svn commit: r149 - trunk/mapbender/http/classes/class_administration.php
uli at osgeo.org
uli at osgeo.org
Wed Apr 26 06:12:19 EDT 2006
Author: uli
Date: 2006-04-26 10:12:19+0000
New Revision: 149
code cleaning in process
db_prep_query coversion in process
new methods to handle owsproxys
Modified: trunk/mapbender/http/classes/class_administration.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/class_administration.php?view=diff&rev=149&p1=trunk/mapbender/http/classes/class_administration.php&p2=trunk/mapbender/http/classes/class_administration.php&r1=148&r2=149
--- trunk/mapbender/http/classes/class_administration.php (original)
+++ trunk/mapbender/http/classes/class_administration.php 2006-04-26 10:12:19+0000
@@ -1,8 +1,7 @@
<?php
-#$Id: class_administration.php,v 1.22 2006/02/15 10:51:14 astrid_emde Exp $
-#$Header: /cvsroot/mapbender/mapbender/http/classes/class_administration.php,v 1.22 2006/02/15 10:51:14 astrid_emde Exp $
-# Copyright (C) 2002 CCGIS
+# $Id$
+# http://www.mapbender.org/index.php/class_administration
+# Copyright (C) 2002 CCGIS
# This program is free software; you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation; either version 2, or (at your option)
@@ -36,9 +35,7 @@
function adminstration(){
// CB - returns true if $email is a valid email
function isValidEmail ($email) {
if(eregi("^[_a-z0-9-]+(\.[_a-z0-9-]+)*@[a-z0-9-]+(\.[a-z0-9-]+)*(\.[a-z]{2,3})$", $email)) {
@@ -126,28 +123,23 @@
// CB - returns all owners (both from mb_user *and* mb_user from mb_group) of a gui
function getOwnerByGui($gui_id) {
global $DBSERVER,$DB,$OWNER,$PW;
-$sql = "(SELECT mb_user.mb_user_name";
-$sql .= "FROM mb_user ";
-$sql .= "JOIN gui_mb_user ON mb_user.mb_user_id = gui_mb_user.fkey_mb_user_id ";
-$sql .= "WHERE gui_mb_user.mb_user_type = 'owner' ";
-$sql .= "AND gui_mb_user.fkey_gui_id = '".$gui_id."' ";
-$sql .= "GROUP BY mb_user.mb_user_name ";
-$sql .= ") ";
-$sql .= "UNION ( ";
-$sql .= "SELECT mb_user.mb_user_name ";
-$sql .= "FROM gui_mb_group ";
-$sql .= "JOIN mb_user_mb_group ON mb_user_mb_group.fkey_mb_group_id = gui_mb_group.fkey_mb_group_id ";
-$sql .= "JOIN mb_user ON mb_user.mb_user_id = mb_user_mb_group.fkey_mb_user_id ";
-$sql .= "WHERE gui_mb_group.mb_group_type = 'owner' ";
-$sql .= "AND gui_mb_group.fkey_gui_id = '".$gui_id."' ";
-$sql .= "GROUP BY mb_user.mb_user_name) ;";
+ $sql = "(SELECT mb_user.mb_user_name";
+ $sql .= "FROM mb_user ";
+ $sql .= "JOIN gui_mb_user ON mb_user.mb_user_id = gui_mb_user.fkey_mb_user_id ";
+ $sql .= "WHERE gui_mb_user.mb_user_type = 'owner' ";
+ $sql .= "AND gui_mb_user.fkey_gui_id = '".$gui_id."' ";
+ $sql .= "GROUP BY mb_user.mb_user_name ";
+ $sql .= ") ";
+ $sql .= "UNION ( ";
+ $sql .= "SELECT mb_user.mb_user_name ";
+ $sql .= "FROM gui_mb_group ";
+ $sql .= "JOIN mb_user_mb_group ON mb_user_mb_group.fkey_mb_group_id = gui_mb_group.fkey_mb_group_id ";
+ $sql .= "JOIN mb_user ON mb_user.mb_user_id = mb_user_mb_group.fkey_mb_user_id ";
+ $sql .= "WHERE gui_mb_group.mb_group_type = 'owner' ";
+ $sql .= "AND gui_mb_group.fkey_gui_id = '".$gui_id."' ";
+ $sql .= "GROUP BY mb_user.mb_user_name)";
$owner = array();
$res = db_query($sql);
$cnt = 0;
@@ -159,17 +151,17 @@
//CB - returns the email address of a user identified by id
- function getEmailByUserId($id){
- global $DBSERVER,$DB,$OWNER,$PW;
- $con = db_connect($DBSERVER,$OWNER,$PW);
+ function getEmailByUserId($userid){
+ $con = db_connect(DBSERVER,OWNER,PW);
db_select_db(DB,$con);
$sql = "SELECT mb_user_email FROM mb_user ";
- $sql .= "WHERE mb_user_id = '".$id."' GROUP by mb_user_email";
- $res = db_query($sql);
+ $sql .= "WHERE mb_user_id = $1 GROUP by mb_user_email";
+ $v = array($userid);
+ $t = array('i');
+ $res = db_prep_query($sql,$v,$t);
$count_g = 0;
$array = array();
- $row = db_fetch_array($res);
+ $row = db_fetch_array($res);
if ($row) {
return $row["mb_user_email"];
@@ -179,17 +171,17 @@
//CB - returns the user id of a user identified by username
- function getUserNameByUserId($id){
+ function getUserNameByUserId($userid){
$sql = "SELECT mb_user_name FROM mb_user ";
- $sql .= "WHERE mb_user_id = '".$id."' GROUP BY mb_user_name";
+ $sql .= "WHERE mb_user_id = $1 GROUP BY mb_user_name";
+ $t = array("i");
$count_g = 0;
$array = array();
if ($row) {
return $row["mb_user_name"];
@@ -200,12 +192,13 @@
// CB - returns userId of user(s) with email address $email
function getUserIdByEmail($email){
$sql = "SELECT mb_user_id FROM mb_user ";
- $sql .= "WHERE mb_user_email = '".$email."' GROUP BY mb_user_id";
+ $sql .= "WHERE mb_user_email = $1 GROUP BY mb_user_id";
+ $v = array($email);
+ $t = array('s');
$count_g = 0;
$array = array();
while($row = db_fetch_array($res)){
@@ -222,9 +215,9 @@
// CB - returns all owners of wms $wms_id
function getOwnerByWms($wms_id){
- $sql = "SELECT fkey_gui_id FROM gui_wms WHERE fkey_wms_id = ".$wms_id." GROUP BY fkey_gui_id";
- $count=0;
+ global $DBSERVER,$DB,$OWNER,$PW;
+ $sql = "SELECT fkey_gui_id FROM gui_wms WHERE fkey_wms_id = ".$wms_id." GROUP BY fkey_gui_id";
+ $count=0;
$gui[$count] = $row["fkey_gui_id"];
@@ -577,61 +570,71 @@
- function getGuisByPermission($mb_user_id){
+ function getGuisByPermission($mb_user_id){
+ $connect = db_connect(DBSERVER,OWNER,PW);
+ db_select_db(DB);
$arrayGuis = array();
- $sql_groups = "SELECT fkey_mb_group_id FROM mb_user_mb_group WHERE fkey_mb_user_id = ". $mb_user_id." ;";
- $res_groups = db_query($sql_groups);
+ $mb_user_groups = array();
+ $sql_groups = "SELECT fkey_mb_group_id FROM mb_user_mb_group WHERE fkey_mb_user_id = $1 ";
+ $v = array($mb_user_id);
+ $t = array("i");
+ $res_groups = db_prep_query($sql_groups,$v,$t);
$cnt_groups = 0;
while($row = db_fetch_array($res_groups)){
$mb_user_groups[$cnt_groups] = $row["fkey_mb_group_id"];
$cnt_groups++;
$count_g = 0;
- if($cnt_groups > 0){
- $sql_g = "SELECT gui.gui_id FROM gui JOIN gui_mb_group ";
- $sql_g .= " ON gui.gui_id = gui_mb_group.fkey_gui_id WHERE gui_mb_group.fkey_mb_group_id IN (";
- for($i=0; $i<count($mb_user_groups);$i++){
- if($i > 0){$sql_g .= ",";}
- $sql_g .= $mb_user_groups[$i];
- $sql_g .= ") GROUP BY gui.gui_id";
- $res_g = db_query($sql_g);
- while($row = db_fetch_array($res_g)){
- $arrayGuis[$count_g] = $row["gui_id"];
- $count_g++;
- $sql_guis = "SELECT gui.gui_id FROM gui JOIN gui_mb_user ON gui.gui_id = gui_mb_user.fkey_gui_id";
- $sql_guis .= " WHERE (gui_mb_user.fkey_mb_user_id = ".$mb_user_id.") ";
- $sql_guis .= " AND gui.gui_public = 1 GROUP BY gui.gui_id";
- $res_guis = db_query($sql_guis);
- $count_guis = 0;
- $guis = array();
- while($row = db_fetch_array($res_guis)){
- $guis[$count_guis] = $row['gui_id'];
- $count_guis++;
+ if($cnt_groups > 0){
+ $v = array();
+ $t = array();
+ $sql_g = "SELECT gui.gui_id FROM gui JOIN gui_mb_group ";
+ $sql_g .= " ON gui.gui_id = gui_mb_group.fkey_gui_id WHERE gui_mb_group.fkey_mb_group_id IN (";
+ for($i=0; $i<count($mb_user_groups);$i++){
+ if($i > 0){$sql_g .= ",";}
+ $sql_g .= "$".strval($i+1);
+ array_push($v,$mb_user_groups[$i]);
+ array_push($t,"i");
+ $sql_g .= ") GROUP BY gui.gui_id";
+ $res_g = db_prep_query($sql_g,$v,$t);
+ while($row = db_fetch_array($res_g)){
+ $arrayGuis[$count_g] = $row["gui_id"];
+ $count_g++;
+ $sql_guis = "SELECT gui.gui_id FROM gui JOIN gui_mb_user ON gui.gui_id = gui_mb_user.fkey_gui_id";
+ $sql_guis .= " WHERE (gui_mb_user.fkey_mb_user_id = $1) ";
+ $sql_guis .= " AND gui.gui_public = 1 GROUP BY gui.gui_id";
+ $t = array("i");
+ $res_guis = db_prep_query($sql_guis,$v,$t);
+ $count_guis = 0;
+ $guis = array();
+ while($row = db_fetch_array($res_guis)){
+ $guis[$count_guis] = $row['gui_id'];
+ $count_guis++;
return $guis;
- function getWmsByOwnGuis($array_gui_ids){
+ function getWmsByOwnGuis($array_gui_ids){
+ db_select_db(DB);
if(count($array_gui_ids)>0){
+ $v = array();
+ $t = array();
$sql = "SELECT fkey_wms_id from gui_wms WHERE gui_wms.fkey_gui_id IN(";
for($i=0; $i<count($array_gui_ids); $i++){
if($i>0){ $sql .= ",";}
- $sql .= "'".$array_gui_ids[$i]."'";
+ $sql .= "$".strval($i+1);
+ array_push($v, $array_gui_ids[$i]);
+ array_push($t, "s");
$sql .= ") GROUP BY fkey_wms_id";
$ownguis = array();
$i=0;
@@ -689,9 +692,9 @@
return true;
function checkModulePermission($arrayGuis, $modulePath, $column){
+ // no prepared statements necessary - no client requests
$check = true;
if($check == true){
@@ -718,5 +721,45 @@
return true;
+ function getWMSOWSstring($wms_id){
+ $sql = "SELECT wms_owsproxy FROM wms WHERE wms_id = $1 ";
+ $v = array($wms_id);
+ $t = array("i");
+ if($row = db_fetch_array($res)){
+ return $row["wms_owsproxy"];
+ else{
+ return false;
+ function setWMSOWSstring($wms_id, $status){
+ $sql = "UPDATE wms SET wms_owsproxy = $1 WHERE wms_id = $2 ";
+ $t = array("s","i");
+ if($status == 'on'){
+ $time = md5(microtime(1));
+ $v = array($time,$wms_id);
+ else{
+ $v = array("",$wms_id);
+ function checkURL($url){
+ $pos_qm = strpos($url,"?");
+ if($pos_qm > 0 && $pos_qm < (strlen($url)-1) && substr($url,(strlen($url)-1)) != "&"){
+ $url = $url."&";
+ return $url;
+ else if($pos_qm === false){
+ return $url."?";
+ else{
+ return $url;
+$n = new administration();
+$r = $n->getOwnerByGui("admin1");
+print_r($r);
\ No newline at end of file
More information about the Mapbender_commits
