svn commit: r128 - trunk/mapbender/http/php
arnulf at osgeo.org
arnulf at osgeo.org
Sun Apr 23 05:41:41 EDT 2006
Author: arnulf
Date: 2006-04-23 09:41:40+0000
New Revision: 128
trunk/mapbender/http/php/mb_getGUIs.php
trunk/mapbender/http/php/mb_listGUIs.php (contents, props changed)
cleaned, added SVN headers
Modified: trunk/mapbender/http/php/mb_getGUIs.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mb_getGUIs.php?view=diff&rev=128&p1=trunk/mapbender/http/php/mb_getGUIs.php&p2=trunk/mapbender/http/php/mb_getGUIs.php&r1=127&r2=128
--- trunk/mapbender/http/php/mb_getGUIs.php (original)
+++ trunk/mapbender/http/php/mb_getGUIs.php 2006-04-23 09:41:40+0000
@@ -1,7 +1,7 @@
<?php
# $Id$
# Copyright (C) 2002 CCGIS
# This program is free software; you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation; either version 2, or (at your option)
@@ -18,49 +18,44 @@
#returns an array of all guis of the user
function mb_getGUIs($mb_user_id){
- $arrayGuis = array();
- if(isset($mb_user_id)){
- $sql_groups = "SELECT fkey_mb_group_id FROM mb_user_mb_group WHERE fkey_mb_user_id = " . $mb_user_id;
- $res_groups = db_query($sql_groups);
- $cnt_groups = 0;
- while(db_fetch_row($res_groups)){
- $mb_user_groups[$cnt_groups] = db_result($res_groups,$cnt_groups,"fkey_mb_group_id");
- $cnt_groups++;
- $count_g = 0;
- if($cnt_groups > 0){
- $sql_g = "SELECT DISTINCT gui.gui_id FROM gui JOIN gui_mb_group ";
- $sql_g .= " ON gui.gui_id = gui_mb_group.fkey_gui_id WHERE( gui_mb_group.fkey_mb_group_id IN (";
- for($i=0; $i<count($mb_user_groups);$i++){
- if($i > 0){$sql_g .= ",";}
- $sql_g .= $mb_user_groups[$i];
- $sql_g .= "))";
- $res_g = db_query($sql_g);
- while(db_fetch_row($res_g)){
- $arrayGuis[$count_g] = db_result($res_g, $count_g, "gui_id");
- $count_g++;
- $sql_guis = "SELECT DISTINCT gui.gui_id FROM gui JOIN gui_mb_user ";
- $sql_guis .= "ON gui.gui_id = gui_mb_user.fkey_gui_id WHERE (gui_mb_user.fkey_mb_user_id = ".$mb_user_id.") ";
- $sql_guis .= " AND gui.gui_public = 1";
- $res_guis = db_query($sql_guis);
- $count_guis = 0;
- while(db_fetch_row($res_guis)){
- if( !in_array(db_result($res_guis,$count_guis,"gui_id"),$arrayGuis)){
- $arrayGuis[$count_g] = db_result($res_guis,$count_guis,"gui_id");
- $count_g++;
- $count_guis++;
- return $arrayGuis;
+ $arrayGuis = array();
+ if(isset($mb_user_id)){
+ $sql_groups = "SELECT fkey_mb_group_id FROM mb_user_mb_group WHERE fkey_mb_user_id = " . $mb_user_id;
+ $res_groups = db_query($sql_groups);
+ $cnt_groups = 0;
+ while(db_fetch_row($res_groups)){
+ $mb_user_groups[$cnt_groups] = db_result($res_groups,$cnt_groups,"fkey_mb_group_id");
+ $cnt_groups++;
+ $count_g = 0;
+ if($cnt_groups > 0){
+ $sql_g = "SELECT DISTINCT gui.gui_id FROM gui JOIN gui_mb_group ";
+ $sql_g .= " ON gui.gui_id = gui_mb_group.fkey_gui_id WHERE( gui_mb_group.fkey_mb_group_id IN (";
+ for($i=0; $i<count($mb_user_groups);$i++){
+ if($i > 0){$sql_g .= ",";}
+ $sql_g .= $mb_user_groups[$i];
+ $sql_g .= "))";
+ $res_g = db_query($sql_g);
+ while(db_fetch_row($res_g)){
+ $arrayGuis[$count_g] = db_result($res_g, $count_g, "gui_id");
+ $count_g++;
+ $sql_guis = "SELECT DISTINCT gui.gui_id FROM gui JOIN gui_mb_user ";
+ $sql_guis .= "ON gui.gui_id = gui_mb_user.fkey_gui_id WHERE (gui_mb_user.fkey_mb_user_id = ".$mb_user_id.") ";
+ $sql_guis .= " AND gui.gui_public = 1";
+ $res_guis = db_query($sql_guis);
+ $count_guis = 0;
+ while(db_fetch_row($res_guis)){
+ if( !in_array(db_result($res_guis,$count_guis,"gui_id"),$arrayGuis)){
+ $arrayGuis[$count_g] = db_result($res_guis,$count_guis,"gui_id");
+ $count_g++;
+ $count_guis++;
+ return $arrayGuis;
Modified: trunk/mapbender/http/php/mb_listGUIs.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mb_listGUIs.php?view=diff&rev=128&p1=trunk/mapbender/http/php/mb_listGUIs.php&p2=trunk/mapbender/http/php/mb_listGUIs.php&r1=127&r2=128
--- trunk/mapbender/http/php/mb_listGUIs.php (original)
+++ trunk/mapbender/http/php/mb_listGUIs.php 2006-04-23 09:41:40+0000
@@ -1,6 +1,5 @@
<?php
-# $Id: mb_listGUIs.php,v 1.13 2005/11/18 14:23:58 astrid_emde Exp $
-# $Header: /cvsroot/mapbender/mapbender/http/php/mb_listGUIs.php,v 1.13 2005/11/18 14:23:58 astrid_emde Exp $
+# $Id$
@@ -17,7 +16,6 @@
# along with this program; if not, write to the Free Software
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
# list of user-guis after login:
function mb_listGUIs($arrayGUIs){
echo "<form name='listGUIsForm' target='_blank'>";
@@ -26,44 +24,37 @@
echo "</td><td>";
if (count($arrayGUIs)>0){
- $sql_list_guis = "SELECT DISTINCT gui_id,gui_name,gui_description FROM gui WHERE gui_id IN (";
- for($i=0; $i<count($arrayGUIs); $i++){
- if($i>0){$sql_list_guis .= ",";}
- $sql_list_guis .= "'". $arrayGUIs[$i]."'";
- $sql_list_guis .= ") ORDER BY gui_name";
- $res_list_guis = db_query($sql_list_guis);
+ $sql_list_guis = "SELECT DISTINCT gui_id,gui_name,gui_description FROM gui WHERE gui_id IN (";
+ for($i=0; $i<count($arrayGUIs); $i++){
+ if($i>0){$sql_list_guis .= ",";}
+ $sql_list_guis .= "'". $arrayGUIs[$i]."'";
+ $sql_list_guis .= ") ORDER BY gui_name";
+ $res_list_guis = db_query($sql_list_guis);
echo "<a href=\"../php/mod_editSelf.php?".SID."\" class='list_guis' target=_blank>Change personal settings</a>";
- echo "</td><td align = 'right'>";
- echo "<a href=\"../php/mod_logout.php?".SID."\"><img src =\"../img/button_gray/logout_off.png\" border='0' onmouseover='this.src=\"../img/button_gray/logout_over.png\"' onmouseout='this.src=\"../img/button_gray/logout_off.png\"' title=\"Logout\"></a>";
- echo "</td></tr></table>";
- echo "<table width='50%' class='list_guis' border='1' cellpadding='3' rules='rows'><tr style='background-color:#F0F0F0;' width='80px'><td ><b>GUI name</b></td><td><b>GUI description</b></td></tr>";
- $cnt_list_guis = 0;
- while($row = db_fetch_array($res_list_guis)){
- echo "<tr ";
- if(($cnt_list_guis % 2) == 0){ echo " style='background-color:#ffffff;' ";}
- echo ">";
- echo "<td><b><a href='index.php?".strip_tags (SID)."&gui_id=".$row["gui_id"]."'>".$row["gui_name"]."</a><b></td>";
- echo "<td>".$row["gui_description"]."</td>";
- echo "</tr>";
- $cnt_list_guis++;
- }else{
+ echo "</td><td align = 'right'>";
+ echo "<a href=\"../php/mod_logout.php?".SID."\"><img src =\"../img/button_gray/logout_off.png\" border='0' onmouseover='this.src=\"../img/button_gray/logout_over.png\"' onmouseout='this.src=\"../img/button_gray/logout_off.png\"' title=\"Logout\"></a>";
+ echo "</td></tr></table>";
+ echo "<table width='50%' class='list_guis' border='1' cellpadding='3' rules='rows'><tr style='background-color:#F0F0F0;' width='80px'><td ><b>GUI name</b></td><td><b>GUI description</b></td></tr>";
+ $cnt_list_guis = 0;
+ while($row = db_fetch_array($res_list_guis)){
+ echo "<tr ";
+ if(($cnt_list_guis % 2) == 0){ echo " style='background-color:#ffffff;' ";}
+ echo ">";
+ echo "<td><b><a href='index.php?".strip_tags (SID)."&gui_id=".$row["gui_id"]."'>".$row["gui_name"]."</a><b></td>";
+ echo "<td>".$row["gui_description"]."</td>";
+ echo "</tr>";
+ $cnt_list_guis++;
+ else{
- echo "</td><tr>" ;
- echo "<td><br>There are no guis available for this user</td></tr>";
+ echo "</td><tr>" ;
+ echo "<td><br>There are no guis available for this user</td></tr>";
echo "</table>";
echo "</form>";
More information about the Mapbender_commits
