svn commit: r273 - trunk/mapbender/http/javascripts/mod_savewmc.php
vera_schulze at osgeo.org
Mon May 15 04:48:44 EDT 2006
Author: vera_schulze
Date: 2006-05-15 08:48:44+0000
New Revision: 273
trunk/mapbender/http/javascripts/mod_savewmc.php (contents, props changed)
Code cleaning ready
Modified: trunk/mapbender/http/javascripts/mod_savewmc.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_savewmc.php?view=diff&rev=273&p1=trunk/mapbender/http/javascripts/mod_savewmc.php&p2=trunk/mapbender/http/javascripts/mod_savewmc.php&r1=272&r2=273
--- trunk/mapbender/http/javascripts/mod_savewmc.php (original)
+++ trunk/mapbender/http/javascripts/mod_savewmc.php 2006-05-15 08:48:44+0000
@@ -1,6 +1,6 @@
<?php
-#$Id$
-#$Header$
+# $Id: mod_savewmc.php 264 2006-05-12 11:07:19Z vera_schulze
+# http://www.mapbender.org/index.php/mod_savewmc.php
# Copyright (C) 2002 CCGIS
# This program is free software; you can redistribute it and/or modify
@@ -17,430 +17,378 @@
# along with this program; if not, write to the Free Software
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
$gui_id = $_REQUEST["gui_id"];
require_once("../../conf/mapbender.conf");
$con = db_connect($DBSERVER,$OWNER,$PW);
db_select_db(DB,$con);
-$sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = 'savewmc' AND fkey_gui_id = '".$gui_id."'";
-$res = db_query($sql);
+$sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = 'savewmc' AND fkey_gui_id = $1";
+$v = array($gui_id);
+$t = array('s');
+$res = db_prep_query($sql, $v, $t);
$cnt = 0;
while($row = db_fetch_array($res)){
- $e_src = $row["e_src"];
- $e_target = $row["e_target"];
- $cnt++;
+ $e_src = $row["e_src"];
+ $e_target = $row["e_target"];
+ $cnt++;
+if($cnt > 1){
+ echo "alert('savewmc: ID not unique!');";
-if($cnt > 1){ echo "alert('savewmc: ID not unique!');";}
echo "mod_savewmc_target = '".$e_target."';";
var mod_savewmc_img = new Image(); mod_savewmc_img.src = "<?php echo $e_src; ?>";
//var mod_savewmc_img_over = new Image(); mod_savewmc_img_over.src = "<?php echo preg_replace("/_off/","_over",$e_src); ?>";
function mod_savewmc(obj){
- var user = "<?php echo $_SESSION["mb_user_id"]; ?>";
- var ind = getMapObjIndexByName(mod_savewmc_target);
- var generalTitle = prompt("Save WMC as...");
- if (generalTitle != null) {
- var wmc = "";
- // ViewContext variables
- var version = "1.0.0";
- var id = "<?php echo $_SESSION["mb_user_id"] . "_";?>";
- var jetzt = new Date();
- id += jetzt.getTime();
- // General variables
- var generalWidth = mb_mapObj[ind].width;
- var generalHeight = mb_mapObj[ind].height;
- var generalBboxSrs = mb_mapObj[ind].epsg;
- var arrayBBox = mb_mapObj[ind].extent.split(",");
- var generalBboxMinx = parseFloat(arrayBBox[0]);
- var generalBboxMiny = parseFloat(arrayBBox[1]);
- var generalBboxMaxx = parseFloat(arrayBBox[2]);
- var generalBboxMaxy = parseFloat(arrayBBox[3]);
- var generalName = "Mapbender WMC"; // TO do : insert proper data
- var generalKeywords = ""; // TO do : insert proper data
- var generalAbstract = ""; // TO do : insert proper data
- var generalLogoUrl = ""; // TO do : insert proper data
- var generalLogoUrlWidth = ""; // TO do : insert proper data
- var generalLogoUrlHeight = ""; // TO do : insert proper data
- var generalLogoUrlFormat = ""; // TO do : insert proper data
- var generalDescriptionUrl = ""; // TO do : insert proper data
- var generalContactPerson = "";
- var generalContactOrganization = "";
- var generalContactPosition = "";
- var generalContactAddressType = "";
- var generalContactAddress = "";
- var generalContactCity = "";
- var generalContactStateOrProvince = "";
- var generalContactPostCode = "";
- var generalContactCountry = "";
- var generalContactVoiceTelephone = "";
- var generalContactFacsimileTelephone = "";
- var generalContactElectronicMailAddress = "";
- // Missing: Extension
- // LayerList variables
- var layerHidden = "";
- var layerQueryable = "";
- var layerAbstract = "";
- var layerName = "";
- var layerSrs = "";
- var layerDataUrl = "";
- var layerMetadataUrl = "";
- var layerFormat = "";
- var layerFormat_current = "";
- var layerStyle_current = "";
- var layerStyle_name = "";
- var layerStyle_title = "";
- var layerStyle_legendURL = "";
- var layerStyle_legendURL_width = "";
- var layerStyle_legendURL_height = "";
- var layerStyle_legendURL_format = "";
- //ViewContext
- wmc += "<?xml version=\"1.0\" encoding=\"<?php echo CHARSET; ?>\" ?>\n";
-// wmc += "<!ENTITY amp \"&#38;#38;\">\n";
- wmc += "<ViewContext version=\"" + version + "\" ";
- wmc += "id = \"" + id + "\" ";
- wmc += "xmlns=\"http://www.opengis.net/context\" xmlns:xlink=\"http://www.w3.org/1999/xlink\" xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:SchemaLocation=\"http://schemas.opengis.net/context/1.0.0/context.xsd\" ";
- wmc += ">\n";
- //General
- wmc += "\t<General>\n";
- if (generalWidth && generalHeight) {
- wmc += "\t\t<Window width=\"" + generalWidth + "\" height=\"" + generalHeight + "\" />\n";
- wmc += "\t\t<BoundingBox SRS=\"" + generalBboxSrs + "\" minx =\"" + generalBboxMinx + "\" ";
- wmc += "miny =\"" + generalBboxMiny + "\" maxx =\"" + generalBboxMaxx + "\" maxy =\"" + generalBboxMaxy + "\" />\n";
- wmc += "\t\t<Name>" + generalName + "</Name>\n";
- wmc += "\t\t<Title>" + generalTitle + "</Title>\n";
- if (generalKeywords) {
- wmc += "\t\t<KeywordList>\n";
- wmc += "\t\t\t<Keyword>" + generalKeywords + "</Keyword>\n";
- if (generalAbstract) {
- wmc += "\t\t<Abstract>" + generalAbstract + "</Abstract>\n";
- if (generalLogoUrlWidth && generalLogoUrlHeight && generalLogoUrlFormat && generalLogoUrl) {
- wmc += "\t\t<LogoURL width = \"" + generalLogoUrlWidth + "\" ";
- wmc += "height = \"" + generalLogoUrlHeight + "\" ";
- wmc += "format = \"" + generalLogoUrlFormat + "\">\n";
- wmc += "\t\t\t<OnlineResource xmlns:xlink=\"http://www.w3.org/1999/xlink\" xlink:type = \"simple\" xlink:href=\"" + generalLogoUrl + "\" />\n";
- wmc += "\t\t</LogoUrl>\n";
- if (generalDescriptionUrl) {
- wmc += "\t\t<DescriptionURL>\n";
- wmc += "\t\t\t<OnlineResource xmlns:xlink=\"http://www.w3.org/1999/xlink\" xlink:type = \"simple\" xlink:href=\"" + generalDescriptionUrl + "\" />\n";
- wmc += "\t\t</DescriptionUrl>\n";
- if (generalContactElectronicMailAddress || generalContactOrganization ||
- generalContactPerson || generalContactPosition || generalContactAddressType ||
- generalContactAddress || generalContactCity || generalContactStateOrProvince ||
- generalContactPostCode || generalContactCountry || generalContactVoiceTelephone ||
- generalContactFacsimileTelephone || generalContactElectronicMailAddress
- wmc += "\t\t<ContactInformation>\n";
- if (generalContactPerson || generalContactOrganization) {
- wmc += "\t\t\t<ContactPersonPrimary>\n";
- if (generalContactPerson) {
- wmc += "\t\t\t\t<ContactPerson>" + generalContactPerson + "</ContactPerson>\n";
- if (generalContactOrganization) {
- wmc += "\t\t\t\t<ContactOrganization>" + generalContactOrganization + "</ContactOrganization>\n";
- wmc += "\t\t\t</ContactPersonPrimary>\n";
- if (generalContactPosition) {
- wmc += "\t\t\t<ContactPosition>" + generalContactPosition + "</ContactPosition>\n";
- if (generalContactAddressType || generalContactAddress || generalContactCity || generalContactStateOrProvince ||
- generalContactPostCode || generalContactCountry) {
- wmc += "\t\t\t<ContactAddress>\n";
- if (generalContactAddressType) {
- wmc += "\t\t\t\t<AddressType>" + generalContactAddressType + "</AddressType>\n";
- if (generalContactAddress) {
- wmc += "\t\t\t\t<Address>" + generalContactAddress + "</Address>\n";
- if (generalContactCity) {
- wmc += "\t\t\t\t<City>" + generalContactCity + "</City>\n";
- if (generalContactStateOrProvince) {
- wmc += "\t\t\t\t<StateOrProvince>" + generalContactStateOrProvince + "</StateOrProvince>\n";
- if (generalContactPostCode) {
- wmc += "\t\t\t\t<PostCode>" + generalContactPostCode + "</PostCode>\n";
- if (generalContactCountry) {
- wmc += "\t\t\t\t<Country>" + generalContactCountry + "</Country>\n";
- wmc += "\t\t\t</ContactAddress>\n";
- wmc += "\t\t\t<ContactVoiceTelephone>" + generalContactVoiceTelephone + "</ContactVoiceTelephone>\n";
- wmc += "\t\t\t<ContactFacsimileTelephone>" + generalContactFacsimileTelephone + "</ContactFacsimileTelephone>\n";
- wmc += "\t\t\t<ContactElectronicMailAddress>" + generalContactElectronicMailAddress + "</ContactElectronicMailAddress>\n";
- wmc += "\t\t</ContactInformation>\n";
- wmc += "\t</General>\n";
- //layerList
- wmc += "\t<LayerList>\n";
- for (var i = 0; i < mb_mapObj[ind].wms.length; i++){
- // BEGIN: new code
- // in the end, this array contains all epsg´s of this wms
- var wms_epsg = new Array();
- // the gui_wms_epsg is always the first epsg in this layer´s epsg list
- wms_epsg[0] = mb_mapObj[ind].wms[i].gui_wms_epsg;
- // the epsg of the mapObj has to be in this list
- if (mb_mapObj[ind].wms[i].gui_wms_epsg != mb_mapObj[ind].epsg) {
- wms_epsg[1] = mb_mapObj[ind].epsg;
+ var user = "<?php echo $_SESSION["mb_user_id"]; ?>";
+ var ind = getMapObjIndexByName(mod_savewmc_target);
+ var generalTitle = prompt("Save WMC as...");
+ if (generalTitle != null){
+ var wmc = "";
+ // ViewContext variables
+ var version = "1.0.0";
+ var id = "<?php echo $_SESSION["mb_user_id"] . "_";?>";
+ var jetzt = new Date();
+ id += jetzt.getTime();
+ // General variables
+ var generalWidth = mb_mapObj[ind].width;
+ var generalHeight = mb_mapObj[ind].height;
+ var generalBboxSrs = mb_mapObj[ind].epsg;
+ var arrayBBox = mb_mapObj[ind].extent.split(",");
+ var generalBboxMinx = parseFloat(arrayBBox[0]);
+ var generalBboxMiny = parseFloat(arrayBBox[1]);
+ var generalBboxMaxx = parseFloat(arrayBBox[2]);
+ var generalBboxMaxy = parseFloat(arrayBBox[3]);
+ var generalName = "Mapbender WMC"; // TO do : insert proper data
+ var generalKeywords = ""; // TO do : insert proper data
+ var generalAbstract = ""; // TO do : insert proper data
+ var generalLogoUrl = ""; // TO do : insert proper data
+ var generalLogoUrlWidth = ""; // TO do : insert proper data
+ var generalLogoUrlHeight = ""; // TO do : insert proper data
+ var generalLogoUrlFormat = ""; // TO do : insert proper data
+ var generalDescriptionUrl = ""; // TO do : insert proper data
+ var generalContactPerson = "";
+ var generalContactOrganization = "";
+ var generalContactPosition = "";
+ var generalContactAddressType = "";
+ var generalContactAddress = "";
+ var generalContactCity = "";
+ var generalContactStateOrProvince = "";
+ var generalContactPostCode = "";
+ var generalContactCountry = "";
+ var generalContactVoiceTelephone = "";
+ var generalContactFacsimileTelephone = "";
+ var generalContactElectronicMailAddress = "";
+ // Missing: Extension
+ // LayerList variables
+ var layerHidden = "";
+ var layerQueryable = "";
+ var layerAbstract = "";
+ var layerName = "";
+ var layerSrs = "";
+ var layerDataUrl = "";
+ var layerMetadataUrl = "";
+ var layerFormat = "";
+ var layerFormat_current = "";
+ var layerStyle_current = "";
+ var layerStyle_name = "";
+ var layerStyle_title = "";
+ var layerStyle_legendURL = "";
+ var layerStyle_legendURL_width = "";
+ var layerStyle_legendURL_height = "";
+ var layerStyle_legendURL_format = "";
+ //ViewContext
+ wmc += "<?xml version=\"1.0\" encoding=\"<?php echo CHARSET; ?>\" ?>\n";
+ // wmc += "<!ENTITY amp \"&#38;#38;\">\n";
+ wmc += "<ViewContext version=\"" + version + "\" ";
+ wmc += "id = \"" + id + "\" ";
+ wmc += "xmlns=\"http://www.opengis.net/context\" xmlns:xlink=\"http://www.w3.org/1999/xlink\" xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:SchemaLocation=\"http://schemas.opengis.net/context/1.0.0/context.xsd\" ";
+ wmc += ">\n";
+ //General
+ wmc += "\t<General>\n";
+ if (generalWidth && generalHeight){
+ wmc += "\t\t<Window width=\"" + generalWidth + "\" height=\"" + generalHeight + "\" />\n";
+ wmc += "\t\t<BoundingBox SRS=\"" + generalBboxSrs + "\" minx =\"" + generalBboxMinx + "\" ";
+ wmc += "miny =\"" + generalBboxMiny + "\" maxx =\"" + generalBboxMaxx + "\" maxy =\"" + generalBboxMaxy + "\" />\n";
+ wmc += "\t\t<Name>" + generalName + "</Name>\n";
+ wmc += "\t\t<Title>" + generalTitle + "</Title>\n";
+ if (generalKeywords){
+ wmc += "\t\t<KeywordList>\n";
+ wmc += "\t\t\t<Keyword>" + generalKeywords + "</Keyword>\n";
+ if (generalAbstract){
+ wmc += "\t\t<Abstract>" + generalAbstract + "</Abstract>\n";
+ if (generalLogoUrlWidth && generalLogoUrlHeight && generalLogoUrlFormat && generalLogoUrl){
+ wmc += "\t\t<LogoURL width = \"" + generalLogoUrlWidth + "\" ";
+ wmc += "height = \"" + generalLogoUrlHeight + "\" ";
+ wmc += "format = \"" + generalLogoUrlFormat + "\">\n";
+ wmc += "\t\t\t<OnlineResource xmlns:xlink=\"http://www.w3.org/1999/xlink\" xlink:type = \"simple\" xlink:href=\"" + generalLogoUrl + "\" />\n";
+ wmc += "\t\t</LogoUrl>\n";
+ if (generalDescriptionUrl){
+ wmc += "\t\t<DescriptionURL>\n";
+ wmc += "\t\t\t<OnlineResource xmlns:xlink=\"http://www.w3.org/1999/xlink\" xlink:type = \"simple\" xlink:href=\"" + generalDescriptionUrl + "\" />\n";
+ wmc += "\t\t</DescriptionUrl>\n";
+ if (generalContactElectronicMailAddress || generalContactOrganization ||
+ generalContactPerson || generalContactPosition || generalContactAddressType ||
+ generalContactAddress || generalContactCity || generalContactStateOrProvince ||
+ generalContactPostCode || generalContactCountry || generalContactVoiceTelephone ||
+ generalContactFacsimileTelephone || generalContactElectronicMailAddress){
+ wmc += "\t\t<ContactInformation>\n";
+ if (generalContactPerson || generalContactOrganization){
+ wmc += "\t\t\t<ContactPersonPrimary>\n";
+ if (generalContactPerson){
+ wmc += "\t\t\t\t<ContactPerson>" + generalContactPerson + "</ContactPerson>\n";
+ if (generalContactOrganization){
+ wmc += "\t\t\t\t<ContactOrganization>" + generalContactOrganization + "</ContactOrganization>\n";
+ wmc += "\t\t\t</ContactPersonPrimary>\n";
+ if (generalContactPosition){
+ wmc += "\t\t\t<ContactPosition>" + generalContactPosition + "</ContactPosition>\n";
+ if (generalContactAddressType || generalContactAddress || generalContactCity || generalContactStateOrProvince ||
+ generalContactPostCode || generalContactCountry){
+ wmc += "\t\t\t<ContactAddress>\n";
+ if (generalContactAddressType){
+ wmc += "\t\t\t\t<AddressType>" + generalContactAddressType + "</AddressType>\n";
+ if (generalContactAddress){
+ wmc += "\t\t\t\t<Address>" + generalContactAddress + "</Address>\n";
+ if (generalContactCity){
+ wmc += "\t\t\t\t<City>" + generalContactCity + "</City>\n";
+ if (generalContactStateOrProvince){
+ wmc += "\t\t\t\t<StateOrProvince>" + generalContactStateOrProvince + "</StateOrProvince>\n";
+ if (generalContactPostCode){
+ wmc += "\t\t\t\t<PostCode>" + generalContactPostCode + "</PostCode>\n";
+ if (generalContactCountry){
+ wmc += "\t\t\t\t<Country>" + generalContactCountry + "</Country>\n";
+ wmc += "\t\t\t</ContactAddress>\n";
+ wmc += "\t\t\t<ContactVoiceTelephone>" + generalContactVoiceTelephone + "</ContactVoiceTelephone>\n";
+ wmc += "\t\t\t<ContactFacsimileTelephone>" + generalContactFacsimileTelephone + "</ContactFacsimileTelephone>\n";
+ wmc += "\t\t\t<ContactElectronicMailAddress>" + generalContactElectronicMailAddress + "</ContactElectronicMailAddress>\n";
+ wmc += "\t\t</ContactInformation>\n";
+ wmc += "\t</General>\n";
+ //layerList
+ wmc += "\t<LayerList>\n";
+ for (var i = 0; i < mb_mapObj[ind].wms.length; i++){
+ // BEGIN: new code
+ // in the end, this array contains all epsg´s of this wms
+ var wms_epsg = new Array();
+ // the gui_wms_epsg is always the first epsg in this layer´s epsg list
+ wms_epsg[0] = mb_mapObj[ind].wms[i].gui_wms_epsg;
+ // the epsg of the mapObj has to be in this list
+ if (mb_mapObj[ind].wms[i].gui_wms_epsg != mb_mapObj[ind].epsg){
+ wms_epsg[1] = mb_mapObj[ind].epsg;
- // add all gui_epsg if not already in the array
- for (q = 0; q < mb_mapObj[ind].wms[i].gui_epsg.length ; q ++) {
- var isInArray = false;
- for (r = 0 ; r < wms_epsg.length ; r ++) {
- if (wms_epsg[r] == mb_mapObj[ind].wms[i].gui_epsg[q]) {
- isInArray = true;
- if (isInArray == false) {
- wms_epsg[wms_epsg.length] = mb_mapObj[ind].wms[i].gui_epsg[q];
- // END: new code
- for (var j = 0; j < mb_mapObj[ind].wms[i].objLayer.length; j++) {
- if (mb_mapObj[ind].wms[i].objLayer[j].layer_parent != '') {
- if (mb_mapObj[ind].wms[i].objLayer[j].gui_layer_visible == '1') {
- layerHidden = 0;
- else {
- layerHidden = 1;
- layerQueryable = mb_mapObj[ind].wms[i].objLayer[j].layer_queryable;
- layerName = mb_mapObj[ind].wms[i].objLayer[j].layer_name;
- layerTitle = mb_mapObj[ind].wms[i].objLayer[j].layer_title;
- layerAbstract = mb_mapObj[ind].wms[i].wms_abstract; //To Do: insert actual abstract
- layerDataUrl = mb_mapObj[ind].wms[i].objLayer[j].layer_dataurl_href;
- //layerDataUrl = mb_mapObj[ind].wms[i].objLayer[j].layer_dataurl_href;
- layerMetadataUrl = mb_mapObj[ind].wms[i].objLayer[j].layer_metadataurl;
- //layerMetadataUrl = mb_mapObj[ind].wms[i].objLayer[j].layer_metadataurl;
- wmsVersion = mb_mapObj[ind].wms[i].wms_version;
- wmsTitle = mb_mapObj[ind].wms[i].wms_title;
- wmsOnlineResource = mb_mapObj[ind].wms[i].wms_getmap;
- //wmsOnlineResource = mb_mapObj[ind].wms[i].wms_getmap;
- wmc += "\t\t<Layer queryable = \"" + layerQueryable + "\" hidden = \"" + layerHidden + "\">\n";
- wmc += "\t\t\t<Server service = \"OGC:WMS\" version = \"" + wmsVersion + "\" title = \"" + wmsTitle + "\">\n";
- wmc += "\t\t\t\t<OnlineResource xmlns:xlink=\"http://www.w3.org/1999/xlink\" xlink:type=\"simple\" xlink:href=\"" + wmsOnlineResource + "\" />\n";
- wmc += "\t\t\t</Server>\n";
- wmc += "\t\t\t<Name>" + layerName + "</Name>\n";
- wmc += "\t\t\t<Title>" + layerTitle + "</Title>\n";
- if (layerAbstract) {
- wmc += "\t\t\t<Abstract>" + layerAbstract + "</Abstract>\n";
- wmc += "\t\t\t<SRS>";
- for (var k = 0; k < wms_epsg.length ; k ++) {
- wmc += wms_epsg[k];
- if (k < wms_epsg.length-1) {
- wmc += " ";
- wmc += "</SRS>\n";
- if (layerDataUrl) {
- wmc += "\t\t\t<DataURL>\n";
- wmc += "\t\t\t\t<OnlineResource xmlns:xlink=\"http://www.w3.org/1999/xlink\" xlink:type = \"simple\" xlink:href=\"" + layerDataUrl + "\" />\n";
- wmc += "\t\t\t</DataURL>\n";
- if (layerMetadataUrl) {
- wmc += "\t\t\t<MetadataURL>\n";
- wmc += "\t\t\t\t<OnlineResource xmlns:xlink=\"http://www.w3.org/1999/xlink\" xlink:type = \"simple\" xlink:href=\"" + layerMetadataUrl + "\" />\n";
- wmc += "\t\t\t</MetadataURL>\n";
- //layerFormat
- wmc += "\t\t\t<FormatList>\n";
- for (var k = 0; k < 1; k++) {
- if (k == 0) {
- layerFormat_current = 1; // To do: insert proper data
- else {
- layerFormat_current = 0; // To do: insert proper data
- layerFormat = mb_mapObj[ind].wms[i].gui_wms_mapformat;
- wmc += "\t\t\t\t<Format ";
- if (layerFormat_current == 1) {
- wmc += "current = \"1\"";
- wmc += ">" + layerFormat + "</Format>\n";
- wmc += "\t\t\t</FormatList>\n";
- // LayerStyle
- wmc += "\t\t\t<StyleList>\n";
- if (k == 0) {
- layerStyle_current = 1; // To do: insert proper data
- else {
- layerStyle_current = 0; // To do: insert proper data
- wmc += "\t\t\t\t<Style";
- layerStyleSLD = "";
- if (layerStyleSLD) {
- layerStyleSLDUrl = ""; // To Do: Insert Proper Data
- wmc += "\t\t\t\t\t\t<OnlineResource xmlns:xlink=\"http://www.w3.org/1999/xlink\" xlink:type=\"simple\" xlink:href=\"" + layerStyleSLDUrl + "\" />\n";
- else {
- if (mb_mapObj[ind].wms[i].objLayer[j].layer_style[k]) {
- layerStyle_name = mb_mapObj[ind].wms[i].objLayer[j].layer_style[k]['name'];
- layerStyle_title = mb_mapObj[ind].wms[i].objLayer[j].layer_style[k]['title'];
- layerStyle_legendUrl = mb_mapObj[ind].wms[i].objLayer[j].layer_style[k]["legendurl"];
- else {
- layerStyle_name = "default";
- layerStyle_title = "default";
- layerStyle_legendUrl = "";
- layerStyle_legendUrl_width = ""; // To Do: add proper data
- layerStyle_legendUrl_height = ""; // To Do: add proper data
- layerStyle_legendUrl_format = ""; // To Do: add proper data
-// layerStyle_legendUrl = stripAmpersand(mb_mapObj[ind].wms[i].wms_getlegendurl);
- if (layerStyle_current == 1) {
- wmc += " current = \"1\"";
- wmc += ">\n\t\t\t\t\t<Name>" + layerStyle_name + "</Name>\n";
- wmc += "\t\t\t\t\t<Title>" + layerStyle_title + "</Title>\n";
- wmc += "\t\t\t\t\t<LegendUrl ";
- wmc += "width = \"" + layerStyle_legendUrl_width + "\" ";
- wmc += "height = \"" + layerStyle_legendUrl_height + "\" ";
- wmc += "format = \"" + layerStyle_legendUrl_format + "\">\n";
- wmc += "\t\t\t\t\t\t<OnlineResource xmlns:xlink=\"http://www.w3.org/1999/xlink\" xlink:type=\"simple\" xlink:href=\"" + layerStyle_legendUrl + "\" />\n";
- wmc += "\t\t\t\t\t</LegendUrl>\n";
- wmc += "\t\t\t\t</Style>\n";
- // Missing: Describe Style via SLD (see: http://center.ccgis/phprojekt/addons/ewiki/index.php?id=links/SLD)
- wmc += "\t\t\t</StyleList>\n";
- wmc += "\t\t</Layer>\n";
- wmc += "\t</LayerList>\n";
- wmc += "</ViewContext>\n";
- //document.sendData.target = "_blank";
- document.sendData.action = "../javascripts/mod_insertWmcIntoDb.php";
- document.sendData.data.value = user + "____" + generalTitle + "____" + wmc + "____" + id;
- document.sendData.submit();
+ // add all gui_epsg if not already in the array
+ for (q = 0; q < mb_mapObj[ind].wms[i].gui_epsg.length ; q ++){
+ var isInArray = false;
+ for (r = 0 ; r < wms_epsg.length ; r ++){
+ if (wms_epsg[r] == mb_mapObj[ind].wms[i].gui_epsg[q]){
+ isInArray = true;
+ if (isInArray == false){
+ wms_epsg[wms_epsg.length] = mb_mapObj[ind].wms[i].gui_epsg[q];
+ // END: new code
+ for (var j = 0; j < mb_mapObj[ind].wms[i].objLayer.length; j++){
+ if (mb_mapObj[ind].wms[i].objLayer[j].layer_parent != ''){
+ if (mb_mapObj[ind].wms[i].objLayer[j].gui_layer_visible == '1'){
+ layerHidden = 0;
+ else{
+ layerHidden = 1;
+ layerQueryable = mb_mapObj[ind].wms[i].objLayer[j].layer_queryable;
+ layerName = mb_mapObj[ind].wms[i].objLayer[j].layer_name;
+ layerTitle = mb_mapObj[ind].wms[i].objLayer[j].layer_title;
+ layerAbstract = mb_mapObj[ind].wms[i].wms_abstract; //To Do: insert actual abstract
+ layerDataUrl = mb_mapObj[ind].wms[i].objLayer[j].layer_dataurl_href;
+ //layerDataUrl = mb_mapObj[ind].wms[i].objLayer[j].layer_dataurl_href;
+ layerMetadataUrl = mb_mapObj[ind].wms[i].objLayer[j].layer_metadataurl;
+ //layerMetadataUrl = mb_mapObj[ind].wms[i].objLayer[j].layer_metadataurl;
+ wmsVersion = mb_mapObj[ind].wms[i].wms_version;
+ wmsTitle = mb_mapObj[ind].wms[i].wms_title;
+ wmsOnlineResource = mb_mapObj[ind].wms[i].wms_getmap;
+ //wmsOnlineResource = mb_mapObj[ind].wms[i].wms_getmap;
+ wmc += "\t\t<Layer queryable = \"" + layerQueryable + "\" hidden = \"" + layerHidden + "\">\n";
+ wmc += "\t\t\t<Server service = \"OGC:WMS\" version = \"" + wmsVersion + "\" title = \"" + wmsTitle + "\">\n";
+ wmc += "\t\t\t\t<OnlineResource xmlns:xlink=\"http://www.w3.org/1999/xlink\" xlink:type=\"simple\" xlink:href=\"" + wmsOnlineResource + "\" />\n";
+ wmc += "\t\t\t</Server>\n";
+ wmc += "\t\t\t<Name>" + layerName + "</Name>\n";
+ wmc += "\t\t\t<Title>" + layerTitle + "</Title>\n";
+ if (layerAbstract){
+ wmc += "\t\t\t<Abstract>" + layerAbstract + "</Abstract>\n";
+ wmc += "\t\t\t<SRS>";
+ for (var k = 0; k < wms_epsg.length ; k ++){
+ wmc += wms_epsg[k];
+ if (k < wms_epsg.length-1){
+ wmc += " ";
+ wmc += "</SRS>\n";
+ if (layerDataUrl){
+ wmc += "\t\t\t<DataURL>\n";
+ wmc += "\t\t\t\t<OnlineResource xmlns:xlink=\"http://www.w3.org/1999/xlink\" xlink:type = \"simple\" xlink:href=\"" + layerDataUrl + "\" />\n";
+ wmc += "\t\t\t</DataURL>\n";
+ if (layerMetadataUrl){
+ wmc += "\t\t\t<MetadataURL>\n";
+ wmc += "\t\t\t\t<OnlineResource xmlns:xlink=\"http://www.w3.org/1999/xlink\" xlink:type = \"simple\" xlink:href=\"" + layerMetadataUrl + "\" />\n";
+ wmc += "\t\t\t</MetadataURL>\n";
+ //layerFormat
+ wmc += "\t\t\t<FormatList>\n";
+ for (var k = 0; k < 1; k++){
+ if (k == 0){
+ layerFormat_current = 1; // To do: insert proper data
+ else{
+ layerFormat_current = 0; // To do: insert proper data
+ layerFormat = mb_mapObj[ind].wms[i].gui_wms_mapformat;
+ wmc += "\t\t\t\t<Format ";
+ if (layerFormat_current == 1){
+ wmc += "current = \"1\"";
+ wmc += ">" + layerFormat + "</Format>\n";
+ wmc += "\t\t\t</FormatList>\n";
+ // LayerStyle
+ wmc += "\t\t\t<StyleList>\n";
+ if (k == 0){
+ layerStyle_current = 1; // To do: insert proper data
+ else{
+ layerStyle_current = 0; // To do: insert proper data
+ wmc += "\t\t\t\t<Style";
+ layerStyleSLD = "";
+ if (layerStyleSLD){
+ layerStyleSLDUrl = ""; // To Do: Insert Proper Data
+ wmc += "\t\t\t\t\t\t<OnlineResource xmlns:xlink=\"http://www.w3.org/1999/xlink\" xlink:type=\"simple\" xlink:href=\"" + layerStyleSLDUrl + "\" />\n";
+ else{
+ if (mb_mapObj[ind].wms[i].objLayer[j].layer_style[k]){
+ layerStyle_name = mb_mapObj[ind].wms[i].objLayer[j].layer_style[k]['name'];
+ layerStyle_title = mb_mapObj[ind].wms[i].objLayer[j].layer_style[k]['title'];
+ layerStyle_legendUrl = mb_mapObj[ind].wms[i].objLayer[j].layer_style[k]["legendurl"];
+ else{
+ layerStyle_name = "default";
+ layerStyle_title = "default";
+ layerStyle_legendUrl = "";
+ layerStyle_legendUrl_width = ""; // To Do: add proper data
+ layerStyle_legendUrl_height = ""; // To Do: add proper data
+ layerStyle_legendUrl_format = ""; // To Do: add proper data
+ //layerStyle_legendUrl = stripAmpersand(mb_mapObj[ind].wms[i].wms_getlegendurl);
+ if (layerStyle_current == 1){
+ wmc += " current = \"1\"";
+ wmc += ">\n\t\t\t\t\t<Name>" + layerStyle_name + "</Name>\n";
+ wmc += "\t\t\t\t\t<Title>" + layerStyle_title + "</Title>\n";
+ wmc += "\t\t\t\t\t<LegendUrl ";
+ wmc += "width = \"" + layerStyle_legendUrl_width + "\" ";
+ wmc += "height = \"" + layerStyle_legendUrl_height + "\" ";
+ wmc += "format = \"" + layerStyle_legendUrl_format + "\">\n";
+ wmc += "\t\t\t\t\t\t<OnlineResource xmlns:xlink=\"http://www.w3.org/1999/xlink\" xlink:type=\"simple\" xlink:href=\"" + layerStyle_legendUrl + "\" />\n";
+ wmc += "\t\t\t\t\t</LegendUrl>\n";
+ wmc += "\t\t\t\t</Style>\n";
+ // Missing: Describe Style via SLD (see: http://center.ccgis/phprojekt/addons/ewiki/index.php?id=links/SLD)
+ wmc += "\t\t\t</StyleList>\n";
+ wmc += "\t\t</Layer>\n";
+ wmc += "\t</LayerList>\n";
+ wmc += "</ViewContext>\n";
+ //document.sendData.target = "_blank";
+ document.sendData.action = "../javascripts/mod_insertWmcIntoDb.php";
+ document.sendData.data.value = user + "____" + generalTitle + "____" + wmc + "____" + id;
+ document.sendData.submit();
-function mod_savewmc_init(obj) {
- //document.getElementById("savewmc").src = mod_zoom1_img_over.src;
- //obj.onmouseover = new Function("mod_zoomIn1_over()");
- //obj.onmouseout = new Function("mod_zoomIn1_out()");
+function mod_savewmc_init(obj){
+ //document.getElementById("savewmc").src = mod_zoom1_img_over.src;
+ //obj.onmouseover = new Function("mod_zoomIn1_over()");
+ //obj.onmouseout = new Function("mod_zoomIn1_out()");
function mod_zoomIn1_over(){
- // document.getElementById("zoomIn1").src = mod_zoom1_img_over.src;
+ //document.getElementById("zoomIn1").src = mod_zoom1_img_over.src;
function mod_zoomIn1_out(){
- // document.getElementById("zoomIn1").src = mod_zoom1_img.src;
+ //document.getElementById("zoomIn1").src = mod_zoom1_img.src;
More information about the Mapbender_commits
