svn commit: r324 - trunk/mapbender/http/javascripts/wfs.js
vera_schulze at osgeo.org vera_schulze at osgeo.org
Thu May 18 08:14:06 EDT 2006
Author: vera_schulze
Date: 2006-05-18 12:14:06+0000
New Revision: 324
   trunk/mapbender/http/javascripts/wfs.js   (contents, props changed)
Code cleaning ready
Modified: trunk/mapbender/http/javascripts/wfs.js
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/wfs.js?view=diff&rev=324&p1=trunk/mapbender/http/javascripts/wfs.js&p2=trunk/mapbender/http/javascripts/wfs.js&r1=323&r2=324
--- trunk/mapbender/http/javascripts/wfs.js	(original)
+++ trunk/mapbender/http/javascripts/wfs.js	2006-05-18 12:14:06+0000
@@ -1,3 +1,21 @@
+// $Id$
+// http://www.mapbender.org/index.php/wfs.js
+// Copyright (C) 2002 CCGIS
+// This program is free software; you can redistribute it and/or modify
+// it under the terms of the GNU General Public License as published by
+// the Free Software Foundation; either version 2, or (at your option)
+// any later version.
+// This program is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+// GNU General Public License for more details.
+// You should have received a copy of the GNU General Public License
+// along with this program; if not, write to the Free Software
+// Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
 var digiFrame = "digitize";
 var mb_wfs_fetched = new Array();
 var	mb_wfs_fetch = new Array();
@@ -23,32 +41,29 @@
 var useCheckboxForHighlighting = true;
 var useUsemap = false;
-if (useCheckboxForHighlighting) {
+if (useCheckboxForHighlighting){
 	mb_registerSubFunctions('highlightGeometry()');
-if (useUsemap) {
+if (useUsemap){
 	mb_registerSubFunctions('mod_usemap("")');
 if (useExtentIsSet()) {
 	mb_registerSubFunctions("mb_setwfsrequest_extent()");
-function mb_setwfsrequest_extent() {
-	if (useExtentIsSet()) {
+function mb_setwfsrequest_extent(){
+	if (useExtentIsSet()){
 		var ind = getMapObjIndexByName(mb_wfs_targets[0]);
 		var pos_a = makeClickPos2RealWorldPos(mb_wfs_targets[0],0,0);
 		var pos_b = makeClickPos2RealWorldPos(mb_wfs_targets[0],mb_mapObj[ind].width,mb_mapObj[ind].height);
 		var x = new Array();
 		var y = new Array();
 		x[0] = pos_a[0];
 		x[1] = pos_b[0];
 		y[0] = pos_a[1];
 		y[1] = pos_b[1];
 		mb_setwfsrequest(mb_wfs_targets[0],'rectangle',x,y);
@@ -95,27 +110,27 @@
 			path += "&filter=";
 			var filter = '<ogc:Filter xmlns:ogc="http://ogc.org" xmlns:gml="http://www.opengis.net/gml">';
 			filter += "<Within>";
-				filter += '<ogc:PropertyName>';
-					for(var j=0; j<wfs_conf[w_[i]]['element'].length; j++){
-						if(wfs_conf[w_[i]]['element'][j]['f_geom'] == 1){
-							filter += wfs_conf[w_[i]]['element'][j]['element_name'];
-				filter += "</ogc:PropertyName>";
-				filter += '<gml:Polygon srsName="EPSG:4326">';
-					filter += '<gml:outerBoundaryIs>';
-						filter += '<gml:LinearRing>';
-							filter += '<gml:coordinates>';
-								for(var k=0; k<x.length; k++){
-									if(k>0){
-										filter += " ";
-									filter += x[k]+","+y[k];
-							filter += '</gml:coordinates>';
-						filter += '</gml:LinearRing>';
-					filter += '</gml:outerBoundaryIs>';
-				filter += '</gml:Polygon>';
+			filter += '<ogc:PropertyName>';
+			for(var j=0; j<wfs_conf[w_[i]]['element'].length; j++){
+				if(wfs_conf[w_[i]]['element'][j]['f_geom'] == 1){
+					filter += wfs_conf[w_[i]]['element'][j]['element_name'];
+			filter += "</ogc:PropertyName>";
+			filter += '<gml:Polygon srsName="EPSG:4326">';
+			filter += '<gml:outerBoundaryIs>';
+			filter += '<gml:LinearRing>';
+			filter += '<gml:coordinates>';
+			for(var k=0; k<x.length; k++){
+				if(k>0){
+					filter += " ";
+				filter += x[k]+","+y[k];
+			filter += '</gml:coordinates>';
+			filter += '</gml:LinearRing>';
+			filter += '</gml:outerBoundaryIs>';
+			filter += '</gml:Polygon>';
 			filter += '</Within>';
 			filter += '</ogc:Filter>';
 			path += filter;
@@ -135,16 +150,16 @@
 			filter += "<ogc:BBOX>";
 			filter += '<gml:Box srsName="4326"><gml:coordinates>';
-				filter += x[0]+","+y[0];
-				filter += " ";
-				filter += x[1]+","+y[1];
+			filter += x[0]+","+y[0];
+			filter += " ";
+			filter += x[1]+","+y[1];
 			filter += '</gml:coordinates></gml:Box></ogc:BBOX>';
 			path += filter;
@@ -157,8 +172,8 @@
 // --- usemap (begin) --------------------------------------------------------------------------------------------
-function mod_usemap (wfs_name) {
-	if (wfs_name == "") {
+function mod_usemap (wfs_name){
+	if (wfs_name == ""){
 		usemap = "";
@@ -166,14 +181,12 @@
 	myImg.width = mb_mapObj[ind].width;
 	myImg.height = mb_mapObj[ind].height;
-	for (var i = 0 ; i < mb_wfs_fetch.length ; i ++) {
-		if (mb_wfs_fetch[i]['wfs_conf'] == wfs_name || wfs_name == "") {
-			if (mb_wfs_fetch[i]['geomtype'] == "Polygon") {
+	for (var i = 0 ; i < mb_wfs_fetch.length ; i ++){
+		if (mb_wfs_fetch[i]['wfs_conf'] == wfs_name || wfs_name == ""){
+			if (mb_wfs_fetch[i]['geomtype'] == "Polygon"){
 				usemap += mod_usemap_polygon(i);
-			else if (mb_wfs_fetch[i]['geomtype'] == "Point") {
+			else if (mb_wfs_fetch[i]['geomtype'] == "Point"){
 				usemap += mod_usemap_circle(i);
 			else if (mb_wfs_fetch[i]['geomtype'] == "Line") {
@@ -187,23 +200,22 @@
 function mod_usemap_circle(ind){
 	var str = "";
 	var coord = "";
-	for (var i = 0 ; i < mb_wfs_fetch[ind]['geometry'].length ; i ++) {
+	for (var i = 0 ; i < mb_wfs_fetch[ind]['geometry'].length ; i ++){
 		var xArray = mb_wfs_fetch[ind]['geometry'][i]['x'];
 		var yArray = mb_wfs_fetch[ind]['geometry'][i]['y'];
 		var title = getElementValueByName(mb_wfs_fetch, ind, "name") + " (Pt)";
 		var pos = makeRealWorld2mapPos(mb_wfs_targets[0],xArray[0],yArray[0]);
 		coord += pos[0] + ", " + pos[1];
 		str += "<AREA  onmouseover='parent.mb_wfs_perform(\"over\",parent.mb_wfs_fetch["+ind+"])' ";
 		str += "onmouseout='parent.mb_wfs_perform(\"out\",parent.mb_wfs_fetch["+ind+"])' shape='circle'  coords='";
 		str += coord + ", " + mod_usemap_radius + "' href='#'>";
 	return str;
-function mod_usemap_line_calculate (xArray, yArray, j, orientation, cnt) {
+function mod_usemap_line_calculate (xArray, yArray, j, orientation, cnt){
 	var coord = "";
 	var p1 = makeRealWorld2mapPos(mb_wfs_targets[0],xArray[j],yArray[j]);
@@ -212,8 +224,8 @@
 	var vec = new Array();
 	vec[0] = p2[0] - p1[0];
 	vec[1] = p2[1] - p1[1];
-	if (vec[0] != 0 || vec[1] != 0) {
+	if (vec[0] != 0 || vec[1] != 0){
 		n_vec = new Array();
 		if (vec[0] != 0) {
 			if (vec[0] > 0) {
@@ -225,8 +237,8 @@
 				n_vec[1] = 1;
-		else {
-			if (vec[1] > 0) {
+		else{
+			if (vec[1] > 0){
 				n_vec[0] = 1;
 				n_vec[1] = 0;
@@ -244,19 +256,18 @@
 		lp[0] = p1[0] + n_vec[0];
 		lp[1] = p1[1] - n_vec[1];
-		if (cnt > 0) {
+		if (cnt > 0){
 			coord += ", ";
 		coord += parseInt(lp[0]) + ", " + parseInt(lp[1]);
-		coord += ", " + parseInt(lp[0]+vec[0]) + ", " + parseInt(lp[1]+vec[1]);
+		coord += ", " + parseInt(lp[0]+vec[0]) + ", " + parseInt(lp[1]+vec[1]);
 	return coord;
 function mod_usemap_line(ind){
 	var str = "";
 		var coord = "";
 		var cnt = 0;
@@ -264,25 +275,22 @@
 		yArray = new Array();
-		for (var j = 0 ; j < xArray.length - 1  ; j ++) {
+		for (var j = 0 ; j < xArray.length - 1  ; j ++){
 			var result = mod_usemap_line_calculate(xArray, yArray, j, 1, cnt);
 			if (result != "") {
 				coord += result;
 				cnt++;
-		for (var j = (xArray.length - 1) ; j > 0 ; j--) {
+		for (var j = (xArray.length - 1) ; j > 0 ; j--){
 			var result = mod_usemap_line_calculate(xArray, yArray, j, -1, cnt);
-			if (result != "") {
+			if (result != ""){
 				coord += result;
 				cnt++;
-		if (coord != "") {
+		if (coord != ""){
 			str += "<AREA ";
 			str += "onmouseover='parent.mb_wfs_perform(\"over\",parent.mb_wfs_fetch["+ind+"])' ";
 			str += "onmouseout='parent.mb_wfs_perform(\"out\",parent.mb_wfs_fetch["+ind+"])' ";
@@ -293,51 +301,48 @@
 			//display circle
 	return str;
 function mod_usemap_polygon(ind){
 	var str = "";
 	var coord = "";
 		var title = getElementValueByName(mb_wfs_fetch, ind, "name") + " (Py)";
-		for (var j = 1 ; j < xArray.length ; j ++) {
+		for (var j = 1 ; j < xArray.length ; j ++){
 			pos = makeRealWorld2mapPos(mb_wfs_targets[0],xArray[j],yArray[j]);
 			coord += ", " + pos[0] + ", " + pos[1];
 		str += "onmouseout='parent.mb_wfs_perform(\"out\",parent.mb_wfs_fetch["+ind+"])' shape='poly'  coords='";
 		str += coord + "' href='#'>";
 	return str;
-function writeUsemap(str) {
+function writeUsemap(str){
 	writeTag(mb_wfs_targets[0], 'um', str);
 // --- usemap (end) ----------------------------------------------------------------------------------------------
-function mb_repaint() {
-	for (var i = 0 ; i < mb_wfs_targets.length ; i ++) {
+function mb_repaint(){
+	for (var i = 0 ; i < mb_wfs_targets.length ; i ++){
 		mf = mb_wfs_targets[i];
-		if (canvas[mf]) {
+		if (canvas[mf]){
 			canvas[mf].paint();
@@ -353,10 +358,7 @@
 	tmp.style.visibility = 'hidden';
-// x- and y- coordinates are put in different arrays, the old arrays are being deleted
-function rearrangeXY (cnt) {
+function rearrangeXY (cnt){
 	for(var j=0; j<mb_wfs_fetch[cnt]['geometry'].length; j++){
 		var g = mb_wfs_sortXY(mb_wfs_fetch[cnt]['geometry'][j]);
 		mb_wfs_fetch[cnt]['geometry'][j] = new Array();
@@ -369,7 +371,7 @@
 	var tmp = n.split("_");
 	var current_wfs_name = tmp[3];
 	var wfs_conf = window.frames["wfs_conf"].get_wfs_conf();
-//	alert("response from " + wfs_conf[tmp[3]]['wfs_conf_abstract']);
+	//	alert("response from " + wfs_conf[tmp[3]]['wfs_conf_abstract']);
 	if(a && a.length){
 		var str = n + ": \n";
 		for(var i=0; i<a.length; i++){
@@ -378,16 +380,16 @@
 			var wfs_tmp = wfs_conf[current_wfs_name]['featuretype_srs'] + " - " + mb_mapObj[ind].epsg;
-			if (wfs_conf[current_wfs_name]['featuretype_srs'] == mb_mapObj[ind].epsg) {
+			if (wfs_conf[current_wfs_name]['featuretype_srs'] == mb_mapObj[ind].epsg){
 				mb_wfs_fetch[cnt] = a[i];
 				mb_wfs_fetch[cnt]['wfs_conf'] = current_wfs_name;
 				rearrangeXY(cnt);
 				var check = mb_wfs_cntBasePoint(mb_wfs_fetch[cnt]['geometry']);
 				if(check == false){
 					var newGeom = mb_wfs_getBBOX(mb_wfs_fetch[cnt]['geometry']);
 					mb_wfs_fetch[cnt]['geometry'] = new Array();
 					mb_wfs_fetch[cnt]['geometry'][0] = new Array();
 					mb_wfs_fetch[cnt]['geometry'][0]['x'] = new Array();
@@ -407,64 +409,59 @@
 			else {
 				alert("EPSG mismatch. Invalid WFS result. Press OK to continue.");
 		checkMbWfsFetch();
 	mb_wfs_listMember(current_wfs_name);
-// checks if the mb_wfs_fetch array is valid. If not, a pop up window will display the error(s).
-function checkMbWfsFetch() {
+function checkMbWfsFetch(){
 	var error = "";
-	for (var i = 0 ; i < mb_wfs_fetch.length ; i++) {
+	for (var i = 0 ; i < mb_wfs_fetch.length ; i++){
 		error += checkWfsObj(i);
-	if (error) {
+	if (error){
 		var wfsWindow = open("about:blank", "wfsattributes", "width=300, height=300, resizable, dependent=yes, scrollbars=yes");
 		wfsWindow.document.open("text/html");
 		wfsWindow.document.write("An error occured:<br><hr>" + error);
 		wfsWindow.document.close();
-// checks if a wfs object at index index is valid. if not, alerts will be displayed
-function checkWfsObj (index) {
+function checkWfsObj (index){
 	var obj = mb_wfs_fetch[index];
 	var geometry = false;
 	var element = false;
 	var geomtype = false;
 	var wfs_conf = false;
 	var error = "";
-	for (attr in obj) {
-		if (attr == "geometry") {
+	for (attr in obj){
+		if (attr == "geometry"){
 			geometry = true;
 			var objGeom = obj['geometry'];
 			var objGeomLength = objGeom.length;
-			if (objGeomLength == 0) {
+			if (objGeomLength == 0){
 				error += "object " + index + " doesn't contain any geometries.<br>";
 			else {
-				for (var i = 0 ; i < objGeomLength ; i ++) {
+				for (var i = 0 ; i < objGeomLength ; i ++){
 					var objGeomAtIndex = objGeom[i];
 					var x = false;
 					var y = false;
-					for (attrib in objGeomAtIndex) {
-						if (attrib == "x") {
+					for (attrib in objGeomAtIndex){
+						if (attrib == "x"){
 							x = true;
-						else if (attrib == "y") {
+						else if (attrib == "y"){
 							y = true;
 						else {
 							error += "object " + index + ": unknown geometry attribute: " + attrib + ".<br>";
-					if (x == true && y == true) {
-						if (objGeomAtIndex['x'].length != objGeomAtIndex['y'].length || objGeomAtIndex['x'].length == 0) {
+					if (x == true && y == true){
+						if (objGeomAtIndex['x'].length != objGeomAtIndex['y'].length || objGeomAtIndex['x'].length == 0){
 							error += "object " + index + " has an invalid geometry.<br>";
@@ -474,60 +471,58 @@
-		else if (attr == "element") {
+		else if (attr == "element"){
 			elements = true;
 			var objElem = obj['element'];
 			var objElemLength = objElem.length;
-			for (var i = 0 ; i < objElemLength ; i ++) {
+			for (var i = 0 ; i < objElemLength ; i ++){
 				var objElemAtIndex = objElem[i];
 				var elemName = false;
 				var elemVal = false;
-				for (attrib in objElemAtIndex) {
-					if (attrib == "name") {
+				for (attrib in objElemAtIndex){
+					if (attrib == "name"){
 						elemName = true;
-					else if (attrib == "val") {
+					else if (attrib == "val"){
 						elemVal = true;
 					else {
 						error += "object " + index + ": unknown element attributes: " + attrib + ".<br>";
-				if (elemName != true || elemVal != true) {
+				if (elemName != true || elemVal != true){
 					error += "object " + index + ": missing object attributes.<br>";
 				else {
-					if (objElemAtIndex['name'] == "name") {
-						if (!objElemAtIndex['val']) {
+					if (objElemAtIndex['name'] == "name"){
+						if (!objElemAtIndex['val']){
 							error += "object " + index + " doesn't have a name.<br>";
-		else if (attr == "geomtype") {
+		else if (attr == "geomtype"){
 			geomtype = true;
-			if (obj['geomtype'] != "Point" && obj['geomtype'] != "Line" && obj['geomtype'] != "Polygon") {
+			if (obj['geomtype'] != "Point" && obj['geomtype'] != "Line" && obj['geomtype'] != "Polygon"){
 				error += "object " + index + ": wrong geometry type.<br>";
-		else if (attr == "wfs_conf") {
+		else if (attr == "wfs_conf"){
 			wfs_conf = true;
-			if (!obj['wfs_conf']) {
+			if (!obj['wfs_conf']){
 				error += "object " + index + ": no wfs conf.<br>";
 		else {
 			error += "object " + index + ": unknown attribute: " + attr + ".<br>";
-	if (geometry == false || geomtype == false || elements == false) {
+	if (geometry == false || geomtype == false || elements == false){
 		error += "object " + index + " is corrupted.<br>";
-	if (error) {
+	if (error){
 		error += displayObject(mb_wfs_fetch[index]);
 		error += "<hr>";
@@ -559,18 +554,14 @@
 	return true;
-// displays an object
-function displayObject (someArray) {
+function displayObject(someArray){
 	var a = someArray;
 	var str = "";
-	for (attr in a) {
+	for (attr in a){
 		b = a[attr];
-		if (typeof(b) == "object") {
+		if (typeof(b) == "object"){
 			str += "<br>[" + attr + "]<br>";
 			str += displayObject(b);
@@ -581,13 +572,10 @@
 	return str;
-// returns an element value by name
-function getElementValueByName(member, memberIndex, elementName) {
+function getElementValueByName(member, memberIndex, elementName){
 	var arrayLength = member[memberIndex]['element'].length;
 	for (var j = 0 ; j < arrayLength ; j++) {
-		if (member[memberIndex]['element'][j]['name'] == elementName) {
+		if (member[memberIndex]['element'][j]['name'] == elementName){
 			return member[memberIndex]['element'][j]['val'];
@@ -600,22 +588,19 @@
 	var str = "<table>";
 	for(var i=0; i<mb_wfs_fetch.length; i++){
 		var t = wfs_conf[mb_wfs_fetch[i]['wfs_conf']];
-//		str += t['g_label']+ ": <br>";
+		// str += t['g_label']+ ": <br>";
 		for(var j=0; j<t['element'].length; j++){
 			if(t['element'][j]['f_show'] > 0){
 				for(var k=0; k<mb_wfs_fetch[i]['element'].length; k++){
 					if(t['element'][j]['element_name'] == mb_wfs_fetch[i]['element'][k]['name']){
 						//str += mb_wfs_fetch[i]['element'][k]['name'] + ": ";
 						str += "<tr><td><img src = '../img/wfs_digitize.png' onClick = 'tab_open(digiFrame);parent.window.frames[digiFrame].addMember(mb_wfs_fetch["+i+"])'></td>";
 						str += "<td>";
-						if (useCheckboxForHighlighting) {
+						if (useCheckboxForHighlighting){
 							str += "<input type=checkbox id=highlightCheckbox" + i + " onClick='highlightGeometry()'></td><td>";
 						str += "<div";
-						if (!useCheckboxForHighlighting) {
+						if (!useCheckboxForHighlighting){
 							str += " onmouseover='mb_wfs_perform(\"over\",mb_wfs_fetch["+i+"])' ";
 							str += " onmouseout='mb_wfs_perform(\"out\",mb_wfs_fetch["+i+"])' ";
@@ -628,23 +613,22 @@
 	str += "</table>";
 	mb_wfs_objwin.innerHTML = str;
-	if (useUsemap) {
+	if (useUsemap){
 		mod_usemap(wfs_name);
-function highlightGeometry() {
+function highlightGeometry(){
 	var l = mb_wfs_fetch.length;
-//	if (l > 0) {
-		mb_wfs_wzClean();
-		mb_wfs_checkTag();
-	for (var i = 0; i < l ; i++) {
+	//	if (l > 0){
+	mb_wfs_wzClean();
+	mb_wfs_checkTag();
+	for (var i = 0; i < l ; i++){
 		var id = "highlightCheckbox"+i;
 		var cb = document.getElementById(id);
-		if (cb) {
-			if (cb.checked) {
+		if (cb){
+			if (cb.checked){
 				mb_wfs_draw(mb_wfs_fetch[i]);
@@ -652,12 +636,12 @@
 	mb_repaint();
-function get_wfs_conf(index) {
+function get_wfs_conf(index){
 	return wfs_conf[index];
-function get_complete_wfs_conf() {
+function get_complete_wfs_conf(){
 	return wfs_conf;
@@ -670,7 +654,7 @@
 		mb_repaint();
 	if(type=='out'){
 			highlightGeometry();
 		else {
@@ -683,11 +667,12 @@
 		var b = parseFloat(wfs_conf[m['wfs_conf']]['g_buffer']);
 		mb_calculateExtent(mb_wfs_targets[0],parseFloat(tmp[0])-b,parseFloat(tmp[1])-b,parseFloat(tmp[2])+b,parseFloat(tmp[3])+b);
 		zoom(mb_wfs_targets[0], 'true', 1.0);
 			mb_wfs_draw(m);
 function mb_wfs_cntBasePoint(g){
 	var c = 0;
 	for(var i=0; i<g.length;i++){
@@ -700,6 +685,7 @@
 		return false;
 function mb_wfs_getBBOX(g){
 	var tmp_x = new Array();
 	var tmp_y = new Array();
@@ -708,27 +694,26 @@
 		tmp_x = tmp_x.concat(g[i]['x']);
 		tmp_y = tmp_y.concat(g[i]['y']);
 	var min_x = parseFloat(tmp_x[0]);
 	var min_y = parseFloat(tmp_y[0]);
 	var max_x = parseFloat(tmp_x[0]);
 	var max_y = parseFloat(tmp_y[0]);
 	var x,y;
 	for(var i=1; i<tmp_x.length; i++){
 		x = parseFloat(tmp_x[i]);
 		y = parseFloat(tmp_y[i]);
-		if (x < min_x) {
+		if (x < min_x){
 			min_x = x;
-		else if (x > max_x) {
+		else if (x > max_x){
 			max_x = x;
-		if (y < min_y) {
+		if (y < min_y){
 			min_y = y;
-		else if (y > max_y) {
+		else if (y > max_y){
 			max_y = y;
@@ -807,7 +792,7 @@
 			var apos = mb_wfs_toPix(mf,g[i]);
 			canvas[mf].setColor(mb_wfs_lineColor);
 			canvas[mf].drawPolyline(apos[0],apos[1]);
 	else if(t=='Polygon'){
 		for(var i=0; i<g.length; i++){
More information about the Mapbender_commits mailing list
