svn commit: r234 - trunk/mapbender/http/php/mod_filteredGroup_filteredGui.php
uli at osgeo.org
uli at osgeo.org
Thu May 11 04:13:40 EDT 2006
Author: uli
Date: 2006-05-11 08:13:40+0000
New Revision: 234
trunk/mapbender/http/php/mod_filteredGroup_filteredGui.php (contents, props changed)
db_prep_query included
verification of user permissions
Modified: trunk/mapbender/http/php/mod_filteredGroup_filteredGui.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_filteredGroup_filteredGui.php?view=diff&rev=234&p1=trunk/mapbender/http/php/mod_filteredGroup_filteredGui.php&p2=trunk/mapbender/http/php/mod_filteredGroup_filteredGui.php&r1=233&r2=234
--- trunk/mapbender/http/php/mod_filteredGroup_filteredGui.php (original)
+++ trunk/mapbender/http/php/mod_filteredGroup_filteredGui.php 2006-05-11 08:13:40+0000
@@ -1,6 +1,7 @@
<?php
-# $Id: mod_filteredGroup_filteredGui.php,v 1.15 2006/03/09 10:42:29 uli_rothstein Exp $
-# $Header: /cvsroot/mapbender/mapbender/http/php/mod_filteredGroup_filteredGui.php,v 1.15 2006/03/09 10:42:29 uli_rothstein Exp $
+# $Id$
+# http://www.mapbender.org/index.php/Administration
# Copyright (C) 2002 CCGIS
# This program is free software; you can redistribute it and/or modify
@@ -17,13 +18,12 @@
# along with this program; if not, write to the Free Software
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-session_start();
import_request_variables("PG");
-require_once("../php/mb_validateSession.php");
require_once("../../conf/mapbender.conf");
-$con = db_connect($DBSERVER,$OWNER,$PW);
+$con = db_connect(DBSERVER,OWNER,PW);
db_select_db(DB,$con);
-$gui_id = $_SESSION["mb_user_gui"];
+require_once("../php/mb_validatePermission.php");
+$self = $PHP_SELF . "?".SID."&guiID=".$_REQUEST["guiID"]."&elementID=".$_REQUEST["elementID"];
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
@@ -37,8 +37,8 @@
<script language="JavaScript">
function validate(wert){
if(document.forms[0]["selected_group"].selectedIndex == -1){
- document.getElementsByName("selected_group")[0].style.backgroundColor = '#ff0000';
- return;
+ document.getElementsByName("selected_group")[0].style.backgroundColor = '#ff0000';
+ return;
}else{
if(wert == "remove"){
if(document.forms[0]["remove_gui[]"].selectedIndex == -1){
@@ -63,10 +63,6 @@
</head>
<body>
<?php
-require_once("../../conf/mapbender.conf");
-db_select_db(DB,$con);
require_once("../php/mb_getGUIs.php");
$fieldHeight = 20;
@@ -83,17 +79,21 @@
$logged_user_id=$_SESSION["mb_user_id"];
-/*handle remove, update and insert**************************************************************************************/
+/*handle remove, update and insert*****************************************************************/
if($insert){
if(count($selected_gui)>0){
for($i=0; $i<count($selected_gui); $i++){
$exists = false;
- $sql_insert = "SELECT * from gui_mb_group where fkey_mb_group_id = '".$selected_group."' and fkey_gui_id = '".$selected_gui[$i]."'";
- $res_insert = db_query($sql_insert);
+ $sql_insert = "SELECT * from gui_mb_group where fkey_mb_group_id = $1 and fkey_gui_id = $2 ";
+ $v = array($selected_group,$selected_gui[$i]);
+ $t = array('i','s');
+ $res_insert = db_prep_query($sql_insert,$v,$t);
while(db_fetch_row($res_insert)){$exists = true;}
if($exists == false){
- $sql_insert = "INSERT INTO gui_mb_group(fkey_mb_group_id, fkey_gui_id) VALUES('$selected_group', '".$selected_gui[$i]."');";
+ $sql_insert = "INSERT INTO gui_mb_group(fkey_mb_group_id, fkey_gui_id) VALUES($1, $2)";
@@ -101,40 +101,41 @@
if($remove){
if(count($remove_gui)>0){
for($i=0; $i<count($remove_gui); $i++){
- $sql_remove = "DELETE FROM gui_mb_group WHERE fkey_gui_id = '".$remove_gui[$i]."' and fkey_mb_group_id = '$selected_group'";
- db_query($sql_remove);
+ $sql_remove = "DELETE FROM gui_mb_group WHERE fkey_gui_id = $1 and fkey_mb_group_id = $2";
+ $v = array($remove_gui[$i],$selected_group);
+ $t = array('s','i');
+ db_prep_query($sql_remove,$v,$t);
-/*get allocated gui ********************************************************************************************/
-#$sql_gui = "SELECT * FROM gui ORDER BY gui_name";
-#$sql_gui = "SELECT gui.gui_id, gui.gui_name, gui_mb_user.fkey_mb_user_id ";
-#$sql_gui .= "FROM gui INNER JOIN gui_mb_user ON gui.gui_id = gui_mb_user.fkey_gui_id ";
-#$sql_gui .= "WHERE gui_mb_user.fkey_mb_user_id='".$logged_user_id."'";
+/*get allocated gui ******************************************************************************/
$arrayGuis=mb_getGUIs($logged_user_id);
+$v = array();
+$t = array();
$sql_gui = "SELECT * FROM gui WHERE gui_id IN (";
for($i=0; $i<count($arrayGuis); $i++){
if($i>0){ $sql_gui .= ",";}
- $sql_gui .= "'".$arrayGuis[$i]."'";
+ $sql_gui .= "$".($i+1);
+ array_push($v,$arrayGuis[$i]);
+ array_push($t,'s');
$sql_gui.= ") ORDER BY gui_name";
-$res_gui = db_query($sql_gui);
+$res_gui = db_prep_query($sql_gui,$v,$t);
while($row = db_fetch_array($res_gui)){
$gui_id_array[$cnt_gui] = $row["gui_id"];
$gui_name[$cnt_gui] = $row["gui_name"];
$cnt_gui++;
-/*get owner group **********************************************************************************************/
-#$sql_group = "SELECT * FROM mb_group ORDER BY mb_group_name";
-$sql_group = "SELECT * FROM mb_group WHERE mb_group_owner='".$logged_user_id."' ORDER BY mb_group_name";
-$res_group = db_query($sql_group);
+/*get owner group *********************************************************************************/
+$sql_group = "SELECT * FROM mb_group WHERE mb_group_owner = $1 ORDER BY mb_group_name";
+$v = array($logged_user_id);
+$t = array('i');
+$res_group = db_prep_query($sql_group,$v,$t);
while($row = db_fetch_array($res_group)){
$group_id[$cnt_group] = $row["mb_group_id"];
$group_name[$cnt_group] = $row["mb_group_name"];
@@ -143,26 +144,37 @@
/*get allocated gui from selected_group******************************************************************************/
+$v = array();
+$t = array();
$sql_group_mb_gui = "SELECT gui.gui_id, gui.gui_name, gui_mb_group.fkey_mb_group_id FROM gui_mb_group ";
$sql_group_mb_gui .= " JOIN gui ON gui_mb_group.fkey_gui_id = gui.gui_id ";
-$sql_group_mb_gui .= "WHERE gui_mb_group.fkey_mb_group_id=";
+$sql_group_mb_gui .= "WHERE gui_mb_group.fkey_mb_group_id = $1 ";
if(!$selected_group){
- if($group_id[0] > 0)
- $sql_group_mb_gui .= "'".$group_id[0]."'";
- else
- $sql_group_mb_gui .= "NULL";
+ if($group_id[0] > 0){
+ array_push($v,$group_id[0]);
+ array_push($t,'i');
+ else{
+ array_push($v, "NULL");
+else if($selected_group){
+ array_push($v,$selected_group);
-if($selected_group){$sql_group_mb_gui .= $selected_group;}
$sql_group_mb_gui .= " AND gui.gui_id IN (";
+$c = 2;
if($i>0){ $sql_group_mb_gui .= ",";}
- $sql_group_mb_gui .= "'".$arrayGuis[$i]."'";
+ $sql_group_mb_gui .= "$".$c;
+ $c++;
$sql_group_mb_gui .= ") ORDER BY gui.gui_name";
-$res_group_mb_gui = db_query($sql_group_mb_gui);
+$res_group_mb_gui = db_prep_query($sql_group_mb_gui,$v,$t);
while($row = db_fetch_array($res_group_mb_gui)){
$gui_id_group[$cnt_gui_group] = $row["gui_id"];
$gui_name_group[$cnt_gui_group] = $row["gui_name"];
@@ -170,9 +182,9 @@
/*INSERT HTML*/
-echo "<form name='form1' action='" . $PHP_SELF . "?".SID."&e_id_css=".$_REQUEST["e_id_css"]."' method='post'>";
+echo "<form name='form1' action='" . $self ."' method='post'>";
-/*insert all group in selectbox*************************************************************************************/
+/*insert all group in selectbox********************************************************************/
echo "<div class='text1'>GROUP: </div>";
echo "<select style='background:#ffffff' class='select1' name='selected_group' onChange='submit()' size='10'>";
for($i=0; $i<$cnt_group; $i++){
@@ -184,7 +196,7 @@
echo "</select>";
-/*insert all gui in selectbox**************************************************************************/
+/*insert all gui in selectbox**********************************************************************/
echo "<div class='text2'>GUI:</div>";
echo "<select style='background:#ffffff' class='select2' multiple='multiple' name='selected_gui[]' size='$fieldHeight' >";
for($i=0; $i<$cnt_gui; $i++){
@@ -192,7 +204,7 @@
echo "</select>";
-/*Button****************************************************************************************************/
+/*Button*******************************************************************************************/
echo "<div class='button1'><input type='button' value='==>' onClick='validate(\"insert\")'></div>";
echo "<input type='hidden' name='insert'>";
@@ -200,7 +212,7 @@
echo "<div class='button2'><input type='button' value='<==' onClick='validate(\"remove\")'></div>";
echo "<input type='hidden' name='remove'>";
-/*insert group_gui_dependence in selectbox**************************************************/
+/*insert group_gui_dependence in selectbox*********************************************************/
echo "<div class='text3'>SELECTED GUI:</div>";
echo "<select style='background:#ffffff' class='select3' multiple='multiple' name='remove_gui[]' size='$fieldHeight' >";
for($i=0; $i<$cnt_gui_group; $i++){
More information about the Mapbender_commits
