svn commit: r147 - trunk/mapbender/http/php
arnulf at osgeo.org
arnulf at osgeo.org
Wed Apr 26 04:11:04 EDT 2006
Author: arnulf
Date: 2006-04-26 08:11:04+0000
New Revision: 147
trunk/mapbender/http/php/mod_WMSpreferences.php (contents, props changed)
trunk/mapbender/http/php/mod_renameGUI.php (contents, props changed)
trunk/mapbender/http/php/mod_saveWKT.php (contents, props changed)
trunk/mapbender/http/php/mod_showLoggedUser.php (contents, props changed)
trunk/mapbender/http/php/mod_simpleWMSpreferences.php (contents, props changed)
trunk/mapbender/http/php/mod_treefolderAdmin.php (contents, props changed)
trunk/mapbender/http/php/mod_treefolderClient.php (contents, props changed)
trunk/mapbender/http/php/mod_usemap.php (contents, props changed)
trunk/mapbender/http/php/mod_user_filteredGroup.php (contents, props changed)
trunk/mapbender/http/php/mod_user_filteredGui.php (contents, props changed)
trunk/mapbender/http/php/mod_user_group.php (contents, props changed)
trunk/mapbender/http/php/mod_user_gui.php (contents, props changed)
trunk/mapbender/http/php/mod_wfs.php (contents, props changed)
trunk/mapbender/http/php/mod_wfsLayerObj_conf.php (contents, props changed)
trunk/mapbender/http/php/mod_wfs_conf.php (contents, props changed)
trunk/mapbender/http/php/mod_wfs_edit.php (contents, props changed)
trunk/mapbender/http/php/mod_wfs_result.php (contents, props changed)
trunk/mapbender/http/php/mod_wfs_save.php (contents, props changed)
trunk/mapbender/http/php/mod_wfsrequest.php (contents, props changed)
trunk/mapbender/http/php/mod_zoomCoords.php
trunk/mapbender/http/php/mod_zoomCoords_en.php (contents, props changed)
trunk/mapbender/http/php/nestedSets.php
added license ref, formatting
Modified: trunk/mapbender/http/php/mod_WMSpreferences.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_WMSpreferences.php?view=diff&rev=147&p1=trunk/mapbender/http/php/mod_WMSpreferences.php&p2=trunk/mapbender/http/php/mod_WMSpreferences.php&r1=146&r2=147
--- trunk/mapbender/http/php/mod_WMSpreferences.php (original)
+++ trunk/mapbender/http/php/mod_WMSpreferences.php 2006-04-26 08:11:04+0000
@@ -1,4 +1,6 @@
<?php
+# $Id$
+# http://www.mapbender.org/index.php/Administration
# Copyright (C) 2002 CCGIS
# This program is free software; you can redistribute it and/or modify
@@ -14,6 +16,7 @@
# You should have received a copy of the GNU General Public License
# along with this program; if not, write to the Free Software
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
require_once("../../conf/mapbender.conf");
session_start();
Modified: trunk/mapbender/http/php/mod_renameGUI.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_renameGUI.php?view=diff&rev=147&p1=trunk/mapbender/http/php/mod_renameGUI.php&p2=trunk/mapbender/http/php/mod_renameGUI.php&r1=146&r2=147
--- trunk/mapbender/http/php/mod_renameGUI.php (original)
+++ trunk/mapbender/http/php/mod_renameGUI.php 2006-04-26 08:11:04+0000
@@ -1,5 +1,21 @@
<?php
-/* version 2.0.2*/
+# $Id$
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
session_start();
import_request_variables("PG");
Modified: trunk/mapbender/http/php/mod_saveWKT.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_saveWKT.php?view=diff&rev=147&p1=trunk/mapbender/http/php/mod_saveWKT.php&p2=trunk/mapbender/http/php/mod_saveWKT.php&r1=146&r2=147
--- trunk/mapbender/http/php/mod_saveWKT.php (original)
+++ trunk/mapbender/http/php/mod_saveWKT.php 2006-04-26 08:11:04+0000
@@ -1,5 +1,7 @@
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<?php
+# $Id$
Modified: trunk/mapbender/http/php/mod_showLoggedUser.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_showLoggedUser.php?view=diff&rev=147&p1=trunk/mapbender/http/php/mod_showLoggedUser.php&p2=trunk/mapbender/http/php/mod_showLoggedUser.php&r1=146&r2=147
--- trunk/mapbender/http/php/mod_showLoggedUser.php (original)
+++ trunk/mapbender/http/php/mod_showLoggedUser.php 2006-04-26 08:11:04+0000
@@ -1,6 +1,22 @@
<?php
-/* version 2.0.1*/
+# $Id$
session_start();
$con = db_connect($DBSERVER,$OWNER,$PW);
@@ -10,17 +26,6 @@
-<?php
- #---------------- FILE HEADER --------------------------------
- # PROJECT : Mapbender
- # FILE TYPE : Php-Script
- # DESCRIPTION : USERADMINISTRATION, allotment of project-authorizations for profiles
- # AUTHOR : Thekla Wirkus, info at ccgis.de
- # DATE: 11.05.2004
<html>
<head>
<?php
@@ -35,8 +40,6 @@
<?php
$logged_user_name=$_SESSION["mb_user_name"];
$logged_user_id=$_SESSION["mb_user_id"];
-#echo $logged_user_name;
-#echo <div class="text1">$logged_user_name</div>;
echo "<div class='text4'>Logged User: ".$logged_user_name."</div>";
</body>
Modified: trunk/mapbender/http/php/mod_simpleWMSpreferences.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_simpleWMSpreferences.php?view=diff&rev=147&p1=trunk/mapbender/http/php/mod_simpleWMSpreferences.php&p2=trunk/mapbender/http/php/mod_simpleWMSpreferences.php&r1=146&r2=147
--- trunk/mapbender/http/php/mod_simpleWMSpreferences.php (original)
+++ trunk/mapbender/http/php/mod_simpleWMSpreferences.php 2006-04-26 08:11:04+0000
@@ -1,4 +1,6 @@
<?php
+# $Id$
Modified: trunk/mapbender/http/php/mod_treefolderAdmin.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_treefolderAdmin.php?view=diff&rev=147&p1=trunk/mapbender/http/php/mod_treefolderAdmin.php&p2=trunk/mapbender/http/php/mod_treefolderAdmin.php&r1=146&r2=147
--- trunk/mapbender/http/php/mod_treefolderAdmin.php (original)
+++ trunk/mapbender/http/php/mod_treefolderAdmin.php 2006-04-26 08:11:04+0000
@@ -1,4 +1,23 @@
<?php
+# $Id$
+# Copyright (C) see license below
+# Dual License
Modified: trunk/mapbender/http/php/mod_treefolderClient.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_treefolderClient.php?view=diff&rev=147&p1=trunk/mapbender/http/php/mod_treefolderClient.php&p2=trunk/mapbender/http/php/mod_treefolderClient.php&r1=146&r2=147
--- trunk/mapbender/http/php/mod_treefolderClient.php (original)
+++ trunk/mapbender/http/php/mod_treefolderClient.php 2006-04-26 08:11:04+0000
@@ -1,4 +1,22 @@
<?php
+# $Id$
session_start();
Modified: trunk/mapbender/http/php/mod_usemap.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_usemap.php?view=diff&rev=147&p1=trunk/mapbender/http/php/mod_usemap.php&p2=trunk/mapbender/http/php/mod_usemap.php&r1=146&r2=147
--- trunk/mapbender/http/php/mod_usemap.php (original)
+++ trunk/mapbender/http/php/mod_usemap.php 2006-04-26 08:11:04+0000
@@ -1,6 +1,24 @@
<html>
<head>
<?php
+# $Id$
echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
Modified: trunk/mapbender/http/php/mod_user_filteredGroup.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_user_filteredGroup.php?view=diff&rev=147&p1=trunk/mapbender/http/php/mod_user_filteredGroup.php&p2=trunk/mapbender/http/php/mod_user_filteredGroup.php&r1=146&r2=147
--- trunk/mapbender/http/php/mod_user_filteredGroup.php (original)
+++ trunk/mapbender/http/php/mod_user_filteredGroup.php 2006-04-26 08:11:04+0000
@@ -1,5 +1,5 @@
<?php
-#$Id: mod_user_filteredGroup.php,v 1.14 2006/03/09 11:27:41 uli_rothstein Exp $
+#$Id$
#$Header: /cvsroot/mapbender/mapbender/http/php/mod_user_filteredGroup.php,v 1.14 2006/03/09 11:27:41 uli_rothstein Exp $
Modified: trunk/mapbender/http/php/mod_user_filteredGui.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_user_filteredGui.php?view=diff&rev=147&p1=trunk/mapbender/http/php/mod_user_filteredGui.php&p2=trunk/mapbender/http/php/mod_user_filteredGui.php&r1=146&r2=147
--- trunk/mapbender/http/php/mod_user_filteredGui.php (original)
+++ trunk/mapbender/http/php/mod_user_filteredGui.php 2006-04-26 08:11:04+0000
@@ -1,6 +1,6 @@
<?php
-# $Id: mod_user_filteredGui.php,v 1.14 2006/03/09 08:41:26 uli_rothstein Exp $
-# $Head$
+# $Id$
@@ -16,6 +16,7 @@
session_start();
$gui_id = $_SESSION["mb_user_gui"];
Modified: trunk/mapbender/http/php/mod_user_group.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_user_group.php?view=diff&rev=147&p1=trunk/mapbender/http/php/mod_user_group.php&p2=trunk/mapbender/http/php/mod_user_group.php&r1=146&r2=147
--- trunk/mapbender/http/php/mod_user_group.php (original)
+++ trunk/mapbender/http/php/mod_user_group.php 2006-04-26 08:11:04+0000
@@ -1,6 +1,6 @@
<?php
-#$Id: mod_user_group.php,v 1.14 2006/03/09 10:43:33 uli_rothstein Exp $
-#$Header: /cvsroot/mapbender/mapbender/http/php/mod_user_group.php,v 1.14 2006/03/09 10:43:33 uli_rothstein Exp $
+# $Id$
Modified: trunk/mapbender/http/php/mod_user_gui.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_user_gui.php?view=diff&rev=147&p1=trunk/mapbender/http/php/mod_user_gui.php&p2=trunk/mapbender/http/php/mod_user_gui.php&r1=146&r2=147
--- trunk/mapbender/http/php/mod_user_gui.php (original)
+++ trunk/mapbender/http/php/mod_user_gui.php 2006-04-26 08:11:04+0000
@@ -1,5 +1,5 @@
<?php
-# $Id: mod_user_gui.php,v 1.15 2006/03/09 12:11:54 uli_rothstein Exp $
+# $Id$
# $Header: /cvsroot/mapbender/mapbender/http/php/mod_user_gui.php,v 1.15 2006/03/09 12:11:54 uli_rothstein Exp $
Modified: trunk/mapbender/http/php/mod_wfs.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_wfs.php?view=diff&rev=147&p1=trunk/mapbender/http/php/mod_wfs.php&p2=trunk/mapbender/http/php/mod_wfs.php&r1=146&r2=147
--- trunk/mapbender/http/php/mod_wfs.php (original)
+++ trunk/mapbender/http/php/mod_wfs.php 2006-04-26 08:11:04+0000
@@ -1,7 +1,7 @@
<?php
-# $Id: mod_wfs.php,v 1.5 2006/03/09 12:11:07 uli_rothstein Exp $
-# $Header: /cvsroot/mapbender/mapbender/http/php/mod_wfs.php,v 1.5 2006/03/09 12:11:07 uli_rothstein Exp $
-# Copyright (C) 2002 CCGIS
+# $Id$
@@ -16,7 +16,7 @@
-# session_start();
Modified: trunk/mapbender/http/php/mod_wfsLayerObj_conf.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_wfsLayerObj_conf.php?view=diff&rev=147&p1=trunk/mapbender/http/php/mod_wfsLayerObj_conf.php&p2=trunk/mapbender/http/php/mod_wfsLayerObj_conf.php&r1=146&r2=147
--- trunk/mapbender/http/php/mod_wfsLayerObj_conf.php (original)
+++ trunk/mapbender/http/php/mod_wfsLayerObj_conf.php 2006-04-26 08:11:04+0000
@@ -1,4 +1,22 @@
<?php
+# $Id$
require("../classes/class_wfs_conf.php");
require("../../conf/mapbender.conf");
Modified: trunk/mapbender/http/php/mod_wfs_conf.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_wfs_conf.php?view=diff&rev=147&p1=trunk/mapbender/http/php/mod_wfs_conf.php&p2=trunk/mapbender/http/php/mod_wfs_conf.php&r1=146&r2=147
--- trunk/mapbender/http/php/mod_wfs_conf.php (original)
+++ trunk/mapbender/http/php/mod_wfs_conf.php 2006-04-26 08:11:04+0000
@@ -1,4 +1,22 @@
<?php
+# $Id$
Modified: trunk/mapbender/http/php/mod_wfs_edit.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_wfs_edit.php?view=diff&rev=147&p1=trunk/mapbender/http/php/mod_wfs_edit.php&p2=trunk/mapbender/http/php/mod_wfs_edit.php&r1=146&r2=147
--- trunk/mapbender/http/php/mod_wfs_edit.php (original)
+++ trunk/mapbender/http/php/mod_wfs_edit.php 2006-04-26 08:11:04+0000
@@ -1,4 +1,22 @@
<?php
+# $Id$
<html>
Modified: trunk/mapbender/http/php/mod_wfs_result.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_wfs_result.php?view=diff&rev=147&p1=trunk/mapbender/http/php/mod_wfs_result.php&p2=trunk/mapbender/http/php/mod_wfs_result.php&r1=146&r2=147
--- trunk/mapbender/http/php/mod_wfs_result.php (original)
+++ trunk/mapbender/http/php/mod_wfs_result.php 2006-04-26 08:11:04+0000
@@ -1,6 +1,6 @@
<?php
-# $Id: mod_wfs_result.php,v 1.8 2006/03/09 12:17:27 uli_rothstein Exp $
-# $Header: /cvsroot/mapbender/mapbender/http/php/mod_wfs_result.php,v 1.8 2006/03/09 12:17:27 uli_rothstein Exp $
+# $Id$
Modified: trunk/mapbender/http/php/mod_wfs_save.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_wfs_save.php?view=diff&rev=147&p1=trunk/mapbender/http/php/mod_wfs_save.php&p2=trunk/mapbender/http/php/mod_wfs_save.php&r1=146&r2=147
--- trunk/mapbender/http/php/mod_wfs_save.php (original)
+++ trunk/mapbender/http/php/mod_wfs_save.php 2006-04-26 08:11:04+0000
@@ -1,6 +1,24 @@
<html>
<head>
<?php
+# $Id$
Modified: trunk/mapbender/http/php/mod_wfsrequest.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_wfsrequest.php?view=diff&rev=147&p1=trunk/mapbender/http/php/mod_wfsrequest.php&p2=trunk/mapbender/http/php/mod_wfsrequest.php&r1=146&r2=147
--- trunk/mapbender/http/php/mod_wfsrequest.php (original)
+++ trunk/mapbender/http/php/mod_wfsrequest.php 2006-04-26 08:11:04+0000
@@ -1,6 +1,6 @@
<?php
-# $Id: mod_wfsrequest.php,v 1.4 2006/01/29 11:31:42 uli_rothstein Exp $
-# $Header: /cvsroot/mapbender/mapbender/http/php/mod_wfsrequest.php,v 1.4 2006/01/29 11:31:42 uli_rothstein Exp $
+# $Id$
@@ -16,6 +16,7 @@
db_select_db($DB,$con);
Modified: trunk/mapbender/http/php/mod_zoomCoords.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_zoomCoords.php?view=diff&rev=147&p1=trunk/mapbender/http/php/mod_zoomCoords.php&p2=trunk/mapbender/http/php/mod_zoomCoords.php&r1=146&r2=147
--- trunk/mapbender/http/php/mod_zoomCoords.php (original)
+++ trunk/mapbender/http/php/mod_zoomCoords.php 2006-04-26 08:11:04+0000
@@ -1,6 +1,6 @@
<?php
# $Id$
-# http://www.mapbender.org/index.php/ZoomCoords
Modified: trunk/mapbender/http/php/mod_zoomCoords_en.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_zoomCoords_en.php?view=diff&rev=147&p1=trunk/mapbender/http/php/mod_zoomCoords_en.php&p2=trunk/mapbender/http/php/mod_zoomCoords_en.php&r1=146&r2=147
--- trunk/mapbender/http/php/mod_zoomCoords_en.php (original)
+++ trunk/mapbender/http/php/mod_zoomCoords_en.php 2006-04-26 08:11:04+0000
@@ -1,4 +1,6 @@
<?php
+# $Id$
Modified: trunk/mapbender/http/php/nestedSets.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/nestedSets.php?view=diff&rev=147&p1=trunk/mapbender/http/php/nestedSets.php&p2=trunk/mapbender/http/php/nestedSets.php&r1=146&r2=147
--- trunk/mapbender/http/php/nestedSets.php (original)
+++ trunk/mapbender/http/php/nestedSets.php 2006-04-26 08:11:04+0000
@@ -1,6 +1,6 @@
<?php
# $Id$
-# http://www.mapbender.org/index.php/TreeGde
More information about the Mapbender_commits
