svn commit: r315 - trunk/mapbender/http/php/mod_editElementVars.php
    uli at osgeo.org
    uli at osgeo.org
    Tue May 16 08:45:55 EDT 2006
Author: uli
Date: 2006-05-16 12:45:54+0000
New Revision: 315
db_prep_query included
Modified: trunk/mapbender/http/php/mod_editElementVars.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_editElementVars.php?view=diff&rev=315&p1=trunk/mapbender/http/php/mod_editElementVars.php&p2=trunk/mapbender/http/php/mod_editElementVars.php&r1=314&r2=315
--- trunk/mapbender/http/php/mod_editElementVars.php	(original)
+++ trunk/mapbender/http/php/mod_editElementVars.php	2006-05-16 12:45:54+0000
@@ -114,20 +114,27 @@
 # handle database updates etc.....
-   if(isset($mySave) && ($mySave == '1')){
-      $sql  = "DELETE FROM gui_element_vars WHERE fkey_gui_id ='".$fkey_gui_id."' AND fkey_e_id ='".$fkey_e_id."' AND var_name ='".$var_name."';";
-      $res  = db_query($sql);
-      $sql  = "INSERT INTO gui_element_vars(fkey_gui_id,fkey_e_id,var_name,var_value,context,var_type) ";
-      $sql .= "VALUES ('".$fkey_gui_id."','".$fkey_e_id."','".$var_name."','".db_escape_string($var_value)."','".db_escape_string($context)."','".$var_type."');";
-      $mySave = 0;
+if(isset($mySave) && ($mySave == '1')){
+	$sql  = "DELETE FROM gui_element_vars WHERE fkey_gui_id = $1 AND fkey_e_id = $2 AND var_name = $3";
+	$v = array($fkey_gui_id,$fkey_e_id,$var_name);
+	$t = array('s','s','s');
+	$res = db_prep_query($sql,$v,$t);
+	$sql  = "INSERT INTO gui_element_vars(fkey_gui_id,fkey_e_id,var_name,var_value,context,var_type) ";
+	$sql .= "VALUES ($1, $2, $3, $4, $5, $6)";
+	//db_escape_string($var_value)?,db_escape_string($context)?
+	$v = array($fkey_gui_id,$fkey_e_id,$var_name,$var_value,$context,$var_type);
+	$t = array('s','s','s','s','s','s');
+	$mySave = 0;
-   if(isset($myDelete) && ($myDelete == '1')){
-      $myDelete = 0;
+if(isset($myDelete) && ($myDelete == '1')){
+	$myDelete = 0;
 <script type="text/javascript">
@@ -178,9 +185,11 @@
    echo "<input type='button' class='' name='' value='return' onclick=\"".$href."\"> \n";
    echo "</div>\n";
-   $sql = "SELECT * FROM gui_element_vars WHERE fkey_gui_id = '".$fkey_gui_id."' AND fkey_e_id = '".$fkey_e_id."';";
-   $cnt = 0;
+	$sql = "SELECT * FROM gui_element_vars WHERE fkey_gui_id = $1 AND fkey_e_id = $2";
+	$v = array($fkey_gui_id,$fkey_e_id);
+	$t = array('s','s');
+	$cnt = 0;
    echo "<div class='myElements'>\n<table>\n";
@@ -198,8 +207,10 @@
    echo "<table class='myForm'>\n";
    $formOk = 0;
    if(isset($myElement)){
-      $sql = "SELECT * FROM gui_element_vars WHERE fkey_gui_id = '".$fkey_gui_id."' AND fkey_e_id = '".$fkey_e_id."' AND var_name = '".$myElement."';";
+      $sql = "SELECT * FROM gui_element_vars WHERE fkey_gui_id = $1 AND fkey_e_id = $2 AND var_name = $3";
+      $v = array($fkey_gui_id,$fkey_e_id,$myElement);
       if(db_fetch_row($res)){
          echo "<tr><td>Name:</td><td><input type='text' class='textfield' name='var_name' value='".db_result($res,0,"var_name")."'></td></tr>\n";
          echo "<tr><td>Value:</td><td><textarea cols='32' rows='5'  name='var_value' >".stripslashes(db_result($res,0,"var_value"))."</textarea></td></tr>\n";
More information about the Mapbender_commits
