svn commit: r141 - trunk/mapbender/http/php
arnulf at osgeo.org arnulf at osgeo.org
Mon Apr 24 07:28:57 EDT 2006
Author: arnulf
Date: 2006-04-24 11:28:57+0000
New Revision: 141
   trunk/mapbender/http/php/mod_deleteFilteredGUI.php
   trunk/mapbender/http/php/mod_deleteGUI.php
   trunk/mapbender/http/php/mod_deleteWMS.php   (contents, props changed)
cleaned, added SVN headers
Modified: trunk/mapbender/http/php/mod_deleteFilteredGUI.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_deleteFilteredGUI.php?view=diff&rev=141&p1=trunk/mapbender/http/php/mod_deleteFilteredGUI.php&p2=trunk/mapbender/http/php/mod_deleteFilteredGUI.php&r1=140&r2=141
--- trunk/mapbender/http/php/mod_deleteFilteredGUI.php	(original)
+++ trunk/mapbender/http/php/mod_deleteFilteredGUI.php	2006-04-24 11:28:57+0000
@@ -1,6 +1,6 @@
 <?php
-# $Id: mod_deleteFilteredGUI.php,v 1.12 2006/03/09 10:56:01 uli_rothstein Exp $
-# $Header: /cvsroot/mapbender/mapbender/http/php/mod_deleteFilteredGUI.php,v 1.12 2006/03/09 10:56:01 uli_rothstein Exp $
+# $Id$
+# http://www.mapbender.org/index.php/DeleteGUI
 # Copyright (C) 2002 CCGIS
 # This program is free software; you can redistribute it and/or modify
@@ -39,7 +39,7 @@
 <?php
 echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
-<title>deletefilteredGui</title>
+<title>Delete GUI</title>
 <?php
 include '../include/dyn_css.php';
@@ -176,16 +176,10 @@
 		if ($count == 0) {
 			echo "<i>- none -</i><br>";
 		echo "</p>";
-	echo "<input class='button_del' type='button' value='delete' onclick='validate()'>";
+	echo "<input class='button_del' type='button' value='delete' onclick='validate()'>";
 	echo "<input type='hidden' name='del'>";
 	echo "</form>";
 }else{
Modified: trunk/mapbender/http/php/mod_deleteGUI.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_deleteGUI.php?view=diff&rev=141&p1=trunk/mapbender/http/php/mod_deleteGUI.php&p2=trunk/mapbender/http/php/mod_deleteGUI.php&r1=140&r2=141
--- trunk/mapbender/http/php/mod_deleteGUI.php	(original)
+++ trunk/mapbender/http/php/mod_deleteGUI.php	2006-04-24 11:28:57+0000
@@ -1,6 +1,6 @@
 <?php
-# $Id: mod_deleteGUI.php,v 1.16 2006/03/09 12:13:50 uli_rothstein Exp $
-# $Header: /cvsroot/mapbender/mapbender/http/php/mod_deleteGUI.php,v 1.16 2006/03/09 12:13:50 uli_rothstein Exp $
+# $Id$
@@ -39,7 +39,7 @@
 <?php
-<title>deleteGui</title>
+<title>Delete GUI - All Users</title>
 <?php
@@ -65,24 +65,21 @@
 ###delete
 if($guiList){
-		 $sql = "DELETE FROM gui WHERE gui_id = '".$guiList."'";
-		 $res = db_query($sql);
+	 $sql = "DELETE FROM gui WHERE gui_id = '".$guiList."'";
+	 $res = db_query($sql);
 $sql_gui = "SELECT * FROM gui ";
 $sql_gui .= " ORDER BY gui_name";
 $res_gui = db_query($sql_gui);
 $cnt_gui = 0;
 echo "<form name='form1' action='" . $PHP_SELF . "?".SID."' method='post'>";
 echo "<select class='guiList' size='20' name='guiList' class='guiList'>";
 while($row = db_fetch_array($res_gui)){
-   echo "<option value='".$row["gui_id"]."'>".$row["gui_name"]."</option>";
-   $cnt_gui++;
+	echo "<option value='".$row["gui_id"]."'>".$row["gui_name"]."</option>";
+	$cnt_gui++;
 echo "</select><br>";
Modified: trunk/mapbender/http/php/mod_deleteWMS.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_deleteWMS.php?view=diff&rev=141&p1=trunk/mapbender/http/php/mod_deleteWMS.php&p2=trunk/mapbender/http/php/mod_deleteWMS.php&r1=140&r2=141
--- trunk/mapbender/http/php/mod_deleteWMS.php	(original)
+++ trunk/mapbender/http/php/mod_deleteWMS.php	2006-04-24 11:28:57+0000
@@ -1,6 +1,6 @@
 <?php
-# $Id: mod_deleteWMS.php,v 1.19 2006/03/09 10:46:00 uli_rothstein Exp $
-# $Header: /cvsroot/mapbender/mapbender/http/php/mod_deleteWMS.php,v 1.19 2006/03/09 10:46:00 uli_rothstein Exp $
+# $Id$
+# http://www.mapbender.org/index.php/DeleteWMS
More information about the Mapbender_commits mailing list
