svn commit: r464 - trunk/mapbender/http/img/button_gray
vera_schulze at osgeo.org vera_schulze at osgeo.org
Mon Jun 19 06:46:33 EDT 2006
Author: vera_schulze
Date: 2006-06-19 10:46:33+0000
New Revision: 464
Added:
   trunk/mapbender/http/img/button_gray/select_choose_off.png   (contents, props changed)
   trunk/mapbender/http/img/button_gray/select_choose_on.png   (contents, props changed)
   trunk/mapbender/http/img/button_gray/select_choose_over.png   (contents, props changed)
   trunk/mapbender/http/img/button_gray/select_extent_off.png   (contents, props changed)
   trunk/mapbender/http/img/button_gray/select_extent_on.png   (contents, props changed)
   trunk/mapbender/http/img/button_gray/select_extent_over.png   (contents, props changed)
   trunk/mapbender/http/img/button_gray/select_point_off.png   (contents, props changed)
   trunk/mapbender/http/img/button_gray/select_point_on.png   (contents, props changed)
   trunk/mapbender/http/img/button_gray/select_point_over.png   (contents, props changed)
   trunk/mapbender/http/img/button_gray/select_polygon_off.png   (contents, props changed)
   trunk/mapbender/http/img/button_gray/select_polygon_on.png   (contents, props changed)
   trunk/mapbender/http/img/button_gray/select_polygon_over.png   (contents, props changed)
   trunk/mapbender/http/img/button_gray/select_rectangle_off.png   (contents, props changed)
   trunk/mapbender/http/img/button_gray/select_rectangle_on.png   (contents, props changed)
   trunk/mapbender/http/img/button_gray/select_rectangle_over.png   (contents, props changed)
new buttons_gray select...
Added: trunk/mapbender/http/img/button_gray/select_choose_off.png
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/img/button_gray/select_choose_off.png?view=auto&rev=464
Binary file. No diff available.
Added: trunk/mapbender/http/img/button_gray/select_choose_on.png
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/img/button_gray/select_choose_on.png?view=auto&rev=464
Added: trunk/mapbender/http/img/button_gray/select_choose_over.png
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/img/button_gray/select_choose_over.png?view=auto&rev=464
Added: trunk/mapbender/http/img/button_gray/select_extent_off.png
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/img/button_gray/select_extent_off.png?view=auto&rev=464
Added: trunk/mapbender/http/img/button_gray/select_extent_on.png
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/img/button_gray/select_extent_on.png?view=auto&rev=464
Added: trunk/mapbender/http/img/button_gray/select_extent_over.png
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/img/button_gray/select_extent_over.png?view=auto&rev=464
Added: trunk/mapbender/http/img/button_gray/select_point_off.png
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/img/button_gray/select_point_off.png?view=auto&rev=464
Added: trunk/mapbender/http/img/button_gray/select_point_on.png
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/img/button_gray/select_point_on.png?view=auto&rev=464
Added: trunk/mapbender/http/img/button_gray/select_point_over.png
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/img/button_gray/select_point_over.png?view=auto&rev=464
Added: trunk/mapbender/http/img/button_gray/select_polygon_off.png
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/img/button_gray/select_polygon_off.png?view=auto&rev=464
Added: trunk/mapbender/http/img/button_gray/select_polygon_on.png
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/img/button_gray/select_polygon_on.png?view=auto&rev=464
Added: trunk/mapbender/http/img/button_gray/select_polygon_over.png
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/img/button_gray/select_polygon_over.png?view=auto&rev=464
Added: trunk/mapbender/http/img/button_gray/select_rectangle_off.png
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/img/button_gray/select_rectangle_off.png?view=auto&rev=464
Added: trunk/mapbender/http/img/button_gray/select_rectangle_on.png
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/img/button_gray/select_rectangle_on.png?view=auto&rev=464
Added: trunk/mapbender/http/img/button_gray/select_rectangle_over.png
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/img/button_gray/select_rectangle_over.png?view=auto&rev=464
More information about the Mapbender_commits mailing list
