
</body>
Modified: trunk/mapbender/http/php/nestedSets.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/nestedSets.php?view=diff&rev=126&p1=trunk/mapbender/http/php/nestedSets.php&p2=trunk/mapbender/http/php/nestedSets.php&r1=125&r2=126
--- trunk/mapbender/http/php/nestedSets.php (original)
+++ trunk/mapbender/http/php/nestedSets.php 2006-04-23 09:09:27+0000
@@ -1,6 +1,7 @@
<?php
-# $Id: nestedSets.php,v 1.12 2006/03/09 12:09:29 uli_rothstein Exp $
-# $Header: /cvsroot/mapbender/mapbender/http/php/nestedSets.php,v 1.12 2006/03/09 12:09:29 uli_rothstein Exp $
+# $Id$
+# http://www.mapbender.org/index.php/TreeGde
@@ -15,6 +16,7 @@
session_start();
@@ -37,17 +39,15 @@
- input{
- width: 164px;
- body{
- font-family : Arial, Helvetica, sans-serif;
- font-size: 12px;
+ input{
+ width: 164px;
+ body{
+ font-family : Arial, Helvetica, sans-serif;
+ font-size: 12px;
</style>
</head>
<!-- <link rel='stylesheet' type='text/css' href='administration.css'> -->
@@ -103,7 +103,8 @@
function rmWMS(obj){
if(obj.value == ''){
- document.forms[0].wmsList.selectedIndex = 0;
+ document.forms[0].wmsList.selectedIndex = 0;
</script>
@@ -200,7 +201,7 @@
<br />
<b>Create your own tree for your GUI. Include the element treeconfGDE to see this tree</b><br />
-Detailed infos you will find in the mapbender wiki (<a href='http://www.mapbender.org' target='_blank'>http://www.mapbender.org</a>)<br />
+Find detailed infos in the (<a href='http://www.mapbender.org/index.php/ConfTreeGde' target='_blank'>Mapbender Wiki</a>)<br />
1. Select the GUI you want to create the new tree for <br />
2. Select an element in the folder view<br />
<br />
@@ -237,16 +238,14 @@
echo "<select class='guiList' size='10' name='guiList' class='guiList' onchange='document.forms[0].submit()'>";
echo "<option value=''>GUI ...</option>";
- echo "<option value='".$row["gui_id"]."' ";
- if(isset($guiList) && $guiList == $row["gui_id"]){
- echo "selected";
- echo ">".$row["gui_name"]."</option>";
- $cnt++;
+ echo "<option value='".$row["gui_id"]."' ";
+ if(isset($guiList) && $guiList == $row["gui_id"]){
+ echo "selected";
+ echo ">".$row["gui_name"]."</option>";
+ $cnt++;
echo "</select><br>";
echo "<tr>";
#echo "<td>Beschriftung:</td>";
echo "<td>Labeling:</td>";
@@ -267,7 +266,6 @@
$sql .= "WHERE gui_wms.fkey_gui_id = '" . $guiList . "' ";
$sql .= "ORDER BY wms.wms_title";
$cnt = 0;
echo "<option value='".$row["fkey_wms_id"]."' ";
@@ -282,25 +280,20 @@
else{echo "<option value=''>no gui selected</option>";}
echo"</select>";
echo"</td> </tr><tr>";
#echo"<td>Ordner oder Ebene: </td>";
echo"<td>Folder or Layer: </td>";
echo"<td>";
echo"<select name='layer' onchange='rmWMS(this)'>";
#echo"<option value=''>Ordner</option>";
echo"<option value=''>Folder</option>";
if(isset($wmsList) && $wmsList != ""){
$sql_l = "SELECT gui_layer.fkey_layer_id, layer.layer_name, layer.layer_title FROM gui_layer ";
$sql_l .= "LEFT JOIN layer ON gui_layer.fkey_layer_id = layer.layer_id ";
$sql_l .= "WHERE gui_layer.gui_layer_wms_id = " . $wmsList . " AND layer.layer_parent = '0' AND gui_layer.fkey_gui_id = '".$guiList."'";
$sql_l .= " ORDER BY layer.layer_title";
$res_l = db_query($sql_l);
$cnt = 0;
while($row = db_fetch_array($res_l)){
echo "<option value='".$row["fkey_layer_id"]."###".$row["layer_name"]."'>";
@@ -318,58 +311,54 @@
<td>
<select name='pos'>
<?php
- #echo "<option value='hinter'>hinter</option>";
- echo "<option value='hinter'>behind</option>";
- echo "<option value='in' ";
- if($pos == 'in'){
- echo "selected";
- echo ">in</option>";
- echo"</select> </td> </tr><tr>";
- #echo"<td>Hinter bzw. in Element Nr.:</td>";
- echo"<td>Insert behind or <br>in element with number:</td>";
- echo "<td><input type='text' size='1' name='left' ";
- if($left)
- echo "value='".$left."'";
- echo "></td>";
+ #echo "<option value='hinter'>hinter</option>";
+ echo "<option value='hinter'>behind</option>";
+ echo "<option value='in' ";
+ if($pos == 'in'){
+ echo "selected";
+ echo ">in</option>";
+ echo"</select> </td> </tr><tr>";
+ #echo"<td>Hinter bzw. in Element Nr.:</td>";
+ echo"<td>Insert behind or <br>in element with number:</td>";
+ echo "<td><input type='text' size='1' name='left' ";
+ if($left)
+ echo "value='".$left."'";
+ echo "></td>";
</tr>
<tr>
- <td>
- <!--<input class='abutton' type='button' name="insert" value='einfügen' onclick="validate('insert')"></td>
- <input class='abutton' type='button' name="insert" value='create new element' onclick="validate('insert')"></td>
- <td></td>
+ <td>
+ <!--<input class='abutton' type='button' name="insert" value='einfügen' onclick="validate('insert')"></td>
+ <input class='abutton' type='button' name="insert" value='create new element' onclick="validate('insert')"></td>
+ <td></td>
</tr>
<tr>
- <td>
- <input class='abutton' type='button' name="delete" value='löschen' onclick="validate('delete')"></td>
- <input class='abutton' type='button' name="delete" value='delete element' onclick="validate('delete')"></td>
+ <td>
+ <input class='abutton' type='button' name="delete" value='löschen' onclick="validate('delete')"></td>
+ <input class='abutton' type='button' name="delete" value='delete element' onclick="validate('delete')"></td>
<td></td>
</tr>
<tr>
- <td>
- <input class='abutton' type='button' name="update" value='&amlndern' onclick="validate('update')"></td>
- <input class='abutton' type='button' name="update" value='change element' onclick="validate('update')"></td>
- <td></td>
+ <td>
+ <input class='abutton' type='button' name="update" value='&amlndern' onclick="validate('update')"></td>
+ <input class='abutton' type='button' name="update" value='change element' onclick="validate('update')"></td>
+ <td></td>
</tr>
<tr>
- <td>
- <input class='abutton' type='button' name="update" value='Ebene verbinden' onclick="validate('add')"></td>
- <input class='abutton' type='button' name="update" value='join layer' onclick="validate('add')"></td>
- <td></td>
+ <td>
+ <input class='abutton' type='button' name="update" value='Ebene verbinden' onclick="validate('add')"></td>
+ <input class='abutton' type='button' name="update" value='join layer' onclick="validate('add')"></td>
+ <td></td>
</tr>
<input type='hidden' name="action">
</table>
More information about the Mapbender_commits
