svn commit: r156 - trunk/mapbender/http/javascripts/mod_digitize_tab.php
christoph at osgeo.org
Thu Apr 27 08:54:47 EDT 2006
Author: christoph
Date: 2006-04-27 12:54:47+0000
New Revision: 156
improved button handling: data now comes from element vars
-> it's possible to include or exclude certain button types
Modified: trunk/mapbender/http/javascripts/mod_digitize_tab.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_digitize_tab.php?view=diff&rev=156&p1=trunk/mapbender/http/javascripts/mod_digitize_tab.php&p2=trunk/mapbender/http/javascripts/mod_digitize_tab.php&r1=155&r2=156
--- trunk/mapbender/http/javascripts/mod_digitize_tab.php (original)
+++ trunk/mapbender/http/javascripts/mod_digitize_tab.php 2006-04-27 12:54:47+0000
@@ -122,12 +122,6 @@
var currentMemberIndex = -1;
var currentGeometryIndex = -1;
- var canvas = new Array();
// --- registered functions (begin) ---------------------------------------------------------------------------------------
@@ -189,105 +183,88 @@
- // --- preload images (begin) ---------------------------------------------------------------------------------------------
- // up
- var digitize_point_up = new Image(); digitize_point_up.src = "../img/button_digitize/text_up.png";
- var digitize_line_up = new Image(); digitize_line_up.src = "../img/button_digitize/line_up.png";
- var digitize_poly_up = new Image(); digitize_poly_up.src = "../img/button_digitize/poly_up.png";
- var digitize_move_up = new Image(); digitize_move_up.src = "../img/button_digitize/move_up.png";
- var digitize_addNode_up = new Image(); digitize_addNode_up.src = "../img/button_digitize/newNode_up.png";
- var digitize_delNode_up = new Image(); digitize_delNode_up.src = "../img/button_digitize/delNode_up.png";
- // down
- var digitize_point_down = new Image(); digitize_point_down.src = "../img/button_digitize/text_down.png";
- var digitize_line_down = new Image(); digitize_line_down.src = "../img/button_digitize/line_down.png";
- var digitize_poly_down = new Image(); digitize_poly_down.src = "../img/button_digitize/poly_down.png";
- var digitize_move_down = new Image(); digitize_move_down.src = "../img/button_digitize/move_down.png";
- var digitize_addNode_down = new Image(); digitize_addNode_down.src = "../img/button_digitize/newNode_down.png";
- var digitize_delNode_down = new Image(); digitize_delNode_down.src = "../img/button_digitize/delNode_down.png";
- // --- preload images (end) -----------------------------------------------------------------------------------------------
// --- button handling (begin) --------------------------------------------------------------------------------------------
- function register_button(obj) {
- parent.mb_regButton_frame("init_digitize_button", obj, mod_digitize_elName);
- function init_digitize_button(obj, ind){
- parent.mb_button[ind] = obj;
- parent.mb_button[ind].img_over = obj.src;
- if (obj.id == "dragBasePoint") {
- parent.mb_button[ind].img_on = digitize_move_down.src;
- parent.mb_button[ind].img_off = digitize_move_up.src;
+ function displayButtons() {
+ if (parseInt(buttonPoint)==1) {
+ var tagContent = "<img name=\""+buttonPointId+"\" onmouseover=\"registerButton('initButtonPoint')\" id=\""+buttonPointId+"\" title=\""+buttonPointTitleUp+"\" src=\""+buttonPointSrcUp+"\">";
+ parent.writeTag(mod_digitize_elName,"divButtonPoint",tagContent);
- else if (obj.id == "setBasePoint"){
- parent.mb_button[ind].img_on = digitize_addNode_down.src;
- parent.mb_button[ind].img_off = digitize_addNode_up.src;
+ if (parseInt(buttonLine)==1) {
+ var tagContent = "<img name=\""+buttonLineId+"\" onmouseover=\"registerButton('initButtonLine')\" id=\""+buttonLineId+"\" title=\""+buttonLineTitleUp+"\" src=\""+buttonLineSrcUp+"\">";
+ parent.writeTag(mod_digitize_elName,"divButtonLine",tagContent);
- else if (obj.id == "delBasePoint"){
- parent.mb_button[ind].img_on = digitize_delNode_down.src;
- parent.mb_button[ind].img_off = digitize_delNode_up.src;
+ if (parseInt(buttonPolygon)==1) {
+ var tagContent = "<img name=\""+buttonPolygonId+"\" onmouseover=\"registerButton('initButtonPolygon')\" id=\""+buttonPolygonId+"\" title=\""+buttonPolygonTitleUp+"\" src=\""+buttonPolygonSrcUp+"\">";
+ parent.writeTag(mod_digitize_elName,"divButtonPolygon",tagContent);
- else if (obj.id == "Point"){
- parent.mb_button[ind].img_on = digitize_point_down.src;
- parent.mb_button[ind].img_off = digitize_point_up.src;
+ if (parseInt(buttonMove)==1) {
+ var tagContent = "<img name=\""+buttonMoveId+"\" onmouseover=\"registerButton('initButtonMove')\" id=\""+buttonMoveId+"\" title=\""+buttonMoveTitleUp+"\" src=\""+buttonMoveSrcUp+"\">";
+ parent.writeTag(mod_digitize_elName,"divButtonMove",tagContent);
- else if (obj.id == "Line"){
- parent.mb_button[ind].img_on = digitize_line_down.src;
- parent.mb_button[ind].img_off = digitize_line_up.src;
+ if (parseInt(buttonInsert)==1) {
+ var tagContent = "<img name=\""+buttonInsertId+"\" onmouseover=\"registerButton('initButtonInsert')\" id=\""+buttonInsertId+"\" title=\""+buttonInsertTitleUp+"\" src=\""+buttonInsertSrcUp+"\">";
+ parent.writeTag(mod_digitize_elName,"divButtonInsert",tagContent);
- else if (obj.id == "Polygon"){
- parent.mb_button[ind].img_on = digitize_poly_down.src;
- parent.mb_button[ind].img_off = digitize_poly_up.src;
+ if (parseInt(buttonDelete)==1) {
+ var tagContent = "<img name=\""+buttonDeleteId+"\" onmouseover=\"registerButton('initButtonDelete')\" id=\""+buttonDeleteId+"\" title=\""+buttonDeleteTitleUp+"\" src=\""+buttonDeleteSrcUp+"\">";
+ parent.writeTag(mod_digitize_elName,"divButtonDelete",tagContent);
- parent.mb_button[ind].status = 0;
- parent.mb_button[ind].elName = obj.id;
- parent.mb_button[ind].fName = "";
- parent.mb_button[ind].go = new Function ("digitize_click(parent.mb_button["+ind+"])");
- parent.mb_button[ind].stop = new Function ("digitize_disable(parent.mb_button["+ind+"])");
- function digitize_click(obj) {
- activeButton = obj.id;
- setEvent(obj);
- setEvent(obj);
+ function registerButton(functionName) {
+ parent.mb_regButton_frame(functionName, mod_digitize_elName);
+ function initButtonPoint(ind){
+ initButton(ind, buttonPointSrcUp, buttonPointSrcDown, buttonPointSrcUp, buttonPointTitleUp, buttonPointTitleDown, buttonPointId);
+ function initButtonLine(ind){
+ initButton(ind, buttonLineSrcUp, buttonLineSrcDown, buttonLineSrcUp, buttonLineTitleUp, buttonLineTitleDown, buttonLineId);
+ function initButtonPolygon(ind){
+ initButton(ind, buttonPolygonSrcUp, buttonPolygonSrcDown, buttonPolygonSrcUp, buttonPolygonTitleUp, buttonPolygonTitleDown, buttonPolygonId);
+ function initButtonMove(ind){
+ initButton(ind, buttonMoveSrcUp, buttonMoveSrcDown, buttonMoveSrcUp, buttonMoveTitleUp, buttonMoveTitleDown, buttonMoveId);
+ function initButtonInsert(ind){
+ initButton(ind, buttonInsertSrcUp, buttonInsertSrcDown, buttonInsertSrcUp, buttonInsertTitleUp, buttonInsertTitleDown, buttonInsertId);
+ function initButtonDelete(ind){
+ initButton(ind, buttonDeleteSrcUp, buttonDeleteSrcDown, buttonDeleteSrcUp, buttonDeleteTitleUp, buttonDeleteTitleDown, buttonDeleteId);
+ function initButton(ind, srcOver, srcDown, srcUp, titleUp, titleDown, id) {
+ parent.mb_button[ind] = document.getElementById(id);
+ parent.mb_button[ind].img_over = srcOver;
+ parent.mb_button[ind].img_on = srcDown;
+ parent.mb_button[ind].img_off = srcUp;
+ parent.mb_button[ind].title_on = titleUp;
+ parent.mb_button[ind].title_off = titleDown;
+ parent.mb_button[ind].status = 0;
+ parent.mb_button[ind].elName = id;
+ parent.mb_button[ind].fName = "";
+ parent.mb_button[ind].go = new Function ("digitizeEnable(parent.mb_button["+ind+"])");
+ parent.mb_button[ind].stop = new Function ("digitizeDisable(parent.mb_button["+ind+"])");
+ function digitizeEnable(obj) {
+ if (obj.id == buttonMoveId || obj.id == buttonInsertId || obj.id == buttonDeleteId) {
setEvent(obj);
+ else if (obj.id == buttonPointId || obj.id == buttonLineId || obj.id == buttonPolygonId){
- obj.title = "Finish editing";
- currentMemberIndex = -1;
- registerGeometry(obj);
- storeSnappingCoordinates();
- var el = parent.frames[mod_digitize_target].document;
- el.onmousemove = mod_digitize_go;
+ obj.title = obj.title_off;
@@ -296,28 +273,10 @@
- function digitize_disable(obj) {
- activeButton = null;
- obj.title = "Add point";
- closeGeometry(obj.id);
- mod_digitize_timeout();
- obj.title = "Add line";
+ function digitizeDisable(obj) {
+ if (obj.id == buttonPointId || obj.id == buttonLineId || obj.id == buttonPolygonId){
- obj.title = "Add polygon";
+ obj.title = obj.title_on;
@@ -1827,36 +1786,23 @@
document.forms[1].submit();
return false;
</script>
</head>
- <body onload="registerFunctions()">
+ <body onload="registerFunctions();displayButtons()">
<table cellpadding='0' cellspacing='0' align = center>
<tr>
<td>
<form name='dig'>
<table cellpadding='0' cellspacing='2'>
<tr>
- <td>
- <img name='Point' onmouseover='register_button(this)' id='Point' title="Add point" src = '../img/button_digitize/text_up.png'>
- </td>
- <td>
- <img name='Line' onmouseover='register_button(this)' id='Line' title="Add line" src = '../img/button_digitize/line_up.png'>
- </td>
- <td>
- <img name='Polygon' onmouseover='register_button(this)' id='Polygon' title="Add polygon" src = '../img/button_digitize/poly_up.png'>
- </td>
- <td>
- </td>
- <td>
- <img name='dragBasePoint' onmouseover='register_button(this)' id='dragBasePoint' title="Move node" src = '../img/button_digitize/move_up.png'>
- </td>
- <td>
- <img name='setBasePoint' onmouseover='register_button(this)' id='setBasePoint' title="Add node" src = '../img/button_digitize/newNode_up.png'>
- </td>
- <td>
- <img name='delBasePoint' onmouseover='register_button(this)' id='delBasePoint' title="Delete node" src = '../img/button_digitize/delNode_up.png'>
- </td>
+ <td><div id = 'divButtonPoint'></div></td>
+ <td><div id = 'divButtonLine'></div></td>
+ <td><div id = 'divButtonPolygon'></div></td>
+ <td> </td>
+ <td><div id = 'divButtonMove'></div></td>
+ <td><div id = 'divButtonInsert'></div></td>
+ <td><div id = 'divButtonDelete'></div></td>
</tr>
</table>
</form>
More information about the Mapbender_commits
