svn commit: r261 - trunk/mapbender/http/javascripts/mod_export_image.php
vera_schulze at osgeo.org
Fri May 12 06:46:25 EDT 2006
Author: vera_schulze
Date: 2006-05-12 10:46:25+0000
New Revision: 261
Code cleaning ready
Modified: trunk/mapbender/http/javascripts/mod_export_image.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_export_image.php?view=diff&rev=261&p1=trunk/mapbender/http/javascripts/mod_export_image.php&p2=trunk/mapbender/http/javascripts/mod_export_image.php&r1=260&r2=261
--- trunk/mapbender/http/javascripts/mod_export_image.php (original)
+++ trunk/mapbender/http/javascripts/mod_export_image.php 2006-05-12 10:46:25+0000
@@ -57,7 +57,7 @@
$sql = "SELECT * from gui_element WHERE fkey_gui_id = '".$_SESSION["mb_user_gui"]."' AND e_id = $1";
$v = array($mb_module_id);
$t = array('s');
-$res = db_Prep_query($sql, $v, $t);
+$res = db_prep_query($sql, $v, $t);
echo "<script type='text/javascript'>";
#echo "var mb_user_resolution = ".$_SESSION["mb_user_resolution"]." / 2.54;";
More information about the Mapbender_commits
