svn commit: r730 - trunk/mapbender/http: extensions javascripts
christoph at osgeo.org
Wed Aug 2 05:42:19 EDT 2006
Author: christoph
Date: 2006-08-02 09:42:19+0000
New Revision: 730
trunk/mapbender/http/extensions/geom2wfst.php
trunk/mapbender/http/javascripts/mod_digitize_tab.php
changed dialogue after wfs save/update/delete
Modified: trunk/mapbender/http/extensions/geom2wfst.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/extensions/geom2wfst.php?view=diff&rev=730&p1=trunk/mapbender/http/extensions/geom2wfst.php&p2=trunk/mapbender/http/extensions/geom2wfst.php&r1=729&r2=730
--- trunk/mapbender/http/extensions/geom2wfst.php (original)
+++ trunk/mapbender/http/extensions/geom2wfst.php 2006-08-02 09:42:19+0000
@@ -56,6 +56,7 @@
xml_parser_free($parser);
$section;
+$error=true;
$result="";
foreach ($values as $element) {
$element[tag] = sepNameSpace($element[tag]);
@@ -70,7 +71,7 @@
$section = "status";
if ($section == "status" && strtoupper($element[tag]) == "SUCCESS") {
- $result = "Success!";
+ $result = "Success.";
$error = false;
@@ -85,6 +86,7 @@
echo $result;
echo "<script language='javascript'>";
echo "window.focus();";
+ echo "alert('An error has occured.');\n";
echo "</script>";
else {
Modified: trunk/mapbender/http/javascripts/mod_digitize_tab.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_digitize_tab.php?view=diff&rev=730&p1=trunk/mapbender/http/javascripts/mod_digitize_tab.php&p2=trunk/mapbender/http/javascripts/mod_digitize_tab.php&r1=729&r2=730
--- trunk/mapbender/http/javascripts/mod_digitize_tab.php (original)
+++ trunk/mapbender/http/javascripts/mod_digitize_tab.php 2006-08-02 09:42:19+0000
@@ -968,7 +968,7 @@
<body onload="registerFunctions();displayButtons();">
<table cellpadding='0' cellspacing='0' align = center><tr><td><div id='digButtons'></div></td></tr></table>
<div id = 'listOfGeometries'></div>
- <form name='sendForm' action='../extensions/geom2wfst.php' method='POST' TARGET='wfsupdate'>
+ <form name='sendForm' action='../extensions/geom2wfst.php' method='POST' TARGET='_blank'>
<input type='hidden' name='url'><input type='hidden' name='filter'><input type='hidden' name='onlineresource'>
</form>
<iframe id='wfsupdate' name='wfsupdate' width=0 height=0></iframe>
More information about the Mapbender_commits
