svn commit: r137 - trunk/mapbender/http/php/mod_monitorCapabilities.php
arnulf at osgeo.org arnulf at osgeo.org
Sun Apr 23 20:30:52 EDT 2006
Author: arnulf
Date: 2006-04-24 00:30:51+0000
New Revision: 137
added caps as link and short description
Modified: trunk/mapbender/http/php/mod_monitorCapabilities.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_monitorCapabilities.php?view=diff&rev=137&p1=trunk/mapbender/http/php/mod_monitorCapabilities.php&p2=trunk/mapbender/http/php/mod_monitorCapabilities.php&r1=136&r2=137
--- trunk/mapbender/http/php/mod_monitorCapabilities.php	(original)
+++ trunk/mapbender/http/php/mod_monitorCapabilities.php	2006-04-24 00:30:51+0000
@@ -78,18 +78,22 @@
 } // end function
 //for ($k=0; $k<count($wms_id_own) && 0 == 1; $k++) {
+echo "Starting monitoring cycle...<br><br>";
+echo "WMS services are requested for availabiltiy. ";
+echo "Capabilities documents are requested and all changes synchronized with the database cache.<br><br>";
 echo "<table cellspacing=10 cellpadding = 8 border = 1>";
 for ($k=0; $k<count($wms_id_own); $k++) {
 	$wmsId = $wms_id_own[$k];
-	echo "<tr><td><b>Processing WMS Id </b>" . $wmsId . "<br>";
+	echo "<tr><td><b>Processing WMS</b> (ID = " . $wmsId . ")<br>";
 	// get the wms version, capabilities, capabilities_doc
-	$sql = "SELECT wms_version, wms_getcapabilities, wms_getcapabilities_doc FROM wms WHERE wms_id = '" . $wmsId . "'";
+	$sql = "SELECT wms_title, wms_version, wms_getcapabilities, wms_getcapabilities_doc FROM wms WHERE wms_id = '" . $wmsId . "'";
 	$res = db_query($sql);
 	$someArray = db_fetch_row($res);
-	$version = $someArray[0];
-	$capabilities = $someArray[1];
-	$capabilities_doc = $someArray[2];
+	$wms_title = $someArray[0];
+	$version = $someArray[1];
+	$capabilities = $someArray[2];
+	$capabilities_doc = $someArray[3];
+	echo "WMS Title: <b><i>" . $wms_title . "</i></b><br>";
 	// construct capabilities URL
 	if ($version == "1.1.1" || $version == "1.1.0") {
 		$myURL = $capabilities . "REQUEST=GetCapabilities&SERVICE=wms&VERSION=" . $version;
@@ -98,13 +102,14 @@
 		$myURL = $capabilities . "REQUEST=capabilities&WMTVER=1.0.0";
 	else {
-		echo "Unknown wms version '" . $version . "'! No update possible.</td><td><img src ='../img/trafficlights/stop.bmp'></td></tr>";
+		echo "Version '" . $version . "' cannot be handled! Update process terminated.</td><td><img src ='../img/trafficlights/stop.bmp'></td></tr>";
 	if (($version == "1.1.1" || $version == "1.1.0" ||$version == "1.0.0") && $myURL) {
 		// compare the capabilities XML documents
 		$localXml = $capabilities_doc;
 		set_time_limit(30);
+		echo "<a href='" . $myURL . "'>Get Capabilities Link</a><br>";
 		$remoteXml = implode("", file($myURL));
 		$localXmlArray = explode("\n", $localXml);
 		$remoteXmlArray = explode("\n", $remoteXml);
@@ -127,7 +132,7 @@
 		else {
 			if ($localXml == $remoteXml) {
 				$result = 1;
-				echo "No update necessary.</td><td><img src ='../img/trafficlights/go.bmp'></td></tr>";
+				echo "WMS is stable.</td><td><img src ='../img/trafficlights/go.bmp'></td></tr>";
 			else {
 				$result = 0;
@@ -143,7 +148,7 @@
 echo "</table>";
-echo "<br><br>done!";
+echo "<br>Monitoring Cycle completed.";
 </body>
 </html>
\ No newline at end of file
More information about the Mapbender_commits mailing list
