svn commit: r236 - trunk/mapbender/http/php/mod_filteredGui_filteredGroup.php
uli at osgeo.org
uli at osgeo.org
Thu May 11 04:59:21 EDT 2006
Author: uli
Date: 2006-05-11 08:59:20+0000
New Revision: 236
trunk/mapbender/http/php/mod_filteredGui_filteredGroup.php (contents, props changed)
db_prep_query included
verification of user permissions
Modified: trunk/mapbender/http/php/mod_filteredGui_filteredGroup.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_filteredGui_filteredGroup.php?view=diff&rev=236&p1=trunk/mapbender/http/php/mod_filteredGui_filteredGroup.php&p2=trunk/mapbender/http/php/mod_filteredGui_filteredGroup.php&r1=235&r2=236
--- trunk/mapbender/http/php/mod_filteredGui_filteredGroup.php (original)
+++ trunk/mapbender/http/php/mod_filteredGui_filteredGroup.php 2006-05-11 08:59:20+0000
@@ -1,6 +1,7 @@
<?php
-# $Id: mod_filteredGui_filteredGroup.php,v 1.14 2006/03/09 10:54:39 uli_rothstein Exp $
-# $Head$
+# $Id$
+# http://www.mapbender.org/index.php/Administration
# Copyright (C) 2002 CCGIS
# This program is free software; you can redistribute it and/or modify
@@ -17,14 +18,12 @@
# along with this program; if not, write to the Free Software
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-session_start();
import_request_variables("PG");
-require_once("../php/mb_validateSession.php");
require_once("../../conf/mapbender.conf");
-$con = db_connect($DBSERVER,$OWNER,$PW);
+$con = db_connect(DBSERVER,OWNER,PW);
db_select_db(DB,$con);
-$gui_id = $_SESSION["mb_user_gui"];
+require_once("../php/mb_validatePermission.php");
+$self = $PHP_SELF . "?".SID."&guiID=".$_REQUEST["guiID"]."&elementID=".$_REQUEST["elementID"];
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
@@ -64,9 +63,6 @@
</head>
<body>
<?php
-require_once("../../conf/mapbender.conf");
-db_select_db(DB,$con);
require_once("../php/mb_getGUIs.php");
@@ -83,17 +79,21 @@
$logged_user_name=$_SESSION["mb_user_name"];
$logged_user_id=$_SESSION["mb_user_id"];
-/*handle remove, update and insert**************************************************************************************/
+/*handle remove, update and insert****************************************************************/
if($insert){
if(count($selected_group)>0){
for($i=0; $i<count($selected_group); $i++){
$exists = false;
- $sql_insert = "SELECT * from gui_mb_group where fkey_gui_id = '".$selected_gui."' and fkey_mb_group_id = '".$selected_group[$i]."'";
- $res_insert = db_query($sql_insert);
+ $sql_insert = "SELECT * from gui_mb_group where fkey_gui_id = $1 and fkey_mb_group_id = $2";
+ $v = array($selected_gui,$selected_group[$i]);
+ $t = array('s','i');
+ $res_insert = db_prep_query($sql_insert,$v,$t);
while(db_fetch_row($res_insert)){$exists = true;}
if($exists == false){
- $sql_insert = "INSERT INTO gui_mb_group(fkey_gui_id, fkey_mb_group_id) VALUES('$selected_gui', '".$selected_group[$i]."');";
+ $sql_insert = "INSERT INTO gui_mb_group(fkey_gui_id, fkey_mb_group_id) VALUES($1, $2);";
@@ -101,63 +101,69 @@
if($remove){
if(count($remove_group)>0){
for($i=0; $i<count($remove_group); $i++){
- $sql_remove = "DELETE FROM gui_mb_group WHERE fkey_mb_group_id = '".$remove_group[$i]."' and fkey_gui_id = '$selected_gui'";
- db_query($sql_remove);
+ $sql_remove = "DELETE FROM gui_mb_group WHERE fkey_mb_group_id = $1 and fkey_gui_id = $2";
+ $v = array($remove_group[$i],$selected_gui);
+ $t = array('i','s');
+ db_prep_query($sql_remove,$v,$t);
-/*get allocated gui ********************************************************************************************/
+/*get allocated gui ******************************************************************************/
$arrayGuis=mb_getGUIs($logged_user_id);
+$v = array();
+$t = array();
$sql_gui = "SELECT * FROM gui WHERE gui_id IN (";
for($i=0; $i<count($arrayGuis); $i++){
if($i>0){ $sql_gui .= ",";}
- $sql_gui .= "'".$arrayGuis[$i]."'";
+ $sql_gui .= "$".($i+1);
+ array_push($v,$arrayGuis[$i]);
+ array_push($t,'s');
$sql_gui.= ") ORDER BY gui_name";
-$res_gui = db_query($sql_gui);
+$res_gui = db_prep_query($sql_gui,$v,$t);
while($row = db_fetch_array($res_gui)){
$gui_id_array[$cnt_gui] = $row["gui_id"];
$gui_name[$cnt_gui] = $row["gui_name"];
$cnt_gui++;
-/*get owner groups **********************************************************************************************/
+/*get owner groups ********************************************************************************/
-$sql_group = "SELECT * FROM mb_group WHERE mb_group_owner='".$logged_user_id."' ORDER BY mb_group_name";
-$res_group = db_query($sql_group);
+$sql_group = "SELECT * FROM mb_group WHERE mb_group_owner = $1 ORDER BY mb_group_name";
+$v = array($logged_user_id);
+$t = array('i');
+$res_group = db_prep_query($sql_group,$v,$t);
while($row = db_fetch_array($res_group)){
$group_id[$cnt_group] = $row["mb_group_id"];
$group_name[$cnt_group] = $row["mb_group_name"];
$cnt_group++;
-/*get owner groups from selected gui******************************************************************************/
+/*get owner groups from selected gui***************************************************************/
$sql_gui_group = "SELECT mb_group.mb_group_id, mb_group.mb_group_name, gui_mb_group.fkey_gui_id FROM gui_mb_group ";
$sql_gui_group .= "INNER JOIN mb_group ON gui_mb_group.fkey_mb_group_id = mb_group.mb_group_id ";
-$sql_gui_group .= "WHERE gui_mb_group.fkey_gui_id= '";
+$sql_gui_group .= "WHERE gui_mb_group.fkey_gui_id = $1 ";
-if(!$selected_gui){$sql_gui_group .= $gui_id_array[0];}
-if($selected_gui){$sql_gui_group .= $selected_gui;}
-$sql_gui_group .= "' AND mb_group.mb_group_owner = '".$logged_user_id."'";
+if(!$selected_gui){$v = array($gui_id_array[0]);}
+if($selected_gui){$v = array($selected_gui);}
+$t = array('s');
+$sql_gui_group .= " AND mb_group.mb_group_owner = $2 ";
+array_push($v,$logged_user_id);
+array_push($t,'i');
$sql_gui_group .= " ORDER BY mb_group.mb_group_name";
-$res_gui_group = db_query($sql_gui_group);
+$res_gui_group = db_prep_query($sql_gui_group,$v,$t);
while($row = db_fetch_array($res_gui_group)){
$group_id_gui[$cnt_gui_group] = $row["mb_group_id"];
$group_name_gui[$cnt_gui_group] = $row["mb_group_name"];
$cnt_gui_group++;
/*INSERT HTML*/
-echo "<form name='form1' action='" . $PHP_SELF . "?".SID."&e_id_css=".$_REQUEST["e_id_css"]."' method='post'>";
+echo "<form name='form1' action='" . $self ."' method='post'>";
-/*insert guis in selectbox*************************************************************************************/
+/*insert guis in selectbox*************************************************************************/
echo "<div class='text1'>GUI: </div>";
echo "<select style='background:#ffffff' class='select1' name='selected_gui' onChange='submit()' size='10'>";
for($i=0; $i<$cnt_gui; $i++){
More information about the Mapbender_commits
