svn commit: r761 - trunk/mapbender/http/php/mod_editUser.php
uli at osgeo.org
uli at osgeo.org
Thu Aug 31 09:51:41 EDT 2006
Author: uli
Date: 2006-08-31 13:51:41+0000
New Revision: 761
function setPassword removed
encode password with php-md5
Modified: trunk/mapbender/http/php/mod_editUser.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_editUser.php?view=diff&rev=761&p1=trunk/mapbender/http/php/mod_editUser.php&p2=trunk/mapbender/http/php/mod_editUser.php&r1=760&r2=761
--- trunk/mapbender/http/php/mod_editUser.php (original)
+++ trunk/mapbender/http/php/mod_editUser.php 2006-08-31 13:51:41+0000
@@ -20,7 +20,7 @@
import_request_variables("PG");
require_once("../../conf/mapbender.conf");
-$con = db_connect($DBSERVER,$OWNER,$PW);
+$con = db_connect(DBSERVER,OWNER,PW);
db_select_db(DB,$con);
require_once("../php/mb_validatePermission.php");
$self = $PHP_SELF . "?".SID."&guiID=".$_REQUEST["guiID"]."&elementID=".$_REQUEST["elementID"];
@@ -95,23 +95,6 @@
</head>
<body>
<?php
-function setPassword($password){
- if($password != ""){
- if (SYS_DBTYPE=="mysql"){
- $pw = "password('".$password."')";
- }else{
- if (MD5 == 'false'){
- $pw = $password;
- }else{
- $pw = "md5('".$password."')";
- return $pw;
- else{
- return false;
#delete
if($action == 'delete'){
$sql = "DELETE FROM mb_user WHERE mb_user_id = $1";
@@ -164,7 +147,7 @@
$res = db_prep_query($sql,$v,$t);
if($password != ''){
$sql = "UPDATE mb_user SET mb_user_password = $1 WHERE mb_user_name = $2 AND mb_user_id = $3";
- $v = array(setPassword($password), $name, $selected_user);
+ $v = array(md5($password), $name, $selected_user);
$t = array('s','s','i');
if($password && $res){
More information about the Mapbender_commits
