svn commit: r133 - trunk/mapbender/http/php
arnulf at osgeo.org
arnulf at osgeo.org
Sun Apr 23 09:08:46 EDT 2006
Author: arnulf
Date: 2006-04-23 13:08:46+0000
New Revision: 133
trunk/mapbender/http/php/mod_changeEPSG.php (contents, props changed)
trunk/mapbender/http/php/mod_changeEPSG_dynamic.php (contents, props changed)
cleaned, added SVN headers
Modified: trunk/mapbender/http/php/mod_changeEPSG.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_changeEPSG.php?view=diff&rev=133&p1=trunk/mapbender/http/php/mod_changeEPSG.php&p2=trunk/mapbender/http/php/mod_changeEPSG.php&r1=132&r2=133
--- trunk/mapbender/http/php/mod_changeEPSG.php (original)
+++ trunk/mapbender/http/php/mod_changeEPSG.php 2006-04-23 13:08:46+0000
@@ -1,6 +1,6 @@
<?php
-# $Id: mod_changeEPSG.php,v 1.13 2006/03/09 10:33:11 uli_rothstein Exp $
-# $Header: /cvsroot/mapbender/mapbender/http/php/mod_changeEPSG.php,v 1.13 2006/03/09 10:33:11 uli_rothstein Exp $
+# $Id$
# Copyright (C) 2002 CCGIS
# This program is free software; you can redistribute it and/or modify
@@ -16,6 +16,7 @@
# You should have received a copy of the GNU General Public License
# along with this program; if not, write to the Free Software
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
require("mb_validateSession.php");
$gui_id = $_SESSION["mb_user_gui"];
require_once("../../conf/mapbender.conf");
@@ -41,7 +42,7 @@
<style type="text/css">
-.epsg{
+epsg{
width:100px;
border: solid;
@@ -51,149 +52,140 @@
$sql = "SELECT e_target FROM gui_element WHERE e_id = 'changeEPSG' AND fkey_gui_id = '".$gui_id."'";
$res = db_query($sql);
-# erst noch die History einbauen und dann nach dem Ursprungsextent suchen.....
echo "<script type='text/javascript'>";
echo "var myTarget = '".db_result($res,0,"e_target")."';";
echo "</script>";
-###transform coordinates
+# transform coordinates
if(isset($_REQUEST["srs"])){
- require_once("../../conf/mapbender.conf");
- $arraymapObj = split("###", $_REQUEST["srs"]);
- echo "<script type='text/javascript'>";
- echo "var newExtent = new Array();";
- for($i=0; $i < count($arraymapObj); $i++){
- $temp = split(",",$arraymapObj[$i]);
- if(SYS_DBTYPE=='pgsql'){
- $con = db_connect($DBSERVER,$OWNER,$PW);
- $sqlMinx = "SELECT X(transform(GeometryFromText('POINT(".$temp[2]." ".$temp[3].")',".str_replace("EPSG:","",$temp[1])."),".str_replace("EPSG:","",$_REQUEST["newSRS"]).")) as minx";
- $resMinx = db_query($sqlMinx);
- $minx = db_result($resMinx,0,"minx");
- $sqlMiny = "SELECT Y(transform(GeometryFromText('POINT(".$temp[2]." ".$temp[3].")',".str_replace("EPSG:","",$temp[1])."),".str_replace("EPSG:","",$_REQUEST["newSRS"]).")) as miny";
- $resMiny = db_query($sqlMiny);
- $miny = db_result($resMiny,0,"miny");
- $sqlMaxx = "SELECT X(transform(GeometryFromText('POINT(".$temp[4]." ".$temp[5].")',".str_replace("EPSG:","",$temp[1])."),".str_replace("EPSG:","",$_REQUEST["newSRS"]).")) as maxx";
- $resMaxx =db_query($sqlMaxx);
- $maxx = db_result($resMaxx,0,"maxx");
- $sqlMaxy = "SELECT Y(transform(GeometryFromText('POINT(".$temp[4]." ".$temp[5].")',".str_replace("EPSG:","",$temp[1])."),".str_replace("EPSG:","",$_REQUEST["newSRS"]).")) as maxy";
- $resMaxy = db_query($sqlMaxy);
- $maxy = db_result($resMaxy,0,"maxy");
- }else{
+ require_once("../../conf/mapbender.conf");
+ $arraymapObj = split("###", $_REQUEST["srs"]);
+ echo "<script type='text/javascript'>";
+ echo "var newExtent = new Array();";
+ for($i=0; $i < count($arraymapObj); $i++){
+ $temp = split(",",$arraymapObj[$i]);
+ if(SYS_DBTYPE=='pgsql'){
+ $con = db_connect($DBSERVER,$OWNER,$PW);
+ $sqlMinx = "SELECT X(transform(GeometryFromText('POINT(".$temp[2]." ".$temp[3].")',".str_replace("EPSG:","",$temp[1])."),".str_replace("EPSG:","",$_REQUEST["newSRS"]).")) as minx";
+ $resMinx = db_query($sqlMinx);
+ $minx = db_result($resMinx,0,"minx");
+ $sqlMiny = "SELECT Y(transform(GeometryFromText('POINT(".$temp[2]." ".$temp[3].")',".str_replace("EPSG:","",$temp[1])."),".str_replace("EPSG:","",$_REQUEST["newSRS"]).")) as miny";
+ $resMiny = db_query($sqlMiny);
+ $miny = db_result($resMiny,0,"miny");
+ $sqlMaxx = "SELECT X(transform(GeometryFromText('POINT(".$temp[4]." ".$temp[5].")',".str_replace("EPSG:","",$temp[1])."),".str_replace("EPSG:","",$_REQUEST["newSRS"]).")) as maxx";
+ $resMaxx =db_query($sqlMaxx);
+ $maxx = db_result($resMaxx,0,"maxx");
+ $sqlMaxy = "SELECT Y(transform(GeometryFromText('POINT(".$temp[4]." ".$temp[5].")',".str_replace("EPSG:","",$temp[1])."),".str_replace("EPSG:","",$_REQUEST["newSRS"]).")) as maxy";
+ $resMaxy = db_query($sqlMaxy);
+ $maxy = db_result($resMaxy,0,"maxy");
+ }else{
$con_string = "host=$GEOS_DBSERVER port=$GEOS_PORT dbname=$GEOS_DB user=$GEOS_OWNER password=$GEOS_PW";
$con = pg_connect($con_string) or die ("Error while connecting database");
- $resMinx = pg_query($con,$sqlMinx);
- $minx = pg_fetch_result($resMinx,0,"minx");
- $resMiny = pg_query($con,$sqlMiny);
- $miny = pg_fetch_result($resMiny,0,"miny");
- $resMaxx = pg_query($con,$sqlMaxx);
- $maxx = pg_fetch_result($resMaxx,0,"maxx");
- $resMaxy = pg_query($con,$sqlMaxy);
- $maxy = pg_fetch_result($resMaxy,0,"maxy");
- #frameName, EPSG, minx, miny, maxx, maxy, width, height
- $extenty = $maxy - $miny;
- $extentx = $maxx - $minx;
- $relation_px_x = $temp[6] / $temp[7];
- $relation_px_y = $temp[7] / $temp[6];
- $relation_bbox_x = $extentx / $extenty;
- if($relation_bbox_x <= $relation_px_x){
- $centerx = $minx + ($extentx/2);
- $minx = $centerx - $relation_px_x * $extenty / 2;
- $maxx = $centerx + $relation_px_x * $extenty / 2;
- if($relation_bbox_x > $relation_px_x){
- $centery = $miny + ($extenty/2);
- $miny = $centery - $relation_px_y * $extentx / 2;
- $maxy = $centery + $relation_px_y * $extentx / 2;
- echo "newExtent[".$i."] = '".$temp[0].",".$_REQUEST["newSRS"].",".$minx.",".$miny.",".$maxx.",".$maxy."';";
- echo "</script>";
+ $resMinx = pg_query($con,$sqlMinx);
+ $minx = pg_fetch_result($resMinx,0,"minx");
+ $resMiny = pg_query($con,$sqlMiny);
+ $miny = pg_fetch_result($resMiny,0,"miny");
+ $resMaxx = pg_query($con,$sqlMaxx);
+ $maxx = pg_fetch_result($resMaxx,0,"maxx");
+ $resMaxy = pg_query($con,$sqlMaxy);
+ $maxy = pg_fetch_result($resMaxy,0,"maxy");
+ $extenty = $maxy - $miny;
+ $extentx = $maxx - $minx;
+ $relation_px_x = $temp[6] / $temp[7];
+ $relation_px_y = $temp[7] / $temp[6];
+ $relation_bbox_x = $extentx / $extenty;
+ if($relation_bbox_x <= $relation_px_x){
+ $centerx = $minx + ($extentx/2);
+ $minx = $centerx - $relation_px_x * $extenty / 2;
+ $maxx = $centerx + $relation_px_x * $extenty / 2;
+ if($relation_bbox_x > $relation_px_x){
+ $centery = $miny + ($extenty/2);
+ $miny = $centery - $relation_px_y * $extentx / 2;
+ $maxy = $centery + $relation_px_y * $extentx / 2;
+ echo "newExtent[".$i."] = '".$temp[0].",".$_REQUEST["newSRS"].",".$minx.",".$miny.",".$maxx.",".$maxy."';";
+ echo "</script>";
else{
- echo "<script type='text/javascript'>var newExtent = false;</script>";
+ echo "<script type='text/javascript'>var newExtent = false;</script>";
if(newExtent == false){
- parent.mb_registerSubFunctions("window.frames['changeEPSG'].mod_changeEPSG_setBox()");
+ parent.mb_registerSubFunctions("window.frames['changeEPSG'].mod_changeEPSG_setBox()");
function mod_changeEPSG_init(){
//frameName, EPSG, minx, miny, maxx, maxy, width, height
- var exists = false;
- if(newExtent){
- for(var i=0; i<newExtent.length; i++){
- var temp = newExtent[i].split(",");
- if(temp[0] == myTarget){
- for(var ii=0; ii<parent.mb_MapHistoryObj[temp[0]].length; ii++){
- if(parent.mb_MapHistoryObj[temp[0]][ii].epsg == temp[1]){
- exists = ii;
- var goback = true;
- var ind = parent.getMapObjIndexByName(temp[0]);
- if(goback){
- parent.mb_mapObj[ind].epsg = temp[1];
- parent.mb_mapObj[ind].extent = parent.mb_MapHistoryObj[temp[0]][exists].extent;
- parent.setMapRequest(temp[0]);
- else{
- parent.mb_mapObj[ind].extent = parseFloat(temp[2]) + "," + parseFloat(temp[3]) + "," + parseFloat(temp[4]) + "," + parseFloat(temp[5]);
- if(temp[0] != myTarget){
+ var exists = false;
+ if(newExtent){
+ for(var i=0; i<newExtent.length; i++){
+ var temp = newExtent[i].split(",");
+ if(temp[0] == myTarget){
+ for(var ii=0; ii<parent.mb_MapHistoryObj[temp[0]].length; ii++){
+ if(parent.mb_MapHistoryObj[temp[0]][ii].epsg == temp[1]){
+ exists = ii;
+ var goback = true;
+ var ind = parent.getMapObjIndexByName(temp[0]);
+ if(goback){
+ parent.mb_mapObj[ind].epsg = temp[1];
+ parent.mb_mapObj[ind].extent = parent.mb_MapHistoryObj[temp[0]][exists].extent;
+ parent.setMapRequest(temp[0]);
+ else{
+ parent.mb_mapObj[ind].extent = parseFloat(temp[2]) + "," + parseFloat(temp[3]) + "," + parseFloat(temp[4]) + "," + parseFloat(temp[5]);
+ if(temp[0] != myTarget){
function mod_changeEPSG_setBox(){
- var myEPSG = parent.mb_mapObj[0].epsg;
- for(var i=0; i<document.forms[0].epsg.length; i++){
- if(document.forms[0].epsg.options[i].value == myEPSG){
- document.forms[0].epsg.selectedIndex = i;
- isEPSG = true;
+ var myEPSG = parent.mb_mapObj[0].epsg;
+ for(var i=0; i<document.forms[0].epsg.length; i++){
+ if(document.forms[0].epsg.options[i].value == myEPSG){
+ document.forms[0].epsg.selectedIndex = i;
+ isEPSG = true;
function mod_changeEPSG(){
- str_srs = "";
- for(var i=0; i<parent.mb_mapObj.length; i++){
- if(i>0){str_srs += "###";}
- str_srs += parent.mb_mapObj[i].frameName + "," + parent.mb_mapObj[i].epsg + "," + parent.mb_mapObj[i].extent + ","+parent.mb_mapObj[i].width+","+parent.mb_mapObj[i].height;
- document.forms[0].srs.value = str_srs;
- var ind = document.forms[0].epsg.selectedIndex;
- document.forms[0].newSRS.value = document.forms[0].epsg.options[ind].value;
- document.forms[0].submit();
+ str_srs = "";
+ for(var i=0; i<parent.mb_mapObj.length; i++){
+ if(i>0){str_srs += "###";}
+ str_srs += parent.mb_mapObj[i].frameName + "," + parent.mb_mapObj[i].epsg + "," + parent.mb_mapObj[i].extent + ","+parent.mb_mapObj[i].width+","+parent.mb_mapObj[i].height;
+ document.forms[0].srs.value = str_srs;
+ var ind = document.forms[0].epsg.selectedIndex;
+ document.forms[0].newSRS.value = document.forms[0].epsg.options[ind].value;
+ document.forms[0].submit();
</script>
Modified: trunk/mapbender/http/php/mod_changeEPSG_dynamic.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_changeEPSG_dynamic.php?view=diff&rev=133&p1=trunk/mapbender/http/php/mod_changeEPSG_dynamic.php&p2=trunk/mapbender/http/php/mod_changeEPSG_dynamic.php&r1=132&r2=133
--- trunk/mapbender/http/php/mod_changeEPSG_dynamic.php (original)
+++ trunk/mapbender/http/php/mod_changeEPSG_dynamic.php 2006-04-23 13:08:46+0000
@@ -1,6 +1,6 @@
<?php
-# $Id: mod_changeEPSG_dynamic.php,v 1.8 2006/03/09 12:13:00 uli_rothstein Exp $
-# $Header: /cvsroot/mapbender/mapbender/http/php/mod_changeEPSG_dynamic.php,v 1.8 2006/03/09 12:13:00 uli_rothstein Exp $
+# $Id$
@@ -21,7 +21,6 @@
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta name="author-mail" content="info at ccgis.de">
@@ -48,120 +47,111 @@
db_select_db(DB,$con);
-/*TW: EPSG_Code dynamic ********************************************************************************************/
$cnt_gui_wms = 0;
$cnt_epsg_wms = 0;
$cnt_layer_wms = 0;
-/*get allocated wms from allocated gui ********************************************************************************************/
+/*get allocated wms from allocated gui ********************************************************************************************/
$sql_gui_wms = "SELECT fkey_wms_id FROM gui_wms WHERE fkey_gui_id IN (";
$sql_gui_wms .= "'".$gui_id."'";
$sql_gui_wms.= ") ORDER BY fkey_wms_id";
# echo"$sql_gui_wms";
$res_gui_wms = db_query($sql_gui_wms);
- while(db_fetch_row($res_gui_wms)){
- $fkey_gui_id[$cnt_gui_wms] = db_result($res_gui_wms,$cnt_gui_wms,"fkey_gui_id");
- $fkey_wms_id_1[$cnt_gui_wms] = db_result($res_gui_wms,$cnt_gui_wms,"fkey_wms_id");
- $cnt_gui_wms++;
-/*get allocated layer_id from allocated gui ********************************************************************************************/
+while(db_fetch_row($res_gui_wms)){
+ $fkey_gui_id[$cnt_gui_wms] = db_result($res_gui_wms,$cnt_gui_wms,"fkey_gui_id");
+ $fkey_wms_id_1[$cnt_gui_wms] = db_result($res_gui_wms,$cnt_gui_wms,"fkey_wms_id");
+ $cnt_gui_wms++;
+/*get allocated layer_id from allocated gui ********************************************************************************************/
$sql_layer_wms = "SELECT layer_id FROM layer WHERE fkey_wms_id IN (";
for($i=0; $i<count($fkey_wms_id_1); $i++){
- if($i>0){ $sql_layer_wms .= ",";}
- $sql_layer_wms .= "'".$fkey_wms_id_1[$i]."'";
+ if($i>0){ $sql_layer_wms .= ",";}
+ $sql_layer_wms .= "'".$fkey_wms_id_1[$i]."'";
$sql_layer_wms.= ") ORDER BY layer_id";
$res_layer_wms = db_query($sql_layer_wms);
- while($row = db_fetch_array($res_layer_wms)){
- $layer_id[$cnt_layer_wms] = $row["layer_id"];
- $fkey_wms_id[$cnt_layer_wms] = $row["fkey_wms_id"];
- $cnt_layer_wms++;
-/*get allocated epsg-code from allocated wms ********************************************************************************************/
+while($row = db_fetch_array($res_layer_wms)){
+ $layer_id[$cnt_layer_wms] = $row["layer_id"];
+ $fkey_wms_id[$cnt_layer_wms] = $row["fkey_wms_id"];
+ $cnt_layer_wms++;
+/*get allocated epsg-code from allocated wms ********************************************************************************************/
#$sql_epsg_layer = "SELECT DISTINCT epsg FROM layer_epsg WHERE fkey_layer_id IN (";
$sql_epsg_wms = "SELECT DISTINCT wms_srs FROM wms_srs WHERE fkey_wms_id IN (";
- if($i>0){ $sql_epsg_wms .= ",";}
- $sql_epsg_wms .= "'".$fkey_wms_id_1[$i]."'";
+ if($i>0){ $sql_epsg_wms .= ",";}
+ $sql_epsg_wms .= "'".$fkey_wms_id_1[$i]."'";
$sql_epsg_wms.= ") ORDER BY wms_srs";
$res_epsg_wms = db_query($sql_epsg_wms);
- while($row = db_fetch_array($res_epsg_wms)){
- $fkey_wms_id_2[$cnt_epsg_wms] = $row["fkey_wms_id"];
- $epsg_code[$cnt_epsg_wms] = $row["wms_srs"];
- $cnt_epsg_wms++; //possible error because increment before echo statement
- echo"$epsg_code[$cnt_epsg_wms]";
+while($row = db_fetch_array($res_epsg_wms)){
+ $fkey_wms_id_2[$cnt_epsg_wms] = $row["fkey_wms_id"];
+ $epsg_code[$cnt_epsg_wms] = $row["wms_srs"];
+ $cnt_epsg_wms++; //possible error because increment before echo statement
+ echo"$epsg_code[$cnt_epsg_wms]";
echo "</script>";
- $con = pg_connect ($con_string) or die ("Error while connecting database DBname");
- $resMinx = @pg_query($con,$sqlMinx);
- $minx = pg_result($resMinx,0,"minx");
- $resMiny = @pg_query($con,$sqlMiny);
- $miny = pg_result($resMiny,0,"miny");
- $resMaxx = @pg_query($con,$sqlMaxx);
- $maxx = pg_result($resMaxx,0,"maxx");
- $resMaxy = @pg_query($con,$sqlMaxy);
- $maxy = pg_result($resMaxy,0,"maxy");
- echo "</script>";
+ $con = pg_connect ($con_string) or die ("Error while connecting database DBname");
+ $resMinx = @pg_query($con,$sqlMinx);
+ $minx = pg_result($resMinx,0,"minx");
+ $resMiny = @pg_query($con,$sqlMiny);
+ $miny = pg_result($resMiny,0,"miny");
+ $resMaxx = @pg_query($con,$sqlMaxx);
+ $maxx = pg_result($resMaxx,0,"maxx");
+ $resMaxy = @pg_query($con,$sqlMaxy);
+ $maxy = pg_result($resMaxy,0,"maxy");
+ echo "</script>";
else{
@@ -172,78 +162,76 @@
- if(newExtent){
- exists = ii;
- if(goback){
- else{
+ if(newExtent){
+ exists = ii;
+ if(goback){
+ else{
- isEPSG = true;
+ isEPSG = true;
- str_srs = "";
+ str_srs = "";
</script>
</head>
<body leftmargin="1" topmargin="1" onload="mod_changeEPSG_init()" bgcolor="#0066cc">
<?php
-/*insert EPSG in selectbox************************************************************************************/
+/*insert EPSG into selectbox************************************************************************************/
echo "<form action='" . $PHP_SELF . "?".SID."' method='post'>";
-#echo "<select class='epsg' name='epsg' onChange='mod_changeEPSG()'><option value=\"\">undefined</option>";
echo "<select class='epsg' name='epsg' onChange='mod_changeEPSG()'>";
- for($i=0; $i<$cnt_epsg_wms; $i++){
- echo "<option value='" . $epsg_code[$i] . "' ";
- if($epsg && $epsg == $epsg_code[$i]){
- echo ">" . $epsg_code[$i] . "</option>";
+for($i=0; $i<$cnt_epsg_wms; $i++){
+ echo "<option value='" . $epsg_code[$i] . "' ";
+ if($epsg && $epsg == $epsg_code[$i]){
+ echo ">" . $epsg_code[$i] . "</option>";
echo "</select>";
-#echo"<input type='text'size='30' name='srs' value=''>";
echo"<input type='hidden' name='srs' value=''>";
echo"<input type='hidden' name='newSRS' value=''>";
echo"</form>";
More information about the Mapbender_commits
