svn commit: r308 - trunk/mapbender/http/php/mod_renameGUI.php
uli at osgeo.org uli at osgeo.org
Tue May 16 06:11:18 EDT 2006
Author: uli
Date: 2006-05-16 10:11:17+0000
New Revision: 308
db_prep_query included
Modified: trunk/mapbender/http/php/mod_renameGUI.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_renameGUI.php?view=diff&rev=308&p1=trunk/mapbender/http/php/mod_renameGUI.php&p2=trunk/mapbender/http/php/mod_renameGUI.php&r1=307&r2=308
--- trunk/mapbender/http/php/mod_renameGUI.php	(original)
+++ trunk/mapbender/http/php/mod_renameGUI.php	2006-05-16 10:11:17+0000
@@ -18,11 +18,12 @@
 # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
 session_start();
-import_request_variables("PG");
-require_once("../php/mb_validateSession.php");
 require_once("../../conf/mapbender.conf");
-$con = db_connect($DBSERVER,$OWNER,$PW);
+$con = db_connect(DBSERVER,OWNER,PW);
 db_select_db(DB,$con);
+import_request_variables("PG");
+require_once("../php/mb_validateSession.php");
+$self = $PHP_SELF . "?".SID."&guiID=".$_REQUEST["guiID"]."&elementID=".$_REQUEST["elementID"];
 <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
@@ -80,78 +81,69 @@
 function validate_rename(){
-   if(document.form1.newGuiName.value == ""){
-      alert("Please enter a GUI name!");
-      document.form1.newGuiName.focus();
-   else{
-    // gui name already taken?
-    var taken = false;
-    for (var i=0; i<document.form1.guiList.options.length; i++){
-      if(document.form1.guiList.options[i].text == document.form1.newGuiName.value){
-        alert("GUI name already taken!");
-        taken = true;
-    if (!taken){
-      var ind = document.form1.guiList.selectedIndex;
-      // check if any gui is selected
-      if(ind > -1){
-        var permission =  confirm("rename '" + document.form1.guiList.options[ind].text + "' to '" + document.form1.newGuiName.value + "' ?");
-        if(permission == true){
-          document.form1.rename.value = 1;
-          document.form1.submit();
-      else
-        alert("Please select a GUI!");
+	if(document.form1.newGuiName.value == ""){
+		alert("Please enter a GUI name!");
+		document.form1.newGuiName.focus();
+	else{
+		// gui name already taken?
+		var taken = false;
+		for (var i=0; i<document.form1.guiList.options.length; i++){
+			if(document.form1.guiList.options[i].text == document.form1.newGuiName.value){
+				alert("GUI name already taken!");
+				taken = true;
+		if (!taken){
+			var ind = document.form1.guiList.selectedIndex;
+			// check if any gui is selected
+			if(ind > -1){
+				var permission =  confirm("rename '" + document.form1.guiList.options[ind].text + "' to '" + document.form1.newGuiName.value + "' ?");
+				if(permission == true){
+					document.form1.rename.value = 1;
+					document.form1.submit();
+			else{
+				alert("Please select a GUI!");
 function validate_copy(){
-   else{
-        taken = true;
-    if (!taken){
-      if(ind > -1){
-        var permission =  confirm("copy '" + document.form1.guiList.options[ind].text + "' to '" + document.form1.newGuiName.value + "' ?");
-          document.form1.copy.value = 1;
-      else
+	else{
+				taken = true;
+		if (!taken){
+			if(ind > -1){
+				var permission =  confirm("copy '" + document.form1.guiList.options[ind].text + "' to '" + document.form1.newGuiName.value + "' ?");
+					document.form1.copy.value = 1;
+			else{
 </script>
 </head>
 <body onLoad='document.form1.newGuiName.focus()'>
-<!--<form name='form1' action="<?php $PHP_SELF ?>" method="POST">-->
-<!--<form name='form1' action='" . $PHP_SELF . "?".SID."' method='post'>;-->
 <?php
 require_once("../classes/class_administration.php");
@@ -176,34 +168,35 @@
 $admin = new administration();
 $ownguis = $admin->getGuisByOwner($_SESSION["mb_user_id"]);
-echo "<form name='form1' action='" . $PHP_SELF . "?".SID."' method='post'>";
+echo "<form name='form1' action='" . $self ."' method='post'>";
 if(count($ownguis)>0){
-$sql = "SELECT * FROM gui WHERE gui_id IN (";
-for($i=0; $i<count($ownguis); $i++){
-				if($i>0){ $sql .= ",";}
-				$sql .= "'".$ownguis[$i]."'";
-$sql .= ") ORDER BY gui_name";
-$res = db_query($sql);
-$count=0;
-while($row = db_fetch_array($res)){
-	$gui_id[$count]=$row["gui_id"];
-	$count++;
+	$sql = "SELECT * FROM gui WHERE gui_id IN (";
+	$v = array();
+	$t = array();
+	for($i=0; $i<count($ownguis); $i++){
+		if($i>0){ $sql .= ",";}
+		$sql .= "$".($i+1);
+		array_push($v,$ownguis[$i]);
+		array_push($t,'s');
+	$sql .= ") ORDER BY gui_name";
+	$res = db_prep_query($sql,$v,$t);
+	$count=0;
+	while($row = db_fetch_array($res)){
+		$gui_id[$count]=$row["gui_id"];
+		$count++;
 	echo "<select class='guiList' size='20' name='guiList' onchange='document.form1.guiList.value = this.value;submit();'>";
 	for ($i=0; $i<$count;$i++){
-	  echo "<option value='".$gui_id[$i]."' ";
-	  if($guiList && $guiList == $gui_id[$i]){
-	    echo "selected";
-	  echo ">".$gui_id[$i]."</option>";
+		echo "<option value='".$gui_id[$i]."' ";
+		if($guiList && $guiList == $gui_id[$i]){
+			echo "selected";
+		echo ">".$gui_id[$i]."</option>";
 	echo "</select><br><br><br>";
-}else{
+else{
 	echo "There are no guis owned by this user.";
More information about the Mapbender_commits mailing list
