svn commit: r752 - trunk/mapbender/http/php/mod_monitorCapabilities_main.php
christoph at osgeo.org
Thu Aug 10 08:05:50 EDT 2006
Author: christoph
Date: 2006-08-10 12:05:50+0000
New Revision: 752
distinction browser/cli now seems to work
added some debugging code
Modified: trunk/mapbender/http/php/mod_monitorCapabilities_main.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_monitorCapabilities_main.php?view=diff&rev=752&p1=trunk/mapbender/http/php/mod_monitorCapabilities_main.php&p2=trunk/mapbender/http/php/mod_monitorCapabilities_main.php&r1=751&r2=752
--- trunk/mapbender/http/php/mod_monitorCapabilities_main.php (original)
+++ trunk/mapbender/http/php/mod_monitorCapabilities_main.php 2006-08-10 12:05:50+0000
@@ -25,29 +25,34 @@
db_select_db(DB,$con);
$admin = new administration();
-$filename_array = explode("/", $PHP_SELF);
-$filename = $filename_array[count($filename_array)-1];
//$user = "root";
+$user = "";
$gui = "";
+$cl = 0;
// retrieve username and gui_id
-if ($_SERVER["argv"][0] != $filename) {
+if ($_REQUEST['user']) {
+ $cl = 0;
//browser
+ echo "browser";
$user = $_REQUEST['user'];
$gui = $_REQUEST['gui'];
-else {
+elseif ($_SERVER["argv"][1]) {
+ $cl = 1;
//command line
$p1 = $_SERVER["argv"][1];
$p2 = $_SERVER["argv"][2];
if (substr($p1, 0,5) == "user:") {
- $user = substr($p1);
+ $user = substr($p1, 5);
if (substr($p2, 0,4) == "gui:") {
- $gui = substr($p2);
+ $gui = substr($p2, 4);
+else {
+ echo "Please specify a username!\n";die();
$userid = $admin->getUserIdByUserName($user);
@@ -72,9 +77,12 @@
$wms_id_own = $admin->getWmsByOwnGuis($ownguis);
// initialise monitoring processes
-echo "Starting monitoring cycle...\n<br/>\n<br/>";
-echo "WMS services are requested for availabiltiy.\n<br/> ";
-echo "Capabilities documents are requested and all changes synchronized with the database cache.\n<br>\n<br>";
+echo "Starting monitoring cycle...\n\n";
+if ($cl == 0) echo "<br/><br/>";
+echo "WMS services are requested for availability.\n";
+if ($cl == 0) echo "<br/>";
+echo "Capabilities documents are requested and all changes synchronized with the database cache.\n\n";
$time = strval(time()-2);
@@ -113,17 +121,20 @@
for ($k=0; $k<count($wms_id_own); $k++) {
if (intval(AUTO_UPDATE)) {
- $exec = PHP_PATH . "php mod_monitorCapabilities_write.php ".$wms_id_own[$k]." ".$time." 1 > ../tmp/output.txt &";
+ $exec = PHP_PATH . "php mod_monitorCapabilities_write.php ".$wms_id_own[$k]." ".$time." 1 > ../tmp/output_".$time."_".$wms_id_own[$k].".txt &";
else {
- $exec = PHP_PATH . "php mod_monitorCapabilities_write.php ".$wms_id_own[$k]." ".$time." 0 > ../tmp/output.txt &";
+ $exec = PHP_PATH . "php mod_monitorCapabilities_write.php ".$wms_id_own[$k]." ".$time." 0 > ../tmp/output_".$time."_".$wms_id_own[$k].".txt &";
exec($exec);
echo "Monitoring Cycle completed (total: " . count($wms_id_own) . " wms).\n\n";
set_time_limit(2*TIME_LIMIT);
// wait until all monitoring processes are finished
+echo "please wait " . TIME_LIMIT . " seconds for the monitoring to finish...\n\n";
sleep(TIME_LIMIT);
$sql = "SELECT fkey_wms_id, status, status_comment, timestamp_begin, timestamp_end, upload_url FROM mb_monitor WHERE upload_id = $1";
@@ -154,6 +165,8 @@
$new_res = db_prep_query($new_sql,$new_v,$new_t);
// compose mail message
+ echo $wms_id[$i] . ": status " . $status[$i] . "\n";
+ if ($cl == 0) echo "<br/><br/>";
if ($status[$i] == -1) {
$body .= $admin->getWmsTitleByWmsId($wms_id[$i]) . " (" . $wms_id[$i] . "): " . $comment[$i] . "\n\n";
More information about the Mapbender_commits
